Mk3s+ Replacement Part GCode or STL
I have MK3s+ and would like to reprint the X-ends (both). Can I use the gcode that Prusa offers for the mk3s to + upgrade or would it be better to slice the STL's myself?
Thank you
Respondido : 19/01/2021 4:32 pm
RE: Mk3s+ Replacement Part GCode or STL
My opinion, it's always better to slice your own, If your interested in the settings that Prusa used you can load the .gcode and see the settings and make any adjustments you need for your personal printer and filament. that's how I do it.
Good Luck
The Filament Whisperer
Respondido : 20/01/2021 3:59 am
There shouldn't be any issues using the Gcode either. There are no Gcode changes between the models that I know of.
Respondido : 21/01/2021 4:17 pm
