Messerschmitt Bf 109 H/F by 3DLabPrint Slicing Issue
huskyte
(@huskyte)
Hi there,
I just purchased the above file (Messerschmitt Bf 109 H/F, Messerschmitt Bf 109 H/F $20.00 ) of https://3dlabprint.com.
Something like this was once bundled with the Prusa Drivers, but I liked the Messerschmitt. Having a look at it, I have to admit that I am not abler to slice it properly. Neither with PrusaSlicer (which isn't mentioned in their advertising), nor with Cura (which is supported by them). The inner structure seems too fine to be sliced. I know that their must be successfully sliced models out there. Any hint on what the settings are? I am mostly interested in PrusaSlicer in combination with a MK3s MMU2s, but any other hints will help.
I also contacted their support, but no answer (it is weekend) so far.
Opublikowany : 22/12/2019 4:11 pm
towlerg
(@towlerg)
RE: Messerschmitt Bf 109 H/F by 3DLabPrint Slicing Issue
Doesn't this site provide Gcode?
Opublikowany : 22/12/2019 6:03 pm
huskyte
(@huskyte)
Yes, right, but only for something like PLA.
I just had contact with support who advised for a print in PLA. I'll give it a try. The gcode should work with filament preloaded to the nozzle (even on my MMU2s's).
Opublikowany : 22/12/2019 6:08 pm
