[Gelöst] Little piece do not stick to raft
kankan
(@kankan)
Hello
I am printing some little figurine but facing some troubles with first layers :
As you can see on the two following pictures, the first elements of the object do not stick : i have try with and without raft.
I would like to try again with raft support but do not know where to set option so that first layer of object stik to the draft
Please can you help ?
Thank you
Veröffentlicht : 30/11/2025 9:26 pm
Collin
(@collin)
RE: Little piece do not stick to raft
Maybe bump your temperature up and/or adjust your nozzle lower.  Satin sheet works wonders for small parts if you have one - it's the only one I use anymore
Veröffentlicht : 09/12/2025 6:23 pm
kankan
(@kankan)
Hi Collin
Thanks for help.
I recalibrated first layer and added more support layers via Prusa and it went ok !
What is Satin sheet  ? 🙂
Veröffentlicht : 09/12/2025 6:44 pm
Collin
(@collin)
I realize now you are working with a MK2(s), sorry for the confusion on my part!  I'm glad you got it figured out
Veröffentlicht : 10/12/2025 7:07 pm
