Line in print from variable layer?
Question... so still very new to 3d printing. I started to experiment with layer changes. I believe that is what this line is on my print. Going from 0.15 to 0.10 for the "floor" section so it would look better. I'm using the Prusa slicer. I now realize there is a "smooth" feature I can use to move between layer heights, and will use it next time. Just want to confirm that is what that line probably is. Thanks!
Can't tell from the picture. If you posted a zipped .3mf file with the model and your settings, you could get better advice. But if the line is where you're changing layer height, sure, that may be it. But honestly, I wouldn't expect to see any serious difference between 0.15 and 0.1 mm. In fact, a model like this I'd print at 0.2mm, and I'm sure it would be perfectly pretty.
RE: Line in print from variable layer?
Thanks for the reply. Gah I posted this in the wrong forum. I have an MK3S+. But anyway here is the .3mg zipped up.
Lowering the layer to .10 on the "floor" section so far has made the stones look better. But yeah maybe overall it could be .20 instead of .10? I'm still learning and experimenting. Thanks.
You should be in the correct forum now!
