Kugel drucken
Thomas
(@thomas-15)
Kugel drucken
Wer kann mir hier helfen?
Beim drucken dieser hohlen Kugel ändert sich die Oberfläche. Es entsteht auch ein Versatz. Material ist PETG.
Wie könnte man dies beheben?
Danke für die Hilfe.
Napsal : 06/02/2021 12:45 pm
Matto
(@matto)
RE: Kugel drucken
Can you post your .stl file or a link to it?
 -Matt
Stock Prusa MK3S+ built from kit on 12/2020
OctoPrint, typically print from a drybox, no enclosure yet
Printing proudly since 2011
Napsal : 07/02/2021 1:36 pm
Thomas
(@thomas-15)
RE: Kugel drucken
@matto
https://app.box.com/s/svuplapltwc8352whzvfqmzzomde06e5
Napsal : 07/02/2021 4:48 pm
Matto
(@matto)
RE: Kugel drucken
I think you are having an issue with PETG overhang.   PETG is very bad with overhangs.  It likes to curl and change shape.  I think your best solution for this shape is to add more supports, almost half way down the inside of the sphere.
You could also try increasing cooling during those layers to see if that helps.  However, I think you will probably end up with supports being the answer.
 -Matt
Napsal : 08/02/2021 2:54 pm
1 lidem se líbí
