Module keeps falling over
Madmardigan
(@madmardigan)
Hello all,
I am new into the printing game and am having troubles with finishing a wall for a miniatures building. It knocks over the with 27% left and I don't know what to do. Please help?
Publié : 12/07/2019 3:55 am
RE: Module keeps falling over
If it's falling over, you're most likely to have adhesion issues. The print comes loose during the print. This is common starting out and can be caused or aggravated by two factors that need to work together well for successful prints. Here's mama's tried and true copypasta recipe to get you going...
You are having bed adhesion issues. PLA should lay down cleanly on the PEI print surface and hold throughout the print. There are 2 main causes of bed adhesion issues. Even if you're dubious that these are the cause of your problems, they're 2 fundamental troubleshooting steps that you need to complete to rule out the basics:
  • A dirty PEI print surface. Even if you don't think this is the cause, it's always a good idea to make sure your PEI surface is clean before trying any other fixes. If it's a smooth PEI sheet, take it to the kitchen sink and give it a good dunk with Dawn (original formula, no vinegar or hand softener variants) dishwashing soap or your local equivalent (e.g. Fairy in UK). Use a clean paper towel to clean it off, and another to dry it. Avoid using any sponge or cloth that has been in contact with grease. Above all else, avoid touching the PEI print surface. Once it's good and clean, you should be able to use 91%+ isopropyl alcohol between prints, 100% acetone when that fails , and another dunk when acetone fails. Worst-case, use a 3M 7445 ScotchBrite pad or equivalent on smooth PEI to give it a very light buff, but only infrequently. If you've got a textured powder-coated PEI print surface, the official instructions are to use 91%+ isopropyl alcohol on it only. Rumors persist that some tribes deep in the jungle have had good luck getting started with these sheets by giving them a wipe with 100% acetone and a dunk with Dawn. No intrepid explorers have survived the journey to confirm whether this is true or not. YMMV.
  • If you have not already done so, try using Jeff Jordan's "Life Adjust" procedure for calibrating your Live-Z setting. It is much easier to use and understand than the on-board routine. In general, start high (less negative) and work lower (more negative) in large increments (e.g. 0.1mm) until the filament starts to stick on its own. When it's right, you should be able to gently rub it without it coming loose. Then start lowering (more negative) the level until there are no gaps between layers. When you've got your Live-Z setting adjusted properly, you should be able to gently rub the extruded lines without dislodging them.
And above all else, avoid touching the PEI print surface.
Try those 2 steps. If you're uncertain of the Live-Z results, post pics here of the 75x75 print bottom and you'll get quick help. If you want more detail, I've consolidated my notes on Prusa PEI adhesion, bed cleaning, and Live-Z calibration. I've done a brain dump on nozzle sizes as well.
Publié : 12/07/2019 4:25 am
1 personnes ont aimé
Dave Avery
(@dave-avery)
also  I can't tell the dimensions of those parts but you might need to print them on a small raft
Publié : 12/07/2019 4:34 am
Madmardigan
(@madmardigan)
Thank you for the help
Publié : 12/07/2019 4:56 am
Peter M
(@peter-m)
Clean bed,
make a big brim attacht to model.
glue stick,
make extra wall(small) attach to model in different direction then model.
And the length of model, set this in the y direction of the printer.
Ce message a été modifié il y a 7 years 2 fois par Peter M
Publié : 13/07/2019 9:32 am
