Mixed print with PETG and TPU
micha.p
(@micha-p)
I want to print a case for my mobile. The back should be PETG and the sides in TPU. I want to print it in one go, rather than glueing it together.
Adding a color change does not allow me to change the setting for different filament type. The filament type and thus all settings associated to it seem to be global for a print.
Can I get this to work somehow?
Thanks
Mike
MK3S+, no MMU
Napsal : 26/07/2024 9:35 pm
micha.p
(@micha-p)
RE: Mixed print with PETG and TPU
After doing more research, it seems there is no easy way to mix different base types of filament in one print .
I had a look at the G-code and maybe it would be possible to manipulate the code to change the printer settings mids print while changing the filament .
But I wish there was an easier way. Material compounds are base to good product design and would be great to be able to print easily.
I am tempted to issue a change request.
Maybe someone can explain upfront, why it is either already achievable or extremely complicated to implement, so it is not worthwhile writing a CR.
Thanks
Mike
Napsal : 29/07/2024 3:51 pm
With an XL it's straightforward, with an MMU it's doable but tricky...
If you only have a Mk3 it's *just* possible but a huge chore ... the basic method is in these two threads:
https://forum.prusa3d.com/forum/prusaslicer/manual-multicolor/
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/acting-as-my-own-mmu
Napsal : 29/07/2024 4:53 pm
