Multi part printing with different print setting Slic3r PE
Is it possible print multi parts same time with different print setting with Slic3r PE? If its possible how it can proceed?
Napsal : 11/07/2018 10:09 am
Re: Multi part printing with different print setting Slic3r PE
I believe you can use variable layer height on different models on the same build plate.
And
You can use mesh modifiers to change print parameters in different areas of a model on the build plate. Within slic3r
Regards Joan
Napsal : 11/07/2018 12:46 pm
Topic starter
answered:
I assume that I cannot change print temperature, like do temp tower with these settings?
Napsal : 11/07/2018 1:32 pm
