Missing layer when slicing in Prusa Slicer
Melic
(@melic)
Hello everyone, anybody know why a model with no detected errors is missing layer lines when it is being sliced ?
I added an image (ObjectWithoutErrors.png) of the loaded model in Prusa Slicer so you can see there is no errors and two others (MissingLayers1.png, MissingLayers1b.png) that show the problem/missing layer lines.
Anyone know why it is doing that ? I tried to repair the model in different tools even if it had no errors but the problem persist. I also tried to change some settings in the slicer to see if it would disappear but nothing changes.
This "bug" is the reason that the toad teeth don't print without problems, the printer is printing in the air because of this bug :-/.
Thank you for your help and have a nice day !
Posted : 20/09/2024 5:57 am
Robin
(@robin)
RE: Missing layer when slicing in Prusa Slicer
Save, zip and post the slicer project, so people can see what's up.
Posted : 23/09/2024 12:07 pm
As Robin says we would need the saved project file to be certain.  However the default slicing option of arachne has problems with geo like cones which those teeth look like.  The default settings are 'good for most' and not expected to work for ALL.
Changing to Classic usually works or changing some of the arachne settings can also work, but is all geometry dependent.
Posted : 23/09/2024 12:48 pm
