MK3S abl problem
Hi, I have a problem with abl. It just doesn't work because I don't see any reaction on the Z-axis. Of course, there is no problem with small prints, it prints correctly. But as the print covers almost the entire bed, the problem begins. I have CR10S on Klipper and despite the larger bed prints are perfect. I levelled the bed to 0.05 mm which should be enough for correct prints, but none of that. I hesitate to use Klipper on original MK3S, but 2 days of searching the web did nothing. What else will I see here, maybe someone solved this problem?
Publié : 14/04/2020 6:15 pm
