Layer Gaps
Ypkwok
(@ypkwok)
Layer Gaps
I did a visual cube calibration which shows a good top solid layer with no gaps..  However, when I print finer detail I have gaps on the top layer. I set 5 layers of top layer and I have no solution for it.  I do not have detect thin layer wall turn on. Can anyone help me figure out what is going on?   Thank you!
Posted : 05/07/2020 7:05 pm
Peter M
(@peter-m)
RE: Layer Gaps
Give as much info you know, we know nothing of what you are doing?
I would try to print hotter,(then more filament will run out of nozzle),
I would check if 2 spring are pressing hard enough on the extruder, (if you have a lot of retraction to minimize slip).
Check if your is flowing thick enough, move extruder to 100mm, and extrude by hand, look if it is flowing thick enough, and is not partial clogged.
You could also do a 100mm extrude and llo if the filament moves real 100mm, mark the filament on the roll.
If nothing helps , extusion muliplier can be set higher.
This post was modified 6 years ago by Peter M
Posted : 06/07/2020 4:33 am
