Looking for soft flex filament
ga
 ga
(@ga)
I'm trying to print a plug that goes in the back of a replaceable ink cartridge for an Epson 3880 printer.  I have some Matterhackers FLEX filament which I've used for other things, so I printed one using that.  Unfortunately, the material is a little too stiff to seal well, at least for a cartridge with PiezoFlush in it.  Does anyone have suggestions for a soft, silicone-like filament?
Opublikowany : 30/12/2025 4:04 am
Not one printable on a Mk3 ...  but you have another option.
Use the part file you have as a negative to make a mould:
Design a block, perhaps in two parts, and subtract (difference) your part from the block to make a void into which you can pour two-part or low temperature setting silicone of the desired softness.  You may need to tweak tolerances to account for thermal contraction as the part cools and you may need a coat of separator to prevent the part sticking to the mould.
Opublikowany : 30/12/2025 9:17 am
1 ludzie polubili
ga
 ga
(@ga)
RE: Looking for soft flex filament
Thanks, may try that.  It's kinda small so not sure how easy it will be to inject the silicone.  Need to use a syringe most likely, so I guess I need both a hole for injection and a hole for air to come out.
Opublikowany : 30/12/2025 7:19 pm
