Just Can't Prevent These Walls From Fusing Together.
Nafiul Ahmed
(@nafiul-ahmed)
I just started printing a few days ago on an Ender 3 Pro using PETG filament.
These last few days I've been messing with different configurations on Prusaslicer (wasn't able to get Cura working on my linux distro) and seeing the different kind of results.
I've been trying to print this phone stand, but whenever I go to slice the model, there are parts that should be separate and free that end up touching, which result in the print fusing the stand on those critical points, which then causes it to break when I try to snap them free so it can move properly.
I tried every single option I could find and every single time those external perimeters will end up touching. So I am printing a different phone stand as I type this, but I need to get some feedback on this issue so I can move on and get some sleep.
Do I need a more precise nozzle? I am certain my printer is running 0.40mm.
Anyways, I will be providing screenshots and the .gcode file so my settings can be looked at.
I appreciate you all, especially anyone who takes the time to check this out.
; generated by PrusaSlicer 2.8.0 on 2024-06-29 at 08:22:01 UTC
; external perimeters extrusion width = 0.40mm
; perimeters extrusion width = 0.40mm
; infill extrusion width = 0.40mm
; solid infill extrusion width = 0.40mm
; top infill extrusion width = 0.40mm
; support material extrusion width = 0.36mm
; first layer extrusion width = 0.40mm
M201 X500 Y500 Z100 E5000 ; sets maximum accelerations, mm/sec^2
M203 X500 Y500 Z10 E60 ; sets maximum feedrates, mm / sec
M204 S500 T1000 ; sets acceleration (S) and retract acceleration (R), mm/sec^2
M205 X8.00 Y8.00 Z0.40 E5.00 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
; printing object stand_s.stl id:0 copy 0
; stop printing object stand_s.stl id:0 copy 0
;TYPE:Custom
M83 ; extruder relative mode
M104 S150 ; set temporary nozzle temp to prevent oozing during homing
M140 S80 ; set final bed temp
G4 S30 ; allow partial nozzle warmup
G28 ; home all axis
G1 Z50 F240
G1 X2.0 Y10 F3000
M104 S240 ; set final nozzle temp
M190 S80 ; wait for bed temp to stabilize
M109 S240 ; wait for nozzle temp to stabilize
G1 Z0.28 F240
G92 E0
G1 X2.0 Y140 E10 F1500 ; prime the nozzle
G1 X2.3 Y140 F5000
G92 E0
G1 X2.3 Y10 E10 F1200 ; prime the nozzle
G92 E0
G21 ; set units to millimeters
M83 ; use relative distances for extrusion
; Filament gcode
M107
;LAYER_CHANGE
;Z:0.3
;HEIGHT:0.3
G1 E-5 F3600
G1 Z.3 F9000
G1 X87.039 Y72.713
G1 Z.3
G1 E5 F2400
;TYPE:Skirt/Brim
;WIDTH:0.4
G1 F1200
G1 X87.979 Y71.746 E.05645
G1 X89.029 Y70.9 E.05644
G1 X90.173 Y70.186 E.05645
G1 X91.395 Y69.615 E.05646
G1 X92.676 Y69.196 E.05642
G1 X93.999 Y68.935 E.05645
G1 X95.5 Y68.832 E.06298
G1 X135.656 Y68.835 E1.68094
G1 X137.666 Y69.046 E.0846
G1 X139.605 Y69.615 E.08459
G1 X141.41 Y70.526 E.08464
G1 X143.021 Y71.746 E.08459
G1 X144.385 Y73.237 E.08459
G1 X145.459 Y74.949 E.0846
G1 X146.206 Y76.827 E.0846
G1 X146.603 Y78.809 E.08462
G1 X146.668 Y80 E.04993
G1 X146.666 Y151.152 E2.97844
G1 X146.569 Y152.479 E.0557
G1 X146.314 Y153.784 E.05566
G1 X145.907 Y155.05 E.05567
G1 X145.462 Y156.046 E.04566
G1 X144.785 Y157.203 E.05611
G1 X143.967 Y158.281 E.05665
G1 X143.028 Y159.247 E.05639
G1 X141.818 Y160.208 E.06468
G1 X140.679 Y160.894 E.05566
G1 X139.338 Y161.486 E.06136
G1 X138.001 Y161.883 E.05838
G1 X136.349 Y162.134 E.06995
G1 X95.35 Y162.166 E1.71623
G1 X94.213 Y162.093 E.04769
G1 X92.855 Y161.85 E.05775
G1 X91.692 Y161.497 E.05088
G1 X90.47 Y160.97 E.05571
G1 X89.16 Y160.194 E.06374
G1 X88.001 Y159.273 E.06197
G1 X87.06 Y158.311 E.05633
G1 X86.218 Y157.208 E.05809
G1 X85.538 Y156.046 E.05636
G1 X84.894 Y154.492 E.07042
G1 X84.539 Y153.135 E.05872
G1 X84.345 Y151.518 E.06817
G1 X84.335 Y79.844 E3.0003
G1 X84.397 Y78.809 E.0434
G1 X84.622 Y77.48 E.05642
G1 X85.005 Y76.187 E.05645
G1 X85.541 Y74.949 E.05647
G1 X86.222 Y73.786 E.05642
G1 X87.003 Y72.76 E.05398
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X87.039 Y72.713 E-.02812
G1 X87.979 Y71.746 E-.64058
G1 X89.029 Y70.9 E-.6405
G1 X89.37 Y70.687 E-.1908
;WIPE_END
G1 X92.125 Y94.242 F9000
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.42372
G1 F1200
G1 X92.126 Y94.233 E.00041
G1 X92.27 Y94.233 E.00645
;WIDTH:0.42809
G1 X95.72 Y94.221 E.15651
;WIDTH:0.4
G1 X104.808 Y94.221 E.38043
G1 X104.839 Y94.432 E.00893
G1 X104.839 Y136.791 E1.77316
G1 X104.81 Y137.421 E.0264
G1 X104.839 Y137.81 E.01633
G1 X104.858 Y139.571 E.07372
G1 X105.006 Y139.661 E.00725
G1 X125.994 Y139.661 E.87856
G1 X126.086 Y139.633 E.00403
G1 X126.161 Y139.495 E.00657
G1 X126.161 Y138.382 E.04659
G1 X126.186 Y137.614 E.03217
G1 X126.161 Y137.19 E.01778
G1 X126.161 Y94.449 E1.78915
G1 X126.194 Y94.218 E.00977
G1 X135.279 Y94.221 E.3803
;WIDTH:0.428347
G1 X138.727 Y94.233 E.15653
;WIDTH:0.423744
G1 X138.867 Y94.233 E.00628
G1 X138.902 Y94.458 E.01021
G1 X138.868 Y94.592 E.0062
G1 X138.729 Y94.593 E.00623
;WIDTH:0.428347
G1 X136.006 Y94.599 E.12361
G1 X135.839 Y94.781 E.01121
;WIDTH:0.4
G1 X135.839 Y126.998 E1.34861
G1 X135.817 Y127.466 E.01961
G1 X135.817 Y132.943 E.22927
G1 X135.665 Y134.108 E.04918
G1 X135.528 Y134.726 E.0265
G1 X135.259 Y135.592 E.03796
G1 X134.985 Y136.261 E.03026
G1 X134.707 Y136.832 E.02658
G1 X134.243 Y137.611 E.03796
G1 X133.821 Y138.198 E.03026
G1 X133.418 Y138.688 E.02656
G1 X132.785 Y139.338 E.03798
G1 X132.237 Y139.81 E.03028
G1 X131.731 Y140.194 E.02659
G1 X130.965 Y140.678 E.03793
G1 X130.322 Y141.01 E.03029
G1 X129.741 Y141.265 E.02656
G1 X128.883 Y141.558 E.03795
G1 X128.18 Y141.73 E.0303
G1 X127.557 Y141.843 E.0265
G1 X126.192 Y141.939 E.05728
G1 X104.347 Y141.928 E.91444
G1 X103.262 Y141.813 E.04567
G1 X102.554 Y141.674 E.0302
G1 X101.683 Y141.421 E.03797
G1 X101.091 Y141.194 E.02654
G1 X100.433 Y140.893 E.03029
G1 X99.645 Y140.445 E.03794
G1 X99.121 Y140.086 E.02659
G1 X98.553 Y139.641 E.0302
G1 X97.581 Y138.688 E.05698
G1 X96.909 Y137.831 E.04559
G1 X96.516 Y137.229 E.03009
G1 X95.904 Y136.012 E.05702
G1 X95.544 Y134.984 E.04559
G1 X95.367 Y134.284 E.03022
G1 X95.265 Y133.669 E.0261
G1 X95.16 Y132.8 E.03664
G1 X95.16 Y94.781 E1.59148
;WIDTH:0.42809
G1 X94.993 Y94.599 E.01121
G1 X92.27 Y94.593 E.12353
;WIDTH:0.42372
G1 X92.125 Y94.592 E.0065
G1 X92.094 Y94.453 E.00638
G1 X92.116 Y94.301 E.00688
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X92.125 Y94.242 E-.02835
G1 X92.126 Y94.233 E-.0043
G1 X92.27 Y94.233 E-.0684
G1 X95.215 Y94.223 E-1.39895
;WIPE_END
G1 X135.375 Y94.326 F9000
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.400666
G1 F1200
G1 X135.68 Y94.63 E.01806
G1 X135.587 Y94.753 E.00647
G1 X135.587 Y95.013 E.01091
G1 X135.046 Y94.472 E.03209
G1 X134.571 Y94.472 E.01992
G1 X135.587 Y95.489 E.0603
G1 X135.587 Y95.965 E.01997
G1 X134.095 Y94.472 E.08853
G1 X133.619 Y94.472 E.01997
G1 X135.587 Y96.44 E.11674
G1 X135.587 Y96.916 E.01997
G1 X133.143 Y94.472 E.14497
G1 X132.668 Y94.472 E.01992
G1 X135.587 Y97.391 E.17315
G1 X135.587 Y97.867 E.01997
G1 X132.192 Y94.472 E.20138
G1 X131.716 Y94.471 E.01997
G1 X135.587 Y98.342 E.22962
G1 X135.587 Y98.818 E.01997
G1 X131.241 Y94.471 E.25782
G1 X130.765 Y94.471 E.01997
G1 X135.587 Y99.294 E.28606
G1 X135.587 Y99.769 E.01992
G1 X130.289 Y94.471 E.31426
G1 X129.814 Y94.471 E.01992
G1 X135.587 Y100.245 E.34247
G1 X135.587 Y100.72 E.01992
G1 X129.338 Y94.471 E.37067
G1 X128.862 Y94.471 E.01997
G1 X135.587 Y101.196 E.39891
G1 X135.587 Y101.671 E.01992
G1 X128.387 Y94.471 E.42708
G1 X127.911 Y94.471 E.01997
G1 X135.587 Y102.147 E.45532
G1 X135.587 Y102.623 E.01997
G1 X127.435 Y94.47 E.48358
G1 X126.96 Y94.47 E.01992
G1 X135.587 Y103.098 E.51176
G1 X135.587 Y103.574 E.01997
G1 X126.484 Y94.47 E.53999
G1 X126.413 Y94.47 E.00298
G1 X126.413 Y94.875 E.01699
G1 X135.587 Y104.049 E.54417
G1 X135.587 Y104.525 E.01997
G1 X126.413 Y95.351 E.54417
G1 X126.413 Y95.826 E.01992
G1 X135.587 Y105 E.54417
G1 X135.587 Y105.476 E.01997
G1 X126.413 Y96.302 E.54417
G1 X126.413 Y96.777 E.01992
G1 X135.587 Y105.952 E.5442
G1 X135.587 Y106.427 E.01992
G1 X126.413 Y97.253 E.54417
G1 X126.413 Y97.728 E.01992
G1 X135.587 Y106.903 E.5442
G1 X135.587 Y107.378 E.01992
G1 X126.413 Y98.204 E.54417
G1 X126.413 Y98.68 E.01997
G1 X135.587 Y107.854 E.54417
G1 X135.587 Y108.329 E.01992
G1 X126.413 Y99.155 E.54417
G1 X126.413 Y99.631 E.01997
G1 X135.587 Y108.805 E.54417
G1 X135.587 Y109.281 E.01997
G1 X126.413 Y100.106 E.5442
G1 X126.413 Y100.582 E.01997
G1 X135.587 Y109.756 E.54417
G1 X135.587 Y110.232 E.01997
G1 X126.413 Y101.058 E.54417
G1 X126.413 Y101.533 E.01992
G1 X135.587 Y110.707 E.54417
G1 X135.587 Y111.183 E.01997
G1 X126.413 Y102.009 E.54417
G1 X126.413 Y102.484 E.01992
G1 X135.587 Y111.658 E.54417
G1 X135.587 Y112.134 E.01997
G1 X126.413 Y102.96 E.54417
G1 X126.413 Y103.435 E.01992
G1 X135.587 Y112.61 E.5442
G1 X135.587 Y113.085 E.01992
G1 X126.413 Y103.911 E.54417
G1 X126.413 Y104.387 E.01997
G1 X135.587 Y113.561 E.54417
G1 X135.587 Y114.036 E.01992
G1 X126.413 Y104.862 E.54417
G1 X126.413 Y105.338 E.01997
G1 X135.587 Y114.512 E.54417
G1 X135.587 Y114.987 E.01992
G1 X126.413 Y105.813 E.54417
G1 X126.413 Y106.289 E.01997
G1 X135.587 Y115.463 E.54417
G1 X135.587 Y115.939 E.01997
G1 X126.413 Y106.764 E.5442
G1 X126.413 Y107.24 E.01997
G1 X135.587 Y116.414 E.54417
G1 X135.587 Y116.89 E.01997
G1 X126.413 Y107.716 E.54417
G1 X126.413 Y108.191 E.01992
G1 X135.587 Y117.365 E.54417
G1 X135.587 Y117.841 E.01997
G1 X126.413 Y108.667 E.54417
G1 X126.413 Y109.142 E.01992
G1 X135.587 Y118.316 E.54417
G1 X135.587 Y118.792 E.01997
G1 X126.413 Y109.618 E.54417
G1 X126.413 Y110.094 E.01997
G1 X135.587 Y119.268 E.54417
G1 X135.587 Y119.743 E.01992
G1 X126.413 Y110.569 E.54417
G1 X126.413 Y111.045 E.01997
G1 X135.587 Y120.219 E.54417
G1 X135.587 Y120.694 E.01992
G1 X126.413 Y111.52 E.54417
G1 X126.413 Y111.996 E.01997
G1 X135.587 Y121.17 E.54417
G1 X135.587 Y121.645 E.01992
G1 X126.413 Y112.471 E.54417
G1 X126.413 Y112.947 E.01997
G1 X135.587 Y122.121 E.54417
G1 X135.587 Y122.597 E.01997
G1 X126.413 Y113.423 E.54417
G1 X126.413 Y113.898 E.01992
G1 X135.587 Y123.072 E.54417
G1 X135.587 Y123.548 E.01997
G1 X126.413 Y114.374 E.54417
G1 X126.413 Y114.849 E.01992
G1 X135.587 Y124.023 E.54417
G1 X135.587 Y124.499 E.01997
G1 X126.413 Y115.325 E.54417
G1 X126.413 Y115.8 E.01992
G1 X135.587 Y124.974 E.54417
G1 X135.587 Y125.45 E.01997
G1 X126.413 Y116.276 E.54417
G1 X126.413 Y116.752 E.01997
G1 X135.587 Y125.926 E.54417
G1 X135.587 Y126.401 E.01992
G1 X126.413 Y117.227 E.54417
G1 X126.413 Y117.703 E.01997
G1 X135.587 Y126.877 E.54417
G1 X135.587 Y127.352 E.01992
G1 X126.413 Y118.178 E.54417
G1 X126.413 Y118.654 E.01997
G1 X135.565 Y127.806 E.54287
G1 X135.565 Y128.282 E.01997
G1 X126.413 Y119.13 E.54287
G1 X126.413 Y119.605 E.01992
G1 X135.565 Y128.757 E.54287
G1 X135.565 Y129.233 E.01997
G1 X126.413 Y120.081 E.54287
G1 X126.413 Y120.556 E.01992
G1 X135.565 Y129.708 E.54287
G1 X135.565 Y130.184 E.01997
G1 X126.413 Y121.032 E.54287
G1 X126.413 Y121.507 E.01992
G1 X135.565 Y130.659 E.54287
G1 X135.565 Y131.135 E.01997
G1 X126.413 Y121.983 E.54287
G1 X126.413 Y122.459 E.01997
G1 X135.565 Y131.611 E.54287
G1 X135.565 Y132.086 E.01992
G1 X126.413 Y122.934 E.54287
G1 X126.413 Y123.41 E.01997
G1 X135.565 Y132.562 E.54287
G1 X135.552 Y133.025 E.01943
G1 X126.413 Y123.885 E.54213
G1 X126.413 Y124.361 E.01997
G1 X135.497 Y133.445 E.53883
G1 X135.443 Y133.866 E.0178
G1 X126.413 Y124.836 E.53563
G1 X126.413 Y125.312 E.01997
G1 X135.371 Y134.27 E.53136
G1 X135.285 Y134.66 E.01675
G1 X126.413 Y125.788 E.52626
G1 X126.413 Y126.263 E.01992
G1 X135.172 Y135.023 E.51959
G1 X135.06 Y135.385 E.01589
G1 X126.413 Y126.739 E.51288
G1 X126.413 Y127.214 E.01992
G1 X134.93 Y135.731 E.5052
G1 X134.791 Y136.068 E.01529
G1 X126.413 Y127.69 E.49696
G1 X126.413 Y128.166 E.01997
G1 X134.64 Y136.393 E.488
G1 X134.485 Y136.713 E.01491
G1 X126.413 Y128.641 E.47881
G1 X126.413 Y129.117 E.01997
G1 X134.307 Y137.011 E.46825
G1 X134.13 Y137.309 E.01454
G1 X126.413 Y129.592 E.45775
G1 X126.413 Y130.068 E.01997
G1 X133.943 Y137.598 E.44666
G1 X133.744 Y137.874 E.01427
G1 X126.413 Y130.543 E.43485
G1 X126.413 Y131.019 E.01997
G1 X133.539 Y138.144 E.42266
G1 X133.324 Y138.406 E.01422
G1 X126.413 Y131.495 E.40994
G1 X126.413 Y131.97 E.01992
G1 X133.098 Y138.655 E.39653
G1 X132.864 Y138.897 E.01412
G1 X126.413 Y132.446 E.38265
G1 X126.413 Y132.921 E.01992
G1 X132.629 Y139.138 E.36874
G1 X132.375 Y139.359 E.01412
G1 X126.413 Y133.397 E.35365
G1 X126.413 Y133.872 E.01992
G1 X132.12 Y139.579 E.33852
G1 X131.852 Y139.787 E.01423
G1 X126.413 Y134.348 E.32262
G1 X126.413 Y134.824 E.01997
G1 X131.581 Y139.991 E.30652
G1 X131.289 Y140.175 E.01448
G1 X126.413 Y135.299 E.28923
G1 X126.413 Y135.775 E.01997
G1 X130.998 Y140.36 E.27197
G1 X130.696 Y140.534 E.01462
G1 X126.413 Y136.25 E.25408
G1 X126.413 Y136.726 E.01997
G1 X130.383 Y140.696 E.23549
G1 X130.061 Y140.85 E.01497
G1 X126.417 Y137.205 E.21618
G1 X126.451 Y137.481 E.01166
G1 X126.428 Y137.692 E.0089
G1 X129.73 Y140.994 E.19586
G1 X129.649 Y141.03 E.00372
G1 X129.382 Y141.121 E.01183
G1 X126.413 Y138.153 E.17608
G1 X126.413 Y138.628 E.01992
G1 X129.027 Y141.242 E.15505
G1 X128.662 Y141.353 E.016
G1 X126.413 Y139.104 E.1334
G1 X126.403 Y139.569 E.01951
G1 X128.28 Y141.447 E.11137
G1 X127.886 Y141.528 E.01687
G1 X126.21 Y139.852 E.09941
G1 X126.006 Y139.913 E.00893
G1 X125.795 Y139.913 E.00885
G1 X127.478 Y141.596 E.09983
G1 X127.034 Y141.627 E.01867
G1 X125.32 Y139.913 E.10167
G1 X124.844 Y139.913 E.01997
G1 X126.59 Y141.659 E.10357
G1 X126.143 Y141.687 E.01879
G1 X124.369 Y139.913 E.10523
G1 X123.893 Y139.913 E.01997
G1 X125.667 Y141.687 E.10523
G1 X125.191 Y141.687 E.01997
G1 X123.418 Y139.913 E.1052
G1 X122.942 Y139.913 E.01997
G1 X124.715 Y141.686 E.10517
G1 X124.24 Y141.686 E.01992
G1 X122.466 Y139.913 E.1052
G1 X121.991 Y139.913 E.01992
G1 X123.764 Y141.686 E.10517
G1 X123.288 Y141.686 E.01997
G1 X121.515 Y139.913 E.10517
G1 X121.04 Y139.913 E.01992
G1 X122.812 Y141.685 E.10511
G1 X122.336 Y141.685 E.01997
G1 X120.564 Y139.913 E.10511
G1 X120.089 Y139.913 E.01992
G1 X121.861 Y141.685 E.10511
G1 X121.385 Y141.685 E.01997
G1 X119.613 Y139.913 E.10511
G1 X119.137 Y139.913 E.01997
G1 X120.909 Y141.685 E.10511
G1 X120.433 Y141.684 E.01997
G1 X118.662 Y139.913 E.10505
G1 X118.186 Y139.913 E.01997
G1 X119.957 Y141.684 E.10505
G1 X119.481 Y141.684 E.01997
G1 X117.711 Y139.913 E.10502
G1 X117.235 Y139.913 E.01997
G1 X119.006 Y141.684 E.10505
G1 X118.53 Y141.683 E.01997
G1 X116.759 Y139.913 E.10502
G1 X116.284 Y139.913 E.01992
G1 X118.054 Y141.683 E.10499
G1 X117.578 Y141.683 E.01997
G1 X115.808 Y139.913 E.10499
G1 X115.333 Y139.913 E.01992
G1 X117.102 Y141.683 E.10496
G1 X116.627 Y141.682 E.01992
G1 X114.857 Y139.913 E.10496
G1 X114.382 Y139.913 E.01992
G1 X116.151 Y141.682 E.10493
G1 X115.675 Y141.682 E.01997
G1 X113.906 Y139.913 E.10493
G1 X113.43 Y139.913 E.01997
G1 X115.199 Y141.682 E.10493
G1 X114.723 Y141.681 E.01997
G1 X112.955 Y139.913 E.10487
G1 X112.479 Y139.913 E.01997
G1 X114.247 Y141.681 E.10487
G1 X113.772 Y141.681 E.01992
G1 X112.004 Y139.913 E.10487
G1 X111.528 Y139.913 E.01997
G1 X113.296 Y141.681 E.10487
G1 X112.82 Y141.681 E.01997
G1 X111.053 Y139.913 E.10484
G1 X110.577 Y139.913 E.01997
G1 X112.344 Y141.68 E.10481
G1 X111.868 Y141.68 E.01997
G1 X110.101 Y139.913 E.10481
G1 X109.626 Y139.913 E.01992
G1 X111.393 Y141.68 E.10481
G1 X110.917 Y141.68 E.01997
G1 X109.15 Y139.913 E.10481
G1 X108.675 Y139.913 E.01992
G1 X110.441 Y141.679 E.10475
G1 X109.965 Y141.679 E.01997
G1 X108.199 Y139.913 E.10475
G1 X107.723 Y139.913 E.01997
G1 X109.489 Y141.679 E.10475
G1 X109.013 Y141.679 E.01997
G1 X107.248 Y139.913 E.10472
G1 X106.772 Y139.913 E.01997
G1 X108.538 Y141.678 E.10472
G1 X108.062 Y141.678 E.01997
G1 X106.297 Y139.913 E.10469
G1 X105.821 Y139.913 E.01997
G1 X107.586 Y141.678 E.10469
G1 X107.11 Y141.678 E.01997
G1 X105.195 Y139.762 E.11362
G1 E-5 F3600
G1 X105.195 Y139.762 F9000
G1 X105.195 Y139.865
G1 X104.635 Y139.865
G1 X104.597 Y137.5
G1 X104.102 Y94.422
G1 X103.983 Y94.422
G1 X103.983 Y94.321
G1 E5 F2400
G1 F1200
G1 X104.579 Y94.918 E.03538
G1 X104.579 Y95.393 E.01992
G1 X103.658 Y94.472 E.05463
G1 X103.183 Y94.473 E.01992
G1 X104.579 Y95.869 E.08281
G1 X104.579 Y96.345 E.01997
G1 X102.707 Y94.473 E.11104
G1 X102.232 Y94.473 E.01992
G1 X104.579 Y96.82 E.13922
G1 X104.579 Y97.296 E.01997
G1 X101.756 Y94.473 E.16745
G1 X101.281 Y94.473 E.01992
G1 X104.579 Y97.772 E.19566
G1 X104.58 Y98.247 E.01992
G1 X100.805 Y94.473 E.22389
G1 X100.329 Y94.473 E.01997
G1 X104.58 Y98.723 E.25213
G1 X104.58 Y99.199 E.01997
G1 X99.854 Y94.473 E.28033
G1 X99.378 Y94.473 E.01997
G1 X104.58 Y99.674 E.30854
G1 X104.58 Y100.15 E.01997
G1 X98.903 Y94.473 E.33674
G1 X98.427 Y94.473 E.01997
G1 X104.58 Y100.626 E.36498
G1 X104.58 Y101.101 E.01992
G1 X97.952 Y94.473 E.39315
G1 X97.476 Y94.473 E.01997
G1 X104.58 Y101.577 E.42139
G1 X104.58 Y102.053 E.01997
G1 X97.001 Y94.473 E.44959
G1 X96.525 Y94.473 E.01997
G1 X104.58 Y102.528 E.4778
G1 X104.58 Y103.004 E.01997
G1 X96.049 Y94.473 E.50603
G1 X95.579 Y94.478 E.01971
G1 X104.581 Y103.48 E.53397
G1 X104.581 Y103.955 E.01992
G1 X95.412 Y94.787 E.54385
G1 X95.412 Y95.262 E.01992
G1 X104.581 Y104.431 E.54388
G1 X104.581 Y104.907 E.01997
G1 X95.412 Y95.738 E.54388
G1 X95.412 Y96.213 E.01992
G1 X104.581 Y105.382 E.54388
G1 X104.581 Y105.858 E.01997
G1 X95.412 Y96.689 E.54388
G1 X95.412 Y97.164 E.01992
G1 X104.581 Y106.334 E.54391
G1 X104.581 Y106.809 E.01992
G1 X95.412 Y97.64 E.54388
G1 X95.412 Y98.116 E.01997
G1 X104.581 Y107.285 E.54388
G1 X104.581 Y107.761 E.01997
G1 X95.412 Y98.591 E.54391
G1 X95.412 Y99.067 E.01997
G1 X104.581 Y108.236 E.54388
G1 X104.582 Y108.712 E.01997
G1 X95.412 Y99.542 E.54394
G1 X95.412 Y100.018 E.01997
G1 X104.582 Y109.188 E.54394
G1 X104.582 Y109.663 E.01992
G1 X95.412 Y100.493 E.54394
G1 X95.412 Y100.969 E.01997
G1 X104.582 Y110.139 E.54394
G1 X104.582 Y110.615 E.01997
G1 X95.412 Y101.445 E.54394
G1 X95.412 Y101.92 E.01992
G1 X104.582 Y111.09 E.54394
G1 X104.582 Y111.566 E.01997
G1 X95.412 Y102.396 E.54394
G1 X95.412 Y102.871 E.01992
G1 X104.582 Y112.042 E.54396
G1 X104.582 Y112.517 E.01992
G1 X95.412 Y103.347 E.54394
G1 X95.412 Y103.822 E.01992
G1 X104.582 Y112.993 E.54396
G1 X104.582 Y113.469 E.01997
G1 X95.412 Y104.298 E.54396
G1 X95.412 Y104.774 E.01997
G1 X104.583 Y113.944 E.54396
G1 X104.583 Y114.42 E.01997
G1 X95.412 Y105.249 E.54399
G1 X95.412 Y105.725 E.01997
G1 X104.583 Y114.896 E.54399
G1 X104.583 Y115.371 E.01992
G1 X95.412 Y106.2 E.54399
G1 X95.412 Y106.676 E.01997
G1 X104.583 Y115.847 E.54399
G1 X104.583 Y116.323 E.01997
G1 X95.412 Y107.151 E.54402
G1 X95.412 Y107.627 E.01997
G1 X104.583 Y116.798 E.54399
G1 X104.583 Y117.274 E.01997
G1 X95.412 Y108.103 E.54399
G1 X95.412 Y108.578 E.01992
G1 X104.583 Y117.75 E.54402
G1 X104.583 Y118.225 E.01992
G1 X95.412 Y109.054 E.54399
G1 X95.412 Y109.529 E.01992
G1 X104.583 Y118.701 E.54402
G1 X104.584 Y119.177 E.01997
G1 X95.412 Y110.005 E.54405
G1 X95.412 Y110.48 E.01992
G1 X104.584 Y119.652 E.54405
G1 X104.584 Y120.128 E.01997
G1 X95.412 Y110.956 E.54405
G1 X95.412 Y111.432 E.01997
G1 X104.584 Y120.604 E.54405
G1 X104.584 Y121.079 E.01992
G1 X95.412 Y111.907 E.54405
G1 X95.412 Y112.383 E.01997
G1 X104.584 Y121.555 E.54405
G1 X104.584 Y122.031 E.01997
G1 X95.412 Y112.858 E.54408
G1 X95.412 Y113.334 E.01997
G1 X104.584 Y122.506 E.54405
G1 X104.584 Y122.982 E.01997
G1 X95.412 Y113.809 E.54408
G1 X95.412 Y114.285 E.01997
G1 X104.584 Y123.458 E.54408
G1 X104.584 Y123.933 E.01992
G1 X95.412 Y114.761 E.54405
G1 X95.412 Y115.236 E.01992
G1 X104.585 Y124.409 E.54411
G1 X104.585 Y124.885 E.01997
G1 X95.412 Y115.712 E.54411
G1 X95.412 Y116.187 E.01992
G1 X104.585 Y125.36 E.54411
G1 X104.585 Y125.836 E.01997
G1 X95.412 Y116.663 E.54411
G1 X95.412 Y117.138 E.01992
G1 X104.585 Y126.312 E.54414
G1 X104.585 Y126.787 E.01992
G1 X95.412 Y117.614 E.54411
G1 X95.412 Y118.09 E.01997
G1 X104.585 Y127.263 E.54411
G1 X104.585 Y127.739 E.01997
G1 X95.412 Y118.565 E.54414
G1 X95.412 Y119.041 E.01997
G1 X104.585 Y128.214 E.54411
G1 X104.585 Y128.69 E.01997
G1 X95.412 Y119.516 E.54414
G1 X95.412 Y119.992 E.01997
G1 X104.585 Y129.166 E.54414
G1 X104.586 Y129.641 E.01992
G1 X95.412 Y120.467 E.54417
G1 X95.412 Y120.943 E.01997
G1 X104.586 Y130.117 E.54417
G1 X104.586 Y130.593 E.01997
G1 X95.412 Y121.419 E.54417
G1 X95.412 Y121.894 E.01992
G1 X104.586 Y131.068 E.54417
G1 X104.586 Y131.544 E.01997
G1 X95.411 Y122.37 E.5442
G1 X95.411 Y122.845 E.01992
G1 X104.586 Y132.02 E.54423
G1 X104.586 Y132.495 E.01992
G1 X95.411 Y123.321 E.5442
G1 X95.411 Y123.796 E.01992
G1 X104.586 Y132.971 E.54423
G1 X104.586 Y133.447 E.01997
G1 X95.411 Y124.272 E.54423
G1 X95.411 Y124.748 E.01997
G1 X104.586 Y133.922 E.5442
G1 X104.586 Y134.398 E.01997
G1 X95.411 Y125.223 E.54423
G1 X95.411 Y125.699 E.01997
G1 X104.587 Y134.874 E.54426
G1 X104.587 Y135.349 E.01992
G1 X95.411 Y126.174 E.54426
G1 X95.411 Y126.65 E.01997
G1 X104.587 Y135.825 E.54426
G1 X104.587 Y136.301 E.01997
G1 X95.411 Y127.125 E.54429
G1 X95.411 Y127.601 E.01997
G1 X104.587 Y136.776 E.54426
G1 X104.579 Y137.244 E.01963
G1 X95.411 Y128.077 E.54379
G1 X95.411 Y128.552 E.01992
G1 X104.574 Y137.714 E.54349
G1 X104.587 Y138.203 E.02052
G1 X95.411 Y129.028 E.54426
G1 X95.411 Y129.503 E.01992
G1 X104.587 Y138.679 E.54429
G1 X104.587 Y139.154 E.01992
G1 X95.411 Y129.979 E.54426
G1 X95.411 Y130.454 E.01992
G1 X106.634 Y141.677 E.66571
G1 X106.159 Y141.677 E.01992
G1 X95.411 Y130.93 E.63751
G1 X95.411 Y131.405 E.01992
G1 X105.683 Y141.677 E.6093
G1 X105.207 Y141.677 E.01997
G1 X95.411 Y131.881 E.58107
G1 X95.411 Y132.357 E.01997
G1 X104.731 Y141.676 E.5528
G1 X104.243 Y141.664 E.02047
G1 X95.419 Y132.84 E.52341
G1 X95.483 Y133.38 E.02281
G1 X103.711 Y141.607 E.48803
G1 X103.165 Y141.537 E.02309
G1 X95.557 Y133.929 E.45128
G1 X95.691 Y134.539 E.0262
G1 X102.568 Y141.416 E.40792
G1 X101.898 Y141.221 E.02927
G1 X95.892 Y135.215 E.35626
G1 X96.158 Y135.957 E.03306
G1 X101.142 Y140.941 E.29563
G1 X100.548 Y140.669 E.0274
G1 X100.192 Y140.467 E.01717
G1 X96.639 Y136.914 E.21075
G1 X96.735 Y137.103 E.00889
G1 X97.113 Y137.684 E.02907
G1 X97.768 Y138.518 E.04448
G1 X99.416 Y140.166 E.09775
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X97.768 Y138.518 E-1.10705
G1 X97.257 Y137.868 E-.39295
;WIPE_END
G1 X97.21 Y137.904 F9000
G1 X104.635 Y128.876
G1 X106.065 Y127.134
G1 X112.043 Y119.888
G1 X112.155 Y119.712
G1 E5 F2400
;WIDTH:0.4
G1 F1200
G1 X111.717 Y119.403 E.02244
G1 X111.173 Y118.805 E.03384
G1 X109.297 Y115.578 E.15625
G1 X109.067 Y115.085 E.02277
G1 X108.922 Y114.543 E.02349
G1 X108.876 Y113.983 E.02352
G1 X108.922 Y113.457 E.0221
G1 X109.057 Y112.943 E.02225
G1 X109.297 Y112.422 E.02401
G1 X111.173 Y109.195 E.15625
G1 X111.674 Y108.648 E.03105
G1 X112.144 Y108.314 E.02414
G1 X112.423 Y108.14 E.01376
G1 X112.981 Y107.94 E.02481
G1 X113.766 Y107.839 E.03313
G1 X117.498 Y107.85 E.15622
G1 X118.253 Y108.01 E.03231
G1 X118.775 Y108.248 E.02402
G1 X119.441 Y108.74 E.03466
G1 X119.827 Y109.194 E.02495
G1 X121.703 Y112.422 E.15629
G1 X121.933 Y112.915 E.02277
G1 X122.078 Y113.457 E.02349
G1 X122.116 Y114.228 E.03231
G1 X122.025 Y114.788 E.02375
G1 X121.837 Y115.318 E.02354
G1 X119.827 Y118.805 E.16848
G1 X119.264 Y119.42 E.0349
G1 X118.851 Y119.714 E.02122
G1 X118.347 Y119.957 E.02342
G1 X117.806 Y120.108 E.02351
G1 X117.236 Y120.161 E.02396
G1 X113.764 Y120.161 E.14534
G1 X113.025 Y120.063 E.03121
G1 X112.205 Y119.746 E.0368
G1 E-5 F3600
G1 X112.205 Y119.746 F9000
G1 X112.102 Y119.923
G1 X112.052 Y119.894
G1 X111.864 Y119.774
G1 X111.801 Y119.729
G1 X111.625 Y119.594
G1 X111.566 Y119.543
G1 X111.402 Y119.393
G1 X111.348 Y119.337
G1 X111.198 Y119.172
G1 X111.15 Y119.111
G1 X111.015 Y118.935
G1 X110.973 Y118.87
G1 X110.859 Y118.692
G1 X109.116 Y115.673
G1 X109.019 Y115.486
G1 X108.984 Y115.417
G1 X108.898 Y115.211
G1 X108.87 Y115.139
G1 X108.803 Y114.927
G1 X108.781 Y114.853
G1 X108.733 Y114.635
G1 X108.718 Y114.559
G1 X108.689 Y114.338
G1 X108.681 Y114.261
G1 X108.672 Y114.039
G1 X108.672 Y113.961
G1 X108.681 Y113.739
G1 X108.689 Y113.662
G1 X108.718 Y113.441
G1 X108.733 Y113.365
G1 X108.781 Y113.147
G1 X108.803 Y113.073
G1 X108.87 Y112.861
G1 X108.898 Y112.789
G1 X108.984 Y112.583
G1 X109.019 Y112.514
G1 X109.116 Y112.327
G1 X110.859 Y109.308
G1 X110.973 Y109.13
G1 X111.015 Y109.065
G1 X111.15 Y108.889
G1 X111.198 Y108.828
G1 X111.348 Y108.663
G1 X111.402 Y108.607
G1 X111.566 Y108.457
G1 X111.625 Y108.406
G1 X111.801 Y108.271
G1 X111.864 Y108.226
G1 X112.052 Y108.106
G1 X112.119 Y108.067
G1 X112.317 Y107.964
G1 X112.387 Y107.932
G1 X112.593 Y107.847
G1 X112.666 Y107.822
G1 X112.879 Y107.755
G1 X112.954 Y107.736
G1 X113.172 Y107.688
G1 X113.248 Y107.677
G1 X113.333 Y107.666
G1 X113.448 Y106.349
G1 X113.477 Y106.123
G1 E5 F2400
G1 F1200
G1 X113.025 Y106.063 E.01909
G1 X112.202 Y105.745 E.03693
G1 X111.693 Y105.383 E.02615
G1 X111.173 Y104.805 E.03255
G1 X109.297 Y101.578 E.15625
G1 X109.067 Y101.085 E.02277
G1 X108.922 Y100.543 E.02349
G1 X108.876 Y99.983 E.02352
G1 X108.922 Y99.457 E.0221
G1 X109.057 Y98.943 E.02225
G1 X109.289 Y98.436 E.02334
G1 X111.173 Y95.195 E.15693
G1 X111.736 Y94.58 E.0349
G1 X112.389 Y94.157 E.03257
G1 X112.981 Y93.94 E.02639
G1 X113.744 Y93.84 E.03221
G1 X117.498 Y93.85 E.15714
G1 X118.253 Y94.01 E.03231
G1 X118.826 Y94.271 E.02636
G1 X119.441 Y94.74 E.03238
G1 X119.827 Y95.194 E.02495
G1 X121.703 Y98.422 E.15629
G1 X121.933 Y98.915 E.02277
G1 X122.078 Y99.457 E.02349
G1 X122.116 Y100.228 E.03231
G1 X122.025 Y100.788 E.02375
G1 X121.837 Y101.318 E.02354
G1 X119.827 Y104.805 E.16848
G1 X119.264 Y105.42 E.0349
G1 X118.797 Y105.745 E.02382
G1 X118.338 Y105.962 E.02125
G1 X117.806 Y106.108 E.02309
G1 X117.251 Y106.161 E.02334
G1 X113.764 Y106.161 E.14597
G1 X113.537 Y106.131 E.00958
G1 E-5 F3600
G1 X113.537 Y106.131 F9000
G1 X113.526 Y106.355
G1 X111.15 Y108.889
G1 X110.973 Y109.13
G1 X108.87 Y112.861
G1 X108.87 Y115.139
G1 X110.973 Y118.87
G1 X111.15 Y119.111
G1 X112.119 Y119.933
G1 X112.317 Y120.036
G1 X112.387 Y120.068
G1 X112.593 Y120.153
G1 X112.666 Y120.178
G1 X112.879 Y120.245
G1 X112.954 Y120.264
G1 X113.172 Y120.312
G1 X113.248 Y120.323
G1 X113.469 Y120.352
G1 X113.546 Y120.356
G1 X113.746 Y120.364
G1 X113.768 Y121.635
G1 X113.768 Y121.839
G1 E5 F2400
G1 F1200
G1 X117.498 Y121.85 E.15614
G1 X118.253 Y122.01 E.03231
G1 X118.826 Y122.271 E.02636
G1 X119.441 Y122.74 E.03238
G1 X119.81 Y123.17 E.02372
G1 X121.703 Y126.422 E.15751
G1 X121.933 Y126.915 E.02277
G1 X122.078 Y127.457 E.02349
G1 X122.116 Y128.228 E.03231
G1 X122.025 Y128.788 E.02375
G1 X121.825 Y129.345 E.02477
G1 X119.827 Y132.805 E.16725
G1 X119.264 Y133.42 E.0349
G1 X118.797 Y133.745 E.02382
G1 X118.319 Y133.968 E.02208
G1 X117.806 Y134.108 E.02226
G1 X117.236 Y134.161 E.02396
G1 X113.764 Y134.161 E.14534
G1 X112.956 Y134.054 E.03412
G1 X112.234 Y133.763 E.03259
G1 X111.717 Y133.403 E.02637
G1 X111.173 Y132.805 E.03384
G1 X109.297 Y129.578 E.15625
G1 X109.067 Y129.085 E.02277
G1 X108.922 Y128.543 E.02349
G1 X108.876 Y127.983 E.02352
G1 X108.922 Y127.457 E.0221
G1 X109.067 Y126.915 E.02349
G1 X109.297 Y126.422 E.02277
G1 X111.173 Y123.195 E.15625
G1 X111.674 Y122.648 E.03105
G1 X112.144 Y122.314 E.02414
G1 X112.423 Y122.14 E.01376
G1 X112.981 Y121.94 E.02481
G1 X113.708 Y121.846 E.03069
G1 E-5 F3600
G1 X113.708 Y121.846 F9000
G1 X113.699 Y121.638
G1 X113.547 Y121.644
G1 X113.469 Y121.648
G1 X113.248 Y121.677
G1 X113.172 Y121.688
G1 X112.954 Y121.736
G1 X112.879 Y121.755
G1 X112.666 Y121.822
G1 X112.593 Y121.847
G1 X112.387 Y121.932
G1 X112.317 Y121.964
G1 X112.119 Y122.067
G1 X112.052 Y122.106
G1 X111.864 Y122.226
G1 X111.801 Y122.271
G1 X111.625 Y122.406
G1 X111.566 Y122.457
G1 X111.402 Y122.607
G1 X111.348 Y122.663
G1 X111.198 Y122.828
G1 X111.15 Y122.889
G1 X111.015 Y123.065
G1 X110.973 Y123.13
G1 X110.859 Y123.308
G1 X109.116 Y126.327
G1 X109.019 Y126.514
G1 X108.984 Y126.583
G1 X108.898 Y126.789
G1 X108.87 Y126.861
G1 X108.803 Y127.073
G1 X108.781 Y127.147
G1 X108.733 Y127.365
G1 X108.718 Y127.441
G1 X108.689 Y127.662
G1 X108.681 Y127.739
G1 X108.672 Y127.961
G1 X108.672 Y128.039
G1 X108.681 Y128.261
G1 X108.689 Y128.338
G1 X108.718 Y128.559
G1 X108.733 Y128.635
G1 X108.781 Y128.853
G1 X108.803 Y128.927
G1 X108.87 Y129.139
G1 X108.898 Y129.211
G1 X108.984 Y129.417
G1 X109.019 Y129.486
G1 X109.116 Y129.673
G1 X109.37 Y130.112
G1 X106.04 Y136.927
G1 X105.846 Y136.827
G1 E5 F2400
G1 F1200
G1 X105.861 Y136.788 E.00175
G1 X105.861 Y91.211 E1.90786
G1 X105.713 Y90.856 E.0161
G1 X105.638 Y90.555 E.01299
G1 X105.707 Y90.176 E.01613
G1 X125.3 Y90.176 E.82017
G1 X125.356 Y90.45 E.01171
G1 X125.321 Y90.743 E.01235
G1 X125.139 Y91.212 E.02106
G1 X125.139 Y136.789 E1.90786
G1 X125.287 Y137.144 E.0161
G1 X125.36 Y137.487 E.01468
G1 X125.293 Y137.824 E.01438
G1 X105.7 Y137.824 E.82017
G1 X105.644 Y137.55 E.01171
G1 X105.679 Y137.257 E.01235
G1 X105.825 Y136.882 E.01685
G1 E-5 F3600
G1 X105.825 Y136.882 F9000
G1 X106.013 Y136.98
G1 X106.065 Y136.88
G1 X109.248 Y90.379
G1 X125.098 Y90.798
G1 X125.074 Y90.853
G1 X125.16 Y90.89
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.400211
G1 F1200
G1 X124.699 Y90.428 E.02734
G1 X124.224 Y90.428 E.0199
G1 X124.907 Y91.112 E.04049
G1 X124.887 Y91.203 E.0039
G1 X124.887 Y91.566 E.0152
G1 X123.749 Y90.428 E.06741
G1 X123.274 Y90.428 E.0199
G1 X124.887 Y92.041 E.09555
G1 X124.887 Y92.516 E.0199
G1 X122.799 Y90.428 E.12369
G1 X122.324 Y90.428 E.0199
G1 X124.887 Y92.991 E.15182
G1 X124.887 Y93.466 E.0199
G1 X121.849 Y90.428 E.17996
G1 X121.374 Y90.428 E.0199
G1 X124.887 Y93.941 E.2081
G1 X124.887 Y94.416 E.0199
G1 X120.899 Y90.428 E.23624
G1 X120.424 Y90.428 E.0199
G1 X124.887 Y94.891 E.26437
G1 X124.887 Y95.366 E.0199
G1 X119.949 Y90.428 E.29251
G1 X119.474 Y90.428 E.0199
G1 X124.887 Y95.841 E.32065
G1 X124.887 Y96.316 E.0199
G1 X118.999 Y90.428 E.34878
G1 X118.525 Y90.428 E.01985
G1 X124.887 Y96.791 E.37689
G1 X124.887 Y97.266 E.0199
G1 X118.05 Y90.428 E.40503
G1 X117.575 Y90.428 E.0199
G1 X124.887 Y97.74 E.43314
G1 X124.887 Y98.215 E.0199
G1 X117.1 Y90.428 E.46128
G1 X116.625 Y90.428 E.0199
G1 X124.887 Y98.69 E.48941
G1 X124.887 Y99.165 E.0199
G1 X116.15 Y90.428 E.51755
G1 X115.675 Y90.428 E.0199
G1 X124.887 Y99.64 E.54569
G1 X124.887 Y100.115 E.0199
G1 X120.328 Y95.556 E.27006
G1 X120.04 Y95.061 E.02399
G1 X119.602 Y94.546 E.02832
G1 X119.004 Y94.086 E.0316
G1 X118.731 Y93.959 E.01261
G1 X115.2 Y90.428 E.20916
G1 X114.725 Y90.428 E.0199
G1 X117.997 Y93.7 E.19382
G1 X117.507 Y93.599 E.02096
G1 X117.42 Y93.598 E.00364
G1 X114.25 Y90.428 E.18778
G1 X113.775 Y90.428 E.0199
G1 X116.944 Y93.597 E.18772
G1 X116.468 Y93.596 E.01994
G1 X113.3 Y90.428 E.18766
G1 X112.825 Y90.428 E.0199
G1 X115.992 Y93.595 E.1876
G1 X115.516 Y93.594 E.01994
G1 X112.35 Y90.428 E.18754
G1 X111.875 Y90.428 E.0199
G1 X115.04 Y93.593 E.18748
G1 X114.564 Y93.592 E.01994
G1 X111.401 Y90.428 E.18739
G1 X110.926 Y90.428 E.0199
G1 X114.088 Y93.59 E.18731
G1 X113.624 Y93.601 E.01944
G1 X110.451 Y90.428 E.18796
G1 X109.976 Y90.428 E.0199
G1 X113.202 Y93.655 E.19113
G1 X112.96 Y93.685 E.01021
G1 X112.812 Y93.739 E.0066
G1 X109.501 Y90.428 E.19613
G1 X109.026 Y90.428 E.0199
G1 X112.464 Y93.866 E.20366
G1 X112.261 Y93.94 E.00905
G1 X112.141 Y94.019 E.00602
G1 X108.551 Y90.428 E.21269
G1 X108.076 Y90.428 E.0199
G1 X111.855 Y94.207 E.22385
G1 X111.568 Y94.395 E.01437
G1 X107.601 Y90.428 E.23499
G1 X107.126 Y90.428 E.0199
G1 X111.34 Y94.642 E.24962
G1 X111.114 Y94.891 E.01409
G1 X106.651 Y90.428 E.26437
G1 X106.176 Y90.428 E.0199
G1 X110.904 Y95.156 E.28007
G1 X110.73 Y95.457 E.01456
G1 X105.912 Y90.639 E.2854
G1 X105.93 Y90.725 E.00368
G1 X106.078 Y91.042 E.01465
G1 X106.113 Y91.202 E.00686
G1 X106.113 Y91.315 E.00473
G1 X110.555 Y95.757 E.26313
G1 X110.381 Y96.057 E.01453
G1 X106.113 Y91.79 E.25279
G1 X106.113 Y92.265 E.0199
G1 X110.206 Y96.358 E.24246
G1 X110.031 Y96.658 E.01455
G1 X106.113 Y92.74 E.23209
G1 X106.113 Y93.215 E.0199
G1 X109.857 Y96.958 E.22175
G1 X109.682 Y97.259 E.01458
G1 X106.113 Y93.69 E.21142
G1 X106.113 Y94.164 E.01985
G1 X109.507 Y97.559 E.20108
G1 X109.333 Y97.859 E.01453
G1 X106.113 Y94.639 E.19074
G1 X106.113 Y95.114 E.0199
G1 X109.158 Y98.159 E.18038
G1 X108.997 Y98.474 E.01482
G1 X106.113 Y95.589 E.17087
G1 X106.113 Y96.064 E.0199
G1 X108.848 Y98.8 E.16204
G1 X108.739 Y99.165 E.01596
G1 X106.113 Y96.539 E.15556
G1 X106.113 Y97.014 E.0199
G1 X108.662 Y99.563 E.15099
G1 X108.626 Y100.002 E.01845
G1 X106.113 Y97.489 E.14886
G1 X106.113 Y97.964 E.0199
G1 X108.667 Y100.517 E.15126
G1 X108.827 Y101.153 E.02747
G1 X106.113 Y98.439 E.16077
G1 X106.113 Y98.914 E.0199
G1 X109.323 Y102.123 E.19012
G1 X109.982 Y103.258 E.05497
G1 X105.962 Y99.238 E.23813
G1 E-5 F3600
G1 X105.962 Y99.238 F9000
G1 X106.065 Y99.238
G1 X111.566 Y94.457
G1 X111.625 Y94.406
G1 X111.801 Y94.271
G1 X111.864 Y94.226
G1 X112.052 Y94.106
G1 X112.119 Y94.067
G1 X112.317 Y93.964
G1 X112.387 Y93.932
G1 X112.593 Y93.847
G1 X112.666 Y93.822
G1 X112.879 Y93.755
G1 X112.954 Y93.736
G1 X113.172 Y93.688
G1 X113.248 Y93.677
G1 X113.469 Y93.648
G1 X113.547 Y93.644
G1 X113.757 Y93.635
G1 X117.243 Y93.635
G1 X117.453 Y93.644
G1 X117.531 Y93.648
G1 X117.752 Y93.677
G1 X117.828 Y93.688
G1 X118.046 Y93.736
G1 X118.121 Y93.755
G1 X118.334 Y93.822
G1 X118.407 Y93.847
G1 X118.613 Y93.932
G1 X118.683 Y93.964
G1 X118.881 Y94.067
G1 X118.948 Y94.106
G1 X119.136 Y94.226
G1 X119.199 Y94.271
G1 X119.375 Y94.406
G1 X119.434 Y94.457
G1 X119.598 Y94.607
G1 X119.652 Y94.663
G1 X119.802 Y94.828
G1 X119.85 Y94.889
G1 X119.985 Y95.065
G1 X120.027 Y95.13
G1 X120.141 Y95.308
G1 X120.563 Y96.04
G1 X120.666 Y96.219
G1 X120.571 Y96.274
G1 E5 F2400
G1 F1200
G1 X124.887 Y100.59 E.25566
G1 X124.887 Y101.065 E.0199
G1 X121.648 Y97.826 E.19187
G1 X121.923 Y98.299 E.02292
G1 X122.165 Y98.818 E.02399
G1 X124.887 Y101.54 E.16124
G1 X124.887 Y102.015 E.0199
G1 X122.331 Y99.458 E.15144
G1 X122.355 Y99.958 E.02097
G1 X124.887 Y102.49 E.14999
G1 X124.887 Y102.965 E.0199
G1 X122.34 Y100.417 E.15091
G1 X122.274 Y100.826 E.01735
G1 X124.887 Y103.44 E.15481
G1 X124.887 Y103.915 E.0199
G1 X122.15 Y101.177 E.16216
G1 X122.015 Y101.518 E.01536
G1 X124.887 Y104.39 E.17013
G1 X124.887 Y104.865 E.0199
G1 X121.841 Y101.818 E.18046
G1 X121.667 Y102.119 E.01456
G1 X124.887 Y105.339 E.19074
G1 X124.887 Y105.814 E.0199
G1 X121.492 Y102.42 E.20108
G1 X121.318 Y102.72 E.01453
G1 X124.887 Y106.289 E.21142
G1 X124.887 Y106.764 E.0199
G1 X121.143 Y103.021 E.22175
G1 X120.969 Y103.321 E.01453
G1 X124.887 Y107.239 E.23209
G1 X124.887 Y107.714 E.0199
G1 X120.795 Y103.622 E.2424
G1 X120.62 Y103.922 E.01455
G1 X124.887 Y108.189 E.25276
G1 X124.887 Y108.664 E.0199
G1 X120.446 Y104.223 E.26307
G1 X120.272 Y104.524 E.01456
G1 X124.887 Y109.139 E.27338
G1 X124.887 Y109.614 E.0199
G1 X120.097 Y104.824 E.28374
G1 X119.996 Y104.999 E.00846
G1 X119.9 Y105.101 E.00587
G1 X124.887 Y110.089 E.29544
G1 X124.887 Y110.564 E.0199
G1 X119.669 Y105.346 E.3091
G1 X119.439 Y105.59 E.01405
G1 X124.887 Y111.039 E.32275
G1 X124.887 Y111.514 E.0199
G1 X119.168 Y105.795 E.33877
G1 X118.884 Y105.985 E.01431
G1 X124.887 Y111.989 E.35563
G1 X124.887 Y112.463 E.01985
G1 X118.559 Y106.136 E.37482
G1 X118.43 Y106.196 E.00596
G1 X118.207 Y106.258 E.00969
G1 X124.887 Y112.938 E.3957
G1 X124.887 Y113.413 E.0199
G1 X117.83 Y106.356 E.41803
G1 X117.398 Y106.399 E.01818
G1 X124.887 Y113.888 E.44362
G1 X124.887 Y114.363 E.0199
G1 X120.673 Y110.149 E.24962
G1 X121.333 Y111.284 E.05499
G1 X124.887 Y114.838 E.21053
G1 X124.887 Y115.313 E.0199
G1 X121.967 Y112.393 E.17297
G1 X122.164 Y112.816 E.01955
G1 X122.251 Y113.152 E.01454
G1 X124.887 Y115.788 E.15615
G1 X124.887 Y116.263 E.0199
G1 X122.345 Y113.721 E.15058
G1 X122.367 Y114.218 E.02084
G1 X124.887 Y116.738 E.14928
G1 X124.887 Y117.213 E.0199
G1 X122.305 Y114.631 E.15295
G1 X122.272 Y114.839 E.00882
G1 X122.21 Y115.011 E.00766
G1 X124.887 Y117.688 E.15858
G1 X124.887 Y118.163 E.0199
G1 X122.084 Y115.36 E.16604
G1 X122.046 Y115.464 E.00464
G1 X121.924 Y115.675 E.01021
G1 X124.887 Y118.638 E.17552
G1 X124.887 Y119.113 E.0199
G1 X121.75 Y115.975 E.18585
G1 X121.575 Y116.276 E.01458
G1 X124.887 Y119.588 E.19619
G1 X124.887 Y120.062 E.01985
G1 X121.401 Y116.577 E.20647
G1 X121.227 Y116.877 E.01453
G1 X124.887 Y120.537 E.21681
G1 X124.887 Y121.012 E.0199
G1 X121.052 Y117.178 E.22714
G1 X120.878 Y117.478 E.01453
G1 X124.887 Y121.487 E.23748
G1 X124.887 Y121.962 E.0199
G1 X120.704 Y117.779 E.24779
G1 X120.529 Y118.079 E.01455
G1 X124.887 Y122.437 E.25815
G1 X124.887 Y122.912 E.0199
G1 X120.355 Y118.38 E.26846
G1 X120.181 Y118.681 E.01456
G1 X124.887 Y123.387 E.27877
G1 X124.887 Y123.862 E.0199
G1 X120.006 Y118.981 E.28913
G1 X119.779 Y119.229 E.01408
G1 X124.887 Y124.337 E.30258
G1 X124.887 Y124.812 E.0199
G1 X119.549 Y119.474 E.3162
G1 X119.388 Y119.645 E.00984
G1 X119.303 Y119.703 E.00431
G1 X124.887 Y125.287 E.33078
G1 X124.887 Y125.762 E.0199
G1 X119.022 Y119.897 E.34742
G1 X118.712 Y120.062 E.01471
G1 X124.887 Y126.237 E.36579
G1 X124.887 Y126.712 E.0199
G1 X118.384 Y120.209 E.38522
G1 X118.013 Y120.312 E.01613
G1 X124.887 Y127.186 E.40719
G1 X124.887 Y127.661 E.0199
G1 X117.604 Y120.379 E.43139
G1 X117.162 Y120.412 E.01857
G1 X118.682 Y121.932 E.09004
G1 X118.992 Y122.077 E.01434
G1 X119.617 Y122.558 E.03303
G1 X120.041 Y123.062 E.02759
G1 X120.358 Y123.607 E.02641
G1 X124.887 Y128.136 E.26828
G1 X124.887 Y128.611 E.0199
G1 X121.018 Y124.742 E.22919
G1 X121.678 Y125.877 E.05499
G1 X124.887 Y129.086 E.19009
G1 X124.887 Y129.561 E.0199
G1 X122.172 Y126.846 E.16083
G1 X122.335 Y127.484 E.02758
G1 X124.887 Y130.036 E.15117
G1 X124.887 Y130.511 E.0199
G1 X122.356 Y127.98 E.14993
G1 X122.368 Y128.241 E.01094
G1 X122.337 Y128.436 E.00827
G1 X124.887 Y130.986 E.15105
G1 X124.887 Y131.461 E.0199
G1 X122.27 Y128.844 E.15502
G1 X122.144 Y129.193 E.01554
G1 X124.887 Y131.936 E.16249
G1 X124.887 Y132.411 E.0199
G1 X122.008 Y129.531 E.17057
G1 X121.833 Y129.832 E.01458
G1 X124.887 Y132.886 E.18091
G1 X124.887 Y133.361 E.0199
G1 X121.659 Y130.133 E.19122
G1 X121.485 Y130.434 E.01456
G1 X124.887 Y133.836 E.20152
G1 X124.887 Y134.311 E.0199
G1 X121.311 Y130.734 E.21186
G1 X121.137 Y131.035 E.01456
G1 X124.887 Y134.785 E.22214
G1 X124.887 Y135.26 E.0199
G1 X120.962 Y131.336 E.23247
G1 X120.788 Y131.637 E.01456
G1 X124.887 Y135.735 E.24278
G1 X124.887 Y136.21 E.0199
G1 X120.614 Y131.937 E.25312
G1 X120.44 Y132.238 E.01456
G1 X124.887 Y136.685 E.26342
G1 X124.887 Y136.798 E.00473
G1 X124.922 Y136.958 E.00686
G1 X125.07 Y137.275 E.01465
G1 X125.088 Y137.361 E.00368
G1 X120.266 Y132.539 E.28564
G1 X120.091 Y132.839 E.01455
G1 X124.824 Y137.572 E.28037
G1 X124.349 Y137.572 E.0199
G1 X119.889 Y133.112 E.2642
G1 X119.659 Y133.357 E.01408
G1 X123.874 Y137.572 E.24968
G1 X123.399 Y137.572 E.0199
G1 X119.428 Y133.601 E.23523
G1 X119.156 Y133.804 E.01422
G1 X122.924 Y137.572 E.2232
G1 X122.449 Y137.572 E.0199
G1 X118.866 Y133.989 E.21224
G1 X118.544 Y134.142 E.01493
G1 X121.974 Y137.572 E.20318
G1 X121.499 Y137.572 E.0199
G1 X118.188 Y134.261 E.19613
G1 X117.814 Y134.362 E.01623
G1 X121.024 Y137.572 E.19015
G1 X120.549 Y137.572 E.0199
G1 X117.379 Y134.402 E.18778
G1 X116.914 Y134.412 E.01948
G1 X120.074 Y137.572 E.18719
G1 X119.599 Y137.572 E.0199
G1 X116.44 Y134.412 E.18716
G1 X115.965 Y134.412 E.0199
G1 X119.125 Y137.572 E.18719
G1 X118.65 Y137.572 E.0199
G1 X115.49 Y134.412 E.18719
G1 X115.015 Y134.413 E.0199
G1 X118.175 Y137.572 E.18716
G1 X117.7 Y137.572 E.0199
G1 X114.541 Y134.413 E.18713
G1 X114.066 Y134.413 E.0199
G1 X117.225 Y137.572 E.18713
G1 X116.75 Y137.572 E.0199
G1 X113.566 Y134.388 E.18861
G1 X113.019 Y134.316 E.02311
G1 X116.426 Y137.723 E.20182
G1 E-5 F3600
G1 X116.426 Y137.723 F9000
G1 X116.426 Y137.621
G1 X119.985 Y132.935
G1 X120.027 Y132.87
G1 X120.141 Y132.692
G1 X121.884 Y129.673
G1 X121.981 Y129.486
G1 X122.016 Y129.417
G1 X122.102 Y129.211
G1 X122.13 Y129.139
G1 X122.197 Y128.927
G1 X122.219 Y128.853
G1 X122.267 Y128.635
G1 X122.282 Y128.559
G1 X122.311 Y128.338
G1 X122.319 Y128.261
G1 X122.328 Y128.039
G1 X122.328 Y127.961
G1 X122.319 Y127.739
G1 X122.311 Y127.662
G1 X122.282 Y127.441
G1 X122.267 Y127.365
G1 X122.219 Y127.147
G1 X122.197 Y127.073
G1 X122.13 Y126.861
G1 X122.102 Y126.789
G1 X122.016 Y126.583
G1 X121.981 Y126.514
G1 X121.884 Y126.327
G1 X120.141 Y123.308
G1 X120.027 Y123.13
G1 X119.985 Y123.065
G1 X119.85 Y122.889
G1 X119.802 Y122.828
G1 X119.652 Y122.663
G1 X119.598 Y122.607
G1 X119.434 Y122.457
G1 X119.375 Y122.406
G1 X119.199 Y122.271
G1 X119.136 Y122.226
G1 X118.948 Y122.106
G1 X118.881 Y122.067
G1 X118.683 Y121.964
G1 X118.613 Y121.932
G1 X118.407 Y121.847
G1 X118.334 Y121.822
G1 X118.202 Y121.78
G1 X118.167 Y121.891
G1 E5 F2400
G1 F1200
G1 X116.688 Y120.412 E.08761
G1 X116.213 Y120.412 E.0199
G1 X117.399 Y121.598 E.07025
G1 X116.923 Y121.597 E.01994
G1 X115.738 Y120.412 E.0702
G1 X115.263 Y120.412 E.0199
G1 X116.446 Y121.595 E.07008
G1 X115.97 Y121.594 E.01994
G1 X114.789 Y120.413 E.06996
G1 X114.314 Y120.413 E.0199
G1 X115.493 Y121.592 E.06984
G1 X115.017 Y121.591 E.01994
G1 X113.839 Y120.413 E.06978
G1 X113.302 Y120.351 E.02264
G1 X114.541 Y121.589 E.07336
G1 X114.064 Y121.588 E.01998
G1 X112.425 Y119.949 E.09709
G1 E-5 F3600
G1 X112.425 Y119.949 F9000
G1 X112.374 Y120.062
G1 X111.15 Y119.111
G1 X110.973 Y118.87
G1 X108.87 Y115.139
G1 X108.87 Y112.861
G1 X110.973 Y109.13
G1 X111.15 Y108.889
G1 X113.469 Y107.648
G1 X113.547 Y107.644
G1 X113.757 Y107.635
G1 X116.347 Y107.635
G1 X116.785 Y106.365
G1 X116.785 Y106.261
G1 E5 F2400
G1 F1200
G1 X118.286 Y107.762 E.08891
G1 X117.685 Y107.636 E.02572
G1 X116.461 Y106.412 E.07251
G1 X115.986 Y106.412 E.0199
G1 X117.171 Y107.598 E.07022
G1 X116.695 Y107.596 E.01994
G1 X115.511 Y106.412 E.07014
G1 X115.037 Y106.413 E.01985
G1 X116.219 Y107.595 E.07002
G1 X115.742 Y107.593 E.01998
G1 X114.562 Y106.413 E.0699
G1 X114.087 Y106.413 E.0199
G1 X115.266 Y107.592 E.06984
G1 X114.789 Y107.59 E.01998
G1 X113.589 Y106.39 E.07108
G1 X113.039 Y106.315 E.02325
G1 X114.313 Y107.589 E.07547
G1 X113.837 Y107.587 E.01994
G1 X112.318 Y106.068 E.08998
G1 X112.117 Y105.986 E.00909
G1 X111.538 Y105.583 E.02955
G1 X110.96 Y104.939 E.03625
G1 X110.642 Y104.393 E.02647
G1 X106.113 Y99.864 E.26828
G1 X106.113 Y100.339 E.0199
G1 X113.405 Y107.631 E.43195
G1 X112.982 Y107.683 E.01785
G1 X106.113 Y100.814 E.4069
G1 X106.113 Y101.289 E.0199
G1 X112.629 Y107.804 E.38596
G1 X112.28 Y107.93 E.01554
G1 X106.113 Y101.763 E.36531
G1 X106.113 Y102.238 E.0199
G1 X111.99 Y108.116 E.34816
G1 X111.702 Y108.302 E.01436
G1 X106.113 Y102.713 E.33107
G1 X106.113 Y103.188 E.0199
G1 X111.449 Y108.524 E.31609
G1 X111.222 Y108.773 E.01411
G1 X106.113 Y103.663 E.30267
G1 X106.113 Y104.138 E.0199
G1 X110.996 Y109.021 E.28925
G1 X110.813 Y109.313 E.01443
G1 X106.113 Y104.613 E.27841
G1 X106.113 Y105.088 E.0199
G1 X110.639 Y109.614 E.2681
G1 X110.464 Y109.914 E.01455
G1 X106.113 Y105.563 E.25774
G1 X106.113 Y106.038 E.0199
G1 X110.289 Y110.214 E.24737
G1 X110.115 Y110.514 E.01453
G1 X106.113 Y106.513 E.23704
G1 X106.113 Y106.988 E.0199
G1 X109.94 Y110.815 E.2267
G1 X109.765 Y111.115 E.01455
G1 X106.113 Y107.463 E.21633
G1 X106.113 Y107.938 E.0199
G1 X109.591 Y111.415 E.206
G1 X109.416 Y111.716 E.01458
G1 X106.113 Y108.413 E.19566
G1 X106.113 Y108.887 E.01985
G1 X109.242 Y112.016 E.18535
G1 X109.068 Y112.318 E.0146
G1 X106.113 Y109.362 E.17507
G1 X106.113 Y109.837 E.0199
G1 X108.92 Y112.644 E.16628
G1 X108.815 Y112.872 E.01051
G1 X108.786 Y112.985 E.00489
G1 X106.113 Y110.312 E.15834
G1 X106.113 Y110.787 E.0199
G1 X108.687 Y113.361 E.15247
G1 X108.64 Y113.789 E.01804
G1 X106.113 Y111.262 E.14969
G1 X106.113 Y111.737 E.0199
G1 X108.647 Y114.271 E.15011
G1 X108.671 Y114.572 E.01265
G1 X108.744 Y114.843 E.01176
G1 X106.113 Y112.212 E.15585
G1 X106.113 Y112.687 E.0199
G1 X109.033 Y115.607 E.17297
G1 X109.667 Y116.716 E.05351
G1 X106.113 Y113.162 E.21053
G1 X106.113 Y113.637 E.0199
G1 X110.745 Y118.268 E.27435
G1 E-5 F3600
G1 X110.745 Y118.268 F9000
G1 X113.743 Y121.741
G1 E5 F2400
G1 F1200
G1 X106.113 Y114.112 E.45195
G1 X106.113 Y114.587 E.0199
G1 X113.184 Y121.658 E.41886
G1 X112.956 Y121.686 E.00962
G1 X112.795 Y121.744 E.00717
G1 X106.113 Y115.062 E.39582
G1 X106.113 Y115.537 E.0199
G1 X112.446 Y121.87 E.37515
G1 X112.274 Y121.932 E.00766
G1 X112.128 Y122.026 E.00727
G1 X106.113 Y116.012 E.35628
G1 X106.113 Y116.486 E.01985
G1 X111.839 Y122.213 E.33922
G1 X111.557 Y122.405 E.01429
G1 X106.113 Y116.961 E.32248
G1 X106.113 Y117.436 E.0199
G1 X111.33 Y122.654 E.30907
G1 X111.104 Y122.902 E.01405
G1 X106.113 Y117.911 E.29565
G1 X106.113 Y118.386 E.0199
G1 X110.897 Y123.17 E.28339
G1 X110.722 Y123.47 E.01455
G1 X106.113 Y118.861 E.27302
G1 X106.113 Y119.336 E.0199
G1 X110.547 Y123.77 E.26265
G1 X110.373 Y124.071 E.01456
G1 X106.113 Y119.811 E.25235
G1 X106.113 Y120.286 E.0199
G1 X110.198 Y124.371 E.24198
G1 X110.023 Y124.671 E.01455
G1 X106.113 Y120.761 E.23161
G1 X106.113 Y121.236 E.0199
G1 X109.849 Y124.972 E.22131
G1 X109.674 Y125.272 E.01455
G1 X106.113 Y121.711 E.21094
G1 X106.113 Y122.186 E.0199
G1 X109.5 Y125.572 E.2006
G1 X109.325 Y125.873 E.01458
G1 X106.113 Y122.661 E.19027
G1 X106.113 Y123.136 E.0199
G1 X109.15 Y126.173 E.1799
G1 X108.991 Y126.488 E.01478
G1 X106.113 Y123.61 E.17048
G1 X106.113 Y124.085 E.0199
G1 X108.842 Y126.814 E.16166
G1 X108.734 Y127.182 E.01606
G1 X106.113 Y124.56 E.15529
G1 X106.113 Y125.035 E.0199
G1 X108.66 Y127.582 E.15088
G1 X108.628 Y128.025 E.0186
G1 X106.113 Y125.51 E.14898
G1 X106.113 Y125.985 E.0199
G1 X108.668 Y128.541 E.15138
G1 X108.835 Y129.182 E.02775
G1 X106.113 Y126.46 E.16124
G1 X106.113 Y126.935 E.0199
G1 X109.352 Y130.174 E.19187
G1 X110.012 Y131.309 E.05499
G1 X106.113 Y127.41 E.23096
G1 X106.113 Y127.885 E.0199
G1 X110.672 Y132.444 E.27006
G1 X110.96 Y132.939 E.02399
G1 X111.508 Y133.555 E.03453
G1 X112.13 Y133.992 E.03184
G1 X112.279 Y134.051 E.00671
G1 X115.8 Y137.572 E.20857
G1 X115.325 Y137.572 E.0199
G1 X106.113 Y128.36 E.54569
G1 X106.113 Y128.835 E.0199
G1 X114.85 Y137.572 E.51755
G1 X114.375 Y137.572 E.0199
G1 X106.113 Y129.31 E.48941
G1 X106.113 Y129.785 E.0199
G1 X113.9 Y137.572 E.46128
G1 X113.425 Y137.572 E.0199
G1 X106.113 Y130.26 E.43314
G1 X106.113 Y130.735 E.0199
G1 X112.95 Y137.572 E.405
G1 X112.475 Y137.572 E.0199
G1 X106.113 Y131.209 E.37689
G1 X106.113 Y131.684 E.0199
G1 X112 Y137.572 E.34876
G1 X111.526 Y137.572 E.01985
G1 X106.113 Y132.159 E.32065
G1 X106.113 Y132.634 E.0199
G1 X111.051 Y137.572 E.29251
G1 X110.576 Y137.572 E.0199
G1 X106.113 Y133.109 E.26437
G1 X106.113 Y133.584 E.0199
G1 X110.101 Y137.572 E.23624
G1 X109.626 Y137.572 E.0199
G1 X106.113 Y134.059 E.2081
G1 X106.113 Y134.534 E.0199
G1 X109.151 Y137.572 E.17996
G1 X108.676 Y137.572 E.0199
G1 X106.113 Y135.009 E.15182
G1 X106.113 Y135.484 E.0199
G1 X108.201 Y137.572 E.12369
G1 X107.726 Y137.572 E.0199
G1 X106.113 Y135.959 E.09555
G1 X106.113 Y136.434 E.0199
G1 X107.251 Y137.572 E.06741
G1 X106.776 Y137.572 E.0199
G1 X106.093 Y136.888 E.04049
G1 X105.953 Y137.224 E.01525
G1 X106.452 Y137.723 E.02956
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X105.953 Y137.224 E-.3352
G1 X106.093 Y136.888 E-.1729
G1 X106.776 Y137.572 E-.45914
G1 X107.251 Y137.572 E-.22563
G1 X106.794 Y137.115 E-.30713
;WIPE_END
G1 X106.793 Y137.622 F9000
G1 X108.506 Y90.378
G1 X109.5 Y90.379
G1 X109.733 Y90.379
G1 X109.874 Y88.135
G1 X109.97 Y86.615
G1 X109.847 Y85.135
G1 X110.05 Y85.338
G1 E5 F2400
;WIDTH:0.4
G1 F1200
G1 X104.278 Y85.328 E.24162
G1 X103.74 Y85.247 E.02277
G1 X103.221 Y85.087 E.02273
G1 X102.731 Y84.851 E.02277
G1 X102.282 Y84.544 E.02277
G1 X101.883 Y84.175 E.02275
G1 X101.544 Y83.749 E.02279
G1 X101.274 Y83.281 E.02262
G1 X101.003 Y82.506 E.03437
G1 X100.911 Y81.694 E.03421
G1 X100.911 Y78.294 E.14232
G1 X100.723 Y77.878 E.01911
G1 X100.639 Y77.562 E.01369
G1 X100.7 Y77.177 E.01632
G1 X130.3 Y77.176 E1.23906
G1 X130.327 Y77.253 E.00342
G1 X130.354 Y77.44 E.00791
G1 X130.284 Y77.842 E.01708
G1 X130.089 Y78.29 E.02045
G1 X130.089 Y81.258 E.12424
G1 X130.068 Y81.971 E.02986
G1 X129.987 Y82.507 E.02269
G1 X129.827 Y83.025 E.02269
G1 X129.592 Y83.514 E.02271
G1 X129.286 Y83.962 E.02271
G1 X128.918 Y84.359 E.02266
G1 X128.494 Y84.697 E.0227
G1 X128.024 Y84.969 E.02273
G1 X127.519 Y85.167 E.02271
G1 X126.991 Y85.287 E.02267
G1 X126.444 Y85.339 E.023
G1 X120.979 Y85.339 E.22877
G1 X120.833 Y85.149 E.01003
G1 X120.782 Y85.141 E.00216
G1 X110.218 Y85.141 E.44221
G1 X110.168 Y85.149 E.00212
G1 X110.082 Y85.287 E.00681
G1 E-5 F3600
G1 X110.082 Y85.287 F9000
G1 X109.847 Y85.135
G1 X109.847 Y84.938
G1 X130.048 Y77.907
G1 X130.074 Y77.852
G1 X130.165 Y77.894
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.400309
G1 F1200
G1 X129.699 Y77.428 E.02761
G1 X129.223 Y77.428 E.01994
G1 X129.887 Y78.092 E.03934
G1 X129.837 Y78.28 E.00815
G1 X129.837 Y78.517 E.00993
G1 X128.748 Y77.428 E.06453
G1 X128.273 Y77.428 E.0199
G1 X129.837 Y78.992 E.09267
G1 X129.837 Y79.467 E.0199
G1 X127.798 Y77.428 E.12082
G1 X127.323 Y77.428 E.0199
G1 X129.837 Y79.942 E.14896
G1 X129.837 Y80.417 E.0199
G1 X126.848 Y77.428 E.17711
G1 X126.373 Y77.428 E.0199
G1 X129.837 Y80.892 E.20526
G1 X129.837 Y81.367 E.0199
G1 X125.898 Y77.428 E.2334
G1 X125.423 Y77.428 E.0199
G1 X129.826 Y81.831 E.26089
G1 X129.784 Y82.265 E.01827
G1 X124.948 Y77.428 E.28658
G1 X124.473 Y77.428 E.0199
G1 X129.696 Y82.651 E.30948
G1 X129.567 Y82.998 E.01551
G1 X123.998 Y77.428 E.33001
G1 X123.523 Y77.428 E.0199
G1 X129.414 Y83.319 E.34906
G1 X129.238 Y83.619 E.01457
G1 X123.047 Y77.428 E.36684
G1 X122.572 Y77.428 E.0199
G1 X129.027 Y83.883 E.38248
G1 X128.797 Y84.128 E.01408
G1 X122.097 Y77.428 E.397
G1 X121.622 Y77.428 E.0199
G1 X128.549 Y84.355 E.41045
G1 X128.267 Y84.548 E.01432
G1 X121.147 Y77.428 E.42189
G1 X120.672 Y77.428 E.0199
G1 X127.963 Y84.719 E.43202
G1 X127.636 Y84.867 E.01504
G1 X120.197 Y77.428 E.44079
G1 X119.722 Y77.428 E.0199
G1 X127.273 Y84.979 E.44743
G1 X126.87 Y85.051 E.01715
G1 X119.247 Y77.428 E.45169
G1 X118.772 Y77.428 E.0199
G1 X126.431 Y85.087 E.45383
G1 X125.956 Y85.087 E.0199
G1 X118.297 Y77.428 E.45383
G1 X117.822 Y77.428 E.0199
G1 X125.48 Y85.087 E.4538
G1 X125.005 Y85.087 E.0199
G1 X117.347 Y77.428 E.4538
G1 X116.872 Y77.428 E.0199
G1 X124.53 Y85.087 E.4538
G1 X124.055 Y85.087 E.0199
G1 X116.396 Y77.428 E.45383
G1 X115.921 Y77.428 E.0199
G1 X123.58 Y85.087 E.45383
G1 X123.105 Y85.087 E.0199
G1 X115.446 Y77.428 E.45383
G1 X114.971 Y77.428 E.0199
G1 X122.63 Y85.087 E.45383
G1 X122.155 Y85.087 E.0199
G1 X114.496 Y77.428 E.45383
G1 X114.021 Y77.428 E.0199
G1 X121.68 Y85.087 E.45383
G1 X121.205 Y85.087 E.0199
G1 X113.546 Y77.428 E.45383
G1 X113.071 Y77.428 E.0199
G1 X120.532 Y84.89 E.44212
G1 X120.057 Y84.89 E.0199
G1 X112.596 Y77.428 E.44212
G1 X112.121 Y77.428 E.0199
G1 X119.582 Y84.89 E.44212
G1 X119.107 Y84.89 E.0199
G1 X111.646 Y77.428 E.44212
G1 X111.171 Y77.428 E.0199
G1 X118.632 Y84.89 E.44212
G1 X118.157 Y84.89 E.0199
G1 X110.696 Y77.428 E.44212
G1 X110.22 Y77.428 E.01994
G1 X117.682 Y84.89 E.44215
G1 X117.207 Y84.89 E.0199
G1 X109.745 Y77.428 E.44215
G1 X109.27 Y77.428 E.0199
G1 X116.732 Y84.89 E.44215
G1 X116.257 Y84.89 E.0199
G1 X108.795 Y77.428 E.44215
G1 X108.32 Y77.428 E.0199
G1 X115.782 Y84.89 E.44215
G1 X115.307 Y84.89 E.0199
G1 X107.845 Y77.428 E.44215
G1 X107.37 Y77.428 E.0199
G1 X114.832 Y84.89 E.44215
G1 X114.356 Y84.89 E.01994
G1 X106.895 Y77.428 E.44212
G1 X106.42 Y77.428 E.0199
G1 X113.881 Y84.89 E.44212
G1 X113.406 Y84.89 E.0199
G1 X105.945 Y77.428 E.44212
G1 X105.47 Y77.428 E.0199
G1 X112.931 Y84.89 E.44212
G1 X112.456 Y84.89 E.0199
G1 X104.995 Y77.428 E.44212
G1 X104.52 Y77.428 E.0199
G1 X111.981 Y84.89 E.44212
G1 X111.506 Y84.89 E.0199
G1 X104.045 Y77.428 E.44212
G1 X103.569 Y77.428 E.01994
G1 X111.031 Y84.89 E.44215
G1 X110.556 Y84.89 E.0199
G1 X103.094 Y77.428 E.44215
G1 X102.619 Y77.428 E.0199
G1 X110.084 Y84.893 E.44233
G1 X109.942 Y85.086 E.01004
G1 X109.802 Y85.086 E.00587
G1 X102.144 Y77.428 E.45377
G1 X101.669 Y77.428 E.0199
G1 X109.326 Y85.085 E.45371
G1 X108.85 Y85.084 E.01994
G1 X101.194 Y77.428 E.45365
G1 X100.908 Y77.428 E.01198
G1 X100.894 Y77.549 E.0051
G1 X100.909 Y77.618 E.00296
G1 X108.374 Y85.084 E.44236
G1 X107.898 Y85.083 E.01994
G1 X101.163 Y78.347 E.3991
G1 X101.163 Y78.822 E.0199
G1 X107.423 Y85.082 E.37093
G1 X106.947 Y85.081 E.01994
G1 X101.163 Y79.297 E.34272
G1 X101.163 Y79.773 E.01994
G1 X106.471 Y85.08 E.31449
G1 X105.995 Y85.079 E.01994
G1 X101.163 Y80.248 E.28628
G1 X101.163 Y80.723 E.0199
G1 X105.519 Y85.078 E.25808
G1 X105.043 Y85.078 E.01994
G1 X101.163 Y81.198 E.2299
G1 X101.163 Y81.673 E.0199
G1 X104.567 Y85.077 E.2017
G1 X104.297 Y85.076 E.01131
G1 X104.055 Y85.04 E.01025
G1 X101.21 Y82.195 E.16858
G1 X101.248 Y82.446 E.01064
G1 X101.389 Y82.849 E.01789
G1 X103.655 Y85.115 E.13427
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X101.422 Y82.882 E-1.5
;WIPE_END
G1 X101.337 Y82.912 F9000
G1 X102.313 Y84.303
G1 X103.746 Y86.59
G1 X104.635 Y88.407
G1 X104.886 Y88.407
G1 E5 F2400
;WIDTH:0.4
G1 F1200
G1 X104.9 Y88.377 E.00139
G1 X105.006 Y88.339 E.00471
G1 X125.994 Y88.339 E.87856
G1 X126.114 Y88.389 E.00544
G1 X126.161 Y88.506 E.00528
G1 X126.161 Y90.19 E.07049
G1 X126.198 Y90.521 E.01394
G1 X126.161 Y90.945 E.01782
G1 X126.161 Y93.098 E.09013
G1 X139.209 Y93.098 E.54619
G1 X139.419 Y93.145 E.00901
G1 X139.598 Y93.262 E.00895
G1 X139.846 Y93.262 E.01038
G1 X139.942 Y93.302 E.00435
G1 X140 Y93.429 E.00584
G1 X140 Y95.399 E.08246
G1 X139.942 Y95.527 E.00588
G1 X139.61 Y95.567 E.014
G1 X139.492 Y95.65 E.00604
G1 X139.209 Y95.731 E.01232
G1 X136.861 Y95.731 E.09829
G1 X136.859 Y132.813 E1.55226
G1 X136.823 Y133.464 E.02729
G1 X136.638 Y134.736 E.05381
G1 X136.484 Y135.362 E.02699
G1 X136.237 Y136.142 E.03425
G1 X135.862 Y137.04 E.04074
G1 X135.567 Y137.61 E.02687
G1 X135.146 Y138.311 E.03423
G1 X134.572 Y139.096 E.04071
G1 X134.152 Y139.582 E.02689
G1 X133.579 Y140.166 E.03425
G1 X132.839 Y140.796 E.04068
G1 X132.305 Y141.179 E.02751
G1 X131.199 Y141.834 E.05381
G1 X129.856 Y142.402 E.06104
G1 X129.224 Y142.594 E.02765
G1 X127.966 Y142.857 E.0538
G1 X126.994 Y142.95 E.04087
G1 X104.498 Y142.962 E.94169
G1 X103.536 Y142.916 E.04032
G1 X102.572 Y142.78 E.04075
G1 X101.772 Y142.593 E.03439
G1 X100.706 Y142.242 E.04698
G1 X99.94 Y141.901 E.0351
G1 X98.972 Y141.364 E.04634
G1 X98.283 Y140.886 E.0351
G1 X97.433 Y140.177 E.04633
G1 X96.845 Y139.579 E.03511
G1 X96.142 Y138.724 E.04634
G1 X95.684 Y138.039 E.03449
G1 X95.145 Y137.055 E.04697
G1 X94.768 Y136.157 E.04077
G1 X94.478 Y135.228 E.04074
G1 X94.208 Y133.796 E.061
G1 X94.138 Y132.911 E.03716
G1 X94.139 Y95.731 E1.55636
G1 X91.791 Y95.731 E.09829
G1 X91.582 Y95.683 E.00898
G1 X91.402 Y95.567 E.00896
G1 X91.154 Y95.566 E.01038
G1 X91.059 Y95.527 E.0043
G1 X91 Y95.399 E.0059
G1 X91 Y93.429 E.08246
G1 X91.059 Y93.302 E.00586
G1 X91.39 Y93.262 E.01396
G1 X91.509 Y93.178 E.0061
G1 X91.791 Y93.098 E.01227
G1 X101.736 Y93.098 E.4163
G1 X104.839 Y93.098 E.12989
G1 X104.839 Y90.81 E.09578
G1 X104.814 Y90.383 E.0179
G1 X104.839 Y88.506 E.07858
G1 X104.86 Y88.461 E.00208
G1 E-5 F3600
G1 X104.86 Y88.461 F9000
G1 X104.635 Y88.461
G1 X101.134 Y85.432
G1 X101.053 Y85.356
G1 X100.894 Y85.197
G1 X100.818 Y85.116
G1 X100.671 Y84.945
G1 X100.602 Y84.859
G1 X100.468 Y84.677
G1 X100.405 Y84.586
G1 X100.285 Y84.395
G1 X100.228 Y84.3
G1 X100.123 Y84.101
G1 X100.074 Y84.002
G1 X99.983 Y83.795
G1 X99.941 Y83.693
G1 X99.867 Y83.48
G1 X99.832 Y83.375
G1 X99.773 Y83.157
G1 X99.746 Y83.05
G1 X99.704 Y82.829
G1 X99.684 Y82.72
G1 X99.659 Y82.496
G1 X99.647 Y82.386
G1 X99.639 Y82.16
G1 X99.635 Y82.059
G1 X99.612 Y77.724
G1 X99.598 Y77.515
G1 X99.824 Y77.5
G1 E5 F2400
G1 F1200
G1 X99.818 Y77.355 E.00607
G1 X99.839 Y76.269 E.04547
G1 X99.906 Y76.135 E.00627
G1 X100.006 Y76.101 E.00442
G1 X130.994 Y76.101 E1.29717
G1 X131.094 Y76.135 E.00442
G1 X131.161 Y76.269 E.00627
G1 X131.161 Y77.19 E.03855
G1 X131.19 Y77.581 E.01641
G1 X131.161 Y78.777 E.05008
G1 X131.161 Y82.053 E.13713
G1 X131.116 Y82.678 E.02623
G1 X130.976 Y83.305 E.02689
G1 X130.747 Y83.905 E.02688
G1 X130.431 Y84.465 E.02692
G1 X130.037 Y84.971 E.02685
G1 X129.721 Y85.287 E.01871
G1 X129.235 Y85.667 E.02582
G1 X128.388 Y86.111 E.04003
G1 X127.803 Y86.291 E.02562
G1 X126.803 Y86.411 E.04216
G1 X104.197 Y86.411 E.94629
G1 X103.572 Y86.366 E.02623
G1 X103.03 Y86.245 E.02325
G1 X102.51 Y86.06 E.0231
G1 X101.785 Y85.681 E.03425
G1 X101.279 Y85.287 E.02685
G1 X100.773 Y84.746 E.03101
G1 X100.413 Y84.212 E.02696
G1 X100.136 Y83.632 E.02691
G1 X99.948 Y83.019 E.02684
G1 X99.839 Y82.053 E.04069
G1 X99.839 Y77.81 E.17761
G1 X99.827 Y77.56 E.01048
G1 E-5 F3600
G1 X99.827 Y77.56 F9000
G1 X99.827 Y74.372
G1 E5 F2400
G1 F1200
G1 X134.833 Y74.369 E1.46536
G1 X135.951 Y74.385 E.0468
G1 X136.605 Y74.481 E.02767
G1 X137.23 Y74.642 E.02702
G1 X137.839 Y74.87 E.02722
G1 X138.356 Y75.14 E.02442
G1 X139.013 Y75.59 E.03333
G1 X139.447 Y75.974 E.02426
G1 X140.117 Y76.765 E.04339
G1 X140.629 Y77.661 E.0432
G1 X140.97 Y78.635 E.0432
G1 X141.128 Y79.658 E.04333
G1 X141.128 Y80.039 E.01595
G1 X141.139 Y150.992 E2.97011
G1 X141.096 Y151.688 E.02919
G1 X140.97 Y152.365 E.02883
G1 X140.763 Y153.022 E.02883
G1 X140.477 Y153.649 E.02885
G1 X140.117 Y154.236 E.02882
G1 X139.687 Y154.775 E.02886
G1 X139.277 Y155.186 E.0243
G1 X138.445 Y155.807 E.04346
G1 X137.84 Y156.13 E.02871
G1 X137.197 Y156.377 E.02883
G1 X136.528 Y156.544 E.02886
G1 X135.845 Y156.628 E.02881
G1 X95.508 Y156.639 E1.68852
G1 X94.812 Y156.596 E.02919
G1 X94.135 Y156.47 E.02883
G1 X93.478 Y156.263 E.02883
G1 X92.851 Y155.977 E.02885
G1 X92.264 Y155.617 E.02882
G1 X91.725 Y155.187 E.02886
G1 X91.314 Y154.777 E.0243
G1 X90.693 Y153.945 E.04346
G1 X90.37 Y153.34 E.02871
G1 X90.123 Y152.697 E.02883
G1 X89.956 Y152.029 E.02882
G1 X89.869 Y151.237 E.03335
G1 X89.861 Y80.008 E2.98166
G1 X89.904 Y79.312 E.02919
G1 X90.03 Y78.635 E.02883
G1 X90.237 Y77.978 E.02883
G1 X90.523 Y77.351 E.02885
G1 X90.883 Y76.764 E.02882
G1 X91.313 Y76.225 E.02886
G1 X91.723 Y75.814 E.0243
G1 X92.555 Y75.193 E.04346
G1 X93.16 Y74.87 E.02871
G1 X93.803 Y74.623 E.02883
G1 X94.472 Y74.456 E.02886
G1 X95.155 Y74.372 E.02881
G1 X99.767 Y74.372 E.19306
G1 E-5 F3600
G1 X99.767 Y74.372 F9000
G1 X102.678 Y74.565
G1 X139.377 Y76.192
G1 X140.006 Y76.962
G1 X140.091 Y77.094
G1 X140.162 Y77.047
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.401179
G1 F1200
G1 X139.264 Y76.149 E.05335
G1 X138.858 Y75.789 E.02279
G1 X138.226 Y75.356 E.03218
G1 X137.742 Y75.103 E.02294
G1 X140.393 Y77.754 E.15749
G1 X140.653 Y78.49 E.03279
G1 X136.996 Y74.833 E.21725
G1 X136.806 Y74.774 E.00836
G1 X136.382 Y74.696 E.01811
G1 X140.787 Y79.101 E.26169
G1 X140.874 Y79.664 E.02393
G1 X135.839 Y74.629 E.29912
G1 X135.354 Y74.621 E.02038
G1 X140.876 Y80.142 E.32802
G1 X140.876 Y80.619 E.02004
G1 X134.878 Y74.621 E.35632
G1 X134.402 Y74.621 E.02
G1 X140.876 Y81.095 E.3846
G1 X140.876 Y81.571 E.02
G1 X133.926 Y74.621 E.41288
G1 X133.449 Y74.621 E.02004
G1 X140.876 Y82.048 E.44122
G1 X140.876 Y82.524 E.02
G1 X132.973 Y74.621 E.4695
G1 X132.497 Y74.621 E.02
G1 X140.877 Y83.001 E.49783
G1 X140.877 Y83.477 E.02
G1 X132.02 Y74.621 E.52614
G1 X131.544 Y74.621 E.02
G1 X140.877 Y83.953 E.55442
G1 X140.877 Y84.43 E.02004
G1 X131.068 Y74.621 E.58273
G1 X130.592 Y74.621 E.02
G1 X140.877 Y84.906 E.611
G1 X140.877 Y85.383 E.02004
G1 X130.115 Y74.621 E.63934
G1 X129.639 Y74.621 E.02
G1 X130.868 Y75.85 E.07301
G1 X131.007 Y75.85 E.00584
G1 X131.246 Y75.929 E.01057
G1 X131.382 Y76.104 E.00931
G1 X131.413 Y76.261 E.00672
G1 X131.413 Y76.395 E.00563
G1 X140.877 Y85.859 E.56223
G1 X140.877 Y86.335 E.02
G1 X131.413 Y76.871 E.56223
G1 X131.413 Y77.174 E.01273
G1 X131.438 Y77.373 E.00843
G1 X140.877 Y86.812 E.56075
G1 X140.877 Y87.288 E.02
G1 X131.413 Y77.824 E.56223
G1 X131.413 Y78.3 E.02
G1 X140.877 Y87.764 E.56223
G1 X140.877 Y88.241 E.02004
G1 X131.413 Y78.776 E.56226
G1 X131.413 Y79.252 E.02
G1 X140.877 Y88.717 E.56226
G1 X140.877 Y89.194 E.02004
G1 X131.413 Y79.729 E.56226
G1 X131.413 Y80.205 E.02
G1 X140.878 Y89.67 E.56229
G1 X140.878 Y90.146 E.02
G1 X131.412 Y80.681 E.56232
G1 X131.412 Y81.157 E.02
G1 X140.878 Y90.623 E.56235
G1 X140.878 Y91.099 E.02
G1 X131.412 Y81.633 E.56235
G1 X131.41 Y82.108 E.01995
G1 X140.878 Y91.575 E.56244
G1 X140.878 Y92.052 E.02004
G1 X131.376 Y82.55 E.56449
G1 X131.362 Y82.736 E.00784
G1 X131.311 Y82.962 E.00973
G1 X140.878 Y92.528 E.56832
G1 X140.878 Y93.005 E.02004
G1 X131.224 Y83.351 E.57352
G1 X131.093 Y83.696 E.0155
G1 X140.878 Y93.481 E.5813
G1 X140.878 Y93.957 E.02
G1 X130.961 Y84.04 E.58914
G1 X130.788 Y84.343 E.01466
G1 X139.31 Y92.865 E.50627
G1 X139.218 Y92.846 E.00395
G1 X138.814 Y92.846 E.01697
G1 X130.613 Y84.644 E.48723
G1 X130.403 Y84.911 E.01427
G1 X138.338 Y92.846 E.4714
G1 X137.862 Y92.846 E.02
G1 X130.191 Y85.175 E.45571
G1 X129.951 Y85.412 E.01417
G1 X137.385 Y92.846 E.44163
G1 X136.909 Y92.846 E.02
G1 X129.692 Y85.629 E.42874
G1 X129.425 Y85.838 E.01424
G1 X136.433 Y92.846 E.41633
G1 X135.956 Y92.846 E.02004
G1 X129.119 Y86.008 E.4062
G1 X128.805 Y86.171 E.01486
G1 X135.48 Y92.846 E.39654
G1 X135.004 Y92.846 E.02
G1 X128.492 Y86.334 E.38686
G1 X128.135 Y86.453 E.01581
G1 X134.527 Y92.846 E.37976
G1 X134.051 Y92.846 E.02
G1 X127.762 Y86.557 E.37361
G1 X127.335 Y86.606 E.01805
G1 X133.575 Y92.846 E.3707
G1 X133.099 Y92.846 E.02
G1 X126.907 Y86.654 E.36785
G1 X126.437 Y86.661 E.01975
G1 X132.622 Y92.846 E.36743
G1 X132.146 Y92.846 E.02
G1 X125.961 Y86.661 E.36743
G1 X125.485 Y86.661 E.02
G1 X131.67 Y92.846 E.36743
G1 X131.193 Y92.846 E.02004
G1 X125.009 Y86.661 E.3674
G1 X124.532 Y86.661 E.02004
G1 X130.717 Y92.846 E.36743
G1 X130.241 Y92.846 E.02
G1 X126.412 Y89.017 E.22747
G1 X126.412 Y89.494 E.02004
G1 X129.765 Y92.846 E.19916
G1 X129.288 Y92.846 E.02004
G1 X126.413 Y89.971 E.1708
G1 X126.413 Y90.174 E.00853
G1 X126.446 Y90.48 E.01293
G1 X128.812 Y92.846 E.14056
G1 X128.336 Y92.846 E.02
G1 X126.413 Y90.923 E.11424
G1 X126.413 Y91.4 E.02004
G1 X127.859 Y92.846 E.0859
G1 X127.383 Y92.846 E.02
G1 X126.413 Y91.876 E.05763
G1 X126.413 Y92.352 E.02
G1 X126.907 Y92.846 E.02935
G1 X126.431 Y92.846 E.02
G1 X126.262 Y92.678 E.01001
G1 E-5 F3600
G1 X126.262 Y92.678 F9000
G1 X126.365 Y92.678
G1 X126.403 Y90.5
G1 X126.365 Y88.135
G1 X125.633 Y88.135
G1 X125.633 Y88.238
G1 E5 F2400
G1 F1200
G1 X124.056 Y86.661 E.09369
G1 X123.58 Y86.661 E.02
G1 X125.005 Y88.087 E.08469
G1 X124.529 Y88.087 E.02
G1 X123.104 Y86.661 E.08469
G1 X122.627 Y86.661 E.02004
G1 X124.053 Y88.087 E.08471
G1 X123.577 Y88.087 E.02
G1 X122.151 Y86.661 E.08471
G1 X121.675 Y86.661 E.02
G1 X123.1 Y88.087 E.08469
G1 X122.624 Y88.087 E.02
G1 X121.198 Y86.661 E.08471
G1 X120.722 Y86.662 E.02
G1 X122.148 Y88.087 E.08469
G1 X121.671 Y88.087 E.02004
G1 X120.246 Y86.662 E.08466
G1 X119.77 Y86.662 E.02
G1 X121.195 Y88.087 E.08466
G1 X120.719 Y88.087 E.02
G1 X119.293 Y86.662 E.08469
G1 X118.817 Y86.662 E.02
G1 X120.242 Y88.087 E.08466
G1 X119.766 Y88.087 E.02
G1 X118.341 Y86.662 E.08466
G1 X117.865 Y86.662 E.02
G1 X119.29 Y88.087 E.08466
G1 X118.814 Y88.087 E.02
G1 X117.388 Y86.662 E.08469
G1 X116.912 Y86.662 E.02
G1 X118.337 Y88.087 E.08466
G1 X117.861 Y88.087 E.02
G1 X116.436 Y86.662 E.08466
G1 X115.96 Y86.662 E.02
G1 X117.385 Y88.087 E.08466
G1 X116.908 Y88.087 E.02004
G1 X115.483 Y86.662 E.08466
G1 X115.007 Y86.662 E.02
G1 X116.432 Y88.087 E.08466
G1 X115.956 Y88.087 E.02
G1 X114.531 Y86.662 E.08466
G1 X114.055 Y86.662 E.02
G1 X115.479 Y88.087 E.08463
G1 X115.003 Y88.087 E.02
G1 X113.578 Y86.662 E.08466
G1 X113.102 Y86.662 E.02
G1 X114.527 Y88.087 E.08466
G1 X114.05 Y88.087 E.02004
G1 X112.626 Y86.662 E.08463
G1 X112.15 Y86.662 E.02
G1 X113.574 Y88.087 E.08463
G1 X113.098 Y88.087 E.02
G1 X111.673 Y86.662 E.08466
G1 X111.197 Y86.662 E.02
G1 X112.622 Y88.087 E.08466
G1 X112.145 Y88.087 E.02004
G1 X110.721 Y86.662 E.08463
G1 X110.244 Y86.662 E.02004
G1 X111.669 Y88.087 E.08466
G1 X111.193 Y88.087 E.02
G1 X109.768 Y86.663 E.08463
G1 X109.292 Y86.663 E.02
G1 X110.716 Y88.087 E.0846
G1 X110.24 Y88.087 E.02
G1 X108.816 Y86.663 E.0846
G1 X108.339 Y86.663 E.02004
G1 X109.764 Y88.087 E.08463
G1 X109.287 Y88.087 E.02004
G1 X107.863 Y86.663 E.0846
G1 X107.387 Y86.663 E.02
G1 X108.811 Y88.087 E.0846
G1 X108.335 Y88.087 E.02
G1 X106.911 Y86.663 E.0846
G1 X106.434 Y86.663 E.02004
G1 X107.859 Y88.087 E.08463
G1 X107.382 Y88.087 E.02004
G1 X105.958 Y86.663 E.0846
G1 X105.482 Y86.663 E.02
G1 X106.906 Y88.087 E.0846
G1 X106.43 Y88.087 E.02
G1 X105.006 Y86.663 E.0846
G1 X104.529 Y86.663 E.02004
G1 X105.953 Y88.087 E.0846
G1 X105.477 Y88.087 E.02
G1 X104.042 Y86.652 E.08525
G1 X103.525 Y86.611 E.02179
G1 X105.001 Y88.087 E.08769
G1 X104.925 Y88.094 E.00321
G1 X104.718 Y88.198 E.00973
G1 X104.685 Y88.247 E.00248
G1 X102.662 Y86.225 E.12015
G1 E-5 F3600
G1 X102.662 Y86.225 F9000
G1 X102.625 Y86.333
G1 X90.797 Y93.058
G1 X90.797 Y95.77
G1 X91.709 Y95.927
G1 X91.739 Y95.931
G1 X91.775 Y95.934
G1 X92.658 Y95.936
G1 X93.336 Y95.935
G1 X93.693 Y95.935
G1 X93.693 Y95.832
G1 E5 F2400
G1 F1200
G1 X93.887 Y96.025 E.0115
G1 X93.887 Y96.502 E.02004
G1 X93.368 Y95.983 E.03083
G1 X92.892 Y95.983 E.02
G1 X93.887 Y96.978 E.05911
G1 X93.887 Y97.454 E.02
G1 X92.415 Y95.983 E.08742
G1 X91.939 Y95.983 E.02
G1 X94.038 Y98.082 E.1247
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X91.939 Y95.983 E-1.41001
G1 X92.129 Y95.983 E-.08999
;WIPE_END
G1 X92.129 Y95.935 F9000
G1 X91.775 Y95.934
G1 X91.739 Y95.931
G1 X91.709 Y95.927
G1 X90.797 Y95.77
G1 X90.797 Y93.058
G1 X108.19 Y86.615
G1 X126.809 Y86.615
G1 X126.91 Y86.611
G1 X127.136 Y86.603
G1 X127.246 Y86.591
G1 X127.47 Y86.566
G1 X127.579 Y86.546
G1 X127.8 Y86.504
G1 X127.907 Y86.477
G1 X128.125 Y86.418
G1 X128.23 Y86.383
G1 X128.443 Y86.309
G1 X128.545 Y86.267
G1 X128.752 Y86.176
G1 X128.851 Y86.127
G1 X129.05 Y86.022
G1 X129.145 Y85.965
G1 X129.336 Y85.845
G1 X129.427 Y85.782
G1 X129.609 Y85.648
G1 X129.695 Y85.579
G1 X129.866 Y85.432
G1 X129.947 Y85.356
G1 X130.106 Y85.197
G1 X130.182 Y85.116
G1 X130.329 Y84.945
G1 X130.398 Y84.859
G1 X130.532 Y84.677
G1 X130.595 Y84.586
G1 X130.715 Y84.395
G1 X130.772 Y84.3
G1 X130.877 Y84.101
G1 X130.926 Y84.002
G1 X131.017 Y83.795
G1 X131.059 Y83.693
G1 X131.133 Y83.48
G1 X131.168 Y83.375
G1 X131.227 Y83.157
G1 X131.254 Y83.05
G1 X131.296 Y82.829
G1 X131.316 Y82.72
G1 X131.341 Y82.496
G1 X131.353 Y82.386
G1 X131.361 Y82.16
G1 X131.365 Y82.059
G1 X131.403 Y77.5
G1 X131.365 Y75.898
G1 X128.145 Y75.898
G1 X126.561 Y75.9
G1 X128.85 Y74.565
G1 X129.012 Y74.47
G1 E5 F2400
G1 F1200
G1 X130.391 Y75.85 E.08195
G1 X129.915 Y75.85 E.02
G1 X128.687 Y74.621 E.07298
G1 X128.21 Y74.621 E.02004
G1 X129.439 Y75.85 E.07301
G1 X128.962 Y75.85 E.02004
G1 X127.734 Y74.621 E.07298
G1 X127.258 Y74.621 E.02
G1 X128.486 Y75.85 E.07298
G1 X128.01 Y75.85 E.02
G1 X126.782 Y74.621 E.07298
G1 X126.305 Y74.621 E.02004
G1 X127.534 Y75.85 E.07301
G1 X127.057 Y75.85 E.02004
G1 X125.829 Y74.621 E.07298
G1 X125.353 Y74.621 E.02
G1 X126.581 Y75.85 E.07298
G1 X126.105 Y75.85 E.02
G1 X124.877 Y74.621 E.07298
G1 X124.4 Y74.622 E.02004
G1 X125.628 Y75.85 E.07295
G1 X125.152 Y75.85 E.02
G1 X123.924 Y74.622 E.07295
G1 X123.448 Y74.622 E.02
G1 X124.676 Y75.85 E.07295
G1 X124.199 Y75.85 E.02004
G1 X122.971 Y74.622 E.07295
G1 X122.495 Y74.622 E.02
G1 X123.723 Y75.85 E.07295
G1 X123.247 Y75.85 E.02
G1 X122.019 Y74.622 E.07295
G1 X121.543 Y74.622 E.02
G1 X122.771 Y75.85 E.07295
G1 X122.294 Y75.85 E.02004
G1 X121.066 Y74.622 E.07295
G1 X120.59 Y74.622 E.02
G1 X121.818 Y75.85 E.07295
G1 X121.342 Y75.85 E.02
G1 X120.114 Y74.622 E.07295
G1 X119.638 Y74.622 E.02
G1 X120.865 Y75.85 E.07292
G1 X120.389 Y75.85 E.02
G1 X119.161 Y74.622 E.07295
G1 X118.685 Y74.622 E.02
G1 X119.913 Y75.85 E.07295
G1 X119.436 Y75.85 E.02004
G1 X118.209 Y74.622 E.07292
G1 X117.733 Y74.622 E.02
G1 X118.96 Y75.85 E.07292
G1 X118.484 Y75.85 E.02
G1 X117.256 Y74.622 E.07295
G1 X116.78 Y74.622 E.02
G1 X118.007 Y75.85 E.07292
G1 X117.531 Y75.85 E.02
G1 X116.304 Y74.622 E.07292
G1 X115.827 Y74.622 E.02004
G1 X117.055 Y75.85 E.07295
G1 X116.579 Y75.85 E.02
G1 X115.351 Y74.622 E.07295
G1 X114.875 Y74.622 E.02
G1 X116.102 Y75.85 E.07292
G1 X115.626 Y75.85 E.02
G1 X114.399 Y74.622 E.07292
G1 X113.922 Y74.622 E.02004
G1 X115.15 Y75.85 E.07295
G1 X114.673 Y75.85 E.02004
G1 X113.446 Y74.622 E.07292
G1 X112.97 Y74.622 E.02
G1 X114.197 Y75.85 E.07292
G1 X113.721 Y75.85 E.02
G1 X112.494 Y74.623 E.07289
G1 X112.017 Y74.623 E.02004
G1 X113.244 Y75.85 E.07289
G1 X112.768 Y75.85 E.02
G1 X111.541 Y74.623 E.07289
G1 X111.065 Y74.623 E.02
G1 X112.292 Y75.85 E.07289
G1 X111.816 Y75.85 E.02
G1 X110.589 Y74.623 E.07289
G1 X110.112 Y74.623 E.02004
G1 X111.339 Y75.85 E.07289
G1 X110.863 Y75.85 E.02
G1 X109.636 Y74.623 E.07289
G1 X109.16 Y74.623 E.02
G1 X110.387 Y75.85 E.07289
G1 X109.91 Y75.85 E.02004
G1 X108.684 Y74.623 E.07286
G1 X108.207 Y74.623 E.02004
G1 X109.434 Y75.85 E.07289
G1 X108.958 Y75.85 E.02
G1 X107.731 Y74.623 E.07289
G1 X107.255 Y74.623 E.02
G1 X108.481 Y75.85 E.07286
G1 X108.005 Y75.85 E.02
G1 X106.778 Y74.623 E.07289
G1 X106.302 Y74.623 E.02
G1 X107.529 Y75.85 E.07289
G1 X107.052 Y75.85 E.02004
G1 X105.826 Y74.623 E.07286
G1 X105.35 Y74.623 E.02
G1 X106.576 Y75.85 E.07286
G1 X106.1 Y75.85 E.02
G1 X104.873 Y74.623 E.07289
G1 X104.397 Y74.623 E.02
G1 X105.624 Y75.85 E.07289
G1 X105.147 Y75.85 E.02004
G1 X103.921 Y74.623 E.07286
G1 X103.445 Y74.623 E.02
G1 X104.671 Y75.85 E.07286
G1 X104.195 Y75.85 E.02
G1 X102.968 Y74.623 E.07289
G1 X102.492 Y74.623 E.02
G1 X103.718 Y75.85 E.07286
G1 X103.242 Y75.85 E.02
G1 X102.016 Y74.623 E.07286
G1 X101.54 Y74.623 E.02
G1 X102.766 Y75.85 E.07286
G1 X102.289 Y75.85 E.02004
G1 X101.063 Y74.623 E.07286
G1 X100.587 Y74.624 E.02
G1 X101.813 Y75.85 E.07283
G1 X101.337 Y75.85 E.02
G1 X100.111 Y74.624 E.07283
G1 X99.635 Y74.624 E.02
G1 X100.861 Y75.85 E.07283
G1 X100.384 Y75.85 E.02004
G1 X99.158 Y74.624 E.07283
G1 X98.682 Y74.624 E.02
G1 X99.918 Y75.86 E.07343
G1 X99.752 Y75.932 E.0076
G1 X99.648 Y76.066 E.00713
G1 X98.206 Y74.624 E.08567
G1 X97.729 Y74.624 E.02004
G1 X99.587 Y76.481 E.11035
G1 X99.587 Y76.958 E.02004
G1 X97.253 Y74.624 E.13866
G1 X96.777 Y74.624 E.02
G1 X99.564 Y77.411 E.16557
G1 X99.551 Y77.543 E.00557
G1 X99.587 Y77.91 E.01549
G1 X96.301 Y74.624 E.19521
G1 X95.824 Y74.624 E.02004
G1 X99.587 Y78.387 E.22355
G1 X99.587 Y78.863 E.02
G1 X95.348 Y74.624 E.25183
G1 X95.171 Y74.624 E.00744
G1 X94.905 Y74.657 E.01126
G1 X99.587 Y79.339 E.27814
G1 X99.587 Y79.815 E.02
G1 X94.484 Y74.713 E.30313
G1 X94.103 Y74.808 E.01649
G1 X99.587 Y80.292 E.32579
G1 X99.587 Y80.768 E.02
G1 X93.737 Y74.918 E.34753
G1 X93.393 Y75.05 E.01548
G1 X99.587 Y81.244 E.36797
G1 X99.587 Y81.721 E.02004
G1 X93.07 Y75.204 E.38716
G1 X92.759 Y75.369 E.01479
G1 X99.605 Y82.215 E.4067
G1 X99.667 Y82.753 E.02275
G1 X92.478 Y75.564 E.42708
G1 X92.205 Y75.768 E.01432
G1 X100.016 Y83.579 E.46403
G1 E-5 F3600
G1 X100.016 Y83.579 F9000
G1 X99.914 Y83.615
G1 X99.941 Y83.693
G1 X99.983 Y83.795
G1 X100.074 Y84.002
G1 X100.123 Y84.101
G1 X100.228 Y84.3
G1 X100.285 Y84.395
G1 X100.405 Y84.586
G1 X100.468 Y84.677
G1 X100.602 Y84.859
G1 X100.671 Y84.945
G1 X100.818 Y85.116
G1 X100.894 Y85.197
G1 X101.053 Y85.356
G1 X101.134 Y85.432
G1 X101.305 Y85.579
G1 X101.391 Y85.648
G1 X101.573 Y85.782
G1 X101.664 Y85.845
G1 X101.855 Y85.965
G1 X101.95 Y86.022
G1 X102.149 Y86.127
G1 X102.248 Y86.176
G1 X102.459 Y86.269
G1 X104.635 Y88.777
G1 X104.738 Y88.777
G1 E5 F2400
G1 F1200
G1 X102.116 Y86.155 E.15577
G1 X101.656 Y85.897 E.02216
G1 X101.079 Y85.445 E.03079
G1 X100.584 Y84.912 E.03056
G1 X100.199 Y84.344 E.02882
G1 X100.1 Y84.139 E.00956
G1 X91.933 Y75.972 E.48518
G1 X91.689 Y76.204 E.01414
G1 X104.587 Y89.102 E.76624
G1 X104.587 Y89.578 E.02
G1 X91.457 Y76.448 E.78002
G1 X91.245 Y76.713 E.01426
G1 X104.587 Y90.055 E.79261
G1 X104.556 Y90.5 E.01874
G1 X91.042 Y76.986 E.80283
G1 X90.861 Y77.281 E.01454
G1 X104.587 Y91.007 E.81542
G1 X104.587 Y91.484 E.02004
G1 X90.691 Y77.588 E.82552
G1 X90.542 Y77.915 E.0151
G1 X104.587 Y91.96 E.83438
G1 X104.587 Y92.436 E.02
G1 X90.412 Y78.261 E.8421
G1 X90.297 Y78.623 E.01596
G1 X104.52 Y92.846 E.84495
G1 X104.044 Y92.846 E.02
G1 X90.215 Y79.017 E.82154
G1 X90.149 Y79.427 E.01744
G1 X103.568 Y92.846 E.79719
G1 X103.091 Y92.846 E.02004
G1 X90.122 Y79.876 E.77048
G1 X90.113 Y80.344 E.01966
G1 X102.615 Y92.846 E.74271
G1 X102.139 Y92.846 E.02
G1 X90.113 Y80.82 E.71443
G1 X90.113 Y81.297 E.02004
G1 X101.663 Y92.846 E.68612
G1 X101.186 Y92.846 E.02004
G1 X90.113 Y81.773 E.65782
G1 X90.113 Y82.249 E.02
G1 X100.71 Y92.846 E.62954
G1 X100.234 Y92.846 E.02
G1 X90.113 Y82.726 E.60123
G1 X90.113 Y83.202 E.02
G1 X99.757 Y92.846 E.57292
G1 X99.281 Y92.846 E.02
G1 X90.113 Y83.678 E.54465
G1 X90.113 Y84.155 E.02004
G1 X98.805 Y92.846 E.51634
G1 X98.328 Y92.846 E.02004
G1 X90.114 Y84.631 E.488
G1 X90.114 Y85.107 E.02
G1 X97.852 Y92.846 E.45972
G1 X97.376 Y92.846 E.02
G1 X90.114 Y85.584 E.43142
G1 X90.114 Y86.06 E.02
G1 X96.899 Y92.846 E.40311
G1 X96.423 Y92.846 E.02
G1 X90.114 Y86.537 E.3748
G1 X90.114 Y87.013 E.02
G1 X95.947 Y92.846 E.34652
G1 X95.47 Y92.846 E.02004
G1 X90.114 Y87.489 E.31822
G1 X90.114 Y87.966 E.02004
G1 X94.994 Y92.846 E.28991
G1 X94.518 Y92.846 E.02
G1 X90.114 Y88.442 E.26163
G1 X90.114 Y88.918 E.02
G1 X94.042 Y92.846 E.23335
G1 X93.565 Y92.846 E.02004
G1 X90.114 Y89.395 E.20501
G1 X90.114 Y89.871 E.02
G1 X93.089 Y92.846 E.17674
G1 X92.613 Y92.846 E.02
G1 X90.114 Y90.347 E.14846
G1 X90.114 Y90.824 E.02004
G1 X92.136 Y92.846 E.12012
G1 X91.78 Y92.846 E.01495
G1 X91.686 Y92.871 E.00409
G1 X90.114 Y91.3 E.09336
G1 X90.114 Y91.776 E.02
G1 X91.331 Y92.993 E.0723
G1 X91.304 Y93.01 E.00134
G1 X91.124 Y93.011 E.00756
G1 X90.946 Y93.085 E.0081
G1 X90.114 Y92.253 E.04943
G1 X90.114 Y92.729 E.02
G1 X90.763 Y93.378 E.03856
G1 X90.748 Y93.411 E.00152
G1 X90.748 Y93.839 E.01798
G1 X90.114 Y93.205 E.03766
G1 X90.114 Y93.682 E.02004
G1 X90.748 Y94.316 E.03766
G1 X90.748 Y94.792 E.02
G1 X90.115 Y94.158 E.03763
G1 X90.115 Y94.635 E.02004
G1 X90.748 Y95.268 E.0376
G1 X90.755 Y95.483 E.00904
G1 X90.891 Y95.721 E.01151
G1 X91.123 Y95.817 E.01055
G1 X91.298 Y95.818 E.00735
G1 X93.887 Y98.407 E.15381
G1 X93.887 Y98.883 E.02
G1 X90.115 Y95.111 E.22408
G1 X90.115 Y95.587 E.02
G1 X93.887 Y99.359 E.22408
G1 X93.887 Y99.836 E.02004
G1 X90.115 Y96.064 E.22408
G1 X90.115 Y96.54 E.02
G1 X93.887 Y100.312 E.22408
G1 X93.887 Y100.788 E.02
G1 X90.115 Y97.016 E.22408
G1 X90.115 Y97.493 E.02004
G1 X93.887 Y101.265 E.22408
G1 X93.887 Y101.741 E.02
G1 X90.115 Y97.969 E.22408
G1 X90.115 Y98.445 E.02
G1 X93.887 Y102.217 E.22408
G1 X93.887 Y102.694 E.02004
G1 X90.115 Y98.922 E.22408
G1 X90.115 Y99.398 E.02
G1 X93.887 Y103.17 E.22408
G1 X93.887 Y103.646 E.02
G1 X90.115 Y99.874 E.22408
G1 X90.115 Y100.351 E.02004
G1 X93.887 Y104.122 E.22405
G1 X93.887 Y104.599 E.02004
G1 X90.115 Y100.827 E.22408
G1 X90.115 Y101.304 E.02004
G1 X93.887 Y105.075 E.22405
G1 X93.887 Y105.551 E.02
G1 X90.115 Y101.78 E.22405
G1 X90.115 Y102.256 E.02
G1 X93.887 Y106.028 E.22408
G1 X93.887 Y106.504 E.02
G1 X90.115 Y102.733 E.22405
G1 X90.115 Y103.209 E.02
G1 X93.887 Y106.98 E.22405
G1 X93.887 Y107.457 E.02004
G1 X90.116 Y103.685 E.22405
G1 X90.116 Y104.162 E.02004
G1 X93.887 Y107.933 E.22402
G1 X93.887 Y108.409 E.02
G1 X90.116 Y104.638 E.22402
G1 X90.116 Y105.114 E.02
G1 X93.887 Y108.885 E.22402
G1 X93.887 Y109.362 E.02004
G1 X90.116 Y105.591 E.22402
G1 X90.116 Y106.067 E.02
G1 X93.887 Y109.838 E.22402
G1 X93.887 Y110.314 E.02
G1 X90.116 Y106.543 E.22402
G1 X90.116 Y107.02 E.02004
G1 X93.887 Y110.791 E.22402
G1 X93.887 Y111.267 E.02
G1 X90.116 Y107.496 E.22402
G1 X90.116 Y107.972 E.02
G1 X93.887 Y111.743 E.22402
G1 X93.887 Y112.219 E.02
G1 X90.116 Y108.449 E.224
G1 X90.116 Y108.925 E.02
G1 X93.887 Y112.696 E.22402
G1 X93.887 Y113.172 E.02
G1 X90.116 Y109.402 E.224
G1 X90.116 Y109.878 E.02
G1 X93.887 Y113.648 E.224
G1 X93.887 Y114.125 E.02004
G1 X90.116 Y110.354 E.22402
G1 X90.116 Y110.831 E.02004
G1 X93.887 Y114.601 E.224
G1 X93.887 Y115.077 E.02
G1 X90.116 Y111.307 E.224
G1 X90.116 Y111.783 E.02
G1 X93.887 Y115.554 E.22402
G1 X93.887 Y116.03 E.02
G1 X90.116 Y112.26 E.224
G1 X90.116 Y112.736 E.02
G1 X93.887 Y116.506 E.224
G1 X93.887 Y116.982 E.02
G1 X90.117 Y113.212 E.22397
G1 X90.117 Y113.689 E.02004
G1 X93.887 Y117.459 E.22397
G1 X93.887 Y117.935 E.02
G1 X90.117 Y114.165 E.22397
G1 X90.117 Y114.641 E.02
G1 X93.887 Y118.411 E.22397
G1 X93.887 Y118.888 E.02004
G1 X90.117 Y115.118 E.22397
G1 X90.117 Y115.594 E.02
G1 X93.887 Y119.364 E.22397
G1 X93.887 Y119.84 E.02
G1 X90.117 Y116.071 E.22394
G1 X90.117 Y116.547 E.02
G1 X93.887 Y120.317 E.22397
G1 X93.887 Y120.793 E.02
G1 X90.117 Y117.023 E.22397
G1 X90.117 Y117.5 E.02004
G1 X93.887 Y121.269 E.22394
G1 X93.887 Y121.745 E.02
G1 X90.117 Y117.976 E.22394
G1 X90.117 Y118.452 E.02
G1 X93.887 Y122.222 E.22397
G1 X93.887 Y122.698 E.02
G1 X90.117 Y118.929 E.22394
G1 X90.117 Y119.405 E.02
G1 X93.887 Y123.174 E.22394
G1 X93.886 Y123.651 E.02004
G1 X90.117 Y119.881 E.22394
G1 X90.117 Y120.358 E.02004
G1 X93.886 Y124.127 E.22391
G1 X93.886 Y124.603 E.02
G1 X90.117 Y120.834 E.22391
G1 X90.117 Y121.31 E.02
G1 X93.886 Y125.079 E.22391
G1 X93.886 Y125.556 E.02004
G1 X90.117 Y121.787 E.22391
G1 X90.118 Y122.263 E.02
G1 X93.886 Y126.032 E.22388
G1 X93.886 Y126.508 E.02
G1 X90.118 Y122.739 E.22388
G1 X90.118 Y123.216 E.02004
G1 X93.886 Y126.985 E.22388
G1 X93.886 Y127.461 E.02
G1 X90.118 Y123.692 E.22388
G1 X90.118 Y124.169 E.02004
G1 X93.886 Y127.937 E.22385
G1 X93.886 Y128.414 E.02004
G1 X90.118 Y124.645 E.22388
G1 X90.118 Y125.121 E.02
G1 X93.886 Y128.89 E.22388
G1 X93.886 Y129.366 E.02
G1 X90.118 Y125.598 E.22385
G1 X90.118 Y126.074 E.02
G1 X93.886 Y129.842 E.22385
G1 X93.886 Y130.319 E.02004
G1 X90.118 Y126.55 E.22388
G1 X90.118 Y127.027 E.02004
G1 X93.886 Y130.795 E.22385
G1 X93.886 Y131.271 E.02
G1 X90.118 Y127.503 E.22385
G1 X90.118 Y127.979 E.02
G1 X93.886 Y131.748 E.22388
G1 X93.886 Y132.224 E.02
G1 X90.118 Y128.456 E.22385
G1 X90.118 Y128.932 E.02
G1 X93.886 Y132.7 E.22385
G1 X93.909 Y133.199 E.02098
G1 X90.118 Y129.408 E.22521
G1 X90.118 Y129.885 E.02004
G1 X93.95 Y133.717 E.22765
G1 X94.044 Y134.287 E.02427
G1 X90.118 Y130.361 E.23323
G1 X90.118 Y130.838 E.02004
G1 X94.154 Y134.873 E.23974
G1 X94.226 Y135.26 E.01654
G1 X94.299 Y135.494 E.0103
G1 X90.118 Y131.314 E.24835
G1 X90.119 Y131.79 E.02
G1 X94.513 Y136.184 E.26104
G1 X94.849 Y136.997 E.03695
G1 X90.119 Y132.267 E.281
G1 X90.119 Y132.743 E.02
G1 X95.866 Y138.49 E.34141
G1 E-5 F3600
G1 X95.866 Y138.49 F9000
G1 X95.775 Y138.553
G1 X95.972 Y138.837
G1 X96.274 Y139.23
G1 X96.595 Y139.609
G1 X96.932 Y139.972
G1 X97.287 Y140.32
G1 X97.657 Y140.65
G1 X98.043 Y140.962
G1 X98.442 Y141.256
G1 X98.856 Y141.531
G1 X99.281 Y141.786
G1 X99.718 Y142.021
G1 X100.166 Y142.235
G1 X100.623 Y142.428
G1 X101.089 Y142.599
G1 X101.562 Y142.748
G1 X102.042 Y142.875
G1 X102.527 Y142.979
G1 X103.016 Y143.06
G1 X103.509 Y143.119
G1 X104.004 Y143.154
G1 X104.494 Y143.165
G1 X126.506 Y143.165
G1 X126.996 Y143.154
G1 X127.491 Y143.119
G1 X127.984 Y143.06
G1 X128.473 Y142.979
G1 X128.958 Y142.875
G1 X129.438 Y142.748
G1 X129.911 Y142.599
G1 X130.377 Y142.428
G1 X130.834 Y142.235
G1 X131.282 Y142.021
G1 X131.719 Y141.786
G1 X132.144 Y141.531
G1 X132.558 Y141.256
G1 X132.957 Y140.962
G1 X133.343 Y140.65
G1 X133.713 Y140.32
G1 X134.068 Y139.972
G1 X134.405 Y139.609
G1 X134.726 Y139.23
G1 X135.028 Y138.837
G1 X135.311 Y138.429
G1 X135.575 Y138.009
G1 X135.819 Y137.577
G1 X136.043 Y137.134
G1 X136.245 Y136.681
G1 X136.426 Y136.219
G1 X136.585 Y135.749
G1 X136.722 Y135.272
G1 X136.836 Y134.789
G1 X136.927 Y134.301
G1 X136.996 Y133.81
G1 X137.041 Y133.316
G1 X140.204 Y95.77
G1 X140.204 Y95.387
G1 X140.935 Y94.676
G1 X141.029 Y94.585
G1 E5 F2400
G1 F1200
G1 X140.252 Y93.808 E.04616
G1 X140.252 Y94.284 E.02
G1 X140.878 Y94.91 E.03719
G1 X140.878 Y95.386 E.02
G1 X140.252 Y94.76 E.03719
G1 X140.252 Y95.236 E.02
G1 X140.879 Y95.863 E.03725
G1 X140.879 Y96.339 E.02
G1 X140.164 Y95.625 E.04245
G1 X140.109 Y95.721 E.00465
G1 X139.879 Y95.816 E.01045
G1 X140.879 Y96.816 E.05941
G1 X140.879 Y97.292 E.02
G1 X139.496 Y95.909 E.08216
G1 X139.22 Y95.983 E.012
G1 X139.093 Y95.983 E.00533
G1 X140.879 Y97.768 E.10607
G1 X140.879 Y98.245 E.02004
G1 X138.617 Y95.983 E.13438
G1 X138.14 Y95.983 E.02004
G1 X140.879 Y98.721 E.16269
G1 X140.879 Y99.197 E.02
G1 X137.664 Y95.983 E.19096
G1 X137.188 Y95.983 E.02
G1 X140.879 Y99.674 E.21927
G1 X140.879 Y100.15 E.02
G1 X137.113 Y96.384 E.22373
G1 X137.113 Y96.86 E.02
G1 X140.879 Y100.627 E.22376
G1 X140.879 Y101.103 E.02
G1 X137.113 Y97.337 E.22373
G1 X137.113 Y97.813 E.02
G1 X140.879 Y101.579 E.22373
G1 X140.879 Y102.056 E.02004
G1 X137.113 Y98.289 E.22376
G1 X137.113 Y98.765 E.02
G1 X140.88 Y102.532 E.22379
G1 X140.88 Y103.008 E.02
G1 X137.113 Y99.242 E.22376
G1 X137.113 Y99.718 E.02
G1 X140.88 Y103.485 E.22379
G1 X140.88 Y103.961 E.02
G1 X137.113 Y100.194 E.22379
G1 X137.113 Y100.671 E.02004
G1 X140.88 Y104.438 E.22379
G1 X140.88 Y104.914 E.02
G1 X137.113 Y101.147 E.22379
G1 X137.113 Y101.623 E.02
G1 X140.88 Y105.39 E.22379
G1 X140.88 Y105.867 E.02004
G1 X137.113 Y102.099 E.22382
G1 X137.113 Y102.576 E.02004
G1 X140.88 Y106.343 E.22379
G1 X140.88 Y106.82 E.02004
G1 X137.113 Y103.052 E.22382
G1 X137.113 Y103.528 E.02
G1 X140.88 Y107.296 E.22382
G1 X140.88 Y107.772 E.02
G1 X137.113 Y104.004 E.22382
G1 X137.113 Y104.481 E.02004
G1 X140.88 Y108.249 E.22382
G1 X140.88 Y108.725 E.02
G1 X137.112 Y104.957 E.22385
G1 X137.112 Y105.433 E.02
G1 X140.881 Y109.201 E.22388
G1 X140.881 Y109.678 E.02004
G1 X137.112 Y105.91 E.22388
G1 X137.112 Y106.386 E.02
G1 X140.881 Y110.154 E.22388
G1 X140.881 Y110.631 E.02004
G1 X137.112 Y106.862 E.22391
G1 X137.112 Y107.338 E.02
G1 X140.881 Y111.107 E.22391
G1 X140.881 Y111.583 E.02
G1 X137.112 Y107.815 E.22388
G1 X137.112 Y108.291 E.02
G1 X140.881 Y112.06 E.22391
G1 X140.881 Y112.536 E.02
G1 X137.112 Y108.767 E.22391
G1 X137.112 Y109.244 E.02004
G1 X140.881 Y113.012 E.22388
G1 X140.881 Y113.489 E.02004
G1 X137.112 Y109.72 E.22391
G1 X137.112 Y110.196 E.02
G1 X140.881 Y113.965 E.22391
G1 X140.881 Y114.442 E.02004
G1 X137.112 Y110.672 E.22394
G1 X137.112 Y111.149 E.02004
G1 X140.881 Y114.918 E.22391
G1 X140.882 Y115.394 E.02
G1 X137.112 Y111.625 E.22394
G1 X137.112 Y112.101 E.02
G1 X140.882 Y115.871 E.22397
G1 X140.882 Y116.347 E.02
G1 X137.112 Y112.577 E.22397
G1 X137.112 Y113.054 E.02004
G1 X140.882 Y116.823 E.22394
G1 X140.882 Y117.3 E.02004
G1 X137.112 Y113.53 E.22397
G1 X137.112 Y114.006 E.02
G1 X140.882 Y117.776 E.22397
G1 X140.882 Y118.253 E.02004
G1 X137.112 Y114.483 E.22397
G1 X137.112 Y114.959 E.02
G1 X140.882 Y118.729 E.22397
G1 X140.882 Y119.205 E.02
G1 X137.112 Y115.435 E.22397
G1 X137.112 Y115.911 E.02
G1 X140.882 Y119.682 E.224
G1 X140.882 Y120.158 E.02
G1 X137.112 Y116.388 E.22397
G1 X137.112 Y116.864 E.02
G1 X140.882 Y120.634 E.22397
G1 X140.882 Y121.111 E.02004
G1 X137.112 Y117.34 E.224
G1 X137.112 Y117.816 E.02
G1 X140.882 Y121.587 E.224
G1 X140.883 Y122.064 E.02004
G1 X137.112 Y118.293 E.22402
G1 X137.112 Y118.769 E.02
G1 X140.883 Y122.54 E.22402
G1 X140.883 Y123.016 E.02
G1 X137.112 Y119.245 E.22402
G1 X137.112 Y119.722 E.02004
G1 X140.883 Y123.493 E.22402
G1 X140.883 Y123.969 E.02
G1 X137.112 Y120.198 E.22402
G1 X137.112 Y120.674 E.02
G1 X140.883 Y124.445 E.22402
G1 X140.883 Y124.922 E.02004
G1 X137.112 Y121.15 E.22405
G1 X137.112 Y121.627 E.02004
G1 X140.883 Y125.398 E.22402
G1 X140.883 Y125.875 E.02004
G1 X137.111 Y122.103 E.22408
G1 X137.111 Y122.579 E.02
G1 X140.883 Y126.351 E.22408
G1 X140.883 Y126.827 E.02
G1 X137.111 Y123.056 E.22405
G1 X137.111 Y123.532 E.02
G1 X140.883 Y127.304 E.22408
G1 X140.883 Y127.78 E.02
G1 X137.111 Y124.008 E.22408
G1 X137.111 Y124.484 E.02
G1 X140.883 Y128.256 E.22408
G1 X140.884 Y128.733 E.02004
G1 X137.111 Y124.961 E.22411
G1 X137.111 Y125.437 E.02
G1 X140.884 Y129.209 E.22411
G1 X140.884 Y129.686 E.02004
G1 X137.111 Y125.913 E.22414
G1 X137.111 Y126.389 E.02
G1 X140.884 Y130.162 E.22414
G1 X140.884 Y130.638 E.02
G1 X137.111 Y126.866 E.22411
G1 X137.111 Y127.342 E.02
G1 X140.884 Y131.115 E.22414
G1 X140.884 Y131.591 E.02
G1 X137.111 Y127.818 E.22414
G1 X137.111 Y128.295 E.02004
G1 X140.884 Y132.068 E.22414
G1 X140.884 Y132.544 E.02
G1 X137.111 Y128.771 E.22414
G1 X137.111 Y129.247 E.02
G1 X140.884 Y133.02 E.22414
G1 X140.884 Y133.497 E.02004
G1 X137.111 Y129.723 E.22417
G1 X137.111 Y130.2 E.02004
G1 X140.884 Y133.973 E.22414
G1 X140.884 Y134.449 E.02
G1 X137.111 Y130.676 E.22414
G1 X137.111 Y131.152 E.02
G1 X140.885 Y134.926 E.2242
G1 X140.885 Y135.402 E.02
G1 X137.111 Y131.629 E.22417
G1 X137.111 Y132.105 E.02
G1 X140.885 Y135.879 E.2242
G1 X140.885 Y136.355 E.02
G1 X137.111 Y132.581 E.2242
G1 X137.098 Y133.044 E.01946
G1 X140.885 Y136.831 E.22498
G1 X140.885 Y137.308 E.02004
G1 X137.072 Y133.495 E.22652
G1 X137.012 Y133.911 E.01766
G1 X140.885 Y137.784 E.23008
G1 X140.885 Y138.26 E.02
G1 X136.952 Y134.327 E.23365
G1 X136.892 Y134.743 E.01766
G1 X140.885 Y138.737 E.23724
G1 X140.885 Y139.213 E.02
G1 X136.801 Y135.129 E.24262
G1 X136.703 Y135.507 E.0164
G1 X140.885 Y139.69 E.24847
G1 X140.885 Y140.166 E.02
G1 X136.588 Y135.868 E.2553
G1 X136.473 Y136.23 E.01596
G1 X140.885 Y140.642 E.26211
G1 X140.885 Y141.119 E.02004
G1 X136.332 Y136.565 E.27051
G1 X136.192 Y136.901 E.01529
G1 X140.886 Y141.595 E.27886
G1 X140.886 Y142.071 E.02
G1 X136.046 Y137.232 E.2875
G1 X135.883 Y137.546 E.01486
G1 X140.886 Y142.548 E.29719
G1 X140.886 Y143.024 E.02
G1 X135.715 Y137.853 E.3072
G1 X135.536 Y138.151 E.0146
G1 X140.886 Y143.501 E.31783
G1 X140.886 Y143.977 E.02
G1 X135.356 Y138.448 E.32849
G1 X135.156 Y138.723 E.01428
G1 X140.886 Y144.453 E.3404
G1 X140.886 Y144.93 E.02004
G1 X134.955 Y138.998 E.35237
G1 X134.752 Y139.272 E.01432
G1 X140.886 Y145.406 E.3644
G1 X140.886 Y145.882 E.02
G1 X134.531 Y139.528 E.3775
G1 X134.309 Y139.782 E.01417
G1 X140.886 Y146.359 E.39072
G1 X140.886 Y146.835 E.02
G1 X134.073 Y140.022 E.40474
G1 X133.837 Y140.262 E.01414
G1 X140.886 Y147.312 E.41879
G1 X140.886 Y147.788 E.02
G1 X133.587 Y140.489 E.43361
G1 X133.33 Y140.708 E.01418
G1 X140.887 Y148.264 E.44891
G1 X140.887 Y148.741 E.02004
G1 X133.073 Y140.927 E.46421
G1 X132.802 Y141.132 E.01427
G1 X140.887 Y149.217 E.48031
G1 X140.887 Y149.693 E.02
G1 X132.524 Y141.331 E.49679
G1 X132.232 Y141.515 E.0145
G1 X140.887 Y150.17 E.51417
G1 X140.887 Y150.646 E.02
G1 X131.932 Y141.691 E.53199
G1 X131.632 Y141.868 E.01463
G1 X140.879 Y151.115 E.54934
G1 X140.852 Y151.563 E.01885
G1 X131.333 Y142.044 E.5655
G1 X131.004 Y142.192 E.01515
G1 X140.787 Y151.975 E.58118
G1 X140.705 Y152.37 E.01695
G1 X130.669 Y142.333 E.59624
G1 X130.334 Y142.474 E.01527
G1 X140.591 Y152.732 E.60937
G1 X140.461 Y153.078 E.01553
G1 X129.999 Y142.616 E.62152
G1 X129.638 Y142.732 E.01593
G1 X140.312 Y153.405 E.63408
G1 X140.143 Y153.712 E.01472
G1 X129.271 Y142.84 E.64588
G1 X128.877 Y142.923 E.01691
G1 X139.962 Y154.008 E.65853
G1 X139.759 Y154.281 E.01429
G1 X128.483 Y143.006 E.66985
G1 X128.089 Y143.088 E.01691
G1 X139.548 Y154.546 E.68072
G1 X139.499 Y154.607 E.00329
G1 X139.316 Y154.791 E.0109
G1 X127.663 Y143.138 E.69227
G1 X127.228 Y143.179 E.01835
G1 X139.073 Y155.024 E.70368
G1 X138.8 Y155.228 E.01432
G1 X126.775 Y143.202 E.7144
G1 X126.299 Y143.202 E.02
G1 X138.528 Y155.432 E.72652
G1 X138.247 Y155.628 E.01439
G1 X125.822 Y143.203 E.73814
G1 X125.346 Y143.203 E.02
G1 X137.937 Y155.793 E.74797
G1 X137.614 Y155.947 E.01503
G1 X124.87 Y143.203 E.75709
G1 X124.394 Y143.203 E.02
G1 X137.27 Y156.079 E.76493
G1 X136.905 Y156.19 E.01603
G1 X123.918 Y143.204 E.77149
G1 X123.442 Y143.204 E.02
G1 X136.524 Y156.285 E.77714
G1 X136.104 Y156.342 E.0178
G1 X122.966 Y143.204 E.78049
G1 X122.49 Y143.204 E.02
G1 X135.662 Y156.376 E.78251
G1 X135.186 Y156.376 E.02
G1 X122.014 Y143.205 E.78248
G1 X121.538 Y143.205 E.02
G1 X134.709 Y156.376 E.78245
G1 X134.233 Y156.376 E.02
G1 X121.062 Y143.205 E.78245
G1 X120.586 Y143.205 E.02
G1 X133.757 Y156.377 E.78248
G1 X133.281 Y156.377 E.02
G1 X120.11 Y143.205 E.78248
G1 X119.634 Y143.206 E.02
G1 X132.805 Y156.377 E.78245
G1 X132.329 Y156.377 E.02
G1 X119.158 Y143.206 E.78245
G1 X118.681 Y143.206 E.02004
G1 X131.852 Y156.377 E.78245
G1 X131.376 Y156.377 E.02
G1 X118.205 Y143.206 E.78245
G1 X117.729 Y143.207 E.02
G1 X130.9 Y156.377 E.78242
G1 X130.424 Y156.377 E.02
G1 X117.253 Y143.207 E.78242
G1 X116.777 Y143.207 E.02
G1 X129.948 Y156.378 E.78245
G1 X129.471 Y156.378 E.02004
G1 X116.301 Y143.207 E.78242
G1 X115.825 Y143.208 E.02
G1 X128.995 Y156.378 E.78239
G1 X128.519 Y156.378 E.02
G1 X115.349 Y143.208 E.78239
G1 X114.873 Y143.208 E.02
G1 X128.043 Y156.378 E.78239
G1 X127.567 Y156.378 E.02
G1 X114.397 Y143.208 E.78239
G1 X113.921 Y143.209 E.02
G1 X127.091 Y156.378 E.78236
G1 X126.614 Y156.379 E.02004
G1 X113.445 Y143.209 E.78236
G1 X112.969 Y143.209 E.02
G1 X126.138 Y156.379 E.78236
G1 X125.662 Y156.379 E.02
G1 X112.493 Y143.209 E.78236
G1 X112.017 Y143.21 E.02
G1 X125.186 Y156.379 E.78233
G1 X124.71 Y156.379 E.02
G1 X111.54 Y143.21 E.78236
G1 X111.064 Y143.21 E.02
G1 X124.234 Y156.379 E.78236
G1 X123.757 Y156.379 E.02004
G1 X110.588 Y143.21 E.78233
G1 X110.112 Y143.21 E.02
G1 X123.281 Y156.379 E.78233
G1 X122.805 Y156.38 E.02
G1 X109.636 Y143.211 E.78233
G1 X109.16 Y143.211 E.02
G1 X122.329 Y156.38 E.78233
G1 X121.853 Y156.38 E.02
G1 X108.684 Y143.211 E.78233
G1 X108.208 Y143.211 E.02
G1 X121.377 Y156.38 E.78233
G1 X120.9 Y156.38 E.02004
G1 X107.732 Y143.212 E.78228
G1 X107.256 Y143.212 E.02
G1 X120.424 Y156.38 E.78228
G1 X119.948 Y156.38 E.02
G1 X106.78 Y143.212 E.78228
G1 X106.304 Y143.212 E.02
G1 X119.472 Y156.38 E.78228
G1 X118.996 Y156.381 E.02
G1 X105.828 Y143.213 E.78228
G1 X105.352 Y143.213 E.02
G1 X118.519 Y156.381 E.78225
G1 X118.043 Y156.381 E.02
G1 X104.875 Y143.213 E.78228
G1 X104.394 Y143.208 E.02021
G1 X117.567 Y156.381 E.78257
G1 X117.091 Y156.381 E.02
G1 X103.894 Y143.184 E.784
G1 X103.383 Y143.15 E.02151
G1 X116.615 Y156.381 E.78605
G1 X116.139 Y156.381 E.02
G1 X102.828 Y143.071 E.79074
G1 X102.533 Y143.029 E.01252
G1 X102.242 Y142.961 E.01255
G1 X115.662 Y156.381 E.79725
G1 X115.186 Y156.382 E.02
G1 X101.608 Y142.804 E.80663
G1 X100.896 Y142.568 E.03151
G1 X114.71 Y156.382 E.82065
G1 X114.234 Y156.382 E.02
G1 X100.099 Y142.247 E.83972
G1 X99.821 Y142.123 E.01279
G1 X99.096 Y141.72 E.03484
G1 X113.758 Y156.382 E.87103
G1 X113.282 Y156.382 E.02
G1 X90.119 Y133.219 E1.37605
G1 X90.119 Y133.696 E.02004
G1 X112.805 Y156.382 E1.34771
G1 X112.329 Y156.382 E.02
G1 X90.119 Y134.172 E1.31944
G1 X90.119 Y134.648 E.02
G1 X111.853 Y156.383 E1.29119
G1 X111.377 Y156.383 E.02
G1 X90.119 Y135.125 E1.26288
G1 X90.119 Y135.601 E.02
G1 X110.901 Y156.383 E1.2346
G1 X110.424 Y156.383 E.02004
G1 X90.119 Y136.077 E1.20629
G1 X90.119 Y136.554 E.02004
G1 X109.948 Y156.383 E1.17799
G1 X109.472 Y156.383 E.02
G1 X90.119 Y137.03 E1.14971
G1 X90.119 Y137.506 E.02
G1 X108.996 Y156.383 E1.12143
G1 X108.52 Y156.383 E.02
G1 X90.119 Y137.983 E1.09312
G1 X90.119 Y138.459 E.02
G1 X108.044 Y156.384 E1.06488
G1 X107.567 Y156.384 E.02004
G1 X90.119 Y138.936 E1.03654
G1 X90.119 Y139.412 E.02
G1 X107.091 Y156.384 E1.00826
G1 X106.615 Y156.384 E.02
G1 X90.119 Y139.888 E.97998
G1 X90.119 Y140.365 E.02004
G1 X106.139 Y156.384 E.95168
G1 X105.663 Y156.384 E.02
G1 X90.119 Y140.841 E.9234
G1 X90.12 Y141.317 E.02
G1 X105.187 Y156.384 E.89509
G1 X104.71 Y156.384 E.02004
G1 X90.12 Y141.794 E.86675
G1 X90.12 Y142.27 E.02
G1 X104.234 Y156.385 E.8385
G1 X103.758 Y156.385 E.02
G1 X90.12 Y142.746 E.81023
G1 X90.12 Y143.223 E.02004
G1 X103.282 Y156.385 E.78192
G1 X102.806 Y156.385 E.02
G1 X90.12 Y143.699 E.75364
G1 X90.12 Y144.175 E.02
G1 X102.33 Y156.385 E.72536
G1 X101.853 Y156.385 E.02004
G1 X90.12 Y144.652 E.69703
G1 X90.12 Y145.128 E.02
G1 X101.377 Y156.385 E.66875
G1 X100.901 Y156.386 E.02
G1 X90.12 Y145.604 E.6405
G1 X90.12 Y146.081 E.02004
G1 X100.425 Y156.386 E.61219
G1 X99.949 Y156.386 E.02
G1 X90.12 Y146.557 E.58391
G1 X90.12 Y147.034 E.02004
G1 X99.472 Y156.386 E.55558
G1 X98.996 Y156.386 E.02
G1 X90.12 Y147.51 E.5273
G1 X90.12 Y147.986 E.02
G1 X98.52 Y156.386 E.49902
G1 X98.044 Y156.386 E.02
G1 X90.12 Y148.463 E.47071
G1 X90.12 Y148.939 E.02
G1 X97.568 Y156.386 E.44244
G1 X97.092 Y156.387 E.02
G1 X90.12 Y149.415 E.41419
G1 X90.12 Y149.892 E.02004
G1 X96.615 Y156.387 E.38585
G1 X96.139 Y156.387 E.02
G1 X90.12 Y150.368 E.35757
G1 X90.121 Y150.844 E.02
G1 X95.663 Y156.387 E.32926
G1 X95.165 Y156.366 E.02094
G1 X90.133 Y151.333 E.29897
G1 X90.192 Y151.868 E.02261
G1 X94.63 Y156.306 E.26365
G1 X94.196 Y156.226 E.01854
G1 X94.016 Y156.169 E.00793
G1 X90.329 Y152.482 E.21903
G1 X90.364 Y152.621 E.00602
G1 X90.596 Y153.225 E.02718
G1 X93.256 Y155.885 E.15802
G1 X92.97 Y155.755 E.0132
G1 X92.409 Y155.41 E.02767
G1 X91.898 Y155.003 E.02744
G1 X90.769 Y153.874 E.06707
;LAYER_CHANGE
;Z:0.46
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;0.46
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X91.898 Y155.003 E-.75841
G1 X92.409 Y155.41 E-.31031
G1 X92.97 Y155.755 E-.31283
G1 X93.197 Y155.858 E-.11845
;WIPE_END
G1 Z.46 F9000
;AFTER_LAYER_CHANGE
;0.46
M140 S70 ; set bed temperature
; stop printing object stand_s.stl id:0 copy 0
G1 Z.46
G1 X90.908 Y161.158
G1 E5 F2400
;TYPE:Skirt/Brim
;WIDTH:0.4
G1 F3600
G1 X90.47 Y160.97 E.01159
G1 X89.16 Y160.194 E.03704
G1 X88.001 Y159.273 E.03601
G1 X87.06 Y158.311 E.03273
G1 X86.218 Y157.208 E.03375
G1 X85.538 Y156.046 E.03275
G1 X84.894 Y154.492 E.04092
G1 X84.539 Y153.135 E.03412
G1 X84.345 Y151.518 E.03961
G1 X84.335 Y79.844 E1.7434
G1 X84.397 Y78.809 E.02522
G1 X84.622 Y77.48 E.03279
G1 X85.005 Y76.187 E.0328
G1 X85.541 Y74.949 E.03281
G1 X86.222 Y73.786 E.03278
G1 X87.039 Y72.713 E.0328
G1 X87.979 Y71.746 E.0328
G1 X89.029 Y70.9 E.0328
G1 X90.173 Y70.186 E.0328
G1 X91.395 Y69.615 E.03281
G1 X92.676 Y69.196 E.03278
G1 X93.999 Y68.935 E.0328
G1 X95.5 Y68.832 E.0366
G1 X135.656 Y68.835 E.97676
G1 X137.666 Y69.046 E.04916
G1 X139.605 Y69.615 E.04915
G1 X141.41 Y70.526 E.04918
G1 X143.021 Y71.746 E.04915
G1 X144.385 Y73.237 E.04915
G1 X145.459 Y74.949 E.04916
G1 X146.206 Y76.827 E.04916
G1 X146.603 Y78.809 E.04917
G1 X146.668 Y80 E.02901
G1 X146.666 Y151.152 E1.7307
G1 X146.569 Y152.479 E.03236
G1 X146.314 Y153.784 E.03234
G1 X145.907 Y155.05 E.03235
G1 X145.462 Y156.046 E.02653
G1 X144.785 Y157.203 E.03261
G1 X143.967 Y158.281 E.03292
G1 X143.028 Y159.247 E.03277
G1 X141.818 Y160.208 E.03759
G1 X140.679 Y160.894 E.03234
G1 X139.338 Y161.486 E.03566
G1 X138.001 Y161.883 E.03392
G1 X136.349 Y162.134 E.04064
G1 X95.35 Y162.166 E.99726
G1 X94.213 Y162.093 E.02771
G1 X92.855 Y161.85 E.03356
G1 X91.692 Y161.497 E.02956
G1 X90.963 Y161.182 E.01932
G1 E-3.5
;WIPE_START
G1 F7200
G1 X90.908 Y161.158 E-.0285
G1 X90.47 Y160.97 E-.22641
G1 X89.16 Y160.194 E-.72323
G1 X88.3 Y159.511 E-.52186
;WIPE_END
G1 X91.952 Y155.136 F9000
G1 X102.175 Y142.888
G1 X103.235 Y141.619
G1 X104.651 Y138.568
G1 X104.651 Y139.44
; printing object stand_s.stl id:0 copy 0
G1 X105.054 Y139.44
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X105.059 Y139.451 E.00029
G1 X105.183 Y139.5 E.00324
G1 X125.817 Y139.5 E.5019
G1 X125.941 Y139.452 E.00323
G1 X126 Y139.317 E.00358
G1 X126 Y138.451 E.02106
G1 X126.264 Y138 E.01271
G1 X126.37 Y137.533 E.01165
G1 X126.264 Y137 E.01322
G1 X126 Y136.549 E.01271
G1 X126 Y103.852 E.79532
G1 X126.044 Y103.792 E.00181
G1 X126.044 Y98.457 E.12977
G1 X126 Y98.395 E.00185
G1 X126 Y93.87 E.11007
G1 X126.064 Y93.718 E.00401
;TYPE:Overhang perimeter
;WIDTH:0.368782
;HEIGHT:0.368782
G1 X138.882 Y93.721 E.56922
;WIDTH:0.399999
;HEIGHT:0.16
G1 X139.062 Y93.777 E.00459
G1 X139.151 Y93.977 E.00532
G1 X139.206 Y94.5 E.01279
G1 X139.184 Y94.728 E.00557
G1 X139.053 Y95.055 E.00857
G1 X138.937 Y95.107 E.00309
;WIDTH:0.368782
;HEIGHT:0.368782
G1 X136.339 Y95.119 E.11537
;WIDTH:0.399999
;HEIGHT:0.16
G1 X136.183 Y95.119 E.00379
G1 X136.037 Y95.192 E.00397
G1 X136 Y95.301 E.0028
G1 X136 Y127.168 E.77513
G1 X135.978 Y127.642 E.01154
G1 X135.978 Y132.948 E.12906
G1 X135.87 Y133.89 E.02306
G1 X135.689 Y134.747 E.02131
G1 X135.249 Y136.062 E.03373
G1 X134.835 Y136.933 E.02346
G1 X134.387 Y137.686 E.02131
G1 X133.544 Y138.788 E.03375
G1 X132.871 Y139.478 E.02344
G1 X132.203 Y140.046 E.02133
G1 X131.05 Y140.816 E.03372
G1 X130.189 Y141.251 E.02346
G1 X129.371 Y141.573 E.02138
G1 X128.484 Y141.83 E.02246
G1 X127.993 Y141.934 E.01221
G1 X127.171 Y142.05 E.02019
G1 X126.663 Y142.089 E.01239
G1 X120.734 Y142.1 E.14422
G1 X120.667 Y142.062 E.00187
G1 X110.333 Y142.062 E.25136
G1 X110.265 Y142.1 E.00189
G1 X104.804 Y142.1 E.13283
G1 X103.879 Y142.057 E.02252
G1 X102.646 Y141.854 E.0304
G1 X102.069 Y141.712 E.01445
G1 X101.195 Y141.413 E.02247
G1 X100.394 Y141.053 E.02136
G1 X99.554 Y140.578 E.02347
G1 X98.472 Y139.783 E.03266
G1 X97.766 Y139.125 E.02347
G1 X97.283 Y138.579 E.01773
G1 X96.878 Y138.071 E.0158
G1 X96.163 Y136.932 E.03271
G1 X95.749 Y136.06 E.02348
G1 X95.437 Y135.195 E.02237
G1 X95.129 Y133.888 E.03266
G1 X95.021 Y132.948 E.02301
G1 X95.021 Y127.642 E.12906
G1 X94.999 Y127.607 E.00101
G1 X94.999 Y95.301 E.78581
G1 X94.962 Y95.192 E.0028
G1 X94.816 Y95.119 E.00397
G1 X94.66 Y95.119 E.00379
;WIDTH:0.368782
;HEIGHT:0.368782
G1 X92.155 Y95.107 E.11124
;WIDTH:0.399999
;HEIGHT:0.16
G1 X91.953 Y95.068 E.005
G1 X91.846 Y94.867 E.00554
G1 X91.786 Y94.413 E.01114
G1 X91.847 Y93.952 E.01131
G1 X91.953 Y93.782 E.00487
G1 X92.057 Y93.721 E.00293
;WIDTH:0.368782
;HEIGHT:0.368782
G1 X104.939 Y93.721 E.57207
;WIDTH:0.399999
;HEIGHT:0.16
G1 X105 Y93.829 E.00302
G1 X105 Y98.395 E.11106
G1 X104.956 Y98.457 E.00185
G1 X104.956 Y103.792 E.12977
G1 X105 Y103.852 E.00181
G1 X105 Y136.549 E.79532
G1 X104.736 Y137 E.01271
G1 X104.629 Y137.471 E.01175
G1 X104.736 Y138 E.01313
G1 X105 Y138.451 E.01271
G1 X105 Y139.317 E.02106
G1 X105.03 Y139.385 E.00181
G1 X105.03 Y139.385 F9000
G1 X104.796 Y139.691
;TYPE:Perimeter
G1 F6000
G1 X104.811 Y139.72 E.00079
G1 X105.056 Y139.851 E.00676
G1 X105.183 Y139.866 E.00311
G1 X125.817 Y139.866 E.5019
G1 X126.093 Y139.792 E.00695
G1 X126.321 Y139.535 E.00836
G1 X126.366 Y139.317 E.00541
G1 X126.366 Y138.55 E.01866
G1 X126.644 Y138.017 E.01462
G1 X126.736 Y137.447 E.01404
G1 X126.621 Y136.902 E.01355
G1 X126.366 Y136.45 E.01262
G1 X126.366 Y103.897 E.79182
G1 X126.409 Y103.792 E.00276
G1 X126.409 Y98.457 E.12977
G1 X126.366 Y98.346 E.0029
G1 X126.366 Y94.077 E.10384
G1 X138.796 Y94.075 E.30235
G1 X138.842 Y94.465 E.00955
G1 X138.795 Y94.753 E.0071
G1 X136.088 Y94.761 E.06585
G1 X135.745 Y94.972 E.0098
G1 X135.635 Y95.301 E.00844
G1 X135.634 Y127.168 E.77513
G1 X135.613 Y127.642 E.01154
G1 X135.613 Y132.927 E.12855
G1 X135.508 Y133.831 E.02214
G1 X135.336 Y134.651 E.02038
G1 X134.909 Y135.925 E.03268
G1 X134.512 Y136.761 E.02251
G1 X134.083 Y137.481 E.02039
G1 X133.267 Y138.549 E.03269
G1 X132.621 Y139.211 E.0225
G1 X131.982 Y139.754 E.0204
G1 X130.865 Y140.499 E.03266
G1 X130.039 Y140.917 E.02252
G1 X129.253 Y141.226 E.02054
G1 X128.395 Y141.475 E.02173
G1 X127.88 Y141.58 E.01278
G1 X126.65 Y141.724 E.03012
G1 X120.999 Y141.734 E.13746
G1 X120.667 Y141.697 E.00813
G1 X110.333 Y141.697 E.25136
G1 X110.191 Y141.735 E.00358
G1 X104.812 Y141.735 E.13084
G1 X103.918 Y141.692 E.02177
G1 X102.705 Y141.493 E.0299
G1 X102.175 Y141.362 E.01328
G1 X101.329 Y141.073 E.02175
G1 X100.559 Y140.727 E.02053
G1 X99.753 Y140.27 E.02254
G1 X98.706 Y139.501 E.0316
G1 X98.029 Y138.869 E.02253
G1 X97.557 Y138.337 E.0173
G1 X97.179 Y137.861 E.01478
G1 X96.484 Y136.755 E.03177
G1 X96.087 Y135.919 E.02251
G1 X95.788 Y135.09 E.02144
G1 X95.49 Y133.824 E.03164
G1 X95.386 Y132.927 E.02196
G1 X95.386 Y127.642 E.12855
G1 X95.365 Y127.574 E.00173
G1 X95.365 Y95.301 E.78501
G1 X95.255 Y94.972 E.00844
G1 X94.816 Y94.753 E.01193
G1 X92.194 Y94.753 E.06378
G1 X92.157 Y94.447 E.0075
G1 X92.192 Y94.075 E.00909
G1 X104.634 Y94.077 E.30264
G1 X104.634 Y98.346 E.10384
G1 X104.591 Y98.457 E.0029
G1 X104.591 Y103.792 E.12977
G1 X104.634 Y103.897 E.00276
G1 X104.634 Y136.45 E.79182
G1 X104.42 Y136.816 E.01031
G1 X104.35 Y137.013 E.00509
G1 X104.264 Y137.549 E.0132
G1 X104.378 Y138.096 E.01359
G1 X104.634 Y138.55 E.01268
G1 X104.636 Y139.364 E.0198
G1 X104.77 Y139.637 E.0074
G1 E-5 F3600
G1 X104.77 Y139.637 F9000
G1 X104.651 Y139.637
G1 X104.651 Y139.849
G1 X126.349 Y139.849
G1 X126.709 Y137.703
G1 X126.723 Y137.5
G1 X127.769 Y94.058
G1 X136.475 Y94.77
G1 X136.029 Y94.77
G1 X136.029 Y94.421
G1 E5 F2400
;WIDTH:0.359528
G1 F6000
G1 X136.183 Y94.414 E.00333
;WIDTH:0.346948
G1 X138.502 Y94.414 E.04822
G1 E-5 F3600
G1 X138.502 Y94.414 F9000
G1 X138.502 Y94.058
G1 X135.652 Y94.77
G1 X135.652 Y96.54
G1 X135.269 Y96.54
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X135.269 Y127.168 E.745
G1 X135.247 Y127.642 E.01154
G1 X135.247 Y132.906 E.12804
G1 X135.147 Y133.772 E.0212
G1 X134.982 Y134.555 E.01946
G1 X134.569 Y135.788 E.03163
G1 X134.189 Y136.589 E.02156
G1 X133.78 Y137.276 E.01945
G1 X132.99 Y138.309 E.03163
G1 X132.371 Y138.943 E.02155
G1 X131.762 Y139.461 E.01945
G1 X130.68 Y140.183 E.03164
G1 X129.889 Y140.583 E.02156
G1 X129.135 Y140.88 E.01971
G1 X128.353 Y141.107 E.01981
G1 X127.829 Y141.218 E.01303
G1 X126.637 Y141.358 E.02919
G1 X120.998 Y141.368 E.13716
G1 X120.667 Y141.331 E.0081
G1 X110.333 Y141.331 E.25136
G1 X110.116 Y141.369 E.00536
G1 X104.821 Y141.369 E.1288
G1 X103.956 Y141.328 E.02106
G1 X102.765 Y141.132 E.02936
G1 X102.28 Y141.011 E.01216
G1 X101.464 Y140.732 E.02098
G1 X100.724 Y140.4 E.01973
G1 X99.952 Y139.963 E.02158
G1 X98.94 Y139.219 E.03055
G1 X98.291 Y138.614 E.02158
G1 X97.83 Y138.094 E.0169
G1 X97.479 Y137.652 E.01373
G1 X96.806 Y136.579 E.03081
G1 X96.425 Y135.778 E.02158
G1 X96.139 Y134.986 E.02048
G1 X95.851 Y133.761 E.03061
G1 X95.752 Y132.906 E.02094
G1 X95.752 Y127.642 E.12804
G1 X95.73 Y127.542 E.00249
G1 X95.73 Y95.301 E.78423
G1 X95.547 Y94.753 E.01405
G1 X95.182 Y94.583 E.00979
;WIDTH:0.373053
G1 X94.816 Y94.414 E.00908
G1 X95.26 Y94.428 E.01001
;WIDTH:0.399999
G1 X95.703 Y94.441 E.01078
G1 X104.269 Y94.443 E.20836
G1 X104.269 Y98.298 E.09377
G1 X104.234 Y98.328 E.00112
G1 X104.225 Y98.457 E.00315
G1 X104.225 Y103.792 E.12977
G1 X104.233 Y103.91 E.00288
G1 X104.269 Y103.941 E.00116
G1 X104.269 Y136.35 E.78832
G1 X104.024 Y136.809 E.01266
G1 X103.914 Y137.316 E.01262
G1 X103.914 Y137.684 E.00895
G1 X104.035 Y138.222 E.01341
G1 X104.269 Y138.65 E.01187
G1 X104.291 Y139.517 E.0211
G1 X104.563 Y139.989 E.01325
G1 X104.971 Y140.206 E.01124
G1 X105.183 Y140.231 E.00519
G1 X125.817 Y140.231 E.5019
G1 X125.977 Y140.217 E.00391
G1 X126.276 Y140.108 E.00774
G1 X126.436 Y139.99 E.00484
G1 X126.656 Y139.68 E.00925
G1 X126.731 Y139.317 E.00902
G1 X126.731 Y138.65 E.01622
G1 X126.924 Y138.316 E.00938
G1 X127.086 Y137.684 E.01587
G1 X127.1 Y137.412 E.00662
G1 X126.994 Y136.872 E.01339
G1 X126.731 Y136.35 E.01422
G1 X126.731 Y103.941 E.78832
G1 X126.767 Y103.91 E.00116
G1 X126.775 Y103.792 E.00288
G1 X126.775 Y98.689 E.12413
G1 X126.766 Y98.328 E.00878
G1 X126.731 Y98.298 E.00112
G1 X126.731 Y94.443 E.09377
G1 X135.296 Y94.441 E.20834
G1 X136.029 Y94.421 E.01784
G1 X135.452 Y94.753 E.01619
G1 X135.269 Y95.301 E.01405
G1 X135.269 Y96.48 E.02868
G1 X135.269 Y96.48 F9000
G1 X135.068 Y94.807
G1 F6000
G1 X134.903 Y95.301 E.01267
G1 X134.903 Y127.168 E.77513
G1 X134.881 Y127.642 E.01154
G1 X134.881 Y132.885 E.12753
G1 X134.786 Y133.713 E.02027
G1 X134.629 Y134.459 E.01854
G1 X134.23 Y135.651 E.03058
G1 X133.866 Y136.416 E.02061
G1 X133.477 Y137.071 E.01853
G1 X132.827 Y137.921 E.02603
G1 X132.456 Y138.332 E.01347
G1 X131.97 Y138.804 E.01648
G1 X131.418 Y139.251 E.01728
G1 X130.32 Y139.955 E.03173
G1 X129.664 Y140.278 E.01779
G1 X128.8 Y140.596 E.02239
G1 X127.778 Y140.856 E.02565
G1 X126.613 Y140.992 E.02853
;WIDTH:0.415528
G1 X125.818 Y140.986 E.02016
;WIDTH:0.419963
G1 X120.997 Y140.993 E.12367
G1 X120.667 Y140.965 E.0085
;WIDTH:0.401407
G1 X110.333 Y140.965 E.25233
;WIDTH:0.420283
G1 X110 Y140.993 E.00858
G1 X105.183 Y140.993 E.12367
;WIDTH:0.440706
G1 X103.995 Y140.964 E.03212
;WIDTH:0.399999
G1 X102.824 Y140.771 E.02887
G1 X102.385 Y140.661 E.01101
G1 X101.598 Y140.392 E.02023
G1 X100.89 Y140.073 E.01889
G1 X100.151 Y139.655 E.02065
G1 X99.173 Y138.937 E.02951
G1 X98.553 Y138.358 E.02063
G1 X98.104 Y137.852 E.01645
G1 X97.78 Y137.443 E.01269
G1 X97.127 Y136.403 E.02987
G1 X96.763 Y135.637 E.02063
G1 X96.49 Y134.882 E.01953
G1 X96.212 Y133.698 E.02958
G1 X96.118 Y132.885 E.01991
G1 X96.118 Y127.642 E.12753
G1 X96.096 Y127.51 E.00326
G1 X96.096 Y95.301 E.78345
G1 X95.931 Y94.807 E.01267
G1 X103.903 Y94.808 E.19391
G1 X103.903 Y97.845 E.07387
G1 X103.859 Y98.457 E.01492
G1 X103.859 Y103.792 E.12977
G1 X103.87 Y103.957 E.00402
G1 X103.903 Y103.986 E.00107
G1 X103.903 Y136.251 E.78481
G1 X103.677 Y136.695 E.01212
G1 X103.547 Y137.295 E.01493
G1 X103.556 Y137.757 E.01124
G1 X103.692 Y138.348 E.01475
G1 X103.903 Y138.749 E.01102
G1 X103.934 Y139.597 E.02064
G1 X104.315 Y140.257 E.01854
;WIDTH:0.440706
G1 X104.882 Y140.582 E.01767
G1 X105.183 Y140.607 E.00816
;WIDTH:0.420285
G1 X110.333 Y140.598 E.13222
;WIDTH:0.401407
G1 X120.667 Y140.598 E.25233
;WIDTH:0.419963
G1 X125.817 Y140.605 E.13211
;WIDTH:0.426727
G1 X126.043 Y140.59 E.00591
G1 X126.46 Y140.424 E.01172
;WIDTH:0.399999
G1 X126.684 Y140.259 E.00677
G1 X126.992 Y139.825 E.01294
G1 X127.061 Y139.618 E.00531
G1 X127.097 Y139.317 E.00737
G1 X127.097 Y138.749 E.01382
G1 X127.346 Y138.227 E.01407
G1 X127.444 Y137.757 E.01168
G1 X127.464 Y137.376 E.00928
G1 X127.307 Y136.648 E.01811
G1 X127.097 Y136.251 E.01092
G1 X127.097 Y103.986 E.78481
G1 X127.13 Y103.957 E.00107
G1 X127.141 Y103.792 E.00402
G1 X127.141 Y98.457 E.12977
G1 X127.097 Y98.249 E.00517
G1 X127.097 Y94.808 E.0837
G1 X135.008 Y94.807 E.19243
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X135.068 Y94.807 E-.0285
G1 X134.903 Y95.301 E-.24739
G1 X134.903 Y97.878 E-1.22411
;WIPE_END
G1 X103.537 Y95.174 F9000
G1 E5 F2400
G1 F6000
G1 X103.537 Y97.845 E.06497
G1 X103.494 Y98.457 E.01492
G1 X103.494 Y103.792 E.12977
G1 X103.537 Y104.031 E.00591
G1 X103.537 Y136.152 E.78131
G1 X103.329 Y136.582 E.01162
G1 X103.186 Y137.236 E.01628
G1 X103.198 Y137.83 E.01445
G1 X103.348 Y138.474 E.01608
G1 X103.537 Y138.848 E.01019
G1 X103.537 Y139.134 E.00696
G1 X103.577 Y139.676 E.01322
G1 X104.067 Y140.526 E.02386
G1 X104.221 Y140.608 E.00424
G1 X104.033 Y140.6 E.00458
G1 X102.884 Y140.41 E.02833
G1 X102.491 Y140.311 E.00986
G1 X101.732 Y140.051 E.01952
G1 X101.055 Y139.747 E.01805
G1 X100.35 Y139.348 E.0197
G1 X99.516 Y138.735 E.02518
G1 X99.188 Y138.45 E.01057
G1 X98.711 Y137.985 E.0162
G1 X98.08 Y137.234 E.02386
G1 X97.448 Y136.226 E.02894
G1 X97.101 Y135.497 E.01964
G1 X96.841 Y134.777 E.01862
G1 X96.572 Y133.635 E.02854
G1 X96.483 Y132.864 E.01888
G1 X96.483 Y127.642 E.12702
G1 X96.462 Y127.478 E.00402
G1 X96.462 Y95.301 E.78267
G1 X96.419 Y95.173 E.00328
G1 X103.477 Y95.174 E.17168
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.537 Y95.174 E-.0285
G1 X103.537 Y97.845 E-1.26872
G1 X103.507 Y98.271 E-.20278
;WIPE_END
G1 X127.463 Y114.216 F9000
G1 E5 F2400
G1 F6000
G1 X127.463 Y104.462 E.23726
G1 X127.506 Y103.792 E.01633
G1 X127.506 Y98.457 E.12977
G1 X127.463 Y98.201 E.00631
G1 X127.463 Y95.174 E.07363
G1 X134.581 Y95.173 E.17314
G1 X134.538 Y95.301 E.00328
G1 X134.537 Y127.168 E.77513
G1 X134.516 Y127.642 E.01154
G1 X134.516 Y132.864 E.12702
G1 X134.424 Y133.655 E.01937
G1 X134.275 Y134.363 E.0176
G1 X133.89 Y135.514 E.02952
G1 X133.543 Y136.244 E.01966
G1 X133.173 Y136.865 E.01758
G1 X132.536 Y137.698 E.02551
G1 X132.195 Y138.077 E.0124
G1 X131.734 Y138.525 E.01564
G1 X131.215 Y138.947 E.01627
G1 X130.155 Y139.629 E.03066
G1 X129.53 Y139.938 E.01696
G1 X128.698 Y140.245 E.02157
G1 X127.727 Y140.494 E.02438
G1 X126.817 Y140.612 E.02232
G1 X126.932 Y140.528 E.00346
G1 X127.328 Y139.97 E.01664
G1 X127.417 Y139.704 E.00682
G1 X127.463 Y139.317 E.00948
G1 X127.463 Y138.848 E.01141
G1 X127.7 Y138.319 E.0141
G1 X127.802 Y137.83 E.01215
G1 X127.828 Y137.341 E.01191
G1 X127.65 Y136.521 E.02041
G1 X127.463 Y136.152 E.01006
G1 X127.463 Y114.276 E.53211
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X127.463 Y114.216 E-.0285
G1 X127.463 Y111.118 E-1.4715
;WIPE_END
G1 X92.494 Y94.414 F9000
G1 E5 F2400
;WIDTH:0.346952
G1 F6000
G1 X94.816 Y94.414 E.04829
;WIDTH:0.346106
G1 E-5 F3600
G1 X94.816 Y94.414 F9000
G1 X96.835 Y95.477
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.488694
G1 F1200
G1 X96.795 Y95.436 E.00173
G1 X96.74 Y95.451 E.00172
G1 X96.725 Y95.506 E.00172
G1 X96.766 Y95.546 E.00173
G1 X96.82 Y95.532 E.00169
;WIDTH:0.399999
G1 X97.404 Y95.447 E.01435
G1 X96.736 Y96.116 E.023
G1 X96.736 Y96.633 E.01258
G1 X97.921 Y95.447 E.04078
G1 X98.438 Y95.447 E.01258
G1 X96.736 Y97.15 E.05856
G1 X96.736 Y97.667 E.01258
G1 X98.955 Y95.447 E.07635
G1 X99.473 Y95.447 E.0126
G1 X96.736 Y98.184 E.09415
G1 X96.736 Y98.701 E.01258
G1 X99.99 Y95.448 E.11192
G1 X100.507 Y95.448 E.01258
G1 X96.736 Y99.218 E.1297
G1 X96.736 Y99.735 E.01258
G1 X101.024 Y95.448 E.14749
G1 X101.541 Y95.448 E.01258
G1 X96.736 Y100.253 E.16529
G1 X96.736 Y100.77 E.01258
G1 X102.058 Y95.448 E.18307
G1 X102.575 Y95.448 E.01258
G1 X96.736 Y101.287 E.20086
G1 X96.736 Y101.804 E.01258
G1 X103.092 Y95.448 E.21864
G1 X103.263 Y95.794 E.00939
G1 X96.736 Y102.321 E.22452
G1 X96.736 Y102.838 E.01258
G1 X103.263 Y96.311 E.22452
G1 X103.263 Y96.828 E.01258
G1 X96.736 Y103.355 E.22452
G1 X96.736 Y103.872 E.01258
G1 X103.263 Y97.345 E.22452
G1 X103.263 Y97.862 E.01258
G1 X96.736 Y104.39 E.22454
G1 X96.736 Y104.907 E.01258
G1 X103.222 Y98.421 E.22311
G1 X103.22 Y98.94 E.01262
G1 X96.736 Y105.424 E.22305
G1 X96.736 Y105.941 E.01258
G1 X103.22 Y99.457 E.22305
G1 X103.22 Y99.974 E.01258
G1 X96.736 Y106.458 E.22305
G1 X96.736 Y106.975 E.01258
G1 X103.22 Y100.492 E.22303
G1 X103.22 Y101.009 E.01258
G1 X96.736 Y107.492 E.22303
G1 X96.736 Y108.009 E.01258
G1 X103.22 Y101.526 E.22303
G1 X103.22 Y102.043 E.01258
G1 X96.736 Y108.527 E.22305
G1 X96.736 Y109.044 E.01258
G1 X103.22 Y102.56 E.22305
G1 X103.22 Y103.077 E.01258
G1 X96.736 Y109.561 E.22305
G1 X96.736 Y110.078 E.01258
G1 X103.22 Y103.594 E.22305
G1 X103.249 Y104.082 E.01189
G1 X96.736 Y110.595 E.22404
G1 X96.736 Y111.112 E.01258
G1 X103.263 Y104.585 E.22452
G1 X103.263 Y105.102 E.01258
G1 X96.736 Y111.629 E.22452
G1 X96.736 Y112.146 E.01258
G1 X103.263 Y105.619 E.22452
G1 X103.263 Y106.136 E.01258
G1 X96.736 Y112.664 E.22454
G1 X96.736 Y113.181 E.01258
G1 X103.263 Y106.654 E.22452
G1 X103.263 Y107.171 E.01258
G1 X96.736 Y113.698 E.22452
G1 X96.736 Y114.215 E.01258
G1 X103.263 Y107.688 E.22452
G1 X103.263 Y108.205 E.01258
G1 X96.736 Y114.732 E.22452
G1 X96.736 Y115.249 E.01258
G1 X103.263 Y108.722 E.22452
G1 X103.263 Y109.239 E.01258
G1 X96.736 Y115.766 E.22452
G1 X96.736 Y116.283 E.01258
G1 X103.263 Y109.756 E.22452
G1 X103.263 Y110.273 E.01258
G1 X96.736 Y116.801 E.22454
G1 X96.736 Y117.318 E.01258
G1 X103.263 Y110.791 E.22452
G1 X103.263 Y111.308 E.01258
G1 X96.736 Y117.835 E.22452
G1 X96.736 Y118.352 E.01258
G1 X103.263 Y111.825 E.22452
G1 X103.263 Y112.342 E.01258
G1 X96.736 Y118.869 E.22452
G1 X96.736 Y119.386 E.01258
G1 X103.263 Y112.859 E.22452
G1 X103.263 Y113.376 E.01258
G1 X96.736 Y119.903 E.22452
G1 X96.736 Y120.42 E.01258
G1 X103.263 Y113.893 E.22452
G1 X103.263 Y114.41 E.01258
G1 X96.736 Y120.938 E.22454
G1 X96.736 Y121.455 E.01258
G1 X103.263 Y114.928 E.22452
G1 X103.263 Y115.445 E.01258
G1 X96.736 Y121.972 E.22452
G1 X96.736 Y122.489 E.01258
G1 X103.263 Y115.962 E.22452
G1 X103.263 Y116.479 E.01258
G1 X96.736 Y123.006 E.22452
G1 X96.736 Y123.523 E.01258
G1 X103.263 Y116.996 E.22452
G1 X103.263 Y117.513 E.01258
G1 X96.736 Y124.04 E.22452
G1 X96.736 Y124.557 E.01258
G1 X103.263 Y118.03 E.22452
G1 X103.263 Y118.547 E.01258
G1 X96.736 Y125.075 E.22454
G1 X96.736 Y125.592 E.01258
G1 X103.263 Y119.065 E.22452
G1 X103.263 Y119.582 E.01258
G1 X96.736 Y126.109 E.22452
G1 X96.736 Y126.626 E.01258
G1 X103.263 Y120.099 E.22452
G1 X103.263 Y120.616 E.01258
G1 X96.736 Y127.143 E.22452
G1 X96.758 Y127.638 E.01205
G1 X103.263 Y121.133 E.22377
G1 X103.263 Y121.65 E.01258
G1 X96.758 Y128.156 E.22378
G1 X96.758 Y128.673 E.01258
G1 X103.263 Y122.167 E.22378
G1 X103.263 Y122.684 E.01258
G1 X96.758 Y129.19 E.22378
G1 X96.758 Y129.707 E.01258
G1 X103.263 Y123.202 E.22377
G1 X103.263 Y123.719 E.01258
G1 X96.758 Y130.224 E.22377
G1 X96.758 Y130.741 E.01258
G1 X103.263 Y124.236 E.22377
G1 X103.263 Y124.753 E.01258
G1 X96.758 Y131.258 E.22377
G1 X96.758 Y131.775 E.01258
G1 X103.263 Y125.27 E.22377
G1 X103.263 Y125.787 E.01258
G1 X96.758 Y132.293 E.22378
G1 X96.758 Y132.81 E.01258
G1 X103.263 Y126.304 E.22378
G1 X103.263 Y126.821 E.01258
G1 X96.807 Y133.277 E.22208
G1 X96.875 Y133.726 E.01105
G1 X103.263 Y127.339 E.21973
G1 X103.263 Y127.856 E.01258
G1 X96.974 Y134.145 E.21634
G1 X97.072 Y134.563 E.01044
G1 X103.263 Y128.373 E.21295
G1 X103.263 Y128.89 E.01258
G1 X97.197 Y134.956 E.20867
G1 X97.334 Y135.336 E.00983
G1 X103.263 Y129.407 E.20395
G1 X103.263 Y129.924 E.01258
G1 X97.497 Y135.691 E.19836
G1 X97.663 Y136.041 E.00942
G1 X103.263 Y130.441 E.19264
G1 X103.263 Y130.958 E.01258
G1 X97.858 Y136.364 E.18595
G1 X98.057 Y136.682 E.00912
G1 X103.263 Y131.476 E.17908
G1 X103.263 Y131.993 E.01258
G1 X98.257 Y136.999 E.1722
G1 X98.475 Y137.298 E.009
G1 X103.263 Y132.51 E.1647
G1 X103.263 Y133.027 E.01258
G1 X98.714 Y137.576 E.15648
G1 X98.957 Y137.85 E.00891
G1 X103.263 Y133.544 E.14812
G1 X103.263 Y134.061 E.01258
G1 X99.219 Y138.105 E.13911
G1 X99.487 Y138.354 E.0089
G1 X103.263 Y134.578 E.12989
G1 X103.263 Y135.095 E.01258
G1 X99.774 Y138.584 E.12002
G1 X100.072 Y138.803 E.009
G1 X103.263 Y135.613 E.10975
G1 X103.216 Y136.177 E.01377
G1 X100.37 Y139.022 E.09788
G1 E-5 F3600
G1 X100.37 Y139.022 F9000
G1 X102.836 Y137.074
G1 E5 F2400
G1 F1200
G1 X100.687 Y139.223 E.07392
G1 X101.179 Y139.502 E.01376
G1 X101.831 Y139.795 E.01739
G1 X102.918 Y140.138 E.02773
G1 X103.601 Y140.251 E.01684
G1 X103.328 Y139.777 E.01331
G1 X103.27 Y139.466 E.0077
G1 X103.263 Y138.919 E.01331
G1 X103.087 Y138.553 E.00988
G1 X102.901 Y137.688 E.02152
G1 X102.917 Y137.181 E.01234
G1 X102.965 Y136.945 E.00586
G1 X102.965 Y136.945 F9000
G1 X102.562 Y137.865
G1 F1200
G1 X102.664 Y138.403 E.01332
G1 X102.852 Y138.912 E.0132
G1 X102.9 Y139.111 E.00498
G1 X102.943 Y139.763 E.01589
G1 X101.935 Y139.441 E.02574
G1 X101.285 Y139.142 E.0174
G1 X102.432 Y137.995 E.03946
G1 X102.338 Y138.612 E.01518
;WIDTH:0.409155
G1 X102.52 Y139.076 E.01243
G1 X102.531 Y139.244 E.0042
G1 X101.922 Y139.029 E.0161
G1 X102.209 Y138.742 E.01012
G1 E-5 F3600
G1 X102.209 Y138.742 F9000
G1 X126.723 Y137.5
G1 X127.836 Y95.478
G1 E5 F2400
;WIDTH:0.488738
G1 F1200
G1 X127.796 Y95.438 E.00171
G1 X127.741 Y95.452 E.00172
G1 X127.726 Y95.507 E.00172
G1 X127.767 Y95.547 E.00173
G1 X127.821 Y95.533 E.00169
;WIDTH:0.399999
G1 X127.737 Y96.117 E.01435
G1 X128.406 Y95.448 E.02301
G1 X128.576 Y95.322 E.00515
;WIDTH:0.374336
G1 X128.535 Y95.333 E.00096
G1 X128.516 Y95.262 E.00166
G1 X128.587 Y95.281 E.00166
;WIDTH:0.399999
G1 X128.923 Y95.448 E.00913
G1 X127.737 Y96.634 E.0408
G1 X127.737 Y97.151 E.01258
G1 X129.44 Y95.448 E.05858
G1 X129.957 Y95.448 E.01258
G1 X127.737 Y97.668 E.07637
G1 X127.76 Y98.162 E.01203
G1 X130.474 Y95.448 E.09336
G1 X130.992 Y95.448 E.0126
G1 X127.78 Y98.659 E.11047
G1 X127.78 Y99.176 E.01258
G1 X131.509 Y95.448 E.12826
G1 X132.026 Y95.447 E.01258
G1 X127.78 Y99.693 E.14606
G1 X127.78 Y100.21 E.01258
G1 X132.543 Y95.447 E.16384
G1 X133.061 Y95.447 E.0126
G1 X127.78 Y100.727 E.18165
G1 X127.78 Y101.244 E.01258
G1 X133.578 Y95.447 E.19943
G1 X134.095 Y95.447 E.01258
G1 X127.78 Y101.762 E.21723
G1 X127.78 Y102.279 E.01258
G1 X134.264 Y95.796 E.22303
G1 X134.264 Y96.313 E.01258
G1 X127.78 Y102.796 E.22303
G1 X127.78 Y103.313 E.01258
G1 X134.264 Y96.83 E.22303
G1 X134.264 Y97.347 E.01258
G1 X127.778 Y103.833 E.22311
G1 X127.737 Y104.391 E.01361
G1 X134.264 Y97.864 E.22452
G1 X134.264 Y98.381 E.01258
G1 X127.737 Y104.908 E.22452
G1 X127.737 Y105.425 E.01258
G1 X134.264 Y98.898 E.22452
G1 X134.263 Y99.416 E.0126
G1 X127.737 Y105.942 E.22449
G1 X127.737 Y106.459 E.01258
G1 X134.263 Y99.933 E.22449
G1 X134.263 Y100.45 E.01258
G1 X127.737 Y106.976 E.22449
G1 X127.737 Y107.494 E.0126
G1 X134.263 Y100.967 E.22451
G1 X134.263 Y101.484 E.01258
G1 X127.737 Y108.011 E.22451
G1 X127.737 Y108.528 E.01258
G1 X134.263 Y102.001 E.22451
G1 X134.263 Y102.518 E.01258
G1 X127.737 Y109.045 E.22451
G1 X127.737 Y109.562 E.01258
G1 X134.263 Y103.036 E.22449
G1 X134.263 Y103.553 E.01258
G1 X127.737 Y110.079 E.22449
G1 X127.737 Y110.596 E.01258
G1 X134.263 Y104.07 E.22449
G1 X134.263 Y104.587 E.01258
G1 X127.737 Y111.113 E.22449
G1 X127.737 Y111.631 E.0126
G1 X134.263 Y105.104 E.22451
G1 X134.263 Y105.621 E.01258
G1 X127.737 Y112.148 E.22451
G1 X127.737 Y112.665 E.01258
G1 X134.263 Y106.138 E.22451
G1 X134.263 Y106.655 E.01258
G1 X127.737 Y113.182 E.22451
G1 X127.737 Y113.699 E.01258
G1 X134.263 Y107.173 E.22449
G1 X134.263 Y107.69 E.01258
G1 X127.737 Y114.216 E.22449
G1 X127.737 Y114.733 E.01258
G1 X134.263 Y108.207 E.22449
G1 X134.263 Y108.724 E.01258
G1 X127.737 Y115.25 E.22449
G1 X127.737 Y115.768 E.0126
G1 X134.263 Y109.241 E.22451
G1 X134.263 Y109.758 E.01258
G1 X127.737 Y116.285 E.22451
G1 X127.737 Y116.802 E.01258
G1 X134.263 Y110.275 E.22451
G1 X134.263 Y110.792 E.01258
G1 X127.737 Y117.319 E.22451
G1 X127.737 Y117.836 E.01258
G1 X134.263 Y111.31 E.22449
G1 X134.263 Y111.827 E.01258
G1 X127.737 Y118.353 E.22449
G1 X127.737 Y118.87 E.01258
G1 X134.263 Y112.344 E.22449
G1 X134.263 Y112.861 E.01258
G1 X127.737 Y119.387 E.22449
G1 X127.737 Y119.905 E.0126
G1 X134.263 Y113.378 E.22451
G1 X134.263 Y113.895 E.01258
G1 X127.737 Y120.422 E.22451
G1 X127.737 Y120.939 E.01258
G1 X134.263 Y114.412 E.22451
G1 X134.263 Y114.93 E.0126
G1 X127.737 Y121.456 E.22449
G1 X127.737 Y121.973 E.01258
G1 X134.263 Y115.447 E.22449
G1 X134.263 Y115.964 E.01258
G1 X127.737 Y122.49 E.22449
G1 X127.737 Y123.007 E.01258
G1 X134.263 Y116.481 E.22449
G1 X134.263 Y116.998 E.01258
G1 X127.737 Y123.524 E.22449
G1 X127.737 Y124.042 E.0126
G1 X134.263 Y117.515 E.22451
G1 X134.263 Y118.032 E.01258
G1 X127.737 Y124.559 E.22451
G1 X127.737 Y125.076 E.01258
G1 X134.263 Y118.549 E.22451
G1 X134.263 Y119.067 E.0126
G1 X127.737 Y125.593 E.22449
G1 X127.737 Y126.11 E.01258
G1 X134.263 Y119.584 E.22449
G1 X134.263 Y120.101 E.01258
G1 X127.737 Y126.627 E.22449
G1 X127.737 Y127.144 E.01258
G1 X134.263 Y120.618 E.22449
G1 X134.263 Y121.135 E.01258
G1 X127.737 Y127.661 E.22449
G1 X127.737 Y128.179 E.0126
G1 X134.263 Y121.652 E.22451
G1 X134.263 Y122.169 E.01258
G1 X127.737 Y128.696 E.22451
G1 X127.737 Y129.213 E.01258
G1 X134.263 Y122.687 E.22449
G1 X134.263 Y123.204 E.01258
G1 X127.737 Y129.73 E.22449
G1 X127.737 Y130.247 E.01258
G1 X134.263 Y123.721 E.22449
G1 X134.263 Y124.238 E.01258
G1 X127.737 Y130.764 E.22449
G1 X127.737 Y131.281 E.01258
G1 X134.263 Y124.755 E.22449
G1 X134.263 Y125.272 E.01258
G1 X127.737 Y131.798 E.22449
G1 X127.737 Y132.316 E.0126
G1 X134.263 Y125.789 E.22451
G1 X134.263 Y126.306 E.01258
G1 X127.737 Y132.833 E.22451
G1 X127.737 Y133.35 E.01258
G1 X134.263 Y126.824 E.22449
G1 X134.263 Y127.341 E.01258
G1 X127.737 Y133.867 E.22449
G1 X127.737 Y134.384 E.01258
G1 X134.241 Y127.88 E.22373
G1 X134.241 Y128.397 E.01258
G1 X127.737 Y134.901 E.22373
G1 X127.737 Y135.418 E.01258
G1 X134.241 Y128.914 E.22373
G1 X134.241 Y129.431 E.01258
G1 X127.737 Y135.935 E.22373
G1 X127.86 Y136.33 E.01006
G1 X134.241 Y129.948 E.21952
G1 X134.241 Y130.465 E.01258
G1 X127.987 Y136.72 E.21515
G1 X128.07 Y137.153 E.01072
G1 X134.241 Y130.982 E.21228
G1 X134.241 Y131.499 E.01258
G1 X128.088 Y137.653 E.21168
G1 X128.088 Y137.653 F9000
G1 X127.864 Y138.554
;WIDTH:0.374336
G1 F1200
G1 X127.823 Y138.565 E.00096
G1 X127.804 Y138.494 E.00166
G1 X127.875 Y138.513 E.00166
;WIDTH:0.399999
G1 X127.993 Y138.265 E.00668
G1 X134.241 Y132.017 E.21493
G1 X134.241 Y132.534 E.01258
G1 X127.737 Y139.038 E.22373
G1 X127.705 Y139.587 E.01338
G1 X134.215 Y133.077 E.22394
G1 X134.141 Y133.668 E.01449
G1 X127.57 Y140.239 E.22604
G1 X127.462 Y140.017 E.00601
;WIDTH:0.374336
G1 X127.326 Y140.331 E.00774
G1 X127.326 Y140.331 F9000
G1 X128.232 Y140.095
;WIDTH:0.399999
G1 F1200
G1 X133.998 Y134.329 E.19835
G1 X133.935 Y134.837 E.01245
;WIDTH:0.374336
G1 X133.864 Y134.818 E.00166
G1 X133.883 Y134.889 E.00166
G1 X133.924 Y134.878 E.00096
;WIDTH:0.399999
G1 X133.737 Y135.107 E.00719
G1 X128.986 Y139.858 E.16343
G1 X128.76 Y140.049 E.0072
;WIDTH:0.374336
G1 X128.719 Y140.06 E.00096
G1 X128.7 Y139.989 E.00166
G1 X128.771 Y140.008 E.00166
G1 X128.771 Y140.008 F9000
G1 X129.705 Y139.611
G1 F1200
G1 X129.634 Y139.592 E.00166
G1 X129.653 Y139.663 E.00166
G1 X129.694 Y139.652 E.00096
;WIDTH:0.399999
G1 X133.35 Y136.01 E.12552
G1 X133.556 Y135.782 E.00747
;WIDTH:0.374336
G1 X133.515 Y135.793 E.00096
G1 X133.496 Y135.722 E.00166
G1 X133.567 Y135.741 E.00166
G1 X133.567 Y135.741 F9000
G1 X133.01 Y136.757
G1 F1200
G1 X132.455 Y137.39 E.01904
G1 X132.415 Y137.576 E.0043
G1 X131.743 Y138.271 E.02186
G1 X131.507 Y138.487 E.00724
G1 X131.334 Y138.523 E.004
G1 X131.169 Y138.676 E.00509
;WIDTH:0.399999
G1 X131.593 Y138.285 E.01403
G1 X132.229 Y137.649 E.02188
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X131.593 Y138.285 E-.42723
G1 X131.169 Y138.676 E-.27396
G1 X131.334 Y138.523 E-.10688
G1 X131.507 Y138.487 E-.08394
G1 X131.743 Y138.271 E-.15196
G1 X132.41 Y137.581 E-.45603
;WIPE_END
G1 X126.349 Y129.348 F9000
G1 X124.901 Y127.382
G1 X119.129 Y119.551
G1 X118.921 Y119.259
G1 E5 F2400
G1 F6000
G1 X118.592 Y119.481 E.00965
G1 X118.234 Y119.647 E.0096
G1 X117.742 Y119.785 E.01243
G1 X117.233 Y119.831 E.01243
G1 X113.767 Y119.831 E.08431
G1 X112.978 Y119.718 E.01939
G1 X112.44 Y119.499 E.01413
G1 X111.886 Y119.112 E.01644
G1 X111.447 Y118.621 E.01602
G1 X109.584 Y115.415 E.09019
G1 X109.373 Y114.959 E.01222
G1 X109.242 Y114.456 E.01264
G1 X109.207 Y113.937 E.01265
G1 X109.243 Y113.544 E.0096
G1 X109.373 Y113.041 E.01264
G1 X109.584 Y112.585 E.01222
G1 X111.447 Y109.379 E.09019
G1 X112.005 Y108.786 E.01981
G1 X112.494 Y108.473 E.01412
G1 X113.13 Y108.244 E.01644
G1 X113.768 Y108.169 E.01563
G1 X117.475 Y108.18 E.09017
G1 X117.774 Y108.223 E.00735
G1 X118.465 Y108.453 E.01771
G1 X119.001 Y108.79 E.0154
G1 X119.553 Y109.379 E.01964
G1 X121.416 Y112.585 E.09019
G1 X121.627 Y113.041 E.01222
G1 X121.757 Y113.544 E.01264
G1 X121.789 Y114.161 E.01503
G1 X121.712 Y114.677 E.01269
G1 X121.472 Y115.306 E.01638
G1 X119.553 Y118.621 E.09317
G1 X119.029 Y119.185 E.01873
G1 X118.97 Y119.225 E.00173
G1 X118.97 Y119.225 F9000
G1 X119.189 Y119.51
;TYPE:Perimeter
G1 F6000
G1 X118.795 Y119.786 E.0117
G1 X118.334 Y119.999 E.01235
G1 X117.792 Y120.147 E.01367
G1 X117.233 Y120.197 E.01365
G1 X113.767 Y120.197 E.08431
G1 X113.152 Y120.117 E.01509
G1 X112.84 Y120.056 E.00773
G1 X112.302 Y119.837 E.01413
G1 X111.877 Y119.554 E.01242
G1 X111.582 Y119.328 E.00904
G1 X111.131 Y118.805 E.0168
G1 X109.268 Y115.599 E.09019
G1 X109.041 Y115.112 E.01307
G1 X108.888 Y114.545 E.01429
G1 X108.842 Y113.96 E.01427
G1 X108.888 Y113.455 E.01233
G1 X109.041 Y112.888 E.01429
G1 X109.268 Y112.401 E.01307
G1 X111.131 Y109.195 E.09019
G1 X111.537 Y108.742 E.0148
G1 X111.808 Y108.478 E.0092
G1 X112.297 Y108.165 E.01412
G1 X112.794 Y107.975 E.01294
G1 X113.129 Y107.872 E.00852
G1 X113.706 Y107.806 E.01413
G1 X117.477 Y107.814 E.09173
G1 X117.89 Y107.876 E.01016
G1 X118.581 Y108.107 E.01772
G1 X119.212 Y108.492 E.01798
G1 X119.74 Y109.037 E.01846
G1 X119.869 Y109.195 E.00496
G1 X121.732 Y112.401 E.09019
G1 X121.959 Y112.888 E.01307
G1 X122.112 Y113.454 E.01426
G1 X122.155 Y114.144 E.01682
G1 X122.074 Y114.734 E.01449
G1 X121.813 Y115.439 E.01829
G1 X119.869 Y118.804 E.09453
G1 X119.296 Y119.436 E.02075
G1 X119.238 Y119.476 E.00171
G1 X119.238 Y119.476 F9000
G1 X119.442 Y119.772
G1 F6000
G1 X118.997 Y120.091 E.01332
G1 X118.433 Y120.351 E.01511
G1 X117.842 Y120.509 E.01488
G1 X117.233 Y120.563 E.01487
G1 X113.767 Y120.563 E.08431
G1 X113.101 Y120.479 E.01633
G1 X112.702 Y120.395 E.00992
G1 X112.164 Y120.176 E.01413
G1 X111.666 Y119.852 E.01445
G1 X111.309 Y119.571 E.01105
G1 X110.923 Y119.137 E.01413
G1 X110.815 Y118.988 E.00448
G1 X108.952 Y115.783 E.09017
G1 X108.708 Y115.265 E.01393
G1 X108.533 Y114.635 E.0159
G1 X108.477 Y113.983 E.01592
G1 X108.533 Y113.365 E.01509
G1 X108.708 Y112.735 E.0159
G1 X108.952 Y112.217 E.01393
G1 X110.815 Y109.011 E.09019
G1 X111.27 Y108.492 E.01679
G1 X111.611 Y108.17 E.01141
G1 X112.1 Y107.857 E.01412
G1 X112.672 Y107.63 E.01497
G1 X113.088 Y107.508 E.01054
G1 X113.665 Y107.443 E.01412
G1 X117.478 Y107.448 E.09275
G1 X118.006 Y107.529 E.01299
G1 X118.696 Y107.76 E.0177
G1 X119.423 Y108.193 E.02058
G1 X120.006 Y108.787 E.02024
G1 X120.185 Y109.011 E.00697
G1 X122.048 Y112.217 E.09019
G1 X122.292 Y112.735 E.01393
G1 X122.467 Y113.365 E.0159
G1 X122.52 Y114.127 E.01858
G1 X122.435 Y114.79 E.01626
G1 X122.154 Y115.572 E.02021
G1 X120.185 Y118.988 E.09591
G1 X119.562 Y119.686 E.02276
G1 X119.491 Y119.737 E.00213
G1 E-5 F3600
G1 X119.491 Y119.737 F9000
G1 X119.248 Y119.458
G1 X119.362 Y119.36
G1 X119.451 Y119.278
G1 X119.569 Y119.154
G1 X119.65 Y119.066
G1 X119.756 Y118.93
G1 X119.83 Y118.835
G1 X119.922 Y118.691
G1 X119.98 Y118.6
G1 X121.724 Y115.58
G1 X121.773 Y115.485
G1 X121.852 Y115.332
G1 X121.898 Y115.221
G1 X121.962 Y115.061
G1 X121.998 Y114.947
G1 X122.046 Y114.782
G1 X122.073 Y114.665
G1 X122.105 Y114.496
G1 X122.121 Y114.377
G1 X122.137 Y114.206
G1 X122.142 Y114.086
G1 X122.142 Y113.914
G1 X122.137 Y113.794
G1 X122.121 Y113.623
G1 X122.105 Y113.504
G1 X122.073 Y113.335
G1 X122.046 Y113.218
G1 X121.998 Y113.053
G1 X121.962 Y112.939
G1 X121.898 Y112.779
G1 X121.852 Y112.668
G1 X121.773 Y112.515
G1 X121.724 Y112.42
G1 X120.98 Y111.131
G1 X122.027 Y100.85
G1 X122.723 Y101.054
G1 E5 F2400
G1 F6000
G1 X122.494 Y101.704 E.01676
G1 X122.193 Y102.254 E.01525
G1 X120.502 Y105.171 E.08201
G1 X119.829 Y105.936 E.02478
G1 X119.357 Y106.301 E.01451
G1 X118.757 Y106.616 E.01648
G1 X118.13 Y106.817 E.01602
;WIDTH:0.440341
G1 X118.037 Y106.852 E.00268
;WIDTH:0.480682
G1 X117.944 Y106.888 E.00296
;WIDTH:0.521023
G1 X117.851 Y106.924 E.00323
;WIDTH:0.561365
G1 X117.758 Y106.959 E.00348
;WIDTH:0.601706
G1 X117.665 Y106.995 E.00376
G1 X117.836 Y107.059 E.00689
;WIDTH:0.561365
G1 X118.007 Y107.123 E.0064
;WIDTH:0.521023
G1 X118.178 Y107.187 E.00591
;WIDTH:0.480682
G1 X118.348 Y107.251 E.00539
;WIDTH:0.440341
G1 X118.519 Y107.315 E.00493
;WIDTH:0.399999
G1 X119.097 Y107.549 E.01517
G1 X119.586 Y107.862 E.01412
G1 X119.829 Y108.064 E.00769
G1 X120.327 Y108.595 E.01771
G1 X120.501 Y108.827 E.00705
G1 X122.365 Y112.033 E.09021
G1 X122.624 Y112.582 E.01477
G1 X122.821 Y113.275 E.01752
G1 X122.885 Y114.111 E.02039
G1 X122.796 Y114.847 E.01803
G1 X122.494 Y115.704 E.0221
G1 X122.409 Y115.882 E.0048
G1 X120.502 Y119.171 E.09248
G1 X119.829 Y119.936 E.02478
G1 X119.2 Y120.395 E.01894
G1 X118.721 Y120.633 E.01301
G1 X118.13 Y120.817 E.01506
;WIDTH:0.44034
G1 X118.037 Y120.852 E.00268
;WIDTH:0.480681
G1 X117.944 Y120.888 E.00296
;WIDTH:0.521022
G1 X117.851 Y120.924 E.00323
;WIDTH:0.561363
G1 X117.758 Y120.959 E.00348
;WIDTH:0.601704
G1 X117.665 Y120.995 E.00376
G1 X117.836 Y121.059 E.00689
;WIDTH:0.561363
G1 X118.007 Y121.123 E.0064
;WIDTH:0.521022
G1 X118.177 Y121.187 E.00588
;WIDTH:0.480681
G1 X118.348 Y121.251 E.00542
;WIDTH:0.44034
G1 X118.519 Y121.315 E.00493
;WIDTH:0.399999
G1 X119.002 Y121.494 E.01253
G1 X119.586 Y121.862 E.01679
G1 X119.829 Y122.064 E.00769
G1 X120.327 Y122.595 E.01771
G1 X120.501 Y122.827 E.00705
G1 X122.365 Y126.033 E.09021
G1 X122.624 Y126.582 E.01477
G1 X122.821 Y127.275 E.01752
G1 X122.885 Y128.111 E.02039
G1 X122.796 Y128.847 E.01803
G1 X122.494 Y129.704 E.0221
G1 X122.409 Y129.882 E.0048
G1 X120.502 Y133.171 E.09248
G1 X119.829 Y133.936 E.02478
G1 X119.357 Y134.301 E.01451
G1 X118.753 Y134.618 E.01659
G1 X118.066 Y134.835 E.01752
G1 X117.233 Y134.928 E.02039
G1 X113.767 Y134.928 E.08431
G1 X112.871 Y134.816 E.02196
G1 X112.564 Y134.734 E.00773
G1 X112.027 Y134.515 E.01411
G1 X111.252 Y134.007 E.02254
G1 X110.737 Y133.479 E.01794
G1 X110.499 Y133.172 E.00945
G1 X108.635 Y129.967 E.09018
G1 X108.376 Y129.418 E.01477
G1 X108.179 Y128.724 E.01755
G1 X108.112 Y128.007 E.01752
G1 X108.145 Y127.473 E.01301
G1 X108.298 Y126.804 E.01669
G1 X108.579 Y126.141 E.01752
G1 X110.499 Y122.828 E.09314
G1 X111.004 Y122.242 E.01882
G1 X111.414 Y121.862 E.0136
G1 X111.903 Y121.549 E.01412
G1 X112.551 Y121.285 E.01702
G1 X113.047 Y121.145 E.01254
;WIDTH:0.44229
G1 X113.225 Y121.104 E.00496
;WIDTH:0.484581
G1 X113.404 Y121.062 E.00551
;WIDTH:0.526872
G1 X113.582 Y121.021 E.00598
;WIDTH:0.553692
G1 X113.649 Y121 E.00243
G1 X113.5 Y120.96 E.00533
;WIDTH:0.515269
G1 X113.35 Y120.921 E.00496
;WIDTH:0.476846
G1 X113.201 Y120.881 E.00454
;WIDTH:0.438423
G1 X113.051 Y120.841 E.00417
;WIDTH:0.399999
G1 X112.564 Y120.734 E.01213
G1 X112.027 Y120.515 E.01411
G1 X111.454 Y120.15 E.01653
G1 X111.036 Y119.814 E.01305
G1 X110.65 Y119.38 E.01413
G1 X110.499 Y119.172 E.00625
G1 X108.635 Y115.967 E.09018
G1 X108.376 Y115.418 E.01477
G1 X108.179 Y114.724 E.01755
G1 X108.112 Y114.007 E.01752
G1 X108.145 Y113.473 E.01301
G1 X108.298 Y112.804 E.01669
G1 X108.579 Y112.141 E.01752
G1 X110.499 Y108.828 E.09314
G1 X111.004 Y108.242 E.01882
G1 X111.414 Y107.862 E.0136
G1 X111.903 Y107.549 E.01412
G1 X112.551 Y107.285 E.01702
G1 X113.047 Y107.145 E.01254
;WIDTH:0.44229
G1 X113.225 Y107.104 E.00496
;WIDTH:0.484581
G1 X113.404 Y107.062 E.00551
;WIDTH:0.526872
G1 X113.582 Y107.021 E.00598
;WIDTH:0.553692
G1 X113.649 Y107 E.00243
G1 X113.5 Y106.96 E.00533
;WIDTH:0.515269
G1 X113.35 Y106.921 E.00496
;WIDTH:0.476846
G1 X113.201 Y106.881 E.00454
;WIDTH:0.438423
G1 X113.051 Y106.841 E.00417
;WIDTH:0.399999
G1 X112.564 Y106.734 E.01213
G1 X112.027 Y106.515 E.01411
G1 X111.454 Y106.15 E.01653
G1 X111.036 Y105.814 E.01305
G1 X110.65 Y105.38 E.01413
G1 X110.499 Y105.172 E.00625
G1 X108.635 Y101.967 E.09018
G1 X108.376 Y101.418 E.01477
G1 X108.179 Y100.724 E.01755
G1 X108.112 Y100.007 E.01752
G1 X108.145 Y99.473 E.01301
G1 X108.294 Y98.821 E.01627
G1 X108.579 Y98.141 E.01793
G1 X110.499 Y94.828 E.09314
G1 X111.171 Y94.064 E.02475
G1 X111.414 Y93.862 E.00769
G1 X111.903 Y93.549 E.01412
G1 X112.767 Y93.209 E.02258
G1 X113.771 Y93.072 E.02465
G1 X117.479 Y93.083 E.09019
G1 X118.122 Y93.182 E.01582
G1 X118.812 Y93.413 E.0177
G1 X119.097 Y93.549 E.00768
G1 X119.586 Y93.862 E.01412
G1 X119.829 Y94.064 E.00769
G1 X120.327 Y94.595 E.01771
G1 X120.501 Y94.827 E.00705
G1 X122.365 Y98.033 E.09021
G1 X122.624 Y98.582 E.01477
G1 X122.821 Y99.275 E.01752
G1 X122.885 Y100.111 E.02039
G1 X122.796 Y100.847 E.01803
G1 X122.743 Y100.997 E.00387
G1 E-5 F3600
G1 X122.743 Y100.997 F9000
G1 X122.044 Y100.792
G1 X121.724 Y115.58
G1 X119.98 Y118.6
G1 X119.83 Y118.835
G1 X119.756 Y118.93
G1 X119.65 Y119.066
G1 E5 F2400
;WIDTH:0.601704
G1 F6000
G1 X117.233 Y121.005 E.01631
;WIDTH:0.553774
G1 X113.649 Y121 E.12384
G1 E-5 F3600
G1 X113.649 Y121 F9000
G1 X111.768 Y122.528
G1 X111.638 Y122.64
G1 X111.549 Y122.722
G1 X111.431 Y122.846
G1 X111.35 Y122.934
G1 X111.244 Y123.069
G1 X111.17 Y123.165
G1 X111.078 Y123.309
G1 X111.02 Y123.4
G1 X109.276 Y126.42
G1 X109.227 Y126.515
G1 X109.148 Y126.668
G1 X109.102 Y126.779
G1 X109.038 Y126.939
G1 X109.002 Y127.053
G1 X108.954 Y127.218
G1 X108.927 Y127.335
G1 X108.895 Y127.504
G1 X108.879 Y127.623
G1 X108.863 Y127.794
G1 X108.858 Y127.914
G1 X108.858 Y128.086
G1 X108.863 Y128.206
G1 X108.879 Y128.377
G1 X108.895 Y128.496
G1 X108.927 Y128.665
G1 X108.954 Y128.782
G1 X109.002 Y128.947
G1 X109.038 Y129.061
G1 X109.102 Y129.221
G1 X109.148 Y129.332
G1 X109.227 Y129.485
G1 X109.276 Y129.58
G1 X112.161 Y134.964
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X111.889 Y134.853 E.00715
G1 X111.558 Y134.672 E.00918
G1 X111.04 Y134.306 E.01543
G1 X110.464 Y133.722 E.01995
G1 X110.183 Y133.356 E.01122
G1 X108.319 Y130.151 E.09018
G1 X108.044 Y129.571 E.01561
;WIDTH:0.435993
G1 X107.917 Y129.197 E.01055
;WIDTH:0.471986
G1 X107.789 Y128.822 E.01154
;WIDTH:0.49988
G1 X107.728 Y128.518 E.0096
G1 X107.702 Y127.926 E.01835
;WIDTH:0.527739
G1 X107.762 Y127.17 E.02489
G1 X107.856 Y126.923 E.00867
;WIDTH:0.485159
G1 X107.95 Y126.676 E.00793
;WIDTH:0.442579
G1 X108.044 Y126.429 E.00718
;WIDTH:0.399999
G1 X108.319 Y125.849 E.01561
G1 X110.183 Y122.644 E.09018
G1 X110.737 Y121.991 E.02083
G1 X111.078 Y121.653 E.01168
G1 X111.542 Y121.346 E.01353
G1 X112.047 Y121.075 E.01394
G1 X112.254 Y121.002 E.00534
G1 X111.694 Y120.759 E.01485
G1 X111.243 Y120.449 E.01331
G1 X110.763 Y120.057 E.01507
G1 X110.376 Y119.623 E.01414
G1 X110.183 Y119.356 E.00801
G1 X108.319 Y116.151 E.09018
G1 X108.044 Y115.571 E.01561
;WIDTH:0.435993
G1 X107.917 Y115.197 E.01055
;WIDTH:0.471986
G1 X107.789 Y114.822 E.01154
;WIDTH:0.49988
G1 X107.728 Y114.518 E.0096
G1 X107.702 Y113.926 E.01835
;WIDTH:0.527738
G1 X107.762 Y113.17 E.02489
G1 X107.856 Y112.923 E.00867
;WIDTH:0.485159
G1 X107.95 Y112.676 E.00793
;WIDTH:0.442579
G1 X108.044 Y112.429 E.00718
;WIDTH:0.399999
G1 X108.319 Y111.849 E.01561
G1 X110.183 Y108.644 E.09018
G1 X110.737 Y107.991 E.02083
G1 X111.078 Y107.653 E.01168
G1 X111.542 Y107.346 E.01353
G1 X112.047 Y107.075 E.01394
G1 X112.254 Y107.002 E.00534
G1 X111.694 Y106.759 E.01485
G1 X111.243 Y106.449 E.01331
G1 X110.763 Y106.057 E.01507
G1 X110.376 Y105.623 E.01414
G1 X110.183 Y105.356 E.00801
G1 X108.319 Y102.151 E.09018
G1 X108.044 Y101.571 E.01561
G1 X107.824 Y100.814 E.01918
G1 X107.747 Y100.03 E.01916
G1 X107.781 Y99.44 E.01437
G1 X107.939 Y98.732 E.01765
G1 X108.319 Y97.849 E.02338
G1 X110.183 Y94.644 E.09018
G1 X110.433 Y94.316 E.01003
G1 X110.904 Y93.814 E.01674
G1 X111.217 Y93.554 E.0099
G1 X111.706 Y93.241 E.01412
G1 X112.047 Y93.075 E.00923
G1 X112.645 Y92.864 E.01542
G1 X113.006 Y92.782 E.009
G1 X113.773 Y92.706 E.01875
G1 X117.48 Y92.717 E.09017
G1 X117.943 Y92.766 E.01132
G1 X118.928 Y93.066 E.02505
G1 X119.294 Y93.241 E.00987
G1 X119.783 Y93.554 E.01412
G1 X120.095 Y93.813 E.00986
G1 X120.594 Y94.344 E.01772
G1 X120.817 Y94.644 E.00909
G1 X122.681 Y97.849 E.09018
G1 X122.956 Y98.429 E.01561
G1 X123.176 Y99.186 E.01918
G1 X123.25 Y100.094 E.02216
G1 X123.157 Y100.903 E.01981
G1 X123.065 Y101.246 E.00864
G1 X122.835 Y101.837 E.01543
G1 X122.509 Y102.438 E.01663
G1 X120.818 Y105.354 E.08199
G1 X120.539 Y105.714 E.01108
G1 X120.095 Y106.187 E.01578
G1 X119.568 Y106.6 E.01629
G1 X118.92 Y106.943 E.01783
G1 X118.753 Y107.008 E.00436
G1 X119.294 Y107.241 E.01433
G1 X119.783 Y107.554 E.01412
G1 X120.096 Y107.814 E.0099
G1 X120.594 Y108.344 E.01769
G1 X120.817 Y108.644 E.00909
G1 X122.681 Y111.849 E.09018
G1 X122.956 Y112.429 E.01561
;WIDTH:0.442587
G1 X123.05 Y112.676 E.00718
;WIDTH:0.485174
G1 X123.144 Y112.923 E.00793
;WIDTH:0.527761
G1 X123.238 Y113.17 E.00867
G1 X123.293 Y114.092 E.03032
;WIDTH:0.534046
G1 X123.224 Y114.914 E.02742
G1 X123.094 Y115.221 E.01108
;WIDTH:0.489364
G1 X122.965 Y115.529 E.01011
;WIDTH:0.444682
G1 X122.835 Y115.837 E.00913
;WIDTH:0.399999
G1 X122.725 Y116.065 E.00616
G1 X120.818 Y119.354 E.09248
G1 X120.539 Y119.714 E.01108
G1 X120.095 Y120.187 E.01578
G1 X119.773 Y120.453 E.01016
G1 X119.306 Y120.759 E.01358
G1 X118.756 Y121.009 E.0147
G1 X119.294 Y121.241 E.01425
G1 X119.783 Y121.554 E.01412
G1 X120.096 Y121.814 E.0099
G1 X120.594 Y122.344 E.01769
G1 X120.817 Y122.644 E.00909
G1 X122.681 Y125.849 E.09018
G1 X122.956 Y126.429 E.01561
;WIDTH:0.442587
G1 X123.05 Y126.676 E.00718
;WIDTH:0.485174
G1 X123.144 Y126.923 E.00793
;WIDTH:0.527761
G1 X123.238 Y127.17 E.00867
G1 X123.293 Y128.092 E.03032
;WIDTH:0.534046
G1 X123.224 Y128.914 E.02742
G1 X123.094 Y129.221 E.01108
;WIDTH:0.489364
G1 X122.965 Y129.529 E.01011
;WIDTH:0.444682
G1 X122.835 Y129.837 E.00913
;WIDTH:0.399999
G1 X122.725 Y130.065 E.00616
G1 X120.818 Y133.355 E.0925
G1 X120.567 Y133.684 E.01007
G1 X120.096 Y134.186 E.01674
G1 X119.568 Y134.6 E.01632
G1 X118.916 Y134.945 E.01794
G1 X118.165 Y135.187 E.01919
G1 X117.233 Y135.294 E.02282
G1 X113.767 Y135.294 E.08431
G1 X112.82 Y135.178 E.02321
G1 X112.427 Y135.072 E.0099
G1 X112.217 Y134.987 E.00551
G1 E-5 F3600
G1 X112.217 Y134.987 F9000
G1 X109.276 Y129.58
G1 X109.276 Y126.42
G1 X111.02 Y123.4
G1 X111.17 Y123.165
G1 X111.35 Y122.934
G1 X111.638 Y122.64
G1 X111.863 Y122.455
G1 X112.003 Y122.355
G1 X115.099 Y120.18
G1 X117.244 Y120.18
G1 X117.351 Y120.175
G1 X117.523 Y120.167
G1 X117.642 Y120.151
G1 X117.812 Y120.127
G1 X117.929 Y120.101
G1 X118.096 Y120.06
G1 X118.211 Y120.024
G1 X118.373 Y119.968
G1 X118.484 Y119.922
G1 X118.64 Y119.851
G1 X118.747 Y119.795
G1 X118.895 Y119.709
G1 X118.997 Y119.645
G1 X119.137 Y119.545
G1 X119.232 Y119.472
G1 X119.362 Y119.36
G1 X119.65 Y119.066
G1 X119.756 Y118.93
G1 X119.83 Y118.835
G1 X119.98 Y118.6
G1 X121.724 Y115.58
G1 X121.724 Y112.42
G1 X119.98 Y109.4
G1 X119.922 Y109.309
G1 X119.83 Y109.165
G1 X119.756 Y109.07
G1 X119.65 Y108.934
G1 X119.569 Y108.846
G1 X119.451 Y108.722
G1 E5 F2400
;WIDTH:0.601706
G1 F6000
G1 X117.233 Y107.005 E.01631
;WIDTH:0.553774
G1 X113.649 Y107 E.12384
G1 X113.649 Y107 F9000
G1 X113.703 Y105.822
;WIDTH:0.399999
G1 F6000
G1 X112.978 Y105.718 E.01782
G1 X112.418 Y105.488 E.01473
G1 X111.886 Y105.112 E.01585
G1 X111.447 Y104.621 E.01602
G1 X109.584 Y101.415 E.09019
G1 X109.373 Y100.959 E.01222
G1 X109.242 Y100.456 E.01264
G1 X109.207 Y99.937 E.01265
G1 X109.243 Y99.544 E.0096
G1 X109.373 Y99.041 E.01264
G1 X109.584 Y98.585 E.01222
G1 X111.447 Y95.379 E.09019
G1 X111.97 Y94.815 E.01871
G1 X112.494 Y94.473 E.01522
G1 X113.13 Y94.244 E.01644
G1 X113.768 Y94.169 E.01563
G1 X117.475 Y94.18 E.09017
G1 X117.774 Y94.223 E.00735
G1 X118.465 Y94.453 E.01771
G1 X118.994 Y94.786 E.0152
G1 X119.553 Y95.379 E.01982
G1 X121.416 Y98.585 E.09019
G1 X121.627 Y99.041 E.01222
G1 X121.757 Y99.544 E.01264
G1 X121.789 Y100.161 E.01503
G1 X121.712 Y100.677 E.01269
G1 X121.472 Y101.306 E.01638
G1 X119.553 Y104.621 E.09317
G1 X119.029 Y105.185 E.01873
G1 X118.671 Y105.434 E.01061
G1 X118.234 Y105.647 E.01183
G1 X117.742 Y105.785 E.01243
G1 X117.233 Y105.831 E.01243
G1 X113.767 Y105.831 E.08431
G1 X113.763 Y105.831 E.0001
G1 X113.763 Y105.831 F9000
G1 X113.742 Y106.194
;TYPE:Perimeter
G1 F6000
G1 X113.152 Y106.117 E.01447
G1 X112.84 Y106.056 E.00773
G1 X112.237 Y105.806 E.01588
G1 X111.675 Y105.41 E.01672
G1 X111.131 Y104.805 E.01979
G1 X109.268 Y101.599 E.09019
G1 X109.041 Y101.112 E.01307
G1 X108.888 Y100.545 E.01429
G1 X108.842 Y99.96 E.01427
G1 X108.888 Y99.455 E.01233
G1 X109.041 Y98.888 E.01429
G1 X109.268 Y98.401 E.01307
G1 X111.131 Y95.195 E.09019
G1 X111.704 Y94.565 E.02071
G1 X112.297 Y94.165 E.0174
G1 X113.009 Y93.899 E.01849
G1 X113.769 Y93.803 E.01863
G1 X117.477 Y93.814 E.09019
G1 X117.89 Y93.876 E.01016
G1 X118.581 Y94.107 E.01772
G1 X119.191 Y94.478 E.01737
G1 X119.768 Y95.067 E.02006
G1 X119.869 Y95.195 E.00397
G1 X121.732 Y98.401 E.09019
G1 X121.959 Y98.888 E.01307
G1 X122.112 Y99.454 E.01426
G1 X122.155 Y100.144 E.01682
G1 X122.074 Y100.734 E.01449
G1 X121.813 Y101.439 E.01829
G1 X119.869 Y104.804 E.09453
G1 X119.296 Y105.436 E.02075
G1 X118.863 Y105.746 E.01295
G1 X118.334 Y105.999 E.01426
G1 X117.792 Y106.147 E.01367
G1 X117.233 Y106.197 E.01365
G1 X113.802 Y106.197 E.08346
G1 X113.802 Y106.197 F9000
G1 X113.802 Y106.563
G1 F6000
G1 X113.767 Y106.563 E.00085
G1 X113.101 Y106.479 E.01633
G1 X112.702 Y106.395 E.00992
G1 X112.056 Y106.123 E.01705
G1 X111.463 Y105.709 E.01759
G1 X111.039 Y105.267 E.0149
G1 X110.815 Y104.988 E.0087
G1 X108.952 Y101.783 E.09017
G1 X108.708 Y101.265 E.01393
G1 X108.533 Y100.635 E.0159
G1 X108.477 Y99.983 E.01592
G1 X108.512 Y99.484 E.01217
G1 X108.648 Y98.911 E.01432
G1 X108.952 Y98.217 E.01843
G1 X110.815 Y95.011 E.09019
G1 X111.437 Y94.314 E.02272
G1 X112.1 Y93.857 E.01959
G1 X112.888 Y93.554 E.02054
G1 X113.77 Y93.437 E.02164
G1 X117.478 Y93.448 E.09019
G1 X118.006 Y93.529 E.01299
G1 X118.696 Y93.76 E.0177
G1 X119.389 Y94.17 E.01959
G1 X120.034 Y94.817 E.02222
G1 X120.185 Y95.011 E.00598
G1 X122.048 Y98.217 E.09019
G1 X122.292 Y98.735 E.01393
G1 X122.467 Y99.365 E.0159
G1 X122.52 Y100.127 E.01858
G1 X122.435 Y100.79 E.01626
G1 X122.154 Y101.572 E.02021
G1 X120.185 Y104.988 E.09591
G1 X119.563 Y105.686 E.02274
G1 X119.147 Y106.002 E.01271
G1 X118.595 Y106.288 E.01512
G1 X118.031 Y106.465 E.01438
G1 X117.233 Y106.563 E.01956
G1 X113.862 Y106.563 E.082
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.802 Y106.563 E-.0285
G1 X113.767 Y106.563 E-.01663
G1 X113.101 Y106.479 E-.31886
G1 X112.702 Y106.395 E-.19368
G1 X112.056 Y106.123 E-.33294
G1 X111.463 Y105.709 E-.34353
G1 X111.075 Y105.306 E-.26586
;WIPE_END
G1 X111.35 Y105.066 F9000
G1 X108.954 Y113.218
G1 X108.927 Y113.335
G1 X108.895 Y113.504
G1 X108.879 Y113.623
G1 X108.863 Y113.794
G1 X108.858 Y113.914
G1 X108.858 Y114.086
G1 X108.863 Y114.206
G1 X108.879 Y114.377
G1 X108.895 Y114.496
G1 X108.927 Y114.665
G1 X108.954 Y114.782
G1 X109.002 Y114.947
G1 X109.038 Y115.061
G1 X109.102 Y115.221
G1 X109.148 Y115.332
G1 X109.227 Y115.485
G1 X109.276 Y115.58
G1 X111.02 Y118.6
G1 X111.078 Y118.691
G1 X111.17 Y118.835
G1 X111.244 Y118.93
G1 X111.35 Y119.066
G1 X111.431 Y119.154
G1 X111.549 Y119.278
G1 X111.638 Y119.36
G1 X111.768 Y119.472
G1 X111.863 Y119.545
G1 X112.003 Y119.645
G1 X112.105 Y119.709
G1 X112.253 Y119.795
G1 X112.36 Y119.851
G1 X112.516 Y119.922
G1 X112.627 Y119.968
G1 X112.789 Y120.024
G1 X112.904 Y120.06
G1 X113.071 Y120.101
G1 X113.188 Y120.127
G1 X113.358 Y120.151
G1 X113.477 Y120.167
G1 X113.531 Y120.17
G1 X113.862 Y121.82
G1 X113.862 Y122.169
G1 E5 F2400
G1 F6000
G1 X117.475 Y122.18 E.08788
G1 X117.774 Y122.223 E.00735
G1 X118.465 Y122.453 E.01771
G1 X118.994 Y122.786 E.0152
G1 X119.553 Y123.379 E.01982
G1 X121.416 Y126.585 E.09019
G1 X121.627 Y127.041 E.01222
G1 X121.757 Y127.544 E.01264
G1 X121.789 Y128.161 E.01503
G1 X121.712 Y128.677 E.01269
G1 X121.472 Y129.306 E.01638
G1 X119.553 Y132.621 E.09317
G1 X119.029 Y133.185 E.01873
G1 X118.701 Y133.419 E.0098
G1 X118.234 Y133.647 E.01264
G1 X117.748 Y133.784 E.01228
G1 X117.233 Y133.831 E.01258
G1 X113.767 Y133.831 E.08431
G1 X113.022 Y133.729 E.01829
G1 X112.44 Y133.499 E.01522
G1 X111.886 Y133.112 E.01644
G1 X111.447 Y132.621 E.01602
G1 X109.584 Y129.415 E.09019
G1 X109.373 Y128.959 E.01222
G1 X109.242 Y128.456 E.01264
G1 X109.207 Y127.937 E.01265
G1 X109.243 Y127.544 E.0096
G1 X109.373 Y127.041 E.01264
G1 X109.584 Y126.585 E.01222
G1 X111.447 Y123.379 E.09019
G1 X112.005 Y122.786 E.01981
G1 X112.494 Y122.473 E.01412
G1 X113.13 Y122.244 E.01644
G1 X113.768 Y122.169 E.01563
G1 X113.802 Y122.169 E.00083
G1 X113.802 Y122.169 F9000
G1 X113.802 Y121.807
;TYPE:Perimeter
G1 F6000
G1 X117.477 Y121.814 E.08939
G1 X117.89 Y121.876 E.01016
G1 X118.581 Y122.107 E.01772
G1 X119.191 Y122.478 E.01737
G1 X119.74 Y123.037 E.01906
G1 X119.869 Y123.195 E.00496
G1 X121.732 Y126.401 E.09019
G1 X121.959 Y126.888 E.01307
G1 X122.112 Y127.454 E.01426
G1 X122.155 Y128.144 E.01682
G1 X122.074 Y128.734 E.01449
G1 X121.813 Y129.439 E.01829
G1 X119.869 Y132.804 E.09453
G1 X119.296 Y133.436 E.02075
G1 X118.863 Y133.746 E.01295
G1 X118.334 Y133.999 E.01426
G1 X117.811 Y134.144 E.0132
G1 X117.233 Y134.197 E.01412
G1 X113.767 Y134.197 E.08431
G1 X112.971 Y134.092 E.01953
G1 X112.302 Y133.837 E.01741
G1 X111.675 Y133.41 E.01845
G1 X111.131 Y132.805 E.01979
G1 X109.268 Y129.599 E.09019
G1 X109.041 Y129.112 E.01307
G1 X108.888 Y128.545 E.01429
G1 X108.842 Y127.96 E.01427
G1 X108.888 Y127.455 E.01233
G1 X109.041 Y126.888 E.01429
G1 X109.268 Y126.401 E.01307
G1 X111.131 Y123.195 E.09019
G1 X111.537 Y122.742 E.0148
G1 X111.808 Y122.478 E.0092
G1 X112.297 Y122.165 E.01412
G1 X112.794 Y121.975 E.01294
G1 X113.129 Y121.872 E.00852
G1 X113.706 Y121.806 E.01413
G1 X113.742 Y121.807 E.00088
G1 X113.742 Y121.807 F9000
G1 X113.725 Y121.443
G1 F6000
G1 X117.478 Y121.448 E.09129
G1 X118.006 Y121.529 E.01299
G1 X118.696 Y121.76 E.0177
G1 X119.389 Y122.17 E.01959
G1 X120.006 Y122.787 E.02122
G1 X120.185 Y123.011 E.00697
G1 X122.048 Y126.217 E.09019
G1 X122.292 Y126.735 E.01393
G1 X122.467 Y127.365 E.0159
G1 X122.52 Y128.127 E.01858
G1 X122.435 Y128.79 E.01626
G1 X122.154 Y129.572 E.02021
G1 X120.185 Y132.988 E.09591
G1 X119.563 Y133.686 E.02274
G1 X119.147 Y134.002 E.01271
G1 X118.591 Y134.29 E.01523
G1 X117.966 Y134.483 E.01591
G1 X117.233 Y134.563 E.01794
G1 X113.767 Y134.563 E.08431
G1 X112.921 Y134.454 E.02075
G1 X112.164 Y134.176 E.01962
G1 X111.463 Y133.709 E.02049
G1 X111.01 Y133.236 E.01593
G1 X110.815 Y132.988 E.00767
G1 X108.952 Y129.783 E.09017
G1 X108.708 Y129.265 E.01393
G1 X108.533 Y128.635 E.0159
G1 X108.477 Y127.983 E.01592
G1 X108.533 Y127.365 E.01509
G1 X108.708 Y126.735 E.0159
G1 X108.952 Y126.217 E.01393
G1 X110.815 Y123.011 E.09019
G1 X111.27 Y122.492 E.01679
G1 X111.611 Y122.17 E.01141
G1 X112.1 Y121.857 E.01412
G1 X112.672 Y121.63 E.01497
G1 X113.088 Y121.508 E.01054
G1 X113.665 Y121.443 E.01412
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.725 Y121.443 E-.0285
G1 X116.823 Y121.448 E-1.4715
;WIPE_END
G1 X116.823 Y121.82 F9000
G1 X113.756 Y121.82
G1 X113.649 Y121.825
G1 X113.477 Y121.833
G1 X113.358 Y121.849
G1 X113.188 Y121.873
G1 X113.071 Y121.899
G1 X112.904 Y121.94
G1 X112.789 Y121.976
G1 X112.627 Y122.032
G1 X112.516 Y122.078
G1 X112.36 Y122.149
G1 X112.253 Y122.205
G1 X112.105 Y122.291
G1 X111.638 Y122.64
G1 X111.35 Y122.934
G1 X111.17 Y123.165
G1 X111.02 Y123.4
G1 X109.276 Y126.42
G1 X109.276 Y129.58
G1 X109.959 Y130.762
G1 X106.099 Y136.512
G1 X105.721 Y136.512
G1 E5 F2400
G1 F6000
G1 X105.75 Y136.459 E.00147
G1 X105.75 Y103.607 E.79909
G1 X105.74 Y103.547 E.00148
G1 X105.616 Y103.459 E.0037
G1 X105.616 Y98.791 E.11354
G1 X105.738 Y98.707 E.0036
G1 X105.75 Y98.642 E.00161
G1 X105.75 Y91.541 E.17272
G1 X105.717 Y91.436 E.00268
G1 X105.48 Y91.101 E.00998
G1 X105.294 Y90.715 E.01042
G1 X105.272 Y90.385 E.00804
G1 X105.339 Y90.152 E.0059
G1 X105.61 Y89.716 E.01249
G1 X125.39 Y89.716 E.48113
G1 X125.658 Y90.148 E.01237
G1 X125.736 Y90.507 E.00894
G1 X125.666 Y90.791 E.00711
G1 X125.25 Y91.541 E.02086
G1 X125.255 Y98.684 E.17375
G1 X125.384 Y98.791 E.00408
G1 X125.384 Y103.459 E.11354
G1 X125.26 Y103.547 E.0037
G1 X125.25 Y103.607 E.00148
G1 X125.25 Y136.459 E.79909
G1 X125.283 Y136.564 E.00268
G1 X125.52 Y136.899 E.00998
G1 X125.651 Y137.156 E.00702
G1 X125.715 Y137.423 E.00668
G1 X125.728 Y137.615 E.00468
G1 X125.661 Y137.848 E.0059
G1 X125.39 Y138.284 E.01249
G1 X105.61 Y138.284 E.48113
G1 X105.342 Y137.852 E.01237
G1 X105.264 Y137.493 E.00894
G1 X105.334 Y137.209 E.00711
G1 X105.692 Y136.564 E.01794
G1 X105.692 Y136.564 F9000
G1 X106.06 Y136.625
;TYPE:Perimeter
G1 F6000
G1 X106.116 Y136.459 E.00426
G1 X106.116 Y103.607 E.79909
G1 X106.085 Y103.427 E.00444
G1 X105.982 Y103.354 E.00307
G1 X105.982 Y98.905 E.10822
G1 X106.079 Y98.839 E.00285
G1 X106.116 Y98.642 E.00488
G1 X106.116 Y91.541 E.17272
G1 X106.016 Y91.225 E.00806
G1 X105.685 Y90.699 E.01512
G1 X105.641 Y90.425 E.00675
G1 X105.813 Y90.082 E.00933
G1 X125.187 Y90.082 E.47125
G1 X125.284 Y90.239 E.00449
G1 X125.365 Y90.522 E.00716
G1 X125.172 Y90.96 E.01164
G1 X124.996 Y91.21 E.00744
G1 X124.884 Y91.541 E.0085
G1 X124.884 Y98.247 E.16312
G1 X124.914 Y98.818 E.01391
G1 X125.018 Y98.905 E.0033
G1 X125.018 Y103.354 E.10822
G1 X124.915 Y103.427 E.00307
G1 X124.884 Y103.607 E.00444
G1 X124.884 Y136.459 E.79909
G1 X124.984 Y136.775 E.00806
G1 X125.251 Y137.154 E.01128
G1 X125.35 Y137.447 E.00752
G1 X125.359 Y137.575 E.00312
G1 X125.187 Y137.918 E.00933
G1 X105.814 Y137.918 E.47123
G1 X105.716 Y137.761 E.0045
G1 X105.635 Y137.478 E.00716
G1 X105.828 Y137.04 E.01164
G1 X106.004 Y136.79 E.00744
G1 X106.041 Y136.681 E.0028
G1 X106.041 Y136.681 F9000
G1 X106.389 Y136.735
G1 F6000
G1 X106.481 Y136.459 E.00708
G1 X106.481 Y103.607 E.79909
G1 X106.43 Y103.306 E.00743
G1 X106.348 Y103.248 E.00244
G1 X106.348 Y99.02 E.10284
G1 X106.42 Y98.97 E.00213
G1 X106.481 Y98.642 E.00812
G1 X106.481 Y91.541 E.17272
G1 X106.314 Y91.015 E.01342
G1 X106.02 Y90.554 E.0133
G1 X106.017 Y90.448 E.00258
G1 X124.975 Y90.448 E.46113
G1 X124.98 Y90.528 E.00195
G1 X124.704 Y90.989 E.01307
G1 X124.519 Y91.541 E.01416
G1 X124.519 Y98.624 E.17229
G1 X124.568 Y98.936 E.00768
G1 X124.652 Y99.02 E.00289
G1 X124.652 Y103.248 E.10284
G1 X124.57 Y103.307 E.00246
G1 X124.519 Y103.607 E.0074
G1 X124.519 Y136.459 E.79909
G1 X124.686 Y136.985 E.01342
G1 X124.922 Y137.321 E.00999
G1 X124.986 Y137.471 E.00397
G1 X124.983 Y137.552 E.00197
G1 X106.025 Y137.552 E.46113
G1 X106.02 Y137.472 E.00195
G1 X106.296 Y137.011 E.01307
G1 X106.369 Y136.792 E.00562
G1 X106.369 Y136.792 F9000
G1 X106.717 Y136.845
G1 F6000
G1 X106.847 Y136.459 E.00991
G1 X106.847 Y103.607 E.79909
G1 X106.776 Y103.186 E.01039
G1 X106.713 Y103.142 E.00187
G1 X106.713 Y99.134 E.09749
G1 X106.761 Y99.101 E.00142
G1 X106.847 Y98.642 E.01136
G1 X106.847 Y91.541 E.17272
G1 X106.616 Y90.813 E.01858
G1 X124.398 Y90.813 E.43253
G1 X124.153 Y91.541 E.01868
G1 X124.153 Y98.624 E.17229
G1 X124.221 Y99.054 E.01059
G1 X124.287 Y99.134 E.00252
G1 X124.287 Y103.142 E.09749
G1 X124.224 Y103.186 E.00187
G1 X124.153 Y103.607 E.01039
G1 X124.153 Y136.459 E.79909
G1 X124.384 Y137.187 E.01858
G1 X106.602 Y137.187 E.43253
G1 X106.698 Y136.902 E.00732
G1 X106.698 Y136.902 F9000
G1 X107.091 Y136.821
G1 F6000
G1 X107.213 Y136.459 E.00929
G1 X107.213 Y129.376 E.17229
;WIDTH:0.44994
G1 X107.238 Y128.954 E.01169
;WIDTH:0.49988
G1 X107.263 Y128.532 E.01309
G1 X107.256 Y127.752 E.02416
;WIDTH:0.527739
G1 X107.277 Y127.11 E.02108
G1 X107.255 Y126.948 E.00537
;WIDTH:0.485159
G1 X107.234 Y126.786 E.0049
;WIDTH:0.442579
G1 X107.213 Y126.624 E.00444
;WIDTH:0.399999
G1 X107.213 Y115.376 E.2736
;WIDTH:0.44994
G1 X107.238 Y114.954 E.01169
;WIDTH:0.49988
G1 X107.263 Y114.532 E.01309
G1 X107.256 Y113.752 E.02416
;WIDTH:0.527738
G1 X107.277 Y113.11 E.02108
G1 X107.255 Y112.948 E.00537
;WIDTH:0.485159
G1 X107.234 Y112.786 E.0049
;WIDTH:0.442579
G1 X107.213 Y112.624 E.00444
;WIDTH:0.399999
G1 X107.213 Y103.607 E.21933
G1 X107.121 Y103.066 E.01335
G1 X107.079 Y103.036 E.00126
G1 X107.079 Y99.36 E.08942
G1 X107.213 Y98.642 E.01777
G1 X107.213 Y91.541 E.17272
G1 X107.098 Y91.179 E.00924
G1 X123.909 Y91.179 E.40891
G1 X123.787 Y91.541 E.00929
G1 X123.787 Y98.247 E.16312
G1 X123.833 Y99.024 E.01893
G1 X123.921 Y99.249 E.00588
G1 X123.921 Y103.036 E.09211
G1 X123.879 Y103.066 E.00126
G1 X123.787 Y103.607 E.01335
G1 X123.787 Y112.624 E.21933
;WIDTH:0.442587
G1 X123.766 Y112.786 E.00444
;WIDTH:0.485174
G1 X123.745 Y112.948 E.0049
;WIDTH:0.527761
G1 X123.723 Y113.11 E.00537
G1 X123.738 Y113.501 E.01284
;WIDTH:0.499021
G1 X123.745 Y114.169 E.02065
;WIDTH:0.534046
G1 X123.72 Y114.952 E.02604
G1 X123.742 Y115.095 E.00481
;WIDTH:0.489749
G1 X123.765 Y115.239 E.00442
;WIDTH:0.445451
G1 X123.787 Y115.382 E.00396
;WIDTH:0.401153
G1 X123.787 Y116.016 E.01547
;WIDTH:0.399999
G1 X123.787 Y126.624 E.25803
;WIDTH:0.442587
G1 X123.766 Y126.786 E.00444
;WIDTH:0.485174
G1 X123.745 Y126.948 E.0049
;WIDTH:0.527761
G1 X123.723 Y127.11 E.00537
G1 X123.738 Y127.501 E.01284
;WIDTH:0.499021
G1 X123.745 Y128.169 E.02065
;WIDTH:0.534046
G1 X123.72 Y128.952 E.02604
G1 X123.742 Y129.095 E.00481
;WIDTH:0.489749
G1 X123.765 Y129.239 E.00442
;WIDTH:0.445451
G1 X123.787 Y129.382 E.00396
;WIDTH:0.401153
G1 X123.787 Y130.016 E.01547
;WIDTH:0.399999
G1 X123.787 Y136.459 E.15672
G1 X123.902 Y136.821 E.00924
G1 X107.151 Y136.821 E.40745
G1 E-5 F3600
G1 X107.151 Y136.821 F9000
G1 X107.564 Y129.094
G1 E5 F2400
;TYPE:Solid infill
G1 F1200
G1 X107.797 Y129.689 E.01554
G1 X108.084 Y130.292 E.01624
G1 X109.943 Y133.49 E.08998
G1 X110.55 Y134.23 E.02328
G1 X110.886 Y134.532 E.01099
G1 X111.395 Y134.893 E.01518
G1 X111.79 Y135.109 E.01095
G1 X112.318 Y135.324 E.01387
G1 X112.788 Y135.451 E.01184
G1 X113.771 Y135.568 E.02408
G1 X117.244 Y135.568 E.08448
G1 X116.99 Y135.847 E.00918
G1 X116.937 Y135.999 E.00392
G1 X117.072 Y136.189 E.00567
G1 X117.105 Y136.547 E.00874
G1 X107.465 Y136.547 E.23448
G1 X107.487 Y136.444 E.00256
G1 X107.487 Y129.735 E.16319
G1 X107.519 Y129.245 E.01194
G1 X107.519 Y129.245 F9000
G1 X107.853 Y130.621
G1 F1200
G1 X109.627 Y133.674 E.08589
G1 X110.268 Y134.463 E.02473
G1 X110.675 Y134.831 E.01335
G1 X111.184 Y135.191 E.01516
G1 X111.652 Y135.448 E.01299
G1 X112.245 Y135.685 E.01553
;WIDTH:0.402305
G1 X112.738 Y135.814 E.01247
G1 X113.365 Y135.879 E.01543
;WIDTH:0.407063
G1 X113.425 Y135.909 E.00166
;WIDTH:0.455433
G1 X113.485 Y135.938 E.00187
;WIDTH:0.503803
G1 X113.544 Y135.968 E.00207
;WIDTH:0.552174
G1 X113.604 Y135.998 E.00231
;WIDTH:0.600544
G1 X113.664 Y136.027 E.00251
;WIDTH:0.648914
G1 X113.724 Y136.057 E.00274
G1 X113.66 Y136.081 E.00279
;WIDTH:0.600544
G1 X113.597 Y136.105 E.00254
;WIDTH:0.552174
G1 X113.533 Y136.129 E.00235
;WIDTH:0.503803
G1 X113.47 Y136.153 E.00211
;WIDTH:0.455433
G1 X113.406 Y136.178 E.00192
;WIDTH:0.407063
G1 X113.342 Y136.202 E.00169
;WIDTH:0.402305
G1 X112.179 Y136.181 E.02847
;WIDTH:0.399999
G1 X107.853 Y136.181 E.10523
G1 X107.853 Y130.804 E.13079
G1 X107.853 Y130.804 F9000
G1 X108.218 Y131.977
G1 F1200
G1 X109.311 Y133.857 E.0529
G1 X110.082 Y134.795 E.02953
G1 X110.463 Y135.129 E.01232
G1 X111.061 Y135.545 E.01772
G1 X111.585 Y135.816 E.01435
G1 X108.218 Y135.816 E.0819
G1 X108.218 Y132.16 E.08893
G1 X108.218 Y132.16 F9000
G1 X108.584 Y133.334
G1 F1200
G1 X109.113 Y134.211 E.02491
G1 X109.838 Y135.068 E.0273
G1 X110.284 Y135.45 E.01428
G1 X108.584 Y135.45 E.04135
G1 X108.584 Y133.517 E.04702
G1 X108.584 Y133.517 F9000
G1 X108.924 Y134.516
;WIDTH:0.348256
G1 F1200
G1 X109.413 Y135.11 E.01607
G1 X108.924 Y135.11 E.01021
G1 X108.924 Y134.698 E.0086
G1 E-5 F3600
G1 X108.924 Y134.698 F9000
G1 E5 F2400
;WIDTH:0.648914
G1 F1200
G1 X113.771 Y136.058 E.00192
;WIDTH:0.64731
G1 X116.452 Y136.058 E.10932
G1 X116.452 Y136.058 F9000
G1 X117.377 Y135.977
;WIDTH:0.399999
G1 F1200
G1 X117.834 Y135.52 E.01572
G1 X118.492 Y135.379 E.01637
G1 X117.421 Y136.45 E.03684
G1 E-5 F3600
G1 X117.421 Y136.45 F9000
G1 X123.335 Y129.349
G1 E5 F2400
;WIDTH:0.410891
G1 F1200
G1 X123.115 Y129.889 E.01461
G1 X123.131 Y129.965 E.00195
G1 X123.272 Y130.071 E.00442
G1 X123.507 Y130.134 E.00609
G1 X123.507 Y129.398 E.01844
G1 X123.437 Y129.198 E.00531
G1 X123.437 Y129.198 F9000
G1 X122.998 Y130.357
;WIDTH:0.399999
G1 F1200
G1 X122.702 Y130.652 E.01017
G1 X122.544 Y130.9 E.00715
;WIDTH:0.374336
G1 X122.473 Y130.881 E.00166
G1 X122.492 Y130.952 E.00166
G1 X122.533 Y130.941 E.00096
G1 X123.405 Y130.466 F9000
;WIDTH:0.399999
G1 F1200
G1 X121.988 Y131.883 E.04874
G1 X121.83 Y132.131 E.00715
;WIDTH:0.374336
G1 X121.759 Y132.112 E.00166
G1 X121.778 Y132.183 E.00166
G1 X121.819 Y132.172 E.00096
G1 E-5 F3600
G1 X121.819 Y132.172 F9000
G1 X123.512 Y130.876
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X121.275 Y133.114 E.07697
G1 X121.068 Y133.372 E.00805
;WIDTH:0.374336
G1 X120.724 Y133.789 E.01223
G1 X119.961 Y134.55 E.02437
G1 X119.614 Y134.834 E.01014
;WIDTH:0.399999
G1 X119.355 Y135.033 E.00794
G1 X117.842 Y136.547 E.05206
G1 X118.13 Y136.684 E.00776
;WIDTH:0.374336
G1 X118.089 Y136.695 E.00096
G1 X118.07 Y136.624 E.00166
G1 X118.141 Y136.643 E.00166
;WIDTH:0.399999
G1 X118.359 Y136.547 E.00579
G1 X123.512 Y131.393 E.17728
G1 X123.512 Y131.91 E.01258
G1 X118.876 Y136.547 E.15949
G1 X119.393 Y136.547 E.01258
G1 X123.512 Y132.427 E.14171
G1 X123.513 Y132.944 E.01258
G1 X119.91 Y136.547 E.12394
G1 X120.427 Y136.547 E.01258
G1 X123.513 Y133.461 E.10616
G1 X123.513 Y133.979 E.0126
G1 X120.944 Y136.547 E.08835
G1 X121.461 Y136.547 E.01258
G1 X123.513 Y134.496 E.07057
G1 X123.513 Y135.013 E.01258
G1 X121.979 Y136.547 E.05277
G1 X122.496 Y136.547 E.01258
G1 X123.513 Y135.53 E.03498
G1 X123.513 Y136.047 E.01258
G1 X123.013 Y136.547 E.0172
G1 X122.914 Y136.692 E.00427
;WIDTH:0.374336
G1 X122.842 Y136.673 E.00168
G1 X122.862 Y136.744 E.00167
G1 X122.903 Y136.733 E.00096
;WIDTH:0.399999
G1 X123.565 Y136.578 E.01654
;WIDTH:0.402388
G1 X123.521 Y136.59 E.00112
G1 X123.5 Y136.513 E.00195
G1 X123.577 Y136.534 E.00195
G1 E-5 F3600
G1 X123.577 Y136.534 F9000
G1 X123.437 Y115.198
G1 E5 F2400
;WIDTH:0.411317
G1 F1200
G1 X123.506 Y115.398 E.00531
G1 X123.506 Y116.134 E.01846
G1 X123.26 Y116.068 E.00639
G1 X123.097 Y115.935 E.00528
G1 X123.335 Y115.35 E.01584
G1 X123.335 Y115.35 F9000
G1 X122.986 Y116.354
;WIDTH:0.399999
G1 F1200
G1 X122.721 Y116.619 E.00912
G1 X122.564 Y116.866 E.00712
;WIDTH:0.374336
G1 X122.493 Y116.847 E.00166
G1 X122.512 Y116.918 E.00166
G1 X122.553 Y116.907 E.00096
G1 X122.553 Y116.907 F9000
G1 X123.394 Y116.463
;WIDTH:0.399999
G1 F1200
G1 X122.008 Y117.849 E.04768
G1 X121.85 Y118.097 E.00715
;WIDTH:0.374336
G1 X121.779 Y118.078 E.00166
G1 X121.798 Y118.149 E.00166
G1 X121.839 Y118.138 E.00096
G1 X121.294 Y119.08 F9000
;WIDTH:0.399999
G1 F1200
G1 X123.512 Y116.862 E.0763
G1 E-5 F3600
G1 X123.512 Y116.862 F9000
G1 X121.088 Y119.339
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X120.733 Y119.772 E.01266
G1 X120.09 Y120.429 E.02079
G1 X119.39 Y121.003 E.02047
;WIDTH:0.399999
G1 X119.707 Y121.184 E.00888
G1 X123.512 Y117.379 E.13089
G1 X123.512 Y117.896 E.01258
G1 X120.02 Y121.389 E.12014
G1 X120.292 Y121.634 E.0089
G1 X123.512 Y118.413 E.11078
G1 X123.512 Y118.93 E.01258
G1 X120.545 Y121.897 E.10206
G1 E-5 F3600
G1 X120.545 Y121.897 F9000
G1 X123.383 Y119.577
G1 E5 F2400
G1 F1200
G1 X120.788 Y122.172 E.08927
G1 X121.057 Y122.51 E.01051
G1 X122.916 Y125.708 E.08998
G1 X123.313 Y126.622 E.02424
G1 X123.446 Y126.866 E.00676
G1 X123.513 Y126.581 E.00712
G1 X123.512 Y119.448 E.1735
G1 X123.512 Y119.448 F9000
G1 X123.147 Y120.33
G1 F1200
G1 X123.147 Y125.379 E.12281
G1 X121.61 Y122.734 E.07441
G1 X121.278 Y122.199 E.01532
G1 X123.018 Y120.46 E.05984
G1 X123.018 Y120.46 F9000
G1 X122.781 Y121.213
G1 F1200
G1 X122.782 Y124.022 E.06833
G1 X121.749 Y122.245 E.05
G1 X122.652 Y121.342 E.03106
G1 X122.652 Y121.342 F9000
G1 X122.389 Y122.302
;WIDTH:0.586028
G1 F1200
G1 X122.341 Y122.254 E.00249
G1 X122.274 Y122.271 E.00254
G1 X122.256 Y122.338 E.00255
G1 X122.305 Y122.387 E.00254
G1 X122.371 Y122.369 E.00251
G1 E-5 F3600
G1 X122.371 Y122.369 F9000
G1 X112.904 Y120.06
G1 X112.36 Y119.851
G1 X111.638 Y119.36
G1 X107.564 Y115.094
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X107.797 Y115.689 E.01554
G1 X108.084 Y116.292 E.01624
G1 X109.943 Y119.49 E.08998
G1 X110.211 Y119.835 E.01063
G1 X107.487 Y122.559 E.0937
G1 X107.487 Y115.735 E.16599
G1 X107.519 Y115.245 E.01194
G1 X107.519 Y115.245 F9000
G1 X107.853 Y116.621
G1 F1200
G1 X109.392 Y119.268 E.07448
G1 X109.724 Y119.805 E.01536
G1 X107.853 Y121.676 E.06436
G1 X107.853 Y116.804 E.11851
G1 X107.853 Y116.804 F9000
G1 X108.218 Y117.977
G1 F1200
G1 X109.253 Y119.758 E.0501
G1 X108.218 Y120.793 E.0356
G1 X108.218 Y118.16 E.06405
G1 X108.218 Y118.16 F9000
G1 X108.745 Y119.665
;WIDTH:0.588332
G1 F1200
G1 X108.696 Y119.616 E.00255
G1 X108.629 Y119.634 E.00256
G1 X108.611 Y119.701 E.00256
G1 X108.66 Y119.75 E.00255
G1 X108.727 Y119.732 E.00256
G1 X108.727 Y119.732 F9000
G1 X110.448 Y120.116
;WIDTH:0.399999
G1 F1200
G1 X107.487 Y123.076 E.10184
G1 X107.487 Y123.593 E.01258
G1 X110.702 Y120.379 E.11058
G1 X110.993 Y120.604 E.00895
G1 X107.487 Y124.11 E.1206
G1 X107.487 Y124.628 E.0126
G1 X111.294 Y120.82 E.13098
G1 X111.613 Y121.002 E.00893
;WIDTH:0.375456
G1 X110.864 Y121.617 E.02199
;WIDTH:0.374336
G1 X110.27 Y122.228 E.01927
G1 X109.902 Y122.677 E.01313
;WIDTH:0.399999
G1 X109.696 Y122.935 E.00803
G1 X107.487 Y125.145 E.07601
G1 X107.615 Y125.534 E.00996
G1 X109.207 Y123.942 E.05476
;WIDTH:0.374336
G1 X109.166 Y123.953 E.00096
G1 X109.147 Y123.882 E.00166
G1 X109.218 Y123.901 E.00166
G1 X109.218 Y123.901 F9000
G1 X108.261 Y125.405
;WIDTH:0.399645
G1 F1200
G1 X108.077 Y125.722 E.00891
G1 X107.554 Y126.866 E.03057
G1 X107.487 Y126.612 E.00638
G1 X107.487 Y125.922 E.01677
G1 X107.642 Y125.973 E.00397
G1 X107.744 Y125.922 E.00277
G1 X108.131 Y125.534 E.01332
G1 E-5 F3600
G1 X108.131 Y125.534 F9000
G1 X107.549 Y91.465
G1 E5 F2400
;WIDTH:0.450666
G1 F1200
G1 X107.512 Y91.428 E.00145
G1 X107.462 Y91.442 E.00144
G1 X107.449 Y91.492 E.00143
G1 X107.485 Y91.529 E.00143
G1 X107.536 Y91.515 E.00146
;WIDTH:0.399999
G1 X107.487 Y92.043 E.0129
G1 X108.077 Y91.453 E.0203
;WIDTH:0.449921
G1 X108.116 Y91.433 E.00121
;WIDTH:0.499844
G1 X108.155 Y91.412 E.00137
;WIDTH:0.549766
G1 X108.194 Y91.392 E.0015
;WIDTH:0.599688
G1 X108.233 Y91.372 E.00165
;WIDTH:0.64961
G1 X108.272 Y91.351 E.00181
G1 X108.198 Y91.371 E.00314
G1 X108.143 Y91.317 E.00315
G1 X108.163 Y91.243 E.00314
G1 X108.237 Y91.223 E.00314
G1 X108.292 Y91.277 E.00315
;WIDTH:0.399999
G1 X108.594 Y91.453 E.0085
G1 X107.487 Y92.56 E.03808
G1 X107.487 Y93.078 E.0126
G1 X109.111 Y91.453 E.05588
G1 X109.628 Y91.453 E.01258
G1 X107.487 Y93.595 E.07367
G1 X107.487 Y94.112 E.01258
G1 X110.146 Y91.453 E.09147
G1 X110.663 Y91.453 E.01258
G1 X107.487 Y94.629 E.10925
G1 X107.487 Y95.146 E.01258
G1 X111.18 Y91.453 E.12704
G1 X111.697 Y91.453 E.01258
G1 X107.487 Y95.663 E.14482
G1 X107.487 Y96.18 E.01258
G1 X112.214 Y91.453 E.16261
G1 X112.731 Y91.453 E.01258
G1 X107.487 Y96.697 E.18039
G1 X107.421 Y96.945 E.00624
;WIDTH:0.374336
G1 X107.35 Y96.926 E.00166
G1 X107.369 Y96.997 E.00166
G1 X107.41 Y96.986 E.00096
G1 E-5 F3600
G1 X107.41 Y96.986 F9000
G1 X109.798 Y94.844
G1 E5 F2400
G1 F1200
G1 X110.297 Y94.235 E.01781
G1 X111.134 Y93.412 E.02655
G1 X111.561 Y93.077 E.01227
;WIDTH:0.399999
G1 X111.82 Y92.882 E.00789
G1 X113.248 Y91.453 E.04914
G1 X123.535 Y91.453 E.25022
G1 X123.513 Y91.556 E.00256
G1 X123.513 Y97.783 E.15147
;WIDTH:0.44743
G1 X123.489 Y97.997 E.00592
;WIDTH:0.49486
G1 X123.466 Y98.211 E.00659
;WIDTH:0.54229
G1 X123.442 Y98.426 E.00731
;WIDTH:0.58972
G1 X123.418 Y98.64 E.00796
G1 X123.391 Y98.595 E.00194
;WIDTH:0.564095
G1 X123.292 Y98.412 E.00733
;WIDTH:0.523071
G1 X123.193 Y98.229 E.00676
;WIDTH:0.482047
G1 X123.095 Y98.045 E.00621
;WIDTH:0.441023
G1 X122.996 Y97.862 E.00563
;WIDTH:0.399999
G1 X121.057 Y94.511 E.09417
G1 X120.79 Y94.153 E.01086
G1 X120.299 Y93.63 E.01745
G1 X119.926 Y93.32 E.0118
G1 X119.446 Y93.013 E.01386
G1 X119.01 Y92.804 E.01176
G1 X118.306 Y92.571 E.01804
G1 X117.478 Y92.443 E.02038
G1 X113.821 Y92.432 E.08895
G1 X114.018 Y92.235 E.00678
G1 X114.066 Y92.062 E.00437
G1 X113.933 Y91.891 E.00527
G1 X113.886 Y91.633 E.00638
G1 X113.571 Y91.648 E.00767
G1 X112.634 Y92.584 E.03221
G1 X112.42 Y92.734 E.00636
;WIDTH:0.374336
G1 X112.348 Y92.715 E.00168
G1 X112.368 Y92.786 E.00167
G1 X112.409 Y92.775 E.00096
G1 X112.409 Y92.775 F9000
G1 X113.251 Y92.485
;WIDTH:0.399999
G1 F1200
G1 X113.63 Y92.106 E.01304
G1 X113.63 Y92.106 F9000
G1 X114.542 Y91.944
;WIDTH:0.655606
G1 F1200
G1 X116.538 Y91.947 E.08249
G1 X116.596 Y91.924 E.00258
;WIDTH:0.611131
G1 X116.653 Y91.902 E.00234
;WIDTH:0.566656
G1 X116.71 Y91.88 E.00216
;WIDTH:0.522182
G1 X116.768 Y91.858 E.00201
G1 X116.71 Y91.88 E.00201
;WIDTH:0.566656
G1 X116.653 Y91.902 E.00216
;WIDTH:0.611131
G1 X116.596 Y91.924 E.00234
;WIDTH:0.655606
G1 X116.538 Y91.947 E.00258
G1 X116.595 Y91.969 E.00253
;WIDTH:0.611316
G1 X116.652 Y91.991 E.00235
;WIDTH:0.567025
G1 X116.71 Y92.014 E.00221
;WIDTH:0.522734
G1 X116.767 Y92.036 E.00198
;WIDTH:0.478443
G1 X116.824 Y92.058 E.0018
;WIDTH:0.434153
G1 X116.881 Y92.081 E.00163
;WIDTH:0.389862
G1 X116.938 Y92.103 E.00144
;WIDTH:0.346382
G1 X117.479 Y92.104 E.01123
;WIDTH:0.373191
G1 X117.927 Y92.158 E.01017
;WIDTH:0.399999
G1 X118.375 Y92.212 E.01098
G1 X119.125 Y92.457 E.01919
G1 X119.584 Y92.672 E.01233
G1 X120.123 Y93.012 E.0155
G1 X120.516 Y93.333 E.01234
G1 X121.034 Y93.878 E.01829
G1 X121.373 Y94.327 E.01368
G1 X123.147 Y97.394 E.08618
G1 X123.147 Y91.819 E.13561
G1 X118.413 Y91.819 E.11515
G1 X117.849 Y91.799 E.01373
;WIDTH:0.36121
G1 X116.938 Y91.792 E.01981
G1 E-5 F3600
G1 X116.938 Y91.792 F9000
G1 X119.412 Y92.184
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X122.782 Y92.184 E.08197
G1 X122.782 Y96.032 E.0936
G1 X121.69 Y94.144 E.05305
G1 X121.3 Y93.628 E.01573
G1 X120.75 Y93.052 E.01937
G1 X120.32 Y92.704 E.01346
G1 X119.84 Y92.397 E.01386
G1 X119.576 Y92.266 E.00717
G1 X119.576 Y92.266 F9000
G1 X120.718 Y92.55
G1 F1200
G1 X122.416 Y92.55 E.0413
G1 X122.416 Y94.669 E.05154
G1 X121.925 Y93.838 E.02348
G1 X121.59 Y93.402 E.01337
G1 X121.099 Y92.879 E.01745
G1 X120.857 Y92.67 E.00778
G1 X120.857 Y92.67 F9000
G1 X121.999 Y93.021
;WIDTH:0.650826
G1 F1200
G1 X121.945 Y92.967 E.00313
G1 X121.871 Y92.987 E.00314
G1 X121.851 Y93.061 E.00314
G1 X121.905 Y93.116 E.00316
G1 X121.98 Y93.096 E.00318
G1 E-5 F3600
G1 X121.98 Y93.096 F9000
G1 X123.418 Y98.64
G1 E5 F2400
;WIDTH:0.58972
G1 F1200
G1 X123.557 Y99.337 E.02626
;WIDTH:0.579208
G1 X123.576 Y100.439 E.03995
;WIDTH:0.546926
G1 X123.525 Y100.669 E.00803
;WIDTH:0.524641
G1 X123.437 Y100.997 E.01108
;WIDTH:0.483278
G1 X123.348 Y101.324 E.01012
;WIDTH:0.441915
G1 X123.147 Y101.849 E.01524
G1 X123.278 Y101.849 E.00355
G1 X123.409 Y101.959 E.00464
G1 X123.626 Y102.037 E.00625
G1 X123.626 Y101.353 E.01854
;WIDTH:0.476919
G1 X123.608 Y101.066 E.00847
;WIDTH:0.511923
G1 X123.591 Y100.78 E.0091
;WIDTH:0.546926
G1 X123.573 Y100.493 E.00981
G1 X123.573 Y100.493 F9000
G1 X123.134 Y102.252
;WIDTH:0.399999
G1 F1200
G1 X122.657 Y102.729 E.01641
G1 X122.5 Y102.977 E.00714
;WIDTH:0.374336
G1 X122.428 Y102.958 E.00168
G1 X122.447 Y103.029 E.00166
G1 X122.489 Y103.018 E.00098
G1 X122.489 Y103.018 F9000
G1 X123.514 Y102.389
;WIDTH:0.399999
G1 F1200
G1 X121.944 Y103.96 E.05402
G1 X121.786 Y104.208 E.00715
;WIDTH:0.374336
G1 X121.715 Y104.188 E.00167
G1 X121.734 Y104.26 E.00168
G1 X121.775 Y104.249 E.00096
G1 E-5 F3600
G1 X121.775 Y104.249 F9000
G1 X123.647 Y102.774
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X121.23 Y105.191 E.08314
G1 X121.022 Y105.449 E.00806
;WIDTH:0.374336
G1 X120.117 Y106.427 E.03014
G1 X119.705 Y106.782 E.0123
;WIDTH:0.405594
G1 X119.423 Y106.994 E.00871
;WIDTH:0.399999
G1 X119.738 Y107.2 E.00916
G1 X123.549 Y103.389 E.1311
G1 X123.513 Y103.942 E.01348
G1 X120.048 Y107.407 E.11919
G1 X120.316 Y107.656 E.0089
G1 X123.513 Y104.459 E.10997
G1 X123.513 Y104.976 E.01258
G1 X120.569 Y107.921 E.10129
G1 E-5 F3600
G1 X120.569 Y107.921 F9000
G1 X123.384 Y105.623
G1 E5 F2400
G1 F1200
G1 X120.81 Y108.196 E.08853
G1 X121.057 Y108.51 E.00972
G1 X122.916 Y111.708 E.08998
G1 X123.313 Y112.622 E.02424
G1 X123.446 Y112.866 E.00676
G1 X123.513 Y112.581 E.00712
G1 X123.513 Y105.493 E.17241
G1 X123.513 Y105.493 F9000
G1 X123.147 Y106.376
G1 F1200
G1 X123.147 Y111.379 E.12169
G1 X121.299 Y108.224 E.08894
G1 X123.018 Y106.505 E.05913
G1 X123.018 Y106.505 F9000
G1 X122.782 Y107.259
G1 F1200
G1 X122.782 Y110.023 E.06723
G1 X121.766 Y108.275 E.04918
G1 X122.652 Y107.388 E.0305
G1 X122.652 Y107.388 F9000
G1 X122.395 Y108.331
;WIDTH:0.571236
G1 F1200
G1 X122.348 Y108.284 E.00237
G1 X122.283 Y108.301 E.0024
G1 X122.266 Y108.366 E.0024
G1 X122.313 Y108.413 E.00237
G1 X122.378 Y108.396 E.0024
G1 E-5 F3600
G1 X122.378 Y108.396 F9000
G1 X112.904 Y106.06
G1 X112.789 Y106.024
G1 X112.627 Y105.968
G1 X112.516 Y105.922
G1 X112.36 Y105.851
G1 X112.253 Y105.795
G1 X112.105 Y105.709
G1 X112.003 Y105.645
G1 X111.863 Y105.545
G1 X111.768 Y105.472
G1 X111.638 Y105.36
G1 X111.549 Y105.278
G1 X111.431 Y105.154
G1 X111.35 Y105.066
G1 X111.244 Y104.93
G1 X111.17 Y104.835
G1 X111.078 Y104.691
G1 X111.02 Y104.6
G1 X109.276 Y101.58
G1 X109.227 Y101.485
G1 X109.148 Y101.332
G1 X109.102 Y101.221
G1 X109.038 Y101.061
G1 X109.002 Y100.947
G1 X108.954 Y100.782
G1 X108.927 Y100.665
G1 X108.895 Y100.496
G1 X108.879 Y100.377
G1 X108.863 Y100.206
G1 X108.858 Y100.086
G1 X108.858 Y99.914
G1 X108.863 Y99.794
G1 X108.879 Y99.623
G1 X108.895 Y99.504
G1 X109.599 Y95.102
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X107.487 Y97.215 E.07267
G1 X107.67 Y97.549 E.00926
G1 X109.11 Y96.109 E.04954
;WIDTH:0.374336
G1 X109.069 Y96.12 E.00096
G1 X109.05 Y96.049 E.00166
G1 X109.121 Y96.068 E.00166
G1 X109.121 Y96.068 F9000
G1 X108.172 Y97.561
;WIDTH:0.396155
G1 F1200
G1 X107.932 Y98.031 E.0127
;WIDTH:0.437043
G1 X107.863 Y98.158 E.00387
;WIDTH:0.477931
G1 X107.793 Y98.286 E.0043
;WIDTH:0.518819
G1 X107.724 Y98.414 E.00469
;WIDTH:0.559706
G1 X107.655 Y98.542 E.00508
;WIDTH:0.600594
G1 X107.585 Y98.669 E.00546
G1 X107.561 Y98.575 E.00365
;WIDTH:0.552056
G1 X107.538 Y98.481 E.00333
;WIDTH:0.503517
G1 X107.514 Y98.387 E.00303
;WIDTH:0.454979
G1 X107.49 Y98.293 E.00271
;WIDTH:0.40644
G1 X107.485 Y97.86 E.01072
;WIDTH:0.396155
G1 X107.668 Y97.988 E.00537
G1 X107.798 Y97.935 E.00338
G1 X108.043 Y97.69 E.00834
G1 X108.043 Y97.69 F9000
G1 X107.585 Y98.669
;WIDTH:0.600594
G1 F1200
G1 X107.443 Y99.337 E.02572
;WIDTH:0.579398
G1 X107.428 Y99.619 E.01024
;WIDTH:0.54856
G1 X107.412 Y99.9 E.00963
;WIDTH:0.550444
G1 X107.429 Y100.533 E.02174
;WIDTH:0.553934
G1 X107.414 Y100.755 E.00769
;WIDTH:0.516223
G1 X107.393 Y100.962 E.00667
;WIDTH:0.477482
G1 X107.373 Y101.169 E.00613
;WIDTH:0.438741
G1 X107.353 Y101.376 E.00559
;WIDTH:0.399999
G1 X107.353 Y102.959 E.0385
G1 X107.487 Y103.615 E.01629
G1 X107.487 Y108.591 E.12104
G1 X110.226 Y105.852 E.09422
G1 X109.943 Y105.49 E.01118
G1 X108.004 Y102.138 E.09419
G1 X107.685 Y101.374 E.02014
;WIDTH:0.437564
G1 X107.622 Y101.174 E.00562
;WIDTH:0.475129
G1 X107.558 Y100.973 E.00619
;WIDTH:0.512694
G1 X107.495 Y100.773 E.00667
;WIDTH:0.550258
G1 X107.431 Y100.573 E.00721
G1 X107.431 Y100.573 F9000
G1 X107.719 Y102.375
;WIDTH:0.399999
G1 F1200
G1 X109.403 Y105.286 E.0818
G1 X109.738 Y105.823 E.0154
G1 X107.853 Y107.709 E.06486
G1 X107.853 Y103.615 E.09958
G1 X107.726 Y102.873 E.01831
G1 X107.722 Y102.558 E.00766
G1 X107.722 Y102.558 F9000
G1 X108.218 Y103.968
G1 F1200
G1 X109.265 Y105.778 E.05086
G1 X108.218 Y106.826 E.03603
G1 X108.218 Y104.151 E.06507
G1 X108.218 Y104.151 F9000
G1 X108.752 Y105.684
;WIDTH:0.599502
G1 F1200
G1 X108.702 Y105.634 E.00266
G1 X108.634 Y105.652 E.00264
G1 X108.615 Y105.72 E.00265
G1 X108.665 Y105.77 E.00266
G1 X108.734 Y105.752 E.00268
G1 X108.734 Y105.752 F9000
G1 X110.463 Y106.133
;WIDTH:0.399999
G1 F1200
G1 X107.487 Y109.108 E.10236
G1 X107.487 Y109.626 E.0126
G1 X110.718 Y106.394 E.11116
G1 X111.012 Y106.618 E.00899
G1 X107.487 Y110.143 E.12126
G1 X107.487 Y110.66 E.01258
G1 X111.313 Y106.834 E.13161
G1 X111.632 Y107.001 E.00876
;WIDTH:0.374336
G1 X110.873 Y107.625 E.02222
G1 X110.28 Y108.234 E.01922
G1 X109.857 Y108.754 E.01516
;WIDTH:0.399999
G1 X109.651 Y109.013 E.00805
G1 X107.487 Y111.177 E.07444
G1 X107.64 Y111.541 E.0096
G1 X109.162 Y110.019 E.05236
;WIDTH:0.374336
G1 X109.121 Y110.03 E.00096
G1 X109.102 Y109.959 E.00166
G1 X109.173 Y109.978 E.00166
G1 X109.173 Y109.978 F9000
G1 X108.22 Y111.476
;WIDTH:0.397814
G1 F1200
G1 X108.078 Y111.722 E.00687
G1 X107.553 Y112.869 E.0305
G1 X107.486 Y112.612 E.00642
G1 X107.486 Y111.939 E.01627
G1 X107.654 Y111.981 E.00419
G1 X107.769 Y111.928 E.00306
G1 X108.091 Y111.606 E.01101
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X107.769 Y111.928 E-.2163
G1 X107.654 Y111.981 E-.06015
G1 X107.486 Y111.939 E-.08226
G1 X107.486 Y112.612 E-.31968
G1 X107.553 Y112.869 E-.12616
G1 X108.078 Y111.722 E-.59918
G1 X108.179 Y111.547 E-.09627
;WIPE_END
G1 X108.863 Y99.794 F9000
G1 X108.879 Y99.623
G1 X109.803 Y90.065
G1 X109.948 Y88.151
G1 X110.065 Y86.599
G1 X109.801 Y85.151
G1 X110.149 Y85.499
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X105.142 Y85.5 E.12179
G1 X104.267 Y85.478 E.02129
G1 X103.709 Y85.394 E.01373
G1 X103.167 Y85.227 E.0138
G1 X102.655 Y84.981 E.01382
G1 X102.187 Y84.662 E.01378
G1 X101.773 Y84.277 E.01375
G1 X101.42 Y83.835 E.01376
G1 X101.137 Y83.345 E.01376
G1 X100.928 Y82.813 E.0139
G1 X100.795 Y82.21 E.01502
G1 X100.75 Y81.696 E.01255
G1 X100.75 Y78.538 E.07682
G1 X100.718 Y78.436 E.0026
G1 X100.344 Y77.847 E.01697
G1 X100.264 Y77.507 E.0085
G1 X100.342 Y77.148 E.00894
G1 X100.61 Y76.716 E.01237
G1 X130.39 Y76.716 E.72437
G1 X130.689 Y77.251 E.01491
G1 X130.719 Y77.517 E.00651
G1 X130.705 Y77.718 E.0049
G1 X130.555 Y78.036 E.00855
G1 X130.286 Y78.429 E.01158
G1 X130.25 Y78.538 E.00279
G1 X130.239 Y81.983 E.0838
G1 X130.155 Y82.541 E.01373
G1 X129.871 Y83.352 E.0209
G1 X129.604 Y83.816 E.01302
G1 X129.031 Y84.487 E.02146
G1 X128.591 Y84.839 E.01371
G1 X128.113 Y85.115 E.01343
G1 X127.29 Y85.405 E.02123
G1 X126.951 Y85.457 E.00834
G1 X126.446 Y85.5 E.01233
G1 X120.851 Y85.499 E.13609
G1 X120.719 Y85.323 E.00535
G1 X120.667 Y85.316 E.00128
G1 X110.333 Y85.316 E.25136
G1 X110.307 Y85.318 E.00063
G1 X110.188 Y85.453 E.00438
G1 X110.188 Y85.453 F9000
G1 X110.01 Y85.134
;TYPE:Perimeter
G1 F6000
G1 X105.142 Y85.134 E.11841
G1 X104.294 Y85.114 E.02063
G1 X103.79 Y85.038 E.0124
G1 X103.301 Y84.887 E.01245
G1 X102.838 Y84.664 E.0125
G1 X102.415 Y84.376 E.01245
G1 X102.041 Y84.029 E.01241
G1 X101.722 Y83.629 E.01244
G1 X101.466 Y83.186 E.01245
G1 X101.278 Y82.705 E.01256
G1 X101.165 Y82.212 E.0123
G1 X101.116 Y81.688 E.0128
G1 X101.116 Y78.538 E.07662
G1 X101.021 Y78.23 E.00784
G1 X100.732 Y77.804 E.01252
G1 X100.649 Y77.625 E.0048
G1 X100.674 Y77.343 E.00689
G1 X100.813 Y77.082 E.00719
G1 X130.187 Y77.082 E.71449
G1 X130.324 Y77.302 E.0063
G1 X130.354 Y77.492 E.00468
G1 X130.35 Y77.543 E.00124
G1 X130.224 Y77.88 E.00875
G1 X129.992 Y78.212 E.00985
G1 X129.884 Y78.536 E.00831
G1 X129.873 Y81.955 E.08316
G1 X129.798 Y82.453 E.01225
G1 X129.537 Y83.199 E.01922
G1 X129.304 Y83.604 E.01137
G1 X128.776 Y84.223 E.01979
G1 X128.553 Y84.401 E.00694
G1 X127.96 Y84.782 E.01714
G1 X127.201 Y85.049 E.01957
G1 X126.438 Y85.134 E.01867
G1 X120.943 Y85.134 E.13366
G1 X120.821 Y84.972 E.00493
G1 X120.667 Y84.95 E.00378
G1 X110.333 Y84.95 E.25136
G1 X110.179 Y84.972 E.00378
G1 X110.065 Y85.124 E.00462
G1 X110.065 Y85.124 F9000
G1 X109.756 Y84.769
G1 F6000
G1 X105.142 Y84.769 E.11223
G1 X104.382 Y84.754 E.01849
G1 X103.872 Y84.681 E.01253
G1 X103.22 Y84.463 E.01672
G1 X102.643 Y84.09 E.01671
G1 X102.154 Y83.612 E.01663
G1 X101.796 Y83.027 E.01668
G1 X101.56 Y82.381 E.01673
G1 X101.481 Y81.68 E.01716
G1 X101.481 Y78.538 E.07643
G1 X101.324 Y78.025 E.01305
G1 X101.034 Y77.598 E.01256
G1 X101.025 Y77.448 E.00366
G1 X129.422 Y77.448 E.69073
G1 X129.989 Y77.467 E.0138
G1 X129.894 Y77.724 E.00666
G1 X129.698 Y77.994 E.00812
G1 X129.519 Y78.535 E.01386
G1 X129.508 Y81.733 E.07779
G1 X129.442 Y82.365 E.01546
G1 X129.27 Y82.857 E.01268
G1 X129.004 Y83.392 E.01453
G1 X128.681 Y83.772 E.01213
G1 X128.325 Y84.115 E.01202
G1 X127.806 Y84.448 E.015
G1 X127.112 Y84.693 E.0179
G1 X126.43 Y84.769 E.01669
G1 X121.034 Y84.769 E.13125
G1 X120.924 Y84.621 E.00449
G1 X120.667 Y84.584 E.00632
G1 X110.333 Y84.584 E.25136
G1 X110.076 Y84.621 E.00632
G1 X109.966 Y84.769 E.00449
G1 X109.816 Y84.769 E.00365
G1 X109.816 Y84.769 F9000
G1 X109.494 Y84.402
G1 F6000
G1 X104.492 Y84.395 E.12167
G1 X103.953 Y84.325 E.01322
G1 X103.379 Y84.132 E.01473
G1 X102.871 Y83.804 E.01471
G1 X102.44 Y83.384 E.01464
G1 X102.125 Y82.868 E.01471
G1 X101.918 Y82.299 E.01473
G1 X101.847 Y81.672 E.01535
G1 X101.847 Y78.538 E.07623
G1 X101.63 Y77.818 E.01829
G1 X129.392 Y77.813 E.67528
G1 X129.153 Y78.534 E.01848
G1 X129.145 Y81.119 E.06288
G1 X129.117 Y82.064 E.023
G1 X128.989 Y82.552 E.01227
G1 X128.787 Y83.038 E.0128
G1 X128.403 Y83.534 E.01526
G1 X128.097 Y83.829 E.01034
G1 X127.652 Y84.115 E.01287
G1 X127.023 Y84.336 E.01622
G1 X126.422 Y84.403 E.01471
G1 X121.126 Y84.403 E.12882
G1 X121.027 Y84.27 E.00403
G1 X120.667 Y84.219 E.00884
G1 X110.333 Y84.219 E.25136
G1 X109.973 Y84.27 E.00884
G1 X109.874 Y84.403 E.00403
G1 X109.554 Y84.403 E.00778
G1 X109.554 Y84.403 F9000
G1 X109.23 Y84.037
G1 F6000
G1 X104.612 Y84.037 E.11233
G1 X104.034 Y83.968 E.01416
G1 X103.538 Y83.802 E.01272
G1 X103.099 Y83.518 E.01272
G1 X102.727 Y83.155 E.01264
G1 X102.454 Y82.71 E.0127
G1 X102.275 Y82.217 E.01276
G1 X102.213 Y81.664 E.01354
G1 X102.213 Y78.538 E.07604
G1 X102.102 Y78.179 E.00914
G1 X128.905 Y78.179 E.65196
G1 X128.787 Y78.533 E.00908
G1 X128.779 Y81.118 E.06288
G1 X128.756 Y82.01 E.0217
G1 X128.579 Y82.616 E.01536
G1 X128.404 Y82.969 E.00958
G1 X128.01 Y83.431 E.01477
G1 X127.499 Y83.781 E.01507
G1 X126.934 Y83.98 E.01457
G1 X126.414 Y84.037 E.01272
G1 X121.218 Y84.037 E.12639
G1 X121.129 Y83.919 E.0036
G1 X120.667 Y83.853 E.01135
G1 X110.333 Y83.853 E.25136
G1 X109.871 Y83.919 E.01135
G1 X109.782 Y84.037 E.0036
G1 X109.29 Y84.037 E.01197
G1 E-5 F3600
G1 X109.29 Y84.037 F9000
G1 X102.55 Y78.466
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.45165
G1 F1200
G1 X102.513 Y78.429 E.00145
G1 X102.463 Y78.442 E.00143
G1 X102.45 Y78.493 E.00146
G1 X102.486 Y78.529 E.00141
G1 X102.537 Y78.516 E.00146
;WIDTH:0.399999
G1 X102.488 Y79.045 E.01292
G1 X103.079 Y78.453 E.02035
G1 X103.25 Y78.327 E.00517
;WIDTH:0.374336
G1 X103.209 Y78.338 E.00096
G1 X103.19 Y78.267 E.00166
G1 X103.261 Y78.286 E.00166
;WIDTH:0.399999
G1 X103.597 Y78.453 E.00913
G1 X102.489 Y79.56 E.0381
G1 X102.491 Y80.076 E.01255
G1 X104.114 Y78.453 E.05583
G1 X104.631 Y78.453 E.01258
G1 X102.492 Y80.592 E.07358
G1 X102.493 Y81.108 E.01255
G1 X105.148 Y78.453 E.09133
G1 X105.665 Y78.453 E.01258
G1 X102.494 Y81.624 E.10908
G1 X102.535 Y82.1 E.01162
G1 X106.182 Y78.453 E.12545
G1 X106.699 Y78.453 E.01258
G1 X102.656 Y82.496 E.13908
G1 X102.838 Y82.832 E.00929
G1 X107.216 Y78.453 E.15062
G1 X107.734 Y78.453 E.0126
G1 X103.068 Y83.119 E.16051
G1 X103.342 Y83.361 E.00889
G1 X108.251 Y78.453 E.16885
G1 X108.768 Y78.453 E.01258
G1 X103.664 Y83.557 E.17557
G1 X104.048 Y83.69 E.00988
G1 X109.285 Y78.453 E.18015
G1 X109.802 Y78.453 E.01258
G1 X104.501 Y83.754 E.18235
G1 X105.009 Y83.763 E.01236
G1 X110.319 Y78.453 E.18266
G1 X110.836 Y78.453 E.01258
G1 X105.526 Y83.763 E.18266
G1 X106.044 Y83.763 E.0126
G1 X111.353 Y78.453 E.18264
G1 X111.871 Y78.453 E.0126
G1 X106.561 Y83.763 E.18266
G1 X107.078 Y83.763 E.01258
G1 X112.388 Y78.453 E.18266
G1 X112.905 Y78.453 E.01258
G1 X107.595 Y83.763 E.18266
G1 X108.112 Y83.763 E.01258
G1 X113.422 Y78.453 E.18266
G1 X113.939 Y78.453 E.01258
G1 X108.629 Y83.763 E.18266
G1 X109.146 Y83.763 E.01258
G1 X114.456 Y78.453 E.18266
G1 X114.973 Y78.453 E.01258
G1 X109.663 Y83.763 E.18266
G1 X109.792 Y83.881 E.00425
;WIDTH:0.374336
G1 X109.721 Y83.862 E.00166
G1 X109.74 Y83.933 E.00166
G1 X109.781 Y83.922 E.00096
;WIDTH:0.399999
G1 X110.365 Y83.579 E.01647
G1 X115.49 Y78.453 E.17631
G1 X116.008 Y78.453 E.0126
G1 X110.882 Y83.579 E.17633
G1 X111.399 Y83.579 E.01258
G1 X116.525 Y78.453 E.17633
G1 X117.042 Y78.453 E.01258
G1 X111.916 Y83.579 E.17633
G1 X112.433 Y83.579 E.01258
G1 X117.559 Y78.453 E.17633
G1 X118.076 Y78.453 E.01258
G1 X112.95 Y83.579 E.17633
G1 X113.468 Y83.579 E.0126
G1 X118.593 Y78.453 E.17631
G1 X119.11 Y78.453 E.01258
G1 X113.985 Y83.579 E.17631
G1 X114.502 Y83.579 E.01258
G1 X119.627 Y78.453 E.17631
G1 X120.145 Y78.453 E.0126
G1 X115.019 Y83.579 E.17633
G1 X115.536 Y83.579 E.01258
G1 X120.662 Y78.453 E.17633
G1 X121.179 Y78.453 E.01258
G1 X116.053 Y83.579 E.17633
G1 X116.57 Y83.579 E.01258
G1 X121.696 Y78.453 E.17633
G1 X122.213 Y78.453 E.01258
G1 X117.087 Y83.579 E.17633
G1 X117.605 Y83.579 E.0126
G1 X122.73 Y78.453 E.17631
G1 X123.247 Y78.453 E.01258
G1 X118.122 Y83.579 E.17631
G1 X118.639 Y83.579 E.01258
G1 X123.764 Y78.453 E.17631
G1 X124.282 Y78.453 E.0126
G1 X119.156 Y83.579 E.17633
G1 X119.673 Y83.579 E.01258
G1 X124.799 Y78.453 E.17633
G1 X125.316 Y78.453 E.01258
G1 X120.19 Y83.579 E.17633
G1 X120.705 Y83.581 E.01253
G1 X125.833 Y78.453 E.1764
G1 X126.35 Y78.453 E.01258
G1 X121.158 Y83.645 E.1786
G1 X121.289 Y83.883 E.00661
;WIDTH:0.374336
G1 X121.218 Y83.864 E.00166
G1 X121.237 Y83.935 E.00166
G1 X121.278 Y83.924 E.00096
;WIDTH:0.399999
G1 X121.557 Y83.763 E.00784
G1 X126.867 Y78.453 E.18266
G1 X127.384 Y78.453 E.01258
G1 X122.074 Y83.763 E.18266
G1 X122.592 Y83.763 E.0126
G1 X127.901 Y78.453 E.18264
G1 X127.901 Y78.453 F9000
G1 X128.692 Y78.352
;WIDTH:0.374336
G1 F1200
G1 X128.621 Y78.333 E.00166
G1 X128.64 Y78.404 E.00166
G1 X128.681 Y78.393 E.00096
;WIDTH:0.399999
G1 X128.419 Y78.453 E.00654
G1 X123.109 Y83.763 E.18266
G1 X123.626 Y83.763 E.01258
G1 X128.512 Y78.877 E.16808
G1 X128.51 Y79.396 E.01262
G1 X124.143 Y83.763 E.15022
G1 X124.66 Y83.763 E.01258
G1 X128.509 Y79.915 E.13239
G1 X128.507 Y80.433 E.0126
G1 X125.177 Y83.763 E.11455
G1 X125.694 Y83.763 E.01258
G1 X128.505 Y80.952 E.0967
G1 X128.504 Y81.471 E.01262
G1 X126.211 Y83.763 E.07886
G1 X126.769 Y83.723 E.01361
G1 X128.478 Y82.014 E.05879
G1 X128.285 Y82.684 E.01696
;WIDTH:0.374336
G1 X128.255 Y82.873 E.00433
G1 X127.874 Y83.285 E.01269
G1 X127.505 Y83.589 E.01081
G1 X127.349 Y83.593 E.00353
;WIDTH:0.399999
G1 X127.608 Y83.401 E.00784
G1 X128.067 Y82.942 E.01579
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X127.608 Y83.401 E-.30833
G1 X127.349 Y83.593 E-.15314
G1 X127.505 Y83.589 E-.07412
G1 X127.874 Y83.285 E-.2271
G1 X128.255 Y82.873 E-.26655
G1 X128.285 Y82.684 E-.0909
G1 X128.478 Y82.014 E-.33119
G1 X128.406 Y82.086 E-.04867
;WIPE_END
G1 X127.276 Y85.049 F9000
G1 X126.685 Y86.599
G1 X125.941 Y88.151
G1 X125.941 Y88.552
G1 E5 F2400
G1 F6000
G1 X125.947 Y88.555 E.00016
G1 X126 Y88.683 E.00337
G1 X126 Y89.551 E.02111
G1 X126.264 Y90 E.01267
G1 X126.369 Y90.537 E.01331
G1 X126.264 Y91 E.01155
G1 X126 Y91.449 E.01267
G1 X126 Y92.948 E.03646
G1 X139.202 Y92.948 E.32113
G1 X139.507 Y93.043 E.00777
G1 X139.77 Y93.328 E.00943
G1 X139.9 Y93.602 E.00738
G1 X139.9 Y95.227 E.03953
G1 X139.861 Y95.34 E.00291
G1 X139.604 Y95.72 E.01116
G1 X139.264 Y95.869 E.00903
G1 X136.7 Y95.88 E.06237
G1 X136.698 Y132.81 E.89829
G1 X136.634 Y133.757 E.02309
G1 X136.471 Y134.748 E.02443
G1 X136.253 Y135.585 E.02104
G1 X135.913 Y136.529 E.02441
G1 X135.491 Y137.416 E.02389
G1 X135.031 Y138.19 E.0219
G1 X134.438 Y139.005 E.02452
G1 X133.808 Y139.715 E.02309
G1 X132.723 Y140.681 E.03534
G1 X131.987 Y141.198 E.02188
G1 X131.105 Y141.701 E.0247
G1 X129.768 Y142.262 E.03527
G1 X128.945 Y142.502 E.02085
G1 X127.897 Y142.704 E.02596
G1 X126.886 Y142.792 E.02468
G1 X120.483 Y142.8 E.15575
G1 X120.397 Y142.729 E.00271
G1 X110.603 Y142.729 E.23823
G1 X110.517 Y142.8 E.00271
G1 X104.5 Y142.8 E.14636
G1 X103.859 Y142.778 E.0156
G1 X102.622 Y142.626 E.03032
G1 X102.051 Y142.501 E.01422
G1 X101.252 Y142.269 E.02024
G1 X100.298 Y141.894 E.02493
G1 X99.488 Y141.484 E.02208
G1 X98.613 Y140.929 E.0252
G1 X97.567 Y140.081 E.03275
G1 X97.186 Y139.709 E.01295
G1 X96.573 Y139.018 E.02247
G1 X95.967 Y138.186 E.02504
G1 X95.302 Y137.008 E.0329
G1 X94.915 Y136.088 E.02428
G1 X94.621 Y135.135 E.02426
G1 X94.371 Y133.801 E.03301
G1 X94.303 Y132.823 E.02385
G1 X94.3 Y95.88 E.8986
G1 X91.798 Y95.88 E.06086
G1 X91.493 Y95.786 E.00776
G1 X91.231 Y95.501 E.00942
G1 X91.1 Y95.227 E.00739
G1 X91.1 Y93.602 E.03953
G1 X91.259 Y93.278 E.00878
G1 X91.458 Y93.067 E.00705
G1 X91.798 Y92.948 E.00876
G1 X103.822 Y92.948 E.29247
G1 X105 Y92.948 E.02865
G1 X105 Y91.449 E.03646
G1 X104.736 Y91 E.01267
G1 X104.631 Y90.463 E.01331
G1 X104.736 Y90 E.01155
G1 X105 Y89.551 E.01267
G1 X105 Y88.683 E.02111
G1 X105.062 Y88.545 E.00368
G1 X105.183 Y88.5 E.00314
G1 X125.817 Y88.5 E.5019
G1 X125.885 Y88.529 E.0018
G1 X125.885 Y88.529 F9000
G1 X126.189 Y88.29
;TYPE:Perimeter
G1 F6000
G1 X126.208 Y88.298 E.0005
G1 X126.35 Y88.553 E.0071
G1 X126.366 Y89.451 E.02185
G1 X126.617 Y89.892 E.01234
G1 X126.727 Y90.39 E.01241
G1 X126.727 Y90.61 E.00535
G1 X126.579 Y91.185 E.01444
G1 X126.366 Y91.549 E.01026
G1 X126.366 Y92.583 E.02515
G1 X139.202 Y92.583 E.31222
G1 X139.505 Y92.639 E.00749
G1 X139.766 Y92.784 E.00726
G1 X139.986 Y93.003 E.00755
;WIDTH:0.448959
G1 X140.104 Y93.203 E.0064
;WIDTH:0.497919
G1 X140.222 Y93.402 E.00713
;WIDTH:0.546878
G1 X140.34 Y93.602 E.00792
;WIDTH:0.547002
G1 X140.34 Y95.227 E.05542
;WIDTH:0.553658
G1 X140.334 Y95.334 E.0037
G1 X140.256 Y95.447 E.00474
;WIDTH:0.515244
G1 X140.179 Y95.559 E.00435
;WIDTH:0.476829
G1 X140.101 Y95.671 E.00402
;WIDTH:0.438414
G1 X140.024 Y95.783 E.00365
;WIDTH:0.399999
G1 X139.887 Y95.951 E.00527
G1 X139.647 Y96.121 E.00715
G1 X139.202 Y96.246 E.01124
G1 X137.066 Y96.246 E.05196
G1 X137.063 Y132.81 E.88938
G1 X136.995 Y133.817 E.02455
G1 X136.831 Y134.812 E.02453
G1 X136.607 Y135.677 E.02173
G1 X136.257 Y136.653 E.02522
G1 X135.821 Y137.573 E.02476
G1 X135.345 Y138.377 E.02273
G1 X134.734 Y139.22 E.02532
G1 X134.051 Y139.988 E.025
G1 X132.966 Y140.954 E.03534
G1 X132.197 Y141.497 E.0229
G1 X131.286 Y142.019 E.02554
G1 X129.909 Y142.599 E.03634
G1 X129.014 Y142.861 E.02268
G1 X127.97 Y143.062 E.02586
G1 X126.918 Y143.156 E.02569
G1 X120.483 Y143.166 E.15653
G1 X120.406 Y143.16 E.00188
G1 X120.349 Y143.095 E.0021
G1 X110.651 Y143.095 E.23589
G1 X110.594 Y143.16 E.0021
G1 X110.517 Y143.166 E.00188
G1 X104.5 Y143.166 E.14636
G1 X103.814 Y143.141 E.0167
G1 X102.577 Y142.988 E.03032
G1 X101.972 Y142.858 E.01505
G1 X101.15 Y142.62 E.02082
G1 X100.162 Y142.234 E.0258
G1 X99.323 Y141.81 E.02287
G1 X98.435 Y141.25 E.02554
G1 X97.337 Y140.365 E.0343
G1 X96.93 Y139.971 E.01378
G1 X96.299 Y139.261 E.0231
G1 X95.648 Y138.366 E.02692
G1 X94.984 Y137.187 E.03291
G1 X94.578 Y136.23 E.02529
G1 X94.276 Y135.263 E.02464
G1 X94.012 Y133.87 E.03449
G1 X93.938 Y132.848 E.02492
G1 X93.934 Y96.246 E.89031
G1 X91.798 Y96.246 E.05196
G1 X91.496 Y96.19 E.00747
G1 X91.235 Y96.045 E.00726
G1 X91.015 Y95.825 E.00757
;WIDTH:0.439255
G1 X90.928 Y95.703 E.00404
;WIDTH:0.478511
G1 X90.84 Y95.58 E.00447
;WIDTH:0.517767
G1 X90.753 Y95.458 E.00482
;WIDTH:0.557023
G1 X90.665 Y95.335 E.00526
G1 X90.659 Y95.227 E.00376
;WIDTH:0.550466
G1 X90.659 Y93.602 E.05579
G1 X90.737 Y93.464 E.00544
;WIDTH:0.51285
G1 X90.815 Y93.327 E.00502
;WIDTH:0.475233
G1 X90.894 Y93.189 E.00466
;WIDTH:0.437616
G1 X90.972 Y93.051 E.00425
;WIDTH:0.399999
G1 X91.094 Y92.897 E.00478
G1 X91.326 Y92.726 E.00701
G1 X91.798 Y92.583 E.012
G1 X103.822 Y92.583 E.29247
G1 X104.634 Y92.583 E.01975
G1 X104.634 Y91.549 E.02515
G1 X104.356 Y91.017 E.0146
G1 X104.273 Y90.61 E.0101
G1 X104.273 Y90.39 E.00535
G1 X104.381 Y89.897 E.01228
G1 X104.634 Y89.451 E.01247
G1 X104.634 Y88.683 E.01868
G1 X104.732 Y88.37 E.00798
G1 X104.822 Y88.27 E.00327
G1 X105.088 Y88.143 E.00717
G1 X125.817 Y88.134 E.50421
G1 X126.134 Y88.267 E.00836
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X126.189 Y88.29 E-.02832
G1 X126.208 Y88.298 E-.00979
G1 X126.35 Y88.553 E-.13864
G1 X126.366 Y89.451 E-.42662
G1 X126.617 Y89.892 E-.24103
G1 X126.727 Y90.39 E-.24225
G1 X126.727 Y90.61 E-.1045
G1 X126.579 Y91.185 E-.28203
G1 X126.55 Y91.234 E-.02682
;WIPE_END
G1 X126.543 Y91.231 F9000
G1 X126.602 Y91.103
G1 X126.668 Y90.905
G1 X126.709 Y90.703
G1 X126.723 Y90.5
G1 X126.709 Y90.297
G1 X126.349 Y88.151
G1 X122.784 Y88.151
G1 X120.371 Y86.599
G1 X120.371 Y86.177
G1 E5 F2400
G1 F6000
G1 X120.342 Y86.131 E.00132
G1 X110.658 Y86.131 E.23555
G1 X110.549 Y86.247 E.00387
G1 X110.517 Y86.25 E.00078
G1 X104.2 Y86.25 E.15365
G1 X103.844 Y86.233 E.00867
G1 X102.993 Y86.072 E.02107
G1 X102.459 Y85.867 E.01391
G1 X101.844 Y85.526 E.0171
G1 X101.355 Y85.139 E.01517
G1 X100.93 Y84.685 E.01513
G1 X100.576 Y84.172 E.01516
G1 X100.292 Y83.587 E.01582
G1 X100.05 Y82.69 E.0226
G1 X100.001 Y82.064 E.01527
G1 X100 Y78.449 E.08793
G1 X99.736 Y78 E.01267
G1 X99.627 Y77.504 E.01235
G1 X99.736 Y77 E.01254
G1 X100 Y76.551 E.01267
G1 X100.018 Y76.072 E.01166
G1 X100.151 Y75.97 E.00408
G1 X100.183 Y75.967 E.00078
G1 X130.817 Y75.967 E.74514
G1 X130.922 Y76 E.00268
G1 X131 Y76.15 E.00411
G1 X131 Y76.551 E.00975
G1 X131.264 Y77 E.01267
G1 X131.373 Y77.503 E.01252
G1 X131.264 Y78 E.01238
G1 X131 Y78.45 E.01269
G1 X130.996 Y79.712 E.0307
G1 X130.989 Y82.348 E.06412
G1 X130.899 Y82.964 E.01514
G1 X130.709 Y83.585 E.0158
G1 X130.297 Y84.365 E.02146
G1 X129.669 Y85.116 E.02381
G1 X128.897 Y85.687 E.02336
G1 X128.356 Y85.951 E.01464
G1 X127.44 Y86.2 E.02309
G1 X126.814 Y86.249 E.01527
G1 X120.483 Y86.25 E.154
G1 X120.408 Y86.234 E.00187
G1 X120.404 Y86.228 E.00018
G1 X120.404 Y86.228 F9000
G1 X120.124 Y86.497
;TYPE:Perimeter
G1 F6000
G1 X110.787 Y86.497 E.22711
G1 X110.741 Y86.568 E.00206
G1 X110.517 Y86.616 E.00557
G1 X104.2 Y86.616 E.15365
G1 X103.775 Y86.593 E.01035
G1 X102.925 Y86.431 E.02105
G1 X102.326 Y86.208 E.01555
G1 X101.662 Y85.843 E.01843
G1 X101.127 Y85.425 E.01651
G1 X100.662 Y84.934 E.01645
G1 X100.274 Y84.378 E.01649
G1 X99.963 Y83.746 E.01713
G1 X99.697 Y82.784 E.02428
G1 X99.634 Y82.051 E.0179
G1 X99.634 Y78.549 E.08518
G1 X99.375 Y78.086 E.0129
G1 X99.262 Y77.511 E.01425
G1 X99.356 Y76.983 E.01305
G1 X99.634 Y76.451 E.0146
G1 X99.635 Y76.122 E.008
G1 X99.687 Y75.915 E.00519
G1 X99.867 Y75.701 E.0068
G1 X100.183 Y75.601 E.00806
G1 X130.817 Y75.601 E.74514
G1 X131.133 Y75.701 E.00806
G1 X131.313 Y75.915 E.0068
G1 X131.366 Y76.15 E.00586
G1 X131.366 Y76.451 E.00732
G1 X131.644 Y76.983 E.0146
G1 X131.738 Y77.508 E.01297
G1 X131.644 Y78.017 E.01259
G1 X131.365 Y78.55 E.01463
G1 X131.362 Y79.713 E.02829
G1 X131.355 Y82.349 E.06412
G1 X131.26 Y83.018 E.01644
G1 X131.058 Y83.693 E.01714
G1 X130.62 Y84.537 E.02313
G1 X129.946 Y85.355 E.02578
G1 X129.113 Y85.982 E.02536
G1 X128.514 Y86.28 E.01627
G1 X127.534 Y86.553 E.02475
G1 X126.841 Y86.614 E.01692
G1 X120.483 Y86.616 E.15465
G1 X120.259 Y86.568 E.00557
G1 X120.213 Y86.497 E.00206
G1 X120.184 Y86.497 E.00071
G1 X120.184 Y86.497 F9000
G1 X119.855 Y86.863
G1 F6000
G1 X110.915 Y86.863 E.21746
G1 X110.89 Y86.902 E.00113
G1 X110.517 Y86.981 E.00927
G1 X104.2 Y86.981 E.15365
G1 X103.707 Y86.952 E.01201
G1 X102.857 Y86.79 E.02105
G1 X102.194 Y86.549 E.01716
G1 X101.48 Y86.16 E.01978
G1 X100.899 Y85.711 E.01786
G1 X100.395 Y85.183 E.01775
G1 X99.973 Y84.585 E.0178
G1 X99.633 Y83.904 E.01851
G1 X99.344 Y82.878 E.02593
G1 X99.271 Y82.119 E.01855
G1 X99.269 Y78.648 E.08443
G1 X99.029 Y78.206 E.01223
G1 X98.914 Y77.684 E.013
G1 X98.914 Y77.316 E.00895
G1 X98.998 Y76.909 E.01011
G1 X99.166 Y76.526 E.01017
G1 X99.269 Y76.352 E.00492
G1 X99.27 Y76.103 E.00606
G1 X99.356 Y75.759 E.00862
G1 X99.657 Y75.402 E.01136
G1 X100.027 Y75.263 E.00961
;WIDTH:0.372535
G1 X100.183 Y75.253 E.00352
;WIDTH:0.368101
G1 X130.817 Y75.252 E.68014
;WIDTH:0.399999
G1 X131.343 Y75.402 E.0133
G1 X131.643 Y75.759 E.01134
G1 X131.731 Y76.15 E.00975
G1 X131.731 Y76.352 E.00491
G1 X131.895 Y76.629 E.00783
G1 X132.002 Y76.909 E.00729
G1 X132.104 Y77.513 E.0149
G1 X132.009 Y78.058 E.01346
G1 X131.895 Y78.371 E.0081
G1 X131.731 Y78.65 E.00787
G1 X131.728 Y79.714 E.02588
G1 X131.72 Y82.35 E.06412
G1 X131.622 Y83.072 E.01772
G1 X131.407 Y83.802 E.01851
G1 X130.943 Y84.709 E.02478
G1 X130.805 Y84.918 E.00609
G1 X130.223 Y85.593 E.02168
G1 X129.329 Y86.277 E.02738
G1 X128.672 Y86.61 E.01792
G1 X127.629 Y86.906 E.02637
G1 X126.868 Y86.979 E.0186
G1 X120.483 Y86.981 E.15531
G1 X120.11 Y86.902 E.00927
G1 X120.085 Y86.863 E.00113
G1 X119.915 Y86.863 E.00414
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X119.855 Y86.863 E-.0285
G1 X116.757 Y86.863 E-1.4715
;WIPE_END
G1 X119.915 Y74.205 F9000
G1 E5 F2400
G1 F6000
G1 X135.541 Y74.201 E.38009
G1 X136.199 Y74.243 E.01604
G1 X136.888 Y74.369 E.01704
G1 X137.557 Y74.577 E.01704
G1 X138.195 Y74.865 E.01703
G1 X138.792 Y75.226 E.01697
G1 X139.601 Y75.9 E.02561
G1 X140.273 Y76.706 E.02553
G1 X140.788 Y77.62 E.02552
G1 X141.131 Y78.612 E.02553
G1 X141.289 Y79.653 E.02561
G1 X141.289 Y80.042 E.00946
G1 X141.3 Y150.994 E1.72584
G1 X141.258 Y151.698 E.01715
G1 X141.132 Y152.385 E.01699
G1 X140.924 Y153.053 E.01702
G1 X140.638 Y153.69 E.01698
G1 X140.277 Y154.289 E.01701
G1 X139.847 Y154.84 E.017
G1 X139.353 Y155.334 E.01699
G1 X138.783 Y155.781 E.01762
G1 X138.186 Y156.14 E.01694
G1 X137.245 Y156.53 E.02478
G1 X136.531 Y156.707 E.01789
G1 X135.845 Y156.789 E.01681
G1 X95.482 Y156.8 E.98179
G1 X94.792 Y156.756 E.01682
G1 X94.102 Y156.629 E.01707
G1 X93.448 Y156.425 E.01666
G1 X92.816 Y156.141 E.01685
G1 X92.196 Y155.766 E.01762
G1 X91.647 Y155.335 E.01698
G1 X91.153 Y154.84 E.01701
G1 X90.723 Y154.289 E.017
G1 X90.363 Y153.692 E.01696
G1 X89.969 Y152.743 E.02499
G1 X89.795 Y152.043 E.01754
G1 X89.711 Y151.349 E.017
G1 X89.7 Y80.006 E1.73535
G1 X89.743 Y79.301 E.01718
G1 X89.869 Y78.612 E.01704
G1 X90.077 Y77.943 E.01704
G1 X90.365 Y77.305 E.01703
G1 X90.727 Y76.705 E.01704
G1 X91.159 Y76.154 E.01703
G1 X91.654 Y75.659 E.01703
G1 X92.205 Y75.227 E.01703
G1 X92.805 Y74.865 E.01704
G1 X93.441 Y74.578 E.01697
G1 X94.412 Y74.305 E.02453
G1 X95.15 Y74.211 E.0181
G1 X119.855 Y74.205 E.60092
G1 X119.855 Y74.205 F9000
G1 X119.855 Y74.571
;TYPE:Perimeter
G1 F6000
G1 X135.529 Y74.567 E.38125
G1 X136.154 Y74.606 E.01523
G1 X136.8 Y74.725 E.01598
G1 X137.427 Y74.92 E.01597
G1 X138.025 Y75.189 E.01595
G1 X138.58 Y75.524 E.01577
G1 X139.341 Y76.159 E.02411
G1 X139.971 Y76.914 E.02392
G1 X140.454 Y77.771 E.02393
G1 X140.774 Y78.7 E.0239
G1 X140.923 Y79.68 E.02411
G1 X140.923 Y80.042 E.00881
G1 X140.925 Y93.02 E.31568
;WIDTH:0.448959
G1 X140.901 Y93.214 E.00539
;WIDTH:0.497919
G1 X140.877 Y93.408 E.00603
;WIDTH:0.546878
G1 X140.852 Y93.602 E.00667
;WIDTH:0.547002
G1 X140.852 Y95.226 E.05538
G1 X140.877 Y95.42 E.00667
;WIDTH:0.498001
G1 X140.901 Y95.614 E.00603
;WIDTH:0.449
G1 X140.926 Y95.809 E.00542
;WIDTH:0.399999
G1 X140.934 Y150.983 E1.34205
G1 X140.894 Y151.654 E.01635
G1 X140.776 Y152.298 E.01593
G1 X140.582 Y152.923 E.01592
G1 X140.313 Y153.52 E.01593
G1 X139.975 Y154.081 E.01593
G1 X139.572 Y154.597 E.01593
G1 X139.11 Y155.06 E.01591
G1 X138.575 Y155.479 E.01653
G1 X138.021 Y155.812 E.01572
G1 X137.13 Y156.182 E.02347
G1 X136.465 Y156.347 E.01667
G1 X135.823 Y156.424 E.01573
G1 X95.493 Y156.434 E.98099
G1 X94.836 Y156.393 E.01601
G1 X94.19 Y156.273 E.01598
G1 X93.578 Y156.082 E.01559
G1 X92.986 Y155.817 E.01578
G1 X92.405 Y155.465 E.01652
G1 X91.89 Y155.061 E.01592
G1 X91.428 Y154.597 E.01593
G1 X91.025 Y154.081 E.01593
G1 X90.691 Y153.527 E.01574
G1 X90.318 Y152.629 E.02365
G1 X90.155 Y151.977 E.01635
G1 X90.077 Y151.327 E.01592
G1 X90.068 Y95.81 E1.3504
;WIDTH:0.437585
G1 X90.087 Y95.664 E.00395
;WIDTH:0.475171
G1 X90.106 Y95.519 E.00429
;WIDTH:0.512757
G1 X90.124 Y95.373 E.00468
;WIDTH:0.550342
G1 X90.143 Y95.227 E.00505
;WIDTH:0.550466
G1 X90.143 Y93.602 E.05579
G1 X90.124 Y93.456 E.00505
;WIDTH:0.51285
G1 X90.105 Y93.31 E.00469
;WIDTH:0.475233
G1 X90.086 Y93.164 E.00432
;WIDTH:0.437616
G1 X90.068 Y93.018 E.00395
;WIDTH:0.399999
G1 X90.066 Y80.017 E.31624
G1 X90.106 Y79.345 E.01637
G1 X90.225 Y78.7 E.01595
G1 X90.42 Y78.073 E.01597
G1 X90.689 Y77.475 E.01595
G1 X91.028 Y76.914 E.01594
G1 X91.433 Y76.397 E.01597
G1 X91.897 Y75.933 E.01596
G1 X92.414 Y75.528 E.01597
G1 X92.975 Y75.189 E.01594
G1 X93.567 Y74.923 E.01579
G1 X94.485 Y74.664 E.0232
G1 X95.173 Y74.577 E.01687
G1 X119.795 Y74.571 E.59891
G1 E-5 F3600
G1 X119.795 Y74.571 F9000
G1 X119.795 Y74.549
G1 X139.559 Y76.363
G1 X140.951 Y80.008
G1 X140.951 Y95.519
G1 X140.56 Y95.519
G1 E5 F2400
G1 F6000
G1 X140.569 Y150.972 E1.34884
G1 X140.53 Y151.61 E.01555
G1 X140.42 Y152.21 E.01484
G1 X140.239 Y152.793 E.01485
G1 X139.989 Y153.35 E.01485
G1 X139.673 Y153.873 E.01486
G1 X139.297 Y154.354 E.01485
G1 X138.867 Y154.786 E.01483
G1 X138.367 Y155.177 E.01544
G1 X137.856 Y155.485 E.01451
G1 X137.016 Y155.833 E.02212
G1 X136.399 Y155.986 E.01546
G1 X135.802 Y156.058 E.01463
G1 X95.505 Y156.068 E.98018
G1 X94.881 Y156.029 E.01521
G1 X94.278 Y155.917 E.01492
G1 X93.708 Y155.739 E.01452
G1 X93.156 Y155.492 E.01471
G1 X92.613 Y155.164 E.01543
G1 X92.134 Y154.787 E.01483
G1 X91.703 Y154.354 E.01486
G1 X91.327 Y153.873 E.01485
G1 X91.018 Y153.361 E.01455
G1 X90.666 Y152.514 E.02231
G1 X90.516 Y151.91 E.01514
G1 X90.442 Y151.305 E.01483
G1 X90.434 Y95.504 E1.3573
G1 X90.549 Y95.772 E.00709
G1 X90.757 Y96.085 E.00914
G1 X90.978 Y96.304 E.00757
G1 X91.412 Y96.546 E.01209
G1 X91.798 Y96.612 E.00953
G1 X93.569 Y96.612 E.04308
G1 X93.571 Y132.81 E.88048
G1 X93.653 Y133.937 E.02749
G1 X93.927 Y135.371 E.03551
G1 X94.241 Y136.371 E.02549
G1 X94.665 Y137.367 E.02633
G1 X95.387 Y138.635 E.03549
G1 X96.025 Y139.503 E.0262
G1 X96.675 Y140.232 E.02376
G1 X97.106 Y140.649 E.01459
G1 X98.152 Y141.497 E.03275
G1 X99.157 Y142.136 E.02897
G1 X100.027 Y142.573 E.02368
G1 X101.047 Y142.971 E.02663
G1 X101.894 Y143.215 E.02144
G1 X102.533 Y143.351 E.01589
G1 X103.769 Y143.504 E.03029
G1 X104.5 Y143.532 E.01779
G1 X110.517 Y143.532 E.14636
G1 X110.645 Y143.523 E.00312
G1 X110.699 Y143.46 E.00202
G1 X120.301 Y143.46 E.23356
G1 X120.355 Y143.523 E.00202
G1 X120.483 Y143.532 E.00312
G1 X126.871 Y143.524 E.15538
G1 X128.039 Y143.421 E.02852
G1 X129.084 Y143.22 E.02588
G1 X130.05 Y142.937 E.02448
G1 X131.467 Y142.337 E.03743
G1 X132.407 Y141.797 E.02637
G1 X133.209 Y141.227 E.02393
G1 X134.294 Y140.261 E.03534
G1 X135.029 Y139.436 E.02688
G1 X135.66 Y138.564 E.02618
G1 X136.152 Y137.73 E.02355
G1 X136.601 Y136.778 E.0256
G1 X136.961 Y135.769 E.02606
G1 X137.193 Y134.865 E.0227
G1 X137.365 Y133.789 E.0265
G1 X137.429 Y132.81 E.02386
G1 X137.431 Y96.612 E.88048
G1 X138.996 Y96.612 E.03807
G1 X139.511 Y96.558 E.0126
G1 X139.771 Y96.465 E.00672
G1 X140.171 Y96.182 E.01192
G1 X140.307 Y96.014 E.00526
G1 X140.533 Y95.572 E.01208
G1 X140.533 Y95.572 F9000
G1 X140.195 Y96.596
G1 F6000
G1 X140.203 Y150.961 E1.32237
G1 X140.167 Y151.565 E.01472
G1 X140.065 Y152.123 E.0138
G1 X139.896 Y152.664 E.01379
G1 X139.664 Y153.18 E.01376
G1 X139.372 Y153.666 E.01379
G1 X139.023 Y154.112 E.01378
G1 X138.624 Y154.512 E.01374
G1 X138.16 Y154.875 E.01433
G1 X137.69 Y155.158 E.01334
G1 X136.901 Y155.485 E.02077
G1 X136.333 Y155.626 E.01424
G1 X135.78 Y155.692 E.01355
G1 X95.516 Y155.703 E.97938
G1 X94.926 Y155.665 E.01438
G1 X94.366 Y155.562 E.01385
G1 X93.837 Y155.397 E.01348
G1 X93.326 Y155.168 E.01362
G1 X92.821 Y154.862 E.01436
G1 X92.377 Y154.513 E.01374
G1 X91.977 Y154.112 E.01378
G1 X91.628 Y153.666 E.01378
G1 X91.345 Y153.196 E.01334
G1 X91.014 Y152.399 E.02099
G1 X90.876 Y151.844 E.01391
G1 X90.808 Y151.283 E.01375
G1 X90.8 Y96.608 E1.32991
G1 X91.328 Y96.901 E.01469
G1 X91.798 Y96.977 E.01158
G1 X93.203 Y96.977 E.03418
G1 X93.208 Y132.899 E.87377
G1 X93.293 Y134.005 E.02698
G1 X93.578 Y135.479 E.03652
G1 X93.904 Y136.512 E.02635
G1 X94.347 Y137.547 E.02738
G1 X95.011 Y138.725 E.03289
G1 X95.752 Y139.746 E.03069
G1 X96.419 Y140.494 E.02438
G1 X96.876 Y140.933 E.01541
G1 X98.043 Y141.868 E.03637
G1 X98.992 Y142.462 E.02723
G1 X99.892 Y142.913 E.02449
G1 X100.945 Y143.322 E.02748
G1 X101.815 Y143.572 E.02202
G1 X102.488 Y143.714 E.01673
G1 X103.724 Y143.867 E.03029
G1 X104.5 Y143.897 E.01889
G1 X110.517 Y143.897 E.14636
G1 X110.696 Y143.885 E.00436
G1 X110.747 Y143.826 E.0019
G1 X120.253 Y143.826 E.23122
G1 X120.304 Y143.885 E.0019
G1 X120.483 Y143.897 E.00436
G1 X126.981 Y143.885 E.15806
G1 X128.108 Y143.78 E.02753
G1 X129.153 Y143.579 E.02588
G1 X130.191 Y143.274 E.02632
G1 X131.005 Y142.933 E.02147
G1 X131.648 Y142.654 E.01705
G1 X132.616 Y142.096 E.02718
G1 X133.453 Y141.5 E.02499
G1 X134.644 Y140.428 E.03898
G1 X135.325 Y139.651 E.02513
G1 X135.974 Y138.751 E.02699
G1 X136.482 Y137.887 E.02438
G1 X136.944 Y136.902 E.02646
G1 X137.314 Y135.862 E.02685
G1 X137.553 Y134.925 E.02352
G1 X137.73 Y133.813 E.02739
G1 X137.795 Y132.81 E.02445
G1 X137.797 Y96.977 E.8716
G1 X138.996 Y96.977 E.02916
G1 X139.635 Y96.902 E.01565
G1 X139.894 Y96.809 E.00669
G1 X140.146 Y96.631 E.0075
G1 X140.146 Y96.631 F9000
G1 X139.829 Y97.221
G1 F6000
G1 X139.837 Y150.814 E1.3036
G1 X139.818 Y151.262 E.01091
G1 X139.756 Y151.78 E.01269
G1 X139.631 Y152.287 E.0127
G1 X139.445 Y152.775 E.0127
G1 X139.203 Y153.238 E.01271
G1 X138.905 Y153.669 E.01275
G1 X138.561 Y154.057 E.01261
G1 X138.129 Y154.435 E.01396
G1 X137.525 Y154.83 E.01755
G1 X136.786 Y155.137 E.01946
G1 X136.267 Y155.266 E.01301
G1 X135.758 Y155.327 E.01247
G1 X95.67 Y155.337 E.9751
G1 X95.229 Y155.318 E.01074
G1 X94.706 Y155.253 E.01282
G1 X94.211 Y155.13 E.01241
G1 X93.734 Y154.95 E.0124
G1 X93.252 Y154.695 E.01326
G1 X92.82 Y154.396 E.01278
G1 X92.426 Y154.044 E.01285
G1 X92.067 Y153.634 E.01326
G1 X91.672 Y153.03 E.01755
G1 X91.362 Y152.284 E.01965
G1 X91.236 Y151.777 E.01271
G1 X91.174 Y151.261 E.01264
G1 X91.165 Y97.214 E1.31464
G1 X91.244 Y97.257 E.00219
G1 X91.798 Y97.343 E.01364
G1 X92.837 Y97.343 E.02527
G1 X92.84 Y132.81 E.8627
G1 X92.934 Y134.072 E.03078
G1 X93.228 Y135.587 E.03754
G1 X93.566 Y136.654 E.02722
G1 X94.028 Y137.726 E.02839
G1 X94.796 Y139.065 E.03755
G1 X95.478 Y139.989 E.02793
G1 X96.163 Y140.755 E.025
G1 X96.646 Y141.217 E.01626
G1 X97.692 Y142.065 E.03275
G1 X98.826 Y142.788 E.03271
G1 X99.756 Y143.253 E.02529
G1 X100.843 Y143.673 E.02835
G1 X101.737 Y143.93 E.02263
G1 X102.443 Y144.077 E.01754
G1 X103.679 Y144.23 E.03029
G1 X104.5 Y144.263 E.01999
G1 X110.517 Y144.263 E.14636
G1 X110.748 Y144.247 E.00563
G1 X110.795 Y144.192 E.00176
G1 X120.205 Y144.192 E.22889
G1 X120.252 Y144.247 E.00176
G1 X120.483 Y144.263 E.00563
G1 X126.872 Y144.255 E.15541
G1 X128.177 Y144.139 E.03187
G1 X129.37 Y143.902 E.02959
G1 X130.332 Y143.611 E.02445
G1 X131.829 Y142.972 E.03959
G1 X132.826 Y142.396 E.02801
G1 X133.696 Y141.773 E.02603
G1 X134.78 Y140.808 E.0353
G1 X135.62 Y139.866 E.0307
G1 X136.288 Y138.938 E.02781
G1 X136.812 Y138.045 E.02518
G1 X137.288 Y137.026 E.02736
G1 X137.668 Y135.954 E.02767
G1 X137.914 Y134.984 E.02434
G1 X138.095 Y133.838 E.02822
G1 X138.16 Y132.81 E.02506
G1 X138.163 Y97.343 E.8627
G1 X139.202 Y97.343 E.02527
G1 X139.77 Y97.232 E.01408
G1 E-5 F3600
G1 X139.77 Y97.232 F9000
G1 X140.249 Y95.726
G1 X140.249 Y93.071
G1 X139.61 Y92.691
G1 X139.422 Y92.624
G1 X139.304 Y92.606
G1 X139.224 Y92.6
G1 X138.594 Y92.599
G1 X134.11 Y74.549
G1 X134.11 Y74.933
G1 E5 F2400
G1 F6000
G1 X135.518 Y74.933 E.03425
G1 X136.11 Y74.97 E.01443
G1 X136.713 Y75.08 E.01491
G1 X137.297 Y75.262 E.01488
G1 X137.855 Y75.513 E.01488
G1 X138.367 Y75.823 E.01456
G1 X139.082 Y76.419 E.02264
G1 X139.668 Y77.123 E.02228
G1 X140.119 Y77.921 E.0223
G1 X140.418 Y78.788 E.02231
G1 X140.558 Y79.708 E.02264
G1 X140.558 Y80.042 E.00812
G1 X140.56 Y93.385 E.32456
G1 X140.451 Y93.056 E.00843
G1 X140.244 Y92.744 E.00911
G1 X140.024 Y92.525 E.00755
G1 X139.589 Y92.283 E.01211
G1 X139.202 Y92.217 E.00955
G1 X126.731 Y92.217 E.30334
G1 X126.731 Y91.648 E.01384
G1 X127.002 Y91.091 E.01507
G1 X127.086 Y90.684 E.01011
G1 X127.086 Y90.316 E.00895
G1 X126.984 Y89.835 E.01196
G1 X126.731 Y89.352 E.01326
G1 X126.731 Y88.683 E.01627
G1 X126.649 Y88.304 E.00943
G1 X126.419 Y87.995 E.00937
G1 X125.817 Y87.769 E.01564
G1 X105.183 Y87.769 E.5019
G1 X105.025 Y87.782 E.00386
G1 X104.581 Y87.995 E.01198
G1 X104.364 Y88.276 E.00864
G1 X104.269 Y88.683 E.01017
G1 X104.269 Y89.352 E.01627
G1 X104.039 Y89.767 E.01154
G1 X103.914 Y90.316 E.0137
G1 X103.914 Y90.684 E.00895
G1 X103.998 Y91.091 E.01011
G1 X104.105 Y91.371 E.00729
G1 X104.269 Y91.648 E.00783
G1 X104.269 Y92.217 E.01384
G1 X91.798 Y92.217 E.30334
G1 X91.467 Y92.279 E.00819
G1 X91.193 Y92.385 E.00715
G1 X90.808 Y92.67 E.01165
G1 X90.557 Y93.043 E.01094
G1 X90.433 Y93.406 E.00933
G1 X90.431 Y80.028 E.32541
G1 X90.47 Y79.389 E.01557
G1 X90.58 Y78.787 E.01489
G1 X90.762 Y78.203 E.01488
G1 X91.013 Y77.645 E.01488
G1 X91.33 Y77.122 E.01488
G1 X91.707 Y76.64 E.01488
G1 X92.14 Y76.207 E.01489
G1 X92.622 Y75.83 E.01488
G1 X93.145 Y75.513 E.01488
G1 X93.692 Y75.267 E.01459
G1 X94.558 Y75.023 E.02188
G1 X95.196 Y74.942 E.01564
G1 X99.511 Y74.941 E.10496
G1 X100.183 Y74.923 E.01635
;WIDTH:0.368101
G1 X130.817 Y74.918 E.68014
;WIDTH:0.399999
G1 X131.491 Y74.934 E.0164
G1 X134.05 Y74.933 E.06225
G1 E-5 F3600
G1 X134.05 Y74.933 F9000
G1 X134.05 Y74.549
G1 X131.138 Y83.418
G1 X131.041 Y83.693
G1 X131.024 Y83.736
G1 X130.908 Y84.004
G1 X130.887 Y84.045
G1 X130.751 Y84.303
G1 X130.728 Y84.343
G1 X130.574 Y84.588
G1 X130.548 Y84.627
G1 X130.376 Y84.86
G1 X130.348 Y84.896
G1 X130.159 Y85.116
G1 X130.128 Y85.15
G1 X129.923 Y85.356
G1 X129.891 Y85.388
G1 X129.671 Y85.577
G1 X129.637 Y85.606
G1 X129.6 Y85.633
G1 X129.367 Y85.805
G1 X129.328 Y85.83
G1 X129.083 Y85.985
G1 X129.042 Y86.007
G1 X128.785 Y86.143
G1 X128.743 Y86.162
G1 X128.478 Y86.278
G1 X128.436 Y86.294
G1 X128.163 Y86.39
G1 X128.119 Y86.403
G1 X127.84 Y86.478
G1 X127.795 Y86.488
G1 X127.511 Y86.542
G1 X127.466 Y86.55
G1 X127.179 Y86.582
G1 X127.133 Y86.587
G1 X126.844 Y86.597
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X105.183 Y87.375 E.0067
;WIDTH:0.456022
G1 X110.517 Y87.375 E.14962
;WIDTH:0.495578
G1 X110.703 Y87.355 E.00574
;WIDTH:0.535136
G1 X110.889 Y87.335 E.00623
;WIDTH:0.574694
G1 X111.074 Y87.316 E.00668
G1 X119.926 Y87.316 E.31818
G1 X120.111 Y87.335 E.00668
;WIDTH:0.535134
G1 X120.297 Y87.355 E.00623
;WIDTH:0.495576
G1 X120.483 Y87.375 E.00574
;WIDTH:0.456022
G1 X125.817 Y87.375 E.14962
G1 E-5 F3600
G1 X125.817 Y87.375 F9000
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X104.628 Y87.57 E.01103
;WIDTH:0.43792
G1 X104.3 Y87.756 E.01012
;WIDTH:0.399999
G1 X104.037 Y88.113 E.01079
G1 X103.903 Y88.683 E.01424
G1 X103.903 Y89.252 E.01384
G1 X103.698 Y89.637 E.01061
G1 X103.556 Y90.243 E.01514
G1 X103.556 Y90.757 E.0125
G1 X103.64 Y91.164 E.01011
G1 X103.892 Y91.729 E.01505
G1 X103.903 Y91.851 E.00298
G1 X91.798 Y91.851 E.29444
G1 X91.335 Y91.938 E.01146
G1 X91.061 Y92.044 E.00715
G1 X90.799 Y92.238 E.00793
G1 X90.797 Y80.039 E.29673
G1 X90.834 Y79.433 E.01477
G1 X90.936 Y78.875 E.0138
G1 X91.105 Y78.333 E.01381
G1 X91.338 Y77.816 E.01379
G1 X91.631 Y77.33 E.0138
G1 X91.982 Y76.883 E.01382
G1 X92.383 Y76.482 E.01379
G1 X92.83 Y76.131 E.01382
G1 X93.315 Y75.838 E.01378
G1 X93.817 Y75.612 E.01339
G1 X94.631 Y75.383 E.02057
G1 X95.22 Y75.308 E.01444
G1 X99.275 Y75.307 E.09863
G1 X99.026 Y75.603 E.00941
G1 X98.905 Y76.084 E.01206
G1 X98.903 Y76.252 E.00409
G1 X98.64 Y76.836 E.01558
G1 X98.53 Y77.526 E.017
G1 X98.556 Y77.757 E.00565
G1 X98.674 Y78.297 E.01344
G1 X98.903 Y78.748 E.0123
G1 X98.907 Y82.146 E.08265
G1 X98.99 Y82.972 E.02019
G1 X99.304 Y84.063 E.02761
G1 X99.671 Y84.792 E.01985
G1 X100.127 Y85.432 E.01911
G1 X100.671 Y85.997 E.01908
G1 X101.298 Y86.477 E.01921
G1 X102.062 Y86.89 E.02113
G1 X102.789 Y87.149 E.01877
G1 X103.639 Y87.311 E.02105
G1 X104.2 Y87.347 E.01367
;WIDTH:0.43792
G1 X104.577 Y87.366 E.01013
;WIDTH:0.47584
G1 X104.895 Y87.382 E.00935
G1 X104.895 Y87.382 F9000
G1 X103.869 Y87.7
;WIDTH:0.399999
G1 F6000
G1 X103.709 Y87.95 E.00722
G1 X103.541 Y88.571 E.01565
G1 X103.537 Y89.153 E.01416
G1 X103.356 Y89.507 E.00967
G1 X103.198 Y90.17 E.01658
G1 X103.198 Y90.83 E.01605
G1 X103.281 Y91.238 E.01013
G1 X103.377 Y91.486 E.00647
G1 X91.798 Y91.486 E.28165
G1 X91.164 Y91.612 E.01572
G1 X91.163 Y80.05 E.28123
G1 X91.197 Y79.478 E.01394
G1 X91.292 Y78.963 E.01274
G1 X91.447 Y78.463 E.01273
G1 X91.662 Y77.986 E.01273
G1 X91.933 Y77.538 E.01274
G1 X92.256 Y77.126 E.01273
G1 X92.626 Y76.756 E.01273
G1 X93.038 Y76.433 E.01273
G1 X93.486 Y76.162 E.01274
G1 X93.943 Y75.957 E.01218
G1 X94.704 Y75.742 E.01924
G1 X95.243 Y75.674 E.01321
G1 X98.638 Y75.673 E.08258
G1 X98.537 Y76.15 E.01186
G1 X98.475 Y76.259 E.00305
G1 X98.281 Y76.762 E.01311
G1 X98.165 Y77.534 E.01899
G1 X98.198 Y77.83 E.00724
G1 X98.317 Y78.38 E.01369
G1 X98.537 Y78.847 E.01256
G1 X98.542 Y82.173 E.0809
G1 X98.637 Y83.066 E.02184
G1 X98.974 Y84.222 E.02929
G1 X99.369 Y84.998 E.02118
G1 X99.859 Y85.681 E.02045
G1 X100.443 Y86.283 E.0204
G1 X101.116 Y86.795 E.02057
G1 X101.929 Y87.231 E.02244
G1 X102.72 Y87.509 E.02039
G1 X103.81 Y87.69 E.02688
G1 E-5 F3600
G1 X103.81 Y87.69 F9000
G1 X125.817 Y87.375
G1 E5 F2400
;WIDTH:0.456022
G1 F6000
G1 X126.356 Y87.359 E.01513
;WIDTH:0.428011
G1 X126.895 Y87.343 E.01412
;WIDTH:0.399999
G1 X127.724 Y87.259 E.02027
G1 X128.309 Y87.102 E.01473
G1 X128.831 Y86.939 E.0133
G1 X129.545 Y86.572 E.01953
G1 X130.5 Y85.832 E.02939
G1 X131.082 Y85.157 E.02168
G1 X131.265 Y84.881 E.00806
G1 X131.756 Y83.91 E.02647
G1 X131.984 Y83.126 E.01986
G1 X132.086 Y82.351 E.01901
G1 X132.096 Y78.75 E.08759
G1 X132.21 Y78.556 E.00547
G1 X132.367 Y78.131 E.01102
G1 X132.47 Y77.518 E.01512
G1 X132.36 Y76.836 E.0168
G1 X132.097 Y76.252 E.01558
G1 X132.097 Y76.15 E.00248
G1 X131.974 Y75.602 E.01366
G1 X131.719 Y75.299 E.00963
G1 X135.507 Y75.298 E.09214
G1 X136.065 Y75.333 E.0136
G1 X136.625 Y75.436 E.01385
G1 X137.167 Y75.605 E.01381
G1 X137.684 Y75.838 E.01379
G1 X138.154 Y76.122 E.01336
G1 X138.822 Y76.678 E.02114
G1 X139.366 Y77.332 E.02069
G1 X139.784 Y78.072 E.02067
G1 X140.061 Y78.876 E.02068
G1 X140.146 Y79.433 E.01371
G1 X140.192 Y80.042 E.01486
G1 X140.194 Y92.217 E.29614
G1 X139.673 Y91.927 E.0145
G1 X139.202 Y91.851 E.0116
G1 X127.097 Y91.851 E.29444
G1 X127.108 Y91.729 E.00298
G1 X127.36 Y91.164 E.01505
G1 X127.444 Y90.757 E.01011
G1 X127.444 Y90.243 E.0125
G1 X127.334 Y89.732 E.01271
G1 X127.097 Y89.252 E.01302
G1 X127.061 Y88.38 E.02123
G1 X126.982 Y88.152 E.00587
G1 X126.66 Y87.72 E.01311
;WIDTH:0.428011
G1 X126.239 Y87.548 E.01191
;WIDTH:0.456022
G1 X125.873 Y87.398 E.0111
G1 X125.873 Y87.398 F9000
G1 X127.104 Y87.695
;WIDTH:0.399999
G1 F6000
G1 X127.819 Y87.612 E.01751
G1 X128.511 Y87.427 E.01742
G1 X128.989 Y87.269 E.01225
G1 X129.762 Y86.867 E.02119
G1 X130.503 Y86.324 E.02235
G1 X130.777 Y86.071 E.00907
G1 X131.359 Y85.396 E.02168
G1 X131.588 Y85.052 E.01005
G1 X132.106 Y84.018 E.02813
G1 X132.345 Y83.18 E.0212
G1 X132.452 Y82.352 E.02031
G1 X132.461 Y78.85 E.08518
G1 X132.661 Y78.448 E.01092
G1 X132.757 Y78.048 E.01001
G1 X132.835 Y77.523 E.01291
G1 X132.719 Y76.762 E.01872
G1 X132.464 Y76.155 E.01601
G1 X132.36 Y75.665 E.01218
G1 X134.721 Y75.664 E.05743
G1 X135.845 Y75.686 E.02735
G1 X136.351 Y75.758 E.01243
G1 X136.849 Y75.889 E.01253
G1 X137.329 Y76.079 E.01256
G1 X137.941 Y76.42 E.01704
G1 X138.562 Y76.938 E.01967
G1 X139.064 Y77.54 E.01907
G1 X139.449 Y78.223 E.01907
G1 X139.705 Y78.964 E.01907
G1 X139.785 Y79.488 E.01289
G1 X139.826 Y80.042 E.01351
G1 X139.828 Y91.611 E.2814
G1 X139.757 Y91.571 E.00198
G1 X139.202 Y91.486 E.01366
G1 X127.623 Y91.486 E.28165
G1 X127.719 Y91.238 E.00647
G1 X127.802 Y90.83 E.01013
G1 X127.802 Y90.17 E.01605
G1 X127.685 Y89.628 E.01349
G1 X127.463 Y89.153 E.01275
G1 X127.463 Y88.794 E.00873
G1 X127.416 Y88.293 E.01224
G1 X127.315 Y88.001 E.00752
G1 X127.138 Y87.744 E.00759
G1 E-5 F3600
G1 X127.138 Y87.744 F9000
G1 X129.671 Y85.577
G1 X129.891 Y85.388
G1 X129.923 Y85.356
G1 X130.128 Y85.15
G1 X130.159 Y85.116
G1 X130.348 Y84.896
G1 X130.376 Y84.86
G1 X130.548 Y84.627
G1 X130.574 Y84.588
G1 X130.728 Y84.343
G1 X130.751 Y84.303
G1 X130.887 Y84.045
G1 X130.908 Y84.004
G1 X131.024 Y83.736
G1 X131.041 Y83.693
G1 X131.138 Y83.418
G1 X131.151 Y83.374
G1 X131.227 Y83.093
G1 X131.238 Y83.049
G1 X132.791 Y75.955
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.4594
G1 F1200
G1 X132.754 Y75.918 E.00148
G1 X132.703 Y75.931 E.00149
G1 X132.689 Y75.983 E.00152
G1 X132.726 Y76.02 E.00148
G1 X132.778 Y76.006 E.00152
;WIDTH:0.399999
G1 X132.865 Y76.403 E.00989
G1 X133.328 Y75.94 E.01593
G1 X133.845 Y75.941 E.01258
G1 X133.003 Y76.783 E.02896
G1 X133.081 Y77.221 E.01082
G1 X134.361 Y75.941 E.04403
G1 X134.877 Y75.942 E.01255
G1 X133.089 Y77.731 E.06152
G1 X133.089 Y77.731 F9000
G1 X132.827 Y78.656
;WIDTH:0.374336
G1 F1200
G1 X132.786 Y78.667 E.00096
G1 X132.767 Y78.596 E.00166
G1 X132.838 Y78.615 E.00166
;WIDTH:0.399999
G1 X132.969 Y78.367 E.00682
G1 X135.394 Y75.943 E.0834
G1 X135.89 Y75.964 E.01208
G1 X132.735 Y79.119 E.10853
G1 X132.733 Y79.638 E.01262
G1 X136.337 Y76.034 E.12398
G1 X136.745 Y76.144 E.01028
G1 X132.732 Y80.156 E.13803
G1 X132.731 Y80.675 E.01262
G1 X137.12 Y76.285 E.151
G1 X137.468 Y76.455 E.00942
G1 X132.729 Y81.193 E.163
G1 X132.728 Y81.712 E.01262
G1 X137.789 Y76.65 E.17411
G1 X138.071 Y76.886 E.00894
G1 X132.726 Y82.23 E.18385
G1 X132.681 Y82.793 E.01374
G1 X138.353 Y77.121 E.19511
G1 X138.591 Y77.4 E.00892
G1 X132.572 Y83.419 E.20705
G1 X132.464 Y83.667 E.00658
;WIDTH:0.374336
G1 X132.393 Y83.648 E.00166
G1 X132.412 Y83.719 E.00166
G1 X132.453 Y83.708 E.00096
G1 X132.453 Y83.708 F9000
G1 X132.195 Y84.458
G1 F1200
G1 X132.154 Y84.469 E.00096
G1 X132.134 Y84.397 E.00169
G1 X132.206 Y84.417 E.00169
;WIDTH:0.399999
G1 X132.339 Y84.169 E.00685
G1 X138.826 Y77.682 E.22315
G1 E-5 F3600
G1 X138.826 Y77.682 F9000
G1 X128.492 Y87.633
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X128.421 Y87.614 E.00166
G1 X128.44 Y87.685 E.00166
G1 X128.481 Y87.674 E.00096
;WIDTH:0.399999
G1 X128.196 Y87.795 E.00753
G1 X127.691 Y88.299 E.01735
G1 X127.737 Y88.771 E.01154
G1 X128.92 Y87.588 E.04069
G1 X128.92 Y87.588 F9000
G1 X129.973 Y87.052
G1 F1200
G1 X127.81 Y89.215 E.07441
G1 E-5 F3600
G1 X127.81 Y89.215 F9000
G1 X130.232 Y86.83
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X130.622 Y86.495 E.01163
G1 X131.582 Y85.49 E.03143
;WIDTH:0.399999
G1 X131.793 Y85.232 E.00811
G1 X139.015 Y78.011 E.24841
G1 X139.2 Y78.342 E.00922
G1 X127.956 Y89.586 E.38679
G1 X128.048 Y90.011 E.01058
G1 X139.333 Y78.727 E.38818
G1 X139.452 Y79.125 E.0101
G1 X128.073 Y90.504 E.39143
G1 X128.073 Y90.504 F9000
G1 X127.927 Y91.325
;WIDTH:0.374336
G1 F1200
G1 X127.886 Y91.336 E.00096
G1 X127.867 Y91.265 E.00166
G1 X127.938 Y91.284 E.00166
;WIDTH:0.399999
G1 X128.033 Y91.061 E.0059
G1 X139.52 Y79.573 E.39516
G1 X139.552 Y80.059 E.01185
G1 X128.399 Y91.211 E.38364
G1 X128.917 Y91.211 E.0126
G1 X139.552 Y80.576 E.36584
G1 X139.552 Y81.093 E.01258
G1 X129.434 Y91.211 E.34805
G1 X129.951 Y91.211 E.01258
G1 X139.552 Y81.61 E.33027
G1 X139.553 Y82.127 E.01258
G1 X130.468 Y91.211 E.3125
G1 X130.985 Y91.211 E.01258
G1 X139.553 Y82.644 E.29472
G1 X139.553 Y83.161 E.01258
G1 X131.502 Y91.211 E.27693
G1 X132.019 Y91.211 E.01258
G1 X139.553 Y83.678 E.25915
G1 X139.553 Y84.195 E.01258
G1 X132.536 Y91.211 E.24136
G1 X133.054 Y91.211 E.0126
G1 X139.553 Y84.712 E.22356
G1 X139.553 Y85.229 E.01258
G1 X133.571 Y91.211 E.20578
G1 X134.088 Y91.211 E.01258
G1 X139.553 Y85.746 E.18799
G1 X139.553 Y86.263 E.01258
G1 X134.605 Y91.211 E.17021
G1 X135.122 Y91.211 E.01258
G1 X139.553 Y86.78 E.15242
G1 X139.553 Y87.297 E.01258
G1 X135.639 Y91.211 E.13464
G1 X136.156 Y91.211 E.01258
G1 X139.553 Y87.814 E.11685
G1 X139.553 Y88.331 E.01258
G1 X136.673 Y91.211 E.09907
G1 X137.191 Y91.211 E.0126
G1 X139.554 Y88.848 E.08129
G1 X139.554 Y89.365 E.01258
G1 X137.708 Y91.211 E.0635
G1 X138.225 Y91.211 E.01258
G1 X139.554 Y89.882 E.04572
G1 X139.554 Y90.399 E.01258
G1 X138.742 Y91.211 E.02793
G1 X139.254 Y91.217 E.01245
G1 X139.554 Y90.916 E.01034
G1 E-5 F3600
G1 X139.554 Y90.916 F9000
G1 X140.249 Y93.071
G1 X140.249 Y95.726
G1 X138.813 Y97.617
G1 E5 F2400
G1 F1200
G1 X138.437 Y97.617 E.00915
G1 X138.434 Y132.819 E.85625
G1 X138.367 Y133.869 E.02559
G1 X138.147 Y135.207 E.03298
G1 X137.885 Y136.18 E.02451
G1 X137.548 Y137.115 E.02418
G1 X137.259 Y137.724 E.0164
G1 X139.432 Y135.551 E.07475
G1 X139.561 Y135.551 E.00314
G1 X139.555 Y97.557 E.92417
G1 X138.996 Y97.617 E.01368
G1 X139.001 Y97.988 E.00903
;WIDTH:0.410621
G1 X138.808 Y97.988 E.00483
G1 X138.808 Y98.176 E.00471
;WIDTH:0.414298
G1 X138.808 Y132.807 E.8753
;WIDTH:0.415047
G1 X138.807 Y132.842 E.00089
;WIDTH:0.447801
G1 X138.758 Y133.876 E.02847
;WIDTH:0.452198
G1 X138.754 Y133.933 E.00159
;WIDTH:0.499806
G1 X138.683 Y134.513 E.01809
;WIDTH:0.547414
G1 X138.612 Y135.093 E.01994
G1 X138.398 Y135.964 E.03061
G1 X139.12 Y135.24 E.0349
G1 X139.145 Y134.55 E.02357
;WIDTH:0.499806
G1 X139.169 Y133.967 E.01807
;WIDTH:0.452198
G1 X139.171 Y133.889 E.00217
;WIDTH:0.447801
G1 X139.187 Y132.854 E.02847
;WIDTH:0.415047
G1 X139.187 Y132.807 E.00119
;WIDTH:0.414298
G1 X139.184 Y98.176 E.8753
;WIDTH:0.410621
G1 X139.184 Y97.988 E.00471
G1 E-5 F3600
G1 X139.184 Y97.988 F9000
G1 X139.709 Y136.187
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X139.638 Y136.168 E.00166
G1 X139.657 Y136.239 E.00166
G1 X139.698 Y136.228 E.00096
;WIDTH:0.399999
G1 X139.561 Y135.939 E.00778
G1 X136.661 Y138.839 E.09976
G1 X136.458 Y139.098 E.008
;WIDTH:0.374336
G1 X135.735 Y139.951 E.02529
G1 E-5 F3600
G1 X135.735 Y139.951 F9000
G1 X130.843 Y142.213
G1 X130.824 Y142.222
G1 X130.804 Y142.231
G1 X130.781 Y142.241
G1 X130.417 Y142.394
G1 X130.394 Y142.404
G1 X130.341 Y142.425
G1 X129.931 Y142.575
G1 X129.862 Y142.599
G1 X129.519 Y142.707
G1 X129.452 Y142.727
G1 X129.367 Y142.751
G1 X129.044 Y142.837
G1 X128.958 Y142.858
G1 X128.858 Y142.881
G1 X128.556 Y142.946
G1 X128.452 Y142.967
G1 X128.337 Y142.986
G1 X128.056 Y143.033
G1 X127.935 Y143.051
G1 X127.545 Y143.097
G1 X127.413 Y143.109
G1 X127.155 Y143.127
G1 X127.025 Y143.136
G1 X126.887 Y143.141
G1 X126.637 Y143.147
G1 X126.504 Y143.149
G1 X104.496 Y143.149
G1 X104.363 Y143.147
G1 X104.113 Y143.141
G1 X103.975 Y143.136
G1 X103.845 Y143.127
G1 X103.587 Y143.109
G1 X103.455 Y143.097
G1 X103.065 Y143.051
G1 X102.944 Y143.033
G1 X102.663 Y142.986
G1 X102.548 Y142.967
G1 X102.444 Y142.946
G1 X102.142 Y142.881
G1 X102.042 Y142.858
G1 X101.956 Y142.837
G1 X101.633 Y142.751
G1 X101.548 Y142.727
G1 X101.481 Y142.707
G1 X101.138 Y142.599
G1 X101.069 Y142.575
G1 X100.659 Y142.424
G1 X100.606 Y142.404
G1 X100.583 Y142.394
G1 X100.219 Y142.241
G1 X100.196 Y142.231
G1 X100.176 Y142.222
G1 X100.157 Y142.213
G1 X100.138 Y142.204
G1 X99.753 Y142.02
G1 X99.733 Y142.01
G1 X99.714 Y142.001
G1 X99.696 Y141.991
G1 X99.312 Y141.785
G1 X99.25 Y141.749
G1 X98.888 Y141.532
G1 X98.827 Y141.493
G1 X98.477 Y141.26
G1 X98.417 Y141.218
G1 X98.078 Y140.968
G1 X98.021 Y140.924
G1 X97.693 Y140.658
G1 X97.638 Y140.611
G1 X97.324 Y140.331
G1 X97.271 Y140.281
G1 X96.971 Y139.988
G1 X96.929 Y139.946
G1 X96.644 Y139.639
G1 X96.606 Y139.597
G1 X96.57 Y139.556
G1 X96.299 Y139.234
G1 X96.264 Y139.191
G1 X96.007 Y138.855
G1 X95.974 Y138.812
G1 X95.731 Y138.463
G1 X95.702 Y138.421
G1 X95.677 Y138.38
G1 X95.448 Y138.017
G1 X95.424 Y137.975
G1 X95.205 Y137.587
G1 X95.191 Y137.561
G1 X95.172 Y137.525
G1 X94.993 Y137.17
G1 X94.984 Y137.152
G1 X94.973 Y137.13
G1 X94.961 Y137.103
G1 X94.948 Y137.074
G1 X94.795 Y136.732
G1 X94.783 Y136.705
G1 X94.769 Y136.671
G1 X94.754 Y136.635
G1 X94.74 Y136.6
G1 X94.611 Y136.271
G1 X94.597 Y136.234
G1 X94.583 Y136.196
G1 X94.57 Y136.159
G1 X94.445 Y135.789
G1 X94.433 Y135.752
G1 X94.422 Y135.716
G1 X94.414 Y135.686
G1 X94.311 Y135.329
G1 X94.302 Y135.297
G1 X94.295 Y135.269
G1 X94.288 Y135.244
G1 X94.284 Y135.225
G1 X94.188 Y134.819
G1 X94.18 Y134.786
G1 X94.174 Y134.754
G1 X94.094 Y134.326
G1 X94.085 Y134.271
G1 X94.024 Y133.837
G1 X94.018 Y133.781
G1 X93.978 Y133.345
G1 X93.974 Y133.289
G1 X91.804 Y97.617
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X92.563 Y97.617 E.01846
G1 X92.566 Y132.821 E.8563
G1 X92.661 Y134.105 E.03132
G1 X92.968 Y135.674 E.03889
G1 X93.309 Y136.748 E.02741
G1 X93.697 Y137.672 E.02438
G1 X94.133 Y138.446 E.02161
G1 X91.446 Y141.132 E.09241
G1 X91.44 Y97.573 E1.05953
G1 X91.622 Y97.595 E.00446
G1 X91.812 Y97.989 E.01064
;WIDTH:0.413297
G1 X92.191 Y97.989 E.00955
G1 X92.194 Y132.807 E.87771
;WIDTH:0.412677
G1 X92.195 Y132.848 E.00103
;WIDTH:0.459342
G1 X92.265 Y134.116 E.0359
;WIDTH:0.461882
G1 X92.438 Y134.954 E.02434
;WIDTH:0.430941
G1 X92.604 Y135.724 E.02078
;WIDTH:0.399999
G1 X92.978 Y136.905 E.03013
G1 X93.38 Y137.854 E.02507
G1 X93.678 Y138.383 E.01477
G1 X91.812 Y140.25 E.06421
G1 X91.811 Y135.8 E.10824
;WIDTH:0.430941
G1 X91.826 Y135.013 E.02077
;WIDTH:0.461882
G1 X91.841 Y134.132 E.02506
;WIDTH:0.459342
G1 X91.817 Y132.862 E.03591
;WIDTH:0.412677
G1 X91.816 Y132.807 E.00138
;WIDTH:0.413297
G1 X91.812 Y98.172 E.8731
G1 E-5 F3600
G1 X91.812 Y98.172 F9000
G1 X92.177 Y135.442
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X92.271 Y135.895 E.01125
G1 X92.612 Y136.97 E.02743
G1 X93.014 Y137.938 E.0255
G1 X93.223 Y138.321 E.01061
G1 X92.177 Y139.367 E.03598
G1 X92.177 Y135.625 E.09102
G1 E-5 F3600
G1 X92.177 Y135.625 F9000
G1 X92.712 Y138.223
G1 E5 F2400
;WIDTH:0.601186
G1 F1200
G1 X92.662 Y138.173 E.00267
G1 X92.593 Y138.192 E.0027
G1 X92.575 Y138.26 E.00265
G1 X92.625 Y138.31 E.00267
G1 X92.693 Y138.292 E.00265
G1 X92.693 Y138.292 F9000
G1 X94.32 Y138.776
;WIDTH:0.399999
G1 F1200
G1 X91.446 Y141.649 E.09885
G1 X91.446 Y142.167 E.0126
G1 X94.506 Y139.107 E.10526
G1 X94.714 Y139.416 E.00906
G1 X91.446 Y142.684 E.11242
G1 X91.447 Y143.201 E.01258
G1 X94.934 Y139.713 E.11997
G1 X95.154 Y140.01 E.00899
G1 X91.447 Y143.718 E.12754
G1 X91.447 Y144.235 E.01258
G1 X95.385 Y140.296 E.13548
G1 X95.629 Y140.569 E.00891
G1 X91.447 Y144.752 E.14388
G1 X91.447 Y145.269 E.01258
G1 X95.874 Y140.842 E.15229
G1 X96.13 Y141.103 E.00889
G1 X91.447 Y145.786 E.16109
G1 X91.447 Y146.303 E.01258
G1 X96.395 Y141.355 E.17021
G1 X96.674 Y141.593 E.00892
G1 X91.447 Y146.82 E.17981
G1 X91.447 Y147.337 E.01258
G1 X96.96 Y141.824 E.18964
G1 X97.245 Y142.056 E.00894
G1 X91.447 Y147.854 E.19945
G1 X91.447 Y148.371 E.01258
G1 X97.532 Y142.287 E.2093
G1 X97.847 Y142.488 E.00909
G1 X91.447 Y148.888 E.22016
G1 X91.448 Y149.405 E.01258
G1 X98.163 Y142.689 E.23101
G1 X98.479 Y142.891 E.00912
G1 X91.448 Y149.922 E.24186
G1 X91.448 Y150.439 E.01258
G1 X98.804 Y143.083 E.25304
G1 X99.149 Y143.255 E.00938
G1 X91.448 Y150.956 E.26491
G1 X91.473 Y151.449 E.01201
G1 X99.494 Y143.427 E.27593
G1 X99.854 Y143.584 E.00955
G1 X91.547 Y151.891 E.28576
G1 X91.663 Y152.293 E.01018
G1 X100.227 Y143.728 E.29461
G1 X100.6 Y143.873 E.00973
G1 X91.815 Y152.658 E.3022
G1 X91.98 Y153.01 E.00946
G1 X100.989 Y144 E.30992
G1 X101.391 Y144.115 E.01017
G1 X92.178 Y153.329 E.31694
G1 X92.404 Y153.62 E.00896
G1 X101.801 Y144.223 E.32325
G1 X102.229 Y144.312 E.01063
G1 X92.655 Y153.886 E.32934
G1 X92.927 Y154.131 E.0089
G1 X102.676 Y144.382 E.33536
G1 X103.136 Y144.439 E.01127
G1 X93.22 Y154.356 E.34112
G1 X93.542 Y154.55 E.00914
G1 X103.596 Y144.496 E.34585
G1 X104.089 Y144.521 E.01201
G1 X93.89 Y154.719 E.35082
G1 X94.266 Y154.86 E.00977
G1 X104.59 Y144.537 E.35512
G1 X105.107 Y144.537 E.01258
G1 X94.676 Y154.968 E.35882
G1 X95.124 Y155.037 E.01103
G1 X105.624 Y144.537 E.36119
G1 X106.141 Y144.537 E.01258
G1 X95.615 Y155.063 E.36209
G1 X96.133 Y155.063 E.0126
G1 X106.658 Y144.537 E.36207
G1 X107.175 Y144.537 E.01258
G1 X96.65 Y155.062 E.36205
G1 X97.167 Y155.062 E.01258
G1 X107.692 Y144.537 E.36205
G1 X108.209 Y144.537 E.01258
G1 X97.684 Y155.062 E.36205
G1 X98.202 Y155.062 E.0126
G1 X108.727 Y144.537 E.36205
G1 X109.244 Y144.537 E.01258
G1 X98.719 Y155.062 E.36205
G1 X99.236 Y155.062 E.01258
G1 X109.761 Y144.537 E.36205
G1 X110.278 Y144.537 E.01258
G1 X99.753 Y155.062 E.36205
G1 X100.271 Y155.062 E.0126
G1 X110.816 Y144.516 E.36276
G1 X110.978 Y144.334 E.00593
;WIDTH:0.374336
G1 X110.802 Y144.338 E.00398
;WIDTH:0.399999
G1 X111.383 Y144.466 E.01447
G1 X100.788 Y155.061 E.36446
G1 X101.305 Y155.061 E.01258
G1 X111.9 Y144.466 E.36446
G1 X112.418 Y144.466 E.0126
G1 X101.822 Y155.061 E.36448
G1 X102.34 Y155.061 E.0126
G1 X112.935 Y144.466 E.36446
G1 X113.452 Y144.466 E.01258
G1 X102.857 Y155.061 E.36446
G1 X103.374 Y155.061 E.01258
G1 X113.969 Y144.466 E.36446
G1 X114.486 Y144.466 E.01258
G1 X103.891 Y155.061 E.36446
G1 X104.409 Y155.06 E.0126
G1 X115.003 Y144.466 E.36443
G1 X115.52 Y144.466 E.01258
G1 X104.926 Y155.06 E.36443
G1 X105.443 Y155.06 E.01258
G1 X116.037 Y144.466 E.36443
G1 X116.555 Y144.466 E.0126
G1 X105.961 Y155.06 E.36443
G1 X106.478 Y155.06 E.01258
G1 X117.072 Y144.466 E.36443
G1 X117.589 Y144.466 E.01258
G1 X106.995 Y155.06 E.36443
G1 X107.512 Y155.06 E.01258
G1 X118.106 Y144.466 E.36443
G1 X118.623 Y144.466 E.01258
G1 X108.03 Y155.06 E.36441
G1 X108.547 Y155.059 E.01258
G1 X119.14 Y144.466 E.36439
G1 X119.657 Y144.466 E.01258
G1 X109.064 Y155.059 E.36439
G1 X109.581 Y155.059 E.01258
G1 X120.155 Y144.485 E.36374
G1 X120.621 Y144.537 E.01141
G1 X110.099 Y155.059 E.36195
G1 X110.616 Y155.059 E.01258
G1 X121.138 Y144.536 E.36197
G1 X121.656 Y144.536 E.0126
G1 X111.133 Y155.059 E.36198
G1 X111.65 Y155.059 E.01258
G1 X122.174 Y144.535 E.36202
G1 X122.692 Y144.535 E.0126
G1 X112.168 Y155.058 E.362
G1 X112.685 Y155.058 E.01258
G1 X123.209 Y144.534 E.36202
G1 X123.727 Y144.533 E.0126
G1 X113.202 Y155.058 E.36205
G1 X113.719 Y155.058 E.01258
G1 X124.245 Y144.533 E.36207
G1 X124.762 Y144.532 E.01258
G1 X114.237 Y155.058 E.36207
G1 X114.754 Y155.058 E.01258
G1 X125.28 Y144.532 E.36209
G1 X125.798 Y144.531 E.0126
G1 X115.271 Y155.058 E.36212
G1 X115.788 Y155.058 E.01258
G1 X126.316 Y144.53 E.36216
G1 X126.833 Y144.53 E.01258
G1 X116.306 Y155.057 E.36212
G1 X116.823 Y155.057 E.01258
G1 X127.396 Y144.485 E.36369
G1 X127.962 Y144.435 E.01382
G1 X117.34 Y155.057 E.36539
G1 X117.857 Y155.057 E.01258
G1 X128.727 Y144.2 E.3737
;WIDTH:0.374336
G1 X128.686 Y144.211 E.00096
G1 X128.667 Y144.14 E.00166
G1 X128.738 Y144.159 E.00166
;WIDTH:0.399999
G1 X129.221 Y144.211 E.01182
G1 X118.375 Y155.057 E.3731
G1 X118.892 Y155.057 E.01258
G1 X129.93 Y144.019 E.3797
G1 X130.215 Y143.89 E.00761
;WIDTH:0.374336
G1 X130.174 Y143.901 E.00096
G1 X130.155 Y143.829 E.00168
G1 X130.226 Y143.849 E.00167
;WIDTH:0.399999
G1 X130.719 Y143.747 E.01225
G1 X119.409 Y155.057 E.38906
G1 X119.926 Y155.057 E.01258
G1 X131.608 Y143.375 E.40185
G1 E-5 F3600
G1 X131.608 Y143.375 F9000
G1 X133.798 Y141.881
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X132.982 Y142.568 E.02413
;WIDTH:0.399999
G1 X132.723 Y142.777 E.0081
G1 X120.444 Y155.056 E.42239
G1 X120.961 Y155.056 E.01258
G1 X139.561 Y136.456 E.63983
G1 X139.561 Y136.973 E.01258
G1 X121.478 Y155.056 E.62204
G1 X121.995 Y155.056 E.01258
G1 X139.561 Y137.49 E.60426
G1 X139.561 Y138.007 E.01258
G1 X122.513 Y155.056 E.58646
G1 X123.03 Y155.056 E.01258
G1 X139.561 Y138.525 E.56866
G1 X139.561 Y139.042 E.01258
G1 X123.547 Y155.056 E.55087
G1 X124.065 Y155.055 E.0126
G1 X139.561 Y139.559 E.53305
G1 X139.561 Y140.076 E.01258
G1 X124.582 Y155.055 E.51527
G1 X125.099 Y155.055 E.01258
G1 X139.562 Y140.593 E.4975
G1 X139.562 Y141.11 E.01258
G1 X125.616 Y155.055 E.47972
G1 X126.134 Y155.055 E.0126
G1 X139.562 Y141.627 E.46191
G1 X139.562 Y142.144 E.01258
G1 X126.651 Y155.055 E.44413
G1 X127.168 Y155.055 E.01258
G1 X139.562 Y142.661 E.42635
G1 X139.562 Y143.178 E.01258
G1 X127.685 Y155.055 E.40856
G1 X128.203 Y155.054 E.0126
G1 X139.562 Y143.695 E.39074
G1 X139.562 Y144.212 E.01258
G1 X128.72 Y155.054 E.37296
G1 X129.237 Y155.054 E.01258
G1 X139.562 Y144.729 E.35517
G1 X139.562 Y145.246 E.01258
G1 X129.754 Y155.054 E.33739
G1 X130.272 Y155.054 E.0126
G1 X139.562 Y145.763 E.31959
G1 X139.562 Y146.28 E.01258
G1 X130.789 Y155.054 E.3018
G1 X131.306 Y155.054 E.01258
G1 X139.562 Y146.797 E.28402
G1 X139.563 Y147.314 E.01258
G1 X131.823 Y155.053 E.26623
G1 X132.341 Y155.053 E.0126
G1 X139.563 Y147.831 E.24843
G1 X139.563 Y148.348 E.01258
G1 X132.858 Y155.053 E.23065
G1 X133.375 Y155.053 E.01258
G1 X139.563 Y148.865 E.21286
G1 X139.563 Y149.383 E.0126
G1 X133.892 Y155.053 E.19506
G1 X134.41 Y155.053 E.0126
G1 X139.563 Y149.9 E.17726
G1 X139.563 Y150.417 E.01258
G1 X134.927 Y155.053 E.15948
G1 X135.444 Y155.053 E.01258
G1 X139.563 Y150.934 E.14169
G1 X139.53 Y151.483 E.01338
G1 X135.991 Y155.022 E.12174
G1 X136.64 Y154.89 E.01611
G1 X139.388 Y152.143 E.09451
G1 X139.18 Y152.798 E.01672
;WIDTH:0.374336
G1 X139.174 Y152.973 E.00396
G1 X138.563 Y153.706 E.02158
G1 X137.829 Y154.395 E.02277
G1 X137.452 Y154.686 E.01077
G1 X137.301 Y154.681 E.00342
;WIDTH:0.399999
G1 X137.557 Y154.491 E.00775
G1 X138.992 Y153.056 E.04936
G1 E-5 F3600
G1 X138.992 Y153.056 F9000
G1 X99.753 Y142.02
G1 X99.733 Y142.01
G1 X99.714 Y142.001
G1 X99.696 Y141.991
G1 X99.312 Y141.785
G1 X99.25 Y141.749
G1 X98.888 Y141.532
G1 X98.827 Y141.493
G1 X98.477 Y141.26
G1 X98.417 Y141.218
G1 X98.078 Y140.968
G1 X98.021 Y140.924
G1 X97.693 Y140.658
G1 X97.638 Y140.611
G1 X97.324 Y140.331
G1 X97.271 Y140.281
G1 X96.971 Y139.988
G1 X96.929 Y139.946
G1 X96.644 Y139.639
G1 X96.606 Y139.597
G1 X96.57 Y139.556
G1 X96.299 Y139.234
G1 X96.264 Y139.191
G1 X96.007 Y138.855
G1 X95.974 Y138.812
G1 X95.731 Y138.463
G1 X95.702 Y138.421
G1 X95.677 Y138.38
G1 X95.448 Y138.017
G1 X95.424 Y137.975
G1 X95.205 Y137.587
G1 X95.191 Y137.561
G1 X95.172 Y137.525
G1 X94.993 Y137.17
G1 X94.984 Y137.152
G1 X94.973 Y137.13
G1 X94.961 Y137.103
G1 X94.948 Y137.074
G1 X94.795 Y136.732
G1 X94.783 Y136.705
G1 X94.769 Y136.671
G1 X94.754 Y136.635
G1 X94.74 Y136.6
G1 X94.611 Y136.271
G1 X94.597 Y136.234
G1 X94.583 Y136.196
G1 X94.57 Y136.159
G1 X94.445 Y135.789
G1 X94.433 Y135.752
G1 X94.422 Y135.716
G1 X94.414 Y135.686
G1 X94.311 Y135.329
G1 X94.302 Y135.297
G1 X94.295 Y135.269
G1 X94.288 Y135.244
G1 X94.284 Y135.225
G1 X94.188 Y134.819
G1 X94.18 Y134.786
G1 X94.174 Y134.754
G1 X94.094 Y134.326
G1 X94.085 Y134.271
G1 X94.024 Y133.837
G1 X94.018 Y133.781
G1 X93.978 Y133.345
G1 X90.751 Y95.758
G1 X90.751 Y93.103
G1 X93.123 Y76.56
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X92.747 Y76.893 E.01136
G1 X92.393 Y77.247 E.01132
G1 X92.06 Y77.623 E.01136
G1 X92.06 Y77.623 F9000
G1 X91.75 Y78.419
G1 F1200
G1 X91.709 Y78.43 E.00096
G1 X91.689 Y78.358 E.00169
G1 X91.761 Y78.378 E.00169
;WIDTH:0.399999
G1 X91.898 Y78.13 E.00689
G1 X93.63 Y76.398 E.05958
G1 X94.445 Y76.1 F9000
G1 F1200
G1 X91.577 Y78.968 E.09866
G1 X91.465 Y79.597 E.01554
G1 X95.093 Y75.969 E.1248
G1 X95.632 Y75.948 E.01312
G1 X91.437 Y80.142 E.14429
G1 X91.437 Y80.659 E.01258
G1 X96.149 Y75.948 E.16207
G1 X96.666 Y75.947 E.01258
G1 X91.437 Y81.177 E.17989
G1 X91.437 Y81.694 E.01258
G1 X97.183 Y75.947 E.19768
G1 X97.701 Y75.947 E.0126
G1 X91.437 Y82.211 E.21548
G1 X91.437 Y82.728 E.01258
G1 X98.218 Y75.947 E.23326
G1 X98.424 Y75.845 E.00559
;WIDTH:0.374336
G1 X98.22 Y76.529 E.01614
;WIDTH:0.399999
G1 X98.036 Y76.646 E.0053
G1 X91.437 Y83.245 E.227
G1 X91.437 Y83.762 E.01258
G1 X97.913 Y77.286 E.22277
G1 X97.919 Y77.797 E.01243
G1 X91.438 Y84.279 E.22296
G1 X91.438 Y84.796 E.01258
G1 X98.003 Y78.231 E.22583
G1 X98.123 Y78.627 E.01006
G1 X91.438 Y85.313 E.22998
G1 X91.438 Y85.83 E.01258
G1 X98.263 Y79.004 E.23479
G1 X98.264 Y79.521 E.01258
G1 X91.438 Y86.347 E.23481
G1 X91.438 Y86.864 E.01258
G1 X98.265 Y80.037 E.23484
G1 X98.266 Y80.553 E.01255
G1 X91.438 Y87.381 E.23488
G1 X91.438 Y87.898 E.01258
G1 X98.266 Y81.07 E.23488
G1 X98.267 Y81.586 E.01255
G1 X91.438 Y88.415 E.23491
G1 X91.438 Y88.932 E.01258
G1 X98.268 Y82.102 E.23495
G1 X98.302 Y82.585 E.01178
G1 X91.438 Y89.449 E.23612
G1 X91.438 Y89.966 E.01258
G1 X98.355 Y83.05 E.23792
G1 X98.461 Y83.46 E.0103
G1 X91.439 Y90.483 E.24157
G1 X91.439 Y90.483 F9000
G1 X91.413 Y91.374
;WIDTH:0.374336
G1 F1200
G1 X91.372 Y91.385 E.00096
G1 X91.353 Y91.314 E.00166
G1 X91.424 Y91.333 E.00166
;WIDTH:0.399999
G1 X91.439 Y91 E.00811
G1 X98.568 Y83.871 E.24523
G1 X98.697 Y84.259 E.00995
G1 X91.734 Y91.222 E.23952
G1 X92.262 Y91.211 E.01285
G1 X98.861 Y84.612 E.227
G1 X99.031 Y84.959 E.0094
G1 X92.779 Y91.211 E.21506
G1 X93.296 Y91.211 E.01258
G1 X99.231 Y85.277 E.20414
G1 X99.439 Y85.585 E.00904
G1 X93.813 Y91.211 E.19353
G1 X94.33 Y91.211 E.01258
G1 X99.666 Y85.876 E.18354
G1 X99.915 Y86.144 E.0089
G1 X94.848 Y91.211 E.1743
G1 X95.365 Y91.211 E.01258
G1 X100.172 Y86.404 E.16536
G1 X100.452 Y86.641 E.00892
G1 X95.882 Y91.211 E.1572
G1 X96.399 Y91.211 E.01258
G1 X100.74 Y86.87 E.14933
G1 X101.053 Y87.075 E.0091
G1 X96.916 Y91.211 E.14229
G1 X97.433 Y91.211 E.01258
G1 X101.381 Y87.263 E.13581
G1 X101.722 Y87.44 E.00935
G1 X97.95 Y91.211 E.12974
G1 X98.467 Y91.211 E.01258
G1 X102.091 Y87.588 E.12465
G1 X102.473 Y87.722 E.00985
G1 X98.985 Y91.211 E.12
G1 X99.502 Y91.211 E.01258
G1 X102.893 Y87.82 E.11665
G1 X103.59 Y87.848 E.01697
;WIDTH:0.374336
G1 X103.519 Y87.829 E.00166
G1 X103.538 Y87.9 E.00166
G1 X103.579 Y87.889 E.00096
;WIDTH:0.399999
G1 X103.328 Y87.902 E.00611
G1 X100.019 Y91.211 E.11383
G1 X100.536 Y91.211 E.01258
G1 X103.293 Y88.454 E.09484
G1 X103.264 Y89 E.0133
G1 X101.053 Y91.211 E.07606
G1 X101.57 Y91.211 E.01258
G1 X102.997 Y89.784 E.04909
G1 X103.184 Y89.556 E.00717
;WIDTH:0.374336
G1 X103.143 Y89.567 E.00096
G1 X103.124 Y89.496 E.00166
G1 X103.195 Y89.515 E.00166
G1 X103.195 Y89.515 F9000
G1 X102.927 Y90.371
;WIDTH:0.399999
G1 F1200
G1 X102.087 Y91.211 E.0289
G1 X102.604 Y91.211 E.01258
G1 X102.929 Y90.886 E.01118
;LAYER_CHANGE
;Z:0.62
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;0.62
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X102.604 Y91.211 E-.21832
G1 X102.087 Y91.211 E-.24557
G1 X102.927 Y90.371 E-.56427
;WIPE_END
G1 E-.47184 F3600
G1 Z.62 F9000
;AFTER_LAYER_CHANGE
;0.62
G1 Z.62
G1 X104.266 Y92.473
G1 X104.651 Y93.889
G1 X104.947 Y93.543
G1 E5 F2400
;TYPE:External perimeter
G1 F6000
G1 X105 Y93.618 E.00223
G1 X105 Y98.295 E.11376
G1 X104.852 Y98.407 E.00451
G1 X104.845 Y98.457 E.00123
G1 X104.845 Y103.792 E.12977
G1 X104.846 Y103.814 E.00054
G1 X105 Y103.953 E.00505
G1 X105 Y136.368 E.78846
G1 X104.602 Y136.915 E.01645
G1 X104.526 Y137.09 E.00464
G1 X104.438 Y137.475 E.00961
G1 X104.469 Y137.754 E.00683
G1 X104.601 Y138.085 E.00867
G1 X105 Y138.632 E.01647
G1 X105 Y139.323 E.01681
G1 X105.094 Y139.477 E.00439
G1 X105.182 Y139.5 E.00221
G1 X125.817 Y139.5 E.50193
G1 X125.924 Y139.465 E.00274
G1 X126 Y139.317 E.00405
G1 X126 Y138.632 E.01666
G1 X126.398 Y138.085 E.01645
G1 X126.519 Y137.797 E.0076
G1 X126.562 Y137.525 E.0067
G1 X126.531 Y137.246 E.00683
G1 X126.398 Y136.915 E.00868
G1 X126 Y136.368 E.01645
G1 X126 Y103.953 E.78846
G1 X126.15 Y103.836 E.00463
G1 X126.156 Y103.792 E.00108
G1 X126.156 Y98.462 E.12965
G1 X126.154 Y98.433 E.00071
G1 X126 Y98.295 E.00503
G1 X126 Y93.653 E.11291
G1 X126.054 Y93.54 E.00305
G1 X138.926 Y93.54 E.3131
G1 X139.108 Y93.627 E.00491
G1 X139.226 Y93.982 E.0091
G1 X139.227 Y94.847 E.02104
G1 X139.108 Y95.201 E.00908
G1 X138.926 Y95.289 E.00492
G1 X136.183 Y95.289 E.06672
G1 X136.074 Y95.326 E.0028
G1 X136 Y95.472 E.00398
G1 X136 Y127.168 E.77097
G1 X135.978 Y127.642 E.01154
G1 X135.978 Y132.948 E.12906
G1 X135.865 Y133.916 E.02371
G1 X135.692 Y134.735 E.02036
G1 X135.42 Y135.62 E.02252
G1 X135.221 Y136.126 E.01323
G1 X134.861 Y136.884 E.02041
G1 X134.391 Y137.681 E.02251
G1 X134.079 Y138.126 E.01322
G1 X133.552 Y138.78 E.02043
G1 X132.908 Y139.444 E.0225
G1 X132.501 Y139.805 E.01323
G1 X131.836 Y140.317 E.02041
G1 X131.055 Y140.813 E.0225
G1 X130.574 Y141.068 E.01324
G1 X129.808 Y141.412 E.02042
G1 X128.933 Y141.711 E.02249
G1 X128.406 Y141.847 E.01324
G1 X127.583 Y142.002 E.02037
G1 X126.193 Y142.1 E.03389
G1 X120.824 Y142.1 E.1306
G1 X120.745 Y141.976 E.00358
G1 X120.667 Y141.959 E.00194
G1 X110.333 Y141.959 E.25136
G1 X110.301 Y141.961 E.00078
G1 X110.176 Y142.1 E.00455
G1 X104.339 Y142.089 E.14198
G1 X103.043 Y141.94 E.03173
G1 X102.512 Y141.83 E.01319
G1 X101.624 Y141.571 E.0225
G1 X100.843 Y141.265 E.0204
G1 X100.353 Y141.033 E.01319
G1 X99.163 Y140.317 E.03378
G1 X98.15 Y139.498 E.03169
G1 X97.763 Y139.122 E.01312
G1 X96.87 Y138.059 E.03377
G1 X96.177 Y136.956 E.03169
G1 X95.933 Y136.475 E.01312
G1 X95.432 Y135.179 E.0338
G1 X95.134 Y133.914 E.03161
G1 X95.021 Y132.948 E.02366
G1 X95.021 Y127.642 E.12906
G1 X94.999 Y127.607 E.00101
G1 X94.999 Y95.472 E.78165
G1 X94.926 Y95.326 E.00397
G1 X94.816 Y95.289 E.00282
G1 X92.64 Y95.289 E.05293
G1 X91.981 Y95.265 E.01604
G1 X91.843 Y95.125 E.00478
G1 X91.776 Y94.915 E.00536
G1 X91.758 Y94.076 E.02041
G1 X91.883 Y93.648 E.01085
G1 X92.085 Y93.54 E.00557
G1 X104.889 Y93.541 E.31144
G1 X104.889 Y93.541 F9000
G1 X104.634 Y93.968
;TYPE:Perimeter
G1 F6000
G1 X104.634 Y98.205 E.10306
G1 X104.5 Y98.306 E.00408
G1 X104.479 Y98.457 E.00371
G1 X104.479 Y103.792 E.12977
G1 X104.487 Y103.886 E.00229
G1 X104.634 Y104.033 E.00506
G1 X104.634 Y136.249 E.78362
G1 X104.306 Y136.699 E.01354
G1 X104.141 Y137.067 E.00981
G1 X104.076 Y137.426 E.00887
G1 X104.12 Y137.87 E.01085
G1 X104.305 Y138.299 E.01136
G1 X104.634 Y138.751 E.0136
G1 X104.634 Y139.307 E.01352
G1 X104.68 Y139.537 E.00571
G1 X104.917 Y139.797 E.00856
G1 X105.182 Y139.866 E.00666
G1 X125.817 Y139.866 E.50193
G1 X125.912 Y139.857 E.00232
G1 X126.138 Y139.762 E.00596
G1 X126.275 Y139.619 E.00482
G1 X126.366 Y139.317 E.00767
G1 X126.366 Y138.751 E.01377
G1 X126.694 Y138.301 E.01354
G1 X126.859 Y137.933 E.00981
G1 X126.924 Y137.574 E.00887
G1 X126.875 Y137.115 E.01123
G1 X126.694 Y136.699 E.01104
G1 X126.366 Y136.249 E.01354
G1 X126.366 Y104.033 E.78362
G1 X126.505 Y103.925 E.00428
G1 X126.521 Y103.792 E.00326
G1 X126.521 Y98.462 E.12965
G1 X126.5 Y98.306 E.00383
G1 X126.366 Y98.205 E.00408
G1 X126.366 Y93.905 E.10459
G1 X138.828 Y93.905 E.30313
G1 X138.861 Y94 E.00245
G1 X138.882 Y94.44 E.01071
G1 X138.828 Y94.923 E.01182
G1 X136.183 Y94.923 E.06434
G1 X135.854 Y95.033 E.00844
G1 X135.677 Y95.261 E.00702
G1 X135.635 Y95.472 E.00523
G1 X135.634 Y127.168 E.77097
G1 X135.613 Y127.642 E.01154
G1 X135.613 Y132.927 E.12855
G1 X135.504 Y133.857 E.02278
G1 X135.338 Y134.644 E.01956
G1 X135.075 Y135.499 E.02176
G1 X134.886 Y135.98 E.01257
G1 X134.538 Y136.713 E.01974
G1 X134.083 Y137.483 E.02176
G1 X133.786 Y137.906 E.01257
G1 X133.277 Y138.537 E.01972
G1 X132.655 Y139.18 E.02176
G1 X132.268 Y139.523 E.01258
G1 X131.626 Y140.018 E.01972
G1 X130.871 Y140.497 E.02175
G1 X130.414 Y140.74 E.01259
G1 X129.674 Y141.071 E.01972
G1 X128.828 Y141.361 E.02175
G1 X128.327 Y141.49 E.01258
G1 X127.536 Y141.639 E.01958
G1 X126.18 Y141.735 E.03307
G1 X120.958 Y141.735 E.12702
G1 X120.901 Y141.645 E.00259
G1 X120.667 Y141.593 E.00583
G1 X110.333 Y141.593 E.25136
G1 X110.1 Y141.645 E.00581
G1 X110.043 Y141.734 E.00257
G1 X104.361 Y141.724 E.13821
G1 X103.101 Y141.578 E.03085
G1 X102.601 Y141.474 E.01242
G1 X101.742 Y141.225 E.02175
G1 X100.988 Y140.929 E.0197
G1 X100.525 Y140.71 E.01246
G1 X99.373 Y140.017 E.0327
G1 X98.393 Y139.224 E.03066
G1 X98.031 Y138.873 E.01226
G1 X97.166 Y137.843 E.03272
G1 X96.495 Y136.776 E.03066
G1 X96.267 Y136.326 E.01227
G1 X95.782 Y135.071 E.03273
G1 X95.495 Y133.85 E.03051
G1 X95.386 Y132.927 E.02261
G1 X95.386 Y127.642 E.12855
G1 X95.365 Y127.574 E.00173
G1 X95.365 Y95.472 E.78085
G1 X95.322 Y95.261 E.00524
G1 X95.145 Y95.033 E.00702
G1 X94.816 Y94.923 E.00844
G1 X92.162 Y94.923 E.06456
G1 X92.14 Y94.855 E.00174
G1 X92.125 Y94.145 E.01727
G1 X92.175 Y93.905 E.00596
G1 X104.634 Y93.907 E.30305
G1 X104.634 Y93.907 F9000
G1 X104.073 Y94.272
G1 F6000
G1 X104.269 Y94.272 E.00477
G1 X104.269 Y98.114 E.09345
G1 X104.149 Y98.205 E.00366
G1 X104.113 Y98.457 E.00619
G1 X104.113 Y103.792 E.12977
G1 X104.141 Y104.014 E.00544
G1 X104.269 Y104.114 E.00395
G1 X104.269 Y136.13 E.77876
G1 X104.011 Y136.484 E.01065
G1 X103.802 Y136.932 E.01202
G1 X103.713 Y137.376 E.01101
G1 X103.745 Y137.853 E.01163
G1 X103.945 Y138.412 E.01444
G1 X104.269 Y138.87 E.01365
G1 X104.269 Y139.307 E.01063
G1 X104.346 Y139.684 E.00936
G1 X104.741 Y140.117 E.01426
G1 X105.181 Y140.231 E.01106
G1 X125.817 Y140.231 E.50195
G1 X125.975 Y140.218 E.00386
G1 X126.352 Y140.058 E.00996
G1 X126.581 Y139.82 E.00803
G1 X126.703 Y139.542 E.00738
G1 X126.728 Y139.393 E.00367
G1 X126.731 Y138.87 E.01272
G1 X126.989 Y138.516 E.01065
G1 X127.198 Y138.068 E.01202
G1 X127.287 Y137.624 E.01101
G1 X127.254 Y137.139 E.01182
G1 X127.082 Y136.642 E.01279
G1 X126.731 Y136.13 E.0151
G1 X126.731 Y104.114 E.77876
G1 X126.859 Y104.014 E.00395
G1 X126.887 Y103.792 E.00544
G1 X126.887 Y98.462 E.12965
G1 X126.851 Y98.205 E.00631
G1 X126.731 Y98.114 E.00366
G1 X126.731 Y94.271 E.09348
G1 X135.478 Y94.271 E.21276
G1 X136.183 Y94.251 E.01716
;WIDTH:0.360531
G1 X138.527 Y94.251 E.05086
;WIDTH:0.360458
G1 X138.528 Y94.577 E.00707
G1 X136.183 Y94.577 E.05087
;WIDTH:0.368544
G1 X136.028 Y94.587 E.00345
;WIDTH:0.399999
G1 X135.635 Y94.741 E.01027
G1 X135.339 Y95.12 E.0117
G1 X135.269 Y95.472 E.00873
G1 X135.269 Y127.168 E.77097
G1 X135.247 Y127.642 E.01154
G1 X135.247 Y132.905 E.12802
G1 X135.142 Y133.798 E.02187
G1 X134.983 Y134.552 E.01874
G1 X134.776 Y135.228 E.0172
G1 X134.55 Y135.835 E.01575
G1 X134.215 Y136.541 E.01901
G1 X133.849 Y137.16 E.01749
G1 X133.494 Y137.687 E.01546
G1 X133.003 Y138.295 E.01901
G1 X132.484 Y138.831 E.01815
G1 X132.035 Y139.241 E.01479
G1 X131.416 Y139.718 E.01901
G1 X130.762 Y140.133 E.01884
G1 X130.253 Y140.411 E.01411
G1 X129.54 Y140.731 E.01901
G1 X128.78 Y140.991 E.01954
G1 X128.247 Y141.133 E.01342
G1 X127.489 Y141.275 E.01876
G1 X126.167 Y141.369 E.03224
G1 X121.091 Y141.369 E.12347
G1 X121.057 Y141.315 E.00155
G1 X120.667 Y141.227 E.00972
G1 X110.333 Y141.227 E.25136
G1 X109.945 Y141.314 E.00967
G1 X109.91 Y141.368 E.00157
G1 X104.382 Y141.358 E.13446
G1 X103.209 Y141.223 E.02872
G1 X102.689 Y141.119 E.0129
G1 X101.86 Y140.879 E.02099
G1 X101.195 Y140.617 E.01739
G1 X100.698 Y140.388 E.01331
G1 X99.584 Y139.716 E.03165
G1 X98.746 Y139.04 E.02619
G1 X98.3 Y138.623 E.01485
G1 X97.462 Y137.627 E.03166
G1 X96.912 Y136.751 E.02516
G1 X96.602 Y136.177 E.01587
G1 X96.132 Y134.963 E.03167
G1 X95.855 Y133.787 E.02939
G1 X95.752 Y132.905 E.0216
G1 X95.752 Y127.642 E.12802
G1 X95.73 Y127.542 E.00249
G1 X95.73 Y95.472 E.78007
G1 X95.66 Y95.12 E.00873
G1 X95.365 Y94.741 E.01168
G1 X94.816 Y94.577 E.01394
;WIDTH:0.360424
G1 X92.48 Y94.577 E.05067
G1 X92.474 Y94.251 E.00707
G1 X94.816 Y94.251 E.0508
;WIDTH:0.399999
G1 X95.521 Y94.271 E.01716
G1 X104.013 Y94.272 E.20656
G1 X104.013 Y94.272 F9000
G1 X103.58 Y94.638
G1 F6000
G1 X103.903 Y94.638 E.00786
G1 X103.903 Y98.024 E.08236
G1 X103.797 Y98.104 E.00323
G1 X103.748 Y98.457 E.00867
G1 X103.748 Y103.792 E.12977
G1 X103.786 Y104.103 E.00762
G1 X103.903 Y104.194 E.00361
G1 X103.903 Y136.011 E.77392
G1 X103.586 Y136.49 E.01397
G1 X103.397 Y137.015 E.01357
G1 X103.34 Y137.524 E.01246
G1 X103.413 Y138.056 E.01306
G1 X103.624 Y138.586 E.01388
G1 X103.903 Y138.989 E.01192
G1 X103.904 Y139.359 E.009
G1 X104.011 Y139.831 E.01177
G1 X104.564 Y140.437 E.01996
;WIDTH:0.415519
G1 X105.183 Y140.605 E.01626
;WIDTH:0.419686
G1 X109.703 Y140.607 E.11586
G1 X110.018 Y140.589 E.00809
;WIDTH:0.384601
G1 X110.333 Y140.572 E.00735
;WIDTH:0.349516
G1 X120.667 Y140.572 E.21666
;WIDTH:0.3849
G1 X120.983 Y140.589 E.00738
;WIDTH:0.420284
G1 X121.299 Y140.607 E.00813
G1 X125.817 Y140.607 E.11599
;WIDTH:0.42588
G1 X126.101 Y140.578 E.00744
G1 X126.567 Y140.355 E.01346
;WIDTH:0.399999
G1 X126.886 Y140.021 E.01123
G1 X127.058 Y139.632 E.01035
G1 X127.097 Y138.989 E.01567
G1 X127.439 Y138.452 E.01549
G1 X127.59 Y138.046 E.01054
G1 X127.66 Y137.526 E.01276
G1 X127.616 Y137.087 E.01073
G1 X127.414 Y136.49 E.01533
G1 X127.097 Y136.011 E.01397
G1 X127.097 Y104.194 E.77392
G1 X127.214 Y104.103 E.00361
G1 X127.252 Y103.792 E.00762
G1 X127.252 Y98.462 E.12965
G1 X127.203 Y98.104 E.00879
G1 X127.097 Y98.024 E.00323
G1 X127.097 Y94.637 E.08239
G1 X135.269 Y94.637 E.19878
G1 X135.002 Y94.98 E.01057
G1 X134.903 Y95.472 E.01221
G1 X134.903 Y127.168 E.77097
G1 X134.881 Y127.642 E.01154
G1 X134.881 Y132.884 E.12751
G1 X134.781 Y133.739 E.02094
G1 X134.629 Y134.461 E.01795
G1 X134.426 Y135.121 E.0168
G1 X134.214 Y135.689 E.01475
G1 X133.892 Y136.369 E.0183
G1 X133.534 Y136.974 E.0171
G1 X133.201 Y137.467 E.01447
G1 X132.729 Y138.053 E.0183
G1 X132.222 Y138.576 E.01772
G1 X131.802 Y138.959 E.01383
G1 X131.206 Y139.418 E.0183
G1 X130.566 Y139.824 E.01844
G1 X130.092 Y140.082 E.01313
G1 X129.405 Y140.39 E.01831
G1 X128.662 Y140.645 E.01911
G1 X128.168 Y140.776 E.01243
G1 X127.443 Y140.912 E.01794
G1 X126.786 Y140.959 E.01602
;WIDTH:0.420285
G1 X125.817 Y140.993 E.02489
G1 X121.299 Y140.993 E.11599
G1 X120.942 Y140.931 E.0093
;WIDTH:0.3849
G1 X120.667 Y140.887 E.00649
;WIDTH:0.349516
G1 X110.333 Y140.887 E.21666
;WIDTH:0.384601
G1 X110.018 Y140.94 E.00744
;WIDTH:0.419686
G1 X109.703 Y140.992 E.00818
G1 X105.182 Y140.986 E.11589
;WIDTH:0.415519
G1 X104.403 Y140.992 E.01975
;WIDTH:0.399999
G1 X103.251 Y140.86 E.0282
G1 X102.777 Y140.764 E.01176
G1 X101.979 Y140.532 E.02021
G1 X101.329 Y140.277 E.01698
G1 X100.871 Y140.065 E.01228
G1 X99.794 Y139.416 E.03059
G1 X98.976 Y138.755 E.02558
G1 X98.568 Y138.374 E.01358
G1 X97.758 Y137.411 E.03061
G1 X97.221 Y136.557 E.02454
G1 X96.936 Y136.028 E.01462
G1 X96.483 Y134.854 E.03061
G1 X96.216 Y133.724 E.02824
G1 X96.118 Y132.884 E.02057
G1 X96.118 Y127.642 E.12751
G1 X96.096 Y127.51 E.00326
G1 X96.096 Y95.472 E.77929
G1 X95.998 Y94.98 E.0122
G1 X95.731 Y94.637 E.01057
G1 X103.52 Y94.638 E.18946
G1 X103.52 Y94.638 F9000
G1 X103.537 Y95.004
G1 F6000
G1 X103.537 Y97.934 E.07127
G1 X103.446 Y98.003 E.00278
G1 X103.382 Y98.457 E.01115
G1 X103.382 Y103.792 E.12977
G1 X103.431 Y104.192 E.0098
G1 X103.537 Y104.274 E.00326
G1 X103.537 Y135.892 E.76908
G1 X103.221 Y136.412 E.0148
G1 X103.026 Y137.009 E.01528
G1 X102.974 Y137.531 E.01276
G1 X103.059 Y138.149 E.01517
G1 X103.302 Y138.76 E.01599
G1 X103.537 Y139.108 E.01021
G1 X103.582 Y139.699 E.01442
G1 X103.676 Y139.978 E.00716
G1 X104.249 Y140.606 E.02068
G1 X103.292 Y140.496 E.02343
G1 X102.866 Y140.409 E.01058
G1 X102.097 Y140.186 E.01948
G1 X101.514 Y139.957 E.01524
G1 X101.044 Y139.742 E.01257
G1 X100.004 Y139.116 E.02953
G1 X99.206 Y138.471 E.02496
G1 X98.836 Y138.125 E.01232
G1 X98.055 Y137.195 E.02954
G1 X97.531 Y136.362 E.02394
G1 X97.271 Y135.879 E.01334
G1 X96.833 Y134.746 E.02955
G1 X96.577 Y133.66 E.02714
G1 X96.483 Y132.863 E.01952
G1 X96.483 Y127.642 E.127
G1 X96.462 Y127.478 E.00402
G1 X96.462 Y95.472 E.77851
G1 X96.368 Y95.003 E.01163
G1 X103.477 Y95.004 E.17292
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.537 Y95.004 E-.0285
G1 X103.537 Y97.934 E-1.39175
G1 X103.446 Y98.003 E-.05425
G1 X103.438 Y98.056 E-.0255
;WIPE_END
G1 X127.463 Y95.002 F9000
G1 E5 F2400
G1 F6000
G1 X134.632 Y95.002 E.17438
G1 X134.538 Y95.472 E.01166
G1 X134.537 Y127.168 E.77097
G1 X134.516 Y127.642 E.01154
G1 X134.516 Y132.863 E.127
G1 X134.42 Y133.68 E.02001
G1 X134.275 Y134.369 E.01713
G1 X134.077 Y135.013 E.01639
G1 X133.879 Y135.544 E.01378
G1 X133.568 Y136.197 E.01759
G1 X133.22 Y136.787 E.01666
G1 X132.909 Y137.247 E.01351
G1 X132.455 Y137.81 E.01759
G1 X131.959 Y138.322 E.01734
G1 X131.569 Y138.676 E.01281
G1 X130.996 Y139.118 E.0176
G1 X130.393 Y139.5 E.01736
G1 X129.931 Y139.753 E.01281
G1 X129.271 Y140.05 E.0176
G1 X128.66 Y140.259 E.01571
G1 X128.088 Y140.418 E.01444
G1 X127.396 Y140.549 E.01713
G1 X126.841 Y140.588 E.01353
G1 X127.192 Y140.222 E.01233
G1 X127.412 Y139.722 E.01329
G1 X127.463 Y139.108 E.01499
G1 X127.779 Y138.588 E.0148
G1 X127.944 Y138.136 E.0117
G1 X128.011 Y137.722 E.0102
G1 X128.012 Y137.282 E.0107
G1 X127.927 Y136.804 E.01181
G1 X127.747 Y136.338 E.01215
G1 X127.463 Y135.892 E.01286
G1 X127.463 Y104.274 E.76908
G1 X127.569 Y104.192 E.00326
G1 X127.618 Y103.792 E.0098
G1 X127.618 Y98.462 E.12965
G1 X127.554 Y98.003 E.01127
G1 X127.463 Y97.934 E.00278
G1 X127.463 Y95.062 E.06986
G1 E-5 F3600
G1 X127.463 Y95.062 F9000
G1 X127.733 Y139.195
G1 E5 F2400
;TYPE:Solid infill
G1 F1200
G1 X128.037 Y138.681 E.01453
G1 X128.213 Y138.184 E.01282
G1 X128.298 Y137.509 E.01655
G1 X128.199 Y136.777 E.01797
G1 X130.518 Y139.096 E.07977
G1 X130.184 Y139.309 E.00964
G1 X129.168 Y139.795 E.0274
G1 X128.439 Y140.045 E.01875
G1 X127.481 Y140.24 E.02378
G1 X127.683 Y139.757 E.01273
G1 X127.717 Y139.377 E.00928
G1 X128.084 Y139.373 E.00893
G1 X128.336 Y138.899 E.01306
G1 X128.547 Y138.347 E.01437
G1 X128.643 Y137.738 E.015
G1 X129.929 Y139.025 E.04425
G1 X128.84 Y139.521 E.02911
G1 X128.051 Y139.75 E.01998
G1 X128.068 Y139.555 E.00476
G1 X128.585 Y139.212 E.01509
;WIDTH:0.41782
G1 X128.657 Y139.091 E.00359
G1 X128.886 Y138.511 E.01591
G1 X129.29 Y138.916 E.01459
G1 X128.754 Y139.141 E.01483
G1 E-5 F3600
G1 X128.754 Y139.141 F9000
G1 X130.834 Y138.896
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X127.737 Y135.798 E.10655
G1 X127.737 Y135.281 E.01258
G1 X131.127 Y138.671 E.11661
G1 X131.417 Y138.444 E.00896
G1 X127.737 Y134.764 E.12659
G1 X127.737 Y134.247 E.01258
G1 X131.692 Y138.201 E.13603
G1 X131.947 Y137.94 E.00888
G1 X127.737 Y133.73 E.14482
G1 X127.737 Y133.212 E.0126
G1 X132.202 Y137.677 E.15359
G1 X132.437 Y137.395 E.00893
G1 X127.737 Y132.695 E.16168
G1 X127.737 Y132.178 E.01258
G1 X132.668 Y137.109 E.16962
G1 X132.882 Y136.807 E.009
G1 X127.737 Y131.661 E.177
G1 X127.737 Y131.144 E.01258
G1 X133.079 Y136.486 E.18376
G1 X133.271 Y136.161 E.00918
G1 X127.737 Y130.627 E.19037
G1 X127.737 Y130.11 E.01258
G1 X133.445 Y135.818 E.19635
G1 X133.611 Y135.467 E.00944
G1 X127.737 Y129.593 E.20206
G1 X127.737 Y129.075 E.0126
G1 X133.759 Y135.098 E.20717
G1 X133.884 Y134.706 E.01001
G1 X127.737 Y128.558 E.21147
G1 X127.737 Y128.041 E.01258
G1 X134.006 Y134.31 E.21565
G1 X134.097 Y133.884 E.0106
G1 X127.737 Y127.524 E.21878
G1 X127.737 Y127.007 E.01258
G1 X134.172 Y133.442 E.22136
G1 X134.226 Y132.979 E.01134
G1 X127.737 Y126.49 E.22322
G1 X127.737 Y125.973 E.01258
G1 X134.241 Y132.477 E.22373
G1 X134.241 Y131.96 E.01258
G1 X127.737 Y125.456 E.22373
G1 X127.737 Y124.938 E.0126
G1 X134.241 Y131.443 E.22375
G1 X134.241 Y130.926 E.01258
G1 X127.737 Y124.421 E.22375
G1 X127.737 Y123.904 E.01258
G1 X134.241 Y130.409 E.22375
G1 X134.241 Y129.892 E.01258
G1 X127.737 Y123.387 E.22375
G1 X127.737 Y122.87 E.01258
G1 X134.241 Y129.374 E.22373
G1 X134.241 Y128.857 E.01258
G1 X127.737 Y122.353 E.22373
G1 X127.737 Y121.836 E.01258
G1 X134.241 Y128.34 E.22373
G1 X134.241 Y127.823 E.01258
G1 X127.737 Y121.319 E.22373
G1 X127.737 Y120.801 E.0126
G1 X134.263 Y127.328 E.22451
G1 X134.263 Y126.811 E.01258
G1 X127.737 Y120.284 E.22451
G1 X127.737 Y119.767 E.01258
G1 X134.263 Y126.293 E.22449
G1 X134.263 Y125.776 E.01258
G1 X127.737 Y119.25 E.22449
G1 X127.737 Y118.733 E.01258
G1 X134.263 Y125.259 E.22449
G1 X134.263 Y124.742 E.01258
G1 X127.737 Y118.216 E.22449
G1 X127.737 Y117.699 E.01258
G1 X134.263 Y124.225 E.22449
G1 X134.263 Y123.708 E.01258
G1 X127.737 Y117.182 E.22449
G1 X127.737 Y116.664 E.0126
G1 X134.263 Y123.191 E.22451
G1 X134.263 Y122.674 E.01258
G1 X127.737 Y116.147 E.22451
G1 X127.737 Y115.63 E.01258
G1 X134.263 Y122.157 E.22451
G1 X134.263 Y121.639 E.0126
G1 X127.737 Y115.113 E.22449
G1 X127.737 Y114.596 E.01258
G1 X134.263 Y121.122 E.22449
G1 X134.263 Y120.605 E.01258
G1 X127.737 Y114.079 E.22449
G1 X127.737 Y113.562 E.01258
G1 X134.263 Y120.088 E.22449
G1 X134.263 Y119.571 E.01258
G1 X127.737 Y113.045 E.22449
G1 X127.737 Y112.527 E.0126
G1 X134.263 Y119.054 E.22451
G1 X134.263 Y118.537 E.01258
G1 X127.737 Y112.01 E.22451
G1 X127.737 Y111.493 E.01258
G1 X134.263 Y118.02 E.22451
G1 X134.263 Y117.502 E.0126
G1 X127.737 Y110.976 E.22449
G1 X127.737 Y110.459 E.01258
G1 X134.263 Y116.985 E.22449
G1 X134.263 Y116.468 E.01258
G1 X127.737 Y109.942 E.22449
G1 X127.737 Y109.425 E.01258
G1 X134.263 Y115.951 E.22449
G1 X134.263 Y115.434 E.01258
G1 X127.737 Y108.908 E.22449
G1 X127.737 Y108.39 E.0126
G1 X134.263 Y114.917 E.22451
G1 X134.263 Y114.4 E.01258
G1 X127.737 Y107.873 E.22451
G1 X127.737 Y107.356 E.01258
G1 X134.263 Y113.883 E.22451
G1 X134.263 Y113.365 E.0126
G1 X127.737 Y106.839 E.22449
G1 X127.737 Y106.322 E.01258
G1 X134.263 Y112.848 E.22449
G1 X134.263 Y112.331 E.01258
G1 X127.737 Y105.805 E.22449
G1 X127.737 Y105.288 E.01258
G1 X134.263 Y111.814 E.22449
G1 X134.263 Y111.297 E.01258
G1 X127.737 Y104.771 E.22449
G1 X127.796 Y104.313 E.01123
G1 X134.263 Y110.78 E.22246
G1 X134.263 Y110.263 E.01258
G1 X127.887 Y103.886 E.21935
G1 X127.892 Y103.375 E.01243
G1 X134.263 Y109.746 E.21916
G1 X134.263 Y109.229 E.01258
G1 X127.892 Y102.858 E.21916
G1 X127.892 Y102.34 E.0126
G1 X134.263 Y108.711 E.21916
G1 X134.263 Y108.194 E.01258
G1 X127.892 Y101.823 E.21916
G1 X127.892 Y101.306 E.01258
G1 X134.263 Y107.677 E.21916
G1 X134.263 Y107.16 E.01258
G1 X127.892 Y100.789 E.21916
G1 X127.892 Y100.272 E.01258
G1 X134.263 Y106.643 E.21916
G1 X134.263 Y106.126 E.01258
G1 X127.892 Y99.755 E.21916
G1 X127.892 Y99.238 E.01258
G1 X134.263 Y105.609 E.21916
G1 X134.263 Y105.092 E.01258
G1 X127.892 Y98.721 E.21916
G1 X127.871 Y98.182 E.01312
G1 X134.263 Y104.574 E.21988
G1 X134.263 Y104.057 E.01258
G1 X127.737 Y97.531 E.22449
G1 X127.661 Y97.866 E.00836
;WIDTH:0.374336
G1 X127.672 Y97.907 E.00096
G1 X127.601 Y97.926 E.00166
G1 X127.62 Y97.855 E.00166
G1 X127.62 Y97.855 F9000
G1 X127.737 Y97.014
;WIDTH:0.399999
G1 F1200
G1 X134.263 Y103.54 E.22449
G1 X134.263 Y103.023 E.01258
G1 X127.737 Y96.497 E.22449
G1 X127.737 Y95.979 E.0126
G1 X134.263 Y102.506 E.22451
G1 X134.263 Y101.989 E.01258
G1 X127.737 Y95.462 E.22451
G1 X128.068 Y95.277 E.00922
G1 X134.263 Y101.472 E.2131
G1 X134.263 Y100.955 E.01258
G1 X128.585 Y95.277 E.19532
G1 X129.102 Y95.277 E.01258
G1 X134.263 Y100.438 E.17753
G1 X134.263 Y99.92 E.0126
G1 X129.62 Y95.277 E.15972
G1 X130.137 Y95.277 E.01258
G1 X134.263 Y99.403 E.14193
G1 X134.264 Y98.886 E.01258
G1 X130.654 Y95.277 E.12416
G1 X131.171 Y95.277 E.01258
G1 X134.264 Y98.369 E.10638
G1 X134.264 Y97.852 E.01258
G1 X131.688 Y95.277 E.0886
G1 X132.205 Y95.277 E.01258
G1 X134.264 Y97.335 E.07081
G1 X134.264 Y96.818 E.01258
G1 X132.722 Y95.277 E.05303
G1 X133.239 Y95.277 E.01258
G1 X134.264 Y96.301 E.03524
G1 X134.264 Y95.783 E.0126
G1 X133.757 Y95.277 E.01742
G1 X133.646 Y95.09 E.00529
;WIDTH:0.374336
G1 X133.657 Y95.131 E.00096
G1 X133.586 Y95.15 E.00166
G1 X133.605 Y95.079 E.00166
;WIDTH:0.399999
G1 X134.279 Y95.238 E.01684
;WIDTH:0.414892
G1 X134.258 Y95.318 E.00209
G1 X134.338 Y95.296 E.0021
G1 X134.325 Y95.25 E.00121
G1 E-5 F3600
G1 X134.325 Y95.25 F9000
G1 X126.901 Y137.685
G1 X126.864 Y137.867
G1 X126.349 Y139.849
G1 X104.651 Y139.849
G1 X97.867 Y136.426
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X97.848 Y136.498 E.00168
G1 X97.919 Y136.478 E.00167
G1 X97.908 Y136.437 E.00096
;WIDTH:0.399999
G1 X98.084 Y136.726 E.00823
G1 X100.38 Y139.022 E.07898
G1 X100.668 Y139.194 E.00816
;WIDTH:0.374336
G1 X100.679 Y139.235 E.00096
G1 X100.608 Y139.254 E.00166
G1 X100.627 Y139.183 E.00166
G1 X100.627 Y139.183 F9000
G1 X101.799 Y139.805
G1 F1200
G1 X101.78 Y139.876 E.00166
G1 X101.852 Y139.857 E.00168
G1 X101.841 Y139.816 E.00096
;WIDTH:0.399999
G1 X101.552 Y139.677 E.0078
G1 X97.446 Y135.571 E.14124
G1 X97.446 Y135.571 F9000
G1 X97.12 Y134.728
G1 F1200
G1 X102.372 Y139.98 E.18067
G1 X102.658 Y140.103 E.00757
;WIDTH:0.374336
G1 X102.669 Y140.144 E.00096
G1 X102.598 Y140.163 E.00166
G1 X102.617 Y140.092 E.00166
;WIDTH:0.399999
G1 X103.083 Y140.174 E.01151
G1 X96.948 Y134.039 E.21104
G1 X96.822 Y133.396 E.01594
G1 X103.379 Y139.953 E.22556
G1 X103.565 Y140.213 E.00778
;WIDTH:0.392992
G1 X103.545 Y140.288 E.00185
G1 X103.62 Y140.268 E.00185
G1 X103.608 Y140.225 E.00107
G1 X103.608 Y140.225 F9000
G1 X103.264 Y139.32
;WIDTH:0.399999
G1 F1200
G1 X96.758 Y132.814 E.2238
G1 X96.758 Y132.297 E.01258
G1 X102.849 Y138.389 E.20954
G1 X103.011 Y138.606 E.00659
;WIDTH:0.374336
G1 X102.992 Y138.677 E.00166
G1 X103.063 Y138.658 E.00166
G1 X103.052 Y138.617 E.00096
G1 X103.052 Y138.617 F9000
G1 X102.722 Y137.744
;WIDTH:0.399999
G1 F1200
G1 X96.758 Y131.78 E.20516
G1 X96.758 Y131.263 E.01258
G1 X102.729 Y137.234 E.2054
G1 X102.803 Y136.791 E.01092
G1 X96.758 Y130.746 E.20794
G1 X96.758 Y130.229 E.01258
G1 X102.931 Y136.402 E.21235
G1 X103.105 Y136.059 E.00936
G1 X96.758 Y129.712 E.21833
G1 X96.758 Y129.194 E.0126
G1 X103.263 Y135.7 E.22378
G1 X103.263 Y135.183 E.01258
G1 X96.758 Y128.677 E.22378
G1 X96.758 Y128.16 E.01258
G1 X103.263 Y134.666 E.22378
G1 X103.263 Y134.148 E.0126
G1 X96.758 Y127.643 E.22377
G1 X96.736 Y127.104 E.01312
G1 X103.263 Y133.631 E.22452
G1 X103.263 Y133.114 E.01258
G1 X96.736 Y126.587 E.22452
G1 X96.736 Y126.07 E.01258
G1 X103.263 Y132.597 E.22452
G1 X103.263 Y132.08 E.01258
G1 X96.736 Y125.553 E.22452
G1 X96.736 Y125.036 E.01258
G1 X103.263 Y131.563 E.22452
G1 X103.263 Y131.046 E.01258
G1 X96.736 Y124.519 E.22452
G1 X96.736 Y124.001 E.0126
G1 X103.263 Y130.529 E.22454
G1 X103.263 Y130.011 E.0126
G1 X96.736 Y123.484 E.22452
G1 X96.736 Y122.967 E.01258
G1 X103.263 Y129.494 E.22452
G1 X103.263 Y128.977 E.01258
G1 X96.736 Y122.45 E.22452
G1 X96.736 Y121.933 E.01258
G1 X103.263 Y128.46 E.22452
G1 X103.263 Y127.943 E.01258
G1 X96.736 Y121.416 E.22452
G1 X96.736 Y120.899 E.01258
G1 X103.263 Y127.426 E.22452
G1 X103.263 Y126.909 E.01258
G1 X96.736 Y120.381 E.22454
G1 X96.736 Y119.864 E.01258
G1 X103.263 Y126.392 E.22454
G1 X103.263 Y125.874 E.0126
G1 X96.736 Y119.347 E.22452
G1 X96.736 Y118.83 E.01258
G1 X103.263 Y125.357 E.22452
G1 X103.263 Y124.84 E.01258
G1 X96.736 Y118.313 E.22452
G1 X96.736 Y117.796 E.01258
G1 X103.263 Y124.323 E.22452
G1 X103.263 Y123.806 E.01258
G1 X96.736 Y117.279 E.22452
G1 X96.736 Y116.762 E.01258
G1 X103.263 Y123.289 E.22452
G1 X103.263 Y122.772 E.01258
G1 X96.736 Y116.244 E.22454
G1 X96.736 Y115.727 E.01258
G1 X103.263 Y122.255 E.22454
G1 X103.263 Y121.737 E.0126
G1 X96.736 Y115.21 E.22452
G1 X96.736 Y114.693 E.01258
G1 X103.263 Y121.22 E.22452
G1 X103.263 Y120.703 E.01258
G1 X96.736 Y114.176 E.22452
G1 X96.736 Y113.659 E.01258
G1 X103.263 Y120.186 E.22452
G1 X103.263 Y119.669 E.01258
G1 X96.736 Y113.142 E.22452
G1 X96.736 Y112.625 E.01258
G1 X103.263 Y119.152 E.22452
G1 X103.263 Y118.635 E.01258
G1 X96.736 Y112.107 E.22454
G1 X96.736 Y111.59 E.01258
G1 X103.263 Y118.118 E.22454
G1 X103.263 Y117.6 E.0126
G1 X96.736 Y111.073 E.22452
G1 X96.736 Y110.556 E.01258
G1 X103.263 Y117.083 E.22452
G1 X103.263 Y116.566 E.01258
G1 X96.736 Y110.039 E.22452
G1 X96.736 Y109.522 E.01258
G1 X103.263 Y116.049 E.22452
G1 X103.263 Y115.532 E.01258
G1 X96.736 Y109.005 E.22452
G1 X96.736 Y108.488 E.01258
G1 X103.263 Y115.015 E.22452
G1 X103.263 Y114.498 E.01258
G1 X96.736 Y107.97 E.22454
G1 X96.736 Y107.453 E.01258
G1 X103.263 Y113.981 E.22454
G1 X103.263 Y113.463 E.0126
G1 X96.736 Y106.936 E.22452
G1 X96.736 Y106.419 E.01258
G1 X103.263 Y112.946 E.22452
G1 X103.263 Y112.429 E.01258
G1 X96.736 Y105.902 E.22452
G1 X96.736 Y105.385 E.01258
G1 X103.263 Y111.912 E.22452
G1 X103.263 Y111.395 E.01258
G1 X96.736 Y104.868 E.22452
G1 X96.736 Y104.351 E.01258
G1 X103.263 Y110.878 E.22452
G1 X103.263 Y110.361 E.01258
G1 X96.736 Y103.833 E.22454
G1 X96.736 Y103.316 E.01258
G1 X103.263 Y109.844 E.22454
G1 X103.263 Y109.326 E.0126
G1 X96.736 Y102.799 E.22452
G1 X96.736 Y102.282 E.01258
G1 X103.263 Y108.809 E.22452
G1 X103.263 Y108.292 E.01258
G1 X96.736 Y101.765 E.22452
G1 X96.736 Y101.248 E.01258
G1 X103.263 Y107.775 E.22452
G1 X103.263 Y107.258 E.01258
G1 X96.736 Y100.731 E.22452
G1 X96.736 Y100.214 E.01258
G1 X103.263 Y106.741 E.22452
G1 X103.263 Y106.224 E.01258
G1 X96.736 Y99.696 E.22454
G1 X96.736 Y99.179 E.01258
G1 X103.263 Y105.707 E.22454
G1 X103.263 Y105.189 E.0126
G1 X96.736 Y98.662 E.22452
G1 X96.736 Y98.145 E.01258
G1 X103.263 Y104.672 E.22452
G1 X103.397 Y104.278 E.01012
;WIDTH:0.374336
G1 X103.408 Y104.319 E.00096
G1 X103.337 Y104.339 E.00167
G1 X103.356 Y104.267 E.00168
;WIDTH:0.399999
G1 X103.121 Y104.013 E.00842
G1 X96.736 Y97.628 E.21964
G1 X96.736 Y97.111 E.01258
G1 X103.108 Y103.483 E.21919
G1 X103.108 Y102.965 E.0126
G1 X96.736 Y96.594 E.21918
G1 X96.736 Y96.077 E.01258
G1 X103.108 Y102.448 E.21918
G1 X103.108 Y101.931 E.01258
G1 X96.736 Y95.559 E.21919
G1 X96.614 Y95.176 E.00978
;WIDTH:0.374336
G1 X96.595 Y95.247 E.00166
G1 X96.666 Y95.228 E.00166
G1 X96.655 Y95.187 E.00096
;WIDTH:0.399999
G1 X96.971 Y95.277 E.00799
G1 X103.108 Y101.414 E.21111
G1 X103.108 Y100.897 E.01258
G1 X97.488 Y95.277 E.19332
G1 X98.005 Y95.277 E.01258
G1 X103.108 Y100.38 E.17554
G1 X103.108 Y99.863 E.01258
G1 X98.522 Y95.277 E.15776
G1 X99.039 Y95.277 E.01258
G1 X103.108 Y99.346 E.13997
G1 X103.108 Y98.828 E.0126
G1 X99.557 Y95.277 E.12215
G1 X100.074 Y95.277 E.01258
G1 X103.116 Y98.32 E.10466
G1 X103.202 Y97.889 E.01069
G1 X100.591 Y95.278 E.08982
G1 X101.108 Y95.278 E.01258
G1 X103.263 Y97.433 E.07413
G1 X103.263 Y96.915 E.0126
G1 X101.625 Y95.278 E.05633
G1 X102.143 Y95.278 E.0126
G1 X103.263 Y96.398 E.03853
G1 X103.263 Y95.881 E.01258
G1 X102.66 Y95.278 E.02074
G1 X102.549 Y95.092 E.00527
;WIDTH:0.374336
G1 X102.56 Y95.133 E.00096
G1 X102.489 Y95.152 E.00166
G1 X102.508 Y95.081 E.00166
G1 X102.508 Y95.081 F9000
G1 X103.224 Y95.253
;WIDTH:0.45048
G1 F1200
G1 X103.188 Y95.29 E.00143
G1 X103.201 Y95.34 E.00143
G1 X103.251 Y95.353 E.00143
G1 X103.288 Y95.317 E.00143
G1 X103.275 Y95.266 E.00146
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.288 Y95.317 E-.025
G1 X103.251 Y95.353 E-.02452
G1 X103.201 Y95.34 E-.02454
G1 X103.188 Y95.29 E-.02454
G1 X103.224 Y95.253 E-.02452
;WIPE_END
G1 E-1.37688 F3600
G1 X104.651 Y97.371 F9000
G1 X105.866 Y99.173
G1 X112.136 Y108.459
G1 X112.34 Y108.779
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X112.549 Y108.624 E.00633
G1 X113.044 Y108.43 E.01293
G1 X113.768 Y108.329 E.01778
G1 X117.467 Y108.34 E.08997
G1 X117.983 Y108.438 E.01278
G1 X118.449 Y108.622 E.01219
G1 X119.059 Y109.054 E.01818
G1 X119.418 Y109.466 E.01329
G1 X121.277 Y112.664 E.08998
G1 X121.551 Y113.339 E.01772
G1 X121.632 Y114.089 E.01835
G1 X121.562 Y114.618 E.01298
G1 X121.385 Y115.127 E.01311
G1 X119.419 Y118.533 E.09566
G1 X118.909 Y119.077 E.01814
G1 X118.482 Y119.36 E.01246
G1 X117.783 Y119.609 E.01805
G1 X117.25 Y119.671 E.01305
G1 X113.767 Y119.671 E.08472
G1 X113.228 Y119.615 E.01318
G1 X112.759 Y119.472 E.01193
G1 X112.132 Y119.11 E.01761
G1 X111.581 Y118.534 E.01939
G1 X109.723 Y115.336 E.08996
G1 X109.449 Y114.66 E.01774
G1 X109.369 Y114.132 E.01299
G1 X109.391 Y113.629 E.01225
G1 X109.508 Y113.139 E.01225
G1 X109.714 Y112.68 E.01224
G1 X111.455 Y109.664 E.08471
G1 X111.882 Y109.116 E.0169
G1 X112.291 Y108.814 E.01237
G1 X112.291 Y108.814 F9000
G1 X112.074 Y108.511
;TYPE:Perimeter
G1 F6000
G1 X112.101 Y108.489 E.00085
G1 X112.413 Y108.285 E.00907
G1 X112.987 Y108.069 E.01492
G1 X113.769 Y107.963 E.0192
G1 X117.468 Y107.974 E.08997
G1 X118.029 Y108.074 E.01386
G1 X118.505 Y108.25 E.01234
G1 X119.007 Y108.568 E.01445
G1 X119.369 Y108.844 E.01107
G1 X119.734 Y109.282 E.01387
G1 X121.594 Y112.48 E.08999
G1 X121.89 Y113.203 E.019
G1 X121.996 Y114.053 E.02084
G1 X121.924 Y114.67 E.01511
G1 X121.702 Y115.31 E.01648
G1 X119.735 Y118.716 E.09567
G1 X119.174 Y119.329 E.02021
G1 X118.739 Y119.629 E.01285
G1 X118.204 Y119.849 E.01407
G1 X117.671 Y119.998 E.01346
G1 X117.233 Y120.037 E.0107
G1 X113.767 Y120.037 E.08431
G1 X113.125 Y119.966 E.01571
G1 X112.58 Y119.79 E.01393
G1 X111.949 Y119.426 E.01772
G1 X111.428 Y118.91 E.01784
G1 X111.265 Y118.717 E.00614
G1 X109.406 Y115.52 E.08996
G1 X109.11 Y114.797 E.019
G1 X109.007 Y114.184 E.01512
G1 X109.026 Y113.61 E.01397
G1 X109.153 Y113.052 E.01392
G1 X109.382 Y112.528 E.01391
G1 X111.138 Y109.481 E.08554
G1 X111.594 Y108.891 E.01814
G1 X112.027 Y108.548 E.01344
G1 X112.027 Y108.548 F9000
G1 X111.811 Y108.247
G1 F6000
G1 X112.085 Y108.051 E.00819
G1 X112.669 Y107.788 E.01558
G1 X113.216 Y107.667 E.01363
G1 X113.767 Y107.597 E.01351
G1 X117.469 Y107.608 E.09005
G1 X118.099 Y107.715 E.01554
G1 X118.641 Y107.91 E.01401
G1 X118.893 Y108.038 E.00688
G1 X119.483 Y108.458 E.01762
G1 X119.952 Y108.96 E.01671
G1 X120.051 Y109.099 E.00415
G1 X121.91 Y112.297 E.08998
G1 X122.229 Y113.067 E.02027
G1 X122.291 Y113.317 E.00627
G1 X122.36 Y114.017 E.01711
G1 X122.286 Y114.721 E.01722
G1 X122.09 Y115.336 E.0157
G1 X122.019 Y115.493 E.00419
G1 X120.052 Y118.899 E.09567
G1 X119.724 Y119.281 E.01225
G1 X119.366 Y119.65 E.01251
G1 X118.938 Y119.936 E.01252
G1 X118.684 Y120.069 E.00697
G1 X118 Y120.308 E.01762
G1 X117.233 Y120.403 E.0188
G1 X113.767 Y120.403 E.08431
G1 X113.189 Y120.349 E.01412
G1 X113.022 Y120.317 E.00414
G1 X112.399 Y120.108 E.01598
G1 X111.767 Y119.743 E.01775
G1 X111.561 Y119.581 E.00637
G1 X111.077 Y119.071 E.0171
G1 X110.949 Y118.901 E.00518
G1 X109.09 Y115.703 E.08998
G1 X108.771 Y114.933 E.02027
G1 X108.645 Y114.235 E.01725
G1 X108.661 Y113.591 E.01567
G1 X108.798 Y112.965 E.01559
G1 X109.049 Y112.376 E.01557
G1 X110.821 Y109.298 E.08639
G1 X111.307 Y108.665 E.01941
G1 X111.513 Y108.46 E.00707
G1 X111.762 Y108.282 E.00745
G1 X111.762 Y108.282 F9000
G1 X111.549 Y107.985
G1 F6000
G1 X111.871 Y107.754 E.00964
G1 X112.532 Y107.448 E.01772
G1 X112.892 Y107.344 E.00911
;WIDTH:0.443276
G1 X113.584 Y107.223 E.01911
;WIDTH:0.448854
G1 X113.771 Y107.207 E.00518
;WIDTH:0.45401
G1 X117.232 Y107.215 E.09662
G1 X117.715 Y107.259 E.01354
;WIDTH:0.416339
G1 X118.424 Y107.429 E.01853
;WIDTH:0.399999
G1 X118.965 Y107.654 E.01425
G1 X119.431 Y107.972 E.01372
G1 X119.922 Y108.366 E.01531
G1 X120.367 Y108.915 E.01719
G1 X122.226 Y112.113 E.08998
G1 X122.569 Y112.93 E.02155
G1 X122.655 Y113.281 E.00879
G1 X122.724 Y113.981 E.01711
G1 X122.717 Y114.287 E.00745
G1 X122.642 Y114.813 E.01292
G1 X122.436 Y115.456 E.01642
G1 X122.335 Y115.675 E.00587
G1 X120.369 Y119.082 E.09568
G1 X119.989 Y119.533 E.01434
G1 X119.602 Y119.929 E.01347
G1 X119.137 Y120.243 E.01365
G1 X118.804 Y120.415 E.00912
G1 X118.12 Y120.653 E.01762
;WIDTH:0.431122
G1 X117.786 Y120.719 E.00899
;WIDTH:0.462244
G1 X117.451 Y120.785 E.00972
G1 X117.233 Y120.795 E.00621
;WIDTH:0.45401
G1 X113.772 Y120.793 E.09662
;WIDTH:0.448853
G1 X113.152 Y120.713 E.01724
;WIDTH:0.399999
G1 X112.918 Y120.667 E.0058
G1 X112.219 Y120.426 E.01798
G1 X111.584 Y120.06 E.01783
G1 X111.296 Y119.833 E.00892
G1 X110.812 Y119.323 E.0171
G1 X110.633 Y119.085 E.00724
G1 X108.774 Y115.887 E.08998
G1 X108.431 Y115.069 E.02158
G1 X108.283 Y114.287 E.01936
G1 X108.296 Y113.573 E.01737
G1 X108.442 Y112.878 E.01727
G1 X108.717 Y112.224 E.01726
G1 X110.505 Y109.115 E.08724
G1 X111.019 Y108.439 E.02066
G1 X111.3 Y108.163 E.00958
G1 X111.5 Y108.02 E.00598
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X111.549 Y107.985 E-.0286
G1 X111.871 Y107.754 E-.18824
G1 X112.532 Y107.448 E-.34599
G1 X112.892 Y107.344 E-.17799
G1 X113.584 Y107.223 E-.33369
G1 X113.771 Y107.207 E-.08915
G1 X114.479 Y107.209 E-.33634
;WIPE_END
G1 X112.361 Y108.328 F9000
G1 X112.157 Y108.446
G1 X112.117 Y108.471
G1 X111.925 Y108.608
G1 X111.887 Y108.637
G1 X111.709 Y108.791
G1 X111.674 Y108.824
G1 X111.511 Y108.994
G1 X111.479 Y109.029
G1 X111.334 Y109.215
G1 X111.305 Y109.252
G1 X111.177 Y109.451
G1 X111.159 Y109.48
G1 X109.415 Y112.5
G1 X109.399 Y112.531
G1 X109.291 Y112.741
G1 X109.272 Y112.784
G1 X109.185 Y113.003
G1 X109.171 Y113.049
G1 X109.104 Y113.275
G1 X109.094 Y113.321
G1 X109.049 Y113.553
G1 X109.043 Y113.6
G1 X109.021 Y113.835
G1 X109.019 Y113.882
G1 X109.019 Y114.118
G1 X109.021 Y114.165
G1 X109.043 Y114.4
G1 X109.049 Y114.447
G1 X109.094 Y114.679
G1 X109.104 Y114.725
G1 X109.171 Y114.951
G1 X109.185 Y114.997
G1 X109.272 Y115.216
G1 X109.291 Y115.259
G1 X109.399 Y115.469
G1 X109.415 Y115.5
G1 X111.159 Y118.52
G1 X111.177 Y118.549
G1 X111.305 Y118.748
G1 X111.333 Y118.785
G1 X111.479 Y118.971
G1 X111.511 Y119.006
G1 X111.674 Y119.176
G1 X111.709 Y119.209
G1 X111.887 Y119.363
G1 X111.925 Y119.392
G1 X112.117 Y119.529
G1 X112.157 Y119.554
G1 X112.361 Y119.672
G1 X112.403 Y119.694
G1 X112.618 Y119.792
G1 X112.662 Y119.81
G1 X112.885 Y119.887
G1 X112.93 Y119.902
G1 X113.159 Y119.957
G1 X113.206 Y119.967
G1 X113.439 Y120.001
G1 X113.486 Y120.007
G1 X113.674 Y120.016
G1 X113.509 Y121.992
G1 X113.527 Y122.362
G1 E5 F2400
G1 F6000
G1 X113.768 Y122.329 E.00592
G1 X117.467 Y122.34 E.08997
G1 X117.983 Y122.438 E.01278
G1 X118.449 Y122.622 E.01219
G1 X119.059 Y123.054 E.01818
G1 X119.418 Y123.466 E.01329
G1 X121.277 Y126.664 E.08998
G1 X121.551 Y127.339 E.01772
G1 X121.632 Y128.089 E.01835
G1 X121.562 Y128.618 E.01298
G1 X121.385 Y129.127 E.01311
G1 X119.419 Y132.533 E.09566
G1 X118.909 Y133.077 E.01814
G1 X118.482 Y133.36 E.01246
G1 X117.759 Y133.617 E.01866
G1 X117.233 Y133.671 E.01286
G1 X113.767 Y133.671 E.08431
G1 X113.262 Y133.622 E.01234
G1 X112.759 Y133.472 E.01277
G1 X112.132 Y133.11 E.01761
G1 X111.581 Y132.534 E.01939
G1 X109.723 Y129.336 E.08996
G1 X109.449 Y128.66 E.01774
G1 X109.369 Y128.132 E.01299
G1 X109.391 Y127.629 E.01225
G1 X109.508 Y127.139 E.01225
G1 X109.714 Y126.68 E.01224
G1 X111.455 Y123.664 E.08471
G1 X111.882 Y123.116 E.0169
G1 X112.549 Y122.624 E.02016
G1 X113.044 Y122.43 E.01293
G1 X113.467 Y122.371 E.01039
G1 X113.467 Y122.371 F9000
G1 X113.416 Y122.011
;TYPE:Perimeter
G1 F6000
G1 X113.769 Y121.963 E.00867
G1 X117.468 Y121.974 E.08997
G1 X118.029 Y122.074 E.01386
G1 X118.505 Y122.25 E.01234
G1 X119.007 Y122.568 E.01445
G1 X119.369 Y122.844 E.01107
G1 X119.734 Y123.282 E.01387
G1 X121.594 Y126.48 E.08999
G1 X121.89 Y127.203 E.019
G1 X121.996 Y128.053 E.02084
G1 X121.924 Y128.67 E.01511
G1 X121.702 Y129.31 E.01648
G1 X119.735 Y132.716 E.09567
G1 X119.174 Y133.329 E.02021
G1 X118.681 Y133.666 E.01453
G1 X117.88 Y133.962 E.02077
G1 X117.233 Y134.037 E.01584
G1 X113.767 Y134.037 E.08431
G1 X113.225 Y133.985 E.01324
G1 X112.696 Y133.839 E.01335
G1 X111.949 Y133.426 E.02076
G1 X111.411 Y132.892 E.01844
G1 X111.265 Y132.717 E.00554
G1 X109.406 Y129.52 E.08996
G1 X109.11 Y128.797 E.019
G1 X109.007 Y128.184 E.01512
G1 X109.026 Y127.61 E.01397
G1 X109.153 Y127.052 E.01392
G1 X109.382 Y126.528 E.01391
G1 X111.138 Y123.481 E.08554
G1 X111.594 Y122.891 E.01814
G1 X112.101 Y122.489 E.01574
G1 X112.413 Y122.285 E.00907
G1 X112.987 Y122.069 E.01492
G1 X113.356 Y122.019 E.00906
G1 X113.356 Y122.019 F9000
G1 X113.305 Y121.656
G1 F6000
G1 X113.767 Y121.597 E.01133
G1 X117.469 Y121.608 E.09005
G1 X118.099 Y121.715 E.01554
G1 X118.641 Y121.91 E.01401
G1 X118.893 Y122.038 E.00688
G1 X119.483 Y122.458 E.01762
G1 X119.952 Y122.96 E.01671
G1 X120.051 Y123.099 E.00415
G1 X121.91 Y126.297 E.08998
G1 X122.229 Y127.067 E.02027
G1 X122.291 Y127.317 E.00627
G1 X122.36 Y128.017 E.01711
G1 X122.286 Y128.721 E.01722
G1 X122.09 Y129.336 E.0157
G1 X122.019 Y129.493 E.00419
G1 X120.052 Y132.899 E.09567
G1 X119.439 Y133.581 E.02231
G1 X118.88 Y133.973 E.01661
G1 X118 Y134.308 E.0229
G1 X117.233 Y134.403 E.0188
G1 X113.767 Y134.403 E.08431
G1 X113.189 Y134.349 E.01412
G1 X112.592 Y134.19 E.01503
G1 X111.767 Y133.743 E.02282
G1 X111.561 Y133.581 E.00637
G1 X111.077 Y133.071 E.0171
G1 X110.949 Y132.901 E.00518
G1 X109.09 Y129.703 E.08998
G1 X108.771 Y128.933 E.02027
G1 X108.645 Y128.235 E.01725
G1 X108.661 Y127.591 E.01567
G1 X108.798 Y126.965 E.01559
G1 X109.049 Y126.376 E.01557
G1 X110.821 Y123.298 E.08639
G1 X111.307 Y122.665 E.01941
G1 X111.513 Y122.46 E.00707
G1 X112.085 Y122.051 E.0171
G1 X112.669 Y121.788 E.01558
G1 X113.216 Y121.667 E.01363
G1 X113.245 Y121.663 E.00071
G1 X113.245 Y121.663 F9000
G1 X113.192 Y121.291
;WIDTH:0.443276
G1 F6000
G1 X113.584 Y121.223 E.01082
;WIDTH:0.448853
G1 X113.771 Y121.207 E.00518
;WIDTH:0.45401
G1 X117.232 Y121.215 E.09662
G1 X117.715 Y121.259 E.01354
;WIDTH:0.416339
G1 X118.424 Y121.429 E.01853
;WIDTH:0.399999
G1 X118.965 Y121.654 E.01425
G1 X119.431 Y121.972 E.01372
G1 X119.922 Y122.366 E.01531
G1 X120.367 Y122.915 E.01719
G1 X122.226 Y126.113 E.08998
G1 X122.569 Y126.93 E.02155
G1 X122.655 Y127.281 E.00879
G1 X122.724 Y127.981 E.01711
G1 X122.717 Y128.287 E.00745
G1 X122.642 Y128.813 E.01292
G1 X122.436 Y129.456 E.01642
G1 X122.335 Y129.675 E.00587
G1 X120.369 Y133.082 E.09568
G1 X119.704 Y133.833 E.0244
G1 X119.079 Y134.28 E.01869
G1 X118.804 Y134.415 E.00745
G1 X118.12 Y134.653 E.01762
G1 X117.82 Y134.718 E.00747
G1 X117.233 Y134.768 E.01433
G1 X113.767 Y134.768 E.08431
G1 X113.152 Y134.713 E.01502
G1 X112.489 Y134.541 E.01666
G1 X112.211 Y134.422 E.00736
G1 X111.584 Y134.06 E.01761
G1 X111.296 Y133.833 E.00892
G1 X110.812 Y133.323 E.0171
G1 X110.633 Y133.085 E.00724
G1 X108.774 Y129.887 E.08998
G1 X108.431 Y129.069 E.02158
G1 X108.283 Y128.287 E.01936
G1 X108.296 Y127.573 E.01737
G1 X108.442 Y126.878 E.01727
G1 X108.717 Y126.224 E.01726
G1 X110.505 Y123.115 E.08724
G1 X111.019 Y122.439 E.02066
G1 X111.3 Y122.163 E.00958
G1 X111.871 Y121.754 E.01708
G1 X112.533 Y121.448 E.01774
G1 X112.892 Y121.344 E.00909
;WIDTH:0.443276
G1 X113.133 Y121.302 E.00665
G1 E-5 F3600
G1 X113.133 Y121.302 F9000
G1 X111.674 Y122.824
G1 X111.511 Y122.994
G1 X111.479 Y123.029
G1 X111.334 Y123.215
G1 X111.305 Y123.252
G1 X111.177 Y123.451
G1 X111.159 Y123.48
G1 X109.415 Y126.5
G1 X109.399 Y126.531
G1 X109.291 Y126.741
G1 X109.272 Y126.784
G1 X109.185 Y127.003
G1 X109.171 Y127.049
G1 X109.104 Y127.275
G1 X109.094 Y127.321
G1 X109.049 Y127.553
G1 X109.043 Y127.6
G1 X109.021 Y127.835
G1 X109.019 Y127.882
G1 X109.019 Y128.118
G1 X109.021 Y128.165
G1 X109.043 Y128.4
G1 X109.049 Y128.447
G1 X109.094 Y128.679
G1 X109.104 Y128.725
G1 X109.171 Y128.951
G1 X109.185 Y128.997
G1 X109.272 Y129.216
G1 X109.291 Y129.259
G1 X109.399 Y129.469
G1 X109.415 Y129.5
G1 X112.316 Y134.862
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X112.028 Y134.738 E.00763
G1 X111.401 Y134.376 E.01761
G1 X111.031 Y134.084 E.01146
G1 X110.546 Y133.575 E.0171
G1 X110.317 Y133.269 E.0093
G1 X108.458 Y130.071 E.08998
G1 X108.092 Y129.206 E.02285
G1 X107.99 Y128.824 E.00962
G1 X107.904 Y128.107 E.01757
G1 X107.931 Y127.554 E.01347
G1 X108.087 Y126.791 E.01894
G1 X108.455 Y125.934 E.02269
G1 X110.188 Y122.933 E.08429
G1 X110.731 Y122.213 E.02194
G1 X111.087 Y121.866 E.01209
G1 X111.658 Y121.457 E.01708
G1 X112.003 Y121.267 E.00958
G1 X112.758 Y121.001 E.01947
G1 X112.038 Y120.744 E.0186
G1 X111.401 Y120.376 E.01789
G1 X111.031 Y120.084 E.01146
G1 X110.546 Y119.575 E.0171
G1 X110.317 Y119.269 E.0093
G1 X108.458 Y116.071 E.08998
G1 X108.092 Y115.206 E.02285
G1 X107.99 Y114.824 E.00962
G1 X107.904 Y114.107 E.01757
G1 X107.931 Y113.554 E.01347
G1 X108.087 Y112.791 E.01894
G1 X108.455 Y111.934 E.02269
G1 X110.188 Y108.933 E.08429
G1 X110.731 Y108.213 E.02194
G1 X111.087 Y107.866 E.01209
G1 X111.658 Y107.457 E.01708
G1 X112.003 Y107.267 E.00958
G1 X112.758 Y107.001 E.01947
G1 X112.038 Y106.744 E.0186
G1 X111.401 Y106.376 E.01789
G1 X111.031 Y106.084 E.01146
G1 X110.546 Y105.575 E.0171
G1 X110.317 Y105.269 E.0093
G1 X108.458 Y102.071 E.08998
G1 X108.092 Y101.206 E.02285
G1 X107.99 Y100.824 E.00962
G1 X107.904 Y100.107 E.01757
G1 X107.931 Y99.554 E.01347
G1 X108.087 Y98.791 E.01894
G1 X108.384 Y98.072 E.01892
G1 X110.188 Y94.933 E.08806
G1 X110.735 Y94.209 E.02207
G1 X111.031 Y93.908 E.01027
G1 X111.417 Y93.605 E.01194
G1 X111.754 Y93.401 E.00958
G1 X112.394 Y93.112 E.01708
G1 X112.84 Y92.982 E.0113
G1 X113.535 Y92.883 E.01708
G1 X113.772 Y92.866 E.00578
G1 X117.472 Y92.877 E.09
G1 X118.265 Y93.002 E.01953
G1 X118.976 Y93.256 E.01836
G1 X119.316 Y93.442 E.00943
G1 X119.907 Y93.862 E.01764
G1 X120.329 Y94.278 E.01441
G1 X120.683 Y94.731 E.01398
G1 X122.542 Y97.929 E.08998
G1 X122.908 Y98.794 E.02285
G1 X123.018 Y99.245 E.01129
G1 X123.088 Y99.945 E.01711
G1 X123.079 Y100.338 E.00956
G1 X123.002 Y100.877 E.01324
G1 X122.781 Y101.576 E.01783
G1 X122.552 Y102.031 E.01239
G1 X120.686 Y105.264 E.0908
G1 X120.254 Y105.785 E.01646
G1 X119.838 Y106.209 E.01445
G1 X119.335 Y106.55 E.01478
G1 X118.924 Y106.76 E.01123
G1 X118.242 Y106.998 E.01757
G1 X118.913 Y107.231 E.01728
G1 X119.316 Y107.442 E.01106
G1 X119.907 Y107.862 E.01764
G1 X120.331 Y108.28 E.01448
G1 X120.683 Y108.731 E.01392
G1 X122.542 Y111.929 E.08998
G1 X122.908 Y112.794 E.02285
G1 X123.018 Y113.245 E.01129
G1 X123.088 Y113.945 E.01711
G1 X123.079 Y114.338 E.00956
G1 X123.002 Y114.877 E.01324
G1 X122.781 Y115.576 E.01783
G1 X122.652 Y115.858 E.00754
G1 X120.686 Y119.264 E.09566
G1 X120.254 Y119.785 E.01646
G1 X119.838 Y120.209 E.01445
G1 X119.335 Y120.55 E.01478
G1 X118.924 Y120.76 E.01123
G1 X118.242 Y120.998 E.01757
G1 X118.913 Y121.231 E.01728
G1 X119.316 Y121.442 E.01106
G1 X119.907 Y121.862 E.01764
G1 X120.331 Y122.28 E.01448
G1 X120.683 Y122.731 E.01392
G1 X122.542 Y125.929 E.08998
G1 X122.908 Y126.794 E.02285
G1 X123.018 Y127.245 E.01129
G1 X123.088 Y127.945 E.01711
G1 X123.079 Y128.338 E.00956
G1 X123.002 Y128.877 E.01324
G1 X122.781 Y129.576 E.01783
G1 X122.652 Y129.858 E.00754
G1 X120.686 Y133.264 E.09566
G1 X120.385 Y133.647 E.01185
G1 X119.97 Y134.084 E.01466
G1 X119.671 Y134.332 E.00945
G1 X119.278 Y134.587 E.0114
G1 X118.924 Y134.76 E.00958
G1 X118.24 Y134.998 E.01762
G1 X117.854 Y135.082 E.00961
G1 X117.233 Y135.134 E.01516
G1 X113.767 Y135.134 E.08431
G1 X113.116 Y135.077 E.0159
G1 X112.386 Y134.892 E.01832
G1 X112.371 Y134.885 E.0004
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X112.316 Y134.862 E-.02832
G1 X112.028 Y134.738 E-.14894
G1 X111.401 Y134.376 E-.3439
G1 X111.031 Y134.084 E-.22389
G1 X110.546 Y133.575 E-.33396
G1 X110.317 Y133.269 E-.18155
G1 X110.064 Y132.833 E-.23944
;WIPE_END
G1 X109.104 Y128.725 F9000
G1 X109.043 Y128.4
G1 X109.043 Y113.6
G1 X109.415 Y112.5
G1 X111.159 Y109.48
G1 X112.403 Y108.306
G1 X112.618 Y108.208
G1 X112.662 Y108.19
G1 X112.885 Y108.113
G1 X112.93 Y108.098
G1 X113.159 Y108.043
G1 X113.206 Y108.033
G1 X113.436 Y107.999
G1 X113.737 Y106.019
G1 X113.752 Y105.67
G1 E5 F2400
G1 F6000
G1 X113.262 Y105.622 E.01198
G1 X112.76 Y105.472 E.01274
G1 X112.132 Y105.11 E.01763
G1 X111.581 Y104.534 E.01939
G1 X109.721 Y101.333 E.09005
G1 X109.449 Y100.66 E.01766
G1 X109.367 Y100.107 E.0136
G1 X109.396 Y99.595 E.01247
G1 X109.519 Y99.106 E.01226
G1 X109.722 Y98.665 E.01181
G1 X111.455 Y95.664 E.08429
G1 X111.885 Y95.112 E.01702
G1 X112.32 Y94.757 E.01366
G1 X112.997 Y94.444 E.01814
G1 X113.768 Y94.329 E.01896
G1 X117.467 Y94.34 E.08997
G1 X117.983 Y94.438 E.01278
G1 X118.469 Y94.635 E.01276
G1 X119.059 Y95.054 E.0176
G1 X119.418 Y95.466 E.01329
G1 X121.277 Y98.664 E.08998
G1 X121.551 Y99.339 E.01772
G1 X121.631 Y100.132 E.01939
G1 X121.554 Y100.652 E.01279
G1 X121.385 Y101.127 E.01226
G1 X119.419 Y104.533 E.09566
G1 X118.909 Y105.077 E.01814
G1 X118.482 Y105.36 E.01246
G1 X117.783 Y105.609 E.01805
G1 X117.25 Y105.671 E.01305
G1 X113.812 Y105.671 E.08363
G1 X113.812 Y105.671 F9000
G1 X113.812 Y106.037
;TYPE:Perimeter
G1 F6000
G1 X113.767 Y106.037 E.00109
G1 X113.225 Y105.985 E.01324
G1 X112.696 Y105.839 E.01335
G1 X112.159 Y105.547 E.01487
G1 X111.826 Y105.329 E.00968
G1 X111.342 Y104.819 E.0171
G1 X111.265 Y104.717 E.00311
G1 X109.406 Y101.52 E.08996
G1 X109.11 Y100.797 E.019
G1 X109.001 Y100.107 E.01699
G1 X109.032 Y99.553 E.0135
G1 X109.153 Y99.052 E.01254
G1 X109.405 Y98.482 E.01516
G1 X111.138 Y95.481 E.08429
G1 X111.598 Y94.887 E.01827
G1 X112.094 Y94.469 E.01578
G1 X112.847 Y94.111 E.02028
G1 X113.69 Y93.969 E.02079
G1 X117.468 Y93.974 E.0919
G1 X118.054 Y94.079 E.01448
G1 X118.567 Y94.275 E.01336
G1 X119.271 Y94.756 E.02074
G1 X119.675 Y95.199 E.01458
G1 X121.594 Y98.48 E.09246
G1 X121.89 Y99.203 E.019
G1 X121.979 Y99.884 E.01671
G1 X121.993 Y100.184 E.00731
G1 X121.921 Y100.687 E.01236
G1 X121.745 Y101.216 E.01356
G1 X119.735 Y104.716 E.09817
G1 X119.174 Y105.329 E.02021
G1 X118.739 Y105.629 E.01285
G1 X118.204 Y105.849 E.01407
G1 X117.671 Y105.998 E.01346
G1 X117.233 Y106.037 E.0107
G1 X113.872 Y106.037 E.08175
G1 X113.872 Y106.037 F9000
G1 X113.872 Y106.403
G1 F6000
G1 X113.767 Y106.403 E.00255
G1 X113.189 Y106.349 E.01412
G1 X112.657 Y106.209 E.01338
G1 X112.394 Y106.105 E.00688
G1 X111.767 Y105.743 E.01761
G1 X111.561 Y105.581 E.00637
G1 X111.077 Y105.071 E.0171
G1 X110.949 Y104.901 E.00518
G1 X109.09 Y101.703 E.08998
G1 X108.771 Y100.933 E.02027
G1 X108.636 Y100.107 E.02036
G1 X108.661 Y99.591 E.01257
G1 X108.798 Y98.965 E.01559
G1 X109.049 Y98.376 E.01557
G1 X110.821 Y95.298 E.08639
G1 X111.31 Y94.661 E.01953
G1 X111.869 Y94.181 E.01792
G1 X112.696 Y93.778 E.02238
G1 X112.944 Y93.706 E.00628
G1 X113.77 Y93.597 E.02027
G1 X117.469 Y93.608 E.08997
G1 X118.124 Y93.72 E.01616
G1 X118.703 Y93.935 E.01502
G1 X119.483 Y94.458 E.02284
G1 X119.952 Y94.96 E.01671
G1 X120.051 Y95.099 E.00415
G1 X121.91 Y98.297 E.08998
G1 X122.229 Y99.067 E.02027
G1 X122.291 Y99.317 E.00627
G1 X122.36 Y100.017 E.01711
G1 X122.286 Y100.721 E.01722
G1 X122.09 Y101.336 E.0157
G1 X121.742 Y101.972 E.01763
G1 X120.052 Y104.899 E.08221
G1 X119.724 Y105.281 E.01225
G1 X119.366 Y105.65 E.01251
G1 X118.938 Y105.936 E.01252
G1 X118.684 Y106.069 E.00697
G1 X118 Y106.308 E.01762
G1 X117.233 Y106.403 E.0188
G1 X113.932 Y106.403 E.08029
G1 X113.932 Y106.403 F9000
G1 X113.932 Y106.793
;WIDTH:0.45401
G1 F6000
G1 X113.772 Y106.793 E.00447
;WIDTH:0.448854
G1 X113.152 Y106.713 E.01724
;WIDTH:0.399999
G1 X112.554 Y106.56 E.01501
G1 X112.211 Y106.422 E.00899
G1 X111.584 Y106.06 E.01761
G1 X111.296 Y105.833 E.00892
G1 X110.812 Y105.323 E.0171
G1 X110.633 Y105.085 E.00724
G1 X108.774 Y101.887 E.08998
G1 X108.431 Y101.069 E.02158
G1 X108.283 Y100.287 E.01936
G1 X108.27 Y100.107 E.00439
G1 X108.296 Y99.573 E.013
G1 X108.442 Y98.878 E.01727
G1 X108.772 Y98.117 E.02018
G1 X110.505 Y95.115 E.08431
G1 X111.022 Y94.435 E.02078
G1 X111.257 Y94.196 E.00815
G1 X111.905 Y93.734 E.01936
G1 X112.545 Y93.445 E.01708
G1 X112.892 Y93.344 E.00879
G1 X113.771 Y93.232 E.02155
G1 X117.471 Y93.243 E.09
G1 X118.195 Y93.361 E.01784
G1 X118.84 Y93.596 E.0167
G1 X119.104 Y93.74 E.00731
G1 X119.695 Y94.16 E.01764
G1 X120.052 Y94.517 E.01228
G1 X120.367 Y94.915 E.01235
G1 X122.226 Y98.113 E.08998
G1 X122.569 Y98.93 E.02155
G1 X122.655 Y99.281 E.00879
G1 X122.724 Y99.981 E.01711
G1 X122.717 Y100.287 E.00745
G1 X122.642 Y100.813 E.01292
G1 X122.436 Y101.456 E.01642
G1 X122.059 Y102.155 E.01932
G1 X120.369 Y105.082 E.08221
G1 X119.989 Y105.533 E.01434
G1 X119.602 Y105.929 E.01347
G1 X119.137 Y106.243 E.01365
G1 X118.804 Y106.415 E.00912
G1 X118.12 Y106.653 E.01762
;WIDTH:0.431122
G1 X117.786 Y106.719 E.00899
;WIDTH:0.462244
G1 X117.451 Y106.785 E.00972
G1 X117.233 Y106.795 E.00621
;WIDTH:0.45401
G1 X113.992 Y106.793 E.09048
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.932 Y106.793 E-.0285
G1 X113.772 Y106.793 E-.076
G1 X113.152 Y106.713 E-.29694
G1 X112.554 Y106.56 E-.2932
G1 X112.211 Y106.422 E-.17562
G1 X111.584 Y106.06 E-.3439
G1 X111.296 Y105.833 E-.17419
G1 X111.134 Y105.663 E-.11165
;WIPE_END
G1 X111.66 Y105.162 F9000
G1 X106.099 Y103.505
G1 X105.669 Y103.505
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.567 Y103.424 E.00317
G1 X105.457 Y103.424 E.00268
G1 X105.457 Y98.824 E.11189
G1 X105.567 Y98.824 E.00268
G1 X105.725 Y98.734 E.00442
G1 X105.75 Y98.642 E.00232
G1 X105.75 Y91.689 E.16912
G1 X105.708 Y91.572 E.00302
G1 X105.359 Y91.152 E.01328
G1 X105.13 Y90.774 E.01075
G1 X105.074 Y90.501 E.00678
G1 X105.113 Y90.323 E.00443
G1 X105.249 Y90.008 E.00835
G1 X105.595 Y89.559 E.01379
G1 X125.401 Y89.559 E.48176
G1 X125.806 Y90.091 E.01626
G1 X125.913 Y90.397 E.00789
G1 X125.911 Y90.597 E.00487
G1 X125.793 Y90.932 E.00864
G1 X125.289 Y91.576 E.01989
G1 X125.25 Y91.688 E.00288
G1 X125.257 Y98.691 E.17034
G1 X125.433 Y98.824 E.00537
G1 X125.543 Y98.824 E.00268
G1 X125.543 Y103.424 E.11189
G1 X125.433 Y103.424 E.00268
G1 X125.272 Y103.521 E.00457
G1 X125.25 Y103.607 E.00216
G1 X125.25 Y136.311 E.79549
G1 X125.292 Y136.428 E.00302
G1 X125.641 Y136.848 E.01328
G1 X125.87 Y137.226 E.01075
G1 X125.926 Y137.499 E.00678
G1 X125.887 Y137.677 E.00443
G1 X125.751 Y137.992 E.00835
G1 X125.405 Y138.441 E.01379
G1 X105.599 Y138.441 E.48176
G1 X105.258 Y137.993 E.01369
G1 X105.099 Y137.685 E.00843
G1 X105.089 Y137.403 E.00686
G1 X105.207 Y137.068 E.00864
G1 X105.711 Y136.424 E.01989
G1 X105.75 Y136.312 E.00288
G1 X105.75 Y103.607 E.79552
G1 X105.745 Y103.565 E.00103
G1 X105.716 Y103.542 E.0009
G1 X105.716 Y103.542 F9000
G1 X105.907 Y103.264
;TYPE:Perimeter
G1 F6000
G1 X105.822 Y103.211 E.00244
G1 X105.822 Y99.044 E.10136
G1 X106.041 Y98.918 E.00615
G1 X106.116 Y98.642 E.00696
G1 X106.116 Y91.689 E.16912
G1 X106.091 Y91.525 E.00404
G1 X105.989 Y91.339 E.00516
G1 X105.641 Y90.918 E.01329
G1 X105.465 Y90.586 E.00914
G1 X105.485 Y90.335 E.00612
G1 X105.77 Y89.925 E.01215
G1 X125.22 Y89.925 E.4731
G1 X125.451 Y90.228 E.00927
G1 X125.551 Y90.45 E.00592
G1 X125.557 Y90.492 E.00103
G1 X125.479 Y90.74 E.00632
G1 X125.001 Y91.35 E.01885
G1 X124.884 Y91.688 E.0087
G1 X124.884 Y98.642 E.16915
G1 X124.959 Y98.918 E.00696
G1 X125.178 Y99.044 E.00615
G1 X125.178 Y103.211 E.10136
G1 X124.95 Y103.348 E.00647
G1 X124.884 Y103.607 E.0065
G1 X124.884 Y136.311 E.79549
G1 X124.909 Y136.475 E.00404
G1 X125.011 Y136.661 E.00516
G1 X125.359 Y137.082 E.01329
G1 X125.535 Y137.414 E.00914
G1 X125.515 Y137.665 E.00612
G1 X125.23 Y138.075 E.01215
G1 X105.78 Y138.075 E.4731
G1 X105.513 Y137.724 E.01073
G1 X105.443 Y137.507 E.00555
G1 X105.521 Y137.26 E.0063
G1 X105.999 Y136.65 E.01885
G1 X106.116 Y136.312 E.0087
G1 X106.116 Y103.607 E.79552
G1 X106.055 Y103.356 E.00628
G1 X105.958 Y103.295 E.00279
G1 X105.958 Y103.295 F9000
G1 X106.188 Y103.024
G1 F6000
G1 X106.188 Y99.199 E.09304
G1 X106.356 Y99.103 E.00471
G1 X106.396 Y99.028 E.00207
G1 X106.481 Y98.642 E.00961
G1 X106.481 Y91.689 E.16912
G1 X106.44 Y91.416 E.00671
G1 X106.271 Y91.105 E.00861
G1 X105.922 Y90.685 E.01328
G1 X105.823 Y90.512 E.00485
G1 X105.944 Y90.29 E.00615
G1 X125.039 Y90.29 E.46447
G1 X125.185 Y90.5 E.00622
G1 X125.165 Y90.548 E.00126
G1 X124.713 Y91.125 E.01783
G1 X124.519 Y91.688 E.01448
G1 X124.523 Y98.732 E.17134
G1 X124.643 Y99.102 E.00946
G1 X124.812 Y99.199 E.00474
G1 X124.812 Y103.064 E.09401
G1 X124.627 Y103.175 E.00525
G1 X124.574 Y103.294 E.00317
G1 X124.519 Y103.607 E.00773
G1 X124.519 Y136.311 E.79549
G1 X124.56 Y136.584 E.00671
G1 X124.729 Y136.895 E.00861
G1 X125.078 Y137.315 E.01328
G1 X125.177 Y137.488 E.00485
G1 X125.056 Y137.71 E.00615
G1 X105.961 Y137.71 E.46447
G1 X105.837 Y137.547 E.00498
G1 X105.835 Y137.452 E.00231
G1 X106.287 Y136.875 E.01783
G1 X106.481 Y136.312 E.01448
G1 X106.481 Y103.607 E.79552
G1 X106.456 Y103.395 E.00519
G1 X106.38 Y103.188 E.00536
G1 X106.205 Y103.075 E.00507
G1 X106.205 Y103.075 F9000
G1 X106.554 Y102.756
G1 F6000
G1 X106.554 Y99.355 E.08273
G1 X106.672 Y99.287 E.00331
G1 X106.778 Y99.058 E.00614
G1 X106.847 Y98.642 E.01026
G1 X106.847 Y91.689 E.16912
G1 X106.789 Y91.307 E.0094
G1 X106.552 Y90.872 E.01205
G1 X106.373 Y90.656 E.00682
G1 X124.616 Y90.656 E.44374
G1 X124.425 Y90.899 E.00752
G1 X124.153 Y91.688 E.0203
G1 X124.165 Y98.816 E.17338
G1 X124.328 Y99.287 E.01212
G1 X124.446 Y99.355 E.00331
G1 X124.446 Y102.917 E.08664
G1 X124.305 Y103.002 E.004
G1 X124.231 Y103.168 E.00442
G1 X124.153 Y103.607 E.01085
G1 X124.153 Y136.311 E.79549
G1 X124.211 Y136.693 E.0094
G1 X124.448 Y137.128 E.01205
G1 X124.627 Y137.344 E.00682
G1 X106.384 Y137.344 E.44374
G1 X106.575 Y137.101 E.00752
G1 X106.847 Y136.312 E.0203
G1 X106.847 Y103.607 E.79552
G1 X106.812 Y103.311 E.00725
G1 X106.705 Y103.021 E.00752
G1 X106.554 Y102.917 E.00446
G1 X106.554 Y102.816 E.00246
G1 X106.554 Y102.816 F9000
G1 X106.919 Y102.483
G1 F6000
G1 X106.919 Y99.511 E.07229
G1 X106.988 Y99.472 E.00193
G1 X107.123 Y99.176 E.00791
G1 X107.213 Y98.642 E.01317
G1 X107.213 Y91.689 E.16912
G1 X107.138 Y91.197 E.01211
G1 X107.042 Y91.022 E.00486
G1 X124.017 Y91.022 E.4129
G1 X123.787 Y91.688 E.01714
G1 X123.787 Y98.624 E.16871
G1 X123.849 Y99.087 E.01136
G1 X124.012 Y99.471 E.01015
G1 X124.081 Y99.511 E.00194
G1 X124.081 Y102.77 E.07927
G1 X123.983 Y102.829 E.00278
G1 X123.887 Y103.043 E.00571
G1 X123.787 Y103.607 E.01393
G1 X123.787 Y136.311 E.79549
G1 X123.862 Y136.803 E.01211
G1 X123.958 Y136.978 E.00486
G1 X106.983 Y136.978 E.4129
G1 X107.213 Y136.312 E.01714
G1 X107.213 Y103.607 E.79552
G1 X107.168 Y103.226 E.00933
G1 X107.03 Y102.853 E.00967
G1 X106.919 Y102.77 E.00337
G1 X106.919 Y102.543 E.00552
G1 E-5 F3600
G1 X106.919 Y102.543 F9000
G1 X107.384 Y136.632
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.444708
G1 F1200
G1 X107.347 Y136.669 E.00143
G1 X107.361 Y136.718 E.00139
G1 X107.41 Y136.731 E.00138
G1 X107.447 Y136.695 E.00141
G1 X107.433 Y136.646 E.00139
;WIDTH:0.399999
G1 X107.487 Y136.223 E.01037
G1 X107.968 Y136.704 E.01655
G1 X108.485 Y136.704 E.01258
G1 X107.487 Y135.706 E.03433
G1 X107.487 Y135.189 E.01258
G1 X109.002 Y136.704 E.05211
G1 X109.52 Y136.704 E.0126
G1 X107.487 Y134.672 E.06992
G1 X107.487 Y134.154 E.0126
G1 X110.037 Y136.704 E.08772
G1 X110.554 Y136.704 E.01258
G1 X107.487 Y133.637 E.1055
G1 X107.487 Y133.12 E.01258
G1 X111.071 Y136.704 E.12329
G1 X111.588 Y136.704 E.01258
G1 X107.487 Y132.603 E.14107
G1 X107.487 Y132.086 E.01258
G1 X112.105 Y136.704 E.15886
G1 X112.622 Y136.704 E.01258
G1 X107.487 Y131.569 E.17664
G1 X107.487 Y131.052 E.01258
G1 X113.139 Y136.704 E.19443
G1 X113.139 Y136.704 F9000
G1 X112.087 Y135.134
G1 F1200
G1 X113.527 Y136.575 E.04955
G1 X113.527 Y136.704 E.00314
G1 X123.572 Y136.704 E.24433
G1 X123.513 Y136.304 E.00983
G1 X123.513 Y129.295 E.17049
;WIDTH:0.446251
G1 X123.49 Y129.21 E.00241
;WIDTH:0.492503
G1 X123.467 Y129.124 E.00271
;WIDTH:0.538755
G1 X123.444 Y129.039 E.00295
;WIDTH:0.585006
G1 X123.421 Y128.954 E.00323
;WIDTH:0.631258
G1 X123.397 Y128.868 E.00355
G1 X123.356 Y128.941 E.00332
;WIDTH:0.585006
G1 X123.315 Y129.015 E.0031
;WIDTH:0.538755
G1 X123.273 Y129.088 E.00283
;WIDTH:0.492503
G1 X123.232 Y129.161 E.00255
;WIDTH:0.446251
G1 X123.19 Y129.234 E.00231
;WIDTH:0.399999
G1 X122.887 Y129.999 E.02001
G1 X120.926 Y133.397 E.09543
G1 X120.583 Y133.836 E.01355
G1 X120.172 Y134.269 E.01452
G1 X119.816 Y134.565 E.01126
G1 X119.412 Y134.825 E.01169
G1 X119.009 Y135.021 E.0109
G1 X118.336 Y135.255 E.01733
G1 X117.873 Y135.356 E.01153
G1 X117.229 Y135.408 E.01572
G1 X113.771 Y135.408 E.08411
G1 X113.095 Y135.35 E.0165
G1 X112.32 Y135.158 E.01942
G1 X111.957 Y135.005 E.00958
G1 X111.957 Y135.005 F9000
G1 X113.327 Y135.787
;WIDTH:0.499473
G1 F1200
G1 X113.771 Y135.824 E.01379
G1 X117.229 Y135.824 E.10699
;WIDTH:0.500863
G1 X117.278 Y135.822 E.00152
;WIDTH:0.531731
G1 X117.964 Y135.779 E.02274
G1 X118.128 Y135.72 E.00577
;WIDTH:0.487821
G1 X118.292 Y135.66 E.00527
;WIDTH:0.44391
G1 X118.456 Y135.601 E.00475
;WIDTH:0.399999
G1 X119.13 Y135.366 E.01736
G1 X119.573 Y135.154 E.01195
G1 X120.014 Y134.872 E.01273
G1 X120.437 Y134.521 E.01337
G1 X120.914 Y134.019 E.01684
G1 X121.242 Y133.58 E.01333
G1 X123.147 Y130.28 E.09268
G1 X123.15 Y136.339 E.14738
G1 X118.47 Y136.339 E.11384
;WIDTH:0.442224
G1 X118.29 Y136.317 E.00492
;WIDTH:0.484449
G1 X118.109 Y136.296 E.00546
;WIDTH:0.526673
G1 X117.928 Y136.275 E.00597
G1 X117.229 Y136.289 E.0229
;WIDTH:0.499473
G1 X113.821 Y136.281 E.10545
G1 X113.457 Y135.917 E.01593
G1 E-5 F3600
G1 X113.457 Y135.917 F9000
G1 X110.446 Y133.678
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X109.892 Y132.999 E.01982
;WIDTH:0.399999
G1 X109.693 Y132.74 E.00794
G1 X107.487 Y130.535 E.07587
G1 X107.617 Y130.147 E.00995
G1 X108.975 Y131.505 E.04671
G1 X109.163 Y131.723 E.007
;WIDTH:0.374336
G1 X109.144 Y131.794 E.00166
G1 X109.215 Y131.775 E.00166
G1 X109.204 Y131.734 E.00096
G1 E-5 F3600
G1 X109.204 Y131.734 F9000
G1 X107.499 Y129.563
G1 E5 F2400
;WIDTH:0.424281
G1 F1200
G1 X107.499 Y129.744 E.0047
G1 X107.655 Y129.697 E.00423
G1 X107.754 Y129.751 E.00293
G1 X108.202 Y130.198 E.01642
G1 X107.821 Y129.298 E.02535
;WIDTH:0.467933
G1 X107.779 Y129.226 E.0024
;WIDTH:0.511586
G1 X107.736 Y129.155 E.00264
;WIDTH:0.555238
G1 X107.693 Y129.084 E.00288
;WIDTH:0.59889
G1 X107.651 Y129.013 E.0031
;WIDTH:0.642542
G1 X107.608 Y128.942 E.00336
G1 X107.586 Y129.029 E.00363
;WIDTH:0.59889
G1 X107.565 Y129.117 E.0034
;WIDTH:0.555238
G1 X107.543 Y129.205 E.00314
;WIDTH:0.511586
G1 X107.521 Y129.293 E.00288
;WIDTH:0.467933
G1 X107.499 Y129.38 E.00259
;WIDTH:0.399999
G1 X107.608 Y128.942 E.01098
;WIDTH:0.642542
G1 X107.584 Y128.539 E.01633
;WIDTH:0.593884
G1 X107.56 Y128.136 E.01503
;WIDTH:0.582208
G1 X107.578 Y127.666 E.01714
;WIDTH:0.61919
G1 X107.596 Y127.196 E.0183
;WIDTH:0.399999
G1 X107.508 Y126.525 E.01646
;WIDTH:0.491019
G1 X107.532 Y126.729 E.00624
;WIDTH:0.539241
G1 X107.557 Y126.934 E.00694
;WIDTH:0.587464
G1 X107.581 Y127.138 E.00756
;WIDTH:0.61919
G1 X107.596 Y127.196 E.00233
G1 X107.664 Y127.038 E.00669
;WIDTH:0.575352
G1 X107.731 Y126.88 E.00618
;WIDTH:0.531514
G1 X107.798 Y126.722 E.00568
;WIDTH:0.487676
G1 X107.865 Y126.564 E.00518
;WIDTH:0.443837
G1 X107.932 Y126.406 E.00467
;WIDTH:0.399999
G1 X108.22 Y125.793 E.01647
G1 X109.949 Y122.798 E.08412
G1 X110.229 Y122.417 E.0115
G1 X107.487 Y119.675 E.09432
G1 X107.487 Y126.343 E.16219
G1 X107.853 Y125.713 E.01772
G1 X107.853 Y120.558 E.12539
G1 X109.748 Y122.453 E.06519
G1 X109.632 Y122.615 E.00485
G1 X107.937 Y125.551 E.08246
G1 X107.937 Y125.551 F9000
G1 X108.218 Y124.333
G1 F1200
G1 X108.218 Y121.441 E.07035
G1 X109.277 Y122.499 E.03641
G1 X108.31 Y124.175 E.04707
G1 X108.31 Y124.175 F9000
G1 X108.74 Y122.526
;WIDTH:0.60999
G1 F1200
G1 X108.758 Y122.595 E.00273
G1 X108.708 Y122.646 E.00273
G1 X108.638 Y122.628 E.00277
G1 X108.619 Y122.558 E.00278
G1 X108.67 Y122.507 E.00276
G1 X108.67 Y122.507 F9000
G1 X110.453 Y122.124
;WIDTH:0.399999
G1 F1200
G1 X107.487 Y119.158 E.10203
G1 X107.487 Y118.641 E.01258
G1 X110.695 Y121.849 E.11035
G1 X110.979 Y121.615 E.00895
G1 X107.487 Y118.124 E.12011
G1 X107.487 Y117.606 E.0126
G1 X111.277 Y121.396 E.13037
G1 X111.584 Y121.186 E.00905
G1 X107.487 Y117.089 E.14093
G1 X107.487 Y116.572 E.01258
G1 X109.745 Y118.83 E.07767
G1 X109.944 Y119.089 E.00794
;WIDTH:0.374336
G1 X110.431 Y119.681 E.01734
G1 X111.066 Y120.325 E.02045
;WIDTH:0.397658
G1 X111.883 Y120.97 E.02516
;WIDTH:0.419142
G1 X111.934 Y121.005 E.00158
G1 E-5 F3600
G1 X111.934 Y121.005 F9000
G1 X109.256 Y117.823
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X109.267 Y117.864 E.00096
G1 X109.196 Y117.884 E.00167
G1 X109.215 Y117.812 E.00168
;WIDTH:0.399999
G1 X109.027 Y117.595 E.00698
G1 X107.587 Y116.155 E.04954
G1 X107.994 Y116.045 E.01026
G1 X108.309 Y116.36 E.01084
G1 X108.497 Y116.577 E.00698
;WIDTH:0.374336
G1 X108.478 Y116.648 E.00166
G1 X108.549 Y116.629 E.00166
G1 X108.538 Y116.588 E.00096
G1 X108.538 Y116.588 F9000
G1 X107.565 Y115.119
;WIDTH:0.55573
G1 F1200
G1 X107.543 Y115.206 E.00311
;WIDTH:0.513192
G1 X107.522 Y115.293 E.00285
;WIDTH:0.470655
G1 X107.501 Y115.38 E.0026
;WIDTH:0.428117
G1 X107.501 Y115.81 E.01126
G1 X107.796 Y115.707 E.00818
G1 X107.855 Y115.647 E.0022
G1 X107.959 Y115.647 E.00272
G1 X107.82 Y115.298 E.00984
;WIDTH:0.471002
G1 X107.777 Y115.227 E.00241
;WIDTH:0.513887
G1 X107.735 Y115.156 E.00263
;WIDTH:0.556772
G1 X107.693 Y115.084 E.0029
;WIDTH:0.599657
G1 X107.65 Y115.013 E.00312
;WIDTH:0.642542
G1 X107.608 Y114.942 E.00334
G1 X107.584 Y114.539 E.01633
;WIDTH:0.593883
G1 X107.56 Y114.136 E.01503
;WIDTH:0.582204
G1 X107.578 Y113.666 E.01714
;WIDTH:0.619184
G1 X107.596 Y113.196 E.0183
;WIDTH:0.399999
G1 X107.508 Y112.525 E.01646
;WIDTH:0.491016
G1 X107.532 Y112.729 E.00624
;WIDTH:0.539238
G1 X107.557 Y112.934 E.00694
;WIDTH:0.58746
G1 X107.581 Y113.138 E.00756
;WIDTH:0.619184
G1 X107.596 Y113.196 E.00233
G1 X107.664 Y113.038 E.00669
;WIDTH:0.575347
G1 X107.731 Y112.88 E.00618
;WIDTH:0.53151
G1 X107.798 Y112.722 E.00568
;WIDTH:0.487673
G1 X107.865 Y112.564 E.00518
;WIDTH:0.443836
G1 X107.932 Y112.406 E.00467
;WIDTH:0.399999
G1 X108.22 Y111.793 E.01647
G1 X109.949 Y108.798 E.08412
G1 X110.213 Y108.438 E.01086
G1 X107.487 Y105.713 E.09376
G1 X107.487 Y112.343 E.16127
G1 X107.853 Y111.713 E.01772
G1 X107.853 Y106.595 E.12449
G1 X109.732 Y108.475 E.06465
G1 X109.632 Y108.615 E.00418
G1 X107.937 Y111.551 E.08246
G1 X107.937 Y111.551 F9000
G1 X108.218 Y110.333
G1 F1200
G1 X108.218 Y107.478 E.06945
G1 X109.263 Y108.523 E.03595
G1 X108.31 Y110.175 E.04639
G1 X108.31 Y110.175 F9000
G1 X108.733 Y108.55
;WIDTH:0.59775
G1 F1200
G1 X108.751 Y108.618 E.00264
G1 X108.701 Y108.668 E.00265
G1 X108.633 Y108.649 E.00265
G1 X108.615 Y108.581 E.00264
G1 X108.665 Y108.532 E.00262
G1 X108.665 Y108.532 F9000
G1 X110.436 Y108.145
;WIDTH:0.399999
G1 F1200
G1 X107.487 Y105.195 E.10146
G1 X107.361 Y105.025 E.00515
;WIDTH:0.374336
G1 X107.372 Y105.066 E.00096
G1 X107.301 Y105.085 E.00166
G1 X107.32 Y105.014 E.00166
;WIDTH:0.399999
G1 X107.487 Y104.678 E.00913
G1 X110.677 Y107.868 E.10973
G1 X110.957 Y107.631 E.00892
G1 X107.487 Y104.161 E.11937
G1 X107.487 Y103.644 E.01258
G1 X111.255 Y107.412 E.12962
G1 X111.559 Y107.199 E.00903
G1 X107.397 Y103.037 E.14317
G1 X107.226 Y102.778 E.00755
;WIDTH:0.374336
G1 X107.13 Y102.68 E.0031
;WIDTH:0.399999
G1 X107.194 Y102.316 E.00899
G1 X109.797 Y104.92 E.08956
G1 X110.003 Y105.178 E.00803
;WIDTH:0.374336
G1 X110.417 Y105.685 E.0148
G1 X111.059 Y106.336 E.02068
;WIDTH:0.399478
G1 X111.467 Y106.659 E.01264
;WIDTH:0.42462
G1 X111.876 Y106.981 E.01351
;WIDTH:0.438826
G1 X111.911 Y107.006 E.00116
G1 E-5 F3600
G1 X111.911 Y107.006 F9000
G1 X109.267 Y103.902
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X109.248 Y103.973 E.00166
G1 X109.319 Y103.954 E.00166
G1 X109.308 Y103.913 E.00096
;WIDTH:0.399999
G1 X107.265 Y101.871 E.07026
G1 X107.074 Y101.732 E.00575
;WIDTH:0.374336
G1 X107.061 Y101.885 E.00347
G1 E-5 F3600
G1 X107.061 Y101.885 F9000
G1 X107.485 Y98.459
G1 E5 F2400
;WIDTH:0.397848
G1 F1200
G1 X107.482 Y98.697 E.00576
;WIDTH:0.395044
G1 X107.374 Y99.213 E.01265
;WIDTH:0.410544
G1 X107.295 Y99.467 E.00666
;WIDTH:0.447056
G1 X107.217 Y99.72 E.00727
;WIDTH:0.48446
G1 X107.236 Y100.943 E.03662
;WIDTH:0.490065
G1 X107.239 Y101.432 E.01482
G1 X107.542 Y101.218 E.01125
G1 X107.779 Y101.269 E.00735
G1 X107.684 Y100.916 E.01108
;WIDTH:0.48446
G1 X107.613 Y100.13 E.02363
;WIDTH:0.437019
G1 X107.649 Y99.743 E.01041
;WIDTH:0.409425
G1 X107.685 Y99.356 E.0097
;WIDTH:0.395044
G1 X107.835 Y98.768 E.01456
;WIDTH:0.399999
G1 X107.942 Y98.379 E.00981
G1 X108.22 Y97.793 E.01578
G1 X109.949 Y94.798 E.08412
G1 X110.519 Y94.04 E.02307
G1 X110.866 Y93.689 E.01201
G1 X111.262 Y93.38 E.01222
G1 X111.646 Y93.149 E.0109
G1 X112.276 Y92.864 E.01682
G1 X112.754 Y92.718 E.01216
G1 X113.771 Y92.592 E.02493
G1 X117.468 Y92.603 E.08993
G1 X118.307 Y92.731 E.02064
G1 X119.067 Y92.993 E.01955
G1 X117.504 Y91.425 E.05385
G1 X117.504 Y91.296 E.00314
G1 X107.428 Y91.296 E.24509
G1 X107.487 Y91.696 E.00983
G1 X107.487 Y98.276 E.16005
G1 X107.852 Y97.714 E.0163
G1 X107.85 Y91.661 E.14723
G1 X112.062 Y91.661 E.10245
;WIDTH:0.441319
G1 X112.213 Y91.682 E.00413
;WIDTH:0.482639
G1 X112.364 Y91.703 E.00455
;WIDTH:0.523959
G1 X112.515 Y91.723 E.00496
;WIDTH:0.565278
G1 X112.665 Y91.744 E.00535
G1 X113.166 Y91.728 E.0177
;WIDTH:0.534003
G1 X113.667 Y91.713 E.01666
;WIDTH:0.502727
G1 X113.771 Y91.711 E.00324
;WIDTH:0.504443
G1 X117.209 Y91.714 E.10751
G1 X117.703 Y92.214 E.02198
G1 X117.104 Y92.184 E.01876
G1 X113.772 Y92.176 E.1042
;WIDTH:0.502727
G1 X113.696 Y92.179 E.00237
;WIDTH:0.534003
G1 X113.197 Y92.226 E.01666
;WIDTH:0.565278
G1 X112.698 Y92.273 E.0177
G1 X112.598 Y92.318 E.00387
;WIDTH:0.520234
G1 X112.44 Y92.389 E.0056
;WIDTH:0.480156
G1 X112.283 Y92.46 E.00511
;WIDTH:0.440078
G1 X112.125 Y92.531 E.00468
;WIDTH:0.399999
G1 X111.495 Y92.816 E.01682
G1 X111.018 Y93.105 E.01357
G1 X110.592 Y93.445 E.01326
G1 X110.231 Y93.814 E.01256
G1 X109.632 Y94.615 E.02433
G1 X107.937 Y97.552 E.08248
G1 X107.937 Y97.552 F9000
G1 X108.218 Y96.334
G1 F1200
G1 X108.218 Y92.027 E.10476
G1 X112.503 Y92.027 E.10423
G1 X111.974 Y92.198 E.01352
G1 X111.247 Y92.534 E.01948
G1 X110.793 Y92.817 E.01301
G1 X110.333 Y93.186 E.01434
G1 X109.943 Y93.589 E.01364
G1 X109.316 Y94.433 E.02557
G1 X108.309 Y96.175 E.04894
G1 X108.309 Y96.175 F9000
G1 X108.584 Y94.969
G1 F1200
G1 X108.584 Y92.393 E.06266
G1 X110.775 Y92.393 E.05329
G1 X110.567 Y92.53 E.00606
G1 X110.075 Y92.927 E.01538
G1 X109.656 Y93.363 E.01471
G1 X108.999 Y94.25 E.02685
G1 X108.675 Y94.811 E.01576
G1 X108.675 Y94.811 F9000
G1 X108.975 Y93.596
;WIDTH:0.451407
G1 F1200
G1 X108.975 Y92.784 E.02253
G1 X109.664 Y92.784 E.01912
G1 X109.362 Y93.104 E.01221
G1 X109.088 Y93.453 E.01231
G1 E-5 F3600
G1 X109.088 Y93.453 F9000
G1 X107.607 Y101.695
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X108.361 Y102.45 E.02595
G1 X108.549 Y102.667 E.00698
;WIDTH:0.374336
G1 X108.53 Y102.738 E.00166
G1 X108.601 Y102.719 E.00166
G1 X108.59 Y102.678 E.00096
G1 E-5 F3600
G1 X109.049 Y99.553 F9000
G1 X109.094 Y99.321
G1 X109.104 Y99.275
G1 X109.171 Y99.049
G1 X109.185 Y99.003
G1 X109.272 Y98.784
G1 X109.291 Y98.741
G1 X109.399 Y98.531
G1 X109.415 Y98.5
G1 X111.159 Y95.48
G1 X111.177 Y95.451
G1 X111.305 Y95.252
G1 X111.334 Y95.215
G1 X111.479 Y95.029
G1 X111.511 Y94.994
G1 X111.674 Y94.824
G1 X111.709 Y94.791
G1 X111.887 Y94.637
G1 X111.925 Y94.608
G1 X112.117 Y94.471
G1 X112.157 Y94.446
G1 X112.361 Y94.328
G1 X112.403 Y94.306
G1 X112.618 Y94.208
G1 X112.662 Y94.19
G1 X112.885 Y94.113
G1 X112.93 Y94.098
G1 X113.159 Y94.043
G1 X113.206 Y94.033
G1 X113.439 Y93.999
G1 X113.486 Y93.993
G1 X119.443 Y93.274
G1 E5 F2400
G1 F1200
G1 X119.995 Y93.74 E.01634
G1 E-5 F3600
G1 X119.995 Y93.74 F9000
G1 X121.815 Y99.003
G1 X121.829 Y99.049
G1 X121.896 Y99.275
G1 X121.906 Y99.321
G1 X121.951 Y99.553
G1 X121.957 Y99.6
G1 X121.979 Y99.835
G1 X123.392 Y127.173
G1 E5 F2400
;WIDTH:0.614786
G1 F1200
G1 X123.303 Y126.966 E.0087
;WIDTH:0.566892
G1 X123.213 Y126.758 E.00803
;WIDTH:0.518998
G1 X123.124 Y126.551 E.00726
;WIDTH:0.471104
G1 X123.035 Y126.344 E.00655
;WIDTH:0.423209
G1 X123.184 Y126.349 E.00386
G1 X123.264 Y126.27 E.00291
G1 X123.502 Y126.187 E.00652
G1 X123.501 Y126.669 E.01247
;WIDTH:0.464454
G1 X123.478 Y126.777 E.00316
;WIDTH:0.505699
G1 X123.454 Y126.886 E.0035
;WIDTH:0.546944
G1 X123.431 Y126.995 E.0038
;WIDTH:0.585863
G1 X123.416 Y127.093 E.00364
;WIDTH:0.624782
G1 X123.402 Y127.216 E.00486
;WIDTH:0.621492
G1 X123.421 Y127.676 E.01798
;WIDTH:0.583473
G1 X123.44 Y128.135 E.01678
;WIDTH:0.588356
G1 X123.419 Y128.502 E.01355
;WIDTH:0.631258
G1 X123.397 Y128.868 E.01456
G1 E-5 F3600
G1 X123.397 Y128.868 F9000
G1 X118.664 Y135.973
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X122.782 Y135.973 E.10017
G1 X122.782 Y131.645 E.10527
G1 X121.559 Y133.762 E.05947
G1 X121.248 Y134.189 E.01285
G1 X120.702 Y134.773 E.01945
G1 X120.3 Y135.115 E.01284
G1 X119.829 Y135.428 E.01376
G1 X119.351 Y135.669 E.01302
G1 X118.481 Y135.973 E.02242
G1 X118.481 Y135.973 F9000
G1 X120.225 Y135.607
G1 F1200
G1 X120.534 Y135.397 E.00909
G1 X120.967 Y135.025 E.01389
G1 X121.541 Y134.408 E.0205
G1 X121.876 Y133.945 E.0139
G1 X122.416 Y133.009 E.02628
G1 X122.416 Y135.607 E.06319
G1 X120.408 Y135.607 E.04884
G1 X120.408 Y135.607 F9000
G1 X121.328 Y135.215
;WIDTH:0.452802
G1 F1200
G1 X121.663 Y134.862 E.01355
G1 X122.024 Y134.417 E.01595
G1 X122.024 Y135.215 E.02221
G1 X121.51 Y135.215 E.01431
G1 E-5 F3600
G1 X121.51 Y135.215 F9000
G1 X123.06 Y125.94
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X122.595 Y125.475 E.016
G1 X122.426 Y125.186 E.00814
;WIDTH:0.374336
G1 X122.437 Y125.227 E.00096
G1 X122.366 Y125.246 E.00166
G1 X122.385 Y125.175 E.00166
G1 X122.385 Y125.175 F9000
G1 X123.468 Y125.83
;WIDTH:0.399999
G1 F1200
G1 X121.877 Y124.24 E.05471
G1 X121.708 Y123.951 E.00814
;WIDTH:0.374336
G1 X121.719 Y123.992 E.00096
G1 X121.648 Y124.011 E.00166
G1 X121.667 Y123.94 E.00166
G1 E-5 F3600
G1 X121.667 Y123.94 F9000
G1 X123.513 Y125.359
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X121.159 Y123.005 E.08098
G1 X120.955 Y122.746 E.00802
;WIDTH:0.374336
G1 X120.164 Y121.856 E.02693
G1 X119.413 Y121.214 E.02235
;WIDTH:0.417676
G1 X119.264 Y121.109 E.00465
;WIDTH:0.461016
G1 X119.115 Y121.004 E.00517
;WIDTH:0.399999
G1 X119.46 Y120.789 E.00989
G1 X123.513 Y124.841 E.1394
G1 X123.513 Y124.324 E.01258
G1 X119.778 Y120.589 E.12848
G1 X120.071 Y120.365 E.00897
G1 X123.513 Y123.807 E.1184
G1 X123.513 Y123.29 E.01258
G1 X120.327 Y120.104 E.1096
G1 X120.58 Y119.84 E.00889
G1 X123.513 Y122.773 E.10089
G1 E-5 F3600
G1 X123.513 Y122.773 F9000
G1 X120.817 Y119.544
G1 E5 F2400
G1 F1200
G1 X123.513 Y122.256 E.09302
G1 X123.513 Y115.295 E.16932
;WIDTH:0.446251
G1 X123.49 Y115.21 E.00241
;WIDTH:0.492504
G1 X123.467 Y115.124 E.00271
;WIDTH:0.538756
G1 X123.444 Y115.039 E.00295
;WIDTH:0.585008
G1 X123.421 Y114.954 E.00323
;WIDTH:0.63126
G1 X123.397 Y114.868 E.00355
G1 X123.356 Y114.941 E.00332
;WIDTH:0.585008
G1 X123.315 Y115.015 E.0031
;WIDTH:0.538756
G1 X123.273 Y115.088 E.00283
;WIDTH:0.492504
G1 X123.232 Y115.161 E.00255
;WIDTH:0.446251
G1 X123.19 Y115.234 E.00231
;WIDTH:0.399999
G1 X122.887 Y115.999 E.02001
G1 X120.926 Y119.397 E.09543
G1 X121.283 Y119.509 E.0091
G1 X123.147 Y116.28 E.09069
G1 X123.147 Y121.373 E.12388
G1 X121.413 Y119.638 E.05967
G1 X121.74 Y119.449 E.00919
G1 X122.782 Y117.645 E.05067
G1 X122.782 Y120.49 E.0692
G1 X121.869 Y119.578 E.03139
G1 X122.301 Y119.305 E.01243
;WIDTH:0.594632
G1 X122.251 Y119.354 E.00261
G1 X122.269 Y119.422 E.00262
G1 X122.337 Y119.44 E.00262
G1 X122.386 Y119.391 E.00258
G1 X122.368 Y119.323 E.00262
G1 E-5 F3600
G1 X122.368 Y119.323 F9000
G1 E5 F2400
;WIDTH:0.63126
G1 F1200
G1 X123.419 Y114.502 E.01456
;WIDTH:0.588357
G1 X123.44 Y114.135 E.01355
;WIDTH:0.583472
G1 X123.421 Y113.676 E.01678
;WIDTH:0.62149
G1 X123.402 Y113.216 E.01798
;WIDTH:0.62478
G1 X123.415 Y113.093 E.00486
;WIDTH:0.586327
G1 X123.43 Y112.994 E.00368
;WIDTH:0.547875
G1 X123.454 Y112.886 E.00378
;WIDTH:0.507156
G1 X123.477 Y112.777 E.0035
;WIDTH:0.466437
G1 X123.5 Y112.669 E.00317
;WIDTH:0.425718
G1 X123.5 Y112.394 E.00716
G1 X123.566 Y112.186 E.00568
;WIDTH:0.400027
G1 X123.631 Y111.978 E.0053
;WIDTH:0.386577
G1 X123.592 Y112.06 E.00213
;WIDTH:0.425718
G1 X123.169 Y112.345 E.01328
G1 X123.037 Y112.346 E.00344
;WIDTH:0.473016
G1 X123.126 Y112.553 E.00658
;WIDTH:0.520313
G1 X123.215 Y112.759 E.00725
;WIDTH:0.567611
G1 X123.303 Y112.966 E.00798
;WIDTH:0.614908
G1 X123.392 Y113.173 E.0087
G1 X123.392 Y113.173 F9000
G1 X123.031 Y111.948
;WIDTH:0.399999
G1 F1200
G1 X122.647 Y111.565 E.01319
G1 X122.478 Y111.276 E.00814
;WIDTH:0.374336
G1 X122.489 Y111.317 E.00096
G1 X122.418 Y111.336 E.00166
G1 X122.437 Y111.265 E.00166
G1 X122.437 Y111.265 F9000
G1 F1200
G1 X123.645 Y111.812 E.00377
;WIDTH:0.399999
G1 X123.438 Y111.838 E.00507
G1 X121.929 Y110.33 E.05189
G1 X121.76 Y110.041 E.00814
;WIDTH:0.374336
G1 X121.771 Y110.082 E.00096
G1 X121.7 Y110.101 E.00166
G1 X121.719 Y110.03 E.00166
G1 E-5 F3600
G1 X121.719 Y110.03 F9000
G1 X123.513 Y111.396
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X121.211 Y109.094 E.07919
G1 X121.008 Y108.836 E.00799
;WIDTH:0.374336
G1 X120.639 Y108.377 E.01332
G1 X120.086 Y107.802 E.01804
G1 X119.404 Y107.224 E.02022
;WIDTH:0.407938
G1 X119.247 Y107.114 E.00476
;WIDTH:0.44154
G1 X119.091 Y107.003 E.00519
;WIDTH:0.399999
G1 X119.437 Y106.803 E.00972
G1 X123.513 Y110.879 E.14021
G1 X123.513 Y110.362 E.01258
G1 X119.755 Y106.604 E.12927
G1 X120.05 Y106.382 E.00898
G1 X123.513 Y109.845 E.11912
G1 X123.513 Y109.328 E.01258
G1 X120.309 Y106.123 E.11023
G1 X120.561 Y105.859 E.00888
G1 X123.513 Y108.811 E.10155
G1 E-5 F3600
G1 X123.513 Y108.811 F9000
G1 X120.817 Y105.544
G1 E5 F2400
G1 F1200
G1 X120.794 Y105.575 E.00094
G1 X123.513 Y108.293 E.09351
G1 X123.513 Y103.613 E.11384
G1 X123.577 Y103.122 E.01204
G1 X123.735 Y102.715 E.01062
G1 X123.806 Y102.637 E.00257
G1 X123.806 Y101.283 E.03293
;WIDTH:0.439993
G1 X123.786 Y101.084 E.0054
;WIDTH:0.479984
G1 X123.766 Y100.886 E.0059
G1 X123.788 Y100.152 E.02177
;WIDTH:0.451982
G1 X123.78 Y99.64 E.01423
G1 X123.691 Y99.4 E.00711
;WIDTH:0.409959
G1 X123.601 Y99.159 E.00643
;WIDTH:0.390437
G1 X123.52 Y98.663 E.0119
;WIDTH:0.428581
G1 X123.499 Y98.19 E.01242
G1 X123.199 Y98.295 E.00834
G1 X123.14 Y98.354 E.00219
G1 X123.042 Y98.354 E.00257
G1 X123.17 Y98.729 E.01039
;WIDTH:0.390437
G1 X123.275 Y99.22 E.01189
;WIDTH:0.409694
G1 X123.319 Y99.479 E.00656
;WIDTH:0.451982
G1 X123.364 Y99.739 E.00733
G1 X123.387 Y100.129 E.01085
;WIDTH:0.479984
G1 X123.322 Y100.86 E.02176
G1 X123.111 Y101.417 E.01766
;WIDTH:0.439992
G1 X122.899 Y101.975 E.01611
;WIDTH:0.399999
G1 X120.926 Y105.397 E.09608
G1 X121.269 Y105.533 E.00898
G1 X122.535 Y103.341 E.06157
;WIDTH:0.434535
G1 X122.859 Y102.814 E.01647
G1 X123.238 Y102.108 E.02133
;WIDTH:0.397538
G1 X123.442 Y101.59 E.01345
G1 X123.418 Y102.535 E.02284
;WIDTH:0.435519
G1 X123.216 Y102.994 E.01338
G1 X123.147 Y103.613 E.01662
;WIDTH:0.399999
G1 X123.147 Y107.411 E.09238
G1 X121.399 Y105.662 E.06015
G1 X121.726 Y105.473 E.00919
G1 X122.782 Y103.645 E.05135
G1 X122.782 Y106.528 E.07013
G1 X121.856 Y105.602 E.03185
G1 X122.294 Y105.326 E.01259
;WIDTH:0.606868
G1 X122.244 Y105.377 E.00272
G1 X122.262 Y105.446 E.00272
G1 X122.331 Y105.464 E.00272
G1 X122.382 Y105.414 E.00272
G1 X122.363 Y105.345 E.00273
G1 E-5 F3600
G1 X122.363 Y105.345 F9000
G1 X123.001 Y97.956
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X122.7 Y97.655 E.01035
G1 X122.531 Y97.366 E.00814
;WIDTH:0.374336
G1 X122.542 Y97.407 E.00096
G1 X122.471 Y97.426 E.00166
G1 X122.49 Y97.355 E.00166
G1 X122.49 Y97.355 F9000
G1 X123.408 Y97.846
;WIDTH:0.399999
G1 F1200
G1 X121.982 Y96.419 E.04907
G1 X121.813 Y96.131 E.00812
;WIDTH:0.374336
G1 X121.824 Y96.172 E.00096
G1 X121.752 Y96.191 E.00168
G1 X121.772 Y96.12 E.00167
G1 X121.772 Y96.12 F9000
G1 X120.837 Y94.631
G1 F1200
G1 X121.065 Y94.926 E.00843
;WIDTH:0.399999
G1 X121.264 Y95.184 E.00793
G1 X123.513 Y97.434 E.07738
G1 X123.513 Y96.917 E.01258
G1 X117.892 Y91.296 E.19336
G1 X118.409 Y91.296 E.01258
G1 X123.513 Y96.4 E.17557
G1 X123.513 Y95.882 E.0126
G1 X118.926 Y91.296 E.15777
G1 X119.444 Y91.296 E.0126
G1 X123.513 Y95.365 E.13997
G1 X123.513 Y94.848 E.01258
G1 X119.961 Y91.296 E.12219
G1 X120.478 Y91.296 E.01258
G1 X123.513 Y94.331 E.1044
G1 X123.513 Y93.814 E.01258
G1 X120.995 Y91.296 E.08662
G1 X121.512 Y91.296 E.01258
G1 X123.513 Y93.297 E.06883
G1 X123.513 Y92.78 E.01258
G1 X122.029 Y91.296 E.05105
G1 X122.546 Y91.296 E.01258
G1 X123.513 Y92.263 E.03326
G1 X123.513 Y91.745 E.0126
G1 X123.063 Y91.296 E.01546
G1 X123.602 Y91.262 E.01314
;WIDTH:0.428146
G1 X123.58 Y91.345 E.00225
G1 X123.662 Y91.323 E.00222
G1 X123.649 Y91.275 E.0013
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X123.662 Y91.323 E-.02362
G1 X123.58 Y91.345 E-.04033
G1 X123.602 Y91.262 E-.04079
G1 X123.063 Y91.296 E-.25653
G1 X123.513 Y91.745 E-.30195
G1 X123.513 Y92.263 E-.24605
G1 X122.634 Y91.383 E-.59073
;WIPE_END
G1 X122.191 Y89.908 F9000
G1 X121.664 Y88.151
G1 X121.198 Y86.599
G1 X121.199 Y85.151
G1 X120.864 Y85.486
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X120.721 Y85.3 E.00571
G1 X120.667 Y85.292 E.00133
G1 X110.333 Y85.292 E.25136
G1 X110.279 Y85.3 E.00133
G1 X110.15 Y85.5 E.00579
G1 X104.557 Y85.5 E.13604
G1 X103.986 Y85.457 E.01393
G1 X103.438 Y85.333 E.01367
G1 X102.65 Y84.99 E.0209
G1 X101.966 Y84.484 E.0207
G1 X101.411 Y83.839 E.0207
G1 X101.118 Y83.328 E.01433
G1 X100.858 Y82.589 E.01906
G1 X100.761 Y81.982 E.01495
G1 X100.75 Y78.688 E.08012
G1 X100.706 Y78.57 E.00306
G1 X100.37 Y78.176 E.0126
G1 X100.114 Y77.73 E.01251
G1 X100.089 Y77.416 E.00766
G1 X100.194 Y77.091 E.00831
G1 X100.599 Y76.559 E.01626
G1 X130.401 Y76.559 E.7249
G1 X130.803 Y77.087 E.01614
G1 X130.925 Y77.486 E.01015
G1 X130.886 Y77.73 E.00601
G1 X130.63 Y78.177 E.01253
G1 X130.294 Y78.57 E.01258
G1 X130.25 Y78.688 E.00306
G1 X130.239 Y81.982 E.08012
G1 X130.154 Y82.544 E.01383
G1 X129.987 Y83.088 E.01384
G1 X129.74 Y83.601 E.01385
G1 X129.419 Y84.071 E.01384
G1 X129.034 Y84.485 E.01375
G1 X128.591 Y84.839 E.01379
G1 X128.125 Y85.11 E.01311
G1 X127.288 Y85.406 E.02159
G1 X126.733 Y85.489 E.01365
G1 X120.918 Y85.5 E.14144
G1 X120.918 Y85.5 F9000
G1 X120.987 Y85.134
;TYPE:Perimeter
G1 F6000
G1 X120.964 Y85.134 E.00056
G1 X120.828 Y84.951 E.00555
G1 X120.667 Y84.926 E.00396
G1 X110.333 Y84.926 E.25136
G1 X110.171 Y84.951 E.00399
G1 X110.036 Y85.134 E.00553
G1 X104.571 Y85.134 E.13293
G1 X104.041 Y85.095 E.01293
G1 X103.552 Y84.984 E.0122
G1 X102.834 Y84.671 E.01905
G1 X102.216 Y84.215 E.01868
G1 X101.711 Y83.627 E.01885
G1 X101.452 Y83.175 E.01267
G1 X101.214 Y82.499 E.01743
G1 X101.127 Y81.952 E.01347
G1 X101.116 Y78.687 E.07942
G1 X101.089 Y78.521 E.00409
G1 X100.984 Y78.332 E.00526
G1 X100.71 Y78.011 E.01027
G1 X100.452 Y77.563 E.01258
G1 X100.477 Y77.361 E.00495
G1 X100.78 Y76.925 E.01291
G1 X130.22 Y76.925 E.7161
G1 X130.434 Y77.206 E.00859
G1 X130.56 Y77.5 E.00778
G1 X130.36 Y77.912 E.01114
G1 X130.016 Y78.332 E.01321
G1 X129.911 Y78.521 E.00526
G1 X129.884 Y78.687 E.00409
G1 X129.874 Y81.705 E.07341
G1 X129.835 Y82.211 E.01234
G1 X129.721 Y82.71 E.01245
G1 X129.531 Y83.191 E.01258
G1 X129.272 Y83.637 E.01255
G1 X128.95 Y84.039 E.01253
G1 X128.548 Y84.405 E.01322
G1 X127.97 Y84.776 E.01671
G1 X127.199 Y85.049 E.01989
G1 X126.705 Y85.123 E.01215
G1 X121.047 Y85.134 E.13763
G1 X121.047 Y85.134 F9000
G1 X121.238 Y84.768
G1 F6000
G1 X121.059 Y84.768 E.00435
G1 X120.936 Y84.601 E.00504
G1 X120.667 Y84.561 E.00662
G1 X110.333 Y84.561 E.25136
G1 X110.063 Y84.602 E.00664
G1 X109.939 Y84.769 E.00506
G1 X105.228 Y84.769 E.11459
G1 X104.289 Y84.747 E.02285
G1 X103.667 Y84.635 E.01537
G1 X103.018 Y84.352 E.01722
G1 X102.466 Y83.945 E.01668
G1 X102.011 Y83.415 E.01699
G1 X101.785 Y83.022 E.01103
G1 X101.57 Y82.409 E.0158
G1 X101.492 Y81.922 E.012
G1 X101.481 Y78.686 E.07871
G1 X101.437 Y78.409 E.00682
G1 X101.262 Y78.095 E.00874
G1 X100.988 Y77.774 E.01027
G1 X100.819 Y77.49 E.00804
G1 X100.961 Y77.29 E.00597
G1 X130.039 Y77.29 E.70729
G1 X130.175 Y77.501 E.00611
G1 X130.116 Y77.603 E.00287
G1 X129.738 Y78.095 E.01509
G1 X129.563 Y78.409 E.00874
G1 X129.519 Y78.686 E.00682
G1 X129.508 Y81.926 E.07881
G1 X129.371 Y82.603 E.0168
G1 X129.105 Y83.234 E.01666
G1 X128.696 Y83.775 E.0165
G1 X128.32 Y84.119 E.0124
G1 X127.816 Y84.443 E.01457
G1 X127.11 Y84.693 E.01822
G1 X126.677 Y84.758 E.01065
G1 X121.298 Y84.767 E.13084
G1 X121.298 Y84.767 F9000
G1 X121.499 Y84.401
G1 F6000
G1 X121.154 Y84.402 E.00839
G1 X121.043 Y84.252 E.00454
G1 X120.667 Y84.195 E.00925
G1 X110.333 Y84.195 E.25136
G1 X109.955 Y84.252 E.0093
G1 X109.843 Y84.403 E.00457
G1 X105.228 Y84.403 E.11226
G1 X104.316 Y84.382 E.02219
G1 X103.782 Y84.286 E.0132
G1 X103.202 Y84.033 E.01539
G1 X102.717 Y83.675 E.01466
G1 X102.439 Y83.352 E.01037
G1 X102.119 Y82.869 E.01409
G1 X101.926 Y82.319 E.01418
G1 X101.858 Y81.893 E.01049
G1 X101.847 Y78.684 E.07806
G1 X101.786 Y78.297 E.00953
G1 X101.54 Y77.858 E.01224
G1 X101.368 Y77.656 E.00645
G1 X129.632 Y77.656 E.68749
G1 X129.46 Y77.858 E.00645
G1 X129.214 Y78.297 E.01224
G1 X129.153 Y78.684 E.00953
G1 X129.143 Y81.702 E.07341
G1 X129.082 Y82.299 E.0146
G1 X128.873 Y82.873 E.01486
G1 X128.559 Y83.385 E.01461
G1 X128.092 Y83.833 E.01574
G1 X127.662 Y84.11 E.01244
G1 X127.021 Y84.336 E.01653
G1 X126.65 Y84.392 E.00913
G1 X121.559 Y84.401 E.12383
G1 X121.559 Y84.401 F9000
G1 X121.763 Y84.035
G1 F6000
G1 X121.25 Y84.036 E.01248
G1 X121.151 Y83.902 E.00405
G1 X120.667 Y83.829 E.01191
G1 X110.333 Y83.829 E.25136
G1 X109.847 Y83.903 E.01196
G1 X109.747 Y84.037 E.00407
G1 X104.43 Y84.024 E.12933
G1 X103.896 Y83.937 E.01316
G1 X103.386 Y83.715 E.01353
G1 X102.967 Y83.405 E.01268
G1 X102.53 Y82.851 E.01716
G1 X102.348 Y82.416 E.01147
G1 X102.223 Y81.863 E.01379
G1 X102.213 Y78.683 E.07735
G1 X102.134 Y78.185 E.01226
G1 X102.042 Y78.022 E.00455
G1 X128.958 Y78.022 E.6547
G1 X128.866 Y78.185 E.00455
G1 X128.787 Y78.683 E.01226
G1 X128.779 Y81.035 E.05721
G1 X128.75 Y82.048 E.02465
G1 X128.621 Y82.552 E.01265
G1 X128.366 Y83.019 E.01294
G1 X128.037 Y83.41 E.01243
G1 X127.651 Y83.693 E.01164
G1 X127.1 Y83.921 E.0145
G1 X126.622 Y84.026 E.0119
G1 X121.823 Y84.035 E.11673
G1 E-5 F3600
G1 X121.823 Y84.035 F9000
G1 X102.746 Y82.898
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.374336
G1 F1200
G1 X103.092 Y83.271 E.01151
G1 X103.458 Y83.586 E.01092
G1 X103.458 Y83.586 F9000
G1 X104.353 Y83.876
G1 F1200
G1 X103.955 Y83.789 E.00921
;WIDTH:0.399999
G1 X103.808 Y83.599 E.00584
G1 X102.645 Y82.437 E.03999
G1 X102.497 Y81.771 E.01659
G1 X104.478 Y83.752 E.06815
G1 X105.006 Y83.763 E.01285
G1 X102.496 Y81.253 E.08634
G1 X102.494 Y80.734 E.01262
G1 X105.523 Y83.763 E.1042
G1 X106.04 Y83.763 E.01258
G1 X102.492 Y80.215 E.12205
G1 X102.49 Y79.696 E.01262
G1 X106.557 Y83.763 E.1399
G1 X107.075 Y83.763 E.0126
G1 X102.489 Y79.177 E.15776
G1 X102.484 Y78.655 E.0127
G1 X107.592 Y83.763 E.17571
G1 X108.109 Y83.763 E.01258
G1 X102.642 Y78.296 E.18806
G1 X102.383 Y78.202 E.0067
;WIDTH:0.374336
G1 X102.394 Y78.244 E.00098
G1 X102.323 Y78.263 E.00166
G1 X102.342 Y78.191 E.00168
G1 X102.342 Y78.191 F9000
G1 X103.159 Y78.296
;WIDTH:0.399999
G1 F1200
G1 X108.626 Y83.763 E.18806
G1 X109.143 Y83.763 E.01258
G1 X103.676 Y78.296 E.18806
G1 X104.193 Y78.296 E.01258
G1 X109.656 Y83.759 E.18792
G1 X110.001 Y83.587 E.00938
G1 X104.71 Y78.296 E.18201
G1 X105.227 Y78.296 E.01258
G1 X110.487 Y83.555 E.18092
G1 X111.004 Y83.555 E.01258
G1 X105.744 Y78.296 E.18092
G1 X106.261 Y78.296 E.01258
G1 X111.521 Y83.555 E.18092
G1 X112.038 Y83.555 E.01258
G1 X106.779 Y78.296 E.18091
G1 X107.296 Y78.296 E.01258
G1 X112.555 Y83.555 E.18091
G1 X113.072 Y83.555 E.01258
G1 X107.813 Y78.296 E.18091
G1 X108.33 Y78.296 E.01258
G1 X113.589 Y83.555 E.18091
G1 X114.106 Y83.555 E.01258
G1 X108.847 Y78.296 E.18091
G1 X109.364 Y78.296 E.01258
G1 X114.624 Y83.555 E.18092
G1 X115.141 Y83.555 E.01258
G1 X109.881 Y78.296 E.18092
G1 X110.398 Y78.296 E.01258
G1 X115.658 Y83.555 E.18092
G1 X116.175 Y83.555 E.01258
G1 X110.916 Y78.296 E.18091
G1 X111.433 Y78.296 E.01258
G1 X116.692 Y83.555 E.18091
G1 X117.209 Y83.555 E.01258
G1 X111.95 Y78.296 E.18091
G1 X112.467 Y78.296 E.01258
G1 X117.726 Y83.555 E.18091
G1 X118.243 Y83.555 E.01258
G1 X112.984 Y78.296 E.18091
G1 X113.501 Y78.296 E.01258
G1 X118.761 Y83.555 E.18092
G1 X119.278 Y83.555 E.01258
G1 X114.018 Y78.296 E.18092
G1 X114.535 Y78.296 E.01258
G1 X119.795 Y83.555 E.18092
G1 X120.312 Y83.555 E.01258
G1 X115.053 Y78.296 E.18091
G1 X115.57 Y78.296 E.01258
G1 X120.842 Y83.568 E.18135
G1 X121.101 Y83.704 E.00712
;WIDTH:0.374336
G1 X121.29 Y83.867 E.00564
;WIDTH:0.399999
G1 X121.552 Y83.761 E.00687
G1 X116.087 Y78.296 E.18799
G1 X116.604 Y78.296 E.01258
G1 X122.069 Y83.761 E.18799
G1 X122.585 Y83.76 E.01255
G1 X117.121 Y78.296 E.18796
G1 X117.638 Y78.296 E.01258
G1 X123.101 Y83.759 E.18792
G1 X123.617 Y83.758 E.01255
G1 X118.155 Y78.296 E.18789
G1 X118.672 Y78.296 E.01258
G1 X124.133 Y83.757 E.18785
G1 X124.65 Y83.756 E.01258
G1 X119.19 Y78.296 E.18782
G1 X119.707 Y78.296 E.01258
G1 X125.166 Y83.755 E.18779
G1 X125.682 Y83.754 E.01255
G1 X120.224 Y78.296 E.18775
G1 X120.741 Y78.296 E.01258
G1 X126.198 Y83.753 E.18772
G1 X126.7 Y83.738 E.01222
G1 X121.258 Y78.296 E.1872
G1 X121.775 Y78.296 E.01258
G1 X127.107 Y83.627 E.1834
G1 X127.475 Y83.478 E.00966
G1 X122.292 Y78.296 E.17827
G1 X122.809 Y78.296 E.01258
G1 X127.779 Y83.265 E.17095
G1 X128.037 Y83.006 E.00889
G1 X123.327 Y78.296 E.16202
G1 X123.844 Y78.296 E.01258
G1 X128.246 Y82.699 E.15144
G1 X128.401 Y82.336 E.0096
G1 X124.361 Y78.296 E.13897
G1 X124.878 Y78.296 E.01258
G1 X128.493 Y81.911 E.12435
G1 X128.504 Y81.405 E.01231
G1 X125.395 Y78.296 E.10695
G1 X125.912 Y78.296 E.01258
G1 X128.506 Y80.889 E.08921
G1 X128.507 Y80.374 E.01253
G1 X126.429 Y78.296 E.07148
G1 X126.946 Y78.296 E.01258
G1 X128.509 Y79.859 E.05377
G1 X128.511 Y79.343 E.01255
G1 X127.464 Y78.296 E.03602
G1 X127.981 Y78.296 E.01258
G1 X128.513 Y78.828 E.0183
G1 X128.585 Y78.281 E.01342
;WIDTH:0.44212
G1 X128.598 Y78.33 E.00138
G1 X128.562 Y78.366 E.00138
G1 X128.513 Y78.353 E.00138
G1 X128.499 Y78.304 E.00138
G1 X128.535 Y78.268 E.00138
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X128.499 Y78.304 E-.02418
G1 X128.513 Y78.353 E-.02421
G1 X128.562 Y78.366 E-.02408
G1 X128.598 Y78.33 E-.02418
G1 X128.585 Y78.281 E-.02408
G1 X128.513 Y78.828 E-.26207
G1 X127.981 Y78.296 E-.35737
G1 X127.464 Y78.296 E-.24558
G1 X128.229 Y79.062 E-.51425
;WIPE_END
G1 X126.764 Y85.135 F9000
G1 X126.411 Y86.599
G1 X125.94 Y88.151
G1 X125.94 Y88.552
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X125.947 Y88.554 E.00018
G1 X126 Y88.689 E.00353
G1 X126 Y89.367 E.01649
G1 X126.399 Y89.915 E.01649
G1 X126.531 Y90.246 E.00867
G1 X126.562 Y90.525 E.00683
G1 X126.519 Y90.797 E.0067
G1 X126.398 Y91.085 E.0076
G1 X126 Y91.633 E.01647
G1 X126 Y92.822 E.02892
G1 X139.202 Y92.821 E.32113
G1 X139.518 Y92.916 E.00803
G1 X139.794 Y93.221 E.01001
G1 X139.9 Y93.658 E.01094
G1 X139.9 Y95.171 E.0368
G1 X139.794 Y95.607 E.01091
G1 X139.518 Y95.913 E.01002
G1 X139.202 Y96.007 E.00802
G1 X136.7 Y96.007 E.06086
G1 X136.698 Y132.81 E.8952
G1 X136.638 Y133.72 E.02218
G1 X136.56 Y134.279 E.01373
G1 X136.461 Y134.79 E.01266
G1 X136.262 Y135.554 E.0192
G1 X135.914 Y136.526 E.02511
G1 X135.482 Y137.432 E.02441
G1 X135.05 Y138.16 E.02059
G1 X134.753 Y138.595 E.01281
G1 X134.427 Y139.018 E.01299
G1 X133.834 Y139.688 E.02176
G1 X133.426 Y140.087 E.01388
G1 X132.7 Y140.699 E.0231
G1 X132.016 Y141.179 E.02033
G1 X131.087 Y141.71 E.02603
G1 X130.617 Y141.932 E.01264
G1 X129.84 Y142.237 E.0203
G1 X128.889 Y142.516 E.02411
G1 X128.379 Y142.626 E.01269
G1 X127.856 Y142.71 E.01288
G1 X127.323 Y142.767 E.01304
G1 X126.775 Y142.796 E.01335
G1 X120.483 Y142.8 E.15305
G1 X120.405 Y142.783 E.00194
G1 X120.254 Y142.572 E.00631
G1 X110.7 Y142.572 E.23239
G1 X110.595 Y142.783 E.00573
G1 X110.517 Y142.8 E.00194
G1 X104.5 Y142.8 E.14636
G1 X103.734 Y142.771 E.01865
G1 X103.154 Y142.711 E.01418
G1 X102.631 Y142.627 E.01288
G1 X101.975 Y142.482 E.01634
G1 X101.271 Y142.275 E.01785
G1 X100.274 Y141.883 E.02606
G1 X99.1 Y141.253 E.03241
G1 X98.599 Y140.919 E.01465
G1 X97.941 Y140.411 E.02022
G1 X97.495 Y140.013 E.01454
G1 X96.932 Y139.437 E.01959
G1 X96.579 Y139.026 E.01318
G1 X96.253 Y138.602 E.01301
G1 X95.956 Y138.17 E.01275
G1 X95.301 Y137.006 E.03249
G1 X94.91 Y136.074 E.02458
G1 X94.613 Y135.103 E.0247
G1 X94.374 Y133.821 E.03172
G1 X94.302 Y132.81 E.02465
G1 X94.3 Y96.007 E.8952
G1 X91.798 Y96.007 E.06086
G1 X91.483 Y95.913 E.008
G1 X91.206 Y95.607 E.01004
G1 X91.108 Y95.259 E.00879
G1 X91.1 Y93.658 E.03894
G1 X91.145 Y93.371 E.00707
G1 X91.281 Y93.1 E.00738
G1 X91.583 Y92.864 E.00932
G1 X91.798 Y92.821 E.00533
G1 X105 Y92.822 E.32113
G1 X105 Y91.633 E.02892
G1 X104.602 Y91.085 E.01647
G1 X104.469 Y90.754 E.00868
G1 X104.438 Y90.475 E.00683
G1 X104.481 Y90.203 E.0067
G1 X104.602 Y89.915 E.0076
G1 X105 Y89.367 E.01647
G1 X105 Y88.683 E.01664
G1 X105.062 Y88.545 E.00368
G1 X105.183 Y88.5 E.00314
G1 X125.817 Y88.5 E.5019
G1 X125.885 Y88.528 E.00179
G1 X125.885 Y88.528 F9000
G1 X126.189 Y88.29
;TYPE:Perimeter
G1 F6000
G1 X126.208 Y88.298 E.0005
G1 X126.35 Y88.552 E.00708
G1 X126.366 Y89.248 E.01693
G1 X126.695 Y89.701 E.01362
G1 X126.875 Y90.115 E.01098
G1 X126.924 Y90.574 E.01123
G1 X126.859 Y90.933 E.00887
G1 X126.694 Y91.3 E.00979
G1 X126.366 Y91.752 E.01358
G1 X126.366 Y92.456 E.01712
G1 X139.202 Y92.455 E.31222
G1 X139.633 Y92.568 E.01084
G1 X139.894 Y92.753 E.00778
G1 X140.083 Y92.997 E.00751
;WIDTH:0.439107
G1 X140.145 Y93.13 E.00395
;WIDTH:0.478215
G1 X140.207 Y93.263 E.00433
;WIDTH:0.517323
G1 X140.269 Y93.396 E.00471
;WIDTH:0.55643
G1 X140.331 Y93.529 E.0051
G1 X140.34 Y93.658 E.00449
;WIDTH:0.546998
G1 X140.34 Y95.171 E.0516
G1 X140.323 Y95.298 E.00437
;WIDTH:0.540725
G1 X140.243 Y95.476 E.00657
;WIDTH:0.493817
G1 X140.163 Y95.654 E.00596
;WIDTH:0.446908
G1 X140.083 Y95.831 E.00533
;WIDTH:0.399999
G1 X139.894 Y96.075 E.00751
G1 X139.633 Y96.26 E.00778
G1 X139.202 Y96.373 E.01084
G1 X137.066 Y96.372 E.05196
G1 X137.063 Y132.81 E.88632
G1 X137.003 Y133.744 E.02277
G1 X136.923 Y134.329 E.01436
G1 X136.82 Y134.86 E.01316
G1 X136.606 Y135.678 E.02057
G1 X136.258 Y136.649 E.02509
G1 X135.812 Y137.59 E.02533
G1 X135.364 Y138.347 E.0214
G1 X135.054 Y138.801 E.01337
G1 X134.717 Y139.241 E.01348
G1 X134.108 Y139.931 E.02239
G1 X133.682 Y140.349 E.01452
G1 X132.935 Y140.979 E.02377
G1 X132.226 Y141.478 E.02109
G1 X131.268 Y142.028 E.02687
G1 X130.772 Y142.263 E.01335
G1 X129.974 Y142.578 E.02087
G1 X128.991 Y142.867 E.02492
G1 X128.455 Y142.983 E.01334
G1 X127.914 Y143.071 E.01333
G1 X127.361 Y143.13 E.01353
G1 X126.776 Y143.162 E.01425
G1 X120.483 Y143.166 E.15307
G1 X120.249 Y143.113 E.00584
G1 X120.137 Y142.937 E.00507
G1 X110.863 Y142.937 E.22558
G1 X110.751 Y143.113 E.00507
G1 X110.517 Y143.166 E.00584
G1 X104.5 Y143.166 E.14636
G1 X103.72 Y143.136 E.01899
G1 X103.116 Y143.075 E.01477
G1 X102.573 Y142.988 E.01338
G1 X101.895 Y142.839 E.01689
G1 X101.137 Y142.615 E.01923
G1 X100.082 Y142.196 E.02761
G1 X98.927 Y141.575 E.0319
G1 X98.396 Y141.223 E.0155
G1 X97.717 Y140.7 E.02085
G1 X97.251 Y140.286 E.01516
G1 X96.67 Y139.692 E.02021
G1 X96.301 Y139.264 E.01375
G1 X95.963 Y138.825 E.01348
G1 X95.629 Y138.336 E.0144
G1 X94.964 Y137.148 E.03312
G1 X94.573 Y136.216 E.02458
G1 X94.253 Y135.17 E.02661
G1 X94.014 Y133.885 E.03179
G1 X93.937 Y132.81 E.02622
G1 X93.934 Y96.372 E.88632
G1 X91.798 Y96.373 E.05196
G1 X91.368 Y96.26 E.01081
G1 X91.106 Y96.075 E.0078
G1 X90.917 Y95.831 E.00751
;WIDTH:0.440213
G1 X90.856 Y95.715 E.00354
;WIDTH:0.480427
G1 X90.794 Y95.599 E.0039
;WIDTH:0.520641
G1 X90.733 Y95.483 E.00424
;WIDTH:0.560855
G1 X90.671 Y95.367 E.00461
G1 X90.665 Y95.261 E.00372
;WIDTH:0.554151
G1 X90.659 Y93.658 E.05543
;WIDTH:0.570355
G1 X90.686 Y93.354 E.01088
G1 X90.717 Y93.322 E.00159
;WIDTH:0.527766
G1 X90.748 Y93.291 E.00144
;WIDTH:0.485177
G1 X90.779 Y93.259 E.00134
;WIDTH:0.442588
G1 X90.809 Y93.227 E.00119
;WIDTH:0.399999
G1 X90.898 Y93.021 E.00546
G1 X91.039 Y92.826 E.00585
G1 X91.259 Y92.632 E.00713
G1 X91.504 Y92.507 E.00669
G1 X91.798 Y92.455 E.00726
G1 X104.634 Y92.456 E.31222
G1 X104.634 Y91.752 E.01712
G1 X104.306 Y91.3 E.01358
G1 X104.107 Y90.804 E.013
G1 X104.076 Y90.426 E.00923
G1 X104.141 Y90.067 E.00887
G1 X104.306 Y89.7 E.00979
G1 X104.634 Y89.248 E.01358
G1 X104.634 Y88.683 E.01374
G1 X104.728 Y88.377 E.00779
G1 X104.822 Y88.27 E.00346
G1 X105.088 Y88.143 E.00717
G1 X105.183 Y88.134 E.00232
G1 X125.817 Y88.134 E.5019
G1 X126.134 Y88.267 E.00836
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X126.189 Y88.29 E-.02832
G1 X126.208 Y88.298 E-.00979
G1 X126.35 Y88.552 E-.13822
G1 X126.366 Y89.248 E-.33069
G1 X126.695 Y89.701 E-.26594
G1 X126.875 Y90.115 E-.21443
G1 X126.924 Y90.574 E-.21926
G1 X126.859 Y90.933 E-.1733
G1 X126.755 Y91.164 E-.12005
;WIPE_END
G1 X126.751 Y91.162 F9000
G1 X126.804 Y91.046
G1 X126.864 Y90.867
G1 X126.901 Y90.685
G1 X126.913 Y90.5
G1 X126.901 Y90.315
G1 X126.864 Y90.133
G1 X126.349 Y88.151
G1 X122.885 Y88.151
G1 X120.36 Y86.599
G1 X120.36 Y86.186
G1 E5 F2400
G1 F6000
G1 X120.3 Y86.067 E.00324
G1 X120.3 Y85.971 E.00234
G1 X110.7 Y85.971 E.23351
G1 X110.7 Y86.067 E.00234
G1 X110.625 Y86.215 E.00404
G1 X110.517 Y86.25 E.00276
G1 X104.2 Y86.25 E.15365
G1 X103.823 Y86.231 E.00918
G1 X103.001 Y86.074 E.02036
G1 X102.425 Y85.855 E.01499
G1 X101.842 Y85.524 E.01631
G1 X101.356 Y85.14 E.01507
G1 X100.935 Y84.691 E.01497
G1 X100.582 Y84.182 E.01507
G1 X100.307 Y83.625 E.01511
G1 X100.118 Y83.033 E.01512
G1 X100.044 Y82.652 E.00944
G1 X100 Y82.051 E.01466
G1 X100 Y78.633 E.08314
G1 X99.602 Y78.085 E.01647
G1 X99.468 Y77.745 E.00889
G1 X99.438 Y77.475 E.00661
G1 X99.481 Y77.203 E.0067
G1 X99.602 Y76.915 E.0076
G1 X100 Y76.367 E.01647
G1 X100.001 Y76.009 E.00871
G1 X100.047 Y75.907 E.00272
G1 X100.183 Y75.846 E.00363
G1 X130.817 Y75.846 E.74514
G1 X130.953 Y75.907 E.00363
G1 X131 Y76.029 E.00318
G1 X131 Y76.367 E.00822
G1 X131.398 Y76.915 E.01647
G1 X131.531 Y77.246 E.00868
G1 X131.55 Y77.614 E.00896
G1 X131.458 Y77.95 E.00847
G1 X131.398 Y78.085 E.00359
G1 X131 Y78.634 E.01649
G1 X130.989 Y82.345 E.09027
G1 X130.9 Y82.957 E.01504
G1 X130.703 Y83.599 E.01633
G1 X130.246 Y84.448 E.02345
G1 X129.668 Y85.117 E.02151
G1 X129.182 Y85.509 E.01519
G1 X128.437 Y85.912 E.0206
G1 X127.4 Y86.206 E.02622
G1 X126.814 Y86.25 E.01429
G1 X120.483 Y86.25 E.154
G1 X120.401 Y86.223 E.0021
G1 X120.401 Y86.223 F9000
G1 X120.116 Y86.425
;TYPE:Perimeter
G1 F6000
G1 X120.071 Y86.337 E.0024
G1 X110.929 Y86.337 E.22237
G1 X110.841 Y86.51 E.00472
G1 X110.517 Y86.616 E.00829
G1 X104.2 Y86.616 E.15365
G1 X103.754 Y86.59 E.01087
G1 X102.925 Y86.432 E.02053
G1 X102.294 Y86.196 E.01639
G1 X101.66 Y85.842 E.01766
G1 X101.128 Y85.426 E.01643
G1 X100.667 Y84.94 E.01629
G1 X100.281 Y84.389 E.01636
G1 X99.979 Y83.785 E.01643
G1 X99.769 Y83.143 E.01643
G1 X99.679 Y82.679 E.0115
G1 X99.634 Y82.051 E.01531
G1 X99.634 Y78.752 E.08024
G1 X99.306 Y78.3 E.01358
G1 X99.111 Y77.828 E.01242
G1 X99.076 Y77.426 E.00982
G1 X99.141 Y77.067 E.00887
G1 X99.306 Y76.7 E.00979
G1 X99.634 Y76.248 E.01358
G1 X99.638 Y75.967 E.00684
G1 X99.775 Y75.663 E.00811
G1 X100.088 Y75.489 E.00871
G1 X130.817 Y75.481 E.74745
G1 X131.225 Y75.663 E.01087
G1 X131.366 Y76.029 E.00954
G1 X131.366 Y76.248 E.00533
G1 X131.694 Y76.7 E.01358
G1 X131.893 Y77.196 E.013
G1 X131.924 Y77.574 E.00923
G1 X131.846 Y77.964 E.00967
G1 X131.694 Y78.3 E.00897
G1 X131.365 Y78.753 E.01362
G1 X131.355 Y82.346 E.0874
G1 X131.262 Y83.011 E.01633
G1 X131.052 Y83.707 E.01768
G1 X130.523 Y84.687 E.02709
G1 X129.944 Y85.356 E.02152
G1 X129.41 Y85.795 E.01681
G1 X129.008 Y86.044 E.0115
G1 X128.522 Y86.277 E.01311
G1 X127.482 Y86.564 E.02624
G1 X126.841 Y86.614 E.01564
G1 X120.483 Y86.616 E.15465
G1 X120.159 Y86.51 E.00829
G1 X120.143 Y86.478 E.00087
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X120.116 Y86.425 E-.02825
G1 X120.071 Y86.337 E-.04695
G1 X117.071 Y86.337 E-1.4248
;WIPE_END
G1 X120.143 Y74.206 F9000
G1 E5 F2400
G1 F6000
G1 X135.585 Y74.203 E.37561
G1 X136.199 Y74.243 E.01497
G1 X136.888 Y74.369 E.01704
G1 X137.472 Y74.548 E.01486
G1 X138.196 Y74.865 E.01922
G1 X138.792 Y75.226 E.01695
G1 X139.601 Y75.9 E.02561
G1 X140.273 Y76.706 E.02553
G1 X140.788 Y77.62 E.02552
G1 X141.131 Y78.612 E.02553
G1 X141.289 Y79.653 E.02561
G1 X141.289 Y80.041 E.00944
G1 X141.3 Y150.994 E1.72586
G1 X141.258 Y151.696 E.01711
G1 X141.132 Y152.383 E.01699
G1 X140.926 Y153.049 E.01696
G1 X140.64 Y153.686 E.01698
G1 X140.281 Y154.283 E.01694
G1 X139.852 Y154.834 E.01699
G1 X139.36 Y155.328 E.01696
G1 X138.772 Y155.788 E.01816
G1 X138.175 Y156.145 E.01692
G1 X137.266 Y156.523 E.02395
G1 X136.58 Y156.698 E.01722
G1 X135.84 Y156.79 E.01814
G1 X95.459 Y156.799 E.98223
G1 X94.783 Y156.755 E.01648
G1 X94.093 Y156.626 E.01707
G1 X93.453 Y156.426 E.01631
G1 X92.827 Y156.147 E.01667
G1 X92.187 Y155.76 E.01819
G1 X91.64 Y155.328 E.01695
G1 X91.148 Y154.834 E.01696
G1 X90.719 Y154.283 E.01699
G1 X90.361 Y153.687 E.01691
G1 X89.976 Y152.763 E.02435
G1 X89.795 Y152.041 E.01811
G1 X89.711 Y151.349 E.01696
G1 X89.7 Y80.006 E1.73535
G1 X89.743 Y79.301 E.01718
G1 X89.869 Y78.612 E.01704
G1 X90.077 Y77.943 E.01704
G1 X90.365 Y77.305 E.01703
G1 X90.727 Y76.705 E.01704
G1 X91.159 Y76.154 E.01703
G1 X91.654 Y75.659 E.01703
G1 X92.205 Y75.227 E.01703
G1 X92.805 Y74.865 E.01704
G1 X93.442 Y74.578 E.01699
G1 X94.37 Y74.314 E.02347
G1 X95.151 Y74.211 E.01916
G1 X120.083 Y74.206 E.60645
G1 X120.083 Y74.572 F9000
;TYPE:Perimeter
G1 F6000
G1 X135.573 Y74.568 E.37678
G1 X136.154 Y74.606 E.01416
G1 X136.802 Y74.725 E.01603
G1 X137.344 Y74.891 E.01379
G1 X138.027 Y75.19 E.01814
G1 X138.58 Y75.524 E.01571
G1 X139.341 Y76.159 E.02411
G1 X139.971 Y76.914 E.02392
G1 X140.454 Y77.771 E.02393
G1 X140.774 Y78.7 E.0239
G1 X140.923 Y79.68 E.02411
G1 X140.923 Y80.041 E.00878
G1 X140.925 Y93.142 E.31867
;WIDTH:0.439107
G1 X140.906 Y93.225 E.00229
;WIDTH:0.478215
G1 X140.886 Y93.308 E.00252
;WIDTH:0.517323
G1 X140.867 Y93.392 E.00277
;WIDTH:0.55643
G1 X140.847 Y93.475 E.00297
G1 X140.852 Y93.658 E.00636
;WIDTH:0.546998
G1 X140.852 Y95.171 E.0516
G1 X140.877 Y95.342 E.00589
;WIDTH:0.497999
G1 X140.901 Y95.514 E.00536
;WIDTH:0.448999
G1 X140.926 Y95.686 E.00479
;WIDTH:0.399999
G1 X140.934 Y150.983 E1.34504
G1 X140.894 Y151.652 E.0163
G1 X140.777 Y152.295 E.0159
G1 X140.583 Y152.92 E.01592
G1 X140.316 Y153.516 E.01589
G1 X139.979 Y154.076 E.0159
G1 X139.577 Y154.591 E.01589
G1 X139.117 Y155.054 E.01588
G1 X138.564 Y155.486 E.01707
G1 X138.01 Y155.818 E.01571
G1 X137.15 Y156.175 E.02265
G1 X136.512 Y156.338 E.01602
G1 X135.818 Y156.424 E.01701
G1 X95.471 Y156.434 E.9814
G1 X94.828 Y156.392 E.01567
G1 X94.182 Y156.271 E.01599
G1 X93.582 Y156.084 E.01529
G1 X92.997 Y155.822 E.01559
G1 X92.396 Y155.459 E.01708
G1 X91.884 Y155.055 E.01586
G1 X91.423 Y154.591 E.01591
G1 X91.021 Y154.076 E.01589
G1 X90.688 Y153.522 E.01572
G1 X90.324 Y152.648 E.02303
G1 X90.155 Y151.974 E.0169
G1 X90.077 Y151.327 E.01585
G1 X90.068 Y95.726 E1.35244
;WIDTH:0.441884
G1 X90.089 Y95.644 E.00229
;WIDTH:0.483769
G1 X90.11 Y95.563 E.0025
;WIDTH:0.525654
G1 X90.131 Y95.481 E.00277
;WIDTH:0.554151
G1 X90.145 Y95.262 E.00759
G1 X90.143 Y93.662 E.05533
;WIDTH:0.570355
G1 X90.153 Y93.316 E.01234
G1 X90.132 Y93.256 E.00227
;WIDTH:0.527766
G1 X90.11 Y93.195 E.00213
;WIDTH:0.485177
G1 X90.089 Y93.135 E.00191
;WIDTH:0.442588
G1 X90.068 Y93.075 E.00173
;WIDTH:0.399999
G1 X90.066 Y80.017 E.31762
G1 X90.106 Y79.345 E.01637
G1 X90.225 Y78.7 E.01595
G1 X90.42 Y78.073 E.01597
G1 X90.689 Y77.475 E.01595
G1 X91.028 Y76.914 E.01594
G1 X91.433 Y76.397 E.01597
G1 X91.897 Y75.933 E.01596
G1 X92.414 Y75.528 E.01597
G1 X92.975 Y75.189 E.01594
G1 X93.567 Y74.922 E.0158
G1 X94.444 Y74.673 E.02218
G1 X95.175 Y74.577 E.01793
G1 X120.023 Y74.572 E.6044
G1 E-5 F3600
G1 X120.023 Y74.572 F9000
G1 X120.023 Y74.549
G1 X139.355 Y76.145
G1 X140.951 Y81.116
G1 X140.951 Y95.605
G1 X140.56 Y95.605
G1 E5 F2400
G1 F6000
G1 X140.569 Y150.972 E1.34675
G1 X140.53 Y151.608 E.0155
G1 X140.421 Y152.208 E.01483
G1 X140.24 Y152.79 E.01483
G1 X139.991 Y153.346 E.01482
G1 X139.677 Y153.869 E.01484
G1 X139.302 Y154.349 E.01482
G1 X138.874 Y154.78 E.01477
G1 X138.357 Y155.184 E.01596
G1 X137.845 Y155.49 E.01451
G1 X137.034 Y155.827 E.02136
G1 X136.444 Y155.978 E.01481
G1 X135.795 Y156.058 E.01591
G1 X95.482 Y156.068 E.98057
G1 X94.874 Y156.028 E.01482
G1 X94.27 Y155.915 E.01495
G1 X93.712 Y155.741 E.01422
G1 X93.167 Y155.497 E.01452
G1 X92.605 Y155.158 E.01596
G1 X92.128 Y154.781 E.01479
G1 X91.698 Y154.349 E.01483
G1 X91.323 Y153.869 E.01482
G1 X91.015 Y153.357 E.01453
G1 X90.672 Y152.532 E.02173
G1 X90.515 Y151.908 E.01565
G1 X90.442 Y151.305 E.01477
G1 X90.434 Y95.598 E1.35502
G1 X90.628 Y96.054 E.01205
G1 X90.817 Y96.299 E.00753
G1 X91.253 Y96.607 E.01298
G1 X91.798 Y96.739 E.01364
G1 X93.569 Y96.738 E.04308
G1 X93.571 Y132.81 E.87742
G1 X93.655 Y133.957 E.02797
G1 X93.918 Y135.337 E.03417
G1 X94.236 Y136.357 E.02599
G1 X94.627 Y137.289 E.02458
G1 X95.353 Y138.584 E.03611
G1 X95.673 Y139.048 E.01371
G1 X96.024 Y139.502 E.01396
G1 X96.409 Y139.948 E.01433
G1 X97.008 Y140.559 E.02081
G1 X97.494 Y140.989 E.01578
G1 X98.193 Y141.527 E.02146
G1 X98.754 Y141.897 E.01635
G1 X99.909 Y142.518 E.0319
G1 X101.004 Y142.956 E.02869
G1 X101.816 Y143.196 E.0206
G1 X102.515 Y143.35 E.01741
G1 X103.078 Y143.438 E.01386
G1 X103.706 Y143.502 E.01535
G1 X104.5 Y143.532 E.01933
G1 X110.517 Y143.532 E.14636
G1 X110.632 Y143.524 E.0028
G1 X110.907 Y143.444 E.00697
G1 X110.997 Y143.303 E.00407
G1 X120.003 Y143.303 E.21906
G1 X120.093 Y143.444 E.00407
G1 X120.256 Y143.503 E.00422
G1 X120.483 Y143.532 E.00557
G1 X126.776 Y143.528 E.15307
G1 X127.4 Y143.494 E.0152
G1 X127.972 Y143.432 E.01399
G1 X128.531 Y143.341 E.01378
G1 X129.094 Y143.218 E.01402
G1 X130.108 Y142.918 E.02572
G1 X130.928 Y142.594 E.02145
G1 X131.449 Y142.345 E.01405
G1 X132.365 Y141.823 E.02564
G1 X133.171 Y141.259 E.02393
G1 X133.937 Y140.611 E.0244
G1 X134.382 Y140.173 E.01519
G1 X135.008 Y139.464 E.02301
G1 X135.356 Y139.008 E.01395
G1 X135.679 Y138.534 E.01395
G1 X136.142 Y137.747 E.02221
G1 X136.603 Y136.772 E.02623
G1 X136.95 Y135.801 E.02508
G1 X137.179 Y134.929 E.02193
G1 X137.285 Y134.38 E.0136
G1 X137.368 Y133.768 E.01502
G1 X137.429 Y132.81 E.02335
G1 X137.431 Y96.738 E.87742
G1 X139.202 Y96.739 E.04308
G1 X139.747 Y96.607 E.01364
G1 X140.183 Y96.299 E.01298
G1 X140.372 Y96.055 E.00751
G1 X140.537 Y95.661 E.01039
G1 X140.537 Y95.661 F9000
G1 X140.195 Y96.719
G1 F6000
G1 X140.203 Y150.961 E1.31938
G1 X140.167 Y151.564 E.01469
G1 X140.065 Y152.121 E.01377
G1 X139.898 Y152.661 E.01375
G1 X139.666 Y153.177 E.01376
G1 X139.375 Y153.661 E.01374
G1 X139.027 Y154.107 E.01376
G1 X138.631 Y154.506 E.01367
G1 X138.15 Y154.882 E.01485
G1 X137.68 Y155.163 E.01332
G1 X136.918 Y155.48 E.02007
G1 X136.376 Y155.618 E.0136
G1 X135.772 Y155.693 E.0148
G1 X95.494 Y155.702 E.97972
G1 X94.92 Y155.665 E.01399
G1 X94.358 Y155.56 E.01391
G1 X93.841 Y155.398 E.01318
G1 X93.336 Y155.173 E.01345
G1 X92.813 Y154.857 E.01486
G1 X92.371 Y154.508 E.0137
G1 X91.973 Y154.107 E.01374
G1 X91.625 Y153.661 E.01376
G1 X91.342 Y153.191 E.01334
G1 X91.02 Y152.417 E.02039
G1 X90.875 Y151.841 E.01445
G1 X90.808 Y151.283 E.01367
G1 X90.8 Y96.715 E1.32731
G1 X91.138 Y96.954 E.01007
G1 X91.396 Y97.04 E.00662
G1 X91.799 Y97.104 E.00993
G1 X93.203 Y97.104 E.03415
G1 X93.205 Y132.81 E.86851
G1 X93.296 Y134.024 E.02961
G1 X93.569 Y135.445 E.0352
G1 X93.899 Y136.499 E.02686
G1 X94.29 Y137.431 E.02458
G1 X95.052 Y138.79 E.0379
G1 X95.383 Y139.271 E.0142
G1 X95.746 Y139.74 E.01443
G1 X96.147 Y140.203 E.0149
G1 X96.764 Y140.832 E.02143
G1 X97.27 Y141.279 E.01642
G1 X97.99 Y141.831 E.02207
G1 X98.58 Y142.219 E.01718
G1 X99.735 Y142.84 E.0319
G1 X100.87 Y143.296 E.02975
G1 X101.736 Y143.552 E.02197
G1 X102.457 Y143.711 E.01796
G1 X103.04 Y143.802 E.01435
G1 X103.692 Y143.867 E.01594
G1 X104.5 Y143.897 E.01967
G1 X110.517 Y143.897 E.14636
G1 X110.678 Y143.887 E.00392
G1 X111.063 Y143.775 E.00975
G1 X111.131 Y143.669 E.00306
G1 X119.869 Y143.669 E.21254
G1 X119.937 Y143.775 E.00306
G1 X120.165 Y143.857 E.00589
G1 X120.483 Y143.897 E.0078
G1 X126.776 Y143.893 E.15307
G1 X127.439 Y143.858 E.01615
G1 X128.029 Y143.793 E.01444
G1 X128.607 Y143.699 E.01424
G1 X129.197 Y143.569 E.0147
G1 X130.242 Y143.258 E.02652
G1 X131.083 Y142.925 E.022
G1 X131.631 Y142.663 E.01477
G1 X132.546 Y142.14 E.02564
G1 X133.406 Y141.538 E.02553
G1 X134.193 Y140.872 E.02508
G1 X134.655 Y140.416 E.01579
G1 X135.298 Y139.686 E.02366
G1 X135.657 Y139.215 E.01441
G1 X135.993 Y138.721 E.01453
G1 X136.472 Y137.905 E.02302
G1 X136.947 Y136.896 E.02713
G1 X137.295 Y135.924 E.02511
G1 X137.538 Y134.999 E.02326
G1 X137.647 Y134.43 E.01409
G1 X137.732 Y133.793 E.01563
G1 X137.795 Y132.81 E.02396
G1 X137.797 Y97.104 E.86851
G1 X138.996 Y97.104 E.02916
G1 X139.604 Y97.04 E.01487
G1 X139.862 Y96.954 E.00662
G1 X140.146 Y96.754 E.00845
G1 X140.146 Y96.754 F9000
G1 X139.829 Y97.35
G1 F6000
G1 X139.837 Y150.814 E1.30046
G1 X139.819 Y151.261 E.01088
G1 X139.756 Y151.778 E.01267
G1 X139.631 Y152.284 E.01268
G1 X139.447 Y152.772 E.01269
G1 X139.205 Y153.234 E.01269
G1 X138.909 Y153.664 E.0127
G1 X138.573 Y154.045 E.01236
G1 X138.123 Y154.439 E.01455
G1 X137.516 Y154.835 E.01763
G1 X136.802 Y155.132 E.01881
G1 X136.308 Y155.258 E.0124
G1 X135.75 Y155.327 E.01368
G1 X95.506 Y155.337 E.9789
G1 X94.965 Y155.301 E.01319
G1 X94.447 Y155.204 E.01282
G1 X93.744 Y154.954 E.01815
G1 X93.247 Y154.691 E.01368
G1 X92.814 Y154.392 E.0128
G1 X92.422 Y154.04 E.01282
G1 X92.065 Y153.631 E.01321
G1 X91.67 Y153.026 E.01757
G1 X91.368 Y152.301 E.0191
G1 X91.236 Y151.774 E.01321
G1 X91.174 Y151.261 E.01257
G1 X91.165 Y97.348 E1.31138
G1 X91.282 Y97.387 E.003
G1 X91.799 Y97.47 E.01274
G1 X92.837 Y97.47 E.02525
G1 X92.84 Y132.81 E.85961
G1 X92.936 Y134.091 E.03125
G1 X93.219 Y135.552 E.0362
G1 X93.561 Y136.64 E.02774
G1 X93.952 Y137.572 E.02458
G1 X94.75 Y138.997 E.03973
G1 X95.093 Y139.493 E.01467
G1 X95.469 Y139.979 E.01495
G1 X95.885 Y140.458 E.01543
G1 X96.521 Y141.104 E.02205
G1 X97.046 Y141.568 E.01704
G1 X97.787 Y142.135 E.0227
G1 X98.407 Y142.541 E.01803
G1 X99.562 Y143.162 E.0319
G1 X100.736 Y143.636 E.0308
G1 X101.657 Y143.909 E.02337
G1 X102.4 Y144.072 E.0185
G1 X103.002 Y144.166 E.01482
G1 X103.678 Y144.232 E.01652
G1 X104.5 Y144.263 E.02001
G1 X110.517 Y144.263 E.14636
G1 X110.724 Y144.25 E.00504
G1 X111.219 Y144.105 E.01255
G1 X111.265 Y144.034 E.00206
G1 X119.735 Y144.034 E.20602
G1 X119.781 Y144.105 E.00206
G1 X120.074 Y144.211 E.00758
G1 X120.483 Y144.263 E.01003
G1 X126.776 Y144.259 E.15307
G1 X127.478 Y144.221 E.0171
G1 X128.087 Y144.154 E.0149
G1 X128.684 Y144.056 E.01472
G1 X129.299 Y143.92 E.01532
G1 X130.376 Y143.599 E.02734
G1 X131.239 Y143.255 E.0226
G1 X131.812 Y142.98 E.01546
G1 X132.727 Y142.458 E.02562
G1 X133.642 Y141.818 E.02716
G1 X134.448 Y141.134 E.02571
G1 X134.929 Y140.659 E.01644
G1 X135.588 Y139.909 E.02428
G1 X135.959 Y139.422 E.01489
G1 X136.307 Y138.908 E.0151
G1 X136.802 Y138.062 E.02384
G1 X137.291 Y137.019 E.02802
G1 X137.639 Y136.047 E.02511
G1 X137.897 Y135.069 E.0246
G1 X138.009 Y134.481 E.01456
G1 X138.097 Y133.817 E.01629
G1 X138.16 Y132.81 E.02454
G1 X138.163 Y97.47 E.85961
G1 X139.202 Y97.47 E.02527
G1 X139.77 Y97.362 E.01406
G1 E-5 F3600
G1 X139.77 Y97.362 F9000
G1 X140.249 Y95.718
G1 X140.249 Y93.111
G1 X139.93 Y92.795
G1 X139.875 Y92.744
G1 X139.765 Y92.651
G1 X139.593 Y92.554
G1 X139.411 Y92.495
G1 X139.288 Y92.477
G1 X139.221 Y92.472
G1 X137.64 Y92.471
G1 X131.438 Y78.659
G1 X131.73 Y78.901
G1 E5 F2400
G1 F6000
G1 X131.73 Y78.872 E.00071
G1 X131.99 Y78.515 E.01074
G1 X132.186 Y78.1 E.01116
G1 X132.287 Y77.624 E.01184
G1 X132.255 Y77.147 E.01163
G1 X132.099 Y76.683 E.01191
G1 X131.731 Y76.129 E.01618
G1 X131.725 Y75.925 E.00496
G1 X131.497 Y75.418 E.01352
;WIDTH:0.445022
G1 X131.327 Y75.32 E.00536
;WIDTH:0.490044
G1 X131.157 Y75.222 E.00595
;WIDTH:0.535066
G1 X130.987 Y75.123 E.00655
;WIDTH:0.580088
G1 X130.817 Y75.025 E.00712
G1 X131.041 Y75.003 E.00817
;WIDTH:0.535066
G1 X131.265 Y74.98 E.0075
;WIDTH:0.490044
G1 X131.489 Y74.957 E.00683
;WIDTH:0.445022
G1 X131.713 Y74.935 E.00615
;WIDTH:0.399999
G1 X135.561 Y74.934 E.0936
G1 X136.109 Y74.97 E.01336
G1 X136.715 Y75.081 E.01499
G1 X137.217 Y75.235 E.01277
G1 X137.859 Y75.516 E.01705
G1 X138.367 Y75.823 E.01444
G1 X139.082 Y76.419 E.02264
G1 X139.668 Y77.123 E.02228
G1 X140.119 Y77.921 E.0223
G1 X140.418 Y78.788 E.02231
G1 X140.558 Y79.708 E.02264
G1 X140.558 Y80.041 E.0081
G1 X140.56 Y93.142 E.31867
G1 X140.372 Y92.773 E.01007
G1 X140.183 Y92.53 E.00749
G1 X139.747 Y92.221 E.013
G1 X139.202 Y92.09 E.01363
G1 X126.731 Y92.091 E.30334
G1 X126.731 Y91.871 E.00535
G1 X126.99 Y91.515 E.01071
G1 X127.198 Y91.068 E.01199
G1 X127.287 Y90.624 E.01101
G1 X127.255 Y90.147 E.01163
G1 X127.088 Y89.655 E.01264
G1 X126.731 Y89.129 E.01546
G1 X126.731 Y88.657 E.01148
G1 X126.648 Y88.301 E.00889
G1 X126.419 Y87.995 E.0093
G1 X125.817 Y87.769 E.01564
G1 X105.183 Y87.769 E.5019
G1 X105.025 Y87.782 E.00386
G1 X104.581 Y87.995 E.01198
G1 X104.424 Y88.173 E.00577
G1 X104.271 Y88.618 E.01145
G1 X104.269 Y89.129 E.01243
G1 X104.01 Y89.485 E.01071
G1 X103.802 Y89.932 E.01199
G1 X103.713 Y90.376 E.01101
G1 X103.745 Y90.853 E.01163
G1 X103.901 Y91.317 E.01191
G1 X104.269 Y91.871 E.01618
G1 X104.269 Y92.091 E.00535
G1 X91.798 Y92.09 E.30334
G1 X91.425 Y92.15 E.00919
G1 X91.017 Y92.358 E.01114
G1 X90.797 Y92.552 E.00713
G1 X90.562 Y92.876 E.00974
G1 X90.433 Y93.226 E.00907
G1 X90.431 Y80.028 E.32103
G1 X90.47 Y79.389 E.01557
G1 X90.58 Y78.787 E.01489
G1 X90.762 Y78.203 E.01488
G1 X91.013 Y77.645 E.01488
G1 X91.33 Y77.122 E.01488
G1 X91.707 Y76.64 E.01488
G1 X92.14 Y76.207 E.01489
G1 X92.622 Y75.83 E.01488
G1 X93.145 Y75.513 E.01488
G1 X93.693 Y75.267 E.01461
G1 X94.518 Y75.032 E.02087
G1 X95.199 Y74.942 E.01671
G1 X99.289 Y74.941 E.09949
;WIDTH:0.447265
G1 X99.469 Y74.965 E.00499
;WIDTH:0.494531
G1 X99.649 Y74.989 E.00556
;WIDTH:0.541797
G1 X99.829 Y75.012 E.00613
;WIDTH:0.589062
G1 X100.008 Y75.036 E.00666
G1 X99.882 Y75.132 E.00585
;WIDTH:0.541797
G1 X99.755 Y75.227 E.00535
;WIDTH:0.494531
G1 X99.629 Y75.323 E.00485
;WIDTH:0.447265
G1 X99.502 Y75.419 E.00437
;WIDTH:0.399999
G1 X99.275 Y75.926 E.01351
G1 X99.269 Y76.129 E.00494
G1 X99.01 Y76.485 E.01071
G1 X98.802 Y76.932 E.01199
G1 X98.713 Y77.376 E.01101
G1 X98.745 Y77.853 E.01163
G1 X98.91 Y78.339 E.01248
G1 X99.269 Y78.871 E.01561
G1 X99.269 Y82.051 E.07735
G1 X99.315 Y82.706 E.01597
G1 X99.421 Y83.253 E.01355
G1 X99.65 Y83.946 E.01775
G1 X99.98 Y84.596 E.01773
G1 X100.4 Y85.189 E.01768
G1 X100.9 Y85.712 E.0176
G1 X101.479 Y86.16 E.01781
G1 X102.037 Y86.478 E.01562
G1 X102.868 Y86.793 E.02162
G1 X103.686 Y86.949 E.02026
G1 X104.2 Y86.981 E.01253
G1 X110.517 Y86.981 E.15365
G1 X110.675 Y86.968 E.00386
G1 X111.056 Y86.805 E.01008
G1 X111.109 Y86.703 E.0028
G1 X119.891 Y86.703 E.21361
G1 X119.944 Y86.805 E.0028
G1 X120.483 Y86.981 E.01379
G1 X125.817 Y86.981 E.12974
G1 X126.868 Y86.979 E.02556
G1 X127.546 Y86.924 E.01655
G1 X128.68 Y86.607 E.02864
G1 X129.166 Y86.373 E.01312
G1 X129.637 Y86.081 E.01348
G1 X130.221 Y85.595 E.01848
G1 X130.799 Y84.927 E.02149
G1 X130.997 Y84.606 E.00917
G1 X131.401 Y83.816 E.02158
G1 X131.624 Y83.064 E.01908
G1 X131.72 Y82.348 E.01757
G1 X131.73 Y78.961 E.08239
G1 E-5 F3600
G1 X131.73 Y78.961 F9000
G1 X131.349 Y78.961
G1 X131.349 Y82.06
G1 X131.347 Y82.114
G1 X131.337 Y82.382
G1 X131.33 Y82.448
G1 X131.3 Y82.714
G1 X131.288 Y82.78
G1 X131.239 Y83.042
G1 X131.223 Y83.109
G1 X131.154 Y83.366
G1 X131.133 Y83.432
G1 X131.045 Y83.684
G1 X131.019 Y83.749
G1 X130.912 Y83.993
G1 X130.882 Y84.056
G1 X130.758 Y84.291
G1 X130.723 Y84.352
G1 X130.582 Y84.576
G1 X130.543 Y84.634
G1 X130.386 Y84.846
G1 X130.343 Y84.902
G1 X130.171 Y85.102
G1 X130.125 Y85.154
G1 X129.939 Y85.34
G1 X129.889 Y85.389
G1 X129.69 Y85.561
G1 X129.637 Y85.606
G1 X129.581 Y85.647
G1 X129.369 Y85.804
G1 X129.309 Y85.842
G1 X129.086 Y85.982
G1 X129.023 Y86.017
G1 X128.79 Y86.14
G1 X128.727 Y86.169
G1 X128.486 Y86.274
G1 X128.422 Y86.299
G1 X128.174 Y86.386
G1 X128.108 Y86.406
G1 X127.854 Y86.474
G1 X127.787 Y86.49
G1 X127.529 Y86.539
G1 X127.46 Y86.551
G1 X127.199 Y86.58
G1 X127.131 Y86.587
G1 X126.868 Y86.597
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X105.183 Y87.375 E.0067
;WIDTH:0.456022
G1 X110.517 Y87.375 E.14962
;WIDTH:0.475838
G1 X110.745 Y87.365 E.0067
G1 X110.745 Y87.365 F9000
G1 X110.773 Y87.349
G1 F6000
G1 X111.015 Y87.213 E.00815
;WIDTH:0.430177
G1 X111.285 Y87.061 E.00816
;WIDTH:0.384515
G1 X119.715 Y87.061 E.19637
G1 X119.732 Y87.094 E.00086
;WIDTH:0.420267
G1 X120.108 Y87.235 E.01031
;WIDTH:0.456018
G1 X120.483 Y87.375 E.01123
G1 X120.056 Y87.393 E.01199
;WIDTH:0.420267
G1 X119.629 Y87.411 E.01097
;WIDTH:0.384515
G1 X111.371 Y87.411 E.19236
;WIDTH:0.430177
G1 X111.058 Y87.388 E.00826
;WIDTH:0.475838
G1 X110.772 Y87.367 E.00842
G1 E-5 F3600
G1 X110.772 Y87.367 F9000
G1 X125.817 Y87.375
G1 E5 F2400
;WIDTH:0.456022
G1 F6000
G1 X120.483 Y87.375 E.14962
G1 E-5 F3600
G1 X120.483 Y87.375 F9000
G1 X125.817 Y87.375
G1 E5 F2400
G1 F6000
G1 X126.356 Y87.359 E.01513
;WIDTH:0.428011
G1 X126.895 Y87.344 E.01412
;WIDTH:0.399999
G1 X127.719 Y87.26 E.02015
G1 X128.617 Y87.019 E.02262
G1 X128.912 Y86.901 E.00773
G1 X129.444 Y86.638 E.01444
G1 X129.865 Y86.366 E.01219
G1 X130.497 Y85.835 E.02008
G1 X131.076 Y85.166 E.02152
G1 X131.319 Y84.779 E.01112
G1 X131.751 Y83.924 E.0233
G1 X131.985 Y83.118 E.02041
G1 X132.086 Y82.349 E.01887
G1 X132.096 Y78.992 E.08166
G1 X132.286 Y78.73 E.00787
G1 X132.548 Y78.179 E.01484
G1 X132.649 Y77.673 E.01255
G1 X132.617 Y77.097 E.01403
G1 X132.439 Y76.548 E.01404
G1 X132.096 Y76.008 E.01556
G1 X132.089 Y75.883 E.00305
G1 X131.826 Y75.301 E.01553
G1 X135.367 Y75.3 E.08613
G1 X135.883 Y75.321 E.01256
G1 X136.438 Y75.402 E.01364
G1 X137.089 Y75.578 E.0164
G1 X137.69 Y75.841 E.01596
G1 X138.154 Y76.122 E.01319
G1 X138.822 Y76.678 E.02114
G1 X139.366 Y77.332 E.02069
G1 X139.784 Y78.072 E.02067
G1 X140.061 Y78.876 E.02068
G1 X140.146 Y79.434 E.01373
G1 X140.192 Y80.041 E.01481
G1 X140.194 Y92.109 E.29354
G1 X139.862 Y91.874 E.00989
G1 X139.604 Y91.789 E.00661
G1 X139.202 Y91.724 E.00991
G1 X127.289 Y91.725 E.28977
G1 X127.538 Y91.204 E.01405
G1 X127.649 Y90.673 E.0132
G1 X127.617 Y90.097 E.01403
G1 X127.422 Y89.508 E.01509
G1 X127.097 Y89.01 E.01446
G1 X127.06 Y88.376 E.01545
G1 X126.98 Y88.148 E.00588
G1 X126.66 Y87.72 E.013
;WIDTH:0.428011
G1 X126.239 Y87.548 E.01191
;WIDTH:0.456022
G1 X125.873 Y87.398 E.0111
G1 X125.873 Y87.398 F9000
G1 X127.118 Y87.714
;WIDTH:0.399999
G1 F6000
G1 X127.104 Y87.695 E.00057
G1 X127.814 Y87.613 E.01738
G1 X128.712 Y87.372 E.02262
G1 X129.07 Y87.231 E.00936
G1 X129.637 Y86.949 E.0154
G1 X130.093 Y86.652 E.01324
G1 X130.774 Y86.074 E.02173
G1 X131.353 Y85.405 E.02152
G1 X131.641 Y84.951 E.01308
G1 X132.1 Y84.033 E.02497
G1 X132.347 Y83.172 E.02179
G1 X132.452 Y82.35 E.02016
G1 X132.461 Y79.111 E.07879
G1 X132.761 Y78.631 E.01377
G1 X132.907 Y78.26 E.0097
G1 X133.011 Y77.722 E.01333
G1 X132.98 Y77.048 E.01641
G1 X132.779 Y76.412 E.01622
G1 X132.373 Y75.666 E.02066
G1 X135.618 Y75.671 E.07893
G1 X136.176 Y75.725 E.01364
G1 X136.795 Y75.87 E.01546
G1 X137.328 Y76.082 E.01395
G1 X137.941 Y76.42 E.01703
G1 X138.562 Y76.938 E.01967
G1 X139.064 Y77.54 E.01907
G1 X139.449 Y78.223 E.01907
G1 X139.705 Y78.964 E.01907
G1 X139.785 Y79.489 E.01292
G1 X139.826 Y80.041 E.01346
G1 X139.828 Y91.478 E.27819
G1 X139.719 Y91.442 E.00279
G1 X139.202 Y91.358 E.01274
G1 X127.891 Y91.359 E.27513
G1 X127.98 Y90.952 E.01013
G1 X128.011 Y90.278 E.01641
G1 X127.927 Y89.804 E.01171
G1 X127.757 Y89.361 E.01154
G1 X127.463 Y88.891 E.01348
G1 X127.415 Y88.289 E.01469
G1 X127.312 Y87.995 E.00758
G1 X127.152 Y87.764 E.00684
G1 E-5 F3600
G1 X127.152 Y87.764 F9000
G1 X103.869 Y86.587
G1 X103.801 Y86.58
G1 X103.54 Y86.551
G1 X103.471 Y86.539
G1 X103.213 Y86.49
G1 X103.146 Y86.474
G1 X102.892 Y86.406
G1 X102.826 Y86.386
G1 X102.578 Y86.299
G1 X102.514 Y86.274
G1 X102.273 Y86.169
G1 X102.21 Y86.14
G1 X101.977 Y86.017
G1 X101.914 Y85.982
G1 X101.691 Y85.842
G1 X101.631 Y85.804
G1 X101.419 Y85.647
G1 X101.363 Y85.606
G1 X101.31 Y85.561
G1 X101.111 Y85.389
G1 X101.061 Y85.34
G1 X100.875 Y85.154
G1 X100.829 Y85.102
G1 X100.657 Y84.902
G1 X100.614 Y84.846
G1 X100.457 Y84.634
G1 X100.418 Y84.576
G1 X100.277 Y84.352
G1 X100.242 Y84.291
G1 X100.118 Y84.056
G1 X100.088 Y83.993
G1 X99.981 Y83.749
G1 X99.955 Y83.684
G1 X99.867 Y83.432
G1 X99.846 Y83.366
G1 X99.777 Y83.109
G1 X99.761 Y83.042
G1 X99.712 Y82.78
G1 X99.7 Y82.714
G1 X99.099 Y77.685
G1 X99.087 Y77.5
G1 X99.099 Y77.315
G1 X99.136 Y77.133
G1 X99.651 Y75.498
G1 X100.009 Y75.498
G1 X100.008 Y75.036
G1 E5 F2400
;WIDTH:0.589062
G1 F6000
G1 X100.183 Y75.028 E.00646
;WIDTH:0.580088
G1 X130.817 Y75.025 E1.11212
G1 E-5 F3600
G1 X130.817 Y75.025 F9000
G1 X130.817 Y75.498
G1 X131.349 Y75.498
G1 X131.864 Y77.133
G1 X131.901 Y77.315
G1 X131.913 Y77.5
G1 X131.901 Y77.685
G1 X131.3 Y82.714
G1 X131.288 Y82.78
G1 X131.239 Y83.042
G1 X131.223 Y83.109
G1 X131.154 Y83.366
G1 X131.133 Y83.432
G1 X131.045 Y83.684
G1 X131.019 Y83.749
G1 X130.912 Y83.993
G1 X130.882 Y84.056
G1 X130.758 Y84.291
G1 X130.723 Y84.352
G1 X130.582 Y84.576
G1 X130.543 Y84.634
G1 X130.386 Y84.846
G1 X130.343 Y84.902
G1 X130.171 Y85.102
G1 X130.125 Y85.154
G1 X129.939 Y85.34
G1 X129.889 Y85.389
G1 X129.69 Y85.561
G1 X129.637 Y85.606
G1 X129.581 Y85.647
G1 X129.369 Y85.804
G1 X129.309 Y85.842
G1 X129.086 Y85.982
G1 X129.023 Y86.017
G1 X128.79 Y86.14
G1 X128.727 Y86.169
G1 X128.486 Y86.274
G1 X128.422 Y86.299
G1 X128.174 Y86.386
G1 X128.108 Y86.406
G1 X127.854 Y86.474
G1 X127.787 Y86.49
G1 X127.529 Y86.539
G1 X127.46 Y86.551
G1 X127.199 Y86.58
G1 X127.131 Y86.587
G1 X126.868 Y86.597
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X104.626 Y87.572 E.01111
;WIDTH:0.43792
G1 X104.297 Y87.759 E.01016
;WIDTH:0.399999
G1 X104.03 Y88.127 E.01106
G1 X103.906 Y88.592 E.01171
G1 X103.903 Y89.01 E.01017
G1 X103.714 Y89.27 E.00782
G1 X103.561 Y89.548 E.00772
G1 X103.383 Y90.097 E.01404
G1 X103.351 Y90.673 E.01403
G1 X103.462 Y91.204 E.0132
G1 X103.711 Y91.725 E.01405
G1 X91.798 Y91.724 E.28977
G1 X91.346 Y91.793 E.01112
G1 X90.799 Y92.071 E.01492
G1 X90.797 Y80.039 E.29267
G1 X90.834 Y79.433 E.01477
G1 X90.936 Y78.875 E.0138
G1 X91.105 Y78.333 E.01381
G1 X91.338 Y77.816 E.01379
G1 X91.631 Y77.33 E.0138
G1 X91.982 Y76.883 E.01382
G1 X92.383 Y76.482 E.01379
G1 X92.83 Y76.131 E.01382
G1 X93.315 Y75.838 E.01378
G1 X93.819 Y75.611 E.01345
G1 X94.593 Y75.391 E.01957
G1 X95.223 Y75.308 E.01546
G1 X99.171 Y75.307 E.09603
G1 X98.911 Y75.884 E.01539
G1 X98.904 Y76.008 E.00302
G1 X98.714 Y76.27 E.00787
G1 X98.462 Y76.796 E.01419
G1 X98.351 Y77.327 E.0132
G1 X98.392 Y77.959 E.01541
G1 X98.574 Y78.483 E.01349
G1 X98.903 Y78.99 E.0147
G1 X98.907 Y82.145 E.07674
G1 X98.966 Y82.86 E.01745
G1 X99.072 Y83.364 E.01253
G1 X99.322 Y84.107 E.01907
G1 X99.678 Y84.803 E.01902
G1 X100.132 Y85.438 E.01899
G1 X100.672 Y85.998 E.01892
G1 X101.298 Y86.477 E.01917
G1 X101.856 Y86.796 E.01563
G1 X102.219 Y86.951 E.0096
G1 X102.799 Y87.153 E.01494
G1 X103.617 Y87.309 E.02026
G1 X104.2 Y87.347 E.01421
;WIDTH:0.43792
G1 X104.577 Y87.366 E.01013
;WIDTH:0.47584
G1 X104.895 Y87.382 E.00935
G1 X104.895 Y87.382 F9000
G1 X103.872 Y87.699
;WIDTH:0.399999
G1 F6000
G1 X103.7 Y87.969 E.00779
G1 X103.541 Y88.566 E.01503
G1 X103.537 Y88.891 E.00791
G1 X103.369 Y89.127 E.00705
G1 X103.122 Y89.661 E.01431
G1 X103.02 Y90.048 E.00973
G1 X102.989 Y90.722 E.01641
G1 X103.13 Y91.359 E.01587
G1 X91.798 Y91.358 E.27564
G1 X91.444 Y91.397 E.00866
G1 X91.164 Y91.488 E.00716
G1 X91.163 Y80.05 E.27822
G1 X91.197 Y79.478 E.01394
G1 X91.292 Y78.963 E.01274
G1 X91.447 Y78.463 E.01273
G1 X91.662 Y77.986 E.01273
G1 X91.933 Y77.538 E.01274
G1 X92.256 Y77.126 E.01273
G1 X92.626 Y76.756 E.01273
G1 X93.038 Y76.433 E.01273
G1 X93.486 Y76.162 E.01274
G1 X93.945 Y75.956 E.01224
G1 X94.667 Y75.75 E.01826
G1 X95.247 Y75.674 E.01423
G1 X98.624 Y75.673 E.08214
G1 X98.52 Y75.916 E.00643
G1 X98.221 Y76.412 E.01409
G1 X98.02 Y77.048 E.01622
G1 X97.989 Y77.722 E.01641
G1 X98.056 Y78.134 E.01015
G1 X98.238 Y78.628 E.01281
G1 X98.537 Y79.109 E.01378
G1 X98.542 Y82.172 E.0745
G1 X98.611 Y82.952 E.01905
G1 X98.723 Y83.474 E.01299
G1 X98.994 Y84.268 E.02041
G1 X99.377 Y85.011 E.02033
G1 X99.865 Y85.688 E.0203
G1 X100.444 Y86.284 E.02021
G1 X101.116 Y86.795 E.02053
G1 X101.674 Y87.113 E.01562
G1 X102.087 Y87.292 E.01095
G1 X102.731 Y87.512 E.01655
G1 X103.813 Y87.69 E.02667
G1 E-5 F3600
G1 X103.813 Y87.69 F9000
G1 X91.462 Y91.038
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.475842
G1 F1200
G1 X91.423 Y91.077 E.00162
G1 X91.437 Y91.131 E.00164
G1 X91.491 Y91.145 E.00164
G1 X91.53 Y91.106 E.00162
G1 X91.516 Y91.053 E.00161
;WIDTH:0.399999
G1 X92.04 Y91.084 E.01277
G1 X91.438 Y90.483 E.02069
G1 X91.438 Y89.966 E.01258
G1 X92.557 Y91.084 E.03848
G1 X93.074 Y91.084 E.01258
G1 X91.438 Y89.449 E.05626
G1 X91.438 Y88.931 E.0126
G1 X93.591 Y91.084 E.07406
G1 X94.108 Y91.084 E.01258
G1 X91.438 Y88.414 E.09185
G1 X91.438 Y87.897 E.01258
G1 X94.626 Y91.084 E.10965
G1 X95.143 Y91.084 E.01258
G1 X91.438 Y87.38 E.12743
G1 X91.438 Y86.862 E.0126
G1 X95.66 Y91.084 E.14523
G1 X96.177 Y91.084 E.01258
G1 X91.438 Y86.345 E.16302
G1 X91.438 Y85.828 E.01258
G1 X96.694 Y91.084 E.1808
G1 X97.211 Y91.085 E.01258
G1 X91.438 Y85.311 E.1986
G1 X91.438 Y84.794 E.01258
G1 X97.729 Y91.085 E.21641
G1 X98.246 Y91.085 E.01258
G1 X91.438 Y84.276 E.23421
G1 X91.437 Y83.759 E.01258
G1 X98.763 Y91.085 E.25201
G1 X99.28 Y91.085 E.01258
G1 X91.437 Y83.242 E.26979
G1 X91.437 Y82.725 E.01258
G1 X99.797 Y91.085 E.28758
G1 X100.314 Y91.085 E.01258
G1 X91.437 Y82.208 E.30536
G1 X91.437 Y81.69 E.0126
G1 X100.831 Y91.085 E.32316
G1 X101.349 Y91.085 E.0126
G1 X91.437 Y81.173 E.34097
G1 X91.437 Y80.656 E.01258
G1 X101.866 Y91.085 E.35875
G1 X102.383 Y91.085 E.01258
G1 X91.437 Y80.139 E.37654
G1 X91.462 Y79.647 E.01198
G1 X102.74 Y90.924 E.38794
G1 X102.87 Y91.122 E.00576
;WIDTH:0.374336
G1 X102.851 Y91.193 E.00166
G1 X102.922 Y91.174 E.00166
G1 X102.911 Y91.133 E.00096
G1 X102.911 Y91.133 F9000
G1 X102.716 Y90.384
;WIDTH:0.399999
G1 F1200
G1 X91.528 Y79.195 E.38488
G1 X91.634 Y78.785 E.0103
G1 X102.769 Y89.92 E.38304
G1 X102.886 Y89.519 E.01016
G1 X91.773 Y78.407 E.38226
G1 X91.94 Y78.056 E.00945
G1 X99.382 Y85.498 E.256
G1 X99.61 Y85.757 E.00839
;WIDTH:0.374336
G1 X100.107 Y86.285 E.0164
G1 X100.524 Y86.668 E.01281
;WIDTH:0.399999
G1 X100.783 Y86.899 E.00844
G1 X103.041 Y89.157 E.07767
G1 X103.238 Y88.838 E.00912
G1 X101.921 Y87.52 E.04532
G1 X101.692 Y87.314 E.00749
;WIDTH:0.374336
G1 X101.703 Y87.355 E.00096
G1 X101.632 Y87.374 E.00166
G1 X101.651 Y87.303 E.00166
G1 X101.651 Y87.303 F9000
G1 X102.423 Y87.59
G1 F1200
G1 X102.404 Y87.661 E.00166
G1 X102.475 Y87.642 E.00166
G1 X102.464 Y87.601 E.00096
;WIDTH:0.399999
G1 X102.693 Y87.775 E.007
G1 X103.31 Y88.392 E.02122
G1 X103.448 Y87.908 E.01224
;WIDTH:0.445518
G1 X103.462 Y87.958 E.00142
G1 X103.425 Y87.994 E.00141
G1 X103.376 Y87.981 E.00139
G1 X103.362 Y87.932 E.00139
G1 X103.399 Y87.895 E.00143
G1 E-5 F3600
G1 X103.399 Y87.895 F9000
G1 X98.931 Y84.547
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X98.942 Y84.588 E.00096
G1 X98.871 Y84.607 E.00166
G1 X98.89 Y84.536 E.00166
;WIDTH:0.399999
G1 X98.719 Y84.318 E.00674
G1 X92.135 Y77.734 E.22649
G1 X92.358 Y77.44 E.00898
G1 X98.458 Y83.54 E.20984
G1 X98.603 Y83.757 E.00635
;WIDTH:0.374336
G1 X98.584 Y83.829 E.00168
G1 X98.655 Y83.809 E.00167
G1 X98.644 Y83.768 E.00096
G1 X98.644 Y83.768 F9000
G1 X98.329 Y82.893
;WIDTH:0.399999
G1 F1200
G1 X92.602 Y77.167 E.19699
G1 X92.867 Y76.915 E.0089
G1 X98.28 Y82.328 E.1862
G1 X98.267 Y81.798 E.0129
G1 X93.157 Y76.688 E.17578
G1 X93.475 Y76.489 E.00912
G1 X98.267 Y81.28 E.16482
G1 X98.266 Y80.762 E.0126
G1 X93.817 Y76.314 E.15303
G1 X94.191 Y76.171 E.00974
G1 X98.265 Y80.244 E.14013
G1 X98.264 Y79.726 E.0126
G1 X94.594 Y76.056 E.12625
G1 X95.033 Y75.978 E.01085
G1 X98.263 Y79.208 E.11111
G1 X98.263 Y79.208 F9000
G1 X97.971 Y78.306
;WIDTH:0.374336
G1 F1200
G1 X97.959 Y78.484 E.00403
;WIDTH:0.399999
G1 X97.797 Y78.225 E.00743
G1 X95.52 Y75.948 E.07833
G1 X96.037 Y75.948 E.01258
G1 X97.716 Y77.627 E.05776
G1 X97.733 Y77.126 E.01219
G1 X96.554 Y75.948 E.04054
G1 X97.071 Y75.947 E.01258
G1 X97.828 Y76.705 E.02606
G1 X97.962 Y76.322 E.00987
G1 X97.588 Y75.947 E.01288
G1 X98.128 Y75.914 E.01316
;WIDTH:0.429824
G1 X98.106 Y75.997 E.00226
G1 X98.189 Y75.975 E.00226
G1 X98.176 Y75.927 E.00131
G1 E-5 F3600
G1 X98.176 Y75.927 F9000
G1 X99.761 Y83.042
G1 X99.777 Y83.109
G1 X99.846 Y83.366
G1 X99.867 Y83.432
G1 X99.955 Y83.684
G1 X99.981 Y83.749
G1 X100.088 Y83.993
G1 X100.118 Y84.056
G1 X100.242 Y84.291
G1 X100.277 Y84.352
G1 X100.418 Y84.576
G1 X100.457 Y84.634
G1 X100.614 Y84.846
G1 X100.657 Y84.902
G1 X100.829 Y85.102
G1 X100.875 Y85.154
G1 X101.061 Y85.34
G1 X101.111 Y85.389
G1 X101.31 Y85.561
G1 X101.363 Y85.606
G1 X101.419 Y85.647
G1 X101.631 Y85.804
G1 X101.691 Y85.842
G1 X101.914 Y85.982
G1 X101.977 Y86.017
G1 X102.21 Y86.14
G1 X102.273 Y86.169
G1 X102.514 Y86.274
G1 X102.578 Y86.299
G1 X102.826 Y86.386
G1 X102.892 Y86.406
G1 X103.146 Y86.474
G1 X103.213 Y86.49
G1 X103.471 Y86.539
G1 X103.54 Y86.551
G1 X103.801 Y86.58
G1 X103.869 Y86.587
G1 X126.349 Y88.151
G1 X128.239 Y91.002
G1 E5 F2400
;WIDTH:0.461662
G1 F1200
G1 X128.202 Y91.04 E.00151
G1 X128.215 Y91.092 E.00152
G1 X128.267 Y91.106 E.00153
G1 X128.305 Y91.068 E.00153
G1 X128.291 Y91.016 E.00153
;WIDTH:0.399999
G1 X128.284 Y90.524 E.01197
G1 X128.974 Y91.2 E.0235
;WIDTH:0.374336
G1 X128.955 Y91.271 E.00166
G1 X129.026 Y91.252 E.00166
G1 X129.015 Y91.211 E.00096
;WIDTH:0.399999
G1 X129.362 Y91.085 E.00898
G1 X128.241 Y89.964 E.03856
G1 X128.128 Y89.678 E.00748
;WIDTH:0.374336
G1 X128.139 Y89.719 E.00096
G1 X128.068 Y89.739 E.00167
G1 X128.087 Y89.667 E.00168
G1 X128.087 Y89.667 F9000
G1 X127.752 Y88.876
G1 F1200
G1 X127.733 Y88.947 E.00166
G1 X127.804 Y88.928 E.00166
G1 X127.793 Y88.887 E.00096
;WIDTH:0.399999
G1 X127.966 Y89.172 E.00811
G1 X129.879 Y91.085 E.06581
G1 X130.396 Y91.085 E.01258
G1 X127.707 Y88.396 E.0925
G1 X127.472 Y87.835 E.01479
;WIDTH:0.374336
G1 X127.453 Y87.906 E.00166
G1 X127.524 Y87.887 E.00166
G1 X127.513 Y87.846 E.00096
;WIDTH:0.399999
G1 X127.73 Y87.902 E.00545
G1 X130.913 Y91.085 E.10949
G1 X131.43 Y91.085 E.01258
G1 X128.151 Y87.806 E.1128
G1 X128.559 Y87.696 E.01028
G1 X131.947 Y91.085 E.11656
G1 X132.464 Y91.085 E.01258
G1 X128.956 Y87.576 E.12069
G1 X129.315 Y87.418 E.00954
G1 X132.981 Y91.085 E.12613
G1 X133.499 Y91.085 E.0126
G1 X129.66 Y87.246 E.13206
G1 X129.985 Y87.053 E.00919
G1 X134.016 Y91.085 E.13868
G1 X134.533 Y91.084 E.01258
G1 X130.286 Y86.838 E.14608
G1 X130.578 Y86.613 E.00897
G1 X135.05 Y91.084 E.15382
G1 X135.567 Y91.084 E.01258
G1 X130.856 Y86.374 E.16204
G1 X131.106 Y86.106 E.00891
G1 X136.084 Y91.084 E.17124
G1 X136.601 Y91.084 E.01258
G1 X131.343 Y85.826 E.18087
G1 X131.58 Y85.546 E.00892
G1 X137.118 Y91.084 E.1905
G1 X137.635 Y91.084 E.01258
G1 X131.789 Y85.238 E.2011
G1 X131.972 Y84.904 E.00926
G1 X138.152 Y91.084 E.21259
G1 X138.669 Y91.084 E.01258
G1 X132.155 Y84.57 E.22408
G1 X132.319 Y84.217 E.00947
G1 X139.187 Y91.084 E.23624
G1 X139.649 Y91.186 E.01151
;WIDTH:0.374336
G1 X139.66 Y91.227 E.00096
G1 X139.589 Y91.247 E.00167
G1 X139.608 Y91.175 E.00168
;WIDTH:0.399999
G1 X139.554 Y90.934 E.00601
G1 X132.45 Y83.83 E.24437
G1 X132.568 Y83.432 E.0101
G1 X139.554 Y90.417 E.2403
G1 X139.554 Y89.9 E.01258
G1 X132.65 Y82.996 E.23749
G1 X132.712 Y82.541 E.01117
G1 X139.554 Y89.383 E.23536
G1 X139.554 Y88.866 E.01258
G1 X132.727 Y82.039 E.23484
G1 X132.728 Y81.523 E.01255
G1 X139.553 Y88.348 E.23478
G1 X139.553 Y87.831 E.01258
G1 X132.73 Y81.008 E.23471
G1 X132.731 Y80.492 E.01255
G1 X139.553 Y87.314 E.23467
G1 X139.553 Y86.797 E.01258
G1 X132.733 Y79.976 E.23462
G1 X132.734 Y79.461 E.01253
G1 X139.553 Y86.28 E.23457
G1 X139.553 Y85.762 E.0126
G1 X132.831 Y79.04 E.23123
G1 X133.023 Y78.715 E.00918
G1 X139.553 Y85.245 E.22463
G1 X139.553 Y84.728 E.01258
G1 X133.165 Y78.34 E.21974
G1 X133.259 Y77.917 E.01054
G1 X139.553 Y84.211 E.21651
G1 X139.553 Y83.694 E.01258
G1 X133.284 Y77.424 E.21567
G1 X133.204 Y76.828 E.01463
G1 X139.553 Y83.176 E.21838
G1 X139.553 Y82.659 E.01258
G1 X132.834 Y75.941 E.23111
G1 X132.638 Y75.79 E.00602
;WIDTH:0.374336
G1 X132.649 Y75.831 E.00096
G1 X132.577 Y75.85 E.00168
G1 X132.596 Y75.779 E.00166
G1 X132.596 Y75.779 F9000
G1 X133.352 Y75.941
;WIDTH:0.399999
G1 F1200
G1 X139.553 Y82.142 E.21331
G1 X139.552 Y81.625 E.01258
G1 X133.87 Y75.942 E.19547
G1 X134.388 Y75.943 E.0126
G1 X139.552 Y81.107 E.17764
G1 X139.552 Y80.59 E.01258
G1 X134.906 Y75.944 E.15982
G1 X135.423 Y75.944 E.01258
G1 X139.552 Y80.073 E.14203
G1 X139.511 Y79.515 E.01361
G1 X135.964 Y75.968 E.12201
G1 X136.615 Y76.102 E.01617
G1 X139.382 Y78.868 E.09517
G1 E-5 F3600
G1 X139.382 Y78.868 F9000
G1 X137.511 Y76.481
G1 E5 F2400
G1 F1200
G1 X138.98 Y77.95 E.05053
G1 X139.177 Y78.208 E.0079
;WIDTH:0.374336
G1 X139.173 Y78.056 E.00344
G1 X138.881 Y77.666 E.01102
G1 X138.381 Y77.119 E.01676
G1 X137.431 Y76.303 E.02832
G1 X137.253 Y76.299 E.00403
G1 E-5 F3600
G1 X137.253 Y76.299 F9000
G1 X126.602 Y89.571
G1 X126.349 Y88.151
G1 X104.651 Y88.151
G1 X91.407 Y92.554
G1 X91.235 Y92.651
G1 X91.126 Y92.744
G1 X91.07 Y92.795
G1 X90.751 Y93.111
G1 X90.751 Y95.718
G1 X92.053 Y153.369
G1 E5 F2400
G1 F1200
G1 X92.385 Y153.744 E.01133
G1 X93.108 Y154.428 E.02251
G1 X93.108 Y154.428 F9000
G1 X93.917 Y154.75
G1 F1200
G1 X93.928 Y154.791 E.00096
G1 X93.857 Y154.81 E.00166
G1 X93.876 Y154.739 E.00166
;WIDTH:0.399999
G1 X93.629 Y154.602 E.00687
G1 X91.905 Y152.878 E.0593
G1 X91.762 Y152.592 E.00778
;WIDTH:0.374336
G1 X91.773 Y152.633 E.00096
G1 X91.702 Y152.652 E.00166
G1 X91.721 Y152.581 E.00166
;WIDTH:0.399999
G1 X91.586 Y152.041 E.01354
G1 X94.468 Y154.924 E.09916
G1 X95.096 Y155.035 E.01551
G1 X91.467 Y151.406 E.12484
G1 X91.448 Y150.869 E.01307
G1 X95.641 Y155.062 E.14424
G1 X96.158 Y155.062 E.01258
G1 X91.448 Y150.352 E.16202
G1 X91.448 Y149.835 E.01258
G1 X96.675 Y155.062 E.17981
G1 X97.192 Y155.062 E.01258
G1 X91.447 Y149.318 E.19761
G1 X91.447 Y148.8 E.0126
G1 X97.709 Y155.062 E.21541
G1 X98.226 Y155.062 E.01258
G1 X91.447 Y148.283 E.23319
G1 X91.447 Y147.766 E.01258
G1 X98.743 Y155.062 E.25098
G1 X99.26 Y155.062 E.01258
G1 X91.447 Y147.249 E.26876
G1 X91.447 Y146.732 E.01258
G1 X99.777 Y155.061 E.28653
G1 X100.294 Y155.061 E.01258
G1 X91.447 Y146.214 E.30433
G1 X91.447 Y145.697 E.01258
G1 X100.811 Y155.061 E.32212
G1 X101.328 Y155.061 E.01258
G1 X91.447 Y145.18 E.3399
G1 X91.447 Y144.663 E.01258
G1 X101.845 Y155.061 E.35768
G1 X102.362 Y155.061 E.01258
G1 X91.447 Y144.146 E.37547
G1 X91.447 Y143.628 E.0126
G1 X102.879 Y155.061 E.39327
G1 X103.396 Y155.061 E.01258
G1 X91.447 Y143.111 E.41105
G1 X91.446 Y142.594 E.01258
G1 X103.913 Y155.06 E.42884
G1 X104.43 Y155.06 E.01258
G1 X91.446 Y142.077 E.44662
G1 X91.446 Y141.56 E.01258
G1 X104.947 Y155.06 E.46441
G1 X105.464 Y155.06 E.01258
G1 X91.446 Y141.042 E.48221
G1 X91.446 Y140.525 E.01258
G1 X105.981 Y155.06 E.49999
G1 X106.498 Y155.06 E.01258
G1 X91.446 Y140.008 E.51778
G1 X91.446 Y139.491 E.01258
G1 X107.015 Y155.06 E.53556
G1 X107.532 Y155.06 E.01258
G1 X91.446 Y138.974 E.55335
G1 X91.446 Y138.456 E.0126
G1 X108.049 Y155.059 E.57113
G1 X108.566 Y155.059 E.01258
G1 X91.446 Y137.939 E.58892
G1 X91.446 Y137.422 E.01258
G1 X109.083 Y155.059 E.6067
G1 X109.083 Y155.059 F9000
G1 X109.888 Y155.136
;WIDTH:0.374336
G1 F1200
G1 X109.899 Y155.177 E.00096
G1 X109.828 Y155.196 E.00166
G1 X109.847 Y155.125 E.00166
;WIDTH:0.399999
G1 X109.6 Y155.059 E.00622
G1 X91.446 Y136.905 E.62449
G1 X91.445 Y136.388 E.01258
G1 X95.788 Y140.738 E.14952
;WIDTH:0.388756
G1 X96.322 Y141.279 E.01792
;WIDTH:0.399999
G1 X110.117 Y155.059 E.47428
G1 X110.634 Y155.059 E.01258
G1 X98.451 Y142.876 E.41909
G1 X98.192 Y142.674 E.00799
;WIDTH:0.374336
G1 X97.467 Y142.079 E.02121
G1 E-5 F3600
G1 X97.467 Y142.079 F9000
G1 X99.271 Y143.225
G1 E5 F2400
G1 F1200
G1 X99.252 Y143.296 E.00166
G1 X99.323 Y143.277 E.00166
G1 X99.312 Y143.236 E.00096
;WIDTH:0.399999
G1 X111.151 Y155.059 E.40698
G1 X111.668 Y155.059 E.01258
G1 X100.409 Y143.8 E.3873
G1 X100.181 Y143.602 E.00735
;WIDTH:0.374336
G1 X100.192 Y143.643 E.00096
G1 X100.121 Y143.662 E.00166
G1 X100.14 Y143.591 E.00166
G1 X100.14 Y143.591 F9000
G1 X100.921 Y143.894
G1 F1200
G1 X101.064 Y143.874 E.00327
G1 X101.13 Y143.893 E.00155
;WIDTH:0.399999
G1 X101.18 Y144.053 E.00408
G1 X112.185 Y155.058 E.37856
G1 X112.702 Y155.058 E.01258
G1 X101.885 Y144.241 E.3721
G1 X102.529 Y144.368 E.01597
G1 X113.219 Y155.058 E.36773
G1 X113.736 Y155.058 E.01258
G1 X103.129 Y144.451 E.36487
G1 X103.703 Y144.508 E.01403
G1 X114.253 Y155.058 E.36291
G1 X114.77 Y155.058 E.01258
G1 X104.24 Y144.528 E.36222
G1 X104.766 Y144.537 E.0128
G1 X115.287 Y155.058 E.36192
G1 X115.804 Y155.058 E.01258
G1 X105.283 Y144.537 E.36192
G1 X105.801 Y144.537 E.0126
G1 X116.321 Y155.057 E.36188
G1 X116.838 Y155.057 E.01258
G1 X106.318 Y144.537 E.36188
G1 X106.835 Y144.537 E.01258
G1 X117.355 Y155.057 E.36188
G1 X117.872 Y155.057 E.01258
G1 X107.352 Y144.537 E.36188
G1 X107.869 Y144.537 E.01258
G1 X118.389 Y155.057 E.36188
G1 X118.906 Y155.057 E.01258
G1 X108.386 Y144.537 E.36188
G1 X108.903 Y144.537 E.01258
G1 X119.423 Y155.057 E.36188
G1 X119.94 Y155.057 E.01258
G1 X109.42 Y144.537 E.36188
G1 X109.938 Y144.537 E.0126
G1 X120.457 Y155.056 E.36185
G1 X120.974 Y155.056 E.01258
G1 X110.455 Y144.537 E.36185
G1 X110.925 Y144.49 E.01149
G1 X121.491 Y155.056 E.36346
G1 X122.008 Y155.056 E.01258
G1 X111.314 Y144.362 E.36787
G1 X111.777 Y144.308 E.01134
G1 X122.525 Y155.056 E.36972
G1 X123.042 Y155.056 E.01258
G1 X112.295 Y144.308 E.36971
G1 X112.812 Y144.308 E.01258
G1 X123.559 Y155.056 E.36971
G1 X124.076 Y155.056 E.01258
G1 X113.329 Y144.308 E.36971
G1 X113.846 Y144.308 E.01258
G1 X124.593 Y155.055 E.36969
G1 X125.11 Y155.055 E.01258
G1 X114.363 Y144.308 E.36969
G1 X114.88 Y144.308 E.01258
G1 X125.627 Y155.055 E.36969
G1 X126.144 Y155.055 E.01258
G1 X115.397 Y144.308 E.36969
G1 X115.914 Y144.308 E.01258
G1 X126.661 Y155.055 E.36969
G1 X127.178 Y155.055 E.01258
G1 X116.432 Y144.308 E.36967
G1 X116.949 Y144.308 E.01258
G1 X127.695 Y155.055 E.36967
G1 X128.212 Y155.055 E.01258
G1 X117.466 Y144.308 E.36967
G1 X117.983 Y144.308 E.01258
G1 X128.729 Y155.054 E.36966
G1 X129.246 Y155.054 E.01258
G1 X118.5 Y144.308 E.36966
G1 X119.017 Y144.308 E.01258
G1 X129.763 Y155.054 E.36966
G1 X130.28 Y155.054 E.01258
G1 X119.534 Y144.308 E.36966
G1 X119.997 Y144.334 E.01128
;WIDTH:0.374336
G1 X119.978 Y144.405 E.00166
G1 X120.049 Y144.386 E.00166
G1 X120.038 Y144.345 E.00096
;WIDTH:0.399999
G1 X120.267 Y144.524 E.00707
G1 X130.797 Y155.054 E.36222
G1 X131.314 Y155.054 E.01258
G1 X120.797 Y144.537 E.36178
G1 X121.314 Y144.537 E.01258
G1 X131.831 Y155.054 E.36178
G1 X132.348 Y155.054 E.01258
G1 X121.831 Y144.536 E.36179
G1 X122.347 Y144.536 E.01255
G1 X132.865 Y155.053 E.36179
G1 X133.382 Y155.053 E.01258
G1 X122.864 Y144.536 E.36179
G1 X123.381 Y144.535 E.01258
G1 X133.899 Y155.053 E.36181
G1 X134.416 Y155.053 E.01258
G1 X123.898 Y144.535 E.36181
G1 X124.415 Y144.535 E.01258
G1 X134.933 Y155.053 E.36181
G1 X135.45 Y155.053 E.01258
G1 X124.931 Y144.534 E.36185
G1 X125.448 Y144.534 E.01258
G1 X135.941 Y155.027 E.36095
G1 X136.386 Y154.955 E.01096
G1 X125.965 Y144.534 E.35848
G1 X126.482 Y144.533 E.01258
G1 X136.789 Y154.84 E.35455
G1 X137.154 Y154.689 E.00961
G1 X126.988 Y144.522 E.34972
G1 X127.478 Y144.496 E.01194
G1 X137.505 Y154.522 E.3449
G1 X137.824 Y154.324 E.00913
G1 X127.945 Y144.445 E.33983
G1 X128.399 Y144.382 E.01115
G1 X138.114 Y154.097 E.33419
G1 X138.382 Y153.848 E.0089
G1 X128.836 Y144.302 E.32838
G1 X129.26 Y144.209 E.01056
G1 X138.629 Y153.577 E.32227
G1 X138.854 Y153.286 E.00895
G1 X129.665 Y144.097 E.3161
G1 X130.063 Y143.978 E.0101
G1 X139.048 Y152.963 E.30908
G1 X139.217 Y152.614 E.00943
G1 X130.461 Y143.859 E.30118
G1 X130.833 Y143.713 E.00972
G1 X139.358 Y152.239 E.29327
G1 X139.468 Y151.831 E.01028
G1 X131.204 Y143.567 E.28428
G1 X131.558 Y143.404 E.00948
G1 X139.537 Y151.383 E.27447
G1 X139.563 Y150.892 E.01196
G1 X131.909 Y143.238 E.26329
G1 X132.24 Y143.052 E.00924
G1 X139.563 Y150.375 E.25191
G1 X139.563 Y149.858 E.01258
G1 X132.569 Y142.864 E.24059
G1 X132.896 Y142.674 E.0092
G1 X139.563 Y149.34 E.22932
G1 X139.563 Y148.823 E.01258
G1 X133.202 Y142.463 E.2188
G1 X133.509 Y142.252 E.00906
G1 X139.563 Y148.306 E.20825
G1 X139.563 Y147.789 E.01258
G1 X133.805 Y142.031 E.19807
G1 X134.088 Y141.797 E.00893
G1 X139.563 Y147.272 E.18834
G1 X139.562 Y146.754 E.0126
G1 X134.37 Y141.562 E.1786
G1 X134.645 Y141.32 E.00891
G1 X139.562 Y146.237 E.16914
G1 X139.562 Y145.72 E.01258
G1 X134.908 Y141.066 E.16009
G1 X135.162 Y140.803 E.00889
G1 X139.562 Y145.203 E.15136
G1 X139.562 Y144.686 E.01258
G1 X135.406 Y140.53 E.14296
G1 X135.651 Y140.257 E.00892
G1 X139.562 Y144.168 E.13454
G1 X139.562 Y143.651 E.01258
G1 X135.881 Y139.97 E.12662
G1 X136.107 Y139.679 E.00896
G1 X139.562 Y143.134 E.11885
G1 X139.562 Y142.617 E.01258
G1 X136.321 Y139.376 E.11149
G1 X136.53 Y139.068 E.00905
G1 X139.562 Y142.1 E.1043
G1 X139.562 Y141.582 E.0126
G1 X136.722 Y138.742 E.09769
G1 E-5 F3600
G1 X136.722 Y138.742 F9000
G1 X138.424 Y132.99
G1 E5 F2400
G1 F1200
G1 X138.371 Y133.831 E.0205
G1 X138.281 Y134.515 E.01678
G1 X138.141 Y135.231 E.01775
G1 X137.949 Y135.973 E.01864
G1 X137.551 Y137.107 E.02923
G1 X137.052 Y138.176 E.0287
G1 X136.912 Y138.416 E.00676
G1 X139.562 Y141.065 E.09114
G1 X139.555 Y97.689 E1.05508
G1 X138.996 Y97.744 E.01366
G1 X138.437 Y97.744 E.0136
G1 X138.435 Y132.807 E.85287
G1 X138.808 Y132.807 E.00907
;WIDTH:0.4143
G1 X138.808 Y98.115 E.87685
;WIDTH:0.410631
G1 X139.184 Y98.115 E.00941
G1 X139.184 Y98.303 E.00471
;WIDTH:0.4143
G1 X139.187 Y132.807 E.8721
;WIDTH:0.415028
G1 X139.187 Y132.854 E.00119
;WIDTH:0.446754
G1 X139.171 Y133.869 E.02785
;WIDTH:0.449364
G1 X139.17 Y133.922 E.00146
;WIDTH:0.498113
G1 X139.146 Y134.65 E.02247
G1 X139.17 Y135.009 E.0111
;WIDTH:0.449056
G1 X139.195 Y135.368 E.00993
;WIDTH:0.399999
G1 X139.196 Y140.182 E.1171
G1 X137.391 Y138.378 E.06207
G1 X137.383 Y138.331 E.00116
G1 X137.896 Y137.228 E.02959
G1 X138.289 Y136.109 E.02885
G1 X138.5 Y135.301 E.02031
;WIDTH:0.446968
G1 X138.595 Y134.935 E.01038
;WIDTH:0.493936
G1 X138.69 Y134.569 E.01156
G1 X138.759 Y133.856 E.0219
;WIDTH:0.446754
G1 X138.8 Y132.99 E.02378
G1 E-5 F3600
G1 X138.8 Y132.99 F9000
G1 X138.829 Y135.492
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X138.83 Y139.299 E.0926
G1 X137.811 Y138.28 E.03505
G1 X138.241 Y137.349 E.02494
G1 X138.634 Y136.23 E.02885
G1 X138.783 Y135.669 E.01412
G1 E-5 F3600
G1 X138.783 Y135.669 F9000
G1 X138.349 Y138.115
G1 E5 F2400
;WIDTH:0.594024
G1 F1200
G1 X138.3 Y138.164 E.00258
G1 X138.318 Y138.232 E.00262
G1 X138.385 Y138.25 E.00258
G1 X138.435 Y138.2 E.00263
G1 X138.417 Y138.133 E.00258
G1 E-5 F3600
G1 X138.417 Y138.133 F9000
G1 X131.67 Y141.795
G1 X131.325 Y141.98
G1 X131.294 Y141.997
G1 X131.262 Y142.013
G1 X131.229 Y142.029
G1 X130.885 Y142.194
G1 X130.854 Y142.208
G1 X130.822 Y142.223
G1 X130.788 Y142.238
G1 X130.747 Y142.255
G1 X130.451 Y142.38
G1 X130.412 Y142.396
G1 X130.319 Y142.433
G1 X129.95 Y142.569
G1 X129.827 Y142.61
G1 X129.59 Y142.685
G1 X129.466 Y142.723
G1 X129.311 Y142.767
G1 X129.119 Y142.818
G1 X128.962 Y142.858
G1 X128.775 Y142.9
G1 X128.629 Y142.931
G1 X128.437 Y142.969
G1 X128.221 Y143.007
G1 X128.12 Y143.023
G1 X127.897 Y143.056
G1 X127.593 Y143.092
G1 X127.346 Y143.115
G1 X127.295 Y143.118
G1 X127.05 Y143.134
G1 X126.792 Y143.145
G1 X126.758 Y143.145
G1 X126.504 Y143.149
G1 X104.496 Y143.149
G1 X104.242 Y143.145
G1 X104.208 Y143.145
G1 X103.95 Y143.134
G1 X103.705 Y143.118
G1 X103.654 Y143.115
G1 X103.407 Y143.092
G1 X103.103 Y143.056
G1 X102.88 Y143.023
G1 X102.779 Y143.007
G1 X102.563 Y142.969
G1 X102.371 Y142.931
G1 X102.225 Y142.9
G1 X102.039 Y142.858
G1 X101.881 Y142.818
G1 X101.689 Y142.767
G1 X101.534 Y142.723
G1 X101.41 Y142.685
G1 X101.173 Y142.61
G1 X101.05 Y142.569
G1 X100.681 Y142.433
G1 X100.588 Y142.396
G1 X100.549 Y142.38
G1 X100.253 Y142.255
G1 X100.212 Y142.238
G1 X100.178 Y142.223
G1 X100.146 Y142.208
G1 X100.114 Y142.193
G1 X99.771 Y142.029
G1 X99.738 Y142.013
G1 X99.706 Y141.997
G1 X99.675 Y141.98
G1 X99.33 Y141.795
G1 X99.219 Y141.731
G1 X98.907 Y141.544
G1 X98.798 Y141.474
G1 X98.495 Y141.273
G1 X98.39 Y141.198
G1 X98.097 Y140.983
G1 X91.613 Y136.038
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X94.242 Y138.666 E.09042
G1 X93.791 Y137.865 E.02236
G1 X93.304 Y136.733 E.02997
G1 X92.904 Y135.415 E.0335
G1 X92.639 Y133.919 E.03696
G1 X92.565 Y132.807 E.02711
G1 X92.563 Y97.744 E.85287
G1 X92.001 Y97.744 E.01367
G1 X91.44 Y97.688 E.01371
G1 X91.445 Y136 E.9319
G1 E-5 F3600
G1 X91.445 Y136 F9000
G1 X91.819 Y132.99
G1 E5 F2400
;WIDTH:0.448994
G1 F1200
G1 X91.835 Y133.959 E.02673
;WIDTH:0.454218
G1 X91.824 Y134.795 E.02335
;WIDTH:0.427109
G1 X91.811 Y135.544 E.01957
;WIDTH:0.399999
G1 X91.833 Y135.741 E.00482
G1 X92.967 Y136.875 E.03901
G1 X92.544 Y135.479 E.03548
;WIDTH:0.427109
G1 X92.399 Y134.744 E.01957
;WIDTH:0.454218
G1 X92.249 Y133.945 E.02271
;WIDTH:0.448994
G1 X92.195 Y132.844 E.03041
;WIDTH:0.412501
G1 X92.194 Y132.807 E.00093
;WIDTH:0.413291
G1 X92.191 Y98.116 E.8745
G1 X91.812 Y98.117 E.00955
G1 X91.816 Y132.807 E.87447
G1 E-5 F3600
G1 X91.816 Y132.807 F9000
G1 X92.17 Y135.519
G1 E5 F2400
;WIDTH:0.411462
G1 F1200
G1 X92.149 Y135.598 E.00205
G1 X92.228 Y135.577 E.00205
G1 X92.216 Y135.532 E.00117
;LAYER_CHANGE
;Z:0.78
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;0.78
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X92.228 Y135.577 E-.02212
G1 X92.149 Y135.598 E-.03883
G1 X92.17 Y135.519 E-.03883
;WIPE_END
G1 E-1.40022 F3600
G1 Z.78 F9000
;AFTER_LAYER_CHANGE
;0.78
G1 Z.78
G1 X94.473 Y135.874
G1 X96.162 Y136.134
G1 X103.907 Y137.333
G1 X103.906 Y137.357
G1 X104.263 Y137.382
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X104.247 Y137.475 E.0023
G1 X104.31 Y137.831 E.00879
G1 X104.47 Y138.142 E.00851
G1 X105 Y138.766 E.01991
G1 X105.001 Y139.339 E.01394
G1 X105.094 Y139.477 E.00405
G1 X105.182 Y139.5 E.00221
G1 X125.817 Y139.5 E.50193
G1 X125.924 Y139.465 E.00274
G1 X126 Y139.317 E.00405
G1 X126 Y138.766 E.0134
G1 X126.512 Y138.163 E.01924
G1 X126.711 Y137.769 E.01074
G1 X126.753 Y137.525 E.00602
G1 X126.69 Y137.169 E.00879
G1 X126.53 Y136.858 E.00851
G1 X126 Y136.234 E.01991
G1 X126 Y103.974 E.78469
G1 X126.133 Y103.974 E.00324
G1 X126.285 Y103.892 E.0042
G1 X126.316 Y103.792 E.00255
G1 X126.316 Y98.457 E.12977
G1 X126.311 Y98.419 E.00093
G1 X126.133 Y98.274 E.00558
G1 X126 Y98.274 E.00324
G1 X126 Y93.502 E.11607
G1 X126.046 Y93.413 E.00244
G1 X138.248 Y93.415 E.2968
G1 X139.039 Y93.439 E.01925
G1 X139.168 Y93.568 E.00444
G1 X139.243 Y93.849 E.00707
G1 X139.25 Y94.865 E.02471
G1 X139.205 Y95.178 E.00769
G1 X139.103 Y95.329 E.00443
G1 X138.929 Y95.413 E.0047
G1 X136.183 Y95.413 E.06679
G1 X136.074 Y95.45 E.0028
G1 X136 Y95.596 E.00398
G1 X136 Y127.168 E.76796
G1 X135.978 Y127.642 E.01154
G1 X135.978 Y132.948 E.12906
G1 X135.86 Y133.942 E.02435
G1 X135.696 Y134.722 E.01939
G1 X135.425 Y135.607 E.02251
G1 X135.21 Y136.153 E.01427
G1 X134.867 Y136.874 E.01942
G1 X134.396 Y137.672 E.02254
G1 X134.06 Y138.152 E.01425
G1 X133.558 Y138.773 E.01942
G1 X132.914 Y139.439 E.02253
G1 X132.474 Y139.826 E.01425
G1 X131.841 Y140.314 E.01944
G1 X131.06 Y140.81 E.0225
G1 X130.541 Y141.084 E.01428
G1 X129.812 Y141.41 E.01942
G1 X128.936 Y141.71 E.02252
G1 X128.368 Y141.855 E.01426
G1 X127.585 Y142.002 E.01938
G1 X126.193 Y142.1 E.03394
G1 X120.85 Y142.1 E.12996
G1 X120.85 Y141.982 E.00287
G1 X120.778 Y141.836 E.00396
G1 X120.667 Y141.799 E.00285
G1 X110.333 Y141.799 E.25136
G1 X110.223 Y141.836 E.00282
G1 X110.15 Y141.982 E.00397
G1 X110.15 Y142.1 E.00287
G1 X104.339 Y142.089 E.14135
G1 X103.082 Y141.946 E.03077
G1 X102.51 Y141.829 E.0142
G1 X101.621 Y141.57 E.02252
G1 X100.877 Y141.279 E.01943
G1 X100.348 Y141.031 E.01421
G1 X99.158 Y140.313 E.03381
G1 X98.175 Y139.521 E.03071
G1 X97.757 Y139.116 E.01416
G1 X96.864 Y138.05 E.03383
G1 X96.191 Y136.983 E.03069
G1 X95.928 Y136.464 E.01415
G1 X95.428 Y135.166 E.03383
G1 X95.191 Y134.163 E.02507
G1 X95.074 Y133.484 E.01676
G1 X95.021 Y132.951 E.01303
G1 X95.021 Y127.642 E.12914
G1 X94.999 Y127.607 E.00101
G1 X94.999 Y95.596 E.77864
G1 X94.926 Y95.45 E.00397
G1 X94.816 Y95.413 E.00282
G1 X92.192 Y95.413 E.06383
G1 X91.92 Y95.36 E.00674
G1 X91.852 Y95.273 E.00269
G1 X91.758 Y95.032 E.00629
G1 X91.758 Y93.875 E.02814
G1 X91.813 Y93.633 E.00604
G1 X91.907 Y93.492 E.00412
G1 X92.071 Y93.415 E.00441
G1 X104.913 Y93.415 E.31237
G1 X105 Y93.471 E.00252
G1 X105 Y98.274 E.11683
G1 X104.867 Y98.274 E.00324
G1 X104.7 Y98.384 E.00486
G1 X104.685 Y98.457 E.00181
G1 X104.685 Y103.792 E.12977
G1 X104.696 Y103.854 E.00153
G1 X104.867 Y103.974 E.00508
G1 X105 Y103.974 E.00324
G1 X105 Y136.234 E.78469
G1 X104.47 Y136.858 E.01991
G1 X104.289 Y137.231 E.01008
G1 X104.273 Y137.323 E.00227
G1 X104.273 Y137.323 F9000
G1 X103.904 Y137.334
;TYPE:Perimeter
G1 F6000
G1 X103.885 Y137.426 E.00229
G1 X103.961 Y137.942 E.01269
G1 X104.191 Y138.379 E.01201
G1 X104.634 Y138.9 E.01663
G1 X104.634 Y139.317 E.01014
G1 X104.685 Y139.546 E.00571
G1 X104.917 Y139.797 E.00831
G1 X105.182 Y139.866 E.00666
G1 X125.817 Y139.866 E.50193
G1 X125.912 Y139.857 E.00232
G1 X126.139 Y139.762 E.00599
G1 X126.276 Y139.618 E.00483
G1 X126.347 Y139.461 E.00419
G1 X126.366 Y138.9 E.01365
G1 X126.809 Y138.379 E.01663
G1 X127.042 Y137.924 E.01243
G1 X127.115 Y137.574 E.0087
G1 X127.041 Y137.064 E.01254
G1 X126.809 Y136.621 E.01216
G1 X126.366 Y136.1 E.01663
G1 X126.366 Y104.215 E.77557
G1 X126.59 Y104.094 E.00619
G1 X126.648 Y103.98 E.00311
G1 X126.681 Y103.792 E.00464
G1 X126.681 Y98.457 E.12977
G1 X126.635 Y98.236 E.00549
G1 X126.366 Y98.061 E.00781
G1 X126.366 Y93.778 E.10418
G1 X138.862 Y93.781 E.30395
G1 X138.878 Y93.851 E.00175
G1 X138.863 Y95.048 E.02912
G1 X136.183 Y95.048 E.06519
G1 X135.854 Y95.157 E.00843
G1 X135.677 Y95.385 E.00702
G1 X135.635 Y95.596 E.00523
G1 X135.634 Y127.168 E.76796
G1 X135.613 Y127.642 E.01154
G1 X135.613 Y132.926 E.12853
G1 X135.499 Y133.883 E.02344
G1 X135.341 Y134.63 E.01857
G1 X135.079 Y135.486 E.02177
G1 X134.874 Y136.007 E.01362
G1 X134.544 Y136.702 E.01871
G1 X134.089 Y137.474 E.0218
G1 X133.767 Y137.932 E.01362
G1 X133.284 Y138.531 E.01872
G1 X132.661 Y139.174 E.02178
G1 X132.241 Y139.544 E.01361
G1 X131.631 Y140.014 E.01873
G1 X130.876 Y140.494 E.02176
G1 X130.381 Y140.755 E.01361
G1 X129.678 Y141.07 E.01874
G1 X128.832 Y141.36 E.02175
G1 X128.289 Y141.498 E.01363
G1 X127.538 Y141.638 E.01858
G1 X126.18 Y141.735 E.03312
G1 X121.093 Y141.735 E.12374
G1 X120.998 Y141.545 E.00517
G1 X120.667 Y141.434 E.00849
G1 X110.333 Y141.434 E.25136
G1 X110.002 Y141.544 E.00848
G1 X109.908 Y141.734 E.00516
G1 X104.36 Y141.723 E.13495
G1 X103.14 Y141.585 E.02986
G1 X102.598 Y141.474 E.01346
G1 X101.739 Y141.224 E.02176
G1 X101.022 Y140.943 E.01873
G1 X100.521 Y140.708 E.01346
G1 X99.368 Y140.013 E.03275
G1 X98.418 Y139.246 E.0297
G1 X98.025 Y138.866 E.0133
G1 X97.16 Y137.835 E.03274
G1 X96.51 Y136.802 E.02969
G1 X96.262 Y136.315 E.01329
G1 X95.778 Y135.058 E.03276
G1 X95.547 Y134.079 E.02447
G1 X95.436 Y133.433 E.01594
G1 X95.386 Y132.935 E.01217
G1 X95.386 Y127.642 E.12875
G1 X95.365 Y127.574 E.00173
G1 X95.365 Y95.596 E.77783
G1 X95.322 Y95.385 E.00524
G1 X95.145 Y95.157 E.00702
G1 X94.816 Y95.048 E.00843
G1 X92.143 Y95.048 E.06502
G1 X92.123 Y94.987 E.00156
G1 X92.123 Y94.414 E.01394
G1 X92.149 Y93.781 E.01541
G1 X104.634 Y93.781 E.30369
G1 X104.634 Y98.061 E.10411
G1 X104.365 Y98.236 E.00781
G1 X104.319 Y98.457 E.00549
G1 X104.319 Y103.792 E.12977
G1 X104.327 Y103.886 E.00229
G1 X104.41 Y104.094 E.00545
G1 X104.634 Y104.215 E.00619
G1 X104.634 Y136.1 E.77557
G1 X104.191 Y136.621 E.01663
G1 X103.958 Y137.076 E.01243
G1 X103.916 Y137.275 E.00495
G1 X103.916 Y137.275 F9000
G1 X103.542 Y137.286
G1 F6000
G1 X103.515 Y137.542 E.00626
G1 X103.646 Y138.148 E.01508
G1 X103.913 Y138.616 E.01311
G1 X104.269 Y139.035 E.01337
G1 X104.269 Y139.317 E.00686
G1 X104.352 Y139.699 E.00951
G1 X104.74 Y140.117 E.01387
G1 X105.181 Y140.231 E.01108
G1 X125.817 Y140.231 E.50195
G1 X125.975 Y140.218 E.00386
G1 X126.353 Y140.058 E.00998
G1 X126.581 Y139.819 E.00803
G1 X126.7 Y139.556 E.00702
G1 X126.731 Y139.035 E.0127
G1 X127.104 Y138.596 E.01401
G1 X127.374 Y138.078 E.01421
G1 X127.477 Y137.624 E.01132
G1 X127.467 Y137.316 E.0075
G1 X127.341 Y136.823 E.01238
G1 X127.087 Y136.384 E.01234
G1 X126.731 Y135.965 E.01337
G1 X126.731 Y104.384 E.76818
G1 X126.895 Y104.296 E.00453
G1 X126.991 Y104.106 E.00518
G1 X127.047 Y103.792 E.00776
G1 X127.047 Y98.457 E.12977
G1 X126.969 Y98.089 E.00915
G1 X126.731 Y97.934 E.00691
G1 X126.731 Y94.144 E.09219
G1 X135.395 Y94.146 E.21074
;WIDTH:0.442585
G1 X135.789 Y94.167 E.01071
;WIDTH:0.485171
G1 X136.183 Y94.189 E.01183
G1 X138.472 Y94.189 E.06865
;WIDTH:0.484976
G1 X138.475 Y94.639 E.01349
;WIDTH:0.485171
G1 X136.183 Y94.639 E.06874
;WIDTH:0.494128
G1 X136.017 Y94.649 E.00509
G1 X135.826 Y94.757 E.00671
;WIDTH:0.447064
G1 X135.635 Y94.865 E.00602
;WIDTH:0.399999
G1 X135.339 Y95.244 E.0117
G1 X135.269 Y95.596 E.00873
G1 X135.269 Y127.168 E.76796
G1 X135.247 Y127.642 E.01154
G1 X135.247 Y132.905 E.12802
G1 X135.138 Y133.823 E.02249
G1 X134.987 Y134.539 E.0178
G1 X134.734 Y135.366 E.02104
G1 X134.538 Y135.861 E.01295
G1 X134.22 Y136.531 E.01804
G1 X133.781 Y137.275 E.02101
G1 X133.475 Y137.711 E.01296
G1 X133.009 Y138.288 E.01804
G1 X132.409 Y138.909 E.021
G1 X132.009 Y139.262 E.01298
G1 X131.421 Y139.714 E.01804
G1 X130.692 Y140.177 E.02101
G1 X130.221 Y140.426 E.01296
G1 X129.544 Y140.729 E.01804
G1 X128.727 Y141.009 E.02101
G1 X128.21 Y141.141 E.01298
G1 X127.491 Y141.275 E.01779
G1 X126.167 Y141.369 E.03229
G1 X121.276 Y141.369 E.11897
G1 X121.219 Y141.254 E.00312
G1 X120.667 Y141.068 E.01417
G1 X110.333 Y141.068 E.25136
G1 X110.175 Y141.082 E.00386
G1 X109.782 Y141.253 E.01043
G1 X109.725 Y141.368 E.00312
G1 X104.381 Y141.358 E.12999
G1 X103.197 Y141.223 E.02899
G1 X102.686 Y141.118 E.01269
G1 X101.857 Y140.877 E.021
G1 X101.166 Y140.607 E.01805
G1 X100.693 Y140.385 E.01271
G1 X99.578 Y139.713 E.03167
G1 X98.66 Y138.972 E.0287
G1 X98.293 Y138.617 E.01242
G1 X97.456 Y137.619 E.03168
G1 X96.828 Y136.621 E.02868
G1 X96.597 Y136.166 E.01241
G1 X96.23 Y135.213 E.02484
G1 X96.064 Y134.675 E.0137
G1 X95.83 Y133.608 E.02657
G1 X95.752 Y132.919 E.01687
G1 X95.752 Y127.642 E.12836
G1 X95.73 Y127.542 E.00249
G1 X95.73 Y95.596 E.77705
G1 X95.66 Y95.244 E.00873
G1 X95.365 Y94.865 E.01168
;WIDTH:0.44246
G1 X95.09 Y94.752 E.00807
;WIDTH:0.48492
G1 X94.816 Y94.639 E.00888
G1 X92.531 Y94.639 E.06849
G1 X92.531 Y94.189 E.01349
G1 X94.816 Y94.189 E.06849
G1 X95.21 Y94.168 E.01183
;WIDTH:0.44246
G1 X95.604 Y94.146 E.01071
;WIDTH:0.399999
G1 X104.269 Y94.146 E.21077
G1 X104.269 Y97.934 E.09214
G1 X104.031 Y98.089 E.00691
G1 X103.953 Y98.457 E.00915
G1 X103.953 Y103.792 E.12977
G1 X103.967 Y103.949 E.00383
G1 X104.105 Y104.296 E.00908
G1 X104.269 Y104.384 E.00453
G1 X104.269 Y135.965 E.76818
G1 X103.781 Y136.59 E.01929
G1 X103.559 Y137.127 E.01413
G1 X103.548 Y137.226 E.00242
G1 E-5 F3600
G1 X103.548 Y137.226 F9000
G1 X103.914 Y137.301
G1 X103.896 Y137.5
G1 X103.907 Y137.667
G1 X103.941 Y137.83
G1 X103.994 Y137.989
G1 X104.651 Y139.849
G1 X110.101 Y140.66
G1 E5 F2400
;WIDTH:0.525622
G1 F6000
G1 X110.333 Y140.65 E.00759
;WIDTH:0.505428
G1 X120.667 Y140.65 E.32384
G1 E-5 F3600
G1 X120.667 Y140.65 F9000
G1 X103.941 Y137.83
G1 X103.896 Y137.5
G1 X103.903 Y124.395
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X103.903 Y135.831 E.27817
G1 X103.634 Y136.148 E.01011
G1 X103.449 Y136.436 E.00833
G1 X103.2 Y137.055 E.01623
G1 X103.15 Y137.559 E.01232
G1 X103.257 Y138.14 E.01437
G1 X103.502 Y138.666 E.01411
G1 X103.903 Y139.169 E.01565
G1 X103.912 Y139.468 E.00728
G1 X104.02 Y139.852 E.0097
G1 X104.562 Y140.437 E.0194
;WIDTH:0.415509
G1 X105.183 Y140.605 E.01631
;WIDTH:0.419442
G1 X109.44 Y140.607 E.10905
;WIDTH:0.454836
G1 X109.66 Y140.624 E.00617
;WIDTH:0.490229
G1 X109.881 Y140.642 E.00672
;WIDTH:0.525622
G1 X110.101 Y140.66 E.00721
G1 X109.913 Y140.771 E.00713
;WIDTH:0.490229
G1 X109.725 Y140.881 E.00661
;WIDTH:0.454836
G1 X109.537 Y140.992 E.00611
;WIDTH:0.419442
G1 X105.182 Y140.986 E.11156
;WIDTH:0.415509
G1 X104.402 Y140.992 E.01978
;WIDTH:0.399999
G1 X103.287 Y140.866 E.02729
G1 X102.774 Y140.763 E.01273
G1 X101.975 Y140.531 E.02024
G1 X101.357 Y140.289 E.01614
G1 X100.866 Y140.062 E.01316
G1 X99.788 Y139.412 E.03062
G1 X98.995 Y138.772 E.02479
G1 X98.561 Y138.367 E.01444
G1 X97.753 Y137.403 E.0306
G1 X97.235 Y136.581 E.02363
G1 X96.931 Y136.017 E.01558
G1 X96.571 Y135.082 E.02437
G1 X96.419 Y134.591 E.0125
G1 X96.192 Y133.557 E.02575
G1 X96.118 Y132.903 E.01601
G1 X96.118 Y127.642 E.12797
G1 X96.096 Y127.51 E.00326
G1 X96.096 Y95.596 E.77628
G1 X95.998 Y95.104 E.0122
G1 X95.584 Y94.572 E.0164
G1 X95.404 Y94.512 E.00462
G1 X103.903 Y94.512 E.20673
G1 X103.903 Y97.807 E.08015
G1 X103.696 Y97.942 E.00601
G1 X103.616 Y98.187 E.00627
G1 X103.588 Y98.457 E.0066
G1 X103.588 Y103.792 E.12977
G1 X103.665 Y104.231 E.01084
G1 X103.8 Y104.498 E.00728
G1 X103.903 Y104.553 E.00284
G1 X103.903 Y124.335 E.48118
G1 E-5 F3600
G1 X103.903 Y124.335 F9000
G1 X103.537 Y135.697
G1 E5 F2400
G1 F6000
G1 X103.157 Y136.203 E.01539
G1 X102.963 Y136.613 E.01103
G1 X102.826 Y137.073 E.01167
G1 X102.785 Y137.576 E.01228
G1 X102.905 Y138.239 E.01639
G1 X103.186 Y138.85 E.01636
G1 X103.528 Y139.293 E.01361
G1 X103.549 Y139.512 E.00535
G1 X103.688 Y140.005 E.01246
G1 X104.246 Y140.607 E.01997
G1 X103.297 Y140.497 E.02324
G1 X102.558 Y140.32 E.01848
G1 X101.709 Y140.034 E.02179
G1 X101.038 Y139.739 E.01783
G1 X99.998 Y139.112 E.02954
G1 X99.224 Y138.488 E.02418
G1 X98.829 Y138.118 E.01316
G1 X98.049 Y137.187 E.02954
G1 X97.545 Y136.386 E.02302
G1 X97.266 Y135.868 E.01431
G1 X96.912 Y134.95 E.02393
G1 X96.775 Y134.507 E.01128
G1 X96.554 Y133.507 E.02491
G1 X96.483 Y132.887 E.01518
G1 X96.483 Y127.642 E.12758
G1 X96.462 Y127.478 E.00402
G1 X96.462 Y95.596 E.7755
G1 X96.335 Y94.963 E.0157
G1 X96.269 Y94.878 E.00262
G1 X103.537 Y94.878 E.17679
G1 X103.537 Y97.68 E.06816
G1 X103.361 Y97.794 E.0051
G1 X103.259 Y98.11 E.00808
G1 X103.222 Y98.457 E.00849
G1 X103.222 Y103.792 E.12977
G1 X103.247 Y104.076 E.00693
G1 X103.322 Y104.357 E.00707
G1 X103.537 Y104.722 E.0103
G1 X103.537 Y135.637 E.75198
G1 E-5 F3600
G1 X103.537 Y135.637 F9000
G1 X103.941 Y137.83
G1 X121.199 Y141.451
G1 X120.85 Y141.451
G1 X120.85 Y140.721
G1 E5 F2400
;WIDTH:0.505428
G1 F6000
G1 X120.667 Y140.65 E.00615
G1 X121.115 Y140.628 E.01406
;WIDTH:0.462856
G1 X121.563 Y140.607 E.01278
;WIDTH:0.420285
G1 X125.817 Y140.607 E.10921
;WIDTH:0.425885
G1 X126.101 Y140.578 E.00744
G1 X126.567 Y140.354 E.01347
;WIDTH:0.399999
G1 X126.887 Y140.019 E.01127
G1 X127.052 Y139.652 E.00979
G1 X127.097 Y139.169 E.0118
G1 X127.348 Y138.874 E.00942
G1 X127.598 Y138.462 E.01172
G1 X127.802 Y137.936 E.01372
G1 X127.844 Y137.367 E.01388
G1 X127.747 Y136.873 E.01225
G1 X127.52 Y136.375 E.01331
G1 X127.097 Y135.831 E.01676
G1 X127.097 Y104.553 E.76081
G1 X127.2 Y104.498 E.00284
G1 X127.335 Y104.231 E.00728
G1 X127.412 Y103.792 E.01084
G1 X127.411 Y98.406 E.13101
G1 X127.304 Y97.942 E.01158
G1 X127.097 Y97.807 E.00601
G1 X127.097 Y94.51 E.0802
G1 X135.556 Y94.511 E.20576
G1 X135.415 Y94.572 E.00374
G1 X135.002 Y95.104 E.01638
G1 X134.903 Y95.596 E.01221
G1 X134.903 Y127.168 E.76796
G1 X134.881 Y127.642 E.01154
G1 X134.881 Y132.883 E.12748
G1 X134.777 Y133.764 E.02158
G1 X134.632 Y134.447 E.01698
G1 X134.388 Y135.245 E.0203
G1 X134.203 Y135.716 E.01231
G1 X133.897 Y136.359 E.01732
G1 X133.474 Y137.077 E.02027
G1 X133.183 Y137.491 E.01231
G1 X132.735 Y138.046 E.01735
G1 X132.156 Y138.645 E.02026
G1 X131.776 Y138.979 E.01231
G1 X131.211 Y139.414 E.01734
G1 X130.508 Y139.861 E.02026
G1 X130.061 Y140.097 E.0123
G1 X129.41 Y140.388 E.01734
G1 X128.622 Y140.658 E.02026
G1 X128.131 Y140.784 E.01233
G1 X127.445 Y140.912 E.01697
G1 X126.787 Y140.958 E.01604
;WIDTH:0.420285
G1 X125.817 Y140.993 E.02492
G1 X121.465 Y140.993 E.11173
G1 X121.446 Y140.954 E.00111
;WIDTH:0.462856
G1 X121.057 Y140.802 E.01191
;WIDTH:0.505428
G1 X120.906 Y140.743 E.00508
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X120.85 Y140.721 E-.02858
G1 X120.667 Y140.65 E-.09324
G1 X121.115 Y140.628 E-.21306
G1 X121.563 Y140.607 E-.21303
G1 X123.567 Y140.607 E-.95209
;WIPE_END
G1 X126.349 Y139.849 F9000
G1 X127.006 Y137.989
G1 X127.059 Y137.83
G1 X127.093 Y137.667
G1 X127.463 Y135.697
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X127.463 Y104.722 E.75344
G1 X127.678 Y104.357 E.0103
G1 X127.753 Y104.081 E.00696
G1 X127.778 Y103.792 E.00706
G1 X127.778 Y98.457 E.12977
G1 X127.741 Y98.109 E.00851
G1 X127.639 Y97.795 E.00803
G1 X127.463 Y97.68 E.00511
G1 X127.463 Y94.875 E.06823
G1 X134.731 Y94.877 E.17679
G1 X134.664 Y94.963 E.00265
G1 X134.538 Y95.596 E.0157
G1 X134.537 Y127.168 E.76796
G1 X134.516 Y127.642 E.01154
G1 X134.516 Y132.862 E.12697
G1 X134.416 Y133.704 E.02062
G1 X134.278 Y134.356 E.01621
G1 X134.082 Y134.997 E.0163
G1 X133.867 Y135.57 E.01489
G1 X133.574 Y136.187 E.01661
G1 X133.225 Y136.778 E.01669
G1 X132.891 Y137.271 E.01448
G1 X132.461 Y137.803 E.01664
G1 X131.965 Y138.316 E.01736
G1 X131.544 Y138.697 E.01381
G1 X131.001 Y139.114 E.01665
G1 X130.374 Y139.513 E.01808
G1 X129.9 Y139.769 E.0131
G1 X129.275 Y140.048 E.01665
G1 X128.548 Y140.297 E.01869
G1 X128.053 Y140.426 E.01244
G1 X127.398 Y140.548 E.01621
G1 X126.841 Y140.588 E.01358
G1 X127.193 Y140.22 E.01239
G1 X127.405 Y139.748 E.01259
G1 X127.463 Y139.317 E.01058
G1 X127.674 Y139.054 E.0082
G1 X128.037 Y138.387 E.01847
G1 X128.176 Y137.914 E.01199
G1 X128.208 Y137.33 E.01423
G1 X128.1 Y136.778 E.01368
G1 X127.843 Y136.203 E.01532
G1 X127.499 Y135.745 E.01393
G1 E-5 F3600
G1 X127.499 Y135.745 F9000
G1 X130.75 Y139.144
G1 E5 F2400
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X132.255 Y137.621 E.05208
G1 X132.935 Y136.73 E.02726
G1 X133.346 Y136.028 E.01979
G1 X129.933 Y139.441 E.11741
G1 X129.003 Y139.851 E.02472
G1 X133.76 Y135.094 E.16364
G1 X133.997 Y134.338 E.01927
G1 X128.239 Y140.096 E.19807
G1 X127.585 Y140.229 E.01623
G1 X134.142 Y133.673 E.22554
G1 X134.213 Y133.082 E.01448
G1 X127.717 Y139.578 E.22346
G1 X127.732 Y139.41 E.0041
G1 X128.128 Y138.84 E.01688
G1 X128.294 Y138.481 E.00962
G1 X134.241 Y132.534 E.20457
G1 X134.241 Y132.014 E.01265
G1 X128.464 Y137.792 E.19874
G1 X128.467 Y137.269 E.01272
G1 X134.241 Y131.494 E.19864
G1 X134.241 Y130.975 E.01262
G1 X128.39 Y136.826 E.20127
G1 X128.263 Y136.433 E.01005
G1 X134.241 Y130.455 E.20564
G1 X134.241 Y129.935 E.01265
G1 X128.091 Y136.086 E.21157
G1 X127.882 Y135.774 E.00913
G1 X134.241 Y129.415 E.21875
G1 X134.241 Y128.895 E.01265
G1 X127.737 Y135.4 E.22375
G1 X127.737 Y134.88 E.01265
G1 X134.241 Y128.376 E.22373
G1 X134.241 Y127.856 E.01265
G1 X127.737 Y134.36 E.22373
G1 X127.737 Y133.841 E.01262
G1 X134.263 Y127.314 E.22451
G1 X134.263 Y126.795 E.01262
G1 X127.737 Y133.321 E.22449
G1 X127.737 Y132.801 E.01265
G1 X134.263 Y126.275 E.22449
G1 X134.263 Y125.755 E.01265
G1 X127.737 Y132.281 E.22449
G1 X127.737 Y131.762 E.01262
G1 X134.263 Y125.235 E.22451
G1 X134.263 Y124.716 E.01262
G1 X127.737 Y131.242 E.22449
G1 X127.737 Y130.722 E.01265
G1 X134.263 Y124.196 E.22449
G1 X134.263 Y123.676 E.01265
G1 X127.737 Y130.202 E.22449
G1 X127.737 Y129.683 E.01262
G1 X134.263 Y123.156 E.22451
G1 X134.263 Y122.636 E.01265
G1 X127.737 Y129.163 E.22451
G1 X127.737 Y128.643 E.01265
G1 X134.263 Y122.117 E.22449
G1 X134.263 Y121.597 E.01265
G1 X127.737 Y128.123 E.22449
G1 X127.737 Y127.603 E.01265
G1 X134.263 Y121.077 E.22449
G1 X134.263 Y120.557 E.01265
G1 X127.737 Y127.084 E.22451
G1 X127.737 Y126.564 E.01265
G1 X134.263 Y120.038 E.22449
G1 X134.263 Y119.518 E.01265
G1 X127.737 Y126.044 E.22449
G1 X127.737 Y125.524 E.01265
G1 X134.263 Y118.998 E.22449
G1 X134.263 Y118.478 E.01265
G1 X127.737 Y125.005 E.22451
G1 X127.737 Y124.485 E.01265
G1 X134.263 Y117.958 E.22451
G1 X134.263 Y117.439 E.01262
G1 X127.737 Y123.965 E.22449
G1 X127.737 Y123.445 E.01265
G1 X134.263 Y116.919 E.22449
G1 X134.263 Y116.399 E.01265
G1 X127.737 Y122.926 E.22451
G1 X127.737 Y122.406 E.01265
G1 X134.263 Y115.879 E.22451
G1 X134.263 Y115.36 E.01262
G1 X127.737 Y121.886 E.22449
G1 X127.737 Y121.366 E.01265
G1 X134.263 Y114.84 E.22449
G1 X134.263 Y114.32 E.01265
G1 X127.737 Y120.846 E.22449
G1 X127.737 Y120.327 E.01262
G1 X134.263 Y113.8 E.22451
G1 X134.263 Y113.281 E.01262
G1 X127.737 Y119.807 E.22449
G1 X127.737 Y119.287 E.01265
G1 X134.263 Y112.761 E.22449
G1 X134.263 Y112.241 E.01265
G1 X127.737 Y118.767 E.22449
G1 X127.737 Y118.248 E.01262
G1 X134.263 Y111.721 E.22451
G1 X134.263 Y111.201 E.01265
G1 X127.737 Y117.728 E.22451
G1 X127.737 Y117.208 E.01265
G1 X134.263 Y110.682 E.22449
G1 X134.263 Y110.162 E.01265
G1 X127.737 Y116.688 E.22449
G1 X127.737 Y116.169 E.01262
G1 X134.263 Y109.642 E.22451
G1 X134.263 Y109.122 E.01265
G1 X127.737 Y115.649 E.22451
G1 X127.737 Y115.129 E.01265
G1 X134.263 Y108.603 E.22449
G1 X134.263 Y108.083 E.01265
G1 X127.737 Y114.609 E.22449
G1 X127.737 Y114.089 E.01265
G1 X134.263 Y107.563 E.22449
G1 X134.263 Y107.043 E.01265
G1 X127.737 Y113.57 E.22451
G1 X127.737 Y113.05 E.01265
G1 X134.263 Y106.523 E.22451
G1 X134.263 Y106.004 E.01262
G1 X127.737 Y112.53 E.22449
G1 X127.737 Y112.01 E.01265
G1 X134.263 Y105.484 E.22449
G1 X134.263 Y104.964 E.01265
G1 X127.737 Y111.491 E.22451
G1 X127.737 Y110.971 E.01265
G1 X134.263 Y104.444 E.22451
G1 X134.263 Y103.925 E.01262
G1 X127.737 Y110.451 E.22449
G1 X127.737 Y109.931 E.01265
G1 X134.263 Y103.405 E.22449
G1 X134.263 Y102.885 E.01265
G1 X127.737 Y109.412 E.22451
G1 X127.737 Y108.892 E.01265
G1 X134.263 Y102.365 E.22451
G1 X134.263 Y101.845 E.01265
G1 X127.737 Y108.372 E.22451
G1 X127.737 Y107.852 E.01265
G1 X134.263 Y101.326 E.22449
G1 X134.263 Y100.806 E.01265
G1 X127.737 Y107.333 E.22451
G1 X127.737 Y106.813 E.01265
G1 X134.263 Y100.286 E.22451
G1 X134.264 Y99.766 E.01265
G1 X127.737 Y106.293 E.22452
G1 X127.737 Y105.773 E.01265
G1 X134.264 Y99.247 E.22451
G1 X134.264 Y98.727 E.01265
G1 X127.737 Y105.253 E.22451
G1 X127.737 Y104.83 E.01029
G1 X127.844 Y104.627 E.00558
G1 X134.264 Y98.207 E.22084
G1 X134.264 Y97.687 E.01265
G1 X128.042 Y103.908 E.21402
G1 X128.052 Y103.379 E.01287
G1 X134.264 Y97.168 E.21367
G1 X134.264 Y96.648 E.01265
G1 X128.052 Y102.859 E.21367
G1 X128.052 Y102.339 E.01265
G1 X134.264 Y96.128 E.21367
G1 X134.264 Y95.608 E.01265
G1 X128.052 Y101.82 E.21369
G1 X128.052 Y101.3 E.01265
G1 X133.828 Y95.524 E.19869
G1 X133.308 Y95.524 E.01265
G1 X128.052 Y100.781 E.18082
G1 X128.051 Y100.261 E.01265
G1 X132.788 Y95.524 E.16295
G1 X132.269 Y95.524 E.01262
G1 X128.051 Y99.741 E.14508
G1 X128.051 Y99.222 E.01262
G1 X131.749 Y95.524 E.12721
G1 X131.229 Y95.524 E.01265
G1 X128.051 Y98.702 E.10932
G1 X128.029 Y98.205 E.0121
G1 X130.709 Y95.524 E.09221
G1 X130.189 Y95.525 E.01265
G1 X127.924 Y97.789 E.0779
G1 X127.883 Y97.662 E.00325
G1 X127.737 Y97.567 E.00424
G1 X127.737 Y97.457 E.00268
G1 X129.669 Y95.525 E.06646
G1 X129.149 Y95.525 E.01265
G1 X127.737 Y96.937 E.04857
G1 X127.737 Y96.417 E.01265
G1 X128.63 Y95.525 E.0307
G1 X128.11 Y95.525 E.01265
G1 X127.572 Y96.062 E.01849
G1 X127.572 Y96.062 F9000
G1 X127.742 Y95.155
;TYPE:Solid infill
;WIDTH:0.409484
G1 F1200
G1 X134.337 Y95.155 E.16458
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X131.179 Y95.155 E-1.5
;WIPE_END
G1 X97.247 Y95.359 F9000
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X96.736 Y95.87 E.01758
G1 X96.736 Y96.392 E.0127
G1 X97.604 Y95.524 E.02986
G1 X98.126 Y95.524 E.0127
G1 X96.736 Y96.914 E.04782
G1 X96.736 Y97.435 E.01267
G1 X98.647 Y95.524 E.06574
G1 X99.169 Y95.524 E.0127
G1 X96.736 Y97.957 E.08369
G1 X96.736 Y98.479 E.0127
G1 X99.69 Y95.524 E.10163
G1 X100.212 Y95.524 E.0127
G1 X96.736 Y99 E.11957
G1 X96.736 Y99.522 E.0127
G1 X100.734 Y95.524 E.13753
G1 X101.255 Y95.525 E.01267
G1 X96.736 Y100.044 E.15545
G1 X96.736 Y100.566 E.0127
G1 X101.777 Y95.525 E.17341
G1 X102.298 Y95.525 E.01267
G1 X96.736 Y101.087 E.19133
G1 X96.736 Y101.609 E.0127
G1 X102.82 Y95.525 E.20929
G1 X103.263 Y95.525 E.01078
G1 X103.263 Y95.603 E.0019
G1 X96.736 Y102.131 E.22454
G1 X96.736 Y102.652 E.01267
G1 X103.263 Y96.125 E.22452
G1 X103.263 Y96.647 E.0127
G1 X96.736 Y103.174 E.22452
G1 X96.736 Y103.696 E.0127
G1 X103.263 Y97.169 E.22452
G1 X103.263 Y97.566 E.00966
G1 X103.117 Y97.662 E.00425
G1 X103.033 Y97.92 E.0066
G1 X96.736 Y104.217 E.21661
G1 X96.736 Y104.739 E.0127
G1 X102.948 Y98.527 E.21369
G1 X102.948 Y99.049 E.0127
G1 X96.736 Y105.261 E.21369
G1 X96.736 Y105.782 E.01267
G1 X102.948 Y99.571 E.21367
G1 X102.948 Y100.092 E.01267
G1 X96.736 Y106.304 E.21369
G1 X96.736 Y106.826 E.0127
G1 X102.948 Y100.614 E.21369
G1 X102.948 Y101.136 E.0127
G1 X96.736 Y107.348 E.21369
G1 X96.736 Y107.869 E.01267
G1 X102.948 Y101.658 E.21367
G1 X102.948 Y102.179 E.01267
G1 X96.736 Y108.391 E.21369
G1 X96.736 Y108.913 E.0127
G1 X102.948 Y102.701 E.21369
G1 X102.948 Y103.223 E.0127
G1 X96.736 Y109.434 E.21367
G1 X96.736 Y109.956 E.0127
G1 X102.948 Y103.744 E.21369
G1 X103 Y104.214 E.0115
G1 X96.736 Y110.478 E.21548
G1 X96.736 Y110.999 E.01267
G1 X103.14 Y104.596 E.22028
G1 X103.263 Y104.83 E.00643
G1 X103.263 Y104.994 E.00399
G1 X96.736 Y111.521 E.22452
G1 X96.736 Y112.043 E.0127
G1 X103.263 Y105.516 E.22452
G1 X103.263 Y106.037 E.01267
G1 X96.736 Y112.565 E.22454
G1 X96.736 Y113.086 E.01267
G1 X103.263 Y106.559 E.22452
G1 X103.263 Y107.081 E.0127
G1 X96.736 Y113.608 E.22452
G1 X96.736 Y114.13 E.0127
G1 X103.263 Y107.602 E.22454
G1 X103.263 Y108.124 E.0127
G1 X96.736 Y114.651 E.22452
G1 X96.736 Y115.173 E.0127
G1 X103.263 Y108.646 E.22452
G1 X103.263 Y109.167 E.01267
G1 X96.736 Y115.695 E.22454
G1 X96.736 Y116.216 E.01267
G1 X103.263 Y109.689 E.22452
G1 X103.263 Y110.211 E.0127
G1 X96.736 Y116.738 E.22452
G1 X96.736 Y117.26 E.0127
G1 X103.263 Y110.733 E.22452
G1 X103.263 Y111.254 E.01267
G1 X96.736 Y117.781 E.22452
G1 X96.736 Y118.303 E.0127
G1 X103.263 Y111.776 E.22452
G1 X103.263 Y112.298 E.0127
G1 X96.736 Y118.825 E.22452
G1 X96.736 Y119.347 E.0127
G1 X103.263 Y112.819 E.22454
G1 X103.263 Y113.341 E.0127
G1 X96.736 Y119.868 E.22452
G1 X96.736 Y120.39 E.0127
G1 X103.263 Y113.863 E.22452
G1 X103.263 Y114.384 E.01267
G1 X96.736 Y120.912 E.22454
G1 X96.736 Y121.433 E.01267
G1 X103.263 Y114.906 E.22452
G1 X103.263 Y115.428 E.0127
G1 X96.736 Y121.955 E.22452
G1 X96.736 Y122.477 E.0127
G1 X103.263 Y115.949 E.22454
G1 X103.263 Y116.471 E.0127
G1 X96.736 Y122.998 E.22452
G1 X96.736 Y123.52 E.0127
G1 X103.263 Y116.993 E.22452
G1 X103.263 Y117.515 E.0127
G1 X96.736 Y124.042 E.22452
G1 X96.736 Y124.563 E.01267
G1 X103.263 Y118.036 E.22452
G1 X103.263 Y118.558 E.0127
G1 X96.736 Y125.085 E.22452
G1 X96.736 Y125.607 E.0127
G1 X103.263 Y119.08 E.22452
G1 X103.263 Y119.601 E.01267
G1 X96.736 Y126.129 E.22454
G1 X96.736 Y126.65 E.01267
G1 X103.263 Y120.123 E.22452
G1 X103.263 Y120.645 E.0127
G1 X96.736 Y127.172 E.22452
G1 X96.736 Y127.457 E.00693
G1 X96.758 Y127.672 E.00526
G1 X103.263 Y121.166 E.22379
G1 X103.263 Y121.688 E.0127
G1 X96.758 Y128.194 E.22379
G1 X96.758 Y128.715 E.01267
G1 X103.263 Y122.21 E.22377
G1 X103.263 Y122.731 E.01267
G1 X96.758 Y129.237 E.22379
G1 X96.758 Y129.759 E.0127
G1 X103.263 Y123.253 E.22379
G1 X103.263 Y123.775 E.0127
G1 X96.758 Y130.28 E.22377
G1 X96.758 Y130.802 E.0127
G1 X103.263 Y124.297 E.22377
G1 X103.263 Y124.818 E.01267
G1 X96.758 Y131.324 E.22379
G1 X96.758 Y131.845 E.01267
G1 X103.263 Y125.34 E.22377
G1 X103.263 Y125.862 E.0127
G1 X96.758 Y132.367 E.22377
G1 X96.758 Y132.873 E.01231
G1 X103.263 Y126.383 E.22351
G1 X103.263 Y126.905 E.0127
G1 X96.815 Y133.353 E.22181
G1 X96.89 Y133.8 E.01102
G1 X103.263 Y127.427 E.21923
G1 X103.263 Y127.948 E.01267
G1 X96.99 Y134.222 E.2158
G1 X97.089 Y134.644 E.01054
G1 X103.263 Y128.47 E.21238
G1 X103.263 Y128.992 E.0127
G1 X97.234 Y135.021 E.20739
G1 X97.379 Y135.398 E.00983
G1 X103.263 Y129.514 E.20241
G1 X103.263 Y130.035 E.01267
G1 X97.525 Y135.773 E.19738
G1 X97.701 Y136.119 E.00944
G1 X103.263 Y130.557 E.19133
G1 X103.263 Y131.079 E.0127
G1 X97.902 Y136.44 E.18442
G1 X98.104 Y136.76 E.0092
G1 X103.263 Y131.6 E.17748
G1 X103.263 Y132.122 E.0127
G1 X98.312 Y137.074 E.17033
G1 X98.55 Y137.357 E.00899
G1 X103.263 Y132.644 E.16212
G1 X103.263 Y133.165 E.01267
G1 X98.788 Y137.641 E.15395
G1 X99.025 Y137.925 E.009
G1 X103.263 Y133.687 E.14578
G1 X103.263 Y134.209 E.0127
G1 X99.29 Y138.182 E.13667
G1 X99.575 Y138.418 E.009
G1 X103.263 Y134.73 E.12686
G1 X103.263 Y135.252 E.0127
G1 X99.864 Y138.651 E.11692
G1 X100.153 Y138.884 E.00903
G1 X102.872 Y136.165 E.09353
G1 X102.563 Y136.996 E.02157
G1 X100.478 Y139.081 E.07172
G1 X100.803 Y139.277 E.00923
G1 X102.511 Y137.569 E.05875
G1 X102.582 Y138.02 E.01111
G1 X101.129 Y139.473 E.04998
G1 X101.48 Y139.644 E.0095
G1 X102.687 Y138.436 E.04154
G1 X102.85 Y138.795 E.00959
G1 X101.85 Y139.795 E.0344
G1 X102.229 Y139.938 E.00985
G1 X103.048 Y139.119 E.02817
G1 X103.271 Y139.418 E.00907
G1 X102.633 Y140.056 E.02195
G1 X103.045 Y140.166 E.01037
G1 X103.349 Y139.861 E.01047
G1 X103.519 Y140.213 E.00951
G1 X103.339 Y140.393 E.00619
G1 E-5 F3600
G1 X103.339 Y140.393 F9000
G1 X96.662 Y95.155
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.407356
G1 F1200
G1 X103.259 Y95.156 E.16369
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X100.101 Y95.156 E-1.5
;WIPE_END
G1 X104.336 Y99.901 F9000
G1 X105.645 Y101.368
G1 X112.178 Y108.593
G1 X112.365 Y108.898
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X112.559 Y108.772 E.00563
G1 X112.927 Y108.608 E.0098
G1 X113.488 Y108.48 E.014
G1 X117.376 Y108.468 E.09457
G1 X117.974 Y108.575 E.01478
G1 X118.392 Y108.745 E.01098
G1 X118.743 Y108.963 E.01005
G1 X119.059 Y109.241 E.01024
G1 X119.43 Y109.73 E.01493
G1 X121.162 Y112.732 E.0843
G1 X121.337 Y113.103 E.00998
G1 X121.451 Y113.501 E.01007
G1 X121.499 Y113.911 E.01004
G1 X121.48 Y114.324 E.01006
G1 X121.391 Y114.734 E.01021
G1 X121.172 Y115.249 E.01361
G1 X119.43 Y118.269 E.0848
G1 X119.059 Y118.758 E.01493
G1 X118.578 Y119.149 E.01508
G1 X118.017 Y119.411 E.01506
G1 X117.376 Y119.532 E.01587
G1 X113.768 Y119.538 E.08776
G1 X113.126 Y119.453 E.01575
G1 X112.695 Y119.297 E.01115
G1 X112.205 Y118.996 E.01399
G1 X111.873 Y118.685 E.01107
G1 X111.57 Y118.27 E.0125
G1 X109.838 Y115.269 E.08428
G1 X109.582 Y114.639 E.01654
G1 X109.507 Y114.192 E.01102
G1 X109.509 Y113.778 E.01007
G1 X109.582 Y113.361 E.0103
G1 X109.826 Y112.755 E.01589
G1 X111.57 Y109.73 E.08493
G1 X111.873 Y109.315 E.0125
G1 X112.198 Y109.008 E.01087
G1 X112.315 Y108.931 E.00341
G1 X112.315 Y108.931 F9000
G1 X112.1 Y108.637
;TYPE:Perimeter
G1 F6000
G1 X112.407 Y108.439 E.00889
G1 X112.846 Y108.251 E.01162
G1 X113.407 Y108.123 E.014
G1 X113.775 Y108.108 E.00896
G1 X117.377 Y108.102 E.08762
G1 X118.041 Y108.216 E.01639
G1 X118.566 Y108.423 E.01373
G1 X118.983 Y108.687 E.012
G1 X119.349 Y109.02 E.01204
G1 X119.746 Y109.547 E.01605
G1 X121.479 Y112.549 E.08431
G1 X121.688 Y113 E.01209
G1 X121.814 Y113.456 E.01151
G1 X121.864 Y113.926 E.0115
G1 X121.838 Y114.399 E.01152
G1 X121.728 Y114.878 E.01195
G1 X121.509 Y115.392 E.01359
G1 X119.747 Y118.452 E.08589
G1 X119.35 Y118.98 E.01607
G1 X118.806 Y119.435 E.01725
G1 X118.169 Y119.744 E.01722
G1 X117.377 Y119.898 E.01963
G1 X113.768 Y119.904 E.08779
G1 X113.077 Y119.815 E.01695
G1 X112.519 Y119.618 E.01439
G1 X112.013 Y119.308 E.01443
G1 X111.625 Y118.957 E.01273
G1 X111.254 Y118.453 E.01522
G1 X109.521 Y115.451 E.08431
G1 X109.243 Y114.775 E.01778
G1 X109.141 Y114.192 E.0144
G1 X109.148 Y113.719 E.01151
G1 X109.243 Y113.225 E.01224
G1 X109.487 Y112.618 E.01591
G1 X111.254 Y109.547 E.08618
G1 X111.578 Y109.099 E.01345
G1 X111.973 Y108.72 E.01332
G1 X112.049 Y108.67 E.00221
G1 X112.049 Y108.67 F9000
G1 X111.836 Y108.379
G1 F6000
G1 X112.109 Y108.187 E.00812
G1 X112.56 Y107.968 E.0122
G1 X113.102 Y107.818 E.01368
G1 X113.548 Y107.744 E.011
G1 X117.378 Y107.736 E.09316
G1 X118.108 Y107.856 E.01799
G1 X118.642 Y108.054 E.01385
G1 X119.102 Y108.322 E.01295
G1 X119.512 Y108.661 E.01294
G1 X119.998 Y109.267 E.0189
G1 X121.796 Y112.366 E.08715
G1 X122.038 Y112.897 E.01419
G1 X122.177 Y113.411 E.01295
G1 X122.23 Y113.941 E.01296
G1 X122.201 Y114.445 E.01228
G1 X122.064 Y115.021 E.0144
G1 X121.845 Y115.535 E.01359
G1 X120.063 Y118.635 E.08697
G1 X119.641 Y119.202 E.01719
G1 X119.034 Y119.72 E.01941
G1 X118.321 Y120.076 E.01938
G1 X117.543 Y120.248 E.01938
G1 X117.378 Y120.264 E.00403
G1 X113.769 Y120.269 E.08779
G1 X113.256 Y120.208 E.01257
G1 X112.84 Y120.132 E.01029
G1 X112.337 Y119.935 E.01314
G1 X111.822 Y119.619 E.0147
G1 X111.394 Y119.243 E.01386
G1 X110.991 Y118.718 E.0161
G1 X109.204 Y115.634 E.0867
G1 X108.904 Y114.912 E.01902
G1 X108.788 Y114.34 E.0142
G1 X108.776 Y114.192 E.00361
G1 X108.788 Y113.66 E.01294
G1 X108.904 Y113.088 E.0142
G1 X109.148 Y112.482 E.01589
G1 X110.937 Y109.365 E.08742
G1 X111.283 Y108.883 E.01443
G1 X111.674 Y108.494 E.01342
G1 X111.787 Y108.414 E.00337
G1 X111.787 Y108.414 F9000
G1 X111.573 Y108.121
G1 F6000
G1 X111.905 Y107.883 E.00994
G1 X112.408 Y107.635 E.01364
G1 X113.021 Y107.461 E.0155
G1 X113.523 Y107.378 E.01238
G1 X117.379 Y107.371 E.09379
G1 X118.174 Y107.497 E.01958
G1 X118.78 Y107.715 E.01567
G1 X119.293 Y108.011 E.01441
G1 X119.751 Y108.385 E.01438
G1 X120.289 Y109.045 E.02071
G1 X122.113 Y112.183 E.08829
G1 X122.389 Y112.794 E.01631
G1 X122.54 Y113.367 E.01441
G1 X122.596 Y113.904 E.01313
G1 X122.561 Y114.509 E.01474
G1 X122.401 Y115.164 E.0164
G1 X122.182 Y115.678 E.01359
G1 X120.38 Y118.818 E.08806
G1 X119.931 Y119.423 E.01833
G1 X119.509 Y119.81 E.01393
G1 X119.038 Y120.15 E.01413
G1 X118.473 Y120.409 E.01512
G1 X118.175 Y120.503 E.0076
G1 X117.609 Y120.608 E.014
G1 X117.378 Y120.629 E.00564
G1 X113.769 Y120.635 E.08779
G1 X113.206 Y120.571 E.01378
G1 X112.716 Y120.475 E.01215
G1 X112.156 Y120.253 E.01465
G1 X111.631 Y119.931 E.01498
G1 X111.144 Y119.51 E.01566
G1 X110.696 Y118.934 E.01775
G1 X108.888 Y115.817 E.08765
G1 X108.565 Y115.048 E.02029
G1 X108.427 Y114.4 E.01612
G1 X108.41 Y114.192 E.00508
G1 X108.427 Y113.6 E.01441
G1 X108.565 Y112.952 E.01612
G1 X108.808 Y112.345 E.0159
G1 X110.62 Y109.182 E.08867
G1 X110.988 Y108.667 E.0154
G1 X111.423 Y108.227 E.01505
G1 X111.524 Y108.156 E.003
G1 E-5 F3600
G1 X111.524 Y108.156 F9000
G1 X108.217 Y101.146
G1 E5 F2400
G1 F6000
G1 X108.066 Y100.459 E.01711
G1 X108.044 Y99.808 E.01584
G1 X108.128 Y99.162 E.01585
G1 X108.225 Y98.816 E.00874
G1 X108.571 Y98 E.02156
G1 X110.304 Y94.999 E.08429
G1 X110.692 Y94.451 E.01633
G1 X111.173 Y93.961 E.0167
G1 X111.929 Y93.457 E.0221
G1 X112.592 Y93.181 E.01747
G1 X113.228 Y93.04 E.01585
G1 X113.521 Y93.013 E.00716
G1 X117.38 Y93.005 E.09387
G1 X117.99 Y93.076 E.01494
G1 X118.855 Y93.353 E.02209
G1 X119.214 Y93.534 E.00978
G1 X119.691 Y93.855 E.01399
G1 X120.218 Y94.343 E.01747
G1 X120.618 Y94.877 E.01623
G1 X122.429 Y98 E.08781
G1 X122.649 Y98.451 E.01221
G1 X122.848 Y99.06 E.01558
G1 X122.949 Y99.703 E.01583
G1 X122.945 Y100.355 E.01586
G1 X122.834 Y100.996 E.01582
G1 X122.524 Y101.809 E.02116
G1 X120.697 Y105.001 E.08946
G1 X120.222 Y105.645 E.01946
G1 X119.939 Y105.934 E.00984
G1 X119.49 Y106.293 E.01398
G1 X119.147 Y106.503 E.00978
G1 X118.624 Y106.742 E.01399
G1 X118.241 Y106.863 E.00977
;WIDTH:0.402393
G1 X117.676 Y106.969 E.01407
;WIDTH:0.409774
G1 X117.38 Y107 E.00743
G1 X118.241 Y107.137 E.02177
;WIDTH:0.399999
G1 X118.918 Y107.377 E.01747
G1 X119.485 Y107.699 E.01586
G1 X119.896 Y108.027 E.01279
G1 X120.222 Y108.354 E.01123
G1 X120.58 Y108.824 E.01437
G1 X120.696 Y108.999 E.00511
G1 X122.429 Y112 E.08429
G1 X122.649 Y112.451 E.01221
G1 X122.848 Y113.059 E.01556
G1 X122.949 Y113.703 E.01586
G1 X122.945 Y114.355 E.01586
G1 X122.834 Y114.996 E.01582
G1 X122.518 Y115.821 E.02149
G1 X120.697 Y119.001 E.08913
G1 X120.222 Y119.645 E.01946
G1 X119.94 Y119.934 E.00982
G1 X119.49 Y120.292 E.01399
G1 X119.148 Y120.502 E.00976
G1 X118.625 Y120.741 E.01399
G1 X118.241 Y120.863 E.0098
;WIDTH:0.413322
G1 X117.677 Y120.974 E.01449
;WIDTH:0.422368
G1 X117.52 Y121 E.00411
G1 X118.241 Y121.137 E.01894
;WIDTH:0.399999
G1 X118.918 Y121.377 E.01747
G1 X119.485 Y121.699 E.01586
G1 X119.897 Y122.028 E.01282
G1 X120.222 Y122.354 E.0112
G1 X120.696 Y122.999 E.01947
G1 X122.429 Y126 E.08429
G1 X122.649 Y126.451 E.01221
G1 X122.848 Y127.059 E.01556
G1 X122.949 Y127.703 E.01586
G1 X122.945 Y128.355 E.01586
G1 X122.834 Y128.996 E.01582
G1 X122.518 Y129.821 E.02149
G1 X122.429 Y130 E.00486
G1 X120.697 Y133.001 E.08428
G1 X120.222 Y133.645 E.01946
G1 X119.94 Y133.934 E.00982
G1 X119.49 Y134.292 E.01399
G1 X119.147 Y134.503 E.0098
G1 X118.625 Y134.742 E.01396
G1 X118.242 Y134.863 E.00977
G1 X117.677 Y134.967 E.01397
G1 X117.379 Y134.995 E.00728
G1 X113.767 Y135.001 E.08786
G1 X112.93 Y134.902 E.0205
G1 X112.196 Y134.673 E.0187
G1 X111.648 Y134.388 E.01502
G1 X110.943 Y133.821 E.02201
G1 X110.692 Y133.549 E.009
G1 X110.304 Y133.001 E.01633
G1 X108.571 Y130 E.08429
G1 X108.225 Y129.184 E.02156
G1 X108.066 Y128.459 E.01805
G1 X108.044 Y127.808 E.01584
G1 X108.128 Y127.162 E.01585
G1 X108.225 Y126.816 E.00874
G1 X108.469 Y126.209 E.01591
G1 X108.571 Y126 E.00566
G1 X110.304 Y122.999 E.08429
G1 X110.692 Y122.451 E.01633
G1 X111.173 Y121.961 E.0167
G1 X111.701 Y121.58 E.01584
G1 X112.256 Y121.302 E.0151
G1 X112.939 Y121.105 E.01729
;WIDTH:0.439126
G1 X113.464 Y120.994 E.01445
G1 X112.93 Y120.902 E.01459
;WIDTH:0.399999
G1 X112.26 Y120.7 E.01702
G1 X111.677 Y120.389 E.01607
G1 X111.173 Y120.039 E.01493
G1 X110.782 Y119.66 E.01325
G1 X110.401 Y119.15 E.01548
G1 X108.571 Y116 E.08861
G1 X108.225 Y115.184 E.02156
G1 X108.066 Y114.459 E.01805
G1 X108.044 Y114.192 E.00652
G1 X108.066 Y113.541 E.01584
G1 X108.225 Y112.816 E.01805
G1 X108.469 Y112.209 E.01591
G1 X108.571 Y112 E.00566
G1 X110.304 Y108.999 E.08429
G1 X110.692 Y108.451 E.01633
G1 X111.173 Y107.961 E.0167
G1 X111.701 Y107.58 E.01584
G1 X112.256 Y107.302 E.0151
G1 X112.939 Y107.105 E.01729
;WIDTH:0.439124
G1 X113.464 Y106.994 E.01445
G1 X112.93 Y106.902 E.01459
;WIDTH:0.399999
G1 X112.26 Y106.699 E.01703
G1 X111.653 Y106.39 E.01657
G1 X111.132 Y105.985 E.01605
G1 X110.692 Y105.549 E.01507
G1 X110.304 Y105.001 E.01633
G1 X108.571 Y102 E.08429
G1 X108.233 Y101.203 E.02106
G1 E-5 F3600
G1 X108.233 Y101.203 F9000
G1 X109.16 Y114.235
G1 X109.188 Y114.469
G1 X109.236 Y114.699
G1 X109.302 Y114.925
G1 X109.387 Y115.145
G1 X109.49 Y115.36
G1 X109.529 Y115.432
G1 X111.274 Y118.454
G1 X111.339 Y118.558
G1 X111.475 Y118.753
G1 X111.626 Y118.934
G1 X111.791 Y119.102
G1 X111.969 Y119.256
G1 X112.159 Y119.395
G1 X112.359 Y119.519
G1 X112.569 Y119.625
G1 X112.787 Y119.714
G1 X113.012 Y119.785
G1 X117.52 Y121
G1 E5 F2400
;WIDTH:0.422368
G1 F6000
G1 X117.38 Y121 E.00361
;WIDTH:0.40977
G1 X115.949 Y120.999 E.03574
;WIDTH:0.410754
G1 X113.77 Y121.006 E.05456
;WIDTH:0.439126
G1 X113.464 Y120.994 E.00825
G1 E-5 F3600
G1 X113.464 Y120.994 F9000
G1 X109.49 Y115.36
G1 X109.16 Y114.235
G1 X109.15 Y114
G1 X109.16 Y113.765
G1 X109.188 Y113.531
G1 X109.236 Y113.301
G1 X109.302 Y113.075
G1 X109.387 Y112.855
G1 X109.49 Y112.64
G1 X109.529 Y112.568
G1 X111.274 Y109.546
G1 X111.339 Y109.442
G1 X111.475 Y109.247
G1 X111.626 Y109.066
G1 X111.791 Y108.898
G1 X111.969 Y108.744
G1 X112.159 Y108.605
G1 X112.359 Y108.481
G1 X112.569 Y108.375
G1 X112.787 Y108.286
G1 X113.012 Y108.215
G1 X117.38 Y107
G1 E5 F2400
;WIDTH:0.409774
G1 F6000
G1 X115.937 Y106.999 E.03604
;WIDTH:0.410752
G1 X113.77 Y107.006 E.05426
;WIDTH:0.439124
G1 X113.464 Y106.994 E.00825
G1 X113.464 Y106.994 F9000
G1 X113.547 Y105.507
;WIDTH:0.399999
G1 F6000
G1 X113.089 Y105.444 E.01125
G1 X112.685 Y105.292 E.0105
G1 X112.336 Y105.092 E.00978
G1 X111.901 Y104.716 E.01399
G1 X111.57 Y104.27 E.01351
G1 X109.838 Y101.269 E.08428
G1 X109.582 Y100.639 E.01654
G1 X109.507 Y100.192 E.01102
G1 X109.527 Y99.669 E.01273
G1 X109.582 Y99.361 E.00761
G1 X109.838 Y98.731 E.01654
G1 X111.57 Y95.73 E.08428
G1 X111.873 Y95.315 E.0125
G1 X112.204 Y95.004 E.01105
G1 X112.694 Y94.703 E.01399
G1 X113.118 Y94.548 E.01098
G1 X113.528 Y94.475 E.01013
G1 X117.377 Y94.468 E.09362
G1 X117.818 Y94.533 E.01084
G1 X118.358 Y94.728 E.01397
G1 X118.876 Y95.069 E.01508
G1 X119.192 Y95.39 E.01096
G1 X119.43 Y95.73 E.0101
G1 X121.162 Y98.732 E.0843
G1 X121.365 Y99.2 E.01241
G1 X121.451 Y99.503 E.00766
G1 X121.498 Y99.922 E.01026
G1 X121.48 Y100.324 E.00979
G1 X121.391 Y100.734 E.01021
G1 X121.172 Y101.249 E.01361
G1 X119.43 Y104.269 E.0848
G1 X119.059 Y104.758 E.01493
G1 X118.578 Y105.149 E.01508
G1 X118.017 Y105.411 E.01506
G1 X117.376 Y105.532 E.01587
G1 X113.768 Y105.538 E.08776
G1 X113.607 Y105.516 E.00395
G1 X113.607 Y105.516 F9000
G1 X113.587 Y105.878
;TYPE:Perimeter
G1 F6000
G1 X112.965 Y105.788 E.01529
G1 X112.507 Y105.611 E.01194
G1 X112.096 Y105.369 E.0116
G1 X111.661 Y104.992 E.014
G1 X111.254 Y104.453 E.01643
G1 X109.521 Y101.451 E.08431
G1 X109.243 Y100.775 E.01778
G1 X109.148 Y100.281 E.01224
G1 X109.148 Y99.719 E.01367
G1 X109.243 Y99.225 E.01224
G1 X109.487 Y98.618 E.01591
G1 X111.254 Y95.547 E.08618
G1 X111.578 Y95.099 E.01345
G1 X112.013 Y94.692 E.01449
G1 X112.503 Y94.391 E.01399
G1 X113.051 Y94.189 E.01421
G1 X113.526 Y94.11 E.01171
G1 X115.946 Y94.098 E.05886
G1 X117.378 Y94.102 E.03483
G1 X117.942 Y94.189 E.01388
G1 X118.483 Y94.384 E.01399
G1 X119.08 Y94.766 E.01724
G1 X119.441 Y95.119 E.01228
G1 X119.746 Y95.547 E.01278
G1 X121.479 Y98.549 E.08431
G1 X121.716 Y99.097 E.01452
G1 X121.814 Y99.459 E.00912
G1 X121.864 Y99.937 E.01169
G1 X121.838 Y100.399 E.01126
G1 X121.728 Y100.878 E.01195
G1 X121.509 Y101.392 E.01359
G1 X119.747 Y104.452 E.08589
G1 X119.35 Y104.98 E.01607
G1 X118.806 Y105.435 E.01725
G1 X118.169 Y105.744 E.01722
G1 X117.377 Y105.898 E.01963
G1 X113.768 Y105.904 E.08779
G1 X113.646 Y105.886 E.003
G1 X113.625 Y106.252 F9000
G1 F6000
G1 X113.256 Y106.208 E.00904
G1 X112.84 Y106.132 E.01029
G1 X112.344 Y105.939 E.01295
G1 X111.891 Y105.673 E.01278
G1 X111.422 Y105.268 E.01507
G1 X110.937 Y104.636 E.01938
G1 X109.204 Y101.634 E.08431
G1 X108.904 Y100.912 E.01902
G1 X108.788 Y100.34 E.0142
G1 X108.776 Y99.808 E.01294
G1 X108.85 Y99.281 E.01294
G1 X109.148 Y98.482 E.02074
G1 X110.937 Y95.364 E.08744
G1 X111.283 Y94.883 E.01441
G1 X111.674 Y94.494 E.01342
G1 X112.311 Y94.08 E.01848
G1 X112.84 Y93.868 E.01386
G1 X113.361 Y93.759 E.01295
G1 X113.524 Y93.744 E.00398
G1 X117.379 Y93.736 E.09377
G1 X117.886 Y93.8 E.01243
G1 X118.607 Y94.04 E.01848
G1 X119.283 Y94.462 E.01938
G1 X119.695 Y94.855 E.01385
G1 X120.02 Y95.297 E.01334
G1 X121.796 Y98.366 E.08625
G1 X122.038 Y98.897 E.01419
G1 X122.177 Y99.411 E.01295
G1 X122.23 Y99.941 E.01296
G1 X122.201 Y100.445 E.01228
G1 X122.064 Y101.021 E.0144
G1 X121.845 Y101.535 E.01359
G1 X120.063 Y104.635 E.08697
G1 X119.64 Y105.202 E.01721
G1 X119.034 Y105.721 E.01941
G1 X118.32 Y106.076 E.0194
G1 X117.543 Y106.248 E.01936
G1 X117.377 Y106.264 E.00406
G1 X113.769 Y106.269 E.08776
G1 X113.685 Y106.259 E.00206
G1 X113.685 Y106.259 F9000
G1 X113.664 Y106.623
G1 F6000
G1 X113.206 Y106.571 E.01121
G1 X112.716 Y106.475 E.01215
G1 X112.165 Y106.258 E.0144
G1 X111.665 Y105.961 E.01415
G1 X111.183 Y105.545 E.01549
G1 X110.62 Y104.818 E.02237
G1 X108.888 Y101.817 E.08428
G1 X108.565 Y101.048 E.02029
G1 X108.427 Y100.4 E.01612
G1 X108.41 Y99.808 E.01441
G1 X108.489 Y99.222 E.01438
G1 X108.808 Y98.345 E.0227
G1 X110.62 Y95.182 E.08867
G1 X110.988 Y94.667 E.0154
G1 X111.423 Y94.228 E.01503
G1 X112.12 Y93.768 E.02031
G1 X112.716 Y93.525 E.01566
G1 X113.295 Y93.4 E.01441
G1 X113.522 Y93.378 E.00555
G1 X117.38 Y93.371 E.09384
G1 X117.938 Y93.438 E.01367
G1 X118.731 Y93.697 E.02029
G1 X119.487 Y94.159 E.02155
G1 X119.956 Y94.599 E.01564
G1 X120.319 Y95.087 E.01479
G1 X122.113 Y98.183 E.08704
G1 X122.389 Y98.794 E.01631
G1 X122.54 Y99.367 E.01441
G1 X122.595 Y99.956 E.01439
G1 X122.561 Y100.509 E.01348
G1 X122.401 Y101.164 E.0164
G1 X122.182 Y101.678 E.01359
G1 X120.38 Y104.818 E.08806
G1 X119.931 Y105.424 E.01835
G1 X119.509 Y105.809 E.01389
G1 X119.038 Y106.15 E.01414
G1 X118.472 Y106.409 E.01514
G1 X118.174 Y106.503 E.0076
G1 X117.609 Y106.608 E.01398
G1 X117.378 Y106.629 E.00564
G1 X113.769 Y106.635 E.08779
G1 X113.724 Y106.63 E.0011
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.664 Y106.623 E-.02869
G1 X113.206 Y106.571 E-.21895
G1 X112.716 Y106.475 E-.23717
G1 X112.165 Y106.258 E-.28129
G1 X111.665 Y105.961 E-.27624
G1 X111.183 Y105.545 E-.30243
G1 X110.983 Y105.287 E-.15523
;WIPE_END
G1 X111.537 Y104.827 F9000
G1 X109.16 Y113.765
G1 X109.15 Y114
G1 X109.16 Y114.235
G1 X109.49 Y115.36
G1 X113.241 Y119.837
G1 X113.342 Y119.852
G1 X113.769 Y122.113
G1 X113.768 Y122.479
G1 E5 F2400
G1 F6000
G1 X117.409 Y122.471 E.08856
G1 X117.975 Y122.576 E.014
G1 X118.392 Y122.745 E.01094
G1 X118.743 Y122.963 E.01005
G1 X119.059 Y123.241 E.01024
G1 X119.43 Y123.73 E.01493
G1 X121.162 Y126.732 E.0843
G1 X121.337 Y127.103 E.00998
G1 X121.451 Y127.501 E.01007
G1 X121.499 Y127.911 E.01004
G1 X121.48 Y128.324 E.01006
G1 X121.391 Y128.734 E.01021
G1 X121.172 Y129.249 E.01361
G1 X119.43 Y132.269 E.0848
G1 X119.059 Y132.758 E.01493
G1 X118.578 Y133.149 E.01508
G1 X118.017 Y133.411 E.01506
G1 X117.376 Y133.532 E.01587
G1 X113.767 Y133.538 E.08779
G1 X113.126 Y133.453 E.01573
G1 X112.677 Y133.289 E.01163
G1 X112.336 Y133.092 E.00958
G1 X111.901 Y132.716 E.01399
G1 X111.581 Y132.286 E.01304
G1 X109.838 Y129.269 E.08475
G1 X109.582 Y128.639 E.01654
G1 X109.507 Y128.192 E.01102
G1 X109.509 Y127.778 E.01007
G1 X109.582 Y127.361 E.0103
G1 X109.826 Y126.755 E.01589
G1 X111.57 Y123.73 E.08493
G1 X111.873 Y123.315 E.0125
G1 X112.285 Y122.949 E.0134
G1 X112.543 Y122.779 E.00752
G1 X112.927 Y122.608 E.01022
G1 X113.488 Y122.48 E.014
G1 X113.708 Y122.479 E.00535
G1 X113.708 Y122.479 F9000
G1 X113.685 Y122.121
;TYPE:Perimeter
G1 F6000
G1 X115.946 Y122.098 E.055
G1 X117.476 Y122.111 E.03722
G1 X118.041 Y122.216 E.01398
G1 X118.566 Y122.423 E.01373
G1 X118.983 Y122.687 E.012
G1 X119.349 Y123.02 E.01204
G1 X119.746 Y123.547 E.01605
G1 X121.479 Y126.549 E.08431
G1 X121.688 Y127 E.01209
G1 X121.814 Y127.456 E.01151
G1 X121.864 Y127.926 E.0115
G1 X121.838 Y128.399 E.01152
G1 X121.728 Y128.878 E.01195
G1 X121.479 Y129.451 E.0152
G1 X119.747 Y132.452 E.08428
G1 X119.35 Y132.98 E.01607
G1 X118.806 Y133.435 E.01725
G1 X118.169 Y133.744 E.01722
G1 X117.377 Y133.898 E.01963
G1 X113.767 Y133.904 E.08781
G1 X113.077 Y133.815 E.01692
G1 X112.577 Y133.644 E.01285
G1 X112.096 Y133.369 E.01348
G1 X111.661 Y132.992 E.014
G1 X111.286 Y132.502 E.01501
G1 X109.521 Y129.451 E.08574
G1 X109.243 Y128.775 E.01778
G1 X109.148 Y128.281 E.01224
G1 X109.148 Y127.719 E.01367
G1 X109.243 Y127.225 E.01224
G1 X109.487 Y126.618 E.01591
G1 X111.254 Y123.547 E.08618
G1 X111.578 Y123.099 E.01345
G1 X111.956 Y122.733 E.0128
G1 X112.375 Y122.454 E.01224
G1 X112.836 Y122.254 E.01222
G1 X113.407 Y122.123 E.01425
G1 X113.625 Y122.121 E.0053
G1 X113.625 Y122.121 F9000
G1 X113.602 Y121.744
G1 F6000
G1 X115.947 Y121.733 E.05704
G1 X117.378 Y121.736 E.03481
G1 X117.543 Y121.752 E.00403
G1 X118.108 Y121.857 E.01398
G1 X118.642 Y122.054 E.01384
G1 X119.102 Y122.322 E.01295
G1 X119.512 Y122.661 E.01294
G1 X120.063 Y123.365 E.02175
G1 X121.796 Y126.366 E.08429
G1 X122.038 Y126.897 E.01419
G1 X122.177 Y127.411 E.01295
G1 X122.23 Y127.941 E.01296
G1 X122.201 Y128.445 E.01228
G1 X122.064 Y129.021 E.0144
G1 X121.796 Y129.634 E.01627
G1 X120.063 Y132.635 E.08429
G1 X119.641 Y133.202 E.01719
G1 X119.034 Y133.721 E.01943
G1 X118.321 Y134.076 E.01937
G1 X117.543 Y134.248 E.01938
G1 X117.378 Y134.264 E.00403
G1 X113.767 Y134.269 E.08783
G1 X113.028 Y134.178 E.01811
G1 X112.45 Y133.987 E.01481
G1 X112.007 Y133.751 E.01221
G1 X111.422 Y133.268 E.01845
G1 X110.991 Y132.718 E.017
G1 X109.204 Y129.634 E.0867
G1 X108.904 Y128.912 E.01902
G1 X108.788 Y128.34 E.0142
G1 X108.776 Y127.808 E.01294
G1 X108.85 Y127.281 E.01294
G1 X109.148 Y126.482 E.02074
G1 X110.937 Y123.365 E.08742
G1 X111.283 Y122.883 E.01443
G1 X111.674 Y122.494 E.01342
G1 X112.109 Y122.187 E.01295
G1 X112.56 Y121.967 E.01221
G1 X113.102 Y121.818 E.01367
G1 X113.542 Y121.745 E.01085
G1 X113.542 Y121.745 F9000
G1 X113.528 Y121.378
G1 F6000
G1 X117.379 Y121.371 E.09367
G1 X117.609 Y121.392 E.00562
G1 X118.175 Y121.497 E.014
G1 X118.78 Y121.715 E.01564
G1 X119.293 Y122.011 E.01441
G1 X119.751 Y122.385 E.01438
G1 X120.289 Y123.045 E.02071
G1 X120.38 Y123.182 E.004
G1 X122.113 Y126.183 E.08429
G1 X122.389 Y126.794 E.01631
G1 X122.54 Y127.367 E.01441
G1 X122.596 Y127.904 E.01313
G1 X122.561 Y128.509 E.01474
G1 X122.401 Y129.164 E.0164
G1 X122.113 Y129.817 E.01736
G1 X120.38 Y132.818 E.08429
G1 X119.931 Y133.423 E.01833
G1 X119.712 Y133.648 E.00764
G1 X119.262 Y134.006 E.01399
G1 X118.473 Y134.409 E.02155
G1 X117.61 Y134.608 E.02154
G1 X117.378 Y134.629 E.00567
G1 X113.767 Y134.635 E.08783
G1 X112.979 Y134.54 E.01931
G1 X112.323 Y134.33 E.01675
G1 X111.827 Y134.069 E.01363
G1 X111.183 Y133.545 E.02019
G1 X110.696 Y132.934 E.01901
G1 X108.888 Y129.817 E.08765
G1 X108.565 Y129.048 E.02029
G1 X108.427 Y128.4 E.01612
G1 X108.41 Y127.808 E.01441
G1 X108.489 Y127.222 E.01438
G1 X108.808 Y126.345 E.0227
G1 X110.62 Y123.182 E.08867
G1 X110.988 Y122.667 E.0154
G1 X111.423 Y122.227 E.01505
G1 X111.905 Y121.883 E.0144
G1 X112.408 Y121.635 E.01364
G1 X113.021 Y121.461 E.0155
G1 X113.469 Y121.387 E.01104
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.528 Y121.378 E-.02835
G1 X116.626 Y121.372 E-1.47165
;WIPE_END
G1 X113.012 Y122.215 F9000
G1 X112.787 Y122.286
G1 X112.569 Y122.375
G1 X112.359 Y122.481
G1 X112.159 Y122.605
G1 X111.969 Y122.744
G1 X111.791 Y122.898
G1 X111.626 Y123.066
G1 X111.475 Y123.247
G1 X111.339 Y123.442
G1 X111.274 Y123.546
G1 X109.529 Y126.568
G1 X109.49 Y126.64
G1 X109.387 Y126.855
G1 X109.302 Y127.075
G1 X109.236 Y127.301
G1 X109.188 Y127.531
G1 X109.16 Y127.765
G1 X109.15 Y128
G1 X109.16 Y128.235
G1 X109.188 Y128.469
G1 X109.236 Y128.699
G1 X109.302 Y128.925
G1 X109.387 Y129.145
G1 X109.49 Y129.36
G1 X109.529 Y129.432
G1 X110.058 Y130.344
G1 X106.099 Y136.265
G1 X105.725 Y136.265
G1 E5 F2400
G1 F6000
G1 X105.75 Y136.199 E.00172
G1 X105.75 Y103.607 E.79277
G1 X105.739 Y103.545 E.00153
G1 X105.567 Y103.424 E.00512
G1 X105.297 Y103.424 E.00657
G1 X105.297 Y98.824 E.11189
G1 X105.567 Y98.824 E.00657
G1 X105.714 Y98.751 E.00399
G1 X105.75 Y98.642 E.00279
G1 X105.75 Y91.802 E.16638
G1 X105.701 Y91.677 E.00327
G1 X105.181 Y91.119 E.01855
G1 X104.914 Y90.674 E.01262
G1 X104.913 Y90.336 E.00822
G1 X105.164 Y89.903 E.01217
G1 X105.588 Y89.441 E.01525
G1 X125.41 Y89.441 E.48215
G1 X125.854 Y89.948 E.01639
G1 X126.042 Y90.247 E.00859
G1 X126.099 Y90.466 E.0055
G1 X126.105 Y90.6 E.00326
G1 X125.93 Y90.97 E.00996
G1 X125.296 Y91.68 E.02315
G1 X125.25 Y91.801 E.00315
G1 X125.25 Y98.195 E.15553
G1 X125.27 Y98.725 E.0129
G1 X125.433 Y98.824 E.00464
G1 X125.703 Y98.824 E.00657
G1 X125.703 Y103.424 E.11189
G1 X125.433 Y103.424 E.00657
G1 X125.283 Y103.503 E.00412
G1 X125.25 Y103.607 E.00265
G1 X125.25 Y136.198 E.79274
G1 X125.299 Y136.323 E.00327
G1 X125.819 Y136.881 E.01855
G1 X126.086 Y137.326 E.01262
G1 X126.087 Y137.664 E.00822
G1 X125.837 Y138.097 E.01216
G1 X125.412 Y138.559 E.01527
G1 X105.59 Y138.559 E.48215
G1 X105.121 Y138.024 E.01731
G1 X104.906 Y137.649 E.01051
G1 X104.895 Y137.4 E.00606
G1 X105.07 Y137.03 E.00996
G1 X105.703 Y136.321 E.02312
G1 X105.703 Y136.321 F9000
G1 X106.065 Y136.409
;TYPE:Perimeter
G1 F6000
G1 X106.088 Y136.37 E.0011
G1 X106.116 Y136.199 E.00421
G1 X106.116 Y103.607 E.79277
G1 X106.1 Y103.479 E.00314
G1 X106.018 Y103.294 E.00492
G1 X105.662 Y103.108 E.00977
G1 X105.662 Y99.142 E.09647
G1 X106.007 Y98.969 E.00939
G1 X106.075 Y98.849 E.00335
G1 X106.116 Y98.642 E.00513
G1 X106.116 Y91.802 E.16638
G1 X106.087 Y91.626 E.00434
G1 X105.969 Y91.428 E.00561
G1 X105.546 Y90.973 E.01511
G1 X105.294 Y90.595 E.01105
G1 X105.262 Y90.472 E.00309
G1 X105.426 Y90.173 E.0083
G1 X105.749 Y89.807 E.01187
G1 X125.244 Y89.807 E.4742
G1 X125.603 Y90.217 E.01326
G1 X125.734 Y90.482 E.00719
G1 X125.622 Y90.766 E.00743
G1 X125.024 Y91.436 E.02184
G1 X124.912 Y91.63 E.00545
G1 X124.884 Y91.801 E.00421
G1 X124.889 Y98.714 E.16815
G1 X124.992 Y98.967 E.00664
G1 X125.338 Y99.142 E.00943
G1 X125.338 Y103.108 E.09647
G1 X124.982 Y103.294 E.00977
G1 X124.946 Y103.354 E.0017
G1 X124.884 Y103.607 E.00634
G1 X124.884 Y136.198 E.79274
G1 X124.913 Y136.374 E.00434
G1 X125.031 Y136.572 E.00561
G1 X125.454 Y137.027 E.01511
G1 X125.706 Y137.405 E.01105
G1 X125.738 Y137.528 E.00309
G1 X125.574 Y137.827 E.0083
G1 X125.251 Y138.193 E.01187
G1 X105.756 Y138.193 E.4742
G1 X105.396 Y137.783 E.01327
G1 X105.266 Y137.518 E.00718
G1 X105.378 Y137.234 E.00743
G1 X105.976 Y136.564 E.02184
G1 X106.035 Y136.461 E.00289
G1 X106.035 Y136.461 F9000
G1 X106.398 Y136.55
G1 F6000
G1 X106.436 Y136.484 E.00185
G1 X106.481 Y136.199 E.00702
G1 X106.481 Y103.607 E.79277
G1 X106.456 Y103.394 E.00522
G1 X106.318 Y103.086 E.00821
G1 X106.028 Y102.934 E.00796
G1 X106.028 Y99.324 E.08781
G1 X106.3 Y99.188 E.0074
G1 X106.413 Y98.988 E.00559
G1 X106.481 Y98.642 E.00858
G1 X106.481 Y91.802 E.16638
G1 X106.433 Y91.509 E.00722
G1 X106.236 Y91.179 E.00935
G1 X105.813 Y90.724 E.01511
G1 X105.658 Y90.492 E.00679
G1 X105.909 Y90.172 E.00989
G1 X125.078 Y90.172 E.46627
G1 X125.347 Y90.492 E.01017
G1 X125.314 Y90.562 E.00188
G1 X124.751 Y91.193 E.02057
G1 X124.564 Y91.516 E.00908
G1 X124.519 Y91.801 E.00702
G1 X124.519 Y98.541 E.16394
G1 X124.558 Y98.907 E.00895
G1 X124.697 Y99.184 E.00754
G1 X124.972 Y99.324 E.00751
G1 X124.972 Y102.934 E.08781
G1 X124.682 Y103.086 E.00796
G1 X124.574 Y103.294 E.0057
G1 X124.519 Y103.607 E.00773
G1 X124.519 Y136.198 E.79274
G1 X124.567 Y136.491 E.00722
G1 X124.764 Y136.821 E.00935
G1 X125.187 Y137.276 E.01511
G1 X125.342 Y137.508 E.00679
G1 X125.091 Y137.828 E.00989
G1 X105.922 Y137.828 E.46627
G1 X105.671 Y137.542 E.00926
G1 X105.686 Y137.438 E.00256
G1 X106.249 Y136.807 E.02057
G1 X106.368 Y136.602 E.00577
G1 X106.368 Y136.602 F9000
G1 X106.73 Y136.69
G1 F6000
G1 X106.783 Y136.598 E.00258
G1 X106.847 Y136.199 E.00983
G1 X106.847 Y103.607 E.79277
G1 X106.769 Y103.168 E.01085
G1 X106.619 Y102.877 E.00796
G1 X106.394 Y102.76 E.00617
G1 X106.394 Y99.507 E.07913
G1 X106.593 Y99.406 E.00543
G1 X106.775 Y99.065 E.0094
G1 X106.847 Y98.642 E.01044
G1 X106.847 Y91.802 E.16638
G1 X106.78 Y91.392 E.01011
G1 X106.504 Y90.93 E.01309
G1 X106.139 Y90.538 E.01303
G1 X124.845 Y90.538 E.455
G1 X124.478 Y90.949 E.0134
G1 X124.217 Y91.402 E.01272
G1 X124.153 Y91.801 E.00983
G1 X124.153 Y98.541 E.16394
G1 X124.208 Y99.014 E.01158
G1 X124.403 Y99.402 E.01056
G1 X124.606 Y99.507 E.00556
G1 X124.606 Y102.76 E.07913
G1 X124.381 Y102.877 E.00617
G1 X124.231 Y103.168 E.00796
G1 X124.153 Y103.607 E.01085
G1 X124.153 Y136.198 E.79274
G1 X124.22 Y136.608 E.01011
G1 X124.496 Y137.07 E.01309
G1 X124.861 Y137.462 E.01303
G1 X106.155 Y137.462 E.455
G1 X106.522 Y137.051 E.0134
G1 X106.7 Y136.742 E.00867
G1 X106.7 Y136.742 F9000
G1 X107.062 Y136.831
G1 F6000
G1 X107.13 Y136.712 E.00333
G1 X107.213 Y136.199 E.01264
G1 X107.213 Y103.607 E.79277
G1 X107.113 Y103.043 E.01393
G1 X106.919 Y102.669 E.01025
G1 X106.759 Y102.585 E.0044
G1 X106.759 Y99.689 E.07044
G1 X106.887 Y99.625 E.00348
G1 X107.09 Y99.265 E.01005
G1 X107.177 Y98.983 E.00718
G1 X107.213 Y98.642 E.00834
G1 X107.213 Y91.802 E.16638
G1 X107.126 Y91.275 E.01299
G1 X106.905 Y90.904 E.0105
G1 X124.091 Y90.904 E.41803
G1 X123.87 Y91.288 E.01078
G1 X123.787 Y91.801 E.01264
G1 X123.787 Y98.642 E.1664
G1 X123.859 Y99.122 E.01181
G1 X124.109 Y99.619 E.01353
G1 X124.241 Y99.689 E.00363
G1 X124.241 Y102.585 E.07044
G1 X124.081 Y102.669 E.0044
G1 X123.887 Y103.043 E.01025
G1 X123.787 Y103.607 E.01393
G1 X123.787 Y136.198 E.79274
G1 X123.874 Y136.725 E.01299
G1 X124.095 Y137.096 E.0105
G1 X106.909 Y137.096 E.41803
G1 X107.032 Y136.883 E.00598
G1 X107.032 Y136.883 F9000
G1 X107.392 Y136.829
;TYPE:Solid infill
;WIDTH:0.386478
G1 F1200
G1 X123.611 Y136.829 E.37992
G1 X123.611 Y136.829 F9000
G1 X123.023 Y136.635
;WIDTH:0.4
G1 F3072.127
G1 X123.513 Y136.145 E.01686
G1 X123.513 Y135.619 E.01279
G1 X122.662 Y136.47 E.02927
G1 X122.136 Y136.47 E.01279
G1 X123.513 Y135.093 E.04737
G1 X123.513 Y134.567 E.01279
G1 X121.61 Y136.47 E.06546
G1 X121.084 Y136.47 E.01279
G1 X123.513 Y134.041 E.08356
G1 X123.513 Y133.515 E.01279
G1 X120.558 Y136.47 E.10165
G1 X120.032 Y136.47 E.01279
G1 X123.513 Y132.988 E.11976
G1 X123.513 Y132.462 E.01279
G1 X119.505 Y136.47 E.13787
G1 X118.979 Y136.47 E.01279
G1 X123.513 Y131.936 E.15597
G1 X123.513 Y131.41 E.01279
G1 X118.453 Y136.47 E.17406
G1 X117.927 Y136.47 E.01279
G1 X119.203 Y135.194 E.04389
G1 X118.381 Y135.491 E.02126
G1 X117.401 Y136.47 E.03369
G1 X116.875 Y136.47 E.01279
G1 X117.741 Y135.605 E.02977
G1 X117.174 Y135.645 E.01383
G1 X116.349 Y136.47 E.02838
G1 X115.823 Y136.47 E.01279
G1 X116.648 Y135.645 E.02838
G1 X116.122 Y135.645 E.01279
G1 X115.297 Y136.47 E.02838
G1 X114.771 Y136.47 E.01279
G1 X115.596 Y135.645 E.02838
G1 X115.07 Y135.645 E.01279
G1 X114.245 Y136.47 E.02838
G1 X113.719 Y136.47 E.01279
G1 X114.544 Y135.645 E.02838
G1 X114.018 Y135.645 E.01279
G1 X113.193 Y136.47 E.02838
G1 X112.667 Y136.47 E.01279
G1 X113.509 Y135.628 E.02896
G1 X113.047 Y135.564 E.01135
G1 X112.141 Y136.47 E.03117
G1 X111.615 Y136.47 E.01279
G1 X112.603 Y135.482 E.03399
G1 X112.2 Y135.359 E.01025
G1 X111.089 Y136.47 E.03822
G1 X110.563 Y136.47 E.01279
G1 X111.826 Y135.207 E.04345
G1 X111.479 Y135.028 E.0095
G1 X110.037 Y136.47 E.0496
G1 X109.511 Y136.47 E.01279
G1 X111.16 Y134.821 E.05672
G1 X110.852 Y134.602 E.00919
G1 X108.985 Y136.47 E.06424
G1 X108.459 Y136.47 E.01279
G1 X110.572 Y134.356 E.0727
G1 X110.318 Y134.085 E.00903
G1 X107.933 Y136.47 E.08204
G1 X107.445 Y136.47 E.01187
G1 X110.074 Y133.803 E.09109
G1 X109.857 Y133.494 E.00918
G1 X107.487 Y135.864 E.08153
G1 X107.487 Y135.338 E.01279
G1 X109.663 Y133.161 E.07487
G1 X109.47 Y132.828 E.00936
G1 X107.487 Y134.812 E.06823
G1 X107.487 Y134.286 E.01279
G1 X109.277 Y132.496 E.06157
G1 X109.083 Y132.163 E.00937
G1 X107.487 Y133.759 E.0549
G1 X107.487 Y133.233 E.01279
G1 X108.89 Y131.83 E.04826
G1 X108.696 Y131.498 E.00935
G1 X107.487 Y132.707 E.04159
G1 X107.487 Y132.181 E.01279
G1 X108.503 Y131.165 E.03495
G1 X108.31 Y130.833 E.00934
G1 X107.487 Y131.655 E.02829
G1 X107.487 Y131.129 E.01279
G1 X108.116 Y130.5 E.02164
G1 X107.934 Y130.156 E.00947
G1 X107.487 Y130.603 E.01538
G1 X107.487 Y130.077 E.01279
G1 X107.764 Y129.8 E.00953
G1 X107.611 Y129.427 E.00981
G1 X107.322 Y129.716 E.00994
G1 E-5 F3600
G1 X107.322 Y129.716 F9000
G1 X109.588 Y123.297
G1 E5 F2400
G1 F3072.127
G1 X107.487 Y125.397 E.07226
G1 X107.487 Y125.916 E.01262
G1 X108.413 Y124.99 E.03185
G1 X107.803 Y126.119 E.03121
G1 X107.322 Y126.6 E.01655
G1 X107.322 Y126.6 F9000
G1 X107.322 Y125.043
G1 F3072.127
G1 X111.388 Y120.978 E.13985
G1 X111.083 Y120.763 E.00908
G1 X107.487 Y124.36 E.12372
G1 X107.487 Y123.841 E.01262
G1 X110.782 Y120.546 E.11335
G1 X110.509 Y120.3 E.00894
G1 X107.487 Y123.322 E.10395
G1 X107.487 Y122.803 E.01262
G1 X110.265 Y120.026 E.09554
G1 X110.03 Y119.742 E.00897
G1 X107.487 Y122.285 E.08748
G1 X107.487 Y121.766 E.01262
G1 X109.821 Y119.432 E.08029
G1 X109.63 Y119.104 E.00923
G1 X107.487 Y121.247 E.07372
G1 X107.487 Y120.728 E.01262
G1 X109.439 Y118.776 E.06715
G1 X109.249 Y118.448 E.00922
G1 X107.487 Y120.209 E.06059
G1 X107.487 Y119.691 E.0126
G1 X109.058 Y118.12 E.05404
G1 X108.867 Y117.791 E.00925
G1 X107.487 Y119.172 E.04749
G1 X107.487 Y118.653 E.01262
G1 X108.676 Y117.463 E.04092
G1 X108.486 Y117.135 E.00922
G1 X107.487 Y118.134 E.03437
G1 X107.487 Y117.615 E.01262
G1 X108.295 Y116.807 E.02779
G1 X108.104 Y116.479 E.00923
G1 X107.487 Y117.097 E.02124
G1 X107.487 Y116.578 E.01262
G1 X107.926 Y116.139 E.0151
G1 X107.758 Y115.787 E.00949
G1 X107.487 Y116.059 E.00934
G1 X107.487 Y115.54 E.01262
G1 X107.735 Y115.292 E.00853
G1 X107.735 Y115.292 F9000
G1 X107.781 Y114.814
;TYPE:Solid infill
;WIDTH:0.534686
G1 F1200
G1 X107.815 Y114.883 E.00256
;WIDTH:0.494595
G1 X107.848 Y114.951 E.00231
;WIDTH:0.454504
G1 X108.075 Y115.558 E.01811
;WIDTH:0.436574
G1 X108.336 Y116.146 E.01721
;WIDTH:0.403992
G1 X110.066 Y119.133 E.08488
;WIDTH:0.41674
G1 X110.195 Y119.331 E.00601
G1 X110.593 Y119.846 E.01656
;WIDTH:0.38425
G1 X111.115 Y120.339 E.01671
;WIDTH:0.40834
G1 X111.752 Y120.758 E.01897
;WIDTH:0.450318
G1 X111.787 Y120.799 E.00149
;WIDTH:0.492296
G1 X111.822 Y120.84 E.00164
;WIDTH:0.534274
G1 X111.856 Y120.88 E.00175
;WIDTH:0.576252
G1 X111.891 Y120.921 E.00194
;WIDTH:0.61823
G1 X111.926 Y120.961 E.00206
;WIDTH:0.660208
G1 X111.961 Y121.002 E.00224
G1 X111.926 Y121.041 E.00218
;WIDTH:0.615857
G1 X111.891 Y121.081 E.00206
;WIDTH:0.571506
G1 X111.855 Y121.12 E.0019
;WIDTH:0.527155
G1 X111.82 Y121.16 E.00174
;WIDTH:0.482804
G1 X111.785 Y121.199 E.00156
;WIDTH:0.438453
G1 X111.75 Y121.238 E.00141
;WIDTH:0.409828
G1 X110.996 Y121.752 E.02279
;WIDTH:0.411238
G1 X110.432 Y122.346 E.02054
G1 X110.067 Y122.867 E.01595
;WIDTH:0.40398
G1 X108.324 Y125.88 E.08559
;WIDTH:0.41069
G1 X107.949 Y126.762 E.02399
;WIDTH:0.407582
G1 X107.808 Y127.522 E.01919
;WIDTH:0.373249
G1 X107.811 Y128.415 E.02013
;WIDTH:0.419969
G1 X107.794 Y128.467 E.0014
;WIDTH:0.466689
G1 X107.777 Y128.519 E.00157
;WIDTH:0.513409
G1 X107.76 Y128.571 E.00174
;WIDTH:0.560129
G1 X107.744 Y128.624 E.00194
G1 X107.781 Y128.814 E.00677
;WIDTH:0.560667
G1 X107.699 Y128.749 E.00366
G1 X107.567 Y128.715 E.00477
;WIDTH:0.560129
G1 X107.567 Y128.635 E.0028
G1 X107.544 Y128.585 E.00192
;WIDTH:0.513409
G1 X107.52 Y128.536 E.00174
;WIDTH:0.466689
G1 X107.497 Y128.486 E.00158
;WIDTH:0.419969
G1 X107.474 Y128.437 E.00139
;WIDTH:0.373249
G1 X107.466 Y128.177 E.00586
;WIDTH:0.370521
G1 X107.472 Y127.415 E.01704
G1 X107.626 Y127.303 E.00426
;WIDTH:0.39957
G1 X107.867 Y126.891 E.0116
G1 X107.867 Y126.891 F9000
;WIDTH:0.533854
G1 F1200
G1 X107.815 Y128.883 E.00256
;WIDTH:0.494353
G1 X107.848 Y128.951 E.00231
;WIDTH:0.454852
G1 X108.069 Y129.561 E.01815
;WIDTH:0.423024
G1 X108.336 Y130.146 E.01663
;WIDTH:0.40399
G1 X110.066 Y133.133 E.08488
;WIDTH:0.394892
G1 X110.076 Y133.149 E.00045
;WIDTH:0.418624
G1 X110.398 Y133.611 E.0144
G1 X110.768 Y134.029 E.01427
;WIDTH:0.415898
G1 X111.219 Y134.417 E.0151
;WIDTH:0.406964
G1 X111.901 Y134.838 E.01987
;WIDTH:0.407212
G1 X112.416 Y135.048 E.0138
G1 X112.901 Y135.174 E.01243
;WIDTH:0.404124
G1 X113.776 Y135.277 E.02167
;WIDTH:0.409412
G1 X117.402 Y135.263 E.09047
;WIDTH:0.39749
G1 X118.308 Y135.127 E.02213
;WIDTH:0.4163
G1 X118.92 Y134.917 E.01644
G1 X119.666 Y134.504 E.02167
;WIDTH:0.4009
G1 X120.12 Y134.139 E.0142
;WIDTH:0.418126
G1 X120.565 Y133.652 E.01684
G1 X120.934 Y133.132 E.01628
;WIDTH:0.400058
G1 X122.665 Y130.139 E.08411
;WIDTH:0.41584
G1 X122.815 Y129.824 E.00885
;WIDTH:0.416382
G1 X123.042 Y129.245 E.01581
G1 E-5 F3600
G1 X123.042 Y129.245 F9000
G1 X123.055 Y112.775
G1 E5 F2400
;WIDTH:0.415045
G1 F1200
G1 X123.372 Y113.304 E.01562
;WIDTH:0.375878
G1 X123.525 Y113.416 E.00431
G1 X123.535 Y113.999 E.01325
;WIDTH:0.377139
G1 X123.525 Y114.678 E.01549
G1 X123.362 Y114.816 E.00487
;WIDTH:0.416332
G1 X123.042 Y115.245 E.0136
G1 X123.051 Y115.199 E.00119
;WIDTH:0.411731
G1 X123.182 Y114.595 E.01552
;WIDTH:0.377139
G1 X123.212 Y113.963 E.01443
;WIDTH:0.375878
G1 X123.159 Y113.272 E.01575
;WIDTH:0.400964
G1 X123.092 Y112.954 E.00793
;WIDTH:0.416632
G1 X123.049 Y112.76 E.00505
G1 X122.934 Y112.437 E.00872
;WIDTH:0.416038
G1 X122.664 Y111.854 E.01631
;WIDTH:0.403992
G1 X120.934 Y108.868 E.08486
;WIDTH:0.41871
G1 X120.805 Y108.671 E.00602
G1 X120.366 Y108.12 E.01801
;WIDTH:0.409742
G1 X119.827 Y107.608 E.01856
G1 X119.253 Y107.234 E.01711
;WIDTH:0.447313
G1 X119.218 Y107.195 E.00144
;WIDTH:0.490893
G1 X119.182 Y107.156 E.00161
;WIDTH:0.534473
G1 X119.147 Y107.116 E.00177
;WIDTH:0.578054
G1 X119.112 Y107.077 E.0019
;WIDTH:0.621634
G1 X119.076 Y107.037 E.0021
;WIDTH:0.665214
G1 X119.041 Y106.998 E.0022
G1 X119.076 Y106.957 E.00226
;WIDTH:0.620922
G1 X119.112 Y106.917 E.0021
;WIDTH:0.576629
G1 X119.148 Y106.876 E.00197
;WIDTH:0.532336
G1 X119.184 Y106.836 E.00178
;WIDTH:0.488044
G1 X119.22 Y106.795 E.00165
;WIDTH:0.443751
G1 X119.255 Y106.755 E.00145
;WIDTH:0.414126
G1 X119.557 Y106.58 E.00882
;WIDTH:0.426722
G1 X119.961 Y106.275 E.01321
G1 X120.566 Y105.651 E.02269
;WIDTH:0.417422
G1 X120.933 Y105.134 E.01616
;WIDTH:0.400054
G1 X122.664 Y102.141 E.08411
;WIDTH:0.408014
G1 X122.987 Y101.388 E.02037
;WIDTH:0.38724
G1 X123.187 Y100.601 E.01906
;WIDTH:0.394222
G1 X123.231 Y99.963 E.01531
G1 X123.164 Y99.271 E.01664
;WIDTH:0.393812
G1 X122.993 Y98.595 E.01667
;WIDTH:0.39604
G1 X122.663 Y97.861 E.01936
G1 X120.933 Y94.866 E.08322
;WIDTH:0.3939
G1 X120.926 Y94.855 E.00031
;WIDTH:0.401406
G1 X120.578 Y94.351 E.01496
;WIDTH:0.403036
G1 X120.096 Y93.838 E.01726
G1 X119.369 Y93.307 E.02208
;WIDTH:0.404628
G1 X118.908 Y93.077 E.01269
;WIDTH:0.412826
G1 X117.932 Y92.787 E.02563
G1 X117.376 Y92.731 E.01407
;WIDTH:0.399692
G1 X115.936 Y92.727 E.035
;WIDTH:0.416476
G1 X113.783 Y92.729 E.05473
G1 X113.499 Y92.745 E.00723
;WIDTH:0.408924
G1 X112.648 Y92.884 E.02149
G1 X112.069 Y93.086 E.01528
;WIDTH:0.406478
G1 X111.305 Y93.517 E.02171
;WIDTH:0.422494
G1 X110.919 Y93.837 E.01295
G1 X110.433 Y94.347 E.01819
;WIDTH:0.412802
G1 X110.067 Y94.867 E.01601
;WIDTH:0.403982
G1 X108.323 Y97.882 E.08564
;WIDTH:0.401756
G1 X107.905 Y98.929 E.02755
;WIDTH:0.403206
G1 X107.792 Y99.517 E.01469
G1 X107.774 Y100.182 E.01632
;WIDTH:0.419254
G1 X107.823 Y100.688 E.01302
;WIDTH:0.434446
G1 X107.972 Y101.268 E.01594
G1 X108.337 Y102.139 E.02514
;WIDTH:0.403868
G1 X110.169 Y105.3 E.08981
;WIDTH:0.407592
G1 X110.654 Y105.911 E.01937
;WIDTH:0.381724
G1 X111.294 Y106.466 E.01958
;WIDTH:0.406202
G1 X111.751 Y106.759 E.01343
;WIDTH:0.448174
G1 X111.786 Y106.8 E.00148
;WIDTH:0.490146
G1 X111.821 Y106.84 E.00161
;WIDTH:0.532118
G1 X111.856 Y106.88 E.00176
;WIDTH:0.57409
G1 X111.89 Y106.921 E.00191
;WIDTH:0.616062
G1 X111.925 Y106.961 E.00206
;WIDTH:0.658034
G1 X111.96 Y107.002 E.00224
G1 X111.926 Y107.041 E.00215
;WIDTH:0.615185
G1 X111.891 Y107.081 E.00205
;WIDTH:0.572336
G1 X111.856 Y107.121 E.0019
;WIDTH:0.529486
G1 X111.821 Y107.161 E.00175
;WIDTH:0.486637
G1 X111.787 Y107.201 E.00158
;WIDTH:0.443788
G1 X111.752 Y107.241 E.00145
;WIDTH:0.412938
G1 X110.997 Y107.753 E.02297
;WIDTH:0.41733
G1 X110.434 Y108.348 E.02087
G1 X110.067 Y108.867 E.01619
;WIDTH:0.40398
G1 X108.324 Y111.88 E.08559
;WIDTH:0.410692
G1 X107.949 Y112.762 E.02399
;WIDTH:0.407582
G1 X107.808 Y113.522 E.01919
;WIDTH:0.373394
G1 X107.811 Y114.416 E.02016
;WIDTH:0.420041
G1 X107.794 Y114.467 E.00138
;WIDTH:0.466688
G1 X107.778 Y114.519 E.00156
;WIDTH:0.513335
G1 X107.761 Y114.571 E.00174
;WIDTH:0.559982
G1 X107.744 Y114.623 E.00191
G1 X107.781 Y114.814 E.0068
;WIDTH:0.560771
G1 X107.699 Y114.749 E.00366
G1 X107.567 Y114.715 E.00477
;WIDTH:0.559982
G1 X107.567 Y114.635 E.0028
G1 X107.544 Y114.585 E.00192
;WIDTH:0.513335
G1 X107.52 Y114.536 E.00174
;WIDTH:0.466688
G1 X107.497 Y114.487 E.00156
;WIDTH:0.420041
G1 X107.474 Y114.437 E.00141
;WIDTH:0.373394
G1 X107.466 Y114.177 E.00587
;WIDTH:0.370521
G1 X107.472 Y113.415 E.01704
G1 X107.626 Y113.303 E.00426
;WIDTH:0.399571
G1 X107.867 Y112.891 E.0116
G1 E-5 F3600
G1 X107.867 Y112.891 F9000
G1 X113.474 Y119.871
G1 X113.671 Y119.883
G1 X113.75 Y119.887
G1 X117.245 Y119.887
G1 X117.406 Y119.881
G1 X117.643 Y119.857
G1 X117.874 Y119.814
G1 X118.101 Y119.752
G1 X118.323 Y119.672
G1 X118.537 Y119.574
G1 X118.742 Y119.459
G1 X118.938 Y119.328
G1 X119.122 Y119.181
G1 X119.293 Y119.02
G1 E5 F2400
;WIDTH:0.416332
G1 F1200
G1 X122.815 Y115.824 E.0158
;WIDTH:0.415994
G1 X122.664 Y116.141 E.00891
;WIDTH:0.400052
G1 X120.934 Y119.132 E.08406
;WIDTH:0.415102
G1 X120.567 Y119.652 E.01612
G1 X120.176 Y120.081 E.0147
;WIDTH:0.39251
G1 X119.599 Y120.549 E.0177
;WIDTH:0.408236
G1 X119.254 Y120.76 E.01006
;WIDTH:0.451015
G1 X119.219 Y120.8 E.00147
;WIDTH:0.493793
G1 X119.183 Y120.839 E.00162
;WIDTH:0.536571
G1 X119.148 Y120.879 E.00178
;WIDTH:0.57935
G1 X119.113 Y120.918 E.0019
;WIDTH:0.622128
G1 X119.077 Y120.958 E.0021
;WIDTH:0.664906
G1 X119.042 Y120.997 E.0022
G1 X119.078 Y121.038 E.00229
;WIDTH:0.619958
G1 X119.115 Y121.079 E.00215
;WIDTH:0.57501
G1 X119.151 Y121.12 E.00196
;WIDTH:0.530061
G1 X119.187 Y121.162 E.00182
;WIDTH:0.485113
G1 X119.224 Y121.203 E.00166
;WIDTH:0.440165
G1 X119.26 Y121.244 E.00147
;WIDTH:0.410654
G1 X119.77 Y121.57 E.01515
G1 X120.369 Y122.118 E.02032
;WIDTH:0.41873
G1 X120.805 Y122.671 E.01801
G1 X120.934 Y122.868 E.00602
;WIDTH:0.40399
G1 X122.664 Y125.854 E.08486
;WIDTH:0.41604
G1 X122.934 Y126.437 E.01631
;WIDTH:0.416624
G1 X123.049 Y126.76 E.00872
G1 X123.092 Y126.954 E.00505
;WIDTH:0.400376
G1 X123.158 Y127.272 E.00791
;WIDTH:0.374435
G1 X123.213 Y127.891 E.01406
;WIDTH:0.377028
G1 X123.182 Y128.596 E.01609
;WIDTH:0.411762
G1 X123.051 Y129.199 E.01549
;WIDTH:0.416382
G1 X123.042 Y129.245 E.00119
G1 X123.362 Y128.816 E.0136
;WIDTH:0.377028
G1 X123.525 Y128.678 E.00487
G1 X123.535 Y127.927 E.01712
;WIDTH:0.374435
G1 X123.526 Y127.416 E.01156
G1 X123.373 Y127.304 E.00429
;WIDTH:0.414983
G1 X123.055 Y126.775 E.01563
G1 X123.055 Y126.775 F9000
G1 X123.35 Y126.872
;WIDTH:0.4
G1 F3072.127
G1 X123.513 Y126.709 E.00561
G1 X123.513 Y126.184 E.01277
G1 X123.312 Y126.385 E.00691
G1 X123.151 Y126.022 E.00966
G1 X123.513 Y125.66 E.01245
G1 X123.513 Y125.135 E.01277
G1 X122.981 Y125.667 E.0183
G1 X122.788 Y125.335 E.00934
G1 X123.513 Y124.61 E.02494
G1 X123.513 Y124.086 E.01275
G1 X122.595 Y125.004 E.03158
G1 X122.402 Y124.672 E.00934
G1 X123.513 Y123.561 E.03822
G1 X123.513 Y123.036 E.01277
G1 X122.209 Y124.34 E.04486
G1 X122.016 Y124.008 E.00934
G1 X123.513 Y122.512 E.05148
G1 X123.513 Y121.987 E.01277
G1 X121.823 Y123.676 E.05812
G1 X121.631 Y123.345 E.00931
G1 X123.513 Y121.462 E.06476
G1 X123.513 Y120.938 E.01275
G1 X121.438 Y123.013 E.07138
G1 X121.245 Y122.681 E.00934
G1 X123.513 Y120.413 E.07802
G1 X123.513 Y119.888 E.01277
G1 X121.042 Y122.36 E.08502
G1 X120.812 Y122.065 E.0091
G1 X123.513 Y119.364 E.09291
G1 X123.513 Y118.839 E.01277
G1 X120.555 Y121.797 E.10175
G1 X120.298 Y121.529 E.00903
G1 X123.513 Y118.314 E.11059
G1 X123.513 Y117.79 E.01275
G1 X120.014 Y121.289 E.12036
G1 X119.693 Y121.085 E.00925
G1 X123.513 Y117.265 E.13141
G1 X123.513 Y116.74 E.01277
G1 X121.672 Y118.581 E.06333
G1 X122.396 Y117.332 E.03512
G1 X123.513 Y116.216 E.03841
G1 X123.513 Y115.691 E.01277
G1 X122.668 Y116.536 E.02907
G1 E-5 F3600
G1 X122.668 Y116.536 F9000
G1 X123.352 Y112.877
G1 E5 F2400
G1 F3072.127
G1 X123.513 Y112.716 E.00554
G1 X123.513 Y112.197 E.01262
G1 X123.315 Y112.395 E.00681
G1 X123.156 Y112.034 E.00959
G1 X123.513 Y111.677 E.01228
G1 X123.513 Y111.157 E.01265
G1 X122.989 Y111.682 E.01804
G1 X122.798 Y111.353 E.00925
G1 X123.513 Y110.638 E.0246
G1 X123.513 Y110.118 E.01265
G1 X122.607 Y111.024 E.03117
G1 X122.416 Y110.695 E.00925
G1 X123.513 Y109.598 E.03774
G1 X123.513 Y109.079 E.01262
G1 X122.225 Y110.367 E.04431
G1 X122.034 Y110.038 E.00925
G1 X123.513 Y108.559 E.05088
G1 X123.513 Y108.039 E.01265
G1 X121.843 Y109.71 E.05746
G1 X121.652 Y109.381 E.00925
G1 X123.513 Y107.52 E.06402
G1 X123.513 Y107 E.01265
G1 X121.461 Y109.052 E.07059
G1 X121.27 Y108.724 E.00923
G1 X123.513 Y106.48 E.07718
G1 X123.513 Y105.961 E.01262
G1 X121.073 Y108.401 E.08393
G1 X120.85 Y108.104 E.00903
G1 X123.513 Y105.441 E.09161
G1 X123.513 Y104.921 E.01265
G1 X120.596 Y107.838 E.10034
G1 X120.342 Y107.573 E.00893
G1 X123.513 Y104.402 E.10908
G1 X123.513 Y103.882 E.01265
G1 X120.069 Y107.326 E.11847
G1 X119.755 Y107.12 E.00913
G1 X123.545 Y103.33 E.13037
G1 X123.73 Y102.72 E.01551
G1 X123.866 Y102.496 E.00637
G1 X123.966 Y102.443 E.00275
G1 X123.966 Y102.389 E.00131
G1 X121.531 Y104.824 E.08376
G1 X122.248 Y103.588 E.03476
G1 X123.966 Y101.869 E.05912
G1 X123.966 Y101.35 E.01262
G1 X122.965 Y102.351 E.03443
G1 X123.372 Y101.424 E.02463
G1 X123.966 Y100.83 E.02043
G1 X123.966 Y100.31 E.01265
G1 X123.538 Y100.739 E.01474
G1 X123.603 Y100.154 E.01432
G1 X123.936 Y99.821 E.01146
G1 X123.723 Y99.515 E.00907
G1 X123.581 Y99.656 E.00487
G1 X123.516 Y98.683 E.02372
G1 X123.432 Y98.766 E.00287
G1 X123.307 Y98.372 E.01005
G1 X123.513 Y98.165 E.0071
G1 X123.513 Y97.646 E.01262
G1 X123.149 Y98.01 E.01252
G1 X122.972 Y97.667 E.00939
G1 X123.513 Y97.126 E.01861
G1 X123.513 Y96.606 E.01265
G1 X122.781 Y97.338 E.02518
G1 X122.591 Y97.009 E.00924
G1 X123.513 Y96.087 E.03172
G1 X123.513 Y95.567 E.01265
G1 X122.4 Y96.68 E.03829
G1 X122.21 Y96.351 E.00924
G1 X123.513 Y95.047 E.04484
G1 X123.513 Y94.528 E.01262
G1 X122.02 Y96.021 E.05136
G1 X121.829 Y95.692 E.00925
G1 X123.513 Y94.008 E.05793
G1 X123.513 Y93.488 E.01265
G1 X121.639 Y95.363 E.06448
G1 X121.448 Y95.034 E.00925
G1 X123.513 Y92.969 E.07103
G1 X123.513 Y92.449 E.01265
G1 X121.258 Y94.704 E.07757
G1 X121.059 Y94.383 E.00919
G1 X123.513 Y91.929 E.08442
G1 X123.555 Y91.53 E.00976
G1 X123.393 Y91.53 E.00394
G1 X120.835 Y94.088 E.08799
G1 X120.583 Y93.82 E.00895
G1 X122.873 Y91.53 E.07877
G1 X122.353 Y91.53 E.01265
G1 X120.33 Y93.554 E.06961
G1 X120.046 Y93.318 E.00898
G1 X121.834 Y91.53 E.06151
G1 X121.314 Y91.53 E.01265
G1 X119.737 Y93.107 E.05425
G1 X119.414 Y92.911 E.00919
G1 X120.794 Y91.53 E.04749
G1 X120.275 Y91.53 E.01262
G1 X119.062 Y92.743 E.04173
G1 X118.674 Y92.611 E.00997
G1 X119.755 Y91.53 E.03719
G1 X119.235 Y91.53 E.01265
G1 X118.28 Y92.486 E.03287
G1 X117.847 Y92.399 E.01074
G1 X118.716 Y91.53 E.02989
G1 X118.196 Y91.53 E.01265
G1 X117.36 Y92.366 E.02876
G1 X116.842 Y92.364 E.0126
G1 X117.676 Y91.53 E.02869
G1 X117.157 Y91.53 E.01262
G1 X116.324 Y92.363 E.02865
G1 X115.806 Y92.361 E.0126
G1 X116.637 Y91.53 E.02859
G1 X116.117 Y91.53 E.01265
G1 X115.288 Y92.36 E.02853
G1 X114.77 Y92.358 E.0126
G1 X115.598 Y91.53 E.02848
G1 X115.078 Y91.53 E.01265
G1 X114.252 Y92.356 E.02841
G1 X113.73 Y92.358 E.0127
G1 X114.558 Y91.53 E.02848
G1 X114.039 Y91.53 E.01262
G1 X113.15 Y92.418 E.03056
G1 X112.509 Y92.54 E.01587
G1 X113.519 Y91.53 E.03474
G1 X112.999 Y91.53 E.01265
G1 X111.65 Y92.879 E.0464
G1 X111.029 Y93.258 E.0177
G1 X110.647 Y93.575 E.01207
G1 X110.137 Y94.12 E.01816
G1 X109.626 Y94.903 E.02274
G1 X107.487 Y97.042 E.07358
G1 X107.487 Y96.523 E.01262
G1 X112.48 Y91.53 E.17176
G1 X111.96 Y91.53 E.01265
G1 X107.487 Y96.003 E.15387
G1 X107.487 Y95.483 E.01265
G1 X111.44 Y91.53 E.13598
G1 X110.921 Y91.53 E.01262
G1 X107.487 Y94.964 E.11813
G1 X107.487 Y94.444 E.01265
G1 X110.401 Y91.53 E.10024
G1 X109.881 Y91.53 E.01265
G1 X107.487 Y93.924 E.08235
G1 X107.487 Y93.405 E.01262
G1 X109.362 Y91.53 E.0645
G1 X108.842 Y91.53 E.01265
G1 X107.487 Y92.885 E.04661
G1 X107.487 Y92.365 E.01265
G1 X108.322 Y91.53 E.02872
G1 X107.803 Y91.53 E.01262
G1 X107.322 Y92.01 E.01653
G1 X107.322 Y92.01 F9000
G1 X107.389 Y91.171
;TYPE:Solid infill
;WIDTH:0.386506
G1 F1200
G1 X123.608 Y91.171 E.37995
G1 E-5 F3600
G1 X113.012 Y94.215 F9000
G1 X112.787 Y94.286
G1 X112.569 Y94.375
G1 X112.359 Y94.481
G1 X112.159 Y94.605
G1 X107.322 Y97.727
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X108.904 Y96.145 E.05442
G1 X108.183 Y97.386 E.03491
G1 X107.487 Y98.082 E.02394
G1 X107.487 Y98.601 E.01262
G1 X107.68 Y98.408 E.00664
G1 X107.478 Y99.129 E.01821
G1 X107.203 Y99.646 E.01424
G1 X107.034 Y99.836 E.00619
G1 X107.034 Y100.094 E.00628
G1 X107.408 Y99.72 E.01287
G1 X107.41 Y100.237 E.01258
G1 X107.034 Y100.614 E.01295
G1 X107.034 Y101.133 E.01262
G1 X107.449 Y100.718 E.01428
G1 X107.547 Y101.14 E.01054
G1 X107.034 Y101.653 E.01765
G1 X107.034 Y102.173 E.01265
G1 X107.663 Y101.543 E.02165
G1 X107.815 Y101.911 E.00968
G1 X107.17 Y102.556 E.02219
G1 X107.348 Y102.898 E.00938
G1 X107.986 Y102.26 E.02195
G1 X108.176 Y102.589 E.00924
G1 X107.453 Y103.313 E.02489
G1 X107.487 Y103.798 E.01183
G1 X108.367 Y102.918 E.03027
G1 X108.557 Y103.247 E.00924
G1 X107.487 Y104.318 E.03682
G1 X107.487 Y104.837 E.01262
G1 X108.748 Y103.577 E.04336
G1 X108.938 Y103.906 E.00924
G1 X107.487 Y105.357 E.04991
G1 X107.487 Y105.877 E.01265
G1 X109.129 Y104.235 E.05648
G1 X109.319 Y104.564 E.00924
G1 X107.487 Y106.397 E.06304
G1 X107.487 Y106.916 E.01262
G1 X109.51 Y104.893 E.06959
G1 X109.7 Y105.223 E.00926
G1 X107.487 Y107.436 E.07613
G1 X107.487 Y107.956 E.01265
G1 X109.892 Y105.551 E.08273
G1 X110.11 Y105.852 E.00904
G1 X107.487 Y108.475 E.09023
G1 X107.487 Y108.995 E.01265
G1 X110.355 Y106.127 E.09866
G1 X110.607 Y106.394 E.00893
G1 X107.487 Y109.515 E.10734
G1 X107.487 Y110.034 E.01262
G1 X110.894 Y106.627 E.1172
G1 X111.196 Y106.844 E.00905
G1 X107.487 Y110.554 E.1276
G1 X107.487 Y111.074 E.01265
G1 X109.583 Y108.978 E.0721
G1 X108.861 Y110.219 E.03492
G1 X107.487 Y111.593 E.04726
G1 X107.487 Y112.113 E.01265
G1 X108.139 Y111.46 E.02245
G1 X107.663 Y112.456 E.02685
G1 X107.322 Y112.797 E.01173
G1 E-5 F3600
G1 X107.322 Y112.797 F9000
G1 X116.587 Y122.114
G1 X117.245 Y122.113
G1 X117.406 Y122.119
G1 X117.643 Y122.143
G1 X117.874 Y122.186
G1 X118.101 Y122.248
G1 X118.323 Y122.328
G1 X118.537 Y122.426
G1 X118.742 Y122.541
G1 X118.938 Y122.672
G1 X119.122 Y122.819
G1 X119.293 Y122.98
G1 X119.451 Y123.155
G1 X119.594 Y123.342
G1 X119.709 Y123.517
G1 X121.471 Y126.569
G1 X121.563 Y126.745
G1 X123.069 Y129.75
G1 E5 F2400
G1 F3072.127
G1 X123.513 Y129.306 E.01527
G1 X123.513 Y129.832 E.01279
G1 X122.925 Y130.42 E.02023
G1 X122.199 Y131.672 E.0352
G1 X123.513 Y130.358 E.0452
G1 X123.513 Y130.884 E.01279
G1 X121.021 Y133.377 E.08574
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X123.254 Y131.144 E-1.5
;WIPE_END
G1 X121.848 Y99.882 F9000
G1 X121.076 Y89.79
G1 X120.99 Y88.151
G1 X120.908 Y86.599
G1 X121.199 Y85.151
G1 X120.85 Y85.5
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X120.85 Y85.38 E.00292
G1 X120.77 Y85.229 E.00416
G1 X120.667 Y85.197 E.00262
G1 X110.333 Y85.197 E.25136
G1 X110.268 Y85.209 E.00161
G1 X110.15 Y85.38 E.00505
G1 X110.15 Y85.5 E.00292
G1 X104.557 Y85.5 E.13604
G1 X103.987 Y85.458 E.0139
G1 X103.437 Y85.333 E.01372
G1 X102.867 Y85.106 E.01492
G1 X102.41 Y84.839 E.01287
G1 X102.078 Y84.567 E.01044
G1 X101.584 Y84.074 E.01698
G1 X101.127 Y83.348 E.02087
G1 X100.864 Y82.612 E.01901
G1 X100.761 Y81.98 E.01558
G1 X100.75 Y78.802 E.0773
G1 X100.7 Y78.677 E.00327
G1 X100.071 Y77.966 E.02309
G1 X99.901 Y77.62 E.00938
G1 X99.903 Y77.357 E.0064
G1 X100.055 Y77.052 E.00829
G1 X100.59 Y76.441 E.01975
G1 X130.41 Y76.441 E.72534
G1 X130.992 Y77.145 E.02222
G1 X131.107 Y77.451 E.00795
G1 X131.117 Y77.537 E.00211
G1 X131.053 Y77.748 E.00536
G1 X130.745 Y78.208 E.01347
G1 X130.3 Y78.677 E.01573
G1 X130.25 Y78.802 E.00327
G1 X130.24 Y81.704 E.07059
G1 X130.197 Y82.263 E.01364
G1 X130.071 Y82.814 E.01375
G1 X129.862 Y83.346 E.0139
G1 X129.577 Y83.839 E.01385
G1 X129.227 Y84.278 E.01366
G1 X128.803 Y84.67 E.01405
G1 X128.357 Y84.975 E.01314
G1 X127.833 Y85.239 E.01427
G1 X127.29 Y85.405 E.01381
G1 X126.732 Y85.489 E.01373
G1 X120.91 Y85.5 E.14161
G1 X120.91 Y85.5 F9000
G1 X121.029 Y85.027
;TYPE:Perimeter
G1 F6000
G1 X120.975 Y84.926 E.00279
G1 X120.86 Y84.866 E.00316
G1 X120.667 Y84.831 E.00477
G1 X110.333 Y84.831 E.25136
G1 X110.238 Y84.84 E.00232
G1 X110.024 Y84.927 E.00562
G1 X109.914 Y85.134 E.0057
G1 X105.287 Y85.134 E.11255
G1 X104.299 Y85.114 E.02404
G1 X103.8 Y85.04 E.01227
G1 X103.295 Y84.882 E.01287
G1 X102.829 Y84.66 E.01256
G1 X102.309 Y84.284 E.01561
G1 X101.876 Y83.852 E.01488
G1 X101.458 Y83.187 E.01911
G1 X101.22 Y82.52 E.01723
G1 X101.127 Y81.95 E.01405
G1 X101.116 Y78.801 E.0766
G1 X101.086 Y78.624 E.00437
G1 X100.965 Y78.425 E.00567
G1 X100.379 Y77.767 E.02143
G1 X100.253 Y77.518 E.00679
G1 X100.361 Y77.257 E.00687
G1 X100.756 Y76.807 E.01456
G1 X130.244 Y76.807 E.71727
G1 X130.602 Y77.215 E.0132
G1 X130.744 Y77.49 E.00753
G1 X130.737 Y77.562 E.00176
G1 X130.466 Y77.971 E.01193
G1 X130.035 Y78.425 E.01523
G1 X129.914 Y78.624 E.00567
G1 X129.884 Y78.801 E.00437
G1 X129.874 Y81.703 E.07059
G1 X129.835 Y82.208 E.01232
G1 X129.722 Y82.706 E.01242
G1 X129.533 Y83.187 E.01257
G1 X129.275 Y83.633 E.01253
G1 X128.959 Y84.029 E.01232
G1 X128.585 Y84.375 E.01239
G1 X128.173 Y84.659 E.01217
G1 X127.704 Y84.896 E.01278
G1 X127.209 Y85.048 E.0126
G1 X126.704 Y85.123 E.01242
G1 X121.085 Y85.134 E.13668
G1 X121.057 Y85.08 E.00148
G1 X121.057 Y85.08 F9000
G1 X121.268 Y84.768
G1 F6000
G1 X121.257 Y84.768 E.00027
G1 X121.181 Y84.624 E.00396
G1 X120.988 Y84.524 E.00529
G1 X120.667 Y84.466 E.00793
G1 X110.333 Y84.466 E.25136
G1 X110.175 Y84.479 E.00386
G1 X109.818 Y84.624 E.00937
G1 X109.742 Y84.769 E.00398
G1 X105.287 Y84.769 E.10836
G1 X104.316 Y84.749 E.02362
G1 X103.655 Y84.632 E.01633
G1 X103.014 Y84.344 E.01709
G1 X102.541 Y84.001 E.01421
G1 X102.168 Y83.629 E.01281
G1 X101.789 Y83.027 E.0173
G1 X101.575 Y82.428 E.01547
G1 X101.492 Y81.92 E.01252
G1 X101.481 Y78.8 E.07589
G1 X101.431 Y78.505 E.00728
G1 X101.23 Y78.173 E.00944
G1 X100.651 Y77.52 E.02123
G1 X100.922 Y77.172 E.01073
G1 X130.078 Y77.172 E.70919
G1 X130.355 Y77.508 E.01059
G1 X130.187 Y77.734 E.00685
G1 X129.77 Y78.173 E.01473
G1 X129.569 Y78.505 E.00944
G1 X129.519 Y78.8 E.00728
G1 X129.509 Y81.701 E.07056
G1 X129.439 Y82.38 E.0166
G1 X129.204 Y83.028 E.01677
G1 X128.845 Y83.614 E.01672
G1 X128.347 Y84.098 E.01689
G1 X127.797 Y84.455 E.01595
G1 X127.346 Y84.624 E.01172
G1 X126.677 Y84.758 E.0166
G1 X121.328 Y84.767 E.13011
G1 X121.328 Y84.767 F9000
G1 X121.544 Y84.401
G1 F6000
G1 X121.429 Y84.402 E.0028
G1 X121.386 Y84.321 E.00223
G1 X121.117 Y84.182 E.00737
G1 X120.667 Y84.1 E.01113
G1 X110.333 Y84.1 E.25136
G1 X109.881 Y84.182 E.01117
G1 X109.612 Y84.322 E.00738
G1 X109.569 Y84.403 E.00223
G1 X104.493 Y84.395 E.12347
G1 X103.962 Y84.327 E.01302
G1 X103.349 Y84.117 E.01576
G1 X102.862 Y83.792 E.01424
G1 X102.46 Y83.406 E.01356
G1 X102.12 Y82.866 E.01552
G1 X101.931 Y82.336 E.01369
G1 X101.858 Y81.89 E.01099
G1 X101.847 Y78.798 E.07521
G1 X101.777 Y78.386 E.01017
G1 X101.496 Y77.922 E.01319
G1 X101.131 Y77.538 E.01289
G1 X129.869 Y77.538 E.69902
G1 X129.504 Y77.922 E.01289
G1 X129.223 Y78.386 E.01319
G1 X129.153 Y78.798 E.01017
G1 X129.143 Y81.7 E.07059
G1 X129.082 Y82.299 E.01465
G1 X128.874 Y82.869 E.01476
G1 X128.558 Y83.385 E.01472
G1 X128.13 Y83.803 E.01455
G1 X127.712 Y84.081 E.01221
G1 X127.238 Y84.274 E.01245
G1 X126.649 Y84.392 E.01461
G1 X121.604 Y84.401 E.12271
G1 X121.604 Y84.401 F9000
G1 X121.822 Y84.035
G1 F6000
G1 X121.647 Y84.036 E.00426
G1 X121.245 Y83.839 E.01089
G1 X120.963 Y83.761 E.00712
G1 X120.667 Y83.734 E.00723
G1 X110.333 Y83.734 E.25136
G1 X110.049 Y83.759 E.00693
G1 X109.752 Y83.84 E.00749
G1 X109.397 Y84.037 E.00988
G1 X104.612 Y84.037 E.11639
G1 X104.042 Y83.97 E.01396
G1 X103.51 Y83.787 E.01368
G1 X103.125 Y83.535 E.01119
G1 X102.752 Y83.183 E.01247
G1 X102.451 Y82.705 E.01374
G1 X102.356 Y82.441 E.00682
G1 X102.223 Y81.859 E.01452
G1 X102.213 Y78.797 E.07448
G1 X102.123 Y78.267 E.01308
G1 X101.902 Y77.903 E.01036
G1 X129.098 Y77.903 E.66152
G1 X128.877 Y78.267 E.01036
G1 X128.787 Y78.797 E.01308
G1 X128.78 Y80.977 E.05303
G1 X128.75 Y82.045 E.02599
G1 X128.621 Y82.552 E.01273
G1 X128.369 Y83.014 E.0128
G1 X128.037 Y83.41 E.01257
G1 X127.528 Y83.765 E.01509
G1 X127.131 Y83.924 E.0104
G1 X126.622 Y84.027 E.01263
G1 X121.882 Y84.035 E.1153
G1 E-5 F3600
G1 X121.882 Y84.035 F9000
G1 X127.317 Y83.739
G1 E5 F2400
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X128.057 Y82.985 E.0257
G1 X128.365 Y82.451 E.01499
G1 X128.47 Y82.065 E.00973
G1 X126.814 Y83.72 E.05695
G1 X126.26 Y83.753 E.0135
G1 X128.504 Y81.51 E.07718
G1 X128.506 Y80.986 E.01275
G1 X125.738 Y83.754 E.09522
G1 X125.216 Y83.755 E.0127
G1 X128.507 Y80.463 E.11323
G1 X128.509 Y79.94 E.01272
G1 X124.693 Y83.756 E.13127
G1 X124.171 Y83.757 E.0127
G1 X128.511 Y79.417 E.14929
G1 X128.513 Y78.893 E.01275
G1 X123.649 Y83.758 E.16734
G1 X123.126 Y83.759 E.01272
G1 X128.355 Y78.53 E.17987
G1 X127.833 Y78.53 E.0127
G1 X122.604 Y83.76 E.17989
G1 X122.081 Y83.761 E.01272
G1 X127.312 Y78.53 E.17994
G1 X126.79 Y78.53 E.0127
G1 X121.603 Y83.717 E.17843
G1 X121.244 Y83.555 E.00958
G1 X126.269 Y78.53 E.17286
G1 X125.748 Y78.53 E.01267
G1 X120.805 Y83.472 E.17002
G1 X120.296 Y83.46 E.01238
G1 X125.226 Y78.53 E.16959
G1 X124.705 Y78.53 E.01267
G1 X119.775 Y83.46 E.16959
G1 X119.253 Y83.46 E.0127
G1 X124.183 Y78.53 E.16959
G1 X123.662 Y78.53 E.01267
G1 X118.732 Y83.46 E.16959
G1 X118.21 Y83.46 E.0127
G1 X123.14 Y78.53 E.16959
G1 X122.619 Y78.53 E.01267
G1 X117.689 Y83.46 E.16959
G1 X117.167 Y83.46 E.0127
G1 X122.098 Y78.53 E.16961
G1 X121.576 Y78.53 E.0127
G1 X116.646 Y83.46 E.16959
G1 X116.125 Y83.46 E.01267
G1 X121.055 Y78.53 E.16959
G1 X120.533 Y78.53 E.0127
G1 X115.603 Y83.46 E.16959
G1 X115.082 Y83.46 E.01267
G1 X120.012 Y78.53 E.16959
G1 X119.49 Y78.53 E.0127
G1 X114.56 Y83.46 E.16959
G1 X114.039 Y83.46 E.01267
G1 X118.969 Y78.53 E.16959
G1 X118.447 Y78.53 E.0127
G1 X113.517 Y83.46 E.16959
G1 X112.996 Y83.46 E.01267
G1 X117.926 Y78.53 E.16959
G1 X117.405 Y78.53 E.01267
G1 X112.474 Y83.46 E.16961
G1 X111.953 Y83.46 E.01267
G1 X116.883 Y78.53 E.16959
G1 X116.362 Y78.53 E.01267
G1 X111.432 Y83.46 E.16959
G1 X110.91 Y83.46 E.0127
G1 X115.84 Y78.53 E.16959
G1 X115.319 Y78.53 E.01267
G1 X110.389 Y83.46 E.16959
G1 X109.778 Y83.549 E.01502
G1 X114.797 Y78.53 E.17265
G1 X114.276 Y78.53 E.01267
G1 X109.043 Y83.763 E.18001
G1 X108.521 Y83.763 E.0127
G1 X113.755 Y78.53 E.18003
G1 X113.233 Y78.53 E.0127
G1 X108 Y83.763 E.18001
G1 X107.479 Y83.763 E.01267
G1 X112.712 Y78.53 E.18001
G1 X112.19 Y78.53 E.0127
G1 X106.957 Y83.763 E.18001
G1 X106.436 Y83.763 E.01267
G1 X111.669 Y78.53 E.18001
G1 X111.147 Y78.53 E.0127
G1 X105.914 Y83.763 E.18001
G1 X105.393 Y83.763 E.01267
G1 X110.626 Y78.53 E.18001
G1 X110.105 Y78.53 E.01267
G1 X104.871 Y83.763 E.18003
G1 X104.369 Y83.744 E.01222
G1 X109.583 Y78.53 E.17936
G1 X109.062 Y78.53 E.01267
G1 X103.932 Y83.66 E.17647
G1 X103.567 Y83.503 E.00966
G1 X108.54 Y78.53 E.17107
G1 X108.019 Y78.53 E.01267
G1 X103.259 Y83.29 E.16374
G1 X102.99 Y83.037 E.00898
G1 X107.497 Y78.53 E.15504
G1 X106.976 Y78.53 E.01267
G1 X102.785 Y82.721 E.14417
G1 X102.62 Y82.364 E.00957
G1 X106.454 Y78.53 E.13189
G1 X105.933 Y78.53 E.01267
G1 X102.516 Y81.947 E.11754
G1 X102.496 Y81.445 E.01222
G1 X105.412 Y78.53 E.10029
G1 X104.89 Y78.53 E.0127
G1 X102.494 Y80.926 E.08242
G1 X102.492 Y80.406 E.01265
G1 X104.369 Y78.53 E.06455
G1 X103.847 Y78.53 E.0127
G1 X102.491 Y79.887 E.04666
G1 X102.489 Y79.367 E.01265
G1 X103.326 Y78.53 E.02879
G1 X102.804 Y78.53 E.0127
G1 X102.323 Y79.011 E.01655
G1 X102.323 Y79.011 F9000
G1 X102.387 Y78.171
;TYPE:Solid infill
;WIDTH:0.386574
G1 F1200
G1 X128.613 Y78.171 E.6145
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X125.455 Y78.171 E-1.5
;WIPE_END
G1 X125.779 Y85.151 F9000
G1 X125.846 Y86.599
G1 X125.937 Y88.151
G1 X125.937 Y88.558
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X125.961 Y88.57 E.00065
G1 X126 Y88.683 E.00291
G1 X126 Y89.233 E.01338
G1 X126.522 Y89.846 E.01958
G1 X126.69 Y90.169 E.00886
G1 X126.753 Y90.525 E.00879
G1 X126.711 Y90.77 E.00605
G1 X126.522 Y91.155 E.01043
G1 X126 Y91.767 E.01957
G1 X126 Y92.723 E.02325
G1 X139.202 Y92.722 E.32113
G1 X139.514 Y92.81 E.00789
G1 X139.789 Y93.089 E.00953
G1 X139.9 Y93.531 E.01109
G1 X139.9 Y95.298 E.04298
G1 X139.852 Y95.601 E.00746
G1 X139.713 Y95.851 E.00696
G1 X139.415 Y96.066 E.00894
G1 X138.997 Y96.106 E.01021
G1 X136.7 Y96.105 E.05587
G1 X136.698 Y132.81 E.89281
G1 X136.64 Y133.7 E.02169
G1 X136.557 Y134.298 E.01469
G1 X136.449 Y134.844 E.01354
G1 X136.102 Y136.041 E.03031
G1 X135.88 Y136.605 E.01474
G1 X135.553 Y137.298 E.01864
G1 X135.298 Y137.76 E.01284
G1 X135.01 Y138.223 E.01326
G1 X134.688 Y138.682 E.01364
G1 X134.222 Y139.261 E.01808
G1 X133.843 Y139.679 E.01372
G1 X133.407 Y140.105 E.01483
G1 X132.68 Y140.714 E.02307
G1 X132.046 Y141.16 E.01885
G1 X131.069 Y141.719 E.02738
G1 X130.449 Y141.994 E.0165
G1 X129.688 Y142.289 E.01985
G1 X129.113 Y142.459 E.01458
G1 X128.511 Y142.601 E.01504
G1 X127.84 Y142.722 E.01658
G1 X127.307 Y142.785 E.01305
G1 X126.773 Y142.817 E.01301
G1 X120.483 Y142.8 E.153
G1 X120.387 Y142.773 E.00243
G1 X120.3 Y142.617 E.00434
G1 X120.3 Y142.412 E.00499
G1 X110.7 Y142.412 E.23351
G1 X110.7 Y142.617 E.00499
G1 X110.576 Y142.791 E.0052
G1 X110.517 Y142.8 E.00145
G1 X105.923 Y142.8 E.11174
G1 X105.741 Y142.821 E.00446
G1 X104.5 Y142.822 E.03019
G1 X103.309 Y142.742 E.02904
G1 X102.126 Y142.52 E.02928
G1 X101.449 Y142.332 E.01709
G1 X100.832 Y142.118 E.01588
G1 X100.231 Y141.863 E.01588
G1 X99.119 Y141.264 E.03072
G1 X98.572 Y140.899 E.016
G1 X97.96 Y140.427 E.0188
G1 X97.473 Y139.992 E.01588
G1 X96.96 Y139.468 E.01784
G1 X96.587 Y139.036 E.01388
G1 X96.245 Y138.591 E.01365
G1 X95.937 Y138.14 E.01328
G1 X95.319 Y137.043 E.03063
G1 X95.09 Y136.536 E.01353
G1 X94.903 Y136.056 E.01253
G1 X94.605 Y135.071 E.02503
G1 X94.377 Y133.842 E.0304
G1 X94.302 Y132.81 E.02517
G1 X94.3 Y96.105 E.89281
G1 X91.798 Y96.106 E.06086
G1 X91.508 Y96.03 E.00729
G1 X91.232 Y95.774 E.00916
G1 X91.108 Y95.413 E.00928
G1 X91.108 Y93.415 E.0486
G1 X91.201 Y93.103 E.00792
G1 X91.367 Y92.89 E.00657
G1 X91.586 Y92.762 E.00617
G1 X91.798 Y92.722 E.00525
G1 X104.301 Y92.723 E.30412
G1 X105 Y92.723 E.017
G1 X105 Y91.767 E.02325
G1 X104.478 Y91.155 E.01957
G1 X104.31 Y90.831 E.00888
G1 X104.247 Y90.475 E.00879
G1 X104.289 Y90.23 E.00605
G1 X104.478 Y89.845 E.01043
G1 X105 Y89.233 E.01957
G1 X105 Y88.683 E.01338
G1 X105.062 Y88.545 E.00368
G1 X105.183 Y88.5 E.00314
G1 X125.817 Y88.5 E.5019
G1 X125.883 Y88.532 E.00178
G1 X126.189 Y88.311 F9000
;TYPE:Perimeter
G1 F6000
G1 X126.293 Y88.409 E.00348
G1 X126.366 Y88.683 E.0069
G1 X126.366 Y89.099 E.01012
G1 X126.801 Y89.609 E.0163
G1 X127.036 Y90.048 E.01211
G1 X127.115 Y90.574 E.01294
G1 X127.041 Y90.926 E.00875
G1 X126.8 Y91.392 E.01276
G1 X126.366 Y91.901 E.01627
G1 X126.366 Y92.357 E.01109
G1 X139.202 Y92.357 E.31222
G1 X139.622 Y92.46 E.01052
G1 X139.879 Y92.63 E.0075
G1 X140.068 Y92.853 E.00711
;WIDTH:0.439128
G1 X140.133 Y92.99 E.00408
;WIDTH:0.478257
G1 X140.199 Y93.127 E.00449
;WIDTH:0.517386
G1 X140.265 Y93.264 E.00489
;WIDTH:0.556515
G1 X140.331 Y93.401 E.00528
G1 X140.34 Y93.531 E.00453
;WIDTH:0.547008
G1 X140.34 Y95.298 E.06026
;WIDTH:0.569133
G1 X140.311 Y95.632 E.01193
G1 X140.278 Y95.664 E.00164
;WIDTH:0.526853
G1 X140.246 Y95.695 E.00146
;WIDTH:0.484572
G1 X140.214 Y95.727 E.00136
;WIDTH:0.442291
G1 X140.182 Y95.759 E.00123
;WIDTH:0.40001
G1 X139.944 Y96.135 E.01082
G1 X139.724 Y96.313 E.00688
G1 X139.489 Y96.425 E.00633
G1 X138.996 Y96.472 E.01205
G1 X137.066 Y96.471 E.04695
G1 X137.063 Y132.81 E.88394
G1 X137.005 Y133.724 E.02228
G1 X136.919 Y134.349 E.01535
G1 X136.8 Y134.946 E.01481
G1 X136.453 Y136.143 E.03032
G1 X136.221 Y136.739 E.01556
G1 X135.883 Y137.455 E.01926
G1 X135.618 Y137.937 E.01338
G1 X135.32 Y138.417 E.01374
G1 X134.987 Y138.892 E.01411
G1 X134.507 Y139.491 E.01867
G1 X134.114 Y139.925 E.01424
G1 X133.662 Y140.367 E.01538
G1 X132.915 Y140.994 E.02372
G1 X132.213 Y141.486 E.02085
G1 X131.25 Y142.037 E.02699
G1 X130.597 Y142.329 E.0174
G1 X129.811 Y142.633 E.0205
G1 X129.217 Y142.81 E.01508
G1 X128.595 Y142.957 E.01555
G1 X127.904 Y143.082 E.01708
G1 X127.35 Y143.148 E.01357
G1 X126.763 Y143.183 E.0143
G1 X120.483 Y143.166 E.15276
G1 X120.307 Y143.137 E.00434
G1 X120.196 Y143.085 E.00298
G1 X120.024 Y142.777 E.00858
G1 X110.976 Y142.777 E.22009
G1 X110.804 Y143.085 E.00858
G1 X110.577 Y143.163 E.00584
G1 X105.945 Y143.166 E.11267
G1 X105.742 Y143.187 E.00496
G1 X104.5 Y143.188 E.03021
G1 X103.307 Y143.11 E.02908
G1 X102.058 Y142.879 E.0309
G1 X101.351 Y142.684 E.01784
G1 X100.712 Y142.463 E.01645
G1 X100.058 Y142.185 E.01729
G1 X98.945 Y141.586 E.03075
G1 X98.368 Y141.203 E.01685
G1 X97.736 Y140.716 E.01941
G1 X97.229 Y140.265 E.01651
G1 X96.699 Y139.723 E.01844
G1 X96.31 Y139.275 E.01443
G1 X95.955 Y138.814 E.01415
G1 X95.635 Y138.346 E.01379
G1 X95 Y137.222 E.0314
G1 X94.757 Y136.686 E.01432
G1 X94.562 Y136.188 E.01301
G1 X94.26 Y135.197 E.0252
G1 X94.016 Y133.905 E.03198
G1 X93.937 Y132.81 E.0267
G1 X93.934 Y96.471 E.88394
G1 X91.798 Y96.472 E.05196
G1 X91.513 Y96.425 E.00703
G1 X91.279 Y96.314 E.0063
G1 X91.058 Y96.137 E.00689
G1 X90.89 Y95.904 E.00699
G1 X90.777 Y95.607 E.00773
;WIDTH:0.44021
G1 X90.751 Y95.586 E.0009
;WIDTH:0.480421
G1 X90.724 Y95.564 E.00103
;WIDTH:0.520632
G1 X90.698 Y95.543 E.00108
;WIDTH:0.560843
G1 X90.671 Y95.522 E.0012
G1 X90.665 Y95.413 E.00382
;WIDTH:0.554286
G1 X90.665 Y93.415 E.06911
;WIDTH:0.572659
G1 X90.681 Y93.236 E.00644
G1 X90.765 Y93.109 E.00545
;WIDTH:0.529494
G1 X90.849 Y92.982 E.00502
;WIDTH:0.486329
G1 X90.933 Y92.856 E.00455
;WIDTH:0.443164
G1 X91.017 Y92.729 E.00414
;WIDTH:0.399999
G1 X91.323 Y92.482 E.00957
G1 X91.688 Y92.368 E.0093
G1 X91.798 Y92.357 E.00269
G1 X104.301 Y92.357 E.30412
G1 X104.634 Y92.357 E.0081
G1 X104.634 Y91.901 E.01109
G1 X104.2 Y91.392 E.01627
G1 X104.004 Y91.051 E.00957
G1 X103.891 Y90.61 E.01107
G1 X103.911 Y90.234 E.00916
G1 X104.121 Y89.73 E.01328
G1 X104.634 Y89.099 E.01978
G1 X104.656 Y88.531 E.01383
G1 X104.821 Y88.27 E.00751
G1 X105.088 Y88.143 E.00719
G1 X125.817 Y88.134 E.50421
G1 X126.069 Y88.196 E.00631
G1 X126.146 Y88.269 E.00258
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X126.189 Y88.311 E-.02855
G1 X126.293 Y88.409 E-.06788
G1 X126.366 Y88.683 E-.13469
G1 X126.366 Y89.099 E-.1976
G1 X126.801 Y89.609 E-.3184
G1 X127.036 Y90.048 E-.23652
G1 X127.115 Y90.574 E-.25265
G1 X127.041 Y90.926 E-.17085
G1 X126.951 Y91.1 E-.09286
;WIPE_END
G1 X126.955 Y91.102 F9000
G1 X127.006 Y90.989
G1 X127.059 Y90.83
G1 X127.093 Y90.667
G1 X127.104 Y90.5
G1 X127.093 Y90.333
G1 X127.059 Y90.17
G1 X127.006 Y90.011
G1 X126.349 Y88.151
G1 X122.988 Y88.151
G1 X119.951 Y86.191
G1 X120.352 Y86.191
G1 E5 F2400
G1 F6000
G1 X120.3 Y86.067 E.00327
G1 X120.3 Y85.811 E.00623
G1 X110.7 Y85.811 E.23351
G1 X110.7 Y86.067 E.00623
G1 X110.645 Y86.197 E.00343
G1 X110.517 Y86.25 E.00337
G1 X105.183 Y86.25 E.12974
G1 X104.199 Y86.25 E.02393
G1 X103.606 Y86.207 E.01446
G1 X102.94 Y86.055 E.01662
G1 X102.077 Y85.673 E.02296
G1 X101.652 Y85.386 E.01247
G1 X101.092 Y84.872 E.01849
G1 X100.553 Y84.129 E.02233
G1 X100.312 Y83.637 E.01333
G1 X100.105 Y82.978 E.0168
G1 X100.013 Y82.369 E.01498
G1 X100 Y78.767 E.08762
G1 X99.478 Y78.155 E.01957
G1 X99.31 Y77.831 E.00888
G1 X99.247 Y77.475 E.00879
G1 X99.289 Y77.23 E.00605
G1 X99.478 Y76.845 E.01043
G1 X100 Y76.233 E.01957
G1 X100.002 Y75.905 E.00798
G1 X100.051 Y75.807 E.00267
G1 X100.183 Y75.751 E.00349
G1 X130.817 Y75.751 E.74514
G1 X130.949 Y75.807 E.00349
G1 X131 Y75.934 E.00333
G1 X131 Y76.233 E.00727
G1 X131.522 Y76.845 E.01957
G1 X131.69 Y77.169 E.00888
G1 X131.753 Y77.525 E.00879
G1 X131.711 Y77.77 E.00605
G1 X131.522 Y78.155 E.01043
G1 X131 Y78.767 E.01957
G1 X130.989 Y82.343 E.08698
G1 X130.824 Y83.25 E.02242
G1 X130.572 Y83.894 E.01682
G1 X130.26 Y84.429 E.01506
G1 X129.666 Y85.118 E.02213
G1 X129.183 Y85.507 E.01508
G1 X128.652 Y85.819 E.01498
G1 X128.159 Y86.016 E.01291
G1 X127.694 Y86.153 E.01179
G1 X127.118 Y86.238 E.01416
G1 X120.483 Y86.25 E.16139
G1 X120.403 Y86.217 E.0021
G1 X120.403 Y86.217 F9000
G1 X120.09 Y86.439
;TYPE:Perimeter
G1 F6000
G1 X119.98 Y86.177 E.00691
G1 X111.02 Y86.177 E.21794
G1 X110.902 Y86.458 E.00741
G1 X110.612 Y86.607 E.00793
G1 X110.517 Y86.616 E.00232
G1 X105.183 Y86.616 E.12974
G1 X104.199 Y86.616 E.02393
G1 X103.58 Y86.572 E.01509
G1 X102.858 Y86.412 E.01799
G1 X101.873 Y85.976 E.0262
G1 X101.447 Y85.689 E.01249
G1 X100.844 Y85.141 E.01982
G1 X100.256 Y84.343 E.02411
G1 X99.983 Y83.795 E.01489
G1 X99.756 Y83.086 E.01811
G1 X99.645 Y82.344 E.01825
G1 X99.635 Y78.902 E.08372
G1 X99.2 Y78.392 E.0163
G1 X98.963 Y77.951 E.01218
G1 X98.885 Y77.426 E.01291
G1 X98.959 Y77.074 E.00875
G1 X99.2 Y76.608 E.01276
G1 X99.634 Y76.099 E.01627
G1 X99.641 Y75.846 E.00616
G1 X99.788 Y75.553 E.00797
G1 X100.088 Y75.394 E.00826
G1 X130.817 Y75.385 E.74745
G1 X131.212 Y75.553 E.01044
G1 X131.359 Y75.846 E.00797
G1 X131.366 Y76.099 E.00616
G1 X131.8 Y76.608 E.01627
G1 X131.996 Y76.949 E.00957
G1 X132.109 Y77.39 E.01107
G1 X132.074 Y77.838 E.01093
G1 X131.8 Y78.392 E.01503
G1 X131.365 Y78.902 E.0163
G1 X131.355 Y82.344 E.08372
G1 X131.297 Y82.827 E.01183
G1 X131.181 Y83.332 E.0126
G1 X130.912 Y84.029 E.01817
G1 X130.576 Y84.614 E.01641
G1 X129.943 Y85.358 E.02376
G1 X129.411 Y85.793 E.01672
G1 X128.836 Y86.135 E.01627
G1 X128.264 Y86.366 E.01501
G1 X127.747 Y86.515 E.01309
G1 X127.171 Y86.599 E.01416
G1 X120.483 Y86.616 E.16268
G1 X120.134 Y86.473 E.00917
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X120.09 Y86.439 E-.02641
G1 X119.98 Y86.177 E-.13497
G1 X117.162 Y86.177 E-1.33862
;WIPE_END
G1 X120.134 Y74.207 F9000
G1 E5 F2400
G1 F6000
G1 X135.629 Y74.204 E.3769
G1 X136.198 Y74.243 E.01387
G1 X136.889 Y74.369 E.01709
G1 X137.43 Y74.534 E.01376
G1 X138.196 Y74.865 E.0203
G1 X138.792 Y75.226 E.01695
G1 X139.601 Y75.9 E.02561
G1 X140.273 Y76.706 E.02553
G1 X140.788 Y77.62 E.02552
G1 X141.131 Y78.612 E.02553
G1 X141.289 Y79.653 E.02561
G1 X141.289 Y80.035 E.00929
G1 X141.3 Y150.994 E1.72601
G1 X141.258 Y151.695 E.01708
G1 X141.133 Y152.38 E.01694
G1 X140.927 Y153.045 E.01693
G1 X140.643 Y153.681 E.01694
G1 X140.284 Y154.278 E.01694
G1 X139.857 Y154.828 E.01694
G1 X139.367 Y155.322 E.01692
G1 X138.76 Y155.796 E.01873
G1 X138.23 Y156.116 E.01506
G1 X137.229 Y156.536 E.0264
G1 X136.503 Y156.712 E.01817
G1 X135.836 Y156.79 E.01633
G1 X95.435 Y156.799 E.98271
G1 X94.774 Y156.754 E.01612
G1 X94.084 Y156.624 E.01708
G1 X93.457 Y156.428 E.01598
G1 X92.838 Y156.152 E.01649
G1 X92.179 Y155.754 E.01873
G1 X91.633 Y155.322 E.01694
G1 X91.143 Y154.828 E.01692
G1 X90.716 Y154.278 E.01694
G1 X90.358 Y153.683 E.01689
G1 X89.983 Y152.783 E.02372
G1 X89.794 Y152.039 E.01867
G1 X89.711 Y151.348 E.01693
G1 X89.7 Y80.006 E1.73532
G1 X89.743 Y79.301 E.01718
G1 X89.869 Y78.612 E.01704
G1 X90.077 Y77.943 E.01704
G1 X90.365 Y77.305 E.01703
G1 X90.727 Y76.705 E.01704
G1 X91.159 Y76.154 E.01703
G1 X91.654 Y75.659 E.01703
G1 X92.205 Y75.227 E.01703
G1 X92.803 Y74.866 E.01699
G1 X93.651 Y74.506 E.02241
G1 X94.456 Y74.295 E.02024
G1 X95.15 Y74.211 E.017
G1 X120.074 Y74.207 E.60625
G1 X120.074 Y74.207 F9000
G1 X120.074 Y74.572
;TYPE:Perimeter
G1 F6000
G1 X135.617 Y74.57 E.37807
G1 X136.153 Y74.606 E.01307
G1 X136.802 Y74.725 E.01605
G1 X137.304 Y74.877 E.01276
G1 X138.028 Y75.191 E.0192
G1 X138.58 Y75.524 E.01568
G1 X139.341 Y76.159 E.02411
G1 X139.971 Y76.914 E.02392
G1 X140.454 Y77.771 E.02393
G1 X140.774 Y78.7 E.0239
G1 X140.923 Y79.68 E.02411
G1 X140.923 Y80.035 E.00864
G1 X140.925 Y93.016 E.31575
;WIDTH:0.439128
G1 X140.906 Y93.099 E.00229
;WIDTH:0.478257
G1 X140.886 Y93.182 E.00252
;WIDTH:0.517386
G1 X140.867 Y93.264 E.0027
;WIDTH:0.556515
G1 X140.847 Y93.347 E.00297
G1 X140.852 Y93.531 E.00639
;WIDTH:0.547008
G1 X140.852 Y95.297 E.06023
;WIDTH:0.566483
G1 X140.843 Y95.644 E.01229
G1 X140.863 Y95.715 E.00261
;WIDTH:0.524865
G1 X140.884 Y95.786 E.00242
;WIDTH:0.483247
G1 X140.905 Y95.856 E.00218
;WIDTH:0.441629
G1 X140.926 Y95.927 E.00201
;WIDTH:0.40001
G1 X140.934 Y150.983 E1.33922
G1 X140.894 Y151.651 E.01628
G1 X140.777 Y152.293 E.01587
G1 X140.584 Y152.916 E.01586
G1 X140.318 Y153.512 E.01588
G1 X139.982 Y154.071 E.01586
G1 X139.582 Y154.586 E.01586
G1 X139.124 Y155.048 E.01582
G1 X138.552 Y155.494 E.01764
G1 X138.064 Y155.789 E.01387
G1 X137.114 Y156.187 E.02505
G1 X136.439 Y156.351 E.0169
G1 X135.815 Y156.424 E.01528
G1 X95.448 Y156.433 E.98192
G1 X94.82 Y156.391 E.01531
G1 X94.173 Y156.269 E.01602
G1 X93.587 Y156.085 E.01494
G1 X93.007 Y155.827 E.01544
G1 X92.388 Y155.453 E.01759
G1 X91.877 Y155.049 E.01585
G1 X91.418 Y154.586 E.01586
G1 X91.018 Y154.071 E.01586
G1 X90.686 Y153.517 E.01571
G1 X90.33 Y152.667 E.02242
G1 X90.154 Y151.972 E.01744
G1 X90.076 Y151.326 E.01583
G1 X90.068 Y95.737 E1.35219
;WIDTH:0.44021
G1 X90.088 Y95.695 E.00126
;WIDTH:0.480421
G1 X90.108 Y95.652 E.00141
;WIDTH:0.520632
G1 X90.128 Y95.61 E.0015
;WIDTH:0.560843
G1 X90.148 Y95.567 E.00166
G1 X90.145 Y95.413 E.00539
;WIDTH:0.554286
G1 X90.145 Y93.415 E.06911
;WIDTH:0.572659
G1 X90.154 Y93.16 E.00914
G1 X90.132 Y93.106 E.00209
;WIDTH:0.529494
G1 X90.111 Y93.052 E.00191
;WIDTH:0.486329
G1 X90.089 Y92.998 E.00175
;WIDTH:0.443164
G1 X90.068 Y92.944 E.00158
;WIDTH:0.399999
G1 X90.066 Y80.017 E.31444
G1 X90.106 Y79.345 E.01637
G1 X90.225 Y78.7 E.01595
G1 X90.42 Y78.073 E.01597
G1 X90.689 Y77.475 E.01595
G1 X91.028 Y76.914 E.01594
G1 X91.433 Y76.397 E.01597
G1 X91.897 Y75.933 E.01596
G1 X92.414 Y75.528 E.01597
G1 X92.97 Y75.192 E.0158
G1 X93.769 Y74.853 E.02111
G1 X94.524 Y74.655 E.01899
G1 X95.172 Y74.577 E.01588
G1 X120.014 Y74.572 E.60426
G1 E-5 F3600
G1 X120.014 Y74.572 F9000
G1 X120.014 Y74.549
G1 X139.115 Y75.92
G1 X140.951 Y80.008
G1 X140.951 Y95.766
G1 X140.56 Y95.766
G1 E5 F2400
G1 F6000
G1 X140.569 Y150.972 E1.34283
G1 X140.53 Y151.607 E.01547
G1 X140.421 Y152.206 E.01481
G1 X140.241 Y152.787 E.01479
G1 X139.993 Y153.342 E.01479
G1 X139.68 Y153.864 E.0148
G1 X139.307 Y154.344 E.01479
G1 X138.88 Y154.774 E.01474
G1 X138.345 Y155.193 E.01653
G1 X137.898 Y155.463 E.0127
G1 X137 Y155.839 E.02368
G1 X136.374 Y155.991 E.01567
G1 X135.794 Y156.059 E.0142
G1 X95.46 Y156.068 E.98108
G1 X94.867 Y156.027 E.01446
G1 X94.262 Y155.913 E.01497
G1 X93.716 Y155.743 E.01391
G1 X93.177 Y155.502 E.01436
G1 X92.597 Y155.152 E.01648
G1 X92.122 Y154.776 E.01474
G1 X91.693 Y154.344 E.01481
G1 X91.32 Y153.864 E.01479
G1 X91.013 Y153.352 E.01452
G1 X90.678 Y152.551 E.02112
G1 X90.515 Y151.905 E.01621
G1 X90.442 Y151.304 E.01473
G1 X90.435 Y95.737 E1.35161
G1 X90.548 Y96.033 E.00771
G1 X90.829 Y96.421 E.01165
G1 X91.049 Y96.599 E.00688
G1 X91.439 Y96.783 E.01049
G1 X91.799 Y96.838 E.00886
G1 X93.569 Y96.837 E.04305
G1 X93.571 Y132.81 E.87501
G1 X93.658 Y133.977 E.02846
G1 X93.91 Y135.304 E.03285
G1 X94.222 Y136.321 E.02588
G1 X94.423 Y136.836 E.01345
G1 X94.682 Y137.401 E.01512
G1 X95.333 Y138.552 E.03216
G1 X95.665 Y139.037 E.0143
G1 X96.033 Y139.514 E.01465
G1 X96.437 Y139.979 E.01498
G1 X96.986 Y140.538 E.01906
G1 X97.513 Y141.005 E.01713
G1 X98.165 Y141.507 E.02002
G1 X98.772 Y141.908 E.0177
G1 X99.885 Y142.507 E.03074
G1 X100.592 Y142.808 E.01869
G1 X101.253 Y143.037 E.01702
G1 X101.991 Y143.239 E.01861
G1 X103.282 Y143.475 E.03192
G1 X104.5 Y143.553 E.02969
G1 X105.742 Y143.552 E.03021
G1 X105.967 Y143.532 E.00549
G1 X110.517 Y143.532 E.11067
G1 X110.675 Y143.518 E.00386
G1 X110.996 Y143.396 E.00835
G1 X111.137 Y143.143 E.00705
G1 X119.863 Y143.143 E.21225
G1 X120.004 Y143.396 E.00705
G1 X120.19 Y143.483 E.00499
G1 X120.483 Y143.532 E.00723
G1 X126.764 Y143.549 E.15278
G1 X127.393 Y143.512 E.01533
G1 X127.969 Y143.442 E.01411
G1 X128.678 Y143.313 E.01753
G1 X129.32 Y143.161 E.01605
G1 X129.934 Y142.978 E.01558
G1 X130.744 Y142.663 E.02114
G1 X131.432 Y142.354 E.01835
G1 X132.395 Y141.803 E.02699
G1 X133.15 Y141.275 E.02241
G1 X133.917 Y140.629 E.02439
G1 X134.385 Y140.171 E.01593
G1 X134.792 Y139.72 E.01478
G1 X135.286 Y139.103 E.01923
G1 X135.631 Y138.61 E.01464
G1 X135.938 Y138.114 E.01419
G1 X136.214 Y137.611 E.01396
G1 X136.561 Y136.873 E.01984
G1 X136.804 Y136.245 E.01638
G1 X137.151 Y135.048 E.03031
G1 X137.281 Y134.399 E.0161
G1 X137.37 Y133.748 E.01598
G1 X137.429 Y132.81 E.02286
G1 X137.431 Y96.837 E.87501
G1 X139.202 Y96.838 E.04308
G1 X139.562 Y96.783 E.00886
G1 X139.954 Y96.597 E.01055
G1 X140.174 Y96.419 E.00688
G1 X140.423 Y96.103 E.00979
G1 X140.538 Y95.821 E.00741
G1 X140.538 Y95.821 F9000
G1 X140.195 Y96.873
G1 F6000
G1 X140.203 Y150.814 E1.31206
G1 X140.184 Y151.283 E.01142
G1 X140.116 Y151.843 E.01372
G1 X139.981 Y152.391 E.01373
G1 X139.782 Y152.919 E.01372
G1 X139.52 Y153.42 E.01375
G1 X139.199 Y153.887 E.01378
G1 X138.839 Y154.296 E.01325
G1 X138.304 Y154.76 E.01723
G1 X137.732 Y155.136 E.01665
G1 X136.885 Y155.49 E.02233
G1 X136.31 Y155.63 E.01439
G1 X135.772 Y155.693 E.01318
G1 X95.473 Y155.702 E.98023
G1 X94.913 Y155.664 E.01365
G1 X94.35 Y155.558 E.01394
G1 X93.845 Y155.4 E.01287
G1 X93.346 Y155.178 E.01328
G1 X92.805 Y154.851 E.01538
G1 X92.366 Y154.503 E.01363
G1 X91.969 Y154.102 E.01373
G1 X91.622 Y153.657 E.01373
G1 X91.34 Y153.186 E.01335
G1 X91.026 Y152.435 E.0198
G1 X90.875 Y151.838 E.01498
G1 X90.808 Y151.282 E.01362
G1 X90.8 Y96.867 E1.32359
G1 X91.366 Y97.141 E.0153
G1 X91.799 Y97.203 E.01064
G1 X93.203 Y97.203 E.03415
G1 X93.205 Y132.81 E.8661
G1 X93.298 Y134.044 E.0301
G1 X93.56 Y135.41 E.03383
G1 X93.881 Y136.453 E.02654
G1 X94.09 Y136.986 E.01393
G1 X94.363 Y137.581 E.01592
G1 X95.031 Y138.758 E.03292
G1 X95.375 Y139.259 E.01478
G1 X95.757 Y139.753 E.01519
G1 X96.175 Y140.234 E.0155
G1 X96.742 Y140.81 E.01966
G1 X97.289 Y141.295 E.01778
G1 X97.962 Y141.811 E.02063
G1 X98.599 Y142.23 E.01855
G1 X99.711 Y142.829 E.03072
G1 X100.471 Y143.154 E.02011
G1 X101.155 Y143.389 E.01759
G1 X101.923 Y143.598 E.01936
G1 X103.258 Y143.839 E.033
G1 X104.5 Y143.919 E.03027
G1 X105.742 Y143.918 E.03021
G1 X105.989 Y143.897 E.00603
G1 X110.517 Y143.897 E.11014
G1 X110.739 Y143.878 E.00542
G1 X111.187 Y143.708 E.01166
G1 X111.298 Y143.509 E.00554
G1 X119.702 Y143.509 E.20442
G1 X119.813 Y143.708 E.00554
G1 X120.073 Y143.83 E.00699
G1 X120.483 Y143.897 E.01011
G1 X126.765 Y143.915 E.1528
G1 X127.436 Y143.875 E.01635
G1 X128.034 Y143.802 E.01465
G1 X128.762 Y143.669 E.018
G1 X129.424 Y143.511 E.01655
G1 X130.057 Y143.322 E.01607
G1 X130.892 Y142.998 E.02179
G1 X131.613 Y142.671 E.01926
G1 X132.576 Y142.121 E.02698
G1 X133.384 Y141.555 E.024
G1 X134.172 Y140.891 E.02506
G1 X134.655 Y140.417 E.01646
G1 X135.077 Y139.949 E.01533
G1 X135.585 Y139.313 E.0198
G1 X135.941 Y138.803 E.01513
G1 X136.258 Y138.291 E.01465
G1 X136.544 Y137.768 E.0145
G1 X136.901 Y137.007 E.02045
G1 X137.155 Y136.346 E.01722
G1 X137.503 Y135.15 E.0303
G1 X137.644 Y134.449 E.01739
G1 X137.735 Y133.772 E.01662
G1 X137.795 Y132.81 E.02345
G1 X137.797 Y97.203 E.8661
G1 X139.202 Y97.203 E.03418
G1 X139.636 Y97.141 E.01066
G1 X140.141 Y96.899 E.01362
G1 X140.141 Y96.899 F9000
G1 X139.829 Y97.442
G1 F6000
G1 X139.837 Y150.814 E1.29822
G1 X139.819 Y151.261 E.01088
G1 X139.756 Y151.778 E.01267
G1 X139.632 Y152.283 E.01265
G1 X139.448 Y152.77 E.01266
G1 X139.207 Y153.231 E.01265
G1 X138.91 Y153.662 E.01273
G1 X138.58 Y154.039 E.01219
G1 X138.079 Y154.472 E.01611
G1 X137.566 Y154.809 E.01493
G1 X137.053 Y155.023 E.01352
G1 X136.473 Y155.214 E.01485
G1 X135.751 Y155.327 E.01778
G1 X95.485 Y155.336 E.97943
G1 X94.96 Y155.301 E.0128
G1 X94.439 Y155.202 E.0129
G1 X93.753 Y154.958 E.01771
G1 X93.24 Y154.687 E.01411
G1 X92.807 Y154.386 E.01283
G1 X92.418 Y154.036 E.01273
G1 X92.063 Y153.628 E.01315
G1 X91.667 Y153.021 E.01763
G1 X91.374 Y152.319 E.0185
G1 X91.235 Y151.771 E.01375
G1 X91.173 Y151.26 E.01252
G1 X91.165 Y97.439 E1.30914
G1 X91.292 Y97.499 E.00342
G1 X91.799 Y97.569 E.01245
G1 X92.837 Y97.569 E.02525
G1 X92.84 Y132.81 E.8572
G1 X92.939 Y134.11 E.03171
G1 X93.21 Y135.516 E.03483
G1 X93.54 Y136.585 E.02721
G1 X93.756 Y137.136 E.0144
G1 X94.044 Y137.76 E.01672
G1 X94.728 Y138.964 E.03368
G1 X95.085 Y139.482 E.0153
G1 X95.48 Y139.992 E.01569
G1 X95.914 Y140.489 E.01605
G1 X96.498 Y141.083 E.02026
G1 X97.065 Y141.584 E.0184
G1 X97.758 Y142.115 E.02124
G1 X98.425 Y142.552 E.0194
G1 X99.538 Y143.151 E.03074
G1 X100.351 Y143.499 E.02151
G1 X101.057 Y143.741 E.01815
G1 X101.856 Y143.957 E.02013
G1 X103.234 Y144.204 E.03405
G1 X104.5 Y144.285 E.03086
G1 X105.743 Y144.284 E.03023
G1 X106.011 Y144.263 E.00654
G1 X110.517 Y144.263 E.1096
G1 X110.874 Y144.224 E.00874
G1 X111.378 Y144.02 E.01323
G1 X111.46 Y143.874 E.00407
G1 X119.54 Y143.874 E.19654
G1 X119.622 Y144.02 E.00407
G1 X120.126 Y144.224 E.01323
G1 X120.483 Y144.263 E.00874
G1 X126.766 Y144.28 E.15283
G1 X127.478 Y144.238 E.01735
G1 X128.099 Y144.162 E.01522
G1 X128.846 Y144.025 E.01847
G1 X129.528 Y143.862 E.01706
G1 X130.18 Y143.666 E.01656
G1 X131.04 Y143.332 E.02244
G1 X131.795 Y142.989 E.02017
G1 X132.758 Y142.438 E.02699
G1 X133.619 Y141.835 E.02557
G1 X134.428 Y141.153 E.02574
G1 X134.926 Y140.662 E.01701
G1 X135.362 Y140.178 E.01585
G1 X135.884 Y139.523 E.02037
G1 X136.252 Y138.996 E.01563
G1 X136.578 Y138.468 E.01509
G1 X136.875 Y137.924 E.01508
G1 X137.242 Y137.141 E.02103
G1 X137.507 Y136.448 E.01805
G1 X137.854 Y135.252 E.03029
G1 X138.006 Y134.5 E.01866
G1 X138.099 Y133.796 E.01727
G1 X138.16 Y132.81 E.02403
G1 X138.163 Y97.569 E.8572
G1 X138.996 Y97.569 E.02026
G1 X139.533 Y97.535 E.01309
G1 X139.772 Y97.46 E.00609
G1 E-5 F3600
G1 X139.772 Y97.46 F9000
G1 X140.197 Y95.677
G1 X140.218 Y95.58
G1 X140.238 Y95.484
G1 X140.249 Y95.314
G1 X140.249 Y93.514
G1 X140.238 Y93.344
G1 X140.218 Y93.248
G1 X140.197 Y93.152
G1 X140.13 Y92.978
G1 X140.035 Y92.815
G1 X139.951 Y92.712
G1 X139.9 Y92.655
G1 X139.751 Y92.537
G1 X139.581 Y92.447
G1 X139.404 Y92.394
G1 X139.285 Y92.378
G1 X139.219 Y92.374
G1 X137.549 Y92.373
G1 X131.452 Y78.801
G1 X131.73 Y79.059
G1 E5 F2400
G1 F6000
G1 X131.73 Y79.037 E.00054
G1 X132.209 Y78.426 E.01888
G1 X132.444 Y77.857 E.01497
G1 X132.467 Y77.316 E.01317
G1 X132.319 Y76.778 E.01357
G1 X132.078 Y76.371 E.01151
G1 X131.751 Y75.987 E.01227
G1 X131.719 Y75.787 E.00493
G1 X131.475 Y75.299 E.01327
;WIDTH:0.441718
G1 X131.146 Y75.139 E.00991
;WIDTH:0.483436
G1 X130.817 Y74.978 E.01094
G1 X131.223 Y74.957 E.01215
;WIDTH:0.441718
G1 X131.63 Y74.936 E.01104
;WIDTH:0.399999
G1 X135.502 Y74.935 E.09418
G1 X135.921 Y74.957 E.01021
G1 X136.52 Y75.045 E.01473
G1 X137.178 Y75.221 E.01657
G1 X137.86 Y75.517 E.01808
G1 X138.367 Y75.823 E.0144
G1 X139.082 Y76.419 E.02264
G1 X139.668 Y77.123 E.02228
G1 X140.119 Y77.921 E.0223
G1 X140.418 Y78.788 E.02231
G1 X140.509 Y79.385 E.01469
G1 X140.558 Y80.035 E.01586
G1 X140.56 Y93.096 E.3177
G1 X140.347 Y92.617 E.01275
G1 X140.158 Y92.394 E.00711
G1 X139.73 Y92.111 E.01248
G1 X139.202 Y91.991 E.01317
G1 X126.769 Y91.992 E.30242
G1 X127.209 Y91.426 E.01744
G1 X127.451 Y90.816 E.01596
G1 X127.467 Y90.316 E.01217
G1 X127.345 Y89.832 E.01214
G1 X127.08 Y89.373 E.01289
G1 X126.731 Y88.964 E.01308
G1 X126.708 Y88.477 E.01186
G1 X126.536 Y88.118 E.00968
G1 X126.237 Y87.871 E.00943
G1 X125.817 Y87.769 E.01051
G1 X105.183 Y87.769 E.5019
G1 X105.025 Y87.782 E.00386
G1 X104.532 Y88.041 E.01355
G1 X104.304 Y88.43 E.01097
G1 X104.269 Y88.964 E.01302
G1 X103.922 Y89.371 E.01301
G1 X103.725 Y89.712 E.00958
G1 X103.549 Y90.184 E.01225
G1 X103.533 Y90.684 E.01217
G1 X103.593 Y90.978 E.0073
G1 X103.81 Y91.464 E.01295
G1 X104.231 Y91.992 E.01643
G1 X91.798 Y91.991 E.30242
G1 X91.438 Y92.046 E.00886
G1 X90.967 Y92.277 E.01276
G1 X90.602 Y92.685 E.01332
G1 X90.433 Y93.089 E.01065
G1 X90.431 Y80.028 E.3177
G1 X90.47 Y79.389 E.01557
G1 X90.58 Y78.787 E.01489
G1 X90.762 Y78.203 E.01488
G1 X91.013 Y77.645 E.01488
G1 X91.33 Y77.122 E.01488
G1 X91.707 Y76.64 E.01488
G1 X92.14 Y76.207 E.01489
G1 X92.622 Y75.83 E.01488
G1 X93.137 Y75.518 E.01465
G1 X93.888 Y75.2 E.01984
G1 X94.593 Y75.015 E.01773
G1 X95.194 Y74.942 E.01473
G1 X99.372 Y74.942 E.10163
;WIDTH:0.446358
G1 X99.694 Y74.965 E.00885
;WIDTH:0.492716
G1 X100.017 Y74.988 E.00987
G1 X99.771 Y75.144 E.00888
;WIDTH:0.446358
G1 X99.524 Y75.3 E.00801
;WIDTH:0.399999
G1 X99.281 Y75.787 E.01324
G1 X99.269 Y75.934 E.00359
G1 X98.791 Y76.574 E.01943
G1 X98.549 Y77.184 E.01596
G1 X98.532 Y77.678 E.01202
G1 X98.653 Y78.165 E.01221
G1 X98.922 Y78.629 E.01305
G1 X99.27 Y79.037 E.01304
G1 X99.279 Y82.345 E.08046
G1 X99.407 Y83.195 E.02091
G1 X99.653 Y83.954 E.01941
G1 X99.959 Y84.556 E.01643
G1 X100.596 Y85.41 E.02591
G1 X101.243 Y85.992 E.02117
G1 X101.668 Y86.279 E.01247
G1 X102.017 Y86.45 E.00945
G1 X102.775 Y86.768 E.01999
G1 X103.553 Y86.937 E.01937
G1 X104.199 Y86.981 E.01575
G1 X110.517 Y86.981 E.15368
G1 X110.675 Y86.968 E.00386
G1 X111.158 Y86.719 E.01322
G1 X111.232 Y86.543 E.00464
G1 X119.768 Y86.543 E.20763
G1 X119.842 Y86.719 E.00464
G1 X120.483 Y86.981 E.01684
G1 X127.224 Y86.961 E.16397
G1 X127.93 Y86.848 E.01739
G1 X128.53 Y86.667 E.01524
G1 X129.02 Y86.451 E.01303
G1 X129.639 Y86.079 E.01757
G1 X130.219 Y85.597 E.01834
G1 X130.891 Y84.799 E.02538
G1 X131.252 Y84.163 E.01779
G1 X131.537 Y83.414 E.01949
G1 X131.663 Y82.861 E.0138
G1 X131.721 Y82.345 E.01263
G1 X131.73 Y79.119 E.07847
G1 E-5 F3600
G1 X131.73 Y79.119 F9000
G1 X131.349 Y79.119
G1 X131.349 Y82.06
G1 X131.346 Y82.136
G1 X131.337 Y82.379
G1 X131.328 Y82.468
G1 X131.301 Y82.709
G1 X131.285 Y82.798
G1 X131.24 Y83.035
G1 X131.219 Y83.125
G1 X131.156 Y83.358
G1 X131.128 Y83.447
G1 X131.048 Y83.674
G1 X131.014 Y83.762
G1 X130.917 Y83.982
G1 X130.876 Y84.067
G1 X130.764 Y84.279
G1 X130.717 Y84.361
G1 X130.59 Y84.563
G1 X130.538 Y84.642
G1 X130.396 Y84.833
G1 X130.339 Y84.907
G1 X130.184 Y85.087
G1 X130.122 Y85.157
G1 X129.954 Y85.325
G1 X129.888 Y85.39
G1 X129.708 Y85.545
G1 X129.637 Y85.605
G1 X129.562 Y85.662
G1 X129.371 Y85.802
G1 X129.29 Y85.854
G1 X129.09 Y85.98
G1 X129.005 Y86.027
G1 X128.795 Y86.138
G1 X128.711 Y86.177
G1 X128.495 Y86.271
G1 X128.408 Y86.304
G1 X128.185 Y86.382
G1 X128.096 Y86.41
G1 X127.868 Y86.471
G1 X127.778 Y86.492
G1 X127.546 Y86.536
G1 X127.455 Y86.551
G1 X127.22 Y86.578
G1 X127.128 Y86.587
G1 X126.892 Y86.596
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X105.183 Y87.375 E.0067
;WIDTH:0.456022
G1 X110.517 Y87.375 E.14962
;WIDTH:0.475838
G1 X110.745 Y87.365 E.0067
G1 X111.437 Y87.002 E.02295
;WIDTH:0.464516
G1 X111.463 Y86.941 E.0019
G1 X119.537 Y86.941 E.23104
G1 X119.562 Y87.002 E.00189
G1 X120.483 Y87.375 E.02843
G1 X111.588 Y87.371 E.25454
;WIDTH:0.475838
G1 X110.805 Y87.365 E.023
G1 E-5 F3600
G1 X110.805 Y87.365 F9000
G1 X125.817 Y87.371
G1 E5 F2400
;WIDTH:0.464534
G1 F6000
G1 X120.483 Y87.375 E.15264
G1 E-5 F3600
G1 X120.483 Y87.375 F9000
G1 X125.817 Y87.371
G1 E5 F2400
G1 F6000
G1 X126.136 Y87.354 E.00914
;WIDTH:0.432267
G1 X126.455 Y87.337 E.00846
;WIDTH:0.399999
G1 X127.277 Y87.323 E.02
G1 X128.035 Y87.198 E.01869
G1 X128.731 Y86.981 E.01773
G1 X129.204 Y86.767 E.01263
G1 X129.867 Y86.365 E.01886
G1 X130.495 Y85.837 E.01996
G1 X131.206 Y84.985 E.02699
G1 X131.592 Y84.297 E.01919
G1 X131.893 Y83.496 E.02081
G1 X132.033 Y82.859 E.01586
G1 X132.086 Y82.346 E.01254
G1 X132.096 Y79.173 E.07718
G1 X132.526 Y78.612 E.01719
G1 X132.702 Y78.239 E.01003
G1 X132.818 Y77.831 E.01032
G1 X132.825 Y77.243 E.0143
G1 X132.765 Y76.949 E.0073
G1 X132.513 Y76.364 E.01549
G1 X132.088 Y75.818 E.01683
G1 X132.08 Y75.728 E.0022
G1 X131.867 Y75.302 E.01159
G1 X135.502 Y75.301 E.08842
G1 X135.897 Y75.322 E.00962
G1 X136.454 Y75.405 E.0137
G1 X137.051 Y75.565 E.01503
G1 X137.692 Y75.842 E.01699
G1 X138.154 Y76.122 E.01314
G1 X138.822 Y76.678 E.02114
G1 X139.366 Y77.332 E.02069
G1 X139.784 Y78.072 E.02067
G1 X140.061 Y78.876 E.02068
G1 X140.147 Y79.44 E.01388
G1 X140.192 Y80.035 E.01451
G1 X140.194 Y91.997 E.29096
G1 X139.837 Y91.762 E.0104
G1 X139.202 Y91.625 E.0158
G1 X127.512 Y91.626 E.28435
G1 X127.702 Y91.239 E.01049
G1 X127.813 Y90.865 E.00949
G1 X127.825 Y90.243 E.01513
G1 X127.736 Y89.836 E.01013
G1 X127.513 Y89.364 E.0127
G1 X127.097 Y88.829 E.01648
G1 X127.087 Y88.519 E.00754
G1 X126.927 Y88.045 E.01217
G1 X126.824 Y87.892 E.00449
G1 X126.405 Y87.546 E.01322
;WIDTH:0.432267
G1 X126.111 Y87.458 E.00812
;WIDTH:0.464534
G1 X125.875 Y87.388 E.00704
G1 X125.875 Y87.388 F9000
G1 X127.133 Y87.699
;WIDTH:0.399999
G1 F6000
G1 X127.33 Y87.685 E.0048
G1 X128.14 Y87.549 E.01998
G1 X128.876 Y87.317 E.01877
G1 X129.388 Y87.083 E.01369
G1 X130.095 Y86.651 E.02015
G1 X130.771 Y86.077 E.02157
G1 X131.521 Y85.17 E.02863
G1 X131.933 Y84.431 E.02058
G1 X132.25 Y83.578 E.02213
G1 X132.396 Y82.903 E.0168
G1 X132.452 Y82.347 E.01359
G1 X132.461 Y79.308 E.07392
G1 X132.635 Y79.103 E.00654
G1 X132.871 Y78.739 E.01055
G1 X133.104 Y78.22 E.01384
G1 X133.205 Y77.7 E.01288
G1 X133.183 Y77.17 E.0129
G1 X133.123 Y76.876 E.0073
G1 X132.836 Y76.193 E.01802
G1 X132.443 Y75.669 E.01593
G1 X135.502 Y75.667 E.07441
G1 X136.193 Y75.728 E.01687
G1 X136.771 Y75.862 E.01443
G1 X137.333 Y76.085 E.01471
G1 X137.941 Y76.42 E.01689
G1 X138.562 Y76.938 E.01967
G1 X139.064 Y77.54 E.01907
G1 X139.449 Y78.223 E.01907
G1 X139.705 Y78.964 E.01907
G1 X139.786 Y79.495 E.01307
G1 X139.826 Y80.035 E.01317
G1 X139.828 Y91.376 E.27586
G1 X139.202 Y91.26 E.01549
G1 X128.073 Y91.26 E.2707
G1 X128.202 Y90.722 E.01346
G1 X128.183 Y90.17 E.01343
G1 X128.074 Y89.693 E.0119
G1 X127.836 Y89.193 E.01347
G1 X127.47 Y88.703 E.01488
G1 X127.449 Y88.473 E.00562
G1 X127.244 Y87.862 E.01568
G1 X127.167 Y87.749 E.00333
G1 E-5 F3600
G1 X103.872 Y86.587 F9000
G1 X103.78 Y86.578
G1 X103.545 Y86.551
G1 X103.454 Y86.536
G1 X103.222 Y86.492
G1 X103.132 Y86.471
G1 X102.904 Y86.41
G1 X102.815 Y86.382
G1 X102.592 Y86.304
G1 X102.505 Y86.271
G1 X102.289 Y86.177
G1 X102.205 Y86.138
G1 X101.995 Y86.027
G1 X101.91 Y85.98
G1 X101.71 Y85.854
G1 X101.629 Y85.802
G1 X101.438 Y85.662
G1 X101.363 Y85.605
G1 X101.292 Y85.545
G1 X101.112 Y85.39
G1 X101.046 Y85.325
G1 X100.878 Y85.157
G1 X100.816 Y85.087
G1 X100.661 Y84.907
G1 X100.604 Y84.833
G1 X100.462 Y84.642
G1 X100.41 Y84.563
G1 X100.283 Y84.361
G1 X100.236 Y84.279
G1 X100.124 Y84.067
G1 X100.083 Y83.982
G1 X99.986 Y83.762
G1 X99.952 Y83.674
G1 X99.872 Y83.447
G1 X99.844 Y83.358
G1 X99.781 Y83.125
G1 X99.76 Y83.035
G1 X99.715 Y82.798
G1 X99.699 Y82.709
G1 X98.907 Y77.667
G1 X98.896 Y77.5
G1 X98.907 Y77.333
G1 X98.941 Y77.17
G1 X98.994 Y77.011
G1 X99.651 Y75.403
G1 X100.017 Y75.403
G1 X100.017 Y74.988
G1 E5 F2400
;WIDTH:0.492716
G1 F6000
G1 X100.183 Y74.981 E.00507
;WIDTH:0.483436
G1 X130.817 Y74.978 E.91517
G1 E-5 F3600
G1 X130.817 Y74.978 F9000
G1 X130.817 Y75.402
G1 X131.349 Y75.403
G1 X132.006 Y77.011
G1 X132.059 Y77.17
G1 X132.093 Y77.333
G1 X132.104 Y77.5
G1 X132.093 Y77.667
G1 X131.301 Y82.709
G1 X131.285 Y82.798
G1 X131.24 Y83.035
G1 X131.219 Y83.125
G1 X131.156 Y83.358
G1 X131.128 Y83.447
G1 X131.048 Y83.674
G1 X131.014 Y83.762
G1 X130.917 Y83.982
G1 X130.876 Y84.067
G1 X130.764 Y84.279
G1 X130.717 Y84.361
G1 X130.59 Y84.563
G1 X130.538 Y84.642
G1 X130.396 Y84.833
G1 X130.339 Y84.907
G1 X130.184 Y85.087
G1 X130.122 Y85.157
G1 X129.954 Y85.325
G1 X129.888 Y85.39
G1 X129.708 Y85.545
G1 X129.637 Y85.605
G1 X129.562 Y85.662
G1 X129.371 Y85.802
G1 X129.29 Y85.854
G1 X129.09 Y85.98
G1 X129.005 Y86.027
G1 X128.795 Y86.138
G1 X128.711 Y86.177
G1 X128.495 Y86.271
G1 X128.408 Y86.304
G1 X128.185 Y86.382
G1 X128.096 Y86.41
G1 X127.868 Y86.471
G1 X127.778 Y86.492
G1 X127.546 Y86.536
G1 X127.455 Y86.551
G1 X127.22 Y86.578
G1 X127.128 Y86.587
G1 X126.892 Y86.596
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X104.647 Y87.552 E.01029
;WIDTH:0.43792
G1 X104.34 Y87.72 E.0094
;WIDTH:0.399999
G1 X104.022 Y88.144 E.01289
G1 X103.953 Y88.329 E.0048
G1 X103.903 Y88.829 E.01222
G1 X103.548 Y89.261 E.0136
G1 X103.298 Y89.761 E.0136
G1 X103.187 Y90.135 E.00949
G1 X103.175 Y90.757 E.01513
G1 X103.235 Y91.051 E.0073
G1 X103.481 Y91.626 E.01521
G1 X91.798 Y91.625 E.28418
G1 X91.365 Y91.688 E.01064
G1 X90.799 Y91.95 E.01517
G1 X90.797 Y80.039 E.28972
G1 X90.834 Y79.433 E.01477
G1 X90.936 Y78.875 E.0138
G1 X91.105 Y78.333 E.01381
G1 X91.338 Y77.816 E.01379
G1 X91.631 Y77.33 E.0138
G1 X91.982 Y76.883 E.01382
G1 X92.383 Y76.482 E.01379
G1 X92.83 Y76.131 E.01382
G1 X93.304 Y75.845 E.01347
G1 X94.006 Y75.547 E.01855
G1 X94.662 Y75.375 E.0165
G1 X95.216 Y75.308 E.01357
G1 X99.13 Y75.307 E.0952
G1 X98.92 Y75.729 E.01147
G1 X98.912 Y75.818 E.00217
G1 X98.643 Y76.134 E.01009
G1 X98.298 Y76.761 E.01741
G1 X98.187 Y77.135 E.00949
G1 X98.163 Y77.693 E.01359
G1 X98.263 Y78.161 E.01164
G1 X98.487 Y78.636 E.01277
G1 X98.904 Y79.173 E.01654
G1 X98.927 Y82.529 E.08163
G1 X99.057 Y83.304 E.01911
G1 X99.324 Y84.113 E.02072
G1 X99.662 Y84.77 E.01797
G1 X100.348 Y85.678 E.02768
G1 X101.038 Y86.295 E.02252
G1 X101.661 Y86.692 E.01797
G1 X102.462 Y87.047 E.02131
G1 X102.994 Y87.194 E.01343
G1 X103.526 Y87.301 E.0132
G1 X104.199 Y87.347 E.01641
;WIDTH:0.43792
G1 X104.577 Y87.366 E.01016
;WIDTH:0.47584
G1 X104.895 Y87.382 E.00935
G1 X104.895 Y87.382 F9000
G1 X103.895 Y87.695
;WIDTH:0.399999
G1 F6000
G1 X103.69 Y87.99 E.00874
G1 X103.602 Y88.228 E.00617
G1 X103.537 Y88.683 E.01118
G1 X103.365 Y88.897 E.00668
G1 X103.129 Y89.261 E.01055
G1 X102.895 Y89.785 E.01396
G1 X102.798 Y90.278 E.01222
G1 X102.817 Y90.83 E.01343
G1 X102.926 Y91.26 E.01079
G1 X91.798 Y91.26 E.27068
G1 X91.467 Y91.293 E.00809
G1 X91.164 Y91.382 E.00768
G1 X91.163 Y80.05 E.27564
G1 X91.197 Y79.478 E.01394
G1 X91.292 Y78.963 E.01274
G1 X91.447 Y78.463 E.01273
G1 X91.662 Y77.986 E.01273
G1 X91.933 Y77.538 E.01274
G1 X92.256 Y77.126 E.01273
G1 X92.626 Y76.756 E.01273
G1 X93.038 Y76.433 E.01273
G1 X93.471 Y76.171 E.01231
G1 X94.124 Y75.894 E.01725
G1 X94.73 Y75.735 E.01524
G1 X95.238 Y75.674 E.01245
G1 X98.556 Y75.673 E.08071
G1 X98.129 Y76.261 E.01768
G1 X97.967 Y76.605 E.00925
G1 X97.798 Y77.278 E.01688
G1 X97.817 Y77.83 E.01343
G1 X97.937 Y78.341 E.01277
G1 X98.164 Y78.807 E.01261
G1 X98.539 Y79.308 E.01522
G1 X98.548 Y82.347 E.07392
G1 X98.566 Y82.583 E.00576
G1 X98.708 Y83.413 E.02048
G1 X98.995 Y84.272 E.02203
G1 X99.366 Y84.984 E.01953
G1 X100.1 Y85.947 E.02945
G1 X100.833 Y86.598 E.02385
G1 X101.512 Y87.026 E.01952
G1 X102.106 Y87.289 E.0158
G1 X102.61 Y87.481 E.01312
G1 X103.249 Y87.628 E.01595
G1 X103.835 Y87.689 E.01433
G1 E-5 F3600
G1 X103.835 Y87.689 F9000
G1 X102.031 Y91.151
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X102.539 Y90.643 E.01747
G1 X102.553 Y90.108 E.01302
G1 X101.675 Y90.986 E.0302
G1 X101.155 Y90.986 E.01265
G1 X102.795 Y89.345 E.05643
G1 X102.94 Y89.03 E.00843
G1 X103.269 Y88.586 E.01344
G1 X103.303 Y88.317 E.0066
G1 X100.635 Y90.986 E.09179
G1 X100.114 Y90.986 E.01267
G1 X103.202 Y87.898 E.10623
G1 X102.779 Y87.801 E.01056
G1 X99.594 Y90.986 E.10956
G1 X99.074 Y90.986 E.01265
G1 X102.367 Y87.692 E.11329
G1 X101.999 Y87.54 E.00968
G1 X98.554 Y90.986 E.11852
G1 X98.034 Y90.986 E.01265
G1 X101.638 Y87.381 E.12399
G1 X101.286 Y87.213 E.00949
G1 X97.513 Y90.986 E.12979
G1 X96.993 Y90.986 E.01265
G1 X100.963 Y87.016 E.13657
G1 X100.654 Y86.805 E.0091
G1 X96.473 Y90.986 E.14382
G1 X95.953 Y90.986 E.01265
G1 X100.37 Y86.569 E.15194
G1 X100.099 Y86.319 E.00897
G1 X95.433 Y90.986 E.16052
G1 X94.912 Y90.986 E.01267
G1 X99.837 Y86.061 E.16942
G1 X99.6 Y85.777 E.009
G1 X94.392 Y90.985 E.17915
G1 X93.872 Y90.985 E.01265
G1 X99.386 Y85.472 E.18966
G1 X99.171 Y85.166 E.0091
G1 X93.352 Y90.985 E.20017
G1 X92.832 Y90.985 E.01265
G1 X98.97 Y84.847 E.21114
G1 X98.8 Y84.497 E.00946
G1 X92.311 Y90.985 E.2232
G1 X91.791 Y90.986 E.01265
G1 X98.645 Y84.131 E.23579
G1 X98.521 Y83.735 E.01009
G1 X91.439 Y90.818 E.24363
G1 X91.438 Y90.298 E.01265
G1 X98.406 Y83.33 E.2397
G1 X98.333 Y82.883 E.01102
G1 X91.438 Y89.778 E.23718
G1 X91.438 Y89.257 E.01267
G1 X98.279 Y82.417 E.23531
G1 X98.273 Y81.903 E.0125
G1 X91.438 Y88.737 E.2351
G1 X91.438 Y88.217 E.01265
G1 X98.271 Y81.384 E.23505
G1 X98.269 Y80.866 E.0126
G1 X91.438 Y87.697 E.23498
G1 X91.438 Y87.177 E.01265
G1 X98.268 Y80.347 E.23495
G1 X98.266 Y79.828 E.01262
G1 X91.438 Y86.657 E.2349
G1 X91.438 Y86.136 E.01267
G1 X98.219 Y79.355 E.23326
G1 X98.001 Y79.053 E.00906
G1 X91.438 Y85.616 E.22576
G1 X91.438 Y85.096 E.01265
G1 X97.811 Y78.723 E.21923
G1 X97.657 Y78.356 E.00968
G1 X91.438 Y84.576 E.21395
G1 X91.438 Y84.056 E.01265
G1 X97.56 Y77.933 E.21061
G1 X97.527 Y77.446 E.01187
G1 X91.437 Y83.536 E.20949
G1 X91.437 Y83.016 E.01265
G1 X97.614 Y76.839 E.21249
G1 X97.716 Y76.494 E.00875
G1 X98.008 Y75.947 E.01508
G1 X91.437 Y82.495 E.22564
G1 X91.437 Y81.975 E.01265
G1 X97.465 Y75.947 E.20736
G1 X96.945 Y75.948 E.01265
G1 X91.437 Y81.455 E.18945
G1 X91.437 Y80.935 E.01265
G1 X96.424 Y75.948 E.17155
G1 X95.904 Y75.948 E.01265
G1 X91.437 Y80.415 E.15366
G1 X91.447 Y79.884 E.01292
G1 X95.384 Y75.948 E.13541
G1 X94.809 Y76.002 E.01405
G1 X91.508 Y79.303 E.11355
G1 X91.692 Y78.599 E.0177
G1 X94.081 Y76.21 E.08218
G1 X93.194 Y76.659 E.02418
G1 X92.815 Y76.956 E.01171
G1 X91.798 Y77.973 E.03498
G1 E-5 F3600
G1 X91.798 Y77.973 F9000
G1 X90.756 Y93.444
G1 X90.751 Y93.514
G1 X90.751 Y95.314
G1 X90.763 Y95.484
G1 X91.275 Y98.393
G1 E5 F2400
G1 F3072.127
G1 X91.825 Y97.843 E.01892
G1 X92.363 Y97.843 E.01309
G1 X91.44 Y98.766 E.03175
G1 X91.44 Y99.303 E.01306
G1 X92.563 Y98.18 E.03863
G1 X92.563 Y98.718 E.01309
G1 X91.44 Y99.841 E.03863
G1 X91.44 Y100.378 E.01306
G1 X92.563 Y99.255 E.03863
G1 X92.563 Y99.793 E.01309
G1 X91.44 Y100.916 E.03863
G1 X91.44 Y101.313 E.00966
G1 X91.603 Y101.291 E.004
G1 X92.563 Y100.33 E.03304
G1 X92.563 Y100.868 E.01309
G1 X91.999 Y101.433 E.01942
G1 X91.999 Y101.433 F9000
G1 X91.784 Y101.635
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X92.563 Y101.633 E.01895
G1 X92.564 Y106.367 E.11515
G1 X92.001 Y106.366 E.01369
G1 X91.441 Y106.304 E.0137
G1 X91.44 Y101.698 E.11204
G1 X91.604 Y101.668 E.00406
G1 X92.008 Y102.01 E.01288
;WIDTH:0.413117
G1 X91.812 Y102.014 E.00494
G1 X91.813 Y105.987 E.10011
;WIDTH:0.412947
G1 X92.192 Y105.994 E.00955
G1 X92.192 Y105.804 E.00479
;WIDTH:0.413117
G1 X92.191 Y102.006 E.0957
G1 E-5 F3600
G1 X92.191 Y102.006 F9000
G1 X91.276 Y107.283
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X91.828 Y106.732 E.01897
G1 X92.393 Y106.732 E.01374
G1 X91.441 Y107.685 E.03277
G1 X91.441 Y108.25 E.01374
G1 X92.564 Y107.128 E.03861
G1 X92.564 Y107.694 E.01377
G1 X91.441 Y108.816 E.03861
G1 X91.441 Y109.313 E.01209
G1 X91.521 Y109.302 E.00196
G1 X92.564 Y108.26 E.03586
G1 X92.564 Y108.825 E.01374
G1 X91.957 Y109.433 E.0209
G1 X91.957 Y109.433 F9000
G1 X91.784 Y109.635
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X92.564 Y109.633 E.01897
G1 X92.564 Y114.367 E.11515
G1 X92.002 Y114.366 E.01367
G1 X91.442 Y114.305 E.0137
G1 X91.441 Y109.698 E.11206
G1 X91.604 Y109.668 E.00403
G1 X92.009 Y110.009 E.01288
;WIDTH:0.412747
G1 X91.813 Y110.013 E.00493
G1 X91.814 Y113.988 E.10006
;WIDTH:0.412578
G1 X92.192 Y113.994 E.00951
G1 X92.192 Y113.805 E.00476
;WIDTH:0.412747
G1 X92.192 Y110.006 E.09563
G1 E-5 F3600
G1 X92.192 Y110.006 F9000
G1 X91.278 Y115.283
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X91.829 Y114.732 E.01895
G1 X92.395 Y114.732 E.01377
G1 X91.442 Y115.685 E.03278
G1 X91.442 Y116.25 E.01374
G1 X92.564 Y115.128 E.0386
G1 X92.564 Y115.694 E.01377
G1 X91.442 Y116.816 E.0386
G1 X91.443 Y117.313 E.01209
G1 X91.523 Y117.302 E.00196
G1 X92.564 Y116.26 E.03583
G1 X92.564 Y116.826 E.01377
G1 X91.957 Y117.433 E.02088
G1 X91.957 Y117.433 F9000
G1 X91.784 Y117.635
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X92.564 Y117.633 E.01897
G1 X92.565 Y122.367 E.11515
G1 X92.003 Y122.366 E.01367
G1 X91.443 Y122.305 E.0137
G1 X91.443 Y117.698 E.11206
G1 X91.604 Y117.668 E.00398
G1 X92.01 Y118.009 E.0129
;WIDTH:0.412377
G1 X91.819 Y118.011 E.0048
G1 X91.815 Y121.805 E.09541
;WIDTH:0.412208
G1 X91.819 Y121.99 E.00465
G1 X92.193 Y121.994 E.0094
G1 X92.193 Y121.805 E.00475
;WIDTH:0.412377
G1 X92.193 Y118.006 E.09553
G1 E-5 F3600
G1 X92.193 Y118.006 F9000
G1 X91.279 Y123.283
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X91.831 Y122.732 E.01897
G1 X92.396 Y122.732 E.01374
G1 X91.444 Y123.685 E.03277
G1 X91.444 Y124.25 E.01374
G1 X92.565 Y123.129 E.03856
G1 X92.565 Y123.695 E.01377
G1 X91.444 Y124.816 E.03856
G1 X91.444 Y125.313 E.01209
G1 X91.524 Y125.302 E.00196
G1 X92.565 Y124.26 E.03583
G1 X92.565 Y124.826 E.01377
G1 X91.958 Y125.433 E.02088
G1 X91.958 Y125.433 F9000
G1 X91.784 Y125.635
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X92.565 Y125.633 E.019
G1 X92.565 Y130.367 E.11515
G1 X92.004 Y130.366 E.01365
G1 X91.445 Y130.305 E.01368
G1 X91.444 Y125.697 E.11208
G1 X91.604 Y125.668 E.00396
G1 X92.01 Y126.008 E.01288
;WIDTH:0.412008
G1 X91.819 Y126.01 E.0048
G1 X91.816 Y129.806 E.09537
;WIDTH:0.41184
G1 X91.819 Y129.991 E.00465
G1 X92.194 Y129.995 E.00942
G1 X92.194 Y129.806 E.00475
;WIDTH:0.412008
G1 X92.193 Y126.006 E.09547
G1 E-5 F3600
G1 X92.193 Y126.006 F9000
G1 X91.28 Y131.29
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X91.839 Y130.732 E.01921
G1 X92.408 Y130.733 E.01384
G1 X91.445 Y131.696 E.03313
G1 X91.445 Y132.266 E.01386
G1 X92.565 Y131.145 E.03854
G1 X92.565 Y131.715 E.01386
G1 X91.445 Y132.836 E.03854
G1 X91.445 Y133.312 E.01158
G1 X91.553 Y133.297 E.00265
G1 X92.565 Y132.286 E.03479
G1 X92.568 Y132.853 E.01379
G1 X91.988 Y133.433 E.01995
G1 X91.988 Y133.433 F9000
G1 X91.785 Y133.635
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X92.621 Y133.633 E.02033
G1 X92.644 Y133.962 E.00802
G1 X92.896 Y135.382 E.03508
G1 X93.281 Y136.674 E.03279
G1 X93.508 Y137.252 E.0151
G1 X93.807 Y137.898 E.01731
G1 X94.072 Y138.368 E.01312
G1 X91.819 Y138.366 E.0548
G1 X91.446 Y138.306 E.00919
G1 X91.445 Y133.697 E.11211
G1 X91.605 Y133.668 E.00396
G1 X92.07 Y134.004 E.01395
G1 X91.811 Y134.009 E.0063
G1 X91.811 Y137.999 E.09705
G1 X93.452 Y138.002 E.03992
G1 X93.176 Y137.406 E.01598
G1 X92.93 Y136.779 E.01638
G1 X92.551 Y135.507 E.03228
G1 X92.284 Y134.025 E.03663
G1 X92.253 Y134 E.00097
G1 X92.253 Y134 F9000
G1 X92.226 Y135.872
;WIDTH:0.498868
G1 F1200
G1 X92.533 Y136.898 E.03309
G1 X92.795 Y137.582 E.02263
G1 X92.226 Y137.585 E.01758
G1 X92.226 Y136.055 E.04728
G1 E-5 F3600
G1 X92.226 Y136.055 F9000
G1 X91.281 Y139.233
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X91.783 Y138.732 E.01725
G1 X92.314 Y138.732 E.01292
G1 X91.446 Y139.6 E.02986
G1 X91.446 Y140.132 E.01294
G1 X92.846 Y138.733 E.04814
G1 X93.377 Y138.733 E.01292
G1 X91.446 Y140.664 E.06643
G1 X91.446 Y141.195 E.01292
G1 X93.908 Y138.734 E.08467
G1 X94.278 Y138.734 E.009
G1 X94.336 Y138.838 E.0029
G1 X91.905 Y141.268 E.08361
G1 X92.437 Y141.268 E.01294
G1 X94.54 Y139.165 E.07234
G1 X94.753 Y139.484 E.00933
G1 X92.969 Y141.268 E.06137
G1 X93.501 Y141.268 E.01294
G1 X94.978 Y139.791 E.05081
G1 X95.208 Y140.092 E.00921
G1 X94.033 Y141.268 E.04044
G1 X94.565 Y141.267 E.01294
G1 X95.453 Y140.379 E.03055
G1 X95.703 Y140.661 E.00917
G1 X95.097 Y141.267 E.02085
G1 X95.629 Y141.267 E.01294
G1 X95.966 Y140.93 E.01159
G1 X96.229 Y141.199 E.00915
G1 X95.996 Y141.432 E.00802
G1 E-5 F3600
G1 X95.996 Y141.432 F9000
G1 X91.559 Y141.728
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.50993
G1 F1200
G1 X91.517 Y141.685 E.0019
G1 X91.459 Y141.701 E.0019
G1 X91.444 Y141.758 E.00186
G1 X91.486 Y141.8 E.00188
G1 X91.543 Y141.785 E.00186
;WIDTH:0.399999
G1 X92.205 Y141.634 E.01652
G1 X91.331 Y142.522 E.03031
;WIDTH:0.374336
G1 X91.26 Y142.503 E.00166
G1 X91.279 Y142.574 E.00166
G1 X91.32 Y142.563 E.00096
;WIDTH:0.399999
G1 X91.446 Y142.91 E.00898
G1 X92.722 Y141.634 E.04389
G1 X93.24 Y141.634 E.0126
G1 X91.447 Y143.427 E.06168
G1 X91.447 Y143.944 E.01258
G1 X93.757 Y141.633 E.07948
G1 X94.274 Y141.633 E.01258
G1 X91.447 Y144.461 E.09726
G1 X91.447 Y144.978 E.01258
G1 X94.792 Y141.633 E.11507
G1 X95.309 Y141.633 E.01258
G1 X91.447 Y145.495 E.13285
G1 X91.447 Y146.012 E.01258
G1 X95.826 Y141.633 E.15063
G1 X96.343 Y141.633 E.01258
G1 X91.623 Y146.353 E.16236
G1 X91.39 Y146.377 E.0057
;WIDTH:0.374336
G1 X91.319 Y146.358 E.00166
G1 X91.338 Y146.429 E.00166
G1 X91.379 Y146.418 E.00096
G1 X91.379 Y146.418 F9000
G1 X92.127 Y146.366
;WIDTH:0.399999
G1 F1200
G1 X96.788 Y141.705 E.16034
G1 X97.073 Y141.937 E.00894
G1 X92.644 Y146.366 E.15235
G1 X93.162 Y146.366 E.0126
G1 X97.365 Y142.162 E.1446
G1 X97.667 Y142.378 E.00903
G1 X93.679 Y146.366 E.13718
G1 X94.196 Y146.366 E.01258
G1 X97.978 Y142.584 E.1301
G1 X98.289 Y142.79 E.00907
G1 X94.713 Y146.366 E.12301
G1 X95.23 Y146.366 E.01258
G1 X98.625 Y142.971 E.11679
G1 X98.961 Y143.152 E.00928
G1 X95.747 Y146.366 E.11056
G1 X96.265 Y146.366 E.0126
G1 X99.297 Y143.333 E.10432
G1 X99.651 Y143.497 E.00949
G1 X96.782 Y146.365 E.09867
G1 E-5 F3600
G1 X96.782 Y146.365 F9000
G1 X99.883 Y143.781
G1 E5 F2400
G1 F1200
G1 X97.299 Y146.365 E.08889
G1 X105.795 Y146.365 E.20666
G1 X106.329 Y146.195 E.01363
G1 X106.644 Y145.92 E.01017
G1 X106.867 Y145.584 E.00981
G1 X106.964 Y145.046 E.0133
G1 X106.965 Y144.537 E.01238
G1 X104.503 Y144.559 E.05989
G1 X103.004 Y144.451 E.03656
G1 X101.655 Y144.192 E.03341
G1 X100.986 Y144.006 E.01689
G1 X100.265 Y143.759 E.01854
G1 X100.013 Y143.652 E.00666
G1 X100.146 Y144.105 E.01148
G1 X100.888 Y144.358 E.01907
G1 X101.586 Y144.551 E.01762
G1 X102.913 Y144.807 E.03287
G1 X104.503 Y144.925 E.03878
G1 X106.599 Y144.903 E.05099
G1 X106.519 Y145.458 E.01364
G1 X106.387 Y145.661 E.00589
G1 X106.195 Y145.851 E.00657
G1 X105.747 Y145.999 E.01148
G1 X98.182 Y146 E.18401
G1 X100 Y144.181 E.06256
G1 X100.191 Y144.507 E.00919
G1 X100.789 Y144.711 E.01537
G1 X101.517 Y144.91 E.01836
;WIDTH:0.426506
G1 X102.178 Y145.051 E.01763
;WIDTH:0.453012
G1 X102.95 Y145.202 E.02191
;WIDTH:0.444073
G1 X103.694 Y145.243 E.02031
;WIDTH:0.417109
G1 X104.438 Y145.283 E.01897
;WIDTH:0.390145
G1 X104.503 Y145.285 E.00154
;WIDTH:0.389202
G1 X105.677 Y145.284 E.02771
G1 X106.191 Y145.263 E.01214
G1 X106.134 Y145.404 E.00359
G1 X105.998 Y145.539 E.00452
G1 X105.7 Y145.639 E.00742
G1 X104.504 Y145.639 E.02823
;WIDTH:0.390145
G1 X104.425 Y145.638 E.00187
;WIDTH:0.417109
G1 X103.68 Y145.625 E.01897
;WIDTH:0.444073
G1 X102.935 Y145.612 E.02031
;WIDTH:0.453012
G1 X102.123 Y145.62 E.02262
;WIDTH:0.426506
G1 X101.447 Y145.634 E.01764
;WIDTH:0.399999
G1 X99.065 Y145.634 E.05794
G1 X100.062 Y144.636 E.03431
G1 X100.285 Y144.913 E.00865
;WIDTH:0.375923
G1 X100.695 Y145.051 E.00983
G1 X101.568 Y145.28 E.02051
G1 X99.919 Y145.28 E.03747
G1 X100.156 Y145.043 E.00762
G1 E-5 F3600
G1 X100.156 Y145.043 F9000
G1 X103.059 Y149.434
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X105.763 Y146.73 E.09302
G1 X105.245 Y146.73 E.0126
G1 X102.706 Y149.269 E.08734
G1 X102.187 Y149.269 E.01262
G1 X104.726 Y146.73 E.08734
G1 X104.208 Y146.73 E.0126
G1 X101.669 Y149.269 E.08734
G1 X101.15 Y149.269 E.01262
G1 X103.689 Y146.73 E.08734
G1 X103.171 Y146.731 E.0126
G1 X100.632 Y149.269 E.08732
G1 X100.114 Y149.269 E.0126
G1 X102.652 Y146.731 E.08731
G1 X102.134 Y146.731 E.0126
G1 X99.595 Y149.269 E.08732
G1 X99.077 Y149.269 E.0126
G1 X101.615 Y146.731 E.08731
G1 X101.097 Y146.731 E.0126
G1 X98.559 Y149.269 E.08731
G1 X98.04 Y149.269 E.01262
G1 X100.578 Y146.731 E.08731
G1 X100.06 Y146.731 E.0126
G1 X97.522 Y149.269 E.08731
G1 X97.004 Y149.269 E.0126
G1 X99.542 Y146.731 E.08731
G1 X99.023 Y146.731 E.01262
G1 X96.485 Y149.269 E.08731
G1 X95.967 Y149.269 E.0126
G1 X98.505 Y146.731 E.08731
G1 X97.986 Y146.731 E.01262
G1 X95.448 Y149.269 E.08731
G1 X94.93 Y149.269 E.0126
G1 X97.468 Y146.731 E.08731
G1 X96.949 Y146.731 E.01262
G1 X94.412 Y149.269 E.08729
G1 X93.893 Y149.269 E.01262
G1 X96.431 Y146.731 E.08731
G1 X95.912 Y146.731 E.01262
G1 X93.375 Y149.269 E.08729
G1 X92.857 Y149.268 E.0126
G1 X95.394 Y146.731 E.08727
G1 X94.875 Y146.731 E.01262
G1 X92.338 Y149.268 E.08727
G1 X91.82 Y149.268 E.0126
G1 X94.357 Y146.731 E.08727
G1 X93.838 Y146.731 E.01262
G1 X91.447 Y149.122 E.08225
G1 X91.447 Y148.604 E.0126
G1 X93.32 Y146.731 E.06443
G1 X92.801 Y146.732 E.01262
G1 X91.447 Y148.086 E.04658
G1 X91.447 Y147.567 E.01262
G1 X92.283 Y146.732 E.02874
G1 X91.765 Y146.731 E.0126
G1 X91.283 Y147.214 E.0166
G1 E-5 F3600
G1 X91.283 Y147.214 F9000
G1 X91.56 Y149.727
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.509918
G1 F1200
G1 X91.518 Y149.685 E.00188
G1 X91.46 Y149.701 E.0019
G1 X91.445 Y149.758 E.00186
G1 X91.487 Y149.8 E.00188
G1 X91.544 Y149.785 E.00186
;WIDTH:0.399999
G1 X91.448 Y150.392 E.01495
G1 X92.206 Y149.634 E.02607
G1 X92.723 Y149.634 E.01258
G1 X91.448 Y150.909 E.04386
G1 X91.467 Y151.407 E.01212
G1 X93.24 Y149.634 E.06099
G1 X93.757 Y149.634 E.01258
G1 X91.539 Y151.853 E.07631
G1 X91.647 Y152.261 E.01027
G1 X94.274 Y149.634 E.09037
G1 X94.791 Y149.634 E.01258
G1 X91.799 Y152.626 E.10292
G1 X91.962 Y152.98 E.00948
G1 X95.308 Y149.634 E.1151
G1 X95.825 Y149.634 E.01258
G1 X92.157 Y153.302 E.12618
G1 X92.384 Y153.593 E.00898
G1 X96.343 Y149.634 E.13619
G1 X96.86 Y149.634 E.01258
G1 X92.632 Y153.862 E.14544
G1 X92.901 Y154.11 E.0089
G1 X97.377 Y149.635 E.15395
G1 X97.894 Y149.635 E.01258
G1 X93.192 Y154.337 E.16175
G1 X93.514 Y154.531 E.00914
G1 X98.411 Y149.635 E.16844
G1 X98.928 Y149.635 E.01258
G1 X94.196 Y154.367 E.16278
G1 X94.713 Y154.367 E.01258
G1 X99.445 Y149.635 E.16278
G1 X99.962 Y149.635 E.01258
G1 X95.23 Y154.367 E.16278
G1 X95.747 Y154.367 E.01258
G1 X100.479 Y149.635 E.16278
G1 X100.996 Y149.635 E.01258
G1 X96.264 Y154.367 E.16278
G1 X96.781 Y154.367 E.01258
G1 X101.513 Y149.635 E.16278
G1 X102.03 Y149.635 E.01258
G1 X97.298 Y154.368 E.16279
G1 X97.815 Y154.368 E.01258
G1 X102.547 Y149.635 E.16279
G1 X103.065 Y149.635 E.0126
G1 X98.332 Y154.368 E.16281
G1 X98.849 Y154.368 E.01258
G1 X103.582 Y149.635 E.16281
G1 X104.099 Y149.635 E.01258
G1 X99.366 Y154.368 E.16281
G1 X99.883 Y154.368 E.01258
G1 X104.616 Y149.635 E.16281
G1 X105.133 Y149.635 E.01258
G1 X100.4 Y154.369 E.16283
G1 X100.917 Y154.369 E.01258
G1 X105.65 Y149.635 E.16283
G1 X106.1 Y149.703 E.01107
G1 X101.433 Y154.369 E.16052
G1 X101.95 Y154.369 E.01258
G1 X106.444 Y149.876 E.15457
G1 X106.706 Y150.13 E.00888
G1 X102.467 Y154.369 E.14582
G1 X102.984 Y154.369 E.01258
G1 X106.886 Y150.468 E.13421
G1 X106.965 Y150.905 E.0108
G1 X103.501 Y154.369 E.11916
G1 X104.018 Y154.37 E.01258
G1 X106.965 Y151.423 E.10137
G1 X106.965 Y151.94 E.01258
G1 X104.535 Y154.37 E.08359
G1 X105.052 Y154.37 E.01258
G1 X106.965 Y152.457 E.06581
G1 X106.965 Y152.974 E.01258
G1 X105.569 Y154.37 E.04802
G1 X105.693 Y154.503 E.00442
;WIDTH:0.374336
G1 X106.114 Y154.415 E.00973
G1 X106.339 Y154.273 E.00602
G1 X106.738 Y153.904 E.01229
G1 X107 Y153.547 E.01002
G1 X107.094 Y153.107 E.01018
;WIDTH:0.399999
G1 X106.825 Y153.631 E.01433
G1 X106.207 Y154.249 E.02126
G1 X106.207 Y154.249 F9000
G1 X105.564 Y155.224
;WIDTH:0.4
G1 F3072.127
G1 X106.123 Y154.665 E.01923
G1 X105.534 Y154.736 E.01443
G1 X105.21 Y155.06 E.01115
G1 X104.691 Y155.06 E.01262
G1 X105.016 Y154.736 E.01116
G1 X104.497 Y154.735 E.01262
G1 X104.173 Y155.06 E.01116
G1 X103.654 Y155.06 E.01262
G1 X103.979 Y154.735 E.01118
G1 X103.461 Y154.735 E.0126
G1 X103.136 Y155.06 E.01118
G1 X102.617 Y155.06 E.01262
G1 X102.942 Y154.735 E.01118
G1 X102.424 Y154.735 E.0126
G1 X102.098 Y155.061 E.01121
G1 X101.58 Y155.061 E.0126
G1 X101.906 Y154.735 E.01121
G1 X101.388 Y154.735 E.0126
G1 X101.061 Y155.061 E.01123
G1 X100.543 Y155.061 E.0126
G1 X100.869 Y154.734 E.01123
G1 X100.351 Y154.734 E.0126
G1 X100.024 Y155.061 E.01125
G1 X99.506 Y155.061 E.0126
G1 X99.833 Y154.734 E.01125
G1 X99.315 Y154.734 E.0126
G1 X98.987 Y155.061 E.01127
G1 X98.469 Y155.061 E.0126
G1 X98.796 Y154.734 E.01125
G1 X98.278 Y154.734 E.0126
G1 X97.95 Y155.062 E.01128
G1 X97.432 Y155.062 E.0126
G1 X97.76 Y154.733 E.0113
G1 X97.242 Y154.733 E.0126
G1 X96.913 Y155.062 E.01132
G1 X96.395 Y155.062 E.0126
G1 X96.723 Y154.733 E.0113
G1 X96.205 Y154.733 E.0126
G1 X95.876 Y155.062 E.01132
G1 X95.366 Y155.053 E.01241
G1 X95.687 Y154.733 E.01103
G1 X95.169 Y154.733 E.0126
G1 X94.892 Y155.009 E.00951
G1 X94.461 Y154.922 E.0107
G1 X94.65 Y154.732 E.00652
G1 X94.132 Y154.732 E.0126
G1 X93.942 Y154.923 E.00655
G1 E-5 F3600
G1 X93.942 Y154.923 F9000
G1 X107.602 Y144.373
G1 E5 F2400
G1 F3072.127
G1 X107.331 Y144.644 E.00932
G1 X107.321 Y145.172 E.01285
G1 X107.956 Y144.537 E.02184
G1 X108.475 Y144.537 E.01262
G1 X103.742 Y149.269 E.1628
G1 X104.261 Y149.27 E.01262
G1 X108.993 Y144.537 E.1628
G1 X109.511 Y144.537 E.0126
G1 X104.779 Y149.27 E.1628
G1 X105.297 Y149.27 E.0126
G1 X110.03 Y144.537 E.16281
G1 X110.551 Y144.535 E.01267
G1 X105.816 Y149.27 E.16288
G1 X106.24 Y149.364 E.01056
G1 X111.198 Y144.406 E.17055
G1 X111.301 Y144.543 E.00417
G1 X111.579 Y144.543 E.00676
G1 X106.59 Y149.532 E.17162
G1 X106.87 Y149.771 E.00895
G1 X112.098 Y144.543 E.17984
G1 X112.616 Y144.543 E.0126
G1 X107.094 Y150.065 E.18995
G1 X107.254 Y150.424 E.00956
G1 X113.135 Y144.543 E.2023
G1 X113.653 Y144.543 E.0126
G1 X107.329 Y150.867 E.21754
G1 X107.331 Y151.383 E.01255
G1 X114.171 Y144.543 E.23529
G1 X114.69 Y144.543 E.01262
G1 X107.331 Y151.902 E.25315
G1 X107.331 Y152.42 E.0126
G1 X115.208 Y144.543 E.27096
G1 X115.727 Y144.543 E.01262
G1 X107.331 Y152.938 E.2888
G1 X107.274 Y153.514 E.01408
G1 X116.245 Y144.543 E.3086
G1 X116.764 Y144.543 E.01262
G1 X106.247 Y155.06 E.36178
G1 X106.765 Y155.06 E.0126
G1 X117.282 Y144.543 E.36178
G1 X117.8 Y144.543 E.0126
G1 X107.284 Y155.059 E.36174
G1 X107.802 Y155.059 E.0126
G1 X118.319 Y144.543 E.36176
G1 X118.837 Y144.543 E.0126
G1 X108.321 Y155.059 E.36174
G1 X108.839 Y155.059 E.0126
G1 X119.356 Y144.543 E.36176
G1 X119.699 Y144.543 E.00834
G1 X119.784 Y144.397 E.00411
G1 X119.96 Y144.457 E.00452
G1 X109.358 Y155.059 E.3647
G1 X109.876 Y155.059 E.0126
G1 X120.409 Y144.526 E.36233
G1 X120.926 Y144.528 E.01258
G1 X110.395 Y155.059 E.36226
G1 X110.913 Y155.059 E.0126
G1 X121.443 Y144.529 E.36223
G1 X121.96 Y144.53 E.01258
G1 X111.432 Y155.058 E.36216
G1 X111.951 Y155.058 E.01262
G1 X122.478 Y144.531 E.36212
G1 X122.995 Y144.532 E.01258
G1 X112.469 Y155.058 E.36209
G1 X112.988 Y155.058 E.01262
G1 X123.512 Y144.534 E.36202
G1 X123.669 Y144.534 E.00382
G1 X123.669 Y144.895 E.00878
G1 X113.506 Y155.058 E.3496
G1 X114.025 Y155.058 E.01262
G1 X123.715 Y145.367 E.33335
G1 X123.822 Y145.779 E.01035
G1 X114.543 Y155.058 E.31919
G1 X115.062 Y155.058 E.01262
G1 X124.016 Y146.103 E.30803
G1 X124.272 Y146.366 E.00893
G1 X115.58 Y155.058 E.299
G1 X116.099 Y155.057 E.01262
G1 X124.586 Y146.57 E.29195
G1 X124.974 Y146.701 E.00996
G1 X116.617 Y155.057 E.28746
G1 X117.136 Y155.057 E.01262
G1 X125.463 Y146.73 E.28644
G1 X125.981 Y146.73 E.0126
G1 X117.654 Y155.057 E.28644
G1 X118.173 Y155.057 E.01262
G1 X126.499 Y146.73 E.28643
G1 X127.018 Y146.731 E.01262
G1 X118.691 Y155.057 E.28643
G1 X119.21 Y155.057 E.01262
G1 X123.707 Y150.56 E.15469
G1 X123.669 Y151.116 E.01356
G1 X119.729 Y155.057 E.13555
G1 X120.247 Y155.057 E.0126
G1 X123.669 Y151.635 E.11771
G1 X123.669 Y152.153 E.0126
G1 X120.766 Y155.056 E.09986
G1 X121.284 Y155.056 E.0126
G1 X123.669 Y152.671 E.08204
G1 X123.678 Y153.181 E.01241
G1 X121.803 Y155.056 E.0645
G1 X122.321 Y155.056 E.0126
G1 X123.759 Y153.618 E.04947
G1 X123.932 Y153.964 E.00941
G1 X122.84 Y155.056 E.03756
G1 X123.358 Y155.056 E.0126
G1 X124.173 Y154.241 E.02804
G1 X124.452 Y154.48 E.00894
G1 X123.877 Y155.056 E.0198
G1 X124.395 Y155.056 E.0126
G1 X124.828 Y154.623 E.01489
G1 X125.243 Y154.727 E.01041
G1 X124.914 Y155.055 E.0113
G1 X125.432 Y155.055 E.0126
G1 X125.752 Y154.736 E.01099
G1 X126.27 Y154.736 E.0126
G1 X125.951 Y155.055 E.01097
G1 X126.469 Y155.055 E.0126
G1 X126.789 Y154.735 E.01101
G1 X127.308 Y154.735 E.01262
G1 X126.988 Y155.055 E.01101
G1 X127.507 Y155.055 E.01262
G1 X127.826 Y154.735 E.01099
G1 X128.345 Y154.735 E.01262
G1 X128.025 Y155.055 E.01101
G1 X128.544 Y155.055 E.01262
G1 X128.863 Y154.735 E.01099
G1 X129.382 Y154.735 E.01262
G1 X129.062 Y155.055 E.01101
G1 X129.581 Y155.054 E.01262
G1 X129.901 Y154.734 E.01101
G1 X130.419 Y154.734 E.0126
G1 X130.099 Y155.054 E.01101
G1 X130.618 Y155.054 E.01262
G1 X130.938 Y154.734 E.01101
G1 X131.456 Y154.734 E.0126
G1 X131.136 Y155.054 E.01101
G1 X131.655 Y155.054 E.01262
G1 X131.975 Y154.734 E.01101
G1 X132.493 Y154.734 E.0126
G1 X132.173 Y155.054 E.01101
G1 X132.692 Y155.054 E.01262
G1 X133.012 Y154.734 E.01101
G1 X133.531 Y154.733 E.01262
G1 X133.21 Y155.054 E.01104
G1 X133.729 Y155.053 E.01262
G1 X134.049 Y154.733 E.01101
G1 X134.568 Y154.733 E.01262
G1 X134.247 Y155.053 E.01103
G1 X134.766 Y155.053 E.01262
G1 X135.086 Y154.733 E.01101
G1 X135.605 Y154.733 E.01262
G1 X135.284 Y155.053 E.01103
G1 X135.735 Y155.053 E.01097
G1 X135.812 Y155.044 E.00189
G1 X136.123 Y154.733 E.0107
G1 X136.642 Y154.732 E.01262
G1 X136.211 Y155.163 E.01483
G1 E-5 F3600
G1 X136.211 Y155.163 F9000
G1 X139.34 Y149.443
G1 E5 F2400
G1 F3072.127
G1 X139.563 Y149.219 E.00769
G1 X139.563 Y148.701 E.0126
G1 X138.996 Y149.268 E.0195
G1 X138.477 Y149.268 E.01262
G1 X139.563 Y148.183 E.03734
G1 X139.563 Y147.664 E.01262
G1 X137.959 Y149.268 E.05518
G1 X137.44 Y149.269 E.01262
G1 X139.563 Y147.146 E.07303
G1 X139.562 Y146.686 E.01119
G1 X139.495 Y146.696 E.00165
G1 X136.922 Y149.269 E.08851
G1 X136.403 Y149.269 E.01262
G1 X138.94 Y146.732 E.08727
G1 X138.422 Y146.732 E.0126
G1 X135.885 Y149.269 E.08727
G1 X135.366 Y149.269 E.01262
G1 X137.904 Y146.732 E.08729
G1 X137.385 Y146.731 E.01262
G1 X134.848 Y149.269 E.08729
G1 X134.329 Y149.269 E.01262
G1 X136.867 Y146.731 E.08731
G1 X136.348 Y146.731 E.01262
G1 X133.811 Y149.269 E.08729
G1 X133.292 Y149.269 E.01262
G1 X135.83 Y146.731 E.08731
G1 X135.312 Y146.731 E.0126
G1 X132.774 Y149.269 E.08731
G1 X132.255 Y149.269 E.01262
G1 X134.793 Y146.731 E.08731
G1 X134.275 Y146.731 E.0126
G1 X131.737 Y149.269 E.08731
G1 X131.219 Y149.269 E.0126
G1 X133.757 Y146.731 E.08731
G1 X133.238 Y146.731 E.01262
G1 X130.7 Y149.269 E.08731
G1 X130.182 Y149.269 E.0126
G1 X132.72 Y146.731 E.08731
G1 X132.201 Y146.731 E.01262
G1 X129.663 Y149.269 E.08731
G1 X129.145 Y149.269 E.0126
G1 X131.683 Y146.731 E.08731
G1 X131.165 Y146.731 E.0126
G1 X128.626 Y149.269 E.08732
G1 X128.108 Y149.269 E.0126
G1 X130.646 Y146.731 E.08731
G1 X130.128 Y146.731 E.0126
G1 X127.589 Y149.27 E.08734
G1 X127.071 Y149.27 E.0126
G1 X129.61 Y146.731 E.08734
G1 X129.091 Y146.731 E.01262
G1 X126.552 Y149.27 E.08734
G1 X126.034 Y149.27 E.0126
G1 X128.573 Y146.731 E.08734
G1 X128.055 Y146.731 E.0126
G1 X125.515 Y149.27 E.08736
G1 X124.966 Y149.301 E.01338
G1 X127.701 Y146.566 E.09408
G1 E-5 F3600
G1 X127.701 Y146.566 F9000
G1 X130.667 Y143.783
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X128.215 Y146.236 E.08436
G1 X128.215 Y146.364 E.00311
G1 X125.19 Y146.363 E.07358
G1 X124.752 Y146.242 E.01105
G1 X124.352 Y145.931 E.01232
G1 X124.123 Y145.558 E.01065
G1 X124.034 Y145.077 E.0119
G1 X124.035 Y144.535 E.01318
G1 X125.263 Y144.558 E.02988
G1 X126.764 Y144.555 E.03651
G1 X127.585 Y144.501 E.02001
G1 X128.15 Y144.431 E.01385
G1 X128.816 Y144.311 E.01646
G1 X129.507 Y144.151 E.01725
G1 X130.495 Y143.844 E.02517
G1 X130.495 Y143.844 F9000
G1 X131.572 Y143.396
G1 F1200
G1 X128.603 Y146.365 E.10213
G1 X129.12 Y146.365 E.01258
G1 X132.716 Y142.768 E.12372
G1 X132.975 Y142.562 E.00805
;WIDTH:0.374336
G1 X133.825 Y141.847 E.02512
;WIDTH:0.399999
G1 X134.369 Y141.633 E.01422
G1 X129.637 Y146.365 E.16278
G1 X130.154 Y146.365 E.01258
G1 X134.886 Y141.633 E.16278
G1 X135.403 Y141.633 E.01258
G1 X130.671 Y146.365 E.16278
G1 X131.188 Y146.365 E.01258
G1 X135.92 Y141.633 E.16278
G1 X136.437 Y141.633 E.01258
G1 X131.705 Y146.365 E.16278
G1 X132.222 Y146.365 E.01258
G1 X136.954 Y141.633 E.16278
G1 X137.471 Y141.634 E.01258
G1 X132.739 Y146.365 E.16276
G1 X133.256 Y146.365 E.01258
G1 X137.988 Y141.634 E.16276
G1 X138.505 Y141.634 E.01258
G1 X133.773 Y146.365 E.16276
G1 X134.29 Y146.366 E.01258
G1 X139.022 Y141.634 E.16278
G1 X139.507 Y141.666 E.01182
G1 X134.808 Y146.366 E.16166
G1 X135.325 Y146.366 E.01258
G1 X139.562 Y142.129 E.14575
G1 X139.562 Y142.646 E.01258
G1 X135.842 Y146.366 E.12797
G1 X136.359 Y146.366 E.01258
G1 X139.562 Y143.163 E.11018
G1 X139.562 Y143.68 E.01258
G1 X136.876 Y146.366 E.0924
G1 X137.393 Y146.366 E.01258
G1 X139.562 Y144.197 E.07461
G1 X139.562 Y144.714 E.01258
G1 X137.91 Y146.366 E.05683
G1 X138.427 Y146.366 E.01258
G1 X139.562 Y145.231 E.03904
G1 X139.562 Y145.748 E.01258
G1 X138.944 Y146.366 E.02126
G1 X139.586 Y146.326 E.01565
;WIDTH:0.422308
G1 X139.539 Y146.339 E.00126
G1 X139.517 Y146.258 E.00217
G1 X139.598 Y146.279 E.00216
G1 E-5 F3600
G1 X139.598 Y146.279 F9000
G1 X129.377 Y144.557
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X127.956 Y145.998 E.04923
G1 X125.313 Y145.998 E.06429
G1 X124.993 Y145.929 E.00796
G1 X124.671 Y145.741 E.00907
G1 X124.473 Y145.437 E.00882
G1 X124.4 Y144.901 E.01316
G1 X125.264 Y144.923 E.02102
G1 X126.796 Y144.919 E.03726
G1 X127.63 Y144.864 E.02033
G1 X128.214 Y144.791 E.01432
G1 X129.199 Y144.598 E.02441
G1 X129.199 Y144.598 F9000
G1 X128.23 Y145.17
;WIDTH:0.420789
G1 F1200
G1 X127.779 Y145.622 E.01641
G1 X127.558 Y145.626 E.00568
;WIDTH:0.413185
G1 X126.766 Y145.637 E.01996
;WIDTH:0.390362
G1 X125.313 Y145.638 E.03441
;WIDTH:0.388705
G1 X125.141 Y145.597 E.00417
G1 X124.915 Y145.472 E.00609
G1 X124.807 Y145.262 E.00557
G1 X125.264 Y145.283 E.01078
;WIDTH:0.390362
G1 X126.765 Y145.281 E.03555
;WIDTH:0.391335
G1 X126.818 Y145.28 E.00126
;WIDTH:0.420789
G1 X127.676 Y145.237 E.02208
G1 X128.049 Y145.192 E.00966
G1 E-5 F3600
G1 X128.049 Y145.192 F9000
G1 X125.006 Y149.666
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X124.078 Y150.594 E.03192
G1 X124.035 Y151.154 E.01366
G1 X125.553 Y149.635 E.05224
G1 X126.071 Y149.635 E.0126
G1 X124.035 Y151.671 E.07004
G1 X124.035 Y152.189 E.0126
G1 X126.588 Y149.635 E.08784
G1 X127.105 Y149.635 E.01258
G1 X124.035 Y152.706 E.10562
G1 X124.051 Y153.206 E.01217
G1 X127.622 Y149.635 E.12284
G1 X128.139 Y149.635 E.01258
G1 X124.164 Y153.61 E.13674
G1 X124.366 Y153.925 E.0091
G1 X128.657 Y149.635 E.14759
G1 X129.174 Y149.635 E.01258
G1 X124.645 Y154.164 E.15579
G1 X125.029 Y154.297 E.00988
G1 X129.691 Y149.635 E.16037
G1 X130.208 Y149.635 E.01258
G1 X125.473 Y154.37 E.16288
G1 X125.99 Y154.37 E.01258
G1 X130.725 Y149.635 E.16288
G1 X131.242 Y149.635 E.01258
G1 X126.507 Y154.37 E.16288
G1 X127.025 Y154.37 E.0126
G1 X131.76 Y149.635 E.16288
G1 X132.277 Y149.635 E.01258
G1 X127.542 Y154.37 E.16288
G1 X128.059 Y154.369 E.01258
G1 X132.794 Y149.635 E.16286
G1 X133.311 Y149.635 E.01258
G1 X128.577 Y154.369 E.16285
G1 X129.094 Y154.369 E.01258
G1 X133.828 Y149.635 E.16285
G1 X134.345 Y149.635 E.01258
G1 X129.611 Y154.369 E.16285
G1 X130.128 Y154.369 E.01258
G1 X134.863 Y149.634 E.16288
G1 X135.38 Y149.634 E.01258
G1 X130.646 Y154.369 E.16286
G1 X131.163 Y154.368 E.01258
G1 X135.897 Y149.634 E.16285
G1 X136.414 Y149.634 E.01258
G1 X131.68 Y154.368 E.16285
G1 X132.197 Y154.368 E.01258
G1 X136.931 Y149.634 E.16285
G1 X137.449 Y149.634 E.0126
G1 X132.715 Y154.368 E.16285
G1 X133.232 Y154.368 E.01258
G1 X137.966 Y149.634 E.16285
G1 X138.483 Y149.634 E.01258
G1 X133.749 Y154.368 E.16285
G1 X134.267 Y154.367 E.0126
G1 X139 Y149.634 E.16281
G1 X139.688 Y149.587 E.01677
;WIDTH:0.374336
G1 X139.695 Y149.679 E.00209
;WIDTH:0.399999
G1 X139.49 Y149.661 E.00501
G1 X134.784 Y154.367 E.16188
G1 X135.301 Y154.367 E.01258
G1 X139.563 Y150.105 E.14661
G1 X139.563 Y150.622 E.01258
G1 X135.818 Y154.367 E.12883
G1 X136.336 Y154.367 E.0126
G1 X139.55 Y151.152 E.11058
G1 X139.485 Y151.735 E.01427
G1 X136.853 Y154.367 E.09054
G1 X137.305 Y154.432 E.01111
G1 X139.293 Y152.443 E.0684
G1 X139.477 Y152.218 E.00707
;WIDTH:0.374336
G1 X139.436 Y152.229 E.00096
G1 X139.417 Y152.158 E.00166
G1 X139.488 Y152.177 E.00166
G1 X139.488 Y152.177 F9000
G1 X138.882 Y153.317
;WIDTH:0.38435
G1 F1200
G1 X138.216 Y154.027 E.02267
G1 X137.799 Y154.396 E.01296
G1 E-5 F3600
G1 X137.799 Y154.396 F9000
G1 X139.019 Y141.433
G1 E5 F2400
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X139.562 Y140.891 E.01866
G1 X139.561 Y140.331 E.01362
G1 X138.624 Y141.268 E.03223
G1 X138.064 Y141.268 E.01362
G1 X139.561 Y139.77 E.05151
G1 X139.561 Y139.21 E.01362
G1 X137.504 Y141.268 E.07078
G1 X136.944 Y141.268 E.01362
G1 X139.519 Y138.692 E.0886
G1 X138.92 Y138.732 E.0146
G1 X136.384 Y141.268 E.08724
G1 X135.824 Y141.267 E.01362
G1 X138.359 Y138.732 E.0872
G1 X137.798 Y138.733 E.01365
G1 X135.264 Y141.267 E.08717
G1 X134.704 Y141.267 E.01362
G1 X137.402 Y138.569 E.09281
G1 E-5 F3600
G1 X137.402 Y138.569 F9000
G1 X139.023 Y133.634
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X138.384 Y133.633 E.01554
G1 X138.325 Y134.172 E.01319
G1 X138.12 Y135.318 E.02832
G1 X137.771 Y136.521 E.03047
G1 X137.491 Y137.254 E.01909
G1 X136.936 Y138.368 E.03027
G1 X139.215 Y138.365 E.05543
G1 X139.561 Y138.301 E.00856
G1 X139.56 Y133.681 E.11238
G1 X139.205 Y133.634 E.00871
G1 X138.749 Y134.035 E.01477
;WIDTH:0.471959
G1 X139.159 Y134.036 E.01194
;WIDTH:0.496688
G1 X139.147 Y134.743 E.02175
G1 X139.171 Y135.104 E.01113
;WIDTH:0.448344
G1 X139.195 Y135.465 E.00996
;WIDTH:0.399999
G1 X139.183 Y137.999 E.06164
G1 X137.527 Y138.002 E.04028
G1 X137.936 Y137.117 E.02371
G1 X138.122 Y136.623 E.01284
G1 X138.478 Y135.392 E.03117
;WIDTH:0.433573
G1 X138.545 Y135.145 E.0068
;WIDTH:0.467146
G1 X138.613 Y134.899 E.00735
;WIDTH:0.500719
G1 X138.68 Y134.653 E.00791
G1 X138.729 Y134.217 E.01361
G1 X138.729 Y134.217 F9000
G1 X138.778 Y135.859
;WIDTH:0.502725
G1 F1200
G1 X138.778 Y137.583 E.05372
G1 X138.2 Y137.584 E.01801
G1 X138.523 Y136.739 E.02819
G1 X138.727 Y136.034 E.02287
G1 E-5 F3600
G1 X138.727 Y136.034 F9000
G1 X139.009 Y133.433
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X139.56 Y132.881 E.01897
G1 X139.56 Y132.315 E.01377
G1 X138.607 Y133.268 E.03278
G1 X138.407 Y133.268 E.00486
G1 X138.431 Y132.878 E.0095
G1 X139.56 Y131.749 E.03884
G1 X139.56 Y131.182 E.01379
G1 X138.435 Y132.308 E.03872
G1 X138.435 Y131.741 E.01379
G1 X139.478 Y130.698 E.03588
G1 X138.878 Y130.732 E.01462
G1 X138.27 Y131.34 E.02091
G1 E-5 F3600
G1 X138.27 Y131.34 F9000
G1 X138.998 Y125.634
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X139.559 Y125.696 E.01373
G1 X139.56 Y130.302 E.11204
G1 X139.216 Y130.365 E.00851
G1 X138.435 Y130.367 E.019
G1 X138.435 Y125.633 E.11515
G1 X138.815 Y125.634 E.00924
G1 X138.808 Y126.006 E.00905
;WIDTH:0.413594
G1 X139.18 Y126.007 E.00938
G1 X139.187 Y126.196 E.00477
;WIDTH:0.413979
G1 X139.182 Y129.992 E.09586
G1 X138.808 Y129.993 E.00945
G1 X138.808 Y126.189 E.09607
G1 X138.808 Y126.189 F9000
G1 X139.007 Y125.433
;WIDTH:0.4
G1 F3072.127
G1 X139.559 Y124.881 E.01899
G1 X139.559 Y124.315 E.01377
G1 X138.606 Y125.268 E.03278
G1 X138.435 Y125.268 E.00416
G1 X138.435 Y124.873 E.00961
G1 X139.559 Y123.749 E.03866
G1 X139.559 Y123.183 E.01377
G1 X138.435 Y124.307 E.03866
G1 X138.435 Y123.741 E.01377
G1 X139.478 Y122.698 E.03588
G1 X138.878 Y122.732 E.01462
G1 X138.271 Y123.339 E.02088
G1 E-5 F3600
G1 X138.271 Y123.339 F9000
G1 X138.998 Y117.634
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X139.558 Y117.695 E.0137
G1 X139.559 Y122.302 E.11206
G1 X139.216 Y122.365 E.00848
G1 X138.435 Y122.367 E.019
G1 X138.436 Y117.633 E.11515
G1 X138.815 Y117.634 E.00922
G1 X138.808 Y118.006 E.00905
;WIDTH:0.412743
G1 X139.181 Y118.006 E.00939
G1 X139.186 Y118.195 E.00476
;WIDTH:0.413128
G1 X139.182 Y121.993 E.0957
G1 X138.808 Y121.994 E.00942
G1 X138.808 Y118.189 E.09588
G1 X138.808 Y118.189 F9000
G1 X139.006 Y117.433
;WIDTH:0.4
G1 F3072.127
G1 X139.558 Y116.881 E.01899
G1 X139.558 Y116.315 E.01377
G1 X138.605 Y117.268 E.03278
G1 X138.436 Y117.268 E.00411
G1 X138.436 Y116.872 E.00963
G1 X139.558 Y115.75 E.0386
G1 X139.558 Y115.184 E.01377
G1 X138.436 Y116.306 E.0386
G1 X138.436 Y115.74 E.01377
G1 X139.478 Y114.698 E.03584
G1 X138.878 Y114.732 E.01462
G1 X138.271 Y115.339 E.02088
G1 E-5 F3600
G1 X138.271 Y115.339 F9000
G1 X138.997 Y109.634
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X139.557 Y109.695 E.0137
G1 X139.557 Y114.302 E.11206
G1 X139.216 Y114.365 E.00843
G1 X138.436 Y114.367 E.01897
G1 X138.436 Y109.633 E.11515
G1 X138.814 Y109.634 E.00919
G1 X138.808 Y110.005 E.00903
;WIDTH:0.411893
G1 X139.181 Y110.01 E.00937
G1 X139.185 Y110.194 E.00462
;WIDTH:0.412278
G1 X139.181 Y113.989 E.09541
G1 X138.808 Y113.994 E.00938
G1 X138.808 Y110.188 E.09569
G1 X138.808 Y110.188 F9000
G1 X139.005 Y109.433
;WIDTH:0.4
G1 F3072.127
G1 X139.557 Y108.881 E.01899
G1 X139.557 Y108.316 E.01374
G1 X138.605 Y109.268 E.03275
G1 X138.436 Y109.268 E.00411
G1 X138.436 Y108.871 E.00966
G1 X139.556 Y107.75 E.03854
G1 X139.556 Y107.185 E.01374
G1 X138.436 Y108.305 E.03853
G1 X138.436 Y107.739 E.01377
G1 X139.477 Y106.698 E.03581
G1 X138.878 Y106.732 E.01459
G1 X138.272 Y107.338 E.02085
G1 E-5 F3600
G1 X138.272 Y107.338 F9000
G1 X138.997 Y101.634
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X139.556 Y101.695 E.01368
G1 X139.556 Y106.303 E.11208
G1 X139.216 Y106.365 E.00841
G1 X138.436 Y106.367 E.01897
G1 X138.437 Y101.633 E.11515
G1 X138.814 Y101.634 E.00917
G1 X138.808 Y102.005 E.00903
;WIDTH:0.411041
G1 X139.181 Y102.009 E.00935
G1 X139.184 Y102.194 E.00464
;WIDTH:0.411428
G1 X139.181 Y105.99 E.09522
G1 X138.808 Y105.995 E.00936
G1 X138.808 Y102.188 E.0955
G1 X138.808 Y102.188 F9000
G1 X139.046 Y101.433
;WIDTH:0.4
G1 F3072.127
G1 X139.555 Y100.924 E.01751
G1 X139.555 Y100.387 E.01306
G1 X138.674 Y101.268 E.03031
G1 X138.437 Y101.268 E.00576
G1 X138.437 Y100.968 E.0073
G1 X139.555 Y99.85 E.03846
G1 X139.555 Y99.313 E.01306
G1 X138.437 Y100.431 E.03846
G1 X138.437 Y99.894 E.01306
G1 X139.555 Y98.776 E.03846
G1 X139.555 Y98.239 E.01306
G1 X138.437 Y99.357 E.03846
G1 X138.437 Y98.82 E.01306
G1 X139.441 Y97.815 E.03455
G1 X138.876 Y97.843 E.01376
G1 X138.272 Y98.447 E.02078
G1 E-5 F3600
G1 X138.272 Y98.447 F9000
G1 X140.035 Y96.014
G1 X140.13 Y95.851
G1 X140.197 Y95.677
G1 X140.218 Y95.58
G1 X140.238 Y95.484
G1 X140.249 Y95.314
G1 X140.249 Y93.514
G1 X140.238 Y93.344
G1 X140.218 Y93.248
G1 X140.197 Y93.152
G1 X140.13 Y92.978
G1 X140.035 Y92.815
G1 X139.049 Y91.15
G1 E5 F2400
G1 F3072.127
G1 X139.554 Y90.645 E.01737
G1 X139.554 Y90.12 E.01277
G1 X138.688 Y90.985 E.02977
G1 X138.163 Y90.985 E.01277
G1 X139.554 Y89.595 E.04783
G1 X139.554 Y89.07 E.01277
G1 X137.638 Y90.985 E.06589
G1 X137.113 Y90.985 E.01277
G1 X139.554 Y88.545 E.08395
G1 X139.553 Y88.02 E.01277
G1 X136.588 Y90.985 E.10199
G1 X136.063 Y90.986 E.01277
G1 X139.553 Y87.495 E.12007
G1 X139.553 Y86.97 E.01277
G1 X135.538 Y90.986 E.13813
G1 X135.013 Y90.986 E.01277
G1 X139.553 Y86.445 E.15619
G1 X139.553 Y85.92 E.01277
G1 X134.488 Y90.986 E.17425
G1 X133.963 Y90.986 E.01277
G1 X139.553 Y85.395 E.19231
G1 X139.553 Y84.87 E.01277
G1 X133.437 Y90.986 E.21039
G1 X132.912 Y90.986 E.01277
G1 X139.553 Y84.345 E.22845
G1 X139.553 Y83.82 E.01277
G1 X132.387 Y90.986 E.24651
G1 X131.862 Y90.986 E.01277
G1 X139.553 Y83.295 E.26457
G1 X139.553 Y82.77 E.01277
G1 X131.337 Y90.986 E.28263
G1 X130.812 Y90.986 E.01277
G1 X139.553 Y82.245 E.30069
G1 X139.552 Y81.72 E.01277
G1 X130.287 Y90.986 E.31873
G1 X129.762 Y90.986 E.01277
G1 X139.552 Y81.195 E.33679
G1 X139.552 Y80.67 E.01277
G1 X129.237 Y90.986 E.35485
G1 X128.712 Y90.986 E.01277
G1 X139.552 Y80.145 E.37291
G1 X139.531 Y79.642 E.01225
G1 X128.473 Y90.7 E.38039
G1 X128.456 Y90.192 E.01236
G1 X139.461 Y79.186 E.37858
G1 X139.349 Y78.773 E.01041
G1 X128.371 Y89.751 E.37764
G1 X128.234 Y89.364 E.00999
G1 X139.214 Y78.383 E.37772
G1 X139.032 Y78.041 E.00942
G1 X128.051 Y89.021 E.37772
G1 X127.836 Y88.711 E.00918
G1 X128.98 Y87.567 E.03935
G1 X128.208 Y87.814 E.01972
G1 X127.697 Y88.325 E.01758
G1 X127.564 Y87.933 E.01007
G1 X127.765 Y87.732 E.00691
G1 E-5 F3600
G1 X127.765 Y87.732 F9000
G1 X131.995 Y84.552
G1 E5 F2400
G1 F3072.127
G1 X138.842 Y77.705 E.23553
G1 X138.605 Y77.417 E.00907
G1 X132.556 Y83.466 E.20808
G1 X132.676 Y82.821 E.01596
G1 X138.366 Y77.131 E.19573
G1 X138.079 Y76.893 E.00907
G1 X132.726 Y82.245 E.18412
G1 X132.728 Y81.719 E.01279
G1 X137.793 Y76.654 E.17423
G1 X137.467 Y76.454 E.0093
G1 X132.73 Y81.192 E.16297
G1 X132.731 Y80.666 E.01279
G1 X137.109 Y76.287 E.15062
G1 X136.734 Y76.137 E.00982
G1 X132.733 Y80.139 E.13765
G1 X132.734 Y79.612 E.01282
G1 X136.317 Y76.03 E.12324
G1 X135.861 Y75.961 E.01122
G1 X133.255 Y78.567 E.08964
G1 X133.4 Y78.187 E.00989
G1 X133.46 Y77.837 E.00864
G1 X135.351 Y75.945 E.06507
G1 X134.827 Y75.945 E.01275
G1 X133.461 Y77.31 E.04697
G1 X133.398 Y76.849 E.01132
G1 X134.303 Y75.944 E.03113
G1 X133.778 Y75.943 E.01277
G1 X133.263 Y76.459 E.01773
G1 X133.097 Y76.099 E.00964
G1 X133.418 Y75.778 E.01104
G1 E-5 F3600
G1 X133.418 Y75.778 F9000
G1 X140.13 Y92.978
G1 X140.197 Y93.152
G1 X140.218 Y93.248
G1 X140.238 Y93.344
G1 X140.249 Y93.514
G1 X140.249 Y95.314
G1 X140.238 Y95.484
G1 X137.018 Y133.39
G1 X136.986 Y133.743
G1 X136.97 Y133.879
G1 X136.921 Y134.23
G1 X136.9 Y134.364
G1 X136.831 Y134.733
G1 X136.82 Y134.784
G1 X136.812 Y134.82
G1 X136.803 Y134.863
G1 X136.791 Y134.915
G1 X136.732 Y135.162
G1 X136.721 Y135.209
G1 X136.705 Y135.269
G1 X136.686 Y135.34
G1 X136.663 Y135.423
G1 X136.614 Y135.595
G1 X136.591 Y135.672
G1 X136.564 Y135.761
G1 X136.533 Y135.858
G1 X136.5 Y135.956
G1 X136.46 Y136.073
G1 X136.427 Y136.169
G1 X136.391 Y136.265
G1 X136.356 Y136.359
G1 X136.309 Y136.477
G1 X136.272 Y136.573
G1 X136.234 Y136.665
G1 X136.198 Y136.749
G1 X136.167 Y136.82
G1 X136.091 Y136.99
G1 X136.056 Y137.066
G1 X136.025 Y137.132
G1 X135.999 Y137.187
G1 X135.977 Y137.23
G1 X135.862 Y137.46
G1 X135.837 Y137.508
G1 X135.816 Y137.548
G1 X135.799 Y137.581
G1 X135.784 Y137.608
G1 X135.764 Y137.644
G1 X135.598 Y137.937
G1 X135.539 Y138.037
G1 X135.361 Y138.321
G1 X135.298 Y138.42
G1 X135.226 Y138.525
G1 X135.042 Y138.79
G1 X134.963 Y138.897
G1 X134.77 Y139.147
G1 X134.686 Y139.254
G1 X134.485 Y139.491
G1 X134.396 Y139.595
G1 X134.299 Y139.701
G1 X134.092 Y139.923
G1 X133.99 Y140.027
G1 X133.773 Y140.24
G1 X133.637 Y140.367
G1 X133.409 Y140.57
G1 X133.268 Y140.691
G1 X133.03 Y140.883
G1 X132.884 Y140.997
G1 X132.637 Y141.178
G1 X132.486 Y141.286
G1 X132.231 Y141.455
G1 X132.075 Y141.555
G1 X131.812 Y141.712
G1 X131.652 Y141.805
G1 X131.345 Y141.97
G1 X131.302 Y141.993
G1 X131.257 Y142.015
G1 X131.211 Y142.038
G1 X130.909 Y142.183
G1 X130.865 Y142.203
G1 X130.819 Y142.224
G1 X130.771 Y142.245
G1 X130.713 Y142.27
G1 X130.485 Y142.366
G1 X130.43 Y142.389
G1 X130.297 Y142.442
G1 X129.969 Y142.562
G1 X129.792 Y142.622
G1 X129.661 Y142.663
G1 X129.481 Y142.719
G1 X129.256 Y142.782
G1 X129.194 Y142.798
G1 X128.965 Y142.857
G1 X128.699 Y142.918
G1 X128.426 Y142.975
G1 X128.158 Y143.025
G1 X127.883 Y143.068
G1 X127.61 Y143.104
G1 X127.333 Y143.133
G1 X127.056 Y143.154
G1 X111.602 Y144.163
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.428734
G1 F1200
G1 X119.398 Y144.163 E.20453
;LAYER_CHANGE
;Z:0.94
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;0.94
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X116.24 Y144.163 E-1.5
;WIPE_END
G1 Z.94 F9000
;AFTER_LAYER_CHANGE
;0.94
G1 Z.94
G1 X119.701 Y142.614
G1 X121.198 Y141.752
G1 X120.85 Y142.1
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X120.85 Y141.837 E.0064
G1 X120.798 Y141.71 E.00334
G1 X120.667 Y141.655 E.00346
G1 X110.333 Y141.655 E.25136
G1 X110.202 Y141.709 E.00345
G1 X110.15 Y141.837 E.00336
G1 X110.15 Y142.1 E.0064
G1 X104.338 Y142.089 E.14137
G1 X103.121 Y141.953 E.02979
G1 X102.507 Y141.828 E.01524
G1 X101.617 Y141.569 E.02255
G1 X100.912 Y141.294 E.01841
G1 X100.343 Y141.028 E.01528
G1 X99.152 Y140.309 E.03384
G1 X98.2 Y139.543 E.02972
G1 X97.751 Y139.109 E.01519
G1 X96.858 Y138.042 E.03384
G1 X96.206 Y137.009 E.02971
G1 X95.923 Y136.453 E.01518
G1 X95.424 Y135.153 E.03387
G1 X95.143 Y133.966 E.02967
G1 X95.021 Y132.948 E.02494
G1 X95.021 Y127.642 E.12906
G1 X94.999 Y127.607 E.00101
G1 X94.999 Y95.69 E.77635
G1 X94.926 Y95.543 E.00399
G1 X94.816 Y95.507 E.00282
G1 X92.846 Y95.507 E.04792
G1 X91.995 Y95.482 E.02071
G1 X91.851 Y95.39 E.00416
G1 X91.757 Y95.188 E.00542
G1 X91.75 Y93.803 E.03369
G1 X91.794 Y93.554 E.00615
G1 X91.911 Y93.372 E.00526
G1 X92.078 Y93.321 E.00425
G1 X104.927 Y93.321 E.31254
G1 X105 Y93.366 E.00209
G1 X105 Y98.274 E.11938
G1 X104.729 Y98.274 E.00659
G1 X104.599 Y98.328 E.00342
G1 X104.546 Y98.457 E.00339
G1 X104.546 Y103.792 E.12977
G1 X104.562 Y103.866 E.00184
G1 X104.729 Y103.974 E.00484
G1 X105 Y103.974 E.00659
G1 X105 Y136.13 E.78216
G1 X104.324 Y136.845 E.02393
G1 X104.129 Y137.17 E.00922
G1 X104.059 Y137.463 E.00733
G1 X104.107 Y137.773 E.00763
G1 X104.33 Y138.162 E.01091
G1 X105 Y138.867 E.02366
G1 X105.003 Y139.352 E.0118
G1 X105.094 Y139.477 E.00376
G1 X105.182 Y139.5 E.00221
G1 X125.817 Y139.5 E.50193
G1 X125.924 Y139.465 E.00274
G1 X125.993 Y139.368 E.0029
G1 X126 Y138.87 E.01211
G1 X126.651 Y138.185 E.02299
G1 X126.871 Y137.83 E.01016
G1 X126.941 Y137.537 E.00733
G1 X126.893 Y137.227 E.00763
G1 X126.67 Y136.838 E.01091
G1 X126 Y136.133 E.02366
G1 X126 Y103.974 E.78224
G1 X126.271 Y103.974 E.00659
G1 X126.414 Y103.906 E.00385
G1 X126.454 Y103.792 E.00294
G1 X126.454 Y98.457 E.12977
G1 X126.431 Y98.368 E.00224
G1 X126.271 Y98.274 E.00451
G1 X126 Y98.274 E.00659
G1 X126 Y93.393 E.11873
G1 X126.04 Y93.319 E.00205
G1 X138.15 Y93.321 E.29456
G1 X139.044 Y93.344 E.02175
G1 X139.201 Y93.497 E.00533
G1 X139.243 Y93.691 E.00483
G1 X139.216 Y95.274 E.03851
G1 X139.09 Y95.456 E.00538
G1 X138.922 Y95.507 E.00427
G1 X136.183 Y95.507 E.06662
G1 X136.074 Y95.543 E.00279
G1 X136 Y95.69 E.004
G1 X136 Y127.168 E.76567
G1 X135.978 Y127.642 E.01154
G1 X135.978 Y132.95 E.12911
G1 X135.924 Y133.507 E.01361
G1 X135.699 Y134.71 E.02977
G1 X135.429 Y135.595 E.02251
G1 X135.198 Y136.18 E.0153
G1 X134.872 Y136.864 E.01843
G1 X134.402 Y137.663 E.02255
G1 X134.04 Y138.177 E.01529
G1 X133.564 Y138.766 E.01842
G1 X132.92 Y139.433 E.02255
G1 X132.447 Y139.848 E.01531
G1 X131.847 Y140.31 E.01842
G1 X131.065 Y140.807 E.02254
G1 X130.508 Y141.1 E.01531
G1 X129.816 Y141.409 E.01843
G1 X128.939 Y141.709 E.02255
G1 X128.329 Y141.864 E.01531
G1 X127.586 Y142.001 E.01838
G1 X126.193 Y142.1 E.03397
G1 X120.91 Y142.1 E.1285
G1 X120.91 Y142.1 F9000
G1 X121.195 Y141.735
;TYPE:Perimeter
G1 F6000
G1 X121.174 Y141.735 E.00051
G1 X121.059 Y141.454 E.00739
G1 X120.667 Y141.289 E.01035
G1 X110.333 Y141.289 E.25136
G1 X110.238 Y141.297 E.00232
G1 X109.941 Y141.453 E.00816
G1 X109.827 Y141.734 E.00738
G1 X104.359 Y141.723 E.133
G1 X103.178 Y141.591 E.02891
G1 X102.595 Y141.473 E.01447
G1 X101.735 Y141.223 E.02178
G1 X101.055 Y140.957 E.01776
G1 X100.516 Y140.705 E.01447
G1 X99.362 Y140.009 E.03278
G1 X98.443 Y139.269 E.0287
G1 X98.019 Y138.86 E.01433
G1 X97.154 Y137.826 E.03279
G1 X96.524 Y136.828 E.02871
G1 X96.257 Y136.304 E.01431
G1 X95.774 Y135.045 E.0328
G1 X95.504 Y133.902 E.02857
G1 X95.386 Y132.926 E.02391
G1 X95.386 Y127.642 E.12853
G1 X95.365 Y127.574 E.00173
G1 X95.365 Y95.69 E.77555
G1 X95.322 Y95.479 E.00524
G1 X95.145 Y95.251 E.00702
G1 X94.816 Y95.141 E.00844
G1 X92.123 Y95.131 E.0655
G1 X92.139 Y93.687 E.03513
G1 X104.634 Y93.687 E.30393
G1 X104.634 Y97.948 E.10364
G1 X104.34 Y98.07 E.00774
G1 X104.25 Y98.19 E.00365
G1 X104.18 Y98.457 E.00671
G1 X104.18 Y103.792 E.12977
G1 X104.186 Y103.869 E.00188
G1 X104.302 Y104.136 E.00708
G1 X104.634 Y104.295 E.00895
G1 X104.634 Y135.976 E.77061
G1 X104.046 Y136.607 E.02098
G1 X103.781 Y137.051 E.01258
G1 X103.691 Y137.541 E.01212
G1 X103.768 Y137.918 E.00936
G1 X104.065 Y138.414 E.01406
G1 X104.634 Y139.013 E.0201
G1 X104.634 Y139.317 E.00739
G1 X104.689 Y139.555 E.00594
G1 X104.916 Y139.797 E.00807
G1 X105.182 Y139.866 E.00668
G1 X125.817 Y139.866 E.50193
G1 X125.912 Y139.857 E.00232
G1 X126.139 Y139.761 E.006
G1 X126.276 Y139.617 E.00483
G1 X126.344 Y139.469 E.00396
G1 X126.366 Y139.024 E.01084
G1 X126.575 Y138.818 E.00714
G1 X126.954 Y138.393 E.01385
G1 X127.228 Y137.929 E.01311
G1 X127.309 Y137.46 E.01158
G1 X127.209 Y137.027 E.01081
G1 X126.935 Y136.586 E.01263
G1 X126.366 Y135.987 E.0201
G1 X126.366 Y104.295 E.77088
G1 X126.698 Y104.136 E.00895
G1 X126.772 Y104.016 E.00343
G1 X126.82 Y103.792 E.00557
G1 X126.82 Y98.457 E.12977
G1 X126.799 Y98.309 E.00364
G1 X126.66 Y98.07 E.00673
G1 X126.366 Y97.948 E.00774
G1 X126.366 Y93.685 E.10369
G1 X138.874 Y93.691 E.30424
G1 X138.868 Y95.141 E.03527
G1 X136.183 Y95.141 E.06531
G1 X135.854 Y95.251 E.00844
G1 X135.677 Y95.479 E.00702
G1 X135.635 Y95.69 E.00523
G1 X135.634 Y127.168 E.76567
G1 X135.613 Y127.642 E.01154
G1 X135.613 Y132.932 E.12867
G1 X135.562 Y133.455 E.01278
G1 X135.343 Y134.623 E.02891
G1 X135.084 Y135.474 E.02164
G1 X134.862 Y136.034 E.01465
G1 X134.549 Y136.692 E.01772
G1 X134.095 Y137.464 E.02178
G1 X133.748 Y137.957 E.01466
G1 X133.29 Y138.524 E.01773
G1 X132.667 Y139.168 E.02179
G1 X132.215 Y139.566 E.01465
G1 X131.637 Y140.01 E.01773
G1 X130.881 Y140.491 E.0218
G1 X130.348 Y140.771 E.01464
G1 X129.682 Y141.068 E.01774
G1 X128.835 Y141.359 E.02178
G1 X128.251 Y141.506 E.01465
G1 X127.54 Y141.638 E.01759
G1 X126.18 Y141.735 E.03316
G1 X121.255 Y141.735 E.1198
G1 X121.255 Y141.735 F9000
G1 X121.287 Y141.184
G1 F6000
G1 X120.667 Y140.923 E.01636
G1 X110.333 Y140.923 E.25136
G1 X110.175 Y140.937 E.00386
G1 X109.681 Y141.197 E.01358
G1 X109.611 Y141.368 E.00449
G1 X104.379 Y141.358 E.12726
G1 X103.235 Y141.23 E.028
G1 X102.682 Y141.118 E.01372
G1 X101.853 Y140.876 E.02101
G1 X101.199 Y140.621 E.01707
G1 X100.688 Y140.382 E.01372
G1 X99.572 Y139.709 E.0317
G1 X98.685 Y138.994 E.02771
G1 X98.287 Y138.61 E.01345
G1 X97.45 Y137.61 E.03172
G1 X96.843 Y136.647 E.02769
G1 X96.592 Y136.155 E.01343
G1 X96.125 Y134.937 E.03173
G1 X95.864 Y133.838 E.02748
G1 X95.752 Y132.904 E.02288
G1 X95.752 Y127.642 E.12799
G1 X95.73 Y127.542 E.00249
G1 X95.73 Y95.69 E.77477
G1 X95.66 Y95.338 E.00873
G1 X95.365 Y94.958 E.0117
G1 X94.816 Y94.776 E.01407
G1 X92.487 Y94.776 E.05665
G1 X92.483 Y94.053 E.01759
G1 X104.269 Y94.052 E.28668
G1 X104.269 Y97.734 E.08956
G1 X104.081 Y97.812 E.00495
G1 X103.931 Y98.011 E.00606
G1 X103.848 Y98.211 E.00527
G1 X103.815 Y98.457 E.00604
G1 X103.815 Y103.792 E.12977
G1 X103.851 Y104.047 E.00626
G1 X104.017 Y104.365 E.00873
G1 X104.269 Y104.485 E.00679
G1 X104.269 Y135.823 E.76227
G1 X103.768 Y136.369 E.01802
G1 X103.557 Y136.699 E.00953
G1 X103.391 Y137.08 E.01011
G1 X103.326 Y137.568 E.01197
G1 X103.391 Y137.92 E.00871
G1 X103.499 Y138.201 E.00732
G1 X103.8 Y138.666 E.01347
G1 X104.269 Y139.159 E.01655
G1 X104.269 Y139.317 E.00384
G1 X104.359 Y139.714 E.0099
G1 X104.739 Y140.116 E.01346
G1 X105.181 Y140.231 E.01111
G1 X125.817 Y140.231 E.50195
G1 X125.975 Y140.218 E.00386
G1 X126.354 Y140.057 E.01002
G1 X126.582 Y139.818 E.00803
G1 X126.695 Y139.571 E.00661
G1 X126.731 Y139.177 E.00962
G1 X126.965 Y138.942 E.00807
G1 X127.324 Y138.501 E.01383
G1 X127.57 Y138.057 E.01235
G1 X127.674 Y137.57 E.01211
G1 X127.609 Y137.08 E.01202
G1 X127.501 Y136.799 E.00732
G1 X127.2 Y136.334 E.01347
G1 X126.731 Y135.841 E.01655
G1 X126.731 Y104.485 E.7627
G1 X126.983 Y104.365 E.00679
G1 X127.105 Y104.166 E.00568
G1 X127.185 Y103.792 E.0093
G1 X127.185 Y98.457 E.12977
G1 X127.183 Y98.391 E.00161
G1 X127.069 Y98.011 E.00965
G1 X126.919 Y97.812 E.00606
G1 X126.731 Y97.734 E.00495
G1 X126.731 Y94.051 E.08959
G1 X138.512 Y94.053 E.28656
G1 X138.512 Y94.776 E.01759
G1 X136.183 Y94.776 E.05665
G1 X136.025 Y94.789 E.00386
G1 X135.635 Y94.958 E.01034
G1 X135.339 Y95.338 E.01172
G1 X135.269 Y95.69 E.00873
G1 X135.269 Y127.168 E.76567
G1 X135.247 Y127.642 E.01154
G1 X135.247 Y132.709 E.12325
G1 X135.2 Y133.404 E.01694
G1 X134.987 Y134.535 E.02799
G1 X134.738 Y135.353 E.0208
G1 X134.527 Y135.888 E.01399
G1 X134.226 Y136.52 E.01703
G1 X133.787 Y137.266 E.02105
G1 X133.456 Y137.736 E.01398
G1 X133.015 Y138.281 E.01705
G1 X132.415 Y138.903 E.02102
G1 X131.983 Y139.283 E.01399
G1 X131.427 Y139.71 E.01705
G1 X130.697 Y140.174 E.02104
G1 X130.189 Y140.442 E.01397
G1 X129.548 Y140.727 E.01706
G1 X128.731 Y141.008 E.02102
G1 X128.173 Y141.149 E.014
G1 X127.494 Y141.275 E.0168
G1 X126.167 Y141.369 E.03236
G1 X121.39 Y141.369 E.1162
G1 X121.329 Y141.22 E.00392
G1 E-5 F3600
G1 X121.329 Y141.22 F9000
G1 X110.113 Y140.587
G1 E5 F2400
;WIDTH:0.37974
G1 F6000
G1 X110.333 Y140.577 E.00506
;WIDTH:0.360642
G1 X120.667 Y140.577 E.22431
G1 E-5 F3600
G1 X120.667 Y140.577 F9000
G1 X120.667 Y139.849
G1 X104.651 Y139.849
G1 X103.792 Y137.933
G1 X103.745 Y137.793
G1 X103.715 Y137.648
G1 X103.705 Y137.5
G1 X103.903 Y124.423
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X103.903 Y135.67 E.27357
G1 X103.491 Y136.132 E.01506
G1 X103.184 Y136.613 E.01388
G1 X103.032 Y137.007 E.01027
G1 X102.961 Y137.596 E.01443
G1 X103.032 Y137.993 E.00981
G1 X103.184 Y138.387 E.01027
G1 X103.535 Y138.918 E.01548
G1 X103.895 Y139.296 E.0127
G1 X103.926 Y139.561 E.00649
G1 X104.03 Y139.873 E.008
G1 X104.561 Y140.436 E.01882
;WIDTH:0.4155
G1 X105.183 Y140.605 E.01634
;WIDTH:0.419288
G1 X109.275 Y140.607 E.10478
G1 X110.113 Y140.587 E.02146
G1 X109.413 Y140.934 E.02001
G1 X109.389 Y140.992 E.00161
G1 X105.182 Y140.986 E.10773
;WIDTH:0.4155
G1 X104.4 Y140.992 E.01983
;WIDTH:0.399999
G1 X103.292 Y140.868 E.02712
G1 X102.77 Y140.762 E.01296
G1 X101.971 Y140.529 E.02024
G1 X101.343 Y140.285 E.01639
G1 X100.86 Y140.059 E.01297
G1 X99.782 Y139.408 E.03063
G1 X98.927 Y138.72 E.02669
G1 X98.555 Y138.361 E.01257
G1 X97.747 Y137.395 E.03063
G1 X97.161 Y136.466 E.02672
G1 X96.926 Y136.006 E.01256
G1 X96.475 Y134.829 E.03066
G1 X96.225 Y133.774 E.02637
G1 X96.118 Y132.882 E.02185
G1 X96.118 Y127.642 E.12746
G1 X96.096 Y127.51 E.00326
G1 X96.096 Y95.69 E.77399
G1 X95.998 Y95.198 E.0122
G1 X95.584 Y94.666 E.0164
G1 X94.816 Y94.414 E.01966
G1 X103.903 Y94.418 E.22103
G1 X103.903 Y97.52 E.07545
G1 X103.822 Y97.554 E.00214
G1 X103.611 Y97.833 E.00851
G1 X103.496 Y98.112 E.00734
G1 X103.449 Y98.457 E.00847
G1 X103.449 Y103.792 E.12977
G1 X103.5 Y104.149 E.00877
G1 X103.732 Y104.594 E.01221
G1 X103.903 Y104.676 E.00461
G1 X103.903 Y124.363 E.47887
G1 E-5 F3600
G1 X103.903 Y124.363 F9000
G1 X103.537 Y135.52
G1 E5 F2400
G1 F6000
G1 X103.012 Y136.184 E.02059
G1 X102.769 Y136.625 E.01225
G1 X102.654 Y137.033 E.01031
G1 X102.597 Y137.623 E.01442
G1 X102.733 Y138.279 E.0163
G1 X103.076 Y138.922 E.01773
G1 X103.552 Y139.466 E.01758
G1 X103.567 Y139.63 E.00401
G1 X103.701 Y140.032 E.01031
G1 X104.243 Y140.607 E.01922
G1 X103.349 Y140.507 E.02188
G1 X102.858 Y140.407 E.01219
G1 X102.088 Y140.183 E.01951
G1 X101.487 Y139.948 E.0157
G1 X101.033 Y139.736 E.01219
G1 X99.993 Y139.108 E.02955
G1 X99.243 Y138.505 E.02341
G1 X98.823 Y138.111 E.01401
G1 X98.043 Y137.179 E.02956
G1 X97.556 Y136.407 E.0222
G1 X97.261 Y135.857 E.01518
G1 X96.825 Y134.721 E.0296
G1 X96.585 Y133.71 E.02527
G1 X96.483 Y132.86 E.02082
G1 X96.483 Y127.642 E.12692
G1 X96.462 Y127.478 E.00402
G1 X96.462 Y95.69 E.77321
G1 X96.335 Y95.057 E.0157
G1 X96.123 Y94.784 E.00841
G1 X103.537 Y94.784 E.18034
G1 X103.537 Y97.33 E.06193
G1 X103.292 Y97.655 E.0099
G1 X103.144 Y98.014 E.00945
G1 X103.083 Y98.457 E.01088
G1 X103.083 Y103.792 E.12977
G1 X103.1 Y104.025 E.00568
G1 X103.227 Y104.465 E.01114
G1 X103.447 Y104.824 E.01024
G1 X103.537 Y104.867 E.00243
G1 X103.537 Y135.46 E.74414
G1 E-5 F3600
G1 X103.537 Y135.46 F9000
G1 X95.348 Y95.158
G1 X92.846 Y94.414
G1 E5 F2400
;WIDTH:0.391736
G1 F6000
G1 X94.816 Y94.414 E.04684
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X92.846 Y94.414 E-.93575
;WIPE_END
G1 E-.56425 F3600
G1 X135.961 Y94.424 F9000
G1 E5 F2400
;WIDTH:0.411382
G1 F6000
G1 X136.183 Y94.414 E.00557
;WIDTH:0.39205
G1 X138.15 Y94.414 E.04681
G1 E-5 F3600
G1 X138.15 Y94.414 F9000
G1 X127.097 Y94.416
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X135.333 Y94.418 E.20033
;WIDTH:0.411382
G1 X135.961 Y94.424 E.01575
G1 X135.415 Y94.666 E.01498
;WIDTH:0.399999
G1 X135.002 Y95.198 E.01638
G1 X134.903 Y95.69 E.01221
G1 X134.903 Y127.168 E.76567
G1 X134.881 Y127.642 E.01154
G1 X134.881 Y132.709 E.12325
G1 X134.837 Y133.352 E.01568
G1 X134.631 Y134.448 E.02713
G1 X134.393 Y135.233 E.01995
G1 X134.191 Y135.742 E.01332
G1 X133.902 Y136.349 E.01635
G1 X133.479 Y137.068 E.02029
G1 X133.164 Y137.516 E.01332
G1 X132.741 Y138.039 E.01636
G1 X132.162 Y138.639 E.02028
G1 X131.751 Y139 E.01331
G1 X131.217 Y139.41 E.01638
G1 X130.514 Y139.858 E.02028
G1 X130.029 Y140.113 E.01333
G1 X129.414 Y140.387 E.01638
G1 X128.626 Y140.657 E.02026
G1 X128.095 Y140.791 E.01332
G1 X127.447 Y140.911 E.01603
G1 X126.788 Y140.958 E.01607
;WIDTH:0.420285
G1 X125.817 Y140.993 E.02495
G1 X121.613 Y140.993 E.10793
G1 X121.589 Y140.935 E.00161
G1 X121.128 Y140.756 E.0127
;WIDTH:0.390463
G1 X120.667 Y140.577 E.01172
G1 X121.197 Y140.592 E.01256
;WIDTH:0.420284
G1 X121.727 Y140.607 E.01361
G1 X125.817 Y140.607 E.105
;WIDTH:0.42589
G1 X126.101 Y140.578 E.00744
G1 X126.568 Y140.353 E.0135
;WIDTH:0.399999
G1 X126.888 Y140.018 E.01127
G1 X127.047 Y139.672 E.00926
G1 X127.096 Y139.331 E.00838
G1 X127.291 Y139.124 E.00692
G1 X127.639 Y138.687 E.01359
G1 X127.912 Y138.185 E.0139
G1 X128.016 Y137.757 E.01071
G1 X128.039 Y137.407 E.00853
G1 X127.968 Y137.007 E.00988
G1 X127.816 Y136.613 E.01027
G1 X127.465 Y136.082 E.01548
G1 X127.097 Y135.695 E.01299
G1 X127.097 Y104.676 E.75451
G1 X127.268 Y104.594 E.00461
G1 X127.5 Y104.149 E.01221
G1 X127.551 Y103.792 E.00877
G1 X127.551 Y98.457 E.12977
G1 X127.504 Y98.112 E.00847
G1 X127.389 Y97.833 E.00734
G1 X127.178 Y97.554 E.00851
G1 X127.097 Y97.52 E.00214
G1 X127.097 Y94.476 E.07404
G1 X127.097 Y94.476 F9000
G1 X127.463 Y94.782
G1 F6000
G1 X134.877 Y94.783 E.18034
G1 X134.664 Y95.057 E.00844
G1 X134.538 Y95.69 E.0157
G1 X134.537 Y127.168 E.76567
G1 X134.516 Y127.642 E.01154
G1 X134.516 Y132.709 E.12325
G1 X134.475 Y133.301 E.01443
G1 X134.276 Y134.361 E.02623
G1 X134.047 Y135.112 E.0191
G1 X133.856 Y135.596 E.01266
G1 X133.579 Y136.177 E.01566
G1 X133.172 Y136.87 E.01955
G1 X132.872 Y137.295 E.01265
G1 X132.467 Y137.796 E.01567
G1 X131.909 Y138.374 E.01954
G1 X131.518 Y138.718 E.01267
G1 X131.007 Y139.11 E.01567
G1 X130.33 Y139.541 E.01952
G1 X129.869 Y139.784 E.01268
G1 X129.28 Y140.046 E.01568
G1 X128.522 Y140.306 E.01949
G1 X128.017 Y140.434 E.01267
G1 X127.401 Y140.548 E.01524
G1 X126.842 Y140.588 E.01363
G1 X127.194 Y140.218 E.01242
G1 X127.398 Y139.774 E.01189
G1 X127.449 Y139.531 E.00604
G1 X127.954 Y138.873 E.02018
G1 X128.255 Y138.314 E.01544
G1 X128.374 Y137.83 E.01212
G1 X128.403 Y137.381 E.01094
G1 X128.326 Y136.933 E.01106
G1 X128.198 Y136.554 E.00973
G1 X127.943 Y136.109 E.01248
G1 X127.463 Y135.549 E.01794
G1 X127.463 Y104.867 E.74631
G1 X127.553 Y104.824 E.00243
G1 X127.773 Y104.465 E.01024
G1 X127.851 Y104.252 E.00552
G1 X127.917 Y103.792 E.0113
G1 X127.917 Y98.457 E.12977
G1 X127.856 Y98.014 E.01088
G1 X127.708 Y97.655 E.00945
G1 X127.463 Y97.33 E.0099
G1 X127.463 Y94.842 E.06052
G1 E-5 F3600
G1 X127.463 Y94.842 F9000
G1 X134.471 Y95.501
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X134.027 Y95.057 E.01527
G1 X133.507 Y95.057 E.01265
G1 X134.264 Y95.814 E.02604
G1 X134.264 Y96.334 E.01265
G1 X132.986 Y95.057 E.04395
G1 X132.466 Y95.057 E.01265
G1 X134.264 Y96.855 E.06185
G1 X134.264 Y97.375 E.01265
G1 X131.946 Y95.057 E.07974
G1 X131.425 Y95.057 E.01267
G1 X134.264 Y97.895 E.09764
G1 X134.264 Y98.416 E.01267
G1 X130.905 Y95.057 E.11555
G1 X130.385 Y95.057 E.01265
G1 X134.264 Y98.936 E.13344
G1 X134.264 Y99.456 E.01265
G1 X129.864 Y95.057 E.15134
G1 X129.344 Y95.057 E.01265
G1 X134.264 Y99.976 E.16923
G1 X134.263 Y100.497 E.01267
G1 X128.824 Y95.057 E.18712
G1 X128.303 Y95.056 E.01267
G1 X134.263 Y101.017 E.20504
G1 X134.263 Y101.537 E.01265
G1 X127.737 Y95.056 E.22372
G1 X127.737 Y95.531 E.01155
G1 X134.263 Y102.057 E.22449
G1 X134.263 Y102.578 E.01267
G1 X127.737 Y96.051 E.22451
G1 X127.737 Y96.571 E.01265
G1 X134.263 Y103.098 E.22451
G1 X134.263 Y103.618 E.01265
G1 X127.737 Y97.092 E.22449
G1 X127.737 Y97.241 E.00362
G1 X127.947 Y97.52 E.00849
G1 X128.132 Y98.007 E.01267
G1 X134.263 Y104.138 E.2109
G1 X134.263 Y104.659 E.01267
G1 X128.191 Y98.586 E.20889
G1 X128.191 Y99.106 E.01265
G1 X134.263 Y105.179 E.20889
G1 X134.263 Y105.699 E.01265
G1 X128.191 Y99.627 E.20887
G1 X128.191 Y100.147 E.01265
G1 X134.263 Y106.219 E.20887
G1 X134.263 Y106.74 E.01267
G1 X128.191 Y100.667 E.20889
G1 X128.191 Y101.188 E.01267
G1 X134.263 Y107.26 E.20887
G1 X134.263 Y107.78 E.01265
G1 X128.191 Y101.708 E.20887
G1 X128.191 Y102.228 E.01265
G1 X134.263 Y108.301 E.20889
G1 X134.263 Y108.821 E.01265
G1 X128.191 Y102.748 E.20889
G1 X128.191 Y103.269 E.01267
G1 X134.263 Y109.341 E.20887
G1 X134.263 Y109.861 E.01265
G1 X128.191 Y103.789 E.20887
G1 X128.133 Y104.251 E.01133
G1 X134.263 Y110.382 E.21089
G1 X134.263 Y110.902 E.01265
G1 X127.991 Y104.63 E.21575
G1 X127.794 Y104.952 E.00918
G1 X134.263 Y111.422 E.22255
G1 X134.263 Y111.942 E.01265
G1 X127.737 Y105.416 E.22449
G1 X127.737 Y105.936 E.01265
G1 X134.263 Y112.463 E.22451
G1 X134.263 Y112.983 E.01265
G1 X127.737 Y106.456 E.22451
G1 X127.737 Y106.977 E.01267
G1 X134.263 Y113.503 E.22449
G1 X134.263 Y114.023 E.01265
G1 X127.737 Y107.497 E.22449
G1 X127.737 Y108.017 E.01265
G1 X134.263 Y114.544 E.22451
G1 X134.263 Y115.064 E.01265
G1 X127.737 Y108.538 E.22449
G1 X127.737 Y109.058 E.01265
G1 X134.263 Y115.584 E.22449
G1 X134.263 Y116.105 E.01267
G1 X127.737 Y109.578 E.22451
G1 X127.737 Y110.098 E.01265
G1 X134.263 Y116.625 E.22451
G1 X134.263 Y117.145 E.01265
G1 X127.737 Y110.619 E.22449
G1 X127.737 Y111.139 E.01265
G1 X134.263 Y117.665 E.22449
G1 X134.263 Y118.186 E.01267
G1 X127.737 Y111.659 E.22451
G1 X127.737 Y112.179 E.01265
G1 X134.263 Y118.706 E.22451
G1 X134.263 Y119.226 E.01265
G1 X127.737 Y112.7 E.22449
G1 X127.737 Y113.22 E.01265
G1 X134.263 Y119.746 E.22449
G1 X134.263 Y120.267 E.01267
G1 X127.737 Y113.74 E.22451
G1 X127.737 Y114.261 E.01267
G1 X134.263 Y120.787 E.22449
G1 X134.263 Y121.307 E.01265
G1 X127.737 Y114.781 E.22449
G1 X127.737 Y115.301 E.01265
G1 X134.263 Y121.827 E.22449
G1 X134.263 Y122.348 E.01267
G1 X127.737 Y115.821 E.22451
G1 X127.737 Y116.342 E.01267
G1 X134.263 Y122.868 E.22449
G1 X134.263 Y123.388 E.01265
G1 X127.737 Y116.862 E.22449
G1 X127.737 Y117.382 E.01265
G1 X134.263 Y123.908 E.22449
G1 X134.263 Y124.429 E.01267
G1 X127.737 Y117.902 E.22451
G1 X127.737 Y118.423 E.01267
G1 X134.263 Y124.949 E.22449
G1 X134.263 Y125.469 E.01265
G1 X127.737 Y118.943 E.22449
G1 X127.737 Y119.463 E.01265
G1 X134.263 Y125.99 E.22451
G1 X134.263 Y126.51 E.01265
G1 X127.737 Y119.984 E.22449
G1 X127.737 Y120.504 E.01265
G1 X134.263 Y127.03 E.22449
G1 X134.253 Y127.54 E.01241
G1 X127.737 Y121.024 E.22415
G1 X127.737 Y121.544 E.01265
G1 X134.241 Y128.049 E.22375
G1 X134.241 Y128.569 E.01265
G1 X127.737 Y122.065 E.22373
G1 X127.737 Y122.585 E.01265
G1 X134.241 Y129.089 E.22373
G1 X134.241 Y129.61 E.01267
G1 X127.737 Y123.105 E.22375
G1 X127.737 Y123.625 E.01265
G1 X134.241 Y130.13 E.22375
G1 X134.241 Y130.65 E.01265
G1 X127.737 Y124.146 E.22373
G1 X127.737 Y124.666 E.01265
G1 X134.241 Y131.17 E.22373
G1 X134.241 Y131.691 E.01267
G1 X127.737 Y125.186 E.22375
G1 X127.737 Y125.707 E.01267
G1 X134.241 Y132.211 E.22373
G1 X134.241 Y132.731 E.01265
G1 X127.737 Y126.227 E.22373
G1 X127.737 Y126.747 E.01265
G1 X134.207 Y133.217 E.22256
G1 X134.129 Y133.659 E.01092
G1 X127.737 Y127.267 E.21988
G1 X127.737 Y127.788 E.01267
G1 X134.046 Y134.097 E.21703
G1 X133.943 Y134.514 E.01045
G1 X127.737 Y128.308 E.21348
G1 X127.737 Y128.828 E.01265
G1 X133.821 Y134.913 E.2093
G1 X133.681 Y135.293 E.00985
G1 X127.737 Y129.348 E.20449
G1 X127.737 Y129.869 E.01267
G1 X133.524 Y135.656 E.19907
G1 X133.356 Y136.008 E.00949
G1 X127.737 Y130.389 E.19329
G1 X127.737 Y130.909 E.01265
G1 X133.166 Y136.338 E.18675
G1 X132.973 Y136.666 E.00926
G1 X127.737 Y131.43 E.18012
G1 X127.737 Y131.95 E.01265
G1 X132.762 Y136.975 E.17286
G1 X132.539 Y137.272 E.00903
G1 X127.737 Y132.47 E.16519
G1 X127.737 Y132.99 E.01265
G1 X132.306 Y137.559 E.15717
G1 X132.055 Y137.829 E.00897
G1 X127.737 Y133.511 E.14854
G1 X127.737 Y134.031 E.01265
G1 X131.799 Y138.093 E.13973
G1 X131.529 Y138.343 E.00895
G1 X127.737 Y134.551 E.13044
G1 X127.737 Y135.071 E.01265
G1 X131.246 Y138.581 E.12072
G1 X130.952 Y138.807 E.00902
G1 X128.272 Y136.127 E.09219
G1 X128.5 Y136.56 E.0119
G1 X128.615 Y136.991 E.01085
G1 X130.642 Y139.017 E.06971
G1 X130.324 Y139.22 E.00918
G1 X128.677 Y137.572 E.05667
G1 X128.611 Y138.026 E.01116
G1 X129.993 Y139.409 E.04756
G1 X129.647 Y139.583 E.00942
G1 X128.5 Y138.436 E.03946
G1 X128.326 Y138.782 E.00942
G1 X129.287 Y139.743 E.03306
G1 X128.907 Y139.884 E.00986
G1 X128.126 Y139.103 E.02687
G1 X127.9 Y139.396 E.009
G1 X128.52 Y140.017 E.02134
G1 X128.11 Y140.127 E.01033
G1 X127.692 Y139.709 E.01438
G1 X127.552 Y140.09 E.00987
G1 X127.819 Y140.357 E.00918
G1 E-5 F3600
G1 X127.819 Y140.357 F9000
G1 X97.989 Y136.888
G1 E5 F2400
G1 F3072.127
G1 X99.351 Y138.24 E.04668
G1 X100.15 Y138.883 E.02495
G1 X101.039 Y139.42 E.02526
G1 X97.664 Y136.044 E.11612
G1 X97.28 Y135.142 E.02385
G1 X101.988 Y139.849 E.16194
G1 X102.746 Y140.089 E.01934
G1 X97.023 Y134.365 E.19688
G1 X96.861 Y133.685 E.017
G1 X103.414 Y140.238 E.22542
G1 X103.543 Y140.252 E.00316
G1 X103.456 Y140.16 E.00308
G1 X103.291 Y139.596 E.01429
G1 X96.788 Y133.093 E.2237
G1 X96.758 Y132.544 E.01337
G1 X102.432 Y138.218 E.19518
G1 X102.325 Y137.593 E.01542
G1 X96.758 Y132.025 E.19152
G1 X96.758 Y131.506 E.01262
G1 X102.359 Y137.108 E.19269
G1 X102.462 Y136.692 E.01042
G1 X96.758 Y130.988 E.19621
G1 X96.758 Y130.469 E.01262
G1 X102.62 Y136.331 E.20165
G1 X102.805 Y135.998 E.00927
G1 X96.758 Y129.95 E.20803
G1 X96.758 Y129.431 E.01262
G1 X103.022 Y135.695 E.21548
G1 X103.262 Y135.416 E.00895
G1 X96.758 Y128.912 E.22373
G1 X96.758 Y128.394 E.0126
G1 X103.263 Y134.899 E.22377
G1 X103.263 Y134.38 E.01262
G1 X96.758 Y127.875 E.22377
G1 X96.736 Y127.334 E.01317
G1 X103.263 Y133.862 E.22454
G1 X103.263 Y133.343 E.01262
G1 X96.736 Y126.815 E.22454
G1 X96.736 Y126.297 E.0126
G1 X103.263 Y132.824 E.22452
G1 X103.263 Y132.305 E.01262
G1 X96.736 Y125.778 E.22452
G1 X96.736 Y125.259 E.01262
G1 X103.263 Y131.786 E.22452
G1 X103.263 Y131.268 E.0126
G1 X96.736 Y124.74 E.22454
G1 X96.736 Y124.222 E.0126
G1 X103.263 Y130.749 E.22452
G1 X103.263 Y130.23 E.01262
G1 X96.736 Y123.703 E.22452
G1 X96.736 Y123.184 E.01262
G1 X103.263 Y129.711 E.22452
G1 X103.263 Y129.192 E.01262
G1 X96.736 Y122.665 E.22452
G1 X96.736 Y122.146 E.01262
G1 X103.263 Y128.674 E.22454
G1 X103.263 Y128.155 E.01262
G1 X96.736 Y121.628 E.22452
G1 X96.736 Y121.109 E.01262
G1 X103.263 Y127.636 E.22452
G1 X103.263 Y127.117 E.01262
G1 X96.736 Y120.59 E.22452
G1 X96.736 Y120.071 E.01262
G1 X103.263 Y126.598 E.22452
G1 X103.263 Y126.08 E.0126
G1 X96.736 Y119.552 E.22454
G1 X96.736 Y119.034 E.0126
G1 X103.263 Y125.561 E.22452
G1 X103.263 Y125.042 E.01262
G1 X96.736 Y118.515 E.22452
G1 X96.736 Y117.996 E.01262
G1 X103.263 Y124.523 E.22452
G1 X103.263 Y124.004 E.01262
G1 X96.736 Y117.477 E.22452
G1 X96.736 Y116.958 E.01262
G1 X103.263 Y123.486 E.22454
G1 X103.263 Y122.967 E.01262
G1 X96.736 Y116.44 E.22452
G1 X96.736 Y115.921 E.01262
G1 X103.263 Y122.448 E.22452
G1 X103.263 Y121.929 E.01262
G1 X96.736 Y115.402 E.22452
G1 X96.736 Y114.883 E.01262
G1 X103.263 Y121.41 E.22452
G1 X103.263 Y120.892 E.0126
G1 X96.736 Y114.364 E.22454
G1 X96.736 Y113.846 E.0126
G1 X103.263 Y120.373 E.22452
G1 X103.263 Y119.854 E.01262
G1 X96.736 Y113.327 E.22452
G1 X96.736 Y112.808 E.01262
G1 X103.263 Y119.335 E.22452
G1 X103.263 Y118.816 E.01262
G1 X96.736 Y112.289 E.22452
G1 X96.736 Y111.77 E.01262
G1 X103.263 Y118.298 E.22454
G1 X103.263 Y117.779 E.01262
G1 X96.736 Y111.252 E.22452
G1 X96.736 Y110.733 E.01262
G1 X103.263 Y117.26 E.22452
G1 X103.263 Y116.741 E.01262
G1 X96.736 Y110.214 E.22452
G1 X96.736 Y109.695 E.01262
G1 X103.263 Y116.222 E.22452
G1 X103.263 Y115.704 E.0126
G1 X96.736 Y109.176 E.22454
G1 X96.736 Y108.658 E.0126
G1 X103.263 Y115.185 E.22452
G1 X103.263 Y114.666 E.01262
G1 X96.736 Y108.139 E.22452
G1 X96.736 Y107.62 E.01262
G1 X103.263 Y114.147 E.22452
G1 X103.263 Y113.628 E.01262
G1 X96.736 Y107.101 E.22452
G1 X96.736 Y106.582 E.01262
G1 X103.263 Y113.11 E.22454
G1 X103.263 Y112.591 E.01262
G1 X96.736 Y106.064 E.22452
G1 X96.736 Y105.545 E.01262
G1 X103.263 Y112.072 E.22452
G1 X103.263 Y111.553 E.01262
G1 X96.736 Y105.026 E.22452
G1 X96.736 Y104.507 E.01262
G1 X103.263 Y111.034 E.22452
G1 X103.263 Y110.516 E.0126
G1 X96.736 Y103.988 E.22454
G1 X96.736 Y103.47 E.0126
G1 X103.263 Y109.997 E.22452
G1 X103.263 Y109.478 E.01262
G1 X96.736 Y102.951 E.22452
G1 X96.736 Y102.432 E.01262
G1 X103.263 Y108.959 E.22452
G1 X103.263 Y108.44 E.01262
G1 X96.736 Y101.913 E.22452
G1 X96.736 Y101.394 E.01262
G1 X103.263 Y107.922 E.22454
G1 X103.263 Y107.403 E.01262
G1 X96.736 Y100.876 E.22452
G1 X96.736 Y100.357 E.01262
G1 X103.263 Y106.884 E.22452
G1 X103.263 Y106.365 E.01262
G1 X96.736 Y99.838 E.22452
G1 X96.736 Y99.319 E.01262
G1 X103.263 Y105.846 E.22452
G1 X103.263 Y105.328 E.0126
G1 X96.736 Y98.8 E.22454
G1 X96.736 Y98.282 E.0126
G1 X102.945 Y104.491 E.21359
G1 X102.813 Y103.84 E.01616
G1 X96.736 Y97.763 E.20905
G1 X96.736 Y97.244 E.01262
G1 X102.809 Y103.318 E.20892
G1 X102.81 Y102.799 E.01262
G1 X96.736 Y96.725 E.20894
G1 X96.736 Y96.206 E.01262
G1 X102.81 Y102.281 E.20896
G1 X102.811 Y101.762 E.01262
G1 X96.736 Y95.688 E.20896
G1 X96.602 Y95.058 E.01567
G1 X102.811 Y101.244 E.21319
G1 X102.812 Y100.726 E.0126
G1 X97.144 Y95.058 E.19498
G1 X97.663 Y95.058 E.01262
G1 X102.812 Y100.207 E.17712
G1 X102.813 Y99.689 E.0126
G1 X98.182 Y95.058 E.1593
G1 X98.7 Y95.058 E.0126
G1 X102.813 Y99.171 E.14148
G1 X102.813 Y98.652 E.01262
G1 X99.219 Y95.058 E.12363
G1 X99.738 Y95.058 E.01262
G1 X102.841 Y98.161 E.10674
G1 X102.955 Y97.756 E.01023
G1 X100.257 Y95.058 E.09281
G1 X100.775 Y95.058 E.0126
G1 X103.132 Y97.415 E.08108
G1 X103.263 Y97.241 E.0053
G1 X103.263 Y97.027 E.00521
G1 X101.294 Y95.058 E.06773
G1 X101.813 Y95.058 E.01262
G1 X103.263 Y96.508 E.04988
G1 X103.263 Y95.989 E.01262
G1 X102.332 Y95.058 E.03203
G1 X102.851 Y95.058 E.01262
G1 X103.428 Y95.635 E.01985
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X102.851 Y95.058 E-.3876
G1 X102.332 Y95.058 E-.24652
G1 X103.263 Y95.989 E-.6254
G1 X103.263 Y96.495 E-.24048
;WIPE_END
G1 X104.204 Y97.926 F9000
G1 X105.507 Y99.908
G1 X111.538 Y109.276
G1 X111.819 Y109.51
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X112.019 Y109.266 E.00767
G1 X112.543 Y108.856 E.01618
G1 X112.949 Y108.671 E.01085
G1 X113.273 Y108.597 E.00808
G1 X113.902 Y108.532 E.01538
G1 X117.372 Y108.534 E.0844
G1 X117.955 Y108.639 E.01441
G1 X118.371 Y108.81 E.01094
G1 X118.899 Y109.182 E.01571
G1 X119.262 Y109.594 E.01336
G1 X121.102 Y112.766 E.0892
G1 X121.275 Y113.127 E.00974
G1 X121.386 Y113.521 E.00996
G1 X121.432 Y114.078 E.01359
G1 X121.377 Y114.522 E.01088
G1 X121.198 Y115.051 E.01358
G1 X119.263 Y118.406 E.09421
G1 X118.986 Y118.739 E.01054
G1 X118.487 Y119.119 E.01526
G1 X118.058 Y119.31 E.01142
G1 X117.767 Y119.411 E.00749
G1 X117.371 Y119.466 E.00972
G1 X113.721 Y119.47 E.08878
G1 X113.142 Y119.388 E.01422
G1 X112.582 Y119.166 E.01465
G1 X112.092 Y118.814 E.01468
G1 X111.685 Y118.328 E.01542
G1 X109.859 Y115.167 E.08879
G1 X109.646 Y114.62 E.01428
G1 X109.567 Y114.022 E.01467
G1 X109.601 Y113.584 E.01069
G1 X109.701 Y113.194 E.00979
G1 X109.859 Y112.833 E.00959
G1 X111.685 Y109.672 E.08879
G1 X111.781 Y109.556 E.00366
G1 X111.781 Y109.556 F9000
G1 X111.53 Y109.289
;TYPE:Perimeter
G1 F6000
G1 X111.738 Y109.032 E.00804
G1 X111.876 Y108.892 E.00478
G1 X112.327 Y108.561 E.01361
G1 X112.833 Y108.323 E.0136
G1 X113.192 Y108.24 E.00896
G1 X113.521 Y108.176 E.00815
G1 X113.902 Y108.166 E.00927
G1 X117.372 Y108.168 E.0844
G1 X118.021 Y108.279 E.01602
G1 X118.553 Y108.492 E.01394
G1 X119.11 Y108.883 E.01655
G1 X119.579 Y109.411 E.01718
G1 X121.418 Y112.583 E.08918
G1 X121.625 Y113.024 E.01185
G1 X121.751 Y113.491 E.01177
G1 X121.796 Y114.049 E.01362
G1 X121.744 Y114.558 E.01245
G1 X121.5 Y115.267 E.01824
G1 X119.579 Y118.589 E.09334
G1 X119.248 Y118.995 E.01274
G1 X118.871 Y119.313 E.012
G1 X118.453 Y119.556 E.01176
G1 X117.928 Y119.746 E.01358
G1 X117.42 Y119.83 E.01252
G1 X113.721 Y119.835 E.08997
G1 X113.09 Y119.75 E.01549
G1 X112.444 Y119.504 E.01681
G1 X111.876 Y119.108 E.01684
G1 X111.422 Y118.588 E.01679
G1 X109.542 Y115.35 E.09107
G1 X109.305 Y114.752 E.01565
G1 X109.204 Y114.067 E.01684
G1 X109.247 Y113.495 E.01395
G1 X109.366 Y113.049 E.01123
G1 X109.542 Y112.65 E.01061
G1 X111.369 Y109.489 E.08881
G1 X111.493 Y109.336 E.00479
G1 X111.493 Y109.336 F9000
G1 X111.242 Y109.068
G1 F6000
G1 X111.457 Y108.798 E.0084
G1 X111.66 Y108.597 E.00695
G1 X112.111 Y108.266 E.01361
G1 X112.61 Y108.017 E.01356
G1 X113.11 Y107.884 E.01258
G1 X113.511 Y107.811 E.00991
G1 X113.903 Y107.801 E.00954
G1 X117.373 Y107.803 E.0844
G1 X118.088 Y107.92 E.01762
G1 X118.599 Y108.108 E.01324
G1 X119.082 Y108.416 E.01393
G1 X119.482 Y108.729 E.01235
G1 X119.895 Y109.227 E.01574
G1 X121.734 Y112.399 E.08918
G1 X121.976 Y112.921 E.014
G1 X122.115 Y113.462 E.01359
G1 X122.161 Y114.019 E.01359
G1 X122.112 Y114.575 E.01358
G1 X121.891 Y115.285 E.01809
G1 X121.816 Y115.45 E.00441
G1 X119.896 Y118.772 E.09333
G1 X119.569 Y119.185 E.01281
G1 X119.183 Y119.536 E.01269
G1 X118.745 Y119.819 E.01268
G1 X118.052 Y120.09 E.0181
G1 X117.372 Y120.197 E.01674
G1 X113.722 Y120.201 E.08878
G1 X113.038 Y120.112 E.01678
G1 X112.306 Y119.843 E.01897
G1 X111.66 Y119.403 E.01901
G1 X111.141 Y118.821 E.01897
G1 X111.052 Y118.694 E.00377
G1 X109.226 Y115.533 E.08879
G1 X108.964 Y114.883 E.01705
G1 X108.841 Y114.112 E.01899
G1 X108.868 Y113.554 E.01359
G1 X108.982 Y113.045 E.01269
G1 X109.225 Y112.467 E.01525
G1 X111.052 Y109.306 E.08881
G1 X111.204 Y109.115 E.00594
G1 X111.204 Y109.115 F9000
G1 X110.953 Y108.847
G1 F6000
G1 X111.176 Y108.564 E.00876
G1 X111.444 Y108.302 E.00912
G1 X111.895 Y107.971 E.01361
G1 X112.458 Y107.685 E.01536
G1 X113.029 Y107.527 E.01441
G1 X113.501 Y107.445 E.01165
G1 X113.903 Y107.435 E.00978
G1 X117.373 Y107.437 E.0844
G1 X117.903 Y107.514 E.01303
G1 X118.405 Y107.634 E.01255
G1 X118.936 Y107.869 E.01412
G1 X119.531 Y108.285 E.01766
G1 X119.87 Y108.617 E.01154
G1 X120.211 Y109.044 E.01329
G1 X122.051 Y112.216 E.0892
G1 X122.327 Y112.818 E.01611
G1 X122.48 Y113.432 E.01539
G1 X122.525 Y113.989 E.01359
G1 X122.474 Y114.619 E.01537
G1 X122.237 Y115.403 E.01992
G1 X122.133 Y115.633 E.00614
G1 X120.212 Y118.955 E.09334
G1 X119.85 Y119.419 E.01431
G1 X119.422 Y119.812 E.01413
G1 X118.936 Y120.131 E.01414
G1 X118.431 Y120.342 E.01331
G1 X117.923 Y120.497 E.01292
G1 X117.373 Y120.563 E.01347
G1 X113.722 Y120.567 E.08881
G1 X113.21 Y120.507 E.01254
G1 X112.685 Y120.392 E.01307
G1 X112.168 Y120.181 E.01358
G1 X111.895 Y120.029 E.0076
G1 X111.444 Y119.698 E.01361
G1 X111.176 Y119.436 E.00912
G1 X110.736 Y118.877 E.0173
G1 X108.909 Y115.716 E.08881
G1 X108.622 Y115.014 E.01845
G1 X108.546 Y114.711 E.0076
G1 X108.478 Y114.156 E.0136
G1 X108.503 Y113.524 E.01538
G1 X108.628 Y112.956 E.01415
G1 X108.909 Y112.284 E.01772
G1 X110.736 Y109.123 E.08881
G1 X110.916 Y108.895 E.00707
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X110.953 Y108.847 E-.02879
G1 X111.176 Y108.564 E-.17114
G1 X111.444 Y108.302 E-.17803
G1 X111.895 Y107.971 E-.26573
G1 X112.458 Y107.685 E-.29995
G1 X113.029 Y107.527 E-.28142
G1 X113.501 Y107.445 E-.22756
G1 X113.601 Y107.442 E-.04738
;WIPE_END
G1 X111.528 Y104.712 F9000
G1 X111.52 Y104.7
G1 X111.82 Y104.489
G1 E5 F2400
G1 F6000
G1 X111.685 Y104.328 E.00511
G1 X109.859 Y101.167 E.08879
G1 X109.646 Y100.62 E.01428
G1 X109.567 Y100.022 E.01467
G1 X109.601 Y99.584 E.01069
G1 X109.701 Y99.194 E.00979
G1 X109.859 Y98.833 E.00959
G1 X111.685 Y95.672 E.08879
G1 X111.936 Y95.343 E.01007
G1 X112.326 Y94.999 E.01265
G1 X112.903 Y94.688 E.01594
G1 X113.494 Y94.546 E.01478
G1 X113.902 Y94.532 E.00993
G1 X117.372 Y94.534 E.0844
G1 X117.955 Y94.639 E.01441
G1 X118.368 Y94.808 E.01085
G1 X118.832 Y95.119 E.01359
G1 X119.263 Y95.594 E.0156
G1 X121.102 Y98.766 E.08918
G1 X121.299 Y99.21 E.01182
G1 X121.386 Y99.521 E.00786
G1 X121.432 Y100.079 E.01362
G1 X121.364 Y100.575 E.01218
G1 X121.197 Y101.054 E.01234
G1 X120.931 Y101.52 E.01305
G1 X119.263 Y104.406 E.08108
G1 X118.98 Y104.744 E.01072
G1 X118.543 Y105.092 E.01359
G1 X118.127 Y105.3 E.01131
G1 X117.767 Y105.411 E.00916
G1 X117.371 Y105.466 E.00972
G1 X113.721 Y105.47 E.08878
G1 X113.142 Y105.388 E.01422
G1 X112.582 Y105.165 E.01466
G1 X112.093 Y104.814 E.01464
G1 X111.859 Y104.535 E.00886
G1 X111.535 Y104.707 F9000
;TYPE:Perimeter
G1 F6000
G1 X111.369 Y104.511 E.00625
G1 X109.542 Y101.35 E.08881
G1 X109.305 Y100.752 E.01565
G1 X109.204 Y100.067 E.01684
G1 X109.236 Y99.55 E.0126
G1 X109.366 Y99.049 E.01259
G1 X109.542 Y98.65 E.01061
G1 X111.369 Y95.489 E.08881
G1 X111.667 Y95.095 E.01202
G1 X112.046 Y94.752 E.01243
G1 X112.73 Y94.366 E.0191
G1 X113.413 Y94.19 E.01716
G1 X113.902 Y94.166 E.01191
G1 X117.372 Y94.168 E.0844
G1 X118.021 Y94.279 E.01602
G1 X118.572 Y94.504 E.01448
G1 X119.036 Y94.816 E.0136
G1 X119.512 Y95.318 E.01683
G1 X119.579 Y95.411 E.00279
G1 X121.418 Y98.583 E.08918
G1 X121.65 Y99.107 E.01394
G1 X121.751 Y99.491 E.00966
G1 X121.796 Y100.049 E.01362
G1 X121.726 Y100.628 E.01419
G1 X121.542 Y101.176 E.01406
G1 X121.248 Y101.703 E.01468
G1 X119.579 Y104.589 E.08109
G1 X119.241 Y105.001 E.01296
G1 X118.771 Y105.378 E.01466
G1 X118.262 Y105.641 E.01394
G1 X117.819 Y105.773 E.01124
G1 X117.372 Y105.832 E.01097
G1 X113.721 Y105.835 E.08881
G1 X113.09 Y105.75 E.01549
G1 X112.444 Y105.504 E.01681
G1 X111.876 Y105.108 E.01684
G1 X111.574 Y104.753 E.01134
G1 X111.574 Y104.753 F9000
G1 X111.24 Y104.933
G1 F6000
G1 X111.141 Y104.821 E.00364
G1 X111.052 Y104.694 E.00377
G1 X109.226 Y101.533 E.08879
G1 X108.964 Y100.883 E.01705
G1 X108.841 Y100.112 E.01899
G1 X108.868 Y99.554 E.01359
G1 X108.982 Y99.045 E.01269
G1 X109.178 Y98.562 E.01268
G1 X111.052 Y95.306 E.09138
G1 X111.399 Y94.846 E.01402
G1 X111.802 Y94.48 E.01324
G1 X112.557 Y94.044 E.02121
G1 X113.331 Y93.833 E.01951
G1 X113.903 Y93.801 E.01394
G1 X117.372 Y93.803 E.08438
G1 X118.088 Y93.92 E.01765
G1 X118.612 Y94.113 E.01358
G1 X119.24 Y94.512 E.0181
G1 X119.783 Y95.073 E.01899
G1 X119.895 Y95.227 E.00463
G1 X121.734 Y98.399 E.08918
G1 X121.976 Y98.921 E.014
G1 X122.112 Y99.426 E.01272
G1 X122.161 Y100.019 E.01447
G1 X122.087 Y100.681 E.0162
G1 X121.887 Y101.298 E.01578
G1 X121.565 Y101.886 E.01631
G1 X119.896 Y104.772 E.08109
G1 X119.569 Y105.185 E.01281
G1 X118.999 Y105.664 E.01811
G1 X118.522 Y105.927 E.01325
G1 X118.016 Y106.102 E.01302
G1 X117.502 Y106.188 E.01268
G1 X113.722 Y106.201 E.09195
G1 X113.038 Y106.112 E.01678
G1 X112.305 Y105.843 E.01899
G1 X111.66 Y105.403 E.01899
G1 X111.28 Y104.978 E.01387
G1 X111.28 Y104.978 F9000
G1 X110.953 Y105.153
G1 F6000
G1 X110.735 Y104.877 E.00855
G1 X108.909 Y101.716 E.08879
G1 X108.622 Y101.014 E.01845
G1 X108.546 Y100.711 E.0076
G1 X108.478 Y100.156 E.0136
G1 X108.503 Y99.524 E.01538
G1 X108.628 Y98.956 E.01415
G1 X108.842 Y98.417 E.01411
G1 X110.736 Y95.123 E.09242
G1 X111.131 Y94.598 E.01598
G1 X111.557 Y94.207 E.01407
G1 X112.384 Y93.722 E.02332
G1 X112.705 Y93.601 E.00834
G1 X113.25 Y93.477 E.0136
G1 X113.903 Y93.435 E.01592
G1 X117.373 Y93.437 E.0844
G1 X118.155 Y93.56 E.01926
G1 X118.75 Y93.775 E.01539
G1 X119.444 Y94.209 E.01991
G1 X119.836 Y94.587 E.01325
G1 X120.212 Y95.044 E.01439
G1 X122.051 Y98.216 E.08918
G1 X122.327 Y98.818 E.01611
G1 X122.462 Y99.303 E.01225
G1 X122.525 Y99.989 E.01676
G1 X122.449 Y100.734 E.01822
G1 X122.231 Y101.421 E.01753
G1 X121.881 Y102.069 E.01791
G1 X120.212 Y104.955 E.08109
G1 X119.85 Y105.419 E.01431
G1 X119.455 Y105.768 E.01282
G1 X119.008 Y106.091 E.01341
G1 X118.482 Y106.338 E.01413
G1 X117.923 Y106.497 E.01414
G1 X117.373 Y106.563 E.01347
G1 X113.722 Y106.567 E.08881
G1 X113.21 Y106.507 E.01254
G1 X112.684 Y106.392 E.0131
G1 X112.167 Y106.181 E.01358
G1 X111.894 Y106.028 E.00761
G1 X111.444 Y105.698 E.01357
G1 X111.176 Y105.436 E.00912
G1 X110.99 Y105.2 E.00731
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X110.953 Y105.153 E-.02841
G1 X110.735 Y104.877 E-.16706
G1 X109.361 Y102.499 E-1.30453
;WIPE_END
G1 X109.217 Y114 F9000
G1 X109.226 Y114.23
G1 X109.254 Y114.458
G1 X109.301 Y114.683
G1 X109.365 Y114.904
G1 X109.448 Y115.119
G1 X109.549 Y115.328
G1 X110.461 Y116.909
G1 X111.195 Y118.177
G1 X111.538 Y123.276
G1 X111.819 Y123.51
G1 E5 F2400
G1 F6000
G1 X112.019 Y123.266 E.00767
G1 X112.543 Y122.856 E.01618
G1 X112.949 Y122.671 E.01085
G1 X113.494 Y122.546 E.0136
G1 X113.902 Y122.532 E.00993
G1 X117.372 Y122.534 E.0844
G1 X117.955 Y122.639 E.01441
G1 X118.371 Y122.81 E.01094
G1 X118.9 Y123.183 E.01574
G1 X119.262 Y123.594 E.01332
G1 X121.102 Y126.766 E.0892
G1 X121.275 Y127.127 E.00974
G1 X121.386 Y127.521 E.00996
G1 X121.432 Y128.079 E.01362
G1 X121.364 Y128.575 E.01218
G1 X121.183 Y129.084 E.01314
G1 X119.245 Y132.431 E.09408
G1 X118.98 Y132.744 E.00998
G1 X118.543 Y133.092 E.01359
G1 X118.152 Y133.292 E.01068
G1 X117.767 Y133.411 E.0098
G1 X117.372 Y133.466 E.0097
G1 X113.721 Y133.47 E.08881
G1 X113.142 Y133.388 E.01422
G1 X112.582 Y133.165 E.01466
G1 X112.092 Y132.814 E.01466
G1 X111.703 Y132.354 E.01465
G1 X109.859 Y129.167 E.08956
G1 X109.646 Y128.62 E.01428
G1 X109.567 Y128.022 E.01467
G1 X109.601 Y127.584 E.01069
G1 X109.701 Y127.194 E.00979
G1 X109.859 Y126.833 E.00959
G1 X111.685 Y123.672 E.08879
G1 X111.781 Y123.556 E.00366
G1 X111.781 Y123.556 F9000
G1 X111.53 Y123.289
;TYPE:Perimeter
G1 F6000
G1 X111.738 Y123.032 E.00804
G1 X111.876 Y122.892 E.00478
G1 X112.327 Y122.561 E.01361
G1 X112.833 Y122.323 E.0136
G1 X113.413 Y122.19 E.01447
G1 X113.902 Y122.166 E.01191
G1 X117.372 Y122.168 E.0844
G1 X118.021 Y122.279 E.01602
G1 X118.516 Y122.471 E.01291
G1 X119.11 Y122.883 E.01758
G1 X119.517 Y123.324 E.0146
G1 X121.418 Y126.583 E.09177
G1 X121.625 Y127.024 E.01185
G1 X121.751 Y127.491 E.01177
G1 X121.796 Y128.049 E.01362
G1 X121.726 Y128.628 E.01419
G1 X121.5 Y129.267 E.01649
G1 X119.526 Y132.665 E.09559
G1 X119.208 Y133.029 E.01176
G1 X118.771 Y133.378 E.0136
G1 X118.262 Y133.641 E.01394
G1 X117.819 Y133.773 E.01124
G1 X117.373 Y133.832 E.01094
G1 X113.721 Y133.835 E.08883
G1 X113.09 Y133.75 E.01549
G1 X112.444 Y133.504 E.01681
G1 X111.876 Y133.108 E.01684
G1 X111.422 Y132.588 E.01679
G1 X109.542 Y129.35 E.09107
G1 X109.305 Y128.752 E.01565
G1 X109.204 Y128.067 E.01684
G1 X109.247 Y127.495 E.01395
G1 X109.366 Y127.049 E.01123
G1 X109.542 Y126.65 E.01061
G1 X111.369 Y123.489 E.08881
G1 X111.493 Y123.336 E.00479
G1 X111.493 Y123.336 F9000
G1 X111.242 Y123.068
G1 F6000
G1 X111.457 Y122.798 E.0084
G1 X111.66 Y122.597 E.00695
G1 X112.111 Y122.266 E.01361
G1 X112.61 Y122.017 E.01356
G1 X113.111 Y121.884 E.01261
G1 X113.511 Y121.811 E.00989
G1 X117.373 Y121.803 E.09394
G1 X118.088 Y121.92 E.01762
G1 X118.612 Y122.113 E.01358
G1 X119.32 Y122.584 E.02068
G1 X119.792 Y123.083 E.01671
G1 X119.895 Y123.227 E.00431
G1 X121.734 Y126.399 E.08918
G1 X121.976 Y126.921 E.014
G1 X122.115 Y127.462 E.01359
G1 X122.161 Y128.019 E.01359
G1 X122.087 Y128.681 E.0162
G1 X121.887 Y129.298 E.01578
G1 X121.817 Y129.45 E.00407
G1 X119.896 Y132.772 E.09334
G1 X119.807 Y132.899 E.00377
G1 X119.436 Y133.315 E.01356
G1 X118.999 Y133.664 E.0136
G1 X118.51 Y133.933 E.01358
G1 X118.016 Y134.102 E.0127
G1 X117.373 Y134.197 E.01581
G1 X113.721 Y134.201 E.08883
G1 X113.038 Y134.112 E.01675
G1 X112.305 Y133.843 E.01899
G1 X111.66 Y133.403 E.01899
G1 X111.141 Y132.821 E.01897
G1 X111.052 Y132.694 E.00377
G1 X109.226 Y129.533 E.08879
G1 X108.964 Y128.883 E.01705
G1 X108.841 Y128.112 E.01899
G1 X108.868 Y127.554 E.01359
G1 X108.982 Y127.045 E.01269
G1 X109.225 Y126.467 E.01525
G1 X111.052 Y123.306 E.08881
G1 X111.204 Y123.115 E.00594
G1 X111.204 Y123.115 F9000
G1 X110.953 Y122.847
G1 F6000
G1 X111.176 Y122.564 E.00876
G1 X111.444 Y122.302 E.00912
G1 X111.895 Y121.971 E.01361
G1 X112.458 Y121.685 E.01536
G1 X113.029 Y121.527 E.01441
G1 X113.501 Y121.445 E.01165
G1 X117.373 Y121.437 E.09418
G1 X117.903 Y121.514 E.01303
G1 X118.405 Y121.634 E.01255
G1 X118.936 Y121.869 E.01412
G1 X119.531 Y122.285 E.01766
G1 X119.87 Y122.617 E.01154
G1 X120.211 Y123.044 E.01329
G1 X122.051 Y126.216 E.0892
G1 X122.327 Y126.818 E.01611
G1 X122.48 Y127.432 E.01539
G1 X122.525 Y127.989 E.01359
G1 X122.449 Y128.734 E.01822
G1 X122.231 Y129.421 E.01753
G1 X122.133 Y129.633 E.00568
G1 X120.212 Y132.955 E.09334
G1 X120.089 Y133.132 E.00524
G1 X119.664 Y133.601 E.0154
G1 X119.227 Y133.95 E.0136
G1 X118.675 Y134.259 E.01539
G1 X118.127 Y134.451 E.01412
G1 X117.554 Y134.55 E.01414
G1 X117.373 Y134.563 E.00441
G1 X113.721 Y134.567 E.08883
G1 X112.986 Y134.474 E.01802
G1 X112.167 Y134.181 E.02116
G1 X111.444 Y133.698 E.02115
G1 X110.86 Y133.055 E.02113
G1 X110.736 Y132.877 E.00528
G1 X108.909 Y129.716 E.08881
G1 X108.622 Y129.014 E.01845
G1 X108.546 Y128.711 E.0076
G1 X108.478 Y128.156 E.0136
G1 X108.503 Y127.524 E.01538
G1 X108.628 Y126.956 E.01415
G1 X108.909 Y126.284 E.01772
G1 X110.736 Y123.123 E.08881
G1 X110.916 Y122.895 E.00707
G1 E-5 F3600
G1 X110.916 Y122.895 F9000
G1 X111.511 Y123.312
G1 X111.395 Y123.477
G1 X111.334 Y123.581
G1 X110.671 Y124.726
G1 X109.549 Y126.672
G1 X109.448 Y126.881
G1 X109.365 Y127.096
G1 X109.301 Y127.317
G1 X109.254 Y127.542
G1 X109.226 Y127.77
G1 X109.217 Y128
G1 X109.226 Y128.23
G1 X109.254 Y128.458
G1 X109.301 Y128.683
G1 X109.365 Y128.904
G1 X109.448 Y129.119
G1 X109.549 Y129.328
G1 X112.346 Y134.649
G1 E5 F2400
G1 F6000
G1 X112.029 Y134.52 E.00832
G1 X111.678 Y134.323 E.00979
G1 X111.228 Y133.993 E.01357
G1 X110.935 Y133.718 E.00977
G1 X110.578 Y133.289 E.01358
G1 X110.419 Y133.06 E.00678
G1 X108.592 Y129.899 E.08881
G1 X108.281 Y129.146 E.01982
G1 X108.184 Y128.756 E.00978
G1 X108.115 Y128.201 E.0136
G1 X108.139 Y127.494 E.01721
G1 X108.273 Y126.868 E.01557
G1 X108.507 Y126.272 E.01557
G1 X110.419 Y122.94 E.09344
G1 X110.895 Y122.331 E.0188
G1 X111.228 Y122.007 E.0113
G1 X111.678 Y121.676 E.01359
G1 X112.307 Y121.352 E.01721
G1 X112.948 Y121.171 E.0162
;WIDTH:0.441282
G1 X113.079 Y121.127 E.00374
;WIDTH:0.482564
G1 X113.211 Y121.084 E.00414
;WIDTH:0.523846
G1 X113.343 Y121.041 E.00452
;WIDTH:0.565128
G1 X113.475 Y120.997 E.00491
G1 X113.339 Y120.957 E.00501
;WIDTH:0.523846
G1 X113.204 Y120.917 E.00458
;WIDTH:0.482564
G1 X113.069 Y120.876 E.00421
;WIDTH:0.441282
G1 X112.934 Y120.836 E.00381
;WIDTH:0.399999
G1 X112.547 Y120.731 E.00975
G1 X112.029 Y120.52 E.01361
G1 X111.678 Y120.324 E.00978
G1 X111.228 Y119.993 E.01359
G1 X110.895 Y119.669 E.0113
G1 X110.419 Y119.06 E.0188
G1 X108.592 Y115.899 E.08881
G1 X108.281 Y115.146 E.01982
G1 X108.184 Y114.756 E.00978
G1 X108.115 Y114.201 E.0136
G1 X108.139 Y113.494 E.01721
G1 X108.273 Y112.868 E.01557
G1 X108.507 Y112.272 E.01557
G1 X110.419 Y108.94 E.09344
G1 X110.895 Y108.331 E.0188
G1 X111.228 Y108.007 E.0113
G1 X111.678 Y107.676 E.01359
G1 X112.307 Y107.352 E.01721
G1 X112.947 Y107.171 E.01618
;WIDTH:0.441286
G1 X113.079 Y107.127 E.00377
;WIDTH:0.482572
G1 X113.211 Y107.084 E.00414
;WIDTH:0.523858
G1 X113.343 Y107.041 E.00452
;WIDTH:0.565144
G1 X113.475 Y106.997 E.00491
G1 X113.339 Y106.957 E.00501
;WIDTH:0.523858
G1 X113.204 Y106.917 E.00458
;WIDTH:0.482572
G1 X113.069 Y106.876 E.00421
;WIDTH:0.441286
G1 X112.934 Y106.836 E.00381
;WIDTH:0.399999
G1 X112.546 Y106.731 E.00978
G1 X112.029 Y106.52 E.01358
G1 X111.678 Y106.323 E.00979
G1 X111.228 Y105.993 E.01357
G1 X110.895 Y105.669 E.0113
G1 X110.419 Y105.06 E.0188
G1 X108.592 Y101.899 E.08881
G1 X108.281 Y101.146 E.01982
G1 X108.184 Y100.756 E.00978
G1 X108.115 Y100.201 E.0136
G1 X108.139 Y99.494 E.01721
G1 X108.273 Y98.868 E.01557
G1 X108.507 Y98.272 E.01557
G1 X110.419 Y94.94 E.09344
G1 X110.863 Y94.349 E.01798
G1 X111.313 Y93.935 E.01487
G1 X111.633 Y93.711 E.0095
G1 X112.21 Y93.4 E.01594
G1 X112.624 Y93.245 E.01075
G1 X113.169 Y93.12 E.0136
G1 X113.903 Y93.069 E.0179
G1 X117.373 Y93.071 E.0844
G1 X118.221 Y93.201 E.02087
G1 X118.888 Y93.436 E.0172
G1 X119.647 Y93.905 E.0217
G1 X120.107 Y94.341 E.01542
G1 X120.528 Y94.861 E.01627
G1 X122.367 Y98.032 E.08916
G1 X122.678 Y98.715 E.01825
G1 X122.822 Y99.236 E.01315
G1 X122.89 Y99.959 E.01766
G1 X122.878 Y100.332 E.00908
G1 X122.804 Y100.833 E.01232
G1 X122.576 Y101.543 E.01814
G1 X122.198 Y102.252 E.01954
G1 X120.529 Y105.138 E.08109
G1 X120.132 Y105.653 E.01582
G1 X119.683 Y106.054 E.01464
G1 X119.264 Y106.367 E.01272
G1 X118.592 Y106.687 E.0181
G1 X117.975 Y106.859 E.01558
;WIDTH:0.43894
G1 X117.862 Y106.894 E.00318
;WIDTH:0.477881
G1 X117.749 Y106.929 E.00349
;WIDTH:0.516822
G1 X117.635 Y106.965 E.00384
;WIDTH:0.555762
G1 X117.522 Y107 E.0041
G1 X117.697 Y107.05 E.00631
;WIDTH:0.516822
G1 X117.872 Y107.1 E.00584
;WIDTH:0.477881
G1 X118.047 Y107.151 E.00538
;WIDTH:0.43894
G1 X118.221 Y107.201 E.00487
;WIDTH:0.399999
G1 X118.875 Y107.431 E.01686
G1 X119.213 Y107.614 E.00935
G1 X119.741 Y107.986 E.01571
G1 X120.145 Y108.376 E.01366
G1 X120.528 Y108.86 E.01501
G1 X122.367 Y112.032 E.08918
G1 X122.678 Y112.715 E.01825
G1 X122.844 Y113.402 E.01719
G1 X122.89 Y113.959 E.01359
G1 X122.837 Y114.664 E.0172
G1 X122.584 Y115.52 E.02171
G1 X122.45 Y115.816 E.0079
G1 X120.529 Y119.138 E.09334
G1 X120.131 Y119.653 E.01583
G1 X119.662 Y120.089 E.01558
G1 X119.128 Y120.442 E.01557
G1 X118.555 Y120.685 E.01514
G1 X117.975 Y120.859 E.01473
;WIDTH:0.43894
G1 X117.862 Y120.894 E.00318
;WIDTH:0.477881
G1 X117.749 Y120.929 E.00349
;WIDTH:0.516822
G1 X117.635 Y120.965 E.00384
;WIDTH:0.555762
G1 X117.522 Y121 E.0041
G1 X117.697 Y121.05 E.00631
;WIDTH:0.516822
G1 X117.872 Y121.1 E.00584
;WIDTH:0.477881
G1 X118.047 Y121.151 E.00538
;WIDTH:0.43894
G1 X118.221 Y121.201 E.00487
;WIDTH:0.399999
G1 X118.81 Y121.404 E.01515
G1 X119.213 Y121.614 E.01105
G1 X119.741 Y121.986 E.01571
G1 X120.145 Y122.376 E.01366
G1 X120.528 Y122.86 E.01501
G1 X122.367 Y126.032 E.08918
G1 X122.678 Y126.715 E.01825
G1 X122.844 Y127.402 E.01719
G1 X122.89 Y127.959 E.01359
G1 X122.878 Y128.332 E.00908
G1 X122.804 Y128.833 E.01232
G1 X122.576 Y129.543 E.01814
G1 X122.45 Y129.816 E.00731
G1 X120.529 Y133.138 E.09334
G1 X120.131 Y133.653 E.01583
G1 X119.455 Y134.236 E.02171
G1 X118.841 Y134.585 E.01718
G1 X118.237 Y134.799 E.01559
G1 X117.606 Y134.912 E.01559
G1 X117.374 Y134.929 E.00566
G1 X113.721 Y134.932 E.08886
G1 X112.934 Y134.836 E.01928
G1 X112.546 Y134.731 E.00978
G1 X112.401 Y134.672 E.00381
G1 E-5 F3600
G1 X112.401 Y134.672 F9000
G1 X109.226 Y128.23
G1 X109.217 Y128
G1 X109.226 Y127.77
G1 X111.528 Y123.288
G1 X111.675 Y123.111
G1 X111.836 Y122.946
G1 X112.01 Y122.796
G1 X112.196 Y122.66
G1 X112.392 Y122.539
G1 X112.597 Y122.435
G1 X112.81 Y122.349
G1 X113.029 Y122.279
G1 X117.522 Y121
G1 E5 F2400
;WIDTH:0.555762
G1 F6000
G1 X117.373 Y121 E.00517
;WIDTH:0.542648
G1 X113.903 Y121.001 E.11733
;WIDTH:0.565128
G1 X113.475 Y120.997 E.01511
G1 E-5 F3600
G1 X113.475 Y120.997 F9000
G1 X111.675 Y118.889
G1 X111.528 Y118.712
G1 X111.395 Y118.523
G1 X111.335 Y118.419
G1 X109.226 Y114.23
G1 X109.217 Y114
G1 X109.226 Y113.77
G1 X109.254 Y113.542
G1 X109.301 Y113.317
G1 X109.365 Y113.096
G1 X109.448 Y112.881
G1 X109.549 Y112.672
G1 X110.461 Y111.091
G1 X111.334 Y109.581
G1 X111.395 Y109.477
G1 X111.528 Y109.288
G1 X111.675 Y109.111
G1 X111.836 Y108.946
G1 X112.01 Y108.796
G1 X112.196 Y108.66
G1 X112.392 Y108.539
G1 X112.597 Y108.435
G1 X112.81 Y108.349
G1 X113.029 Y108.279
G1 X117.522 Y107
G1 E5 F2400
;WIDTH:0.555762
G1 F6000
G1 X117.373 Y107 E.00517
;WIDTH:0.542648
G1 X113.903 Y107.001 E.11733
;WIDTH:0.565144
G1 X113.475 Y106.997 E.01511
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.903 Y107.001 E-.20331
G1 X116.633 Y107 E-1.29669
;WIPE_END
G1 X105.681 Y103.076 F9000
G1 X105.681 Y103.491
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.567 Y103.424 E.00322
G1 X105.158 Y103.424 E.00995
G1 X105.158 Y98.824 E.11189
G1 X105.567 Y98.824 E.00995
G1 X105.705 Y98.762 E.00368
G1 X105.75 Y98.642 E.00312
G1 X105.75 Y91.888 E.16428
G1 X105.696 Y91.758 E.00342
G1 X105.25 Y91.318 E.01524
G1 X104.83 Y90.832 E.01562
G1 X104.696 Y90.523 E.00819
G1 X104.731 Y90.332 E.00472
G1 X105.036 Y89.894 E.01298
G1 X105.583 Y89.351 E.01875
G1 X125.419 Y89.351 E.48249
G1 X125.747 Y89.667 E.01108
G1 X126.09 Y90.044 E.0124
G1 X126.285 Y90.403 E.00994
G1 X126.279 Y90.613 E.00511
G1 X126.08 Y90.969 E.00992
G1 X125.302 Y91.759 E.02697
G1 X125.25 Y91.888 E.00338
G1 X125.25 Y98.556 E.16219
G1 X125.281 Y98.743 E.00461
G1 X125.433 Y98.824 E.00419
G1 X125.842 Y98.824 E.00995
G1 X125.842 Y103.424 E.11189
G1 X125.433 Y103.424 E.00995
G1 X125.292 Y103.491 E.0038
G1 X125.25 Y103.607 E.003
G1 X125.25 Y136.112 E.79065
G1 X125.304 Y136.242 E.00342
G1 X125.75 Y136.682 E.01524
G1 X126.17 Y137.168 E.01562
G1 X126.304 Y137.477 E.00819
G1 X126.285 Y137.582 E.0026
G1 X126.269 Y137.668 E.00213
G1 X125.964 Y138.106 E.01298
G1 X125.417 Y138.649 E.01875
G1 X105.581 Y138.649 E.48249
G1 X105.252 Y138.333 E.0111
G1 X104.91 Y137.956 E.01238
G1 X104.715 Y137.597 E.00994
G1 X104.721 Y137.387 E.00511
G1 X104.92 Y137.031 E.00992
G1 X105.698 Y136.241 E.02697
G1 X105.75 Y136.112 E.00338
G1 X105.75 Y103.607 E.79065
G1 X105.729 Y103.525 E.00206
G1 X105.729 Y103.525 F9000
G1 X105.925 Y103.23
;TYPE:Perimeter
G1 F6000
G1 X105.524 Y103.059 E.0106
G1 X105.524 Y99.233 E.09306
G1 X105.98 Y99.003 E.01242
G1 X106.077 Y98.844 E.00453
G1 X106.116 Y98.642 E.005
G1 X106.116 Y91.888 E.16428
G1 X106.084 Y91.704 E.00454
G1 X105.952 Y91.497 E.00597
G1 X105.324 Y90.878 E.02145
G1 X105.076 Y90.506 E.01087
G1 X105.318 Y90.13 E.01088
G1 X105.733 Y89.717 E.01424
G1 X125.272 Y89.717 E.47527
G1 X125.775 Y90.24 E.01765
G1 X125.928 Y90.481 E.00694
G1 X125.794 Y90.738 E.00705
G1 X125.042 Y91.503 E.02609
G1 X124.915 Y91.706 E.00582
G1 X124.884 Y91.888 E.00449
G1 X124.884 Y98.185 E.15317
G1 X124.899 Y98.768 E.01419
G1 X125.02 Y99.003 E.00643
G1 X125.476 Y99.19 E.01199
G1 X125.476 Y103.059 E.09411
G1 X125.01 Y103.258 E.01233
G1 X124.964 Y103.322 E.00192
G1 X124.884 Y103.607 E.0072
G1 X124.884 Y136.112 E.79065
G1 X124.916 Y136.296 E.00454
G1 X125.048 Y136.503 E.00597
G1 X125.493 Y136.942 E.0152
G1 X125.879 Y137.389 E.01437
G1 X125.925 Y137.515 E.00326
G1 X125.683 Y137.869 E.01043
G1 X125.267 Y138.283 E.01428
G1 X105.728 Y138.283 E.47527
G1 X105.225 Y137.76 E.01765
G1 X105.072 Y137.519 E.00694
G1 X105.206 Y137.262 E.00705
G1 X105.958 Y136.497 E.02609
G1 X106.085 Y136.294 E.00582
G1 X106.116 Y136.112 E.00449
G1 X106.116 Y103.607 E.79065
G1 X106.099 Y103.471 E.00333
G1 X105.991 Y103.259 E.00579
G1 X105.98 Y103.254 E.00029
G1 X106.17 Y102.984 F9000
G1 F6000
G1 X105.889 Y102.845 E.00763
G1 X105.889 Y99.41 E.08355
G1 X106.255 Y99.244 E.00978
G1 X106.417 Y98.98 E.00753
G1 X106.481 Y98.642 E.00837
G1 X106.481 Y91.888 E.16428
G1 X106.428 Y91.581 E.00758
G1 X106.209 Y91.237 E.00992
G1 X105.501 Y90.507 E.02474
G1 X105.884 Y90.083 E.0139
G1 X125.125 Y90.083 E.46802
G1 X125.507 Y90.508 E.0139
G1 X124.781 Y91.247 E.0252
G1 X124.57 Y91.586 E.00971
G1 X124.519 Y91.888 E.00745
G1 X124.519 Y98.556 E.16219
G1 X124.558 Y98.908 E.00861
G1 X124.745 Y99.244 E.00935
G1 X125.111 Y99.41 E.00978
G1 X125.111 Y102.845 E.08355
G1 X124.727 Y103.026 E.01033
G1 X124.574 Y103.293 E.00749
G1 X124.519 Y103.607 E.00775
G1 X124.519 Y136.112 E.79065
G1 X124.572 Y136.419 E.00758
G1 X124.791 Y136.763 E.00992
G1 X125.499 Y137.493 E.02474
G1 X125.116 Y137.917 E.0139
G1 X105.875 Y137.917 E.46802
G1 X105.493 Y137.492 E.0139
G1 X106.219 Y136.753 E.0252
G1 X106.43 Y136.414 E.00971
G1 X106.481 Y136.112 E.00745
G1 X106.481 Y103.607 E.79065
G1 X106.453 Y103.38 E.00556
G1 X106.285 Y103.042 E.00918
G1 X106.224 Y103.011 E.00166
G1 X106.224 Y103.011 F9000
G1 X106.419 Y102.736
G1 F6000
G1 X106.255 Y102.652 E.00448
G1 X106.255 Y99.609 E.07402
G1 X106.53 Y99.484 E.00735
G1 X106.597 Y99.401 E.00259
G1 X106.783 Y99.041 E.00986
G1 X106.847 Y98.642 E.00983
G1 X106.847 Y91.888 E.16428
G1 X106.773 Y91.458 E.01061
G1 X106.466 Y90.976 E.0139
G1 X105.983 Y90.5 E.01649
G1 X106.035 Y90.448 E.00179
G1 X124.962 Y90.448 E.46038
G1 X125.014 Y90.488 E.0016
G1 X124.52 Y90.99 E.01713
G1 X124.225 Y91.465 E.0136
G1 X124.153 Y91.888 E.01044
G1 X124.153 Y98.642 E.16428
G1 X124.224 Y99.063 E.01039
G1 X124.47 Y99.485 E.01188
G1 X124.745 Y99.609 E.00734
G1 X124.745 Y102.652 E.07402
G1 X124.445 Y102.793 E.00806
G1 X124.231 Y103.168 E.0105
G1 X124.153 Y103.607 E.01085
G1 X124.153 Y136.112 E.79065
G1 X124.227 Y136.542 E.01061
G1 X124.534 Y137.024 E.0139
G1 X125.017 Y137.5 E.01649
G1 X124.965 Y137.552 E.00179
G1 X106.038 Y137.552 E.46038
G1 X105.986 Y137.512 E.0016
G1 X106.48 Y137.01 E.01713
G1 X106.775 Y136.535 E.0136
G1 X106.847 Y136.112 E.01044
G1 X106.847 Y103.607 E.79065
G1 X106.769 Y103.168 E.01085
G1 X106.573 Y102.815 E.00982
G1 X106.472 Y102.764 E.00275
G1 X106.472 Y102.764 F9000
G1 X106.677 Y102.49
G1 F6000
G1 X106.621 Y102.459 E.00156
G1 X106.621 Y99.809 E.06446
G1 X106.805 Y99.725 E.00492
G1 X106.892 Y99.618 E.00335
G1 X107.13 Y99.155 E.01266
G1 X107.213 Y98.642 E.01264
G1 X107.213 Y91.888 E.16428
G1 X107.117 Y91.335 E.01365
G1 X106.785 Y90.814 E.01503
G1 X124.21 Y90.814 E.42385
G1 X123.88 Y91.344 E.01519
G1 X123.787 Y91.888 E.01342
G1 X123.787 Y98.556 E.16219
G1 X123.832 Y99.022 E.01139
G1 X124.062 Y99.552 E.01405
G1 X124.195 Y99.726 E.00533
G1 X124.379 Y99.809 E.00491
G1 X124.379 Y102.459 E.06446
G1 X124.163 Y102.561 E.00581
G1 X123.887 Y103.042 E.01349
G1 X123.787 Y103.607 E.01396
G1 X123.787 Y136.112 E.79065
G1 X123.883 Y136.665 E.01365
G1 X124.215 Y137.186 E.01503
G1 X106.79 Y137.186 E.42385
G1 X107.12 Y136.656 E.01519
G1 X107.213 Y136.112 E.01342
G1 X107.213 Y103.607 E.79065
G1 X107.113 Y103.043 E.01393
G1 X106.86 Y102.589 E.01264
G1 X106.73 Y102.519 E.00359
G1 E-5 F3600
G1 X106.73 Y102.519 F9000
G1 X112.028 Y106.638
G1 E5 F2400
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X112.539 Y107.148 E.01756
G1 E-5 F3600
G1 X112.539 Y107.148 F9000
G1 X118.973 Y107.357
G1 E5 F2400
G1 F3072.127
G1 X118.59 Y106.974 E.01317
G1 X118.965 Y106.83 E.00977
G1 X123.513 Y111.378 E.15645
G1 X123.513 Y110.86 E.0126
G1 X119.307 Y106.653 E.1447
G1 X119.624 Y106.452 E.00913
G1 X123.513 Y110.341 E.13378
G1 X123.513 Y109.822 E.01262
G1 X119.913 Y106.222 E.12384
G1 X120.192 Y105.982 E.00895
G1 X123.513 Y109.303 E.11424
G1 X123.513 Y108.784 E.01262
G1 X120.439 Y105.71 E.10574
G1 X120.666 Y105.419 E.00898
G1 X123.513 Y108.266 E.09794
G1 X123.513 Y107.747 E.01262
G1 X120.867 Y105.101 E.09102
G1 X121.057 Y104.772 E.00924
G1 X123.513 Y107.228 E.08448
G1 X123.513 Y106.709 E.01262
G1 X121.247 Y104.443 E.07795
G1 X121.437 Y104.115 E.00922
G1 X123.513 Y106.191 E.07141
G1 X123.513 Y105.672 E.01262
G1 X121.627 Y103.786 E.06488
G1 X121.817 Y103.457 E.00924
G1 X123.513 Y105.153 E.05834
G1 X123.513 Y104.634 E.01262
G1 X122.007 Y103.129 E.05179
G1 X122.198 Y102.8 E.00925
G1 X123.513 Y104.116 E.04525
G1 X123.514 Y103.597 E.01262
G1 X122.388 Y102.471 E.03873
G1 X122.578 Y102.142 E.00924
G1 X123.575 Y103.14 E.03431
G1 X123.716 Y102.762 E.00981
G1 X122.759 Y101.805 E.03292
G1 X122.905 Y101.433 E.00972
G1 X123.913 Y102.441 E.03467
G1 X124.105 Y102.304 E.00574
G1 X124.105 Y102.114 E.00462
G1 X123.032 Y101.04 E.03693
G1 X123.115 Y100.604 E.0108
G1 X124.105 Y101.595 E.03407
G1 X124.105 Y101.076 E.01262
G1 X123.157 Y100.128 E.03261
G1 X123.134 Y99.587 E.01317
G1 X124.105 Y100.557 E.03338
G1 X124.105 Y100.039 E.0126
G1 X123.039 Y98.973 E.03667
G1 X122.733 Y98.147 E.02143
G1 X123.545 Y98.96 E.02795
G1 X123.513 Y98.409 E.01343
G1 X122.05 Y96.946 E.05033
G1 X121.34 Y95.717 E.03452
G1 X123.678 Y98.055 E.08043
G1 E-5 F3600
G1 X123.678 Y98.055 F9000
G1 X123.762 Y91.395
G1 E5 F2400
G1 F3072.127
G1 X123.455 Y91.088 E.01056
G1 X122.936 Y91.088 E.01262
G1 X123.544 Y91.696 E.02091
G1 X123.513 Y92.184 E.01189
G1 X122.417 Y91.088 E.0377
G1 X121.899 Y91.088 E.0126
G1 X123.513 Y92.703 E.05554
G1 X123.513 Y93.221 E.0126
G1 X121.38 Y91.088 E.07337
G1 X120.861 Y91.088 E.01262
G1 X123.513 Y93.74 E.09123
G1 X123.513 Y94.259 E.01262
G1 X120.342 Y91.088 E.10908
G1 X119.824 Y91.088 E.0126
G1 X123.513 Y94.778 E.12692
G1 X123.513 Y95.296 E.0126
G1 X119.305 Y91.088 E.14475
G1 X118.786 Y91.088 E.01262
G1 X123.513 Y95.815 E.16261
G1 X123.513 Y96.334 E.01262
G1 X118.267 Y91.088 E.18046
G1 X117.749 Y91.088 E.0126
G1 X123.513 Y96.853 E.1983
G1 X123.513 Y97.371 E.0126
G1 X117.23 Y91.088 E.21613
G1 X116.711 Y91.088 E.01262
G1 X118.676 Y93.054 E.06761
G1 X117.982 Y92.877 E.01742
G1 X116.192 Y91.088 E.06156
G1 X115.673 Y91.088 E.01262
G1 X117.383 Y92.798 E.05882
G1 X116.863 Y92.797 E.01265
G1 X115.155 Y91.088 E.05877
G1 X114.636 Y91.088 E.01262
G1 X116.344 Y92.797 E.05877
G1 X115.825 Y92.796 E.01262
G1 X114.117 Y91.088 E.05875
G1 X113.598 Y91.088 E.01262
G1 X115.306 Y92.796 E.05875
G1 X114.788 Y92.796 E.0126
G1 X113.08 Y91.088 E.05875
G1 X112.561 Y91.088 E.01262
G1 X114.269 Y92.796 E.05875
G1 X113.752 Y92.798 E.01258
G1 X112.042 Y91.088 E.05882
G1 X111.523 Y91.088 E.01262
G1 X113.267 Y92.832 E.05999
G1 X112.832 Y92.916 E.01078
G1 X111.004 Y91.088 E.06288
G1 X110.486 Y91.088 E.0126
G1 X112.426 Y93.028 E.06673
G1 X112.052 Y93.173 E.00976
G1 X109.967 Y91.088 E.07172
G1 X109.448 Y91.088 E.01262
G1 X111.715 Y93.355 E.07798
G1 X111.389 Y93.548 E.00922
G1 X108.929 Y91.088 E.08462
G1 X108.411 Y91.088 E.0126
G1 X111.09 Y93.768 E.09217
G1 X110.82 Y94.016 E.00892
G1 X107.892 Y91.088 E.10072
G1 X107.373 Y91.088 E.01262
G1 X110.567 Y94.282 E.10987
G1 X110.338 Y94.572 E.00899
G1 X107.454 Y91.687 E.09923
G1 X107.487 Y92.239 E.01345
G1 X110.133 Y94.886 E.09104
G1 X109.943 Y95.215 E.00924
G1 X107.487 Y92.758 E.0845
G1 X107.487 Y93.277 E.01262
G1 X109.753 Y95.544 E.07797
G1 X109.563 Y95.872 E.00922
G1 X107.486 Y93.795 E.07145
G1 X107.486 Y94.314 E.01262
G1 X109.373 Y96.201 E.06491
G1 X109.184 Y96.53 E.00923
G1 X107.486 Y94.833 E.05839
G1 X107.486 Y95.351 E.0126
G1 X108.994 Y96.859 E.05187
G1 X108.804 Y97.188 E.00924
G1 X107.486 Y95.87 E.04534
G1 X107.486 Y96.388 E.0126
G1 X108.614 Y97.516 E.0388
G1 X108.424 Y97.845 E.00924
G1 X107.486 Y96.907 E.03227
G1 X107.485 Y97.426 E.01262
G1 X108.251 Y98.191 E.02633
G1 X108.091 Y98.55 E.00956
G1 X107.485 Y97.944 E.02085
G1 X107.485 Y98.463 E.01262
G1 X107.974 Y98.952 E.01682
G1 X107.877 Y99.374 E.01053
G1 X107.456 Y98.952 E.0145
G1 X107.346 Y99.361 E.0103
G1 X107.84 Y99.856 E.01701
G1 X107.87 Y100.404 E.01335
G1 X107.166 Y99.7 E.02422
G1 X106.909 Y99.962 E.00893
G1 X107.969 Y101.022 E.03646
G1 X108.254 Y101.826 E.02075
G1 X106.895 Y100.467 E.04675
G1 X106.895 Y100.985 E.0126
G1 X108.915 Y103.006 E.0695
G1 X109.625 Y104.234 E.0345
G1 X106.895 Y101.504 E.09391
G1 X106.895 Y102.023 E.01262
G1 X112.043 Y107.171 E.17709
G1 X111.7 Y107.347 E.00938
G1 X107.401 Y103.048 E.14788
G1 X107.487 Y103.652 E.01484
G1 X111.388 Y107.554 E.13421
G1 X111.094 Y107.779 E.00901
G1 X107.487 Y104.171 E.1241
G1 X107.487 Y104.69 E.01262
G1 X110.813 Y108.016 E.11441
G1 X110.573 Y108.295 E.00895
G1 X107.487 Y105.209 E.10616
G1 X107.487 Y105.728 E.01262
G1 X110.338 Y108.578 E.09806
G1 X110.131 Y108.89 E.00911
G1 X107.487 Y106.246 E.09095
G1 X107.487 Y106.765 E.01262
G1 X109.941 Y109.219 E.08442
G1 X109.751 Y109.548 E.00924
G1 X107.487 Y107.284 E.07788
G1 X107.487 Y107.803 E.01262
G1 X109.561 Y109.877 E.07134
G1 X109.371 Y110.205 E.00922
G1 X107.487 Y108.321 E.06481
G1 X107.487 Y108.84 E.01262
G1 X109.181 Y110.534 E.05827
G1 X108.991 Y110.863 E.00924
G1 X107.487 Y109.359 E.05174
G1 X107.487 Y109.878 E.01262
G1 X108.801 Y111.192 E.0452
G1 X108.611 Y111.521 E.00924
G1 X107.487 Y110.396 E.03868
G1 X107.487 Y110.915 E.01262
G1 X108.421 Y111.849 E.03213
G1 X108.248 Y112.196 E.00943
G1 X107.487 Y111.434 E.0262
G1 X107.487 Y111.953 E.01262
G1 X108.09 Y112.555 E.02073
G1 X107.969 Y112.953 E.01012
G1 X107.487 Y112.472 E.01656
G1 X107.487 Y112.99 E.0126
G1 X107.88 Y113.383 E.01352
G1 X107.835 Y113.857 E.01158
G1 X107.487 Y113.509 E.01197
G1 X107.487 Y114.028 E.01262
G1 X107.865 Y114.406 E.013
G1 X107.963 Y115.023 E.0152
G1 X107.487 Y114.547 E.01637
G1 X107.487 Y115.065 E.0126
G1 X108.26 Y115.839 E.02661
G1 X108.924 Y117.022 E.033
G1 X107.487 Y115.584 E.04945
G1 X107.487 Y116.103 E.01262
G1 X110.085 Y118.701 E.08937
G1 E-5 F3600
G1 X110.085 Y118.701 F9000
G1 X112.015 Y120.631
G1 E5 F2400
G1 F3072.127
G1 X112.534 Y121.15 E.01785
G1 X112.162 Y121.297 F9000
G1 F3072.127
G1 X107.487 Y116.622 E.16082
G1 X107.487 Y117.14 E.0126
G1 X111.696 Y121.349 E.14479
G1 X111.384 Y121.557 E.00912
G1 X107.487 Y117.659 E.13407
G1 X107.487 Y118.178 E.01262
G1 X111.09 Y121.781 E.12394
G1 X110.809 Y122.019 E.00896
G1 X107.487 Y118.697 E.11427
G1 X107.487 Y119.216 E.01262
G1 X110.57 Y122.299 E.10605
G1 X110.335 Y122.582 E.00895
G1 X107.487 Y119.734 E.09797
G1 X107.487 Y120.253 E.01262
G1 X110.129 Y122.895 E.09088
G1 X109.94 Y123.225 E.00925
G1 X107.487 Y120.772 E.08438
G1 X107.487 Y121.291 E.01262
G1 X109.75 Y123.554 E.07785
G1 X109.561 Y123.884 E.00925
G1 X107.487 Y121.809 E.07136
G1 X107.487 Y122.328 E.01262
G1 X109.372 Y124.214 E.06486
G1 X109.183 Y124.543 E.00923
G1 X107.487 Y122.847 E.05834
G1 X107.487 Y123.366 E.01262
G1 X108.994 Y124.873 E.05184
G1 X108.805 Y125.203 E.00925
G1 X107.487 Y123.885 E.04534
G1 X107.487 Y124.403 E.0126
G1 X108.616 Y125.532 E.03884
G1 X108.427 Y125.862 E.00925
G1 X107.487 Y124.922 E.03234
G1 X107.487 Y125.441 E.01262
G1 X108.241 Y126.195 E.02594
G1 X108.088 Y126.561 E.00965
G1 X107.487 Y125.96 E.02067
G1 X107.487 Y126.478 E.0126
G1 X107.967 Y126.959 E.01653
G1 X107.879 Y127.389 E.01068
G1 X107.487 Y126.997 E.01348
G1 X107.487 Y127.516 E.01262
G1 X107.835 Y127.864 E.01197
G1 X107.866 Y128.414 E.0134
G1 X107.487 Y128.035 E.01304
G1 X107.487 Y128.553 E.0126
G1 X107.966 Y129.033 E.01649
G1 X108.267 Y129.852 E.02122
G1 X107.487 Y129.072 E.02683
G1 X107.487 Y129.591 E.01262
G1 X108.934 Y131.038 E.04978
G1 X109.644 Y132.267 E.03452
G1 X107.322 Y129.945 E.07988
G1 E-5 F3600
G1 X107.322 Y129.945 F9000
G1 X107.238 Y136.605
G1 E5 F2400
G1 F3072.127
G1 X107.545 Y136.912 E.01056
G1 X108.064 Y136.912 E.01262
G1 X107.456 Y136.304 E.02091
G1 X107.487 Y135.816 E.01189
G1 X108.583 Y136.912 E.0377
G1 X109.101 Y136.912 E.0126
G1 X107.487 Y135.298 E.05552
G1 X107.487 Y134.779 E.01262
G1 X109.62 Y136.912 E.07337
G1 X110.139 Y136.912 E.01262
G1 X107.487 Y134.26 E.09123
G1 X107.487 Y133.741 E.01262
G1 X110.658 Y136.912 E.10908
G1 X111.176 Y136.912 E.0126
G1 X107.487 Y133.222 E.12692
G1 X107.487 Y132.704 E.0126
G1 X111.695 Y136.912 E.14475
G1 X112.214 Y136.912 E.01262
G1 X107.487 Y132.185 E.16261
G1 X107.487 Y131.666 E.01262
G1 X112.733 Y136.912 E.18046
G1 X113.251 Y136.912 E.0126
G1 X107.487 Y131.147 E.1983
G1 X107.487 Y130.629 E.0126
G1 X113.77 Y136.912 E.21613
G1 X114.289 Y136.912 E.01262
G1 X112.306 Y134.929 E.06821
G1 X113.022 Y135.126 E.01806
G1 X114.808 Y136.912 E.06144
G1 X115.327 Y136.912 E.01262
G1 X113.614 Y135.199 E.05893
G1 X114.14 Y135.206 E.0128
G1 X115.845 Y136.912 E.05867
G1 X116.364 Y136.912 E.01262
G1 X114.658 Y135.206 E.05869
G1 X115.176 Y135.205 E.0126
G1 X116.883 Y136.912 E.05872
G1 X117.402 Y136.912 E.01262
G1 X115.694 Y135.205 E.05874
G1 X116.213 Y135.204 E.01262
G1 X117.92 Y136.912 E.05874
G1 X118.439 Y136.912 E.01262
G1 X116.731 Y135.204 E.05875
G1 X117.249 Y135.203 E.0126
G1 X118.958 Y136.912 E.05879
G1 X119.477 Y136.912 E.01262
G1 X117.735 Y135.17 E.05992
G1 X118.179 Y135.095 E.01095
G1 X119.995 Y136.912 E.06249
G1 X120.514 Y136.912 E.01262
G1 X118.581 Y134.978 E.06651
G1 X118.955 Y134.834 E.00975
G1 X121.033 Y136.912 E.07148
G1 X121.552 Y136.912 E.01262
G1 X119.3 Y134.66 E.07747
G1 X119.616 Y134.457 E.00914
G1 X122.071 Y136.912 E.08445
G1 X122.589 Y136.912 E.0126
G1 X119.905 Y134.228 E.09233
G1 X120.182 Y133.986 E.00895
G1 X123.108 Y136.912 E.10065
G1 X123.627 Y136.912 E.01262
G1 X120.433 Y133.718 E.10987
G1 X120.661 Y133.427 E.00899
G1 X123.546 Y136.313 E.09926
G1 X123.513 Y135.761 E.01345
G1 X120.862 Y133.11 E.09119
G1 X121.052 Y132.781 E.00924
G1 X123.513 Y135.242 E.08466
G1 X123.513 Y134.723 E.01262
G1 X121.242 Y132.452 E.07812
G1 X121.432 Y132.123 E.00924
G1 X123.513 Y134.204 E.07159
G1 X123.513 Y133.685 E.01262
G1 X121.622 Y131.795 E.06503
G1 X121.812 Y131.466 E.00924
G1 X123.513 Y133.167 E.05851
G1 X123.513 Y132.648 E.01262
G1 X122.002 Y131.137 E.05198
G1 X122.193 Y130.809 E.00923
G1 X123.513 Y132.129 E.04541
G1 X123.513 Y131.61 E.01262
G1 X122.383 Y130.48 E.03887
G1 X122.573 Y130.151 E.00924
G1 X123.513 Y131.092 E.03235
G1 X123.513 Y130.573 E.01262
G1 X122.753 Y129.812 E.02616
G1 X122.902 Y129.443 E.00968
G1 X123.513 Y130.054 E.02102
G1 X123.513 Y129.535 E.01262
G1 X123.027 Y129.05 E.0167
G1 X123.113 Y128.617 E.01074
G1 X123.513 Y129.017 E.01376
G1 X123.513 Y128.498 E.01262
G1 X123.157 Y128.142 E.01225
G1 X123.136 Y127.601 E.01317
G1 X123.513 Y127.979 E.01299
G1 X123.513 Y127.46 E.01262
G1 X123.045 Y126.992 E.0161
G1 X122.741 Y126.169 E.02134
G1 X123.513 Y126.941 E.02656
G1 X123.513 Y126.423 E.0126
G1 X122.079 Y124.988 E.04935
G1 X121.363 Y123.754 E.0347
G1 X123.678 Y126.068 E.07962
G1 E-5 F3600
G1 X123.678 Y126.068 F9000
G1 X118.963 Y121.354
G1 E5 F2400
G1 F3072.127
G1 X118.571 Y120.962 E.01348
G1 X118.958 Y120.83 E.00995
G1 X123.513 Y125.385 E.15669
G1 X123.513 Y124.866 E.01262
G1 X119.303 Y120.656 E.14482
G1 X119.622 Y120.457 E.00915
G1 X123.513 Y124.348 E.13385
G1 X123.513 Y123.829 E.01262
G1 X119.914 Y120.23 E.1238
G1 X120.188 Y119.985 E.00894
G1 X123.513 Y123.31 E.11438
G1 X123.513 Y122.791 E.01262
G1 X120.436 Y119.714 E.10585
G1 X120.664 Y119.423 E.00899
G1 X123.513 Y122.273 E.09802
G1 X123.513 Y121.754 E.01262
G1 X120.865 Y119.105 E.09111
G1 X121.055 Y118.776 E.00924
G1 X123.513 Y121.235 E.08457
G1 X123.513 Y120.716 E.01262
G1 X121.245 Y118.448 E.07802
G1 X121.435 Y118.119 E.00924
G1 X123.513 Y120.197 E.07148
G1 X123.513 Y119.679 E.0126
G1 X121.625 Y117.79 E.06496
G1 X121.815 Y117.462 E.00922
G1 X123.513 Y119.16 E.05841
G1 X123.513 Y118.641 E.01262
G1 X122.005 Y117.133 E.05187
G1 X122.195 Y116.804 E.00924
G1 X123.513 Y118.122 E.04534
G1 X123.513 Y117.604 E.0126
G1 X122.385 Y116.476 E.0388
G1 X122.575 Y116.147 E.00924
G1 X123.513 Y117.085 E.03227
G1 X123.513 Y116.566 E.01262
G1 X122.754 Y115.807 E.02611
G1 X122.902 Y115.436 E.00972
G1 X123.513 Y116.047 E.02102
G1 X123.513 Y115.528 E.01262
G1 X123.031 Y115.046 E.01658
G1 X123.118 Y114.615 E.0107
G1 X123.513 Y115.01 E.01359
G1 X123.513 Y114.491 E.01262
G1 X123.159 Y114.137 E.01218
G1 X123.135 Y113.594 E.01322
G1 X123.513 Y113.972 E.013
G1 X123.513 Y113.453 E.01262
G1 X123.042 Y112.983 E.01618
G1 X122.734 Y112.156 E.02147
G1 X123.513 Y112.935 E.0268
G1 X123.513 Y112.416 E.01262
G1 X122.069 Y110.972 E.04967
G1 X121.353 Y109.737 E.03472
G1 X123.678 Y112.062 E.07998
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X121.445 Y109.829 E-1.5
;WIPE_END
G1 X121.781 Y100.115 F9000
G1 X121.781 Y99.885
G1 X120.953 Y89.7
G1 X120.915 Y88.151
G1 X120.877 Y86.599
G1 X121.199 Y85.151
G1 X120.85 Y85.5
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X120.85 Y85.237 E.0064
G1 X120.784 Y85.097 E.00376
G1 X120.667 Y85.054 E.00303
G1 X110.333 Y85.054 E.25136
G1 X110.256 Y85.072 E.00192
G1 X110.15 Y85.237 E.00477
G1 X110.15 Y85.5 E.0064
G1 X104.557 Y85.5 E.13604
G1 X103.988 Y85.458 E.01388
G1 X103.44 Y85.334 E.01367
G1 X102.856 Y85.1 E.0153
G1 X102.41 Y84.839 E.01257
G1 X102.051 Y84.543 E.01132
G1 X101.585 Y84.075 E.01606
G1 X101.127 Y83.348 E.0209
G1 X100.87 Y82.635 E.01844
G1 X100.761 Y81.979 E.01618
G1 X100.75 Y78.888 E.07519
G1 X100.695 Y78.758 E.00343
G1 X100.136 Y78.214 E.01897
G1 X99.821 Y77.822 E.01223
G1 X99.693 Y77.524 E.00789
G1 X99.747 Y77.317 E.0052
G1 X100.033 Y76.898 E.01234
G1 X100.583 Y76.351 E.01887
G1 X130.417 Y76.351 E.72568
G1 X130.751 Y76.682 E.01144
G1 X131.175 Y77.158 E.01551
G1 X131.3 Y77.46 E.00795
G1 X131.291 Y77.587 E.0031
G1 X131.126 Y77.909 E.0088
G1 X130.301 Y78.762 E.02887
G1 X130.25 Y78.888 E.00331
G1 X130.24 Y81.704 E.0685
G1 X130.197 Y82.262 E.01361
G1 X130.072 Y82.812 E.01372
G1 X129.862 Y83.346 E.01396
G1 X129.576 Y83.841 E.01391
G1 X129.227 Y84.278 E.0136
G1 X128.799 Y84.672 E.01415
G1 X128.282 Y85.019 E.01515
G1 X127.83 Y85.24 E.01224
G1 X127.289 Y85.406 E.01376
G1 X126.731 Y85.489 E.01372
G1 X120.91 Y85.5 E.14159
G1 X120.91 Y85.5 F9000
G1 X121.192 Y85.133
;TYPE:Perimeter
G1 F6000
G1 X121.167 Y85.133 E.00061
G1 X121.018 Y84.816 E.00852
G1 X120.898 Y84.74 E.00346
G1 X120.667 Y84.689 E.00575
G1 X110.333 Y84.689 E.25136
G1 X110.252 Y84.695 E.00198
G1 X109.981 Y84.816 E.00722
G1 X109.832 Y85.134 E.00854
G1 X105.332 Y85.134 E.10946
G1 X104.303 Y85.114 E.02503
G1 X103.804 Y85.041 E.01227
G1 X103.278 Y84.875 E.01342
G1 X102.825 Y84.658 E.01222
G1 X102.283 Y84.261 E.01634
G1 X101.877 Y83.853 E.014
G1 X101.458 Y83.187 E.01914
G1 X101.225 Y82.542 E.01668
G1 X101.127 Y81.948 E.01464
G1 X101.116 Y78.887 E.07446
G1 X101.083 Y78.702 E.00457
G1 X100.95 Y78.496 E.00596
G1 X100.192 Y77.719 E.0264
G1 X100.064 Y77.5 E.00617
G1 X100.306 Y77.142 E.01051
G1 X100.733 Y76.717 E.01465
G1 X130.267 Y76.717 E.71839
G1 X130.694 Y77.142 E.01465
G1 X130.936 Y77.5 E.01051
G1 X130.835 Y77.684 E.00511
G1 X130.039 Y78.508 E.02787
G1 X129.915 Y78.708 E.00572
G1 X129.884 Y78.887 E.00442
G1 X129.873 Y81.953 E.07458
G1 X129.797 Y82.46 E.01247
G1 X129.646 Y82.953 E.01254
G1 X129.421 Y83.419 E.01259
G1 X129.131 Y83.843 E.01249
G1 X128.785 Y84.216 E.01238
G1 X128.176 Y84.657 E.01829
G1 X127.701 Y84.897 E.01294
G1 X127.208 Y85.048 E.01254
G1 X126.704 Y85.123 E.01239
G1 X121.252 Y85.133 E.13261
G1 X121.252 Y85.133 F9000
G1 X121.296 Y84.628
G1 F6000
G1 X121.252 Y84.535 E.0025
G1 X120.931 Y84.362 E.00887
G1 X120.667 Y84.323 E.00649
G1 X110.333 Y84.323 E.25136
G1 X110.068 Y84.362 E.00652
G1 X109.747 Y84.536 E.00888
G1 X109.638 Y84.769 E.00626
G1 X105.332 Y84.769 E.10474
G1 X104.314 Y84.749 E.02477
G1 X103.658 Y84.633 E.0162
G1 X103.01 Y84.343 E.01727
G1 X102.623 Y84.067 E.01156
G1 X102.169 Y83.63 E.01533
G1 X101.789 Y83.026 E.01736
G1 X101.581 Y82.449 E.01492
G1 X101.492 Y81.918 E.0131
G1 X101.481 Y78.886 E.07375
G1 X101.427 Y78.577 E.00763
G1 X101.205 Y78.234 E.00994
G1 X100.487 Y77.501 E.02496
G1 X100.884 Y77.083 E.01402
G1 X130.116 Y77.083 E.71104
G1 X130.509 Y77.496 E.01387
G1 X129.776 Y78.253 E.02563
G1 X129.57 Y78.588 E.00957
G1 X129.519 Y78.886 E.00735
G1 X129.509 Y81.701 E.06847
G1 X129.44 Y82.379 E.01658
G1 X129.203 Y83.029 E.01683
G1 X128.844 Y83.615 E.01672
G1 X128.344 Y84.1 E.01694
G1 X127.807 Y84.45 E.01559
G1 X127.344 Y84.624 E.01203
G1 X126.676 Y84.758 E.01657
G1 X121.361 Y84.767 E.12928
G1 X121.322 Y84.683 E.00225
G1 X121.322 Y84.683 F9000
G1 X121.541 Y84.37
G1 F6000
G1 X121.486 Y84.254 E.00312
G1 X121.036 Y84.012 E.01243
G1 X120.667 Y83.957 E.00907
G1 X110.333 Y83.957 E.25136
G1 X109.963 Y84.012 E.0091
G1 X109.512 Y84.255 E.01246
G1 X109.443 Y84.403 E.00397
G1 X104.493 Y84.395 E.1204
G1 X103.965 Y84.328 E.01295
G1 X103.339 Y84.112 E.01611
G1 X102.855 Y83.784 E.01422
G1 X102.461 Y83.408 E.01325
G1 X102.119 Y82.865 E.01561
G1 X101.936 Y82.356 E.01316
G1 X101.858 Y81.887 E.01156
G1 X101.847 Y78.884 E.07305
G1 X101.77 Y78.453 E.01065
G1 X101.459 Y77.971 E.01395
G1 X100.979 Y77.504 E.01629
G1 X101.035 Y77.448 E.00193
G1 X129.948 Y77.448 E.70328
G1 X130.006 Y77.489 E.00173
G1 X129.513 Y77.999 E.01725
G1 X129.224 Y78.467 E.01338
G1 X129.153 Y78.884 E.01029
G1 X129.146 Y80.933 E.04984
G1 X129.112 Y82.099 E.02837
G1 X128.963 Y82.686 E.01473
G1 X128.67 Y83.222 E.01486
G1 X128.286 Y83.678 E.0145
G1 X127.728 Y84.073 E.01663
G1 X127.237 Y84.274 E.01291
G1 X126.649 Y84.392 E.01459
G1 X121.581 Y84.401 E.12327
G1 X121.581 Y84.401 F9000
G1 X121.812 Y84.035
G1 F6000
G1 X121.75 Y84.035 E.00151
G1 X121.721 Y83.973 E.00166
G1 X121.36 Y83.745 E.01039
G1 X121.141 Y83.662 E.0057
G1 X120.667 Y83.592 E.01165
G1 X110.333 Y83.592 E.25136
G1 X110.091 Y83.61 E.0059
G1 X109.638 Y83.746 E.0115
G1 X109.278 Y83.975 E.01038
G1 X109.248 Y84.037 E.00168
G1 X104.612 Y84.037 E.11277
G1 X104.046 Y83.971 E.01386
G1 X103.5 Y83.782 E.01405
G1 X103.134 Y83.54 E.01067
G1 X102.753 Y83.185 E.01267
G1 X102.45 Y82.703 E.01385
G1 X102.291 Y82.263 E.01138
G1 X102.223 Y81.856 E.01004
G1 X102.213 Y78.883 E.07232
G1 X102.114 Y78.328 E.01371
G1 X101.782 Y77.814 E.01488
G1 X129.208 Y77.814 E.66711
G1 X128.879 Y78.347 E.01524
G1 X128.787 Y78.883 E.01323
G1 X128.78 Y80.932 E.04984
G1 X128.75 Y82.045 E.02708
G1 X128.621 Y82.552 E.01273
G1 X128.368 Y83.015 E.01283
G1 X128.037 Y83.409 E.01252
G1 X127.543 Y83.757 E.0147
G1 X127.13 Y83.925 E.01085
G1 X126.621 Y84.027 E.01263
G1 X121.872 Y84.035 E.11551
G1 E-5 F3600
G1 X121.872 Y84.035 F9000
G1 X128.761 Y78.404
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X128.445 Y78.088 E.01087
G1 X127.921 Y78.088 E.01275
G1 X128.542 Y78.709 E.02136
G1 X128.512 Y79.204 E.01206
G1 X127.397 Y78.088 E.03837
G1 X126.872 Y78.088 E.01277
G1 X128.51 Y79.726 E.05635
G1 X128.508 Y80.249 E.01272
G1 X126.348 Y78.088 E.07432
G1 X125.823 Y78.088 E.01277
G1 X128.506 Y80.771 E.09229
G1 X128.505 Y81.293 E.0127
G1 X125.299 Y78.088 E.11027
G1 X124.775 Y78.088 E.01275
G1 X128.503 Y81.816 E.12824
G1 X128.424 Y82.261 E.01099
G1 X124.25 Y78.088 E.14357
G1 X123.726 Y78.088 E.01275
G1 X128.276 Y82.638 E.15652
G1 X128.074 Y82.96 E.00925
G1 X123.202 Y78.088 E.16759
G1 X122.677 Y78.088 E.01277
G1 X127.821 Y83.231 E.17693
G1 X127.516 Y83.451 E.00915
G1 X122.153 Y78.088 E.18448
G1 X121.629 Y78.088 E.01275
G1 X127.167 Y83.627 E.19052
G1 X126.904 Y83.707 E.00669
G1 X126.747 Y83.731 E.00386
G1 X121.104 Y78.088 E.19412
G1 X120.58 Y78.088 E.01275
G1 X126.245 Y83.753 E.19487
G1 X125.722 Y83.754 E.01272
G1 X120.056 Y78.088 E.19491
G1 X119.531 Y78.088 E.01277
G1 X125.198 Y83.755 E.19494
G1 X124.675 Y83.756 E.01272
G1 X119.007 Y78.088 E.19498
G1 X118.483 Y78.088 E.01275
G1 X124.151 Y83.757 E.19499
G1 X123.628 Y83.758 E.01272
G1 X117.958 Y78.088 E.19504
G1 X117.434 Y78.088 E.01275
G1 X123.105 Y83.759 E.19508
G1 X122.581 Y83.76 E.01275
G1 X116.91 Y78.088 E.1951
G1 X116.385 Y78.088 E.01277
G1 X122.058 Y83.761 E.19515
G1 X121.874 Y83.761 E.00448
G1 X121.479 Y83.497 E.01156
G1 X121.158 Y83.385 E.00827
G1 X115.861 Y78.088 E.18221
G1 X115.337 Y78.088 E.01275
G1 X120.566 Y83.318 E.17989
G1 X120.042 Y83.318 E.01275
G1 X114.812 Y78.088 E.17991
G1 X114.288 Y78.088 E.01275
G1 X119.517 Y83.318 E.17989
G1 X118.993 Y83.318 E.01275
G1 X113.764 Y78.088 E.17989
G1 X113.239 Y78.088 E.01277
G1 X118.469 Y83.318 E.17991
G1 X117.944 Y83.318 E.01277
G1 X112.715 Y78.088 E.17989
G1 X112.191 Y78.088 E.01275
G1 X117.42 Y83.318 E.17989
G1 X116.896 Y83.318 E.01275
G1 X111.666 Y78.088 E.17991
G1 X111.142 Y78.088 E.01275
G1 X116.371 Y83.318 E.17989
G1 X115.847 Y83.318 E.01275
G1 X110.618 Y78.088 E.17989
G1 X110.093 Y78.088 E.01277
G1 X115.323 Y83.318 E.17991
G1 X114.798 Y83.318 E.01277
G1 X109.569 Y78.088 E.17989
G1 X109.044 Y78.088 E.01277
G1 X114.274 Y83.318 E.17991
G1 X113.75 Y83.318 E.01275
G1 X108.52 Y78.088 E.17991
G1 X107.996 Y78.088 E.01275
G1 X113.225 Y83.318 E.17989
G1 X112.701 Y83.318 E.01275
G1 X107.471 Y78.088 E.17991
G1 X106.947 Y78.088 E.01275
G1 X112.177 Y83.318 E.17991
G1 X111.652 Y83.318 E.01277
G1 X106.423 Y78.088 E.17989
G1 X105.898 Y78.088 E.01277
G1 X111.128 Y83.318 E.17991
G1 X110.604 Y83.318 E.01275
G1 X105.374 Y78.088 E.17991
G1 X104.85 Y78.088 E.01275
G1 X110.096 Y83.335 E.18048
G1 X109.676 Y83.438 E.01052
G1 X104.325 Y78.088 E.18405
G1 X103.801 Y78.088 E.01275
G1 X109.334 Y83.621 E.19033
G1 X109.123 Y83.763 E.00619
G1 X108.952 Y83.763 E.00416
G1 X103.277 Y78.088 E.19522
G1 X102.752 Y78.088 E.01277
G1 X108.427 Y83.763 E.19522
G1 X107.903 Y83.763 E.01275
G1 X102.373 Y78.233 E.19023
G1 X102.486 Y78.871 E.01576
G1 X107.379 Y83.763 E.1683
G1 X106.854 Y83.763 E.01277
G1 X102.489 Y79.397 E.15017
G1 X102.491 Y79.924 E.01282
G1 X106.33 Y83.763 E.13206
G1 X105.806 Y83.763 E.01275
G1 X102.492 Y80.45 E.11398
G1 X102.494 Y80.976 E.01279
G1 X105.281 Y83.763 E.09587
G1 X104.757 Y83.763 E.01275
G1 X102.496 Y81.502 E.07778
G1 X102.536 Y82.067 E.01378
G1 X104.193 Y83.723 E.05698
G1 X103.957 Y83.67 E.00588
G1 X103.407 Y83.41 E.0148
G1 X102.52 Y82.575 E.02963
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.407 Y83.41 E-.57864
G1 X103.957 Y83.67 E-.28897
G1 X104.193 Y83.723 E-.11489
G1 X103.423 Y82.953 E-.5175
;WIPE_END
G1 X104.056 Y85.115 F9000
G1 X104.491 Y86.599
G1 X105.067 Y88.151
G1 X105.067 Y88.567
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.151 Y88.503 E.00257
G1 X125.817 Y88.5 E.50268
G1 X125.961 Y88.57 E.00389
G1 X126 Y88.683 E.00291
G1 X126 Y89.133 E.01095
G1 X126.653 Y89.816 E.02298
G1 X126.893 Y90.226 E.01156
G1 X126.941 Y90.537 E.00765
G1 X126.87 Y90.831 E.00736
G1 X126.656 Y91.181 E.00998
G1 X126.324 Y91.556 E.01218
G1 X126 Y91.871 E.01099
G1 X126 Y92.647 E.01888
G1 X139.202 Y92.646 E.32113
G1 X139.511 Y92.728 E.00778
G1 X139.785 Y92.991 E.00924
G1 X139.9 Y93.409 E.01055
G1 X139.9 Y95.42 E.04892
G1 X139.85 Y95.707 E.00709
G1 X139.709 Y95.943 E.00669
G1 X139.412 Y96.145 E.00874
G1 X138.996 Y96.182 E.01016
G1 X136.7 Y96.182 E.05585
G1 X136.698 Y132.81 E.89094
G1 X136.642 Y133.68 E.02121
G1 X136.554 Y134.317 E.01564
G1 X136.444 Y134.867 E.01364
G1 X136.266 Y135.543 E.017
G1 X136.105 Y136.033 E.01255
G1 X135.871 Y136.628 E.01555
G1 X135.57 Y137.265 E.01714
G1 X135.309 Y137.741 E.0132
G1 X135.01 Y138.223 E.0138
G1 X134.672 Y138.702 E.01426
G1 X134.25 Y139.229 E.01642
G1 X133.855 Y139.667 E.01435
G1 X133.387 Y140.123 E.01589
G1 X132.661 Y140.729 E.023
G1 X132.075 Y141.141 E.01742
G1 X131.051 Y141.728 E.02871
G1 X130.548 Y141.962 E.01349
G1 X129.866 Y142.229 E.01781
G1 X128.626 Y142.61 E.03155
G1 X128.104 Y142.734 E.01305
G1 X127.577 Y142.826 E.01301
G1 X126.763 Y142.897 E.01987
G1 X125.482 Y142.902 E.03116
G1 X125.115 Y142.8 E.00927
G1 X120.483 Y142.8 E.11267
G1 X120.353 Y142.746 E.00342
G1 X120.3 Y142.617 E.00339
G1 X120.3 Y142.267 E.00851
G1 X110.7 Y142.267 E.23351
G1 X110.7 Y142.617 E.00851
G1 X110.607 Y142.776 E.00448
G1 X110.517 Y142.8 E.00227
G1 X105.841 Y142.8 E.11374
G1 X105.518 Y142.902 E.00824
G1 X104.5 Y142.902 E.02476
G1 X103.696 Y142.859 E.01958
G1 X102.555 Y142.657 E.02819
G1 X101.607 Y142.384 E.024
G1 X100.855 Y142.127 E.01933
G1 X100.33 Y141.909 E.01383
G1 X99.804 Y141.654 E.01422
G1 X99.134 Y141.274 E.01874
G1 X98.353 Y140.739 E.02303
G1 X97.801 Y140.291 E.01729
G1 X97.28 Y139.804 E.01735
G1 X96.868 Y139.367 E.01461
G1 X96.335 Y138.712 E.02054
G1 X95.996 Y138.232 E.01429
G1 X95.696 Y137.749 E.01383
G1 X95.325 Y137.057 E.0191
G1 X95.089 Y136.533 E.01398
G1 X94.898 Y136.042 E.01281
G1 X94.737 Y135.554 E.0125
G1 X94.6 Y135.054 E.01261
G1 X94.448 Y134.33 E.01799
G1 X94.331 Y133.389 E.02307
G1 X94.302 Y132.81 E.0141
G1 X94.3 Y96.182 E.89094
G1 X91.798 Y96.182 E.06086
G1 X91.526 Y96.121 E.00678
G1 X91.312 Y95.967 E.00641
G1 X91.133 Y95.651 E.00883
G1 X91.1 Y95.42 E.00568
G1 X91.108 Y93.302 E.05152
G1 X91.205 Y93.004 E.00762
G1 X91.371 Y92.803 E.00634
G1 X91.588 Y92.683 E.00603
G1 X91.798 Y92.646 E.00519
G1 X105 Y92.647 E.32113
G1 X105 Y91.867 E.01897
G1 X104.349 Y91.186 E.02292
G1 X104.107 Y90.774 E.01162
G1 X104.059 Y90.463 E.00765
G1 X104.151 Y90.133 E.00833
G1 X104.344 Y89.819 E.00897
G1 X104.676 Y89.444 E.01218
G1 X105 Y89.129 E.01099
G1 X105.017 Y88.605 E.01275
G1 X105.02 Y88.603 E.00009
G1 X105.02 Y88.603 F9000
G1 X104.793 Y88.306
;TYPE:Perimeter
G1 F6000
G1 X104.805 Y88.286 E.00057
G1 X105.183 Y88.134 E.00991
G1 X125.817 Y88.134 E.5019
G1 X126.101 Y88.217 E.0072
G1 X126.269 Y88.377 E.00564
G1 X126.356 Y88.595 E.00571
G1 X126.364 Y88.984 E.00946
G1 X126.916 Y89.561 E.01942
G1 X127.197 Y90.007 E.01282
G1 X127.302 Y90.45 E.01107
G1 X127.231 Y90.9 E.01108
G1 X126.952 Y91.392 E.01376
G1 X126.366 Y92.021 E.02091
G1 X126.366 Y92.281 E.00632
G1 X139.202 Y92.28 E.31222
G1 X139.659 Y92.398 E.01148
G1 X139.867 Y92.536 E.00607
G1 X140.082 Y92.784 E.00798
;WIDTH:0.438052
G1 X140.146 Y92.927 E.00421
;WIDTH:0.476104
G1 X140.21 Y93.07 E.0046
;WIDTH:0.514156
G1 X140.273 Y93.213 E.00499
;WIDTH:0.552208
G1 X140.337 Y93.356 E.0054
G1 X140.34 Y93.409 E.00183
;WIDTH:0.547018
G1 X140.34 Y95.42 E.06858
G1 X140.282 Y95.577 E.00571
;WIDTH:0.498012
G1 X140.224 Y95.733 E.00513
;WIDTH:0.449006
G1 X140.166 Y95.889 E.00459
;WIDTH:0.399999
G1 X139.918 Y96.243 E.01051
G1 X139.476 Y96.505 E.0125
G1 X138.996 Y96.548 E.01172
G1 X137.066 Y96.548 E.04695
G1 X137.065 Y102.714 E.14998
G1 X139.225 Y102.716 E.05254
G1 X139.402 Y102.746 E.00437
G1 X139.686 Y102.888 E.00772
G1 X139.962 Y103.183 E.00983
G1 X140.09 Y103.513 E.00861
G1 X140.145 Y104.022 E.01245
G1 X140.077 Y104.535 E.01259
G1 X139.932 Y104.865 E.00877
G1 X139.743 Y105.078 E.00693
G1 X139.501 Y105.226 E.0069
G1 X139.225 Y105.284 E.00686
G1 X137.065 Y105.286 E.05254
G1 X137.065 Y110.714 E.13203
G1 X139.225 Y110.716 E.05254
G1 X139.402 Y110.746 E.00437
G1 X139.686 Y110.888 E.00772
G1 X139.962 Y111.183 E.00983
G1 X140.09 Y111.513 E.00861
G1 X140.145 Y112.022 E.01245
G1 X140.077 Y112.535 E.01259
G1 X139.932 Y112.865 E.00877
G1 X139.743 Y113.078 E.00693
G1 X139.501 Y113.226 E.0069
G1 X139.225 Y113.284 E.00686
G1 X137.065 Y113.286 E.05254
G1 X137.064 Y118.714 E.13203
G1 X139.225 Y118.716 E.05256
G1 X139.402 Y118.746 E.00437
G1 X139.686 Y118.888 E.00772
G1 X139.962 Y119.183 E.00983
G1 X140.09 Y119.513 E.00861
G1 X140.145 Y120.022 E.01245
G1 X140.077 Y120.535 E.01259
G1 X139.932 Y120.865 E.00877
G1 X139.743 Y121.078 E.00693
G1 X139.501 Y121.226 E.0069
G1 X139.225 Y121.284 E.00686
G1 X137.064 Y121.286 E.05256
G1 X137.064 Y126.714 E.13203
G1 X139.225 Y126.716 E.05256
G1 X139.402 Y126.746 E.00437
G1 X139.686 Y126.888 E.00772
G1 X139.962 Y127.183 E.00983
G1 X140.09 Y127.513 E.00861
G1 X140.145 Y128.022 E.01245
G1 X140.077 Y128.535 E.01259
G1 X139.932 Y128.865 E.00877
G1 X139.743 Y129.078 E.00693
G1 X139.501 Y129.226 E.0069
G1 X139.225 Y129.284 E.00686
G1 X137.064 Y129.286 E.05256
G1 X137.063 Y132.81 E.08572
G1 X137.007 Y133.704 E.02179
G1 X136.916 Y134.368 E.0163
G1 X136.847 Y134.714 E.00858
G1 X139.225 Y134.716 E.05784
G1 X139.402 Y134.746 E.00437
G1 X139.686 Y134.888 E.00772
G1 X139.962 Y135.183 E.00983
G1 X140.09 Y135.513 E.00861
G1 X140.145 Y136.022 E.01245
G1 X140.077 Y136.535 E.01259
G1 X139.932 Y136.865 E.00877
G1 X139.743 Y137.078 E.00693
G1 X139.501 Y137.226 E.0069
G1 X139.225 Y137.284 E.00686
G1 X135.964 Y137.287 E.07932
G1 X135.63 Y137.917 E.01734
G1 X135.321 Y138.416 E.01428
G1 X134.971 Y138.913 E.01479
G1 X134.535 Y139.458 E.01698
G1 X134.126 Y139.912 E.01486
G1 X133.642 Y140.385 E.01646
G1 X132.895 Y141.009 E.02368
G1 X132.285 Y141.44 E.01817
G1 X131.233 Y142.045 E.02952
G1 X130.702 Y142.294 E.01427
G1 X130.012 Y142.565 E.01803
G1 X129.528 Y142.714 E.01232
G1 X139.225 Y142.716 E.23587
G1 X139.402 Y142.746 E.00437
G1 X139.686 Y142.888 E.00772
G1 X139.962 Y143.183 E.00983
G1 X140.09 Y143.513 E.00861
G1 X140.145 Y144.022 E.01245
G1 X140.077 Y144.535 E.01259
G1 X139.932 Y144.865 E.00877
G1 X139.743 Y145.078 E.00693
G1 X139.501 Y145.226 E.0069
G1 X139.225 Y145.284 E.00686
G1 X125.3 Y145.288 E.33871
G1 X125.16 Y145.223 E.00375
G1 X125.117 Y145.105 E.00305
G1 X125.117 Y143.171 E.04704
G1 X120.436 Y143.163 E.11386
G1 X120.142 Y143.038 E.00777
G1 X120.054 Y142.944 E.00313
G1 X119.937 Y142.632 E.00811
G1 X111.063 Y142.632 E.21585
G1 X110.946 Y142.944 E.00811
G1 X110.858 Y143.038 E.00313
G1 X110.564 Y143.163 E.00777
G1 X105.888 Y143.171 E.11374
G1 X105.883 Y145.105 E.04704
G1 X105.826 Y145.238 E.00352
G1 X105.7 Y145.288 E.0033
G1 X91.775 Y145.284 E.33871
G1 X91.598 Y145.254 E.00437
G1 X91.314 Y145.112 E.00772
G1 X91.038 Y144.817 E.00983
G1 X90.91 Y144.487 E.00861
G1 X90.855 Y143.978 E.01245
G1 X90.923 Y143.465 E.01259
G1 X91.068 Y143.135 E.00877
G1 X91.257 Y142.922 E.00693
G1 X91.499 Y142.774 E.0069
G1 X91.775 Y142.716 E.00686
G1 X101.441 Y142.713 E.23512
G1 X100.737 Y142.473 E.01809
G1 X100.259 Y142.275 E.01258
G1 X99.645 Y141.984 E.01653
G1 X98.953 Y141.592 E.01935
G1 X98.146 Y141.04 E.02378
G1 X97.571 Y140.575 E.01799
G1 X97.03 Y140.071 E.01798
G1 X96.602 Y139.618 E.01516
G1 X96.052 Y138.943 E.02118
G1 X95.697 Y138.443 E.01492
G1 X95.385 Y137.942 E.01436
G1 X95.036 Y137.287 E.01805
G1 X91.775 Y137.284 E.07932
G1 X91.598 Y137.254 E.00437
G1 X91.314 Y137.112 E.00772
G1 X91.038 Y136.817 E.00983
G1 X90.91 Y136.487 E.00861
G1 X90.855 Y135.978 E.01245
G1 X90.923 Y135.465 E.01259
G1 X91.068 Y135.135 E.00877
G1 X91.257 Y134.922 E.00693
G1 X91.499 Y134.774 E.0069
G1 X91.775 Y134.716 E.00686
G1 X94.155 Y134.714 E.05789
G1 X93.969 Y133.434 E.03146
G1 X93.937 Y132.838 E.01452
G1 X93.936 Y129.287 E.08637
G1 X91.775 Y129.284 E.05256
G1 X91.598 Y129.254 E.00437
G1 X91.314 Y129.112 E.00772
G1 X91.038 Y128.817 E.00983
G1 X90.91 Y128.487 E.00861
G1 X90.855 Y127.978 E.01245
G1 X90.91 Y127.513 E.01139
G1 X91.068 Y127.135 E.00997
G1 X91.257 Y126.922 E.00693
G1 X91.499 Y126.774 E.0069
G1 X91.775 Y126.716 E.00686
G1 X93.936 Y126.714 E.05256
G1 X93.936 Y121.286 E.13203
G1 X91.775 Y121.284 E.05256
G1 X91.598 Y121.254 E.00437
G1 X91.314 Y121.112 E.00772
G1 X91.038 Y120.817 E.00983
G1 X90.91 Y120.487 E.00861
G1 X90.855 Y119.978 E.01245
G1 X90.923 Y119.465 E.01259
G1 X91.068 Y119.135 E.00877
G1 X91.257 Y118.922 E.00693
G1 X91.499 Y118.774 E.0069
G1 X91.775 Y118.716 E.00686
G1 X93.936 Y118.714 E.05256
G1 X93.935 Y113.286 E.13203
G1 X91.775 Y113.284 E.05254
G1 X91.598 Y113.254 E.00437
G1 X91.314 Y113.112 E.00772
G1 X91.038 Y112.817 E.00983
G1 X90.91 Y112.487 E.00861
G1 X90.855 Y111.978 E.01245
G1 X90.923 Y111.465 E.01259
G1 X91.068 Y111.135 E.00877
G1 X91.257 Y110.922 E.00693
G1 X91.499 Y110.774 E.0069
G1 X91.775 Y110.716 E.00686
G1 X93.935 Y110.714 E.05254
G1 X93.935 Y105.286 E.13203
G1 X91.775 Y105.284 E.05254
G1 X91.598 Y105.254 E.00437
G1 X91.314 Y105.112 E.00772
G1 X91.038 Y104.817 E.00983
G1 X90.91 Y104.487 E.00861
G1 X90.855 Y103.978 E.01245
G1 X90.923 Y103.465 E.01259
G1 X91.068 Y103.135 E.00877
G1 X91.257 Y102.922 E.00693
G1 X91.499 Y102.774 E.0069
G1 X91.775 Y102.716 E.00686
G1 X93.935 Y102.714 E.05254
G1 X93.934 Y96.548 E.14998
G1 X92.001 Y96.548 E.04702
G1 X91.47 Y96.487 E.013
G1 X91.129 Y96.29 E.00958
;WIDTH:0.405113
G1 X90.823 Y95.86 E.01302
;WIDTH:0.454207
G1 X90.77 Y95.732 E.00387
;WIDTH:0.503301
G1 X90.716 Y95.603 E.00436
;WIDTH:0.552395
G1 X90.662 Y95.475 E.00479
;WIDTH:0.554305
G1 X90.665 Y93.301 E.0752
G1 X90.711 Y93.201 E.00381
;WIDTH:0.515729
G1 X90.758 Y93.101 E.00354
;WIDTH:0.477152
G1 X90.804 Y93.001 E.00324
;WIDTH:0.438576
G1 X90.85 Y92.901 E.00296
;WIDTH:0.399999
G1 X91.066 Y92.593 E.00915
G1 X91.388 Y92.374 E.00947
G1 X91.798 Y92.28 E.01023
G1 X104.634 Y92.281 E.31222
G1 X104.634 Y92.014 E.00649
G1 X104.084 Y91.439 E.01935
G1 X103.796 Y90.972 E.01335
G1 X103.698 Y90.55 E.01054
G1 X103.768 Y90.102 E.01103
G1 X104.023 Y89.64 E.01284
G1 X104.636 Y88.976 E.02198
G1 X104.664 Y88.523 E.01104
G1 X104.763 Y88.357 E.0047
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X104.793 Y88.306 E-.02811
G1 X104.805 Y88.286 E-.01108
G1 X105.183 Y88.134 E-.19352
G1 X107.851 Y88.134 E-1.26729
;WIPE_END
G1 X107.851 Y88.151 F9000
G1 X110.638 Y86.599
G1 X110.638 Y86.194
G1 E5 F2400
G1 F6000
G1 X110.517 Y86.25 E.00324
G1 X104.199 Y86.25 E.15368
G1 X103.586 Y86.204 E.01495
G1 X103.023 Y86.081 E.01402
G1 X102.618 Y85.94 E.01043
G1 X102.096 Y85.684 E.01414
G1 X101.364 Y85.147 E.02208
G1 X100.765 Y84.463 E.02212
G1 X100.388 Y83.81 E.01834
G1 X100.128 Y83.07 E.01908
G1 X100.011 Y82.34 E.01798
G1 X100 Y78.868 E.08445
G1 X99.349 Y78.186 E.02293
G1 X99.107 Y77.774 E.01162
G1 X99.059 Y77.463 E.00765
G1 X99.13 Y77.169 E.00736
G1 X99.344 Y76.819 E.00998
G1 X99.676 Y76.444 E.01218
G1 X100 Y76.129 E.01099
G1 X100.004 Y75.82 E.00752
G1 X100.056 Y75.727 E.00259
G1 X100.183 Y75.676 E.00333
G1 X130.817 Y75.676 E.74514
G1 X130.946 Y75.729 E.00339
G1 X131 Y75.859 E.00342
G1 X131 Y76.133 E.00666
G1 X131.651 Y76.814 E.02292
G1 X131.893 Y77.226 E.01162
G1 X131.941 Y77.537 E.00765
G1 X131.87 Y77.831 E.00736
G1 X131.656 Y78.181 E.00998
G1 X131.324 Y78.556 E.01218
G1 X131 Y78.872 E.01101
G1 X130.989 Y82.34 E.08436
G1 X130.935 Y82.771 E.01057
G1 X130.694 Y83.62 E.02147
G1 X130.24 Y84.458 E.02318
G1 X129.874 Y84.911 E.01417
G1 X129.431 Y85.323 E.01472
G1 X128.663 Y85.813 E.02216
G1 X128.099 Y86.043 E.01482
G1 X127.685 Y86.155 E.01043
G1 X127.115 Y86.238 E.01401
G1 X120.483 Y86.25 E.16132
G1 X120.344 Y86.186 E.00372
G1 X120.3 Y86.067 E.00309
G1 X120.3 Y85.697 E.009
G1 X110.7 Y85.697 E.23351
G1 X110.7 Y86.067 E.009
G1 X110.67 Y86.148 E.0021
G1 X110.67 Y86.148 F9000
G1 X110.895 Y86.451
;TYPE:Perimeter
G1 F6000
G1 X110.718 Y86.574 E.00524
G1 X110.517 Y86.616 E.00499
G1 X104.199 Y86.616 E.15368
G1 X103.586 Y86.573 E.01495
G1 X103.053 Y86.462 E.01324
G1 X102.481 Y86.278 E.01462
G1 X101.877 Y85.977 E.01641
G1 X101.087 Y85.386 E.024
G1 X100.447 Y84.645 E.02382
G1 X100.043 Y83.93 E.01998
G1 X99.768 Y83.133 E.02051
G1 X99.652 Y82.426 E.01743
G1 X99.635 Y79.015 E.08297
G1 X99.084 Y78.439 E.01939
G1 X98.811 Y78.01 E.01237
G1 X98.698 Y77.55 E.01152
G1 X98.769 Y77.1 E.01108
G1 X99.048 Y76.608 E.01376
G1 X99.634 Y75.979 E.02091
G1 X99.649 Y75.787 E.00468
G1 X99.761 Y75.524 E.00695
G1 X99.861 Y75.426 E.00341
G1 X100.183 Y75.311 E.00832
G1 X130.817 Y75.311 E.74514
G1 X131.143 Y75.43 E.00844
G1 X131.235 Y75.512 E.003
G1 X131.359 Y75.783 E.00725
G1 X131.364 Y75.984 E.00489
G1 X131.916 Y76.561 E.01942
G1 X132.231 Y77.099 E.01516
G1 X132.305 Y77.569 E.01157
G1 X132.209 Y77.968 E.00998
G1 X131.95 Y78.397 E.01219
G1 X131.365 Y79.022 E.02082
G1 X131.355 Y82.341 E.08073
G1 X131.292 Y82.845 E.01235
G1 X131.014 Y83.796 E.0241
G1 X130.523 Y84.689 E.02479
G1 X130.122 Y85.18 E.01542
G1 X129.625 Y85.633 E.01636
G1 X128.858 Y86.122 E.02213
G1 X128.108 Y86.407 E.01952
G1 X127.781 Y86.508 E.00832
G1 X127.168 Y86.6 E.01508
G1 X120.483 Y86.616 E.16261
G1 X120.212 Y86.541 E.00684
G1 X120.034 Y86.369 E.00602
G1 X119.93 Y86.067 E.00777
G1 X119.28 Y86.062 E.01581
G1 X111.07 Y86.067 E.1997
G1 X110.938 Y86.412 E.00899
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X110.895 Y86.451 E-.02757
G1 X110.718 Y86.574 E-.10238
G1 X110.517 Y86.616 E-.09754
G1 X107.838 Y86.616 E-1.27251
;WIPE_END
G1 X110.938 Y74.209 F9000
G1 E5 F2400
G1 F6000
G1 X135.674 Y74.205 E.60168
G1 X136.198 Y74.242 E.01278
G1 X136.889 Y74.369 E.01709
G1 X137.391 Y74.52 E.01275
G1 X137.877 Y74.71 E.01269
G1 X138.795 Y75.227 E.02563
G1 X139.601 Y75.9 E.02554
G1 X140.273 Y76.706 E.02553
G1 X140.788 Y77.62 E.02552
G1 X141.131 Y78.612 E.02553
G1 X141.289 Y79.653 E.02561
G1 X141.289 Y80.028 E.00912
G1 X141.3 Y150.994 E1.72618
G1 X141.258 Y151.694 E.01706
G1 X141.134 Y152.378 E.01691
G1 X140.928 Y153.042 E.01691
G1 X140.645 Y153.676 E.01689
G1 X140.288 Y154.272 E.0169
G1 X139.862 Y154.822 E.01692
G1 X139.374 Y155.316 E.01689
G1 X138.749 Y155.803 E.01927
G1 X138.241 Y156.111 E.01445
G1 X137.231 Y156.535 E.02664
G1 X136.49 Y156.714 E.01854
G1 X135.832 Y156.79 E.01611
G1 X95.412 Y156.799 E.98318
G1 X94.765 Y156.753 E.01578
G1 X94.075 Y156.622 E.01708
G1 X93.462 Y156.43 E.01562
G1 X92.848 Y156.157 E.01634
G1 X92.17 Y155.748 E.01926
G1 X91.626 Y155.316 E.0169
G1 X91.138 Y154.822 E.01689
G1 X90.712 Y154.272 E.01692
G1 X90.356 Y153.678 E.01684
G1 X89.989 Y152.802 E.0231
G1 X89.794 Y152.037 E.0192
G1 X89.711 Y151.347 E.0169
G1 X89.7 Y80.006 E1.7353
G1 X89.743 Y79.301 E.01718
G1 X89.869 Y78.612 E.01704
G1 X90.077 Y77.943 E.01704
G1 X90.365 Y77.305 E.01703
G1 X90.727 Y76.705 E.01704
G1 X91.159 Y76.154 E.01703
G1 X91.654 Y75.659 E.01703
G1 X92.205 Y75.227 E.01703
G1 X92.804 Y74.865 E.01702
G1 X93.612 Y74.519 E.02138
G1 X94.109 Y74.37 E.01262
G1 X95.153 Y74.211 E.02569
G1 X110.878 Y74.209 E.38249
G1 X110.878 Y74.209 F9000
G1 X110.878 Y74.574
;TYPE:Perimeter
G1 F6000
G1 X134.806 Y74.571 E.58202
G1 X135.962 Y74.592 E.02812
G1 X136.601 Y74.688 E.01572
G1 X137.124 Y74.822 E.01313
G1 X137.72 Y75.041 E.01544
G1 X138.586 Y75.53 E.02419
G1 X139.341 Y76.159 E.0239
G1 X139.971 Y76.914 E.02392
G1 X140.454 Y77.771 E.02393
G1 X140.774 Y78.7 E.0239
G1 X140.923 Y79.68 E.02411
G1 X140.923 Y80.028 E.00846
G1 X140.925 Y92.76 E.30969
;WIDTH:0.448954
G1 X140.901 Y92.976 E.00599
;WIDTH:0.497909
G1 X140.877 Y93.192 E.0067
;WIDTH:0.546863
G1 X140.852 Y93.409 E.00745
;WIDTH:0.547018
G1 X140.852 Y95.42 E.06858
G1 X140.877 Y95.578 E.00546
;WIDTH:0.498012
G1 X140.901 Y95.736 E.00493
;WIDTH:0.449006
G1 X140.926 Y95.894 E.00441
;WIDTH:0.399999
G1 X140.934 Y150.983 E1.33998
G1 X140.896 Y151.626 E.01567
;WIDTH:0.43505
G1 X140.857 Y151.747 E.00339
;WIDTH:0.4701
G1 X140.818 Y151.869 E.00371
;WIDTH:0.50515
G1 X140.779 Y151.99 E.00398
;WIDTH:0.519232
G1 X140.621 Y152.595 E.02017
;WIDTH:0.521429
G1 X140.399 Y153.223 E.02158
;WIDTH:0.480953
G1 X140.337 Y153.403 E.00566
;WIDTH:0.440476
G1 X140.275 Y153.582 E.00512
;WIDTH:0.399999
G1 X139.986 Y154.066 E.01371
G1 X139.587 Y154.58 E.01583
G1 X139.13 Y155.042 E.01581
G1 X138.541 Y155.502 E.01818
G1 X138.074 Y155.784 E.01327
G1 X137.116 Y156.187 E.02528
G1 X136.426 Y156.353 E.01726
G1 X135.811 Y156.424 E.01506
G1 X95.425 Y156.433 E.98235
G1 X94.812 Y156.39 E.01495
G1 X94.164 Y156.266 E.01605
G1 X93.591 Y156.087 E.0146
G1 X93.018 Y155.832 E.01526
G1 X92.379 Y155.447 E.01815
G1 X91.871 Y155.043 E.01579
G1 X91.413 Y154.58 E.01584
G1 X91.014 Y154.066 E.01583
G1 X90.721 Y153.576 E.01389
;WIDTH:0.439681
G1 X90.673 Y153.418 E.00445
;WIDTH:0.479363
G1 X90.624 Y153.26 E.0049
;WIDTH:0.519045
G1 X90.576 Y153.103 E.00529
;WIDTH:0.52074
G1 X90.373 Y152.583 E.01806
G1 X90.197 Y151.941 E.02154
;WIDTH:0.491532
G1 X90.137 Y151.633 E.00954
;WIDTH:0.445766
G1 X90.076 Y151.326 E.00857
;WIDTH:0.399999
G1 X90.068 Y96.189 E1.34115
;WIDTH:0.438098
G1 X90.087 Y96.01 E.00483
;WIDTH:0.476197
G1 X90.106 Y95.832 E.00526
;WIDTH:0.514296
G1 X90.125 Y95.653 E.00575
;WIDTH:0.552394
G1 X90.144 Y95.475 E.00617
;WIDTH:0.554305
G1 X90.145 Y93.3 E.07523
;WIDTH:0.562954
G1 X90.149 Y93.167 E.00468
G1 X90.129 Y93.09 E.0028
;WIDTH:0.522216
G1 X90.108 Y93.012 E.00262
;WIDTH:0.481477
G1 X90.088 Y92.934 E.0024
;WIDTH:0.440738
G1 X90.068 Y92.857 E.00215
;WIDTH:0.399999
G1 X90.066 Y80.017 E.31232
G1 X90.106 Y79.345 E.01637
G1 X90.225 Y78.7 E.01595
G1 X90.42 Y78.073 E.01597
G1 X90.689 Y77.475 E.01595
G1 X91.028 Y76.914 E.01594
G1 X91.433 Y76.397 E.01597
G1 X91.897 Y75.933 E.01596
G1 X92.414 Y75.528 E.01597
G1 X92.971 Y75.192 E.01582
G1 X93.733 Y74.865 E.02017
G1 X94.457 Y74.687 E.01814
G1 X95.18 Y74.577 E.01779
G1 X110.818 Y74.574 E.38038
G1 E-5 F3600
G1 X110.818 Y74.574 F9000
G1 X110.818 Y74.549
G1 X92.012 Y75.814
G1 X90.049 Y80.008
G1 X90.049 Y112.571
G1 X90.494 Y112.571
G1 E5 F2400
;WIDTH:0.516128
G1 F6000
G1 X90.479 Y112.319 E.00809
;WIDTH:0.485872
G1 X90.464 Y112.068 E.00755
;WIDTH:0.483509
G1 X90.478 Y111.766 E.00903
;WIDTH:0.511402
G1 X90.492 Y111.463 E.00963
G1 X90.492 Y111.463 F9000
G1 X90.494 Y112.571
;WIDTH:0.516128
G1 F6000
G1 X90.549 Y112.689 E.00417
;WIDTH:0.477153
G1 X90.684 Y112.912 E.00768
;WIDTH:0.438576
G1 X90.82 Y113.136 E.00705
;WIDTH:0.399999
G1 X91.056 Y113.371 E.0081
G1 X91.445 Y113.587 E.01082
G1 X91.774 Y113.649 E.00814
G1 X93.57 Y113.651 E.04369
G1 X93.57 Y118.349 E.11427
G1 X91.774 Y118.351 E.04369
G1 X91.419 Y118.417 E.00878
G1 X91.053 Y118.619 E.01017
G1 X90.789 Y118.899 E.00936
;WIDTH:0.436728
G1 X90.69 Y119.087 E.00569
;WIDTH:0.473457
G1 X90.591 Y119.275 E.00621
;WIDTH:0.510186
G1 X90.492 Y119.463 E.00673
G1 X90.474 Y119.307 E.00497
;WIDTH:0.473457
G1 X90.456 Y119.15 E.00462
;WIDTH:0.436728
G1 X90.437 Y118.994 E.00421
;WIDTH:0.399999
G1 X90.436 Y113.295 E.13862
;WIDTH:0.438709
G1 X90.456 Y113.054 E.0065
;WIDTH:0.477419
G1 X90.475 Y112.812 E.00715
;WIDTH:0.516128
G1 X90.49 Y112.63 E.00585
G1 E-5 F3600
G1 X90.49 Y112.63 F9000
G1 X93.204 Y114.017
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.204 Y117.983 E.09647
G1 X91.774 Y117.985 E.03478
G1 X91.339 Y118.06 E.01074
G1 X91.028 Y118.195 E.00825
G1 X90.803 Y118.357 E.00674
G1 X90.802 Y113.633 E.11491
G1 X91.293 Y113.919 E.01382
G1 X91.774 Y114.015 E.01193
G1 X93.144 Y114.016 E.03332
G1 E-5 F3600
G1 X93.144 Y114.016 F9000
G1 X92.839 Y117.618
G1 E5 F2400
G1 F6000
G1 X92.004 Y117.619 E.02031
G1 X91.494 Y117.651 E.01243
G1 X91.168 Y117.743 E.00824
G1 X91.168 Y114.26 E.08472
G1 X91.517 Y114.358 E.00882
G1 X91.773 Y114.381 E.00625
G1 X92.838 Y114.382 E.02591
G1 X92.839 Y117.558 E.07725
G1 E-5 F3600
G1 X92.839 Y117.558 F9000
G1 X90.494 Y104.571
G1 E5 F2400
;WIDTH:0.517346
G1 F6000
G1 X90.479 Y104.319 E.00811
;WIDTH:0.487087
G1 X90.463 Y104.068 E.00757
;WIDTH:0.484721
G1 X90.477 Y103.766 E.00906
;WIDTH:0.512614
G1 X90.491 Y103.463 E.00965
G1 E-5 F3600
G1 X90.491 Y103.463 F9000
G1 X93.57 Y110.349
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X91.774 Y110.351 E.04369
G1 X91.419 Y110.417 E.00878
G1 X91.053 Y110.619 E.01017
G1 X90.789 Y110.899 E.00936
;WIDTH:0.437134
G1 X90.69 Y111.087 E.00569
;WIDTH:0.474268
G1 X90.591 Y111.275 E.00622
;WIDTH:0.511402
G1 X90.492 Y111.463 E.00674
G1 X90.473 Y111.306 E.00502
;WIDTH:0.474268
G1 X90.455 Y111.15 E.0046
;WIDTH:0.437134
G1 X90.436 Y110.993 E.00424
;WIDTH:0.399999
G1 X90.435 Y105.296 E.13857
;WIDTH:0.439115
G1 X90.455 Y105.054 E.00654
;WIDTH:0.478231
G1 X90.474 Y104.812 E.00717
;WIDTH:0.517346
G1 X90.494 Y104.571 E.00777
G1 X90.548 Y104.689 E.00417
;WIDTH:0.477924
G1 X90.684 Y104.912 E.00771
;WIDTH:0.438962
G1 X90.82 Y105.136 E.00705
;WIDTH:0.399999
G1 X91.056 Y105.371 E.0081
G1 X91.445 Y105.587 E.01082
G1 X91.774 Y105.649 E.00814
G1 X93.569 Y105.651 E.04366
G1 X93.57 Y110.289 E.11281
G1 X93.57 Y110.289 F9000
G1 X93.204 Y109.983
G1 F6000
G1 X91.774 Y109.985 E.03478
G1 X91.339 Y110.06 E.01074
G1 X91.028 Y110.195 E.00825
G1 X90.802 Y110.358 E.00678
G1 X90.801 Y105.632 E.11496
G1 X91.063 Y105.814 E.00776
G1 X91.293 Y105.919 E.00615
G1 X91.774 Y106.015 E.01193
G1 X93.204 Y106.017 E.03478
G1 X93.204 Y109.923 E.09501
G1 X93.204 Y109.923 F9000
G1 X92.838 Y109.618
G1 F6000
G1 X92.004 Y109.619 E.02029
G1 X91.494 Y109.651 E.01243
G1 X91.167 Y109.743 E.00826
G1 X91.167 Y106.259 E.08474
G1 X91.517 Y106.358 E.00885
G1 X91.773 Y106.381 E.00625
G1 X92.838 Y106.382 E.02591
G1 X92.838 Y109.558 E.07725
G1 E-5 F3600
G1 X92.838 Y109.558 F9000
G1 X93.569 Y102.349
G1 E5 F2400
G1 F6000
G1 X91.774 Y102.351 E.04366
G1 X91.419 Y102.417 E.00878
G1 X91.053 Y102.619 E.01017
G1 X90.789 Y102.899 E.00936
;WIDTH:0.437538
G1 X90.69 Y103.087 E.0057
;WIDTH:0.475076
G1 X90.59 Y103.275 E.00624
;WIDTH:0.512614
G1 X90.491 Y103.463 E.00676
G1 X90.472 Y103.306 E.00503
;WIDTH:0.475076
G1 X90.454 Y103.15 E.0046
;WIDTH:0.437538
G1 X90.435 Y102.993 E.00424
;WIDTH:0.399999
G1 X90.434 Y96.643 E.15446
;WIDTH:0.405113
G1 X90.441 Y95.859 E.01934
G1 X90.564 Y96.145 E.00768
;WIDTH:0.399999
G1 X90.836 Y96.509 E.01105
G1 X91.023 Y96.668 E.00597
G1 X91.505 Y96.871 E.01272
G1 X92.001 Y96.914 E.01211
G1 X93.569 Y96.913 E.03814
G1 X93.569 Y102.289 E.13077
G1 X93.569 Y102.289 F9000
G1 X93.203 Y101.983
G1 F6000
G1 X91.774 Y101.985 E.03476
G1 X91.339 Y102.06 E.01074
G1 X91.028 Y102.195 E.00825
G1 X90.8 Y102.359 E.00683
G1 X90.8 Y96.946 E.13167
G1 X91.134 Y97.137 E.00936
G1 X91.472 Y97.236 E.00857
G1 X92.001 Y97.279 E.01291
G1 X93.203 Y97.279 E.02924
G1 X93.203 Y101.923 E.11296
G1 X93.203 Y101.923 F9000
G1 X92.838 Y101.618
G1 F6000
G1 X92.003 Y101.619 E.02031
G1 X91.494 Y101.651 E.01241
G1 X91.166 Y101.744 E.00829
G1 X91.165 Y97.52 E.10274
G1 X91.44 Y97.6 E.00697
G1 X92.001 Y97.645 E.01369
G1 X92.837 Y97.645 E.02033
G1 X92.838 Y101.558 E.09518
G1 E-5 F3600
G1 X92.838 Y101.558 F9000
G1 X90.495 Y120.57
G1 E5 F2400
;WIDTH:0.514912
G1 F6000
G1 X90.48 Y120.319 E.00804
;WIDTH:0.484659
G1 X90.465 Y120.068 E.00753
;WIDTH:0.482296
G1 X90.478 Y119.766 E.00901
;WIDTH:0.510186
G1 X90.492 Y119.463 E.0096
G1 E-5 F3600
G1 X90.492 Y119.463 F9000
G1 X93.57 Y121.651
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.57 Y126.349 E.11427
G1 X91.774 Y126.351 E.04369
G1 X91.419 Y126.417 E.00878
G1 X91.053 Y126.619 E.01017
G1 X90.789 Y126.899 E.00936
;WIDTH:0.436325
G1 X90.69 Y127.087 E.00568
;WIDTH:0.472651
G1 X90.592 Y127.275 E.00618
;WIDTH:0.508976
G1 X90.493 Y127.463 E.00671
G1 X90.475 Y127.307 E.00496
;WIDTH:0.472651
G1 X90.457 Y127.15 E.00461
;WIDTH:0.436325
G1 X90.438 Y126.994 E.0042
;WIDTH:0.399999
G1 X90.438 Y121.294 E.13865
;WIDTH:0.438304
G1 X90.457 Y121.053 E.0065
;WIDTH:0.476608
G1 X90.476 Y120.812 E.00711
;WIDTH:0.514912
G1 X90.495 Y120.57 E.00776
G1 X90.549 Y120.689 E.00418
;WIDTH:0.476383
G1 X90.685 Y120.912 E.00768
;WIDTH:0.438191
G1 X90.82 Y121.136 E.00703
;WIDTH:0.399999
G1 X91.056 Y121.371 E.0081
G1 X91.445 Y121.587 E.01082
G1 X91.774 Y121.649 E.00814
G1 X93.51 Y121.651 E.04223
G1 X93.51 Y121.651 F9000
G1 X93.205 Y122.017
G1 F6000
G1 X93.205 Y125.984 E.09649
G1 X91.774 Y125.985 E.03481
G1 X91.339 Y126.06 E.01074
G1 X91.028 Y126.195 E.00825
G1 X90.804 Y126.356 E.00671
G1 X90.803 Y121.634 E.11486
G1 X91.293 Y121.919 E.01379
G1 X91.774 Y122.015 E.01193
G1 X93.145 Y122.016 E.03335
G1 E-5 F3600
G1 X93.145 Y122.016 F9000
G1 X92.839 Y125.618
G1 E5 F2400
G1 F6000
G1 X92.005 Y125.619 E.02029
G1 X91.494 Y125.651 E.01245
G1 X91.17 Y125.742 E.00819
G1 X91.169 Y122.26 E.0847
G1 X91.517 Y122.358 E.00879
G1 X91.773 Y122.381 E.00625
G1 X92.839 Y122.382 E.02593
G1 X92.839 Y125.558 E.07725
G1 E-5 F3600
G1 X92.839 Y125.558 F9000
G1 X90.496 Y128.57
G1 E5 F2400
;WIDTH:0.513692
G1 F6000
G1 X90.48 Y128.319 E.00802
;WIDTH:0.483442
G1 X90.465 Y128.068 E.00751
;WIDTH:0.481084
G1 X90.479 Y127.766 E.00898
;WIDTH:0.508976
G1 X90.493 Y127.463 E.00958
G1 X90.496 Y128.57 F9000
;WIDTH:0.513692
G1 F6000
G1 X90.549 Y128.689 E.00415
;WIDTH:0.475612
G1 X90.685 Y128.912 E.00767
;WIDTH:0.437806
G1 X90.82 Y129.136 E.00702
;WIDTH:0.399999
G1 X91.056 Y129.371 E.0081
G1 X91.445 Y129.587 E.01082
G1 X91.774 Y129.649 E.00814
G1 X93.571 Y129.652 E.04371
G1 X93.572 Y132.857 E.07796
G1 X93.606 Y133.479 E.01515
G1 X93.714 Y134.349 E.02132
G1 X91.775 Y134.351 E.04716
G1 X91.419 Y134.417 E.00881
G1 X91.053 Y134.619 E.01017
G1 X90.789 Y134.899 E.00936
;WIDTH:0.43592
G1 X90.69 Y135.087 E.00568
;WIDTH:0.471841
G1 X90.592 Y135.275 E.00617
;WIDTH:0.507762
G1 X90.494 Y135.463 E.00668
G1 X90.476 Y135.307 E.00495
;WIDTH:0.471841
G1 X90.458 Y135.15 E.0046
;WIDTH:0.43592
G1 X90.44 Y134.994 E.00419
;WIDTH:0.399999
G1 X90.439 Y129.294 E.13865
;WIDTH:0.437897
G1 X90.458 Y129.053 E.00649
;WIDTH:0.475795
G1 X90.477 Y128.812 E.0071
;WIDTH:0.513692
G1 X90.491 Y128.63 E.00582
G1 E-5 F3600
G1 X90.491 Y128.63 F9000
G1 X93.3 Y133.984
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X91.774 Y133.985 E.03712
G1 X91.339 Y134.06 E.01074
G1 X91.028 Y134.195 E.00825
G1 X90.805 Y134.354 E.00666
G1 X90.804 Y129.635 E.11478
G1 X91.293 Y129.919 E.01375
G1 X91.774 Y130.015 E.01193
G1 X93.205 Y130.017 E.03481
G1 X93.207 Y132.875 E.06952
G1 X93.237 Y133.458 E.0142
G1 X93.293 Y133.924 E.01142
G1 X93.293 Y133.924 F9000
G1 X92.886 Y133.618
G1 F6000
G1 X92.006 Y133.619 E.02141
G1 X91.494 Y133.651 E.01248
G1 X91.171 Y133.742 E.00816
G1 X91.17 Y130.26 E.0847
G1 X91.517 Y130.358 E.00877
G1 X91.773 Y130.381 E.00625
G1 X92.84 Y130.382 E.02595
G1 X92.84 Y132.784 E.05843
G1 X92.883 Y133.559 E.01888
G1 E-5 F3600
G1 X92.883 Y133.559 F9000
G1 X90.496 Y136.57
G1 E5 F2400
;WIDTH:0.512474
G1 F6000
G1 X90.481 Y136.319 E.008
;WIDTH:0.482226
G1 X90.466 Y136.068 E.00749
;WIDTH:0.47987
G1 X90.48 Y135.766 E.00896
;WIDTH:0.507762
G1 X90.494 Y135.463 E.00955
G1 E-5 F3600
G1 X90.494 Y135.463 F9000
G1 X99.25 Y142.176
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X99.56 Y142.348 E.00862
G1 X91.775 Y142.351 E.18936
G1 X91.419 Y142.417 E.00881
G1 X91.053 Y142.619 E.01017
G1 X90.789 Y142.899 E.00936
;WIDTH:0.435516
G1 X90.691 Y143.087 E.00566
;WIDTH:0.471033
G1 X90.592 Y143.275 E.00617
;WIDTH:0.50655
G1 X90.494 Y143.463 E.00666
G1 X90.476 Y143.307 E.00493
;WIDTH:0.471033
G1 X90.459 Y143.151 E.00456
;WIDTH:0.435516
G1 X90.441 Y142.994 E.00422
;WIDTH:0.399999
G1 X90.44 Y137.293 E.13867
;WIDTH:0.437491
G1 X90.459 Y137.052 E.00648
;WIDTH:0.474983
G1 X90.477 Y136.811 E.00708
;WIDTH:0.512474
G1 X90.496 Y136.57 E.00769
G1 X90.55 Y136.688 E.00413
;WIDTH:0.47484
G1 X90.685 Y136.912 E.00766
;WIDTH:0.43742
G1 X90.82 Y137.136 E.00701
;WIDTH:0.399999
G1 X91.056 Y137.371 E.0081
G1 X91.445 Y137.587 E.01082
G1 X91.775 Y137.649 E.00817
G1 X94.816 Y137.652 E.07397
G1 X95.075 Y138.136 E.01335
G1 X95.399 Y138.654 E.01486
G1 X95.768 Y139.174 E.01551
G1 X96.336 Y139.869 E.02183
G1 X96.78 Y140.338 E.01571
G1 X97.34 Y140.859 E.0186
G1 X97.939 Y141.342 E.01872
G1 X98.773 Y141.91 E.02454
G1 X99.198 Y142.146 E.01182
G1 X99.198 Y142.146 F9000
G1 X98.229 Y141.983
G1 F6000
G1 X91.775 Y141.985 E.15699
G1 X91.339 Y142.06 E.01076
G1 X91.028 Y142.195 E.00825
G1 X90.806 Y142.353 E.00663
G1 X90.806 Y137.635 E.11476
G1 X91.293 Y137.919 E.01371
G1 X91.774 Y138.015 E.01193
G1 X94.596 Y138.018 E.06864
G1 X94.764 Y138.329 E.0086
G1 X95.1 Y138.865 E.01539
G1 X95.485 Y139.405 E.01613
G1 X96.07 Y140.12 E.02247
G1 X96.531 Y140.606 E.01629
G1 X97.11 Y141.143 E.01921
G1 X97.733 Y141.644 E.01945
G1 X98.179 Y141.949 E.01314
G1 X98.179 Y141.949 F9000
G1 X97.115 Y141.618
G1 F6000
G1 X91.775 Y141.619 E.12989
G1 X91.495 Y141.651 E.00686
G1 X91.172 Y141.741 E.00816
G1 X91.171 Y138.261 E.08465
G1 X91.517 Y138.358 E.00874
G1 X91.774 Y138.381 E.00628
G1 X94.377 Y138.383 E.06332
G1 X94.802 Y139.076 E.01977
G1 X95.201 Y139.636 E.01673
G1 X95.804 Y140.371 E.02312
G1 X96.282 Y140.873 E.01686
G1 X97.07 Y141.578 E.02572
G1 E-5 F3600
G1 X97.07 Y141.578 F9000
G1 X106.249 Y143.531
G1 E5 F2400
G1 F6000
G1 X110.653 Y143.521 E.10712
G1 X111.02 Y143.366 E.00969
G1 X111.284 Y143.083 E.00941
G1 X111.319 Y142.998 E.00224
G1 X119.681 Y142.998 E.2034
G1 X119.716 Y143.083 E.00224
G1 X119.98 Y143.366 E.00941
G1 X120.193 Y143.472 E.00579
G1 X120.435 Y143.529 E.00605
G1 X124.751 Y143.536 E.10498
G1 X124.751 Y145.105 E.03816
G1 X124.852 Y145.421 E.00807
G1 X125.066 Y145.601 E.0068
G1 X125.3 Y145.654 E.00584
G1 X139.225 Y145.649 E.33871
G1 X139.581 Y145.583 E.00881
G1 X139.947 Y145.381 E.01017
G1 X140.211 Y145.101 E.00936
;WIDTH:0.44002
G1 X140.31 Y144.925 E.00545
;WIDTH:0.480041
G1 X140.409 Y144.748 E.00601
;WIDTH:0.520062
G1 X140.508 Y144.571 E.00655
G1 X140.528 Y144.716 E.00473
;WIDTH:0.480041
G1 X140.548 Y144.862 E.00437
;WIDTH:0.44002
G1 X140.568 Y145.007 E.00395
;WIDTH:0.399999
G1 X140.569 Y150.703 E.13855
G1 X140.549 Y151.304 E.01463
G1 X140.494 Y151.81 E.01238
G1 X140.453 Y151.469 E.00835
G1 X140.292 Y151.027 E.01144
G1 X139.944 Y150.629 E.01286
G1 X139.555 Y150.413 E.01082
G1 X139.225 Y150.351 E.00817
G1 X125.3 Y150.347 E.33871
G1 X125.252 Y150.349 E.00117
G1 X124.983 Y150.447 E.00696
G1 X124.81 Y150.648 E.00645
G1 X124.751 Y150.895 E.00618
G1 X124.751 Y153.105 E.05376
G1 X124.773 Y153.259 E.00378
G1 X124.861 Y153.434 E.00476
G1 X125.042 Y153.589 E.0058
G1 X125.3 Y153.654 E.00647
G1 X139.225 Y153.649 E.33871
G1 X139.581 Y153.583 E.00881
G1 X139.988 Y153.349 E.01142
G1 X139.683 Y153.859 E.01445
G1 X139.311 Y154.339 E.01477
G1 X138.887 Y154.768 E.01467
G1 X138.373 Y155.169 E.01586
G1 X137.908 Y155.457 E.0133
G1 X137.001 Y155.838 E.02393
G1 X136.362 Y155.993 E.01599
G1 X135.79 Y156.059 E.01401
G1 X95.395 Y156.064 E.98257
G1 X94.791 Y156.013 E.01474
G1 X94.19 Y155.891 E.01492
G1 X93.664 Y155.719 E.01346
G1 X93.134 Y155.476 E.01418
G1 X92.547 Y155.113 E.01679
G1 X92.089 Y154.743 E.01432
G1 X91.674 Y154.319 E.01443
G1 X91.271 Y153.782 E.01633
;WIDTH:0.400286
G1 X91.011 Y153.347 E.01234
G1 X91.056 Y153.371 E.00124
;WIDTH:0.399999
G1 X91.445 Y153.587 E.01082
G1 X91.775 Y153.649 E.00817
G1 X105.7 Y153.653 E.33871
G1 X105.958 Y153.589 E.00647
G1 X106.139 Y153.434 E.0058
G1 X106.227 Y153.259 E.00476
G1 X106.249 Y153.105 E.00378
G1 X106.249 Y150.895 E.05376
G1 X106.24 Y150.797 E.00239
G1 X106.148 Y150.579 E.00576
G1 X105.934 Y150.399 E.0068
G1 X105.7 Y150.346 E.00584
G1 X91.775 Y150.351 E.33871
G1 X91.419 Y150.417 E.00881
G1 X91.053 Y150.619 E.01017
G1 X90.789 Y150.899 E.00936
G1 X90.584 Y151.327 E.01154
G1 X90.505 Y151.824 E.01224
G1 X90.442 Y151.304 E.01274
G1 X90.441 Y145.293 E.14621
;WIDTH:0.437085
G1 X90.46 Y145.052 E.00648
;WIDTH:0.474171
G1 X90.478 Y144.811 E.00707
;WIDTH:0.511256
G1 X90.497 Y144.57 E.00767
G1 X90.55 Y144.688 E.0041
;WIDTH:0.474067
G1 X90.685 Y144.912 E.00765
;WIDTH:0.437033
G1 X90.82 Y145.136 E.00701
;WIDTH:0.399999
G1 X91.056 Y145.371 E.0081
G1 X91.445 Y145.587 E.01082
G1 X91.775 Y145.649 E.00817
G1 X105.7 Y145.653 E.33871
G1 X105.934 Y145.601 E.00583
G1 X106.148 Y145.421 E.0068
G1 X106.249 Y145.105 E.00807
G1 X106.249 Y143.591 E.03683
G1 E-5 F3600
G1 X106.249 Y143.591 F9000
G1 X90.497 Y144.57
G1 E5 F2400
;WIDTH:0.511256
G1 F6000
G1 X90.482 Y144.319 E.00798
;WIDTH:0.481011
G1 X90.466 Y144.068 E.00747
;WIDTH:0.478658
G1 X90.48 Y143.766 E.00894
;WIDTH:0.50655
G1 X90.494 Y143.463 E.00953
G1 E-5 F3600
G1 X90.494 Y143.463 F9000
G1 X106.614 Y143.897
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X109.798 Y143.895 E.07745
G1 X110.772 Y143.87 E.0237
G1 X111.183 Y143.694 E.01088
G1 X111.491 Y143.364 E.01098
G1 X119.509 Y143.364 E.19503
G1 X119.817 Y143.694 E.01098
G1 X120.089 Y143.826 E.00735
G1 X120.435 Y143.894 E.00858
G1 X124.386 Y143.901 E.0961
G1 X124.386 Y145.105 E.02929
G1 X124.448 Y145.438 E.00824
G1 X124.553 Y145.632 E.00537
G1 X124.771 Y145.851 E.00752
G1 X125.09 Y145.995 E.00851
G1 X125.3 Y146.019 E.00514
G1 X139.225 Y146.015 E.33871
G1 X139.661 Y145.94 E.01076
G1 X139.972 Y145.805 E.00825
G1 X140.202 Y145.639 E.0069
G1 X140.202 Y150.37 E.11508
G1 X139.707 Y150.08 E.01395
G1 X139.225 Y149.985 E.01195
G1 X125.3 Y149.981 E.33871
G1 X125.22 Y149.984 E.00195
G1 X124.91 Y150.068 E.00781
G1 X124.602 Y150.304 E.00944
G1 X124.451 Y150.554 E.0071
G1 X124.386 Y150.895 E.00844
G1 X124.386 Y153.105 E.05376
G1 X124.422 Y153.361 E.00629
G1 X124.568 Y153.654 E.00796
G1 X124.87 Y153.912 E.00966
G1 X125.3 Y154.019 E.01078
G1 X139.099 Y154.015 E.33565
G1 X138.643 Y154.494 E.01609
G1 X138.148 Y154.881 E.01528
G1 X137.742 Y155.13 E.01158
G1 X136.887 Y155.49 E.02257
G1 X136.297 Y155.632 E.01476
G1 X135.769 Y155.693 E.01293
G1 X95.481 Y155.702 E.97997
G1 X94.859 Y155.654 E.01517
G1 X94.299 Y155.542 E.01389
G1 X93.812 Y155.385 E.01245
G1 X93.323 Y155.163 E.01306
G1 X92.774 Y154.827 E.01566
G1 X92.349 Y154.486 E.01325
G1 X91.901 Y154.015 E.01581
G1 X105.7 Y154.019 E.33565
G1 X106.13 Y153.912 E.01078
G1 X106.431 Y153.654 E.00964
G1 X106.578 Y153.361 E.00797
G1 X106.614 Y153.105 E.00629
G1 X106.614 Y150.895 E.05376
G1 X106.588 Y150.679 E.00529
G1 X106.447 Y150.368 E.00831
G1 X106.229 Y150.149 E.00752
G1 X105.91 Y150.005 E.00851
G1 X105.7 Y149.981 E.00514
G1 X91.775 Y149.985 E.33871
G1 X91.339 Y150.06 E.01076
G1 X91.028 Y150.195 E.00825
G1 X90.808 Y150.352 E.00657
G1 X90.807 Y145.636 E.11471
G1 X91.293 Y145.919 E.01368
G1 X91.775 Y146.015 E.01195
G1 X105.78 Y146.016 E.34066
G1 X106.09 Y145.932 E.00781
G1 X106.328 Y145.77 E.007
G1 X106.552 Y145.438 E.00974
G1 X106.614 Y145.105 E.00824
G1 X106.614 Y143.957 E.02792
G1 X106.614 Y143.957 F9000
G1 X106.98 Y144.262
G1 F6000
G1 X110.565 Y144.26 E.0872
G1 X110.855 Y144.226 E.0071
G1 X111.345 Y144.022 E.01291
G1 X111.617 Y143.729 E.00972
G1 X119.383 Y143.729 E.1889
G1 X119.655 Y144.022 E.00972
G1 X120.071 Y144.207 E.01107
G1 X120.434 Y144.26 E.00892
G1 X124.02 Y144.266 E.08723
G1 X124.02 Y145.105 E.02041
G1 X124.108 Y145.572 E.01156
G1 X124.254 Y145.843 E.00749
G1 X124.56 Y146.15 E.01054
G1 X125.006 Y146.351 E.0119
G1 X125.3 Y146.385 E.0072
G1 X139.225 Y146.381 E.33871
G1 X139.505 Y146.349 E.00686
G1 X139.837 Y146.255 E.00839
G1 X139.837 Y149.742 E.08482
G1 X139.483 Y149.642 E.00895
G1 X139.225 Y149.619 E.0063
G1 X125.3 Y149.615 E.33871
G1 X125.006 Y149.649 E.0072
G1 X124.56 Y149.85 E.0119
G1 X124.254 Y150.157 E.01054
G1 X124.079 Y150.51 E.00958
G1 X124.02 Y150.895 E.00947
G1 X124.02 Y153.105 E.05376
G1 X124.071 Y153.463 E.0088
G1 X124.276 Y153.873 E.01115
G1 X124.698 Y154.234 E.01351
G1 X125.3 Y154.385 E.0151
G1 X138.194 Y154.381 E.31363
G1 X137.576 Y154.803 E.0182
G1 X136.772 Y155.141 E.02121
G1 X136.26 Y155.265 E.01281
G1 X135.747 Y155.327 E.01257
G1 X95.464 Y155.336 E.97984
G1 X94.954 Y155.3 E.01244
G1 X94.455 Y155.205 E.01236
G1 X93.979 Y155.059 E.01211
G1 X93.512 Y154.85 E.01245
G1 X92.801 Y154.381 E.02072
G1 X105.7 Y154.385 E.31376
G1 X105.922 Y154.365 E.00542
G1 X106.302 Y154.234 E.00978
G1 X106.724 Y153.873 E.01351
G1 X106.929 Y153.463 E.01115
G1 X106.98 Y153.105 E.0088
G1 X106.98 Y150.895 E.05376
G1 X106.921 Y150.509 E.0095
G1 X106.746 Y150.157 E.00956
G1 X106.44 Y149.85 E.01054
G1 X105.994 Y149.649 E.0119
G1 X105.7 Y149.615 E.0072
G1 X91.775 Y149.619 E.33871
G1 X91.495 Y149.651 E.00686
G1 X91.173 Y149.741 E.00813
G1 X91.173 Y146.261 E.08465
G1 X91.517 Y146.358 E.00869
G1 X91.775 Y146.381 E.0063
G1 X105.7 Y146.385 E.33871
G1 X105.994 Y146.351 E.0072
G1 X106.44 Y146.149 E.01191
G1 X106.677 Y145.932 E.00782
G1 X106.892 Y145.571 E.01022
G1 X106.98 Y145.105 E.01154
G1 X106.98 Y144.322 E.01905
G1 E-5 F3600
G1 X106.98 Y144.322 F9000
G1 X96.576 Y150.715
G1 E5 F2400
G1 F6000
G1 X105.7 Y150.712 E.22193
G1 X105.84 Y150.777 E.00375
G1 X105.878 Y150.852 E.00205
G1 X105.883 Y153.105 E.0548
G1 X105.846 Y153.215 E.00282
G1 X105.7 Y153.288 E.00397
G1 X91.775 Y153.284 E.33871
G1 X91.598 Y153.254 E.00437
;WIDTH:0.400286
G1 X91.281 Y153.079 E.00881
;WIDTH:0.438659
G1 X91.182 Y152.999 E.00342
;WIDTH:0.477032
G1 X91.084 Y152.919 E.00373
;WIDTH:0.515404
G1 X90.985 Y152.839 E.00407
;WIDTH:0.52074
G1 X90.85 Y152.494 E.01199
;WIDTH:0.551586
G1 X90.779 Y152.031 E.01612
G1 X90.812 Y151.901 E.00461
;WIDTH:0.51369
G1 X90.845 Y151.772 E.00425
;WIDTH:0.475793
G1 X90.877 Y151.642 E.00393
;WIDTH:0.437896
G1 X90.91 Y151.513 E.00357
;WIDTH:0.399999
G1 X91.068 Y151.135 E.00997
G1 X91.257 Y150.922 E.00693
G1 X91.5 Y150.774 E.00692
G1 X91.775 Y150.716 E.00684
G1 X96.516 Y150.715 E.11532
G1 E-5 F3600
G1 X96.516 Y150.715 F9000
G1 X125.117 Y150.895
G1 E5 F2400
G1 F6000
G1 X125.174 Y150.762 E.00352
G1 X125.3 Y150.712 E.0033
G1 X139.225 Y150.716 E.33871
G1 X139.402 Y150.746 E.00437
G1 X139.686 Y150.888 E.00772
G1 X139.962 Y151.183 E.00983
G1 X140.09 Y151.513 E.00861
;WIDTH:0.438169
G1 X140.123 Y151.642 E.00358
;WIDTH:0.476339
G1 X140.155 Y151.772 E.00394
;WIDTH:0.514509
G1 X140.188 Y151.901 E.00425
;WIDTH:0.552679
G1 X140.221 Y152.031 E.00462
G1 X140.138 Y152.537 E.01768
;WIDTH:0.515263
G1 X139.974 Y152.9 E.01274
;WIDTH:0.507944
G1 X139.837 Y153 E.00534
;WIDTH:0.471963
G1 X139.7 Y153.099 E.00492
;WIDTH:0.435981
G1 X139.563 Y153.199 E.00453
;WIDTH:0.399999
G1 X139.225 Y153.284 E.00848
G1 X125.3 Y153.288 E.33871
G1 X125.154 Y153.215 E.00397
G1 X125.117 Y153.105 E.00282
G1 X125.117 Y150.955 E.0523
G1 E-5 F3600
G1 X140.51 Y143.463 F9000
G1 E5 F2400
;WIDTH:0.515014
G1 F6000
G1 X140.525 Y143.731 E.00858
;WIDTH:0.485176
G1 X140.54 Y144 E.00808
G1 X140.525 Y144.269 E.00808
;WIDTH:0.515182
G1 X140.51 Y144.537 E.00859
;WIDTH:0.520062
G1 X140.508 Y144.571 E.0011
G1 E-5 F3600
G1 X140.508 Y144.571 F9000
G1 X131.439 Y142.349
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X132.453 Y141.766 E.02845
G1 X133.129 Y141.29 E.02011
G1 X133.898 Y140.647 E.02438
G1 X134.398 Y140.157 E.01703
G1 X134.821 Y139.686 E.0154
G1 X135.27 Y139.124 E.0175
G1 X135.632 Y138.608 E.01533
G1 X135.95 Y138.092 E.01474
G1 X136.191 Y137.652 E.0122
G1 X139.225 Y137.649 E.0738
G1 X139.581 Y137.583 E.00881
G1 X139.947 Y137.381 E.01017
G1 X140.211 Y137.101 E.00936
;WIDTH:0.439608
G1 X140.31 Y136.924 E.00547
;WIDTH:0.479217
G1 X140.408 Y136.748 E.00596
;WIDTH:0.518826
G1 X140.507 Y136.571 E.00654
G1 X140.527 Y136.716 E.00472
;WIDTH:0.479217
G1 X140.547 Y136.862 E.00436
;WIDTH:0.439608
G1 X140.567 Y137.007 E.00395
;WIDTH:0.399999
G1 X140.567 Y142.703 E.13855
;WIDTH:0.438338
G1 X140.548 Y142.957 E.00685
;WIDTH:0.476676
G1 X140.529 Y143.21 E.00747
;WIDTH:0.515014
G1 X140.51 Y143.463 E.00811
G1 X140.446 Y143.313 E.00521
;WIDTH:0.466653
G1 X140.313 Y143.089 E.00749
;WIDTH:0.433326
G1 X140.18 Y142.864 E.00694
;WIDTH:0.399999
G1 X139.944 Y142.629 E.0081
G1 X139.555 Y142.413 E.01082
G1 X139.225 Y142.351 E.00817
G1 X131.499 Y142.349 E.18793
G1 X131.499 Y142.349 F9000
G1 X132.784 Y141.983
G1 F6000
G1 X133.364 Y141.571 E.01731
G1 X134.153 Y140.908 E.02507
G1 X134.67 Y140.402 E.0176
G1 X135.106 Y139.915 E.0159
G1 X135.569 Y139.334 E.01807
G1 X135.943 Y138.801 E.01584
G1 X136.408 Y138.018 E.02215
G1 X139.226 Y138.015 E.06855
G1 X139.661 Y137.94 E.01074
G1 X139.972 Y137.805 E.00825
G1 X140.201 Y137.64 E.00687
G1 X140.202 Y142.37 E.11505
G1 X139.937 Y142.186 E.00785
G1 X139.707 Y142.08 E.00616
G1 X139.225 Y141.985 E.01195
G1 X132.844 Y141.983 E.15521
G1 X132.844 Y141.983 F9000
G1 X133.878 Y141.618
G1 F6000
G1 X134.409 Y141.17 E.0169
G1 X134.941 Y140.646 E.01816
G1 X135.391 Y140.144 E.0164
G1 X135.868 Y139.544 E.01864
G1 X136.254 Y138.993 E.01636
G1 X136.625 Y138.383 E.01737
G1 X139.226 Y138.381 E.06327
G1 X139.505 Y138.349 E.00683
G1 X139.835 Y138.256 E.00834
G1 X139.836 Y141.742 E.08479
G1 X139.483 Y141.642 E.00892
G1 X139.225 Y141.619 E.0063
G1 X133.938 Y141.618 E.1286
G1 E-5 F3600
G1 X140.509 Y135.463 F9000
G1 E5 F2400
;WIDTH:0.513784
G1 F6000
G1 X140.524 Y135.731 E.00856
;WIDTH:0.483947
G1 X140.539 Y136 E.00806
G1 X140.524 Y136.269 E.00806
;WIDTH:0.51395
G1 X140.509 Y136.537 E.00856
;WIDTH:0.518826
G1 X140.507 Y136.571 E.0011
G1 E-5 F3600
G1 X140.507 Y136.571 F9000
G1 X137.288 Y134.349
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.372 Y133.727 E.01527
G1 X137.429 Y132.81 E.02235
G1 X137.429 Y129.651 E.07684
G1 X139.226 Y129.649 E.04371
G1 X139.581 Y129.583 E.00878
G1 X139.947 Y129.381 E.01017
G1 X140.211 Y129.101 E.00936
;WIDTH:0.439195
G1 X140.31 Y128.924 E.00546
;WIDTH:0.478391
G1 X140.408 Y128.747 E.00598
;WIDTH:0.517586
G1 X140.506 Y128.57 E.0065
G1 X140.526 Y128.716 E.00474
;WIDTH:0.478391
G1 X140.546 Y128.861 E.00432
;WIDTH:0.439195
G1 X140.565 Y129.007 E.00397
;WIDTH:0.399999
G1 X140.566 Y134.704 E.13857
;WIDTH:0.437928
G1 X140.547 Y134.957 E.00681
;WIDTH:0.475856
G1 X140.528 Y135.21 E.00745
;WIDTH:0.513784
G1 X140.509 Y135.463 E.00809
G1 X140.446 Y135.313 E.00519
;WIDTH:0.46599
G1 X140.313 Y135.089 E.00748
;WIDTH:0.432995
G1 X140.18 Y134.864 E.00693
;WIDTH:0.399999
G1 X139.944 Y134.629 E.0081
G1 X139.555 Y134.413 E.01082
G1 X139.225 Y134.351 E.00817
G1 X137.348 Y134.349 E.04566
G1 X137.348 Y134.349 F9000
G1 X137.707 Y133.984
G1 F6000
G1 X137.795 Y132.81 E.02864
G1 X137.795 Y130.017 E.06794
G1 X139.226 Y130.015 E.03481
G1 X139.661 Y129.94 E.01074
G1 X139.972 Y129.805 E.00825
G1 X140.2 Y129.641 E.00683
G1 X140.2 Y134.369 E.115
G1 X139.937 Y134.186 E.00779
G1 X139.707 Y134.08 E.00616
G1 X139.226 Y133.985 E.01193
G1 X137.767 Y133.984 E.03549
G1 X137.767 Y133.984 F9000
G1 X138.112 Y133.618
G1 F6000
G1 X138.16 Y132.81 E.01969
G1 X138.161 Y130.382 E.05906
G1 X138.996 Y130.381 E.02031
G1 X139.506 Y130.349 E.01243
G1 X139.834 Y130.256 E.00829
G1 X139.835 Y133.741 E.08477
G1 X139.483 Y133.642 E.00889
G1 X139.226 Y133.619 E.00628
G1 X138.172 Y133.619 E.02564
G1 E-5 F3600
G1 X138.172 Y133.619 F9000
G1 X140.509 Y127.463
G1 E5 F2400
;WIDTH:0.51255
G1 F6000
G1 X140.524 Y127.731 E.00854
;WIDTH:0.482717
G1 X140.539 Y128 E.00804
G1 X140.524 Y128.269 E.00804
;WIDTH:0.512716
G1 X140.509 Y128.537 E.00854
;WIDTH:0.517586
G1 X140.506 Y128.57 E.00107
G1 E-5 F3600
G1 X140.506 Y128.57 F9000
G1 X137.43 Y126.349
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.43 Y121.651 E.11427
G1 X139.226 Y121.649 E.04369
G1 X139.581 Y121.583 E.00878
G1 X139.947 Y121.381 E.01017
G1 X140.211 Y121.101 E.00936
;WIDTH:0.438782
G1 X140.309 Y120.924 E.00544
;WIDTH:0.477565
G1 X140.408 Y120.747 E.00598
;WIDTH:0.516348
G1 X140.506 Y120.57 E.00649
G1 X140.525 Y120.716 E.00472
;WIDTH:0.477565
G1 X140.545 Y120.861 E.00432
;WIDTH:0.438782
G1 X140.564 Y121.007 E.00396
;WIDTH:0.399999
G1 X140.565 Y126.704 E.13857
;WIDTH:0.437516
G1 X140.546 Y126.957 E.0068
;WIDTH:0.475033
G1 X140.528 Y127.21 E.00744
;WIDTH:0.51255
G1 X140.509 Y127.463 E.00807
G1 X140.446 Y127.313 E.00518
;WIDTH:0.46532
G1 X140.313 Y127.089 E.00747
;WIDTH:0.43266
G1 X140.18 Y126.864 E.00693
;WIDTH:0.399999
G1 X139.944 Y126.629 E.0081
G1 X139.555 Y126.413 E.01082
G1 X139.226 Y126.351 E.00814
G1 X137.49 Y126.349 E.04223
G1 E-5 F3600
G1 X137.49 Y126.349 F9000
G1 X137.795 Y122.017
G1 E5 F2400
G1 F6000
G1 X139.226 Y122.015 E.03481
G1 X139.661 Y121.94 E.01074
G1 X139.972 Y121.805 E.00825
G1 X140.199 Y121.642 E.0068
G1 X140.199 Y126.368 E.11496
G1 X139.937 Y126.186 E.00776
G1 X139.707 Y126.081 E.00615
G1 X139.226 Y125.985 E.01193
G1 X137.795 Y125.983 E.03481
G1 X137.795 Y122.077 E.09501
G1 X137.795 Y122.077 F9000
G1 X138.161 Y122.382
G1 F6000
G1 X138.996 Y122.381 E.02031
G1 X139.506 Y122.349 E.01243
G1 X139.833 Y122.257 E.00826
G1 X139.833 Y125.741 E.08474
G1 X139.483 Y125.642 E.00885
G1 X139.227 Y125.619 E.00625
G1 X138.161 Y125.618 E.02593
G1 X138.161 Y122.442 E.07725
G1 E-5 F3600
G1 X138.161 Y122.442 F9000
G1 X140.508 Y119.463
G1 E5 F2400
;WIDTH:0.511318
G1 F6000
G1 X140.523 Y119.731 E.00852
;WIDTH:0.481487
G1 X140.538 Y120 E.00801
G1 X140.523 Y120.269 E.00801
;WIDTH:0.511482
G1 X140.508 Y120.537 E.00852
;WIDTH:0.516348
G1 X140.506 Y120.57 E.00106
G1 E-5 F3600
G1 X140.506 Y120.57 F9000
G1 X137.43 Y118.349
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.43 Y113.651 E.11427
G1 X139.226 Y113.649 E.04369
G1 X139.581 Y113.583 E.00878
G1 X139.947 Y113.381 E.01017
G1 X140.211 Y113.101 E.00936
;WIDTH:0.438371
G1 X140.309 Y112.924 E.00544
;WIDTH:0.476743
G1 X140.407 Y112.747 E.00595
;WIDTH:0.515114
G1 X140.505 Y112.57 E.00647
G1 X140.524 Y112.716 E.00471
;WIDTH:0.476743
G1 X140.544 Y112.861 E.00431
;WIDTH:0.438371
G1 X140.563 Y113.006 E.00393
;WIDTH:0.399999
G1 X140.564 Y118.705 E.13862
;WIDTH:0.437106
G1 X140.545 Y118.958 E.0068
;WIDTH:0.474212
G1 X140.527 Y119.21 E.00739
;WIDTH:0.511318
G1 X140.508 Y119.463 E.00805
G1 X140.445 Y119.314 E.00513
;WIDTH:0.464653
G1 X140.313 Y119.089 E.00747
;WIDTH:0.432326
G1 X140.18 Y118.864 E.00692
;WIDTH:0.399999
G1 X139.944 Y118.629 E.0081
G1 X139.555 Y118.413 E.01082
G1 X139.226 Y118.351 E.00814
G1 X137.49 Y118.349 E.04223
G1 X137.49 Y118.349 F9000
G1 X137.796 Y117.983
G1 F6000
G1 X137.796 Y114.017 E.09647
G1 X139.226 Y114.015 E.03478
G1 X139.661 Y113.94 E.01074
G1 X139.972 Y113.805 E.00825
G1 X140.197 Y113.643 E.00674
G1 X140.198 Y118.367 E.11491
G1 X139.707 Y118.081 E.01382
G1 X139.226 Y117.985 E.01193
G1 X137.856 Y117.984 E.03332
G1 X137.856 Y117.984 F9000
G1 X138.161 Y117.618
G1 F6000
G1 X138.162 Y114.382 E.07871
G1 X138.996 Y114.381 E.02029
G1 X139.506 Y114.349 E.01243
G1 X139.832 Y114.257 E.00824
G1 X139.832 Y117.74 E.08472
G1 X139.483 Y117.642 E.00882
G1 X139.227 Y117.619 E.00625
G1 X138.221 Y117.618 E.02447
G1 E-5 F3600
G1 X138.221 Y117.618 F9000
G1 X140.508 Y111.463
G1 E5 F2400
;WIDTH:0.51009
G1 F6000
G1 X140.523 Y111.731 E.00849
;WIDTH:0.48026
G1 X140.537 Y112 E.00799
G1 X140.523 Y112.268 E.00796
;WIDTH:0.510252
G1 X140.508 Y112.537 E.00853
;WIDTH:0.515114
G1 X140.505 Y112.57 E.00106
G1 E-5 F3600
G1 X140.505 Y112.57 F9000
G1 X137.431 Y105.651
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X139.226 Y105.649 E.04366
G1 X139.581 Y105.583 E.00878
G1 X139.947 Y105.381 E.01017
G1 X140.211 Y105.101 E.00936
;WIDTH:0.437958
G1 X140.309 Y104.924 E.00543
;WIDTH:0.475917
G1 X140.407 Y104.747 E.00594
;WIDTH:0.513876
G1 X140.505 Y104.57 E.00645
G1 X140.524 Y104.715 E.00466
;WIDTH:0.475917
G1 X140.543 Y104.861 E.00432
;WIDTH:0.437958
G1 X140.562 Y105.006 E.00393
;WIDTH:0.399999
G1 X140.562 Y110.706 E.13865
;WIDTH:0.436696
G1 X140.544 Y110.958 E.00676
;WIDTH:0.473393
G1 X140.526 Y111.21 E.00738
;WIDTH:0.51009
G1 X140.508 Y111.463 E.00803
G1 X140.445 Y111.314 E.00512
;WIDTH:0.463988
G1 X140.313 Y111.089 E.00746
;WIDTH:0.431994
G1 X140.18 Y110.864 E.00691
;WIDTH:0.399999
G1 X139.944 Y110.629 E.0081
G1 X139.555 Y110.413 E.01082
G1 X139.226 Y110.351 E.00814
G1 X137.43 Y110.349 E.04369
G1 X137.431 Y105.711 E.11281
G1 X137.431 Y105.711 F9000
G1 X137.796 Y106.017
G1 F6000
G1 X139.226 Y106.015 E.03478
G1 X139.661 Y105.94 E.01074
G1 X139.972 Y105.805 E.00825
G1 X140.196 Y105.644 E.00671
G1 X140.197 Y110.366 E.11486
G1 X139.707 Y110.081 E.01379
G1 X139.226 Y109.985 E.01193
G1 X137.796 Y109.983 E.03478
G1 X137.796 Y106.077 E.09501
G1 X137.796 Y106.077 F9000
G1 X138.162 Y106.382
G1 F6000
G1 X138.995 Y106.381 E.02026
G1 X139.506 Y106.349 E.01245
G1 X139.83 Y106.258 E.00819
G1 X139.831 Y109.74 E.0847
G1 X139.483 Y109.642 E.00879
G1 X139.227 Y109.619 E.00625
G1 X138.162 Y109.618 E.02591
G1 X138.162 Y106.442 E.07725
G1 E-5 F3600
G1 X138.162 Y106.442 F9000
G1 X140.507 Y103.463
G1 E5 F2400
;WIDTH:0.508858
G1 F6000
G1 X140.522 Y103.731 E.00847
;WIDTH:0.47903
G1 X140.537 Y104 E.00797
G1 X140.522 Y104.268 E.00794
;WIDTH:0.50902
G1 X140.507 Y104.537 E.00851
;WIDTH:0.513876
G1 X140.505 Y104.57 E.00105
G1 E-5 F3600
G1 X140.505 Y104.57 F9000
G1 X137.431 Y102.349
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y96.913 E.13223
G1 X139.291 Y96.906 E.04524
G1 X139.74 Y96.788 E.01129
G1 X140.114 Y96.551 E.01077
G1 X140.281 Y96.386 E.00571
G1 X140.556 Y95.894 E.01371
G1 X140.561 Y102.706 E.1657
;WIDTH:0.436286
G1 X140.543 Y102.958 E.00676
;WIDTH:0.472572
G1 X140.525 Y103.211 E.00739
;WIDTH:0.508858
G1 X140.507 Y103.463 E.00797
G1 X140.445 Y103.314 E.00509
;WIDTH:0.463317
G1 X140.312 Y103.089 E.00746
;WIDTH:0.431658
G1 X140.18 Y102.864 E.00689
;WIDTH:0.399999
G1 X139.944 Y102.629 E.0081
G1 X139.555 Y102.413 E.01082
G1 X139.226 Y102.351 E.00814
G1 X137.491 Y102.349 E.0422
G1 X137.491 Y102.349 F9000
G1 X137.797 Y101.983
G1 F6000
G1 X137.797 Y97.279 E.11442
G1 X138.996 Y97.279 E.02916
G1 X139.594 Y97.227 E.0146
G1 X139.936 Y97.097 E.0089
G1 X140.195 Y96.933 E.00746
G1 X140.196 Y102.365 E.13213
G1 X139.707 Y102.081 E.01375
G1 X139.226 Y101.985 E.01193
G1 X137.857 Y101.984 E.0333
G1 X137.857 Y101.984 F9000
G1 X138.162 Y101.618
G1 F6000
G1 X138.163 Y97.645 E.09664
G1 X139.409 Y97.628 E.03031
G1 X139.829 Y97.521 E.01054
G1 X139.83 Y101.74 E.10262
G1 X139.483 Y101.642 E.00877
G1 X139.227 Y101.619 E.00625
G1 X138.222 Y101.618 E.02445
G1 E-5 F3600
G1 X138.222 Y101.618 F9000
G1 X140.194 Y95.787
G1 X140.236 Y95.609
G1 X140.241 Y95.55
G1 X140.249 Y95.439
G1 X140.249 Y93.39
G1 X140.241 Y93.278
G1 X140.236 Y93.22
G1 X140.194 Y93.041
G1 X140.123 Y92.87
G1 X140.025 Y92.712
G1 X139.943 Y92.619
G1 X139.89 Y92.562
G1 X139.74 Y92.45
G1 X139.571 Y92.365
G1 X126.349 Y88.151
G1 X121.628 Y88.151
G1 X119.951 Y86.599
G1 X119.844 Y86.703
G1 E5 F2400
G1 F6000
G1 X119.87 Y86.74 E.0011
G1 X120.201 Y86.931 E.0093
G1 X120.483 Y86.981 E.00697
G1 X126.835 Y86.968 E.15451
G1 X127.422 Y86.931 E.01431
G1 X127.919 Y86.85 E.01225
G1 X128.555 Y86.648 E.01623
G1 X129.054 Y86.431 E.01324
G1 X129.871 Y85.904 E.02365
G1 X130.405 Y85.412 E.01766
G1 X130.806 Y84.92 E.01544
G1 X131.365 Y83.9 E.02829
G1 X131.655 Y82.891 E.02554
G1 X131.721 Y82.342 E.01345
G1 X131.73 Y79.168 E.0772
G1 X132.262 Y78.586 E.01918
G1 X132.522 Y78.158 E.01218
G1 X132.627 Y77.811 E.00882
G1 X132.668 Y77.444 E.00898
G1 X132.548 Y76.917 E.01315
G1 X132.18 Y76.308 E.01731
G1 X131.726 Y75.833 E.01598
G1 X131.714 Y75.68 E.00373
G1 X131.557 Y75.338 E.00915
G1 X131.282 Y75.091 E.00899
;WIDTH:0.40745
G1 X130.817 Y74.941 E.01213
G1 X131.312 Y74.937 E.01229
;WIDTH:0.399999
G1 X135.75 Y74.944 E.10795
G1 X136.274 Y75 E.01282
G1 X137.019 Y75.172 E.0186
G1 X137.563 Y75.372 E.0141
G1 X138.377 Y75.832 E.02274
G1 X139.082 Y76.419 E.02231
G1 X139.668 Y77.123 E.02228
G1 X140.119 Y77.922 E.02232
G1 X140.418 Y78.788 E.02228
G1 X140.51 Y79.392 E.01486
G1 X140.558 Y80.028 E.01551
G1 X140.56 Y92.411 E.3012
;WIDTH:0.404459
G1 X140.551 Y92.918 E.01248
G1 X140.327 Y92.501 E.01165
;WIDTH:0.399999
G1 X140.022 Y92.194 E.01053
G1 X139.694 Y92.02 E.00903
G1 X139.202 Y91.915 E.01224
G1 X126.969 Y91.915 E.29756
G1 X127.271 Y91.572 E.01112
G1 X127.549 Y91.081 E.01372
G1 X127.616 Y90.879 E.00518
G1 X127.665 Y90.495 E.00942
G1 X127.651 Y90.286 E.0051
G1 X127.491 Y89.782 E.01286
G1 X127.18 Y89.308 E.01379
G1 X126.727 Y88.834 E.01595
G1 X126.712 Y88.496 E.00823
G1 X126.598 Y88.218 E.00731
G1 X126.453 Y88.033 E.00572
G1 X126.114 Y87.825 E.00967
G1 X125.817 Y87.769 E.00735
G1 X105.183 Y87.769 E.5019
G1 X104.971 Y87.811 E.00526
G1 X104.542 Y88.031 E.01173
G1 X104.31 Y88.42 E.01102
G1 X104.272 Y88.825 E.00989
G1 X103.686 Y89.489 E.02154
G1 X103.412 Y90.004 E.01419
G1 X103.335 Y90.505 E.01233
G1 X103.349 Y90.714 E.0051
G1 X103.443 Y91.066 E.00886
G1 X103.752 Y91.605 E.01511
G1 X104.034 Y91.915 E.01019
G1 X91.798 Y91.915 E.29763
G1 X91.302 Y92.018 E.01232
G1 X91.105 Y92.11 E.00529
G1 X90.849 Y92.298 E.00773
G1 X90.544 Y92.701 E.01229
G1 X90.433 Y93.013 E.00806
G1 X90.431 Y80.028 E.31585
G1 X90.47 Y79.389 E.01557
G1 X90.58 Y78.787 E.01489
G1 X90.762 Y78.203 E.01488
G1 X91.013 Y77.645 E.01488
G1 X91.33 Y77.122 E.01488
G1 X91.707 Y76.64 E.01488
G1 X92.14 Y76.207 E.01489
G1 X92.622 Y75.83 E.01488
G1 X93.138 Y75.518 E.01467
G1 X93.849 Y75.213 E.01882
G1 X94.528 Y75.046 E.01701
G1 X95.208 Y74.942 E.01673
G1 X99.135 Y74.942 E.09552
;WIDTH:0.41165
G1 X100.087 Y74.947 E.02389
G1 X99.725 Y75.086 E.00973
;WIDTH:0.400104
G1 X99.425 Y75.38 E.01022
;WIDTH:0.399999
G1 X99.313 Y75.644 E.00698
G1 X99.273 Y75.829 E.0046
G1 X98.729 Y76.428 E.01968
G1 X98.451 Y76.919 E.01372
G1 X98.384 Y77.121 E.00518
G1 X98.335 Y77.505 E.00942
G1 X98.349 Y77.714 E.0051
G1 X98.509 Y78.218 E.01286
G1 X98.82 Y78.692 E.01379
G1 X99.27 Y79.162 E.01583
G1 X99.284 Y82.399 E.07874
G1 X99.422 Y83.252 E.02102
G1 X99.697 Y84.05 E.02053
G1 X100.169 Y84.883 E.02329
G1 X100.867 Y85.678 E.02573
G1 X101.713 Y86.304 E.0256
G1 X102.369 Y86.626 E.01778
G1 X102.978 Y86.82 E.01555
G1 X103.56 Y86.938 E.01444
G1 X104.199 Y86.981 E.01558
G1 X110.517 Y86.981 E.15368
G1 X110.612 Y86.973 E.00232
G1 X111.012 Y86.83 E.01033
G1 X111.211 Y86.662 E.00633
G1 X111.334 Y86.428 E.00643
G1 X119.666 Y86.428 E.20267
G1 X119.691 Y86.495 E.00174
G1 X119.808 Y86.655 E.00482
G1 E-5 F3600
G1 X119.808 Y86.655 F9000
G1 X105.019 Y87.382
G1 E5 F2400
;WIDTH:0.4703
G1 F6000
G1 X105.183 Y87.375 E.00476
;WIDTH:0.456022
G1 X110.517 Y87.375 E.14962
;WIDTH:0.4703
G1 X110.681 Y87.368 E.00476
;WIDTH:0.498002
G1 X110.893 Y87.335 E.00662
;WIDTH:0.521824
G1 X111.273 Y87.168 E.01346
G1 X111.39 Y87.077 E.00481
G1 X111.585 Y86.855 E.00958
G1 X119.415 Y86.855 E.25391
G1 X119.465 Y86.94 E.0032
G1 X119.728 Y87.168 E.01129
G1 X120.108 Y87.335 E.01346
;WIDTH:0.497328
G1 X120.269 Y87.363 E.00503
;WIDTH:0.521824
G1 X119.669 Y87.342 E.01947
G1 X111.007 Y87.355 E.28089
;WIDTH:0.496062
G1 X110.741 Y87.365 E.00818
G1 E-5 F3600
G1 X110.741 Y87.365 F9000
G1 X120.269 Y87.363
G1 E5 F2400
;WIDTH:0.480186
G1 F6000
G1 X120.485 Y87.375 E.00642
;WIDTH:0.46734
G1 X125.817 Y87.369 E.15358
;WIDTH:0.494918
G1 X126.044 Y87.383 E.00697
G1 X126.216 Y87.362 E.00531
;WIDTH:0.453713
G1 X126.526 Y87.348 E.00866
;WIDTH:0.426856
G1 X126.835 Y87.334 E.00808
;WIDTH:0.399999
G1 X127.476 Y87.293 E.01562
G1 X128.028 Y87.199 E.01362
G1 X128.696 Y86.985 E.01706
G1 X129.25 Y86.74 E.01473
G1 X130.116 Y86.175 E.02515
G1 X130.688 Y85.643 E.019
G1 X131.09 Y85.152 E.01544
G1 X131.409 Y84.603 E.01544
G1 X131.716 Y84.003 E.01639
G1 X132.017 Y82.938 E.02692
G1 X132.086 Y82.343 E.01457
G1 X132.095 Y79.313 E.0737
G1 X132.575 Y78.776 E.01752
G1 X132.835 Y78.347 E.0122
G1 X132.939 Y78.1 E.00652
G1 X133.038 Y77.608 E.01221
G1 X132.975 Y77.045 E.01378
G1 X132.865 Y76.735 E.008
G1 X132.576 Y76.232 E.01411
G1 X132.138 Y75.736 E.0161
G1 X131.953 Y75.303 E.01145
G1 X135.635 Y75.302 E.08956
G1 X136.208 Y75.36 E.01401
G1 X136.914 Y75.522 E.01762
G1 X137.405 Y75.703 E.01273
G1 X138.169 Y76.134 E.02134
G1 X138.822 Y76.678 E.02067
G1 X139.366 Y77.332 E.02069
G1 X139.784 Y78.072 E.02067
G1 X140.061 Y78.876 E.02068
G1 X140.148 Y79.447 E.01405
G1 X140.192 Y80.028 E.01417
G1 X140.194 Y91.87 E.28804
G1 X139.782 Y91.665 E.01119
G1 X139.202 Y91.549 E.01439
G1 X127.704 Y91.549 E.27968
G1 X127.867 Y91.261 E.00805
G1 X127.979 Y90.925 E.00861
G1 X128.027 Y90.541 E.00941
G1 X128.004 Y90.192 E.00851
G1 X127.911 Y89.84 E.00886
G1 X127.801 Y89.588 E.00669
G1 X127.444 Y89.056 E.01558
G1 X127.089 Y88.684 E.01251
G1 X127.087 Y88.579 E.00255
G1 X126.996 Y88.201 E.00946
G1 X126.844 Y87.92 E.00777
G1 X126.566 Y87.653 E.00938
;WIDTH:0.447459
G1 X126.305 Y87.518 E.00808
;WIDTH:0.494918
G1 X126.097 Y87.41 E.00718
G1 X126.097 Y87.41 F9000
G1 X127.144 Y87.703
;WIDTH:0.399999
G1 F6000
G1 X128.138 Y87.548 E.02447
G1 X128.837 Y87.323 E.01786
G1 X129.445 Y87.049 E.01622
G1 X130.362 Y86.446 E.0267
G1 X130.971 Y85.875 E.02031
G1 X131.373 Y85.383 E.01545
G1 X131.729 Y84.78 E.01703
G1 X132.067 Y84.106 E.01834
G1 X132.38 Y82.984 E.02833
G1 X132.452 Y82.344 E.01567
G1 X132.461 Y79.459 E.07018
G1 X132.888 Y78.965 E.01588
G1 X133.147 Y78.537 E.01217
G1 X133.304 Y78.143 E.01032
G1 X133.402 Y77.639 E.01249
G1 X133.336 Y76.987 E.01594
G1 X133.182 Y76.552 E.01122
G1 X132.893 Y76.05 E.01409
G1 X132.58 Y75.669 E.01199
G1 X135.622 Y75.668 E.07399
G1 X136.142 Y75.719 E.01271
G1 X136.698 Y75.839 E.01384
G1 X137.248 Y76.035 E.0142
G1 X137.96 Y76.436 E.01988
G1 X138.562 Y76.938 E.01907
G1 X139.064 Y77.54 E.01907
G1 X139.449 Y78.223 E.01907
G1 X139.705 Y78.964 E.01907
G1 X139.787 Y79.502 E.01324
G1 X139.826 Y80.028 E.01283
G1 X139.828 Y91.3 E.27418
G1 X139.202 Y91.183 E.01549
G1 X128.271 Y91.184 E.26589
G1 X128.342 Y90.971 E.00546
G1 X128.39 Y90.587 E.00941
G1 X128.358 Y90.098 E.01192
G1 X128.217 Y89.604 E.0125
G1 X127.867 Y89.006 E.01685
G1 X127.448 Y88.531 E.01541
G1 X127.43 Y88.359 E.00421
G1 X127.325 Y88.042 E.00812
G1 X127.172 Y87.755 E.00791
G1 E-5 F3600
G1 X127.172 Y87.755 F9000
G1 X103.875 Y86.587
G1 X103.76 Y86.576
G1 X103.551 Y86.552
G1 X103.436 Y86.533
G1 X103.231 Y86.494
G1 X103.117 Y86.467
G1 X102.915 Y86.413
G1 X102.804 Y86.378
G1 X102.606 Y86.309
G1 X102.497 Y86.268
G1 X102.305 Y86.184
G1 X102.199 Y86.135
G1 X102.013 Y86.036
G1 X101.906 Y85.978
G1 X101.728 Y85.866
G1 X101.627 Y85.8
G1 X101.458 Y85.676
G1 X101.362 Y85.605
G1 X101.273 Y85.529
G1 X101.113 Y85.391
G1 X101.03 Y85.31
G1 X100.881 Y85.161
G1 X100.803 Y85.073
G1 X100.666 Y84.913
G1 X100.593 Y84.819
G1 X100.468 Y84.649
G1 X100.402 Y84.55
G1 X100.289 Y84.371
G1 X100.229 Y84.267
G1 X100.13 Y84.079
G1 X100.078 Y83.971
G1 X99.992 Y83.775
G1 X99.948 Y83.665
G1 X99.877 Y83.461
G1 X99.841 Y83.35
G1 X99.786 Y83.141
G1 X99.758 Y83.029
G1 X98.715 Y77.648
G1 X98.705 Y77.5
G1 X98.715 Y77.352
G1 X98.745 Y77.207
G1 X98.792 Y77.067
G1 X98.854 Y76.931
G1 X99.651 Y75.328
G1 X100.087 Y75.328
G1 X100.087 Y74.947
G1 E5 F2400
;WIDTH:0.41165
G1 F6000
G1 X100.183 Y74.943 E.00241
;WIDTH:0.40745
G1 X130.817 Y74.941 E.76032
G1 E-5 F3600
G1 X130.817 Y74.941 F9000
G1 X130.817 Y75.328
G1 X131.349 Y75.328
G1 X132.146 Y76.931
G1 X132.208 Y77.067
G1 X132.255 Y77.207
G1 X132.285 Y77.352
G1 X132.295 Y77.5
G1 X132.285 Y77.648
G1 X131.242 Y83.029
G1 X131.214 Y83.141
G1 X131.159 Y83.35
G1 X131.123 Y83.461
G1 X131.052 Y83.665
G1 X131.008 Y83.775
G1 X130.922 Y83.971
G1 X130.87 Y84.079
G1 X130.771 Y84.267
G1 X130.711 Y84.371
G1 X130.598 Y84.55
G1 X130.532 Y84.649
G1 X130.407 Y84.819
G1 X130.334 Y84.913
G1 X130.197 Y85.073
G1 X130.119 Y85.16
G1 X129.97 Y85.31
G1 X129.887 Y85.391
G1 X129.727 Y85.529
G1 X129.638 Y85.605
G1 X129.542 Y85.676
G1 X129.373 Y85.8
G1 X129.272 Y85.866
G1 X129.094 Y85.978
G1 X128.987 Y86.036
G1 X128.801 Y86.135
G1 X128.695 Y86.184
G1 X128.503 Y86.268
G1 X128.394 Y86.309
G1 X128.196 Y86.378
G1 X128.085 Y86.413
G1 X127.883 Y86.467
G1 X127.769 Y86.494
G1 X127.564 Y86.533
G1 X127.449 Y86.552
G1 X127.24 Y86.576
G1 X127.125 Y86.587
G1 X104.651 Y88.151
G1 X103.507 Y89.134
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X103.365 Y89.313 E.00556
G1 X103.068 Y89.88 E.01557
G1 X102.973 Y90.459 E.01427
G1 X102.996 Y90.808 E.00851
G1 X103.089 Y91.16 E.00886
G1 X103.285 Y91.549 E.0106
G1 X91.798 Y91.549 E.27941
G1 X91.217 Y91.663 E.0144
G1 X90.799 Y91.881 E.01147
G1 X90.797 Y80.039 E.28804
G1 X90.834 Y79.433 E.01477
G1 X90.936 Y78.875 E.0138
G1 X91.105 Y78.333 E.01381
G1 X91.338 Y77.815 E.01382
G1 X91.631 Y77.33 E.01378
G1 X91.982 Y76.883 E.01382
G1 X92.383 Y76.482 E.01379
G1 X92.83 Y76.131 E.01382
G1 X93.306 Y75.844 E.01352
G1 X93.966 Y75.561 E.01747
G1 X94.599 Y75.405 E.01586
G1 X95.236 Y75.308 E.01567
G1 X99.059 Y75.307 E.09299
G1 X98.88 Y75.712 E.01077
G1 X98.411 Y76.247 E.01731
G1 X98.133 Y76.739 E.01375
G1 X98.021 Y77.075 E.00861
G1 X97.968 Y77.648 E.014
G1 X98.065 Y78.068 E.01048
G1 X98.199 Y78.412 E.00898
G1 X98.556 Y78.944 E.01558
G1 X98.905 Y79.31 E.0123
G1 X98.93 Y82.541 E.07859
G1 X99.076 Y83.371 E.0205
G1 X99.351 Y84.169 E.02053
G1 X99.557 Y84.564 E.01084
G1 X99.892 Y85.121 E.01581
G1 X100.647 Y85.97 E.02764
G1 X101.549 Y86.631 E.0272
G1 X102.256 Y86.974 E.01911
G1 X102.902 Y87.177 E.01647
G1 X103.534 Y87.302 E.01567
G1 X104.199 Y87.347 E.01621
;WIDTH:0.43515
G1 X104.609 Y87.365 E.01094
;WIDTH:0.4703
G1 X105.019 Y87.382 E.0119
G1 X104.824 Y87.459 E.00608
;WIDTH:0.432359
G1 X104.336 Y87.724 E.0147
;WIDTH:0.399999
G1 X104.116 Y87.995 E.00849
G1 X103.967 Y88.294 E.00813
G1 X103.909 Y88.674 E.00935
G1 X103.684 Y88.909 E.00791
G1 X103.544 Y89.087 E.00551
G1 X103.544 Y89.087 F9000
G1 X103.212 Y88.922
G1 F6000
G1 X103.044 Y89.138 E.00666
G1 X102.724 Y89.756 E.01693
G1 X102.61 Y90.413 E.01622
G1 X102.642 Y90.902 E.01192
G1 X102.717 Y91.184 E.0071
G1 X91.798 Y91.183 E.26559
G1 X91.164 Y91.299 E.01568
G1 X91.163 Y80.05 E.27362
G1 X91.197 Y79.478 E.01394
G1 X91.292 Y78.963 E.01274
G1 X91.447 Y78.463 E.01273
G1 X91.662 Y77.986 E.01273
G1 X91.933 Y77.538 E.01274
G1 X92.256 Y77.126 E.01273
G1 X92.626 Y76.756 E.01273
G1 X93.038 Y76.433 E.01273
G1 X93.473 Y76.17 E.01236
G1 X94.082 Y75.909 E.01612
G1 X94.671 Y75.764 E.01475
G1 X95.263 Y75.674 E.01457
G1 X98.414 Y75.673 E.07664
G1 X98.093 Y76.067 E.01236
G1 X97.815 Y76.559 E.01375
G1 X97.658 Y77.029 E.01205
G1 X97.604 Y77.678 E.01584
G1 X97.642 Y77.902 E.00553
G1 X97.839 Y78.518 E.01573
G1 X98.133 Y78.994 E.01361
G1 X98.54 Y79.457 E.01499
G1 X98.553 Y82.403 E.07166
G1 X98.569 Y82.599 E.00478
G1 X98.731 Y83.49 E.02203
G1 X99.006 Y84.288 E.02053
G1 X99.239 Y84.744 E.01246
G1 X99.614 Y85.359 E.01752
G1 X100.427 Y86.262 E.02956
G1 X101.385 Y86.958 E.0288
G1 X101.964 Y87.248 E.01575
G1 X102.826 Y87.535 E.0221
G1 X103.333 Y87.642 E.0126
G1 X103.891 Y87.694 E.01363
G1 X103.794 Y87.823 E.00393
G1 X103.623 Y88.168 E.00937
G1 X103.551 Y88.519 E.00872
G1 X103.405 Y88.672 E.00514
G1 X103.249 Y88.875 E.00623
G1 X103.249 Y88.875 F9000
G1 X102.762 Y89.447
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X91.757 Y78.443 E.37855
G1 X91.621 Y78.826 E.00989
G1 X102.464 Y89.669 E.37299
G1 X102.373 Y90.097 E.01064
G1 X91.519 Y79.243 E.37337
G1 X91.459 Y79.701 E.01124
G1 X102.354 Y90.596 E.37478
G1 X102.38 Y90.91 E.00766
G1 X102.148 Y90.91 E.00564
G1 X91.437 Y80.198 E.36847
G1 X91.437 Y80.717 E.01262
G1 X101.629 Y90.91 E.35062
G1 X101.11 Y90.91 E.01262
G1 X91.437 Y81.236 E.33276
G1 X91.437 Y81.755 E.01262
G1 X100.592 Y90.909 E.31491
G1 X100.073 Y90.909 E.01262
G1 X91.437 Y82.274 E.29706
G1 X91.437 Y82.793 E.01262
G1 X99.554 Y90.909 E.2792
G1 X99.035 Y90.909 E.01262
G1 X91.437 Y83.312 E.26135
G1 X91.437 Y83.831 E.01262
G1 X98.516 Y90.909 E.2435
G1 X97.997 Y90.909 E.01262
G1 X91.438 Y84.35 E.22563
G1 X91.438 Y84.869 E.01262
G1 X97.478 Y90.909 E.20777
G1 X96.959 Y90.909 E.01262
G1 X91.438 Y85.388 E.18992
G1 X91.438 Y85.907 E.01262
G1 X96.44 Y90.909 E.17207
G1 X95.921 Y90.909 E.01262
G1 X91.438 Y86.426 E.15421
G1 X91.438 Y86.945 E.01262
G1 X95.402 Y90.909 E.13636
G1 X94.883 Y90.909 E.01262
G1 X91.438 Y87.464 E.11851
G1 X91.438 Y87.983 E.01262
G1 X94.365 Y90.909 E.10067
G1 X93.846 Y90.909 E.01262
G1 X91.438 Y88.502 E.08282
G1 X91.438 Y89.021 E.01262
G1 X93.327 Y90.909 E.06496
G1 X92.808 Y90.909 E.01262
G1 X91.438 Y89.54 E.04711
G1 X91.438 Y90.059 E.01262
G1 X92.289 Y90.909 E.02926
G1 X91.773 Y90.912 E.01255
G1 X91.274 Y90.413 E.01717
G1 E-5 F3600
G1 X91.274 Y90.413 F9000
G1 X90.764 Y93.22
G1 X90.759 Y93.278
G1 X90.751 Y93.39
G1 X90.751 Y95.439
G1 X90.759 Y95.55
G1 X90.764 Y95.609
G1 X90.806 Y95.787
G1 X90.877 Y95.958
G1 X90.975 Y96.117
G1 X92.728 Y98.521
G1 E5 F2400
G1 F3072.127
G1 X92.126 Y97.919 E.02071
G1 X91.555 Y97.884 E.01392
G1 X92.563 Y98.892 E.03467
G1 X92.563 Y99.427 E.01301
G1 X91.44 Y98.304 E.03863
G1 X91.44 Y98.839 E.01301
G1 X92.563 Y99.963 E.03865
G1 X92.563 Y100.498 E.01301
G1 X91.44 Y99.375 E.03863
G1 X91.44 Y99.91 E.01301
G1 X92.563 Y101.033 E.03863
G1 X92.563 Y101.344 E.00756
G1 X92.339 Y101.345 E.00545
G1 X91.44 Y100.445 E.03094
G1 X91.44 Y100.981 E.01304
G1 X91.969 Y101.51 E.0182
G1 X91.969 Y101.51 F9000
G1 X93.378 Y102.824
;TYPE:Top solid infill
;WIDTH:0.435098
G1 F900
G1 X94.026 Y103.472 E.02443
G1 X94.026 Y104.039 E.01512
G1 X92.976 Y102.989 E.03959
G1 X92.41 Y102.99 E.01509
G1 X94.026 Y104.606 E.06093
G1 X94.026 Y105.012 E.01082
G1 X93.865 Y105.012 E.00429
G1 X91.844 Y102.991 E.07619
G1 X91.576 Y103.038 E.00725
G1 X91.426 Y103.139 E.00482
G1 X93.298 Y105.011 E.07058
G1 X92.73 Y105.01 E.01514
G1 X91.209 Y103.489 E.05734
G1 X91.14 Y103.79 E.00823
G1 X91.129 Y103.976 E.00497
G1 X92.163 Y105.01 E.03898
G1 X91.785 Y105.009 E.01008
G1 X91.576 Y104.962 E.00571
G1 X91.491 Y104.905 E.00273
G1 X91.01 Y104.424 E.01813
G1 E-5 F3600
G1 X91.01 Y104.424 F9000
G1 X92.728 Y107.32
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X92.063 Y106.655 E.02288
G1 X91.455 Y106.624 E.01481
G1 X92.564 Y107.733 E.03815
G1 X92.564 Y108.31 E.01403
G1 X91.441 Y107.187 E.03863
G1 X91.441 Y107.764 E.01403
G1 X92.564 Y108.887 E.03863
G1 X92.564 Y109.344 E.01112
G1 X92.445 Y109.344 E.00289
G1 X91.441 Y108.341 E.03452
G1 X91.441 Y108.918 E.01403
G1 X92.033 Y109.509 E.02035
G1 X92.033 Y109.509 F9000
G1 X93.378 Y110.824
;WIDTH:0.435136
G1 F900
G1 X94.027 Y111.473 E.02447
G1 X94.027 Y112.039 E.01509
G1 X92.977 Y110.989 E.03959
G1 X92.41 Y110.99 E.01512
G1 X94.027 Y112.606 E.06095
G1 X94.027 Y113.012 E.01082
G1 X93.865 Y113.012 E.00432
G1 X91.844 Y110.991 E.0762
G1 X91.576 Y111.038 E.00725
G1 X91.426 Y111.139 E.00482
G1 X93.298 Y113.011 E.07058
G1 X92.731 Y113.01 E.01512
G1 X91.209 Y111.489 E.05737
G1 X91.14 Y111.79 E.00823
G1 X91.129 Y111.976 E.00497
G1 X92.163 Y113.01 E.03899
G1 X91.785 Y113.009 E.01008
G1 X91.576 Y112.962 E.00571
G1 X91.491 Y112.905 E.00273
G1 X91.01 Y112.424 E.01814
G1 E-5 F3600
G1 X91.01 Y112.424 F9000
G1 X92.729 Y115.32
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X92.064 Y114.655 E.02288
G1 X91.456 Y114.624 E.01481
G1 X92.564 Y115.732 E.03811
G1 X92.564 Y116.309 E.01403
G1 X91.442 Y115.187 E.0386
G1 X91.442 Y115.764 E.01403
G1 X92.564 Y116.886 E.0386
G1 X92.564 Y117.344 E.01114
G1 X92.446 Y117.344 E.00287
G1 X91.442 Y116.341 E.03452
G1 X91.442 Y116.918 E.01403
G1 X92.034 Y117.509 E.02035
G1 X92.034 Y117.509 F9000
G1 X93.379 Y118.824
;WIDTH:0.435173
G1 F900
G1 X94.027 Y119.473 E.02445
G1 X94.027 Y120.039 E.01509
G1 X92.977 Y118.989 E.03959
G1 X92.411 Y118.99 E.01509
G1 X94.027 Y120.606 E.06094
G1 X94.027 Y121.012 E.01083
G1 X93.866 Y121.012 E.00429
G1 X91.845 Y118.991 E.07621
G1 X91.576 Y119.038 E.00728
G1 X91.426 Y119.139 E.00482
G1 X93.298 Y121.011 E.07059
G1 X92.731 Y121.01 E.01512
G1 X91.209 Y119.489 E.05737
G1 X91.14 Y119.79 E.00823
G1 X91.129 Y119.976 E.00497
G1 X92.163 Y121.01 E.03899
G1 X91.785 Y121.009 E.01008
G1 X91.576 Y120.962 E.00571
G1 X91.492 Y120.905 E.00271
G1 X91.01 Y120.424 E.01816
G1 E-5 F3600
G1 X91.01 Y120.424 F9000
G1 X92.729 Y123.32
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X92.064 Y122.655 E.02288
G1 X91.457 Y122.624 E.01478
G1 X92.565 Y123.732 E.03811
G1 X92.565 Y124.309 E.01403
G1 X91.443 Y123.188 E.03858
G1 X91.444 Y123.764 E.01401
G1 X92.565 Y124.886 E.03858
G1 X92.565 Y125.344 E.01114
G1 X92.447 Y125.344 E.00287
G1 X91.444 Y124.341 E.0345
G1 X91.444 Y124.918 E.01403
G1 X92.035 Y125.509 E.02033
G1 X92.035 Y125.509 F9000
G1 X93.379 Y126.824
;WIDTH:0.435203
G1 F900
G1 X94.028 Y127.473 E.02447
G1 X94.028 Y128.04 E.01512
G1 X92.977 Y126.989 E.03963
G1 X92.411 Y126.99 E.01509
G1 X94.028 Y128.607 E.06098
G1 X94.028 Y129.013 E.01083
G1 X93.867 Y129.012 E.00429
G1 X91.845 Y126.991 E.07623
G1 X91.576 Y127.038 E.00728
G1 X91.426 Y127.139 E.00482
G1 X93.299 Y129.012 E.07063
G1 X92.731 Y129.011 E.01515
G1 X91.209 Y127.489 E.0574
G1 X91.14 Y127.79 E.00823
G1 X91.129 Y127.976 E.00497
G1 X92.163 Y129.01 E.03899
G1 X91.785 Y129.009 E.01008
G1 X91.576 Y128.962 E.00571
G1 X91.492 Y128.905 E.00271
G1 X91.01 Y128.424 E.01816
G1 E-5 F3600
G1 X91.01 Y128.424 F9000
G1 X92.73 Y131.32
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X92.065 Y130.655 E.02288
G1 X91.458 Y130.624 E.01478
G1 X92.566 Y131.732 E.03811
G1 X92.566 Y132.309 E.01403
G1 X91.445 Y131.188 E.03856
G1 X91.445 Y131.764 E.01401
G1 X92.569 Y132.888 E.03866
G1 X92.591 Y133.345 E.01113
G1 X92.448 Y133.345 E.00348
G1 X91.445 Y132.341 E.03452
G1 X91.445 Y132.918 E.01403
G1 X92.037 Y133.51 E.02036
G1 E-5 F3600
G1 X92.037 Y133.51 F9000
G1 X94.732 Y135.888
G1 E5 F2400
;WIDTH:0.41211
G1 F900
G1 X93.833 Y134.989 E.03195
G1 X93.299 Y134.989 E.01342
G1 X94.764 Y136.454 E.05206
G1 X95.004 Y137.012 E.01526
G1 X94.788 Y137.012 E.00543
G1 X92.766 Y134.99 E.07186
G1 X92.232 Y134.99 E.01342
G1 X94.253 Y137.012 E.07184
G1 X93.718 Y137.011 E.01344
G1 X91.714 Y135.007 E.07122
G1 X91.576 Y135.038 E.00355
G1 X91.421 Y135.143 E.0047
G1 X91.373 Y135.2 E.00187
G1 X93.184 Y137.011 E.06436
G1 X92.649 Y137.01 E.01344
G1 X91.185 Y135.547 E.05201
G1 X91.14 Y135.79 E.00621
G1 X91.129 Y136.025 E.00591
G1 X92.114 Y137.01 E.03501
G1 X91.785 Y137.009 E.00827
G1 X91.576 Y136.962 E.00538
G1 X91.441 Y136.871 E.00409
G1 X91.014 Y136.443 E.01519
G1 E-5 F3600
G1 X91.014 Y136.443 F9000
G1 X91.282 Y140.775
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X91.852 Y141.345 E.01961
G1 X92.414 Y141.345 E.01367
G1 X91.446 Y140.377 E.0333
G1 X91.446 Y139.815 E.01367
G1 X92.975 Y141.345 E.05261
G1 X93.537 Y141.345 E.01367
G1 X91.446 Y139.253 E.07195
G1 X91.446 Y138.691 E.01367
G1 X94.099 Y141.344 E.09126
G1 X94.66 Y141.344 E.01365
G1 X91.971 Y138.655 E.0925
G1 X92.534 Y138.656 E.01369
G1 X95.222 Y141.344 E.09247
G1 X95.784 Y141.344 E.01367
G1 X93.096 Y138.656 E.09247
G1 X93.659 Y138.657 E.01369
G1 X96.51 Y141.508 E.09807
G1 E-5 F3600
G1 X96.51 Y141.508 F9000
G1 X91.733 Y146.63
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.374336
G1 F1200
G1 X105.423 Y146.631 E.30963
G1 E-5 F3600
G1 X105.423 Y146.631 F9000
G1 X105.199 Y149.177
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X103.009 Y146.987 E.07533
G1 X102.486 Y146.987 E.01272
G1 X104.512 Y149.013 E.06969
G1 X103.99 Y149.013 E.0127
G1 X101.964 Y146.987 E.06969
G1 X101.442 Y146.987 E.0127
G1 X103.468 Y149.013 E.06969
G1 X102.946 Y149.013 E.0127
G1 X100.92 Y146.987 E.06969
G1 X100.398 Y146.987 E.0127
G1 X102.424 Y149.013 E.06969
G1 X101.902 Y149.013 E.0127
G1 X99.876 Y146.987 E.06969
G1 X99.354 Y146.987 E.0127
G1 X101.38 Y149.013 E.06969
G1 X100.858 Y149.013 E.0127
G1 X98.832 Y146.987 E.06969
G1 X98.31 Y146.987 E.0127
G1 X100.336 Y149.013 E.06969
G1 X99.814 Y149.013 E.0127
G1 X97.788 Y146.987 E.06969
G1 X97.266 Y146.987 E.0127
G1 X99.292 Y149.013 E.06969
G1 X98.77 Y149.013 E.0127
G1 X96.744 Y146.987 E.06969
G1 X96.222 Y146.987 E.0127
G1 X98.248 Y149.014 E.06971
G1 X97.726 Y149.014 E.0127
G1 X95.7 Y146.987 E.06971
G1 X95.178 Y146.987 E.0127
G1 X97.204 Y149.014 E.06971
G1 X96.682 Y149.014 E.0127
G1 X94.656 Y146.987 E.06971
G1 X94.134 Y146.987 E.0127
G1 X96.16 Y149.014 E.06971
G1 X95.638 Y149.014 E.0127
G1 X93.612 Y146.987 E.06971
G1 X93.09 Y146.987 E.0127
G1 X95.117 Y149.014 E.06973
G1 X94.595 Y149.014 E.0127
G1 X92.568 Y146.987 E.06973
G1 X92.046 Y146.987 E.0127
G1 X94.073 Y149.014 E.06973
G1 X93.551 Y149.014 E.0127
G1 X91.447 Y146.935 E.07195
G1 X91.447 Y147.433 E.01211
G1 X93.029 Y149.014 E.0544
G1 X92.507 Y149.014 E.0127
G1 X91.447 Y147.955 E.03645
G1 X91.447 Y148.477 E.0127
G1 X91.985 Y149.014 E.01849
G1 X91.52 Y149.072 E.0114
G1 X91.283 Y148.834 E.00817
G1 X91.283 Y148.834 F9000
G1 X91.743 Y149.372
;TYPE:Solid infill
;WIDTH:0.374336
G1 F1200
G1 X105.422 Y149.369 E.30938
G1 E-5 F3600
G1 X105.422 Y149.369 F9000
G1 X105.773 Y151.567
G1 E5 F2400
;WIDTH:0.403026
G1 F900
G1 X105.192 Y150.986 E.02015
G1 X104.671 Y150.987 E.01278
G1 X105.609 Y151.924 E.03252
G1 X105.609 Y152.446 E.0128
G1 X104.15 Y150.987 E.0506
G1 X103.629 Y150.987 E.01278
G1 X105.609 Y152.967 E.06867
G1 X105.609 Y153.014 E.00115
G1 X105.134 Y153.013 E.01165
G1 X103.108 Y150.987 E.07027
G1 X102.586 Y150.987 E.0128
G1 X104.612 Y153.013 E.07027
G1 X104.091 Y153.013 E.01278
G1 X102.065 Y150.987 E.07027
G1 X101.544 Y150.988 E.01278
G1 X103.569 Y153.013 E.07024
G1 X103.048 Y153.013 E.01278
G1 X101.023 Y150.988 E.07024
G1 X100.501 Y150.988 E.0128
G1 X102.526 Y153.013 E.07024
G1 X102.004 Y153.012 E.0128
G1 X99.98 Y150.988 E.0702
G1 X99.459 Y150.988 E.01278
G1 X101.483 Y153.012 E.0702
G1 X100.961 Y153.012 E.0128
G1 X98.938 Y150.988 E.07018
G1 X98.416 Y150.989 E.0128
G1 X100.44 Y153.012 E.07018
G1 X99.918 Y153.012 E.0128
G1 X97.895 Y150.989 E.07017
G1 X97.374 Y150.989 E.01278
G1 X99.397 Y153.012 E.07017
G1 X98.875 Y153.012 E.0128
G1 X96.853 Y150.989 E.07015
G1 X96.331 Y150.989 E.0128
G1 X98.353 Y153.011 E.07013
G1 X97.832 Y153.011 E.01278
G1 X95.81 Y150.989 E.07013
G1 X95.289 Y150.99 E.01278
G1 X97.31 Y153.011 E.0701
G1 X96.789 Y153.011 E.01278
G1 X94.768 Y150.99 E.0701
G1 X94.246 Y150.99 E.0128
G1 X96.267 Y153.011 E.0701
G1 X95.746 Y153.011 E.01278
G1 X93.725 Y150.99 E.0701
G1 X93.204 Y150.99 E.01278
G1 X95.224 Y153.01 E.07006
G1 X94.702 Y153.01 E.0128
G1 X92.683 Y150.99 E.07004
G1 X92.161 Y150.991 E.0128
G1 X94.181 Y153.01 E.07004
G1 X93.659 Y153.01 E.0128
G1 X91.667 Y151.017 E.06911
G1 X91.576 Y151.038 E.00229
G1 X91.421 Y151.143 E.00459
G1 X91.352 Y151.224 E.00261
G1 X93.138 Y153.01 E.06195
G1 X92.616 Y153.01 E.0128
G1 X91.178 Y151.571 E.04989
G1 X91.14 Y151.79 E.00545
G1 X91.13 Y152.045 E.00626
G1 X92.095 Y153.009 E.03345
G1 X91.786 Y153.009 E.00758
G1 X91.576 Y152.962 E.00528
G1 X91.422 Y152.858 E.00456
G1 X91.015 Y152.451 E.01412
G1 E-5 F3600
G1 X91.015 Y152.451 F9000
G1 X93.819 Y154.657
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.403577
G1 F1200
G1 X94.532 Y154.657 E.01751
;WIDTH:0.420075
G1 X105.34 Y154.668 E.27733
;WIDTH:0.41755
G1 X105.739 Y154.664 E.01017
G1 X105.588 Y154.797 E.00513
G1 X105.498 Y155.051 E.00687
G1 X105.34 Y155.051 E.00403
;WIDTH:0.420075
G1 X95.481 Y155.052 E.25298
G1 X94.99 Y155.026 E.01262
;WIDTH:0.403577
G1 X94.491 Y154.93 E.01248
G1 X93.967 Y154.74 E.01369
G1 E-5 F3600
G1 X93.967 Y154.74 F9000
G1 X106.547 Y155.224
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X106.136 Y154.813 E.01414
G1 X106.259 Y154.715 E.00383
G1 X106.196 Y154.558 E.00411
G1 X106.35 Y154.505 E.00396
G1 X106.904 Y155.059 E.01906
G1 X107.426 Y155.059 E.0127
G1 X106.655 Y154.288 E.02652
G1 X106.936 Y154.047 E.009
G1 X107.948 Y155.059 E.03481
G1 X108.47 Y155.059 E.0127
G1 X107.113 Y153.702 E.04668
G1 X107.228 Y153.295 E.01029
G1 X108.992 Y155.059 E.06068
G1 X109.514 Y155.059 E.0127
G1 X107.254 Y152.799 E.07774
G1 X107.254 Y152.277 E.0127
G1 X110.036 Y155.059 E.0957
G1 X110.558 Y155.059 E.0127
G1 X107.254 Y151.755 E.11366
G1 X107.254 Y151.233 E.0127
G1 X111.08 Y155.058 E.13159
G1 X111.602 Y155.058 E.0127
G1 X107.236 Y150.693 E.15017
G1 X107.142 Y150.314 E.0095
G1 X106.884 Y149.887 E.01214
G1 X106.363 Y149.489 E.01595
G1 X105.9 Y149.357 E.01171
G1 X103.531 Y146.987 E.08151
G1 X104.053 Y146.987 E.0127
G1 X112.124 Y155.058 E.27764
G1 X112.646 Y155.058 E.0127
G1 X104.575 Y146.987 E.27764
G1 X105.097 Y146.987 E.0127
G1 X113.167 Y155.058 E.27762
G1 X113.689 Y155.058 E.0127
G1 X105.589 Y146.957 E.27865
G1 X105.785 Y146.933 E.0048
G1 X105.768 Y146.653 E.00682
G1 X105.807 Y146.653 E.00095
G1 X114.211 Y155.058 E.28911
G1 X114.733 Y155.058 E.0127
G1 X106.232 Y146.557 E.29243
G1 X106.581 Y146.384 E.00947
G1 X115.255 Y155.058 E.29838
G1 X115.777 Y155.057 E.0127
G1 X106.855 Y146.135 E.30691
G1 X107.066 Y145.824 E.00914
G1 X116.299 Y155.057 E.31761
G1 X116.821 Y155.057 E.0127
G1 X107.194 Y145.431 E.33115
G1 X107.254 Y144.969 E.01133
G1 X117.343 Y155.057 E.34704
G1 X117.865 Y155.057 E.0127
G1 X107.344 Y144.536 E.36192
G1 X107.865 Y144.535 E.01267
G1 X118.387 Y155.057 E.36195
G1 X118.909 Y155.057 E.0127
G1 X108.385 Y144.534 E.362
G1 X108.906 Y144.532 E.01267
G1 X119.431 Y155.057 E.36205
G1 X119.952 Y155.057 E.01267
G1 X109.427 Y144.531 E.36207
G1 X109.948 Y144.53 E.01267
G1 X120.474 Y155.056 E.36209
G1 X120.996 Y155.056 E.0127
G1 X110.469 Y144.529 E.36212
G1 X110.944 Y144.482 E.01161
G1 X121.518 Y155.056 E.36374
G1 X122.04 Y155.056 E.0127
G1 X111.317 Y144.333 E.36886
G1 X111.361 Y144.314 E.00117
G1 X111.392 Y144.385 E.00188
G1 X111.891 Y144.385 E.01214
G1 X122.562 Y155.056 E.36708
G1 X123.084 Y155.056 E.0127
G1 X112.413 Y144.385 E.36708
G1 X112.935 Y144.385 E.0127
G1 X123.606 Y155.056 E.36708
G1 X124.128 Y155.056 E.0127
G1 X113.457 Y144.385 E.36708
G1 X113.979 Y144.385 E.0127
G1 X124.65 Y155.056 E.36708
G1 X125.172 Y155.055 E.0127
G1 X114.501 Y144.385 E.36706
G1 X115.023 Y144.385 E.0127
G1 X123.746 Y153.107 E.30005
G1 X123.746 Y152.585 E.0127
G1 X115.546 Y144.385 E.28208
G1 X116.068 Y144.385 E.0127
G1 X123.746 Y152.063 E.26412
G1 X123.746 Y151.541 E.0127
G1 X116.59 Y144.385 E.24616
G1 X117.112 Y144.385 E.0127
G1 X123.746 Y151.019 E.22821
G1 X123.792 Y150.543 E.01163
G1 X117.634 Y144.385 E.21183
G1 X118.156 Y144.385 E.0127
G1 X123.938 Y150.167 E.1989
G1 X124.149 Y149.857 E.00912
G1 X118.678 Y144.385 E.18822
G1 X119.2 Y144.385 E.0127
G1 X124.426 Y149.612 E.17979
G1 X124.777 Y149.44 E.00951
G1 X119.66 Y144.323 E.17602
G1 X119.992 Y144.47 E.00883
G1 X120.387 Y144.529 E.00971
G1 X125.205 Y149.347 E.16574
G1 X125.215 Y149.067 E.00682
G1 X125.422 Y149.041 E.00507
G1 X120.911 Y144.53 E.15518
G1 X121.435 Y144.532 E.01275
G1 X125.915 Y149.013 E.15413
G1 X126.437 Y149.013 E.0127
G1 X121.959 Y144.534 E.15406
G1 X122.482 Y144.535 E.01272
G1 X126.96 Y149.013 E.15404
G1 X127.482 Y149.013 E.0127
G1 X125.114 Y146.645 E.08146
G1 X124.637 Y146.511 E.01205
G1 X124.232 Y146.234 E.01194
G1 X123.85 Y145.669 E.01659
G1 X123.784 Y145.315 E.00876
G1 X123.006 Y144.537 E.02676
G1 X123.53 Y144.539 E.01275
G1 X123.91 Y144.919 E.01307
G1 E-5 F3600
G1 X123.91 Y144.919 F9000
G1 X125.578 Y146.631
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.374336
G1 F1200
G1 X139.269 Y146.629 E.30965
G1 X139.727 Y147.163 F9000
;WIDTH:0.4
G1 F3072.127
G1 X139.506 Y146.943 E.00759
G1 X139.029 Y146.987 E.01165
G1 X139.563 Y147.521 E.01837
G1 X139.563 Y148.043 E.0127
G1 X138.507 Y146.987 E.03633
G1 X137.985 Y146.987 E.0127
G1 X139.563 Y148.565 E.05428
G1 X139.563 Y149.084 E.01262
G1 X137.463 Y146.987 E.07219
G1 X136.941 Y146.987 E.0127
G1 X138.966 Y149.013 E.06968
G1 X138.444 Y149.013 E.0127
G1 X136.419 Y146.987 E.06968
G1 X135.897 Y146.987 E.0127
G1 X137.922 Y149.013 E.06968
G1 X137.4 Y149.013 E.0127
G1 X135.375 Y146.987 E.06968
G1 X134.853 Y146.987 E.0127
G1 X136.878 Y149.013 E.06968
G1 X136.356 Y149.013 E.0127
G1 X134.331 Y146.987 E.06968
G1 X133.809 Y146.987 E.0127
G1 X135.834 Y149.013 E.06968
G1 X135.312 Y149.013 E.0127
G1 X133.287 Y146.987 E.06968
G1 X132.764 Y146.987 E.01272
G1 X134.79 Y149.013 E.06969
G1 X134.268 Y149.013 E.0127
G1 X132.242 Y146.987 E.06969
G1 X131.72 Y146.987 E.0127
G1 X133.746 Y149.013 E.06969
G1 X133.224 Y149.013 E.0127
G1 X131.198 Y146.987 E.06969
G1 X130.676 Y146.987 E.0127
G1 X132.702 Y149.013 E.06969
G1 X132.18 Y149.013 E.0127
G1 X130.154 Y146.987 E.06969
G1 X129.632 Y146.987 E.0127
G1 X131.658 Y149.013 E.06969
G1 X131.136 Y149.013 E.0127
G1 X129.11 Y146.987 E.06969
G1 X128.588 Y146.987 E.0127
G1 X130.614 Y149.013 E.06969
G1 X130.092 Y149.013 E.0127
G1 X128.066 Y146.987 E.06969
G1 X127.544 Y146.987 E.0127
G1 X129.57 Y149.013 E.06969
G1 X129.048 Y149.013 E.0127
G1 X127.022 Y146.987 E.06969
G1 X126.5 Y146.987 E.0127
G1 X128.526 Y149.013 E.06969
G1 X128.004 Y149.013 E.0127
G1 X125.814 Y146.823 E.07533
G1 E-5 F3600
G1 X125.814 Y146.823 F9000
G1 X125.577 Y149.369
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.374336
G1 F1200
G1 X139.253 Y149.37 E.30931
G1 E-5 F3600
G1 X139.253 Y149.37 F9000
G1 X139.985 Y151.549
G1 E5 F2400
;WIDTH:0.403026
G1 F900
G1 X139.578 Y151.142 E.01412
G1 X139.424 Y151.038 E.00456
G1 X139.214 Y150.991 E.00528
G1 X138.905 Y150.991 E.00758
G1 X139.87 Y151.955 E.03345
G1 X139.86 Y152.21 E.00626
G1 X139.822 Y152.429 E.00545
G1 X138.384 Y150.99 E.04989
G1 X137.862 Y150.99 E.0128
G1 X139.648 Y152.776 E.06195
G1 X139.579 Y152.857 E.00261
G1 X139.424 Y152.962 E.00459
G1 X139.333 Y152.983 E.00229
G1 X137.341 Y150.99 E.06911
G1 X136.819 Y150.99 E.0128
G1 X138.839 Y153.009 E.07004
G1 X138.317 Y153.01 E.0128
G1 X136.298 Y150.99 E.07004
G1 X135.776 Y150.99 E.0128
G1 X137.796 Y153.01 E.07006
G1 X137.275 Y153.01 E.01278
G1 X135.254 Y150.99 E.07008
G1 X134.733 Y150.989 E.01278
G1 X136.754 Y153.01 E.0701
G1 X136.232 Y153.01 E.0128
G1 X134.211 Y150.989 E.0701
G1 X133.69 Y150.989 E.01278
G1 X135.711 Y153.01 E.0701
G1 X135.19 Y153.011 E.01278
G1 X133.168 Y150.989 E.07013
G1 X132.647 Y150.989 E.01278
G1 X134.669 Y153.011 E.07013
G1 X134.147 Y153.011 E.0128
G1 X132.125 Y150.989 E.07013
G1 X131.604 Y150.989 E.01278
G1 X133.626 Y153.011 E.07013
G1 X133.105 Y153.011 E.01278
G1 X131.082 Y150.989 E.07015
G1 X130.561 Y150.988 E.01278
G1 X132.584 Y153.011 E.07017
G1 X132.062 Y153.012 E.0128
G1 X130.039 Y150.988 E.07018
G1 X129.517 Y150.988 E.0128
G1 X131.541 Y153.012 E.0702
G1 X131.02 Y153.012 E.01278
G1 X128.996 Y150.988 E.0702
G1 X128.474 Y150.988 E.0128
G1 X130.499 Y153.012 E.07022
G1 X129.977 Y153.012 E.0128
G1 X127.953 Y150.988 E.0702
G1 X127.431 Y150.988 E.0128
G1 X129.456 Y153.012 E.07022
G1 X128.935 Y153.013 E.01278
G1 X126.91 Y150.987 E.07025
G1 X126.388 Y150.987 E.0128
G1 X128.414 Y153.013 E.07027
G1 X127.892 Y153.013 E.0128
G1 X125.867 Y150.987 E.07025
G1 X125.391 Y150.987 E.01167
G1 X125.391 Y151.033 E.00113
G1 X127.371 Y153.013 E.06867
G1 X126.85 Y153.013 E.01278
G1 X125.391 Y151.554 E.0506
G1 X125.391 Y152.076 E.0128
G1 X126.329 Y153.013 E.03252
G1 X125.807 Y153.014 E.0128
G1 X125.227 Y152.433 E.02013
G1 E-5 F3600
G1 X125.227 Y152.433 F9000
G1 X125.455 Y154.667
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.415352
G1 F1200
G1 X125.804 Y154.667 E.00885
;WIDTH:0.415821
G1 X136.65 Y154.651 E.27523
;WIDTH:0.390904
G1 X137.152 Y154.669 E.01191
G1 X137.155 Y154.688 E.00046
G1 X136.688 Y154.884 E.01201
G1 X136.197 Y155.003 E.01198
;WIDTH:0.415821
G1 X135.72 Y155.045 E.01215
G1 X125.804 Y155.048 E.25163
;WIDTH:0.415352
G1 X125.609 Y155.048 E.00494
G1 X125.594 Y154.831 E.00551
G1 X125.573 Y154.806 E.00083
G1 E-5 F3600
G1 X125.573 Y154.806 F9000
G1 X134.953 Y141.509
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X134.702 Y141.258 E.00863
G1 X134.981 Y140.992 E.00938
G1 X135.333 Y141.344 E.01211
G1 X135.878 Y141.344 E.01326
G1 X135.247 Y140.713 E.02171
G1 X135.505 Y140.426 E.00939
G1 X136.423 Y141.344 E.03158
G1 X136.968 Y141.345 E.01326
G1 X135.753 Y140.129 E.04181
G1 X135.995 Y139.826 E.00943
G1 X137.513 Y141.345 E.05224
G1 X138.058 Y141.345 E.01326
G1 X136.226 Y139.512 E.06304
G1 X136.45 Y139.191 E.00952
G1 X138.604 Y141.345 E.0741
G1 X139.149 Y141.345 E.01326
G1 X136.66 Y138.857 E.0856
G1 X136.783 Y138.657 E.00571
G1 X137.005 Y138.657 E.0054
G1 X139.562 Y141.213 E.08794
G1 X139.562 Y140.668 E.01326
G1 X137.55 Y138.656 E.06921
G1 X138.094 Y138.656 E.01323
G1 X139.561 Y140.123 E.05046
G1 X139.561 Y139.578 E.01326
G1 X138.638 Y138.655 E.03175
G1 X139.183 Y138.655 E.01326
G1 X139.726 Y139.198 E.01868
G1 E-5 F3600
G1 X139.726 Y139.198 F9000
G1 X139.989 Y135.572
G1 E5 F2400
;WIDTH:0.429725
G1 F900
G1 X139.52 Y135.103 E.01744
G1 X139.424 Y135.038 E.00305
G1 X139.215 Y134.991 E.00563
G1 X138.848 Y134.99 E.00965
G1 X139.871 Y136.013 E.03805
G1 X139.86 Y136.21 E.00519
G1 X139.796 Y136.498 E.00776
G1 X138.289 Y134.99 E.05607
G1 X137.729 Y134.989 E.01473
G1 X139.587 Y136.848 E.06913
G1 X139.424 Y136.962 E.00523
G1 X139.19 Y137.009 E.00628
G1 X137.169 Y134.989 E.07515
G1 X136.695 Y134.988 E.01247
G1 X136.677 Y135.056 E.00185
G1 X138.631 Y137.01 E.07268
G1 X138.073 Y137.01 E.01468
G1 X136.561 Y135.499 E.05622
G1 X136.429 Y135.926 E.01176
G1 X137.514 Y137.011 E.04036
G1 X136.955 Y137.012 E.0147
G1 X136.28 Y136.336 E.02513
G1 X136.122 Y136.737 E.01134
G1 X136.561 Y137.176 E.01633
G1 E-5 F3600
G1 X136.561 Y137.176 F9000
G1 X138.27 Y132.811
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X138.804 Y133.345 E.01837
G1 X139.331 Y133.354 E.01282
G1 X138.435 Y132.458 E.03082
G1 X138.435 Y131.94 E.0126
G1 X139.56 Y133.065 E.0387
G1 X139.56 Y132.547 E.0126
G1 X138.435 Y131.422 E.0387
G1 X138.435 Y130.904 E.0126
G1 X139.56 Y132.029 E.0387
G1 X139.56 Y131.511 E.0126
G1 X138.704 Y130.655 E.02945
G1 X139.222 Y130.655 E.0126
G1 X139.725 Y131.158 E.0173
G1 E-5 F3600
G1 X139.725 Y131.158 F9000
G1 X139.99 Y127.577
G1 E5 F2400
;WIDTH:0.43522
G1 F900
G1 X139.508 Y127.095 E.01818
G1 X139.424 Y127.038 E.00271
G1 X139.215 Y126.991 E.00571
G1 X138.837 Y126.99 E.01008
G1 X139.871 Y128.024 E.03899
G1 X139.86 Y128.21 E.00497
G1 X139.82 Y128.44 E.00623
G1 X139.791 Y128.511 E.00205
G1 X138.269 Y126.99 E.05738
G1 X137.701 Y126.989 E.01515
G1 X139.574 Y128.861 E.07062
G1 X139.424 Y128.962 E.00482
G1 X139.155 Y129.009 E.00728
G1 X137.134 Y126.988 E.07622
G1 X136.972 Y126.988 E.00432
G1 X136.972 Y127.394 E.01083
G1 X138.589 Y129.01 E.06096
G1 X138.022 Y129.011 E.01512
G1 X136.972 Y127.961 E.0396
G1 X136.972 Y128.528 E.01512
G1 X137.621 Y129.176 E.02446
G1 E-5 F3600
G1 X137.621 Y129.176 F9000
G1 X139.101 Y125.51
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X138.435 Y124.844 E.02291
G1 X138.435 Y124.267 E.01403
G1 X139.559 Y125.38 E.03848
G1 X139.559 Y124.814 E.01377
G1 X138.435 Y123.69 E.03866
G1 X138.435 Y123.113 E.01403
G1 X139.559 Y124.237 E.03866
G1 X139.559 Y123.659 E.01406
G1 X138.555 Y122.656 E.03452
G1 X139.131 Y122.655 E.01401
G1 X139.723 Y123.247 E.02036
G1 E-5 F3600
G1 X139.723 Y123.247 F9000
G1 X139.99 Y119.576
G1 E5 F2400
;WIDTH:0.435182
G1 F900
G1 X139.508 Y119.095 E.01816
G1 X139.424 Y119.038 E.00271
G1 X139.215 Y118.991 E.00571
G1 X138.837 Y118.99 E.01008
G1 X139.871 Y120.024 E.03899
G1 X139.86 Y120.21 E.00497
G1 X139.82 Y120.44 E.00622
G1 X139.791 Y120.511 E.00205
G1 X138.269 Y118.99 E.05737
G1 X137.702 Y118.989 E.01512
G1 X139.574 Y120.861 E.07059
G1 X139.424 Y120.962 E.00482
G1 X139.155 Y121.009 E.00728
G1 X137.134 Y118.988 E.07621
G1 X136.973 Y118.988 E.00429
G1 X136.973 Y119.394 E.01083
G1 X138.589 Y121.01 E.06094
G1 X138.023 Y121.011 E.01509
G1 X136.973 Y119.961 E.03959
G1 X136.973 Y120.528 E.01512
G1 X137.621 Y121.176 E.02444
G1 E-5 F3600
G1 X137.621 Y121.176 F9000
G1 X139.101 Y117.51
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X138.436 Y116.845 E.02288
G1 X138.436 Y116.268 E.01403
G1 X139.558 Y117.38 E.03842
G1 X139.558 Y116.813 E.01379
G1 X138.436 Y115.691 E.0386
G1 X138.436 Y115.114 E.01403
G1 X139.558 Y116.236 E.0386
G1 X139.558 Y115.659 E.01403
G1 X138.554 Y114.656 E.03452
G1 X139.13 Y114.655 E.01401
G1 X139.722 Y115.247 E.02036
G1 E-5 F3600
G1 X139.722 Y115.247 F9000
G1 X139.99 Y111.576
G1 E5 F2400
;WIDTH:0.435145
G1 F900
G1 X139.508 Y111.095 E.01816
G1 X139.424 Y111.038 E.00271
G1 X139.215 Y110.991 E.00571
G1 X138.837 Y110.99 E.01008
G1 X139.871 Y112.024 E.03899
G1 X139.86 Y112.21 E.00497
G1 X139.791 Y112.511 E.00823
G1 X138.269 Y110.99 E.05737
G1 X137.702 Y110.989 E.01512
G1 X139.574 Y112.861 E.07058
G1 X139.424 Y112.962 E.00482
G1 X139.155 Y113.009 E.00728
G1 X137.134 Y110.988 E.0762
G1 X136.973 Y110.988 E.00429
G1 X136.973 Y111.394 E.01082
G1 X138.589 Y113.01 E.06093
G1 X138.023 Y113.011 E.01509
G1 X136.973 Y111.961 E.03959
G1 X136.973 Y112.528 E.01512
G1 X137.621 Y113.176 E.02443
G1 E-5 F3600
G1 X137.621 Y113.176 F9000
G1 X139.101 Y109.51
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X138.436 Y108.845 E.02288
G1 X138.436 Y108.268 E.01403
G1 X139.557 Y109.38 E.03841
G1 X139.557 Y108.812 E.01382
G1 X138.436 Y107.692 E.03854
G1 X138.436 Y107.115 E.01403
G1 X139.557 Y108.236 E.03856
G1 X139.556 Y107.659 E.01403
G1 X138.553 Y106.656 E.0345
G1 X139.129 Y106.655 E.01401
G1 X139.721 Y107.247 E.02036
G1 E-5 F3600
G1 X139.721 Y107.247 F9000
G1 X139.99 Y103.576
G1 E5 F2400
;WIDTH:0.435108
G1 F900
G1 X139.508 Y103.095 E.01815
G1 X139.424 Y103.038 E.00271
G1 X139.215 Y102.991 E.00571
G1 X138.837 Y102.99 E.01008
G1 X139.871 Y104.024 E.03898
G1 X139.86 Y104.21 E.00497
G1 X139.791 Y104.511 E.00823
G1 X138.269 Y102.99 E.05736
G1 X137.702 Y102.989 E.01512
G1 X139.574 Y104.861 E.07058
G1 X139.424 Y104.962 E.00482
G1 X139.156 Y105.009 E.00725
G1 X137.135 Y102.988 E.0762
G1 X136.974 Y102.988 E.00429
G1 X136.974 Y103.394 E.01082
G1 X138.59 Y105.01 E.06093
G1 X138.023 Y105.011 E.01512
G1 X136.974 Y103.961 E.03957
G1 X136.974 Y104.528 E.01512
G1 X137.622 Y105.176 E.02443
G1 E-5 F3600
G1 X137.622 Y105.176 F9000
G1 X139.037 Y101.51
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X138.437 Y100.909 E.02066
G1 X138.437 Y100.375 E.01299
G1 X139.423 Y101.361 E.03392
G1 X139.556 Y101.379 E.00326
G1 X139.555 Y100.96 E.01019
G1 X138.437 Y99.841 E.03848
G1 X138.437 Y99.307 E.01299
G1 X139.555 Y100.426 E.03848
G1 X139.555 Y99.892 E.01299
G1 X138.437 Y98.773 E.03848
G1 X138.437 Y98.239 E.01299
G1 X139.555 Y99.358 E.03848
G1 X139.555 Y98.824 E.01299
G1 X138.651 Y97.919 E.03111
G1 X139.185 Y97.919 E.01299
G1 X139.72 Y98.454 E.0184
G1 E-5 F3600
G1 X139.72 Y98.454 F9000
G1 X140.236 Y95.609
G1 X140.241 Y95.55
G1 X140.249 Y95.439
G1 X140.249 Y93.39
G1 X140.241 Y93.278
G1 X140.236 Y93.22
G1 X140.194 Y93.041
G1 X140.123 Y92.87
G1 X140.025 Y92.712
G1 X139.943 Y92.619
G1 X139.89 Y92.562
G1 X139.74 Y92.45
G1 X139.571 Y92.365
G1 X139.398 Y92.316
G1 X128.482 Y90.37
G1 E5 F2400
G1 F3072.127
G1 X129.022 Y90.91 E.01858
G1 X129.547 Y90.91 E.01277
G1 X128.607 Y89.969 E.03235
G1 X128.507 Y89.6 E.0093
G1 X128.226 Y89.063 E.01474
G1 X130.073 Y90.91 E.06354
G1 X130.598 Y90.909 E.01277
G1 X127.607 Y87.919 E.10287
G1 X128.06 Y87.846 E.01116
G1 X131.124 Y90.909 E.10538
G1 X131.649 Y90.909 E.01277
G1 X128.468 Y87.729 E.10941
G1 X128.868 Y87.603 E.0102
G1 X132.174 Y90.909 E.11372
G1 X132.7 Y90.909 E.01279
G1 X129.239 Y87.449 E.11904
G1 X129.59 Y87.274 E.00954
G1 X133.225 Y90.909 E.12504
G1 X133.751 Y90.909 E.01279
G1 X129.914 Y87.072 E.13199
G1 X130.237 Y86.871 E.00925
G1 X134.276 Y90.909 E.13892
G1 X134.802 Y90.909 E.01279
G1 X130.544 Y86.651 E.14647
G1 X130.819 Y86.402 E.00902
G1 X135.327 Y90.909 E.15506
G1 X135.852 Y90.909 E.01277
G1 X131.087 Y86.143 E.16393
G1 X131.328 Y85.859 E.00906
G1 X136.378 Y90.909 E.17372
G1 X136.903 Y90.909 E.01277
G1 X131.569 Y85.575 E.18349
G1 X131.778 Y85.259 E.00922
G1 X137.429 Y90.909 E.19437
G1 X137.954 Y90.909 E.01277
G1 X131.965 Y84.92 E.20602
G1 X132.152 Y84.582 E.0094
G1 X138.479 Y90.909 E.21765
G1 X139.005 Y90.909 E.01279
G1 X132.315 Y84.22 E.23011
G1 X132.438 Y83.817 E.01025
G1 X139.554 Y90.933 E.24479
G1 X139.554 Y90.407 E.01279
G1 X132.557 Y83.411 E.24068
G1 X132.655 Y82.983 E.01068
G1 X139.554 Y89.882 E.23732
G1 X139.554 Y89.356 E.01279
G1 X132.715 Y82.517 E.23526
G1 X132.718 Y81.995 E.0127
G1 X139.554 Y88.831 E.23515
G1 X139.553 Y88.305 E.01279
G1 X132.722 Y81.473 E.235
G1 X132.725 Y80.951 E.0127
G1 X139.553 Y87.78 E.2349
G1 X139.553 Y87.254 E.01279
G1 X132.729 Y80.429 E.23476
G1 X132.732 Y79.907 E.0127
G1 X139.553 Y86.729 E.23466
G1 X139.553 Y86.203 E.01279
G1 X132.824 Y79.474 E.23147
G1 X133.062 Y79.187 E.00907
G1 X139.553 Y85.678 E.22329
G1 X139.553 Y85.152 E.01279
G1 X133.267 Y78.866 E.21623
G1 X133.457 Y78.531 E.00937
G1 X139.553 Y84.626 E.20968
G1 X139.553 Y84.101 E.01277
G1 X133.584 Y78.132 E.20533
G1 X133.67 Y77.692 E.01091
G1 X139.553 Y83.575 E.20237
G1 X139.553 Y83.05 E.01277
G1 X133.637 Y77.134 E.20351
G1 X133.387 Y76.359 E.01981
G1 X139.553 Y82.524 E.21209
G1 X139.553 Y81.999 E.01277
G1 X133.497 Y75.944 E.20831
G1 X134.024 Y75.944 E.01282
G1 X139.552 Y81.473 E.19018
G1 X139.552 Y80.948 E.01277
G1 X134.55 Y75.945 E.17208
G1 X135.076 Y75.946 E.01279
G1 X139.552 Y80.422 E.15397
G1 X139.552 Y79.897 E.01277
G1 X135.603 Y75.947 E.13586
G1 X136.187 Y76.006 E.01428
G1 X139.478 Y79.297 E.11321
G1 X139.28 Y78.574 E.01823
G1 X136.899 Y76.192 E.08192
G1 X137.804 Y76.663 E.02482
G1 X138.349 Y77.117 E.01725
G1 X139.153 Y77.921 E.02766
G1 E-5 F3600
G1 X139.153 Y77.921 F9000
G1 X129.638 Y85.605
G1 X129.542 Y85.676
G1 X129.373 Y85.8
G1 X129.272 Y85.866
G1 X129.094 Y85.978
G1 X128.987 Y86.036
G1 X128.801 Y86.135
G1 X128.695 Y86.184
G1 X128.503 Y86.268
G1 X128.394 Y86.309
G1 X128.196 Y86.378
G1 X128.085 Y86.413
G1 X127.883 Y86.467
G1 X127.769 Y86.494
G1 X127.564 Y86.533
G1 X127.449 Y86.552
G1 X127.24 Y86.576
G1 X127.125 Y86.587
G1 X103.093 Y87.703
G1 E5 F2400
G1 F3072.127
G1 X103.397 Y88.007 E.01046
G1 X103.279 Y88.408 E.01017
G1 X102.639 Y87.768 E.02202
G1 X101.849 Y87.497 E.02032
G1 X103.038 Y88.686 E.0409
G1 X102.818 Y88.985 E.00903
G1 X91.921 Y78.088 E.37485
G1 X92.116 Y77.764 E.0092
G1 X98.76 Y84.408 E.22855
G1 X98.482 Y83.611 E.02053
G1 X92.337 Y77.466 E.21138
G1 X92.58 Y77.19 E.00894
G1 X98.348 Y82.958 E.19842
G1 X98.278 Y82.369 E.01443
G1 X92.843 Y76.934 E.18696
G1 X93.134 Y76.706 E.00899
G1 X98.276 Y81.848 E.17688
G1 X98.274 Y81.327 E.01267
G1 X93.45 Y76.504 E.16593
G1 X93.795 Y76.33 E.0094
G1 X98.271 Y80.806 E.15397
G1 X98.269 Y80.285 E.01267
G1 X94.159 Y76.174 E.1414
G1 X94.573 Y76.07 E.01038
G1 X98.267 Y79.764 E.12707
G1 X98.266 Y79.567 E.00479
G1 X97.903 Y79.144 E.01356
G1 X97.548 Y78.526 E.01734
G1 X95.011 Y75.989 E.08727
G1 X95.489 Y75.948 E.01167
G1 X97.348 Y77.806 E.06393
G1 X97.349 Y77.289 E.01258
G1 X96.008 Y75.948 E.04613
G1 X96.526 Y75.948 E.0126
G1 X97.432 Y76.853 E.03115
G1 X97.561 Y76.463 E.00999
G1 X97.045 Y75.948 E.01773
G1 X97.564 Y75.948 E.01262
G1 X97.865 Y76.248 E.01034
G1 E-5 F3600
G1 X97.865 Y76.248 F9000
G1 X90.877 Y92.87
G1 X90.806 Y93.041
G1 X90.764 Y93.22
G1 X90.759 Y93.278
G1 X90.751 Y93.39
G1 X90.751 Y95.439
G1 X91.128 Y144
G1 X91.14 Y144.21
G1 X91.18 Y144.44
G1 X91.287 Y144.699
G1 X91.421 Y144.858
G1 X91.576 Y144.962
G1 X91.786 Y145.009
G1 X105.609 Y145.014
G1 X105.609 Y143.68
G1 X105.773 Y143.68
G1 E5 F2400
;WIDTH:0.400417
G1 F900
G1 X105.27 Y143.176 E.01734
G1 X104.752 Y143.176 E.01261
G1 X105.609 Y144.033 E.02951
G1 X105.609 Y144.551 E.01261
G1 X104.219 Y143.161 E.04787
G1 X103.671 Y143.131 E.01336
G1 X105.554 Y145.014 E.06485
G1 X105.036 Y145.013 E.01261
G1 X103.045 Y143.022 E.06857
G1 X102.845 Y142.987 E.00494
G1 X102.492 Y142.987 E.0086
G1 X104.518 Y145.013 E.06977
G1 X104 Y145.013 E.01261
G1 X101.974 Y142.987 E.06977
G1 X101.457 Y142.987 E.01259
G1 X103.482 Y145.013 E.06976
G1 X102.964 Y145.013 E.01261
G1 X100.939 Y142.987 E.06976
G1 X100.422 Y142.988 E.01259
G1 X102.447 Y145.013 E.06974
G1 X101.929 Y145.012 E.01261
G1 X99.904 Y142.988 E.06972
G1 X99.387 Y142.988 E.01259
G1 X101.411 Y145.012 E.0697
G1 X100.893 Y145.012 E.01261
G1 X98.869 Y142.988 E.0697
G1 X98.351 Y142.988 E.01261
G1 X100.375 Y145.012 E.0697
G1 X99.857 Y145.012 E.01261
G1 X97.834 Y142.989 E.06967
G1 X97.316 Y142.989 E.01261
G1 X99.339 Y145.012 E.06967
G1 X98.821 Y145.011 E.01261
G1 X96.799 Y142.989 E.06963
G1 X96.281 Y142.989 E.01261
G1 X98.304 Y145.011 E.06965
G1 X97.786 Y145.011 E.01261
G1 X95.764 Y142.989 E.06963
G1 X95.246 Y142.989 E.01261
G1 X97.268 Y145.011 E.06963
G1 X96.75 Y145.011 E.01261
G1 X94.729 Y142.99 E.0696
G1 X94.211 Y142.99 E.01261
G1 X96.232 Y145.011 E.0696
G1 X95.714 Y145.011 E.01261
G1 X93.694 Y142.99 E.06958
G1 X93.176 Y142.99 E.01261
G1 X95.196 Y145.01 E.06957
G1 X94.678 Y145.01 E.01261
G1 X92.659 Y142.99 E.06955
G1 X92.141 Y142.99 E.01261
G1 X94.161 Y145.01 E.06957
G1 X93.643 Y145.01 E.01261
G1 X91.653 Y143.02 E.06853
G1 X91.576 Y143.038 E.00193
G1 X91.421 Y143.143 E.00456
G1 X91.346 Y143.231 E.00282
G1 X93.125 Y145.01 E.06127
G1 X92.607 Y145.01 E.01261
G1 X91.177 Y143.579 E.04926
G1 X91.14 Y143.79 E.00522
G1 X91.131 Y144.051 E.00636
G1 X92.254 Y145.174 E.03867
G1 E-5 F3600
G1 X92.254 Y145.174 F9000
G1 X111.724 Y144.012
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.415904
G1 F1200
G1 X119.276 Y144.012 E.19168
G1 E-5 F3600
G1 X119.276 Y144.012 F9000
G1 X139.985 Y143.549
G1 E5 F2400
;WIDTH:0.403029
G1 F900
G1 X139.578 Y143.142 E.01412
G1 X139.424 Y143.038 E.00456
G1 X139.214 Y142.991 E.00528
G1 X138.905 Y142.991 E.00758
G1 X139.87 Y143.955 E.03345
G1 X139.86 Y144.21 E.00626
G1 X139.822 Y144.429 E.00545
G1 X138.384 Y142.991 E.04988
G1 X137.862 Y142.991 E.0128
G1 X139.648 Y144.776 E.06193
G1 X139.579 Y144.857 E.00261
G1 X139.424 Y144.962 E.00459
G1 X139.333 Y144.983 E.00229
G1 X137.341 Y142.991 E.06909
G1 X136.82 Y142.991 E.01278
G1 X138.839 Y145.009 E.07001
G1 X138.317 Y145.01 E.0128
G1 X136.298 Y142.991 E.07003
G1 X135.777 Y142.991 E.01278
G1 X137.796 Y145.01 E.07003
G1 X137.275 Y145.01 E.01278
G1 X135.255 Y142.991 E.07005
G1 X134.734 Y142.991 E.01278
G1 X136.754 Y145.01 E.07005
G1 X136.232 Y145.01 E.0128
G1 X134.213 Y142.991 E.07003
G1 X133.691 Y142.991 E.0128
G1 X135.711 Y145.01 E.07005
G1 X135.19 Y145.011 E.01278
G1 X133.17 Y142.991 E.07006
G1 X132.648 Y142.991 E.0128
G1 X134.669 Y145.011 E.07008
G1 X134.147 Y145.011 E.0128
G1 X132.127 Y142.991 E.07006
G1 X131.606 Y142.991 E.01278
G1 X133.626 Y145.011 E.07006
G1 X133.105 Y145.011 E.01278
G1 X131.084 Y142.991 E.07008
G1 X130.563 Y142.991 E.01278
G1 X132.584 Y145.011 E.07008
G1 X132.062 Y145.012 E.0128
G1 X130.041 Y142.991 E.0701
G1 X129.52 Y142.991 E.01278
G1 X131.541 Y145.012 E.0701
G1 X131.02 Y145.012 E.01278
G1 X128.999 Y142.991 E.0701
G1 X128.475 Y142.988 E.01285
G1 X130.499 Y145.012 E.0702
G1 X129.977 Y145.012 E.0128
G1 X127.993 Y143.028 E.06881
G1 X127.548 Y143.104 E.01107
G1 X129.456 Y145.012 E.06618
G1 X128.935 Y145.013 E.01278
G1 X127.068 Y143.146 E.06476
G1 X126.573 Y143.172 E.01216
G1 X128.414 Y145.013 E.06385
G1 X127.892 Y145.013 E.0128
G1 X126.054 Y143.174 E.06377
G1 X125.534 Y143.176 E.01275
G1 X127.371 Y145.013 E.06372
G1 X126.85 Y145.013 E.01278
G1 X125.391 Y143.555 E.05059
G1 X125.391 Y144.076 E.01278
G1 X126.329 Y145.013 E.03252
G1 X125.807 Y145.014 E.0128
G1 X125.227 Y144.433 E.02013
;LAYER_CHANGE
;Z:1.1
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;1.1
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X125.807 Y145.014 E-.38995
G1 X126.329 Y145.013 E-.24795
G1 X125.391 Y144.076 E-.62977
G1 X125.391 Y143.587 E-.23233
;WIPE_END
G1 Z1.1 F9000
;AFTER_LAYER_CHANGE
;1.1
G1 Z1.1
G1 X125.942 Y139.441
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X125.992 Y139.371 E.00209
G1 X126 Y138.944 E.01039
G1 X126.855 Y138.106 E.02912
G1 X127.119 Y137.631 E.01322
G1 X127.093 Y137.287 E.00839
G1 X126.826 Y136.858 E.01229
G1 X126 Y136.059 E.02795
G1 X126 Y103.974 E.78044
G1 X126.304 Y103.974 E.00739
G1 X126.444 Y103.909 E.00375
G1 X126.487 Y103.792 E.00303
G1 X126.487 Y98.457 E.12977
G1 X126.462 Y98.365 E.00232
G1 X126.304 Y98.274 E.00444
G1 X126 Y98.274 E.00739
G1 X126 Y93.315 E.12062
G1 X126.037 Y93.25 E.00182
G1 X138.081 Y93.252 E.29296
G1 X139.048 Y93.274 E.02353
G1 X139.204 Y93.416 E.00513
G1 X139.243 Y93.588 E.00429
G1 X139.243 Y95.212 E.0395
G1 X139.206 Y95.373 E.00402
G1 X139.101 Y95.51 E.0042
G1 X138.932 Y95.576 E.00441
G1 X136.183 Y95.576 E.06687
G1 X136.074 Y95.612 E.00279
G1 X136 Y95.759 E.004
G1 X135.99 Y132.733 E.89936
G1 X135.946 Y133.327 E.01449
G1 X135.851 Y133.993 E.01636
G1 X135.703 Y134.694 E.01743
G1 X135.434 Y135.582 E.02257
G1 X135.186 Y136.207 E.01636
G1 X134.878 Y136.853 E.01741
G1 X134.408 Y137.654 E.02259
G1 X134.021 Y138.203 E.01634
G1 X133.57 Y138.759 E.01741
G1 X132.926 Y139.427 E.02257
G1 X132.421 Y139.87 E.01634
G1 X131.852 Y140.306 E.01744
G1 X131.07 Y140.804 E.02255
G1 X130.475 Y141.116 E.01634
G1 X129.82 Y141.407 E.01743
G1 X128.942 Y141.708 E.02258
G1 X128.291 Y141.872 E.01633
G1 X127.588 Y142.001 E.01739
G1 X126.193 Y142.1 E.03402
G1 X120.85 Y142.1 E.12996
G1 X120.85 Y141.796 E.00739
G1 X120.803 Y141.673 E.0032
G1 X120.667 Y141.613 E.00362
G1 X110.333 Y141.613 E.25136
G1 X110.198 Y141.673 E.00359
G1 X110.15 Y141.796 E.00321
G1 X110.15 Y142.1 E.00739
G1 X104.337 Y142.089 E.1414
G1 X103.161 Y141.96 E.02878
G1 X102.504 Y141.828 E.0163
G1 X101.614 Y141.568 E.02255
G1 X100.946 Y141.308 E.01744
G1 X100.339 Y141.026 E.01628
G1 X99.147 Y140.305 E.03389
G1 X98.226 Y139.566 E.02872
G1 X97.745 Y139.103 E.01624
G1 X96.852 Y138.034 E.03388
G1 X96.221 Y137.036 E.02872
G1 X95.918 Y136.441 E.01624
G1 X95.42 Y135.14 E.03388
G1 X95.148 Y133.992 E.0287
G1 X95.031 Y133.074 E.02251
G1 X94.999 Y132.296 E.01894
G1 X94.999 Y95.759 E.88873
G1 X94.926 Y95.612 E.00399
G1 X94.816 Y95.576 E.00282
G1 X92.038 Y95.57 E.06757
G1 X91.821 Y95.451 E.00602
G1 X91.75 Y95.205 E.00623
G1 X91.75 Y93.674 E.03724
G1 X91.799 Y93.418 E.00634
G1 X91.909 Y93.3 E.00392
G1 X92.077 Y93.252 E.00425
G1 X104.937 Y93.252 E.31281
G1 X105 Y93.29 E.00179
G1 X105 Y98.274 E.12123
G1 X104.696 Y98.274 E.00739
G1 X104.569 Y98.326 E.00334
G1 X104.513 Y98.457 E.00347
G1 X104.513 Y103.792 E.12977
G1 X104.53 Y103.869 E.00192
G1 X104.696 Y103.974 E.00478
G1 X105 Y103.974 E.00739
G1 X105 Y136.056 E.78036
G1 X104.145 Y136.894 E.02912
G1 X103.884 Y137.347 E.01272
G1 X103.907 Y137.713 E.00892
G1 X104.174 Y138.142 E.01229
G1 X105 Y138.941 E.02795
G1 X105.006 Y139.363 E.01027
G1 X105.094 Y139.477 E.0035
G1 X105.182 Y139.5 E.00221
G1 X125.817 Y139.5 E.50193
G1 X125.896 Y139.474 E.00202
G1 X125.896 Y139.474 F9000
G1 X126.199 Y139.698
;TYPE:Perimeter
G1 F6000
G1 X126.277 Y139.617 E.00274
G1 X126.342 Y139.478 E.00373
G1 X126.366 Y139.104 E.00912
G1 X126.807 Y138.695 E.01463
G1 X127.168 Y138.295 E.01311
G1 X127.462 Y137.777 E.01449
G1 X127.481 Y137.313 E.0113
G1 X127.406 Y137.098 E.00554
G1 X127.08 Y136.595 E.01458
G1 X126.366 Y135.904 E.02417
G1 X126.366 Y104.311 E.76847
G1 X126.724 Y104.144 E.00961
G1 X126.801 Y104.024 E.00347
G1 X126.852 Y103.792 E.00578
G1 X126.852 Y98.457 E.12977
G1 X126.829 Y98.3 E.00386
G1 X126.685 Y98.062 E.00677
G1 X126.366 Y97.934 E.00836
G1 X126.366 Y93.616 E.10503
G1 X138.877 Y93.618 E.30432
G1 X138.877 Y95.211 E.03875
G1 X136.183 Y95.21 E.06553
G1 X135.854 Y95.32 E.00844
G1 X135.677 Y95.548 E.00702
G1 X135.635 Y95.758 E.00521
G1 X135.625 Y132.719 E.89904
G1 X135.582 Y133.287 E.01386
G1 X135.491 Y133.93 E.0158
G1 X135.348 Y134.603 E.01674
G1 X135.088 Y135.462 E.02183
G1 X134.851 Y136.06 E.01565
G1 X134.554 Y136.682 E.01677
G1 X134.1 Y137.455 E.02181
G1 X133.729 Y137.982 E.01568
G1 X133.296 Y138.517 E.01674
G1 X132.673 Y139.162 E.02181
G1 X132.189 Y139.587 E.01567
G1 X131.642 Y140.006 E.01676
G1 X130.886 Y140.488 E.02181
G1 X130.315 Y140.787 E.01568
G1 X129.686 Y141.066 E.01674
G1 X128.838 Y141.358 E.02182
G1 X128.213 Y141.514 E.01567
G1 X127.542 Y141.638 E.0166
G1 X126.18 Y141.735 E.03321
G1 X121.192 Y141.735 E.12133
G1 X121.073 Y141.428 E.00801
G1 X120.667 Y141.248 E.0108
G1 X110.333 Y141.248 E.25136
G1 X110.238 Y141.256 E.00232
G1 X109.927 Y141.427 E.00863
G1 X109.809 Y141.734 E.008
G1 X104.358 Y141.723 E.13259
G1 X103.217 Y141.598 E.02792
G1 X102.592 Y141.472 E.01551
G1 X101.731 Y141.221 E.02181
G1 X101.089 Y140.972 E.01675
G1 X100.511 Y140.703 E.01551
G1 X99.357 Y140.005 E.03281
G1 X98.467 Y139.291 E.02775
G1 X98.013 Y138.853 E.01534
G1 X97.148 Y137.818 E.03281
G1 X96.539 Y136.854 E.02774
G1 X96.252 Y136.293 E.01533
G1 X95.77 Y135.032 E.03284
G1 X95.508 Y133.927 E.02762
G1 X95.396 Y133.043 E.02167
G1 X95.365 Y132.289 E.01836
G1 X95.365 Y95.759 E.88856
G1 X95.322 Y95.548 E.00524
G1 X95.145 Y95.32 E.00702
G1 X94.816 Y95.21 E.00844
G1 X92.124 Y95.211 E.06548
G1 X92.129 Y93.62 E.0387
G1 X104.634 Y93.618 E.30417
G1 X104.634 Y97.934 E.10498
G1 X104.315 Y98.062 E.00836
G1 X104.222 Y98.181 E.00367
G1 X104.148 Y98.457 E.00695
G1 X104.148 Y103.792 E.12977
G1 X104.154 Y103.872 E.00195
G1 X104.276 Y104.144 E.00725
G1 X104.634 Y104.311 E.00961
G1 X104.634 Y135.896 E.76827
G1 X103.903 Y136.612 E.02489
G1 X103.685 Y136.947 E.00972
G1 X103.525 Y137.276 E.0089
G1 X103.515 Y137.618 E.00832
G1 X103.594 Y137.903 E.00719
G1 X103.92 Y138.405 E.01456
G1 X104.634 Y139.096 E.02417
G1 X104.634 Y139.317 E.00538
G1 X104.693 Y139.565 E.0062
G1 X104.916 Y139.796 E.00781
G1 X105.182 Y139.866 E.00669
G1 X125.817 Y139.866 E.50193
G1 X125.912 Y139.857 E.00232
G1 X126.139 Y139.761 E.006
G1 X126.158 Y139.742 E.00065
G1 X126.158 Y139.742 F9000
G1 X126.453 Y139.953
G1 F6000
G1 X126.583 Y139.816 E.00459
G1 X126.691 Y139.585 E.0062
G1 X126.731 Y139.264 E.00787
G1 X127.072 Y138.947 E.01132
G1 X127.481 Y138.485 E.01501
G1 X127.755 Y138.026 E.013
G1 X127.849 Y137.681 E.0087
G1 X127.844 Y137.267 E.01007
G1 X127.719 Y136.908 E.00925
G1 X127.334 Y136.332 E.01685
G1 X126.731 Y135.749 E.0204
G1 X126.731 Y104.506 E.75995
G1 X127.005 Y104.378 E.00736
G1 X127.179 Y104.056 E.0089
G1 X127.218 Y103.792 E.00649
G1 X127.218 Y98.457 E.12977
G1 X127.214 Y98.376 E.00197
G1 X127.094 Y97.997 E.00967
G1 X126.938 Y97.799 E.00613
G1 X126.731 Y97.715 E.00543
G1 X126.731 Y93.982 E.0908
G1 X138.512 Y93.984 E.28656
G1 X138.512 Y94.845 E.02094
G1 X136.183 Y94.844 E.05665
G1 X136.025 Y94.858 E.00386
G1 X135.635 Y95.027 E.01034
G1 X135.34 Y95.407 E.0117
G1 X135.269 Y95.758 E.00871
G1 X135.259 Y132.705 E.8987
G1 X135.218 Y133.248 E.01325
G1 X135.131 Y133.866 E.01518
G1 X134.994 Y134.512 E.01606
G1 X134.743 Y135.341 E.02107
G1 X134.515 Y135.914 E.015
G1 X134.231 Y136.51 E.01606
G1 X133.793 Y137.257 E.02106
G1 X133.437 Y137.761 E.01501
G1 X133.022 Y138.274 E.01605
G1 X132.421 Y138.898 E.02107
G1 X131.957 Y139.304 E.015
G1 X131.432 Y139.706 E.01608
G1 X130.703 Y140.171 E.02103
G1 X130.156 Y140.457 E.01501
G1 X129.552 Y140.726 E.01608
G1 X128.734 Y141.007 E.02104
G1 X128.136 Y141.157 E.015
G1 X127.496 Y141.275 E.01583
G1 X126.167 Y141.369 E.03241
G1 X121.416 Y141.369 E.11556
G1 X121.344 Y141.182 E.00487
;WIDTH:0.447528
G1 X121.119 Y141.058 E.00706
;WIDTH:0.495057
G1 X120.893 Y140.935 E.00789
;WIDTH:0.542585
G1 X120.667 Y140.811 E.00872
G1 X110.333 Y140.811 E.34938
;WIDTH:0.551978
G1 X110.162 Y140.821 E.0059
G1 X110.035 Y140.911 E.00536
;WIDTH:0.513984
G1 X109.909 Y141.001 E.00494
;WIDTH:0.475989
G1 X109.783 Y141.091 E.00455
;WIDTH:0.437994
G1 X109.657 Y141.181 E.00416
;WIDTH:0.399999
G1 X109.585 Y141.367 E.00485
G1 X104.378 Y141.358 E.12666
G1 X103.273 Y141.236 E.02704
G1 X102.679 Y141.117 E.01474
G1 X101.849 Y140.875 E.02103
G1 X101.233 Y140.635 E.01608
G1 X100.683 Y140.38 E.01475
G1 X99.567 Y139.705 E.03172
G1 X98.709 Y139.016 E.02677
G1 X98.281 Y138.604 E.01445
G1 X97.444 Y137.602 E.03176
G1 X96.857 Y136.673 E.02673
G1 X96.587 Y136.144 E.01445
G1 X96.121 Y134.924 E.03177
G1 X95.868 Y133.861 E.02658
G1 X95.76 Y133.012 E.02082
G1 X95.73 Y132.281 E.0178
G1 X95.73 Y95.759 E.88836
G1 X95.66 Y95.407 E.00873
G1 X95.365 Y95.027 E.0117
G1 X94.816 Y94.844 E.01408
G1 X92.481 Y94.845 E.0568
G1 X92.481 Y93.984 E.02094
G1 X104.269 Y93.984 E.28673
G1 X104.269 Y97.715 E.09075
G1 X104.062 Y97.799 E.00543
G1 X103.906 Y97.997 E.00613
G1 X103.82 Y98.196 E.00527
G1 X103.782 Y98.457 E.00642
G1 X103.782 Y103.792 E.12977
G1 X103.821 Y104.056 E.00649
G1 X103.995 Y104.378 E.0089
G1 X104.269 Y104.506 E.00736
G1 X104.269 Y135.736 E.75964
G1 X103.928 Y136.053 E.01132
G1 X103.548 Y136.47 E.01372
G1 X103.281 Y136.908 E.01248
G1 X103.166 Y137.206 E.00777
G1 X103.149 Y137.618 E.01003
G1 X103.23 Y137.994 E.00936
G1 X103.346 Y138.199 E.00573
G1 X103.666 Y138.668 E.01381
G1 X104.269 Y139.251 E.0204
G1 X104.269 Y139.317 E.00161
G1 X104.367 Y139.73 E.01032
G1 X104.738 Y140.116 E.01302
G1 X105.181 Y140.231 E.01113
G1 X109.237 Y140.231 E.09866
;WIDTH:0.447528
G1 X109.602 Y140.255 E.01005
;WIDTH:0.495057
G1 X109.967 Y140.279 E.01121
;WIDTH:0.542585
G1 X110.333 Y140.303 E.0124
G1 X120.667 Y140.303 E.34938
G1 X121.033 Y140.279 E.0124
;WIDTH:0.495057
G1 X121.399 Y140.255 E.01124
;WIDTH:0.447528
G1 X121.766 Y140.231 E.01011
;WIDTH:0.399999
G1 X125.817 Y140.231 E.09854
G1 X125.975 Y140.218 E.00386
G1 X126.354 Y140.057 E.01002
G1 X126.412 Y139.996 E.00205
G1 E-5 F3600
G1 X126.412 Y139.996 F9000
G1 X126.348 Y139.848
G1 X104.651 Y139.849
G1 X103.642 Y137.99
G1 X103.589 Y137.876
G1 X103.549 Y137.756
G1 X103.524 Y137.63
G1 X103.515 Y137.5
G1 X103.903 Y124.292
G1 E5 F2400
G1 F6000
G1 X103.903 Y135.576 E.27447
G1 X103.662 Y135.802 E.00804
G1 X103.247 Y136.263 E.01509
G1 X102.969 Y136.719 E.01299
G1 X102.807 Y137.136 E.01088
G1 X102.784 Y137.618 E.01174
G1 X102.897 Y138.144 E.01309
G1 X103.206 Y138.674 E.01492
G1 X103.412 Y138.931 E.00801
G1 X103.916 Y139.419 E.01706
G1 X103.943 Y139.636 E.00532
G1 X104.041 Y139.895 E.00674
G1 X104.56 Y140.435 E.01822
;WIDTH:0.41549
G1 X105.183 Y140.605 E.01637
;WIDTH:0.41925
G1 X109.964 Y140.607 E.12242
G1 X109.379 Y140.929 E.0171
G1 X109.355 Y140.992 E.00173
G1 X105.182 Y140.986 E.10685
;WIDTH:0.41549
G1 X104.398 Y140.992 E.01988
;WIDTH:0.399999
G1 X103.329 Y140.874 E.02616
G1 X102.767 Y140.761 E.01394
G1 X101.967 Y140.528 E.02027
G1 X101.376 Y140.299 E.01542
G1 X100.855 Y140.056 E.01398
G1 X99.777 Y139.404 E.03064
G1 X98.951 Y138.742 E.02575
G1 X98.549 Y138.354 E.01359
G1 X97.741 Y137.386 E.03067
G1 X97.175 Y136.492 E.02574
G1 X96.921 Y135.995 E.01358
G1 X96.471 Y134.816 E.0307
G1 X96.228 Y133.796 E.0255
G1 X96.125 Y132.982 E.01996
G1 X96.096 Y132.274 E.01724
G1 X96.096 Y95.759 E.88819
G1 X95.998 Y95.266 E.01223
G1 X95.584 Y94.735 E.01638
;WIDTH:0.443184
G1 X95.328 Y94.628 E.00755
;WIDTH:0.486368
G1 X95.072 Y94.521 E.00834
;WIDTH:0.529552
G1 X94.816 Y94.414 E.00914
G1 X95.115 Y94.392 E.00988
;WIDTH:0.486368
G1 X95.414 Y94.371 E.00901
;WIDTH:0.443184
G1 X95.712 Y94.349 E.00813
;WIDTH:0.399999
G1 X103.903 Y94.349 E.19924
G1 X103.903 Y97.497 E.07657
G1 X103.808 Y97.536 E.0025
G1 X103.59 Y97.813 E.00857
G1 X103.47 Y98.091 E.00737
G1 X103.416 Y98.457 E.009
G1 X103.416 Y103.792 E.12977
G1 X103.471 Y104.162 E.0091
G1 X103.715 Y104.613 E.01247
G1 X103.903 Y104.701 E.00505
G1 X103.903 Y124.232 E.47507
G1 E-5 F3600
G1 X103.903 Y124.232 F9000
G1 X103.537 Y135.416
G1 E5 F2400
G1 F6000
G1 X103.106 Y135.858 E.01502
G1 X102.857 Y136.197 E.01023
G1 X102.564 Y136.703 E.01422
G1 X102.427 Y137.207 E.0127
G1 X102.422 Y137.728 E.01267
G1 X102.563 Y138.295 E.01421
G1 X102.894 Y138.863 E.01599
G1 X103.157 Y139.194 E.01028
G1 X103.573 Y139.595 E.01405
G1 X103.714 Y140.06 E.01182
G1 X104.24 Y140.607 E.01846
G1 X103.385 Y140.513 E.02092
G1 X102.854 Y140.406 E.01318
G1 X102.084 Y140.182 E.01951
G1 X101.52 Y139.962 E.01473
G1 X101.028 Y139.733 E.0132
G1 X99.987 Y139.104 E.02958
G1 X99.193 Y138.467 E.02476
G1 X98.817 Y138.105 E.0127
G1 X98.037 Y137.17 E.02962
G1 X97.493 Y136.311 E.02473
G1 X97.256 Y135.846 E.0127
G1 X96.821 Y134.708 E.02963
G1 X96.589 Y133.73 E.02445
G1 X96.49 Y132.951 E.0191
G1 X96.462 Y132.266 E.01668
G1 X96.462 Y95.759 E.888
G1 X96.335 Y95.126 E.0157
G1 X96.016 Y94.715 E.01266
G1 X103.537 Y94.715 E.18294
G1 X103.537 Y97.294 E.06273
G1 X103.274 Y97.629 E.01036
G1 X103.119 Y97.986 E.00947
G1 X103.051 Y98.457 E.01158
G1 X103.051 Y103.792 E.12977
G1 X103.069 Y104.034 E.0059
G1 X103.205 Y104.488 E.01153
G1 X103.434 Y104.848 E.01038
G1 X103.537 Y104.896 E.00276
G1 X103.537 Y135.356 E.74091
G1 E-5 F3600
G1 X103.537 Y135.356 F9000
G1 X95.348 Y95.226
G1 X92.912 Y94.414
G1 E5 F2400
;WIDTH:0.529834
G1 F6000
G1 X94.816 Y94.414 E.06276
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X92.912 Y94.414 E-.9044
;WIPE_END
G1 E-.5956 F3600
G1 X135.949 Y94.424 F9000
G1 E5 F2400
;WIDTH:0.550358
G1 F6000
G1 X136.183 Y94.414 E.00804
;WIDTH:0.529982
G1 X138.081 Y94.414 E.06258
G1 E-5 F3600
G1 X138.081 Y94.414 F9000
G1 X127.097 Y94.347
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X135.287 Y94.349 E.19921
;WIDTH:0.437589
G1 X135.453 Y94.367 E.00448
;WIDTH:0.475179
G1 X135.618 Y94.386 E.00487
;WIDTH:0.512769
G1 X135.784 Y94.405 E.00532
;WIDTH:0.550358
G1 X135.949 Y94.424 E.0057
G1 X135.816 Y94.502 E.00529
;WIDTH:0.512769
G1 X135.682 Y94.579 E.00492
;WIDTH:0.475179
G1 X135.549 Y94.657 E.00452
;WIDTH:0.437589
G1 X135.416 Y94.735 E.00414
;WIDTH:0.399999
G1 X135.002 Y95.266 E.01638
G1 X134.903 Y95.758 E.01221
G1 X134.893 Y132.691 E.89836
G1 X134.854 Y133.209 E.01264
G1 X134.77 Y133.802 E.01457
G1 X134.639 Y134.421 E.01539
G1 X134.397 Y135.221 E.02033
G1 X134.18 Y135.768 E.01431
G1 X133.908 Y136.339 E.01538
G1 X133.485 Y137.059 E.02031
G1 X133.146 Y137.54 E.01431
G1 X132.747 Y138.032 E.01541
G1 X132.168 Y138.633 E.0203
G1 X131.725 Y139.021 E.01432
G1 X131.222 Y139.406 E.01541
G1 X130.519 Y139.854 E.02028
G1 X129.997 Y140.128 E.01434
G1 X129.418 Y140.385 E.01541
G1 X128.63 Y140.656 E.02027
G1 X128.058 Y140.799 E.01434
G1 X127.45 Y140.911 E.01504
G1 X126.79 Y140.958 E.01609
;WIDTH:0.420285
G1 X125.817 Y140.993 E.025
G1 X121.647 Y140.993 E.10706
G1 X121.623 Y140.93 E.00173
G1 X120.895 Y140.607 E.02045
G1 X125.817 Y140.607 E.12636
;WIDTH:0.425895
G1 X126.101 Y140.578 E.00744
G1 X126.569 Y140.353 E.01353
;WIDTH:0.399999
G1 X126.889 Y140.016 E.0113
G1 X127.041 Y139.693 E.00868
G1 X127.082 Y139.438 E.00628
G1 X127.338 Y139.198 E.00854
G1 X127.794 Y138.674 E.0169
G1 X128.082 Y138.189 E.01372
G1 X128.213 Y137.706 E.01217
G1 X128.216 Y137.382 E.00788
G1 X128.163 Y137.017 E.00897
G1 X127.904 Y136.508 E.01389
G1 X127.588 Y136.069 E.01316
G1 X127.097 Y135.594 E.01662
G1 X127.097 Y104.701 E.75144
G1 X127.285 Y104.613 E.00505
G1 X127.529 Y104.162 E.01247
G1 X127.584 Y103.792 E.0091
G1 X127.584 Y98.457 E.12977
G1 X127.53 Y98.091 E.009
G1 X127.41 Y97.813 E.00737
G1 X127.192 Y97.536 E.00857
G1 X127.097 Y97.497 E.0025
G1 X127.097 Y94.407 E.07516
G1 X127.097 Y94.407 F9000
G1 X127.463 Y94.713
G1 F6000
G1 X134.984 Y94.714 E.18294
G1 X134.665 Y95.125 E.01266
G1 X134.538 Y95.758 E.0157
G1 X134.528 Y132.545 E.89481
G1 X134.491 Y133.169 E.0152
G1 X134.41 Y133.739 E.014
G1 X134.285 Y134.33 E.01469
G1 X134.051 Y135.1 E.01958
G1 X133.845 Y135.622 E.01365
G1 X133.584 Y136.167 E.0147
G1 X133.178 Y136.861 E.01956
G1 X132.854 Y137.32 E.01367
G1 X132.473 Y137.789 E.0147
G1 X131.916 Y138.368 E.01954
G1 X131.493 Y138.738 E.01367
G1 X131.013 Y139.106 E.01471
G1 X130.336 Y139.538 E.01953
G1 X129.838 Y139.799 E.01368
G1 X129.284 Y140.044 E.01473
G1 X128.526 Y140.305 E.0195
G1 X127.98 Y140.442 E.01369
G1 X127.403 Y140.548 E.01427
G1 X126.842 Y140.588 E.01368
G1 X127.196 Y140.216 E.01249
G1 X127.39 Y139.8 E.01117
G1 X127.426 Y139.618 E.00451
G1 X127.894 Y139.142 E.01624
G1 X128.344 Y138.471 E.01965
G1 X128.512 Y138.094 E.01004
G1 X128.578 Y137.73 E.009
G1 X128.569 Y137.176 E.01348
G1 X128.457 Y136.753 E.01064
G1 X128.216 Y136.318 E.0121
G1 X127.843 Y135.806 E.01541
G1 X127.463 Y135.439 E.01285
G1 X127.463 Y104.896 E.74293
G1 X127.566 Y104.848 E.00276
G1 X127.795 Y104.488 E.01038
G1 X127.879 Y104.268 E.00573
G1 X127.949 Y103.792 E.0117
G1 X127.949 Y98.457 E.12977
G1 X127.88 Y97.986 E.01158
G1 X127.726 Y97.629 E.00946
G1 X127.463 Y97.294 E.01036
G1 X127.463 Y94.773 E.06132
G1 X127.463 Y94.773 F9000
G1 X128.315 Y94.823
;WIDTH:0.4
G1 F3072.127
G1 X127.737 Y95.401 E.01988
G1 X127.737 Y95.92 E.01262
G1 X128.67 Y94.988 E.03208
G1 X129.189 Y94.988 E.01262
G1 X127.737 Y96.44 E.04995
G1 X127.737 Y96.96 E.01265
G1 X129.709 Y94.988 E.06784
G1 X130.228 Y94.988 E.01262
G1 X127.859 Y97.357 E.08149
G1 X128.048 Y97.687 E.00925
G1 X130.748 Y94.988 E.09286
G1 X131.267 Y94.988 E.01262
G1 X128.177 Y98.078 E.10629
G1 X128.224 Y98.551 E.01156
G1 X131.786 Y94.988 E.12255
G1 X132.306 Y94.988 E.01265
G1 X128.224 Y99.07 E.14042
G1 X128.224 Y99.59 E.01265
G1 X132.825 Y94.988 E.15829
G1 X133.345 Y94.988 E.01265
G1 X128.224 Y100.109 E.17616
G1 X128.224 Y100.629 E.01265
G1 X133.864 Y94.988 E.19403
G1 X134.384 Y94.988 E.01265
G1 X128.224 Y101.148 E.2119
G1 X128.224 Y101.668 E.01265
G1 X134.294 Y95.598 E.2088
G1 X134.263 Y96.148 E.0134
G1 X128.224 Y102.188 E.20776
G1 X128.224 Y102.707 E.01262
G1 X134.263 Y96.667 E.20776
G1 X134.263 Y97.187 E.01265
G1 X128.224 Y103.227 E.20776
G1 X128.224 Y103.746 E.01262
G1 X134.263 Y97.707 E.20774
G1 X134.263 Y98.226 E.01262
G1 X128.142 Y104.348 E.21058
G1 X128.043 Y104.606 E.00672
G1 X127.737 Y105.052 E.01316
G1 X127.737 Y105.272 E.00535
G1 X134.263 Y98.746 E.22449
G1 X134.263 Y99.266 E.01265
G1 X127.737 Y105.791 E.22447
G1 X127.737 Y106.311 E.01265
G1 X134.262 Y99.785 E.22447
G1 X134.262 Y100.305 E.01265
G1 X127.737 Y106.83 E.22446
G1 X127.737 Y107.35 E.01265
G1 X134.262 Y100.825 E.22446
G1 X134.262 Y101.344 E.01262
G1 X127.737 Y107.869 E.22446
G1 X127.737 Y108.389 E.01265
G1 X134.262 Y101.864 E.22446
G1 X134.262 Y102.384 E.01265
G1 X127.737 Y108.908 E.22444
G1 X127.737 Y109.428 E.01265
G1 X134.262 Y102.903 E.22446
G1 X134.261 Y103.423 E.01265
G1 X127.737 Y109.947 E.22442
G1 X127.737 Y110.467 E.01265
G1 X134.261 Y103.943 E.22442
G1 X134.261 Y104.462 E.01262
G1 X127.737 Y110.986 E.22442
G1 X127.737 Y111.506 E.01265
G1 X134.261 Y104.982 E.22442
G1 X134.261 Y105.502 E.01265
G1 X127.737 Y112.026 E.22442
G1 X127.737 Y112.545 E.01262
G1 X134.261 Y106.021 E.22442
G1 X134.261 Y106.541 E.01265
G1 X127.737 Y113.065 E.22442
G1 X127.737 Y113.584 E.01262
G1 X134.26 Y107.06 E.2244
G1 X134.26 Y107.58 E.01265
G1 X127.737 Y114.104 E.2244
G1 X127.737 Y114.623 E.01262
G1 X134.26 Y108.1 E.22439
G1 X134.26 Y108.619 E.01262
G1 X127.737 Y115.143 E.2244
G1 X127.737 Y115.662 E.01262
G1 X134.26 Y109.139 E.22439
G1 X134.26 Y109.659 E.01265
G1 X127.737 Y116.182 E.22439
G1 X127.737 Y116.701 E.01262
G1 X134.26 Y110.178 E.22439
G1 X134.259 Y110.698 E.01265
G1 X127.737 Y117.221 E.22437
G1 X127.737 Y117.74 E.01262
G1 X134.259 Y111.218 E.22435
G1 X134.259 Y111.737 E.01262
G1 X127.737 Y118.26 E.22437
G1 X127.737 Y118.779 E.01262
G1 X134.259 Y112.257 E.22435
G1 X134.259 Y112.777 E.01265
G1 X127.737 Y119.299 E.22435
G1 X127.737 Y119.818 E.01262
G1 X134.259 Y113.296 E.22435
G1 X134.259 Y113.816 E.01265
G1 X127.737 Y120.338 E.22435
G1 X127.737 Y120.857 E.01262
G1 X134.258 Y114.336 E.22432
G1 X134.258 Y114.855 E.01262
G1 X127.737 Y121.377 E.22434
G1 X127.737 Y121.896 E.01262
G1 X134.258 Y115.375 E.22432
G1 X134.258 Y115.895 E.01265
G1 X127.737 Y122.416 E.22432
G1 X127.737 Y122.935 E.01262
G1 X134.258 Y116.414 E.22432
G1 X134.258 Y116.934 E.01265
G1 X127.737 Y123.455 E.22432
G1 X127.737 Y123.974 E.01262
G1 X134.258 Y117.454 E.2243
G1 X134.257 Y117.973 E.01262
G1 X127.737 Y124.494 E.2243
G1 X127.737 Y125.013 E.01262
G1 X134.257 Y118.493 E.22428
G1 X134.257 Y119.013 E.01265
G1 X127.737 Y125.533 E.22428
G1 X127.737 Y126.052 E.01262
G1 X134.257 Y119.532 E.22428
G1 X134.257 Y120.052 E.01265
G1 X127.737 Y126.572 E.22428
G1 X127.737 Y127.092 E.01265
G1 X134.257 Y120.572 E.22428
G1 X134.257 Y121.091 E.01262
G1 X127.737 Y127.611 E.22428
G1 X127.737 Y128.131 E.01265
G1 X134.256 Y121.611 E.22427
G1 X134.256 Y122.131 E.01265
G1 X127.737 Y128.65 E.22425
G1 X127.737 Y129.17 E.01265
G1 X134.256 Y122.65 E.22427
G1 X134.256 Y123.17 E.01265
G1 X127.737 Y129.689 E.22425
G1 X127.737 Y130.209 E.01265
G1 X134.256 Y123.69 E.22425
G1 X134.256 Y124.209 E.01262
G1 X127.737 Y130.728 E.22425
G1 X127.737 Y131.248 E.01265
G1 X134.256 Y124.729 E.22425
G1 X134.255 Y125.249 E.01265
G1 X127.737 Y131.767 E.22422
G1 X127.737 Y132.287 E.01265
G1 X134.255 Y125.768 E.22423
G1 X134.255 Y126.288 E.01265
G1 X127.737 Y132.806 E.22422
G1 X127.737 Y133.326 E.01265
G1 X134.255 Y126.808 E.22422
G1 X134.255 Y127.327 E.01262
G1 X127.737 Y133.845 E.22422
G1 X127.737 Y134.365 E.01265
G1 X134.255 Y127.847 E.22422
G1 X134.255 Y128.367 E.01265
G1 X127.737 Y134.884 E.2242
G1 X127.737 Y135.322 E.01065
G1 X127.778 Y135.362 E.00139
G1 X134.254 Y128.886 E.22277
G1 X134.254 Y129.406 E.01265
G1 X128.042 Y135.618 E.21369
G1 X128.28 Y135.9 E.00898
G1 X134.254 Y129.926 E.2055
G1 X134.254 Y130.445 E.01262
G1 X128.475 Y136.224 E.19879
G1 X128.664 Y136.554 E.00925
G1 X134.254 Y130.965 E.19228
G1 X134.254 Y131.484 E.01262
G1 X128.799 Y136.939 E.18765
G1 X128.85 Y137.408 E.01148
G1 X134.254 Y132.004 E.18589
G1 X134.253 Y132.524 E.01265
G1 X128.813 Y137.964 E.18713
G1 X128.655 Y138.474 E.01299
G1 X128.413 Y138.884 E.01158
G1 X134.223 Y133.074 E.19986
G1 X134.142 Y133.674 E.01473
G1 X127.586 Y140.23 E.22552
G1 X128.242 Y140.093 E.0163
G1 X133.995 Y134.341 E.19788
G1 X133.757 Y135.098 E.0193
G1 X129.005 Y139.85 E.16347
G1 X129.939 Y139.436 E.02485
G1 X133.347 Y136.028 E.11723
G1 X132.947 Y136.712 E.01927
G1 X132.267 Y137.608 E.02736
G1 X130.752 Y139.142 E.05244
G1 E-5 F3600
G1 X130.752 Y139.142 F9000
G1 X126.349 Y139.849
G1 X103.332 Y140.39
G1 E5 F2400
G1 F3072.127
G1 X103.501 Y140.222 E.0058
G1 X103.346 Y139.857 E.00965
G1 X103.04 Y140.164 E.01054
G1 X102.629 Y140.055 E.01034
G1 X103.132 Y139.551 E.01732
G1 X102.876 Y139.288 E.00893
G1 X102.227 Y139.937 E.02233
G1 X101.849 Y139.796 E.00981
G1 X102.655 Y138.99 E.02773
G1 X102.456 Y138.669 E.00919
G1 X101.483 Y139.643 E.03349
G1 X101.131 Y139.475 E.00949
G1 X102.289 Y138.317 E.03983
G1 X102.185 Y137.901 E.01043
G1 X100.807 Y139.279 E.0474
G1 X100.483 Y139.084 E.0092
G1 X102.148 Y137.419 E.05728
G1 X102.246 Y136.801 E.01522
G1 X100.16 Y138.888 E.07177
G1 X99.87 Y138.658 E.009
G1 X103.263 Y135.265 E.11672
G1 X103.263 Y134.746 E.01262
G1 X99.582 Y138.427 E.12662
G1 X99.3 Y138.189 E.00898
G1 X103.263 Y134.226 E.13632
G1 X103.263 Y133.707 E.01262
G1 X99.036 Y137.934 E.14541
G1 X98.797 Y137.653 E.00897
G1 X103.263 Y133.187 E.15363
G1 X103.263 Y132.668 E.01262
G1 X98.561 Y137.37 E.16175
G1 X98.324 Y137.087 E.00898
G1 X103.263 Y132.149 E.16988
G1 X103.263 Y131.629 E.01265
G1 X98.113 Y136.779 E.17716
G1 X97.912 Y136.461 E.00915
G1 X103.263 Y131.11 E.18407
G1 X103.263 Y130.59 E.01265
G1 X97.714 Y136.14 E.1909
G1 X97.538 Y135.796 E.0094
G1 X103.263 Y130.071 E.19694
G1 X103.263 Y129.551 E.01265
G1 X97.389 Y135.426 E.20208
G1 X97.245 Y135.05 E.00979
G1 X103.263 Y129.032 E.20702
G1 X103.263 Y128.513 E.01262
G1 X97.102 Y134.674 E.21193
G1 X96.996 Y134.26 E.01039
G1 X103.263 Y127.993 E.21558
G1 X103.263 Y127.474 E.01262
G1 X96.897 Y133.84 E.21899
G1 X96.823 Y133.395 E.01097
G1 X103.263 Y126.954 E.22155
G1 X103.263 Y126.435 E.01262
G1 X96.764 Y132.934 E.22356
G1 X96.743 Y132.435 E.01215
G1 X103.263 Y125.915 E.22428
G1 X103.263 Y125.396 E.01262
G1 X96.736 Y131.923 E.22452
G1 X96.736 Y131.404 E.01262
G1 X103.263 Y124.877 E.22452
G1 X103.263 Y124.357 E.01265
G1 X96.736 Y130.884 E.22452
G1 X96.736 Y130.365 E.01262
G1 X103.263 Y123.838 E.22452
G1 X103.263 Y123.318 E.01265
G1 X96.736 Y129.845 E.22452
G1 X96.736 Y129.326 E.01262
G1 X103.263 Y122.799 E.22452
G1 X103.263 Y122.279 E.01265
G1 X96.736 Y128.807 E.22454
G1 X96.736 Y128.287 E.01265
G1 X103.263 Y121.76 E.22452
G1 X103.263 Y121.241 E.01262
G1 X96.736 Y127.768 E.22452
G1 X96.736 Y127.248 E.01265
G1 X103.263 Y120.721 E.22452
G1 X103.263 Y120.202 E.01262
G1 X96.736 Y126.729 E.22452
G1 X96.736 Y126.209 E.01265
G1 X103.263 Y119.682 E.22452
G1 X103.263 Y119.163 E.01262
G1 X96.736 Y125.69 E.22452
G1 X96.736 Y125.171 E.01262
G1 X103.263 Y118.643 E.22454
G1 X103.263 Y118.124 E.01262
G1 X96.736 Y124.651 E.22452
G1 X96.736 Y124.132 E.01262
G1 X103.263 Y117.605 E.22452
G1 X103.263 Y117.085 E.01265
G1 X96.736 Y123.612 E.22452
G1 X96.736 Y123.093 E.01262
G1 X103.263 Y116.566 E.22452
G1 X103.263 Y116.046 E.01265
G1 X96.736 Y122.573 E.22452
G1 X96.736 Y122.054 E.01262
G1 X103.263 Y115.527 E.22452
G1 X103.263 Y115.007 E.01265
G1 X96.736 Y121.535 E.22454
G1 X96.736 Y121.015 E.01265
G1 X103.263 Y114.488 E.22452
G1 X103.263 Y113.969 E.01262
G1 X96.736 Y120.496 E.22452
G1 X96.736 Y119.976 E.01265
G1 X103.263 Y113.449 E.22452
G1 X103.263 Y112.93 E.01262
G1 X96.736 Y119.457 E.22452
G1 X96.736 Y118.937 E.01265
G1 X103.263 Y112.41 E.22452
G1 X103.263 Y111.891 E.01262
G1 X96.736 Y118.418 E.22452
G1 X96.736 Y117.899 E.01262
G1 X103.263 Y111.371 E.22454
G1 X103.263 Y110.852 E.01262
G1 X96.736 Y117.379 E.22452
G1 X96.736 Y116.86 E.01262
G1 X103.263 Y110.333 E.22452
G1 X103.263 Y109.813 E.01265
G1 X96.736 Y116.34 E.22452
G1 X96.736 Y115.821 E.01262
G1 X103.263 Y109.294 E.22452
G1 X103.263 Y108.774 E.01265
G1 X96.736 Y115.301 E.22452
G1 X96.736 Y114.782 E.01262
G1 X103.263 Y108.255 E.22452
G1 X103.263 Y107.735 E.01265
G1 X96.736 Y114.263 E.22454
G1 X96.736 Y113.743 E.01265
G1 X103.263 Y107.216 E.22452
G1 X103.263 Y106.697 E.01262
G1 X96.736 Y113.224 E.22452
G1 X96.736 Y112.704 E.01265
G1 X103.263 Y106.177 E.22452
G1 X103.263 Y105.658 E.01262
G1 X96.736 Y112.185 E.22452
G1 X96.736 Y111.665 E.01265
G1 X103.263 Y105.138 E.22452
G1 X103.263 Y105.051 E.00212
G1 X103.081 Y104.801 E.00752
G1 X96.736 Y111.146 E.21826
G1 X96.736 Y110.627 E.01262
G1 X102.902 Y104.461 E.21211
G1 X102.798 Y104.045 E.01043
G1 X96.736 Y110.107 E.20853
G1 X96.736 Y109.588 E.01262
G1 X102.777 Y103.547 E.20781
G1 X102.777 Y103.027 E.01265
G1 X96.736 Y109.068 E.20781
G1 X96.736 Y108.549 E.01262
G1 X102.778 Y102.507 E.20784
G1 X102.779 Y101.987 E.01265
G1 X96.736 Y108.03 E.20788
G1 X96.736 Y107.51 E.01265
G1 X102.779 Y101.467 E.20788
G1 X102.78 Y100.946 E.01267
G1 X96.736 Y106.991 E.20793
G1 X96.736 Y106.471 E.01265
G1 X102.781 Y100.426 E.20794
G1 X102.781 Y99.906 E.01265
G1 X96.736 Y105.952 E.20796
G1 X96.736 Y105.432 E.01265
G1 X102.782 Y99.386 E.20798
G1 X102.783 Y98.866 E.01265
G1 X96.736 Y104.913 E.20801
G1 X96.736 Y104.394 E.01262
G1 X102.784 Y98.346 E.20805
G1 X102.856 Y97.907 E.01082
G1 X102.974 Y97.636 E.00719
G1 X96.736 Y103.874 E.21458
G1 X96.736 Y103.355 E.01262
G1 X103.263 Y96.827 E.22454
G1 X103.263 Y96.308 E.01262
G1 X96.736 Y102.835 E.22452
G1 X96.736 Y102.316 E.01262
G1 X103.263 Y95.789 E.22452
G1 X103.263 Y95.269 E.01265
G1 X96.736 Y101.796 E.22452
G1 X96.736 Y101.277 E.01262
G1 X103.024 Y94.989 E.2163
G1 X102.504 Y94.989 E.01265
G1 X96.736 Y100.758 E.19843
G1 X96.736 Y100.238 E.01265
G1 X101.985 Y94.989 E.18056
G1 X101.465 Y94.989 E.01265
G1 X96.736 Y99.719 E.16269
G1 X96.736 Y99.199 E.01265
G1 X100.946 Y94.989 E.14482
G1 X100.427 Y94.989 E.01262
G1 X96.736 Y98.68 E.12697
G1 X96.736 Y98.16 E.01265
G1 X99.907 Y94.989 E.10908
G1 X99.388 Y94.989 E.01262
G1 X96.736 Y97.641 E.09123
G1 X96.736 Y97.122 E.01262
G1 X98.868 Y94.989 E.07336
G1 X98.349 Y94.989 E.01262
G1 X96.736 Y96.602 E.05549
G1 X96.736 Y96.083 E.01262
G1 X97.829 Y94.989 E.03762
G1 X97.31 Y94.989 E.01262
G1 X96.705 Y95.594 E.02081
G1 X96.618 Y95.161 E.01074
G1 X96.955 Y94.825 E.01158
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X96.618 Y95.161 E-.22604
G1 X96.705 Y95.594 E-.20979
G1 X97.31 Y94.989 E-.40641
G1 X97.829 Y94.989 E-.24653
G1 X97.217 Y95.601 E-.41123
;WIPE_END
G1 X104.166 Y102.085 F9000
G1 X106.099 Y103.888
G1 X111.707 Y109.109
G1 X111.969 Y109.366
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X112.072 Y109.235 E.00405
G1 X112.554 Y108.874 E.01465
G1 X113.105 Y108.643 E.01453
G1 X113.704 Y108.553 E.01473
G1 X117.371 Y108.555 E.0892
G1 X117.948 Y108.659 E.01426
G1 X118.494 Y108.902 E.01454
G1 X118.996 Y109.303 E.01563
G1 X119.354 Y109.774 E.01439
G1 X121.087 Y112.775 E.08429
G1 X121.255 Y113.135 E.00966
G1 X121.366 Y113.526 E.00989
G1 X121.411 Y114.078 E.01347
G1 X121.357 Y114.517 E.01076
G1 X121.164 Y115.075 E.01436
G1 X119.246 Y118.394 E.09324
G1 X118.874 Y118.808 E.01354
G1 X118.667 Y118.984 E.00661
G1 X118.319 Y119.193 E.00987
G1 X117.799 Y119.382 E.01346
G1 X117.254 Y119.45 E.01336
G1 X113.767 Y119.451 E.08482
G1 X113.149 Y119.368 E.01517
G1 X112.593 Y119.148 E.01454
G1 X112.108 Y118.799 E.01453
G1 X111.703 Y118.317 E.01531
G1 X109.913 Y115.225 E.0869
G1 X109.667 Y114.617 E.01595
G1 X109.594 Y114.185 E.01066
G1 X109.598 Y113.779 E.00988
G1 X109.71 Y113.236 E.01349
G1 X109.913 Y112.775 E.01225
G1 X111.646 Y109.774 E.08429
G1 X111.932 Y109.413 E.0112
G1 X111.932 Y109.413 F9000
G1 X111.651 Y109.18
;TYPE:Perimeter
G1 F6000
G1 X111.786 Y109.008 E.00532
G1 X112.208 Y108.674 E.01309
G1 X112.455 Y108.514 E.00716
G1 X112.967 Y108.305 E.01345
G1 X113.653 Y108.191 E.01692
G1 X117.372 Y108.189 E.09046
G1 X118.014 Y108.299 E.01584
G1 X118.646 Y108.57 E.01673
G1 X119.193 Y108.985 E.0167
G1 X119.287 Y109.081 E.00327
G1 X119.671 Y109.591 E.01553
G1 X121.404 Y112.592 E.08429
G1 X121.606 Y113.032 E.01178
G1 X121.73 Y113.496 E.01168
G1 X121.775 Y114.048 E.01347
G1 X121.724 Y114.554 E.01237
G1 X121.481 Y115.258 E.01812
G1 X119.562 Y118.577 E.09325
G1 X119.243 Y118.97 E.01231
G1 X118.859 Y119.296 E.01225
G1 X118.444 Y119.537 E.01167
G1 X117.923 Y119.725 E.01347
G1 X117.296 Y119.813 E.0154
G1 X113.767 Y119.816 E.08584
G1 X113.1 Y119.731 E.01636
G1 X112.455 Y119.486 E.01678
G1 X111.891 Y119.094 E.01671
G1 X111.387 Y118.5 E.01895
G1 X109.597 Y115.408 E.0869
G1 X109.328 Y114.754 E.0172
G1 X109.228 Y114.185 E.01405
G1 X109.24 Y113.705 E.01168
G1 X109.352 Y113.162 E.01349
G1 X109.571 Y112.642 E.01372
G1 X111.329 Y109.591 E.08565
G1 X111.614 Y109.227 E.01124
G1 X111.614 Y109.227 F9000
G1 X111.334 Y108.994
G1 F6000
G1 X111.5 Y108.78 E.00659
G1 X111.992 Y108.379 E.01544
G1 X112.316 Y108.175 E.00931
G1 X112.829 Y107.966 E.01347
G1 X113.601 Y107.829 E.01907
G1 X117.372 Y107.824 E.09173
G1 X118.081 Y107.94 E.01748
G1 X118.798 Y108.237 E.01888
G1 X119.421 Y108.699 E.01887
G1 X119.578 Y108.859 E.00545
G1 X119.988 Y109.409 E.01669
G1 X121.72 Y112.41 E.08428
G1 X121.957 Y112.929 E.01388
G1 X122.095 Y113.466 E.01349
G1 X122.14 Y114.018 E.01347
G1 X122.091 Y114.57 E.01348
G1 X121.872 Y115.276 E.01798
G1 X121.798 Y115.441 E.0044
G1 X119.879 Y118.76 E.09325
G1 X119.554 Y119.171 E.01275
G1 X119.17 Y119.519 E.01261
G1 X118.736 Y119.8 E.01258
G1 X118.048 Y120.069 E.01797
G1 X117.338 Y120.176 E.01747
G1 X113.767 Y120.182 E.08686
G1 X113.051 Y120.093 E.01755
G1 X112.317 Y119.825 E.01901
G1 X111.675 Y119.389 E.01888
G1 X111.158 Y118.81 E.01888
G1 X111.07 Y118.683 E.00376
G1 X109.28 Y115.592 E.08688
G1 X108.989 Y114.89 E.01848
G1 X108.875 Y114.333 E.01383
G1 X108.863 Y113.816 E.01258
G1 X108.994 Y113.088 E.01799
G1 X109.237 Y112.493 E.01563
G1 X111.012 Y109.408 E.08657
G1 X111.297 Y109.041 E.0113
G1 X111.297 Y109.041 F9000
G1 X111.017 Y108.808
G1 F6000
G1 X111.214 Y108.552 E.00786
G1 X111.459 Y108.317 E.00826
G1 X111.905 Y107.989 E.01347
G1 X112.422 Y107.737 E.01399
G1 X112.995 Y107.545 E.0147
G1 X113.55 Y107.467 E.01363
G1 X117.373 Y107.458 E.09299
G1 X118.148 Y107.58 E.01908
G1 X118.446 Y107.675 E.00761
G1 X118.95 Y107.904 E.01347
G1 X119.216 Y108.068 E.0076
G1 X119.649 Y108.414 E.01348
G1 X119.868 Y108.637 E.0076
G1 X120.304 Y109.226 E.01782
G1 X122.037 Y112.227 E.08429
G1 X122.308 Y112.826 E.01599
G1 X122.459 Y113.436 E.01529
G1 X122.504 Y113.988 E.01347
G1 X122.454 Y114.615 E.0153
G1 X122.218 Y115.394 E.0198
G1 X122.114 Y115.624 E.00614
G1 X120.195 Y118.943 E.09325
G1 X119.835 Y119.404 E.01423
G1 X119.41 Y119.795 E.01405
G1 X118.927 Y120.112 E.01405
G1 X118.172 Y120.413 E.01977
G1 X117.638 Y120.509 E.0132
G1 X117.233 Y120.548 E.0099
G1 X113.766 Y120.548 E.08433
G1 X113.001 Y120.455 E.01874
G1 X112.69 Y120.372 E.00783
G1 X112.177 Y120.163 E.01347
G1 X111.905 Y120.01 E.00759
G1 X111.458 Y119.683 E.01347
G1 X111.197 Y119.428 E.00888
G1 X110.877 Y119.043 E.01218
G1 X110.754 Y118.866 E.00524
G1 X108.964 Y115.775 E.08688
G1 X108.649 Y115.026 E.01976
G1 X108.514 Y114.393 E.01574
G1 X108.497 Y113.816 E.01404
G1 X108.636 Y113.014 E.0198
G1 X108.904 Y112.343 E.01758
G1 X110.696 Y109.226 E.08745
G1 X110.98 Y108.856 E.01135
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X111.017 Y108.808 E-.02879
G1 X111.214 Y108.552 E-.15344
G1 X111.459 Y108.317 E-.16126
G1 X111.905 Y107.989 E-.26297
G1 X112.422 Y107.737 E-.27319
G1 X112.995 Y107.545 E-.28705
G1 X113.55 Y107.467 E-.26622
G1 X113.691 Y107.467 E-.06708
;WIPE_END
G1 X112.586 Y105.535 F9000
G1 X112.744 Y105.222
G1 E5 F2400
G1 F6000
G1 X112.731 Y105.218 E.00033
G1 X112.259 Y104.928 E.01347
G1 X111.938 Y104.627 E.0107
G1 X111.646 Y104.226 E.01207
G1 X109.913 Y101.225 E.08429
G1 X109.667 Y100.617 E.01595
G1 X109.594 Y100.185 E.01066
G1 X109.612 Y99.691 E.01202
G1 X109.667 Y99.383 E.00761
G1 X109.902 Y98.798 E.01533
G1 X111.646 Y95.774 E.08491
G1 X111.953 Y95.355 E.01263
G1 X112.253 Y95.076 E.00997
G1 X112.592 Y94.853 E.00987
G1 X113.105 Y94.643 E.01348
G1 X113.537 Y94.562 E.01069
G1 X117.233 Y94.549 E.0899
G1 X117.602 Y94.58 E.00901
G1 X118.137 Y94.725 E.01348
G1 X118.518 Y94.918 E.01039
G1 X118.964 Y95.27 E.01382
G1 X119.355 Y95.775 E.01554
G1 X121.165 Y98.926 E.08839
G1 X121.351 Y99.486 E.01435
G1 X121.411 Y100.085 E.01464
G1 X121.319 Y100.668 E.01436
G1 X121.097 Y101.205 E.01413
G1 X119.354 Y104.226 E.08484
G1 X118.997 Y104.697 E.01438
G1 X118.532 Y105.074 E.01456
G1 X117.991 Y105.327 E.01453
G1 X117.37 Y105.445 E.01538
G1 X113.767 Y105.451 E.08764
G1 X113.149 Y105.368 E.01517
G1 X112.801 Y105.243 E.00899
G1 X112.801 Y105.243 F9000
G1 X112.663 Y105.58
;TYPE:Perimeter
G1 F6000
G1 X112.578 Y105.551 E.00218
G1 X112.068 Y105.239 E.01454
G1 X111.692 Y104.901 E.0123
G1 X111.362 Y104.459 E.01342
G1 X109.596 Y101.408 E.08575
G1 X109.328 Y100.754 E.01719
G1 X109.229 Y100.203 E.01362
G1 X109.251 Y99.631 E.01392
G1 X109.328 Y99.246 E.00955
G1 X109.562 Y98.662 E.0153
G1 X111.329 Y95.591 E.08618
G1 X111.643 Y95.157 E.01303
G1 X112.049 Y94.773 E.01359
G1 X112.454 Y94.514 E.01169
G1 X112.967 Y94.305 E.01347
G1 X113.535 Y94.197 E.01406
G1 X117.233 Y94.184 E.08995
G1 X117.698 Y94.227 E.01136
G1 X118.232 Y94.372 E.01346
G1 X118.745 Y94.631 E.01398
G1 X119.191 Y94.983 E.01382
G1 X119.632 Y95.533 E.01715
G1 X121.482 Y98.743 E.09012
G1 X121.676 Y99.25 E.0132
G1 X121.762 Y99.701 E.01117
G1 X121.77 Y100.181 E.01168
G1 X121.679 Y100.733 E.01361
G1 X121.433 Y101.348 E.01611
G1 X119.671 Y104.409 E.08591
G1 X119.287 Y104.919 E.01553
G1 X118.76 Y105.36 E.01671
G1 X118.143 Y105.66 E.01669
G1 X117.371 Y105.811 E.01913
G1 X113.767 Y105.816 E.08766
G1 X113.1 Y105.731 E.01636
G1 X112.72 Y105.6 E.00978
G1 X112.72 Y105.6 F9000
G1 X112.58 Y105.942
G1 F6000
G1 X112.516 Y105.922 E.00163
G1 X112.013 Y105.635 E.01409
G1 X111.728 Y105.438 E.00843
G1 X111.348 Y105.059 E.01305
G1 X111.013 Y104.592 E.01398
G1 X109.28 Y101.591 E.08429
G1 X108.989 Y100.89 E.01846
G1 X108.875 Y100.333 E.01383
G1 X108.863 Y99.815 E.0126
G1 X108.935 Y99.302 E.0126
G1 X109.223 Y98.526 E.02013
G1 X111.013 Y95.408 E.08745
G1 X111.348 Y94.941 E.01398
G1 X111.728 Y94.562 E.01305
G1 X112.151 Y94.263 E.0126
G1 X112.828 Y93.966 E.01798
G1 X113.37 Y93.846 E.0135
G1 X113.534 Y93.831 E.00401
G1 X117.233 Y93.818 E.08998
G1 X117.794 Y93.874 E.01371
G1 X118.328 Y94.019 E.01346
G1 X118.816 Y94.245 E.01308
G1 X119.418 Y94.696 E.0183
G1 X119.923 Y95.311 E.01936
G1 X121.799 Y98.561 E.09128
G1 X121.992 Y99.033 E.0124
G1 X122.109 Y99.538 E.01261
G1 X122.142 Y100.055 E.0126
G1 X122.041 Y100.787 E.01797
G1 X121.77 Y101.491 E.01835
G1 X119.988 Y104.591 E.08697
G1 X119.578 Y105.141 E.01669
G1 X118.988 Y105.646 E.01889
G1 X118.294 Y105.993 E.01887
G1 X117.538 Y106.161 E.01884
G1 X117.371 Y106.176 E.00408
G1 X113.767 Y106.182 E.08766
G1 X113.051 Y106.093 E.01755
G1 X112.637 Y105.96 E.01058
G1 X112.637 Y105.96 F9000
G1 X112.5 Y106.299
G1 F6000
G1 X112.392 Y106.265 E.00275
G1 X111.822 Y105.947 E.01588
G1 X111.478 Y105.704 E.01024
G1 X111.053 Y105.275 E.01469
G1 X110.696 Y104.775 E.01494
G1 X108.963 Y101.773 E.08431
G1 X108.649 Y101.026 E.01971
G1 X108.514 Y100.393 E.01574
G1 X108.497 Y99.815 E.01407
G1 X108.574 Y99.243 E.01404
G1 X108.884 Y98.39 E.02208
G1 X110.696 Y95.225 E.08871
G1 X111.053 Y94.725 E.01494
G1 X111.478 Y94.296 E.01469
G1 X111.947 Y93.96 E.01403
G1 X112.69 Y93.628 E.01979
G1 X113.304 Y93.487 E.01532
G1 X113.533 Y93.465 E.0056
G1 X117.233 Y93.452 E.09
G1 X117.89 Y93.521 E.01607
G1 X118.424 Y93.666 E.01346
G1 X118.981 Y93.918 E.01487
G1 X119.644 Y94.41 E.02008
G1 X119.868 Y94.637 E.00776
G1 X120.213 Y95.089 E.01383
G1 X122.116 Y98.379 E.09245
G1 X122.333 Y98.902 E.01377
G1 X122.467 Y99.464 E.01405
G1 X122.507 Y100.04 E.01404
G1 X122.402 Y100.846 E.01977
G1 X122.211 Y101.388 E.01398
G1 X121.868 Y102.066 E.01848
G1 X120.304 Y104.774 E.07607
G1 X119.868 Y105.363 E.01782
G1 X119.649 Y105.587 E.00762
G1 X119.216 Y105.932 E.01347
G1 X118.95 Y106.096 E.0076
G1 X118.446 Y106.326 E.01348
G1 X118.148 Y106.42 E.0076
G1 X117.604 Y106.521 E.01346
G1 X117.372 Y106.542 E.00567
G1 X113.766 Y106.548 E.08771
G1 X113.001 Y106.455 E.01874
G1 X112.557 Y106.317 E.01131
G1 E-5 F3600
G1 X112.557 Y106.317 F9000
G1 X108.292 Y101.081
G1 E5 F2400
G1 F6000
G1 X108.153 Y100.452 E.01567
G1 X108.131 Y99.815 E.0155
G1 X108.213 Y99.183 E.0155
G1 X108.31 Y98.838 E.00872
G1 X108.646 Y98.044 E.02097
G1 X110.379 Y95.042 E.08431
G1 X110.758 Y94.509 E.01591
G1 X111.227 Y94.029 E.01632
G1 X111.744 Y93.656 E.01551
G1 X112.552 Y93.289 E.02159
G1 X113.237 Y93.127 E.01712
G1 X113.531 Y93.1 E.00718
G1 X117.233 Y93.087 E.09005
G1 X117.986 Y93.169 E.01842
G1 X118.52 Y93.314 E.01346
G1 X119.146 Y93.592 E.01666
G1 X119.871 Y94.123 E.02186
G1 X120.159 Y94.415 E.00998
G1 X120.504 Y94.867 E.01383
G1 X120.623 Y95.046 E.00523
G1 X122.433 Y98.197 E.08839
G1 X122.675 Y98.771 E.01515
G1 X122.825 Y99.39 E.01549
G1 X122.873 Y100.025 E.01549
G1 X122.763 Y100.905 E.02157
G1 X122.547 Y101.531 E.01611
G1 X122.185 Y102.248 E.01954
G1 X120.621 Y104.957 E.07609
G1 X120.159 Y105.584 E.01894
G1 X119.877 Y105.872 E.0098
G1 X119.444 Y106.218 E.01348
G1 X119.102 Y106.428 E.00976
G1 X118.598 Y106.658 E.01348
G1 X118.215 Y106.779 E.00977
;WIDTH:0.436733
G1 X117.675 Y106.898 E.0148
;WIDTH:0.486005
G1 X117.574 Y106.932 E.0032
;WIDTH:0.535277
G1 X117.474 Y106.966 E.00352
;WIDTH:0.584548
G1 X117.373 Y107 E.0039
G1 X117.584 Y107.055 E.00798
;WIDTH:0.538411
G1 X117.794 Y107.11 E.00728
;WIDTH:0.492274
G1 X118.004 Y107.166 E.00662
;WIDTH:0.446137
G1 X118.215 Y107.221 E.00597
;WIDTH:0.399999
G1 X118.598 Y107.342 E.00977
G1 X119.102 Y107.572 E.01348
G1 X119.444 Y107.782 E.00976
G1 X119.877 Y108.128 E.01348
G1 X120.159 Y108.416 E.0098
G1 X120.504 Y108.867 E.01381
G1 X120.621 Y109.043 E.00514
G1 X122.354 Y112.044 E.08429
G1 X122.658 Y112.723 E.0181
G1 X122.824 Y113.406 E.0171
G1 X122.869 Y113.958 E.01347
G1 X122.817 Y114.66 E.01712
G1 X122.565 Y115.511 E.02159
G1 X122.431 Y115.807 E.0079
G1 X120.512 Y119.126 E.09325
G1 X120.116 Y119.638 E.01574
G1 X119.649 Y120.072 E.01551
G1 X119.118 Y120.424 E.0155
G1 X118.627 Y120.637 E.01302
G1 X118.194 Y120.79 E.01117
;WIDTH:0.433246
G1 X117.939 Y120.848 E.00694
;WIDTH:0.466493
G1 X117.684 Y120.906 E.00752
;WIDTH:0.50816
G1 X117.6 Y120.936 E.00281
;WIDTH:0.549826
G1 X117.517 Y120.967 E.00304
;WIDTH:0.591492
G1 X117.433 Y120.998 E.00332
G1 X117.554 Y121.04 E.00475
;WIDTH:0.543619
G1 X117.674 Y121.081 E.0043
;WIDTH:0.495746
G1 X117.795 Y121.123 E.00393
;WIDTH:0.447873
G1 X117.915 Y121.165 E.0035
;WIDTH:0.399999
G1 X118.32 Y121.244 E.01004
G1 X119.102 Y121.572 E.02063
G1 X119.444 Y121.782 E.00976
G1 X119.877 Y122.128 E.01348
G1 X120.159 Y122.416 E.0098
G1 X120.621 Y123.043 E.01894
G1 X122.354 Y126.044 E.08429
G1 X122.675 Y126.783 E.0196
G1 X122.807 Y127.305 E.0131
G1 X122.872 Y128.017 E.01739
G1 X122.767 Y128.887 E.02132
G1 X122.545 Y129.567 E.0174
G1 X122.431 Y129.807 E.00646
G1 X120.512 Y133.125 E.09323
G1 X120.06 Y133.68 E.01741
G1 X119.689 Y134.04 E.01257
G1 X119.162 Y134.399 E.01551
G1 X118.584 Y134.667 E.0155
G1 X118.021 Y134.83 E.01426
G1 X117.422 Y134.903 E.01468
G1 X113.767 Y134.913 E.0889
G1 X112.952 Y134.818 E.01996
G1 X112.552 Y134.711 E.01007
G1 X112.039 Y134.501 E.01348
G1 X111.688 Y134.305 E.00978
G1 X111.242 Y133.978 E.01345
G1 X110.95 Y133.703 E.00976
G1 X110.596 Y133.278 E.01345
G1 X110.437 Y133.05 E.00676
G1 X108.647 Y129.958 E.0869
G1 X108.31 Y129.163 E.021
G1 X108.204 Y128.755 E.01025
G1 X108.137 Y128.22 E.01311
G1 X108.159 Y127.506 E.01738
G1 X108.293 Y126.874 E.01571
G1 X108.646 Y126.044 E.02194
G1 X110.379 Y123.043 E.08429
G1 X110.927 Y122.324 E.02199
G1 X111.243 Y122.022 E.01063
G1 X111.689 Y121.694 E.01347
G1 X112.04 Y121.498 E.00978
G1 X112.553 Y121.289 E.01347
;WIDTH:0.444545
G1 X112.786 Y121.221 E.00662
;WIDTH:0.489091
G1 X113.02 Y121.153 E.00737
;WIDTH:0.533637
G1 X113.253 Y121.085 E.00806
;WIDTH:0.578183
G1 X113.487 Y121.017 E.00882
;WIDTH:0.602448
G1 X113.532 Y120.999 E.00183
G1 X113.416 Y120.963 E.00459
;WIDTH:0.561958
G1 X113.3 Y120.926 E.00427
;WIDTH:0.521469
G1 X113.184 Y120.89 E.00394
;WIDTH:0.480979
G1 X113.068 Y120.854 E.00361
;WIDTH:0.440489
G1 X112.952 Y120.818 E.00328
;WIDTH:0.399999
G1 X112.552 Y120.711 E.01007
G1 X112.039 Y120.501 E.01348
G1 X111.688 Y120.305 E.00978
G1 X111.242 Y119.978 E.01345
G1 X110.916 Y119.662 E.01104
G1 X110.596 Y119.277 E.01218
G1 X110.437 Y119.05 E.00674
G1 X108.647 Y115.958 E.0869
G1 X108.31 Y115.162 E.02103
G1 X108.153 Y114.452 E.01769
G1 X108.131 Y113.816 E.01548
G1 X108.278 Y112.94 E.02161
G1 X108.57 Y112.193 E.01951
G1 X110.379 Y109.043 E.08836
G1 X110.927 Y108.324 E.02199
G1 X111.243 Y108.022 E.01063
G1 X111.689 Y107.694 E.01347
G1 X112.04 Y107.498 E.00978
G1 X112.553 Y107.289 E.01347
;WIDTH:0.444541
G1 X112.786 Y107.221 E.00662
;WIDTH:0.489083
G1 X113.02 Y107.153 E.00737
;WIDTH:0.533625
G1 X113.253 Y107.085 E.00806
;WIDTH:0.578167
G1 X113.487 Y107.017 E.00882
;WIDTH:0.602442
G1 X113.532 Y106.999 E.00183
G1 X113.416 Y106.963 E.00459
;WIDTH:0.561954
G1 X113.3 Y106.926 E.00427
;WIDTH:0.521465
G1 X113.184 Y106.89 E.00394
;WIDTH:0.480976
G1 X113.068 Y106.854 E.00361
;WIDTH:0.440488
G1 X112.952 Y106.818 E.00328
;WIDTH:0.399999
G1 X112.267 Y106.609 E.01742
G1 X111.631 Y106.258 E.01767
G1 X111.227 Y105.971 E.01205
G1 X110.86 Y105.616 E.01242
G1 X110.477 Y105.107 E.01549
G1 X108.646 Y101.956 E.08865
G1 X108.31 Y101.162 E.02097
G1 X108.305 Y101.14 E.00055
G1 E-5 F3600
G1 X108.305 Y101.14 F9000
G1 X109.247 Y114.228
G1 X109.275 Y114.455
G1 X109.321 Y114.678
G1 X109.385 Y114.897
G1 X109.467 Y115.11
G1 X109.567 Y115.317
G1 X109.605 Y115.389
G1 X111.35 Y118.41
G1 X111.413 Y118.512
G1 X111.545 Y118.7
G1 X111.691 Y118.875
G1 X111.851 Y119.038
G1 X112.023 Y119.188
G1 X112.207 Y119.323
G1 X112.402 Y119.442
G1 X112.605 Y119.545
G1 X112.817 Y119.632
G1 X113.035 Y119.701
G1 E5 F2400
;WIDTH:0.591492
G1 F6000
G1 X117.233 Y121.003 E.00741
;WIDTH:0.578678
G1 X113.766 Y121.001 E.12554
;WIDTH:0.602448
G1 X113.532 Y120.999 E.00884
G1 E-5 F3600
G1 X113.532 Y120.999 F9000
G1 X111.545 Y118.7
G1 X111.35 Y118.41
G1 X109.467 Y115.11
G1 X109.238 Y114
G1 X109.247 Y113.772
G1 X109.275 Y113.545
G1 X109.321 Y113.322
G1 X109.385 Y113.103
G1 X109.467 Y112.89
G1 X109.567 Y112.683
G1 X109.605 Y112.611
G1 X111.35 Y109.59
G1 X111.413 Y109.488
G1 X111.545 Y109.3
G1 X111.691 Y109.125
G1 X111.851 Y108.962
G1 X112.023 Y108.812
G1 X112.207 Y108.677
G1 X112.402 Y108.558
G1 X112.605 Y108.455
G1 X112.817 Y108.368
G1 X113.035 Y108.299
G1 X117.373 Y107
G1 E5 F2400
;WIDTH:0.584548
G1 F6000
G1 X113.77 Y107.001 E.13187
;WIDTH:0.602442
G1 X113.532 Y106.999 E.00899
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.77 Y107.001 E-.11305
G1 X116.69 Y107 E-1.38695
;WIPE_END
G1 X112.817 Y108.368 F9000
G1 X111.545 Y109.3
G1 X111.35 Y109.59
G1 X109.467 Y112.89
G1 X109.238 Y114
G1 X109.467 Y115.11
G1 X111.35 Y118.41
G1 X111.545 Y118.7
G1 X113.257 Y119.751
G1 X113.483 Y119.784
G1 X113.716 Y119.798
G1 X113.752 Y119.799
G1 X114.286 Y119.799
G1 X113.769 Y122.201
G1 X113.768 Y122.553
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X117.371 Y122.555 E.08764
G1 X117.948 Y122.659 E.01426
G1 X118.494 Y122.902 E.01454
G1 X118.965 Y123.271 E.01455
G1 X119.354 Y123.774 E.01547
G1 X121.087 Y126.775 E.08429
G1 X121.257 Y127.141 E.00982
G1 X121.388 Y127.663 E.01309
G1 X121.409 Y128.121 E.01115
G1 X121.323 Y128.655 E.01316
G1 X121.164 Y129.075 E.01092
G1 X119.246 Y132.393 E.09322
G1 X118.852 Y132.835 E.0144
G1 X118.501 Y133.094 E.01061
G1 X118.144 Y133.273 E.00971
G1 X117.758 Y133.391 E.00982
G1 X117.254 Y133.45 E.01234
G1 X113.767 Y133.451 E.08482
G1 X113.149 Y133.368 E.01517
G1 X112.592 Y133.147 E.01458
G1 X112.107 Y132.798 E.01453
G1 X111.703 Y132.317 E.01528
G1 X109.913 Y129.225 E.0869
G1 X109.656 Y128.572 E.01707
G1 X109.589 Y128.038 E.01309
G1 X109.622 Y127.587 E.011
G1 X109.722 Y127.198 E.00977
G1 X109.913 Y126.775 E.01129
G1 X111.646 Y123.774 E.08429
G1 X112.072 Y123.235 E.01671
G1 X112.553 Y122.875 E.01461
G1 X113.104 Y122.644 E.01453
G1 X113.704 Y122.553 E.01476
G1 X113.708 Y122.553 E.0001
G1 X113.708 Y122.553 F9000
G1 X113.689 Y122.197
;TYPE:Perimeter
G1 F6000
G1 X113.766 Y122.186 E.00189
G1 X117.371 Y122.189 E.08769
G1 X118.015 Y122.3 E.0159
G1 X118.646 Y122.57 E.01669
G1 X119.193 Y122.985 E.0167
G1 X119.632 Y123.533 E.01708
G1 X121.404 Y126.592 E.08599
G1 X121.611 Y127.052 E.01227
G1 X121.743 Y127.574 E.0131
G1 X121.777 Y128.092 E.01263
G1 X121.684 Y128.711 E.01523
G1 X121.481 Y129.258 E.01419
G1 X119.562 Y132.576 E.09323
G1 X119.123 Y133.08 E.01626
G1 X118.666 Y133.421 E.01387
G1 X118.254 Y133.621 E.01114
G1 X117.8 Y133.754 E.01151
G1 X117.233 Y133.816 E.01387
G1 X113.767 Y133.816 E.08431
G1 X113.1 Y133.731 E.01636
G1 X112.454 Y133.486 E.01681
G1 X111.891 Y133.093 E.0167
G1 X111.387 Y132.5 E.01893
G1 X109.597 Y129.408 E.0869
G1 X109.328 Y128.754 E.0172
G1 X109.293 Y128.618 E.00342
G1 X109.226 Y128.084 E.01309
G1 X109.267 Y127.499 E.01426
G1 X109.389 Y127.049 E.01134
G1 X109.596 Y126.593 E.01218
G1 X111.329 Y123.591 E.08431
G1 X111.786 Y123.008 E.01802
G1 X112.337 Y122.58 E.01697
G1 X112.966 Y122.305 E.0167
G1 X113.629 Y122.206 E.01631
G1 X113.629 Y122.206 F9000
G1 X113.608 Y121.829
G1 F6000
G1 X113.767 Y121.82 E.00387
G1 X117.372 Y121.824 E.08769
G1 X118.082 Y121.94 E.0175
G1 X118.798 Y122.237 E.01885
G1 X119.232 Y122.548 E.01299
G1 X119.578 Y122.859 E.01132
G1 X119.988 Y123.409 E.01669
G1 X121.72 Y126.41 E.08428
G1 X121.966 Y126.962 E.0147
G1 X122.098 Y127.484 E.0131
G1 X122.142 Y128.05 E.01381
G1 X122.045 Y128.77 E.01767
G1 X121.861 Y129.307 E.01381
G1 X121.798 Y129.441 E.0036
G1 X119.879 Y132.759 E.09323
G1 X119.517 Y133.19 E.01369
G1 X119.257 Y133.45 E.00894
G1 X118.832 Y133.747 E.01261
G1 X118.364 Y133.97 E.01261
G1 X117.842 Y134.118 E.0132
G1 X117.233 Y134.182 E.01489
G1 X113.767 Y134.182 E.08431
G1 X113.051 Y134.093 E.01755
G1 X112.316 Y133.824 E.01904
G1 X111.675 Y133.388 E.01886
G1 X111.159 Y132.81 E.01885
G1 X111.07 Y132.684 E.00375
G1 X109.28 Y129.592 E.0869
G1 X108.989 Y128.89 E.01848
G1 X108.93 Y128.664 E.00568
G1 X108.863 Y128.129 E.01311
G1 X108.888 Y127.562 E.01381
G1 X109.002 Y127.052 E.01271
G1 X109.28 Y126.41 E.01702
G1 X111.012 Y123.408 E.0843
G1 X111.5 Y122.78 E.01935
G1 X111.675 Y122.612 E.0059
G1 X112.121 Y122.284 E.01347
G1 X112.828 Y121.967 E.01885
G1 X113.548 Y121.839 E.01779
G1 X113.548 Y121.839 F9000
G1 X113.527 Y121.47
G1 F6000
G1 X113.55 Y121.467 E.00056
G1 X113.767 Y121.455 E.00529
G1 X117.372 Y121.458 E.08769
G1 X118.149 Y121.581 E.01914
G1 X118.63 Y121.758 E.01247
G1 X119.165 Y122.029 E.01459
G1 X119.649 Y122.413 E.01503
G1 X119.868 Y122.637 E.00762
G1 X120.213 Y123.089 E.01383
G1 X122.037 Y126.227 E.08829
G1 X122.32 Y126.873 E.01715
G1 X122.452 Y127.395 E.0131
G1 X122.507 Y128.034 E.0156
G1 X122.406 Y128.828 E.01947
G1 X122.203 Y129.437 E.01561
G1 X122.114 Y129.624 E.00504
G1 X120.195 Y132.942 E.09323
G1 X119.789 Y133.435 E.01553
G1 X119.473 Y133.745 E.01077
G1 X118.997 Y134.073 E.01406
G1 X118.474 Y134.319 E.01406
G1 X117.958 Y134.47 E.01308
G1 X117.233 Y134.548 E.01774
G1 X113.767 Y134.548 E.08431
G1 X113.001 Y134.455 E.01877
G1 X112.69 Y134.372 E.00783
G1 X112.177 Y134.163 E.01347
G1 X111.459 Y133.683 E.02101
G1 X111.231 Y133.469 E.00761
G1 X110.877 Y133.044 E.01345
G1 X110.754 Y132.867 E.00524
G1 X108.964 Y129.775 E.0869
G1 X108.649 Y129.027 E.01974
G1 X108.567 Y128.709 E.00799
G1 X108.5 Y128.175 E.01309
G1 X108.523 Y127.534 E.0156
G1 X108.647 Y126.963 E.01421
G1 X108.963 Y126.227 E.01948
G1 X110.696 Y123.226 E.08429
G1 X111.214 Y122.552 E.02068
G1 X111.459 Y122.317 E.00826
G1 X111.905 Y121.989 E.01347
G1 X112.178 Y121.837 E.0076
G1 X112.691 Y121.628 E.01347
G1 X113.004 Y121.544 E.00788
G1 X113.468 Y121.479 E.0114
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.527 Y121.47 E-.02835
G1 X113.55 Y121.467 E-.01102
G1 X113.767 Y121.455 E-.10323
G1 X116.625 Y121.457 E-1.3574
;WIPE_END
G1 X113.035 Y122.299 F9000
G1 X112.817 Y122.368
G1 X112.605 Y122.455
G1 X112.402 Y122.558
G1 X112.207 Y122.677
G1 X112.023 Y122.812
G1 X111.851 Y122.962
G1 X111.691 Y123.125
G1 X111.545 Y123.3
G1 X111.413 Y123.488
G1 X111.35 Y123.59
G1 X109.605 Y126.611
G1 X109.567 Y126.683
G1 X109.467 Y126.89
G1 X109.385 Y127.103
G1 X109.321 Y127.322
G1 X109.275 Y127.545
G1 X109.247 Y127.772
G1 X109.238 Y128
G1 X109.247 Y128.228
G1 X109.275 Y128.455
G1 X109.321 Y128.678
G1 X109.385 Y128.897
G1 X109.467 Y129.11
G1 X109.567 Y129.317
G1 X109.605 Y129.389
G1 X110.095 Y130.235
G1 X106.099 Y136.118
G1 X105.719 Y136.118
G1 E5 F2400
G1 F6000
G1 X105.75 Y136.048 E.00186
G1 X105.75 Y103.607 E.78909
G1 X105.729 Y103.523 E.00211
G1 X105.567 Y103.424 E.00462
G1 X105.125 Y103.424 E.01075
G1 X105.125 Y98.824 E.11189
G1 X105.567 Y98.824 E.01075
G1 X105.703 Y98.764 E.00362
G1 X105.75 Y98.642 E.00318
G1 X105.75 Y91.952 E.16273
G1 X105.691 Y91.817 E.00358
G1 X104.902 Y91.088 E.02613
G1 X104.577 Y90.675 E.01278
G1 X104.51 Y90.472 E.0052
G1 X104.629 Y90.24 E.00634
G1 X104.886 Y89.928 E.00983
G1 X105.579 Y89.285 E.02299
G1 X125.423 Y89.285 E.48269
G1 X126.193 Y90.016 E.02583
G1 X126.443 Y90.372 E.01058
G1 X126.481 Y90.511 E.00351
G1 X126.479 Y90.581 E.0017
G1 X126.238 Y90.94 E.01052
G1 X125.878 Y91.303 E.01244
G1 X125.31 Y91.816 E.01862
G1 X125.25 Y91.952 E.00362
G1 X125.25 Y98.195 E.15185
G1 X125.269 Y98.723 E.01285
G1 X125.433 Y98.824 E.00468
G1 X125.875 Y98.824 E.01075
G1 X125.875 Y103.424 E.11189
G1 X125.433 Y103.424 E.01075
G1 X125.294 Y103.489 E.00373
G1 X125.25 Y103.607 E.00306
G1 X125.25 Y136.048 E.78909
G1 X125.309 Y136.183 E.00358
G1 X126.098 Y136.912 E.02613
G1 X126.423 Y137.325 E.01278
G1 X126.49 Y137.528 E.0052
G1 X126.371 Y137.759 E.00632
G1 X126.114 Y138.071 E.00983
G1 X125.421 Y138.715 E.02301
G1 X105.577 Y138.715 E.48269
G1 X104.801 Y137.978 E.02603
G1 X104.516 Y137.565 E.01221
G1 X104.52 Y137.419 E.00355
G1 X104.762 Y137.06 E.01053
G1 X105.122 Y136.697 E.01244
G1 X105.69 Y136.184 E.01862
G1 X105.695 Y136.172 E.00032
G1 X105.695 Y136.172 F9000
G1 X106.059 Y136.273
;TYPE:Perimeter
G1 F6000
G1 X106.081 Y136.241 E.00094
G1 X106.116 Y136.048 E.00477
G1 X106.116 Y103.607 E.78909
G1 X106.1 Y103.479 E.00314
G1 X106.013 Y103.287 E.00513
G1 X105.567 Y103.059 E.01218
G1 X105.491 Y103.059 E.00185
G1 X105.491 Y99.19 E.09411
G1 X105.567 Y99.19 E.00185
G1 X105.974 Y99.009 E.01083
G1 X106.076 Y98.845 E.0047
G1 X106.116 Y98.642 E.00503
G1 X106.116 Y91.952 E.16273
G1 X106.081 Y91.761 E.00472
G1 X105.94 Y91.549 E.00619
G1 X105.201 Y90.865 E.02449
G1 X104.906 Y90.502 E.01138
G1 X105.147 Y90.185 E.00969
G1 X105.722 Y89.65 E.0191
G1 X125.282 Y89.65 E.47578
G1 X125.933 Y90.273 E.02192
G1 X126.092 Y90.503 E.0068
G1 X125.976 Y90.674 E.00503
G1 X125.625 Y91.038 E.0123
G1 X125.065 Y91.545 E.01837
G1 X124.919 Y91.759 E.0063
G1 X124.884 Y91.952 E.00477
G1 X124.889 Y98.712 E.16443
G1 X124.988 Y98.962 E.00654
G1 X125.433 Y99.19 E.01216
G1 X125.509 Y99.19 E.00185
G1 X125.509 Y103.059 E.09411
G1 X125.433 Y103.059 E.00185
G1 X125.015 Y103.252 E.0112
G1 X124.947 Y103.353 E.00296
G1 X124.884 Y103.607 E.00637
G1 X124.884 Y136.048 E.78909
G1 X124.919 Y136.239 E.00472
G1 X125.06 Y136.451 E.00619
G1 X125.799 Y137.135 E.02449
G1 X126.094 Y137.498 E.01138
G1 X125.853 Y137.815 E.00969
G1 X125.278 Y138.35 E.0191
G1 X105.718 Y138.35 E.47578
G1 X105.067 Y137.727 E.02192
G1 X104.908 Y137.497 E.0068
G1 X105.024 Y137.326 E.00503
G1 X105.375 Y136.962 E.0123
G1 X105.935 Y136.455 E.01837
G1 X106.025 Y136.323 E.00389
G1 X106.025 Y136.323 F9000
G1 X106.387 Y136.423
G1 F6000
G1 X106.423 Y136.37 E.00156
G1 X106.481 Y136.048 E.00796
G1 X106.481 Y103.607 E.78909
G1 X106.426 Y103.294 E.00773
G1 X106.263 Y103.015 E.00786
G1 X105.857 Y102.827 E.01088
G1 X105.857 Y99.427 E.0827
G1 X106.245 Y99.255 E.01032
G1 X106.416 Y98.981 E.00786
G1 X106.481 Y98.642 E.0084
G1 X106.481 Y91.952 E.16273
G1 X106.424 Y91.634 E.00786
G1 X106.188 Y91.281 E.01033
G1 X105.363 Y90.491 E.02778
G1 X105.866 Y90.016 E.01683
G1 X125.14 Y90.016 E.46882
G1 X125.644 Y90.5 E.017
G1 X125.372 Y90.773 E.00937
G1 X124.82 Y91.274 E.01813
G1 X124.577 Y91.63 E.01048
G1 X124.519 Y91.952 E.00796
G1 X124.519 Y98.564 E.16083
G1 X124.57 Y98.945 E.00935
G1 X124.755 Y99.255 E.00878
G1 X125.143 Y99.427 E.01032
G1 X125.143 Y102.827 E.0827
G1 X124.737 Y103.014 E.01087
G1 X124.574 Y103.294 E.00788
G1 X124.519 Y103.607 E.00773
G1 X124.519 Y136.048 E.78909
G1 X124.576 Y136.366 E.00786
G1 X124.812 Y136.719 E.01033
G1 X125.637 Y137.509 E.02778
G1 X125.134 Y137.984 E.01683
G1 X105.86 Y137.984 E.46882
G1 X105.356 Y137.5 E.017
G1 X105.628 Y137.227 E.00937
G1 X106.18 Y136.726 E.01813
G1 X106.353 Y136.472 E.00748
G1 X106.353 Y136.472 F9000
G1 X106.715 Y136.572
G1 F6000
G1 X106.765 Y136.498 E.00217
G1 X106.847 Y136.048 E.01113
G1 X106.847 Y103.607 E.78909
G1 X106.769 Y103.168 E.01085
G1 X106.542 Y102.778 E.01098
G1 X106.222 Y102.63 E.00858
G1 X106.222 Y99.63 E.07297
G1 X106.544 Y99.469 E.00876
G1 X106.775 Y99.065 E.01132
G1 X106.847 Y98.642 E.01044
G1 X106.847 Y91.952 E.16273
G1 X106.767 Y91.507 E.011
G1 X106.436 Y91.012 E.01448
G1 X105.882 Y90.5 E.01835
G1 X106.01 Y90.382 E.00423
G1 X124.999 Y90.382 E.46189
G1 X125.129 Y90.5 E.00427
G1 X124.574 Y91.002 E.0182
G1 X124.235 Y91.502 E.01469
G1 X124.153 Y91.952 E.01113
G1 X124.164 Y98.805 E.16669
G1 X124.287 Y99.211 E.01032
G1 X124.484 Y99.5 E.00851
G1 X124.778 Y99.631 E.00783
G1 X124.778 Y102.63 E.07295
G1 X124.459 Y102.777 E.00854
G1 X124.231 Y103.168 E.01101
G1 X124.153 Y103.607 E.01085
G1 X124.153 Y136.048 E.78909
G1 X124.233 Y136.493 E.011
G1 X124.564 Y136.988 E.01448
G1 X125.118 Y137.5 E.01835
G1 X124.99 Y137.618 E.00423
G1 X106.001 Y137.618 E.46189
G1 X105.88 Y137.491 E.00427
G1 X106.426 Y136.998 E.01789
G1 X106.681 Y136.622 E.01105
G1 X106.681 Y136.622 F9000
G1 X107.043 Y136.722
G1 F6000
G1 X107.108 Y136.627 E.0028
G1 X107.213 Y136.048 E.01431
G1 X107.213 Y103.607 E.78909
G1 X107.167 Y103.222 E.00943
G1 X107.026 Y102.846 E.00977
G1 X106.82 Y102.541 E.00895
G1 X106.588 Y102.433 E.00622
G1 X106.588 Y99.834 E.06322
G1 X106.788 Y99.745 E.00532
G1 X106.975 Y99.493 E.00763
G1 X107.176 Y98.987 E.01324
G1 X107.213 Y98.642 E.00844
G1 X107.213 Y91.952 E.16273
G1 X107.11 Y91.38 E.01414
G1 X106.687 Y90.747 E.01852
G1 X124.318 Y90.747 E.42886
G1 X123.892 Y91.373 E.01842
G1 X123.787 Y91.952 E.01431
G1 X123.787 Y98.195 E.15185
G1 X123.821 Y98.975 E.01899
G1 X123.959 Y99.374 E.01027
G1 X124.213 Y99.745 E.01094
G1 X124.412 Y99.834 E.0053
G1 X124.412 Y102.433 E.06322
G1 X124.18 Y102.54 E.00621
G1 X124.077 Y102.674 E.00411
G1 X123.887 Y103.043 E.0101
G1 X123.787 Y103.607 E.01393
G1 X123.787 Y136.048 E.78909
G1 X123.89 Y136.62 E.01414
G1 X124.313 Y137.253 E.01852
G1 X106.682 Y137.253 E.42886
G1 X107.009 Y136.771 E.01417
G1 E-5 F3600
G1 X107.009 Y136.771 F9000
G1 X116.666 Y137.143
G1 E5 F2400
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X119.042 Y134.768 E.08172
G1 X118.241 Y135.052 E.02067
G1 X116.314 Y136.978 E.06627
G1 X115.797 Y136.978 E.01258
G1 X117.62 Y135.155 E.06271
G1 X117.081 Y135.177 E.01312
G1 X115.279 Y136.978 E.06197
G1 X114.762 Y136.978 E.01258
G1 X116.562 Y135.178 E.06192
G1 X116.043 Y135.18 E.01262
G1 X114.245 Y136.978 E.06185
G1 X113.728 Y136.978 E.01258
G1 X115.524 Y135.182 E.06178
G1 X115.005 Y135.184 E.01262
G1 X113.21 Y136.978 E.06173
G1 X112.693 Y136.978 E.01258
G1 X114.486 Y135.185 E.06168
G1 X113.967 Y135.187 E.01262
G1 X112.176 Y136.978 E.06161
G1 X111.659 Y136.978 E.01258
G1 X113.472 Y135.165 E.06237
G1 X113.017 Y135.103 E.01117
G1 X111.142 Y136.978 E.0645
G1 X110.624 Y136.978 E.0126
G1 X112.597 Y135.005 E.06787
G1 X112.216 Y134.87 E.00983
G1 X110.107 Y136.978 E.07253
G1 X109.59 Y136.978 E.01258
G1 X111.856 Y134.712 E.07795
G1 X111.525 Y134.526 E.00924
G1 X109.073 Y136.978 E.08435
G1 X108.555 Y136.978 E.0126
G1 X111.227 Y134.307 E.0919
G1 X110.943 Y134.073 E.00895
G1 X108.038 Y136.978 E.09993
G1 X107.521 Y136.978 E.01258
G1 X110.686 Y133.814 E.10886
G1 X110.451 Y133.531 E.00895
G1 X107.39 Y136.593 E.10531
G1 X107.487 Y135.978 E.01514
G1 X110.232 Y133.233 E.09443
G1 X110.039 Y132.909 E.00917
G1 X107.487 Y135.461 E.08779
G1 X107.487 Y134.944 E.01258
G1 X109.849 Y132.581 E.08127
G1 X109.66 Y132.254 E.00919
G1 X107.487 Y134.426 E.07473
G1 X107.487 Y133.909 E.01258
G1 X109.47 Y131.926 E.06821
G1 X109.28 Y131.599 E.0092
G1 X107.487 Y133.392 E.06168
G1 X107.487 Y132.875 E.01258
G1 X109.091 Y131.271 E.05518
G1 X108.901 Y130.943 E.00922
G1 X107.487 Y132.357 E.04864
G1 X107.487 Y131.84 E.01258
G1 X108.711 Y130.616 E.0421
G1 X108.522 Y130.288 E.00921
G1 X107.487 Y131.323 E.0356
G1 X107.487 Y130.806 E.01258
G1 X108.34 Y129.952 E.02936
G1 X108.186 Y129.59 E.00957
G1 X107.487 Y130.289 E.02405
G1 X107.487 Y129.771 E.0126
G1 X108.041 Y129.217 E.01906
G1 X107.937 Y128.804 E.01036
G1 X107.487 Y129.254 E.01548
G1 X107.487 Y128.737 E.01258
G1 X107.886 Y128.338 E.01373
G1 X107.861 Y127.845 E.01201
G1 X107.487 Y128.22 E.01288
G1 X107.487 Y127.702 E.0126
G1 X107.92 Y127.269 E.01489
G1 X108.112 Y126.56 E.01787
G1 X107.487 Y127.185 E.0215
G1 X107.487 Y126.668 E.01258
G1 X108.628 Y125.526 E.03927
G1 X109.335 Y124.303 E.03436
G1 X107.487 Y126.151 E.06357
G1 X107.487 Y125.634 E.01258
G1 X110.042 Y123.079 E.08789
G1 X110.3 Y122.672 E.01172
G1 X110.879 Y121.969 E.02215
G1 X111.819 Y121.301 E.02805
G1 X112.241 Y120.88 E.0145
G1 X111.877 Y120.727 E.0096
G1 X107.487 Y125.116 E.151
G1 X107.487 Y124.599 E.01258
G1 X111.546 Y120.54 E.13963
G1 X111.252 Y120.316 E.00899
G1 X107.487 Y124.082 E.12953
G1 X107.487 Y123.565 E.01258
G1 X110.96 Y120.092 E.11947
G1 X110.706 Y119.828 E.00891
G1 X107.487 Y123.048 E.11075
G1 X107.487 Y122.53 E.0126
G1 X110.468 Y119.549 E.10254
G1 X110.246 Y119.254 E.00898
G1 X107.487 Y122.013 E.09491
G1 X107.487 Y121.496 E.01258
G1 X110.052 Y118.931 E.08823
G1 X109.862 Y118.604 E.0092
G1 X107.487 Y120.979 E.0817
G1 X107.487 Y120.461 E.0126
G1 X109.672 Y118.276 E.07516
G1 X109.483 Y117.948 E.00921
G1 X107.487 Y119.944 E.06866
G1 X107.487 Y119.427 E.01258
G1 X109.293 Y117.621 E.06213
G1 X109.103 Y117.293 E.00922
G1 X107.487 Y118.91 E.05561
G1 X107.487 Y118.393 E.01258
G1 X108.914 Y116.966 E.04909
G1 X108.724 Y116.638 E.00922
G1 X107.487 Y117.875 E.04255
G1 X107.487 Y117.358 E.01258
G1 X108.535 Y116.31 E.03605
G1 X108.352 Y115.976 E.00926
G1 X107.487 Y116.841 E.02976
G1 X107.487 Y116.324 E.01258
G1 X108.196 Y115.615 E.02439
G1 X108.049 Y115.244 E.00971
G1 X107.487 Y115.806 E.01933
G1 X107.487 Y115.289 E.01258
G1 X107.939 Y114.837 E.01555
G1 X107.873 Y114.386 E.01109
G1 X107.487 Y114.772 E.01328
G1 X107.487 Y114.255 E.01258
G1 X107.857 Y113.884 E.01274
G1 X107.923 Y113.302 E.01425
G1 X107.487 Y113.738 E.015
G1 X107.487 Y113.22 E.0126
G1 X108.097 Y112.61 E.02098
G1 X108.581 Y111.61 E.02702
G1 X107.487 Y112.703 E.03762
G1 X107.487 Y112.186 E.01258
G1 X109.287 Y110.386 E.06192
G1 X109.994 Y109.162 E.03438
G1 X107.487 Y111.669 E.08624
G1 X107.487 Y111.151 E.0126
G1 X111.899 Y106.739 E.15177
G1 X111.577 Y106.544 E.00916
G1 X107.487 Y110.634 E.14069
G1 X107.487 Y110.117 E.01258
G1 X111.26 Y106.344 E.12979
G1 X110.978 Y106.109 E.00893
G1 X107.487 Y109.6 E.12009
G1 X107.487 Y109.083 E.01258
G1 X110.711 Y105.859 E.1109
G1 X110.485 Y105.567 E.00898
G1 X107.487 Y108.565 E.10313
G1 X107.487 Y108.048 E.01258
G1 X110.26 Y105.275 E.09539
G1 X110.069 Y104.949 E.00919
G1 X107.487 Y107.531 E.08882
G1 X107.487 Y107.014 E.01258
G1 X109.879 Y104.622 E.08228
G1 X109.689 Y104.295 E.0092
G1 X107.487 Y106.497 E.07575
G1 X107.487 Y105.979 E.0126
G1 X109.498 Y103.968 E.06918
G1 X109.308 Y103.641 E.0092
G1 X107.487 Y105.462 E.06264
G1 X107.487 Y104.945 E.01258
G1 X109.118 Y103.314 E.05611
G1 X108.928 Y102.986 E.00922
G1 X107.487 Y104.428 E.04959
G1 X107.487 Y103.91 E.0126
G1 X108.738 Y102.659 E.04303
G1 X108.548 Y102.332 E.0092
G1 X107.465 Y103.415 E.03725
G1 X107.381 Y102.982 E.01073
G1 X108.363 Y102 E.03378
G1 X108.206 Y101.64 E.00955
G1 X107.212 Y102.634 E.03419
G1 X106.992 Y102.336 E.00901
G1 X108.058 Y101.271 E.03665
G1 X107.944 Y100.867 E.01021
G1 X106.862 Y101.949 E.03722
G1 X106.862 Y101.432 E.01258
G1 X107.881 Y100.413 E.03505
G1 X107.857 Y99.919 E.01203
G1 X106.862 Y100.914 E.03423
G1 X106.862 Y100.397 E.01258
G1 X107.911 Y99.348 E.03608
G1 X108.1 Y98.642 E.01778
G1 X107.302 Y99.44 E.02745
G1 X107.444 Y99.045 E.01021
G1 X107.478 Y98.747 E.0073
G1 X108.533 Y97.693 E.03627
G1 X109.239 Y96.469 E.03437
G1 X107.479 Y98.229 E.06054
G1 X107.479 Y97.711 E.0126
G1 X109.946 Y95.245 E.08485
G1 X110.693 Y94.16 E.03204
G1 X111.281 Y93.637 E.01914
G1 X111.953 Y93.238 E.01901
G1 X114.169 Y91.022 E.07623
G1 X114.686 Y91.022 E.01258
G1 X112.766 Y92.942 E.06605
G1 X113.387 Y92.838 E.01532
G1 X115.203 Y91.022 E.06247
G1 X115.721 Y91.022 E.0126
G1 X113.918 Y92.824 E.062
G1 X114.437 Y92.822 E.01262
G1 X116.238 Y91.022 E.06194
G1 X116.755 Y91.022 E.01258
G1 X114.956 Y92.82 E.06187
G1 X115.475 Y92.819 E.01262
G1 X117.272 Y91.022 E.06182
G1 X117.789 Y91.022 E.01258
G1 X115.994 Y92.817 E.06175
G1 X116.514 Y92.815 E.01265
G1 X118.307 Y91.022 E.06168
G1 X118.824 Y91.022 E.01258
G1 X117.033 Y92.813 E.06161
G1 X117.531 Y92.832 E.01212
G1 X119.341 Y91.022 E.06226
G1 X119.858 Y91.022 E.01258
G1 X117.988 Y92.892 E.06433
G1 X118.4 Y92.997 E.01034
G1 X120.376 Y91.022 E.06796
G1 X120.893 Y91.022 E.01258
G1 X118.79 Y93.125 E.07234
G1 X119.147 Y93.285 E.00952
G1 X121.41 Y91.022 E.07785
G1 X121.927 Y91.022 E.01258
G1 X119.473 Y93.476 E.08442
G1 X119.772 Y93.695 E.00902
G1 X122.444 Y91.022 E.09193
G1 X122.962 Y91.022 E.0126
G1 X120.059 Y93.924 E.09984
G1 X120.319 Y94.182 E.00891
G1 X123.479 Y91.022 E.1087
G1 X123.806 Y91.022 E.00795
G1 X123.635 Y91.273 E.00739
G1 X123.61 Y91.407 E.00332
G1 X120.545 Y94.473 E.10545
G1 X120.767 Y94.768 E.00898
G1 X123.513 Y92.022 E.09446
G1 X123.513 Y92.539 E.01258
G1 X120.964 Y95.089 E.0877
G1 X121.152 Y95.417 E.0092
G1 X123.513 Y93.056 E.08122
G1 X123.513 Y93.574 E.0126
G1 X121.341 Y95.746 E.07472
G1 X121.53 Y96.074 E.00921
G1 X123.513 Y94.091 E.06821
G1 X123.513 Y94.608 E.01258
G1 X121.718 Y96.403 E.06175
G1 X121.907 Y96.731 E.00921
G1 X123.513 Y95.125 E.05525
G1 X123.513 Y95.642 E.01258
G1 X122.096 Y97.06 E.04876
G1 X122.285 Y97.388 E.00921
G1 X123.513 Y96.16 E.04224
G1 X123.513 Y96.677 E.01258
G1 X122.473 Y97.717 E.03578
G1 X122.662 Y98.045 E.00921
G1 X123.513 Y97.194 E.02927
G1 X123.513 Y97.711 E.01258
G1 X122.825 Y98.399 E.02367
G1 X122.964 Y98.778 E.00982
G1 X123.513 Y98.229 E.01889
G1 X123.519 Y98.74 E.01243
G1 X123.06 Y99.199 E.01579
G1 X123.132 Y99.644 E.01096
G1 X123.593 Y99.183 E.01586
G1 X123.745 Y99.548 E.00962
G1 X123.142 Y100.151 E.02074
G1 X123.064 Y100.746 E.0146
G1 X123.952 Y99.859 E.03053
G1 X124.138 Y99.995 E.0056
G1 X124.138 Y100.19 E.00474
G1 X122.879 Y101.449 E.04331
G1 X122.372 Y102.473 E.02779
G1 X124.138 Y100.707 E.06075
G1 X124.138 Y101.225 E.0126
G1 X121.665 Y103.697 E.08505
G1 X120.959 Y104.921 E.03437
G1 X124.138 Y101.742 E.10936
G1 X124.138 Y102.259 E.01258
G1 X119.117 Y107.279 E.1727
G1 X119.457 Y107.457 E.00933
G1 X123.54 Y103.374 E.14045
G1 X123.513 Y103.918 E.01325
G1 X119.749 Y107.682 E.12948
G1 X120.041 Y107.907 E.00897
G1 X123.513 Y104.435 E.11943
G1 X123.513 Y104.952 E.01258
G1 X120.304 Y108.161 E.11039
G1 X120.526 Y108.457 E.009
G1 X123.513 Y105.47 E.10275
G1 X123.513 Y105.987 E.01258
G1 X120.746 Y108.754 E.09518
G1 X120.951 Y109.066 E.00908
G1 X123.513 Y106.504 E.08813
G1 X123.513 Y107.021 E.01258
G1 X121.14 Y109.394 E.08163
G1 X121.33 Y109.722 E.00922
G1 X123.513 Y107.539 E.07509
G1 X123.513 Y108.056 E.01258
G1 X121.519 Y110.05 E.06859
G1 X121.708 Y110.378 E.00921
G1 X123.513 Y108.573 E.06209
G1 X123.513 Y109.09 E.01258
G1 X121.898 Y110.706 E.05557
G1 X122.087 Y111.034 E.00921
G1 X123.513 Y109.607 E.04907
G1 X123.513 Y110.125 E.0126
G1 X122.276 Y111.361 E.04253
G1 X122.466 Y111.689 E.00922
G1 X123.513 Y110.642 E.03602
G1 X123.513 Y111.159 E.01258
G1 X122.648 Y112.024 E.02976
G1 X122.818 Y112.372 E.00942
G1 X123.513 Y111.676 E.02392
G1 X123.513 Y112.193 E.01258
G1 X122.946 Y112.76 E.0195
G1 X123.057 Y113.167 E.01026
G1 X123.513 Y112.711 E.01569
G1 X123.513 Y113.228 E.01258
G1 X123.117 Y113.624 E.01362
G1 X123.139 Y114.119 E.01205
G1 X123.513 Y113.745 E.01287
G1 X123.513 Y114.262 E.01258
G1 X123.088 Y114.688 E.01464
G1 X122.891 Y115.401 E.01799
G1 X123.513 Y114.78 E.02138
G1 X123.513 Y115.297 E.01258
G1 X122.397 Y116.413 E.03839
G1 X121.688 Y117.639 E.03445
G1 X123.513 Y115.814 E.06278
G1 X123.513 Y116.331 E.01258
G1 X120.979 Y118.865 E.08717
G1 X120.566 Y119.527 E.01898
G1 X120.223 Y119.929 E.01285
G1 X119.659 Y120.41 E.01803
G1 X119.107 Y120.737 E.01561
G1 X118.739 Y121.105 E.01266
G1 X119.094 Y121.268 E.0095
G1 X123.513 Y116.848 E.15203
G1 X123.513 Y117.366 E.0126
G1 X119.433 Y121.445 E.14033
G1 X119.73 Y121.666 E.009
G1 X123.513 Y117.883 E.13013
G1 X123.513 Y118.4 E.01258
G1 X120.014 Y121.899 E.12036
G1 X120.284 Y122.147 E.00892
G1 X123.513 Y118.917 E.11109
G1 X123.513 Y119.435 E.0126
G1 X120.512 Y122.436 E.10323
G1 X120.739 Y122.726 E.00896
G1 X123.513 Y119.952 E.09542
G1 X123.513 Y120.469 E.01258
G1 X120.938 Y123.044 E.08858
G1 X121.128 Y123.372 E.00922
G1 X123.513 Y120.986 E.08206
G1 X123.513 Y121.503 E.01258
G1 X121.317 Y123.7 E.07556
G1 X121.506 Y124.028 E.00921
G1 X123.513 Y122.021 E.06904
G1 X123.513 Y122.538 E.01258
G1 X121.695 Y124.355 E.06252
G1 X121.885 Y124.683 E.00922
G1 X123.513 Y123.055 E.056
G1 X123.513 Y123.572 E.01258
G1 X122.074 Y125.011 E.0495
G1 X122.263 Y125.339 E.00921
G1 X123.513 Y124.09 E.04298
G1 X123.513 Y124.607 E.01258
G1 X122.453 Y125.667 E.03646
G1 X122.637 Y126 E.00925
G1 X123.513 Y125.124 E.03013
G1 X123.513 Y125.641 E.01258
G1 X122.806 Y126.348 E.02432
G1 X122.944 Y126.728 E.00983
G1 X123.513 Y126.158 E.01959
G1 X123.513 Y126.676 E.0126
G1 X123.048 Y127.141 E.016
G1 X123.124 Y127.582 E.01089
G1 X123.513 Y127.193 E.01338
G1 X123.513 Y127.71 E.01258
G1 X123.143 Y128.081 E.01274
G1 X123.082 Y128.659 E.01414
G1 X123.513 Y128.227 E.01484
G1 X123.513 Y128.744 E.01258
G1 X122.928 Y129.33 E.02014
G1 X122.445 Y130.329 E.02699
G1 X123.513 Y129.262 E.03672
G1 X123.513 Y129.779 E.01258
G1 X121.736 Y131.556 E.06113
G1 X121.027 Y132.782 E.03445
G1 X123.513 Y130.296 E.08552
G1 X123.513 Y130.813 E.01258
G1 X117.348 Y136.978 E.21207
G1 X117.865 Y136.978 E.01258
G1 X123.513 Y131.331 E.19427
G1 X123.513 Y131.848 E.01258
G1 X118.383 Y136.978 E.17647
G1 X118.9 Y136.978 E.01258
G1 X123.513 Y132.365 E.15868
G1 X123.513 Y132.882 E.01258
G1 X119.417 Y136.978 E.1409
G1 X119.934 Y136.978 E.01258
G1 X123.513 Y133.399 E.12312
G1 X123.513 Y133.917 E.0126
G1 X120.452 Y136.978 E.1053
G1 X120.969 Y136.978 E.01258
G1 X123.513 Y134.434 E.08751
G1 X123.513 Y134.951 E.01258
G1 X121.486 Y136.978 E.06973
G1 X122.003 Y136.978 E.01258
G1 X123.513 Y135.468 E.05194
G1 X123.513 Y135.986 E.0126
G1 X122.52 Y136.978 E.03414
G1 X123.038 Y136.978 E.0126
G1 X123.581 Y136.435 E.01868
G1 X123.705 Y136.828 E.01002
G1 X123.39 Y137.143 E.01084
G1 E-5 F3600
G1 X123.39 Y137.143 F9000
G1 X121.76 Y113.886
G1 X121.742 Y113.658
G1 X121.704 Y113.433
G1 X119.865 Y106.014
G1 E5 F2400
G1 F3072.127
G1 X118.632 Y107.247 E.04241
G1 E-5 F3600
G1 X118.632 Y107.247 F9000
G1 X112.39 Y106.765
G1 E5 F2400
G1 F3072.127
G1 X111.345 Y107.811 E.03596
G1 E-5 F3600
G1 X111.345 Y107.811 F9000
G1 X107.315 Y97.358
G1 E5 F2400
G1 F3072.127
G1 X113.652 Y91.022 E.21797
G1 X113.135 Y91.022 E.01258
G1 X107.481 Y96.676 E.19449
G1 X107.481 Y96.158 E.0126
G1 X112.617 Y91.022 E.17668
G1 X112.1 Y91.022 E.01258
G1 X107.482 Y95.64 E.15886
G1 X107.483 Y95.122 E.0126
G1 X111.583 Y91.022 E.14104
G1 X111.066 Y91.022 E.01258
G1 X107.483 Y94.604 E.12324
G1 X107.484 Y94.086 E.0126
G1 X110.548 Y91.022 E.1054
G1 X110.031 Y91.022 E.01258
G1 X107.485 Y93.568 E.08758
G1 X107.485 Y93.05 E.0126
G1 X109.514 Y91.022 E.06978
G1 X108.997 Y91.022 E.01258
G1 X107.486 Y92.532 E.05196
G1 X107.487 Y92.014 E.0126
G1 X108.48 Y91.022 E.03414
G1 X107.962 Y91.022 E.0126
G1 X107.419 Y91.565 E.01868
G1 X107.295 Y91.172 E.01002
G1 X107.61 Y90.857 E.01084
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X107.295 Y91.172 E-.2116
G1 X107.419 Y91.565 E-.19575
G1 X107.962 Y91.022 E-.36476
G1 X108.48 Y91.022 E-.24605
G1 X107.762 Y91.739 E-.48184
;WIPE_END
G1 X108.568 Y89.634 F9000
G1 X109.135 Y88.151
G1 X109.73 Y86.599
G1 X109.801 Y85.151
G1 X110.15 Y85.5
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X104.557 Y85.5 E.13604
G1 X103.99 Y85.458 E.01383
G1 X103.442 Y85.334 E.01367
G1 X102.844 Y85.094 E.01567
G1 X102.41 Y84.839 E.01224
G1 X101.88 Y84.399 E.01676
G1 X101.413 Y83.842 E.01768
G1 X101.157 Y83.407 E.01228
G1 X100.92 Y82.819 E.01542
G1 X100.761 Y81.976 E.02087
G1 X100.75 Y78.952 E.07356
G1 X100.691 Y78.817 E.00358
G1 X99.976 Y78.16 E.02362
G1 X99.585 Y77.704 E.01461
G1 X99.511 Y77.47 E.00597
G1 X99.659 Y77.182 E.00788
G1 X100.114 Y76.705 E.01603
G1 X100.577 Y76.285 E.01521
G1 X130.423 Y76.285 E.72597
G1 X130.886 Y76.705 E.01521
G1 X131.272 Y77.109 E.01359
G1 X131.489 Y77.47 E.01025
G1 X131.468 Y77.58 E.00272
G1 X131.294 Y77.876 E.00835
G1 X130.307 Y78.82 E.03322
G1 X130.25 Y78.952 E.0035
G1 X130.24 Y81.703 E.06692
G1 X130.197 Y82.261 E.01361
G1 X130.072 Y82.811 E.01372
G1 X129.862 Y83.347 E.014
G1 X129.575 Y83.842 E.01392
G1 X129.226 Y84.278 E.01358
G1 X128.796 Y84.675 E.01424
G1 X128.298 Y85.01 E.0146
G1 X127.827 Y85.241 E.01276
G1 X127.287 Y85.406 E.01373
G1 X126.731 Y85.489 E.01367
G1 X120.85 Y85.5 E.14305
G1 X120.85 Y85.196 E.00739
G1 X120.787 Y85.058 E.00369
G1 X120.667 Y85.013 E.00312
G1 X110.333 Y85.013 E.25136
G1 X110.253 Y85.032 E.002
G1 X110.15 Y85.196 E.00471
G1 X110.15 Y85.44 E.00594
G1 X109.95 Y84.83 F9000
;TYPE:Perimeter
G1 F6000
G1 X109.812 Y85.134 E.00812
G1 X105.365 Y85.134 E.10817
G1 X104.309 Y85.115 E.02569
G1 X103.807 Y85.042 E.01234
G1 X103.205 Y84.845 E.01541
G1 X102.621 Y84.539 E.01604
G1 X102.138 Y84.138 E.01527
G1 X101.713 Y83.631 E.01609
G1 X101.486 Y83.245 E.01089
G1 X101.272 Y82.716 E.01388
G1 X101.127 Y81.942 E.01915
G1 X101.116 Y78.95 E.07278
G1 X101.081 Y78.759 E.00472
G1 X100.938 Y78.548 E.0062
G1 X100.241 Y77.908 E.02302
G1 X99.899 Y77.515 E.01267
G1 X99.948 Y77.419 E.00262
G1 X100.241 Y77.102 E.0105
G1 X100.718 Y76.65 E.01598
G1 X130.282 Y76.65 E.71911
G1 X130.63 Y76.967 E.01145
G1 X131.007 Y77.362 E.01328
G1 X131.101 Y77.515 E.00437
G1 X131.015 Y77.637 E.00363
G1 X130.054 Y78.556 E.03234
G1 X129.918 Y78.764 E.00604
G1 X129.884 Y78.95 E.0046
G1 X129.873 Y81.952 E.07302
G1 X129.797 Y82.46 E.01249
G1 X129.646 Y82.953 E.01254
G1 X129.421 Y83.419 E.01259
G1 X129.13 Y83.844 E.01253
G1 X128.785 Y84.216 E.01234
G1 X128.18 Y84.655 E.01818
G1 X127.698 Y84.898 E.01313
G1 X127.206 Y85.048 E.01251
G1 X126.703 Y85.123 E.01237
G1 X121.187 Y85.133 E.13417
G1 X121.028 Y84.783 E.00935
G1 X120.907 Y84.703 E.00353
G1 X120.667 Y84.648 E.00599
G1 X110.333 Y84.648 E.25136
G1 X110.238 Y84.656 E.00232
G1 X109.979 Y84.78 E.00698
G1 X109.979 Y84.78 F9000
G1 X109.696 Y84.584
G1 F6000
G1 X109.613 Y84.769 E.00493
G1 X104.416 Y84.756 E.12641
G1 X103.888 Y84.685 E.01296
G1 X103.342 Y84.506 E.01398
G1 X102.832 Y84.238 E.01401
G1 X102.397 Y83.878 E.01373
G1 X102.145 Y83.577 E.00955
G1 X101.815 Y83.083 E.01445
G1 X101.625 Y82.613 E.01233
G1 X101.492 Y81.907 E.01747
G1 X101.481 Y78.949 E.07195
G1 X101.423 Y78.631 E.00786
G1 X101.184 Y78.278 E.01037
G1 X100.362 Y77.505 E.02745
G1 X100.86 Y77.016 E.01698
G1 X130.14 Y77.016 E.71221
G1 X130.631 Y77.498 E.01674
G1 X129.801 Y78.292 E.02794
G1 X129.574 Y78.638 E.01007
G1 X129.519 Y78.949 E.00768
G1 X129.509 Y81.701 E.06694
G1 X129.44 Y82.378 E.01655
G1 X129.203 Y83.029 E.01685
G1 X128.844 Y83.615 E.01672
G1 X128.34 Y84.103 E.01706
G1 X127.817 Y84.445 E.0152
G1 X127.342 Y84.625 E.01236
G1 X126.676 Y84.758 E.01652
G1 X121.386 Y84.767 E.12867
G1 X121.268 Y84.507 E.00695
G1 X120.942 Y84.324 E.00909
G1 X120.667 Y84.282 E.00677
G1 X110.333 Y84.282 E.25136
G1 X110.057 Y84.324 E.00679
G1 X109.731 Y84.508 E.00911
G1 X109.721 Y84.529 E.00057
G1 X109.721 Y84.529 F9000
G1 X109.448 Y84.326
G1 F6000
G1 X109.413 Y84.403 E.00206
G1 X104.703 Y84.403 E.11457
G1 X104.152 Y84.37 E.01343
G1 X103.557 Y84.198 E.01507
G1 X103.042 Y83.938 E.01403
G1 X102.656 Y83.618 E.0122
G1 X102.223 Y83.056 E.01726
G1 X101.978 Y82.51 E.01456
G1 X101.858 Y81.872 E.01579
G1 X101.847 Y78.948 E.07112
G1 X101.765 Y78.502 E.01103
G1 X101.431 Y78.008 E.0145
G1 X100.881 Y77.504 E.01815
G1 X101.001 Y77.382 E.00416
G1 X129.958 Y77.382 E.70435
G1 X130.114 Y77.486 E.00456
G1 X129.548 Y78.027 E.01904
G1 X129.231 Y78.512 E.01409
G1 X129.153 Y78.948 E.01077
G1 X129.143 Y81.699 E.06692
G1 X129.082 Y82.297 E.01462
G1 X128.874 Y82.87 E.01483
G1 X128.557 Y83.387 E.01475
G1 X128.112 Y83.817 E.01505
G1 X127.65 Y84.119 E.01343
G1 X127.235 Y84.275 E.01078
G1 X126.648 Y84.392 E.01456
G1 X121.586 Y84.401 E.12313
G1 X121.509 Y84.232 E.00452
G1 X121.051 Y83.975 E.01277
G1 X120.667 Y83.916 E.00945
G1 X110.333 Y83.916 E.25136
G1 X110.137 Y83.931 E.00478
G1 X109.771 Y84.046 E.00933
G1 X109.49 Y84.233 E.00821
G1 X109.473 Y84.271 E.00101
G1 X109.473 Y84.271 F9000
G1 X109.193 Y84.037
G1 F6000
G1 X105.365 Y84.037 E.09311
G1 X104.39 Y84.021 E.02372
G1 X103.879 Y83.933 E.01261
G1 X103.377 Y83.71 E.01336
G1 X102.915 Y83.357 E.01414
G1 X102.538 Y82.871 E.01496
G1 X102.33 Y82.407 E.01237
G1 X102.223 Y81.837 E.01411
G1 X102.213 Y78.946 E.07032
G1 X102.107 Y78.374 E.01415
G1 X101.684 Y77.747 E.0184
G1 X129.312 Y77.747 E.67202
G1 X128.888 Y78.387 E.01867
G1 X128.787 Y78.946 E.01382
G1 X128.78 Y80.899 E.04751
G1 X128.75 Y82.044 E.02786
G1 X128.622 Y82.552 E.01274
G1 X128.367 Y83.017 E.0129
G1 X128.037 Y83.409 E.01246
G1 X127.557 Y83.749 E.01431
G1 X127.128 Y83.925 E.01128
G1 X126.621 Y84.027 E.01258
G1 X121.785 Y84.035 E.11763
G1 X121.749 Y83.956 E.00211
G1 X121.387 Y83.717 E.01055
G1 X121.161 Y83.627 E.00592
G1 X120.667 Y83.551 E.01216
G1 X110.333 Y83.551 E.25136
G1 X110.081 Y83.57 E.00615
G1 X109.61 Y83.718 E.01201
G1 X109.249 Y83.958 E.01054
G1 X109.23 Y84.001 E.00114
G1 E-5 F3600
G1 X109.23 Y84.001 F9000
G1 X102.177 Y78.29
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X102.445 Y78.022 E.00922
G1 X102.964 Y78.022 E.01262
G1 X102.419 Y78.567 E.01875
G1 X102.487 Y79.017 E.01107
G1 X103.482 Y78.022 E.03423
G1 X104.001 Y78.022 E.01262
G1 X102.489 Y79.533 E.05199
G1 X102.491 Y80.05 E.01258
G1 X104.519 Y78.022 E.06976
G1 X105.038 Y78.022 E.01262
G1 X102.493 Y80.567 E.08755
G1 X102.495 Y81.083 E.01255
G1 X105.556 Y78.022 E.1053
G1 X106.075 Y78.022 E.01262
G1 X102.497 Y81.6 E.12308
G1 X102.546 Y82.069 E.01147
G1 X106.593 Y78.022 E.13921
G1 X107.112 Y78.022 E.01262
G1 X102.655 Y82.478 E.1533
G1 X102.828 Y82.823 E.00939
G1 X107.63 Y78.022 E.16517
G1 X108.149 Y78.022 E.01262
G1 X103.063 Y83.107 E.17494
G1 X103.337 Y83.351 E.00892
G1 X108.667 Y78.022 E.18333
G1 X109.186 Y78.022 E.01262
G1 X103.658 Y83.549 E.19014
G1 X104.038 Y83.688 E.00984
G1 X109.704 Y78.022 E.19491
G1 X110.223 Y78.022 E.01262
G1 X104.491 Y83.753 E.19716
G1 X105 Y83.763 E.01238
G1 X110.741 Y78.022 E.19749
G1 X111.259 Y78.022 E.0126
G1 X105.518 Y83.763 E.19749
G1 X106.037 Y83.763 E.01262
G1 X111.778 Y78.022 E.19749
G1 X112.296 Y78.022 E.0126
G1 X106.555 Y83.763 E.19749
G1 X107.074 Y83.763 E.01262
G1 X112.815 Y78.022 E.19749
G1 X113.333 Y78.022 E.0126
G1 X107.592 Y83.763 E.19749
G1 X108.111 Y83.763 E.01262
G1 X113.852 Y78.022 E.19749
G1 X114.37 Y78.022 E.0126
G1 X108.629 Y83.763 E.19749
G1 X109.05 Y83.763 E.01024
G1 X109.342 Y83.569 E.00853
G1 X114.889 Y78.022 E.19081
G1 X115.407 Y78.022 E.0126
G1 X110.138 Y83.291 E.18125
G1 X110.671 Y83.276 E.01297
G1 X115.926 Y78.022 E.18075
G1 X116.444 Y78.022 E.0126
G1 X111.19 Y83.276 E.18073
G1 X111.708 Y83.276 E.0126
G1 X116.963 Y78.022 E.18075
G1 X117.481 Y78.022 E.0126
G1 X112.227 Y83.276 E.18073
G1 X112.745 Y83.276 E.0126
G1 X118 Y78.022 E.18075
G1 X118.518 Y78.022 E.0126
G1 X113.264 Y83.276 E.18073
G1 X113.782 Y83.276 E.0126
G1 X119.037 Y78.022 E.18075
G1 X119.555 Y78.022 E.0126
G1 X114.301 Y83.276 E.18073
G1 X114.819 Y83.276 E.0126
G1 X120.074 Y78.022 E.18075
G1 X120.592 Y78.022 E.0126
G1 X115.338 Y83.276 E.18073
G1 X115.856 Y83.276 E.0126
G1 X121.111 Y78.022 E.18075
G1 X121.629 Y78.022 E.0126
G1 X116.375 Y83.276 E.18073
G1 X116.893 Y83.276 E.0126
G1 X122.148 Y78.022 E.18075
G1 X122.666 Y78.022 E.0126
G1 X117.412 Y83.276 E.18073
G1 X117.93 Y83.276 E.0126
G1 X123.185 Y78.022 E.18075
G1 X123.703 Y78.022 E.0126
G1 X118.449 Y83.276 E.18073
G1 X118.967 Y83.276 E.0126
G1 X124.222 Y78.022 E.18075
G1 X124.74 Y78.022 E.0126
G1 X119.485 Y83.276 E.18075
G1 X120.004 Y83.276 E.01262
G1 X125.259 Y78.022 E.18075
G1 X125.777 Y78.022 E.0126
G1 X120.522 Y83.276 E.18075
G1 X121.008 Y83.31 E.01185
G1 X126.296 Y78.022 E.1819
G1 X126.814 Y78.022 E.0126
G1 X121.406 Y83.43 E.18603
G1 X121.735 Y83.62 E.00924
G1 X127.333 Y78.022 E.19257
G1 X127.851 Y78.022 E.0126
G1 X122.112 Y83.76 E.1974
G1 X122.632 Y83.76 E.01265
G1 X128.37 Y78.022 E.19738
G1 X128.804 Y78.022 E.01056
G1 X128.646 Y78.264 E.00703
G1 X123.151 Y83.759 E.18902
G1 X123.671 Y83.758 E.01265
G1 X128.518 Y78.91 E.16675
G1 X128.511 Y79.435 E.01277
G1 X124.19 Y83.757 E.14866
G1 X124.709 Y83.756 E.01262
G1 X128.509 Y79.956 E.13072
G1 X128.508 Y80.476 E.01265
G1 X125.229 Y83.755 E.1128
G1 X125.748 Y83.754 E.01262
G1 X128.506 Y80.997 E.09486
G1 X128.504 Y81.517 E.01265
G1 X126.268 Y83.753 E.07692
G1 X126.819 Y83.72 E.01343
G1 X128.469 Y82.07 E.05676
G1 X128.365 Y82.451 E.00961
G1 X128.056 Y82.986 E.01503
G1 X127.306 Y83.752 E.02608
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X128.056 Y82.986 E-.50922
G1 X128.365 Y82.451 E-.29347
G1 X128.469 Y82.07 E-.1876
G1 X127.71 Y82.829 E-.50971
;WIPE_END
G1 X127.006 Y85.105 F9000
G1 X126.544 Y86.599
G1 X125.937 Y88.151
G1 X125.937 Y88.558
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X125.961 Y88.569 E.00064
G1 X126 Y88.683 E.00293
G1 X126 Y89.056 E.00907
G1 X126.422 Y89.441 E.01389
G1 X126.801 Y89.828 E.01318
G1 X127.092 Y90.285 E.01318
G1 X127.119 Y90.618 E.00813
G1 X126.825 Y91.141 E.01459
G1 X126.43 Y91.552 E.01387
G1 X126 Y91.944 E.01415
G1 X126 Y92.589 E.01569
G1 X139.201 Y92.589 E.3211
G1 X139.581 Y92.706 E.00967
G1 X139.758 Y92.878 E.006
G1 X139.867 Y93.102 E.00606
G1 X139.9 Y93.321 E.00539
G1 X139.9 Y95.508 E.0532
G1 X139.848 Y95.784 E.00683
G1 X139.706 Y96.01 E.00649
G1 X139.41 Y96.205 E.00862
G1 X138.996 Y96.239 E.0101
G1 X136.7 Y96.239 E.05585
G1 X136.7 Y103.098 E.16684
G1 X139.248 Y103.105 E.06198
G1 X139.47 Y103.201 E.00588
G1 X139.698 Y103.553 E.0102
G1 X139.762 Y104.021 E.01149
G1 X139.698 Y104.447 E.01048
G1 X139.47 Y104.799 E.0102
G1 X139.248 Y104.895 E.00588
G1 X136.7 Y104.902 E.06198
G1 X136.7 Y111.098 E.15071
G1 X139.248 Y111.105 E.06198
G1 X139.47 Y111.201 E.00588
G1 X139.698 Y111.553 E.0102
G1 X139.762 Y112.021 E.01149
G1 X139.698 Y112.447 E.01048
G1 X139.47 Y112.799 E.0102
G1 X139.248 Y112.895 E.00588
G1 X136.7 Y112.902 E.06198
G1 X136.7 Y119.098 E.15071
G1 X139.248 Y119.105 E.06198
G1 X139.47 Y119.201 E.00588
G1 X139.698 Y119.553 E.0102
G1 X139.762 Y120.021 E.01149
G1 X139.698 Y120.447 E.01048
G1 X139.47 Y120.799 E.0102
G1 X139.248 Y120.895 E.00588
G1 X136.7 Y120.902 E.06198
G1 X136.7 Y127.098 E.15071
G1 X139.248 Y127.105 E.06198
G1 X139.36 Y127.143 E.00288
G1 X139.631 Y127.395 E.009
G1 X139.753 Y127.835 E.01111
G1 X139.721 Y128.37 E.01304
G1 X139.542 Y128.728 E.00974
G1 X139.336 Y128.873 E.00613
G1 X138.993 Y128.896 E.00836
G1 X136.7 Y128.902 E.05578
G1 X136.7 Y132.616 E.09034
G1 X136.642 Y133.679 E.02589
G1 X136.455 Y134.819 E.0281
G1 X136.386 Y135.097 E.00697
G1 X139.202 Y135.099 E.0685
G1 X139.419 Y135.168 E.00554
G1 X139.64 Y135.411 E.00799
G1 X139.753 Y135.835 E.01067
G1 X139.721 Y136.37 E.01304
G1 X139.542 Y136.727 E.00971
G1 X139.275 Y136.885 E.00755
G1 X139.202 Y136.901 E.00182
G1 X135.744 Y136.904 E.08411
G1 X135.517 Y137.367 E.01254
G1 X135.232 Y137.872 E.0141
G1 X134.955 Y138.292 E.01224
G1 X134.404 Y139.047 E.02274
G1 X133.99 Y139.522 E.01533
G1 X133.58 Y139.942 E.01428
G1 X133.011 Y140.451 E.01857
G1 X132.257 Y141.019 E.02296
G1 X131.703 Y141.372 E.01598
G1 X131.162 Y141.672 E.01505
G1 X130.665 Y141.911 E.01341
G1 X128.89 Y142.62 E.04649
G1 X128.128 Y142.869 E.0195
;WIDTH:0.446054
G1 X127.869 Y142.956 E.00748
;WIDTH:0.492109
G1 X127.611 Y143.043 E.00829
G1 X127.875 Y143.068 E.00808
;WIDTH:0.446054
G1 X128.14 Y143.093 E.00729
;WIDTH:0.399999
G1 X139.202 Y143.099 E.26907
G1 X139.419 Y143.168 E.00554
G1 X139.64 Y143.411 E.00799
G1 X139.753 Y143.835 E.01067
G1 X139.721 Y144.37 E.01304
G1 X139.542 Y144.727 E.00971
G1 X139.275 Y144.885 E.00755
G1 X139.202 Y144.901 E.00182
G1 X125.683 Y144.905 E.32884
G1 X125.538 Y144.833 E.00394
G1 X125.5 Y144.722 E.00285
G1 X125.5 Y143.274 E.03522
G1 X125.515 Y143.204 E.00174
;WIDTH:0.397057
G1 X125.653 Y143.101 E.00415
;WIDTH:0.399999
G1 X125.464 Y142.969 E.00561
G1 X125.352 Y142.848 E.00401
G1 X125.026 Y142.8 E.00802
G1 X120.483 Y142.8 E.1105
G1 X120.35 Y142.743 E.00352
G1 X120.3 Y142.617 E.0033
G1 X120.3 Y142.226 E.00951
G1 X110.7 Y142.226 E.23351
G1 X110.7 Y142.617 E.00951
G1 X110.61 Y142.775 E.00442
G1 X109.587 Y142.8 E.02489
G1 X105.819 Y142.8 E.09165
G1 X105.62 Y142.882 E.00524
G1 X105.5 Y143.023 E.0045
;WIDTH:0.397076
G1 X105.347 Y143.101 E.00414
;WIDTH:0.399999
G1 X105.496 Y143.237 E.00491
G1 X105.5 Y143.274 E.00091
G1 X105.5 Y144.722 E.03522
G1 X105.437 Y144.86 E.00369
G1 X105.317 Y144.905 E.00312
G1 X91.798 Y144.901 E.32884
G1 X91.584 Y144.834 E.00545
G1 X91.369 Y144.605 E.00764
G1 X91.247 Y144.165 E.01111
G1 X91.279 Y143.63 E.01304
G1 X91.458 Y143.273 E.00971
G1 X91.725 Y143.115 E.00755
G1 X91.798 Y143.099 E.00182
G1 X102.903 Y143.093 E.27012
;WIDTH:0.40024
G1 X104.075 Y143.092 E.02853
G1 X102.922 Y142.882 E.02853
;WIDTH:0.399999
G1 X102.15 Y142.635 E.01972
G1 X100.666 Y142.052 E.03878
G1 X100.197 Y141.848 E.01244
G1 X99.56 Y141.524 E.01738
G1 X98.757 Y141.029 E.02295
G1 X98.14 Y140.574 E.01865
G1 X97.642 Y140.149 E.01592
G1 X97.142 Y139.664 E.01694
G1 X96.604 Y139.057 E.01973
G1 X96.229 Y138.569 E.01497
G1 X95.775 Y137.882 E.02003
G1 X95.488 Y137.377 E.01413
G1 X95.256 Y136.904 E.01281
G1 X91.798 Y136.901 E.08411
G1 X91.584 Y136.834 E.00545
G1 X91.369 Y136.605 E.00764
G1 X91.247 Y136.165 E.01111
G1 X91.279 Y135.63 E.01304
G1 X91.458 Y135.273 E.00971
G1 X91.725 Y135.115 E.00755
G1 X94.62 Y135.097 E.07042
G1 X94.449 Y134.332 E.01907
G1 X94.319 Y133.202 E.02767
G1 X94.3 Y132.67 E.01295
G1 X94.3 Y128.903 E.09163
G1 X91.751 Y128.895 E.062
G1 X91.53 Y128.799 E.00586
G1 X91.302 Y128.447 E.0102
G1 X91.238 Y127.979 E.01149
G1 X91.302 Y127.553 E.01048
G1 X91.53 Y127.201 E.0102
G1 X91.752 Y127.105 E.00588
G1 X94.3 Y127.098 E.06198
G1 X94.3 Y120.902 E.15071
G1 X91.752 Y120.895 E.06198
G1 X91.53 Y120.799 E.00588
G1 X91.302 Y120.447 E.0102
G1 X91.238 Y119.979 E.01149
G1 X91.302 Y119.553 E.01048
G1 X91.53 Y119.201 E.0102
G1 X91.752 Y119.105 E.00588
G1 X94.3 Y119.098 E.06198
G1 X94.3 Y112.902 E.15071
G1 X91.752 Y112.895 E.06198
G1 X91.53 Y112.799 E.00588
G1 X91.302 Y112.447 E.0102
G1 X91.238 Y111.979 E.01149
G1 X91.302 Y111.553 E.01048
G1 X91.53 Y111.201 E.0102
G1 X91.752 Y111.105 E.00588
G1 X94.3 Y111.098 E.06198
G1 X94.3 Y104.902 E.15071
G1 X91.752 Y104.895 E.06198
G1 X91.53 Y104.799 E.00588
G1 X91.302 Y104.447 E.0102
G1 X91.238 Y103.979 E.01149
G1 X91.302 Y103.553 E.01048
G1 X91.53 Y103.201 E.0102
G1 X91.752 Y103.105 E.00588
G1 X94.3 Y103.098 E.06198
G1 X94.3 Y96.239 E.16684
G1 X91.798 Y96.239 E.06086
G1 X91.529 Y96.182 E.00669
G1 X91.315 Y96.033 E.00634
G1 X91.133 Y95.727 E.00866
G1 X91.1 Y95.508 E.00539
G1 X91.1 Y93.321 E.0532
G1 X91.153 Y93.044 E.00686
G1 X91.295 Y92.818 E.00649
G1 X91.591 Y92.623 E.00862
G1 X91.798 Y92.589 E.0051
G1 X105 Y92.589 E.32113
G1 X105 Y91.944 E.01569
G1 X104.578 Y91.559 E.01389
G1 X104.199 Y91.172 E.01318
G1 X103.908 Y90.715 E.01318
G1 X103.881 Y90.382 E.00813
G1 X104.175 Y89.859 E.01459
G1 X104.57 Y89.448 E.01387
G1 X105 Y89.056 E.01415
G1 X105.018 Y88.605 E.01098
G1 X105.151 Y88.503 E.00408
G1 X125.817 Y88.5 E.50268
G1 X125.883 Y88.532 E.00178
G1 X125.883 Y88.532 F9000
G1 X126.194 Y88.305
;TYPE:Perimeter
G1 F6000
G1 X126.267 Y88.374 E.00244
G1 X126.353 Y88.583 E.0055
G1 X126.363 Y88.892 E.00752
G1 X126.751 Y89.256 E.01294
G1 X127.107 Y89.624 E.01245
G1 X127.422 Y90.127 E.01444
G1 X127.484 Y90.602 E.01165
G1 X127.4 Y90.912 E.00781
G1 X127.085 Y91.399 E.01411
G1 X126.366 Y92.142 E.02515
G1 X126.366 Y92.224 E.00199
G1 X139.201 Y92.224 E.3122
G1 X139.662 Y92.341 E.01157
G1 X139.994 Y92.593 E.01014
;WIDTH:0.438921
G1 X140.079 Y92.746 E.00471
;WIDTH:0.477843
G1 X140.163 Y92.899 E.00515
;WIDTH:0.516765
G1 X140.248 Y93.051 E.00559
;WIDTH:0.555687
G1 X140.333 Y93.204 E.00607
G1 X140.336 Y93.262 E.00201
;WIDTH:0.549097
G1 X140.34 Y95.508 E.07691
;WIDTH:0.546881
G1 X140.28 Y95.663 E.00567
;WIDTH:0.497921
G1 X140.22 Y95.818 E.00513
;WIDTH:0.44896
G1 X140.16 Y95.973 E.00458
;WIDTH:0.399999
G1 X139.91 Y96.313 E.01027
G1 X139.469 Y96.566 E.01237
G1 X138.996 Y96.605 E.01154
G1 X137.066 Y96.605 E.04695
G1 X137.066 Y102.733 E.14906
G1 X139.249 Y102.739 E.0531
G1 X139.536 Y102.823 E.00727
G1 X139.861 Y103.094 E.01029
G1 X140.038 Y103.432 E.00928
G1 X140.124 Y103.926 E.0122
G1 X140.082 Y104.433 E.01237
G1 X139.866 Y104.896 E.01243
G1 X139.624 Y105.13 E.00819
G1 X139.249 Y105.261 E.00966
G1 X137.066 Y105.267 E.0531
G1 X137.066 Y110.733 E.13295
G1 X139.249 Y110.739 E.0531
G1 X139.536 Y110.823 E.00727
G1 X139.861 Y111.094 E.01029
G1 X140.038 Y111.432 E.00928
G1 X140.124 Y111.926 E.0122
G1 X140.082 Y112.433 E.01237
G1 X139.866 Y112.896 E.01243
G1 X139.624 Y113.13 E.00819
G1 X139.249 Y113.261 E.00966
G1 X137.066 Y113.267 E.0531
G1 X137.066 Y118.733 E.13295
G1 X139.249 Y118.739 E.0531
G1 X139.536 Y118.823 E.00727
G1 X139.861 Y119.094 E.01029
G1 X140.038 Y119.432 E.00928
G1 X140.124 Y119.926 E.0122
G1 X140.082 Y120.433 E.01237
G1 X139.866 Y120.896 E.01243
G1 X139.624 Y121.13 E.00819
G1 X139.249 Y121.261 E.00966
G1 X137.066 Y121.267 E.0531
G1 X137.066 Y126.733 E.13295
G1 X139.249 Y126.739 E.0531
G1 X139.583 Y126.853 E.00858
G1 X139.83 Y127.055 E.00776
G1 X139.983 Y127.295 E.00692
G1 X140.119 Y127.824 E.01329
G1 X140.081 Y128.433 E.01484
G1 X139.865 Y128.899 E.01249
G1 X139.624 Y129.13 E.00812
G1 X139.249 Y129.261 E.00966
G1 X137.066 Y129.267 E.0531
G1 X137.066 Y132.616 E.08146
G1 X137.003 Y133.738 E.02733
G1 X136.836 Y134.732 E.02452
G1 X139.279 Y134.742 E.05942
G1 X139.669 Y134.902 E.01025
G1 X139.871 Y135.1 E.00688
G1 X139.993 Y135.315 E.00601
G1 X140.119 Y135.824 E.01275
G1 X140.081 Y136.433 E.01484
G1 X139.866 Y136.898 E.01246
G1 X139.588 Y137.146 E.00906
G1 X139.202 Y137.266 E.00983
G1 X135.972 Y137.27 E.07857
G1 X135.55 Y138.052 E.02161
G1 X135.258 Y138.496 E.01293
G1 X134.694 Y139.27 E.02329
G1 X134.266 Y139.762 E.01586
G1 X133.841 Y140.198 E.01481
G1 X133.255 Y140.723 E.01914
G1 X132.477 Y141.311 E.02372
G1 X131.9 Y141.68 E.01666
G1 X131.34 Y141.992 E.01559
G1 X130.823 Y142.241 E.01396
G1 X129.606 Y142.728 E.03188
G1 X139.202 Y142.734 E.23341
G1 X139.348 Y142.756 E.00359
G1 X139.669 Y142.902 E.00858
G1 X139.871 Y143.1 E.00688
G1 X139.993 Y143.315 E.00601
G1 X140.119 Y143.824 E.01275
G1 X140.081 Y144.434 E.01487
G1 X139.866 Y144.898 E.01244
G1 X139.588 Y145.146 E.00906
G1 X139.202 Y145.266 E.00983
G1 X125.683 Y145.27 E.32884
G1 X125.425 Y145.201 E.0065
G1 X125.219 Y145.003 E.00695
G1 X125.134 Y144.722 E.00714
G1 X125.134 Y143.274 E.03522
G1 X125.149 Y143.181 E.00229
G1 X125.026 Y143.166 E.00301
G1 X120.429 Y143.162 E.11182
G1 X120.102 Y143.011 E.00876
G1 X119.908 Y142.591 E.01125
G1 X111.066 Y142.591 E.21507
G1 X110.952 Y142.937 E.00886
G1 X110.866 Y143.032 E.00312
G1 X110.571 Y143.162 E.00784
G1 X105.868 Y143.166 E.1144
G1 X105.866 Y144.722 E.03785
G1 X105.772 Y145.021 E.00762
G1 X105.569 Y145.203 E.00663
G1 X105.317 Y145.27 E.00634
G1 X91.798 Y145.266 E.32884
G1 X91.393 Y145.139 E.01032
G1 X91.145 Y144.921 E.00803
G1 X91.017 Y144.705 E.00611
G1 X90.884 Y144.207 E.01254
G1 X90.914 Y143.609 E.01456
G1 X91.132 Y143.107 E.01331
G1 X91.412 Y142.854 E.00918
G1 X91.798 Y142.734 E.00983
G1 X101.388 Y142.728 E.23327
G1 X100.051 Y142.183 E.03512
G1 X99.394 Y141.85 E.01792
G1 X98.565 Y141.34 E.02367
G1 X97.923 Y140.868 E.01938
G1 X97.405 Y140.428 E.01653
G1 X96.888 Y139.926 E.01753
G1 X96.331 Y139.3 E.02038
G1 X95.939 Y138.792 E.01561
G1 X95.456 Y138.063 E.02127
G1 X95.032 Y137.27 E.02187
G1 X91.798 Y137.266 E.07866
G1 X91.393 Y137.139 E.01032
G1 X91.145 Y136.921 E.00803
G1 X91.017 Y136.705 E.00611
G1 X90.884 Y136.207 E.01254
G1 X90.914 Y135.609 E.01456
G1 X91.132 Y135.107 E.01331
G1 X91.412 Y134.854 E.00918
G1 X91.798 Y134.734 E.00983
G1 X94.163 Y134.732 E.05753
G1 X94.092 Y134.413 E.00795
G1 X93.955 Y133.244 E.02863
G1 X93.936 Y132.73 E.01251
G1 X93.934 Y129.268 E.08421
G1 X91.75 Y129.261 E.05312
G1 X91.464 Y129.177 E.00725
G1 X91.139 Y128.906 E.01029
G1 X90.962 Y128.568 E.00928
G1 X90.876 Y128.074 E.0122
G1 X90.934 Y127.52 E.01355
G1 X91.17 Y127.053 E.01273
G1 X91.376 Y126.87 E.0067
G1 X91.751 Y126.739 E.00966
G1 X93.934 Y126.733 E.0531
G1 X93.934 Y121.267 E.13295
G1 X91.751 Y121.261 E.0531
G1 X91.464 Y121.177 E.00727
G1 X91.139 Y120.906 E.01029
G1 X90.962 Y120.568 E.00928
G1 X90.876 Y120.074 E.0122
G1 X90.934 Y119.52 E.01355
G1 X91.17 Y119.053 E.01273
G1 X91.376 Y118.87 E.0067
G1 X91.751 Y118.739 E.00966
G1 X93.934 Y118.733 E.0531
G1 X93.934 Y113.267 E.13295
G1 X91.751 Y113.261 E.0531
G1 X91.464 Y113.177 E.00727
G1 X91.139 Y112.906 E.01029
G1 X90.962 Y112.568 E.00928
G1 X90.876 Y112.074 E.0122
G1 X90.934 Y111.52 E.01355
G1 X91.17 Y111.053 E.01273
G1 X91.376 Y110.87 E.0067
G1 X91.751 Y110.739 E.00966
G1 X93.934 Y110.733 E.0531
G1 X93.934 Y105.267 E.13295
G1 X91.751 Y105.261 E.0531
G1 X91.464 Y105.177 E.00727
G1 X91.139 Y104.906 E.01029
G1 X90.962 Y104.568 E.00928
G1 X90.876 Y104.074 E.0122
G1 X90.934 Y103.52 E.01355
G1 X91.17 Y103.053 E.01273
G1 X91.376 Y102.87 E.0067
G1 X91.751 Y102.739 E.00966
G1 X93.934 Y102.733 E.0531
G1 X93.934 Y96.605 E.14906
G1 X92.001 Y96.605 E.04702
G1 X91.477 Y96.549 E.01282
G1 X91.136 Y96.359 E.0095
;WIDTH:0.404937
G1 X90.828 Y95.944 E.01274
;WIDTH:0.454192
G1 X90.773 Y95.818 E.00384
;WIDTH:0.503447
G1 X90.718 Y95.693 E.00426
;WIDTH:0.552702
G1 X90.663 Y95.567 E.00474
G1 X90.659 Y93.321 E.07745
;WIDTH:0.550503
G1 X90.704 Y93.204 E.0043
;WIDTH:0.512877
G1 X90.75 Y93.088 E.00397
;WIDTH:0.475251
G1 X90.795 Y92.971 E.00368
;WIDTH:0.437625
G1 X90.84 Y92.855 E.00334
;WIDTH:0.399999
G1 X91.091 Y92.515 E.01028
G1 X91.531 Y92.263 E.01233
G1 X91.798 Y92.224 E.00656
G1 X104.634 Y92.224 E.31222
G1 X104.608 Y92.081 E.00354
G1 X103.887 Y91.364 E.02473
G1 X103.598 Y90.909 E.01311
G1 X103.515 Y90.618 E.00736
G1 X103.521 Y90.333 E.00693
G1 X103.594 Y90.099 E.00596
G1 X103.865 Y89.665 E.01245
G1 X104.244 Y89.259 E.01351
G1 X104.635 Y88.894 E.01301
G1 X104.659 Y88.542 E.00858
G1 X104.806 Y88.285 E.0072
G1 X105.183 Y88.134 E.00988
G1 X125.817 Y88.134 E.5019
G1 X126.1 Y88.216 E.00717
G1 X126.151 Y88.264 E.0017
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X126.194 Y88.305 E-.02822
G1 X126.267 Y88.374 E-.04771
G1 X126.353 Y88.583 E-.10735
G1 X126.363 Y88.892 E-.14685
G1 X126.751 Y89.256 E-.25271
G1 X127.107 Y89.624 E-.24321
G1 X127.422 Y90.127 E-.28191
G1 X127.484 Y90.602 E-.22754
G1 X127.4 Y90.912 E-.15256
G1 X127.386 Y90.933 E-.01194
;WIPE_END
G1 X104.075 Y143.092 F9000
G1 E5 F2400
;WIDTH:0.40024
G1 F6000
G1 X104.106 Y143.093 E.00075
;WIDTH:0.39727
G1 X105.319 Y143.1 E.02929
;WIDTH:0.385098
G1 X105.347 Y143.101 E.00065
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X105.319 Y143.1 E-.01331
G1 X104.106 Y143.093 E-.57618
G1 X104.075 Y143.092 E-.01473
;WIPE_END
G1 E-.89578 F3600
G1 X104.07 Y143.227 F9000
G1 X105.354 Y143.237
G1 X105.765 Y144.113
G1 X105.849 Y144.348
G1 X105.849 Y145.254
G1 X104.44 Y145.252
G1 X105.436 Y150.747
G1 X105.437 Y151.154
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.462 Y151.167 E.00069
G1 X105.5 Y151.278 E.00285
G1 X105.5 Y152.722 E.03512
G1 X105.443 Y152.854 E.0035
G1 X105.317 Y152.905 E.00331
G1 X95.461 Y152.902 E.23974
G1 X91.798 Y152.901 E.0891
G1 X91.584 Y152.834 E.00545
G1 X91.369 Y152.605 E.00764
G1 X91.247 Y152.165 E.01111
G1 X91.279 Y151.63 E.01304
G1 X91.458 Y151.273 E.00971
G1 X91.725 Y151.115 E.00755
G1 X91.798 Y151.099 E.00182
G1 X105.317 Y151.095 E.32884
G1 X105.383 Y151.128 E.00179
G1 X105.383 Y151.128 F9000
G1 X105.693 Y150.896
;TYPE:Perimeter
G1 F6000
G1 X105.732 Y150.92 E.00111
G1 X105.863 Y151.235 E.0083
G1 X105.866 Y152.721 E.03615
G1 X105.799 Y152.984 E.0066
G1 X105.581 Y153.195 E.00738
G1 X105.317 Y153.27 E.00668
G1 X92.545 Y153.267 E.31067
G1 X91.571 Y153.23 E.02371
;WIDTH:0.400455
G1 X91.193 Y152.972 E.01115
;WIDTH:0.449282
G1 X91.156 Y152.969 E.00102
;WIDTH:0.498109
G1 X91.119 Y152.965 E.00115
;WIDTH:0.546936
G1 X91.083 Y152.961 E.00124
G1 X90.954 Y152.719 E.00935
;WIDTH:0.542627
G1 X90.819 Y152.217 E.01758
;WIDTH:0.556673
G1 X90.805 Y152.132 E.00299
G1 X90.829 Y152.073 E.00221
;WIDTH:0.517505
G1 X90.854 Y152.014 E.00206
;WIDTH:0.478336
G1 X90.878 Y151.955 E.00188
;WIDTH:0.439168
G1 X90.903 Y151.895 E.00175
;WIDTH:0.399999
G1 X90.958 Y151.428 E.01144
G1 X91.175 Y151.049 E.01062
G1 X91.412 Y150.854 E.00747
G1 X91.798 Y150.734 E.00983
G1 X105.317 Y150.73 E.32884
G1 X105.442 Y150.744 E.00306
G1 X105.642 Y150.865 E.00569
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X105.693 Y150.896 E-.02835
G1 X105.732 Y150.92 E-.02175
G1 X105.863 Y151.235 E-.16205
G1 X105.866 Y152.721 E-.70585
G1 X105.799 Y152.984 E-.12892
G1 X105.581 Y153.195 E-.14411
G1 X105.317 Y153.27 E-.13036
G1 X104.941 Y153.27 E-.17861
;WIPE_END
G1 X104.941 Y153.253 F9000
G1 X105.849 Y153.254
G1 X105.849 Y152.824
G1 X125.653 Y143.237
G1 E5 F2400
;WIDTH:0.385048
G1 F6000
G1 X125.683 Y143.1 E.0007
;WIDTH:0.388922
G1 X126.767 Y143.097 E.02557
;WIDTH:0.42393
G1 X127.04 Y143.08 E.00709
;WIDTH:0.458937
G1 X127.313 Y143.063 E.00773
;WIDTH:0.493944
G1 X127.586 Y143.045 E.00836
;WIDTH:0.495486
G1 X127.596 Y143.045 E.00031
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X127.586 Y143.045 E-.00475
G1 X127.313 Y143.063 E-.12996
G1 X127.04 Y143.08 E-.12993
G1 X126.767 Y143.097 E-.12993
G1 X125.683 Y143.1 E-.5149
G1 X125.653 Y143.101 E-.01426
;WIPE_END
G1 E-.57627 F3600
G1 X125.653 Y143.237 F9000
G1 X125.646 Y143.237
G1 X125.234 Y144.115
G1 X125.151 Y144.389
G1 X125.151 Y145.254
G1 X125.627 Y145.253
G1 X125.151 Y151.157
G1 X125.555 Y151.157
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X125.563 Y151.14 E.00046
G1 X125.683 Y151.095 E.00312
G1 X139.202 Y151.099 E.32884
G1 X139.456 Y151.194 E.0066
G1 X139.616 Y151.404 E.00642
G1 X139.72 Y151.62 E.00583
G1 X139.75 Y152.126 E.01233
G1 X139.689 Y152.464 E.00835
G1 X139.503 Y152.776 E.00884
G1 X139.202 Y152.901 E.00793
G1 X125.683 Y152.905 E.32884
G1 X125.557 Y152.854 E.00331
G1 X125.5 Y152.722 E.0035
G1 X125.5 Y151.278 E.03512
G1 X125.53 Y151.211 E.00179
G1 X125.53 Y151.211 F9000
G1 X125.307 Y150.904
;TYPE:Perimeter
G1 F6000
G1 X125.366 Y150.831 E.00228
G1 X125.683 Y150.73 E.00809
G1 X139.202 Y150.734 E.32884
G1 X139.653 Y150.892 E.01162
G1 X139.862 Y151.095 E.00709
G1 X140.038 Y151.432 E.00925
;WIDTH:0.435377
G1 X140.084 Y151.594 E.00449
;WIDTH:0.470755
G1 X140.13 Y151.756 E.00489
;WIDTH:0.506132
G1 X140.176 Y151.917 E.00526
;WIDTH:0.535971
G1 X140.192 Y151.95 E.00122
;WIDTH:0.56581
G1 X140.208 Y151.983 E.0013
G1 X140.125 Y152.508 E.01879
;WIDTH:0.551826
G1 X139.916 Y152.962 E.0172
G1 X139.834 Y153.008 E.00324
;WIDTH:0.51387
G1 X139.752 Y153.054 E.003
;WIDTH:0.475913
G1 X139.67 Y153.1 E.00276
;WIDTH:0.437956
G1 X139.588 Y153.146 E.00252
;WIDTH:0.399999
G1 X139.202 Y153.266 E.00983
G1 X125.683 Y153.27 E.32884
G1 X125.419 Y153.195 E.00668
G1 X125.183 Y152.938 E.00849
G1 X125.134 Y152.722 E.00539
G1 X125.134 Y151.278 E.03512
G1 X125.194 Y151.043 E.0059
G1 X125.269 Y150.95 E.00291
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X125.307 Y150.904 E-.02834
G1 X125.366 Y150.831 E-.04458
G1 X125.683 Y150.73 E-.15803
G1 X128.355 Y150.731 E-1.26905
;WIPE_END
G1 X128.355 Y150.75 F9000
G1 X128.38 Y142.803
G1 X128.591 Y142.769
G1 X128.649 Y142.759
G1 X128.839 Y142.726
G1 X128.918 Y142.711
G1 X129.11 Y142.675
G1 X130.249 Y142.45
G1 X130.466 Y142.375
G1 X130.553 Y142.338
G1 X130.645 Y142.3
G1 X130.738 Y142.26
G1 X130.815 Y142.226
G1 X130.887 Y142.193
G1 X130.957 Y142.161
G1 X131.102 Y142.091
G1 X131.175 Y142.056
G1 X131.247 Y142.02
G1 X131.317 Y141.984
G1 X131.386 Y141.948
G1 X131.616 Y141.825
G1 X131.875 Y141.676
G1 X139.525 Y137.184
G1 X139.74 Y137.038
G1 X139.886 Y136.866
G1 X139.941 Y136.778
G1 X140.052 Y136.507
G1 X140.099 Y136.237
G1 X140.113 Y136
G1 X140.249 Y95.527
G1 X140.249 Y93.301
G1 X140.243 Y93.221
G1 X140.236 Y93.137
G1 X140.191 Y92.959
G1 X140.118 Y92.791
G1 X140.017 Y92.636
G1 X139.89 Y92.5
G1 X139.837 Y92.46
G1 X139.732 Y92.384
G1 X139.565 Y92.304
G1 X126.349 Y88.151
G1 X120.605 Y88.151
G1 X120.362 Y86.599
G1 X120.362 Y86.193
G1 E5 F2400
G1 F6000
G1 X120.342 Y86.183 E.00054
G1 X120.3 Y86.067 E.003
G1 X120.3 Y85.667 E.00973
G1 X110.7 Y85.667 E.23351
G1 X110.7 Y86.067 E.00973
G1 X110.658 Y86.183 E.003
G1 X110.517 Y86.25 E.0038
G1 X104.199 Y86.25 E.15368
G1 X103.618 Y86.209 E.01417
G1 X103.079 Y86.094 E.01341
G1 X102.609 Y85.936 E.01206
G1 X102.092 Y85.681 E.01402
G1 X101.366 Y85.148 E.02191
G1 X100.77 Y84.471 E.02194
G1 X100.465 Y83.947 E.01475
G1 X100.132 Y83.087 E.02243
G1 X100.013 Y82.366 E.01777
G1 X100 Y78.945 E.08321
G1 X99.578 Y78.559 E.01391
G1 X99.199 Y78.172 E.01318
G1 X98.908 Y77.715 E.01318
G1 X98.881 Y77.618 E.00245
G1 X98.908 Y77.285 E.00813
G1 X99.175 Y76.859 E.01223
G1 X99.57 Y76.448 E.01387
G1 X100 Y76.056 E.01415
G1 X100.005 Y75.761 E.00718
G1 X100.058 Y75.67 E.00256
G1 X100.183 Y75.621 E.00327
G1 X130.817 Y75.621 E.74514
G1 X130.942 Y75.67 E.00327
G1 X131 Y75.804 E.00355
G1 X131 Y76.056 E.00613
G1 X131.422 Y76.441 E.01389
G1 X131.801 Y76.828 E.01318
G1 X132.092 Y77.285 E.01318
G1 X132.118 Y77.639 E.00863
G1 X131.825 Y78.141 E.01414
G1 X131.43 Y78.552 E.01387
G1 X131 Y78.945 E.01417
G1 X130.99 Y82.337 E.08251
G1 X130.931 Y82.79 E.01111
G1 X130.688 Y83.634 E.02136
G1 X130.252 Y84.439 E.02227
G1 X129.871 Y84.914 E.01481
G1 X129.431 Y85.323 E.01461
G1 X128.668 Y85.81 E.02202
G1 X128.11 Y86.039 E.01467
G1 X127.628 Y86.164 E.01211
G1 X127.111 Y86.238 E.0127
G1 X120.483 Y86.25 E.16122
G1 X120.416 Y86.219 E.0018
G1 X120.416 Y86.219 F9000
G1 X120.109 Y86.441
;TYPE:Perimeter
G1 F6000
G1 X120.028 Y86.361 E.00277
G1 X119.9 Y86.033 E.00856
G1 X111.066 Y86.033 E.21488
G1 X110.972 Y86.361 E.0083
G1 X110.795 Y86.537 E.00607
G1 X110.517 Y86.616 E.00703
G1 X104.199 Y86.616 E.15368
G1 X103.592 Y86.574 E.0148
G1 X103.003 Y86.451 E.01464
G1 X102.47 Y86.274 E.01366
G1 X101.999 Y86.038 E.01281
G1 X101.089 Y85.387 E.02722
G1 X100.452 Y84.652 E.02366
G1 X100.038 Y83.92 E.02046
G1 X99.772 Y83.149 E.01984
G1 X99.652 Y82.424 E.01787
G1 X99.635 Y79.106 E.08071
G1 X98.891 Y78.369 E.02547
G1 X98.574 Y77.863 E.01452
G1 X98.515 Y77.397 E.01143
G1 X98.6 Y77.088 E.0078
G1 X98.915 Y76.601 E.01411
G1 X99.309 Y76.193 E.0138
G1 X99.634 Y75.894 E.01074
G1 X99.65 Y75.731 E.00398
G1 X99.766 Y75.463 E.0071
G1 X99.867 Y75.366 E.00341
G1 X100.183 Y75.256 E.00814
G1 X130.817 Y75.256 E.74514
G1 X131.133 Y75.366 E.00814
G1 X131.224 Y75.444 E.00292
G1 X131.355 Y75.71 E.00721
G1 X131.362 Y75.892 E.00443
G1 X132.113 Y76.636 E.02571
G1 X132.449 Y77.199 E.01595
G1 X132.48 Y77.66 E.01124
G1 X132.4 Y77.912 E.00643
G1 X132.085 Y78.399 E.01411
G1 X131.691 Y78.807 E.0138
G1 X131.365 Y79.106 E.01076
G1 X131.355 Y82.339 E.07864
G1 X131.294 Y82.835 E.01216
G1 X131.04 Y83.734 E.02272
G1 X130.535 Y84.671 E.02589
G1 X130.118 Y85.184 E.01608
G1 X129.626 Y85.633 E.0162
G1 X128.851 Y86.127 E.02236
G1 X128.248 Y86.378 E.01589
G1 X127.676 Y86.524 E.01436
G1 X127.164 Y86.6 E.01259
G1 X120.483 Y86.616 E.16251
G1 X120.206 Y86.537 E.00701
G1 X120.151 Y86.483 E.00187
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X120.109 Y86.441 E-.02821
G1 X120.028 Y86.361 E-.05408
G1 X119.9 Y86.033 E-.16724
G1 X117.267 Y86.033 E-1.25047
;WIPE_END
G1 X120.151 Y74.208 F9000
G1 E5 F2400
G1 F6000
G1 X135.589 Y74.207 E.37551
G1 X136.198 Y74.242 E.01484
G1 X136.885 Y74.368 E.01699
G1 X137.88 Y74.712 E.02561
G1 X138.795 Y75.227 E.02554
G1 X139.601 Y75.9 E.02554
G1 X140.273 Y76.706 E.02553
G1 X140.788 Y77.62 E.02552
G1 X141.131 Y78.612 E.02553
G1 X141.289 Y79.653 E.02561
G1 X141.289 Y80.022 E.00898
G1 X141.3 Y150.994 E1.72632
G1 X141.258 Y151.692 E.01701
G1 X141.134 Y152.375 E.01688
G1 X140.93 Y153.038 E.01687
G1 X140.648 Y153.672 E.01688
G1 X140.292 Y154.267 E.01687
G1 X139.867 Y154.816 E.01689
G1 X139.381 Y155.309 E.01684
G1 X138.738 Y155.811 E.01984
G1 X138.249 Y156.106 E.01389
G1 X137.533 Y156.432 E.01914
G1 X137.018 Y156.593 E.01312
G1 X136.479 Y156.716 E.01345
G1 X135.827 Y156.79 E.01596
G1 X95.389 Y156.798 E.98361
G1 X94.756 Y156.752 E.01544
G1 X94.066 Y156.619 E.01709
G1 X93.466 Y156.431 E.01529
G1 X92.859 Y156.163 E.01614
G1 X92.161 Y155.742 E.01983
G1 X91.62 Y155.31 E.01684
G1 X91.133 Y154.816 E.01687
G1 X90.708 Y154.267 E.01689
G1 X90.353 Y153.673 E.01683
G1 X89.996 Y152.822 E.02245
G1 X89.793 Y152.035 E.01977
G1 X89.711 Y151.347 E.01685
G1 X89.7 Y80.006 E1.7353
G1 X89.743 Y79.301 E.01718
G1 X89.869 Y78.612 E.01704
G1 X90.077 Y77.943 E.01704
G1 X90.365 Y77.305 E.01703
G1 X90.727 Y76.705 E.01704
G1 X91.159 Y76.154 E.01703
G1 X91.654 Y75.659 E.01703
G1 X92.205 Y75.227 E.01703
G1 X92.804 Y74.865 E.01702
G1 X93.571 Y74.533 E.02033
G1 X94.109 Y74.37 E.01367
G1 X95.153 Y74.211 E.02569
G1 X120.091 Y74.208 E.60659
G1 X120.091 Y74.208 F9000
G1 X120.091 Y74.574
;TYPE:Perimeter
G1 F6000
G1 X135.702 Y74.572 E.37972
G1 X136.201 Y74.625 E.01221
G1 X136.792 Y74.723 E.01457
G1 X137.73 Y75.047 E.02414
G1 X138.586 Y75.53 E.02391
G1 X139.341 Y76.159 E.0239
G1 X139.971 Y76.914 E.02392
G1 X140.454 Y77.771 E.02393
G1 X140.774 Y78.7 E.0239
G1 X140.923 Y79.68 E.02411
G1 X140.923 Y80.022 E.00832
G1 X140.925 Y92.638 E.30687
;WIDTH:0.449699
G1 X140.9 Y92.846 E.00579
;WIDTH:0.499398
G1 X140.876 Y93.054 E.00648
;WIDTH:0.549097
G1 X140.851 Y93.261 E.00714
G1 X140.852 Y95.506 E.07687
;WIDTH:0.546882
G1 X140.853 Y95.612 E.00361
;WIDTH:0.54508
G1 X140.877 Y95.811 E.00681
;WIDTH:0.49672
G1 X140.901 Y96.009 E.00613
;WIDTH:0.44836
G1 X140.926 Y96.208 E.00552
;WIDTH:0.399999
G1 X140.932 Y151.021 E1.33327
;WIDTH:0.409698
G1 X140.885 Y151.658 E.01595
;WIDTH:0.457915
G1 X140.837 Y151.79 E.00396
;WIDTH:0.506132
G1 X140.79 Y151.921 E.00437
;WIDTH:0.555388
G1 X140.501 Y152.924 E.03618
;WIDTH:0.545222
G1 X140.418 Y153.15 E.00818
;WIDTH:0.501745
G1 X140.335 Y153.377 E.00751
;WIDTH:0.458267
G1 X140.253 Y153.603 E.00678
;WIDTH:0.414789
G1 X139.963 Y154.094 E.01443
;WIDTH:0.399999
G1 X139.592 Y154.575 E.01478
G1 X139.137 Y155.036 E.01576
G1 X138.53 Y155.509 E.01872
G1 X138.078 Y155.782 E.01284
G1 X137.402 Y156.089 E.01806
G1 X136.841 Y156.265 E.0143
G1 X136.338 Y156.364 E.01247
G1 X135.806 Y156.425 E.01303
G1 X95.396 Y156.428 E.98293
G1 X94.715 Y156.371 E.01662
G1 X94.072 Y156.238 E.01597
G1 X93.52 Y156.055 E.01415
G1 X92.954 Y155.793 E.01517
G1 X92.31 Y155.392 E.01845
G1 X91.795 Y154.967 E.01624
G1 X91.378 Y154.535 E.0146
G1 X90.974 Y153.999 E.01633
;WIDTH:0.400455
G1 X90.681 Y153.507 E.01395
;WIDTH:0.449282
G1 X90.664 Y153.404 E.00288
;WIDTH:0.498109
G1 X90.647 Y153.301 E.00322
;WIDTH:0.546936
G1 X90.63 Y153.197 E.00359
G1 X90.407 Y152.664 E.0197
;WIDTH:0.556673
G1 X90.291 Y152.174 E.0175
G1 X90.256 Y152.113 E.00244
;WIDTH:0.517505
G1 X90.22 Y152.053 E.00225
;WIDTH:0.478336
G1 X90.185 Y151.992 E.00208
;WIDTH:0.439168
G1 X90.149 Y151.932 E.00188
;WIDTH:0.399999
G1 X90.076 Y151.288 E.01576
G1 X90.068 Y96.284 E1.33792
;WIDTH:0.438175
G1 X90.087 Y96.105 E.00484
;WIDTH:0.476351
G1 X90.106 Y95.926 E.00529
;WIDTH:0.514527
G1 X90.125 Y95.747 E.00575
;WIDTH:0.552702
G1 X90.144 Y95.567 E.00624
G1 X90.143 Y93.322 E.07741
;WIDTH:0.550504
G1 X90.124 Y93.203 E.00414
;WIDTH:0.512878
G1 X90.105 Y93.084 E.00384
;WIDTH:0.475252
G1 X90.086 Y92.964 E.00356
;WIDTH:0.437626
G1 X90.068 Y92.845 E.00323
;WIDTH:0.399999
G1 X90.066 Y80.017 E.31203
G1 X90.106 Y79.345 E.01637
G1 X90.225 Y78.7 E.01595
G1 X90.42 Y78.073 E.01597
G1 X90.689 Y77.475 E.01595
G1 X91.028 Y76.914 E.01594
G1 X91.433 Y76.397 E.01597
G1 X91.897 Y75.933 E.01596
G1 X92.414 Y75.528 E.01597
G1 X92.972 Y75.191 E.01586
G1 X93.697 Y74.877 E.01922
G1 X94.19 Y74.727 E.01253
G1 X95.18 Y74.577 E.02436
G1 X120.031 Y74.574 E.60448
G1 E-5 F3600
G1 X120.031 Y74.574 F9000
G1 X120.031 Y74.549
G1 X92.403 Y75.514
G1 X90.049 Y80.008
G1 X90.049 Y112.646
G1 X90.52 Y112.646
G1 E5 F2400
;WIDTH:0.56691
G1 F6000
G1 X90.498 Y112.394 E.00896
;WIDTH:0.523676
G1 X90.476 Y112.143 E.0082
;WIDTH:0.516506
G1 X90.494 Y111.542 E.01929
G1 E-5 F3600
G1 X90.494 Y111.542 F9000
G1 X90.927 Y111.617
G1 X90.901 Y111.763
G1 X90.887 Y112
G1 X90.901 Y112.237
G1 X90.948 Y112.507
G1 X91.059 Y112.778
G1 X91.114 Y112.866
G1 X91.26 Y113.038
G1 X91.475 Y113.184
G1 X91.643 Y113.234
G1 X91.766 Y113.249
G1 X93.303 Y113.253
G1 X93.57 Y113.253
G1 X93.569 Y113.631
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.569 Y118.369 E.11525
G1 X91.75 Y118.373 E.04425
G1 X91.245 Y118.528 E.01285
G1 X91.055 Y118.651 E.00551
G1 X90.804 Y118.945 E.0094
;WIDTH:0.438433
G1 X90.701 Y119.144 E.00602
;WIDTH:0.476867
G1 X90.598 Y119.343 E.0066
;WIDTH:0.5153
G1 X90.495 Y119.542 E.00717
G1 X90.476 Y119.315 E.00729
;WIDTH:0.476867
G1 X90.456 Y119.089 E.00668
;WIDTH:0.438433
G1 X90.437 Y118.862 E.00612
;WIDTH:0.399999
G1 X90.436 Y113.183 E.13814
;WIDTH:0.441727
G1 X90.457 Y113.049 E.00368
;WIDTH:0.483455
G1 X90.478 Y112.915 E.00405
;WIDTH:0.525183
G1 X90.499 Y112.78 E.00446
;WIDTH:0.56691
G1 X90.52 Y112.646 E.00481
G1 X90.575 Y112.734 E.00368
;WIDTH:0.521058
G1 X90.63 Y112.822 E.00336
;WIDTH:0.475206
G1 X90.796 Y113.036 E.00794
;WIDTH:0.437603
G1 X90.961 Y113.25 E.00725
;WIDTH:0.399999
G1 X91.239 Y113.466 E.00856
G1 X91.439 Y113.564 E.00542
G1 X91.75 Y113.627 E.00772
G1 X93.509 Y113.631 E.04279
G1 X93.509 Y113.631 F9000
G1 X93.203 Y113.996
G1 F6000
G1 X93.203 Y118.004 E.09749
G1 X91.749 Y118.008 E.03537
G1 X91.424 Y118.068 E.00804
G1 X91.114 Y118.187 E.00808
G1 X90.803 Y118.389 E.00902
G1 X90.802 Y113.589 E.11676
G1 X91.015 Y113.755 E.00657
G1 X91.348 Y113.918 E.00902
G1 X91.749 Y113.992 E.00992
G1 X93.143 Y113.996 E.03391
G1 X92.837 Y114.361 F9000
G1 F6000
G1 X92.837 Y117.639 E.07973
G1 X91.748 Y117.642 E.02649
G1 X91.168 Y117.775 E.01447
G1 X91.168 Y114.229 E.08625
G1 X91.257 Y114.273 E.00241
G1 X91.748 Y114.358 E.01212
G1 X92.777 Y114.361 E.02503
G1 E-5 F3600
G1 X92.777 Y114.361 F9000
G1 X90.52 Y120.644
G1 E5 F2400
;WIDTH:0.565472
G1 F6000
G1 X90.499 Y120.394 E.00886
;WIDTH:0.522351
G1 X90.477 Y120.143 E.00818
;WIDTH:0.5153
G1 X90.495 Y119.542 E.01924
G1 E-5 F3600
G1 X93.569 Y126.369 F9000
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X91.75 Y126.373 E.04425
G1 X91.245 Y126.528 E.01285
G1 X91.055 Y126.651 E.00551
G1 X90.804 Y126.945 E.0094
;WIDTH:0.43803
G1 X90.701 Y127.144 E.00602
;WIDTH:0.476061
G1 X90.598 Y127.343 E.00658
;WIDTH:0.514092
G1 X90.496 Y127.542 E.00714
G1 X90.476 Y127.315 E.00727
;WIDTH:0.476061
G1 X90.457 Y127.089 E.00666
;WIDTH:0.43803
G1 X90.438 Y126.862 E.00612
;WIDTH:0.399999
G1 X90.438 Y121.183 E.13814
;WIDTH:0.441368
G1 X90.458 Y121.048 E.0037
;WIDTH:0.482736
G1 X90.479 Y120.914 E.00405
;WIDTH:0.524104
G1 X90.5 Y120.779 E.00445
;WIDTH:0.565472
G1 X90.52 Y120.644 E.00482
G1 X90.575 Y120.733 E.0037
;WIDTH:0.519791
G1 X90.631 Y120.821 E.00337
;WIDTH:0.47411
G1 X90.796 Y121.036 E.00793
;WIDTH:0.437055
G1 X90.961 Y121.25 E.00724
;WIDTH:0.399999
G1 X91.239 Y121.466 E.00856
G1 X91.439 Y121.564 E.00542
G1 X91.75 Y121.627 E.00772
G1 X93.569 Y121.631 E.04425
G1 X93.569 Y126.309 E.11379
G1 X93.569 Y126.309 F9000
G1 X93.203 Y126.004
G1 F6000
G1 X91.749 Y126.008 E.03537
G1 X91.424 Y126.068 E.00804
G1 X91.114 Y126.187 E.00808
G1 X90.804 Y126.388 E.00899
G1 X90.803 Y121.59 E.11671
G1 X91.015 Y121.755 E.00653
G1 X91.348 Y121.918 E.00902
G1 X91.749 Y121.992 E.00992
G1 X93.203 Y121.996 E.03537
G1 X93.203 Y125.944 E.09603
G1 X92.837 Y125.639 F9000
G1 F6000
G1 X91.748 Y125.642 E.02649
G1 X91.17 Y125.774 E.01442
G1 X91.169 Y122.229 E.08623
G1 X91.257 Y122.273 E.00239
G1 X91.748 Y122.358 E.01212
G1 X92.837 Y122.361 E.02649
G1 X92.837 Y125.579 E.07827
G1 E-5 F3600
G1 X92.837 Y125.579 F9000
G1 X91.26 Y126.962
G1 X91.114 Y127.134
G1 X91.059 Y127.222
G1 X90.948 Y127.493
G1 X90.901 Y127.763
G1 X90.887 Y128
G1 X90.901 Y128.237
G1 X90.917 Y128.328
G1 X90.948 Y128.507
G1 X90.521 Y128.646
G1 E5 F2400
;WIDTH:0.564482
G1 F6000
G1 X90.499 Y128.394 E.00892
;WIDTH:0.521249
G1 X90.478 Y128.143 E.00816
;WIDTH:0.514092
G1 X90.496 Y127.542 E.01919
G1 E-5 F3600
G1 X90.496 Y127.542 F9000
G1 X93.719 Y134.367
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X91.798 Y134.368 E.04673
G1 X91.295 Y134.507 E.01269
G1 X91.101 Y134.622 E.00549
G1 X90.8 Y134.954 E.0109
;WIDTH:0.436524
G1 X90.698 Y135.164 E.00625
;WIDTH:0.473048
G1 X90.596 Y135.374 E.00681
;WIDTH:0.509572
G1 X90.494 Y135.584 E.00738
G1 X90.476 Y135.348 E.00748
;WIDTH:0.473048
G1 X90.458 Y135.111 E.00694
;WIDTH:0.436524
G1 X90.44 Y134.875 E.00633
;WIDTH:0.399999
G1 X90.439 Y129.183 E.13845
;WIDTH:0.44112
G1 X90.459 Y129.048 E.00369
;WIDTH:0.482241
G1 X90.48 Y128.914 E.00404
;WIDTH:0.523362
G1 X90.5 Y128.78 E.00441
;WIDTH:0.564482
G1 X90.521 Y128.646 E.00478
G1 X90.576 Y128.733 E.00363
;WIDTH:0.519383
G1 X90.631 Y128.821 E.00335
;WIDTH:0.474284
G1 X90.796 Y129.036 E.00793
;WIDTH:0.437142
G1 X90.961 Y129.25 E.00724
;WIDTH:0.399999
G1 X91.239 Y129.466 E.00856
G1 X91.439 Y129.564 E.00542
G1 X91.749 Y129.627 E.00769
G1 X93.569 Y129.632 E.04427
G1 X93.571 Y132.75 E.07584
G1 X93.592 Y133.287 E.01307
G1 X93.712 Y134.307 E.02498
G1 X93.712 Y134.307 F9000
G1 X93.308 Y134.001
G1 F6000
G1 X92.006 Y134.002 E.03167
G1 X91.506 Y134.05 E.01222
G1 X91.178 Y134.161 E.00842
G1 X90.805 Y134.396 E.01072
G1 X90.804 Y129.591 E.11688
G1 X91.015 Y129.755 E.0065
G1 X91.348 Y129.918 E.00902
G1 X91.748 Y129.992 E.00989
G1 X93.204 Y129.997 E.03542
G1 X93.206 Y132.763 E.06728
G1 X93.229 Y133.329 E.01378
G1 X93.301 Y133.942 E.01501
G1 X93.301 Y133.942 F9000
G1 X92.897 Y133.636
G1 F6000
G1 X91.797 Y133.637 E.02676
G1 X91.171 Y133.777 E.0156
G1 X91.17 Y130.23 E.08628
G1 X91.257 Y130.272 E.00235
G1 X91.747 Y130.358 E.0121
G1 X92.838 Y130.361 E.02654
G1 X92.839 Y132.731 E.05765
G1 X92.893 Y133.576 E.0206
G1 E-5 F3600
G1 X90.482 Y136.278 F9000
G1 E5 F2400
;WIDTH:0.509572
G1 F6000
G1 X90.494 Y135.584 E.02194
G1 E-5 F3600
G1 X90.494 Y135.584 F9000
G1 X90.495 Y143.584
G1 E5 F2400
;WIDTH:0.508366
G1 F6000
G1 X90.477 Y143.348 E.00746
;WIDTH:0.472244
G1 X90.459 Y143.111 E.00692
;WIDTH:0.436122
G1 X90.441 Y142.875 E.00633
;WIDTH:0.399999
G1 X90.44 Y136.83 E.14704
;WIDTH:0.442422
G1 X90.461 Y136.554 E.00751
;WIDTH:0.484844
G1 X90.482 Y136.278 E.0083
G1 X90.499 Y136.328 E.00158
;WIDTH:0.473578
G1 X90.582 Y136.564 E.00731
;WIDTH:0.436789
G1 X90.664 Y136.8 E.00669
;WIDTH:0.399999
G1 X90.836 Y137.117 E.00877
G1 X91.094 Y137.377 E.00891
G1 X91.516 Y137.584 E.01143
G1 X91.797 Y137.632 E.00693
G1 X94.813 Y137.635 E.07336
G1 X95.151 Y138.264 E.01737
G1 X95.65 Y139.015 E.02193
G1 X96.057 Y139.542 E.0162
G1 X96.633 Y140.189 E.02107
G1 X97.168 Y140.707 E.01811
G1 X97.706 Y141.162 E.01714
G1 X98.373 Y141.652 E.02013
G1 X99.598 Y142.363 E.03445
G1 X91.798 Y142.368 E.18973
G1 X91.295 Y142.507 E.01269
G1 X91.101 Y142.622 E.00549
G1 X90.8 Y142.954 E.0109
;WIDTH:0.436122
G1 X90.698 Y143.164 E.00624
;WIDTH:0.472244
G1 X90.597 Y143.374 E.00679
;WIDTH:0.508366
G1 X90.521 Y143.53 E.00547
G1 X90.521 Y143.53 F9000
G1 X90.806 Y142.395
;WIDTH:0.399999
G1 F6000
G1 X90.806 Y137.61 E.11639
G1 X91.118 Y137.817 E.00911
G1 X91.379 Y137.923 E.00685
G1 X91.797 Y137.998 E.01033
G1 X94.593 Y138 E.06801
G1 X94.846 Y138.466 E.0129
G1 X95.36 Y139.238 E.02256
G1 X95.784 Y139.785 E.01683
G1 X96.378 Y140.451 E.02171
G1 X96.931 Y140.985 E.0187
G1 X97.489 Y141.456 E.01776
G1 X98.239 Y141.998 E.02251
G1 X91.797 Y142.002 E.1567
G1 X91.506 Y142.05 E.00717
G1 X91.178 Y142.161 E.00842
G1 X90.857 Y142.363 E.00923
G1 X90.857 Y142.363 F9000
G1 X91.172 Y141.777
G1 F6000
G1 X91.171 Y138.233 E.0862
G1 X91.242 Y138.262 E.00187
G1 X91.797 Y138.363 E.01372
G1 X94.374 Y138.366 E.06268
G1 X94.541 Y138.668 E.00839
G1 X95.07 Y139.461 E.02319
G1 X95.51 Y140.028 E.01746
G1 X96.123 Y140.713 E.02236
G1 X96.694 Y141.264 E.0193
G1 X97.129 Y141.633 E.01388
G1 X91.797 Y141.637 E.1297
G1 X91.23 Y141.764 E.01413
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X91.172 Y141.777 E-.02823
G1 X91.171 Y138.679 E-1.47177
;WIPE_END
G1 X99.969 Y145.634 F9000
G1 E5 F2400
G1 F6000
G1 X105.317 Y145.636 E.13008
G1 X105.673 Y145.554 E.00889
G1 X105.87 Y145.448 E.00544
G1 X106.121 Y145.157 E.00935
G1 X106.232 Y144.722 E.01092
G1 X106.231 Y143.531 E.02897
G1 X109.58 Y143.528 E.08146
G1 X110.719 Y143.507 E.02771
G1 X111.131 Y143.293 E.01129
G1 X111.338 Y142.957 E.0096
G1 X119.662 Y142.957 E.20247
G1 X119.869 Y143.293 E.0096
G1 X120.176 Y143.466 E.00857
G1 X120.428 Y143.528 E.00631
G1 X124.769 Y143.531 E.10559
G1 X124.768 Y144.722 E.02897
G1 X124.798 Y144.898 E.00434
G1 X124.915 Y145.214 E.0082
G1 X125.055 Y145.377 E.00523
G1 X125.371 Y145.58 E.00914
G1 X125.683 Y145.636 E.00771
G1 X139.202 Y145.632 E.32884
G1 X139.705 Y145.493 E.01269
G1 X139.899 Y145.379 E.00547
G1 X140.193 Y145.061 E.01053
;WIDTH:0.442936
G1 X140.296 Y144.883 E.00559
;WIDTH:0.485873
G1 X140.399 Y144.706 E.00615
;WIDTH:0.52881
G1 X140.502 Y144.528 E.00676
G1 X140.524 Y144.735 E.00685
;WIDTH:0.485873
G1 X140.545 Y144.942 E.00625
;WIDTH:0.442936
G1 X140.567 Y145.149 E.00566
;WIDTH:0.399999
G1 X140.557 Y151.148 E.14592
;WIDTH:0.409698
G1 X140.484 Y151.777 E.01581
G1 X140.337 Y151.197 E.01494
;WIDTH:0.399999
G1 X140.072 Y150.778 E.01206
G1 X139.705 Y150.507 E.0111
G1 X139.202 Y150.368 E.01269
G1 X125.683 Y150.364 E.32884
G1 X125.327 Y150.446 E.00889
G1 X125.133 Y150.55 E.00535
G1 X124.835 Y150.938 E.0119
G1 X124.768 Y151.278 E.00843
G1 X124.768 Y152.722 E.03512
G1 X124.785 Y152.855 E.00326
G1 X124.882 Y153.164 E.00788
G1 X125.173 Y153.465 E.01018
G1 X125.435 Y153.597 E.00714
G1 X125.683 Y153.636 E.00611
G1 X139.202 Y153.632 E.32884
G1 X139.705 Y153.493 E.01269
;WIDTH:0.414789
G1 X139.959 Y153.354 E.00733
G1 X139.661 Y153.887 E.01545
;WIDTH:0.399999
G1 X139.316 Y154.334 E.01373
G1 X138.894 Y154.762 E.01462
G1 X138.322 Y155.207 E.01763
G1 X137.856 Y155.481 E.01315
G1 X137.207 Y155.767 E.01725
G1 X136.33 Y155.993 E.02203
G1 X135.786 Y156.059 E.01333
G1 X95.396 Y156.062 E.98245
G1 X94.784 Y156.012 E.01494
G1 X94.182 Y155.889 E.01495
G1 X93.668 Y155.721 E.01315
G1 X93.143 Y155.48 E.01405
G1 X92.538 Y155.107 E.01729
G1 X92.056 Y154.711 E.01517
G1 X91.669 Y154.313 E.0135
G1 X91.288 Y153.811 E.01533
;WIDTH:0.400455
G1 X90.979 Y153.271 E.01515
G1 X91.467 Y153.58 E.01407
;WIDTH:0.399999
G1 X92.545 Y153.632 E.02625
G1 X105.317 Y153.636 E.31067
G1 X105.566 Y153.597 E.00613
G1 X105.827 Y153.465 E.00711
G1 X106.009 Y153.3 E.00598
G1 X106.172 Y153.027 E.00773
G1 X106.232 Y152.721 E.00758
G1 X106.229 Y151.234 E.03617
G1 X106.201 Y151.062 E.00424
G1 X105.995 Y150.665 E.01088
G1 X105.623 Y150.422 E.01081
G1 X105.317 Y150.364 E.00758
G1 X91.798 Y150.368 E.32884
G1 X91.295 Y150.507 E.01269
G1 X90.928 Y150.778 E.0111
G1 X90.615 Y151.298 E.01476
G1 X90.531 Y151.951 E.01601
G1 X90.442 Y151.267 E.01678
G1 X90.441 Y144.83 E.15657
;WIDTH:0.441815
G1 X90.462 Y144.554 E.0075
;WIDTH:0.48363
G1 X90.483 Y144.278 E.00827
G1 X90.5 Y144.328 E.00158
;WIDTH:0.472537
G1 X90.582 Y144.564 E.00728
;WIDTH:0.436268
G1 X90.664 Y144.8 E.00668
;WIDTH:0.399999
G1 X90.836 Y145.117 E.00877
G1 X91.094 Y145.377 E.00891
G1 X91.516 Y145.584 E.01143
G1 X91.798 Y145.632 E.00696
G1 X99.909 Y145.634 E.19729
G1 E-5 F3600
G1 X99.909 Y145.634 F9000
G1 X99.909 Y145.249
G1 X91.766 Y145.249
G1 X91.643 Y145.234
G1 X91.475 Y145.184
G1 X91.26 Y145.038
G1 X91.114 Y144.866
G1 X91.059 Y144.778
G1 X90.948 Y144.507
G1 X90.901 Y144.237
G1 X90.483 Y144.278
G1 E5 F2400
;WIDTH:0.508366
G1 F6000
G1 X90.495 Y143.584 E.02189
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X90.483 Y144.278 E-.3297
;WIPE_END
G1 E-1.1703 F3600
G1 X90.901 Y144.237 F9000
G1 X90.887 Y144
G1 X90.901 Y143.763
G1 X90.948 Y143.493
G1 X91.059 Y143.222
G1 X91.114 Y143.134
G1 X91.26 Y142.962
G1 X91.475 Y142.816
G1 X91.643 Y142.766
G1 X91.766 Y142.751
G1 X100.362 Y142.751
G1 X100.845 Y142.787
G1 X106.597 Y143.897
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X110.572 Y143.893 E.09669
G1 X110.93 Y143.82 E.00889
G1 X111.363 Y143.575 E.0121
G1 X111.548 Y143.323 E.0076
G1 X119.452 Y143.323 E.19226
G1 X119.637 Y143.575 E.0076
G1 X120.07 Y143.82 E.0121
G1 X120.428 Y143.893 E.00889
G1 X124.403 Y143.897 E.09669
G1 X124.403 Y144.722 E.02007
G1 X124.527 Y145.238 E.01291
G1 X124.668 Y145.502 E.00728
G1 X124.975 Y145.778 E.01004
G1 X125.261 Y145.929 E.00787
G1 X125.683 Y146.002 E.01042
G1 X139.202 Y145.998 E.32884
G1 X139.494 Y145.95 E.0072
G1 X139.822 Y145.839 E.00842
G1 X140.201 Y145.598 E.01092
G1 X140.202 Y150.402 E.11685
G1 X139.822 Y150.161 E.01095
G1 X139.494 Y150.05 E.00842
G1 X139.202 Y150.002 E.0072
G1 X125.683 Y149.998 E.32884
G1 X125.223 Y150.095 E.01144
G1 X124.934 Y150.241 E.00788
G1 X124.638 Y150.567 E.01071
G1 X124.475 Y150.853 E.00801
G1 X124.403 Y151.278 E.01048
G1 X124.403 Y152.722 E.03512
G1 X124.43 Y152.943 E.00542
G1 X124.564 Y153.343 E.01026
G1 X124.927 Y153.736 E.01301
G1 X125.363 Y153.956 E.01188
G1 X125.683 Y154.002 E.00786
G1 X139.113 Y153.998 E.32667
G1 X138.65 Y154.488 E.0164
G1 X138.138 Y154.887 E.01579
G1 X137.705 Y155.148 E.0123
G1 X137.098 Y155.418 E.01616
G1 X136.618 Y155.564 E.0122
G1 X135.765 Y155.693 E.02098
G1 X95.396 Y155.697 E.98194
G1 X94.9 Y155.662 E.01209
G1 X94.334 Y155.554 E.01402
G1 X93.816 Y155.387 E.01324
G1 X93.332 Y155.167 E.01293
G1 X92.766 Y154.821 E.01614
G1 X92.316 Y154.454 E.01412
G1 X91.873 Y153.977 E.01583
G1 X92.545 Y153.998 E.01635
G1 X105.317 Y154.002 E.31067
G1 X105.637 Y153.956 E.00786
G1 X106.073 Y153.736 E.01188
G1 X106.436 Y153.344 E.013
G1 X106.527 Y153.116 E.00597
G1 X106.597 Y152.72 E.00978
G1 X106.595 Y151.234 E.03615
G1 X106.548 Y150.947 E.00707
G1 X106.315 Y150.478 E.01274
G1 X106.158 Y150.317 E.00547
G1 X105.691 Y150.056 E.01301
G1 X105.317 Y149.998 E.00921
G1 X91.798 Y150.002 E.32884
G1 X91.506 Y150.05 E.0072
G1 X91.178 Y150.161 E.00842
G1 X90.808 Y150.394 E.01064
G1 X90.807 Y145.611 E.11634
G1 X91.118 Y145.817 E.00907
G1 X91.379 Y145.923 E.00685
G1 X91.798 Y145.998 E.01035
G1 X105.317 Y146.002 E.32884
G1 X105.51 Y145.981 E.00472
G1 X105.989 Y145.811 E.01236
G1 X106.335 Y145.489 E.0115
G1 X106.524 Y145.123 E.01002
G1 X106.597 Y144.722 E.00991
G1 X106.597 Y143.957 E.01861
G1 X106.597 Y143.957 F9000
G1 X107.058 Y144.262
G1 F6000
G1 X109.58 Y144.26 E.06135
G1 X110.801 Y144.238 E.0297
G1 X111.161 Y144.115 E.00925
G1 X111.596 Y143.857 E.0123
G1 X111.719 Y143.688 E.00508
G1 X119.281 Y143.688 E.18394
G1 X119.404 Y143.857 E.00508
G1 X119.628 Y144.005 E.00653
G1 X120.084 Y144.211 E.01217
G1 X120.428 Y144.259 E.00845
G1 X124.037 Y144.262 E.08779
G1 X124.037 Y144.722 E.01119
G1 X124.181 Y145.356 E.01581
G1 X124.378 Y145.725 E.01017
G1 X124.75 Y146.066 E.01227
G1 X125.151 Y146.277 E.01102
G1 X125.683 Y146.367 E.01312
G1 X139.202 Y146.363 E.32884
G1 X139.835 Y146.221 E.01578
G1 X139.836 Y149.78 E.08657
G1 X139.202 Y149.637 E.01581
G1 X125.571 Y149.638 E.33156
G1 X125.119 Y149.745 E.0113
G1 X124.714 Y149.949 E.01103
G1 X124.351 Y150.34 E.01298
G1 X124.13 Y150.732 E.01095
G1 X124.037 Y151.278 E.01347
G1 X124.037 Y152.722 E.03512
G1 X124.075 Y153.032 E.0076
G1 X124.246 Y153.523 E.01265
G1 X124.681 Y154.006 E.01581
G1 X125.291 Y154.314 E.01662
G1 X125.683 Y154.367 E.00962
G1 X138.215 Y154.364 E.30483
G1 X137.566 Y154.81 E.01915
G1 X137.03 Y155.054 E.01432
G1 X136.547 Y155.205 E.01231
G1 X135.744 Y155.328 E.01976
G1 X95.396 Y155.331 E.98142
G1 X94.948 Y155.299 E.01092
G1 X94.447 Y155.203 E.01241
G1 X93.983 Y155.06 E.01181
G1 X93.521 Y154.854 E.0123
G1 X92.779 Y154.364 E.02163
G1 X105.317 Y154.367 E.30497
G1 X105.709 Y154.314 E.00962
G1 X106.319 Y154.006 E.01662
G1 X106.754 Y153.523 E.01581
G1 X106.882 Y153.204 E.00836
G1 X106.963 Y152.72 E.01194
G1 X106.96 Y151.233 E.03617
G1 X106.951 Y151.079 E.00375
G1 X106.843 Y150.7 E.00959
G1 X106.575 Y150.218 E.01341
G1 X106.222 Y149.92 E.01124
G1 X105.809 Y149.71 E.01127
G1 X105.317 Y149.633 E.01211
G1 X91.798 Y149.637 E.32884
G1 X91.173 Y149.776 E.01557
G1 X91.173 Y146.234 E.08616
G1 X91.242 Y146.262 E.00181
G1 X91.798 Y146.363 E.01375
G1 X105.317 Y146.367 E.32884
G1 X105.587 Y146.339 E.0066
G1 X106.106 Y146.164 E.01332
G1 X106.456 Y145.898 E.01069
G1 X106.766 Y145.503 E.01221
G1 X106.923 Y145.038 E.01194
G1 X106.963 Y144.262 E.0189
G1 X106.998 Y144.262 E.00085
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X107.058 Y144.262 E-.0285
G1 X109.58 Y144.26 E-1.19795
G1 X110.156 Y144.25 E-.27355
;WIPE_END
G1 X130.638 Y142.751 F9000
G1 X139.234 Y142.751
G1 X139.357 Y142.766
G1 X139.525 Y142.816
G1 X139.74 Y142.962
G1 X139.886 Y143.134
G1 X139.941 Y143.222
G1 X140.052 Y143.493
G1 X140.083 Y143.672
G1 X140.096 Y143.747
G1 X140.516 Y143.674
G1 E5 F2400
;WIDTH:0.520784
G1 F6000
G1 X140.506 Y144.46 E.02544
;WIDTH:0.52881
G1 X140.502 Y144.528 E.00224
G1 E-5 F3600
G1 X140.502 Y144.528 F9000
G1 X140.062 Y144.451
G1 X140.099 Y144.237
G1 X140.113 Y144
G1 X140.099 Y143.763
G1 X139.74 Y142.962
G1 X132.362 Y142.751
G1 X131.469 Y142.751
G1 X131.469 Y142.363
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X131.412 Y142.363 E.00139
G1 X132.096 Y141.989 E.01896
G1 X132.698 Y141.603 E.01739
G1 X133.499 Y140.996 E.02445
G1 X134.103 Y140.453 E.01976
G1 X134.541 Y140.002 E.01529
G1 X134.984 Y139.492 E.01643
G1 X135.563 Y138.697 E.02392
G1 X135.869 Y138.231 E.01356
G1 X136.201 Y137.635 E.01659
G1 X139.203 Y137.632 E.07302
G1 X139.705 Y137.493 E.01267
G1 X139.899 Y137.378 E.00549
G1 X140.193 Y137.061 E.01052
;WIDTH:0.442566
G1 X140.296 Y136.883 E.00558
;WIDTH:0.485133
G1 X140.399 Y136.705 E.00617
;WIDTH:0.5277
G1 X140.502 Y136.528 E.00672
G1 X140.523 Y136.735 E.00683
;WIDTH:0.485133
G1 X140.544 Y136.941 E.00621
;WIDTH:0.442566
G1 X140.566 Y137.148 E.00565
;WIDTH:0.399999
G1 X140.566 Y142.994 E.1422
;WIDTH:0.433712
G1 X140.549 Y143.221 E.00605
;WIDTH:0.467424
G1 X140.533 Y143.448 E.00656
;WIDTH:0.501136
G1 X140.516 Y143.674 E.00704
G1 X140.46 Y143.524 E.00497
;WIDTH:0.467424
G1 X140.403 Y143.374 E.00462
;WIDTH:0.433712
G1 X140.347 Y143.223 E.00428
;WIDTH:0.399999
G1 X140.183 Y142.909 E.00862
G1 X139.919 Y142.635 E.00926
G1 X139.488 Y142.418 E.01174
G1 X139.202 Y142.368 E.00706
G1 X131.529 Y142.363 E.18664
G1 X131.529 Y142.363 F9000
G1 X132.861 Y141.998
G1 F6000
G1 X132.761 Y141.998 E.00243
G1 X133.743 Y141.268 E.02976
G1 X134.365 Y140.708 E.02036
G1 X134.817 Y140.243 E.01577
G1 X135.275 Y139.714 E.01702
G1 X135.694 Y139.163 E.01684
G1 X136.154 Y138.465 E.02033
G1 X136.419 Y138 E.01302
G1 X139.203 Y137.998 E.06772
G1 X139.494 Y137.95 E.00717
G1 X139.822 Y137.839 E.00842
G1 X140.2 Y137.599 E.01089
G1 X140.201 Y142.398 E.11673
G1 X139.895 Y142.191 E.00899
G1 X139.628 Y142.08 E.00703
G1 X139.203 Y142.002 E.01051
G1 X132.921 Y141.998 E.1528
G1 X132.921 Y141.998 F9000
G1 X134.022 Y141.633
G1 F6000
G1 X133.871 Y141.633 E.00367
G1 X134.626 Y140.964 E.02454
G1 X135.093 Y140.483 E.01631
G1 X135.565 Y139.936 E.01757
G1 X136.173 Y139.1 E.02514
G1 X136.633 Y138.366 E.02107
G1 X139.203 Y138.363 E.06251
G1 X139.834 Y138.221 E.01573
G1 X139.835 Y141.77 E.08633
G1 X139.769 Y141.742 E.00174
G1 X139.203 Y141.637 E.014
G1 X134.082 Y141.634 E.12456
G1 E-5 F3600
G1 X134.082 Y141.634 F9000
G1 X139.74 Y137.038
G1 X140.113 Y136
G1 X140.099 Y135.763
G1 X140.096 Y135.747
G1 X140.515 Y135.675
G1 E5 F2400
;WIDTH:0.51968
G1 F6000
G1 X140.506 Y136.46 E.02535
;WIDTH:0.5277
G1 X140.502 Y136.528 E.00224
G1 X140.502 Y136.528 F9000
;WIDTH:0.500038
G1 F6000
G1 X140.438 Y135.474 E.00667
;WIDTH:0.466692
G1 X140.361 Y135.274 E.00616
;WIDTH:0.433346
G1 X140.284 Y135.074 E.00569
;WIDTH:0.399999
G1 X140.091 Y134.796 E.00823
G1 X139.754 Y134.528 E.01047
G1 X139.282 Y134.376 E.01206
G1 X137.268 Y134.367 E.04899
G1 X137.373 Y133.688 E.01671
G1 X137.431 Y132.616 E.02611
G1 X137.431 Y129.631 E.07261
G1 X139.25 Y129.627 E.04425
G1 X139.755 Y129.472 E.01285
G1 X139.945 Y129.349 E.00551
G1 X140.192 Y129.062 E.00921
;WIDTH:0.442203
G1 X140.295 Y128.884 E.00558
;WIDTH:0.484407
G1 X140.398 Y128.706 E.00616
;WIDTH:0.52661
G1 X140.501 Y128.528 E.00673
G1 X140.522 Y128.735 E.00681
;WIDTH:0.484407
G1 X140.543 Y128.942 E.00623
;WIDTH:0.442203
G1 X140.564 Y129.149 E.00565
;WIDTH:0.399999
G1 X140.565 Y134.994 E.14217
;WIDTH:0.433346
G1 X140.549 Y135.221 E.00604
;WIDTH:0.466692
G1 X140.532 Y135.448 E.00655
;WIDTH:0.500038
G1 X140.52 Y135.615 E.00519
G1 X140.52 Y135.615 F9000
G1 X140.199 Y134.396
;WIDTH:0.399999
G1 F6000
G1 X139.895 Y134.191 E.00892
G1 X139.628 Y134.08 E.00703
G1 X139.284 Y134.01 E.00854
G1 X137.7 Y134.001 E.03853
G1 X137.738 Y133.708 E.00719
G1 X137.797 Y132.616 E.0266
G1 X137.797 Y129.996 E.06373
G1 X139.251 Y129.992 E.03537
G1 X139.576 Y129.932 E.00804
G1 X139.886 Y129.813 E.00808
G1 X140.199 Y129.61 E.00907
G1 X140.199 Y134.336 E.11496
G1 X140.199 Y134.336 F9000
G1 X139.834 Y133.769
G1 F6000
G1 X139.287 Y133.645 E.01364
G1 X138.108 Y133.636 E.02868
G1 X138.163 Y132.616 E.02485
G1 X138.163 Y130.361 E.05485
G1 X139.252 Y130.358 E.02649
G1 X139.833 Y130.225 E.0145
G1 X139.834 Y133.709 E.08474
G1 E-5 F3600
G1 X139.834 Y133.709 F9000
G1 X140.514 Y127.669
G1 E5 F2400
;WIDTH:0.518594
G1 F6000
G1 X140.505 Y128.46 E.02548
;WIDTH:0.52661
G1 X140.501 Y128.528 E.00223
G1 X140.501 Y128.528 F9000
;WIDTH:0.500512
G1 F6000
G1 X140.429 Y127.456 E.00711
;WIDTH:0.467008
G1 X140.343 Y127.243 E.00661
;WIDTH:0.433504
G1 X140.258 Y127.031 E.00606
;WIDTH:0.399999
G1 X140.015 Y126.724 E.00952
G1 X139.649 Y126.479 E.01071
G1 X139.25 Y126.373 E.01004
G1 X137.431 Y126.369 E.04425
G1 X137.431 Y121.631 E.11525
G1 X139.25 Y121.627 E.04425
G1 X139.755 Y121.472 E.01285
G1 X139.945 Y121.349 E.00551
G1 X140.196 Y121.055 E.0094
;WIDTH:0.440766
G1 X140.298 Y120.872 E.00566
;WIDTH:0.481532
G1 X140.4 Y120.689 E.00623
;WIDTH:0.522298
G1 X140.502 Y120.506 E.0068
G1 X140.523 Y120.717 E.00688
;WIDTH:0.481532
G1 X140.543 Y120.928 E.0063
;WIDTH:0.440766
G1 X140.563 Y121.138 E.0057
;WIDTH:0.399999
G1 X140.564 Y127.169 E.1467
;WIDTH:0.433504
G1 X140.547 Y127.336 E.00446
;WIDTH:0.467008
G1 X140.531 Y127.502 E.0048
;WIDTH:0.500512
G1 X140.52 Y127.609 E.00334
G1 X140.198 Y126.404 F9000
;WIDTH:0.399999
G1 F6000
G1 X139.767 Y126.133 E.01238
G1 X139.251 Y126.008 E.01291
G1 X137.797 Y126.004 E.03537
G1 X137.797 Y121.996 E.09749
G1 X139.251 Y121.992 E.03537
G1 X139.576 Y121.932 E.00804
G1 X139.886 Y121.813 E.00808
G1 X140.198 Y121.611 E.00904
G1 X140.198 Y126.344 E.11513
G1 X140.198 Y126.344 F9000
G1 X139.833 Y125.769
G1 F6000
G1 X139.252 Y125.642 E.01447
G1 X138.163 Y125.639 E.02649
G1 X138.163 Y122.361 E.07973
G1 X139.252 Y122.358 E.02649
G1 X139.832 Y122.225 E.01447
G1 X139.833 Y125.709 E.08474
G1 E-5 F3600
G1 X139.833 Y125.709 F9000
G1 X140.48 Y119.356
G1 E5 F2400
;WIDTH:0.566024
G1 F6000
G1 X140.502 Y119.606 E.00888
;WIDTH:0.522897
G1 X140.523 Y119.857 E.00819
;WIDTH:0.515832
G1 X140.505 Y120.458 E.01926
;WIDTH:0.522298
G1 X140.502 Y120.506 E.00156
G1 E-5 F3600
G1 X140.502 Y120.506 F9000
G1 X140.065 Y120.43
G1 X140.099 Y120.237
G1 X140.113 Y120
G1 X140.099 Y119.763
G1 X140.052 Y119.493
G1 X139.941 Y119.221
G1 X139.886 Y119.134
G1 X139.74 Y118.962
G1 X139.525 Y118.816
G1 X139.357 Y118.766
G1 X139.234 Y118.751
G1 X137.697 Y118.747
G1 X137.43 Y118.747
G1 X137.431 Y118.369
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y113.631 E.11525
G1 X139.25 Y113.627 E.04425
G1 X139.755 Y113.472 E.01285
G1 X139.945 Y113.349 E.00551
G1 X140.196 Y113.055 E.0094
;WIDTH:0.440402
G1 X140.298 Y112.872 E.00566
;WIDTH:0.480805
G1 X140.4 Y112.689 E.00622
;WIDTH:0.521208
G1 X140.502 Y112.506 E.00679
G1 X140.522 Y112.717 E.00686
;WIDTH:0.480805
G1 X140.542 Y112.927 E.00627
;WIDTH:0.440402
G1 X140.562 Y113.138 E.00572
;WIDTH:0.399999
G1 X140.563 Y118.817 E.13814
;WIDTH:0.441506
G1 X140.542 Y118.952 E.0037
;WIDTH:0.483012
G1 X140.522 Y119.086 E.00404
;WIDTH:0.524518
G1 X140.501 Y119.221 E.00445
;WIDTH:0.566024
G1 X140.48 Y119.356 E.00483
G1 X140.425 Y119.267 E.0037
;WIDTH:0.52017
G1 X140.369 Y119.179 E.00337
;WIDTH:0.474316
G1 X140.204 Y118.964 E.00793
;WIDTH:0.437158
G1 X140.039 Y118.75 E.00724
;WIDTH:0.399999
G1 X139.761 Y118.534 E.00856
G1 X139.561 Y118.436 E.00542
G1 X139.25 Y118.373 E.00772
G1 X137.491 Y118.369 E.04279
G1 X137.491 Y118.369 F9000
G1 X137.797 Y118.004
G1 F6000
G1 X137.797 Y113.996 E.09749
G1 X139.251 Y113.992 E.03537
G1 X139.576 Y113.932 E.00804
G1 X139.886 Y113.813 E.00808
G1 X140.197 Y113.612 E.00901
G1 X140.197 Y118.41 E.11671
G1 X139.985 Y118.245 E.00653
G1 X139.652 Y118.082 E.00902
G1 X139.251 Y118.008 E.00992
G1 X137.857 Y118.004 E.03391
G1 X138.163 Y117.639 F9000
G1 F6000
G1 X138.163 Y114.361 E.07973
G1 X139.252 Y114.358 E.02649
G1 X139.831 Y114.226 E.01444
G1 X139.832 Y117.771 E.08623
G1 X139.743 Y117.727 E.00241
G1 X139.252 Y117.642 E.01212
G1 X138.223 Y117.639 E.02503
G1 E-5 F3600
G1 X138.223 Y117.639 F9000
G1 X140.48 Y111.356
G1 E5 F2400
;WIDTH:0.564934
G1 F6000
G1 X140.501 Y111.606 E.00885
;WIDTH:0.521807
G1 X140.523 Y111.857 E.00817
;WIDTH:0.514746
G1 X140.505 Y112.458 E.01921
;WIDTH:0.521208
G1 X140.502 Y112.506 E.00156
G1 E-5 F3600
G1 X140.502 Y112.506 F9000
G1 X140.065 Y112.43
G1 X140.099 Y112.237
G1 X140.113 Y112
G1 X140.099 Y111.763
G1 X140.052 Y111.493
G1 X139.941 Y111.221
G1 X139.886 Y111.134
G1 X139.74 Y110.962
G1 X139.525 Y110.816
G1 X139.357 Y110.766
G1 X139.234 Y110.751
G1 X138.107 Y110.748
G1 X137.821 Y110.747
G1 X137.822 Y110.37
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y110.369 E.00951
G1 X137.431 Y105.631 E.11525
G1 X139.25 Y105.627 E.04425
G1 X139.755 Y105.472 E.01285
G1 X139.945 Y105.349 E.00551
G1 X140.196 Y105.055 E.0094
;WIDTH:0.440038
G1 X140.298 Y104.872 E.00565
;WIDTH:0.480077
G1 X140.399 Y104.689 E.0062
;WIDTH:0.520116
G1 X140.501 Y104.506 E.00677
G1 X140.521 Y104.717 E.00685
;WIDTH:0.480077
G1 X140.541 Y104.927 E.00625
;WIDTH:0.440038
G1 X140.561 Y105.138 E.00572
;WIDTH:0.399999
G1 X140.562 Y110.817 E.13814
;WIDTH:0.441233
G1 X140.541 Y110.952 E.0037
;WIDTH:0.482467
G1 X140.521 Y111.086 E.00404
;WIDTH:0.523701
G1 X140.5 Y111.221 E.00445
;WIDTH:0.564934
G1 X140.48 Y111.356 E.00482
G1 X140.424 Y111.267 E.00371
;WIDTH:0.519421
G1 X140.369 Y111.179 E.00335
;WIDTH:0.473907
G1 X140.204 Y110.964 E.00792
;WIDTH:0.436953
G1 X140.039 Y110.75 E.00724
;WIDTH:0.399999
G1 X139.761 Y110.534 E.00856
G1 X139.561 Y110.436 E.00542
G1 X139.25 Y110.373 E.00772
G1 X137.882 Y110.37 E.03328
G1 X137.882 Y110.37 F9000
G1 X137.946 Y110.004
G1 F6000
G1 X137.797 Y110.004 E.00362
G1 X137.797 Y105.996 E.09749
G1 X139.251 Y105.992 E.03537
G1 X139.576 Y105.932 E.00804
G1 X139.886 Y105.813 E.00808
G1 X140.196 Y105.612 E.00899
G1 X140.196 Y110.41 E.11671
G1 X139.985 Y110.245 E.00652
G1 X139.652 Y110.082 E.00902
G1 X139.251 Y110.008 E.00992
G1 X138.006 Y110.004 E.03028
G1 X138.006 Y110.004 F9000
G1 X138.377 Y109.64
G1 F6000
G1 X138.163 Y109.639 E.00521
G1 X138.163 Y106.361 E.07973
G1 X139.252 Y106.358 E.02649
G1 X139.83 Y106.226 E.01442
G1 X139.83 Y109.77 E.0862
G1 X139.743 Y109.727 E.00236
G1 X139.252 Y109.642 E.01212
G1 X138.437 Y109.64 E.01982
G1 E-5 F3600
G1 X138.437 Y109.64 F9000
G1 X140.479 Y103.356
G1 E5 F2400
;WIDTH:0.563844
G1 F6000
G1 X140.501 Y103.606 E.00884
;WIDTH:0.520718
G1 X140.522 Y103.857 E.00815
;WIDTH:0.51366
G1 X140.504 Y104.458 E.01917
;WIDTH:0.520116
G1 X140.501 Y104.506 E.00155
G1 E-5 F3600
G1 X140.065 Y104.43 F9000
G1 X140.099 Y104.237
G1 X140.113 Y104
G1 X140.099 Y103.763
G1 X140.052 Y103.493
G1 X139.941 Y103.222
G1 X139.886 Y103.134
G1 X139.74 Y102.962
G1 X139.525 Y102.816
G1 X139.357 Y102.766
G1 X139.234 Y102.751
G1 X137.697 Y102.747
G1 X137.43 Y102.747
G1 X137.431 Y102.369
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y96.971 E.1313
G1 X139.285 Y96.964 E.0451
G1 X139.727 Y96.853 E.01109
G1 X140.1 Y96.625 E.01063
G1 X140.269 Y96.465 E.00566
;WIDTH:0.404586
G1 X140.553 Y95.983 E.01378
G1 X140.56 Y96.208 E.00554
;WIDTH:0.399999
G1 X140.561 Y102.817 E.16076
;WIDTH:0.440961
G1 X140.54 Y102.952 E.0037
;WIDTH:0.481922
G1 X140.52 Y103.087 E.00406
;WIDTH:0.522883
G1 X140.499 Y103.221 E.00441
;WIDTH:0.563844
G1 X140.479 Y103.356 E.00481
G1 X140.424 Y103.267 E.00369
;WIDTH:0.51867
G1 X140.369 Y103.179 E.00334
;WIDTH:0.473496
G1 X140.204 Y102.965 E.00789
;WIDTH:0.436748
G1 X140.039 Y102.75 E.00725
;WIDTH:0.399999
G1 X139.761 Y102.534 E.00856
G1 X139.561 Y102.436 E.00542
G1 X139.25 Y102.373 E.00772
G1 X137.491 Y102.369 E.04279
G1 X137.491 Y102.369 F9000
G1 X137.797 Y102.004
G1 F6000
G1 X137.797 Y97.336 E.11354
G1 X138.996 Y97.336 E.02916
G1 X139.58 Y97.289 E.01425
G1 X139.918 Y97.165 E.00876
G1 X140.194 Y96.996 E.00787
G1 X140.195 Y102.409 E.13167
G1 X139.985 Y102.245 E.00648
G1 X139.652 Y102.082 E.00902
G1 X139.251 Y102.008 E.00992
G1 X137.857 Y102.004 E.03391
G1 X138.163 Y101.639 F9000
G1 F6000
G1 X138.163 Y97.702 E.09576
G1 X139.396 Y97.687 E.02999
G1 X139.829 Y97.58 E.01085
G1 X139.829 Y101.77 E.10192
G1 X139.743 Y101.727 E.00234
G1 X139.252 Y101.642 E.01212
G1 X138.223 Y101.639 E.02503
G1 E-5 F3600
G1 X138.223 Y101.639 F9000
G1 X140.191 Y95.869
G1 X140.236 Y95.692
G1 X140.243 Y95.607
G1 X140.249 Y95.527
G1 X140.249 Y93.301
G1 X140.243 Y93.221
G1 X140.236 Y93.137
G1 X140.191 Y92.959
G1 X140.118 Y92.791
G1 X140.017 Y92.636
G1 X139.89 Y92.5
G1 X139.837 Y92.46
G1 X139.732 Y92.384
G1 X139.565 Y92.304
G1 X126.349 Y88.151
G1 X121.622 Y88.151
G1 X119.951 Y86.599
G1 X119.842 Y86.704
G1 E5 F2400
G1 F6000
G1 X119.859 Y86.729 E.00074
G1 X120.194 Y86.928 E.00948
G1 X120.483 Y86.981 E.00715
G1 X126.832 Y86.968 E.15443
G1 X127.393 Y86.936 E.01367
G1 X127.892 Y86.857 E.01229
G1 X128.387 Y86.716 E.01252
G1 X129.047 Y86.436 E.01744
G1 X129.871 Y85.904 E.02386
G1 X130.401 Y85.416 E.01752
G1 X130.854 Y84.85 E.01763
G1 X131.11 Y84.396 E.01268
G1 X131.391 Y83.834 E.01528
G1 X131.663 Y82.851 E.02481
G1 X131.721 Y82.34 E.01251
G1 X131.73 Y79.268 E.07472
G1 X131.953 Y79.063 E.00737
G1 X132.392 Y78.597 E.01557
G1 X132.707 Y78.11 E.01411
G1 X132.829 Y77.77 E.00879
G1 X132.839 Y77.272 E.01212
G1 X132.764 Y77.014 E.00654
G1 X132.378 Y76.384 E.01797
G1 X131.743 Y75.744 E.02193
G1 X131.706 Y75.589 E.00388
G1 X131.539 Y75.259 E.009
G1 X131.267 Y75.026 E.00871
G1 X131.013 Y74.939 E.00653
G1 X135.542 Y74.938 E.11016
G1 X136.163 Y74.989 E.01516
G1 X136.699 Y75.078 E.01322
G1 X137.579 Y75.381 E.02264
G1 X138.377 Y75.832 E.0223
G1 X139.082 Y76.419 E.02231
G1 X139.668 Y77.123 E.02228
G1 X140.119 Y77.922 E.02232
G1 X140.418 Y78.788 E.02228
G1 X140.51 Y79.397 E.01498
G1 X140.558 Y80.022 E.01525
G1 X140.56 Y92.833 E.31161
G1 X140.472 Y92.664 E.00463
G1 X140.157 Y92.244 E.01277
G1 X139.873 Y92.042 E.00848
G1 X139.682 Y91.956 E.0051
G1 X139.201 Y91.858 E.01194
G1 X127.153 Y91.858 E.29306
G1 X127.392 Y91.597 E.00861
G1 X127.774 Y90.964 E.01798
G1 X127.849 Y90.569 E.00978
G1 X127.763 Y89.991 E.01421
G1 X127.482 Y89.533 E.01307
G1 X127.246 Y89.24 E.00915
G1 X126.724 Y88.726 E.01782
G1 X126.714 Y88.516 E.00511
G1 X126.594 Y88.21 E.008
G1 X126.452 Y88.032 E.00554
G1 X126.113 Y87.825 E.00966
G1 X125.817 Y87.769 E.00733
G1 X105.183 Y87.769 E.5019
G1 X104.972 Y87.811 E.00523
G1 X104.543 Y88.03 E.01172
G1 X104.31 Y88.429 E.01124
G1 X104.272 Y88.733 E.00745
G1 X103.978 Y89.008 E.00979
G1 X103.555 Y89.471 E.01525
G1 X103.237 Y89.998 E.01497
G1 X103.149 Y90.382 E.00958
G1 X103.17 Y90.77 E.00945
G1 X103.288 Y91.103 E.00859
G1 X103.555 Y91.529 E.01223
G1 X103.852 Y91.858 E.01078
G1 X91.715 Y91.864 E.29522
G1 X91.273 Y91.975 E.01109
G1 X90.9 Y92.203 E.01063
G1 X90.732 Y92.363 E.00564
G1 X90.538 Y92.65 E.00843
G1 X90.433 Y92.951 E.00775
G1 X90.431 Y80.028 E.31434
G1 X90.47 Y79.389 E.01557
G1 X90.58 Y78.787 E.01489
G1 X90.762 Y78.203 E.01488
G1 X91.013 Y77.645 E.01488
G1 X91.33 Y77.122 E.01488
G1 X91.707 Y76.64 E.01488
G1 X92.14 Y76.207 E.01489
G1 X92.622 Y75.83 E.01488
G1 X93.14 Y75.517 E.01472
G1 X93.653 Y75.295 E.0136
G1 X94.271 Y75.085 E.01588
G1 X95.208 Y74.942 E.02306
G1 X99.185 Y74.942 E.09674
G1 X99.985 Y74.926 E.01946
;WIDTH:0.397859
G1 X99.733 Y75.027 E.00656
;WIDTH:0.399999
G1 X99.431 Y75.317 E.01018
G1 X99.283 Y75.72 E.01044
G1 X99.047 Y75.937 E.0078
G1 X98.608 Y76.403 E.01557
G1 X98.293 Y76.89 E.01411
G1 X98.171 Y77.23 E.00879
G1 X98.183 Y77.813 E.01418
G1 X98.263 Y78.056 E.00622
G1 X98.626 Y78.622 E.01636
G1 X99.27 Y79.268 E.02219
G1 X99.284 Y82.398 E.07613
G1 X99.426 Y83.268 E.02144
G1 X99.692 Y84.039 E.01984
G1 X100.175 Y84.891 E.02382
G1 X100.868 Y85.679 E.02553
G1 X101.625 Y86.249 E.02305
G1 X102.354 Y86.62 E.0199
G1 X102.927 Y86.809 E.01468
G1 X103.567 Y86.938 E.01588
G1 X104.199 Y86.981 E.01541
G1 X110.517 Y86.981 E.15368
G1 X110.612 Y86.973 E.00232
G1 X111.022 Y86.823 E.01062
G1 X111.223 Y86.648 E.00648
G1 X111.347 Y86.399 E.00677
G1 X119.653 Y86.399 E.20204
G1 X119.684 Y86.485 E.00222
G1 X119.807 Y86.656 E.00512
G1 E-5 F3600
G1 X119.807 Y86.656 F9000
G1 X105.019 Y87.382
G1 E5 F2400
;WIDTH:0.4703
G1 F6000
G1 X105.183 Y87.375 E.00476
;WIDTH:0.456022
G1 X110.517 Y87.375 E.14962
;WIDTH:0.4703
G1 X110.681 Y87.368 E.00476
;WIDTH:0.507536
G1 X110.903 Y87.336 E.00706
;WIDTH:0.536576
G1 X111.293 Y87.163 E.01425
G1 X111.412 Y87.068 E.00509
G1 X111.61 Y86.832 E.01029
G1 X119.39 Y86.832 E.25992
G1 X119.442 Y86.924 E.00353
G1 X119.708 Y87.163 E.01195
G1 X120.098 Y87.335 E.01424
;WIDTH:0.504721
G1 X120.264 Y87.362 E.00526
;WIDTH:0.509012
G1 X119.956 Y87.349 E.00973
;WIDTH:0.536576
G1 X119.648 Y87.335 E.0103
G1 X111.353 Y87.335 E.27713
G1 X111.017 Y87.351 E.01124
;WIDTH:0.503438
G1 X110.741 Y87.365 E.00862
G1 E-5 F3600
G1 X110.741 Y87.365 F9000
G1 X120.264 Y87.362
G1 E5 F2400
;WIDTH:0.481448
G1 F6000
G1 X120.485 Y87.375 E.00658
;WIDTH:0.467118
G1 X125.817 Y87.369 E.1535
;WIDTH:0.494564
G1 X126.043 Y87.383 E.00693
G1 X126.215 Y87.362 E.0053
;WIDTH:0.453602
G1 X126.524 Y87.348 E.00863
;WIDTH:0.426801
G1 X126.833 Y87.334 E.00808
;WIDTH:0.399999
G1 X127.446 Y87.297 E.01494
G1 X127.99 Y87.21 E.0134
G1 X128.526 Y87.054 E.01358
G1 X129.242 Y86.745 E.01897
G1 X130.117 Y86.175 E.0254
G1 X130.684 Y85.648 E.01883
G1 X131.173 Y85.029 E.01919
G1 X131.433 Y84.566 E.01292
G1 X131.743 Y83.934 E.01712
G1 X132.026 Y82.895 E.02619
G1 X132.087 Y82.341 E.01356
G1 X132.095 Y79.429 E.07083
G1 X132.739 Y78.735 E.02303
G1 X133.054 Y78.242 E.01423
G1 X133.193 Y77.825 E.01069
G1 X133.205 Y77.26 E.01375
G1 X133.079 Y76.829 E.01092
G1 X132.643 Y76.132 E.02
G1 X132.108 Y75.583 E.01865
G1 X131.981 Y75.304 E.00746
G1 X135.784 Y75.317 E.0925
G1 X136.606 Y75.432 E.02019
G1 X137.428 Y75.716 E.02115
G1 X138.169 Y76.134 E.02069
G1 X138.822 Y76.678 E.02067
G1 X139.366 Y77.332 E.02069
G1 X139.784 Y78.072 E.02067
G1 X140.061 Y78.876 E.02068
G1 X140.149 Y79.452 E.01417
G1 X140.192 Y80.022 E.0139
G1 X140.194 Y91.822 E.28702
G1 X139.765 Y91.6 E.01175
G1 X139.201 Y91.492 E.01397
G1 X127.896 Y91.492 E.27498
G1 X128.125 Y91.065 E.01179
G1 X128.213 Y90.536 E.01304
G1 X128.177 Y90.141 E.00965
G1 X128.065 Y89.779 E.00922
G1 X127.792 Y89.339 E.0126
G1 X127.508 Y88.985 E.01104
G1 X127.085 Y88.56 E.01459
G1 X127.054 Y88.354 E.00507
G1 X126.843 Y87.918 E.01178
G1 X126.565 Y87.652 E.00936
;WIDTH:0.447282
G1 X126.304 Y87.517 E.00807
;WIDTH:0.494564
G1 X126.097 Y87.41 E.00713
G1 X126.097 Y87.41 F9000
G1 X127.14 Y87.701
;WIDTH:0.399999
G1 F6000
G1 X128.087 Y87.562 E.02328
G1 X128.666 Y87.393 E.01467
G1 X129.438 Y87.054 E.02051
G1 X130.362 Y86.446 E.0269
G1 X130.966 Y85.88 E.02013
G1 X131.492 Y85.209 E.02074
G1 X131.757 Y84.736 E.01319
G1 X132.095 Y84.033 E.01897
G1 X132.389 Y82.939 E.02755
G1 X132.452 Y82.342 E.0146
G1 X132.476 Y79.574 E.06733
G1 X132.847 Y79.194 E.01292
G1 X133.046 Y78.933 E.00798
G1 X133.447 Y78.255 E.01916
G1 X133.575 Y77.751 E.01265
G1 X133.57 Y77.247 E.01226
G1 X133.395 Y76.643 E.0153
G1 X133.084 Y76.114 E.01493
G1 X132.708 Y75.67 E.01415
G1 X135.746 Y75.68 E.0739
G1 X136.513 Y75.787 E.01884
G1 X137.277 Y76.051 E.01966
G1 X137.96 Y76.436 E.01907
G1 X138.562 Y76.938 E.01907
G1 X139.064 Y77.54 E.01907
G1 X139.449 Y78.223 E.01907
G1 X139.705 Y78.964 E.01907
G1 X139.787 Y79.507 E.01336
G1 X139.826 Y80.022 E.01256
G1 X139.828 Y91.239 E.27284
G1 X139.201 Y91.127 E.01549
G1 X128.488 Y91.127 E.26058
G1 X128.577 Y90.503 E.01533
G1 X128.541 Y90.108 E.00965
G1 X128.457 Y89.754 E.00885
G1 X128.352 Y89.546 E.00567
G1 X127.877 Y88.84 E.0207
G1 X127.463 Y88.414 E.01445
G1 X127.315 Y88.015 E.01035
G1 X127.169 Y87.753 E.0073
G1 E-5 F3600
G1 X127.169 Y87.753 F9000
G1 X105.019 Y87.382
G1 E5 F2400
;WIDTH:0.4703
G1 F6000
G1 X104.825 Y87.459 E.00605
;WIDTH:0.432421
G1 X104.289 Y87.767 E.01637
;WIDTH:0.399999
G1 X104.006 Y88.212 E.01283
G1 X103.913 Y88.567 E.00893
G1 X103.713 Y88.756 E.00669
G1 X103.245 Y89.277 E.01703
G1 X102.974 Y89.711 E.01245
G1 X102.816 Y90.14 E.01112
G1 X102.784 Y90.618 E.01165
G1 X102.875 Y91.065 E.0111
G1 X103.1 Y91.492 E.01174
G1 X91.798 Y91.492 E.27491
G1 X91.42 Y91.54 E.00927
G1 X91.083 Y91.663 E.00873
G1 X90.799 Y91.836 E.00809
G1 X90.797 Y80.039 E.28695
G1 X90.834 Y79.433 E.01477
G1 X90.936 Y78.875 E.0138
G1 X91.105 Y78.333 E.01381
G1 X91.338 Y77.815 E.01382
G1 X91.631 Y77.33 E.01378
G1 X91.982 Y76.883 E.01382
G1 X92.383 Y76.482 E.01379
G1 X92.83 Y76.131 E.01382
G1 X93.308 Y75.842 E.01359
G1 X93.798 Y75.63 E.01299
G1 X94.352 Y75.442 E.01423
G1 X95.236 Y75.308 E.02175
G1 X99.036 Y75.308 E.09243
G1 X98.954 Y75.502 E.00512
G1 X98.3 Y76.204 E.02334
G1 X97.986 Y76.692 E.01412
G1 X97.875 Y76.935 E.0065
G1 X97.787 Y77.457 E.01288
G1 X97.837 Y77.967 E.01246
G1 X97.952 Y78.248 E.00739
G1 X98.362 Y78.874 E.0182
G1 X98.905 Y79.43 E.0189
G1 X98.93 Y82.541 E.07567
G1 X99.08 Y83.387 E.0209
G1 X99.347 Y84.158 E.01985
G1 X99.536 Y84.524 E.01002
G1 X99.898 Y85.129 E.01715
G1 X100.648 Y85.971 E.02743
G1 X101.405 Y86.541 E.02305
G1 X101.67 Y86.691 E.00741
G1 X102.237 Y86.967 E.01534
G1 X102.852 Y87.167 E.01573
G1 X103.541 Y87.303 E.01708
G1 X104.199 Y87.347 E.01604
;WIDTH:0.43515
G1 X104.609 Y87.365 E.01094
;WIDTH:0.4703
G1 X104.959 Y87.38 E.01016
G1 X104.959 Y87.38 F9000
G1 X103.894 Y87.694
;WIDTH:0.399999
G1 F6000
G1 X103.704 Y88 E.00876
G1 X103.57 Y88.387 E.00996
G1 X102.935 Y89.083 E.02292
G1 X102.641 Y89.554 E.01351
G1 X102.463 Y90.044 E.01268
G1 X102.418 Y90.618 E.014
G1 X102.512 Y91.127 E.01259
G1 X91.798 Y91.127 E.26061
G1 X91.604 Y91.141 E.00473
G1 X91.164 Y91.251 E.01103
G1 X91.163 Y80.05 E.27245
G1 X91.197 Y79.478 E.01394
G1 X91.292 Y78.963 E.01274
G1 X91.447 Y78.463 E.01273
G1 X91.662 Y77.986 E.01273
G1 X91.933 Y77.538 E.01274
G1 X92.256 Y77.126 E.01273
G1 X92.626 Y76.756 E.01273
G1 X93.038 Y76.433 E.01273
G1 X93.476 Y76.168 E.01245
G1 X93.943 Y75.966 E.01238
G1 X94.433 Y75.8 E.01258
G1 X95.263 Y75.674 E.02042
G1 X98.283 Y75.673 E.07346
G1 X97.993 Y76.006 E.01074
G1 X97.678 Y76.493 E.01411
G1 X97.468 Y77.029 E.014
G1 X97.425 Y77.524 E.01209
G1 X97.48 Y78.046 E.01277
G1 X97.64 Y78.44 E.01034
G1 X98.097 Y79.127 E.02007
G1 X98.54 Y79.589 E.01557
G1 X98.552 Y82.401 E.0684
G1 X98.569 Y82.6 E.00486
G1 X98.735 Y83.507 E.02243
G1 X99.001 Y84.278 E.01984
G1 X99.217 Y84.703 E.0116
G1 X99.62 Y85.367 E.01889
G1 X100.428 Y86.263 E.02935
G1 X101.184 Y86.833 E.02303
G1 X101.505 Y87.018 E.00901
G1 X102.121 Y87.313 E.01661
G1 X102.777 Y87.525 E.01677
G1 X103.341 Y87.644 E.01402
G1 X103.834 Y87.689 E.01204
G1 E-5 F3600
G1 X103.834 Y87.689 F9000
G1 X101.362 Y85.604
G1 X101.254 Y85.512
G1 X101.115 Y85.392
G1 X101.015 Y85.294
G1 X100.884 Y85.164
G1 X100.791 Y85.058
G1 X100.67 Y84.918
G1 X100.583 Y84.805
G1 X100.473 Y84.657
G1 X100.393 Y84.537
G1 X100.294 Y84.38
G1 X100.223 Y84.255
G1 X100.135 Y84.09
G1 X100.073 Y83.961
G1 X99.997 Y83.787
G1 X99.944 Y83.655
G1 X99.882 Y83.476
G1 X99.839 Y83.341
G1 X99.79 Y83.157
G1 X99.757 Y83.022
G1 X98.549 Y77.756
G1 X98.524 Y77.63
G1 X98.515 Y77.5
G1 X98.524 Y77.37
G1 X98.549 Y77.244
G1 X98.589 Y77.124
G1 X98.642 Y77.008
G1 X99.651 Y75.273
G1 X100.092 Y75.273
G1 X100.092 Y74.92
G1 E5 F2400
;WIDTH:0.356236
G1 F6000
G1 X100.183 Y74.916 E.00195
;WIDTH:0.35143
G1 X130.817 Y74.914 E.64617
G1 E-5 F3600
G1 X130.817 Y74.914 F9000
G1 X130.817 Y75.273
G1 X131.349 Y75.273
G1 X132.358 Y77.008
G1 X132.411 Y77.124
G1 X132.451 Y77.244
G1 X132.476 Y77.37
G1 X132.485 Y77.5
G1 X132.476 Y77.63
G1 X132.451 Y77.756
G1 X131.243 Y83.022
G1 X131.21 Y83.157
G1 X131.161 Y83.341
G1 X131.118 Y83.476
G1 X131.056 Y83.655
G1 X131.003 Y83.787
G1 X130.927 Y83.961
G1 X130.865 Y84.09
G1 X130.777 Y84.255
G1 X130.706 Y84.38
G1 X130.607 Y84.537
G1 X130.527 Y84.657
G1 X130.417 Y84.805
G1 X130.33 Y84.918
G1 X130.209 Y85.058
G1 X130.116 Y85.164
G1 X129.985 Y85.294
G1 X129.885 Y85.392
G1 X129.746 Y85.513
G1 X129.638 Y85.604
G1 X129.523 Y85.69
G1 X129.376 Y85.799
G1 X129.253 Y85.878
G1 X129.098 Y85.975
G1 X128.969 Y86.046
G1 X128.806 Y86.132
G1 X128.679 Y86.191
G1 X128.511 Y86.264
G1 X128.38 Y86.314
G1 X128.208 Y86.375
G1 X128.074 Y86.416
G1 X127.897 Y86.463
G1 X127.761 Y86.496
G1 X127.581 Y86.53
G1 X127.443 Y86.553
G1 X127.261 Y86.573
G1 X127.122 Y86.587
G1 X104.651 Y88.151
G1 X91.435 Y92.304
G1 X91.268 Y92.384
G1 X91.163 Y92.46
G1 X91.111 Y92.5
G1 X90.984 Y92.636
G1 X90.882 Y92.791
G1 X90.809 Y92.959
G1 X90.765 Y93.137
G1 X90.758 Y93.221
G1 X90.751 Y93.301
G1 X90.751 Y95.527
G1 X90.758 Y95.607
G1 X90.765 Y95.692
G1 X90.809 Y95.869
G1 X90.882 Y96.038
G1 X90.984 Y96.193
G1 X91.111 Y96.329
G1 X91.163 Y96.368
G1 X91.268 Y96.444
G1 X91.435 Y96.524
G1 X91.606 Y96.572
G1 X91.692 Y96.582
G1 X91.783 Y96.588
G1 X93.04 Y96.589
G1 X93.315 Y96.589
G1 X93.568 Y96.588
G1 X93.569 Y96.971
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.569 Y102.369 E.1313
G1 X91.75 Y102.373 E.04425
G1 X91.245 Y102.528 E.01285
G1 X91.055 Y102.651 E.00551
G1 X90.804 Y102.945 E.0094
;WIDTH:0.439237
G1 X90.701 Y103.144 E.00604
;WIDTH:0.478475
G1 X90.597 Y103.343 E.00663
;WIDTH:0.517712
G1 X90.494 Y103.542 E.00721
G1 X90.474 Y103.315 E.00733
;WIDTH:0.478475
G1 X90.454 Y103.088 E.00673
;WIDTH:0.439237
G1 X90.435 Y102.861 E.00614
;WIDTH:0.399999
G1 X90.434 Y96.727 E.1492
;WIDTH:0.404937
G1 X90.441 Y95.927 E.01972
G1 X90.576 Y96.236 E.00831
;WIDTH:0.399999
G1 X90.848 Y96.584 E.01074
G1 X91.036 Y96.737 E.0059
G1 X91.513 Y96.932 E.01253
G1 X92.001 Y96.971 E.01191
G1 X93.509 Y96.971 E.03668
G1 X93.509 Y96.971 F9000
G1 X93.203 Y97.336
G1 F6000
G1 X93.203 Y102.004 E.11354
G1 X91.749 Y102.008 E.03537
G1 X91.423 Y102.068 E.00806
G1 X91.114 Y102.187 E.00805
G1 X90.8 Y102.39 E.00909
G1 X90.8 Y97.005 E.13098
G1 X91.151 Y97.203 E.0098
G1 X91.483 Y97.296 E.00839
G1 X92.001 Y97.336 E.01264
G1 X93.143 Y97.336 E.02778
G1 X93.143 Y97.336 F9000
G1 X92.837 Y97.702
G1 F6000
G1 X92.837 Y101.639 E.09576
G1 X91.748 Y101.642 E.02649
G1 X91.166 Y101.776 E.01453
G1 X91.165 Y97.58 E.10206
G1 X91.453 Y97.661 E.00728
G1 X92.001 Y97.702 E.01337
G1 X92.777 Y97.702 E.01888
G1 E-5 F3600
G1 X92.777 Y97.702 F9000
G1 X90.519 Y104.645
G1 E5 F2400
;WIDTH:0.567898
G1 F6000
G1 X90.497 Y104.394 E.00894
;WIDTH:0.524777
G1 X90.476 Y104.143 E.00822
;WIDTH:0.517712
G1 X90.494 Y103.542 E.01933
G1 E-5 F3600
G1 X90.494 Y103.542 F9000
G1 X90.927 Y103.617
G1 X90.901 Y103.763
G1 X90.887 Y104
G1 X90.901 Y104.237
G1 X90.948 Y104.507
G1 X91.059 Y104.778
G1 X91.114 Y104.866
G1 X91.26 Y105.038
G1 X91.475 Y105.184
G1 X91.643 Y105.234
G1 X91.766 Y105.249
G1 X92.073 Y105.25
G1 X92.857 Y105.252
G1 X92.856 Y105.63
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.569 Y105.631 E.01734
G1 X93.569 Y110.369 E.11525
G1 X91.75 Y110.373 E.04425
G1 X91.245 Y110.528 E.01285
G1 X91.055 Y110.651 E.00551
G1 X90.804 Y110.945 E.0094
;WIDTH:0.438835
G1 X90.701 Y111.144 E.00603
;WIDTH:0.477671
G1 X90.598 Y111.343 E.00661
;WIDTH:0.516506
G1 X90.494 Y111.542 E.0072
G1 X90.475 Y111.315 E.00731
;WIDTH:0.477671
G1 X90.455 Y111.088 E.00672
;WIDTH:0.438835
G1 X90.436 Y110.862 E.0061
;WIDTH:0.399999
G1 X90.435 Y105.184 E.13811
;WIDTH:0.441974
G1 X90.456 Y105.049 E.0037
;WIDTH:0.483949
G1 X90.477 Y104.914 E.00409
;WIDTH:0.525924
G1 X90.498 Y104.779 E.00447
;WIDTH:0.567898
G1 X90.519 Y104.645 E.00481
G1 X90.575 Y104.733 E.0037
;WIDTH:0.521458
G1 X90.63 Y104.822 E.00339
;WIDTH:0.475018
G1 X90.796 Y105.036 E.00794
;WIDTH:0.437509
G1 X90.961 Y105.25 E.00725
;WIDTH:0.399999
G1 X91.239 Y105.466 E.00856
G1 X91.439 Y105.564 E.00542
G1 X91.75 Y105.627 E.00772
G1 X92.796 Y105.629 E.02544
G1 X92.796 Y105.629 F9000
G1 X93.065 Y105.996
G1 F6000
G1 X93.203 Y105.996 E.00336
G1 X93.203 Y110.004 E.09749
G1 X91.749 Y110.008 E.03537
G1 X91.424 Y110.068 E.00804
G1 X91.114 Y110.187 E.00808
G1 X90.802 Y110.389 E.00904
G1 X90.801 Y105.588 E.11678
G1 X91.015 Y105.755 E.0066
G1 X91.348 Y105.918 E.00902
G1 X91.749 Y105.992 E.00992
G1 X93.005 Y105.996 E.03055
G1 X93.005 Y105.996 F9000
G1 X92.656 Y106.36
G1 F6000
G1 X92.837 Y106.361 E.0044
G1 X92.837 Y109.639 E.07973
G1 X91.748 Y109.642 E.02649
G1 X91.167 Y109.775 E.0145
G1 X91.167 Y106.228 E.08628
G1 X91.257 Y106.273 E.00245
G1 X91.748 Y106.358 E.01212
G1 X92.596 Y106.36 E.02063
G1 X92.596 Y106.36 F9000
G1 X91.276 Y107.239
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X91.883 Y106.633 E.02086
G1 X92.463 Y106.634 E.01411
G1 X91.441 Y107.656 E.03516
G1 X91.441 Y108.237 E.01413
G1 X92.563 Y107.115 E.0386
G1 X92.563 Y107.696 E.01413
G1 X91.441 Y108.818 E.0386
G1 X91.441 Y109.399 E.01413
G1 X92.563 Y108.278 E.03858
G1 X92.563 Y108.859 E.01413
G1 X91.89 Y109.532 E.02315
G1 E-5 F3600
G1 X91.89 Y109.532 F9000
G1 X91.059 Y111.222
G1 X90.948 Y111.493
G1 X90.901 Y111.763
G1 X90.887 Y112
G1 X90.901 Y112.237
G1 X91.278 Y115.239
G1 E5 F2400
G1 F3072.127
G1 X91.884 Y114.633 E.02085
G1 X92.464 Y114.634 E.01411
G1 X91.442 Y115.656 E.03516
G1 X91.442 Y116.237 E.01413
G1 X92.563 Y115.116 E.03856
G1 X92.563 Y115.697 E.01413
G1 X91.442 Y116.818 E.03856
G1 X91.443 Y117.399 E.01413
G1 X92.563 Y116.278 E.03854
G1 X92.563 Y116.859 E.01413
G1 X91.89 Y117.532 E.02315
G1 E-5 F3600
G1 X91.89 Y117.532 F9000
G1 X91.059 Y119.222
G1 X90.948 Y119.493
G1 X90.901 Y119.763
G1 X90.887 Y120
G1 X90.901 Y120.237
G1 X91.279 Y123.239
G1 E5 F2400
G1 F3072.127
G1 X91.885 Y122.633 E.02085
G1 X92.465 Y122.634 E.01411
G1 X91.443 Y123.656 E.03516
G1 X91.444 Y124.236 E.01411
G1 X92.563 Y123.117 E.03849
G1 X92.563 Y123.698 E.01413
G1 X91.444 Y124.817 E.03849
G1 X91.444 Y125.398 E.01413
G1 X92.563 Y124.279 E.03849
G1 X92.563 Y124.859 E.01411
G1 X91.891 Y125.532 E.02313
G1 E-5 F3600
G1 X91.891 Y125.532 F9000
G1 X91.059 Y127.222
G1 X90.948 Y127.493
G1 X90.901 Y127.763
G1 X90.887 Y128
G1 X90.901 Y128.237
G1 X90.948 Y128.507
G1 X91.059 Y128.778
G1 X91.96 Y130.468
G1 E5 F2400
G1 F3072.127
G1 X91.445 Y130.984 E.01773
G1 X91.445 Y131.504 E.01265
G1 X92.315 Y130.634 E.02993
G1 X92.564 Y130.635 E.00606
G1 X92.564 Y130.905 E.00657
G1 X91.445 Y132.025 E.03851
G1 X91.445 Y132.545 E.01265
G1 X92.564 Y131.425 E.03851
G1 X92.565 Y131.946 E.01267
G1 X91.445 Y133.065 E.03851
G1 X91.445 Y133.419 E.00861
G1 X91.645 Y133.386 E.00493
G1 X92.565 Y132.466 E.03165
G1 X92.577 Y132.974 E.01236
G1 X92.024 Y133.527 E.01902
G1 E-5 F3600
G1 X92.024 Y133.527 F9000
G1 X91.059 Y135.222
G1 X90.948 Y135.493
G1 X90.901 Y135.763
G1 X90.887 Y136
G1 X90.901 Y136.237
G1 X91.281 Y139.166
G1 E5 F2400
G1 F3072.127
G1 X91.809 Y138.638 E.01816
G1 X92.359 Y138.638 E.01338
G1 X91.446 Y139.551 E.03141
G1 X91.446 Y140.101 E.01338
G1 X92.908 Y138.639 E.05029
G1 X93.458 Y138.639 E.01338
G1 X91.446 Y140.651 E.06921
G1 X91.446 Y140.911 E.00632
G1 X91.808 Y140.838 E.00898
G1 X94.007 Y138.64 E.07563
G1 X94.211 Y138.64 E.00496
G1 X94.339 Y138.858 E.00615
G1 X92.359 Y140.838 E.06811
G1 X92.91 Y140.837 E.0134
G1 X94.558 Y139.189 E.05669
G1 X94.776 Y139.52 E.00964
G1 X93.461 Y140.836 E.04525
G1 X94.012 Y140.835 E.0134
G1 X95.013 Y139.834 E.03443
G1 X95.252 Y140.145 E.00954
G1 X94.562 Y140.834 E.02372
G1 X95.113 Y140.834 E.0134
G1 X95.511 Y140.436 E.01369
G1 X95.769 Y140.727 E.00946
G1 X95.499 Y140.997 E.00929
G1 E-5 F3600
G1 X95.499 Y140.997 F9000
G1 X91.511 Y141.343
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.558216
G1 F1200
G1 X91.804 Y141.283 E.01042
;WIDTH:0.562138
G1 X96.201 Y141.279 E.15438
G1 E-5 F3600
G1 X96.201 Y141.279 F9000
G1 X91.475 Y142.816
G1 X91.26 Y142.962
G1 X91.114 Y143.134
G1 X91.059 Y143.222
G1 X90.948 Y143.493
G1 X90.901 Y143.763
G1 X90.887 Y144
G1 X90.901 Y144.237
G1 X91.283 Y147.656
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X91.768 Y147.171 E.01668
G1 X92.283 Y147.173 E.01253
G1 X91.447 Y148.009 E.02876
G1 X91.447 Y148.526 E.01258
G1 X92.801 Y147.173 E.04656
G1 X93.318 Y147.173 E.01258
G1 X91.639 Y148.852 E.05776
G1 X92.179 Y148.829 E.01315
G1 X93.836 Y147.172 E.057
G1 X94.354 Y147.172 E.0126
G1 X92.697 Y148.829 E.057
G1 X93.214 Y148.829 E.01258
G1 X94.871 Y147.172 E.057
G1 X95.389 Y147.172 E.0126
G1 X93.732 Y148.829 E.057
G1 X94.25 Y148.829 E.0126
G1 X95.907 Y147.172 E.057
G1 X96.425 Y147.171 E.0126
G1 X94.767 Y148.828 E.05702
G1 X95.285 Y148.828 E.0126
G1 X96.942 Y147.171 E.057
G1 X97.46 Y147.171 E.0126
G1 X95.803 Y148.828 E.057
G1 X96.32 Y148.828 E.01258
G1 X97.978 Y147.171 E.05702
G1 X98.495 Y147.171 E.01258
G1 X96.838 Y148.828 E.057
G1 X97.356 Y148.828 E.0126
G1 X99.013 Y147.17 E.05702
G1 X99.531 Y147.17 E.0126
G1 X97.873 Y148.827 E.05702
G1 X98.391 Y148.827 E.0126
G1 X100.048 Y147.17 E.057
G1 X100.566 Y147.17 E.0126
G1 X98.909 Y148.827 E.057
G1 X99.426 Y148.827 E.01258
G1 X101.084 Y147.17 E.05702
G1 X101.602 Y147.169 E.0126
G1 X99.944 Y148.827 E.05703
G1 X100.462 Y148.827 E.0126
G1 X102.119 Y147.169 E.05702
G1 X102.637 Y147.169 E.0126
G1 X100.979 Y148.827 E.05703
G1 X101.497 Y148.826 E.0126
G1 X103.155 Y147.169 E.05702
G1 X103.672 Y147.169 E.01258
G1 X102.015 Y148.826 E.057
G1 X102.533 Y148.826 E.0126
G1 X104.19 Y147.168 E.05702
G1 X104.708 Y147.168 E.0126
G1 X103.05 Y148.826 E.05703
G1 X103.568 Y148.826 E.0126
G1 X105.226 Y147.168 E.05703
G1 X105.785 Y147.126 E.01364
G1 X104.086 Y148.826 E.05846
G1 X104.603 Y148.825 E.01258
G1 X108.896 Y144.533 E.14766
G1 X109.414 Y144.532 E.0126
G1 X105.121 Y148.825 E.14768
G1 X105.619 Y148.845 E.01212
G1 X109.933 Y144.531 E.1484
G1 X110.451 Y144.53 E.0126
G1 X106.033 Y148.948 E.15198
G1 X106.39 Y149.109 E.00953
G1 X111.044 Y144.455 E.16009
G1 X111.502 Y144.246 E.01225
G1 X111.852 Y143.963 E.01095
G1 X112.054 Y143.963 E.00491
G1 X106.69 Y149.326 E.1845
G1 X106.943 Y149.591 E.00891
G1 X112.571 Y143.963 E.1936
G1 X113.089 Y143.963 E.0126
G1 X107.144 Y149.907 E.20449
G1 X107.287 Y150.281 E.00974
G1 X113.606 Y143.963 E.21735
G1 X114.124 Y143.963 E.0126
G1 X107.19 Y150.896 E.23851
G1 X107.235 Y151.369 E.01156
G1 X114.641 Y143.963 E.25476
G1 X115.159 Y143.963 E.0126
G1 X107.236 Y151.885 E.27253
G1 X107.237 Y152.402 E.01258
G1 X115.676 Y143.963 E.2903
G1 X116.194 Y143.963 E.0126
G1 X107.21 Y152.946 E.30903
G1 X107.099 Y153.396 E.01127
G1 X107.213 Y153.46 E.00318
G1 X116.711 Y143.963 E.32671
G1 X117.229 Y143.963 E.0126
G1 X106.156 Y155.035 E.38089
G1 X106.653 Y155.056 E.0121
G1 X117.746 Y143.963 E.38159
G1 X118.264 Y143.963 E.0126
G1 X107.17 Y155.056 E.38161
G1 X107.688 Y155.056 E.0126
G1 X118.781 Y143.963 E.38159
G1 X119.149 Y143.963 E.00895
G1 X119.212 Y144.049 E.00259
G1 X108.206 Y155.056 E.37862
G1 X108.723 Y155.056 E.01258
G1 X119.52 Y144.258 E.37143
G1 X119.874 Y144.422 E.00949
G1 X109.241 Y155.056 E.36579
G1 X109.758 Y155.056 E.01258
G1 X120.288 Y144.526 E.36223
G1 X120.802 Y144.529 E.0125
G1 X110.276 Y155.056 E.36211
G1 X110.793 Y155.055 E.01258
G1 X121.318 Y144.531 E.36204
G1 X121.835 Y144.532 E.01258
G1 X111.311 Y155.055 E.362
G1 X111.828 Y155.055 E.01258
G1 X122.351 Y144.533 E.36197
G1 X122.867 Y144.534 E.01255
G1 X112.346 Y155.055 E.36192
G1 X112.863 Y155.055 E.01258
G1 X123.384 Y144.535 E.3619
G1 X123.763 Y144.536 E.00922
G1 X123.763 Y144.673 E.00333
G1 X113.381 Y155.055 E.35713
G1 X113.899 Y155.055 E.0126
G1 X123.828 Y145.125 E.34157
G1 X123.912 Y145.389 E.00674
G1 X123.644 Y145.52 E.00726
G1 X123.721 Y145.751 E.00592
G1 X114.416 Y155.055 E.32007
G1 X114.934 Y155.055 E.0126
G1 X123.87 Y146.119 E.30739
G1 X124.079 Y146.427 E.00905
G1 X115.451 Y155.055 E.2968
G1 X115.969 Y155.055 E.0126
G1 X124.33 Y146.693 E.28763
G1 X124.634 Y146.907 E.00904
G1 X116.486 Y155.055 E.28029
G1 X117.004 Y155.055 E.0126
G1 X124.996 Y147.063 E.27492
G1 X125.427 Y147.15 E.0107
G1 X117.521 Y155.055 E.27194
G1 X118.039 Y155.055 E.0126
G1 X125.919 Y147.175 E.27107
G1 X126.437 Y147.175 E.0126
G1 X118.392 Y155.219 E.27673
G1 E-5 F3600
G1 X118.392 Y155.219 F9000
G1 X124.946 Y154.876
G1 E5 F2400
G1 F3072.127
G1 X124.767 Y155.054 E.00614
G1 X124.25 Y155.054 E.01258
G1 X124.508 Y154.796 E.00888
G1 X124.21 Y154.576 E.00901
G1 X123.732 Y155.054 E.01644
G1 X123.214 Y155.054 E.0126
G1 X123.987 Y154.282 E.02657
G1 X123.801 Y153.95 E.00926
G1 X122.697 Y155.055 E.03799
G1 X122.179 Y155.055 E.0126
G1 X123.883 Y153.351 E.05862
G1 X123.788 Y152.929 E.01052
G1 X121.662 Y155.055 E.07313
G1 X121.144 Y155.055 E.0126
G1 X123.763 Y152.436 E.09009
G1 X123.763 Y151.918 E.0126
G1 X120.627 Y155.055 E.10789
G1 X120.109 Y155.055 E.0126
G1 X123.763 Y151.401 E.1257
G1 X123.831 Y150.815 E.01435
G1 X119.592 Y155.055 E.14584
G1 X119.074 Y155.055 E.0126
G1 X123.64 Y150.489 E.15707
G1 X123.838 Y149.936 E.01429
G1 X124.169 Y149.458 E.01414
G1 X124.66 Y149.075 E.01515
G1 X125.256 Y148.873 E.01531
G1 X126.954 Y147.175 E.05841
G1 X127.472 Y147.175 E.0126
G1 X125.821 Y148.825 E.05678
G1 X126.339 Y148.825 E.0126
G1 X127.989 Y147.175 E.05676
G1 X128.507 Y147.175 E.0126
G1 X126.856 Y148.826 E.05679
G1 X127.373 Y148.826 E.01258
G1 X129.024 Y147.174 E.05681
G1 X129.542 Y147.174 E.0126
G1 X127.891 Y148.826 E.05681
G1 X128.408 Y148.826 E.01258
G1 X130.06 Y147.174 E.05683
G1 X130.577 Y147.174 E.01258
G1 X128.925 Y148.826 E.05683
G1 X129.443 Y148.826 E.0126
G1 X131.095 Y147.174 E.05683
G1 X131.612 Y147.174 E.01258
G1 X129.96 Y148.826 E.05683
G1 X130.477 Y148.827 E.01258
G1 X132.13 Y147.174 E.05686
G1 X132.647 Y147.174 E.01258
G1 X130.995 Y148.827 E.05685
G1 X131.512 Y148.827 E.01258
G1 X133.165 Y147.174 E.05686
G1 X133.683 Y147.174 E.0126
G1 X132.029 Y148.827 E.05688
G1 X132.547 Y148.827 E.0126
G1 X134.2 Y147.174 E.05686
G1 X134.718 Y147.174 E.0126
G1 X133.064 Y148.827 E.05688
G1 X133.581 Y148.828 E.01258
G1 X135.235 Y147.174 E.0569
G1 X135.753 Y147.174 E.0126
G1 X134.099 Y148.828 E.0569
G1 X134.616 Y148.828 E.01258
G1 X136.27 Y147.174 E.0569
G1 X136.788 Y147.173 E.0126
G1 X135.133 Y148.828 E.05693
G1 X135.651 Y148.828 E.0126
G1 X137.306 Y147.173 E.05693
G1 X137.823 Y147.173 E.01258
G1 X136.168 Y148.828 E.05693
G1 X136.685 Y148.829 E.01258
G1 X138.341 Y147.173 E.05697
G1 X138.858 Y147.173 E.01258
G1 X137.203 Y148.829 E.05695
G1 X137.72 Y148.829 E.01258
G1 X139.4 Y147.149 E.05779
G1 X139.561 Y147.129 E.00395
G1 X139.561 Y147.505 E.00915
G1 X138.237 Y148.829 E.04554
G1 X138.755 Y148.829 E.0126
G1 X139.561 Y148.023 E.02773
G1 X139.561 Y148.54 E.01258
G1 X139.108 Y148.994 E.0156
G1 E-5 F3600
G1 X139.108 Y148.994 F9000
G1 X140.052 Y144.507
G1 X140.113 Y144
G1 X139.118 Y141.003
G1 E5 F2400
G1 F3072.127
G1 X139.56 Y140.56 E.01522
G1 X139.56 Y140.037 E.01272
G1 X138.759 Y140.838 E.02755
G1 X138.236 Y140.837 E.01272
G1 X139.56 Y139.513 E.04554
G1 X139.56 Y138.99 E.01272
G1 X137.714 Y140.836 E.0635
G1 X137.191 Y140.835 E.01272
G1 X139.424 Y138.603 E.0768
G1 X138.865 Y138.638 E.01362
G1 X136.668 Y140.835 E.07558
G1 X136.145 Y140.834 E.01272
G1 X138.341 Y138.638 E.07554
G1 X137.817 Y138.639 E.01275
G1 X135.622 Y140.833 E.07549
G1 X135.138 Y140.832 E.01177
G1 X137.457 Y138.475 E.08043
G1 E-5 F3600
G1 X137.457 Y138.475 F9000
G1 X134.806 Y141.279
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.562006
G1 F1200
G1 X139.2 Y141.285 E.15423
;WIDTH:0.553864
G1 X139.494 Y141.345 E.01037
G1 E-5 F3600
G1 X139.494 Y141.345 F9000
G1 X140.099 Y136.237
G1 X140.113 Y136
G1 X140.052 Y135.493
G1 X139.941 Y135.222
G1 X139.076 Y133.533
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X139.559 Y133.05 E.01661
G1 X139.559 Y132.529 E.01267
G1 X138.722 Y133.366 E.02879
G1 X138.398 Y133.364 E.00788
G1 X138.408 Y133.16 E.00497
G1 X139.559 Y132.009 E.03959
G1 X139.559 Y131.489 E.01265
G1 X138.437 Y132.611 E.0386
G1 X138.437 Y132.091 E.01265
G1 X139.559 Y130.968 E.03861
G1 X139.559 Y130.577 E.00951
G1 X139.401 Y130.606 E.00391
G1 X138.437 Y131.57 E.03316
G1 X138.437 Y131.05 E.01265
G1 X139.018 Y130.468 E.02
G1 E-5 F3600
G1 X139.018 Y130.468 F9000
G1 X139.941 Y128.778
G1 X140.052 Y128.507
G1 X140.099 Y128.237
G1 X140.113 Y128
G1 X140.099 Y127.763
G1 X140.052 Y127.493
G1 X139.941 Y127.222
G1 X139.065 Y125.532
G1 E5 F2400
G1 F3072.127
G1 X139.558 Y125.038 E.01698
G1 X139.558 Y124.52 E.0126
G1 X138.712 Y125.366 E.0291
G1 X138.437 Y125.366 E.00669
G1 X138.437 Y125.122 E.00594
G1 X139.558 Y124.001 E.03856
G1 X139.558 Y123.482 E.01262
G1 X138.437 Y124.604 E.03858
G1 X138.437 Y124.085 E.01262
G1 X139.558 Y122.964 E.03856
G1 X139.558 Y122.577 E.00941
G1 X139.396 Y122.607 E.00401
G1 X138.437 Y123.566 E.03299
G1 X138.437 Y123.047 E.01262
G1 X139.016 Y122.468 E.01992
G1 E-5 F3600
G1 X139.016 Y122.468 F9000
G1 X139.941 Y120.778
G1 X140.052 Y120.507
G1 X140.113 Y120
G1 X138.955 Y117.531
G1 E5 F2400
G1 F3072.127
G1 X139.557 Y116.93 E.02069
G1 X139.557 Y116.348 E.01416
G1 X138.539 Y117.366 E.03502
G1 X138.437 Y117.366 E.00248
G1 X138.437 Y116.887 E.01165
G1 X139.557 Y115.767 E.03853
G1 X139.557 Y115.185 E.01416
G1 X138.437 Y116.305 E.03853
G1 X138.437 Y115.723 E.01416
G1 X139.557 Y114.577 E.03898
G1 X138.945 Y114.633 E.01495
G1 X138.272 Y115.306 E.02315
G1 E-5 F3600
G1 X138.272 Y115.306 F9000
G1 X139.886 Y112.866
G1 X139.941 Y112.778
G1 X140.052 Y112.507
G1 X140.113 Y112
G1 X138.954 Y109.531
G1 E5 F2400
G1 F3072.127
G1 X139.556 Y108.93 E.02069
G1 X139.556 Y108.348 E.01416
G1 X138.538 Y109.366 E.03502
G1 X138.437 Y109.366 E.00246
G1 X138.437 Y108.886 E.01168
G1 X139.556 Y107.767 E.03849
G1 X139.556 Y107.185 E.01416
G1 X138.437 Y108.304 E.03849
G1 X138.437 Y107.723 E.01413
G1 X139.556 Y106.577 E.03896
G1 X138.945 Y106.633 E.01492
G1 X138.272 Y107.306 E.02315
G1 E-5 F3600
G1 X138.272 Y107.306 F9000
G1 X139.886 Y104.866
G1 X139.941 Y104.778
G1 X140.052 Y104.507
G1 X140.113 Y104
G1 X139.029 Y101.532
G1 E5 F2400
G1 F3072.127
G1 X139.555 Y101.005 E.01811
G1 X139.555 Y100.474 E.01292
G1 X138.663 Y101.366 E.03068
G1 X138.437 Y101.366 E.0055
G1 X138.437 Y101.061 E.00742
G1 X139.555 Y99.943 E.03846
G1 X139.555 Y99.413 E.01289
G1 X138.437 Y100.531 E.03846
G1 X138.437 Y100 E.01292
G1 X139.555 Y98.882 E.03846
G1 X139.555 Y98.351 E.01292
G1 X138.437 Y99.469 E.03846
G1 X138.437 Y98.938 E.01292
G1 X139.423 Y97.951 E.03394
G1 X138.868 Y97.976 E.01351
G1 X138.272 Y98.571 E.02048
G1 E-5 F3600
G1 X138.272 Y98.571 F9000
G1 X140.017 Y96.193
G1 X140.118 Y96.038
G1 X140.191 Y95.869
G1 X140.236 Y95.692
G1 X140.243 Y95.607
G1 X140.249 Y95.527
G1 X140.249 Y93.301
G1 X140.243 Y93.221
G1 X140.236 Y93.137
G1 X140.191 Y92.959
G1 X140.118 Y92.791
G1 X139.044 Y91.017
G1 E5 F2400
G1 F3072.127
G1 X139.554 Y90.507 E.01754
G1 X139.554 Y89.981 E.01279
G1 X138.682 Y90.852 E.02998
G1 X138.156 Y90.852 E.01279
G1 X139.553 Y89.455 E.04806
G1 X139.553 Y88.928 E.01282
G1 X137.629 Y90.852 E.06618
G1 X137.103 Y90.852 E.01279
G1 X139.553 Y88.402 E.08428
G1 X139.553 Y87.876 E.01279
G1 X136.577 Y90.852 E.10237
G1 X136.05 Y90.852 E.01282
G1 X139.553 Y87.35 E.12048
G1 X139.553 Y86.823 E.01282
G1 X135.524 Y90.852 E.1386
G1 X134.998 Y90.852 E.01279
G1 X139.553 Y86.297 E.15669
G1 X139.553 Y85.771 E.01279
G1 X134.471 Y90.852 E.1748
G1 X133.945 Y90.852 E.01279
G1 X139.553 Y85.244 E.19291
G1 X139.553 Y84.718 E.01279
G1 X133.419 Y90.852 E.21101
G1 X132.892 Y90.852 E.01282
G1 X139.553 Y84.192 E.22912
G1 X139.553 Y83.665 E.01282
G1 X132.366 Y90.852 E.24723
G1 X131.839 Y90.852 E.01282
G1 X139.553 Y83.139 E.26534
G1 X139.553 Y82.613 E.01279
G1 X131.313 Y90.852 E.28343
G1 X130.787 Y90.852 E.01279
G1 X139.552 Y82.087 E.30151
G1 X139.552 Y81.56 E.01282
G1 X130.26 Y90.852 E.31964
G1 X129.734 Y90.852 E.01279
G1 X139.552 Y81.034 E.33773
G1 X139.552 Y80.508 E.01279
G1 X129.208 Y90.852 E.35583
G1 X128.816 Y90.852 E.00954
G1 X128.83 Y90.703 E.00364
G1 X139.552 Y79.981 E.36883
G1 X139.509 Y79.499 E.01177
G1 X128.823 Y90.184 E.36757
G1 X128.735 Y89.746 E.01087
G1 X139.439 Y79.042 E.36821
G1 X139.306 Y78.649 E.01009
G1 X128.573 Y89.382 E.36921
G1 X128.369 Y89.059 E.00929
G1 X139.16 Y78.268 E.3712
G1 X138.97 Y77.932 E.00939
G1 X131.935 Y84.966 E.24198
G1 X132.241 Y84.403 E.01559
G1 X132.395 Y83.98 E.01095
G1 X138.765 Y77.61 E.21912
G1 X138.526 Y77.323 E.00908
G1 X132.603 Y83.246 E.20375
G1 X132.701 Y82.622 E.01536
G1 X138.271 Y77.052 E.1916
G1 X137.984 Y76.813 E.00908
G1 X132.719 Y82.078 E.18111
G1 X132.722 Y81.548 E.01289
G1 X137.678 Y76.592 E.17048
G1 X137.342 Y76.402 E.00939
G1 X132.726 Y81.018 E.15879
G1 X132.729 Y80.488 E.01289
G1 X136.979 Y76.238 E.1462
G1 X136.588 Y76.103 E.01006
G1 X132.733 Y79.958 E.13261
G1 X132.734 Y79.702 E.00623
G1 X133.235 Y79.147 E.01819
G1 X133.606 Y78.559 E.01691
G1 X136.163 Y76.002 E.08796
G1 X135.685 Y75.953 E.01169
G1 X133.846 Y77.792 E.06326
G1 X133.844 Y77.267 E.01277
G1 X135.16 Y75.951 E.04527
G1 X134.636 Y75.949 E.01275
G1 X133.735 Y76.851 E.03101
G1 X133.603 Y76.456 E.01013
G1 X134.111 Y75.948 E.01747
G1 X133.587 Y75.946 E.01275
G1 X133.288 Y76.245 E.01029
G1 E-5 F3600
G1 X133.288 Y76.245 F9000
G1 X131.161 Y83.341
G1 X131.118 Y83.476
G1 X131.056 Y83.655
G1 X131.003 Y83.787
G1 X130.927 Y83.961
G1 X130.865 Y84.09
G1 X130.777 Y84.255
G1 X130.706 Y84.38
G1 X130.607 Y84.537
G1 X130.527 Y84.657
G1 X130.417 Y84.805
G1 X130.33 Y84.918
G1 X128.208 Y87.641
G1 E5 F2400
G1 F3072.127
G1 X127.661 Y88.188 E.01882
G1 X127.898 Y88.477 E.00909
G1 X128.712 Y87.664 E.02798
G1 X129.69 Y87.212 E.02621
G1 X128.037 Y88.865 E.05686
G1 E-5 F3600
G1 X128.037 Y88.865 F9000
G1 X126.349 Y88.151
G1 X104.651 Y88.151
G1 X101.625 Y91.017
G1 E5 F2400
G1 F3072.127
G1 X102.144 Y90.498 E.01785
G1 X102.219 Y89.902 E.01461
G1 X101.269 Y90.852 E.03268
G1 X100.75 Y90.852 E.01262
G1 X103.317 Y88.25 E.08891
G1 X103.436 Y87.931 E.00828
G1 X103.19 Y87.892 E.00606
G1 X100.23 Y90.852 E.10182
G1 X99.71 Y90.852 E.01265
G1 X102.762 Y87.8 E.10499
G1 X102.361 Y87.682 E.01017
G1 X99.19 Y90.852 E.10906
G1 X98.67 Y90.852 E.01265
G1 X101.976 Y87.547 E.11371
G1 X101.625 Y87.378 E.00948
G1 X98.151 Y90.852 E.1195
G1 X97.631 Y90.852 E.01265
G1 X101.275 Y87.208 E.12535
G1 X100.958 Y87.006 E.00914
G1 X97.111 Y90.852 E.13232
G1 X96.591 Y90.852 E.01265
G1 X100.661 Y86.782 E.14001
G1 X100.365 Y86.559 E.00901
G1 X96.071 Y90.852 E.14769
G1 X95.552 Y90.852 E.01262
G1 X100.087 Y86.317 E.156
G1 X99.84 Y86.044 E.00896
G1 X95.032 Y90.852 E.16539
G1 X94.512 Y90.852 E.01265
G1 X99.6 Y85.765 E.17501
G1 X99.365 Y85.48 E.00899
G1 X93.992 Y90.852 E.18481
G1 X93.472 Y90.852 E.01265
G1 X99.162 Y85.163 E.19572
G1 X98.974 Y84.831 E.00928
G1 X92.953 Y90.852 E.20712
G1 X92.433 Y90.852 E.01265
G1 X98.796 Y84.489 E.21888
G1 X98.654 Y84.112 E.0098
G1 X91.913 Y90.852 E.23187
G1 X91.439 Y90.893 E.01157
G1 X91.439 Y90.807 E.00209
G1 X98.52 Y83.725 E.2436
G1 X98.408 Y83.318 E.01027
G1 X91.438 Y90.287 E.23975
G1 X91.438 Y89.768 E.01262
G1 X98.335 Y82.871 E.23725
G1 X98.278 Y82.408 E.01135
G1 X91.438 Y89.248 E.23529
G1 X91.438 Y88.728 E.01265
G1 X98.276 Y81.89 E.23522
G1 X98.274 Y81.373 E.01258
G1 X91.438 Y88.209 E.23515
G1 X91.438 Y87.689 E.01265
G1 X98.272 Y80.855 E.23509
G1 X98.269 Y80.338 E.01258
G1 X91.438 Y87.169 E.23498
G1 X91.438 Y86.649 E.01265
G1 X98.267 Y79.82 E.23491
G1 X98.267 Y79.701 E.00289
G1 X98.071 Y79.496 E.0069
G1 X91.438 Y86.13 E.22819
G1 X91.438 Y85.61 E.01265
G1 X97.826 Y79.222 E.21974
G1 X97.613 Y78.914 E.00911
G1 X91.438 Y85.09 E.21243
G1 X91.438 Y84.571 E.01262
G1 X97.418 Y78.59 E.20573
G1 X97.25 Y78.239 E.00947
G1 X91.437 Y84.051 E.19995
G1 X91.437 Y83.531 E.01265
G1 X97.173 Y77.795 E.19731
G1 X97.17 Y77.279 E.01255
G1 X91.437 Y83.011 E.19719
G1 X91.437 Y82.492 E.01262
G1 X97.332 Y76.597 E.20278
G1 X97.704 Y75.948 E.0182
G1 X97.462 Y75.948 E.00589
G1 X91.437 Y81.972 E.20724
G1 X91.437 Y81.452 E.01265
G1 X96.942 Y75.948 E.18935
G1 X96.422 Y75.948 E.01265
G1 X91.437 Y80.933 E.17148
G1 X91.437 Y80.413 E.01265
G1 X95.902 Y75.948 E.15359
G1 X95.382 Y75.948 E.01265
G1 X91.448 Y79.883 E.13534
G1 X91.508 Y79.302 E.01421
G1 X94.787 Y76.024 E.11278
G1 X94.089 Y76.202 E.01752
G1 X91.693 Y78.598 E.08242
G1 X92.159 Y77.694 E.02474
G1 X92.457 Y77.314 E.01175
G1 X93.472 Y76.299 E.03492
G1 E-5 F3600
G1 X93.472 Y76.299 F9000
G1 X90.765 Y93.137
G1 X90.758 Y93.221
G1 X90.751 Y93.301
G1 X90.751 Y95.527
G1 X90.758 Y95.607
G1 X90.765 Y95.692
G1 X91.275 Y98.514
G1 E5 F2400
G1 F3072.127
G1 X91.826 Y97.963 E.01895
G1 X92.343 Y97.976 E.01258
G1 X91.44 Y98.88 E.03108
G1 X91.44 Y99.409 E.01287
G1 X92.563 Y98.286 E.03863
G1 X92.563 Y98.816 E.01289
G1 X91.44 Y99.939 E.03863
G1 X91.44 Y100.469 E.01289
G1 X92.563 Y99.346 E.03863
G1 X92.563 Y99.876 E.01289
G1 X91.44 Y100.999 E.03863
G1 X91.44 Y101.423 E.01031
G1 X91.57 Y101.399 E.00322
G1 X92.563 Y100.406 E.03416
G1 X92.563 Y100.936 E.01289
G1 X91.967 Y101.532 E.0205
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X92.563 Y100.936 E-.40036
G1 X92.563 Y100.406 E-.25175
G1 X91.57 Y101.399 E-.66705
G1 X91.44 Y101.423 E-.06279
G1 X91.44 Y101.174 E-.11805
;WIPE_END
G1 X90.948 Y103.493 F9000
G1 X90.901 Y103.763
G1 X90.887 Y104
G1 X90.887 Y136
G1 X90.901 Y136.237
G1 X90.948 Y136.507
G1 X91.059 Y136.778
G1 X91.114 Y136.866
G1 X91.26 Y137.038
G1 X91.475 Y137.184
G1 X99.126 Y141.676
G1 X99.384 Y141.825
G1 X99.614 Y141.948
G1 X99.683 Y141.984
G1 X99.753 Y142.02
G1 X99.825 Y142.056
G1 X99.897 Y142.091
G1 X100.043 Y142.16
G1 X100.113 Y142.193
G1 X100.185 Y142.226
G1 X100.262 Y142.26
G1 X100.355 Y142.3
G1 X100.447 Y142.339
G1 X100.534 Y142.375
G1 X100.751 Y142.45
G1 X100.778 Y142.456
G1 X101.962 Y142.689
G1 X102.127 Y142.72
G1 X102.518 Y142.787
G1 X102.915 Y142.847
G1 X103.311 Y142.897
G1 X103.707 Y142.933
G1 X106.537 Y143.149
G1 X107.505 Y144.371
G1 E5 F2400
G1 F3072.127
G1 X107.237 Y144.639 E.00922
G1 X107.155 Y145.239 E.01473
G1 X107.859 Y144.535 E.02422
G1 X108.377 Y144.534 E.0126
G1 X107.079 Y145.832 E.04465
G1 X107.079 Y145.832 F9000
G1 X106.934 Y145.682
;TYPE:Solid infill
;WIDTH:0.411054
G1 F1200
G1 X106.838 Y145.85 E.00485
;WIDTH:0.447772
G1 X106.741 Y146.018 E.00534
;WIDTH:0.485102
G1 X106.529 Y146.261 E.00967
;WIDTH:0.522099
G1 X106.322 Y146.399 E.00807
;WIDTH:0.559096
G1 X106.114 Y146.537 E.00871
;WIDTH:0.572176
G1 X105.462 Y146.718 E.02421
;WIDTH:0.569096
G1 X91.809 Y146.722 E.48567
;WIDTH:0.576014
G1 X91.549 Y146.685 E.00946
G1 E-5 F3600
G1 X91.549 Y146.685 F9000
G1 X91.52 Y149.333
G1 E5 F2400
;WIDTH:0.565056
G1 F1200
G1 X91.805 Y149.28 E.01023
;WIDTH:0.575878
G1 X105.356 Y149.279 E.48815
;WIDTH:0.587588
G1 X105.784 Y149.344 E.01593
G1 X106.114 Y149.46 E.01287
;WIDTH:0.554786
G1 X106.323 Y149.603 E.00877
;WIDTH:0.524086
G1 X106.532 Y149.746 E.00825
;WIDTH:0.493386
G1 X106.685 Y149.93 E.00731
;WIDTH:0.446929
G1 X106.839 Y150.114 E.00659
;WIDTH:0.400472
G1 X106.933 Y150.321 E.00554
G1 E-5 F3600
G1 X106.933 Y150.321 F9000
G1 X105.129 Y154.654
G1 E5 F2400
;WIDTH:0.426152
G1 F1200
G1 X94.527 Y154.644 E.27633
;WIDTH:0.411977
G1 X93.783 Y154.644 E.01869
G1 X94.086 Y154.799 E.00855
G1 X94.5 Y154.928 E.01089
G1 X94.996 Y155.022 E.01268
;WIDTH:0.426152
G1 X95.396 Y155.044 E.01044
G1 X105.311 Y155.044 E.25842
;WIDTH:0.435439
G1 X105.506 Y155.038 E.00521
;WIDTH:0.475453
G1 X105.542 Y155.018 E.00121
;WIDTH:0.515466
G1 X105.579 Y154.998 E.00135
G1 X105.724 Y154.998 E.00464
;WIDTH:0.56308
G1 X105.792 Y154.732 E.00966
;WIDTH:0.589191
G1 X105.843 Y154.655 E.00341
G1 X105.7 Y154.662 E.00528
;WIDTH:0.552329
G1 X105.558 Y154.669 E.0049
;WIDTH:0.515466
G1 X105.435 Y154.661 E.00394
;WIDTH:0.469919
G1 X105.312 Y154.654 E.00357
;WIDTH:0.399999
G1 X105.844 Y154.655 E.01294
;WIDTH:0.594572
G1 X105.938 Y154.606 E.00395
;WIDTH:0.591862
G1 X106.202 Y154.452 E.01133
;WIDTH:0.555471
G1 X106.467 Y154.298 E.01063
;WIDTH:0.51908
G1 X106.623 Y154.12 E.00763
;WIDTH:0.485612
G1 X106.78 Y153.941 E.00715
G1 E-5 F3600
G1 X106.78 Y153.941 F9000
G1 X124.175 Y150.112
G1 E5 F2400
;WIDTH:0.455211
G1 F1200
G1 X124.335 Y149.917 E.00706
;WIDTH:0.485206
G1 X124.494 Y149.723 E.00752
;WIDTH:0.520281
G1 X124.737 Y149.573 E.00923
;WIDTH:0.555356
G1 X124.98 Y149.423 E.0099
;WIDTH:0.560768
G1 X125.503 Y149.291 E.01889
;WIDTH:0.573272
G1 X125.652 Y149.277 E.00537
G1 X139.195 Y149.28 E.48552
;WIDTH:0.565056
G1 X139.477 Y149.329 E.0101
G1 E-5 F3600
G1 X139.477 Y149.329 F9000
G1 X125.151 Y150.746
G1 X125.151 Y153.254
G1 X125.689 Y154.653
G1 E5 F2400
;WIDTH:0.424579
G1 F1200
G1 X136.089 Y154.64 E.26997
;WIDTH:0.403529
G1 X137.196 Y154.64 E.02719
G1 X137.203 Y154.672 E.0008
G1 X136.915 Y154.803 E.00777
G1 X136.135 Y155.004 E.01978
;WIDTH:0.424579
G1 X135.717 Y155.041 E.01089
G1 X125.689 Y155.042 E.26032
;WIDTH:0.465804
G1 X125.5 Y155.021 E.00546
;WIDTH:0.508039
G1 X125.311 Y155 E.00599
;WIDTH:0.545712
G1 X125.274 Y154.818 E.00632
;WIDTH:0.581544
G1 X125.16 Y154.649 E.00742
G1 X125.275 Y154.65 E.00419
;WIDTH:0.547074
G1 X125.391 Y154.651 E.00396
;WIDTH:0.512603
G1 X125.506 Y154.652 E.00366
G1 X125.391 Y154.651 E.00366
;WIDTH:0.547074
G1 X125.275 Y154.65 E.00396
;WIDTH:0.581544
G1 X125.141 Y154.638 E.0049
;WIDTH:0.578928
G1 X124.849 Y154.476 E.0121
;WIDTH:0.552711
G1 X124.557 Y154.314 E.01151
;WIDTH:0.526494
G1 X124.386 Y154.129 E.00825
;WIDTH:0.483536
G1 X124.214 Y153.943 E.00757
G1 E-5 F3600
G1 X124.214 Y153.943 F9000
G1 X124.075 Y145.693
G1 E5 F2400
;WIDTH:0.408192
G1 F1200
G1 X124.166 Y145.856 E.00464
;WIDTH:0.442048
G1 X124.256 Y146.019 E.00505
;WIDTH:0.46962
G1 X124.361 Y146.135 E.00453
;WIDTH:0.497192
G1 X124.466 Y146.251 E.00482
;WIDTH:0.523371
G1 X124.675 Y146.396 E.00827
;WIDTH:0.54955
G1 X124.884 Y146.542 E.00874
;WIDTH:0.57761
G1 X125.212 Y146.66 E.0126
G1 X125.64 Y146.721 E.01562
;WIDTH:0.574602
G1 X139.185 Y146.722 E.48679
;WIDTH:0.56903
G1 X139.481 Y146.675 E.01066
;LAYER_CHANGE
;Z:1.26
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;1.26
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X139.185 Y146.722 E-.14236
G1 X136.327 Y146.722 E-1.35764
;WIPE_END
G1 Z1.26 F9000
;AFTER_LAYER_CHANGE
;1.26
G1 Z1.26
G1 X125.935 Y139.44
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X125.97 Y139.417 E.00102
G1 X126 Y138.994 E.01031
G1 X126.725 Y138.354 E.02352
G1 X127.201 Y137.844 E.01697
G1 X127.326 Y137.499 E.00893
G1 X127.201 Y137.156 E.00888
G1 X126.712 Y136.633 E.01742
G1 X126 Y136.006 E.02308
G1 X126 Y103.974 E.77915
G1 X126.241 Y103.974 E.00586
G1 X126.386 Y103.904 E.00392
G1 X126.424 Y103.792 E.00288
G1 X126.424 Y98.457 E.12977
G1 X126.403 Y98.372 E.00213
G1 X126.241 Y98.274 E.00461
G1 X126 Y98.274 E.00586
G1 X126 Y93.263 E.12189
G1 X126.034 Y93.203 E.00168
G1 X138.037 Y93.204 E.29196
G1 X139.05 Y93.226 E.02465
G1 X139.206 Y93.362 E.00503
G1 X139.243 Y93.519 E.00392
G1 X139.243 Y95.333 E.04412
G1 X139.132 Y95.553 E.00599
G1 X138.932 Y95.624 E.00516
G1 X136.183 Y95.623 E.06687
G1 X136.074 Y95.66 E.0028
G1 X136 Y95.806 E.00398
G1 X135.996 Y132.558 E.89396
G1 X135.966 Y133.099 E.01318
G1 X135.888 Y133.772 E.01648
G1 X135.754 Y134.474 E.01738
G1 X135.583 Y135.126 E.0164
G1 X135.173 Y136.236 E.02878
G1 X134.883 Y136.843 E.01636
G1 X134.414 Y137.645 E.0226
G1 X134.002 Y138.228 E.01736
G1 X133.576 Y138.752 E.01643
G1 X132.932 Y139.422 E.0226
G1 X132.394 Y139.892 E.01738
G1 X131.858 Y140.302 E.01641
G1 X131.075 Y140.802 E.0226
G1 X130.441 Y141.132 E.01739
G1 X129.824 Y141.405 E.01641
G1 X128.945 Y141.708 E.02262
G1 X128.252 Y141.88 E.01737
G1 X127.59 Y142.001 E.01637
G1 X126.193 Y142.1 E.03407
G1 X120.85 Y142.1 E.12996
G1 X120.85 Y141.847 E.00615
G1 X120.797 Y141.718 E.00339
G1 X120.667 Y141.665 E.00341
G1 X110.333 Y141.665 E.25136
G1 X110.204 Y141.718 E.00339
G1 X110.15 Y141.847 E.0034
G1 X110.15 Y142.1 E.00615
G1 X104.337 Y142.089 E.1414
G1 X103.2 Y141.966 E.02782
G1 X102.502 Y141.827 E.01731
G1 X101.61 Y141.567 E.0226
G1 X100.98 Y141.323 E.01643
G1 X100.334 Y141.024 E.01731
G1 X99.141 Y140.302 E.03392
G1 X98.251 Y139.589 E.02774
G1 X97.739 Y139.097 E.01727
G1 X96.846 Y138.026 E.03392
G1 X96.236 Y137.062 E.02775
G1 X95.912 Y136.43 E.01728
G1 X95.416 Y135.127 E.03391
G1 X95.152 Y134.019 E.02771
G1 X95.033 Y133.099 E.02256
G1 X94.999 Y132.296 E.01955
G1 X94.999 Y95.806 E.88758
G1 X94.926 Y95.66 E.00397
G1 X94.816 Y95.623 E.00282
G1 X92.037 Y95.618 E.0676
G1 X91.821 Y95.504 E.00594
G1 X91.75 Y95.286 E.00558
G1 X91.75 Y93.599 E.04103
G1 X91.797 Y93.363 E.00585
G1 X91.906 Y93.252 E.00378
G1 X92.077 Y93.204 E.00432
G1 X104.942 Y93.205 E.31293
G1 X105 Y93.239 E.00164
G1 X105 Y98.274 E.12247
G1 X104.759 Y98.274 E.00586
G1 X104.625 Y98.332 E.00355
G1 X104.576 Y98.457 E.00327
G1 X104.576 Y103.792 E.12977
G1 X104.591 Y103.864 E.00179
G1 X104.759 Y103.974 E.00488
G1 X105 Y103.974 E.00586
G1 X105 Y136.006 E.77915
G1 X104.277 Y136.644 E.02345
G1 X103.841 Y137.095 E.01526
G1 X103.675 Y137.48 E.0102
G1 X103.804 Y137.849 E.00951
G1 X103.895 Y137.961 E.00351
G1 X104.288 Y138.367 E.01374
G1 X105 Y138.994 E.02308
G1 X105.009 Y139.373 E.00922
G1 X105.094 Y139.477 E.00327
G1 X105.182 Y139.5 E.00221
G1 X125.817 Y139.5 E.50193
G1 X125.849 Y139.497 E.00078
G1 X125.885 Y139.473 E.00105
G1 X125.885 Y139.473 F9000
G1 X126.199 Y139.698
;TYPE:Perimeter
G1 F6000
G1 X126.277 Y139.616 E.00275
G1 X126.339 Y139.487 E.00348
G1 X126.366 Y139.159 E.00801
G1 X126.992 Y138.604 E.02035
G1 X127.469 Y138.094 E.01699
G1 X127.586 Y137.899 E.00553
G1 X127.692 Y137.498 E.01009
G1 X127.586 Y137.101 E.00999
G1 X127.469 Y136.906 E.00553
G1 X126.954 Y136.359 E.01827
G1 X126.366 Y135.841 E.01906
G1 X126.366 Y104.279 E.76771
G1 X126.675 Y104.128 E.00837
G1 X126.745 Y104.009 E.00336
G1 X126.79 Y103.792 E.00539
G1 X126.79 Y98.457 E.12977
G1 X126.77 Y98.309 E.00363
G1 X126.642 Y98.082 E.00634
G1 X126.366 Y97.963 E.00731
G1 X126.366 Y93.569 E.10688
G1 X138.878 Y93.57 E.30434
G1 X138.882 Y95.256 E.04101
G1 X136.183 Y95.258 E.06565
G1 X135.854 Y95.367 E.00843
G1 X135.677 Y95.595 E.00702
G1 X135.635 Y95.806 E.00523
G1 X135.63 Y132.548 E.89371
G1 X135.602 Y133.068 E.01267
G1 X135.527 Y133.716 E.01587
G1 X135.398 Y134.393 E.01676
G1 X135.234 Y135.016 E.01567
G1 X134.836 Y136.093 E.02793
G1 X134.56 Y136.671 E.01558
G1 X134.106 Y137.447 E.02187
G1 X133.71 Y138.007 E.01668
G1 X133.302 Y138.51 E.01575
G1 X132.679 Y139.157 E.02185
G1 X132.163 Y139.609 E.01669
G1 X131.648 Y140.002 E.01576
G1 X130.891 Y140.485 E.02184
G1 X130.283 Y140.803 E.01669
G1 X129.69 Y141.065 E.01577
G1 X128.842 Y141.357 E.02182
G1 X128.175 Y141.523 E.01672
G1 X127.544 Y141.638 E.0156
G1 X126.18 Y141.735 E.03326
G1 X121.169 Y141.735 E.12189
G1 X121.055 Y141.46 E.00724
G1 X120.667 Y141.299 E.01022
G1 X110.333 Y141.299 E.25136
G1 X110.238 Y141.307 E.00232
G1 X109.945 Y141.459 E.00803
G1 X109.832 Y141.734 E.00723
G1 X104.357 Y141.723 E.13317
G1 X103.256 Y141.604 E.02694
G1 X102.589 Y141.471 E.01654
G1 X101.728 Y141.22 E.02181
G1 X101.123 Y140.986 E.01578
G1 X100.506 Y140.7 E.01654
G1 X99.351 Y140.001 E.03284
G1 X98.492 Y139.314 E.02675
G1 X98.007 Y138.847 E.01638
G1 X97.142 Y137.81 E.03285
G1 X96.554 Y136.881 E.02674
G1 X96.247 Y136.282 E.01637
G1 X95.766 Y135.019 E.03287
G1 X95.512 Y133.953 E.02666
G1 X95.398 Y133.068 E.0217
G1 X95.365 Y132.288 E.01899
G1 X95.365 Y95.806 E.88739
G1 X95.322 Y95.595 E.00524
G1 X95.145 Y95.367 E.00702
G1 X94.816 Y95.258 E.00843
G1 X92.119 Y95.255 E.0656
G1 X92.126 Y93.57 E.04099
G1 X104.634 Y93.571 E.30424
G1 X104.634 Y97.963 E.10683
G1 X104.358 Y98.082 E.00731
G1 X104.273 Y98.203 E.0036
G1 X104.21 Y98.457 E.00637
G1 X104.21 Y103.792 E.12977
G1 X104.215 Y103.867 E.00183
G1 X104.325 Y104.128 E.00689
G1 X104.634 Y104.279 E.00837
G1 X104.634 Y135.841 E.76771
G1 X104.014 Y136.39 E.02014
G1 X103.556 Y136.865 E.01605
G1 X103.35 Y137.288 E.01144
G1 X103.313 Y137.575 E.00704
G1 X103.467 Y137.99 E.01077
G1 X103.632 Y138.215 E.00679
G1 X104.046 Y138.641 E.01445
G1 X104.634 Y139.159 E.01906
G1 X104.634 Y139.317 E.00384
G1 X104.698 Y139.574 E.00644
G1 X104.915 Y139.796 E.00755
G1 X105.182 Y139.866 E.00671
G1 X125.817 Y139.866 E.50193
G1 X125.912 Y139.857 E.00232
G1 X126.14 Y139.761 E.00602
G1 X126.158 Y139.742 E.00064
G1 X126.158 Y139.742 F9000
G1 X126.453 Y139.953
G1 F6000
G1 X126.584 Y139.815 E.00463
G1 X126.686 Y139.6 E.00579
G1 X126.73 Y139.326 E.00675
G1 X127.349 Y138.758 E.02043
G1 X127.877 Y138.145 E.01968
G1 X128.049 Y137.626 E.0133
G1 X128.049 Y137.371 E.0062
G1 X127.926 Y136.965 E.01032
G1 X127.736 Y136.656 E.00882
G1 X127.196 Y136.084 E.01913
G1 X126.731 Y135.675 E.01506
G1 X126.731 Y104.466 E.75913
G1 X126.964 Y104.352 E.00631
G1 X127.081 Y104.154 E.00559
G1 X127.155 Y103.792 E.00899
G1 X127.155 Y98.457 E.12977
G1 X127.152 Y98.374 E.00202
G1 X127.051 Y98.033 E.00865
G1 X126.909 Y97.832 E.00599
G1 X126.731 Y97.756 E.00471
G1 X126.731 Y93.934 E.09297
G1 X138.514 Y93.935 E.28661
G1 X138.517 Y94.893 E.0233
G1 X136.184 Y94.892 E.05675
G1 X136.025 Y94.906 E.00388
G1 X135.635 Y95.075 E.01034
G1 X135.34 Y95.454 E.01168
G1 X135.269 Y95.806 E.00873
G1 X135.265 Y132.538 E.89347
G1 X135.237 Y133.037 E.01216
G1 X135.165 Y133.661 E.01528
G1 X135.041 Y134.313 E.01614
G1 X134.885 Y134.906 E.01491
G1 X134.499 Y135.951 E.0271
G1 X134.236 Y136.5 E.01481
G1 X133.799 Y137.248 E.02107
G1 X133.419 Y137.786 E.01602
G1 X133.028 Y138.267 E.01508
G1 X132.427 Y138.892 E.02109
G1 X131.931 Y139.325 E.01602
G1 X131.438 Y139.702 E.0151
G1 X130.708 Y140.168 E.02107
G1 X130.124 Y140.473 E.01603
G1 X129.556 Y140.724 E.0151
G1 X128.738 Y141.006 E.02105
G1 X128.098 Y141.165 E.01604
G1 X127.498 Y141.274 E.01483
G1 X126.167 Y141.369 E.03246
G1 X121.383 Y141.369 E.11637
G1 X121.314 Y141.202 E.0044
G1 X120.667 Y140.933 E.01704
G1 X110.333 Y140.933 E.25136
G1 X110.175 Y140.947 E.00386
G1 X109.687 Y141.201 E.01338
G1 X109.618 Y141.368 E.0044
G1 X104.377 Y141.358 E.12748
G1 X103.311 Y141.243 E.02608
G1 X102.676 Y141.116 E.01575
G1 X101.845 Y140.873 E.02106
G1 X101.266 Y140.65 E.01509
G1 X100.678 Y140.377 E.01577
G1 X99.561 Y139.701 E.03176
G1 X98.734 Y139.039 E.02577
G1 X98.275 Y138.597 E.0155
G1 X97.438 Y137.594 E.03178
G1 X96.871 Y136.699 E.02577
G1 X96.582 Y136.133 E.01546
G1 X96.117 Y134.911 E.0318
G1 X95.873 Y133.887 E.02561
G1 X95.762 Y133.037 E.02085
G1 X95.73 Y132.281 E.01841
G1 X95.73 Y95.806 E.88722
G1 X95.66 Y95.455 E.00871
G1 X95.365 Y95.075 E.0117
G1 X94.816 Y94.892 E.01408
G1 X92.481 Y94.893 E.0568
G1 X92.481 Y93.936 E.02328
G1 X104.269 Y93.936 E.28673
G1 X104.269 Y97.756 E.09292
G1 X104.091 Y97.832 E.00471
G1 X103.949 Y98.033 E.00599
G1 X103.878 Y98.211 E.00466
G1 X103.845 Y98.457 E.00604
G1 X103.845 Y103.792 E.12977
G1 X103.879 Y104.039 E.00606
G1 X104.036 Y104.352 E.00852
G1 X104.269 Y104.466 E.00631
G1 X104.269 Y135.675 E.75913
G1 X103.751 Y136.136 E.01687
G1 X103.187 Y136.754 E.02035
G1 X102.963 Y137.306 E.01449
G1 X102.951 Y137.625 E.00776
G1 X103.13 Y138.131 E.01306
G1 X103.369 Y138.469 E.01007
G1 X103.804 Y138.915 E.01515
G1 X104.27 Y139.326 E.01511
G1 X104.375 Y139.745 E.01051
G1 X104.737 Y140.115 E.01259
G1 X105.181 Y140.231 E.01116
G1 X125.817 Y140.231 E.50195
G1 X125.975 Y140.218 E.00386
G1 X126.355 Y140.056 E.01005
G1 X126.412 Y139.996 E.00201
G1 E-5 F3600
G1 X126.412 Y139.996 F9000
G1 X110.113 Y140.592
G1 E5 F2400
;WIDTH:0.38983
G1 F6000
G1 X110.333 Y140.582 E.00521
;WIDTH:0.370658
G1 X120.667 Y140.582 E.23119
G1 E-5 F3600
G1 X120.667 Y140.582 F9000
G1 X104.651 Y139.849
G1 X103.483 Y138.005
G1 X103.43 Y137.913
G1 X103.387 Y137.819
G1 X103.353 Y137.719
G1 X103.332 Y137.612
G1 X103.324 Y137.5
G1 X103.903 Y124.442
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X103.903 Y135.51 E.26922
G1 X103.488 Y135.882 E.01356
G1 X103.001 Y136.389 E.0171
G1 X102.793 Y136.727 E.00965
G1 X102.606 Y137.229 E.01303
G1 X102.589 Y137.675 E.01086
G1 X102.793 Y138.273 E.01537
G1 X103.052 Y138.667 E.01147
G1 X103.488 Y139.118 E.01526
G1 X103.934 Y139.517 E.01456
G1 X103.963 Y139.705 E.00463
G1 X104.052 Y139.916 E.00557
G1 X104.558 Y140.434 E.01761
;WIDTH:0.41548
G1 X105.183 Y140.605 E.01643
;WIDTH:0.419293
G1 X109.285 Y140.607 E.10504
G1 X110.113 Y140.592 E.02121
G1 X109.421 Y140.935 E.01978
G1 X109.398 Y140.992 E.00157
G1 X105.182 Y140.986 E.10796
;WIDTH:0.41548
G1 X104.397 Y140.992 E.0199
;WIDTH:0.399999
G1 X103.367 Y140.881 E.0252
G1 X102.763 Y140.761 E.01498
G1 X101.963 Y140.527 E.02027
G1 X101.409 Y140.313 E.01445
G1 X100.85 Y140.054 E.01499
G1 X99.771 Y139.4 E.03069
G1 X98.975 Y138.763 E.0248
G1 X98.543 Y138.348 E.01457
G1 X97.734 Y137.378 E.03072
G1 X97.189 Y136.518 E.02477
G1 X96.916 Y135.984 E.01459
G1 X96.467 Y134.803 E.03073
G1 X96.233 Y133.82 E.02458
G1 X96.127 Y133.005 E.01999
G1 X96.096 Y132.273 E.01782
G1 X96.096 Y95.806 E.88702
G1 X95.998 Y95.314 E.0122
G1 X95.584 Y94.782 E.0164
;WIDTH:0.444999
G1 X95.43 Y94.709 E.00466
;WIDTH:0.489999
G1 X95.277 Y94.635 E.00515
;WIDTH:0.534999
G1 X95.123 Y94.561 E.00569
;WIDTH:0.579998
G1 X94.97 Y94.488 E.00615
;WIDTH:0.624998
G1 X94.816 Y94.414 E.00671
G1 X95.002 Y94.391 E.00736
;WIDTH:0.579998
G1 X95.187 Y94.369 E.00676
;WIDTH:0.534999
G1 X95.373 Y94.346 E.00624
;WIDTH:0.489999
G1 X95.559 Y94.324 E.00568
;WIDTH:0.444999
G1 X95.744 Y94.301 E.00509
;WIDTH:0.399999
G1 X103.903 Y94.302 E.19846
G1 X103.903 Y97.548 E.07896
G1 X103.824 Y97.583 E.0021
G1 X103.625 Y97.863 E.00836
G1 X103.526 Y98.113 E.00654
G1 X103.479 Y98.457 E.00845
G1 X103.479 Y103.792 E.12977
G1 X103.527 Y104.137 E.00847
G1 X103.747 Y104.576 E.01194
G1 X103.903 Y104.652 E.00422
G1 X103.903 Y124.382 E.47991
G1 E-5 F3600
G1 X103.903 Y124.382 F9000
G1 X103.537 Y135.345
G1 E5 F2400
G1 F6000
G1 X103.225 Y135.628 E.01025
G1 X102.608 Y136.302 E.02223
G1 X102.431 Y136.644 E.00937
G1 X102.248 Y137.152 E.01313
G1 X102.226 Y137.725 E.01395
G1 X102.339 Y138.136 E.01037
G1 X102.608 Y138.697 E.01513
G1 X102.789 Y138.921 E.00701
G1 X103.225 Y139.372 E.01526
G1 X103.598 Y139.708 E.01221
G1 X103.729 Y140.087 E.00975
G1 X104.237 Y140.607 E.01768
G1 X103.422 Y140.519 E.01994
G1 X102.85 Y140.405 E.01419
G1 X102.08 Y140.18 E.01951
G1 X101.552 Y139.976 E.01377
G1 X101.022 Y139.731 E.0142
G1 X99.981 Y139.1 E.02961
G1 X99.217 Y138.488 E.02381
G1 X98.811 Y138.098 E.01369
G1 X98.031 Y137.162 E.02964
G1 X97.507 Y136.336 E.02379
G1 X97.251 Y135.835 E.01369
G1 X96.817 Y134.696 E.02965
G1 X96.593 Y133.754 E.02355
G1 X96.492 Y132.974 E.01913
G1 X96.462 Y132.265 E.01726
G1 X96.462 Y95.806 E.88683
G1 X96.335 Y95.173 E.0157
G1 X95.941 Y94.667 E.0156
G1 X103.537 Y94.668 E.18477
G1 X103.537 Y97.361 E.0655
G1 X103.301 Y97.693 E.00991
G1 X103.174 Y98.014 E.0084
G1 X103.113 Y98.457 E.01088
G1 X103.113 Y103.792 E.12977
G1 X103.129 Y104.017 E.00549
G1 X103.248 Y104.443 E.01076
G1 X103.458 Y104.8 E.01007
G1 X103.537 Y104.839 E.00214
G1 X103.537 Y135.285 E.74057
G1 E-5 F3600
G1 X103.537 Y135.285 F9000
G1 X95.348 Y95.273
G1 X92.96 Y94.414
G1 E5 F2400
;WIDTH:0.625724
G1 F6000
G1 X94.816 Y94.414 E.07301
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X92.96 Y94.414 E-.8816
;WIPE_END
G1 E-.6184 F3600
G1 X135.941 Y94.424 F9000
G1 E5 F2400
;WIDTH:0.646578
G1 F6000
G1 X136.184 Y94.414 E.0099
;WIDTH:0.625878
G1 X138.037 Y94.414 E.07291
G1 E-5 F3600
G1 X127.097 Y94.3 F9000
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X135.255 Y94.301 E.19844
;WIDTH:0.449315
G1 X135.392 Y94.325 E.00384
;WIDTH:0.498631
G1 X135.53 Y94.35 E.00433
;WIDTH:0.547947
G1 X135.667 Y94.375 E.00476
;WIDTH:0.597262
G1 X135.804 Y94.4 E.00521
;WIDTH:0.646578
G1 X135.941 Y94.424 E.00566
G1 X135.836 Y94.496 E.00519
;WIDTH:0.597262
G1 X135.731 Y94.567 E.00475
;WIDTH:0.547947
G1 X135.626 Y94.639 E.00435
;WIDTH:0.498631
G1 X135.521 Y94.711 E.00393
;WIDTH:0.449315
G1 X135.416 Y94.782 E.0035
;WIDTH:0.399999
G1 X135.002 Y95.314 E.0164
G1 X134.903 Y95.806 E.01221
G1 X134.899 Y132.42 E.8906
G1 X134.873 Y133.006 E.01427
G1 X134.803 Y133.606 E.01469
G1 X134.684 Y134.232 E.0155
G1 X134.536 Y134.796 E.01418
G1 X134.162 Y135.808 E.02624
G1 X133.913 Y136.329 E.01405
G1 X133.491 Y137.05 E.02032
G1 X133.127 Y137.565 E.01534
G1 X132.753 Y138.025 E.01442
G1 X132.174 Y138.627 E.02032
G1 X131.699 Y139.042 E.01534
G1 X131.228 Y139.402 E.01442
G1 X130.525 Y139.851 E.02029
G1 X129.965 Y140.143 E.01536
G1 X129.423 Y140.383 E.01442
G1 X128.634 Y140.655 E.0203
G1 X128.021 Y140.807 E.01536
G1 X127.452 Y140.911 E.01407
G1 X126.791 Y140.958 E.01612
;WIDTH:0.420284
G1 X125.817 Y140.993 E.02502
G1 X121.604 Y140.993 E.10816
G1 X121.58 Y140.936 E.00159
G1 X120.667 Y140.582 E.02514
G1 X121.717 Y140.607 E.02696
G1 X125.817 Y140.607 E.10526
;WIDTH:0.425899
G1 X126.101 Y140.578 E.00744
G1 X126.57 Y140.352 E.01356
;WIDTH:0.399999
G1 X126.89 Y140.014 E.01132
G1 X127.034 Y139.713 E.00812
G1 X127.066 Y139.517 E.00483
G1 X127.616 Y139.007 E.01824
G1 X128.062 Y138.525 E.01597
G1 X128.278 Y138.137 E.0108
G1 X128.411 Y137.676 E.01167
G1 X128.411 Y137.32 E.00866
G1 X128.221 Y136.724 E.01522
G1 X128.003 Y136.407 E.00936
G1 X127.527 Y135.897 E.01697
G1 X127.097 Y135.51 E.01407
G1 X127.097 Y104.652 E.75059
G1 X127.253 Y104.576 E.00422
G1 X127.473 Y104.137 E.01194
G1 X127.521 Y103.792 E.00847
G1 X127.521 Y98.457 E.12977
G1 X127.516 Y98.34 E.00285
G1 X127.375 Y97.863 E.0121
G1 X127.176 Y97.583 E.00836
G1 X127.097 Y97.548 E.0021
G1 X127.097 Y94.36 E.07754
G1 X127.463 Y94.666 F9000
G1 F6000
G1 X135.059 Y94.666 E.18477
G1 X134.664 Y95.173 E.01563
G1 X134.538 Y95.806 E.0157
G1 X134.533 Y132.42 E.8906
G1 X134.508 Y132.975 E.01351
G1 X134.442 Y133.55 E.01408
G1 X134.327 Y134.151 E.01488
G1 X134.187 Y134.686 E.01345
G1 X133.825 Y135.666 E.02541
G1 X133.59 Y136.157 E.01324
G1 X133.183 Y136.852 E.01959
G1 X132.835 Y137.344 E.01466
G1 X132.479 Y137.783 E.01375
G1 X131.922 Y138.362 E.01954
G1 X131.468 Y138.759 E.01467
G1 X131.019 Y139.102 E.01374
G1 X130.341 Y139.535 E.01957
G1 X129.806 Y139.814 E.01468
G1 X129.289 Y140.043 E.01375
G1 X128.53 Y140.304 E.01952
G1 X127.944 Y140.45 E.01469
G1 X127.406 Y140.548 E.0133
G1 X126.842 Y140.588 E.01375
G1 X127.197 Y140.214 E.01254
G1 X127.382 Y139.826 E.01046
G1 X127.402 Y139.708 E.00291
G1 X127.794 Y139.353 E.01286
G1 X128.27 Y138.843 E.01697
G1 X128.524 Y138.485 E.01068
G1 X128.699 Y138.037 E.0117
G1 X128.789 Y137.494 E.01339
G1 X128.71 Y136.994 E.01231
G1 X128.55 Y136.566 E.01111
G1 X128.27 Y136.157 E.01206
G1 X127.463 Y135.345 E.02785
G1 X127.463 Y104.839 E.74203
G1 X127.541 Y104.8 E.00212
G1 X127.752 Y104.443 E.01009
G1 X127.826 Y104.236 E.00535
G1 X127.887 Y103.792 E.0109
G1 X127.887 Y98.457 E.12977
G1 X127.826 Y98.014 E.01088
G1 X127.699 Y97.694 E.00837
G1 X127.463 Y97.361 E.00993
G1 X127.463 Y94.726 E.06409
G1 E-5 F3600
G1 X127.463 Y94.726 F9000
G1 X134.55 Y95.206
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X134.284 Y94.941 E.00913
G1 X133.765 Y94.941 E.01262
G1 X134.323 Y95.498 E.01918
G1 X134.264 Y95.958 E.01128
G1 X133.247 Y94.941 E.03498
G1 X132.728 Y94.94 E.01262
G1 X134.263 Y96.476 E.05282
G1 X134.263 Y96.995 E.01262
G1 X132.209 Y94.94 E.07067
G1 X131.69 Y94.94 E.01262
G1 X134.263 Y97.514 E.08853
G1 X134.263 Y98.033 E.01262
G1 X131.171 Y94.94 E.10638
G1 X130.652 Y94.94 E.01262
G1 X134.263 Y98.551 E.12422
G1 X134.263 Y99.07 E.01262
G1 X130.133 Y94.94 E.14207
G1 X129.614 Y94.94 E.01262
G1 X134.263 Y99.589 E.15992
G1 X134.263 Y100.108 E.01262
G1 X129.095 Y94.94 E.17778
G1 X128.576 Y94.94 E.01262
G1 X134.263 Y100.627 E.19563
G1 X134.263 Y101.145 E.0126
G1 X128.058 Y94.94 E.21345
G1 X127.737 Y94.94 E.00781
G1 X127.737 Y95.138 E.00482
G1 X134.263 Y101.664 E.22449
G1 X134.263 Y102.183 E.01262
G1 X127.737 Y95.657 E.22449
G1 X127.737 Y96.176 E.01262
G1 X134.263 Y102.702 E.22449
G1 X134.263 Y103.221 E.01262
G1 X127.737 Y96.695 E.22449
G1 X127.737 Y97.214 E.01262
G1 X134.263 Y103.739 E.22447
G1 X134.263 Y104.258 E.01262
G1 X128.123 Y98.119 E.2112
G1 X128.161 Y98.675 E.01356
G1 X134.262 Y104.777 E.20989
G1 X134.262 Y105.296 E.01262
G1 X128.161 Y99.194 E.20989
G1 X128.161 Y99.713 E.01262
G1 X134.262 Y105.815 E.20989
G1 X134.262 Y106.333 E.0126
G1 X128.161 Y100.232 E.20987
G1 X128.161 Y100.751 E.01262
G1 X134.262 Y106.852 E.20987
G1 X134.262 Y107.371 E.01262
G1 X128.161 Y101.27 E.20987
G1 X128.161 Y101.789 E.01262
G1 X134.262 Y107.89 E.20987
G1 X134.262 Y108.408 E.0126
G1 X128.161 Y102.307 E.20987
G1 X128.161 Y102.826 E.01262
G1 X134.262 Y108.927 E.20987
G1 X134.262 Y109.446 E.01262
G1 X128.161 Y103.345 E.20987
G1 X128.156 Y103.858 E.01248
G1 X134.262 Y109.965 E.21006
G1 X134.262 Y110.484 E.01262
G1 X128.08 Y104.301 E.21267
G1 X127.933 Y104.674 E.00975
G1 X134.262 Y111.002 E.2177
G1 X134.262 Y111.521 E.01262
G1 X127.737 Y104.996 E.22446
G1 X127.737 Y105.515 E.01262
G1 X134.262 Y112.04 E.22446
G1 X134.262 Y112.559 E.01262
G1 X127.737 Y106.034 E.22446
G1 X127.737 Y106.553 E.01262
G1 X134.262 Y113.078 E.22446
G1 X134.261 Y113.596 E.0126
G1 X127.737 Y107.072 E.22442
G1 X127.737 Y107.591 E.01262
G1 X134.261 Y114.115 E.22442
G1 X134.261 Y114.634 E.01262
G1 X127.737 Y108.11 E.22442
G1 X127.737 Y108.628 E.0126
G1 X134.261 Y115.153 E.22444
G1 X134.261 Y115.672 E.01262
G1 X127.737 Y109.147 E.22444
G1 X127.737 Y109.666 E.01262
G1 X134.261 Y116.19 E.22442
G1 X134.261 Y116.709 E.01262
G1 X127.737 Y110.185 E.22442
G1 X127.737 Y110.704 E.01262
G1 X134.261 Y117.228 E.22442
G1 X134.261 Y117.747 E.01262
G1 X127.737 Y111.223 E.22442
G1 X127.737 Y111.741 E.0126
G1 X134.261 Y118.265 E.22442
G1 X134.261 Y118.784 E.01262
G1 X127.737 Y112.26 E.22442
G1 X127.737 Y112.779 E.01262
G1 X134.261 Y119.303 E.22442
G1 X134.261 Y119.822 E.01262
G1 X127.737 Y113.298 E.22442
G1 X127.737 Y113.817 E.01262
G1 X134.261 Y120.341 E.22442
G1 X134.261 Y120.859 E.0126
G1 X127.737 Y114.336 E.2244
G1 X127.737 Y114.855 E.01262
G1 X134.261 Y121.378 E.2244
G1 X134.26 Y121.897 E.01262
G1 X127.737 Y115.373 E.2244
G1 X127.737 Y115.892 E.01262
G1 X134.26 Y122.416 E.2244
G1 X134.26 Y122.935 E.01262
G1 X127.737 Y116.411 E.2244
G1 X127.737 Y116.93 E.01262
G1 X134.26 Y123.453 E.22439
G1 X134.26 Y123.972 E.01262
G1 X127.737 Y117.449 E.22439
G1 X127.737 Y117.968 E.01262
G1 X134.26 Y124.491 E.22439
G1 X134.26 Y125.01 E.01262
G1 X127.737 Y118.487 E.22439
G1 X127.737 Y119.005 E.0126
G1 X134.26 Y125.529 E.2244
G1 X134.26 Y126.047 E.0126
G1 X127.737 Y119.524 E.22439
G1 X127.737 Y120.043 E.01262
G1 X134.26 Y126.566 E.22439
G1 X134.26 Y127.085 E.01262
G1 X127.737 Y120.562 E.22439
G1 X127.737 Y121.081 E.01262
G1 X134.26 Y127.604 E.22439
G1 X134.26 Y128.122 E.0126
G1 X127.737 Y121.6 E.22437
G1 X127.737 Y122.118 E.0126
G1 X134.26 Y128.641 E.22439
G1 X134.26 Y129.16 E.01262
G1 X127.737 Y122.637 E.22439
G1 X127.737 Y123.156 E.01262
G1 X134.26 Y129.679 E.22439
G1 X134.259 Y130.198 E.01262
G1 X127.737 Y123.675 E.22437
G1 X127.737 Y124.194 E.01262
G1 X134.259 Y130.716 E.22435
G1 X134.259 Y131.235 E.01262
G1 X127.737 Y124.713 E.22435
G1 X127.737 Y125.232 E.01262
G1 X134.259 Y131.754 E.22435
G1 X134.259 Y132.273 E.01262
G1 X127.737 Y125.75 E.22437
G1 X127.737 Y126.269 E.01262
G1 X134.244 Y132.777 E.22385
G1 X134.2 Y133.251 E.01158
G1 X127.737 Y126.788 E.22232
G1 X127.737 Y127.307 E.01262
G1 X134.133 Y133.703 E.22002
G1 X134.047 Y134.136 E.01074
G1 X127.737 Y127.826 E.21706
G1 X127.737 Y128.345 E.01262
G1 X133.939 Y134.547 E.21335
G1 X133.804 Y134.931 E.0099
G1 X127.737 Y128.864 E.2087
G1 X127.737 Y129.382 E.0126
G1 X133.664 Y135.309 E.20389
G1 X133.514 Y135.679 E.00971
G1 X127.737 Y129.901 E.19874
G1 X127.737 Y130.42 E.01262
G1 X133.347 Y136.03 E.19298
G1 X133.155 Y136.357 E.00922
G1 X127.737 Y130.939 E.18638
G1 X127.737 Y131.458 E.01262
G1 X132.964 Y136.684 E.17979
G1 X132.75 Y136.99 E.00908
G1 X127.737 Y131.977 E.17244
G1 X127.737 Y132.496 E.01262
G1 X132.528 Y137.287 E.16481
G1 X132.296 Y137.573 E.00896
G1 X127.737 Y133.014 E.15683
G1 X127.737 Y133.533 E.01262
G1 X132.044 Y137.84 E.14816
G1 X131.789 Y138.104 E.00893
G1 X127.737 Y134.052 E.13939
G1 X127.737 Y134.571 E.01262
G1 X131.517 Y138.351 E.13003
G1 X131.237 Y138.59 E.00895
G1 X127.737 Y135.09 E.1204
G1 X127.737 Y135.222 E.00321
G1 X128.677 Y136.234 E.0336
G1 X128.93 Y136.802 E.01512
G1 X130.943 Y138.815 E.06925
G1 X130.633 Y139.023 E.00908
G1 X129.061 Y137.451 E.05408
G1 X129.009 Y137.918 E.01143
G1 X130.316 Y139.225 E.04496
G1 X129.984 Y139.412 E.00927
G1 X128.885 Y138.313 E.0378
G1 X128.727 Y138.674 E.00959
G1 X129.64 Y139.587 E.03141
G1 X129.281 Y139.746 E.00955
G1 X128.514 Y138.98 E.02637
G1 X128.265 Y139.25 E.00893
G1 X128.901 Y139.886 E.02188
G1 X128.515 Y140.019 E.00993
G1 X128.015 Y139.518 E.01722
G1 X127.745 Y139.768 E.00895
G1 X128.105 Y140.127 E.01237
G1 X127.675 Y140.216 E.01068
G1 X127.432 Y139.973 E.00836
G1 E-5 F3600
G1 X127.432 Y139.973 F9000
G1 X97.98 Y136.878
G1 E5 F2400
G1 F3072.127
G1 X99.398 Y138.282 E.04854
G1 X100.138 Y138.875 E.02307
G1 X101.048 Y139.425 E.02586
G1 X97.665 Y136.043 E.11636
G1 X97.278 Y135.136 E.02399
G1 X101.996 Y139.854 E.1623
G1 X102.754 Y140.091 E.01932
G1 X97.018 Y134.356 E.1973
G1 X96.859 Y133.677 E.01696
G1 X103.422 Y140.239 E.22575
G1 X103.501 Y140.252 E.00195
G1 X103.345 Y139.85 E.01049
G1 X102.589 Y139.109 E.02575
G1 X102.188 Y138.485 E.01804
G1 X96.782 Y133.079 E.18596
G1 X96.747 Y132.525 E.0135
G1 X101.953 Y137.731 E.17908
G1 X101.96 Y137.217 E.0125
G1 X96.736 Y131.993 E.1797
G1 X96.736 Y131.473 E.01265
G1 X102.07 Y136.807 E.18349
G1 X102.223 Y136.44 E.00967
G1 X96.736 Y130.953 E.18875
G1 X96.736 Y130.433 E.01265
G1 X102.412 Y136.11 E.19527
G1 X102.65 Y135.828 E.00898
G1 X96.736 Y129.913 E.20346
G1 X96.736 Y129.393 E.01265
G1 X102.906 Y135.563 E.21224
G1 X103.17 Y135.307 E.00894
G1 X96.736 Y128.873 E.22133
G1 X96.736 Y128.353 E.01265
G1 X103.263 Y134.88 E.22452
G1 X103.263 Y134.36 E.01265
G1 X96.736 Y127.833 E.22452
G1 X96.736 Y127.313 E.01265
G1 X103.263 Y133.84 E.22452
G1 X103.263 Y133.32 E.01265
G1 X96.736 Y126.793 E.22452
G1 X96.736 Y126.273 E.01265
G1 X103.263 Y132.8 E.22452
G1 X103.263 Y132.28 E.01265
G1 X96.736 Y125.753 E.22452
G1 X96.736 Y125.233 E.01265
G1 X103.263 Y131.76 E.22452
G1 X103.263 Y131.24 E.01265
G1 X96.736 Y124.713 E.22452
G1 X96.736 Y124.193 E.01265
G1 X103.263 Y130.72 E.22452
G1 X103.263 Y130.2 E.01265
G1 X96.736 Y123.672 E.22454
G1 X96.736 Y123.152 E.01265
G1 X103.263 Y129.68 E.22454
G1 X103.263 Y129.16 E.01265
G1 X96.736 Y122.632 E.22454
G1 X96.736 Y122.112 E.01265
G1 X103.263 Y128.64 E.22454
G1 X103.263 Y128.12 E.01265
G1 X96.736 Y121.592 E.22454
G1 X96.736 Y121.072 E.01265
G1 X103.263 Y127.599 E.22452
G1 X103.263 Y127.079 E.01265
G1 X96.736 Y120.552 E.22452
G1 X96.736 Y120.032 E.01265
G1 X103.263 Y126.559 E.22452
G1 X103.263 Y126.039 E.01265
G1 X96.736 Y119.512 E.22452
G1 X96.736 Y118.992 E.01265
G1 X103.263 Y125.519 E.22452
G1 X103.263 Y124.999 E.01265
G1 X96.736 Y118.472 E.22452
G1 X96.736 Y117.952 E.01265
G1 X103.263 Y124.479 E.22452
G1 X103.263 Y123.959 E.01265
G1 X96.736 Y117.432 E.22452
G1 X96.736 Y116.912 E.01265
G1 X103.263 Y123.439 E.22452
G1 X103.263 Y122.919 E.01265
G1 X96.736 Y116.392 E.22452
G1 X96.736 Y115.872 E.01265
G1 X103.263 Y122.399 E.22452
G1 X103.263 Y121.879 E.01265
G1 X96.736 Y115.352 E.22452
G1 X96.736 Y114.832 E.01265
G1 X103.263 Y121.359 E.22452
G1 X103.263 Y120.839 E.01265
G1 X96.736 Y114.312 E.22452
G1 X96.736 Y113.792 E.01265
G1 X103.263 Y120.319 E.22452
G1 X103.263 Y119.799 E.01265
G1 X96.736 Y113.272 E.22452
G1 X96.736 Y112.751 E.01267
G1 X103.263 Y119.279 E.22454
G1 X103.263 Y118.759 E.01265
G1 X96.736 Y112.231 E.22454
G1 X96.736 Y111.711 E.01265
G1 X103.263 Y118.239 E.22454
G1 X103.263 Y117.719 E.01265
G1 X96.736 Y111.191 E.22454
G1 X96.736 Y110.671 E.01265
G1 X103.263 Y117.198 E.22452
G1 X103.263 Y116.678 E.01265
G1 X96.736 Y110.151 E.22452
G1 X96.736 Y109.631 E.01265
G1 X103.263 Y116.158 E.22452
G1 X103.263 Y115.638 E.01265
G1 X96.736 Y109.111 E.22452
G1 X96.736 Y108.591 E.01265
G1 X103.263 Y115.118 E.22452
G1 X103.263 Y114.598 E.01265
G1 X96.736 Y108.071 E.22452
G1 X96.736 Y107.551 E.01265
G1 X103.263 Y114.078 E.22452
G1 X103.263 Y113.558 E.01265
G1 X96.736 Y107.031 E.22452
G1 X96.736 Y106.511 E.01265
G1 X103.263 Y113.038 E.22452
G1 X103.263 Y112.518 E.01265
G1 X96.736 Y105.991 E.22452
G1 X96.736 Y105.471 E.01265
G1 X103.263 Y111.998 E.22452
G1 X103.263 Y111.478 E.01265
G1 X96.736 Y104.951 E.22452
G1 X96.736 Y104.431 E.01265
G1 X103.263 Y110.958 E.22452
G1 X103.263 Y110.438 E.01265
G1 X96.736 Y103.911 E.22452
G1 X96.736 Y103.391 E.01265
G1 X103.263 Y109.918 E.22452
G1 X103.263 Y109.398 E.01265
G1 X96.736 Y102.871 E.22452
G1 X96.736 Y102.35 E.01267
G1 X103.263 Y108.878 E.22454
G1 X103.263 Y108.358 E.01265
G1 X96.736 Y101.83 E.22454
G1 X96.736 Y101.31 E.01265
G1 X103.263 Y107.838 E.22454
G1 X103.263 Y107.318 E.01265
G1 X96.736 Y100.79 E.22454
G1 X96.736 Y100.27 E.01265
G1 X103.263 Y106.798 E.22454
G1 X103.263 Y106.277 E.01267
G1 X96.736 Y99.75 E.22452
G1 X96.736 Y99.23 E.01265
G1 X103.263 Y105.757 E.22452
G1 X103.263 Y105.237 E.01265
G1 X96.736 Y98.71 E.22452
G1 X96.736 Y98.19 E.01265
G1 X102.952 Y104.406 E.21383
G1 X102.839 Y103.773 E.01564
G1 X96.736 Y97.67 E.20994
G1 X96.736 Y97.15 E.01265
G1 X102.84 Y103.254 E.20997
G1 X102.84 Y102.734 E.01265
G1 X96.736 Y96.63 E.20997
G1 X96.736 Y96.11 E.01265
G1 X102.841 Y102.215 E.21001
G1 X102.842 Y101.696 E.01262
G1 X96.684 Y95.538 E.21183
G1 X96.589 Y95.064 E.01176
G1 X96.494 Y94.941 E.00378
G1 X96.608 Y94.941 E.00277
G1 X102.843 Y101.177 E.2145
G1 X102.843 Y100.657 E.01265
G1 X97.128 Y94.941 E.19661
G1 X97.648 Y94.942 E.01265
G1 X102.844 Y100.138 E.17874
G1 X102.845 Y99.619 E.01262
G1 X98.168 Y94.942 E.16089
G1 X98.688 Y94.942 E.01265
G1 X102.845 Y99.099 E.143
G1 X102.846 Y98.58 E.01262
G1 X99.208 Y94.942 E.12515
G1 X99.728 Y94.942 E.01265
G1 X102.881 Y98.095 E.10846
G1 X103.005 Y97.699 E.01009
G1 X100.248 Y94.942 E.09484
G1 X100.768 Y94.942 E.01265
G1 X103.197 Y97.37 E.08354
G1 X103.263 Y97.276 E.00279
G1 X103.263 Y96.917 E.00873
G1 X101.288 Y94.942 E.06794
G1 X101.808 Y94.942 E.01265
G1 X103.263 Y96.397 E.05005
G1 X103.263 Y95.876 E.01267
G1 X102.328 Y94.942 E.03215
G1 X102.849 Y94.942 E.01267
G1 X103.428 Y95.521 E.01992
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X102.849 Y94.942 E-.38894
G1 X102.328 Y94.942 E-.24748
G1 X103.263 Y95.876 E-.62775
G1 X103.263 Y96.372 E-.23583
;WIPE_END
G1 X104.227 Y98.835 F9000
G1 X105.536 Y102.182
G1 X106.099 Y103.076
G1 X106.099 Y103.618
G1 X109.45 Y112.866
G1 X109.779 Y113.025
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X109.855 Y112.831 E.00507
G1 X111.626 Y109.763 E.08617
G1 X112.054 Y109.217 E.01687
G1 X112.407 Y108.934 E.01101
G1 X112.906 Y108.681 E.01361
G1 X113.494 Y108.541 E.0147
G1 X117.373 Y108.529 E.09435
G1 X117.804 Y108.593 E.0106
G1 X118.33 Y108.783 E.0136
G1 X118.835 Y109.116 E.01471
G1 X119.266 Y109.591 E.0156
G1 X121.107 Y112.763 E.08921
G1 X121.279 Y113.126 E.00977
G1 X121.391 Y113.52 E.00996
G1 X121.435 Y114.119 E.01461
G1 X121.365 Y114.59 E.01158
G1 X121.187 Y115.086 E.01282
G1 X119.266 Y118.408 E.09334
G1 X118.983 Y118.747 E.01074
G1 X118.546 Y119.096 E.0136
G1 X118.153 Y119.296 E.01073
G1 X117.768 Y119.416 E.00981
G1 X117.372 Y119.471 E.00972
G1 X113.721 Y119.474 E.08881
G1 X113.141 Y119.393 E.01424
G1 X112.58 Y119.17 E.01468
G1 X112.089 Y118.817 E.01471
G1 X111.699 Y118.356 E.01469
G1 X109.855 Y115.169 E.08956
G1 X109.686 Y114.772 E.0105
G1 X109.572 Y114.224 E.01361
G1 X109.571 Y113.783 E.01073
G1 X109.641 Y113.379 E.00997
G1 X109.758 Y113.08 E.00781
G1 X109.758 Y113.08 F9000
G1 X109.446 Y112.88
;TYPE:Perimeter
G1 F6000
G1 X109.538 Y112.648 E.00607
G1 X111.309 Y109.58 E.08617
G1 X111.767 Y108.991 E.01815
G1 X112.201 Y108.631 E.01372
G1 X112.741 Y108.355 E.01475
G1 X113.413 Y108.185 E.01686
G1 X114.233 Y108.161 E.01995
G1 X117.373 Y108.164 E.07638
G1 X117.907 Y108.242 E.01313
G1 X118.455 Y108.44 E.01417
G1 X118.91 Y108.726 E.01307
G1 X119.14 Y108.9 E.00702
G1 X119.515 Y109.316 E.01362
G1 X121.423 Y112.58 E.09196
G1 X121.63 Y113.023 E.01189
G1 X121.755 Y113.491 E.01178
G1 X121.797 Y114.171 E.01657
G1 X121.71 Y114.711 E.0133
G1 X121.504 Y115.269 E.01447
G1 X119.583 Y118.591 E.09334
G1 X119.254 Y118.995 E.01267
G1 X118.774 Y119.382 E.015
G1 X118.33 Y119.619 E.01224
G1 X117.82 Y119.778 E.01299
G1 X117.373 Y119.836 E.01096
G1 X113.721 Y119.84 E.08883
G1 X113.089 Y119.755 E.01551
G1 X112.442 Y119.508 E.01685
G1 X111.873 Y119.112 E.01686
G1 X111.418 Y118.59 E.01684
G1 X109.538 Y115.352 E.09107
G1 X109.328 Y114.846 E.01333
G1 X109.214 Y114.298 E.01361
G1 X109.21 Y113.724 E.01396
G1 X109.3 Y113.248 E.01178
G1 X109.424 Y112.936 E.00817
G1 X109.424 Y112.936 F9000
G1 X109.119 Y112.739
G1 F6000
G1 X109.221 Y112.465 E.00711
G1 X110.992 Y109.397 E.08617
G1 X111.48 Y108.764 E.01944
G1 X111.92 Y108.383 E.01416
G1 X112.396 Y108.12 E.01323
G1 X112.786 Y107.953 E.01032
G1 X113.332 Y107.828 E.01362
G1 X114.219 Y107.796 E.02159
G1 X117.373 Y107.798 E.07672
G1 X117.872 Y107.86 E.01223
G1 X118.579 Y108.096 E.01813
G1 X119.114 Y108.423 E.01525
G1 X119.411 Y108.655 E.00917
G1 X119.787 Y109.07 E.01362
G1 X119.899 Y109.224 E.00463
G1 X121.739 Y112.396 E.0892
G1 X121.981 Y112.92 E.01404
G1 X122.12 Y113.461 E.01359
G1 X122.165 Y114.019 E.01362
G1 X122.159 Y114.222 E.00494
G1 X122.055 Y114.832 E.01505
G1 X121.82 Y115.452 E.01613
G1 X119.9 Y118.774 E.09333
G1 X119.572 Y119.188 E.01285
G1 X119.122 Y119.572 E.01439
G1 X118.845 Y119.769 E.00827
G1 X118.374 Y119.994 E.0127
G1 X117.872 Y120.14 E.01272
G1 X117.373 Y120.202 E.01223
G1 X113.722 Y120.206 E.08881
G1 X113.037 Y120.117 E.0168
G1 X112.49 Y119.923 E.01412
G1 X112.108 Y119.738 E.01032
G1 X111.657 Y119.407 E.01361
G1 X111.137 Y118.824 E.019
G1 X111.048 Y118.697 E.00377
G1 X109.221 Y115.535 E.08883
G1 X108.97 Y114.92 E.01616
G1 X108.856 Y114.372 E.01361
G1 X108.837 Y113.813 E.0136
G1 X108.91 Y113.296 E.0127
G1 X109.098 Y112.795 E.01302
G1 X109.098 Y112.795 F9000
G1 X108.774 Y112.59
G1 F6000
G1 X108.819 Y112.463 E.00328
G1 X108.905 Y112.282 E.00487
G1 X110.676 Y109.214 E.08617
G1 X111.193 Y108.537 E.02072
G1 X111.692 Y108.097 E.01618
G1 X112.23 Y107.794 E.01502
G1 X112.704 Y107.597 E.01249
G1 X113.25 Y107.472 E.01362
G1 X114.214 Y107.43 E.02347
G1 X117.374 Y107.432 E.07686
G1 X117.924 Y107.498 E.01347
G1 X118.457 Y107.663 E.01357
G1 X118.938 Y107.865 E.01269
G1 X119.446 Y108.205 E.01487
G1 X119.897 Y108.647 E.01536
G1 X120.215 Y109.041 E.01232
G1 X122.055 Y112.213 E.0892
G1 X122.331 Y112.817 E.01615
G1 X122.484 Y113.431 E.01539
G1 X122.53 Y113.989 E.01362
G1 X122.521 Y114.274 E.00694
G1 X122.4 Y114.953 E.01678
G1 X122.137 Y115.635 E.01778
G1 X120.216 Y118.957 E.09334
G1 X119.854 Y119.422 E.01433
G1 X119.35 Y119.857 E.01619
G1 X119.01 Y120.095 E.0101
G1 X118.484 Y120.342 E.01413
G1 X117.924 Y120.501 E.01416
G1 X117.374 Y120.568 E.01348
G1 X113.722 Y120.571 E.08883
G1 X113.211 Y120.511 E.01251
G1 X112.683 Y120.397 E.01314
G1 X112.165 Y120.185 E.01361
G1 X111.646 Y119.852 E.015
G1 X111.213 Y119.487 E.01378
G1 X110.855 Y119.057 E.01361
G1 X110.732 Y118.879 E.00526
G1 X108.905 Y115.718 E.08881
G1 X108.69 Y115.243 E.01268
G1 X108.498 Y114.446 E.01994
G1 X108.472 Y113.813 E.01541
G1 X108.549 Y113.237 E.01414
G1 X108.754 Y112.647 E.01519
G1 E-5 F3600
G1 X108.754 Y112.647 F9000
G1 X108.254 Y101.069
G1 E5 F2400
G1 F6000
G1 X108.14 Y100.52 E.01364
G1 X108.106 Y99.813 E.01722
G1 X108.188 Y99.177 E.0156
G1 X108.477 Y98.331 E.02175
G1 X108.588 Y98.1 E.00623
G1 X110.359 Y95.031 E.08619
G1 X110.906 Y94.311 E.02199
G1 X111.225 Y94.003 E.01079
G1 X111.676 Y93.672 E.01361
G1 X112.305 Y93.348 E.01721
G1 X113.169 Y93.115 E.02177
G1 X113.511 Y93.074 E.00838
G1 X117.373 Y93.067 E.09394
G1 X118.223 Y93.196 E.02091
G1 X118.89 Y93.432 E.01721
G1 X119.65 Y93.902 E.02174
G1 X120.056 Y94.278 E.01346
G1 X120.531 Y94.857 E.01822
G1 X122.372 Y98.029 E.08921
G1 X122.682 Y98.714 E.01829
G1 X122.827 Y99.235 E.01315
G1 X122.894 Y99.959 E.01769
G1 X122.884 Y100.325 E.00891
G1 X122.745 Y101.074 E.01853
G1 X122.545 Y101.634 E.01446
G1 X120.533 Y105.14 E.09832
G1 X120.135 Y105.656 E.01585
G1 X119.578 Y106.143 E.018
G1 X119.176 Y106.421 E.01189
G1 X118.594 Y106.691 E.01561
;WIDTH:0.409556
G1 X117.977 Y106.868 E.01602
;WIDTH:0.449313
G1 X117.887 Y106.901 E.00265
;WIDTH:0.489069
G1 X117.798 Y106.934 E.00287
;WIDTH:0.528826
G1 X117.708 Y106.967 E.00315
;WIDTH:0.568582
G1 X117.619 Y107 E.00337
G1 X117.773 Y107.049 E.00574
;WIDTH:0.526437
G1 X117.928 Y107.098 E.00532
;WIDTH:0.484291
G1 X118.083 Y107.147 E.00487
;WIDTH:0.442145
G1 X118.238 Y107.196 E.00441
;WIDTH:0.399999
G1 X118.827 Y107.408 E.01523
G1 X119.186 Y107.589 E.00978
G1 X119.65 Y107.902 E.01361
G1 X119.954 Y108.165 E.00978
G1 X120.329 Y108.58 E.01361
G1 X120.531 Y108.857 E.00834
G1 X122.372 Y112.029 E.08921
G1 X122.682 Y112.714 E.01829
G1 X122.849 Y113.401 E.0172
G1 X122.894 Y113.959 E.01362
G1 X122.884 Y114.325 E.00891
G1 X122.745 Y115.074 E.01853
G1 X122.454 Y115.818 E.01943
G1 X120.533 Y119.14 E.09334
G1 X120.135 Y119.656 E.01585
G1 X119.578 Y120.143 E.018
G1 X119.176 Y120.421 E.01189
G1 X118.594 Y120.691 E.01561
G1 X117.976 Y120.863 E.0156
;WIDTH:0.448816
G1 X117.825 Y120.909 E.00435
;WIDTH:0.497633
G1 X117.674 Y120.954 E.00486
;WIDTH:0.54645
G1 X117.522 Y121 E.00541
G1 X117.761 Y121.065 E.00844
;WIDTH:0.497633
G1 X117.999 Y121.131 E.00761
;WIDTH:0.448816
G1 X118.238 Y121.196 E.00683
;WIDTH:0.399999
G1 X118.827 Y121.408 E.01523
G1 X119.186 Y121.589 E.00978
G1 X119.65 Y121.902 E.01361
G1 X119.954 Y122.165 E.00978
G1 X120.329 Y122.58 E.01361
G1 X120.531 Y122.857 E.00834
G1 X122.372 Y126.029 E.08921
G1 X122.682 Y126.714 E.01829
G1 X122.849 Y127.401 E.0172
G1 X122.894 Y127.959 E.01362
G1 X122.884 Y128.325 E.00891
G1 X122.745 Y129.074 E.01853
G1 X122.454 Y129.818 E.01943
G1 X120.533 Y133.14 E.09334
G1 X120.135 Y133.656 E.01585
G1 X119.458 Y134.24 E.02175
G1 X118.842 Y134.59 E.01723
G1 X118.238 Y134.804 E.01559
G1 X117.607 Y134.917 E.01559
G1 X117.374 Y134.933 E.00568
G1 X113.721 Y134.937 E.08886
G1 X112.932 Y134.841 E.01933
G1 X112.545 Y134.735 E.00976
G1 X112.027 Y134.524 E.01361
G1 X111.676 Y134.327 E.00979
G1 X111.224 Y133.996 E.01363
G1 X110.932 Y133.721 E.00976
G1 X110.574 Y133.291 E.01361
G1 X110.415 Y133.062 E.00678
G1 X108.588 Y129.901 E.08881
G1 X108.354 Y129.388 E.01372
G1 X108.14 Y128.52 E.02175
G1 X108.106 Y127.813 E.01722
G1 X108.188 Y127.177 E.0156
G1 X108.477 Y126.331 E.02175
G1 X108.588 Y126.099 E.00626
G1 X110.359 Y123.031 E.08617
G1 X110.906 Y122.311 E.02199
G1 X111.265 Y121.97 E.01204
G1 X111.745 Y121.63 E.01431
G1 X112.245 Y121.377 E.01363
G1 X112.623 Y121.24 E.00978
;WIDTH:0.425874
G1 X113.166 Y121.103 E.01459
;WIDTH:0.469176
G1 X113.269 Y121.068 E.00315
;WIDTH:0.512477
G1 X113.372 Y121.033 E.00346
;WIDTH:0.555778
G1 X113.475 Y120.997 E.00378
G1 X113.34 Y120.958 E.00487
;WIDTH:0.516834
G1 X113.204 Y120.919 E.00454
;WIDTH:0.477889
G1 X113.068 Y120.88 E.00417
;WIDTH:0.438944
G1 X112.933 Y120.841 E.00378
;WIDTH:0.399999
G1 X112.545 Y120.735 E.00978
G1 X112.027 Y120.524 E.01361
G1 X111.676 Y120.328 E.00978
G1 X111.224 Y119.996 E.01364
G1 X110.891 Y119.671 E.01132
G1 X110.415 Y119.062 E.0188
G1 X108.588 Y115.901 E.08881
G1 X108.354 Y115.388 E.01372
G1 X108.14 Y114.52 E.02175
G1 X108.106 Y113.813 E.01722
G1 X108.188 Y113.177 E.0156
G1 X108.477 Y112.331 E.02175
G1 X108.588 Y112.1 E.00623
G1 X110.359 Y109.031 E.08619
G1 X110.906 Y108.311 E.02199
G1 X111.265 Y107.97 E.01204
G1 X111.745 Y107.63 E.01431
G1 X112.245 Y107.377 E.01363
G1 X112.623 Y107.24 E.00978
;WIDTH:0.425892
G1 X113.166 Y107.103 E.01459
;WIDTH:0.46919
G1 X113.269 Y107.068 E.00315
;WIDTH:0.512487
G1 X113.372 Y107.033 E.00346
;WIDTH:0.555784
G1 X113.475 Y106.997 E.00378
G1 X113.339 Y106.958 E.00491
;WIDTH:0.516838
G1 X113.204 Y106.919 E.00451
;WIDTH:0.477892
G1 X113.068 Y106.88 E.00417
;WIDTH:0.438946
G1 X112.932 Y106.841 E.00381
;WIDTH:0.399999
G1 X112.545 Y106.735 E.00976
G1 X112.027 Y106.524 E.01361
G1 X111.676 Y106.327 E.00979
G1 X111.224 Y105.996 E.01363
G1 X110.891 Y105.671 E.01132
G1 X110.415 Y105.062 E.0188
G1 X108.588 Y101.901 E.08881
G1 X108.456 Y101.624 E.00746
G1 X108.274 Y101.125 E.01292
G1 E-5 F3600
G1 X108.274 Y101.125 F9000
G1 X109.221 Y114.23
G1 X109.249 Y114.459
G1 X109.296 Y114.684
G1 X109.361 Y114.905
G1 X109.444 Y115.12
G1 X109.544 Y115.33
G1 X110.457 Y116.912
G1 X111.33 Y118.422
G1 X111.392 Y118.526
G1 X111.525 Y118.715
G1 X111.672 Y118.892
G1 X111.833 Y119.057
G1 X112.007 Y119.208
G1 X112.193 Y119.344
G1 X112.389 Y119.465
G1 X112.595 Y119.569
G1 X112.808 Y119.656
G1 X113.028 Y119.725
G1 X117.522 Y121
G1 E5 F2400
;WIDTH:0.54645
G1 F6000
G1 X117.374 Y121 E.00504
;WIDTH:0.53337
G1 X114.23 Y121 E.10437
;WIDTH:0.534266
G1 X113.722 Y121.004 E.01689
;WIDTH:0.555778
G1 X113.475 Y120.997 E.00857
G1 E-5 F3600
G1 X113.475 Y120.997 F9000
G1 X111.33 Y118.422
G1 X109.544 Y115.33
G1 X109.444 Y115.12
G1 X109.221 Y114.23
G1 X109.212 Y114
G1 X109.221 Y113.77
G1 X109.249 Y113.541
G1 X109.296 Y113.316
G1 X109.361 Y113.095
G1 X109.444 Y112.88
G1 X109.544 Y112.67
G1 X110.457 Y111.088
G1 X111.33 Y109.578
G1 X111.391 Y109.474
G1 X111.525 Y109.285
G1 X111.672 Y109.108
G1 X111.833 Y108.943
G1 X112.007 Y108.792
G1 X112.193 Y108.656
G1 X112.389 Y108.535
G1 X112.595 Y108.431
G1 X112.808 Y108.344
G1 X113.028 Y108.275
G1 X117.619 Y107
G1 E5 F2400
;WIDTH:0.568582
G1 F6000
G1 X114.233 Y107 E.12033
;WIDTH:0.527734
G1 X114.207 Y107 E.00085
;WIDTH:0.555784
G1 X113.475 Y106.997 E.02539
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X114.207 Y107 E-.3477
G1 X114.233 Y107 E-.01235
G1 X116.633 Y107 E-1.13995
;WIPE_END
G1 X112.808 Y105.656 F9000
G1 X112.595 Y105.569
G1 X112.389 Y105.465
G1 X112.193 Y105.344
G1 X112.007 Y105.208
G1 X111.833 Y105.057
G1 X111.672 Y104.892
G1 X111.525 Y104.715
G1 X111.391 Y104.526
G1 X111.33 Y104.422
G1 X110.538 Y103.053
G1 X109.545 Y101.33
G1 X109.444 Y101.12
G1 X109.438 Y101.107
G1 X109.772 Y100.979
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X109.686 Y100.772 E.00545
G1 X109.572 Y100.224 E.01361
G1 X109.587 Y99.685 E.01312
G1 X109.647 Y99.365 E.00792
G1 X109.855 Y98.831 E.01394
G1 X111.626 Y95.763 E.08617
G1 X112.054 Y95.217 E.01687
G1 X112.541 Y94.852 E.0148
G1 X112.948 Y94.666 E.01088
G1 X113.494 Y94.541 E.01362
G1 X117.372 Y94.529 E.09433
G1 X117.956 Y94.635 E.01444
G1 X118.37 Y94.804 E.01088
G1 X118.835 Y95.116 E.01362
G1 X119.266 Y95.591 E.0156
G1 X121.107 Y98.763 E.08921
G1 X121.303 Y99.209 E.01185
G1 X121.391 Y99.52 E.00786
G1 X121.437 Y100.079 E.01364
G1 X121.365 Y100.59 E.01255
G1 X121.198 Y101.066 E.01227
G1 X119.266 Y104.408 E.0939
G1 X118.983 Y104.747 E.01074
G1 X118.546 Y105.096 E.0136
G1 X118.153 Y105.296 E.01073
G1 X117.768 Y105.416 E.00981
G1 X117.372 Y105.471 E.00972
G1 X113.721 Y105.474 E.08881
G1 X113.141 Y105.393 E.01424
G1 X112.58 Y105.17 E.01468
G1 X112.089 Y104.817 E.01471
G1 X111.681 Y104.331 E.01543
G1 X109.855 Y101.169 E.08882
G1 X109.799 Y101.043 E.00335
G1 X109.795 Y101.034 E.00024
G1 X109.437 Y101.123 F9000
;TYPE:Perimeter
G1 F6000
G1 X109.328 Y100.846 E.00724
G1 X109.214 Y100.298 E.01361
G1 X109.21 Y99.724 E.01396
G1 X109.305 Y99.234 E.01214
G1 X109.538 Y98.648 E.01534
G1 X111.309 Y95.58 E.08617
G1 X111.767 Y94.991 E.01815
G1 X112.325 Y94.557 E.01719
G1 X112.867 Y94.31 E.01449
G1 X113.413 Y94.185 E.01362
G1 X114.233 Y94.161 E.01995
G1 X117.373 Y94.164 E.07638
G1 X118.023 Y94.275 E.01604
G1 X118.574 Y94.5 E.01448
G1 X119.039 Y94.812 E.01362
G1 X119.515 Y95.316 E.01686
G1 X119.583 Y95.408 E.00278
G1 X121.423 Y98.58 E.0892
G1 X121.654 Y99.106 E.01397
G1 X121.755 Y99.491 E.00968
G1 X121.801 Y100.049 E.01362
G1 X121.736 Y100.606 E.01364
G1 X121.547 Y101.176 E.01461
G1 X119.583 Y104.591 E.09582
G1 X119.254 Y104.995 E.01267
G1 X118.774 Y105.382 E.015
G1 X118.33 Y105.619 E.01224
G1 X117.82 Y105.778 E.01299
G1 X117.373 Y105.836 E.01096
G1 X113.721 Y105.84 E.08883
G1 X113.089 Y105.755 E.01551
G1 X112.441 Y105.508 E.01687
G1 X111.873 Y105.112 E.01684
G1 X111.365 Y104.514 E.01909
G1 X109.538 Y101.352 E.08883
G1 X109.463 Y101.188 E.00439
G1 X109.46 Y101.179 E.00023
G1 X109.46 Y101.179 F9000
G1 X109.103 Y101.268
G1 F6000
G1 X108.97 Y100.921 E.00904
G1 X108.856 Y100.372 E.01364
G1 X108.837 Y99.813 E.0136
G1 X108.91 Y99.296 E.0127
G1 X109.221 Y98.465 E.02158
G1 X110.992 Y95.397 E.08617
G1 X111.48 Y94.764 E.01944
G1 X112.109 Y94.262 E.01958
G1 X112.609 Y94.013 E.01359
G1 X113.332 Y93.828 E.01815
G1 X114.219 Y93.796 E.02159
G1 X117.373 Y93.798 E.07672
G1 X118.089 Y93.916 E.01765
G1 X118.614 Y94.109 E.01361
G1 X119.243 Y94.509 E.01813
G1 X119.787 Y95.07 E.01901
G1 X119.899 Y95.224 E.00463
G1 X121.739 Y98.396 E.0892
G1 X121.981 Y98.92 E.01404
G1 X122.116 Y99.425 E.01271
G1 X122.165 Y100.019 E.0145
G1 X122.098 Y100.658 E.01563
G1 X121.892 Y101.298 E.01635
G1 X121.569 Y101.888 E.01636
G1 X119.9 Y104.774 E.08109
G1 X119.572 Y105.188 E.01285
G1 X119.122 Y105.572 E.01439
G1 X118.845 Y105.769 E.00827
G1 X118.374 Y105.994 E.0127
G1 X117.872 Y106.14 E.01272
G1 X117.373 Y106.202 E.01223
G1 X113.722 Y106.206 E.08881
G1 X113.037 Y106.117 E.0168
G1 X112.49 Y105.923 E.01412
G1 X112.108 Y105.738 E.01032
G1 X111.657 Y105.407 E.01361
G1 X111.137 Y104.823 E.01902
G1 X111.048 Y104.697 E.00375
G1 X109.221 Y101.535 E.08883
G1 X109.128 Y101.333 E.00541
G1 X109.124 Y101.324 E.00024
G1 X108.767 Y101.413 F9000
G1 F6000
G1 X108.612 Y100.995 E.01084
G1 X108.498 Y100.446 E.01364
G1 X108.472 Y99.813 E.01541
G1 X108.549 Y99.237 E.01414
G1 X108.819 Y98.463 E.01994
G1 X108.905 Y98.282 E.00487
G1 X110.676 Y95.214 E.08617
G1 X111.193 Y94.538 E.0207
G1 X111.441 Y94.298 E.00839
G1 X111.893 Y93.967 E.01363
G1 X112.457 Y93.68 E.01539
G1 X113.25 Y93.472 E.01994
G1 X114.214 Y93.43 E.02347
G1 X117.373 Y93.432 E.07684
G1 X118.156 Y93.556 E.01928
G1 X118.752 Y93.771 E.01541
G1 X119.446 Y94.205 E.01991
G1 X120.058 Y94.825 E.02119
G1 X120.215 Y95.041 E.0065
G1 X122.055 Y98.213 E.0892
G1 X122.331 Y98.817 E.01615
G1 X122.467 Y99.302 E.01225
G1 X122.53 Y99.989 E.01678
G1 X122.46 Y100.709 E.0176
G1 X122.237 Y101.419 E.0181
G1 X121.885 Y102.071 E.01802
G1 X120.216 Y104.957 E.08109
G1 X119.854 Y105.422 E.01433
G1 X119.35 Y105.857 E.01619
G1 X119.01 Y106.095 E.0101
G1 X118.484 Y106.342 E.01413
G1 X117.924 Y106.501 E.01416
G1 X117.374 Y106.568 E.01348
G1 X113.722 Y106.571 E.08883
G1 X113.211 Y106.511 E.01251
G1 X112.683 Y106.397 E.01314
G1 X112.165 Y106.185 E.01361
G1 X111.646 Y105.852 E.015
G1 X111.213 Y105.487 E.01378
G1 X110.855 Y105.057 E.01361
G1 X110.732 Y104.879 E.00526
G1 X108.905 Y101.718 E.08881
G1 X108.792 Y101.479 E.00643
G1 X108.788 Y101.469 E.00026
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X108.767 Y101.413 E-.02841
G1 X108.612 Y100.995 E-.21176
G1 X108.498 Y100.446 E-.26634
G1 X108.472 Y99.813 E-.30093
G1 X108.549 Y99.237 E-.27603
G1 X108.819 Y98.463 E-.38938
G1 X108.843 Y98.411 E-.02715
;WIPE_END
G1 X109.212 Y114 F9000
G1 X109.221 Y114.23
G1 X109.384 Y114.965
G1 X109.438 Y126.893
G1 X109.778 Y127.024
G1 E5 F2400
G1 F6000
G1 X109.842 Y126.856 E.00437
G1 X111.626 Y123.763 E.08685
G1 X112.054 Y123.217 E.01687
G1 X112.407 Y122.934 E.01101
G1 X112.906 Y122.681 E.01361
G1 X113.494 Y122.541 E.0147
G1 X117.373 Y122.529 E.09435
G1 X117.804 Y122.593 E.0106
G1 X118.33 Y122.783 E.0136
G1 X118.835 Y123.116 E.01471
G1 X119.266 Y123.591 E.0156
G1 X121.107 Y126.763 E.08921
G1 X121.279 Y127.126 E.00977
G1 X121.391 Y127.52 E.00996
G1 X121.437 Y128.079 E.01364
G1 X121.365 Y128.59 E.01255
G1 X121.187 Y129.086 E.01282
G1 X119.266 Y132.408 E.09334
G1 X118.983 Y132.747 E.01074
G1 X118.546 Y133.096 E.0136
G1 X118.153 Y133.296 E.01073
G1 X117.768 Y133.416 E.00981
G1 X117.373 Y133.471 E.0097
G1 X113.695 Y133.473 E.08946
G1 X113.141 Y133.393 E.01362
G1 X112.58 Y133.17 E.01468
G1 X112.089 Y132.817 E.01471
G1 X111.681 Y132.331 E.01543
G1 X109.855 Y129.169 E.08882
G1 X109.686 Y128.772 E.0105
G1 X109.572 Y128.224 E.01361
G1 X109.571 Y127.783 E.01073
G1 X109.641 Y127.379 E.00997
G1 X109.756 Y127.08 E.00779
G1 X109.756 Y127.08 F9000
G1 X109.442 Y126.879
;TYPE:Perimeter
G1 F6000
G1 X109.501 Y126.725 E.00401
G1 X111.309 Y123.58 E.08824
G1 X111.767 Y122.991 E.01815
G1 X112.201 Y122.631 E.01372
G1 X112.741 Y122.355 E.01475
G1 X113.413 Y122.185 E.01686
G1 X114.233 Y122.161 E.01995
G1 X117.373 Y122.164 E.07638
G1 X117.907 Y122.242 E.01313
G1 X118.455 Y122.44 E.01417
G1 X118.91 Y122.726 E.01307
G1 X119.14 Y122.9 E.00702
G1 X119.583 Y123.408 E.0164
G1 X121.423 Y126.58 E.0892
G1 X121.63 Y127.023 E.01189
G1 X121.755 Y127.491 E.01178
G1 X121.801 Y128.049 E.01362
G1 X121.736 Y128.606 E.01364
G1 X121.547 Y129.176 E.01461
G1 X119.583 Y132.591 E.09582
G1 X119.211 Y133.033 E.01405
G1 X118.774 Y133.382 E.0136
G1 X118.264 Y133.645 E.01396
G1 X117.82 Y133.778 E.01127
G1 X117.373 Y133.836 E.01096
G1 X113.643 Y133.835 E.09073
G1 X113.089 Y133.755 E.01362
G1 X112.441 Y133.508 E.01687
G1 X111.873 Y133.112 E.01684
G1 X111.365 Y132.514 E.01909
G1 X109.538 Y129.352 E.08883
G1 X109.328 Y128.846 E.01333
G1 X109.214 Y128.298 E.01361
G1 X109.21 Y127.724 E.01396
G1 X109.3 Y127.248 E.01178
G1 X109.42 Y126.935 E.00815
G1 X109.42 Y126.935 F9000
G1 X109.11 Y126.735
G1 F6000
G1 X109.16 Y126.594 E.00364
G1 X110.992 Y123.397 E.08963
G1 X111.48 Y122.764 E.01944
G1 X111.92 Y122.383 E.01416
G1 X112.396 Y122.12 E.01323
G1 X112.786 Y121.953 E.01032
G1 X113.332 Y121.828 E.01362
G1 X114.233 Y121.795 E.02193
G1 X117.373 Y121.798 E.07638
G1 X117.872 Y121.86 E.01223
G1 X118.579 Y122.096 E.01813
G1 X119.114 Y122.423 E.01525
G1 X119.411 Y122.655 E.00917
G1 X119.787 Y123.07 E.01362
G1 X119.899 Y123.224 E.00463
G1 X121.739 Y126.396 E.0892
G1 X121.981 Y126.92 E.01404
G1 X122.12 Y127.461 E.01359
G1 X122.165 Y128.019 E.01362
G1 X122.098 Y128.658 E.01563
G1 X121.892 Y129.298 E.01635
G1 X121.82 Y129.452 E.00414
G1 X119.9 Y132.774 E.09333
G1 X119.572 Y133.188 E.01285
G1 X119.002 Y133.668 E.01813
G1 X118.512 Y133.937 E.0136
G1 X118.017 Y134.106 E.01272
G1 X117.503 Y134.193 E.01268
G1 X113.59 Y134.196 E.09518
G1 X113.037 Y134.117 E.01359
G1 X112.303 Y133.847 E.01902
G1 X111.657 Y133.407 E.01901
G1 X111.137 Y132.824 E.019
G1 X111.048 Y132.697 E.00377
G1 X109.221 Y129.535 E.08883
G1 X108.97 Y128.921 E.01613
G1 X108.856 Y128.372 E.01364
G1 X108.837 Y127.813 E.0136
G1 X108.91 Y127.296 E.0127
G1 X109.089 Y126.792 E.01301
G1 X109.089 Y126.792 F9000
G1 X108.774 Y126.59
G1 F6000
G1 X108.819 Y126.463 E.00328
G1 X108.905 Y126.282 E.00487
G1 X110.676 Y123.214 E.08617
G1 X111.193 Y122.537 E.02072
G1 X111.692 Y122.097 E.01618
G1 X112.231 Y121.794 E.01504
G1 X112.704 Y121.597 E.01246
G1 X113.25 Y121.472 E.01362
G1 X114.214 Y121.43 E.02347
G1 X117.374 Y121.432 E.07686
G1 X117.924 Y121.498 E.01347
G1 X118.457 Y121.663 E.01357
G1 X118.938 Y121.865 E.01269
G1 X119.446 Y122.205 E.01487
G1 X119.897 Y122.647 E.01536
G1 X120.215 Y123.041 E.01232
G1 X122.055 Y126.213 E.0892
G1 X122.331 Y126.817 E.01615
G1 X122.484 Y127.431 E.01539
G1 X122.53 Y127.989 E.01362
G1 X122.46 Y128.709 E.0176
G1 X122.237 Y129.419 E.0181
G1 X122.137 Y129.635 E.00579
G1 X120.216 Y132.957 E.09334
G1 X119.854 Y133.422 E.01433
G1 X119.23 Y133.954 E.01995
G1 X118.677 Y134.264 E.01542
G1 X118.128 Y134.455 E.01414
G1 X117.555 Y134.555 E.01415
G1 X113.721 Y134.571 E.09326
G1 X113.538 Y134.558 E.00446
G1 X112.985 Y134.479 E.01359
G1 X112.165 Y134.185 E.02119
G1 X111.441 Y133.702 E.02117
G1 X111.213 Y133.487 E.00762
G1 X110.855 Y133.057 E.01361
G1 X110.732 Y132.879 E.00526
G1 X108.905 Y129.718 E.08881
G1 X108.69 Y129.243 E.01268
G1 X108.498 Y128.446 E.01994
G1 X108.472 Y127.813 E.01541
G1 X108.549 Y127.237 E.01414
G1 X108.754 Y126.647 E.01519
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X108.774 Y126.59 E-.02869
G1 X108.819 Y126.463 E-.064
G1 X108.905 Y126.282 E-.09519
G1 X110.286 Y123.89 E-1.31212
;WIPE_END
G1 X106.099 Y135.059 F9000
G1 X106.099 Y136.074
G1 X105.718 Y136.074
G1 E5 F2400
G1 F6000
G1 X105.75 Y136.004 E.00187
G1 X105.75 Y103.607 E.78802
G1 X105.727 Y103.518 E.00224
G1 X105.567 Y103.424 E.00451
G1 X105.188 Y103.424 E.00922
G1 X105.188 Y98.824 E.11189
G1 X105.567 Y98.824 E.00922
G1 X105.707 Y98.76 E.00374
G1 X105.75 Y98.643 E.00303
G1 X105.75 Y91.996 E.16168
G1 X105.687 Y91.858 E.00369
G1 X104.966 Y91.231 E.02324
G1 X104.499 Y90.782 E.01576
G1 X104.326 Y90.54 E.00724
G1 X104.357 Y90.406 E.00335
G1 X104.7 Y90.014 E.01267
G1 X105.576 Y89.239 E.02845
G1 X125.425 Y89.239 E.48281
G1 X126.402 Y90.115 E.03192
G1 X126.644 Y90.414 E.00936
G1 X126.674 Y90.535 E.00303
G1 X126.435 Y90.854 E.0097
G1 X126.035 Y91.23 E.01335
G1 X125.313 Y91.858 E.02328
G1 X125.25 Y91.996 E.00369
G1 X125.25 Y98.555 E.15954
G1 X125.281 Y98.743 E.00463
G1 X125.433 Y98.824 E.00419
G1 X125.812 Y98.824 E.00922
G1 X125.812 Y103.424 E.11189
G1 X125.433 Y103.424 E.00922
G1 X125.29 Y103.493 E.00386
G1 X125.25 Y103.607 E.00294
G1 X125.25 Y136.004 E.78802
G1 X125.313 Y136.142 E.00369
G1 X126.034 Y136.77 E.02326
G1 X126.501 Y137.218 E.01574
G1 X126.645 Y137.417 E.00597
G1 X126.671 Y137.512 E.0024
G1 X126.643 Y137.594 E.00211
G1 X126.3 Y137.986 E.01267
G1 X125.424 Y138.761 E.02845
G1 X105.575 Y138.761 E.48281
G1 X104.598 Y137.885 E.03192
G1 X104.356 Y137.586 E.00936
G1 X104.326 Y137.465 E.00303
G1 X104.565 Y137.146 E.0097
G1 X104.965 Y136.77 E.01335
G1 X105.687 Y136.142 E.02328
G1 X105.693 Y136.128 E.00037
G1 X105.693 Y136.128 F9000
G1 X106.057 Y136.232
;TYPE:Perimeter
G1 F6000
G1 X106.079 Y136.2 E.00094
G1 X106.116 Y136.004 E.00485
G1 X106.116 Y103.607 E.78802
G1 X106.098 Y103.471 E.00334
G1 X106.011 Y103.286 E.00497
G1 X105.554 Y103.059 E.01241
G1 X105.554 Y99.204 E.09377
G1 X105.986 Y98.996 E.01166
G1 X106.076 Y98.846 E.00425
G1 X106.116 Y98.645 E.00498
G1 X106.116 Y91.996 E.16173
G1 X106.079 Y91.8 E.00485
G1 X105.927 Y91.582 E.00646
G1 X105.213 Y90.961 E.02302
G1 X104.751 Y90.516 E.0156
G1 X104.951 Y90.28 E.00752
G1 X105.714 Y89.604 E.0248
G1 X125.288 Y89.604 E.47612
G1 X125.802 Y90.053 E.0166
G1 X126.246 Y90.497 E.01527
G1 X126.161 Y90.61 E.00344
G1 X125.79 Y90.958 E.01237
G1 X125.073 Y91.582 E.02312
G1 X124.921 Y91.8 E.00646
G1 X124.884 Y91.996 E.00485
G1 X124.884 Y98.19 E.15066
G1 X124.899 Y98.769 E.01409
G1 X125.014 Y98.996 E.00619
G1 X125.446 Y99.19 E.01152
G1 X125.446 Y103.045 E.09377
G1 X125.004 Y103.266 E.01202
G1 X124.964 Y103.322 E.00167
G1 X124.884 Y103.607 E.0072
G1 X124.884 Y136.004 E.78802
G1 X124.921 Y136.2 E.00485
G1 X125.073 Y136.418 E.00646
G1 X125.798 Y137.05 E.02339
G1 X126.262 Y137.502 E.01576
G1 X126.049 Y137.72 E.00741
G1 X125.286 Y138.396 E.0248
G1 X105.712 Y138.396 E.47612
G1 X105.197 Y137.946 E.01664
G1 X104.754 Y137.503 E.01524
G1 X104.839 Y137.39 E.00344
G1 X105.21 Y137.042 E.01237
G1 X105.927 Y136.418 E.02312
G1 X106.023 Y136.281 E.00407
G1 X106.023 Y136.281 F9000
G1 X106.384 Y136.384
G1 F6000
G1 X106.421 Y136.332 E.00155
G1 X106.481 Y136.004 E.00811
G1 X106.481 Y103.607 E.78802
G1 X106.453 Y103.38 E.00556
G1 X106.308 Y103.071 E.0083
G1 X105.919 Y102.863 E.01073
G1 X105.919 Y99.392 E.08443
G1 X106.265 Y99.232 E.00927
G1 X106.415 Y98.983 E.00707
G1 X106.481 Y98.648 E.00831
G1 X106.481 Y91.996 E.1618
G1 X106.421 Y91.668 E.00811
G1 X106.167 Y91.307 E.01074
G1 X105.258 Y90.497 E.02962
G1 X105.853 Y89.97 E.01933
G1 X125.151 Y89.97 E.4694
G1 X125.744 Y90.5 E.01935
G1 X124.833 Y91.307 E.0296
G1 X124.579 Y91.668 E.01074
G1 X124.519 Y91.996 E.00811
G1 X124.519 Y98.555 E.15954
G1 X124.558 Y98.908 E.00864
G1 X124.735 Y99.232 E.00898
G1 X125.081 Y99.393 E.00928
G1 X125.081 Y102.863 E.0844
G1 X124.717 Y103.038 E.00982
G1 X124.574 Y103.293 E.00711
G1 X124.519 Y103.607 E.00775
G1 X124.519 Y136.004 E.78802
G1 X124.579 Y136.332 E.00811
G1 X124.833 Y136.693 E.01074
G1 X125.742 Y137.503 E.02962
G1 X125.147 Y138.03 E.01933
G1 X105.849 Y138.03 E.4694
G1 X105.256 Y137.5 E.01935
G1 X106.167 Y136.693 E.0296
G1 X106.35 Y136.433 E.00773
G1 X106.35 Y136.433 F9000
G1 X106.711 Y136.536
G1 F6000
G1 X106.762 Y136.463 E.00217
G1 X106.847 Y136.004 E.01135
G1 X106.847 Y103.607 E.78802
G1 X106.769 Y103.168 E.01085
G1 X106.604 Y102.857 E.00856
G1 X106.285 Y102.674 E.00895
G1 X106.285 Y99.589 E.07504
G1 X106.544 Y99.469 E.00694
G1 X106.775 Y99.065 E.01132
G1 X106.847 Y98.65 E.01025
G1 X106.847 Y91.996 E.16185
G1 X106.762 Y91.537 E.01135
G1 X106.407 Y91.031 E.01503
G1 X105.802 Y90.504 E.01952
G1 X105.992 Y90.336 E.00617
G1 X125.014 Y90.336 E.46269
G1 X125.203 Y90.5 E.00609
G1 X124.593 Y91.031 E.01967
G1 X124.238 Y91.537 E.01503
G1 X124.153 Y91.996 E.01135
G1 X124.153 Y98.642 E.16166
G1 X124.224 Y99.063 E.01039
G1 X124.456 Y99.469 E.01137
G1 X124.715 Y99.589 E.00694
G1 X124.715 Y102.674 E.07504
G1 X124.431 Y102.81 E.00766
G1 X124.231 Y103.168 E.00997
G1 X124.153 Y103.607 E.01085
G1 X124.153 Y136.004 E.78802
G1 X124.238 Y136.463 E.01135
G1 X124.593 Y136.969 E.01503
G1 X125.198 Y137.496 E.01952
G1 X125.008 Y137.664 E.00617
G1 X105.986 Y137.664 E.46269
G1 X105.797 Y137.5 E.00609
G1 X106.407 Y136.969 E.01967
G1 X106.676 Y136.585 E.0114
G1 X106.676 Y136.585 F9000
G1 X107.037 Y136.688
G1 F6000
G1 X107.103 Y136.594 E.00279
G1 X107.213 Y136.004 E.0146
G1 X107.213 Y103.607 E.78802
G1 X107.113 Y103.043 E.01393
G1 X106.855 Y102.583 E.01283
G1 X106.651 Y102.484 E.00552
G1 X106.651 Y99.785 E.06565
G1 X106.823 Y99.705 E.00461
G1 X107.094 Y99.256 E.01276
G1 X107.176 Y98.986 E.00686
G1 X107.213 Y98.642 E.00842
G1 X107.213 Y91.996 E.16166
G1 X107.103 Y91.406 E.0146
G1 X106.586 Y90.701 E.02127
G1 X124.414 Y90.701 E.43365
G1 X124.353 Y90.755 E.00198
G1 X123.897 Y91.406 E.01933
G1 X123.787 Y91.996 E.0146
G1 X123.787 Y98.19 E.15066
G1 X123.802 Y98.857 E.01623
G1 X123.879 Y99.183 E.00815
G1 X124.177 Y99.705 E.01462
G1 X124.349 Y99.785 E.00461
G1 X124.349 Y102.484 E.06565
G1 X124.145 Y102.583 E.00552
G1 X123.887 Y103.042 E.01281
G1 X123.787 Y103.607 E.01396
G1 X123.787 Y136.004 E.78802
G1 X123.897 Y136.594 E.0146
G1 X124.414 Y137.299 E.02127
G1 X106.586 Y137.299 E.43365
G1 X106.647 Y137.245 E.00198
G1 X107.003 Y136.737 E.01509
G1 X107.003 Y136.737 F9000
G1 X107.539 Y137.189
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X107.231 Y136.881 E.0106
G1 X107.36 Y136.696 E.00549
G1 X107.392 Y136.523 E.00428
G1 X107.894 Y137.025 E.01727
G1 X108.413 Y137.025 E.01262
G1 X107.473 Y136.085 E.03234
G1 X107.487 Y135.579 E.01231
G1 X108.932 Y137.025 E.04972
G1 X109.451 Y137.025 E.01262
G1 X107.487 Y135.06 E.06758
G1 X107.487 Y134.541 E.01262
G1 X109.971 Y137.025 E.08545
G1 X110.49 Y137.025 E.01262
G1 X107.487 Y134.022 E.1033
G1 X107.487 Y133.503 E.01262
G1 X111.009 Y137.025 E.12115
G1 X111.528 Y137.025 E.01262
G1 X107.487 Y132.983 E.13903
G1 X107.487 Y132.464 E.01262
G1 X112.047 Y137.025 E.15688
G1 X112.566 Y137.025 E.01262
G1 X107.487 Y131.945 E.17473
G1 X107.487 Y131.426 E.01262
G1 X113.086 Y137.025 E.1926
G1 X113.605 Y137.025 E.01262
G1 X107.487 Y130.907 E.21046
G1 X107.487 Y130.388 E.01262
G1 X110.014 Y132.915 E.08693
G1 X110.361 Y133.463 E.01578
G1 X110.755 Y133.937 E.01499
G1 X111.058 Y134.215 E.01
G1 X111.82 Y134.721 E.02225
G1 X114.124 Y137.025 E.07926
G1 X114.643 Y137.025 E.01262
G1 X112.671 Y135.052 E.06785
G1 X113.31 Y135.172 E.01581
G1 X115.162 Y137.025 E.06372
G1 X115.681 Y137.025 E.01262
G1 X113.868 Y135.211 E.06238
G1 X114.387 Y135.211 E.01262
G1 X116.2 Y137.025 E.06238
G1 X116.72 Y137.025 E.01265
G1 X114.905 Y135.21 E.06243
G1 X115.424 Y135.21 E.01262
G1 X117.239 Y137.025 E.06243
G1 X117.758 Y137.025 E.01262
G1 X115.942 Y135.209 E.06247
G1 X116.461 Y135.208 E.01262
G1 X118.277 Y137.025 E.06249
G1 X118.796 Y137.025 E.01262
G1 X116.98 Y135.208 E.06249
G1 X117.49 Y135.199 E.01241
G1 X119.315 Y137.025 E.0628
G1 X119.835 Y137.025 E.01265
G1 X117.953 Y135.143 E.06474
G1 X118.377 Y135.047 E.01057
G1 X120.354 Y137.025 E.06802
G1 X120.873 Y137.025 E.01262
G1 X118.765 Y134.917 E.07251
G1 X119.123 Y134.755 E.00956
G1 X121.392 Y137.025 E.07807
G1 X121.911 Y137.025 E.01262
G1 X119.454 Y134.567 E.08454
G1 X119.757 Y134.351 E.00905
G1 X122.43 Y137.025 E.09197
G1 X122.95 Y137.025 E.01265
G1 X120.046 Y134.121 E.0999
G1 X120.311 Y133.866 E.00895
G1 X123.469 Y137.025 E.10865
G1 X123.87 Y137.025 E.00975
G1 X123.635 Y136.672 E.01032
G1 X120.549 Y133.586 E.10616
G1 X120.766 Y133.284 E.00905
G1 X123.517 Y136.035 E.09463
G1 X123.513 Y135.511 E.01275
G1 X120.957 Y132.955 E.08792
G1 X121.147 Y132.626 E.00924
G1 X123.513 Y134.992 E.08139
G1 X123.513 Y134.473 E.01262
G1 X121.337 Y132.297 E.07485
G1 X121.527 Y131.968 E.00924
G1 X123.513 Y133.954 E.06832
G1 X123.513 Y133.435 E.01262
G1 X121.718 Y131.639 E.06176
G1 X121.908 Y131.31 E.00924
G1 X123.513 Y132.916 E.05523
G1 X123.513 Y132.396 E.01265
G1 X122.098 Y130.981 E.04868
G1 X122.288 Y130.652 E.00924
G1 X123.513 Y131.877 E.04214
G1 X123.513 Y131.358 E.01262
G1 X122.478 Y130.323 E.0356
G1 X122.669 Y129.994 E.00925
G1 X123.513 Y130.839 E.02905
G1 X123.513 Y130.32 E.01262
G1 X122.836 Y129.642 E.02331
G1 X122.971 Y129.259 E.00988
G1 X123.513 Y129.801 E.01864
G1 X123.513 Y129.281 E.01265
G1 X123.081 Y128.85 E.01484
G1 X123.15 Y128.399 E.0111
G1 X123.513 Y128.762 E.01249
G1 X123.513 Y128.243 E.01262
G1 X123.164 Y127.894 E.01201
G1 X123.112 Y127.323 E.01395
G1 X123.513 Y127.724 E.01379
G1 X123.513 Y127.205 E.01262
G1 X122.946 Y126.637 E.01952
G1 X122.457 Y125.629 E.02725
G1 X123.513 Y126.686 E.03634
G1 X123.513 Y126.166 E.01265
G1 X121.739 Y124.392 E.06102
G1 X121.022 Y123.156 E.03476
G1 X123.513 Y125.647 E.08569
G1 X123.513 Y125.128 E.01262
G1 X119.133 Y120.748 E.15067
G1 X119.467 Y120.563 E.00929
G1 X123.513 Y124.609 E.13918
G1 X123.513 Y124.09 E.01262
G1 X119.765 Y120.342 E.12893
G1 X120.051 Y120.108 E.00899
G1 X123.513 Y123.571 E.11911
G1 X123.513 Y123.051 E.01265
G1 X120.317 Y119.855 E.10994
G1 X120.557 Y119.576 E.00895
G1 X123.513 Y122.532 E.10168
G1 X123.513 Y122.013 E.01262
G1 X120.773 Y119.273 E.09425
G1 X120.963 Y118.944 E.00924
G1 X123.513 Y121.494 E.08772
G1 X123.513 Y120.975 E.01262
G1 X121.153 Y118.615 E.08118
G1 X121.344 Y118.286 E.00925
G1 X123.513 Y120.456 E.07463
G1 X123.513 Y119.936 E.01265
G1 X121.534 Y117.957 E.06808
G1 X121.724 Y117.628 E.00924
G1 X123.513 Y119.417 E.06154
G1 X123.513 Y118.898 E.01262
G1 X121.914 Y117.299 E.055
G1 X122.104 Y116.97 E.00924
G1 X123.513 Y118.379 E.04847
G1 X123.513 Y117.86 E.01262
G1 X122.295 Y116.641 E.04192
G1 X122.485 Y116.312 E.00924
G1 X123.513 Y117.341 E.03538
G1 X123.513 Y116.821 E.01265
G1 X122.675 Y115.983 E.02883
G1 X122.841 Y115.63 E.00949
G1 X123.513 Y116.302 E.02312
G1 X123.513 Y115.783 E.01262
G1 X122.976 Y115.246 E.01847
G1 X123.087 Y114.838 E.01028
G1 X123.513 Y115.264 E.01465
G1 X123.513 Y114.745 E.01262
G1 X123.152 Y114.384 E.01242
G1 X123.163 Y113.875 E.01238
G1 X123.513 Y114.226 E.01206
G1 X123.513 Y113.706 E.01265
G1 X123.108 Y113.301 E.01393
G1 X122.936 Y112.61 E.01732
G1 X123.513 Y113.187 E.01985
G1 X123.513 Y112.668 E.01262
G1 X122.433 Y111.588 E.03715
G1 X121.715 Y110.351 E.03479
G1 X123.513 Y112.149 E.06185
G1 X123.513 Y111.63 E.01262
G1 X120.998 Y109.114 E.08653
G1 X120.536 Y108.4 E.02069
G1 X120.015 Y107.838 E.01864
G1 X119.139 Y107.256 E.02558
G1 X118.792 Y106.908 E.01195
G1 X119.145 Y106.742 E.00949
G1 X123.513 Y111.111 E.15027
G1 X123.513 Y110.591 E.01265
G1 X119.478 Y106.556 E.1388
G1 X119.775 Y106.334 E.00902
G1 X123.513 Y110.072 E.12858
G1 X123.513 Y109.553 E.01262
G1 X120.06 Y106.1 E.11878
G1 X120.325 Y105.846 E.00893
G1 X123.513 Y109.034 E.10967
G1 X123.513 Y108.515 E.01262
G1 X120.565 Y105.567 E.10141
G1 X120.779 Y105.262 E.00906
G1 X123.513 Y107.996 E.09405
G1 X123.513 Y107.476 E.01265
G1 X120.97 Y104.933 E.08748
G1 X121.16 Y104.604 E.00924
G1 X123.513 Y106.957 E.08094
G1 X123.513 Y106.438 E.01262
G1 X121.35 Y104.275 E.07441
G1 X121.54 Y103.946 E.00924
G1 X123.513 Y105.919 E.06787
G1 X123.513 Y105.4 E.01262
G1 X121.73 Y103.617 E.06133
G1 X121.921 Y103.288 E.00925
G1 X123.513 Y104.881 E.05478
G1 X123.513 Y104.362 E.01262
G1 X122.111 Y102.959 E.04825
G1 X122.301 Y102.63 E.00924
G1 X123.513 Y103.842 E.04169
G1 X123.546 Y103.356 E.01185
G1 X122.491 Y102.301 E.03629
G1 X122.681 Y101.972 E.00924
G1 X123.638 Y102.929 E.03292
G1 X123.813 Y102.584 E.00941
G1 X122.843 Y101.615 E.03335
G1 X122.98 Y101.232 E.00989
G1 X124.075 Y102.328 E.03768
G1 X124.075 Y101.809 E.01262
G1 X123.089 Y100.822 E.03394
G1 X123.154 Y100.369 E.01113
G1 X124.075 Y101.289 E.03166
G1 X124.075 Y100.77 E.01262
G1 X123.161 Y99.856 E.03144
G1 X123.111 Y99.287 E.01389
G1 X124.075 Y100.251 E.03316
G1 X124.075 Y99.941 E.00754
G1 X123.833 Y99.703 E.00826
G1 X123.622 Y99.279 E.01152
G1 X122.925 Y98.581 E.02399
G1 X122.408 Y97.546 E.02814
G1 X123.514 Y98.651 E.03803
G1 X123.513 Y98.132 E.01262
G1 X121.691 Y96.309 E.06269
G1 X120.973 Y95.073 E.03477
G1 X123.678 Y97.777 E.09303
G1 E-5 F3600
G1 X123.678 Y97.777 F9000
G1 X123.887 Y91.238
G1 E5 F2400
G1 F3072.127
G1 X123.625 Y90.975 E.00903
G1 X123.106 Y90.975 E.01262
G1 X123.608 Y91.477 E.01727
G1 X123.527 Y91.915 E.01083
G1 X122.587 Y90.975 E.03234
G1 X122.068 Y90.975 E.01262
G1 X123.513 Y92.421 E.04972
G1 X123.513 Y92.94 E.01262
G1 X121.549 Y90.975 E.06758
G1 X121.029 Y90.975 E.01265
G1 X123.513 Y93.459 E.08545
G1 X123.513 Y93.978 E.01262
G1 X120.51 Y90.975 E.1033
G1 X119.991 Y90.975 E.01262
G1 X123.513 Y94.497 E.12115
G1 X123.513 Y95.017 E.01265
G1 X119.472 Y90.975 E.13903
G1 X118.953 Y90.975 E.01262
G1 X123.513 Y95.536 E.15688
G1 X123.513 Y96.055 E.01262
G1 X118.434 Y90.975 E.17473
G1 X117.914 Y90.975 E.01265
G1 X123.513 Y96.574 E.1926
G1 X123.513 Y97.093 E.01262
G1 X117.395 Y90.975 E.21046
G1 X116.876 Y90.975 E.01262
G1 X119.175 Y93.274 E.07908
G1 X118.323 Y92.941 E.02225
G1 X116.357 Y90.975 E.06763
G1 X115.838 Y90.975 E.01262
G1 X117.683 Y92.821 E.06348
G1 X117.136 Y92.792 E.01332
G1 X115.319 Y90.975 E.0625
G1 X114.799 Y90.975 E.01265
G1 X116.616 Y92.792 E.0625
G1 X116.096 Y92.792 E.01265
G1 X114.28 Y90.975 E.06249
G1 X113.761 Y90.975 E.01262
G1 X115.577 Y92.791 E.06247
G1 X115.057 Y92.791 E.01265
G1 X113.242 Y90.975 E.06245
G1 X112.723 Y90.975 E.01262
G1 X114.538 Y92.79 E.06243
G1 X114.021 Y92.793 E.01258
G1 X112.204 Y90.975 E.06252
G1 X111.685 Y90.975 E.01262
G1 X113.509 Y92.8 E.06276
G1 X113.053 Y92.863 E.0112
G1 X111.165 Y90.975 E.06495
G1 X110.646 Y90.975 E.01262
G1 X112.629 Y92.958 E.06821
G1 X112.235 Y93.083 E.01005
G1 X110.127 Y90.975 E.07251
G1 X109.608 Y90.975 E.01262
G1 X111.875 Y93.243 E.078
G1 X111.545 Y93.432 E.00925
G1 X109.089 Y90.975 E.0845
G1 X108.57 Y90.975 E.01262
G1 X111.244 Y93.649 E.09198
G1 X110.955 Y93.88 E.009
G1 X108.05 Y90.975 E.09993
G1 X107.531 Y90.975 E.01262
G1 X110.695 Y94.139 E.10884
G1 X110.465 Y94.428 E.00898
G1 X107.365 Y91.328 E.10664
G1 X107.483 Y91.965 E.01576
G1 X110.239 Y94.721 E.0948
G1 X110.038 Y95.039 E.00915
G1 X107.487 Y92.489 E.08774
G1 X107.487 Y93.008 E.01262
G1 X109.848 Y95.369 E.08122
G1 X109.658 Y95.698 E.00924
G1 X107.486 Y93.526 E.07472
G1 X107.485 Y94.045 E.01262
G1 X109.468 Y96.027 E.0682
G1 X109.278 Y96.356 E.00924
G1 X107.484 Y94.563 E.0617
G1 X107.484 Y95.081 E.0126
G1 X109.088 Y96.685 E.05518
G1 X108.898 Y97.014 E.00924
G1 X107.483 Y95.6 E.04866
G1 X107.482 Y96.118 E.0126
G1 X108.708 Y97.344 E.04217
G1 X108.518 Y97.673 E.00924
G1 X107.481 Y96.636 E.03567
G1 X107.48 Y97.155 E.01262
G1 X108.33 Y98.004 E.02922
G1 X108.171 Y98.364 E.00957
G1 X107.48 Y97.673 E.02377
G1 X107.479 Y98.191 E.0126
G1 X108.027 Y98.739 E.01885
G1 X107.915 Y99.147 E.01029
G1 X107.478 Y98.71 E.01503
G1 X107.411 Y99.162 E.01111
G1 X107.849 Y99.6 E.01507
G1 X107.832 Y100.102 E.01222
G1 X107.26 Y99.53 E.01968
G1 X107.058 Y99.847 E.00914
G1 X107.894 Y100.683 E.02876
G1 X108.062 Y101.371 E.01723
G1 X106.925 Y100.233 E.03913
G1 X106.925 Y100.752 E.01262
G1 X108.543 Y102.37 E.05566
G1 X109.253 Y103.6 E.03455
G1 X106.925 Y101.272 E.08008
G1 X106.925 Y101.791 E.01262
G1 X109.964 Y104.829 E.10452
G1 X110.361 Y105.464 E.01822
G1 X110.839 Y106.026 E.01795
G1 X111.518 Y106.552 E.02089
G1 X111.899 Y106.765 E.01062
G1 X112.224 Y107.09 E.01118
G1 X111.873 Y107.258 E.00947
G1 X106.76 Y102.145 E.17588
G1 E-5 F3600
G1 X106.76 Y102.145 F9000
G1 X111.655 Y107.559
G1 E5 F2400
G1 F3072.127
G1 X107.457 Y103.361 E.14441
G1 X107.487 Y103.91 E.01337
G1 X111.226 Y107.65 E.12864
G1 X110.943 Y107.885 E.00895
G1 X107.487 Y104.429 E.11888
G1 X107.487 Y104.949 E.01265
G1 X110.686 Y108.148 E.11004
G1 X110.457 Y108.438 E.00899
G1 X107.487 Y105.468 E.10217
G1 X107.487 Y105.987 E.01262
G1 X110.232 Y108.732 E.09443
G1 X110.031 Y109.051 E.00917
G1 X107.487 Y106.506 E.08753
G1 X107.487 Y107.025 E.01262
G1 X109.841 Y109.38 E.08099
G1 X109.651 Y109.709 E.00924
G1 X107.487 Y107.544 E.07446
G1 X107.487 Y108.064 E.01265
G1 X109.461 Y110.038 E.0679
G1 X109.271 Y110.367 E.00924
G1 X107.487 Y108.583 E.06137
G1 X107.487 Y109.102 E.01262
G1 X109.081 Y110.696 E.05483
G1 X108.891 Y111.025 E.00924
G1 X107.487 Y109.621 E.0483
G1 X107.487 Y110.14 E.01262
G1 X108.701 Y111.355 E.04178
G1 X108.511 Y111.684 E.00924
G1 X107.487 Y110.659 E.03524
G1 X107.487 Y111.179 E.01265
G1 X108.324 Y112.016 E.02879
G1 X108.166 Y112.377 E.00959
G1 X107.487 Y111.698 E.02336
G1 X107.487 Y112.217 E.01262
G1 X108.022 Y112.752 E.0184
G1 X107.913 Y113.162 E.01032
G1 X107.487 Y112.736 E.01465
G1 X107.487 Y113.255 E.01262
G1 X107.847 Y113.616 E.0124
G1 X107.832 Y114.119 E.01224
G1 X107.487 Y113.774 E.01187
G1 X107.487 Y114.294 E.01265
G1 X107.899 Y114.706 E.01417
G1 X108.07 Y115.396 E.01729
G1 X107.487 Y114.813 E.02005
G1 X107.487 Y115.332 E.01262
G1 X108.566 Y116.411 E.03712
G1 X109.277 Y117.641 E.03456
G1 X107.487 Y115.851 E.06157
G1 X107.487 Y116.37 E.01262
G1 X109.987 Y118.871 E.08602
G1 X110.361 Y119.464 E.01705
G1 X110.839 Y120.027 E.01796
G1 X111.866 Y120.749 E.03054
G1 X112.212 Y121.095 E.0119
G1 X111.863 Y121.266 E.00945
G1 X107.487 Y116.889 E.15055
G1 X107.487 Y117.409 E.01265
G1 X111.521 Y121.443 E.13877
G1 X111.225 Y121.666 E.00901
G1 X107.487 Y117.928 E.12858
G1 X107.487 Y118.447 E.01262
G1 X110.936 Y121.896 E.11864
G1 X110.684 Y122.164 E.00895
G1 X107.487 Y118.966 E.10999
G1 X107.487 Y119.485 E.01262
G1 X110.452 Y122.45 E.10199
G1 X110.225 Y122.742 E.009
G1 X107.487 Y120.004 E.09419
G1 X107.487 Y120.524 E.01265
G1 X110.025 Y123.062 E.08731
G1 X109.835 Y123.391 E.00924
G1 X107.487 Y121.043 E.08077
G1 X107.487 Y121.562 E.01262
G1 X109.645 Y123.72 E.07423
G1 X109.455 Y124.049 E.00924
G1 X107.487 Y122.081 E.0677
G1 X107.487 Y122.6 E.01262
G1 X109.265 Y124.378 E.06116
G1 X109.075 Y124.707 E.00924
G1 X107.487 Y123.119 E.05463
G1 X107.487 Y123.638 E.01262
G1 X108.885 Y125.037 E.04811
G1 X108.695 Y125.366 E.00924
G1 X107.487 Y124.158 E.04155
G1 X107.487 Y124.677 E.01262
G1 X108.505 Y125.695 E.03502
G1 X108.319 Y126.028 E.00928
G1 X107.487 Y125.196 E.02862
G1 X107.487 Y125.715 E.01262
G1 X108.161 Y126.389 E.02319
G1 X108.017 Y126.765 E.00979
G1 X107.487 Y126.234 E.01825
G1 X107.487 Y126.753 E.01262
G1 X107.911 Y127.177 E.01459
G1 X107.846 Y127.632 E.01118
G1 X107.487 Y127.273 E.01235
G1 X107.487 Y127.792 E.01262
G1 X107.832 Y128.137 E.01187
G1 X107.903 Y128.728 E.01448
G1 X107.487 Y128.311 E.01433
G1 X107.487 Y128.83 E.01262
G1 X108.079 Y129.422 E.02036
G1 X108.618 Y130.48 E.02888
G1 X107.487 Y129.349 E.03891
G1 X107.487 Y129.868 E.01262
G1 X109.761 Y132.142 E.07822
G1 E-5 F3600
G1 X109.761 Y132.142 F9000
G1 X109.249 Y128.459
G1 X109.221 Y128.23
G1 X109.212 Y128
G1 X109.221 Y127.77
G1 X109.249 Y127.541
G1 X109.296 Y127.316
G1 X109.361 Y127.095
G1 X109.444 Y126.88
G1 X109.545 Y126.67
G1 X110.667 Y124.724
G1 X111.33 Y123.578
G1 X111.391 Y123.474
G1 X111.525 Y123.285
G1 X111.672 Y123.108
G1 X111.833 Y122.943
G1 X112.007 Y122.792
G1 X112.193 Y122.656
G1 X112.389 Y122.535
G1 X112.595 Y122.431
G1 X112.808 Y122.344
G1 X113.028 Y122.275
G1 X113.252 Y122.223
G1 X113.48 Y122.191
G1 X119.606 Y121.74
G1 E5 F2400
G1 F3072.127
G1 X118.652 Y120.786 E.03282
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X119.606 Y121.74 E-.64085
;WIPE_END
G1 E-.85915 F3600
G1 X121.674 Y114.796 F9000
G1 X121.73 Y114.572
G1 X121.767 Y114.345
G1 X121.786 Y114.115
G1 X121.786 Y99.885
G1 X121.767 Y99.655
G1 X120.71 Y89.587
G1 X120.759 Y88.151
G1 X120.812 Y86.599
G1 X121.199 Y85.151
G1 X120.85 Y85.5
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X120.85 Y85.247 E.00615
G1 X120.783 Y85.106 E.0038
G1 X120.667 Y85.064 E.003
G1 X110.333 Y85.064 E.25136
G1 X110.257 Y85.081 E.00189
G1 X110.15 Y85.247 E.0048
G1 X110.15 Y85.5 E.00615
G1 X104.557 Y85.5 E.13604
G1 X103.991 Y85.458 E.01381
G1 X103.445 Y85.335 E.01361
G1 X103.051 Y85.176 E.01033
G1 X102.41 Y84.839 E.01762
G1 X101.862 Y84.381 E.01737
G1 X101.416 Y83.846 E.01694
G1 X101.042 Y83.156 E.01909
G1 X100.881 Y82.609 E.01387
G1 X100.761 Y81.98 E.01558
G1 X100.75 Y78.995 E.07261
G1 X100.688 Y78.859 E.00364
G1 X99.82 Y78.098 E.02808
G1 X99.467 Y77.724 E.01251
G1 X99.317 Y77.508 E.0064
G1 X99.459 Y77.258 E.00699
G1 X99.964 Y76.771 E.01706
G1 X100.575 Y76.238 E.01972
G1 X130.425 Y76.238 E.72607
G1 X131.036 Y76.771 E.01972
G1 X131.537 Y77.254 E.01693
G1 X131.678 Y77.505 E.007
G1 X131.55 Y77.712 E.00592
G1 X131.183 Y78.096 E.01292
G1 X130.312 Y78.859 E.02817
G1 X130.25 Y78.995 E.00364
G1 X130.24 Y81.703 E.06587
G1 X130.197 Y82.261 E.01361
G1 X130.072 Y82.81 E.0137
G1 X129.861 Y83.348 E.01406
G1 X129.574 Y83.844 E.01394
G1 X129.226 Y84.278 E.01353
G1 X128.792 Y84.678 E.01436
G1 X128.315 Y85.001 E.01401
G1 X127.824 Y85.243 E.01331
G1 X127.285 Y85.407 E.0137
G1 X126.73 Y85.489 E.01365
G1 X120.91 Y85.5 E.14157
G1 X120.91 Y85.5 F9000
G1 X121.19 Y85.133
;TYPE:Perimeter
G1 F6000
G1 X121.162 Y85.133 E.00068
G1 X121.014 Y84.823 E.00836
G1 X120.894 Y84.748 E.00344
G1 X120.667 Y84.699 E.00565
G1 X110.333 Y84.699 E.25136
G1 X110.254 Y84.705 E.00193
G1 X109.985 Y84.823 E.00715
G1 X109.838 Y85.134 E.00837
G1 X104.571 Y85.134 E.12811
G1 X104.045 Y85.095 E.01283
G1 X103.554 Y84.985 E.01224
G1 X103.188 Y84.837 E.0096
G1 X102.622 Y84.539 E.01556
G1 X102.122 Y84.122 E.01584
G1 X101.72 Y83.64 E.01527
G1 X101.382 Y83.016 E.01726
G1 X101.231 Y82.505 E.01296
G1 X101.127 Y81.955 E.01362
G1 X101.116 Y78.994 E.07202
G1 X101.079 Y78.799 E.00483
G1 X100.929 Y78.584 E.00638
G1 X100.222 Y77.964 E.02287
G1 X99.747 Y77.488 E.01636
G1 X100.211 Y77.041 E.01567
G1 X100.712 Y76.604 E.01617
G1 X130.288 Y76.604 E.71941
G1 X130.8 Y77.052 E.01655
G1 X131.257 Y77.494 E.01546
G1 X130.935 Y77.827 E.01127
G1 X130.071 Y78.584 E.02794
G1 X129.921 Y78.799 E.00638
G1 X129.884 Y78.994 E.00483
G1 X129.873 Y81.951 E.07193
G1 X129.797 Y82.459 E.01249
G1 X129.646 Y82.953 E.01256
G1 X129.42 Y83.42 E.01262
G1 X129.13 Y83.845 E.01252
G1 X128.785 Y84.216 E.01232
G1 X128.184 Y84.653 E.01807
G1 X127.695 Y84.899 E.01331
G1 X127.204 Y85.049 E.01249
G1 X126.703 Y85.124 E.01232
G1 X121.25 Y85.133 E.13264
G1 X121.25 Y85.133 F9000
G1 X121.293 Y84.639
G1 F6000
G1 X121.246 Y84.539 E.00269
G1 X121.046 Y84.415 E.00572
G1 X120.667 Y84.333 E.00943
G1 X110.333 Y84.333 E.25136
G1 X110.073 Y84.371 E.00639
G1 X109.753 Y84.54 E.0088
G1 X109.645 Y84.769 E.00616
G1 X105.388 Y84.769 E.10355
G1 X104.466 Y84.76 E.02243
G1 X103.891 Y84.686 E.0141
G1 X103.325 Y84.498 E.01451
G1 X102.833 Y84.239 E.01352
G1 X102.381 Y83.862 E.01432
G1 X102.024 Y83.433 E.01358
G1 X101.722 Y82.875 E.01543
G1 X101.618 Y82.524 E.0089
G1 X101.492 Y81.929 E.01479
G1 X101.481 Y78.993 E.07142
G1 X101.42 Y78.667 E.00807
G1 X101.17 Y78.309 E.01062
G1 X100.261 Y77.5 E.0296
G1 X100.849 Y76.97 E.01926
G1 X130.151 Y76.97 E.71274
G1 X130.742 Y77.504 E.01937
G1 X129.83 Y78.309 E.02959
G1 X129.58 Y78.667 E.01062
G1 X129.519 Y78.993 E.00807
G1 X129.509 Y81.7 E.06585
G1 X129.44 Y82.378 E.01658
G1 X129.203 Y83.029 E.01685
G1 X128.843 Y83.616 E.01675
G1 X128.337 Y84.106 E.01713
G1 X127.828 Y84.439 E.0148
G1 X127.34 Y84.625 E.0127
G1 X126.675 Y84.758 E.0165
G1 X121.354 Y84.767 E.12943
G1 X121.319 Y84.693 E.00199
G1 X121.319 Y84.693 F9000
G1 X121.536 Y84.382
G1 F6000
G1 X121.477 Y84.256 E.00338
G1 X121.197 Y84.082 E.00802
G1 X120.941 Y83.997 E.00656
G1 X120.667 Y83.967 E.0067
G1 X110.333 Y83.967 E.25136
G1 X109.969 Y84.02 E.00895
G1 X109.521 Y84.258 E.01234
G1 X109.453 Y84.403 E.0039
G1 X104.703 Y84.403 E.11554
G1 X104.153 Y84.37 E.0134
G1 X103.557 Y84.197 E.0151
G1 X103.045 Y83.939 E.01395
G1 X102.641 Y83.602 E.0128
G1 X102.328 Y83.227 E.01188
G1 X102.061 Y82.735 E.01362
G1 X101.969 Y82.421 E.00796
G1 X101.858 Y81.904 E.01286
G1 X101.847 Y78.991 E.07086
G1 X101.761 Y78.536 E.01126
G1 X101.411 Y78.034 E.01489
G1 X100.8 Y77.498 E.01977
G1 X100.986 Y77.335 E.00602
G1 X130.014 Y77.335 E.70608
G1 X130.2 Y77.498 E.00602
G1 X129.589 Y78.034 E.01977
G1 X129.239 Y78.536 E.01489
G1 X129.153 Y78.991 E.01126
G1 X129.143 Y81.699 E.06587
G1 X129.082 Y82.296 E.0146
G1 X128.874 Y82.87 E.01485
G1 X128.557 Y83.387 E.01475
G1 X128.109 Y83.82 E.01516
G1 X127.659 Y84.114 E.01307
G1 X127.234 Y84.276 E.01106
G1 X126.648 Y84.392 E.01453
G1 X121.584 Y84.401 E.12318
G1 X121.584 Y84.401 F9000
G1 X121.811 Y84.035
G1 F6000
G1 X121.738 Y84.035 E.00178
G1 X121.709 Y83.973 E.00166
G1 X121.349 Y83.749 E.01031
G1 X121.02 Y83.64 E.00843
G1 X120.667 Y83.602 E.00864
G1 X110.333 Y83.602 E.25136
G1 X110.095 Y83.619 E.0058
G1 X109.649 Y83.751 E.01131
G1 X109.29 Y83.975 E.01029
G1 X109.26 Y84.037 E.00168
G1 X104.611 Y84.037 E.11308
G1 X104.052 Y83.972 E.01369
G1 X103.482 Y83.773 E.01469
G1 X103.054 Y83.471 E.01274
G1 X102.632 Y83.021 E.01501
G1 X102.401 Y82.595 E.01179
G1 X102.223 Y81.878 E.01797
G1 X102.213 Y78.99 E.07025
G1 X102.103 Y78.404 E.0145
G1 X101.586 Y77.701 E.02123
G1 X129.414 Y77.701 E.67689
G1 X129.348 Y77.759 E.00214
G1 X128.897 Y78.404 E.01914
G1 X128.787 Y78.99 E.0145
G1 X128.78 Y80.876 E.04588
G1 X128.75 Y82.044 E.02842
G1 X128.622 Y82.551 E.01272
G1 X128.366 Y83.018 E.01295
G1 X128.037 Y83.409 E.01243
G1 X127.572 Y83.741 E.0139
G1 X127.127 Y83.926 E.01172
G1 X126.621 Y84.027 E.01255
G1 X121.871 Y84.035 E.11554
G1 E-5 F3600
G1 X121.871 Y84.035 F9000
G1 X128.886 Y78.239
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X128.622 Y77.975 E.00908
G1 X128.102 Y77.975 E.01265
G1 X128.607 Y78.481 E.01739
G1 X128.525 Y78.919 E.01084
G1 X127.581 Y77.975 E.03247
G1 X127.061 Y77.975 E.01265
G1 X128.512 Y79.426 E.04991
G1 X128.51 Y79.944 E.0126
G1 X126.541 Y77.975 E.06773
G1 X126.02 Y77.975 E.01267
G1 X128.508 Y80.463 E.08559
G1 X128.506 Y80.981 E.0126
G1 X125.5 Y77.975 E.1034
G1 X124.98 Y77.975 E.01265
G1 X128.504 Y81.5 E.12124
G1 X128.48 Y81.996 E.01208
G1 X124.459 Y77.975 E.13832
G1 X123.939 Y77.975 E.01265
G1 X128.377 Y82.413 E.15266
G1 X128.208 Y82.764 E.00948
G1 X123.419 Y77.975 E.16474
G1 X122.898 Y77.975 E.01267
G1 X127.985 Y83.062 E.17499
G1 X127.717 Y83.314 E.00895
G1 X122.378 Y77.975 E.18366
G1 X121.858 Y77.975 E.01265
G1 X127.404 Y83.522 E.1908
G1 X127.031 Y83.668 E.00974
G1 X121.337 Y77.975 E.19585
G1 X120.817 Y77.975 E.01265
G1 X126.594 Y83.752 E.19873
G1 X126.075 Y83.753 E.01262
G1 X120.297 Y77.975 E.19876
G1 X119.776 Y77.975 E.01267
G1 X125.555 Y83.754 E.19879
G1 X125.036 Y83.755 E.01262
G1 X119.256 Y77.975 E.19883
G1 X118.736 Y77.975 E.01265
G1 X124.517 Y83.756 E.19886
G1 X123.997 Y83.757 E.01265
G1 X118.215 Y77.975 E.1989
G1 X117.695 Y77.975 E.01265
G1 X123.478 Y83.758 E.19893
G1 X122.958 Y83.759 E.01265
G1 X117.175 Y77.975 E.19895
G1 X116.655 Y77.975 E.01265
G1 X122.439 Y83.76 E.19898
G1 X121.92 Y83.761 E.01262
G1 X116.134 Y77.975 E.19903
G1 X115.614 Y77.975 E.01265
G1 X121.002 Y83.363 E.18534
G1 X120.446 Y83.328 E.01355
G1 X115.094 Y77.975 E.18412
G1 X114.573 Y77.975 E.01267
G1 X119.925 Y83.328 E.18412
G1 X119.405 Y83.328 E.01265
G1 X114.053 Y77.975 E.18412
G1 X113.533 Y77.975 E.01265
G1 X118.885 Y83.328 E.18412
G1 X118.365 Y83.328 E.01265
G1 X113.012 Y77.975 E.18414
G1 X112.492 Y77.975 E.01265
G1 X117.844 Y83.328 E.18412
G1 X117.324 Y83.328 E.01265
G1 X111.972 Y77.975 E.18412
G1 X111.451 Y77.975 E.01267
G1 X116.804 Y83.328 E.18414
G1 X116.283 Y83.328 E.01267
G1 X110.931 Y77.975 E.18412
G1 X110.411 Y77.975 E.01265
G1 X115.763 Y83.328 E.18412
G1 X115.243 Y83.328 E.01265
G1 X109.89 Y77.975 E.18414
G1 X109.37 Y77.975 E.01265
G1 X114.722 Y83.328 E.18412
G1 X114.202 Y83.328 E.01265
G1 X108.85 Y77.975 E.18412
G1 X108.329 Y77.975 E.01267
G1 X113.682 Y83.328 E.18414
G1 X113.161 Y83.328 E.01267
G1 X107.809 Y77.975 E.18412
G1 X107.289 Y77.975 E.01265
G1 X112.641 Y83.328 E.18412
G1 X112.121 Y83.328 E.01265
G1 X106.768 Y77.975 E.18414
G1 X106.248 Y77.975 E.01265
G1 X111.6 Y83.328 E.18412
G1 X111.08 Y83.328 E.01265
G1 X105.728 Y77.975 E.18412
G1 X105.208 Y77.975 E.01265
G1 X110.56 Y83.328 E.18412
G1 X110.059 Y83.347 E.0122
G1 X104.687 Y77.975 E.18479
G1 X104.167 Y77.975 E.01265
G1 X109.65 Y83.458 E.18861
G1 X109.316 Y83.645 E.00931
G1 X103.647 Y77.975 E.19503
G1 X103.126 Y77.975 E.01267
G1 X108.914 Y83.763 E.1991
G1 X108.394 Y83.763 E.01265
G1 X102.606 Y77.975 E.1991
G1 X102.131 Y77.975 E.01155
G1 X107.873 Y83.763 E.19831
G1 X107.353 Y83.763 E.01265
G1 X102.467 Y78.877 E.16808
G1 X102.488 Y79.419 E.01319
G1 X106.833 Y83.763 E.14945
G1 X106.312 Y83.763 E.01267
G1 X102.49 Y79.941 E.13147
G1 X102.492 Y80.463 E.0127
G1 X105.792 Y83.763 E.11352
G1 X105.272 Y83.763 E.01265
G1 X102.494 Y80.986 E.09554
G1 X102.496 Y81.508 E.0127
G1 X104.751 Y83.763 E.07757
G1 X104.191 Y83.723 E.01366
G1 X102.53 Y82.062 E.05714
G1 X102.656 Y82.49 E.01085
G1 X102.86 Y82.866 E.01041
G1 X103.684 Y83.736 E.02915
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X102.86 Y82.866 E-.56918
G1 X102.656 Y82.49 E-.20319
G1 X102.53 Y82.062 E-.21193
G1 X103.298 Y82.83 E-.5157
;WIPE_END
G1 X104 Y85.106 F9000
G1 X104.46 Y86.599
G1 X105.067 Y88.151
G1 X105.067 Y88.567
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.151 Y88.503 E.00257
G1 X125.817 Y88.5 E.50268
G1 X125.96 Y88.569 E.00386
G1 X126 Y88.683 E.00294
G1 X126 Y89.005 E.00783
G1 X126.559 Y89.494 E.01807
G1 X127.196 Y90.148 E.02221
G1 X127.325 Y90.48 E.00866
G1 X127.265 Y90.733 E.00632
G1 X126.979 Y91.109 E.01149
G1 X126.564 Y91.502 E.0139
G1 X126 Y91.995 E.01822
G1 X126 Y92.549 E.01348
G1 X139.201 Y92.549 E.3211
G1 X139.506 Y92.624 E.00764
G1 X139.78 Y92.87 E.00896
G1 X139.9 Y93.263 E.01
G1 X139.9 Y95.567 E.05604
G1 X139.846 Y95.837 E.0067
G1 X139.705 Y96.056 E.00634
G1 X139.407 Y96.248 E.00862
G1 X138.996 Y96.279 E.01003
G1 X136.7 Y96.279 E.05585
G1 X136.7 Y102.83 E.15935
G1 X139.201 Y102.827 E.06083
G1 X139.389 Y102.871 E.0047
G1 X139.622 Y103.043 E.00704
G1 X139.781 Y103.348 E.00837
G1 X139.863 Y103.976 E.01541
G1 X139.781 Y104.652 E.01656
G1 X139.579 Y105.007 E.00994
G1 X139.435 Y105.109 E.00429
G1 X139.201 Y105.173 E.0059
G1 X136.7 Y105.17 E.06083
G1 X136.7 Y110.83 E.13767
G1 X139.201 Y110.827 E.06083
G1 X139.389 Y110.871 E.0047
G1 X139.622 Y111.043 E.00704
G1 X139.781 Y111.348 E.00837
G1 X139.863 Y111.976 E.01541
G1 X139.781 Y112.652 E.01656
G1 X139.579 Y113.007 E.00994
G1 X139.435 Y113.109 E.00429
G1 X139.201 Y113.173 E.0059
G1 X136.7 Y113.17 E.06083
G1 X136.7 Y118.83 E.13767
G1 X139.201 Y118.827 E.06083
G1 X139.389 Y118.871 E.0047
G1 X139.622 Y119.043 E.00704
G1 X139.781 Y119.348 E.00837
G1 X139.863 Y119.976 E.01541
G1 X139.781 Y120.652 E.01656
G1 X139.579 Y121.007 E.00994
G1 X139.435 Y121.109 E.00429
G1 X139.201 Y121.173 E.0059
G1 X136.7 Y121.17 E.06083
G1 X136.7 Y126.83 E.13767
G1 X139.201 Y126.827 E.06083
G1 X139.389 Y126.871 E.0047
G1 X139.622 Y127.043 E.00704
G1 X139.776 Y127.326 E.00784
G1 X139.833 Y127.567 E.00602
G1 X139.848 Y128.314 E.01817
G1 X139.755 Y128.723 E.0102
G1 X139.511 Y129.057 E.01006
G1 X139.201 Y129.173 E.00805
G1 X136.7 Y129.17 E.06083
G1 X136.7 Y132.616 E.08382
G1 X136.683 Y133.174 E.01358
G1 X136.587 Y134.107 E.02281
G1 X136.445 Y134.826 E.01783
G1 X139.202 Y134.827 E.06706
G1 X139.511 Y134.943 E.00803
G1 X139.708 Y135.173 E.00737
G1 X139.82 Y135.495 E.00829
G1 X139.865 Y136 E.01233
G1 X139.82 Y136.504 E.01231
G1 X139.736 Y136.772 E.00683
G1 X139.545 Y137.03 E.00781
G1 X139.217 Y137.172 E.00869
G1 X135.61 Y137.173 E.08774
G1 X135.014 Y138.217 E.02924
G1 X134.398 Y139.054 E.02528
G1 X133.961 Y139.553 E.01613
G1 X133.258 Y140.239 E.02389
G1 X132.621 Y140.759 E.02
G1 X131.842 Y141.289 E.02292
G1 X131.093 Y141.707 E.02086
G1 X130.258 Y142.086 E.0223
G1 X129.513 Y142.475 E.02044
G1 X128.985 Y142.8 E.01508
G1 X129.599 Y142.825 E.01495
G1 X139.217 Y142.828 E.23395
G1 X139.514 Y142.942 E.00774
G1 X139.712 Y143.186 E.00764
G1 X139.848 Y143.677 E.01239
G1 X139.86 Y144.178 E.01219
G1 X139.81 Y144.552 E.00918
G1 X139.672 Y144.886 E.00879
G1 X139.434 Y145.11 E.00795
G1 X139.203 Y145.173 E.00582
G1 X125.668 Y145.174 E.32923
G1 X125.526 Y145.106 E.00383
G1 X125.485 Y144.991 E.00297
G1 X125.484 Y143.115 E.04563
G1 X125.438 Y142.956 E.00403
G1 X125.329 Y142.847 E.00375
G1 X125.097 Y142.8 E.00576
G1 X120.483 Y142.8 E.11223
G1 X120.353 Y142.747 E.00341
G1 X120.3 Y142.617 E.00341
G1 X120.3 Y142.277 E.00827
G1 X110.7 Y142.277 E.23351
G1 X110.7 Y142.617 E.00827
G1 X110.607 Y142.777 E.0045
G1 X109.785 Y142.801 E.02
G1 X105.774 Y142.808 E.09756
G1 X105.595 Y142.923 E.00518
G1 X105.524 Y143.049 E.00352
G1 X105.514 Y144.992 E.04726
G1 X105.44 Y145.138 E.00398
G1 X105.331 Y145.174 E.00279
G1 X91.797 Y145.173 E.3292
G1 X91.486 Y145.059 E.00806
G1 X91.288 Y144.814 E.00766
G1 X91.152 Y144.318 E.01251
G1 X91.167 Y143.567 E.01827
G1 X91.264 Y143.229 E.00855
G1 X91.455 Y142.97 E.00783
G1 X91.783 Y142.828 E.00869
G1 X101.726 Y142.826 E.24185
G1 X102 Y142.784 E.00674
G1 X101.346 Y142.397 E.01848
G1 X100.762 Y142.095 E.01599
G1 X99.921 Y141.714 E.02246
G1 X99.172 Y141.297 E.02085
G1 X98.392 Y140.768 E.02292
G1 X97.754 Y140.25 E.01999
G1 X97.036 Y139.55 E.02439
G1 X96.368 Y138.756 E.02524
G1 X95.782 Y137.894 E.02535
G1 X95.388 Y137.173 E.01999
G1 X91.783 Y137.172 E.08769
G1 X91.563 Y137.108 E.00557
G1 X91.275 Y136.788 E.01047
G1 X91.18 Y136.504 E.00728
G1 X91.135 Y136 E.01231
G1 X91.18 Y135.495 E.01233
G1 X91.319 Y135.124 E.00964
G1 X91.489 Y134.943 E.00604
G1 X91.798 Y134.827 E.00803
G1 X94.555 Y134.826 E.06706
G1 X94.415 Y134.122 E.01746
G1 X94.317 Y133.181 E.02301
G1 X94.3 Y132.664 E.01258
G1 X94.3 Y129.174 E.08489
G1 X91.798 Y129.173 E.06086
G1 X91.611 Y129.129 E.00467
G1 X91.378 Y128.957 E.00704
G1 X91.219 Y128.652 E.00837
G1 X91.137 Y128.024 E.01541
G1 X91.219 Y127.348 E.01656
G1 X91.421 Y126.993 E.00994
G1 X91.565 Y126.891 E.00429
G1 X91.799 Y126.827 E.0059
G1 X94.3 Y126.83 E.06083
G1 X94.3 Y121.17 E.13767
G1 X91.799 Y121.173 E.06083
G1 X91.611 Y121.129 E.0047
G1 X91.378 Y120.957 E.00704
G1 X91.219 Y120.652 E.00837
G1 X91.137 Y120.024 E.01541
G1 X91.219 Y119.348 E.01656
G1 X91.421 Y118.993 E.00994
G1 X91.565 Y118.891 E.00429
G1 X91.799 Y118.827 E.0059
G1 X94.3 Y118.83 E.06083
G1 X94.3 Y113.17 E.13767
G1 X91.799 Y113.173 E.06083
G1 X91.611 Y113.129 E.0047
G1 X91.378 Y112.957 E.00704
G1 X91.219 Y112.652 E.00837
G1 X91.137 Y112.024 E.01541
G1 X91.219 Y111.348 E.01656
G1 X91.421 Y110.993 E.00994
G1 X91.565 Y110.891 E.00429
G1 X91.799 Y110.827 E.0059
G1 X94.3 Y110.83 E.06083
G1 X94.3 Y105.17 E.13767
G1 X91.799 Y105.173 E.06083
G1 X91.611 Y105.129 E.0047
G1 X91.378 Y104.957 E.00704
G1 X91.219 Y104.652 E.00837
G1 X91.137 Y104.024 E.01541
G1 X91.219 Y103.348 E.01656
G1 X91.421 Y102.993 E.00994
G1 X91.565 Y102.891 E.00429
G1 X91.799 Y102.827 E.0059
G1 X94.3 Y102.83 E.06083
G1 X94.3 Y96.279 E.15935
G1 X91.799 Y96.279 E.06083
G1 X91.529 Y96.224 E.0067
G1 X91.317 Y96.078 E.00626
G1 X91.133 Y95.779 E.00854
G1 X91.1 Y95.566 E.00524
G1 X91.108 Y93.169 E.0583
G1 X91.21 Y92.881 E.00743
G1 X91.374 Y92.697 E.006
G1 X91.593 Y92.581 E.00603
G1 X91.799 Y92.549 E.00507
G1 X105 Y92.549 E.3211
G1 X105 Y91.995 E.01348
G1 X104.441 Y91.506 E.01807
G1 X103.804 Y90.852 E.02221
G1 X103.684 Y90.561 E.00766
G1 X103.721 Y90.29 E.00665
G1 X104.092 Y89.824 E.01449
G1 X105 Y89.005 E.02974
G1 X105.018 Y88.604 E.00976
G1 X105.018 Y88.604 F9000
G1 X104.8 Y88.303
;TYPE:Perimeter
G1 F6000
G1 X104.821 Y88.27 E.00095
G1 X105.088 Y88.143 E.00719
G1 X125.817 Y88.134 E.50421
G1 X126.067 Y88.195 E.00626
G1 X126.29 Y88.405 E.00745
G1 X126.366 Y88.683 E.00701
G1 X126.366 Y88.839 E.00379
G1 X126.8 Y89.218 E.01402
G1 X127.458 Y89.893 E.02293
G1 X127.582 Y90.093 E.00572
G1 X127.689 Y90.441 E.00886
G1 X127.656 Y90.733 E.00715
G1 X127.557 Y90.952 E.00585
G1 X127.23 Y91.375 E.013
G1 X126.371 Y92.157 E.02826
G1 X126.381 Y92.183 E.00068
G1 X139.201 Y92.184 E.31183
G1 X139.599 Y92.27 E.0099
G1 X139.854 Y92.419 E.00718
G1 X140.043 Y92.616 E.00664
;WIDTH:0.440254
G1 X140.114 Y92.738 E.00381
;WIDTH:0.480509
G1 X140.185 Y92.86 E.00419
;WIDTH:0.520764
G1 X140.256 Y92.983 E.0046
;WIDTH:0.561018
G1 X140.327 Y93.105 E.00495
G1 X140.34 Y93.263 E.00555
;WIDTH:0.547029
G1 X140.34 Y95.567 E.07858
;WIDTH:0.56926
G1 X140.31 Y95.857 E.01037
G1 X140.213 Y95.981 E.0056
;WIDTH:0.526945
G1 X140.115 Y96.105 E.00518
;WIDTH:0.48463
G1 X140.017 Y96.228 E.00471
;WIDTH:0.442315
G1 X139.919 Y96.352 E.00429
;WIDTH:0.399999
G1 X139.699 Y96.511 E.0066
G1 X139.291 Y96.637 E.01039
G1 X137.066 Y96.645 E.05412
G1 X137.066 Y102.464 E.14154
G1 X139.201 Y102.461 E.05193
G1 X139.391 Y102.487 E.00466
G1 X139.756 Y102.67 E.00993
G1 X139.939 Y102.862 E.00645
G1 X140.143 Y103.3 E.01175
G1 X140.226 Y103.928 E.01541
G1 X140.143 Y104.7 E.01889
G1 X139.939 Y105.138 E.01175
G1 X139.729 Y105.358 E.0074
G1 X139.366 Y105.514 E.00961
G1 X138.999 Y105.539 E.00895
G1 X137.066 Y105.536 E.04702
G1 X137.066 Y110.464 E.11987
G1 X139.201 Y110.461 E.05193
G1 X139.391 Y110.487 E.00466
G1 X139.756 Y110.67 E.00993
G1 X139.939 Y110.862 E.00645
G1 X140.143 Y111.3 E.01175
G1 X140.226 Y111.928 E.01541
G1 X140.143 Y112.7 E.01889
G1 X139.939 Y113.138 E.01175
G1 X139.729 Y113.358 E.0074
G1 X139.366 Y113.514 E.00961
G1 X139 Y113.539 E.00892
G1 X137.066 Y113.536 E.04704
G1 X137.066 Y118.464 E.11987
G1 X139.201 Y118.461 E.05193
G1 X139.391 Y118.487 E.00466
G1 X139.756 Y118.67 E.00993
G1 X139.939 Y118.862 E.00645
G1 X140.143 Y119.3 E.01175
G1 X140.226 Y119.928 E.01541
G1 X140.143 Y120.7 E.01889
G1 X139.939 Y121.138 E.01175
G1 X139.729 Y121.358 E.0074
G1 X139.366 Y121.514 E.00961
G1 X139 Y121.539 E.00892
G1 X137.066 Y121.536 E.04704
G1 X137.066 Y126.464 E.11987
G1 X139.201 Y126.461 E.05193
G1 X139.391 Y126.487 E.00466
G1 X139.756 Y126.67 E.00993
G1 X139.939 Y126.862 E.00645
G1 X140.131 Y127.236 E.01023
G1 X140.198 Y127.56 E.00805
G1 X140.213 Y128.307 E.01817
G1 X140.136 Y128.741 E.01072
G1 X139.906 Y129.176 E.01197
G1 X139.655 Y129.393 E.00807
G1 X139.201 Y129.539 E.0116
G1 X137.066 Y129.536 E.05193
G1 X137.066 Y132.616 E.07492
G1 X137.049 Y133.185 E.01385
G1 X136.951 Y134.145 E.02347
G1 X136.89 Y134.461 E.00783
G1 X139.202 Y134.461 E.05624
G1 X139.655 Y134.607 E.01158
G1 X139.872 Y134.775 E.00668
G1 X140.051 Y135.047 E.00792
G1 X140.184 Y135.462 E.0106
G1 X140.231 Y136 E.01314
G1 X140.184 Y136.537 E.01311
G1 X140.047 Y136.963 E.01088
G1 X139.93 Y137.154 E.00545
G1 X139.708 Y137.357 E.00732
G1 X139.462 Y137.48 E.00669
G1 X139.217 Y137.538 E.00612
G1 X135.822 Y137.538 E.08258
G1 X135.332 Y138.398 E.02408
G1 X134.692 Y139.271 E.02633
G1 X134.236 Y139.794 E.01688
G1 X133.514 Y140.501 E.02458
G1 X132.852 Y141.042 E.0208
G1 X132.047 Y141.591 E.0237
G1 X131.271 Y142.027 E.02165
G1 X130.33 Y142.46 E.0252
G1 X139.217 Y142.462 E.21617
G1 X139.553 Y142.545 E.00842
G1 X139.784 Y142.695 E.0067
G1 X139.941 Y142.866 E.00565
G1 X140.063 Y143.084 E.00608
G1 X140.213 Y143.667 E.01464
G1 X140.223 Y144.222 E.0135
G1 X140.153 Y144.679 E.01125
G1 X139.941 Y145.133 E.01219
G1 X139.784 Y145.305 E.00566
G1 X139.544 Y145.458 E.00692
G1 X139.203 Y145.539 E.00853
G1 X125.668 Y145.539 E.32923
G1 X125.425 Y145.482 E.00607
G1 X125.214 Y145.297 E.00683
G1 X125.138 Y145.129 E.00449
G1 X125.12 Y144.991 E.00339
G1 X125.118 Y143.171 E.04427
G1 X120.483 Y143.166 E.11274
G1 X120.214 Y143.096 E.00676
G1 X120.095 Y143.005 E.00364
G1 X119.945 Y142.642 E.00955
G1 X111.055 Y142.642 E.21624
G1 X110.905 Y143.005 E.00955
G1 X110.667 Y143.145 E.00672
G1 X109.785 Y143.167 E.02146
G1 X105.889 Y143.173 E.09477
G1 X105.88 Y144.994 E.04429
G1 X105.826 Y145.228 E.00584
G1 X105.658 Y145.431 E.00641
G1 X105.463 Y145.523 E.00524
G1 X105.331 Y145.539 E.00323
G1 X91.797 Y145.539 E.3292
G1 X91.456 Y145.458 E.00853
G1 X91.216 Y145.305 E.00692
G1 X91.059 Y145.134 E.00565
G1 X90.937 Y144.916 E.00608
G1 X90.795 Y144.413 E.01271
G1 X90.802 Y143.56 E.02075
G1 X90.892 Y143.176 E.00959
G1 X91.07 Y142.846 E.00912
G1 X91.292 Y142.643 E.00732
G1 X91.538 Y142.52 E.00669
G1 X91.783 Y142.462 E.00612
G1 X100.672 Y142.46 E.21622
G1 X99.77 Y142.048 E.02412
G1 X98.994 Y141.617 E.02159
G1 X98.186 Y141.071 E.02372
G1 X97.523 Y140.533 E.02077
G1 X96.793 Y139.825 E.02474
G1 X96.088 Y138.991 E.02656
G1 X95.479 Y138.099 E.02627
G1 X95.171 Y137.538 E.01557
G1 X91.783 Y137.538 E.08241
G1 X91.447 Y137.455 E.00842
G1 X91.187 Y137.271 E.00775
G1 X90.895 Y136.837 E.01272
G1 X90.816 Y136.537 E.00755
G1 X90.769 Y136 E.01311
G1 X90.816 Y135.462 E.01314
G1 X90.949 Y135.047 E.0106
G1 X91.128 Y134.775 E.00792
G1 X91.345 Y134.607 E.00668
G1 X91.798 Y134.461 E.01158
G1 X94.11 Y134.461 E.05624
G1 X93.954 Y133.218 E.03047
G1 X93.935 Y132.676 E.01319
G1 X93.934 Y129.539 E.0763
G1 X91.798 Y129.539 E.05196
G1 X91.609 Y129.513 E.00464
G1 X91.244 Y129.33 E.00993
G1 X91.061 Y129.138 E.00645
G1 X90.857 Y128.7 E.01175
G1 X90.774 Y128.072 E.01541
G1 X90.857 Y127.3 E.01889
G1 X91.061 Y126.862 E.01175
G1 X91.271 Y126.642 E.0074
G1 X91.634 Y126.486 E.00961
G1 X92.001 Y126.461 E.00895
G1 X93.934 Y126.464 E.04702
G1 X93.934 Y121.536 E.11987
G1 X91.799 Y121.539 E.05193
G1 X91.609 Y121.513 E.00466
G1 X91.244 Y121.33 E.00993
G1 X91.061 Y121.138 E.00645
G1 X90.857 Y120.7 E.01175
G1 X90.774 Y120.072 E.01541
G1 X90.857 Y119.3 E.01889
G1 X91.061 Y118.862 E.01175
G1 X91.271 Y118.642 E.0074
G1 X91.634 Y118.486 E.00961
G1 X92 Y118.461 E.00892
G1 X93.934 Y118.464 E.04704
G1 X93.934 Y113.536 E.11987
G1 X91.799 Y113.539 E.05193
G1 X91.609 Y113.513 E.00466
G1 X91.244 Y113.33 E.00993
G1 X91.061 Y113.138 E.00645
G1 X90.857 Y112.7 E.01175
G1 X90.774 Y112.072 E.01541
G1 X90.857 Y111.3 E.01889
G1 X91.061 Y110.862 E.01175
G1 X91.271 Y110.642 E.0074
G1 X91.634 Y110.486 E.00961
G1 X92 Y110.461 E.00892
G1 X93.934 Y110.464 E.04704
G1 X93.934 Y105.536 E.11987
G1 X91.799 Y105.539 E.05193
G1 X91.609 Y105.513 E.00466
G1 X91.244 Y105.33 E.00993
G1 X91.061 Y105.138 E.00645
G1 X90.857 Y104.7 E.01175
G1 X90.774 Y104.072 E.01541
G1 X90.857 Y103.3 E.01889
G1 X91.061 Y102.862 E.01175
G1 X91.271 Y102.642 E.0074
G1 X91.634 Y102.486 E.00961
G1 X91.999 Y102.461 E.0089
G1 X93.934 Y102.464 E.04707
G1 X93.934 Y96.645 E.14154
G1 X91.799 Y96.645 E.05193
G1 X91.534 Y96.608 E.00651
G1 X91.187 Y96.446 E.00931
G1 X91.014 Y96.283 E.00578
;WIDTH:0.443142
G1 X90.933 Y96.177 E.00363
;WIDTH:0.486284
G1 X90.851 Y96.071 E.00403
;WIDTH:0.529427
G1 X90.77 Y95.964 E.00442
;WIDTH:0.572569
G1 X90.689 Y95.858 E.00478
G1 X90.659 Y95.565 E.01055
;WIDTH:0.554322
G1 X90.665 Y93.168 E.08291
;WIDTH:0.580282
G1 X90.688 Y92.958 E.00767
G1 X90.725 Y92.922 E.00187
;WIDTH:0.535544
G1 X90.761 Y92.885 E.00172
;WIDTH:0.490806
G1 X90.797 Y92.849 E.00155
;WIDTH:0.446068
G1 X90.834 Y92.813 E.00141
;WIDTH:0.40133
G1 X91.042 Y92.508 E.00901
;WIDTH:0.399999
G1 X91.342 Y92.29 E.00902
G1 X91.71 Y92.191 E.00927
G1 X91.799 Y92.184 E.00217
G1 X104.634 Y92.183 E.3122
G1 X104.2 Y91.782 E.01437
G1 X103.542 Y91.107 E.02293
G1 X103.418 Y90.907 E.00572
G1 X103.339 Y90.682 E.0058
G1 X103.344 Y90.267 E.0101
G1 X103.443 Y90.048 E.00585
G1 X103.77 Y89.625 E.013
G1 X104.634 Y88.839 E.02841
G1 X104.66 Y88.518 E.00783
G1 X104.767 Y88.354 E.00476
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X104.8 Y88.303 E-.02885
G1 X104.821 Y88.27 E-.01858
G1 X105.088 Y88.143 E-.14044
G1 X107.85 Y88.142 E-1.31213
;WIPE_END
G1 X107.85 Y88.151 F9000
G1 X110.639 Y86.599
G1 X110.639 Y86.194
G1 E5 F2400
G1 F6000
G1 X110.517 Y86.25 E.00327
G1 X104.199 Y86.25 E.15368
G1 X103.598 Y86.206 E.01466
G1 X103.046 Y86.087 E.01374
G1 X102.475 Y85.869 E.01487
G1 X101.595 Y85.342 E.02495
G1 X100.958 Y84.718 E.02169
G1 X100.462 Y83.96 E.02203
G1 X100.177 Y83.251 E.01859
G1 X100.01 Y82.335 E.02265
G1 X100 Y78.996 E.08122
G1 X99.441 Y78.506 E.01808
G1 X98.804 Y77.852 E.02221
G1 X98.674 Y77.499 E.00915
G1 X98.735 Y77.267 E.00583
G1 X99.021 Y76.891 E.01149
G1 X99.436 Y76.498 E.0139
G1 X100 Y76.005 E.01822
G1 X100.006 Y75.721 E.00691
G1 X100.06 Y75.631 E.00255
G1 X100.183 Y75.584 E.0032
G1 X130.817 Y75.584 E.74514
G1 X130.94 Y75.631 E.0032
G1 X131 Y75.767 E.00362
G1 X131 Y76.005 E.00579
G1 X131.559 Y76.494 E.01807
G1 X132.196 Y77.148 E.02221
G1 X132.326 Y77.507 E.00929
G1 X132.265 Y77.733 E.00569
G1 X131.979 Y78.109 E.01149
G1 X131.564 Y78.502 E.0139
G1 X131 Y78.995 E.01822
G1 X131 Y82.051 E.07433
G1 X130.972 Y82.508 E.01114
G1 X130.788 Y83.361 E.02123
G1 X130.41 Y84.192 E.02221
G1 X130.063 Y84.693 E.01482
G1 X129.436 Y85.318 E.02153
G1 X128.935 Y85.666 E.01484
G1 X128.502 Y85.887 E.01182
G1 X127.698 Y86.151 E.02058
G1 X127.108 Y86.238 E.01451
G1 X120.483 Y86.25 E.16115
G1 X120.345 Y86.187 E.00369
G1 X120.3 Y86.067 E.00312
G1 X120.3 Y85.703 E.00885
G1 X110.7 Y85.703 E.23351
G1 X110.7 Y86.067 E.00885
G1 X110.67 Y86.148 E.0021
G1 X110.891 Y86.449 F9000
;TYPE:Perimeter
G1 F6000
G1 X110.612 Y86.607 E.0078
G1 X110.517 Y86.616 E.00232
G1 X104.199 Y86.616 E.15368
G1 X103.521 Y86.564 E.01654
G1 X102.969 Y86.445 E.01374
G1 X102.343 Y86.21 E.01626
G1 X102.105 Y86.1 E.00638
G1 X101.398 Y85.651 E.02037
G1 X100.701 Y84.978 E.02357
G1 X100.155 Y84.159 E.02394
G1 X99.837 Y83.386 E.02033
G1 X99.645 Y82.336 E.02596
G1 X99.635 Y79.162 E.0772
G1 X99.2 Y78.782 E.01405
G1 X98.542 Y78.107 E.02293
G1 X98.417 Y77.905 E.00578
G1 X98.308 Y77.497 E.01027
G1 X98.344 Y77.267 E.00566
G1 X98.443 Y77.048 E.00585
G1 X98.77 Y76.625 E.013
G1 X99.634 Y75.839 E.02841
G1 X99.652 Y75.629 E.00513
G1 X99.814 Y75.361 E.00762
;WIDTH:0.448238
G1 X99.901 Y75.292 E.00306
;WIDTH:0.496476
G1 X99.988 Y75.224 E.00339
;WIDTH:0.544714
G1 X100.076 Y75.155 E.0038
G1 X100.183 Y75.149 E.00364
;WIDTH:0.539178
G1 X130.817 Y75.149 E1.02876
G1 X130.94 Y75.219 E.00475
;WIDTH:0.492785
G1 X131.063 Y75.29 E.00433
;WIDTH:0.446392
G1 X131.186 Y75.361 E.00389
;WIDTH:0.399999
G1 X131.348 Y75.629 E.00762
G1 X131.366 Y75.839 E.00513
G1 X131.8 Y76.218 E.01402
G1 X132.458 Y76.893 E.02293
G1 X132.582 Y77.093 E.00572
G1 X132.692 Y77.522 E.01077
G1 X132.605 Y77.876 E.00887
G1 X132.292 Y78.305 E.01292
G1 X131.816 Y78.767 E.01614
G1 X131.366 Y79.161 E.01455
G1 X131.366 Y82.051 E.0703
G1 X131.333 Y82.564 E.0125
G1 X131.145 Y83.438 E.02175
G1 X130.743 Y84.345 E.02413
G1 X130.363 Y84.903 E.01642
G1 X129.693 Y85.578 E.02313
G1 X129.142 Y85.967 E.01641
G1 X128.696 Y86.201 E.01225
G1 X127.813 Y86.499 E.02267
G1 X127.16 Y86.6 E.01607
G1 X120.483 Y86.616 E.16241
G1 X120.068 Y86.426 E.0111
G1 X119.935 Y86.069 E.00927
G1 X111.065 Y86.069 E.21575
G1 X110.936 Y86.414 E.00896
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X110.891 Y86.449 E-.02708
G1 X110.612 Y86.607 E-.1523
G1 X110.517 Y86.616 E-.04533
G1 X107.832 Y86.616 E-1.27529
;WIPE_END
G1 X107.832 Y86.599 F9000
G1 X91.437 Y92.261
G1 X91.268 Y92.342
G1 X91.118 Y92.451
G1 X90.99 Y92.583
G1 X90.886 Y92.736
G1 X90.811 Y92.903
G1 X90.765 Y93.08
G1 X90.757 Y93.176
G1 X90.751 Y93.241
G1 X90.751 Y95.587
G1 X90.786 Y144
G1 X90.791 Y144.185
G1 X90.807 Y144.374
G1 X90.826 Y144.517
G1 X90.845 Y144.612
G1 X90.896 Y144.797
G1 X90.934 Y144.893
G1 X91.007 Y145.039
G1 X91.136 Y145.219
G1 X91.216 Y145.293
G1 X91.344 Y145.393
G1 X91.545 Y145.483
G1 X91.705 Y145.515
G1 X91.772 Y145.522
G1 X102.715 Y145.522
G1 X105.651 Y145.522
G1 X105.452 Y150.478
G1 X105.452 Y150.884
G1 E5 F2400
G1 F6000
G1 X105.474 Y150.894 E.00059
G1 X105.509 Y150.965 E.00193
G1 X105.515 Y152.991 E.04928
G1 X105.458 Y153.123 E.0035
G1 X105.332 Y153.174 E.00331
G1 X91.797 Y153.173 E.32923
G1 X91.486 Y153.059 E.00806
G1 X91.288 Y152.814 E.00766
G1 X91.152 Y152.323 E.01239
G1 X91.142 Y151.814 E.01238
G1 X91.242 Y151.28 E.01321
G1 X91.455 Y150.97 E.00915
G1 X91.783 Y150.828 E.00869
G1 X105.332 Y150.826 E.32957
G1 X105.398 Y150.858 E.00178
G1 X105.398 Y150.858 F9000
G1 X105.707 Y150.633
;TYPE:Perimeter
G1 F6000
G1 X105.786 Y150.703 E.00257
G1 X105.864 Y150.877 E.00464
G1 X105.88 Y151.009 E.00323
G1 X105.88 Y152.991 E.04821
G1 X105.816 Y153.249 E.00647
G1 X105.71 Y153.388 E.00425
G1 X105.426 Y153.531 E.00773
G1 X91.797 Y153.539 E.33151
G1 X91.454 Y153.458 E.00857
;WIDTH:0.423934
G1 X91.109 Y153.207 E.01106
;WIDTH:0.448479
G1 X90.936 Y152.986 E.00773
;WIDTH:0.473235
G1 X90.773 Y152.48 E.01552
;WIDTH:0.522723
G1 X90.712 Y151.861 E.02021
G1 X90.758 Y151.691 E.00572
;WIDTH:0.481815
G1 X90.803 Y151.521 E.00523
;WIDTH:0.440907
G1 X90.848 Y151.351 E.00476
;WIDTH:0.399999
G1 X90.925 Y151.099 E.00641
G1 X91.061 Y150.862 E.00665
G1 X91.292 Y150.643 E.00774
G1 X91.538 Y150.52 E.00669
G1 X91.783 Y150.462 E.00612
G1 X105.332 Y150.461 E.32957
G1 X105.575 Y150.518 E.00607
G1 X105.662 Y150.594 E.00281
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X105.707 Y150.633 E-.02829
G1 X105.786 Y150.703 E-.05014
G1 X105.864 Y150.877 E-.09057
G1 X105.88 Y151.009 E-.06316
G1 X105.88 Y152.991 E-.94145
G1 X105.816 Y153.249 E-.12626
G1 X105.71 Y153.388 E-.08303
G1 X105.49 Y153.499 E-.1171
;WIPE_END
G1 X105.49 Y153.522 F9000
G1 X125.137 Y150.885
G1 X125.537 Y150.886
G1 E5 F2400
G1 F6000
G1 X125.54 Y150.879 E.00019
G1 X125.668 Y150.826 E.00337
G1 X139.202 Y150.827 E.3292
G1 X139.511 Y150.943 E.00803
G1 X139.709 Y151.177 E.00746
G1 X139.834 Y151.62 E.0112
G1 X139.848 Y152.314 E.01688
G1 X139.712 Y152.814 E.0126
G1 X139.514 Y153.059 E.00766
G1 X139.203 Y153.173 E.00806
G1 X137.535 Y153.173 E.04057
G1 X125.668 Y153.174 E.28865
G1 X125.542 Y153.123 E.00331
G1 X125.485 Y152.991 E.0035
G1 X125.485 Y151.009 E.04821
G1 X125.514 Y150.941 E.0018
G1 X125.289 Y150.631 F9000
;TYPE:Perimeter
G1 F6000
G1 X125.342 Y150.569 E.00198
G1 X125.537 Y150.477 E.00524
G1 X125.668 Y150.461 E.00321
G1 X139.202 Y150.461 E.3292
G1 X139.655 Y150.607 E.01158
G1 X139.872 Y150.775 E.00668
G1 X140.073 Y151.112 E.00954
G1 X140.198 Y151.56 E.01131
;WIDTH:0.436027
G1 X140.223 Y151.891 E.00887
;WIDTH:0.472054
G1 X140.248 Y152.223 E.00969
G1 X140.226 Y152.479 E.00748
;WIDTH:0.470646
G1 X140.061 Y152.997 E.01578
;WIDTH:0.452346
G1 X139.898 Y153.203 E.0073
;WIDTH:0.429039
G1 X139.544 Y153.458 E.01145
;WIDTH:0.399999
G1 X139.203 Y153.539 E.00853
G1 X137.535 Y153.539 E.04057
G1 X125.668 Y153.539 E.28865
G1 X125.457 Y153.497 E.00523
G1 X125.29 Y153.388 E.00485
G1 X125.133 Y153.111 E.00774
G1 X125.12 Y152.991 E.00294
G1 X125.12 Y151.009 E.04821
G1 X125.178 Y150.764 E.00612
G1 X125.251 Y150.677 E.00276
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X125.289 Y150.631 E-.02834
G1 X125.342 Y150.569 E-.03874
G1 X125.537 Y150.477 E-.10242
G1 X125.668 Y150.461 E-.06269
G1 X128.337 Y150.461 E-1.26781
;WIPE_END
G1 X125.251 Y156.789 F9000
G1 E5 F2400
G1 F6000
G1 X97.146 Y156.784 E.68363
G1 X95.365 Y156.798 E.04332
G1 X94.747 Y156.751 E.01508
G1 X94.057 Y156.617 E.0171
G1 X93.471 Y156.433 E.01494
G1 X92.938 Y156.198 E.01417
G1 X92.446 Y155.929 E.01364
G1 X91.611 Y155.302 E.0254
G1 X91.127 Y154.81 E.01679
G1 X90.705 Y154.261 E.01684
G1 X90.351 Y153.668 E.0168
G1 X90.015 Y152.872 E.02102
G1 X89.866 Y152.376 E.0126
G1 X89.711 Y151.343 E.02541
G1 X89.7 Y80.006 E1.7352
G1 X89.743 Y79.301 E.01718
G1 X89.869 Y78.612 E.01704
G1 X90.077 Y77.943 E.01704
G1 X90.365 Y77.305 E.01703
G1 X90.727 Y76.705 E.01704
G1 X91.159 Y76.154 E.01703
G1 X91.654 Y75.659 E.01703
G1 X92.205 Y75.227 E.01703
G1 X92.804 Y74.865 E.01702
G1 X93.529 Y74.548 E.01925
G1 X94.109 Y74.37 E.01476
G1 X95.153 Y74.211 E.02569
G1 X135.632 Y74.208 E.98461
G1 X136.197 Y74.242 E.01377
G1 X136.885 Y74.368 E.01701
G1 X137.88 Y74.712 E.02561
G1 X138.795 Y75.227 E.02554
G1 X139.601 Y75.9 E.02554
G1 X140.273 Y76.706 E.02553
G1 X140.788 Y77.62 E.02552
G1 X141.132 Y78.615 E.02561
G1 X141.258 Y79.304 E.01704
G1 X141.289 Y79.819 E.01255
G1 X141.3 Y150.994 E1.73126
G1 X141.258 Y151.691 E.01698
G1 X141.135 Y152.372 E.01683
G1 X140.931 Y153.034 E.01685
G1 X140.65 Y153.667 E.01685
G1 X140.295 Y154.261 E.01683
G1 X139.873 Y154.81 E.01684
G1 X139.388 Y155.303 E.01682
G1 X138.726 Y155.818 E.0204
G1 X138.26 Y156.1 E.01325
G1 X137.528 Y156.433 E.01956
G1 X137.021 Y156.592 E.01292
G1 X136.465 Y156.719 E.01387
G1 X135.823 Y156.791 E.01571
G1 X125.311 Y156.789 E.25569
G1 X125.311 Y156.789 F9000
G1 X125.311 Y156.423
;TYPE:Perimeter
G1 F6000
G1 X97.146 Y156.418 E.68509
G1 X95.378 Y156.432 E.04301
G1 X94.796 Y156.388 E.0142
G1 X94.146 Y156.262 E.0161
G1 X93.6 Y156.09 E.01392
G1 X93.086 Y155.864 E.01366
G1 X92.646 Y155.623 E.0122
G1 X91.852 Y155.026 E.02416
G1 X91.404 Y154.569 E.01557
G1 X91.022 Y154.074 E.01521
;WIDTH:0.40413
G1 X90.763 Y153.642 E.01239
;WIDTH:0.451193
G1 X90.52 Y153.061 E.01746
;WIDTH:0.48669
G1 X90.3 Y152.404 E.02085
;WIDTH:0.522723
G1 X90.227 Y151.904 E.01642
G1 X90.177 Y151.708 E.00657
;WIDTH:0.481815
G1 X90.127 Y151.512 E.00602
;WIDTH:0.440907
G1 X90.076 Y151.316 E.00548
;WIDTH:0.399999
G1 X90.068 Y96.301 E1.33818
;WIDTH:0.443142
G1 X90.09 Y96.202 E.00276
;WIDTH:0.486284
G1 X90.111 Y96.103 E.00304
;WIDTH:0.529427
G1 X90.133 Y96.004 E.00334
;WIDTH:0.572569
G1 X90.154 Y95.905 E.00362
G1 X90.143 Y95.567 E.01211
;WIDTH:0.554322
G1 X90.145 Y93.167 E.08302
;WIDTH:0.580282
G1 X90.158 Y92.867 E.01091
G1 X90.135 Y92.821 E.00187
;WIDTH:0.535544
G1 X90.113 Y92.775 E.0017
;WIDTH:0.490806
G1 X90.091 Y92.729 E.00155
;WIDTH:0.446068
G1 X90.068 Y92.682 E.00143
;WIDTH:0.40133
G1 X90.068 Y92.345 E.00823
;WIDTH:0.399999
G1 X90.066 Y80.017 E.29987
G1 X90.106 Y79.345 E.01637
G1 X90.225 Y78.7 E.01595
G1 X90.42 Y78.073 E.01597
G1 X90.689 Y77.475 E.01595
G1 X91.028 Y76.914 E.01594
G1 X91.433 Y76.397 E.01597
G1 X91.897 Y75.933 E.01596
G1 X92.414 Y75.528 E.01597
G1 X92.973 Y75.19 E.01589
G1 X93.656 Y74.891 E.01814
G1 X94.191 Y74.727 E.01361
G1 X95.18 Y74.577 E.02433
G1 X99.51 Y74.576 E.10532
;WIDTH:0.446042
G1 X99.734 Y74.599 E.00617
;WIDTH:0.492084
G1 X99.959 Y74.622 E.00689
;WIDTH:0.538126
G1 X100.183 Y74.645 E.00755
;WIDTH:0.539178
G1 X130.817 Y74.644 E1.02876
G1 X131.042 Y74.621 E.0076
;WIDTH:0.492785
G1 X131.266 Y74.597 E.00687
;WIDTH:0.446392
G1 X131.491 Y74.574 E.0062
;WIDTH:0.399999
G1 X135.632 Y74.574 E.10073
G1 X136.15 Y74.605 E.01262
G1 X136.792 Y74.723 E.01588
G1 X137.73 Y75.047 E.02414
G1 X138.586 Y75.53 E.02391
G1 X139.341 Y76.159 E.0239
G1 X139.971 Y76.914 E.02392
G1 X140.454 Y77.771 E.02393
G1 X140.777 Y78.708 E.02411
G1 X140.867 Y79.2 E.01217
G1 X140.923 Y79.819 E.01512
G1 X140.925 Y92.765 E.3149
;WIDTH:0.440254
G1 X140.905 Y92.833 E.00191
;WIDTH:0.480509
G1 X140.885 Y92.902 E.00213
;WIDTH:0.520764
G1 X140.865 Y92.971 E.00232
;WIDTH:0.561018
G1 X140.845 Y93.039 E.00248
G1 X140.852 Y93.263 E.00785
;WIDTH:0.547029
G1 X140.852 Y95.566 E.07854
;WIDTH:0.568871
G1 X140.841 Y95.899 E.01185
G1 X140.861 Y95.978 E.0029
;WIDTH:0.529159
G1 X140.881 Y96.057 E.00268
;WIDTH:0.489446
G1 X140.901 Y96.135 E.00244
;WIDTH:0.449733
G1 X140.921 Y96.214 E.00225
;WIDTH:0.41002
G1 X140.926 Y96.397 E.00457
;WIDTH:0.399999
G1 X140.934 Y150.41 E1.31381
G1 X140.934 Y150.996 E.01425
G1 X140.891 Y151.668 E.01638
;WIDTH:0.445651
G1 X140.798 Y152.018 E.00991
;WIDTH:0.491303
G1 X140.551 Y152.906 E.02802
;WIDTH:0.46806
G1 X140.304 Y153.505 E.01869
;WIDTH:0.429039
G1 X139.993 Y154.055 E.01659
;WIDTH:0.399999
G1 X139.596 Y154.569 E.0158
G1 X139.144 Y155.029 E.01569
G1 X138.519 Y155.517 E.01929
G1 X138.089 Y155.776 E.01221
G1 X137.397 Y156.091 E.01849
G1 X136.912 Y156.244 E.01237
G1 X136.406 Y156.357 E.01261
G1 X135.802 Y156.425 E.01478
G1 X125.371 Y156.423 E.25372
G1 E-5 F3600
G1 X125.371 Y156.423 F9000
G1 X125.371 Y156.436
G1 X90.654 Y153.496
G1 X90.049 Y150.992
G1 X90.049 Y112.792
G1 X90.469 Y112.792
G1 E5 F2400
;WIDTH:0.464594
G1 F6000
G1 X90.446 Y112.455 E.00967
;WIDTH:0.419911
G1 X90.424 Y112.118 E.00866
;WIDTH:0.416955
G1 X90.445 Y111.683 E.01108
;WIDTH:0.458682
G1 X90.465 Y111.248 E.01229
G1 E-5 F3600
G1 X90.465 Y111.248 F9000
G1 X90.854 Y111.356
G1 X90.845 Y111.388
G1 X90.826 Y111.483
G1 X90.807 Y111.626
G1 X90.791 Y111.815
G1 X90.786 Y112
G1 X90.791 Y112.185
G1 X90.807 Y112.374
G1 X90.826 Y112.517
G1 X90.845 Y112.612
G1 X90.896 Y112.797
G1 X90.934 Y112.893
G1 X91.007 Y113.039
G1 X91.136 Y113.219
G1 X91.216 Y113.294
G1 X91.344 Y113.393
G1 X91.545 Y113.483
G1 X91.705 Y113.515
G1 X91.772 Y113.522
G1 X92.141 Y113.523
G1 X93.321 Y113.521
G1 X93.568 Y113.52
G1 X93.569 Y113.903
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.569 Y118.097 E.10201
G1 X92.001 Y118.096 E.03814
G1 X91.524 Y118.137 E.01165
G1 X91.039 Y118.36 E.01298
G1 X90.743 Y118.68 E.0106
;WIDTH:0.428739
G1 X90.605 Y118.964 E.00828
;WIDTH:0.457478
G1 X90.466 Y119.248 E.0089
G1 X90.452 Y118.923 E.00916
;WIDTH:0.428739
G1 X90.437 Y118.599 E.00851
;WIDTH:0.399999
G1 X90.436 Y113.402 E.12641
;WIDTH:0.432297
G1 X90.452 Y113.097 E.00809
;WIDTH:0.464594
G1 X90.469 Y112.792 E.00874
G1 X90.606 Y113.056 E.00851
;WIDTH:0.432297
G1 X90.743 Y113.32 E.00787
;WIDTH:0.399999
G1 X91.049 Y113.64 E.01077
G1 X91.543 Y113.873 E.01329
G1 X91.8 Y113.905 E.0063
G1 X93.509 Y113.903 E.04157
G1 X93.509 Y113.903 F9000
G1 X93.203 Y114.269
G1 F6000
G1 X93.203 Y117.731 E.08421
G1 X91.8 Y117.73 E.03413
G1 X91.236 Y117.845 E.014
G1 X90.805 Y118.075 E.01188
G1 X90.802 Y113.894 E.1017
G1 X91.026 Y114.057 E.00674
G1 X91.476 Y114.233 E.01175
G1 X91.8 Y114.27 E.00793
G1 X93.143 Y114.269 E.03267
G1 E-5 F3600
G1 X93.143 Y114.269 F9000
G1 X92.837 Y117.365
G1 E5 F2400
G1 F6000
G1 X91.8 Y117.364 E.02522
G1 X91.168 Y117.483 E.01564
G1 X91.168 Y114.498 E.07261
G1 X91.41 Y114.592 E.00631
G1 X91.8 Y114.636 E.00955
G1 X92.837 Y114.635 E.02522
G1 X92.837 Y117.305 E.06495
G1 E-5 F3600
G1 X92.837 Y117.305 F9000
G1 X91.216 Y118.706
G1 X91.136 Y118.781
G1 X91.007 Y118.961
G1 X90.934 Y119.107
G1 X90.896 Y119.203
G1 X90.845 Y119.388
G1 X90.826 Y119.483
G1 X90.807 Y119.626
G1 X90.791 Y119.815
G1 X90.786 Y120
G1 X90.791 Y120.185
G1 X90.807 Y120.374
G1 X90.826 Y120.517
G1 X90.845 Y120.612
G1 X90.864 Y120.682
G1 X90.469 Y120.792
G1 E5 F2400
;WIDTH:0.463386
G1 F6000
G1 X90.447 Y120.455 E.00964
;WIDTH:0.418704
G1 X90.424 Y120.118 E.00864
;WIDTH:0.41575
G1 X90.445 Y119.683 E.01105
;WIDTH:0.457478
G1 X90.466 Y119.248 E.01226
G1 E-5 F3600
G1 X90.466 Y119.248 F9000
G1 X90.854 Y119.356
G1 X90.845 Y119.388
G1 X90.826 Y119.483
G1 X90.807 Y119.626
G1 X90.791 Y119.815
G1 X90.786 Y120
G1 X90.791 Y120.185
G1 X90.807 Y120.374
G1 X90.826 Y120.517
G1 X90.845 Y120.612
G1 X90.896 Y120.797
G1 X90.934 Y120.893
G1 X91.007 Y121.039
G1 X91.136 Y121.219
G1 X91.216 Y121.294
G1 X91.344 Y121.393
G1 X91.545 Y121.483
G1 X91.705 Y121.515
G1 X91.772 Y121.522
G1 X92.141 Y121.523
G1 X92.869 Y121.521
G1 X93.568 Y121.52
G1 X93.569 Y121.903
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.569 Y126.097 E.10201
G1 X92.001 Y126.096 E.03814
G1 X91.524 Y126.137 E.01165
G1 X91.039 Y126.36 E.01298
G1 X90.743 Y126.68 E.0106
;WIDTH:0.428136
G1 X90.605 Y126.964 E.00827
;WIDTH:0.456272
G1 X90.467 Y127.248 E.00886
G1 X90.452 Y126.924 E.0091
;WIDTH:0.428136
G1 X90.438 Y126.599 E.00852
;WIDTH:0.399999
G1 X90.438 Y121.401 E.12644
;WIDTH:0.431693
G1 X90.453 Y121.097 E.00805
;WIDTH:0.463386
G1 X90.469 Y120.792 E.00872
G1 X90.606 Y121.056 E.00849
;WIDTH:0.431693
G1 X90.743 Y121.32 E.00786
;WIDTH:0.399999
G1 X91.049 Y121.64 E.01077
G1 X91.543 Y121.873 E.01329
G1 X91.8 Y121.905 E.0063
G1 X93.509 Y121.903 E.04157
G1 X93.509 Y121.903 F9000
G1 X93.156 Y122.269
G1 F6000
G1 X93.203 Y122.269 E.00114
G1 X93.203 Y125.731 E.08421
G1 X91.8 Y125.73 E.03413
G1 X91.236 Y125.845 E.014
G1 X90.806 Y126.076 E.01187
G1 X90.803 Y121.895 E.1017
G1 X91.026 Y122.057 E.0067
G1 X91.476 Y122.233 E.01175
G1 X91.8 Y122.27 E.00793
G1 X93.096 Y122.269 E.03152
G1 X93.096 Y122.269 F9000
G1 X92.713 Y122.635
G1 F6000
G1 X92.837 Y122.635 E.00302
G1 X92.837 Y125.365 E.0664
G1 X91.8 Y125.364 E.02522
G1 X91.169 Y125.482 E.01561
G1 X91.169 Y122.498 E.07258
G1 X91.41 Y122.592 E.00629
G1 X91.8 Y122.636 E.00955
G1 X92.653 Y122.635 E.02075
G1 E-5 F3600
G1 X90.47 Y128.792 F9000
G1 E5 F2400
;WIDTH:0.462176
G1 F6000
G1 X90.447 Y128.455 E.00961
;WIDTH:0.417497
G1 X90.425 Y128.118 E.00861
;WIDTH:0.414545
G1 X90.446 Y127.683 E.01101
;WIDTH:0.456272
G1 X90.467 Y127.248 E.01222
G1 E-5 F3600
G1 X90.467 Y127.248 F9000
G1 X90.446 Y135.429
G1 E5 F2400
;WIDTH:0.411768
G1 F6000
G1 X90.44 Y134.89 E.01353
;WIDTH:0.399999
G1 X90.439 Y129.401 E.13351
;WIDTH:0.431088
G1 X90.454 Y129.096 E.00806
;WIDTH:0.462176
G1 X90.47 Y128.792 E.00866
G1 X90.606 Y129.056 E.00845
;WIDTH:0.431088
G1 X90.743 Y129.32 E.00785
;WIDTH:0.399999
G1 X91.049 Y129.64 E.01077
G1 X91.543 Y129.873 E.01329
G1 X91.798 Y129.905 E.00625
G1 X93.569 Y129.905 E.04308
G1 X93.569 Y132.688 E.06769
G1 X93.59 Y133.256 E.01383
G1 X93.676 Y134.095 E.02051
G1 X91.798 Y134.095 E.04568
G1 X91.438 Y134.169 E.00894
G1 X91.201 Y134.271 E.00628
G1 X90.839 Y134.55 E.01112
G1 X90.606 Y134.92 E.01064
;WIDTH:0.411768
G1 X90.464 Y135.372 E.0119
G1 X90.464 Y135.372 F9000
G1 X90.805 Y134.129
;WIDTH:0.399999
G1 F6000
G1 X90.804 Y129.897 E.10294
G1 X91.026 Y130.057 E.00666
G1 X91.476 Y130.233 E.01175
G1 X91.798 Y130.27 E.00788
G1 X93.203 Y130.271 E.03418
G1 X93.204 Y132.7 E.05908
G1 X93.22 Y133.203 E.01224
G1 X93.271 Y133.729 E.01285
G1 X91.798 Y133.73 E.03583
G1 X91.294 Y133.833 E.01251
G1 X91.057 Y133.935 E.00628
G1 X90.853 Y134.092 E.00626
G1 X90.853 Y134.092 F9000
G1 X91.171 Y133.493
G1 F6000
G1 X91.17 Y130.499 E.07283
G1 X91.41 Y130.592 E.00626
G1 X91.798 Y130.636 E.0095
G1 X92.837 Y130.636 E.02527
G1 X92.838 Y132.711 E.05047
G1 X92.866 Y133.364 E.0159
G1 X91.798 Y133.364 E.02598
G1 X91.229 Y133.481 E.01413
G1 E-5 F3600
G1 X91.229 Y133.481 F9000
G1 X90.451 Y136.648
G1 E5 F2400
;WIDTH:0.421748
G1 F6000
G1 X90.437 Y136.364 E.00733
;WIDTH:0.39461
G1 X90.423 Y136.081 E.00679
;WIDTH:0.411768
G1 X90.446 Y135.429 E.01638
G1 E-5 F3600
G1 X90.446 Y135.429 F9000
G1 X90.486 Y143.242
G1 E5 F2400
;WIDTH:0.429916
G1 F6000
G1 X90.456 Y143.319 E.00217
G1 X90.441 Y142.788 E.01398
;WIDTH:0.399999
G1 X90.44 Y137.324 E.13291
;WIDTH:0.421748
G1 X90.451 Y136.648 E.01742
G1 X90.481 Y136.759 E.00296
;WIDTH:0.415385
G1 X90.697 Y137.236 E.01327
;WIDTH:0.399999
G1 X90.898 Y137.495 E.00797
G1 X91.332 Y137.802 E.01293
G1 X91.783 Y137.903 E.01124
G1 X94.953 Y137.904 E.07711
G1 X95.177 Y138.305 E.01117
G1 X95.808 Y139.226 E.02716
G1 X96.538 Y140.087 E.02746
G1 X97.292 Y140.817 E.02553
G1 X97.981 Y141.373 E.02154
G1 X99.1 Y142.095 E.03239
G1 X91.783 Y142.097 E.17798
G1 X91.375 Y142.193 E.0102
G1 X91.129 Y142.316 E.00669
G1 X90.758 Y142.654 E.01221
G1 X90.641 Y142.845 E.00545
;WIDTH:0.429916
G1 X90.508 Y143.186 E.00963
G1 X90.508 Y143.186 F9000
G1 X90.806 Y142.134
;WIDTH:0.399999
G1 F6000
G1 X90.806 Y137.858 E.10401
G1 X91.216 Y138.149 E.01223
G1 X91.783 Y138.269 E.0141
G1 X94.736 Y138.269 E.07183
G1 X94.874 Y138.51 E.00676
G1 X95.528 Y139.462 E.02809
G1 X96.197 Y140.256 E.02525
G1 X97.061 Y141.1 E.02938
G1 X97.854 Y141.73 E.02464
G1 X91.783 Y141.731 E.14767
G1 X91.212 Y141.866 E.01427
G1 X90.965 Y141.989 E.00671
G1 X90.851 Y142.094 E.00377
G1 X90.851 Y142.094 F9000
G1 X91.172 Y141.509
G1 F6000
G1 X91.171 Y138.52 E.0727
G1 X91.263 Y138.55 E.00235
G1 X91.783 Y138.635 E.01282
G1 X94.523 Y138.635 E.06665
G1 X95.248 Y139.697 E.03128
G1 X96.028 Y140.611 E.02923
G1 X96.808 Y141.364 E.02637
G1 X91.783 Y141.365 E.12223
G1 X91.23 Y141.496 E.01382
G1 E-5 F3600
G1 X91.23 Y141.496 F9000
G1 X90.845 Y143.388
G1 X90.826 Y143.483
G1 X90.807 Y143.626
G1 X90.791 Y143.815
G1 X90.786 Y144
G1 X90.791 Y144.185
G1 X90.807 Y144.374
G1 X90.826 Y144.517
G1 X90.845 Y144.612
G1 X90.896 Y144.797
G1 X90.934 Y144.893
G1 X91.007 Y145.039
G1 X91.136 Y145.219
G1 X91.216 Y145.293
G1 X91.344 Y145.393
G1 X91.545 Y145.483
G1 X91.705 Y145.515
G1 X91.772 Y145.522
G1 X96.943 Y145.522
G1 X96.943 Y145.905
G1 E5 F2400
G1 F6000
G1 X105.331 Y145.905 E.20403
G1 X105.737 Y145.81 E.01014
G1 X105.974 Y145.641 E.00708
G1 X106.156 Y145.386 E.00762
G1 X106.246 Y144.995 E.00976
G1 X106.253 Y143.538 E.03544
G1 X110.519 Y143.532 E.10377
G1 X110.854 Y143.467 E.0083
G1 X111.164 Y143.263 E.00903
G1 X111.27 Y143.008 E.00672
G1 X119.73 Y143.008 E.20578
G1 X119.836 Y143.263 E.00672
G1 X120.146 Y143.467 E.00903
G1 X120.483 Y143.532 E.00835
G1 X124.753 Y143.532 E.10386
G1 X124.754 Y144.992 E.03551
G1 X124.784 Y145.221 E.00562
G1 X124.958 Y145.566 E.0094
G1 X125.263 Y145.81 E.0095
G1 X125.668 Y145.905 E.01012
G1 X139.203 Y145.905 E.32923
G1 X139.653 Y145.807 E.0112
G1 X140.054 Y145.552 E.01156
G1 X140.211 Y145.38 E.00566
G1 X140.394 Y145.08 E.00855
;WIDTH:0.42941
G1 X140.553 Y144.649 E.01207
G1 X140.568 Y145.111 E.01215
;WIDTH:0.399999
G1 X140.569 Y150.975 E.14264
G1 X140.549 Y151.553 E.01407
;WIDTH:0.391201
G1 X140.511 Y151.278 E.00659
;WIDTH:0.399999
G1 X140.402 Y150.942 E.00859
G1 X140.161 Y150.55 E.01119
G1 X139.799 Y150.271 E.01112
G1 X139.562 Y150.169 E.00628
G1 X139.202 Y150.095 E.00894
G1 X125.668 Y150.095 E.3292
G1 X125.263 Y150.19 E.01012
G1 X125.026 Y150.359 E.00708
G1 X124.82 Y150.668 E.00903
G1 X124.754 Y151.009 E.00845
G1 X124.754 Y152.991 E.04821
G1 X124.776 Y153.191 E.00489
G1 X124.862 Y153.421 E.00597
G1 X125.038 Y153.653 E.00708
G1 X125.317 Y153.835 E.0081
G1 X125.668 Y153.905 E.00871
G1 X139.127 Y153.905 E.32738
G1 X139.476 Y153.863 E.00855
G1 X139.752 Y153.746 E.00729
G1 X139.32 Y154.328 E.01763
G1 X138.9 Y154.756 E.01459
G1 X138.311 Y155.215 E.01816
G1 X137.875 Y155.472 E.01231
G1 X137.21 Y155.767 E.0177
G1 X136.348 Y155.996 E.02169
G1 X135.782 Y156.059 E.01385
G1 X97.146 Y156.053 E.93978
G1 X95.391 Y156.066 E.04269
G1 X94.845 Y156.025 E.01332
G1 X94.236 Y155.907 E.01509
G1 X93.729 Y155.747 E.01293
G1 X93.233 Y155.529 E.01318
G1 X92.806 Y155.286 E.01195
G1 X92.069 Y154.724 E.02254
G1 X91.624 Y154.257 E.01569
G1 X91.248 Y153.746 E.01543
G1 X91.343 Y153.806 E.00273
G1 X91.797 Y153.905 E.0113
G1 X105.332 Y153.905 E.32923
G1 X105.683 Y153.835 E.00871
G1 X105.962 Y153.653 E.0081
G1 X106.138 Y153.421 E.00708
G1 X106.224 Y153.191 E.00597
G1 X106.246 Y152.991 E.00489
G1 X106.246 Y151.009 E.04821
G1 X106.203 Y150.732 E.00682
G1 X106.042 Y150.434 E.00824
G1 X105.737 Y150.19 E.0095
G1 X105.332 Y150.095 E.01012
G1 X91.783 Y150.097 E.32957
G1 X91.375 Y150.193 E.0102
G1 X91.128 Y150.316 E.00671
G1 X90.743 Y150.68 E.01289
;WIDTH:0.428818
G1 X90.607 Y150.948 E.00789
;WIDTH:0.457636
G1 X90.471 Y151.216 E.00846
G1 X90.456 Y150.908 E.00868
;WIDTH:0.428818
G1 X90.442 Y150.6 E.00809
;WIDTH:0.399999
G1 X90.438 Y144.475 E.14898
G1 X90.585 Y145.017 E.01366
G1 X90.789 Y145.381 E.01015
G1 X90.946 Y145.552 E.00565
G1 X91.347 Y145.807 E.01156
G1 X91.797 Y145.905 E.0112
G1 X96.883 Y145.905 E.12371
G1 E-5 F3600
G1 X96.883 Y145.905 F9000
G1 X96.883 Y145.522
G1 X91.772 Y145.522
G1 X91.705 Y145.515
G1 X91.545 Y145.483
G1 X91.344 Y145.393
G1 X91.216 Y145.293
G1 X91.136 Y145.219
G1 X91.007 Y145.039
G1 X90.934 Y144.893
G1 X90.896 Y144.797
G1 X90.845 Y144.612
G1 X90.826 Y144.517
G1 X90.814 Y144.429
G1 X90.813 Y144.425
G1 X90.438 Y144.475
G1 E5 F2400
;WIDTH:0.395162
G1 F6000
G1 X90.438 Y143.553 E.02213
;WIDTH:0.429916
G1 X90.456 Y143.319 E.00618
G1 E-5 F3600
G1 X90.456 Y143.319 F9000
G1 X90.843 Y143.396
G1 X90.826 Y143.483
G1 X90.807 Y143.626
G1 X90.791 Y143.815
G1 X90.786 Y144
G1 X90.791 Y144.185
G1 X90.807 Y144.374
G1 X90.826 Y144.517
G1 X90.845 Y144.612
G1 X90.896 Y144.797
G1 X90.934 Y144.893
G1 X91.007 Y145.039
G1 X91.136 Y145.219
G1 X91.216 Y145.293
G1 X91.344 Y145.393
G1 X91.545 Y145.483
G1 X91.705 Y145.515
G1 X96.59 Y146.27
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.331 Y146.271 E.21262
G1 X105.639 Y146.233 E.00755
G1 X106.094 Y146.019 E.01223
G1 X106.393 Y145.706 E.01053
G1 X106.569 Y145.316 E.01041
G1 X106.611 Y144.997 E.00783
G1 X106.617 Y143.903 E.02661
G1 X110.623 Y143.893 E.09744
G1 X110.989 Y143.807 E.00915
G1 X111.423 Y143.522 E.01263
G1 X111.484 Y143.374 E.00389
G1 X119.516 Y143.374 E.19537
G1 X119.577 Y143.522 E.00389
G1 X119.856 Y143.733 E.00851
G1 X120.132 Y143.848 E.00727
G1 X120.483 Y143.897 E.00862
G1 X124.388 Y143.897 E.09499
G1 X124.388 Y144.992 E.02663
G1 X124.43 Y145.314 E.0079
G1 X124.607 Y145.706 E.01046
G1 X124.906 Y146.019 E.01053
G1 X125.361 Y146.233 E.01223
G1 X125.668 Y146.271 E.00752
G1 X139.203 Y146.27 E.32923
G1 X139.763 Y146.156 E.0139
G1 X140.202 Y145.876 E.01267
G1 X140.203 Y150.135 E.1036
G1 X139.943 Y149.935 E.00798
G1 X139.706 Y149.833 E.00628
G1 X139.202 Y149.73 E.01251
G1 X125.668 Y149.729 E.3292
G1 X125.361 Y149.767 E.00752
G1 X124.906 Y149.981 E.01223
G1 X124.607 Y150.294 E.01053
G1 X124.449 Y150.62 E.00881
G1 X124.388 Y151.009 E.00958
G1 X124.388 Y152.991 E.04821
G1 X124.42 Y153.272 E.00688
G1 X124.539 Y153.593 E.00833
G1 X124.786 Y153.918 E.00993
G1 X125.176 Y154.172 E.01132
G1 X125.668 Y154.271 E.01221
G1 X138.864 Y154.27 E.32098
G1 X138.656 Y154.482 E.00722
G1 X138.12 Y154.9 E.01653
G1 X137.723 Y155.139 E.01127
G1 X137.1 Y155.418 E.0166
G1 X136.289 Y155.634 E.02041
G1 X135.762 Y155.694 E.0129
G1 X97.146 Y155.687 E.9393
G1 X95.403 Y155.701 E.0424
G1 X94.894 Y155.662 E.01242
G1 X94.326 Y155.552 E.01407
G1 X93.828 Y155.392 E.01272
G1 X93.047 Y155.009 E.02116
G1 X92.343 Y154.479 E.02143
G1 X92.136 Y154.27 E.00716
G1 X105.332 Y154.271 E.32098
G1 X105.824 Y154.172 E.01221
G1 X106.214 Y153.918 E.01132
G1 X106.461 Y153.593 E.00993
G1 X106.58 Y153.272 E.00833
G1 X106.612 Y152.991 E.00688
G1 X106.612 Y151.009 E.04821
G1 X106.574 Y150.7 E.00757
G1 X106.393 Y150.294 E.01081
G1 X106.094 Y149.981 E.01053
G1 X105.639 Y149.767 E.01223
G1 X105.332 Y149.729 E.00752
G1 X91.783 Y149.731 E.32957
G1 X91.211 Y149.866 E.0143
G1 X90.965 Y149.989 E.00669
G1 X90.808 Y150.138 E.00526
G1 X90.807 Y145.882 E.10352
G1 X91.237 Y146.156 E.0124
G1 X91.797 Y146.27 E.0139
G1 X96.53 Y146.27 E.11513
G1 X96.53 Y146.27 F9000
G1 X96.234 Y146.636
G1 F6000
G1 X105.331 Y146.636 E.22128
G1 X105.726 Y146.588 E.00968
G1 X106.061 Y146.466 E.00867
G1 X106.488 Y146.161 E.01276
G1 X106.696 Y145.911 E.00791
G1 X106.923 Y145.409 E.0134
G1 X106.977 Y144.999 E.01006
G1 X106.981 Y144.268 E.01778
G1 X110.52 Y144.263 E.08608
G1 X110.876 Y144.223 E.00871
G1 X111.323 Y144.052 E.01164
G1 X111.698 Y143.739 E.01188
G1 X119.302 Y143.739 E.18496
G1 X119.677 Y144.052 E.01188
G1 X120.032 Y144.2 E.00936
G1 X120.483 Y144.263 E.01108
G1 X124.022 Y144.263 E.08608
G1 X124.023 Y144.992 E.01773
G1 X124.076 Y145.406 E.01015
G1 X124.304 Y145.911 E.01348
G1 X124.511 Y146.161 E.00789
G1 X124.939 Y146.466 E.01278
G1 X125.273 Y146.588 E.00865
G1 X125.668 Y146.636 E.00968
G1 X139.203 Y146.636 E.32923
G1 X139.837 Y146.516 E.0157
G1 X139.837 Y149.494 E.07244
G1 X139.202 Y149.364 E.01577
G1 X125.668 Y149.364 E.3292
G1 X125.273 Y149.412 E.00968
G1 X124.939 Y149.534 E.00865
G1 X124.511 Y149.839 E.01278
G1 X124.304 Y150.089 E.00789
G1 X124.101 Y150.509 E.01135
G1 X124.023 Y151.009 E.01231
G1 X124.023 Y152.991 E.04821
G1 X124.063 Y153.352 E.00883
G1 X124.216 Y153.765 E.01071
G1 X124.534 Y154.182 E.01276
G1 X125.035 Y154.51 E.01457
;WIDTH:0.440543
G1 X125.194 Y154.562 E.00452
;WIDTH:0.481087
G1 X125.352 Y154.614 E.00494
;WIDTH:0.521631
G1 X125.51 Y154.665 E.00538
;WIDTH:0.562175
G1 X125.668 Y154.717 E.00584
;WIDTH:0.563093
G1 X136.18 Y154.705 E.36974
;WIDTH:0.53749
G1 X137.608 Y154.705 E.0478
G1 X136.97 Y155.003 E.02357
G1 X136.232 Y155.203 E.02559
;WIDTH:0.563093
G1 X135.722 Y155.246 E.018
G1 X125.668 Y155.245 E.35363
;WIDTH:0.562175
G1 X125.469 Y155.265 E.00702
;WIDTH:0.521631
G1 X125.27 Y155.286 E.00649
;WIDTH:0.481087
G1 X125.071 Y155.306 E.00594
;WIDTH:0.440543
G1 X124.872 Y155.326 E.0054
;WIDTH:0.399999
G1 X106.127 Y155.323 E.45595
;WIDTH:0.443881
G1 X106.015 Y155.301 E.00311
;WIDTH:0.487762
G1 X105.902 Y155.279 E.00347
;WIDTH:0.531643
G1 X105.79 Y155.257 E.00378
;WIDTH:0.575524
G1 X105.678 Y155.235 E.00411
G1 X105.332 Y155.243 E.01246
;WIDTH:0.560454
G1 X97.146 Y155.242 E.28649
;WIDTH:0.559846
G1 X97.132 Y155.242 E.00049
;WIDTH:0.566505
G1 X95.43 Y155.252 E.06025
G1 X94.953 Y155.224 E.01691
;WIDTH:0.549609
G1 X94.446 Y155.126 E.0177
G1 X94.005 Y154.988 E.01584
G1 X93.415 Y154.711 E.02234
G1 X94.486 Y154.711 E.03671
;WIDTH:0.566505
G1 X97.146 Y154.716 E.09416
;WIDTH:0.560454
G1 X105.332 Y154.716 E.28649
;WIDTH:0.575524
G1 X105.631 Y154.698 E.01078
G1 X105.714 Y154.651 E.00343
;WIDTH:0.531643
G1 X105.798 Y154.604 E.00318
;WIDTH:0.487762
G1 X105.881 Y154.557 E.00288
;WIDTH:0.443881
G1 X105.965 Y154.51 E.00262
;WIDTH:0.399999
G1 X106.467 Y154.182 E.01459
G1 X106.784 Y153.765 E.01274
G1 X106.937 Y153.352 E.01071
G1 X106.977 Y152.991 E.00883
G1 X106.977 Y151.009 E.04821
G1 X106.9 Y150.51 E.01228
G1 X106.696 Y150.089 E.01138
G1 X106.488 Y149.839 E.00791
G1 X106.061 Y149.534 E.01276
G1 X105.726 Y149.412 E.00867
G1 X105.332 Y149.364 E.00965
G1 X91.783 Y149.365 E.32957
G1 X91.173 Y149.509 E.01525
G1 X91.173 Y146.519 E.07273
G1 X91.797 Y146.636 E.01544
G1 X96.174 Y146.636 E.10647
G1 E-5 F3600
G1 X96.174 Y146.636 F9000
G1 X139.228 Y145.522
G1 X139.295 Y145.515
G1 X139.455 Y145.483
G1 X139.656 Y145.393
G1 X139.784 Y145.294
G1 X139.864 Y145.219
G1 X139.993 Y145.039
G1 X140.066 Y144.893
G1 X140.104 Y144.797
G1 X140.155 Y144.612
G1 X140.174 Y144.517
G1 X140.193 Y144.374
G1 X140.209 Y144.185
G1 X140.214 Y144
G1 X140.209 Y143.815
G1 X140.193 Y143.626
G1 X140.186 Y143.571
G1 X140.174 Y143.483
G1 X140.555 Y143.426
G1 E5 F2400
;WIDTH:0.424696
G1 F6000
G1 X140.58 Y144.132 E.01834
;WIDTH:0.402604
G1 X140.566 Y144.39 E.00633
;WIDTH:0.42941
G1 X140.553 Y144.649 E.00682
G1 X140.555 Y143.426 F9000
;WIDTH:0.424696
G1 F6000
G1 X140.415 Y142.983 E.01206
;WIDTH:0.399999
G1 X140.211 Y142.619 E.01015
G1 X140.054 Y142.448 E.00565
G1 X139.668 Y142.198 E.01119
G1 X139.217 Y142.097 E.01124
G1 X131.9 Y142.095 E.17798
G1 X132.253 Y141.894 E.00988
G1 X133.083 Y141.326 E.02446
G1 X133.769 Y140.763 E.02159
G1 X134.511 Y140.035 E.02528
G1 X134.987 Y139.488 E.01764
G1 X135.649 Y138.579 E.02735
G1 X136.034 Y137.904 E.0189
G1 X139.217 Y137.903 E.07742
G1 X139.625 Y137.807 E.0102
G1 X139.871 Y137.684 E.00669
G1 X140.242 Y137.346 E.01221
G1 X140.359 Y137.155 E.00545
;WIDTH:0.428038
G1 X140.552 Y136.648 E.01421
G1 X140.567 Y137.214 E.01483
;WIDTH:0.399999
G1 X140.567 Y142.481 E.12811
;WIDTH:0.424696
G1 X140.556 Y143.366 E.02298
G1 X140.556 Y143.366 F9000
G1 X140.202 Y142.122
;WIDTH:0.399999
G1 F6000
G1 X139.784 Y141.851 E.01212
G1 X139.217 Y141.731 E.0141
G1 X133.146 Y141.729 E.14767
G1 X134.024 Y141.025 E.02737
G1 X134.786 Y140.276 E.02599
G1 X135.281 Y139.705 E.01838
G1 X135.967 Y138.76 E.0284
G1 X136.247 Y138.269 E.01375
G1 X139.217 Y138.269 E.07224
G1 X139.788 Y138.134 E.01427
G1 X140.035 Y138.011 E.00671
G1 X140.201 Y137.859 E.00547
G1 X140.202 Y142.062 E.10223
G1 X140.202 Y142.062 F9000
G1 X139.836 Y141.483
G1 F6000
G1 X139.737 Y141.45 E.00254
G1 X139.217 Y141.365 E.01282
G1 X134.192 Y141.364 E.12223
G1 X135.061 Y140.517 E.02952
G1 X135.575 Y139.922 E.01913
G1 X136.179 Y139.103 E.02475
G1 X136.459 Y138.635 E.01327
G1 X139.217 Y138.635 E.06709
G1 X139.835 Y138.489 E.01545
G1 X139.836 Y141.423 E.07137
G1 E-5 F3600
G1 X139.836 Y141.423 F9000
G1 X140.557 Y135.429
G1 E5 F2400
;WIDTH:0.417706
G1 F6000
G1 X140.581 Y136 E.01457
;WIDTH:0.417836
G1 X140.558 Y136.571 E.01458
;WIDTH:0.428038
G1 X140.552 Y136.648 E.00202
G1 X140.552 Y136.648 F9000
;WIDTH:0.417706
G1 F6000
G1 X140.394 Y134.92 E.01363
;WIDTH:0.399999
G1 X140.161 Y134.55 E.01064
G1 X139.799 Y134.271 E.01112
G1 X139.562 Y134.169 E.00628
G1 X139.202 Y134.095 E.00894
G1 X137.324 Y134.095 E.04568
G1 X137.414 Y133.196 E.02198
G1 X137.431 Y132.616 E.01411
G1 X137.431 Y129.903 E.06599
G1 X139.2 Y129.905 E.04303
G1 X139.562 Y129.831 E.00899
G1 X139.799 Y129.729 E.00628
G1 X140.218 Y129.367 E.01347
G1 X140.378 Y129.106 E.00745
G1 X140.494 Y128.817 E.00757
G1 X140.562 Y128.507 E.00772
G1 X140.566 Y134.889 E.15524
;WIDTH:0.417706
G1 X140.558 Y135.369 E.01224
G1 X140.558 Y135.369 F9000
G1 X140.2 Y134.133
;WIDTH:0.399999
G1 F6000
G1 X139.943 Y133.935 E.00789
G1 X139.706 Y133.833 E.00628
G1 X139.202 Y133.73 E.01251
G1 X137.729 Y133.729 E.03583
G1 X137.78 Y133.207 E.01276
G1 X137.797 Y132.616 E.01438
G1 X137.797 Y130.269 E.05709
G1 X139.2 Y130.27 E.03413
G1 X139.706 Y130.167 E.01256
G1 X139.943 Y130.065 E.00628
G1 X140.2 Y129.844 E.00824
G1 X140.2 Y134.073 E.10287
G1 X140.2 Y134.073 F9000
G1 X139.835 Y133.494
G1 F6000
G1 X139.202 Y133.364 E.01572
G1 X138.135 Y133.364 E.02595
G1 X138.163 Y132.616 E.01821
G1 X138.163 Y130.635 E.04819
G1 X139.2 Y130.636 E.02522
G1 X139.834 Y130.506 E.01574
G1 X139.835 Y133.434 E.07122
G1 E-5 F3600
G1 X139.835 Y133.434 F9000
G1 X140.55 Y127.341
G1 E5 F2400
;WIDTH:0.429728
G1 F6000
G1 X140.572 Y128.299 E.0252
;WIDTH:0.39983
G1 X140.565 Y128.475 E.00428
G1 E-5 F3600
G1 X140.565 Y128.475 F9000
G1 X140.187 Y128.425
G1 X140.193 Y128.374
G1 X140.209 Y128.185
G1 X140.214 Y128
G1 X140.209 Y127.815
G1 X140.193 Y127.626
G1 X140.174 Y127.483
G1 X140.155 Y127.388
G1 X140.104 Y127.203
G1 X140.066 Y127.107
G1 X139.993 Y126.961
G1 X139.864 Y126.781
G1 X139.784 Y126.706
G1 X139.656 Y126.607
G1 X139.455 Y126.517
G1 X139.295 Y126.485
G1 X139.228 Y126.478
G1 X138.859 Y126.477
G1 X137.679 Y126.479
G1 X137.432 Y126.48
G1 X137.431 Y126.097
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y121.903 E.10201
G1 X139 Y121.904 E.03816
G1 X139.476 Y121.863 E.01162
G1 X139.961 Y121.64 E.01298
G1 X140.257 Y121.32 E.0106
;WIDTH:0.432414
G1 X140.394 Y121.056 E.00788
;WIDTH:0.464828
G1 X140.532 Y120.792 E.00853
G1 X140.548 Y121.097 E.00875
;WIDTH:0.432414
G1 X140.564 Y121.402 E.00809
;WIDTH:0.399999
G1 X140.565 Y126.598 E.12639
;WIDTH:0.429728
G1 X140.55 Y127.341 E.01955
G1 X140.492 Y127.144 E.0054
;WIDTH:0.414303
G1 X140.257 Y126.68 E.01315
;WIDTH:0.399999
G1 X139.951 Y126.36 E.01077
G1 X139.457 Y126.127 E.01329
G1 X139.2 Y126.095 E.0063
G1 X137.491 Y126.097 E.04157
G1 E-5 F3600
G1 X137.491 Y126.097 F9000
G1 X137.797 Y122.269
G1 E5 F2400
G1 F6000
G1 X139.2 Y122.27 E.03413
G1 X139.764 Y122.155 E.014
G1 X140.195 Y121.925 E.01188
G1 X140.199 Y126.107 E.10172
G1 X139.974 Y125.943 E.00677
G1 X139.524 Y125.767 E.01175
G1 X139.2 Y125.73 E.00793
G1 X137.797 Y125.731 E.03413
G1 X137.797 Y122.329 E.08275
G1 X137.797 Y122.329 F9000
G1 X138.163 Y122.635
G1 F6000
G1 X139.2 Y122.636 E.02522
G1 X139.833 Y122.517 E.01567
G1 X139.833 Y125.503 E.07263
G1 X139.59 Y125.408 E.00635
G1 X139.2 Y125.364 E.00955
G1 X138.163 Y125.365 E.02522
G1 X138.163 Y122.695 E.06495
G1 E-5 F3600
G1 X138.163 Y122.695 F9000
G1 X139.784 Y121.294
G1 X139.864 Y121.219
G1 X139.993 Y121.039
G1 X140.066 Y120.893
G1 X140.104 Y120.797
G1 X140.155 Y120.612
G1 X140.174 Y120.517
G1 X140.193 Y120.374
G1 X140.209 Y120.185
G1 X140.214 Y120
G1 X140.209 Y119.815
G1 X140.193 Y119.626
G1 X140.174 Y119.483
G1 X140.155 Y119.388
G1 X140.146 Y119.356
G1 X140.535 Y119.248
G1 E5 F2400
;WIDTH:0.458494
G1 F6000
G1 X140.555 Y119.565 E.00896
;WIDTH:0.416881
G1 X140.576 Y119.882 E.00808
;WIDTH:0.416998
G1 X140.555 Y120.317 E.01109
;WIDTH:0.458728
G1 X140.535 Y120.752 E.01229
;WIDTH:0.464828
G1 X140.532 Y120.792 E.00115
G1 E-5 F3600
G1 X140.532 Y120.792 F9000
G1 X140.136 Y120.682
G1 X140.214 Y120
G1 X140.104 Y119.203
G1 X140.066 Y119.107
G1 X139.993 Y118.961
G1 X139.864 Y118.781
G1 X139.784 Y118.706
G1 X139.656 Y118.607
G1 X139.455 Y118.517
G1 X139.295 Y118.485
G1 X139.228 Y118.478
G1 X138.859 Y118.477
G1 X137.679 Y118.479
G1 X137.432 Y118.48
G1 X137.431 Y118.097
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y113.903 E.10201
G1 X138.999 Y113.904 E.03814
G1 X139.476 Y113.863 E.01165
G1 X139.961 Y113.64 E.01298
G1 X140.257 Y113.32 E.0106
;WIDTH:0.431795
G1 X140.394 Y113.056 E.00786
;WIDTH:0.46359
G1 X140.531 Y112.792 E.00849
G1 X140.547 Y113.097 E.00872
;WIDTH:0.431795
G1 X140.563 Y113.401 E.00805
;WIDTH:0.399999
G1 X140.564 Y118.598 E.12641
;WIDTH:0.429247
G1 X140.549 Y118.923 E.00855
;WIDTH:0.458494
G1 X140.535 Y119.248 E.00918
G1 X140.396 Y118.964 E.00892
;WIDTH:0.429247
G1 X140.257 Y118.68 E.00831
;WIDTH:0.399999
G1 X139.951 Y118.36 E.01077
G1 X139.457 Y118.127 E.01329
G1 X139.2 Y118.095 E.0063
G1 X137.491 Y118.097 E.04157
G1 X137.491 Y118.097 F9000
G1 X137.797 Y117.731
G1 F6000
G1 X137.797 Y114.269 E.08421
G1 X139.2 Y114.27 E.03413
G1 X139.764 Y114.155 E.014
G1 X140.195 Y113.925 E.01188
G1 X140.198 Y118.106 E.1017
G1 X139.974 Y117.943 E.00674
G1 X139.524 Y117.767 E.01175
G1 X139.2 Y117.73 E.00793
G1 X137.857 Y117.731 E.03267
G1 X137.857 Y117.731 F9000
G1 X138.163 Y117.365
G1 F6000
G1 X138.163 Y114.635 E.0664
G1 X139.2 Y114.636 E.02522
G1 X139.832 Y114.517 E.01564
G1 X139.832 Y117.502 E.07261
G1 X139.59 Y117.408 E.00631
G1 X139.2 Y117.364 E.00955
G1 X138.223 Y117.365 E.02376
G1 E-5 F3600
G1 X138.223 Y117.365 F9000
G1 X140.534 Y111.248
G1 E5 F2400
;WIDTH:0.457262
G1 F6000
G1 X140.555 Y111.565 E.00894
;WIDTH:0.415649
G1 X140.576 Y111.882 E.00806
;WIDTH:0.415766
G1 X140.555 Y112.317 E.01105
;WIDTH:0.457496
G1 X140.534 Y112.752 E.01226
;WIDTH:0.46359
G1 X140.531 Y112.792 E.00115
G1 E-5 F3600
G1 X140.531 Y112.792 F9000
G1 X137.431 Y105.903
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X138.999 Y105.904 E.03814
G1 X139.476 Y105.863 E.01165
G1 X139.961 Y105.64 E.01298
G1 X140.257 Y105.32 E.0106
;WIDTH:0.431177
G1 X140.394 Y105.056 E.00785
;WIDTH:0.462354
G1 X140.53 Y104.792 E.00846
G1 X140.546 Y105.096 E.00867
;WIDTH:0.431177
G1 X140.562 Y105.401 E.00806
;WIDTH:0.399999
G1 X140.562 Y110.599 E.12644
;WIDTH:0.428631
G1 X140.548 Y110.923 E.00851
;WIDTH:0.457262
G1 X140.534 Y111.248 E.00915
G1 X140.395 Y110.964 E.0089
;WIDTH:0.428631
G1 X140.257 Y110.68 E.00828
;WIDTH:0.399999
G1 X139.951 Y110.36 E.01077
G1 X139.457 Y110.127 E.01329
G1 X139.2 Y110.095 E.0063
G1 X137.431 Y110.097 E.04303
G1 X137.431 Y105.963 E.10056
G1 X137.431 Y105.963 F9000
G1 X137.797 Y106.269
G1 F6000
G1 X139.2 Y106.27 E.03413
G1 X139.764 Y106.155 E.014
G1 X140.194 Y105.924 E.01187
G1 X140.197 Y110.105 E.1017
G1 X139.974 Y109.943 E.0067
G1 X139.524 Y109.767 E.01175
G1 X139.2 Y109.73 E.00793
G1 X137.797 Y109.731 E.03413
G1 X137.797 Y106.329 E.08275
G1 X137.797 Y106.329 F9000
G1 X138.163 Y106.635
G1 F6000
G1 X139.2 Y106.636 E.02522
G1 X139.831 Y106.518 E.01561
G1 X139.831 Y109.502 E.07258
G1 X139.59 Y109.408 E.00629
G1 X139.2 Y109.364 E.00955
G1 X138.163 Y109.365 E.02522
G1 X138.163 Y106.695 E.06495
G1 E-5 F3600
G1 X138.163 Y106.695 F9000
G1 X139.784 Y105.294
G1 X139.864 Y105.219
G1 X139.993 Y105.039
G1 X140.066 Y104.893
G1 X140.104 Y104.797
G1 X140.155 Y104.612
G1 X140.174 Y104.517
G1 X140.193 Y104.374
G1 X140.209 Y104.185
G1 X140.214 Y104
G1 X140.209 Y103.815
G1 X140.193 Y103.626
G1 X140.174 Y103.483
G1 X140.155 Y103.388
G1 X140.146 Y103.356
G1 X140.533 Y103.248
G1 E5 F2400
;WIDTH:0.456032
G1 F6000
G1 X140.554 Y103.565 E.00891
;WIDTH:0.414418
G1 X140.575 Y103.882 E.00803
;WIDTH:0.414533
G1 X140.554 Y104.317 E.01101
;WIDTH:0.456262
G1 X140.533 Y104.752 E.01222
;WIDTH:0.462354
G1 X140.53 Y104.792 E.00114
G1 E-5 F3600
G1 X140.53 Y104.792 F9000
G1 X140.136 Y104.682
G1 X140.214 Y104
G1 X140.104 Y103.203
G1 X140.066 Y103.107
G1 X139.993 Y102.961
G1 X139.864 Y102.781
G1 X139.784 Y102.706
G1 X139.656 Y102.607
G1 X139.455 Y102.517
G1 X139.295 Y102.485
G1 X139.228 Y102.478
G1 X138.859 Y102.477
G1 X137.679 Y102.479
G1 X137.432 Y102.48
G1 X137.431 Y102.097
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y97.011 E.12371
G1 X138.996 Y97.01 E.03807
G1 X139.526 Y96.969 E.01293
G1 X139.914 Y96.807 E.01023
G1 X140.134 Y96.648 E.0066
G1 X140.395 Y96.354 E.00956
;WIDTH:0.41002
G1 X140.545 Y96.068 E.00807
G1 X140.56 Y96.397 E.00823
;WIDTH:0.399999
G1 X140.561 Y102.599 E.15086
;WIDTH:0.428016
G1 X140.547 Y102.924 E.00852
;WIDTH:0.456032
G1 X140.533 Y103.248 E.0091
G1 X140.395 Y102.964 E.00886
;WIDTH:0.428016
G1 X140.257 Y102.68 E.00827
;WIDTH:0.399999
G1 X139.951 Y102.36 E.01077
G1 X139.457 Y102.127 E.01329
G1 X139.2 Y102.095 E.0063
G1 X137.491 Y102.097 E.04157
G1 X137.491 Y102.097 F9000
G1 X137.797 Y101.731
G1 F6000
G1 X137.797 Y97.376 E.10593
G1 X138.996 Y97.376 E.02916
G1 X139.585 Y97.33 E.01437
G1 X140.195 Y97.056 E.01627
G1 X140.196 Y102.103 E.12276
G1 X139.974 Y101.943 E.00666
G1 X139.524 Y101.767 E.01175
G1 X139.2 Y101.73 E.00793
G1 X137.857 Y101.731 E.03267
G1 X137.857 Y101.731 F9000
G1 X138.163 Y101.365
G1 F6000
G1 X138.163 Y97.742 E.08813
G1 X139.469 Y97.72 E.03177
G1 X139.829 Y97.614 E.00913
G1 X139.83 Y101.501 E.09455
G1 X139.59 Y101.408 E.00626
G1 X139.2 Y101.364 E.00955
G1 X138.223 Y101.365 E.02376
G1 E-5 F3600
G1 X138.223 Y101.365 F9000
G1 X140.19 Y95.926
G1 X140.235 Y95.749
G1 X140.244 Y95.652
G1 X140.249 Y95.587
G1 X140.249 Y93.241
G1 X140.244 Y93.176
G1 X140.235 Y93.08
G1 X140.19 Y92.903
G1 X140.114 Y92.736
G1 X140.011 Y92.583
G1 X139.882 Y92.451
G1 X139.732 Y92.342
G1 X139.564 Y92.261
G1 X126.349 Y88.151
G1 X121.687 Y88.151
G1 X119.951 Y86.599
G1 X119.874 Y86.703
G1 E5 F2400
G1 F6000
G1 X120.483 Y86.981 E.01628
G1 X127.211 Y86.962 E.16365
G1 X127.927 Y86.846 E.01764
G1 X128.863 Y86.527 E.02405
G1 X129.349 Y86.268 E.0134
G1 X129.951 Y85.838 E.01799
G1 X130.662 Y85.112 E.02472
G1 X131.075 Y84.498 E.018
G1 X131.503 Y83.515 E.02608
G1 X131.693 Y82.628 E.02206
G1 X131.731 Y82.051 E.01407
G1 X131.731 Y79.327 E.06626
G1 X132.482 Y78.64 E.02476
G1 X132.85 Y78.172 E.01448
G1 X132.974 Y77.946 E.00627
G1 X133.058 Y77.504 E.01094
G1 X132.927 Y76.972 E.01333
G1 X132.72 Y76.638 E.00956
G1 X132.094 Y75.994 E.02185
G1 X131.718 Y75.661 E.01222
G1 X131.702 Y75.537 E.00304
G1 X131.432 Y75.09 E.0127
G1 X131.043 Y74.94 E.01014
G1 X135.632 Y74.939 E.11162
G1 X136.103 Y74.968 E.01148
G1 X136.699 Y75.078 E.01474
G1 X137.579 Y75.381 E.02264
G1 X138.377 Y75.832 E.0223
G1 X139.082 Y76.419 E.02231
G1 X139.668 Y77.123 E.02228
G1 X140.119 Y77.922 E.02232
G1 X140.422 Y78.801 E.02262
G1 X140.507 Y79.266 E.0115
G1 X140.558 Y79.819 E.01351
G1 X140.56 Y92.868 E.3174
G1 X140.306 Y92.361 E.01379
G1 X140.117 Y92.165 E.00662
G1 X139.693 Y91.917 E.01195
G1 X139.201 Y91.818 E.01221
G1 X127.294 Y91.818 E.28963
G1 X127.482 Y91.64 E.0063
G1 X127.85 Y91.172 E.01448
G1 X128.014 Y90.806 E.00976
G1 X128.053 Y90.402 E.00987
G1 X127.918 Y89.947 E.01154
G1 X127.72 Y89.638 E.00893
G1 X127.337 Y89.244 E.01337
G1 X126.73 Y88.671 E.0203
G1 X126.689 Y88.409 E.00645
G1 X126.533 Y88.114 E.00812
G1 X126.234 Y87.869 E.0094
G1 X125.817 Y87.769 E.01043
G1 X105.183 Y87.769 E.5019
G1 X105.025 Y87.782 E.00386
G1 X104.581 Y87.995 E.01198
G1 X104.358 Y88.289 E.00898
G1 X104.27 Y88.671 E.00954
G1 X103.933 Y88.967 E.01091
G1 X103.415 Y89.475 E.01765
G1 X103.077 Y89.943 E.01404
G1 X102.961 Y90.317 E.00952
G1 X102.994 Y90.803 E.01185
G1 X103.073 Y91.028 E.0058
G1 X103.28 Y91.362 E.00956
G1 X103.723 Y91.818 E.01546
G1 X91.799 Y91.818 E.29004
G1 X91.474 Y91.859 E.00797
G1 X90.999 Y92.069 E.01263
G1 X90.642 Y92.419 E.01216
;WIDTH:0.40133
G1 X90.435 Y92.84 E.01145
G1 X90.433 Y92.345 E.01208
;WIDTH:0.399999
G1 X90.431 Y80.028 E.2996
G1 X90.47 Y79.389 E.01557
G1 X90.58 Y78.787 E.01489
G1 X90.762 Y78.203 E.01488
G1 X91.013 Y77.645 E.01488
G1 X91.33 Y77.122 E.01488
G1 X91.707 Y76.64 E.01488
G1 X92.14 Y76.207 E.01489
G1 X92.622 Y75.83 E.01488
G1 X93.141 Y75.516 E.01475
G1 X93.784 Y75.235 E.01707
G1 X94.272 Y75.085 E.01242
G1 X95.208 Y74.942 E.02303
G1 X99.871 Y74.942 E.11342
G1 X99.568 Y75.091 E.00821
G1 X99.298 Y75.537 E.01268
G1 X99.282 Y75.661 E.00304
G1 X98.518 Y76.36 E.02519
G1 X98.15 Y76.828 E.01448
G1 X97.986 Y77.194 E.00976
G1 X97.951 Y77.627 E.01057
G1 X98.083 Y78.054 E.01087
G1 X98.28 Y78.362 E.00889
G1 X99.27 Y79.328 E.03365
G1 X99.279 Y82.337 E.07319
G1 X99.294 Y82.497 E.00391
G1 X99.497 Y83.521 E.02539
G1 X99.848 Y84.358 E.02208
G1 X100.443 Y85.237 E.02582
G1 X101.202 Y85.96 E.0255
G1 X101.909 Y86.409 E.02037
G1 X102.211 Y86.551 E.00812
G1 X102.893 Y86.802 E.01768
G1 X103.572 Y86.939 E.01685
G1 X104.199 Y86.981 E.01529
G1 X110.517 Y86.981 E.15368
G1 X110.675 Y86.968 E.00386
G1 X111.209 Y86.665 E.01493
G1 X111.295 Y86.434 E.006
G1 X119.705 Y86.434 E.20456
G1 X119.791 Y86.665 E.006
G1 X119.819 Y86.678 E.00075
G1 E-5 F3600
G1 X119.819 Y86.678 F9000
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X105.183 Y87.375 E.0067
;WIDTH:0.456022
G1 X110.517 Y87.375 E.14962
;WIDTH:0.47584
G1 X110.745 Y87.365 E.0067
;WIDTH:0.518665
G1 X111.53 Y86.943 E.02871
G1 X111.561 Y86.859 E.00288
G1 X119.439 Y86.859 E.25381
G1 X119.47 Y86.943 E.00288
G1 X119.976 Y87.159 E.01773
;WIDTH:0.487331
G1 X120.483 Y87.375 E.01661
G1 X119.885 Y87.359 E.01803
;WIDTH:0.518665
G1 X119.287 Y87.344 E.01927
G1 X111.713 Y87.344 E.24402
G1 X110.805 Y87.364 E.02926
G1 E-5 F3600
G1 X110.805 Y87.364 F9000
G1 X125.817 Y87.371
G1 E5 F2400
;WIDTH:0.46404
G1 F6000
G1 X120.485 Y87.375 E.15241
;WIDTH:0.455996
G1 X120.483 Y87.375 E.00006
G1 E-5 F3600
G1 X120.483 Y87.375 F9000
G1 X125.817 Y87.371
G1 E5 F2400
;WIDTH:0.46404
G1 F6000
G1 X126.134 Y87.355 E.00907
;WIDTH:0.43202
G1 X126.451 Y87.338 E.0084
;WIDTH:0.399999
G1 X127.262 Y87.324 E.01973
G1 X128.041 Y87.194 E.01921
G1 X129.03 Y86.852 E.02545
G1 X129.556 Y86.57 E.01452
G1 X130.208 Y86.097 E.01959
G1 X130.962 Y85.322 E.0263
G1 X131.407 Y84.65 E.0196
G1 X131.772 Y83.857 E.02123
G1 X131.86 Y83.592 E.00679
G1 X132.054 Y82.691 E.02242
G1 X132.097 Y82.051 E.0156
G1 X132.097 Y79.493 E.06222
G1 X132.318 Y79.299 E.00715
G1 X132.907 Y78.705 E.02035
G1 X133.294 Y78.13 E.01686
G1 X133.416 Y77.637 E.01235
G1 X133.351 Y77.075 E.01376
G1 X133.272 Y76.85 E.0058
G1 X132.982 Y76.383 E.01337
G1 X132.091 Y75.501 E.0305
G1 X131.972 Y75.305 E.00558
G1 X135.632 Y75.305 E.08903
G1 X136.055 Y75.332 E.01031
G1 X136.606 Y75.432 E.01362
G1 X137.428 Y75.716 E.02115
G1 X138.169 Y76.134 E.02069
G1 X138.822 Y76.678 E.02067
G1 X139.366 Y77.332 E.02069
G1 X139.784 Y78.072 E.02067
G1 X139.978 Y78.633 E.01444
G1 X140.132 Y79.245 E.01535
G1 X140.192 Y79.819 E.01404
G1 X140.194 Y91.802 E.29147
G1 X139.786 Y91.563 E.0115
G1 X139.201 Y91.452 E.01448
G1 X128.096 Y91.452 E.27012
G1 X128.142 Y91.391 E.00186
G1 X128.372 Y90.88 E.01363
G1 X128.416 Y90.362 E.01265
G1 X128.351 Y90.075 E.00716
G1 X128.183 Y89.652 E.01107
G1 X127.982 Y89.383 E.00817
G1 X127.066 Y88.48 E.03129
G1 X127.038 Y88.299 E.00446
G1 X126.819 Y87.887 E.01135
G1 X126.401 Y87.544 E.01315
;WIDTH:0.43202
G1 X126.109 Y87.458 E.00805
;WIDTH:0.46404
G1 X125.875 Y87.388 E.00698
G1 X125.875 Y87.388 F9000
G1 X127.133 Y87.699
;WIDTH:0.399999
G1 F6000
G1 X127.314 Y87.686 E.00441
G1 X128.155 Y87.541 E.02076
G1 X129.197 Y87.177 E.02685
G1 X129.763 Y86.871 E.01565
G1 X130.465 Y86.357 E.02116
G1 X131.261 Y85.532 E.02789
G1 X131.739 Y84.803 E.0212
G1 X132.104 Y84.01 E.02123
G1 X132.218 Y83.669 E.00875
G1 X132.436 Y82.565 E.02737
G1 X132.463 Y82.051 E.01252
G1 X132.463 Y79.659 E.05818
G1 X133.199 Y78.925 E.02528
G1 X133.579 Y78.382 E.01612
G1 X133.712 Y78.032 E.00911
G1 X133.789 Y77.507 E.01291
G1 X133.696 Y76.954 E.01364
G1 X133.617 Y76.729 E.0058
G1 X133.245 Y76.128 E.01719
G1 X132.8 Y75.671 E.01552
G1 X135.632 Y75.671 E.06889
G1 X136.008 Y75.695 E.00916
G1 X136.513 Y75.787 E.01249
G1 X137.277 Y76.051 E.01966
G1 X137.96 Y76.436 E.01907
G1 X138.562 Y76.938 E.01907
G1 X139.064 Y77.54 E.01907
G1 X139.449 Y78.223 E.01907
G1 X139.632 Y78.753 E.01364
G1 X139.772 Y79.311 E.01399
G1 X139.826 Y79.819 E.01243
G1 X139.828 Y91.196 E.27673
G1 X139.201 Y91.087 E.01548
G1 X128.671 Y91.086 E.25613
G1 X128.756 Y90.83 E.00656
G1 X128.78 Y90.323 E.01235
G1 X128.696 Y89.954 E.00921
G1 X128.502 Y89.474 E.01259
G1 X128.245 Y89.128 E.01048
G1 X127.402 Y88.288 E.02895
G1 X127.387 Y88.19 E.00241
G1 X127.161 Y87.753 E.01197
G1 E-5 F3600
G1 X127.161 Y87.753 F9000
G1 X104.651 Y88.151
G1 X100.413 Y91.452
G1 E5 F2400
G1 F6000
G1 X91.799 Y91.452 E.20953
G1 X91.591 Y91.469 E.00508
G1 X90.968 Y91.662 E.01586
G1 X90.799 Y91.766 E.00483
G1 X90.797 Y80.152 E.2825
G1 X90.82 Y79.655 E.0121
G1 X90.896 Y79.091 E.01384
G1 X91.04 Y78.54 E.01385
G1 X91.25 Y78.01 E.01387
G1 X91.524 Y77.508 E.01391
G1 X91.856 Y77.043 E.0139
G1 X92.244 Y76.621 E.01394
G1 X92.681 Y76.248 E.01398
G1 X93.141 Y75.943 E.01343
G1 X93.766 Y75.642 E.01687
G1 X94.354 Y75.442 E.01511
G1 X95.236 Y75.308 E.0217
G1 X99.027 Y75.308 E.09221
G1 X98.944 Y75.446 E.00392
G1 X98.267 Y76.094 E.0228
G1 X97.858 Y76.609 E.016
G1 X97.603 Y77.243 E.01662
G1 X97.594 Y77.712 E.01141
G1 X97.769 Y78.252 E.01381
G1 X98.018 Y78.617 E.01075
G1 X98.905 Y79.495 E.03036
G1 X98.913 Y82.338 E.06915
G1 X98.934 Y82.562 E.00547
G1 X99.157 Y83.655 E.02713
G1 X99.541 Y84.557 E.02385
G1 X100.186 Y85.497 E.02773
G1 X101.006 Y86.268 E.02738
G1 X101.713 Y86.718 E.02039
G1 X102.079 Y86.892 E.00986
G1 X102.816 Y87.16 E.01908
G1 X103.546 Y87.304 E.0181
G1 X104.199 Y87.347 E.01592
;WIDTH:0.43792
G1 X104.577 Y87.366 E.01016
;WIDTH:0.47584
G1 X104.955 Y87.385 E.01112
G1 X104.647 Y87.552 E.01029
;WIDTH:0.43792
G1 X104.34 Y87.72 E.0094
;WIDTH:0.399999
G1 X104.028 Y88.131 E.01255
G1 X103.934 Y88.48 E.00879
G1 X103.682 Y88.701 E.00815
G1 X103.123 Y89.256 E.01916
G1 X102.755 Y89.769 E.01536
G1 X102.603 Y90.243 E.01211
G1 X102.649 Y90.925 E.01663
G1 X102.728 Y91.15 E.0058
G1 X102.916 Y91.452 E.00865
G1 X100.473 Y91.452 E.05942
G1 X100.473 Y91.452 F9000
G1 X99.793 Y91.087
G1 F6000
G1 X91.799 Y91.087 E.19445
G1 X91.531 Y91.109 E.00654
G1 X91.164 Y91.207 E.00924
G1 X91.163 Y80.152 E.2689
G1 X91.185 Y79.677 E.01157
G1 X91.256 Y79.157 E.01277
G1 X91.39 Y78.649 E.01278
G1 X91.584 Y78.16 E.0128
G1 X91.836 Y77.697 E.01282
G1 X92.144 Y77.269 E.01283
G1 X92.502 Y76.879 E.01288
G1 X92.906 Y76.536 E.01289
G1 X93.331 Y76.256 E.01238
G1 X93.912 Y75.977 E.01568
G1 X94.435 Y75.8 E.01343
G1 X95.263 Y75.674 E.02037
G1 X98.179 Y75.673 E.07093
G1 X98.016 Y75.828 E.00547
G1 X97.565 Y76.39 E.01753
G1 X97.269 Y77.047 E.01753
G1 X97.211 Y77.492 E.01092
G1 X97.274 Y77.953 E.01132
G1 X97.454 Y78.44 E.01263
G1 X97.755 Y78.872 E.01281
G1 X98.54 Y79.661 E.02707
G1 X98.548 Y82.339 E.06514
G1 X98.574 Y82.627 E.00703
G1 X98.817 Y83.79 E.0289
G1 X99.235 Y84.756 E.0256
G1 X99.706 Y85.483 E.02107
G1 X99.929 Y85.757 E.00859
G1 X100.535 Y86.357 E.02074
G1 X100.81 Y86.577 E.00857
G1 X101.517 Y87.026 E.02037
G1 X101.947 Y87.233 E.01161
G1 X102.739 Y87.517 E.02047
G1 X103.291 Y87.636 E.01374
G1 X103.894 Y87.695 E.01474
G1 X103.698 Y87.974 E.00829
G1 X103.598 Y88.288 E.00802
G1 X102.884 Y88.968 E.02398
G1 X102.565 Y89.39 E.01287
G1 X102.37 Y89.727 E.00947
G1 X102.244 Y90.17 E.0112
G1 X102.318 Y91.086 E.02235
G1 X99.853 Y91.087 E.05996
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X99.793 Y91.087 E-.0285
G1 X96.695 Y91.087 E-1.4715
;WIPE_END
G1 X93.569 Y97.011 F9000
G1 E5 F2400
G1 F6000
G1 X93.569 Y102.097 E.12371
G1 X92 Y102.096 E.03816
G1 X91.524 Y102.137 E.01162
G1 X91.039 Y102.36 E.01298
G1 X90.743 Y102.68 E.0106
;WIDTH:0.429943
G1 X90.604 Y102.964 E.00832
;WIDTH:0.459886
G1 X90.465 Y103.248 E.00895
G1 X90.45 Y102.923 E.00921
;WIDTH:0.429943
G1 X90.435 Y102.598 E.00856
;WIDTH:0.399999
G1 X90.434 Y95.956 E.16156
G1 X90.558 Y96.262 E.00803
G1 X90.712 Y96.489 E.00667
G1 X91 Y96.76 E.00962
G1 X91.474 Y96.969 E.0126
G1 X91.798 Y97.01 E.00794
G1 X93.509 Y97.011 E.04162
G1 X93.509 Y97.011 F9000
G1 X93.203 Y97.376
G1 F6000
G1 X93.203 Y101.731 E.10593
G1 X92 Y101.73 E.02926
G1 X91.415 Y101.789 E.0143
G1 X90.804 Y102.074 E.0164
G1 X90.8 Y97.062 E.12191
G1 X91.415 Y97.33 E.01632
G1 X91.798 Y97.376 E.00938
G1 X93.143 Y97.376 E.03272
G1 X93.143 Y97.376 F9000
G1 X92.837 Y97.742
G1 F6000
G1 X92.837 Y101.365 E.08813
G1 X91.8 Y101.364 E.02522
G1 X91.166 Y101.483 E.01569
G1 X91.165 Y97.621 E.09394
G1 X91.355 Y97.691 E.00493
G1 X91.798 Y97.742 E.01085
G1 X92.777 Y97.742 E.02381
G1 E-5 F3600
G1 X92.777 Y97.742 F9000
G1 X90.468 Y104.792
G1 E5 F2400
;WIDTH:0.465802
G1 F6000
G1 X90.446 Y104.455 E.00969
;WIDTH:0.421117
G1 X90.423 Y104.118 E.00869
;WIDTH:0.418159
G1 X90.444 Y103.683 E.01112
;WIDTH:0.459886
G1 X90.465 Y103.248 E.01233
G1 E-5 F3600
G1 X90.465 Y103.248 F9000
G1 X90.854 Y103.356
G1 X90.845 Y103.388
G1 X90.826 Y103.483
G1 X90.807 Y103.626
G1 X90.791 Y103.815
G1 X90.786 Y104
G1 X90.791 Y104.185
G1 X90.807 Y104.374
G1 X90.826 Y104.517
G1 X90.845 Y104.612
G1 X90.896 Y104.797
G1 X90.934 Y104.893
G1 X91.007 Y105.039
G1 X91.136 Y105.219
G1 X91.216 Y105.294
G1 X91.344 Y105.393
G1 X91.545 Y105.483
G1 X91.705 Y105.515
G1 X91.772 Y105.522
G1 X92.141 Y105.523
G1 X93.951 Y105.52
G1 X93.951 Y107.697
G1 X93.569 Y107.697
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.569 Y110.097 E.05838
G1 X92 Y110.096 E.03816
G1 X91.524 Y110.137 E.01162
G1 X91.039 Y110.36 E.01298
G1 X90.743 Y110.68 E.0106
;WIDTH:0.429341
G1 X90.604 Y110.964 E.00831
;WIDTH:0.458682
G1 X90.465 Y111.248 E.00893
G1 X90.451 Y110.923 E.00918
;WIDTH:0.429341
G1 X90.436 Y110.598 E.00855
;WIDTH:0.399999
G1 X90.435 Y105.402 E.12639
;WIDTH:0.432901
G1 X90.452 Y105.097 E.0081
;WIDTH:0.465802
G1 X90.468 Y104.792 E.00877
G1 X90.606 Y105.056 E.00855
;WIDTH:0.432901
G1 X90.743 Y105.32 E.00789
;WIDTH:0.399999
G1 X91.049 Y105.64 E.01077
G1 X91.543 Y105.873 E.01329
G1 X91.8 Y105.905 E.0063
G1 X93.569 Y105.903 E.04303
G1 X93.569 Y107.637 E.04218
G1 X93.569 Y107.637 F9000
G1 X93.203 Y107.879
G1 F6000
G1 X93.203 Y109.731 E.04505
G1 X91.8 Y109.73 E.03413
G1 X91.236 Y109.845 E.014
G1 X90.805 Y110.075 E.01188
G1 X90.801 Y105.893 E.10172
G1 X91.026 Y106.057 E.00677
G1 X91.476 Y106.233 E.01175
G1 X91.8 Y106.27 E.00793
G1 X93.203 Y106.269 E.03413
G1 X93.203 Y107.819 E.0377
G1 X93.203 Y107.819 F9000
G1 X92.837 Y108.062
G1 F6000
G1 X92.837 Y109.365 E.03169
G1 X91.8 Y109.364 E.02522
G1 X91.167 Y109.483 E.01567
G1 X91.167 Y106.497 E.07263
G1 X91.41 Y106.592 E.00635
G1 X91.8 Y106.636 E.00955
G1 X92.837 Y106.635 E.02522
G1 X92.837 Y108.002 E.03325
G1 X92.837 Y108.002 F9000
G1 X92.728 Y107.59
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X92.047 Y106.91 E.02341
G1 X91.441 Y106.871 E.01477
G1 X92.563 Y108.014 E.03896
G1 X92.563 Y108.602 E.0143
G1 X91.441 Y107.48 E.0386
G1 X91.441 Y108.069 E.01433
G1 X92.463 Y109.091 E.03516
G1 X91.874 Y109.09 E.01433
G1 X91.277 Y108.492 E.02055
G1 E-5 F3600
G1 X91.277 Y108.492 F9000
G1 X90.826 Y111.483
G1 X90.807 Y111.626
G1 X90.791 Y111.815
G1 X90.786 Y112
G1 X90.791 Y112.185
G1 X90.807 Y112.374
G1 X90.826 Y112.517
G1 X90.845 Y112.612
G1 X90.896 Y112.797
G1 X90.934 Y112.893
G1 X91.007 Y113.039
G1 X92.728 Y115.59
G1 E5 F2400
G1 F3072.127
G1 X92.048 Y114.91 E.02339
G1 X91.442 Y114.871 E.01477
G1 X92.563 Y116.014 E.03894
G1 X92.563 Y116.602 E.0143
G1 X91.442 Y115.481 E.03856
G1 X91.442 Y116.069 E.0143
G1 X92.464 Y117.091 E.03516
G1 X91.875 Y117.09 E.01433
G1 X91.278 Y116.492 E.02055
G1 E-5 F3600
G1 X91.278 Y116.492 F9000
G1 X90.826 Y119.483
G1 X90.807 Y119.626
G1 X90.791 Y119.815
G1 X90.786 Y120
G1 X90.791 Y120.185
G1 X90.807 Y120.374
G1 X90.826 Y120.517
G1 X90.845 Y120.612
G1 X90.896 Y120.797
G1 X90.934 Y120.893
G1 X91.007 Y121.039
G1 X92.728 Y123.59
G1 E5 F2400
G1 F3072.127
G1 X92.048 Y122.91 E.02339
G1 X91.443 Y122.871 E.01475
G1 X92.563 Y124.013 E.03891
G1 X92.563 Y124.601 E.0143
G1 X91.443 Y123.481 E.03853
G1 X91.443 Y124.069 E.0143
G1 X92.465 Y125.091 E.03516
G1 X91.876 Y125.09 E.01433
G1 X91.279 Y124.493 E.02054
G1 E-5 F3600
G1 X91.279 Y124.493 F9000
G1 X90.826 Y127.483
G1 X90.807 Y127.626
G1 X90.791 Y127.815
G1 X90.786 Y128
G1 X90.791 Y128.185
G1 X90.807 Y128.374
G1 X90.826 Y128.517
G1 X90.845 Y128.612
G1 X90.896 Y128.797
G1 X90.934 Y128.893
G1 X91.007 Y129.039
G1 X92.732 Y131.491
G1 E5 F2400
G1 F3072.127
G1 X92.152 Y130.91 E.01997
G1 X91.614 Y130.89 E.0131
G1 X92.57 Y131.846 E.03289
G1 X92.574 Y132.367 E.01267
G1 X91.445 Y131.238 E.03884
G1 X91.445 Y131.756 E.0126
G1 X92.577 Y132.888 E.03894
G1 X92.579 Y133.09 E.00491
G1 X92.261 Y133.09 E.00774
G1 X91.445 Y132.273 E.02809
G1 X91.445 Y132.791 E.0126
G1 X91.908 Y133.254 E.01593
G1 E-5 F3600
G1 X91.908 Y133.254 F9000
G1 X91.007 Y134.961
G1 X90.934 Y135.107
G1 X90.896 Y135.203
G1 X90.845 Y135.388
G1 X90.826 Y135.483
G1 X90.807 Y135.626
G1 X90.791 Y135.815
G1 X90.786 Y136
G1 X90.791 Y136.185
G1 X90.807 Y136.374
G1 X91.281 Y140.616
G1 E5 F2400
G1 F3072.127
G1 X91.76 Y141.094 E.01646
G1 X92.291 Y141.091 E.01292
G1 X91.446 Y140.246 E.02907
G1 X91.446 Y139.712 E.01299
G1 X92.825 Y141.091 E.04744
G1 X93.359 Y141.091 E.01299
G1 X91.446 Y139.177 E.06582
G1 X91.446 Y138.855 E.00783
G1 X91.699 Y138.896 E.00623
G1 X93.893 Y141.091 E.07549
G1 X94.427 Y141.09 E.01299
G1 X92.246 Y138.909 E.07503
G1 X92.78 Y138.909 E.01299
G1 X94.961 Y141.09 E.07503
G1 X95.495 Y141.09 E.01299
G1 X93.315 Y138.909 E.07501
G1 X93.849 Y138.91 E.01299
G1 X96.194 Y141.255 E.08067
G1 E-5 F3600
G1 X96.194 Y141.255 F9000
G1 X91.545 Y142.517
G1 X91.344 Y142.607
G1 X91.216 Y142.707
G1 X91.136 Y142.781
G1 X91.007 Y142.961
G1 X90.934 Y143.107
G1 X90.896 Y143.203
G1 X90.845 Y143.388
G1 X90.826 Y143.483
G1 X90.807 Y143.626
G1 X90.791 Y143.815
G1 X90.786 Y144
G1 X90.791 Y144.185
G1 X90.807 Y144.374
G1 X90.826 Y144.517
G1 X90.845 Y144.612
G1 X90.896 Y144.797
G1 X91.484 Y146.886
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.445244
G1 F1200
G1 X91.805 Y146.929 E.00885
;WIDTH:0.439558
G1 X105.326 Y146.93 E.36446
;WIDTH:0.461612
G1 X105.882 Y146.855 E.01595
G1 X106.244 Y146.706 E.01113
;WIDTH:0.4576
G1 X106.661 Y146.378 E.01494
;WIDTH:0.40811
G1 X106.981 Y145.899 E.01432
G1 E-5 F3600
G1 X106.981 Y145.899 F9000
G1 X111.828 Y144.025
G1 E5 F2400
;WIDTH:0.423234
G1 F1200
G1 X119.172 Y144.025 E.18999
G1 E-5 F3600
G1 X119.172 Y144.025 F9000
G1 X122.266 Y144.37
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X123.659 Y145.763 E.04792
G1 X123.876 Y145.654 E.00591
G1 X123.798 Y145.381 E.00691
G1 X122.952 Y144.536 E.02908
G1 X123.473 Y144.536 E.01267
G1 X123.913 Y144.976 E.01514
G1 X123.913 Y144.976 F9000
G1 X124.143 Y146.123
;TYPE:Solid infill
;WIDTH:0.419842
G1 F1200
G1 X124.336 Y146.384 E.00832
;WIDTH:0.45808
G1 X124.746 Y146.699 E.01457
G1 X125.221 Y146.878 E.01431
;WIDTH:0.441384
G1 X125.674 Y146.93 E.01235
;WIDTH:0.43857
G1 X139.176 Y146.929 E.36307
;WIDTH:0.438354
G1 X139.537 Y146.874 E.00981
G1 X139.537 Y146.874 F9000
G1 X139.727 Y147.783
;WIDTH:0.4
G1 F3072.127
G1 X139.252 Y147.308 E.01634
G1 X138.738 Y147.314 E.0125
G1 X139.563 Y148.139 E.02838
G1 X139.563 Y148.659 E.01265
G1 X138.218 Y147.314 E.04627
G1 X137.698 Y147.314 E.01265
G1 X139.072 Y148.689 E.04728
G1 X138.552 Y148.689 E.01265
G1 X137.177 Y147.315 E.04728
G1 X136.657 Y147.315 E.01265
G1 X138.032 Y148.689 E.04728
G1 X137.511 Y148.689 E.01267
G1 X136.137 Y147.315 E.04726
G1 X135.617 Y147.315 E.01265
G1 X136.991 Y148.689 E.04726
G1 X136.47 Y148.688 E.01267
G1 X135.097 Y147.315 E.04723
G1 X134.576 Y147.315 E.01267
G1 X135.95 Y148.688 E.04725
G1 X135.429 Y148.688 E.01267
G1 X134.056 Y147.315 E.04723
G1 X133.536 Y147.315 E.01265
G1 X134.909 Y148.688 E.04723
G1 X134.388 Y148.688 E.01267
G1 X133.016 Y147.315 E.04721
G1 X132.495 Y147.315 E.01267
G1 X133.868 Y148.687 E.04721
G1 X133.347 Y148.687 E.01267
G1 X131.975 Y147.315 E.0472
G1 X131.455 Y147.315 E.01265
G1 X132.827 Y148.687 E.0472
G1 X132.306 Y148.687 E.01267
G1 X130.935 Y147.315 E.04718
G1 X130.414 Y147.315 E.01267
G1 X131.786 Y148.687 E.0472
G1 X131.265 Y148.686 E.01267
G1 X129.894 Y147.315 E.04716
G1 X129.374 Y147.315 E.01265
G1 X130.745 Y148.686 E.04716
G1 X130.224 Y148.686 E.01267
G1 X128.854 Y147.315 E.04714
G1 X128.334 Y147.315 E.01265
G1 X129.704 Y148.686 E.04714
G1 X129.183 Y148.686 E.01267
G1 X127.813 Y147.316 E.04713
G1 X127.293 Y147.316 E.01265
G1 X128.663 Y148.685 E.04711
G1 X128.142 Y148.685 E.01267
G1 X126.773 Y147.316 E.04709
G1 X126.253 Y147.316 E.01265
G1 X127.622 Y148.685 E.04709
G1 X127.101 Y148.685 E.01267
G1 X125.732 Y147.316 E.04709
G1 X125.157 Y147.261 E.01405
G1 X126.581 Y148.685 E.04898
G1 X126.061 Y148.684 E.01265
G1 X121.91 Y144.534 E.14277
G1 X121.389 Y144.533 E.01267
G1 X125.541 Y148.685 E.14283
G1 X125.085 Y148.749 E.0112
G1 X120.867 Y144.532 E.14508
G1 X120.346 Y144.531 E.01267
G1 X124.703 Y148.888 E.14988
G1 X124.375 Y149.08 E.00924
G1 X119.618 Y144.323 E.16364
G1 X119.554 Y144.403 E.00249
G1 X119.177 Y144.403 E.00917
G1 X124.096 Y149.321 E.16919
G1 X123.87 Y149.615 E.00902
G1 X118.657 Y144.403 E.17931
G1 X118.137 Y144.403 E.01265
G1 X123.696 Y149.961 E.19121
G1 X123.571 Y150.274 E.0082
G1 X123.852 Y150.419 E.00769
G1 X123.798 Y150.585 E.00425
G1 X117.616 Y144.403 E.21266
G1 X117.096 Y144.403 E.01265
G1 X123.749 Y151.055 E.22884
G1 X123.749 Y151.575 E.01265
G1 X116.576 Y144.403 E.24673
G1 X116.055 Y144.403 E.01267
G1 X123.749 Y152.096 E.26465
G1 X123.749 Y152.616 E.01265
G1 X115.535 Y144.403 E.28254
G1 X115.015 Y144.403 E.01265
G1 X123.952 Y153.34 E.30743
G1 E-5 F3600
G1 X123.952 Y153.34 F9000
G1 X125.236 Y155.144
G1 E5 F2400
G1 F3072.127
G1 X114.495 Y144.403 E.36948
G1 X113.974 Y144.403 E.01267
G1 X124.624 Y155.052 E.36634
G1 X124.103 Y155.052 E.01267
G1 X113.454 Y144.403 E.36632
G1 X112.934 Y144.403 E.01265
G1 X123.583 Y155.052 E.36632
G1 X123.063 Y155.052 E.01265
G1 X112.413 Y144.403 E.36634
G1 X111.893 Y144.403 E.01265
G1 X122.542 Y155.052 E.36632
G1 X122.022 Y155.051 E.01265
G1 X111.325 Y144.354 E.36797
G1 X110.94 Y144.49 E.00993
G1 X121.501 Y155.051 E.36329
G1 X120.981 Y155.051 E.01265
G1 X110.461 Y144.531 E.36188
G1 X109.943 Y144.533 E.0126
G1 X120.461 Y155.051 E.36181
G1 X119.94 Y155.051 E.01267
G1 X109.424 Y144.535 E.36174
G1 X108.906 Y144.537 E.0126
G1 X119.42 Y155.051 E.36168
G1 X118.9 Y155.051 E.01265
G1 X108.387 Y144.538 E.36164
G1 X107.868 Y144.54 E.01262
G1 X118.379 Y155.051 E.36157
G1 X117.859 Y155.051 E.01265
G1 X107.35 Y144.542 E.3615
G1 X107.254 Y144.542 E.00234
G1 X107.251 Y144.964 E.01027
G1 X117.338 Y155.051 E.34699
G1 X116.818 Y155.051 E.01265
G1 X107.196 Y145.428 E.33101
G1 X107.145 Y145.599 E.00434
G1 X107.427 Y145.749 E.00777
G1 X107.295 Y146.048 E.00795
G1 X116.298 Y155.05 E.30968
G1 X115.777 Y155.05 E.01267
G1 X107.125 Y146.398 E.29762
G1 X106.895 Y146.688 E.009
G1 X115.257 Y155.05 E.28765
G1 X114.737 Y155.05 E.01265
G1 X106.615 Y146.928 E.27939
G1 X106.284 Y147.118 E.00928
G1 X114.216 Y155.05 E.27286
G1 X113.696 Y155.05 E.01265
G1 X105.899 Y147.253 E.26821
G1 X105.441 Y147.316 E.01125
G1 X113.175 Y155.05 E.26604
G1 X112.655 Y155.05 E.01265
G1 X104.921 Y147.316 E.26604
G1 X104.401 Y147.316 E.01265
G1 X105.821 Y148.736 E.04885
G1 X105.249 Y148.684 E.01397
G1 X103.88 Y147.316 E.04708
G1 X103.36 Y147.316 E.01265
G1 X104.729 Y148.685 E.04709
G1 X104.209 Y148.685 E.01265
G1 X102.84 Y147.315 E.04711
G1 X102.319 Y147.315 E.01267
G1 X103.689 Y148.686 E.04714
G1 X103.169 Y148.686 E.01265
G1 X101.799 Y147.315 E.04714
G1 X101.279 Y147.315 E.01265
G1 X102.65 Y148.686 E.04716
G1 X102.13 Y148.687 E.01265
G1 X100.758 Y147.315 E.0472
G1 X100.238 Y147.315 E.01265
G1 X101.61 Y148.687 E.0472
G1 X101.09 Y148.688 E.01265
G1 X99.718 Y147.315 E.04721
G1 X99.197 Y147.315 E.01267
G1 X100.57 Y148.688 E.04723
G1 X100.05 Y148.688 E.01265
G1 X98.677 Y147.315 E.04723
G1 X98.157 Y147.315 E.01265
G1 X99.53 Y148.689 E.04725
G1 X99.01 Y148.689 E.01265
G1 X97.636 Y147.315 E.04726
G1 X97.116 Y147.315 E.01265
G1 X98.49 Y148.689 E.04726
G1 X97.971 Y148.69 E.01262
G1 X96.596 Y147.315 E.0473
G1 X96.075 Y147.315 E.01267
G1 X97.451 Y148.69 E.04732
G1 X96.931 Y148.691 E.01265
G1 X95.555 Y147.315 E.04733
G1 X95.034 Y147.315 E.01267
G1 X96.411 Y148.691 E.04735
G1 X95.891 Y148.691 E.01265
G1 X94.514 Y147.315 E.04735
G1 X93.994 Y147.315 E.01265
G1 X95.371 Y148.692 E.04737
G1 X94.851 Y148.692 E.01265
G1 X93.473 Y147.315 E.04739
G1 X92.953 Y147.314 E.01265
G1 X94.331 Y148.693 E.04742
G1 X93.811 Y148.693 E.01265
G1 X92.433 Y147.314 E.04742
G1 X91.912 Y147.314 E.01267
G1 X93.291 Y148.693 E.04744
G1 X92.772 Y148.694 E.01262
G1 X91.447 Y147.369 E.04558
G1 X91.447 Y147.89 E.01267
G1 X92.252 Y148.694 E.02767
G1 X91.732 Y148.695 E.01265
G1 X91.283 Y148.245 E.01546
G1 X91.283 Y148.245 F9000
G1 X91.463 Y149.151
;TYPE:Solid infill
;WIDTH:0.430928
G1 F1200
G1 X91.794 Y149.076 E.00895
;WIDTH:0.438488
G1 X105.326 Y149.07 E.3638
;WIDTH:0.46342
G1 X105.905 Y149.152 E.01669
G1 X106.255 Y149.3 E.01085
;WIDTH:0.455112
G1 X106.666 Y149.626 E.01468
;WIDTH:0.431824
G1 X106.926 Y149.984 E.0117
;WIDTH:0.389538
G1 X106.987 Y150.11 E.00331
G1 E-5 F3600
G1 X106.987 Y150.11 F9000
G1 X106.575 Y155.213
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X106.104 Y154.742 E.0162
G1 X106.419 Y154.537 E.00914
G1 X106.931 Y155.049 E.01761
G1 X107.451 Y155.049 E.01265
G1 X106.712 Y154.309 E.02544
G1 X106.936 Y154.014 E.00901
G1 X107.972 Y155.049 E.03562
G1 X108.492 Y155.049 E.01265
G1 X107.111 Y153.668 E.04751
G1 X107.222 Y153.259 E.01031
G1 X109.012 Y155.049 E.06157
G1 X109.533 Y155.049 E.01267
G1 X107.251 Y152.768 E.07848
G1 X107.251 Y152.248 E.01265
G1 X110.053 Y155.049 E.09637
G1 X110.574 Y155.049 E.01267
G1 X107.251 Y151.727 E.11429
G1 X107.251 Y151.207 E.01265
G1 X111.094 Y155.05 E.1322
G1 X111.614 Y155.05 E.01265
G1 X107.213 Y150.648 E.15141
G1 X107.149 Y150.42 E.00576
G1 X107.384 Y150.299 E.00643
G1 X112.299 Y155.214 E.16907
G1 E-5 F3600
G1 X112.299 Y155.214 F9000
G1 X124.218 Y149.764
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.457778
G1 F1200
G1 X124.499 Y149.477 E.01131
G1 X124.827 Y149.259 E.01109
;WIDTH:0.447364
G1 X125.226 Y149.121 E.0116
;WIDTH:0.443558
G1 X125.674 Y149.07 E.01227
;WIDTH:0.439532
G1 X139.192 Y149.073 E.36436
;WIDTH:0.444538
G1 X139.541 Y149.135 E.00967
G1 E-5 F3600
G1 X139.541 Y149.135 F9000
G1 X140.214 Y144
G1 X140.155 Y143.388
G1 X140.104 Y143.203
G1 X140.066 Y143.107
G1 X139.993 Y142.961
G1 X139.864 Y142.781
G1 X139.784 Y142.706
G1 X139.656 Y142.607
G1 X139.455 Y142.517
G1 X134.841 Y140.888
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X135.043 Y141.09 E.00695
G1 X135.576 Y141.09 E.01296
G1 X135.226 Y140.74 E.01204
G1 X135.477 Y140.459 E.00916
G1 X136.109 Y141.09 E.02172
G1 X136.642 Y141.09 E.01296
G1 X135.724 Y140.172 E.03158
G1 X135.951 Y139.867 E.00925
G1 X137.174 Y141.091 E.04209
G1 X137.707 Y141.091 E.01296
G1 X136.179 Y139.562 E.05258
G1 X136.406 Y139.257 E.00925
G1 X138.24 Y141.091 E.06309
G1 X138.773 Y141.091 E.01296
G1 X136.607 Y138.925 E.07451
G1 X137.124 Y138.909 E.01258
G1 X139.322 Y141.107 E.07561
G1 X139.562 Y141.146 E.00591
G1 X139.562 Y140.814 E.00808
G1 X137.657 Y138.909 E.06553
G1 X138.189 Y138.909 E.01294
G1 X139.561 Y140.281 E.0472
G1 X139.561 Y139.748 E.01296
G1 X138.722 Y138.909 E.02886
G1 X139.249 Y138.904 E.01282
G1 X139.726 Y139.38 E.01639
G1 E-5 F3600
G1 X139.726 Y139.38 F9000
G1 X140.174 Y136.517
G1 X140.193 Y136.374
G1 X140.209 Y136.185
G1 X140.214 Y136
G1 X140.209 Y135.815
G1 X140.193 Y135.626
G1 X140.174 Y135.483
G1 X140.155 Y135.388
G1 X140.104 Y135.203
G1 X140.066 Y135.107
G1 X139.993 Y134.961
G1 X139 Y133.254
G1 E5 F2400
G1 F3072.127
G1 X138.424 Y132.679 E.0198
G1 X138.428 Y132.162 E.01258
G1 X139.393 Y133.127 E.0332
G1 X139.56 Y133.161 E.00415
G1 X139.56 Y132.774 E.00941
G1 X138.431 Y131.645 E.03884
G1 X138.435 Y131.128 E.01258
G1 X139.56 Y132.253 E.0387
G1 X139.56 Y131.733 E.01265
G1 X138.737 Y130.91 E.02831
G1 X139.25 Y130.902 E.01248
G1 X139.725 Y131.377 E.01634
G1 E-5 F3600
G1 X139.725 Y131.377 F9000
G1 X140.174 Y128.517
G1 X140.214 Y128
G1 X138.272 Y124.41
G1 E5 F2400
G1 F3072.127
G1 X138.953 Y125.09 E.02341
G1 X139.559 Y125.135 E.01478
G1 X138.437 Y123.986 E.03906
G1 X138.437 Y123.398 E.0143
G1 X139.559 Y124.52 E.0386
G1 X139.559 Y123.932 E.0143
G1 X138.537 Y122.909 E.03517
G1 X139.126 Y122.91 E.01433
G1 X139.723 Y123.508 E.02055
G1 E-5 F3600
G1 X139.723 Y123.508 F9000
G1 X140.214 Y120
G1 X138.272 Y116.41
G1 E5 F2400
G1 F3072.127
G1 X138.952 Y117.09 E.02339
G1 X139.558 Y117.134 E.01478
G1 X138.437 Y115.986 E.03903
G1 X138.437 Y115.398 E.0143
G1 X139.558 Y116.519 E.03856
G1 X139.558 Y115.931 E.0143
G1 X138.536 Y114.909 E.03516
G1 X139.125 Y114.91 E.01433
G1 X139.722 Y115.508 E.02055
G1 E-5 F3600
G1 X139.722 Y115.508 F9000
G1 X140.174 Y112.517
G1 X140.193 Y112.374
G1 X140.209 Y112.185
G1 X140.214 Y112
G1 X140.209 Y111.815
G1 X140.193 Y111.626
G1 X140.174 Y111.483
G1 X140.155 Y111.388
G1 X140.104 Y111.203
G1 X140.066 Y111.107
G1 X139.877 Y110.73
G1 X138.272 Y108.41
G1 E5 F2400
G1 F3072.127
G1 X138.952 Y109.09 E.02339
G1 X139.557 Y109.134 E.01475
G1 X138.437 Y107.987 E.03899
G1 X138.437 Y107.399 E.0143
G1 X139.557 Y108.519 E.03853
G1 X139.557 Y107.931 E.0143
G1 X138.535 Y106.909 E.03516
G1 X139.124 Y106.91 E.01433
G1 X139.721 Y107.508 E.02055
G1 E-5 F3600
G1 X139.721 Y107.508 F9000
G1 X140.214 Y104
G1 X138.272 Y100.461
G1 E5 F2400
G1 F3072.127
G1 X138.901 Y101.09 E.02164
G1 X139.49 Y101.125 E.01435
G1 X138.437 Y100.072 E.03622
G1 X138.437 Y99.519 E.01345
G1 X139.555 Y100.637 E.03846
G1 X139.555 Y100.083 E.01348
G1 X138.437 Y98.965 E.03846
G1 X138.437 Y98.411 E.01348
G1 X139.555 Y99.529 E.03846
G1 X139.555 Y98.976 E.01345
G1 X138.595 Y98.016 E.03302
G1 X139.149 Y98.016 E.01348
G1 X139.72 Y98.586 E.01962
G1 E-5 F3600
G1 X139.72 Y98.586 F9000
G1 X140.235 Y95.749
G1 X140.244 Y95.652
G1 X140.249 Y95.587
G1 X140.249 Y93.241
G1 X140.244 Y93.176
G1 X140.235 Y93.08
G1 X140.19 Y92.903
G1 X140.114 Y92.736
G1 X140.011 Y92.583
G1 X139.882 Y92.451
G1 X139.732 Y92.342
G1 X139.564 Y92.261
G1 X139.375 Y92.21
G1 X129.601 Y90.977
G1 E5 F2400
G1 F3072.127
G1 X129.046 Y90.422 E.01909
G1 X128.922 Y89.772 E.0161
G1 X129.962 Y90.812 E.03578
G1 X130.488 Y90.812 E.01279
G1 X127.598 Y87.923 E.0994
G1 X128.05 Y87.849 E.01114
G1 X131.014 Y90.812 E.10194
G1 X131.539 Y90.812 E.01277
G1 X128.457 Y87.73 E.10602
G1 X128.853 Y87.6 E.01014
G1 X132.065 Y90.812 E.11049
G1 X132.591 Y90.812 E.01279
G1 X129.236 Y87.457 E.11541
G1 X129.584 Y87.279 E.00951
G1 X133.117 Y90.812 E.12153
G1 X133.642 Y90.812 E.01277
G1 X129.924 Y87.094 E.1279
G1 X130.235 Y86.88 E.00918
G1 X134.168 Y90.812 E.13528
G1 X134.694 Y90.812 E.01279
G1 X130.536 Y86.654 E.14303
G1 X130.81 Y86.402 E.00905
G1 X135.22 Y90.812 E.1517
G1 X135.746 Y90.812 E.01279
G1 X131.074 Y86.141 E.1607
G1 X131.332 Y85.873 E.00905
G1 X136.271 Y90.812 E.1699
G1 X136.797 Y90.812 E.01279
G1 X131.563 Y85.579 E.18003
G1 X131.78 Y85.269 E.0092
G1 X137.323 Y90.813 E.19069
G1 X137.849 Y90.813 E.01279
G1 X131.976 Y84.94 E.20203
G1 X132.14 Y84.578 E.00967
G1 X138.374 Y90.813 E.21446
G1 X138.9 Y90.813 E.01279
G1 X132.303 Y84.215 E.22695
G1 X132.451 Y83.838 E.00985
G1 X139.459 Y90.845 E.24105
G1 X139.554 Y90.858 E.00233
G1 X139.554 Y90.415 E.01078
G1 X132.548 Y83.408 E.24102
G1 X132.644 Y82.979 E.01069
G1 X139.554 Y89.889 E.2377
G1 X139.554 Y89.363 E.01279
G1 X132.705 Y82.514 E.2356
G1 X132.737 Y82.02 E.01204
G1 X139.554 Y88.837 E.2345
G1 X139.553 Y88.311 E.01279
G1 X132.737 Y81.495 E.23447
G1 X132.737 Y80.969 E.01279
G1 X139.553 Y87.785 E.23447
G1 X139.553 Y87.26 E.01277
G1 X132.737 Y80.443 E.23448
G1 X132.737 Y79.917 E.01279
G1 X139.553 Y86.734 E.23448
G1 X139.553 Y86.208 E.01279
G1 X132.938 Y79.592 E.22757
G1 X133.206 Y79.335 E.00903
G1 X139.553 Y85.682 E.21833
G1 X139.553 Y85.156 E.01279
G1 X133.447 Y79.051 E.21003
G1 X133.671 Y78.749 E.00915
G1 X139.553 Y84.63 E.20232
G1 X139.553 Y84.105 E.01277
G1 X133.864 Y78.415 E.19572
G1 X133.993 Y78.019 E.01013
G1 X139.553 Y83.579 E.19126
G1 X139.553 Y83.053 E.01279
G1 X134.061 Y77.561 E.18892
G1 X133.97 Y76.944 E.01517
G1 X139.553 Y82.527 E.19205
G1 X139.553 Y82.001 E.01279
G1 X133.497 Y75.946 E.20831
G1 X134.024 Y75.947 E.01282
G1 X139.552 Y81.475 E.19016
G1 X139.552 Y80.95 E.01277
G1 X134.551 Y75.948 E.17205
G1 X135.077 Y75.949 E.01279
G1 X139.552 Y80.424 E.15394
G1 X139.552 Y79.898 E.01279
G1 X135.604 Y75.95 E.13581
G1 X136.186 Y76.006 E.01422
G1 X139.494 Y79.314 E.11379
G1 X139.28 Y78.575 E.01871
G1 X136.926 Y76.22 E.08099
G1 X137.804 Y76.663 E.02392
G1 X138.348 Y77.116 E.01722
G1 X139.153 Y77.922 E.02771
G1 E-5 F3600
G1 X139.153 Y77.922 F9000
G1 X129.639 Y85.604
G1 X129.504 Y85.704
G1 X129.378 Y85.797
G1 X129.234 Y85.89
G1 X129.101 Y85.973
G1 X128.951 Y86.056
G1 X128.811 Y86.13
G1 X128.663 Y86.198
G1 X128.519 Y86.261
G1 X128.367 Y86.319
G1 X128.219 Y86.371
G1 X128.063 Y86.419
G1 X127.912 Y86.46
G1 X127.752 Y86.498
G1 X127.599 Y86.527
G1 X127.437 Y86.554
G1 X127.282 Y86.571
G1 X127.119 Y86.588
G1 X102.723 Y87.625
G1 E5 F2400
G1 F3072.127
G1 X103.294 Y88.196 E.01964
G1 X103.027 Y88.452 E.009
G1 X102.188 Y87.613 E.02886
G1 X101.728 Y87.442 E.01194
G1 X101.206 Y87.153 E.01451
G1 X102.76 Y88.708 E.05347
G1 X102.523 Y88.993 E.00902
G1 X91.824 Y78.294 E.36804
G1 X92.004 Y77.951 E.00942
G1 X99.098 Y85.046 E.24405
G1 X98.625 Y84.05 E.02682
G1 X92.207 Y77.632 E.22078
G1 X92.437 Y77.339 E.00906
G1 X98.421 Y83.323 E.20585
G1 X98.306 Y82.685 E.01577
G1 X92.695 Y77.074 E.19302
G1 X92.974 Y76.831 E.009
G1 X98.273 Y82.13 E.18228
G1 X98.271 Y81.605 E.01277
G1 X93.276 Y76.61 E.17183
G1 X93.601 Y76.413 E.00924
G1 X98.27 Y81.081 E.16059
G1 X98.268 Y80.557 E.01275
G1 X93.965 Y76.253 E.14804
G1 X94.348 Y76.113 E.00992
G1 X98.266 Y80.032 E.13479
G1 X98.266 Y79.782 E.00608
G1 X97.466 Y78.96 E.0279
G1 X97.129 Y78.372 E.01649
G1 X94.781 Y76.024 E.08077
G1 X95.235 Y75.955 E.01117
G1 X96.948 Y77.669 E.05894
G1 X96.977 Y77.175 E.01204
G1 X95.75 Y75.948 E.04221
G1 X96.273 Y75.948 E.01272
G1 X97.097 Y76.772 E.02835
G1 X97.259 Y76.412 E.0096
G1 X96.796 Y75.948 E.01594
G1 X97.318 Y75.948 E.0127
G1 X97.57 Y76.2 E.00867
G1 E-5 F3600
G1 X97.57 Y76.2 F9000
G1 X102.418 Y89.411
G1 E5 F2400
G1 F3072.127
G1 X91.672 Y78.665 E.36966
G1 X91.551 Y79.067 E.01021
G1 X102.113 Y89.629 E.36333
G1 X101.998 Y90.036 E.01029
G1 X91.47 Y79.509 E.36214
G1 X91.44 Y80.002 E.01201
G1 X102.003 Y90.564 E.36334
G1 X102.02 Y90.812 E.00605
G1 X101.728 Y90.812 E.0071
G1 X91.437 Y80.521 E.354
G1 X91.437 Y81.044 E.01272
G1 X101.205 Y90.812 E.33601
G1 X100.683 Y90.812 E.0127
G1 X91.437 Y81.567 E.31804
G1 X91.437 Y82.089 E.0127
G1 X100.16 Y90.812 E.30007
G1 X99.637 Y90.812 E.01272
G1 X91.437 Y82.612 E.28208
G1 X91.437 Y83.135 E.01272
G1 X99.115 Y90.812 E.2641
G1 X98.592 Y90.812 E.01272
G1 X91.437 Y83.658 E.24611
G1 X91.438 Y84.181 E.01272
G1 X98.069 Y90.812 E.2281
G1 X97.546 Y90.812 E.01272
G1 X91.438 Y84.703 E.21013
G1 X91.438 Y85.226 E.01272
G1 X97.024 Y90.812 E.19216
G1 X96.501 Y90.812 E.01272
G1 X91.438 Y85.749 E.17416
G1 X91.438 Y86.272 E.01272
G1 X95.978 Y90.812 E.15617
G1 X95.456 Y90.812 E.0127
G1 X91.438 Y86.795 E.1382
G1 X91.438 Y87.318 E.01272
G1 X94.933 Y90.812 E.12021
G1 X94.41 Y90.812 E.01272
G1 X91.438 Y87.84 E.10224
G1 X91.438 Y88.363 E.01272
G1 X93.887 Y90.813 E.08426
G1 X93.365 Y90.813 E.0127
G1 X91.438 Y88.886 E.06629
G1 X91.438 Y89.409 E.01272
G1 X92.842 Y90.813 E.0483
G1 X92.319 Y90.813 E.01272
G1 X91.438 Y89.932 E.03031
G1 X91.438 Y90.454 E.0127
G1 X91.961 Y90.977 E.01799
G1 E-5 F3600
G1 X91.961 Y90.977 F9000
G1 X90.886 Y92.736
G1 X90.811 Y92.903
G1 X90.765 Y93.08
G1 X90.757 Y93.176
G1 X90.751 Y93.241
G1 X90.751 Y95.587
G1 X90.757 Y95.652
G1 X90.765 Y95.749
G1 X90.811 Y95.926
G1 X90.886 Y96.093
G1 X90.99 Y96.245
G1 X92.728 Y98.65
G1 E5 F2400
G1 F3072.127
G1 X92.093 Y98.016 E.02183
G1 X91.513 Y97.993 E.01412
G1 X92.563 Y99.043 E.03612
G1 X92.563 Y99.6 E.01355
G1 X91.44 Y98.476 E.03865
G1 X91.44 Y99.033 E.01355
G1 X92.563 Y100.157 E.03865
G1 X92.563 Y100.713 E.01352
G1 X91.44 Y99.59 E.03863
G1 X91.44 Y100.147 E.01355
G1 X92.383 Y101.09 E.03244
G1 X91.826 Y101.09 E.01355
G1 X91.275 Y100.54 E.01894
;LAYER_CHANGE
;Z:1.42
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;1.42
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X91.826 Y101.09 E-.3698
G1 X92.383 Y101.09 E-.26457
G1 X91.44 Y100.147 E-.63346
G1 X91.44 Y99.658 E-.23217
;WIPE_END
G1 Z1.42 F9000
;AFTER_LAYER_CHANGE
;1.42
G1 Z1.42
G1 X91.861 Y96.652
G1 X92.099 Y95.305
G1 X92.004 Y95.63
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X91.819 Y95.535 E.00506
G1 X91.75 Y95.33 E.00526
G1 X91.75 Y93.556 E.04315
G1 X91.797 Y93.331 E.00559
G1 X91.905 Y93.223 E.00372
G1 X92.076 Y93.175 E.00432
G1 X104.945 Y93.177 E.31303
G1 X105 Y93.21 E.00156
G1 X105 Y98.274 E.12318
G1 X104.914 Y98.274 E.00209
G1 X104.743 Y98.391 E.00504
G1 X104.731 Y98.457 E.00163
G1 X104.731 Y103.792 E.12977
G1 X104.741 Y103.85 E.00143
G1 X104.914 Y103.974 E.00518
G1 X105 Y103.974 E.00209
G1 X105 Y135.983 E.77859
G1 X104.355 Y136.522 E.02045
G1 X103.676 Y137.132 E.0222
G1 X103.512 Y137.381 E.00725
G1 X103.487 Y137.51 E.0032
G1 X103.6 Y137.78 E.00712
G1 X104.001 Y138.172 E.01364
G1 X104.991 Y139.018 E.03168
G1 X105.01 Y139.377 E.00874
G1 X105.093 Y139.477 E.00316
G1 X105.182 Y139.5 E.00224
G1 X125.817 Y139.5 E.50193
G1 X125.849 Y139.497 E.00078
G1 X125.971 Y139.417 E.00355
G1 X126.009 Y139.017 E.00977
G1 X127.013 Y138.153 E.03222
G1 X127.405 Y137.775 E.01325
G1 X127.516 Y137.531 E.00652
G1 X127.442 Y137.281 E.00634
G1 X127.165 Y136.978 E.00999
G1 X126 Y135.975 E.03739
G1 X126 Y103.974 E.77839
G1 X126.086 Y103.974 E.00209
G1 X126.242 Y103.887 E.00434
G1 X126.269 Y103.792 E.0024
G1 X126.269 Y98.457 E.12977
G1 X126.265 Y98.418 E.00095
G1 X126.086 Y98.274 E.00559
G1 X126 Y98.274 E.00209
G1 X126 Y93.232 E.12264
G1 X126.033 Y93.175 E.0016
G1 X138.008 Y93.175 E.29128
G1 X139.051 Y93.198 E.02538
G1 X139.207 Y93.33 E.00497
G1 X139.243 Y93.48 E.00375
G1 X139.25 Y95.253 E.04313
G1 X139.184 Y95.522 E.00674
G1 X139.102 Y95.584 E.0025
G1 X138.932 Y95.653 E.00446
G1 X136.183 Y95.652 E.06687
G1 X136.037 Y95.725 E.00397
G1 X136 Y95.835 E.00282
G1 X135.995 Y132.598 E.89422
G1 X135.964 Y133.125 E.01284
G1 X135.891 Y133.757 E.01547
G1 X135.748 Y134.501 E.01843
G1 X135.587 Y135.113 E.01539
G1 X135.162 Y136.263 E.02982
G1 X134.889 Y136.833 E.01537
G1 X134.42 Y137.636 E.02262
G1 X133.983 Y138.253 E.01839
G1 X133.582 Y138.745 E.01544
G1 X132.938 Y139.416 E.02262
G1 X132.368 Y139.914 E.01841
G1 X131.863 Y140.298 E.01543
G1 X131.079 Y140.799 E.02263
G1 X130.408 Y141.148 E.0184
G1 X129.828 Y141.404 E.01542
G1 X128.948 Y141.707 E.02264
G1 X128.214 Y141.889 E.01839
G1 X127.591 Y142.001 E.0154
G1 X126.193 Y142.1 E.03409
G1 X120.85 Y142.1 E.12996
G1 X120.85 Y142 E.00243
G1 X120.775 Y141.852 E.00404
G1 X120.667 Y141.817 E.00276
G1 X110.333 Y141.817 E.25136
G1 X110.226 Y141.852 E.00274
G1 X110.15 Y142 E.00405
G1 X110.15 Y142.1 E.00243
G1 X104.336 Y142.089 E.14142
G1 X103.239 Y141.973 E.02683
G1 X102.499 Y141.826 E.01835
G1 X101.607 Y141.566 E.0226
G1 X101.015 Y141.338 E.01543
G1 X100.329 Y141.021 E.01838
G1 X99.136 Y140.298 E.03393
G1 X98.276 Y139.611 E.02677
G1 X97.733 Y139.09 E.0183
G1 X96.84 Y138.017 E.03396
G1 X96.25 Y137.089 E.02675
G1 X95.907 Y136.419 E.01831
G1 X95.412 Y135.114 E.03395
G1 X95.157 Y134.044 E.02676
G1 X95.074 Y133.461 E.01432
G1 X95.019 Y132.871 E.01441
G1 X94.999 Y132.298 E.01395
G1 X94.999 Y95.835 E.88693
G1 X94.962 Y95.725 E.00282
G1 X94.816 Y95.652 E.00397
G1 X92.06 Y95.647 E.06704
G1 X92.06 Y95.647 F9000
G1 X92.116 Y95.288
;TYPE:Perimeter
G1 F6000
G1 X92.126 Y93.541 E.04249
G1 X104.634 Y93.543 E.30424
G1 X104.634 Y98.101 E.11087
G1 X104.402 Y98.26 E.00684
G1 X104.366 Y98.457 E.00487
G1 X104.366 Y103.792 E.12977
G1 X104.446 Y104.077 E.0072
G1 X104.634 Y104.183 E.00525
G1 X104.634 Y135.812 E.76934
G1 X104.11 Y136.25 E.01661
G1 X103.334 Y136.977 E.02586
G1 X103.129 Y137.373 E.01085
G1 X103.127 Y137.575 E.00491
G1 X103.211 Y137.833 E.0066
G1 X103.344 Y138.041 E.00601
G1 X103.764 Y138.45 E.01426
G1 X104.63 Y139.19 E.02771
G1 X104.635 Y139.333 E.00348
G1 X104.703 Y139.583 E.0063
G1 X104.915 Y139.796 E.00731
G1 X105.182 Y139.866 E.00671
G1 X125.817 Y139.866 E.50193
G1 X125.912 Y139.857 E.00232
G1 X126.14 Y139.76 E.00603
G1 X126.335 Y139.497 E.00796
G1 X126.37 Y139.189 E.00754
G1 X127.251 Y138.43 E.02829
G1 X127.668 Y138.029 E.01407
G1 X127.841 Y137.713 E.00876
G1 X127.88 Y137.433 E.00688
G1 X127.763 Y137.105 E.00847
G1 X127.404 Y136.701 E.01315
G1 X126.366 Y135.807 E.03332
G1 X126.366 Y104.183 E.76922
G1 X126.554 Y104.077 E.00525
G1 X126.634 Y103.792 E.0072
G1 X126.634 Y98.457 E.12977
G1 X126.598 Y98.26 E.00487
G1 X126.366 Y98.101 E.00684
G1 X126.366 Y93.541 E.11092
G1 X138.878 Y93.541 E.30434
G1 X138.875 Y95.288 E.04249
G1 X136.184 Y95.286 E.06546
G1 X135.925 Y95.351 E.0065
G1 X135.745 Y95.505 E.00576
G1 X135.657 Y95.681 E.00479
G1 X135.635 Y95.835 E.00378
G1 X135.629 Y132.588 E.89398
G1 X135.6 Y133.093 E.0123
G1 X135.529 Y133.701 E.01489
G1 X135.392 Y134.42 E.0178
G1 X135.238 Y135.003 E.01467
G1 X134.825 Y136.12 E.02897
G1 X134.565 Y136.661 E.0146
G1 X134.112 Y137.438 E.02188
G1 X133.691 Y138.032 E.01771
G1 X133.308 Y138.503 E.01477
G1 X132.685 Y139.151 E.02187
G1 X132.136 Y139.63 E.01772
G1 X131.653 Y139.998 E.01477
G1 X130.896 Y140.482 E.02186
G1 X130.25 Y140.818 E.01771
G1 X129.694 Y141.063 E.01478
G1 X128.845 Y141.356 E.02185
G1 X128.137 Y141.531 E.01774
G1 X127.546 Y141.637 E.0146
G1 X126.18 Y141.735 E.03331
G1 X121.081 Y141.735 E.12403
G1 X120.99 Y141.556 E.00488
G1 X120.667 Y141.451 E.00826
G1 X110.333 Y141.451 E.25136
G1 X110.011 Y141.555 E.00823
G1 X109.92 Y141.734 E.00488
G1 X104.355 Y141.723 E.13536
G1 X103.294 Y141.611 E.02595
G1 X102.586 Y141.471 E.01755
G1 X101.724 Y141.219 E.02184
G1 X101.157 Y141.001 E.01478
G1 X100.501 Y140.698 E.01758
G1 X99.346 Y139.997 E.03286
G1 X98.517 Y139.336 E.02579
G1 X98.001 Y138.841 E.01739
G1 X97.136 Y137.802 E.03288
G1 X96.568 Y136.907 E.02578
G1 X96.242 Y136.271 E.01738
G1 X95.763 Y135.006 E.0329
G1 X95.516 Y133.976 E.02576
G1 X95.436 Y133.41 E.0139
G1 X95.383 Y132.843 E.01385
G1 X95.365 Y132.294 E.01336
G1 X95.365 Y95.835 E.88683
G1 X95.343 Y95.681 E.00378
G1 X95.255 Y95.505 E.00479
G1 X95.074 Y95.351 E.00578
G1 X94.816 Y95.286 E.00647
G1 X92.176 Y95.288 E.06422
G1 X92.176 Y95.288 F9000
G1 X92.481 Y94.831
G1 F6000
G1 X92.481 Y93.906 E.0225
G1 X104.269 Y93.908 E.28673
G1 X104.269 Y97.986 E.09919
G1 X104.061 Y98.128 E.00613
G1 X104 Y98.457 E.00814
G1 X104 Y103.792 E.12977
G1 X104.012 Y103.94 E.00361
G1 X104.133 Y104.267 E.00848
G1 X104.269 Y104.343 E.00379
G1 X104.269 Y135.641 E.76129
G1 X103.187 Y136.589 E.03499
G1 X102.893 Y136.992 E.01213
G1 X102.77 Y137.303 E.00813
G1 X102.767 Y137.639 E.00817
G1 X102.927 Y138.089 E.01162
G1 X103.089 Y138.303 E.00653
G1 X103.526 Y138.728 E.01483
G1 X104.273 Y139.366 E.0239
G1 X104.383 Y139.76 E.00995
G1 X104.736 Y140.115 E.01218
G1 X105.181 Y140.231 E.01119
G1 X125.817 Y140.231 E.50195
G1 X125.975 Y140.218 E.00386
G1 X126.356 Y140.056 E.01007
G1 X126.585 Y139.814 E.0081
G1 X126.681 Y139.617 E.00533
G1 X126.727 Y139.364 E.00625
G1 X127.642 Y138.576 E.02937
G1 X128.039 Y138.148 E.0142
G1 X128.155 Y137.909 E.00646
G1 X128.249 Y137.532 E.00945
G1 X128.208 Y137.227 E.00749
G1 X127.999 Y136.797 E.01163
G1 X127.642 Y136.424 E.01256
G1 X126.731 Y135.64 E.02924
G1 X126.731 Y104.343 E.76127
G1 X126.867 Y104.267 E.00379
G1 X126.953 Y104.082 E.00496
G1 X127 Y103.792 E.00715
G1 X127 Y98.457 E.12977
G1 X126.939 Y98.129 E.00812
G1 X126.731 Y97.986 E.00614
G1 X126.731 Y93.907 E.09922
G1 X138.514 Y93.906 E.28661
G1 X138.517 Y94.922 E.02471
G1 X136.183 Y94.921 E.05677
G1 X135.753 Y95.028 E.01078
G1 X135.452 Y95.286 E.00964
G1 X135.306 Y95.578 E.00794
G1 X135.269 Y95.835 E.00632
G1 X135.263 Y132.454 E.89072
G1 X135.235 Y133.061 E.01478
G1 X135.167 Y133.645 E.0143
G1 X135.035 Y134.339 E.01718
G1 X134.889 Y134.892 E.01391
G1 X134.488 Y135.977 E.02814
G1 X134.242 Y136.49 E.01384
G1 X133.804 Y137.239 E.02111
G1 X133.4 Y137.811 E.01703
G1 X133.034 Y138.26 E.01409
G1 X132.433 Y138.886 E.02111
G1 X131.905 Y139.347 E.01705
G1 X131.444 Y139.698 E.01409
G1 X130.713 Y140.165 E.0211
G1 X130.092 Y140.489 E.01704
G1 X129.561 Y140.722 E.0141
G1 X128.741 Y141.005 E.0211
G1 X128.061 Y141.173 E.01704
G1 X127.5 Y141.274 E.01387
G1 X126.167 Y141.369 E.03251
G1 X121.26 Y141.369 E.11936
G1 X121.205 Y141.26 E.00297
G1 X120.667 Y141.085 E.01376
G1 X110.333 Y141.085 E.25136
G1 X110.175 Y141.099 E.00386
G1 X109.797 Y141.259 E.00998
G1 X109.741 Y141.368 E.00298
G1 X104.375 Y141.358 E.13052
G1 X103.349 Y141.249 E.0251
G1 X102.673 Y141.115 E.01676
G1 X101.841 Y140.872 E.02108
G1 X101.3 Y140.664 E.0141
G1 X100.673 Y140.375 E.01679
G1 X99.555 Y139.697 E.0318
G1 X98.758 Y139.061 E.0248
G1 X98.269 Y138.591 E.0165
G1 X97.432 Y137.586 E.03181
G1 X96.886 Y136.725 E.0248
G1 X96.577 Y136.122 E.01648
G1 X96.113 Y134.898 E.03184
G1 X95.876 Y133.907 E.02478
G1 X95.798 Y133.358 E.01349
G1 X95.748 Y132.816 E.01324
G1 X95.73 Y132.29 E.0128
G1 X95.73 Y95.835 E.88673
G1 X95.694 Y95.579 E.00629
G1 X95.547 Y95.286 E.00797
G1 X95.246 Y95.028 E.00964
G1 X94.816 Y94.921 E.01078
G1 X92.481 Y94.922 E.0568
G1 X92.481 Y94.891 E.00075
G1 E-5 F3600
G1 X92.481 Y94.891 F9000
G1 X92.099 Y94.891
G1 X104.651 Y93.525
G1 X104.383 Y97.926
G1 X103.133 Y137.5
G1 X103.14 Y137.593
G1 X103.158 Y137.682
G1 X103.185 Y137.763
G1 X103.218 Y137.836
G1 X103.258 Y137.904
G1 X103.302 Y137.967
G1 X104.651 Y139.849
G1 X110.099 Y140.669
G1 E5 F2400
;WIDTH:0.5431
G1 F6000
G1 X110.333 Y140.658 E.00793
;WIDTH:0.522776
G1 X120.667 Y140.658 E.33576
G1 E-5 F3600
G1 X120.667 Y140.658 F9000
G1 X103.14 Y137.593
G1 X103.133 Y137.5
G1 X103.903 Y124.448
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X103.903 Y135.47 E.2681
G1 X102.869 Y136.389 E.03365
G1 X102.583 Y136.797 E.01212
G1 X102.411 Y137.232 E.01138
G1 X102.407 Y137.704 E.01148
G1 X102.606 Y138.265 E.01448
G1 X102.833 Y138.564 E.00913
G1 X103.288 Y139.006 E.01543
G1 X103.942 Y139.564 E.02091
G1 X104.064 Y139.938 E.00957
G1 X104.557 Y140.433 E.01699
;WIDTH:0.41547
G1 X105.183 Y140.605 E.01646
;WIDTH:0.419457
G1 X109.463 Y140.607 E.10965
;WIDTH:0.460672
G1 X109.675 Y140.627 E.00604
;WIDTH:0.501886
G1 X109.887 Y140.648 E.00663
;WIDTH:0.5431
G1 X110.099 Y140.669 E.00721
G1 X109.919 Y140.776 E.00709
;WIDTH:0.501886
G1 X109.738 Y140.884 E.00656
;WIDTH:0.460672
G1 X109.558 Y140.992 E.00595
;WIDTH:0.419457
G1 X105.182 Y140.986 E.11211
;WIDTH:0.41547
G1 X104.395 Y140.992 E.01995
;WIDTH:0.399999
G1 X103.404 Y140.887 E.02424
G1 X102.76 Y140.76 E.01597
G1 X101.958 Y140.525 E.02033
G1 X101.442 Y140.327 E.01344
G1 X100.845 Y140.051 E.016
G1 X99.765 Y139.396 E.03072
G1 X98.999 Y138.785 E.02383
G1 X98.537 Y138.341 E.01559
G1 X97.728 Y137.37 E.03074
G1 X97.204 Y136.543 E.02381
G1 X96.911 Y135.973 E.01559
G1 X96.463 Y134.791 E.03075
G1 X96.236 Y133.839 E.02381
G1 X96.16 Y133.307 E.01307
G1 X96.113 Y132.789 E.01265
G1 X96.096 Y132.286 E.01224
G1 X96.096 Y95.835 E.88663
G1 X96.045 Y95.476 E.00882
G1 X95.84 Y95.067 E.01113
G1 X95.418 Y94.705 E.01352
G1 X94.816 Y94.576 E.01498
;WIDTH:0.359047
G1 X92.827 Y94.576 E.04296
G1 X92.827 Y94.252 E.007
G1 X94.815 Y94.252 E.04294
;WIDTH:0.399999
G1 X95.526 Y94.273 E.0173
G1 X103.903 Y94.274 E.20376
G1 X103.903 Y97.871 E.08749
G1 X103.72 Y97.997 E.0054
G1 X103.664 Y98.183 E.00472
G1 X103.634 Y98.457 E.0067
G1 X103.634 Y103.792 E.12977
G1 X103.651 Y103.999 E.00505
G1 X103.821 Y104.457 E.01188
G1 X103.903 Y104.503 E.00229
G1 X103.903 Y124.388 E.48368
G1 E-5 F3600
G1 X103.903 Y124.388 F9000
G1 X103.537 Y135.299
G1 E5 F2400
G1 F6000
G1 X102.604 Y136.137 E.0305
G1 X102.273 Y136.603 E.0139
G1 X102.052 Y137.162 E.01462
G1 X102.047 Y137.768 E.01474
G1 X102.117 Y138.031 E.00662
G1 X102.286 Y138.441 E.01079
G1 X102.577 Y138.825 E.01172
G1 X103.051 Y139.284 E.01605
G1 X103.611 Y139.763 E.01792
G1 X103.744 Y140.115 E.00915
G1 X104.234 Y140.607 E.01689
G1 X103.459 Y140.525 E.01896
G1 X102.847 Y140.404 E.01517
G1 X102.075 Y140.179 E.01956
G1 X101.585 Y139.99 E.01277
G1 X101.017 Y139.728 E.01522
G1 X99.975 Y139.096 E.02964
G1 X99.241 Y138.51 E.02285
G1 X98.805 Y138.092 E.01469
G1 X98.024 Y137.154 E.02969
G1 X97.521 Y136.362 E.02282
G1 X97.246 Y135.825 E.01468
G1 X96.934 Y135.002 E.02141
G1 X96.762 Y134.469 E.01362
G1 X96.572 Y133.609 E.02142
G1 X96.496 Y133.02 E.01445
G1 X96.462 Y132.281 E.01799
G1 X96.462 Y95.835 E.88651
G1 X96.396 Y95.374 E.01133
G1 X96.132 Y94.847 E.01434
G1 X95.889 Y94.638 E.0078
G1 X103.537 Y94.64 E.18603
G1 X103.537 Y97.757 E.07582
G1 X103.379 Y97.866 E.00467
G1 X103.307 Y98.105 E.00607
G1 X103.269 Y98.457 E.00861
G1 X103.269 Y103.792 E.12977
G1 X103.354 Y104.315 E.01289
G1 X103.537 Y104.663 E.00956
G1 X103.537 Y135.239 E.74373
G1 E-5 F3600
G1 X103.537 Y135.239 F9000
G1 X103.14 Y137.407
G1 X103.133 Y137.5
G1 X103.14 Y137.593
G1 X120.678 Y140.663
G1 E5 F2400
;WIDTH:0.522776
G1 F6000
G1 X120.667 Y140.658 E.00039
G1 X120.958 Y140.641 E.00947
;WIDTH:0.488612
G1 X121.248 Y140.624 E.00878
;WIDTH:0.454448
G1 X121.539 Y140.607 E.00815
;WIDTH:0.420285
G1 X125.817 Y140.607 E.10983
;WIDTH:0.425904
G1 X126.101 Y140.578 E.00744
G1 X126.571 Y140.351 E.0136
;WIDTH:0.399999
G1 X126.892 Y140.013 E.01134
G1 X127.026 Y139.736 E.00748
G1 X127.059 Y139.561 E.00433
G1 X127.728 Y138.985 E.02147
G1 X128.194 Y138.537 E.01572
G1 X128.452 Y138.145 E.01141
G1 X128.596 Y137.719 E.01094
G1 X128.606 Y137.343 E.00915
G1 X128.516 Y137.005 E.00851
G1 X128.29 Y136.575 E.01182
G1 X127.881 Y136.147 E.0144
G1 X127.097 Y135.472 E.02516
G1 X127.097 Y104.503 E.75329
G1 X127.179 Y104.457 E.00229
G1 X127.299 Y104.198 E.00694
G1 X127.366 Y103.792 E.01001
G1 X127.366 Y98.457 E.12977
G1 X127.362 Y98.354 E.00251
G1 X127.28 Y97.997 E.00891
G1 X127.097 Y97.871 E.0054
G1 X127.097 Y94.272 E.08754
G1 X135.473 Y94.272 E.20374
G1 X136.183 Y94.251 E.01728
;WIDTH:0.359108
G1 X138.17 Y94.252 E.04293
G1 X138.171 Y94.576 E.007
G1 X136.184 Y94.576 E.04293
;WIDTH:0.369314
G1 X135.965 Y94.589 E.00489
;WIDTH:0.399999
G1 X135.582 Y94.705 E.00973
G1 X135.16 Y95.066 E.01351
G1 X134.955 Y95.476 E.01115
G1 X134.903 Y95.834 E.0088
G1 X134.898 Y132.454 E.89074
G1 X134.871 Y133.03 E.01403
G1 X134.806 Y133.59 E.01371
G1 X134.678 Y134.258 E.01654
G1 X134.54 Y134.782 E.01318
G1 X134.15 Y135.834 E.02729
G1 X133.919 Y136.318 E.01304
G1 X133.497 Y137.041 E.02036
G1 X133.108 Y137.589 E.01635
G1 X132.76 Y138.018 E.01344
G1 X132.18 Y138.621 E.02035
G1 X131.674 Y139.063 E.01634
G1 X131.234 Y139.398 E.01345
G1 X130.53 Y139.848 E.02032
G1 X129.933 Y140.159 E.01637
G1 X129.427 Y140.382 E.01345
G1 X128.637 Y140.654 E.02032
G1 X127.985 Y140.815 E.01634
G1 X127.455 Y140.911 E.0131
G1 X126.793 Y140.958 E.01614
;WIDTH:0.420285
G1 X125.817 Y140.993 E.02507
G1 X121.444 Y140.993 E.11227
G1 X121.426 Y140.956 E.00106
;WIDTH:0.454448
G1 X121.173 Y140.857 E.00759
;WIDTH:0.488612
G1 X120.92 Y140.758 E.00821
;WIDTH:0.522776
G1 X120.734 Y140.685 E.00649
G1 E-5 F3600
G1 X120.734 Y140.685 F9000
G1 X126.349 Y139.849
G1 X127.698 Y137.967
G1 X127.742 Y137.904
G1 X127.782 Y137.836
G1 X127.815 Y137.763
G1 X127.842 Y137.682
G1 X127.86 Y137.593
G1 X127.867 Y137.5
G1 X127.86 Y137.407
G1 X127.463 Y135.304
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X127.463 Y104.75 E.7432
G1 X127.646 Y104.315 E.01148
G1 X127.731 Y103.792 E.01289
G1 X127.731 Y98.457 E.12977
G1 X127.726 Y98.324 E.00324
G1 X127.621 Y97.866 E.01143
G1 X127.463 Y97.757 E.00467
G1 X127.463 Y94.638 E.07587
G1 X135.111 Y94.638 E.18603
G1 X134.867 Y94.847 E.00781
G1 X134.604 Y95.374 E.01433
G1 X134.538 Y95.834 E.0113
G1 X134.532 Y132.454 E.89074
G1 X134.506 Y132.998 E.01325
G1 X134.444 Y133.534 E.01312
G1 X134.321 Y134.177 E.01592
G1 X134.191 Y134.672 E.01245
G1 X133.813 Y135.691 E.02644
G1 X133.595 Y136.147 E.01229
G1 X133.189 Y136.843 E.0196
G1 X132.817 Y137.368 E.01565
G1 X132.486 Y137.775 E.01276
G1 X131.928 Y138.356 E.01959
G1 X131.443 Y138.78 E.01567
G1 X131.025 Y139.098 E.01278
G1 X130.346 Y139.531 E.01959
G1 X129.775 Y139.829 E.01567
G1 X129.294 Y140.041 E.01279
G1 X128.534 Y140.303 E.01955
G1 X127.908 Y140.457 E.01568
G1 X127.409 Y140.547 E.01233
G1 X126.843 Y140.588 E.0138
G1 X127.199 Y140.211 E.01261
G1 X127.39 Y139.758 E.01196
G1 X128.23 Y139.026 E.0271
G1 X128.651 Y138.547 E.01551
G1 X128.789 Y138.287 E.00716
G1 X128.957 Y137.782 E.01295
G1 X128.98 Y137.557 E.0055
G1 X128.906 Y137.009 E.01345
G1 X128.789 Y136.713 E.00774
G1 X128.58 Y136.353 E.01013
G1 X128.119 Y135.87 E.01624
G1 X127.508 Y135.343 E.01963
G1 E-5 F3600
G1 X127.508 Y135.343 F9000
G1 X130.753 Y139.141
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X132.28 Y137.594 E.05287
G1 X132.958 Y136.694 E.02741
G1 X133.348 Y136.026 E.01881
G1 X129.94 Y139.434 E.11723
G1 X129.003 Y139.851 E.02495
G1 X133.732 Y135.122 E.16267
G1 X133.995 Y134.338 E.02011
G1 X128.241 Y140.093 E.19795
G1 X127.58 Y140.233 E.01643
G1 X134.138 Y133.675 E.22559
G1 X134.222 Y133.071 E.01483
G1 X129.129 Y138.164 E.1752
G1 X129.252 Y137.52 E.01595
G1 X134.258 Y132.515 E.17219
G1 X134.258 Y131.994 E.01267
G1 X129.196 Y137.056 E.17413
G1 X129.062 Y136.67 E.00994
G1 X134.258 Y131.474 E.17874
G1 X134.258 Y130.953 E.01267
G1 X128.89 Y136.322 E.18467
G1 X128.663 Y136.028 E.00903
G1 X134.258 Y130.433 E.19246
G1 X134.258 Y129.913 E.01265
G1 X128.406 Y135.765 E.20131
G1 X128.129 Y135.522 E.00896
G1 X134.258 Y129.392 E.21085
G1 X134.258 Y128.872 E.01265
G1 X127.851 Y135.279 E.2204
G1 X127.737 Y135.179 E.00369
G1 X127.737 Y134.873 E.00744
G1 X134.258 Y128.351 E.22434
G1 X134.259 Y127.831 E.01265
G1 X127.737 Y134.352 E.22434
G1 X127.737 Y133.832 E.01265
G1 X134.259 Y127.31 E.22435
G1 X134.259 Y126.79 E.01265
G1 X127.737 Y133.312 E.22435
G1 X127.737 Y132.791 E.01267
G1 X134.259 Y126.27 E.22434
G1 X134.259 Y125.749 E.01267
G1 X127.737 Y132.271 E.22435
G1 X127.737 Y131.751 E.01265
G1 X134.259 Y125.229 E.22435
G1 X134.259 Y124.708 E.01267
G1 X127.737 Y131.23 E.22435
G1 X127.737 Y130.71 E.01265
G1 X134.259 Y124.188 E.22435
G1 X134.259 Y123.668 E.01265
G1 X127.737 Y130.19 E.22435
G1 X127.737 Y129.669 E.01267
G1 X134.259 Y123.147 E.22435
G1 X134.259 Y122.627 E.01265
G1 X127.737 Y129.149 E.22435
G1 X127.737 Y128.629 E.01265
G1 X134.259 Y122.106 E.22437
G1 X134.26 Y121.586 E.01265
G1 X127.737 Y128.108 E.22437
G1 X127.737 Y127.588 E.01265
G1 X134.26 Y121.065 E.22439
G1 X134.26 Y120.545 E.01265
G1 X127.737 Y127.068 E.22439
G1 X127.737 Y126.547 E.01267
G1 X134.26 Y120.025 E.22437
G1 X134.26 Y119.504 E.01267
G1 X127.737 Y126.027 E.22439
G1 X127.737 Y125.507 E.01265
G1 X134.26 Y118.984 E.22439
G1 X134.26 Y118.463 E.01267
G1 X127.737 Y124.986 E.22439
G1 X127.737 Y124.466 E.01265
G1 X134.26 Y117.943 E.22439
G1 X134.26 Y117.422 E.01267
G1 X127.737 Y123.946 E.2244
G1 X127.737 Y123.425 E.01267
G1 X134.26 Y116.902 E.22439
G1 X134.26 Y116.382 E.01265
G1 X127.737 Y122.905 E.22439
G1 X127.737 Y122.385 E.01265
G1 X134.26 Y115.861 E.2244
G1 X134.26 Y115.341 E.01265
G1 X127.737 Y121.864 E.22439
G1 X127.737 Y121.344 E.01265
G1 X134.261 Y114.82 E.22442
G1 X134.261 Y114.3 E.01265
G1 X127.737 Y120.824 E.22442
G1 X127.737 Y120.303 E.01267
G1 X134.261 Y113.78 E.2244
G1 X134.261 Y113.259 E.01267
G1 X127.737 Y119.783 E.22442
G1 X127.737 Y119.263 E.01265
G1 X134.261 Y112.739 E.22442
G1 X134.261 Y112.218 E.01267
G1 X127.737 Y118.742 E.22442
G1 X127.737 Y118.222 E.01265
G1 X134.261 Y111.698 E.22442
G1 X134.261 Y111.177 E.01267
G1 X127.737 Y117.702 E.22444
G1 X127.737 Y117.181 E.01267
G1 X134.261 Y110.657 E.22442
G1 X134.261 Y110.137 E.01265
G1 X127.737 Y116.661 E.22442
G1 X127.737 Y116.141 E.01265
G1 X134.261 Y109.616 E.22444
G1 X134.261 Y109.096 E.01265
G1 X127.737 Y115.62 E.22442
G1 X127.737 Y115.1 E.01265
G1 X134.262 Y108.575 E.22446
G1 X134.262 Y108.055 E.01265
G1 X127.737 Y114.58 E.22446
G1 X127.737 Y114.059 E.01267
G1 X134.262 Y107.535 E.22444
G1 X134.262 Y107.014 E.01267
G1 X127.737 Y113.539 E.22446
G1 X127.737 Y113.019 E.01265
G1 X134.262 Y106.494 E.22446
G1 X134.262 Y105.973 E.01267
G1 X127.737 Y112.498 E.22446
G1 X127.737 Y111.978 E.01265
G1 X134.262 Y105.453 E.22446
G1 X134.262 Y104.932 E.01267
G1 X127.737 Y111.458 E.22447
G1 X127.737 Y110.937 E.01267
G1 X134.262 Y104.412 E.22446
G1 X134.262 Y103.892 E.01265
G1 X127.737 Y110.417 E.22446
G1 X127.737 Y109.897 E.01265
G1 X134.262 Y103.371 E.22447
G1 X134.262 Y102.851 E.01265
G1 X127.737 Y109.376 E.22446
G1 X127.737 Y108.856 E.01265
G1 X134.263 Y102.33 E.22449
G1 X134.263 Y101.81 E.01265
G1 X127.737 Y108.336 E.22449
G1 X127.737 Y107.815 E.01267
G1 X134.263 Y101.289 E.22449
G1 X134.263 Y100.769 E.01265
G1 X127.737 Y107.295 E.22449
G1 X127.737 Y106.775 E.01265
G1 X134.263 Y100.249 E.22449
G1 X134.263 Y99.728 E.01267
G1 X127.737 Y106.254 E.22449
G1 X127.737 Y105.734 E.01265
G1 X134.263 Y99.208 E.22449
G1 X134.263 Y98.687 E.01267
G1 X127.737 Y105.214 E.22451
G1 X127.737 Y104.764 E.01095
G1 X127.799 Y104.631 E.00357
G1 X134.263 Y98.167 E.22236
G1 X134.263 Y97.647 E.01265
G1 X127.996 Y103.914 E.21558
G1 X128.006 Y103.384 E.01289
G1 X134.263 Y97.126 E.21525
G1 X134.263 Y96.606 E.01265
G1 X128.006 Y102.864 E.21525
G1 X128.006 Y102.343 E.01267
G1 X134.264 Y96.085 E.21527
G1 X134.307 Y95.521 E.01376
G1 X128.006 Y101.823 E.21677
G1 X128.006 Y101.302 E.01267
G1 X134.396 Y94.912 E.21981
G1 X133.876 Y94.912 E.01265
G1 X128.006 Y100.782 E.20192
G1 X128.006 Y100.262 E.01265
G1 X133.355 Y94.912 E.18402
G1 X132.835 Y94.912 E.01265
G1 X128.006 Y99.741 E.16611
G1 X128.006 Y99.221 E.01265
G1 X132.315 Y94.912 E.14823
G1 X131.794 Y94.912 E.01267
G1 X128.006 Y98.701 E.13032
G1 X127.979 Y98.207 E.01203
G1 X131.274 Y94.912 E.11335
G1 X130.754 Y94.912 E.01265
G1 X127.882 Y97.783 E.09878
G1 X127.737 Y97.651 E.00477
G1 X127.737 Y97.409 E.00589
G1 X130.233 Y94.912 E.08588
G1 X129.713 Y94.912 E.01265
G1 X127.737 Y96.888 E.06797
G1 X127.737 Y96.368 E.01265
G1 X129.193 Y94.912 E.05009
G1 X128.672 Y94.912 E.01267
G1 X127.737 Y95.848 E.03218
G1 X127.737 Y95.327 E.01267
G1 X128.316 Y94.748 E.01992
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X127.737 Y95.327 E-.38894
G1 X127.737 Y95.848 E-.24748
G1 X128.672 Y94.912 E-.62842
G1 X129.167 Y94.912 E-.23516
;WIPE_END
G1 X96.932 Y94.748 F9000
G1 E5 F2400
G1 F3072.127
G1 X96.568 Y95.112 E.01252
G1 X96.69 Y95.508 E.01008
G1 X97.286 Y94.913 E.02048
G1 X97.804 Y94.913 E.0126
G1 X96.736 Y95.981 E.03674
G1 X96.736 Y96.499 E.0126
G1 X98.322 Y94.913 E.05456
G1 X98.841 Y94.913 E.01262
G1 X96.736 Y97.018 E.07241
G1 X96.736 Y97.536 E.0126
G1 X99.359 Y94.913 E.09023
G1 X99.877 Y94.913 E.0126
G1 X96.736 Y98.055 E.10807
G1 X96.736 Y98.573 E.0126
G1 X100.396 Y94.913 E.1259
G1 X100.914 Y94.913 E.0126
G1 X96.736 Y99.092 E.14374
G1 X96.736 Y99.61 E.0126
G1 X101.432 Y94.913 E.16156
G1 X101.951 Y94.914 E.01262
G1 X96.736 Y100.129 E.17939
G1 X96.736 Y100.647 E.0126
G1 X102.469 Y94.914 E.19721
G1 X102.988 Y94.914 E.01262
G1 X96.736 Y101.165 E.21505
G1 X96.736 Y101.684 E.01262
G1 X103.263 Y95.157 E.22452
G1 X103.263 Y95.675 E.0126
G1 X96.736 Y102.202 E.22452
G1 X96.736 Y102.721 E.01262
G1 X103.263 Y96.193 E.22454
G1 X103.263 Y96.712 E.01262
G1 X96.736 Y103.239 E.22452
G1 X96.736 Y103.758 E.01262
G1 X103.263 Y97.23 E.22454
G1 X103.263 Y97.651 E.01024
G1 X103.13 Y97.743 E.00393
G1 X103.07 Y97.942 E.00506
G1 X96.736 Y104.276 E.21789
G1 X96.736 Y104.794 E.0126
G1 X102.994 Y98.536 E.21527
G1 X102.994 Y99.054 E.0126
G1 X96.736 Y105.313 E.21529
G1 X96.736 Y105.831 E.0126
G1 X102.994 Y99.573 E.21527
G1 X102.994 Y100.091 E.0126
G1 X96.736 Y106.35 E.21529
G1 X96.736 Y106.868 E.0126
G1 X102.994 Y100.61 E.21527
G1 X102.994 Y101.128 E.0126
G1 X96.736 Y107.387 E.21529
G1 X96.736 Y107.905 E.0126
G1 X102.994 Y101.647 E.21527
G1 X102.994 Y102.165 E.0126
G1 X96.736 Y108.424 E.21529
G1 X96.736 Y108.942 E.0126
G1 X102.994 Y102.683 E.21529
G1 X102.994 Y103.202 E.01262
G1 X96.736 Y109.46 E.21527
G1 X96.736 Y109.979 E.01262
G1 X102.994 Y103.72 E.21529
G1 X103.042 Y104.192 E.01154
G1 X96.736 Y110.497 E.21691
G1 X96.736 Y111.016 E.01262
G1 X103.175 Y104.576 E.22151
G1 X103.263 Y104.764 E.00505
G1 X103.263 Y105.007 E.00591
G1 X96.736 Y111.534 E.22452
G1 X96.736 Y112.053 E.01262
G1 X103.263 Y105.525 E.22454
G1 X103.263 Y106.044 E.01262
G1 X96.736 Y112.571 E.22452
G1 X96.736 Y113.089 E.0126
G1 X103.263 Y106.562 E.22452
G1 X103.263 Y107.081 E.01262
G1 X96.736 Y113.608 E.22452
G1 X96.736 Y114.126 E.0126
G1 X103.263 Y107.599 E.22452
G1 X103.263 Y108.118 E.01262
G1 X96.736 Y114.645 E.22452
G1 X96.736 Y115.163 E.0126
G1 X103.263 Y108.636 E.22452
G1 X103.263 Y109.154 E.0126
G1 X96.736 Y115.682 E.22454
G1 X96.736 Y116.2 E.0126
G1 X103.263 Y109.673 E.22452
G1 X103.263 Y110.191 E.0126
G1 X96.736 Y116.719 E.22454
G1 X96.736 Y117.237 E.0126
G1 X103.263 Y110.71 E.22452
G1 X103.263 Y111.228 E.0126
G1 X96.736 Y117.755 E.22452
G1 X96.736 Y118.274 E.01262
G1 X103.263 Y111.747 E.22452
G1 X103.263 Y112.265 E.0126
G1 X96.736 Y118.792 E.22452
G1 X96.736 Y119.311 E.01262
G1 X103.263 Y112.783 E.22454
G1 X103.263 Y113.302 E.01262
G1 X96.736 Y119.829 E.22452
G1 X96.736 Y120.348 E.01262
G1 X103.263 Y113.82 E.22454
G1 X103.263 Y114.339 E.01262
G1 X96.736 Y120.866 E.22452
G1 X96.736 Y121.384 E.0126
G1 X103.263 Y114.857 E.22452
G1 X103.263 Y115.376 E.01262
G1 X96.736 Y121.903 E.22452
G1 X96.736 Y122.421 E.0126
G1 X103.263 Y115.894 E.22452
G1 X103.263 Y116.413 E.01262
G1 X96.736 Y122.94 E.22452
G1 X96.736 Y123.458 E.0126
G1 X103.263 Y116.931 E.22452
G1 X103.263 Y117.449 E.0126
G1 X96.736 Y123.977 E.22454
G1 X96.736 Y124.495 E.0126
G1 X103.263 Y117.968 E.22452
G1 X103.263 Y118.486 E.0126
G1 X96.736 Y125.014 E.22454
G1 X96.736 Y125.532 E.0126
G1 X103.263 Y119.005 E.22452
G1 X103.263 Y119.523 E.0126
G1 X96.736 Y126.05 E.22452
G1 X96.736 Y126.569 E.01262
G1 X103.263 Y120.042 E.22452
G1 X103.263 Y120.56 E.0126
G1 X96.736 Y127.087 E.22452
G1 X96.736 Y127.606 E.01262
G1 X103.263 Y121.078 E.22454
G1 X103.263 Y121.597 E.01262
G1 X96.736 Y128.124 E.22452
G1 X96.736 Y128.643 E.01262
G1 X103.263 Y122.115 E.22454
G1 X103.263 Y122.634 E.01262
G1 X96.736 Y129.161 E.22452
G1 X96.736 Y129.679 E.0126
G1 X103.263 Y123.152 E.22452
G1 X103.263 Y123.671 E.01262
G1 X96.736 Y130.198 E.22452
G1 X96.736 Y130.716 E.0126
G1 X103.263 Y124.189 E.22452
G1 X103.263 Y124.708 E.01262
G1 X96.736 Y131.235 E.22452
G1 X96.736 Y131.753 E.0126
G1 X103.263 Y125.226 E.22452
G1 X103.263 Y125.744 E.0126
G1 X96.736 Y132.277 E.22463
G1 X96.761 Y132.765 E.01189
G1 X103.263 Y126.263 E.22366
G1 X103.263 Y126.781 E.0126
G1 X96.798 Y133.247 E.22241
G1 X96.862 Y133.701 E.01115
G1 X103.263 Y127.3 E.22019
G1 X103.263 Y127.818 E.0126
G1 X96.961 Y134.121 E.2168
G1 X97.061 Y134.539 E.01045
G1 X103.263 Y128.337 E.21335
G1 X103.263 Y128.855 E.0126
G1 X97.197 Y134.921 E.20867
G1 X97.339 Y135.297 E.00978
G1 X103.263 Y129.374 E.20376
G1 X103.263 Y129.892 E.0126
G1 X97.482 Y135.673 E.19886
G1 X97.654 Y136.019 E.0094
G1 X103.263 Y130.41 E.19295
G1 X103.263 Y130.929 E.01262
G1 X97.84 Y136.352 E.18655
G1 X98.041 Y136.669 E.00913
G1 X103.263 Y131.447 E.17963
G1 X103.263 Y131.966 E.01262
G1 X98.243 Y136.986 E.17268
G1 X98.478 Y137.27 E.00897
G1 X103.263 Y132.484 E.16462
G1 X103.263 Y133.003 E.01262
G1 X98.713 Y137.553 E.15652
G1 X98.949 Y137.836 E.00896
G1 X103.263 Y133.521 E.14842
G1 X103.263 Y134.039 E.0126
G1 X99.206 Y138.097 E.13958
G1 X99.475 Y138.346 E.00892
G1 X103.263 Y134.558 E.1303
G1 X103.263 Y135.076 E.0126
G1 X99.763 Y138.576 E.1204
G1 X100.052 Y138.806 E.00898
G1 X101.799 Y137.059 E.0601
G1 X101.766 Y137.611 E.01345
G1 X100.365 Y139.012 E.04819
G1 X100.688 Y139.207 E.00918
G1 X101.84 Y138.055 E.03963
G1 X101.985 Y138.428 E.00973
G1 X101.01 Y139.403 E.03354
G1 X101.352 Y139.58 E.00937
G1 X102.174 Y138.758 E.02828
G1 X102.407 Y139.043 E.00895
G1 X101.707 Y139.743 E.02408
G1 X102.081 Y139.887 E.00975
G1 X102.671 Y139.297 E.0203
G1 X102.939 Y139.548 E.00893
G1 X102.477 Y140.01 E.01589
G1 X102.878 Y140.127 E.01016
G1 X103.218 Y139.787 E.0117
G1 X103.37 Y139.917 E.00487
G1 X103.438 Y140.086 E.00443
G1 X103.168 Y140.356 E.00929
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.438 Y140.086 E-.18137
G1 X103.37 Y139.917 E-.08653
G1 X103.218 Y139.787 E-.095
G1 X102.878 Y140.127 E-.2284
G1 X102.477 Y140.01 E-.19842
G1 X102.939 Y139.548 E-.31035
G1 X102.671 Y139.297 E-.17441
G1 X102.335 Y139.633 E-.22552
;WIPE_END
G1 X104.651 Y131.893 F9000
G1 X106.099 Y127.058
G1 X109.382 Y115.163
G1 X109.705 Y115.008
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X109.617 Y114.803 E.00543
G1 X109.519 Y114.399 E.01011
G1 X109.488 Y113.978 E.01027
G1 X109.559 Y113.404 E.01407
G1 X109.829 Y112.726 E.01775
G1 X111.561 Y109.725 E.08428
G1 X111.821 Y109.37 E.0107
G1 X112.175 Y109.01 E.01228
G1 X112.615 Y108.733 E.01265
G1 X112.923 Y108.596 E.0082
G1 X113.487 Y108.468 E.01407
G1 X117.233 Y108.452 E.09112
G1 X117.616 Y108.481 E.00934
G1 X118.174 Y108.633 E.01407
G1 X118.583 Y108.839 E.01114
G1 X118.987 Y109.155 E.01248
G1 X119.438 Y109.725 E.01768
G1 X121.171 Y112.727 E.08431
G1 X121.35 Y113.106 E.0102
G1 X121.49 Y113.667 E.01406
G1 X121.509 Y114.126 E.01117
G1 X121.415 Y114.698 E.0141
G1 X121.171 Y115.274 E.01522
G1 X119.327 Y118.451 E.08935
G1 X119.042 Y118.794 E.01085
G1 X118.726 Y119.064 E.01011
G1 X118.346 Y119.29 E.01075
G1 X117.978 Y119.436 E.00963
G1 X117.413 Y119.541 E.01398
G1 X113.768 Y119.548 E.08866
G1 X113.124 Y119.465 E.01579
G1 X112.543 Y119.234 E.01521
G1 X112.038 Y118.871 E.01513
G1 X111.619 Y118.371 E.01587
G1 X109.789 Y115.204 E.08897
G1 X109.729 Y115.063 E.00373
G1 X109.729 Y115.063 F9000
G1 X109.373 Y115.151
;TYPE:Perimeter
G1 F6000
G1 X109.262 Y114.892 E.00685
G1 X109.154 Y114.429 E.01156
G1 X109.125 Y113.933 E.01209
G1 X109.196 Y113.359 E.01407
G1 X109.512 Y112.544 E.02126
G1 X111.245 Y109.543 E.08429
G1 X111.56 Y109.114 E.01295
G1 X111.94 Y108.73 E.01314
G1 X112.385 Y108.436 E.01297
G1 X112.842 Y108.24 E.0121
G1 X113.405 Y108.111 E.01405
G1 X114.368 Y108.087 E.02343
G1 X117.232 Y108.086 E.06966
G1 X117.712 Y108.129 E.01172
G1 X118.27 Y108.28 E.01406
G1 X118.793 Y108.54 E.01421
G1 X119.212 Y108.866 E.01291
G1 X119.755 Y109.542 E.02109
G1 X121.488 Y112.544 E.08431
G1 X121.705 Y113.017 E.01266
G1 X121.845 Y113.578 E.01406
G1 X121.877 Y114.096 E.01262
G1 X121.776 Y114.755 E.01622
G1 X121.487 Y115.457 E.01847
G1 X119.643 Y118.635 E.08937
G1 X119.317 Y119.037 E.01259
G1 X118.933 Y119.366 E.0123
G1 X118.484 Y119.629 E.01266
G1 X118.045 Y119.796 E.01142
G1 X117.479 Y119.901 E.014
G1 X113.768 Y119.914 E.09027
G1 X113.076 Y119.827 E.01696
G1 X112.405 Y119.573 E.01745
G1 X111.822 Y119.166 E.01729
G1 X111.303 Y118.554 E.01952
G1 X109.473 Y115.387 E.08897
G1 X109.396 Y115.206 E.00478
G1 X109.396 Y115.206 F9000
G1 X109.04 Y115.295
G1 F6000
G1 X108.908 Y114.98 E.00831
G1 X108.79 Y114.459 E.01299
G1 X108.762 Y113.888 E.01391
G1 X108.833 Y113.314 E.01407
G1 X109.196 Y112.361 E.02481
G1 X110.928 Y109.36 E.08428
G1 X111.233 Y108.926 E.0129
G1 X111.64 Y108.51 E.01416
G1 X112.103 Y108.176 E.01389
G1 X112.584 Y107.943 E.013
G1 X113.103 Y107.805 E.01306
G1 X113.561 Y107.731 E.01128
G1 X117.232 Y107.721 E.08929
G1 X117.808 Y107.776 E.01407
G1 X118.366 Y107.927 E.01406
G1 X118.873 Y108.163 E.0136
G1 X119.303 Y108.474 E.01291
G1 X119.594 Y108.735 E.00951
G1 X120.072 Y109.36 E.01914
G1 X121.804 Y112.361 E.08428
G1 X122.059 Y112.929 E.01514
G1 X122.199 Y113.489 E.01404
G1 X122.242 Y114.059 E.0139
G1 X122.137 Y114.815 E.01857
G1 X121.803 Y115.641 E.02167
G1 X119.959 Y118.818 E.08935
G1 X119.626 Y119.239 E.01306
G1 X119.229 Y119.599 E.01304
G1 X118.79 Y119.883 E.01272
G1 X118.29 Y120.103 E.01329
G1 X117.546 Y120.26 E.0185
G1 X117.231 Y120.276 E.00767
G1 X113.768 Y120.279 E.08423
G1 X113.253 Y120.219 E.01261
G1 X112.802 Y120.13 E.01118
G1 X112.267 Y119.911 E.01406
G1 X111.839 Y119.632 E.01243
G1 X111.444 Y119.308 E.01243
G1 X110.986 Y118.737 E.0178
G1 X109.156 Y115.57 E.08897
G1 X109.064 Y115.35 E.0058
G1 X109.064 Y115.35 F9000
G1 X108.699 Y115.442
G1 F6000
G1 X108.62 Y115.267 E.00467
G1 X108.459 Y114.695 E.01445
G1 X108.394 Y114.104 E.01446
G1 X108.47 Y113.27 E.02037
G1 X108.554 Y112.945 E.00817
G1 X108.879 Y112.178 E.02026
G1 X110.611 Y109.177 E.08428
G1 X110.971 Y108.671 E.01511
G1 X111.378 Y108.254 E.01417
G1 X111.818 Y107.927 E.01333
G1 X112.432 Y107.61 E.01681
G1 X113.022 Y107.449 E.01488
G1 X113.557 Y107.366 E.01317
G1 X117.232 Y107.355 E.08939
G1 X117.904 Y107.423 E.01643
G1 X118.462 Y107.574 E.01406
G1 X119.039 Y107.837 E.01542
G1 X119.528 Y108.186 E.01461
G1 X119.882 Y108.509 E.01166
G1 X120.388 Y109.177 E.02038
G1 X122.121 Y112.178 E.08429
G1 X122.414 Y112.84 E.01761
G1 X122.554 Y113.401 E.01406
G1 X122.607 Y114.044 E.01569
G1 X122.497 Y114.874 E.02037
G1 X122.189 Y115.688 E.02117
G1 X122.12 Y115.824 E.00371
G1 X120.276 Y119.002 E.08937
G1 X119.908 Y119.473 E.01454
G1 X119.469 Y119.876 E.0145
G1 X118.982 Y120.195 E.01416
G1 X118.429 Y120.441 E.01472
G1 X117.613 Y120.62 E.02032
G1 X117.232 Y120.642 E.00928
G1 X113.769 Y120.645 E.08423
G1 X113.205 Y120.582 E.0138
G1 X112.664 Y120.468 E.01345
G1 X112.129 Y120.25 E.01405
G1 X111.623 Y119.926 E.01461
G1 X111.162 Y119.542 E.01459
G1 X110.793 Y119.098 E.01404
G1 X110.669 Y118.92 E.00528
G1 X108.839 Y115.753 E.08897
G1 X108.724 Y115.497 E.00683
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X108.699 Y115.442 E-.0287
G1 X108.62 Y115.267 E-.0912
G1 X108.459 Y114.695 E-.28226
G1 X108.394 Y114.104 E-.28242
G1 X108.47 Y113.27 E-.39779
G1 X108.554 Y112.945 E-.15945
G1 X108.766 Y112.444 E-.25818
;WIPE_END
G1 X109.42 Y112.759 F9000
G1 X109.562 Y126.491
G1 X109.521 Y126.563
G1 X109.48 Y126.634
G1 X109.376 Y126.85
G1 X109.291 Y127.071
G1 X109.224 Y127.298
G1 X109.176 Y127.529
G1 X109.148 Y127.764
G1 X109.138 Y128
G1 X109.148 Y128.236
G1 X109.176 Y128.471
G1 X109.224 Y128.702
G1 X109.291 Y128.929
G1 X109.322 Y129.011
G1 X109.37 Y129.136
G1 X109.705 Y129.008
G1 E5 F2400
G1 F6000
G1 X109.617 Y128.803 E.00543
G1 X109.519 Y128.399 E.01011
G1 X109.487 Y128.015 E.00937
G1 X109.559 Y127.404 E.01496
G1 X109.829 Y126.726 E.01775
G1 X111.561 Y123.725 E.08428
G1 X111.821 Y123.37 E.0107
G1 X112.175 Y123.01 E.01228
G1 X112.615 Y122.733 E.01265
G1 X112.923 Y122.596 E.0082
G1 X113.487 Y122.468 E.01407
G1 X117.233 Y122.452 E.09112
G1 X117.616 Y122.481 E.00934
G1 X118.174 Y122.633 E.01407
G1 X118.583 Y122.839 E.01114
G1 X118.987 Y123.155 E.01248
G1 X119.424 Y123.704 E.01707
G1 X121.171 Y126.727 E.08493
G1 X121.35 Y127.106 E.0102
G1 X121.49 Y127.667 E.01406
G1 X121.509 Y128.126 E.01117
G1 X121.415 Y128.698 E.0141
G1 X121.171 Y129.274 E.01522
G1 X119.327 Y132.451 E.08935
G1 X119.042 Y132.794 E.01085
G1 X118.726 Y133.064 E.01011
G1 X118.371 Y133.28 E.01011
G1 X117.978 Y133.436 E.01028
G1 X117.408 Y133.542 E.0141
G1 X113.768 Y133.548 E.08854
G1 X113.124 Y133.465 E.01579
G1 X112.543 Y133.234 E.01521
G1 X112.039 Y132.871 E.01511
G1 X111.637 Y132.396 E.01514
G1 X109.789 Y129.204 E.08972
G1 X109.729 Y129.063 E.00373
G1 X109.729 Y129.063 F9000
G1 X109.373 Y129.151
;TYPE:Perimeter
G1 F6000
G1 X109.262 Y128.892 E.00685
G1 X109.154 Y128.429 E.01156
G1 X109.123 Y128.045 E.00937
G1 X109.196 Y127.359 E.01678
G1 X109.512 Y126.544 E.02126
G1 X111.245 Y123.543 E.08429
G1 X111.56 Y123.114 E.01295
G1 X111.94 Y122.73 E.01314
G1 X112.385 Y122.436 E.01297
G1 X112.842 Y122.24 E.0121
G1 X113.405 Y122.111 E.01405
G1 X114.368 Y122.087 E.02343
G1 X117.232 Y122.086 E.06966
G1 X117.712 Y122.129 E.01172
G1 X118.27 Y122.28 E.01406
G1 X118.793 Y122.54 E.01421
G1 X119.212 Y122.866 E.01291
G1 X119.712 Y123.478 E.01922
G1 X121.488 Y126.544 E.08619
G1 X121.705 Y127.017 E.01266
G1 X121.845 Y127.578 E.01406
G1 X121.877 Y128.096 E.01262
G1 X121.776 Y128.755 E.01622
G1 X121.487 Y129.457 E.01847
G1 X119.643 Y132.635 E.08937
G1 X119.324 Y133.029 E.01233
G1 X118.918 Y133.376 E.01299
G1 X118.509 Y133.618 E.01156
G1 X118.045 Y133.796 E.01209
G1 X117.471 Y133.902 E.0142
G1 X113.768 Y133.914 E.09007
G1 X113.076 Y133.827 E.01696
G1 X112.405 Y133.573 E.01745
G1 X111.823 Y133.166 E.01727
G1 X111.356 Y132.63 E.01729
G1 X109.473 Y129.387 E.09122
G1 X109.396 Y129.206 E.00478
G1 X109.396 Y129.206 F9000
G1 X109.04 Y129.295
G1 F6000
G1 X108.908 Y128.98 E.00831
G1 X108.79 Y128.459 E.01299
G1 X108.759 Y128.075 E.00937
G1 X108.833 Y127.314 E.0186
G1 X109.14 Y126.474 E.02175
G1 X110.928 Y123.36 E.08734
G1 X111.233 Y122.926 E.0129
G1 X111.64 Y122.51 E.01416
G1 X112.103 Y122.176 E.01389
G1 X112.584 Y121.943 E.013
G1 X113.103 Y121.805 E.01306
G1 X113.561 Y121.731 E.01128
G1 X114.375 Y121.721 E.0198
G1 X117.232 Y121.721 E.06949
G1 X117.808 Y121.776 E.01407
G1 X118.366 Y121.927 E.01406
G1 X118.873 Y122.163 E.0136
G1 X119.303 Y122.474 E.01291
G1 X119.594 Y122.735 E.00951
G1 X120.072 Y123.36 E.01914
G1 X121.804 Y126.361 E.08428
G1 X122.059 Y126.929 E.01514
G1 X122.199 Y127.489 E.01404
G1 X122.242 Y128.059 E.0139
G1 X122.137 Y128.815 E.01857
G1 X121.853 Y129.543 E.01901
G1 X119.959 Y132.818 E.09202
G1 X119.625 Y133.24 E.01309
G1 X119.229 Y133.599 E.013
G1 X118.78 Y133.889 E.013
G1 X118.29 Y134.103 E.01301
G1 X117.543 Y134.261 E.01857
G1 X117.377 Y134.276 E.00405
G1 X113.768 Y134.279 E.08779
G1 X113.028 Y134.19 E.01813
G1 X112.267 Y133.911 E.01972
G1 X111.606 Y133.461 E.01945
G1 X111.075 Y132.864 E.01943
G1 X110.986 Y132.737 E.00377
G1 X109.156 Y129.57 E.08897
G1 X109.064 Y129.35 E.0058
G1 X109.064 Y129.35 F9000
G1 X108.699 Y129.442
G1 F6000
G1 X108.62 Y129.267 E.00467
G1 X108.459 Y128.695 E.01445
G1 X108.394 Y128.104 E.01446
G1 X108.47 Y127.27 E.02037
G1 X108.554 Y126.945 E.00817
G1 X108.801 Y126.336 E.01599
G1 X110.611 Y123.177 E.08856
G1 X110.971 Y122.671 E.01511
G1 X111.378 Y122.254 E.01417
G1 X111.818 Y121.927 E.01333
G1 X112.432 Y121.61 E.01681
G1 X113.022 Y121.449 E.01488
G1 X113.557 Y121.366 E.01317
G1 X114.374 Y121.356 E.01987
G1 X117.232 Y121.355 E.06952
G1 X117.904 Y121.423 E.01643
G1 X118.462 Y121.574 E.01406
G1 X119.039 Y121.837 E.01542
G1 X119.528 Y122.186 E.01461
G1 X119.882 Y122.509 E.01166
G1 X120.388 Y123.177 E.02038
G1 X122.121 Y126.178 E.08429
G1 X122.414 Y126.84 E.01761
G1 X122.554 Y127.401 E.01406
G1 X122.607 Y128.044 E.01569
G1 X122.497 Y128.874 E.02037
G1 X122.189 Y129.688 E.02117
G1 X120.276 Y133.002 E.09308
G1 X119.906 Y133.474 E.01459
G1 X119.469 Y133.876 E.01444
G1 X118.972 Y134.201 E.01444
G1 X118.429 Y134.441 E.01444
G1 X117.61 Y134.62 E.02039
G1 X117.378 Y134.642 E.00567
G1 X113.768 Y134.645 E.08781
G1 X112.98 Y134.552 E.0193
G1 X112.664 Y134.468 E.00795
G1 X112.129 Y134.25 E.01405
G1 X111.39 Y133.756 E.02162
G1 X111.163 Y133.542 E.00759
G1 X110.793 Y133.098 E.01406
G1 X110.669 Y132.92 E.00528
G1 X108.839 Y129.753 E.08897
G1 X108.724 Y129.497 E.00683
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X108.699 Y129.442 E-.0287
G1 X108.62 Y129.267 E-.0912
G1 X108.459 Y128.695 E-.28226
G1 X108.394 Y128.104 E-.28242
G1 X108.47 Y127.27 E-.39779
G1 X108.554 Y126.945 E-.15945
G1 X108.759 Y126.442 E-.25818
;WIPE_END
G1 X109.138 Y114 F9000
G1 X109.148 Y113.764
G1 X109.176 Y113.529
G1 X109.224 Y113.298
G1 X109.251 Y113.206
G1 X109.37 Y101.136
G1 X109.705 Y101.008
G1 E5 F2400
G1 F6000
G1 X109.617 Y100.803 E.00543
G1 X109.519 Y100.399 E.01011
G1 X109.488 Y99.978 E.01027
G1 X109.559 Y99.404 E.01407
G1 X109.818 Y98.749 E.01713
G1 X111.561 Y95.726 E.08488
G1 X111.753 Y95.44 E.00838
G1 X112.038 Y95.129 E.01026
G1 X112.505 Y94.787 E.01408
G1 X112.923 Y94.596 E.01118
G1 X113.487 Y94.468 E.01407
G1 X117.233 Y94.452 E.09112
G1 X117.616 Y94.481 E.00934
G1 X118.174 Y94.633 E.01407
G1 X118.525 Y94.807 E.00953
G1 X119.034 Y95.199 E.01563
G1 X119.426 Y95.706 E.01559
G1 X121.171 Y98.727 E.08486
G1 X121.354 Y99.121 E.01057
G1 X121.49 Y99.667 E.01369
G1 X121.509 Y100.126 E.01117
G1 X121.415 Y100.698 E.0141
G1 X121.181 Y101.254 E.01467
G1 X119.327 Y104.451 E.08989
G1 X119.042 Y104.794 E.01085
G1 X118.726 Y105.064 E.01011
G1 X118.346 Y105.29 E.01075
G1 X118.01 Y105.427 E.00883
G1 X117.413 Y105.541 E.01478
G1 X113.768 Y105.548 E.08866
G1 X113.124 Y105.465 E.01579
G1 X112.543 Y105.234 E.01521
G1 X112.038 Y104.871 E.01513
G1 X111.619 Y104.371 E.01587
G1 X109.789 Y101.204 E.08897
G1 X109.729 Y101.063 E.00373
G1 X109.729 Y101.063 F9000
G1 X109.373 Y101.151
;TYPE:Perimeter
G1 F6000
G1 X109.262 Y100.892 E.00685
G1 X109.154 Y100.429 E.01156
G1 X109.125 Y99.933 E.01209
G1 X109.196 Y99.359 E.01407
G1 X109.479 Y98.612 E.01943
G1 X111.245 Y95.543 E.08613
G1 X111.481 Y95.195 E.01023
G1 X111.822 Y94.834 E.01208
G1 X112.289 Y94.493 E.01407
G1 X112.842 Y94.24 E.01479
G1 X113.405 Y94.111 E.01405
G1 X114.368 Y94.087 E.02343
G1 X117.233 Y94.086 E.06969
G1 X117.712 Y94.129 E.0117
G1 X118.27 Y94.28 E.01406
G1 X118.748 Y94.517 E.01298
G1 X119.257 Y94.909 E.01563
G1 X119.717 Y95.486 E.01795
G1 X121.488 Y98.544 E.08596
G1 X121.705 Y99.017 E.01266
G1 X121.845 Y99.578 E.01406
G1 X121.877 Y100.096 E.01262
G1 X121.776 Y100.755 E.01622
G1 X121.517 Y101.399 E.01688
G1 X119.643 Y104.635 E.09096
G1 X119.317 Y105.037 E.01259
G1 X118.933 Y105.366 E.0123
G1 X118.484 Y105.629 E.01266
G1 X118.142 Y105.768 E.00898
G1 X117.479 Y105.901 E.01645
G1 X117.231 Y105.91 E.00604
G1 X113.768 Y105.914 E.08423
G1 X113.076 Y105.827 E.01696
G1 X112.405 Y105.573 E.01745
G1 X111.822 Y105.166 E.01729
G1 X111.356 Y104.63 E.01728
G1 X109.473 Y101.387 E.09122
G1 X109.396 Y101.206 E.00478
G1 X109.396 Y101.206 F9000
G1 X109.04 Y101.295
G1 F6000
G1 X108.908 Y100.98 E.00831
G1 X108.79 Y100.459 E.01299
G1 X108.762 Y99.888 E.01391
G1 X108.833 Y99.314 E.01407
G1 X108.893 Y99.082 E.00583
G1 X109.14 Y98.474 E.01596
G1 X110.928 Y95.36 E.08734
G1 X111.21 Y94.95 E.0121
G1 X111.606 Y94.539 E.01388
G1 X112.072 Y94.198 E.01405
G1 X112.584 Y93.943 E.01391
G1 X113.324 Y93.755 E.01857
G1 X114.364 Y93.722 E.02531
G1 X117.233 Y93.721 E.06979
G1 X117.808 Y93.776 E.01405
G1 X118.366 Y93.927 E.01406
G1 X118.82 Y94.133 E.01213
G1 X119.48 Y94.62 E.01995
G1 X119.651 Y94.792 E.0059
G1 X120.009 Y95.265 E.01443
G1 X121.804 Y98.361 E.08705
G1 X122.059 Y98.929 E.01514
G1 X122.199 Y99.489 E.01404
G1 X122.239 Y99.989 E.0122
G1 X122.23 Y100.245 E.00623
G1 X122.137 Y100.815 E.01405
G1 X121.853 Y101.543 E.01901
G1 X119.959 Y104.818 E.09202
G1 X119.626 Y105.239 E.01306
G1 X119.229 Y105.599 E.01304
G1 X118.79 Y105.883 E.01272
G1 X118.273 Y106.11 E.01373
G1 X117.546 Y106.26 E.01806
G1 X117.231 Y106.276 E.00767
G1 X113.768 Y106.279 E.08423
G1 X113.253 Y106.219 E.01261
G1 X112.802 Y106.13 E.01118
G1 X112.267 Y105.911 E.01406
G1 X111.839 Y105.632 E.01243
G1 X111.444 Y105.308 E.01243
G1 X111.074 Y104.864 E.01406
G1 X110.986 Y104.737 E.00376
G1 X109.156 Y101.57 E.08897
G1 X109.064 Y101.35 E.0058
G1 X109.064 Y101.35 F9000
G1 X108.699 Y101.442
G1 F6000
G1 X108.62 Y101.267 E.00467
G1 X108.459 Y100.695 E.01445
G1 X108.394 Y100.104 E.01446
G1 X108.458 Y99.369 E.01795
G1 X108.554 Y98.945 E.01057
G1 X108.801 Y98.336 E.01599
G1 X110.611 Y95.177 E.08856
G1 X110.938 Y94.705 E.01397
G1 X111.39 Y94.244 E.0157
G1 X111.856 Y93.903 E.01405
G1 X112.432 Y93.61 E.01572
G1 X113.243 Y93.398 E.02039
G1 X114.359 Y93.356 E.02716
G1 X117.233 Y93.355 E.06991
G1 X117.904 Y93.423 E.01641
G1 X118.462 Y93.574 E.01406
G1 X118.982 Y93.805 E.01384
G1 X119.703 Y94.33 E.02169
G1 X119.942 Y94.571 E.00826
G1 X120.3 Y95.044 E.01443
G1 X122.121 Y98.178 E.08817
G1 X122.414 Y98.84 E.01761
G1 X122.554 Y99.401 E.01406
G1 X122.604 Y99.974 E.01399
G1 X122.591 Y100.304 E.00803
G1 X122.497 Y100.874 E.01405
G1 X122.189 Y101.688 E.02117
G1 X120.276 Y105.002 E.09308
G1 X119.908 Y105.473 E.01454
G1 X119.469 Y105.876 E.0145
G1 X118.982 Y106.195 E.01416
G1 X118.404 Y106.451 E.01538
G1 X117.613 Y106.62 E.01967
G1 X117.232 Y106.642 E.00928
G1 X113.769 Y106.645 E.08423
G1 X113.205 Y106.582 E.0138
G1 X112.664 Y106.468 E.01345
G1 X112.129 Y106.25 E.01405
G1 X111.623 Y105.927 E.0146
G1 X111.162 Y105.541 E.01463
G1 X110.793 Y105.097 E.01404
G1 X110.669 Y104.92 E.00526
G1 X108.839 Y101.753 E.08897
G1 X108.724 Y101.497 E.00683
G1 X108.206 Y101.139 F9000
G1 F6000
G1 X108.105 Y100.783 E.009
G1 X108.03 Y100.134 E.01589
G1 X108.095 Y99.324 E.01977
G1 X108.207 Y98.829 E.01234
G1 X108.562 Y97.995 E.02205
G1 X110.295 Y94.994 E.08429
G1 X110.667 Y94.46 E.01583
G1 X111.174 Y93.95 E.01749
G1 X111.64 Y93.608 E.01406
G1 X112.28 Y93.278 E.01751
G1 X113.161 Y93.042 E.02218
G1 X113.507 Y93.001 E.00847
G1 X117.233 Y92.989 E.09063
G1 X118 Y93.07 E.01876
G1 X118.557 Y93.221 E.01404
G1 X119.145 Y93.478 E.01561
G1 X119.926 Y94.04 E.0234
G1 X120.234 Y94.35 E.01063
G1 X120.705 Y94.994 E.01941
G1 X122.438 Y97.995 E.08429
G1 X122.769 Y98.751 E.02007
G1 X122.909 Y99.312 E.01406
G1 X122.97 Y99.959 E.01581
G1 X122.952 Y100.363 E.00984
G1 X122.858 Y100.933 E.01405
G1 X122.746 Y101.316 E.00971
G1 X122.525 Y101.832 E.01365
G1 X120.592 Y105.185 E.09414
G1 X120.189 Y105.706 E.01602
G1 X119.708 Y106.152 E.01596
G1 X119.173 Y106.507 E.01562
G1 X118.567 Y106.78 E.01617
G1 X118.006 Y106.919 E.01406
;WIDTH:0.408974
G1 X117.549 Y107.003 E.01158
G1 X118.235 Y107.134 E.0174
;WIDTH:0.399999
G1 X118.87 Y107.342 E.01625
G1 X119.439 Y107.654 E.01578
G1 X119.887 Y108.002 E.0138
G1 X120.169 Y108.284 E.0097
G1 X120.575 Y108.802 E.01601
G1 X120.705 Y108.994 E.00564
G1 X122.438 Y111.995 E.08429
G1 X122.769 Y112.751 E.02007
G1 X122.909 Y113.312 E.01406
G1 X122.972 Y114.029 E.01751
G1 X122.858 Y114.933 E.02216
G1 X122.746 Y115.316 E.00971
G1 X122.525 Y115.832 E.01365
G1 X120.592 Y119.185 E.09414
G1 X120.189 Y119.706 E.01602
G1 X119.708 Y120.152 E.01596
G1 X119.173 Y120.507 E.01562
G1 X118.567 Y120.78 E.01617
G1 X118.006 Y120.919 E.01406
;WIDTH:0.408972
G1 X117.549 Y121.003 E.01158
G1 X118.235 Y121.134 E.0174
;WIDTH:0.399999
G1 X118.87 Y121.342 E.01625
G1 X119.439 Y121.654 E.01578
G1 X119.887 Y122.002 E.0138
G1 X120.169 Y122.284 E.0097
G1 X120.575 Y122.802 E.01601
G1 X120.705 Y122.994 E.00564
G1 X122.438 Y125.995 E.08429
G1 X122.769 Y126.751 E.02007
G1 X122.909 Y127.312 E.01406
G1 X122.972 Y128.029 E.01751
G1 X122.858 Y128.933 E.02216
G1 X122.746 Y129.316 E.00971
G1 X122.525 Y129.832 E.01365
G1 X120.592 Y133.185 E.09414
G1 X120.188 Y133.708 E.01607
G1 X119.708 Y134.152 E.0159
G1 X119.163 Y134.513 E.0159
G1 X118.567 Y134.78 E.01589
G1 X117.677 Y134.98 E.02219
G1 X117.378 Y135.007 E.0073
G1 X113.768 Y135.011 E.08781
G1 X112.933 Y134.915 E.02044
G1 X112.526 Y134.807 E.01024
G1 X111.99 Y134.588 E.01408
G1 X111.64 Y134.392 E.00976
G1 X111.174 Y134.051 E.01405
G1 X110.882 Y133.776 E.00976
G1 X110.512 Y133.332 E.01406
G1 X110.353 Y133.103 E.00678
G1 X108.523 Y129.936 E.08897
G1 X108.284 Y129.412 E.01401
G1 X108.105 Y128.783 E.01591
G1 X108.03 Y128.134 E.01589
G1 X108.107 Y127.225 E.02219
G1 X108.216 Y126.807 E.01051
G1 X108.463 Y126.199 E.01596
G1 X108.562 Y125.995 E.00552
G1 X110.295 Y122.994 E.08429
G1 X110.708 Y122.416 E.01728
G1 X111.117 Y121.999 E.01421
G1 X111.615 Y121.623 E.01518
G1 X112.28 Y121.278 E.01822
G1 X112.941 Y121.092 E.0167
;WIDTH:0.417928
G1 X113.457 Y120.993 E.01341
G1 X112.933 Y120.915 E.01352
;WIDTH:0.399999
G1 X112.526 Y120.807 E.01024
G1 X111.99 Y120.588 E.01408
G1 X111.64 Y120.392 E.00976
G1 X111.174 Y120.05 E.01406
G1 X110.814 Y119.695 E.0123
G1 X110.353 Y119.103 E.01825
G1 X108.523 Y115.936 E.08897
G1 X108.284 Y115.412 E.01401
G1 X108.105 Y114.783 E.01591
G1 X108.03 Y114.134 E.01589
G1 X108.107 Y113.225 E.02219
G1 X108.216 Y112.807 E.01051
G1 X108.463 Y112.199 E.01596
G1 X108.562 Y111.995 E.00552
G1 X110.295 Y108.994 E.08429
G1 X110.708 Y108.416 E.01728
G1 X111.117 Y107.999 E.01421
G1 X111.615 Y107.623 E.01518
G1 X112.28 Y107.278 E.01822
G1 X112.941 Y107.092 E.0167
;WIDTH:0.417928
G1 X113.457 Y106.993 E.01341
G1 X112.933 Y106.915 E.01352
;WIDTH:0.399999
G1 X112.526 Y106.807 E.01024
G1 X111.99 Y106.588 E.01408
G1 X111.64 Y106.392 E.00976
G1 X111.174 Y106.05 E.01406
G1 X110.814 Y105.695 E.0123
G1 X110.353 Y105.102 E.01827
G1 X108.523 Y101.936 E.08895
G1 X108.284 Y101.412 E.01401
G1 X108.223 Y101.196 E.00546
G1 E-5 F3600
G1 X108.223 Y101.196 F9000
G1 X109.148 Y114.236
G1 X109.176 Y114.471
G1 X109.224 Y114.702
G1 X109.291 Y114.929
G1 X109.376 Y115.15
G1 X109.48 Y115.366
G1 X110.393 Y116.949
G1 X111.266 Y118.459
G1 X111.329 Y118.565
G1 X111.466 Y118.76
G1 X111.617 Y118.942
G1 X111.782 Y119.111
G1 X111.961 Y119.266
G1 X112.152 Y119.406
G1 X112.353 Y119.529
G1 X112.564 Y119.636
G1 X112.783 Y119.726
G1 X113.008 Y119.797
G1 E5 F2400
;WIDTH:0.408972
G1 F6000
G1 X117.232 Y120.998 E.0079
;WIDTH:0.381856
G1 X114.373 Y121 E.06609
;WIDTH:0.386734
G1 X113.769 Y121.004 E.01416
;WIDTH:0.417928
G1 X113.457 Y120.993 E.00797
G1 E-5 F3600
G1 X113.457 Y120.993 F9000
G1 X117.877 Y119.825
G1 X118.105 Y119.763
G1 X118.327 Y119.683
G1 X118.542 Y119.585
G1 X118.749 Y119.469
G1 X118.945 Y119.338
G1 X119.13 Y119.19
G1 X119.302 Y119.028
G1 X119.461 Y118.853
G1 X119.604 Y118.665
G1 X119.718 Y118.488
G1 X120.512 Y117.115
G1 X121.48 Y115.436
G1 X121.574 Y115.261
G1 X121.669 Y115.04
G1 X121.745 Y114.816
G1 X121.802 Y114.587
G1 X121.84 Y114.354
G1 X121.86 Y114.118
G1 X121.86 Y113.882
G1 X121.84 Y113.646
G1 X121.802 Y113.413
G1 X121.745 Y113.184
G1 X121.669 Y112.96
G1 X121.574 Y112.739
G1 X121.48 Y112.564
G1 X120.703 Y111.217
G1 X119.718 Y109.512
G1 X119.604 Y109.335
G1 X119.461 Y109.147
G1 E5 F2400
;WIDTH:0.408974
G1 F6000
G1 X117.232 Y106.998 E.0079
;WIDTH:0.381858
G1 X114.373 Y107 E.06609
;WIDTH:0.386732
G1 X113.769 Y107.004 E.01416
;WIDTH:0.417928
G1 X113.457 Y106.993 E.00797
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.769 Y107.004 E-.14829
G1 X114.373 Y107 E-.28691
G1 X116.615 Y106.999 E-1.0648
;WIPE_END
G1 X105.692 Y103.076 F9000
G1 X105.674 Y103.499
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.567 Y103.424 E.00318
G1 X105.343 Y103.424 E.00545
G1 X105.343 Y98.824 E.11189
G1 X105.567 Y98.824 E.00545
G1 X105.717 Y98.746 E.00411
G1 X105.75 Y98.642 E.00265
G1 X105.75 Y92.023 E.161
G1 X105.686 Y91.884 E.00372
G1 X104.692 Y91.04 E.03172
G1 X104.248 Y90.638 E.01457
G1 X104.147 Y90.492 E.00432
G1 X104.423 Y90.196 E.00984
G1 X105.574 Y89.21 E.03687
G1 X125.426 Y89.21 E.48288
G1 X126.694 Y90.305 E.04075
G1 X126.867 Y90.492 E.0062
G1 X126.705 Y90.686 E.00615
G1 X125.314 Y91.885 E.04467
G1 X125.25 Y92.023 E.0037
G1 X125.261 Y98.703 E.16248
G1 X125.433 Y98.824 E.00512
G1 X125.657 Y98.824 E.00545
G1 X125.657 Y103.424 E.11189
G1 X125.433 Y103.424 E.00545
G1 X125.279 Y103.508 E.00427
G1 X125.25 Y103.607 E.00251
G1 X125.25 Y135.977 E.78737
G1 X125.314 Y136.116 E.00372
G1 X126.308 Y136.96 E.03172
G1 X126.752 Y137.362 E.01457
G1 X126.853 Y137.508 E.00432
G1 X126.577 Y137.804 E.00984
G1 X125.426 Y138.79 E.03687
G1 X105.574 Y138.79 E.48288
G1 X104.306 Y137.695 E.04075
G1 X104.14 Y137.518 E.0059
G1 X104.295 Y137.314 E.00623
G1 X105.686 Y136.115 E.04467
G1 X105.75 Y135.977 E.0037
G1 X105.75 Y103.607 E.78737
G1 X105.739 Y103.544 E.00156
G1 X105.724 Y103.534 E.00044
G1 X105.724 Y103.534 F9000
G1 X105.911 Y103.258
;TYPE:Perimeter
G1 F6000
G1 X105.709 Y103.136 E.00574
G1 X105.709 Y99.116 E.09778
G1 X106.044 Y98.913 E.00953
G1 X106.116 Y98.642 E.00682
G1 X106.116 Y92.023 E.161
G1 X106.078 Y91.824 E.00493
G1 X105.922 Y91.605 E.00654
G1 X104.637 Y90.497 E.04127
G1 X105.709 Y89.576 E.03438
G1 X125.29 Y89.576 E.47629
G1 X126.361 Y90.5 E.03441
G1 X125.075 Y91.608 E.04129
G1 X124.921 Y91.826 E.00649
G1 X124.884 Y92.023 E.00488
G1 X124.884 Y98.18 E.14976
G1 X124.901 Y98.775 E.01448
G1 X124.983 Y98.956 E.00483
G1 X125.291 Y99.116 E.00844
G1 X125.291 Y103.136 E.09778
G1 X124.946 Y103.355 E.00994
G1 X124.884 Y103.607 E.00631
G1 X124.884 Y135.977 E.78737
G1 X124.922 Y136.176 E.00493
G1 X125.078 Y136.395 E.00654
G1 X126.363 Y137.503 E.04127
G1 X125.291 Y138.424 E.03438
G1 X105.71 Y138.424 E.47629
G1 X104.639 Y137.5 E.03441
G1 X105.925 Y136.392 E.04129
G1 X106.079 Y136.174 E.00649
G1 X106.116 Y135.977 E.00488
G1 X106.116 Y103.607 E.78737
G1 X106.045 Y103.339 E.00674
G1 X105.963 Y103.289 E.00234
G1 X105.963 Y103.289 F9000
G1 X106.154 Y103.012
G1 F6000
G1 X106.075 Y102.969 E.00219
G1 X106.075 Y99.291 E.08946
G1 X106.316 Y99.165 E.00661
G1 X106.442 Y98.908 E.00696
G1 X106.481 Y98.642 E.00654
G1 X106.481 Y92.023 E.161
G1 X106.419 Y91.692 E.00819
G1 X106.159 Y91.327 E.0109
G1 X105.189 Y90.503 E.03096
G1 X105.844 Y89.942 E.02098
G1 X125.154 Y89.942 E.4697
G1 X125.801 Y90.5 E.02078
G1 X124.836 Y91.331 E.03098
G1 X124.58 Y91.694 E.0108
G1 X124.519 Y92.023 E.00814
G1 X124.519 Y98.18 E.14976
G1 X124.546 Y98.863 E.01663
G1 X124.683 Y99.165 E.00807
G1 X124.925 Y99.291 E.00664
G1 X124.925 Y102.969 E.08946
G1 X124.666 Y103.11 E.00717
G1 X124.575 Y103.292 E.00495
G1 X124.519 Y103.607 E.00778
G1 X124.519 Y135.977 E.78737
G1 X124.581 Y136.308 E.00819
G1 X124.841 Y136.673 E.0109
G1 X125.811 Y137.497 E.03096
G1 X125.156 Y138.058 E.02098
G1 X105.846 Y138.058 E.4697
G1 X105.199 Y137.5 E.02078
G1 X106.164 Y136.669 E.03098
G1 X106.42 Y136.306 E.0108
G1 X106.481 Y135.977 E.00814
G1 X106.481 Y103.607 E.78737
G1 X106.453 Y103.38 E.00556
G1 X106.334 Y103.11 E.00718
G1 X106.207 Y103.04 E.00353
G1 X106.207 Y103.04 F9000
G1 X106.44 Y102.767
G1 F6000
G1 X106.44 Y99.466 E.08029
G1 X106.616 Y99.375 E.00482
G1 X106.791 Y99.015 E.00974
G1 X106.847 Y98.642 E.00917
G1 X106.847 Y92.023 E.161
G1 X106.76 Y91.559 E.01148
G1 X106.396 Y91.048 E.01526
G1 X105.753 Y90.502 E.02052
G1 X105.979 Y90.307 E.00726
G1 X125.018 Y90.307 E.4631
G1 X125.241 Y90.5 E.00717
G1 X124.598 Y91.054 E.02064
G1 X124.239 Y91.562 E.01513
G1 X124.153 Y92.023 E.01141
G1 X124.153 Y98.626 E.16061
G1 X124.197 Y98.974 E.00853
G1 X124.383 Y99.374 E.01073
G1 X124.56 Y99.466 E.00485
G1 X124.56 Y102.802 E.08114
G1 X124.359 Y102.911 E.00556
G1 X124.232 Y103.166 E.00693
G1 X124.153 Y103.607 E.0109
G1 X124.153 Y135.977 E.78737
G1 X124.24 Y136.441 E.01148
G1 X124.604 Y136.952 E.01526
G1 X125.247 Y137.498 E.02052
G1 X125.021 Y137.693 E.00726
G1 X105.982 Y137.693 E.4631
G1 X105.759 Y137.5 E.00717
G1 X106.402 Y136.946 E.02064
G1 X106.761 Y136.438 E.01513
G1 X106.847 Y135.977 E.01141
G1 X106.847 Y103.607 E.78737
G1 X106.807 Y103.289 E.0078
G1 X106.641 Y102.911 E.01004
G1 X106.463 Y102.814 E.00493
G1 X106.463 Y102.814 F9000
G1 X106.806 Y102.494
G1 F6000
G1 X106.806 Y99.641 E.0694
G1 X106.916 Y99.584 E.00301
G1 X107.141 Y99.122 E.0125
G1 X107.213 Y98.642 E.01181
G1 X107.213 Y92.023 E.161
G1 X107.1 Y91.426 E.01478
G1 X106.632 Y90.769 E.01962
G1 X106.519 Y90.673 E.00361
G1 X124.479 Y90.673 E.43686
G1 X124.359 Y90.777 E.00386
G1 X123.898 Y91.43 E.01944
G1 X123.787 Y92.023 E.01467
G1 X123.787 Y98.642 E.161
G1 X123.882 Y99.192 E.01358
G1 X124.084 Y99.584 E.01073
G1 X124.194 Y99.641 E.00301
G1 X124.194 Y102.635 E.07283
G1 X124.052 Y102.712 E.00393
G1 X123.888 Y103.04 E.00892
G1 X123.787 Y103.607 E.01401
G1 X123.787 Y135.977 E.78737
G1 X123.9 Y136.574 E.01478
G1 X124.368 Y137.231 E.01962
G1 X124.481 Y137.327 E.00361
G1 X106.521 Y137.327 E.43686
G1 X106.641 Y137.223 E.00386
G1 X107.102 Y136.57 E.01944
G1 X107.213 Y135.977 E.01467
G1 X107.213 Y103.607 E.78737
G1 X107.161 Y103.198 E.01003
G1 X106.948 Y102.712 E.01291
G1 X106.806 Y102.635 E.00393
G1 X106.806 Y102.554 E.00197
G1 X106.806 Y102.554 F9000
G1 X107.312 Y102.39
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X107.796 Y101.907 E.01663
G1 X107.639 Y101.528 E.00998
G1 X107.312 Y101.854 E.01123
G1 X107.312 Y101.854 F9000
G1 X107.803 Y100.877
;TYPE:Solid infill
;WIDTH:0.489846
G1 F1200
G1 X107.929 Y101.22 E.01107
;WIDTH:0.460321
G1 X108.055 Y101.564 E.01038
;WIDTH:0.430796
G1 X108.324 Y102.152 E.01705
;WIDTH:0.411828
G1 X110.112 Y105.237 E.08954
;WIDTH:0.417976
G1 X110.683 Y105.964 E.02359
;WIDTH:0.413976
G1 X111.053 Y106.31 E.01279
G1 X111.685 Y106.744 E.01936
;WIDTH:0.444862
G1 X111.726 Y106.786 E.0016
;WIDTH:0.490173
G1 X111.767 Y106.828 E.00178
;WIDTH:0.535484
G1 X111.808 Y106.87 E.00196
;WIDTH:0.580796
G1 X111.849 Y106.912 E.00213
;WIDTH:0.626107
G1 X111.89 Y106.954 E.00231
;WIDTH:0.671418
G1 X111.931 Y106.996 E.00249
G1 X111.895 Y107.037 E.00231
;WIDTH:0.627389
G1 X111.86 Y107.079 E.00216
;WIDTH:0.58336
G1 X111.825 Y107.12 E.00197
;WIDTH:0.539331
G1 X111.789 Y107.161 E.00183
;WIDTH:0.495302
G1 X111.754 Y107.202 E.00165
;WIDTH:0.451273
G1 X111.718 Y107.244 E.00153
;WIDTH:0.43346
G1 X110.992 Y107.748 E.02346
G1 X110.418 Y108.339 E.02187
;WIDTH:0.415548
G1 X110.056 Y108.859 E.01607
;WIDTH:0.411312
G1 X108.312 Y111.873 E.08732
;WIDTH:0.419278
G1 X107.937 Y112.753 E.02449
;WIDTH:0.417973
G1 X107.829 Y113.371 E.01601
;WIDTH:0.37358
G1 X107.776 Y113.985 E.01391
;WIDTH:0.364484
G1 X107.799 Y114.446 E.01014
;WIDTH:0.412683
G1 X107.781 Y114.496 E.00134
;WIDTH:0.460882
G1 X107.764 Y114.547 E.00153
;WIDTH:0.509081
G1 X107.746 Y114.597 E.00168
;WIDTH:0.557279
G1 X107.729 Y114.648 E.00187
G1 X107.765 Y114.817 E.00601
G1 X107.566 Y114.74 E.00742
G1 X107.541 Y114.669 E.00262
;WIDTH:0.509081
G1 X107.517 Y114.599 E.00234
;WIDTH:0.460882
G1 X107.493 Y114.528 E.00213
;WIDTH:0.412683
G1 X107.469 Y114.457 E.00189
;WIDTH:0.364484
G1 X107.462 Y113.968 E.01074
;WIDTH:0.37358
G1 X107.474 Y113.419 E.01239
G1 X107.617 Y113.306 E.00411
;WIDTH:0.406426
G1 X107.85 Y112.901 E.01156
G1 X107.85 Y112.901 F9000
;WIDTH:0.557142
G1 F1200
G1 X107.806 Y114.896 E.0031
;WIDTH:0.509867
G1 X107.847 Y114.974 E.00279
;WIDTH:0.462592
G1 X108.057 Y115.567 E.01792
;WIDTH:0.430858
G1 X108.324 Y116.152 E.01696
;WIDTH:0.411826
G1 X110.112 Y119.237 E.08954
;WIDTH:0.417956
G1 X110.683 Y119.965 E.02361
;WIDTH:0.413966
G1 X111.053 Y120.31 E.01278
G1 X111.685 Y120.744 E.01936
;WIDTH:0.445961
G1 X111.726 Y120.787 E.00163
;WIDTH:0.492374
G1 X111.768 Y120.83 E.00183
;WIDTH:0.538786
G1 X111.809 Y120.873 E.00199
;WIDTH:0.585199
G1 X111.851 Y120.915 E.00218
;WIDTH:0.631612
G1 X111.893 Y120.958 E.00239
;WIDTH:0.678024
G1 X111.934 Y121.001 E.00254
G1 X111.916 Y121.029 E.00143
;WIDTH:0.641199
G1 X111.899 Y121.056 E.00129
;WIDTH:0.604374
G1 X111.881 Y121.083 E.00123
;WIDTH:0.567548
G1 X111.825 Y121.131 E.00262
;WIDTH:0.523719
G1 X111.77 Y121.179 E.00238
;WIDTH:0.479889
G1 X111.714 Y121.227 E.00219
;WIDTH:0.43606
G1 X111.659 Y121.274 E.00193
;WIDTH:0.414766
G1 X110.986 Y121.741 E.02073
;WIDTH:0.415524
G1 X110.418 Y122.339 E.02091
G1 X110.056 Y122.859 E.01607
;WIDTH:0.411314
G1 X108.312 Y125.873 E.08732
;WIDTH:0.419276
G1 X107.941 Y126.742 E.02419
G1 X107.849 Y127.199 E.01194
;WIDTH:0.370728
G1 X107.786 Y127.78 E.01308
;WIDTH:0.365334
G1 X107.8 Y128.428 E.01427
;WIDTH:0.405495
G1 X107.784 Y128.475 E.00123
;WIDTH:0.445655
G1 X107.768 Y128.521 E.00133
;WIDTH:0.485816
G1 X107.753 Y128.567 E.00145
;WIDTH:0.525977
G1 X107.737 Y128.613 E.00159
;WIDTH:0.566137
G1 X107.721 Y128.659 E.00172
G1 X107.752 Y128.809 E.00542
G1 X107.57 Y128.736 E.00694
G1 X107.55 Y128.677 E.0022
;WIDTH:0.525977
G1 X107.53 Y128.619 E.00201
;WIDTH:0.485816
G1 X107.51 Y128.561 E.00184
;WIDTH:0.445655
G1 X107.49 Y128.502 E.0017
;WIDTH:0.405495
G1 X107.47 Y128.444 E.00151
;WIDTH:0.365334
G1 X107.463 Y128.139 E.00672
;WIDTH:0.370728
G1 X107.472 Y127.418 E.01613
G1 X107.616 Y127.305 E.0041
;WIDTH:0.405624
G1 X107.85 Y126.9 E.01155
G1 X107.85 Y126.9 F9000
;WIDTH:0.557104
G1 F1200
G1 X107.782 Y128.864 E.00218
;WIDTH:0.523362
G1 X107.813 Y128.92 E.00208
;WIDTH:0.48962
G1 X107.844 Y128.976 E.00194
;WIDTH:0.455878
G1 X108.057 Y129.567 E.01762
;WIDTH:0.430846
G1 X108.324 Y130.152 E.01696
;WIDTH:0.411826
G1 X110.112 Y133.237 E.08954
;WIDTH:0.418188
G1 X110.697 Y133.984 E.02423
;WIDTH:0.434892
G1 X111.057 Y134.299 E.01275
G1 X111.465 Y134.607 E.01362
;WIDTH:0.411226
G1 X111.89 Y134.85 E.01227
G1 X112.414 Y135.064 E.01419
G1 X112.902 Y135.189 E.01263
;WIDTH:0.411454
G1 X113.776 Y135.291 E.02207
;WIDTH:0.415044
G1 X117.402 Y135.28 E.09183
;WIDTH:0.400572
G1 X118.317 Y135.135 E.02257
;WIDTH:0.422954
G1 X118.872 Y134.955 E.01508
G1 X119.407 Y134.686 E.01548
;WIDTH:0.422842
G1 X119.792 Y134.429 E.01196
G1 X120.334 Y133.946 E.01876
;WIDTH:0.408248
G1 X120.835 Y133.322 E.0199
;WIDTH:0.419698
G1 X122.717 Y130.065 E.09643
G1 X122.835 Y129.825 E.00686
;WIDTH:0.417078
G1 X123.06 Y129.249 E.01574
G1 E-5 F3600
G1 X123.038 Y98.696 F9000
G1 E5 F2400
;WIDTH:0.437989
G1 F1200
G1 X123.135 Y99.02 E.00908
;WIDTH:0.472668
G1 X123.204 Y99.304 E.00852
;WIDTH:0.507838
G1 X123.272 Y99.587 E.00917
;WIDTH:0.553114
G1 X123.324 Y100.095 E.01762
G1 X123.278 Y100.301 E.00728
;WIDTH:0.515222
G1 X123.232 Y100.507 E.00675
;WIDTH:0.47733
G1 X123.185 Y100.713 E.00623
;WIDTH:0.439438
G1 X123.139 Y100.919 E.00569
;WIDTH:0.414582
G1 X123.058 Y101.253 E.00869
G1 X123.276 Y100.981 E.00882
;WIDTH:0.401546
G1 X123.508 Y100.926 E.00582
;WIDTH:0.399999
G1 X123.614 Y100.942 E.00261
;WIDTH:0.403135
G1 X123.758 Y101.053 E.00446
;WIDTH:0.430214
G1 X123.905 Y101.334 E.00835
G1 X123.92 Y100.677 E.01731
;WIDTH:0.448126
G1 X123.896 Y100.497 E.005
;WIDTH:0.496252
G1 X123.872 Y100.317 E.00558
;WIDTH:0.544378
G1 X123.848 Y100.137 E.00616
;WIDTH:0.557527
G1 X123.841 Y99.819 E.01107
G1 X123.668 Y99.551 E.0111
;WIDTH:0.532362
G1 X123.6 Y99.249 E.01026
;WIDTH:0.48493
G1 X123.531 Y98.948 E.00926
;WIDTH:0.437498
G1 X123.514 Y98.804 E.00389
G1 X123.219 Y98.715 E.00826
;WIDTH:0.438253
G1 X122.986 Y98.52 E.00816
;WIDTH:0.438362
G1 X122.954 Y98.45 E.00207
;WIDTH:0.435476
G1 X122.676 Y97.848 E.01769
;WIDTH:0.411326
G1 X120.945 Y94.859 E.08662
;WIDTH:0.40251
G1 X120.933 Y94.84 E.00055
;WIDTH:0.429214
G1 X120.583 Y94.351 E.0158
G1 X120.102 Y93.835 E.01853
;WIDTH:0.425428
G1 X119.568 Y93.417 E.01764
;WIDTH:0.408616
G1 X118.91 Y93.062 E.01861
;WIDTH:0.425474
G1 X117.933 Y92.776 E.02649
G1 X117.229 Y92.714 E.01839
;WIDTH:0.410952
G1 X114.353 Y92.711 E.07205
;WIDTH:0.41968
G1 X113.783 Y92.713 E.01461
G1 X113.187 Y92.761 E.01533
;WIDTH:0.402858
G1 X112.514 Y92.909 E.01689
;WIDTH:0.417594
G1 X111.709 Y93.248 E.02227
;WIDTH:0.431542
G1 X111.237 Y93.557 E.01491
G1 X110.903 Y93.824 E.0113
;WIDTH:0.416172
G1 X110.415 Y94.336 E.01797
;WIDTH:0.407282
G1 X110.113 Y94.764 E.013
;WIDTH:0.411654
G1 X108.311 Y97.875 E.09024
;WIDTH:0.445878
G1 X107.929 Y98.768 E.02659
;WIDTH:0.438904
G1 X107.813 Y99.304 E.01476
;WIDTH:0.478344
G1 X107.77 Y99.482 E.00541
;WIDTH:0.517783
G1 X107.727 Y99.661 E.00592
;WIDTH:0.557222
G1 X107.684 Y99.839 E.00637
;WIDTH:0.568288
G1 X107.697 Y100.421 E.02068
G1 X107.75 Y100.649 E.00831
;WIDTH:0.529067
G1 X107.803 Y100.877 E.0077
;WIDTH:0.518579
G1 X107.726 Y100.762 E.00446
;WIDTH:0.568288
G1 X107.559 Y100.699 E.00634
G1 X107.337 Y100.727 E.00795
G1 X107.164 Y100.89 E.00844
G1 X107.159 Y99.82 E.03801
;WIDTH:0.557222
G1 X107.237 Y99.732 E.00409
G1 X107.297 Y99.568 E.00607
;WIDTH:0.522954
G1 X107.358 Y99.403 E.00572
;WIDTH:0.488685
G1 X107.418 Y99.238 E.00531
;WIDTH:0.454416
G1 X107.482 Y98.807 E.01218
;WIDTH:0.435658
G1 X107.748 Y98.746 E.00729
;WIDTH:0.441472
G1 X107.922 Y98.579 E.00653
G1 E-5 F3600
G1 X107.922 Y98.579 F9000
G1 X107.097 Y101.362
G1 E5 F2400
;WIDTH:0.434356
G1 F1200
G1 X107.096 Y101.399 E.00098
;WIDTH:0.430936
G1 X107.096 Y102.488 E.02873
G1 E-5 F3600
G1 X107.096 Y102.488 F9000
G1 X112.353 Y105.529
G1 X112.564 Y105.636
G1 X112.783 Y105.726
G1 X113.008 Y105.797
G1 X113.239 Y105.849
G1 X113.473 Y105.883
G1 X113.571 Y105.889
G1 X113.75 Y105.897
G1 X115.5 Y105.898
G1 X117.245 Y105.897
G1 X117.407 Y105.893
G1 X117.644 Y105.869
G1 X117.877 Y105.825
G1 X118.105 Y105.763
G1 X118.327 Y105.683
G1 X118.542 Y105.585
G1 X118.749 Y105.469
G1 X118.945 Y105.338
G1 X119.13 Y105.19
G1 X119.302 Y105.028
G1 E5 F2400
;WIDTH:0.422948
G1 F1200
G1 X122.831 Y101.824 E.01588
G1 X122.674 Y102.152 E.0094
;WIDTH:0.408236
G1 X120.835 Y105.322 E.09115
G1 X120.304 Y105.975 E.02093
;WIDTH:0.39522
G1 X119.704 Y106.496 E.01908
;WIDTH:0.425556
G1 X119.271 Y106.764 E.01325
;WIDTH:0.471219
G1 X119.234 Y106.812 E.00176
;WIDTH:0.516881
G1 X119.197 Y106.859 E.00192
;WIDTH:0.562543
G1 X119.159 Y106.907 E.00215
;WIDTH:0.608206
G1 X119.122 Y106.954 E.00228
;WIDTH:0.653868
G1 X119.084 Y107.001 E.00249
G1 X119.126 Y107.051 E.00269
;WIDTH:0.606247
G1 X119.167 Y107.101 E.00246
;WIDTH:0.558625
G1 X119.208 Y107.151 E.00226
;WIDTH:0.511003
G1 X119.249 Y107.201 E.00205
;WIDTH:0.463382
G1 X119.29 Y107.251 E.00185
;WIDTH:0.42222
G1 X119.807 Y107.58 E.01581
G1 X120.365 Y108.096 E.01961
;WIDTH:0.427758
G1 X120.816 Y108.664 E.01898
G1 X120.945 Y108.859 E.00612
;WIDTH:0.411326
G1 X122.676 Y111.847 E.0866
;WIDTH:0.430064
G1 X122.943 Y112.432 E.01693
G1 X123.059 Y112.744 E.00876
;WIDTH:0.421844
G1 X123.094 Y112.945 E.00526
;WIDTH:0.404205
G1 X123.165 Y113.384 E.01094
;WIDTH:0.368313
G1 X123.21 Y113.646 E.00591
;WIDTH:0.361514
G1 X123.205 Y114.383 E.01604
;WIDTH:0.390192
G1 X123.122 Y114.991 E.01453
;WIDTH:0.417076
G1 X123.06 Y115.249 E.00676
G1 X123.37 Y114.817 E.01354
;WIDTH:0.377954
G1 X123.524 Y114.72 E.00416
G1 X123.534 Y113.648 E.0245
;WIDTH:0.368313
G1 X123.529 Y113.417 E.00513
G1 X123.385 Y113.304 E.00407
;WIDTH:0.393643
G1 X123.225 Y113.034 E.0075
;WIDTH:0.418973
G1 X123.065 Y112.765 E.00801
G1 E-5 F3600
G1 X123.065 Y112.765 F9000
G1 X123.06 Y115.249
G1 E5 F2400
;WIDTH:0.422958
G1 F1200
G1 X122.831 Y115.823 E.01598
G1 X122.674 Y116.152 E.00942
;WIDTH:0.408236
G1 X120.835 Y119.322 E.09115
G1 X120.304 Y119.975 E.02093
;WIDTH:0.395218
G1 X119.704 Y120.496 E.01908
;WIDTH:0.425558
G1 X119.271 Y120.764 E.01325
;WIDTH:0.471219
G1 X119.234 Y120.812 E.00176
;WIDTH:0.516881
G1 X119.197 Y120.859 E.00192
;WIDTH:0.562542
G1 X119.159 Y120.907 E.00215
;WIDTH:0.608203
G1 X119.122 Y120.954 E.00228
;WIDTH:0.653864
G1 X119.084 Y121.001 E.00249
G1 X119.126 Y121.051 E.00269
;WIDTH:0.606245
G1 X119.167 Y121.101 E.00246
;WIDTH:0.558627
G1 X119.208 Y121.151 E.00226
;WIDTH:0.511008
G1 X119.249 Y121.201 E.00205
;WIDTH:0.463389
G1 X119.29 Y121.251 E.00185
;WIDTH:0.420452
G1 X119.807 Y121.58 E.01574
G1 X120.361 Y122.093 E.01939
;WIDTH:0.427748
G1 X120.816 Y122.664 E.01911
G1 X120.945 Y122.859 E.00612
;WIDTH:0.411324
G1 X122.676 Y125.847 E.0866
;WIDTH:0.430066
G1 X122.943 Y126.432 E.01693
G1 X123.059 Y126.744 E.00876
;WIDTH:0.421842
G1 X123.094 Y126.945 E.00526
;WIDTH:0.404204
G1 X123.165 Y127.384 E.01094
;WIDTH:0.368315
G1 X123.21 Y127.646 E.00591
;WIDTH:0.361514
G1 X123.205 Y128.383 E.01604
;WIDTH:0.390191
G1 X123.122 Y128.991 E.01453
;WIDTH:0.417078
G1 X123.06 Y129.249 E.00676
G1 X123.37 Y128.817 E.01354
;WIDTH:0.377954
G1 X123.524 Y128.72 E.00416
G1 X123.534 Y127.648 E.0245
;WIDTH:0.368315
G1 X123.529 Y127.417 E.00513
G1 X123.385 Y127.304 E.00407
;WIDTH:0.393643
G1 X123.225 Y127.034 E.0075
;WIDTH:0.418971
G1 X123.065 Y126.765 E.00801
G1 E-5 F3600
G1 X123.065 Y126.765 F9000
G1 X123.823 Y102.889
G1 E5 F2400
;WIDTH:0.402636
G1 F1200
G1 X123.864 Y102.688 E.00503
;WIDTH:0.430936
G1 X123.904 Y102.488 E.00538
G1 X123.904 Y101.412 E.02839
;WIDTH:0.433942
G1 X123.903 Y101.378 E.0009
G1 X123.903 Y101.378 F9000
G1 X122.586 Y102.711
;WIDTH:0.4
G1 F3072.127
G1 X123.523 Y101.774 E.03223
G1 X123.523 Y102.295 E.01267
G1 X122.32 Y103.497 E.04137
G1 X121.602 Y104.737 E.03485
G1 X123.54 Y102.799 E.06667
G1 X123.593 Y102.83 E.00149
G1 X123.432 Y103.427 E.01504
G1 X119.757 Y107.103 E.12643
G1 X120.072 Y107.309 E.00916
G1 X123.513 Y103.867 E.11839
G1 X123.513 Y104.388 E.01267
G1 X120.347 Y107.554 E.10891
G1 X120.602 Y107.82 E.00896
G1 X123.513 Y104.909 E.10014
G1 X123.513 Y105.43 E.01267
G1 X120.857 Y108.086 E.09136
G1 X121.081 Y108.383 E.00905
G1 X123.513 Y105.951 E.08366
G1 X123.513 Y106.472 E.01267
G1 X121.279 Y108.706 E.07685
G1 X121.471 Y109.035 E.00927
G1 X123.513 Y106.992 E.07026
G1 X123.513 Y107.513 E.01267
G1 X121.662 Y109.364 E.06367
G1 X121.854 Y109.694 E.00929
G1 X123.513 Y108.034 E.05709
G1 X123.513 Y108.555 E.01267
G1 X122.045 Y110.023 E.0505
G1 X122.236 Y110.352 E.00925
G1 X123.513 Y109.076 E.04391
G1 X123.513 Y109.597 E.01267
G1 X122.428 Y110.682 E.03732
G1 X122.619 Y111.011 E.00925
G1 X123.513 Y110.117 E.03075
G1 X123.513 Y110.638 E.01267
G1 X122.811 Y111.34 E.02415
G1 X123.002 Y111.67 E.00927
G1 X123.513 Y111.159 E.01758
G1 X123.513 Y111.68 E.01267
G1 X123.17 Y112.023 E.0118
G1 X123.33 Y112.384 E.0096
G1 X123.513 Y112.201 E.0063
G1 X123.513 Y112.722 E.01267
G1 X123.364 Y112.87 E.00511
G1 E-5 F3600
G1 X123.364 Y112.87 F9000
G1 X122.702 Y116.511
G1 E5 F2400
G1 F3072.127
G1 X123.513 Y115.7 E.0279
G1 X123.513 Y116.224 E.01275
G1 X122.431 Y117.306 E.03722
G1 X121.708 Y118.554 E.03508
G1 X123.513 Y116.749 E.06209
G1 X123.513 Y117.274 E.01277
G1 X119.712 Y121.075 E.13075
G1 X120.033 Y121.279 E.00925
G1 X123.513 Y117.798 E.11973
G1 X123.513 Y118.323 E.01277
G1 X120.315 Y121.521 E.11001
G1 X120.572 Y121.789 E.00903
G1 X123.513 Y118.847 E.10119
G1 X123.513 Y119.372 E.01277
G1 X120.828 Y122.057 E.09236
G1 X121.058 Y122.352 E.0091
G1 X123.513 Y119.896 E.08447
G1 X123.513 Y120.421 E.01277
G1 X121.261 Y122.674 E.07748
G1 X121.453 Y123.005 E.00931
G1 X123.513 Y120.946 E.07085
G1 X123.513 Y121.47 E.01275
G1 X121.646 Y123.337 E.06422
G1 X121.839 Y123.669 E.00934
G1 X123.513 Y121.995 E.05758
G1 X123.513 Y122.519 E.01275
G1 X122.032 Y124.001 E.05096
G1 X122.225 Y124.332 E.00932
G1 X123.513 Y123.044 E.04431
G1 X123.513 Y123.569 E.01277
G1 X122.418 Y124.664 E.03767
G1 X122.611 Y124.996 E.00934
G1 X123.513 Y124.093 E.03105
G1 X123.513 Y124.618 E.01277
G1 X122.803 Y125.327 E.02441
G1 X122.996 Y125.659 E.00934
G1 X123.513 Y125.142 E.01778
G1 X123.513 Y125.667 E.01277
G1 X123.166 Y126.014 E.01194
G1 X123.327 Y126.377 E.00966
G1 X123.513 Y126.191 E.0064
G1 X123.513 Y126.716 E.01277
G1 X123.363 Y126.867 E.00518
G1 E-5 F3600
G1 X123.363 Y126.867 F9000
G1 X123.096 Y129.733
G1 E5 F2400
G1 F3072.127
G1 X123.513 Y129.315 E.01436
G1 X123.513 Y129.841 E.01279
G1 X122.96 Y130.394 E.01902
G1 X122.235 Y131.644 E.03515
G1 X123.513 Y130.366 E.04396
G1 X123.513 Y130.892 E.01279
G1 X121.058 Y133.347 E.08445
G1 E-5 F3600
G1 X121.058 Y133.347 F9000
G1 X123.495 Y137.217
G1 E5 F2400
G1 F3072.127
G1 X123.806 Y136.906 E.0107
G1 X123.622 Y136.565 E.00942
G1 X123.134 Y137.053 E.01679
G1 X122.609 Y137.053 E.01277
G1 X123.539 Y136.122 E.03201
G1 X123.513 Y135.623 E.01215
G1 X122.083 Y137.053 E.04919
G1 X121.557 Y137.053 E.01279
G1 X123.513 Y135.097 E.06729
G1 X123.513 Y134.571 E.01279
G1 X121.032 Y137.053 E.08536
G1 X120.506 Y137.053 E.01279
G1 X123.513 Y134.046 E.10344
G1 X123.513 Y133.52 E.01279
G1 X119.981 Y137.053 E.12152
G1 X119.455 Y137.053 E.01279
G1 X123.513 Y132.995 E.13959
G1 X123.513 Y132.469 E.01279
G1 X118.929 Y137.053 E.15769
G1 X118.404 Y137.053 E.01277
G1 X123.513 Y131.943 E.17576
G1 X123.513 Y131.418 E.01277
G1 X117.878 Y137.053 E.19384
G1 X117.352 Y137.053 E.01279
G1 X119.185 Y135.22 E.06305
G1 X118.375 Y135.505 E.02089
G1 X116.827 Y137.053 E.05325
G1 X116.301 Y137.053 E.01279
G1 X117.736 Y135.618 E.04936
G1 X117.166 Y135.662 E.01391
G1 X115.776 Y137.053 E.04783
G1 X115.25 Y137.053 E.01279
G1 X116.64 Y135.662 E.04783
G1 X116.115 Y135.662 E.01277
G1 X114.724 Y137.053 E.04785
G1 X114.199 Y137.053 E.01277
G1 X115.589 Y135.662 E.04783
G1 X115.063 Y135.662 E.01279
G1 X113.673 Y137.053 E.04783
G1 X113.147 Y137.053 E.01279
G1 X114.538 Y135.662 E.04785
G1 X114.012 Y135.662 E.01279
G1 X112.622 Y137.053 E.04783
G1 X112.096 Y137.053 E.01279
G1 X113.504 Y135.645 E.04843
G1 X113.042 Y135.581 E.01135
G1 X111.571 Y137.053 E.05062
G1 X111.045 Y137.053 E.01279
G1 X112.599 Y135.499 E.05346
G1 X112.196 Y135.376 E.01025
G1 X110.519 Y137.053 E.05769
G1 X109.994 Y137.053 E.01277
G1 X111.823 Y135.224 E.06292
G1 X111.475 Y135.046 E.00951
G1 X109.468 Y137.053 E.06904
G1 X108.942 Y137.053 E.01279
G1 X111.156 Y134.839 E.07616
G1 X110.848 Y134.621 E.00918
G1 X108.417 Y137.053 E.08364
G1 X107.891 Y137.053 E.01279
G1 X110.568 Y134.376 E.09209
G1 X110.313 Y134.105 E.00905
G1 X107.366 Y137.053 E.10139
G1 X107.09 Y137.053 E.00671
G1 X107.359 Y136.672 E.01134
G1 X107.39 Y136.502 E.0042
G1 X110.068 Y133.824 E.09212
G1 X109.85 Y133.517 E.00916
G1 X107.487 Y135.88 E.08129
G1 X107.487 Y135.355 E.01277
G1 X109.657 Y133.184 E.07466
G1 X109.464 Y132.852 E.00934
G1 X107.487 Y134.829 E.06801
G1 X107.487 Y134.303 E.01279
G1 X109.271 Y132.52 E.06135
G1 X109.077 Y132.187 E.00937
G1 X107.487 Y133.778 E.05471
G1 X107.487 Y133.252 E.01279
G1 X108.884 Y131.855 E.04806
G1 X108.691 Y131.523 E.00934
G1 X107.487 Y132.726 E.0414
G1 X107.487 Y132.201 E.01277
G1 X108.498 Y131.19 E.03478
G1 X108.304 Y130.858 E.00935
G1 X107.487 Y131.675 E.0281
G1 X107.487 Y131.15 E.01277
G1 X108.111 Y130.525 E.02148
G1 X107.928 Y130.183 E.00943
G1 X107.487 Y130.624 E.01517
G1 X107.487 Y130.098 E.01279
G1 X107.758 Y129.827 E.00932
G1 X107.605 Y129.454 E.00981
G1 X107.322 Y129.737 E.00974
G1 E-5 F3600
G1 X107.322 Y129.737 F9000
G1 X109.543 Y123.339
G1 E5 F2400
G1 F3072.127
G1 X107.487 Y125.395 E.07073
G1 X107.487 Y125.913 E.0126
G1 X108.369 Y125.03 E.03036
G1 X107.771 Y126.147 E.03082
G1 X107.322 Y126.595 E.01543
G1 X107.322 Y126.595 F9000
G1 X107.322 Y125.042
G1 F3072.127
G1 X111.374 Y120.99 E.13939
G1 X111.069 Y120.778 E.00903
G1 X107.487 Y124.36 E.12322
G1 X107.487 Y123.842 E.0126
G1 X110.77 Y120.559 E.11293
G1 X110.502 Y120.31 E.0089
G1 X107.487 Y123.325 E.10371
G1 X107.487 Y122.807 E.0126
G1 X110.256 Y120.038 E.09525
G1 X110.02 Y119.757 E.00893
G1 X107.487 Y122.29 E.08713
G1 X107.487 Y121.772 E.0126
G1 X109.81 Y119.448 E.07993
G1 X109.62 Y119.121 E.0092
G1 X107.487 Y121.254 E.07337
G1 X107.487 Y120.737 E.01258
G1 X109.43 Y118.794 E.06684
G1 X109.24 Y118.466 E.00922
G1 X107.487 Y120.219 E.0603
G1 X107.487 Y119.702 E.01258
G1 X109.049 Y118.139 E.05375
G1 X108.859 Y117.812 E.0092
G1 X107.487 Y119.184 E.0472
G1 X107.487 Y118.666 E.0126
G1 X108.669 Y117.485 E.04064
G1 X108.478 Y117.157 E.00923
G1 X107.487 Y118.149 E.03411
G1 X107.487 Y117.631 E.0126
G1 X108.288 Y116.83 E.02755
G1 X108.098 Y116.503 E.0092
G1 X107.487 Y117.114 E.02102
G1 X107.487 Y116.596 E.0126
G1 X107.919 Y116.164 E.01486
G1 X107.752 Y115.814 E.00943
G1 X107.487 Y116.078 E.0091
G1 X107.487 Y115.561 E.01258
G1 X107.73 Y115.318 E.00836
G1 E-5 F3600
G1 X107.73 Y115.318 F9000
G1 X109.633 Y109.184
G1 E5 F2400
G1 F3072.127
G1 X107.487 Y111.33 E.07382
G1 X107.487 Y111.867 E.01306
G1 X108.434 Y110.92 E.03258
G1 X107.796 Y112.094 E.0325
G1 X107.322 Y112.567 E.01629
G1 X107.322 Y112.567 F9000
G1 X107.322 Y110.959
G1 F3072.127
G1 X111.323 Y106.958 E.13763
G1 X111.009 Y106.736 E.00935
G1 X107.487 Y110.258 E.12115
G1 X107.487 Y109.722 E.01304
G1 X110.704 Y106.505 E.11066
G1 X110.436 Y106.237 E.00922
G1 X107.487 Y109.186 E.10144
G1 X107.487 Y108.65 E.01304
G1 X110.181 Y105.956 E.09267
G1 X109.946 Y105.655 E.00929
G1 X107.487 Y108.113 E.08457
G1 X107.487 Y107.577 E.01304
G1 X109.739 Y105.325 E.07747
G1 X109.542 Y104.986 E.00954
G1 X107.487 Y107.041 E.07069
G1 X107.487 Y106.505 E.01304
G1 X109.345 Y104.647 E.06391
G1 X109.148 Y104.308 E.00954
G1 X107.487 Y105.969 E.05714
G1 X107.487 Y105.433 E.01304
G1 X108.95 Y103.969 E.05034
G1 X108.753 Y103.63 E.00954
G1 X107.487 Y104.897 E.04357
G1 X107.487 Y104.36 E.01306
G1 X108.556 Y103.291 E.03677
G1 X108.359 Y102.952 E.00954
G1 X107.487 Y103.824 E.03
G1 X107.452 Y103.323 E.01222
G1 X108.162 Y102.613 E.02442
G1 X107.969 Y102.27 E.00957
G1 X107.22 Y103.019 E.02577
G1 E-5 F3600
G1 X107.22 Y103.019 F9000
G1 X107.322 Y98.36
G1 E5 F2400
G1 F3072.127
G1 X107.984 Y97.698 E.02277
G1 X108.71 Y96.444 E.03525
G1 X107.487 Y97.667 E.04207
G1 X107.487 Y97.139 E.01284
G1 X109.898 Y94.728 E.08294
G1 E-5 F3600
G1 X109.898 Y94.728 F9000
G1 X107.508 Y90.783
G1 E5 F2400
G1 F3072.127
G1 X107.195 Y91.096 E.01077
G1 X107.379 Y91.44 E.00949
G1 X107.871 Y90.947 E.01694
G1 X108.399 Y90.947 E.01284
G1 X107.462 Y91.884 E.03223
G1 X107.487 Y92.388 E.01227
G1 X108.927 Y90.947 E.04955
G1 X109.455 Y90.947 E.01284
G1 X107.487 Y92.916 E.06772
G1 X107.487 Y93.444 E.01284
G1 X109.983 Y90.947 E.08588
G1 X110.511 Y90.947 E.01284
G1 X107.487 Y93.972 E.10404
G1 X107.487 Y94.5 E.01284
G1 X111.039 Y90.947 E.1222
G1 X111.567 Y90.947 E.01284
G1 X107.487 Y95.028 E.14037
G1 X107.487 Y95.556 E.01284
G1 X112.095 Y90.947 E.15853
G1 X112.623 Y90.947 E.01284
G1 X107.487 Y96.083 E.17668
G1 X107.487 Y96.611 E.01284
G1 X113.151 Y90.947 E.19484
G1 X113.679 Y90.947 E.01284
G1 X111.878 Y92.749 E.06197
G1 X112.679 Y92.475 E.02059
G1 X114.207 Y90.947 E.05256
G1 X114.735 Y90.947 E.01284
G1 X113.296 Y92.386 E.0495
G1 X113.872 Y92.338 E.01406
G1 X115.263 Y90.947 E.04785
G1 X115.791 Y90.947 E.01284
G1 X114.399 Y92.34 E.0479
G1 X114.925 Y92.341 E.01279
G1 X116.319 Y90.947 E.04795
G1 X116.847 Y90.947 E.01284
G1 X115.451 Y92.343 E.04802
G1 X115.978 Y92.344 E.01282
G1 X117.375 Y90.947 E.04806
G1 X117.903 Y90.947 E.01284
G1 X116.504 Y92.346 E.04812
G1 X117.03 Y92.347 E.01279
G1 X118.431 Y90.947 E.04818
G1 X118.959 Y90.947 E.01284
G1 X117.552 Y92.353 E.04838
G1 X118.026 Y92.408 E.01161
G1 X119.487 Y90.947 E.05026
G1 X120.015 Y90.947 E.01284
G1 X118.445 Y92.517 E.05401
G1 X118.841 Y92.649 E.01015
G1 X120.543 Y90.947 E.05855
G1 X121.071 Y90.947 E.01284
G1 X119.219 Y92.799 E.06371
G1 X119.567 Y92.979 E.00953
G1 X121.598 Y90.947 E.06988
G1 X122.126 Y90.947 E.01284
G1 X119.889 Y93.185 E.07697
G1 X120.188 Y93.413 E.00915
G1 X122.654 Y90.947 E.08483
G1 X123.182 Y90.947 E.01284
G1 X120.463 Y93.667 E.09355
G1 X120.719 Y93.939 E.00909
G1 X123.71 Y90.947 E.10291
G1 X123.91 Y90.947 E.00486
G1 X123.641 Y91.328 E.01134
G1 X123.592 Y91.594 E.00658
G1 X120.962 Y94.224 E.09047
G1 X121.179 Y94.534 E.0092
G1 X123.513 Y92.2 E.08029
G1 X123.513 Y92.728 E.01284
G1 X121.373 Y94.868 E.07361
G1 X121.568 Y95.202 E.00941
G1 X123.513 Y93.256 E.06692
G1 X123.513 Y93.784 E.01284
G1 X121.762 Y95.536 E.06025
G1 X121.956 Y95.87 E.0094
G1 X123.513 Y94.312 E.05358
G1 X123.513 Y94.84 E.01284
G1 X122.15 Y96.203 E.04689
G1 X122.344 Y96.537 E.0094
G1 X123.513 Y95.368 E.04021
G1 X123.513 Y95.896 E.01284
G1 X122.538 Y96.871 E.03354
G1 X122.732 Y97.205 E.0094
G1 X123.513 Y96.424 E.02687
G1 X123.513 Y96.952 E.01284
G1 X122.926 Y97.539 E.02019
G1 X123.106 Y97.887 E.00953
G1 X123.513 Y97.48 E.014
G1 X123.513 Y98.008 E.01284
G1 X123.159 Y98.362 E.01218
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X123.513 Y98.008 E-.2378
G1 X123.513 Y97.48 E-.2508
G1 X123.106 Y97.887 E-.2734
G1 X122.926 Y97.539 E-.1861
G1 X123.513 Y96.952 E-.39432
G1 X123.513 Y96.62 E-.15758
;WIPE_END
G1 X121.822 Y89.559 F9000
G1 X121.485 Y88.151
G1 X121.113 Y86.599
G1 X121.199 Y85.151
G1 X120.85 Y85.5
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X120.85 Y85.399 E.00246
G1 X120.767 Y85.246 E.00423
G1 X120.667 Y85.217 E.00253
G1 X110.333 Y85.217 E.25136
G1 X110.271 Y85.227 E.00153
G1 X110.15 Y85.399 E.00512
G1 X110.15 Y85.5 E.00246
G1 X104.557 Y85.5 E.13604
G1 X103.992 Y85.458 E.01378
G1 X103.447 Y85.336 E.01358
G1 X103.034 Y85.168 E.01085
G1 X102.41 Y84.839 E.01716
G1 X101.844 Y84.363 E.01799
G1 X101.416 Y83.847 E.01631
G1 X101.047 Y83.167 E.01882
G1 X100.889 Y82.642 E.01334
G1 X100.761 Y81.979 E.01642
G1 X100.75 Y79.021 E.07195
G1 X100.686 Y78.883 E.0037
G1 X99.362 Y77.748 E.04242
G1 X99.141 Y77.519 E.00774
G1 X99.292 Y77.317 E.00613
G1 X100.574 Y76.21 E.0412
G1 X130.426 Y76.21 E.72612
G1 X131.639 Y77.257 E.03898
G1 X131.865 Y77.491 E.00791
G1 X131.649 Y77.738 E.00798
G1 X130.314 Y78.883 E.04278
G1 X130.25 Y79.021 E.0037
G1 X130.24 Y81.702 E.06521
G1 X130.197 Y82.26 E.01361
G1 X130.072 Y82.809 E.0137
G1 X129.861 Y83.348 E.01408
G1 X129.572 Y83.845 E.01398
G1 X129.226 Y84.279 E.0135
G1 X128.788 Y84.681 E.01446
G1 X128.332 Y84.991 E.01341
G1 X127.821 Y85.244 E.01387
G1 X127.283 Y85.407 E.01367
G1 X126.73 Y85.489 E.0136
G1 X120.91 Y85.5 E.14157
G1 X120.91 Y85.5 F9000
G1 X121.025 Y85.049
;TYPE:Perimeter
G1 F6000
G1 X120.965 Y84.939 E.00305
G1 X120.851 Y84.883 E.00309
G1 X120.667 Y84.851 E.00454
G1 X110.333 Y84.851 E.25136
G1 X110.238 Y84.859 E.00232
G1 X110.034 Y84.939 E.00533
G1 X109.928 Y85.134 E.0054
G1 X104.571 Y85.134 E.1303
G1 X104.046 Y85.096 E.0128
G1 X103.557 Y84.986 E.01219
G1 X103.171 Y84.829 E.01014
G1 X102.622 Y84.539 E.0151
G1 X102.105 Y84.105 E.01642
G1 X101.721 Y83.641 E.01465
G1 X101.386 Y83.026 E.01703
G1 X101.24 Y82.538 E.01239
G1 X101.127 Y81.953 E.01449
G1 X101.116 Y79.02 E.07134
G1 X101.078 Y78.823 E.00488
G1 X100.924 Y78.606 E.00647
G1 X99.637 Y77.502 E.04124
G1 X100.71 Y76.576 E.03447
G1 X130.29 Y76.576 E.7195
G1 X131.363 Y77.502 E.03447
G1 X130.076 Y78.606 E.04124
G1 X129.922 Y78.823 E.00647
G1 X129.884 Y79.02 E.00488
G1 X129.874 Y81.701 E.06521
G1 X129.835 Y82.206 E.01232
G1 X129.723 Y82.702 E.01237
G1 X129.532 Y83.189 E.01272
G1 X129.271 Y83.639 E.01265
G1 X128.958 Y84.03 E.01218
G1 X128.561 Y84.395 E.01312
G1 X128.146 Y84.677 E.0122
G1 X127.692 Y84.901 E.01231
G1 X127.203 Y85.049 E.01243
G1 X126.702 Y85.124 E.01232
G1 X121.071 Y85.134 E.13697
G1 X121.054 Y85.102 E.00088
G1 X121.054 Y85.102 F9000
G1 X121.269 Y84.768
G1 F6000
G1 X121.238 Y84.768 E.00075
G1 X121.164 Y84.632 E.00377
G1 X120.974 Y84.538 E.00516
G1 X120.667 Y84.485 E.00758
G1 X110.333 Y84.485 E.25136
G1 X110.175 Y84.499 E.00386
G1 X109.835 Y84.633 E.00889
G1 X109.761 Y84.769 E.00377
G1 X104.466 Y84.76 E.1288
G1 X103.894 Y84.687 E.01403
G1 X103.308 Y84.49 E.01504
G1 X102.835 Y84.24 E.01301
G1 X102.365 Y83.846 E.01492
G1 X102.025 Y83.435 E.01297
G1 X101.725 Y82.884 E.01526
G1 X101.59 Y82.433 E.01145
G1 X101.492 Y81.927 E.01254
G1 X101.481 Y79.019 E.07073
G1 X101.419 Y78.69 E.00814
G1 X101.162 Y78.328 E.0108
G1 X100.198 Y77.501 E.03089
G1 X100.846 Y76.942 E.02082
G1 X130.154 Y76.942 E.71289
G1 X130.802 Y77.501 E.02082
G1 X129.838 Y78.328 E.03089
G1 X129.581 Y78.69 E.0108
G1 X129.519 Y79.019 E.00814
G1 X129.509 Y81.7 E.06521
G1 X129.44 Y82.377 E.01655
G1 X129.203 Y83.03 E.0169
G1 X128.842 Y83.617 E.01676
G1 X128.333 Y84.109 E.01722
G1 X127.838 Y84.434 E.0144
G1 X127.338 Y84.626 E.01303
G1 X126.675 Y84.758 E.01644
G1 X121.329 Y84.767 E.13004
G1 X121.329 Y84.767 F9000
G1 X121.544 Y84.401
G1 F6000
G1 X121.404 Y84.402 E.00341
G1 X121.363 Y84.325 E.00212
G1 X121.097 Y84.194 E.00721
G1 X120.667 Y84.12 E.01061
G1 X110.333 Y84.12 E.25136
G1 X109.901 Y84.195 E.01067
G1 X109.636 Y84.326 E.00719
G1 X109.594 Y84.403 E.00213
G1 X104.703 Y84.403 E.11897
G1 X104.154 Y84.37 E.01338
G1 X103.556 Y84.196 E.01515
G1 X103.047 Y83.941 E.01385
G1 X102.626 Y83.587 E.01338
G1 X102.329 Y83.229 E.01131
G1 X102.065 Y82.743 E.01345
G1 X101.972 Y82.435 E.00783
G1 X101.858 Y81.901 E.01328
G1 X101.847 Y79.017 E.07015
G1 X101.759 Y78.557 E.01139
G1 X101.4 Y78.05 E.01511
G1 X100.758 Y77.5 E.02056
G1 X100.982 Y77.307 E.00719
G1 X130.018 Y77.307 E.70627
G1 X130.242 Y77.5 E.00719
G1 X129.6 Y78.05 E.02056
G1 X129.241 Y78.557 E.01511
G1 X129.153 Y79.017 E.01139
G1 X129.143 Y81.698 E.06521
G1 X129.082 Y82.296 E.01462
G1 X128.873 Y82.871 E.01488
G1 X128.556 Y83.388 E.01475
G1 X128.105 Y83.823 E.01524
G1 X127.669 Y84.109 E.01268
G1 X127.232 Y84.276 E.01138
G1 X126.648 Y84.392 E.01448
G1 X121.604 Y84.401 E.12269
G1 X121.604 Y84.401 F9000
G1 X121.81 Y84.035
G1 F6000
G1 X121.621 Y84.036 E.0046
G1 X121.22 Y83.85 E.01075
G1 X120.667 Y83.754 E.01365
G1 X110.333 Y83.754 E.25136
G1 X109.777 Y83.851 E.01373
G1 X109.427 Y84.037 E.00964
G1 X104.611 Y84.037 E.11714
G1 X104.055 Y83.973 E.01361
G1 X103.472 Y83.768 E.01503
G1 X103.16 Y83.558 E.00915
G1 X102.764 Y83.181 E.0133
G1 X102.519 Y82.812 E.01077
G1 X102.335 Y82.372 E.0116
G1 X102.223 Y81.875 E.01239
G1 X102.213 Y79.016 E.06954
G1 X102.1 Y78.424 E.01466
G1 X101.638 Y77.773 E.01942
G1 X101.522 Y77.673 E.00373
G1 X129.478 Y77.673 E.68
G1 X129.362 Y77.773 E.00373
G1 X128.9 Y78.424 E.01942
G1 X128.787 Y79.016 E.01466
G1 X128.781 Y80.863 E.04493
G1 X128.75 Y82.043 E.02871
G1 X128.622 Y82.551 E.01274
G1 X128.365 Y83.019 E.01299
G1 X128.038 Y83.409 E.01238
G1 X127.587 Y83.733 E.01351
G1 X127.126 Y83.926 E.01216
G1 X126.62 Y84.027 E.01255
G1 X121.87 Y84.035 E.11554
G1 E-5 F3600
G1 X121.87 Y84.035 F9000
G1 X127.304 Y83.752
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X128.055 Y82.988 E.02606
G1 X128.365 Y82.451 E.01508
G1 X128.47 Y82.065 E.00973
G1 X126.814 Y83.721 E.05697
G1 X126.26 Y83.753 E.0135
G1 X128.504 Y81.509 E.07719
G1 X128.506 Y80.986 E.01272
G1 X125.737 Y83.754 E.09523
G1 X125.215 Y83.755 E.0127
G1 X128.508 Y80.462 E.11328
G1 X128.51 Y79.939 E.01272
G1 X124.692 Y83.756 E.13132
G1 X124.17 Y83.757 E.0127
G1 X128.512 Y79.415 E.14936
G1 X128.54 Y78.865 E.0134
G1 X123.647 Y83.758 E.16832
G1 X123.125 Y83.759 E.0127
G1 X128.909 Y77.947 E.19945
G1 X128.415 Y77.947 E.01202
G1 X122.602 Y83.76 E.19996
G1 X122.08 Y83.761 E.0127
G1 X127.893 Y77.947 E.19998
G1 X127.372 Y77.947 E.01267
G1 X121.591 Y83.728 E.19886
G1 X121.229 Y83.569 E.00962
G1 X126.85 Y77.947 E.19338
G1 X126.329 Y77.947 E.01267
G1 X120.786 Y83.49 E.19068
G1 X120.275 Y83.48 E.01243
G1 X125.807 Y77.947 E.19031
G1 X125.286 Y77.947 E.01267
G1 X119.753 Y83.48 E.19033
G1 X119.232 Y83.48 E.01267
G1 X124.764 Y77.947 E.19031
G1 X124.242 Y77.947 E.0127
G1 X118.71 Y83.48 E.19031
G1 X118.188 Y83.48 E.0127
G1 X123.721 Y77.947 E.19033
G1 X123.199 Y77.947 E.0127
G1 X117.667 Y83.48 E.19031
G1 X117.145 Y83.48 E.0127
G1 X122.678 Y77.947 E.19033
G1 X122.156 Y77.947 E.0127
G1 X116.624 Y83.48 E.19031
G1 X116.102 Y83.48 E.0127
G1 X121.635 Y77.947 E.19033
G1 X121.113 Y77.947 E.0127
G1 X115.581 Y83.48 E.19031
G1 X115.059 Y83.48 E.0127
G1 X120.592 Y77.947 E.19033
G1 X120.07 Y77.947 E.0127
G1 X114.538 Y83.48 E.19031
G1 X114.016 Y83.48 E.0127
G1 X119.548 Y77.947 E.19031
G1 X119.027 Y77.947 E.01267
G1 X113.494 Y83.48 E.19033
G1 X112.973 Y83.48 E.01267
G1 X118.505 Y77.947 E.19031
G1 X117.984 Y77.947 E.01267
G1 X112.451 Y83.48 E.19033
G1 X111.93 Y83.48 E.01267
G1 X117.462 Y77.947 E.19031
G1 X116.941 Y77.947 E.01267
G1 X111.408 Y83.48 E.19033
G1 X110.887 Y83.48 E.01267
G1 X116.419 Y77.947 E.19031
G1 X115.898 Y77.947 E.01267
G1 X110.365 Y83.48 E.19033
G1 X109.748 Y83.575 E.01518
G1 X115.376 Y77.947 E.1936
G1 X114.854 Y77.947 E.0127
G1 X109.038 Y83.763 E.20007
G1 X108.517 Y83.763 E.01267
G1 X114.333 Y77.947 E.20007
G1 X113.811 Y77.947 E.0127
G1 X107.995 Y83.763 E.20007
G1 X107.474 Y83.763 E.01267
G1 X113.29 Y77.947 E.20007
G1 X112.768 Y77.947 E.0127
G1 X106.952 Y83.763 E.20007
G1 X106.431 Y83.763 E.01267
G1 X112.247 Y77.947 E.20007
G1 X111.725 Y77.947 E.0127
G1 X105.909 Y83.763 E.20007
G1 X105.388 Y83.763 E.01267
G1 X111.204 Y77.947 E.20007
G1 X110.682 Y77.947 E.0127
G1 X104.866 Y83.763 E.20007
G1 X104.363 Y83.744 E.01224
G1 X110.16 Y77.947 E.19941
G1 X109.639 Y77.947 E.01267
G1 X103.929 Y83.657 E.19642
G1 X103.562 Y83.502 E.00969
G1 X109.117 Y77.947 E.19109
G1 X108.596 Y77.947 E.01267
G1 X103.259 Y83.284 E.18359
G1 X102.993 Y83.028 E.00898
G1 X108.074 Y77.947 E.17478
G1 X107.553 Y77.947 E.01267
G1 X102.78 Y82.719 E.16417
G1 X102.618 Y82.36 E.00958
G1 X107.031 Y77.947 E.1518
G1 X106.509 Y77.947 E.0127
G1 X102.51 Y81.947 E.13758
G1 X102.496 Y81.439 E.01236
G1 X105.988 Y77.947 E.12012
G1 X105.466 Y77.947 E.0127
G1 X102.494 Y80.92 E.10225
G1 X102.492 Y80.4 E.01265
G1 X104.945 Y77.947 E.08438
G1 X104.423 Y77.947 E.0127
G1 X102.49 Y79.88 E.06649
G1 X102.488 Y79.361 E.01262
G1 X103.902 Y77.947 E.04864
G1 X103.38 Y77.947 E.0127
G1 X102.46 Y78.867 E.03165
G1 X102.377 Y78.429 E.01084
G1 X102.859 Y77.947 E.01658
G1 X102.337 Y77.947 E.0127
G1 X102.075 Y78.209 E.00901
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X102.337 Y77.947 E-.176
G1 X102.859 Y77.947 E-.24795
G1 X102.377 Y78.429 E-.32378
G1 X102.46 Y78.867 E-.21175
G1 X103.265 Y78.062 E-.54052
;WIPE_END
G1 X104.473 Y85.148 F9000
G1 X104.72 Y86.599
G1 X104.651 Y88.557
G1 X105.053 Y88.557
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.062 Y88.545 E.00036
G1 X105.183 Y88.5 E.00314
G1 X125.817 Y88.5 E.5019
G1 X125.96 Y88.569 E.00386
G1 X126 Y88.683 E.00294
G1 X126 Y88.975 E.0071
G1 X127.222 Y90.032 E.0393
G1 X127.46 Y90.307 E.00885
G1 X127.5 Y90.604 E.00729
G1 X127.222 Y90.969 E.01116
G1 X126 Y92.025 E.03928
G1 X126 Y92.525 E.01216
G1 X139.201 Y92.525 E.3211
G1 X139.589 Y92.648 E.0099
G1 X139.825 Y92.921 E.00878
G1 X139.9 Y93.228 E.00769
G1 X139.9 Y95.601 E.05772
G1 X139.845 Y95.869 E.00665
G1 X139.703 Y96.084 E.00627
G1 X139.408 Y96.27 E.00848
G1 X138.995 Y96.303 E.01008
G1 X136.7 Y96.304 E.05582
G1 X136.7 Y102.641 E.15414
G1 X139.292 Y102.652 E.06305
G1 X139.546 Y102.763 E.00674
G1 X139.804 Y103.13 E.01091
G1 X139.89 Y103.572 E.01095
G1 X139.89 Y104.428 E.02082
G1 X139.812 Y104.856 E.01058
G1 X139.638 Y105.15 E.00831
G1 X139.292 Y105.348 E.0097
G1 X136.7 Y105.359 E.06305
G1 X136.7 Y110.641 E.12848
G1 X139.292 Y110.652 E.06305
G1 X139.546 Y110.763 E.00674
G1 X139.804 Y111.13 E.01091
G1 X139.89 Y111.572 E.01095
G1 X139.89 Y112.428 E.02082
G1 X139.812 Y112.856 E.01058
G1 X139.638 Y113.15 E.00831
G1 X139.292 Y113.348 E.0097
G1 X136.7 Y113.359 E.06305
G1 X136.7 Y118.641 E.12848
G1 X139.292 Y118.652 E.06305
G1 X139.546 Y118.763 E.00674
G1 X139.804 Y119.13 E.01091
G1 X139.89 Y119.572 E.01095
G1 X139.89 Y120.428 E.02082
G1 X139.812 Y120.856 E.01058
G1 X139.637 Y121.151 E.00834
G1 X139.291 Y121.348 E.00968
G1 X136.7 Y121.359 E.06302
G1 X136.7 Y126.64 E.12846
G1 X139.202 Y126.64 E.06086
G1 X139.497 Y126.729 E.0075
G1 X139.705 Y126.933 E.00709
G1 X139.869 Y127.374 E.01144
G1 X139.895 Y127.741 E.00895
G1 X139.869 Y128.618 E.02134
G1 X139.705 Y129.066 E.0116
G1 X139.394 Y129.316 E.00971
G1 X138.989 Y129.349 E.00988
G1 X136.7 Y129.359 E.05568
G1 X136.7 Y132.616 E.07922
G1 X136.684 Y133.155 E.01312
G1 X136.59 Y134.086 E.02276
G1 X136.487 Y134.639 E.01368
G1 X139.202 Y134.64 E.06604
G1 X139.497 Y134.729 E.0075
G1 X139.705 Y134.933 E.00709
G1 X139.869 Y135.38 E.01158
G1 X139.898 Y136.05 E.01631
G1 X139.87 Y136.62 E.01388
G1 X139.705 Y137.066 E.01157
G1 X139.497 Y137.27 E.00709
G1 X139.237 Y137.357 E.00667
G1 X135.516 Y137.361 E.09051
G1 X135.146 Y138.009 E.01815
G1 X134.559 Y138.851 E.02497
G1 X133.935 Y139.582 E.02338
G1 X133.329 Y140.177 E.02066
G1 X132.602 Y140.773 E.02287
G1 X131.823 Y141.301 E.02289
G1 X131.174 Y141.666 E.01811
G1 X130.205 Y142.171 E.02658
G1 X129.791 Y142.505 E.01294
G1 X129.741 Y142.585 E.00229
G1 X130.065 Y142.639 E.00799
G1 X139.291 Y142.652 E.22441
G1 X139.638 Y142.85 E.00972
G1 X139.705 Y142.934 E.00261
G1 X139.869 Y143.369 E.01131
G1 X139.892 Y143.611 E.00591
G1 X139.87 Y144.616 E.02445
G1 X139.705 Y145.067 E.01168
G1 X139.497 Y145.271 E.00709
G1 X139.202 Y145.36 E.0075
G1 X125.627 Y145.361 E.3302
G1 X125.492 Y145.302 E.00358
G1 X125.444 Y145.178 E.00323
G1 X125.442 Y143.109 E.05033
G1 X125.397 Y142.96 E.00379
G1 X125.276 Y142.85 E.00398
G1 X125.006 Y142.8 E.00668
G1 X120.483 Y142.8 E.11002
G1 X120.389 Y142.774 E.00237
G1 X120.3 Y142.617 E.00439
G1 X120.3 Y142.429 E.00457
G1 X110.7 Y142.429 E.23351
G1 X110.7 Y142.617 E.00457
G1 X110.569 Y142.793 E.00534
G1 X105.854 Y142.808 E.11469
G1 X105.632 Y142.924 E.00609
G1 X105.566 Y143.051 E.00348
G1 X105.556 Y145.179 E.05176
G1 X105.489 Y145.32 E.0038
G1 X105.373 Y145.361 E.00299
G1 X91.798 Y145.36 E.3302
G1 X91.502 Y145.269 E.00753
G1 X91.297 Y145.075 E.00687
G1 X91.17 Y144.803 E.0073
G1 X91.11 Y144.429 E.00921
G1 X91.104 Y143.736 E.01686
G1 X91.17 Y143.204 E.01304
G1 X91.301 Y142.919 E.00763
G1 X91.606 Y142.684 E.00937
G1 X91.709 Y142.652 E.00262
G1 X100.953 Y142.639 E.22485
G1 X101.267 Y142.599 E.0077
G1 X101.018 Y142.337 E.00879
G1 X100.481 Y141.981 E.01567
G1 X99.831 Y141.669 E.01754
G1 X99.19 Y141.309 E.01788
G1 X98.411 Y140.783 E.02286
G1 X97.683 Y140.187 E.02289
G1 X97.076 Y139.594 E.02064
G1 X96.441 Y138.851 E.02377
G1 X95.862 Y138.023 E.02458
G1 X95.484 Y137.361 E.01854
G1 X91.763 Y137.357 E.09051
G1 X91.503 Y137.27 E.00667
G1 X91.295 Y137.066 E.00709
G1 X91.131 Y136.619 E.01158
G1 X91.113 Y136.206 E.01006
G1 X91.131 Y135.379 E.02012
G1 X91.295 Y134.933 E.01156
G1 X91.503 Y134.729 E.00709
G1 X91.798 Y134.64 E.0075
G1 X94.513 Y134.639 E.06604
G1 X94.409 Y134.079 E.01385
G1 X94.301 Y132.661 E.03459
G1 X94.3 Y129.358 E.08034
G1 X91.708 Y129.348 E.06305
G1 X91.454 Y129.237 E.00674
G1 X91.196 Y128.87 E.01091
G1 X91.11 Y128.429 E.01093
G1 X91.108 Y127.606 E.02002
G1 X91.188 Y127.144 E.0114
G1 X91.347 Y126.86 E.00792
G1 X91.575 Y126.693 E.00687
G1 X91.798 Y126.64 E.00558
G1 X94.3 Y126.64 E.06086
G1 X94.3 Y121.359 E.12846
G1 X91.708 Y121.348 E.06305
G1 X91.454 Y121.237 E.00674
G1 X91.196 Y120.87 E.01091
G1 X91.11 Y120.428 E.01095
G1 X91.11 Y119.572 E.02082
G1 X91.188 Y119.144 E.01058
G1 X91.363 Y118.849 E.00834
G1 X91.709 Y118.652 E.00968
G1 X94.3 Y118.641 E.06302
G1 X94.3 Y113.359 E.12848
G1 X91.708 Y113.348 E.06305
G1 X91.362 Y113.151 E.00968
G1 X91.171 Y112.805 E.00961
G1 X91.11 Y112.428 E.00929
G1 X91.11 Y111.572 E.02082
G1 X91.188 Y111.144 E.01058
G1 X91.363 Y110.849 E.00834
G1 X91.709 Y110.652 E.00968
G1 X94.3 Y110.641 E.06302
G1 X94.3 Y105.359 E.12848
G1 X91.708 Y105.348 E.06305
G1 X91.454 Y105.237 E.00674
G1 X91.196 Y104.87 E.01091
G1 X91.11 Y104.428 E.01095
G1 X91.11 Y103.572 E.02082
G1 X91.188 Y103.144 E.01058
G1 X91.363 Y102.849 E.00834
G1 X91.709 Y102.652 E.00968
G1 X94.3 Y102.641 E.06302
G1 X94.3 Y96.304 E.15414
G1 X91.798 Y96.303 E.06086
G1 X91.531 Y96.248 E.00663
G1 X91.318 Y96.104 E.00625
G1 X91.134 Y95.81 E.00844
G1 X91.1 Y95.601 E.00515
G1 X91.108 Y93.137 E.05993
G1 X91.211 Y92.851 E.00739
G1 X91.375 Y92.671 E.00592
G1 X91.592 Y92.558 E.00595
G1 X91.799 Y92.525 E.0051
G1 X105 Y92.525 E.3211
G1 X105 Y92.025 E.01216
G1 X103.778 Y90.968 E.0393
G1 X103.527 Y90.647 E.00991
G1 X103.513 Y90.357 E.00706
G1 X103.778 Y90.031 E.01022
G1 X105 Y88.975 E.03928
G1 X105.018 Y88.605 E.00901
G1 X104.798 Y88.306 F9000
;TYPE:Perimeter
G1 F6000
G1 X104.821 Y88.27 E.00104
G1 X105.183 Y88.134 E.00941
G1 X125.817 Y88.134 E.5019
G1 X126.067 Y88.195 E.00626
G1 X126.289 Y88.403 E.0074
G1 X126.366 Y88.683 E.00706
G1 X126.366 Y88.807 E.00302
G1 X127.462 Y89.755 E.03525
G1 X127.778 Y90.125 E.01184
G1 X127.863 Y90.486 E.00902
G1 X127.858 Y90.677 E.00465
G1 X127.743 Y90.917 E.00647
G1 X127.461 Y91.245 E.01052
G1 X126.404 Y92.159 E.03399
G1 X139.201 Y92.16 E.31127
G1 X139.6 Y92.246 E.00993
G1 X139.849 Y92.391 E.00701
G1 X140.038 Y92.582 E.00654
;WIDTH:0.439954
G1 X140.128 Y92.746 E.00505
;WIDTH:0.479908
G1 X140.217 Y92.909 E.0055
;WIDTH:0.519862
G1 X140.306 Y93.072 E.006
;WIDTH:0.54685
G1 X140.34 Y93.228 E.00544
;WIDTH:0.547032
G1 X140.34 Y95.601 E.08093
;WIDTH:0.569223
G1 X140.31 Y95.887 E.01023
G1 X140.211 Y96.011 E.00565
;WIDTH:0.526917
G1 X140.112 Y96.135 E.0052
;WIDTH:0.484611
G1 X140.013 Y96.258 E.00473
;WIDTH:0.442305
G1 X139.914 Y96.382 E.00431
;WIDTH:0.399999
G1 X139.694 Y96.538 E.00656
G1 X139.294 Y96.661 E.01018
G1 X137.066 Y96.669 E.05419
G1 X137.066 Y102.277 E.13641
G1 X139.293 Y102.287 E.05417
G1 X139.548 Y102.35 E.00639
G1 X139.717 Y102.44 E.00466
G1 X139.925 Y102.634 E.00692
G1 X140.114 Y102.936 E.00867
G1 X140.19 Y103.136 E.0052
G1 X140.255 Y103.572 E.01072
G1 X140.255 Y104.428 E.02082
G1 X140.139 Y105.02 E.01467
G1 X140.025 Y105.246 E.00616
G1 X139.844 Y105.452 E.00667
G1 X139.6 Y105.618 E.00718
G1 X139.293 Y105.713 E.00782
G1 X137.066 Y105.723 E.05417
G1 X137.066 Y110.277 E.11077
G1 X139.293 Y110.287 E.05417
G1 X139.548 Y110.35 E.00639
G1 X139.717 Y110.44 E.00466
G1 X139.925 Y110.634 E.00692
G1 X140.114 Y110.936 E.00867
G1 X140.19 Y111.136 E.0052
G1 X140.255 Y111.572 E.01072
G1 X140.255 Y112.428 E.02082
G1 X140.139 Y113.02 E.01467
G1 X140.025 Y113.246 E.00616
G1 X139.844 Y113.452 E.00667
G1 X139.6 Y113.618 E.00718
G1 X139.293 Y113.713 E.00782
G1 X137.066 Y113.723 E.05417
G1 X137.066 Y118.277 E.11077
G1 X139.293 Y118.287 E.05417
G1 X139.548 Y118.35 E.00639
G1 X139.717 Y118.44 E.00466
G1 X139.925 Y118.634 E.00692
G1 X140.114 Y118.936 E.00867
G1 X140.19 Y119.136 E.0052
G1 X140.255 Y119.572 E.01072
G1 X140.255 Y120.428 E.02082
G1 X140.139 Y121.02 E.01467
G1 X140.025 Y121.246 E.00616
G1 X139.842 Y121.454 E.00674
G1 X139.597 Y121.62 E.0072
G1 X139.292 Y121.713 E.00776
G1 X137.066 Y121.723 E.05415
G1 X137.066 Y126.275 E.11072
G1 X139.202 Y126.275 E.05196
G1 X139.517 Y126.339 E.00782
G1 X139.887 Y126.58 E.01074
G1 X140.045 Y126.8 E.00659
G1 X140.227 Y127.293 E.01278
G1 X140.261 Y127.752 E.0112
G1 X140.235 Y128.629 E.02134
G1 X140.046 Y129.199 E.01461
G1 X139.843 Y129.453 E.00791
G1 X139.599 Y129.619 E.00718
G1 X139.293 Y129.713 E.00779
G1 X137.066 Y129.723 E.05417
G1 X137.066 Y132.616 E.07037
G1 X137.05 Y133.165 E.01336
G1 X136.928 Y134.273 E.02711
G1 X139.203 Y134.275 E.05534
G1 X139.517 Y134.339 E.00779
G1 X139.887 Y134.58 E.01074
G1 X140.045 Y134.8 E.00659
G1 X140.227 Y135.293 E.01278
G1 X140.263 Y136.035 E.01807
G1 X140.235 Y136.639 E.01471
G1 X140.046 Y137.199 E.01438
G1 X139.888 Y137.42 E.00661
G1 X139.54 Y137.655 E.01021
G1 X139.237 Y137.723 E.00755
G1 X135.728 Y137.726 E.08535
G1 X135.464 Y138.19 E.01299
G1 X134.837 Y139.089 E.02666
G1 X134.213 Y139.82 E.02338
G1 X133.584 Y140.438 E.02145
G1 X132.834 Y141.056 E.02364
G1 X132.028 Y141.604 E.02371
G1 X130.799 Y142.274 E.03405
G1 X139.292 Y142.287 E.20658
G1 X139.599 Y142.381 E.00781
G1 X139.843 Y142.547 E.00718
G1 X140.046 Y142.801 E.00791
G1 X140.227 Y143.293 E.01275
G1 X140.258 Y143.619 E.00797
G1 X140.235 Y144.624 E.02445
G1 X140.045 Y145.2 E.01475
G1 X139.887 Y145.42 E.00659
G1 X139.517 Y145.661 E.01074
G1 X139.202 Y145.725 E.00782
G1 X125.627 Y145.727 E.3302
G1 X125.365 Y145.661 E.00657
G1 X125.159 Y145.466 E.0069
G1 X125.078 Y145.179 E.00725
G1 X125.077 Y143.18 E.04862
G1 X125.006 Y143.166 E.00176
G1 X120.483 Y143.166 E.11002
G1 X120.2 Y143.087 E.00715
G1 X120.035 Y142.795 E.00816
G1 X110.965 Y142.795 E.22062
G1 X110.8 Y143.087 E.00816
G1 X110.518 Y143.166 E.00712
G1 X105.931 Y143.173 E.11157
G1 X105.922 Y145.181 E.04884
G1 X105.84 Y145.466 E.00721
G1 X105.634 Y145.661 E.0069
G1 X105.373 Y145.727 E.00655
G1 X91.798 Y145.725 E.3302
G1 X91.482 Y145.661 E.00784
G1 X91.264 Y145.547 E.00598
G1 X90.97 Y145.239 E.01036
G1 X90.81 Y144.864 E.00992
G1 X90.745 Y144.432 E.01063
G1 X90.739 Y143.736 E.01693
G1 X90.807 Y143.158 E.01416
G1 X90.975 Y142.754 E.01064
G1 X91.156 Y142.548 E.00667
G1 X91.401 Y142.381 E.00721
G1 X91.708 Y142.287 E.00781
G1 X100.246 Y142.274 E.20768
G1 X99.673 Y141.999 E.01546
G1 X99.01 Y141.627 E.01849
G1 X98.207 Y141.086 E.02355
G1 X97.452 Y140.47 E.0237
G1 X96.821 Y139.855 E.02143
G1 X96.163 Y139.089 E.02456
G1 X95.562 Y138.232 E.02546
G1 X95.272 Y137.726 E.01419
G1 X91.763 Y137.723 E.08535
G1 X91.46 Y137.655 E.00755
G1 X91.112 Y137.42 E.01021
G1 X90.954 Y137.199 E.00661
G1 X90.773 Y136.706 E.01277
;WIDTH:0.438535
G1 X90.747 Y136.586 E.0033
;WIDTH:0.477071
G1 X90.722 Y136.466 E.00361
;WIDTH:0.515607
G1 X90.696 Y136.345 E.00396
;WIDTH:0.554143
G1 X90.671 Y136.225 E.00424
;WIDTH:0.563096
G1 X90.684 Y135.356 E.03057
G1 X90.714 Y135.314 E.00182
;WIDTH:0.522322
G1 X90.743 Y135.272 E.00166
;WIDTH:0.481548
G1 X90.773 Y135.23 E.00154
;WIDTH:0.440774
G1 X90.803 Y135.188 E.0014
;WIDTH:0.399999
G1 X90.955 Y134.8 E.01014
G1 X91.113 Y134.58 E.00659
G1 X91.483 Y134.339 E.01074
G1 X91.797 Y134.275 E.00779
G1 X94.072 Y134.273 E.05534
G1 X94.044 Y134.107 E.00409
G1 X93.936 Y132.689 E.03459
G1 X93.934 Y129.723 E.07215
G1 X91.707 Y129.713 E.05417
G1 X91.452 Y129.65 E.00639
G1 X91.283 Y129.56 E.00466
G1 X91.075 Y129.366 E.00692
G1 X90.886 Y129.064 E.00867
G1 X90.81 Y128.864 E.0052
G1 X90.745 Y128.43 E.01067
G1 X90.742 Y127.606 E.02004
G1 X90.809 Y127.14 E.01145
G1 X90.975 Y126.754 E.01022
G1 X91.268 Y126.449 E.01029
G1 X91.659 Y126.293 E.01024
G1 X92.003 Y126.275 E.00838
G1 X93.934 Y126.275 E.04697
G1 X93.934 Y121.723 E.11072
G1 X91.707 Y121.713 E.05417
G1 X91.452 Y121.65 E.00639
G1 X91.283 Y121.56 E.00466
G1 X91.075 Y121.366 E.00692
G1 X90.886 Y121.064 E.00867
G1 X90.81 Y120.864 E.0052
G1 X90.745 Y120.428 E.01072
G1 X90.745 Y119.572 E.02082
G1 X90.861 Y118.98 E.01467
G1 X90.975 Y118.754 E.00616
G1 X91.158 Y118.546 E.00674
G1 X91.403 Y118.38 E.0072
G1 X91.708 Y118.287 E.00776
G1 X93.934 Y118.277 E.05415
G1 X93.934 Y113.723 E.11077
G1 X91.707 Y113.713 E.05417
G1 X91.402 Y113.619 E.00776
G1 X91.157 Y113.453 E.0072
G1 X90.975 Y113.246 E.0067
G1 X90.81 Y112.864 E.01012
G1 X90.745 Y112.428 E.01072
G1 X90.745 Y111.572 E.02082
G1 X90.861 Y110.98 E.01467
G1 X90.975 Y110.754 E.00616
G1 X91.158 Y110.546 E.00674
G1 X91.403 Y110.38 E.0072
G1 X91.708 Y110.287 E.00776
G1 X93.934 Y110.277 E.05415
G1 X93.934 Y105.723 E.11077
G1 X91.707 Y105.713 E.05417
G1 X91.452 Y105.65 E.00639
G1 X91.283 Y105.56 E.00466
G1 X91.075 Y105.366 E.00692
G1 X90.886 Y105.064 E.00867
G1 X90.81 Y104.864 E.0052
G1 X90.745 Y104.428 E.01072
G1 X90.745 Y103.572 E.02082
G1 X90.861 Y102.98 E.01467
G1 X90.975 Y102.754 E.00616
G1 X91.158 Y102.546 E.00674
G1 X91.403 Y102.38 E.0072
G1 X91.708 Y102.287 E.00776
G1 X93.934 Y102.277 E.05415
G1 X93.934 Y96.669 E.13641
G1 X91.798 Y96.669 E.05196
G1 X91.531 Y96.631 E.00656
G1 X91.192 Y96.474 E.00909
G1 X91.018 Y96.313 E.00577
;WIDTH:0.443021
G1 X90.936 Y96.207 E.00364
;WIDTH:0.486042
G1 X90.853 Y96.101 E.00405
;WIDTH:0.529064
G1 X90.771 Y95.994 E.00444
;WIDTH:0.572085
G1 X90.689 Y95.888 E.00479
G1 X90.659 Y95.599 E.01039
;WIDTH:0.554329
G1 X90.665 Y93.136 E.0852
G1 X90.731 Y93.006 E.00504
;WIDTH:0.515747
G1 X90.797 Y92.876 E.00467
;WIDTH:0.477164
G1 X90.864 Y92.747 E.00428
;WIDTH:0.438582
G1 X90.93 Y92.617 E.00392
;WIDTH:0.399999
G1 X91.191 Y92.355 E.009
G1 X91.531 Y92.198 E.00911
G1 X91.799 Y92.16 E.00658
G1 X104.596 Y92.159 E.31127
G1 X103.538 Y91.245 E.03401
G1 X103.301 Y90.988 E.0085
G1 X103.165 Y90.701 E.00773
G1 X103.141 Y90.33 E.00904
G1 X103.257 Y90.083 E.00664
G1 X103.539 Y89.755 E.01052
G1 X104.634 Y88.807 E.03523
G1 X104.663 Y88.508 E.00731
G1 X104.765 Y88.356 E.00445
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X104.798 Y88.306 E-.02846
G1 X104.821 Y88.27 E-.02029
G1 X105.183 Y88.134 E-.18368
G1 X107.852 Y88.134 E-1.26757
;WIPE_END
G1 X107.852 Y88.151 F9000
G1 X104.651 Y88.151
G1 X91.439 Y92.238
G1 X91.273 Y92.316
G1 X91.123 Y92.422
G1 X90.994 Y92.552
G1 X90.889 Y92.703
G1 X90.812 Y92.869
G1 X90.765 Y93.046
G1 X90.756 Y93.149
G1 X90.751 Y93.206
G1 X90.753 Y144.059
G1 X90.754 Y144.102
G1 X90.755 Y144.201
G1 X90.756 Y144.275
G1 X90.76 Y144.421
G1 X90.764 Y144.476
G1 X90.783 Y144.654
G1 X90.79 Y144.708
G1 X90.844 Y144.937
G1 X90.926 Y145.134
G1 X91.013 Y145.28
G1 X91.054 Y145.339
G1 X91.197 Y145.485
G1 X91.372 Y145.604
G1 X91.565 Y145.679
G1 X91.698 Y145.702
G1 X91.779 Y145.708
G1 X105.684 Y145.71
G1 X105.496 Y150.29
G1 X105.496 Y150.692
G1 E5 F2400
G1 F6000
G1 X105.508 Y150.698 E.00033
G1 X105.556 Y150.822 E.00323
G1 X105.556 Y153.178 E.05731
G1 X105.5 Y153.311 E.00351
G1 X105.373 Y153.361 E.00332
G1 X91.795 Y153.359 E.33027
G1 X91.503 Y153.271 E.00742
G1 X91.302 Y153.082 E.00671
G1 X91.17 Y152.797 E.00764
G1 X91.106 Y152.287 E.0125
G1 X91.108 Y151.605 E.01659
G1 X91.196 Y151.13 E.01175
G1 X91.465 Y150.758 E.01117
G1 X91.763 Y150.643 E.00777
G1 X105.373 Y150.639 E.33105
G1 X105.441 Y150.668 E.0018
G1 X105.441 Y150.668 F9000
G1 X105.748 Y150.447
;TYPE:Perimeter
G1 F6000
G1 X105.84 Y150.534 E.00308
G1 X105.914 Y150.732 E.00514
G1 X105.922 Y150.822 E.0022
G1 X105.922 Y153.178 E.05731
G1 X105.857 Y153.436 E.00647
G1 X105.752 Y153.576 E.00426
G1 X105.468 Y153.719 E.00773
G1 X105.373 Y153.727 E.00232
G1 X91.798 Y153.725 E.3302
G1 X91.378 Y153.622 E.01052
;WIDTH:0.415198
G1 X91.043 Y153.362 E.01074
G1 X90.848 Y152.986 E.01073
;WIDTH:0.428861
G1 X90.78 Y152.661 E.00871
;WIDTH:0.462643
G1 X90.712 Y152.337 E.00943
;WIDTH:0.494696
G1 X90.695 Y151.97 E.01125
;WIDTH:0.526749
G1 X90.679 Y151.603 E.01203
;WIDTH:0.556318
G1 X90.698 Y151.364 E.00832
;WIDTH:0.585887
G1 X90.717 Y151.126 E.00876
G1 X90.806 Y151.003 E.00557
;WIDTH:0.539415
G1 X90.895 Y150.88 E.0051
;WIDTH:0.492943
G1 X90.985 Y150.758 E.00462
;WIDTH:0.446471
G1 X91.074 Y150.635 E.00416
;WIDTH:0.399999
G1 X91.316 Y150.424 E.00781
G1 X91.763 Y150.277 E.01145
G1 X105.373 Y150.273 E.33105
G1 X105.635 Y150.339 E.00657
G1 X105.705 Y150.405 E.00234
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X105.748 Y150.447 E-.02855
G1 X105.84 Y150.534 E-.06015
G1 X105.914 Y150.732 E-.1004
G1 X105.922 Y150.822 E-.04292
G1 X105.922 Y153.178 E-1.1191
G1 X105.857 Y153.436 E-.12638
G1 X105.828 Y153.474 E-.0225
;WIPE_END
G1 X105.905 Y153.474 F9000
G1 X125.095 Y150.702
G1 X125.501 Y150.701
G1 E5 F2400
G1 F6000
G1 X125.511 Y150.68 E.00057
G1 X125.627 Y150.639 E.00299
G1 X139.237 Y150.643 E.33105
G1 X139.535 Y150.758 E.00777
G1 X139.804 Y151.13 E.01117
G1 X139.892 Y151.607 E.0118
G1 X139.89 Y152.428 E.01997
G1 X139.813 Y152.855 E.01055
G1 X139.658 Y153.133 E.00774
G1 X139.425 Y153.307 E.00707
G1 X139.202 Y153.36 E.00558
G1 X137.948 Y153.36 E.0305
G1 X125.627 Y153.361 E.2997
G1 X125.5 Y153.311 E.00332
G1 X125.444 Y153.178 E.00351
G1 X125.444 Y150.822 E.05731
G1 X125.475 Y150.756 E.00177
G1 X125.475 Y150.756 F9000
G1 X125.245 Y150.442
;TYPE:Perimeter
G1 F6000
G1 X125.281 Y150.396 E.00142
G1 X125.483 Y150.292 E.00553
G1 X125.627 Y150.273 E.00353
G1 X139.237 Y150.277 E.33105
G1 X139.684 Y150.424 E.01145
G1 X139.926 Y150.635 E.00781
G1 X140.177 Y151.077 E.01236
;WIDTH:0.445453
G1 X140.227 Y151.254 E.00503
;WIDTH:0.490907
G1 X140.276 Y151.431 E.00558
;WIDTH:0.53636
G1 X140.326 Y151.608 E.00614
G1 X140.312 Y151.914 E.01023
;WIDTH:0.509384
G1 X140.297 Y152.22 E.00968
;WIDTH:0.482408
G1 X140.254 Y152.51 E.00874
;WIDTH:0.450656
G1 X140.21 Y152.8 E.00812
;WIDTH:0.418904
G1 X139.999 Y153.301 E.01391
;WIDTH:0.409859
G1 X139.737 Y153.548 E.00899
;WIDTH:0.402644
G1 X139.518 Y153.661 E.00604
;WIDTH:0.399999
G1 X139.202 Y153.725 E.00784
G1 X137.948 Y153.725 E.0305
G1 X125.627 Y153.727 E.2997
G1 X125.416 Y153.685 E.00523
G1 X125.248 Y153.576 E.00487
G1 X125.091 Y153.299 E.00774
G1 X125.078 Y153.178 E.00296
G1 X125.078 Y150.822 E.05731
G1 X125.133 Y150.583 E.00597
G1 X125.207 Y150.489 E.00291
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X125.245 Y150.442 E-.02871
G1 X125.281 Y150.396 E-.02775
G1 X125.483 Y150.292 E-.10792
G1 X125.627 Y150.273 E-.06899
G1 X128.294 Y150.274 E-1.26663
;WIPE_END
G1 X128.294 Y150.291 F9000
G1 X139.628 Y145.604
G1 X139.803 Y145.485
G1 X139.946 Y145.339
G1 X139.987 Y145.279
G1 X140.074 Y145.134
G1 X140.156 Y144.938
G1 X140.21 Y144.708
G1 X140.217 Y144.654
G1 X140.236 Y144.476
G1 X140.24 Y144.421
G1 X140.244 Y144.275
G1 X140.245 Y144.201
G1 X140.246 Y144.102
G1 X140.247 Y144.059
G1 X140.249 Y95.623
G1 X140.249 Y93.206
G1 X140.244 Y93.148
G1 X140.235 Y93.046
G1 X140.188 Y92.869
G1 X140.111 Y92.703
G1 X140.007 Y92.552
G1 X139.878 Y92.422
G1 X139.728 Y92.316
G1 X139.561 Y92.238
G1 X126.348 Y88.151
G1 X120.596 Y88.151
G1 X119.951 Y86.19
G1 X120.353 Y86.19
G1 E5 F2400
G1 F6000
G1 X120.3 Y86.067 E.00326
G1 X120.3 Y85.829 E.00579
G1 X110.7 Y85.829 E.23351
G1 X110.7 Y86.067 E.00579
G1 X110.644 Y86.199 E.00349
G1 X110.517 Y86.25 E.00333
G1 X104.199 Y86.25 E.15368
G1 X103.63 Y86.211 E.01387
G1 X103.058 Y86.091 E.01422
G1 X102.366 Y85.826 E.01802
G1 X101.594 Y85.342 E.02216
G1 X100.963 Y84.723 E.0215
G1 X100.468 Y83.972 E.02188
G1 X100.175 Y83.243 E.01911
G1 X100.013 Y82.364 E.02174
G1 X100 Y79.026 E.08119
G1 X98.778 Y77.968 E.03932
G1 X98.528 Y77.656 E.00972
G1 X98.506 Y77.376 E.00683
G1 X98.778 Y77.031 E.01069
G1 X100 Y75.975 E.03928
G1 X100.006 Y75.697 E.00676
G1 X100.06 Y75.608 E.00253
G1 X100.183 Y75.561 E.0032
G1 X130.817 Y75.561 E.74514
G1 X130.94 Y75.608 E.0032
G1 X131 Y75.744 E.00362
G1 X131 Y75.975 E.00562
G1 X132.222 Y77.032 E.0393
G1 X132.46 Y77.306 E.00883
G1 X132.495 Y77.623 E.00776
G1 X132.222 Y77.969 E.01072
G1 X131 Y79.025 E.03928
G1 X131 Y82.051 E.0736
G1 X130.969 Y82.529 E.01165
G1 X130.783 Y83.376 E.02109
G1 X130.404 Y84.202 E.02211
G1 X130.058 Y84.699 E.01473
G1 X129.436 Y85.318 E.02134
G1 X128.939 Y85.663 E.01472
G1 X128.493 Y85.892 E.01219
G1 X127.689 Y86.154 E.02057
G1 X127.105 Y86.239 E.01435
G1 X120.483 Y86.25 E.16107
G1 X120.403 Y86.218 E.0021
G1 X120.093 Y86.438 F9000
;TYPE:Perimeter
G1 F6000
G1 X119.989 Y86.194 E.00645
G1 X111.011 Y86.194 E.21838
G1 X110.896 Y86.463 E.00712
G1 X110.612 Y86.607 E.00775
G1 X110.517 Y86.616 E.00232
G1 X104.199 Y86.616 E.15368
G1 X103.604 Y86.575 E.01451
G1 X102.982 Y86.449 E.01544
G1 X102.235 Y86.167 E.01942
G1 X101.398 Y85.65 E.02393
G1 X100.706 Y84.983 E.02338
G1 X100.161 Y84.171 E.02379
G1 X99.835 Y83.378 E.02086
G1 X99.653 Y82.429 E.0235
G1 X99.635 Y79.193 E.07871
G1 X98.538 Y78.245 E.03527
G1 X98.214 Y77.86 E.01224
G1 X98.17 Y77.729 E.00336
G1 X98.131 Y77.422 E.00753
G1 X98.158 Y77.263 E.00392
G1 X98.539 Y76.755 E.01545
G1 X99.634 Y75.807 E.03523
G1 X99.653 Y75.604 E.00496
G1 X99.815 Y75.337 E.0076
;WIDTH:0.444401
G1 X99.902 Y75.271 E.00298
;WIDTH:0.488802
G1 X99.989 Y75.204 E.00332
;WIDTH:0.533203
G1 X100.077 Y75.138 E.00365
G1 X100.183 Y75.132 E.00352
;WIDTH:0.527248
G1 X130.817 Y75.132 E1.00445
G1 X130.94 Y75.2 E.00461
;WIDTH:0.484832
G1 X131.062 Y75.269 E.0042
;WIDTH:0.442416
G1 X131.185 Y75.337 E.00382
;WIDTH:0.399999
G1 X131.347 Y75.603 E.00758
G1 X131.366 Y75.807 E.00498
G1 X132.462 Y76.755 E.03525
G1 X132.795 Y77.159 E.01273
G1 X132.868 Y77.604 E.01097
G1 X132.796 Y77.84 E.006
G1 X132.461 Y78.245 E.01278
G1 X131.366 Y79.193 E.03523
G1 X131.366 Y82.051 E.06952
G1 X131.326 Y82.607 E.01356
G1 X131.14 Y83.455 E.02112
G1 X130.736 Y84.356 E.02402
G1 X130.357 Y84.909 E.01631
G1 X129.693 Y85.578 E.02293
G1 X129.146 Y85.965 E.0163
G1 X128.679 Y86.209 E.01282
G1 X128.141 Y86.391 E.01381
G1 X127.549 Y86.545 E.01488
G1 X127.08 Y86.606 E.0115
G1 X120.483 Y86.616 E.16047
G1 X120.133 Y86.475 E.00918
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X120.093 Y86.438 E-.02588
G1 X119.989 Y86.194 E-.12599
G1 X117.151 Y86.194 E-1.34813
;WIPE_END
G1 X120.133 Y74.21 F9000
G1 E5 F2400
G1 F6000
G1 X135.673 Y74.21 E.37799
G1 X136.197 Y74.242 E.01277
G1 X136.888 Y74.369 E.01709
G1 X137.557 Y74.577 E.01704
G1 X138.195 Y74.865 E.01703
G1 X138.792 Y75.226 E.01697
G1 X139.601 Y75.9 E.02561
G1 X140.273 Y76.706 E.02553
G1 X140.47 Y77.056 E.00977
G1 X140.788 Y77.62 E.01575
G1 X141.131 Y78.612 E.02553
G1 X141.289 Y79.653 E.02561
G1 X141.3 Y150.994 E1.7353
G1 X141.258 Y151.69 E.01696
G1 X141.136 Y152.37 E.0168
G1 X140.933 Y153.03 E.0168
G1 X140.652 Y153.662 E.01682
G1 X140.299 Y154.256 E.01681
G1 X139.878 Y154.804 E.01681
G1 X139.395 Y155.297 E.01679
G1 X138.715 Y155.826 E.02096
G1 X138.271 Y156.094 E.01261
G1 X137.525 Y156.435 E.01995
G1 X136.763 Y156.66 E.01933
G1 X135.923 Y156.776 E.02063
G1 X135.372 Y156.796 E.01341
G1 X133.855 Y156.742 E.03692
G1 X97.145 Y156.742 E.89293
G1 X95.34 Y156.797 E.04393
G1 X94.738 Y156.749 E.01469
G1 X94.048 Y156.615 E.0171
G1 X93.475 Y156.435 E.01461
G1 X92.878 Y156.173 E.01586
G1 X92.436 Y155.923 E.01235
G1 X91.604 Y155.295 E.02536
G1 X91.122 Y154.804 E.01674
G1 X90.701 Y154.256 E.01681
G1 X90.348 Y153.663 E.01679
G1 X90.008 Y152.859 E.02123
G1 X89.865 Y152.373 E.01232
G1 X89.711 Y151.343 E.02533
G1 X89.7 Y80.006 E1.7352
G1 X89.743 Y79.301 E.01718
G1 X89.869 Y78.612 E.01704
G1 X90.077 Y77.943 E.01704
G1 X90.365 Y77.305 E.01703
G1 X90.727 Y76.705 E.01704
G1 X91.159 Y76.154 E.01703
G1 X91.654 Y75.659 E.01703
G1 X92.245 Y75.202 E.01817
G1 X92.802 Y74.866 E.01582
G1 X93.777 Y74.462 E.02567
G1 X94.455 Y74.295 E.01698
G1 X95.15 Y74.211 E.01703
G1 X120.073 Y74.21 E.60623
G1 X120.073 Y74.639 F9000
;TYPE:Perimeter
;WIDTH:0.527248
G1 F6000
G1 X130.817 Y74.639 E.35228
G1 X131.037 Y74.618 E.00725
;WIDTH:0.484832
G1 X131.258 Y74.597 E.00665
;WIDTH:0.442416
G1 X131.478 Y74.575 E.006
;WIDTH:0.399999
G1 X135.37 Y74.575 E.09467
G1 X136.148 Y74.605 E.01894
G1 X136.8 Y74.725 E.01613
G1 X137.427 Y74.92 E.01597
G1 X138.025 Y75.189 E.01595
G1 X138.58 Y75.524 E.01577
G1 X139.341 Y76.159 E.02411
G1 X139.971 Y76.914 E.02392
G1 X140.152 Y77.236 E.00898
G1 X140.454 Y77.771 E.01494
G1 X140.774 Y78.7 E.0239
G1 X140.923 Y79.68 E.02411
G1 X140.925 Y92.73 E.31743
;WIDTH:0.439954
G1 X140.905 Y92.82 E.00249
;WIDTH:0.479908
G1 X140.885 Y92.91 E.00273
;WIDTH:0.519862
G1 X140.866 Y92.999 E.00294
;WIDTH:0.54685
G1 X140.852 Y93.228 E.00782
;WIDTH:0.547032
G1 X140.852 Y95.601 E.08093
;WIDTH:0.569223
G1 X140.841 Y95.933 E.01182
G1 X140.862 Y96.058 E.00451
;WIDTH:0.526917
G1 X140.884 Y96.183 E.00416
;WIDTH:0.484611
G1 X140.905 Y96.309 E.00383
;WIDTH:0.442305
G1 X140.926 Y96.434 E.00344
;WIDTH:0.399999
G1 X140.927 Y151.104 E1.32979
;WIDTH:0.445436
G1 X140.893 Y151.287 E.00509
;WIDTH:0.490873
G1 X140.858 Y151.47 E.00566
;WIDTH:0.53631
G1 X140.78 Y151.97 E.0169
;WIDTH:0.509359
G1 X140.736 Y152.286 E.01008
;WIDTH:0.482408
G1 X140.644 Y152.629 E.01058
;WIDTH:0.446441
G1 X140.553 Y152.972 E.00973
;WIDTH:0.414965
G1 X140.269 Y153.578 E.01695
G1 X139.996 Y154.05 E.01381
;WIDTH:0.399999
G1 X139.601 Y154.563 E.01575
G1 X139.151 Y155.023 E.01565
G1 X138.554 Y155.488 E.01841
G1 X138.1 Y155.77 E.013
G1 X137.396 Y156.091 E.01882
G1 X136.686 Y156.301 E.01801
G1 X135.873 Y156.414 E.01997
G1 X135.376 Y156.43 E.0121
G1 X133.855 Y156.376 E.03702
G1 X97.145 Y156.376 E.89293
G1 X95.349 Y156.431 E.04371
G1 X94.788 Y156.387 E.01369
G1 X94.138 Y156.26 E.01611
G1 X93.604 Y156.092 E.01362
G1 X93.042 Y155.845 E.01493
G1 X92.582 Y155.575 E.01297
G1 X91.807 Y154.981 E.02375
G1 X91.234 Y154.35 E.02073
;WIDTH:0.402669
G1 X90.896 Y153.867 E.01444
;WIDTH:0.404374
G1 X90.637 Y153.403 E.01308
;WIDTH:0.409014
G1 X90.444 Y152.939 E.01253
;WIDTH:0.443382
G1 X90.351 Y152.605 E.00943
;WIDTH:0.47775
G1 X90.259 Y152.271 E.01022
;WIDTH:0.526749
G1 X90.189 Y151.638 E.02086
;WIDTH:0.556318
G1 X90.179 Y151.36 E.00966
;WIDTH:0.585887
G1 X90.169 Y151.083 E.01017
G1 X90.147 Y150.988 E.00358
;WIDTH:0.541234
G1 X90.125 Y150.894 E.00326
;WIDTH:0.49658
G1 X90.102 Y150.799 E.00301
;WIDTH:0.451926
G1 X90.08 Y150.705 E.00268
;WIDTH:0.407272
G1 X90.076 Y150.349 E.00883
;WIDTH:0.399999
G1 X90.074 Y136.767 E.33037
;WIDTH:0.438535
G1 X90.093 Y136.635 E.00359
;WIDTH:0.477071
G1 X90.113 Y136.502 E.00396
;WIDTH:0.515607
G1 X90.132 Y136.369 E.0043
;WIDTH:0.554143
G1 X90.151 Y136.236 E.00465
G1 X90.148 Y135.897 E.01172
;WIDTH:0.563096
G1 X90.155 Y135.343 E.01949
G1 X90.135 Y135.27 E.00266
;WIDTH:0.522322
G1 X90.115 Y135.196 E.00249
;WIDTH:0.481548
G1 X90.094 Y135.123 E.00226
;WIDTH:0.440774
G1 X90.074 Y135.05 E.00205
;WIDTH:0.399999
G1 X90.068 Y96.341 E.94156
;WIDTH:0.443021
G1 X90.09 Y96.24 E.00281
;WIDTH:0.486042
G1 X90.111 Y96.138 E.00313
;WIDTH:0.529064
G1 X90.133 Y96.036 E.00343
;WIDTH:0.572085
G1 X90.154 Y95.935 E.00369
G1 X90.143 Y95.601 E.01195
;WIDTH:0.554329
G1 X90.145 Y93.135 E.0853
G1 X90.125 Y93.013 E.00428
;WIDTH:0.515747
G1 X90.106 Y92.891 E.00395
;WIDTH:0.477164
G1 X90.087 Y92.769 E.00364
;WIDTH:0.438582
G1 X90.068 Y92.647 E.00332
;WIDTH:0.399999
G1 X90.066 Y80.017 E.30721
G1 X90.106 Y79.345 E.01637
G1 X90.225 Y78.7 E.01595
G1 X90.42 Y78.073 E.01597
G1 X90.689 Y77.475 E.01595
G1 X91.028 Y76.914 E.01594
G1 X91.433 Y76.397 E.01597
G1 X91.896 Y75.934 E.01593
G1 X92.452 Y75.504 E.0171
G1 X92.968 Y75.193 E.01465
G1 X93.892 Y74.811 E.02432
G1 X94.521 Y74.656 E.01576
G1 X95.172 Y74.577 E.01595
G1 X99.523 Y74.576 E.10583
;WIDTH:0.442234
G1 X99.743 Y74.598 E.006
;WIDTH:0.484468
G1 X99.963 Y74.619 E.00662
;WIDTH:0.526702
G1 X100.183 Y74.64 E.00724
;WIDTH:0.527248
G1 X120.013 Y74.639 E.6502
G1 E-5 F3600
G1 X120.013 Y74.639 F9000
G1 X120.013 Y74.549
G1 X92.68 Y75.335
G1 X90.049 Y80.008
G1 X90.049 Y112.933
G1 X90.443 Y112.933
G1 E5 F2400
;WIDTH:0.414294
G1 F6000
G1 X90.425 Y112.68 E.00641
;WIDTH:0.378506
G1 X90.408 Y112.428 E.00578
;WIDTH:0.342854
G1 X90.407 Y111.572 E.01757
;WIDTH:0.378097
G1 X90.425 Y111.323 E.00571
;WIDTH:0.41334
G1 X90.443 Y111.075 E.00627
G1 E-5 F3600
G1 X90.443 Y111.075 F9000
G1 X90.82 Y111.163
G1 X90.79 Y111.292
G1 X90.783 Y111.346
G1 X90.764 Y111.524
G1 X90.76 Y111.579
G1 X90.756 Y111.725
G1 X90.755 Y111.799
G1 X90.754 Y111.898
G1 X90.753 Y111.941
G1 X90.753 Y112.059
G1 X90.754 Y112.102
G1 X90.755 Y112.201
G1 X90.756 Y112.275
G1 X90.76 Y112.421
G1 X90.764 Y112.476
G1 X90.783 Y112.654
G1 X90.79 Y112.708
G1 X90.844 Y112.937
G1 X90.926 Y113.134
G1 X93.951 Y118.291
G1 X93.568 Y118.29
G1 X93.569 Y117.913
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X91.706 Y117.921 E.04532
G1 X91.198 Y118.077 E.01293
G1 X90.953 Y118.243 E.0072
G1 X90.649 Y118.589 E.0112
;WIDTH:0.412138
G1 X90.443 Y119.075 E.01327
G1 X90.437 Y118.539 E.01347
;WIDTH:0.399999
G1 X90.436 Y113.461 E.12352
;WIDTH:0.414294
G1 X90.443 Y112.933 E.01335
G1 X90.648 Y113.411 E.01315
;WIDTH:0.399999
G1 X90.952 Y113.756 E.01118
G1 X91.197 Y113.922 E.0072
G1 X91.705 Y114.079 E.01293
G1 X93.569 Y114.087 E.04534
G1 X93.569 Y117.853 E.0916
G1 X93.569 Y117.853 F9000
G1 X93.203 Y117.549
G1 F6000
G1 X91.704 Y117.555 E.03646
G1 X90.994 Y117.774 E.01807
G1 X90.803 Y117.903 E.00561
G1 X90.802 Y114.096 E.0926
G1 X90.992 Y114.225 E.00559
G1 X91.704 Y114.445 E.01813
G1 X93.203 Y114.451 E.03646
G1 X93.203 Y117.489 E.0739
G1 X92.837 Y117.185 F9000
G1 F6000
G1 X91.703 Y117.19 E.02758
G1 X91.168 Y117.354 E.01361
G1 X91.168 Y114.645 E.06589
G1 X91.702 Y114.81 E.01359
G1 X92.837 Y114.815 E.02761
G1 X92.837 Y117.125 E.05619
G1 E-5 F3600
G1 X92.837 Y117.125 F9000
G1 X90.926 Y113.134
G1 X90.844 Y112.937
G1 X90.79 Y112.708
G1 X90.783 Y112.654
G1 X90.764 Y112.476
G1 X90.76 Y112.421
G1 X90.756 Y112.275
G1 X90.755 Y112.201
G1 X90.754 Y112.102
G1 X90.753 Y112.059
G1 X90.753 Y111.941
G1 X90.754 Y111.898
G1 X90.755 Y111.799
G1 X90.844 Y104.937
G1 X90.822 Y104.844
G1 X90.443 Y104.933
G1 E5 F2400
;WIDTH:0.415498
G1 F6000
G1 X90.425 Y104.68 E.00643
;WIDTH:0.379705
G1 X90.407 Y104.428 E.0058
;WIDTH:0.34405
G1 X90.407 Y103.572 E.01764
;WIDTH:0.379298
G1 X90.424 Y103.323 E.00573
;WIDTH:0.414546
G1 X90.442 Y103.075 E.00629
G1 E-5 F3600
G1 X90.442 Y103.075 F9000
G1 X90.82 Y103.163
G1 X90.79 Y103.292
G1 X90.783 Y103.346
G1 X90.764 Y103.524
G1 X90.76 Y103.579
G1 X90.756 Y103.725
G1 X90.755 Y103.799
G1 X90.754 Y103.898
G1 X90.753 Y103.941
G1 X90.753 Y104.059
G1 X90.754 Y104.102
G1 X90.755 Y104.201
G1 X90.756 Y104.275
G1 X90.76 Y104.421
G1 X90.764 Y104.476
G1 X90.783 Y104.654
G1 X90.79 Y104.708
G1 X90.844 Y104.937
G1 X90.926 Y105.134
G1 X91.013 Y105.279
G1 X91.054 Y105.339
G1 X91.197 Y105.485
G1 X91.372 Y105.604
G1 X91.565 Y105.679
G1 X91.698 Y105.702
G1 X91.779 Y105.708
G1 X93.217 Y105.71
G1 X93.951 Y105.709
G1 X93.951 Y107.719
G1 X93.569 Y107.719
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.569 Y109.913 E.05337
G1 X91.706 Y109.921 E.04532
G1 X91.198 Y110.077 E.01293
G1 X90.953 Y110.243 E.0072
G1 X90.649 Y110.589 E.0112
;WIDTH:0.41334
G1 X90.443 Y111.075 E.01331
G1 X90.436 Y110.538 E.01354
;WIDTH:0.399999
G1 X90.435 Y105.654 E.1188
;WIDTH:0.415498
G1 X90.443 Y104.933 E.01828
G1 X90.575 Y105.258 E.00889
;WIDTH:0.40109
G1 X90.764 Y105.56 E.00869
;WIDTH:0.399999
G1 X91.112 Y105.883 E.01155
G1 X91.281 Y105.973 E.00466
G1 X91.705 Y106.079 E.01063
G1 X93.569 Y106.087 E.04534
G1 X93.569 Y107.659 E.03824
G1 X93.569 Y107.659 F9000
G1 X93.203 Y107.902
G1 F6000
G1 X93.203 Y109.549 E.04006
G1 X91.704 Y109.555 E.03646
G1 X90.994 Y109.774 E.01807
G1 X90.801 Y109.904 E.00566
G1 X90.801 Y106.076 E.09311
G1 X90.941 Y106.206 E.00465
G1 X91.11 Y106.296 E.00466
G1 X91.703 Y106.445 E.01487
G1 X93.203 Y106.451 E.03649
G1 X93.203 Y107.842 E.03383
G1 X93.203 Y107.842 F9000
G1 X92.837 Y108.086
G1 F6000
G1 X92.837 Y109.185 E.02673
G1 X91.703 Y109.19 E.02758
G1 X91.167 Y109.355 E.01364
G1 X91.167 Y106.676 E.06516
G1 X91.702 Y106.81 E.01342
G1 X92.837 Y106.815 E.02761
G1 X92.837 Y108.026 E.02946
G1 E-5 F3600
G1 X92.837 Y108.026 F9000
G1 X91.013 Y105.279
G1 X90.926 Y105.134
G1 X90.844 Y104.937
G1 X90.79 Y104.708
G1 X90.783 Y104.654
G1 X90.764 Y104.476
G1 X90.76 Y104.421
G1 X90.756 Y104.275
G1 X90.755 Y104.201
G1 X90.754 Y104.102
G1 X90.753 Y104.059
G1 X90.753 Y103.941
G1 X90.754 Y103.898
G1 X90.755 Y103.799
G1 X90.756 Y103.725
G1 X90.76 Y103.579
G1 X90.764 Y103.524
G1 X90.783 Y103.346
G1 X90.79 Y103.292
G1 X90.844 Y103.062
G1 X90.926 Y102.866
G1 X91.013 Y102.721
G1 X91.054 Y102.661
G1 X91.197 Y102.515
G1 X91.372 Y102.396
G1 X91.565 Y102.321
G1 X91.698 Y102.298
G1 X91.779 Y102.292
G1 X93.217 Y102.29
G1 X93.492 Y102.29
G1 X93.568 Y102.29
G1 X93.569 Y101.913
G1 E5 F2400
G1 F6000
G1 X91.706 Y101.921 E.04532
G1 X91.198 Y102.077 E.01293
G1 X90.953 Y102.243 E.0072
G1 X90.649 Y102.589 E.0112
;WIDTH:0.414546
G1 X90.442 Y103.075 E.01336
G1 X90.435 Y102.538 E.01358
;WIDTH:0.399999
G1 X90.434 Y95.986 E.15937
G1 X90.563 Y96.301 E.00828
G1 X90.718 Y96.522 E.00657
G1 X91.008 Y96.79 E.0096
G1 X91.469 Y96.991 E.01223
G1 X91.798 Y97.034 E.00807
G1 X93.569 Y97.035 E.04308
G1 X93.569 Y101.853 E.11719
G1 X93.569 Y101.853 F9000
G1 X93.203 Y101.549
G1 F6000
G1 X91.704 Y101.555 E.03646
G1 X90.994 Y101.774 E.01807
G1 X90.8 Y101.905 E.00569
G1 X90.8 Y97.083 E.11729
G1 X91.407 Y97.352 E.01615
G1 X91.798 Y97.4 E.00958
G1 X93.203 Y97.4 E.03418
G1 X93.203 Y101.489 E.09946
G1 X92.837 Y101.185 F9000
G1 F6000
G1 X91.703 Y101.19 E.02758
G1 X91.166 Y101.355 E.01366
G1 X91.165 Y97.647 E.09019
G1 X91.346 Y97.712 E.00468
G1 X91.798 Y97.766 E.01107
G1 X92.837 Y97.766 E.02527
G1 X92.837 Y101.125 E.0817
G1 E-5 F3600
G1 X92.837 Y101.125 F9000
G1 X90.812 Y95.959
G1 X90.765 Y95.783
G1 X90.756 Y95.68
G1 X90.751 Y95.623
G1 X90.751 Y93.206
G1 X90.756 Y93.149
G1 X90.765 Y93.046
G1 X90.812 Y92.869
G1 X90.889 Y92.703
G1 X90.994 Y92.552
G1 X91.123 Y92.422
G1 X91.273 Y92.316
G1 X91.439 Y92.238
G1 X104.651 Y88.151
G1 X109.311 Y88.151
G1 X111.048 Y86.598
G1 X111.165 Y86.692
G1 E5 F2400
G1 F6000
G1 X111.221 Y86.56 E.00349
G1 X119.779 Y86.56 E.20816
G1 X119.851 Y86.728 E.00445
G1 X120.483 Y86.981 E.01656
G1 X127.207 Y86.963 E.16356
G1 X127.76 Y86.885 E.01358
G1 X128.254 Y86.739 E.01253
G1 X128.846 Y86.534 E.01524
G1 X129.353 Y86.266 E.01395
G1 X129.951 Y85.838 E.01789
G1 X130.656 Y85.12 E.02448
G1 X131.068 Y84.51 E.0179
G1 X131.497 Y83.533 E.02595
G1 X131.684 Y82.686 E.0211
G1 X131.731 Y82.051 E.01549
G1 X131.731 Y79.36 E.06546
G1 X132.701 Y78.522 E.03118
G1 X133.025 Y78.15 E.012
G1 X133.191 Y77.848 E.00838
G1 X133.233 Y77.517 E.00812
G1 X133.129 Y77.012 E.01254
G1 X132.971 Y76.767 E.00709
G1 X132.701 Y76.478 E.00962
G1 X131.716 Y75.627 E.03166
G1 X131.701 Y75.51 E.00287
G1 X131.43 Y75.066 E.01265
G1 X131.106 Y74.941 E.00845
G1 X135.37 Y74.941 E.10372
G1 X136.1 Y74.968 E.01777
G1 X136.713 Y75.08 E.01516
G1 X137.297 Y75.262 E.01488
G1 X137.855 Y75.513 E.01488
G1 X138.367 Y75.823 E.01456
G1 X139.082 Y76.419 E.02264
G1 X139.668 Y77.123 E.02228
G1 X139.833 Y77.415 E.00816
G1 X140.119 Y77.921 E.01414
G1 X140.418 Y78.788 E.02231
G1 X140.558 Y79.708 E.02264
G1 X140.56 Y92.837 E.31935
G1 X140.298 Y92.325 E.01399
G1 X140.109 Y92.133 E.00655
G1 X139.694 Y91.893 E.01166
G1 X139.201 Y91.794 E.01223
G1 X127.386 Y91.793 E.28739
G1 X127.701 Y91.522 E.01011
G1 X128.025 Y91.15 E.012
G1 X128.216 Y90.751 E.01076
G1 X128.225 Y90.432 E.00776
G1 X128.131 Y90.014 E.01042
G1 X128.037 Y89.85 E.0046
G1 X127.701 Y89.478 E.01219
G1 X126.723 Y88.633 E.03144
G1 X126.684 Y88.391 E.00596
G1 X126.532 Y88.113 E.00771
G1 X126.233 Y87.869 E.00939
G1 X125.817 Y87.769 E.01041
G1 X105.183 Y87.769 E.5019
G1 X104.581 Y87.995 E.01564
G1 X104.359 Y88.286 E.0089
G1 X104.277 Y88.633 E.00867
G1 X103.281 Y89.495 E.03204
G1 X102.914 Y89.933 E.0139
G1 X102.781 Y90.262 E.00863
G1 X102.803 Y90.755 E.012
G1 X103.029 Y91.233 E.01286
G1 X103.219 Y91.443 E.00689
G1 X103.614 Y91.793 E.01284
G1 X91.798 Y91.794 E.28741
G1 X91.469 Y91.837 E.00807
G1 X91.007 Y92.039 E.01226
G1 X90.649 Y92.383 E.01208
G1 X90.433 Y92.82 E.01186
G1 X90.431 Y80.028 E.31115
G1 X90.47 Y79.389 E.01557
G1 X90.58 Y78.787 E.01489
G1 X90.762 Y78.203 E.01488
G1 X91.013 Y77.645 E.01488
G1 X91.33 Y77.122 E.01488
G1 X91.707 Y76.64 E.01488
G1 X92.138 Y76.209 E.01483
G1 X92.658 Y75.806 E.016
G1 X93.133 Y75.521 E.01347
G1 X94.006 Y75.159 E.02299
G1 X94.587 Y75.016 E.01455
G1 X95.194 Y74.942 E.01487
G1 X99.823 Y74.942 E.1126
G1 X99.57 Y75.066 E.00685
G1 X99.299 Y75.51 E.01265
G1 X99.284 Y75.627 E.00287
G1 X98.299 Y76.478 E.03166
G1 X97.975 Y76.85 E.012
G1 X97.81 Y77.149 E.00831
G1 X97.765 Y77.415 E.00656
G1 X97.803 Y77.755 E.00832
G1 X97.922 Y78.088 E.0086
G1 X98.299 Y78.522 E.01398
G1 X99.27 Y79.361 E.03121
G1 X99.279 Y82.334 E.07232
G1 X99.293 Y82.493 E.00388
G1 X99.495 Y83.513 E.02529
G1 X99.855 Y84.371 E.02263
G1 X100.448 Y85.243 E.02565
G1 X101.201 Y85.959 E.02527
G1 X101.927 Y86.421 E.02093
G1 X102.422 Y86.632 E.01309
G1 X102.906 Y86.806 E.01251
G1 X103.579 Y86.94 E.01669
G1 X104.199 Y86.981 E.01511
G1 X110.517 Y86.981 E.15368
G1 X110.675 Y86.968 E.00386
G1 X111.131 Y86.737 E.01243
G1 X111.131 Y86.737 F9000
G1 X110.745 Y87.365
;WIDTH:0.47584
G1 F6000
G1 X110.517 Y87.375 E.0067
;WIDTH:0.456022
G1 X105.183 Y87.375 E.14962
G1 E-5 F3600
G1 X105.183 Y87.375 F9000
G1 X110.745 Y87.365
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X111.421 Y87.012 E.0224
;WIDTH:0.455842
G1 X111.446 Y86.954 E.00177
G1 X119.554 Y86.954 E.22734
G1 X119.579 Y87.012 E.00177
;WIDTH:0.455998
G1 X120.483 Y87.375 E.02732
G1 X119.433 Y87.375 E.02945
;WIDTH:0.455842
G1 X111.567 Y87.375 E.22055
;WIDTH:0.47584
G1 X110.805 Y87.366 E.02238
G1 E-5 F3600
G1 X110.805 Y87.366 F9000
G1 X125.817 Y87.371
G1 E5 F2400
;WIDTH:0.463876
G1 F6000
G1 X120.485 Y87.375 E.15235
;WIDTH:0.455998
G1 X120.483 Y87.375 E.00006
G1 E-5 F3600
G1 X120.483 Y87.375 F9000
G1 X125.817 Y87.371
G1 E5 F2400
;WIDTH:0.463876
G1 F6000
G1 X126.133 Y87.355 E.00904
;WIDTH:0.431938
G1 X126.449 Y87.338 E.00837
;WIDTH:0.399999
G1 X127.258 Y87.325 E.01968
G1 X127.811 Y87.247 E.01358
G1 X128.367 Y87.087 E.01407
G1 X129.013 Y86.86 E.01666
G1 X129.561 Y86.567 E.01512
G1 X130.208 Y86.098 E.01944
G1 X130.955 Y85.33 E.02606
G1 X131.399 Y84.664 E.01947
G1 X131.854 Y83.612 E.02788
G1 X132.068 Y82.566 E.02597
G1 X132.097 Y82.051 E.01255
G1 X132.097 Y79.527 E.06139
G1 X132.94 Y78.798 E.02711
G1 X133.088 Y78.647 E.00514
G1 X133.43 Y78.205 E.01359
G1 X133.577 Y77.812 E.01021
G1 X133.586 Y77.378 E.01056
G1 X133.464 Y76.865 E.01283
G1 X133.242 Y76.521 E.00996
G1 X132.94 Y76.202 E.01068
G1 X132.081 Y75.46 E.02761
G1 X131.988 Y75.307 E.00436
G1 X135.37 Y75.307 E.08226
G1 X136.052 Y75.331 E.0166
G1 X136.625 Y75.436 E.01417
G1 X137.167 Y75.605 E.01381
G1 X137.684 Y75.838 E.01379
G1 X138.154 Y76.122 E.01336
G1 X138.822 Y76.678 E.02114
G1 X139.366 Y77.332 E.02069
G1 X139.515 Y77.595 E.00735
G1 X139.784 Y78.072 E.01332
G1 X140.061 Y78.876 E.02068
G1 X140.192 Y79.736 E.02116
G1 X140.194 Y91.775 E.29284
G1 X139.787 Y91.54 E.01143
G1 X139.201 Y91.428 E.01451
G1 X128.269 Y91.428 E.26591
G1 X128.306 Y91.383 E.00142
G1 X128.574 Y90.824 E.01508
G1 X128.586 Y90.378 E.01085
G1 X128.466 Y89.868 E.01274
G1 X128.292 Y89.581 E.00816
G1 X127.94 Y89.202 E.01258
G1 X127.057 Y88.438 E.0284
G1 X127.03 Y88.274 E.00404
G1 X126.818 Y87.885 E.01078
G1 X126.4 Y87.543 E.01314
;WIDTH:0.431938
G1 X126.109 Y87.457 E.00803
;WIDTH:0.463876
G1 X125.875 Y87.388 E.00697
G1 E-5 F3600
G1 X125.875 Y87.388 F9000
G1 X128.854 Y91.062
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X128.932 Y90.898 E.00442
G1 X128.948 Y90.323 E.01399
G1 X128.801 Y89.722 E.01505
G1 X128.578 Y89.352 E.01051
G1 X128.179 Y88.925 E.01422
G1 X127.391 Y88.244 E.02533
G1 X127.377 Y88.158 E.00212
G1 X127.133 Y87.699 E.01264
G1 X127.862 Y87.609 E.01787
G1 X128.48 Y87.434 E.01562
G1 X129.179 Y87.185 E.01805
G1 X129.768 Y86.868 E.01627
G1 X130.465 Y86.358 E.02101
G1 X131.254 Y85.541 E.02763
G1 X131.731 Y84.818 E.02107
G1 X132.097 Y84.03 E.02113
G1 X132.211 Y83.69 E.00872
G1 X132.433 Y82.588 E.02734
G1 X132.463 Y82.051 E.01308
G1 X132.463 Y79.694 E.05733
G1 X133.179 Y79.075 E.02302
G1 X133.588 Y78.617 E.01494
G1 X133.823 Y78.237 E.01087
G1 X133.951 Y77.787 E.01138
G1 X133.948 Y77.323 E.01129
G1 X133.799 Y76.718 E.01516
G1 X133.513 Y76.276 E.01281
G1 X133.323 Y76.066 E.00689
G1 X132.886 Y75.672 E.01431
G1 X135.916 Y75.686 E.0737
G1 X136.413 Y75.769 E.01226
G1 X136.905 Y75.906 E.01242
G1 X137.378 Y76.101 E.01244
G1 X137.941 Y76.42 E.01574
G1 X138.562 Y76.938 E.01967
G1 X138.892 Y77.333 E.01252
G1 X139.196 Y77.775 E.01305
G1 X139.449 Y78.223 E.01251
G1 X139.705 Y78.964 E.01907
G1 X139.826 Y79.763 E.01966
G1 X139.828 Y91.172 E.27751
G1 X139.201 Y91.063 E.01548
G1 X128.914 Y91.062 E.25022
G1 E-5 F3600
G1 X128.914 Y91.062 F9000
G1 X126.348 Y88.151
G1 X104.651 Y88.151
G1 X98.964 Y91.428
G1 E5 F2400
G1 F6000
G1 X91.798 Y91.428 E.17431
G1 X91.583 Y91.447 E.00525
G1 X90.979 Y91.632 E.01537
G1 X90.799 Y91.744 E.00516
G1 X90.797 Y80.039 E.28471
G1 X90.834 Y79.433 E.01477
G1 X90.936 Y78.875 E.0138
G1 X91.105 Y78.333 E.01381
G1 X91.338 Y77.815 E.01382
G1 X91.631 Y77.33 E.01378
G1 X91.982 Y76.883 E.01382
G1 X92.381 Y76.484 E.01373
G1 X92.865 Y76.108 E.01491
G1 X93.298 Y75.848 E.01229
G1 X94.12 Y75.508 E.02164
G1 X94.653 Y75.376 E.01336
G1 X95.216 Y75.308 E.01379
G1 X99.012 Y75.308 E.09233
G1 X98.943 Y75.439 E.0036
G1 X98.06 Y76.202 E.02839
G1 X97.694 Y76.617 E.01346
G1 X97.463 Y77.036 E.01164
G1 X97.4 Y77.408 E.00918
G1 X97.453 Y77.873 E.01138
G1 X97.608 Y78.275 E.01048
G1 X98.06 Y78.798 E.01681
G1 X98.905 Y79.529 E.02718
G1 X98.913 Y82.336 E.06828
G1 X98.933 Y82.558 E.00542
G1 X99.155 Y83.648 E.02706
G1 X99.549 Y84.571 E.02441
G1 X100.191 Y85.503 E.02753
G1 X101.005 Y86.267 E.02715
G1 X101.731 Y86.73 E.02094
G1 X102.29 Y86.973 E.01483
G1 X102.83 Y87.164 E.01393
G1 X103.553 Y87.305 E.01792
G1 X104.199 Y87.347 E.01575
;WIDTH:0.428011
G1 X104.691 Y87.361 E.01289
;WIDTH:0.456022
G1 X105.183 Y87.375 E.01381
G1 X104.761 Y87.548 E.01279
;WIDTH:0.428011
G1 X104.34 Y87.72 E.01191
;WIDTH:0.399999
G1 X104.03 Y88.127 E.01244
G1 X103.943 Y88.438 E.00786
G1 X103.034 Y89.225 E.02925
G1 X102.608 Y89.733 E.01613
G1 X102.422 Y90.193 E.01207
G1 X102.442 Y90.81 E.01502
G1 X102.734 Y91.428 E.01663
G1 X99.024 Y91.428 E.09024
G1 X99.024 Y91.428 F9000
G1 X98.385 Y91.062
G1 F6000
G1 X91.798 Y91.063 E.16022
G1 X91.521 Y91.086 E.00676
G1 X91.164 Y91.182 E.00899
G1 X91.163 Y80.15 E.26834
G1 X91.186 Y79.672 E.01164
G1 X91.257 Y79.151 E.01279
G1 X91.391 Y78.643 E.01278
G1 X91.586 Y78.154 E.01281
G1 X91.84 Y77.692 E.01282
G1 X92.148 Y77.263 E.01285
G1 X92.499 Y76.883 E.01258
G1 X92.951 Y76.505 E.01433
G1 X93.463 Y76.176 E.0148
G1 X94.084 Y75.918 E.01636
G1 X94.719 Y75.737 E.01606
G1 X95.238 Y75.674 E.01272
G1 X98.112 Y75.673 E.06991
G1 X97.821 Y75.925 E.00936
G1 X97.412 Y76.383 E.01494
G1 X97.115 Y76.922 E.01497
G1 X97.034 Y77.401 E.01182
G1 X97.08 Y77.864 E.01132
G1 X97.206 Y78.294 E.0109
G1 X97.487 Y78.724 E.01249
G1 X97.821 Y79.075 E.01179
G1 X98.54 Y79.696 E.02311
G1 X98.547 Y82.337 E.06424
G1 X98.573 Y82.623 E.00699
G1 X98.815 Y83.782 E.0288
G1 X99.091 Y84.479 E.01823
G1 X99.242 Y84.771 E.008
G1 X99.713 Y85.492 E.02095
G1 X99.934 Y85.763 E.00851
G1 X100.535 Y86.358 E.02057
G1 X100.808 Y86.575 E.00848
G1 X101.664 Y87.113 E.02459
G1 X102.159 Y87.314 E.013
G1 X102.754 Y87.522 E.01533
G1 X103.324 Y87.642 E.01417
G1 X103.894 Y87.695 E.01392
G1 X103.701 Y87.968 E.00813
G1 X103.609 Y88.244 E.00708
G1 X102.63 Y89.12 E.03195
G1 X102.226 Y89.661 E.01642
G1 X102.063 Y90.124 E.01194
G1 X102.08 Y90.864 E.018
G1 X102.174 Y91.062 E.00533
G1 X98.445 Y91.062 E.0907
G1 E-5 F3600
G1 X98.445 Y91.062 F9000
G1 X104.651 Y88.151
G1 X126.348 Y88.151
G1 X139.561 Y92.238
G1 X139.728 Y92.316
G1 X139.878 Y92.422
G1 X140.007 Y92.552
G1 X140.111 Y92.703
G1 X140.188 Y92.869
G1 X140.235 Y93.046
G1 X140.244 Y93.148
G1 X140.249 Y93.206
G1 X140.249 Y95.623
G1 X140.156 Y103.063
G1 X140.178 Y103.156
G1 X140.555 Y103.068
G1 E5 F2400
;WIDTH:0.411842
G1 F6000
G1 X140.573 Y103.32 E.00634
;WIDTH:0.376065
G1 X140.591 Y103.572 E.00574
;WIDTH:0.340424
G1 X140.591 Y104.428 E.01743
;WIDTH:0.375659
G1 X140.574 Y104.677 E.00567
;WIDTH:0.410894
G1 X140.556 Y104.925 E.00623
G1 E-5 F3600
G1 X140.556 Y104.925 F9000
G1 X140.18 Y104.837
G1 X140.21 Y104.708
G1 X140.217 Y104.654
G1 X140.236 Y104.476
G1 X140.24 Y104.421
G1 X140.244 Y104.275
G1 X140.245 Y104.201
G1 X140.246 Y104.102
G1 X140.247 Y104.059
G1 X140.247 Y103.941
G1 X140.246 Y103.898
G1 X140.245 Y103.799
G1 X140.244 Y103.725
G1 X140.24 Y103.579
G1 X140.236 Y103.524
G1 X140.217 Y103.346
G1 X140.21 Y103.292
G1 X140.074 Y102.866
G1 X139.987 Y102.721
G1 X139.946 Y102.661
G1 X139.803 Y102.515
G1 X139.628 Y102.396
G1 X139.435 Y102.321
G1 X139.302 Y102.298
G1 X139.221 Y102.292
G1 X137.783 Y102.29
G1 X137.508 Y102.29
G1 X137.432 Y102.29
G1 X137.431 Y101.913
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y97.035 E.11865
G1 X138.996 Y97.034 E.03807
G1 X139.531 Y96.991 E.01306
G1 X139.906 Y96.836 E.00987
G1 X140.125 Y96.681 E.00653
G1 X140.391 Y96.389 E.00961
;WIDTH:0.411703
G1 X140.543 Y96.11 E.00798
G1 X140.56 Y96.434 E.00814
;WIDTH:0.399999
G1 X140.561 Y102.347 E.14383
;WIDTH:0.411842
G1 X140.555 Y103.068 E.01811
G1 X140.425 Y102.742 E.00881
;WIDTH:0.400854
G1 X140.236 Y102.44 E.00869
;WIDTH:0.399999
G1 X139.888 Y102.117 E.01155
G1 X139.719 Y102.027 E.00466
G1 X139.295 Y101.921 E.01063
G1 X137.491 Y101.913 E.04388
G1 X137.491 Y101.913 F9000
G1 X137.797 Y101.549
G1 F6000
G1 X137.797 Y97.4 E.10092
G1 X138.996 Y97.4 E.02916
G1 X139.593 Y97.352 E.01457
G1 X140.195 Y97.08 E.01607
G1 X140.195 Y101.92 E.11773
G1 X139.89 Y101.704 E.00909
G1 X139.297 Y101.555 E.01487
G1 X137.857 Y101.549 E.03503
G1 X137.857 Y101.549 F9000
G1 X138.163 Y101.185
G1 F6000
G1 X138.163 Y97.766 E.08316
G1 X139.479 Y97.742 E.03202
G1 X139.829 Y97.64 E.00887
G1 X139.83 Y101.323 E.08959
G1 X139.298 Y101.19 E.01334
G1 X138.223 Y101.185 E.02615
G1 E-5 F3600
G1 X138.223 Y101.185 F9000
G1 X140.21 Y103.292
G1 X140.24 Y103.579
G1 X140.156 Y111.063
G1 X140.178 Y111.156
G1 X140.556 Y111.067
G1 E5 F2400
;WIDTH:0.413078
G1 F6000
G1 X140.574 Y111.32 E.00639
;WIDTH:0.377296
G1 X140.592 Y111.572 E.00576
;WIDTH:0.341652
G1 X140.592 Y112.428 E.0175
;WIDTH:0.37689
G1 X140.574 Y112.677 E.00569
;WIDTH:0.412128
G1 X140.557 Y112.925 E.00625
G1 E-5 F3600
G1 X140.557 Y112.925 F9000
G1 X140.18 Y112.837
G1 X140.21 Y112.708
G1 X140.217 Y112.654
G1 X140.236 Y112.476
G1 X140.24 Y112.421
G1 X140.244 Y112.275
G1 X140.245 Y112.201
G1 X140.246 Y112.102
G1 X140.247 Y112.059
G1 X140.247 Y111.941
G1 X140.246 Y111.898
G1 X140.245 Y111.799
G1 X140.244 Y111.725
G1 X140.24 Y111.579
G1 X140.236 Y111.524
G1 X140.217 Y111.346
G1 X140.21 Y111.292
G1 X140.074 Y110.865
G1 X139.987 Y110.721
G1 X139.946 Y110.661
G1 X139.803 Y110.515
G1 X139.628 Y110.396
G1 X139.435 Y110.321
G1 X139.302 Y110.298
G1 X139.221 Y110.292
G1 X137.783 Y110.29
G1 X137.508 Y110.29
G1 X137.432 Y110.29
G1 X137.431 Y109.913
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y106.087 E.09306
G1 X139.295 Y106.079 E.04534
G1 X139.805 Y105.921 E.01299
G1 X140.049 Y105.755 E.00718
G1 X140.352 Y105.41 E.01117
;WIDTH:0.410894
G1 X140.556 Y104.925 E.01318
G1 X140.562 Y105.46 E.0134
;WIDTH:0.399999
G1 X140.562 Y110.346 E.11885
;WIDTH:0.413078
G1 X140.556 Y111.067 E.01817
G1 X140.425 Y110.742 E.00883
;WIDTH:0.400936
G1 X140.236 Y110.44 E.00869
;WIDTH:0.399999
G1 X139.888 Y110.117 E.01155
G1 X139.719 Y110.027 E.00466
G1 X139.295 Y109.921 E.01063
G1 X137.491 Y109.913 E.04388
G1 X137.491 Y109.913 F9000
G1 X137.797 Y109.549
G1 F6000
G1 X137.797 Y106.451 E.07536
G1 X139.297 Y106.445 E.03649
G1 X140.011 Y106.223 E.01819
G1 X140.196 Y106.097 E.00544
G1 X140.197 Y109.922 E.09304
G1 X139.89 Y109.704 E.00916
G1 X139.297 Y109.555 E.01487
G1 X137.857 Y109.549 E.03503
G1 X137.857 Y109.549 F9000
G1 X138.163 Y109.185
G1 F6000
G1 X138.163 Y106.815 E.05765
G1 X139.298 Y106.81 E.02761
G1 X139.831 Y106.645 E.01357
G1 X139.831 Y109.323 E.06514
G1 X139.298 Y109.19 E.01336
G1 X138.223 Y109.185 E.02615
G1 E-5 F3600
G1 X138.223 Y109.185 F9000
G1 X140.21 Y111.292
G1 X140.24 Y111.579
G1 X140.156 Y119.063
G1 X140.178 Y119.156
G1 X140.557 Y119.067
G1 E5 F2400
;WIDTH:0.414312
G1 F6000
G1 X140.575 Y119.32 E.00641
;WIDTH:0.378527
G1 X140.592 Y119.572 E.00578
;WIDTH:0.34288
G1 X140.593 Y120.428 E.01757
;WIDTH:0.378122
G1 X140.575 Y120.677 E.00571
;WIDTH:0.413364
G1 X140.557 Y120.925 E.00627
G1 E-5 F3600
G1 X140.557 Y120.925 F9000
G1 X140.18 Y120.837
G1 X140.21 Y120.708
G1 X140.217 Y120.654
G1 X140.236 Y120.476
G1 X140.24 Y120.421
G1 X140.244 Y120.275
G1 X140.245 Y120.201
G1 X140.246 Y120.102
G1 X140.247 Y120.059
G1 X140.247 Y119.941
G1 X140.246 Y119.898
G1 X140.245 Y119.799
G1 X140.244 Y119.725
G1 X140.24 Y119.579
G1 X140.236 Y119.524
G1 X140.217 Y119.346
G1 X140.21 Y119.292
G1 X140.074 Y118.866
G1 X139.987 Y118.721
G1 X139.946 Y118.661
G1 X139.803 Y118.515
G1 X139.628 Y118.396
G1 X139.435 Y118.321
G1 X139.302 Y118.298
G1 X139.221 Y118.292
G1 X137.783 Y118.29
G1 X137.508 Y118.29
G1 X137.432 Y118.29
G1 X137.431 Y117.913
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y114.087 E.09306
G1 X139.295 Y114.079 E.04534
G1 X139.805 Y113.921 E.01299
G1 X140.049 Y113.755 E.00718
G1 X140.352 Y113.41 E.01117
;WIDTH:0.412128
G1 X140.557 Y112.925 E.01323
G1 X140.563 Y113.46 E.01345
;WIDTH:0.399999
G1 X140.564 Y118.346 E.11885
;WIDTH:0.414312
G1 X140.557 Y119.067 E.01822
G1 X140.425 Y118.742 E.00887
;WIDTH:0.401015
G1 X140.236 Y118.44 E.00869
;WIDTH:0.399999
G1 X139.888 Y118.117 E.01155
G1 X139.719 Y118.027 E.00466
G1 X139.295 Y117.921 E.01063
G1 X137.491 Y117.913 E.04388
G1 X137.491 Y117.913 F9000
G1 X137.797 Y117.549
G1 F6000
G1 X137.797 Y114.451 E.07536
G1 X139.297 Y114.445 E.03649
G1 X140.011 Y114.223 E.01819
G1 X140.197 Y114.096 E.00548
G1 X140.198 Y117.923 E.09309
G1 X139.89 Y117.704 E.00919
G1 X139.297 Y117.555 E.01487
G1 X137.857 Y117.549 E.03503
G1 X137.857 Y117.549 F9000
G1 X138.163 Y117.185
G1 F6000
G1 X138.163 Y114.815 E.05765
G1 X139.298 Y114.81 E.02761
G1 X139.832 Y114.645 E.01359
G1 X139.832 Y117.324 E.06516
G1 X139.298 Y117.19 E.01339
G1 X138.223 Y117.185 E.02615
G1 E-5 F3600
G1 X138.223 Y117.185 F9000
G1 X140.21 Y119.292
G1 X140.24 Y119.579
G1 X140.21 Y127.292
G1 X140.576 Y127.232
G1 E5 F2400
;WIDTH:0.377654
G1 F6000
G1 X140.596 Y127.735 E.0115
;WIDTH:0.364752
G1 X140.583 Y128.639 E.01987
G1 E-5 F3600
G1 X140.583 Y128.639 F9000
G1 X140.223 Y128.601
G1 X140.236 Y128.476
G1 X140.24 Y128.421
G1 X140.244 Y128.275
G1 X140.245 Y128.201
G1 X140.246 Y128.102
G1 X140.247 Y128.059
G1 X140.247 Y127.941
G1 X140.246 Y127.898
G1 X140.245 Y127.799
G1 X140.244 Y127.725
G1 X140.24 Y127.579
G1 X140.236 Y127.524
G1 X140.217 Y127.346
G1 X140.21 Y127.292
G1 X140.156 Y127.063
G1 X140.074 Y126.866
G1 X139.987 Y126.721
G1 X139.946 Y126.661
G1 X139.803 Y126.515
G1 X139.628 Y126.396
G1 X139.435 Y126.321
G1 X139.302 Y126.298
G1 X139.221 Y126.292
G1 X137.783 Y126.29
G1 X137.508 Y126.29
G1 X137.432 Y126.29
G1 X137.431 Y125.909
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y122.087 E.09297
G1 X139.294 Y122.079 E.04532
G1 X139.802 Y121.923 E.01293
G1 X140.047 Y121.757 E.0072
G1 X140.351 Y121.411 E.0112
;WIDTH:0.413364
G1 X140.557 Y120.925 E.01331
G1 X140.564 Y121.462 E.01354
;WIDTH:0.399999
G1 X140.576 Y127.232 E.14035
G1 X140.386 Y126.666 E.01452
G1 X140.123 Y126.3 E.01096
G1 X139.967 Y126.169 E.00495
G1 X139.61 Y125.985 E.00977
G1 X139.202 Y125.909 E.01009
G1 X137.491 Y125.909 E.04162
G1 X137.491 Y125.909 F9000
G1 X137.797 Y125.543
G1 F6000
G1 X137.797 Y122.451 E.07521
G1 X139.296 Y122.445 E.03646
G1 X140.006 Y122.226 E.01807
G1 X140.199 Y122.096 E.00566
G1 X140.199 Y125.888 E.09224
G1 X139.702 Y125.631 E.01361
G1 X139.202 Y125.544 E.01234
G1 X137.857 Y125.543 E.03272
G1 X137.857 Y125.543 F9000
G1 X138.163 Y125.178
G1 F6000
G1 X138.163 Y122.815 E.05748
G1 X139.297 Y122.81 E.02758
G1 X139.833 Y122.645 E.01364
G1 X139.833 Y125.297 E.06451
G1 X139.794 Y125.277 E.00107
G1 X139.202 Y125.178 E.0146
G1 X138.223 Y125.178 E.02381
G1 E-5 F3600
G1 X138.223 Y125.178 F9000
G1 X140.21 Y127.292
G1 X140.24 Y127.579
G1 X140.21 Y135.292
G1 X140.577 Y135.231
G1 E5 F2400
;WIDTH:0.378968
G1 F6000
G1 X140.597 Y136.02 E.01809
;WIDTH:0.366568
G1 X140.583 Y136.657 E.01408
G1 X140.583 Y136.657 F9000
;WIDTH:0.399999
G1 F6000
G1 X140.386 Y134.666 E.01451
G1 X140.123 Y134.3 E.01096
G1 X139.967 Y134.169 E.00495
G1 X139.61 Y133.985 E.00977
G1 X139.203 Y133.909 E.01007
G1 X137.344 Y133.908 E.04522
G1 X137.415 Y133.176 E.01789
G1 X137.431 Y132.616 E.01363
G1 X137.431 Y130.087 E.06152
G1 X139.295 Y130.079 E.04534
G1 X139.805 Y129.921 E.01299
G1 X140.049 Y129.755 E.00718
G1 X140.386 Y129.333 E.01314
G1 X140.534 Y128.945 E.0101
;WIDTH:0.392408
G1 X140.583 Y128.639 E.00738
;WIDTH:0.399999
G1 X140.565 Y129.367 E.01771
G1 X140.577 Y135.171 E.14118
G1 X140.577 Y135.171 F9000
G1 X140.2 Y133.888
G1 F6000
G1 X139.702 Y133.631 E.01363
G1 X139.203 Y133.544 E.01232
G1 X137.748 Y133.542 E.03539
G1 X137.781 Y133.187 E.00867
G1 X137.797 Y132.616 E.01389
G1 X137.797 Y130.451 E.05266
G1 X139.297 Y130.445 E.03649
G1 X140.01 Y130.224 E.01816
G1 X140.2 Y130.095 E.00559
G1 X140.2 Y133.828 E.0908
G1 X140.2 Y133.828 F9000
G1 X139.835 Y133.298
G1 F6000
G1 X139.794 Y133.277 E.00112
G1 X139.203 Y133.178 E.01458
G1 X138.147 Y133.177 E.02569
G1 X138.163 Y130.815 E.05745
G1 X139.298 Y130.81 E.02761
G1 X139.834 Y130.644 E.01365
G1 X139.835 Y133.238 E.0631
G1 E-5 F3600
G1 X139.835 Y133.238 F9000
G1 X140.577 Y143.231
G1 E5 F2400
;WIDTH:0.380204
G1 F6000
G1 X140.596 Y143.626 E.0091
;WIDTH:0.36695
G1 X140.584 Y144.632 E.02226
G1 X140.584 Y144.632 F9000
;WIDTH:0.399999
G1 F6000
G1 X140.386 Y142.667 E.01448
G1 X140.049 Y142.245 E.01314
G1 X139.805 Y142.079 E.00718
G1 X139.292 Y141.921 E.01306
G1 X132.234 Y141.908 E.17168
G1 X133.066 Y141.339 E.02452
G1 X133.84 Y140.699 E.02443
G1 X134.491 Y140.057 E.02224
G1 X135.115 Y139.326 E.02338
G1 X135.411 Y138.91 E.01242
G1 X135.941 Y138.092 E.02371
G1 X139.238 Y138.088 E.0802
G1 X139.505 Y138.048 E.00657
G1 X139.967 Y137.83 E.01243
G1 X140.123 Y137.7 E.00494
G1 X140.387 Y137.332 E.01102
G1 X140.534 Y136.942 E.01014
;WIDTH:0.391141
G1 X140.583 Y136.657 E.00686
;WIDTH:0.399999
G1 X140.567 Y137.366 E.01725
G1 X140.577 Y143.171 E.1412
G1 X140.577 Y143.171 F9000
G1 X140.202 Y141.906
G1 F6000
G1 X140.01 Y141.776 E.00564
G1 X139.293 Y141.555 E.01825
G1 X133.389 Y141.547 E.14361
G1 X134.096 Y140.96 E.02235
G1 X134.769 Y140.295 E.02301
G1 X135.393 Y139.564 E.02338
G1 X136.153 Y138.457 E.03266
G1 X139.238 Y138.454 E.07504
G1 X139.755 Y138.354 E.01281
G1 X140.201 Y138.111 E.01235
G1 X140.202 Y141.846 E.09085
G1 X140.202 Y141.846 F9000
G1 X139.836 Y141.357
G1 F6000
G1 X139.294 Y141.19 E.0138
G1 X134.392 Y141.182 E.11924
G1 X135.047 Y140.532 E.02245
G1 X135.671 Y139.801 E.02338
G1 X136.361 Y138.823 E.02911
G1 X139.239 Y138.82 E.07
G1 X139.835 Y138.712 E.01473
G1 X139.836 Y141.297 E.06288
G1 E-5 F3600
G1 X139.836 Y141.297 F9000
G1 X140.21 Y143.292
G1 X140.217 Y143.346
G1 X140.236 Y143.524
G1 X140.24 Y143.579
G1 X140.244 Y143.725
G1 X140.245 Y143.799
G1 X140.246 Y143.898
G1 X140.247 Y143.941
G1 X140.24 Y144.421
G1 X140.21 Y144.708
G1 X139.435 Y145.679
G1 X139.302 Y145.702
G1 X139.221 Y145.708
G1 X125.095 Y145.71
G1 X105.905 Y145.71
G1 X91.779 Y145.708
G1 X91.698 Y145.702
G1 X91.565 Y145.679
G1 X91.372 Y145.604
G1 X91.197 Y145.485
G1 X91.054 Y145.339
G1 X91.013 Y145.28
G1 X90.926 Y145.134
G1 X90.844 Y144.937
G1 X90.822 Y144.844
G1 X90.446 Y144.932
G1 E5 F2400
;WIDTH:0.40947
G1 F6000
G1 X90.426 Y144.338 E.01483
;WIDTH:0.370882
G1 X90.407 Y143.743 E.01333
;WIDTH:0.367765
G1 X90.425 Y143.428 E.007
;WIDTH:0.403236
G1 X90.442 Y143.112 E.00777
G1 E-5 F3600
G1 X90.442 Y143.112 F9000
G1 X90.812 Y143.199
G1 X90.79 Y143.292
G1 X90.783 Y143.346
G1 X90.764 Y143.524
G1 X90.76 Y143.579
G1 X90.756 Y143.725
G1 X90.755 Y143.799
G1 X90.754 Y143.898
G1 X90.753 Y143.941
G1 X90.753 Y144.059
G1 X90.754 Y144.102
G1 X90.755 Y144.201
G1 X90.756 Y144.275
G1 X90.76 Y144.421
G1 X90.764 Y144.476
G1 X90.783 Y144.654
G1 X90.79 Y144.708
G1 X90.844 Y144.937
G1 X90.926 Y145.134
G1 X91.013 Y145.28
G1 X91.054 Y145.339
G1 X91.197 Y145.485
G1 X91.372 Y145.604
G1 X91.565 Y145.679
G1 X91.698 Y145.702
G1 X91.779 Y145.708
G1 X96.768 Y145.708
G1 X96.768 Y146.09
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.453 Y146.089 E.21125
G1 X105.809 Y145.982 E.00904
G1 X106.045 Y145.799 E.00726
G1 X106.211 Y145.544 E.0074
G1 X106.287 Y145.182 E.009
G1 X106.295 Y143.538 E.03999
G1 X110.664 Y143.52 E.10627
G1 X110.988 Y143.401 E.0084
G1 X111.124 Y143.16 E.00673
G1 X119.876 Y143.16 E.21288
G1 X120.012 Y143.401 E.00673
G1 X120.196 Y143.485 E.00492
G1 X120.483 Y143.532 E.00707
G1 X124.711 Y143.532 E.10284
G1 X124.712 Y145.179 E.04006
G1 X124.737 Y145.389 E.00514
G1 X124.848 Y145.658 E.00708
G1 X125.05 Y145.888 E.00745
G1 X125.388 Y146.061 E.00924
G1 X125.627 Y146.093 E.00587
G1 X139.202 Y146.091 E.3302
G1 X139.61 Y146.015 E.01009
G1 X139.967 Y145.831 E.00977
G1 X140.123 Y145.7 E.00495
G1 X140.386 Y145.334 E.01096
G1 X140.535 Y144.945 E.01013
;WIDTH:0.393458
G1 X140.584 Y144.632 E.00757
;WIDTH:0.399999
G1 X140.568 Y145.368 E.01791
G1 X140.562 Y151.083 E.13901
G1 X140.529 Y150.977 E.0027
G1 X140.237 Y150.441 E.01485
G1 X139.832 Y150.09 E.01304
G1 X139.608 Y149.99 E.00597
G1 X139.237 Y149.912 E.00922
G1 X125.627 Y149.907 E.33105
G1 X125.388 Y149.939 E.00587
G1 X125.191 Y150.018 E.00516
G1 X124.955 Y150.201 E.00726
G1 X124.773 Y150.495 E.00841
G1 X124.712 Y150.822 E.00809
G1 X124.712 Y153.178 E.05731
G1 X124.735 Y153.379 E.00492
G1 X124.82 Y153.609 E.00596
G1 X124.996 Y153.84 E.00706
G1 X125.275 Y154.022 E.0081
G1 X125.627 Y154.093 E.00873
G1 X139.202 Y154.091 E.3302
G1 X139.55 Y154.031 E.00859
G1 X139.325 Y154.323 E.00897
G1 X138.907 Y154.75 E.01453
G1 X138.329 Y155.2 E.01782
G1 X137.929 Y155.446 E.01142
G1 X137.268 Y155.748 E.01768
G1 X136.609 Y155.943 E.01672
G1 X135.823 Y156.052 E.0193
G1 X135.381 Y156.064 E.01076
G1 X133.855 Y156.011 E.03714
G1 X97.145 Y156.011 E.89293
G1 X95.413 Y156.064 E.04215
G1 X94.784 Y156.013 E.01535
G1 X94.179 Y155.889 E.01502
G1 X93.69 Y155.73 E.01251
G1 X92.837 Y155.31 E.02313
G1 X92.088 Y154.745 E.02282
G1 X91.693 Y154.341 E.01374
G1 X91.45 Y154.031 E.00958
G1 X91.798 Y154.091 E.00859
G1 X105.373 Y154.093 E.3302
G1 X105.725 Y154.022 E.00873
G1 X106.004 Y153.84 E.0081
G1 X106.18 Y153.609 E.00706
G1 X106.265 Y153.379 E.00596
G1 X106.288 Y153.178 E.00492
G1 X106.288 Y150.822 E.05731
G1 X106.275 Y150.672 E.00366
G1 X106.152 Y150.342 E.00857
G1 X105.95 Y150.112 E.00745
G1 X105.612 Y149.939 E.00924
G1 X105.373 Y149.907 E.00587
G1 X91.763 Y149.912 E.33105
G1 X91.392 Y149.99 E.00922
G1 X91.168 Y150.09 E.00597
G1 X90.763 Y150.441 E.01304
;WIDTH:0.407272
G1 X90.566 Y150.737 E.00882
G1 X90.453 Y151.04 E.00802
G1 X90.442 Y150.349 E.01714
;WIDTH:0.399999
G1 X90.441 Y145.45 E.11916
;WIDTH:0.40947
G1 X90.446 Y144.932 E.01293
G1 X90.643 Y145.402 E.01272
;WIDTH:0.399999
G1 X90.867 Y145.688 E.00884
G1 X91.027 Y145.825 E.00512
G1 X91.39 Y146.015 E.00997
G1 X91.798 Y146.091 E.01009
G1 X96.708 Y146.09 E.11943
G1 X96.708 Y146.09 F9000
G1 X96.421 Y146.457
G1 F6000
G1 X105.373 Y146.458 E.21775
G1 X105.708 Y146.414 E.00822
G1 X105.983 Y146.304 E.0072
G1 X106.18 Y146.172 E.00577
G1 X106.463 Y145.849 E.01045
G1 X106.618 Y145.475 E.00985
G1 X106.653 Y145.184 E.00713
G1 X106.659 Y143.903 E.03116
G1 X109.949 Y143.898 E.08003
G1 X110.722 Y143.881 E.01881
G1 X111.177 Y143.714 E.01179
G1 X111.283 Y143.526 E.00525
G1 X119.717 Y143.526 E.20515
G1 X119.823 Y143.714 E.00525
G1 X120.081 Y143.832 E.0069
G1 X120.483 Y143.897 E.00991
G1 X124.346 Y143.897 E.09396
G1 X124.347 Y145.179 E.03118
G1 X124.381 Y145.473 E.0072
G1 X124.453 Y145.69 E.00556
G1 X124.686 Y146.047 E.01037
G1 X125.017 Y146.304 E.01019
G1 X125.292 Y146.414 E.0072
G1 X125.627 Y146.458 E.00822
G1 X139.202 Y146.456 E.3302
G1 X139.702 Y146.369 E.01234
G1 X140.202 Y146.111 E.01369
G1 X140.203 Y149.949 E.09336
G1 X139.98 Y149.756 E.00717
G1 X139.756 Y149.656 E.00597
G1 X139.237 Y149.546 E.0129
G1 X125.627 Y149.542 E.33105
G1 X125.292 Y149.586 E.00822
G1 X125.017 Y149.696 E.0072
G1 X124.82 Y149.828 E.00577
G1 X124.597 Y150.061 E.00784
G1 X124.4 Y150.455 E.01071
G1 X124.347 Y150.822 E.00902
G1 X124.347 Y153.178 E.05731
G1 X124.378 Y153.459 E.00688
G1 X124.497 Y153.781 E.00835
G1 X124.744 Y154.105 E.00991
G1 X125.134 Y154.36 E.01133
G1 X125.627 Y154.458 E.01223
G1 X138.682 Y154.457 E.31755
G1 X138.104 Y154.911 E.01788
G1 X137.758 Y155.123 E.00987
G1 X137.14 Y155.404 E.01651
G1 X136.531 Y155.584 E.01545
G1 X135.772 Y155.689 E.01864
G1 X135.386 Y155.698 E.00939
G1 X133.855 Y155.645 E.03726
G1 X97.145 Y155.645 E.89293
G1 X95.402 Y155.698 E.04242
G1 X94.888 Y155.661 E.01253
G1 X94.318 Y155.55 E.01413
G1 X93.837 Y155.395 E.01229
G1 X93.022 Y154.992 E.02212
G1 X92.318 Y154.457 E.02151
G1 X105.373 Y154.458 E.31755
G1 X105.866 Y154.36 E.01223
G1 X106.256 Y154.105 E.01133
G1 X106.503 Y153.781 E.00991
G1 X106.622 Y153.459 E.00835
G1 X106.653 Y153.178 E.00688
G1 X106.653 Y150.822 E.05731
G1 X106.636 Y150.612 E.00512
G1 X106.526 Y150.266 E.00883
G1 X106.314 Y149.953 E.0092
G1 X105.983 Y149.696 E.01019
G1 X105.708 Y149.586 E.0072
G1 X105.373 Y149.542 E.00822
G1 X91.763 Y149.546 E.33105
G1 X91.244 Y149.656 E.0129
G1 X91.02 Y149.756 E.00597
G1 X90.807 Y149.94 E.00685
G1 X90.807 Y146.112 E.09311
G1 X91.298 Y146.369 E.01348
G1 X91.798 Y146.456 E.01234
G1 X96.361 Y146.457 E.11099
G1 X96.361 Y146.457 F9000
G1 X96.072 Y146.823
G1 F6000
G1 X105.373 Y146.824 E.22624
G1 X105.803 Y146.767 E.01055
G1 X106.157 Y146.625 E.00928
G1 X106.582 Y146.295 E.01309
G1 X106.775 Y146.041 E.00776
G1 X106.974 Y145.56 E.01266
G1 X107.019 Y145.186 E.00916
G1 X107.023 Y144.269 E.02231
G1 X110.52 Y144.263 E.08506
G1 X110.888 Y144.22 E.00901
G1 X111.365 Y144.028 E.01251
G1 X111.442 Y143.892 E.0038
G1 X119.558 Y143.892 E.19741
G1 X119.635 Y144.028 E.0038
G1 X120.019 Y144.196 E.0102
G1 X120.483 Y144.263 E.0114
G1 X123.981 Y144.263 E.08509
G1 X123.981 Y145.179 E.02228
G1 X124.025 Y145.557 E.00926
G1 X124.225 Y146.041 E.01274
G1 X124.418 Y146.295 E.00776
G1 X124.843 Y146.625 E.01309
G1 X125.197 Y146.767 E.00928
G1 X125.627 Y146.824 E.01055
G1 X139.202 Y146.822 E.3302
G1 X139.617 Y146.769 E.01018
G1 X139.837 Y146.701 E.0056
G1 X139.837 Y149.308 E.06341
G1 X139.237 Y149.18 E.01492
G1 X125.627 Y149.176 E.33105
G1 X125.197 Y149.233 E.01055
G1 X124.843 Y149.375 E.00928
G1 X124.418 Y149.705 E.01309
G1 X124.225 Y149.959 E.00776
G1 X124.05 Y150.351 E.01044
G1 X123.981 Y150.822 E.01158
G1 X123.981 Y153.178 E.05731
G1 X124.021 Y153.54 E.00886
G1 X124.175 Y153.953 E.01072
G1 X124.492 Y154.37 E.01274
G1 X124.994 Y154.697 E.01457
;WIDTH:0.444913
G1 X125.627 Y154.846 E.01776
;WIDTH:0.445424
G1 X133.855 Y154.846 E.225
;WIDTH:0.446015
G1 X133.921 Y154.846 E.00181
;WIDTH:0.472184
G1 X135.687 Y154.858 E.05144
;WIDTH:0.470677
G1 X136.411 Y154.833 E.02103
;WIDTH:0.420858
G1 X137.487 Y154.833 E.02767
G1 X137 Y155.053 E.01374
G1 X136.437 Y155.218 E.01508
;WIDTH:0.446521
G1 X135.911 Y155.257 E.01446
;WIDTH:0.472184
G1 X135.386 Y155.296 E.01533
G1 X133.914 Y155.257 E.04289
;WIDTH:0.446015
G1 X133.855 Y155.257 E.00162
;WIDTH:0.445424
G1 X125.627 Y155.257 E.225
;WIDTH:0.444913
G1 X124.877 Y155.279 E.02049
;WIDTH:0.399999
G1 X106.123 Y155.279 E.45617
;WIDTH:0.444913
G1 X105.373 Y155.257 E.02049
;WIDTH:0.445424
G1 X97.145 Y155.257 E.225
;WIDTH:0.445871
G1 X97.094 Y155.257 E.0014
;WIDTH:0.472228
G1 X95.389 Y155.297 E.04968
G1 X94.929 Y155.268 E.01343
;WIDTH:0.455791
G1 X94.406 Y155.165 E.01494
G1 X93.574 Y154.85 E.02494
G1 X94.455 Y154.85 E.0247
;WIDTH:0.472228
G1 X97.088 Y154.846 E.0767
;WIDTH:0.445871
G1 X97.146 Y154.846 E.00159
;WIDTH:0.445424
G1 X105.373 Y154.846 E.22497
;WIDTH:0.459106
G1 X105.663 Y154.828 E.00821
G1 X105.835 Y154.763 E.0052
;WIDTH:0.429553
G1 X106.006 Y154.697 E.00482
;WIDTH:0.399999
G1 X106.508 Y154.37 E.01457
G1 X106.825 Y153.953 E.01274
G1 X106.979 Y153.54 E.01072
G1 X107.019 Y153.178 E.00886
G1 X107.019 Y150.822 E.05731
G1 X106.997 Y150.552 E.00659
G1 X106.856 Y150.107 E.01135
G1 X106.582 Y149.705 E.01183
G1 X106.157 Y149.375 E.01309
G1 X105.803 Y149.233 E.00928
G1 X105.373 Y149.176 E.01055
G1 X91.763 Y149.18 E.33105
G1 X91.173 Y149.305 E.01467
G1 X91.173 Y146.706 E.06322
G1 X91.798 Y146.822 E.01546
G1 X96.012 Y146.823 E.1025
G1 E-5 F3600
G1 X96.012 Y146.823 F9000
G1 X91.565 Y145.679
G1 X91.372 Y145.604
G1 X91.197 Y145.485
G1 X91.054 Y145.339
G1 X91.013 Y145.28
G1 X90.926 Y145.134
G1 X90.844 Y144.937
G1 X90.79 Y144.708
G1 X90.783 Y144.654
G1 X90.764 Y144.476
G1 X90.76 Y144.421
G1 X90.756 Y144.275
G1 X90.755 Y144.201
G1 X90.754 Y144.102
G1 X90.753 Y144.059
G1 X90.753 Y143.941
G1 X90.79 Y136.708
G1 X90.426 Y136.767
G1 E5 F2400
;WIDTH:0.372794
G1 F6000
G1 X90.42 Y136.649 E.00266
G1 E-5 F3600
G1 X90.42 Y136.649 F9000
G1 X90.442 Y143.112
G1 E5 F2400
;WIDTH:0.403236
G1 F6000
G1 X90.441 Y142.54 E.01404
;WIDTH:0.399999
G1 X90.426 Y136.767 E.14042
G1 X90.613 Y137.332 E.01448
G1 X90.877 Y137.7 E.01102
G1 X91.033 Y137.83 E.00494
G1 X91.352 Y138.004 E.00884
G1 X91.762 Y138.088 E.01018
G1 X95.059 Y138.092 E.0802
G1 X95.262 Y138.441 E.00982
G1 X95.885 Y139.326 E.02633
G1 X96.565 Y140.117 E.02537
G1 X97.22 Y140.753 E.02221
G1 X98.002 Y141.389 E.02452
G1 X98.766 Y141.908 E.02247
G1 X91.708 Y141.921 E.17168
G1 X91.195 Y142.079 E.01306
G1 X90.951 Y142.245 E.00718
G1 X90.648 Y142.59 E.01117
;WIDTH:0.403236
G1 X90.464 Y143.057 E.01232
G1 X90.464 Y143.057 F9000
G1 X90.806 Y141.901
;WIDTH:0.399999
G1 F6000
G1 X90.806 Y138.115 E.09209
G1 X91.245 Y138.354 E.01216
G1 X91.762 Y138.454 E.01281
G1 X94.847 Y138.457 E.07504
G1 X94.962 Y138.65 E.00546
G1 X95.607 Y139.564 E.02721
G1 X96.309 Y140.378 E.02615
G1 X96.988 Y141.036 E.023
G1 X97.611 Y141.546 E.01958
G1 X91.707 Y141.555 E.14361
G1 X90.989 Y141.777 E.01828
G1 X90.856 Y141.867 E.00391
G1 X90.856 Y141.867 F9000
G1 X91.172 Y141.355
G1 F6000
G1 X91.171 Y138.714 E.06424
G1 X91.761 Y138.82 E.01458
G1 X94.593 Y138.823 E.06889
G1 X94.662 Y138.859 E.00189
G1 X95.329 Y139.801 E.02808
G1 X96.053 Y140.639 E.02694
G1 X96.608 Y141.182 E.01889
G1 X91.706 Y141.19 E.11924
G1 X91.229 Y141.337 E.01214
G1 E-5 F3600
G1 X91.229 Y141.337 F9000
G1 X90.445 Y128.932
G1 E5 F2400
;WIDTH:0.411884
G1 F6000
G1 X90.427 Y128.682 E.00629
;WIDTH:0.376114
G1 X90.409 Y128.431 E.00572
;WIDTH:0.340344
G1 X90.407 Y127.606 E.01679
;WIDTH:0.373787
G1 X90.425 Y127.344 E.00593
;WIDTH:0.409726
G1 X90.443 Y127.082 E.00656
G1 E-5 F3600
G1 X90.443 Y127.082 F9000
G1 X90.44 Y135.159
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X90.439 Y129.653 E.13393
;WIDTH:0.411884
G1 X90.445 Y128.932 E.01811
G1 X90.575 Y129.258 E.00881
;WIDTH:0.400857
G1 X90.764 Y129.56 E.00869
;WIDTH:0.399999
G1 X91.112 Y129.883 E.01155
G1 X91.281 Y129.973 E.00466
G1 X91.705 Y130.079 E.01063
G1 X93.569 Y130.087 E.04534
G1 X93.572 Y132.717 E.06397
G1 X93.662 Y133.908 E.02905
G1 X91.797 Y133.909 E.04536
G1 X91.39 Y133.985 E.01007
G1 X91.033 Y134.169 E.00977
G1 X90.877 Y134.3 E.00495
G1 X90.614 Y134.666 E.01096
G1 X90.46 Y135.102 E.01125
G1 X90.46 Y135.102 F9000
G1 X90.805 Y133.886
G1 F6000
G1 X90.804 Y130.08 E.09258
G1 X91.11 Y130.296 E.00911
G1 X91.704 Y130.445 E.0149
G1 X93.203 Y130.451 E.03646
G1 X93.207 Y132.745 E.0558
G1 X93.268 Y133.542 E.01944
G1 X91.797 Y133.544 E.03578
G1 X91.298 Y133.631 E.01232
G1 X90.858 Y133.858 E.01204
G1 X90.858 Y133.858 F9000
G1 X91.171 Y133.295
G1 F6000
G1 X91.17 Y130.677 E.06368
G1 X91.702 Y130.81 E.01334
G1 X92.837 Y130.815 E.02761
G1 X92.838 Y132.648 E.04459
G1 X92.873 Y133.177 E.0129
G1 X92.005 Y133.178 E.02111
G1 X91.383 Y133.231 E.01518
G1 X91.228 Y133.278 E.00394
G1 E-5 F3600
G1 X90.444 Y120.933 F9000
G1 E5 F2400
;WIDTH:0.413088
G1 F6000
G1 X90.426 Y120.68 E.00639
;WIDTH:0.377305
G1 X90.408 Y120.428 E.00576
;WIDTH:0.341658
G1 X90.408 Y119.572 E.0175
;WIDTH:0.376898
G1 X90.426 Y119.323 E.00569
;WIDTH:0.412138
G1 X90.443 Y119.075 E.00625
G1 E-5 F3600
G1 X90.443 Y119.075 F9000
G1 X90.443 Y127.082
G1 E5 F2400
;WIDTH:0.409726
G1 F6000
G1 X90.438 Y126.539 E.01356
;WIDTH:0.399999
G1 X90.438 Y121.654 E.11882
;WIDTH:0.413088
G1 X90.444 Y120.933 E.01817
G1 X90.575 Y121.258 E.00883
;WIDTH:0.400936
G1 X90.764 Y121.56 E.00869
;WIDTH:0.399999
G1 X91.112 Y121.883 E.01155
G1 X91.281 Y121.973 E.00466
G1 X91.705 Y122.079 E.01063
G1 X93.569 Y122.087 E.04534
G1 X93.569 Y125.909 E.09297
G1 X91.798 Y125.909 E.04308
G1 X91.39 Y125.985 E.01009
G1 X91.033 Y126.169 E.00977
G1 X90.877 Y126.3 E.00495
G1 X90.649 Y126.589 E.00895
;WIDTH:0.409726
G1 X90.466 Y127.027 E.01185
G1 E-5 F3600
G1 X90.466 Y127.027 F9000
G1 X93.087 Y122.451
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.203 Y122.451 E.00282
G1 X93.203 Y125.543 E.07521
G1 X91.798 Y125.544 E.03418
G1 X91.298 Y125.631 E.01234
G1 X90.804 Y125.886 E.01352
G1 X90.803 Y122.078 E.09263
G1 X91.11 Y122.296 E.00916
G1 X91.703 Y122.445 E.01487
G1 X93.027 Y122.45 E.03221
G1 X93.027 Y122.45 F9000
G1 X92.642 Y122.814
G1 F6000
G1 X92.837 Y122.815 E.00474
G1 X92.837 Y125.178 E.05748
G1 X92.003 Y125.178 E.02029
G1 X91.383 Y125.231 E.01514
G1 X91.169 Y125.296 E.00544
G1 X91.169 Y122.677 E.0637
G1 X91.702 Y122.81 E.01336
G1 X92.582 Y122.814 E.02141
G1 X92.582 Y122.814 F9000
G1 X91.939 Y122.921
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X91.443 Y123.416 E.01704
G1 X91.443 Y123.957 E.01316
G1 X92.313 Y123.087 E.02993
G1 X92.563 Y123.088 E.00608
G1 X92.563 Y123.377 E.00703
G1 X91.444 Y124.497 E.03851
G1 X91.444 Y124.948 E.01097
G1 X91.546 Y124.935 E.0025
G1 X92.563 Y123.918 E.03498
G1 X92.563 Y124.458 E.01313
G1 X91.953 Y125.068 E.02098
G1 E-5 F3600
G1 X91.953 Y125.068 F9000
G1 X90.926 Y126.866
G1 X90.844 Y127.062
G1 X90.79 Y127.292
G1 X90.783 Y127.346
G1 X90.764 Y127.524
G1 X90.76 Y127.579
G1 X90.756 Y127.725
G1 X90.755 Y127.799
G1 X90.754 Y127.898
G1 X90.753 Y127.941
G1 X90.753 Y128.059
G1 X90.754 Y128.102
G1 X90.755 Y128.201
G1 X90.756 Y128.275
G1 X90.76 Y128.421
G1 X90.764 Y128.476
G1 X90.783 Y128.654
G1 X90.79 Y128.708
G1 X90.844 Y128.937
G1 X90.926 Y129.134
G1 X91.945 Y130.921
G1 E5 F2400
G1 F3072.127
G1 X91.445 Y131.422 E.01722
G1 X91.445 Y131.966 E.01323
G1 X92.323 Y131.087 E.03022
G1 X92.563 Y131.088 E.00584
G1 X92.563 Y131.391 E.00737
G1 X91.445 Y132.51 E.03848
G1 X91.445 Y132.948 E.01065
G1 X91.566 Y132.932 E.00297
G1 X92.563 Y131.935 E.0343
G1 X92.563 Y132.479 E.01323
G1 X91.975 Y133.068 E.02024
G1 E-5 F3600
G1 X91.975 Y133.068 F9000
G1 X90.926 Y134.866
G1 X90.844 Y135.062
G1 X90.79 Y135.292
G1 X90.783 Y135.346
G1 X90.764 Y135.524
G1 X90.76 Y135.579
G1 X90.756 Y135.725
G1 X90.755 Y135.799
G1 X90.754 Y135.898
G1 X90.753 Y135.941
G1 X90.753 Y136.059
G1 X90.754 Y136.102
G1 X90.755 Y136.201
G1 X90.756 Y136.275
G1 X90.76 Y136.421
G1 X90.764 Y136.476
G1 X90.783 Y136.654
G1 X90.79 Y136.708
G1 X91.281 Y139.606
G1 E5 F2400
G1 F3072.127
G1 X91.794 Y139.094 E.01763
G1 X92.32 Y139.094 E.01279
G1 X91.446 Y139.968 E.03007
G1 X91.446 Y140.495 E.01282
G1 X92.846 Y139.095 E.04816
G1 X93.372 Y139.095 E.01279
G1 X91.49 Y140.978 E.06476
G1 X91.692 Y140.915 E.00515
G1 X92.079 Y140.915 E.00941
G1 X93.898 Y139.096 E.06257
G1 X94.424 Y139.097 E.01279
G1 X92.607 Y140.914 E.0625
G1 X93.134 Y140.913 E.01282
G1 X94.684 Y139.364 E.0533
G1 X94.902 Y139.672 E.00918
G1 X93.662 Y140.912 E.04266
G1 X94.189 Y140.912 E.01282
G1 X95.121 Y139.98 E.03206
G1 X95.363 Y140.264 E.00908
G1 X94.717 Y140.911 E.02224
G1 X95.244 Y140.91 E.01282
G1 X95.606 Y140.548 E.01245
G1 X95.857 Y140.824 E.00907
G1 X95.607 Y141.074 E.0086
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X95.857 Y140.824 E-.16794
G1 X95.606 Y140.548 E-.17721
G1 X95.244 Y140.91 E-.24317
G1 X94.717 Y140.911 E-.25033
G1 X95.363 Y140.264 E-.43429
G1 X95.121 Y139.98 E-.17723
G1 X95.047 Y140.054 E-.04983
;WIPE_END
G1 X91.372 Y142.396 F9000
G1 X91.197 Y142.515
G1 X91.054 Y142.661
G1 X91.013 Y142.721
G1 X90.926 Y142.866
G1 X90.844 Y143.062
G1 X90.79 Y143.292
G1 X90.783 Y143.346
G1 X90.764 Y143.524
G1 X90.76 Y143.579
G1 X90.756 Y143.725
G1 X90.755 Y143.799
G1 X90.754 Y143.898
G1 X90.753 Y143.941
G1 X90.753 Y144.059
G1 X90.754 Y144.102
G1 X90.755 Y144.201
G1 X90.756 Y144.275
G1 X90.76 Y144.421
G1 X90.764 Y144.476
G1 X90.783 Y144.654
G1 X90.79 Y144.708
G1 X90.844 Y144.937
G1 X90.926 Y145.134
G1 X91.013 Y145.28
G1 X91.054 Y145.339
G1 X91.197 Y145.485
G1 X94.717 Y148.925
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.374336
G1 F1200
G1 X105.371 Y148.915 E.24096
;WIDTH:0.392866
G1 X105.892 Y148.979 E.01252
;WIDTH:0.420974
G1 X106.32 Y149.142 E.01178
G1 X106.764 Y149.497 E.01462
;WIDTH:0.406018
G1 X107.083 Y149.968 E.01406
;WIDTH:0.386346
G1 X107.163 Y150.224 E.00628
G1 E-5 F3600
G1 X107.163 Y150.224 F9000
G1 X104.535 Y148.728
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X105.869 Y147.393 E.04591
G1 X105.303 Y147.438 E.01381
G1 X104.178 Y148.564 E.03872
G1 X103.656 Y148.565 E.0127
G1 X104.783 Y147.438 E.03877
G1 X104.263 Y147.437 E.01265
G1 X103.134 Y148.566 E.03884
G1 X102.613 Y148.566 E.01267
G1 X103.742 Y147.436 E.03885
G1 X103.222 Y147.436 E.01265
G1 X102.091 Y148.567 E.03891
G1 X101.569 Y148.568 E.0127
G1 X102.702 Y147.435 E.03897
G1 X102.181 Y147.435 E.01267
G1 X101.047 Y148.569 E.03901
G1 X100.526 Y148.57 E.01267
G1 X101.661 Y147.434 E.03906
G1 X101.141 Y147.434 E.01265
G1 X100.004 Y148.571 E.03911
G1 X99.482 Y148.571 E.0127
G1 X100.62 Y147.433 E.03915
G1 X100.1 Y147.433 E.01265
G1 X98.96 Y148.572 E.0392
G1 X98.439 Y148.573 E.01267
G1 X99.579 Y147.432 E.03923
G1 X99.059 Y147.432 E.01265
G1 X97.917 Y148.574 E.03928
G1 X97.395 Y148.575 E.0127
G1 X98.539 Y147.431 E.03935
G1 X98.018 Y147.431 E.01267
G1 X96.873 Y148.576 E.03939
G1 X96.352 Y148.576 E.01267
G1 X97.498 Y147.43 E.03942
G1 X96.978 Y147.43 E.01265
G1 X95.83 Y148.577 E.03947
G1 X95.308 Y148.578 E.0127
G1 X96.457 Y147.429 E.03952
G1 X95.937 Y147.428 E.01265
G1 X94.786 Y148.579 E.03959
G1 X94.371 Y148.58 E.01009
G1 X94.371 Y148.905 E.00791
G1 X93.939 Y148.906 E.01051
G1 X95.416 Y147.428 E.05083
G1 X94.896 Y147.427 E.01265
G1 X93.418 Y148.906 E.05086
G1 X92.897 Y148.906 E.01267
G1 X94.376 Y147.427 E.05088
G1 X93.855 Y147.426 E.01267
G1 X92.376 Y148.906 E.05089
G1 X91.855 Y148.906 E.01267
G1 X93.335 Y147.426 E.05091
G1 X92.815 Y147.425 E.01265
G1 X91.447 Y148.793 E.04706
G1 X91.447 Y148.272 E.01267
G1 X92.294 Y147.425 E.02914
G1 X91.775 Y147.423 E.01262
G1 X91.282 Y147.916 E.01696
G1 E-5 F3600
G1 X91.282 Y147.916 F9000
G1 X107.157 Y145.799
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.400142
G1 F1200
G1 X107.066 Y146.007 E.00552
;WIDTH:0.425948
G1 X106.975 Y146.216 E.00594
;WIDTH:0.44752
G1 X106.645 Y146.622 E.01438
G1 X106.272 Y146.882 E.0125
;WIDTH:0.416284
G1 X105.857 Y147.03 E.01119
;WIDTH:0.390292
G1 X105.525 Y147.082 E.00796
;WIDTH:0.381526
G1 X92.028 Y147.078 E.31172
;WIDTH:0.374336
G1 X91.42 Y147.021 E.01381
G1 E-5 F3600
G1 X91.42 Y147.021 F9000
G1 X105.905 Y145.71
G1 X107.129 Y145.092
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X107.68 Y144.541 E.01895
G1 X108.203 Y144.539 E.01272
G1 X107.268 Y145.474 E.03216
G1 X107.542 Y145.539 E.00685
G1 X107.51 Y145.752 E.00524
G1 X108.725 Y144.537 E.0418
G1 X109.248 Y144.535 E.01272
G1 X105.221 Y148.562 E.13853
G1 X105.72 Y148.584 E.01215
G1 X109.771 Y144.533 E.13935
G1 X110.294 Y144.532 E.01272
G1 X106.166 Y148.659 E.14198
G1 X106.525 Y148.821 E.00958
G1 X110.85 Y144.496 E.14878
G1 X111.187 Y144.41 E.00846
G1 X111.301 Y144.566 E.0047
G1 X106.835 Y149.032 E.15363
G1 X107.098 Y149.29 E.00896
G1 X111.822 Y144.566 E.1625
G1 X112.343 Y144.566 E.01267
G1 X107.308 Y149.601 E.1732
G1 X107.455 Y149.975 E.00977
G1 X112.864 Y144.566 E.18607
G1 X113.385 Y144.566 E.01267
G1 X107.277 Y150.674 E.21011
G1 X107.293 Y151.178 E.01227
G1 X113.906 Y144.566 E.22747
G1 X114.427 Y144.566 E.01267
G1 X107.293 Y151.699 E.24539
G1 X107.293 Y152.22 E.01267
G1 X114.948 Y144.566 E.26331
G1 X115.469 Y144.566 E.01267
G1 X107.293 Y152.741 E.28123
G1 X107.283 Y153.272 E.01292
G1 X115.989 Y144.566 E.29948
G1 X116.51 Y144.566 E.01267
G1 X106.078 Y154.998 E.35885
G1 X106.129 Y155.005 E.00125
G1 X106.592 Y155.005 E.01126
G1 X117.031 Y144.566 E.3591
G1 X117.552 Y144.566 E.01267
G1 X107.113 Y155.005 E.3591
G1 X107.634 Y155.005 E.01267
G1 X118.073 Y144.566 E.3591
G1 X118.594 Y144.566 E.01267
G1 X108.155 Y155.005 E.3591
G1 X108.675 Y155.005 E.01265
G1 X119.115 Y144.566 E.35911
G1 X119.636 Y144.566 E.01267
G1 X109.196 Y155.005 E.35911
G1 X109.717 Y155.005 E.01267
G1 X120.213 Y144.509 E.36106
G1 X120.712 Y144.531 E.01215
G1 X110.238 Y155.005 E.3603
G1 X110.759 Y155.005 E.01267
G1 X121.232 Y144.532 E.36026
G1 X121.752 Y144.533 E.01265
G1 X111.28 Y155.005 E.36023
G1 X111.801 Y155.005 E.01267
G1 X122.272 Y144.534 E.3602
G1 X122.792 Y144.535 E.01265
G1 X112.322 Y155.005 E.36016
G1 X112.843 Y155.005 E.01267
G1 X123.312 Y144.536 E.36013
G1 X123.706 Y144.537 E.00958
G1 X123.707 Y144.662 E.00304
G1 X113.364 Y155.005 E.35579
G1 X113.885 Y155.005 E.01267
G1 X123.707 Y145.183 E.33787
G1 X123.74 Y145.472 E.00708
G1 X123.458 Y145.54 E.00706
G1 X123.511 Y145.899 E.00883
G1 X114.405 Y155.005 E.31324
G1 X114.926 Y155.005 E.01267
G1 X123.643 Y146.288 E.29986
G1 X123.833 Y146.619 E.00928
G1 X115.447 Y155.005 E.28847
G1 X115.968 Y155.005 E.01267
G1 X124.077 Y146.897 E.27893
G1 X124.371 Y147.123 E.00902
G1 X116.489 Y155.005 E.27114
G1 X117.01 Y155.005 E.01267
G1 X124.724 Y147.292 E.26534
G1 X125.141 Y147.395 E.01045
G1 X117.366 Y155.17 E.26746
G1 E-5 F3600
G1 X117.366 Y155.17 F9000
G1 X125.014 Y154.814
G1 E5 F2400
G1 F3072.127
G1 X124.824 Y155.005 E.00655
G1 X124.303 Y155.005 E.01267
G1 X124.566 Y154.742 E.00905
G1 X124.265 Y154.521 E.00908
G1 X123.782 Y155.005 E.01663
G1 X123.261 Y155.005 E.01267
G1 X124.04 Y154.225 E.02681
G1 X123.859 Y153.886 E.00935
G1 X122.74 Y155.005 E.03849
G1 X122.219 Y155.005 E.01267
G1 X123.74 Y153.484 E.05232
G1 X123.707 Y152.996 E.0119
G1 X121.698 Y155.005 E.06911
G1 X121.177 Y155.005 E.01267
G1 X123.707 Y152.475 E.08703
G1 X123.707 Y151.955 E.01265
G1 X120.656 Y155.005 E.10494
G1 X120.135 Y155.005 E.01267
G1 X123.707 Y151.434 E.12286
G1 X123.707 Y150.913 E.01267
G1 X119.614 Y155.005 E.14078
G1 X119.094 Y155.005 E.01265
G1 X123.589 Y150.51 E.15463
G1 X123.422 Y150.46 E.00424
G1 X123.525 Y150.053 E.01021
G1 X118.573 Y155.005 E.17035
G1 X118.052 Y155.005 E.01267
G1 X125.619 Y147.438 E.2603
G1 X126.14 Y147.438 E.01267
G1 X124.943 Y148.635 E.04118
G1 X125.537 Y148.562 E.01456
G1 X126.662 Y147.437 E.0387
G1 X127.183 Y147.437 E.01267
G1 X126.057 Y148.563 E.03873
G1 X126.577 Y148.563 E.01265
G1 X127.704 Y147.436 E.03877
G1 X128.226 Y147.435 E.0127
G1 X127.097 Y148.564 E.03884
G1 X127.617 Y148.565 E.01265
G1 X128.747 Y147.435 E.03887
G1 X129.269 Y147.434 E.0127
G1 X128.137 Y148.566 E.03894
G1 X128.657 Y148.567 E.01265
G1 X129.79 Y147.434 E.03897
G1 X130.312 Y147.433 E.0127
G1 X129.177 Y148.568 E.03904
G1 X129.697 Y148.568 E.01265
G1 X130.833 Y147.433 E.03906
G1 X131.355 Y147.432 E.0127
G1 X130.218 Y148.569 E.03911
G1 X130.738 Y148.57 E.01265
G1 X131.876 Y147.432 E.03915
G1 X132.397 Y147.431 E.01267
G1 X131.258 Y148.571 E.0392
G1 X131.778 Y148.572 E.01265
G1 X132.919 Y147.431 E.03925
G1 X133.44 Y147.43 E.01267
G1 X132.298 Y148.573 E.0393
G1 X132.818 Y148.573 E.01265
G1 X133.962 Y147.43 E.03934
G1 X134.483 Y147.429 E.01267
G1 X133.338 Y148.574 E.03939
G1 X133.858 Y148.575 E.01265
G1 X135.005 Y147.429 E.03944
G1 X135.526 Y147.428 E.01267
G1 X134.378 Y148.576 E.03949
G1 X134.898 Y148.577 E.01265
G1 X136.048 Y147.427 E.03956
G1 X136.569 Y147.427 E.01267
G1 X135.418 Y148.578 E.03959
G1 X135.938 Y148.578 E.01265
G1 X137.09 Y147.426 E.03963
G1 X137.612 Y147.426 E.0127
G1 X136.458 Y148.579 E.03968
G1 X136.627 Y148.58 E.00411
G1 X136.653 Y148.905 E.00793
G1 X138.133 Y147.425 E.05091
G1 X138.655 Y147.425 E.0127
G1 X137.174 Y148.906 E.05095
G1 X137.695 Y148.906 E.01267
G1 X139.176 Y147.424 E.05096
G1 X139.563 Y147.371 E.0095
G1 X139.563 Y147.559 E.00457
G1 X138.215 Y148.906 E.04635
G1 X138.736 Y148.906 E.01267
G1 X139.563 Y148.08 E.02843
G1 X139.563 Y148.6 E.01265
G1 X139.092 Y149.071 E.0162
G1 E-5 F3600
G1 X139.092 Y149.071 F9000
G1 X140.156 Y144.938
G1 X140.21 Y144.708
G1 X140.217 Y144.654
G1 X140.236 Y144.476
G1 X140.24 Y144.421
G1 X140.244 Y144.275
G1 X140.245 Y144.201
G1 X140.246 Y144.102
G1 X140.247 Y144.059
G1 X140.24 Y143.579
G1 X140.21 Y143.292
G1 X140.156 Y143.063
G1 X140.074 Y142.866
G1 X139.057 Y141.08
G1 E5 F2400
G1 F3072.127
G1 X139.562 Y140.575 E.01737
G1 X139.561 Y140.009 E.01377
G1 X138.656 Y140.914 E.03113
G1 X138.091 Y140.914 E.01374
G1 X139.561 Y139.443 E.05058
G1 X139.561 Y139.046 E.00966
G1 X139.362 Y139.076 E.0049
G1 X137.526 Y140.913 E.06317
G1 X136.96 Y140.912 E.01377
G1 X138.778 Y139.094 E.06254
G1 X138.211 Y139.095 E.01379
G1 X136.395 Y140.911 E.06247
G1 X135.83 Y140.91 E.01374
G1 X137.645 Y139.095 E.06243
G1 X137.078 Y139.096 E.01379
G1 X135.265 Y140.909 E.06237
G1 X135.059 Y140.909 E.00501
G1 X135.882 Y139.976 E.03026
G1 X136.676 Y138.932 E.0319
G1 E-5 F3600
G1 X139.628 Y137.604 F9000
G1 X139.803 Y137.485
G1 X139.946 Y137.339
G1 X139.987 Y137.279
G1 X140.074 Y137.134
G1 X140.156 Y136.938
G1 X140.21 Y136.708
G1 X140.217 Y136.654
G1 X140.236 Y136.476
G1 X140.24 Y136.421
G1 X140.244 Y136.275
G1 X140.245 Y136.201
G1 X140.246 Y136.102
G1 X140.247 Y136.059
G1 X140.247 Y135.941
G1 X140.246 Y135.898
G1 X140.245 Y135.799
G1 X140.244 Y135.725
G1 X140.24 Y135.579
G1 X140.236 Y135.524
G1 X140.217 Y135.346
G1 X140.21 Y135.292
G1 X140.156 Y135.063
G1 X140.074 Y134.866
G1 X139.03 Y133.068
G1 E5 F2400
G1 F3072.127
G1 X139.56 Y132.538 E.01823
G1 X139.56 Y132.004 E.01299
G1 X138.661 Y132.903 E.03093
G1 X138.427 Y132.903 E.00569
G1 X138.429 Y132.602 E.00732
G1 X139.56 Y131.47 E.03892
G1 X139.56 Y131.008 E.01124
G1 X139.456 Y131.04 E.00265
G1 X138.431 Y132.065 E.03526
G1 X138.434 Y131.528 E.01306
G1 X139.041 Y130.921 E.02088
G1 E-5 F3600
G1 X139.041 Y130.921 F9000
G1 X140.074 Y129.134
G1 X140.156 Y128.938
G1 X140.21 Y128.708
G1 X140.217 Y128.654
G1 X140.24 Y128.421
G1 X140.24 Y127.579
G1 X140.21 Y127.292
G1 X139.029 Y125.068
G1 E5 F2400
G1 F3072.127
G1 X139.559 Y124.538 E.01823
G1 X139.559 Y124.004 E.01299
G1 X138.66 Y124.904 E.03094
G1 X138.437 Y124.904 E.00542
G1 X138.437 Y124.592 E.00759
G1 X139.559 Y123.47 E.0386
G1 X139.559 Y123.008 E.01124
G1 X139.455 Y123.04 E.00265
G1 X138.437 Y124.058 E.03502
G1 X138.437 Y123.524 E.01299
G1 X139.04 Y122.921 E.02074
G1 E-5 F3600
G1 X139.04 Y122.921 F9000
G1 X140.074 Y121.134
G1 X140.156 Y120.938
G1 X140.21 Y120.708
G1 X140.24 Y120.421
G1 X140.24 Y119.579
G1 X140.21 Y119.292
G1 X139.061 Y117.079
G1 E5 F2400
G1 F3072.127
G1 X139.558 Y116.582 E.0171
G1 X139.558 Y116.04 E.01318
G1 X138.685 Y116.913 E.03003
G1 X138.437 Y116.912 E.00603
G1 X138.437 Y116.619 E.00713
G1 X139.558 Y115.499 E.03854
G1 X139.558 Y115.009 E.01192
G1 X138.437 Y116.078 E.03768
G1 X138.437 Y115.536 E.01318
G1 X139.052 Y114.921 E.02116
G1 E-5 F3600
G1 X139.052 Y114.921 F9000
G1 X140.074 Y113.134
G1 X140.156 Y112.938
G1 X140.21 Y112.708
G1 X140.24 Y112.421
G1 X140.24 Y111.579
G1 X140.21 Y111.292
G1 X139.06 Y109.079
G1 E5 F2400
G1 F3072.127
G1 X139.557 Y108.582 E.0171
G1 X139.557 Y108.041 E.01316
G1 X138.684 Y108.913 E.03001
G1 X138.437 Y108.912 E.00601
G1 X138.437 Y108.619 E.00713
G1 X139.556 Y107.499 E.03851
G1 X139.556 Y107.009 E.01192
G1 X138.437 Y108.077 E.03763
G1 X138.437 Y107.536 E.01316
G1 X139.051 Y106.921 E.02114
G1 E-5 F3600
G1 X139.051 Y106.921 F9000
G1 X140.074 Y105.134
G1 X140.156 Y104.938
G1 X140.21 Y104.708
G1 X140.24 Y104.421
G1 X140.24 Y103.579
G1 X140.21 Y103.292
G1 X139.064 Y101.079
G1 E5 F2400
G1 F3072.127
G1 X139.555 Y100.588 E.01689
G1 X139.555 Y100.05 E.01309
G1 X138.693 Y100.913 E.02967
G1 X138.437 Y100.912 E.00623
G1 X138.437 Y100.631 E.00684
G1 X139.555 Y99.513 E.03846
G1 X139.555 Y98.975 E.01309
G1 X138.437 Y100.094 E.03848
G1 X138.437 Y99.556 E.01309
G1 X139.555 Y98.438 E.03846
G1 X139.555 Y98.001 E.01063
G1 X139.441 Y98.014 E.00279
G1 X138.437 Y99.018 E.03454
G1 X138.437 Y98.481 E.01306
G1 X139.042 Y97.875 E.02083
G1 E-5 F3600
G1 X139.042 Y97.875 F9000
G1 X140.111 Y96.126
G1 X140.188 Y95.959
G1 X140.235 Y95.783
G1 X140.244 Y95.68
G1 X140.249 Y95.623
G1 X140.249 Y93.206
G1 X140.244 Y93.148
G1 X140.235 Y93.046
G1 X140.188 Y92.869
G1 X140.111 Y92.703
G1 X139.045 Y90.953
G1 E5 F2400
G1 F3072.127
G1 X139.554 Y90.444 E.01751
G1 X139.554 Y89.924 E.01265
G1 X138.689 Y90.788 E.02974
G1 X138.169 Y90.788 E.01265
G1 X139.554 Y89.403 E.04764
G1 X139.554 Y88.883 E.01265
G1 X137.648 Y90.788 E.06555
G1 X137.128 Y90.788 E.01265
G1 X139.554 Y88.363 E.08344
G1 X139.553 Y87.842 E.01267
G1 X136.607 Y90.788 E.10134
G1 X136.087 Y90.788 E.01265
G1 X139.553 Y87.322 E.11923
G1 X139.553 Y86.801 E.01267
G1 X135.566 Y90.788 E.13715
G1 X135.046 Y90.788 E.01265
G1 X139.553 Y86.281 E.15504
G1 X139.553 Y85.761 E.01265
G1 X134.526 Y90.788 E.17293
G1 X134.005 Y90.788 E.01267
G1 X139.553 Y85.24 E.19085
G1 X139.553 Y84.72 E.01265
G1 X133.485 Y90.788 E.20874
G1 X132.964 Y90.788 E.01267
G1 X139.553 Y84.2 E.22664
G1 X139.553 Y83.679 E.01267
G1 X132.444 Y90.788 E.24455
G1 X131.924 Y90.788 E.01265
G1 X139.553 Y83.159 E.26243
G1 X139.553 Y82.639 E.01265
G1 X131.403 Y90.788 E.28034
G1 X130.883 Y90.788 E.01265
G1 X139.553 Y82.118 E.29824
G1 X139.552 Y81.598 E.01265
G1 X130.362 Y90.788 E.31613
G1 X129.842 Y90.788 E.01265
G1 X139.552 Y81.077 E.33404
G1 X139.552 Y80.557 E.01265
G1 X129.321 Y90.788 E.35194
G1 X129.207 Y90.788 E.00277
G1 X129.218 Y90.371 E.01015
G1 X139.552 Y80.037 E.35548
G1 X139.517 Y79.552 E.01183
G1 X129.143 Y89.925 E.35684
G1 X129.014 Y89.534 E.01001
G1 X139.448 Y79.1 E.35892
G1 X139.325 Y78.703 E.01011
G1 X128.814 Y89.214 E.36157
G1 X128.573 Y88.934 E.00899
G1 X139.188 Y78.319 E.36515
G1 X139.001 Y77.986 E.00929
G1 X128.303 Y88.684 E.368
G1 X128.027 Y88.439 E.00898
G1 X128.87 Y87.596 E.029
G1 X128.114 Y87.832 E.01926
G1 X127.634 Y88.312 E.01651
G1 E-5 F3600
G1 X127.634 Y88.312 F9000
G1 X132.018 Y84.449
G1 E5 F2400
G1 F3072.127
G1 X138.807 Y77.66 E.23354
G1 X138.57 Y77.376 E.009
G1 X132.552 Y83.394 E.20702
G1 X132.689 Y82.736 E.01635
G1 X138.327 Y77.099 E.19393
G1 X138.043 Y76.862 E.009
G1 X132.73 Y82.175 E.18276
G1 X132.737 Y81.648 E.01282
G1 X137.756 Y76.629 E.17265
G1 X137.431 Y76.433 E.00923
G1 X132.737 Y81.127 E.16147
G1 X132.737 Y80.607 E.01265
G1 X137.077 Y76.266 E.14931
G1 X136.695 Y76.128 E.00988
G1 X132.737 Y80.086 E.13615
G1 X132.737 Y79.82 E.00647
G1 X133.557 Y79.083 E.02682
G1 X133.984 Y78.525 E.01709
G1 X134.149 Y78.154 E.00988
G1 X136.279 Y76.023 E.07329
G1 X135.828 Y75.954 E.0111
G1 X134.239 Y77.543 E.05466
G1 X134.186 Y77.076 E.01143
G1 X135.311 Y75.951 E.0387
G1 X134.792 Y75.95 E.01262
G1 X134.069 Y76.672 E.02485
G1 X133.879 Y76.341 E.00928
G1 X134.272 Y75.948 E.01352
G1 X133.753 Y75.947 E.01262
G1 X133.548 Y76.153 E.00707
G1 E-5 F3600
G1 X133.548 Y76.153 F9000
G1 X131.109 Y83.505
G1 X131.063 Y83.636
G1 X130.992 Y83.813
G1 X130.937 Y83.939
G1 X130.853 Y84.112
G1 X130.79 Y84.232
G1 X130.694 Y84.399
G1 X130.623 Y84.512
G1 X130.516 Y84.672
G1 X130.437 Y84.778
G1 X130.321 Y84.929
G1 X130.235 Y85.029
G1 X130.11 Y85.171
G1 X130.016 Y85.264
G1 X129.883 Y85.395
G1 X129.783 Y85.48
G1 X129.639 Y85.603
G1 X129.485 Y85.718
G1 X129.38 Y85.796
G1 X129.215 Y85.901
G1 X129.105 Y85.971
G1 X128.933 Y86.066
G1 X128.817 Y86.127
G1 X128.647 Y86.206
G1 X128.528 Y86.258
G1 X128.353 Y86.325
G1 X128.23 Y86.367
G1 X128.051 Y86.423
G1 X127.926 Y86.456
G1 X127.744 Y86.499
G1 X127.616 Y86.524
G1 X127.431 Y86.555
G1 X127.302 Y86.569
G1 X127.116 Y86.588
G1 X104.651 Y88.151
G1 X101.24 Y90.953
G1 E5 F2400
G1 F3072.127
G1 X101.786 Y90.406 E.0188
G1 X101.792 Y90.075 E.00805
G1 X101.884 Y89.786 E.00738
G1 X100.883 Y90.788 E.03445
G1 X100.361 Y90.788 E.0127
G1 X103.244 Y87.906 E.09916
G1 X102.813 Y87.815 E.01071
G1 X99.84 Y90.788 E.10227
G1 X99.318 Y90.788 E.0127
G1 X102.404 Y87.702 E.10616
G1 X102.028 Y87.557 E.0098
G1 X98.797 Y90.788 E.11114
G1 X98.276 Y90.788 E.01267
G1 X101.657 Y87.406 E.11632
G1 X101.317 Y87.225 E.00937
G1 X97.754 Y90.788 E.12257
G1 X97.233 Y90.788 E.01267
G1 X100.999 Y87.022 E.12955
G1 X100.68 Y86.819 E.0092
G1 X96.711 Y90.788 E.13653
G1 X96.19 Y90.788 E.01267
G1 X100.388 Y86.59 E.14441
G1 X100.122 Y86.335 E.00896
G1 X95.668 Y90.788 E.1532
G1 X95.147 Y90.788 E.01267
G1 X99.86 Y86.075 E.16212
G1 X99.613 Y85.801 E.00897
G1 X94.626 Y90.788 E.17155
G1 X94.104 Y90.788 E.0127
G1 X99.392 Y85.501 E.18189
G1 X99.187 Y85.184 E.00918
G1 X93.583 Y90.788 E.19277
G1 X93.061 Y90.788 E.0127
G1 X98.982 Y84.867 E.20368
G1 X98.82 Y84.508 E.00958
G1 X92.54 Y90.788 E.21603
G1 X92.018 Y90.788 E.0127
G1 X98.667 Y84.14 E.2287
G1 X98.525 Y83.761 E.00984
G1 X91.439 Y90.828 E.24343
G1 X91.438 Y90.325 E.01224
G1 X98.424 Y83.34 E.2403
G1 X98.344 Y82.898 E.01093
G1 X91.438 Y89.804 E.23756
G1 X91.438 Y89.283 E.01267
G1 X98.282 Y82.439 E.23543
G1 X98.272 Y81.928 E.01243
G1 X91.438 Y88.761 E.23507
G1 X91.438 Y88.24 E.01267
G1 X98.27 Y81.408 E.23502
G1 X98.269 Y80.888 E.01265
G1 X91.438 Y87.719 E.23498
G1 X91.438 Y87.197 E.0127
G1 X98.267 Y80.368 E.23491
G1 X98.266 Y79.848 E.01265
G1 X91.438 Y86.676 E.23488
G1 X91.438 Y86.155 E.01267
G1 X98 Y79.592 E.22575
G1 X97.721 Y79.351 E.00897
G1 X91.438 Y85.633 E.21611
G1 X91.438 Y85.112 E.01267
G1 X97.459 Y79.091 E.20712
G1 X97.214 Y78.814 E.009
G1 X91.438 Y84.591 E.19871
G1 X91.437 Y84.069 E.0127
G1 X97.004 Y78.503 E.19148
G1 X96.861 Y78.125 E.00983
G1 X91.437 Y83.548 E.18657
G1 X91.437 Y83.027 E.01267
G1 X96.787 Y77.677 E.18404
G1 X96.802 Y77.141 E.01304
G1 X91.437 Y82.505 E.18454
G1 X91.437 Y81.984 E.01267
G1 X97.182 Y76.239 E.19762
G1 X97.417 Y75.948 E.0091
G1 X96.952 Y75.948 E.01131
G1 X91.437 Y81.463 E.18971
G1 X91.437 Y80.941 E.0127
G1 X96.431 Y75.948 E.17177
G1 X95.909 Y75.948 E.0127
G1 X91.437 Y80.42 E.15383
G1 X91.447 Y79.889 E.01292
G1 X95.388 Y75.948 E.13557
G1 X94.813 Y76.002 E.01405
G1 X91.507 Y79.307 E.11371
G1 X91.691 Y78.601 E.01775
G1 X94.073 Y76.22 E.08192
G1 X93.227 Y76.637 E.02294
G1 X92.814 Y76.958 E.01272
G1 X91.797 Y77.974 E.03497
G1 E-5 F3600
G1 X91.797 Y77.974 F9000
G1 X90.751 Y93.206
G1 X90.751 Y95.623
G1 X90.756 Y95.68
G1 X90.765 Y95.783
G1 X90.812 Y95.959
G1 X90.889 Y96.126
G1 X91.97 Y97.875
G1 E5 F2400
G1 F3072.127
G1 X91.44 Y98.406 E.01825
G1 X91.44 Y98.938 E.01294
G1 X92.338 Y98.04 E.03089
G1 X92.563 Y98.04 E.00547
G1 X92.563 Y98.347 E.00747
G1 X91.44 Y99.471 E.03865
G1 X91.44 Y100.003 E.01294
G1 X92.563 Y98.88 E.03863
G1 X92.563 Y99.412 E.01294
G1 X91.44 Y100.536 E.03865
G1 X91.44 Y100.992 E.01109
G1 X91.55 Y100.958 E.0028
G1 X92.563 Y99.945 E.03485
G1 X92.563 Y100.478 E.01296
G1 X91.962 Y101.079 E.02067
G1 E-5 F3600
G1 X91.962 Y101.079 F9000
G1 X90.926 Y102.866
G1 X90.844 Y103.062
G1 X90.79 Y103.292
G1 X90.783 Y103.346
G1 X90.764 Y103.524
G1 X90.76 Y103.579
G1 X90.756 Y103.725
G1 X90.755 Y103.799
G1 X90.754 Y103.898
G1 X90.753 Y103.941
G1 X90.753 Y104.059
G1 X90.754 Y104.102
G1 X90.755 Y104.201
G1 X90.756 Y104.275
G1 X90.76 Y104.421
G1 X90.764 Y104.476
G1 X90.783 Y104.654
G1 X90.79 Y104.708
G1 X90.844 Y104.937
G1 X90.926 Y105.134
G1 X91.938 Y106.921
G1 E5 F2400
G1 F3072.127
G1 X91.441 Y107.418 E.0171
G1 X91.441 Y107.96 E.01318
G1 X92.314 Y107.087 E.03003
G1 X92.563 Y107.088 E.00606
G1 X92.563 Y107.38 E.0071
G1 X91.441 Y108.502 E.0386
G1 X91.441 Y108.992 E.01192
G1 X92.563 Y107.922 E.03771
G1 X92.563 Y108.464 E.01318
G1 X91.948 Y109.079 E.02116
G1 E-5 F3600
G1 X91.948 Y109.079 F9000
G1 X90.926 Y110.866
G1 X90.844 Y111.062
G1 X90.79 Y111.292
G1 X90.783 Y111.346
G1 X90.764 Y111.524
G1 X90.76 Y111.579
G1 X90.756 Y111.725
G1 X90.755 Y111.799
G1 X90.754 Y111.898
G1 X90.753 Y111.941
G1 X90.753 Y112.059
G1 X90.754 Y112.102
G1 X90.755 Y112.201
G1 X90.756 Y112.275
G1 X90.76 Y112.421
G1 X90.764 Y112.476
G1 X90.783 Y112.654
G1 X90.79 Y112.708
G1 X90.844 Y112.937
G1 X90.926 Y113.134
G1 X91.918 Y114.921
G1 E5 F2400
G1 F3072.127
G1 X91.442 Y115.396 E.01636
G1 X91.442 Y115.942 E.01328
G1 X92.297 Y115.087 E.02941
G1 X92.563 Y115.088 E.00647
G1 X92.563 Y115.367 E.00679
G1 X91.442 Y116.487 E.03854
G1 X91.442 Y116.991 E.01226
G1 X92.563 Y115.912 E.03785
G1 X92.563 Y116.458 E.01328
G1 X91.942 Y117.079 E.02136
G1 E-5 F3600
G1 X91.942 Y117.079 F9000
G1 X90.926 Y118.866
G1 X90.844 Y119.062
G1 X90.79 Y119.292
G1 X90.783 Y119.346
G1 X90.764 Y119.524
G1 X90.76 Y119.579
G1 X90.756 Y119.725
G1 X90.755 Y119.799
G1 X90.754 Y119.898
G1 X90.753 Y119.941
G1 X90.753 Y144.059
G1 X90.754 Y144.102
G1 X90.755 Y144.201
G1 X90.756 Y144.275
G1 X90.76 Y144.421
G1 X90.764 Y144.476
G1 X90.783 Y144.654
G1 X90.79 Y144.708
G1 X90.844 Y144.937
G1 X90.926 Y145.134
G1 X91.013 Y145.28
G1 X91.054 Y145.339
G1 X91.197 Y145.485
G1 X91.372 Y145.604
G1 X91.565 Y145.679
G1 X91.698 Y145.702
G1 X91.779 Y145.708
G1 X105.905 Y145.71
G1 X111.585 Y144.183
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.434276
G1 F1200
G1 X119.415 Y144.183 E.20831
G1 E-5 F3600
G1 X119.415 Y144.183 F9000
G1 X123.876 Y145.901
G1 E5 F2400
;WIDTH:0.40516
G1 F1200
G1 X124.011 Y146.214 E.00841
;WIDTH:0.408468
G1 X124.39 Y146.649 E.01436
;WIDTH:0.416068
G1 X124.728 Y146.882 E.01042
G1 X125.149 Y147.03 E.01133
;WIDTH:0.388876
G1 X125.633 Y147.085 E.01149
;WIDTH:0.374336
G1 X139.238 Y147.071 E.3077
G1 E-5 F3600
G1 X139.238 Y147.071 F9000
G1 X123.837 Y150.226
G1 E5 F2400
;WIDTH:0.387478
G1 F1200
G1 X123.921 Y149.96 E.00655
;WIDTH:0.422376
G1 X124.189 Y149.536 E.01295
;WIDTH:0.442314
G1 X124.609 Y149.185 E.01485
G1 X124.981 Y149.012 E.01113
;WIDTH:0.42576
G1 X125.61 Y148.916 E.01657
;WIDTH:0.375786
G1 X125.633 Y148.915 E.00052
;WIDTH:0.374336
G1 X136.281 Y148.925 E.24082
;LAYER_CHANGE
;Z:1.58
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;1.58
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X133.123 Y148.922 E-1.5
;WIPE_END
G1 Z1.58 F9000
;AFTER_LAYER_CHANGE
;1.58
G1 Z1.58
G1 X130.796 Y145.85
G1 X127.61 Y141.644
G1 X126.349 Y139.199
G1 X126.349 Y139.439
G1 X125.939 Y139.439
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X125.987 Y139.384 E.00178
G1 X126.019 Y139.021 E.00886
G1 X127.602 Y137.69 E.05031
G1 X127.709 Y137.58 E.00373
G1 X127.726 Y137.48 E.00247
G1 X127.662 Y137.36 E.00331
G1 X126 Y135.963 E.05281
G1 X126 Y103.914 E.77956
G1 X126.109 Y103.792 E.00398
G1 X126.109 Y98.457 E.12977
G1 X126 Y98.334 E.004
G1 X126 Y93.222 E.12434
G1 X126.033 Y93.166 E.00158
G1 X138.873 Y93.165 E.31232
G1 X139.096 Y93.212 E.00554
G1 X139.204 Y93.319 E.0037
G1 X139.25 Y93.541 E.00551
G1 X139.238 Y95.385 E.04485
G1 X139.141 Y95.589 E.00549
G1 X138.932 Y95.663 E.00539
G1 X136.183 Y95.662 E.06687
G1 X136.037 Y95.735 E.00397
G1 X136 Y95.845 E.00282
G1 X136 Y132.295 E.88661
G1 X135.95 Y133.282 E.02404
G1 X135.837 Y134.073 E.01944
G1 X135.713 Y134.651 E.01438
G1 X135.282 Y135.98 E.03398
G1 X134.732 Y137.119 E.03077
G1 X134.427 Y137.625 E.01437
G1 X133.884 Y138.382 E.02266
G1 X133.362 Y138.987 E.01944
G1 X132.945 Y139.409 E.01443
G1 X132.24 Y140.017 E.02264
G1 X131.59 Y140.483 E.01945
G1 X131.088 Y140.794 E.01436
G1 X129.83 Y141.403 E.034
G1 X128.626 Y141.793 E.03078
G1 X128.052 Y141.923 E.01432
G1 X126.662 Y142.089 E.03405
G1 X120.811 Y142.1 E.14232
G1 X120.74 Y141.992 E.00314
G1 X120.667 Y141.977 E.00181
G1 X110.333 Y141.977 E.25136
G1 X110.301 Y141.98 E.00078
G1 X110.189 Y142.1 E.00399
G1 X104.802 Y142.1 E.13103
G1 X104.205 Y142.08 E.01453
G1 X103.41 Y142.001 E.01943
G1 X102.369 Y141.792 E.02583
G1 X101.605 Y141.565 E.01939
G1 X100.74 Y141.22 E.02265
G1 X100.208 Y140.956 E.01445
G1 X99.517 Y140.555 E.01943
G1 X98.758 Y140.016 E.02264
G1 X98.303 Y139.636 E.01442
G1 X97.726 Y139.083 E.01944
G1 X97.114 Y138.381 E.02265
G1 X96.761 Y137.904 E.01443
G1 X96.33 Y137.231 E.01944
G1 X95.9 Y136.405 E.02265
G1 X95.669 Y135.858 E.01444
G1 X95.409 Y135.105 E.01938
G1 X95.106 Y133.741 E.03399
G1 X95.006 Y132.636 E.02699
G1 X94.999 Y95.845 E.8949
G1 X94.962 Y95.735 E.00282
G1 X94.816 Y95.662 E.00397
G1 X93.003 Y95.663 E.0441
G1 X91.949 Y95.641 E.02564
G1 X91.835 Y95.549 E.00356
G1 X91.75 Y95.346 E.00535
G1 X91.757 Y93.415 E.04697
G1 X91.859 Y93.24 E.00493
G1 X92.069 Y93.165 E.00542
G1 X104.945 Y93.167 E.3132
G1 X105 Y93.199 E.00155
G1 X105 Y98.334 E.1249
G1 X104.891 Y98.457 E.004
G1 X104.891 Y103.792 E.12977
G1 X105 Y103.914 E.00398
G1 X105 Y135.963 E.77956
G1 X103.338 Y137.36 E.05281
G1 X103.273 Y137.495 E.00364
G1 X103.338 Y137.64 E.00387
G1 X104.981 Y139.021 E.05221
G1 X105.032 Y139.42 E.00978
G1 X105.183 Y139.5 E.00416
G1 X125.817 Y139.5 E.5019
G1 X125.897 Y139.479 E.00201
G1 X125.897 Y139.479 F9000
G1 X126.199 Y139.701
;TYPE:Perimeter
G1 F6000
G1 X126.237 Y139.67 E.00119
G1 X126.327 Y139.518 E.0043
G1 X126.374 Y139.2 E.00782
G1 X127.838 Y137.97 E.04651
G1 X128.038 Y137.74 E.00741
G1 X128.09 Y137.558 E.0046
G1 X128.057 Y137.305 E.00621
G1 X127.897 Y137.08 E.00672
G1 X126.366 Y135.793 E.04865
G1 X126.366 Y103.982 E.77377
G1 X126.463 Y103.903 E.00304
G1 X126.474 Y103.792 E.00271
G1 X126.474 Y98.457 E.12977
G1 X126.461 Y98.337 E.00294
G1 X126.366 Y98.261 E.00296
G1 X126.366 Y93.532 E.11503
G1 X138.885 Y93.541 E.30451
G1 X138.883 Y95.298 E.04274
G1 X136.184 Y95.297 E.06565
G1 X135.925 Y95.361 E.00649
G1 X135.745 Y95.516 E.00578
G1 X135.657 Y95.692 E.00479
G1 X135.635 Y95.845 E.00376
G1 X135.634 Y132.286 E.88639
G1 X135.586 Y133.247 E.0234
G1 X135.477 Y134.008 E.0187
G1 X135.36 Y134.556 E.01363
G1 X134.942 Y135.843 E.03291
G1 X134.41 Y136.945 E.02977
G1 X134.121 Y137.424 E.01361
G1 X133.596 Y138.156 E.02191
G1 X133.093 Y138.739 E.01873
G1 X132.695 Y139.142 E.01378
G1 X132.014 Y139.73 E.02188
G1 X131.387 Y140.178 E.01874
G1 X130.911 Y140.473 E.01362
G1 X129.693 Y141.063 E.03292
G1 X128.529 Y141.44 E.02976
G1 X127.989 Y141.563 E.01347
G1 X126.64 Y141.723 E.03304
G1 X120.936 Y141.734 E.13874
G1 X120.885 Y141.656 E.00227
G1 X120.667 Y141.611 E.00541
G1 X110.333 Y141.611 E.25136
G1 X110.114 Y141.657 E.00544
G1 X110.063 Y141.735 E.00227
G1 X104.809 Y141.735 E.1278
G1 X104.229 Y141.715 E.01412
G1 X103.464 Y141.639 E.0187
G1 X102.457 Y141.437 E.02498
G1 X101.725 Y141.219 E.01858
G1 X100.889 Y140.886 E.02189
G1 X100.382 Y140.634 E.01377
G1 X99.715 Y140.247 E.01876
G1 X98.981 Y139.727 E.02188
G1 X98.547 Y139.363 E.01378
G1 X97.99 Y138.83 E.01875
G1 X97.399 Y138.152 E.02188
G1 X97.062 Y137.696 E.01379
G1 X96.647 Y137.047 E.01874
G1 X96.231 Y136.249 E.02189
G1 X96.011 Y135.727 E.01378
G1 X95.762 Y135.005 E.01858
G1 X95.468 Y133.684 E.03292
G1 X95.371 Y132.62 E.02599
G1 X95.365 Y95.845 E.89452
G1 X95.343 Y95.691 E.00378
G1 X95.255 Y95.516 E.00476
G1 X95.074 Y95.361 E.0058
G1 X94.816 Y95.297 E.00647
G1 X92.116 Y95.298 E.06567
G1 X92.123 Y93.531 E.04298
G1 X104.634 Y93.533 E.30432
G1 X104.634 Y98.261 E.115
G1 X104.539 Y98.337 E.00296
G1 X104.526 Y98.457 E.00294
G1 X104.526 Y103.792 E.12977
G1 X104.534 Y103.886 E.00229
G1 X104.634 Y103.982 E.00337
G1 X104.634 Y135.793 E.77377
G1 X103.103 Y137.08 E.04865
G1 X103.037 Y137.146 E.00227
G1 X102.918 Y137.394 E.00669
G1 X102.939 Y137.685 E.0071
G1 X103.103 Y137.92 E.00697
G1 X104.626 Y139.2 E.04839
G1 X104.635 Y139.351 E.00368
G1 X104.729 Y139.626 E.00707
G1 X104.881 Y139.775 E.00518
G1 X105.183 Y139.866 E.00767
G1 X125.817 Y139.866 E.5019
G1 X126.082 Y139.797 E.00666
G1 X126.153 Y139.739 E.00223
G1 X126.153 Y139.739 F9000
G1 X126.455 Y139.956
G1 F6000
G1 X126.518 Y139.905 E.00197
G1 X126.668 Y139.653 E.00713
G1 X126.728 Y139.38 E.0068
G1 X128.073 Y138.25 E.04273
G1 X128.366 Y137.9 E.0111
G1 X128.414 Y137.78 E.00314
G1 X128.453 Y137.398 E.00934
G1 X128.338 Y137.047 E.00898
G1 X128.132 Y136.8 E.00782
G1 X126.731 Y135.623 E.04451
G1 X126.731 Y104.051 E.76796
G1 X126.821 Y103.978 E.00282
G1 X126.84 Y103.792 E.00455
G1 X126.84 Y98.457 E.12977
G1 X126.818 Y98.257 E.00489
G1 X126.731 Y98.188 E.0027
G1 X126.731 Y93.897 E.10437
G1 X138.519 Y93.896 E.28673
G1 X138.519 Y94.932 E.0252
G1 X136.183 Y94.931 E.05682
G1 X135.753 Y95.038 E.01078
G1 X135.452 Y95.297 E.00966
G1 X135.306 Y95.589 E.00794
G1 X135.269 Y95.845 E.00629
G1 X135.269 Y132.277 E.88617
G1 X135.222 Y133.211 E.02275
G1 X135.117 Y133.944 E.01801
G1 X135.006 Y134.461 E.01286
G1 X134.602 Y135.707 E.03186
G1 X134.088 Y136.771 E.02874
G1 X133.815 Y137.223 E.01284
G1 X133.309 Y137.929 E.02113
G1 X132.824 Y138.491 E.01806
G1 X132.445 Y138.875 E.01312
G1 X131.787 Y139.442 E.02113
G1 X131.184 Y139.874 E.01804
G1 X130.735 Y140.152 E.01285
G1 X129.556 Y140.723 E.03186
G1 X128.432 Y141.087 E.02874
G1 X127.927 Y141.202 E.0126
G1 X126.618 Y141.358 E.03207
G1 X121.062 Y141.368 E.13514
G1 X121.031 Y141.321 E.00137
G1 X120.667 Y141.245 E.00904
G1 X110.333 Y141.245 E.25136
G1 X109.968 Y141.322 E.00907
G1 X109.937 Y141.369 E.00137
G1 X104.815 Y141.369 E.12459
G1 X104.253 Y141.35 E.01368
G1 X103.518 Y141.277 E.01797
G1 X102.545 Y141.081 E.02414
G1 X101.845 Y140.873 E.01776
G1 X101.038 Y140.552 E.02113
G1 X100.555 Y140.312 E.01312
G1 X99.913 Y139.939 E.01806
G1 X99.205 Y139.437 E.02111
G1 X98.791 Y139.091 E.01312
G1 X98.255 Y138.577 E.01806
G1 X97.684 Y137.922 E.02114
G1 X97.364 Y137.489 E.0131
G1 X96.964 Y136.864 E.01805
G1 X96.563 Y136.093 E.02114
G1 X96.352 Y135.597 E.01311
G1 X96.114 Y134.906 E.01778
G1 X95.83 Y133.628 E.03184
G1 X95.737 Y132.603 E.02503
G1 X95.73 Y95.845 E.8941
G1 X95.694 Y95.589 E.00629
G1 X95.547 Y95.296 E.00797
G1 X95.246 Y95.038 E.00964
G1 X94.816 Y94.931 E.01078
G1 X92.483 Y94.932 E.05675
G1 X92.487 Y93.896 E.0252
G1 X104.269 Y93.898 E.28659
G1 X104.269 Y98.188 E.10435
G1 X104.182 Y98.257 E.0027
G1 X104.16 Y98.457 E.00489
G1 X104.16 Y103.792 E.12977
G1 X104.174 Y103.95 E.00386
G1 X104.269 Y104.051 E.00337
G1 X104.269 Y135.623 E.76796
G1 X102.868 Y136.8 E.04451
G1 X102.635 Y137.098 E.0092
G1 X102.542 Y137.475 E.00945
G1 X102.595 Y137.808 E.0082
G1 X102.688 Y137.997 E.00512
G1 X102.868 Y138.2 E.0066
G1 X104.272 Y139.38 E.04461
G1 X104.323 Y139.628 E.00616
G1 X104.427 Y139.831 E.00555
G1 X104.68 Y140.081 E.00865
G1 X104.965 Y140.205 E.00756
G1 X105.183 Y140.231 E.00534
G1 X125.817 Y140.231 E.5019
G1 X125.977 Y140.217 E.00391
G1 X126.259 Y140.118 E.00727
G1 X126.409 Y139.994 E.00473
G1 X126.711 Y140.211 F9000
G1 F6000
G1 X126.798 Y140.14 E.00273
G1 X127.008 Y139.787 E.00999
G1 X127.056 Y139.582 E.00512
G1 X128.368 Y138.48 E.04168
G1 X128.695 Y138.059 E.01297
G1 X128.817 Y137.636 E.01071
G1 X128.794 Y137.224 E.01004
G1 X128.656 Y136.866 E.00933
G1 X128.368 Y136.52 E.01095
G1 X127.097 Y135.452 E.04038
G1 X127.097 Y104.119 E.76214
G1 X127.179 Y104.052 E.00258
G1 X127.206 Y103.792 E.00636
G1 X127.206 Y98.457 E.12977
G1 X127.175 Y98.177 E.00685
G1 X127.097 Y98.115 E.00242
G1 X127.097 Y94.263 E.0937
G1 X135.468 Y94.262 E.20362
G1 X136.183 Y94.247 E.0174
;WIDTH:0.369222
G1 X138.169 Y94.247 E.04424
G1 X138.169 Y94.582 E.00746
G1 X136.184 Y94.581 E.04422
;WIDTH:0.3796
G1 X135.964 Y94.595 E.00506
;WIDTH:0.399999
G1 X135.581 Y94.716 E.00977
G1 X135.16 Y95.077 E.01349
G1 X134.955 Y95.487 E.01115
G1 X134.903 Y95.845 E.0088
G1 X134.903 Y132.268 E.88595
G1 X134.857 Y133.176 E.02211
G1 X134.776 Y133.748 E.01405
G1 X134.653 Y134.366 E.01533
G1 X134.262 Y135.57 E.03079
G1 X133.826 Y136.472 E.02437
G1 X133.51 Y137.022 E.01543
G1 X133.021 Y137.703 E.02039
G1 X132.555 Y138.243 E.01735
G1 X132.195 Y138.607 E.01245
G1 X131.561 Y139.154 E.02037
G1 X131.021 Y139.541 E.01616
G1 X130.558 Y139.832 E.0133
G1 X129.42 Y140.382 E.03074
G1 X128.373 Y140.722 E.02678
G1 X127.865 Y140.841 E.01269
G1 X126.579 Y140.992 E.0315
;WIDTH:0.415459
G1 X125.818 Y140.986 E.01929
;WIDTH:0.419716
G1 X121.257 Y140.992 E.11692
G1 X120.924 Y140.938 E.00865
;WIDTH:0.389136
G1 X120.667 Y140.9 E.00613
;WIDTH:0.358555
G1 X110.333 Y140.9 E.22287
;WIDTH:0.389419
G1 X110.037 Y140.947 E.00708
;WIDTH:0.420283
G1 X109.74 Y140.993 E.00772
G1 X105.183 Y140.993 E.11699
;WIDTH:0.441882
G1 X104.278 Y140.985 E.02454
;WIDTH:0.399999
G1 X103.573 Y140.915 E.01723
G1 X102.633 Y140.726 E.02332
G1 X101.965 Y140.527 E.01695
G1 X101.187 Y140.217 E.02037
G1 X100.728 Y139.99 E.01246
G1 X100.111 Y139.631 E.01736
G1 X99.428 Y139.147 E.02036
G1 X99.035 Y138.818 E.01247
G1 X98.52 Y138.325 E.01734
G1 X97.97 Y137.693 E.02038
G1 X97.665 Y137.281 E.01247
G1 X97.281 Y136.681 E.01733
G1 X96.894 Y135.937 E.0204
G1 X96.694 Y135.466 E.01245
G1 X96.467 Y134.806 E.01698
G1 X96.192 Y133.571 E.03078
G1 X96.103 Y132.586 E.02406
G1 X96.096 Y95.845 E.89369
G1 X96.045 Y95.486 E.00882
G1 X95.84 Y95.077 E.01113
G1 X95.418 Y94.716 E.01351
G1 X94.816 Y94.581 E.01501
;WIDTH:0.369184
G1 X92.835 Y94.582 E.04413
G1 X92.836 Y94.247 E.00746
G1 X94.816 Y94.247 E.0441
;WIDTH:0.399999
G1 X95.531 Y94.262 E.0174
G1 X103.903 Y94.264 E.20364
G1 X103.903 Y98.115 E.09367
G1 X103.825 Y98.177 E.00242
G1 X103.794 Y98.457 E.00685
G1 X103.794 Y103.792 E.12977
G1 X103.814 Y104.013 E.0054
G1 X103.903 Y104.119 E.00337
G1 X103.903 Y135.452 E.76214
G1 X102.632 Y136.52 E.04038
G1 X102.479 Y136.673 E.00526
G1 X102.264 Y137.034 E.01022
G1 X102.176 Y137.465 E.0107
G1 X102.251 Y137.931 E.01148
G1 X102.382 Y138.196 E.00719
G1 X102.632 Y138.48 E.0092
G1 X103.944 Y139.582 E.04168
G1 X103.979 Y139.753 E.00425
G1 X104.124 Y140.037 E.00776
G1 X104.479 Y140.386 E.01211
;WIDTH:0.441882
G1 X104.873 Y140.581 E.01192
G1 X105.183 Y140.607 E.00843
;WIDTH:0.420285
G1 X109.74 Y140.607 E.11699
G1 X110.037 Y140.592 E.00763
;WIDTH:0.389419
G1 X110.333 Y140.576 E.007
;WIDTH:0.358555
G1 X120.667 Y140.576 E.22287
;WIDTH:0.389136
G1 X120.962 Y140.592 E.00697
;WIDTH:0.419716
G1 X121.257 Y140.607 E.00757
G1 X125.817 Y140.605 E.1169
;WIDTH:0.426658
G1 X126.043 Y140.59 E.00591
G1 X126.436 Y140.438 E.011
;WIDTH:0.399999
G1 X126.664 Y140.249 E.0072
G1 E-5 F3600
G1 X126.664 Y140.249 F9000
G1 X126.348 Y139.848
G1 X104.651 Y139.849
G1 X102.645 Y137.5
G1 X103.537 Y118.921
G1 E5 F2400
G1 F6000
G1 X103.537 Y135.282 E.39796
G1 X102.26 Y136.369 E.04079
G1 X101.978 Y136.776 E.01204
G1 X101.842 Y137.181 E.01039
G1 X101.818 Y137.658 E.01162
G1 X101.906 Y138.054 E.00987
G1 X102.075 Y138.394 E.00924
G1 X102.397 Y138.76 E.01186
G1 X103.616 Y139.784 E.03872
G1 X103.822 Y140.242 E.01222
G1 X104.194 Y140.609 E.01271
G1 X103.627 Y140.553 E.01386
G1 X102.722 Y140.371 E.02245
G1 X102.085 Y140.182 E.01616
G1 X101.366 Y139.895 E.01883
G1 X100.901 Y139.667 E.0126
G1 X100.309 Y139.323 E.01665
G1 X99.696 Y138.888 E.01828
G1 X99.279 Y138.545 E.01313
G1 X98.785 Y138.072 E.01664
G1 X98.311 Y137.528 E.01755
G1 X97.966 Y137.074 E.01387
G1 X97.597 Y136.498 E.01664
G1 X97.279 Y135.886 E.01678
G1 X97.036 Y135.335 E.01465
G1 X96.819 Y134.707 E.01616
G1 X96.554 Y133.515 E.0297
G1 X96.468 Y132.57 E.02308
G1 X96.462 Y95.845 E.8933
G1 X96.396 Y95.384 E.01133
G1 X96.132 Y94.857 E.01434
G1 X95.865 Y94.628 E.00856
G1 X103.537 Y94.629 E.18661
G1 X103.537 Y98.042 E.08302
G1 X103.468 Y98.097 E.00215
G1 X103.429 Y98.457 E.00881
G1 X103.429 Y103.792 E.12977
G1 X103.453 Y104.076 E.00693
G1 X103.537 Y104.187 E.00339
G1 X103.537 Y118.861 E.35693
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.537 Y118.921 E-.0285
G1 X103.537 Y122.019 E-1.4715
;WIPE_END
G1 X127.463 Y94.629 F9000
G1 E5 F2400
G1 F6000
G1 X135.135 Y94.628 E.18661
G1 X134.867 Y94.858 E.00859
G1 X134.604 Y95.384 E.0143
G1 X134.538 Y95.845 E.01133
G1 X134.537 Y132.258 E.88571
G1 X134.493 Y133.141 E.0215
G1 X134.414 Y133.696 E.01364
G1 X134.299 Y134.271 E.01426
G1 X133.922 Y135.434 E.02974
G1 X133.497 Y136.313 E.02375
G1 X133.204 Y136.82 E.01424
G1 X132.734 Y137.476 E.01963
G1 X132.327 Y137.948 E.01516
G1 X131.946 Y138.34 E.0133
G1 X131.335 Y138.867 E.01963
G1 X130.808 Y139.244 E.01576
G1 X130.382 Y139.511 E.01223
G1 X129.283 Y140.042 E.02969
G1 X128.26 Y140.374 E.02616
G1 X127.802 Y140.48 E.01143
G1 X126.805 Y140.599 E.02442
G1 X127.078 Y140.375 E.00859
G1 X127.348 Y139.921 E.01285
G1 X127.383 Y139.785 E.00342
G1 X128.603 Y138.76 E.03876
G1 X129.024 Y138.219 E.01667
G1 X129.18 Y137.674 E.01379
G1 X129.179 Y137.317 E.00868
G1 X129.083 Y136.916 E.01003
G1 X128.923 Y136.603 E.00855
G1 X128.603 Y136.24 E.01177
G1 X127.463 Y135.282 E.03622
G1 X127.463 Y104.187 E.75635
G1 X127.537 Y104.127 E.00232
G1 X127.571 Y103.792 E.00819
G1 X127.571 Y98.457 E.12977
G1 X127.532 Y98.097 E.00881
G1 X127.463 Y98.042 E.00215
G1 X127.463 Y94.689 E.08156
G1 E-5 F3600
G1 X127.463 Y94.689 F9000
G1 X134.564 Y95.225
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X134.242 Y94.902 E.01109
G1 X133.723 Y94.902 E.01262
G1 X134.313 Y95.493 E.02031
G1 X134.264 Y95.962 E.01147
G1 X133.204 Y94.902 E.03646
G1 X132.685 Y94.902 E.01262
G1 X134.264 Y96.481 E.05432
G1 X134.264 Y97 E.01262
G1 X132.166 Y94.902 E.07217
G1 X131.647 Y94.902 E.01262
G1 X134.264 Y97.519 E.09002
G1 X134.264 Y98.038 E.01262
G1 X131.128 Y94.902 E.10788
G1 X130.609 Y94.903 E.01262
G1 X134.264 Y98.557 E.12571
G1 X134.264 Y99.076 E.01262
G1 X130.09 Y94.903 E.14357
G1 X129.571 Y94.903 E.01262
G1 X134.264 Y99.596 E.16144
G1 X134.264 Y100.115 E.01262
G1 X129.052 Y94.903 E.17929
G1 X128.533 Y94.903 E.01262
G1 X134.264 Y100.634 E.19714
G1 X134.263 Y101.153 E.01262
G1 X128.014 Y94.903 E.21498
G1 X127.737 Y94.903 E.00674
G1 X127.737 Y95.145 E.00589
G1 X134.263 Y101.672 E.22451
G1 X134.263 Y102.191 E.01262
G1 X127.737 Y95.664 E.22451
G1 X127.737 Y96.183 E.01262
G1 X134.263 Y102.71 E.22451
G1 X134.263 Y103.229 E.01262
G1 X127.737 Y96.702 E.22451
G1 X127.737 Y97.221 E.01262
G1 X134.263 Y103.748 E.22451
G1 X134.263 Y104.267 E.01262
G1 X128.221 Y98.224 E.20786
G1 X128.238 Y98.76 E.01304
G1 X134.263 Y104.786 E.20727
G1 X134.263 Y105.305 E.01262
G1 X128.238 Y99.279 E.20727
G1 X128.238 Y99.798 E.01262
G1 X134.263 Y105.824 E.20727
G1 X134.263 Y106.343 E.01262
G1 X128.238 Y100.317 E.20727
G1 X128.238 Y100.836 E.01262
G1 X134.263 Y106.862 E.20727
G1 X134.263 Y107.381 E.01262
G1 X128.238 Y101.355 E.20727
G1 X128.238 Y101.874 E.01262
G1 X134.263 Y107.9 E.20727
G1 X134.263 Y108.419 E.01262
G1 X128.238 Y102.393 E.20727
G1 X128.238 Y102.913 E.01265
G1 X134.263 Y108.938 E.20726
G1 X134.263 Y109.457 E.01262
G1 X128.238 Y103.432 E.20726
G1 X128.226 Y103.938 E.01231
G1 X134.263 Y109.976 E.20769
G1 X134.263 Y110.495 E.01262
G1 X128.139 Y104.371 E.21066
G1 X127.985 Y104.736 E.00964
G1 X134.263 Y111.014 E.21596
G1 X134.263 Y111.533 E.01262
G1 X127.737 Y105.007 E.22449
G1 X127.737 Y105.526 E.01262
G1 X134.263 Y112.052 E.22449
G1 X134.263 Y112.571 E.01262
G1 X127.737 Y106.045 E.22449
G1 X127.737 Y106.564 E.01262
G1 X134.263 Y113.09 E.22449
G1 X134.263 Y113.609 E.01262
G1 X127.737 Y107.083 E.22449
G1 X127.737 Y107.602 E.01262
G1 X134.263 Y114.128 E.22449
G1 X134.263 Y114.648 E.01265
G1 X127.737 Y108.121 E.22451
G1 X127.737 Y108.64 E.01262
G1 X134.263 Y115.167 E.22451
G1 X134.263 Y115.686 E.01262
G1 X127.737 Y109.159 E.22451
G1 X127.737 Y109.678 E.01262
G1 X134.263 Y116.205 E.22451
G1 X134.263 Y116.724 E.01262
G1 X127.737 Y110.197 E.22451
G1 X127.737 Y110.716 E.01262
G1 X134.263 Y117.243 E.22451
G1 X134.263 Y117.762 E.01262
G1 X127.737 Y111.235 E.22451
G1 X127.737 Y111.754 E.01262
G1 X134.263 Y118.281 E.22451
G1 X134.263 Y118.8 E.01262
G1 X127.737 Y112.273 E.22451
G1 X127.737 Y112.792 E.01262
G1 X134.263 Y119.319 E.22451
G1 X134.263 Y119.838 E.01262
G1 X127.737 Y113.311 E.22451
G1 X127.737 Y113.831 E.01265
G1 X134.263 Y120.357 E.22449
G1 X134.263 Y120.876 E.01262
G1 X127.737 Y114.35 E.22449
G1 X127.737 Y114.869 E.01262
G1 X134.263 Y121.395 E.22449
G1 X134.263 Y121.914 E.01262
G1 X127.737 Y115.388 E.22449
G1 X127.737 Y115.907 E.01262
G1 X134.263 Y122.433 E.22449
G1 X134.263 Y122.952 E.01262
G1 X127.737 Y116.426 E.22449
G1 X127.737 Y116.945 E.01262
G1 X134.263 Y123.471 E.22449
G1 X134.263 Y123.99 E.01262
G1 X127.737 Y117.464 E.22449
G1 X127.737 Y117.983 E.01262
G1 X134.263 Y124.509 E.22449
G1 X134.263 Y125.028 E.01262
G1 X127.737 Y118.502 E.22449
G1 X127.737 Y119.021 E.01262
G1 X134.263 Y125.547 E.22449
G1 X134.263 Y126.066 E.01262
G1 X127.737 Y119.54 E.22449
G1 X127.737 Y120.059 E.01262
G1 X134.263 Y126.585 E.22449
G1 X134.263 Y127.104 E.01262
G1 X127.737 Y120.578 E.22449
G1 X127.737 Y121.097 E.01262
G1 X134.263 Y127.623 E.22449
G1 X134.263 Y128.142 E.01262
G1 X127.737 Y121.616 E.22449
G1 X127.737 Y122.135 E.01262
G1 X134.263 Y128.661 E.22449
G1 X134.263 Y129.18 E.01262
G1 X127.737 Y122.654 E.22449
G1 X127.737 Y123.173 E.01262
G1 X134.263 Y129.699 E.22449
G1 X134.263 Y130.219 E.01265
G1 X127.737 Y123.692 E.22451
G1 X127.737 Y124.211 E.01262
G1 X134.263 Y130.738 E.22451
G1 X134.263 Y131.257 E.01262
G1 X127.737 Y124.73 E.22451
G1 X127.737 Y125.249 E.01262
G1 X134.263 Y131.776 E.22451
G1 X134.263 Y132.252 E.01158
G1 X134.261 Y132.293 E.001
G1 X127.737 Y125.768 E.22444
G1 X127.737 Y126.287 E.01262
G1 X134.236 Y132.787 E.22358
G1 X134.198 Y133.267 E.01171
G1 X127.737 Y126.807 E.22224
G1 X127.737 Y127.326 E.01262
G1 X134.133 Y133.722 E.22002
G1 X134.044 Y134.152 E.01068
G1 X127.737 Y127.845 E.21696
G1 X127.737 Y128.364 E.01262
G1 X133.921 Y134.548 E.21273
G1 X133.794 Y134.94 E.01002
G1 X127.737 Y128.883 E.20836
G1 X127.737 Y129.402 E.01262
G1 X133.667 Y135.331 E.20397
G1 X133.497 Y135.681 E.00946
G1 X127.737 Y129.921 E.19814
G1 X127.737 Y130.44 E.01262
G1 X133.328 Y136.031 E.19233
G1 X133.153 Y136.375 E.00939
G1 X127.737 Y130.959 E.18631
G1 X127.737 Y131.478 E.01262
G1 X132.955 Y136.696 E.1795
G1 X132.739 Y136.999 E.00905
G1 X127.737 Y131.997 E.17207
G1 X127.737 Y132.516 E.01262
G1 X132.522 Y137.301 E.1646
G1 X132.282 Y137.58 E.00895
G1 X127.737 Y133.035 E.15635
G1 X127.737 Y133.554 E.01262
G1 X132.038 Y137.856 E.14797
G1 X131.781 Y138.117 E.00891
G1 X127.737 Y134.073 E.13911
G1 X127.737 Y134.592 E.01262
G1 X131.504 Y138.359 E.12958
G1 X131.225 Y138.599 E.00895
G1 X127.572 Y134.947 E.12564
G1 E-5 F3600
G1 X127.572 Y134.947 F9000
G1 X131.045 Y138.939
G1 E5 F2400
G1 F3072.127
G1 X129.453 Y137.346 E.05478
G1 X129.425 Y137.838 E.01199
G1 X130.625 Y139.037 E.04126
G1 X130.305 Y139.236 E.00917
G1 X129.31 Y138.242 E.03421
G1 X129.105 Y138.555 E.0091
G1 X129.96 Y139.41 E.02941
G1 X129.61 Y139.58 E.00946
G1 X128.877 Y138.847 E.02521
G1 X128.617 Y139.106 E.00893
G1 X129.26 Y139.749 E.02212
G1 X128.878 Y139.885 E.00986
G1 X128.335 Y139.343 E.01866
G1 X128.053 Y139.58 E.00896
G1 X128.486 Y140.013 E.01489
G1 X128.088 Y140.134 E.01012
G1 X127.771 Y139.817 E.0109
G1 X127.627 Y139.938 E.00458
G1 X127.549 Y140.114 E.00468
G1 X127.803 Y140.368 E.00874
G1 E-5 F3600
G1 X127.803 Y140.368 F9000
G1 X97.954 Y136.852
G1 E5 F2400
G1 F3072.127
G1 X99.819 Y138.64 E.06284
G1 X101.066 Y139.443 E.03608
G1 X97.674 Y136.051 E.11668
G1 X97.246 Y135.102 E.02532
G1 X101.993 Y139.85 E.16331
G1 X102.76 Y140.096 E.01959
G1 X97.023 Y134.359 E.19735
G1 X96.874 Y133.69 E.01667
G1 X103.411 Y140.226 E.22485
G1 X103.518 Y140.247 E.00265
G1 X103.369 Y139.935 E.00841
G1 X102.044 Y138.801 E.04242
G1 X101.843 Y138.543 E.00796
G1 X101.647 Y138.146 E.01077
G1 X101.589 Y137.884 E.00653
G1 X96.791 Y133.086 E.16505
G1 X96.743 Y132.517 E.01389
G1 X101.55 Y137.325 E.16538
G1 X101.64 Y136.894 E.01071
G1 X96.743 Y131.997 E.16845
G1 X96.742 Y131.476 E.01267
G1 X101.803 Y136.536 E.17408
G1 X102.018 Y136.231 E.00908
G1 X96.742 Y130.956 E.18147
G1 X96.742 Y130.435 E.01267
G1 X102.285 Y135.977 E.19066
G1 X102.567 Y135.739 E.00898
G1 X96.742 Y129.914 E.20038
G1 X96.742 Y129.394 E.01265
G1 X102.85 Y135.502 E.21011
G1 X103.133 Y135.264 E.00899
G1 X96.742 Y128.873 E.21985
G1 X96.742 Y128.353 E.01265
G1 X103.263 Y134.874 E.22432
G1 X103.263 Y134.354 E.01265
G1 X96.742 Y127.832 E.22434
G1 X96.742 Y127.312 E.01265
G1 X103.263 Y133.833 E.22432
G1 X103.263 Y133.313 E.01265
G1 X96.742 Y126.791 E.22434
G1 X96.741 Y126.271 E.01265
G1 X103.263 Y132.792 E.22434
G1 X103.263 Y132.272 E.01265
G1 X96.741 Y125.75 E.22435
G1 X96.741 Y125.229 E.01267
G1 X103.263 Y131.751 E.22435
G1 X103.263 Y131.231 E.01265
G1 X96.741 Y124.709 E.22435
G1 X96.741 Y124.188 E.01267
G1 X103.263 Y130.71 E.22435
G1 X103.263 Y130.19 E.01265
G1 X96.741 Y123.668 E.22435
G1 X96.741 Y123.147 E.01267
G1 X103.263 Y129.669 E.22435
G1 X103.263 Y129.149 E.01265
G1 X96.741 Y122.627 E.22435
G1 X96.741 Y122.106 E.01267
G1 X103.263 Y128.628 E.22435
G1 X103.263 Y128.108 E.01265
G1 X96.741 Y121.586 E.22435
G1 X96.741 Y121.065 E.01267
G1 X103.263 Y127.588 E.22437
G1 X103.263 Y127.067 E.01267
G1 X96.74 Y120.544 E.22439
G1 X96.74 Y120.024 E.01265
G1 X103.263 Y126.547 E.22439
G1 X103.263 Y126.026 E.01267
G1 X96.74 Y119.503 E.22439
G1 X96.74 Y118.983 E.01265
G1 X103.263 Y125.506 E.22439
G1 X103.263 Y124.985 E.01267
G1 X96.74 Y118.462 E.22439
G1 X96.74 Y117.942 E.01265
G1 X103.263 Y124.465 E.22439
G1 X103.263 Y123.944 E.01267
G1 X96.74 Y117.421 E.22439
G1 X96.74 Y116.9 E.01267
G1 X103.263 Y123.424 E.2244
G1 X103.263 Y122.903 E.01267
G1 X96.74 Y116.38 E.22439
G1 X96.74 Y115.859 E.01267
G1 X103.263 Y122.383 E.2244
G1 X103.263 Y121.862 E.01267
G1 X96.739 Y115.339 E.2244
G1 X96.739 Y114.818 E.01267
G1 X103.263 Y121.342 E.22442
G1 X103.263 Y120.821 E.01267
G1 X96.739 Y114.298 E.2244
G1 X96.739 Y113.777 E.01267
G1 X103.263 Y120.301 E.22442
G1 X103.263 Y119.781 E.01265
G1 X96.739 Y113.257 E.22442
G1 X96.739 Y112.736 E.01267
G1 X103.263 Y119.26 E.22442
G1 X103.263 Y118.74 E.01265
G1 X96.739 Y112.215 E.22444
G1 X96.739 Y111.695 E.01265
G1 X103.263 Y118.219 E.22442
G1 X103.263 Y117.699 E.01265
G1 X96.739 Y111.174 E.22444
G1 X96.739 Y110.654 E.01265
G1 X103.263 Y117.178 E.22442
G1 X103.263 Y116.658 E.01265
G1 X96.739 Y110.133 E.22444
G1 X96.738 Y109.613 E.01265
G1 X103.263 Y116.137 E.22444
G1 X103.263 Y115.617 E.01265
G1 X96.738 Y109.092 E.22446
G1 X96.738 Y108.572 E.01265
G1 X103.263 Y115.096 E.22444
G1 X103.263 Y114.576 E.01265
G1 X96.738 Y108.051 E.22446
G1 X96.738 Y107.53 E.01267
G1 X103.263 Y114.055 E.22446
G1 X103.263 Y113.535 E.01265
G1 X96.738 Y107.01 E.22446
G1 X96.738 Y106.489 E.01267
G1 X103.263 Y113.015 E.22447
G1 X103.263 Y112.494 E.01267
G1 X96.738 Y105.969 E.22446
G1 X96.738 Y105.448 E.01267
G1 X103.263 Y111.974 E.22447
G1 X103.263 Y111.453 E.01267
G1 X96.738 Y104.928 E.22446
G1 X96.737 Y104.407 E.01267
G1 X103.263 Y110.933 E.22449
G1 X103.263 Y110.412 E.01267
G1 X96.737 Y103.887 E.22447
G1 X96.737 Y103.366 E.01267
G1 X103.263 Y109.892 E.22449
G1 X103.263 Y109.371 E.01267
G1 X96.737 Y102.845 E.22449
G1 X96.737 Y102.325 E.01265
G1 X103.263 Y108.851 E.22449
G1 X103.263 Y108.33 E.01267
G1 X96.737 Y101.804 E.22449
G1 X96.737 Y101.284 E.01265
G1 X103.263 Y107.81 E.22449
G1 X103.263 Y107.289 E.01267
G1 X96.737 Y100.763 E.22449
G1 X96.737 Y100.243 E.01265
G1 X103.263 Y106.769 E.22449
G1 X103.263 Y106.249 E.01265
G1 X96.737 Y99.722 E.22451
G1 X96.737 Y99.201 E.01267
G1 X103.263 Y105.728 E.22451
G1 X103.263 Y105.208 E.01265
G1 X96.736 Y98.681 E.22452
G1 X96.736 Y98.16 E.01267
G1 X102.825 Y104.249 E.20946
G1 X102.762 Y103.666 E.01426
G1 X96.736 Y97.64 E.20729
G1 X96.736 Y97.119 E.01267
G1 X102.763 Y103.146 E.20733
G1 X102.764 Y102.626 E.01265
G1 X96.736 Y96.599 E.20734
G1 X96.736 Y96.078 E.01267
G1 X102.765 Y102.107 E.20739
G1 X102.765 Y101.587 E.01265
G1 X96.689 Y95.511 E.20901
G1 X96.66 Y95.305 E.00506
G1 X96.458 Y94.903 E.01094
G1 X96.601 Y94.903 E.00348
G1 X102.766 Y101.067 E.21206
G1 X102.767 Y100.547 E.01265
G1 X97.122 Y94.903 E.19417
G1 X97.642 Y94.903 E.01265
G1 X102.767 Y100.028 E.1763
G1 X102.768 Y99.508 E.01265
G1 X98.163 Y94.903 E.15841
G1 X98.684 Y94.903 E.01267
G1 X102.769 Y98.988 E.14052
G1 X102.77 Y98.468 E.01265
G1 X99.204 Y94.903 E.12265
G1 X99.725 Y94.903 E.01267
G1 X102.821 Y97.999 E.1065
G1 X102.956 Y97.614 E.00992
G1 X100.245 Y94.903 E.09326
G1 X100.766 Y94.903 E.01267
G1 X103.181 Y97.318 E.08307
G1 X103.263 Y97.334 E.00203
G1 X103.263 Y96.88 E.01104
G1 X101.286 Y94.903 E.06801
G1 X101.807 Y94.903 E.01267
G1 X103.263 Y96.36 E.0501
G1 X103.263 Y95.839 E.01267
G1 X102.327 Y94.904 E.03218
G1 X102.848 Y94.904 E.01267
G1 X103.428 Y95.483 E.01993
G1 E-5 F3600
G1 X103.428 Y95.483 F9000
G1 X103.24 Y104.276
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.446816
G1 F1200
G1 X103.167 Y104.058 E.00631
;WIDTH:0.429328
G1 X103.141 Y103.778 E.00739
;WIDTH:0.426466
G1 X103.146 Y98.462 E.13867
;WIDTH:0.424484
G1 X103.204 Y98.015 E.0117
;WIDTH:0.445522
G1 X103.24 Y97.951 E.00201
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.204 Y98.015 E-.03488
G1 X103.146 Y98.462 E-.2141
G1 X103.144 Y101.096 E-1.25102
;WIPE_END
G1 X127.76 Y104.276 F9000
G1 E5 F2400
;WIDTH:0.446066
G1 F1200
G1 X127.831 Y104.076 E.00581
;WIDTH:0.42766
G1 X127.859 Y103.786 E.00762
;WIDTH:0.426482
G1 X127.859 Y98.473 E.13859
G1 X127.801 Y98.028 E.01171
;WIDTH:0.444136
G1 X127.759 Y97.951 E.00239
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X127.801 Y98.028 E-.04166
G1 X127.859 Y98.473 E-.21316
G1 X127.859 Y101.095 E-1.24518
;WIPE_END
G1 X126.457 Y102.318 F9000
G1 X124.901 Y103.676
G1 X119.138 Y108.636
G1 X118.894 Y108.918
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X119.073 Y109.043 E.00531
G1 X119.433 Y109.457 E.01334
G1 X121.293 Y112.656 E.09001
G1 X121.567 Y113.333 E.01776
G1 X121.649 Y114.085 E.0184
G1 X121.578 Y114.624 E.01322
G1 X121.401 Y115.135 E.01315
G1 X119.433 Y118.543 E.09573
G1 X118.922 Y119.089 E.01819
G1 X118.244 Y119.489 E.01915
G1 X117.752 Y119.637 E.0125
G1 X117.347 Y119.679 E.0099
G1 X113.768 Y119.689 E.08706
G1 X113.49 Y119.673 E.00677
G1 X112.802 Y119.508 E.01721
G1 X112.329 Y119.243 E.01319
G1 X112.078 Y119.089 E.00716
G1 X111.567 Y118.543 E.01819
G1 X109.707 Y115.344 E.09001
G1 X109.433 Y114.667 E.01776
G1 X109.351 Y114.129 E.01324
G1 X109.375 Y113.623 E.01232
G1 X109.492 Y113.132 E.01228
G1 X109.707 Y112.656 E.0127
G1 X111.44 Y109.655 E.08429
G1 X111.865 Y109.109 E.01683
G1 X112.537 Y108.611 E.02034
G1 X113.003 Y108.423 E.01222
G1 X113.768 Y108.311 E.01881
G1 X117.468 Y108.322 E.09
G1 X117.76 Y108.365 E.00718
G1 X118.427 Y108.594 E.01715
G1 X118.845 Y108.884 E.01237
G1 X118.845 Y108.884 F9000
G1 X119.056 Y108.591
;TYPE:Perimeter
G1 F6000
G1 X119.285 Y108.745 E.00671
G1 X119.749 Y109.273 E.0171
G1 X121.609 Y112.472 E.09001
G1 X121.906 Y113.196 E.01903
G1 X122.013 Y114.049 E.02091
G1 X121.94 Y114.675 E.01533
G1 X121.76 Y115.224 E.01405
G1 X119.75 Y118.725 E.0982
G1 X119.187 Y119.341 E.0203
G1 X118.427 Y119.805 E.02166
G1 X117.927 Y119.967 E.01278
G1 X117.381 Y120.043 E.01341
G1 X113.768 Y120.054 E.08788
G1 X113.404 Y120.028 E.00888
G1 X112.719 Y119.864 E.01713
G1 X112.147 Y119.559 E.01577
G1 X111.813 Y119.341 E.0097
G1 X111.327 Y118.829 E.01717
G1 X111.251 Y118.727 E.00309
G1 X109.391 Y115.528 E.09001
G1 X109.094 Y114.803 E.01906
G1 X108.989 Y114.18 E.01537
G1 X109.009 Y113.604 E.01402
G1 X109.137 Y113.044 E.01397
G1 X109.39 Y112.474 E.01517
G1 X111.123 Y109.472 E.08431
G1 X111.578 Y108.884 E.01808
G1 X111.713 Y108.747 E.00468
G1 X112.285 Y108.335 E.01715
G1 X112.865 Y108.085 E.01536
G1 X113.769 Y107.946 E.02225
G1 X117.469 Y107.957 E.09
G1 X117.879 Y108.019 E.01009
G1 X118.546 Y108.248 E.01715
G1 X119.006 Y108.557 E.01348
G1 X119.006 Y108.557 F9000
G1 X119.223 Y108.254
G1 F6000
G1 X119.575 Y108.509 E.01057
G1 X119.967 Y108.951 E.01437
G1 X120.065 Y109.089 E.00412
G1 X121.925 Y112.288 E.09001
G1 X122.245 Y113.06 E.02033
G1 X122.307 Y113.31 E.00627
G1 X122.377 Y114.012 E.01716
G1 X122.303 Y114.727 E.01748
G1 X122.106 Y115.344 E.01575
G1 X122.034 Y115.501 E.0042
G1 X120.067 Y118.908 E.09569
G1 X119.737 Y119.293 E.01233
G1 X119.379 Y119.661 E.01249
G1 X118.61 Y120.122 E.02181
G1 X118.029 Y120.318 E.01491
G1 X117.416 Y120.407 E.01507
G1 X117.233 Y120.42 E.00446
G1 X113.768 Y120.42 E.08428
G1 X113.319 Y120.384 E.01096
G1 X112.634 Y120.219 E.01714
G1 X112.39 Y120.122 E.00639
G1 X111.754 Y119.755 E.01786
G1 X111.547 Y119.592 E.00641
G1 X111.062 Y119.08 E.01715
G1 X110.935 Y118.911 E.00514
G1 X109.075 Y115.712 E.09001
G1 X108.754 Y114.94 E.02034
G1 X108.627 Y114.231 E.01752
G1 X108.644 Y113.585 E.01572
G1 X108.782 Y112.957 E.01564
G1 X109.074 Y112.291 E.01769
G1 X110.806 Y109.29 E.08428
G1 X111.29 Y108.658 E.01936
G1 X111.499 Y108.45 E.00717
G1 X112.072 Y108.038 E.01717
G1 X112.728 Y107.745 E.01748
G1 X113.26 Y107.643 E.01318
G1 X113.768 Y107.58 E.01245
G1 X117.47 Y107.591 E.09005
G1 X117.997 Y107.674 E.01298
G1 X118.664 Y107.902 E.01715
G1 X119.132 Y108.188 E.01334
G1 X119.175 Y108.219 E.00129
G1 X119.175 Y108.219 F9000
G1 X119.389 Y107.922
G1 F6000
G1 X119.767 Y108.193 E.01131
G1 X120.244 Y108.712 E.01715
G1 X120.381 Y108.905 E.00576
G1 X122.241 Y112.104 E.09001
G1 X122.585 Y112.924 E.02163
G1 X122.671 Y113.274 E.00877
G1 X122.741 Y113.976 E.01716
G1 X122.735 Y114.283 E.00747
G1 X122.665 Y114.778 E.01216
G1 X122.451 Y115.464 E.01748
G1 X122.351 Y115.683 E.00586
G1 X120.383 Y119.091 E.09573
G1 X120.002 Y119.544 E.0144
G1 X119.615 Y119.941 E.01349
G1 X118.715 Y120.48 E.02552
G1 X118.131 Y120.669 E.01493
;WIDTH:0.431221
G1 X117.896 Y120.726 E.00638
;WIDTH:0.462442
G1 X117.662 Y120.782 E.00685
G1 X117.452 Y120.793 E.00599
;WIDTH:0.444949
G1 X117.233 Y120.804 E.00599
;WIDTH:0.436668
G1 X113.772 Y120.801 E.09263
;WIDTH:0.431507
G1 X113.234 Y120.739 E.01431
;WIDTH:0.399999
G1 X112.548 Y120.575 E.01716
G1 X112.207 Y120.439 E.00893
G1 X111.571 Y120.072 E.01786
G1 X111.282 Y119.844 E.00895
G1 X110.796 Y119.332 E.01717
G1 X110.619 Y119.094 E.00721
G1 X108.759 Y115.896 E.08999
G1 X108.415 Y115.076 E.02163
G1 X108.265 Y114.283 E.01963
G1 X108.279 Y113.566 E.01744
G1 X108.427 Y112.87 E.01731
G1 X108.702 Y112.215 E.01728
G1 X110.49 Y109.107 E.08722
G1 X111.002 Y108.433 E.02059
G1 X111.286 Y108.153 E.0097
G1 X111.859 Y107.741 E.01717
G1 X112.591 Y107.406 E.01958
G1 X113.208 Y107.281 E.01531
;WIDTH:0.433162
G1 X113.771 Y107.199 E.01509
;WIDTH:0.436668
G1 X117.232 Y107.206 E.09263
;WIDTH:0.462443
G1 X117.652 Y107.207 E.01196
G1 X118.07 Y107.331 E.01242
;WIDTH:0.431221
G1 X118.489 Y107.455 E.01154
;WIDTH:0.399999
G1 X118.865 Y107.587 E.00969
G1 X119.34 Y107.887 E.01367
G1 E-5 F3600
G1 X119.34 Y107.887 F9000
G1 X122.905 Y101.23
G1 E5 F2400
G1 F6000
G1 X122.796 Y101.585 E.00903
G1 X122.517 Y102.127 E.01483
G1 X120.7 Y105.274 E.08839
G1 X120.267 Y105.796 E.0165
G1 X119.851 Y106.22 E.01445
G1 X119.362 Y106.532 E.01411
G1 X118.876 Y106.809 E.01361
G1 X118.295 Y107.003 E.0149
G1 X118.901 Y107.21 E.01558
G1 X119.321 Y107.425 E.01148
G1 X119.92 Y107.85 E.01786
G1 X120.347 Y108.273 E.01462
G1 X120.697 Y108.722 E.01385
G1 X122.557 Y111.92 E.08999
G1 X122.924 Y112.787 E.0229
G1 X123.035 Y113.237 E.01127
G1 X123.105 Y113.939 E.01716
G1 X123.097 Y114.334 E.00961
G1 X123.027 Y114.829 E.01216
G1 X122.796 Y115.585 E.01923
G1 X122.667 Y115.866 E.00752
G1 X120.7 Y119.274 E.09571
G1 X120.267 Y119.796 E.0165
G1 X119.851 Y120.22 E.01445
G1 X119.362 Y120.532 E.01411
G1 X118.876 Y120.809 E.01361
G1 X118.295 Y121.003 E.0149
G1 X118.901 Y121.21 E.01558
G1 X119.321 Y121.425 E.01148
G1 X119.92 Y121.85 E.01786
G1 X120.347 Y122.273 E.01462
G1 X120.697 Y122.722 E.01385
G1 X122.557 Y125.92 E.08999
G1 X122.924 Y126.787 E.0229
G1 X123.035 Y127.237 E.01127
G1 X123.105 Y127.939 E.01716
G1 X123.097 Y128.334 E.00961
G1 X123.027 Y128.829 E.01216
G1 X122.796 Y129.585 E.01923
G1 X122.667 Y129.866 E.00752
G1 X120.7 Y133.274 E.09571
G1 X120.22 Y133.846 E.01816
G1 X119.983 Y134.095 E.00836
G1 X119.612 Y134.388 E.0115
G1 X118.976 Y134.755 E.01786
G1 X118.612 Y134.911 E.00963
G1 X117.985 Y135.082 E.01581
G1 X117.388 Y135.144 E.0146
G1 X113.768 Y135.151 E.08805
G1 X113.149 Y135.095 E.01512
G1 X112.463 Y134.93 E.01716
G1 X112.024 Y134.755 E.0115
G1 X111.388 Y134.388 E.01786
G1 X111.017 Y134.096 E.01148
G1 X110.531 Y133.584 E.01717
G1 X110.302 Y133.278 E.0093
G1 X108.443 Y130.08 E.08998
G1 X108.076 Y129.212 E.02292
G1 X107.973 Y128.829 E.00965
G1 X107.903 Y128.334 E.01216
G1 X107.914 Y127.546 E.01917
G1 X108.072 Y126.783 E.01895
G1 X108.44 Y125.925 E.02271
G1 X110.173 Y122.924 E.08429
G1 X110.714 Y122.207 E.02185
G1 X111.072 Y121.856 E.0122
G1 X111.645 Y121.444 E.01717
G1 X111.991 Y121.254 E.0096
G1 X112.455 Y121.067 E.01217
G1 X112.726 Y120.994 E.00683
G1 X112.445 Y120.926 E.00703
G1 X112.024 Y120.755 E.01105
G1 X111.388 Y120.388 E.01786
G1 X111.017 Y120.096 E.01148
G1 X110.531 Y119.584 E.01717
G1 X110.302 Y119.278 E.0093
G1 X108.443 Y116.08 E.08998
G1 X108.076 Y115.212 E.02292
G1 X107.973 Y114.829 E.00965
G1 X107.903 Y114.334 E.01216
G1 X107.914 Y113.546 E.01917
G1 X108.072 Y112.783 E.01895
G1 X108.44 Y111.925 E.02271
G1 X110.173 Y108.924 E.08429
G1 X110.714 Y108.207 E.02185
G1 X111.072 Y107.856 E.0122
G1 X111.645 Y107.444 E.01717
G1 X111.991 Y107.254 E.0096
G1 X112.455 Y107.067 E.01217
G1 X112.726 Y106.994 E.00683
G1 X112.445 Y106.926 E.00703
G1 X112.024 Y106.755 E.01105
G1 X111.388 Y106.388 E.01786
G1 X111.017 Y106.096 E.01148
G1 X110.531 Y105.584 E.01717
G1 X110.302 Y105.278 E.0093
G1 X108.443 Y102.08 E.08998
G1 X108.076 Y101.212 E.02292
G1 X107.973 Y100.829 E.00965
G1 X107.903 Y100.334 E.01216
G1 X107.914 Y99.546 E.01917
G1 X108.072 Y98.783 E.01895
G1 X108.44 Y97.925 E.02271
G1 X110.173 Y94.924 E.08429
G1 X110.738 Y94.177 E.02278
G1 X111.072 Y93.856 E.01127
G1 X111.645 Y93.444 E.01717
G1 X111.991 Y93.254 E.0096
G1 X112.455 Y93.067 E.01217
G1 X112.838 Y92.964 E.00965
G1 X113.536 Y92.865 E.01715
G1 X113.772 Y92.849 E.00575
G1 X117.472 Y92.86 E.09
G1 X117.933 Y92.909 E.01128
G1 X118.901 Y93.21 E.02466
G1 X119.321 Y93.425 E.01148
G1 X119.92 Y93.85 E.01786
G1 X120.213 Y94.117 E.00964
G1 X120.697 Y94.722 E.01885
G1 X122.557 Y97.92 E.08999
G1 X122.924 Y98.787 E.0229
G1 X123.035 Y99.24 E.01134
G1 X123.105 Y99.939 E.01709
G1 X123.097 Y100.334 E.00961
G1 X123.027 Y100.829 E.01216
G1 X122.922 Y101.172 E.00873
G1 X122.922 Y101.172 F9000
G1 X121.532 Y100.76
G1 F6000
G1 X121.415 Y101.104 E.00884
G1 X119.433 Y104.543 E.09655
G1 X118.922 Y105.089 E.01819
G1 X118.244 Y105.489 E.01915
G1 X117.752 Y105.637 E.0125
G1 X117.233 Y105.689 E.01269
G1 X113.768 Y105.689 E.08428
G1 X113.49 Y105.673 E.00677
G1 X112.802 Y105.508 E.01721
G1 X112.078 Y105.089 E.02035
G1 X111.567 Y104.543 E.01819
G1 X109.707 Y101.344 E.09001
G1 X109.433 Y100.667 E.01776
G1 X109.351 Y100.129 E.01324
G1 X109.375 Y99.623 E.01232
G1 X109.492 Y99.132 E.01228
G1 X109.707 Y98.656 E.0127
G1 X111.44 Y95.655 E.08429
G1 X111.889 Y95.079 E.01776
G1 X112.499 Y94.632 E.01839
G1 X113.001 Y94.424 E.01322
G1 X113.768 Y94.311 E.01886
G1 X117.468 Y94.322 E.09
G1 X117.76 Y94.365 E.00718
G1 X118.427 Y94.594 E.01715
G1 X119.073 Y95.043 E.01914
G1 X119.413 Y95.429 E.01251
G1 X121.293 Y98.656 E.09084
G1 X121.567 Y99.333 E.01776
G1 X121.649 Y100.085 E.0184
G1 X121.578 Y100.624 E.01322
G1 X121.551 Y100.704 E.00205
G1 X121.551 Y100.704 F9000
G1 X121.898 Y100.806
;TYPE:Perimeter
G1 F6000
G1 X121.76 Y101.224 E.01071
G1 X119.75 Y104.725 E.0982
G1 X119.187 Y105.341 E.0203
G1 X118.427 Y105.805 E.02166
G1 X117.927 Y105.967 E.01278
G1 X117.381 Y106.043 E.01341
G1 X113.768 Y106.054 E.08788
G1 X113.404 Y106.028 E.00888
G1 X112.719 Y105.864 E.01713
G1 X112.147 Y105.559 E.01577
G1 X111.813 Y105.341 E.0097
G1 X111.327 Y104.829 E.01717
G1 X111.251 Y104.727 E.00309
G1 X109.391 Y101.528 E.09001
G1 X109.094 Y100.803 E.01906
G1 X108.989 Y100.18 E.01537
G1 X109.009 Y99.604 E.01402
G1 X109.137 Y99.044 E.01397
G1 X109.367 Y98.519 E.01394
G1 X111.123 Y95.472 E.08554
G1 X111.601 Y94.854 E.019
G1 X112.285 Y94.335 E.02088
G1 X112.865 Y94.085 E.01536
G1 X113.69 Y93.951 E.02033
G1 X117.469 Y93.957 E.09192
G1 X117.879 Y94.019 E.01009
G1 X118.546 Y94.248 E.01715
G1 X119.285 Y94.745 E.02166
G1 X119.69 Y95.19 E.01464
G1 X121.609 Y98.472 E.09248
G1 X121.906 Y99.196 E.01903
G1 X121.988 Y99.792 E.01463
G1 X122.011 Y100.18 E.00945
G1 X121.94 Y100.675 E.01216
G1 X121.916 Y100.749 E.00189
G1 X121.916 Y100.749 F9000
G1 X122.261 Y100.855
G1 F6000
G1 X122.106 Y101.344 E.01248
G1 X121.758 Y101.979 E.01761
G1 X120.067 Y104.908 E.08227
G1 X119.737 Y105.293 E.01233
G1 X119.379 Y105.661 E.01249
G1 X118.61 Y106.122 E.02181
G1 X118.029 Y106.318 E.01491
G1 X117.416 Y106.407 E.01507
G1 X117.233 Y106.42 E.00446
G1 X113.768 Y106.42 E.08428
G1 X113.319 Y106.384 E.01096
G1 X112.634 Y106.219 E.01714
G1 X112.39 Y106.122 E.00639
G1 X111.754 Y105.755 E.01786
G1 X111.547 Y105.592 E.00641
G1 X111.062 Y105.08 E.01715
G1 X110.935 Y104.911 E.00514
G1 X109.075 Y101.712 E.09001
G1 X108.754 Y100.94 E.02034
G1 X108.627 Y100.231 E.01752
G1 X108.644 Y99.585 E.01572
G1 X108.782 Y98.957 E.01564
G1 X109.034 Y98.367 E.01561
G1 X110.806 Y95.29 E.08637
G1 X111.313 Y94.628 E.02028
G1 X111.499 Y94.45 E.00626
G1 X112.072 Y94.038 E.01717
G1 X112.728 Y93.745 E.01748
G1 X113.639 Y93.589 E.02248
G1 X117.47 Y93.591 E.09319
G1 X117.997 Y93.674 E.01298
G1 X118.664 Y93.902 E.01715
G1 X118.897 Y94.021 E.00636
G1 X119.496 Y94.447 E.01788
G1 X119.967 Y94.951 E.01678
G1 X120.065 Y95.089 E.00412
G1 X121.925 Y98.288 E.09001
G1 X122.245 Y99.06 E.02033
G1 X122.307 Y99.312 E.00631
G1 X122.377 Y100.012 E.01711
G1 X122.303 Y100.727 E.01748
G1 X122.28 Y100.798 E.00182
G1 X122.28 Y100.798 F9000
G1 X122.608 Y100.958
G1 F6000
G1 X122.451 Y101.464 E.01289
G1 X122.2 Y101.945 E.0132
G1 X120.383 Y105.091 E.08837
G1 X120.002 Y105.544 E.0144
G1 X119.615 Y105.941 E.01349
G1 X118.715 Y106.48 E.02552
G1 X118.131 Y106.669 E.01493
;WIDTH:0.431221
G1 X117.896 Y106.726 E.00638
;WIDTH:0.462443
G1 X117.662 Y106.782 E.00685
G1 X117.233 Y106.804 E.01223
;WIDTH:0.436668
G1 X113.772 Y106.801 E.09263
;WIDTH:0.431507
G1 X113.234 Y106.739 E.01431
;WIDTH:0.399999
G1 X112.548 Y106.575 E.01716
G1 X112.207 Y106.439 E.00893
G1 X111.571 Y106.072 E.01786
G1 X111.282 Y105.844 E.00895
G1 X110.796 Y105.332 E.01717
G1 X110.619 Y105.094 E.00721
G1 X108.759 Y101.896 E.08999
G1 X108.415 Y101.076 E.02163
G1 X108.265 Y100.283 E.01963
G1 X108.279 Y99.566 E.01744
G1 X108.427 Y98.87 E.01731
G1 X108.702 Y98.215 E.01728
G1 X110.49 Y95.107 E.08722
G1 X111.026 Y94.403 E.02152
G1 X111.286 Y94.153 E.00877
G1 X111.859 Y93.741 E.01717
G1 X112.591 Y93.406 E.01958
G1 X112.889 Y93.326 E.00751
G1 X113.587 Y93.227 E.01715
G1 X113.771 Y93.214 E.00449
G1 X117.471 Y93.225 E.09
G1 X118.115 Y93.328 E.01586
G1 X118.782 Y93.556 E.01715
G1 X119.109 Y93.723 E.00893
G1 X119.708 Y94.148 E.01786
G1 X120.244 Y94.712 E.01893
G1 X120.381 Y94.905 E.00576
G1 X122.241 Y98.104 E.09001
G1 X122.585 Y98.924 E.02163
G1 X122.671 Y99.276 E.00881
G1 X122.741 Y99.976 E.01711
G1 X122.735 Y100.283 E.00747
G1 X122.665 Y100.778 E.01216
G1 X122.626 Y100.901 E.00314
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X122.608 Y100.958 E-.02839
G1 X122.451 Y101.464 E-.25165
G1 X122.2 Y101.945 E-.25771
G1 X121.187 Y103.699 E-.96225
;WIPE_END
G1 X121.997 Y113.83 F9000
G1 X121.999 Y113.886
G1 X121.999 Y114.114
G1 X121.997 Y114.17
G1 X121.975 Y114.398
G1 X121.968 Y114.452
G1 X121.924 Y114.677
G1 X121.912 Y114.731
G1 X121.848 Y114.951
G1 X121.831 Y115.004
G1 X121.746 Y115.216
G1 X121.725 Y115.267
G1 X121.62 Y115.471
G1 X121.6 Y115.508
G1 X119.856 Y118.529
G1 X119.834 Y118.565
G1 X119.71 Y118.757
G1 X119.676 Y118.801
G1 X119.535 Y118.981
G1 X119.497 Y119.022
G1 X119.339 Y119.188
G1 X119.299 Y119.225
G1 X119.126 Y119.375
G1 X119.082 Y119.409
G1 X118.895 Y119.541
G1 X118.849 Y119.571
G1 X118.65 Y119.685
G1 X118.601 Y119.711
G1 X118.393 Y119.806
G1 X118.342 Y119.827
G1 X118.231 Y119.866
G1 X117.856 Y122.029
G1 X117.773 Y122.37
G1 E5 F2400
G1 F6000
G1 X118.427 Y122.594 E.01682
G1 X119.073 Y123.043 E.01914
G1 X119.433 Y123.457 E.01334
G1 X121.293 Y126.656 E.09001
G1 X121.567 Y127.333 E.01776
G1 X121.649 Y128.085 E.0184
G1 X121.578 Y128.624 E.01322
G1 X121.401 Y129.135 E.01315
G1 X119.433 Y132.543 E.09573
G1 X118.922 Y133.089 E.01819
G1 X118.244 Y133.489 E.01915
G1 X117.752 Y133.637 E.0125
G1 X117.233 Y133.689 E.01269
G1 X113.768 Y133.689 E.08428
G1 X113.49 Y133.673 E.00677
G1 X112.804 Y133.508 E.01716
G1 X112.119 Y133.121 E.01914
G1 X111.567 Y132.543 E.01944
G1 X109.707 Y129.344 E.09001
G1 X109.433 Y128.667 E.01776
G1 X109.351 Y128.129 E.01324
G1 X109.375 Y127.623 E.01232
G1 X109.492 Y127.132 E.01228
G1 X109.707 Y126.656 E.0127
G1 X111.44 Y123.655 E.08429
G1 X111.865 Y123.109 E.01683
G1 X112.537 Y122.611 E.02034
G1 X113.003 Y122.423 E.01222
G1 X113.768 Y122.311 E.01881
G1 X117.468 Y122.322 E.09
G1 X117.714 Y122.359 E.00605
G1 X117.714 Y122.359 F9000
G1 X117.765 Y122.002
;TYPE:Perimeter
G1 F6000
G1 X117.879 Y122.019 E.0028
G1 X118.546 Y122.248 E.01715
G1 X119.285 Y122.745 E.02166
G1 X119.749 Y123.273 E.0171
G1 X121.609 Y126.472 E.09001
G1 X121.906 Y127.196 E.01903
G1 X122.013 Y128.049 E.02091
G1 X121.94 Y128.675 E.01533
G1 X121.717 Y129.318 E.01655
G1 X119.75 Y132.725 E.09569
G1 X119.187 Y133.341 E.0203
G1 X118.427 Y133.805 E.02166
G1 X117.854 Y133.988 E.01463
G1 X117.233 Y134.054 E.01519
G1 X113.768 Y134.054 E.08428
G1 X113.404 Y134.028 E.00888
G1 X112.719 Y133.864 E.01713
G1 X111.936 Y133.438 E.02168
G1 X111.576 Y133.091 E.01216
G1 X111.251 Y132.727 E.01187
G1 X109.391 Y129.528 E.09001
G1 X109.094 Y128.803 E.01906
G1 X108.989 Y128.18 E.01537
G1 X109.009 Y127.604 E.01402
G1 X109.137 Y127.044 E.01397
G1 X109.39 Y126.474 E.01517
G1 X111.123 Y123.472 E.08431
G1 X111.578 Y122.884 E.01808
G1 X111.713 Y122.747 E.00468
G1 X112.285 Y122.335 E.01715
G1 X112.865 Y122.085 E.01536
G1 X113.769 Y121.946 E.02225
G1 X117.469 Y121.957 E.09
G1 X117.706 Y121.993 E.00583
G1 X117.706 Y121.993 F9000
G1 X117.756 Y121.636
G1 F6000
G1 X117.997 Y121.674 E.00593
G1 X118.664 Y121.902 E.01715
G1 X119.132 Y122.188 E.01334
G1 X119.575 Y122.509 E.01331
G1 X119.967 Y122.951 E.01437
G1 X120.065 Y123.089 E.00412
G1 X121.925 Y126.288 E.09001
G1 X122.245 Y127.06 E.02033
G1 X122.307 Y127.31 E.00627
G1 X122.377 Y128.012 E.01716
G1 X122.303 Y128.727 E.01748
G1 X122.106 Y129.344 E.01575
G1 X122.034 Y129.501 E.0042
G1 X120.067 Y132.908 E.09569
G1 X119.689 Y133.343 E.01402
G1 X119.246 Y133.755 E.01472
G1 X118.61 Y134.122 E.01786
G1 X117.956 Y134.339 E.01676
G1 X117.233 Y134.42 E.0177
G1 X113.768 Y134.42 E.08428
G1 X113.319 Y134.384 E.01096
G1 X112.634 Y134.219 E.01714
G1 X112.39 Y134.122 E.00639
G1 X111.754 Y133.755 E.01786
G1 X111.311 Y133.343 E.01472
G1 X110.935 Y132.911 E.01393
G1 X109.075 Y129.712 E.09001
G1 X108.754 Y128.94 E.02034
G1 X108.627 Y128.231 E.01752
G1 X108.644 Y127.585 E.01572
G1 X108.782 Y126.957 E.01564
G1 X109.074 Y126.291 E.01769
G1 X110.806 Y123.29 E.08428
G1 X111.29 Y122.658 E.01936
G1 X111.499 Y122.45 E.00717
G1 X112.072 Y122.038 E.01717
G1 X112.728 Y121.745 E.01748
G1 X113.26 Y121.643 E.01318
G1 X113.77 Y121.58 E.0125
G1 X117.47 Y121.591 E.09
G1 X117.697 Y121.627 E.00559
G1 X117.697 Y121.627 F9000
G1 X117.755 Y121.238
;WIDTH:0.462442
G1 F6000
G1 X118.07 Y121.331 E.00935
;WIDTH:0.431221
G1 X118.489 Y121.455 E.01154
;WIDTH:0.399999
G1 X118.865 Y121.587 E.00969
G1 X119.344 Y121.89 E.01379
G1 X119.767 Y122.193 E.01266
G1 X120.244 Y122.712 E.01715
G1 X120.381 Y122.905 E.00576
G1 X122.241 Y126.104 E.09001
G1 X122.585 Y126.924 E.02163
G1 X122.671 Y127.274 E.00877
G1 X122.741 Y127.976 E.01716
G1 X122.735 Y128.283 E.00747
G1 X122.665 Y128.778 E.01216
G1 X122.451 Y129.464 E.01748
G1 X122.351 Y129.683 E.00586
G1 X120.383 Y133.091 E.09573
G1 X119.718 Y133.844 E.02444
G1 X119.429 Y134.071 E.00894
G1 X118.793 Y134.439 E.01787
G1 X118.058 Y134.691 E.0189
G1 X117.353 Y134.78 E.01728
G1 X113.768 Y134.786 E.0872
G1 X113.234 Y134.739 E.01304
G1 X112.548 Y134.575 E.01716
G1 X112.207 Y134.439 E.00893
G1 X111.571 Y134.072 E.01786
G1 X111.282 Y133.844 E.00895
G1 X110.796 Y133.332 E.01717
G1 X110.619 Y133.094 E.00721
G1 X108.759 Y129.896 E.08999
G1 X108.415 Y129.076 E.02163
G1 X108.265 Y128.283 E.01963
G1 X108.279 Y127.566 E.01744
G1 X108.427 Y126.87 E.01731
G1 X108.702 Y126.215 E.01728
G1 X110.49 Y123.107 E.08722
G1 X111.002 Y122.433 E.02059
G1 X111.286 Y122.153 E.0097
G1 X111.859 Y121.741 E.01717
G1 X112.591 Y121.406 E.01958
G1 X113.208 Y121.281 E.01531
;WIDTH:0.433162
G1 X113.771 Y121.199 E.01509
;WIDTH:0.436668
G1 X117.232 Y121.206 E.09263
;WIDTH:0.462442
G1 X117.652 Y121.207 E.01196
G1 X117.697 Y121.221 E.00134
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X117.755 Y121.238 E-.02871
G1 X118.07 Y121.331 E-.15601
G1 X118.489 Y121.455 E-.20756
G1 X118.865 Y121.587 E-.18929
G1 X119.344 Y121.89 E-.26922
G1 X119.767 Y122.193 E-.24715
G1 X120.244 Y122.712 E-.33483
G1 X120.326 Y122.828 E-.06723
;WIPE_END
G1 X124.901 Y135.021 F9000
G1 X124.901 Y136.036
G1 X125.282 Y136.036
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X125.315 Y136.106 E.00188
G1 X126.963 Y137.504 E.05257
G1 X125.427 Y138.799 E.04887
G1 X105.573 Y138.799 E.48293
G1 X104.036 Y137.5 E.04895
G1 X105.685 Y136.106 E.05252
G1 X105.75 Y135.966 E.00375
G1 X105.75 Y103.607 E.7871
G1 X105.739 Y103.544 E.00156
G1 X105.567 Y103.424 E.0051
G1 X105.503 Y103.424 E.00156
G1 X105.503 Y98.824 E.11189
G1 X105.567 Y98.824 E.00156
G1 X105.729 Y98.727 E.00459
G1 X105.75 Y98.645 E.00206
G1 X105.75 Y92.034 E.16081
G1 X105.685 Y91.894 E.00375
G1 X104.037 Y90.496 E.05257
G1 X105.573 Y89.201 E.04887
G1 X125.427 Y89.201 E.48293
G1 X126.964 Y90.5 E.04895
G1 X125.315 Y91.894 E.05252
G1 X125.25 Y92.034 E.00375
G1 X125.257 Y98.691 E.16192
G1 X125.433 Y98.824 E.00537
G1 X125.497 Y98.824 E.00156
G1 X125.497 Y98.888 E.00156
G1 X125.497 Y103.424 E.11033
G1 X125.433 Y103.424 E.00156
G1 X125.268 Y103.527 E.00473
G1 X125.25 Y103.607 E.00199
G1 X125.25 Y135.966 E.7871
G1 X125.257 Y135.982 E.00042
G1 X125.257 Y135.982 F9000
G1 X124.944 Y136.196
;TYPE:Perimeter
G1 F6000
G1 X125.078 Y136.384 E.00562
G1 X126.397 Y137.503 E.04207
G1 X125.293 Y138.434 E.03513
G1 X105.707 Y138.434 E.47641
G1 X104.602 Y137.5 E.03519
G1 X105.921 Y136.385 E.04201
G1 X106.078 Y136.166 E.00655
G1 X106.116 Y135.966 E.00495
G1 X106.116 Y103.607 E.7871
G1 X106.061 Y103.367 E.00599
G1 X105.869 Y103.248 E.00549
G1 X105.869 Y99.008 E.10313
G1 X106.052 Y98.898 E.00519
G1 X106.116 Y98.642 E.00642
G1 X106.116 Y92.034 E.16073
G1 X106.078 Y91.835 E.00493
G1 X105.922 Y91.616 E.00654
G1 X104.603 Y90.497 E.04207
G1 X105.707 Y89.566 E.03513
G1 X125.293 Y89.566 E.47641
G1 X126.398 Y90.5 E.03519
G1 X125.079 Y91.615 E.04201
G1 X124.922 Y91.834 E.00655
G1 X124.884 Y92.034 E.00495
G1 X124.884 Y98.62 E.1602
G1 X124.948 Y98.898 E.00694
G1 X125.131 Y99.008 E.00519
G1 X125.131 Y103.248 E.10313
G1 X124.939 Y103.368 E.00551
G1 X124.884 Y103.607 E.00597
G1 X124.884 Y135.966 E.7871
G1 X124.918 Y136.143 E.00438
G1 X124.918 Y136.143 F9000
G1 X124.618 Y136.349
G1 F6000
G1 X124.842 Y136.663 E.00938
G1 X125.831 Y137.502 E.03155
G1 X125.16 Y138.068 E.02135
G1 X105.841 Y138.068 E.46992
G1 X105.169 Y137.5 E.0214
G1 X106.157 Y136.664 E.03148
G1 X106.419 Y136.299 E.01093
G1 X106.481 Y135.966 E.00824
G1 X106.481 Y103.607 E.7871
G1 X106.389 Y103.208 E.00996
G1 X106.235 Y103.111 E.00443
G1 X106.235 Y99.154 E.09625
G1 X106.396 Y99.026 E.005
G1 X106.481 Y98.642 E.00957
G1 X106.481 Y92.034 E.16073
G1 X106.419 Y91.702 E.00822
G1 X106.158 Y91.337 E.01091
G1 X105.169 Y90.498 E.03155
G1 X105.84 Y89.932 E.02135
G1 X125.159 Y89.932 E.46992
G1 X125.831 Y90.5 E.0214
G1 X124.843 Y91.336 E.03148
G1 X124.581 Y91.701 E.01093
G1 X124.519 Y92.034 E.00824
G1 X124.523 Y98.732 E.16292
G1 X124.625 Y99.069 E.00856
G1 X124.765 Y99.154 E.00398
G1 X124.765 Y103.111 E.09625
G1 X124.61 Y103.208 E.00445
G1 X124.519 Y103.607 E.00995
G1 X124.519 Y135.966 E.7871
G1 X124.581 Y136.298 E.00822
G1 X124.583 Y136.3 E.00007
G1 X124.583 Y136.3 F9000
G1 X124.291 Y136.502
G1 F6000
G1 X124.605 Y136.942 E.01315
G1 X125.265 Y137.501 E.02104
G1 X125.026 Y137.702 E.0076
G1 X105.975 Y137.702 E.4634
G1 X105.735 Y137.5 E.00763
G1 X106.393 Y136.944 E.02095
G1 X106.759 Y136.432 E.01531
G1 X106.847 Y135.966 E.01154
G1 X106.847 Y103.607 E.7871
G1 X106.718 Y103.048 E.01395
G1 X106.6 Y102.974 E.00339
G1 X106.6 Y99.3 E.08937
G1 X106.698 Y99.241 E.00278
G1 X106.778 Y99.057 E.00488
G1 X106.847 Y98.642 E.01023
G1 X106.847 Y92.034 E.16073
G1 X106.76 Y91.569 E.01151
G1 X106.395 Y91.058 E.01527
G1 X105.736 Y90.499 E.02102
G1 X105.974 Y90.298 E.00758
G1 X125.025 Y90.298 E.4634
G1 X125.265 Y90.5 E.00763
G1 X124.607 Y91.056 E.02095
G1 X124.241 Y91.568 E.01531
G1 X124.153 Y92.034 E.01154
G1 X124.165 Y98.814 E.16492
G1 X124.302 Y99.24 E.01088
G1 X124.4 Y99.299 E.00278
G1 X124.4 Y102.974 E.08939
G1 X124.281 Y103.048 E.00341
G1 X124.153 Y103.607 E.01395
G1 X124.153 Y135.966 E.7871
G1 X124.24 Y136.431 E.01151
G1 X124.257 Y136.454 E.0007
G1 X124.257 Y136.454 F9000
G1 X123.965 Y136.656
G1 F6000
G1 X124.369 Y137.221 E.01689
G1 X124.505 Y137.337 E.00435
G1 X106.495 Y137.337 E.43808
G1 X106.629 Y137.223 E.00428
G1 X107.1 Y136.565 E.01968
G1 X107.213 Y135.966 E.01483
G1 X107.213 Y103.607 E.7871
G1 X107.111 Y103.038 E.01406
G1 X107.047 Y102.888 E.00397
G1 X106.966 Y102.837 E.00233
G1 X106.966 Y99.445 E.08251
G1 X107.021 Y99.412 E.00156
G1 X107.123 Y99.176 E.00625
G1 X107.213 Y98.642 E.01317
G1 X107.213 Y92.034 E.16073
G1 X107.1 Y91.436 E.0148
G1 X106.631 Y90.779 E.01963
G1 X106.495 Y90.663 E.00435
G1 X124.505 Y90.663 E.43808
G1 X124.371 Y90.777 E.00428
G1 X123.9 Y91.435 E.01968
G1 X123.787 Y92.034 E.01483
G1 X123.787 Y97.916 E.14307
G1 X123.802 Y98.863 E.02304
G1 X123.978 Y99.411 E.014
G1 X124.034 Y99.445 E.00159
G1 X124.034 Y102.838 E.08253
G1 X123.952 Y102.889 E.00235
G1 X123.887 Y103.043 E.00407
G1 X123.787 Y103.607 E.01393
G1 X123.787 Y135.966 E.7871
G1 X123.9 Y136.564 E.0148
G1 X123.93 Y136.607 E.00128
G1 E-5 F3600
G1 X123.93 Y136.607 F9000
G1 X123.678 Y130.1
G1 E5 F2400
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X123.416 Y129.839 E.009
G1 X123.253 Y130.194 E.0095
G1 X123.513 Y130.454 E.00894
G1 X123.513 Y130.973 E.01262
G1 X123.063 Y130.523 E.01548
G1 X122.873 Y130.851 E.00922
G1 X123.513 Y131.491 E.02202
G1 X123.513 Y132.009 E.0126
G1 X122.684 Y131.18 E.02852
G1 X122.494 Y131.508 E.00922
G1 X123.513 Y132.528 E.03507
G1 X123.513 Y133.046 E.0126
G1 X122.304 Y131.837 E.04159
G1 X122.114 Y132.166 E.00924
G1 X123.513 Y133.564 E.04811
G1 X123.513 Y134.083 E.01262
G1 X121.925 Y132.494 E.05464
G1 X121.735 Y132.823 E.00924
G1 X123.513 Y134.601 E.06116
G1 X123.513 Y135.119 E.0126
G1 X121.545 Y133.152 E.06768
G1 X121.355 Y133.48 E.00922
G1 X123.513 Y135.638 E.07423
G1 X123.555 Y136.198 E.01366
G1 X121.149 Y133.793 E.08275
G1 X120.918 Y134.08 E.00896
G1 X123.901 Y137.062 E.1026
G1 X123.383 Y137.062 E.0126
G1 X120.669 Y134.349 E.09334
G1 X120.411 Y134.61 E.00893
G1 X122.864 Y137.062 E.08436
G1 X122.346 Y137.062 E.0126
G1 X120.13 Y134.846 E.07623
G1 X119.822 Y135.057 E.00908
G1 X121.828 Y137.062 E.06899
G1 X121.309 Y137.062 E.01262
G1 X119.498 Y135.251 E.0623
G1 X119.147 Y135.418 E.00945
G1 X120.791 Y137.062 E.05655
G1 X120.272 Y137.062 E.01262
G1 X118.774 Y135.564 E.05153
G1 X118.369 Y135.677 E.01023
G1 X119.754 Y137.062 E.04764
G1 X119.236 Y137.062 E.0126
G1 X117.939 Y135.765 E.04462
G1 X117.46 Y135.805 E.01169
G1 X118.717 Y137.062 E.04324
G1 X118.199 Y137.062 E.0126
G1 X116.959 Y135.822 E.04266
G1 X116.441 Y135.822 E.0126
G1 X117.681 Y137.062 E.04266
G1 X117.162 Y137.062 E.01262
G1 X115.922 Y135.822 E.04266
G1 X115.404 Y135.822 E.0126
G1 X116.644 Y137.062 E.04266
G1 X116.126 Y137.062 E.0126
G1 X114.885 Y135.822 E.04267
G1 X114.367 Y135.822 E.0126
G1 X115.607 Y137.062 E.04266
G1 X115.089 Y137.062 E.0126
G1 X113.849 Y135.822 E.04266
G1 X113.273 Y135.765 E.01408
G1 X114.57 Y137.062 E.04462
G1 X114.052 Y137.062 E.0126
G1 X112.673 Y135.684 E.04742
G1 X111.891 Y135.42 E.02008
G1 X113.534 Y137.062 E.0565
G1 X113.015 Y137.062 E.01262
G1 X107.487 Y131.534 E.19016
G1 X107.487 Y131.016 E.0126
G1 X109.217 Y132.745 E.05949
G1 X108.497 Y131.507 E.03484
G1 X107.487 Y130.497 E.03474
G1 X107.487 Y129.979 E.0126
G1 X108.231 Y130.723 E.02559
G1 E-5 F3600
G1 X108.231 Y130.723 F9000
G1 X107.702 Y126.309
G1 E5 F2400
G1 F3072.127
G1 X107.487 Y126.093 E.00741
G1 X107.487 Y125.563 E.01289
G1 X107.747 Y125.824 E.00896
G1 X107.927 Y125.473 E.00959
G1 X107.487 Y125.033 E.01514
G1 X107.487 Y124.503 E.01289
G1 X108.122 Y125.138 E.02184
G1 X108.317 Y124.803 E.00943
G1 X107.487 Y123.973 E.02855
G1 X107.487 Y123.443 E.01289
G1 X108.511 Y124.468 E.03524
G1 X108.706 Y124.132 E.00945
G1 X107.487 Y122.913 E.04193
G1 X107.487 Y122.383 E.01289
G1 X108.901 Y123.797 E.04864
G1 X109.096 Y123.462 E.00943
G1 X107.487 Y121.853 E.05535
G1 X107.487 Y121.323 E.01289
G1 X109.291 Y123.127 E.06206
G1 X109.486 Y122.792 E.00943
G1 X107.487 Y120.793 E.06876
G1 X107.487 Y120.263 E.01289
G1 X109.681 Y122.457 E.07547
G1 X109.898 Y122.143 E.00928
G1 X107.487 Y119.733 E.08292
G1 X107.487 Y119.203 E.01289
G1 X110.142 Y121.858 E.09133
G1 X110.399 Y121.585 E.00912
G1 X107.487 Y118.673 E.10017
G1 X107.487 Y118.143 E.01289
G1 X110.661 Y121.317 E.10918
G1 X110.966 Y121.092 E.00922
G1 X107.487 Y117.612 E.11969
G1 X107.487 Y117.082 E.01289
G1 X109.31 Y118.905 E.06271
G1 X108.573 Y117.639 E.03563
G1 X107.487 Y116.552 E.03737
G1 X107.487 Y116.022 E.01289
G1 X108.292 Y116.827 E.02769
G1 E-5 F3600
G1 X108.292 Y116.827 F9000
G1 X107.701 Y112.311
G1 E5 F2400
G1 F3072.127
G1 X107.487 Y112.096 E.00738
G1 X107.487 Y111.568 E.01284
G1 X107.746 Y111.827 E.00891
G1 X107.924 Y111.478 E.00953
G1 X107.487 Y111.04 E.01505
G1 X107.487 Y110.512 E.01284
G1 X108.118 Y111.144 E.02172
G1 X108.313 Y110.81 E.00941
G1 X107.487 Y109.984 E.02841
G1 X107.487 Y109.456 E.01284
G1 X108.507 Y110.476 E.03509
G1 X108.701 Y110.142 E.0094
G1 X107.487 Y108.928 E.04176
G1 X107.487 Y108.4 E.01284
G1 X108.895 Y109.808 E.04843
G1 X109.089 Y109.474 E.0094
G1 X107.487 Y107.872 E.05511
G1 X107.487 Y107.344 E.01284
G1 X109.283 Y109.14 E.06178
G1 X109.477 Y108.806 E.0094
G1 X107.487 Y106.816 E.06845
G1 X107.487 Y106.288 E.01284
G1 X109.672 Y108.472 E.07515
G1 X109.886 Y108.159 E.00922
G1 X107.487 Y105.76 E.08252
G1 X107.487 Y105.232 E.01284
G1 X110.128 Y107.873 E.09085
G1 X110.384 Y107.601 E.00909
G1 X107.487 Y104.704 E.09966
G1 X107.487 Y104.176 E.01284
G1 X110.642 Y107.331 E.10853
G1 X110.945 Y107.106 E.00918
G1 X107.487 Y103.648 E.11895
G1 X107.383 Y103.015 E.0156
G1 X109.361 Y104.994 E.06806
G1 X108.628 Y103.732 E.0355
G1 X107.24 Y102.345 E.04773
G1 X107.24 Y101.817 E.01284
G1 X108.349 Y102.925 E.03813
G1 X108.349 Y102.925 F9000
G1 X107.27 Y101.311
;TYPE:Solid infill
;WIDTH:0.459427
G1 F1200
G1 X107.267 Y100.945 E.01035
;WIDTH:0.452812
G1 X107.243 Y100.147 E.02222
;WIDTH:0.418307
G1 X107.249 Y99.615 E.01359
G1 X107.309 Y99.435 E.00485
;WIDTH:0.432731
G1 X107.367 Y99.289 E.00416
;WIDTH:0.475094
G1 X107.425 Y99.144 E.00458
;WIDTH:0.517458
G1 X107.483 Y98.998 E.00505
;WIDTH:0.559821
G1 X107.541 Y98.853 E.00546
G1 X107.739 Y98.778 E.0074
;WIDTH:0.559362
G1 X107.689 Y98.926 E.00546
G1 X107.697 Y98.98 E.00191
;WIDTH:0.516057
G1 X107.704 Y99.034 E.00174
;WIDTH:0.472752
G1 X107.712 Y99.089 E.00162
;WIDTH:0.429447
G1 X107.719 Y99.143 E.00143
;WIDTH:0.390367
G1 X107.655 Y99.505 E.00871
;WIDTH:0.404819
G1 X107.612 Y100.125 E.01532
;WIDTH:0.452812
G1 X107.684 Y100.92 E.02222
G1 X107.8 Y101.306 E.01122
;WIDTH:0.454185
G1 X107.607 Y101.212 E.006
;WIDTH:0.457865
G1 X107.428 Y101.234 E.00508
G1 E-5 F3600
G1 X107.428 Y101.234 F9000
G1 X107.739 Y98.778
G1 E5 F2400
;WIDTH:0.541978
G1 F1200
G1 X107.887 Y98.449 E.01218
;WIDTH:0.504236
G1 X108.036 Y98.121 E.01126
;WIDTH:0.466494
G1 X108.185 Y97.792 E.01038
;WIDTH:0.430754
G1 X109.926 Y94.784 E.09165
;WIDTH:0.446952
G1 X110.29 Y94.268 E.01733
G1 X110.774 Y93.736 E.01974
;WIDTH:0.431956
G1 X111.474 Y93.216 E.02306
;WIDTH:0.441578
G1 X112.02 Y92.931 E.01668
;WIDTH:0.44402
G1 X112.547 Y92.744 E.01524
G1 X112.824 Y92.671 E.00781
;WIDTH:0.44126
G1 X113.754 Y92.561 E.02535
;WIDTH:0.4311
G1 X117.47 Y92.57 E.09808
;WIDTH:0.430378
G1 X118.305 Y92.706 E.02229
;WIDTH:0.444554
G1 X118.841 Y92.876 E.01534
G1 X119.348 Y93.109 E.01523
;WIDTH:0.441626
G1 X120.082 Y93.613 E.02412
;WIDTH:0.426092
G1 X120.411 Y93.92 E.01173
;WIDTH:0.448258
G1 X120.762 Y94.328 E.01482
G1 X120.95 Y94.58 E.00866
;WIDTH:0.430922
G1 X122.806 Y97.772 E.09741
;WIDTH:0.451102
G1 X123.078 Y98.367 E.01814
;WIDTH:0.48531
G1 X123.172 Y98.571 E.00674
;WIDTH:0.519518
G1 X123.266 Y98.775 E.00725
;WIDTH:0.536404
G1 X123.288 Y98.801 E.00114
G1 E-5 F3600
G1 X123.288 Y98.801 F9000
G1 X123.775 Y101.503
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X123.777 Y102.728 E.02771
G1 X123.777 Y102.728 F9000
G1 X123.304 Y101.28
;WIDTH:0.46865
G1 F1200
G1 X123.468 Y101.284 E.00474
G1 X123.647 Y101.334 E.00537
;WIDTH:0.438336
G1 X123.711 Y101.418 E.00284
;WIDTH:0.406336
G1 X123.775 Y101.503 E.00263
;WIDTH:0.413547
G1 X123.754 Y101.22 E.00716
;WIDTH:0.452757
G1 X123.733 Y100.937 E.0079
G1 X123.757 Y100.145 E.02205
;WIDTH:0.424069
G1 X123.748 Y99.629 E.01338
G1 X123.674 Y99.381 E.00671
;WIDTH:0.390899
G1 X123.6 Y99.132 E.00616
;WIDTH:0.399387
G1 X123.562 Y99.077 E.00162
;WIDTH:0.441046
G1 X123.524 Y99.022 E.00181
;WIDTH:0.482704
G1 X123.486 Y98.967 E.00199
;WIDTH:0.524362
G1 X123.447 Y98.912 E.0022
;WIDTH:0.56602
G1 X123.409 Y98.857 E.00236
G1 X123.288 Y98.801 E.00472
G1 X123.33 Y98.941 E.00517
G1 X123.322 Y99.002 E.00218
;WIDTH:0.525352
G1 X123.315 Y99.063 E.00201
;WIDTH:0.484683
G1 X123.307 Y99.124 E.00184
;WIDTH:0.444014
G1 X123.299 Y99.185 E.00168
;WIDTH:0.403346
G1 X123.292 Y99.245 E.00148
;WIDTH:0.404367
G1 X123.388 Y100.085 E.02081
;WIDTH:0.448275
G1 X123.323 Y100.863 E.0215
;WIDTH:0.457333
G1 X123.233 Y101.251 E.01121
G1 X123.169 Y101.403 E.00464
;WIDTH:0.449156
G1 X122.929 Y101.988 E.01745
;WIDTH:0.430738
G1 X122.916 Y102.015 E.00079
;WIDTH:0.430462
G1 X120.953 Y105.414 E.10343
;WIDTH:0.430242
G1 X120.672 Y105.787 E.0123
;WIDTH:0.440354
G1 X120.133 Y106.352 E.02109
;WIDTH:0.44517
G1 X119.579 Y106.75 E.01864
;WIDTH:0.489988
G1 X119.54 Y106.798 E.00187
;WIDTH:0.534806
G1 X119.5 Y106.847 E.00211
;WIDTH:0.579624
G1 X119.461 Y106.896 E.00227
;WIDTH:0.624442
G1 X119.422 Y106.944 E.00243
;WIDTH:0.66926
G1 X119.383 Y106.993 E.00265
G1 X119.421 Y107.043 E.00265
;WIDTH:0.624267
G1 X119.46 Y107.093 E.00249
;WIDTH:0.579273
G1 X119.498 Y107.143 E.00228
;WIDTH:0.534279
G1 X119.537 Y107.193 E.00211
;WIDTH:0.489286
G1 X119.576 Y107.243 E.00192
;WIDTH:0.444292
G1 X120.164 Y107.678 E.01995
;WIDTH:0.4206
G1 X120.435 Y107.94 E.00969
;WIDTH:0.447662
G1 X120.95 Y108.58 E.02259
;WIDTH:0.430918
G1 X122.806 Y111.772 E.09741
;WIDTH:0.451054
G1 X123.078 Y112.367 E.01814
;WIDTH:0.479455
G1 X123.173 Y112.595 E.00731
;WIDTH:0.507856
G1 X123.269 Y112.822 E.00776
;WIDTH:0.545843
G1 X123.297 Y112.859 E.00158
;WIDTH:0.58383
G1 X123.326 Y112.896 E.00172
;WIDTH:0.621817
G1 X123.355 Y112.933 E.00184
;WIDTH:0.659804
G1 X123.383 Y112.97 E.00193
G1 X123.405 Y113.34 E.01542
;WIDTH:0.615627
G1 X123.427 Y113.71 E.01433
;WIDTH:0.57145
G1 X123.449 Y114.08 E.01324
;WIDTH:0.571004
G1 X123.428 Y114.476 E.01416
;WIDTH:0.614736
G1 X123.406 Y114.873 E.01535
;WIDTH:0.661776
G1 X123.382 Y115.078 E.00861
G1 X123.344 Y115.133 E.00279
;WIDTH:0.619256
G1 X123.305 Y115.187 E.00259
;WIDTH:0.576736
G1 X123.267 Y115.241 E.00238
;WIDTH:0.534216
G1 X123.228 Y115.295 E.00221
;WIDTH:0.491696
G1 X123.19 Y115.35 E.00203
;WIDTH:0.449176
G1 X122.929 Y115.988 E.01902
;WIDTH:0.43067
G1 X122.916 Y116.015 E.00079
;WIDTH:0.430458
G1 X120.953 Y119.414 E.10343
;WIDTH:0.430238
G1 X120.672 Y119.787 E.0123
;WIDTH:0.440354
G1 X120.133 Y120.352 E.02109
;WIDTH:0.44517
G1 X119.579 Y120.75 E.01864
;WIDTH:0.489988
G1 X119.54 Y120.798 E.00187
;WIDTH:0.534806
G1 X119.501 Y120.847 E.00208
;WIDTH:0.579624
G1 X119.461 Y120.896 E.00229
;WIDTH:0.624442
G1 X119.422 Y120.944 E.00243
;WIDTH:0.66926
G1 X119.383 Y120.993 E.00265
G1 X119.421 Y121.043 E.00265
;WIDTH:0.624193
G1 X119.46 Y121.093 E.00249
;WIDTH:0.579127
G1 X119.499 Y121.143 E.0023
;WIDTH:0.53406
G1 X119.537 Y121.193 E.00209
;WIDTH:0.488993
G1 X119.576 Y121.243 E.00192
;WIDTH:0.443926
G1 X120.082 Y121.616 E.01713
;WIDTH:0.421242
G1 X120.434 Y121.939 E.0123
;WIDTH:0.44768
G1 X120.95 Y122.58 E.02263
;WIDTH:0.43092
G1 X122.806 Y125.772 E.09741
;WIDTH:0.451054
G1 X123.078 Y126.367 E.01814
;WIDTH:0.479455
G1 X123.173 Y126.595 E.00731
;WIDTH:0.507856
G1 X123.269 Y126.822 E.00776
;WIDTH:0.545843
G1 X123.297 Y126.859 E.00158
;WIDTH:0.58383
G1 X123.326 Y126.896 E.00172
;WIDTH:0.621817
G1 X123.355 Y126.933 E.00184
;WIDTH:0.659804
G1 X123.383 Y126.97 E.00193
G1 X123.405 Y127.34 E.01542
;WIDTH:0.615626
G1 X123.427 Y127.71 E.01433
;WIDTH:0.571448
G1 X123.449 Y128.08 E.01324
;WIDTH:0.571005
G1 X123.428 Y128.476 E.01416
;WIDTH:0.61474
G1 X123.406 Y128.873 E.01535
;WIDTH:0.660522
G1 X123.383 Y129.073 E.00839
G1 X123.345 Y129.127 E.00275
;WIDTH:0.618253
G1 X123.307 Y129.181 E.00256
;WIDTH:0.575985
G1 X123.269 Y129.235 E.00238
;WIDTH:0.533716
G1 X123.231 Y129.289 E.00219
;WIDTH:0.491447
G1 X123.192 Y129.343 E.00203
;WIDTH:0.449178
G1 X122.929 Y129.988 E.01922
;WIDTH:0.430666
G1 X122.916 Y130.015 E.00079
;WIDTH:0.430462
G1 X120.953 Y133.414 E.10343
;WIDTH:0.430238
G1 X120.674 Y133.785 E.01222
;WIDTH:0.433704
G1 X120.22 Y134.269 E.01763
G1 X119.77 Y134.621 E.01518
;WIDTH:0.426532
G1 X119.124 Y135.002 E.01957
G1 X118.678 Y135.186 E.01259
;WIDTH:0.447314
G1 X118.18 Y135.325 E.0142
G1 X117.245 Y135.439 E.02588
;WIDTH:0.43083
G1 X117.225 Y135.441 E.00053
;WIDTH:0.442394
G1 X113.774 Y135.435 E.09367
G1 X113.096 Y135.369 E.01849
;WIDTH:0.432554
G1 X112.402 Y135.214 E.01884
G1 X111.9 Y135.013 E.01432
;WIDTH:0.4492
G1 X111.449 Y134.769 E.01415
G1 X110.992 Y134.449 E.0154
;WIDTH:0.442396
G1 X110.707 Y134.198 E.01031
;WIDTH:0.441264
G1 X110.323 Y133.782 E.01532
;WIDTH:0.430924
G1 X110.049 Y133.419 E.012
G1 X108.194 Y130.228 E.09737
;WIDTH:0.450568
G1 X107.923 Y129.634 E.01808
;WIDTH:0.483536
G1 X107.735 Y129.165 E.0151
;WIDTH:0.531055
G1 X107.69 Y129.092 E.00283
;WIDTH:0.578574
G1 X107.645 Y129.019 E.0031
;WIDTH:0.626092
G1 X107.6 Y128.946 E.00338
G1 X107.575 Y128.539 E.01605
;WIDTH:0.57691
G1 X107.551 Y128.132 E.01472
;WIDTH:0.565257
G1 X107.57 Y127.661 E.01665
;WIDTH:0.602786
G1 X107.588 Y127.19 E.01782
;WIDTH:0.631084
G1 X107.602 Y127.08 E.0044
;WIDTH:0.659382
G1 X107.617 Y126.97 E.00462
G1 X107.654 Y126.916 E.00272
;WIDTH:0.617638
G1 X107.691 Y126.862 E.00254
;WIDTH:0.575894
G1 X107.728 Y126.808 E.00236
;WIDTH:0.53415
G1 X107.766 Y126.754 E.0022
;WIDTH:0.492406
G1 X107.803 Y126.701 E.00197
;WIDTH:0.450662
G1 X108.185 Y125.792 E.02731
;WIDTH:0.430748
G1 X109.926 Y122.784 E.09165
;WIDTH:0.454858
G1 X110.293 Y122.271 E.01764
G1 X110.732 Y121.775 E.01853
;WIDTH:0.426996
G1 X111.426 Y121.248 E.02276
;WIDTH:0.473567
G1 X111.466 Y121.197 E.00189
;WIDTH:0.520137
G1 X111.507 Y121.146 E.00211
;WIDTH:0.566707
G1 X111.547 Y121.095 E.0023
;WIDTH:0.613278
G1 X111.588 Y121.045 E.00249
;WIDTH:0.659848
G1 X111.628 Y120.994 E.0027
G1 X111.589 Y120.946 E.00257
;WIDTH:0.616245
G1 X111.55 Y120.898 E.00239
;WIDTH:0.572642
G1 X111.511 Y120.85 E.00221
;WIDTH:0.529039
G1 X111.472 Y120.803 E.00201
;WIDTH:0.485435
G1 X111.433 Y120.755 E.00186
;WIDTH:0.441832
G1 X110.985 Y120.454 E.01463
;WIDTH:0.427368
G1 X110.327 Y119.787 E.0245
;WIDTH:0.430918
G1 X110.049 Y119.419 E.01217
G1 X108.194 Y116.228 E.09737
;WIDTH:0.45057
G1 X107.923 Y115.634 E.01808
;WIDTH:0.483526
G1 X107.735 Y115.165 E.0151
;WIDTH:0.531049
G1 X107.69 Y115.092 E.00283
;WIDTH:0.578572
G1 X107.645 Y115.019 E.0031
;WIDTH:0.626094
G1 X107.6 Y114.946 E.00338
G1 X107.575 Y114.539 E.01605
;WIDTH:0.576911
G1 X107.551 Y114.132 E.01472
;WIDTH:0.565257
G1 X107.57 Y113.661 E.01665
;WIDTH:0.602786
G1 X107.588 Y113.19 E.01782
;WIDTH:0.631088
G1 X107.602 Y113.08 E.0044
;WIDTH:0.65939
G1 X107.617 Y112.97 E.00462
G1 X107.654 Y112.916 E.00272
;WIDTH:0.617646
G1 X107.691 Y112.862 E.00254
;WIDTH:0.575901
G1 X107.728 Y112.808 E.00236
;WIDTH:0.534157
G1 X107.766 Y112.754 E.0022
;WIDTH:0.492413
G1 X107.803 Y112.701 E.00197
;WIDTH:0.450668
G1 X108.185 Y111.792 E.02731
;WIDTH:0.430754
G1 X109.926 Y108.784 E.09165
;WIDTH:0.454854
G1 X110.293 Y108.271 E.01764
G1 X110.732 Y107.775 E.01853
;WIDTH:0.426996
G1 X111.426 Y107.248 E.02276
;WIDTH:0.473566
G1 X111.466 Y107.197 E.00189
;WIDTH:0.520136
G1 X111.507 Y107.146 E.00211
;WIDTH:0.566706
G1 X111.547 Y107.095 E.0023
;WIDTH:0.613276
G1 X111.588 Y107.045 E.00249
;WIDTH:0.659846
G1 X111.628 Y106.994 E.0027
G1 X111.589 Y106.946 E.00257
;WIDTH:0.616243
G1 X111.55 Y106.898 E.00239
;WIDTH:0.57264
G1 X111.511 Y106.85 E.00221
;WIDTH:0.529037
G1 X111.472 Y106.803 E.00201
;WIDTH:0.485433
G1 X111.433 Y106.755 E.00186
;WIDTH:0.44183
G1 X110.984 Y106.454 E.01465
;WIDTH:0.42737
G1 X110.327 Y105.787 E.02448
;WIDTH:0.43092
G1 X110.049 Y105.419 E.01217
G1 X108.194 Y102.228 E.09737
;WIDTH:0.450566
G1 X107.923 Y101.634 E.01808
G1 X107.809 Y101.325 E.00912
G1 E-5 F3600
G1 X107.809 Y101.325 F9000
G1 X107.72 Y98.262
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X107.487 Y98.028 E.00803
G1 X107.487 Y97.51 E.0126
G1 X107.764 Y97.788 E.00955
G1 X107.942 Y97.448 E.00933
G1 X107.487 Y96.993 E.01565
G1 X107.487 Y96.475 E.0126
G1 X108.132 Y97.12 E.02219
G1 X108.322 Y96.793 E.0092
G1 X107.487 Y95.958 E.02872
G1 X107.487 Y95.44 E.0126
G1 X108.512 Y96.466 E.03528
G1 X108.703 Y96.139 E.00921
G1 X107.487 Y94.923 E.04183
G1 X107.487 Y94.405 E.0126
G1 X108.893 Y95.811 E.04837
G1 X109.083 Y95.484 E.0092
G1 X107.487 Y93.887 E.05492
G1 X107.487 Y93.37 E.01258
G1 X109.274 Y95.157 E.06147
G1 X109.464 Y94.829 E.00922
G1 X107.487 Y92.852 E.06801
G1 X107.487 Y92.335 E.01258
G1 X109.654 Y94.502 E.07454
G1 X109.862 Y94.192 E.00908
G1 X107.439 Y91.769 E.08335
G1 X107.357 Y91.333 E.01079
G1 X107.075 Y90.938 E.01181
G1 X110.094 Y93.907 E.103
G1 X110.343 Y93.638 E.00892
G1 X107.642 Y90.938 E.0929
G1 X108.16 Y90.938 E.0126
G1 X110.603 Y93.38 E.08402
G1 X110.885 Y93.145 E.00893
G1 X108.678 Y90.938 E.07592
G1 X109.195 Y90.938 E.01258
G1 X111.2 Y92.943 E.06897
G1 X111.52 Y92.745 E.00915
G1 X109.713 Y90.938 E.06216
G1 X110.23 Y90.938 E.01258
G1 X111.868 Y92.575 E.05633
G1 X112.249 Y92.439 E.00984
G1 X110.748 Y90.938 E.05163
G1 X111.266 Y90.938 E.0126
G1 X112.645 Y92.317 E.04744
G1 X113.097 Y92.252 E.01111
G1 X111.783 Y90.938 E.0452
G1 X112.301 Y90.938 E.0126
G1 X113.563 Y92.2 E.04341
G1 X114.059 Y92.179 E.01208
G1 X112.818 Y90.938 E.04269
G1 X113.336 Y90.938 E.0126
G1 X114.578 Y92.18 E.04272
G1 X115.098 Y92.182 E.01265
G1 X113.853 Y90.938 E.04281
G1 X114.371 Y90.938 E.0126
G1 X115.617 Y92.183 E.04284
G1 X116.136 Y92.185 E.01262
G1 X114.889 Y90.938 E.0429
G1 X115.406 Y90.938 E.01258
G1 X116.655 Y92.186 E.04295
G1 X117.174 Y92.188 E.01262
G1 X115.924 Y90.938 E.043
G1 X116.441 Y90.938 E.01258
G1 X117.716 Y92.212 E.04384
G1 X118.351 Y92.33 E.01571
G1 X116.959 Y90.938 E.04788
G1 X117.477 Y90.938 E.0126
G1 X119.452 Y92.913 E.06794
G1 E-5 F3600
G1 X119.452 Y92.913 F9000
G1 X123.944 Y91.194
G1 E5 F2400
G1 F3072.127
G1 X123.688 Y90.938 E.00881
G1 X123.17 Y90.938 E.0126
G1 X123.631 Y91.399 E.01586
G1 X123.549 Y91.834 E.01077
G1 X122.652 Y90.938 E.03084
G1 X122.135 Y90.938 E.01258
G1 X123.513 Y92.316 E.0474
G1 X123.513 Y92.833 E.01258
G1 X121.617 Y90.938 E.0652
G1 X121.1 Y90.938 E.01258
G1 X123.513 Y93.351 E.08301
G1 X123.513 Y93.869 E.0126
G1 X120.582 Y90.938 E.10082
G1 X120.064 Y90.938 E.0126
G1 X123.513 Y94.386 E.11863
G1 X123.513 Y94.904 E.0126
G1 X119.547 Y90.938 E.13643
G1 X119.029 Y90.938 E.0126
G1 X123.513 Y95.421 E.15423
G1 X123.513 Y95.939 E.0126
G1 X118.512 Y90.938 E.17203
G1 X117.994 Y90.938 E.0126
G1 X123.513 Y96.457 E.18985
G1 X123.513 Y96.974 E.01258
G1 X121.769 Y95.23 E.05999
G1 X122.488 Y96.466 E.03478
G1 X123.513 Y97.492 E.03528
G1 X123.513 Y98.009 E.01258
G1 X122.752 Y97.248 E.02618
G1 E-5 F3600
G1 X122.752 Y97.248 F9000
G1 X123.592 Y102.322
G1 E5 F2400
G1 F3072.127
G1 X123.321 Y102.051 E.00932
G1 X123.133 Y102.401 E.00966
G1 X123.428 Y102.696 E.01015
G1 X123.428 Y102.981 E.00693
G1 X123.605 Y103.079 E.00492
G1 X123.555 Y103.362 E.00699
G1 X122.936 Y102.743 E.02129
G1 X122.739 Y103.084 E.00958
G1 X123.513 Y103.858 E.02663
G1 X123.513 Y104.397 E.01311
G1 X122.542 Y103.425 E.03342
G1 X122.345 Y103.767 E.0096
G1 X123.513 Y104.935 E.04018
G1 X123.513 Y105.474 E.01311
G1 X122.148 Y104.108 E.04697
G1 X121.951 Y104.449 E.00958
G1 X123.513 Y106.012 E.05375
G1 X123.513 Y106.55 E.01309
G1 X121.753 Y104.791 E.06053
G1 X121.556 Y105.132 E.00958
G1 X123.513 Y107.089 E.06732
G1 X123.513 Y107.627 E.01309
G1 X121.359 Y105.474 E.07408
G1 X121.145 Y105.798 E.00944
G1 X123.513 Y108.166 E.08146
G1 X123.513 Y108.704 E.01309
G1 X120.903 Y106.094 E.08978
G1 X120.643 Y106.373 E.00928
G1 X123.513 Y109.243 E.09873
G1 X123.513 Y109.781 E.01309
G1 X120.38 Y106.649 E.10776
G1 X120.076 Y106.883 E.00933
G1 X123.513 Y110.32 E.11823
G1 X123.513 Y110.858 E.01309
G1 X121.608 Y108.953 E.06553
G1 X122.356 Y110.239 E.03619
G1 X123.513 Y111.397 E.03982
G1 X123.513 Y111.935 E.01309
G1 X122.649 Y111.071 E.02972
G1 E-5 F3600
G1 X122.649 Y111.071 F9000
G1 X123.678 Y116.119
G1 E5 F2400
G1 F3072.127
G1 X123.411 Y115.853 E.00917
G1 X123.243 Y116.211 E.00962
G1 X123.513 Y116.481 E.00929
G1 X123.513 Y117.007 E.01279
G1 X123.05 Y116.544 E.01593
G1 X122.858 Y116.878 E.00937
G1 X123.513 Y117.533 E.02253
G1 X123.513 Y118.06 E.01282
G1 X122.665 Y117.212 E.02917
G1 X122.473 Y117.545 E.00935
G1 X123.513 Y118.586 E.03579
G1 X123.513 Y119.112 E.01279
G1 X122.28 Y117.879 E.04241
G1 X122.087 Y118.213 E.00938
G1 X123.513 Y119.638 E.04904
G1 X123.513 Y120.165 E.01282
G1 X121.895 Y118.546 E.05568
G1 X121.702 Y118.88 E.00938
G1 X123.513 Y120.691 E.0623
G1 X123.513 Y121.217 E.01279
G1 X121.509 Y119.213 E.06894
G1 X121.317 Y119.547 E.00937
G1 X123.513 Y121.743 E.07554
G1 X123.513 Y122.27 E.01282
G1 X121.101 Y119.858 E.08297
G1 X120.859 Y120.142 E.00908
G1 X123.513 Y122.796 E.0913
G1 X123.513 Y123.322 E.01279
G1 X120.605 Y120.414 E.10003
G1 X120.343 Y120.678 E.00905
G1 X123.513 Y123.848 E.10905
G1 X123.513 Y124.375 E.01282
G1 X120.043 Y120.905 E.11937
G1 X119.905 Y120.998 E.00405
G1 X120.555 Y121.509 E.02011
G1 X121.076 Y122.096 E.01909
G1 X121.667 Y123.055 E.0274
G1 X123.513 Y124.901 E.0635
G1 X123.513 Y125.427 E.01279
G1 X122.398 Y124.312 E.03836
G1 X123.129 Y125.569 E.03537
G1 X123.678 Y126.118 E.01889
G1 E-5 F3600
G1 X123.678 Y126.118 F9000
G1 X119.856 Y132.529
G1 X119.834 Y132.565
G1 X119.71 Y132.757
G1 X119.676 Y132.801
G1 X119.535 Y132.981
G1 X119.497 Y133.022
G1 X119.339 Y133.188
G1 X119.299 Y133.225
G1 X119.126 Y133.375
G1 X119.082 Y133.409
G1 X118.895 Y133.541
G1 X118.849 Y133.571
G1 X112.662 Y137.227
G1 E5 F2400
G1 F3072.127
G1 X107.487 Y132.052 E.17802
G1 X107.487 Y132.571 E.01262
G1 X111.979 Y137.062 E.1545
G1 X111.46 Y137.062 E.01262
G1 X107.487 Y133.089 E.13667
G1 X107.487 Y133.607 E.0126
G1 X110.942 Y137.062 E.11885
G1 X110.424 Y137.062 E.0126
G1 X107.487 Y134.126 E.10101
G1 X107.487 Y134.644 E.0126
G1 X109.905 Y137.062 E.08318
G1 X109.387 Y137.062 E.0126
G1 X107.487 Y135.162 E.06536
G1 X107.487 Y135.681 E.01262
G1 X108.869 Y137.062 E.04752
G1 X108.35 Y137.062 E.01262
G1 X107.451 Y136.164 E.03091
G1 X107.369 Y136.6 E.01079
G1 X107.832 Y137.062 E.01591
G1 X107.313 Y137.062 E.01262
G1 X107.056 Y136.805 E.00884
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X107.313 Y137.062 E-.17264
G1 X107.832 Y137.062 E-.24653
G1 X107.369 Y136.6 E-.31069
G1 X107.451 Y136.164 E-.21073
G1 X108.284 Y136.997 E-.55941
;WIPE_END
G1 X109.001 Y99.886 F9000
G1 X109.003 Y99.83
G1 X109.025 Y99.602
G1 X110.024 Y89.549
G1 X110.075 Y88.151
G1 X110.132 Y86.599
G1 X110.172 Y85.028
G1 X110.172 Y85.5
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X104.557 Y85.5 E.13658
G1 X103.993 Y85.458 E.01376
G1 X103.449 Y85.336 E.01356
G1 X102.813 Y85.078 E.01669
G1 X102.179 Y84.668 E.01837
G1 X101.64 Y84.138 E.01839
G1 X101.264 Y83.605 E.01587
G1 X100.948 Y82.907 E.01864
G1 X100.792 Y82.257 E.01626
G1 X100.75 Y81.693 E.01376
G1 X100.75 Y79.031 E.06475
G1 X100.685 Y78.892 E.00373
G1 X99.036 Y77.5 E.05249
G1 X100.573 Y76.201 E.04895
G1 X130.427 Y76.201 E.72617
G1 X130.79 Y76.508 E.01156
G1 X131.964 Y77.5 E.03739
G1 X130.315 Y78.892 E.05249
G1 X130.25 Y79.031 E.00373
G1 X130.24 Y81.702 E.06497
G1 X130.197 Y82.259 E.01359
G1 X130.072 Y82.808 E.0137
G1 X129.861 Y83.349 E.01412
G1 X129.571 Y83.847 E.01402
G1 X129.226 Y84.279 E.01345
G1 X128.784 Y84.684 E.01458
G1 X128.349 Y84.982 E.01283
G1 X127.818 Y85.245 E.01441
G1 X127.282 Y85.407 E.01362
G1 X126.729 Y85.489 E.0136
G1 X120.802 Y85.5 E.14417
G1 X120.667 Y85.377 E.00444
G1 X110.333 Y85.377 E.25136
G1 X110.223 Y85.477 E.00362
G1 X110.223 Y85.477 F9000
G1 X109.998 Y85.134
;TYPE:Perimeter
G1 F6000
G1 X105.4 Y85.134 E.11184
G1 X104.282 Y85.113 E.0272
G1 X103.559 Y84.986 E.01786
G1 X102.983 Y84.752 E.01512
G1 X102.409 Y84.381 E.01662
G1 X101.919 Y83.9 E.0167
G1 X101.583 Y83.423 E.01419
G1 X101.296 Y82.788 E.01695
G1 X101.155 Y82.2 E.01471
G1 X101.116 Y81.679 E.01271
G1 X101.116 Y79.031 E.06441
G1 X101.078 Y78.832 E.00493
G1 X100.921 Y78.612 E.00657
G1 X99.603 Y77.5 E.04195
G1 X100.707 Y76.566 E.03517
G1 X130.293 Y76.566 E.71965
G1 X130.554 Y76.787 E.00832
G1 X131.397 Y77.5 E.02686
G1 X130.079 Y78.612 E.04195
G1 X129.923 Y78.83 E.00652
G1 X129.884 Y79.029 E.00493
G1 X129.874 Y81.7 E.06497
G1 X129.835 Y82.205 E.01232
G1 X129.723 Y82.701 E.01237
G1 X129.531 Y83.19 E.01278
G1 X129.274 Y83.634 E.01248
G1 X128.958 Y84.03 E.01232
G1 X128.58 Y84.379 E.01251
G1 X128.162 Y84.667 E.01235
G1 X127.689 Y84.902 E.01285
G1 X127.201 Y85.05 E.0124
G1 X126.702 Y85.124 E.01227
G1 X120.877 Y85.134 E.14169
G1 X120.789 Y85.025 E.00341
G1 X120.667 Y85.011 E.00299
G1 X110.333 Y85.011 E.25136
G1 X110.238 Y85.019 E.00232
G1 X110.123 Y85.134 E.00396
G1 X110.058 Y85.134 E.00158
G1 X110.058 Y85.134 F9000
G1 X109.74 Y84.769
G1 F6000
G1 X105.4 Y84.769 E.10557
G1 X104.308 Y84.748 E.02657
G1 X103.669 Y84.636 E.01578
G1 X103.153 Y84.426 E.01355
G1 X102.638 Y84.094 E.0149
G1 X102.199 Y83.662 E.01498
G1 X101.902 Y83.241 E.01253
G1 X101.643 Y82.669 E.01527
G1 X101.517 Y82.144 E.01313
G1 X101.481 Y81.665 E.01168
G1 X101.481 Y79.031 E.06407
G1 X101.419 Y78.698 E.00824
G1 X101.157 Y78.333 E.01093
G1 X100.169 Y77.5 E.03143
G1 X100.841 Y76.932 E.0214
G1 X130.159 Y76.932 E.71313
G1 X130.318 Y77.066 E.00506
G1 X130.831 Y77.5 E.01634
G1 X129.843 Y78.333 E.03143
G1 X129.582 Y78.696 E.01088
G1 X129.519 Y79.028 E.00822
G1 X129.509 Y81.699 E.06497
G1 X129.44 Y82.376 E.01655
G1 X129.202 Y83.03 E.01693
G1 X128.842 Y83.618 E.01677
G1 X128.329 Y84.112 E.01732
G1 X127.849 Y84.429 E.01399
G1 X127.336 Y84.627 E.01338
G1 X126.675 Y84.758 E.01639
G1 X120.951 Y84.768 E.13923
G1 X120.871 Y84.668 E.00311
G1 X120.667 Y84.645 E.00499
G1 X110.333 Y84.645 E.25136
G1 X110.175 Y84.659 E.00386
G1 X110.048 Y84.769 E.00409
G1 X109.8 Y84.769 E.00603
G1 X109.8 Y84.769 F9000
G1 X109.478 Y84.402
G1 F6000
G1 X104.493 Y84.395 E.12126
G1 X103.977 Y84.331 E.01265
G1 X103.322 Y84.101 E.01689
G1 X102.868 Y83.807 E.01316
G1 X102.673 Y83.615 E.00666
G1 X102.353 Y83.247 E.01186
G1 X102.097 Y82.784 E.01287
G1 X101.931 Y82.3 E.01245
G1 X101.847 Y81.651 E.01592
G1 X101.847 Y79.031 E.06373
G1 X101.759 Y78.565 E.01154
G1 X101.392 Y78.053 E.01532
G1 X100.736 Y77.5 E.02087
G1 X100.975 Y77.298 E.00761
G1 X130.025 Y77.298 E.70661
G1 X130.082 Y77.345 E.0018
G1 X130.264 Y77.5 E.00581
G1 X129.608 Y78.053 E.02087
G1 X129.242 Y78.562 E.01525
G1 X129.153 Y79.027 E.01152
G1 X129.143 Y81.698 E.06497
G1 X129.082 Y82.295 E.0146
G1 X128.873 Y82.871 E.0149
G1 X128.555 Y83.389 E.01478
G1 X128.101 Y83.826 E.01533
G1 X127.679 Y84.104 E.01229
G1 X127.23 Y84.277 E.0117
G1 X126.647 Y84.392 E.01445
G1 X121.025 Y84.402 E.13675
G1 X120.952 Y84.312 E.00282
G1 X120.667 Y84.28 E.00698
G1 X110.333 Y84.28 E.25136
G1 X110.045 Y84.312 E.00705
G1 X109.973 Y84.403 E.00282
G1 X109.538 Y84.402 E.01058
G1 X109.538 Y84.402 F9000
G1 X109.216 Y84.037
G1 F6000
G1 X104.611 Y84.037 E.11201
G1 X104.057 Y83.974 E.01356
G1 X103.492 Y83.775 E.01457
G1 X103.098 Y83.52 E.01142
G1 X102.759 Y83.187 E.01156
G1 X102.459 Y82.698 E.01395
G1 X102.286 Y82.215 E.01248
G1 X102.213 Y81.638 E.01415
G1 X102.213 Y79.031 E.06341
G1 X102.1 Y78.432 E.01483
G1 X101.628 Y77.774 E.0197
G1 X101.498 Y77.663 E.00416
G1 X129.502 Y77.663 E.68117
G1 X129.372 Y77.774 E.00416
G1 X128.902 Y78.428 E.01959
G1 X128.787 Y79.025 E.01479
G1 X128.781 Y80.858 E.04459
G1 X128.75 Y82.043 E.02883
G1 X128.622 Y82.551 E.01274
G1 X128.364 Y83.02 E.01302
G1 X128.038 Y83.409 E.01235
G1 X127.51 Y83.779 E.01568
G1 X127.124 Y83.927 E.01006
G1 X126.62 Y84.027 E.0125
G1 X121.099 Y84.037 E.13429
G1 X121.034 Y83.955 E.00255
G1 X120.667 Y83.914 E.00898
G1 X110.333 Y83.914 E.25136
G1 X109.963 Y83.956 E.00906
G1 X109.898 Y84.037 E.00253
G1 X109.276 Y84.037 E.01513
G1 X109.276 Y84.037 F9000
G1 X109.807 Y83.742
;TYPE:Solid infill
;WIDTH:0.44124
G1 F1200
G1 X110.113 Y83.648 E.00866
;WIDTH:0.431002
G1 X110.344 Y83.628 E.00612
;WIDTH:0.42323
G1 X120.661 Y83.628 E.26689
;WIDTH:0.42264
G1 X121.118 Y83.698 E.01194
;WIDTH:0.445624
G1 X121.191 Y83.739 E.00229
G1 E-5 F3600
G1 X121.191 Y83.739 F9000
G1 X128.939 Y78.197
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X128.68 Y77.938 E.00891
G1 X128.158 Y77.938 E.0127
G1 X128.63 Y78.409 E.01622
G1 X128.546 Y78.847 E.01085
G1 X127.636 Y77.938 E.03129
G1 X127.115 Y77.938 E.01267
G1 X128.512 Y79.335 E.04806
G1 X128.51 Y79.855 E.01265
G1 X126.593 Y77.938 E.06594
G1 X126.071 Y77.938 E.0127
G1 X128.508 Y80.374 E.08381
G1 X128.506 Y80.894 E.01265
G1 X125.55 Y77.938 E.10168
G1 X125.028 Y77.938 E.0127
G1 X128.504 Y81.414 E.11957
G1 X128.491 Y81.922 E.01236
G1 X124.506 Y77.938 E.13706
G1 X123.985 Y77.938 E.01267
G1 X128.396 Y82.35 E.15175
G1 X128.239 Y82.713 E.00962
G1 X123.463 Y77.938 E.16427
G1 X122.941 Y77.938 E.0127
G1 X128.024 Y83.021 E.17485
G1 X127.761 Y83.279 E.00896
G1 X122.419 Y77.938 E.18374
G1 X121.898 Y77.938 E.01267
G1 X127.454 Y83.494 E.19112
G1 X127.089 Y83.651 E.00966
G1 X121.376 Y77.938 E.19652
G1 X120.854 Y77.938 E.0127
G1 X126.66 Y83.744 E.19972
G1 X126.148 Y83.753 E.01246
G1 X120.333 Y77.938 E.20003
G1 X119.811 Y77.938 E.0127
G1 X125.628 Y83.754 E.20008
G1 X125.107 Y83.755 E.01267
G1 X119.289 Y77.938 E.20012
G1 X118.768 Y77.938 E.01267
G1 X124.586 Y83.756 E.20014
G1 X124.065 Y83.757 E.01267
G1 X118.246 Y77.938 E.20017
G1 X117.724 Y77.938 E.0127
G1 X123.544 Y83.758 E.2002
G1 X123.024 Y83.759 E.01265
G1 X117.202 Y77.938 E.20026
G1 X116.681 Y77.938 E.01267
G1 X122.503 Y83.76 E.20027
G1 X121.982 Y83.761 E.01267
G1 X116.159 Y77.938 E.20031
G1 X115.637 Y77.938 E.0127
G1 X120.984 Y83.284 E.18392
G1 X120.429 Y83.251 E.01352
G1 X115.116 Y77.938 E.18276
G1 X114.594 Y77.938 E.0127
G1 X119.907 Y83.251 E.18276
G1 X119.385 Y83.251 E.0127
G1 X114.072 Y77.938 E.18276
G1 X113.551 Y77.938 E.01267
G1 X118.864 Y83.251 E.18276
G1 X118.342 Y83.251 E.0127
G1 X113.029 Y77.938 E.18276
G1 X112.507 Y77.938 E.0127
G1 X117.82 Y83.251 E.18276
G1 X117.299 Y83.251 E.01267
G1 X111.985 Y77.938 E.18278
G1 X111.464 Y77.938 E.01267
G1 X116.777 Y83.251 E.18276
G1 X116.255 Y83.251 E.0127
G1 X110.942 Y77.938 E.18276
G1 X110.42 Y77.938 E.0127
G1 X115.733 Y83.251 E.18276
G1 X115.212 Y83.251 E.01267
G1 X109.899 Y77.938 E.18276
G1 X109.377 Y77.938 E.0127
G1 X114.69 Y83.251 E.18276
G1 X114.168 Y83.251 E.0127
G1 X108.855 Y77.938 E.18276
G1 X108.334 Y77.938 E.01267
G1 X113.647 Y83.251 E.18276
G1 X113.125 Y83.251 E.0127
G1 X107.812 Y77.938 E.18276
G1 X107.29 Y77.938 E.0127
G1 X112.603 Y83.251 E.18276
G1 X112.082 Y83.251 E.01267
G1 X106.768 Y77.938 E.18278
G1 X106.247 Y77.938 E.01267
G1 X111.56 Y83.251 E.18276
G1 X111.038 Y83.251 E.0127
G1 X105.725 Y77.938 E.18276
G1 X105.203 Y77.938 E.0127
G1 X110.516 Y83.251 E.18276
G1 X110.021 Y83.277 E.01206
G1 X104.682 Y77.938 E.18366
G1 X104.16 Y77.938 E.0127
G1 X109.612 Y83.39 E.18755
G1 X109.278 Y83.577 E.00931
G1 X103.638 Y77.938 E.194
G1 X103.117 Y77.938 E.01267
G1 X108.942 Y83.763 E.20038
G1 X108.42 Y83.763 E.0127
G1 X102.595 Y77.938 E.20038
G1 X102.076 Y77.938 E.01262
G1 X107.899 Y83.763 E.20034
G1 X107.377 Y83.763 E.0127
G1 X102.452 Y78.838 E.16942
G1 X102.487 Y79.395 E.01358
G1 X106.855 Y83.763 E.15026
G1 X106.334 Y83.763 E.01267
G1 X102.487 Y79.916 E.13233
G1 X102.487 Y80.438 E.0127
G1 X105.812 Y83.763 E.11438
G1 X105.29 Y83.763 E.0127
G1 X102.487 Y80.96 E.09642
G1 X102.487 Y81.482 E.0127
G1 X104.768 Y83.763 E.07847
G1 X104.211 Y83.727 E.01358
G1 X102.527 Y82.044 E.05791
G1 X102.779 Y82.74 E.01801
G1 X102.964 Y83.002 E.0078
G1 X103.705 Y83.743 E.02549
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X102.964 Y83.002 E-.49777
G1 X102.779 Y82.74 E-.15235
G1 X102.527 Y82.044 E-.3516
G1 X103.269 Y82.786 E-.49828
;WIPE_END
G1 X103.99 Y85.104 F9000
G1 X104.455 Y86.599
G1 X105.067 Y88.151
G1 X105.067 Y88.566
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.151 Y88.503 E.00255
G1 X125.817 Y88.5 E.50268
G1 X125.96 Y88.569 E.00386
G1 X126 Y88.683 E.00294
G1 X126 Y88.964 E.00684
G1 X127.661 Y90.36 E.05278
G1 X127.724 Y90.468 E.00304
G1 X127.661 Y90.64 E.00446
G1 X126 Y92.036 E.05278
G1 X126 Y92.515 E.01165
G1 X139.202 Y92.516 E.32113
G1 X139.589 Y92.64 E.00988
G1 X139.825 Y92.911 E.00874
G1 X139.9 Y93.216 E.00764
G1 X139.9 Y95.613 E.0583
G1 X139.845 Y95.881 E.00665
G1 X139.714 Y96.085 E.0059
G1 X139.512 Y96.235 E.00612
G1 X139.241 Y96.31 E.00684
G1 X136.7 Y96.313 E.06181
G1 X136.7 Y102.497 E.15042
G1 X139.202 Y102.499 E.06086
G1 X139.5 Y102.586 E.00755
G1 X139.767 Y102.854 E.0092
G1 X139.869 Y103.128 E.00711
G1 X139.9 Y103.454 E.00797
G1 X139.9 Y104.546 E.02656
G1 X139.857 Y104.921 E.00918
G1 X139.732 Y105.202 E.00748
G1 X139.539 Y105.394 E.00662
G1 X139.291 Y105.492 E.00649
G1 X136.7 Y105.502 E.06302
G1 X136.7 Y110.497 E.1215
G1 X139.202 Y110.499 E.06086
G1 X139.5 Y110.586 E.00755
G1 X139.767 Y110.854 E.0092
G1 X139.869 Y111.128 E.00711
G1 X139.9 Y111.454 E.00797
G1 X139.9 Y112.546 E.02656
G1 X139.857 Y112.921 E.00918
G1 X139.732 Y113.202 E.00748
G1 X139.539 Y113.394 E.00662
G1 X139.291 Y113.492 E.00649
G1 X136.7 Y113.502 E.06302
G1 X136.7 Y118.497 E.1215
G1 X139.202 Y118.499 E.06086
G1 X139.5 Y118.586 E.00755
G1 X139.767 Y118.854 E.0092
G1 X139.869 Y119.128 E.00711
G1 X139.9 Y119.454 E.00797
G1 X139.9 Y120.546 E.02656
G1 X139.857 Y120.921 E.00918
G1 X139.732 Y121.202 E.00748
G1 X139.539 Y121.394 E.00662
G1 X139.291 Y121.492 E.00649
G1 X136.7 Y121.502 E.06302
G1 X136.7 Y126.497 E.1215
G1 X139.201 Y126.499 E.06083
G1 X139.52 Y126.599 E.00813
G1 X139.732 Y126.797 E.00706
G1 X139.892 Y127.289 E.01258
G1 X139.892 Y128.711 E.03459
G1 X139.732 Y129.202 E.01256
G1 X139.539 Y129.394 E.00662
G1 X139.291 Y129.492 E.00649
G1 X136.7 Y129.502 E.06302
G1 X136.691 Y132.998 E.08504
G1 X136.612 Y133.93 E.02275
G1 X136.515 Y134.498 E.01402
G1 X139.201 Y134.499 E.06533
G1 X139.52 Y134.599 E.00813
G1 X139.732 Y134.797 E.00706
G1 X139.892 Y135.288 E.01256
G1 X139.9 Y136.546 E.0306
G1 X139.857 Y136.921 E.00918
G1 X139.721 Y137.213 E.00784
G1 X139.43 Y137.453 E.00918
G1 X139.256 Y137.497 E.00437
G1 X135.439 Y137.502 E.09284
G1 X135.013 Y138.219 E.02029
G1 X134.61 Y138.785 E.0169
G1 X134.144 Y139.354 E.01789
G1 X133.647 Y139.877 E.01755
G1 X132.936 Y140.513 E.0232
G1 X131.804 Y141.312 E.0337
G1 X130.716 Y141.906 E.03015
G1 X130.408 Y142.148 E.00953
G1 X130.268 Y142.295 E.00494
G1 X130.21 Y142.435 E.00369
G1 X130.677 Y142.497 E.01146
G1 X139.291 Y142.508 E.20953
G1 X139.595 Y142.648 E.00814
G1 X139.767 Y142.854 E.00653
G1 X139.869 Y143.128 E.00711
G1 X139.9 Y143.454 E.00797
G1 X139.9 Y144.546 E.02656
G1 X139.857 Y144.921 E.00918
G1 X139.732 Y145.202 E.00748
G1 X139.521 Y145.4 E.00704
G1 X139.202 Y145.501 E.00814
G1 X125.554 Y145.502 E.33197
G1 X125.415 Y145.439 E.00371
G1 X125.371 Y145.32 E.00309
G1 X125.365 Y143.076 E.05458
G1 X125.285 Y142.926 E.00414
G1 X125.018 Y142.819 E.007
G1 X124.768 Y142.8 E.0061
G1 X120.483 Y142.8 E.10423
G1 X120.406 Y142.783 E.00192
G1 X120.272 Y142.589 E.00574
G1 X110.7 Y142.589 E.23283
G1 X110.594 Y142.783 E.00538
G1 X106.208 Y142.8 E.10669
G1 X105.903 Y142.825 E.00744
G1 X105.713 Y142.927 E.00525
G1 X105.637 Y143.064 E.00381
G1 X105.629 Y145.32 E.05488
G1 X105.567 Y145.457 E.00366
G1 X105.445 Y145.502 E.00316
G1 X91.798 Y145.501 E.33195
G1 X91.5 Y145.414 E.00755
G1 X91.228 Y145.132 E.00953
G1 X91.108 Y144.711 E.01065
G1 X91.108 Y143.289 E.03459
G1 X91.268 Y142.798 E.01256
G1 X91.461 Y142.606 E.00662
G1 X91.709 Y142.508 E.00649
G1 X100.468 Y142.497 E.21305
G1 X100.79 Y142.431 E.008
G1 X100.707 Y142.261 E.0046
G1 X100.465 Y142.029 E.00815
G1 X100.249 Y141.886 E.0063
G1 X99.214 Y141.324 E.02865
G1 X98.06 Y140.51 E.03435
G1 X97.364 Y139.888 E.0227
G1 X96.865 Y139.363 E.01762
G1 X96.397 Y138.795 E.0179
G1 X95.995 Y138.231 E.01685
G1 X95.561 Y137.502 E.02064
G1 X91.744 Y137.497 E.09284
G1 X91.511 Y137.424 E.00594
G1 X91.303 Y137.243 E.00671
G1 X91.131 Y136.872 E.00995
G1 X91.1 Y136.545 E.00799
G1 X91.108 Y135.288 E.03058
G1 X91.203 Y134.922 E.0092
G1 X91.48 Y134.599 E.01035
G1 X91.799 Y134.499 E.00813
G1 X94.485 Y134.498 E.06533
G1 X94.389 Y133.943 E.0137
G1 X94.309 Y133.005 E.0229
G1 X94.3 Y129.5 E.08526
G1 X91.709 Y129.492 E.06302
G1 X91.405 Y129.352 E.00814
G1 X91.233 Y129.146 E.00653
G1 X91.131 Y128.872 E.00711
G1 X91.1 Y128.546 E.00797
G1 X91.1 Y127.454 E.02656
G1 X91.143 Y127.079 E.00918
G1 X91.268 Y126.798 E.00748
G1 X91.479 Y126.6 E.00704
G1 X91.798 Y126.499 E.00814
G1 X94.3 Y126.497 E.06086
G1 X94.3 Y121.502 E.1215
G1 X91.709 Y121.492 E.06302
G1 X91.405 Y121.352 E.00814
G1 X91.233 Y121.146 E.00653
G1 X91.131 Y120.872 E.00711
G1 X91.1 Y120.546 E.00797
G1 X91.1 Y119.454 E.02656
G1 X91.143 Y119.079 E.00918
G1 X91.268 Y118.798 E.00748
G1 X91.479 Y118.6 E.00704
G1 X91.798 Y118.499 E.00814
G1 X94.3 Y118.497 E.06086
G1 X94.3 Y113.503 E.12147
G1 X91.798 Y113.501 E.06086
G1 X91.5 Y113.414 E.00755
G1 X91.233 Y113.146 E.0092
G1 X91.131 Y112.872 E.00711
G1 X91.1 Y112.546 E.00797
G1 X91.1 Y111.454 E.02656
G1 X91.131 Y111.128 E.00797
G1 X91.268 Y110.798 E.00869
G1 X91.461 Y110.606 E.00662
G1 X91.709 Y110.508 E.00649
G1 X94.3 Y110.498 E.06302
G1 X94.3 Y105.503 E.1215
G1 X91.798 Y105.501 E.06086
G1 X91.5 Y105.414 E.00755
G1 X91.233 Y105.146 E.0092
G1 X91.131 Y104.872 E.00711
G1 X91.1 Y104.546 E.00797
G1 X91.1 Y103.454 E.02656
G1 X91.143 Y103.079 E.00918
G1 X91.268 Y102.798 E.00748
G1 X91.461 Y102.606 E.00662
G1 X91.709 Y102.508 E.00649
G1 X94.3 Y102.498 E.06302
G1 X94.3 Y96.313 E.15044
G1 X91.798 Y96.312 E.06086
G1 X91.532 Y96.256 E.00661
G1 X91.318 Y96.114 E.00625
G1 X91.134 Y95.821 E.00842
G1 X91.1 Y95.613 E.00513
G1 X91.108 Y93.126 E.06049
G1 X91.212 Y92.84 E.0074
G1 X91.376 Y92.662 E.00589
G1 X91.591 Y92.55 E.0059
G1 X91.798 Y92.516 E.0051
G1 X105 Y92.515 E.32113
G1 X105 Y92.036 E.01165
G1 X103.339 Y90.64 E.05278
G1 X103.276 Y90.468 E.00446
G1 X103.339 Y90.36 E.00304
G1 X105 Y88.964 E.05278
G1 X105.018 Y88.603 E.00879
G1 X105.018 Y88.603 F9000
G1 X104.797 Y88.302
;TYPE:Perimeter
G1 F6000
G1 X104.821 Y88.27 E.00097
G1 X105.088 Y88.143 E.00719
G1 X105.183 Y88.134 E.00232
G1 X125.817 Y88.134 E.5019
G1 X126.066 Y88.194 E.00623
G1 X126.288 Y88.402 E.0074
G1 X126.366 Y88.683 E.00709
G1 X126.366 Y88.794 E.0027
G1 X127.896 Y90.08 E.04862
G1 X128.035 Y90.257 E.00547
G1 X128.084 Y90.403 E.00375
G1 X128.076 Y90.634 E.00562
G1 X127.896 Y90.92 E.00822
G1 X126.433 Y92.15 E.04649
G1 X139.202 Y92.15 E.31059
G1 X139.603 Y92.24 E.01
G1 X139.848 Y92.381 E.00688
G1 X140.037 Y92.571 E.00652
;WIDTH:0.440492
G1 X140.109 Y92.691 E.00378
;WIDTH:0.480985
G1 X140.181 Y92.812 E.00418
;WIDTH:0.521478
G1 X140.254 Y92.933 E.00458
;WIDTH:0.561971
G1 X140.326 Y93.053 E.00491
G1 X140.34 Y93.216 E.00574
;WIDTH:0.547032
G1 X140.34 Y95.613 E.08175
;WIDTH:0.569345
G1 X140.31 Y95.899 E.01023
G1 X140.22 Y96.015 E.00523
;WIDTH:0.527009
G1 X140.13 Y96.132 E.00484
;WIDTH:0.484672
G1 X140.039 Y96.249 E.00444
;WIDTH:0.442336
G1 X139.949 Y96.365 E.00398
;WIDTH:0.399999
G1 X139.62 Y96.585 E.00963
G1 X139.241 Y96.676 E.00948
G1 X137.066 Y96.678 E.0529
G1 X137.066 Y102.132 E.13266
G1 X139.202 Y102.134 E.05196
G1 X139.497 Y102.186 E.00729
G1 X139.746 Y102.316 E.00683
G1 X139.966 Y102.515 E.00722
G1 X140.107 Y102.719 E.00603
G1 X140.197 Y102.944 E.00589
;WIDTH:0.441302
G1 X140.226 Y102.979 E.00123
;WIDTH:0.482605
G1 X140.256 Y103.014 E.00137
;WIDTH:0.523908
G1 X140.285 Y103.049 E.00148
;WIDTH:0.56521
G1 X140.315 Y103.084 E.00163
G1 X140.34 Y103.454 E.0131
;WIDTH:0.547941
G1 X140.34 Y104.546 E.03731
;WIDTH:0.569951
G1 X140.311 Y104.963 E.01489
G1 X140.282 Y104.986 E.00132
;WIDTH:0.527463
G1 X140.254 Y105.01 E.00121
;WIDTH:0.484975
G1 X140.225 Y105.033 E.00111
;WIDTH:0.442487
G1 X140.197 Y105.056 E.00098
;WIDTH:0.399999
G1 X140.002 Y105.449 E.01067
G1 X139.695 Y105.724 E.01003
G1 X139.293 Y105.857 E.0103
G1 X137.066 Y105.866 E.05417
G1 X137.066 Y110.132 E.10377
G1 X139.202 Y110.134 E.05196
G1 X139.497 Y110.186 E.00729
G1 X139.746 Y110.316 E.00683
G1 X139.966 Y110.515 E.00722
G1 X140.107 Y110.719 E.00603
G1 X140.197 Y110.944 E.00589
;WIDTH:0.441456
G1 X140.226 Y110.979 E.00123
;WIDTH:0.482912
G1 X140.256 Y111.014 E.00138
;WIDTH:0.524369
G1 X140.285 Y111.049 E.00148
;WIDTH:0.565825
G1 X140.315 Y111.084 E.00163
G1 X140.34 Y111.454 E.01311
;WIDTH:0.548555
G1 X140.34 Y112.546 E.03735
;WIDTH:0.570569
G1 X140.311 Y112.963 E.01491
G1 X140.282 Y112.986 E.00132
;WIDTH:0.527927
G1 X140.254 Y113.01 E.00121
;WIDTH:0.485284
G1 X140.225 Y113.033 E.00111
;WIDTH:0.442642
G1 X140.197 Y113.056 E.00098
;WIDTH:0.399999
G1 X140.002 Y113.449 E.01067
G1 X139.695 Y113.724 E.01003
G1 X139.293 Y113.857 E.0103
G1 X137.066 Y113.866 E.05417
G1 X137.066 Y118.132 E.10377
G1 X139.202 Y118.134 E.05196
G1 X139.497 Y118.186 E.00729
G1 X139.746 Y118.316 E.00683
G1 X139.966 Y118.515 E.00722
G1 X140.107 Y118.719 E.00603
G1 X140.197 Y118.944 E.00589
;WIDTH:0.44161
G1 X140.226 Y118.979 E.00123
;WIDTH:0.48322
G1 X140.256 Y119.014 E.00138
;WIDTH:0.524831
G1 X140.286 Y119.049 E.0015
;WIDTH:0.566441
G1 X140.315 Y119.084 E.00161
G1 X140.34 Y119.454 E.01313
;WIDTH:0.549168
G1 X140.34 Y120.546 E.0374
;WIDTH:0.571187
G1 X140.311 Y120.963 E.01493
G1 X140.283 Y120.986 E.00129
;WIDTH:0.52839
G1 X140.254 Y121.01 E.00124
;WIDTH:0.485593
G1 X140.225 Y121.033 E.00111
;WIDTH:0.442796
G1 X140.197 Y121.056 E.00098
;WIDTH:0.399999
G1 X140.002 Y121.449 E.01067
G1 X139.695 Y121.724 E.01003
G1 X139.293 Y121.857 E.0103
G1 X137.066 Y121.866 E.05417
G1 X137.066 Y126.132 E.10377
G1 X139.201 Y126.134 E.05193
G1 X139.639 Y126.253 E.01104
G1 X139.865 Y126.401 E.00657
;WIDTH:0.404695
G1 X140.124 Y126.76 E.01091
;WIDTH:0.446838
G1 X140.172 Y126.845 E.00268
;WIDTH:0.48898
G1 X140.22 Y126.931 E.00298
;WIDTH:0.531122
G1 X140.269 Y127.017 E.00327
;WIDTH:0.573264
G1 X140.317 Y127.103 E.00353
G1 X140.335 Y127.289 E.0067
;WIDTH:0.553593
G1 X140.335 Y128.711 E.04912
G1 X140.29 Y128.887 E.00627
;WIDTH:0.51599
G1 X140.194 Y129.075 E.00676
;WIDTH:0.477327
G1 X140.098 Y129.262 E.00619
;WIDTH:0.438663
G1 X140.002 Y129.449 E.00565
;WIDTH:0.399999
G1 X139.695 Y129.724 E.01003
G1 X139.293 Y129.857 E.0103
G1 X137.064 Y129.866 E.05422
G1 X137.057 Y132.999 E.07621
G1 X136.949 Y134.133 E.02771
G1 X139.201 Y134.134 E.05478
G1 X139.639 Y134.253 E.01104
G1 X139.865 Y134.401 E.00657
;WIDTH:0.404739
G1 X140.124 Y134.76 E.01091
;WIDTH:0.447029
G1 X140.172 Y134.845 E.00268
;WIDTH:0.489319
G1 X140.22 Y134.931 E.00298
;WIDTH:0.531609
G1 X140.269 Y135.017 E.00327
;WIDTH:0.573899
G1 X140.317 Y135.103 E.00353
G1 X140.335 Y135.285 E.00656
;WIDTH:0.554112
G1 X140.341 Y136.546 E.0436
;WIDTH:0.572424
G1 X140.312 Y136.963 E.01496
G1 X140.283 Y136.986 E.00132
;WIDTH:0.529318
G1 X140.254 Y137.01 E.00124
;WIDTH:0.486212
G1 X140.225 Y137.033 E.00111
;WIDTH:0.443106
G1 X140.197 Y137.056 E.00099
;WIDTH:0.399999
G1 X140.107 Y137.281 E.00589
G1 X139.968 Y137.483 E.00596
G1 X139.749 Y137.683 E.00721
G1 X139.411 Y137.84 E.00907
G1 X138.791 Y137.863 E.01509
G1 X135.648 Y137.867 E.07645
G1 X135.327 Y138.406 E.01526
G1 X134.908 Y138.997 E.01762
G1 X134.426 Y139.586 E.01851
G1 X133.912 Y140.129 E.01819
G1 X133.147 Y140.811 E.02493
G1 X132.015 Y141.611 E.03372
G1 X131.065 Y142.132 E.02635
G1 X139.291 Y142.143 E.20009
G1 X139.695 Y142.276 E.01035
G1 X140.002 Y142.551 E.01003
;WIDTH:0.442071
G1 X140.081 Y142.684 E.0042
;WIDTH:0.484142
G1 X140.159 Y142.818 E.00464
;WIDTH:0.526213
G1 X140.238 Y142.951 E.00506
;WIDTH:0.568284
G1 X140.316 Y143.084 E.00548
G1 X140.341 Y143.454 E.01317
;WIDTH:0.551009
G1 X140.341 Y144.546 E.03753
;WIDTH:0.573042
G1 X140.312 Y144.963 E.01498
G1 X140.283 Y144.987 E.00135
;WIDTH:0.529782
G1 X140.254 Y145.01 E.00122
;WIDTH:0.486521
G1 X140.225 Y145.033 E.00111
;WIDTH:0.44326
G1 X140.197 Y145.056 E.00099
;WIDTH:0.399999
G1 X140.002 Y145.449 E.01067
G1 X139.866 Y145.598 E.00491
G1 X139.641 Y145.746 E.00655
G1 X139.202 Y145.866 E.01107
G1 X125.554 Y145.868 E.33197
G1 X125.278 Y145.794 E.00695
G1 X125.078 Y145.592 E.00691
G1 X125.005 Y145.321 E.00683
G1 X125 Y143.188 E.05188
G1 X124.768 Y143.166 E.00567
G1 X120.483 Y143.166 E.10423
G1 X120.251 Y143.114 E.00578
G1 X120.149 Y142.955 E.00459
G1 X110.851 Y142.955 E.22616
G1 X110.749 Y143.114 E.00459
G1 X110.517 Y143.166 E.00578
G1 X106.223 Y143.166 E.10445
G1 X106.002 Y143.193 E.00542
G1 X105.995 Y145.321 E.05176
G1 X105.922 Y145.592 E.00683
G1 X105.722 Y145.794 E.00691
G1 X105.445 Y145.868 E.00697
G1 X91.798 Y145.866 E.33195
G1 X91.503 Y145.814 E.00729
G1 X91.254 Y145.684 E.00683
G1 X91.034 Y145.485 E.00722
;WIDTH:0.437996
G1 X90.926 Y145.286 E.00608
;WIDTH:0.475992
G1 X90.819 Y145.086 E.00666
;WIDTH:0.513988
G1 X90.711 Y144.887 E.00722
;WIDTH:0.550488
G1 X90.667 Y144.711 E.00623
;WIDTH:0.550594
G1 X90.667 Y143.289 E.04883
;WIDTH:0.570194
G1 X90.684 Y143.105 E.00659
G1 X90.763 Y142.966 E.0057
;WIDTH:0.527646
G1 X90.841 Y142.828 E.0052
;WIDTH:0.485097
G1 X90.92 Y142.689 E.00479
;WIDTH:0.442548
G1 X90.998 Y142.551 E.0043
;WIDTH:0.399999
G1 X91.305 Y142.276 E.01003
G1 X91.709 Y142.143 E.01035
G1 X99.936 Y142.132 E.20011
G1 X99.04 Y141.645 E.02481
G1 X98.614 Y141.374 E.01228
G1 X97.843 Y140.804 E.02332
G1 X97.12 Y140.16 E.02355
G1 X96.6 Y139.615 E.01832
G1 X96.115 Y139.027 E.01854
G1 X95.697 Y138.443 E.01747
G1 X95.353 Y137.867 E.01632
G1 X91.743 Y137.863 E.08781
G1 X91.466 Y137.804 E.00689
G1 X91.137 Y137.6 E.00942
G1 X90.975 Y137.406 E.00615
;WIDTH:0.402401
G1 X90.821 Y137.099 E.00841
;WIDTH:0.442963
G1 X90.787 Y137.053 E.00155
;WIDTH:0.483524
G1 X90.753 Y137.007 E.00171
;WIDTH:0.524086
G1 X90.719 Y136.961 E.00186
;WIDTH:0.564647
G1 X90.685 Y136.916 E.00199
G1 X90.661 Y136.542 E.01322
;WIDTH:0.551204
G1 X90.666 Y135.285 E.04322
;WIDTH:0.562823
G1 X90.677 Y135.146 E.0049
G1 X90.782 Y134.971 E.00717
;WIDTH:0.522117
G1 X90.887 Y134.797 E.00659
;WIDTH:0.481411
G1 X90.992 Y134.622 E.00607
;WIDTH:0.440705
G1 X91.097 Y134.448 E.00549
;WIDTH:0.399999
G1 X91.361 Y134.253 E.00798
G1 X91.799 Y134.134 E.01104
G1 X94.051 Y134.133 E.05478
G1 X93.945 Y133.036 E.02681
G1 X93.936 Y129.865 E.07713
G1 X91.707 Y129.857 E.05422
G1 X91.305 Y129.724 E.0103
G1 X90.998 Y129.449 E.01003
G1 X90.803 Y129.056 E.01067
;WIDTH:0.442463
G1 X90.775 Y129.033 E.00098
;WIDTH:0.484927
G1 X90.746 Y129.01 E.00111
;WIDTH:0.527391
G1 X90.718 Y128.986 E.00121
;WIDTH:0.569855
G1 X90.689 Y128.963 E.00132
G1 X90.66 Y128.546 E.01489
;WIDTH:0.547974
G1 X90.66 Y127.454 E.03731
;WIDTH:0.565386
G1 X90.685 Y127.084 E.0131
G1 X90.715 Y127.049 E.00163
;WIDTH:0.52404
G1 X90.744 Y127.014 E.00148
;WIDTH:0.482693
G1 X90.774 Y126.979 E.00137
;WIDTH:0.441346
G1 X90.803 Y126.944 E.00123
;WIDTH:0.399999
G1 X90.998 Y126.551 E.01067
G1 X91.134 Y126.402 E.00491
G1 X91.359 Y126.254 E.00655
G1 X91.798 Y126.134 E.01107
G1 X93.934 Y126.132 E.05196
G1 X93.934 Y121.866 E.10377
G1 X91.707 Y121.857 E.05417
G1 X91.305 Y121.724 E.0103
G1 X90.998 Y121.449 E.01003
G1 X90.803 Y121.056 E.01067
;WIDTH:0.442613
G1 X90.775 Y121.033 E.00098
;WIDTH:0.485227
G1 X90.746 Y121.01 E.00111
;WIDTH:0.527841
G1 X90.718 Y120.986 E.00121
;WIDTH:0.570454
G1 X90.689 Y120.963 E.00132
G1 X90.66 Y120.546 E.01491
;WIDTH:0.54857
G1 X90.66 Y119.454 E.03735
;WIDTH:0.565983
G1 X90.685 Y119.084 E.01311
G1 X90.714 Y119.049 E.00161
;WIDTH:0.524487
G1 X90.744 Y119.014 E.0015
;WIDTH:0.482991
G1 X90.774 Y118.979 E.00138
;WIDTH:0.441495
G1 X90.803 Y118.944 E.00123
;WIDTH:0.399999
G1 X90.998 Y118.551 E.01067
G1 X91.134 Y118.402 E.00491
G1 X91.359 Y118.254 E.00655
G1 X91.798 Y118.134 E.01107
G1 X93.934 Y118.132 E.05196
G1 X93.934 Y113.868 E.10372
G1 X91.798 Y113.866 E.05196
G1 X91.503 Y113.814 E.00729
G1 X91.254 Y113.684 E.00683
G1 X91.034 Y113.485 E.00722
G1 X90.893 Y113.281 E.00603
G1 X90.803 Y113.056 E.00589
;WIDTH:0.442763
G1 X90.775 Y113.033 E.00098
;WIDTH:0.485527
G1 X90.746 Y113.01 E.00111
;WIDTH:0.528291
G1 X90.717 Y112.987 E.00122
;WIDTH:0.571055
G1 X90.689 Y112.963 E.00132
G1 X90.66 Y112.546 E.01492
;WIDTH:0.549165
G1 X90.66 Y111.454 E.0374
;WIDTH:0.56658
G1 X90.685 Y111.084 E.01313
G1 X90.714 Y111.049 E.00161
;WIDTH:0.524935
G1 X90.744 Y111.014 E.0015
;WIDTH:0.48329
G1 X90.774 Y110.979 E.00138
;WIDTH:0.441645
G1 X90.803 Y110.944 E.00123
;WIDTH:0.399999
G1 X90.998 Y110.551 E.01067
G1 X91.305 Y110.276 E.01003
G1 X91.707 Y110.143 E.0103
G1 X93.934 Y110.134 E.05417
G1 X93.934 Y105.868 E.10377
G1 X91.798 Y105.866 E.05196
G1 X91.503 Y105.814 E.00729
G1 X91.254 Y105.684 E.00683
G1 X91.034 Y105.485 E.00722
G1 X90.893 Y105.281 E.00603
G1 X90.803 Y105.056 E.00589
;WIDTH:0.442913
G1 X90.775 Y105.033 E.00098
;WIDTH:0.485826
G1 X90.746 Y105.01 E.00111
;WIDTH:0.52874
G1 X90.717 Y104.987 E.00122
;WIDTH:0.571653
G1 X90.688 Y104.963 E.00135
G1 X90.659 Y104.546 E.01494
;WIDTH:0.54976
G1 X90.659 Y103.454 E.03744
;WIDTH:0.567176
G1 X90.684 Y103.084 E.01314
G1 X90.714 Y103.049 E.00163
;WIDTH:0.525382
G1 X90.744 Y103.014 E.00151
;WIDTH:0.483588
G1 X90.774 Y102.979 E.00138
;WIDTH:0.441794
G1 X90.803 Y102.944 E.00123
;WIDTH:0.399999
G1 X90.998 Y102.551 E.01067
G1 X91.305 Y102.276 E.01003
G1 X91.707 Y102.143 E.0103
G1 X93.934 Y102.134 E.05417
G1 X93.934 Y96.679 E.13269
G1 X91.798 Y96.678 E.05196
G1 X91.526 Y96.638 E.00669
G1 X91.194 Y96.484 E.0089
G1 X91.019 Y96.324 E.00577
;WIDTH:0.443157
G1 X90.937 Y96.218 E.00364
;WIDTH:0.486314
G1 X90.854 Y96.112 E.00405
;WIDTH:0.529472
G1 X90.771 Y96.005 E.00446
;WIDTH:0.572629
G1 X90.689 Y95.899 E.0048
G1 X90.659 Y95.611 E.01037
;WIDTH:0.554334
G1 X90.665 Y93.124 E.08603
G1 X90.732 Y92.994 E.00506
;WIDTH:0.515751
G1 X90.798 Y92.865 E.00464
;WIDTH:0.477167
G1 X90.865 Y92.735 E.00431
;WIDTH:0.438583
G1 X90.932 Y92.605 E.00393
;WIDTH:0.399999
G1 X91.193 Y92.345 E.00896
G1 X91.526 Y92.19 E.00893
G1 X91.798 Y92.15 E.00669
G1 X104.567 Y92.15 E.31059
G1 X103.104 Y90.92 E.04649
G1 X102.924 Y90.633 E.00824
G1 X102.917 Y90.403 E.0056
G1 X103.027 Y90.159 E.00651
G1 X104.634 Y88.794 E.05129
G1 X104.69 Y88.443 E.00865
G1 X104.761 Y88.349 E.00287
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X104.797 Y88.302 E-.02812
G1 X104.821 Y88.27 E-.019
G1 X105.088 Y88.143 E-.14044
G1 X105.183 Y88.134 E-.04533
G1 X107.851 Y88.134 E-1.26711
;WIPE_END
G1 X107.851 Y88.151 F9000
G1 X110.639 Y86.599
G1 X110.639 Y86.185
G1 E5 F2400
G1 F6000
G1 X110.622 Y86.217 E.00088
G1 X110.517 Y86.25 E.00268
G1 X104.199 Y86.25 E.15368
G1 X103.636 Y86.211 E.01373
G1 X103.07 Y86.094 E.01406
G1 X102.315 Y85.802 E.01969
G1 X101.593 Y85.341 E.02084
G1 X100.967 Y84.729 E.02129
G1 X100.517 Y84.065 E.01951
G1 X100.173 Y83.237 E.02181
G1 X100.013 Y82.361 E.02166
G1 X100.007 Y81.422 E.02284
G1 X100 Y79.036 E.05804
G1 X98.339 Y77.64 E.05278
G1 X98.274 Y77.51 E.00354
G1 X98.339 Y77.36 E.00398
G1 X100 Y75.964 E.05278
G1 X100.006 Y75.687 E.00674
G1 X100.061 Y75.599 E.00252
G1 X100.183 Y75.553 E.00317
G1 X130.817 Y75.553 E.74514
G1 X130.939 Y75.599 E.00317
G1 X131 Y75.735 E.00363
G1 X131 Y75.964 E.00557
G1 X132.661 Y77.36 E.05278
G1 X132.726 Y77.507 E.00391
G1 X132.661 Y77.64 E.0036
G1 X131 Y79.036 E.05278
G1 X131 Y82.051 E.07334
G1 X130.96 Y82.623 E.01395
G1 X130.854 Y83.14 E.01284
G1 X130.544 Y83.948 E.02105
G1 X130.057 Y84.699 E.02177
G1 X129.655 Y85.13 E.01434
G1 X129.264 Y85.448 E.01226
G1 X128.504 Y85.887 E.02135
G1 X127.68 Y86.156 E.02108
G1 X127.102 Y86.239 E.0142
G1 X120.483 Y86.25 E.161
G1 X120.378 Y86.217 E.00268
G1 X120.3 Y86.067 E.00411
G1 X120.3 Y85.989 E.0019
G1 X110.7 Y85.989 E.23351
G1 X110.7 Y86.067 E.0019
G1 X110.666 Y86.132 E.00178
G1 X110.666 Y86.132 F9000
G1 X110.881 Y86.423
;TYPE:Perimeter
G1 F6000
G1 X110.832 Y86.516 E.00256
G1 X110.517 Y86.616 E.00804
G1 X104.199 Y86.616 E.15368
G1 X103.611 Y86.576 E.01434
G1 X102.995 Y86.452 E.01528
G1 X102.118 Y86.11 E.0229
G1 X101.397 Y85.65 E.0208
G1 X100.711 Y84.989 E.02317
G1 X100.214 Y84.269 E.02128
G1 X99.835 Y83.376 E.0236
G1 X99.653 Y82.425 E.02355
G1 X99.642 Y81.423 E.02437
G1 X99.635 Y79.207 E.0539
G1 X98.104 Y77.92 E.04865
G1 X97.947 Y77.702 E.00653
G1 X97.912 Y77.435 E.00655
G1 X97.963 Y77.26 E.00443
G1 X98.104 Y77.08 E.00556
G1 X99.634 Y75.794 E.04862
G1 X99.654 Y75.591 E.00496
G1 X99.817 Y75.327 E.00755
;WIDTH:0.44294
G1 X99.904 Y75.262 E.00295
;WIDTH:0.485881
G1 X99.99 Y75.197 E.00324
;WIDTH:0.528821
G1 X100.077 Y75.132 E.00357
G1 X100.183 Y75.126 E.00349
;WIDTH:0.522394
G1 X130.817 Y75.126 E.99456
G1 X130.939 Y75.193 E.00452
;WIDTH:0.481596
G1 X131.061 Y75.26 E.00414
;WIDTH:0.440798
G1 X131.183 Y75.327 E.00376
;WIDTH:0.399999
G1 X131.346 Y75.591 E.00755
G1 X131.366 Y75.794 E.00496
G1 X132.896 Y77.08 E.04862
G1 X133.037 Y77.26 E.00556
G1 X133.092 Y77.522 E.00651
G1 X133.012 Y77.785 E.00669
G1 X132.896 Y77.92 E.00433
G1 X131.366 Y79.206 E.04862
G1 X131.366 Y82.051 E.0692
G1 X131.324 Y82.649 E.01458
G1 X131.22 Y83.184 E.01326
G1 X130.886 Y84.079 E.02324
G1 X130.363 Y84.9 E.02368
G1 X129.921 Y85.381 E.01589
G1 X129.494 Y85.732 E.01345
G1 X128.686 Y86.204 E.02276
G1 X127.792 Y86.504 E.02294
G1 X127.152 Y86.601 E.01575
G1 X120.483 Y86.616 E.16222
G1 X120.168 Y86.516 E.00804
G1 X120.084 Y86.354 E.00444
G1 X110.916 Y86.354 E.223
G1 X110.908 Y86.37 E.00044
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X110.881 Y86.423 E-.02825
G1 X110.832 Y86.516 E-.04993
G1 X110.517 Y86.616 E-.15698
G1 X107.854 Y86.616 E-1.26484
;WIPE_END
G1 X107.854 Y86.599 F9000
G1 X91.441 Y92.229
G1 X91.275 Y92.306
G1 X91.125 Y92.411
G1 X90.995 Y92.541
G1 X90.89 Y92.691
G1 X90.813 Y92.857
G1 X90.765 Y93.034
G1 X90.751 Y93.193
G1 X90.751 Y144.557
G1 X90.758 Y144.703
G1 X90.761 Y144.767
G1 X90.795 Y144.977
G1 X90.856 Y145.168
G1 X90.948 Y145.359
G1 X91.073 Y145.522
G1 X91.22 Y145.656
G1 X91.394 Y145.761
G1 X91.579 Y145.826
G1 X91.685 Y145.843
G1 X91.781 Y145.849
G1 X95.968 Y145.85
G1 X105.736 Y145.851
G1 X105.568 Y150.149
G1 X105.568 Y150.554
G1 E5 F2400
G1 F6000
G1 X105.585 Y150.561 E.00045
G1 X105.624 Y150.635 E.00203
G1 X105.629 Y153.319 E.06529
G1 X105.593 Y153.429 E.00282
G1 X105.447 Y153.502 E.00397
G1 X91.798 Y153.501 E.332
G1 X91.512 Y153.424 E.0072
G1 X91.303 Y153.243 E.00673
G1 X91.131 Y152.872 E.00995
G1 X91.1 Y152.235 E.01551
G1 X91.1 Y151.454 E.019
G1 X91.15 Y151.065 E.00954
G1 X91.372 Y150.682 E.01077
G1 X91.71 Y150.508 E.00925
G1 X105.447 Y150.498 E.33414
G1 X105.513 Y150.529 E.00177
G1 X105.513 Y150.529 F9000
G1 X105.821 Y150.306
;TYPE:Perimeter
G1 F6000
G1 X105.922 Y150.408 E.00349
G1 X105.978 Y150.544 E.00358
G1 X105.995 Y150.681 E.00336
G1 X105.995 Y153.319 E.06417
G1 X105.973 Y153.473 E.00378
G1 X105.885 Y153.648 E.00476
G1 X105.705 Y153.803 E.00578
G1 X105.446 Y153.868 E.0065
G1 X91.798 Y153.866 E.33197
G1 X91.502 Y153.814 E.00731
G1 X91.293 Y153.715 E.00563
;WIDTH:0.397037
G1 X91.008 Y153.433 E.00967
;WIDTH:0.37869
G1 X90.778 Y152.907 E.01315
;WIDTH:0.427244
G1 X90.737 Y152.571 E.00885
;WIDTH:0.475797
G1 X90.696 Y152.235 E.00994
;WIDTH:0.504898
G1 X90.682 Y151.845 E.01222
;WIDTH:0.533998
G1 X90.667 Y151.454 E.01301
;WIDTH:0.563596
G1 X90.686 Y151.084 E.01304
G1 X90.758 Y150.962 E.00499
;WIDTH:0.522697
G1 X90.831 Y150.839 E.00465
;WIDTH:0.481798
G1 X90.903 Y150.717 E.00422
;WIDTH:0.440899
G1 X90.975 Y150.594 E.00385
;WIDTH:0.399999
G1 X91.182 Y150.37 E.00742
G1 X91.425 Y150.222 E.00692
G1 X91.709 Y150.143 E.00717
G1 X105.446 Y150.132 E.33414
G1 X105.722 Y150.206 E.00695
G1 X105.779 Y150.264 E.00198
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X105.821 Y150.306 E-.02821
G1 X105.922 Y150.408 E-.06818
G1 X105.978 Y150.544 E-.06986
G1 X105.995 Y150.681 E-.06557
G1 X105.995 Y153.319 E-1.25305
G1 X105.991 Y153.35 E-.01513
;WIPE_END
G1 X105.978 Y153.35 F9000
G1 X125.022 Y150.563
G1 X125.435 Y150.563
G1 E5 F2400
G1 F6000
G1 X125.462 Y150.523 E.00117
G1 X125.554 Y150.498 E.00232
G1 X139.256 Y150.503 E.33329
G1 X139.489 Y150.576 E.00594
G1 X139.697 Y150.757 E.00671
G1 X139.869 Y151.128 E.00995
G1 X139.895 Y152.215 E.02645
G1 X139.89 Y152.743 E.01284
G1 X139.806 Y153.066 E.00812
G1 X139.644 Y153.307 E.00706
G1 X139.418 Y153.457 E.0066
G1 X139.202 Y153.501 E.00536
G1 X125.553 Y153.502 E.332
G1 X125.407 Y153.429 E.00397
G1 X125.371 Y153.319 E.00282
G1 X125.373 Y150.654 E.06482
G1 X125.401 Y150.612 E.00123
G1 X125.401 Y150.612 F9000
G1 X125.175 Y150.302
;TYPE:Perimeter
G1 F6000
G1 X125.278 Y150.206 E.00342
G1 X125.554 Y150.132 E.00695
G1 X139.256 Y150.137 E.33329
G1 X139.534 Y150.196 E.00691
G1 X139.863 Y150.4 E.00942
G1 X140.025 Y150.594 E.00615
;WIDTH:0.441873
G1 X140.112 Y150.739 E.00458
;WIDTH:0.483747
G1 X140.199 Y150.884 E.00506
;WIDTH:0.525621
G1 X140.287 Y151.029 E.00554
;WIDTH:0.537039
G1 X140.334 Y151.458 E.01443
G1 X140.318 Y151.838 E.01272
;WIDTH:0.50862
G1 X140.301 Y152.217 E.01197
;WIDTH:0.480201
G1 X140.274 Y152.511 E.00876
;WIDTH:0.437298
G1 X140.247 Y152.806 E.00794
;WIDTH:0.394394
G1 X140.102 Y153.245 E.01107
;WIDTH:0.384079
G1 X139.859 Y153.593 E.00987
;WIDTH:0.399604
G1 X139.686 Y153.732 E.00539
;WIDTH:0.399999
G1 X139.322 Y153.853 E.00933
G1 X138.718 Y153.866 E.0147
G1 X125.553 Y153.868 E.32023
G1 X125.295 Y153.803 E.00647
G1 X125.115 Y153.648 E.00578
G1 X125.027 Y153.473 E.00476
G1 X125.005 Y153.319 E.00378
G1 X125.011 Y150.601 E.06611
G1 X125.102 Y150.369 E.00606
G1 X125.131 Y150.343 E.00095
G1 E-5 F3600
G1 X125.131 Y150.343 F9000
G1 X125.131 Y156.67
G1 E5 F2400
G1 F6000
G1 X97.145 Y156.67 E.68073
G1 X96.572 Y156.689 E.01395
G1 X95.386 Y156.784 E.02894
G1 X94.56 Y156.723 E.02015
G1 X94.04 Y156.613 E.01293
G1 X93.48 Y156.436 E.01429
G1 X92.889 Y156.178 E.01569
G1 X92.426 Y155.917 E.01293
G1 X91.597 Y155.289 E.0253
G1 X91.117 Y154.798 E.0167
G1 X90.697 Y154.251 E.01677
G1 X90.346 Y153.658 E.01676
G1 X90.015 Y152.879 E.02059
G1 X89.865 Y152.371 E.01288
G1 X89.711 Y151.342 E.02531
G1 X89.7 Y80.006 E1.73518
G1 X89.743 Y79.301 E.01718
G1 X89.869 Y78.612 E.01704
G1 X90.077 Y77.943 E.01704
G1 X90.365 Y77.305 E.01703
G1 X90.727 Y76.705 E.01704
G1 X91.159 Y76.154 E.01703
G1 X91.654 Y75.659 E.01703
G1 X92.205 Y75.227 E.01703
G1 X92.805 Y74.865 E.01704
G1 X93.446 Y74.576 E.0171
G1 X94.11 Y74.37 E.01691
G1 X95.153 Y74.211 E.02566
G1 X135.845 Y74.211 E.98979
G1 X136.888 Y74.369 E.02566
G1 X137.88 Y74.712 E.02553
G1 X138.795 Y75.227 E.02554
G1 X139.601 Y75.9 E.02554
G1 X140.273 Y76.706 E.02553
G1 X140.788 Y77.62 E.02552
G1 X141.131 Y78.612 E.02553
G1 X141.289 Y79.653 E.02561
G1 X141.289 Y80.003 E.00851
G1 X141.3 Y150.994 E1.72679
G1 X141.259 Y151.689 E.01693
G1 X141.136 Y152.367 E.01676
G1 X140.934 Y153.027 E.01679
G1 X140.655 Y153.657 E.01676
G1 X140.303 Y154.251 E.01679
G1 X139.883 Y154.798 E.01677
G1 X139.402 Y155.29 E.01674
G1 X138.705 Y155.832 E.02148
G1 X138.111 Y156.178 E.01672
G1 X137.392 Y156.48 E.01897
G1 X136.68 Y156.678 E.01798
G1 X136.047 Y156.765 E.01554
G1 X135.586 Y156.782 E.01122
G1 X134.429 Y156.689 E.02823
G1 X133.855 Y156.67 E.01397
G1 X125.191 Y156.67 E.21074
G1 X125.191 Y156.67 F9000
G1 X125.191 Y156.304
;TYPE:Perimeter
G1 F6000
G1 X97.145 Y156.304 E.68219
G1 X96.542 Y156.324 E.01468
G1 X95.384 Y156.417 E.02826
G1 X94.696 Y156.366 E.01678
G1 X94.133 Y156.259 E.01394
G1 X93.608 Y156.094 E.01339
G1 X93.052 Y155.85 E.01477
G1 X92.576 Y155.572 E.01341
G1 X91.806 Y154.979 E.02364
G1 X91.304 Y154.44 E.01792
G1 X90.973 Y154.002 E.01335
;WIDTH:0.397037
G1 X90.656 Y153.489 E.01455
;WIDTH:0.415327
G1 X90.371 Y152.762 E.01979
;WIDTH:0.445562
G1 X90.314 Y152.515 E.00693
;WIDTH:0.475797
G1 X90.257 Y152.268 E.00744
;WIDTH:0.504898
G1 X90.214 Y151.88 E.01222
;WIDTH:0.533998
G1 X90.17 Y151.491 E.01301
;WIDTH:0.563596
G1 X90.158 Y151.058 E.01525
G1 X90.138 Y150.975 E.00301
;WIDTH:0.52326
G1 X90.118 Y150.893 E.00275
;WIDTH:0.482923
G1 X90.097 Y150.81 E.00255
;WIDTH:0.442586
G1 X90.077 Y150.727 E.00232
;WIDTH:0.402249
G1 X90.076 Y150.383 E.00842
;WIDTH:0.399999
G1 X90.075 Y145.358 E.12223
;WIDTH:0.437622
G1 X90.094 Y145.196 E.00438
;WIDTH:0.475244
G1 X90.113 Y145.035 E.00475
;WIDTH:0.512866
G1 X90.132 Y144.873 E.00519
;WIDTH:0.550488
G1 X90.151 Y144.711 E.0056
;WIDTH:0.550594
G1 X90.15 Y143.289 E.04883
;WIDTH:0.570194
G1 X90.16 Y143.027 E.00935
G1 X90.139 Y142.93 E.00354
;WIDTH:0.5288
G1 X90.119 Y142.834 E.00323
;WIDTH:0.487406
G1 X90.098 Y142.738 E.00296
;WIDTH:0.446012
G1 X90.077 Y142.642 E.00269
;WIDTH:0.404618
G1 X90.075 Y142.192 E.01108
;WIDTH:0.399999
G1 X90.074 Y138.13 E.0988
;WIDTH:0.402401
G1 X90.075 Y137.274 E.02096
;WIDTH:0.444115
G1 X90.096 Y137.208 E.00189
;WIDTH:0.485828
G1 X90.117 Y137.142 E.00208
;WIDTH:0.527541
G1 X90.138 Y137.076 E.00227
;WIDTH:0.569254
G1 X90.159 Y137.009 E.0025
G1 X90.148 Y136.546 E.01648
;WIDTH:0.551204
G1 X90.149 Y135.283 E.04342
;WIDTH:0.562823
G1 X90.155 Y135.086 E.00693
G1 X90.135 Y135.02 E.00242
;WIDTH:0.522117
G1 X90.115 Y134.953 E.00227
;WIDTH:0.481411
G1 X90.094 Y134.887 E.00206
;WIDTH:0.440705
G1 X90.074 Y134.82 E.00189
;WIDTH:0.399999
G1 X90.073 Y129.196 E.1368
;WIDTH:0.442463
G1 X90.094 Y129.149 E.0014
;WIDTH:0.484927
G1 X90.115 Y129.103 E.00152
;WIDTH:0.527391
G1 X90.137 Y129.056 E.0017
;WIDTH:0.569855
G1 X90.158 Y129.01 E.0018
G1 X90.147 Y128.546 E.01653
;WIDTH:0.547974
G1 X90.147 Y127.454 E.03731
;WIDTH:0.565386
G1 X90.155 Y127.058 E.01399
G1 X90.135 Y126.995 E.00233
;WIDTH:0.52404
G1 X90.114 Y126.931 E.00219
;WIDTH:0.482693
G1 X90.093 Y126.868 E.00198
;WIDTH:0.441346
G1 X90.073 Y126.804 E.00182
;WIDTH:0.399999
G1 X90.072 Y121.196 E.13641
;WIDTH:0.442613
G1 X90.093 Y121.15 E.00137
;WIDTH:0.485227
G1 X90.114 Y121.103 E.00154
;WIDTH:0.527841
G1 X90.136 Y121.056 E.0017
;WIDTH:0.570454
G1 X90.157 Y121.01 E.0018
G1 X90.146 Y120.546 E.01655
;WIDTH:0.54857
G1 X90.146 Y119.454 E.03735
;WIDTH:0.565983
G1 X90.154 Y119.058 E.01401
G1 X90.134 Y118.995 E.00234
;WIDTH:0.524487
G1 X90.113 Y118.931 E.0022
;WIDTH:0.482991
G1 X90.092 Y118.867 E.00201
;WIDTH:0.441495
G1 X90.071 Y118.804 E.0018
;WIDTH:0.399999
G1 X90.071 Y113.196 E.13641
;WIDTH:0.442763
G1 X90.092 Y113.15 E.00137
;WIDTH:0.485527
G1 X90.113 Y113.103 E.00155
;WIDTH:0.528291
G1 X90.135 Y113.056 E.00171
;WIDTH:0.571055
G1 X90.156 Y113.01 E.00181
G1 X90.145 Y112.546 E.01657
;WIDTH:0.549165
G1 X90.145 Y111.454 E.0374
;WIDTH:0.56658
G1 X90.154 Y111.058 E.01402
G1 X90.133 Y110.994 E.00238
;WIDTH:0.524935
G1 X90.112 Y110.931 E.00217
;WIDTH:0.48329
G1 X90.091 Y110.867 E.00201
;WIDTH:0.441645
G1 X90.07 Y110.804 E.0018
;WIDTH:0.399999
G1 X90.069 Y105.197 E.13638
;WIDTH:0.442913
G1 X90.091 Y105.15 E.00141
;WIDTH:0.485826
G1 X90.112 Y105.103 E.00155
;WIDTH:0.52874
G1 X90.134 Y105.057 E.00168
;WIDTH:0.571653
G1 X90.155 Y105.01 E.00184
G1 X90.144 Y104.546 E.01659
;WIDTH:0.54976
G1 X90.144 Y103.454 E.03744
;WIDTH:0.567176
G1 X90.153 Y103.058 E.01404
G1 X90.132 Y102.994 E.00239
;WIDTH:0.525382
G1 X90.111 Y102.931 E.00217
;WIDTH:0.483588
G1 X90.09 Y102.867 E.00201
;WIDTH:0.441794
G1 X90.069 Y102.803 E.00183
;WIDTH:0.399999
G1 X90.068 Y96.357 E.15679
;WIDTH:0.443157
G1 X90.09 Y96.254 E.00286
;WIDTH:0.486314
G1 X90.111 Y96.151 E.00316
;WIDTH:0.529472
G1 X90.133 Y96.049 E.00344
;WIDTH:0.572629
G1 X90.154 Y95.946 E.00376
G1 X90.143 Y95.614 E.01189
;WIDTH:0.554334
G1 X90.145 Y93.124 E.08613
G1 X90.125 Y93.001 E.00431
;WIDTH:0.515751
G1 X90.106 Y92.879 E.00395
;WIDTH:0.477167
G1 X90.087 Y92.756 E.00367
;WIDTH:0.438583
G1 X90.068 Y92.634 E.00332
;WIDTH:0.399999
G1 X90.066 Y80.017 E.3069
G1 X90.106 Y79.345 E.01637
G1 X90.225 Y78.7 E.01595
G1 X90.42 Y78.073 E.01597
G1 X90.689 Y77.475 E.01595
G1 X91.028 Y76.914 E.01594
G1 X91.433 Y76.397 E.01597
G1 X91.897 Y75.933 E.01596
G1 X92.414 Y75.528 E.01597
G1 X92.975 Y75.189 E.01594
G1 X93.576 Y74.919 E.01603
G1 X94.192 Y74.727 E.01569
G1 X95.18 Y74.577 E.02431
G1 X99.531 Y74.577 E.10583
;WIDTH:0.440784
G1 X99.748 Y74.597 E.00589
;WIDTH:0.481569
G1 X99.966 Y74.617 E.00651
;WIDTH:0.522353
G1 X100.183 Y74.638 E.00708
G1 X130.817 Y74.638 E.99447
G1 X131.034 Y74.617 E.00708
;WIDTH:0.481596
G1 X131.252 Y74.597 E.00651
;WIDTH:0.440798
G1 X131.469 Y74.577 E.00589
;WIDTH:0.399999
G1 X135.817 Y74.577 E.10576
G1 X136.8 Y74.726 E.02418
G1 X137.73 Y75.047 E.02393
G1 X138.586 Y75.53 E.02391
G1 X139.341 Y76.159 E.0239
G1 X139.971 Y76.914 E.02392
G1 X140.454 Y77.771 E.02393
G1 X140.774 Y78.7 E.0239
G1 X140.875 Y79.362 E.01629
G1 X140.923 Y80.003 E.01564
G1 X140.925 Y92.719 E.3093
;WIDTH:0.440492
G1 X140.905 Y92.785 E.00186
;WIDTH:0.480985
G1 X140.885 Y92.852 E.00208
;WIDTH:0.521478
G1 X140.865 Y92.919 E.00227
;WIDTH:0.561971
G1 X140.844 Y92.985 E.00243
G1 X140.852 Y93.216 E.00811
;WIDTH:0.547032
G1 X140.852 Y95.613 E.08175
;WIDTH:0.569345
G1 X140.841 Y95.945 E.01182
G1 X140.862 Y96.071 E.00455
;WIDTH:0.527009
G1 X140.884 Y96.197 E.00419
;WIDTH:0.484672
G1 X140.905 Y96.322 E.0038
;WIDTH:0.442336
G1 X140.926 Y96.448 E.00347
;WIDTH:0.399999
G1 X140.927 Y102.804 E.1546
;WIDTH:0.441302
G1 X140.906 Y102.868 E.00182
;WIDTH:0.482605
G1 X140.886 Y102.931 E.00197
;WIDTH:0.523908
G1 X140.865 Y102.995 E.00219
;WIDTH:0.56521
G1 X140.844 Y103.058 E.00235
G1 X140.853 Y103.454 E.01399
;WIDTH:0.547941
G1 X140.853 Y104.546 E.03731
;WIDTH:0.565355
G1 X140.845 Y104.942 E.01399
G1 X140.865 Y105.005 E.00233
;WIDTH:0.524016
G1 X140.886 Y105.069 E.00219
;WIDTH:0.482677
G1 X140.907 Y105.132 E.00198
;WIDTH:0.441338
G1 X140.927 Y105.196 E.00182
;WIDTH:0.399999
G1 X140.928 Y110.804 E.13641
;WIDTH:0.441456
G1 X140.907 Y110.867 E.0018
;WIDTH:0.482912
G1 X140.887 Y110.931 E.002
;WIDTH:0.524369
G1 X140.866 Y110.994 E.00216
;WIDTH:0.565825
G1 X140.845 Y111.058 E.00238
G1 X140.854 Y111.454 E.014
;WIDTH:0.548555
G1 X140.854 Y112.546 E.03735
;WIDTH:0.56597
G1 X140.846 Y112.942 E.01401
G1 X140.866 Y113.005 E.00234
;WIDTH:0.524478
G1 X140.887 Y113.069 E.0022
;WIDTH:0.482985
G1 X140.908 Y113.133 E.00201
;WIDTH:0.441492
G1 X140.929 Y113.196 E.0018
;WIDTH:0.399999
G1 X140.929 Y118.804 E.13641
;WIDTH:0.44161
G1 X140.909 Y118.867 E.00179
;WIDTH:0.48322
G1 X140.888 Y118.931 E.00201
;WIDTH:0.524831
G1 X140.867 Y118.994 E.00217
;WIDTH:0.566441
G1 X140.846 Y119.058 E.00238
G1 X140.855 Y119.454 E.01402
;WIDTH:0.549168
G1 X140.855 Y120.546 E.0374
;WIDTH:0.566584
G1 X140.846 Y120.942 E.01402
G1 X140.867 Y121.006 E.00238
;WIDTH:0.524938
G1 X140.888 Y121.069 E.00217
;WIDTH:0.483292
G1 X140.909 Y121.133 E.00201
;WIDTH:0.441646
G1 X140.93 Y121.196 E.0018
;WIDTH:0.399999
G1 X140.931 Y125.987 E.11654
;WIDTH:0.404695
G1 X140.928 Y126.639 E.01606
;WIDTH:0.446838
G1 X140.907 Y126.735 E.0027
;WIDTH:0.48898
G1 X140.886 Y126.832 E.003
;WIDTH:0.531122
G1 X140.865 Y126.928 E.00325
;WIDTH:0.573264
G1 X140.844 Y127.024 E.00352
G1 X140.854 Y127.289 E.00951
;WIDTH:0.553593
G1 X140.854 Y128.711 E.04912
;WIDTH:0.560296
G1 X140.851 Y128.864 E.00535
G1 X140.871 Y128.988 E.00439
;WIDTH:0.520222
G1 X140.891 Y129.112 E.00406
;WIDTH:0.480148
G1 X140.911 Y129.235 E.0037
;WIDTH:0.440074
G1 X140.931 Y129.359 E.00339
;WIDTH:0.399999
G1 X140.932 Y133.987 E.11257
;WIDTH:0.404739
G1 X140.929 Y134.639 E.01606
;WIDTH:0.447029
G1 X140.908 Y134.735 E.0027
;WIDTH:0.489319
G1 X140.887 Y134.831 E.00297
;WIDTH:0.531609
G1 X140.866 Y134.928 E.00328
;WIDTH:0.573899
G1 X140.845 Y135.024 E.00353
G1 X140.855 Y135.283 E.0093
;WIDTH:0.554112
G1 X140.857 Y136.541 E.0435
;WIDTH:0.567814
G1 X140.848 Y136.942 E.01423
G1 X140.869 Y137.006 E.00239
;WIDTH:0.525861
G1 X140.89 Y137.069 E.00217
;WIDTH:0.483907
G1 X140.911 Y137.133 E.00201
;WIDTH:0.441953
G1 X140.932 Y137.197 E.00183
;WIDTH:0.399999
G1 X140.933 Y142.803 E.13636
;WIDTH:0.442071
G1 X140.912 Y142.867 E.00183
;WIDTH:0.484142
G1 X140.891 Y142.93 E.00199
;WIDTH:0.526213
G1 X140.87 Y142.994 E.0022
;WIDTH:0.568284
G1 X140.849 Y143.058 E.00239
G1 X140.858 Y143.454 E.01407
;WIDTH:0.551009
G1 X140.858 Y144.546 E.03753
;WIDTH:0.568429
G1 X140.849 Y144.942 E.01407
G1 X140.87 Y145.006 E.00239
;WIDTH:0.526322
G1 X140.891 Y145.07 E.0022
;WIDTH:0.484214
G1 X140.912 Y145.133 E.00199
;WIDTH:0.442107
G1 X140.933 Y145.197 E.00183
;WIDTH:0.399999
G1 X140.934 Y149.866 E.11357
;WIDTH:0.405676
G1 X140.931 Y150.724 E.02119
;WIDTH:0.445845
G1 X140.91 Y150.812 E.00248
;WIDTH:0.486014
G1 X140.889 Y150.899 E.00269
;WIDTH:0.526183
G1 X140.867 Y150.986 E.00294
;WIDTH:0.566352
G1 X140.846 Y151.074 E.0032
G1 X140.826 Y151.652 E.02047
;WIDTH:0.53308
G1 X140.782 Y151.968 E.01058
;WIDTH:0.506641
G1 X140.737 Y152.284 E.01003
;WIDTH:0.480201
G1 X140.656 Y152.615 E.01011
;WIDTH:0.435152
G1 X140.575 Y152.947 E.00911
;WIDTH:0.390102
G1 X140.277 Y153.608 E.01716
;WIDTH:0.399604
G1 X139.991 Y154.056 E.01291
;WIDTH:0.399999
G1 X139.606 Y154.558 E.01539
G1 X139.158 Y155.017 E.0156
G1 X138.5 Y155.529 E.02028
G1 X137.947 Y155.85 E.01555
G1 X137.272 Y156.134 E.01781
G1 X136.606 Y156.319 E.01681
G1 X135.997 Y156.403 E.01495
G1 X135.599 Y156.417 E.00969
G1 X134.458 Y156.324 E.02785
G1 X133.855 Y156.304 E.01468
G1 X125.251 Y156.304 E.20928
G1 E-5 F3600
G1 X125.251 Y156.322 F9000
G1 X95.219 Y145.849
G1 X91.781 Y145.849
G1 X91.685 Y145.843
G1 X91.579 Y145.826
G1 X91.394 Y145.761
G1 X91.22 Y145.656
G1 X91.073 Y145.522
G1 X90.948 Y145.359
G1 X90.856 Y145.168
G1 X90.795 Y144.977
G1 X90.761 Y144.767
G1 X90.758 Y144.703
G1 X90.751 Y144.557
G1 X90.751 Y119.443
G1 X90.758 Y119.297
G1 X90.761 Y119.233
G1 X90.795 Y119.023
G1 X90.856 Y118.832
G1 X90.948 Y118.641
G1 X91.073 Y118.478
G1 X91.22 Y118.344
G1 X91.394 Y118.239
G1 X91.579 Y118.174
G1 X91.685 Y118.157
G1 X91.781 Y118.151
G1 X92.926 Y118.149
G1 X93.569 Y118.149
G1 X93.569 Y117.767
G1 E5 F2400
G1 F6000
G1 X91.797 Y117.768 E.0431
G1 X91.239 Y117.909 E.014
G1 X90.865 Y118.155 E.01089
G1 X90.553 Y118.584 E.0129
G1 X90.437 Y118.918 E.0086
G1 X90.436 Y113.094 E.14166
G1 X90.553 Y113.416 E.00833
G1 X90.788 Y113.755 E.01003
G1 X91.008 Y113.955 E.00723
G1 X91.423 Y114.171 E.01138
G1 X91.797 Y114.232 E.00922
G1 X93.569 Y114.233 E.0431
G1 X93.569 Y117.707 E.0845
G1 X93.569 Y117.707 F9000
G1 X93.203 Y117.401
G1 F6000
G1 X92.004 Y117.402 E.02916
G1 X91.378 Y117.473 E.01532
G1 X91.119 Y117.563 E.00667
G1 X90.803 Y117.771 E.0092
G1 X90.802 Y114.247 E.08572
G1 X91.343 Y114.527 E.01482
G1 X91.797 Y114.598 E.01118
G1 X93.203 Y114.599 E.0342
G1 X93.203 Y117.341 E.0667
G1 X93.203 Y117.341 F9000
G1 X92.837 Y116.031
G1 F6000
G1 X92.837 Y117.036 E.02445
G1 X91.797 Y117.037 E.0253
G1 X91.168 Y117.159 E.01558
G1 X91.168 Y114.835 E.05653
G1 X91.263 Y114.884 E.0026
G1 X91.797 Y114.963 E.01313
G1 X92.837 Y114.964 E.0253
G1 X92.837 Y115.971 E.02449
G1 E-5 F3600
G1 X92.837 Y115.971 F9000
G1 X90.948 Y113.359
G1 X90.856 Y113.168
G1 X90.795 Y112.977
G1 X90.761 Y112.767
G1 X90.758 Y112.703
G1 X90.751 Y112.557
G1 X90.751 Y111.443
G1 X90.758 Y111.297
G1 X90.761 Y111.233
G1 X90.795 Y111.023
G1 X90.856 Y110.832
G1 X90.948 Y110.641
G1 X91.073 Y110.478
G1 X91.22 Y110.344
G1 X91.394 Y110.239
G1 X91.579 Y110.174
G1 X91.685 Y110.157
G1 X91.781 Y110.151
G1 X93.353 Y110.149
G1 X93.569 Y110.149
G1 X93.569 Y109.77
G1 E5 F2400
G1 F6000
G1 X91.706 Y109.777 E.04532
G1 X91.318 Y109.865 E.00968
G1 X90.865 Y110.154 E.01307
G1 X90.553 Y110.584 E.01292
G1 X90.436 Y110.923 E.00872
G1 X90.435 Y105.09 E.14188
G1 X90.553 Y105.416 E.00843
G1 X90.788 Y105.755 E.01003
G1 X91.008 Y105.955 E.00723
G1 X91.423 Y106.171 E.01138
G1 X91.797 Y106.232 E.00922
G1 X93.569 Y106.233 E.0431
G1 X93.569 Y109.71 E.08457
G1 X93.569 Y109.71 F9000
G1 X93.203 Y109.278
G1 F6000
G1 X93.203 Y109.405 E.00309
G1 X91.704 Y109.411 E.03646
G1 X91.161 Y109.535 E.01355
G1 X90.801 Y109.755 E.01026
G1 X90.801 Y106.246 E.08535
G1 X91.343 Y106.527 E.01485
G1 X91.797 Y106.598 E.01118
G1 X93.203 Y106.599 E.0342
G1 X93.203 Y109.218 E.0637
G1 X93.203 Y109.218 F9000
G1 X92.837 Y107.73
G1 F6000
G1 X92.837 Y109.041 E.03189
G1 X91.703 Y109.046 E.02758
G1 X91.167 Y109.167 E.01337
G1 X91.167 Y106.834 E.05675
G1 X91.263 Y106.884 E.00263
G1 X91.797 Y106.963 E.01313
G1 X92.837 Y106.964 E.0253
G1 X92.837 Y107.67 E.01717
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X92.837 Y107.73 E-.0285
G1 X92.837 Y109.041 E-.62272
G1 X91.703 Y109.046 E-.53866
G1 X91.167 Y109.167 E-.26101
G1 X91.167 Y109.064 E-.04911
;WIPE_END
G1 X90.761 Y104.767 F9000
G1 X90.758 Y104.703
G1 X90.751 Y104.557
G1 X90.751 Y103.443
G1 X90.758 Y103.297
G1 X90.761 Y103.233
G1 X90.795 Y103.023
G1 X90.856 Y102.832
G1 X90.948 Y102.641
G1 X91.073 Y102.478
G1 X91.22 Y102.344
G1 X91.394 Y102.239
G1 X91.579 Y102.174
G1 X91.685 Y102.157
G1 X91.781 Y102.151
G1 X93.353 Y102.149
G1 X93.569 Y102.149
G1 X93.569 Y101.77
G1 E5 F2400
G1 F6000
G1 X91.706 Y101.777 E.04532
G1 X91.318 Y101.865 E.00968
G1 X90.865 Y102.154 E.01307
G1 X90.553 Y102.584 E.01292
G1 X90.435 Y102.928 E.00885
G1 X90.434 Y95.996 E.16861
G1 X90.566 Y96.315 E.0084
G1 X90.72 Y96.534 E.00651
G1 X91.011 Y96.801 E.00961
G1 X91.462 Y96.998 E.01197
G1 X91.798 Y97.044 E.00825
G1 X93.569 Y97.044 E.04308
G1 X93.569 Y101.71 E.1135
G1 X93.569 Y101.71 F9000
G1 X93.203 Y100.845
G1 F6000
G1 X93.203 Y101.405 E.01362
G1 X91.704 Y101.411 E.03646
G1 X91.161 Y101.535 E.01355
G1 X90.8 Y101.756 E.0103
G1 X90.8 Y97.091 E.11347
G1 X91.398 Y97.358 E.01593
G1 X91.798 Y97.409 E.00981
G1 X93.203 Y97.41 E.03418
G1 X93.203 Y100.785 E.08209
G1 X92.837 Y100.102 F9000
G1 F6000
G1 X92.837 Y101.041 E.02284
G1 X91.703 Y101.046 E.02758
G1 X91.166 Y101.168 E.01339
G1 X91.165 Y97.656 E.08543
G1 X91.333 Y97.718 E.00436
G1 X91.798 Y97.775 E.0114
G1 X92.837 Y97.775 E.02527
G1 X92.837 Y100.042 E.05514
G1 E-5 F3600
G1 X92.837 Y100.042 F9000
G1 X90.948 Y102.641
G1 X90.856 Y102.832
G1 X90.795 Y103.023
G1 X90.761 Y103.233
G1 X90.758 Y103.297
G1 X90.751 Y103.443
G1 X90.751 Y120.557
G1 X90.758 Y120.703
G1 X90.761 Y120.767
G1 X90.795 Y120.977
G1 X90.856 Y121.168
G1 X90.948 Y121.359
G1 X91.073 Y121.522
G1 X91.22 Y121.656
G1 X91.394 Y121.761
G1 X91.579 Y121.826
G1 X91.685 Y121.843
G1 X91.781 Y121.849
G1 X93.353 Y121.851
G1 X93.569 Y121.851
G1 X93.569 Y122.23
G1 E5 F2400
G1 F6000
G1 X93.569 Y125.767 E.08603
G1 X91.797 Y125.768 E.0431
G1 X91.239 Y125.909 E.014
G1 X90.865 Y126.155 E.01089
G1 X90.553 Y126.584 E.0129
G1 X90.438 Y126.913 E.00848
G1 X90.437 Y121.099 E.14142
G1 X90.553 Y121.416 E.00821
G1 X90.865 Y121.846 E.01292
G1 X91.318 Y122.135 E.01307
G1 X91.706 Y122.223 E.00968
G1 X93.509 Y122.23 E.04386
G1 X93.509 Y122.23 F9000
G1 X92.872 Y122.593
G1 F6000
G1 X93.203 Y122.595 E.00805
G1 X93.203 Y125.401 E.06825
G1 X92.004 Y125.402 E.02916
G1 X91.378 Y125.473 E.01532
G1 X91.119 Y125.563 E.00667
G1 X90.804 Y125.771 E.00918
G1 X90.803 Y122.246 E.08574
G1 X91.161 Y122.465 E.01021
G1 X91.704 Y122.589 E.01355
G1 X92.812 Y122.593 E.02695
G1 X92.812 Y122.593 F9000
G1 X92.422 Y122.957
G1 F6000
G1 X92.837 Y122.959 E.01009
G1 X92.837 Y125.036 E.05052
G1 X91.797 Y125.037 E.0253
G1 X91.169 Y125.159 E.01556
G1 X91.169 Y122.833 E.05658
G1 X91.703 Y122.954 E.01332
G1 X92.362 Y122.957 E.01603
G1 E-5 F3600
G1 X92.362 Y122.957 F9000
G1 X90.856 Y126.832
G1 X90.795 Y127.023
G1 X90.761 Y127.233
G1 X90.758 Y127.297
G1 X90.751 Y127.443
G1 X90.751 Y128.557
G1 X90.856 Y134.832
G1 X90.795 Y135.023
G1 X90.439 Y134.912
G1 E5 F2400
G1 F6000
G1 X90.439 Y129.103 E.1413
G1 X90.553 Y129.416 E.0081
G1 X90.865 Y129.846 E.01292
G1 X91.318 Y130.135 E.01307
G1 X91.706 Y130.223 E.00968
G1 X93.571 Y130.229 E.04536
G1 X93.58 Y133.067 E.06903
G1 X93.64 Y133.767 E.01709
G1 X91.799 Y133.768 E.04478
G1 X91.242 Y133.907 E.01396
G1 X90.802 Y134.232 E.01331
G1 X90.613 Y134.49 E.00778
G1 X90.462 Y134.856 E.00963
G1 X90.462 Y134.856 F9000
G1 X90.805 Y133.796
G1 F6000
G1 X90.804 Y130.247 E.08633
G1 X91.161 Y130.465 E.01017
G1 X91.705 Y130.589 E.01357
G1 X93.206 Y130.594 E.03651
G1 X93.209 Y132.197 E.03899
G1 X93.242 Y133.402 E.02932
G1 X92.008 Y133.402 E.03002
G1 X91.382 Y133.472 E.01532
G1 X91.123 Y133.561 E.00666
G1 X90.853 Y133.76 E.00816
G1 X90.853 Y133.76 F9000
G1 X91.171 Y133.158
G1 F6000
G1 X91.17 Y130.833 E.05655
G1 X91.704 Y130.954 E.01332
G1 X92.841 Y130.958 E.02766
G1 X92.847 Y133.036 E.05055
G1 X91.798 Y133.037 E.02552
G1 X91.229 Y133.147 E.0141
G1 E-5 F3600
G1 X91.229 Y133.147 F9000
G1 X90.469 Y142.825
G1 E5 F2400
;WIDTH:0.404618
G1 F6000
G1 X90.448 Y142.895 E.0018
G1 X90.441 Y142.192 E.01732
;WIDTH:0.399999
G1 X90.44 Y137.618 E.11126
;WIDTH:0.402401
G1 X90.443 Y137.116 E.01229
G1 X90.648 Y137.569 E.01217
;WIDTH:0.399999
G1 X90.917 Y137.892 E.01022
G1 X91.363 Y138.155 E.01259
G1 X91.743 Y138.228 E.00941
G1 X95.144 Y138.233 E.08273
G1 X95.4 Y138.655 E.01201
G1 X95.832 Y139.259 E.01806
G1 X96.335 Y139.867 E.01919
G1 X96.876 Y140.433 E.01904
G1 X97.625 Y141.098 E.02436
G1 X98.551 Y141.768 E.0278
G1 X91.708 Y141.777 E.16645
G1 X91.318 Y141.865 E.00972
G1 X91.148 Y141.946 E.00458
G1 X90.728 Y142.304 E.01342
;WIDTH:0.404618
G1 X90.522 Y142.653 E.00998
G1 X90.487 Y142.767 E.00294
G1 X90.487 Y142.767 F9000
G1 X90.806 Y141.752
;WIDTH:0.399999
G1 F6000
G1 X90.806 Y138.266 E.08479
G1 X91.26 Y138.506 E.01249
G1 X91.742 Y138.594 E.01192
G1 X94.936 Y138.598 E.07769
G1 X95.102 Y138.867 E.00769
G1 X95.55 Y139.492 E.0187
G1 X96.069 Y140.119 E.0198
G1 X96.632 Y140.705 E.01977
G1 X97.424 Y141.404 E.02569
G1 X91.708 Y141.411 E.13904
G1 X91.161 Y141.535 E.01364
G1 X90.857 Y141.721 E.00867
G1 X90.857 Y141.721 F9000
G1 X91.172 Y141.166
G1 F6000
G1 X91.171 Y138.861 E.05607
G1 X91.742 Y138.96 E.0141
G1 X94.724 Y138.963 E.07253
G1 X95.267 Y139.724 E.02274
G1 X95.804 Y140.371 E.02045
G1 X96.457 Y141.04 E.02274
G1 X91.707 Y141.046 E.11554
G1 X91.23 Y141.153 E.01189
G1 E-5 F3600
G1 X91.23 Y141.153 F9000
G1 X90.795 Y143.023
G1 X90.761 Y143.233
G1 X90.758 Y143.297
G1 X90.751 Y143.443
G1 X90.751 Y144.557
G1 X90.758 Y144.703
G1 X90.761 Y144.767
G1 X90.795 Y144.977
G1 X90.856 Y145.168
G1 X90.948 Y145.359
G1 X91.073 Y145.522
G1 X91.22 Y145.656
G1 X91.394 Y145.761
G1 X91.579 Y145.826
G1 X91.685 Y145.843
G1 X91.781 Y145.849
G1 X95.968 Y145.85
G1 X98.913 Y145.85
G1 X98.913 Y146.233
G1 E5 F2400
G1 F6000
G1 X105.445 Y146.233 E.15888
G1 X105.701 Y146.197 E.00629
G1 X105.905 Y146.11 E.00539
G1 X106.139 Y145.916 E.00739
G1 X106.318 Y145.595 E.00894
G1 X106.361 Y145.322 E.00672
G1 X106.367 Y143.532 E.04354
G1 X110.583 Y143.529 E.10255
G1 X110.904 Y143.446 E.00806
G1 X110.984 Y143.32 E.00363
G1 X120.016 Y143.32 E.21969
G1 X120.096 Y143.446 E.00363
G1 X120.258 Y143.504 E.00419
G1 X120.483 Y143.532 E.00552
G1 X124.635 Y143.532 E.10099
G1 X124.639 Y145.322 E.04354
G1 X124.682 Y145.595 E.00672
G1 X124.761 Y145.775 E.00478
G1 X124.953 Y146.009 E.00736
G1 X125.299 Y146.197 E.00958
G1 X125.554 Y146.233 E.00626
G1 X139.202 Y146.232 E.33197
G1 X139.761 Y146.091 E.01402
G1 X140.135 Y145.845 E.01089
G1 X140.447 Y145.416 E.0129
G1 X140.568 Y145.08 E.00869
G1 X140.569 Y149.866 E.11641
;WIDTH:0.405676
G1 X140.56 Y150.875 E.02492
G1 X140.352 Y150.431 E.01211
;WIDTH:0.399999
G1 X140.083 Y150.108 E.01022
G1 X139.637 Y149.845 E.01259
G1 X139.256 Y149.772 E.00944
G1 X125.554 Y149.767 E.33329
G1 X125.299 Y149.803 E.00626
G1 X125.095 Y149.89 E.00539
G1 X124.861 Y150.084 E.00739
G1 X124.703 Y150.345 E.00742
G1 X124.639 Y150.681 E.00832
G1 X124.639 Y153.319 E.06417
G1 X124.676 Y153.575 E.00629
G1 X124.822 Y153.868 E.00796
G1 X125.123 Y154.126 E.00964
G1 X125.553 Y154.233 E.01078
G1 X138.718 Y154.232 E.32023
G1 X139.403 Y154.215 E.01667
G1 X139.266 Y154.383 E.00527
G1 X138.898 Y154.756 E.01275
G1 X138.263 Y155.243 E.01947
G1 X137.743 Y155.539 E.01455
G1 X137.102 Y155.802 E.01685
G1 X136.474 Y155.968 E.0158
G1 X135.613 Y156.051 E.02104
G1 X134.488 Y155.96 E.02745
G1 X133.855 Y155.938 E.01541
G1 X97.145 Y155.938 E.89293
G1 X96.513 Y155.96 E.01538
G1 X95.383 Y156.05 E.02757
G1 X94.722 Y156.001 E.01612
G1 X94.226 Y155.905 E.01229
G1 X93.737 Y155.751 E.01247
G1 X93.247 Y155.537 E.01301
G1 X92.797 Y155.281 E.01259
G1 X92.067 Y154.724 E.02234
G1 X91.597 Y154.215 E.01685
G1 X91.798 Y154.232 E.00491
G1 X105.446 Y154.233 E.33197
G1 X105.877 Y154.126 E.0108
G1 X106.178 Y153.868 E.00964
G1 X106.324 Y153.575 E.00796
G1 X106.361 Y153.319 E.00629
G1 X106.361 Y150.681 E.06417
G1 X106.351 Y150.548 E.00324
G1 X106.27 Y150.285 E.00669
G1 X106.047 Y149.991 E.00898
G1 X105.701 Y149.803 E.00958
G1 X105.446 Y149.767 E.00626
G1 X91.709 Y149.777 E.33414
G1 X91.236 Y149.909 E.01194
G1 X90.992 Y150.057 E.00694
G1 X90.648 Y150.431 E.01236
;WIDTH:0.402249
G1 X90.445 Y150.899 E.01248
G1 X90.442 Y150.383 E.01263
;WIDTH:0.399999
G1 X90.441 Y145.059 E.1295
G1 X90.528 Y145.345 E.00727
G1 X90.788 Y145.755 E.01181
G1 X91.008 Y145.955 E.00723
G1 X91.423 Y146.171 E.01138
G1 X91.798 Y146.232 E.00924
G1 X98.853 Y146.233 E.17161
G1 E-5 F3600
G1 X98.853 Y146.233 F9000
G1 X98.853 Y145.85
G1 X104.662 Y145.851
G1 X105.978 Y145.851
G1 X106.731 Y143.897
G1 E5 F2400
G1 F6000
G1 X110.609 Y143.894 E.09433
G1 X111.058 Y143.777 E.01129
G1 X111.116 Y143.686 E.00262
G1 X119.884 Y143.686 E.21327
G1 X119.942 Y143.777 E.00262
G1 X120.169 Y143.858 E.00586
G1 X120.483 Y143.897 E.0077
G1 X124.27 Y143.897 E.09211
G1 X124.274 Y145.323 E.03469
G1 X124.333 Y145.705 E.0094
G1 X124.444 Y145.957 E.0067
G1 X124.584 Y146.155 E.0059
G1 X124.911 Y146.426 E.01033
G1 X125.197 Y146.548 E.00756
G1 X125.554 Y146.599 E.00877
G1 X139.202 Y146.598 E.33197
G1 X139.622 Y146.527 E.01036
G1 X139.881 Y146.437 E.00667
G1 X140.202 Y146.225 E.00936
G1 X140.203 Y149.74 E.0855
G1 X139.74 Y149.494 E.01275
G1 X139.257 Y149.406 E.01194
G1 X125.554 Y149.401 E.33331
G1 X125.197 Y149.452 E.00877
G1 X124.911 Y149.574 E.00756
G1 X124.713 Y149.715 E.00591
G1 X124.5 Y149.954 E.00779
G1 X124.335 Y150.289 E.00908
G1 X124.274 Y150.681 E.00965
G1 X124.274 Y153.319 E.06417
G1 X124.325 Y153.678 E.00882
G1 X124.53 Y154.087 E.01113
G1 X124.951 Y154.449 E.01351
G1 X125.553 Y154.599 E.01509
G1 X138.506 Y154.598 E.31507
G1 X138.08 Y154.927 E.01309
G1 X137.602 Y155.202 E.01341
G1 X137.005 Y155.45 E.01572
G1 X136.424 Y155.606 E.01463
G1 X135.626 Y155.685 E.01951
G1 X134.517 Y155.595 E.02706
G1 X133.855 Y155.573 E.01611
G1 X97.145 Y155.573 E.89293
G1 X96.484 Y155.595 E.01609
G1 X95.382 Y155.684 E.02689
G1 X94.749 Y155.637 E.01544
G1 X94.342 Y155.555 E.0101
G1 X93.845 Y155.399 E.01267
G1 X93.029 Y154.998 E.02212
G1 X92.501 Y154.598 E.01611
G1 X105.446 Y154.599 E.31487
G1 X105.668 Y154.58 E.00542
G1 X106.049 Y154.449 E.0098
G1 X106.47 Y154.087 E.01351
G1 X106.675 Y153.678 E.01113
G1 X106.726 Y153.319 E.00882
G1 X106.726 Y150.681 E.06417
G1 X106.713 Y150.494 E.00456
G1 X106.637 Y150.21 E.00715
G1 X106.416 Y149.845 E.01038
G1 X106.089 Y149.574 E.01033
G1 X105.803 Y149.452 E.00756
G1 X105.446 Y149.401 E.00877
G1 X91.709 Y149.411 E.33414
G1 X91.046 Y149.597 E.01675
G1 X90.807 Y149.741 E.00679
G1 X90.807 Y146.249 E.08494
G1 X91.343 Y146.527 E.01469
G1 X91.798 Y146.598 E.0112
G1 X105.445 Y146.599 E.33195
G1 X105.803 Y146.548 E.0088
G1 X106.089 Y146.426 E.00756
G1 X106.287 Y146.285 E.00591
G1 X106.5 Y146.046 E.00779
G1 X106.667 Y145.705 E.00924
G1 X106.726 Y145.323 E.0094
G1 X106.731 Y143.957 E.03323
G1 X106.731 Y143.957 F9000
G1 X107.19 Y144.263
G1 F6000
G1 X110.114 Y144.263 E.07112
G1 X110.741 Y144.248 E.01526
G1 X111.213 Y144.109 E.01197
G1 X111.249 Y144.052 E.00164
G1 X119.751 Y144.052 E.2068
G1 X119.787 Y144.109 E.00164
G1 X120.079 Y144.212 E.00753
G1 X120.483 Y144.263 E.0099
G1 X123.905 Y144.263 E.08324
G1 X123.908 Y145.323 E.02578
G1 X123.985 Y145.815 E.01211
G1 X124.127 Y146.139 E.0086
G1 X124.307 Y146.393 E.00757
G1 X124.728 Y146.742 E.0133
G1 X125.095 Y146.9 E.00972
G1 X125.554 Y146.965 E.01128
G1 X139.202 Y146.963 E.33197
G1 X139.837 Y146.839 E.01574
G1 X139.837 Y149.142 E.05602
G1 X139.257 Y149.04 E.01432
G1 X125.554 Y149.035 E.33331
G1 X125.095 Y149.1 E.01128
G1 X124.728 Y149.258 E.00972
G1 X124.473 Y149.44 E.00762
G1 X124.199 Y149.747 E.01001
G1 X123.987 Y150.177 E.01166
G1 X123.908 Y150.681 E.01241
G1 X123.908 Y153.319 E.06417
G1 X123.974 Y153.78 E.01133
G1 X124.237 Y154.307 E.01433
G1 X124.779 Y154.771 E.01735
;WIDTH:0.448453
G1 X124.934 Y154.834 E.00461
;WIDTH:0.496908
G1 X125.089 Y154.897 E.00515
;WIDTH:0.545362
G1 X125.244 Y154.96 E.00569
;WIDTH:0.593816
G1 X125.399 Y155.023 E.00623
;WIDTH:0.64227
G1 X125.553 Y155.086 E.00673
G1 X125.377 Y155.11 E.00718
;WIDTH:0.593816
G1 X125.2 Y155.134 E.00665
;WIDTH:0.545362
G1 X125.024 Y155.159 E.00604
;WIDTH:0.496908
G1 X124.847 Y155.183 E.0055
;WIDTH:0.448453
G1 X124.67 Y155.207 E.00492
;WIDTH:0.399999
G1 X106.33 Y155.207 E.4461
;WIDTH:0.44484
G1 X106.234 Y155.185 E.00269
;WIDTH:0.48968
G1 X106.138 Y155.162 E.00299
;WIDTH:0.534521
G1 X106.042 Y155.14 E.00328
;WIDTH:0.579361
G1 X105.946 Y155.117 E.00358
;WIDTH:0.624202
G1 X105.85 Y155.095 E.00386
;WIDTH:0.669042
G1 X105.754 Y155.072 E.00417
G1 X105.832 Y155.022 E.00391
;WIDTH:0.624202
G1 X105.91 Y154.972 E.00364
;WIDTH:0.579361
G1 X105.987 Y154.922 E.00333
;WIDTH:0.534521
G1 X106.065 Y154.872 E.00308
;WIDTH:0.48968
G1 X106.143 Y154.821 E.00282
;WIDTH:0.44484
G1 X106.221 Y154.771 E.00253
;WIDTH:0.399999
G1 X106.763 Y154.307 E.01735
G1 X107.026 Y153.78 E.01433
G1 X107.092 Y153.319 E.01133
G1 X107.092 Y150.681 E.06417
G1 X107.074 Y150.441 E.00585
G1 X106.93 Y149.968 E.01203
G1 X106.693 Y149.607 E.0105
G1 X106.272 Y149.258 E.0133
G1 X105.905 Y149.1 E.00972
G1 X105.446 Y149.035 E.01128
G1 X91.709 Y149.046 E.33414
G1 X91.173 Y149.195 E.01353
G1 X91.173 Y146.837 E.05736
G1 X91.263 Y146.884 E.00247
G1 X91.798 Y146.963 E.01315
G1 X105.445 Y146.965 E.33195
G1 X105.905 Y146.9 E.0113
G1 X106.272 Y146.742 E.00972
G1 X106.527 Y146.56 E.00762
G1 X106.801 Y146.253 E.01001
G1 X107.015 Y145.816 E.01184
G1 X107.092 Y145.325 E.01209
G1 X107.095 Y144.263 E.02583
G1 X107.13 Y144.263 E.00085
G1 E-5 F3600
G1 X107.13 Y144.263 F9000
G1 X105.978 Y153.851
G1 X96.848 Y155.09
G1 E5 F2400
;WIDTH:0.651992
G1 F6000
G1 X97.145 Y155.085 E.0122
;WIDTH:0.643122
G1 X105.446 Y155.086 E.33616
;WIDTH:0.669042
G1 X105.754 Y155.072 E.01302
G1 E-5 F3600
G1 X105.754 Y155.072 F9000
G1 X96.848 Y155.09
G1 E5 F2400
;WIDTH:0.651992
G1 F6000
G1 X96.792 Y155.113 E.00249
;WIDTH:0.608971
G1 X96.736 Y155.137 E.00233
;WIDTH:0.565949
G1 X96.68 Y155.161 E.00215
;WIDTH:0.522928
G1 X96.624 Y155.184 E.00197
;WIDTH:0.479906
G1 X96.569 Y155.208 E.00178
;WIDTH:0.436884
G1 X96.513 Y155.232 E.00163
;WIDTH:0.393863
G1 X96.457 Y155.255 E.00145
;WIDTH:0.393467
G1 X95.395 Y155.319 E.02542
G1 X94.775 Y155.286 E.01483
;WIDTH:0.371623
G1 X94.402 Y155.208 E.00855
G1 X93.694 Y154.949 E.01691
G1 X94.788 Y154.949 E.02455
;WIDTH:0.393467
G1 X95.38 Y154.96 E.01415
G1 X96.444 Y154.939 E.02542
;WIDTH:0.393863
G1 X96.502 Y154.961 E.00148
;WIDTH:0.436884
G1 X96.559 Y154.982 E.00163
;WIDTH:0.479906
G1 X96.617 Y155.004 E.00184
;WIDTH:0.522928
G1 X96.675 Y155.025 E.002
;WIDTH:0.565949
G1 X96.733 Y155.047 E.00219
;WIDTH:0.608971
G1 X96.791 Y155.068 E.00236
G1 E-5 F3600
G1 X96.791 Y155.068 F9000
G1 E5 F2400
;WIDTH:0.64227
G1 F6000
G1 X125.554 Y155.086 E.00004
;WIDTH:0.643122
G1 X133.855 Y155.085 E.33616
;WIDTH:0.65199
G1 X134.152 Y155.09 E.0122
G1 E-5 F3600
G1 X134.152 Y155.09 F9000
G1 X137.33 Y154.942
G1 E5 F2400
;WIDTH:0.357803
G1 F6000
G1 X136.912 Y155.117 E.00975
G1 X136.377 Y155.264 E.01194
;WIDTH:0.394971
G1 X135.632 Y155.321 E.01792
G1 X134.545 Y155.255 E.02612
;WIDTH:0.393912
G1 X134.489 Y155.232 E.00145
;WIDTH:0.436925
G1 X134.432 Y155.208 E.00166
;WIDTH:0.479938
G1 X134.376 Y155.184 E.00181
;WIDTH:0.522951
G1 X134.32 Y155.161 E.00197
;WIDTH:0.565964
G1 X134.264 Y155.137 E.00215
;WIDTH:0.608977
G1 X134.208 Y155.113 E.00233
;WIDTH:0.65199
G1 X134.152 Y155.09 E.00249
G1 X134.21 Y155.068 E.00255
;WIDTH:0.608977
G1 X134.268 Y155.047 E.00236
;WIDTH:0.565964
G1 X134.326 Y155.025 E.00219
;WIDTH:0.522951
G1 X134.384 Y155.004 E.002
;WIDTH:0.479938
G1 X134.442 Y154.982 E.00184
;WIDTH:0.436925
G1 X134.499 Y154.961 E.00163
;WIDTH:0.393912
G1 X134.557 Y154.939 E.00148
;WIDTH:0.394971
G1 X135.823 Y154.961 E.03038
;WIDTH:0.39431
G1 X136.355 Y154.943 E.01275
;WIDTH:0.357803
G1 X137.27 Y154.942 E.01969
G1 E-5 F3600
G1 X137.27 Y154.942 F9000
G1 X139.606 Y153.761
G1 X139.78 Y153.656
G1 X139.927 Y153.522
G1 X140.052 Y153.359
G1 X140.144 Y153.168
G1 X140.205 Y152.977
G1 X140.239 Y152.767
G1 X140.242 Y152.703
G1 X140.249 Y152.557
G1 X140.249 Y143.443
G1 X140.242 Y143.297
G1 X140.239 Y143.233
G1 X140.225 Y143.146
G1 X140.205 Y143.023
G1 X140.567 Y142.937
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X140.447 Y142.584 E.00907
G1 X140.135 Y142.154 E.01292
G1 X139.682 Y141.865 E.01307
G1 X139.292 Y141.777 E.00972
G1 X132.426 Y141.768 E.16701
G1 X133.358 Y141.11 E.02775
G1 X134.177 Y140.381 E.02667
G1 X134.709 Y139.818 E.01884
G1 X135.373 Y138.975 E.0261
G1 X135.856 Y138.233 E.02154
G1 X138.791 Y138.229 E.07139
G1 X139.514 Y138.191 E.01761
G1 X139.995 Y137.953 E.01305
G1 X140.214 Y137.753 E.00721
G1 X140.447 Y137.415 E.00999
G1 X140.567 Y137.084 E.00856
G1 X140.567 Y142.877 E.14091
G1 X140.567 Y142.877 F9000
G1 X140.202 Y141.758
G1 F6000
G1 X139.839 Y141.535 E.01036
G1 X139.292 Y141.411 E.01364
G1 X133.575 Y141.404 E.13906
G1 X134.443 Y140.633 E.02824
G1 X134.991 Y140.05 E.01946
G1 X135.671 Y139.187 E.02673
G1 X136.064 Y138.598 E.01722
G1 X139.258 Y138.594 E.07769
G1 X139.74 Y138.506 E.01192
G1 X140.201 Y138.246 E.01287
G1 X140.202 Y141.698 E.08397
G1 X140.202 Y141.698 F9000
G1 X139.836 Y141.168
G1 F6000
G1 X139.293 Y141.046 E.01354
G1 X134.543 Y141.04 E.11554
G1 X135.274 Y140.282 E.02561
G1 X135.968 Y139.4 E.0273
G1 X136.272 Y138.963 E.01295
G1 X139.258 Y138.96 E.07263
G1 X139.835 Y138.859 E.01425
G1 X139.836 Y141.108 E.0547
G1 E-5 F3600
G1 X139.836 Y141.108 F9000
G1 X140.559 Y134.917
G1 E5 F2400
;WIDTH:0.404739
G1 F6000
G1 X140.478 Y134.651 E.00685
G1 X140.271 Y134.304 E.00996
;WIDTH:0.399999
G1 X140.135 Y134.154 E.00492
G1 X139.758 Y133.907 E.01096
G1 X139.201 Y133.768 E.01396
G1 X137.36 Y133.767 E.04478
G1 X137.423 Y132.999 E.01874
G1 X137.429 Y130.231 E.06733
G1 X139.294 Y130.223 E.04536
G1 X139.682 Y130.135 E.00968
G1 X139.852 Y130.054 E.00458
G1 X140.272 Y129.696 E.01342
G1 X140.472 Y129.345 E.00983
G1 X140.565 Y129.039 E.00778
G1 X140.566 Y134.189 E.12527
;WIDTH:0.404739
G1 X140.56 Y134.857 E.01646
G1 X140.56 Y134.857 F9000
G1 X140.2 Y133.774
;WIDTH:0.399999
G1 F6000
G1 X139.877 Y133.561 E.00941
G1 X139.618 Y133.472 E.00666
G1 X139.201 Y133.402 E.01029
G1 X137.758 Y133.402 E.0351
G1 X137.788 Y133 E.00981
G1 X137.794 Y130.595 E.0585
G1 X139.296 Y130.589 E.03653
G1 X139.839 Y130.465 E.01355
G1 X140.2 Y130.244 E.0103
G1 X140.2 Y133.714 E.0844
G1 X140.2 Y133.714 F9000
G1 X139.835 Y133.16
G1 F6000
G1 X139.737 Y133.126 E.00252
G1 X139.202 Y133.037 E.01319
G1 X138.153 Y133.036 E.02552
G1 X138.159 Y130.959 E.05052
G1 X139.297 Y130.954 E.02768
G1 X139.834 Y130.832 E.01339
G1 X139.835 Y133.1 E.05517
G1 E-5 F3600
G1 X139.835 Y133.1 F9000
G1 X140.558 Y126.913
G1 E5 F2400
;WIDTH:0.404695
G1 F6000
G1 X140.478 Y126.651 E.00675
G1 X140.271 Y126.304 E.00995
;WIDTH:0.399999
G1 X140.135 Y126.154 E.00492
G1 X139.758 Y125.907 E.01096
G1 X139.202 Y125.768 E.01394
G1 X137.431 Y125.767 E.04308
G1 X137.431 Y122.23 E.08603
G1 X139.294 Y122.223 E.04532
G1 X139.683 Y122.135 E.0097
G1 X140.135 Y121.846 E.01305
G1 X140.447 Y121.416 E.01292
G1 X140.564 Y121.093 E.00836
G1 X140.565 Y126.19 E.12398
;WIDTH:0.404695
G1 X140.559 Y126.853 E.01633
G1 E-5 F3600
G1 X140.559 Y126.853 F9000
G1 X137.968 Y125.401
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.797 Y125.401 E.00416
G1 X137.797 Y122.595 E.06825
G1 X139.296 Y122.589 E.03646
G1 X139.839 Y122.465 E.01355
G1 X140.199 Y122.245 E.01026
G1 X140.199 Y125.773 E.08582
G1 X139.877 Y125.561 E.00938
G1 X139.618 Y125.472 E.00666
G1 X139.202 Y125.402 E.01026
G1 X138.028 Y125.401 E.02856
G1 X138.028 Y125.401 F9000
G1 X138.28 Y125.036
G1 F6000
G1 X138.163 Y125.036 E.00285
G1 X138.163 Y122.959 E.05052
G1 X139.297 Y122.954 E.02758
G1 X139.833 Y122.833 E.01337
G1 X139.833 Y125.16 E.0566
G1 X139.737 Y125.126 E.00248
G1 X139.202 Y125.037 E.01319
G1 X138.34 Y125.036 E.02097
G1 E-5 F3600
G1 X140.144 Y121.168 F9000
G1 X140.205 Y120.977
G1 X140.239 Y120.767
G1 X140.242 Y120.703
G1 X140.249 Y120.557
G1 X140.249 Y119.443
G1 X140.242 Y119.297
G1 X140.239 Y119.233
G1 X140.205 Y119.023
G1 X140.144 Y118.832
G1 X140.052 Y118.641
G1 X139.927 Y118.478
G1 X139.78 Y118.344
G1 X139.606 Y118.239
G1 X139.421 Y118.174
G1 X139.315 Y118.157
G1 X139.219 Y118.151
G1 X137.647 Y118.149
G1 X137.431 Y118.149
G1 X137.431 Y117.767
G1 E5 F2400
G1 F6000
G1 X137.431 Y114.23 E.08603
G1 X139.294 Y114.223 E.04532
G1 X139.683 Y114.135 E.0097
G1 X140.135 Y113.846 E.01305
G1 X140.447 Y113.416 E.01292
G1 X140.563 Y113.097 E.00826
G1 X140.564 Y118.922 E.14169
G1 X140.447 Y118.584 E.0087
G1 X140.212 Y118.245 E.01003
G1 X139.992 Y118.045 E.00723
G1 X139.577 Y117.829 E.01138
G1 X139.203 Y117.768 E.00922
G1 X137.491 Y117.767 E.04164
G1 X137.491 Y117.767 F9000
G1 X137.797 Y117.401
G1 F6000
G1 X137.797 Y114.595 E.06825
G1 X139.296 Y114.589 E.03646
G1 X139.839 Y114.465 E.01355
G1 X140.197 Y114.246 E.01021
G1 X140.198 Y117.753 E.0853
G1 X139.657 Y117.473 E.01482
G1 X139.203 Y117.402 E.01118
G1 X137.857 Y117.401 E.03274
G1 X137.857 Y117.401 F9000
G1 X138.163 Y117.036
G1 F6000
G1 X138.163 Y114.959 E.05052
G1 X139.297 Y114.954 E.02758
G1 X139.832 Y114.833 E.01334
G1 X139.832 Y117.165 E.05672
G1 X139.737 Y117.116 E.0026
G1 X139.203 Y117.037 E.01313
G1 X138.223 Y117.036 E.02384
G1 E-5 F3600
G1 X138.223 Y117.036 F9000
G1 X140.052 Y113.359
G1 X140.144 Y113.168
G1 X140.205 Y112.977
G1 X140.239 Y112.767
G1 X140.242 Y112.703
G1 X140.249 Y112.557
G1 X140.249 Y111.443
G1 X140.242 Y111.297
G1 X140.239 Y111.233
G1 X140.225 Y111.146
G1 X140.205 Y111.023
G1 X140.563 Y110.917
G1 E5 F2400
G1 F6000
G1 X140.447 Y110.584 E.00858
G1 X140.212 Y110.245 E.01003
G1 X139.992 Y110.045 E.00723
G1 X139.577 Y109.829 E.01138
G1 X139.203 Y109.768 E.00922
G1 X137.431 Y109.767 E.0431
G1 X137.431 Y106.23 E.08603
G1 X139.294 Y106.223 E.04532
G1 X139.682 Y106.135 E.00968
G1 X140.135 Y105.846 E.01307
G1 X140.447 Y105.416 E.01292
G1 X140.562 Y105.102 E.00813
G1 X140.563 Y110.857 E.13998
G1 E-5 F3600
G1 X140.563 Y110.857 F9000
G1 X138.254 Y109.402
G1 E5 F2400
G1 F6000
G1 X137.797 Y109.401 E.01112
G1 X137.797 Y106.595 E.06825
G1 X139.296 Y106.589 E.03646
G1 X139.839 Y106.465 E.01355
G1 X140.196 Y106.246 E.01019
G1 X140.197 Y109.753 E.0853
G1 X139.657 Y109.473 E.0148
G1 X139.203 Y109.402 E.01118
G1 X138.314 Y109.402 E.02162
G1 X138.314 Y109.402 F9000
G1 X138.398 Y109.036
G1 F6000
G1 X138.163 Y109.036 E.00572
G1 X138.163 Y106.959 E.05052
G1 X139.297 Y106.954 E.02758
G1 X139.831 Y106.833 E.01332
G1 X139.831 Y109.165 E.05672
G1 X139.737 Y109.116 E.00258
G1 X139.203 Y109.037 E.01313
G1 X138.458 Y109.036 E.01812
G1 E-5 F3600
G1 X138.458 Y109.036 F9000
G1 X140.144 Y105.168
G1 X140.205 Y104.977
G1 X140.239 Y104.767
G1 X140.242 Y104.703
G1 X140.249 Y104.557
G1 X140.249 Y103.443
G1 X140.242 Y103.297
G1 X140.239 Y103.233
G1 X140.205 Y103.023
G1 X140.144 Y102.832
G1 X140.052 Y102.641
G1 X139.927 Y102.478
G1 X139.78 Y102.344
G1 X139.606 Y102.239
G1 X139.421 Y102.174
G1 X139.315 Y102.157
G1 X139.219 Y102.151
G1 X137.647 Y102.149
G1 X137.431 Y102.149
G1 X137.431 Y101.767
G1 E5 F2400
G1 F6000
G1 X137.431 Y97.043 E.11491
G1 X139.242 Y97.041 E.04405
G1 X139.727 Y96.934 E.01208
G1 X140.046 Y96.761 E.00883
G1 X140.388 Y96.402 E.01206
;WIDTH:0.412418
G1 X140.542 Y96.126 E.00795
G1 X140.56 Y96.448 E.00811
;WIDTH:0.399999
G1 X140.561 Y102.912 E.15723
G1 X140.447 Y102.584 E.00845
G1 X140.212 Y102.245 E.01003
G1 X139.992 Y102.045 E.00723
G1 X139.577 Y101.829 E.01138
G1 X139.203 Y101.768 E.00922
G1 X137.491 Y101.767 E.04164
G1 X137.491 Y101.767 F9000
G1 X137.797 Y101.401
G1 F6000
G1 X137.797 Y97.409 E.0971
G1 X139.242 Y97.407 E.03515
G1 X139.834 Y97.284 E.01471
G1 X140.195 Y97.088 E.00999
G1 X140.195 Y101.752 E.11345
G1 X139.657 Y101.473 E.01474
G1 X139.203 Y101.402 E.01118
G1 X137.857 Y101.401 E.03274
G1 X137.857 Y101.401 F9000
G1 X138.163 Y101.036
G1 F6000
G1 X138.163 Y97.774 E.07934
G1 X139.242 Y97.773 E.02625
G1 X139.829 Y97.668 E.0145
G1 X139.83 Y101.164 E.08504
G1 X139.737 Y101.116 E.00255
G1 X139.203 Y101.037 E.01313
G1 X138.223 Y101.036 E.02384
G1 E-5 F3600
G1 X138.223 Y101.036 F9000
G1 X140.188 Y95.972
G1 X140.235 Y95.795
G1 X140.249 Y95.636
G1 X140.249 Y93.193
G1 X140.235 Y93.034
G1 X140.188 Y92.857
G1 X140.11 Y92.691
G1 X140.005 Y92.541
G1 X139.876 Y92.411
G1 X139.726 Y92.306
G1 X139.56 Y92.229
G1 X126.349 Y88.151
G1 X121.704 Y88.151
G1 X119.951 Y86.599
G1 X119.868 Y86.72
G1 E5 F2400
G1 F6000
G1 X119.908 Y86.72 E.00097
G1 X119.957 Y86.815 E.0026
G1 X120.483 Y86.981 E.01342
G1 X127.202 Y86.963 E.16343
G1 X127.904 Y86.852 E.01729
G1 X128.868 Y86.521 E.02479
G1 X129.724 Y86.017 E.02416
G1 X130.187 Y85.632 E.01465
G1 X130.669 Y85.1 E.01746
G1 X131.227 Y84.209 E.02557
G1 X131.579 Y83.257 E.02469
G1 X131.689 Y82.675 E.01441
G1 X131.731 Y82.051 E.01521
G1 X131.731 Y79.377 E.06504
G1 X133.162 Y78.174 E.04547
G1 X133.372 Y77.886 E.00867
G1 X133.457 Y77.537 E.00874
G1 X133.366 Y77.1 E.01086
G1 X133.132 Y76.8 E.00925
G1 X131.714 Y75.609 E.04504
G1 X131.699 Y75.495 E.0028
G1 X131.426 Y75.054 E.01262
G1 X131.134 Y74.942 E.00761
G1 X135.789 Y74.942 E.11323
G1 X136.712 Y75.082 E.02271
G1 X137.579 Y75.381 E.02231
G1 X138.377 Y75.832 E.0223
G1 X139.082 Y76.419 E.02231
G1 X139.668 Y77.123 E.02228
G1 X140.119 Y77.922 E.02232
G1 X140.418 Y78.788 E.02228
G1 X140.513 Y79.417 E.01547
G1 X140.558 Y80.003 E.0143
G1 X140.56 Y92.826 E.31191
G1 X140.296 Y92.312 E.01406
G1 X140.107 Y92.123 E.0065
G1 X139.699 Y91.887 E.01146
G1 X139.202 Y91.785 E.01234
G1 X127.437 Y91.784 E.28617
G1 X128.132 Y91.2 E.02208
G1 X128.43 Y90.723 E.01368
G1 X128.443 Y90.339 E.00935
G1 X128.363 Y90.095 E.00625
G1 X128.132 Y89.8 E.00911
G1 X126.719 Y88.613 E.04489
G1 X126.679 Y88.379 E.00577
G1 X126.531 Y88.112 E.00743
G1 X126.233 Y87.869 E.00935
G1 X125.817 Y87.769 E.01041
G1 X105.183 Y87.769 E.5019
G1 X105.025 Y87.782 E.00386
G1 X104.581 Y87.995 E.01198
G1 X104.361 Y88.283 E.00882
G1 X104.281 Y88.613 E.00826
G1 X102.868 Y89.8 E.04489
G1 X102.691 Y90 E.0065
G1 X102.557 Y90.338 E.00884
G1 X102.57 Y90.722 E.00935
G1 X102.868 Y91.2 E.0137
G1 X103.563 Y91.784 E.02208
G1 X91.798 Y91.785 E.28617
G1 X91.462 Y91.83 E.00825
G1 X91.011 Y92.028 E.01198
G1 X90.652 Y92.37 E.01206
G1 X90.433 Y92.809 E.01193
G1 X90.431 Y80.028 E.31089
G1 X90.47 Y79.389 E.01557
G1 X90.58 Y78.787 E.01489
G1 X90.762 Y78.203 E.01488
G1 X91.013 Y77.645 E.01488
G1 X91.33 Y77.122 E.01488
G1 X91.707 Y76.64 E.01488
G1 X92.14 Y76.207 E.01489
G1 X92.622 Y75.83 E.01488
G1 X93.145 Y75.514 E.01486
G1 X93.706 Y75.261 E.01497
G1 X94.274 Y75.084 E.01447
G1 X95.208 Y74.942 E.02298
G1 X99.804 Y74.942 E.11179
G1 X99.574 Y75.054 E.00622
G1 X99.301 Y75.495 E.01262
G1 X99.286 Y75.609 E.0028
G1 X97.868 Y76.8 E.04504
G1 X97.634 Y77.101 E.00927
G1 X97.549 Y77.392 E.00737
G1 X97.548 Y77.605 E.00518
G1 X97.648 Y77.926 E.00818
G1 X97.868 Y78.2 E.00855
G1 X99.27 Y79.378 E.04454
G1 X99.293 Y82.49 E.0757
G1 X99.497 Y83.515 E.02542
G1 X99.91 Y84.473 E.02538
G1 X100.454 Y85.25 E.02307
G1 X101.2 Y85.958 E.02502
G1 X101.921 Y86.418 E.0208
G1 X102.333 Y86.597 E.01093
G1 X102.919 Y86.81 E.01517
G1 X103.585 Y86.941 E.01651
G1 X104.199 Y86.981 E.01497
G1 X110.517 Y86.981 E.15368
G1 X110.675 Y86.968 E.00386
G1 X111.043 Y86.815 E.00969
G1 X111.092 Y86.72 E.0026
G1 X119.808 Y86.72 E.21201
G1 E-5 F3600
G1 X119.808 Y86.72 F9000
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X105.183 Y87.375 E.0067
;WIDTH:0.456022
G1 X110.517 Y87.375 E.14962
;WIDTH:0.47584
G1 X110.745 Y87.365 E.0067
G1 X110.745 Y87.365 F9000
G1 X110.773 Y87.349
G1 F6000
G1 X111.003 Y87.219 E.00776
;WIDTH:0.425841
G1 X111.262 Y87.074 E.00773
;WIDTH:0.375842
G1 X119.656 Y87.074 E.19069
G1 X119.754 Y87.105 E.00234
;WIDTH:0.41592
G1 X120.119 Y87.24 E.00988
;WIDTH:0.455998
G1 X120.483 Y87.375 E.01089
G1 X120.069 Y87.395 E.01163
;WIDTH:0.41592
G1 X119.656 Y87.415 E.0105
;WIDTH:0.375842
G1 X111.344 Y87.415 E.18882
;WIDTH:0.425841
G1 X111.044 Y87.39 E.00784
;WIDTH:0.47584
G1 X110.773 Y87.367 E.00799
G1 E-5 F3600
G1 X110.773 Y87.367 F9000
G1 X125.817 Y87.371
G1 E5 F2400
;WIDTH:0.463712
G1 F6000
G1 X120.485 Y87.375 E.15229
;WIDTH:0.455998
G1 X120.483 Y87.375 E.00006
G1 E-5 F3600
G1 X120.483 Y87.375 F9000
G1 X125.817 Y87.371
G1 E5 F2400
;WIDTH:0.463712
G1 F6000
G1 X126.132 Y87.355 E.00901
;WIDTH:0.431856
G1 X126.448 Y87.338 E.00837
;WIDTH:0.399999
G1 X127.253 Y87.325 E.01958
G1 X128.016 Y87.2 E.01881
G1 X129.05 Y86.838 E.02665
G1 X129.953 Y86.301 E.02555
G1 X130.453 Y85.883 E.01585
G1 X130.974 Y85.301 E.019
G1 X131.569 Y84.34 E.02749
G1 X131.937 Y83.33 E.02615
G1 X132.054 Y82.701 E.01556
G1 X132.097 Y82.051 E.01585
G1 X132.097 Y79.547 E.06091
G1 X133.367 Y78.48 E.04035
G1 X133.637 Y78.165 E.01009
G1 X133.786 Y77.805 E.00948
G1 X133.814 Y77.348 E.01114
G1 X133.695 Y76.941 E.01031
G1 X133.367 Y76.52 E.01298
G1 X132.075 Y75.434 E.04105
G1 X131.996 Y75.308 E.00362
G1 X135.762 Y75.308 E.0916
G1 X136.625 Y75.439 E.02123
G1 X137.428 Y75.716 E.02066
G1 X138.169 Y76.134 E.02069
G1 X138.822 Y76.678 E.02067
G1 X139.366 Y77.332 E.02069
G1 X139.784 Y78.072 E.02067
G1 X140.061 Y78.876 E.02068
G1 X140.152 Y79.472 E.01467
G1 X140.192 Y80.003 E.01295
G1 X140.194 Y91.765 E.2861
G1 X139.795 Y91.534 E.01121
G1 X139.202 Y91.419 E.01469
G1 X128.405 Y91.419 E.26263
G1 X128.785 Y90.812 E.01742
G1 X128.803 Y90.274 E.01309
G1 X128.691 Y89.933 E.00873
G1 X128.531 Y89.686 E.00716
G1 X128.367 Y89.52 E.00568
G1 X127.051 Y88.414 E.04181
G1 X127.024 Y88.257 E.00387
G1 X126.817 Y87.883 E.0104
G1 X126.399 Y87.543 E.01311
;WIDTH:0.431856
G1 X126.108 Y87.457 E.00802
;WIDTH:0.463712
G1 X125.875 Y87.388 E.00694
G1 X125.875 Y87.388 F9000
G1 X127.133 Y87.699
;WIDTH:0.399999
G1 F6000
G1 X127.303 Y87.687 E.00415
G1 X128.127 Y87.548 E.02033
G1 X128.916 Y87.295 E.02015
G1 X129.232 Y87.155 E.00841
G1 X130.183 Y86.585 E.02697
G1 X130.719 Y86.134 E.01704
G1 X131.28 Y85.501 E.02057
G1 X131.75 Y84.785 E.02083
G1 X131.911 Y84.471 E.00858
G1 X132.295 Y83.403 E.02761
G1 X132.419 Y82.727 E.01672
G1 X132.463 Y82.051 E.01648
G1 X132.463 Y79.717 E.05677
G1 X133.602 Y78.76 E.03619
G1 X133.811 Y78.549 E.00722
G1 X134.036 Y78.194 E.01022
G1 X134.17 Y77.748 E.01133
G1 X134.177 Y77.304 E.0108
G1 X134.024 Y76.781 E.01325
G1 X133.602 Y76.24 E.01669
G1 X132.928 Y75.674 E.02141
G1 X135.734 Y75.674 E.06825
G1 X136.537 Y75.795 E.01975
G1 X137.277 Y76.051 E.01905
G1 X137.96 Y76.436 E.01907
G1 X138.562 Y76.938 E.01907
G1 X139.064 Y77.54 E.01907
G1 X139.449 Y78.223 E.01907
G1 X139.705 Y78.964 E.01907
G1 X139.826 Y80.003 E.02544
G1 X139.828 Y91.164 E.27148
G1 X139.202 Y91.054 E.01546
G1 X129.045 Y91.053 E.24706
G1 X129.139 Y90.901 E.00435
G1 X129.163 Y90.21 E.01682
G1 X129.019 Y89.77 E.01126
G1 X128.813 Y89.454 E.00918
G1 X128.602 Y89.24 E.00731
G1 X127.383 Y88.215 E.03874
G1 X127.369 Y88.135 E.00198
G1 X127.161 Y87.752 E.0106
G1 E-5 F3600
G1 X127.161 Y87.752 F9000
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X104.647 Y87.552 E.01029
;WIDTH:0.43792
G1 X104.34 Y87.72 E.0094
;WIDTH:0.399999
G1 X104.032 Y88.122 E.01232
G1 X103.949 Y88.414 E.00738
G1 X102.633 Y89.52 E.04181
G1 X102.385 Y89.8 E.0091
G1 X102.197 Y90.273 E.01238
G1 X102.215 Y90.811 E.01309
G1 X102.595 Y91.419 E.01744
G1 X91.798 Y91.419 E.26263
G1 X91.573 Y91.439 E.00549
G1 X90.984 Y91.622 E.015
G1 X90.799 Y91.736 E.00529
G1 X90.797 Y80.039 E.28452
G1 X90.834 Y79.433 E.01477
G1 X90.936 Y78.875 E.0138
G1 X91.105 Y78.333 E.01381
G1 X91.338 Y77.815 E.01382
G1 X91.631 Y77.33 E.01378
G1 X91.982 Y76.883 E.01382
G1 X92.383 Y76.482 E.01379
G1 X92.83 Y76.131 E.01382
G1 X93.315 Y75.838 E.01378
G1 X93.836 Y75.604 E.01389
G1 X94.357 Y75.442 E.01327
G1 X95.236 Y75.308 E.02163
G1 X99.004 Y75.308 E.09165
G1 X98.946 Y75.417 E.003
G1 X97.633 Y76.52 E.04171
G1 X97.305 Y76.941 E.01298
G1 X97.186 Y77.349 E.01034
G1 X97.198 Y77.731 E.0093
G1 X97.343 Y78.132 E.01037
G1 X97.633 Y78.48 E.01102
G1 X98.905 Y79.549 E.04042
G1 X98.933 Y82.554 E.0731
G1 X99.158 Y83.654 E.02731
G1 X99.606 Y84.677 E.02716
G1 X100.197 Y85.51 E.02484
G1 X101.003 Y86.266 E.02688
G1 X101.725 Y86.727 E.02084
G1 X102.202 Y86.938 E.01269
G1 X102.844 Y87.168 E.01659
G1 X103.56 Y87.306 E.01774
G1 X104.199 Y87.347 E.01557
;WIDTH:0.43792
G1 X104.577 Y87.366 E.01016
;WIDTH:0.47584
G1 X104.895 Y87.382 E.00935
G1 X104.895 Y87.382 F9000
G1 X103.893 Y87.695
;WIDTH:0.399999
G1 F6000
G1 X103.703 Y87.962 E.00797
G1 X103.617 Y88.215 E.0065
G1 X102.286 Y89.343 E.04244
G1 X101.982 Y89.769 E.01273
G1 X101.837 Y90.209 E.01127
G1 X101.86 Y90.9 E.01682
G1 X101.956 Y91.053 E.00439
G1 X91.798 Y91.054 E.24708
G1 X91.509 Y91.079 E.00706
G1 X91.164 Y91.172 E.00869
G1 X91.163 Y80.792 E.25248
G1 X91.186 Y79.666 E.02739
G1 X91.258 Y79.146 E.01277
G1 X91.393 Y78.637 E.01281
G1 X91.589 Y78.148 E.01281
G1 X91.844 Y77.685 E.01286
G1 X92.153 Y77.256 E.01286
G1 X92.514 Y76.868 E.01289
G1 X92.92 Y76.525 E.01293
G1 X93.365 Y76.235 E.01292
G1 X93.849 Y75.999 E.0131
G1 X94.439 Y75.799 E.01515
G1 X95.263 Y75.674 E.02027
G1 X98.072 Y75.674 E.06833
G1 X97.398 Y76.24 E.02141
G1 X96.976 Y76.781 E.01669
G1 X96.822 Y77.305 E.01328
G1 X96.813 Y77.59 E.00694
G1 X96.88 Y77.971 E.00941
G1 X97.076 Y78.396 E.01138
G1 X97.398 Y78.76 E.01182
G1 X98.54 Y79.719 E.03627
G1 X98.545 Y81.426 E.04152
G1 X98.572 Y82.614 E.0289
G1 X98.722 Y83.456 E.0208
G1 X98.82 Y83.793 E.00854
G1 X99.147 Y84.588 E.02091
G1 X99.303 Y84.881 E.00807
G1 X99.94 Y85.77 E.0266
G1 X100.536 Y86.358 E.02036
G1 X100.806 Y86.574 E.00841
G1 X101.528 Y87.035 E.02084
G1 X102.07 Y87.279 E.01446
G1 X102.769 Y87.526 E.01803
G1 X103.348 Y87.647 E.01439
G1 X103.833 Y87.69 E.01184
G1 X103.833 Y87.69 F9000
G1 X103.343 Y88.302
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X102.867 Y87.826 E.01637
G1 X102.109 Y87.588 E.01933
G1 X102.944 Y88.423 E.02872
G1 X102.662 Y88.66 E.00896
G1 X91.984 Y77.983 E.3673
G1 X91.809 Y78.327 E.00939
G1 X102.379 Y88.898 E.36362
G1 X102.102 Y89.14 E.00895
G1 X91.661 Y78.699 E.35916
G1 X91.545 Y79.102 E.0102
G1 X101.868 Y89.426 E.35512
G1 X101.694 Y89.772 E.00942
G1 X91.468 Y79.545 E.35179
G1 X91.438 Y80.035 E.01194
G1 X101.565 Y90.162 E.34836
G1 X101.583 Y90.7 E.01309
G1 X91.437 Y80.553 E.34903
G1 X91.437 Y81.073 E.01265
G1 X101.143 Y90.779 E.33388
G1 X100.623 Y90.779 E.01265
G1 X91.437 Y81.593 E.31599
G1 X91.437 Y82.113 E.01265
G1 X100.103 Y90.779 E.29811
G1 X99.584 Y90.779 E.01262
G1 X91.437 Y82.632 E.28025
G1 X91.437 Y83.152 E.01265
G1 X99.064 Y90.779 E.26236
G1 X98.545 Y90.779 E.01262
G1 X91.437 Y83.672 E.24449
G1 X91.438 Y84.191 E.01262
G1 X98.025 Y90.779 E.22661
G1 X97.505 Y90.779 E.01265
G1 X91.438 Y84.711 E.20872
G1 X91.438 Y85.231 E.01265
G1 X96.986 Y90.779 E.19085
G1 X96.466 Y90.779 E.01265
G1 X91.438 Y85.751 E.17296
G1 X91.438 Y86.27 E.01262
G1 X95.946 Y90.779 E.15509
G1 X95.427 Y90.779 E.01262
G1 X91.438 Y86.79 E.13722
G1 X91.438 Y87.31 E.01265
G1 X94.907 Y90.779 E.11933
G1 X94.388 Y90.779 E.01262
G1 X91.438 Y87.83 E.10146
G1 X91.438 Y88.349 E.01262
G1 X93.868 Y90.779 E.08359
G1 X93.348 Y90.779 E.01265
G1 X91.438 Y88.869 E.0657
G1 X91.438 Y89.389 E.01265
G1 X92.829 Y90.779 E.04783
G1 X92.309 Y90.779 E.01265
G1 X91.438 Y89.908 E.02996
G1 X91.438 Y90.428 E.01265
G1 X91.954 Y90.944 E.01775
G1 E-5 F3600
G1 X91.954 Y90.944 F9000
G1 X90.89 Y92.691
G1 X90.813 Y92.857
G1 X90.765 Y93.034
G1 X90.751 Y93.193
G1 X90.751 Y95.636
G1 X90.765 Y95.795
G1 X90.813 Y95.972
G1 X90.89 Y96.138
G1 X90.995 Y96.288
G1 X92.728 Y98.628
G1 E5 F2400
G1 F3072.127
G1 X92.149 Y98.049 E.01992
G1 X91.612 Y98.033 E.01307
G1 X92.563 Y98.984 E.03271
G1 X92.563 Y99.504 E.01265
G1 X91.44 Y98.38 E.03865
G1 X91.44 Y98.9 E.01265
G1 X92.563 Y100.024 E.03865
G1 X92.563 Y100.544 E.01265
G1 X91.44 Y99.42 E.03865
G1 X91.44 Y99.94 E.01265
G1 X92.269 Y100.769 E.02852
G1 X91.751 Y100.771 E.0126
G1 X91.275 Y100.296 E.01636
G1 E-5 F3600
G1 X91.275 Y100.296 F9000
G1 X90.795 Y103.023
G1 X90.761 Y103.233
G1 X90.758 Y103.297
G1 X90.751 Y103.443
G1 X90.751 Y104.557
G1 X90.758 Y104.703
G1 X90.761 Y104.767
G1 X90.795 Y104.977
G1 X90.856 Y105.168
G1 X90.948 Y105.359
G1 X92.728 Y107.91
G1 E5 F2400
G1 F3072.127
G1 X92.056 Y107.238 E.02312
G1 X91.441 Y107.199 E.01499
G1 X92.563 Y108.327 E.0387
G1 X92.563 Y108.768 E.01073
G1 X92.423 Y108.768 E.00341
G1 X91.441 Y107.786 E.03378
G1 X91.441 Y108.368 E.01416
G1 X92.008 Y108.935 E.0195
G1 E-5 F3600
G1 X92.008 Y108.935 F9000
G1 X90.948 Y110.641
G1 X90.856 Y110.832
G1 X90.795 Y111.023
G1 X90.761 Y111.233
G1 X90.758 Y111.297
G1 X90.751 Y111.443
G1 X90.751 Y112.557
G1 X90.758 Y112.703
G1 X90.761 Y112.767
G1 X90.795 Y112.977
G1 X90.856 Y113.168
G1 X90.948 Y113.359
G1 X92.728 Y115.904
G1 E5 F2400
G1 F3072.127
G1 X92.061 Y115.238 E.02293
G1 X91.444 Y115.199 E.01504
G1 X92.563 Y116.318 E.03849
G1 X92.563 Y116.762 E.0108
G1 X92.429 Y116.762 E.00326
G1 X91.442 Y115.775 E.03395
G1 X91.442 Y116.353 E.01406
G1 X92.016 Y116.927 E.01975
G1 E-5 F3600
G1 X92.016 Y116.927 F9000
G1 X90.948 Y118.641
G1 X90.856 Y118.832
G1 X90.795 Y119.023
G1 X90.761 Y119.233
G1 X90.758 Y119.297
G1 X90.751 Y119.443
G1 X90.751 Y120.557
G1 X90.758 Y120.703
G1 X90.761 Y120.767
G1 X90.795 Y120.977
G1 X90.856 Y121.168
G1 X90.948 Y121.359
G1 X92.728 Y123.9
G1 E5 F2400
G1 F3072.127
G1 X92.058 Y123.23 E.02305
G1 X91.443 Y123.172 E.01503
G1 X92.563 Y124.314 E.03891
G1 X92.563 Y124.762 E.0109
G1 X92.432 Y124.762 E.00319
G1 X91.443 Y123.773 E.03402
G1 X91.443 Y124.352 E.01408
G1 X92.018 Y124.927 E.01978
G1 E-5 F3600
G1 X92.018 Y124.927 F9000
G1 X90.948 Y126.641
G1 X90.856 Y126.832
G1 X90.795 Y127.023
G1 X90.761 Y127.233
G1 X90.758 Y127.297
G1 X90.751 Y127.443
G1 X90.751 Y128.557
G1 X90.758 Y128.703
G1 X90.761 Y128.767
G1 X90.795 Y128.977
G1 X90.856 Y129.168
G1 X90.948 Y129.359
G1 X92.733 Y131.902
G1 E5 F2400
G1 F3072.127
G1 X92.062 Y131.23 E.0231
G1 X91.445 Y131.172 E.01507
G1 X92.57 Y132.317 E.03904
G1 X92.571 Y132.762 E.01082
G1 X92.436 Y132.762 E.00328
G1 X91.445 Y131.771 E.03409
G1 X91.445 Y132.35 E.01408
G1 X92.021 Y132.927 E.01983
G1 E-5 F3600
G1 X92.021 Y132.927 F9000
G1 X90.948 Y134.641
G1 X90.856 Y134.832
G1 X90.795 Y135.023
G1 X90.761 Y135.233
G1 X90.758 Y135.297
G1 X90.751 Y135.443
G1 X90.751 Y136.557
G1 X90.758 Y136.703
G1 X90.761 Y136.767
G1 X90.795 Y136.977
G1 X91.954 Y140.936
G1 E5 F2400
G1 F3072.127
G1 X91.446 Y140.427 E.01749
G1 X91.446 Y139.886 E.01316
G1 X92.331 Y140.771 E.03044
G1 X92.871 Y140.77 E.01314
G1 X91.446 Y139.344 E.04904
G1 X91.446 Y139.192 E.0037
G1 X91.877 Y139.234 E.01053
G1 X93.412 Y140.769 E.0528
G1 X93.953 Y140.769 E.01316
G1 X92.419 Y139.235 E.05277
G1 X92.961 Y139.235 E.01318
G1 X94.494 Y140.768 E.05273
G1 X95.035 Y140.767 E.01316
G1 X93.504 Y139.236 E.05267
G1 X94.046 Y139.237 E.01318
G1 X95.74 Y140.931 E.05827
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X94.046 Y139.237 E-1.13795
G1 X93.504 Y139.236 E-.25745
G1 X93.66 Y139.392 E-.1046
;WIPE_END
G1 X96.202 Y147.217 F9000
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.410174
G1 F1200
G1 X97.148 Y147.243 E.02366
G1 X105.44 Y147.243 E.20731
;WIDTH:0.452914
G1 X105.96 Y147.194 E.01454
;WIDTH:0.502116
G1 X106.444 Y147.018 E.01603
;WIDTH:0.506984
G1 X106.914 Y146.634 E.01908
G1 X107.16 Y146.279 E.01358
;WIDTH:0.491118
G1 X107.23 Y146.077 E.0065
;WIDTH:0.463627
G1 X107.3 Y145.876 E.00608
;WIDTH:0.436136
G1 X107.363 Y145.346 E.01427
;WIDTH:0.39798
G1 X107.367 Y144.535 E.01962
G1 E-5 F3600
G1 X107.367 Y144.535 F9000
G1 X111.369 Y144.344
G1 E5 F2400
;WIDTH:0.4362
G1 F1200
G1 X119.632 Y144.343 E.22089
G1 E-5 F3600
G1 X119.632 Y144.343 F9000
G1 X123.438 Y145
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X122.974 Y144.536 E.01596
G1 X122.452 Y144.535 E.0127
G1 X123.273 Y145.357 E.02826
G1 X123.322 Y145.927 E.01392
G1 X121.929 Y144.535 E.0479
G1 X121.407 Y144.534 E.0127
G1 X125.262 Y148.389 E.13261
G1 X124.809 Y148.457 E.01114
G1 X120.884 Y144.533 E.135
G1 X120.362 Y144.532 E.0127
G1 X124.417 Y148.587 E.13949
G1 X124.087 Y148.779 E.00929
G1 X120.034 Y144.727 E.1394
G1 X119.513 Y144.727 E.01267
G1 X123.822 Y149.036 E.14823
G1 X123.594 Y149.329 E.00903
G1 X118.991 Y144.727 E.15832
G1 X118.47 Y144.727 E.01267
G1 X123.411 Y149.668 E.16997
G1 X123.306 Y150.085 E.01046
G1 X117.948 Y144.727 E.18431
G1 X117.426 Y144.727 E.0127
G1 X123.281 Y150.581 E.20139
G1 X123.28 Y151.102 E.01267
G1 X116.905 Y144.727 E.2193
G1 X116.383 Y144.727 E.0127
G1 X123.278 Y151.622 E.23718
G1 X123.277 Y152.142 E.01265
G1 X115.862 Y144.727 E.25507
G1 X115.34 Y144.727 E.0127
G1 X123.275 Y152.662 E.27296
G1 X123.274 Y153.183 E.01267
G1 X114.819 Y144.727 E.29086
G1 X114.297 Y144.727 E.0127
G1 X123.287 Y153.717 E.30925
G1 X123.471 Y154.423 E.01775
G1 X113.775 Y144.727 E.33354
G1 X113.254 Y144.727 E.01267
G1 X123.097 Y154.571 E.33861
G1 X122.576 Y154.571 E.01267
G1 X112.732 Y144.727 E.33863
G1 X112.211 Y144.728 E.01267
G1 X122.054 Y154.571 E.33859
G1 X121.532 Y154.571 E.0127
G1 X111.689 Y144.728 E.33859
G1 X111.167 Y144.728 E.0127
G1 X121.011 Y154.571 E.33861
G1 X120.489 Y154.571 E.0127
G1 X110.451 Y144.533 E.3453
G1 X109.93 Y144.533 E.01267
G1 X119.967 Y154.571 E.34528
G1 X119.446 Y154.571 E.01267
G1 X109.409 Y144.534 E.34527
G1 X108.888 Y144.535 E.01267
G1 X118.924 Y154.571 E.34523
G1 X118.402 Y154.571 E.0127
G1 X108.367 Y144.536 E.3452
G1 X107.846 Y144.536 E.01267
G1 X117.881 Y154.571 E.3452
G1 X117.359 Y154.571 E.0127
G1 X107.73 Y144.942 E.33123
G1 X107.728 Y145.461 E.01262
G1 X116.837 Y154.571 E.31336
G1 X116.316 Y154.571 E.01267
G1 X107.689 Y145.945 E.29675
G1 X107.574 Y146.351 E.01026
G1 X115.794 Y154.571 E.28276
G1 X115.272 Y154.571 E.0127
G1 X107.394 Y146.693 E.271
G1 X107.161 Y146.981 E.00901
G1 X114.751 Y154.571 E.26109
G1 X114.229 Y154.571 E.0127
G1 X106.892 Y147.234 E.25239
G1 X106.556 Y147.42 E.00934
G1 X113.708 Y154.571 E.24601
G1 X113.186 Y154.571 E.0127
G1 X106.163 Y147.548 E.24159
G1 X105.705 Y147.612 E.01125
G1 X112.664 Y154.571 E.23939
G1 X112.143 Y154.571 E.01267
G1 X107.711 Y150.139 E.15246
G1 X107.718 Y150.669 E.01289
G1 X111.621 Y154.571 E.13424
G1 X111.099 Y154.571 E.0127
G1 X107.72 Y151.192 E.11624
G1 X107.722 Y151.715 E.01272
G1 X110.578 Y154.571 E.09824
G1 X110.056 Y154.571 E.0127
G1 X107.723 Y152.238 E.08025
G1 X107.725 Y152.762 E.01275
G1 X109.534 Y154.571 E.06223
G1 X109.013 Y154.571 E.01267
G1 X107.726 Y153.285 E.04425
G1 X107.702 Y153.782 E.0121
G1 X108.491 Y154.571 E.02714
G1 X107.969 Y154.571 E.0127
G1 X107.615 Y154.217 E.01218
G1 X107.437 Y154.56 E.0094
G1 X107.612 Y154.736 E.00604
G1 E-5 F3600
G1 X107.612 Y154.736 F9000
G1 X106.189 Y148.618
G1 E5 F2400
G1 F3072.127
G1 X105.183 Y147.612 E.03461
G1 X104.662 Y147.612 E.01267
G1 X105.438 Y148.388 E.02669
G1 X104.917 Y148.389 E.01267
G1 X104.14 Y147.612 E.02673
G1 X103.619 Y147.612 E.01267
G1 X104.395 Y148.389 E.02671
G1 X103.874 Y148.389 E.01267
G1 X103.097 Y147.613 E.02671
G1 X102.576 Y147.613 E.01267
G1 X103.352 Y148.389 E.02669
G1 X102.831 Y148.39 E.01267
G1 X102.054 Y147.613 E.02673
G1 X101.533 Y147.613 E.01267
G1 X102.31 Y148.39 E.02673
G1 X101.788 Y148.39 E.0127
G1 X101.011 Y147.613 E.02673
G1 X100.49 Y147.613 E.01267
G1 X101.267 Y148.39 E.02673
G1 X100.746 Y148.391 E.01267
G1 X99.968 Y147.613 E.02676
G1 X99.447 Y147.614 E.01267
G1 X100.224 Y148.391 E.02673
G1 X99.703 Y148.391 E.01267
G1 X98.925 Y147.614 E.02675
G1 X98.404 Y147.614 E.01267
G1 X99.181 Y148.391 E.02673
G1 X98.66 Y148.392 E.01267
G1 X97.882 Y147.614 E.02676
G1 X97.361 Y147.614 E.01267
G1 X98.139 Y148.392 E.02676
G1 X97.617 Y148.392 E.0127
G1 X96.821 Y147.597 E.02736
G1 X96.27 Y147.566 E.01342
G1 X97.096 Y148.393 E.02843
G1 X96.594 Y148.412 E.01222
G1 X95.419 Y147.238 E.0404
G1 X94.898 Y147.238 E.01267
G1 X96.099 Y148.439 E.04131
G1 X95.67 Y148.463 E.01045
G1 X95.672 Y148.534 E.00173
G1 X94.376 Y147.238 E.04458
G1 X93.854 Y147.238 E.0127
G1 X95.385 Y148.769 E.05267
G1 X94.864 Y148.769 E.01267
G1 X93.333 Y147.238 E.05267
G1 X92.811 Y147.238 E.0127
G1 X94.343 Y148.769 E.05268
G1 X93.821 Y148.77 E.0127
G1 X92.289 Y147.238 E.0527
G1 X91.764 Y147.234 E.01277
G1 X93.3 Y148.77 E.05284
G1 X92.779 Y148.771 E.01267
G1 X91.447 Y147.439 E.04582
G1 X91.447 Y147.96 E.01267
G1 X92.258 Y148.771 E.0279
G1 X91.736 Y148.771 E.0127
G1 X91.283 Y148.318 E.01558
G1 E-5 F3600
G1 X91.283 Y148.318 F9000
G1 X96.025 Y148.789
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.40913
G1 F1200
G1 X96.964 Y148.763 E.02342
G1 X105.44 Y148.758 E.21132
;WIDTH:0.438596
G1 X105.959 Y148.814 E.01404
;WIDTH:0.486692
G1 X106.422 Y148.978 E.01478
;WIDTH:0.495154
G1 X106.759 Y149.218 E.01268
G1 X107.079 Y149.594 E.01513
;WIDTH:0.487992
G1 X107.283 Y150.058 E.0153
;WIDTH:0.442442
G1 X107.32 Y150.357 E.00818
;WIDTH:0.41477
G1 X107.358 Y150.657 E.00765
;WIDTH:0.387098
G1 X107.359 Y150.684 E.00063
;WIDTH:0.393062
G1 X107.363 Y153.313 E.06273
;WIDTH:0.416708
G1 X107.303 Y153.831 E.01326
;WIDTH:0.458875
G1 X107.243 Y154.008 E.00528
;WIDTH:0.501042
G1 X107.183 Y154.186 E.00583
;WIDTH:0.542661
G1 X107.126 Y154.299 E.00428
;WIDTH:0.584279
G1 X107.069 Y154.412 E.00463
;WIDTH:0.625897
G1 X107.012 Y154.524 E.00495
;WIDTH:0.667516
G1 X106.955 Y154.637 E.00533
;WIDTH:0.709134
G1 X106.898 Y154.75 E.00568
;WIDTH:0.731026
G1 X106.894 Y154.767 E.00081
;WIDTH:0.399999
G1 X107.282 Y154.935 E.01028
;WIDTH:0.39627
G1 X123.717 Y154.935 E.39569
;WIDTH:0.439752
G1 X123.79 Y154.913 E.00206
;WIDTH:0.483234
G1 X123.862 Y154.891 E.00225
;WIDTH:0.526716
G1 X123.935 Y154.869 E.0025
;WIDTH:0.572248
G1 X123.977 Y154.839 E.00185
;WIDTH:0.617779
G1 X124.018 Y154.809 E.00197
;WIDTH:0.663311
G1 X124.06 Y154.779 E.00216
;WIDTH:0.708842
G1 X124.102 Y154.749 E.00232
G1 X124.045 Y154.637 E.00564
;WIDTH:0.667283
G1 X123.988 Y154.524 E.00533
;WIDTH:0.625724
G1 X123.931 Y154.411 E.00498
;WIDTH:0.584165
G1 X123.874 Y154.299 E.0046
;WIDTH:0.542605
G1 X123.817 Y154.186 E.00428
;WIDTH:0.501046
G1 X123.737 Y153.894 E.0094
;WIDTH:0.467104
G1 X123.656 Y153.601 E.00875
;WIDTH:0.433162
G1 X123.637 Y153.313 E.00766
;WIDTH:0.393104
G1 X123.641 Y150.684 E.06274
;WIDTH:0.419109
G1 X123.658 Y150.459 E.00578
;WIDTH:0.45276
G1 X123.676 Y150.234 E.00628
;WIDTH:0.478242
G1 X123.802 Y149.807 E.01315
;WIDTH:0.491354
G1 X124.091 Y149.372 E.01588
;WIDTH:0.505328
G1 X124.531 Y148.998 E.01809
G1 X124.998 Y148.814 E.01573
;WIDTH:0.457464
G1 X125.534 Y148.758 E.01517
;WIDTH:0.409054
G1 X125.561 Y148.757 E.00067
;WIDTH:0.408722
G1 X134.305 Y148.766 E.21776
;WIDTH:0.396724
G1 X134.939 Y148.785 E.01529
G1 E-5 F3600
G1 X134.939 Y148.785 F9000
G1 X139.727 Y147.726
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X139.234 Y147.233 E.01696
G1 X138.717 Y147.238 E.01258
G1 X139.563 Y148.083 E.02908
G1 X139.563 Y148.605 E.0127
G1 X138.195 Y147.238 E.04704
G1 X137.674 Y147.238 E.01267
G1 X139.202 Y148.766 E.05256
G1 X138.68 Y148.766 E.0127
G1 X137.152 Y147.238 E.05256
G1 X136.631 Y147.238 E.01267
G1 X138.159 Y148.766 E.05256
G1 X137.637 Y148.766 E.0127
G1 X136.109 Y147.238 E.05256
G1 X135.587 Y147.238 E.0127
G1 X137.115 Y148.765 E.05255
G1 X136.593 Y148.765 E.0127
G1 X135.187 Y147.359 E.04837
G1 X135.192 Y147.544 E.0045
G1 X134.867 Y147.561 E.00792
G1 X136.071 Y148.765 E.04142
G1 X135.549 Y148.765 E.0127
G1 X134.372 Y147.587 E.04051
G1 X133.876 Y147.613 E.01208
G1 X134.687 Y148.425 E.02792
G1 X134.14 Y148.399 E.01332
G1 X133.355 Y147.613 E.02702
G1 X132.833 Y147.613 E.0127
G1 X133.61 Y148.39 E.02673
G1 X133.087 Y148.39 E.01272
G1 X132.311 Y147.613 E.02671
G1 X131.789 Y147.613 E.0127
G1 X132.566 Y148.389 E.02671
G1 X132.044 Y148.389 E.0127
G1 X131.268 Y147.613 E.02669
G1 X130.746 Y147.613 E.0127
G1 X131.522 Y148.389 E.02669
G1 X131 Y148.389 E.0127
G1 X130.224 Y147.613 E.02669
G1 X129.702 Y147.613 E.0127
G1 X130.479 Y148.389 E.02671
G1 X129.957 Y148.389 E.0127
G1 X129.18 Y147.613 E.02671
G1 X128.659 Y147.613 E.01267
G1 X129.435 Y148.389 E.02669
G1 X128.913 Y148.389 E.0127
G1 X128.137 Y147.612 E.02671
G1 X127.615 Y147.612 E.0127
G1 X128.392 Y148.389 E.02673
G1 X127.87 Y148.389 E.0127
G1 X127.093 Y147.612 E.02673
G1 X126.572 Y147.612 E.01267
G1 X127.348 Y148.389 E.02671
G1 X126.826 Y148.388 E.0127
G1 X126.05 Y147.612 E.02669
G1 X125.528 Y147.612 E.0127
G1 X126.305 Y148.388 E.02671
G1 X125.783 Y148.388 E.0127
G1 X124.766 Y147.371 E.03498
G1 E-5 F3600
G1 X124.766 Y147.371 F9000
G1 X123.635 Y144.533
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.395192
G1 F1200
G1 X123.636 Y145.317 E.01882
;WIDTH:0.433048
G1 X123.702 Y145.875 E.0149
;WIDTH:0.466027
G1 X123.808 Y146.141 E.00822
;WIDTH:0.499006
G1 X123.914 Y146.406 E.00882
;WIDTH:0.505188
G1 X124.252 Y146.801 E.01628
G1 X124.589 Y147.035 E.01285
;WIDTH:0.50093
G1 X124.815 Y147.111 E.0074
;WIDTH:0.469707
G1 X125.041 Y147.186 E.0069
;WIDTH:0.438484
G1 X125.56 Y147.242 E.01403
;WIDTH:0.409746
G1 X133.867 Y147.243 E.20745
G1 X134.838 Y147.217 E.02426
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X133.867 Y147.243 E-.46139
G1 X131.68 Y147.243 E-1.03861
;WIPE_END
G1 X135.175 Y140.548 F9000
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X135.394 Y140.766 E.00752
G1 X135.928 Y140.767 E.01299
G1 X135.545 Y140.384 E.01317
G1 X135.786 Y140.091 E.00923
G1 X136.462 Y140.768 E.02327
G1 X136.997 Y140.768 E.01301
G1 X136.021 Y139.792 E.03357
G1 X136.243 Y139.481 E.00929
G1 X137.531 Y140.769 E.04431
G1 X138.065 Y140.77 E.01299
G1 X136.533 Y139.237 E.05272
G1 X137.066 Y139.237 E.01296
G1 X138.6 Y140.77 E.05275
G1 X139.134 Y140.771 E.01299
G1 X137.599 Y139.236 E.0528
G1 X138.132 Y139.235 E.01296
G1 X139.562 Y140.665 E.04919
G1 X139.561 Y140.131 E.01299
G1 X138.665 Y139.235 E.03082
G1 X139.198 Y139.234 E.01296
G1 X139.726 Y139.762 E.01816
G1 E-5 F3600
G1 X139.726 Y139.762 F9000
G1 X140.205 Y136.977
G1 X140.239 Y136.767
G1 X140.242 Y136.703
G1 X140.249 Y136.557
G1 X140.249 Y135.443
G1 X140.242 Y135.297
G1 X140.239 Y135.233
G1 X140.205 Y135.023
G1 X140.144 Y134.832
G1 X140.052 Y134.641
G1 X139.103 Y132.927
G1 E5 F2400
G1 F3072.127
G1 X138.43 Y132.254 E.02315
G1 X138.431 Y131.673 E.01413
G1 X139.56 Y132.801 E.03882
G1 X139.56 Y132.218 E.01418
G1 X138.574 Y131.232 E.03392
G1 X139.155 Y131.229 E.01413
G1 X139.725 Y131.799 E.01961
G1 E-5 F3600
G1 X139.725 Y131.799 F9000
G1 X140.205 Y128.977
G1 X140.239 Y128.767
G1 X140.242 Y128.703
G1 X140.249 Y128.557
G1 X140.249 Y127.443
G1 X140.242 Y127.297
G1 X140.239 Y127.233
G1 X140.205 Y127.023
G1 X140.144 Y126.832
G1 X140.052 Y126.641
G1 X139.109 Y124.927
G1 E5 F2400
G1 F3072.127
G1 X138.437 Y124.255 E.02312
G1 X138.437 Y123.673 E.01416
G1 X139.559 Y124.796 E.03861
G1 X139.559 Y124.214 E.01416
G1 X138.576 Y123.232 E.0338
G1 X139.156 Y123.229 E.01411
G1 X139.723 Y123.797 E.01952
G1 E-5 F3600
G1 X139.723 Y123.797 F9000
G1 X139.108 Y116.927
G1 E5 F2400
G1 F3072.127
G1 X138.437 Y116.255 E.0231
G1 X138.437 Y115.674 E.01413
G1 X139.558 Y116.795 E.03856
G1 X139.558 Y116.214 E.01413
G1 X138.576 Y115.232 E.03378
G1 X139.155 Y115.229 E.01408
G1 X139.722 Y115.797 E.01952
G1 E-5 F3600
G1 X139.722 Y115.797 F9000
G1 X140.144 Y110.832
G1 X140.052 Y110.641
G1 X139.108 Y108.927
G1 E5 F2400
G1 F3072.127
G1 X138.437 Y108.256 E.02308
G1 X138.437 Y107.675 E.01413
G1 X139.557 Y108.794 E.03851
G1 X139.557 Y108.213 E.01413
G1 X138.575 Y107.232 E.03376
G1 X139.154 Y107.229 E.01408
G1 X139.721 Y107.797 E.01952
G1 E-5 F3600
G1 X139.721 Y107.797 F9000
G1 X139.106 Y100.927
G1 E5 F2400
G1 F3072.127
G1 X138.437 Y100.257 E.02303
G1 X138.437 Y99.678 E.01408
G1 X139.555 Y100.796 E.03846
G1 X139.555 Y100.216 E.01411
G1 X138.437 Y99.098 E.03846
G1 X138.437 Y98.518 E.01411
G1 X139.555 Y99.636 E.03846
G1 X139.555 Y99.056 E.01411
G1 X138.547 Y98.048 E.03467
G1 X139.126 Y98.047 E.01408
G1 X139.72 Y98.64 E.02042
G1 E-5 F3600
G1 X139.72 Y98.64 F9000
G1 X140.235 Y95.795
G1 X140.249 Y95.636
G1 X140.249 Y93.193
G1 X140.235 Y93.034
G1 X140.188 Y92.857
G1 X140.11 Y92.691
G1 X140.005 Y92.541
G1 X139.876 Y92.411
G1 X139.726 Y92.306
G1 X139.56 Y92.229
G1 X139.391 Y92.184
G1 X129.269 Y90.214
G1 E5 F2400
G1 F3072.127
G1 X129.834 Y90.779 E.01944
G1 X130.362 Y90.779 E.01284
G1 X127.61 Y88.027 E.09467
G1 X127.568 Y87.927 E.00264
G1 X127.975 Y87.864 E.01002
G1 X130.89 Y90.779 E.10027
G1 X131.418 Y90.779 E.01284
G1 X128.391 Y87.751 E.10414
G1 X128.79 Y87.623 E.01019
G1 X131.946 Y90.779 E.10856
G1 X132.474 Y90.779 E.01284
G1 X129.177 Y87.481 E.11343
G1 X129.526 Y87.303 E.00953
G1 X133.002 Y90.779 E.11957
G1 X133.53 Y90.779 E.01284
G1 X129.861 Y87.11 E.12621
G1 X130.191 Y86.912 E.00936
G1 X134.058 Y90.779 E.13302
G1 X134.586 Y90.779 E.01284
G1 X130.494 Y86.687 E.14076
G1 X130.78 Y86.445 E.00911
G1 X135.114 Y90.779 E.14909
G1 X135.642 Y90.779 E.01284
G1 X131.042 Y86.179 E.15824
G1 X131.304 Y85.913 E.00908
G1 X136.17 Y90.779 E.16739
G1 X136.698 Y90.779 E.01284
G1 X131.534 Y85.615 E.17764
G1 X131.741 Y85.294 E.00929
G1 X137.226 Y90.779 E.18868
G1 X137.754 Y90.779 E.01284
G1 X131.949 Y84.974 E.19969
G1 X132.137 Y84.634 E.00945
G1 X138.282 Y90.779 E.21138
G1 X138.81 Y90.779 E.01284
G1 X132.286 Y84.256 E.2244
G1 X132.432 Y83.874 E.00995
G1 X139.358 Y90.799 E.23823
G1 X139.554 Y90.825 E.00481
G1 X139.554 Y90.467 E.00871
G1 X132.56 Y83.473 E.24059
G1 X132.649 Y83.035 E.01087
G1 X139.554 Y89.939 E.23751
G1 X139.554 Y89.411 E.01284
G1 X132.701 Y82.558 E.23574
G1 X132.732 Y82.062 E.01209
G1 X139.554 Y88.883 E.23466
G1 X139.554 Y88.355 E.01284
G1 X132.734 Y81.535 E.2346
G1 X132.735 Y81.008 E.01282
G1 X139.553 Y87.827 E.23455
G1 X139.553 Y87.299 E.01284
G1 X132.736 Y80.481 E.23452
G1 X132.737 Y79.954 E.01282
G1 X139.553 Y86.771 E.23448
G1 X139.553 Y86.242 E.01287
G1 X132.965 Y79.654 E.22662
G1 X133.251 Y79.413 E.0091
G1 X139.553 Y85.714 E.21677
G1 X139.553 Y85.186 E.01284
G1 X133.538 Y79.172 E.2069
G1 X133.822 Y78.927 E.00912
G1 X139.553 Y84.658 E.19714
G1 X139.553 Y84.13 E.01284
G1 X134.073 Y78.65 E.18851
G1 X134.275 Y78.324 E.00933
G1 X139.553 Y83.602 E.18156
G1 X139.553 Y83.074 E.01284
G1 X134.412 Y77.933 E.17685
G1 X134.457 Y77.45 E.0118
G1 X139.553 Y82.546 E.1753
G1 X139.553 Y82.018 E.01284
G1 X134.303 Y76.769 E.18058
G1 X134.271 Y76.658 E.00281
G1 X133.68 Y75.948 E.02247
G1 X134.01 Y75.948 E.00803
G1 X139.552 Y81.49 E.19064
G1 X139.552 Y80.962 E.01284
G1 X134.538 Y75.948 E.17248
G1 X135.066 Y75.948 E.01284
G1 X139.552 Y80.434 E.15432
G1 X139.552 Y79.906 E.01284
G1 X135.594 Y75.948 E.13615
G1 X136.195 Y76.021 E.01473
G1 X139.479 Y79.305 E.11297
G1 X139.282 Y78.58 E.01827
G1 X136.92 Y76.218 E.08125
G1 X137.804 Y76.663 E.02407
G1 X138.341 Y77.11 E.017
G1 X139.155 Y77.924 E.028
G1 E-5 F3600
G1 X139.155 Y77.924 F9000
G1 X129.64 Y85.603
G1 X129.465 Y85.732
G1 X129.382 Y85.794
G1 X129.197 Y85.913
G1 X129.109 Y85.968
G1 X128.915 Y86.076
G1 X128.822 Y86.124
G1 X128.631 Y86.213
G1 X128.536 Y86.254
G1 X128.339 Y86.33
G1 X128.242 Y86.364
G1 X128.04 Y86.426
G1 X127.94 Y86.453
G1 X127.735 Y86.501
G1 X127.634 Y86.521
G1 X127.425 Y86.555
G1 X127.323 Y86.567
G1 X127.113 Y86.588
G1 X127.01 Y86.592
G1 X126.809 Y86.599
G1 X104.191 Y86.599
G1 X103.99 Y86.592
G1 X103.887 Y86.588
G1 X103.677 Y86.567
G1 X103.575 Y86.555
G1 X103.366 Y86.521
G1 X103.265 Y86.501
G1 X103.06 Y86.453
G1 X102.96 Y86.426
G1 X102.758 Y86.364
G1 X102.661 Y86.33
G1 X102.464 Y86.254
G1 X102.369 Y86.213
G1 X102.178 Y86.124
G1 X98.983 Y84.462
G1 E5 F2400
G1 F3072.127
G1 X92.184 Y77.662 E.2339
G1 X92.412 Y77.371 E.00899
G1 X98.432 Y83.391 E.20708
G1 X98.319 Y82.759 E.01562
G1 X92.665 Y77.104 E.19451
G1 X92.939 Y76.859 E.00894
G1 X98.273 Y82.192 E.18347
G1 X98.271 Y81.671 E.01267
G1 X93.234 Y76.635 E.17325
G1 X93.558 Y76.439 E.00921
G1 X98.27 Y81.15 E.16207
G1 X98.268 Y80.629 E.01267
G1 X93.911 Y76.272 E.14988
G1 X94.291 Y76.132 E.00985
G1 X98.267 Y80.108 E.13677
G1 X98.266 Y79.847 E.00635
G1 X96.996 Y78.746 E.04088
G1 X96.729 Y78.338 E.01186
G1 X96.583 Y77.905 E.01111
G1 X94.713 Y76.035 E.06433
G1 X95.164 Y75.966 E.0111
G1 X96.547 Y77.349 E.04757
G1 X96.649 Y76.931 E.01047
G1 X95.666 Y75.948 E.03381
G1 X96.185 Y75.948 E.01262
G1 X96.802 Y76.565 E.02122
G1 X97.03 Y76.273 E.00901
G1 X96.705 Y75.948 E.01118
G1 X97.225 Y75.948 E.01265
G1 X97.385 Y76.108 E.0055
;LAYER_CHANGE
;Z:1.74
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;1.74
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X97.225 Y75.948 E-.10748
G1 X96.705 Y75.948 E-.247
G1 X97.03 Y76.273 E-.21832
G1 X96.802 Y76.565 E-.17597
G1 X96.185 Y75.948 E-.41447
G1 X95.666 Y75.948 E-.24653
G1 X95.8 Y76.082 E-.09023
;WIPE_END
G1 Z1.74 F9000
;AFTER_LAYER_CHANGE
;1.74
G1 Z1.74
G1 X98.218 Y77.124
G1 X99.597 Y77.5
G1 X99.118 Y77.512
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X99.232 Y77.362 E.00458
G1 X100.574 Y76.209 E.04304
G1 X130.426 Y76.209 E.72612
G1 X131.685 Y77.29 E.04036
G1 X131.893 Y77.498 E.00716
G1 X131.693 Y77.708 E.00705
G1 X130.314 Y78.885 E.0441
G1 X130.25 Y79.024 E.00372
G1 X130.25 Y81.693 E.06492
G1 X130.208 Y82.256 E.01373
G1 X130.048 Y82.918 E.01657
G1 X129.736 Y83.606 E.01838
G1 X129.534 Y83.895 E.00858
G1 X129.207 Y84.301 E.01268
G1 X128.759 Y84.704 E.01466
G1 X128.201 Y85.071 E.01625
G1 X127.548 Y85.337 E.01715
G1 X127.006 Y85.459 E.01351
G1 X126.443 Y85.5 E.01373
G1 X120.643 Y85.5 E.14108
G1 X120.544 Y85.537 E.00257
G1 X110.456 Y85.537 E.24538
G1 X110.357 Y85.5 E.00257
G1 X104.504 Y85.49 E.14237
G1 X103.777 Y85.418 E.01777
G1 X103.063 Y85.195 E.01819
G1 X102.406 Y84.835 E.01822
G1 X102.15 Y84.632 E.00795
G1 X101.627 Y84.123 E.01775
G1 X101.21 Y83.508 E.01807
G1 X100.899 Y82.743 E.02009
G1 X100.792 Y82.258 E.01208
G1 X100.75 Y81.693 E.01378
G1 X100.75 Y79.024 E.06492
G1 X100.686 Y78.885 E.00372
G1 X99.316 Y77.715 E.04382
G1 X99.156 Y77.555 E.0055
G1 X99.156 Y77.555 F9000
G1 X99.692 Y77.449
;TYPE:Perimeter
G1 F6000
G1 X100.71 Y76.575 E.03264
G1 X130.29 Y76.575 E.7195
G1 X131.371 Y77.502 E.03464
G1 X130.077 Y78.607 E.04139
G1 X129.922 Y78.826 E.00653
G1 X129.884 Y79.024 E.0049
G1 X129.884 Y81.679 E.06458
G1 X129.845 Y82.199 E.01268
G1 X129.701 Y82.798 E.01499
G1 X129.417 Y83.424 E.01672
G1 X128.94 Y84.051 E.01916
G1 X128.531 Y84.418 E.01337
G1 X128.037 Y84.743 E.01438
G1 X127.438 Y84.987 E.01573
G1 X126.952 Y85.096 E.01212
G1 X126.429 Y85.134 E.01275
G1 X120.643 Y85.134 E.14074
G1 X120.505 Y85.171 E.00348
G1 X110.951 Y85.171 E.23239
G1 X110.358 Y85.134 E.01445
G1 X104.505 Y85.124 E.14237
G1 X103.858 Y85.061 E.01581
G1 X103.206 Y84.857 E.01662
G1 X102.841 Y84.657 E.01012
G1 X102.378 Y84.346 E.01357
G1 X101.913 Y83.894 E.01577
G1 X101.534 Y83.335 E.01643
G1 X101.25 Y82.635 E.01837
G1 X101.155 Y82.204 E.01074
G1 X101.116 Y81.679 E.01281
G1 X101.116 Y79.024 E.06458
G1 X101.078 Y78.826 E.0049
G1 X100.923 Y78.607 E.00653
G1 X99.629 Y77.502 E.04139
G1 X99.646 Y77.488 E.00054
G1 X99.646 Y77.488 F9000
G1 X100.319 Y77.611
G1 F6000
G1 X100.192 Y77.502 E.00407
G1 X100.845 Y76.94 E.02096
G1 X130.155 Y76.94 E.71294
G1 X130.808 Y77.502 E.02096
G1 X129.839 Y78.329 E.03099
G1 X129.581 Y78.693 E.01085
G1 X129.519 Y79.024 E.00819
G1 X129.519 Y81.544 E.0613
G1 X129.483 Y82.142 E.01457
G1 X129.353 Y82.679 E.01344
G1 X129.098 Y83.242 E.01503
G1 X128.673 Y83.801 E.01708
G1 X128.175 Y84.235 E.01607
G1 X127.587 Y84.532 E.01602
G1 X127.1 Y84.688 E.01244
G1 X126.416 Y84.769 E.01675
G1 X120.643 Y84.769 E.14042
G1 X120.467 Y84.805 E.00437
G1 X110.951 Y84.805 E.23147
G1 X110.358 Y84.769 E.01445
G1 X104.505 Y84.758 E.14237
G1 X103.939 Y84.703 E.01383
G1 X103.35 Y84.519 E.01501
G1 X103.074 Y84.368 E.00765
G1 X102.606 Y84.06 E.01363
G1 X102.2 Y83.666 E.01376
G1 X101.858 Y83.161 E.01484
G1 X101.718 Y82.815 E.00908
G1 X101.555 Y82.322 E.01263
G1 X101.481 Y81.665 E.01608
G1 X101.481 Y79.024 E.06424
G1 X101.419 Y78.693 E.00819
G1 X101.161 Y78.329 E.01085
G1 X100.365 Y77.65 E.02545
G1 X100.365 Y77.65 F9000
G1 X101.709 Y78.489
G1 F6000
G1 X101.398 Y78.051 E.01307
G1 X100.754 Y77.501 E.0206
G1 X100.98 Y77.306 E.00726
G1 X130.02 Y77.306 E.70637
G1 X130.246 Y77.501 E.00726
G1 X129.602 Y78.051 E.0206
G1 X129.24 Y78.561 E.01521
G1 X129.153 Y79.024 E.01146
G1 X129.137 Y81.864 E.06908
G1 X129.006 Y82.559 E.0172
G1 X128.779 Y83.06 E.01338
G1 X128.406 Y83.551 E.015
G1 X127.966 Y83.933 E.01417
G1 X127.498 Y84.173 E.01279
G1 X127.02 Y84.331 E.01225
G1 X126.402 Y84.403 E.01513
G1 X120.643 Y84.403 E.14008
G1 X120.428 Y84.44 E.00531
G1 X110.951 Y84.44 E.23052
G1 X110.359 Y84.403 E.01443
G1 X104.584 Y84.393 E.14047
G1 X104.02 Y84.345 E.01377
G1 X103.494 Y84.181 E.0134
G1 X102.857 Y83.793 E.01814
G1 X102.486 Y83.437 E.01251
G1 X102.183 Y82.988 E.01318
G1 X101.912 Y82.243 E.01928
G1 X101.847 Y81.651 E.01449
G1 X101.847 Y79.024 E.0639
G1 X101.76 Y78.561 E.01146
G1 X101.744 Y78.538 E.00068
G1 X101.744 Y78.538 F9000
G1 X102.035 Y78.336
G1 F6000
G1 X101.636 Y77.773 E.01678
G1 X101.517 Y77.672 E.0038
G1 X129.483 Y77.672 E.68025
G1 X129.364 Y77.773 E.0038
G1 X128.899 Y78.429 E.01956
G1 X128.787 Y79.024 E.01473
G1 X128.772 Y81.836 E.0684
G1 X128.659 Y82.44 E.01495
G1 X128.46 Y82.878 E.0117
G1 X128.139 Y83.301 E.01292
G1 X127.758 Y83.632 E.01228
G1 X127.425 Y83.808 E.00916
G1 X126.94 Y83.974 E.01247
G1 X126.389 Y84.037 E.01349
G1 X120.643 Y84.037 E.13977
G1 X120.389 Y84.074 E.00624
G1 X110.951 Y84.074 E.22957
G1 X110.36 Y84.037 E.0144
G1 X105.385 Y84.029 E.12101
G1 X104.248 Y84.008 E.02766
G1 X103.638 Y83.843 E.01537
G1 X103.219 Y83.613 E.01163
G1 X102.87 Y83.311 E.01123
G1 X102.507 Y82.815 E.01495
G1 X102.27 Y82.165 E.01683
G1 X102.213 Y81.638 E.01289
G1 X102.213 Y79.024 E.06358
G1 X102.101 Y78.429 E.01473
G1 X102.07 Y78.385 E.00131
G1 X102.182 Y77.994 F9000
;TYPE:Solid infill
;WIDTH:0.496837
G1 F1200
G1 X102.845 Y77.994 E.0204
G1 X102.852 Y78.316 E.00991
;WIDTH:0.483895
G1 X102.868 Y78.674 E.01072
;WIDTH:0.452514
G1 X102.884 Y79.032 E.00997
;WIDTH:0.421877
G1 X102.885 Y80.187 E.02978
G1 X102.822 Y81.396 E.03121
;WIDTH:0.379976
G1 X102.793 Y81.647 E.00581
;WIDTH:0.361806
G1 X102.703 Y82.183 E.01184
G1 X102.545 Y82.19 E.00345
G1 X102.495 Y81.993 E.00443
;WIDTH:0.379976
G1 X102.477 Y81.384 E.01401
;WIDTH:0.421877
G1 X102.497 Y79.033 E.06061
;WIDTH:0.424423
G1 X102.496 Y78.997 E.00093
;WIDTH:0.454159
G1 X102.451 Y78.677 E.00902
;WIDTH:0.483895
G1 X102.406 Y78.358 E.00963
;WIDTH:0.491295
G1 X102.278 Y78.15 E.00742
G1 X102.278 Y78.15 F9000
G1 X103.702 Y77.987
;WIDTH:0.512906
G1 F1200
G1 X103.66 Y77.945 E.00189
G1 X103.602 Y77.96 E.00191
G1 X103.586 Y78.018 E.00192
G1 X103.629 Y78.06 E.00191
G1 X103.687 Y78.045 E.00191
;WIDTH:0.399999
G1 X104.298 Y77.946 E.01506
G1 X103.588 Y78.656 E.02442
G1 X103.588 Y79.173 E.01258
G1 X104.815 Y77.946 E.04221
G1 X105.332 Y77.946 E.01258
G1 X103.588 Y79.69 E.05999
G1 X103.582 Y80.213 E.01272
G1 X105.849 Y77.946 E.07798
G1 X106.366 Y77.946 E.01258
G1 X103.554 Y80.758 E.09673
G1 X103.508 Y81.322 E.01376
G1 X106.883 Y77.946 E.11611
G1 X107.4 Y77.946 E.01258
G1 X103.441 Y81.905 E.13619
G1 X103.323 Y82.541 E.01573
G1 X107.918 Y77.946 E.15806
G1 X108.435 Y77.946 E.01258
G1 X103.163 Y83.218 E.18135
;WIDTH:0.429841
G1 X103.062 Y83.072 E.00467
;WIDTH:0.459682
G1 X102.961 Y82.925 E.00505
G1 X102.91 Y82.939 E.0015
G1 X102.872 Y82.901 E.00152
G1 X102.886 Y82.85 E.0015
G1 X102.937 Y82.836 E.0015
G1 X102.975 Y82.874 E.00152
G1 X102.975 Y82.874 F9000
G1 X103.463 Y83.434
;WIDTH:0.399999
G1 F1200
G1 X108.952 Y77.946 E.1888
G1 X109.469 Y77.946 E.01258
G1 X103.807 Y83.608 E.19477
G1 X104.207 Y83.725 E.01014
G1 X109.986 Y77.946 E.19879
G1 X110.503 Y77.946 E.01258
G1 X104.696 Y83.753 E.19976
G1 X105.212 Y83.754 E.01255
G1 X111.02 Y77.946 E.19979
G1 X111.537 Y77.946 E.01258
G1 X105.728 Y83.755 E.19983
G1 X106.245 Y83.756 E.01258
G1 X112.055 Y77.946 E.19986
G1 X112.572 Y77.946 E.01258
G1 X106.761 Y83.757 E.19989
G1 X107.277 Y83.758 E.01255
G1 X113.089 Y77.946 E.19993
G1 X113.606 Y77.946 E.01258
G1 X107.793 Y83.759 E.19996
G1 X108.31 Y83.759 E.01258
G1 X114.123 Y77.946 E.19996
G1 X114.64 Y77.946 E.01258
G1 X108.826 Y83.76 E.2
G1 X109.342 Y83.761 E.01255
G1 X115.157 Y77.946 E.20003
G1 X115.674 Y77.946 E.01258
G1 X109.858 Y83.762 E.20007
G1 X110.374 Y83.764 E.01255
G1 X116.192 Y77.946 E.20014
G1 X116.709 Y77.946 E.01258
G1 X110.855 Y83.8 E.20137
G1 X111.372 Y83.8 E.01258
G1 X117.226 Y77.946 E.20137
G1 X117.743 Y77.946 E.01258
G1 X111.889 Y83.8 E.20137
G1 X112.406 Y83.8 E.01258
G1 X118.26 Y77.946 E.20137
G1 X118.777 Y77.946 E.01258
G1 X112.924 Y83.8 E.20136
G1 X113.441 Y83.8 E.01258
G1 X119.294 Y77.946 E.20136
G1 X119.811 Y77.946 E.01258
G1 X113.958 Y83.8 E.20136
G1 X114.475 Y83.8 E.01258
G1 X120.329 Y77.946 E.20137
G1 X120.846 Y77.946 E.01258
G1 X114.992 Y83.8 E.20137
G1 X115.509 Y83.8 E.01258
G1 X121.363 Y77.946 E.20137
G1 X121.88 Y77.946 E.01258
G1 X116.026 Y83.8 E.20137
G1 X116.543 Y83.8 E.01258
G1 X122.397 Y77.946 E.20137
G1 X122.914 Y77.946 E.01258
G1 X117.061 Y83.8 E.20136
G1 X117.578 Y83.8 E.01258
G1 X123.431 Y77.946 E.20136
G1 X123.948 Y77.946 E.01258
G1 X118.095 Y83.8 E.20136
G1 X118.612 Y83.8 E.01258
G1 X124.466 Y77.946 E.20137
G1 X124.983 Y77.946 E.01258
G1 X119.129 Y83.8 E.20137
G1 X119.646 Y83.8 E.01258
G1 X125.5 Y77.946 E.20137
G1 X126.017 Y77.946 E.01258
G1 X120.163 Y83.8 E.20137
G1 X120.717 Y83.763 E.01351
G1 X126.534 Y77.946 E.2001
G1 X127.051 Y77.946 E.01258
G1 X121.234 Y83.763 E.2001
G1 X121.751 Y83.763 E.01258
G1 X127.412 Y78.102 E.19473
G1 X127.533 Y77.886 E.00602
;WIDTH:0.374336
G1 X127.492 Y77.897 E.00096
G1 X127.473 Y77.825 E.00168
G1 X127.544 Y77.844 E.00166
G1 X127.544 Y77.844 F9000
G1 X127.412 Y78.619
;WIDTH:0.399999
G1 F1200
G1 X122.268 Y83.763 E.17695
G1 X122.785 Y83.763 E.01258
G1 X127.412 Y79.136 E.15917
G1 X127.412 Y79.653 E.01258
G1 X123.303 Y83.763 E.14136
G1 X123.82 Y83.763 E.01258
G1 X127.418 Y80.165 E.12377
G1 X127.439 Y80.661 E.01208
G1 X124.337 Y83.763 E.10671
G1 X124.854 Y83.763 E.01258
G1 X127.474 Y81.143 E.09013
G1 X127.523 Y81.611 E.01145
G1 X125.371 Y83.763 E.07403
G1 X125.888 Y83.763 E.01258
G1 X127.586 Y82.066 E.05839
G1 X127.669 Y82.5 E.01075
G1 X126.407 Y83.761 E.04339
G1 X127.007 Y83.678 E.01473
G1 X127.865 Y82.821 E.0295
G1 X128.238 Y82.791 E.0091
;WIDTH:0.374336
G1 X128.198 Y82.895 E.00252
G1 X127.887 Y83.243 E.01056
G1 X127.465 Y83.6 E.0125
G1 E-5 F3600
G1 X127.465 Y83.6 F9000
G1 X128.816 Y77.996
G1 E5 F2400
;WIDTH:0.499284
G1 F1200
G1 X128.592 Y78.357 E.01314
;WIDTH:0.48682
G1 X128.547 Y78.695 E.01026
;WIDTH:0.454899
G1 X128.502 Y79.033 E.00954
;WIDTH:0.422978
G1 X128.502 Y80.18 E.02965
;WIDTH:0.422028
G1 X128.523 Y81.379 E.03093
;WIDTH:0.380255
G1 X128.502 Y81.998 E.01425
;WIDTH:0.361752
G1 X128.451 Y82.19 E.00433
G1 X128.306 Y82.19 E.00316
G1 X128.258 Y81.984 E.00461
;WIDTH:0.380255
G1 X128.177 Y81.391 E.01377
;WIDTH:0.422028
G1 X128.114 Y80.187 E.03109
;WIDTH:0.422978
G1 X128.113 Y79.033 E.02983
;WIDTH:0.426391
G1 X128.115 Y78.961 E.00188
;WIDTH:0.462838
G1 X128.132 Y78.478 E.01378
;WIDTH:0.499284
G1 X128.149 Y77.996 E.01492
G1 X128.633 Y77.996 E.01497
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X128.149 Y77.996 E-.2299
G1 X128.132 Y78.478 E-.22909
G1 X128.115 Y78.961 E-.22957
G1 X128.113 Y79.033 E-.03421
G1 X128.114 Y80.187 E-.54815
G1 X128.139 Y80.669 E-.22908
;WIPE_END
G1 X127.407 Y85.015 F9000
G1 X127.143 Y86.585
G1 X126.716 Y89.121
G1 X126.349 Y93.522
G1 X126.033 Y93.174
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X138.871 Y93.174 E.31227
G1 X139.096 Y93.22 E.00559
G1 X139.204 Y93.328 E.00372
G1 X139.25 Y93.553 E.00559
G1 X139.238 Y95.374 E.04429
G1 X139.141 Y95.581 E.00556
G1 X138.932 Y95.655 E.00539
G1 X136.183 Y95.655 E.06687
G1 X136.037 Y95.728 E.00397
G1 X136 Y95.838 E.00282
G1 X136 Y132.295 E.88678
G1 X135.952 Y133.266 E.02365
G1 X135.833 Y134.099 E.02047
G1 X135.717 Y134.637 E.01339
G1 X135.287 Y135.968 E.03402
G1 X134.717 Y137.146 E.03183
G1 X134.432 Y137.616 E.01337
G1 X133.89 Y138.374 E.02267
G1 X133.34 Y139.012 E.02049
G1 X132.951 Y139.404 E.01343
G1 X132.246 Y140.013 E.02266
G1 X131.561 Y140.502 E.02047
G1 X131.093 Y140.791 E.01338
G1 X129.834 Y141.401 E.03403
G1 X128.588 Y141.803 E.03185
G1 X128.054 Y141.923 E.01331
G1 X126.663 Y142.089 E.03407
G1 X120.643 Y142.1 E.14643
G1 X120.542 Y142.137 E.00262
G1 X110.686 Y142.137 E.23974
G1 X110.357 Y142.1 E.00805
G1 X104.802 Y142.1 E.13512
G1 X104.246 Y142.083 E.01353
G1 X103.408 Y142.001 E.02048
G1 X102.406 Y141.802 E.02485
G1 X101.601 Y141.564 E.02042
G1 X100.736 Y141.218 E.02266
G1 X100.24 Y140.974 E.01345
G1 X99.512 Y140.551 E.02048
G1 X98.752 Y140.012 E.02266
G1 X98.328 Y139.658 E.01344
G1 X97.72 Y139.076 E.02047
G1 X97.108 Y138.373 E.02267
G1 X96.779 Y137.93 E.01342
G1 X96.324 Y137.221 E.02049
G1 X95.895 Y136.394 E.02266
G1 X95.679 Y135.886 E.01343
G1 X95.406 Y135.092 E.02042
G1 X95.104 Y133.726 E.03403
G1 X95.007 Y132.677 E.02562
G1 X94.999 Y95.838 E.89607
G1 X94.962 Y95.728 E.00282
G1 X94.816 Y95.655 E.00397
G1 X92.994 Y95.655 E.04432
G1 X91.949 Y95.633 E.02542
G1 X91.836 Y95.542 E.00353
G1 X91.75 Y95.335 E.00545
G1 X91.757 Y93.425 E.04646
G1 X91.86 Y93.247 E.005
G1 X92.068 Y93.174 E.00536
G1 X104.944 Y93.174 E.3132
G1 X105 Y93.207 E.00158
G1 X105 Y135.971 E1.04019
G1 X103.789 Y137.01 E.03881
G1 X103.587 Y137.213 E.00697
G1 X103.46 Y137.452 E.00658
G1 X103.528 Y137.705 E.00637
G1 X103.837 Y138.033 E.01096
G1 X104.988 Y139.018 E.03685
G1 X105.031 Y139.42 E.00983
G1 X105.183 Y139.5 E.00418
G1 X125.817 Y139.5 E.5019
G1 X125.906 Y139.477 E.00224
G1 X125.987 Y139.384 E.003
G1 X126.012 Y139.018 E.00892
G1 X127.18 Y138.017 E.03742
G1 X127.52 Y137.624 E.01264
G1 X127.5 Y137.372 E.00615
G1 X127.44 Y137.247 E.00337
G1 X126.775 Y136.628 E.0221
G1 X126 Y135.971 E.02471
G1 X126 Y93.23 E1.03963
G1 X126.003 Y93.226 E.00012
G1 X126.003 Y93.226 F9000
G1 X126.449 Y93.54
;TYPE:Perimeter
G1 F6000
G1 X138.01 Y93.539 E.28121
G1 X138.885 Y93.553 E.02129
G1 X138.882 Y95.289 E.04223
G1 X136.183 Y95.29 E.06565
G1 X135.925 Y95.354 E.00647
G1 X135.744 Y95.509 E.0058
G1 X135.657 Y95.684 E.00475
G1 X135.635 Y95.838 E.00378
G1 X135.634 Y132.286 E.88656
G1 X135.587 Y133.231 E.02301
G1 X135.472 Y134.035 E.01976
G1 X135.363 Y134.542 E.01261
G1 X134.947 Y135.832 E.03297
G1 X134.395 Y136.971 E.03079
G1 X134.127 Y137.415 E.01261
G1 X133.602 Y138.148 E.02193
G1 X133.071 Y138.763 E.01976
G1 X132.701 Y139.136 E.01278
G1 X132.019 Y139.725 E.02192
G1 X131.358 Y140.198 E.01977
G1 X130.916 Y140.47 E.01262
G1 X129.697 Y141.061 E.03295
G1 X128.492 Y141.45 E.0308
G1 X127.992 Y141.562 E.01246
G1 X126.641 Y141.723 E.03309
G1 X120.642 Y141.735 E.14592
G1 X120.478 Y141.771 E.00408
G1 X110.686 Y141.771 E.23818
G1 X110.357 Y141.735 E.00805
G1 X104.808 Y141.735 E.13497
G1 X104.269 Y141.718 E.01312
G1 X103.462 Y141.639 E.01972
G1 X102.494 Y141.446 E.02401
G1 X101.721 Y141.218 E.0196
G1 X100.885 Y140.884 E.0219
G1 X100.413 Y140.651 E.0128
G1 X99.71 Y140.244 E.01976
G1 X98.975 Y139.722 E.02193
G1 X98.572 Y139.385 E.01278
G1 X97.984 Y138.824 E.01977
G1 X97.393 Y138.144 E.02191
G1 X97.08 Y137.722 E.01278
G1 X96.641 Y137.038 E.01977
G1 X96.226 Y136.238 E.02192
G1 X96.021 Y135.754 E.01279
G1 X95.758 Y134.992 E.01961
G1 X95.466 Y133.669 E.03296
G1 X95.373 Y132.66 E.02465
G1 X95.365 Y95.838 E.89566
G1 X95.343 Y95.684 E.00378
G1 X95.255 Y95.509 E.00476
G1 X95.074 Y95.354 E.0058
G1 X94.816 Y95.29 E.00647
G1 X92.116 Y95.289 E.06567
G1 X92.123 Y93.539 E.04257
G1 X104.634 Y93.54 E.30432
G1 X104.634 Y135.803 E1.02801
G1 X103.551 Y136.732 E.03471
G1 X103.327 Y136.956 E.00771
G1 X103.145 Y137.251 E.00843
G1 X103.091 Y137.526 E.00682
G1 X103.21 Y137.889 E.00929
G1 X103.599 Y138.311 E.01396
G1 X104.629 Y139.192 E.03297
G1 X104.635 Y139.339 E.00358
G1 X104.728 Y139.624 E.00729
G1 X104.892 Y139.782 E.00554
G1 X105.183 Y139.866 E.00737
G1 X125.817 Y139.866 E.5019
G1 X126.082 Y139.797 E.00666
G1 X126.238 Y139.669 E.00491
G1 X126.328 Y139.517 E.0043
G1 X126.371 Y139.192 E.00797
G1 X127.451 Y138.263 E.03465
G1 X127.86 Y137.76 E.01577
G1 X127.898 Y137.585 E.00436
G1 X127.832 Y137.197 E.00957
G1 X127.689 Y136.979 E.00634
G1 X127.011 Y136.349 E.02251
G1 X126.366 Y135.802 E.02057
G1 X126.366 Y93.54 E1.02798
G1 X126.389 Y93.54 E.00056
G1 X126.389 Y93.54 F9000
G1 X126.731 Y94.097
G1 F6000
G1 X126.731 Y93.905 E.00467
G1 X138.519 Y93.905 E.28673
G1 X138.519 Y94.924 E.02479
G1 X136.183 Y94.924 E.05682
G1 X135.753 Y95.031 E.01078
G1 X135.452 Y95.29 E.00966
G1 X135.306 Y95.582 E.00794
G1 X135.269 Y95.838 E.00629
G1 X135.269 Y132.277 E.88634
G1 X135.223 Y133.196 E.02238
G1 X135.133 Y133.824 E.01543
G1 X135.01 Y134.447 E.01545
G1 X134.607 Y135.695 E.0319
G1 X134.143 Y136.653 E.02589
G1 X133.821 Y137.214 E.01573
G1 X133.315 Y137.922 E.02117
G1 X132.862 Y138.445 E.01683
G1 X132.452 Y138.869 E.01435
G1 X131.793 Y139.437 E.02116
G1 X131.209 Y139.855 E.01747
G1 X130.74 Y140.149 E.01346
G1 X129.56 Y140.721 E.0319
G1 X128.45 Y141.079 E.02837
G1 X127.93 Y141.201 E.01299
G1 X126.619 Y141.358 E.03212
G1 X120.642 Y141.369 E.14538
G1 X120.415 Y141.405 E.00559
G1 X110.686 Y141.405 E.23665
G1 X110.357 Y141.369 E.00805
G1 X104.814 Y141.369 E.13483
G1 X104.293 Y141.353 E.01268
G1 X103.515 Y141.276 E.01902
G1 X102.582 Y141.091 E.02314
G1 X101.841 Y140.872 E.01879
G1 X101.091 Y140.572 E.01965
G1 X100.586 Y140.329 E.01363
G1 X99.908 Y139.936 E.01906
G1 X99.268 Y139.481 E.0191
G1 X98.816 Y139.113 E.01418
G1 X98.249 Y138.571 E.01908
G1 X97.754 Y138.002 E.01834
G1 X97.381 Y137.514 E.01494
G1 X96.958 Y136.855 E.01905
G1 X96.625 Y136.212 E.01761
G1 X96.362 Y135.623 E.01569
G1 X96.111 Y134.893 E.01878
G1 X95.828 Y133.613 E.03189
G1 X95.739 Y132.643 E.02369
G1 X95.73 Y95.838 E.89524
G1 X95.694 Y95.582 E.00629
G1 X95.547 Y95.289 E.00797
G1 X95.246 Y95.031 E.00964
G1 X94.816 Y94.924 E.01078
G1 X92.483 Y94.924 E.05675
G1 X92.487 Y93.905 E.02479
G1 X104.269 Y93.906 E.28659
G1 X104.269 Y135.635 E1.01502
G1 X103.313 Y136.455 E.03064
G1 X103.01 Y136.76 E.01046
G1 X102.817 Y137.091 E.00932
G1 X102.725 Y137.454 E.00911
G1 X102.765 Y137.762 E.00755
G1 X102.958 Y138.173 E.01104
G1 X103.361 Y138.589 E.01409
G1 X104.272 Y139.368 E.02916
G1 X104.32 Y139.62 E.00624
G1 X104.425 Y139.829 E.00569
G1 X104.698 Y140.092 E.00922
G1 X104.964 Y140.205 E.00703
G1 X105.183 Y140.231 E.00536
G1 X125.817 Y140.231 E.5019
G1 X125.977 Y140.217 E.00391
G1 X126.259 Y140.117 E.00728
G1 X126.518 Y139.904 E.00816
G1 X126.668 Y139.651 E.00715
G1 X126.728 Y139.368 E.00704
G1 X127.639 Y138.589 E.02916
G1 X128.028 Y138.169 E.01392
G1 X128.234 Y137.793 E.01043
G1 X128.254 Y137.416 E.00918
G1 X128.122 Y136.95 E.01178
G1 X127.938 Y136.711 E.00734
G1 X127.248 Y136.07 E.02291
G1 X126.731 Y135.632 E.01648
G1 X126.731 Y94.157 E1.00884
G1 X126.731 Y94.157 F9000
G1 X127.4 Y94.271
G1 F6000
G1 X135.471 Y94.271 E.19632
G1 X136.183 Y94.251 E.01733
;WIDTH:0.360932
G1 X138.173 Y94.251 E.04323
;WIDTH:0.360862
G1 X138.173 Y94.578 E.0071
G1 X136.183 Y94.578 E.04322
;WIDTH:0.371719
G1 X135.965 Y94.591 E.0049
;WIDTH:0.399999
G1 X135.581 Y94.709 E.00977
G1 X135.159 Y95.07 E.01351
G1 X134.955 Y95.48 E.01114
G1 X134.903 Y95.838 E.0088
G1 X134.903 Y132.268 E.88612
G1 X134.859 Y133.161 E.02175
G1 X134.771 Y133.773 E.01504
G1 X134.656 Y134.352 E.01436
G1 X134.266 Y135.559 E.03085
G1 X133.814 Y136.493 E.02524
G1 X133.516 Y137.013 E.01458
G1 X133.027 Y137.695 E.02041
G1 X132.586 Y138.206 E.01642
G1 X132.202 Y138.601 E.0134
G1 X131.567 Y139.15 E.02042
G1 X130.996 Y139.558 E.01707
G1 X130.564 Y139.828 E.01239
G1 X129.424 Y140.381 E.03082
G1 X128.83 Y140.572 E.01518
G1 X127.868 Y140.84 E.02429
G1 X126.579 Y140.992 E.03157
;WIDTH:0.41545
G1 X125.818 Y140.986 E.01929
;WIDTH:0.42029
G1 X120.641 Y140.993 E.13291
;WIDTH:0.438555
G1 X120.349 Y141.02 E.00789
G1 X110.686 Y141.02 E.25983
G1 X110.357 Y140.993 E.00888
;WIDTH:0.420285
G1 X105.183 Y140.993 E.13283
;WIDTH:0.442131
G1 X104.316 Y140.987 E.02352
;WIDTH:0.399999
G1 X103.569 Y140.914 E.01826
G1 X102.669 Y140.736 E.02232
G1 X101.961 Y140.526 E.01796
G1 X101.226 Y140.233 E.01925
G1 X100.759 Y140.006 E.01263
G1 X100.106 Y139.628 E.01835
G1 X99.48 Y139.183 E.01868
G1 X99.059 Y138.84 E.01321
G1 X98.514 Y138.318 E.01836
G1 X98.03 Y137.762 E.01793
G1 X97.682 Y137.306 E.01395
G1 X97.275 Y136.671 E.01835
G1 X96.949 Y136.043 E.01721
G1 X96.704 Y135.492 E.01467
G1 X96.463 Y134.794 E.01796
G1 X96.19 Y133.556 E.03084
G1 X96.104 Y132.627 E.02269
G1 X96.096 Y95.838 E.89486
G1 X96.045 Y95.479 E.00882
G1 X95.84 Y95.07 E.01113
G1 X95.418 Y94.709 E.01351
G1 X94.816 Y94.578 E.01499
;WIDTH:0.36091
G1 X92.83 Y94.578 E.04314
G1 X92.832 Y94.251 E.0071
G1 X94.816 Y94.251 E.0431
;WIDTH:0.399999
G1 X95.528 Y94.271 E.01733
G1 X103.903 Y94.271 E.20371
G1 X103.903 Y135.467 E1.00205
G1 X102.999 Y136.248 E.02906
G1 X102.605 Y136.7 E.01459
G1 X102.387 Y137.223 E.01378
G1 X102.361 Y137.574 E.00856
G1 X102.452 Y137.969 E.00986
G1 X102.662 Y138.388 E.0114
G1 X103.124 Y138.867 E.01619
G1 X103.942 Y139.567 E.02619
G1 X103.975 Y139.74 E.00428
G1 X104.123 Y140.034 E.00801
G1 X104.505 Y140.403 E.01292
;WIDTH:0.442131
G1 X104.872 Y140.58 E.01105
G1 X105.183 Y140.607 E.00847
;WIDTH:0.420285
G1 X110.357 Y140.607 E.13283
;WIDTH:0.438556
G1 X120.641 Y140.607 E.27652
;WIDTH:0.42029
G1 X125.817 Y140.605 E.13289
;WIDTH:0.426648
G1 X126.043 Y140.59 E.00591
G1 X126.436 Y140.438 E.011
;WIDTH:0.399999
G1 X126.799 Y140.138 E.01145
G1 X127.009 Y139.784 E.01001
G1 X127.058 Y139.567 E.00541
G1 X127.876 Y138.867 E.02619
G1 X128.161 Y138.567 E.01007
G1 X128.538 Y138.032 E.01592
G1 X128.629 Y137.624 E.01017
G1 X128.575 Y137.155 E.01148
G1 X128.444 Y136.778 E.00971
G1 X128.187 Y136.444 E.01025
G1 X127.484 Y135.791 E.02334
G1 X127.097 Y135.463 E.01234
G1 X127.097 Y94.271 E1.00195
G1 X127.34 Y94.271 E.00591
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X127.4 Y94.271 E-.0285
G1 X130.498 Y94.271 E-1.4715
;WIPE_END
G1 X103.537 Y94.637 F9000
G1 E5 F2400
G1 F6000
G1 X103.537 Y135.299 E.98906
G1 X102.837 Y135.9 E.02244
G1 X102.453 Y136.286 E.01324
G1 X102.226 Y136.634 E.01011
G1 X102.03 Y137.146 E.01334
G1 X101.997 Y137.598 E.01102
G1 X102.112 Y138.106 E.01267
G1 X102.366 Y138.603 E.01358
G1 X102.886 Y139.145 E.01827
G1 X103.612 Y139.766 E.02324
G1 X103.82 Y140.239 E.01257
G1 X104.203 Y140.609 E.01295
G1 X103.622 Y140.552 E.0142
G1 X102.781 Y140.385 E.02086
G1 X102.29 Y140.242 E.01244
G1 X101.72 Y140.036 E.01474
G1 X100.931 Y139.684 E.02101
G1 X100.304 Y139.32 E.01763
G1 X99.692 Y138.885 E.01826
G1 X99.303 Y138.567 E.01222
G1 X98.779 Y138.066 E.01763
G1 X98.306 Y137.522 E.01753
G1 X97.983 Y137.098 E.01297
G1 X97.592 Y136.488 E.01762
G1 X97.274 Y135.875 E.0168
G1 X97.046 Y135.361 E.01368
G1 X96.816 Y134.694 E.01716
G1 X96.552 Y133.5 E.02974
G1 X96.47 Y132.61 E.02174
G1 X96.462 Y95.838 E.89444
G1 X96.396 Y95.377 E.01133
G1 X96.132 Y94.851 E.01432
G1 X95.883 Y94.636 E.008
G1 X103.477 Y94.637 E.18472
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.537 Y94.637 E-.0285
G1 X103.537 Y97.735 E-1.4715
;WIPE_END
G1 X127.463 Y94.637 F9000
G1 E5 F2400
G1 F6000
G1 X135.117 Y94.636 E.18618
G1 X134.867 Y94.851 E.00802
G1 X134.604 Y95.377 E.0143
G1 X134.538 Y95.838 E.01133
G1 X134.537 Y132.259 E.8859
G1 X134.494 Y133.126 E.02111
G1 X134.409 Y133.721 E.01462
G1 X134.303 Y134.257 E.01329
G1 X133.926 Y135.422 E.02978
G1 X133.485 Y136.334 E.02464
G1 X133.21 Y136.811 E.01339
G1 X132.74 Y137.469 E.01967
G1 X132.266 Y138.018 E.01764
G1 X131.9 Y138.379 E.0125
G1 X131.286 Y138.901 E.0196
G1 X130.388 Y139.507 E.02635
G1 X129.287 Y140.041 E.02976
G1 X128.718 Y140.224 E.01454
G1 X127.806 Y140.48 E.02304
G1 X126.805 Y140.599 E.02452
G1 X127.079 Y140.373 E.00864
G1 X127.349 Y139.918 E.01287
G1 X127.388 Y139.766 E.00382
G1 X128.114 Y139.145 E.02324
G1 X128.571 Y138.66 E.01621
G1 X128.878 Y138.169 E.01409
G1 X128.994 Y137.643 E.0131
G1 X128.977 Y137.304 E.00826
G1 X128.866 Y136.831 E.01182
G1 X128.729 Y136.539 E.00785
G1 X128.436 Y136.176 E.01135
G1 X127.463 Y135.294 E.03194
G1 X127.463 Y94.697 E.98748
G1 X127.463 Y94.697 F9000
G1 X128.316 Y94.746
;WIDTH:0.4
G1 F3072.127
G1 X127.737 Y95.355 E.02044
G1 X128.227 Y95.355 E.01192
G1 X128.671 Y94.911 E.01527
G1 X129.191 Y94.911 E.01265
G1 X128.747 Y95.355 E.01527
G1 X129.267 Y95.355 E.01265
G1 X129.712 Y94.911 E.01529
G1 X130.232 Y94.911 E.01265
G1 X129.787 Y95.355 E.01529
G1 X130.307 Y95.356 E.01265
G1 X130.752 Y94.911 E.01531
G1 X131.272 Y94.911 E.01265
G1 X130.827 Y95.356 E.01531
G1 X131.347 Y95.356 E.01265
G1 X131.792 Y94.911 E.01531
G1 X132.312 Y94.911 E.01265
G1 X131.867 Y95.356 E.01531
G1 X132.386 Y95.356 E.01262
G1 X132.832 Y94.911 E.01532
G1 X133.352 Y94.911 E.01265
G1 X132.906 Y95.357 E.01534
G1 X133.426 Y95.357 E.01265
G1 X133.872 Y94.911 E.01534
G1 X134.392 Y94.911 E.01265
G1 X133.782 Y95.521 E.02098
G1 X133.782 Y95.521 F9000
G1 X134.096 Y95.723
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X127.737 Y95.72 E.15468
G1 X127.737 Y96.788 E.02598
G1 X134.264 Y96.79 E.15876
G1 X134.264 Y95.845 E.02299
G1 X134.279 Y95.723 E.00299
G1 X133.905 Y96.081 E.01259
;WIDTH:0.385363
G1 X133.905 Y96.432 E.0082
G1 X128.095 Y96.43 E.13567
G1 X128.095 Y96.079 E.0082
G1 X133.722 Y96.081 E.13139
G1 E-5 F3600
G1 X133.722 Y96.081 F9000
G1 X127.851 Y97.512
G1 E5 F2400
;WIDTH:0.51291
G1 F1200
G1 X127.809 Y97.469 E.00191
G1 X127.751 Y97.485 E.00192
G1 X127.736 Y97.543 E.00191
G1 X127.778 Y97.585 E.00189
G1 X127.836 Y97.57 E.00191
;WIDTH:0.399999
G1 X127.737 Y98.181 E.01506
G1 X128.447 Y97.471 E.02442
G1 X128.964 Y97.47 E.01258
G1 X127.737 Y98.698 E.04223
G1 X127.737 Y99.215 E.01258
G1 X129.482 Y97.47 E.06003
G1 X129.999 Y97.47 E.01258
G1 X127.737 Y99.732 E.07781
G1 X127.737 Y100.249 E.01258
G1 X130.516 Y97.47 E.0956
G1 X131.032 Y97.471 E.01255
G1 X127.737 Y100.766 E.11335
G1 X127.737 Y101.283 E.01258
G1 X131.549 Y97.472 E.13111
G1 X132.065 Y97.472 E.01255
G1 X127.737 Y101.801 E.1489
G1 X127.737 Y102.318 E.01258
G1 X132.582 Y97.473 E.16666
G1 X133.098 Y97.473 E.01255
G1 X127.737 Y102.835 E.18443
G1 X127.737 Y103.352 E.01258
G1 X133.615 Y97.474 E.2022
G1 X134.132 Y97.474 E.01258
G1 X127.737 Y103.869 E.21998
G1 X127.737 Y104.386 E.01258
G1 X134.264 Y97.86 E.22451
G1 X134.264 Y98.377 E.01258
G1 X127.737 Y104.903 E.22451
G1 X127.737 Y105.42 E.01258
G1 X134.264 Y98.894 E.22451
G1 X134.264 Y99.411 E.01258
G1 X127.737 Y105.938 E.22452
G1 X127.737 Y106.455 E.01258
G1 X134.264 Y99.928 E.22452
G1 X134.263 Y100.445 E.01258
G1 X127.737 Y106.972 E.22451
G1 X127.737 Y107.489 E.01258
G1 X134.263 Y100.962 E.22451
G1 X134.263 Y101.48 E.0126
G1 X127.737 Y108.006 E.22449
G1 X127.737 Y108.523 E.01258
G1 X134.263 Y101.997 E.22449
G1 X134.263 Y102.514 E.01258
G1 X127.737 Y109.04 E.22449
G1 X127.737 Y109.557 E.01258
G1 X134.263 Y103.031 E.22449
G1 X134.263 Y103.548 E.01258
G1 X127.737 Y110.075 E.22451
G1 X127.737 Y110.592 E.01258
G1 X134.263 Y104.065 E.22451
G1 X134.263 Y104.582 E.01258
G1 X127.737 Y111.109 E.22451
G1 X127.737 Y111.626 E.01258
G1 X134.263 Y105.099 E.22451
G1 X134.263 Y105.617 E.0126
G1 X127.737 Y112.143 E.22449
G1 X127.737 Y112.66 E.01258
G1 X134.263 Y106.134 E.22449
G1 X134.263 Y106.651 E.01258
G1 X127.737 Y113.177 E.22449
G1 X127.737 Y113.694 E.01258
G1 X134.263 Y107.168 E.22449
G1 X134.263 Y107.685 E.01258
G1 X127.737 Y114.212 E.22451
G1 X127.737 Y114.729 E.01258
G1 X134.263 Y108.202 E.22451
G1 X134.263 Y108.719 E.01258
G1 X127.737 Y115.246 E.22451
G1 X127.737 Y115.763 E.01258
G1 X134.263 Y109.236 E.22451
G1 X134.263 Y109.754 E.0126
G1 X127.737 Y116.28 E.22449
G1 X127.737 Y116.797 E.01258
G1 X134.263 Y110.271 E.22449
G1 X134.263 Y110.788 E.01258
G1 X127.737 Y117.314 E.22449
G1 X127.737 Y117.831 E.01258
G1 X134.263 Y111.305 E.22449
G1 X134.263 Y111.822 E.01258
G1 X127.737 Y118.349 E.22451
G1 X127.737 Y118.866 E.01258
G1 X134.263 Y112.339 E.22451
G1 X134.263 Y112.856 E.01258
G1 X127.737 Y119.383 E.22451
G1 X127.737 Y119.9 E.01258
G1 X134.263 Y113.374 E.22449
G1 X134.263 Y113.891 E.01258
G1 X127.737 Y120.417 E.22449
G1 X127.737 Y120.934 E.01258
G1 X134.263 Y114.408 E.22449
G1 X134.263 Y114.925 E.01258
G1 X127.737 Y121.451 E.22449
G1 X127.737 Y121.968 E.01258
G1 X134.263 Y115.442 E.22449
G1 X134.263 Y115.959 E.01258
G1 X127.737 Y122.486 E.22451
G1 X127.737 Y123.003 E.01258
G1 X134.263 Y116.476 E.22451
G1 X134.263 Y116.993 E.01258
G1 X127.737 Y123.52 E.22451
G1 X127.737 Y124.037 E.01258
G1 X134.263 Y117.511 E.22449
G1 X134.263 Y118.028 E.01258
G1 X127.737 Y124.554 E.22449
G1 X127.737 Y125.071 E.01258
G1 X134.263 Y118.545 E.22449
G1 X134.263 Y119.062 E.01258
G1 X127.737 Y125.588 E.22449
G1 X127.737 Y126.105 E.01258
G1 X134.263 Y119.579 E.22449
G1 X134.263 Y120.096 E.01258
G1 X127.737 Y126.623 E.22451
G1 X127.737 Y127.14 E.01258
G1 X134.263 Y120.613 E.22451
G1 X134.263 Y121.131 E.0126
G1 X127.737 Y127.657 E.22449
G1 X127.737 Y128.174 E.01258
G1 X134.263 Y121.648 E.22449
G1 X134.263 Y122.165 E.01258
G1 X127.737 Y128.691 E.22449
G1 X127.737 Y129.208 E.01258
G1 X134.263 Y122.682 E.22449
G1 X134.263 Y123.199 E.01258
G1 X127.737 Y129.725 E.22449
G1 X127.737 Y130.242 E.01258
G1 X134.263 Y123.716 E.22449
G1 X134.263 Y124.233 E.01258
G1 X127.737 Y130.76 E.22451
G1 X127.737 Y131.277 E.01258
G1 X134.263 Y124.75 E.22451
G1 X134.263 Y125.268 E.0126
G1 X127.737 Y131.794 E.22449
G1 X127.737 Y132.311 E.01258
G1 X134.263 Y125.785 E.22449
G1 X134.263 Y126.302 E.01258
G1 X127.737 Y132.828 E.22449
G1 X127.737 Y133.345 E.01258
G1 X134.263 Y126.819 E.22449
G1 X134.263 Y127.336 E.01258
G1 X127.737 Y133.862 E.22449
G1 X127.616 Y134.422 E.01394
;WIDTH:0.374336
G1 X127.605 Y134.284 E.00313
;WIDTH:0.399999
G1 X127.811 Y134.306 E.00504
G1 X134.263 Y127.853 E.22196
G1 X134.263 Y128.37 E.01258
G1 X128.32 Y134.313 E.20444
G1 X128.565 Y134.586 E.00892
G1 X134.263 Y128.887 E.19602
G1 X134.263 Y129.405 E.0126
G1 X128.698 Y134.969 E.19142
G1 X128.792 Y135.393 E.01056
G1 X134.263 Y129.922 E.1882
G1 X134.263 Y130.439 E.01258
G1 X128.858 Y135.844 E.18593
G1 X128.905 Y136.315 E.01151
G1 X134.263 Y130.956 E.18433
G1 X134.263 Y131.473 E.01258
G1 X129.084 Y136.652 E.17815
G1 X129.206 Y137.047 E.01006
G1 X134.263 Y131.99 E.17396
G1 X134.25 Y132.521 E.01292
G1 X129.261 Y137.51 E.17162
G1 X129.19 Y138.097 E.01438
G1 X134.223 Y133.065 E.17311
G1 E-5 F3600
G1 X134.223 Y133.065 F9000
G1 X129.013 Y138.356
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X128.69 Y138.762 E.01173
G1 X127.996 Y139.455 E.02218
;WIDTH:0.394144
G1 X127.964 Y139.576 E.003
;WIDTH:0.428153
G1 X128.07 Y139.81 E.00673
G1 X128.313 Y140.052 E.00898
G1 X128.132 Y140.11 E.00498
G1 X127.508 Y140.211 E.01656
G1 X127.633 Y139.969 E.00714
G1 X127.798 Y139.794 E.0063
G1 X127.904 Y139.613 E.00549
;WIDTH:0.399999
G1 X128.307 Y139.498 E.01019
G1 X134.14 Y133.665 E.20065
G1 X133.99 Y134.332 E.01663
G1 X128.552 Y139.77 E.18706
G1 X128.991 Y139.848 E.01085
G1 X133.744 Y135.095 E.1635
G1 X133.928 Y134.867 E.00713
;WIDTH:0.374336
G1 X133.887 Y134.878 E.00096
G1 X133.868 Y134.807 E.00166
G1 X133.939 Y134.826 E.00166
G1 X133.939 Y134.826 F9000
G1 X133.548 Y135.758
G1 F1200
G1 X133.477 Y135.739 E.00166
G1 X133.496 Y135.81 E.00166
G1 X133.537 Y135.799 E.00096
;WIDTH:0.399999
G1 X133.329 Y136.028 E.00752
G1 X129.705 Y139.637 E.12441
;WIDTH:0.374336
G1 X129.664 Y139.648 E.00096
G1 X129.645 Y139.577 E.00166
G1 X129.716 Y139.596 E.00166
G1 X129.716 Y139.596 F9000
G1 X130.644 Y139.119
G1 F1200
G1 X131.325 Y138.526 E.02042
G1 X131.511 Y138.475 E.00436
G1 X132.393 Y137.6 E.0281
G1 X132.445 Y137.428 E.00406
G1 X133.048 Y136.709 E.02122
G1 X133.048 Y136.709 F9000
G1 X132.204 Y137.669
;WIDTH:0.399999
G1 F1200
G1 X131.584 Y138.29 E.02134
G1 E-5 F3600
G1 X131.584 Y138.29 F9000
G1 X128.246 Y135.856
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X128.462 Y135.64 E.00743
G1 X128.362 Y135.139 E.01243
G1 X128.049 Y135.453 E.01078
G1 X127.737 Y135.165 E.01033
G1 X128.332 Y134.57 E.02047
G1 E-5 F3600
G1 X128.332 Y134.57 F9000
G1 X127.891 Y137.562
G1 X127.875 Y137.658
G1 X127.847 Y137.746
G1 X127.812 Y137.825
G1 X127.77 Y137.895
G1 X127.725 Y137.96
G1 X126.349 Y139.849
G1 X104.651 Y139.849
G1 X103.275 Y137.96
G1 X103.23 Y137.895
G1 X103.188 Y137.825
G1 X103.153 Y137.746
G1 X103.125 Y137.658
G1 X102.42 Y135.352
G1 E5 F2400
G1 F3072.127
G1 X103.101 Y134.671 E.02343
G1 X103.263 Y134.672 E.00394
G1 X103.263 Y135.129 E.01112
G1 X102.326 Y136.066 E.03223
G1 E-5 F3600
G1 X102.326 Y136.066 F9000
G1 X96.851 Y97.516
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.513066
G1 F1200
G1 X96.808 Y97.473 E.00194
G1 X96.751 Y97.489 E.00189
G1 X96.735 Y97.547 E.00192
G1 X96.777 Y97.589 E.00189
G1 X96.835 Y97.574 E.00191
;WIDTH:0.399999
G1 X96.736 Y98.185 E.01506
G1 X97.45 Y97.472 E.02454
G1 X97.966 Y97.473 E.01255
G1 X96.737 Y98.702 E.04228
G1 X96.737 Y99.219 E.01258
G1 X98.484 Y97.472 E.0601
G1 X99.001 Y97.471 E.01258
G1 X96.737 Y99.736 E.0779
G1 X96.737 Y100.253 E.01258
G1 X99.518 Y97.471 E.09568
G1 X100.035 Y97.472 E.01258
G1 X96.737 Y100.77 E.11345
G1 X96.737 Y101.287 E.01258
G1 X100.552 Y97.472 E.13123
G1 X101.069 Y97.472 E.01258
G1 X96.737 Y101.804 E.14902
G1 X96.737 Y102.321 E.01258
G1 X101.586 Y97.472 E.1668
G1 X102.103 Y97.472 E.01258
G1 X96.737 Y102.838 E.18459
G1 X96.738 Y103.355 E.01258
G1 X102.62 Y97.472 E.20235
G1 X103.137 Y97.473 E.01258
G1 X96.738 Y103.872 E.22012
G1 X96.738 Y104.389 E.01258
G1 X103.263 Y97.864 E.22446
G1 X103.263 Y98.381 E.01258
G1 X96.738 Y104.906 E.22446
G1 X96.738 Y105.423 E.01258
G1 X103.263 Y98.898 E.22446
G1 X103.263 Y99.415 E.01258
G1 X96.738 Y105.94 E.22446
G1 X96.738 Y106.457 E.01258
G1 X103.263 Y99.932 E.22446
G1 X103.263 Y100.449 E.01258
G1 X96.738 Y106.974 E.22446
G1 X96.739 Y107.491 E.01258
G1 X103.263 Y100.966 E.22444
G1 X103.263 Y101.483 E.01258
G1 X96.739 Y108.008 E.22444
G1 X96.739 Y108.525 E.01258
G1 X103.263 Y102.001 E.22442
G1 X103.263 Y102.518 E.01258
G1 X96.739 Y109.042 E.22442
G1 X96.739 Y109.559 E.01258
G1 X103.263 Y103.035 E.22442
G1 X103.263 Y103.552 E.01258
G1 X96.739 Y110.076 E.22442
G1 X96.739 Y110.593 E.01258
G1 X103.263 Y104.069 E.22442
G1 X103.263 Y104.586 E.01258
G1 X96.739 Y111.11 E.22442
G1 X96.739 Y111.627 E.01258
G1 X103.263 Y105.103 E.22442
G1 X103.263 Y105.62 E.01258
G1 X96.74 Y112.144 E.2244
G1 X96.74 Y112.661 E.01258
G1 X103.263 Y106.138 E.22439
G1 X103.263 Y106.655 E.01258
G1 X96.74 Y113.178 E.22439
G1 X96.74 Y113.695 E.01258
G1 X103.263 Y107.172 E.22439
G1 X103.263 Y107.689 E.01258
G1 X96.74 Y114.212 E.22439
G1 X96.74 Y114.729 E.01258
G1 X103.263 Y108.206 E.22439
G1 X103.263 Y108.723 E.01258
G1 X96.74 Y115.246 E.22439
G1 X96.74 Y115.763 E.01258
G1 X103.263 Y109.24 E.22439
G1 X103.263 Y109.757 E.01258
G1 X96.74 Y116.28 E.22439
G1 X96.741 Y116.797 E.01258
G1 X103.263 Y110.275 E.22435
G1 X103.263 Y110.792 E.01258
G1 X96.741 Y117.314 E.22435
G1 X96.741 Y117.831 E.01258
G1 X103.263 Y111.309 E.22435
G1 X103.263 Y111.826 E.01258
G1 X96.741 Y118.348 E.22435
G1 X96.741 Y118.865 E.01258
G1 X103.263 Y112.343 E.22435
G1 X103.263 Y112.86 E.01258
G1 X96.741 Y119.382 E.22435
G1 X96.741 Y119.899 E.01258
G1 X103.263 Y113.377 E.22435
G1 X103.263 Y113.895 E.0126
G1 X96.741 Y120.416 E.22434
G1 X96.741 Y120.933 E.01258
G1 X103.263 Y114.412 E.22434
G1 X103.263 Y114.929 E.01258
G1 X96.742 Y121.45 E.22432
G1 X96.742 Y121.967 E.01258
G1 X103.263 Y115.446 E.22432
G1 X103.263 Y115.963 E.01258
G1 X96.742 Y122.484 E.22432
G1 X96.742 Y123.001 E.01258
G1 X103.263 Y116.48 E.22432
G1 X103.263 Y116.997 E.01258
G1 X96.742 Y123.518 E.22432
G1 X96.742 Y124.035 E.01258
G1 X103.263 Y117.514 E.22432
G1 X103.263 Y118.032 E.0126
G1 X96.742 Y124.552 E.2243
G1 X96.742 Y125.069 E.01258
G1 X103.263 Y118.549 E.2243
G1 X103.263 Y119.066 E.01258
G1 X96.743 Y125.586 E.22428
G1 X96.743 Y126.103 E.01258
G1 X103.263 Y119.583 E.22428
G1 X103.263 Y120.1 E.01258
G1 X96.743 Y126.62 E.22428
G1 X96.743 Y127.137 E.01258
G1 X103.263 Y120.617 E.22428
G1 X103.263 Y121.134 E.01258
G1 X96.743 Y127.654 E.22428
G1 X96.743 Y128.171 E.01258
G1 X103.263 Y121.651 E.22428
G1 X103.263 Y122.169 E.0126
G1 X96.743 Y128.688 E.22427
G1 X96.743 Y129.205 E.01258
G1 X103.263 Y122.686 E.22427
G1 X103.263 Y123.203 E.01258
G1 X96.743 Y129.722 E.22427
G1 X96.744 Y130.239 E.01258
G1 X103.263 Y123.72 E.22425
G1 X103.263 Y124.237 E.01258
G1 X96.744 Y130.756 E.22425
G1 X96.744 Y131.273 E.01258
G1 X103.263 Y124.754 E.22425
G1 X103.263 Y125.271 E.01258
G1 X96.744 Y131.79 E.22425
G1 X96.744 Y132.307 E.01258
G1 X103.263 Y125.788 E.22425
G1 X103.263 Y126.306 E.0126
G1 X96.763 Y132.805 E.22358
G1 X96.807 Y133.279 E.01158
G1 X103.263 Y126.823 E.22208
G1 X103.263 Y127.34 E.01258
G1 X96.882 Y133.721 E.2195
G1 X96.975 Y134.145 E.01056
G1 X103.263 Y127.857 E.2163
G1 X103.263 Y128.374 E.01258
G1 X97.069 Y134.568 E.21307
G1 X97.197 Y134.958 E.00998
G1 X103.263 Y128.891 E.20868
G1 X103.263 Y129.408 E.01258
G1 X97.334 Y135.338 E.20397
G1 X97.491 Y135.698 E.00955
G1 X103.263 Y129.925 E.19857
G1 X103.263 Y130.443 E.0126
G1 X97.667 Y136.038 E.19248
G1 X97.846 Y136.377 E.00932
G1 X103.263 Y130.96 E.18634
G1 X103.263 Y131.477 E.01258
G1 X98.048 Y136.692 E.17939
G1 X98.254 Y137.003 E.00907
G1 X103.263 Y131.994 E.17231
G1 X103.263 Y132.511 E.01258
G1 X98.475 Y137.299 E.1647
G1 X98.716 Y137.575 E.00891
G1 X103.263 Y133.028 E.15641
G1 X103.263 Y133.545 E.01258
G1 X98.957 Y137.852 E.14814
G1 X99.219 Y138.107 E.00889
G1 X102.285 Y135.041 E.10547
G1 X102.442 Y134.782 E.00737
;WIDTH:0.374336
G1 X102.702 Y134.446 E.00961
;WIDTH:0.416405
G1 X102.824 Y134.394 E.00337
;WIDTH:0.458474
G1 X102.947 Y134.341 E.00378
;WIDTH:0.500543
G1 X103.069 Y134.288 E.00413
;WIDTH:0.542612
G1 X103.192 Y134.235 E.00453
G1 X103.192 Y134.235 F9000
G1 X102.166 Y135.677
;WIDTH:0.399999
G1 F1200
G1 X102.132 Y136.269 E.01442
G1 X101.866 Y136.757 E.01352
G1 X101.766 Y137.074 E.00809
G1 X101.723 Y137.587 E.01252
G1 X101.811 Y138.076 E.01209
G1 X102.009 Y138.545 E.01238
G1 X102.325 Y138.975 E.01298
G1 X102.606 Y139.259 E.00972
G1 X103.355 Y139.906 E.02407
G1 X103.53 Y140.25 E.00939
G1 X102.822 Y140.114 E.01754
G1 X102.171 Y139.921 E.01652
G1 X101.446 Y139.632 E.01898
G1 X100.45 Y139.088 E.0276
G1 X99.83 Y138.647 E.01851
G1 X99.489 Y138.353 E.01095
G1 X102.036 Y135.806 E.08762
G1 X102.036 Y135.806 F9000
G1 X101.401 Y136.958
G1 F1200
G1 X101.366 Y137.701 E.01809
G1 X101.473 Y138.214 E.01275
G1 X101.714 Y138.762 E.01456
G1 X102.084 Y139.255 E.01499
G1 X102.476 Y139.63 E.0132
G1 X101.865 Y139.405 E.01584
G1 X101.176 Y139.067 E.01867
G1 X100.569 Y138.724 E.01696
G1 X100.025 Y138.335 E.01627
G1 X101.272 Y137.088 E.0429
G1 X101.272 Y137.088 F9000
G1 X101.017 Y137.871
;WIDTH:0.416801
G1 F1200
G1 X101.083 Y138.219 E.00901
G1 X101.262 Y138.688 E.01277
G1 X100.601 Y138.287 E.01967
G1 X100.888 Y138.001 E.01031
G1 E-5 F3600
G1 X100.888 Y138.001 F9000
G1 X96.72 Y95.723
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X103.263 Y95.72 E.15915
G1 X103.263 Y96.789 E.026
G1 X96.736 Y96.797 E.15876
G1 X96.726 Y95.905 E.0217
G1 X97.096 Y96.088 E.01004
;WIDTH:0.388316
G1 X97.096 Y96.436 E.00819
G1 X102.728 Y96.431 E.13262
;WIDTH:0.386492
G1 X102.904 Y96.431 E.00412
G1 X102.904 Y96.079 E.00825
G1 X102.728 Y96.079 E.00412
;WIDTH:0.388316
G1 X97.273 Y96.082 E.12845
G1 X97.273 Y96.082 F9000
G1 X96.964 Y94.746
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X96.577 Y95.133 E.01331
G1 X96.668 Y95.357 E.00588
G1 X96.895 Y95.357 E.00552
G1 X97.341 Y94.911 E.01534
G1 X97.883 Y94.911 E.01318
G1 X97.437 Y95.357 E.01534
G1 X97.979 Y95.356 E.01318
G1 X98.425 Y94.911 E.01532
G1 X98.967 Y94.911 E.01318
G1 X98.521 Y95.356 E.01532
G1 X99.063 Y95.356 E.01318
G1 X99.508 Y94.911 E.01531
G1 X100.05 Y94.911 E.01318
G1 X99.605 Y95.356 E.01531
G1 X100.147 Y95.356 E.01318
G1 X100.592 Y94.911 E.01531
G1 X101.133 Y94.911 E.01316
G1 X100.689 Y95.355 E.01527
G1 X101.231 Y95.355 E.01318
G1 X101.675 Y94.911 E.01527
G1 X102.217 Y94.911 E.01318
G1 X101.773 Y95.355 E.01527
G1 X102.315 Y95.355 E.01318
G1 X102.759 Y94.911 E.01527
G1 X103.263 Y94.911 E.01226
G1 X102.693 Y95.519 E.02027
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.263 Y94.911 E-.39587
G1 X102.759 Y94.911 E-.2394
G1 X102.315 Y95.355 E-.29826
G1 X101.773 Y95.355 E-.25745
G1 X102.217 Y94.911 E-.29826
G1 X102.194 Y94.911 E-.01076
;WIPE_END
G1 X104.651 Y98.339 F9000
G1 X106.012 Y100.237
G1 X111.88 Y108.421
G1 X112.088 Y108.714
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X112.527 Y108.438 E.01261
G1 X113.121 Y108.229 E.01532
G1 X113.768 Y108.151 E.01585
G1 X117.476 Y108.162 E.09019
G1 X117.776 Y108.205 E.00737
G1 X118.469 Y108.436 E.01777
G1 X119.007 Y108.774 E.01545
G1 X119.567 Y109.369 E.01987
G1 X121.431 Y112.576 E.09023
G1 X121.643 Y113.034 E.01228
G1 X121.774 Y113.538 E.01267
G1 X121.806 Y114.165 E.01527
G1 X121.729 Y114.684 E.01276
G1 X121.491 Y115.308 E.01624
G1 X119.567 Y118.63 E.09338
G1 X119.042 Y119.197 E.0188
G1 X118.604 Y119.495 E.01289
G1 X118.238 Y119.664 E.00981
G1 X117.743 Y119.802 E.0125
G1 X117.233 Y119.849 E.01246
G1 X113.767 Y119.849 E.08431
G1 X112.975 Y119.735 E.01946
G1 X112.428 Y119.512 E.01437
G1 X111.878 Y119.128 E.01632
G1 X111.433 Y118.63 E.01624
G1 X109.569 Y115.424 E.09021
G1 X109.357 Y114.966 E.01228
G1 X109.226 Y114.461 E.01269
G1 X109.189 Y114.059 E.00982
G1 X109.226 Y113.539 E.01268
G1 X109.357 Y113.034 E.01269
G1 X109.569 Y112.576 E.01228
G1 X111.433 Y109.37 E.09021
G1 X111.992 Y108.774 E.01988
G1 X112.037 Y108.746 E.00129
G1 X112.037 Y108.746 F9000
G1 X111.814 Y108.455
;TYPE:Perimeter
G1 F6000
G1 X112.406 Y108.093 E.01688
G1 X112.999 Y107.884 E.01529
G1 X113.769 Y107.786 E.01888
G1 X117.477 Y107.797 E.09019
G1 X117.892 Y107.859 E.01021
G1 X118.585 Y108.089 E.01776
G1 X119.204 Y108.466 E.01763
G1 X119.755 Y109.029 E.01916
G1 X119.883 Y109.186 E.00493
G1 X121.747 Y112.392 E.09021
G1 X121.975 Y112.881 E.01312
G1 X122.129 Y113.449 E.01431
G1 X122.172 Y114.149 E.01706
G1 X122.09 Y114.741 E.01454
G1 X121.832 Y115.44 E.01812
G1 X119.884 Y118.814 E.09477
G1 X119.309 Y119.447 E.0208
G1 X118.807 Y119.799 E.01491
G1 X118.337 Y120.016 E.01259
G1 X117.794 Y120.164 E.01369
G1 X117.233 Y120.214 E.0137
G1 X113.767 Y120.214 E.08431
G1 X113.14 Y120.133 E.01538
G1 X112.837 Y120.073 E.00751
G1 X112.29 Y119.851 E.01436
G1 X111.863 Y119.566 E.01249
G1 X111.575 Y119.344 E.00884
G1 X111.117 Y118.814 E.01704
G1 X109.253 Y115.608 E.09021
G1 X109.025 Y115.119 E.01312
G1 X108.871 Y114.551 E.01431
G1 X108.824 Y114.035 E.0126
G1 X108.871 Y113.449 E.0143
G1 X109.025 Y112.881 E.01431
G1 X109.253 Y112.392 E.01312
G1 X111.117 Y109.186 E.09021
G1 X111.533 Y108.722 E.01516
G1 X111.768 Y108.493 E.00798
G1 X111.768 Y108.493 F9000
G1 X111.548 Y108.206
G1 F6000
G1 X111.598 Y108.158 E.00169
G1 X112.095 Y107.84 E.01435
G1 X112.285 Y107.748 E.00513
G1 X112.878 Y107.539 E.01529
G1 X113.77 Y107.42 E.02189
G1 X117.479 Y107.431 E.09022
G1 X118.007 Y107.512 E.01299
G1 X118.7 Y107.742 E.01776
G1 X119.401 Y108.158 E.01983
G1 X120.022 Y108.779 E.02136
G1 X120.199 Y109.002 E.00693
G1 X122.063 Y112.208 E.09021
G1 X122.307 Y112.728 E.01397
G1 X122.483 Y113.359 E.01593
G1 X122.537 Y114.132 E.01885
G1 X122.451 Y114.797 E.01631
G1 X122.172 Y115.573 E.02006
G1 X120.2 Y118.997 E.09611
G1 X119.576 Y119.697 E.02281
G1 X119.01 Y120.103 E.01694
G1 X118.437 Y120.368 E.01536
G1 X117.844 Y120.527 E.01493
G1 X117.233 Y120.58 E.01492
G1 X113.767 Y120.58 E.08431
G1 X113.09 Y120.495 E.0166
G1 X112.699 Y120.412 E.00972
G1 X112.152 Y120.189 E.01437
G1 X111.652 Y119.864 E.01451
G1 X111.302 Y119.588 E.01084
G1 X110.909 Y119.147 E.01437
G1 X110.8 Y118.998 E.00449
G1 X108.937 Y115.792 E.09019
G1 X108.693 Y115.272 E.01397
G1 X108.517 Y114.641 E.01593
G1 X108.458 Y114.071 E.01394
G1 X108.491 Y113.525 E.01331
G1 X108.637 Y112.886 E.01594
G1 X108.937 Y112.208 E.01803
G1 X110.801 Y109.002 E.09021
G1 X111.266 Y108.471 E.01717
G1 X111.504 Y108.247 E.00795
G1 E-5 F3600
G1 X109.428 Y103.365 F9000
G1 E5 F2400
G1 F6000
G1 X108.62 Y101.975 E.03911
G1 X108.36 Y101.425 E.0148
G1 X108.162 Y100.731 E.01755
G1 X108.097 Y100.186 E.01335
G1 X108.126 Y99.502 E.01665
G1 X108.276 Y98.82 E.01699
G1 X108.564 Y98.132 E.01814
G1 X110.484 Y94.818 E.09316
G1 X110.941 Y94.283 E.01711
G1 X111.401 Y93.85 E.01537
G1 X111.898 Y93.532 E.01435
G1 X112.757 Y93.194 E.02245
G1 X113.622 Y93.063 E.02128
G1 X117.48 Y93.065 E.09384
G1 X118.123 Y93.165 E.01583
G1 X118.816 Y93.396 E.01777
G1 X119.101 Y93.532 E.00768
G1 X119.598 Y93.85 E.01435
G1 X120.059 Y94.284 E.0154
G1 X120.515 Y94.818 E.01708
G1 X122.38 Y98.024 E.09022
G1 X122.64 Y98.575 E.01482
G1 X122.838 Y99.269 E.01755
G1 X122.902 Y100.115 E.02064
G1 X122.812 Y100.854 E.01811
G1 X122.513 Y101.705 E.02194
G1 X120.516 Y105.18 E.09749
G1 X119.842 Y105.948 E.02485
G1 X119.213 Y106.408 E.01895
G1 X118.725 Y106.65 E.01325
G1 X118.13 Y106.835 E.01516
;WIDTH:0.441652
G1 X118.014 Y106.875 E.00332
;WIDTH:0.483305
G1 X117.897 Y106.915 E.00369
;WIDTH:0.524958
G1 X117.78 Y106.955 E.00404
;WIDTH:0.56661
G1 X117.663 Y106.995 E.00438
G1 X117.878 Y107.071 E.00807
;WIDTH:0.524958
G1 X118.093 Y107.147 E.00744
;WIDTH:0.483305
G1 X118.308 Y107.222 E.0068
;WIDTH:0.441652
G1 X118.523 Y107.298 E.00618
;WIDTH:0.399999
G1 X119.013 Y107.48 E.01271
G1 X119.598 Y107.85 E.01684
G1 X119.843 Y108.053 E.00774
G1 X120.343 Y108.586 E.01778
G1 X120.515 Y108.818 E.00702
G1 X122.38 Y112.024 E.09022
G1 X122.64 Y112.575 E.01482
G1 X122.838 Y113.269 E.01755
G1 X122.902 Y114.115 E.02064
G1 X122.812 Y114.854 E.01811
G1 X122.513 Y115.705 E.02194
G1 X122.428 Y115.884 E.00482
G1 X120.516 Y119.18 E.09268
G1 X119.842 Y119.948 E.02485
G1 X119.213 Y120.408 E.01895
G1 X118.725 Y120.65 E.01325
G1 X118.13 Y120.835 E.01516
;WIDTH:0.441652
G1 X118.014 Y120.875 E.00332
;WIDTH:0.483304
G1 X117.897 Y120.915 E.00369
;WIDTH:0.524956
G1 X117.78 Y120.955 E.00404
;WIDTH:0.566608
G1 X117.663 Y120.995 E.00438
G1 X117.878 Y121.071 E.00807
;WIDTH:0.524956
G1 X118.093 Y121.147 E.00744
;WIDTH:0.483304
G1 X118.308 Y121.222 E.0068
;WIDTH:0.441652
G1 X118.523 Y121.298 E.00618
;WIDTH:0.399999
G1 X119.013 Y121.48 E.01271
G1 X119.598 Y121.85 E.01684
G1 X119.843 Y122.053 E.00774
G1 X120.343 Y122.586 E.01778
G1 X120.515 Y122.818 E.00702
G1 X122.38 Y126.024 E.09022
G1 X122.64 Y126.575 E.01482
G1 X122.838 Y127.269 E.01755
G1 X122.902 Y128.115 E.02064
G1 X122.812 Y128.854 E.01811
G1 X122.513 Y129.705 E.02194
G1 X122.428 Y129.884 E.00482
G1 X120.516 Y133.18 E.09268
G1 X120.059 Y133.717 E.01715
G1 X119.619 Y134.137 E.0148
G1 X119.04 Y134.504 E.01667
G1 X118.536 Y134.72 E.01334
G1 X117.939 Y134.882 E.01505
G1 X117.233 Y134.946 E.01724
G1 X113.767 Y134.946 E.08431
G1 X112.868 Y134.833 E.02204
G1 X112.561 Y134.751 E.00773
G1 X112.014 Y134.528 E.01437
G1 X111.244 Y134.024 E.02238
G1 X110.636 Y133.39 E.02137
G1 X110.484 Y133.182 E.00627
G1 X108.62 Y129.975 E.09023
G1 X108.36 Y129.425 E.0148
G1 X108.162 Y128.731 E.01755
G1 X108.097 Y128.186 E.01335
G1 X108.126 Y127.502 E.01665
G1 X108.282 Y126.796 E.01759
G1 X108.564 Y126.132 E.01755
G1 X110.484 Y122.818 E.09316
G1 X110.999 Y122.221 E.01918
G1 X111.401 Y121.85 E.01331
G1 X111.898 Y121.532 E.01435
G1 X112.549 Y121.267 E.0171
G1 X113.036 Y121.13 E.01231
;WIDTH:0.449264
G1 X113.31 Y121.073 E.00772
;WIDTH:0.498529
G1 X113.584 Y121.017 E.00864
;WIDTH:0.518864
G1 X113.651 Y121 E.00223
G1 X113.447 Y120.952 E.00675
;WIDTH:0.479243
G1 X113.243 Y120.905 E.0062
;WIDTH:0.439621
G1 X113.039 Y120.857 E.00565
;WIDTH:0.399999
G1 X112.561 Y120.751 E.01191
G1 X112.014 Y120.528 E.01437
G1 X111.441 Y120.163 E.01653
G1 X111.029 Y119.831 E.01287
G1 X110.636 Y119.39 E.01437
G1 X110.484 Y119.182 E.00627
G1 X108.62 Y115.975 E.09023
G1 X108.36 Y115.425 E.0148
G1 X108.162 Y114.731 E.01755
G1 X108.097 Y114.186 E.01335
G1 X108.126 Y113.502 E.01665
G1 X108.282 Y112.796 E.01759
G1 X108.564 Y112.132 E.01755
G1 X110.484 Y108.818 E.09316
G1 X110.999 Y108.221 E.01918
G1 X111.401 Y107.85 E.01331
G1 X111.898 Y107.532 E.01435
G1 X112.549 Y107.267 E.0171
G1 X113.036 Y107.13 E.01231
;WIDTH:0.449265
G1 X113.31 Y107.073 E.00772
;WIDTH:0.49853
G1 X113.584 Y107.017 E.00864
;WIDTH:0.518864
G1 X113.651 Y107 E.00223
G1 X113.447 Y106.952 E.00675
;WIDTH:0.479243
G1 X113.243 Y106.905 E.0062
;WIDTH:0.439621
G1 X113.039 Y106.857 E.00565
;WIDTH:0.399999
G1 X112.561 Y106.751 E.01191
G1 X112.014 Y106.528 E.01437
G1 X111.441 Y106.163 E.01653
G1 X111.029 Y105.831 E.01287
G1 X110.636 Y105.39 E.01437
G1 X110.484 Y105.182 E.00627
G1 X109.459 Y103.417 E.04965
G1 E-5 F3600
G1 X109.459 Y103.417 F9000
G1 X108.846 Y113.79
G1 X108.84 Y113.918
G1 X108.84 Y114.082
G1 X108.846 Y114.21
G1 X108.862 Y114.374
G1 X108.878 Y114.501
G1 X108.909 Y114.663
G1 X108.937 Y114.788
G1 X108.984 Y114.946
G1 X109.022 Y115.068
G1 X109.083 Y115.221
G1 X109.132 Y115.34
G1 X109.208 Y115.486
G1 X109.261 Y115.588
G1 X111.005 Y118.609
G1 X111.067 Y118.706
G1 X111.156 Y118.845
G1 X111.234 Y118.946
G1 X111.336 Y119.076
G1 X111.422 Y119.17
G1 X111.536 Y119.289
G1 X111.63 Y119.376
G1 X111.755 Y119.484
G1 X111.857 Y119.562
G1 X111.991 Y119.657
G1 X112.099 Y119.726
G1 X112.241 Y119.809
G1 X112.355 Y119.868
G1 X112.505 Y119.936
G1 X112.623 Y119.985
G1 X112.779 Y120.039
G1 X112.901 Y120.078
G1 X113.061 Y120.117
G1 X113.186 Y120.144
G1 E5 F2400
;WIDTH:0.566608
G1 F6000
G1 X117.233 Y121.005 E.01523
;WIDTH:0.51909
G1 X113.772 Y121 E.1116
;WIDTH:0.518864
G1 X113.651 Y121 E.0039
G1 E-5 F3600
G1 X113.651 Y121 F9000
G1 X111.63 Y119.376
G1 X111.422 Y119.17
G1 X109.132 Y115.34
G1 X108.846 Y114.21
G1 X108.84 Y114.082
G1 X108.84 Y113.918
G1 X108.846 Y113.79
G1 X108.862 Y113.626
G1 X108.878 Y113.499
G1 X108.909 Y113.337
G1 X108.937 Y113.212
G1 X108.984 Y113.054
G1 X109.022 Y112.932
G1 X109.083 Y112.779
G1 X109.132 Y112.66
G1 X109.208 Y112.514
G1 X109.261 Y112.412
G1 X111.005 Y109.391
G1 X111.067 Y109.294
G1 X111.156 Y109.155
G1 X111.234 Y109.054
G1 X111.336 Y108.924
G1 X111.422 Y108.83
G1 X111.536 Y108.711
G1 X111.63 Y108.624
G1 X111.755 Y108.516
G1 X111.857 Y108.438
G1 X111.991 Y108.343
G1 X112.099 Y108.274
G1 X112.241 Y108.191
G1 X112.355 Y108.132
G1 X112.505 Y108.064
G1 X112.623 Y108.015
G1 X112.779 Y107.961
G1 X112.901 Y107.922
G1 X113.061 Y107.883
G1 X113.186 Y107.856
G1 E5 F2400
;WIDTH:0.56661
G1 F6000
G1 X117.233 Y107.005 E.01523
;WIDTH:0.51909
G1 X113.772 Y107 E.1116
;WIDTH:0.518864
G1 X113.651 Y107 E.0039
G1 E-5 F3600
G1 X113.651 Y107 F9000
G1 X109.021 Y103.393
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X108.304 Y102.159 E.03471
G1 X108.028 Y101.578 E.01565
;WIDTH:0.446536
G1 X107.896 Y101.205 E.01085
;WIDTH:0.493073
G1 X107.763 Y100.832 E.01208
;WIDTH:0.537063
G1 X107.696 Y100.571 E.00901
G1 X107.668 Y100.071 E.01675
;WIDTH:0.53504
G1 X107.694 Y99.474 E.0199
;WIDTH:0.577248
G1 X107.836 Y98.708 E.02814
G1 X107.884 Y98.637 E.0031
;WIDTH:0.532936
G1 X107.932 Y98.565 E.00287
;WIDTH:0.488624
G1 X107.98 Y98.493 E.00261
;WIDTH:0.444312
G1 X108.028 Y98.422 E.00234
;WIDTH:0.399999
G1 X108.304 Y97.841 E.01565
G1 X110.168 Y94.634 E.09023
G1 X110.674 Y94.033 E.01911
G1 X111.204 Y93.542 E.01757
G1 X111.701 Y93.224 E.01435
G1 X112.042 Y93.058 E.00923
G1 X112.635 Y92.849 E.01529
G1 X112.995 Y92.766 E.00899
G1 X113.773 Y92.689 E.01902
G1 X117.481 Y92.7 E.09019
G1 X117.944 Y92.749 E.01132
G1 X118.931 Y93.049 E.02509
G1 X119.298 Y93.224 E.00989
G1 X119.795 Y93.542 E.01435
G1 X120.326 Y94.033 E.01759
G1 X120.832 Y94.634 E.01911
G1 X122.696 Y97.841 E.09023
G1 X122.972 Y98.422 E.01565
;WIDTH:0.444312
G1 X123.02 Y98.493 E.00234
;WIDTH:0.488624
G1 X123.068 Y98.565 E.00261
;WIDTH:0.532937
G1 X123.116 Y98.637 E.00287
;WIDTH:0.577249
G1 X123.164 Y98.708 E.0031
G1 X123.288 Y99.268 E.02071
;WIDTH:0.549788
G1 X123.328 Y100.096 E.02842
;WIDTH:0.569656
G1 X123.257 Y100.924 E.02959
G1 X123.157 Y101.153 E.0089
;WIDTH:0.527242
G1 X123.056 Y101.381 E.00818
;WIDTH:0.484828
G1 X122.955 Y101.609 E.00747
;WIDTH:0.442414
G1 X122.854 Y101.837 E.00677
;WIDTH:0.399999
G1 X122.445 Y102.582 E.02067
G1 X120.833 Y105.364 E.07821
G1 X120.555 Y105.722 E.01103
G1 X120.109 Y106.198 E.01587
G1 X119.785 Y106.465 E.01021
G1 X119.311 Y106.776 E.01379
G1 X118.809 Y107.008 E.01345
G1 X119.298 Y107.224 E.013
G1 X119.795 Y107.542 E.01435
G1 X120.109 Y107.803 E.00993
G1 X120.609 Y108.336 E.01778
G1 X120.832 Y108.634 E.00905
G1 X122.696 Y111.841 E.09023
G1 X122.972 Y112.422 E.01565
;WIDTH:0.439818
G1 X123.064 Y112.67 E.00713
;WIDTH:0.479636
G1 X123.157 Y112.917 E.00782
;WIDTH:0.519454
G1 X123.25 Y113.165 E.00855
G1 X123.306 Y114.097 E.03013
;WIDTH:0.525984
G1 X123.236 Y114.921 E.02705
G1 X123.109 Y115.226 E.01081
;WIDTH:0.483989
G1 X122.981 Y115.532 E.00992
;WIDTH:0.441994
G1 X122.854 Y115.837 E.00896
;WIDTH:0.399999
G1 X122.744 Y116.067 E.0062
G1 X120.833 Y119.364 E.09269
G1 X120.555 Y119.722 E.01103
G1 X120.109 Y120.198 E.01587
G1 X119.785 Y120.465 E.01021
G1 X119.311 Y120.776 E.01379
G1 X118.809 Y121.008 E.01345
G1 X119.298 Y121.224 E.013
G1 X119.795 Y121.542 E.01435
G1 X120.109 Y121.803 E.00993
G1 X120.609 Y122.336 E.01778
G1 X120.832 Y122.634 E.00905
G1 X122.696 Y125.841 E.09023
G1 X122.972 Y126.422 E.01565
;WIDTH:0.439818
G1 X123.064 Y126.67 E.00713
;WIDTH:0.479636
G1 X123.157 Y126.917 E.00782
;WIDTH:0.519454
G1 X123.25 Y127.165 E.00855
G1 X123.306 Y128.097 E.03013
;WIDTH:0.525985
G1 X123.236 Y128.921 E.02705
G1 X123.109 Y129.226 E.01081
;WIDTH:0.48399
G1 X122.981 Y129.532 E.00992
;WIDTH:0.441995
G1 X122.854 Y129.837 E.00896
;WIDTH:0.399999
G1 X122.744 Y130.067 E.0062
G1 X120.833 Y133.364 E.09269
G1 X120.326 Y133.967 E.01916
G1 X119.821 Y134.441 E.01685
G1 X119.194 Y134.836 E.01803
G1 X118.636 Y135.072 E.01474
G1 X118.003 Y135.242 E.01594
G1 X117.384 Y135.304 E.01513
G1 X113.767 Y135.311 E.08798
G1 X112.818 Y135.195 E.02326
G1 X112.423 Y135.089 E.00995
G1 X111.876 Y134.867 E.01436
G1 X111.546 Y134.686 E.00916
G1 X111.033 Y134.322 E.0153
G1 X110.7 Y134.011 E.01108
G1 X110.363 Y133.634 E.0123
G1 X110.168 Y133.365 E.00808
G1 X108.304 Y130.159 E.09021
G1 X108.028 Y129.578 E.01565
;WIDTH:0.433202
G1 X107.902 Y129.203 E.0105
;WIDTH:0.466405
G1 X107.776 Y128.829 E.01134
;WIDTH:0.493568
G1 X107.718 Y128.569 E.00814
G1 X107.692 Y127.963 E.01853
;WIDTH:0.519401
G1 X107.75 Y127.165 E.02582
G1 X107.843 Y126.917 E.00855
;WIDTH:0.479601
G1 X107.936 Y126.67 E.00782
;WIDTH:0.4398
G1 X108.028 Y126.422 E.00713
;WIDTH:0.399999
G1 X108.304 Y125.841 E.01565
G1 X110.168 Y122.634 E.09023
G1 X110.732 Y121.971 E.02117
G1 X111.069 Y121.639 E.01151
G1 X111.531 Y121.333 E.01348
G1 X112.042 Y121.058 E.01412
G1 X112.205 Y121 E.00421
G1 X111.689 Y120.776 E.01368
G1 X111.229 Y120.461 E.01356
G1 X110.756 Y120.075 E.01485
G1 X110.363 Y119.634 E.01437
G1 X110.168 Y119.365 E.00808
G1 X108.304 Y116.159 E.09021
G1 X108.028 Y115.578 E.01565
;WIDTH:0.433202
G1 X107.902 Y115.203 E.0105
;WIDTH:0.466405
G1 X107.776 Y114.829 E.01134
;WIDTH:0.493568
G1 X107.718 Y114.569 E.00814
G1 X107.692 Y113.963 E.01853
;WIDTH:0.519401
G1 X107.75 Y113.165 E.02582
G1 X107.843 Y112.917 E.00855
;WIDTH:0.479601
G1 X107.936 Y112.67 E.00782
;WIDTH:0.4398
G1 X108.028 Y112.422 E.00713
;WIDTH:0.399999
G1 X108.304 Y111.841 E.01565
G1 X110.168 Y108.634 E.09023
G1 X110.732 Y107.971 E.02117
G1 X111.069 Y107.639 E.01151
G1 X111.531 Y107.333 E.01348
G1 X112.042 Y107.058 E.01412
G1 X112.205 Y107 E.00421
G1 X111.689 Y106.776 E.01368
G1 X111.229 Y106.461 E.01356
G1 X110.756 Y106.075 E.01485
G1 X110.363 Y105.634 E.01437
G1 X110.168 Y105.365 E.00808
G1 X109.052 Y103.445 E.05402
G1 X109.052 Y103.445 F9000
G1 X110.318 Y102.713
G1 F6000
G1 X109.569 Y101.424 E.03626
G1 X109.357 Y100.966 E.01228
G1 X109.226 Y100.461 E.01269
G1 X109.189 Y100.059 E.00982
G1 X109.221 Y99.572 E.01187
G1 X109.346 Y99.066 E.01268
G1 X109.569 Y98.576 E.0131
G1 X111.433 Y95.369 E.09023
G1 X111.957 Y94.803 E.01876
G1 X112.49 Y94.456 E.01547
G1 X113.121 Y94.229 E.01631
G1 X113.747 Y94.153 E.01534
G1 X117.476 Y94.162 E.0907
G1 X117.776 Y94.205 E.00737
G1 X118.469 Y94.436 E.01777
G1 X119.007 Y94.774 E.01545
G1 X119.567 Y95.369 E.01987
G1 X121.431 Y98.576 E.09023
G1 X121.643 Y99.034 E.01228
G1 X121.774 Y99.538 E.01267
G1 X121.806 Y100.165 E.01527
G1 X121.729 Y100.684 E.01276
G1 X121.491 Y101.308 E.01624
G1 X119.567 Y104.63 E.09338
G1 X119.042 Y105.197 E.0188
G1 X118.604 Y105.495 E.01289
G1 X118.238 Y105.664 E.00981
G1 X117.743 Y105.802 E.0125
G1 X117.233 Y105.849 E.01246
G1 X113.767 Y105.849 E.08431
G1 X112.975 Y105.735 E.01946
G1 X112.428 Y105.512 E.01437
G1 X111.878 Y105.128 E.01632
G1 X111.433 Y104.63 E.01624
G1 X110.348 Y102.765 E.05248
G1 X110.348 Y102.765 F9000
G1 X110.036 Y102.946
;TYPE:Perimeter
G1 F6000
G1 X109.253 Y101.608 E.03771
G1 X109.025 Y101.119 E.01312
G1 X108.871 Y100.551 E.01431
G1 X108.824 Y100.035 E.0126
G1 X108.856 Y99.549 E.01185
G1 X108.985 Y98.999 E.01374
G1 X109.253 Y98.392 E.01614
G1 X111.117 Y95.186 E.09021
G1 X111.475 Y94.784 E.01309
G1 X111.795 Y94.466 E.01097
G1 X112.293 Y94.148 E.01437
G1 X112.999 Y93.884 E.01833
G1 X113.705 Y93.789 E.01733
G1 X117.477 Y93.797 E.09175
G1 X117.892 Y93.859 E.01021
G1 X118.585 Y94.089 E.01776
G1 X119.204 Y94.466 E.01763
G1 X119.809 Y95.086 E.02107
G1 X119.883 Y95.186 E.00303
G1 X121.747 Y98.392 E.09021
G1 X121.975 Y98.881 E.01312
G1 X122.129 Y99.449 E.01431
G1 X122.172 Y100.149 E.01706
G1 X122.09 Y100.741 E.01454
G1 X121.832 Y101.44 E.01812
G1 X119.884 Y104.814 E.09477
G1 X119.309 Y105.447 E.0208
G1 X118.807 Y105.799 E.01491
G1 X118.337 Y106.016 E.01259
G1 X117.794 Y106.164 E.01369
G1 X117.233 Y106.214 E.0137
G1 X113.767 Y106.214 E.08431
G1 X113.14 Y106.133 E.01538
G1 X112.837 Y106.073 E.00751
G1 X112.29 Y105.851 E.01436
G1 X111.863 Y105.566 E.01249
G1 X111.575 Y105.344 E.00884
G1 X111.181 Y104.904 E.01437
G1 X110.066 Y102.998 E.05371
G1 X110.066 Y102.998 F9000
G1 X109.745 Y103.183
G1 F6000
G1 X108.937 Y101.792 E.03913
G1 X108.693 Y101.272 E.01397
G1 X108.517 Y100.641 E.01593
G1 X108.458 Y100.071 E.01394
G1 X108.491 Y99.525 E.01331
G1 X108.631 Y98.909 E.01537
G1 X108.937 Y98.208 E.0186
G1 X110.801 Y95.002 E.09021
G1 X111.208 Y94.533 E.0151
G1 X111.598 Y94.158 E.01316
G1 X112.095 Y93.84 E.01435
G1 X112.878 Y93.539 E.0204
G1 X113.664 Y93.426 E.01932
G1 X117.479 Y93.431 E.0928
G1 X118.007 Y93.512 E.01299
G1 X118.7 Y93.742 E.01776
G1 X119.401 Y94.158 E.01983
G1 X119.792 Y94.534 E.01319
G1 X120.199 Y95.002 E.01509
G1 X122.063 Y98.208 E.09021
G1 X122.307 Y98.728 E.01397
G1 X122.483 Y99.359 E.01593
G1 X122.537 Y100.132 E.01885
G1 X122.451 Y100.797 E.01631
G1 X122.172 Y101.573 E.02006
G1 X120.2 Y104.997 E.09611
G1 X119.576 Y105.697 E.02281
G1 X119.01 Y106.103 E.01694
G1 X118.437 Y106.368 E.01536
G1 X117.844 Y106.527 E.01493
G1 X117.233 Y106.58 E.01492
G1 X113.767 Y106.58 E.08431
G1 X113.09 Y106.495 E.0166
G1 X112.699 Y106.412 E.00972
G1 X112.152 Y106.189 E.01437
G1 X111.652 Y105.864 E.01451
G1 X111.302 Y105.588 E.01084
G1 X110.909 Y105.147 E.01437
G1 X110.8 Y104.998 E.00449
G1 X109.775 Y103.235 E.0496
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X109.745 Y103.183 E-.02852
G1 X108.937 Y101.792 E-.76411
G1 X108.693 Y101.272 E-.27284
G1 X108.517 Y100.641 E-.31117
G1 X108.49 Y100.383 E-.12336
;WIPE_END
G1 X108.859 Y100.348 F9000
G1 X108.84 Y113.918
G1 X108.84 Y114.082
G1 X108.846 Y114.21
G1 X109.132 Y115.34
G1 X111.422 Y119.17
G1 X111.63 Y119.376
G1 X112.785 Y120.041
G1 X113.208 Y121.853
G1 X113.259 Y122.212
G1 E5 F2400
G1 F6000
G1 X113.768 Y122.151 E.01247
G1 X117.476 Y122.162 E.09019
G1 X117.776 Y122.205 E.00737
G1 X118.469 Y122.436 E.01777
G1 X119.007 Y122.774 E.01545
G1 X119.567 Y123.369 E.01987
G1 X121.431 Y126.576 E.09023
G1 X121.643 Y127.034 E.01228
G1 X121.774 Y127.538 E.01267
G1 X121.806 Y128.165 E.01527
G1 X121.729 Y128.684 E.01276
G1 X121.491 Y129.308 E.01624
G1 X119.567 Y132.63 E.09338
G1 X119.042 Y133.197 E.0188
G1 X118.58 Y133.509 E.01356
G1 X118.238 Y133.664 E.00913
G1 X117.75 Y133.801 E.01233
G1 X117.233 Y133.849 E.01263
G1 X113.767 Y133.849 E.08431
G1 X113.019 Y133.747 E.01836
G1 X112.428 Y133.512 E.01547
G1 X111.878 Y133.128 E.01632
G1 X111.433 Y132.63 E.01624
G1 X109.569 Y129.424 E.09021
G1 X109.357 Y128.966 E.01228
G1 X109.226 Y128.461 E.01269
G1 X109.189 Y128.059 E.00982
G1 X109.226 Y127.539 E.01268
G1 X109.357 Y127.034 E.01269
G1 X109.569 Y126.576 E.01228
G1 X111.433 Y123.37 E.09021
G1 X111.992 Y122.774 E.01988
G1 X112.49 Y122.456 E.01437
G1 X113.121 Y122.229 E.01631
G1 X113.2 Y122.219 E.00194
G1 X113.2 Y122.219 F9000
G1 X113.119 Y121.856
;TYPE:Perimeter
G1 F6000
G1 X113.769 Y121.786 E.0159
G1 X117.477 Y121.797 E.09019
G1 X117.892 Y121.859 E.01021
G1 X118.585 Y122.089 E.01776
G1 X119.204 Y122.466 E.01763
G1 X119.755 Y123.029 E.01916
G1 X119.883 Y123.186 E.00493
G1 X121.747 Y126.392 E.09021
G1 X121.975 Y126.881 E.01312
G1 X122.129 Y127.449 E.01431
G1 X122.172 Y128.149 E.01706
G1 X122.09 Y128.741 E.01454
G1 X121.832 Y129.44 E.01812
G1 X119.884 Y132.814 E.09477
G1 X119.526 Y133.216 E.01309
G1 X119.213 Y133.529 E.01077
G1 X118.733 Y133.84 E.01391
G1 X118.337 Y134.016 E.01054
G1 X117.813 Y134.161 E.01322
G1 X117.233 Y134.214 E.01417
G1 X113.767 Y134.214 E.08431
G1 X112.969 Y134.109 E.01958
G1 X112.29 Y133.851 E.01767
G1 X111.667 Y133.427 E.01833
G1 X111.117 Y132.814 E.02003
G1 X109.253 Y129.608 E.09021
G1 X109.025 Y129.119 E.01312
G1 X108.871 Y128.551 E.01431
G1 X108.824 Y128.035 E.0126
G1 X108.871 Y127.449 E.0143
G1 X109.025 Y126.881 E.01431
G1 X109.253 Y126.392 E.01312
G1 X111.117 Y123.186 E.09021
G1 X111.533 Y122.722 E.01516
G1 X111.795 Y122.466 E.00891
G1 X112.293 Y122.148 E.01437
G1 X112.791 Y121.957 E.01297
G1 X113.062 Y121.874 E.00689
G1 X113.062 Y121.874 F9000
G1 X112.986 Y121.52
G1 F6000
G1 X113.078 Y121.493 E.00233
G1 X113.77 Y121.42 E.01693
G1 X117.479 Y121.431 E.09022
G1 X118.007 Y121.512 E.01299
G1 X118.7 Y121.742 E.01776
G1 X119.401 Y122.158 E.01983
G1 X120.022 Y122.779 E.02136
G1 X120.199 Y123.002 E.00693
G1 X122.063 Y126.208 E.09021
G1 X122.307 Y126.728 E.01397
G1 X122.483 Y127.359 E.01593
G1 X122.537 Y128.132 E.01885
G1 X122.451 Y128.797 E.01631
G1 X122.172 Y129.573 E.02006
G1 X120.2 Y132.997 E.09611
G1 X119.792 Y133.466 E.01512
G1 X119.416 Y133.833 E.01278
G1 X118.887 Y134.172 E.01528
G1 X118.437 Y134.368 E.01194
G1 X117.876 Y134.522 E.01415
G1 X117.233 Y134.58 E.0157
G1 X113.767 Y134.58 E.08431
G1 X112.919 Y134.471 E.0208
G1 X112.152 Y134.189 E.01988
G1 X111.456 Y133.725 E.02035
G1 X110.909 Y133.147 E.01936
G1 X110.8 Y132.998 E.00449
G1 X108.937 Y129.792 E.09019
G1 X108.693 Y129.272 E.01397
G1 X108.517 Y128.641 E.01593
G1 X108.458 Y128.071 E.01394
G1 X108.491 Y127.525 E.01331
G1 X108.637 Y126.886 E.01594
G1 X108.937 Y126.208 E.01803
G1 X110.801 Y123.002 E.09021
G1 X111.266 Y122.471 E.01717
G1 X111.598 Y122.158 E.0111
G1 X112.095 Y121.84 E.01435
G1 X112.67 Y121.612 E.01505
G1 X112.928 Y121.536 E.00654
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X112.986 Y121.52 E-.02858
G1 X113.078 Y121.493 E-.04554
G1 X113.77 Y121.42 E-.33052
G1 X116.076 Y121.427 E-1.09536
;WIPE_END
G1 X116.076 Y121.803 F9000
G1 X113.756 Y121.803
G1 X113.641 Y121.808
G1 X113.476 Y121.816
G1 X113.349 Y121.832
G1 X113.186 Y121.856
G1 X113.061 Y121.883
G1 X112.901 Y121.922
G1 X112.779 Y121.961
G1 X112.623 Y122.015
G1 X112.505 Y122.064
G1 X112.355 Y122.132
G1 X112.241 Y122.191
G1 X112.099 Y122.274
G1 X111.991 Y122.343
G1 X111.857 Y122.438
G1 X111.755 Y122.516
G1 X111.63 Y122.624
G1 X111.536 Y122.711
G1 X111.422 Y122.83
G1 X111.336 Y122.924
G1 X111.234 Y123.054
G1 X111.156 Y123.155
G1 X111.067 Y123.294
G1 X111.005 Y123.391
G1 X109.261 Y126.412
G1 X109.208 Y126.514
G1 X109.132 Y126.66
G1 X109.083 Y126.779
G1 X109.022 Y126.932
G1 X108.984 Y127.054
G1 X108.937 Y127.212
G1 X108.909 Y127.337
G1 X108.878 Y127.499
G1 X108.862 Y127.626
G1 X108.846 Y127.79
G1 X108.84 Y127.918
G1 X108.84 Y128.082
G1 X108.846 Y128.21
G1 X108.862 Y128.374
G1 X108.878 Y128.501
G1 X108.909 Y128.663
G1 X108.937 Y128.788
G1 X108.984 Y128.946
G1 X109.022 Y129.068
G1 X109.083 Y129.221
G1 X109.132 Y129.34
G1 X109.208 Y129.486
G1 X109.261 Y129.588
G1 X109.724 Y130.391
G1 X106.099 Y136.044
G1 X105.718 Y136.044
G1 E5 F2400
;TYPE:External perimeter
G1 F6000
G1 X105.75 Y135.974 E.00187
G1 X105.75 Y103.607 E.78729
G1 X105.743 Y103.559 E.00118
G1 X105.663 Y103.497 E.00246
G1 X105.663 Y98.753 E.11539
G1 X105.742 Y98.695 E.00238
G1 X105.75 Y98.642 E.0013
G1 X105.75 Y92.026 E.16093
G1 X105.686 Y91.887 E.00372
G1 X104.385 Y90.771 E.04169
G1 X104.125 Y90.5 E.00913
G1 X104.378 Y90.228 E.00904
G1 X105.574 Y89.2 E.03836
G1 X125.407 Y89.2 E.48242
G1 X126.74 Y90.336 E.0426
G1 X126.894 Y90.497 E.00542
G1 X126.751 Y90.654 E.00517
G1 X125.314 Y91.887 E.04606
G1 X125.25 Y92.026 E.00372
G1 X125.255 Y98.684 E.16195
G1 X125.337 Y98.753 E.00261
G1 X125.337 Y103.497 E.11539
G1 X125.257 Y103.559 E.00246
G1 X125.25 Y103.607 E.00118
G1 X125.25 Y135.974 E.78729
G1 X125.314 Y136.113 E.00372
G1 X126.615 Y137.229 E.04169
G1 X126.875 Y137.5 E.00913
G1 X126.622 Y137.772 E.00904
G1 X125.426 Y138.8 E.03836
G1 X105.574 Y138.8 E.48288
G1 X104.26 Y137.664 E.04225
G1 X104.106 Y137.503 E.00542
G1 X104.249 Y137.346 E.00517
G1 X105.686 Y136.113 E.04606
G1 X105.693 Y136.099 E.00038
G1 X105.693 Y136.099 F9000
G1 X106.056 Y136.204
;TYPE:Perimeter
G1 F6000
G1 X106.079 Y136.172 E.00096
G1 X106.116 Y135.974 E.0049
G1 X106.116 Y103.607 E.78729
G1 X106.096 Y103.461 E.00358
G1 X106.029 Y103.41 E.00205
G1 X106.029 Y98.849 E.11094
G1 X106.092 Y98.802 E.00191
G1 X106.116 Y98.642 E.00394
G1 X106.116 Y92.026 E.16093
G1 X106.079 Y91.828 E.0049
G1 X105.924 Y91.609 E.00653
G1 X104.627 Y90.496 E.04157
G1 X105.71 Y89.566 E.03472
G1 X125.272 Y89.566 E.47583
G1 X126.369 Y90.5 E.03504
G1 X125.076 Y91.609 E.04143
G1 X124.921 Y91.828 E.00653
G1 X124.884 Y92.026 E.0049
G1 X124.884 Y98.243 E.15122
G1 X124.899 Y98.768 E.01278
G1 X124.971 Y98.849 E.00264
G1 X124.971 Y103.41 E.11094
G1 X124.904 Y103.461 E.00205
G1 X124.884 Y103.607 E.00358
G1 X124.884 Y135.974 E.78729
G1 X124.921 Y136.172 E.0049
G1 X125.076 Y136.391 E.00653
G1 X126.373 Y137.504 E.04157
G1 X125.29 Y138.434 E.03472
G1 X105.711 Y138.434 E.47624
G1 X104.63 Y137.501 E.03473
G1 X105.924 Y136.391 E.04147
G1 X106.021 Y136.253 E.0041
G1 X106.021 Y136.253 F9000
G1 X106.382 Y136.357
G1 F6000
G1 X106.42 Y136.304 E.00159
G1 X106.481 Y135.974 E.00816
G1 X106.481 Y103.607 E.78729
G1 X106.448 Y103.364 E.00596
G1 X106.395 Y103.323 E.00163
G1 X106.395 Y98.944 E.10651
G1 X106.441 Y98.909 E.00141
G1 X106.481 Y98.642 E.00657
G1 X106.481 Y92.026 E.16093
G1 X106.42 Y91.696 E.00816
G1 X106.162 Y91.332 E.01085
G1 X105.188 Y90.496 E.03122
G1 X105.845 Y89.931 E.02108
G1 X125.137 Y89.931 E.46926
G1 X125.806 Y90.501 E.02138
G1 X124.838 Y91.332 E.03103
G1 X124.58 Y91.696 E.01085
G1 X124.519 Y92.026 E.00816
G1 X124.519 Y98.243 E.15122
G1 X124.543 Y98.853 E.01485
G1 X124.605 Y98.944 E.00268
G1 X124.605 Y103.323 E.10651
G1 X124.552 Y103.364 E.00163
G1 X124.519 Y103.607 E.00596
G1 X124.519 Y135.974 E.78729
G1 X124.58 Y136.304 E.00816
G1 X124.838 Y136.668 E.01085
G1 X125.812 Y137.504 E.03122
G1 X125.155 Y138.069 E.02108
G1 X105.847 Y138.069 E.46965
G1 X105.19 Y137.502 E.02111
G1 X106.162 Y136.668 E.03115
G1 X106.348 Y136.406 E.00782
G1 X106.348 Y136.406 F9000
G1 X106.708 Y136.51
G1 F6000
G1 X106.761 Y136.436 E.00221
G1 X106.847 Y135.974 E.01143
G1 X106.847 Y103.607 E.78729
G1 X106.801 Y103.267 E.00835
G1 X106.76 Y103.236 E.00125
G1 X106.76 Y99.039 E.10209
G1 X106.791 Y99.017 E.00092
G1 X106.847 Y98.642 E.00922
G1 X106.847 Y92.026 E.16093
G1 X106.761 Y91.564 E.01143
G1 X106.4 Y91.054 E.0152
G1 X105.749 Y90.496 E.02086
G1 X105.981 Y90.297 E.00743
G1 X125.003 Y90.297 E.46269
G1 X125.243 Y90.502 E.00768
G1 X124.6 Y91.054 E.02061
G1 X124.239 Y91.564 E.0152
G1 X124.153 Y92.026 E.01143
G1 X124.153 Y98.243 E.15122
G1 X124.188 Y98.938 E.01693
G1 X124.24 Y99.039 E.00276
G1 X124.24 Y103.236 E.10209
G1 X124.199 Y103.267 E.00125
G1 X124.153 Y103.607 E.00835
G1 X124.153 Y135.974 E.78729
G1 X124.239 Y136.436 E.01143
G1 X124.6 Y136.946 E.0152
G1 X125.251 Y137.504 E.02086
G1 X125.019 Y137.703 E.00743
G1 X105.983 Y137.703 E.46303
G1 X105.751 Y137.503 E.00745
G1 X106.4 Y136.946 E.0208
G1 X106.674 Y136.559 E.01153
G1 X106.674 Y136.559 F9000
G1 X107.034 Y136.664
G1 F6000
G1 X107.102 Y136.569 E.00284
G1 X107.213 Y135.974 E.01472
G1 X107.213 Y129.383 E.16032
;WIDTH:0.446784
G1 X107.236 Y128.986 E.01091
;WIDTH:0.493568
G1 X107.259 Y128.59 E.01212
G1 X107.251 Y127.948 E.01961
;WIDTH:0.519401
G1 X107.272 Y127.106 E.02718
G1 X107.252 Y126.943 E.0053
;WIDTH:0.479601
G1 X107.233 Y126.78 E.00486
;WIDTH:0.4398
G1 X107.213 Y126.617 E.00443
;WIDTH:0.399999
G1 X107.213 Y115.383 E.27326
;WIDTH:0.446784
G1 X107.236 Y114.986 E.01091
;WIDTH:0.493568
G1 X107.259 Y114.59 E.01212
G1 X107.251 Y113.948 E.01961
;WIDTH:0.519401
G1 X107.272 Y113.106 E.02718
G1 X107.252 Y112.943 E.0053
;WIDTH:0.479601
G1 X107.233 Y112.78 E.00486
;WIDTH:0.4398
G1 X107.213 Y112.617 E.00443
;WIDTH:0.399999
G1 X107.213 Y103.607 E.21916
G1 X107.126 Y103.149 E.01134
G1 X107.126 Y101.393 E.04271
;WIDTH:0.445687
G1 X107.149 Y101.127 E.00731
;WIDTH:0.491375
G1 X107.172 Y100.861 E.00812
;WIDTH:0.537063
G1 X107.194 Y100.594 E.00896
G1 X107.186 Y99.946 E.02167
;WIDTH:0.549776
G1 X107.212 Y99.146 E.02744
;WIDTH:0.577248
G1 X107.301 Y98.642 E.01848
G1 X107.279 Y98.542 E.0037
;WIDTH:0.532936
G1 X107.257 Y98.442 E.0034
;WIDTH:0.488624
G1 X107.235 Y98.343 E.00306
;WIDTH:0.444312
G1 X107.213 Y98.243 E.00279
;WIDTH:0.399999
G1 X107.213 Y92.026 E.15122
G1 X107.102 Y91.431 E.01472
G1 X106.638 Y90.777 E.0195
G1 X106.505 Y90.663 E.00426
G1 X124.495 Y90.663 E.43759
G1 X124.362 Y90.777 E.00426
G1 X123.898 Y91.431 E.0195
G1 X123.787 Y92.026 E.01472
G1 X123.787 Y98.243 E.15122
;WIDTH:0.444312
G1 X123.765 Y98.343 E.00279
;WIDTH:0.488624
G1 X123.743 Y98.442 E.00306
;WIDTH:0.532937
G1 X123.721 Y98.542 E.0034
;WIDTH:0.577249
G1 X123.699 Y98.642 E.0037
G1 X123.807 Y99.494 E.03102
;WIDTH:0.534083
G1 X123.814 Y100.174 E.02261
;WIDTH:0.544626
G1 X123.802 Y100.57 E.01345
;WIDTH:0.569656
G1 X123.789 Y100.966 E.01411
G1 X123.811 Y101.074 E.00392
;WIDTH:0.527242
G1 X123.832 Y101.183 E.00364
;WIDTH:0.484828
G1 X123.853 Y101.291 E.0033
;WIDTH:0.442414
G1 X123.874 Y101.399 E.00299
;WIDTH:0.399999
G1 X123.874 Y102.966 E.03812
G1 X123.787 Y103.607 E.01573
G1 X123.787 Y112.617 E.21916
;WIDTH:0.439818
G1 X123.767 Y112.78 E.00443
;WIDTH:0.479636
G1 X123.748 Y112.943 E.00486
;WIDTH:0.519454
G1 X123.728 Y113.105 E.00527
G1 X123.742 Y113.496 E.01263
;WIDTH:0.490655
G1 X123.749 Y114.174 E.02058
;WIDTH:0.525984
G1 X123.724 Y114.959 E.02569
G1 X123.745 Y115.1 E.00466
;WIDTH:0.48472
G1 X123.766 Y115.242 E.0043
;WIDTH:0.443456
G1 X123.786 Y115.383 E.00388
;WIDTH:0.402192
G1 X123.787 Y116.012 E.01539
;WIDTH:0.399999
G1 X123.787 Y126.617 E.25796
;WIDTH:0.439818
G1 X123.767 Y126.78 E.00443
;WIDTH:0.479636
G1 X123.748 Y126.943 E.00486
;WIDTH:0.519454
G1 X123.728 Y127.105 E.00527
G1 X123.742 Y127.496 E.01263
;WIDTH:0.490655
G1 X123.749 Y128.174 E.02058
;WIDTH:0.525985
G1 X123.724 Y128.959 E.02569
G1 X123.745 Y129.1 E.00466
;WIDTH:0.484721
G1 X123.766 Y129.242 E.0043
;WIDTH:0.443457
G1 X123.786 Y129.383 E.00388
;WIDTH:0.402192
G1 X123.787 Y130.012 E.01539
;WIDTH:0.399999
G1 X123.787 Y135.974 E.14502
G1 X123.898 Y136.569 E.01472
G1 X124.362 Y137.223 E.0195
G1 X124.495 Y137.337 E.00426
G1 X106.505 Y137.337 E.43759
G1 X106.638 Y137.223 E.00426
G1 X107 Y136.713 E.01521
G1 X107 Y136.713 F9000
G1 X107.62 Y137.228
;WIDTH:0.4
G1 F3072.127
G1 X108.222 Y136.626 E.02071
G1 X108.21 Y136.076 E.01338
G1 X107.222 Y137.063 E.03397
G1 X107.081 Y137.063 E.00343
G1 X107.358 Y136.671 E.01168
G1 X107.429 Y136.294 E.00933
G1 X108.151 Y135.571 E.02485
G1 X108.055 Y135.105 E.01157
G1 X107.487 Y135.673 E.01954
G1 X107.487 Y135.11 E.01369
G1 X108.03 Y134.567 E.01868
G1 E-5 F3600
G1 X108.03 Y134.567 F9000
G1 X107.559 Y129.117
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X107.781 Y129.697 E.01511
G1 X108.069 Y130.3 E.01625
G1 X109.946 Y133.524 E.09074
G1 X110.514 Y134.212 E.0217
G1 X110.879 Y134.549 E.01208
G1 X111.384 Y134.906 E.01504
G1 X111.778 Y135.123 E.01094
G1 X112.314 Y135.341 E.01407
G1 X112.786 Y135.468 E.01189
G1 X113.77 Y135.586 E.02411
G1 X117.245 Y135.585 E.08453
G1 X118.065 Y135.508 E.02003
G1 X118.734 Y135.326 E.01686
G1 X119.373 Y135.032 E.01711
G1 X117.47 Y136.934 E.06544
G1 X117.47 Y137.063 E.00314
G1 X108.588 Y137.063 E.21605
G1 X108.587 Y136.373 E.01678
G1 X108.551 Y135.792 E.01416
G1 X108.467 Y135.258 E.01315
G1 X108.339 Y134.764 E.01241
G1 X108.194 Y134.45 E.00841
G1 X108.047 Y134.328 E.00465
G1 X107.487 Y134.307 E.01363
G1 X107.487 Y129.737 E.11116
G1 X107.515 Y129.268 E.01143
G1 X107.515 Y129.268 F9000
G1 X107.853 Y130.655
G1 F1200
G1 X109.579 Y133.626 E.08358
G1 X109.907 Y134.051 E.01306
G1 X110.286 Y134.508 E.01444
G1 X110.668 Y134.847 E.01242
G1 X111.172 Y135.205 E.01504
G1 X111.64 Y135.461 E.01298
G1 X112.241 Y135.702 E.01575
G1 X112.736 Y135.83 E.01244
G1 X113.77 Y135.951 E.02532
G1 X117.278 Y135.949 E.08533
G1 X118.003 Y135.884 E.01771
G1 X117.212 Y136.697 E.02759
G1 X108.953 Y136.697 E.20089
G1 X108.952 Y136.353 E.00837
G1 X108.912 Y135.736 E.01504
G1 X108.821 Y135.165 E.01406
G1 X108.693 Y134.672 E.01239
G1 X108.448 Y134.174 E.0135
G1 X108.227 Y134.01 E.00669
G1 X107.853 Y133.94 E.00926
G1 X107.853 Y130.838 E.07545
G1 X107.853 Y130.838 F9000
G1 X108.218 Y132.012
G1 F1200
G1 X108.944 Y133.261 E.03514
;WIDTH:0.438398
G1 X109.111 Y133.585 E.0098
;WIDTH:0.476797
G1 X109.277 Y133.91 E.01074
G1 X109.451 Y134.097 E.00752
;WIDTH:0.438398
G1 X109.625 Y134.284 E.00687
;WIDTH:0.399999
G1 X110.075 Y134.813 E.01689
G1 X110.456 Y135.146 E.01231
G1 X111.05 Y135.559 E.0176
G1 X111.502 Y135.8 E.01246
G1 X112.146 Y136.055 E.01685
;WIDTH:0.446735
G1 X112.323 Y136.124 E.00521
;WIDTH:0.493471
G1 X112.499 Y136.193 E.00577
;WIDTH:0.540206
G1 X112.676 Y136.262 E.00639
G1 X112.487 Y136.285 E.00641
;WIDTH:0.493471
G1 X112.298 Y136.308 E.00581
;WIDTH:0.446735
G1 X112.11 Y136.332 E.0052
;WIDTH:0.399999
G1 X109.317 Y136.332 E.06794
G1 X109.274 Y135.68 E.01589
G1 X109.175 Y135.073 E.01496
;WIDTH:0.431844
G1 X109.063 Y134.67 E.01106
;WIDTH:0.463688
G1 X108.951 Y134.267 E.01195
;WIDTH:0.483312
G1 X108.759 Y133.912 E.01205
G1 X108.619 Y133.822 E.00497
;WIDTH:0.441656
G1 X108.478 Y133.732 E.00453
;WIDTH:0.399999
G1 X108.218 Y133.642 E.00669
G1 X108.218 Y132.195 E.0352
G1 X108.218 Y132.195 F9000
G1 X108.629 Y133.359
;WIDTH:0.401468
G1 F1200
G1 X108.552 Y133.339 E.00194
G1 X108.573 Y133.416 E.00195
G1 X108.617 Y133.404 E.00111
G1 X108.617 Y133.404 F9000
G1 X109.598 Y134.963
;WIDTH:0.542488
G1 F1200
G1 X110.204 Y135.502 E.02741
G1 X110.765 Y135.895 E.02315
G1 X109.731 Y135.895 E.03495
G1 X109.705 Y135.613 E.00957
G1 X109.628 Y135.143 E.0161
G1 E-5 F3600
G1 X109.628 Y135.143 F9000
G1 E5 F2400
;WIDTH:0.540206
G1 F1200
G1 X113.037 Y136.287 E.01218
;WIDTH:0.490421
G1 X113.397 Y136.311 E.01095
;WIDTH:0.440636
G1 X113.77 Y136.324 E.01009
;WIDTH:0.414872
G1 X117.035 Y136.324 E.08265
G1 E-5 F3600
G1 X117.035 Y136.324 F9000
G1 X123.345 Y129.356
G1 E5 F2400
;WIDTH:0.404643
G1 F1200
G1 X122.992 Y130.187 E.02224
G1 X122.738 Y130.629 E.01256
G1 X123.259 Y130.108 E.01815
G1 X123.357 Y130.057 E.00272
G1 X123.509 Y130.104 E.00392
G1 X123.509 Y129.398 E.01739
G1 X123.446 Y129.204 E.00502
G1 X123.446 Y129.204 F9000
G1 X123.39 Y130.497
;WIDTH:0.399999
G1 F1200
G1 X122.014 Y131.873 E.04733
G1 X121.856 Y132.121 E.00715
;WIDTH:0.374336
G1 X121.785 Y132.102 E.00166
G1 X121.804 Y132.173 E.00166
G1 X121.845 Y132.162 E.00096
G1 X121.3 Y133.104 F9000
;WIDTH:0.399999
G1 F1200
G1 X123.511 Y130.893 E.07606
G1 E-5 F3600
G1 X123.511 Y130.893 F9000
G1 X121.094 Y133.362
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X120.75 Y133.782 E.01228
G1 X120.238 Y134.311 E.01665
G1 X119.924 Y134.6 E.00965
G1 E-5 F3600
G1 X119.924 Y134.6 F9000
G1 X117.858 Y137.063
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X123.512 Y131.41 E.19448
G1 X123.512 Y131.927 E.01258
G1 X118.375 Y137.063 E.17669
G1 X118.893 Y137.063 E.0126
G1 X123.512 Y132.444 E.15889
G1 X123.512 Y132.961 E.01258
G1 X119.41 Y137.063 E.14111
G1 X119.82 Y137.253 E.01099
;WIDTH:0.414872
G1 X119.774 Y137.265 E.0012
G1 X119.753 Y137.186 E.00207
G1 X119.832 Y137.207 E.00207
G1 X119.927 Y137.063 E.00437
;WIDTH:0.399999
G1 X123.512 Y133.478 E.12332
G1 X123.512 Y133.995 E.01258
G1 X123.201 Y134.306 E.0107
G1 X122.943 Y134.438 E.00705
;WIDTH:0.374336
G1 X122.801 Y134.621 E.00524
G1 X122.813 Y134.762 E.0032
G1 X122.79 Y134.839 E.00182
;WIDTH:0.399999
G1 X122.628 Y134.879 E.00406
G1 X120.444 Y137.063 E.07513
G1 X120.226 Y137.159 E.00579
;WIDTH:0.374336
G1 X120.155 Y137.14 E.00166
G1 X120.174 Y137.211 E.00166
G1 X120.215 Y137.2 E.00096
G1 X120.215 Y137.2 F9000
G1 X120.961 Y137.063
;WIDTH:0.399999
G1 F1200
G1 X122.483 Y135.541 E.05236
G1 X122.42 Y136.121 E.01419
G1 X121.478 Y137.063 E.0324
G1 X121.885 Y137.249 E.01088
;WIDTH:0.374336
G1 X121.844 Y137.26 E.00096
G1 X121.825 Y137.189 E.00166
G1 X121.896 Y137.208 E.00166
;WIDTH:0.399999
G1 X121.995 Y137.063 E.00427
G1 X122.412 Y136.646 E.01434
G1 X122.412 Y136.646 F9000
G1 X123.429 Y137.228
;WIDTH:0.4
G1 F3072.127
G1 X123.784 Y136.873 E.01221
G1 X123.642 Y136.671 E.00601
G1 X123.606 Y136.477 E.0048
G1 X123.02 Y137.063 E.02016
G1 X122.778 Y137.063 E.00589
G1 X122.778 Y136.731 E.00808
G1 X123.515 Y135.994 E.02535
G1 X123.513 Y135.422 E.01391
G1 X122.785 Y136.138 E.02484
G1 X122.861 Y135.499 E.01565
G1 X123.513 Y134.848 E.02241
G1 X123.513 Y134.673 E.00426
G1 X123.116 Y134.671 E.00966
G1 X122.809 Y134.978 E.01056
G1 E-5 F3600
G1 X122.809 Y134.978 F9000
G1 X123.446 Y115.203
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.403602
G1 F1200
G1 X123.509 Y115.412 E.00536
G1 X123.507 Y116.103 E.01697
G1 X123.35 Y116.052 E.00405
G1 X123.244 Y116.105 E.00291
G1 X122.761 Y116.588 E.01678
G1 X122.992 Y116.187 E.01137
G1 X123.345 Y115.355 E.0222
G1 X123.345 Y115.355 F9000
G1 X123.375 Y116.494
;WIDTH:0.399999
G1 F1200
G1 X122.039 Y117.829 E.04594
G1 X121.882 Y118.077 E.00714
;WIDTH:0.374336
G1 X121.811 Y118.058 E.00166
G1 X121.83 Y118.129 E.00166
G1 X121.871 Y118.118 E.00096
G1 X121.871 Y118.118 F9000
G1 X121.326 Y119.059
;WIDTH:0.399999
G1 F1200
G1 X123.511 Y116.874 E.07516
G1 E-5 F3600
G1 X123.511 Y116.874 F9000
G1 X121.12 Y119.318
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X120.745 Y119.778 E.01342
G1 X120.101 Y120.436 E.02082
G1 X119.412 Y120.995 E.02007
;WIDTH:0.399999
G1 X119.727 Y121.175 E.00882
G1 X123.511 Y117.391 E.13017
G1 X123.511 Y117.908 E.01258
G1 X120.039 Y121.38 E.11943
G1 X120.31 Y121.627 E.00892
G1 X123.512 Y118.425 E.11015
G1 X123.512 Y118.942 E.01258
G1 X120.563 Y121.891 E.10144
G1 E-5 F3600
G1 X123.382 Y119.589 F9000
G1 E5 F2400
G1 F1200
G1 X120.805 Y122.166 E.08865
G1 X121.071 Y122.501 E.0104
G1 X122.931 Y125.7 E.09001
G1 X123.329 Y126.616 E.02429
G1 X123.453 Y126.851 E.00646
G1 X123.513 Y126.578 E.0068
G1 X123.512 Y119.459 E.17316
G1 X123.512 Y119.459 F9000
G1 X123.146 Y120.342
G1 F1200
G1 X123.147 Y125.344 E.12167
G1 X121.624 Y122.724 E.07371
G1 X121.296 Y122.193 E.01518
G1 X123.017 Y120.471 E.05922
G1 X123.017 Y120.471 F9000
G1 X122.781 Y121.225
G1 F1200
G1 X122.781 Y123.987 E.06718
G1 X121.766 Y122.24 E.04915
G1 X122.651 Y121.354 E.03046
G1 X122.651 Y121.354 F9000
G1 X122.395 Y122.296
;WIDTH:0.570718
G1 F1200
G1 X122.347 Y122.249 E.0024
G1 X122.283 Y122.266 E.00236
G1 X122.265 Y122.331 E.00241
G1 X122.313 Y122.378 E.0024
G1 X122.377 Y122.361 E.00236
G1 E-5 F3600
G1 X122.377 Y122.361 F9000
G1 X111.63 Y119.376
G1 X107.559 Y115.117
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X107.781 Y115.697 E.01511
G1 X108.069 Y116.3 E.01625
G1 X109.929 Y119.499 E.09001
G1 X110.208 Y119.854 E.01098
G1 X107.487 Y122.575 E.0936
G1 X107.487 Y115.737 E.16633
G1 X107.515 Y115.268 E.01143
G1 X107.515 Y115.268 F9000
G1 X107.853 Y116.655
G1 F1200
G1 X109.386 Y119.293 E.07421
G1 X109.719 Y119.826 E.01529
G1 X107.853 Y121.692 E.06419
G1 X107.853 Y116.838 E.11807
G1 X107.853 Y116.838 F9000
G1 X108.218 Y118.012
G1 F1200
G1 X109.247 Y119.781 E.04978
G1 X108.218 Y120.809 E.03538
G1 X108.218 Y118.195 E.06358
G1 X108.218 Y118.195 F9000
G1 X108.741 Y119.689
;WIDTH:0.582208
G1 F1200
G1 X108.693 Y119.64 E.0025
G1 X108.627 Y119.658 E.00249
G1 X108.609 Y119.724 E.00249
G1 X108.657 Y119.773 E.0025
G1 X108.723 Y119.755 E.00249
G1 X108.723 Y119.755 F9000
G1 X110.445 Y120.133
;WIDTH:0.399999
G1 F1200
G1 X107.487 Y123.092 E.10177
G1 X107.487 Y123.609 E.01258
G1 X110.697 Y120.399 E.11042
G1 X110.987 Y120.626 E.00896
G1 X107.487 Y124.126 E.1204
G1 X107.487 Y124.643 E.01258
G1 X111.29 Y120.84 E.13082
G1 X111.606 Y121.002 E.00864
;WIDTH:0.374336
G1 X110.863 Y121.614 E.02177
G1 X110.267 Y122.227 E.01934
G1 X109.832 Y122.762 E.01559
;WIDTH:0.399999
G1 X109.626 Y123.021 E.00805
G1 X107.487 Y125.16 E.07358
G1 X107.654 Y125.51 E.00943
G1 X109.137 Y124.028 E.051
;WIDTH:0.374336
G1 X109.096 Y124.039 E.00096
G1 X109.077 Y123.968 E.00166
G1 X109.148 Y123.987 E.00166
G1 X109.148 Y123.987 F9000
G1 X108.2 Y125.479
;WIDTH:0.395856
G1 F1200
G1 X108.064 Y125.714 E.00653
G1 X107.546 Y126.857 E.03018
G1 X107.485 Y126.607 E.00619
G1 X107.485 Y125.855 E.01808
G1 X107.66 Y125.95 E.00479
G1 X107.782 Y125.897 E.0032
G1 X108.071 Y125.608 E.00983
G1 E-5 F3600
G1 X108.071 Y125.608 F9000
G1 X107.473 Y101.02
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X107.669 Y101.38 E.00997
G1 X108.069 Y102.3 E.0244
G1 X109.929 Y105.499 E.09001
G1 X110.146 Y105.784 E.00871
G1 X107.487 Y108.443 E.09147
G1 X107.487 Y103.613 E.11748
G1 X107.4 Y103.133 E.01187
G1 X107.4 Y101.436 E.04128
G1 X107.441 Y101.2 E.00583
G1 X107.441 Y101.2 F9000
G1 X107.766 Y102.506
G1 F1200
G1 X109.652 Y105.761 E.0915
G1 X107.853 Y107.56 E.06188
G1 X107.853 Y103.613 E.09601
G1 X107.766 Y103.099 E.01268
G1 X107.766 Y102.689 E.00997
G1 X107.766 Y102.689 F9000
G1 X108.218 Y104.012
G1 F1200
G1 X109.198 Y105.698 E.04743
G1 X108.218 Y106.677 E.03369
G1 X108.218 Y104.195 E.06037
G1 X108.218 Y104.195 F9000
G1 X108.714 Y105.61
;WIDTH:0.53917
G1 F1200
G1 X108.67 Y105.566 E.00209
G1 X108.609 Y105.582 E.00212
G1 X108.593 Y105.643 E.00212
G1 X108.637 Y105.688 E.00211
G1 X108.698 Y105.671 E.00213
G1 X108.698 Y105.671 F9000
G1 X110.383 Y106.064
;WIDTH:0.399999
G1 F1200
G1 X107.487 Y108.96 E.09962
G1 X107.487 Y109.477 E.01258
G1 X110.629 Y106.336 E.10807
G1 X110.91 Y106.571 E.00891
G1 X107.487 Y109.994 E.11775
G1 X107.487 Y110.512 E.0126
G1 X111.213 Y106.786 E.12817
G1 X111.531 Y107.001 E.00934
;WIDTH:0.42413
G1 X110.829 Y107.582 E.02363
;WIDTH:0.374336
G1 X110.019 Y108.448 E.02682
;WIDTH:0.399999
G1 X109.809 Y108.706 E.00809
G1 X107.487 Y111.029 E.07989
G1 X107.487 Y111.029 F9000
G1 X107.41 Y111.798
;WIDTH:0.405479
G1 F1200
G1 X107.49 Y112.093 E.00755
G1 X107.49 Y112.606 E.01267
G1 X107.548 Y112.843 E.00602
G1 X107.938 Y111.982 E.02334
G1 X107.806 Y111.962 E.0033
G1 X107.399 Y111.695 E.01202
;WIDTH:0.381063
G1 X107.363 Y111.622 E.00188
;WIDTH:0.374336
G1 X107.355 Y111.502 E.00272
;WIDTH:0.399999
G1 X107.55 Y111.482 E.00477
G1 X109.32 Y109.713 E.06087
;WIDTH:0.374336
G1 X109.279 Y109.724 E.00096
G1 X109.26 Y109.653 E.00166
G1 X109.331 Y109.672 E.00166
G1 X109.331 Y109.672 F9000
G1 X108.613 Y110.907
G1 F1200
G1 X108.542 Y110.888 E.00166
G1 X108.561 Y110.959 E.00166
G1 X108.602 Y110.948 E.00096
;WIDTH:0.399999
G1 X107.958 Y111.592 E.02215
G1 E-5 F3600
G1 X107.958 Y111.592 F9000
G1 X107.72 Y93.493
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X107.92 Y93.294 E.00686
G1 X107.988 Y93.132 E.00427
G1 X108.139 Y92.5 E.01581
G1 X107.487 Y93.152 E.02243
G1 X107.487 Y92.578 E.01396
G1 X108.215 Y91.85 E.02504
G1 X108.222 Y91.269 E.01413
G1 X107.485 Y92.006 E.02535
G1 X107.394 Y91.522 E.01198
G1 X107.98 Y90.937 E.02014
G1 X107.406 Y90.937 E.01396
G1 X107.097 Y91.245 E.01061
G1 X107.097 Y91.245 F9000
G1 X108.702 Y90.978
;TYPE:Solid infill
;WIDTH:0.512906
G1 F1200
G1 X108.66 Y90.936 E.00189
G1 X108.602 Y90.951 E.00191
G1 X108.586 Y91.009 E.00192
G1 X108.629 Y91.051 E.00191
G1 X108.687 Y91.036 E.00191
;WIDTH:0.399999
G1 X109.298 Y90.937 E.01506
G1 X108.587 Y91.648 E.02446
G1 X108.553 Y92.199 E.01343
G1 X109.815 Y90.937 E.04341
G1 X110.332 Y90.937 E.01258
G1 X108.448 Y92.821 E.06481
G1 X108.325 Y93.109 E.00762
;WIDTH:0.374336
G1 X108.284 Y93.12 E.00096
G1 X108.264 Y93.049 E.00167
G1 X108.336 Y93.068 E.00168
G1 X108.336 Y93.068 F9000
G1 X107.563 Y93.705
;WIDTH:0.452204
G1 F1200
G1 X107.527 Y93.668 E.00143
G1 X107.476 Y93.682 E.00147
G1 X107.463 Y93.732 E.00144
G1 X107.499 Y93.769 E.00143
G1 X107.55 Y93.756 E.00146
;WIDTH:0.399999
G1 X107.487 Y94.299 E.0133
G1 X110.849 Y90.937 E.11565
G1 X111.366 Y90.937 E.01258
G1 X107.487 Y94.816 E.13344
G1 X107.487 Y95.333 E.01258
G1 X111.883 Y90.937 E.15122
G1 X112.4 Y90.937 E.01258
G1 X107.487 Y95.85 E.169
G1 X107.487 Y96.368 E.0126
G1 X112.918 Y90.937 E.18682
G1 E-5 F3600
G1 X112.918 Y90.937 F9000
G1 X111.061 Y93.309
G1 E5 F2400
;WIDTH:0.39818
G1 F1200
G1 X110.704 Y93.635 E.0117
;WIDTH:0.374336
G1 X110.33 Y94.021 E.01216
;WIDTH:0.399999
G1 X110.092 Y94.279 E.00854
G1 X107.487 Y96.885 E.08963
G1 X107.487 Y97.402 E.01258
G1 X109.52 Y95.369 E.06993
;WIDTH:0.374336
G1 X109.479 Y95.38 E.00096
G1 X109.46 Y95.309 E.00166
G1 X109.531 Y95.328 E.00166
G1 E-5 F3600
G1 X109.531 Y95.328 F9000
G1 X113.437 Y91.434
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X112.722 Y92.167 E.02491
G1 X113.774 Y92.049 E.02575
G1 X117.48 Y92.06 E.09015
G1 X117.822 Y92.087 E.00834
G1 X118.375 Y92.194 E.0137
G1 X119.128 Y92.44 E.01927
G1 X119.588 Y92.655 E.01235
G1 X120.136 Y93 E.01575
G1 X120.53 Y93.322 E.01238
G1 X121.072 Y93.894 E.01917
G1 X121.379 Y94.304 E.01246
G1 X123.147 Y97.345 E.08556
G1 X123.147 Y94.06 E.0799
G1 X122.773 Y93.99 E.00926
G1 X122.552 Y93.826 E.00669
G1 X122.312 Y93.344 E.0131
G1 X122.179 Y92.835 E.0128
G1 X122.082 Y92.23 E.0149
G1 X122.047 Y91.303 E.02256
G1 X113.564 Y91.303 E.20634
G1 X113.268 Y91.104 E.00868
G1 X111.061 Y93.309 E.07588
G1 X111.549 Y92.996 E.0141
G1 X111.96 Y92.796 E.01112
G1 X112.826 Y92.517 E.02213
G1 X113.753 Y92.415 E.02268
G1 X117.478 Y92.426 E.09061
G1 X118.306 Y92.553 E.02038
G1 X119.013 Y92.787 E.01811
G1 X119.451 Y92.996 E.0118
G1 X119.938 Y93.308 E.01407
G1 X120.432 Y93.746 E.01606
G1 X120.806 Y94.144 E.01328
G1 X121.104 Y94.558 E.01241
G1 X122.931 Y97.7 E.08841
G1 X123.198 Y98.26 E.01509
G1 X123.404 Y98.469 E.00714
G1 X123.499 Y98.256 E.00567
G1 X123.513 Y93.693 E.11099
G1 X122.953 Y93.672 E.01363
G1 X122.806 Y93.55 E.00465
G1 X122.635 Y93.135 E.01092
G1 X122.502 Y92.552 E.01455
G1 X122.413 Y91.626 E.02263
G1 X122.412 Y90.937 E.01676
G1 X113.305 Y90.937 E.22152
G1 X113.305 Y90.937 F9000
G1 X113.741 Y91.676
;WIDTH:0.41542
G1 F1200
G1 X113.775 Y91.676 E.00086
;WIDTH:0.426026
G1 X117.481 Y91.681 E.09656
;WIDTH:0.46008
G1 X117.897 Y91.698 E.01179
G1 X118.179 Y91.683 E.008
;WIDTH:0.43004
G1 X118.461 Y91.668 E.00743
;WIDTH:0.399999
G1 X121.683 Y91.668 E.07837
G1 X121.721 Y92.286 E.01506
G1 X121.825 Y92.927 E.0158
;WIDTH:0.442299
G1 X121.945 Y93.359 E.01217
;WIDTH:0.484599
G1 X122.064 Y93.791 E.01342
G1 X122.241 Y94.088 E.01036
;WIDTH:0.483314
G1 X122.381 Y94.178 E.00497
;WIDTH:0.441657
G1 X122.522 Y94.268 E.00453
;WIDTH:0.399999
G1 X122.782 Y94.358 E.00669
G1 X122.782 Y95.988 E.03965
G1 X122.056 Y94.739 E.03514
;WIDTH:0.442299
G1 X121.868 Y94.38 E.011
;WIDTH:0.484599
G1 X121.68 Y94.022 E.01211
G1 X121.51 Y93.833 E.00761
;WIDTH:0.442299
G1 X121.339 Y93.644 E.00692
;WIDTH:0.399999
G1 X120.764 Y93.041 E.02027
G1 X120.333 Y92.692 E.01349
G1 X119.746 Y92.325 E.01684
G1 X119.244 Y92.093 E.01345
G1 X118.445 Y91.835 E.02042
;WIDTH:0.440635
G1 X118.074 Y91.742 E.01034
G1 E-5 F3600
G1 X118.074 Y91.742 F9000
G1 X120.231 Y92.106
G1 E5 F2400
;WIDTH:0.544881
G1 F1200
G1 X121.268 Y92.106 E.03522
G1 X121.318 Y92.548 E.01511
G1 X121.413 Y93.082 E.01842
G1 X121.166 Y92.819 E.01225
G1 X120.704 Y92.422 E.02069
G1 X120.383 Y92.208 E.0131
G1 E-5 F3600
G1 X120.383 Y92.208 F9000
G1 X122.46 Y94.617
G1 E5 F2400
;WIDTH:0.401476
G1 F1200
G1 X122.383 Y94.596 E.00195
G1 X122.403 Y94.673 E.00194
G1 X122.448 Y94.661 E.00114
G1 E-5 F3600
G1 X122.448 Y94.661 F9000
G1 X117.814 Y93.856
G1 X117.651 Y93.832
G1 X117.524 Y93.816
G1 X117.359 Y93.808
G1 X117.244 Y93.803
G1 X113.756 Y93.803
G1 X113.641 Y93.808
G1 X113.476 Y93.816
G1 X113.349 Y93.832
G1 X113.186 Y93.856
G1 X113.061 Y93.883
G1 X112.901 Y93.922
G1 X112.779 Y93.961
G1 X112.623 Y94.015
G1 X112.505 Y94.064
G1 X112.355 Y94.132
G1 X112.241 Y94.191
G1 X112.099 Y94.274
G1 X111.991 Y94.343
G1 X111.857 Y94.438
G1 X107.484 Y97.785
G1 E5 F2400
;WIDTH:0.395179
G1 F1200
G1 X107.755 Y97.977 E.00797
G1 X107.952 Y97.95 E.00477
G1 X107.77 Y98.313 E.00975
G1 X107.61 Y98.476 E.00548
G1 X107.51 Y98.272 E.00545
G1 X107.494 Y97.968 E.00731
;WIDTH:0.399999
G1 X107.844 Y97.562 E.01304
G1 X108.802 Y96.604 E.03295
;WIDTH:0.374336
G1 X108.761 Y96.615 E.00096
G1 X108.742 Y96.544 E.00166
G1 X108.813 Y96.563 E.00166
G1 E-5 F3600
G1 X108.813 Y96.563 F9000
G1 X111.991 Y94.343
G1 X112.099 Y94.274
G1 X112.241 Y94.191
G1 X112.355 Y94.132
G1 X112.505 Y94.064
G1 X112.623 Y94.015
G1 X112.779 Y93.961
G1 X112.901 Y93.922
G1 X113.061 Y93.883
G1 X113.186 Y93.856
G1 X113.349 Y93.832
G1 X113.476 Y93.816
G1 X113.641 Y93.808
G1 X113.756 Y93.803
G1 X122.97 Y93.433
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X123.513 Y92.89 E.01868
G1 X123.513 Y92.327 E.01369
G1 X122.945 Y92.895 E.01954
G1 X122.849 Y92.429 E.01157
G1 X123.571 Y91.706 E.02485
G1 X123.642 Y91.329 E.00933
G1 X123.919 Y90.937 E.01168
G1 X123.778 Y90.937 E.00343
G1 X122.79 Y91.924 E.03397
G1 X122.778 Y91.374 E.01338
G1 X123.379 Y90.772 E.02069
G1 E-5 F3600
G1 X123.379 Y90.772 F9000
G1 X123.489 Y101.202
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.431056
G1 F1200
G1 X123.584 Y101.421 E.0063
G1 X123.584 Y102.103 E.018
G1 X123.367 Y102.028 E.00606
G1 X123.246 Y101.931 E.00409
G1 X123.118 Y101.919 E.00339
G1 X123.334 Y101.398 E.01488
G1 X123.376 Y101.345 E.00178
G1 X123.376 Y101.345 F9000
G1 X123.094 Y102.318
;WIDTH:0.399999
G1 F1200
G1 X122.668 Y102.744 E.01465
G1 X122.511 Y102.992 E.00714
;WIDTH:0.374336
G1 X122.44 Y102.973 E.00166
G1 X122.459 Y103.044 E.00166
G1 X122.5 Y103.033 E.00096
G1 X122.5 Y103.033 F9000
G1 X123.48 Y102.45
;WIDTH:0.399999
G1 F1200
G1 X121.955 Y103.975 E.05246
G1 X121.797 Y104.222 E.00713
;WIDTH:0.374336
G1 X121.726 Y104.203 E.00166
G1 X121.745 Y104.274 E.00166
G1 X121.786 Y104.263 E.00096
G1 E-5 F3600
G1 X121.786 Y104.263 F9000
G1 X123.6 Y102.847
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X121.242 Y105.205 E.08111
G1 X121.034 Y105.463 E.00806
;WIDTH:0.374336
G1 X120.116 Y106.451 E.0305
;WIDTH:0.407582
G1 X119.447 Y106.994 E.02139
;WIDTH:0.399999
G1 X119.765 Y107.199 E.0092
G1 X123.537 Y103.427 E.12975
G1 X123.513 Y103.968 E.01317
G1 X120.074 Y107.407 E.1183
G1 X120.34 Y107.658 E.0089
G1 X123.513 Y104.485 E.10915
G1 X123.513 Y105.002 E.01258
G1 X120.593 Y107.922 E.10045
G1 E-5 F3600
G1 X120.593 Y107.922 F9000
G1 X123.384 Y105.649
G1 E5 F2400
G1 F1200
G1 X120.834 Y108.198 E.0877
G1 X121.071 Y108.501 E.00936
G1 X122.931 Y111.7 E.09001
G1 X123.329 Y112.616 E.02429
G1 X123.453 Y112.851 E.00646
G1 X123.513 Y112.578 E.0068
G1 X123.513 Y105.519 E.1717
G1 X123.513 Y105.519 F9000
G1 X123.147 Y106.402
G1 F1200
G1 X123.147 Y111.345 E.12023
G1 X121.323 Y108.227 E.08787
G1 X123.018 Y106.531 E.05832
G1 X123.018 Y106.531 F9000
G1 X122.782 Y107.285
G1 F1200
G1 X122.782 Y109.988 E.06575
G1 X121.788 Y108.279 E.04809
G1 X122.652 Y107.414 E.02974
G1 X122.652 Y107.414 F9000
G1 X122.403 Y108.334
;WIDTH:0.551494
G1 F1200
G1 X122.357 Y108.288 E.00224
G1 X122.295 Y108.305 E.00221
G1 X122.278 Y108.367 E.00221
G1 X122.324 Y108.413 E.00224
G1 X122.386 Y108.396 E.00221
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X122.324 Y108.413 E-.03054
G1 X122.278 Y108.367 E-.0309
G1 X122.295 Y108.305 E-.03054
G1 X122.357 Y108.288 E-.03054
G1 X122.403 Y108.334 E-.0309
;WIPE_END
G1 E-1.34658 F3600
G1 X124.901 Y108.693 F9000
G1 X126.349 Y108.901
G1 X135.651 Y110.237
G1 X137.049 Y110.038
G1 X136.7 Y110.387
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X139.201 Y110.389 E.06083
G1 X139.514 Y110.479 E.00792
G1 X139.768 Y110.728 E.00865
G1 X139.892 Y111.1 E.00954
G1 X139.9 Y112.773 E.04069
G1 X139.853 Y113.088 E.00775
G1 X139.727 Y113.337 E.00679
G1 X139.533 Y113.514 E.00639
G1 X139.291 Y113.603 E.00627
G1 X136.7 Y113.612 E.06302
G1 X136.7 Y118.387 E.11615
G1 X139.201 Y118.389 E.06083
G1 X139.514 Y118.479 E.00792
G1 X139.768 Y118.728 E.00865
G1 X139.892 Y119.1 E.00954
G1 X139.9 Y120.773 E.04069
G1 X139.853 Y121.088 E.00775
G1 X139.727 Y121.337 E.00679
G1 X139.533 Y121.514 E.00639
G1 X139.291 Y121.603 E.00627
G1 X136.7 Y121.612 E.06302
G1 X136.7 Y126.387 E.11615
G1 X139.201 Y126.389 E.06083
G1 X139.514 Y126.479 E.00792
G1 X139.768 Y126.728 E.00865
G1 X139.892 Y127.1 E.00954
G1 X139.892 Y128.899 E.04376
G1 X139.79 Y129.233 E.00849
G1 X139.533 Y129.514 E.00926
G1 X139.291 Y129.603 E.00627
G1 X136.699 Y129.612 E.06305
G1 X136.691 Y133.021 E.08292
G1 X136.61 Y133.951 E.02271
G1 X136.537 Y134.388 E.01078
G1 X139.201 Y134.389 E.0648
G1 X139.514 Y134.479 E.00792
G1 X139.768 Y134.728 E.00865
G1 X139.892 Y135.101 E.00956
G1 X139.891 Y136.905 E.04388
G1 X139.799 Y137.221 E.00801
G1 X139.638 Y137.435 E.00651
G1 X139.426 Y137.568 E.00609
G1 X139.259 Y137.607 E.00417
G1 X135.379 Y137.612 E.09438
G1 X135.012 Y138.22 E.01727
G1 X134.624 Y138.77 E.01637
G1 X134.174 Y139.34 E.01766
G1 X133.668 Y139.891 E.0182
G1 X133.121 Y140.39 E.01801
G1 X132.02 Y141.206 E.03333
G1 X130.965 Y141.82 E.02969
G1 X130.611 Y142.117 E.01124
G1 X130.549 Y142.278 E.0042
G1 X130.603 Y142.333 E.00187
G1 X130.808 Y142.376 E.00509
G1 X139.202 Y142.389 E.20418
G1 X139.482 Y142.458 E.00701
G1 X139.681 Y142.608 E.00606
G1 X139.808 Y142.807 E.00574
G1 X139.9 Y143.228 E.01048
G1 X139.892 Y144.9 E.04067
G1 X139.768 Y145.272 E.00954
G1 X139.514 Y145.521 E.00865
G1 X139.201 Y145.611 E.00792
G1 X125.443 Y145.625 E.33465
G1 X125.301 Y145.557 E.00383
G1 X125.26 Y145.442 E.00297
G1 X125.256 Y143.1 E.05697
G1 X125.155 Y142.936 E.00468
G1 X124.776 Y142.826 E.0096
G1 X120.483 Y142.824 E.10442
G1 X120.395 Y142.752 E.00277
G1 X110.605 Y142.752 E.23813
G1 X110.517 Y142.824 E.00277
G1 X106.309 Y142.824 E.10236
G1 X105.905 Y142.892 E.00997
G1 X105.744 Y143.089 E.00619
G1 X105.74 Y145.442 E.05723
G1 X105.681 Y145.576 E.00356
G1 X105.556 Y145.625 E.00327
G1 X91.798 Y145.611 E.33465
G1 X91.518 Y145.542 E.00701
G1 X91.308 Y145.374 E.00654
G1 X91.132 Y145.035 E.00929
G1 X91.1 Y144.772 E.00644
G1 X91.108 Y143.1 E.04067
G1 X91.21 Y142.767 E.00847
G1 X91.467 Y142.486 E.00926
G1 X91.709 Y142.397 E.00627
G1 X98.174 Y142.381 E.15726
G1 X100.222 Y142.376 E.04982
G1 X100.446 Y142.302 E.00574
G1 X100.421 Y142.19 E.00279
G1 X100.316 Y142.033 E.00459
G1 X100.009 Y141.805 E.0093
G1 X98.997 Y141.217 E.02847
G1 X97.875 Y140.388 E.03393
G1 X97.344 Y139.902 E.01751
G1 X96.834 Y139.351 E.01826
G1 X96.375 Y138.769 E.01803
G1 X95.995 Y138.23 E.01604
G1 X95.621 Y137.612 E.01757
G1 X91.741 Y137.607 E.09438
G1 X91.518 Y137.542 E.00565
G1 X91.316 Y137.388 E.00618
G1 X91.175 Y137.167 E.00638
G1 X91.109 Y136.905 E.00657
G1 X91.108 Y135.1 E.0439
G1 X91.232 Y134.728 E.00954
G1 X91.486 Y134.479 E.00865
G1 X91.799 Y134.389 E.00792
G1 X94.463 Y134.388 E.0648
G1 X94.31 Y133.027 E.03331
G1 X94.301 Y129.611 E.08309
G1 X91.709 Y129.603 E.06305
G1 X91.411 Y129.475 E.00789
G1 X91.236 Y129.284 E.0063
G1 X91.132 Y129.035 E.00656
G1 X91.1 Y128.772 E.00644
G1 X91.108 Y127.1 E.04067
G1 X91.232 Y126.728 E.00954
G1 X91.486 Y126.479 E.00865
G1 X91.799 Y126.389 E.00792
G1 X94.3 Y126.387 E.06083
G1 X94.3 Y121.613 E.11612
G1 X91.799 Y121.611 E.06083
G1 X91.486 Y121.521 E.00792
G1 X91.232 Y121.272 E.00865
G1 X91.108 Y120.9 E.00954
G1 X91.1 Y119.227 E.04069
G1 X91.147 Y118.912 E.00775
G1 X91.273 Y118.663 E.00679
G1 X91.467 Y118.486 E.00639
G1 X91.709 Y118.397 E.00627
G1 X94.3 Y118.388 E.06302
G1 X94.3 Y113.613 E.11615
G1 X91.799 Y113.611 E.06083
G1 X91.486 Y113.521 E.00792
G1 X91.232 Y113.272 E.00865
G1 X91.108 Y112.9 E.00954
G1 X91.1 Y111.227 E.04069
G1 X91.147 Y110.912 E.00775
G1 X91.273 Y110.663 E.00679
G1 X91.467 Y110.486 E.00639
G1 X91.709 Y110.397 E.00627
G1 X94.3 Y110.388 E.06302
G1 X94.3 Y105.613 E.11615
G1 X91.799 Y105.611 E.06083
G1 X91.486 Y105.521 E.00792
G1 X91.232 Y105.272 E.00865
G1 X91.108 Y104.9 E.00954
G1 X91.1 Y103.227 E.04069
G1 X91.147 Y102.912 E.00775
G1 X91.273 Y102.663 E.00679
G1 X91.467 Y102.486 E.00639
G1 X91.709 Y102.397 E.00627
G1 X94.3 Y102.388 E.06302
G1 X94.3 Y96.308 E.14789
G1 X91.798 Y96.307 E.06086
G1 X91.531 Y96.249 E.00665
G1 X91.318 Y96.106 E.00624
G1 X91.134 Y95.813 E.00842
G1 X91.1 Y95.604 E.00515
G1 X91.108 Y93.134 E.06008
G1 X91.212 Y92.848 E.0074
G1 X91.376 Y92.669 E.00591
G1 X91.589 Y92.558 E.00584
G1 X91.798 Y92.522 E.00516
G1 X105 Y92.521 E.32113
G1 X105 Y92.026 E.01204
G1 X103.713 Y90.919 E.04129
G1 X103.499 Y90.657 E.00823
G1 X103.463 Y90.438 E.0054
G1 X103.525 Y90.298 E.00372
G1 X104.031 Y89.801 E.01725
G1 X105 Y88.973 E.031
G1 X105.019 Y88.602 E.00904
G1 X105.151 Y88.503 E.00401
G1 X105.183 Y88.5 E.00078
G1 X125.817 Y88.5 E.5019
G1 X125.96 Y88.568 E.00385
G1 X126 Y88.683 E.00296
G1 X126 Y88.974 E.00708
G1 X127.287 Y90.081 E.04129
G1 X127.501 Y90.343 E.00823
G1 X127.537 Y90.562 E.0054
G1 X127.475 Y90.702 E.00372
G1 X127.176 Y91.022 E.01065
G1 X126 Y92.027 E.03763
G1 X126 Y92.521 E.01202
G1 X139.202 Y92.522 E.32113
G1 X139.589 Y92.647 E.00989
G1 X139.826 Y92.919 E.00878
G1 X139.9 Y93.225 E.00766
G1 X139.9 Y95.604 E.05787
G1 X139.845 Y95.872 E.00665
G1 X139.702 Y96.086 E.00626
G1 X139.411 Y96.271 E.00839
G1 X138.999 Y96.307 E.01006
G1 X136.7 Y96.308 E.05592
G1 X136.7 Y102.387 E.14787
G1 X139.201 Y102.389 E.06083
G1 X139.514 Y102.479 E.00792
G1 X139.768 Y102.728 E.00865
G1 X139.892 Y103.1 E.00954
G1 X139.9 Y104.773 E.04069
G1 X139.853 Y105.088 E.00775
G1 X139.727 Y105.337 E.00679
G1 X139.533 Y105.514 E.00639
G1 X139.291 Y105.603 E.00627
G1 X136.7 Y105.612 E.06302
G1 X136.7 Y110.327 E.11469
G1 X136.7 Y110.327 F9000
G1 X137.066 Y110.022
;TYPE:Perimeter
;WIDTH:0.400051
G1 F6000
G1 X139.201 Y110.024 E.05194
G1 X139.624 Y110.13 E.01061
G1 X139.871 Y110.291 E.00717
;WIDTH:0.444024
G1 X139.982 Y110.446 E.0052
;WIDTH:0.488049
G1 X140.094 Y110.601 E.00577
;WIDTH:0.532074
G1 X140.205 Y110.755 E.00629
;WIDTH:0.576098
G1 X140.317 Y110.91 E.00689
G1 X140.336 Y111.098 E.00681
;WIDTH:0.555314
G1 X140.341 Y112.773 E.05805
;WIDTH:0.57362
G1 X140.312 Y113.122 E.01256
G1 X140.281 Y113.151 E.00152
;WIDTH:0.530228
G1 X140.249 Y113.18 E.00142
;WIDTH:0.486836
G1 X140.218 Y113.21 E.0013
;WIDTH:0.443444
G1 X140.186 Y113.239 E.00118
;WIDTH:0.400051
G1 X139.986 Y113.595 E.00993
G1 X139.679 Y113.849 E.00969
G1 X139.292 Y113.968 E.00985
G1 X137.066 Y113.976 E.05415
G1 X137.066 Y118.022 E.09843
G1 X139.201 Y118.024 E.05194
G1 X139.624 Y118.13 E.01061
G1 X139.871 Y118.291 E.00717
;WIDTH:0.444024
G1 X139.982 Y118.446 E.0052
;WIDTH:0.488049
G1 X140.094 Y118.601 E.00577
;WIDTH:0.532074
G1 X140.205 Y118.755 E.00629
;WIDTH:0.576098
G1 X140.317 Y118.91 E.00689
G1 X140.336 Y119.098 E.00681
;WIDTH:0.555314
G1 X140.341 Y120.773 E.05805
;WIDTH:0.57362
G1 X140.312 Y121.122 E.01256
G1 X140.281 Y121.151 E.00152
;WIDTH:0.530228
G1 X140.249 Y121.18 E.00142
;WIDTH:0.486836
G1 X140.218 Y121.21 E.0013
;WIDTH:0.443444
G1 X140.186 Y121.239 E.00118
;WIDTH:0.400051
G1 X139.986 Y121.595 E.00993
G1 X139.679 Y121.849 E.00969
G1 X139.292 Y121.968 E.00985
G1 X137.066 Y121.976 E.05415
G1 X137.066 Y126.022 E.09843
G1 X139.201 Y126.024 E.05194
G1 X139.624 Y126.13 E.01061
G1 X139.871 Y126.291 E.00717
;WIDTH:0.444022
G1 X139.982 Y126.446 E.0052
;WIDTH:0.488045
G1 X140.094 Y126.601 E.00577
;WIDTH:0.532068
G1 X140.205 Y126.755 E.00629
;WIDTH:0.57609
G1 X140.317 Y126.91 E.00689
G1 X140.336 Y127.1 E.00688
;WIDTH:0.555304
G1 X140.336 Y128.899 E.06234
G1 X140.294 Y129.062 E.00583
;WIDTH:0.516674
G1 X140.22 Y129.197 E.00494
;WIDTH:0.477783
G1 X140.146 Y129.331 E.00452
;WIDTH:0.438891
G1 X140.072 Y129.466 E.00414
;WIDTH:0.399999
G1 X139.883 Y129.695 E.00722
G1 X139.679 Y129.849 E.00622
G1 X139.292 Y129.968 E.00985
G1 X137.064 Y129.976 E.05419
G1 X137.056 Y133.022 E.07409
G1 X136.969 Y134.022 E.02442
G1 X139.201 Y134.024 E.05429
G1 X139.624 Y134.13 E.01061
G1 X139.871 Y134.291 E.00717
;WIDTH:0.444021
G1 X139.982 Y134.446 E.0052
;WIDTH:0.488043
G1 X140.094 Y134.601 E.00577
;WIDTH:0.532065
G1 X140.205 Y134.755 E.00629
;WIDTH:0.576087
G1 X140.317 Y134.91 E.00689
G1 X140.336 Y135.415 E.01821
;WIDTH:0.555389
G1 X140.316 Y135.515 E.00353
;WIDTH:0.516542
G1 X140.297 Y135.615 E.00327
;WIDTH:0.477694
G1 X140.277 Y135.715 E.00301
;WIDTH:0.438847
G1 X140.258 Y135.815 E.00274
;WIDTH:0.399999
G1 X140.257 Y136.905 E.02651
G1 X140.177 Y137.266 E.00899
G1 X139.985 Y137.596 E.00929
G1 X139.69 Y137.843 E.00936
G1 X139.403 Y137.953 E.00748
G1 X138.906 Y137.973 E.0121
G1 X135.585 Y137.978 E.08078
G1 X135.325 Y138.409 E.01224
G1 X135.028 Y138.833 E.01259
G1 X134.461 Y139.567 E.02256
G1 X133.936 Y140.139 E.01889
G1 X133.339 Y140.684 E.01966
G1 X132.238 Y141.5 E.03333
G1 X131.363 Y142.012 E.02466
G1 X139.203 Y142.024 E.1907
G1 X139.488 Y142.071 E.00703
G1 X139.845 Y142.264 E.00987
G1 X140.073 Y142.525 E.00843
;WIDTH:0.440702
G1 X140.138 Y142.665 E.00417
;WIDTH:0.481405
G1 X140.202 Y142.806 E.0046
;WIDTH:0.522108
G1 X140.267 Y142.946 E.00501
;WIDTH:0.562811
G1 X140.331 Y143.087 E.00544
G1 X140.341 Y143.23 E.00504
;WIDTH:0.555314
G1 X140.336 Y144.902 E.05794
G1 X140.287 Y145.081 E.00643
;WIDTH:0.514223
G1 X140.206 Y145.225 E.00527
;WIDTH:0.476149
G1 X140.124 Y145.369 E.00487
;WIDTH:0.438074
G1 X140.042 Y145.514 E.00447
;WIDTH:0.399999
G1 X139.871 Y145.709 E.00631
G1 X139.624 Y145.87 E.00717
G1 X139.201 Y145.976 E.01061
G1 X125.443 Y145.99 E.33465
G1 X125.156 Y145.909 E.00725
G1 X124.961 Y145.704 E.00688
G1 X124.894 Y145.443 E.00655
G1 X124.89 Y143.227 E.0539
G1 X124.716 Y143.192 E.00432
G1 X120.482 Y143.189 E.10299
G1 X120.4 Y143.183 E.002
G1 X120.344 Y143.118 E.00209
G1 X110.656 Y143.118 E.23565
G1 X110.561 Y143.188 E.00287
G1 X106.326 Y143.19 E.10301
G1 X106.11 Y143.21 E.00528
G1 X106.106 Y145.443 E.05432
G1 X106.017 Y145.741 E.00756
G1 X105.844 Y145.909 E.00587
G1 X105.555 Y145.99 E.0073
G1 X91.798 Y145.976 E.33463
G1 X91.512 Y145.929 E.00705
G1 X91.155 Y145.736 E.00987
G1 X90.989 Y145.554 E.00599
;WIDTH:0.442201
G1 X90.914 Y145.446 E.00357
;WIDTH:0.484402
G1 X90.84 Y145.338 E.00392
;WIDTH:0.526604
G1 X90.765 Y145.229 E.00433
;WIDTH:0.568805
G1 X90.69 Y145.121 E.00467
G1 X90.661 Y144.77 E.01252
;WIDTH:0.550687
G1 X90.667 Y143.098 E.05743
;WIDTH:0.567178
G1 X90.682 Y142.931 E.00594
G1 X90.79 Y142.775 E.00673
;WIDTH:0.525384
G1 X90.899 Y142.618 E.00624
;WIDTH:0.483589
G1 X91.008 Y142.461 E.00571
;WIDTH:0.441794
G1 X91.117 Y142.305 E.00516
;WIDTH:0.399999
G1 X91.321 Y142.151 E.00622
G1 X91.708 Y142.032 E.00985
G1 X98.173 Y142.015 E.15726
G1 X99.637 Y142.012 E.03561
G1 X98.813 Y141.533 E.02318
G1 X98.373 Y141.237 E.0129
G1 X97.651 Y140.676 E.02224
G1 X97.097 Y140.172 E.01822
G1 X96.566 Y139.599 E.019
G1 X96.088 Y138.995 E.01874
G1 X95.696 Y138.441 E.01651
G1 X95.415 Y137.978 E.01317
G1 X91.741 Y137.973 E.08937
G1 X91.477 Y137.921 E.00654
G1 X91.155 Y137.736 E.00903
G1 X90.9 Y137.429 E.00971
;WIDTH:0.439591
G1 X90.843 Y137.325 E.0032
;WIDTH:0.479183
G1 X90.787 Y137.221 E.0035
;WIDTH:0.518775
G1 X90.73 Y137.117 E.00382
;WIDTH:0.558366
G1 X90.673 Y137.013 E.00413
G1 X90.667 Y136.905 E.00377
;WIDTH:0.551675
G1 X90.666 Y135.101 E.06208
;WIDTH:0.572034
G1 X90.685 Y134.911 E.00683
G1 X90.753 Y134.805 E.0045
;WIDTH:0.529026
G1 X90.821 Y134.699 E.00414
;WIDTH:0.486017
G1 X90.889 Y134.592 E.00381
;WIDTH:0.443008
G1 X90.958 Y134.486 E.00344
;WIDTH:0.399999
G1 X91.129 Y134.291 E.00631
G1 X91.376 Y134.13 E.00717
G1 X91.799 Y134.024 E.01061
G1 X94.031 Y134.022 E.05429
G1 X93.945 Y133.059 E.02352
G1 X93.936 Y129.975 E.07502
G1 X91.708 Y129.968 E.05419
G1 X91.321 Y129.849 E.00985
G1 X91.014 Y129.595 E.00969
;WIDTH:0.442524
G1 X90.933 Y129.477 E.00389
;WIDTH:0.485049
G1 X90.852 Y129.358 E.00432
;WIDTH:0.527574
G1 X90.771 Y129.24 E.0047
;WIDTH:0.570099
G1 X90.689 Y129.122 E.00512
G1 X90.66 Y128.77 E.01259
;WIDTH:0.551973
G1 X90.666 Y127.098 E.05757
;WIDTH:0.572702
G1 X90.685 Y126.91 E.00677
G1 X90.753 Y126.804 E.00451
;WIDTH:0.529527
G1 X90.821 Y126.698 E.00415
;WIDTH:0.486351
G1 X90.889 Y126.592 E.00379
;WIDTH:0.443175
G1 X90.958 Y126.486 E.00344
;WIDTH:0.399999
G1 X91.129 Y126.291 E.00631
G1 X91.376 Y126.13 E.00717
G1 X91.799 Y126.024 E.01061
G1 X93.934 Y126.022 E.05193
G1 X93.934 Y121.978 E.09837
G1 X91.799 Y121.976 E.05193
G1 X91.376 Y121.87 E.01061
G1 X91.129 Y121.709 E.00717
;WIDTH:0.406196
G1 X90.843 Y121.316 E.01202
;WIDTH:0.444438
G1 X90.8 Y121.239 E.00241
;WIDTH:0.482679
G1 X90.757 Y121.162 E.00263
;WIDTH:0.520921
G1 X90.715 Y121.085 E.00284
;WIDTH:0.559162
G1 X90.672 Y121.008 E.00308
G1 X90.666 Y120.902 E.00371
;WIDTH:0.552471
G1 X90.66 Y119.227 E.05773
;WIDTH:0.567771
G1 X90.686 Y118.908 E.01136
G1 X90.718 Y118.871 E.00174
;WIDTH:0.525828
G1 X90.75 Y118.834 E.0016
;WIDTH:0.483885
G1 X90.782 Y118.798 E.00144
;WIDTH:0.441942
G1 X90.814 Y118.761 E.00133
;WIDTH:0.399999
G1 X91.014 Y118.405 E.00993
G1 X91.321 Y118.151 E.00969
G1 X91.708 Y118.032 E.00985
G1 X93.934 Y118.024 E.05415
G1 X93.934 Y113.978 E.09841
G1 X91.799 Y113.976 E.05193
G1 X91.376 Y113.87 E.01061
G1 X91.129 Y113.709 E.00717
;WIDTH:0.406187
G1 X90.843 Y113.316 E.01202
;WIDTH:0.444593
G1 X90.8 Y113.239 E.00241
;WIDTH:0.482999
G1 X90.757 Y113.162 E.00263
;WIDTH:0.521405
G1 X90.714 Y113.085 E.00286
;WIDTH:0.55981
G1 X90.672 Y113.008 E.00307
G1 X90.665 Y112.902 E.00371
;WIDTH:0.553113
G1 X90.66 Y111.227 E.0578
;WIDTH:0.568416
G1 X90.686 Y110.908 E.01137
G1 X90.718 Y110.871 E.00174
;WIDTH:0.526312
G1 X90.75 Y110.834 E.0016
;WIDTH:0.484208
G1 X90.782 Y110.798 E.00144
;WIDTH:0.442104
G1 X90.814 Y110.761 E.00133
;WIDTH:0.399999
G1 X91.014 Y110.405 E.00993
G1 X91.321 Y110.151 E.00969
G1 X91.708 Y110.032 E.00985
G1 X93.934 Y110.024 E.05415
G1 X93.934 Y105.978 E.09841
G1 X91.799 Y105.976 E.05193
G1 X91.376 Y105.87 E.01061
G1 X91.129 Y105.709 E.00717
;WIDTH:0.406178
G1 X90.843 Y105.316 E.01202
;WIDTH:0.444748
G1 X90.8 Y105.239 E.00241
;WIDTH:0.483318
G1 X90.757 Y105.162 E.00263
;WIDTH:0.521888
G1 X90.714 Y105.085 E.00286
;WIDTH:0.560458
G1 X90.671 Y105.008 E.00309
G1 X90.665 Y104.902 E.00372
;WIDTH:0.553756
G1 X90.659 Y103.227 E.05787
;WIDTH:0.569061
G1 X90.686 Y102.908 E.01139
G1 X90.718 Y102.871 E.00174
;WIDTH:0.526796
G1 X90.75 Y102.834 E.0016
;WIDTH:0.48453
G1 X90.782 Y102.798 E.00144
;WIDTH:0.442265
G1 X90.814 Y102.761 E.00133
;WIDTH:0.399999
G1 X91.014 Y102.405 E.00993
G1 X91.321 Y102.151 E.00969
G1 X91.708 Y102.032 E.00985
G1 X93.934 Y102.024 E.05415
G1 X93.934 Y96.673 E.13016
G1 X91.798 Y96.672 E.05196
G1 X91.522 Y96.63 E.00679
G1 X91.193 Y96.476 E.00884
G1 X91.019 Y96.316 E.00575
;WIDTH:0.443144
G1 X90.936 Y96.21 E.00366
;WIDTH:0.486289
G1 X90.854 Y96.104 E.00403
;WIDTH:0.529434
G1 X90.771 Y95.997 E.00446
;WIDTH:0.572578
G1 X90.689 Y95.891 E.0048
G1 X90.659 Y95.602 E.0104
;WIDTH:0.554697
G1 X90.665 Y93.133 E.08546
G1 X90.731 Y93.003 E.00505
;WIDTH:0.516023
G1 X90.798 Y92.873 E.00469
;WIDTH:0.477348
G1 X90.865 Y92.743 E.00431
;WIDTH:0.438674
G1 X90.931 Y92.613 E.00392
;WIDTH:0.399999
G1 X91.193 Y92.353 E.00898
G1 X91.522 Y92.198 E.00885
G1 X91.798 Y92.156 E.00679
G1 X104.589 Y92.155 E.31113
G1 X103.474 Y91.196 E.03577
G1 X103.264 Y90.968 E.00754
G1 X103.115 Y90.653 E.00848
G1 X103.113 Y90.333 E.00778
G1 X103.23 Y90.081 E.00676
G1 X103.581 Y89.705 E.01251
G1 X104.634 Y88.805 E.03369
G1 X104.664 Y88.506 E.00731
G1 X104.821 Y88.27 E.00689
G1 X105.088 Y88.143 E.00719
G1 X105.183 Y88.134 E.00232
G1 X125.817 Y88.134 E.5019
G1 X126.066 Y88.194 E.00623
G1 X126.287 Y88.4 E.00735
G1 X126.366 Y88.683 E.00715
G1 X126.366 Y88.806 E.00299
G1 X127.526 Y89.804 E.03722
G1 X127.828 Y90.175 E.01164
G1 X127.909 Y90.482 E.00772
G1 X127.866 Y90.735 E.00624
G1 X127.743 Y90.951 E.00605
G1 X127.413 Y91.3 E.01168
G1 X126.412 Y92.155 E.03202
G1 X139.202 Y92.156 E.3111
G1 X139.607 Y92.248 E.0101
G1 X139.849 Y92.389 E.00681
G1 X140.038 Y92.579 E.00652
;WIDTH:0.441582
G1 X140.11 Y92.7 E.00381
;WIDTH:0.483164
G1 X140.183 Y92.821 E.00422
;WIDTH:0.524747
G1 X140.255 Y92.942 E.00459
;WIDTH:0.566329
G1 X140.328 Y93.063 E.005
G1 X140.342 Y93.225 E.00575
;WIDTH:0.55128
G1 X140.342 Y95.604 E.08181
;WIDTH:0.573551
G1 X140.312 Y95.891 E.01035
G1 X140.213 Y96.014 E.00566
;WIDTH:0.530163
G1 X140.113 Y96.138 E.00525
;WIDTH:0.486775
G1 X140.013 Y96.262 E.00479
;WIDTH:0.443387
G1 X139.913 Y96.385 E.00431
;WIDTH:0.399999
G1 X139.693 Y96.54 E.00655
G1 X139.303 Y96.663 E.00995
G1 X137.066 Y96.673 E.05441
G1 X137.066 Y102.022 E.13011
G1 X139.201 Y102.024 E.05193
G1 X139.624 Y102.13 E.01061
G1 X139.871 Y102.291 E.00717
;WIDTH:0.444024
G1 X139.982 Y102.446 E.0052
;WIDTH:0.488048
G1 X140.094 Y102.601 E.00577
;WIDTH:0.532072
G1 X140.205 Y102.755 E.00629
;WIDTH:0.576096
G1 X140.317 Y102.91 E.00689
G1 X140.336 Y103.098 E.00681
;WIDTH:0.555314
G1 X140.341 Y104.773 E.05805
;WIDTH:0.57362
G1 X140.312 Y105.122 E.01256
G1 X140.281 Y105.151 E.00152
;WIDTH:0.530228
G1 X140.249 Y105.18 E.00142
;WIDTH:0.486836
G1 X140.218 Y105.21 E.0013
;WIDTH:0.443444
G1 X140.186 Y105.239 E.00118
;WIDTH:0.400051
G1 X139.986 Y105.595 E.00993
G1 X139.679 Y105.849 E.00969
G1 X139.292 Y105.968 E.00985
G1 X137.066 Y105.976 E.05415
G1 X137.066 Y109.962 E.09697
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X137.066 Y110.022 E-.0285
G1 X139.201 Y110.024 E-1.01413
G1 X139.624 Y110.13 E-.20714
G1 X139.871 Y110.291 E-.14005
G1 X139.982 Y110.446 E-.09056
G1 X140.006 Y110.479 E-.01962
;WIPE_END
G1 X140.019 Y110.468 F9000
G1 X140.033 Y110.485
G1 X140.094 Y110.588
G1 X140.136 Y110.666
G1 X140.199 Y110.844
G1 X140.23 Y110.993
G1 X140.238 Y111.036
G1 X140.247 Y111.182
G1 X140.249 Y111.214
G1 X140.249 Y144.786
G1 X140.247 Y144.818
G1 X140.238 Y144.964
G1 X140.23 Y145.007
G1 X140.199 Y145.156
G1 X140.136 Y145.334
G1 X140.094 Y145.412
G1 X140.033 Y145.515
G1 X139.911 Y145.661
G1 X139.762 Y145.786
G1 X139.59 Y145.881
G1 X139.41 Y145.939
G1 X139.313 Y145.953
G1 X139.218 Y145.959
G1 X133.859 Y145.974
G1 X131.1 Y145.976
G1 X127.9 Y145.976
G1 X124.911 Y145.974
G1 X111.977 Y143.101
G1 X105.677 Y150.027
G1 X105.678 Y150.433
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.699 Y150.443 E.00057
G1 X105.74 Y150.558 E.00297
G1 X105.74 Y153.442 E.07015
G1 X105.703 Y153.552 E.00282
G1 X105.557 Y153.625 E.00397
G1 X96.178 Y153.615 E.22813
G1 X91.798 Y153.611 E.10654
G1 X91.518 Y153.542 E.00701
G1 X91.319 Y153.392 E.00606
G1 X91.192 Y153.193 E.00574
G1 X91.1 Y152.713 E.01189
G1 X91.108 Y151.1 E.03924
G1 X91.21 Y150.767 E.00847
G1 X91.467 Y150.486 E.00926
G1 X91.709 Y150.397 E.00627
G1 X105.557 Y150.375 E.33684
G1 X105.624 Y150.407 E.00181
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X105.678 Y150.433 E-.02847
G1 X105.699 Y150.443 E-.01105
G1 X105.74 Y150.558 E-.05799
G1 X105.74 Y153.442 E-1.3699
G1 X105.718 Y153.507 E-.03259
;WIPE_END
G1 X106.089 Y153.507 F9000
G1 X124.911 Y150.437
G1 X125.314 Y150.436
G1 E5 F2400
G1 F6000
G1 X125.319 Y150.424 E.00032
G1 X125.443 Y150.375 E.00324
G1 X139.291 Y150.397 E.33684
G1 X139.589 Y150.525 E.00789
G1 X139.769 Y150.729 E.00662
G1 X139.892 Y151.101 E.00953
G1 X139.891 Y152.905 E.04388
G1 X139.799 Y153.221 E.00801
G1 X139.638 Y153.435 E.00651
G1 X139.414 Y153.571 E.00637
G1 X139.202 Y153.611 E.00525
G1 X125.443 Y153.625 E.33467
G1 X125.297 Y153.552 E.00397
G1 X125.26 Y153.442 E.00282
G1 X125.26 Y150.558 E.07015
G1 X125.29 Y150.491 E.00179
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X125.314 Y150.436 E-.0285
G1 X125.319 Y150.424 E-.00617
G1 X125.443 Y150.375 E-.06333
G1 X128.395 Y150.38 E-1.402
;WIPE_END
G1 X128.395 Y150.024 F9000
G1 X139.59 Y145.881
G1 X140.23 Y145.007
G1 X140.249 Y93.202
G1 X140.235 Y93.042
G1 X140.188 Y92.865
G1 X140.111 Y92.699
G1 X140.006 Y92.549
G1 X139.876 Y92.419
G1 X139.726 Y92.314
G1 X139.56 Y92.236
G1 X126.349 Y88.151
G1 X120.62 Y88.151
G1 X120.373 Y86.599
G1 X120.373 Y86.176
G1 E5 F2400
G1 F6000
G1 X120.353 Y86.146 E.00088
G1 X110.647 Y86.146 E.23609
G1 X110.549 Y86.247 E.00342
G1 X110.517 Y86.25 E.00078
G1 X104.199 Y86.25 E.15368
G1 X103.642 Y86.212 E.01358
G1 X103.082 Y86.098 E.0139
G1 X102.597 Y85.932 E.01247
G1 X102.024 Y85.639 E.01565
G1 X101.587 Y85.337 E.01292
G1 X101.203 Y84.991 E.01257
G1 X100.789 Y84.498 E.01566
G1 X100.472 Y83.941 E.01559
G1 X100.277 Y83.528 E.01111
G1 X100.16 Y83.191 E.00868
G1 X100.01 Y82.327 E.02133
G1 X100 Y79.027 E.08027
G1 X98.824 Y78.022 E.03763
G1 X98.563 Y77.755 E.00908
G1 X98.456 Y77.496 E.00682
G1 X98.537 Y77.276 E.0057
G1 X98.713 Y77.081 E.00639
G1 X99.637 Y76.287 E.02963
G1 X100 Y75.974 E.01166
G1 X100.006 Y75.695 E.00679
G1 X100.06 Y75.605 E.00255
G1 X100.183 Y75.558 E.0032
G1 X130.817 Y75.558 E.74514
G1 X130.94 Y75.605 E.0032
G1 X131 Y75.741 E.00362
G1 X131 Y75.974 E.00567
G1 X132.287 Y77.081 E.04129
G1 X132.501 Y77.343 E.00823
G1 X132.537 Y77.562 E.0054
G1 X132.475 Y77.702 E.00372
G1 X132.176 Y78.022 E.01065
G1 X131 Y79.027 E.03763
G1 X131 Y82.051 E.07356
G1 X130.96 Y82.618 E.01383
G1 X130.858 Y83.127 E.01263
G1 X130.637 Y83.757 E.01624
G1 X130.389 Y84.229 E.01297
G1 X130.049 Y84.71 E.01433
G1 X129.437 Y85.317 E.02097
G1 X128.947 Y85.659 E.01453
G1 X128.48 Y85.898 E.01276
G1 X127.671 Y86.158 E.02067
G1 X127.098 Y86.239 E.01408
G1 X126.445 Y86.242 E.01588
G1 X120.483 Y86.25 E.14502
G1 X120.413 Y86.236 E.00174
G1 X120.406 Y86.226 E.0003
G1 X120.406 Y86.226 F9000
G1 X120.122 Y86.512
;TYPE:Perimeter
G1 F6000
G1 X110.769 Y86.512 E.2275
G1 X110.727 Y86.574 E.00182
G1 X110.517 Y86.616 E.00521
G1 X104.199 Y86.616 E.15368
G1 X103.617 Y86.577 E.01419
G1 X103.007 Y86.456 E.01513
G1 X102.478 Y86.277 E.01358
G1 X101.857 Y85.965 E.0169
G1 X101.378 Y85.637 E.01412
G1 X100.958 Y85.261 E.01371
G1 X100.509 Y84.733 E.01686
G1 X100.153 Y84.121 E.01722
G1 X99.933 Y83.651 E.01262
G1 X99.8 Y83.255 E.01016
G1 X99.652 Y82.421 E.0206
G1 X99.635 Y79.196 E.07845
G1 X98.587 Y78.3 E.03354
G1 X98.24 Y77.927 E.01239
G1 X98.095 Y77.584 E.00906
G1 X98.115 Y77.347 E.00579
G1 X98.264 Y77.032 E.00848
G1 X98.474 Y76.804 E.00754
G1 X99.398 Y76.009 E.02965
G1 X99.634 Y75.806 E.00757
G1 X99.652 Y75.602 E.00498
G1 X99.814 Y75.335 E.0076
;WIDTH:0.441202
G1 X99.902 Y75.27 E.00296
;WIDTH:0.482405
G1 X99.99 Y75.205 E.00326
;WIDTH:0.523608
G1 X100.077 Y75.14 E.00353
G1 X100.183 Y75.134 E.00346
;WIDTH:0.518256
G1 X130.817 Y75.133 E.98612
G1 X130.94 Y75.2 E.00451
;WIDTH:0.478837
G1 X131.063 Y75.267 E.00414
;WIDTH:0.439418
G1 X131.186 Y75.335 E.00379
;WIDTH:0.399999
G1 X131.348 Y75.602 E.0076
G1 X131.366 Y75.806 E.00498
G1 X132.526 Y76.804 E.03722
G1 X132.736 Y77.032 E.00754
G1 X132.885 Y77.347 E.00848
G1 X132.902 Y77.602 E.00622
G1 X132.784 Y77.901 E.00782
G1 X132.413 Y78.3 E.01325
G1 X131.366 Y79.195 E.0335
G1 X131.366 Y82.051 E.06947
G1 X131.325 Y82.644 E.01446
G1 X131.216 Y83.2 E.01378
G1 X130.981 Y83.879 E.01748
G1 X130.712 Y84.4 E.01426
G1 X130.347 Y84.922 E.01549
G1 X129.694 Y85.578 E.02251
G1 X129.154 Y85.96 E.01609
G1 X128.646 Y86.224 E.01393
G1 X127.781 Y86.506 E.02213
G1 X127.148 Y86.601 E.01557
G1 X120.483 Y86.616 E.16212
G1 X120.273 Y86.574 E.00521
G1 X120.231 Y86.512 E.00182
G1 X120.182 Y86.512 E.00119
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X120.122 Y86.512 E-.0285
G1 X117.024 Y86.512 E-1.4715
;WIPE_END
G1 X117.024 Y86.496 F9000
G1 X119.951 Y86.599
G1 X126.809 Y86.599
G1 X127.033 Y86.591
G1 X127.11 Y86.588
G1 X127.343 Y86.565
G1 X127.42 Y86.556
G1 X127.651 Y86.517
G1 X127.726 Y86.503
G1 X127.955 Y86.449
G1 X128.029 Y86.429
G1 X128.253 Y86.36
G1 X128.325 Y86.335
G1 X128.544 Y86.251
G1 X128.615 Y86.22
G1 X128.828 Y86.122
G1 X128.897 Y86.085
G1 X129.113 Y85.966
G1 X129.155 Y85.94
G1 X140.926 Y85.383
G1 X141.29 Y85.367
G1 E5 F2400
G1 F6000
G1 X141.3 Y85.652 E.00694
G1 X141.3 Y150.994 E1.58938
G1 X141.259 Y151.687 E.01689
G1 X141.137 Y152.365 E.01676
G1 X140.935 Y153.023 E.01674
G1 X140.657 Y153.653 E.01675
G1 X140.307 Y154.245 E.01673
G1 X139.888 Y154.792 E.01676
G1 X139.409 Y155.284 E.0167
G1 X138.694 Y155.84 E.02203
G1 X138.099 Y156.184 E.01672
G1 X137.517 Y156.437 E.01544
G1 X136.726 Y156.668 E.02004
G1 X136.125 Y156.755 E.01477
G1 X135.54 Y156.734 E.01424
G1 X134.686 Y156.617 E.02097
G1 X133.854 Y156.56 E.02029
G1 X96.877 Y156.566 E.89943
G1 X96.305 Y156.618 E.01397
G1 X95.498 Y156.732 E.01982
G1 X95.072 Y156.756 E.01038
G1 X94.569 Y156.724 E.01226
G1 X94.03 Y156.61 E.0134
G1 X93.484 Y156.438 E.01392
G1 X92.9 Y156.184 E.01549
G1 X92.417 Y155.911 E.0135
G1 X91.59 Y155.283 E.02526
G1 X91.112 Y154.792 E.01667
G1 X90.693 Y154.245 E.01676
G1 X90.343 Y153.654 E.01671
G1 X90.022 Y152.898 E.01998
G1 X89.864 Y152.368 E.01345
G1 X89.711 Y151.341 E.02526
G1 X89.7 Y85.889 E1.59205
G1 X89.725 Y85.353 E.01305
G1 X89.724 Y80.153 E.12648
G1 X89.751 Y79.577 E.01403
G1 X89.847 Y78.871 E.01733
G1 X90.029 Y78.181 E.01736
G1 X90.296 Y77.519 E.01736
G1 X90.643 Y76.894 E.01739
G1 X91.066 Y76.316 E.01742
G1 X91.557 Y75.794 E.01743
G1 X91.948 Y75.459 E.01252
G1 X92.526 Y75.061 E.01707
G1 X93.146 Y74.737 E.01702
G1 X93.799 Y74.491 E.01697
G1 X94.475 Y74.326 E.01693
G1 X95.322 Y74.227 E.02074
G1 X135.495 Y74.224 E.97717
G1 X136.031 Y74.249 E.01305
G1 X136.733 Y74.358 E.01728
G1 X137.751 Y74.682 E.02599
G1 X138.693 Y75.188 E.02601
G1 X139.044 Y75.45 E.01065
G1 X139.519 Y75.852 E.01514
G1 X139.998 Y76.378 E.0173
G1 X140.41 Y76.992 E.01799
G1 X140.746 Y77.585 E.01658
G1 X140.972 Y78.159 E.01501
G1 X141.177 Y78.94 E.01964
G1 X141.265 Y79.645 E.01728
G1 X141.274 Y84.934 E.12865
G1 X141.288 Y85.307 E.00908
G1 X141.288 Y85.307 F9000
G1 X140.925 Y85.397
;TYPE:Perimeter
G1 F6000
G1 X140.934 Y85.652 E.00621
G1 X140.934 Y92.727 E.17209
;WIDTH:0.441582
G1 X140.914 Y92.794 E.00189
;WIDTH:0.483164
G1 X140.893 Y92.861 E.0021
;WIDTH:0.524747
G1 X140.872 Y92.927 E.00226
;WIDTH:0.566329
G1 X140.851 Y92.994 E.00248
G1 X140.859 Y93.225 E.00818
;WIDTH:0.55128
G1 X140.859 Y95.604 E.08181
;WIDTH:0.573551
G1 X140.848 Y95.938 E.01199
G1 X140.869 Y96.063 E.00455
;WIDTH:0.530163
G1 X140.891 Y96.189 E.00422
;WIDTH:0.486775
G1 X140.913 Y96.315 E.00385
;WIDTH:0.443387
G1 X140.934 Y96.441 E.00348
;WIDTH:0.399999
G1 X140.934 Y101.89 E.13254
;WIDTH:0.404836
G1 X140.932 Y102.565 E.01664
;WIDTH:0.447651
G1 X140.911 Y102.631 E.0019
;WIDTH:0.490466
G1 X140.889 Y102.697 E.00211
;WIDTH:0.533281
G1 X140.868 Y102.763 E.0023
;WIDTH:0.576096
G1 X140.846 Y102.829 E.00251
G1 X140.857 Y103.096 E.00963
;WIDTH:0.555314
G1 X140.859 Y104.769 E.05798
;WIDTH:0.570462
G1 X140.849 Y105.126 E.01274
G1 X140.87 Y105.195 E.00257
;WIDTH:0.52786
G1 X140.892 Y105.264 E.00238
;WIDTH:0.485257
G1 X140.913 Y105.332 E.00213
;WIDTH:0.442654
G1 X140.934 Y105.401 E.00196
;WIDTH:0.400051
G1 X140.934 Y109.89 E.10921
;WIDTH:0.404837
G1 X140.932 Y110.565 E.01664
;WIDTH:0.447653
G1 X140.911 Y110.631 E.0019
;WIDTH:0.490468
G1 X140.889 Y110.697 E.00211
;WIDTH:0.533283
G1 X140.868 Y110.763 E.0023
;WIDTH:0.576098
G1 X140.846 Y110.829 E.00251
G1 X140.857 Y111.096 E.00963
;WIDTH:0.555314
G1 X140.859 Y112.769 E.05798
;WIDTH:0.570462
G1 X140.849 Y113.126 E.01274
G1 X140.87 Y113.195 E.00257
;WIDTH:0.52786
G1 X140.892 Y113.264 E.00238
;WIDTH:0.485257
G1 X140.913 Y113.332 E.00213
;WIDTH:0.442654
G1 X140.934 Y113.401 E.00196
;WIDTH:0.400051
G1 X140.934 Y117.89 E.10921
;WIDTH:0.404837
G1 X140.932 Y118.565 E.01664
;WIDTH:0.447653
G1 X140.911 Y118.631 E.0019
;WIDTH:0.490468
G1 X140.889 Y118.697 E.00211
;WIDTH:0.533283
G1 X140.868 Y118.763 E.0023
;WIDTH:0.576098
G1 X140.846 Y118.829 E.00251
G1 X140.857 Y119.096 E.00963
;WIDTH:0.555314
G1 X140.859 Y120.769 E.05798
;WIDTH:0.570462
G1 X140.849 Y121.126 E.01274
G1 X140.87 Y121.195 E.00257
;WIDTH:0.52786
G1 X140.892 Y121.264 E.00238
;WIDTH:0.485257
G1 X140.913 Y121.332 E.00213
;WIDTH:0.442654
G1 X140.934 Y121.401 E.00196
;WIDTH:0.400051
G1 X140.934 Y125.89 E.10921
;WIDTH:0.404837
G1 X140.932 Y126.565 E.01664
;WIDTH:0.447651
G1 X140.911 Y126.631 E.0019
;WIDTH:0.490464
G1 X140.889 Y126.697 E.00211
;WIDTH:0.533277
G1 X140.868 Y126.763 E.0023
;WIDTH:0.57609
G1 X140.846 Y126.829 E.00251
G1 X140.857 Y127.1 E.00977
;WIDTH:0.555304
G1 X140.857 Y128.899 E.06234
;WIDTH:0.56202
G1 X140.853 Y129.054 E.00544
G1 X140.874 Y129.132 E.00284
;WIDTH:0.521515
G1 X140.894 Y129.211 E.00264
;WIDTH:0.48101
G1 X140.914 Y129.289 E.00239
;WIDTH:0.440505
G1 X140.934 Y129.367 E.00218
;WIDTH:0.399999
G1 X140.934 Y133.89 E.11002
;WIDTH:0.404832
G1 X140.932 Y134.565 E.01664
;WIDTH:0.447646
G1 X140.911 Y134.631 E.0019
;WIDTH:0.49046
G1 X140.889 Y134.697 E.00211
;WIDTH:0.533274
G1 X140.868 Y134.763 E.0023
;WIDTH:0.576087
G1 X140.846 Y134.829 E.00251
G1 X140.857 Y135.415 E.02112
;WIDTH:0.555389
G1 X140.876 Y135.515 E.00353
;WIDTH:0.516542
G1 X140.895 Y135.615 E.00327
;WIDTH:0.477694
G1 X140.915 Y135.715 E.00301
;WIDTH:0.438847
G1 X140.934 Y135.815 E.00274
;WIDTH:0.399999
G1 X140.934 Y142.08 E.15239
;WIDTH:0.403419
G1 X140.933 Y142.638 E.0137
;WIDTH:0.443267
G1 X140.913 Y142.736 E.00272
;WIDTH:0.483115
G1 X140.893 Y142.833 E.00296
;WIDTH:0.522963
G1 X140.873 Y142.93 E.00322
;WIDTH:0.562811
G1 X140.853 Y143.028 E.00352
G1 X140.859 Y143.227 E.007
;WIDTH:0.555314
G1 X140.857 Y144.904 E.05812
G1 X140.882 Y145.081 E.00619
;WIDTH:0.505573
G1 X140.906 Y145.258 E.0056
;WIDTH:0.455832
G1 X140.931 Y145.435 E.00501
;WIDTH:0.406091
G1 X140.934 Y145.85 E.01026
;WIDTH:0.399999
G1 X140.934 Y150.788 E.12011
;WIDTH:0.439975
G1 X140.914 Y150.834 E.00135
;WIDTH:0.479951
G1 X140.894 Y150.88 E.00149
;WIDTH:0.519927
G1 X140.874 Y150.927 E.00165
;WIDTH:0.559903
G1 X140.854 Y150.973 E.00175
G1 X140.851 Y151.117 E.00504
;WIDTH:0.551495
G1 X140.824 Y151.65 E.01836
;WIDTH:0.536646
G1 X140.781 Y151.966 E.01066
;WIDTH:0.509479
G1 X140.737 Y152.282 E.01008
;WIDTH:0.482311
G1 X140.668 Y152.584 E.00923
;WIDTH:0.436109
G1 X140.6 Y152.887 E.0083
;WIDTH:0.439717
G1 X140.541 Y152.959 E.00251
;WIDTH:0.489528
G1 X140.483 Y153.031 E.0028
;WIDTH:0.539339
G1 X140.424 Y153.102 E.0031
;WIDTH:0.589149
G1 X140.365 Y153.174 E.00344
;WIDTH:0.63896
G1 X140.306 Y153.246 E.00374
G1 X140.296 Y153.164 E.00332
;WIDTH:0.589149
G1 X140.285 Y153.082 E.00305
;WIDTH:0.539339
G1 X140.274 Y152.999 E.00281
;WIDTH:0.489528
G1 X140.263 Y152.917 E.00251
;WIDTH:0.439717
G1 X140.252 Y152.835 E.00223
;WIDTH:0.436109
G1 X140.275 Y152.525 E.00831
;WIDTH:0.482311
G1 X140.299 Y152.216 E.00924
;WIDTH:0.509479
G1 X140.312 Y151.911 E.00965
;WIDTH:0.536646
G1 X140.326 Y151.606 E.0102
;WIDTH:0.559903
G1 X140.332 Y151.011 E.0208
G1 X140.305 Y150.986 E.00129
;WIDTH:0.519927
G1 X140.278 Y150.962 E.00117
;WIDTH:0.479951
G1 X140.252 Y150.937 E.00107
;WIDTH:0.439975
G1 X140.225 Y150.913 E.00097
;WIDTH:0.399999
G1 X140.112 Y150.604 E.008
G1 X139.985 Y150.404 E.00576
G1 X139.679 Y150.151 E.00966
G1 X139.291 Y150.032 E.00987
G1 X125.444 Y150.01 E.33681
G1 X125.156 Y150.091 E.00728
G1 X124.961 Y150.296 E.00688
G1 X124.894 Y150.558 E.00658
G1 X124.894 Y153.442 E.07015
G1 X124.916 Y153.596 E.00378
G1 X125.004 Y153.771 E.00476
G1 X125.185 Y153.926 E.0058
G1 X125.443 Y153.99 E.00647
G1 X139.202 Y153.976 E.33467
G1 X139.488 Y153.929 E.00705
;WIDTH:0.441753
G1 X139.581 Y153.895 E.00268
;WIDTH:0.483508
G1 X139.674 Y153.86 E.00297
;WIDTH:0.525262
G1 X139.767 Y153.826 E.00323
;WIDTH:0.567016
G1 X139.86 Y153.791 E.00352
;WIDTH:0.60877
G1 X139.953 Y153.757 E.00378
;WIDTH:0.650524
G1 X140.045 Y153.722 E.00403
G1 X140.024 Y153.8 E.00331
;WIDTH:0.603891
G1 X140.003 Y153.877 E.00302
;WIDTH:0.557257
G1 X139.982 Y153.954 E.00278
;WIDTH:0.510624
G1 X139.961 Y154.031 E.00253
;WIDTH:0.463991
G1 X139.94 Y154.108 E.00228
;WIDTH:0.417357
G1 X139.611 Y154.552 E.01408
;WIDTH:0.399999
G1 X139.164 Y155.011 E.01558
G1 X138.489 Y155.536 E.0208
G1 X137.934 Y155.857 E.0156
G1 X137.393 Y156.093 E.01436
G1 X136.648 Y156.31 E.01887
G1 X136.102 Y156.389 E.01342
G1 X135.59 Y156.372 E.01246
G1 X134.72 Y156.253 E.02136
G1 X133.854 Y156.195 E.02111
G1 X96.876 Y156.2 E.89945
G1 X96.254 Y156.256 E.01519
G1 X95.325 Y156.38 E.0228
G1 X94.623 Y156.362 E.01708
G1 X94.07 Y156.239 E.01378
G1 X93.56 Y156.072 E.01305
G1 X93.019 Y155.831 E.01441
G1 X92.569 Y155.568 E.01268
G1 X91.803 Y154.977 E.02353
G1 X91.376 Y154.535 E.01495
;WIDTH:0.417512
G1 X91.06 Y154.108 E.01354
;WIDTH:0.464137
G1 X91.039 Y154.031 E.00228
;WIDTH:0.510762
G1 X91.018 Y153.954 E.00253
;WIDTH:0.557387
G1 X90.997 Y153.877 E.00278
;WIDTH:0.604011
G1 X90.976 Y153.8 E.00302
;WIDTH:0.650636
G1 X90.955 Y153.723 E.00327
G1 X91.048 Y153.757 E.00406
;WIDTH:0.608863
G1 X91.141 Y153.791 E.00378
;WIDTH:0.567091
G1 X91.234 Y153.826 E.00352
;WIDTH:0.525318
G1 X91.326 Y153.86 E.0032
;WIDTH:0.483545
G1 X91.419 Y153.895 E.00297
;WIDTH:0.441772
G1 X91.512 Y153.929 E.00268
;WIDTH:0.399999
G1 X91.798 Y153.976 E.00705
G1 X105.557 Y153.99 E.33467
G1 X105.815 Y153.926 E.00647
G1 X105.996 Y153.771 E.0058
G1 X106.084 Y153.596 E.00476
G1 X106.106 Y153.442 E.00378
G1 X106.106 Y150.558 E.07015
G1 X106.039 Y150.296 E.00658
G1 X105.844 Y150.091 E.00688
G1 X105.557 Y150.01 E.00725
G1 X91.709 Y150.032 E.33684
G1 X91.321 Y150.151 E.00987
G1 X91.117 Y150.305 E.00622
;WIDTH:0.44163
G1 X91.008 Y150.461 E.00516
;WIDTH:0.483261
G1 X90.899 Y150.618 E.00571
;WIDTH:0.524892
G1 X90.791 Y150.775 E.00622
;WIDTH:0.566522
G1 X90.682 Y150.931 E.00674
G1 X90.666 Y151.291 E.01276
;WIDTH:0.549591
G1 X90.682 Y151.762 E.01615
;WIDTH:0.513486
G1 X90.698 Y152.233 E.01502
;WIDTH:0.47738
G1 X90.696 Y152.77 E.01583
;WIDTH:0.517367
G1 X90.702 Y152.903 E.00428
;WIDTH:0.557354
G1 X90.708 Y153.036 E.00463
;WIDTH:0.597341
G1 X90.714 Y153.168 E.00495
;WIDTH:0.637328
G1 X90.72 Y153.301 E.00534
G1 X90.663 Y153.219 E.00401
;WIDTH:0.598273
G1 X90.607 Y153.137 E.00372
;WIDTH:0.559217
G1 X90.551 Y153.055 E.00347
;WIDTH:0.520162
G1 X90.495 Y152.974 E.00318
;WIDTH:0.481106
G1 X90.4 Y152.753 E.00715
;WIDTH:0.47738
G1 X90.257 Y152.265 E.01499
;WIDTH:0.513486
G1 X90.206 Y151.796 E.01504
;WIDTH:0.549591
G1 X90.154 Y151.328 E.01614
;WIDTH:0.566522
G1 X90.159 Y150.86 E.01657
G1 X90.139 Y150.803 E.00214
;WIDTH:0.524892
G1 X90.118 Y150.747 E.00195
;WIDTH:0.483261
G1 X90.097 Y150.691 E.00179
;WIDTH:0.44163
G1 X90.076 Y150.634 E.00165
;WIDTH:0.399999
G1 X90.075 Y146.303 E.10535
;WIDTH:0.410132
G1 X90.08 Y145.48 E.02057
;WIDTH:0.449801
G1 X90.1 Y145.402 E.00223
;WIDTH:0.489469
G1 X90.12 Y145.324 E.00244
;WIDTH:0.529137
G1 X90.14 Y145.246 E.00265
;WIDTH:0.568805
G1 X90.16 Y145.168 E.00286
G1 X90.149 Y144.773 E.01405
;WIDTH:0.550687
G1 X90.15 Y143.097 E.05757
;WIDTH:0.567178
G1 X90.158 Y142.86 E.00841
G1 X90.138 Y142.803 E.00214
;WIDTH:0.525384
G1 X90.117 Y142.747 E.00195
;WIDTH:0.483589
G1 X90.096 Y142.69 E.00182
;WIDTH:0.441794
G1 X90.075 Y142.634 E.00162
;WIDTH:0.399999
G1 X90.074 Y137.369 E.12807
;WIDTH:0.437601
G1 X90.093 Y137.296 E.00202
;WIDTH:0.475203
G1 X90.112 Y137.222 E.00224
;WIDTH:0.512804
G1 X90.13 Y137.148 E.00242
;WIDTH:0.551675
G1 X90.15 Y136.905 E.00839
G1 X90.149 Y135.101 E.06208
;WIDTH:0.572034
G1 X90.16 Y134.83 E.0097
G1 X90.138 Y134.764 E.00249
;WIDTH:0.529664
G1 X90.117 Y134.698 E.00228
;WIDTH:0.487293
G1 X90.096 Y134.632 E.00209
;WIDTH:0.444923
G1 X90.075 Y134.566 E.00189
;WIDTH:0.402552
G1 X90.073 Y134.153 E.01012
;WIDTH:0.399999
G1 X90.073 Y129.4 E.11561
;WIDTH:0.442524
G1 X90.094 Y129.342 E.00167
;WIDTH:0.485049
G1 X90.115 Y129.284 E.00185
;WIDTH:0.527574
G1 X90.136 Y129.226 E.00202
;WIDTH:0.570099
G1 X90.158 Y129.168 E.00221
G1 X90.147 Y128.773 E.01408
;WIDTH:0.551973
G1 X90.148 Y127.096 E.05774
;WIDTH:0.572702
G1 X90.159 Y126.83 E.00953
G1 X90.137 Y126.764 E.00249
;WIDTH:0.530259
G1 X90.116 Y126.698 E.00228
;WIDTH:0.487816
G1 X90.095 Y126.632 E.00209
;WIDTH:0.445373
G1 X90.074 Y126.566 E.00189
;WIDTH:0.40293
G1 X90.072 Y126.152 E.01015
;WIDTH:0.399999
G1 X90.072 Y122.108 E.09837
;WIDTH:0.406196
G1 X90.075 Y121.434 E.01667
;WIDTH:0.454955
G1 X90.099 Y121.257 E.005
;WIDTH:0.503713
G1 X90.123 Y121.08 E.00558
;WIDTH:0.552471
G1 X90.148 Y120.904 E.00613
G1 X90.145 Y119.231 E.05766
;WIDTH:0.567771
G1 X90.155 Y118.874 E.01267
G1 X90.134 Y118.806 E.00253
;WIDTH:0.525828
G1 X90.113 Y118.737 E.00236
;WIDTH:0.483885
G1 X90.092 Y118.669 E.00213
;WIDTH:0.441942
G1 X90.071 Y118.6 E.00196
;WIDTH:0.399999
G1 X90.07 Y114.108 E.10926
;WIDTH:0.406187
G1 X90.073 Y113.434 E.01667
;WIDTH:0.455163
G1 X90.098 Y113.257 E.005
;WIDTH:0.504138
G1 X90.122 Y113.081 E.00555
;WIDTH:0.553113
G1 X90.147 Y112.904 E.00617
G1 X90.145 Y111.231 E.05773
;WIDTH:0.568416
G1 X90.154 Y110.874 E.01269
G1 X90.133 Y110.805 E.00256
;WIDTH:0.526312
G1 X90.112 Y110.737 E.00233
;WIDTH:0.484208
G1 X90.091 Y110.668 E.00216
;WIDTH:0.442104
G1 X90.07 Y110.6 E.00193
;WIDTH:0.399999
G1 X90.069 Y106.109 E.10924
;WIDTH:0.406178
G1 X90.072 Y105.435 E.01667
;WIDTH:0.455371
G1 X90.097 Y105.258 E.00501
;WIDTH:0.504564
G1 X90.121 Y105.081 E.00559
;WIDTH:0.553756
G1 X90.146 Y104.904 E.00618
G1 X90.144 Y103.231 E.05781
;WIDTH:0.569061
G1 X90.153 Y102.874 E.0127
G1 X90.132 Y102.805 E.00257
;WIDTH:0.526796
G1 X90.111 Y102.737 E.00233
;WIDTH:0.48453
G1 X90.09 Y102.668 E.00216
;WIDTH:0.442265
G1 X90.068 Y102.6 E.00194
;WIDTH:0.399999
G1 X90.067 Y96.347 E.1521
;WIDTH:0.443144
G1 X90.089 Y96.245 E.00284
;WIDTH:0.486289
G1 X90.111 Y96.143 E.00314
;WIDTH:0.529434
G1 X90.132 Y96.04 E.00346
;WIDTH:0.572578
G1 X90.154 Y95.938 E.00374
G1 X90.143 Y95.604 E.01197
;WIDTH:0.554697
G1 X90.144 Y93.132 E.08557
G1 X90.125 Y93.01 E.00427
;WIDTH:0.516023
G1 X90.106 Y92.887 E.00399
;WIDTH:0.477348
G1 X90.086 Y92.765 E.00364
;WIDTH:0.438674
G1 X90.067 Y92.643 E.00332
;WIDTH:0.399999
G1 X90.066 Y85.889 E.16428
G1 X90.091 Y85.353 E.01305
G1 X90.09 Y80.153 E.12648
G1 X90.116 Y79.6 E.01347
G1 X90.206 Y78.938 E.01625
G1 X90.378 Y78.292 E.01626
G1 X90.628 Y77.672 E.01626
G1 X90.868 Y77.225 E.01234
G1 X91.241 Y76.681 E.01604
G1 X91.677 Y76.187 E.01603
G1 X92.169 Y75.75 E.01601
G1 X92.709 Y75.378 E.01595
G1 X93.288 Y75.074 E.01591
G1 X93.899 Y74.842 E.0159
G1 X94.531 Y74.687 E.01583
G1 X95.333 Y74.593 E.01964
G1 X99.528 Y74.592 E.10204
;WIDTH:0.439059
G1 X99.746 Y74.612 E.00589
;WIDTH:0.478119
G1 X99.964 Y74.631 E.00646
;WIDTH:0.517179
G1 X100.183 Y74.651 E.00706
;WIDTH:0.518256
G1 X130.817 Y74.649 E.98612
G1 X131.036 Y74.63 E.00708
;WIDTH:0.478837
G1 X131.254 Y74.61 E.00647
;WIDTH:0.439418
G1 X131.473 Y74.59 E.00593
;WIDTH:0.399999
G1 X135.487 Y74.59 E.09764
G1 X135.995 Y74.613 E.01237
G1 X136.649 Y74.715 E.0161
G1 X137.608 Y75.02 E.02448
G1 X138.25 Y75.365 E.01773
G1 X138.825 Y75.743 E.01674
G1 X139.262 Y76.113 E.01393
G1 X139.71 Y76.604 E.01617
G1 X140.107 Y77.196 E.01734
G1 X140.413 Y77.736 E.0151
G1 X140.624 Y78.272 E.01401
G1 X140.817 Y79.009 E.01853
G1 X140.899 Y79.668 E.01615
G1 X140.908 Y84.935 E.12811
G1 X140.923 Y85.337 E.00979
G1 E-5 F3600
G1 X140.926 Y85.337 F9000
G1 X126.349 Y88.151
G1 X104.651 Y88.151
G1 X91.44 Y92.236
G1 X91.274 Y92.314
G1 X91.124 Y92.419
G1 X90.995 Y92.549
G1 X90.89 Y92.699
G1 X90.813 Y92.865
G1 X90.765 Y93.042
G1 X90.751 Y93.202
G1 X90.751 Y112.786
G1 X90.753 Y112.817
G1 X90.762 Y112.964
G1 X90.77 Y113.007
G1 X90.801 Y113.156
G1 X90.864 Y113.334
G1 X90.906 Y113.412
G1 X90.967 Y113.515
G1 X91.089 Y113.661
G1 X91.238 Y113.786
G1 X91.41 Y113.881
G1 X91.59 Y113.939
G1 X91.687 Y113.953
G1 X91.782 Y113.959
G1 X93.473 Y113.961
G1 X93.569 Y113.961
G1 X93.569 Y114.343
G1 E5 F2400
G1 F6000
G1 X93.569 Y117.659 E.08066
G1 X91.706 Y117.666 E.04532
G1 X91.345 Y117.742 E.00897
G1 X90.893 Y118.008 E.01276
G1 X90.57 Y118.414 E.01262
G1 X90.437 Y118.767 E.00918
G1 X90.436 Y113.848 E.11965
;WIDTH:0.406187
G1 X90.445 Y113.29 E.0138
G1 X90.683 Y113.755 E.01292
;WIDTH:0.399999
G1 X90.854 Y113.95 E.00631
G1 X91.266 Y114.218 E.01196
G1 X91.798 Y114.342 E.01329
G1 X93.509 Y114.343 E.04162
G1 X93.509 Y114.343 F9000
G1 X93.19 Y114.709
G1 F6000
G1 X93.203 Y114.709 E.00032
G1 X93.203 Y117.295 E.0629
G1 X91.705 Y117.3 E.03644
G1 X91.199 Y117.407 E.01258
G1 X90.802 Y117.636 E.01115
G1 X90.802 Y114.336 E.08027
G1 X91.156 Y114.567 E.01028
G1 X91.798 Y114.708 E.01599
G1 X93.13 Y114.709 E.0324
G1 X93.13 Y114.709 F9000
G1 X92.806 Y115.074
G1 F6000
G1 X92.837 Y115.074 E.00075
G1 X92.837 Y116.931 E.04517
G1 X91.703 Y116.935 E.02758
G1 X91.168 Y117.047 E.0133
G1 X91.167 Y114.954 E.05091
G1 X91.798 Y115.073 E.01562
G1 X92.746 Y115.074 E.02306
G1 E-5 F3600
G1 X90.864 Y118.666 F9000
G1 X90.801 Y118.844
G1 X90.77 Y118.993
G1 X90.762 Y119.036
G1 X90.753 Y119.183
G1 X90.751 Y119.214
G1 X90.751 Y120.786
G1 X90.753 Y120.817
G1 X90.762 Y120.964
G1 X90.77 Y121.007
G1 X90.801 Y121.156
G1 X90.864 Y121.334
G1 X90.906 Y121.412
G1 X90.967 Y121.515
G1 X91.089 Y121.661
G1 X91.238 Y121.786
G1 X91.41 Y121.881
G1 X91.59 Y121.939
G1 X91.687 Y121.953
G1 X91.782 Y121.959
G1 X93.473 Y121.961
G1 X93.569 Y121.961
G1 X93.569 Y122.343
G1 E5 F2400
G1 F6000
G1 X93.569 Y125.657 E.08061
G1 X91.798 Y125.658 E.04308
G1 X91.266 Y125.782 E.01329
G1 X90.854 Y126.05 E.01196
G1 X90.683 Y126.245 E.00631
;WIDTH:0.40293
G1 X90.493 Y126.574 E.00932
G1 X90.442 Y126.735 E.00414
G1 X90.438 Y126.152 E.01429
;WIDTH:0.399999
G1 X90.437 Y121.848 E.10469
;WIDTH:0.406196
G1 X90.446 Y121.294 E.01371
G1 X90.683 Y121.755 E.01282
;WIDTH:0.399999
G1 X90.854 Y121.95 E.00631
G1 X91.266 Y122.218 E.01196
G1 X91.798 Y122.342 E.01329
G1 X93.509 Y122.343 E.04162
G1 X93.509 Y122.343 F9000
G1 X92.86 Y122.708
G1 F6000
G1 X93.203 Y122.709 E.00834
G1 X93.203 Y125.291 E.0628
G1 X91.798 Y125.292 E.03418
G1 X91.156 Y125.433 E.01599
G1 X90.803 Y125.663 E.01025
G1 X90.803 Y122.337 E.0809
G1 X91.156 Y122.567 E.01025
G1 X91.798 Y122.708 E.01599
G1 X92.8 Y122.708 E.02437
G1 X92.8 Y122.708 F9000
G1 X92.409 Y123.074
G1 F6000
G1 X92.837 Y123.074 E.01041
G1 X92.837 Y124.926 E.04505
G1 X91.798 Y124.927 E.02527
G1 X91.169 Y125.046 E.01557
G1 X91.169 Y122.954 E.05089
G1 X91.798 Y123.073 E.01557
G1 X92.349 Y123.074 E.0134
G1 E-5 F3600
G1 X92.349 Y123.074 F9000
G1 X90.864 Y126.666
G1 X90.801 Y126.844
G1 X90.77 Y126.993
G1 X90.762 Y127.036
G1 X90.753 Y127.183
G1 X90.751 Y127.214
G1 X90.751 Y128.786
G1 X90.842 Y134.727
G1 X90.801 Y134.844
G1 X90.443 Y134.735
G1 E5 F2400
;WIDTH:0.402552
G1 F6000
G1 X90.439 Y134.153 E.01426
;WIDTH:0.399999
G1 X90.438 Y129.252 E.11921
G1 X90.57 Y129.586 E.00874
G1 X90.893 Y129.992 E.01262
G1 X91.345 Y130.258 E.01276
G1 X91.707 Y130.334 E.009
G1 X93.571 Y130.34 E.04534
G1 X93.581 Y133.091 E.06692
G1 X93.631 Y133.657 E.01382
G1 X91.799 Y133.658 E.04456
G1 X91.266 Y133.782 E.01331
G1 X90.854 Y134.05 E.01196
G1 X90.683 Y134.245 E.00631
;WIDTH:0.402552
G1 X90.493 Y134.574 E.00931
G1 X90.461 Y134.677 E.00264
G1 X90.461 Y134.677 F9000
G1 X90.805 Y133.662
;WIDTH:0.399999
G1 F6000
G1 X90.804 Y130.366 E.08017
G1 X91.199 Y130.593 E.01108
G1 X91.706 Y130.7 E.0126
G1 X93.206 Y130.704 E.03649
G1 X93.232 Y133.292 E.06295
G1 X91.798 Y133.292 E.03488
G1 X91.156 Y133.433 E.01599
G1 X90.855 Y133.629 E.00874
G1 X90.855 Y133.629 F9000
G1 X91.17 Y133.045
G1 F6000
G1 X91.17 Y130.953 E.05089
G1 X91.704 Y131.065 E.01327
G1 X92.841 Y131.069 E.02766
G1 X92.846 Y132.926 E.04517
G1 X91.798 Y132.927 E.02549
G1 X91.229 Y133.034 E.01408
G1 E-5 F3600
G1 X91.229 Y133.034 F9000
G1 X90.497 Y142.623
G1 E5 F2400
G1 F6000
G1 X90.441 Y142.745 E.00327
G1 X90.44 Y137.253 E.13359
G1 X90.599 Y137.637 E.01011
G1 X90.947 Y138.037 E.0129
G1 X91.381 Y138.273 E.01202
G1 X91.74 Y138.338 E.00887
G1 X95.208 Y138.343 E.08436
G1 X95.397 Y138.652 E.00881
G1 X95.801 Y139.222 E.01699
G1 X96.297 Y139.847 E.01941
G1 X96.85 Y140.442 E.01976
G1 X97.427 Y140.965 E.01894
G1 X98.329 Y141.649 E.02754
G1 X91.707 Y141.666 E.16107
G1 X91.345 Y141.742 E.009
G1 X91.176 Y141.816 E.00449
G1 X90.835 Y142.072 E.01037
G1 X90.646 Y142.301 E.00722
G1 X90.522 Y142.569 E.00718
G1 X90.806 Y141.649 F9000
G1 F6000
G1 X90.805 Y138.383 E.07944
G1 X91.285 Y138.626 E.01309
G1 X91.74 Y138.704 E.01123
G1 X95.001 Y138.709 E.07932
G1 X95.513 Y139.448 E.02187
G1 X96.028 Y140.095 E.02011
G1 X96.603 Y140.711 E.0205
G1 X97.244 Y141.286 E.02095
G1 X91.706 Y141.3 E.13471
G1 X91.199 Y141.407 E.0126
G1 X91.03 Y141.48 E.00448
G1 X90.854 Y141.613 E.00537
G1 X90.854 Y141.613 F9000
G1 X91.172 Y141.047
G1 F6000
G1 X91.171 Y138.971 E.0505
G1 X91.739 Y139.07 E.01402
G1 X94.8 Y139.074 E.07446
G1 X95.226 Y139.674 E.0179
G1 X95.759 Y140.343 E.02081
G1 X96.298 Y140.923 E.01926
G1 X91.705 Y140.935 E.11172
G1 X91.23 Y141.034 E.0118
G1 E-5 F3600
G1 X91.23 Y141.034 F9000
G1 X90.801 Y142.844
G1 X90.77 Y142.993
G1 X90.762 Y143.036
G1 X90.753 Y143.183
G1 X90.751 Y143.214
G1 X90.751 Y144.786
G1 X90.753 Y144.817
G1 X90.762 Y144.964
G1 X90.77 Y145.007
G1 X90.801 Y145.156
G1 X90.864 Y145.334
G1 X90.906 Y145.412
G1 X90.967 Y145.515
G1 X91.089 Y145.661
G1 X91.238 Y145.786
G1 X91.41 Y145.881
G1 X91.59 Y145.939
G1 X91.687 Y145.953
G1 X91.782 Y145.959
G1 X97.143 Y145.974
G1 X98.475 Y145.974
G1 X98.568 Y145.974
G1 X98.568 Y146.349
G1 E5 F2400
G1 F6000
G1 X105.555 Y146.356 E.16995
G1 X105.825 Y146.316 E.00664
G1 X106.035 Y146.221 E.00561
G1 X106.266 Y146.019 E.00746
G1 X106.433 Y145.703 E.00869
G1 X106.471 Y145.443 E.00639
G1 X106.475 Y143.556 E.0459
G1 X110.656 Y143.544 E.1017
G1 X110.708 Y143.483 E.00195
G1 X120.292 Y143.483 E.23312
G1 X120.344 Y143.544 E.00195
G1 X120.482 Y143.555 E.00337
G1 X124.525 Y143.558 E.09834
G1 X124.529 Y145.443 E.04585
G1 X124.567 Y145.703 E.00639
G1 X124.64 Y145.878 E.00461
G1 X124.824 Y146.115 E.0073
G1 X125.175 Y146.316 E.00984
G1 X125.444 Y146.356 E.00662
G1 X139.202 Y146.342 E.33465
G1 X139.734 Y146.218 E.01329
G1 X140.146 Y145.95 E.01196
G1 X140.317 Y145.755 E.00631
;WIDTH:0.406091
G1 X140.512 Y145.428 E.00942
G1 X140.56 Y145.275 E.00397
G1 X140.569 Y145.85 E.01422
;WIDTH:0.399999
G1 X140.569 Y150.788 E.12011
G1 X140.456 Y150.478 E.00803
G1 X140.244 Y150.146 E.00958
G1 X140.107 Y150.008 E.00473
G1 X139.655 Y149.742 E.01276
G1 X139.292 Y149.666 E.00902
G1 X125.444 Y149.644 E.33684
G1 X125.175 Y149.684 E.00662
G1 X124.965 Y149.779 E.00561
G1 X124.734 Y149.981 E.00746
G1 X124.591 Y150.227 E.00692
G1 X124.529 Y150.558 E.00819
G1 X124.529 Y153.442 E.07015
G1 X124.565 Y153.698 E.00629
G1 X124.712 Y153.991 E.00797
G1 X125.013 Y154.249 E.00964
G1 X125.443 Y154.356 E.01078
G1 X139.314 Y154.333 E.3374
G1 X138.92 Y154.738 E.01374
G1 X138.285 Y155.232 E.01957
G1 X137.769 Y155.53 E.01449
G1 X137.268 Y155.748 E.01329
G1 X136.626 Y155.936 E.01627
G1 X136.145 Y156.013 E.01185
G1 X135.64 Y156.01 E.01228
G1 X134.753 Y155.889 E.02178
G1 X133.854 Y155.829 E.02192
G1 X96.876 Y155.835 E.89945
G1 X96.203 Y155.894 E.01643
G1 X95.396 Y156.008 E.01982
G1 X94.938 Y156.023 E.01115
G1 X94.254 Y155.91 E.01686
G1 X93.741 Y155.752 E.01306
G1 X93.255 Y155.541 E.01289
G1 X92.819 Y155.299 E.01213
G1 X92.076 Y154.734 E.0227
G1 X91.686 Y154.333 E.01361
G1 X105.557 Y154.356 E.3374
G1 X105.987 Y154.249 E.01078
G1 X106.288 Y153.991 E.00964
G1 X106.435 Y153.698 E.00797
G1 X106.471 Y153.442 E.00629
G1 X106.471 Y150.558 E.07015
G1 X106.464 Y150.442 E.00283
G1 X106.38 Y150.159 E.00718
G1 X106.176 Y149.885 E.00831
G1 X105.825 Y149.684 E.00984
G1 X105.556 Y149.644 E.00662
G1 X91.708 Y149.666 E.33684
G1 X91.345 Y149.742 E.00902
G1 X91.176 Y149.816 E.00449
G1 X90.835 Y150.072 E.01037
G1 X90.646 Y150.301 E.00722
G1 X90.442 Y150.741 E.0118
G1 X90.441 Y146.303 E.10795
;WIDTH:0.410132
G1 X90.456 Y145.335 E.0242
G1 X90.67 Y145.733 E.0113
;WIDTH:0.399999
G1 X90.948 Y146.037 E.01002
G1 X91.439 Y146.287 E.0134
G1 X91.797 Y146.342 E.00881
G1 X98.508 Y146.349 E.16324
G1 E-5 F3600
G1 X98.508 Y146.349 F9000
G1 X98.508 Y145.974
G1 X100.4 Y145.976
G1 X103.35 Y145.976
G1 X106.089 Y145.974
G1 X106.84 Y143.921
G1 E5 F2400
G1 F6000
G1 X110.712 Y143.906 E.09418
G1 X110.76 Y143.849 E.00181
G1 X120.24 Y143.849 E.23059
G1 X120.288 Y143.906 E.00181
G1 X120.482 Y143.921 E.00473
G1 X124.16 Y143.923 E.08946
G1 X124.163 Y145.444 E.037
G1 X124.216 Y145.807 E.00892
G1 X124.318 Y146.053 E.00648
G1 X124.451 Y146.25 E.00578
G1 X124.774 Y146.533 E.01045
G1 X125.068 Y146.666 E.00785
G1 X125.444 Y146.722 E.00925
G1 X139.202 Y146.708 E.33465
G1 X139.844 Y146.567 E.01599
G1 X140.203 Y146.333 E.01042
G1 X140.203 Y149.639 E.08042
G1 X139.801 Y149.407 E.01129
G1 X139.292 Y149.3 E.01265
G1 X125.445 Y149.278 E.33681
G1 X125.068 Y149.334 E.00927
G1 X124.774 Y149.467 E.00785
G1 X124.451 Y149.75 E.01045
G1 X124.25 Y150.095 E.00971
G1 X124.163 Y150.558 E.01146
G1 X124.163 Y153.442 E.07015
G1 X124.214 Y153.8 E.0088
G1 X124.419 Y154.21 E.01115
G1 X124.841 Y154.572 E.01352
G1 X125.443 Y154.722 E.01509
G1 X138.362 Y154.708 E.31424
G1 X138.08 Y154.928 E.0087
G1 X137.604 Y155.203 E.01337
G1 X137.143 Y155.404 E.01223
G1 X136.523 Y155.585 E.01571
G1 X136.093 Y155.651 E.01058
G1 X135.69 Y155.647 E.0098
G1 X134.786 Y155.525 E.02219
G1 X133.854 Y155.463 E.02272
G1 X96.876 Y155.469 E.89945
G1 X96.152 Y155.532 E.01768
G1 X95.345 Y155.645 E.01982
G1 X94.97 Y155.658 E.00913
G1 X94.33 Y155.552 E.01578
G1 X93.852 Y155.402 E.01219
G1 X93.03 Y154.998 E.02228
G1 X92.647 Y154.708 E.01169
G1 X105.556 Y154.722 E.314
G1 X105.779 Y154.702 E.00545
G1 X106.159 Y154.572 E.00977
G1 X106.581 Y154.21 E.01352
G1 X106.786 Y153.8 E.01115
G1 X106.837 Y153.442 E.0088
G1 X106.837 Y150.558 E.07015
G1 X106.75 Y150.094 E.01148
G1 X106.549 Y149.75 E.00969
G1 X106.226 Y149.467 E.01045
G1 X105.932 Y149.334 E.00785
G1 X105.556 Y149.278 E.00925
G1 X91.708 Y149.3 E.33684
G1 X91.199 Y149.407 E.01265
G1 X91.03 Y149.48 E.00448
G1 X90.807 Y149.648 E.00679
G1 X90.807 Y146.384 E.07939
G1 X90.895 Y146.445 E.0026
G1 X91.366 Y146.646 E.01246
G1 X91.797 Y146.708 E.01059
G1 X105.554 Y146.722 E.33463
G1 X105.932 Y146.666 E.00929
G1 X106.226 Y146.533 E.00785
G1 X106.424 Y146.384 E.00603
G1 X106.629 Y146.141 E.00773
G1 X106.784 Y145.807 E.00896
G1 X106.837 Y145.444 E.00892
G1 X106.84 Y143.981 E.03559
G1 X106.84 Y143.981 F9000
G1 X107.205 Y144.287
G1 F6000
G1 X110.266 Y144.286 E.07446
G1 X110.767 Y144.267 E.0122
G1 X110.812 Y144.215 E.00167
G1 X120.188 Y144.215 E.22806
G1 X120.233 Y144.267 E.00167
G1 X120.482 Y144.286 E.00607
G1 X123.795 Y144.288 E.08059
G1 X123.797 Y145.445 E.02814
G1 X123.866 Y145.912 E.01148
G1 X123.997 Y146.227 E.0083
G1 X124.167 Y146.481 E.00743
G1 X124.583 Y146.845 E.01345
G1 X124.961 Y147.015 E.01008
G1 X125.445 Y147.087 E.0119
G1 X139.202 Y147.073 E.33463
G1 X139.837 Y146.952 E.01572
G1 X139.837 Y149.049 E.05101
G1 X139.293 Y148.935 E.01352
G1 X125.445 Y148.913 E.33684
G1 X124.961 Y148.985 E.0119
G1 X124.583 Y149.155 E.01008
G1 X124.329 Y149.347 E.00774
G1 X124.064 Y149.66 E.00998
G1 X123.87 Y150.073 E.0111
G1 X123.797 Y150.558 E.01193
G1 X123.797 Y153.442 E.07015
G1 X123.863 Y153.903 E.01133
G1 X124.127 Y154.43 E.01434
G1 X124.669 Y154.894 E.01735
;WIDTH:0.411708
G1 X125.443 Y155.093 E.02006
G1 X124.618 Y155.099 E.02071
;WIDTH:0.399999
G1 X106.382 Y155.102 E.44357
;WIDTH:0.439852
G1 X105.845 Y155.082 E.0145
G1 X106.33 Y154.894 E.01403
;WIDTH:0.399999
G1 X106.873 Y154.43 E.01737
G1 X107.137 Y153.903 E.01434
G1 X107.203 Y153.442 E.01133
G1 X107.189 Y150.349 E.07523
G1 X107.091 Y149.962 E.00971
G1 X106.833 Y149.519 E.01247
G1 X106.417 Y149.155 E.01345
G1 X106.039 Y148.985 E.01008
G1 X105.556 Y148.913 E.01188
G1 X91.707 Y148.935 E.33686
G1 X91.173 Y149.046 E.01327
G1 X91.173 Y146.953 E.05091
G1 X91.293 Y147.004 E.00317
G1 X91.797 Y147.073 E.01237
G1 X105.554 Y147.087 E.33463
G1 X106.039 Y147.015 E.01193
G1 X106.417 Y146.845 E.01008
G1 X106.671 Y146.653 E.00774
G1 X106.936 Y146.34 E.00998
G1 X107.134 Y145.912 E.01147
G1 X107.203 Y145.445 E.01148
G1 X107.205 Y144.347 E.02671
G1 E-5 F3600
G1 X107.205 Y144.347 F9000
G1 E5 F2400
;WIDTH:0.439852
G1 F6000
G1 X105.556 Y155.095 E.0078
;WIDTH:0.425084
G1 X96.876 Y155.091 E.22562
;WIDTH:0.45397
G1 X96.526 Y155.105 E.00978
;WIDTH:0.482856
G1 X96.177 Y155.119 E.01042
;WIDTH:0.524433
G1 X95.877 Y155.14 E.0098
;WIDTH:0.56601
G1 X95.578 Y155.16 E.0106
;WIDTH:0.607586
G1 X95.279 Y155.181 E.01143
G1 X94.8 Y155.176 E.01827
G1 E-5 F3600
G1 X94.8 Y155.176 F9000
G1 X136.398 Y155.156
G1 E5 F2400
;WIDTH:0.609342
G1 F6000
G1 X135.754 Y155.181 E.02465
G1 X135.469 Y155.162 E.01093
;WIDTH:0.570117
G1 X135.185 Y155.143 E.01014
;WIDTH:0.530892
G1 X134.9 Y155.123 E.00944
;WIDTH:0.491666
G1 X134.588 Y155.109 E.0095
;WIDTH:0.461922
G1 X134.275 Y155.094 E.00891
;WIDTH:0.432178
G1 X133.854 Y155.088 E.01114
;WIDTH:0.419052
G1 X125.444 Y155.093 E.21522
;WIDTH:0.411708
G1 X125.443 Y155.093 E.00003
G1 E-5 F3600
G1 X125.443 Y155.093 F9000
G1 X90.955 Y153.723
G1 E5 F2400
;WIDTH:0.650636
G1 F6000
G1 X90.72 Y153.301 E.0198
G1 E-5 F3600
G1 X90.72 Y153.301 F9000
G1 X90.839 Y153.254
G1 X90.829 Y153.229
G1 X90.801 Y153.155
G1 X90.785 Y153.082
G1 X90.77 Y153.007
G1 X90.762 Y152.964
G1 X90.753 Y152.817
G1 X90.751 Y152.786
G1 X90.751 Y111.214
G1 X90.753 Y111.183
G1 X90.762 Y111.036
G1 X90.77 Y110.993
G1 X90.801 Y110.844
G1 X90.864 Y110.666
G1 X90.906 Y110.588
G1 X90.967 Y110.485
G1 X91.089 Y110.339
G1 X91.238 Y110.214
G1 X91.41 Y110.119
G1 X91.59 Y110.061
G1 X91.687 Y110.047
G1 X91.782 Y110.041
G1 X93.473 Y110.039
G1 X93.569 Y110.039
G1 X93.569 Y109.659
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X91.706 Y109.666 E.04532
G1 X91.345 Y109.742 E.00897
G1 X90.893 Y110.008 E.01276
G1 X90.57 Y110.414 E.01262
G1 X90.435 Y110.771 E.00928
G1 X90.435 Y105.849 E.11972
;WIDTH:0.406178
G1 X90.444 Y105.286 E.01393
G1 X90.683 Y105.755 E.01302
;WIDTH:0.399999
G1 X90.854 Y105.95 E.00631
G1 X91.266 Y106.218 E.01196
G1 X91.798 Y106.342 E.01329
G1 X93.569 Y106.343 E.04308
G1 X93.569 Y109.599 E.0792
G1 X93.569 Y109.599 F9000
G1 X93.203 Y109.237
G1 F6000
G1 X93.203 Y109.295 E.00141
G1 X91.705 Y109.3 E.03644
G1 X91.199 Y109.407 E.01258
G1 X90.801 Y109.636 E.01117
G1 X90.8 Y106.335 E.08029
G1 X91.156 Y106.567 E.01034
G1 X91.798 Y106.708 E.01599
G1 X93.203 Y106.709 E.03418
G1 X93.203 Y109.177 E.06003
G1 X93.203 Y109.177 F9000
G1 X92.837 Y107.815
G1 F6000
G1 X92.837 Y108.931 E.02715
G1 X91.703 Y108.935 E.02758
G1 X91.166 Y109.048 E.01335
G1 X91.166 Y106.953 E.05096
G1 X91.798 Y107.073 E.01565
G1 X92.837 Y107.074 E.02527
G1 X92.837 Y107.755 E.01656
G1 E-5 F3600
G1 X92.837 Y107.755 F9000
G1 X90.967 Y105.515
G1 X90.906 Y105.412
G1 X90.864 Y105.334
G1 X90.801 Y105.156
G1 X90.77 Y105.007
G1 X90.762 Y104.964
G1 X90.753 Y104.817
G1 X90.751 Y104.786
G1 X90.751 Y103.214
G1 X90.753 Y103.183
G1 X90.762 Y103.036
G1 X90.77 Y102.993
G1 X90.801 Y102.844
G1 X90.864 Y102.666
G1 X90.906 Y102.588
G1 X90.967 Y102.485
G1 X91.089 Y102.339
G1 X91.238 Y102.214
G1 X91.41 Y102.119
G1 X91.59 Y102.061
G1 X91.687 Y102.047
G1 X91.782 Y102.041
G1 X93.473 Y102.039
G1 X93.569 Y102.039
G1 X93.569 Y101.659
G1 E5 F2400
G1 F6000
G1 X91.706 Y101.666 E.04532
G1 X91.345 Y101.742 E.00897
G1 X90.893 Y102.008 E.01276
G1 X90.57 Y102.414 E.01262
G1 X90.434 Y102.776 E.00941
G1 X90.433 Y95.987 E.16514
G1 X90.565 Y96.306 E.0084
G1 X90.719 Y96.526 E.00653
G1 X91.01 Y96.793 E.00961
G1 X91.454 Y96.989 E.01181
G1 X91.798 Y97.038 E.00845
G1 X93.569 Y97.039 E.04308
G1 X93.569 Y101.599 E.11092
G1 X93.569 Y101.599 F9000
G1 X93.203 Y100.879
G1 F6000
G1 X93.203 Y101.295 E.01012
G1 X91.705 Y101.3 E.03644
G1 X91.199 Y101.407 E.01258
G1 X90.8 Y101.637 E.0112
G1 X90.799 Y97.083 E.11077
G1 X91.387 Y97.349 E.0157
G1 X91.798 Y97.404 E.01009
G1 X93.203 Y97.404 E.03418
G1 X93.203 Y100.819 E.08307
G1 X93.203 Y100.819 F9000
G1 X92.837 Y100.834
G1 F6000
G1 X92.837 Y100.931 E.00236
G1 X91.703 Y100.935 E.02758
G1 X91.165 Y101.048 E.01337
G1 X91.165 Y97.651 E.08263
G1 X91.319 Y97.708 E.00399
G1 X91.798 Y97.769 E.01175
G1 X92.837 Y97.77 E.02527
G1 X92.837 Y100.774 E.07307
G1 E-5 F3600
G1 X92.837 Y100.774 F9000
G1 X90.813 Y95.963
G1 X90.765 Y95.786
G1 X90.751 Y95.626
G1 X90.751 Y93.202
G1 X90.765 Y93.042
G1 X90.813 Y92.865
G1 X90.89 Y92.699
G1 X90.995 Y92.549
G1 X91.124 Y92.419
G1 X91.274 Y92.314
G1 X91.44 Y92.236
G1 X104.651 Y88.151
G1 X109.468 Y88.151
G1 X111.048 Y86.598
G1 X111.146 Y86.878
G1 E5 F2400
G1 F6000
G1 X120.11 Y86.878 E.21804
G1 X120.133 Y86.912 E.001
G1 X120.483 Y86.981 E.00868
G1 X126.446 Y86.973 E.14504
G1 X127.198 Y86.964 E.01829
G1 X127.892 Y86.855 E.01709
G1 X128.812 Y86.55 E.02358
G1 X129.362 Y86.261 E.01511
G1 X129.95 Y85.838 E.01762
G1 X130.645 Y85.134 E.02406
G1 X131.113 Y84.424 E.02068
G1 X131.4 Y83.791 E.01691
G1 X131.574 Y83.274 E.01327
G1 X131.69 Y82.67 E.01496
G1 X131.731 Y82.051 E.01509
G1 X131.731 Y79.364 E.06536
G1 X132.651 Y78.578 E.02943
G1 X132.908 Y78.31 E.00903
G1 X133.17 Y77.963 E.01058
G1 X133.274 Y77.555 E.01024
G1 X133.235 Y77.238 E.00777
G1 X133.008 Y76.788 E.01226
G1 X132.764 Y76.527 E.00869
G1 X131.716 Y75.626 E.03362
G1 X131.702 Y75.509 E.00287
G1 X131.431 Y75.064 E.01267
G1 X131.152 Y74.956 E.00728
G1 X135.428 Y74.956 E.10401
G1 X135.958 Y74.978 E.0129
G1 X136.565 Y75.072 E.01494
G1 X137.465 Y75.358 E.02297
G1 X138.077 Y75.687 E.0169
G1 X138.606 Y76.036 E.01542
G1 X139.005 Y76.374 E.01272
G1 X139.421 Y76.83 E.01501
G1 X139.803 Y77.399 E.01667
G1 X140.079 Y77.887 E.01364
G1 X140.275 Y78.386 E.01304
G1 X140.457 Y79.078 E.0174
G1 X140.533 Y79.69 E.015
G1 X140.543 Y84.935 E.12758
G1 X140.569 Y85.652 E.01745
G1 X140.569 Y92.868 E.17552
G1 X140.532 Y92.731 E.00345
G1 X140.297 Y92.321 E.01149
G1 X140.108 Y92.131 E.00652
G1 X139.704 Y91.895 E.01138
G1 X139.202 Y91.79 E.01247
G1 X127.403 Y91.79 E.287
G1 X127.651 Y91.578 E.00794
G1 X128.011 Y91.199 E.01271
G1 X128.216 Y90.84 E.01006
G1 X128.274 Y90.464 E.00925
G1 X128.235 Y90.238 E.00558
G1 X128.13 Y89.961 E.00721
G1 X127.764 Y89.527 E.01381
G1 X126.723 Y88.631 E.03341
G1 X126.683 Y88.39 E.00594
G1 X126.53 Y88.11 E.00776
G1 X126.232 Y87.868 E.00934
G1 X125.817 Y87.769 E.01038
G1 X105.183 Y87.769 E.5019
G1 X105.025 Y87.782 E.00386
G1 X104.581 Y87.995 E.01198
G1 X104.363 Y88.279 E.00871
G1 X104.278 Y88.629 E.00876
G1 X103.34 Y89.43 E.03
G1 X102.989 Y89.801 E.01242
G1 X102.827 Y90.045 E.00712
G1 X102.725 Y90.454 E.01025
G1 X102.765 Y90.762 E.00755
G1 X102.992 Y91.212 E.01226
G1 X103.15 Y91.389 E.00577
G1 X103.604 Y91.79 E.01473
G1 X91.798 Y91.79 E.28717
G1 X91.454 Y91.839 E.00845
G1 X91.01 Y92.036 E.01182
G1 X90.651 Y92.378 E.01206
G1 X90.433 Y92.819 E.01197
G1 X90.431 Y85.889 E.16857
G1 X90.456 Y85.353 E.01305
G1 X90.456 Y80.153 E.12648
G1 X90.481 Y79.622 E.01293
G1 X90.554 Y79.066 E.01364
G1 X90.682 Y78.542 E.01312
G1 X90.896 Y77.964 E.01499
G1 X91.179 Y77.418 E.01496
G1 X91.526 Y76.91 E.01496
G1 X91.931 Y76.45 E.01491
G1 X92.389 Y76.042 E.01492
G1 X92.891 Y75.694 E.01486
G1 X93.431 Y75.41 E.01484
G1 X93.999 Y75.194 E.01478
G1 X94.587 Y75.048 E.01474
G1 X95.345 Y74.958 E.01857
G1 X99.785 Y74.958 E.108
G1 X99.568 Y75.064 E.00587
G1 X99.298 Y75.51 E.01268
G1 X99.283 Y75.626 E.00285
G1 X98.236 Y76.527 E.0336
G1 X97.992 Y76.788 E.00869
G1 X97.8 Y77.127 E.00948
G1 X97.727 Y77.443 E.00789
G1 X97.753 Y77.737 E.00718
G1 X97.934 Y78.129 E.0105
G1 X98.349 Y78.578 E.01487
G1 X99.27 Y79.365 E.02947
G1 X99.278 Y82.329 E.0721
G1 X99.292 Y82.485 E.00381
G1 X99.44 Y83.319 E.0206
G1 X99.588 Y83.774 E.01164
G1 X99.835 Y84.3 E.01413
G1 X100.228 Y84.967 E.01883
G1 X100.712 Y85.532 E.0181
G1 X101.169 Y85.937 E.01485
G1 X101.69 Y86.29 E.01531
G1 X102.358 Y86.623 E.01816
G1 X102.933 Y86.814 E.01474
G1 X103.592 Y86.942 E.01633
G1 X104.199 Y86.981 E.0148
G1 X110.517 Y86.981 E.15368
G1 X110.675 Y86.968 E.00386
G1 X110.89 Y86.878 E.00567
G1 X111.086 Y86.878 E.00477
G1 E-5 F3600
G1 X111.086 Y86.878 F9000
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X105.183 Y87.375 E.0067
;WIDTH:0.456022
G1 X110.517 Y87.375 E.14962
;WIDTH:0.490566
G1 X110.691 Y87.358 E.00531
;WIDTH:0.525112
G1 X110.864 Y87.34 E.00568
;WIDTH:0.559658
G1 X111.038 Y87.323 E.00611
G1 X119.962 Y87.323 E.31185
G1 X120.136 Y87.34 E.00611
;WIDTH:0.525104
G1 X120.31 Y87.358 E.00571
;WIDTH:0.49055
G1 X120.485 Y87.375 E.00534
;WIDTH:0.463548
G1 X125.817 Y87.371 E.15224
G1 E-5 F3600
G1 X125.817 Y87.371 F9000
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X104.647 Y87.552 E.01029
;WIDTH:0.43792
G1 X104.34 Y87.72 E.0094
;WIDTH:0.399999
G1 X104.034 Y88.118 E.01221
G1 X103.944 Y88.432 E.00795
G1 X103.319 Y88.967 E.02001
G1 X102.849 Y89.414 E.01578
G1 X102.529 Y89.822 E.01261
G1 X102.433 Y90.054 E.00611
G1 X102.36 Y90.44 E.00956
G1 X102.451 Y90.982 E.01337
G1 X102.701 Y91.424 E.01235
G1 X91.798 Y91.425 E.2652
G1 X91.562 Y91.447 E.00577
G1 X90.982 Y91.63 E.01479
G1 X90.798 Y91.744 E.00527
G1 X90.797 Y85.889 E.14242
G1 X90.822 Y85.353 E.01305
G1 X90.821 Y80.153 E.12648
G1 X90.839 Y79.748 E.00986
G1 X90.899 Y79.209 E.01319
G1 X91.031 Y78.653 E.0139
G1 X91.229 Y78.117 E.0139
G1 X91.49 Y77.61 E.01387
G1 X91.811 Y77.139 E.01386
G1 X92.186 Y76.712 E.01382
G1 X92.609 Y76.334 E.0138
G1 X93.074 Y76.011 E.01377
G1 X93.574 Y75.747 E.01375
G1 X94.099 Y75.546 E.01367
G1 X94.643 Y75.41 E.01364
G1 X95.356 Y75.324 E.01747
G1 X99.001 Y75.324 E.08866
G1 X98.942 Y75.437 E.0031
G1 X97.997 Y76.25 E.03032
G1 X97.719 Y76.544 E.00984
G1 X97.451 Y77.018 E.01324
G1 X97.362 Y77.416 E.00992
G1 X97.384 Y77.761 E.00841
G1 X97.51 Y78.113 E.00909
G1 X97.796 Y78.55 E.0127
G1 X98.112 Y78.856 E.0107
G1 X98.905 Y79.534 E.02538
G1 X98.913 Y82.33 E.06801
G1 X98.932 Y82.549 E.00535
G1 X99.134 Y83.589 E.02577
G1 X99.304 Y84.064 E.01227
G1 X99.516 Y84.479 E.01134
G1 X99.948 Y85.202 E.02049
G1 X100.466 Y85.803 E.0193
G1 X100.96 Y86.237 E.01599
G1 X101.523 Y86.615 E.01649
G1 X102.239 Y86.968 E.01942
G1 X102.858 Y87.172 E.01585
G1 X103.567 Y87.307 E.01756
G1 X104.199 Y87.347 E.0154
;WIDTH:0.43792
G1 X104.577 Y87.366 E.01016
;WIDTH:0.47584
G1 X104.895 Y87.382 E.00935
G1 X104.895 Y87.382 F9000
G1 X103.893 Y87.696
;WIDTH:0.399999
G1 F6000
G1 X103.706 Y87.957 E.00781
G1 X103.611 Y88.236 E.00717
G1 X103.081 Y88.689 E.01696
G1 X102.581 Y89.165 E.01679
G1 X102.206 Y89.65 E.01491
G1 X102.083 Y89.949 E.00786
G1 X101.994 Y90.425 E.01178
G1 X102.092 Y91.058 E.01558
G1 X91.798 Y91.059 E.25039
G1 X91.495 Y91.087 E.0074
G1 X91.164 Y91.178 E.00835
G1 X91.163 Y85.889 E.12865
G1 X91.188 Y85.352 E.01308
G1 X91.193 Y79.95 E.1314
G1 X91.259 Y79.276 E.01647
G1 X91.379 Y78.764 E.01279
G1 X91.561 Y78.27 E.01281
G1 X91.801 Y77.803 E.01277
G1 X92.096 Y77.369 E.01276
G1 X92.44 Y76.975 E.01272
G1 X92.83 Y76.626 E.01273
G1 X93.257 Y76.328 E.01267
G1 X93.716 Y76.084 E.01264
G1 X94.199 Y75.897 E.0126
G1 X94.7 Y75.771 E.01257
G1 X95.367 Y75.69 E.01634
G1 X98.088 Y75.689 E.06619
G1 X97.759 Y75.973 E.01057
G1 X97.447 Y76.301 E.01101
G1 X97.102 Y76.91 E.01703
G1 X96.994 Y77.447 E.01332
G1 X97.045 Y77.919 E.01155
G1 X97.224 Y78.354 E.01144
G1 X97.531 Y78.802 E.01321
G1 X97.874 Y79.134 E.01161
G1 X98.54 Y79.703 E.02131
G1 X98.547 Y82.331 E.06392
G1 X98.572 Y82.613 E.00689
G1 X98.79 Y83.712 E.02725
G1 X98.959 Y84.187 E.01226
G1 X99.198 Y84.659 E.01287
G1 X99.667 Y85.436 E.02208
G1 X100.22 Y86.073 E.02052
G1 X100.75 Y86.537 E.01713
G1 X101.356 Y86.941 E.01772
G1 X102.119 Y87.314 E.02066
G1 X102.784 Y87.53 E.01701
G1 X103.332 Y87.644 E.01361
G1 X103.833 Y87.69 E.01224
G1 E-5 F3600
G1 E5 F2400
;WIDTH:0.463548
G1 F6000
G1 X126.132 Y87.355 E.00901
;WIDTH:0.431774
G1 X126.446 Y87.339 E.00831
;WIDTH:0.399999
G1 X127.248 Y87.326 E.01951
G1 X127.79 Y87.251 E.01331
G1 X128.45 Y87.061 E.01671
G1 X128.978 Y86.876 E.01361
G1 X129.569 Y86.562 E.01628
G1 X130.207 Y86.098 E.01919
G1 X130.943 Y85.346 E.02559
G1 X131.358 Y84.742 E.01783
G1 X131.595 Y84.294 E.01233
G1 X131.745 Y83.913 E.00996
G1 X131.932 Y83.347 E.0145
G1 X132.055 Y82.695 E.01614
G1 X132.097 Y82.051 E.0157
G1 X132.097 Y79.532 E.06127
G1 X132.888 Y78.856 E.02531
G1 X133.176 Y78.559 E.01006
G1 X133.46 Y78.199 E.01115
G1 X133.576 Y77.914 E.00748
G1 X133.641 Y77.471 E.01089
G1 X133.549 Y77.018 E.01124
G1 X133.281 Y76.544 E.01324
G1 X133.003 Y76.25 E.00984
G1 X132.079 Y75.455 E.02965
G1 X131.997 Y75.321 E.00382
G1 X134.916 Y75.321 E.071
G1 X135.922 Y75.342 E.02448
G1 X136.481 Y75.429 E.01376
G1 X137.322 Y75.696 E.02146
G1 X137.904 Y76.009 E.01607
G1 X138.491 Y76.407 E.01725
G1 X138.858 Y76.756 E.01232
G1 X139.266 Y77.255 E.01568
G1 X139.677 Y77.903 E.01867
G1 X139.927 Y78.5 E.01574
G1 X140.098 Y79.147 E.01628
G1 X140.168 Y79.713 E.01387
G1 X140.177 Y84.936 E.12704
G1 X140.203 Y85.652 E.01743
G1 X140.203 Y91.777 E.14898
G1 X139.802 Y91.543 E.01129
G1 X139.202 Y91.425 E.01487
G1 X128.293 Y91.424 E.26535
G1 X128.567 Y90.946 E.0134
G1 X128.64 Y90.446 E.01229
G1 X128.549 Y90.018 E.01064
G1 X128.347 Y89.625 E.01075
G1 X128.003 Y89.25 E.01238
G1 X127.056 Y88.435 E.03039
G1 X127.029 Y88.272 E.00402
G1 X126.815 Y87.882 E.01082
G1 X126.398 Y87.542 E.01309
;WIDTH:0.431774
G1 X126.107 Y87.457 E.00801
;WIDTH:0.463548
G1 X125.875 Y87.388 E.00691
G1 X125.875 Y87.388 F9000
G1 X127.133 Y87.699
;WIDTH:0.399999
G1 F6000
G1 X127.84 Y87.614 E.01732
G1 X128.561 Y87.41 E.01823
G1 X129.144 Y87.201 E.01506
G1 X129.777 Y86.863 E.01745
G1 X130.464 Y86.359 E.02073
G1 X131.241 Y85.557 E.02716
G1 X131.682 Y84.913 E.01899
G1 X131.919 Y84.465 E.01233
G1 X132.09 Y84.035 E.01126
G1 X132.291 Y83.42 E.01574
G1 X132.419 Y82.721 E.01729
G1 X132.463 Y82.051 E.01633
G1 X132.463 Y79.701 E.05716
G1 X133.126 Y79.134 E.02122
G1 X133.444 Y78.808 E.01108
G1 X133.779 Y78.376 E.0133
G1 X133.947 Y77.948 E.01118
G1 X134.006 Y77.46 E.01196
G1 X133.898 Y76.91 E.01363
G1 X133.553 Y76.301 E.01703
G1 X133.395 Y76.123 E.00579
G1 X132.909 Y75.687 E.01588
G1 X134.916 Y75.687 E.04882
G1 X135.885 Y75.706 E.02357
G1 X136.397 Y75.786 E.0126
G1 X137.179 Y76.035 E.01996
G1 X137.731 Y76.331 E.01524
G1 X138.168 Y76.621 E.01276
G1 X138.588 Y77.002 E.01379
G1 X138.962 Y77.459 E.01436
G1 X139.351 Y78.07 E.01762
G1 X139.579 Y78.614 E.01435
G1 X139.738 Y79.217 E.01517
G1 X139.802 Y79.736 E.01272
G1 X139.811 Y84.937 E.12651
G1 X139.837 Y85.652 E.0174
G1 X139.837 Y91.173 E.13429
G1 X139.202 Y91.059 E.01569
G1 X128.922 Y91.058 E.25005
G1 X129.005 Y90.428 E.01546
G1 X128.933 Y90.022 E.01003
G1 X128.83 Y89.729 E.00755
G1 X128.638 Y89.404 E.00918
G1 X128.241 Y88.973 E.01425
G1 X127.39 Y88.24 E.02732
G1 X127.376 Y88.155 E.0021
G1 X127.161 Y87.752 E.01111
G1 E-5 F3600
G1 X127.161 Y87.752 F9000
G1 X139.56 Y92.236
G1 X139.726 Y92.314
G1 X139.876 Y92.419
G1 X140.006 Y92.549
G1 X140.111 Y92.699
G1 X140.188 Y92.865
G1 X140.235 Y93.042
G1 X140.249 Y93.202
G1 X140.249 Y95.626
G1 X140.235 Y95.786
G1 X140.188 Y95.963
G1 X140.111 Y96.129
G1 X140.006 Y96.28
G1 X139.876 Y96.409
G1 X139.726 Y96.514
G1 X139.56 Y96.592
G1 X139.391 Y96.637
G1 X139.263 Y96.653
G1 X139.217 Y96.655
G1 X137.661 Y96.656
G1 X137.431 Y96.656
G1 X137.431 Y97.039
G1 E5 F2400
G1 F6000
G1 X139 Y97.038 E.03816
G1 X139.546 Y96.989 E.01333
G1 X139.903 Y96.839 E.00942
G1 X140.123 Y96.684 E.00655
;WIDTH:0.430754
G1 X140.521 Y96.262 E.0153
G1 X140.569 Y96.441 E.00489
;WIDTH:0.399999
G1 X140.569 Y102.15 E.13887
;WIDTH:0.404836
G1 X140.561 Y102.738 E.01449
G1 X140.51 Y102.573 E.00426
G1 X140.317 Y102.245 E.00938
;WIDTH:0.399999
G1 X140.146 Y102.05 E.00631
G1 X139.734 Y101.782 E.01196
G1 X139.202 Y101.658 E.01329
G1 X137.431 Y101.657 E.04308
G1 X137.431 Y97.099 E.11087
G1 X137.431 Y97.099 F9000
G1 X137.797 Y97.47
G1 F6000
G1 X137.797 Y97.404 E.00161
G1 X139 Y97.404 E.02926
G1 X139.614 Y97.349 E.01499
G1 X140.203 Y97.075 E.0158
G1 X140.203 Y101.667 E.1117
G1 X139.844 Y101.433 E.01042
G1 X139.202 Y101.292 E.01599
G1 X137.797 Y101.291 E.03418
G1 X137.797 Y97.53 E.09148
G1 X137.797 Y97.53 F9000
G1 X138.163 Y97.77
G1 F6000
G1 X139 Y97.77 E.02036
G1 X139.506 Y97.741 E.01233
G1 X139.837 Y97.642 E.0084
G1 X139.837 Y101.048 E.08285
G1 X139.202 Y100.927 E.01572
G1 X138.163 Y100.926 E.02527
G1 X138.163 Y97.83 E.07531
G1 E-5 F3600
G1 X138.163 Y97.83 F9000
G1 X140.136 Y102.666
G1 X140.199 Y102.844
G1 X140.23 Y102.993
G1 X140.238 Y103.036
G1 X140.247 Y103.182
G1 X140.249 Y103.214
G1 X140.249 Y104.786
G1 X140.247 Y104.818
G1 X140.238 Y104.964
G1 X140.23 Y105.007
G1 X140.199 Y105.156
G1 X140.136 Y105.334
G1 X140.094 Y105.412
G1 X140.033 Y105.515
G1 X139.911 Y105.661
G1 X139.762 Y105.786
G1 X139.59 Y105.881
G1 X139.41 Y105.939
G1 X139.313 Y105.953
G1 X139.218 Y105.959
G1 X137.993 Y105.96
G1 X137.431 Y105.961
G1 X137.431 Y106.341
G1 E5 F2400
G1 F6000
G1 X139.294 Y106.334 E.04532
G1 X139.655 Y106.258 E.00897
G1 X140.107 Y105.992 E.01276
G1 X140.43 Y105.586 E.01262
G1 X140.569 Y105.229 E.00932
G1 X140.569 Y110.15 E.1197
;WIDTH:0.404837
G1 X140.561 Y110.738 E.01449
G1 X140.51 Y110.573 E.00426
G1 X140.317 Y110.245 E.00938
;WIDTH:0.399999
G1 X140.146 Y110.05 E.00631
G1 X139.734 Y109.782 E.01196
G1 X139.202 Y109.658 E.01329
G1 X137.431 Y109.657 E.04308
G1 X137.431 Y106.401 E.0792
G1 X137.431 Y106.401 F9000
G1 X137.797 Y106.705
G1 F6000
G1 X139.295 Y106.7 E.03644
G1 X139.801 Y106.593 E.01258
G1 X140.203 Y106.361 E.01129
G1 X140.203 Y109.667 E.08042
G1 X139.844 Y109.433 E.01042
G1 X139.202 Y109.292 E.01599
G1 X137.797 Y109.291 E.03418
G1 X137.797 Y106.765 E.06144
G1 X138.163 Y107.938 F9000
G1 F6000
G1 X138.163 Y107.069 E.02114
G1 X139.297 Y107.065 E.02758
G1 X139.837 Y106.952 E.01342
G1 X139.837 Y109.048 E.05098
G1 X139.202 Y108.927 E.01572
G1 X138.163 Y108.926 E.02527
G1 X138.163 Y107.998 E.02257
G1 E-5 F3600
G1 X138.163 Y107.998 F9000
G1 X140.23 Y110.993
G1 X140.249 Y112.786
G1 X140.247 Y112.818
G1 X140.238 Y112.964
G1 X140.23 Y113.007
G1 X140.199 Y113.156
G1 X140.136 Y113.334
G1 X140.094 Y113.412
G1 X140.033 Y113.515
G1 X139.911 Y113.661
G1 X139.762 Y113.786
G1 X139.59 Y113.881
G1 X139.41 Y113.939
G1 X139.313 Y113.953
G1 X139.218 Y113.959
G1 X137.527 Y113.961
G1 X137.431 Y113.961
G1 X137.431 Y114.341
G1 E5 F2400
G1 F6000
G1 X139.294 Y114.334 E.04532
G1 X139.655 Y114.258 E.00897
G1 X140.107 Y113.992 E.01276
G1 X140.43 Y113.586 E.01262
G1 X140.569 Y113.229 E.00932
G1 X140.569 Y118.15 E.1197
;WIDTH:0.404837
G1 X140.561 Y118.738 E.01449
G1 X140.51 Y118.573 E.00426
G1 X140.317 Y118.245 E.00938
;WIDTH:0.399999
G1 X140.146 Y118.05 E.00631
G1 X139.734 Y117.782 E.01196
G1 X139.202 Y117.658 E.01329
G1 X137.431 Y117.657 E.04308
G1 X137.431 Y114.401 E.0792
G1 X137.431 Y114.401 F9000
G1 X137.797 Y114.777
G1 F6000
G1 X137.797 Y114.705 E.00175
G1 X139.295 Y114.7 E.03644
G1 X139.801 Y114.593 E.01258
G1 X140.203 Y114.361 E.01129
G1 X140.203 Y117.667 E.08042
G1 X139.844 Y117.433 E.01042
G1 X139.202 Y117.292 E.01599
G1 X137.797 Y117.291 E.03418
G1 X137.797 Y114.837 E.05969
G1 X138.174 Y115.069 F9000
G1 F6000
G1 X139.297 Y115.065 E.02732
G1 X139.837 Y114.952 E.01342
G1 X139.837 Y117.048 E.05098
G1 X139.202 Y116.927 E.01572
G1 X138.163 Y116.926 E.02527
G1 X138.163 Y115.118 E.04398
G1 E-5 F3600
G1 X138.163 Y115.118 F9000
G1 X140.094 Y118.588
G1 X140.136 Y118.666
G1 X140.199 Y118.844
G1 X140.23 Y118.993
G1 X140.238 Y119.036
G1 X140.247 Y119.182
G1 X140.249 Y119.214
G1 X140.249 Y120.786
G1 X140.247 Y120.818
G1 X140.238 Y120.964
G1 X140.23 Y121.007
G1 X140.199 Y121.156
G1 X140.136 Y121.334
G1 X140.094 Y121.412
G1 X140.033 Y121.515
G1 X139.911 Y121.661
G1 X139.762 Y121.786
G1 X139.59 Y121.881
G1 X139.41 Y121.939
G1 X139.313 Y121.953
G1 X139.218 Y121.959
G1 X137.527 Y121.961
G1 X137.431 Y121.961
G1 X137.431 Y122.341
G1 E5 F2400
G1 F6000
G1 X139.294 Y122.334 E.04532
G1 X139.655 Y122.258 E.00897
G1 X140.107 Y121.992 E.01276
G1 X140.43 Y121.586 E.01262
G1 X140.569 Y121.229 E.00932
G1 X140.569 Y126.15 E.1197
;WIDTH:0.404837
G1 X140.561 Y126.738 E.01449
G1 X140.51 Y126.573 E.00426
G1 X140.317 Y126.245 E.00938
;WIDTH:0.399999
G1 X140.146 Y126.05 E.00631
G1 X139.734 Y125.782 E.01196
G1 X139.202 Y125.658 E.01329
G1 X137.431 Y125.657 E.04308
G1 X137.431 Y122.401 E.0792
G1 X137.431 Y122.401 F9000
G1 X137.797 Y122.705
G1 F6000
G1 X139.295 Y122.7 E.03644
G1 X139.801 Y122.593 E.01258
G1 X140.203 Y122.361 E.01129
G1 X140.203 Y125.667 E.08042
G1 X139.844 Y125.433 E.01042
G1 X139.202 Y125.292 E.01599
G1 X137.797 Y125.291 E.03418
G1 X137.797 Y122.765 E.06144
G1 X138.163 Y123.711 F9000
G1 F6000
G1 X138.163 Y123.069 E.01562
G1 X139.297 Y123.065 E.02758
G1 X139.837 Y122.952 E.01342
G1 X139.837 Y125.048 E.05098
G1 X139.202 Y124.927 E.01572
G1 X138.163 Y124.926 E.02527
G1 X138.163 Y123.771 E.02809
G1 E-5 F3600
G1 X138.163 Y123.771 F9000
G1 X140.033 Y126.485
G1 X140.094 Y126.588
G1 X140.136 Y126.666
G1 X140.199 Y126.844
G1 X140.23 Y126.993
G1 X140.238 Y127.036
G1 X140.247 Y127.182
G1 X140.249 Y127.214
G1 X140.249 Y128.786
G1 X140.199 Y134.844
G1 X140.561 Y134.738
G1 E5 F2400
;WIDTH:0.404832
G1 F6000
G1 X140.51 Y134.573 E.00426
G1 X140.317 Y134.245 E.00938
;WIDTH:0.399999
G1 X140.146 Y134.05 E.00631
G1 X139.734 Y133.782 E.01196
G1 X139.201 Y133.658 E.01331
G1 X137.37 Y133.657 E.04454
G1 X137.422 Y133.023 E.01547
G1 X137.429 Y130.341 E.06524
G1 X139.294 Y130.334 E.04536
G1 X139.824 Y130.184 E.0134
G1 X140.165 Y129.928 E.01037
G1 X140.354 Y129.699 E.00722
G1 X140.569 Y129.222 E.01273
G1 X140.569 Y134.15 E.11987
;WIDTH:0.404832
G1 X140.562 Y134.678 E.01301
G1 X140.562 Y134.678 F9000
G1 X140.203 Y133.667
;WIDTH:0.399999
G1 F6000
G1 X139.844 Y133.433 E.01042
G1 X139.202 Y133.292 E.01599
G1 X137.769 Y133.292 E.03486
G1 X137.788 Y133.024 E.00654
G1 X137.794 Y130.705 E.05641
G1 X139.295 Y130.7 E.03651
G1 X139.801 Y130.593 E.01258
G1 X139.97 Y130.52 E.00448
G1 X140.203 Y130.344 E.0071
G1 X140.203 Y133.607 E.07937
G1 X139.837 Y133.048 F9000
G1 F6000
G1 X139.202 Y132.927 E.01572
G1 X138.154 Y132.926 E.02549
G1 X138.158 Y131.069 E.04517
G1 X139.297 Y131.065 E.02771
G1 X139.837 Y130.952 E.01342
G1 X139.837 Y132.988 E.04952
G1 E-5 F3600
G1 X139.837 Y132.988 F9000
G1 X140.596 Y135.815
G1 E5 F2400
;WIDTH:0.345946
G1 F6000
G1 X140.596 Y136.905 E.02259
;WIDTH:0.359388
G1 X140.589 Y137.059 E.00333
G1 E-5 F3600
G1 X140.589 Y137.059 F9000
G1 X140.543 Y142.714
G1 E5 F2400
;WIDTH:0.403419
G1 F6000
G1 X140.526 Y142.643 E.00179
G1 X140.272 Y142.177 E.01303
;WIDTH:0.399999
G1 X139.897 Y141.856 E.01201
G1 X139.561 Y141.713 E.00888
G1 X139.203 Y141.658 E.00881
G1 X132.652 Y141.648 E.15935
G1 X133.557 Y140.978 E.02739
G1 X134.205 Y140.387 E.02133
G1 X134.748 Y139.794 E.01956
G1 X135.327 Y139.043 E.02307
G1 X135.792 Y138.343 E.02044
G1 X138.907 Y138.339 E.07577
G1 X139.499 Y138.306 E.01442
G1 X139.897 Y138.144 E.01045
G1 X140.286 Y137.803 E.01258
G1 X140.525 Y137.364 E.01216
;WIDTH:0.39125
G1 X140.589 Y137.059 E.0074
;WIDTH:0.368595
G1 X140.584 Y137.149 E.002
;WIDTH:0.399999
G1 X140.569 Y137.689 E.01314
G1 X140.569 Y142.244 E.1108
;WIDTH:0.403419
G1 X140.564 Y142.805 E.01377
G1 X140.556 Y142.773 E.00081
G1 X140.556 Y142.773 F9000
G1 X140.203 Y141.623
;WIDTH:0.399999
G1 F6000
G1 X140.105 Y141.555 E.0029
G1 X139.634 Y141.354 E.01246
G1 X139.204 Y141.292 E.01057
G1 X133.778 Y141.284 E.13198
G1 X134.474 Y140.634 E.02316
G1 X135.035 Y140.021 E.02021
G1 X135.626 Y139.254 E.02355
G1 X135.999 Y138.709 E.01606
G1 X139.26 Y138.704 E.07932
G1 X139.715 Y138.626 E.01123
G1 X140.203 Y138.377 E.01333
G1 X140.203 Y141.563 E.0775
G1 X140.203 Y141.563 F9000
G1 X139.837 Y141.052
G1 F6000
G1 X139.707 Y140.996 E.00344
G1 X139.204 Y140.927 E.01235
G1 X134.705 Y140.92 E.10943
G1 X135.322 Y140.247 E.02221
G1 X135.82 Y139.613 E.01961
G1 X136.2 Y139.074 E.01604
G1 X139.261 Y139.07 E.07446
G1 X139.837 Y138.967 E.01423
G1 X139.837 Y140.992 E.04926
G1 E-5 F3600
G1 X139.837 Y140.992 F9000
G1 E5 F2400
;WIDTH:0.642016
G1 F6000
G1 X140.085 Y153.664 E.01911
;WIDTH:0.650524
G1 X140.045 Y153.722 E.00289
G1 E-5 F3600
G1 X140.045 Y153.722 F9000
G1 X139.933 Y153.633
G1 X139.987 Y153.566
G1 X140.029 Y153.512
G1 X140.088 Y153.409
G1 X140.13 Y153.331
G1 X140.199 Y153.155
G1 X140.23 Y153.007
G1 X140.238 Y152.964
G1 X140.247 Y152.818
G1 X140.249 Y152.786
G1 X140.249 Y151.214
G1 X140.247 Y151.182
G1 X140.238 Y151.036
G1 X140.23 Y150.993
G1 X140.199 Y150.844
G1 X140.136 Y150.666
G1 X140.094 Y150.588
G1 X140.033 Y150.485
G1 X139.036 Y148.825
G1 E5 F2400
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X139.563 Y148.297 E.01815
G1 X139.563 Y147.747 E.01338
G1 X138.651 Y148.66 E.03139
G1 X138.101 Y148.659 E.01338
G1 X139.449 Y147.31 E.04639
G1 X138.862 Y147.348 E.01431
G1 X137.552 Y148.658 E.04506
G1 X137.002 Y148.657 E.01338
G1 X138.311 Y147.348 E.04503
G1 X137.76 Y147.349 E.0134
G1 X136.453 Y148.656 E.04496
G1 X135.904 Y148.655 E.01335
G1 X137.209 Y147.349 E.04491
G1 X136.658 Y147.35 E.0134
G1 X135.354 Y148.654 E.04486
G1 X135.138 Y148.654 E.00525
G1 X135.138 Y148.32 E.00812
G1 X136.108 Y147.351 E.03335
G1 X135.557 Y147.351 E.0134
G1 X134.973 Y147.935 E.02009
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X135.557 Y147.351 E-.3923
G1 X136.108 Y147.351 E-.26172
G1 X135.138 Y148.32 E-.65126
G1 X135.138 Y148.654 E-.15865
G1 X135.214 Y148.654 E-.03607
;WIPE_END
G1 X135.387 Y140.811 F9000
G1 E5 F2400
G1 F3072.127
G1 X136.851 Y139.347 E.05036
G1 X137.375 Y139.346 E.01275
G1 X136.074 Y140.648 E.04477
G1 X136.597 Y140.649 E.01272
G1 X137.899 Y139.346 E.04481
G1 X138.424 Y139.345 E.01277
G1 X137.119 Y140.649 E.04487
G1 X137.642 Y140.65 E.01272
G1 X138.948 Y139.344 E.04493
G1 X139.504 Y139.312 E.01355
G1 X138.165 Y140.651 E.04606
G1 X138.687 Y140.652 E.0127
G1 X139.563 Y139.776 E.03013
G1 X139.563 Y140.299 E.01272
G1 X139.046 Y140.817 E.0178
G1 E-5 F3600
G1 X139.046 Y140.817 F9000
G1 X140.199 Y137.156
G1 X140.23 Y137.007
G1 X140.238 Y136.964
G1 X140.247 Y136.818
G1 X140.249 Y136.786
G1 X140.249 Y135.214
G1 X140.247 Y135.182
G1 X140.238 Y135.036
G1 X140.23 Y134.993
G1 X140.136 Y134.666
G1 X140.094 Y134.588
G1 X140.033 Y134.485
G1 X139.035 Y132.817
G1 E5 F2400
G1 F3072.127
G1 X139.563 Y132.289 E.01816
G1 X139.563 Y131.746 E.01321
G1 X138.657 Y132.652 E.03117
G1 X138.429 Y132.652 E.00555
G1 X138.429 Y132.337 E.00766
G1 X139.459 Y131.307 E.03543
G1 X138.883 Y131.341 E.01404
G1 X138.266 Y131.958 E.02122
G1 E-5 F3600
G1 X138.266 Y131.958 F9000
G1 X140.033 Y129.515
G1 X140.094 Y129.412
G1 X140.136 Y129.334
G1 X140.199 Y129.156
G1 X140.23 Y129.007
G1 X140.238 Y128.964
G1 X140.247 Y128.818
G1 X140.23 Y126.993
G1 X139.036 Y124.817
G1 E5 F2400
G1 F3072.127
G1 X139.563 Y124.29 E.01813
G1 X139.563 Y123.748 E.01318
G1 X138.659 Y124.652 E.0311
G1 X138.437 Y124.652 E.0054
G1 X138.437 Y124.332 E.00778
G1 X139.463 Y123.307 E.03528
G1 X138.886 Y123.341 E.01406
G1 X138.272 Y123.955 E.02112
G1 E-5 F3600
G1 X138.272 Y123.955 F9000
G1 X140.23 Y121.007
G1 X140.23 Y118.993
G1 X140.033 Y118.485
G1 X139.036 Y116.817
G1 E5 F2400
G1 F3072.127
G1 X139.563 Y116.29 E.01813
G1 X139.563 Y115.748 E.01318
G1 X138.659 Y116.652 E.0311
G1 X138.437 Y116.652 E.0054
G1 X138.437 Y116.332 E.00778
G1 X139.463 Y115.307 E.03528
G1 X138.886 Y115.341 E.01406
G1 X138.272 Y115.955 E.02112
G1 E-5 F3600
G1 X138.272 Y115.955 F9000
G1 X140.23 Y113.007
G1 X140.23 Y110.993
G1 X140.199 Y110.844
G1 X140.136 Y110.666
G1 X140.094 Y110.588
G1 X140.033 Y110.485
G1 X139.036 Y108.817
G1 E5 F2400
G1 F3072.127
G1 X139.563 Y108.29 E.01813
G1 X139.563 Y107.748 E.01318
G1 X138.659 Y108.652 E.0311
G1 X138.437 Y108.652 E.0054
G1 X138.437 Y108.332 E.00778
G1 X139.463 Y107.307 E.03528
G1 X138.886 Y107.341 E.01406
G1 X138.272 Y107.955 E.02112
G1 E-5 F3600
G1 X138.272 Y107.955 F9000
G1 X140.23 Y105.007
G1 X140.23 Y102.993
G1 X140.094 Y102.588
G1 X140.033 Y102.485
G1 X139.911 Y102.339
G1 X138.298 Y100.816
G1 E5 F2400
G1 F3072.127
G1 X139.052 Y100.062 E.02594
G1 X139.563 Y100.062 E.01243
G1 X139.563 Y100.172 E.00268
G1 X138.918 Y100.817 E.02219
G1 E-5 F3600
G1 X138.918 Y100.817 F9000
G1 X139 Y98.044
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X139.563 Y98.002 E.01373
G1 X139.563 Y99.697 E.04123
G1 X138.437 Y99.697 E.02739
G1 X138.437 Y98.044 E.04021
G1 X138.817 Y98.044 E.00924
G1 X139.007 Y98.417 E.01018
;WIDTH:0.414601
G1 X138.81 Y98.417 E.00498
G1 X138.81 Y99.324 E.02294
G1 X139.19 Y99.324 E.00961
G1 X139.19 Y98.417 E.02294
G1 E-5 F3600
G1 X139.19 Y98.417 F9000
G1 X140.188 Y95.963
G1 X140.235 Y95.786
G1 X140.249 Y95.626
G1 X140.249 Y93.202
G1 X140.235 Y93.042
G1 X140.188 Y92.865
G1 X133.897 Y78.699
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X133.896 Y80.194 E.03636
G1 X133.813 Y81.379 E.02889
G1 X133.689 Y82.179 E.01969
G1 X132.728 Y82.176 E.02338
G1 X132.737 Y79.826 E.05716
G1 X133.469 Y79.184 E.02368
G1 X133.776 Y78.836 E.01129
G1 X133.776 Y78.836 F9000
G1 X133.515 Y79.652
;WIDTH:0.431266
G1 F1200
G1 X133.515 Y80.188 E.01415
G1 X133.453 Y81.354 E.03083
;WIDTH:0.390322
G1 X133.393 Y81.832 E.01141
;WIDTH:0.365606
G1 X133.085 Y81.83 E.00679
;WIDTH:0.390322
G1 X133.098 Y81.342 E.01156
;WIDTH:0.431237
G1 X133.118 Y79.999 E.03546
G1 X133.378 Y79.772 E.00911
G1 X133.378 Y79.772 F9000
G1 X133.927 Y78.402
;WIDTH:0.4
G1 F3072.127
G1 X134.387 Y77.942 E.01582
G1 X134.387 Y77.942 F9000
G1 X134.083 Y77.21
G1 F3072.127
G1 X134.222 Y77.071 E.00478
G1 X134.222 Y76.553 E.0126
G1 X134.084 Y76.69 E.00473
G1 X133.897 Y76.36 E.00923
G1 X134.222 Y76.035 E.01118
G1 X134.222 Y75.962 E.00178
G1 X133.778 Y75.961 E.0108
G1 X133.575 Y76.164 E.00698
G1 X133.575 Y76.164 F9000
G1 X135.479 Y75.962
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X136.338 Y76.055 E.02102
G1 X137.049 Y76.281 E.01815
G1 X137.387 Y76.458 E.00928
G1 X134.588 Y79.257 E.09628
G1 X134.588 Y75.962 E.08015
G1 X135.296 Y75.962 E.01722
G1 X135.276 Y76.328 E.00892
G1 X134.953 Y76.328 E.00786
G1 X134.953 Y78.375 E.04979
G1 X136.756 Y76.572 E.06202
G1 X136.262 Y76.415 E.01261
G1 X135.459 Y76.328 E.01965
G1 X135.438 Y76.717 E.00948
;WIDTH:0.447073
G1 X136 Y76.778 E.01552
G1 X135.343 Y77.435 E.02551
G1 X135.343 Y76.805 E.0173
G1 E-5 F3600
G1 X135.343 Y76.805 F9000
G1 X137.724 Y76.639
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X134.588 Y79.775 E.10788
G1 X134.578 Y80.302 E.01282
G1 X138.024 Y76.856 E.11854
G1 X138.302 Y77.095 E.00892
G1 X134.548 Y80.848 E.12912
G1 X134.498 Y81.415 E.01385
G1 X138.548 Y77.365 E.13932
G1 X138.769 Y77.662 E.009
G1 X134.424 Y82.007 E.14947
G1 X134.424 Y82.007 F9000
G1 X134.144 Y82.705
;WIDTH:0.374336
G1 F1200
G1 X134.103 Y82.716 E.00096
G1 X134.084 Y82.645 E.00166
G1 X134.155 Y82.664 E.00166
;WIDTH:0.399999
G1 X134.281 Y82.667 E.00307
G1 X138.976 Y77.972 E.1615
G1 E-5 F3600
G1 X138.976 Y77.972 F9000
G1 X133.051 Y82.862
G1 E5 F2400
G1 F1200
G1 X132.579 Y83.335 E.01625
G1 X132.47 Y83.58 E.00652
;WIDTH:0.374336
G1 X132.399 Y83.561 E.00166
G1 X132.418 Y83.632 E.00166
G1 X132.459 Y83.621 E.00096
G1 X132.459 Y83.621 F9000
G1 X132.239 Y84.347
G1 F1200
G1 X132.198 Y84.358 E.00096
G1 X132.179 Y84.287 E.00166
G1 X132.25 Y84.306 E.00166
;WIDTH:0.399999
G1 X132.372 Y84.059 E.0067
G1 X133.565 Y82.866 E.04104
G1 E-5 F3600
G1 X133.565 Y82.866 F9000
G1 X128.072 Y87.841
G1 E5 F2400
G1 F1200
G1 X127.737 Y88.177 E.01154
G1 X127.566 Y87.893 E.00806
;WIDTH:0.374336
G1 X127.495 Y87.874 E.00166
G1 X127.514 Y87.945 E.00166
G1 X127.555 Y87.934 E.00096
;WIDTH:0.399999
G1 X128.015 Y88.416 E.01621
G1 X128.814 Y87.617 E.02749
G1 X128.814 Y87.617 F9000
G1 X129.756 Y87.192
G1 F1200
G1 X128.293 Y88.655 E.05033
G1 E-5 F3600
G1 X128.293 Y88.655 F9000
G1 X130.015 Y86.985
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X130.363 Y86.695 E.01025
G1 X131.178 Y85.906 E.02566
G1 X131.717 Y85.288 E.01855
;WIDTH:0.399999
G1 X131.919 Y85.029 E.00799
G1 X134.08 Y82.867 E.07435
G1 E-5 F3600
G1 X134.08 Y82.867 F9000
G1 X139.162 Y78.303
G1 E5 F2400
G1 F1200
G1 X128.562 Y88.903 E.36463
G1 X128.805 Y89.178 E.00893
G1 X139.308 Y78.674 E.36131
G1 X139.418 Y79.081 E.01026
G1 X129.015 Y89.484 E.35786
G1 X129.162 Y89.855 E.00971
G1 X139.499 Y79.518 E.35559
G1 X139.528 Y80.005 E.01187
G1 X129.255 Y90.278 E.35338
G1 X129.267 Y90.784 E.01231
G1 X139.529 Y80.521 E.35302
G1 X139.53 Y81.038 E.01258
G1 X129.784 Y90.784 E.33526
G1 X130.301 Y90.784 E.01258
G1 X139.531 Y81.554 E.31751
G1 X139.532 Y82.07 E.01255
G1 X130.818 Y90.784 E.29976
G1 X131.335 Y90.784 E.01258
G1 X139.533 Y82.586 E.28201
G1 X139.534 Y83.102 E.01255
G1 X131.852 Y90.784 E.26426
G1 X132.369 Y90.784 E.01258
G1 X139.535 Y83.619 E.24649
G1 X139.536 Y84.135 E.01255
G1 X132.886 Y90.784 E.22874
G1 X133.403 Y90.784 E.01258
G1 X139.537 Y84.651 E.21099
G1 X139.538 Y85.167 E.01255
G1 X133.92 Y90.784 E.19324
G1 X134.437 Y90.784 E.01258
G1 X139.563 Y85.659 E.17631
G1 X139.563 Y86.176 E.01258
G1 X134.955 Y90.784 E.15851
G1 X135.472 Y90.785 E.01258
G1 X139.563 Y86.693 E.14074
G1 X139.563 Y87.21 E.01258
G1 X135.989 Y90.785 E.12296
G1 X136.506 Y90.785 E.01258
G1 X139.563 Y87.727 E.10518
G1 X139.563 Y88.244 E.01258
G1 X137.023 Y90.785 E.08739
G1 X137.54 Y90.785 E.01258
G1 X139.563 Y88.762 E.06959
G1 X139.563 Y89.279 E.01258
G1 X138.057 Y90.785 E.05181
G1 X138.574 Y90.785 E.01258
G1 X139.563 Y89.796 E.03402
G1 X139.563 Y90.313 E.01258
G1 X139.091 Y90.785 E.01624
G1 E-5 F3600
G1 X139.091 Y90.785 F9000
G1 X118.989 Y86.496
G1 X111.049 Y86.599
G1 X104.191 Y86.599
G1 X103.967 Y86.591
G1 X103.89 Y86.588
G1 X103.657 Y86.565
G1 X103.58 Y86.556
G1 X103.349 Y86.517
G1 X103.274 Y86.503
G1 X103.045 Y86.449
G1 X102.971 Y86.429
G1 X102.747 Y86.36
G1 X102.675 Y86.335
G1 X102.456 Y86.251
G1 X102.385 Y86.22
G1 X102.172 Y86.122
G1 X102.103 Y86.085
G1 X101.887 Y85.966
G1 X101.822 Y85.925
G1 X101.616 Y85.793
G1 X101.554 Y85.747
G1 X101.36 Y85.603
G1 X101.179 Y85.448
G1 X101.12 Y85.397
G1 X100.952 Y85.233
G1 X100.897 Y85.177
G1 X100.74 Y85
G1 X100.688 Y84.94
G1 X100.542 Y84.751
G1 X100.495 Y84.686
G1 X100.361 Y84.486
G1 X100.317 Y84.417
G1 X100.197 Y84.208
G1 X97.103 Y78.659
G1 E5 F2400
G1 F1200
G1 X97.346 Y79.004 E.01026
G1 X98.266 Y79.827 E.03003
G1 X98.272 Y82.176 E.05714
G1 X97.307 Y82.178 E.02347
G1 X97.149 Y81.004 E.02881
G1 X97.103 Y80.19 E.01983
G1 X97.103 Y78.842 E.03279
G1 X97.103 Y78.842 F9000
G1 X97.486 Y79.642
;WIDTH:0.433013
G1 F1200
G1 X97.884 Y79.998 E.01416
;WIDTH:0.433133
G1 X97.897 Y80.951 E.02528
;WIDTH:0.41239
G1 X97.923 Y81.83 E.02211
;WIDTH:0.365598
G1 X97.612 Y81.832 E.00685
G1 X97.593 Y81.687 E.00322
;WIDTH:0.41239
G1 X97.519 Y80.962 E.01833
;WIDTH:0.433133
G1 X97.486 Y79.825 E.03018
G1 E-5 F3600
G1 X97.486 Y79.825 F9000
G1 X96.613 Y77.023
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X96.876 Y76.761 E.00903
G1 X97.38 Y75.964 E.02294
G1 X97.152 Y75.964 E.00555
G1 X96.613 Y76.502 E.01852
G1 E-5 F3600
G1 X96.613 Y76.502 F9000
G1 X93.197 Y76.528
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.374336
G1 F1200
G1 X92.812 Y76.863 E.01154
G1 X92.45 Y77.22 E.0115
G1 X92.11 Y77.599 E.01152
G1 X92.11 Y77.599 F9000
G1 X91.787 Y78.379
G1 F1200
G1 X91.716 Y78.36 E.00166
G1 X91.735 Y78.431 E.00166
G1 X91.776 Y78.42 E.00096
;WIDTH:0.399999
G1 X91.926 Y78.131 E.00792
G1 X93.627 Y76.431 E.0585
G1 X93.627 Y76.431 F9000
G1 X94.469 Y76.106
G1 F1200
G1 X91.599 Y78.975 E.09871
G1 X91.489 Y79.603 E.01551
G1 X95.107 Y75.985 E.12446
G1 X95.645 Y75.964 E.0131
G1 X91.461 Y80.148 E.14393
G1 X91.46 Y80.666 E.0126
G1 X96.162 Y75.964 E.16175
G1 X96.518 Y75.918 E.00873
;WIDTH:0.374336
G1 X96.477 Y75.929 E.00096
G1 X96.458 Y75.858 E.00166
G1 X96.529 Y75.877 E.00166
;WIDTH:0.399999
G1 X96.412 Y76.231 E.00907
G1 X91.459 Y81.185 E.1704
G1 X91.458 Y81.703 E.0126
G1 X96.412 Y76.748 E.17043
G1 X96.412 Y77.265 E.01258
G1 X91.456 Y82.221 E.17048
G1 X91.455 Y82.739 E.0126
G1 X96.412 Y77.783 E.1705
G1 X96.412 Y78.3 E.01258
G1 X91.454 Y83.258 E.17055
G1 X91.453 Y83.776 E.0126
G1 X96.412 Y78.817 E.17059
G1 X96.412 Y79.334 E.01258
G1 X91.452 Y84.294 E.17062
G1 X91.451 Y84.812 E.0126
G1 X96.413 Y79.85 E.17069
G1 X96.425 Y80.356 E.01231
G1 X91.45 Y85.331 E.17114
G1 X91.449 Y85.849 E.0126
G1 X96.452 Y80.846 E.1721
G1 X96.493 Y81.322 E.01162
G1 X91.448 Y86.367 E.17354
G1 X91.446 Y86.885 E.0126
G1 X96.544 Y81.788 E.17535
G1 X96.615 Y82.234 E.01099
G1 X91.445 Y87.404 E.17784
G1 X91.444 Y87.922 E.0126
G1 X96.714 Y82.652 E.18128
G1 X97.197 Y82.702 E.01181
;WIDTH:0.374336
G1 X97.126 Y82.683 E.00166
G1 X97.145 Y82.754 E.00166
G1 X97.186 Y82.743 E.00096
;WIDTH:0.399999
G1 X97.014 Y82.869 E.00519
G1 X91.443 Y88.44 E.19164
G1 X91.442 Y88.958 E.0126
G1 X97.535 Y82.865 E.2096
G1 X98.056 Y82.861 E.01267
G1 X91.441 Y89.476 E.22755
G1 X91.44 Y89.995 E.01262
G1 X98.373 Y83.061 E.23851
G1 X98.43 Y82.794 E.00664
;WIDTH:0.374336
G1 X98.389 Y82.805 E.00096
G1 X98.37 Y82.734 E.00166
G1 X98.441 Y82.753 E.00166
G1 X98.441 Y82.753 F9000
G1 X98.451 Y83.501
;WIDTH:0.399999
G1 F1200
G1 X91.439 Y90.513 E.24121
G1 X91.401 Y90.932 E.01023
;WIDTH:0.374336
G1 X91.36 Y90.943 E.00096
G1 X91.34 Y90.872 E.00167
G1 X91.412 Y90.891 E.00168
;WIDTH:0.399999
G1 X91.67 Y90.799 E.00666
G1 X98.567 Y83.902 E.23725
G1 X98.705 Y84.281 E.00981
G1 X92.201 Y90.785 E.22373
G1 X92.718 Y90.785 E.01258
G1 X98.875 Y84.628 E.2118
G1 X99.058 Y84.962 E.00926
G1 X93.235 Y90.785 E.20031
G1 X93.753 Y90.785 E.0126
G1 X99.242 Y85.296 E.18882
G1 X99.45 Y85.604 E.00904
G1 X94.27 Y90.785 E.17821
G1 X94.787 Y90.785 E.01258
G1 X99.686 Y85.886 E.16852
G1 X99.929 Y86.159 E.00889
G1 X95.304 Y90.785 E.15911
G1 X95.821 Y90.784 E.01258
G1 X100.194 Y86.412 E.15041
G1 X100.467 Y86.656 E.00891
G1 X96.338 Y90.784 E.14202
G1 X96.856 Y90.784 E.0126
G1 X100.768 Y86.872 E.13457
G1 X101.07 Y87.087 E.00902
G1 X97.373 Y90.784 E.12717
G1 X97.89 Y90.784 E.01258
G1 X101.405 Y87.269 E.12091
G1 X101.747 Y87.444 E.00934
G1 X98.407 Y90.784 E.11489
G1 X98.924 Y90.784 E.01258
G1 X102.113 Y87.595 E.1097
G1 X102.502 Y87.724 E.00997
G1 X99.441 Y90.784 E.10528
G1 X99.958 Y90.784 E.01258
G1 X102.907 Y87.835 E.10144
G1 X103.339 Y87.92 E.01071
G1 X100.476 Y90.784 E.0985
G1 X100.993 Y90.784 E.01258
G1 X101.791 Y89.986 E.02745
G1 X101.985 Y89.757 E.0073
;WIDTH:0.374336
G1 X101.944 Y89.768 E.00096
G1 X101.925 Y89.697 E.00166
G1 X101.996 Y89.716 E.00166
G1 X101.747 Y90.695 F9000
;WIDTH:0.544978
G1 F1200
G1 X101.702 Y90.65 E.00216
G1 X101.64 Y90.667 E.00218
G1 X101.623 Y90.728 E.00215
G1 X101.668 Y90.773 E.00216
G1 X101.73 Y90.757 E.00218
G1 E-5 F3600
G1 X101.73 Y90.757 F9000
G1 X103.068 Y88.521
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X103.464 Y88.151 E.01226
G1 X103.627 Y87.861 E.00752
G1 X103.586 Y87.872 E.00096
G1 X103.567 Y87.801 E.00166
G1 X103.638 Y87.82 E.00166
G1 E-5 F3600
G1 X103.638 Y87.82 F9000
G1 X91.44 Y92.236
G1 X91.274 Y92.314
G1 X91.124 Y92.419
G1 X90.995 Y92.549
G1 X90.89 Y92.699
G1 X90.813 Y92.865
G1 X90.765 Y93.042
G1 X90.751 Y93.202
G1 X90.751 Y95.626
G1 X90.765 Y95.786
G1 X90.813 Y95.963
G1 X90.89 Y96.129
G1 X91.802 Y98.044
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X92.563 Y98.044 E.01851
G1 X92.563 Y99.697 E.04021
G1 X91.439 Y99.697 E.02734
G1 X91.439 Y98.011 E.04101
G1 X91.62 Y98.027 E.00442
G1 X91.811 Y98.416 E.01054
;WIDTH:0.413559
G1 X92.191 Y98.416 E.00959
G1 X92.191 Y99.324 E.02291
G1 X91.812 Y99.324 E.00956
G1 X91.811 Y98.599 E.01829
G1 E-5 F3600
G1 X91.811 Y98.599 F9000
G1 X91.83 Y100.825
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X92.563 Y100.062 E.02574
G1 X91.972 Y100.062 E.01438
G1 X91.275 Y100.759 E.02398
G1 E-5 F3600
G1 X91.275 Y100.759 F9000
G1 X90.801 Y102.844
G1 X90.77 Y102.993
G1 X90.762 Y103.036
G1 X90.753 Y103.183
G1 X90.751 Y103.214
G1 X90.751 Y104.786
G1 X90.753 Y104.817
G1 X90.762 Y104.964
G1 X91.276 Y107.874
G1 E5 F2400
G1 F3072.127
G1 X91.802 Y107.347 E.01811
G1 X92.343 Y107.348 E.01316
G1 X91.441 Y108.25 E.03103
G1 X91.441 Y108.714 E.01129
G1 X91.539 Y108.693 E.00244
G1 X92.563 Y107.669 E.03522
G1 X92.563 Y108.21 E.01316
G1 X91.949 Y108.824 E.02112
G1 E-5 F3600
G1 X91.949 Y108.824 F9000
G1 X90.967 Y110.485
G1 X90.906 Y110.588
G1 X90.864 Y110.666
G1 X90.801 Y110.844
G1 X90.77 Y110.993
G1 X90.762 Y111.036
G1 X90.753 Y111.183
G1 X90.751 Y111.214
G1 X90.751 Y112.786
G1 X90.753 Y112.817
G1 X90.762 Y112.964
G1 X91.277 Y115.874
G1 E5 F2400
G1 F3072.127
G1 X91.803 Y115.347 E.01811
G1 X92.344 Y115.348 E.01316
G1 X91.442 Y116.25 E.03103
G1 X91.442 Y116.713 E.01126
G1 X91.54 Y116.693 E.00243
G1 X92.563 Y115.67 E.03519
G1 X92.563 Y116.211 E.01316
G1 X91.95 Y116.824 E.02109
G1 E-5 F3600
G1 X91.95 Y116.824 F9000
G1 X90.967 Y118.485
G1 X90.906 Y118.588
G1 X90.864 Y118.666
G1 X90.801 Y118.844
G1 X90.77 Y118.993
G1 X90.762 Y119.036
G1 X90.753 Y119.183
G1 X90.751 Y119.214
G1 X90.751 Y120.786
G1 X90.753 Y120.817
G1 X90.762 Y120.964
G1 X91.279 Y123.872
G1 E5 F2400
G1 F3072.127
G1 X91.803 Y123.347 E.01804
G1 X92.343 Y123.348 E.01314
G1 X91.443 Y124.247 E.03094
G1 X91.443 Y124.706 E.01116
G1 X91.539 Y124.691 E.00236
G1 X92.563 Y123.667 E.03522
G1 X92.563 Y124.207 E.01313
G1 X91.954 Y124.817 E.02097
G1 E-5 F3600
G1 X91.954 Y124.817 F9000
G1 X90.967 Y126.485
G1 X90.906 Y126.588
G1 X90.864 Y126.666
G1 X90.801 Y126.844
G1 X90.77 Y126.993
G1 X90.762 Y127.036
G1 X90.753 Y127.183
G1 X90.751 Y127.214
G1 X90.751 Y128.786
G1 X90.753 Y128.817
G1 X90.762 Y128.964
G1 X91.28 Y131.86
G1 E5 F2400
G1 F3072.127
G1 X91.8 Y131.34 E.01789
G1 X92.343 Y131.341 E.01321
G1 X91.444 Y132.24 E.03093
G1 X91.444 Y132.706 E.01134
G1 X91.537 Y132.692 E.00229
G1 X92.569 Y131.66 E.0355
G1 X92.57 Y132.203 E.01321
G1 X91.956 Y132.817 E.02112
G1 E-5 F3600
G1 X91.956 Y132.817 F9000
G1 X90.967 Y134.485
G1 X90.906 Y134.588
G1 X90.864 Y134.666
G1 X90.801 Y134.844
G1 X90.77 Y134.993
G1 X90.762 Y135.036
G1 X90.753 Y135.183
G1 X90.751 Y135.214
G1 X90.751 Y136.786
G1 X90.753 Y136.817
G1 X90.762 Y136.964
G1 X91.281 Y139.897
G1 E5 F2400
G1 F3072.127
G1 X91.834 Y139.344 E.01902
G1 X92.38 Y139.345 E.01328
G1 X91.446 Y140.279 E.03213
G1 X91.446 Y140.713 E.01056
G1 X91.588 Y140.683 E.00353
G1 X92.926 Y139.345 E.04603
G1 X93.471 Y139.346 E.01326
G1 X92.158 Y140.659 E.04517
G1 X92.706 Y140.658 E.01333
G1 X94.017 Y139.347 E.0451
G1 X94.563 Y139.348 E.01328
G1 X93.254 Y140.657 E.04503
G1 X93.802 Y140.655 E.01333
G1 X94.845 Y139.612 E.03588
G1 X95.076 Y139.927 E.0095
G1 X94.349 Y140.654 E.02501
G1 X94.897 Y140.653 E.01333
G1 X95.317 Y140.233 E.01445
G1 X95.565 Y140.531 E.00943
G1 X95.28 Y140.816 E.0098
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X95.565 Y140.531 E-.19145
G1 X95.317 Y140.233 E-.18416
G1 X94.897 Y140.653 E-.28214
G1 X94.349 Y140.654 E-.2603
G1 X95.076 Y139.927 E-.48836
G1 X94.96 Y139.768 E-.09359
;WIPE_END
G1 X91.238 Y142.214 F9000
G1 X91.089 Y142.339
G1 X90.967 Y142.485
G1 X90.906 Y142.588
G1 X90.864 Y142.666
G1 X90.801 Y142.844
G1 X90.77 Y142.993
G1 X90.762 Y143.036
G1 X90.753 Y143.183
G1 X90.751 Y143.214
G1 X90.751 Y144.786
G1 X90.753 Y144.817
G1 X90.762 Y144.964
G1 X90.77 Y145.007
G1 X90.801 Y145.156
G1 X90.864 Y145.334
G1 X90.906 Y145.412
G1 X90.967 Y145.515
G1 X91.089 Y145.661
G1 X91.238 Y145.786
G1 X95.284 Y148.819
G1 E5 F2400
G1 F3072.127
G1 X95.862 Y148.241 E.01988
G1 X95.862 Y147.694 E.01331
G1 X94.901 Y148.655 E.03306
G1 X94.354 Y148.656 E.01331
G1 X95.659 Y147.351 E.04489
G1 X95.113 Y147.351 E.01328
G1 X93.806 Y148.657 E.04494
G1 X93.259 Y148.658 E.01331
G1 X94.567 Y147.35 E.04499
G1 X94.021 Y147.35 E.01328
G1 X92.711 Y148.659 E.04505
G1 X92.164 Y148.66 E.01331
G1 X93.475 Y147.349 E.0451
G1 X92.929 Y147.349 E.01328
G1 X91.595 Y148.682 E.04587
G1 X91.447 Y148.713 E.00368
G1 X91.447 Y148.284 E.01044
G1 X92.383 Y147.348 E.0322
G1 X91.837 Y147.347 E.01328
G1 X91.282 Y147.902 E.01909
G1 E-5 F3600
G1 X91.282 Y147.902 F9000
G1 X107.525 Y144.551
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.404064
G1 F1200
G1 X107.448 Y144.53 E.00196
G1 X107.469 Y144.608 E.00199
G1 X107.513 Y144.596 E.00112
;WIDTH:0.399999
G1 X108.003 Y144.561 E.01195
G1 X107.478 Y145.086 E.01806
G1 X107.478 Y145.086 F9000
G1 X107.35 Y145.916
;WIDTH:0.374336
G1 F1200
G1 X107.309 Y145.927 E.00096
G1 X107.29 Y145.856 E.00166
G1 X107.361 Y145.875 E.00166
;WIDTH:0.399999
G1 X107.451 Y145.63 E.00635
G1 X108.52 Y144.561 E.03677
G1 E-5 F3600
G1 X108.52 Y144.561 F9000
G1 X104.694 Y147.361
G1 E5 F2400
G1 F1200
G1 X105.576 Y147.36 E.02145
G1 X106.093 Y147.282 E.01272
G1 X106.536 Y147.078 E.01186
G1 X105.089 Y148.509 E.0495
G1 X105.089 Y148.639 E.00316
G1 X96.228 Y148.653 E.21554
G1 X96.228 Y147.352 E.03165
G1 X104.511 Y147.361 E.20148
G1 X104.511 Y147.772 E.01
;WIDTH:0.501333
G1 X96.644 Y147.769 E.24439
G1 X96.644 Y148.236 E.01451
G1 X104.693 Y148.229 E.25004
;WIDTH:0.491072
G1 X104.798 Y148.228 E.00319
G1 X105.244 Y147.772 E.01938
G1 X104.693 Y147.772 E.01674
G1 X104.693 Y147.772 F9000
G1 X106.562 Y147.058
;WIDTH:0.374336
G1 F1200
G1 X107.037 Y146.608 E.0148
;WIDTH:0.399999
G1 X107.248 Y146.35 E.00811
G1 X109.037 Y144.561 E.06154
G1 X109.554 Y144.561 E.01258
G1 X105.476 Y148.639 E.14028
G1 X105.938 Y148.694 E.01132
G1 X110.072 Y144.561 E.14219
G1 X110.594 Y144.555 E.0127
G1 X106.332 Y148.818 E.14663
G1 X106.666 Y149.001 E.00926
G1 X111.177 Y144.489 E.15519
G1 X111.695 Y144.489 E.0126
G1 X106.945 Y149.239 E.1634
G1 X107.17 Y149.531 E.00897
G1 X112.212 Y144.489 E.17344
G1 X112.729 Y144.489 E.01258
G1 X107.349 Y149.869 E.18507
G1 X107.454 Y150.281 E.01034
G1 X113.246 Y144.489 E.19924
G1 X113.763 Y144.489 E.01258
G1 X107.362 Y150.894 E.22026
;WIDTH:0.374336
G1 X107.291 Y150.875 E.00166
G1 X107.31 Y150.946 E.00166
G1 X107.351 Y150.935 E.00096
;WIDTH:0.399999
G1 X107.477 Y151.292 E.00921
G1 X114.28 Y144.489 E.23402
G1 X114.797 Y144.489 E.01258
G1 X107.477 Y151.809 E.2518
G1 X107.477 Y152.326 E.01258
G1 X115.314 Y144.489 E.26959
G1 X115.832 Y144.489 E.0126
G1 X107.477 Y152.844 E.28741
G1 X107.477 Y153.361 E.01258
G1 X116.349 Y144.489 E.30519
G1 X116.866 Y144.489 E.01258
G1 X107.405 Y153.949 E.32543
G1 X107.225 Y154.208 E.00767
;WIDTH:0.374336
G1 X106.989 Y154.532 E.00907
G1 X106.724 Y154.777 E.00816
G1 X106.672 Y154.884 E.00269
;WIDTH:0.399999
G1 X107.044 Y154.828 E.00915
G1 X117.383 Y144.489 E.35565
G1 X117.9 Y144.489 E.01258
G1 X107.561 Y154.828 E.35565
G1 X108.079 Y154.827 E.0126
G1 X118.417 Y144.489 E.35562
G1 X118.934 Y144.489 E.01258
G1 X108.596 Y154.827 E.35562
G1 X109.113 Y154.827 E.01258
G1 X119.451 Y144.489 E.35562
G1 X119.969 Y144.489 E.0126
G1 X109.63 Y154.827 E.35564
G1 X110.147 Y154.827 E.01258
G1 X120.419 Y144.556 E.35333
G1 X120.931 Y144.561 E.01245
G1 X110.665 Y154.827 E.35314
G1 X111.182 Y154.827 E.01258
G1 X121.448 Y144.561 E.35314
G1 X121.965 Y144.561 E.01258
G1 X111.699 Y154.827 E.35314
G1 X112.216 Y154.827 E.01258
G1 X122.481 Y144.562 E.35311
G1 X122.998 Y144.562 E.01258
G1 X112.734 Y154.827 E.35309
G1 X113.251 Y154.827 E.01258
G1 X123.515 Y144.562 E.35309
G1 X123.522 Y145.072 E.01241
G1 X113.768 Y154.827 E.33555
G1 X114.285 Y154.827 E.01258
G1 X123.541 Y145.571 E.3184
G1 X123.613 Y146.016 E.01096
G1 X114.802 Y154.826 E.30308
G1 X115.32 Y154.826 E.0126
G1 X123.768 Y146.378 E.29061
G1 X123.981 Y146.682 E.00903
G1 X115.837 Y154.826 E.28015
G1 X116.354 Y154.826 E.01258
G1 X124.247 Y146.933 E.27151
G1 X124.563 Y147.135 E.00912
G1 X116.871 Y154.826 E.26458
G1 X117.388 Y154.826 E.01258
G1 X124.929 Y147.286 E.25939
G1 X125.379 Y147.353 E.01107
G1 X117.906 Y154.826 E.25707
G1 X118.423 Y154.826 E.01258
G1 X125.888 Y147.361 E.25679
G1 X134.772 Y147.352 E.21609
G1 X134.772 Y148.653 E.03165
G1 X125.453 Y148.638 E.22668
G1 X125.073 Y148.693 E.00934
G1 X126.238 Y147.528 E.04008
G1 X126.511 Y147.837 E.01003
;WIDTH:0.491554
G1 X126.12 Y148.228 E.01682
G1 X126.67 Y148.229 E.01673
;WIDTH:0.501336
G1 X134.356 Y148.236 E.23877
G1 X134.356 Y147.769 E.01451
G1 X126.67 Y147.772 E.23877
G1 E-5 F3600
G1 X126.67 Y147.772 F9000
G1 X123.756 Y149.929
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X123.684 Y149.91 E.00168
G1 X123.703 Y149.981 E.00166
G1 X123.745 Y149.97 E.00098
;WIDTH:0.399999
G1 X123.567 Y150.198 E.00704
G1 X118.94 Y154.826 E.15918
G1 X119.457 Y154.826 E.01258
G1 X123.523 Y150.76 E.13987
G1 X123.523 Y151.277 E.01258
G1 X119.974 Y154.826 E.12208
G1 X120.381 Y155.012 E.01088
;WIDTH:0.374336
G1 X120.34 Y155.023 E.00096
G1 X120.321 Y154.952 E.00166
G1 X120.392 Y154.971 E.00166
;WIDTH:0.399999
G1 X120.492 Y154.826 E.00428
G1 X123.523 Y151.794 E.10428
G1 X123.523 Y153.435 E.03992
G1 X123.613 Y154.008 E.01411
G1 X123.891 Y154.564 E.01512
G1 X124.174 Y154.825 E.00936
G1 X121.009 Y154.825 E.07699
G1 X123.394 Y152.441 E.08203
G1 X123.394 Y152.441 F9000
G1 X123.157 Y153.194
G1 F1200
G1 X123.157 Y153.435 E.00586
G1 X123.233 Y154.004 E.01396
G1 X123.429 Y154.459 E.01205
G1 X121.892 Y154.46 E.03739
G1 X123.028 Y153.323 E.03909
G1 X123.028 Y153.323 F9000
G1 X122.895 Y154.052
;WIDTH:0.45712
G1 F1200
G1 X122.857 Y154.014 E.00151
G1 X122.806 Y154.028 E.00149
G1 X122.793 Y154.079 E.00148
G1 X122.83 Y154.116 E.00147
G1 X122.881 Y154.103 E.00148
;LAYER_CHANGE
;Z:1.9
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;1.9
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X122.83 Y154.116 E-.025
G1 X122.793 Y154.079 E-.02485
G1 X122.806 Y154.028 E-.025
G1 X122.857 Y154.014 E-.02512
G1 X122.895 Y154.052 E-.02553
;WIPE_END
G1 E-1.3745 F3600
G1 Z1.9 F9000
;AFTER_LAYER_CHANGE
;1.9
G1 Z1.9
G1 X125.954 Y146.146
G1 X133.864 Y146.149
G1 X139.217 Y146.044
G1 X139.3 Y146.039
G1 X139.403 Y146.026
G1 X139.578 Y145.973
G1 X139.748 Y145.884
G1 X139.898 Y145.768
G1 X140.023 Y145.628
G1 X140.122 Y145.47
G1 X140.15 Y145.403
G1 X140.196 Y145.284
G1 X140.237 Y145.104
G1 X140.242 Y145.028
G1 X140.249 Y144.935
G1 X140.249 Y93.234
G1 X140.241 Y93.132
G1 X140.235 Y93.072
G1 X140.189 Y92.895
G1 X140.112 Y92.728
G1 X140.008 Y92.577
G1 X139.88 Y92.446
G1 X139.73 Y92.339
G1 X139.563 Y92.259
G1 X126.349 Y88.151
G1 X120.357 Y86.599
G1 X120.273 Y85.302
G1 X120.32 Y85.631
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X120.274 Y85.65 E.00121
G1 X110.767 Y85.65 E.23125
G1 X110.355 Y85.5 E.01067
G1 X104.272 Y85.489 E.14796
G1 X103.754 Y85.414 E.01273
G1 X103.052 Y85.191 E.01792
G1 X102.405 Y84.835 E.01796
G1 X101.965 Y84.484 E.01369
G1 X101.587 Y84.077 E.01351
G1 X101.286 Y83.64 E.01291
G1 X100.971 Y82.971 E.01799
G1 X100.792 Y82.254 E.01798
G1 X100.75 Y81.693 E.01368
G1 X100.75 Y79.001 E.06548
G1 X100.687 Y78.863 E.00369
G1 X99.801 Y78.09 E.0286
G1 X99.357 Y77.629 E.01557
G1 X99.293 Y77.501 E.00348
G1 X99.331 Y77.398 E.00267
G1 X99.882 Y76.836 E.01914
G1 X100.575 Y76.234 E.02233
G1 X130.425 Y76.234 E.72607
G1 X131.121 Y76.839 E.02243
G1 X131.493 Y77.19 E.01244
G1 X131.699 Y77.494 E.00893
G1 X131.536 Y77.759 E.00757
G1 X131.202 Y78.088 E.0114
G1 X130.313 Y78.863 E.02869
G1 X130.25 Y79 E.00367
G1 X130.239 Y81.976 E.07239
G1 X130.165 Y82.485 E.01251
G1 X129.94 Y83.201 E.01826
G1 X129.581 Y83.85 E.01804
G1 X129.206 Y84.313 E.01449
G1 X128.824 Y84.666 E.01265
G1 X128.209 Y85.066 E.01785
G1 X127.546 Y85.338 E.01743
G1 X127.005 Y85.459 E.01348
G1 X126.443 Y85.5 E.01371
G1 X120.645 Y85.5 E.14103
G1 X120.376 Y85.609 E.00706
G1 X120.376 Y85.609 F9000
G1 X120.267 Y85.272
;TYPE:Perimeter
G1 F6000
G1 X120.239 Y85.284 E.00074
G1 X110.767 Y85.284 E.2304
G1 X110.657 Y85.225 E.00304
G1 X110.356 Y85.134 E.00765
G1 X104.516 Y85.124 E.14205
G1 X103.836 Y85.057 E.01662
G1 X103.197 Y84.853 E.01632
G1 X102.843 Y84.659 E.00982
G1 X102.4 Y84.363 E.01296
G1 X102.024 Y84.011 E.01253
G1 X101.604 Y83.457 E.01691
G1 X101.317 Y82.848 E.01638
G1 X101.154 Y82.196 E.01635
G1 X101.116 Y81.679 E.01261
G1 X101.116 Y79.001 E.06514
G1 X101.079 Y78.804 E.00488
G1 X100.927 Y78.587 E.00644
G1 X100.148 Y77.908 E.02514
G1 X99.742 Y77.501 E.01398
G1 X100.133 Y77.103 E.01357
G1 X100.711 Y76.6 E.01864
G1 X130.289 Y76.6 E.71946
G1 X130.883 Y77.117 E.01915
G1 X131.272 Y77.501 E.0133
G1 X130.955 Y77.818 E.0109
G1 X130.073 Y78.587 E.02846
G1 X129.921 Y78.803 E.00642
G1 X129.884 Y78.999 E.00485
G1 X129.874 Y81.735 E.06655
G1 X129.807 Y82.403 E.01633
G1 X129.602 Y83.056 E.01665
G1 X129.277 Y83.645 E.01636
G1 X129.075 Y83.894 E.0078
G1 X128.598 Y84.376 E.01649
G1 X128.039 Y84.741 E.01624
G1 X127.436 Y84.988 E.01585
G1 X126.951 Y85.096 E.01209
G1 X126.429 Y85.134 E.01273
G1 X120.645 Y85.134 E.14069
G1 X120.577 Y85.139 E.00166
G1 X120.322 Y85.249 E.00676
G1 X120.322 Y85.249 F9000
G1 X120.363 Y84.838
G1 F6000
G1 X120.144 Y84.919 E.00568
G1 X110.856 Y84.919 E.22592
G1 X110.58 Y84.797 E.00734
G1 X110.357 Y84.769 E.00547
G1 X104.517 Y84.758 E.14205
G1 X103.918 Y84.699 E.01464
G1 X103.342 Y84.516 E.0147
G1 X102.812 Y84.224 E.01472
G1 X102.292 Y83.762 E.01692
G1 X101.922 Y83.274 E.0149
G1 X101.663 Y82.725 E.01477
G1 X101.517 Y82.138 E.01471
G1 X101.481 Y81.665 E.01154
G1 X101.481 Y79.001 E.0648
G1 X101.421 Y78.673 E.00811
G1 X101.168 Y78.311 E.01074
G1 X100.252 Y77.504 E.02969
G1 X100.848 Y76.966 E.01953
G1 X130.152 Y76.966 E.71279
G1 X130.757 Y77.501 E.01964
G1 X129.832 Y78.311 E.02991
G1 X129.58 Y78.671 E.01069
G1 X129.519 Y78.997 E.00807
G1 X129.509 Y81.733 E.06655
G1 X129.45 Y82.321 E.01437
G1 X129.264 Y82.911 E.01505
G1 X129.093 Y83.221 E.00861
G1 X128.791 Y83.664 E.01304
G1 X128.373 Y84.086 E.01445
G1 X127.868 Y84.416 E.01467
G1 X127.588 Y84.53 E.00735
G1 X127.097 Y84.689 E.01255
G1 X126.416 Y84.769 E.01668
G1 X120.645 Y84.769 E.14037
G1 X120.531 Y84.776 E.00278
G1 X120.419 Y84.817 E.0029
G1 X120.419 Y84.817 F9000
G1 X120.249 Y84.495
G1 F6000
G1 X120.079 Y84.553 E.00437
G1 X110.921 Y84.553 E.22276
G1 X110.67 Y84.442 E.00668
G1 X110.357 Y84.403 E.00767
G1 X104.517 Y84.393 E.14205
G1 X104 Y84.341 E.01264
G1 X103.487 Y84.178 E.01309
G1 X103.016 Y83.919 E.01307
G1 X102.56 Y83.513 E.01485
G1 X102.24 Y83.091 E.01288
G1 X102.009 Y82.602 E.01315
G1 X101.879 Y82.079 E.01311
G1 X101.847 Y81.651 E.01044
G1 X101.847 Y79.001 E.06446
G1 X101.762 Y78.542 E.01135
G1 X101.408 Y78.036 E.01502
G1 X100.792 Y77.499 E.01988
G1 X100.985 Y77.331 E.00622
G1 X130.015 Y77.331 E.70613
G1 X130.208 Y77.499 E.00622
G1 X129.592 Y78.036 E.01988
G1 X129.239 Y78.539 E.01495
G1 X129.153 Y78.996 E.01131
G1 X129.143 Y81.732 E.06655
G1 X129.092 Y82.24 E.01242
G1 X128.926 Y82.767 E.01344
G1 X128.797 Y83 E.00648
G1 X128.506 Y83.434 E.01271
G1 X128.148 Y83.797 E.0124
G1 X127.698 Y84.091 E.01307
G1 X127.017 Y84.332 E.01757
G1 X126.402 Y84.403 E.01506
G1 X120.645 Y84.403 E.14003
G1 X120.486 Y84.413 E.00388
G1 X120.306 Y84.475 E.00463
G1 X120.306 Y84.475 F9000
G1 X120.132 Y84.145
G1 F6000
G1 X120.015 Y84.187 E.00302
G1 X110.985 Y84.187 E.21965
G1 X110.76 Y84.088 E.00598
G1 X110.358 Y84.037 E.00986
G1 X105.373 Y84.029 E.12126
G1 X104.241 Y84.007 E.02754
G1 X103.632 Y83.84 E.01536
G1 X103.083 Y83.505 E.01564
G1 X102.731 Y83.16 E.01199
G1 X102.454 Y82.689 E.01329
G1 X102.29 Y82.218 E.01213
G1 X102.213 Y81.638 E.01423
G1 X102.213 Y79.001 E.06414
G1 X102.103 Y78.411 E.0146
G1 X101.576 Y77.697 E.02159
G1 X129.424 Y77.697 E.67737
G1 X129.352 Y77.76 E.00233
G1 X128.898 Y78.407 E.01923
G1 X128.787 Y78.995 E.01456
G1 X128.757 Y82.003 E.07317
G1 X128.588 Y82.622 E.01561
G1 X128.363 Y83.03 E.01133
G1 X128.037 Y83.402 E.01203
G1 X127.527 Y83.765 E.01523
G1 X126.937 Y83.975 E.01523
G1 X126.389 Y84.037 E.01341
G1 X120.645 Y84.037 E.13972
G1 X120.361 Y84.062 E.00693
G1 X120.189 Y84.124 E.00445
G1 E-5 F3600
G1 X120.189 Y84.124 F9000
G1 X102.87 Y83.049
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.374336
G1 F1200
G1 X103.313 Y83.476 E.01392
;WIDTH:0.399999
G1 X103.809 Y83.609 E.01249
G1 X102.64 Y82.44 E.04021
G1 X102.456 Y82.295 E.0057
;WIDTH:0.374336
G1 X102.377 Y81.928 E.00849
;WIDTH:0.399999
G1 X102.498 Y81.781 E.00463
G1 X104.47 Y83.753 E.06784
G1 X104.988 Y83.754 E.0126
G1 X102.487 Y81.252 E.08605
G1 X102.487 Y80.735 E.01258
G1 X105.506 Y83.755 E.10387
G1 X106.024 Y83.755 E.0126
G1 X102.487 Y80.218 E.12167
G1 X102.487 Y79.701 E.01258
G1 X106.542 Y83.756 E.13949
G1 X107.06 Y83.757 E.0126
G1 X102.487 Y79.184 E.15731
G1 X102.413 Y78.593 E.01449
G1 X107.578 Y83.758 E.17767
G1 X108.096 Y83.759 E.0126
G1 X102.309 Y77.971 E.19909
G1 X102.079 Y77.902 E.00584
;WIDTH:0.374336
G1 X102.09 Y77.943 E.00096
G1 X102.019 Y77.962 E.00166
G1 X102.038 Y77.891 E.00166
G1 X102.038 Y77.891 F9000
G1 X102.826 Y77.971
;WIDTH:0.399999
G1 F1200
G1 X108.614 Y83.76 E.19912
G1 X109.132 Y83.761 E.0126
G1 X103.343 Y77.971 E.19915
G1 X103.86 Y77.971 E.01258
G1 X109.65 Y83.762 E.19919
G1 X110.168 Y83.763 E.0126
G1 X104.377 Y77.971 E.19922
G1 X104.894 Y77.971 E.01258
G1 X110.732 Y83.809 E.20082
G1 X111.353 Y83.913 E.01532
G1 X105.411 Y77.971 E.2044
G1 X105.928 Y77.971 E.01258
G1 X111.87 Y83.913 E.2044
G1 X112.387 Y83.913 E.01258
G1 X106.446 Y77.971 E.20438
G1 X106.963 Y77.971 E.01258
G1 X112.904 Y83.913 E.20438
G1 X113.422 Y83.913 E.0126
G1 X107.48 Y77.971 E.2044
G1 X107.997 Y77.971 E.01258
G1 X113.939 Y83.913 E.2044
G1 X114.456 Y83.913 E.01258
G1 X108.514 Y77.971 E.2044
G1 X109.031 Y77.971 E.01258
G1 X114.973 Y83.913 E.2044
G1 X115.49 Y83.913 E.01258
G1 X109.548 Y77.971 E.2044
G1 X110.065 Y77.971 E.01258
G1 X116.007 Y83.913 E.2044
G1 X116.524 Y83.913 E.01258
G1 X110.583 Y77.971 E.20438
G1 X111.1 Y77.971 E.01258
G1 X117.041 Y83.913 E.20438
G1 X117.559 Y83.913 E.0126
G1 X111.617 Y77.971 E.2044
G1 X112.134 Y77.971 E.01258
G1 X118.076 Y83.913 E.2044
G1 X118.593 Y83.913 E.01258
G1 X112.651 Y77.971 E.2044
G1 X113.168 Y77.971 E.01258
G1 X119.11 Y83.913 E.2044
G1 X119.627 Y83.913 E.01258
G1 X113.685 Y77.971 E.2044
G1 X114.202 Y77.971 E.01258
G1 X120.089 Y83.858 E.20251
G1 X120.519 Y83.771 E.01067
G1 X114.72 Y77.971 E.1995
G1 X115.237 Y77.971 E.01258
G1 X121.028 Y83.763 E.19922
G1 X121.546 Y83.763 E.0126
G1 X115.754 Y77.971 E.19924
G1 X116.271 Y77.971 E.01258
G1 X122.063 Y83.763 E.19924
G1 X122.58 Y83.763 E.01258
G1 X116.788 Y77.971 E.19924
G1 X117.305 Y77.971 E.01258
G1 X123.097 Y83.763 E.19924
G1 X123.614 Y83.763 E.01258
G1 X117.822 Y77.971 E.19924
G1 X118.339 Y77.971 E.01258
G1 X124.131 Y83.763 E.19924
G1 X124.648 Y83.763 E.01258
G1 X118.857 Y77.971 E.19922
G1 X119.374 Y77.971 E.01258
G1 X125.165 Y83.763 E.19922
G1 X125.683 Y83.763 E.0126
G1 X119.891 Y77.971 E.19924
G1 X120.408 Y77.971 E.01258
G1 X126.2 Y83.763 E.19924
G1 X126.694 Y83.74 E.01203
G1 X120.925 Y77.971 E.19845
G1 X121.442 Y77.971 E.01258
G1 X127.11 Y83.639 E.19498
G1 X127.466 Y83.478 E.0095
G1 X121.959 Y77.971 E.18944
G1 X122.476 Y77.971 E.01258
G1 X127.775 Y83.27 E.18228
G1 X128.029 Y83.007 E.00889
G1 X122.994 Y77.971 E.17322
G1 X123.511 Y77.971 E.01258
G1 X128.235 Y82.695 E.1625
G1 X128.391 Y82.335 E.00954
G1 X124.028 Y77.971 E.1501
G1 X124.545 Y77.971 E.01258
G1 X128.492 Y81.919 E.13579
G1 X128.504 Y81.414 E.01229
G1 X125.062 Y77.971 E.11842
G1 X125.579 Y77.971 E.01258
G1 X128.506 Y80.898 E.10069
G1 X128.508 Y80.383 E.01253
G1 X126.096 Y77.971 E.08297
G1 X126.613 Y77.971 E.01258
G1 X128.51 Y79.868 E.06526
G1 X128.512 Y79.353 E.01253
G1 X127.131 Y77.971 E.04752
G1 X127.648 Y77.971 E.01258
G1 X128.537 Y78.86 E.03058
G1 X128.619 Y78.425 E.01077
G1 X128.165 Y77.971 E.01562
G1 X128.775 Y77.961 E.01484
;WIDTH:0.489148
G1 X128.735 Y78.001 E.00171
G1 X128.749 Y78.056 E.00172
G1 X128.804 Y78.071 E.00172
G1 X128.844 Y78.031 E.00171
G1 X128.83 Y77.976 E.00172
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X128.844 Y78.031 E-.02696
G1 X128.804 Y78.071 E-.02687
G1 X128.749 Y78.056 E-.02708
G1 X128.735 Y78.001 E-.02696
G1 X128.775 Y77.961 E-.02687
G1 X128.165 Y77.971 E-.28979
G1 X128.619 Y78.425 E-.30498
G1 X128.537 Y78.86 E-.21026
G1 X127.703 Y78.026 E-.56023
;WIPE_END
G1 X126.923 Y85.118 F9000
G1 X126.76 Y86.599
G1 X126.499 Y88.97
G1 X126.349 Y93.548
G1 X126.034 Y93.2
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X138.859 Y93.2 E.31196
G1 X139.095 Y93.247 E.00585
G1 X139.203 Y93.357 E.00375
G1 X139.25 Y93.592 E.00583
G1 X139.243 Y95.34 E.04252
G1 X139.133 Y95.559 E.00596
G1 X138.933 Y95.629 E.00515
G1 X136.183 Y95.63 E.06689
G1 X136.074 Y95.667 E.0028
G1 X136 Y95.813 E.00398
G1 X136 Y132.295 E.88739
G1 X135.953 Y133.251 E.02328
G1 X135.828 Y134.126 E.0215
G1 X135.72 Y134.623 E.01237
G1 X135.292 Y135.957 E.03408
G1 X134.702 Y137.172 E.03285
G1 X134.438 Y137.607 E.01238
G1 X133.896 Y138.367 E.02271
G1 X133.317 Y139.036 E.02152
G1 X132.957 Y139.398 E.01242
G1 X132.251 Y140.008 E.02269
G1 X131.531 Y140.522 E.02152
G1 X131.098 Y140.788 E.01236
G1 X129.837 Y141.4 E.03409
G1 X128.551 Y141.813 E.03285
G1 X128.056 Y141.923 E.01233
G1 X126.663 Y142.089 E.03412
G1 X120.644 Y142.1 E.14641
G1 X120.272 Y142.25 E.00976
G1 X110.767 Y142.25 E.2312
G1 X110.355 Y142.1 E.01067
G1 X104.802 Y142.1 E.13507
G1 X104.286 Y142.086 E.01256
G1 X103.406 Y142.001 E.0215
G1 X102.444 Y141.812 E.02385
G1 X101.598 Y141.562 E.02146
G1 X100.731 Y141.216 E.02271
G1 X100.272 Y140.991 E.01243
G1 X99.507 Y140.548 E.0215
G1 X98.746 Y140.007 E.02271
G1 X98.353 Y139.681 E.01242
G1 X97.714 Y139.07 E.0215
G1 X97.102 Y138.366 E.02269
G1 X96.796 Y137.956 E.01244
G1 X96.319 Y137.211 E.02152
G1 X95.89 Y136.383 E.02268
G1 X95.69 Y135.912 E.01245
G1 X95.402 Y135.079 E.02144
G1 X95.102 Y133.711 E.03407
G1 X95.009 Y132.718 E.02426
G1 X94.999 Y95.813 E.89768
G1 X94.926 Y95.667 E.00397
G1 X94.816 Y95.63 E.00282
G1 X92.038 Y95.623 E.06757
G1 X91.821 Y95.51 E.00595
G1 X91.75 Y95.295 E.00551
G1 X91.757 Y93.46 E.04463
G1 X91.861 Y93.274 E.00518
G1 X92.068 Y93.2 E.00535
G1 X104.94 Y93.199 E.3131
G1 X105 Y93.235 E.0017
G1 X105 Y135.999 E1.04019
G1 X104.249 Y136.659 E.02432
G1 X103.756 Y137.186 E.01755
G1 X103.651 Y137.443 E.00675
G1 X103.73 Y137.767 E.00811
G1 X103.89 Y137.959 E.00608
G1 X104.361 Y138.443 E.01643
G1 X105 Y139.001 E.02064
G1 X105 Y139.317 E.00769
G1 X105.031 Y139.419 E.00259
G1 X105.183 Y139.5 E.00419
G1 X125.817 Y139.5 E.5019
G1 X125.906 Y139.477 E.00224
G1 X125.988 Y139.384 E.00302
G1 X126 Y139 E.00934
G1 X126.898 Y138.203 E.02921
G1 X127.26 Y137.784 E.01347
G1 X127.344 Y137.581 E.00534
G1 X127.334 Y137.378 E.00494
G1 X127.074 Y136.983 E.0115
G1 X126.738 Y136.647 E.01156
G1 X126 Y135.999 E.02389
G1 X126 Y93.259 E1.03961
G1 X126.004 Y93.252 E.0002
G1 X126.448 Y93.566 F9000
;TYPE:Perimeter
G1 F6000
G1 X138.859 Y93.566 E.30189
G1 X138.885 Y93.592 E.00089
G1 X138.885 Y95.263 E.04065
G1 X136.183 Y95.264 E.06572
G1 X135.854 Y95.374 E.00844
G1 X135.677 Y95.602 E.00702
G1 X135.635 Y95.813 E.00523
G1 X135.634 Y132.286 E.88717
G1 X135.589 Y133.216 E.02265
G1 X135.491 Y133.901 E.01683
G1 X135.367 Y134.528 E.01555
G1 X134.952 Y135.82 E.03301
G1 X134.46 Y136.833 E.02739
G1 X134.133 Y137.406 E.01605
G1 X133.608 Y138.141 E.02197
G1 X133.12 Y138.705 E.01814
G1 X132.707 Y139.13 E.01441
G1 X132.025 Y139.721 E.02195
G1 X131.396 Y140.169 E.01878
G1 X130.922 Y140.467 E.01362
G1 X129.701 Y141.059 E.03301
G1 X128.527 Y141.436 E.02999
G1 X127.995 Y141.562 E.0133
G1 X126.641 Y141.723 E.03317
G1 X120.644 Y141.735 E.14587
G1 X120.55 Y141.743 E.00229
G1 X120.233 Y141.885 E.00845
G1 X110.767 Y141.885 E.23025
G1 X110.657 Y141.825 E.00305
G1 X110.355 Y141.735 E.00767
G1 X104.82 Y141.735 E.13463
G1 X104.309 Y141.721 E.01243
G1 X103.459 Y141.638 E.02077
G1 X102.531 Y141.456 E.023
G1 X101.718 Y141.216 E.02062
G1 X100.951 Y140.91 E.02009
G1 X100.445 Y140.668 E.01364
G1 X99.705 Y140.24 E.02079
G1 X99.051 Y139.776 E.0195
G1 X98.597 Y139.408 E.01422
G1 X97.979 Y138.818 E.02078
G1 X97.472 Y138.234 E.01881
G1 X97.097 Y137.748 E.01493
G1 X96.636 Y137.028 E.0208
G1 X96.294 Y136.367 E.0181
G1 X96.031 Y135.781 E.01562
G1 X95.754 Y134.979 E.02064
G1 X95.463 Y133.654 E.033
G1 X95.374 Y132.701 E.02328
G1 X95.365 Y95.813 E.89726
G1 X95.322 Y95.602 E.00524
G1 X95.145 Y95.374 E.00702
G1 X94.816 Y95.264 E.00844
G1 X92.116 Y95.263 E.06567
G1 X92.123 Y93.566 E.04128
G1 X104.634 Y93.565 E.30432
G1 X104.634 Y135.834 E1.02815
G1 X103.982 Y136.409 E.02115
G1 X103.489 Y136.936 E.01755
G1 X103.374 Y137.126 E.0054
G1 X103.281 Y137.503 E.00945
G1 X103.401 Y137.931 E.01081
G1 X103.628 Y138.214 E.00882
G1 X104.121 Y138.719 E.01717
G1 X104.634 Y139.167 E.01657
G1 X104.634 Y139.317 E.00365
G1 X104.728 Y139.623 E.00779
G1 X104.903 Y139.789 E.00587
G1 X105.183 Y139.866 E.00706
G1 X125.817 Y139.866 E.5019
G1 X126.082 Y139.797 E.00666
G1 X126.238 Y139.668 E.00492
G1 X126.328 Y139.516 E.0043
G1 X126.366 Y139.165 E.00859
G1 X127.175 Y138.442 E.02639
G1 X127.537 Y138.023 E.01347
G1 X127.65 Y137.823 E.00559
G1 X127.718 Y137.543 E.00701
G1 X127.667 Y137.209 E.00822
G1 X127.346 Y136.735 E.01392
G1 X126.979 Y136.372 E.01256
G1 X126.366 Y135.834 E.01984
G1 X126.366 Y93.566 E1.02813
G1 X126.388 Y93.566 E.00054
G1 X126.388 Y93.566 F9000
G1 X126.731 Y94.121
G1 F6000
G1 X126.731 Y93.931 E.00462
G1 X138.519 Y93.931 E.28673
G1 X138.519 Y94.897 E.0235
G1 X136.183 Y94.899 E.05682
G1 X136.025 Y94.913 E.00386
G1 X135.635 Y95.082 E.01034
G1 X135.339 Y95.461 E.0117
G1 X135.269 Y95.813 E.00873
G1 X135.269 Y132.278 E.88697
G1 X135.225 Y133.181 E.02199
G1 X135.129 Y133.849 E.01642
G1 X135.013 Y134.433 E.01448
G1 X134.611 Y135.684 E.03196
G1 X134.131 Y136.674 E.02676
G1 X133.827 Y137.205 E.01488
G1 X133.321 Y137.914 E.02119
G1 X132.844 Y138.465 E.01773
G1 X132.458 Y138.863 E.01349
G1 X131.799 Y139.433 E.02119
G1 X131.184 Y139.872 E.01838
G1 X130.746 Y140.146 E.01257
G1 X129.565 Y140.719 E.03193
G1 X128.646 Y141.014 E.02348
G1 X127.933 Y141.201 E.01793
G1 X126.619 Y141.358 E.03219
G1 X120.643 Y141.369 E.14536
G1 X120.487 Y141.383 E.00381
G1 X120.146 Y141.519 E.00893
G1 X110.857 Y141.519 E.22595
G1 X110.747 Y141.457 E.00307
G1 X110.355 Y141.369 E.00977
G1 X105.183 Y141.369 E.1258
G1 X104.332 Y141.355 E.0207
G1 X103.512 Y141.276 E.02004
G1 X102.618 Y141.101 E.02216
G1 X101.837 Y140.871 E.0198
G1 X101.086 Y140.57 E.01968
G1 X100.617 Y140.345 E.01265
G1 X99.903 Y139.932 E.02006
G1 X99.263 Y139.478 E.01909
G1 X98.84 Y139.135 E.01325
G1 X98.243 Y138.565 E.02008
G1 X97.748 Y137.995 E.01836
G1 X97.398 Y137.539 E.01398
G1 X96.953 Y136.845 E.02005
G1 X96.619 Y136.199 E.01769
G1 X96.373 Y135.649 E.01466
G1 X96.107 Y134.88 E.01979
G1 X95.825 Y133.598 E.03193
G1 X95.74 Y132.684 E.02233
G1 X95.73 Y95.813 E.89685
G1 X95.66 Y95.461 E.00873
G1 X95.365 Y95.082 E.01168
G1 X94.817 Y94.899 E.01405
G1 X92.483 Y94.897 E.05677
G1 X92.487 Y93.931 E.0235
G1 X104.269 Y93.931 E.28659
G1 X104.269 Y135.668 E1.01521
G1 X103.715 Y136.16 E.01802
G1 X103.222 Y136.686 E.01754
G1 X103.048 Y136.955 E.00779
G1 X102.917 Y137.435 E.0121
G1 X102.946 Y137.718 E.00692
G1 X103.12 Y138.181 E.01203
G1 X103.366 Y138.469 E.00921
G1 X103.88 Y138.994 E.01787
G1 X104.272 Y139.336 E.01265
G1 X104.314 Y139.6 E.0065
G1 X104.424 Y139.827 E.00614
G1 X104.717 Y140.104 E.00981
G1 X104.963 Y140.204 E.00646
G1 X105.183 Y140.231 E.00539
G1 X125.817 Y140.231 E.5019
G1 X125.977 Y140.217 E.00391
G1 X126.259 Y140.117 E.00728
G1 X126.519 Y139.903 E.00819
G1 X126.669 Y139.649 E.00718
G1 X126.729 Y139.332 E.00785
G1 X127.451 Y138.681 E.02365
G1 X127.813 Y138.262 E.01347
G1 X127.999 Y137.934 E.00917
G1 X128.083 Y137.554 E.00947
G1 X128.06 Y137.283 E.00662
G1 X127.939 Y136.934 E.00898
G1 X127.62 Y136.492 E.01326
G1 X127.22 Y136.097 E.01367
G1 X126.731 Y135.668 E.01582
G1 X126.731 Y94.181 E1.00913
G1 E-5 F3600
G1 X126.731 Y94.181 F9000
G1 X135.94 Y94.426
G1 E5 F2400
;WIDTH:0.657402
G1 F6000
G1 X136.183 Y94.415 E.01008
;WIDTH:0.63622
G1 X138.036 Y94.414 E.07419
G1 E-5 F3600
G1 X138.036 Y94.414 F9000
G1 X135.94 Y94.426
G1 E5 F2400
;WIDTH:0.657402
G1 F6000
G1 X135.852 Y94.486 E.00441
;WIDTH:0.614502
G1 X135.765 Y94.547 E.0041
;WIDTH:0.571601
G1 X135.677 Y94.607 E.00381
;WIDTH:0.528701
G1 X135.59 Y94.668 E.00349
;WIDTH:0.4858
G1 X135.503 Y94.729 E.00319
;WIDTH:0.4429
G1 X135.415 Y94.789 E.00289
;WIDTH:0.399999
G1 X135.002 Y95.321 E.01638
G1 X134.903 Y95.813 E.01221
G1 X134.903 Y132.269 E.88676
G1 X134.86 Y133.146 E.02136
G1 X134.767 Y133.797 E.016
G1 X134.66 Y134.339 E.01344
G1 X134.271 Y135.547 E.03087
G1 X133.738 Y136.647 E.02973
G1 X133.455 Y137.097 E.01293
G1 X132.95 Y137.784 E.02074
G1 X132.454 Y138.348 E.01827
G1 X132.05 Y138.733 E.01357
G1 X131.499 Y139.198 E.01754
G1 X130.57 Y139.825 E.02726
G1 X129.428 Y140.379 E.03087
G1 X128.534 Y140.666 E.02284
G1 X127.872 Y140.84 E.01665
G1 X126.58 Y140.992 E.03164
;WIDTH:0.41544
G1 X125.818 Y140.986 E.01932
;WIDTH:0.42029
G1 X120.642 Y140.993 E.13289
;WIDTH:0.431526
G1 X120.421 Y141.007 E.00585
;WIDTH:0.463406
G1 X120.229 Y141.056 E.00566
;WIDTH:0.495286
G1 X120.038 Y141.106 E.00605
G1 X111.022 Y141.106 E.27645
G1 X110.639 Y141.038 E.01193
;WIDTH:0.457786
G1 X110.355 Y140.993 E.0081
;WIDTH:0.420285
G1 X104.344 Y140.989 E.15432
;WIDTH:0.399999
G1 X103.538 Y140.908 E.0197
G1 X102.64 Y140.726 E.02229
G1 X101.752 Y140.443 E.02267
G1 X100.789 Y140.023 E.02555
G1 X100.101 Y139.624 E.01935
G1 X99.475 Y139.18 E.01867
G1 X99.083 Y138.861 E.01229
G1 X98.508 Y138.312 E.01934
G1 X98.024 Y137.755 E.01795
G1 X97.699 Y137.331 E.01299
G1 X97.27 Y136.662 E.01933
G1 X96.943 Y136.031 E.01729
G1 X96.714 Y135.518 E.01367
G1 X96.459 Y134.781 E.01897
G1 X96.187 Y133.541 E.03088
G1 X96.106 Y132.667 E.02135
G1 X96.096 Y95.813 E.89644
G1 X95.997 Y95.321 E.01221
G1 X95.584 Y94.789 E.01638
;WIDTH:0.447271
G1 X95.431 Y94.714 E.00468
;WIDTH:0.494543
G1 X95.277 Y94.64 E.00523
;WIDTH:0.541815
G1 X95.124 Y94.565 E.00575
;WIDTH:0.589086
G1 X94.97 Y94.49 E.00632
;WIDTH:0.636358
G1 X94.817 Y94.415 E.00682
G1 X95.003 Y94.391 E.00751
;WIDTH:0.589086
G1 X95.19 Y94.368 E.00695
;WIDTH:0.541815
G1 X95.376 Y94.344 E.00633
;WIDTH:0.494543
G1 X95.562 Y94.32 E.00574
;WIDTH:0.447271
G1 X95.748 Y94.297 E.00515
;WIDTH:0.399999
G1 X103.903 Y94.296 E.19836
G1 X103.903 Y135.502 E1.00229
G1 X103.448 Y135.91 E.01487
G1 X102.955 Y136.437 E.01755
G1 X102.784 Y136.668 E.00699
G1 X102.621 Y137.063 E.01039
G1 X102.552 Y137.416 E.00875
G1 X102.613 Y137.882 E.01143
G1 X102.806 Y138.369 E.01274
G1 X103.103 Y138.723 E.01124
G1 X103.937 Y139.529 E.02821
G1 X103.966 Y139.713 E.00453
G1 X104.121 Y140.031 E.0086
G1 X104.531 Y140.418 E.01371
;WIDTH:0.442418
G1 X104.87 Y140.58 E.0102
G1 X105.183 Y140.607 E.00853
;WIDTH:0.420285
G1 X110.355 Y140.607 E.13278
;WIDTH:0.457786
G1 X110.689 Y140.626 E.00942
;WIDTH:0.495286
G1 X111.022 Y140.645 E.01023
G1 X119.978 Y140.645 E.27461
G1 X120.31 Y140.626 E.0102
;WIDTH:0.457788
G1 X120.642 Y140.607 E.00937
;WIDTH:0.42029
G1 X125.817 Y140.605 E.13286
;WIDTH:0.426638
G1 X126.043 Y140.59 E.00591
G1 X126.436 Y140.437 E.01101
;WIDTH:0.399999
G1 X126.8 Y140.137 E.01147
G1 X127.01 Y139.782 E.01003
G1 X127.065 Y139.523 E.00644
G1 X127.728 Y138.92 E.0218
G1 X128.096 Y138.494 E.01369
G1 X128.347 Y138.045 E.01251
G1 X128.449 Y137.566 E.01191
G1 X128.406 Y137.142 E.01037
G1 X128.254 Y136.748 E.01027
G1 X127.907 Y136.265 E.01447
G1 X127.504 Y135.861 E.01388
G1 X127.097 Y135.502 E.0132
G1 X127.097 Y94.297 E1.00227
G1 X135.251 Y94.297 E.19834
;WIDTH:0.4429
G1 X135.366 Y94.318 E.00318
;WIDTH:0.4858
G1 X135.481 Y94.34 E.00352
;WIDTH:0.528701
G1 X135.595 Y94.361 E.00381
;WIDTH:0.571601
G1 X135.71 Y94.383 E.00418
;WIDTH:0.614502
G1 X135.825 Y94.404 E.00451
;WIDTH:0.657402
G1 X135.881 Y94.415 E.00237
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X135.94 Y94.426 E-.02851
G1 X135.852 Y94.486 E-.05059
G1 X135.765 Y94.547 E-.05047
G1 X135.677 Y94.607 E-.05059
G1 X135.59 Y94.668 E-.05047
G1 X135.503 Y94.729 E-.05047
G1 X135.415 Y94.789 E-.05059
G1 X135.002 Y95.321 E-.31991
G1 X134.903 Y95.813 E-.23838
G1 X134.903 Y97.097 E-.61002
;WIPE_END
G1 X103.537 Y94.662 F9000
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X103.537 Y135.337 E.98938
G1 X103.181 Y135.66 E.01169
G1 X102.615 Y136.271 E.02026
G1 X102.374 Y136.671 E.01136
G1 X102.226 Y137.113 E.01134
G1 X102.185 Y137.539 E.01041
G1 X102.265 Y137.995 E.01126
G1 X102.493 Y138.558 E.01477
G1 X102.841 Y138.978 E.01327
G1 X103.601 Y139.722 E.02587
G1 X103.618 Y139.826 E.00256
G1 X103.817 Y140.235 E.01106
G1 X104.213 Y140.609 E.01325
G1 X103.608 Y140.55 E.01479
G1 X102.743 Y140.375 E.02147
G1 X101.888 Y140.103 E.02182
G1 X101.294 Y139.863 E.01558
G1 X100.701 Y139.549 E.01632
G1 X100.25 Y139.282 E.01275
G1 X99.327 Y138.588 E.02809
G1 X98.773 Y138.06 E.01862
G1 X98.323 Y137.541 E.01671
G1 X98 Y137.123 E.01285
G1 X97.587 Y136.479 E.01861
G1 X97.268 Y135.863 E.01687
G1 X97.055 Y135.386 E.01271
G1 X96.812 Y134.682 E.01812
G1 X96.549 Y133.485 E.02981
G1 X96.471 Y132.649 E.02042
G1 X96.462 Y95.813 E.896
G1 X96.335 Y95.18 E.0157
G1 X95.933 Y94.662 E.01595
G1 X103.477 Y94.662 E.1835
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.537 Y94.662 E-.0285
G1 X103.537 Y97.76 E-1.4715
;WIPE_END
G1 X127.463 Y94.663 F9000
G1 E5 F2400
G1 F6000
G1 X135.067 Y94.663 E.18496
G1 X134.664 Y95.18 E.01594
G1 X134.538 Y95.813 E.0157
G1 X134.537 Y132.26 E.88654
G1 X134.496 Y133.111 E.02072
G1 X134.405 Y133.745 E.01558
G1 X134.306 Y134.244 E.01237
G1 X133.931 Y135.411 E.02982
G1 X133.473 Y136.355 E.02552
G1 X133.158 Y136.884 E.01498
G1 X132.674 Y137.544 E.01991
G1 X132.195 Y138.09 E.01767
G1 X131.81 Y138.456 E.01292
G1 X131.287 Y138.9 E.01669
G1 X130.394 Y139.504 E.02622
G1 X129.292 Y140.039 E.0298
G1 X128.423 Y140.318 E.0222
G1 X127.811 Y140.479 E.01539
G1 X126.805 Y140.599 E.02464
G1 X127.081 Y140.371 E.00871
G1 X127.35 Y139.914 E.0129
G1 X127.401 Y139.714 E.00502
G1 X128.005 Y139.159 E.01995
G1 X128.373 Y138.733 E.01369
G1 X128.709 Y138.116 E.01709
G1 X128.814 Y137.577 E.01336
G1 X128.801 Y137.311 E.00648
G1 X128.695 Y136.827 E.01205
G1 X128.482 Y136.43 E.01096
G1 X128.043 Y135.872 E.01727
G1 X127.463 Y135.337 E.01919
G1 X127.463 Y94.723 E.98789
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X127.463 Y94.663 E-.0285
G1 X130.561 Y94.663 E-1.4715
;WIPE_END
G1 X92.968 Y94.414 F9000
G1 E5 F2400
;WIDTH:0.636358
G1 F6000
G1 X94.817 Y94.415 E.07405
G1 E-5 F3600
G1 X95.348 Y95.279 F9000
G1 X98.267 Y137.237
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.374336
G1 F1200
G1 X98.905 Y137.932 E.02134
G1 X99.734 Y138.724 E.02593
G1 X99.734 Y138.724 F9000
G1 X100.69 Y139.24
G1 F1200
G1 X100.671 Y139.311 E.00166
G1 X100.742 Y139.292 E.00166
G1 X100.731 Y139.251 E.00096
;WIDTH:0.399999
G1 X100.442 Y139.082 E.00814
G1 X98.044 Y136.684 E.08249
G1 X97.874 Y136.395 E.00816
;WIDTH:0.374336
G1 X97.885 Y136.436 E.00096
G1 X97.814 Y136.455 E.00166
G1 X97.833 Y136.384 E.00166
G1 X97.833 Y136.384 F9000
G1 X97.42 Y135.543
;WIDTH:0.399999
G1 F1200
G1 X101.55 Y139.673 E.14207
G1 X101.798 Y139.802 E.0068
;WIDTH:0.374336
G1 X101.779 Y139.873 E.00166
G1 X101.85 Y139.854 E.00166
G1 X101.839 Y139.813 E.00096
;WIDTH:0.399999
G1 X102.375 Y139.981 E.01366
G1 X97.116 Y134.721 E.18092
G1 X96.952 Y134.041 E.01701
G1 X102.725 Y139.814 E.19859
G1 X102.868 Y140.132 E.00848
;WIDTH:0.386391
G1 X102.93 Y140.102 E.00161
G1 X103.241 Y139.756 E.0109
G1 X103.351 Y139.857 E.0035
G1 X103.543 Y140.259 E.01043
G1 X103.048 Y140.166 E.0118
;WIDTH:0.399999
G1 X102.948 Y139.519 E.01592
G1 X96.816 Y133.387 E.21094
G1 X96.762 Y132.817 E.01393
G1 X101.999 Y138.053 E.18013
G1 X102.156 Y138.271 E.00653
;WIDTH:0.374336
G1 X102.137 Y138.342 E.00166
G1 X102.208 Y138.323 E.00166
G1 X102.197 Y138.282 E.00096
G1 X102.197 Y138.282 F9000
G1 X101.912 Y137.449
;WIDTH:0.399999
G1 F1200
G1 X96.745 Y132.283 E.17772
G1 X96.745 Y131.765 E.0126
G1 X101.976 Y136.996 E.17994
G1 X102.107 Y136.61 E.00992
G1 X96.745 Y131.248 E.18445
G1 X96.745 Y130.731 E.01258
G1 X102.285 Y136.271 E.19057
G1 X102.509 Y135.977 E.00899
G1 X96.745 Y130.213 E.19828
G1 X96.745 Y129.696 E.01258
G1 X102.759 Y135.71 E.20688
G1 X103.011 Y135.445 E.0089
G1 X96.745 Y129.179 E.21555
G1 X96.744 Y128.662 E.01258
G1 X103.263 Y135.18 E.22423
G1 X103.263 Y134.663 E.01258
G1 X96.744 Y128.144 E.22425
G1 X96.744 Y127.627 E.01258
G1 X103.263 Y134.146 E.22425
G1 X103.263 Y133.629 E.01258
G1 X96.744 Y127.11 E.22425
G1 X96.744 Y126.593 E.01258
G1 X103.263 Y133.112 E.22425
G1 X103.263 Y132.595 E.01258
G1 X96.744 Y126.075 E.22427
G1 X96.744 Y125.558 E.01258
G1 X103.263 Y132.078 E.22427
G1 X103.263 Y131.56 E.0126
G1 X96.744 Y125.041 E.22425
G1 X96.743 Y124.524 E.01258
G1 X103.263 Y131.043 E.22427
G1 X103.263 Y130.526 E.01258
G1 X96.743 Y124.006 E.22428
G1 X96.743 Y123.489 E.01258
G1 X103.263 Y130.009 E.22428
G1 X103.263 Y129.492 E.01258
G1 X96.743 Y122.972 E.22428
G1 X96.743 Y122.455 E.01258
G1 X103.263 Y128.975 E.22428
G1 X103.263 Y128.458 E.01258
G1 X96.743 Y121.937 E.2243
G1 X96.743 Y121.42 E.01258
G1 X103.263 Y127.941 E.2243
G1 X103.263 Y127.423 E.0126
G1 X96.742 Y120.903 E.2243
G1 X96.742 Y120.386 E.01258
G1 X103.263 Y126.906 E.2243
G1 X103.263 Y126.389 E.01258
G1 X96.742 Y119.868 E.22432
G1 X96.742 Y119.351 E.01258
G1 X103.263 Y125.872 E.22432
G1 X103.263 Y125.355 E.01258
G1 X96.742 Y118.834 E.22432
G1 X96.742 Y118.316 E.0126
G1 X103.263 Y124.838 E.22434
G1 X103.263 Y124.321 E.01258
G1 X96.742 Y117.799 E.22434
G1 X96.742 Y117.282 E.01258
G1 X103.263 Y123.804 E.22434
G1 X103.263 Y123.286 E.0126
G1 X96.741 Y116.765 E.22434
G1 X96.741 Y116.247 E.0126
G1 X103.263 Y122.769 E.22435
G1 X103.263 Y122.252 E.01258
G1 X96.741 Y115.73 E.22435
G1 X96.741 Y115.213 E.01258
G1 X103.263 Y121.735 E.22435
G1 X103.263 Y121.218 E.01258
G1 X96.741 Y114.696 E.22435
G1 X96.741 Y114.178 E.0126
G1 X103.263 Y120.701 E.22437
G1 X103.263 Y120.184 E.01258
G1 X96.741 Y113.661 E.22437
G1 X96.74 Y113.144 E.01258
G1 X103.263 Y119.667 E.22439
G1 X103.263 Y119.149 E.0126
G1 X96.74 Y112.627 E.22437
G1 X96.74 Y112.109 E.0126
G1 X103.263 Y118.632 E.22439
G1 X103.263 Y118.115 E.01258
G1 X96.74 Y111.592 E.22439
G1 X96.74 Y111.075 E.01258
G1 X103.263 Y117.598 E.22439
G1 X103.263 Y117.081 E.01258
G1 X96.74 Y110.558 E.22439
G1 X96.74 Y110.04 E.0126
G1 X103.263 Y116.564 E.2244
G1 X103.263 Y116.047 E.01258
G1 X96.739 Y109.523 E.22442
G1 X96.739 Y109.006 E.01258
G1 X103.263 Y115.53 E.22442
G1 X103.263 Y115.012 E.0126
G1 X96.739 Y108.489 E.2244
G1 X96.739 Y107.971 E.0126
G1 X103.263 Y114.495 E.22442
G1 X103.263 Y113.978 E.01258
G1 X96.739 Y107.454 E.22442
G1 X96.739 Y106.937 E.01258
G1 X103.263 Y113.461 E.22442
G1 X103.263 Y112.944 E.01258
G1 X96.739 Y106.42 E.22442
G1 X96.739 Y105.902 E.0126
G1 X103.263 Y112.427 E.22444
G1 X103.263 Y111.91 E.01258
G1 X96.738 Y105.385 E.22446
G1 X96.738 Y104.868 E.01258
G1 X103.263 Y111.393 E.22446
G1 X103.263 Y110.875 E.0126
G1 X96.738 Y104.35 E.22446
G1 X96.738 Y103.833 E.01258
G1 X103.263 Y110.358 E.22446
G1 X103.263 Y109.841 E.01258
G1 X96.738 Y103.316 E.22446
G1 X96.738 Y102.799 E.01258
G1 X103.263 Y109.324 E.22446
G1 X103.263 Y108.807 E.01258
G1 X96.738 Y102.281 E.22447
G1 X96.737 Y101.764 E.01258
G1 X103.263 Y108.29 E.22449
G1 X103.263 Y107.773 E.01258
G1 X96.737 Y101.247 E.22449
G1 X96.737 Y100.73 E.01258
G1 X103.263 Y107.256 E.22449
G1 X103.263 Y106.738 E.0126
G1 X96.737 Y100.212 E.22449
G1 X96.737 Y99.695 E.01258
G1 X103.263 Y106.221 E.22449
G1 X103.263 Y105.704 E.01258
G1 X96.737 Y99.178 E.22449
G1 X96.737 Y98.661 E.01258
G1 X103.263 Y105.187 E.22449
G1 X103.263 Y104.67 E.01258
G1 X96.737 Y98.143 E.22451
G1 X96.736 Y97.626 E.01258
G1 X103.263 Y104.153 E.22452
G1 X103.263 Y103.636 E.01258
G1 X96.736 Y97.109 E.22452
G1 X96.736 Y96.592 E.01258
G1 X103.263 Y103.119 E.22452
G1 X103.263 Y102.601 E.0126
G1 X96.736 Y96.074 E.22452
G1 X96.736 Y96.074 F9000
G1 X96.378 Y94.884
;WIDTH:0.374336
G1 F1200
G1 X96.483 Y95.214 E.00783
;WIDTH:0.399999
G1 X96.674 Y95.495 E.00826
G1 X103.263 Y102.084 E.22666
G1 X103.263 Y101.567 E.01258
G1 X96.633 Y94.937 E.22807
G1 X97.15 Y94.937 E.01258
G1 X103.263 Y101.05 E.21028
G1 X103.263 Y100.533 E.01258
G1 X97.667 Y94.937 E.1925
G1 X98.184 Y94.937 E.01258
G1 X103.263 Y100.016 E.17471
G1 X103.263 Y99.499 E.01258
G1 X98.701 Y94.937 E.15693
G1 X99.218 Y94.937 E.01258
G1 X103.263 Y98.982 E.13915
G1 X103.263 Y98.464 E.0126
G1 X99.735 Y94.937 E.12134
G1 X100.252 Y94.936 E.01258
G1 X103.263 Y97.947 E.10358
G1 X103.263 Y97.43 E.01258
G1 X100.769 Y94.936 E.08579
G1 X101.287 Y94.936 E.0126
G1 X103.263 Y96.913 E.06799
G1 X103.263 Y96.396 E.01258
G1 X101.804 Y94.936 E.05021
G1 X102.321 Y94.936 E.01258
G1 X103.263 Y95.879 E.03242
G1 X103.263 Y95.362 E.01258
G1 X102.838 Y94.936 E.01464
G1 E-5 F3600
G1 X102.838 Y94.936 F9000
G1 X103.298 Y137.456
G1 X103.3 Y137.575
G1 X103.32 Y137.691
G1 X103.354 Y137.801
G1 X103.4 Y137.903
G1 X103.457 Y137.999
G1 X104.651 Y139.849
G1 X126.349 Y139.849
G1 X127.692 Y139.819
G1 E5 F2400
G1 F1200
G1 X128.215 Y139.335 E.01733
G1 X128.595 Y138.889 E.01425
G1 X128.965 Y138.211 E.01879
G1 X129.087 Y137.561 E.01609
G1 X129.025 Y136.985 E.01409
;WIDTH:0.441936
G1 X128.813 Y136.397 E.01695
G1 X128.851 Y136.431 E.00138
;WIDTH:0.436621
G1 X129.27 Y136.825 E.01539
;WIDTH:0.399999
G1 X131.117 Y138.672 E.06354
G1 X130.262 Y139.263 E.02528
G1 X129.19 Y139.783 E.02898
G1 X128.102 Y140.133 E.0278
G1 X127.479 Y140.231 E.01534
G1 X127.608 Y139.982 E.00682
G1 X127.608 Y139.982 F9000
G1 X128.417 Y139.647
G1 F1200
G1 X128.914 Y139.068 E.01856
G1 X129.323 Y138.283 E.02153
G1 X129.453 Y137.526 E.01868
G1 X130.558 Y138.629 E.03798
G1 X130.086 Y138.942 E.01378
G1 X129.053 Y139.443 E.02793
G1 X128.591 Y139.592 E.01181
G1 X128.591 Y139.592 F9000
G1 X129.401 Y138.895
;WIDTH:0.350326
G1 F1200
G1 X129.562 Y138.61 E.00688
G1 X129.681 Y138.234 E.00829
G1 X130.026 Y138.579 E.01026
G1 X129.566 Y138.816 E.01088
G1 E-5 F3600
G1 X129.566 Y138.816 F9000
G1 E5 F2400
;WIDTH:0.441936
G1 F1200
G1 X128.6 Y136.146 E.00893
;WIDTH:0.408136
G1 X128.387 Y135.895 E.00819
;WIDTH:0.374336
G1 X127.71 Y135.228 E.02149
;WIDTH:0.399999
G1 X127.737 Y134.774 E.01106
G1 X131.406 Y138.443 E.12621
G1 X131.683 Y138.203 E.00891
G1 X127.737 Y134.257 E.13574
G1 X127.737 Y133.74 E.01258
G1 X131.947 Y137.95 E.14482
G1 X132.194 Y137.68 E.0089
G1 X127.737 Y133.223 E.15332
G1 X127.737 Y132.706 E.01258
G1 X132.434 Y137.402 E.16156
G1 X132.659 Y137.111 E.00895
G1 X127.737 Y132.189 E.16931
G1 X127.737 Y131.671 E.0126
G1 X132.874 Y136.809 E.17673
G1 X133.08 Y136.497 E.00909
G1 X127.737 Y131.154 E.1838
G1 X127.737 Y130.637 E.01258
G1 X133.262 Y136.162 E.19006
G1 X133.431 Y135.814 E.00941
G1 X127.737 Y130.12 E.19587
G1 X127.737 Y129.603 E.01258
G1 X133.6 Y135.466 E.20168
G1 X133.745 Y135.094 E.00971
G1 X127.737 Y129.086 E.20667
G1 X127.737 Y128.569 E.01258
G1 X133.871 Y134.702 E.21099
G1 X133.996 Y134.311 E.00998
G1 X127.737 Y128.052 E.21531
G1 X127.737 Y127.534 E.0126
G1 X134.1 Y133.898 E.2189
G1 X134.17 Y133.45 E.01103
G1 X127.737 Y127.017 E.22129
G1 X127.737 Y126.5 E.01258
G1 X134.227 Y132.99 E.22325
G1 X134.251 Y132.497 E.01201
G1 X127.737 Y125.983 E.22408
G1 X127.737 Y125.466 E.01258
G1 X134.263 Y131.992 E.22449
G1 X134.263 Y131.475 E.01258
G1 X127.737 Y124.949 E.22449
G1 X127.737 Y124.432 E.01258
G1 X134.263 Y130.958 E.22449
G1 X134.263 Y130.441 E.01258
G1 X127.737 Y123.914 E.22451
G1 X127.737 Y123.397 E.01258
G1 X134.263 Y129.924 E.22451
G1 X134.263 Y129.406 E.0126
G1 X127.737 Y122.88 E.22449
G1 X127.737 Y122.363 E.01258
G1 X134.263 Y128.889 E.22449
G1 X134.263 Y128.372 E.01258
G1 X127.737 Y121.846 E.22449
G1 X127.737 Y121.329 E.01258
G1 X134.263 Y127.855 E.22449
G1 X134.263 Y127.338 E.01258
G1 X127.737 Y120.812 E.22449
G1 X127.737 Y120.295 E.01258
G1 X134.263 Y126.821 E.22449
G1 X134.263 Y126.304 E.01258
G1 X127.737 Y119.777 E.22451
G1 X127.737 Y119.26 E.01258
G1 X134.263 Y125.787 E.22451
G1 X134.263 Y125.27 E.01258
G1 X127.737 Y118.743 E.22451
G1 X127.737 Y118.226 E.01258
G1 X134.263 Y124.752 E.22449
G1 X134.263 Y124.235 E.01258
G1 X127.737 Y117.709 E.22449
G1 X127.737 Y117.192 E.01258
G1 X134.263 Y123.718 E.22449
G1 X134.263 Y123.201 E.01258
G1 X127.737 Y116.675 E.22449
G1 X127.737 Y116.158 E.01258
G1 X134.263 Y122.684 E.22449
G1 X134.263 Y122.167 E.01258
G1 X127.737 Y115.64 E.22451
G1 X127.737 Y115.123 E.01258
G1 X134.263 Y121.65 E.22451
G1 X134.263 Y121.133 E.01258
G1 X127.737 Y114.606 E.22451
G1 X127.737 Y114.089 E.01258
G1 X134.263 Y120.615 E.22449
G1 X134.263 Y120.098 E.01258
G1 X127.737 Y113.572 E.22449
G1 X127.737 Y113.055 E.01258
G1 X134.263 Y119.581 E.22449
G1 X134.263 Y119.064 E.01258
G1 X127.737 Y112.538 E.22449
G1 X127.737 Y112.021 E.01258
G1 X134.263 Y118.547 E.22449
G1 X134.263 Y118.03 E.01258
G1 X127.737 Y111.503 E.22451
G1 X127.737 Y110.986 E.01258
G1 X134.263 Y117.513 E.22451
G1 X134.263 Y116.996 E.01258
G1 X127.737 Y110.469 E.22451
G1 X127.737 Y109.952 E.01258
G1 X134.263 Y116.479 E.22451
G1 X134.263 Y115.961 E.0126
G1 X127.737 Y109.435 E.22449
G1 X127.737 Y108.918 E.01258
G1 X134.263 Y115.444 E.22449
G1 X134.263 Y114.927 E.01258
G1 X127.737 Y108.401 E.22449
G1 X127.737 Y107.884 E.01258
G1 X134.263 Y114.41 E.22449
G1 X134.263 Y113.893 E.01258
G1 X127.737 Y107.366 E.22451
G1 X127.737 Y106.849 E.01258
G1 X134.263 Y113.376 E.22451
G1 X134.263 Y112.859 E.01258
G1 X127.737 Y106.332 E.22451
G1 X127.737 Y105.815 E.01258
G1 X134.263 Y112.342 E.22451
G1 X134.263 Y111.824 E.0126
G1 X127.737 Y105.298 E.22449
G1 X127.737 Y104.781 E.01258
G1 X134.263 Y111.307 E.22449
G1 X134.263 Y110.79 E.01258
G1 X127.737 Y104.264 E.22449
G1 X127.737 Y103.747 E.01258
G1 X134.263 Y110.273 E.22449
G1 X134.263 Y109.756 E.01258
G1 X127.737 Y103.229 E.22451
G1 X127.737 Y102.712 E.01258
G1 X134.263 Y109.239 E.22451
G1 X134.263 Y108.722 E.01258
G1 X127.737 Y102.195 E.22451
G1 X127.737 Y101.678 E.01258
G1 X134.263 Y108.205 E.22451
G1 X134.263 Y107.687 E.0126
G1 X127.737 Y101.161 E.22449
G1 X127.737 Y100.644 E.01258
G1 X134.263 Y107.17 E.22449
G1 X134.263 Y106.653 E.01258
G1 X127.737 Y100.127 E.22449
G1 X127.737 Y99.61 E.01258
G1 X134.263 Y106.136 E.22449
G1 X134.263 Y105.619 E.01258
G1 X127.737 Y99.092 E.22451
G1 X127.737 Y98.575 E.01258
G1 X134.263 Y105.102 E.22451
G1 X134.263 Y104.585 E.01258
G1 X127.737 Y98.058 E.22451
G1 X127.737 Y97.541 E.01258
G1 X134.263 Y104.068 E.22451
G1 X134.263 Y103.551 E.01258
G1 X127.737 Y97.024 E.22451
G1 X127.737 Y96.507 E.01258
G1 X134.263 Y103.033 E.22449
G1 X134.263 Y102.516 E.01258
G1 X127.737 Y95.99 E.22449
G1 X127.737 Y95.473 E.01258
G1 X134.263 Y101.999 E.22449
G1 X134.263 Y101.482 E.01258
G1 X127.737 Y94.955 E.22451
G1 X128.236 Y94.937 E.01215
G1 X134.263 Y100.965 E.20734
G1 X134.263 Y100.448 E.01258
G1 X128.753 Y94.937 E.18956
G1 X129.27 Y94.937 E.01258
G1 X134.264 Y99.931 E.17179
G1 X134.264 Y99.414 E.01258
G1 X129.787 Y94.937 E.15401
G1 X130.304 Y94.937 E.01258
G1 X134.264 Y98.896 E.1362
G1 X134.264 Y98.379 E.01258
G1 X130.821 Y94.937 E.11842
G1 X131.338 Y94.937 E.01258
G1 X134.264 Y97.862 E.10064
G1 X134.264 Y97.345 E.01258
G1 X131.855 Y94.937 E.08285
G1 X132.372 Y94.937 E.01258
G1 X134.264 Y96.828 E.06507
G1 X134.264 Y96.311 E.01258
G1 X132.89 Y94.937 E.04726
G1 X133.407 Y94.937 E.01258
G1 X134.265 Y95.795 E.02951
G1 X134.351 Y95.364 E.01069
G1 X133.924 Y94.937 E.01469
G1 X134.468 Y94.905 E.01326
;WIDTH:0.432918
G1 X134.445 Y94.989 E.00231
G1 X134.529 Y94.966 E.00231
G1 X134.516 Y94.918 E.00132
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X134.529 Y94.966 E-.02362
G1 X134.445 Y94.989 E-.04137
G1 X134.468 Y94.905 E-.04137
G1 X133.924 Y94.937 E-.25885
G1 X134.351 Y95.364 E-.28684
G1 X134.265 Y95.795 E-.20876
G1 X133.407 Y94.937 E-.57636
G1 X133.275 Y94.937 E-.06283
;WIPE_END
G1 X126.357 Y101.911 F9000
G1 X124.901 Y103.379
G1 X119.662 Y108.685
G1 X119.399 Y108.926
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X119.683 Y109.256 E.01059
G1 X121.57 Y112.496 E.0912
G1 X121.79 Y112.969 E.01269
G1 X121.928 Y113.488 E.01306
G1 X121.964 Y114.206 E.01749
G1 X121.879 Y114.743 E.01322
G1 X121.7 Y115.25 E.01308
G1 X119.702 Y118.717 E.09733
G1 X119.162 Y119.305 E.01942
G1 X118.714 Y119.617 E.01328
G1 X118.122 Y119.864 E.0156
G1 X117.647 Y119.972 E.01185
G1 X117.233 Y120.009 E.01011
G1 X113.767 Y120.009 E.08431
G1 X113.083 Y119.918 E.01678
G1 X112.543 Y119.727 E.01393
G1 X112.284 Y119.615 E.00686
G1 X111.808 Y119.28 E.01416
G1 X111.299 Y118.718 E.01844
G1 X109.43 Y115.504 E.09043
G1 X109.21 Y115.031 E.01269
G1 X109.072 Y114.511 E.01309
G1 X109.029 Y113.975 E.01308
G1 X109.072 Y113.489 E.01187
G1 X109.199 Y113 E.01229
G1 X109.43 Y112.496 E.01349
G1 X111.299 Y109.282 E.09043
G1 X111.873 Y108.665 E.0205
G1 X112.446 Y108.299 E.01654
G1 X113.032 Y108.085 E.01517
G1 X113.768 Y107.991 E.01805
G1 X117.485 Y108.003 E.09041
G1 X118.188 Y108.15 E.01747
G1 X118.691 Y108.377 E.01342
G1 X119.328 Y108.844 E.01921
G1 X119.36 Y108.881 E.00119
G1 X119.36 Y108.881 F9000
G1 X119.626 Y108.626
;TYPE:Perimeter
G1 F6000
G1 X119.635 Y108.634 E.00029
G1 X119.962 Y109.019 E.01229
G1 X121.886 Y112.312 E.09277
G1 X122.122 Y112.815 E.01351
G1 X122.282 Y113.396 E.01466
G1 X122.329 Y114.19 E.01935
G1 X122.24 Y114.803 E.01507
G1 X122.044 Y115.374 E.01468
G1 X120.018 Y118.9 E.09892
G1 X119.43 Y119.554 E.02139
G1 X118.92 Y119.919 E.01525
G1 X118.454 Y120.144 E.01259
G1 X117.881 Y120.309 E.0145
G1 X117.282 Y120.372 E.01465
G1 X113.767 Y120.374 E.0855
G1 X113.034 Y120.28 E.01798
G1 X112.81 Y120.232 E.00557
G1 X112.181 Y119.973 E.01655
G1 X111.738 Y119.678 E.01295
G1 X111.506 Y119.498 E.00714
G1 X110.982 Y118.902 E.0193
G1 X109.114 Y115.688 E.09042
G1 X108.878 Y115.185 E.01351
G1 X108.718 Y114.603 E.01468
G1 X108.664 Y114.003 E.01465
G1 X108.703 Y113.486 E.01261
G1 X108.845 Y112.907 E.0145
G1 X109.114 Y112.312 E.01588
G1 X110.983 Y109.098 E.09043
G1 X111.487 Y108.534 E.0184
G1 X111.676 Y108.357 E.0063
G1 X112.249 Y107.991 E.01654
G1 X112.773 Y107.789 E.01366
G1 X113.026 Y107.713 E.00643
G1 X113.769 Y107.626 E.0182
G1 X117.486 Y107.637 E.09041
G1 X118.265 Y107.792 E.01932
G1 X118.844 Y108.045 E.01537
G1 X119.259 Y108.328 E.01222
G1 X119.579 Y108.589 E.01004
G1 X119.579 Y108.589 F9000
G1 X119.823 Y108.322
G1 F6000
G1 X119.914 Y108.398 E.00288
G1 X120.333 Y108.914 E.01617
G1 X122.202 Y112.128 E.09043
G1 X122.453 Y112.661 E.01433
G1 X122.636 Y113.304 E.01626
G1 X122.695 Y114.174 E.02121
G1 X122.6 Y114.863 E.01692
G1 X122.388 Y115.497 E.01626
G1 X122.32 Y115.646 E.00398
G1 X120.335 Y119.083 E.09654
G1 X119.979 Y119.5 E.01334
G1 X119.544 Y119.936 E.01498
G1 X119.126 Y120.221 E.01231
G1 X118.608 Y120.475 E.01403
G1 X117.978 Y120.662 E.01598
;WIDTH:0.44594
G1 X117.723 Y120.715 E.00713
;WIDTH:0.491881
G1 X117.467 Y120.769 E.00796
G1 X117.233 Y120.781 E.00713
;WIDTH:0.48242
G1 X113.768 Y120.779 E.10328
;WIDTH:0.477167
G1 X113.767 Y120.779 E.00003
G1 X113.376 Y120.711 E.01169
;WIDTH:0.438583
G1 X112.985 Y120.642 E.01068
;WIDTH:0.399999
G1 X112.671 Y120.57 E.00784
G1 X112.042 Y120.311 E.01655
G1 X111.527 Y119.977 E.01493
G1 X111.235 Y119.744 E.00909
G1 X110.779 Y119.239 E.01655
G1 X110.666 Y119.085 E.00465
G1 X108.798 Y115.872 E.0904
G1 X108.547 Y115.339 E.01433
G1 X108.364 Y114.695 E.01628
G1 X108.299 Y114.03 E.01625
G1 X108.338 Y113.454 E.01404
G1 X108.491 Y112.815 E.01598
G1 X108.759 Y112.203 E.01625
G1 X110.666 Y108.914 E.09248
G1 X111.219 Y108.286 E.02035
G1 X111.479 Y108.049 E.00856
G1 X112.053 Y107.683 E.01656
G1 X112.65 Y107.445 E.01563
G1 X112.981 Y107.35 E.00838
;WIDTH:0.435066
G1 X113.309 Y107.292 E.00888
;WIDTH:0.470132
G1 X113.637 Y107.234 E.00966
;WIDTH:0.47717
G1 X113.77 Y107.221 E.00394
;WIDTH:0.48242
G1 X117.232 Y107.229 E.10319
;WIDTH:0.491881
G1 X117.487 Y107.225 E.00776
G1 X117.743 Y107.293 E.00806
;WIDTH:0.44594
G1 X117.998 Y107.361 E.00723
;WIDTH:0.399999
G1 X118.533 Y107.499 E.01344
G1 X119.062 Y107.743 E.01417
G1 X119.482 Y108.039 E.0125
G1 X119.777 Y108.284 E.00933
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X119.823 Y108.322 E-.02834
G1 X119.914 Y108.398 E-.05632
G1 X120.333 Y108.914 E-.31573
G1 X121.497 Y110.915 E-1.09961
;WIPE_END
G1 X121.169 Y111.104 F9000
G1 X121.878 Y112.332
G1 X121.964 Y112.498
G1 X122.01 Y112.588
G1 X122.087 Y112.773
G1 X122.125 Y112.867
G1 X122.185 Y113.058
G1 X122.213 Y113.155
G1 X122.257 Y113.351
G1 X122.276 Y113.45
G1 X122.302 Y113.649
G1 X122.312 Y113.749
G1 X122.32 Y113.95
G1 X122.32 Y114.05
G1 X122.312 Y114.251
G1 X122.302 Y114.351
G1 X122.276 Y114.55
G1 X122.257 Y114.649
G1 X122.213 Y114.845
G1 X122.185 Y114.942
G1 X122.125 Y115.133
G1 X122.087 Y115.227
G1 X122.01 Y115.412
G1 X121.964 Y115.502
G1 X121.878 Y115.668
G1 X120.134 Y118.689
G1 X120.033 Y118.847
G1 X119.978 Y118.932
G1 X119.856 Y119.091
G1 X119.794 Y119.17
G1 X119.658 Y119.319
G1 X119.589 Y119.391
G1 X119.441 Y119.527
G1 X119.365 Y119.593
G1 X119.205 Y119.715
G1 X119.123 Y119.774
G1 X118.954 Y119.882
G1 X118.867 Y119.932
G1 X118.689 Y120.025
G1 X118.597 Y120.066
G1 X118.413 Y120.143
G1 X117.851 Y121.701
G1 X117.771 Y122.062
G1 E5 F2400
G1 F6000
G1 X118.188 Y122.15 E.01037
G1 X118.691 Y122.377 E.01342
G1 X119.328 Y122.844 E.01921
G1 X119.701 Y123.282 E.01399
G1 X121.57 Y126.496 E.09043
G1 X121.79 Y126.969 E.01269
G1 X121.928 Y127.488 E.01306
G1 X121.964 Y128.206 E.01749
G1 X121.879 Y128.743 E.01322
G1 X121.7 Y129.25 E.01308
G1 X119.702 Y132.717 E.09733
G1 X119.131 Y133.332 E.02041
G1 X118.714 Y133.617 E.01229
G1 X118.271 Y133.823 E.01188
G1 X117.784 Y133.957 E.01229
G1 X117.249 Y134.008 E.01307
G1 X113.767 Y134.009 E.0847
G1 X112.994 Y133.906 E.01897
G1 X112.32 Y133.635 E.01767
G1 X111.808 Y133.28 E.01515
G1 X111.663 Y133.127 E.00513
G1 X111.299 Y132.718 E.01332
G1 X109.43 Y129.504 E.09043
G1 X109.21 Y129.031 E.01269
G1 X109.072 Y128.511 E.01309
G1 X109.029 Y128.025 E.01187
G1 X109.067 Y127.521 E.01229
G1 X109.199 Y127 E.01307
G1 X109.422 Y126.511 E.01307
G1 X111.299 Y123.282 E.09085
G1 X111.873 Y122.665 E.0205
G1 X112.446 Y122.299 E.01654
G1 X113.032 Y122.085 E.01517
G1 X113.731 Y121.994 E.01715
G1 X117.485 Y122.003 E.09131
G1 X117.712 Y122.05 E.00564
G1 X117.712 Y122.05 F9000
G1 X117.761 Y121.692
;TYPE:Perimeter
G1 F6000
G1 X118.265 Y121.792 E.0125
G1 X118.844 Y122.045 E.01537
G1 X119.259 Y122.328 E.01222
G1 X119.635 Y122.634 E.01179
G1 X120.017 Y123.098 E.01462
G1 X121.886 Y126.312 E.09043
G1 X122.122 Y126.815 E.01351
G1 X122.282 Y127.396 E.01466
G1 X122.329 Y128.19 E.01935
G1 X122.24 Y128.803 E.01507
G1 X122.044 Y129.374 E.01468
G1 X120.018 Y132.9 E.09892
G1 X119.629 Y133.34 E.01429
G1 X119.337 Y133.634 E.01008
G1 X118.92 Y133.919 E.01229
G1 X118.454 Y134.144 E.01259
G1 X117.881 Y134.309 E.0145
G1 X117.282 Y134.372 E.01465
G1 X113.767 Y134.374 E.0855
G1 X112.945 Y134.268 E.02016
G1 X112.181 Y133.973 E.01992
G1 X111.597 Y133.579 E.01714
G1 X111.392 Y133.372 E.00709
G1 X110.982 Y132.902 E.01517
G1 X109.114 Y129.688 E.09042
G1 X108.878 Y129.185 E.01351
G1 X108.718 Y128.604 E.01466
G1 X108.665 Y128.087 E.01264
G1 X108.702 Y127.494 E.01445
G1 X108.845 Y126.907 E.0147
G1 X109.091 Y126.357 E.01466
G1 X110.983 Y123.098 E.09166
G1 X111.487 Y122.534 E.0184
G1 X111.676 Y122.357 E.0063
G1 X112.249 Y121.991 E.01654
G1 X112.773 Y121.789 E.01366
G1 X113.026 Y121.713 E.00643
G1 X113.7 Y121.63 E.01652
G1 X117.486 Y121.637 E.09209
G1 X117.702 Y121.68 E.00536
G1 X117.755 Y121.296 F9000
;WIDTH:0.44594
G1 F6000
G1 X117.998 Y121.361 E.00689
;WIDTH:0.399999
G1 X118.533 Y121.499 E.01344
G1 X119.062 Y121.743 E.01417
G1 X119.482 Y122.039 E.0125
G1 X119.914 Y122.398 E.01366
G1 X120.333 Y122.914 E.01617
G1 X122.202 Y126.128 E.09043
G1 X122.453 Y126.661 E.01433
G1 X122.636 Y127.304 E.01626
G1 X122.695 Y128.174 E.02121
G1 X122.6 Y128.863 E.01692
G1 X122.388 Y129.497 E.01626
G1 X122.32 Y129.646 E.00398
G1 X120.335 Y133.083 E.09654
G1 X119.897 Y133.589 E.01628
G1 X119.544 Y133.936 E.01204
G1 X119.127 Y134.221 E.01229
G1 X118.608 Y134.475 E.01405
G1 X117.978 Y134.662 E.01598
G1 X117.315 Y134.736 E.01623
G1 X113.767 Y134.74 E.0863
G1 X112.895 Y134.63 E.02138
G1 X112.042 Y134.311 E.02215
G1 X111.386 Y133.878 E.01912
G1 X111.121 Y133.617 E.00905
G1 X110.779 Y133.239 E.0124
G1 X110.666 Y133.085 E.00465
G1 X108.798 Y129.872 E.0904
G1 X108.547 Y129.339 E.01433
G1 X108.364 Y128.696 E.01626
G1 X108.3 Y128.119 E.01412
G1 X108.337 Y127.466 E.01591
G1 X108.491 Y126.815 E.01627
G1 X108.759 Y126.203 E.01625
G1 X110.666 Y122.914 E.09248
G1 X111.219 Y122.286 E.02035
G1 X111.479 Y122.049 E.00856
G1 X112.053 Y121.683 E.01656
G1 X112.65 Y121.445 E.01563
G1 X112.981 Y121.35 E.00838
;WIDTH:0.435066
G1 X113.309 Y121.292 E.00888
;WIDTH:0.470132
G1 X113.637 Y121.234 E.00966
;WIDTH:0.477169
G1 X113.77 Y121.221 E.00394
;WIDTH:0.48242
G1 X117.232 Y121.229 E.10319
;WIDTH:0.491881
G1 X117.487 Y121.225 E.00776
G1 X117.697 Y121.281 E.00661
G1 E-5 F3600
G1 X117.697 Y121.281 F9000
G1 X117.645 Y121.671
G1 X117.731 Y121.682
G1 X117.831 Y121.696
G1 X118.027 Y121.74
G1 X118.125 Y121.763
G1 X118.316 Y121.824
G1 X118.411 Y121.857
G1 X118.597 Y121.934
G1 X118.688 Y121.975
G1 X118.867 Y122.068
G1 X118.954 Y122.118
G1 X119.123 Y122.226
G1 X119.205 Y122.285
G1 X119.365 Y122.407
G1 X119.441 Y122.473
G1 X119.589 Y122.609
G1 X119.658 Y122.681
G1 X119.794 Y122.83
G1 X119.856 Y122.909
G1 X119.978 Y123.068
G1 X120.033 Y123.153
G1 X120.134 Y123.311
G1 X121.878 Y126.332
G1 X121.964 Y126.498
G1 X122.01 Y126.588
G1 X122.087 Y126.773
G1 X122.125 Y126.867
G1 X122.185 Y127.058
G1 X122.213 Y127.155
G1 X122.257 Y127.351
G1 X122.276 Y127.45
G1 X122.302 Y127.649
G1 X122.312 Y127.749
G1 X122.32 Y127.95
G1 X122.32 Y128.05
G1 X122.312 Y128.251
G1 X122.302 Y128.351
G1 X122.276 Y128.55
G1 X122.257 Y128.649
G1 X122.213 Y128.845
G1 X122.185 Y128.942
G1 X122.125 Y129.133
G1 X122.087 Y129.227
G1 X122.01 Y129.412
G1 X121.964 Y129.502
G1 X121.878 Y129.668
G1 X120.134 Y132.689
G1 X120.033 Y132.847
G1 X119.978 Y132.932
G1 X118.762 Y134.807
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X118.076 Y135.014 E.01743
G1 X117.347 Y135.101 E.01786
G1 X113.767 Y135.106 E.08708
G1 X112.846 Y134.993 E.02257
G1 X112.532 Y134.908 E.00791
G1 X111.903 Y134.65 E.01654
G1 X111.176 Y134.176 E.02111
G1 X110.85 Y133.863 E.01099
G1 X110.508 Y133.484 E.01242
G1 X110.35 Y133.269 E.00649
G1 X108.482 Y130.056 E.0904
G1 X108.215 Y129.492 E.01518
G1 X108.01 Y128.788 E.01784
G1 X107.936 Y128.152 E.01557
G1 X107.973 Y127.439 E.01737
G1 X108.138 Y126.723 E.01787
G1 X108.427 Y126.05 E.01782
G1 X110.35 Y122.731 E.0933
G1 X110.951 Y122.037 E.02233
G1 X111.283 Y121.74 E.01084
G1 X111.856 Y121.374 E.01654
G1 X112.527 Y121.101 E.01762
G1 X112.846 Y120.997 E.00816
G1 X112.126 Y120.742 E.01858
G1 X111.652 Y120.512 E.01282
G1 X111.176 Y120.176 E.01417
G1 X110.579 Y119.563 E.02081
G1 X110.35 Y119.269 E.00906
G1 X108.482 Y116.056 E.0904
G1 X108.215 Y115.492 E.01518
G1 X108.01 Y114.788 E.01784
G1 X107.935 Y114.058 E.01785
G1 X107.974 Y113.421 E.01552
G1 X108.138 Y112.723 E.01744
G1 X108.427 Y112.05 E.01782
G1 X110.35 Y108.731 E.0933
G1 X110.951 Y108.037 E.02233
G1 X111.283 Y107.74 E.01084
G1 X111.856 Y107.374 E.01654
G1 X112.527 Y107.101 E.01762
G1 X112.846 Y106.997 E.00816
G1 X112.126 Y106.742 E.01858
G1 X111.652 Y106.512 E.01282
G1 X111.176 Y106.176 E.01417
G1 X110.579 Y105.563 E.02081
G1 X110.35 Y105.269 E.00906
G1 X108.482 Y102.056 E.0904
G1 X108.215 Y101.492 E.01518
G1 X108.01 Y100.788 E.01784
G1 X107.935 Y100.058 E.01785
G1 X107.974 Y99.421 E.01552
G1 X108.138 Y98.723 E.01744
G1 X108.427 Y98.05 E.01782
G1 X110.35 Y94.731 E.0933
G1 X110.835 Y94.163 E.01817
G1 X111.283 Y93.74 E.01499
G1 X111.856 Y93.374 E.01654
G1 X112.663 Y93.052 E.02113
G1 X113.611 Y92.904 E.02334
G1 X117.488 Y92.906 E.0943
G1 X118.419 Y93.077 E.02302
G1 X119.215 Y93.411 E.021
G1 X119.999 Y93.975 E.02349
G1 X120.52 Y94.546 E.0188
G1 X120.65 Y94.731 E.0055
G1 X122.518 Y97.944 E.0904
G1 X122.785 Y98.508 E.01518
G1 X122.99 Y99.212 E.01784
G1 X123.06 Y100.157 E.02305
G1 X122.961 Y100.923 E.01879
G1 X122.733 Y101.62 E.01784
G1 X122.636 Y101.828 E.00558
G1 X120.652 Y105.266 E.09655
G1 X120.247 Y105.749 E.01533
G1 X119.75 Y106.238 E.01696
G1 X119.333 Y106.523 E.01229
G1 X118.762 Y106.807 E.01551
G1 X118.098 Y107.008 E.01687
G1 X118.687 Y107.167 E.01484
G1 X119.215 Y107.411 E.01415
G1 X119.705 Y107.749 E.01448
G1 X120.193 Y108.161 E.01553
G1 X120.52 Y108.546 E.01229
G1 X120.65 Y108.731 E.0055
G1 X122.518 Y111.944 E.0904
G1 X122.785 Y112.508 E.01518
G1 X122.99 Y113.212 E.01784
G1 X123.06 Y114.157 E.02305
G1 X122.961 Y114.923 E.01879
G1 X122.733 Y115.62 E.01784
G1 X122.636 Y115.828 E.00558
G1 X120.652 Y119.266 E.09655
G1 X120.247 Y119.749 E.01533
G1 X119.75 Y120.238 E.01696
G1 X119.333 Y120.523 E.01229
G1 X118.762 Y120.807 E.01551
G1 X118.098 Y121.008 E.01687
G1 X118.687 Y121.167 E.01484
G1 X119.215 Y121.411 E.01415
G1 X119.705 Y121.749 E.01448
G1 X120.193 Y122.161 E.01553
G1 X120.52 Y122.546 E.01229
G1 X120.65 Y122.731 E.0055
G1 X122.518 Y125.944 E.0904
G1 X122.785 Y126.508 E.01518
G1 X122.99 Y127.212 E.01784
G1 X123.06 Y128.157 E.02305
G1 X122.961 Y128.923 E.01879
G1 X122.733 Y129.62 E.01784
G1 X122.636 Y129.828 E.00558
G1 X120.652 Y133.266 E.09655
G1 X120.165 Y133.837 E.01825
G1 X119.75 Y134.238 E.01404
G1 X119.333 Y134.523 E.01229
G1 X118.815 Y134.78 E.01407
G1 X118.815 Y134.78 F9000
G1 X119.186 Y135.002
G1 F6000
G1 X118.916 Y135.139 E.00736
G1 X118.173 Y135.367 E.0189
G1 X117.233 Y135.471 E.023
G1 X113.767 Y135.471 E.08431
G1 X112.797 Y135.355 E.02376
G1 X112.393 Y135.246 E.01018
G1 X111.764 Y134.988 E.01654
G1 X111.441 Y134.811 E.00896
G1 X110.965 Y134.475 E.01417
G1 X110.579 Y134.108 E.01296
G1 X110.236 Y133.73 E.01242
G1 X110.034 Y133.453 E.00834
G1 X108.166 Y130.239 E.09042
G1 X107.883 Y129.646 E.01598
;WIDTH:0.416454
G1 X107.648 Y128.882 E.02032
G1 X107.573 Y128.184 E.01784
;WIDTH:0.415128
G1 X107.6 Y127.411 E.01959
;WIDTH:0.442666
G1 X107.636 Y127.115 E.0081
G1 X107.784 Y126.631 E.01375
;WIDTH:0.399999
G1 X108.166 Y125.761 E.02311
G1 X110.034 Y122.547 E.09042
G1 X110.293 Y122.209 E.01036
G1 X110.765 Y121.7 E.01688
G1 X111.086 Y121.432 E.01017
G1 X111.764 Y120.988 E.01971
G1 X111.441 Y120.811 E.00896
G1 X110.965 Y120.475 E.01417
G1 X110.693 Y120.234 E.00884
G1 X110.236 Y119.73 E.01655
G1 X110.034 Y119.453 E.00834
G1 X108.166 Y116.239 E.09042
G1 X107.883 Y115.646 E.01598
;WIDTH:0.416446
G1 X107.648 Y114.882 E.02032
G1 X107.572 Y114.085 E.02035
;WIDTH:0.416164
G1 X107.602 Y113.388 E.01772
;WIDTH:0.442682
G1 X107.636 Y113.115 E.00747
G1 X107.784 Y112.631 E.01375
;WIDTH:0.399999
G1 X108.166 Y111.761 E.02311
G1 X110.034 Y108.547 E.09042
G1 X110.293 Y108.209 E.01036
G1 X110.765 Y107.7 E.01688
G1 X111.086 Y107.432 E.01017
G1 X111.764 Y106.988 E.01971
G1 X111.441 Y106.811 E.00896
G1 X110.965 Y106.475 E.01417
G1 X110.693 Y106.234 E.00884
G1 X110.236 Y105.73 E.01655
G1 X110.034 Y105.453 E.00834
G1 X108.166 Y102.239 E.09042
G1 X107.883 Y101.646 E.01598
;WIDTH:0.416445
G1 X107.648 Y100.882 E.02032
G1 X107.572 Y100.085 E.02035
;WIDTH:0.416164
G1 X107.602 Y99.388 E.01772
;WIDTH:0.442682
G1 X107.636 Y99.115 E.00747
G1 X107.784 Y98.631 E.01375
;WIDTH:0.399999
G1 X108.166 Y97.761 E.02311
G1 X110.034 Y94.547 E.09042
G1 X110.567 Y93.914 E.02013
G1 X111.086 Y93.432 E.01723
G1 X111.659 Y93.066 E.01654
G1 X111.991 Y92.903 E.009
G1 X112.54 Y92.708 E.01417
G1 X112.892 Y92.624 E.0088
G1 X113.773 Y92.529 E.02155
G1 X117.489 Y92.54 E.09039
G1 X118.495 Y92.72 E.02486
G1 X119.369 Y93.079 E.02298
G1 X119.684 Y93.27 E.00896
G1 X120.222 Y93.686 E.01654
G1 X120.799 Y94.31 E.02067
G1 X120.966 Y94.547 E.00705
G1 X122.834 Y97.761 E.09042
G1 X123.117 Y98.354 E.01598
;WIDTH:0.442717
G1 X123.364 Y99.115 E.02173
G1 X123.424 Y100.141 E.02792
;WIDTH:0.424951
G1 X123.386 Y100.564 E.01104
;WIDTH:0.451597
G1 X123.347 Y100.987 E.01179
G1 X123.212 Y101.365 E.01114
;WIDTH:0.425798
G1 X123.077 Y101.744 E.01048
;WIDTH:0.399999
G1 X122.953 Y102.011 E.00716
G1 X120.968 Y105.449 E.09656
G1 X120.515 Y105.998 E.01731
G1 X120.157 Y106.378 E.0127
G1 X119.7 Y106.715 E.01381
G1 X119.206 Y107.004 E.01392
G1 X119.684 Y107.27 E.01331
G1 X120.222 Y107.686 E.01654
G1 X120.657 Y108.143 E.01535
G1 X120.966 Y108.547 E.01237
G1 X122.834 Y111.761 E.09042
G1 X123.117 Y112.354 E.01598
;WIDTH:0.442717
G1 X123.364 Y113.115 E.02173
G1 X123.424 Y114.141 E.02792
;WIDTH:0.424951
G1 X123.386 Y114.564 E.01104
;WIDTH:0.451597
G1 X123.347 Y114.987 E.01179
G1 X123.212 Y115.365 E.01114
;WIDTH:0.425798
G1 X123.077 Y115.744 E.01048
;WIDTH:0.399999
G1 X122.953 Y116.011 E.00716
G1 X120.968 Y119.449 E.09656
G1 X120.515 Y119.998 E.01731
G1 X120.157 Y120.378 E.0127
G1 X119.7 Y120.715 E.01381
G1 X119.206 Y121.004 E.01392
G1 X119.684 Y121.27 E.01331
G1 X120.222 Y121.686 E.01654
G1 X120.657 Y122.143 E.01535
G1 X120.966 Y122.547 E.01237
G1 X122.834 Y125.761 E.09042
G1 X123.117 Y126.354 E.01598
;WIDTH:0.442717
G1 X123.364 Y127.115 E.02173
G1 X123.424 Y128.141 E.02792
;WIDTH:0.424951
G1 X123.386 Y128.564 E.01104
;WIDTH:0.451597
G1 X123.347 Y128.987 E.01179
G1 X123.212 Y129.365 E.01114
;WIDTH:0.425798
G1 X123.077 Y129.744 E.01048
;WIDTH:0.399999
G1 X122.953 Y130.011 E.00716
G1 X120.968 Y133.449 E.09656
G1 X120.433 Y134.086 E.02023
G1 X119.956 Y134.54 E.01602
G1 X119.539 Y134.825 E.01229
G1 X119.24 Y134.975 E.00814
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X119.186 Y135.002 E-.02868
G1 X118.916 Y135.139 E-.14382
G1 X118.173 Y135.367 E-.36917
G1 X117.233 Y135.471 E-.44922
G1 X116.161 Y135.471 E-.50911
;WIPE_END
G1 X118.867 Y133.932 F9000
G1 X118.954 Y133.882
G1 X119.123 Y133.774
G1 X119.205 Y133.715
G1 X119.364 Y133.593
G1 X119.441 Y133.527
G1 X119.589 Y133.391
G1 X119.658 Y133.319
G1 X119.794 Y133.17
G1 X119.856 Y133.091
G1 X122.01 Y129.412
G1 X122.276 Y128.55
G1 X122.32 Y128.05
G1 X122.32 Y113.95
G1 X122.276 Y113.45
G1 X122.01 Y112.588
G1 X120.134 Y109.311
G1 X120.033 Y109.153
G1 X119.978 Y109.068
G1 X119.856 Y108.909
G1 X119.794 Y108.83
G1 X119.658 Y108.681
G1 X119.589 Y108.609
G1 X119.441 Y108.473
G1 X119.365 Y108.407
G1 X119.205 Y108.285
G1 X119.123 Y108.226
G1 X118.954 Y108.118
G1 X118.867 Y108.068
G1 X118.688 Y107.975
G1 X118.597 Y107.934
G1 X118.411 Y107.857
G1 X118.316 Y107.824
G1 X118.125 Y107.763
G1 X118.027 Y107.74
G1 X117.831 Y107.696
G1 X117.731 Y107.682
G1 X117.532 Y107.656
G1 X117.416 Y107.65
G1 X117.509 Y106.345
G1 X117.492 Y105.984
G1 E5 F2400
G1 F6000
G1 X117.233 Y106.009 E.00633
G1 X113.767 Y106.009 E.08431
G1 X113.083 Y105.918 E.01678
G1 X112.543 Y105.727 E.01393
G1 X112.284 Y105.615 E.00686
G1 X111.808 Y105.28 E.01416
G1 X111.299 Y104.718 E.01844
G1 X109.43 Y101.504 E.09043
G1 X109.21 Y101.031 E.01269
G1 X109.072 Y100.511 E.01309
G1 X109.029 Y99.975 E.01308
G1 X109.072 Y99.489 E.01187
G1 X109.199 Y99 E.01229
G1 X109.43 Y98.496 E.01349
G1 X111.299 Y95.282 E.09043
G1 X111.873 Y94.665 E.0205
G1 X112.446 Y94.299 E.01654
G1 X113.032 Y94.085 E.01517
G1 X113.768 Y93.991 E.01805
G1 X117.485 Y94.003 E.09041
G1 X118.188 Y94.15 E.01747
G1 X118.755 Y94.407 E.01514
G1 X119.328 Y94.844 E.01753
G1 X119.701 Y95.282 E.01399
G1 X121.57 Y98.496 E.09043
G1 X121.79 Y98.969 E.01269
G1 X121.928 Y99.488 E.01306
G1 X121.964 Y100.206 E.01749
G1 X121.879 Y100.743 E.01322
G1 X121.7 Y101.25 E.01308
G1 X119.702 Y104.717 E.09733
G1 X119.162 Y105.305 E.01942
G1 X118.714 Y105.617 E.01328
G1 X118.3 Y105.812 E.01113
G1 X117.784 Y105.957 E.01304
G1 X117.551 Y105.979 E.00569
G1 X117.551 Y105.979 F9000
G1 X117.6 Y106.339
;TYPE:Perimeter
G1 F6000
G1 X117.282 Y106.372 E.00778
G1 X113.767 Y106.374 E.0855
G1 X113.034 Y106.28 E.01798
G1 X112.81 Y106.232 E.00557
G1 X112.181 Y105.973 E.01655
G1 X111.738 Y105.678 E.01295
G1 X111.506 Y105.498 E.00714
G1 X110.982 Y104.902 E.0193
G1 X109.114 Y101.688 E.09042
G1 X108.878 Y101.185 E.01351
G1 X108.718 Y100.603 E.01468
G1 X108.664 Y100.003 E.01465
G1 X108.703 Y99.486 E.01261
G1 X108.845 Y98.907 E.0145
G1 X109.114 Y98.312 E.01588
G1 X110.983 Y95.098 E.09043
G1 X111.371 Y94.66 E.01423
G1 X111.676 Y94.357 E.01046
G1 X112.249 Y93.991 E.01654
G1 X112.909 Y93.741 E.01717
G1 X113.7 Y93.63 E.01943
G1 X117.486 Y93.637 E.09209
G1 X118.265 Y93.792 E.01932
G1 X118.908 Y94.075 E.01709
G1 X119.552 Y94.554 E.01952
G1 X120.017 Y95.098 E.01741
G1 X121.886 Y98.312 E.09043
G1 X122.122 Y98.815 E.01351
G1 X122.282 Y99.396 E.01466
G1 X122.329 Y100.19 E.01935
G1 X122.24 Y100.803 E.01507
G1 X122.044 Y101.374 E.01468
G1 X120.018 Y104.9 E.09892
G1 X119.43 Y105.554 E.02139
G1 X118.92 Y105.919 E.01525
G1 X118.454 Y106.144 E.01259
G1 X117.881 Y106.309 E.0145
G1 X117.66 Y106.333 E.00541
G1 X117.66 Y106.333 F9000
G1 X117.712 Y106.718
;WIDTH:0.491881
G1 F6000
G1 X117.467 Y106.769 E.00762
G1 X117.233 Y106.781 E.00713
;WIDTH:0.48242
G1 X113.768 Y106.779 E.10328
;WIDTH:0.477167
G1 X113.376 Y106.711 E.01172
;WIDTH:0.438583
G1 X112.985 Y106.642 E.01068
;WIDTH:0.399999
G1 X112.671 Y106.57 E.00784
G1 X112.042 Y106.311 E.01655
G1 X111.527 Y105.977 E.01493
G1 X111.235 Y105.744 E.00909
G1 X110.779 Y105.239 E.01655
G1 X110.666 Y105.085 E.00465
G1 X108.798 Y101.872 E.0904
G1 X108.547 Y101.339 E.01433
G1 X108.364 Y100.695 E.01628
G1 X108.299 Y100.03 E.01625
G1 X108.338 Y99.454 E.01404
G1 X108.491 Y98.815 E.01598
G1 X108.759 Y98.203 E.01625
G1 X110.666 Y94.914 E.09248
G1 X111.103 Y94.411 E.01621
G1 X111.479 Y94.049 E.0127
G1 X112.053 Y93.683 E.01656
G1 X112.786 Y93.396 E.01915
G1 X113.77 Y93.26 E.02416
G1 X117.487 Y93.271 E.09041
G1 X118.342 Y93.435 E.02118
G1 X119.062 Y93.743 E.01905
G1 X119.775 Y94.265 E.02149
G1 X120.241 Y94.783 E.01695
G1 X120.333 Y94.914 E.00389
G1 X122.202 Y98.128 E.09043
G1 X122.453 Y98.661 E.01433
G1 X122.636 Y99.304 E.01626
G1 X122.695 Y100.174 E.02121
G1 X122.6 Y100.863 E.01692
G1 X122.388 Y101.497 E.01626
G1 X122.32 Y101.646 E.00398
G1 X120.335 Y105.083 E.09654
G1 X119.979 Y105.5 E.01334
G1 X119.544 Y105.936 E.01498
G1 X119.127 Y106.221 E.01229
G1 X118.608 Y106.475 E.01405
G1 X117.978 Y106.662 E.01598
;WIDTH:0.44594
G1 X117.771 Y106.705 E.00579
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X117.712 Y106.718 E-.0287
G1 X117.467 Y106.769 E-.11887
G1 X117.233 Y106.781 E-.1113
G1 X114.62 Y106.779 E-1.24113
;WIPE_END
G1 X114.62 Y106.357 F9000
G1 X117.244 Y106.357
G1 X117.432 Y106.349
G1 X117.532 Y106.344
G1 X117.731 Y106.318
G1 X117.831 Y106.304
G1 X118.027 Y106.26
G1 X118.125 Y106.237
G1 X118.316 Y106.176
G1 X118.411 Y106.143
G1 X118.597 Y106.066
G1 X118.688 Y106.025
G1 X118.867 Y105.932
G1 X118.954 Y105.882
G1 X119.123 Y105.774
G1 X119.205 Y105.715
G1 X119.365 Y105.593
G1 X119.441 Y105.527
G1 X119.589 Y105.391
G1 X119.658 Y105.319
G1 X119.794 Y105.17
G1 X119.856 Y105.091
G1 X119.978 Y104.932
G1 X120.033 Y104.847
G1 X120.134 Y104.689
G1 X121.878 Y101.668
G1 X121.964 Y101.502
G1 X122.01 Y101.412
G1 X122.087 Y101.227
G1 X122.125 Y101.133
G1 X122.185 Y100.942
G1 X122.213 Y100.845
G1 X122.257 Y100.649
G1 X122.276 Y100.55
G1 X122.302 Y100.351
G1 X122.312 Y100.251
G1 X122.32 Y100.05
G1 X122.32 Y99.95
G1 X122.312 Y99.749
G1 X122.302 Y99.649
G1 X122.276 Y99.45
G1 X122.257 Y99.351
G1 X122.213 Y99.155
G1 X122.185 Y99.058
G1 X122.125 Y98.867
G1 X122.087 Y98.773
G1 X122.01 Y98.588
G1 X121.964 Y98.498
G1 X121.878 Y98.332
G1 X121.346 Y97.412
G1 X124.901 Y91.931
G1 X125.282 Y91.931
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X125.25 Y92.001 E.00187
G1 X125.25 Y135.999 E1.07021
G1 X125.313 Y136.137 E.00369
G1 X126.065 Y136.789 E.02421
G1 X126.537 Y137.238 E.01585
G1 X126.704 Y137.495 E.00746
G1 X126.465 Y137.839 E.01019
G1 X125.386 Y138.8 E.03515
G1 X105.587 Y138.8 E.48159
G1 X104.915 Y138.191 E.02206
G1 X104.315 Y137.581 E.02081
G1 X104.305 Y137.463 E.00288
G1 X104.529 Y137.167 E.00903
G1 X104.934 Y136.79 E.01346
G1 X105.687 Y136.137 E.02424
G1 X105.75 Y135.999 E.00369
G1 X105.75 Y92.001 E1.07021
G1 X105.687 Y91.863 E.00369
G1 X104.935 Y91.211 E.02421
G1 X104.463 Y90.762 E.01585
G1 X104.296 Y90.505 E.00746
G1 X104.535 Y90.161 E.01019
G1 X105.614 Y89.2 E.03515
G1 X125.413 Y89.2 E.48159
G1 X126.437 Y90.135 E.03373
G1 X126.667 Y90.412 E.00876
G1 X126.699 Y90.535 E.00309
G1 X126.468 Y90.836 E.00923
G1 X126.066 Y91.21 E.01336
G1 X125.313 Y91.863 E.02424
G1 X125.307 Y91.877 E.00037
G1 X125.307 Y91.877 F9000
G1 X124.943 Y91.773
;TYPE:Perimeter
G1 F6000
G1 X124.921 Y91.804 E.00092
G1 X124.884 Y92.001 E.00488
G1 X124.884 Y135.999 E1.07021
G1 X124.921 Y136.196 E.00488
G1 X125.074 Y136.413 E.00646
G1 X125.819 Y137.059 E.02399
G1 X126.271 Y137.49 E.01519
G1 X126.195 Y137.589 E.00304
G1 X125.247 Y138.434 E.03089
G1 X105.728 Y138.434 E.47478
G1 X104.723 Y137.504 E.03331
G1 X105.179 Y137.062 E.01545
G1 X105.926 Y136.413 E.02407
G1 X106.079 Y136.196 E.00646
G1 X106.116 Y135.999 E.00488
G1 X106.116 Y92.001 E1.07021
G1 X106.079 Y91.804 E.00488
G1 X105.926 Y91.587 E.00646
G1 X105.181 Y90.941 E.02399
G1 X104.729 Y90.51 E.01519
G1 X104.805 Y90.411 E.00304
G1 X105.753 Y89.566 E.03089
G1 X125.272 Y89.566 E.47478
G1 X125.829 Y90.069 E.01826
G1 X126.267 Y90.498 E.01491
G1 X126.196 Y90.589 E.00281
G1 X125.821 Y90.938 E.01246
G1 X125.074 Y91.587 E.02407
G1 X124.977 Y91.724 E.00408
G1 X124.977 Y91.724 F9000
G1 X124.616 Y91.62
G1 F6000
G1 X124.58 Y91.673 E.00156
G1 X124.519 Y92.001 E.00812
G1 X124.519 Y135.999 E1.07021
G1 X124.58 Y136.327 E.00812
G1 X124.834 Y136.69 E.01078
G1 X125.749 Y137.497 E.02968
G1 X125.108 Y138.069 E.0209
G1 X105.869 Y138.069 E.46797
G1 X105.247 Y137.498 E.02054
G1 X106.166 Y136.69 E.02977
G1 X106.42 Y136.327 E.01078
G1 X106.481 Y135.999 E.00812
G1 X106.481 Y92.001 E1.07021
G1 X106.42 Y91.673 E.00812
G1 X106.166 Y91.31 E.01078
G1 X105.251 Y90.503 E.02968
G1 X105.892 Y89.931 E.0209
G1 X125.131 Y89.931 E.46797
G1 X125.756 Y90.5 E.02056
G1 X124.834 Y91.31 E.02985
G1 X124.651 Y91.571 E.00775
G1 X124.651 Y91.571 F9000
G1 X124.29 Y91.468
G1 F6000
G1 X124.238 Y91.541 E.00218
G1 X124.153 Y92.001 E.01138
G1 X124.153 Y135.999 E1.07021
G1 X124.238 Y136.459 E.01138
G1 X124.595 Y136.966 E.01508
G1 X125.203 Y137.494 E.01959
G1 X124.968 Y137.703 E.00765
G1 X106.009 Y137.703 E.46116
G1 X105.787 Y137.502 E.00728
G1 X106.405 Y136.966 E.0199
G1 X106.762 Y136.459 E.01508
G1 X106.847 Y135.999 E.01138
G1 X106.847 Y92.001 E1.07021
G1 X106.762 Y91.541 E.01138
G1 X106.405 Y91.034 E.01508
G1 X105.797 Y90.506 E.01959
G1 X106.032 Y90.297 E.00765
G1 X124.991 Y90.297 E.46116
G1 X125.213 Y90.498 E.00728
G1 X124.595 Y91.034 E.0199
G1 X124.324 Y91.419 E.01145
G1 X124.324 Y91.419 F9000
G1 X123.963 Y91.316
G1 F6000
G1 X123.897 Y91.41 E.00279
G1 X123.787 Y92.001 E.01462
G1 X123.787 Y98.558 E.15949
;WIDTH:0.413491
G1 X123.782 Y100.516 E.04938
;WIDTH:0.409857
G1 X123.783 Y101.362 E.02113
;WIDTH:0.409691
G1 X123.787 Y101.867 E.01261
;WIDTH:0.399999
G1 X123.787 Y112.558 E.26005
;WIDTH:0.413491
G1 X123.782 Y114.516 E.04938
;WIDTH:0.409857
G1 X123.783 Y115.362 E.02113
;WIDTH:0.409691
G1 X123.787 Y115.867 E.01261
;WIDTH:0.399999
G1 X123.787 Y126.558 E.26005
;WIDTH:0.413491
G1 X123.782 Y128.516 E.04938
;WIDTH:0.409857
G1 X123.783 Y129.362 E.02113
;WIDTH:0.409691
G1 X123.787 Y129.867 E.01261
;WIDTH:0.399999
G1 X123.787 Y135.999 E.14915
G1 X123.897 Y136.59 E.01462
G1 X124.355 Y137.242 E.01938
G1 X124.465 Y137.337 E.00354
G1 X106.535 Y137.337 E.43613
G1 X106.645 Y137.242 E.00354
G1 X107.103 Y136.59 E.01938
G1 X107.213 Y135.999 E.01462
G1 X107.213 Y129.442 E.15949
;WIDTH:0.416164
G1 X107.211 Y127.901 E.03914
;WIDTH:0.442666
G1 X107.234 Y127.064 E.02274
G1 X107.213 Y126.558 E.01376
;WIDTH:0.399999
G1 X107.213 Y115.442 E.27039
;WIDTH:0.415128
G1 X107.211 Y113.8 E.04159
;WIDTH:0.442682
G1 X107.234 Y113.063 E.02003
G1 X107.213 Y112.558 E.01373
;WIDTH:0.399999
G1 X107.213 Y101.442 E.27039
;WIDTH:0.415128
G1 X107.211 Y99.8 E.04159
;WIDTH:0.442682
G1 X107.234 Y99.063 E.02003
G1 X107.213 Y98.558 E.01373
;WIDTH:0.399999
G1 X107.213 Y92.001 E.15949
G1 X107.103 Y91.41 E.01462
G1 X106.645 Y90.758 E.01938
G1 X106.535 Y90.663 E.00354
G1 X124.465 Y90.663 E.43613
G1 X124.355 Y90.758 E.00354
G1 X123.998 Y91.267 E.01512
G1 E-5 F3600
G1 X123.998 Y91.267 F9000
G1 X107.487 Y92.781
G1 E5 F2400
;TYPE:Solid infill
G1 F1200
G1 X107.487 Y98.562 E.14062
G1 X107.522 Y98.553 E.00088
G1 X107.931 Y97.62 E.02478
G1 X109.795 Y94.413 E.09023
G1 X110.053 Y94.065 E.01054
G1 X110.56 Y93.518 E.01814
G1 X110.943 Y93.198 E.01214
G1 X111.507 Y92.838 E.01628
G1 X111.909 Y92.642 E.01088
G1 X112.738 Y92.373 E.0212
G1 X113.752 Y92.256 E.02483
G1 X117.485 Y92.266 E.0908
G1 X117.893 Y92.31 E.00998
G1 X118.548 Y92.451 E.0163
G1 X118.96 Y92.588 E.01056
G1 X119.479 Y92.828 E.01391
G1 X119.819 Y93.077 E.01025
G1 X119.09 Y92.402 E.02417
G1 X117.754 Y91.066 E.04596
G1 X117.754 Y90.937 E.00314
G1 X107.099 Y90.937 E.25917
G1 X107.367 Y91.347 E.01191
G1 X107.484 Y91.976 E.01556
G1 X107.487 Y92.598 E.01513
G1 X107.853 Y92.598 E.0089
G1 X107.843 Y91.909 E.01676
G1 X107.731 Y91.303 E.01499
G1 X112.51 Y91.303 E.11624
;WIDTH:0.442942
G1 X112.542 Y91.324 E.00104
;WIDTH:0.485884
G1 X112.574 Y91.346 E.00117
;WIDTH:0.528826
G1 X112.606 Y91.367 E.00126
;WIDTH:0.571768
G1 X112.638 Y91.388 E.00137
G1 X112.694 Y91.386 E.002
;WIDTH:0.567762
G1 X113.233 Y91.372 E.01913
;WIDTH:0.53902
G1 X113.773 Y91.358 E.01813
;WIDTH:0.515693
G1 X117.454 Y91.36 E.11787
G1 X117.982 Y91.895 E.02407
G1 X117.349 Y91.842 E.02034
G1 X113.774 Y91.834 E.11447
;WIDTH:0.51289
G1 X113.705 Y91.836 E.0022
;WIDTH:0.542329
G1 X113.195 Y91.879 E.01729
;WIDTH:0.571768
G1 X112.684 Y91.922 E.01833
G1 X112.67 Y91.948 E.00106
;WIDTH:0.528826
G1 X112.655 Y91.973 E.00096
;WIDTH:0.485884
G1 X112.64 Y91.999 E.0009
;WIDTH:0.442942
G1 X112.625 Y92.025 E.00082
;WIDTH:0.399999
G1 X111.796 Y92.294 E.0212
G1 X111.31 Y92.53 E.01314
G1 X110.69 Y92.931 E.01796
G1 X110.292 Y93.269 E.0127
G1 X109.785 Y93.816 E.01814
G1 X109.479 Y94.23 E.01252
G1 X107.853 Y97.026 E.07867
G1 X107.853 Y92.781 E.10326
G1 E-5 F3600
G1 X107.853 Y92.781 F9000
G1 X108.31 Y95.512
G1 E5 F2400
G1 F1200
G1 X109.162 Y94.046 E.04124
G1 X109.517 Y93.567 E.0145
G1 X110.024 Y93.021 E.01812
G1 X110.456 Y92.65 E.01385
G1 X111.114 Y92.221 E.01911
G1 X111.563 Y91.995 E.01223
G1 X112.51 Y91.673 E.02433
G1 X108.17 Y91.668 E.10557
G1 X108.218 Y92.009 E.00838
G1 X108.218 Y95.67 E.08905
G1 X108.218 Y95.67 F9000
G1 X108.584 Y94.313
G1 F1200
G1 X108.584 Y92.034 E.05543
G1 X110.728 Y92.034 E.05215
G1 X110.353 Y92.273 E.01082
G1 X109.874 Y92.66 E.01498
G1 X109.561 Y92.981 E.01091
G1 X109.158 Y93.428 E.01464
G1 X108.846 Y93.862 E.013
G1 X108.676 Y94.155 E.00824
G1 X108.676 Y94.155 F9000
G1 X108.957 Y93.086
;WIDTH:0.415469
G1 F1200
G1 X108.957 Y92.407 E.01721
G1 X109.598 Y92.407 E.01625
G1 X109.081 Y92.951 E.01903
G1 E-5 F3600
G1 X109.081 Y92.951 F9000
G1 X117.532 Y93.656
G1 X117.731 Y93.682
G1 X117.831 Y93.696
G1 X118.027 Y93.74
G1 X118.125 Y93.763
G1 X118.316 Y93.824
G1 X118.411 Y93.857
G1 X118.597 Y93.934
G1 X118.688 Y93.975
G1 X118.867 Y94.068
G1 X118.954 Y94.118
G1 X119.123 Y94.226
G1 X119.205 Y94.285
G1 X119.364 Y94.407
G1 X122.755 Y97.093
G1 E5 F2400
;WIDTH:0.386632
G1 F1200
G1 X123.189 Y97.526 E.01437
G1 X123.351 Y97.623 E.00442
G1 X123.52 Y97.535 E.00447
G1 X123.499 Y98.571 E.02428
G1 X123.064 Y97.623 E.02444
G1 X122.847 Y97.251 E.01009
;WIDTH:0.399999
G1 X123.359 Y97.188 E.01255
G1 X122.069 Y95.898 E.04438
G1 X121.9 Y95.61 E.00812
;WIDTH:0.374336
G1 X121.911 Y95.651 E.00096
G1 X121.84 Y95.67 E.00166
G1 X121.859 Y95.599 E.00166
G1 E-5 F3600
G1 X121.859 Y95.599 F9000
G1 X123.513 Y96.826
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X121.35 Y94.663 E.07441
G1 X121.145 Y94.404 E.00803
;WIDTH:0.374336
G1 X120.576 Y93.763 E.01939
G1 X119.819 Y93.077 E.02311
G1 E-5 F3600
G1 X119.819 Y93.077 F9000
G1 X118.142 Y90.937
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X123.513 Y96.308 E.18476
G1 X123.513 Y95.791 E.01258
G1 X118.659 Y90.937 E.16697
G1 X119.176 Y90.937 E.01258
G1 X123.513 Y95.274 E.14919
G1 X123.513 Y94.757 E.01258
G1 X119.693 Y90.937 E.13141
G1 X120.21 Y90.937 E.01258
G1 X123.513 Y94.24 E.11362
G1 E-5 F3600
G1 X123.513 Y94.24 F9000
G1 X120.856 Y91.066
G1 E5 F2400
G1 F1200
G1 X123.513 Y93.723 E.0914
G1 X123.513 Y92.009 E.04169
G1 X123.633 Y91.347 E.01636
G1 X123.901 Y90.937 E.01191
G1 X120.727 Y90.937 E.0772
G1 X120.727 Y90.937 F9000
G1 X121.61 Y91.303
G1 F1200
G1 X123.269 Y91.303 E.04035
G1 X123.147 Y92.009 E.01743
G1 X123.147 Y92.84 E.02021
G1 X121.739 Y91.432 E.04843
G1 X121.739 Y91.432 F9000
G1 X122.7 Y91.695
;WIDTH:0.58622
G1 F1200
G1 X122.651 Y91.743 E.00252
G1 X122.669 Y91.81 E.00255
G1 X122.735 Y91.828 E.00251
G1 X122.784 Y91.779 E.00254
G1 X122.766 Y91.713 E.00251
G1 E-5 F3600
G1 X122.766 Y91.713 F9000
G1 X122.796 Y111.163
G1 E5 F2400
;WIDTH:0.385725
G1 F1200
G1 X123.172 Y111.539 E.01243
G1 X123.338 Y111.626 E.00438
G1 X123.519 Y111.511 E.00501
G1 X123.499 Y112.571 E.02478
G1 X123.063 Y111.623 E.02439
G1 X122.887 Y111.321 E.00817
;WIDTH:0.399999
G1 X123.332 Y111.192 E.01127
G1 X122.111 Y109.971 E.042
G1 X121.942 Y109.683 E.00812
;WIDTH:0.374336
G1 X121.953 Y109.724 E.00096
G1 X121.882 Y109.743 E.00166
G1 X121.901 Y109.672 E.00166
G1 X121.901 Y109.672 F9000
G1 X123.512 Y110.855
;WIDTH:0.399999
G1 F1200
G1 X121.393 Y108.736 E.07289
G1 X121.188 Y108.477 E.00803
;WIDTH:0.374336
G1 X120.428 Y107.63 E.02574
G1 X119.714 Y106.999 E.02155
;WIDTH:0.399999
G1 X120.009 Y106.835 E.00821
G1 X123.511 Y110.337 E.12047
G1 X123.511 Y109.819 E.0126
G1 X120.303 Y106.612 E.11034
G1 X120.559 Y106.35 E.00891
G1 X123.51 Y109.302 E.10153
G1 E-5 F3600
G1 X123.51 Y109.302 F9000
G1 X120.931 Y106.205
G1 E5 F2400
G1 F1200
G1 X123.51 Y108.784 E.08872
G1 X123.504 Y101.49 E.17742
G1 X123.487 Y101.487 E.00042
G1 X123.188 Y102.152 E.01774
G1 X121.208 Y105.581 E.09631
G1 X120.801 Y106.076 E.01559
G1 X121.296 Y106.053 E.01205
G1 X121.525 Y105.764 E.00897
G1 X123.139 Y102.969 E.07851
G1 X123.143 Y107.901 E.11997
G1 X121.425 Y106.182 E.05912
G1 X121.786 Y106.027 E.00956
G1 X122.775 Y104.331 E.04776
G1 X122.777 Y107.017 E.06533
G1 X121.916 Y106.156 E.02962
G1 X122.322 Y105.899 E.01169
;WIDTH:0.54319
G1 X122.277 Y105.944 E.00215
G1 X122.294 Y106.006 E.00218
G1 X122.355 Y106.022 E.00213
G1 X122.4 Y105.977 E.00215
G1 X122.384 Y105.916 E.00213
G1 E-5 F3600
G1 X122.384 Y105.916 F9000
G1 X113.169 Y107.696
G1 X112.973 Y107.74
G1 X112.875 Y107.763
G1 X112.684 Y107.824
G1 X112.589 Y107.857
G1 X112.403 Y107.934
G1 X112.312 Y107.975
G1 X112.133 Y108.068
G1 X112.046 Y108.118
G1 X111.877 Y108.226
G1 X111.795 Y108.285
G1 X111.636 Y108.407
G1 X108.022 Y111.462
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X109.795 Y108.413 E.08579
G1 X110.233 Y107.888 E.01663
G1 X107.487 Y105.142 E.09446
G1 X107.487 Y112.562 E.18048
G1 X107.522 Y112.553 E.00088
G1 X107.931 Y111.62 E.02478
G1 X107.853 Y111.026 E.01457
G1 X107.853 Y106.025 E.12164
G1 X109.737 Y107.909 E.06481
G1 X109.479 Y108.23 E.01002
G1 X107.944 Y110.868 E.07424
G1 X107.944 Y110.868 F9000
G1 X108.218 Y109.67
G1 F1200
G1 X108.218 Y106.907 E.06721
G1 X109.243 Y107.932 E.03526
G1 X108.31 Y109.512 E.04463
G1 X108.31 Y109.512 F9000
G1 X108.717 Y107.949
;WIDTH:0.570818
G1 F1200
G1 X108.734 Y108.014 E.0024
G1 X108.687 Y108.061 E.00237
G1 X108.622 Y108.044 E.0024
G1 X108.605 Y107.979 E.0024
G1 X108.652 Y107.932 E.00237
G1 X108.652 Y107.932 F9000
G1 X110.476 Y107.614
;WIDTH:0.399999
G1 F1200
G1 X107.487 Y104.625 E.10282
G1 X107.487 Y104.108 E.01258
G1 X110.736 Y107.356 E.11175
G1 E-5 F3600
G1 X110.736 Y107.356 F9000
G1 X109.714 Y105.354
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X110.105 Y105.838 E.01407
G1 X110.631 Y106.39 E.01724
G1 X111.337 Y106.996 E.02104
;WIDTH:0.399999
G1 X111.035 Y107.139 E.00813
G1 X107.487 Y103.591 E.12205
G1 X107.487 Y103.073 E.0126
G1 X109.509 Y105.096 E.06957
G1 X109.509 Y105.096 F9000
G1 X109.02 Y104.089
;WIDTH:0.374336
G1 F1200
G1 X109.031 Y104.13 E.00096
G1 X108.96 Y104.149 E.00166
G1 X108.979 Y104.078 E.00166
;WIDTH:0.399999
G1 X108.791 Y103.86 E.007
G1 X107.479 Y102.542 E.04524
;WIDTH:0.383813
G1 X107.481 Y101.4 E.02655
G1 X107.531 Y101.415 E.00121
G1 X107.811 Y102.113 E.01748
G1 X108.111 Y102.675 E.01481
G1 X107.867 Y102.431 E.00802
G1 X107.687 Y102.36 E.0045
G1 X107.617 Y102.422 E.00217
G1 E-5 F3600
G1 X107.617 Y102.422 F9000
G1 X108.022 Y125.462
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X109.795 Y122.413 E.08579
G1 X110.233 Y121.888 E.01663
G1 X107.487 Y119.142 E.09446
G1 X107.487 Y126.562 E.18048
G1 X107.522 Y126.553 E.00088
G1 X107.931 Y125.62 E.02478
G1 X107.853 Y125.026 E.01457
G1 X107.853 Y120.025 E.12164
G1 X109.737 Y121.909 E.06481
G1 X109.479 Y122.23 E.01002
G1 X107.944 Y124.868 E.07424
G1 X107.944 Y124.868 F9000
G1 X108.218 Y123.67
G1 F1200
G1 X108.218 Y120.908 E.06718
G1 X109.243 Y121.932 E.03524
G1 X108.31 Y123.512 E.04463
G1 X108.31 Y123.512 F9000
G1 X108.717 Y121.949
;WIDTH:0.570806
G1 F1200
G1 X108.734 Y122.014 E.0024
G1 X108.687 Y122.061 E.00237
G1 X108.622 Y122.044 E.0024
G1 X108.605 Y121.979 E.0024
G1 X108.652 Y121.932 E.00237
G1 X108.652 Y121.932 F9000
G1 X110.476 Y121.614
;WIDTH:0.399999
G1 F1200
G1 X107.487 Y118.625 E.10282
G1 X107.487 Y118.108 E.01258
G1 X110.736 Y121.356 E.11175
G1 E-5 F3600
G1 X110.736 Y121.356 F9000
G1 X109.714 Y119.354
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X110.105 Y119.838 E.01407
G1 X110.631 Y120.39 E.01724
G1 X111.337 Y120.996 E.02104
;WIDTH:0.399999
G1 X111.035 Y121.139 E.00813
G1 X107.487 Y117.591 E.12205
G1 X107.487 Y117.073 E.0126
G1 X109.509 Y119.096 E.06957
G1 X109.509 Y119.096 F9000
G1 X109.02 Y118.089
;WIDTH:0.374336
G1 F1200
G1 X109.031 Y118.13 E.00096
G1 X108.96 Y118.149 E.00166
G1 X108.979 Y118.078 E.00166
;WIDTH:0.399999
G1 X108.791 Y117.86 E.007
G1 X107.479 Y116.542 E.04524
;WIDTH:0.383814
G1 X107.481 Y115.4 E.02655
G1 X107.531 Y115.415 E.00121
G1 X107.811 Y116.113 E.01748
G1 X108.111 Y116.675 E.01481
G1 X107.867 Y116.431 E.00802
G1 X107.687 Y116.36 E.0045
G1 X107.617 Y116.422 E.00217
G1 E-5 F3600
G1 X107.617 Y116.422 F9000
G1 X111.636 Y119.593
G1 X111.795 Y119.715
G1 X111.877 Y119.774
G1 X112.046 Y119.882
G1 X112.133 Y119.932
G1 X112.312 Y120.025
G1 X112.403 Y120.066
G1 X112.589 Y120.143
G1 X116.683 Y121.643
G1 X117.244 Y121.643
G1 X117.432 Y121.651
G1 X117.532 Y121.656
G1 X118.027 Y121.74
G1 X122.796 Y125.163
G1 E5 F2400
;WIDTH:0.385726
G1 F1200
G1 X123.172 Y125.539 E.01243
G1 X123.338 Y125.626 E.00438
G1 X123.519 Y125.511 E.00501
G1 X123.499 Y126.571 E.02478
G1 X123.063 Y125.623 E.02439
G1 X122.887 Y125.321 E.00817
;WIDTH:0.399999
G1 X123.332 Y125.192 E.01127
G1 X122.111 Y123.971 E.042
G1 X121.942 Y123.683 E.00812
;WIDTH:0.374336
G1 X121.953 Y123.724 E.00096
G1 X121.882 Y123.743 E.00166
G1 X121.901 Y123.672 E.00166
G1 X121.901 Y123.672 F9000
G1 X123.512 Y124.855
;WIDTH:0.399999
G1 F1200
G1 X121.393 Y122.736 E.07289
G1 X121.188 Y122.477 E.00803
;WIDTH:0.374336
G1 X120.428 Y121.63 E.02574
G1 X119.714 Y120.999 E.02155
;WIDTH:0.399999
G1 X120.009 Y120.835 E.00821
G1 X123.511 Y124.337 E.12047
G1 X123.511 Y123.819 E.0126
G1 X120.303 Y120.612 E.11034
G1 X120.559 Y120.35 E.00891
G1 X123.51 Y123.302 E.10153
G1 E-5 F3600
G1 X123.51 Y123.302 F9000
G1 X120.931 Y120.205
G1 E5 F2400
G1 F1200
G1 X123.51 Y122.784 E.08872
G1 X123.504 Y115.49 E.17742
G1 X123.487 Y115.487 E.00042
G1 X123.188 Y116.152 E.01774
G1 X121.208 Y119.581 E.09631
G1 X120.801 Y120.076 E.01559
G1 X121.296 Y120.053 E.01205
G1 X121.525 Y119.764 E.00897
G1 X123.139 Y116.969 E.07851
G1 X123.143 Y121.901 E.11997
G1 X121.425 Y120.182 E.05912
G1 X121.786 Y120.027 E.00956
G1 X122.775 Y118.331 E.04776
G1 X122.777 Y121.017 E.06533
G1 X121.916 Y120.156 E.02962
G1 X122.322 Y119.899 E.01169
;WIDTH:0.543194
G1 X122.277 Y119.944 E.00215
G1 X122.294 Y120.006 E.00218
G1 X122.355 Y120.022 E.00213
G1 X122.4 Y119.977 E.00215
G1 X122.384 Y119.916 E.00213
G1 E-5 F3600
G1 X122.384 Y119.916 F9000
G1 X113.169 Y121.696
G1 X112.973 Y121.74
G1 X112.875 Y121.763
G1 X112.684 Y121.824
G1 X112.589 Y121.857
G1 X112.403 Y121.934
G1 X112.312 Y121.975
G1 X112.133 Y122.068
G1 X112.046 Y122.118
G1 X111.877 Y122.226
G1 X111.795 Y122.285
G1 X111.636 Y122.407
G1 X111.559 Y122.473
G1 X111.411 Y122.609
G1 X111.342 Y122.681
G1 X111.206 Y122.83
G1 X111.144 Y122.909
G1 X111.022 Y123.068
G1 X110.967 Y123.153
G1 X110.866 Y123.311
G1 X109.122 Y126.332
G1 X109.036 Y126.498
G1 X108.99 Y126.588
G1 X108.913 Y126.773
G1 X108.875 Y126.867
G1 X108.815 Y127.058
G1 X108.787 Y127.155
G1 X108.743 Y127.351
G1 X108.724 Y127.45
G1 X107.487 Y135.991
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X107.487 Y134.288 E.04142
G1 X110.262 Y137.063 E.09546
G1 X107.099 Y137.063 E.07694
G1 X107.367 Y136.653 E.01191
G1 X107.454 Y136.17 E.01194
G1 X107.821 Y136.171 E.00893
G1 X107.731 Y136.697 E.01298
G1 X109.379 Y136.697 E.04009
G1 X107.853 Y135.171 E.05249
G1 X107.853 Y135.991 E.01995
G1 X108.261 Y136.176 E.0109
;WIDTH:0.580364
G1 X108.213 Y136.224 E.00247
G1 X108.231 Y136.29 E.00248
G1 X108.297 Y136.308 E.00248
G1 X108.345 Y136.259 E.00249
G1 X108.327 Y136.193 E.00248
G1 E-5 F3600
G1 X108.327 Y136.193 F9000
G1 X107.487 Y133.771
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X110.779 Y137.063 E.11324
G1 X111.297 Y137.063 E.0126
G1 X107.487 Y133.253 E.13106
G1 X107.487 Y132.736 E.01258
G1 X111.814 Y137.063 E.14885
G1 X112.331 Y137.063 E.01258
G1 X107.487 Y132.219 E.16663
G1 X107.487 Y131.702 E.01258
G1 X112.848 Y137.063 E.18441
G1 E-5 F3600
G1 X112.848 Y137.063 F9000
G1 X111.436 Y135.155
G1 E5 F2400
G1 F1200
G1 X113.236 Y136.934 E.06156
G1 X113.236 Y137.063 E.00314
G1 X123.901 Y137.063 E.25942
G1 X123.633 Y136.653 E.01191
G1 X123.516 Y136.024 E.01556
G1 X123.513 Y129.867 E.14976
G1 X123.489 Y129.481 E.00941
G1 X123.188 Y130.152 E.01789
G1 X121.208 Y133.581 E.09631
G1 X120.947 Y133.935 E.0107
G1 X120.439 Y134.483 E.01818
G1 X120.102 Y134.773 E.01081
G1 X119.438 Y135.197 E.01916
G1 X118.752 Y135.49 E.01814
G1 X117.93 Y135.689 E.02057
G1 X117.229 Y135.746 E.01711
G1 X113.773 Y135.746 E.08406
G1 X112.769 Y135.628 E.02459
G1 X112.283 Y135.498 E.01224
G1 X111.664 Y135.243 E.01628
G1 X111.305 Y135.028 E.01018
;WIDTH:0.375523
G1 X111.29 Y135.016 E.00044
;WIDTH:0.374336
G1 X110.546 Y134.36 E.02243
G1 X109.872 Y133.621 E.02262
;WIDTH:0.399999
G1 X109.664 Y133.362 E.00808
G1 X107.487 Y131.185 E.07489
G1 X107.633 Y130.814 E.0097
G1 X108.946 Y132.127 E.04517
G1 X109.134 Y132.344 E.00698
;WIDTH:0.374336
G1 X109.115 Y132.416 E.00168
G1 X109.186 Y132.396 E.00167
G1 X109.175 Y132.355 E.00096
G1 E-5 F3600
G1 X109.175 Y132.355 F9000
G1 X107.645 Y130.379
G1 E5 F2400
;WIDTH:0.387139
G1 F1200
G1 X107.805 Y130.478 E.00442
G1 X108.258 Y130.931 E.01503
G1 X107.936 Y130.377 E.01504
G1 X107.643 Y129.765 E.01592
G1 X107.53 Y129.415 E.00863
G1 X107.482 Y129.401 E.00117
G1 X107.48 Y130.458 E.02481
G1 E-5 F3600
G1 X107.48 Y130.458 F9000
G1 X112.979 Y136.079
G1 E5 F2400
;WIDTH:0.515174
G1 F1200
G1 X113.773 Y136.166 E.02555
;WIDTH:0.510267
G1 X117.229 Y136.166 E.10941
;WIDTH:0.511573
G1 X117.277 Y136.165 E.00152
;WIDTH:0.523796
G1 X118.029 Y136.105 E.02456
G1 X118.317 Y136.012 E.00985
;WIDTH:0.482531
G1 X118.606 Y135.919 E.00905
;WIDTH:0.441265
G1 X118.895 Y135.827 E.00821
;WIDTH:0.399999
G1 X119.635 Y135.505 E.01963
G1 X120.298 Y135.081 E.01914
G1 X120.707 Y134.732 E.01308
G1 X121.215 Y134.184 E.01818
G1 X121.525 Y133.764 E.0127
G1 X123.147 Y130.954 E.07892
G1 X123.157 Y136.091 E.12495
G1 X123.269 Y136.697 E.01499
G1 X118.907 Y136.697 E.1061
;WIDTH:0.445854
G1 X118.59 Y136.675 E.0087
;WIDTH:0.491709
G1 X118.273 Y136.652 E.00967
;WIDTH:0.537563
G1 X117.956 Y136.629 E.01064
G1 X117.229 Y136.642 E.02434
;WIDTH:0.510267
G1 X113.773 Y136.642 E.10941
;WIDTH:0.515174
G1 X113.535 Y136.635 E.00762
G1 X113.109 Y136.208 E.01929
G1 E-5 F3600
G1 X113.109 Y136.208 F9000
G1 X118.386 Y136.332
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X119.037 Y136.163 E.01636
G1 X119.832 Y135.813 E.02113
G1 X120.6 Y135.312 E.0223
G1 X121.171 Y134.77 E.01915
G1 X121.549 Y134.354 E.01367
G1 X121.842 Y133.947 E.0122
G1 X122.782 Y132.319 E.04573
G1 X122.782 Y135.991 E.08932
G1 X122.83 Y136.332 E.00838
G1 X118.569 Y136.332 E.10364
G1 X118.569 Y136.332 F9000
G1 X120.271 Y135.966
G1 F1200
G1 X120.838 Y135.589 E.01656
G1 X121.439 Y135.019 E.02015
G1 X121.843 Y134.571 E.01467
G1 X122.158 Y134.13 E.01318
G1 X122.416 Y133.684 E.01253
G1 X122.416 Y135.966 E.05551
G1 X120.454 Y135.966 E.04772
G1 X120.454 Y135.966 F9000
G1 X121.403 Y135.593
;WIDTH:0.41548
G1 F1200
G1 X122.043 Y134.914 E.02366
G1 X122.043 Y135.593 E.01722
G1 X121.586 Y135.593 E.01159
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X122.043 Y135.593 E-.21708
G1 X122.043 Y134.914 E-.32252
G1 X121.403 Y135.593 E-.44321
;WIPE_END
G1 E-.51719 F3600
G1 X122.722 Y138.451 F9000
G1 X123.366 Y139.849
G1 X124.244 Y141.752
G1 X124.737 Y143.26
G1 X124.792 Y142.94
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X124.567 Y142.907 E.00553
G1 X106.209 Y142.915 E.44654
G1 X105.983 Y143.003 E.0059
G1 X105.923 Y143.086 E.00249
G1 X105.914 Y145.616 E.06154
G1 X105.859 Y145.746 E.00343
G1 X105.729 Y145.798 E.00341
G1 X97.145 Y145.8 E.2088
G1 X95.349 Y145.699 E.04375
G1 X91.799 Y145.696 E.08635
G1 X91.488 Y145.611 E.00784
G1 X91.215 Y145.346 E.00925
G1 X91.1 Y144.916 E.01083
G1 X91.108 Y142.974 E.04724
G1 X91.204 Y142.677 E.00759
G1 X91.487 Y142.389 E.00982
G1 X91.798 Y142.304 E.00784
G1 X95.364 Y142.3 E.08674
G1 X97.138 Y142.2 E.04322
G1 X100.096 Y142.197 E.07195
G1 X100.16 Y142.17 E.00169
G1 X100.072 Y142.005 E.00455
G1 X99.762 Y141.765 E.00954
G1 X98.565 Y141.028 E.03419
G1 X97.821 Y140.451 E.0229
G1 X97.032 Y139.695 E.02658
G1 X96.56 Y139.101 E.01845
G1 X96.136 Y138.471 E.01847
G1 X95.668 Y137.697 E.022
G1 X91.75 Y137.693 E.0953
G1 X91.523 Y137.632 E.00572
G1 X91.321 Y137.488 E.00603
G1 X91.177 Y137.278 E.00619
G1 X91.108 Y137.026 E.00636
G1 X91.108 Y134.974 E.04991
G1 X91.215 Y134.654 E.00821
G1 X91.488 Y134.389 E.00925
G1 X91.799 Y134.304 E.00784
G1 X94.447 Y134.303 E.06441
G1 X94.31 Y133.034 E.03105
G1 X94.301 Y129.696 E.08119
G1 X91.709 Y129.688 E.06305
G1 X91.416 Y129.569 E.00769
G1 X91.24 Y129.389 E.00612
G1 X91.133 Y129.155 E.00626
G1 X91.1 Y128.917 E.00584
G1 X91.108 Y126.974 E.04726
G1 X91.215 Y126.653 E.00823
G1 X91.489 Y126.389 E.00926
G1 X91.799 Y126.304 E.00782
G1 X94.3 Y126.303 E.06083
G1 X94.3 Y121.697 E.11204
G1 X91.709 Y121.688 E.06302
G1 X91.416 Y121.569 E.00769
G1 X91.24 Y121.389 E.00612
G1 X91.133 Y121.155 E.00626
G1 X91.1 Y120.917 E.00584
G1 X91.108 Y118.974 E.04726
G1 X91.215 Y118.654 E.00821
G1 X91.488 Y118.389 E.00925
G1 X91.799 Y118.304 E.00784
G1 X94.3 Y118.303 E.06083
G1 X94.3 Y113.697 E.11204
G1 X91.709 Y113.688 E.06302
G1 X91.416 Y113.569 E.00769
G1 X91.24 Y113.389 E.00612
G1 X91.133 Y113.155 E.00626
G1 X91.1 Y112.917 E.00584
G1 X91.108 Y110.974 E.04726
G1 X91.215 Y110.654 E.00821
G1 X91.488 Y110.389 E.00925
G1 X91.799 Y110.304 E.00784
G1 X94.3 Y110.303 E.06083
G1 X94.3 Y105.697 E.11204
G1 X91.799 Y105.696 E.06083
G1 X91.489 Y105.611 E.00782
G1 X91.215 Y105.347 E.00926
G1 X91.11 Y105.057 E.0075
G1 X91.1 Y103.082 E.04804
G1 X91.15 Y102.789 E.00723
G1 X91.278 Y102.56 E.00638
G1 X91.472 Y102.395 E.00619
G1 X91.709 Y102.312 E.00611
G1 X94.3 Y102.303 E.06302
G1 X94.3 Y96.285 E.14638
G1 X91.798 Y96.285 E.06086
G1 X91.53 Y96.227 E.00667
G1 X91.317 Y96.082 E.00627
G1 X91.134 Y95.785 E.00849
G1 X91.1 Y95.573 E.00522
G1 X91.108 Y93.162 E.05865
G1 X91.211 Y92.875 E.00742
G1 X91.375 Y92.693 E.00596
G1 X91.588 Y92.58 E.00586
G1 X91.798 Y92.543 E.00519
G1 X105 Y92.543 E.32113
G1 X105 Y91.999 E.01323
G1 X104.335 Y91.42 E.02145
G1 X103.768 Y90.831 E.01989
G1 X103.655 Y90.533 E.00775
G1 X103.659 Y90.414 E.0029
G1 X103.775 Y90.16 E.00679
G1 X104.143 Y89.763 E.01317
G1 X105 Y89.001 E.02789
G1 X105.019 Y88.602 E.00972
G1 X105.151 Y88.503 E.00401
G1 X125.817 Y88.5 E.50268
G1 X125.959 Y88.568 E.00383
G1 X126 Y88.683 E.00297
G1 X126 Y89.001 E.00774
G1 X126.665 Y89.58 E.02145
G1 X127.054 Y89.983 E.01362
G1 X127.275 Y90.242 E.00828
G1 X127.353 Y90.517 E.00695
G1 X127.242 Y90.82 E.00785
G1 X126.671 Y91.414 E.02004
G1 X126 Y91.999 E.02165
G1 X126 Y92.543 E.01323
G1 X139.202 Y92.543 E.32113
G1 X139.591 Y92.671 E.00996
G1 X139.826 Y92.946 E.0088
G1 X139.9 Y93.256 E.00775
G1 X139.9 Y95.573 E.05636
G1 X139.846 Y95.844 E.00672
G1 X139.704 Y96.061 E.00631
G1 X139.412 Y96.249 E.00845
G1 X139 Y96.285 E.01006
G1 X136.7 Y96.285 E.05595
G1 X136.7 Y102.303 E.14638
G1 X139.201 Y102.304 E.06083
G1 X139.584 Y102.431 E.00981
G1 X139.766 Y102.624 E.00645
G1 X139.892 Y102.974 E.00905
G1 X139.9 Y104.918 E.04729
G1 X139.85 Y105.211 E.00723
G1 X139.722 Y105.44 E.00638
G1 X139.528 Y105.605 E.00619
G1 X139.291 Y105.688 E.00611
G1 X136.7 Y105.697 E.06302
G1 X136.7 Y110.303 E.11204
G1 X139.291 Y110.312 E.06302
G1 X139.584 Y110.431 E.00769
G1 X139.76 Y110.611 E.00612
G1 X139.867 Y110.845 E.00626
G1 X139.9 Y111.083 E.00584
G1 X139.892 Y113.026 E.04726
G1 X139.785 Y113.347 E.00823
G1 X139.511 Y113.611 E.00926
G1 X139.201 Y113.696 E.00782
G1 X136.7 Y113.697 E.06083
G1 X136.7 Y118.303 E.11204
G1 X139.201 Y118.304 E.06083
G1 X139.584 Y118.431 E.00981
G1 X139.766 Y118.624 E.00645
G1 X139.892 Y118.974 E.00905
G1 X139.9 Y120.918 E.04729
G1 X139.85 Y121.211 E.00723
G1 X139.722 Y121.44 E.00638
G1 X139.528 Y121.605 E.00619
G1 X139.291 Y121.688 E.00611
G1 X136.7 Y121.697 E.06302
G1 X136.7 Y126.303 E.11204
G1 X139.202 Y126.304 E.06086
G1 X139.477 Y126.368 E.00687
G1 X139.679 Y126.512 E.00603
G1 X139.825 Y126.728 E.00634
G1 X139.895 Y127.009 E.00704
G1 X139.892 Y129.026 E.04906
G1 X139.796 Y129.323 E.00759
G1 X139.528 Y129.605 E.00946
G1 X139.291 Y129.688 E.00611
G1 X136.699 Y129.697 E.06305
G1 X136.69 Y133.044 E.08141
G1 X136.607 Y133.972 E.02266
G1 X136.553 Y134.303 E.00816
G1 X139.201 Y134.304 E.06441
G1 X139.584 Y134.431 E.00981
G1 X139.766 Y134.624 E.00645
G1 X139.892 Y134.974 E.00905
G1 X139.892 Y137.026 E.04991
G1 X139.795 Y137.335 E.00788
G1 X139.632 Y137.532 E.00622
G1 X139.422 Y137.656 E.00593
G1 X138.992 Y137.693 E.0105
G1 X135.332 Y137.697 E.08903
G1 X134.868 Y138.464 E.0218
G1 X134.448 Y139.09 E.01834
G1 X133.732 Y139.945 E.02713
G1 X133.176 Y140.454 E.01834
G1 X132.065 Y141.276 E.03362
G1 X131.017 Y141.921 E.02993
G1 X130.856 Y142.096 E.00578
G1 X130.83 Y142.167 E.00184
G1 X131.115 Y142.202 E.00698
G1 X133.858 Y142.2 E.06672
G1 X135.53 Y142.298 E.04074
G1 X139.202 Y142.304 E.08932
G1 X139.477 Y142.368 E.00687
G1 X139.679 Y142.512 E.00603
G1 X139.827 Y142.736 E.00653
G1 X139.9 Y143.084 E.00865
G1 X139.892 Y145.026 E.04724
G1 X139.785 Y145.346 E.00821
G1 X139.512 Y145.611 E.00925
G1 X139.201 Y145.696 E.00784
G1 X135.636 Y145.7 E.08672
G1 X133.865 Y145.8 E.04315
G1 X125.269 Y145.798 E.20909
G1 X125.124 Y145.726 E.00394
G1 X125.086 Y145.615 E.00285
G1 X125.088 Y143.418 E.05344
G1 X125.068 Y143.052 E.00892
G1 X124.912 Y142.958 E.00443
G1 X124.851 Y142.949 E.0015
G1 X124.851 Y142.949 F9000
G1 X124.718 Y143.325
;TYPE:Perimeter
G1 F6000
G1 X124.718 Y143.301 E.00058
G1 X124.566 Y143.278 E.00374
G1 X106.288 Y143.28 E.44459
G1 X106.279 Y145.617 E.05685
G1 X106.193 Y145.903 E.00726
G1 X105.984 Y146.096 E.00692
G1 X105.729 Y146.164 E.00642
G1 X97.145 Y146.166 E.2088
G1 X95.409 Y146.069 E.04229
G1 X91.798 Y146.061 E.08783
G1 X91.338 Y145.941 E.01156
G1 X91.132 Y145.801 E.00606
G1 X90.916 Y145.551 E.00804
;WIDTH:0.448698
G1 X90.833 Y145.356 E.00584
;WIDTH:0.497396
G1 X90.749 Y145.162 E.00651
;WIDTH:0.546094
G1 X90.666 Y144.967 E.00721
;WIDTH:0.546753
G1 X90.661 Y144.916 E.00175
;WIDTH:0.550713
G1 X90.667 Y142.972 E.06678
G1 X90.711 Y142.875 E.00366
;WIDTH:0.513035
G1 X90.756 Y142.778 E.0034
;WIDTH:0.475356
G1 X90.801 Y142.681 E.00314
;WIDTH:0.437678
G1 X90.845 Y142.584 E.00286
;WIDTH:0.399999
G1 X91.162 Y142.174 E.01261
G1 X91.39 Y142.037 E.00647
G1 X91.798 Y141.939 E.01021
G1 X95.309 Y141.934 E.0854
G1 X97.115 Y141.835 E.044
G1 X99.174 Y141.832 E.05008
G1 X98.373 Y141.339 E.02288
G1 X97.597 Y140.741 E.02383
G1 X96.779 Y139.959 E.02753
G1 X96.427 Y139.522 E.01365
G1 X95.996 Y138.917 E.01807
G1 X95.462 Y138.062 E.02452
G1 X91.75 Y138.059 E.09029
G1 X91.314 Y137.932 E.01105
G1 X91.021 Y137.697 E.00914
;WIDTH:0.446145
G1 X90.907 Y137.494 E.00638
;WIDTH:0.49229
G1 X90.794 Y137.291 E.00708
;WIDTH:0.538435
G1 X90.68 Y137.087 E.00784
;WIDTH:0.551182
G1 X90.666 Y137.026 E.00215
;WIDTH:0.551346
G1 X90.666 Y134.974 E.07057
G1 X90.714 Y134.87 E.00394
;WIDTH:0.51351
G1 X90.761 Y134.766 E.00364
;WIDTH:0.475673
G1 X90.809 Y134.662 E.00336
;WIDTH:0.437836
G1 X90.856 Y134.558 E.00306
;WIDTH:0.399999
G1 X91.17 Y134.166 E.01222
G1 X91.391 Y134.036 E.00624
G1 X91.799 Y133.939 E.0102
G1 X94.024 Y133.938 E.05412
G1 X93.945 Y133.067 E.02127
G1 X93.936 Y130.06 E.07314
G1 X91.708 Y130.053 E.05419
G1 X91.288 Y129.917 E.01074
G1 X90.996 Y129.667 E.00935
;WIDTH:0.449157
G1 X90.887 Y129.452 E.00665
;WIDTH:0.498315
G1 X90.778 Y129.237 E.00744
;WIDTH:0.547472
G1 X90.67 Y129.021 E.00824
;WIDTH:0.549927
G1 X90.663 Y128.97 E.00177
;WIDTH:0.551991
G1 X90.666 Y126.972 E.0688
G1 X90.714 Y126.868 E.00394
;WIDTH:0.513993
G1 X90.761 Y126.765 E.00361
;WIDTH:0.475995
G1 X90.809 Y126.661 E.00337
;WIDTH:0.437997
G1 X90.857 Y126.557 E.00308
;WIDTH:0.399999
G1 X91.171 Y126.165 E.01222
G1 X91.392 Y126.036 E.00622
G1 X91.799 Y125.939 E.01018
G1 X93.934 Y125.937 E.05193
G1 X93.934 Y122.061 E.09428
G1 X91.708 Y122.053 E.05415
G1 X91.288 Y121.917 E.01074
G1 X90.996 Y121.667 E.00935
;WIDTH:0.449361
G1 X90.887 Y121.452 E.00665
;WIDTH:0.498723
G1 X90.778 Y121.237 E.00745
;WIDTH:0.548084
G1 X90.669 Y121.022 E.00824
;WIDTH:0.550568
G1 X90.663 Y120.97 E.0018
;WIDTH:0.552631
G1 X90.666 Y118.972 E.06889
G1 X90.713 Y118.869 E.0039
;WIDTH:0.514473
G1 X90.761 Y118.765 E.00366
;WIDTH:0.476315
G1 X90.809 Y118.661 E.00337
;WIDTH:0.438157
G1 X90.856 Y118.558 E.00304
;WIDTH:0.399999
G1 X91.17 Y118.166 E.01222
G1 X91.391 Y118.036 E.00624
G1 X91.799 Y117.939 E.0102
G1 X93.934 Y117.937 E.05193
G1 X93.934 Y114.061 E.09428
G1 X91.708 Y114.053 E.05415
G1 X91.288 Y113.917 E.01074
G1 X90.996 Y113.667 E.00935
;WIDTH:0.449564
G1 X90.887 Y113.452 E.00666
;WIDTH:0.499129
G1 X90.778 Y113.237 E.00745
;WIDTH:0.548694
G1 X90.669 Y113.022 E.00825
;WIDTH:0.551208
G1 X90.663 Y112.97 E.0018
;WIDTH:0.553271
G1 X90.665 Y110.972 E.06897
G1 X90.713 Y110.869 E.00392
;WIDTH:0.514953
G1 X90.761 Y110.765 E.00366
;WIDTH:0.476635
G1 X90.809 Y110.661 E.00337
;WIDTH:0.438317
G1 X90.856 Y110.558 E.00304
;WIDTH:0.399999
G1 X91.17 Y110.166 E.01222
G1 X91.391 Y110.036 E.00624
G1 X91.799 Y109.939 E.0102
G1 X93.934 Y109.937 E.05193
G1 X93.934 Y106.063 E.09423
G1 X91.799 Y106.061 E.05193
G1 X91.339 Y105.941 E.01156
G1 X91.123 Y105.791 E.0064
G1 X90.825 Y105.377 E.01241
;WIDTH:0.438437
G1 X90.785 Y105.29 E.00257
;WIDTH:0.476874
G1 X90.745 Y105.202 E.00285
;WIDTH:0.515311
G1 X90.705 Y105.115 E.00306
;WIDTH:0.553748
G1 X90.665 Y105.028 E.00331
G1 X90.659 Y103.084 E.06717
;WIDTH:0.550097
G1 X90.702 Y102.966 E.00431
;WIDTH:0.512573
G1 X90.744 Y102.849 E.00395
;WIDTH:0.475048
G1 X90.787 Y102.731 E.00368
;WIDTH:0.437524
G1 X90.829 Y102.614 E.00333
;WIDTH:0.399999
G1 X91.038 Y102.284 E.0095
G1 X91.348 Y102.051 E.00943
G1 X91.708 Y101.947 E.00911
G1 X93.934 Y101.939 E.05415
G1 X93.934 Y96.651 E.12863
G1 X91.798 Y96.651 E.05196
G1 X91.396 Y96.562 E.01002
G1 X91.059 Y96.333 E.00991
G1 X90.795 Y95.909 E.01215
;WIDTH:0.442954
G1 X90.768 Y95.896 E.00081
;WIDTH:0.485909
G1 X90.742 Y95.883 E.00087
;WIDTH:0.528864
G1 X90.715 Y95.87 E.00099
;WIDTH:0.571819
G1 X90.688 Y95.857 E.00107
G1 X90.659 Y95.572 E.01024
;WIDTH:0.554696
G1 X90.665 Y93.161 E.08346
;WIDTH:0.564634
G1 X90.67 Y93.09 E.00251
G1 X90.761 Y92.946 E.00601
;WIDTH:0.523476
G1 X90.853 Y92.801 E.00559
;WIDTH:0.482317
G1 X90.944 Y92.657 E.00508
;WIDTH:0.441158
G1 X91.036 Y92.512 E.00465
;WIDTH:0.399999
G1 X91.396 Y92.266 E.01061
G1 X91.798 Y92.177 E.01002
G1 X104.634 Y92.178 E.31222
G1 X104.095 Y91.695 E.0176
G1 X103.505 Y91.085 E.02064
G1 X103.372 Y90.853 E.0065
G1 X103.292 Y90.39 E.01143
G1 X103.411 Y90.057 E.0086
G1 X103.714 Y89.67 E.01196
G1 X104.076 Y89.322 E.01221
G1 X104.638 Y88.831 E.01815
G1 X104.678 Y88.477 E.00867
G1 X104.807 Y88.284 E.00565
G1 X105.183 Y88.134 E.00985
G1 X125.817 Y88.134 E.5019
G1 X126.097 Y88.214 E.00708
G1 X126.262 Y88.366 E.00546
G1 X126.348 Y88.563 E.00523
G1 X126.362 Y88.831 E.00653
G1 X126.953 Y89.352 E.01916
G1 X127.587 Y90.051 E.02295
G1 X127.711 Y90.564 E.01284
G1 X127.589 Y90.943 E.00968
G1 X127.319 Y91.298 E.01085
G1 X126.924 Y91.678 E.01333
G1 X126.369 Y92.163 E.01793
G1 X127.102 Y92.178 E.01783
G1 X139.202 Y92.177 E.29432
G1 X139.653 Y92.29 E.01131
G1 X139.852 Y92.415 E.00572
G1 X140.069 Y92.646 E.00771
;WIDTH:0.439416
G1 X140.137 Y92.784 E.00415
;WIDTH:0.478832
G1 X140.204 Y92.922 E.00454
;WIDTH:0.518248
G1 X140.271 Y93.06 E.00494
;WIDTH:0.557664
G1 X140.339 Y93.198 E.00536
G1 X140.342 Y93.256 E.00202
;WIDTH:0.551226
G1 X140.342 Y95.573 E.07967
G1 X140.295 Y95.69 E.00434
;WIDTH:0.513408
G1 X140.248 Y95.807 E.00402
;WIDTH:0.475605
G1 X140.201 Y95.923 E.00367
;WIDTH:0.437802
G1 X140.154 Y96.04 E.00338
;WIDTH:0.399999
G1 X139.904 Y96.366 E.00999
G1 X139.476 Y96.608 E.01196
G1 X139 Y96.651 E.01163
G1 X137.066 Y96.651 E.04704
G1 X137.066 Y101.937 E.12858
G1 X138.999 Y101.939 E.04702
G1 X139.373 Y101.967 E.00912
G1 X139.847 Y102.177 E.01261
G1 X140.109 Y102.498 E.01008
;WIDTH:0.442256
G1 X140.164 Y102.596 E.00305
;WIDTH:0.484513
G1 X140.219 Y102.693 E.00334
;WIDTH:0.52677
G1 X140.274 Y102.79 E.00365
;WIDTH:0.569026
G1 X140.329 Y102.888 E.004
G1 X140.336 Y102.972 E.003
;WIDTH:0.555191
G1 X140.341 Y104.916 E.06735
;WIDTH:0.551368
G1 X140.299 Y105.034 E.00431
;WIDTH:0.513526
G1 X140.256 Y105.151 E.00397
;WIDTH:0.475684
G1 X140.213 Y105.269 E.00369
;WIDTH:0.437842
G1 X140.171 Y105.386 E.00334
;WIDTH:0.399999
G1 X139.962 Y105.716 E.0095
G1 X139.652 Y105.949 E.00943
G1 X139.292 Y106.053 E.00911
G1 X137.066 Y106.061 E.05415
G1 X137.066 Y109.939 E.09433
G1 X139.292 Y109.947 E.05415
G1 X139.712 Y110.083 E.01074
G1 X140.004 Y110.333 E.00935
;WIDTH:0.439628
G1 X140.087 Y110.494 E.00488
;WIDTH:0.479256
G1 X140.17 Y110.655 E.00536
;WIDTH:0.518884
G1 X140.253 Y110.816 E.00584
;WIDTH:0.558512
G1 X140.336 Y110.977 E.00632
G1 X140.338 Y111.03 E.00185
;WIDTH:0.555117
G1 X140.336 Y113.028 E.06922
G1 X140.288 Y113.132 E.00397
;WIDTH:0.516338
G1 X140.239 Y113.235 E.00366
;WIDTH:0.477558
G1 X140.191 Y113.339 E.00338
;WIDTH:0.438779
G1 X140.143 Y113.443 E.00308
;WIDTH:0.399999
G1 X139.829 Y113.835 E.01222
G1 X139.608 Y113.964 E.00622
G1 X139.201 Y114.061 E.01018
G1 X137.066 Y114.063 E.05193
G1 X137.066 Y117.937 E.09423
G1 X138.999 Y117.939 E.04702
G1 X139.373 Y117.967 E.00912
G1 X139.847 Y118.177 E.01261
G1 X140.109 Y118.498 E.01008
;WIDTH:0.442227
G1 X140.164 Y118.596 E.00305
;WIDTH:0.484455
G1 X140.219 Y118.693 E.00334
;WIDTH:0.526683
G1 X140.274 Y118.79 E.00365
;WIDTH:0.568911
G1 X140.329 Y118.888 E.004
G1 X140.336 Y118.972 E.003
;WIDTH:0.555079
G1 X140.341 Y120.916 E.06734
;WIDTH:0.551256
G1 X140.299 Y121.034 E.00431
;WIDTH:0.513442
G1 X140.256 Y121.151 E.00397
;WIDTH:0.475628
G1 X140.213 Y121.269 E.00369
;WIDTH:0.437814
G1 X140.171 Y121.386 E.00334
;WIDTH:0.399999
G1 X139.962 Y121.716 E.0095
G1 X139.652 Y121.949 E.00943
G1 X139.292 Y122.053 E.00911
G1 X137.066 Y122.061 E.05415
G1 X137.066 Y125.937 E.09428
G1 X139.202 Y125.939 E.05196
G1 X139.686 Y126.068 E.01218
G1 X139.98 Y126.304 E.00917
;WIDTH:0.440131
G1 X140.069 Y126.466 E.00499
;WIDTH:0.480263
G1 X140.157 Y126.627 E.00544
;WIDTH:0.520395
G1 X140.246 Y126.788 E.00595
;WIDTH:0.560527
G1 X140.334 Y126.949 E.00642
G1 X140.337 Y127.009 E.0021
;WIDTH:0.555
G1 X140.336 Y129.026 E.06986
G1 X140.29 Y129.124 E.00375
;WIDTH:0.51625
G1 X140.245 Y129.221 E.00343
;WIDTH:0.4775
G1 X140.2 Y129.319 E.00318
;WIDTH:0.43875
G1 X140.155 Y129.416 E.00288
;WIDTH:0.399999
G1 X139.845 Y129.821 E.01241
G1 X139.652 Y129.949 E.00563
G1 X139.292 Y130.053 E.00911
G1 X137.064 Y130.061 E.05419
G1 X137.054 Y133.077 E.07336
G1 X136.97 Y133.938 E.02104
G1 X138.996 Y133.939 E.04928
G1 X139.373 Y133.967 E.0092
G1 X139.847 Y134.177 E.01261
G1 X140.109 Y134.498 E.01008
;WIDTH:0.442174
G1 X140.164 Y134.596 E.00305
;WIDTH:0.484349
G1 X140.219 Y134.694 E.00336
;WIDTH:0.526524
G1 X140.274 Y134.792 E.00368
;WIDTH:0.568698
G1 X140.329 Y134.89 E.00399
G1 X140.336 Y134.974 E.003
;WIDTH:0.554957
G1 X140.336 Y137.026 E.07106
G1 X140.29 Y137.127 E.00384
;WIDTH:0.516207
G1 X140.244 Y137.229 E.00359
;WIDTH:0.477471
G1 X140.198 Y137.33 E.00327
;WIDTH:0.438735
G1 X140.152 Y137.431 E.00299
;WIDTH:0.399999
G1 X139.936 Y137.744 E.00925
G1 X139.625 Y137.962 E.00924
G1 X139.25 Y138.059 E.00942
G1 X135.538 Y138.062 E.09029
G1 X135.181 Y138.653 E.01679
G1 X134.752 Y139.293 E.01874
G1 X134.012 Y140.18 E.0281
G1 X133.423 Y140.724 E.0195
G1 X132.283 Y141.57 E.03453
G1 X131.854 Y141.835 E.01227
G1 X133.854 Y141.834 E.04865
G1 X135.496 Y141.929 E.04001
G1 X139.203 Y141.939 E.09017
G1 X139.686 Y142.068 E.01216
G1 X139.982 Y142.307 E.00925
;WIDTH:0.401203
G1 X140.185 Y142.66 E.00994
;WIDTH:0.45117
G1 X140.237 Y142.801 E.00417
;WIDTH:0.501137
G1 X140.289 Y142.943 E.0047
;WIDTH:0.551103
G1 X140.341 Y143.084 E.00517
;WIDTH:0.554895
G1 X140.336 Y145.028 E.06732
G1 X140.288 Y145.132 E.00397
;WIDTH:0.516171
G1 X140.24 Y145.235 E.00364
;WIDTH:0.477447
G1 X140.192 Y145.339 E.00338
;WIDTH:0.438723
G1 X140.144 Y145.442 E.00306
;WIDTH:0.399999
G1 X139.83 Y145.834 E.01222
G1 X139.609 Y145.964 E.00624
G1 X139.201 Y146.061 E.0102
G1 X135.726 Y146.066 E.08453
G1 X133.885 Y146.165 E.04485
G1 X125.27 Y146.164 E.20955
G1 X125.049 Y146.112 E.00552
G1 X124.814 Y145.917 E.00743
G1 X124.721 Y145.615 E.00769
G1 X124.718 Y143.385 E.05424
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X124.718 Y143.325 E-.0285
G1 X124.718 Y143.301 E-.0114
G1 X124.566 Y143.278 E-.07302
G1 X121.646 Y143.278 E-1.38708
;WIPE_END
G1 X121.646 Y143.258 F9000
G1 X124.737 Y146.147
G1 X133.864 Y146.149
G1 X139.217 Y146.044
G1 X139.3 Y146.039
G1 X139.403 Y146.026
G1 X139.578 Y145.973
G1 X139.748 Y145.884
G1 X139.898 Y145.768
G1 X140.023 Y145.628
G1 X140.122 Y145.47
G1 X140.15 Y145.403
G1 X140.196 Y145.284
G1 X140.237 Y145.104
G1 X140.242 Y145.028
G1 X140.249 Y144.935
G1 X140.249 Y93.234
G1 X140.241 Y93.132
G1 X140.235 Y93.072
G1 X140.189 Y92.895
G1 X140.112 Y92.728
G1 X140.008 Y92.577
G1 X131.349 Y82.06
G1 X131.349 Y79.161
G1 X131 Y78.999
G1 E5 F2400
G1 F6000
G1 X131 Y82.051 E.07424
G1 X130.961 Y82.613 E.0137
G1 X130.853 Y83.144 E.01318
G1 X130.641 Y83.746 E.01552
G1 X130.383 Y84.238 E.01351
G1 X129.834 Y84.952 E.02191
G1 X129.432 Y85.322 E.01329
G1 X128.7 Y85.794 E.02119
G1 X128.163 Y86.022 E.01419
G1 X127.655 Y86.162 E.01282
G1 X127.095 Y86.239 E.01375
G1 X110.557 Y86.234 E.40227
G1 X110.517 Y86.25 E.00105
G1 X104.199 Y86.25 E.15368
G1 X103.648 Y86.213 E.01343
G1 X103.093 Y86.101 E.01377
G1 X102.589 Y85.928 E.01296
G1 X102.043 Y85.651 E.01489
G1 X101.587 Y85.337 E.01347
G1 X100.977 Y84.74 E.02076
G1 X100.65 Y84.291 E.01351
G1 X100.353 Y83.733 E.01538
G1 X100.086 Y82.883 E.02167
G1 X100.011 Y82.349 E.01312
G1 X100 Y78.999 E.08149
G1 X99.335 Y78.42 E.02145
G1 X98.767 Y77.83 E.01992
G1 X98.647 Y77.531 E.00784
G1 X98.702 Y77.287 E.00608
G1 X98.963 Y76.934 E.01068
G1 X99.329 Y76.586 E.01228
G1 X100 Y76.001 E.02165
G1 X100.005 Y75.717 E.00691
G1 X100.058 Y75.626 E.00256
G1 X100.183 Y75.577 E.00327
G1 X130.817 Y75.577 E.74514
G1 X130.942 Y75.626 E.00327
G1 X131 Y75.76 E.00355
G1 X131 Y76.001 E.00586
G1 X131.665 Y76.58 E.02145
G1 X132.232 Y77.169 E.01989
G1 X132.353 Y77.528 E.00921
G1 X132.242 Y77.82 E.0076
G1 X131.671 Y78.414 E.02004
G1 X131.045 Y78.96 E.0202
G1 X131.045 Y78.96 F9000
G1 X131.366 Y79.168
;TYPE:Perimeter
G1 F6000
G1 X131.366 Y82.051 E.07013
G1 X131.321 Y82.676 E.01524
G1 X131.198 Y83.267 E.01468
G1 X130.967 Y83.912 E.01666
G1 X130.671 Y84.464 E.01524
G1 X130.079 Y85.223 E.02341
G1 X129.628 Y85.631 E.01479
G1 X128.894 Y86.103 E.02123
G1 X128.31 Y86.357 E.01549
G1 X127.76 Y86.512 E.0139
G1 X127.156 Y86.6 E.01485
G1 X104.2 Y86.616 E.55838
G1 X103.693 Y86.583 E.01236
G1 X103.021 Y86.459 E.01662
G1 X102.471 Y86.274 E.01411
G1 X101.856 Y85.965 E.01674
G1 X101.379 Y85.638 E.01407
G1 X100.721 Y85.002 E.02226
G1 X100.354 Y84.506 E.01501
G1 X100.015 Y83.872 E.01749
G1 X99.737 Y82.991 E.02247
G1 X99.649 Y82.399 E.01456
G1 X99.635 Y79.166 E.07864
G1 X99.095 Y78.695 E.01743
G1 X98.504 Y78.084 E.02068
G1 X98.304 Y77.646 E.01171
G1 X98.293 Y77.414 E.00565
G1 X98.408 Y77.069 E.00885
G1 X98.711 Y76.67 E.01219
G1 X99.077 Y76.321 E.0123
G1 X99.634 Y75.835 E.01798
G1 X99.65 Y75.687 E.00362
G1 X99.766 Y75.42 E.00708
;WIDTH:0.407561
G1 X99.865 Y75.319 E.00351
;WIDTH:0.446988
G1 X100.024 Y75.244 E.00483
;WIDTH:0.486415
G1 X100.183 Y75.169 E.00529
G1 X130.817 Y75.169 E.92124
;WIDTH:0.484876
G1 X130.975 Y75.246 E.00527
;WIDTH:0.442438
G1 X131.133 Y75.323 E.00477
;WIDTH:0.399999
G1 X131.224 Y75.4 E.0029
G1 X131.355 Y75.667 E.00723
G1 X131.362 Y75.831 E.00399
G1 X131.905 Y76.305 E.01753
G1 X132.495 Y76.915 E.02064
G1 X132.626 Y77.14 E.00633
G1 X132.711 Y77.555 E.0103
G1 X132.589 Y77.943 E.00989
G1 X132.319 Y78.298 E.01085
G1 X131.924 Y78.678 E.01333
G1 X131.409 Y79.128 E.01664
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X131.366 Y79.168 E-.0279
G1 X131.366 Y82.051 E-1.36942
G1 X131.351 Y82.267 E-.10268
;WIPE_END
G1 X105.85 Y150.261 F9000
G1 E5 F2400
G1 F6000
G1 X105.876 Y150.274 E.00071
G1 X105.914 Y150.385 E.00285
G1 X105.914 Y153.615 E.07857
G1 X105.877 Y153.725 E.00282
G1 X105.731 Y153.798 E.00397
G1 X97.145 Y153.8 E.20885
G1 X95.349 Y153.699 E.04375
G1 X91.799 Y153.696 E.08635
G1 X91.424 Y153.577 E.00957
G1 X91.173 Y153.264 E.00976
G1 X91.1 Y152.916 E.00865
G1 X91.108 Y150.974 E.04724
G1 X91.233 Y150.625 E.00902
G1 X91.51 Y150.377 E.00904
G1 X91.798 Y150.304 E.00723
G1 X95.298 Y150.3 E.08513
G1 X96.967 Y150.206 E.04066
G1 X105.731 Y150.202 E.21318
G1 X105.796 Y150.234 E.00176
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X105.85 Y150.261 E-.02868
G1 X105.876 Y150.274 E-.01381
G1 X105.914 Y150.385 E-.05573
G1 X105.914 Y153.336 E-1.40178
;WIPE_END
G1 X106.262 Y153.336 F9000
G1 X124.737 Y150.262
G1 X125.138 Y150.261
G1 E5 F2400
G1 F6000
G1 X125.141 Y150.254 E.00019
G1 X125.269 Y150.202 E.00336
G1 X133.574 Y150.203 E.20201
G1 X134.227 Y150.213 E.01589
G1 X135.651 Y150.301 E.0347
G1 X139.202 Y150.304 E.08637
G1 X139.49 Y150.377 E.00723
G1 X139.766 Y150.625 E.00903
G1 X139.892 Y150.976 E.00907
G1 X139.9 Y152.916 E.04719
G1 X139.785 Y153.347 E.01085
G1 X139.511 Y153.612 E.00927
G1 X139.201 Y153.696 E.00781
G1 X135.636 Y153.7 E.08672
G1 X133.855 Y153.8 E.04339
G1 X125.269 Y153.798 E.20885
G1 X125.123 Y153.725 E.00397
G1 X125.086 Y153.615 E.00282
G1 X125.086 Y150.385 E.07857
G1 X125.115 Y150.317 E.0018
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X125.138 Y150.261 E-.02876
G1 X125.141 Y150.254 E-.00362
G1 X125.269 Y150.202 E-.06563
G1 X128.22 Y150.202 E-1.40199
;WIPE_END
G1 X128.22 Y149.854 F9000
G1 X140.122 Y145.47
G1 X140.15 Y145.403
G1 X140.249 Y93.234
G1 X140.241 Y93.132
G1 X140.235 Y93.072
G1 X140.189 Y92.895
G1 X140.112 Y92.728
G1 X140.008 Y92.577
G1 X139.891 Y92.457
G1 X140.951 Y87.21
G1 X141.293 Y85.52
G1 E5 F2400
G1 F6000
G1 X141.3 Y85.568 E.00118
G1 X141.3 Y150.994 E1.59142
G1 X141.259 Y151.686 E.01686
G1 X141.137 Y152.362 E.01671
G1 X140.937 Y153.019 E.0167
G1 X140.66 Y153.648 E.01672
G1 X140.31 Y154.24 E.01673
G1 X139.893 Y154.786 E.01671
G1 X139.415 Y155.279 E.0167
G1 X138.881 Y155.712 E.01672
G1 X138.3 Y156.078 E.0167
G1 X137.68 Y156.374 E.01671
G1 X137.089 Y156.571 E.01515
G1 X136.489 Y156.691 E.01488
G1 X136.144 Y156.709 E.0084
G1 X135.374 Y156.631 E.01883
G1 X134.39 Y156.426 E.02445
G1 X133.855 Y156.384 E.01305
G1 X97.146 Y156.384 E.89291
G1 X96.587 Y156.429 E.01364
G1 X95.435 Y156.667 E.02861
G1 X94.931 Y156.716 E.01232
G1 X94.437 Y156.696 E.01203
G1 X93.485 Y156.438 E.02399
G1 X92.911 Y156.189 E.01522
G1 X92.407 Y155.905 E.01407
G1 X91.583 Y155.277 E.0252
G1 X91.107 Y154.786 E.01663
G1 X90.69 Y154.24 E.01671
G1 X90.341 Y153.649 E.01669
G1 X90.028 Y152.918 E.01934
G1 X89.863 Y152.365 E.01404
G1 X89.711 Y151.341 E.02518
G1 X89.7 Y85.568 E1.59986
G1 X89.81 Y85.199 E.00937
G1 X89.808 Y80.006 E.12631
G1 X89.852 Y79.3 E.01721
G1 X89.967 Y78.674 E.01548
G1 X90.193 Y77.944 E.01859
G1 X90.486 Y77.307 E.01705
G1 X90.855 Y76.712 E.01703
G1 X91.294 Y76.166 E.01704
G1 X91.797 Y75.678 E.01705
G1 X92.356 Y75.256 E.01704
G1 X92.963 Y74.905 E.01706
G1 X93.608 Y74.632 E.01704
G1 X94.282 Y74.44 E.01705
G1 X94.974 Y74.333 E.01703
G1 X96.17 Y74.307 E.0291
G1 X135.495 Y74.308 E.95654
G1 X136.024 Y74.332 E.01288
G1 X136.715 Y74.44 E.01701
G1 X137.719 Y74.759 E.02562
G1 X138.646 Y75.257 E.0256
G1 X139.203 Y75.678 E.01698
G1 X139.706 Y76.165 E.01703
G1 X140.146 Y76.712 E.01708
G1 X140.482 Y77.252 E.01547
G1 X140.807 Y77.944 E.0186
G1 X141.02 Y78.612 E.01705
G1 X141.117 Y79.133 E.01289
G1 X141.181 Y79.647 E.0126
G1 X141.19 Y85.196 E.13497
G1 X141.274 Y85.385 E.00503
G1 X141.285 Y85.461 E.00187
G1 E-5 F3600
G1 X141.285 Y85.461 F9000
G1 X140.951 Y85.91
G1 X140.267 Y153.702
G1 X134.457 Y156.083
G1 X134.152 Y156.048
G1 X90.971 Y154.034
G1 X90.733 Y153.702
G1 X90.707 Y153.652
G1 X90.831 Y153.585
G1 E5 F2400
;TYPE:Perimeter
;WIDTH:0.605255
G1 F6000
G1 X90.754 Y153.393 E.00786
;WIDTH:0.636276
G1 X90.677 Y153.202 E.00825
G1 E-5 F3600
G1 X90.677 Y153.202 F9000
G1 X90.069 Y85.556
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X90.175 Y85.196 E.00913
G1 X90.174 Y80.017 E.12597
G1 X90.215 Y79.345 E.01638
G1 X90.322 Y78.761 E.01444
G1 X90.535 Y78.075 E.01747
G1 X90.808 Y77.481 E.0159
G1 X91.154 Y76.923 E.01597
G1 X91.565 Y76.412 E.01595
G1 X92.035 Y75.956 E.01593
G1 X92.559 Y75.561 E.01596
G1 X93.126 Y75.233 E.01593
G1 X93.73 Y74.978 E.01595
G1 X94.361 Y74.798 E.01596
G1 X95.006 Y74.698 E.01588
G1 X96.174 Y74.673 E.02842
G1 X99.277 Y74.673 E.07548
;WIDTH:0.443207
G1 X99.73 Y74.695 E.01234
;WIDTH:0.486415
G1 X100.183 Y74.716 E.01364
G1 X130.817 Y74.719 E.92124
;WIDTH:0.484876
G1 X131.037 Y74.698 E.00662
;WIDTH:0.442438
G1 X131.256 Y74.676 E.00598
;WIDTH:0.399999
G1 X135.447 Y74.677 E.10194
G1 X136.032 Y74.713 E.01426
G1 X136.631 Y74.797 E.01471
G1 X137.575 Y75.097 E.02409
G1 X138.448 Y75.566 E.02411
G1 X138.965 Y75.956 E.01575
G1 X139.435 Y76.412 E.01593
G1 X139.847 Y76.924 E.01599
G1 X140.161 Y77.427 E.01442
G1 X140.466 Y78.078 E.01749
G1 X140.664 Y78.701 E.0159
G1 X140.786 Y79.351 E.01609
G1 X140.816 Y79.91 E.01362
G1 X140.828 Y85.244 E.12974
G1 X140.934 Y85.569 E.00832
G1 X140.934 Y85.849 E.00681
G1 X140.934 Y92.607 E.16438
;WIDTH:0.437806
G1 X140.915 Y92.769 E.00438
;WIDTH:0.475613
G1 X140.896 Y92.931 E.00479
;WIDTH:0.51342
G1 X140.878 Y93.094 E.00523
;WIDTH:0.551226
G1 X140.859 Y93.256 E.00561
G1 X140.859 Y95.573 E.07967
G1 X140.883 Y95.733 E.00556
;WIDTH:0.501728
G1 X140.908 Y95.894 E.00507
;WIDTH:0.452246
G1 X140.933 Y96.054 E.0045
;WIDTH:0.402764
G1 X140.934 Y96.289 E.00576
;WIDTH:0.399999
G1 X140.934 Y102.364 E.14777
;WIDTH:0.442256
G1 X140.913 Y102.473 E.00301
;WIDTH:0.484513
G1 X140.892 Y102.583 E.00335
;WIDTH:0.52677
G1 X140.871 Y102.693 E.00367
;WIDTH:0.569026
G1 X140.85 Y102.803 E.00398
G1 X140.857 Y102.971 E.00598
;WIDTH:0.555191
G1 X140.858 Y104.914 E.06732
;WIDTH:0.553451
G1 X140.877 Y105.157 E.00842
;WIDTH:0.515088
G1 X140.896 Y105.303 E.00471
;WIDTH:0.476725
G1 X140.915 Y105.449 E.00433
;WIDTH:0.438362
G1 X140.934 Y105.595 E.00396
;WIDTH:0.399999
G1 X140.934 Y110.405 E.117
;WIDTH:0.438306
G1 X140.915 Y110.561 E.00422
;WIDTH:0.476613
G1 X140.896 Y110.717 E.00462
;WIDTH:0.51492
G1 X140.877 Y110.874 E.00506
;WIDTH:0.553226
G1 X140.857 Y111.03 E.00543
;WIDTH:0.555117
G1 X140.856 Y113.028 E.06922
G1 X140.876 Y113.139 E.00391
;WIDTH:0.516338
G1 X140.895 Y113.25 E.00361
;WIDTH:0.477558
G1 X140.915 Y113.36 E.0033
;WIDTH:0.438779
G1 X140.934 Y113.471 E.00303
;WIDTH:0.399999
G1 X140.934 Y118.364 E.11902
;WIDTH:0.442227
G1 X140.913 Y118.474 E.00304
;WIDTH:0.484455
G1 X140.892 Y118.583 E.00332
;WIDTH:0.526683
G1 X140.871 Y118.693 E.00367
;WIDTH:0.568911
G1 X140.849 Y118.803 E.00399
G1 X140.856 Y118.971 E.00598
;WIDTH:0.555079
G1 X140.858 Y120.914 E.06731
;WIDTH:0.553339
G1 X140.876 Y121.157 E.00841
;WIDTH:0.515004
G1 X140.896 Y121.303 E.00471
;WIDTH:0.476669
G1 X140.915 Y121.449 E.00433
;WIDTH:0.438334
G1 X140.934 Y121.595 E.00396
;WIDTH:0.399999
G1 X140.934 Y126.356 E.11581
;WIDTH:0.438436
G1 X140.915 Y126.519 E.00441
;WIDTH:0.476872
G1 X140.895 Y126.682 E.00483
;WIDTH:0.515308
G1 X140.876 Y126.845 E.00525
;WIDTH:0.553744
G1 X140.857 Y127.009 E.0057
;WIDTH:0.555
G1 X140.856 Y129.027 E.06989
G1 X140.876 Y129.13 E.00363
;WIDTH:0.51625
G1 X140.895 Y129.233 E.00336
;WIDTH:0.4775
G1 X140.914 Y129.336 E.00309
;WIDTH:0.43875
G1 X140.934 Y129.439 E.00282
;WIDTH:0.399999
G1 X140.934 Y134.364 E.1198
;WIDTH:0.442174
G1 X140.913 Y134.475 E.00306
;WIDTH:0.484349
G1 X140.891 Y134.585 E.00336
;WIDTH:0.526524
G1 X140.87 Y134.695 E.00367
;WIDTH:0.568698
G1 X140.849 Y134.805 E.00398
G1 X140.856 Y134.974 E.00601
;WIDTH:0.554957
G1 X140.856 Y137.026 E.07106
G1 X140.876 Y137.137 E.00391
;WIDTH:0.516207
G1 X140.895 Y137.248 E.00361
;WIDTH:0.477471
G1 X140.914 Y137.359 E.00332
;WIDTH:0.438735
G1 X140.934 Y137.471 E.00306
;WIDTH:0.399999
G1 X140.934 Y142.038 E.11109
;WIDTH:0.401203
G1 X140.933 Y142.586 E.01337
;WIDTH:0.451169
G1 X140.908 Y142.752 E.00465
;WIDTH:0.501135
G1 X140.883 Y142.917 E.00518
;WIDTH:0.551101
G1 X140.858 Y143.083 E.00577
;WIDTH:0.554895
G1 X140.856 Y145.029 E.06739
G1 X140.875 Y145.14 E.0039
;WIDTH:0.516171
G1 X140.895 Y145.25 E.00358
;WIDTH:0.477447
G1 X140.914 Y145.36 E.00329
;WIDTH:0.438723
G1 X140.934 Y145.47 E.00301
;WIDTH:0.399999
G1 X140.933 Y150.365 E.11907
;WIDTH:0.442158
G1 X140.912 Y150.474 E.00301
;WIDTH:0.484317
G1 X140.891 Y150.584 E.00335
;WIDTH:0.526476
G1 X140.87 Y150.694 E.00367
;WIDTH:0.568635
G1 X140.849 Y150.804 E.00398
G1 X140.855 Y151.004 E.00711
;WIDTH:0.554822
G1 X140.821 Y151.677 E.02333
;WIDTH:0.532803
G1 X140.706 Y152.296 E.02088
G1 X140.504 Y152.93 E.02206
;WIDTH:0.561039
G1 X140.385 Y153.162 E.00914
;WIDTH:0.589274
G1 X140.267 Y153.395 E.00964
G1 X140.299 Y153.114 E.01044
;WIDTH:0.561039
G1 X140.332 Y152.833 E.00991
;WIDTH:0.532803
G1 X140.327 Y151.633 E.03979
;WIDTH:0.568635
G1 X140.329 Y150.888 E.02648
G1 X140.238 Y150.74 E.00617
;WIDTH:0.526476
G1 X140.148 Y150.592 E.00567
;WIDTH:0.484317
G1 X140.058 Y150.443 E.00521
;WIDTH:0.442158
G1 X139.968 Y150.295 E.0047
;WIDTH:0.399999
G1 X139.547 Y150.009 E.01238
G1 X138.994 Y149.938 E.01356
G1 X135.578 Y149.93 E.08309
G1 X134.232 Y149.848 E.0328
G1 X133.574 Y149.838 E.01601
G1 X125.269 Y149.836 E.20201
G1 X124.99 Y149.914 E.00705
G1 X124.78 Y150.151 E.0077
G1 X124.721 Y150.385 E.00587
G1 X124.721 Y153.615 E.07857
G1 X124.803 Y153.893 E.00705
G1 X124.978 Y154.077 E.00618
G1 X125.269 Y154.164 E.00739
G1 X133.92 Y154.163 E.21043
G1 X135.682 Y154.066 E.04292
G1 X139.201 Y154.061 E.0856
;WIDTH:0.431314
G1 X139.439 Y154.015 E.0064
;WIDTH:0.462629
G1 X139.677 Y153.968 E.00691
;WIDTH:0.506408
G1 X139.748 Y153.945 E.00234
;WIDTH:0.550187
G1 X139.818 Y153.922 E.00253
;WIDTH:0.593966
G1 X139.889 Y153.9 E.00277
;WIDTH:0.637744
G1 X139.96 Y153.877 E.003
G1 X139.935 Y153.951 E.00314
;WIDTH:0.593966
G1 X139.911 Y154.024 E.00286
;WIDTH:0.550187
G1 X139.887 Y154.097 E.00264
;WIDTH:0.506408
G1 X139.862 Y154.171 E.00245
;WIDTH:0.462629
G1 X139.729 Y154.369 E.0068
;WIDTH:0.431314
G1 X139.596 Y154.567 E.0063
;WIDTH:0.399999
G1 X139.134 Y155.035 E.016
G1 X138.668 Y155.414 E.01461
G1 X138.123 Y155.757 E.01566
G1 X137.543 Y156.034 E.01563
G1 X136.892 Y156.251 E.01669
G1 X136.298 Y156.352 E.01466
G1 X135.628 Y156.311 E.01633
G1 X134.442 Y156.065 E.02946
G1 X133.855 Y156.019 E.01432
G1 X97.146 Y156.02 E.89291
G1 X96.514 Y156.071 E.01542
G1 X95.377 Y156.306 E.02824
G1 X94.837 Y156.345 E.01317
G1 X94.383 Y156.302 E.01109
G1 X93.607 Y156.092 E.01955
G1 X93.073 Y155.861 E.01415
G1 X92.608 Y155.599 E.01298
G1 X91.827 Y155.003 E.0239
G1 X91.367 Y154.524 E.01615
G1 X90.989 Y154.026 E.01521
;WIDTH:0.443023
G1 X90.95 Y153.916 E.00317
;WIDTH:0.486046
G1 X90.911 Y153.807 E.00348
;WIDTH:0.52907
G1 X90.872 Y153.698 E.00381
;WIDTH:0.572093
G1 X90.833 Y153.589 E.00414
G1 X90.936 Y153.664 E.00456
;WIDTH:0.52907
G1 X91.038 Y153.739 E.00417
;WIDTH:0.486046
G1 X91.141 Y153.814 E.00383
;WIDTH:0.443023
G1 X91.243 Y153.889 E.00344
;WIDTH:0.399999
G1 X91.719 Y154.053 E.01225
G1 X95.374 Y154.067 E.0889
G1 X97.145 Y154.166 E.04315
G1 X105.731 Y154.164 E.20885
G1 X106.022 Y154.077 E.00739
G1 X106.197 Y153.893 E.00618
G1 X106.279 Y153.615 E.00705
G1 X106.277 Y150.346 E.07952
G1 X106.192 Y150.096 E.00642
G1 X105.951 Y149.888 E.00774
G1 X105.731 Y149.836 E.0055
G1 X96.946 Y149.841 E.21369
G1 X95.281 Y149.934 E.04056
G1 X92.016 Y149.938 E.07942
G1 X91.522 Y149.982 E.01206
G1 X91.078 Y150.252 E.01264
G1 X90.917 Y150.448 E.00617
;WIDTH:0.44093
G1 X90.856 Y150.558 E.0034
;WIDTH:0.48186
G1 X90.796 Y150.668 E.00373
;WIDTH:0.52279
G1 X90.735 Y150.779 E.00412
;WIDTH:0.56372
G1 X90.674 Y150.889 E.00443
G1 X90.666 Y151.29 E.01412
;WIDTH:0.549425
G1 X90.682 Y151.745 E.0156
;WIDTH:0.514773
G1 X90.697 Y152.2 E.01455
;WIDTH:0.48012
G1 X90.714 Y152.456 E.00761
;WIDTH:0.443285
G1 X90.732 Y152.712 E.00698
;WIDTH:0.452415
G1 X90.721 Y152.81 E.00274
;WIDTH:0.498381
G1 X90.71 Y152.908 E.00304
;WIDTH:0.544346
G1 X90.699 Y153.006 E.00335
;WIDTH:0.590311
G1 X90.688 Y153.104 E.00365
;WIDTH:0.636276
G1 X90.677 Y153.202 E.00395
G1 X90.625 Y153.142 E.00318
;WIDTH:0.588801
G1 X90.574 Y153.082 E.0029
;WIDTH:0.541326
G1 X90.523 Y153.022 E.00266
;WIDTH:0.493851
G1 X90.472 Y152.963 E.00238
;WIDTH:0.446376
G1 X90.367 Y152.763 E.00619
;WIDTH:0.443285
G1 X90.31 Y152.497 E.0074
;WIDTH:0.48012
G1 X90.254 Y152.232 E.00803
;WIDTH:0.514773
G1 X90.202 Y151.77 E.01486
;WIDTH:0.549425
G1 X90.151 Y151.308 E.01593
;WIDTH:0.56372
G1 X90.158 Y150.805 E.01771
G1 X90.137 Y150.696 E.00391
;WIDTH:0.52279
G1 X90.117 Y150.586 E.00363
;WIDTH:0.48186
G1 X90.097 Y150.477 E.0033
;WIDTH:0.44093
G1 X90.076 Y150.367 E.00303
;WIDTH:0.399999
G1 X90.075 Y145.412 E.12053
;WIDTH:0.448917
G1 X90.1 Y145.247 E.0046
;WIDTH:0.497834
G1 X90.124 Y145.082 E.00514
;WIDTH:0.546751
G1 X90.149 Y144.917 E.00569
;WIDTH:0.550713
G1 X90.15 Y142.971 E.06684
;WIDTH:0.557983
G1 X90.154 Y142.85 E.00422
G1 X90.134 Y142.778 E.0026
;WIDTH:0.518487
G1 X90.114 Y142.706 E.00241
;WIDTH:0.478991
G1 X90.095 Y142.634 E.0022
;WIDTH:0.439495
G1 X90.075 Y142.562 E.00201
;WIDTH:0.399999
G1 X90.074 Y137.661 E.11921
;WIDTH:0.437795
G1 X90.093 Y137.502 E.0043
;WIDTH:0.475591
G1 X90.112 Y137.343 E.0047
;WIDTH:0.513387
G1 X90.131 Y137.185 E.00507
;WIDTH:0.551182
G1 X90.149 Y137.026 E.0055
;WIDTH:0.551346
G1 X90.149 Y134.974 E.07057
;WIDTH:0.559294
G1 X90.153 Y134.846 E.00447
G1 X90.133 Y134.767 E.00285
;WIDTH:0.519471
G1 X90.113 Y134.689 E.0026
;WIDTH:0.479647
G1 X90.093 Y134.61 E.00241
;WIDTH:0.439823
G1 X90.074 Y134.531 E.00219
;WIDTH:0.399999
G1 X90.073 Y129.594 E.12009
;WIDTH:0.449975
G1 X90.098 Y129.386 E.00579
;WIDTH:0.499951
G1 X90.123 Y129.178 E.00649
;WIDTH:0.549927
G1 X90.148 Y128.97 E.00719
;WIDTH:0.551991
G1 X90.148 Y126.972 E.0688
;WIDTH:0.560031
G1 X90.152 Y126.844 E.00448
G1 X90.132 Y126.765 E.00285
;WIDTH:0.520023
G1 X90.112 Y126.687 E.0026
;WIDTH:0.480015
G1 X90.092 Y126.608 E.00242
;WIDTH:0.440007
G1 X90.072 Y126.53 E.00217
;WIDTH:0.399999
G1 X90.071 Y121.594 E.12006
;WIDTH:0.437641
G1 X90.09 Y121.438 E.00422
;WIDTH:0.475283
G1 X90.109 Y121.282 E.00461
;WIDTH:0.512925
G1 X90.128 Y121.126 E.005
;WIDTH:0.550567
G1 X90.147 Y120.97 E.0054
;WIDTH:0.552631
G1 X90.147 Y118.972 E.06889
;WIDTH:0.560672
G1 X90.151 Y118.844 E.00448
G1 X90.131 Y118.765 E.00285
;WIDTH:0.520504
G1 X90.111 Y118.687 E.0026
;WIDTH:0.480336
G1 X90.091 Y118.609 E.00239
;WIDTH:0.440168
G1 X90.071 Y118.53 E.0022
;WIDTH:0.399999
G1 X90.07 Y113.594 E.12006
;WIDTH:0.437801
G1 X90.089 Y113.438 E.00422
;WIDTH:0.475603
G1 X90.108 Y113.282 E.00461
;WIDTH:0.513405
G1 X90.127 Y113.126 E.00501
;WIDTH:0.551207
G1 X90.146 Y112.97 E.0054
;WIDTH:0.553271
G1 X90.146 Y110.972 E.06897
;WIDTH:0.561321
G1 X90.15 Y110.844 E.00449
G1 X90.13 Y110.765 E.00286
;WIDTH:0.520991
G1 X90.11 Y110.687 E.00261
;WIDTH:0.48066
G1 X90.09 Y110.608 E.00242
;WIDTH:0.44033
G1 X90.07 Y110.53 E.00217
;WIDTH:0.399999
G1 X90.069 Y105.71 E.11724
;WIDTH:0.438437
G1 X90.088 Y105.54 E.0046
;WIDTH:0.476874
G1 X90.107 Y105.37 E.00504
;WIDTH:0.515311
G1 X90.126 Y105.199 E.0055
;WIDTH:0.553748
G1 X90.146 Y105.029 E.00591
G1 X90.144 Y103.086 E.06713
;WIDTH:0.550099
G1 X90.125 Y102.966 E.00417
;WIDTH:0.512574
G1 X90.106 Y102.846 E.00387
;WIDTH:0.475049
G1 X90.087 Y102.726 E.00356
;WIDTH:0.437524
G1 X90.068 Y102.606 E.00326
;WIDTH:0.399999
G1 X90.067 Y96.105 E.15813
;WIDTH:0.443234
G1 X90.089 Y96.056 E.00146
;WIDTH:0.486468
G1 X90.111 Y96.008 E.00159
;WIDTH:0.529702
G1 X90.132 Y95.959 E.00176
;WIDTH:0.572936
G1 X90.154 Y95.911 E.00189
G1 X90.143 Y95.573 E.01212
;WIDTH:0.554696
G1 X90.144 Y93.16 E.08352
;WIDTH:0.564634
G1 X90.149 Y93.018 E.00501
G1 X90.129 Y92.942 E.00277
;WIDTH:0.523476
G1 X90.108 Y92.866 E.00257
;WIDTH:0.482317
G1 X90.087 Y92.789 E.00238
;WIDTH:0.441158
G1 X90.067 Y92.713 E.00213
;WIDTH:0.399999
G1 X90.066 Y85.615 E.17265
G1 E-5 F3600
G1 X90.066 Y85.615 F9000
G1 X90.049 Y85.615
G1 X90.751 Y112.935
G1 X90.758 Y113.028
G1 X90.763 Y113.104
G1 X90.804 Y113.284
G1 X90.85 Y113.403
G1 X90.878 Y113.47
G1 X90.977 Y113.628
G1 X91.102 Y113.768
G1 X91.252 Y113.884
G1 X91.422 Y113.973
G1 X91.597 Y114.026
G1 X91.7 Y114.039
G1 X91.783 Y114.044
G1 X92.458 Y114.045
G1 X93.569 Y114.046
G1 X93.569 Y114.425
G1 E5 F2400
G1 F6000
G1 X93.569 Y117.572 E.07655
G1 X91.799 Y117.573 E.04305
G1 X91.301 Y117.682 E.0124
G1 X90.974 Y117.857 E.00902
G1 X90.566 Y118.336 E.0153
G1 X90.437 Y118.666 E.00862
G1 X90.436 Y113.336 E.12965
G1 X90.515 Y113.573 E.00608
G1 X90.809 Y114.001 E.01263
G1 X91.239 Y114.298 E.01271
G1 X91.707 Y114.419 E.01176
G1 X93.509 Y114.425 E.04383
G1 X93.509 Y114.425 F9000
G1 X93.183 Y114.79
G1 F6000
G1 X93.203 Y114.79 E.00049
G1 X93.203 Y117.207 E.05879
G1 X91.798 Y117.207 E.03418
G1 X91.211 Y117.328 E.01458
G1 X90.802 Y117.533 E.01113
G1 X90.802 Y114.464 E.07465
G1 X91.13 Y114.647 E.00914
G1 X91.705 Y114.785 E.01438
G1 X93.123 Y114.789 E.03449
G1 X93.123 Y114.789 F9000
G1 X92.817 Y115.154
G1 F6000
G1 X92.837 Y115.154 E.00049
G1 X92.837 Y116.841 E.04103
G1 X91.798 Y116.842 E.02527
G1 X91.168 Y116.961 E.0156
G1 X91.167 Y115.042 E.04668
G1 X91.704 Y115.15 E.01332
G1 X92.757 Y115.154 E.02561
G1 E-5 F3600
G1 X92.757 Y115.154 F9000
G1 X90.878 Y118.53
G1 X90.85 Y118.597
G1 X90.804 Y118.716
G1 X90.763 Y118.896
G1 X90.758 Y118.972
G1 X90.751 Y119.065
G1 X90.751 Y120.935
G1 X90.758 Y121.028
G1 X90.763 Y121.104
G1 X90.782 Y121.186
G1 X90.799 Y121.261
G1 X90.437 Y121.342
G1 E5 F2400
G1 F6000
G1 X90.515 Y121.573 E.00593
G1 X90.809 Y122.001 E.01263
G1 X91.239 Y122.298 E.01271
G1 X91.707 Y122.419 E.01176
G1 X93.569 Y122.425 E.04529
G1 X93.569 Y125.572 E.07655
G1 X91.799 Y125.573 E.04305
G1 X91.302 Y125.682 E.01238
G1 X90.976 Y125.856 E.00899
G1 X90.567 Y126.334 E.0153
G1 X90.438 Y126.661 E.00855
G1 X90.437 Y121.402 E.12792
G1 E-5 F3600
G1 X90.437 Y121.402 F9000
G1 X92.228 Y122.786
G1 E5 F2400
G1 F6000
G1 X93.203 Y122.79 E.02372
G1 X93.203 Y125.207 E.05879
G1 X91.798 Y125.207 E.03418
G1 X91.212 Y125.327 E.01455
G1 X90.803 Y125.532 E.01113
G1 X90.803 Y122.465 E.0746
G1 X91.13 Y122.647 E.0091
G1 X91.705 Y122.785 E.01438
G1 X92.168 Y122.786 E.01126
G1 X92.168 Y122.786 F9000
G1 X92.403 Y123.153
G1 F6000
G1 X92.837 Y123.154 E.01056
G1 X92.837 Y124.841 E.04103
G1 X91.798 Y124.842 E.02527
G1 X91.169 Y124.961 E.01557
G1 X91.169 Y123.042 E.04668
G1 X91.704 Y123.15 E.01328
G1 X92.343 Y123.152 E.01554
G1 E-5 F3600
G1 X92.343 Y123.152 F9000
G1 X90.878 Y126.53
G1 X90.85 Y126.597
G1 X90.804 Y126.716
G1 X90.763 Y126.896
G1 X90.758 Y126.972
G1 X90.751 Y127.065
G1 X90.751 Y128.935
G1 X90.804 Y134.716
G1 X90.799 Y134.737
G1 X90.439 Y134.656
G1 E5 F2400
G1 F6000
G1 X90.438 Y129.349 E.12909
G1 X90.515 Y129.573 E.00576
G1 X90.809 Y130.001 E.01263
G1 X91.239 Y130.298 E.01271
G1 X91.707 Y130.419 E.01176
G1 X93.571 Y130.425 E.04534
G1 X93.58 Y133.068 E.06429
G1 X93.623 Y133.572 E.0123
G1 X91.799 Y133.573 E.04437
G1 X91.301 Y133.682 E.0124
G1 X90.974 Y133.857 E.00902
G1 X90.566 Y134.336 E.0153
G1 X90.461 Y134.601 E.00693
G1 X90.461 Y134.601 F9000
G1 X90.805 Y133.532
G1 F6000
G1 X90.804 Y130.466 E.07458
G1 X91.13 Y130.647 E.00907
G1 X91.706 Y130.785 E.01441
G1 X93.207 Y130.789 E.03651
G1 X93.223 Y133.207 E.05882
G1 X91.799 Y133.207 E.03464
G1 X91.211 Y133.328 E.0146
G1 X90.858 Y133.505 E.00961
G1 X90.858 Y133.505 F9000
G1 X91.17 Y132.961
G1 F6000
G1 X91.17 Y131.043 E.04665
G1 X91.704 Y131.15 E.01325
G1 X92.842 Y131.154 E.02768
G1 X92.848 Y132.841 E.04103
G1 X91.799 Y132.842 E.02552
G1 X91.229 Y132.95 E.01411
G1 E-5 F3600
G1 X91.229 Y132.95 F9000
G1 X90.506 Y142.479
G1 E5 F2400
G1 F6000
G1 X90.44 Y142.641 E.00425
G1 X90.44 Y137.345 E.12882
G1 X90.542 Y137.63 E.00736
G1 X90.844 Y138.036 E.01231
G1 X91.278 Y138.314 E.01254
G1 X91.75 Y138.424 E.01179
G1 X95.255 Y138.428 E.08526
G1 X95.692 Y139.121 E.01993
G1 X96.142 Y139.75 E.01881
G1 X96.526 Y140.223 E.01482
G1 X97.373 Y141.03 E.02846
G1 X97.94 Y141.468 E.01743
G1 X97.094 Y141.47 E.02058
G1 X95.298 Y141.569 E.04375
G1 X91.797 Y141.573 E.08516
G1 X91.299 Y141.683 E.01241
G1 X90.962 Y141.868 E.00935
G1 X90.551 Y142.367 E.01572
G1 X90.528 Y142.423 E.00147
G1 X90.528 Y142.423 F9000
G1 X90.806 Y141.533
G1 F6000
G1 X90.805 Y138.464 E.07465
G1 X91.181 Y138.667 E.01039
G1 X91.749 Y138.79 E.01414
G1 X95.049 Y138.793 E.08027
G1 X95.389 Y139.325 E.01536
G1 X95.856 Y139.978 E.01953
G1 X96.273 Y140.487 E.01601
G1 X96.927 Y141.113 E.02202
G1 X95.288 Y141.203 E.03993
G1 X91.797 Y141.207 E.08492
G1 X91.208 Y141.329 E.01463
G1 X90.859 Y141.506 E.00952
G1 X90.859 Y141.506 F9000
G1 X91.172 Y140.961
G1 F6000
G1 X91.171 Y139.044 E.04663
G1 X91.749 Y139.156 E.01432
G1 X94.843 Y139.158 E.07526
G1 X95.57 Y140.206 E.03102
G1 X96.065 Y140.794 E.0187
G1 X95.278 Y140.837 E.01917
G1 X91.796 Y140.842 E.0847
G1 X91.23 Y140.949 E.01401
G1 E-5 F3600
G1 X91.23 Y140.949 F9000
G1 X90.804 Y142.716
G1 X90.763 Y142.896
G1 X90.758 Y142.972
G1 X90.751 Y143.065
G1 X90.751 Y144.935
G1 X90.758 Y145.028
G1 X90.763 Y145.104
G1 X90.804 Y145.284
G1 X90.85 Y145.403
G1 X90.878 Y145.47
G1 X90.977 Y145.628
G1 X91.102 Y145.768
G1 X91.252 Y145.884
G1 X91.422 Y145.973
G1 X91.597 Y146.026
G1 X91.7 Y146.039
G1 X91.783 Y146.044
G1 X97.14 Y146.149
G1 X97.433 Y146.145
G1 X98.288 Y146.145
G1 X98.288 Y146.531
G1 E5 F2400
G1 F6000
G1 X105.729 Y146.53 E.18099
G1 X105.888 Y146.506 E.00391
G1 X106.268 Y146.354 E.00996
G1 X106.546 Y146.03 E.01038
G1 X106.645 Y145.619 E.01028
G1 X106.652 Y143.646 E.04799
G1 X124.356 Y143.644 E.43063
G1 X124.355 Y145.615 E.04794
G1 X124.384 Y145.79 E.00431
G1 X124.538 Y146.164 E.00984
G1 X124.899 Y146.448 E.01117
G1 X125.27 Y146.53 E.00924
G1 X133.905 Y146.53 E.21004
G1 X135.736 Y146.431 E.0446
G1 X139.202 Y146.427 E.08431
G1 X139.699 Y146.318 E.01238
G1 X140.026 Y146.143 E.00902
G1 X140.434 Y145.664 E.0153
G1 X140.568 Y145.316 E.00907
G1 X140.568 Y150.716 E.13135
G1 X140.456 Y150.383 E.00855
G1 X140.26 Y150.075 E.00888
G1 X139.745 Y149.702 E.01547
G1 X139.497 Y149.616 E.00638
G1 X138.995 Y149.573 E.01226
G1 X135.59 Y149.564 E.08282
G1 X134.255 Y149.483 E.03253
G1 X133.571 Y149.472 E.01664
G1 X125.27 Y149.47 E.20191
G1 X125.112 Y149.494 E.00389
G1 X124.731 Y149.646 E.00998
G1 X124.438 Y150.01 E.01137
G1 X124.355 Y150.385 E.00934
G1 X124.355 Y153.615 E.07857
G1 X124.456 Y154.008 E.00987
G1 X124.62 Y154.251 E.00713
G1 X124.964 Y154.47 E.00992
G1 X125.269 Y154.53 E.00756
G1 X133.855 Y154.529 E.20885
G1 X135.692 Y154.431 E.04475
G1 X139.202 Y154.427 E.08538
G1 X138.888 Y154.764 E.0112
G1 X138.454 Y155.116 E.01359
G1 X137.946 Y155.437 E.01462
G1 X137.406 Y155.694 E.01455
G1 X136.803 Y155.896 E.01547
G1 X136.279 Y155.985 E.01293
G1 X135.677 Y155.948 E.01467
G1 X134.516 Y155.707 E.02884
G1 X133.855 Y155.653 E.01613
G1 X97.146 Y155.654 E.89291
G1 X96.44 Y155.713 E.01723
G1 X95.493 Y155.908 E.02352
G1 X94.819 Y155.98 E.01649
G1 X94.456 Y155.943 E.00888
G1 X93.728 Y155.746 E.01834
G1 X93.264 Y155.545 E.0123
G1 X92.81 Y155.293 E.01263
G1 X92.082 Y154.737 E.02228
G1 X91.773 Y154.419 E.01079
G1 X95.364 Y154.433 E.08735
G1 X97.145 Y154.532 E.04339
G1 X105.731 Y154.53 E.20885
G1 X106.036 Y154.47 E.00756
G1 X106.38 Y154.251 E.00992
G1 X106.544 Y154.008 E.00713
G1 X106.645 Y153.615 E.00987
G1 X106.643 Y150.345 E.07954
G1 X106.604 Y150.143 E.005
G1 X106.436 Y149.804 E.0092
G1 X106.101 Y149.552 E.0102
G1 X105.731 Y149.47 E.00922
G1 X96.926 Y149.476 E.21417
G1 X95.27 Y149.569 E.04034
G1 X91.707 Y149.58 E.08667
G1 X91.254 Y149.702 E.01141
G1 X90.879 Y149.945 E.01087
G1 X90.625 Y150.228 E.00925
G1 X90.442 Y150.688 E.01204
G1 X90.441 Y145.333 E.13026
G1 X90.506 Y145.554 E.0056
G1 X90.669 Y145.833 E.00786
G1 X90.974 Y146.143 E.01058
G1 X91.301 Y146.318 E.00902
G1 X91.798 Y146.427 E.01238
G1 X95.399 Y146.435 E.08759
G1 X97.145 Y146.532 E.04254
G1 X98.228 Y146.531 E.02634
G1 E-5 F3600
G1 X98.228 Y146.531 F9000
G1 X98.228 Y146.145
G1 X106.263 Y146.147
G1 X107.016 Y144.012
G1 E5 F2400
G1 F6000
G1 X123.99 Y144.009 E.41288
G1 X123.989 Y145.615 E.03906
G1 X124.037 Y145.907 E.0072
G1 X124.191 Y146.302 E.01031
G1 X124.448 Y146.581 E.00923
G1 X124.856 Y146.827 E.01159
G1 X125.27 Y146.895 E.01021
G1 X133.925 Y146.895 E.21052
G1 X135.746 Y146.797 E.04436
G1 X139.202 Y146.793 E.08406
G1 X139.789 Y146.672 E.01458
G1 X140.202 Y146.464 E.01125
G1 X140.202 Y149.562 E.07536
G1 X139.944 Y149.395 E.00748
G1 X139.53 Y149.252 E.01065
G1 X138.996 Y149.207 E.01304
G1 X135.601 Y149.198 E.08258
G1 X134.277 Y149.118 E.03226
G1 X133.571 Y149.106 E.01718
G1 X125.27 Y149.105 E.20191
G1 X124.806 Y149.203 E.01154
G1 X124.507 Y149.358 E.00819
G1 X124.204 Y149.701 E.01113
G1 X124.055 Y149.98 E.00769
G1 X123.989 Y150.385 E.00998
G1 X123.989 Y153.615 E.07857
G1 X124.109 Y154.124 E.01272
G1 X124.382 Y154.529 E.01188
;WIDTH:0.416688
G1 X124.873 Y154.833 E.01469
G1 X125.269 Y154.902 E.01022
;WIDTH:0.413304
G1 X133.855 Y154.902 E.21644
;WIDTH:0.416989
G1 X133.961 Y154.902 E.0027
;WIDTH:0.432584
G1 X135.692 Y154.798 E.04594
;WIDTH:0.399999
G1 X138.271 Y154.794 E.06273
G1 X137.77 Y155.116 E.01449
G1 X137.269 Y155.354 E.01349
G1 X136.713 Y155.54 E.01426
G1 X136.212 Y155.614 E.01232
G1 X135.635 Y155.565 E.01409
;WIDTH:0.432584
G1 X134.594 Y155.333 E.02825
;WIDTH:0.451623
G1 X134.477 Y155.307 E.00333
G1 X133.855 Y155.281 E.01728
;WIDTH:0.413304
G1 X125.269 Y155.281 E.21644
;WIDTH:0.416688
G1 X124.26 Y155.287 E.02566
;WIDTH:0.399999
G1 X106.741 Y155.288 E.42613
;WIDTH:0.41361
G1 X97.146 Y155.282 E.24208
;WIDTH:0.41718
G1 X97.038 Y155.283 E.00275
;WIDTH:0.445062
G1 X96.361 Y155.333 E.01855
G1 X95.419 Y155.55 E.02641
;WIDTH:0.399999
G1 X94.802 Y155.615 E.01509
G1 X94.504 Y155.578 E.0073
G1 X93.828 Y155.391 E.01706
G1 X93.018 Y154.991 E.02197
G1 X92.756 Y154.792 E.008
G1 X95.364 Y154.799 E.06344
;WIDTH:0.428541
G1 X95.914 Y154.844 E.01447
;WIDTH:0.457082
G1 X96.465 Y154.889 E.01555
G1 X97.145 Y154.904 E.01913
;WIDTH:0.41361
G1 X105.731 Y154.902 E.21662
G1 X106.126 Y154.829 E.01013
;WIDTH:0.407739
G1 X106.498 Y154.632 E.01046
;WIDTH:0.399999
G1 X106.618 Y154.529 E.00385
G1 X106.891 Y154.124 E.01188
G1 X107.011 Y153.615 E.01272
G1 X107.008 Y150.345 E.07954
G1 X106.983 Y150.133 E.00519
G1 X106.797 Y149.678 E.01196
G1 X106.552 Y149.419 E.00867
G1 X106.144 Y149.173 E.01159
G1 X105.731 Y149.105 E.01018
G1 X97.146 Y149.109 E.20882
G1 X95.26 Y149.203 E.04593
G1 X92.015 Y149.207 E.07893
G1 X91.402 Y149.261 E.01497
G1 X91.055 Y149.395 E.00905
G1 X90.807 Y149.556 E.00719
G1 X90.807 Y146.47 E.07506
G1 X91.211 Y146.672 E.01099
G1 X91.797 Y146.793 E.01455
G1 X95.388 Y146.8 E.08735
G1 X97.146 Y146.897 E.04283
G1 X105.73 Y146.895 E.2088
G1 X106.194 Y146.797 E.01154
G1 X106.493 Y146.642 E.00819
G1 X106.824 Y146.278 E.01197
G1 X106.945 Y145.995 E.00749
G1 X107.01 Y145.62 E.00926
G1 X107.016 Y144.072 E.03765
G1 X107.016 Y144.072 F9000
G1 X107.497 Y144.377
G1 F6000
G1 X123.625 Y144.375 E.3923
G1 X123.624 Y145.614 E.03014
G1 X123.691 Y146.023 E.01008
G1 X123.829 Y146.401 E.00979
G1 X124.004 Y146.667 E.00774
G1 X124.412 Y147.005 E.01289
G1 X124.736 Y147.172 E.00887
G1 X125.27 Y147.261 E.01317
G1 X133.945 Y147.261 E.21101
G1 X135.756 Y147.163 E.04412
G1 X139.203 Y147.158 E.08384
G1 X139.836 Y147.038 E.01567
G1 X139.836 Y148.982 E.04729
G1 X139.563 Y148.888 E.00702
G1 X138.997 Y148.841 E.01381
G1 X135.613 Y148.833 E.08231
G1 X134.299 Y148.753 E.03202
G1 X133.571 Y148.741 E.01771
G1 X125.27 Y148.739 E.20191
G1 X124.997 Y148.768 E.00668
G1 X124.518 Y148.924 E.01225
G1 X124.282 Y149.069 E.00674
G1 X123.916 Y149.476 E.01331
G1 X123.708 Y149.866 E.01075
G1 X123.624 Y150.385 E.01279
G1 X123.624 Y153.615 E.07857
G1 X123.763 Y154.239 E.01555
G1 X124.144 Y154.806 E.01662
G1 X124.288 Y154.922 E.0045
G1 X106.741 Y154.922 E.42681
G1 X106.856 Y154.806 E.00397
G1 X107.237 Y154.239 E.01662
G1 X107.376 Y153.615 E.01555
G1 X107.367 Y150.21 E.08282
G1 X107.211 Y149.69 E.01321
G1 X106.989 Y149.326 E.01037
G1 X106.587 Y148.995 E.01267
G1 X106.263 Y148.828 E.00887
G1 X105.731 Y148.739 E.01312
G1 X96.885 Y148.746 E.21517
G1 X95.249 Y148.837 E.03986
G1 X92.015 Y148.841 E.07866
G1 X91.587 Y148.859 E.01042
G1 X91.173 Y148.966 E.0104
G1 X91.172 Y147.04 E.04685
G1 X91.796 Y147.158 E.01545
G1 X95.377 Y147.166 E.0871
G1 X97.146 Y147.263 E.04309
G1 X105.73 Y147.261 E.2088
G1 X106.004 Y147.231 E.0067
G1 X106.481 Y147.077 E.01219
G1 X106.812 Y146.85 E.00976
G1 X107.131 Y146.477 E.01194
G1 X107.301 Y146.081 E.01048
G1 X107.376 Y145.621 E.01134
G1 X107.381 Y144.377 E.03026
G1 X107.437 Y144.377 E.00136
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X107.497 Y144.377 E-.0285
G1 X110.595 Y144.377 E-1.4715
;WIPE_END
G1 X106.263 Y154.147 F9000
G1 X95.148 Y155.198
G1 E5 F2400
;WIDTH:0.468246
G1 F6000
G1 X94.608 Y155.194 E.01559
G1 E-5 F3600
G1 X94.608 Y155.194 F9000
G1 X136.622 Y155.173
G1 E5 F2400
;WIDTH:0.458472
G1 F6000
G1 X135.778 Y155.192 E.02382
G1 E-5 F3600
G1 X135.778 Y155.192 F9000
G1 X124.737 Y154.147
G1 X91.597 Y146.026
G1 X91.422 Y145.973
G1 X91.252 Y145.884
G1 X91.102 Y145.768
G1 X90.977 Y145.628
G1 X90.878 Y145.47
G1 X90.85 Y145.403
G1 X90.804 Y145.284
G1 X90.763 Y145.104
G1 X90.758 Y145.028
G1 X90.751 Y144.935
G1 X90.751 Y111.065
G1 X90.758 Y110.972
G1 X90.763 Y110.896
G1 X90.804 Y110.716
G1 X90.85 Y110.597
G1 X90.878 Y110.53
G1 X90.977 Y110.372
G1 X91.102 Y110.232
G1 X91.252 Y110.116
G1 X91.422 Y110.027
G1 X91.597 Y109.974
G1 X91.7 Y109.961
G1 X91.783 Y109.956
G1 X93.227 Y109.954
G1 X93.569 Y109.954
G1 X93.569 Y109.572
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X91.799 Y109.573 E.04305
G1 X91.301 Y109.682 E.0124
G1 X90.974 Y109.857 E.00902
G1 X90.566 Y110.336 E.0153
G1 X90.435 Y110.671 E.00875
G1 X90.434 Y105.326 E.13001
G1 X90.566 Y105.665 E.00885
G1 X90.975 Y106.143 E.0153
G1 X91.302 Y106.318 E.00902
G1 X91.799 Y106.427 E.01238
G1 X93.569 Y106.428 E.04305
G1 X93.569 Y109.512 E.07502
G1 X93.569 Y109.512 F9000
G1 X93.203 Y109.174
G1 F6000
G1 X93.203 Y109.207 E.0008
G1 X91.798 Y109.207 E.03418
G1 X91.211 Y109.328 E.01458
G1 X90.801 Y109.534 E.01116
G1 X90.8 Y106.466 E.07463
G1 X91.212 Y106.673 E.01122
G1 X91.798 Y106.793 E.01455
G1 X93.203 Y106.793 E.03418
G1 X93.203 Y109.114 E.05646
G1 X93.203 Y109.114 F9000
G1 X92.837 Y107.892
G1 F6000
G1 X92.837 Y108.841 E.02308
G1 X91.798 Y108.842 E.02527
G1 X91.166 Y108.962 E.01565
G1 X91.166 Y107.038 E.0468
G1 X91.798 Y107.158 E.01565
G1 X92.837 Y107.159 E.02527
G1 X92.837 Y107.832 E.01637
G1 E-5 F3600
G1 X92.837 Y107.832 F9000
G1 X90.977 Y105.628
G1 X90.878 Y105.47
G1 X90.85 Y105.403
G1 X90.804 Y105.284
G1 X90.763 Y105.104
G1 X90.758 Y105.028
G1 X90.751 Y104.935
G1 X90.751 Y103.065
G1 X90.758 Y102.972
G1 X90.763 Y102.896
G1 X90.804 Y102.716
G1 X90.85 Y102.597
G1 X90.878 Y102.53
G1 X90.977 Y102.372
G1 X91.102 Y102.232
G1 X91.252 Y102.116
G1 X91.422 Y102.027
G1 X91.597 Y101.974
G1 X91.7 Y101.961
G1 X91.783 Y101.956
G1 X93.227 Y101.954
G1 X93.569 Y101.954
G1 X93.569 Y101.575
G1 E5 F2400
G1 F6000
G1 X91.707 Y101.581 E.04529
G1 X91.239 Y101.702 E.01176
G1 X90.809 Y101.999 E.01271
G1 X90.515 Y102.427 E.01263
G1 X90.434 Y102.68 E.00646
G1 X90.433 Y95.966 E.16331
G1 X90.692 Y96.46 E.01357
G1 X90.842 Y96.627 E.00546
G1 X91.113 Y96.826 E.00818
G1 X91.313 Y96.918 E.00535
G1 X91.798 Y97.017 E.01204
G1 X93.569 Y97.017 E.04308
G1 X93.569 Y101.515 E.10941
G1 X93.569 Y101.515 F9000
G1 X93.203 Y100.912
G1 F6000
G1 X93.203 Y101.21 E.00725
G1 X91.705 Y101.215 E.03644
G1 X91.13 Y101.353 E.01438
G1 X90.8 Y101.537 E.00919
G1 X90.799 Y97.049 E.10917
G1 X91.23 Y97.274 E.01183
G1 X91.799 Y97.382 E.01409
G1 X93.203 Y97.382 E.03415
G1 X93.203 Y100.852 E.0844
G1 X93.203 Y100.852 F9000
G1 X92.837 Y100.846
G1 F6000
G1 X91.704 Y100.85 E.02756
G1 X91.165 Y100.959 E.01338
G1 X91.165 Y97.635 E.08085
G1 X91.799 Y97.748 E.01566
G1 X92.837 Y97.748 E.02525
G1 X92.837 Y100.786 E.0739
G1 E-5 F3600
G1 X92.837 Y100.786 F9000
G1 X90.812 Y95.934
G1 X90.765 Y95.757
G1 X90.76 Y95.697
G1 X90.751 Y95.594
G1 X90.751 Y93.234
G1 X90.76 Y93.132
G1 X90.765 Y93.072
G1 X90.812 Y92.895
G1 X90.888 Y92.728
G1 X90.992 Y92.577
G1 X91.121 Y92.446
G1 X91.271 Y92.339
G1 X91.438 Y92.259
G1 X91.608 Y92.213
G1 X91.741 Y92.197
G1 X91.784 Y92.194
G1 X92.562 Y92.194
G1 X95.414 Y92.195
G1 X99.651 Y79.336
G1 X99.27 Y79.336
G1 E5 F2400
G1 F6000
G1 X99.282 Y82.375 E.07392
G1 X99.388 Y83.1 E.01782
G1 X99.692 Y84.044 E.02412
G1 X100.059 Y84.723 E.01877
G1 X100.466 Y85.264 E.01647
G1 X101.172 Y85.939 E.02376
G1 X101.713 Y86.304 E.01587
G1 X102.353 Y86.621 E.01737
G1 X102.949 Y86.818 E.01527
G1 X103.668 Y86.947 E.01777
G1 X104.2 Y86.981 E.01297
G1 X126.82 Y86.969 E.55021
G1 X127.341 Y86.943 E.01269
G1 X127.858 Y86.864 E.01272
G1 X128.452 Y86.694 E.01503
G1 X129.091 Y86.411 E.017
G1 X129.872 Y85.903 E.02266
G1 X130.367 Y85.449 E.01634
G1 X130.993 Y84.638 E.02492
G1 X131.311 Y84.036 E.01656
G1 X131.556 Y83.343 E.01788
G1 X131.686 Y82.702 E.01591
G1 X131.731 Y82.051 E.01587
G1 X131.731 Y79.332 E.06614
G1 X132.177 Y78.942 E.01441
G1 X132.631 Y78.496 E.01548
G1 X132.944 Y78.056 E.01313
G1 X133.082 Y77.554 E.01266
G1 X132.979 Y77.045 E.01263
G1 X132.759 Y76.661 E.01076
G1 X132.146 Y76.029 E.02142
G1 X131.727 Y75.664 E.01352
G1 X131.706 Y75.546 E.00292
G1 X131.54 Y75.216 E.00899
G1 X131.337 Y75.042 E.0065
G1 X135.447 Y75.042 E.09997
G1 X136.004 Y75.078 E.01358
G1 X136.547 Y75.154 E.01334
G1 X137.432 Y75.435 E.02259
G1 X138.25 Y75.875 E.02259
G1 X138.726 Y76.234 E.0145
G1 X139.164 Y76.659 E.01484
G1 X139.548 Y77.136 E.0149
G1 X139.839 Y77.602 E.01336
G1 X140.125 Y78.212 E.01639
G1 X140.309 Y78.79 E.01475
G1 X140.422 Y79.394 E.01495
G1 X140.45 Y79.92 E.01281
G1 X140.462 Y85.245 E.12953
G1 X140.569 Y85.634 E.00981
G1 X140.569 Y85.849 E.00523
G1 X140.569 Y92.915 E.17187
G1 X140.48 Y92.63 E.00726
G1 X140.302 Y92.352 E.00803
G1 X140.001 Y92.071 E.01002
G1 X139.689 Y91.914 E.0085
G1 X139.202 Y91.812 E.0121
G1 X127.313 Y91.812 E.28919
G1 X127.573 Y91.562 E.00877
G1 X127.881 Y91.163 E.01226
G1 X128.062 Y90.665 E.01289
G1 X128.061 Y90.354 E.00756
G1 X127.907 Y89.867 E.01242
G1 X127.608 Y89.512 E.01129
G1 X127.195 Y89.078 E.01457
G1 X126.719 Y88.659 E.01542
G1 X126.714 Y88.545 E.00278
G1 X126.649 Y88.312 E.00588
G1 X126.446 Y88.026 E.00853
G1 X126.11 Y87.823 E.00955
G1 X125.817 Y87.769 E.00725
G1 X105.183 Y87.769 E.5019
G1 X104.973 Y87.811 E.00521
G1 X104.545 Y88.028 E.01167
G1 X104.322 Y88.375 E.01003
G1 X104.281 Y88.658 E.00696
G1 X103.823 Y89.058 E.01479
G1 X103.427 Y89.438 E.01335
G1 X103.118 Y89.838 E.01229
G1 X102.944 Y90.276 E.01146
G1 X102.931 Y90.57 E.00716
G1 X103.078 Y91.091 E.01317
G1 X103.241 Y91.339 E.00722
G1 X103.698 Y91.812 E.016
G1 X91.798 Y91.812 E.28946
G1 X91.313 Y91.91 E.01204
G1 X90.874 Y92.167 E.01237
G1 X90.561 Y92.55 E.01203
G1 X90.433 Y92.886 E.00875
G1 X90.431 Y85.623 E.17667
G1 X90.541 Y85.196 E.01073
G1 X90.539 Y80.029 E.12568
G1 X90.579 Y79.389 E.0156
G1 X90.678 Y78.849 E.01335
G1 X90.877 Y78.206 E.01637
G1 X91.131 Y77.654 E.01478
G1 X91.453 Y77.135 E.01486
G1 X91.835 Y76.659 E.01485
G1 X92.274 Y76.234 E.01486
G1 X92.761 Y75.866 E.01485
G1 X93.29 Y75.561 E.01485
G1 X93.852 Y75.323 E.01485
G1 X94.439 Y75.156 E.01484
G1 X95.038 Y75.063 E.01474
G1 X96.178 Y75.039 E.02774
G1 X99.674 Y75.039 E.08504
G1 X99.431 Y75.274 E.00822
G1 X99.288 Y75.652 E.00983
G1 X98.825 Y76.056 E.01495
G1 X98.398 Y76.473 E.01452
G1 X98.028 Y77.023 E.01612
G1 X97.922 Y77.509 E.0121
G1 X97.994 Y77.889 E.00941
G1 X98.241 Y78.338 E.01246
G1 X98.854 Y78.971 E.02143
G1 X99.227 Y79.296 E.01203
G1 E-5 F3600
G1 X99.227 Y79.296 F9000
G1 X99.479 Y79.011
G1 X99.662 Y82.361
G1 X99.687 Y82.605
G1 X99.695 Y82.675
G1 X99.738 Y82.923
G1 X99.75 Y82.989
G1 X99.811 Y83.238
G1 X99.827 Y83.3
G1 X99.906 Y83.548
G1 X99.927 Y83.607
G1 X100.024 Y83.852
G1 X100.048 Y83.907
G1 X100.164 Y84.145
G1 X100.191 Y84.196
G1 X100.323 Y84.427
G1 X100.352 Y84.474
G1 X100.5 Y84.694
G1 X100.532 Y84.737
G1 X100.693 Y84.946
G1 X100.727 Y84.986
G1 X100.9 Y85.181
G1 X100.937 Y85.218
G1 X101.121 Y85.398
G1 X101.16 Y85.432
G1 X101.359 Y85.602
G1 X101.573 Y85.761
G1 X101.614 Y85.791
G1 X101.841 Y85.937
G1 X101.884 Y85.964
G1 X102.121 Y86.095
G1 X102.167 Y86.119
G1 X102.401 Y86.227
G1 X105.018 Y87.382
G1 E5 F2400
;WIDTH:0.470968
G1 F6000
G1 X105.183 Y87.375 E.0048
;WIDTH:0.460332
G1 X110.574 Y87.373 E.15277
;WIDTH:0.471524
G1 X125.817 Y87.369 E.44329
;WIDTH:0.494958
G1 X126.041 Y87.382 E.00688
G1 E-5 F3600
G1 X126.041 Y87.382 F9000
G1 X105.018 Y87.382
G1 E5 F2400
;WIDTH:0.470968
G1 F6000
G1 X104.826 Y87.458 E.006
;WIDTH:0.433175
G1 X104.292 Y87.764 E.01633
;WIDTH:0.399999
G1 X104.031 Y88.136 E.01105
G1 X103.93 Y88.478 E.00867
G1 X103.174 Y89.174 E.025
G1 X102.807 Y89.644 E.0145
G1 X102.597 Y90.162 E.0136
G1 X102.575 Y90.652 E.01193
G1 X102.66 Y91.018 E.00914
G1 X102.867 Y91.446 E.01156
G1 X91.798 Y91.446 E.26924
G1 X91.23 Y91.554 E.01406
G1 X90.798 Y91.775 E.0118
G1 X90.797 Y85.68 E.14825
G1 X90.863 Y85.476 E.00522
G1 X90.907 Y85.196 E.00689
G1 X90.905 Y80.04 E.12541
G1 X90.942 Y79.434 E.01477
G1 X91.034 Y78.936 E.01232
G1 X91.22 Y78.337 E.01526
G1 X91.454 Y77.827 E.01365
G1 X91.752 Y77.347 E.01374
G1 X92.106 Y76.906 E.01376
G1 X92.512 Y76.512 E.01376
G1 X92.963 Y76.172 E.01374
G1 X93.453 Y75.889 E.01376
G1 X93.974 Y75.669 E.01376
G1 X94.518 Y75.514 E.01376
G1 X95.071 Y75.428 E.01361
G1 X96.182 Y75.404 E.02703
G1 X98.975 Y75.404 E.06794
G1 X98.957 Y75.455 E.00132
G1 X98.207 Y76.14 E.02471
G1 X97.823 Y76.63 E.01514
G1 X97.678 Y76.918 E.00784
G1 X97.592 Y77.206 E.00731
G1 X97.557 Y77.538 E.00812
G1 X97.586 Y77.802 E.00646
G1 X97.756 Y78.238 E.01138
G1 X97.978 Y78.592 E.01016
G1 X98.905 Y79.5 E.03156
G1 X98.925 Y82.504 E.07307
G1 X99.039 Y83.209 E.01737
G1 X99.369 Y84.216 E.02578
G1 X99.765 Y84.939 E.02005
G1 X100.211 Y85.526 E.01793
G1 X100.965 Y86.241 E.02528
G1 X101.549 Y86.631 E.01708
G1 X102.375 Y87.014 E.02215
G1 X103.11 Y87.223 E.01859
G1 X103.644 Y87.312 E.01317
G1 X104.2 Y87.347 E.01355
;WIDTH:0.435484
G1 X104.609 Y87.364 E.01092
;WIDTH:0.470968
G1 X104.958 Y87.379 E.01015
G1 X104.958 Y87.379 F9000
G1 X103.883 Y87.695
;WIDTH:0.399999
G1 F6000
G1 X103.71 Y87.961 E.00772
G1 X103.597 Y88.284 E.00832
G1 X103.145 Y88.695 E.01486
G1 X102.696 Y89.183 E.01613
G1 X102.379 Y89.667 E.01407
G1 X102.249 Y90.049 E.00982
G1 X102.219 Y90.735 E.0167
G1 X102.299 Y91.081 E.00864
G1 X91.798 Y91.08 E.25543
G1 X91.164 Y91.194 E.01567
G1 X91.163 Y85.895 E.12889
G1 X91.272 Y85.196 E.01721
G1 X91.271 Y80.154 E.12264
G1 X91.294 Y79.673 E.01171
G1 X91.39 Y79.024 E.01596
G1 X91.562 Y78.468 E.01416
G1 X91.777 Y78.001 E.01251
G1 X92.051 Y77.558 E.01267
G1 X92.377 Y77.153 E.01265
G1 X92.75 Y76.791 E.01264
G1 X93.166 Y76.477 E.01268
G1 X93.616 Y76.217 E.01264
G1 X94.095 Y76.014 E.01265
G1 X94.596 Y75.872 E.01267
G1 X95.103 Y75.793 E.01248
G1 X96.186 Y75.77 E.02635
G1 X98.065 Y75.77 E.0457
G1 X97.954 Y75.875 E.00372
G1 X97.53 Y76.411 E.01662
G1 X97.327 Y76.814 E.01098
G1 X97.242 Y77.101 E.00728
G1 X97.192 Y77.566 E.01138
G1 X97.256 Y77.998 E.01062
G1 X97.46 Y78.465 E.0124
G1 X97.715 Y78.846 E.01115
G1 X98.54 Y79.667 E.02831
G1 X98.563 Y82.556 E.07027
G1 X98.69 Y83.318 E.01879
G1 X99.046 Y84.387 E.02741
G1 X99.47 Y85.155 E.02134
G1 X99.956 Y85.788 E.01941
G1 X100.758 Y86.542 E.02678
G1 X101.384 Y86.957 E.01827
G1 X102.118 Y87.313 E.01984
G1 X102.645 Y87.492 E.01354
G1 X103.287 Y87.631 E.01598
G1 X103.823 Y87.688 E.01311
G1 E-5 F3600
G1 X103.823 Y87.688 F9000
G1 X126.041 Y87.382
G1 E5 F2400
;WIDTH:0.494958
G1 F6000
G1 X126.21 Y87.362 E.00521
;WIDTH:0.454414
G1 X126.515 Y87.348 E.00853
;WIDTH:0.427207
G1 X126.82 Y87.335 E.00798
;WIDTH:0.399999
G1 X127.392 Y87.305 E.01393
G1 X127.956 Y87.217 E.01388
G1 X128.595 Y87.031 E.01619
G1 X129.288 Y86.719 E.01849
G1 X130.116 Y86.175 E.0241
G1 X130.655 Y85.674 E.0179
G1 X131.315 Y84.812 E.02641
G1 X131.655 Y84.16 E.01789
G1 X131.913 Y83.418 E.01911
G1 X132.051 Y82.728 E.01712
G1 X132.097 Y82.051 E.01651
G1 X132.097 Y79.498 E.0621
G1 X132.826 Y78.826 E.02412
G1 X133.174 Y78.382 E.01372
G1 X133.312 Y78.115 E.00731
G1 X133.443 Y77.619 E.01248
G1 X133.418 Y77.268 E.00856
G1 X133.237 Y76.723 E.01397
G1 X133.022 Y76.407 E.0093
G1 X132.443 Y75.808 E.02026
G1 X132.075 Y75.482 E.01196
G1 X132.04 Y75.408 E.00199
G1 X135.599 Y75.414 E.08657
G1 X136.463 Y75.511 E.02115
G1 X137.289 Y75.774 E.02109
G1 X137.84 Y76.07 E.01521
G1 X138.331 Y76.394 E.01431
G1 X138.748 Y76.764 E.01356
G1 X139.122 Y77.189 E.01377
G1 X139.409 Y77.604 E.01227
G1 X139.686 Y78.137 E.01461
G1 X139.887 Y78.67 E.01386
G1 X140.014 Y79.204 E.01335
G1 X140.084 Y79.93 E.01774
G1 X140.099 Y85.312 E.13091
G1 X140.203 Y85.698 E.00972
G1 X140.203 Y85.849 E.00367
G1 X140.203 Y91.748 E.14349
G1 X139.775 Y91.559 E.01138
G1 X139.202 Y91.446 E.01421
G1 X128.126 Y91.446 E.26941
G1 X128.321 Y91.087 E.00994
G1 X128.414 Y90.767 E.00811
G1 X128.411 Y90.248 E.01262
G1 X128.268 Y89.782 E.01186
G1 X128.077 Y89.477 E.00875
G1 X127.495 Y88.86 E.02063
G1 X127.071 Y88.481 E.01383
G1 X127.038 Y88.298 E.00452
G1 X126.834 Y87.905 E.01077
G1 X126.557 Y87.646 E.00922
;WIDTH:0.447479
G1 X126.299 Y87.514 E.00796
;WIDTH:0.494958
G1 X126.094 Y87.409 E.00706
G1 X126.094 Y87.409 F9000
G1 X127.135 Y87.699
;WIDTH:0.399999
G1 F6000
G1 X128.054 Y87.569 E.02258
G1 X128.737 Y87.368 E.01732
G1 X129.485 Y87.027 E.02
G1 X130.36 Y86.448 E.02552
G1 X130.943 Y85.9 E.01946
G1 X131.518 Y85.167 E.02266
G1 X131.767 Y84.745 E.01192
G1 X131.999 Y84.284 E.01255
G1 X132.271 Y83.494 E.02032
G1 X132.415 Y82.755 E.01831
G1 X132.463 Y82.051 E.01716
G1 X132.463 Y79.664 E.05806
G1 X132.684 Y79.469 E.00717
G1 X133.216 Y78.935 E.01833
G1 X133.564 Y78.45 E.01452
G1 X133.676 Y78.177 E.00718
G1 X133.805 Y77.664 E.01287
G1 X133.771 Y77.173 E.01197
G1 X133.552 Y76.538 E.01634
G1 X133.285 Y76.153 E.0114
G1 X132.918 Y75.774 E.01283
G1 X135.571 Y75.778 E.06453
G1 X136.379 Y75.868 E.01978
G1 X137.146 Y76.112 E.01958
G1 X137.855 Y76.492 E.01957
G1 X138.378 Y76.915 E.01636
G1 X138.736 Y77.294 E.01268
G1 X139.099 Y77.797 E.01509
G1 X139.355 Y78.292 E.01356
G1 X139.539 Y78.781 E.01271
G1 X139.655 Y79.272 E.01227
G1 X139.719 Y79.94 E.01632
G1 X139.734 Y85.339 E.13133
G1 X139.837 Y85.849 E.01266
G1 X139.837 Y91.197 E.13008
G1 X139.202 Y91.08 E.01571
G1 X128.704 Y91.081 E.25535
G1 X128.765 Y90.869 E.00537
G1 X128.76 Y90.142 E.01768
G1 X128.637 Y89.733 E.01039
G1 X128.511 Y89.448 E.00758
G1 X128.14 Y89.011 E.01394
G1 X127.404 Y88.288 E.0251
G1 X127.387 Y88.188 E.00247
G1 X127.162 Y87.753 E.01191
G1 E-5 F3600
G1 X127.162 Y87.753 F9000
G1 X139.563 Y92.259
G1 X139.73 Y92.339
G1 X139.88 Y92.446
G1 X140.008 Y92.577
G1 X140.112 Y92.728
G1 X140.189 Y92.895
G1 X140.235 Y93.072
G1 X140.241 Y93.132
G1 X140.249 Y93.234
G1 X140.249 Y95.594
G1 X140.241 Y95.697
G1 X140.235 Y95.757
G1 X140.189 Y95.934
G1 X140.112 Y96.1
G1 X140.008 Y96.252
G1 X139.88 Y96.383
G1 X139.73 Y96.49
G1 X139.563 Y96.569
G1 X139.393 Y96.616
G1 X139.259 Y96.632
G1 X139.217 Y96.634
G1 X137.579 Y96.634
G1 X137.431 Y96.634
G1 X137.431 Y97.017
G1 E5 F2400
G1 F6000
G1 X139.291 Y97.01 E.04524
G1 X139.729 Y96.898 E.011
G1 X140.093 Y96.679 E.01033
G1 X140.257 Y96.526 E.00546
G1 X140.452 Y96.252 E.00818
;WIDTH:0.402764
G1 X140.564 Y95.962 E.00762
G1 X140.569 Y96.289 E.00802
;WIDTH:0.399999
G1 X140.568 Y102.718 E.15638
G1 X140.456 Y102.382 E.00861
G1 X140.349 Y102.195 E.00524
G1 X140.123 Y101.936 E.00836
G1 X139.912 Y101.788 E.00627
G1 X139.508 Y101.627 E.01058
G1 X138.999 Y101.573 E.01245
G1 X137.431 Y101.572 E.03814
G1 X137.431 Y97.077 E.10934
G1 X137.431 Y97.077 F9000
G1 X137.797 Y97.441
G1 F6000
G1 X137.797 Y97.382 E.00144
G1 X139 Y97.382 E.02926
G1 X139.595 Y97.33 E.01453
G1 X139.918 Y97.211 E.00837
G1 X140.203 Y97.04 E.00808
G1 X140.203 Y101.558 E.1099
G1 X140.047 Y101.448 E.00464
G1 X139.643 Y101.287 E.01058
G1 X139.351 Y101.224 E.00727
G1 X138.999 Y101.207 E.00857
G1 X137.797 Y101.207 E.02924
G1 X137.797 Y97.501 E.09014
G1 X137.797 Y97.501 F9000
G1 X138.163 Y97.748
G1 F6000
G1 X139.41 Y97.731 E.03033
G1 X139.837 Y97.624 E.01071
G1 X139.837 Y100.971 E.08141
G1 X139.369 Y100.858 E.01171
G1 X138.163 Y100.841 E.02934
G1 X138.163 Y97.808 E.07377
G1 E-5 F3600
G1 X138.163 Y97.808 F9000
G1 X140.15 Y102.597
G1 X140.196 Y102.716
G1 X140.237 Y102.896
G1 X140.242 Y102.972
G1 X140.249 Y103.065
G1 X140.249 Y104.935
G1 X140.242 Y105.028
G1 X140.237 Y105.104
G1 X140.196 Y105.284
G1 X140.15 Y105.403
G1 X140.122 Y105.47
G1 X140.023 Y105.628
G1 X139.898 Y105.768
G1 X139.748 Y105.884
G1 X139.578 Y105.973
G1 X139.403 Y106.026
G1 X139.3 Y106.039
G1 X139.217 Y106.044
G1 X138.542 Y106.045
G1 X137.431 Y106.046
G1 X137.431 Y106.425
G1 E5 F2400
G1 F6000
G1 X138.994 Y106.42 E.03802
G1 X139.455 Y106.394 E.01123
G1 X139.941 Y106.202 E.01271
G1 X140.319 Y105.853 E.01251
;WIDTH:0.403975
G1 X140.56 Y105.394 E.01275
G1 X140.568 Y105.595 E.00495
;WIDTH:0.399999
G1 X140.568 Y110.684 E.12378
G1 X140.485 Y110.427 E.00657
G1 X140.191 Y109.999 E.01263
G1 X139.761 Y109.702 E.01271
G1 X139.293 Y109.581 E.01176
G1 X137.431 Y109.575 E.04529
G1 X137.431 Y106.485 E.07516
G1 X137.431 Y106.485 F9000
G1 X137.797 Y106.79
G1 F6000
G1 X139.295 Y106.785 E.03644
G1 X139.87 Y106.647 E.01438
G1 X140.203 Y106.461 E.00928
G1 X140.203 Y109.539 E.07487
G1 X139.87 Y109.353 E.00928
G1 X139.295 Y109.215 E.01438
G1 X137.797 Y109.21 E.03644
G1 X137.797 Y106.85 E.0574
G1 X137.797 Y106.85 F9000
G1 X138.163 Y107.915
G1 F6000
G1 X138.163 Y107.154 E.01851
G1 X139.296 Y107.15 E.02756
G1 X139.837 Y107.041 E.01342
G1 X139.837 Y108.959 E.04665
G1 X139.296 Y108.85 E.01342
G1 X138.163 Y108.846 E.02756
G1 X138.163 Y107.975 E.02119
G1 E-5 F3600
G1 X138.163 Y107.975 F9000
G1 X140.023 Y110.372
G1 X140.122 Y110.53
G1 X140.15 Y110.597
G1 X140.196 Y110.716
G1 X140.237 Y110.896
G1 X140.242 Y110.972
G1 X140.249 Y111.065
G1 X140.249 Y112.935
G1 X140.242 Y113.028
G1 X140.237 Y113.104
G1 X140.196 Y113.284
G1 X140.15 Y113.403
G1 X140.122 Y113.47
G1 X140.023 Y113.628
G1 X139.898 Y113.768
G1 X139.748 Y113.884
G1 X139.578 Y113.973
G1 X139.403 Y114.026
G1 X139.3 Y114.039
G1 X139.217 Y114.044
G1 X137.773 Y114.046
G1 X137.431 Y114.046
G1 X137.431 Y114.428
G1 E5 F2400
G1 F6000
G1 X139.201 Y114.427 E.04305
G1 X139.698 Y114.318 E.01238
G1 X140.024 Y114.144 E.00899
G1 X140.433 Y113.666 E.0153
G1 X140.568 Y113.315 E.00915
G1 X140.568 Y118.718 E.13142
G1 X140.456 Y118.382 E.00861
G1 X140.349 Y118.195 E.00524
G1 X140.123 Y117.936 E.00836
G1 X139.912 Y117.788 E.00627
G1 X139.508 Y117.627 E.01058
G1 X138.999 Y117.573 E.01245
G1 X137.431 Y117.572 E.03814
G1 X137.431 Y114.488 E.07502
G1 X137.431 Y114.488 F9000
G1 X137.8 Y114.793
G1 F6000
G1 X139.202 Y114.793 E.0341
G1 X139.788 Y114.673 E.01455
G1 X140.203 Y114.464 E.0113
G1 X140.203 Y117.558 E.07526
G1 X140.047 Y117.448 E.00464
G1 X139.643 Y117.287 E.01058
G1 X139.351 Y117.224 E.00727
G1 X138.999 Y117.207 E.00857
G1 X137.797 Y117.207 E.02924
G1 X137.797 Y114.851 E.05731
G1 X138.178 Y115.159 F9000
G1 F6000
G1 X139.202 Y115.158 E.02491
G1 X139.837 Y115.038 E.01572
G1 X139.837 Y116.971 E.04702
G1 X139.369 Y116.858 E.01171
G1 X138.163 Y116.841 E.02934
G1 X138.163 Y115.203 E.03984
G1 E-5 F3600
G1 X138.163 Y115.203 F9000
G1 X140.122 Y118.53
G1 X140.15 Y118.597
G1 X140.196 Y118.716
G1 X140.237 Y118.896
G1 X140.242 Y118.972
G1 X140.249 Y119.065
G1 X140.249 Y120.935
G1 X140.242 Y121.028
G1 X140.237 Y121.104
G1 X140.196 Y121.284
G1 X140.15 Y121.403
G1 X140.122 Y121.47
G1 X140.023 Y121.628
G1 X139.898 Y121.768
G1 X139.748 Y121.884
G1 X139.578 Y121.973
G1 X139.403 Y122.026
G1 X139.3 Y122.039
G1 X139.217 Y122.044
G1 X137.773 Y122.046
G1 X137.431 Y122.046
G1 X137.431 Y122.425
G1 E5 F2400
G1 F6000
G1 X138.994 Y122.42 E.03802
G1 X139.455 Y122.394 E.01123
G1 X139.941 Y122.202 E.01271
G1 X140.319 Y121.853 E.01251
;WIDTH:0.403972
G1 X140.56 Y121.394 E.01275
G1 X140.568 Y121.595 E.00495
;WIDTH:0.399999
G1 X140.568 Y126.695 E.12405
G1 X140.536 Y126.556 E.00347
G1 X140.289 Y126.108 E.01244
G1 X139.906 Y125.776 E.01233
G1 X139.708 Y125.682 E.00533
G1 X139.202 Y125.573 E.01259
G1 X137.431 Y125.572 E.04308
G1 X137.431 Y122.485 E.07509
G1 X137.431 Y122.485 F9000
G1 X137.797 Y122.79
G1 F6000
G1 X139.295 Y122.785 E.03644
G1 X139.87 Y122.647 E.01438
G1 X140.202 Y122.461 E.00926
G1 X140.202 Y125.542 E.07494
G1 X139.796 Y125.327 E.01117
G1 X139.202 Y125.207 E.01474
G1 X137.797 Y125.207 E.03418
G1 X137.797 Y122.85 E.05733
G1 X137.797 Y122.85 F9000
G1 X138.163 Y123.685
G1 F6000
G1 X138.163 Y123.154 E.01292
G1 X139.296 Y123.15 E.02756
G1 X139.837 Y123.041 E.01342
G1 X139.837 Y124.96 E.04668
G1 X139.203 Y124.842 E.01569
G1 X138.163 Y124.841 E.0253
G1 X138.163 Y123.745 E.02666
G1 E-5 F3600
G1 X138.163 Y123.745 F9000
G1 X140.023 Y126.372
G1 X140.122 Y126.53
G1 X140.15 Y126.597
G1 X140.196 Y126.716
G1 X140.237 Y126.896
G1 X140.242 Y126.972
G1 X140.249 Y127.065
G1 X140.249 Y128.935
G1 X140.196 Y134.716
G1 X140.214 Y134.797
G1 X140.568 Y134.718
G1 E5 F2400
G1 F6000
G1 X140.456 Y134.383 E.00859
G1 X140.349 Y134.195 E.00526
G1 X140.123 Y133.936 E.00836
G1 X139.912 Y133.788 E.00627
G1 X139.508 Y133.627 E.01058
G1 X138.996 Y133.573 E.01252
G1 X137.373 Y133.572 E.03948
G1 X137.42 Y133.078 E.01207
G1 X137.428 Y130.425 E.06453
G1 X139.293 Y130.419 E.04536
G1 X139.761 Y130.298 E.01176
G1 X140.059 Y130.118 E.00847
G1 X140.449 Y129.633 E.01514
G1 X140.568 Y129.323 E.00808
G1 X140.568 Y134.658 E.12977
G1 X140.568 Y134.658 F9000
G1 X140.202 Y133.558
G1 F6000
G1 X140.047 Y133.448 E.00462
G1 X139.643 Y133.287 E.01058
G1 X139.35 Y133.224 E.00729
G1 X138.996 Y133.207 E.00862
G1 X137.777 Y133.207 E.02965
G1 X137.793 Y130.79 E.05879
G1 X139.295 Y130.785 E.03653
G1 X139.87 Y130.647 E.01438
G1 X140.202 Y130.465 E.00921
G1 X140.202 Y133.498 E.07377
G1 X140.202 Y133.498 F9000
G1 X139.837 Y132.971
G1 F6000
G1 X139.368 Y132.858 E.01173
G1 X138.152 Y132.841 E.02958
G1 X138.157 Y131.154 E.04103
G1 X139.296 Y131.15 E.02771
G1 X139.837 Y131.041 E.01342
G1 X139.837 Y132.911 E.04549
G1 E-5 F3600
G1 X139.837 Y132.911 F9000
G1 X140.493 Y142.49
G1 E5 F2400
;WIDTH:0.401203
G1 F6000
G1 X140.293 Y142.116 E.01035
;WIDTH:0.399999
G1 X139.906 Y141.776 E.01253
G1 X139.708 Y141.682 E.00533
G1 X139.204 Y141.573 E.01254
G1 X135.507 Y141.564 E.08993
G1 X133.854 Y141.468 E.04028
G1 X133.033 Y141.469 E.01997
G1 X133.705 Y140.962 E.02048
G1 X134.292 Y140.414 E.01953
G1 X135.056 Y139.497 E.02903
G1 X135.481 Y138.864 E.01855
G1 X135.745 Y138.428 E.0124
G1 X139.25 Y138.424 E.08526
G1 X139.722 Y138.314 E.01179
G1 X140.156 Y138.036 E.01254
G1 X140.458 Y137.63 E.01231
G1 X140.568 Y137.315 E.00812
G1 X140.568 Y142.038 E.11488
;WIDTH:0.401203
G1 X140.566 Y142.693 E.01598
G1 X140.545 Y142.588 E.00261
G1 X140.521 Y142.543 E.00124
G1 X140.521 Y142.543 F9000
G1 X140.202 Y141.541
;WIDTH:0.399999
G1 F6000
G1 X139.796 Y141.327 E.01116
G1 X139.205 Y141.207 E.01467
G1 X135.518 Y141.198 E.08968
G1 X134.08 Y141.114 E.03504
G1 X134.573 Y140.649 E.01648
G1 X135.301 Y139.778 E.02761
G1 X135.951 Y138.793 E.02871
G1 X139.251 Y138.79 E.08027
G1 X139.819 Y138.667 E.01414
G1 X140.202 Y138.459 E.0106
G1 X140.202 Y141.481 E.07351
G1 X140.202 Y141.481 F9000
G1 X139.837 Y140.96
G1 F6000
G1 X139.206 Y140.842 E.01561
G1 X135.529 Y140.832 E.08944
G1 X134.926 Y140.797 E.01469
G1 X135.663 Y139.904 E.02816
G1 X136.158 Y139.158 E.02178
G1 X139.251 Y139.156 E.07523
G1 X139.837 Y139.041 E.01453
G1 X139.837 Y140.9 E.04522
G1 E-5 F3600
G1 X139.837 Y140.9 F9000
G1 E5 F2400
;WIDTH:0.635732
G1 F6000
G1 X139.967 Y153.866 E.02234
;WIDTH:0.637744
G1 X139.96 Y153.877 E.00052
G1 E-5 F3600
G1 X139.96 Y153.877 F9000
G1 X139.863 Y153.774
G1 X139.885 Y153.754
G1 X140 Y153.61
G1 X140.094 Y153.455
G1 X140.171 Y153.277
G1 X140.223 Y153.102
G1 X140.249 Y152.935
G1 X140.249 Y151.065
G1 X140.242 Y150.972
G1 X140.237 Y150.896
G1 X139.727 Y147.924
G1 E5 F2400
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X139.232 Y147.429 E.01703
G1 X138.718 Y147.433 E.0125
G1 X139.562 Y148.277 E.02903
G1 X139.562 Y148.613 E.00817
G1 X139.364 Y148.597 E.00483
G1 X138.202 Y147.434 E.03999
G1 X137.685 Y147.434 E.01258
G1 X138.817 Y148.567 E.03896
G1 X138.298 Y148.565 E.01262
G1 X137.168 Y147.435 E.03887
G1 X136.891 Y147.435 E.00674
G1 X136.891 Y147.675 E.00584
G1 X137.78 Y148.564 E.03058
G1 X137.261 Y148.563 E.01262
G1 X136.726 Y148.028 E.0184
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X137.261 Y148.563 E-.35939
G1 X137.78 Y148.564 E-.24653
G1 X136.891 Y147.675 E-.59719
G1 X136.891 Y147.435 E-.114
G1 X137.168 Y147.435 E-.13158
G1 X137.244 Y147.511 E-.05131
;WIPE_END
G1 X135.5 Y140.275 F9000
G1 E5 F2400
G1 F3072.127
G1 X135.772 Y140.547 E.00936
G1 X136.338 Y140.551 E.01377
G1 X135.87 Y140.083 E.0161
G1 X136.098 Y139.748 E.00986
G1 X136.903 Y140.554 E.02771
G1 X137.469 Y140.557 E.01377
G1 X136.345 Y139.433 E.03866
G1 X136.907 Y139.432 E.01367
G1 X138.035 Y140.561 E.03882
G1 X138.601 Y140.564 E.01377
G1 X137.469 Y139.431 E.03896
G1 X138.031 Y139.431 E.01367
G1 X139.167 Y140.567 E.03908
G1 X139.562 Y140.62 E.00969
G1 X139.562 Y140.4 E.00535
G1 X138.593 Y139.43 E.03335
G1 X139.155 Y139.43 E.01367
G1 X139.727 Y140.002 E.01968
G1 E-5 F3600
G1 X139.727 Y140.002 F9000
G1 X140.237 Y137.104
G1 X140.242 Y137.028
G1 X140.249 Y136.935
G1 X140.249 Y135.065
G1 X140.242 Y134.972
G1 X140.237 Y134.896
G1 X139.727 Y132.077
G1 E5 F2400
G1 F3072.127
G1 X139.076 Y131.425 E.02241
G1 X138.462 Y131.427 E.01494
G1 X139.562 Y132.528 E.03786
G1 X139.562 Y132.622 E.00229
G1 X138.997 Y132.578 E.01378
G1 X138.265 Y131.846 E.02518
G1 E-5 F3600
G1 X138.265 Y131.846 F9000
G1 X140.023 Y129.628
G1 X140.122 Y129.47
G1 X140.15 Y129.403
G1 X140.196 Y129.284
G1 X140.237 Y129.104
G1 X140.242 Y129.028
G1 X139.727 Y124.074
G1 E5 F2400
G1 F3072.127
G1 X139.078 Y123.425 E.02233
G1 X138.467 Y123.427 E.01486
G1 X139.563 Y124.523 E.0377
G1 X139.563 Y124.62 E.00236
G1 X138.993 Y124.567 E.01392
G1 X138.272 Y123.847 E.02478
G1 E-5 F3600
G1 X138.272 Y123.847 F9000
G1 X140.122 Y121.47
G1 X140.15 Y121.403
G1 X139.727 Y116.07
G1 E5 F2400
G1 F3072.127
G1 X139.09 Y115.433 E.02191
G1 X138.476 Y115.433 E.01493
G1 X139.563 Y116.52 E.03739
G1 X139.563 Y116.622 E.00248
G1 X139.006 Y116.578 E.01359
G1 X138.272 Y115.845 E.02523
G1 E-5 F3600
G1 X138.272 Y115.845 F9000
G1 X140.122 Y113.47
G1 X140.15 Y113.403
G1 X139.727 Y108.075
G1 E5 F2400
G1 F3072.127
G1 X139.077 Y107.425 E.02236
G1 X138.464 Y107.427 E.01491
G1 X139.563 Y108.526 E.0378
G1 X139.563 Y108.616 E.00219
G1 X138.996 Y108.575 E.01383
G1 X138.272 Y107.851 E.02491
G1 E-5 F3600
G1 X138.272 Y107.851 F9000
G1 X140.122 Y105.47
G1 X140.15 Y105.403
G1 X138.437 Y98.205
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X138.437 Y100.568 E.05748
G1 X139.371 Y100.584 E.02272
G1 X139.563 Y100.622 E.00476
G1 X139.563 Y97.979 E.06429
G1 X139 Y98.022 E.01373
G1 X138.437 Y98.022 E.01369
G1 X138.81 Y98.395 E.01283
;WIDTH:0.414507
G1 X139.19 Y98.395 E.00961
G1 X139.19 Y100.208 E.04585
G1 X138.81 Y100.202 E.00961
G1 X138.81 Y98.578 E.04107
G1 E-5 F3600
G1 X138.81 Y98.578 F9000
G1 X140.112 Y96.1
G1 X140.189 Y95.934
G1 X140.235 Y95.757
G1 X140.241 Y95.697
G1 X140.249 Y95.594
G1 X140.249 Y93.234
G1 X140.241 Y93.132
G1 X140.235 Y93.072
G1 X140.189 Y92.895
G1 X140.112 Y92.728
G1 X140.008 Y92.577
G1 X139.88 Y92.446
G1 X139.73 Y92.339
G1 X139.563 Y92.259
G1 X139.393 Y92.213
G1 X129.061 Y90.707
G1 E5 F2400
;WIDTH:0.489542
G1 F1200
G1 X129.021 Y90.747 E.00171
G1 X129.036 Y90.802 E.00173
G1 X129.091 Y90.816 E.00172
G1 X129.131 Y90.776 E.00171
G1 X129.116 Y90.721 E.00173
;WIDTH:0.399999
G1 X129.701 Y90.806 E.01438
G1 X129.027 Y90.132 E.02319
G1 X128.908 Y89.847 E.00751
;WIDTH:0.374336
G1 X128.919 Y89.888 E.00096
G1 X128.848 Y89.907 E.00166
G1 X128.867 Y89.836 E.00166
G1 X128.867 Y89.836 F9000
G1 X130.218 Y90.806
;WIDTH:0.399999
G1 F1200
G1 X128.777 Y89.366 E.04955
G1 X128.549 Y89.107 E.00839
;WIDTH:0.374336
G1 X127.931 Y88.455 E.02032
G1 X127.619 Y88.158 E.00974
G1 X127.459 Y87.864 E.00757
;WIDTH:0.399999
G1 X127.819 Y87.89 E.00878
G1 X130.735 Y90.806 E.10031
G1 X131.252 Y90.806 E.01258
G1 X128.24 Y87.794 E.10361
G1 X128.642 Y87.679 E.01017
G1 X131.769 Y90.806 E.10757
G1 X132.287 Y90.806 E.0126
G1 X129.023 Y87.543 E.11226
G1 X129.384 Y87.387 E.00957
G1 X132.804 Y90.806 E.11763
G1 X133.321 Y90.806 E.01258
G1 X129.716 Y87.201 E.12401
G1 X130.032 Y87.001 E.0091
G1 X133.838 Y90.806 E.13091
G1 X134.355 Y90.806 E.01258
G1 X130.349 Y86.8 E.1378
G1 X130.635 Y86.569 E.00894
G1 X134.872 Y90.806 E.14575
G1 X135.389 Y90.806 E.01258
G1 X130.908 Y86.325 E.15414
G1 X131.163 Y86.063 E.00889
G1 X135.906 Y90.806 E.16316
G1 X136.424 Y90.806 E.0126
G1 X131.391 Y85.773 E.17313
G1 X131.618 Y85.483 E.00896
G1 X136.941 Y90.806 E.18311
G1 X137.458 Y90.806 E.01258
G1 X131.834 Y85.183 E.19344
G1 X132.02 Y84.852 E.00924
G1 X137.975 Y90.806 E.20483
G1 X138.492 Y90.806 E.01258
G1 X132.197 Y84.512 E.21653
G1 X132.339 Y84.136 E.00978
G1 X139.009 Y90.806 E.22944
G1 X139.563 Y90.843 E.01351
G1 X132.48 Y83.76 E.24365
G1 X132.58 Y83.342 E.01045
G1 X139.563 Y90.326 E.24023
G1 X139.563 Y89.809 E.01258
G1 X132.663 Y82.909 E.23736
G1 X132.711 Y82.44 E.01147
G1 X139.563 Y89.292 E.2357
G1 X139.563 Y88.774 E.0126
G1 X132.737 Y81.948 E.23481
G1 X132.737 Y81.431 E.01258
G1 X139.563 Y88.257 E.23481
G1 X139.563 Y87.74 E.01258
G1 X132.737 Y80.914 E.23481
G1 X132.737 Y80.397 E.01258
G1 X139.563 Y87.223 E.23481
G1 X139.563 Y86.706 E.01258
G1 X132.737 Y79.88 E.23481
G1 X132.956 Y79.581 E.00902
G1 X139.563 Y86.189 E.22729
G1 X139.506 Y85.614 E.01405
G1 X133.222 Y79.331 E.21615
G1 X133.459 Y79.051 E.00892
G1 X139.456 Y85.048 E.20629
G1 X139.455 Y84.529 E.01262
G1 X133.688 Y78.763 E.19836
G1 X133.874 Y78.431 E.00926
G1 X139.454 Y84.011 E.19195
G1 X139.453 Y83.493 E.0126
G1 X133.998 Y78.038 E.18765
G1 X134.082 Y77.605 E.01073
G1 X139.451 Y82.974 E.18469
G1 X139.45 Y82.456 E.0126
G1 X134.014 Y77.02 E.18699
G1 X134.014 Y77.02 F9000
G1 X133.298 Y75.896
;WIDTH:0.374336
G1 F1200
G1 X133.279 Y75.967 E.00166
G1 X133.35 Y75.948 E.00166
G1 X133.339 Y75.907 E.00096
;WIDTH:0.399999
G1 X133.559 Y76.048 E.00636
G1 X139.449 Y81.938 E.20261
G1 X139.448 Y81.419 E.01262
G1 X134.076 Y76.048 E.18478
G1 X134.593 Y76.048 E.01258
G1 X139.447 Y80.901 E.16696
G1 X139.445 Y80.383 E.0126
G1 X135.111 Y76.048 E.1491
G1 X135.638 Y76.059 E.01282
G1 X139.44 Y79.86 E.13077
G1 X139.378 Y79.281 E.01416
G1 X136.217 Y76.12 E.10874
G1 X136.682 Y76.143 E.01132
;WIDTH:0.374336
G1 X136.663 Y76.215 E.00168
G1 X136.734 Y76.196 E.00166
G1 X136.723 Y76.154 E.00098
;WIDTH:0.399999
G1 X136.952 Y76.338 E.00715
G1 X139.181 Y78.567 E.07668
G1 X139.366 Y78.792 E.00709
;WIDTH:0.374336
G1 X139.377 Y78.834 E.00098
G1 X139.306 Y78.853 E.00166
G1 X139.325 Y78.781 E.00168
G1 X139.325 Y78.781 F9000
G1 X138.763 Y77.694
G1 F1200
G1 X138.433 Y77.326 E.01118
G1 X137.737 Y76.68 E.02148
G1 E-5 F3600
G1 X137.737 Y76.68 F9000
G1 X130.1 Y85.181
G1 X130.063 Y85.218
G1 X129.879 Y85.398
G1 X129.84 Y85.432
G1 X129.641 Y85.602
G1 X129.427 Y85.761
G1 X129.386 Y85.791
G1 X129.159 Y85.937
G1 X129.116 Y85.964
G1 X128.879 Y86.095
G1 X128.833 Y86.119
G1 X128.599 Y86.227
G1 X128.553 Y86.247
G1 X128.311 Y86.34
G1 X128.264 Y86.356
G1 X128.017 Y86.433
G1 X127.969 Y86.445
G1 X127.718 Y86.505
G1 X127.669 Y86.514
G1 X127.414 Y86.557
G1 X127.364 Y86.563
G1 X127.107 Y86.588
G1 X127.057 Y86.59
G1 X126.809 Y86.599
G1 X105.162 Y86.599
G1 X91.46 Y90.77
G1 E5 F2400
;WIDTH:0.473004
G1 F1200
G1 X91.421 Y90.809 E.00161
G1 X91.435 Y90.862 E.0016
G1 X91.488 Y90.876 E.0016
G1 X91.527 Y90.837 E.00161
G1 X91.513 Y90.784 E.0016
;WIDTH:0.399999
G1 X92.026 Y90.806 E.01249
G1 X91.438 Y90.218 E.02023
G1 X91.438 Y89.701 E.01258
G1 X92.543 Y90.806 E.03801
G1 X93.06 Y90.806 E.01258
G1 X91.437 Y89.183 E.05583
G1 X91.437 Y88.666 E.01258
G1 X93.577 Y90.806 E.07361
G1 X94.094 Y90.806 E.01258
G1 X91.437 Y88.149 E.0914
G1 X91.437 Y87.632 E.01258
G1 X94.612 Y90.806 E.1092
G1 X95.129 Y90.806 E.01258
G1 X91.437 Y87.115 E.12699
G1 X91.437 Y86.597 E.0126
G1 X95.646 Y90.806 E.14479
G1 X96.163 Y90.806 E.01258
G1 X91.437 Y86.08 E.16257
G1 X91.485 Y85.611 E.01147
G1 X96.68 Y90.806 E.1787
G1 X97.197 Y90.806 E.01258
G1 X91.547 Y85.155 E.19437
G1 X91.546 Y84.638 E.01258
G1 X97.714 Y90.806 E.21218
G1 X98.232 Y90.806 E.0126
G1 X91.546 Y84.121 E.22998
G1 X91.546 Y83.604 E.01258
G1 X98.749 Y90.806 E.24776
G1 X99.266 Y90.806 E.01258
G1 X91.546 Y83.086 E.26556
G1 X91.546 Y82.569 E.01258
G1 X99.783 Y90.806 E.28335
G1 X100.3 Y90.806 E.01258
G1 X91.546 Y82.052 E.30113
G1 X91.545 Y81.534 E.0126
G1 X100.817 Y90.806 E.31895
G1 X101.334 Y90.806 E.01258
G1 X91.545 Y81.017 E.33674
G1 X91.545 Y80.5 E.01258
G1 X101.851 Y90.806 E.35452
G1 X102.066 Y90.864 E.00542
;WIDTH:0.374336
G1 X102.047 Y90.935 E.00166
G1 X102.118 Y90.916 E.00166
G1 X102.107 Y90.875 E.00096
;WIDTH:0.399999
G1 X101.966 Y90.403 E.01198
G1 X91.549 Y79.987 E.35832
G1 X91.581 Y79.501 E.01185
G1 X102.002 Y89.923 E.35849
G1 X102.137 Y89.54 E.00988
G1 X91.663 Y79.067 E.36028
G1 X91.786 Y78.672 E.01006
G1 X102.329 Y89.215 E.36267
G1 X102.55 Y88.92 E.00897
G1 X91.938 Y78.307 E.36506
G1 X92.118 Y77.97 E.00929
G1 X98.97 Y84.822 E.2357
G1 X99.172 Y85.081 E.00799
;WIDTH:0.374336
G1 X99.698 Y85.722 E.01875
G1 X100.482 Y86.509 E.02512
G1 X101.166 Y87.087 E.02025
;WIDTH:0.399999
G1 X101.425 Y87.277 E.00781
G1 X102.798 Y88.65 E.04723
G1 X103.066 Y88.401 E.0089
G1 X102.336 Y87.671 E.02511
G1 X102.108 Y87.483 E.00719
;WIDTH:0.374336
G1 X102.119 Y87.524 E.00096
G1 X102.048 Y87.543 E.00166
G1 X102.067 Y87.472 E.00166
G1 X102.067 Y87.472 F9000
G1 X103.038 Y87.855
;WIDTH:0.399999
G1 F1200
G1 X103.334 Y88.151 E.01018
G1 X103.538 Y87.858 E.00868
;WIDTH:0.374336
G1 X103.549 Y87.899 E.00096
G1 X103.478 Y87.918 E.00166
G1 X103.497 Y87.847 E.00166
G1 E-5 F3600
G1 X103.497 Y87.847 F9000
G1 X98.785 Y84.161
G1 E5 F2400
G1 F1200
G1 X98.796 Y84.202 E.00096
G1 X98.724 Y84.221 E.00168
G1 X98.744 Y84.15 E.00167
;WIDTH:0.399999
G1 X98.597 Y83.932 E.0064
G1 X92.323 Y77.658 E.21582
G1 X92.553 Y77.371 E.00895
G1 X98.382 Y83.2 E.20051
G1 X98.526 Y83.415 E.00629
;WIDTH:0.374336
G1 X98.506 Y83.486 E.00167
G1 X98.578 Y83.467 E.00168
G1 X98.567 Y83.426 E.00096
G1 X98.567 Y83.426 F9000
G1 X98.304 Y82.604
;WIDTH:0.399999
G1 F1200
G1 X92.812 Y77.113 E.1889
G1 X93.092 Y76.876 E.00892
G1 X98.275 Y82.058 E.17827
G1 X98.273 Y81.539 E.01262
G1 X93.395 Y76.661 E.1678
G1 X93.723 Y76.472 E.00921
G1 X98.271 Y81.02 E.15645
G1 X98.269 Y80.501 E.01262
G1 X94.084 Y76.317 E.14394
G1 X94.476 Y76.191 E.01002
G1 X98.267 Y79.982 E.13041
G1 X98.381 Y79.74 E.00651
;WIDTH:0.374336
G1 X97.547 Y78.902 E.02674
G1 X97.242 Y78.517 E.01111
;WIDTH:0.399999
G1 X97.061 Y78.259 E.00767
G1 X94.904 Y76.101 E.07422
G1 X95.381 Y76.061 E.01164
G1 X96.921 Y77.601 E.05297
G1 X96.962 Y77.125 E.01162
G1 X95.887 Y76.051 E.03696
G1 X96.398 Y76.044 E.01243
G1 X97.072 Y76.718 E.02319
G1 X97.245 Y76.374 E.00937
G1 X96.915 Y76.044 E.01135
G1 X97.436 Y76.005 E.01271
;WIDTH:0.41383
G1 X97.415 Y76.085 E.00209
G1 X97.494 Y76.063 E.00207
G1 X97.482 Y76.018 E.00118
G1 E-5 F3600
G1 X97.482 Y76.018 F9000
G1 X90.812 Y92.895
G1 X90.765 Y93.072
G1 X90.76 Y93.132
G1 X90.751 Y93.234
G1 X90.751 Y95.594
G1 X90.76 Y95.697
G1 X90.765 Y95.757
G1 X91.439 Y100.615
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X91.439 Y97.982 E.06405
G1 X92.001 Y98.022 E.0137
G1 X92.563 Y98.022 E.01367
G1 X92.563 Y100.573 E.06205
G1 X92.003 Y100.574 E.01362
G1 X91.622 Y100.602 E.00929
G1 X91.812 Y100.203 E.01075
;WIDTH:0.413565
G1 X91.811 Y98.395 E.04561
G1 X92.191 Y98.395 E.00959
G1 X92.191 Y100.201 E.04556
;WIDTH:0.413452
G1 X91.994 Y100.202 E.00497
G1 E-5 F3600
G1 X91.994 Y100.202 F9000
G1 X90.878 Y102.53
G1 X90.85 Y102.597
G1 X90.804 Y102.716
G1 X90.763 Y102.896
G1 X90.758 Y102.972
G1 X90.751 Y103.065
G1 X90.751 Y104.935
G1 X90.758 Y105.028
G1 X90.763 Y105.104
G1 X91.276 Y107.93
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X91.913 Y108.567 E.02191
G1 X92.527 Y108.567 E.01493
G1 X91.44 Y107.48 E.03739
G1 X91.44 Y107.389 E.00221
G1 X92.007 Y107.433 E.01383
G1 X92.728 Y108.153 E.02478
G1 E-5 F3600
G1 X92.728 Y108.153 F9000
G1 X90.977 Y110.372
G1 X90.878 Y110.53
G1 X90.85 Y110.597
G1 X90.804 Y110.716
G1 X90.763 Y110.896
G1 X90.758 Y110.972
G1 X90.751 Y111.065
G1 X90.751 Y112.935
G1 X90.758 Y113.028
G1 X90.763 Y113.104
G1 X91.277 Y115.928
G1 E5 F2400
G1 F3072.127
G1 X91.916 Y116.567 E.02198
G1 X92.531 Y116.567 E.01496
G1 X91.442 Y115.478 E.03746
G1 X91.442 Y115.385 E.00226
G1 X92.004 Y115.425 E.0137
G1 X92.728 Y116.149 E.02491
G1 E-5 F3600
G1 X92.728 Y116.149 F9000
G1 X90.977 Y118.372
G1 X90.878 Y118.53
G1 X90.85 Y118.597
G1 X90.804 Y118.716
G1 X90.763 Y118.896
G1 X90.758 Y118.972
G1 X90.751 Y119.065
G1 X90.751 Y120.935
G1 X90.758 Y121.028
G1 X90.763 Y121.104
G1 X91.278 Y123.929
G1 E5 F2400
G1 F3072.127
G1 X91.917 Y124.567 E.02196
G1 X92.531 Y124.567 E.01493
G1 X91.443 Y123.479 E.03743
G1 X91.443 Y123.385 E.00229
G1 X92.004 Y123.425 E.01368
G1 X92.728 Y124.149 E.02491
G1 E-5 F3600
G1 X92.728 Y124.149 F9000
G1 X90.977 Y126.372
G1 X90.878 Y126.53
G1 X90.85 Y126.597
G1 X90.804 Y126.716
G1 X90.763 Y126.896
G1 X90.758 Y126.972
G1 X90.751 Y127.065
G1 X90.751 Y128.935
G1 X90.758 Y129.028
G1 X90.763 Y129.104
G1 X91.28 Y131.927
G1 E5 F2400
G1 F3072.127
G1 X91.92 Y132.567 E.02202
G1 X92.535 Y132.567 E.01496
G1 X91.444 Y131.476 E.03753
G1 X91.444 Y131.385 E.00221
G1 X92.009 Y131.425 E.01378
G1 X92.736 Y132.153 E.02503
G1 E-5 F3600
G1 X92.736 Y132.153 F9000
G1 X90.977 Y134.372
G1 X90.878 Y134.53
G1 X90.85 Y134.597
G1 X90.804 Y134.716
G1 X90.763 Y134.896
G1 X90.758 Y134.972
G1 X90.751 Y135.065
G1 X90.751 Y136.935
G1 X90.758 Y137.028
G1 X90.763 Y137.104
G1 X90.804 Y137.284
G1 X90.85 Y137.403
G1 X90.878 Y137.47
G1 X90.977 Y137.628
G1 X91.102 Y137.768
G1 X91.252 Y137.884
G1 X95.33 Y140.074
G1 E5 F2400
G1 F3072.127
G1 X94.688 Y139.433 E.02207
G1 X94.12 Y139.432 E.01382
G1 X95.251 Y140.563 E.03891
G1 X94.684 Y140.564 E.01379
G1 X93.552 Y139.431 E.03896
G1 X92.984 Y139.431 E.01382
G1 X94.117 Y140.565 E.03899
G1 X93.55 Y140.565 E.01379
G1 X92.415 Y139.43 E.03904
G1 X91.847 Y139.43 E.01382
G1 X92.983 Y140.566 E.03908
G1 X92.417 Y140.567 E.01377
G1 X91.451 Y139.601 E.03323
G1 X91.448 Y140.166 E.01374
G1 X92.014 Y140.732 E.01947
G1 E-5 F3600
G1 X92.014 Y140.732 F9000
G1 X90.977 Y142.372
G1 X90.878 Y142.53
G1 X90.85 Y142.597
G1 X90.804 Y142.716
G1 X90.763 Y142.896
G1 X90.758 Y142.972
G1 X90.751 Y143.065
G1 X90.751 Y144.935
G1 X90.758 Y145.028
G1 X90.763 Y145.104
G1 X90.804 Y145.284
G1 X90.85 Y145.403
G1 X90.878 Y145.47
G1 X90.977 Y145.628
G1 X91.102 Y145.768
G1 X91.252 Y145.884
G1 X94.475 Y147.621
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X94.475 Y148.564 E.02294
G1 X95.241 Y148.563 E.01863
G1 X96.948 Y148.47 E.04158
G1 X105.427 Y148.463 E.20624
G1 X105.012 Y148.049 E.01426
G1 X104.96 Y147.942 E.00289
G1 X105.012 Y147.79 E.00391
G1 X105.119 Y147.669 E.00393
G1 X105.165 Y147.535 E.00345
G1 X97.148 Y147.537 E.19501
G1 X95.369 Y147.44 E.04334
G1 X94.475 Y147.438 E.02175
G1 X94.847 Y147.812 E.01283
;WIDTH:0.413447
G1 X95.364 Y147.811 E.01304
;WIDTH:0.40949
G1 X96.259 Y147.835 E.02234
;WIDTH:0.407524
G1 X96.324 Y147.862 E.00175
;WIDTH:0.454588
G1 X96.39 Y147.89 E.002
;WIDTH:0.501652
G1 X96.455 Y147.917 E.00219
;WIDTH:0.548716
G1 X96.52 Y147.944 E.00241
;WIDTH:0.59578
G1 X96.585 Y147.971 E.00263
;WIDTH:0.642844
G1 X96.65 Y147.998 E.00285
G1 X96.585 Y148.025 E.00285
;WIDTH:0.59578
G1 X96.52 Y148.052 E.00263
;WIDTH:0.548716
G1 X96.455 Y148.08 E.00242
;WIDTH:0.501652
G1 X96.39 Y148.107 E.00219
;WIDTH:0.454588
G1 X96.324 Y148.134 E.00199
;WIDTH:0.407524
G1 X96.259 Y148.161 E.00175
;WIDTH:0.40949
G1 X95.364 Y148.185 E.02234
;WIDTH:0.413447
G1 X94.847 Y148.191 E.01304
G1 X94.847 Y147.994 E.00497
G1 X94.847 Y147.994 F9000
G1 X96.65 Y147.998
;WIDTH:0.642844
G1 F1200
G1 X97.148 Y148.003 E.02016
;WIDTH:0.6006
G1 X104.499 Y148 E.2769
G1 X104.499 Y148 F9000
G1 X105.4 Y147.92
;WIDTH:0.399999
G1 F1200
G1 X105.97 Y148.49 E.01961
G1 X106.259 Y148.605 E.00757
;WIDTH:0.374336
G1 X106.27 Y148.646 E.00096
G1 X106.198 Y148.665 E.00168
G1 X106.218 Y148.594 E.00167
;WIDTH:0.399999
G1 X106.833 Y148.835 E.01607
G1 X105.532 Y147.535 E.04474
G1 E-5 F3600
G1 X105.532 Y147.535 F9000
G1 X107.353 Y154.549
G1 E5 F2400
;WIDTH:0.488074
G1 F1200
G1 X107.313 Y154.589 E.00171
G1 X107.328 Y154.644 E.00172
G1 X107.383 Y154.659 E.00172
G1 X107.423 Y154.619 E.00171
G1 X107.408 Y154.564 E.00172
;WIDTH:0.399999
G1 X107.541 Y154.197 E.0095
G1 X108.121 Y154.763 E.01971
;WIDTH:0.374336
G1 X108.102 Y154.834 E.00166
G1 X108.173 Y154.815 E.00166
G1 X108.162 Y154.774 E.00096
;WIDTH:0.399999
G1 X108.508 Y154.648 E.00896
G1 X107.627 Y153.767 E.03031
G1 X107.649 Y153.272 E.01205
G1 X109.025 Y154.648 E.04733
G1 X109.543 Y154.648 E.0126
G1 X107.648 Y152.753 E.06519
G1 X107.646 Y152.235 E.0126
G1 X110.06 Y154.648 E.08302
G1 X110.577 Y154.648 E.01258
G1 X107.645 Y151.716 E.10086
G1 X107.643 Y151.197 E.01262
G1 X111.094 Y154.648 E.11871
G1 X111.611 Y154.648 E.01258
G1 X107.642 Y150.679 E.13653
G1 X107.635 Y150.155 E.01275
G1 X112.128 Y154.648 E.15456
G1 X112.645 Y154.648 E.01258
G1 X107.343 Y149.346 E.18239
G1 E-5 F3600
G1 X107.343 Y149.346 F9000
G1 X106.019 Y147.504
G1 E5 F2400
G1 F1200
G1 X113.162 Y154.648 E.24573
G1 X113.679 Y154.648 E.01258
G1 X106.416 Y147.385 E.24984
G1 X106.769 Y147.22 E.00948
G1 X114.197 Y154.648 E.25552
G1 X114.714 Y154.648 E.01258
G1 X107.05 Y146.984 E.26364
G1 X107.291 Y146.708 E.00891
G1 X115.231 Y154.648 E.27313
G1 X115.748 Y154.648 E.01258
G1 X107.481 Y146.381 E.28438
G1 X107.605 Y145.988 E.01002
G1 X116.265 Y154.648 E.2979
G1 X116.782 Y154.648 E.01258
G1 X107.651 Y145.516 E.31412
G1 X107.653 Y145.001 E.01253
G1 X117.299 Y154.648 E.33183
G1 X117.816 Y154.648 E.01258
G1 X107.82 Y144.651 E.34387
G1 X107.596 Y144.533 E.00616
;WIDTH:0.374336
G1 X107.607 Y144.574 E.00096
G1 X107.536 Y144.593 E.00166
G1 X107.555 Y144.522 E.00166
G1 X107.555 Y144.522 F9000
G1 X108.337 Y144.651
;WIDTH:0.399999
G1 F1200
G1 X118.333 Y154.648 E.34387
G1 X118.851 Y154.648 E.0126
G1 X108.854 Y144.651 E.34389
G1 X109.371 Y144.651 E.01258
G1 X119.368 Y154.648 E.34389
G1 X119.885 Y154.648 E.01258
G1 X109.888 Y144.651 E.34389
G1 X110.405 Y144.651 E.01258
G1 X120.402 Y154.648 E.34389
G1 X120.919 Y154.648 E.01258
G1 X110.922 Y144.651 E.34389
G1 X111.439 Y144.651 E.01258
G1 X121.436 Y154.648 E.34389
G1 X121.953 Y154.648 E.01258
G1 X111.956 Y144.651 E.34389
G1 X112.473 Y144.651 E.01258
G1 X122.47 Y154.648 E.34389
G1 X122.987 Y154.648 E.01258
G1 X112.99 Y144.651 E.34389
G1 X113.508 Y144.651 E.0126
G1 X123.505 Y154.648 E.34389
G1 X123.773 Y154.679 E.00656
;WIDTH:0.374336
G1 X123.593 Y154.128 E.01311
;WIDTH:0.399999
G1 X123.418 Y154.044 E.00472
G1 X114.025 Y144.651 E.32311
G1 X114.542 Y144.65 E.01258
G1 X123.35 Y153.459 E.30301
G1 X123.351 Y152.943 E.01255
G1 X115.059 Y144.65 E.28526
G1 X115.576 Y144.65 E.01258
G1 X123.353 Y152.427 E.26752
G1 X123.354 Y151.912 E.01253
G1 X116.093 Y144.65 E.24979
G1 X116.61 Y144.65 E.01258
G1 X123.356 Y151.396 E.23206
G1 X123.357 Y150.88 E.01255
G1 X117.127 Y144.65 E.21431
G1 X117.644 Y144.65 E.01258
G1 X123.358 Y150.364 E.19656
G1 X123.42 Y149.909 E.01117
G1 X118.161 Y144.65 E.18091
G1 X118.678 Y144.65 E.01258
G1 X123.557 Y149.528 E.16782
G1 X123.768 Y149.223 E.00902
G1 X119.195 Y144.65 E.15731
G1 X119.712 Y144.65 E.01258
G1 X124.009 Y148.946 E.1478
G1 X124.31 Y148.731 E.009
G1 X120.229 Y144.65 E.14038
G1 X120.746 Y144.65 E.01258
G1 X124.673 Y148.576 E.13507
G1 X125.097 Y148.483 E.01056
G1 X121.263 Y144.65 E.13187
G1 X121.78 Y144.649 E.01258
G1 X123.54 Y146.409 E.06054
G1 X123.739 Y146.667 E.00793
;WIDTH:0.374336
G1 X123.853 Y146.812 E.00417
G1 X124.239 Y147.158 E.01172
;WIDTH:0.399999
G1 X124.498 Y147.367 E.0081
G1 X125.596 Y148.465 E.03777
G1 X125.83 Y147.664 F9000
G1 F1200
G1 X125.978 Y147.813 E.00511
G1 X126.031 Y147.958 E.00376
G1 X125.903 Y148.146 E.00553
G1 X125.907 Y148.465 E.00776
G1 X133.574 Y148.466 E.18649
G1 X134.31 Y148.479 E.01791
G1 X135.605 Y148.558 E.03156
G1 X136.525 Y148.561 E.02238
G1 X136.525 Y147.436 E.02736
G1 X135.763 Y147.437 E.01853
G1 X133.882 Y147.536 E.04582
G1 X125.7 Y147.535 E.19902
G1 X125.59 Y147.942 E.01026
G1 X125.174 Y147.525 E.01433
G1 X125.174 Y147.525 F9000
G1 X126.494 Y148
;WIDTH:0.59849
G1 F1200
G1 X133.571 Y148.002 E.26558
;WIDTH:0.633296
G1 X134.318 Y147.996 E.02976
;WIDTH:0.642302
G1 X134.403 Y147.996 E.00344
G1 X134.459 Y148.02 E.00246
;WIDTH:0.601824
G1 X134.515 Y148.044 E.0023
;WIDTH:0.561345
G1 X134.571 Y148.068 E.00214
;WIDTH:0.520866
G1 X134.627 Y148.091 E.00196
;WIDTH:0.480923
G1 X134.682 Y148.114 E.00177
;WIDTH:0.44098
G1 X134.737 Y148.138 E.00162
;WIDTH:0.401037
G1 X134.793 Y148.161 E.00148
;WIDTH:0.408714
G1 X135.628 Y148.188 E.02081
;WIDTH:0.412931
G1 X136.153 Y148.188 E.01322
G1 X136.153 Y147.808 E.00957
G1 X135.629 Y147.814 E.0132
;WIDTH:0.408714
G1 X134.794 Y147.835 E.0208
;WIDTH:0.407962
G1 X134.729 Y147.862 E.00175
;WIDTH:0.45483
G1 X134.664 Y147.889 E.00197
;WIDTH:0.501698
G1 X134.599 Y147.916 E.00219
;WIDTH:0.548566
G1 X134.533 Y147.943 E.00244
;WIDTH:0.595434
G1 X134.468 Y147.969 E.00261
;WIDTH:0.642302
G1 X134.403 Y147.996 E.00285
G1 E-5 F3600
G1 X134.403 Y147.996 F9000
G1 X123.365 Y145.717
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X122.298 Y144.649 E.03672
G1 X122.815 Y144.649 E.01258
G1 X123.35 Y145.185 E.01842
G1 X123.378 Y144.621 E.01374
;WIDTH:0.41082
G1 X123.39 Y144.667 E.00119
G1 X123.311 Y144.688 E.00205
G1 X123.333 Y144.609 E.00205
G1 E-5 F3600
G1 X123.333 Y144.609 F9000
G1 X94.274 Y148.063
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X93.647 Y147.437 E.02155
G1 X93.067 Y147.435 E.01411
G1 X94.109 Y148.478 E.03586
G1 X94.109 Y148.565 E.00212
G1 X93.618 Y148.565 E.01194
G1 X92.487 Y147.434 E.03891
G1 X91.907 Y147.433 E.01411
G1 X93.04 Y148.566 E.03897
G1 X92.462 Y148.567 E.01406
G1 X91.447 Y147.552 E.03492
G1 X91.447 Y148.13 E.01406
G1 X92.048 Y148.732 E.02069
;LAYER_CHANGE
;Z:2.06
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;2.06
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X91.447 Y148.13 E-.40406
G1 X91.447 Y147.552 E-.27455
G1 X92.462 Y148.567 E-.68183
G1 X92.756 Y148.566 E-.13956
;WIPE_END
G1 Z2.06 F9000
;AFTER_LAYER_CHANGE
;2.06
G1 Z2.06
G1 X95.824 Y146.29
G1 X105.06 Y139.436
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X105.075 Y139.465 E.00079
G1 X105.183 Y139.5 E.00276
G1 X125.817 Y139.5 E.5019
G1 X125.908 Y139.476 E.00229
G1 X125.993 Y139.366 E.00338
G1 X126 Y138.954 E.01002
G1 X126.49 Y138.507 E.01613
G1 X126.841 Y138.147 E.01223
G1 X127.063 Y137.843 E.00916
G1 X127.161 Y137.461 E.00959
G1 X127.026 Y137.096 E.00947
G1 X126.529 Y136.531 E.0183
G1 X126 Y136.047 E.01744
G1 X126 Y134.669 E.03352
G1 X126.092 Y133.992 E.01662
G1 X126.138 Y133.483 E.01243
G1 X126.169 Y132.81 E.01639
G1 X126.169 Y99.319 E.81464
G1 X126.135 Y98.445 E.02128
G1 X126.081 Y97.896 E.01342
G1 X126 Y97.347 E.0135
G1 X126 Y93.309 E.09822
G1 X126.036 Y93.245 E.00179
G1 X138.834 Y93.245 E.3113
G1 X139.092 Y93.292 E.00638
G1 X139.202 Y93.409 E.00391
G1 X139.25 Y93.662 E.00626
G1 X139.241 Y95.285 E.03948
G1 X139.13 Y95.512 E.00615
G1 X138.932 Y95.584 E.00512
G1 X136.183 Y95.586 E.06687
G1 X136.074 Y95.623 E.0028
G1 X136 Y95.769 E.00398
G1 X136 Y132.295 E.88846
G1 X135.955 Y133.235 E.02289
G1 X135.824 Y134.15 E.02248
G1 X135.602 Y135.064 E.02288
G1 X135.298 Y135.943 E.02262
G1 X134.689 Y137.197 E.03391
G1 X134.183 Y137.985 E.02278
G1 X133.295 Y139.06 E.03392
G1 X132.618 Y139.706 E.02276
G1 X131.502 Y140.542 E.03392
G1 X130.69 Y141.011 E.02281
G1 X129.843 Y141.398 E.02265
G1 X128.516 Y141.822 E.03389
G1 X127.594 Y142 E.02284
G1 X126.666 Y142.089 E.02268
G1 X120.645 Y142.1 E.14646
G1 X120.276 Y142.25 E.00969
G1 X110.755 Y142.25 E.23159
G1 X110.355 Y142.1 E.01039
G1 X104.806 Y142.1 E.13497
G1 X103.403 Y142 E.03421
G1 X102.481 Y141.822 E.02284
G1 X101.596 Y141.562 E.02244
G1 X100.3 Y141.006 E.0343
G1 X99.504 Y140.546 E.02236
G1 X98.375 Y139.7 E.03432
G1 X97.709 Y139.065 E.02238
G1 X96.812 Y137.978 E.03428
G1 X96.314 Y137.204 E.02239
G1 X95.699 Y135.935 E.0343
G1 X95.398 Y135.066 E.02237
G1 X95.099 Y133.696 E.03411
G1 X95.01 Y132.758 E.02292
G1 X94.999 Y95.769 E.89972
G1 X94.926 Y95.622 E.00399
G1 X94.816 Y95.586 E.00282
G1 X92.926 Y95.584 E.04597
G1 X91.996 Y95.561 E.02263
G1 X91.845 Y95.469 E.0043
G1 X91.758 Y95.305 E.00452
G1 X91.758 Y93.523 E.04335
G1 X91.864 Y93.32 E.00557
G1 X92.068 Y93.245 E.00529
G1 X104.935 Y93.243 E.31298
G1 X105 Y93.283 E.00186
G1 X105 Y95.547 E.05507
G1 X104.881 Y95.673 E.00422
G1 X104.831 Y95.798 E.00327
G1 X104.832 Y132.818 E.90047
G1 X104.874 Y133.746 E.0226
G1 X105 Y134.669 E.02266
G1 X105 Y136.047 E.03352
G1 X104.457 Y136.546 E.01794
G1 X103.974 Y137.096 E.0178
G1 X103.848 Y137.417 E.00839
G1 X103.907 Y137.78 E.00895
G1 X104.159 Y138.147 E.01083
G1 X104.518 Y138.514 E.01249
G1 X105 Y138.954 E.01587
G1 X105 Y139.317 E.00883
G1 X105.033 Y139.382 E.00177
G1 X105.033 Y139.382 F9000
G1 X103.807 Y138.277
;TYPE:Perimeter
G1 F6000
G1 X102.783 Y138.252 E.02492
G1 X102.783 Y136.541 E.04162
G1 X102.808 Y135.94 E.01463
G1 X102.882 Y135.441 E.01227
G1 X103.014 Y134.976 E.01176
G1 X104.634 Y134.976 E.0394
G1 X104.634 Y135.887 E.02216
G1 X104.182 Y136.305 E.01498
G1 X103.681 Y136.878 E.01851
G1 X103.485 Y137.382 E.01315
G1 X103.561 Y137.896 E.01264
G1 X103.775 Y138.226 E.00957
G1 E-5 F3600
G1 X103.775 Y138.226 F9000
G1 X103.773 Y138.228
G1 X103.684 Y138.103
G1 X103.612 Y137.981
G1 X103.555 Y137.855
G1 X103.514 Y137.724
G1 X103.492 Y137.588
G1 X103.489 Y137.448
G1 X103.507 Y137.31
G1 X103.543 Y137.178
G1 X103.596 Y137.053
G1 X103.655 Y136.943
G1 X103.726 Y136.836
G1 X103.809 Y136.727
G1 X103.908 Y136.61
G1 X104.041 Y136.467
G1 X104.225 Y136.284
G1 X104.39 Y136.129
G1 X104.132 Y135.854
G1 E5 F2400
G1 F6000
G1 X103.906 Y136.064 E.0075
G1 X103.489 Y136.541 E.01541
G1 X103.303 Y136.811 E.00798
G1 X103.151 Y137.261 E.01155
;WIDTH:0.378451
G1 X103.128 Y137.444 E.00422
G1 X103.138 Y137.258 E.00426
;WIDTH:0.399999
G1 X103.149 Y136.402 E.02082
G1 X103.243 Y135.497 E.02213
G1 X103.287 Y135.341 E.00394
G1 X104.269 Y135.341 E.02389
G1 X104.269 Y135.726 E.00936
G1 X104.175 Y135.813 E.00312
G1 X104.175 Y135.813 F9000
G1 X103.682 Y135.757
;WIDTH:0.500464
G1 F6000
G1 X103.653 Y135.808 E.00182
G1 X103.594 Y135.808 E.00183
G1 X103.565 Y135.757 E.00182
G1 X103.594 Y135.707 E.00179
G1 X103.653 Y135.707 E.00183
G1 E-5 F3600
G1 X103.653 Y135.707 F9000
G1 X103.168 Y137.891
G1 E5 F2400
;WIDTH:0.43857
G1 F6000
G1 X103.148 Y137.668 E.00602
;WIDTH:0.399123
G1 X103.128 Y137.444 E.00546
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.148 Y137.668 E-.10682
G1 X103.168 Y137.891 E-.10635
;WIPE_END
G1 E-1.28683 F3600
G1 X103.531 Y137.777 F9000
G1 X105.219 Y137.924
G1 X108.19 Y137.972
G1 X122.809 Y138.207
G1 X125.431 Y138.249
G1 X127.183 Y138.281
G1 X127.179 Y138.277
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X127.353 Y138.066 E.00665
G1 X127.51 Y137.615 E.01162
G1 X127.507 Y137.347 E.00652
G1 X127.332 Y136.905 E.01156
G1 X127.237 Y136.783 E.00376
G1 X126.776 Y136.261 E.01694
G1 X126.366 Y135.886 E.01352
G1 X126.366 Y134.976 E.02213
G1 X127.986 Y134.976 E.0394
G1 X128.1 Y135.355 E.00963
G1 X128.184 Y135.868 E.01264
G1 X128.217 Y136.398 E.01292
G1 X128.213 Y138.277 E.0457
G1 X127.239 Y138.277 E.02369
G1 X127.239 Y138.277 F9000
G1 X127.861 Y137.329
;WIDTH:0.409042
G1 F6000
G1 X127.844 Y137.61 E.00702
;WIDTH:0.441116
G1 X127.827 Y137.891 E.00762
G1 E-5 F3600
G1 X127.827 Y137.891 F9000
G1 X126.731 Y135.725
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X126.731 Y135.341 E.00934
G1 X127.714 Y135.341 E.02391
G1 X127.827 Y135.963 E.01538
G1 X127.861 Y137.329 E.03324
;WIDTH:0.387895
G1 X127.824 Y137.146 E.00439
;WIDTH:0.399999
G1 X127.575 Y136.613 E.01431
G1 X127.221 Y136.212 E.01301
G1 X126.774 Y135.767 E.01534
G1 X126.774 Y135.767 F9000
G1 X127.433 Y135.757
;WIDTH:0.500058
G1 F6000
G1 X127.403 Y135.807 E.00181
G1 X127.345 Y135.807 E.0018
G1 X127.316 Y135.757 E.00179
G1 X127.345 Y135.707 E.00179
G1 X127.403 Y135.707 E.0018
G1 E-5 F3600
G1 X127.403 Y135.707 F9000
G1 X126.366 Y96.802
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X126.366 Y93.611 E.07762
G1 X138.845 Y93.611 E.30354
G1 X138.885 Y93.661 E.00156
G1 X138.873 Y95.203 E.03751
G1 X136.183 Y95.22 E.06543
G1 X135.906 Y95.303 E.00703
G1 X135.701 Y95.516 E.00719
G1 X135.635 Y95.769 E.00636
G1 X135.635 Y96.806 E.02522
G1 X126.426 Y96.802 E.224
G1 X126.426 Y96.802 F9000
G1 X126.82 Y96.437
G1 F6000
G1 X126.731 Y96.437 E.00216
G1 X126.731 Y93.976 E.05986
G1 X138.519 Y93.976 E.28673
G1 X138.517 Y94.844 E.02111
G1 X136.183 Y94.855 E.05677
G1 X135.79 Y94.956 E.00987
G1 X135.531 Y95.14 E.00773
G1 X135.313 Y95.499 E.01022
G1 X135.269 Y95.769 E.00665
G1 X135.269 Y96.44 E.01632
G1 X126.88 Y96.437 E.20405
G1 E-5 F3600
G1 X126.88 Y96.437 F9000
G1 X136.011 Y94.423
G1 E5 F2400
;WIDTH:0.56199
G1 F6000
G1 X136.182 Y94.415 E.00601
;WIDTH:0.547022
G1 X138.072 Y94.415 E.06446
;WIDTH:0.545424
G1 X138.08 Y94.415 E.00027
G1 E-5 F3600
G1 X138.08 Y94.415 F9000
G1 X127.829 Y96.071
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X127.097 Y96.071 E.01781
G1 X127.097 Y94.342 E.04206
G1 X134.961 Y94.342 E.19128
;WIDTH:0.406222
G1 X135.631 Y94.345 E.01657
;WIDTH:0.445164
G1 X135.726 Y94.364 E.00265
;WIDTH:0.484106
G1 X135.821 Y94.384 E.0029
;WIDTH:0.523048
G1 X135.916 Y94.403 E.00315
;WIDTH:0.56199
G1 X136.011 Y94.423 E.00341
G1 X135.927 Y94.469 E.00336
;WIDTH:0.523048
G1 X135.842 Y94.515 E.00314
;WIDTH:0.484106
G1 X135.758 Y94.56 E.00285
;WIDTH:0.445164
G1 X135.673 Y94.606 E.00264
;WIDTH:0.406222
G1 X135.242 Y94.915 E.01312
;WIDTH:0.399999
G1 X135.124 Y95.067 E.00468
G1 X134.957 Y95.412 E.00932
G1 X134.921 Y95.59 E.00442
G1 X134.903 Y96.074 E.01178
G1 X127.889 Y96.071 E.17061
G1 X127.889 Y96.071 F9000
G1 X127.713 Y95.706
G1 F6000
G1 X127.463 Y95.706 E.00608
G1 X127.463 Y94.708 E.02428
G1 X134.94 Y94.708 E.18187
G1 X134.835 Y94.843 E.00416
G1 X134.602 Y95.326 E.01304
G1 X134.544 Y95.708 E.0094
G1 X127.773 Y95.706 E.1647
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X127.713 Y95.706 E-.0285
G1 X127.463 Y95.706 E-.11875
G1 X127.463 Y94.708 E-.47405
G1 X129.313 Y94.708 E-.8787
;WIPE_END
G1 X126.349 Y94.576 F9000
G1 X104.651 Y93.609
G1 X104.634 Y93.609
G1 E5 F2400
G1 F6000
G1 X104.634 Y95.411 E.04383
G1 X104.536 Y95.536 E.00386
G1 X104.466 Y95.798 E.0066
G1 X104.466 Y96.803 E.02445
G1 X95.365 Y96.812 E.22137
G1 X95.365 Y95.769 E.02537
G1 X95.298 Y95.516 E.00637
G1 X95.094 Y95.303 E.00717
G1 X94.817 Y95.22 E.00703
G1 X92.136 Y95.21 E.06521
G1 X92.123 Y94.413 E.01939
G1 X92.123 Y93.621 E.01926
G1 X104.574 Y93.609 E.30286
G1 X104.574 Y93.609 F9000
G1 X104.269 Y93.975
G1 F6000
G1 X104.269 Y95.252 E.03106
G1 X104.179 Y95.426 E.00477
G1 X104.1 Y95.798 E.00925
G1 X104.1 Y96.437 E.01554
G1 X95.731 Y96.444 E.20357
G1 X95.73 Y95.768 E.01644
G1 X95.687 Y95.498 E.00665
G1 X95.469 Y95.14 E.0102
G1 X95.209 Y94.956 E.00775
G1 X94.817 Y94.855 E.00985
G1 X92.496 Y94.853 E.05646
G1 X92.489 Y94.41 E.01078
G1 X92.489 Y93.982 E.01041
G1 X104.209 Y93.975 E.28508
G1 E-5 F3600
G1 X104.209 Y93.975 F9000
G1 X92.927 Y94.415
G1 E5 F2400
;WIDTH:0.54553
G1 F6000
G1 X92.934 Y94.415 E.00024
;WIDTH:0.547342
G1 X94.817 Y94.415 E.06426
;WIDTH:0.573472
G1 X94.978 Y94.428 E.00579
;WIDTH:0.599602
G1 X95.138 Y94.441 E.00604
G1 E-5 F3600
G1 X95.138 Y94.441 F9000
G1 X103.484 Y96.071
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X96.096 Y96.077 E.17971
G1 X96.096 Y95.768 E.00752
G1 X96.05 Y95.449 E.00784
G1 X95.875 Y95.067 E.01022
G1 X95.757 Y94.915 E.00468
;WIDTH:0.4499
G1 X95.602 Y94.797 E.00539
;WIDTH:0.499801
G1 X95.448 Y94.678 E.00603
;WIDTH:0.549702
G1 X95.293 Y94.56 E.00668
;WIDTH:0.599602
G1 X95.138 Y94.441 E.00735
G1 X95.215 Y94.422 E.00298
;WIDTH:0.560658
G1 X95.292 Y94.402 E.00279
;WIDTH:0.521714
G1 X95.369 Y94.383 E.00257
;WIDTH:0.48277
G1 X95.703 Y94.362 E.00998
;WIDTH:0.441385
G1 X96.038 Y94.341 E.00909
;WIDTH:0.399999
G1 X103.903 Y94.341 E.19131
G1 X103.903 Y95.181 E.02043
G1 X103.845 Y95.277 E.00273
G1 X103.754 Y95.608 E.00835
G1 X103.734 Y96.071 E.01127
G1 X103.544 Y96.071 E.00462
G1 X103.544 Y96.071 F9000
G1 X103.387 Y95.652
G1 F6000
G1 X103.378 Y95.705 E.00131
G1 X96.456 Y95.709 E.16837
G1 X96.397 Y95.325 E.00945
G1 X96.164 Y94.842 E.01304
G1 X96.059 Y94.707 E.00416
G1 X103.537 Y94.706 E.18189
G1 X103.537 Y95.006 E.0073
G1 X103.441 Y95.33 E.00822
G1 X103.397 Y95.593 E.00649
G1 E-5 F3600
G1 X103.397 Y95.593 F9000
G1 X96.883 Y95.003
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.443417
G1 F1200
G1 X102.98 Y95.002 E.16591
;WIDTH:0.442448
G1 X103.222 Y95.002 E.00657
G1 X103.241 Y95.028 E.00087
G1 X103.134 Y95.41 E.01077
G1 X102.98 Y95.41 E.00418
;WIDTH:0.443417
G1 X96.714 Y95.412 E.17051
G1 X96.688 Y95.273 E.00385
G1 X96.566 Y95.003 E.00806
G1 X96.7 Y95.003 E.00365
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X96.566 Y95.003 E-.06365
G1 X96.688 Y95.273 E-.14073
G1 X96.714 Y95.412 E-.06717
G1 X99.3 Y95.411 E-1.22845
;WIPE_END
G1 X104.651 Y95.349 F9000
G1 X126.349 Y95.097
G1 X134.434 Y95.003
G1 E5 F2400
;WIDTH:0.443179
G1 F1200
G1 X134.328 Y95.223 E.00664
G1 X134.285 Y95.412 E.00527
G1 X127.758 Y95.41 E.17751
;WIDTH:0.442071
G1 X127.758 Y95.003 E.01104
;WIDTH:0.443149
G1 X134.251 Y95.003 E.17657
G1 E-5 F3600
G1 X134.251 Y95.003 F9000
G1 X131.741 Y140.226
G1 E5 F2400
;TYPE:Top solid infill
;WIDTH:0.400344
G1 F900
G1 X133.094 Y138.872 E.0466
G1 X133.961 Y137.823 E.03313
G1 X134.449 Y137.062 E.02201
G1 X134.508 Y136.941 E.00328
G1 X130.844 Y140.605 E.12616
G1 X130.564 Y140.767 E.00788
G1 X129.829 Y141.103 E.01968
G1 X134.997 Y135.935 E.17794
G1 X135.292 Y135.122 E.02106
G1 X129.051 Y141.363 E.21489
G1 X128.448 Y141.556 E.01541
G1 X128.314 Y141.582 E.00332
G1 X135.476 Y134.42 E.2466
G1 X135.554 Y134.098 E.00807
G1 X135.6 Y133.779 E.00785
G1 X127.673 Y141.706 E.27294
G1 X127.088 Y141.773 E.01434
G1 X135.683 Y133.178 E.29594
G1 X135.709 Y132.634 E.01326
G1 X126.528 Y141.815 E.31612
G1 X126.01 Y141.816 E.01261
G1 X135.726 Y132.1 E.33454
G1 X135.726 Y131.582 E.01261
G1 X125.491 Y141.817 E.35241
G1 X124.973 Y141.818 E.01261
G1 X135.726 Y131.065 E.37025
G1 X135.726 Y130.547 E.01261
G1 X128.491 Y137.781 E.2491
G1 X128.491 Y137.264 E.01259
G1 X135.726 Y130.029 E.24911
G1 X135.726 Y129.512 E.01259
G1 X128.491 Y136.746 E.2491
G1 X128.484 Y136.236 E.01242
G1 X135.726 Y128.994 E.24936
G1 X135.726 Y128.477 E.01259
G1 X128.443 Y135.76 E.25077
G1 X128.372 Y135.312 E.01104
G1 X135.726 Y127.959 E.25319
G1 X135.726 Y127.441 E.01261
G1 X128.265 Y134.902 E.2569
G1 X128.213 Y134.701 E.00505
G1 X127.948 Y134.701 E.00645
G1 X135.726 Y126.924 E.26779
G1 X135.726 Y126.406 E.01261
G1 X127.43 Y134.701 E.28563
G1 X126.913 Y134.701 E.01259
G1 X135.726 Y125.888 E.30345
G1 X135.726 Y125.371 E.01259
G1 X126.395 Y134.702 E.32128
G1 X126.272 Y134.702 E.00299
G1 X126.334 Y134.245 E.01123
G1 X135.726 Y124.853 E.32338
G1 X135.726 Y124.336 E.01259
G1 X126.405 Y133.657 E.32094
G1 X126.429 Y133.115 E.01321
G1 X135.726 Y123.818 E.32011
G1 X135.726 Y123.3 E.01261
G1 X126.443 Y132.583 E.31963
G1 X126.443 Y132.066 E.01259
G1 X135.726 Y122.783 E.31963
G1 X135.726 Y122.265 E.01261
G1 X126.443 Y131.548 E.31963
G1 X126.443 Y131.03 E.01261
G1 X135.726 Y121.747 E.31963
G1 X135.726 Y121.23 E.01259
G1 X126.443 Y130.513 E.31963
G1 X126.443 Y129.995 E.01261
G1 X135.726 Y120.712 E.31963
G1 X135.726 Y120.195 E.01259
G1 X126.443 Y129.478 E.31963
G1 X126.443 Y128.96 E.01261
G1 X135.726 Y119.677 E.31963
G1 X135.726 Y119.159 E.01261
G1 X126.443 Y128.442 E.31963
G1 X126.443 Y127.925 E.01259
G1 X135.726 Y118.642 E.31963
G1 X135.726 Y118.124 E.01261
G1 X126.443 Y127.407 E.31963
G1 X126.443 Y126.89 E.01259
G1 X135.726 Y117.606 E.31965
G1 X135.726 Y117.089 E.01259
G1 X126.443 Y126.372 E.31963
G1 X126.443 Y125.854 E.01261
G1 X135.726 Y116.571 E.31963
G1 X135.726 Y116.054 E.01259
G1 X126.443 Y125.337 E.31963
G1 X126.443 Y124.819 E.01261
G1 X135.726 Y115.536 E.31963
G1 X135.726 Y115.018 E.01261
G1 X126.443 Y124.301 E.31963
G1 X126.443 Y123.784 E.01259
G1 X135.726 Y114.501 E.31963
G1 X135.726 Y113.983 E.01261
G1 X126.443 Y123.266 E.31963
G1 X126.443 Y122.749 E.01259
G1 X135.726 Y113.466 E.31963
G1 X135.726 Y112.948 E.01261
G1 X126.443 Y122.231 E.31963
G1 X126.443 Y121.713 E.01261
G1 X135.726 Y112.43 E.31963
G1 X135.726 Y111.913 E.01259
G1 X126.443 Y121.196 E.31963
G1 X126.443 Y120.678 E.01261
G1 X135.726 Y111.395 E.31963
G1 X135.726 Y110.877 E.01261
G1 X126.443 Y120.161 E.31965
G1 X126.443 Y119.643 E.01261
G1 X135.726 Y110.36 E.31963
G1 X135.726 Y109.842 E.01261
G1 X126.443 Y119.125 E.31963
G1 X126.443 Y118.608 E.01259
G1 X135.726 Y109.325 E.31963
G1 X135.726 Y108.807 E.01261
G1 X126.443 Y118.09 E.31963
G1 X126.443 Y117.572 E.01261
G1 X135.726 Y108.289 E.31963
G1 X135.726 Y107.772 E.01259
G1 X126.443 Y117.055 E.31963
G1 X126.443 Y116.537 E.01261
G1 X135.726 Y107.254 E.31963
G1 X135.726 Y106.736 E.01261
G1 X126.443 Y116.02 E.31965
G1 X126.443 Y115.502 E.01261
G1 X135.726 Y106.219 E.31963
G1 X135.726 Y105.701 E.01261
G1 X126.443 Y114.984 E.31963
G1 X126.443 Y114.467 E.01259
G1 X135.726 Y105.184 E.31963
G1 X135.726 Y104.666 E.01261
G1 X126.443 Y113.949 E.31963
G1 X126.443 Y113.432 E.01259
G1 X135.726 Y104.148 E.31965
G1 X135.726 Y103.631 E.01259
G1 X126.443 Y112.914 E.31963
G1 X126.443 Y112.396 E.01261
G1 X135.726 Y103.113 E.31963
G1 X135.726 Y102.596 E.01259
G1 X126.443 Y111.879 E.31963
G1 X126.443 Y111.361 E.01261
G1 X135.726 Y102.078 E.31963
G1 X135.726 Y101.56 E.01261
G1 X126.443 Y110.844 E.31965
G1 X126.443 Y110.326 E.01261
G1 X135.726 Y101.043 E.31963
G1 X135.726 Y100.525 E.01261
G1 X126.443 Y109.808 E.31963
G1 X126.443 Y109.291 E.01259
G1 X135.726 Y100.007 E.31965
G1 X135.726 Y99.49 E.01259
G1 X126.443 Y108.773 E.31963
G1 X126.443 Y108.255 E.01261
G1 X135.726 Y98.972 E.31963
G1 X135.726 Y98.455 E.01259
G1 X126.443 Y107.738 E.31963
G1 X126.443 Y107.22 E.01261
G1 X135.726 Y97.937 E.31963
G1 X135.726 Y97.419 E.01261
G1 X126.443 Y106.703 E.31965
G1 X126.443 Y106.185 E.01261
G1 X135.548 Y97.08 E.3135
G1 X135.031 Y97.08 E.01259
G1 X126.443 Y105.667 E.29568
G1 X126.443 Y105.15 E.01259
G1 X134.513 Y97.079 E.27788
G1 X133.996 Y97.079 E.01259
G1 X126.443 Y104.632 E.26006
G1 X126.443 Y104.115 E.01259
G1 X133.478 Y97.079 E.24224
G1 X132.961 Y97.079 E.01259
G1 X126.443 Y103.597 E.22443
G1 X126.443 Y103.079 E.01261
G1 X132.444 Y97.079 E.20661
G1 X131.926 Y97.078 E.01261
G1 X126.443 Y102.562 E.18881
G1 X126.443 Y102.044 E.01261
G1 X131.409 Y97.078 E.17099
G1 X130.891 Y97.078 E.01261
G1 X126.443 Y101.526 E.15315
G1 X126.443 Y101.009 E.01259
G1 X130.374 Y97.078 E.13535
G1 X129.856 Y97.078 E.01261
G1 X126.443 Y100.491 E.11752
G1 X126.443 Y99.974 E.01259
G1 X129.339 Y97.078 E.09971
G1 X128.822 Y97.077 E.01259
G1 X126.443 Y99.456 E.08191
G1 X126.429 Y98.952 E.01228
G1 X128.304 Y97.077 E.06456
G1 X127.787 Y97.077 E.01259
G1 X126.41 Y98.453 E.0474
G1 X126.365 Y97.981 E.01154
G1 X127.269 Y97.077 E.03113
G1 X126.752 Y97.077 E.01259
G1 X126.158 Y97.67 E.02044
G1 E-5 F3600
G1 X126.158 Y97.67 F9000
G1 X127.888 Y138.385
G1 E5 F2400
G1 F900
G1 X124.454 Y141.819 E.11824
G1 X123.935 Y141.82 E.01264
G1 X127.369 Y138.386 E.11824
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X125.136 Y140.619 E-1.5
;WIPE_END
G1 X125.628 Y139.61 F9000
G1 E5 F2400
G1 F900
G1 X123.417 Y141.821 E.07613
G1 X122.898 Y141.822 E.01264
G1 X124.946 Y139.774 E.07052
G1 X124.428 Y139.774 E.01261
G1 X122.38 Y141.823 E.07053
G1 X121.861 Y141.824 E.01264
G1 X123.91 Y139.774 E.07057
G1 X123.393 Y139.774 E.01259
G1 X121.342 Y141.825 E.07062
G1 X120.824 Y141.826 E.01261
G1 X122.875 Y139.774 E.07064
G1 X122.358 Y139.774 E.01259
G1 X120.156 Y141.976 E.07582
G1 X119.638 Y141.976 E.01261
G1 X121.84 Y139.774 E.07582
G1 X121.322 Y139.774 E.01261
G1 X119.121 Y141.976 E.0758
G1 X118.603 Y141.976 E.01261
G1 X120.805 Y139.774 E.07582
G1 X120.287 Y139.774 E.01261
G1 X118.085 Y141.976 E.07582
G1 X117.568 Y141.976 E.01259
G1 X119.77 Y139.774 E.07582
G1 X119.252 Y139.774 E.01261
G1 X117.05 Y141.976 E.07582
G1 X116.533 Y141.976 E.01259
G1 X118.734 Y139.774 E.0758
G1 X118.217 Y139.774 E.01259
G1 X116.015 Y141.976 E.07582
G1 X115.497 Y141.976 E.01261
G1 X117.699 Y139.774 E.07582
G1 X117.181 Y139.774 E.01261
G1 X114.98 Y141.976 E.0758
G1 X114.462 Y141.976 E.01261
G1 X116.664 Y139.774 E.07582
G1 X116.146 Y139.774 E.01261
G1 X113.945 Y141.976 E.0758
G1 X113.427 Y141.976 E.01261
G1 X115.629 Y139.774 E.07582
G1 X115.111 Y139.774 E.01261
G1 X112.909 Y141.976 E.07582
G1 X112.392 Y141.976 E.01259
G1 X114.593 Y139.774 E.0758
G1 X114.076 Y139.774 E.01259
G1 X111.874 Y141.976 E.07582
G1 X111.356 Y141.976 E.01261
G1 X113.558 Y139.774 E.07582
G1 X113.041 Y139.774 E.01259
G1 X110.839 Y141.976 E.07582
G1 X110.717 Y141.971 E.00297
G1 X110.546 Y141.867 E.00487
G1 X110.452 Y141.846 E.00235
G1 X112.523 Y139.774 E.07133
G1 X112.005 Y139.774 E.01261
G1 X109.954 Y141.826 E.07064
G1 X109.436 Y141.826 E.01261
G1 X111.488 Y139.774 E.07065
G1 X110.97 Y139.774 E.01261
G1 X108.918 Y141.826 E.07065
G1 X108.401 Y141.826 E.01259
G1 X110.453 Y139.774 E.07065
G1 X109.935 Y139.774 E.01261
G1 X107.883 Y141.826 E.07065
G1 X107.366 Y141.826 E.01259
G1 X109.417 Y139.774 E.07064
G1 X108.9 Y139.774 E.01259
G1 X106.848 Y141.826 E.07065
G1 X106.33 Y141.826 E.01261
G1 X108.382 Y139.774 E.07065
G1 X107.864 Y139.774 E.01261
G1 X105.813 Y141.826 E.07064
G1 X105.295 Y141.826 E.01261
G1 X107.347 Y139.774 E.07065
G1 X106.829 Y139.774 E.01261
G1 X104.78 Y141.823 E.07055
G1 X104.297 Y141.789 E.01179
G1 X106.312 Y139.774 E.06938
G1 X105.794 Y139.774 E.01261
G1 X103.814 Y141.754 E.06817
G1 X103.439 Y141.728 E.00915
G1 X103.342 Y141.709 E.00241
G1 X105.276 Y139.774 E.06661
G1 X105.078 Y139.763 E.00483
G1 X104.914 Y139.689 E.00438
G1 X104.88 Y139.653 E.00121
G1 X102.908 Y141.625 E.0679
G1 X102.48 Y141.536 E.01064
G1 X104.732 Y139.284 E.07754
G1 X104.727 Y139.075 E.00509
G1 X104.571 Y138.927 E.00524
G1 X102.08 Y141.418 E.08577
G1 X101.681 Y141.3 E.01013
G1 X104.304 Y138.676 E.09033
G1 X104.173 Y138.551 E.00441
G1 X103.911 Y138.551 E.00638
G1 X101.318 Y141.144 E.08928
G1 X100.956 Y140.989 E.00959
G1 X103.394 Y138.551 E.08394
G1 X102.876 Y138.551 E.01261
G1 X100.594 Y140.834 E.07859
G1 X100.25 Y140.66 E.00939
G1 X102.508 Y138.402 E.07775
G1 X102.51 Y137.882 E.01266
G1 X99.921 Y140.471 E.08914
G1 X99.599 Y140.275 E.00918
G1 X102.512 Y137.363 E.10028
G1 X102.513 Y136.844 E.01264
G1 X99.303 Y140.053 E.11051
G1 X99.008 Y139.832 E.00897
G1 X102.515 Y136.324 E.12077
G1 X102.553 Y135.768 E.01357
G1 X98.594 Y139.728 E.13633
G1 E-5 F3600
G1 X98.594 Y139.728 F9000
G1 X104.491 Y134.866
G1 E5 F2400
G1 F900
G1 X104.719 Y134.638 E.00785
G1 X104.657 Y134.182 E.0112
G1 X104.138 Y134.701 E.01787
G1 X103.62 Y134.701 E.01261
G1 X104.598 Y133.723 E.03367
G1 X104.576 Y133.228 E.01206
G1 X103.103 Y134.701 E.05072
G1 X102.787 Y134.701 E.00769
G1 X102.675 Y135.129 E.01077
G1 X98.43 Y139.374 E.14616
G1 X98.165 Y139.121 E.00892
G1 X104.557 Y132.729 E.22009
G1 X104.557 Y132.212 E.01259
G1 X97.901 Y138.867 E.22916
G1 X97.667 Y138.584 E.00894
G1 X104.557 Y131.694 E.23724
G1 X104.557 Y131.176 E.01261
G1 X97.433 Y138.3 E.24529
G1 X97.199 Y138.017 E.00894
G1 X104.557 Y130.659 E.25335
G1 X104.557 Y130.141 E.01261
G1 X96.975 Y137.724 E.26108
G1 X96.772 Y137.409 E.00912
G1 X104.557 Y129.624 E.26805
G1 X104.557 Y129.106 E.01261
G1 X96.57 Y137.094 E.27502
G1 X96.398 Y136.748 E.00941
G1 X104.557 Y128.588 E.28095
G1 X104.557 Y128.071 E.01259
G1 X96.229 Y136.399 E.28675
G1 X96.06 Y136.051 E.00942
G1 X104.557 Y127.553 E.29258
G1 X104.557 Y127.036 E.01259
G1 X95.904 Y135.689 E.29794
G1 X95.771 Y135.305 E.00989
G1 X104.557 Y126.518 E.30253
G1 X104.557 Y126 E.01261
G1 X95.645 Y134.912 E.30686
G1 X95.552 Y134.487 E.01059
G1 X104.557 Y125.483 E.31004
G1 X104.557 Y124.965 E.01261
G1 X95.46 Y134.062 E.31323
G1 X95.369 Y133.636 E.01061
G1 X104.557 Y124.448 E.31636
G1 X104.557 Y123.93 E.01261
G1 X95.324 Y133.163 E.31791
G1 X95.284 Y132.685 E.01168
G1 X104.557 Y123.412 E.31929
G1 X104.557 Y122.895 E.01259
G1 X95.284 Y132.168 E.31929
G1 X95.284 Y131.65 E.01261
G1 X104.557 Y122.377 E.31929
G1 X104.557 Y121.859 E.01261
G1 X95.284 Y131.133 E.3193
G1 X95.284 Y130.615 E.01261
G1 X104.557 Y121.342 E.31929
G1 X104.557 Y120.824 E.01261
G1 X95.283 Y130.098 E.31932
G1 X95.283 Y129.58 E.01261
G1 X104.557 Y120.307 E.3193
G1 X104.557 Y119.789 E.01261
G1 X95.283 Y129.063 E.31932
G1 X95.283 Y128.545 E.01261
G1 X104.557 Y119.271 E.31932
G1 X104.557 Y118.754 E.01259
G1 X95.283 Y128.028 E.31932
G1 X95.283 Y127.511 E.01259
G1 X104.557 Y118.236 E.31934
G1 X104.557 Y117.719 E.01259
G1 X95.283 Y126.993 E.31932
G1 X95.282 Y126.476 E.01259
G1 X104.557 Y117.201 E.31935
G1 X104.557 Y116.683 E.01261
G1 X95.282 Y125.958 E.31935
G1 X95.282 Y125.441 E.01259
G1 X104.557 Y116.166 E.31935
G1 X104.557 Y115.648 E.01261
G1 X95.282 Y124.923 E.31935
G1 X95.282 Y124.406 E.01259
G1 X104.557 Y115.13 E.31937
G1 X104.557 Y114.613 E.01259
G1 X95.282 Y123.888 E.31935
G1 X95.281 Y123.371 E.01259
G1 X104.557 Y114.095 E.31939
G1 X104.557 Y113.578 E.01259
G1 X95.281 Y122.853 E.31937
G1 X95.281 Y122.336 E.01259
G1 X104.557 Y113.06 E.31939
G1 X104.557 Y112.542 E.01261
G1 X95.281 Y121.818 E.31939
G1 X95.281 Y121.301 E.01259
G1 X104.557 Y112.025 E.31939
G1 X104.557 Y111.507 E.01261
G1 X95.281 Y120.784 E.31941
G1 X95.281 Y120.266 E.01261
G1 X104.557 Y110.99 E.31939
G1 X104.557 Y110.472 E.01261
G1 X95.28 Y119.749 E.31942
G1 X95.28 Y119.231 E.01261
G1 X104.557 Y109.954 E.31942
G1 X104.557 Y109.437 E.01259
G1 X95.28 Y118.714 E.31942
G1 X95.28 Y118.196 E.01261
G1 X104.557 Y108.919 E.31942
G1 X104.557 Y108.401 E.01261
G1 X95.28 Y117.679 E.31944
G1 X95.28 Y117.161 E.01261
G1 X104.557 Y107.884 E.31942
G1 X104.557 Y107.366 E.01261
G1 X95.279 Y116.644 E.31946
G1 X95.279 Y116.126 E.01261
G1 X104.557 Y106.849 E.31944
G1 X104.557 Y106.331 E.01261
G1 X95.279 Y115.609 E.31946
G1 X95.279 Y115.092 E.01259
G1 X104.557 Y105.813 E.31948
G1 X104.557 Y105.296 E.01259
G1 X95.279 Y114.574 E.31946
G1 X95.279 Y114.057 E.01259
G1 X104.557 Y104.778 E.31948
G1 X104.557 Y104.261 E.01259
G1 X95.279 Y113.539 E.31946
G1 X95.278 Y113.022 E.01259
G1 X104.557 Y103.743 E.31949
G1 X104.557 Y103.225 E.01261
G1 X95.278 Y112.504 E.31949
G1 X95.278 Y111.987 E.01259
G1 X104.557 Y102.708 E.31949
G1 X104.557 Y102.19 E.01261
G1 X95.278 Y111.469 E.31949
G1 X95.278 Y110.952 E.01259
G1 X104.557 Y101.673 E.31949
G1 X104.557 Y101.155 E.01261
G1 X95.278 Y110.434 E.31949
G1 X95.277 Y109.917 E.01259
G1 X104.557 Y100.637 E.31953
G1 X104.557 Y100.12 E.01259
G1 X95.277 Y109.399 E.31951
G1 X95.277 Y108.882 E.01259
G1 X104.557 Y99.602 E.31953
G1 X104.557 Y99.084 E.01261
G1 X95.277 Y108.365 E.31954
G1 X95.277 Y107.847 E.01261
G1 X104.557 Y98.567 E.31953
G1 X104.557 Y98.049 E.01261
G1 X95.277 Y107.33 E.31954
G1 X95.277 Y106.812 E.01261
G1 X104.557 Y97.532 E.31953
G1 X104.557 Y97.077 E.01108
G1 X104.494 Y97.077 E.00153
G1 X95.276 Y106.295 E.31739
G1 X95.276 Y105.777 E.01261
G1 X103.976 Y97.078 E.29954
G1 X103.458 Y97.078 E.01261
G1 X95.276 Y105.26 E.28172
G1 X95.276 Y104.742 E.01261
G1 X102.94 Y97.079 E.26387
G1 X102.421 Y97.079 E.01264
G1 X95.276 Y104.225 E.24603
G1 X95.276 Y103.707 E.01261
G1 X101.903 Y97.08 E.22818
G1 X101.385 Y97.08 E.01261
G1 X95.275 Y103.19 E.21038
G1 X95.275 Y102.672 E.01261
G1 X100.867 Y97.081 E.19253
G1 X100.349 Y97.082 E.01261
G1 X95.275 Y102.155 E.17469
G1 X95.275 Y101.638 E.01259
G1 X99.83 Y97.082 E.15685
G1 X99.312 Y97.083 E.01261
G1 X95.275 Y101.12 E.139
G1 X95.275 Y100.603 E.01259
G1 X98.794 Y97.083 E.12118
G1 X98.276 Y97.084 E.01261
G1 X95.275 Y100.085 E.10333
G1 X95.274 Y99.568 E.01259
G1 X97.758 Y97.084 E.08553
G1 X97.24 Y97.085 E.01261
G1 X95.274 Y99.05 E.06768
G1 X95.274 Y98.533 E.01259
G1 X96.721 Y97.086 E.04982
G1 X96.203 Y97.086 E.01261
G1 X95.274 Y98.015 E.03199
G1 X95.274 Y97.498 E.01259
G1 X95.85 Y96.922 E.01983
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X95.274 Y97.498 E-.38693
G1 X95.274 Y98.015 E-.24557
G1 X96.203 Y97.086 E-.62406
G1 X96.716 Y97.086 E-.24344
;WIPE_END
G1 X111.357 Y108.963 F9000
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X111.51 Y108.778 E.00584
G1 X111.942 Y108.411 E.01379
G1 X112.41 Y108.138 E.01318
G1 X112.942 Y107.942 E.01379
G1 X113.768 Y107.831 E.02027
G1 X117.494 Y107.843 E.09063
G1 X117.802 Y107.884 E.00756
G1 X118.295 Y108.015 E.01241
G1 X118.797 Y108.247 E.01345
G1 X119.462 Y108.749 E.02027
G1 X119.835 Y109.195 E.01414
G1 X121.708 Y112.416 E.09063
G1 X121.936 Y112.904 E.0131
G1 X122.118 Y113.706 E.02
G1 X122.122 Y114.255 E.01335
G1 X122.029 Y114.801 E.01347
G1 X121.843 Y115.323 E.01348
G1 X119.836 Y118.805 E.09776
G1 X119.282 Y119.414 E.02003
G1 X118.824 Y119.739 E.01366
G1 X118.334 Y119.97 E.01318
G1 X117.8 Y120.117 E.01347
G1 X117.233 Y120.169 E.01385
G1 X113.767 Y120.169 E.08431
G1 X113.244 Y120.124 E.01277
G1 X112.695 Y119.981 E.0138
G1 X112.203 Y119.755 E.01317
G1 X111.737 Y119.431 E.01381
G1 X111.164 Y118.805 E.02064
G1 X109.292 Y115.584 E.09062
G1 X109.064 Y115.096 E.0131
G1 X108.918 Y114.561 E.01349
G1 X108.868 Y114.009 E.01348
G1 X108.913 Y113.47 E.01316
G1 X109.053 Y112.934 E.01348
G1 X109.292 Y112.416 E.01388
G1 X111.165 Y109.195 E.09063
G1 X111.318 Y109.009 E.00586
G1 E-5 F3600
G1 X111.318 Y109.009 F9000
G1 X112.598 Y105.936
G1 E5 F2400
G1 F6000
G1 X112.203 Y105.755 E.01057
G1 X111.737 Y105.431 E.01381
G1 X111.164 Y104.805 E.02064
G1 X109.292 Y101.584 E.09062
G1 X109.064 Y101.096 E.0131
G1 X108.918 Y100.561 E.01349
G1 X108.868 Y100.009 E.01348
G1 X108.913 Y99.47 E.01316
G1 X109.053 Y98.934 E.01348
G1 X109.292 Y98.416 E.01388
G1 X111.165 Y95.195 E.09063
G1 X111.51 Y94.778 E.01316
G1 X111.942 Y94.411 E.01379
G1 X112.41 Y94.138 E.01318
G1 X112.942 Y93.942 E.01379
G1 X113.768 Y93.831 E.02027
G1 X117.494 Y93.843 E.09063
G1 X117.8 Y93.883 E.00751
G1 X118.293 Y94.015 E.01241
G1 X118.808 Y94.252 E.01379
G1 X119.453 Y94.742 E.0197
G1 X119.835 Y95.195 E.01441
G1 X121.708 Y98.416 E.09063
G1 X121.936 Y98.904 E.0131
G1 X122.118 Y99.706 E.02
G1 X122.122 Y100.255 E.01335
G1 X122.029 Y100.801 E.01347
G1 X121.843 Y101.323 E.01348
G1 X119.836 Y104.805 E.09776
G1 X119.282 Y105.414 E.02003
G1 X118.824 Y105.739 E.01366
G1 X118.334 Y105.97 E.01318
G1 X117.8 Y106.117 E.01347
G1 X117.233 Y106.169 E.01385
G1 X113.767 Y106.169 E.08431
G1 X113.244 Y106.124 E.01277
G1 X112.695 Y105.981 E.0138
G1 X112.652 Y105.961 E.00115
G1 E-5 F3600
G1 X113.501 Y121.867 F9000
G1 E5 F2400
G1 F6000
G1 X113.768 Y121.831 E.00655
G1 X117.494 Y121.843 E.09063
G1 X117.802 Y121.884 E.00756
G1 X118.295 Y122.015 E.01241
G1 X118.797 Y122.247 E.01345
G1 X119.453 Y122.742 E.01999
G1 X119.835 Y123.195 E.01441
G1 X121.708 Y126.416 E.09063
G1 X121.936 Y126.904 E.0131
G1 X122.118 Y127.706 E.02
G1 X122.122 Y128.255 E.01335
G1 X122.029 Y128.801 E.01347
G1 X121.843 Y129.323 E.01348
G1 X119.836 Y132.805 E.09776
G1 X119.253 Y133.44 E.02097
G1 X118.835 Y133.732 E.0124
G1 X118.335 Y133.97 E.01347
G1 X117.8 Y134.117 E.0135
G1 X117.249 Y134.168 E.01346
G1 X113.767 Y134.169 E.0847
G1 X113.244 Y134.124 E.01277
G1 X112.695 Y133.981 E.0138
G1 X112.203 Y133.755 E.01317
G1 X111.737 Y133.431 E.01381
G1 X111.164 Y132.805 E.02064
G1 X109.292 Y129.584 E.09062
G1 X109.064 Y129.096 E.0131
G1 X108.913 Y128.53 E.01425
G1 X108.868 Y128.009 E.01272
G1 X108.913 Y127.47 E.01316
G1 X109.053 Y126.934 E.01348
G1 X109.292 Y126.416 E.01388
G1 X111.165 Y123.195 E.09063
G1 X111.51 Y122.778 E.01316
G1 X111.942 Y122.411 E.01379
G1 X112.41 Y122.138 E.01318
G1 X112.942 Y121.942 E.01379
G1 X113.441 Y121.875 E.01225
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.501 Y121.867 E-.02875
G1 X113.768 Y121.831 E-.12797
G1 X116.596 Y121.84 E-1.34328
;WIPE_END
G1 X106.79 Y134.705 F9000
G1 X106.099 Y134.707
G1 X106.099 Y136.11
G1 X105.719 Y136.11
G1 E5 F2400
G1 F6000
G1 X105.75 Y136.041 E.00184
G1 X105.75 Y91.959 E1.07225
G1 X105.689 Y91.823 E.00363
G1 X105.131 Y91.321 E.01826
G1 X104.776 Y90.959 E.01233
G1 X104.496 Y90.588 E.01131
G1 X104.495 Y90.423 E.00401
G1 X104.74 Y90.066 E.01053
G1 X105.649 Y89.2 E.03054
G1 X124.839 Y89.2 E.46678
G1 X125.36 Y89.22 E.01268
G1 X125.909 Y89.717 E.01801
G1 X126.296 Y90.117 E.01354
G1 X126.513 Y90.483 E.01035
G1 X126.517 Y90.541 E.00141
G1 X126.359 Y90.82 E.0078
G1 X125.897 Y91.296 E.01614
G1 X125.311 Y91.823 E.01917
G1 X125.25 Y91.959 E.00363
G1 X125.25 Y136.041 E1.07225
G1 X125.311 Y136.177 E.00363
G1 X125.869 Y136.679 E.01826
G1 X126.224 Y137.041 E.01233
G1 X126.504 Y137.412 E.01131
G1 X126.505 Y137.577 E.00401
G1 X126.26 Y137.934 E.01053
G1 X125.351 Y138.8 E.03054
G1 X106.161 Y138.8 E.46678
G1 X105.64 Y138.78 E.01268
G1 X105.078 Y138.269 E.01848
G1 X104.551 Y137.687 E.0191
G1 X104.487 Y137.452 E.00592
G1 X104.641 Y137.18 E.0076
G1 X105.103 Y136.704 E.01614
G1 X105.689 Y136.177 E.01917
G1 X105.695 Y136.165 E.00033
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X105.719 Y136.11 E-.0285
G1 X105.75 Y136.041 E-.03593
G1 X105.75 Y133.019 E-1.43557
;WIPE_END
G1 X107.685 Y93.298 F9000
G1 X107.686 Y93.024
G1 E5 F2400
;TYPE:Perimeter
G1 F6000
G1 X106.116 Y93.019 E.03819
G1 X106.087 Y91.788 E.02995
G1 X105.934 Y91.551 E.00686
G1 X105.066 Y90.733 E.02901
G1 X104.889 Y90.498 E.00716
G1 X104.939 Y90.429 E.00207
G1 X105.336 Y89.998 E.01425
G1 X105.802 Y89.566 E.01546
G1 X107.879 Y89.566 E.05052
G1 X107.917 Y89.754 E.00467
G1 X107.917 Y91.153 E.03403
G1 X107.893 Y92.051 E.02185
G1 X107.818 Y92.56 E.01251
G1 X107.702 Y92.966 E.01027
G1 X107.702 Y92.966 F9000
G1 X107.463 Y92.392
G1 F6000
G1 X107.413 Y92.657 E.00656
G1 X106.481 Y92.655 E.02267
G1 X106.481 Y92.143 E.01245
G1 X106.443 Y91.705 E.01069
G1 X106.362 Y91.52 E.00491
G1 X106.179 Y91.28 E.00734
G1 X105.346 Y90.496 E.02782
G1 X105.943 Y89.931 E.01999
G1 X107.552 Y89.931 E.03914
G1 X107.551 Y91.577 E.04004
G1 X107.522 Y92.083 E.01233
G1 X107.475 Y92.333 E.00619
G1 X107.475 Y92.333 F9000
G1 X107.149 Y92.147
;WIDTH:0.390279
G1 F6000
G1 X107.135 Y92.309 E.00385
;WIDTH:0.364124
G1 X106.829 Y92.308 E.00671
G1 X106.829 Y92.143 E.00362
;WIDTH:0.394838
G1 X106.797 Y91.622 E.01252
;WIDTH:0.399999
G1 X106.664 Y91.314 E.00816
G1 X106.425 Y91.009 E.00943
G1 X105.865 Y90.504 E.01834
G1 X106.083 Y90.297 E.00731
G1 X107.186 Y90.297 E.02683
G1 X107.18 Y91.774 E.03593
;WIDTH:0.390279
G1 X107.154 Y92.087 E.00744
G1 X107.154 Y92.087 F9000
G1 X106.817 Y90.728
;WIDTH:0.530666
G1 F6000
G1 X106.786 Y90.782 E.00206
G1 X106.724 Y90.782 E.00205
G1 X106.693 Y90.728 E.00206
G1 X106.724 Y90.674 E.00206
G1 X106.786 Y90.674 E.00205
G1 E-5 F3600
G1 X106.786 Y90.674 F9000
G1 X123.087 Y89.736
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X123.139 Y89.566 E.00432
G1 X124.305 Y89.566 E.02836
G1 X125.197 Y89.566 E.0217
G1 X125.6 Y89.93 E.01321
G1 X125.984 Y90.317 E.01326
G1 X126.112 Y90.505 E.00553
G1 X126.037 Y90.627 E.00348
G1 X125.616 Y91.056 E.01462
G1 X125.066 Y91.551 E.018
G1 X124.94 Y91.727 E.00527
G1 X124.884 Y91.959 E.00581
G1 X124.884 Y93.019 E.02578
G1 X123.314 Y93.024 E.03819
G1 X123.2 Y92.645 E.00963
G1 X123.117 Y92.142 E.0124
G1 X123.083 Y91.602 E.01316
G1 X123.087 Y89.796 E.04393
G1 X123.087 Y89.796 F9000
G1 X123.45 Y91.116
G1 F6000
G1 X123.452 Y89.931 E.02882
G1 X124.305 Y89.931 E.02075
G1 X125.057 Y89.931 E.01829
G1 X125.65 Y90.499 E.01997
G1 X124.736 Y91.378 E.03084
G1 X124.557 Y91.705 E.00907
G1 X124.519 Y91.959 E.00625
G1 X124.519 Y92.655 E.01693
G1 X123.585 Y92.657 E.02272
G1 X123.502 Y92.227 E.01065
G1 X123.449 Y91.593 E.01548
G1 X123.45 Y91.176 E.01014
G1 X123.45 Y91.176 F9000
G1 X123.819 Y91.398
G1 F6000
G1 X123.817 Y90.297 E.02678
G1 X124.305 Y90.297 E.01187
G1 X124.916 Y90.297 E.01486
G1 X125.139 Y90.499 E.00732
G1 X124.434 Y91.171 E.02369
G1 X124.203 Y91.623 E.01235
;WIDTH:0.394811
G1 X124.173 Y91.796 E.00421
;WIDTH:0.390277
G1 X124.171 Y92.308 E.01212
;WIDTH:0.363267
G1 X123.867 Y92.309 E.00665
;WIDTH:0.390277
G1 X123.82 Y91.774 E.01272
;WIDTH:0.399999
G1 X123.819 Y91.458 E.00769
G1 X123.819 Y91.458 F9000
G1 X124.308 Y90.727
;WIDTH:0.529498
G1 F6000
G1 X124.278 Y90.781 E.00203
G1 X124.216 Y90.781 E.00204
G1 X124.185 Y90.727 E.00205
G1 X124.216 Y90.674 E.00202
G1 X124.278 Y90.674 E.00204
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X124.216 Y90.674 E-.02945
G1 X124.185 Y90.727 E-.02917
G1 X124.216 Y90.781 E-.02958
G1 X124.278 Y90.781 E-.02945
G1 X124.308 Y90.727 E-.02934
;WIPE_END
G1 E-1.35301 F3600
G1 X123.342 Y93.298 F9000
G1 X107.686 Y134.702
G1 X107.686 Y134.976
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X107.8 Y135.355 E.00963
G1 X107.883 Y135.858 E.0124
G1 X107.917 Y136.398 E.01316
G1 X107.913 Y138.291 E.04605
G1 X107.883 Y138.434 E.00355
G1 X105.803 Y138.434 E.05059
G1 X105.336 Y138.01 E.01534
G1 X104.98 Y137.645 E.0124
G1 X104.885 Y137.499 E.00424
G1 X104.964 Y137.372 E.00364
G1 X105.391 Y136.936 E.01484
G1 X105.934 Y136.449 E.01774
G1 X106.06 Y136.273 E.00527
G1 X106.116 Y136.041 E.00581
G1 X106.116 Y134.981 E.02578
G1 X107.626 Y134.977 E.03673
G1 X107.626 Y134.977 F9000
G1 X107.307 Y135.343
G1 F6000
G1 X107.415 Y135.343 E.00263
G1 X107.498 Y135.773 E.01065
G1 X107.551 Y136.407 E.01548
G1 X107.548 Y138.069 E.04043
G1 X105.944 Y138.069 E.03902
G1 X105.35 Y137.501 E.01999
G1 X106.264 Y136.622 E.03084
G1 X106.444 Y136.294 E.0091
G1 X106.481 Y136.041 E.00622
G1 X106.481 Y135.345 E.01693
G1 X107.247 Y135.343 E.01863
G1 X107.247 Y135.343 F9000
G1 X106.988 Y135.691
;WIDTH:0.363265
G1 F6000
G1 X107.133 Y135.691 E.00317
;WIDTH:0.386229
G1 X107.182 Y136.226 E.01258
;WIDTH:0.399999
G1 X107.183 Y137.703 E.03593
G1 X106.086 Y137.703 E.02668
G1 X105.863 Y137.5 E.00734
G1 X106.566 Y136.829 E.02364
G1 X106.797 Y136.377 E.01235
;WIDTH:0.393924
G1 X106.825 Y136.204 E.00419
;WIDTH:0.386229
G1 X106.829 Y135.692 E.01199
;WIDTH:0.363265
G1 X106.928 Y135.691 E.00217
G1 X106.928 Y135.691 F9000
G1 X106.815 Y137.273
;WIDTH:0.529454
G1 F6000
G1 X106.784 Y137.326 E.00202
G1 X106.722 Y137.326 E.00204
G1 X106.691 Y137.273 E.00202
G1 X106.722 Y137.219 E.00205
G1 X106.784 Y137.219 E.00204
G1 E-5 F3600
G1 X106.784 Y137.219 F9000
G1 X123.083 Y138.236
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X123.083 Y136.847 E.03379
G1 X123.107 Y135.949 E.02185
G1 X123.182 Y135.44 E.01251
G1 X123.314 Y134.976 E.01173
G1 X124.884 Y134.981 E.03819
G1 X124.911 Y136.203 E.02973
G1 X125.066 Y136.449 E.00707
G1 X125.681 Y137.006 E.02018
G1 X126.075 Y137.424 E.01397
G1 X126.111 Y137.502 E.00209
G1 X126.061 Y137.571 E.00207
G1 X125.664 Y138.002 E.01425
G1 X125.198 Y138.434 E.01546
G1 X123.145 Y138.434 E.04994
G1 X123.101 Y138.293 E.00359
G1 X123.101 Y138.293 F9000
G1 X123.449 Y137.174
G1 F6000
G1 X123.449 Y136.423 E.01827
G1 X123.478 Y135.917 E.01233
G1 X123.587 Y135.343 E.01421
G1 X124.519 Y135.345 E.02267
G1 X124.523 Y136.106 E.01851
G1 X124.638 Y136.48 E.00952
G1 X124.821 Y136.72 E.00734
G1 X125.654 Y137.504 E.02782
G1 X125.057 Y138.069 E.01999
G1 X123.449 Y138.069 E.03911
G1 X123.449 Y137.234 E.02031
G1 X123.449 Y137.234 F9000
G1 X123.816 Y136.935
G1 F6000
G1 X123.818 Y136.226 E.01725
;WIDTH:0.38623
G1 X123.865 Y135.691 E.01257
;WIDTH:0.364124
G1 X124.171 Y135.692 E.00671
;WIDTH:0.391684
G1 X124.195 Y136.333 E.01525
;WIDTH:0.399999
G1 X124.336 Y136.686 E.00925
G1 X124.575 Y136.991 E.00943
G1 X125.135 Y137.496 E.01834
G1 X124.917 Y137.703 E.00731
G1 X123.814 Y137.703 E.02683
G1 X123.816 Y136.995 E.01722
G1 X123.816 Y136.995 F9000
G1 X124.307 Y137.272
;WIDTH:0.530666
G1 F6000
G1 X124.276 Y137.326 E.00206
G1 X124.214 Y137.326 E.00205
G1 X124.183 Y137.272 E.00206
G1 X124.214 Y137.218 E.00206
G1 X124.276 Y137.218 E.00205
G1 X124.276 Y137.218 F9000
G1 X122.974 Y138.074
;WIDTH:0.402832
G1 F900
G1 X122.522 Y138.526 E.01567
G1 X122.001 Y138.526 E.01277
G1 X122.81 Y137.716 E.02806
G1 X122.812 Y137.193 E.01282
G1 X121.48 Y138.526 E.04619
G1 X120.958 Y138.526 E.0128
G1 X122.814 Y136.67 E.06434
G1 X122.816 Y136.147 E.01282
G1 X120.437 Y138.526 E.08247
G1 X119.916 Y138.526 E.01277
G1 X123.086 Y135.356 E.10989
G1 X123.086 Y135.356 F9000
G1 X124.614 Y134.87
G1 F900
G1 X124.976 Y134.508 E.01255
G1 X124.976 Y133.987 E.01277
G1 X124.258 Y134.705 E.02489
G1 X123.739 Y134.703 E.01272
G1 X124.976 Y133.466 E.04288
G1 X124.976 Y132.945 E.01277
G1 X119.395 Y138.526 E.19347
G1 X118.874 Y138.526 E.01277
G1 X124.976 Y132.424 E.21153
G1 X124.976 Y131.903 E.01277
G1 X118.353 Y138.526 E.22959
G1 X117.832 Y138.526 E.01277
G1 X124.976 Y131.382 E.24765
G1 X124.976 Y130.861 E.01277
G1 X117.311 Y138.526 E.26571
G1 X116.789 Y138.526 E.0128
G1 X124.976 Y130.339 E.28381
G1 X124.976 Y129.818 E.01277
G1 X116.268 Y138.526 E.30187
G1 X115.747 Y138.526 E.01277
G1 X124.976 Y129.297 E.31993
G1 X124.976 Y128.776 E.01277
G1 X115.226 Y138.526 E.33799
G1 X114.705 Y138.526 E.01277
G1 X124.976 Y128.255 E.35605
G1 X124.976 Y127.734 E.01277
G1 X120.472 Y132.237 E.15612
G1 X120.021 Y133.016 E.02206
G1 X119.418 Y133.659 E.02161
G1 X118.931 Y133.993 E.01448
G1 X118.527 Y134.183 E.01094
G1 X114.184 Y138.526 E.15055
G1 X113.663 Y138.526 E.01277
G1 X117.794 Y134.394 E.14322
G1 X117.226 Y134.442 E.01397
G1 X113.141 Y138.526 E.14159
G1 X112.62 Y138.526 E.01277
G1 X116.704 Y134.442 E.14158
G1 X116.183 Y134.442 E.01277
G1 X112.099 Y138.526 E.14158
G1 X111.578 Y138.526 E.01277
G1 X115.662 Y134.442 E.14158
G1 X115.14 Y134.442 E.0128
G1 X111.057 Y138.526 E.14156
G1 X110.536 Y138.526 E.01277
G1 X114.619 Y134.443 E.14154
G1 X114.098 Y134.443 E.01277
G1 X110.015 Y138.526 E.14154
G1 X109.494 Y138.526 E.01277
G1 X113.592 Y134.427 E.14208
G1 X113.12 Y134.378 E.01163
G1 X108.972 Y138.526 E.14379
G1 X108.451 Y138.526 E.01277
G1 X112.709 Y134.268 E.14761
G1 X112.339 Y134.117 E.0098
G1 X108.191 Y138.265 E.14379
G1 X108.19 Y137.745 E.01275
G1 X111.995 Y133.94 E.1319
G1 X111.69 Y133.724 E.00916
G1 X108.188 Y137.226 E.1214
G1 X108.186 Y136.706 E.01275
G1 X111.409 Y133.483 E.11173
G1 X111.163 Y133.209 E.00903
G1 X108.184 Y136.187 E.10325
G1 X108.138 Y135.712 E.0117
G1 X110.92 Y132.93 E.09644
G1 X110.728 Y132.601 E.00934
G1 X108.061 Y135.268 E.09245
G1 X107.953 Y134.855 E.01046
G1 X110.537 Y132.271 E.08958
G1 X110.345 Y131.942 E.00934
G1 X107.584 Y134.702 E.0957
G1 X107.062 Y134.704 E.0128
G1 X110.154 Y131.612 E.10719
G1 X109.962 Y131.283 E.00934
G1 X106.539 Y134.705 E.11864
G1 X106.024 Y134.707 E.01262
G1 X109.77 Y130.953 E.13
G1 X109.579 Y130.624 E.00933
G1 X106.024 Y134.178 E.12322
G1 X106.024 Y133.657 E.01277
G1 X109.387 Y130.294 E.11658
G1 X109.196 Y129.965 E.00933
G1 X106.024 Y133.136 E.10994
G1 X106.024 Y132.615 E.01277
G1 X109.01 Y129.629 E.10351
G1 X108.844 Y129.274 E.00961
G1 X106.024 Y132.094 E.09776
G1 X106.024 Y131.572 E.0128
G1 X108.721 Y128.875 E.09349
G1 X108.644 Y128.594 E.00714
G1 X108.631 Y128.444 E.00369
G1 X106.024 Y131.051 E.09037
G1 X106.024 Y130.53 E.01277
G1 X108.596 Y127.959 E.08914
G1 X108.656 Y127.378 E.01432
G1 X106.024 Y130.009 E.09122
G1 X106.024 Y129.488 E.01277
G1 X108.902 Y126.61 E.09977
G1 X109.052 Y126.282 E.00884
G1 X109.529 Y125.462 E.02325
G1 X106.024 Y128.967 E.1215
G1 X106.024 Y128.446 E.01277
G1 X110.708 Y123.762 E.16237
G1 E-5 F3600
G1 X110.708 Y123.762 F9000
G1 X125.14 Y127.048
G1 E5 F2400
G1 F900
G1 X121.192 Y130.996 E.13686
G1 X121.913 Y129.755 E.03518
G1 X124.976 Y126.691 E.1062
G1 X124.976 Y126.17 E.01277
G1 X122.3 Y128.847 E.09278
G1 X122.396 Y128.229 E.01533
G1 X124.976 Y125.649 E.08944
G1 X124.976 Y125.128 E.01277
G1 X122.388 Y127.716 E.08972
G1 X122.301 Y127.282 E.01085
G1 X124.976 Y124.607 E.09273
G1 X124.976 Y124.086 E.01277
G1 X122.203 Y126.858 E.09611
G1 X122.047 Y126.494 E.00971
G1 X124.976 Y123.565 E.10154
G1 X124.976 Y123.044 E.01277
G1 X121.87 Y126.149 E.10765
G1 X121.679 Y125.819 E.00935
G1 X124.976 Y122.522 E.11429
G1 X124.976 Y122.001 E.01277
G1 X121.487 Y125.49 E.12095
G1 X121.296 Y125.16 E.00935
G1 X124.976 Y121.48 E.12757
G1 X124.976 Y120.959 E.01277
G1 X121.104 Y124.831 E.13423
G1 X120.912 Y124.501 E.00936
G1 X124.976 Y120.438 E.14086
G1 X124.976 Y119.917 E.01277
G1 X120.721 Y124.172 E.1475
G1 X120.529 Y123.842 E.00936
G1 X124.976 Y119.396 E.15414
G1 X124.976 Y118.875 E.01277
G1 X120.338 Y123.513 E.16078
G1 X120.146 Y123.183 E.00936
G1 X124.976 Y118.353 E.16744
G1 X124.976 Y117.832 E.01277
G1 X119.927 Y122.881 E.17503
G1 X119.69 Y122.597 E.00907
G1 X124.976 Y117.311 E.18324
G1 X124.976 Y116.79 E.01277
G1 X119.405 Y122.36 E.19311
G1 X119.111 Y122.134 E.00909
G1 X124.976 Y116.269 E.20332
G1 X124.976 Y115.748 E.01277
G1 X118.781 Y121.942 E.21474
G1 X118.426 Y121.777 E.0096
G1 X124.976 Y115.227 E.22706
G1 X124.976 Y114.705 E.0128
G1 X118.022 Y121.659 E.24107
G1 X117.583 Y121.577 E.01095
G1 X124.976 Y114.184 E.25628
G1 X124.976 Y113.663 E.01277
G1 X120.57 Y118.069 E.15274
G1 X120.021 Y119.016 E.02683
G1 X119.417 Y119.66 E.02164
G1 X118.922 Y119.999 E.01471
G1 X118.406 Y120.233 E.01389
G1 X117.069 Y121.57 E.04635
G1 X116.55 Y121.568 E.01272
G1 X117.716 Y120.402 E.04042
G1 X117.155 Y120.442 E.01379
G1 X116.031 Y121.566 E.03896
G1 X115.512 Y121.564 E.01272
G1 X116.634 Y120.442 E.0389
G1 X116.112 Y120.442 E.0128
G1 X114.993 Y121.562 E.03881
G1 X114.473 Y121.56 E.01275
G1 X115.591 Y120.442 E.03876
G1 X115.07 Y120.442 E.01277
G1 X113.954 Y121.558 E.03869
G1 X113.762 Y121.557 E.00471
G1 X113.386 Y121.605 E.00929
G1 X114.548 Y120.443 E.04028
G1 X114.027 Y120.443 E.01277
G1 X112.465 Y122.005 E.05415
G1 E-5 F3600
G1 X112.465 Y122.005 F9000
G1 X113.679 Y120.27
G1 E5 F2400
G1 F900
G1 X106.024 Y127.925 E.26537
G1 X106.024 Y127.403 E.0128
G1 X113.065 Y120.363 E.24406
G1 X112.653 Y120.253 E.01045
G1 X106.024 Y126.882 E.2298
G1 X106.024 Y126.361 E.01277
G1 X112.29 Y120.095 E.21722
G1 X112.08 Y120 E.00565
G1 X111.954 Y119.911 E.00378
G1 X106.024 Y125.84 E.20555
G1 X106.024 Y125.319 E.01277
G1 X111.648 Y119.695 E.19496
G1 X111.518 Y119.604 E.00389
G1 X111.376 Y119.446 E.00521
G1 X106.024 Y124.798 E.18553
G1 X106.024 Y124.277 E.01277
G1 X111.13 Y119.171 E.177
G1 X110.894 Y118.886 E.00907
G1 X106.024 Y123.755 E.16881
G1 X106.024 Y123.234 E.01277
G1 X110.702 Y118.556 E.16217
G1 X110.511 Y118.227 E.00933
G1 X106.024 Y122.713 E.15553
G1 X106.024 Y122.192 E.01277
G1 X110.319 Y117.897 E.14889
G1 X110.128 Y117.568 E.00933
G1 X106.024 Y121.671 E.14225
G1 X106.024 Y121.15 E.01277
G1 X109.936 Y117.238 E.13561
G1 X109.744 Y116.908 E.00936
G1 X106.024 Y120.629 E.12897
G1 X106.024 Y120.108 E.01277
G1 X109.553 Y116.579 E.12234
G1 X109.361 Y116.249 E.00936
G1 X106.024 Y119.586 E.11568
G1 X106.024 Y119.065 E.01277
G1 X109.17 Y115.92 E.10904
G1 X108.988 Y115.581 E.00943
G1 X106.024 Y118.544 E.10273
G1 X106.024 Y118.023 E.01277
G1 X108.821 Y115.226 E.09696
G1 X108.706 Y114.82 E.01034
G1 X106.024 Y117.502 E.09297
G1 X106.024 Y116.981 E.01277
G1 X108.626 Y114.379 E.0902
G1 X108.593 Y113.994 E.00947
G1 X108.602 Y113.882 E.00275
G1 X106.024 Y116.46 E.08937
G1 X106.024 Y115.938 E.0128
G1 X108.68 Y113.283 E.09206
G1 X108.79 Y112.856 E.01081
G1 X108.962 Y112.48 E.01014
G1 X106.024 Y115.417 E.10183
G1 X106.024 Y114.896 E.01277
G1 X110.082 Y110.839 E.14066
G1 E-5 F3600
G1 X110.082 Y110.839 F9000
G1 X120.837 Y117.281
G1 E5 F2400
G1 F900
G1 X124.976 Y113.142 E.14348
G1 X124.976 Y112.621 E.01277
G1 X122.01 Y115.586 E.1028
G1 X122.071 Y115.483 E.00293
G1 X122.298 Y114.856 E.01635
G1 X122.314 Y114.762 E.00234
G1 X124.976 Y112.1 E.09228
G1 X124.976 Y111.579 E.01277
G1 X122.395 Y114.16 E.08947
G1 X122.386 Y113.648 E.01255
G1 X124.976 Y111.058 E.08978
G1 X124.976 Y110.536 E.0128
G1 X122.288 Y113.224 E.09318
G1 X122.19 Y112.801 E.01064
G1 X124.976 Y110.015 E.09658
G1 X124.976 Y109.494 E.01277
G1 X122.024 Y112.446 E.10233
G1 X121.844 Y112.104 E.00947
G1 X124.976 Y108.973 E.10856
G1 X124.976 Y108.452 E.01277
G1 X121.653 Y111.775 E.11519
G1 X121.461 Y111.445 E.00936
G1 X124.976 Y107.931 E.12183
G1 X124.976 Y107.41 E.01277
G1 X121.27 Y111.116 E.12847
G1 X121.078 Y110.786 E.00936
G1 X124.976 Y106.888 E.13513
G1 X124.976 Y106.367 E.01277
G1 X120.886 Y110.457 E.14178
G1 X120.695 Y110.127 E.00935
G1 X124.976 Y105.846 E.1484
G1 X124.976 Y105.325 E.01277
G1 X120.503 Y109.798 E.15506
G1 X120.312 Y109.468 E.00935
G1 X124.976 Y104.804 E.16168
G1 X124.976 Y104.283 E.01277
G1 X120.12 Y109.139 E.16834
G1 X120.069 Y109.05 E.00251
G1 X119.895 Y108.843 E.00663
G1 X124.976 Y103.762 E.17614
G1 X124.976 Y103.241 E.01277
G1 X119.657 Y108.559 E.18437
G1 X119.365 Y108.33 E.0091
G1 X124.976 Y102.719 E.19451
G1 X124.976 Y102.198 E.01277
G1 X119.071 Y108.103 E.2047
G1 X118.985 Y108.037 E.00266
G1 X118.733 Y107.92 E.00681
G1 X124.976 Y101.677 E.21642
G1 X124.976 Y101.156 E.01277
G1 X118.378 Y107.754 E.22873
G1 X117.967 Y107.644 E.01043
G1 X124.976 Y100.635 E.24297
G1 X124.976 Y100.114 E.01277
G1 X117.518 Y107.572 E.25854
G1 X116.999 Y107.57 E.01272
G1 X118.309 Y106.259 E.04543
G1 X118.44 Y106.223 E.00333
G1 X118.922 Y105.999 E.01303
G1 X119.417 Y105.66 E.01471
G1 X120.021 Y105.016 E.02164
G1 X120.667 Y103.901 E.03159
G1 X124.976 Y99.593 E.14936
G1 X124.976 Y99.072 E.01277
G1 X121.388 Y102.66 E.12438
G1 X122.086 Y101.44 E.03445
G1 X124.976 Y98.55 E.10018
G1 X124.976 Y98.029 E.01277
G1 X122.328 Y100.677 E.0918
G1 X122.396 Y100.262 E.01031
G1 X122.394 Y100.09 E.00422
G1 X124.976 Y97.508 E.08951
G1 X124.976 Y96.987 E.01277
G1 X122.372 Y99.59 E.09025
G1 X122.275 Y99.167 E.01064
G1 X124.976 Y96.466 E.09363
G1 X124.976 Y95.945 E.01277
G1 X122.168 Y98.752 E.09732
G1 X122.002 Y98.397 E.00961
G1 X124.976 Y95.424 E.10308
G1 X124.976 Y94.902 E.0128
G1 X121.819 Y98.06 E.10946
G1 X121.627 Y97.73 E.00936
G1 X124.976 Y94.381 E.1161
G1 X124.976 Y93.86 E.01277
G1 X121.435 Y97.401 E.12275
G1 X121.244 Y97.071 E.00935
G1 X124.976 Y93.339 E.12937
G1 X124.976 Y93.293 E.00113
G1 X124.499 Y93.295 E.01169
G1 X121.052 Y96.742 E.11949
G1 X120.861 Y96.412 E.00935
G1 X123.977 Y93.296 E.10802
G1 X123.454 Y93.297 E.01282
G1 X120.669 Y96.083 E.09656
G1 X120.477 Y95.753 E.00936
G1 X123.055 Y93.176 E.08935
G1 X122.947 Y92.762 E.01049
G1 X120.286 Y95.423 E.09225
G1 X120.094 Y95.094 E.00934
G1 X122.867 Y92.321 E.09613
G1 X122.816 Y91.851 E.01159
G1 X119.864 Y94.803 E.10233
G1 X119.675 Y94.574 E.00728
G1 X119.617 Y94.529 E.0018
G1 X122.814 Y91.332 E.11083
G1 X122.812 Y90.812 E.01275
G1 X119.324 Y94.301 E.12093
G1 X119.031 Y94.072 E.00912
G1 X122.81 Y90.293 E.131
G1 X122.809 Y89.774 E.01272
G1 X118.683 Y93.899 E.14301
G1 X118.322 Y93.739 E.00968
G1 X122.587 Y89.474 E.14785
G1 X122.066 Y89.474 E.01277
G1 X117.911 Y93.629 E.14404
G1 X117.448 Y93.571 E.01144
G1 X121.545 Y89.474 E.14203
G1 X121.024 Y89.474 E.01277
G1 X116.928 Y93.57 E.14199
G1 X116.408 Y93.568 E.01275
G1 X120.502 Y89.474 E.14192
G1 X119.981 Y89.474 E.01277
G1 X115.889 Y93.567 E.14187
G1 X115.369 Y93.565 E.01275
G1 X119.46 Y89.474 E.14182
G1 X118.939 Y89.474 E.01277
G1 X114.85 Y93.564 E.14177
G1 X114.33 Y93.562 E.01275
G1 X118.418 Y89.474 E.14171
G1 X117.897 Y89.474 E.01277
G1 X113.811 Y93.56 E.14164
G1 X113.226 Y93.624 E.01443
G1 X117.54 Y89.31 E.14955
G1 E-5 F3600
G1 X117.54 Y89.31 F9000
G1 X117.828 Y106.219
G1 E5 F2400
G1 F900
G1 X116.48 Y107.568 E.04675
G1 X115.961 Y107.566 E.01272
G1 X117.085 Y106.442 E.03896
G1 X116.563 Y106.442 E.0128
G1 X115.441 Y107.564 E.0389
G1 X114.922 Y107.562 E.01272
G1 X116.042 Y106.442 E.03883
G1 X115.521 Y106.442 E.01277
G1 X114.403 Y107.56 E.03876
G1 X113.884 Y107.558 E.01272
G1 X114.999 Y106.442 E.03867
G1 X114.478 Y106.443 E.01277
G1 X113.116 Y107.805 E.04721
G1 X113.116 Y107.805 F9000
G1 X114.121 Y106.278
G1 F900
G1 X112.627 Y107.772 E.05179
G1 X112.28 Y107.896 E.00903
G1 X111.772 Y108.196 E.01446
G1 X111.35 Y108.551 E.01352
G1 X110.931 Y109.05 E.01597
G1 X110.351 Y110.048 E.02829
G1 X106.024 Y114.375 E.15
G1 X106.024 Y113.854 E.01277
G1 X113.463 Y106.415 E.25788
G1 X113.15 Y106.386 E.00771
G1 X113.009 Y106.348 E.00358
G1 X106.024 Y113.333 E.24214
G1 X106.024 Y112.812 E.01277
G1 X112.6 Y106.236 E.22796
G1 X112.242 Y106.073 E.00964
G1 X106.024 Y112.291 E.21555
G1 X106.024 Y111.769 E.0128
G1 X111.912 Y105.882 E.2041
G1 X111.606 Y105.666 E.00918
G1 X106.024 Y111.248 E.1935
G1 X106.024 Y110.727 E.01277
G1 X111.343 Y105.409 E.18437
G1 X111.096 Y105.134 E.00906
G1 X106.024 Y110.206 E.17583
G1 X106.024 Y109.685 E.01277
G1 X110.868 Y104.841 E.16792
G1 X110.676 Y104.512 E.00934
G1 X106.024 Y109.164 E.16127
G1 X106.024 Y108.643 E.01277
G1 X110.485 Y104.182 E.15464
G1 X110.293 Y103.852 E.00936
G1 X106.024 Y108.122 E.14801
G1 X106.024 Y107.6 E.0128
G1 X110.102 Y103.523 E.14135
G1 X109.91 Y103.193 E.00936
G1 X106.024 Y107.079 E.13471
G1 X106.024 Y106.558 E.01277
G1 X109.718 Y102.864 E.12806
G1 X109.527 Y102.534 E.00935
G1 X106.024 Y106.037 E.12143
G1 X106.024 Y105.516 E.01277
G1 X109.335 Y102.205 E.11478
G1 X109.144 Y101.875 E.00935
G1 X106.024 Y104.995 E.10816
G1 X106.024 Y104.474 E.01277
G1 X108.965 Y101.533 E.10195
G1 X108.803 Y101.174 E.00965
G1 X106.024 Y103.952 E.09632
G1 X106.024 Y103.431 E.01277
G1 X108.691 Y100.765 E.09244
G1 X108.644 Y100.594 E.00435
G1 X108.62 Y100.314 E.00689
G1 X106.024 Y102.91 E.08999
G1 X106.024 Y102.389 E.01277
G1 X108.609 Y99.804 E.08961
G1 X108.64 Y99.438 E.009
G1 X108.704 Y99.188 E.00633
G1 X106.024 Y101.868 E.0929
G1 X106.024 Y101.347 E.01277
G1 X109.021 Y98.35 E.10389
G1 X109.725 Y97.125 E.03463
G1 X106.024 Y100.826 E.1283
G1 X106.024 Y100.305 E.01277
G1 X110.449 Y95.88 E.1534
G1 X110.931 Y95.05 E.02353
G1 X111.35 Y94.551 E.01597
G1 X111.772 Y94.196 E.01352
G1 X112.279 Y93.896 E.01444
G1 X112.519 Y93.809 E.00626
G1 X116.855 Y89.474 E.15029
G1 X116.333 Y89.474 E.0128
G1 X106.024 Y99.783 E.35737
G1 X106.024 Y99.262 E.01277
G1 X115.812 Y89.474 E.33931
G1 X115.291 Y89.474 E.01277
G1 X106.024 Y98.741 E.32125
G1 X106.024 Y98.22 E.01277
G1 X114.77 Y89.474 E.30319
G1 X114.249 Y89.474 E.01277
G1 X106.024 Y97.699 E.28513
G1 X106.024 Y97.178 E.01277
G1 X113.728 Y89.474 E.26707
G1 X113.207 Y89.474 E.01277
G1 X106.024 Y96.657 E.249
G1 X106.024 Y96.135 E.0128
G1 X112.685 Y89.474 E.23091
G1 X112.164 Y89.474 E.01277
G1 X106.024 Y95.614 E.21285
G1 X106.024 Y95.093 E.01277
G1 X111.643 Y89.474 E.19479
G1 X111.122 Y89.474 E.01277
G1 X108.107 Y92.49 E.10453
G1 X108.182 Y91.894 E.01472
G1 X110.601 Y89.474 E.08387
G1 X110.08 Y89.474 E.01277
G1 X108.186 Y91.368 E.06566
G1 X108.188 Y90.845 E.01282
G1 X109.559 Y89.474 E.04753
G1 X109.038 Y89.474 E.01277
G1 X108.189 Y90.322 E.02941
G1 X108.191 Y89.799 E.01282
G1 X108.681 Y89.31 E.01697
G1 E-5 F3600
G1 X108.681 Y89.31 F9000
G1 X107.464 Y93.133
G1 E5 F2400
G1 F900
G1 X106.024 Y94.572 E.0499
G1 X106.024 Y94.051 E.01277
G1 X106.78 Y93.295 E.02621
G1 X106.26 Y93.294 E.01275
G1 X105.86 Y93.694 E.01387
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X106.26 Y93.294 E-.2687
G1 X106.78 Y93.295 E-.247
G1 X106.024 Y94.051 E-.50784
G1 X106.024 Y94.572 E-.24748
G1 X106.365 Y94.231 E-.22898
;WIPE_END
G1 X106.826 Y93.295 F9000
G1 X108.189 Y90.532
G1 X110.621 Y85.6
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X110.355 Y85.5 E.00691
G1 X104.557 Y85.5 E.14103
G1 X103.997 Y85.459 E.01366
G1 X103.457 Y85.339 E.01346
G1 X102.779 Y85.061 E.01782
G1 X102.417 Y84.823 E.01054
G1 X101.965 Y84.471 E.01394
G1 X101.543 Y84.005 E.01529
G1 X101.192 Y83.477 E.01542
G1 X100.919 Y82.815 E.01742
G1 X100.761 Y81.972 E.02086
G1 X100.75 Y78.959 E.07329
G1 X100.69 Y78.824 E.00359
G1 X99.751 Y77.943 E.03132
G1 X99.518 Y77.607 E.00995
G1 X99.487 Y77.444 E.00404
G1 X99.673 Y77.155 E.00836
G1 X100.048 Y76.756 E.01332
G1 X100.577 Y76.278 E.01734
G1 X130.423 Y76.278 E.72597
G1 X130.922 Y76.729 E.01636
G1 X131.295 Y77.116 E.01307
G1 X131.517 Y77.474 E.01025
G1 X131.499 Y77.569 E.00235
G1 X131.314 Y77.874 E.00868
G1 X130.307 Y78.827 E.03372
G1 X130.25 Y78.959 E.0035
G1 X130.25 Y81.693 E.0665
G1 X130.208 Y82.254 E.01368
G1 X130.041 Y82.94 E.01717
G1 X129.735 Y83.608 E.01787
G1 X129.412 Y84.078 E.01387
G1 X129.035 Y84.484 E.01348
G1 X128.595 Y84.835 E.01369
G1 X127.959 Y85.186 E.01767
G1 X127.27 Y85.41 E.01762
G1 X126.727 Y85.489 E.01335
G1 X120.645 Y85.5 E.14794
G1 X120.276 Y85.65 E.00969
G1 X110.755 Y85.65 E.23159
G1 X110.677 Y85.621 E.00202
G1 E-5 F3600
G1 X110.677 Y85.621 F9000
G1 X102.917 Y77.233
G1 E5 F2400
;TYPE:Perimeter
G1 F6000
G1 X102.916 Y79.837 E.06334
G1 X102.869 Y80.948 E.02705
G1 X102.82 Y81.424 E.01164
G1 X102.708 Y82.186 E.01873
G1 X101.172 Y82.18 E.03736
G1 X101.126 Y81.937 E.00602
G1 X101.119 Y79.814 E.05164
G1 X101.089 Y78.797 E.02475
G1 X100.936 Y78.553 E.00701
G1 X100.21 Y77.89 E.02391
G1 X99.889 Y77.501 E.01227
G1 X99.956 Y77.402 E.00291
G1 X100.23 Y77.101 E.0099
G1 X100.718 Y76.643 E.01628
G1 X102.917 Y76.643 E.05349
G1 X102.917 Y77.173 E.01289
G1 E-5 F3600
G1 X100.854 Y77.014 F9000
G1 E5 F2400
G1 F6000
G1 X100.859 Y77.009 E.00017
G1 X102.551 Y77.009 E.04116
G1 X102.551 Y79.826 E.06852
G1 X102.504 Y80.925 E.02676
G1 X102.403 Y81.819 E.02188
G1 X101.492 Y81.816 E.02216
G1 X101.472 Y78.859 E.07193
G1 X101.363 Y78.522 E.00862
G1 X101.182 Y78.283 E.00729
G1 X100.346 Y77.498 E.02789
G1 X100.81 Y77.055 E.0156
G1 X100.81 Y77.055 F9000
G1 X100.993 Y77.381
G1 F6000
G1 X100.999 Y77.375 E.00021
G1 X102.186 Y77.375 E.02887
G1 X102.192 Y78.954 E.03841
;WIDTH:0.386415
G1 X102.193 Y79.816 E.02019
;WIDTH:0.384794
G1 X102.159 Y80.904 E.02538
;WIDTH:0.407043
G1 X102.129 Y80.969 E.00177
;WIDTH:0.45415
G1 X102.098 Y81.033 E.00199
;WIDTH:0.501257
G1 X102.068 Y81.098 E.00222
;WIDTH:0.548364
G1 X102.038 Y81.163 E.00245
;WIDTH:0.595471
G1 X102.007 Y81.228 E.00269
;WIDTH:0.642578
G1 X101.977 Y81.293 E.0029
G1 X101.955 Y81.233 E.00259
;WIDTH:0.600244
G1 X101.934 Y81.172 E.00243
;WIDTH:0.55791
G1 X101.913 Y81.112 E.00221
;WIDTH:0.515576
G1 X101.891 Y81.052 E.00205
;WIDTH:0.473242
G1 X101.87 Y80.991 E.00188
;WIDTH:0.430907
G1 X101.848 Y80.931 E.00169
;WIDTH:0.388573
G1 X101.839 Y80.468 E.01091
;WIDTH:0.384794
G1 X101.842 Y79.811 E.01532
;WIDTH:0.395485
G1 X101.83 Y78.793 E.02446
;WIDTH:0.399999
G1 X101.665 Y78.316 E.01228
G1 X101.428 Y78.013 E.00936
G1 X100.867 Y77.502 E.01846
G1 X100.95 Y77.423 E.00279
G1 X100.95 Y77.423 F9000
G1 X101.834 Y77.783
;WIDTH:0.485626
G1 F6000
G1 X101.805 Y77.832 E.00171
G1 X101.749 Y77.832 E.00168
G1 X101.721 Y77.783 E.00169
G1 X101.749 Y77.734 E.00169
G1 X101.805 Y77.734 E.00168
G1 E-5 F3600
G1 X101.805 Y77.734 F9000
G1 X128.083 Y76.643
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X130.282 Y76.643 E.05349
G1 X130.732 Y77.055 E.01484
G1 X131.082 Y77.438 E.01262
G1 X131.112 Y77.512 E.00194
G1 X131.009 Y77.659 E.00437
G1 X130.056 Y78.561 E.03192
G1 X129.937 Y78.733 E.00509
G1 X129.884 Y78.959 E.00565
G1 X129.884 Y81.679 E.06616
G1 X129.847 Y82.18 E.01222
G1 X128.292 Y82.186 E.03782
G1 X128.218 Y81.777 E.01011
G1 X128.133 Y80.983 E.01942
G1 X128.083 Y79.793 E.02897
G1 X128.083 Y76.703 E.07516
G1 E-5 F3600
G1 X128.083 Y76.703 F9000
G1 X128.495 Y80.873
G1 E5 F2400
G1 F6000
G1 X128.448 Y79.79 E.02637
G1 X128.448 Y77.009 E.06765
G1 X130.14 Y77.009 E.04116
G1 X130.648 Y77.497 E.01713
G1 X129.723 Y78.392 E.03131
G1 X129.549 Y78.738 E.00942
G1 X129.519 Y78.959 E.00542
G1 X129.507 Y81.816 E.06949
G1 X128.597 Y81.819 E.02213
G1 X128.498 Y80.962 E.02098
G1 X128.497 Y80.933 E.00071
G1 X128.497 Y80.933 F9000
G1 X128.918 Y81.482
;WIDTH:0.340744
G1 F6000
G1 X128.892 Y81.482 E.00053
;WIDTH:0.362086
G1 X128.844 Y80.943 E.0118
;WIDTH:0.386595
G1 X128.807 Y79.786 E.02713
;WIDTH:0.394965
G1 X128.812 Y78.769 E.0244
;WIDTH:0.399999
G1 X128.814 Y77.375 E.03391
G1 X129.999 Y77.375 E.02882
G1 X130.125 Y77.489 E.00413
G1 X129.418 Y78.191 E.02423
G1 X129.191 Y78.675 E.013
;WIDTH:0.396576
G1 X129.16 Y78.959 E.00688
;WIDTH:0.386595
G1 X129.161 Y80.16 E.02814
;WIDTH:0.383847
G1 X129.172 Y80.933 E.01797
;WIDTH:0.362086
G1 X129.183 Y81.481 E.01195
;WIDTH:0.340744
G1 X128.978 Y81.482 E.00418
G1 E-5 F3600
G1 X128.978 Y81.482 F9000
G1 X129.279 Y77.783
G1 E5 F2400
;WIDTH:0.485328
G1 F6000
G1 X129.251 Y77.832 E.00169
G1 X129.194 Y77.832 E.00171
G1 X129.166 Y77.783 E.00169
G1 X129.194 Y77.734 E.00169
G1 X129.251 Y77.734 E.00171
G1 E-5 F3600
G1 X129.251 Y77.734 F9000
G1 X128.2 Y84.928
G1 E5 F2400
;WIDTH:0.40446
G1 F900
G1 X129.198 Y83.906 E.03517
G1 X129.495 Y83.472 E.01295
G1 X129.789 Y82.816 E.0177
G1 X127.585 Y85.019 E.07672
G1 X127.207 Y85.142 E.00979
G1 X126.893 Y85.188 E.00781
G1 X129.626 Y82.455 E.09516
G1 X129.101 Y82.457 E.01293
G1 X126.342 Y85.216 E.09607
G1 X125.818 Y85.217 E.0129
G1 X128.575 Y82.459 E.09601
G1 X128.062 Y82.449 E.01263
G1 X125.293 Y85.218 E.09641
G1 X124.769 Y85.219 E.0129
G1 X127.98 Y82.007 E.11182
G1 X127.915 Y81.549 E.01139
G1 X124.244 Y85.219 E.1278
G1 X123.72 Y85.22 E.0129
G1 X127.875 Y81.066 E.14466
G1 X127.841 Y80.576 E.01209
G1 X123.196 Y85.221 E.16173
G1 X122.671 Y85.222 E.01293
G1 X127.814 Y80.079 E.17907
G1 X127.813 Y79.557 E.01285
G1 X122.147 Y85.223 E.19728
G1 X121.623 Y85.224 E.0129
G1 X127.813 Y79.034 E.21553
G1 X127.812 Y78.512 E.01285
G1 X121.098 Y85.225 E.23376
G1 X120.565 Y85.235 E.01313
G1 X127.811 Y77.989 E.2523
G1 X127.81 Y77.466 E.01288
G1 X119.901 Y85.376 E.2754
G1 X119.377 Y85.376 E.0129
G1 X127.809 Y76.944 E.29359
G1 X127.813 Y76.552 E.00965
G1 X127.678 Y76.552 E.00332
G1 X118.854 Y85.376 E.30724
G1 X118.33 Y85.376 E.0129
G1 X127.154 Y76.552 E.30724
G1 X126.631 Y76.552 E.01288
G1 X117.807 Y85.376 E.30724
G1 X117.284 Y85.376 E.01288
G1 X126.107 Y76.552 E.30723
G1 X125.584 Y76.552 E.01288
G1 X116.76 Y85.376 E.30724
G1 X116.237 Y85.376 E.01288
G1 X125.06 Y76.552 E.30723
G1 X124.537 Y76.552 E.01288
G1 X115.713 Y85.376 E.30724
G1 X115.19 Y85.376 E.01288
G1 X124.014 Y76.552 E.30724
G1 X123.49 Y76.552 E.0129
G1 X114.666 Y85.376 E.30724
G1 X114.143 Y85.376 E.01288
G1 X122.967 Y76.552 E.30724
G1 X122.443 Y76.552 E.0129
G1 X113.62 Y85.376 E.30723
G1 X113.096 Y85.376 E.0129
G1 X121.92 Y76.552 E.30724
G1 X121.396 Y76.552 E.0129
G1 X112.573 Y85.376 E.30723
G1 X112.049 Y85.376 E.0129
G1 X120.873 Y76.552 E.30724
G1 X120.349 Y76.552 E.0129
G1 X111.526 Y85.376 E.30723
G1 X111.002 Y85.376 E.0129
G1 X119.826 Y76.552 E.30724
G1 X119.303 Y76.552 E.01288
G1 X110.565 Y85.29 E.30425
G1 X110.473 Y85.24 E.00258
G1 X110.105 Y85.226 E.00907
G1 X118.779 Y76.552 E.30202
G1 X118.256 Y76.552 E.01288
G1 X109.582 Y85.226 E.30202
G1 X109.059 Y85.226 E.01288
G1 X117.732 Y76.552 E.302
G1 X117.209 Y76.552 E.01288
G1 X108.535 Y85.226 E.30202
G1 X108.012 Y85.226 E.01288
G1 X116.685 Y76.552 E.302
G1 X116.162 Y76.552 E.01288
G1 X107.488 Y85.226 E.30202
G1 X106.965 Y85.226 E.01288
G1 X115.639 Y76.552 E.30202
G1 X115.115 Y76.552 E.0129
G1 X106.441 Y85.226 E.30202
G1 X105.918 Y85.226 E.01288
G1 X114.592 Y76.552 E.30202
G1 X114.068 Y76.552 E.0129
G1 X105.395 Y85.226 E.302
G1 X104.871 Y85.226 E.0129
G1 X113.545 Y76.552 E.30202
G1 X113.021 Y76.552 E.0129
G1 X104.363 Y85.211 E.30148
G1 X104.037 Y85.187 E.00805
G1 X103.895 Y85.155 E.00358
G1 X112.498 Y76.552 E.29955
G1 X111.975 Y76.552 E.01288
G1 X103.476 Y85.05 E.29591
G1 X103.105 Y84.898 E.00987
G1 X111.451 Y76.552 E.2906
G1 X110.928 Y76.552 E.01288
G1 X102.76 Y84.72 E.2844
G1 X102.443 Y84.513 E.00932
G1 X110.404 Y76.552 E.27719
G1 X109.881 Y76.552 E.01288
G1 X102.158 Y84.275 E.26891
G1 X101.899 Y84.011 E.00911
G1 X109.357 Y76.552 E.2597
G1 X108.834 Y76.552 E.01288
G1 X101.666 Y83.72 E.24958
G1 X101.465 Y83.398 E.00935
G1 X102.403 Y82.459 E.03268
G1 X101.882 Y82.457 E.01283
G1 X101.306 Y83.033 E.02006
G1 X101.183 Y82.736 E.00791
G1 X101.167 Y82.649 E.00218
G1 X101.524 Y82.291 E.01245
G1 X101.524 Y82.291 F9000
G1 X102.851 Y82.011
G1 F900
G1 X108.31 Y76.552 E.19008
G1 X107.787 Y76.552 E.01288
G1 X103.114 Y81.225 E.16271
G1 X103.153 Y80.663 E.01387
G1 X107.264 Y76.552 E.14314
G1 X106.74 Y76.552 E.0129
G1 X103.185 Y80.107 E.12378
G1 X103.185 Y79.584 E.01288
G1 X106.217 Y76.552 E.10557
G1 X105.693 Y76.552 E.0129
G1 X103.184 Y79.061 E.08736
G1 X103.183 Y78.539 E.01285
G1 X105.17 Y76.552 E.06919
G1 X104.646 Y76.552 E.0129
G1 X103.182 Y78.016 E.05098
G1 X103.182 Y77.493 E.01288
G1 X104.123 Y76.552 E.03276
G1 X103.6 Y76.552 E.01288
G1 X103.017 Y77.135 E.0203
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.6 Y76.552 E-.39163
G1 X104.123 Y76.552 E-.24842
G1 X103.182 Y77.493 E-.63212
G1 X103.182 Y77.973 E-.22783
;WIPE_END
G1 X103.182 Y77.973 F9000
G1 X105.065 Y88.561
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X105.151 Y88.503 E.00252
G1 X105.183 Y88.5 E.00078
G1 X125.817 Y88.5 E.5019
G1 X125.947 Y88.554 E.00342
G1 X126 Y88.683 E.00339
G1 X126 Y89.051 E.00895
G1 X126.847 Y89.861 E.02851
G1 X127.098 Y90.232 E.0109
G1 X127.154 Y90.584 E.00867
G1 X127.069 Y90.833 E.0064
G1 X126.852 Y91.134 E.00903
G1 X126 Y91.951 E.02871
G1 X126 Y92.582 E.01535
G1 X139.202 Y92.582 E.32113
G1 X139.584 Y92.704 E.00975
G1 X139.816 Y92.972 E.00862
G1 X139.9 Y93.31 E.00847
G1 X139.9 Y95.518 E.05371
G1 X139.815 Y95.863 E.00864
G1 X139.629 Y96.093 E.00719
G1 X139.395 Y96.217 E.00644
G1 X139 Y96.247 E.00964
G1 X136.7 Y96.247 E.05595
G1 X136.7 Y102.24 E.14577
G1 X139.202 Y102.24 E.06086
G1 X139.473 Y102.3 E.00675
G1 X139.683 Y102.448 E.00625
G1 X139.856 Y102.729 E.00803
G1 X139.9 Y102.982 E.00625
G1 X139.9 Y105.018 E.04952
G1 X139.847 Y105.301 E.007
G1 X139.718 Y105.517 E.00612
G1 X139.525 Y105.674 E.00605
G1 X139.291 Y105.751 E.00599
G1 X136.7 Y105.76 E.06302
G1 X136.7 Y110.24 E.10897
G1 X139.291 Y110.249 E.06302
G1 X139.581 Y110.36 E.00755
G1 X139.758 Y110.533 E.00602
G1 X139.867 Y110.757 E.00606
G1 X139.9 Y110.982 E.00553
G1 X139.9 Y113.018 E.04952
G1 X139.836 Y113.327 E.00768
G1 X139.706 Y113.527 E.0058
G1 X139.412 Y113.723 E.00859
G1 X138.94 Y113.76 E.01152
G1 X136.7 Y113.76 E.05449
G1 X136.7 Y118.24 E.10897
G1 X139.202 Y118.24 E.06086
G1 X139.473 Y118.3 E.00675
G1 X139.683 Y118.448 E.00625
G1 X139.856 Y118.729 E.00803
G1 X139.9 Y118.982 E.00625
G1 X139.9 Y121.018 E.04952
G1 X139.847 Y121.301 E.007
G1 X139.718 Y121.517 E.00612
G1 X139.525 Y121.674 E.00605
G1 X139.291 Y121.751 E.00599
G1 X136.7 Y121.76 E.06302
G1 X136.7 Y126.24 E.10897
G1 X139.202 Y126.24 E.06086
G1 X139.473 Y126.3 E.00675
G1 X139.683 Y126.448 E.00625
G1 X139.856 Y126.729 E.00803
G1 X139.9 Y126.982 E.00625
G1 X139.892 Y129.118 E.05196
G1 X139.765 Y129.453 E.00871
G1 X139.525 Y129.674 E.00794
G1 X139.291 Y129.751 E.00599
G1 X136.699 Y129.76 E.06305
G1 X136.689 Y133.068 E.08046
G1 X136.555 Y134.239 E.02867
G1 X139.202 Y134.24 E.06439
G1 X139.473 Y134.3 E.00675
G1 X139.683 Y134.448 E.00625
G1 X139.856 Y134.729 E.00803
G1 X139.9 Y134.982 E.00625
G1 X139.892 Y137.118 E.05196
G1 X139.792 Y137.416 E.00765
G1 X139.629 Y137.604 E.00605
G1 X139.417 Y137.722 E.0059
G1 X139.058 Y137.759 E.00878
G1 X135.317 Y137.762 E.091
G1 X134.589 Y139.12 E.03748
G1 X134.187 Y139.739 E.01795
G1 X133.868 Y140.118 E.01205
G1 X133.317 Y140.62 E.01813
G1 X132.183 Y141.46 E.03433
G1 X131.512 Y141.86 E.019
G1 X133.855 Y141.857 E.05699
G1 X134.358 Y141.942 E.01241
G1 X135.245 Y142.137 E.02209
G1 X136.32 Y142.238 E.02626
G1 X139.202 Y142.24 E.0701
G1 X139.473 Y142.3 E.00675
G1 X139.676 Y142.438 E.00597
G1 X139.826 Y142.654 E.0064
G1 X139.9 Y142.982 E.00818
G1 X139.892 Y145.118 E.05196
G1 X139.782 Y145.427 E.00798
G1 X139.51 Y145.678 E.009
G1 X139.202 Y145.76 E.00775
G1 X136.316 Y145.762 E.0702
G1 X135.729 Y145.798 E.01431
G1 X135.199 Y145.872 E.01302
G1 X134.23 Y146.097 E.0242
G1 X133.855 Y146.143 E.00919
G1 X124.929 Y146.138 E.21712
G1 X124.793 Y146.076 E.00364
G1 X124.747 Y145.955 E.00315
G1 X124.741 Y143.162 E.06794
G1 X124.63 Y143.126 E.00284
G1 X106.312 Y143.129 E.44557
G1 X106.259 Y143.175 E.00171
G1 X106.253 Y145.955 E.06762
G1 X106.18 Y146.101 E.00397
G1 X106.071 Y146.138 E.0028
G1 X97.145 Y146.143 E.21712
G1 X96.763 Y146.094 E.00937
G1 X95.754 Y145.863 E.02518
G1 X94.68 Y145.762 E.02624
G1 X91.767 Y145.759 E.07086
G1 X91.484 Y145.677 E.00717
G1 X91.219 Y145.427 E.00886
G1 X91.1 Y145.018 E.01036
G1 X91.108 Y142.882 E.05196
G1 X91.235 Y142.547 E.00871
G1 X91.419 Y142.361 E.00636
G1 X91.798 Y142.24 E.00968
G1 X94.963 Y142.23 E.07699
G1 X95.803 Y142.128 E.02058
G1 X96.939 Y141.876 E.0283
G1 X99.485 Y141.86 E.06193
G1 X98.438 Y141.206 E.03003
G1 X97.679 Y140.618 E.02335
G1 X97.132 Y140.118 E.01803
G1 X96.828 Y139.759 E.01144
G1 X96.452 Y139.19 E.01659
G1 X96.079 Y138.524 E.01857
G1 X95.683 Y137.762 E.02089
G1 X91.767 Y137.759 E.09525
G1 X91.527 Y137.699 E.00602
G1 X91.324 Y137.562 E.00596
G1 X91.178 Y137.36 E.00606
G1 X91.108 Y137.118 E.00613
G1 X91.1 Y134.982 E.05196
G1 X91.164 Y134.673 E.00768
G1 X91.294 Y134.473 E.0058
G1 X91.588 Y134.277 E.00859
G1 X92.064 Y134.24 E.01161
G1 X94.435 Y134.239 E.05767
G1 X94.31 Y133.056 E.02894
G1 X94.301 Y129.76 E.08017
G1 X91.709 Y129.751 E.06305
G1 X91.419 Y129.64 E.00755
G1 X91.242 Y129.467 E.00602
G1 X91.133 Y129.243 E.00606
G1 X91.1 Y129.018 E.00553
G1 X91.1 Y126.982 E.04952
G1 X91.164 Y126.673 E.00768
G1 X91.294 Y126.473 E.0058
G1 X91.588 Y126.277 E.00859
G1 X92.06 Y126.24 E.01152
G1 X94.3 Y126.24 E.05449
G1 X94.3 Y121.76 E.10897
G1 X91.798 Y121.76 E.06086
G1 X91.527 Y121.7 E.00675
G1 X91.317 Y121.552 E.00625
G1 X91.144 Y121.271 E.00803
G1 X91.1 Y121.018 E.00625
G1 X91.1 Y118.982 E.04952
G1 X91.153 Y118.699 E.007
G1 X91.282 Y118.483 E.00612
G1 X91.475 Y118.326 E.00605
G1 X91.709 Y118.249 E.00599
G1 X94.3 Y118.24 E.06302
G1 X94.3 Y113.76 E.10897
G1 X91.798 Y113.76 E.06086
G1 X91.527 Y113.7 E.00675
G1 X91.317 Y113.552 E.00625
G1 X91.144 Y113.271 E.00803
G1 X91.1 Y113.018 E.00625
G1 X91.1 Y110.982 E.04952
G1 X91.153 Y110.699 E.007
G1 X91.282 Y110.483 E.00612
G1 X91.475 Y110.326 E.00605
G1 X91.709 Y110.249 E.00599
G1 X94.3 Y110.24 E.06302
G1 X94.3 Y105.76 E.10897
G1 X91.798 Y105.76 E.06086
G1 X91.527 Y105.7 E.00675
G1 X91.317 Y105.552 E.00625
G1 X91.144 Y105.271 E.00803
G1 X91.1 Y105.018 E.00625
G1 X91.1 Y102.982 E.04952
G1 X91.153 Y102.699 E.007
G1 X91.282 Y102.483 E.00612
G1 X91.475 Y102.326 E.00605
G1 X91.709 Y102.249 E.00599
G1 X94.3 Y102.24 E.06302
G1 X94.3 Y96.247 E.14577
G1 X91.799 Y96.247 E.06083
G1 X91.542 Y96.194 E.00638
G1 X91.316 Y96.043 E.00661
G1 X91.155 Y95.794 E.00721
G1 X91.1 Y95.518 E.00685
G1 X91.1 Y93.31 E.05371
G1 X91.12 Y93.143 E.00409
G1 X91.308 Y92.799 E.00954
G1 X91.542 Y92.634 E.00696
G1 X91.799 Y92.582 E.00638
G1 X105 Y92.582 E.3211
G1 X105 Y91.949 E.0154
G1 X104.153 Y91.139 E.02851
G1 X103.902 Y90.768 E.0109
G1 X103.846 Y90.416 E.00867
G1 X103.931 Y90.167 E.0064
G1 X104.266 Y89.744 E.01312
G1 X105 Y89.049 E.02459
G1 X105.026 Y88.601 E.01092
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X105.065 Y88.561 E-.02654
G1 X105.151 Y88.503 E-.04927
G1 X105.183 Y88.5 E-.01527
G1 X108.149 Y88.5 E-1.40892
;WIPE_END
G1 X102.946 Y82.404 F9000
G1 X101.099 Y80.24
G1 X99.651 Y79.111
G1 X100 Y78.953
G1 E5 F2400
G1 F6000
G1 X100 Y78.949 E.0001
G1 X99.153 Y78.139 E.02851
G1 X98.902 Y77.768 E.0109
G1 X98.846 Y77.416 E.00867
G1 X98.931 Y77.167 E.0064
G1 X99.148 Y76.866 E.00903
G1 X100 Y76.049 E.02871
G1 X100.003 Y75.764 E.00693
G1 X100.054 Y75.669 E.00262
G1 X100.183 Y75.616 E.00339
G1 X130.817 Y75.616 E.74514
G1 X130.947 Y75.67 E.00342
G1 X131 Y75.798 E.00337
G1 X131 Y76.051 E.00615
G1 X131.847 Y76.861 E.02851
G1 X132.098 Y77.232 E.0109
G1 X132.154 Y77.584 E.00867
G1 X132.069 Y77.833 E.0064
G1 X131.852 Y78.134 E.00903
G1 X131 Y78.952 E.02873
G1 X130.991 Y82.322 E.08197
G1 X130.845 Y83.174 E.02103
G1 X130.652 Y83.722 E.01413
G1 X130.372 Y84.257 E.01469
G1 X129.849 Y84.936 E.02085
G1 X129.433 Y85.321 E.01379
G1 X128.959 Y85.651 E.01405
G1 X128.442 Y85.915 E.01412
G1 X127.918 Y86.098 E.0135
G1 X127.37 Y86.211 E.01361
G1 X126.813 Y86.25 E.01358
G1 X103.932 Y86.241 E.55656
G1 X103.378 Y86.168 E.01359
G1 X102.557 Y85.915 E.0209
G1 X102.067 Y85.667 E.01336
G1 X101.586 Y85.336 E.0142
G1 X101.167 Y84.954 E.01379
G1 X100.645 Y84.283 E.02068
G1 X100.364 Y83.76 E.01444
G1 X100.193 Y83.283 E.01233
G1 X100.042 Y82.632 E.01626
G1 X100 Y82.051 E.01417
G1 X100 Y79.013 E.0739
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X100 Y78.953 E-.0285
G1 X100 Y78.949 E-.0019
G1 X99.153 Y78.139 E-.55668
G1 X98.902 Y77.768 E-.21277
G1 X98.846 Y77.416 E-.1693
G1 X98.931 Y77.167 E-.12498
G1 X99.148 Y76.866 E-.17626
G1 X99.497 Y76.531 E-.22961
;WIPE_END
G1 X99.239 Y76.271 F9000
G1 X101.099 Y81.174
G1 X101.541 Y82.456
G1 X103.932 Y89.39
G1 X103.981 Y89.532
G1 X124.808 Y149.917
G1 E5 F2400
G1 F6000
G1 X124.929 Y149.862 E.00323
G1 X133.855 Y149.857 E.21712
G1 X134.237 Y149.906 E.00937
G1 X135.246 Y150.137 E.02518
G1 X135.824 Y150.191 E.01412
G1 X136.422 Y150.239 E.01459
G1 X139.291 Y150.249 E.06979
G1 X139.581 Y150.36 E.00755
G1 X139.765 Y150.547 E.00638
G1 X139.892 Y150.882 E.00871
G1 X139.9 Y153.018 E.05196
G1 X139.839 Y153.314 E.00735
G1 X139.629 Y153.604 E.00871
G1 X139.417 Y153.722 E.0059
G1 X139.234 Y153.759 E.00454
G1 X135.938 Y153.776 E.08017
G1 X135.198 Y153.872 E.01815
G1 X134.23 Y154.097 E.02417
G1 X133.855 Y154.143 E.00919
G1 X124.929 Y154.138 E.21712
G1 X124.82 Y154.101 E.0028
G1 X124.747 Y153.955 E.00397
G1 X124.747 Y150.045 E.09511
G1 X124.778 Y149.964 E.00211
G1 E-5 F3600
G1 X124.778 Y149.964 F9000
G1 X106.191 Y149.917
G1 E5 F2400
G1 F6000
G1 X106.207 Y149.924 E.00042
G1 X106.253 Y150.045 E.00315
G1 X106.253 Y153.955 E.09511
G1 X106.18 Y154.101 E.00397
G1 X106.071 Y154.138 E.0028
G1 X97.145 Y154.143 E.21712
G1 X96.787 Y154.099 E.00877
G1 X95.837 Y153.882 E.0237
G1 X94.949 Y153.787 E.02172
G1 X94.333 Y153.761 E.015
G1 X91.767 Y153.759 E.06242
G1 X91.527 Y153.699 E.00602
G1 X91.324 Y153.562 E.00596
G1 X91.174 Y153.346 E.0064
G1 X91.1 Y153.018 E.00818
G1 X91.108 Y150.882 E.05196
G1 X91.235 Y150.548 E.00869
G1 X91.514 Y150.309 E.00894
G1 X91.798 Y150.24 E.00711
G1 X94.685 Y150.238 E.07022
G1 X95.687 Y150.143 E.02448
G1 X96.77 Y149.903 E.02698
G1 X97.145 Y149.857 E.00919
G1 X106.071 Y149.862 E.21712
G1 X106.137 Y149.892 E.00176
G1 E-5 F3600
G1 X106.137 Y149.892 F9000
G1 X96.863 Y156.096
G1 E5 F2400
G1 F6000
G1 X96.576 Y156.153 E.00712
G1 X95.73 Y156.474 E.02201
G1 X95.05 Y156.649 E.01708
G1 X94.534 Y156.673 E.01256
G1 X93.977 Y156.595 E.01368
G1 X93.494 Y156.442 E.01232
G1 X92.921 Y156.194 E.01519
G1 X92.397 Y155.899 E.01463
G1 X91.577 Y155.271 E.02512
G1 X91.101 Y154.78 E.01663
G1 X90.686 Y154.235 E.01666
G1 X90.302 Y153.57 E.01868
G1 X90.063 Y153.018 E.01463
G1 X89.791 Y152.022 E.02511
G1 X89.708 Y151.26 E.01864
G1 X89.7 Y85.609 E1.5969
G1 X89.745 Y85.374 E.00582
G1 X90.004 Y85.129 E.00867
G1 X90.027 Y85.039 E.00226
G1 X90.026 Y80.006 E.12242
G1 X90.068 Y79.327 E.01655
G1 X90.19 Y78.676 E.01611
G1 X90.396 Y78.023 E.01666
G1 X90.678 Y77.411 E.01639
G1 X91.033 Y76.838 E.0164
G1 X91.455 Y76.313 E.01638
G1 X91.939 Y75.844 E.01639
G1 X92.477 Y75.438 E.01639
G1 X93.06 Y75.101 E.01638
G1 X93.681 Y74.838 E.0164
G1 X94.329 Y74.654 E.01639
G1 X94.996 Y74.55 E.01642
G1 X95.631 Y74.526 E.01546
G1 X135.495 Y74.526 E.96965
G1 X136.003 Y74.55 E.01237
G1 X136.668 Y74.653 E.01637
G1 X137.636 Y74.961 E.02471
G1 X138.227 Y75.255 E.01606
G1 X138.798 Y75.632 E.01664
G1 X139.308 Y76.069 E.01634
G1 X139.969 Y76.84 E.0247
G1 X140.321 Y77.409 E.01627
G1 X140.712 Y78.331 E.02436
G1 X140.892 Y79.148 E.02035
G1 X140.963 Y79.66 E.01257
G1 X140.977 Y85.081 E.13186
G1 X141.233 Y85.352 E.00907
G1 X141.3 Y85.532 E.00467
G1 X141.3 Y150.994 E1.5923
G1 X141.259 Y151.685 E.01684
G1 X141.138 Y152.36 E.01668
G1 X140.938 Y153.016 E.01668
G1 X140.662 Y153.643 E.01666
G1 X140.314 Y154.234 E.01668
G1 X139.899 Y154.78 E.01668
G1 X139.422 Y155.273 E.01669
G1 X138.89 Y155.705 E.01667
G1 X138.311 Y156.073 E.01669
G1 X137.692 Y156.369 E.01669
G1 X137.127 Y156.559 E.0145
G1 X136.653 Y156.651 E.01174
G1 X136.316 Y156.661 E.0082
G1 X135.596 Y156.57 E.01765
G1 X134.395 Y156.144 E.031
G1 X133.855 Y156.04 E.01338
G1 X97.145 Y156.04 E.89293
G1 X96.922 Y156.084 E.00553
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X96.863 Y156.096 E-.0286
G1 X96.576 Y156.153 E-.13899
G1 X95.73 Y156.474 E-.4298
G1 X95.05 Y156.649 E-.33352
G1 X94.534 Y156.673 E-.24536
G1 X93.977 Y156.595 E-.26716
G1 X93.863 Y156.559 E-.05657
;WIPE_END
G1 X93.931 Y156.219 F9000
G1 X91.273 Y153.94
G1 X91.137 Y153.819
G1 X91.084 Y153.757
G1 X91.022 Y153.682
G1 X90.984 Y153.624
G1 X90.928 Y153.533
G1 X90.868 Y153.406
G1 X90.851 Y153.365
G1 X90.815 Y153.257
G1 X90.798 Y153.196
G1 X90.768 Y153.037
G1 X90.751 Y152.743
G1 X90.751 Y150.962
G1 X90.764 Y150.799
G1 X90.807 Y150.62
G1 X90.835 Y150.552
G1 X90.883 Y150.443
G1 X90.985 Y150.289
G1 X91.112 Y150.153
G1 X95.492 Y146.174
G1 X103.194 Y97.078
G1 X103.741 Y93.592
G1 X104.018 Y91.826
G1 X104.25 Y91.74
G1 X104.061 Y91.552
G1 X104.061 Y91.552
G1 E5 F2400
;TYPE:Perimeter
G1 F6000
G1 X102.878 Y91.552 E.02878
G1 X102.832 Y91.472 E.00224
G1 X102.783 Y91.252 E.00548
G1 X102.787 Y89.719 E.03729
G1 X102.86 Y89.664 E.00222
G1 X103.869 Y89.664 E.02454
G1 X103.572 Y90.075 E.01233
G1 X103.48 Y90.397 E.00815
G1 X103.544 Y90.842 E.01094
G1 X103.826 Y91.316 E.01342
G1 X104.019 Y91.51 E.00666
G1 X104.019 Y91.51 F9000
G1 X103.207 Y91.128
;WIDTH:0.517028
G1 F6000
G1 X103.189 Y90.981 E.00476
;WIDTH:0.479347
G1 X103.171 Y90.834 E.00438
;WIDTH:0.441665
G1 X103.152 Y90.687 E.00402
;WIDTH:0.403984
G1 X103.134 Y90.54 E.00364
;WIDTH:0.403635
G1 X103.153 Y90.295 E.00604
;WIDTH:0.440968
G1 X103.172 Y90.05 E.00665
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.153 Y90.295 E-.11672
G1 X103.134 Y90.54 E-.11672
G1 X103.152 Y90.687 E-.07035
G1 X103.171 Y90.834 E-.07041
G1 X103.189 Y90.981 E-.07035
G1 X103.207 Y91.128 E-.07035
;WIPE_END
G1 E-.9851 F3600
G1 X103.6 Y90.956 F9000
G1 X102.794 Y89.39
G1 X100.02 Y77.724
G1 X99.936 Y77.369
G1 X99.601 Y75.934
G1 X99.593 Y75.925
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X99.223 Y76.263 E.01219
G1 X98.828 Y76.682 E.01401
G1 X98.544 Y77.167 E.01367
G1 X98.481 Y77.496 E.00815
G1 X98.607 Y77.992 E.01245
G1 X98.9 Y78.403 E.01228
G1 X99.634 Y79.105 E.0247
G1 X99.642 Y82.182 E.07485
G1 X97.294 Y82.197 E.05711
G1 X97.218 Y81.776 E.01041
G1 X97.133 Y80.973 E.01964
G1 X97.083 Y79.793 E.02873
G1 X97.087 Y75.926 E.09406
G1 X99.533 Y75.925 E.0595
G1 E-5 F3600
G1 X99.533 Y75.925 F9000
G1 X99.569 Y75.964
G1 X99.25 Y76.26
G1 X99.029 Y76.48
G1 X98.877 Y76.645
G1 X98.764 Y76.783
G1 X98.676 Y76.91
G1 X98.605 Y77.033
G1 X98.55 Y77.16
G1 X98.511 Y77.292
G1 X98.49 Y77.43
G1 X98.49 Y77.57
G1 X98.511 Y77.708
G1 X98.55 Y77.84
G1 X98.605 Y77.967
G1 X98.676 Y78.09
G1 X98.764 Y78.217
G1 X98.877 Y78.355
G1 X99.029 Y78.52
G1 X99.25 Y78.74
G1 X99.52 Y78.991
G1 X99.269 Y79.262
G1 E5 F2400
G1 F6000
G1 X99.269 Y81.818 E.06217
G1 X97.598 Y81.829 E.04065
G1 X97.498 Y80.952 E.02147
G1 X97.449 Y79.791 E.02827
G1 X97.45 Y78.212 E.03841
;WIDTH:0.449269
G1 X97.475 Y77.984 E.00633
;WIDTH:0.498539
G1 X97.5 Y77.757 E.00705
;WIDTH:0.547809
G1 X97.525 Y77.529 E.00783
G1 X97.5 Y77.362 E.00577
;WIDTH:0.498539
G1 X97.476 Y77.195 E.00521
;WIDTH:0.449269
G1 X97.452 Y77.029 E.00463
;WIDTH:0.399999
G1 X97.452 Y76.291 E.01795
G1 X98.691 Y76.291 E.03014
G1 X98.584 Y76.403 E.00377
G1 X98.27 Y76.869 E.01367
G1 X98.185 Y77.098 E.00594
;WIDTH:0.449269
G1 X98.136 Y77.242 E.0042
;WIDTH:0.498539
G1 X98.087 Y77.386 E.0047
;WIDTH:0.547809
G1 X98.038 Y77.529 E.00516
G1 X98.08 Y77.702 E.00608
;WIDTH:0.514208
G1 X98.167 Y77.89 E.00661
;WIDTH:0.476139
G1 X98.254 Y78.077 E.00606
;WIDTH:0.438069
G1 X98.34 Y78.264 E.00553
;WIDTH:0.399999
G1 X98.647 Y78.668 E.01234
G1 X99.225 Y79.22 E.01944
G1 X99.225 Y79.22 F9000
G1 X98.903 Y79.418
G1 F6000
G1 X98.904 Y81.455 E.04955
G1 X97.92 Y81.461 E.02394
G1 X97.863 Y80.932 E.01294
G1 X97.814 Y79.788 E.02785
G1 X97.816 Y77.897 E.046
G1 X97.906 Y78.2 E.00769
G1 X98.046 Y78.481 E.00764
G1 X98.395 Y78.932 E.01387
G1 X98.86 Y79.377 E.01566
G1 X98.86 Y79.377 F9000
G1 X98.464 Y79.501
;WIDTH:0.395943
G1 F6000
G1 X98.54 Y79.574 E.00253
G1 X98.541 Y80.146 E.01376
;WIDTH:0.393425
G1 X98.553 Y81.106 E.02293
;WIDTH:0.370275
G1 X98.234 Y81.108 E.00713
;WIDTH:0.372266
G1 X98.214 Y80.912 E.00443
;WIDTH:0.396037
G1 X98.178 Y79.228 E.04053
;WIDTH:0.395943
G1 X98.421 Y79.46 E.00808
G1 E-5 F3600
G1 X98.421 Y79.46 F9000
G1 X97.873 Y76.713
G1 E5 F2400
;WIDTH:0.511604
G1 F6000
G1 X97.856 Y76.818 E.00338
;WIDTH:0.477224
G1 X97.839 Y76.923 E.00313
;WIDTH:0.442844
G1 X97.821 Y77.029 E.00292
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X97.839 Y76.923 E-.05107
G1 X97.856 Y76.818 E-.05052
G1 X97.873 Y76.713 E-.05052
;WIPE_END
G1 E-1.34789 F3600
G1 X98.604 Y77.036 F9000
G1 X99.929 Y77.623
G1 X103.184 Y79.063
G1 X127.142 Y89.669
G1 X127.147 Y89.665
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X128.188 Y89.668 E.02532
G1 X128.217 Y89.748 E.00207
G1 X128.212 Y91.271 E.03705
G1 X128.128 Y91.552 E.00713
G1 X126.951 Y91.552 E.02863
G1 X127.136 Y91.363 E.00643
G1 X127.422 Y90.934 E.01254
G1 X127.504 Y90.689 E.00628
G1 X127.518 Y90.456 E.00568
G1 X127.386 Y89.998 E.01159
G1 X127.182 Y89.714 E.00851
G1 X127.182 Y89.714 F9000
G1 X127.821 Y90.063
;WIDTH:0.45983
G1 F6000
G1 X127.842 Y90.359 E.0084
;WIDTH:0.415629
G1 X127.863 Y90.654 E.0075
;WIDTH:0.417052
G1 X127.839 Y90.814 E.00412
;WIDTH:0.462676
G1 X127.816 Y90.973 E.00458
;WIDTH:0.5083
G1 X127.793 Y91.132 E.00507
G1 E-5 F3600
G1 X127.793 Y91.132 F9000
G1 X133.706 Y82.197
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X131.353 Y82.182 E.05724
G1 X131.363 Y79.66 E.06135
G1 X131.365 Y79.114 E.01328
G1 X131.777 Y78.737 E.01358
G1 X132.151 Y78.345 E.01318
G1 X132.423 Y77.932 E.01203
G1 X132.523 Y77.591 E.00864
G1 X132.431 Y77.094 E.01229
G1 X132.147 Y76.65 E.01282
G1 X131.396 Y75.924 E.02541
G1 X133.917 Y75.924 E.06132
G1 X133.916 Y79.842 E.0953
G1 X133.895 Y80.53 E.01674
G1 X133.858 Y81.071 E.01319
G1 X133.714 Y82.137 E.02616
G1 X133.714 Y82.137 F9000
G1 X133.402 Y81.829
G1 F6000
G1 X131.72 Y81.818 E.04091
G1 X131.728 Y79.661 E.05247
G1 X131.73 Y79.276 E.00936
G1 X132.042 Y78.989 E.01031
G1 X132.416 Y78.597 E.01318
G1 X132.73 Y78.131 E.01367
;WIDTH:0.438389
G1 X132.787 Y78.015 E.00347
;WIDTH:0.476778
G1 X132.845 Y77.899 E.00382
;WIDTH:0.515167
G1 X132.902 Y77.783 E.00413
;WIDTH:0.553556
G1 X132.959 Y77.667 E.00446
;WIDTH:0.554128
G1 X132.959 Y77.447 E.00761
G1 X132.908 Y77.316 E.00486
;WIDTH:0.515596
G1 X132.857 Y77.185 E.0045
;WIDTH:0.477064
G1 X132.806 Y77.054 E.00414
;WIDTH:0.438532
G1 X132.755 Y76.923 E.00378
;WIDTH:0.399999
G1 X132.484 Y76.49 E.01243
G1 X132.3 Y76.29 E.00661
G1 X133.551 Y76.29 E.03043
;WIDTH:0.409255
G1 X133.547 Y77.026 E.01836
;WIDTH:0.455138
G1 X133.524 Y77.204 E.00502
;WIDTH:0.50102
G1 X133.501 Y77.381 E.00554
;WIDTH:0.546902
G1 X133.478 Y77.559 E.00612
G1 X133.502 Y77.731 E.00592
;WIDTH:0.497935
G1 X133.527 Y77.902 E.00533
;WIDTH:0.448967
G1 X133.551 Y78.074 E.00479
;WIDTH:0.399999
G1 X133.551 Y79.832 E.04276
G1 X133.531 Y80.507 E.01643
G1 X133.495 Y81.031 E.01278
G1 X133.409 Y81.769 E.01807
G1 X133.409 Y81.769 F9000
G1 X133.009 Y81.461
G1 F6000
G1 X132.087 Y81.455 E.02243
G1 X132.094 Y79.662 E.04361
G1 X132.095 Y79.438 E.00545
G1 X132.681 Y78.85 E.02019
G1 X133.037 Y78.33 E.01533
G1 X133.186 Y77.948 E.00997
G1 X133.185 Y79.821 E.04556
G1 X133.137 Y80.942 E.02729
G1 X133.08 Y81.461 E.0127
G1 X133.069 Y81.461 E.00027
G1 X133.069 Y81.461 F9000
G1 X132.764 Y81.107
;WIDTH:0.374013
G1 F6000
G1 X132.441 Y81.105 E.0073
;WIDTH:0.389238
G1 X132.451 Y80.449 E.01549
;WIDTH:0.397118
G1 X132.458 Y79.664 E.01894
G1 X132.459 Y79.599 E.00157
G1 X132.821 Y79.23 E.01247
;WIDTH:0.397348
G1 X132.806 Y80.461 E.02973
;WIDTH:0.389238
G1 X132.768 Y81.047 E.01386
G1 E-5 F3600
G1 X132.768 Y81.047 F9000
G1 X133.187 Y76.715
G1 E5 F2400
;WIDTH:0.51958
G1 F6000
G1 X133.156 Y76.768 E.00198
G1 X133.096 Y76.768 E.00194
G1 X133.065 Y76.715 E.00198
G1 X133.096 Y76.663 E.00195
G1 X133.156 Y76.663 E.00194
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X133.096 Y76.663 E-.0285
G1 X133.065 Y76.715 E-.02876
G1 X133.096 Y76.768 E-.02917
G1 X133.156 Y76.768 E-.0285
G1 X133.187 Y76.715 E-.02917
;WIPE_END
G1 E-1.3559 F3600
G1 X134.01 Y82.056 F9000
G1 X135.789 Y93.593
G1 X136.043 Y95.237
G1 X137.066 Y101.89
G1 X137.066 Y101.874
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.066 Y100.367 E.03666
G1 X140.072 Y100.367 E.07312
;WIDTH:0.448815
G1 X140.166 Y100.321 E.00289
;WIDTH:0.497631
G1 X140.259 Y100.275 E.0032
;WIDTH:0.546446
G1 X140.353 Y100.229 E.00357
G1 X140.355 Y100.185 E.0015
;WIDTH:0.542627
G1 X140.355 Y95.562 E.15631
;WIDTH:0.553542
G1 X140.338 Y95.413 E.00518
G1 X140.342 Y93.395 E.0697
;WIDTH:0.55132
G1 X140.355 Y93.263 E.00456
;WIDTH:0.542643
G1 X140.357 Y85.656 E.25721
;WIDTH:0.541265
G1 X140.864 Y85.654 E.0171
G1 X140.864 Y85.908 E.00857
;WIDTH:0.542643
G1 X140.863 Y93.263 E.24869
;WIDTH:0.55132
G1 X140.859 Y93.395 E.00454
;WIDTH:0.553542
G1 X140.863 Y95.562 E.07484
;WIDTH:0.542627
G1 X140.863 Y100.185 E.15631
;WIDTH:0.546446
G1 X140.885 Y100.582 E.01354
;WIDTH:0.497631
G1 X140.91 Y100.892 E.00958
;WIDTH:0.448815
G1 X140.934 Y101.201 E.00855
;WIDTH:0.399999
G1 X140.934 Y101.706 E.01228
;WIDTH:0.402481
G1 X140.933 Y102.407 E.01717
;WIDTH:0.446417
G1 X140.911 Y102.457 E.0015
;WIDTH:0.490352
G1 X140.889 Y102.508 E.00168
;WIDTH:0.534288
G1 X140.867 Y102.558 E.00182
;WIDTH:0.578223
G1 X140.845 Y102.608 E.00198
G1 X140.858 Y102.982 E.01354
;WIDTH:0.551383
G1 X140.858 Y105.018 E.07003
G1 X140.883 Y105.178 E.00557
;WIDTH:0.501865
G1 X140.908 Y105.339 E.00507
;WIDTH:0.452361
G1 X140.933 Y105.499 E.0045
;WIDTH:0.402856
G1 X140.934 Y105.71 E.00517
;WIDTH:0.399999
G1 X140.934 Y110.29 E.1114
;WIDTH:0.438385
G1 X140.915 Y110.449 E.0043
;WIDTH:0.476771
G1 X140.896 Y110.607 E.00468
;WIDTH:0.515157
G1 X140.876 Y110.766 E.00513
;WIDTH:0.553542
G1 X140.857 Y110.924 E.0055
G1 X140.858 Y113.018 E.07232
;WIDTH:0.551313
G1 X140.877 Y113.148 E.00452
;WIDTH:0.513485
G1 X140.896 Y113.278 E.00419
;WIDTH:0.475656
G1 X140.915 Y113.408 E.00386
;WIDTH:0.437828
G1 X140.934 Y113.538 E.00353
;WIDTH:0.399999
G1 X140.934 Y117.706 E.10138
;WIDTH:0.402413
G1 X140.933 Y118.407 E.01716
;WIDTH:0.446338
G1 X140.911 Y118.457 E.0015
;WIDTH:0.490262
G1 X140.889 Y118.508 E.00168
;WIDTH:0.534186
G1 X140.867 Y118.558 E.00182
;WIDTH:0.57811
G1 X140.845 Y118.608 E.00198
G1 X140.858 Y118.982 E.01354
;WIDTH:0.551272
G1 X140.858 Y121.018 E.07001
G1 X140.883 Y121.178 E.00557
;WIDTH:0.501791
G1 X140.908 Y121.339 E.00507
;WIDTH:0.452325
G1 X140.932 Y121.499 E.0045
;WIDTH:0.402858
G1 X140.934 Y121.71 E.00517
;WIDTH:0.399999
G1 X140.934 Y125.706 E.0972
;WIDTH:0.40238
G1 X140.933 Y126.407 E.01716
;WIDTH:0.446299
G1 X140.911 Y126.457 E.0015
;WIDTH:0.490217
G1 X140.889 Y126.508 E.00168
;WIDTH:0.534136
G1 X140.867 Y126.558 E.00182
;WIDTH:0.578054
G1 X140.845 Y126.608 E.00198
G1 X140.858 Y126.982 E.01354
;WIDTH:0.555007
G1 X140.856 Y129.12 E.07405
G1 X140.876 Y129.222 E.0036
;WIDTH:0.516255
G1 X140.895 Y129.323 E.00329
;WIDTH:0.477503
G1 X140.914 Y129.424 E.00303
;WIDTH:0.438751
G1 X140.934 Y129.525 E.00277
;WIDTH:0.399999
G1 X140.934 Y133.706 E.1017
;WIDTH:0.40234
G1 X140.932 Y134.407 E.01716
;WIDTH:0.446253
G1 X140.911 Y134.458 E.00151
;WIDTH:0.490166
G1 X140.889 Y134.508 E.00166
;WIDTH:0.534079
G1 X140.867 Y134.558 E.00182
;WIDTH:0.577992
G1 X140.845 Y134.608 E.00198
G1 X140.858 Y134.982 E.01353
;WIDTH:0.554952
G1 X140.856 Y137.121 E.07408
G1 X140.876 Y137.232 E.00391
;WIDTH:0.516214
G1 X140.895 Y137.343 E.00361
;WIDTH:0.477476
G1 X140.914 Y137.454 E.00332
;WIDTH:0.438738
G1 X140.934 Y137.565 E.00303
;WIDTH:0.399999
G1 X140.934 Y142.284 E.11478
;WIDTH:0.437775
G1 X140.915 Y142.459 E.00472
;WIDTH:0.475551
G1 X140.896 Y142.633 E.00514
;WIDTH:0.513327
G1 X140.877 Y142.807 E.00558
;WIDTH:0.551103
G1 X140.858 Y142.982 E.00605
;WIDTH:0.554896
G1 X140.856 Y145.121 E.07407
G1 X140.875 Y145.232 E.0039
;WIDTH:0.516172
G1 X140.895 Y145.343 E.00362
;WIDTH:0.477448
G1 X140.914 Y145.453 E.00329
;WIDTH:0.438724
G1 X140.934 Y145.564 E.00303
;WIDTH:0.399999
G1 X140.933 Y150.274 E.11457
;WIDTH:0.44249
G1 X140.912 Y150.381 E.00296
;WIDTH:0.48498
G1 X140.891 Y150.489 E.0033
;WIDTH:0.52747
G1 X140.87 Y150.597 E.00361
;WIDTH:0.56996
G1 X140.848 Y150.704 E.00389
G1 X140.856 Y151.004 E.01069
;WIDTH:0.554664
G1 X140.824 Y151.661 E.02277
;WIDTH:0.53284
G1 X140.71 Y152.282 E.02094
G1 X140.532 Y152.859 E.02002
;WIDTH:0.577946
G1 X140.319 Y153.292 E.01745
G1 X140.331 Y152.829 E.01675
;WIDTH:0.53284
G1 X140.327 Y151.632 E.03969
;WIDTH:0.56996
G1 X140.328 Y150.793 E.02989
G1 X140.272 Y150.698 E.00393
;WIDTH:0.52747
G1 X140.217 Y150.604 E.00357
;WIDTH:0.48498
G1 X140.161 Y150.509 E.00331
;WIDTH:0.44249
G1 X140.105 Y150.415 E.00297
;WIDTH:0.399999
G1 X139.837 Y150.1 E.01006
G1 X139.5 Y149.925 E.00924
G1 X139.05 Y149.882 E.011
G1 X136.338 Y149.873 E.06597
G1 X135.476 Y149.791 E.02106
G1 X135.443 Y149.646 E.00362
G1 X135.443 Y147.136 E.06105
G1 X135.453 Y146.206 E.02262
G1 X135.861 Y146.149 E.01002
G1 X136.432 Y146.127 E.0139
G1 X139.202 Y146.126 E.06738
G1 X139.605 Y146.031 E.01007
G1 X139.821 Y145.909 E.00603
G1 X140.138 Y145.531 E.012
;WIDTH:0.438724
G1 X140.188 Y145.428 E.00308
;WIDTH:0.477448
G1 X140.237 Y145.326 E.00334
;WIDTH:0.516172
G1 X140.286 Y145.223 E.00366
;WIDTH:0.554896
G1 X140.336 Y145.12 E.00396
G1 X140.341 Y142.983 E.074
;WIDTH:0.551105
G1 X140.289 Y142.846 E.00504
;WIDTH:0.503127
G1 X140.237 Y142.709 E.00457
;WIDTH:0.455148
G1 X140.185 Y142.572 E.0041
;WIDTH:0.407169
G1 X139.974 Y142.226 E.01005
;WIDTH:0.399999
G1 X139.675 Y141.996 E.00918
G1 X139.202 Y141.874 E.01188
G1 X136.337 Y141.873 E.06969
G1 X135.467 Y141.79 E.02126
G1 X135.443 Y141.499 E.0071
G1 X135.439 Y139.016 E.0604
G1 X135.411 Y138.919 E.00246
G1 X135.179 Y138.802 E.00632
G1 X135.538 Y138.127 E.0186
G1 X139.233 Y138.124 E.08988
G1 X139.614 Y138.032 E.00953
G1 X139.927 Y137.823 E.00915
G1 X140.147 Y137.52 E.00911
;WIDTH:0.438738
G1 X140.194 Y137.42 E.00297
;WIDTH:0.477476
G1 X140.241 Y137.32 E.00326
;WIDTH:0.516214
G1 X140.288 Y137.22 E.00354
;WIDTH:0.554952
G1 X140.336 Y137.12 E.00384
G1 X140.341 Y134.982 E.07404
;WIDTH:0.577992
G1 X140.305 Y134.652 E.012
G1 X140.277 Y134.64 E.0011
;WIDTH:0.534079
G1 X140.25 Y134.628 E.00098
;WIDTH:0.490166
G1 X140.223 Y134.616 E.0009
;WIDTH:0.446253
G1 X140.196 Y134.604 E.00081
;WIDTH:0.40234
G1 X139.993 Y134.254 E.0099
;WIDTH:0.399999
G1 X139.679 Y133.999 E.00984
G1 X139.202 Y133.874 E.01199
G1 X136.965 Y133.873 E.05441
G1 X137.055 Y133.069 E.01968
G1 X137.064 Y130.124 E.07163
G1 X139.292 Y130.117 E.05419
G1 X139.644 Y130.019 E.00889
G1 X139.951 Y129.799 E.00919
G1 X140.208 Y129.346 E.01267
;WIDTH:0.43893
G1 X140.235 Y129.326 E.0009
;WIDTH:0.477861
G1 X140.263 Y129.306 E.00102
;WIDTH:0.516434
G1 X140.299 Y129.213 E.0032
;WIDTH:0.555007
G1 X140.336 Y129.119 E.0035
G1 X140.341 Y126.982 E.07402
;WIDTH:0.578054
G1 X140.305 Y126.652 E.01201
G1 X140.277 Y126.64 E.0011
;WIDTH:0.534136
G1 X140.25 Y126.628 E.00098
;WIDTH:0.490217
G1 X140.223 Y126.616 E.0009
;WIDTH:0.446299
G1 X140.196 Y126.604 E.00081
;WIDTH:0.40238
G1 X139.993 Y126.254 E.00991
;WIDTH:0.399999
G1 X139.679 Y125.999 E.00984
G1 X139.202 Y125.874 E.01199
G1 X137.066 Y125.874 E.05196
G1 X137.066 Y122.124 E.09122
G1 X139.292 Y122.117 E.05415
G1 X139.644 Y122.019 E.00889
G1 X139.951 Y121.799 E.00919
G1 X140.163 Y121.486 E.0092
;WIDTH:0.437814
G1 X140.207 Y121.369 E.00335
;WIDTH:0.475628
G1 X140.252 Y121.252 E.00368
;WIDTH:0.513443
G1 X140.297 Y121.135 E.004
;WIDTH:0.551257
G1 X140.341 Y121.018 E.0043
G1 X140.341 Y118.982 E.07001
;WIDTH:0.57811
G1 X140.305 Y118.652 E.01201
G1 X140.277 Y118.64 E.0011
;WIDTH:0.534186
G1 X140.25 Y118.628 E.00098
;WIDTH:0.490262
G1 X140.223 Y118.616 E.0009
;WIDTH:0.446338
G1 X140.196 Y118.604 E.00081
;WIDTH:0.402413
G1 X139.993 Y118.254 E.00991
;WIDTH:0.399999
G1 X139.679 Y117.999 E.00984
G1 X139.202 Y117.874 E.01199
G1 X137.066 Y117.874 E.05196
G1 X137.066 Y114.126 E.09117
G1 X138.94 Y114.126 E.04558
G1 X139.476 Y114.083 E.01308
G1 X139.912 Y113.828 E.01229
G1 X140.145 Y113.521 E.00937
;WIDTH:0.437828
G1 X140.194 Y113.396 E.0036
;WIDTH:0.475656
G1 X140.243 Y113.27 E.00397
;WIDTH:0.513485
G1 X140.292 Y113.144 E.00431
;WIDTH:0.551313
G1 X140.341 Y113.018 E.00465
;WIDTH:0.553542
G1 X140.338 Y110.924 E.07232
;WIDTH:0.559916
G1 X140.335 Y110.868 E.00196
G1 X140.25 Y110.713 E.00618
;WIDTH:0.519937
G1 X140.165 Y110.558 E.00571
;WIDTH:0.479958
G1 X140.08 Y110.403 E.00524
;WIDTH:0.439979
G1 X139.994 Y110.249 E.00476
;WIDTH:0.399999
G1 X139.702 Y110.011 E.00916
G1 X139.292 Y109.883 E.01045
G1 X137.066 Y109.876 E.05415
G1 X137.066 Y106.124 E.09126
G1 X139.292 Y106.117 E.05415
G1 X139.644 Y106.019 E.00889
G1 X139.951 Y105.799 E.00919
G1 X140.163 Y105.486 E.0092
;WIDTH:0.437842
G1 X140.207 Y105.369 E.00336
;WIDTH:0.475684
G1 X140.252 Y105.252 E.00368
;WIDTH:0.513527
G1 X140.297 Y105.135 E.004
;WIDTH:0.551369
G1 X140.341 Y105.018 E.0043
G1 X140.341 Y102.982 E.07002
;WIDTH:0.578223
G1 X140.305 Y102.652 E.01201
G1 X140.277 Y102.64 E.0011
;WIDTH:0.534288
G1 X140.25 Y102.628 E.00098
;WIDTH:0.490352
G1 X140.223 Y102.616 E.0009
;WIDTH:0.446417
G1 X140.196 Y102.604 E.00081
;WIDTH:0.402481
G1 X139.993 Y102.254 E.00991
;WIDTH:0.399999
G1 X139.679 Y101.999 E.00984
G1 X139.202 Y101.874 E.01199
G1 X137.126 Y101.874 E.0505
G1 E-5 F3600
G1 X137.126 Y101.874 F9000
G1 X137.126 Y101.89
G1 X137.815 Y101.89
G1 X139.216 Y101.891
G1 X139.281 Y101.895
G1 X139.397 Y101.91
G1 X139.57 Y101.959
G1 X139.738 Y102.042
G1 X139.888 Y102.153
G1 X140.015 Y102.289
G1 X140.117 Y102.443
G1 X140.165 Y102.552
G1 X140.193 Y102.62
G1 X140.236 Y102.799
G1 X140.249 Y102.962
G1 X140.249 Y113.038
G1 X140.236 Y113.201
G1 X140.217 Y113.281
G1 X140.568 Y113.366
G1 E5 F2400
G1 F6000
G1 X140.568 Y118.002 E.11277
;WIDTH:0.402413
G1 X140.565 Y118.56 E.01366
G1 X140.309 Y118.071 E.01351
;WIDTH:0.399999
G1 X140.164 Y117.907 E.00532
G1 X139.899 Y117.707 E.00808
G1 X139.696 Y117.611 E.00546
G1 X139.202 Y117.508 E.01227
G1 X137.431 Y117.508 E.04308
G1 X137.431 Y114.492 E.07336
G1 X139.291 Y114.484 E.04524
G1 X139.736 Y114.369 E.01118
G1 X140.105 Y114.139 E.01058
G1 X140.265 Y113.988 E.00535
G1 X140.445 Y113.731 E.00763
G1 X140.549 Y113.423 E.00791
G1 E-5 F3600
G1 X140.549 Y113.423 F9000
G1 X137.805 Y114.857
G1 E5 F2400
G1 F6000
G1 X139.06 Y114.857 E.03053
G1 X139.595 Y114.805 E.01307
G1 X139.929 Y114.679 E.00868
G1 X140.203 Y114.509 E.00784
G1 X140.203 Y117.478 E.07222
G1 X139.781 Y117.255 E.01161
G1 X139.202 Y117.143 E.01434
G1 X137.797 Y117.143 E.03418
G1 X137.797 Y114.91 E.05432
G1 X137.797 Y114.91 F9000
G1 X138.163 Y115.223
G1 F6000
G1 X139.41 Y115.206 E.03033
G1 X139.837 Y115.097 E.01072
G1 X139.837 Y116.893 E.04369
G1 X139.202 Y116.777 E.0157
G1 X138.163 Y116.777 E.02527
G1 X138.163 Y115.283 E.03634
G1 E-5 F3600
G1 X138.163 Y115.283 F9000
G1 X139.888 Y113.847
G1 X140.015 Y113.711
G1 X140.117 Y113.557
G1 X140.165 Y113.448
G1 X140.193 Y113.38
G1 X140.249 Y110.962
G1 X140.236 Y110.799
G1 X140.22 Y110.734
G1 X140.21 Y110.689
G1 X140.568 Y110.603
G1 E5 F2400
G1 F6000
G1 X140.471 Y110.318 E.00732
G1 X140.174 Y109.911 E.01226
G1 X139.749 Y109.63 E.01239
G1 X139.293 Y109.517 E.01143
G1 X137.431 Y109.511 E.04529
G1 X137.431 Y106.489 E.07351
G1 X139.293 Y106.483 E.04529
G1 X139.749 Y106.37 E.01143
G1 X140.174 Y106.089 E.01239
G1 X140.472 Y105.682 E.01227
;WIDTH:0.402856
G1 X140.564 Y105.428 E.00662
G1 X140.568 Y105.71 E.00691
;WIDTH:0.399999
G1 X140.568 Y110.543 E.11756
G1 E-5 F3600
G1 X140.568 Y110.543 F9000
G1 X138.239 Y109.148
G1 E5 F2400
G1 F6000
G1 X137.797 Y109.147 E.01075
G1 X137.797 Y106.853 E.0558
G1 X139.294 Y106.848 E.03641
G1 X139.854 Y106.72 E.01397
G1 X140.203 Y106.527 E.0097
G1 X140.203 Y109.473 E.07166
G1 X139.854 Y109.28 E.0097
G1 X139.294 Y109.152 E.01397
G1 X138.299 Y109.148 E.0242
G1 X138.299 Y109.148 F9000
G1 X138.36 Y108.783
G1 F6000
G1 X138.163 Y108.782 E.00479
G1 X138.163 Y107.218 E.03804
G1 X139.295 Y107.214 E.02753
G1 X139.837 Y107.107 E.01344
G1 X139.837 Y108.893 E.04344
G1 X139.295 Y108.786 E.01344
G1 X138.42 Y108.783 E.02128
G1 E-5 F3600
G1 X140.117 Y105.557 F9000
G1 X140.165 Y105.448
G1 X140.193 Y105.38
G1 X140.236 Y105.201
G1 X140.249 Y105.038
G1 X140.193 Y102.62
G1 X139.57 Y101.959
G1 X139.397 Y101.91
G1 X137.815 Y101.89
G1 X137.54 Y101.89
G1 X137.432 Y101.89
G1 X137.431 Y101.508
G1 E5 F2400
G1 F6000
G1 X137.431 Y100.733 E.01885
G1 X140.1 Y100.733 E.06492
G1 X140.568 Y100.34 E.01486
G1 X140.568 Y102.002 E.04043
;WIDTH:0.402481
G1 X140.565 Y102.561 E.01369
G1 X140.309 Y102.071 E.01354
;WIDTH:0.399999
G1 X140.164 Y101.907 E.00532
G1 X139.899 Y101.707 E.00808
G1 X139.696 Y101.611 E.00546
G1 X139.202 Y101.508 E.01227
G1 X137.491 Y101.508 E.04162
G1 X137.491 Y101.508 F9000
G1 X137.819 Y101.121
;WIDTH:0.443924
G1 F6000
G1 X139.202 Y101.121 E.03768
;WIDTH:0.469958
G1 X139.422 Y101.134 E.00639
G1 X139.422 Y101.134 F9000
G1 X139.796 Y101.285
;WIDTH:0.429215
G1 F6000
G1 X139.614 Y101.211 E.00516
;WIDTH:0.469958
G1 X139.422 Y101.134 E.00599
G1 X139.639 Y101.113 E.00632
;WIDTH:0.429215
G1 X139.856 Y101.093 E.00572
;WIDTH:0.388471
G1 X140.072 Y101.073 E.00511
;WIDTH:0.347727
G1 X140.229 Y100.965 E.00397
G1 X140.229 Y101.53 E.01178
G1 X139.997 Y101.367 E.00591
;WIDTH:0.388471
G1 X139.851 Y101.308 E.00371
G1 E-5 F3600
G1 X139.851 Y101.308 F9000
G1 X139.57 Y101.959
G1 X140.193 Y102.62
G1 X140.249 Y121.038
G1 X140.236 Y121.201
G1 X140.193 Y121.38
G1 X140.165 Y121.448
G1 X140.117 Y121.557
G1 X140.015 Y121.711
G1 X139.888 Y121.847
G1 X139.738 Y121.958
G1 X139.57 Y122.041
G1 X139.397 Y122.09
G1 X139.281 Y122.105
G1 X139.216 Y122.109
G1 X137.815 Y122.11
G1 X137.54 Y122.11
G1 X137.432 Y122.11
G1 X137.431 Y122.489
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X139.293 Y122.483 E.04529
G1 X139.749 Y122.37 E.01143
G1 X140.174 Y122.089 E.01239
G1 X140.472 Y121.682 E.01227
;WIDTH:0.402858
G1 X140.564 Y121.429 E.0066
G1 X140.568 Y121.71 E.00689
;WIDTH:0.399999
G1 X140.568 Y126.002 E.1044
;WIDTH:0.40238
G1 X140.565 Y126.56 E.01366
G1 X140.309 Y126.071 E.01351
;WIDTH:0.399999
G1 X140.164 Y125.907 E.00532
G1 X139.899 Y125.707 E.00808
G1 X139.696 Y125.611 E.00546
G1 X139.202 Y125.508 E.01227
G1 X137.431 Y125.508 E.04308
G1 X137.431 Y122.549 E.07197
G1 X137.431 Y122.549 F9000
G1 X137.797 Y123.75
G1 F6000
G1 X137.797 Y122.853 E.02182
G1 X139.294 Y122.848 E.03641
G1 X139.854 Y122.72 E.01397
G1 X140.202 Y122.527 E.00968
G1 X140.202 Y125.478 E.07178
G1 X139.781 Y125.255 E.01159
G1 X139.202 Y125.143 E.01434
G1 X137.797 Y125.143 E.03418
G1 X137.797 Y123.81 E.03242
G1 X137.797 Y123.81 F9000
G1 X138.163 Y123.771
G1 F6000
G1 X138.163 Y123.218 E.01345
G1 X139.295 Y123.214 E.02753
G1 X139.837 Y123.107 E.01344
G1 X139.837 Y124.893 E.04344
G1 X139.202 Y124.777 E.0157
G1 X138.163 Y124.777 E.02527
G1 X138.163 Y123.831 E.02301
G1 E-5 F3600
G1 X138.163 Y123.831 F9000
G1 X140.015 Y126.289
G1 X140.117 Y126.443
G1 X140.165 Y126.552
G1 X140.193 Y126.62
G1 X140.236 Y126.799
G1 X140.249 Y126.962
G1 X140.249 Y129.038
G1 X140.236 Y129.201
G1 X140.193 Y129.38
G1 X140.165 Y129.448
G1 X140.117 Y129.557
G1 X140.015 Y129.711
G1 X137.036 Y133.106
G1 X137.012 Y133.453
G1 X137.377 Y133.478
G1 E5 F2400
G1 F6000
G1 X137.42 Y133.07 E.00998
G1 X137.428 Y130.489 E.06278
G1 X139.293 Y130.483 E.04536
G1 X139.749 Y130.37 E.01143
G1 X140.173 Y130.089 E.01237
G1 X140.326 Y129.908 E.00576
G1 X140.568 Y129.414 E.01338
G1 X140.568 Y134.002 E.1116
;WIDTH:0.40234
G1 X140.564 Y134.56 E.01366
G1 X140.309 Y134.071 E.0135
;WIDTH:0.399999
G1 X140.164 Y133.907 E.00532
G1 X139.899 Y133.707 E.00808
G1 X139.696 Y133.611 E.00546
G1 X139.202 Y133.508 E.01227
G1 X137.404 Y133.508 E.04373
G1 X137.404 Y133.508 F9000
G1 X137.784 Y132.72
G1 F6000
G1 X137.793 Y130.853 E.04541
G1 X139.294 Y130.848 E.03651
G1 X139.854 Y130.72 E.01397
G1 X140.202 Y130.528 E.00967
G1 X140.202 Y133.478 E.07176
G1 X139.781 Y133.255 E.01159
G1 X139.202 Y133.143 E.01434
G1 X137.782 Y133.142 E.03454
G1 X137.784 Y132.78 E.00881
G1 X137.784 Y132.78 F9000
G1 X138.154 Y132.28
G1 F6000
G1 X138.158 Y131.218 E.02583
G1 X139.295 Y131.214 E.02766
G1 X139.837 Y131.107 E.01344
G1 X139.837 Y132.893 E.04344
G1 X139.202 Y132.777 E.0157
G1 X138.153 Y132.777 E.02552
G1 X138.154 Y132.34 E.01063
G1 E-5 F3600
G1 X138.154 Y132.34 F9000
G1 X139.888 Y134.153
G1 X140.015 Y134.289
G1 X140.117 Y134.443
G1 X140.165 Y134.552
G1 X140.193 Y134.62
G1 X140.236 Y134.799
G1 X140.249 Y134.962
G1 X140.249 Y137.038
G1 X140.193 Y142.62
G1 X140.553 Y142.493
G1 E5 F2400
;WIDTH:0.407169
G1 F6000
G1 X140.465 Y142.315 E.00492
;WIDTH:0.399999
G1 X140.14 Y141.88 E.01321
G1 X139.696 Y141.611 E.01263
G1 X139.202 Y141.508 E.01227
G1 X136.354 Y141.507 E.06927
G1 X135.809 Y141.455 E.01332
G1 X135.804 Y139.015 E.05935
G1 X135.721 Y138.725 E.00734
G1 X135.659 Y138.678 E.00189
G1 X135.758 Y138.493 E.0051
G1 X139.233 Y138.49 E.08453
G1 X139.705 Y138.387 E.01175
G1 X140.14 Y138.12 E.01242
G1 X140.449 Y137.726 E.01218
G1 X140.568 Y137.4 E.00844
G1 X140.568 Y141.945 E.11055
;WIDTH:0.407169
G1 X140.555 Y142.433 E.01211
G1 X140.555 Y142.433 F9000
G1 X140.202 Y141.474
;WIDTH:0.399999
G1 F6000
G1 X139.781 Y141.255 E.01154
G1 X139.202 Y141.143 E.01434
G1 X136.174 Y141.123 E.07365
G1 X136.17 Y139.015 E.05128
G1 X136.125 Y138.858 E.00397
G1 X139.234 Y138.856 E.07562
G1 X139.796 Y138.741 E.01395
G1 X140.202 Y138.526 E.01117
G1 X140.202 Y141.414 E.07025
G1 X140.202 Y141.414 F9000
G1 X139.837 Y140.893
G1 F6000
G1 X139.202 Y140.777 E.0157
G1 X136.539 Y140.776 E.06477
G1 X136.536 Y139.224 E.03775
G1 X139.234 Y139.221 E.06563
G1 X139.837 Y139.108 E.01492
G1 X139.837 Y140.833 E.04196
G1 E-5 F3600
G1 X139.837 Y140.833 F9000
G1 X140.236 Y142.799
G1 X140.249 Y142.962
G1 X140.249 Y145.038
G1 X140.236 Y145.201
G1 X139.57 Y149.959
G1 X139.708 Y149.639
G1 E5 F2400
G1 F6000
G1 X139.459 Y149.543 E.00649
G1 X139.051 Y149.516 E.00995
G1 X136.356 Y149.507 E.06555
G1 X135.808 Y149.455 E.01339
G1 X135.808 Y146.526 E.07124
G1 X136.439 Y146.493 E.01537
G1 X139.202 Y146.492 E.06721
G1 X139.693 Y146.386 E.01222
G1 X140.012 Y146.221 E.00874
G1 X140.424 Y145.76 E.01504
G1 X140.568 Y145.4 E.00943
G1 X140.568 Y150.629 E.12719
G1 X140.45 Y150.294 E.00864
G1 X140.337 Y150.105 E.00536
G1 X139.938 Y149.729 E.01334
G1 X139.764 Y149.661 E.00454
G1 X139.764 Y149.661 F9000
G1 X139.852 Y149.285
G1 F6000
G1 X139.815 Y149.265 E.00102
G1 X139.484 Y149.178 E.00832
G1 X139.052 Y149.151 E.01053
G1 X136.174 Y149.123 E.07001
G1 X136.174 Y146.869 E.05483
G1 X139.202 Y146.857 E.07365
G1 X139.781 Y146.741 E.01436
G1 X140.202 Y146.534 E.01141
G1 X140.202 Y149.477 E.07159
G1 X139.905 Y149.314 E.00824
G1 X139.905 Y149.314 F9000
G1 X139.836 Y148.899
G1 F6000
G1 X139.509 Y148.813 E.00822
G1 X139.054 Y148.785 E.01109
G1 X136.54 Y148.776 E.06115
G1 X136.54 Y147.224 E.03775
G1 X139.202 Y147.223 E.06475
G1 X139.836 Y147.104 E.01569
G1 X139.836 Y148.839 E.0422
G1 E-5 F3600
G1 X139.836 Y148.839 F9000
G1 E5 F2400
;WIDTH:0.577946
G1 F6000
G1 X140.289 Y153.377 E.00326
;WIDTH:0.562496
G1 X140.039 Y153.82 E.01787
G1 X140.039 Y153.82 F9000
G1 X139.912 Y153.883
;WIDTH:0.520635
G1 F6000
G1 X139.933 Y153.873 E.00075
;WIDTH:0.560846
G1 X140.039 Y153.82 E.00415
G1 X139.999 Y153.915 E.00361
;WIDTH:0.520635
G1 X139.959 Y154.01 E.00333
;WIDTH:0.480423
G1 X139.919 Y154.105 E.00306
;WIDTH:0.440211
G1 X139.879 Y154.2 E.00278
;WIDTH:0.399999
G1 X139.596 Y154.567 E.01127
G1 X139.143 Y155.028 E.01572
G1 X138.676 Y155.408 E.01464
G1 X138.133 Y155.752 E.01564
G1 X137.555 Y156.029 E.01559
G1 X137.011 Y156.212 E.01396
G1 X136.475 Y156.308 E.01325
G1 X135.846 Y156.252 E.01536
G1 X135.437 Y156.137 E.01033
G1 X135.453 Y154.208 E.04692
G1 X135.963 Y154.142 E.01251
G1 X139.236 Y154.124 E.07961
G1 X139.614 Y154.032 E.00946
;WIDTH:0.440211
G1 X139.72 Y153.979 E.0032
;WIDTH:0.480423
G1 X139.827 Y153.926 E.00354
;WIDTH:0.520635
G1 X139.859 Y153.91 E.00116
G1 X139.859 Y153.91 F9000
G1 X139.158 Y154.49
;WIDTH:0.399999
G1 F6000
G1 X138.896 Y154.757 E.0091
G1 X138.462 Y155.111 E.01362
G1 X137.956 Y155.432 E.01458
G1 X137.417 Y155.69 E.01454
G1 X136.894 Y155.865 E.01341
G1 X136.39 Y155.933 E.01237
G1 X135.803 Y155.867 E.01437
G1 X135.808 Y154.53 E.03252
G1 X135.987 Y154.507 E.00439
G1 X139.098 Y154.491 E.07567
G1 X139.098 Y154.491 F9000
G1 X137.911 Y154.938
;WIDTH:0.550683
G1 F6000
G1 X137.742 Y155.045 E.00687
G1 X137.251 Y155.28 E.0187
G1 X136.732 Y155.455 E.01881
;WIDTH:0.561589
G1 X136.251 Y155.472 E.01688
G1 X136.253 Y154.952 E.01824
G1 X136.67 Y154.945 E.01463
;WIDTH:0.550683
G1 X137.851 Y154.938 E.04057
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X137.911 Y154.938 E-.0285
G1 X137.742 Y155.045 E-.09501
G1 X137.251 Y155.28 E-.25856
G1 X136.732 Y155.455 E-.26016
G1 X136.251 Y155.472 E-.22862
G1 X136.253 Y154.952 E-.247
G1 X136.67 Y154.945 E-.1981
G1 X137.057 Y154.943 E-.18405
;WIPE_END
G1 X135.166 Y154.997 F9000
G1 X95.572 Y156.158
G1 X95.563 Y156.133
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X95.095 Y156.26 E.0118
G1 X94.576 Y156.308 E.01268
G1 X94.063 Y156.239 E.01259
G1 X93.527 Y156.058 E.01376
G1 X93.042 Y155.843 E.0129
G1 X92.554 Y155.559 E.01373
G1 X91.794 Y154.97 E.02339
G1 X91.295 Y154.43 E.01788
;WIDTH:0.442001
G1 X91.252 Y154.338 E.00275
;WIDTH:0.484003
G1 X91.209 Y154.246 E.00304
;WIDTH:0.526005
G1 X91.166 Y154.154 E.00332
;WIDTH:0.568006
G1 X91.123 Y154.063 E.00357
;WIDTH:0.610008
G1 X91.08 Y153.971 E.00389
G1 X91.152 Y153.996 E.00292
;WIDTH:0.568637
G1 X91.305 Y154.028 E.00556
;WIDTH:0.526478
G1 X91.459 Y154.06 E.00515
;WIDTH:0.484318
G1 X91.613 Y154.092 E.00471
;WIDTH:0.442159
G1 X91.767 Y154.124 E.00427
;WIDTH:0.399999
G1 X94.663 Y154.127 E.07044
G1 X95.524 Y154.209 E.02104
G1 X95.557 Y154.355 E.00364
G1 X95.562 Y155.696 E.03262
G1 X95.563 Y156.073 E.00917
G1 X95.563 Y156.073 F9000
G1 X95.197 Y155.853
G1 F6000
G1 X94.651 Y155.934 E.01343
G1 X94.21 Y155.89 E.01078
G1 X93.725 Y155.742 E.01233
G1 X93.247 Y155.538 E.01264
G1 X92.801 Y155.287 E.01245
G1 X92.073 Y154.73 E.0223
G1 X91.841 Y154.49 E.00812
G1 X94.645 Y154.493 E.0682
G1 X95.192 Y154.545 E.01337
G1 X95.196 Y155.697 E.02802
G1 X95.197 Y155.793 E.00234
G1 X95.197 Y155.793 F9000
G1 X94.747 Y155.475
;WIDTH:0.564986
G1 F6000
G1 X94.269 Y155.451 E.01689
;WIDTH:0.553178
G1 X93.847 Y155.316 E.01529
G1 X93.074 Y154.934 E.02976
G1 X93.926 Y154.934 E.02941
;WIDTH:0.564986
G1 X94.746 Y154.953 E.02895
G1 X94.747 Y155.415 E.01631
G1 E-5 F3600
G1 X94.747 Y155.415 F9000
G1 X91.08 Y153.971
G1 E5 F2400
;WIDTH:0.610008
G1 F6000
G1 X90.951 Y153.79 E.00851
;WIDTH:0.568739
G1 X90.822 Y153.609 E.0079
;WIDTH:0.564302
G1 X90.756 Y153.436 E.00653
;WIDTH:0.601133
G1 X90.69 Y153.263 E.00698
;WIDTH:0.637964
G1 X90.625 Y153.091 E.00738
G1 E-5 F3600
G1 X90.625 Y153.091 F9000
G1 X90.772 Y153.061
G1 X90.768 Y153.037
G1 X90.751 Y152.743
G1 X90.751 Y134.962
G1 X90.764 Y134.799
G1 X90.807 Y134.62
G1 X90.835 Y134.552
G1 X90.883 Y134.443
G1 X90.985 Y134.289
G1 X91.112 Y134.153
G1 X91.262 Y134.042
G1 X93.951 Y132.601
G1 X93.951 Y130.555
G1 X93.938 Y130.555
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.946 Y133.09 E.06166
G1 X94.02 Y133.873 E.01913
G1 X92.065 Y133.874 E.04755
G1 X91.524 Y133.917 E.0132
G1 X91.088 Y134.172 E.01229
G1 X90.855 Y134.479 E.00937
;WIDTH:0.449502
G1 X90.79 Y134.647 E.00497
;WIDTH:0.499004
G1 X90.725 Y134.815 E.00557
;WIDTH:0.548506
G1 X90.66 Y134.983 E.00616
;WIDTH:0.552184
G1 X90.666 Y137.12 E.07361
G1 X90.682 Y137.184 E.00227
;WIDTH:0.535957
G1 X90.798 Y137.382 E.00766
;WIDTH:0.490638
G1 X90.913 Y137.58 E.00695
;WIDTH:0.445319
G1 X91.029 Y137.778 E.00627
;WIDTH:0.399999
G1 X91.325 Y138.004 E.00906
G1 X91.767 Y138.124 E.01114
G1 X95.461 Y138.127 E.08985
G1 X95.816 Y138.803 E.01857
G1 X95.588 Y138.92 E.00623
G1 X95.561 Y139.015 E.0024
G1 X95.547 Y141.791 E.06752
G1 X94.94 Y141.865 E.01487
G1 X91.797 Y141.874 E.07645
G1 X91.394 Y141.969 E.01007
G1 X91.053 Y142.198 E.00999
G1 X90.792 Y142.654 E.01278
;WIDTH:0.440463
G1 X90.764 Y142.674 E.00093
;WIDTH:0.480926
G1 X90.736 Y142.693 E.00101
;WIDTH:0.516381
G1 X90.701 Y142.787 E.00322
;WIDTH:0.551835
G1 X90.666 Y142.881 E.00345
G1 X90.66 Y145.017 E.07353
;WIDTH:0.547901
G1 X90.668 Y145.072 E.0019
;WIDTH:0.544412
G1 X90.753 Y145.261 E.00703
;WIDTH:0.496275
G1 X90.839 Y145.45 E.00638
;WIDTH:0.448137
G1 X90.925 Y145.64 E.00574
;WIDTH:0.399999
G1 X91.141 Y145.878 E.00782
G1 X91.331 Y146.005 E.00556
G1 X91.767 Y146.124 E.01099
G1 X94.663 Y146.127 E.07044
G1 X95.524 Y146.209 E.02104
G1 X95.557 Y146.354 E.00362
G1 X95.547 Y149.792 E.08363
G1 X94.572 Y149.873 E.0238
G1 X91.949 Y149.874 E.0638
G1 X91.524 Y149.917 E.01039
G1 X91.042 Y150.213 E.01376
;WIDTH:0.441588
G1 X90.95 Y150.358 E.00465
;WIDTH:0.483176
G1 X90.858 Y150.503 E.00513
;WIDTH:0.524764
G1 X90.766 Y150.648 E.0056
;WIDTH:0.566352
G1 X90.674 Y150.793 E.00608
G1 X90.665 Y151.196 E.01427
;WIDTH:0.550769
G1 X90.682 Y151.9 E.02419
;WIDTH:0.554328
G1 X90.663 Y152.297 E.01375
;WIDTH:0.596146
G1 X90.644 Y152.694 E.01485
;WIDTH:0.637964
G1 X90.625 Y153.091 E.01596
G1 X90.548 Y152.967 E.00586
;WIDTH:0.593998
G1 X90.472 Y152.842 E.00545
;WIDTH:0.550032
G1 X90.205 Y151.924 E.0328
;WIDTH:0.550769
G1 X90.149 Y151.209 E.02464
;WIDTH:0.566352
G1 X90.157 Y150.705 E.01784
G1 X90.136 Y150.598 E.00386
;WIDTH:0.524764
G1 X90.115 Y150.49 E.00359
;WIDTH:0.483176
G1 X90.094 Y150.383 E.00326
;WIDTH:0.441588
G1 X90.074 Y150.275 E.00298
;WIDTH:0.399999
G1 X90.073 Y145.669 E.11204
;WIDTH:0.449299
G1 X90.098 Y145.452 E.00603
;WIDTH:0.498599
G1 X90.122 Y145.235 E.00674
;WIDTH:0.547898
G1 X90.147 Y145.018 E.00746
;WIDTH:0.551835
G1 X90.149 Y142.88 E.0736
G1 X90.13 Y142.779 E.00354
;WIDTH:0.513876
G1 X90.111 Y142.678 E.00328
;WIDTH:0.475917
G1 X90.092 Y142.577 E.00302
;WIDTH:0.437958
G1 X90.073 Y142.477 E.00273
;WIDTH:0.399999
G1 X90.072 Y137.761 E.11471
;WIDTH:0.438046
G1 X90.091 Y137.601 E.00433
;WIDTH:0.476092
G1 X90.11 Y137.441 E.00473
;WIDTH:0.514138
G1 X90.129 Y137.281 E.00514
;WIDTH:0.552184
G1 X90.148 Y137.121 E.00555
G1 X90.146 Y134.983 E.07365
;WIDTH:0.548506
G1 X90.121 Y134.81 E.00598
;WIDTH:0.499004
G1 X90.096 Y134.637 E.0054
;WIDTH:0.449502
G1 X90.072 Y134.463 E.00485
;WIDTH:0.399999
G1 X90.071 Y129.708 E.11566
;WIDTH:0.437769
G1 X90.09 Y129.55 E.00427
;WIDTH:0.475539
G1 X90.109 Y129.392 E.00467
;WIDTH:0.513309
G1 X90.128 Y129.234 E.00507
;WIDTH:0.551079
G1 X90.146 Y129.076 E.00547
G1 X90.145 Y126.982 E.07198
;WIDTH:0.548993
G1 X90.12 Y126.809 E.00598
;WIDTH:0.499329
G1 X90.095 Y126.636 E.00541
;WIDTH:0.449664
G1 X90.071 Y126.463 E.00483
;WIDTH:0.399999
G1 X90.07 Y122.292 E.10146
;WIDTH:0.40115
G1 X90.071 Y121.592 E.01708
;WIDTH:0.445038
G1 X90.093 Y121.543 E.00147
;WIDTH:0.488925
G1 X90.114 Y121.495 E.00158
;WIDTH:0.532813
G1 X90.136 Y121.446 E.00178
;WIDTH:0.5767
G1 X90.158 Y121.398 E.0019
G1 X90.145 Y121.019 E.01368
;WIDTH:0.549478
G1 X90.144 Y118.982 E.0698
G1 X90.12 Y118.822 E.00554
;WIDTH:0.499652
G1 X90.095 Y118.662 E.00501
;WIDTH:0.449826
G1 X90.07 Y118.501 E.0045
;WIDTH:0.399999
G1 X90.069 Y114.293 E.10236
;WIDTH:0.401452
G1 X90.07 Y113.592 E.01712
;WIDTH:0.445388
G1 X90.092 Y113.544 E.00144
;WIDTH:0.489323
G1 X90.114 Y113.495 E.00163
;WIDTH:0.533258
G1 X90.136 Y113.447 E.00175
;WIDTH:0.577193
G1 X90.158 Y113.398 E.00194
G1 X90.144 Y113.019 E.0137
;WIDTH:0.549962
G1 X90.144 Y110.982 E.06987
G1 X90.119 Y110.822 E.00555
;WIDTH:0.499975
G1 X90.094 Y110.662 E.00502
;WIDTH:0.449987
G1 X90.069 Y110.501 E.0045
;WIDTH:0.399999
G1 X90.068 Y106.293 E.10236
;WIDTH:0.401749
G1 X90.069 Y105.592 E.01713
;WIDTH:0.445733
G1 X90.091 Y105.544 E.00144
;WIDTH:0.489716
G1 X90.113 Y105.495 E.00163
;WIDTH:0.5337
G1 X90.135 Y105.447 E.00175
;WIDTH:0.577683
G1 X90.157 Y105.398 E.00194
G1 X90.143 Y105.019 E.01371
;WIDTH:0.550447
G1 X90.143 Y102.982 E.06993
G1 X90.124 Y102.862 E.00417
;WIDTH:0.512835
G1 X90.105 Y102.742 E.00387
;WIDTH:0.475223
G1 X90.087 Y102.621 E.00359
;WIDTH:0.437611
G1 X90.068 Y102.501 E.00326
;WIDTH:0.399999
G1 X90.068 Y101.2 E.03165
;WIDTH:0.447343
G1 X90.091 Y100.861 E.00933
;WIDTH:0.494687
G1 X90.115 Y100.523 E.01038
;WIDTH:0.542031
G1 X90.138 Y100.185 E.01144
;WIDTH:0.542311
G1 X90.138 Y95.562 E.15621
;WIDTH:0.553237
G1 X90.142 Y93.399 E.07466
;WIDTH:0.551126
G1 X90.138 Y93.266 E.00457
;WIDTH:0.542896
G1 X90.137 Y85.654 E.25751
G1 X90.646 Y85.654 E.01722
G1 X90.646 Y93.266 E.25751
;WIDTH:0.551126
G1 X90.659 Y93.359 E.00323
;WIDTH:0.553237
G1 X90.662 Y95.413 E.0709
G1 X90.646 Y95.562 E.00517
;WIDTH:0.542311
G1 X90.646 Y100.185 E.15621
;WIDTH:0.545878
G1 X90.648 Y100.229 E.0015
G1 X90.732 Y100.275 E.00326
;WIDTH:0.497252
G1 X90.816 Y100.321 E.00295
;WIDTH:0.448626
G1 X90.9 Y100.367 E.00264
;WIDTH:0.399999
G1 X93.934 Y100.367 E.0738
G1 X93.934 Y101.876 E.0367
G1 X91.708 Y101.883 E.05415
G1 X91.356 Y101.981 E.00889
G1 X91.049 Y102.201 E.00919
G1 X90.837 Y102.514 E.0092
;WIDTH:0.437611
G1 X90.793 Y102.631 E.00335
;WIDTH:0.475223
G1 X90.748 Y102.748 E.00368
;WIDTH:0.512835
G1 X90.704 Y102.865 E.00398
;WIDTH:0.550447
G1 X90.659 Y102.982 E.0043
G1 X90.659 Y105.019 E.06993
;WIDTH:0.577129
G1 X90.696 Y105.348 E.01195
G1 X90.723 Y105.36 E.00107
;WIDTH:0.533284
G1 X90.75 Y105.372 E.00098
;WIDTH:0.489439
G1 X90.777 Y105.384 E.00089
;WIDTH:0.445594
G1 X90.805 Y105.396 E.00083
;WIDTH:0.401749
G1 X91.007 Y105.746 E.00988
;WIDTH:0.399999
G1 X91.321 Y106.001 E.00984
G1 X91.798 Y106.126 E.01199
G1 X93.934 Y106.126 E.05196
G1 X93.934 Y109.876 E.09122
G1 X91.708 Y109.883 E.05415
G1 X91.356 Y109.981 E.00889
G1 X91.049 Y110.201 E.00919
G1 X90.837 Y110.514 E.0092
;WIDTH:0.449987
G1 X90.778 Y110.67 E.00461
;WIDTH:0.499975
G1 X90.719 Y110.826 E.00517
;WIDTH:0.549962
G1 X90.659 Y110.982 E.00573
G1 X90.659 Y113.019 E.06987
;WIDTH:0.576641
G1 X90.696 Y113.348 E.01194
G1 X90.723 Y113.36 E.00107
;WIDTH:0.532844
G1 X90.75 Y113.372 E.00098
;WIDTH:0.489047
G1 X90.778 Y113.384 E.00092
;WIDTH:0.44525
G1 X90.805 Y113.396 E.00081
;WIDTH:0.401452
G1 X91.007 Y113.746 E.00987
;WIDTH:0.399999
G1 X91.321 Y114.001 E.00984
G1 X91.798 Y114.126 E.01199
G1 X93.934 Y114.126 E.05196
G1 X93.934 Y117.876 E.09122
G1 X91.708 Y117.883 E.05415
G1 X91.356 Y117.981 E.00889
G1 X91.049 Y118.201 E.00919
G1 X90.837 Y118.514 E.0092
;WIDTH:0.449826
G1 X90.778 Y118.67 E.00461
;WIDTH:0.499652
G1 X90.719 Y118.826 E.00516
;WIDTH:0.549478
G1 X90.66 Y118.982 E.00572
G1 X90.66 Y121.019 E.0698
;WIDTH:0.576147
G1 X90.696 Y121.348 E.01193
G1 X90.723 Y121.36 E.00106
;WIDTH:0.532398
G1 X90.751 Y121.372 E.00101
;WIDTH:0.488649
G1 X90.778 Y121.384 E.00089
;WIDTH:0.4449
G1 X90.805 Y121.396 E.00081
;WIDTH:0.40115
G1 X91.007 Y121.746 E.00986
;WIDTH:0.399999
G1 X91.321 Y122.001 E.00984
G1 X91.798 Y122.126 E.01199
G1 X93.934 Y122.126 E.05196
G1 X93.934 Y125.874 E.09117
G1 X92.06 Y125.874 E.04558
G1 X91.524 Y125.917 E.01308
G1 X91.088 Y126.172 E.01229
G1 X90.855 Y126.479 E.00937
;WIDTH:0.449664
G1 X90.79 Y126.646 E.00495
;WIDTH:0.499329
G1 X90.725 Y126.814 E.00557
;WIDTH:0.548993
G1 X90.66 Y126.982 E.00617
;WIDTH:0.551079
G1 X90.673 Y129.131 E.07387
;WIDTH:0.544022
G1 X90.784 Y129.338 E.00796
;WIDTH:0.496015
G1 X90.895 Y129.545 E.00721
;WIDTH:0.448007
G1 X91.006 Y129.751 E.00644
;WIDTH:0.399999
G1 X91.298 Y129.989 E.00916
G1 X91.708 Y130.117 E.01045
G1 X93.936 Y130.124 E.05419
G1 X93.937 Y130.495 E.00902
G1 E-5 F3600
G1 X93.937 Y130.495 F9000
G1 X93.951 Y130.495
G1 X91.603 Y130.09
G1 X91.43 Y130.041
G1 X91.262 Y129.958
G1 X91.112 Y129.847
G1 X90.985 Y129.711
G1 X90.883 Y129.557
G1 X90.835 Y129.448
G1 X90.807 Y129.38
G1 X90.764 Y129.201
G1 X90.751 Y129.038
G1 X90.751 Y118.962
G1 X90.764 Y118.799
G1 X90.807 Y118.62
G1 X90.835 Y118.552
G1 X90.883 Y118.443
G1 X90.985 Y118.289
G1 X91.112 Y118.153
G1 X91.262 Y118.042
G1 X91.43 Y117.959
G1 X91.603 Y117.91
G1 X91.719 Y117.895
G1 X91.784 Y117.891
G1 X93.185 Y117.89
G1 X93.46 Y117.89
G1 X93.568 Y117.89
G1 X93.569 Y117.511
G1 E5 F2400
G1 F6000
G1 X91.707 Y117.517 E.04529
G1 X91.251 Y117.63 E.01143
G1 X90.826 Y117.911 E.01239
G1 X90.528 Y118.318 E.01227
G1 X90.435 Y118.597 E.00715
G1 X90.435 Y113.997 E.11189
;WIDTH:0.401452
G1 X90.437 Y113.442 E.01355
G1 X90.691 Y113.929 E.01341
;WIDTH:0.399999
G1 X90.836 Y114.093 E.00532
G1 X91.101 Y114.293 E.00808
G1 X91.304 Y114.389 E.00546
G1 X91.798 Y114.492 E.01227
G1 X93.569 Y114.492 E.04308
G1 X93.569 Y117.451 E.07197
G1 X93.569 Y117.451 F9000
G1 X93.203 Y116.618
G1 F6000
G1 X93.203 Y117.147 E.01287
G1 X91.706 Y117.152 E.03641
G1 X91.146 Y117.28 E.01397
G1 X90.801 Y117.47 E.00958
G1 X90.801 Y114.525 E.07163
G1 X91.219 Y114.745 E.01149
G1 X91.798 Y114.857 E.01434
G1 X93.203 Y114.857 E.03418
G1 X93.203 Y116.558 E.04138
G1 X93.203 Y116.558 F9000
G1 X92.837 Y116.59
G1 F6000
G1 X92.837 Y116.782 E.00467
G1 X91.705 Y116.786 E.02753
G1 X91.166 Y116.892 E.01336
G1 X91.166 Y115.108 E.04339
G1 X91.798 Y115.223 E.01563
G1 X92.837 Y115.223 E.02527
G1 X92.837 Y116.53 E.03179
G1 E-5 F3600
G1 X92.837 Y116.53 F9000
G1 X90.883 Y113.557
G1 X90.835 Y113.448
G1 X90.807 Y113.38
G1 X90.764 Y113.201
G1 X90.751 Y113.038
G1 X90.751 Y110.962
G1 X90.764 Y110.799
G1 X90.807 Y110.62
G1 X90.835 Y110.552
G1 X90.883 Y110.443
G1 X90.985 Y110.289
G1 X91.112 Y110.153
G1 X91.262 Y110.042
G1 X91.43 Y109.959
G1 X91.603 Y109.91
G1 X91.719 Y109.895
G1 X91.784 Y109.891
G1 X93.185 Y109.89
G1 X93.46 Y109.89
G1 X93.568 Y109.89
G1 X93.569 Y109.511
G1 E5 F2400
G1 F6000
G1 X91.707 Y109.517 E.04529
G1 X91.251 Y109.63 E.01143
G1 X90.826 Y109.911 E.01239
G1 X90.528 Y110.318 E.01227
G1 X90.434 Y110.602 E.00728
G1 X90.434 Y105.997 E.11201
;WIDTH:0.401749
G1 X90.436 Y105.442 E.01356
G1 X90.691 Y105.929 E.01344
;WIDTH:0.399999
G1 X90.836 Y106.093 E.00532
G1 X91.101 Y106.293 E.00808
G1 X91.304 Y106.389 E.00546
G1 X91.798 Y106.492 E.01227
G1 X93.569 Y106.492 E.04308
G1 X93.569 Y109.451 E.07197
G1 X93.569 Y109.451 F9000
G1 X93.203 Y107.783
G1 F6000
G1 X93.203 Y109.147 E.03318
G1 X91.706 Y109.152 E.03641
G1 X91.146 Y109.28 E.01397
G1 X90.8 Y109.471 E.00961
G1 X90.8 Y106.524 E.07168
G1 X91.219 Y106.745 E.01152
G1 X91.798 Y106.857 E.01434
G1 X93.203 Y106.857 E.03418
G1 X93.203 Y107.723 E.02106
G1 X93.203 Y107.723 F9000
G1 X92.837 Y107.783
G1 F6000
G1 X92.837 Y108.782 E.0243
G1 X91.705 Y108.786 E.02753
G1 X91.165 Y108.893 E.01339
G1 X91.165 Y107.108 E.04342
G1 X91.798 Y107.223 E.01565
G1 X92.837 Y107.223 E.02527
G1 X92.837 Y107.723 E.01216
G1 E-5 F3600
G1 X92.837 Y107.723 F9000
G1 X90.985 Y105.711
G1 X90.883 Y105.557
G1 X90.835 Y105.448
G1 X90.807 Y105.38
G1 X90.764 Y105.201
G1 X90.751 Y105.038
G1 X90.751 Y102.962
G1 X90.764 Y102.799
G1 X90.807 Y102.62
G1 X90.835 Y102.552
G1 X90.883 Y102.443
G1 X90.985 Y102.289
G1 X91.112 Y102.153
G1 X91.262 Y102.042
G1 X91.43 Y101.959
G1 X91.603 Y101.91
G1 X91.719 Y101.895
G1 X91.784 Y101.891
G1 X93.185 Y101.89
G1 X93.46 Y101.89
G1 X93.568 Y101.89
G1 X93.569 Y101.511
G1 E5 F2400
G1 F6000
G1 X91.707 Y101.517 E.04529
G1 X91.614 Y101.525 E.00227
G1 X91.157 Y101.669 E.01165
G1 X90.826 Y101.911 E.00997
G1 X90.528 Y102.318 E.01227
G1 X90.433 Y102.606 E.00738
G1 X90.433 Y100.341 E.05509
G1 X90.9 Y100.733 E.01483
G1 X93.569 Y100.733 E.06492
G1 X93.569 Y101.451 E.01746
G1 E-5 F3600
G1 X93.569 Y101.451 F9000
G1 X91.545 Y101.132
G1 E5 F2400
;WIDTH:0.467102
G1 F6000
G1 X91.706 Y101.125 E.00464
;WIDTH:0.452852
G1 X93.179 Y101.123 E.04101
G1 X93.179 Y101.123 F9000
G1 X91.524 Y101.13
;WIDTH:0.467102
G1 F6000
G1 X91.545 Y101.132 E.00061
G1 X91.364 Y101.211 E.00569
;WIDTH:0.427093
G1 X91.182 Y101.289 E.00517
;WIDTH:0.387084
G1 X91.001 Y101.367 E.00462
;WIDTH:0.347074
G1 X90.772 Y101.525 E.00579
G1 X90.772 Y100.965 E.01165
G1 X90.929 Y101.072 E.00395
;WIDTH:0.387084
G1 X91.134 Y101.092 E.00483
;WIDTH:0.427093
G1 X91.34 Y101.112 E.00541
;WIDTH:0.467102
G1 X91.464 Y101.124 E.00359
G1 E-5 F3600
G1 X91.464 Y101.124 F9000
G1 X90.883 Y102.443
G1 X90.835 Y102.552
G1 X90.807 Y102.62
G1 X90.764 Y102.799
G1 X90.751 Y102.962
G1 X90.751 Y121.038
G1 X90.764 Y121.201
G1 X90.78 Y121.266
G1 X90.801 Y121.355
G1 X90.437 Y121.442
G1 E5 F2400
;WIDTH:0.40115
G1 F6000
G1 X90.691 Y121.929 E.0134
;WIDTH:0.399999
G1 X90.836 Y122.093 E.00532
G1 X91.101 Y122.293 E.00808
G1 X91.304 Y122.389 E.00546
G1 X91.798 Y122.492 E.01227
G1 X93.569 Y122.492 E.04308
G1 X93.569 Y125.508 E.07336
G1 X91.709 Y125.516 E.04524
G1 X91.264 Y125.631 E.01118
G1 X90.895 Y125.861 E.01058
G1 X90.735 Y126.012 E.00535
G1 X90.555 Y126.269 E.00763
G1 X90.436 Y126.613 E.00885
G1 X90.436 Y121.997 E.11228
;WIDTH:0.40115
G1 X90.437 Y121.502 E.01208
G1 E-5 F3600
G1 X90.437 Y121.502 F9000
G1 X92.209 Y122.857
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.203 Y122.857 E.02418
G1 X93.203 Y125.143 E.0556
G1 X91.944 Y125.143 E.03062
G1 X91.405 Y125.195 E.01317
G1 X91.071 Y125.321 E.00868
G1 X90.802 Y125.488 E.0077
G1 X90.801 Y122.525 E.07207
G1 X91.219 Y122.745 E.01149
G1 X91.798 Y122.857 E.01434
G1 X92.149 Y122.857 E.00854
G1 X92.149 Y122.857 F9000
G1 X92.406 Y123.223
G1 F6000
G1 X92.837 Y123.223 E.01048
G1 X92.837 Y124.777 E.0378
G1 X91.59 Y124.794 E.03033
G1 X91.167 Y124.901 E.01061
G1 X91.167 Y123.108 E.04361
G1 X91.798 Y123.223 E.0156
G1 X92.346 Y123.223 E.01333
G1 E-5 F3600
G1 X92.346 Y123.223 F9000
G1 X90.883 Y126.443
G1 X90.835 Y126.552
G1 X90.807 Y126.62
G1 X90.764 Y126.799
G1 X90.751 Y126.962
G1 X90.751 Y129.038
G1 X90.764 Y129.201
G1 X90.807 Y129.38
G1 X90.835 Y129.448
G1 X90.883 Y129.557
G1 X90.985 Y129.711
G1 X93.963 Y133.094
G1 X93.99 Y133.482
G1 X93.618 Y133.508
G1 E5 F2400
G1 F6000
G1 X91.709 Y133.516 E.04643
G1 X91.264 Y133.631 E.01118
G1 X90.895 Y133.861 E.01058
G1 X90.735 Y134.012 E.00535
G1 X90.555 Y134.269 E.00763
G1 X90.437 Y134.609 E.00875
G1 X90.437 Y129.419 E.12624
G1 X90.529 Y129.682 E.00678
G1 X90.826 Y130.089 E.01226
G1 X91.251 Y130.37 E.01239
G1 X91.707 Y130.483 E.01143
G1 X93.572 Y130.489 E.04536
G1 X93.581 Y133.091 E.06329
G1 X93.612 Y133.448 E.00872
G1 X93.612 Y133.448 F9000
G1 X93.216 Y132.87
G1 F6000
G1 X93.217 Y133.142 E.00662
G1 X91.95 Y133.143 E.03082
G1 X91.405 Y133.195 E.01332
G1 X91.071 Y133.321 E.00868
G1 X90.803 Y133.488 E.00768
G1 X90.802 Y130.531 E.07193
G1 X91.146 Y130.72 E.00955
G1 X91.706 Y130.848 E.01397
G1 X93.207 Y130.853 E.03651
G1 X93.216 Y132.81 E.0476
G1 X92.847 Y132.435 F9000
G1 F6000
G1 X92.848 Y132.777 E.00832
G1 X91.59 Y132.794 E.0306
G1 X91.168 Y132.901 E.01059
G1 X91.168 Y131.108 E.04361
G1 X91.705 Y131.214 E.01331
G1 X92.843 Y131.218 E.02768
G1 X92.847 Y132.375 E.02814
G1 E-5 F3600
G1 X92.847 Y132.375 F9000
G1 X91.112 Y134.153
G1 X90.985 Y134.289
G1 X90.883 Y134.443
G1 X90.835 Y134.552
G1 X90.807 Y134.62
G1 X90.764 Y134.799
G1 X90.751 Y134.962
G1 X90.751 Y137.038
G1 X90.807 Y142.62
G1 X90.799 Y142.655
G1 X90.438 Y142.569
G1 E5 F2400
G1 F6000
G1 X90.438 Y137.42 E.12524
G1 X90.551 Y137.726 E.00793
G1 X90.86 Y138.12 E.01218
G1 X91.295 Y138.387 E.01242
G1 X91.767 Y138.49 E.01175
G1 X95.239 Y138.493 E.08445
G1 X95.337 Y138.683 E.0052
G1 X95.277 Y138.729 E.00184
G1 X95.196 Y139.015 E.00723
G1 X95.192 Y141.466 E.05962
G1 X94.918 Y141.499 E.00671
G1 X91.796 Y141.508 E.07594
G1 X91.306 Y141.614 E.01219
G1 X90.84 Y141.901 E.01331
G1 X90.674 Y142.092 E.00616
G1 X90.465 Y142.515 E.01148
G1 X90.465 Y142.515 F9000
G1 X90.804 Y141.477
G1 F6000
G1 X90.803 Y138.53 E.07168
G1 X91.204 Y138.741 E.01102
G1 X91.766 Y138.856 E.01395
G1 X94.874 Y138.858 E.0756
G1 X94.83 Y139.014 E.00394
G1 X94.827 Y141.134 E.05157
G1 X91.795 Y141.143 E.07375
G1 X91.218 Y141.259 E.01432
G1 X90.857 Y141.449 E.00992
G1 X90.857 Y141.449 F9000
G1 X91.169 Y140.894
G1 F6000
G1 X91.169 Y139.109 E.04342
G1 X91.766 Y139.221 E.01477
G1 X94.464 Y139.224 E.06563
G1 X94.462 Y140.769 E.03758
G1 X91.794 Y140.777 E.0649
G1 X91.228 Y140.883 E.01401
G1 E-5 F3600
G1 X91.228 Y140.883 F9000
G1 X90.807 Y142.62
G1 X90.764 Y142.799
G1 X90.751 Y142.962
G1 X90.751 Y145.038
G1 X90.764 Y145.201
G1 X91.533 Y149.929
G1 X91.43 Y149.959
G1 X91.3 Y149.622
G1 E5 F2400
G1 F6000
G1 X91.265 Y149.631 E.00088
G1 X90.896 Y149.86 E.01056
G1 X90.637 Y150.136 E.00921
G1 X90.439 Y150.609 E.01247
G1 X90.439 Y145.403 E.12663
G1 X90.514 Y145.65 E.00628
G1 X90.686 Y145.928 E.00795
G1 X90.981 Y146.217 E.01005
G1 X91.287 Y146.381 E.00844
G1 X91.766 Y146.49 E.01195
G1 X94.645 Y146.493 E.07003
G1 X95.192 Y146.545 E.01337
G1 X95.192 Y149.47 E.07115
G1 X94.566 Y149.507 E.01525
G1 X91.709 Y149.516 E.06949
G1 X91.359 Y149.607 E.0088
G1 X91.359 Y149.607 F9000
G1 X91.169 Y149.284
G1 F6000
G1 X91.072 Y149.32 E.00252
G1 X90.805 Y149.486 E.00765
G1 X90.804 Y146.538 E.07171
G1 X91.192 Y146.734 E.01057
G1 X91.766 Y146.856 E.01427
G1 X94.826 Y146.877 E.07443
G1 X94.826 Y149.134 E.0549
G1 X91.948 Y149.143 E.07
G1 X91.405 Y149.195 E.01327
G1 X91.225 Y149.263 E.00468
G1 X91.225 Y149.263 F9000
G1 X91.17 Y148.9
G1 F6000
G1 X91.17 Y147.107 E.04361
G1 X91.766 Y147.221 E.01476
G1 X94.46 Y147.224 E.06553
G1 X94.46 Y148.776 E.03775
G1 X91.948 Y148.777 E.0611
G1 X91.59 Y148.794 E.00872
G1 X91.229 Y148.886 E.00906
G1 X91.229 Y148.886 F9000
G1 X91.28 Y148.079
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X91.864 Y147.496 E.02007
G1 X92.431 Y147.496 E.01379
G1 X91.445 Y148.483 E.03394
G1 X91.445 Y148.545 E.00151
G1 X91.993 Y148.503 E.01337
G1 X92.999 Y147.497 E.03461
G1 X93.567 Y147.497 E.01382
G1 X92.562 Y148.502 E.03457
G1 X93.13 Y148.502 E.01382
G1 X94.186 Y147.498 E.03544
G1 X94.186 Y148.015 E.01258
G1 X93.534 Y148.666 E.02241
G1 E-5 F3600
G1 X93.534 Y148.666 F9000
G1 X90.985 Y145.711
G1 X90.883 Y145.557
G1 X90.835 Y145.448
G1 X90.807 Y145.379
G1 X90.764 Y145.201
G1 X90.751 Y145.038
G1 X90.751 Y142.962
G1 X90.764 Y142.799
G1 X90.807 Y142.62
G1 X90.835 Y142.552
G1 X90.883 Y142.443
G1 X90.985 Y142.289
G1 X91.112 Y142.153
G1 X91.262 Y142.042
G1 X93.535 Y140.662
G1 E5 F2400
G1 F3072.127
G1 X94.189 Y140.009 E.02248
G1 X94.189 Y139.498 E.01243
G1 X94.132 Y139.497 E.00139
G1 X93.131 Y140.499 E.03445
G1 X92.562 Y140.5 E.01384
G1 X93.565 Y139.497 E.0345
G1 X92.998 Y139.497 E.01379
G1 X91.992 Y140.502 E.03459
G1 X91.444 Y140.554 E.01339
G1 X91.444 Y140.484 E.0017
G1 X92.431 Y139.496 E.03397
G1 X91.864 Y139.496 E.01379
G1 X91.279 Y140.081 E.02012
G1 E-5 F3600
G1 X91.279 Y140.081 F9000
G1 X97.847 Y141.749
G1 E5 F2400
;TYPE:Top solid infill
;WIDTH:0.406127
G1 F900
G1 X98.215 Y141.381 E.01287
G1 X97.919 Y141.151 E.00927
G1 X97.486 Y141.584 E.01514
G1 X96.943 Y141.601 E.01344
G1 X97.623 Y140.921 E.02378
G1 X97.34 Y140.678 E.00923
G1 X96.279 Y141.739 E.03711
G1 X95.818 Y141.839 E.01167
G1 X95.831 Y141.661 E.00441
G1 X97.065 Y140.428 E.04314
G1 X96.806 Y140.16 E.00922
G1 X95.832 Y141.134 E.03407
G1 X95.833 Y140.608 E.01301
G1 X96.572 Y139.869 E.02585
G1 X96.362 Y139.552 E.0094
G1 X95.834 Y140.081 E.01848
G1 X95.835 Y139.554 E.01303
G1 X96.281 Y139.109 E.01558
G1 E-5 F3600
G1 X96.281 Y139.109 F9000
G1 X95.966 Y139.045
G1 X91.603 Y138.09
G1 X91.43 Y138.041
G1 X91.262 Y137.958
G1 X91.112 Y137.847
G1 X90.985 Y137.711
G1 X90.883 Y137.557
G1 X90.835 Y137.448
G1 X90.807 Y137.379
G1 X90.764 Y137.201
G1 X90.751 Y137.038
G1 X90.751 Y134.962
G1 X90.764 Y134.799
G1 X90.807 Y134.62
G1 X90.835 Y134.552
G1 X90.883 Y134.443
G1 X91.891 Y132.667
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X92.571 Y131.987 E.02339
G1 X92.57 Y131.491 E.01206
G1 X92.479 Y131.491 E.00221
G1 X91.443 Y132.527 E.03564
G1 X91.443 Y131.939 E.0143
G1 X92.056 Y131.325 E.0211
G1 E-5 F3600
G1 X92.056 Y131.325 F9000
G1 X90.985 Y129.711
G1 X90.883 Y129.557
G1 X90.835 Y129.448
G1 X90.807 Y129.38
G1 X90.764 Y129.201
G1 X90.751 Y129.038
G1 X90.751 Y126.962
G1 X90.764 Y126.799
G1 X90.807 Y126.62
G1 X90.835 Y126.552
G1 X90.883 Y126.443
G1 X91.887 Y124.667
G1 E5 F2400
G1 F3072.127
G1 X92.563 Y123.991 E.02325
G1 X92.563 Y123.497 E.01202
G1 X92.473 Y123.497 E.00219
G1 X91.442 Y124.528 E.03547
G1 X91.442 Y123.944 E.01421
G1 X92.053 Y123.333 E.02102
G1 E-5 F3600
G1 X92.053 Y123.333 F9000
G1 X90.883 Y121.557
G1 X90.835 Y121.448
G1 X90.807 Y121.379
G1 X90.764 Y121.201
G1 X90.751 Y121.038
G1 X90.751 Y118.962
G1 X90.764 Y118.799
G1 X90.807 Y118.62
G1 X90.835 Y118.552
G1 X90.883 Y118.443
G1 X91.883 Y116.676
G1 E5 F2400
G1 F3072.127
G1 X92.563 Y115.995 E.02341
G1 X92.563 Y115.497 E.01211
G1 X92.475 Y115.497 E.00214
G1 X91.441 Y116.532 E.03559
G1 X91.441 Y115.946 E.01425
G1 X92.054 Y115.333 E.02109
G1 E-5 F3600
G1 X92.054 Y115.333 F9000
G1 X90.883 Y113.557
G1 X90.835 Y113.448
G1 X90.807 Y113.38
G1 X90.764 Y113.201
G1 X90.751 Y113.038
G1 X90.751 Y110.962
G1 X90.764 Y110.799
G1 X90.807 Y110.62
G1 X90.835 Y110.552
G1 X90.883 Y110.443
G1 X91.882 Y108.676
G1 E5 F2400
G1 F3072.127
G1 X92.563 Y107.995 E.02343
G1 X92.563 Y107.497 E.01211
G1 X92.475 Y107.497 E.00214
G1 X91.44 Y108.532 E.0356
G1 X91.44 Y107.946 E.01425
G1 X92.053 Y107.333 E.02109
G1 E-5 F3600
G1 X92.053 Y107.333 F9000
G1 X90.883 Y105.557
G1 X90.835 Y105.448
G1 X90.807 Y105.38
G1 X90.764 Y105.201
G1 X90.751 Y105.038
G1 X90.751 Y102.962
G1 X90.764 Y102.799
G1 X90.807 Y102.62
G1 X90.835 Y102.552
G1 X90.883 Y102.443
G1 X90.985 Y102.289
G1 X91.112 Y102.153
G1 X91.262 Y102.042
G1 X93.951 Y100.093
G1 X93.401 Y100.093
G1 X93.401 Y100.258
G1 E5 F2400
;WIDTH:0.423421
G1 F900
G1 X94.026 Y99.633 E.02288
G1 X94.026 Y99.083 E.01424
G1 X93.016 Y100.093 E.03697
G1 X92.465 Y100.093 E.01426
G1 X94.026 Y98.533 E.05712
G1 X94.026 Y97.983 E.01424
G1 X91.915 Y100.093 E.07725
G1 X91.365 Y100.093 E.01424
G1 X94.026 Y97.432 E.0974
G1 X94.026 Y96.882 E.01424
G1 X90.991 Y99.916 E.11107
G1 X90.991 Y99.366 E.01424
G1 X93.837 Y96.521 E.10415
G1 X93.286 Y96.521 E.01426
G1 X90.991 Y98.816 E.084
G1 X90.991 Y98.266 E.01424
G1 X92.736 Y96.521 E.06387
G1 X92.186 Y96.521 E.01424
G1 X90.991 Y97.715 E.04372
G1 X90.991 Y97.165 E.01424
G1 X91.655 Y96.501 E.0243
G1 X91.553 Y96.487 E.00266
G1 X91.409 Y96.435 E.00396
G1 X91.26 Y96.346 E.00449
G1 X90.827 Y96.78 E.01587
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X91.26 Y96.346 E-.2912
G1 X91.409 Y96.435 E-.08244
G1 X91.553 Y96.487 E-.07272
G1 X91.655 Y96.501 E-.0489
G1 X90.991 Y97.165 E-.44604
G1 X90.991 Y97.715 E-.26125
G1 X91.434 Y97.272 E-.29745
;WIPE_END
G1 X90.991 Y97.272 F9000
G1 X95.348 Y96.894
G1 X104.483 Y96.013
G1 X126.349 Y93.904
G1 X129.563 Y93.593
G1 X140.009 Y92.621
G1 X139.646 Y92.621
G1 E5 F2400
;WIDTH:0.402886
G1 F900
G1 X140.009 Y92.257 E.0126
G1 X140.01 Y91.736 E.01277
G1 X139.395 Y92.35 E.02131
G1 X139.212 Y92.307 E.00461
G1 X138.917 Y92.307 E.00723
G1 X140.01 Y91.215 E.03788
G1 X140.01 Y90.693 E.0128
G1 X138.396 Y92.307 E.05596
G1 X137.875 Y92.307 E.01277
G1 X140.01 Y90.172 E.07402
G1 X140.01 Y89.65 E.0128
G1 X137.353 Y92.307 E.09212
G1 X136.832 Y92.307 E.01277
G1 X140.011 Y89.129 E.1102
G1 X140.011 Y88.607 E.0128
G1 X136.311 Y92.307 E.12828
G1 X135.79 Y92.307 E.01277
G1 X140.011 Y88.086 E.14635
G1 X140.011 Y87.565 E.01277
G1 X135.269 Y92.307 E.16441
G1 X134.747 Y92.307 E.0128
G1 X140.011 Y87.043 E.18251
G1 X140.012 Y86.522 E.01277
G1 X134.226 Y92.307 E.20059
G1 X133.705 Y92.307 E.01277
G1 X140.176 Y85.836 E.22436
G1 X140.176 Y85.836 F9000
G1 X140.537 Y85.475
G1 F900
G1 X140.754 Y85.259 E.00751
G1 X140.7 Y85.084 E.00449
G1 X140.699 Y84.792 E.00716
G1 X133.184 Y92.307 E.26055
G1 X132.662 Y92.307 E.0128
G1 X140.698 Y84.272 E.2786
G1 X140.697 Y83.752 E.01275
G1 X132.141 Y92.307 E.29663
G1 X131.62 Y92.307 E.01277
G1 X140.696 Y83.232 E.31466
G1 X140.695 Y82.711 E.01277
G1 X131.099 Y92.307 E.3327
G1 X130.578 Y92.307 E.01277
G1 X140.694 Y82.191 E.35073
G1 X140.693 Y81.671 E.01275
G1 X130.056 Y92.307 E.36878
G1 X129.535 Y92.307 E.01277
G1 X140.692 Y81.151 E.38681
G1 X140.691 Y80.631 E.01275
G1 X129.014 Y92.307 E.40484
G1 X128.493 Y92.307 E.01277
G1 X140.689 Y80.111 E.42285
G1 X140.682 Y79.597 E.0126
G1 X127.972 Y92.307 E.44067
G1 X127.45 Y92.307 E.0128
G1 X127.932 Y91.826 E.01669
G1 X128.293 Y91.826 E.00885
G1 X128.443 Y91.544 E.00783
G1 X128.486 Y91.363 E.00456
G1 X128.486 Y91.272 E.00223
G1 X140.611 Y79.147 E.42038
G1 X140.517 Y78.72 E.01072
G1 X128.486 Y90.75 E.41711
G1 X128.487 Y90.229 E.01277
G1 X140.405 Y78.31 E.41323
G1 X140.25 Y77.944 E.00974
G1 X128.487 Y89.707 E.40783
G1 X128.487 Y89.654 E.0013
G1 X128.383 Y89.39 E.00696
G1 X128.283 Y89.39 E.00245
G1 X140.095 Y77.578 E.40953
G1 X139.901 Y77.251 E.00932
G1 X127.762 Y89.39 E.42087
G1 X127.241 Y89.39 E.01277
G1 X139.692 Y76.939 E.43169
G1 X139.451 Y76.658 E.00908
G1 X126.735 Y89.374 E.44088
G1 X126.469 Y89.12 E.00902
G1 X133.121 Y82.467 E.23065
G1 X132.603 Y82.464 E.0127
G1 X126.269 Y88.798 E.21961
G1 X126.262 Y88.564 E.00574
G1 X126.159 Y88.386 E.00504
G1 X128.285 Y86.26 E.07371
G1 X127.961 Y86.371 E.0084
G1 X127.576 Y86.449 E.00963
G1 X125.799 Y88.226 E.06161
G1 X125.277 Y88.226 E.0128
G1 X126.992 Y86.511 E.05946
G1 X126.458 Y86.524 E.0131
G1 X124.756 Y88.226 E.05901
G1 X124.235 Y88.226 E.01277
G1 X125.937 Y86.524 E.05901
G1 X125.416 Y86.524 E.01277
G1 X123.714 Y88.226 E.05901
G1 X123.193 Y88.226 E.01277
G1 X124.895 Y86.523 E.05903
G1 X124.374 Y86.523 E.01277
G1 X122.671 Y88.226 E.05904
G1 X122.15 Y88.226 E.01277
G1 X123.853 Y86.523 E.05904
G1 X123.332 Y86.523 E.01277
G1 X121.629 Y88.226 E.05904
G1 X121.108 Y88.226 E.01277
G1 X122.811 Y86.523 E.05904
G1 X122.29 Y86.522 E.01277
G1 X120.587 Y88.226 E.05906
G1 X120.065 Y88.226 E.0128
G1 X121.769 Y86.522 E.05908
G1 X121.248 Y86.522 E.01277
G1 X119.544 Y88.226 E.05908
G1 X119.023 Y88.226 E.01277
G1 X120.727 Y86.522 E.05908
G1 X120.206 Y86.522 E.01277
G1 X118.502 Y88.226 E.05908
G1 X117.981 Y88.226 E.01277
G1 X119.685 Y86.521 E.0591
G1 X119.164 Y86.521 E.01277
G1 X117.459 Y88.226 E.05911
G1 X116.938 Y88.226 E.01277
G1 X118.643 Y86.521 E.05911
G1 X118.122 Y86.521 E.01277
G1 X116.417 Y88.226 E.05911
G1 X115.896 Y88.226 E.01277
G1 X117.601 Y86.521 E.05911
G1 X117.08 Y86.52 E.01277
G1 X115.375 Y88.226 E.05913
G1 X114.853 Y88.226 E.0128
G1 X116.559 Y86.52 E.05915
G1 X116.038 Y86.52 E.01277
G1 X114.332 Y88.226 E.05915
G1 X113.811 Y88.226 E.01277
G1 X115.517 Y86.52 E.05915
G1 X114.996 Y86.52 E.01277
G1 X113.29 Y88.226 E.05915
G1 X112.768 Y88.226 E.0128
G1 X114.475 Y86.519 E.05918
G1 X113.954 Y86.519 E.01277
G1 X112.247 Y88.226 E.05918
G1 X111.726 Y88.226 E.01277
G1 X113.433 Y86.519 E.05918
G1 X112.912 Y86.519 E.01277
G1 X111.205 Y88.226 E.05918
G1 X110.684 Y88.226 E.01277
G1 X112.391 Y86.519 E.05918
G1 X111.87 Y86.518 E.01277
G1 X110.162 Y88.226 E.05922
G1 X109.641 Y88.226 E.01277
G1 X111.349 Y86.518 E.05922
G1 X110.828 Y86.518 E.01277
G1 X109.12 Y88.226 E.05922
G1 X108.599 Y88.226 E.01277
G1 X110.307 Y86.518 E.05922
G1 X109.786 Y86.518 E.01277
G1 X108.078 Y88.226 E.05922
G1 X107.556 Y88.226 E.0128
G1 X109.265 Y86.517 E.05925
G1 X108.744 Y86.517 E.01277
G1 X107.035 Y88.226 E.05925
G1 X106.514 Y88.226 E.01277
G1 X108.223 Y86.517 E.05925
G1 X107.702 Y86.517 E.01277
G1 X105.993 Y88.226 E.05925
G1 X105.472 Y88.226 E.01277
G1 X107.181 Y86.517 E.05925
G1 X106.66 Y86.516 E.01277
G1 X103.786 Y89.39 E.09964
G1 X103.265 Y89.39 E.01277
G1 X106.303 Y86.352 E.10533
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X104.07 Y88.585 E-1.5
;WIPE_END
G1 X104.859 Y91.966 F9000
G1 E5 F2400
G1 F900
G1 X104.517 Y92.307 E.01184
G1 X103.996 Y92.307 E.01277
G1 X104.476 Y91.827 E.01664
G1 X103.956 Y91.826 E.01275
G1 X103.475 Y92.307 E.01668
G1 X102.954 Y92.307 E.01277
G1 X103.435 Y91.826 E.01668
G1 X102.913 Y91.826 E.0128
G1 X102.432 Y92.307 E.01668
G1 X101.911 Y92.307 E.01277
G1 X102.598 Y91.621 E.0238
G1 X102.557 Y91.544 E.00214
G1 X102.514 Y91.363 E.00456
G1 X102.514 Y91.184 E.00439
G1 X101.39 Y92.307 E.03895
G1 X100.869 Y92.307 E.01277
G1 X102.514 Y90.663 E.05702
G1 X102.513 Y90.142 E.01277
G1 X100.348 Y92.307 E.07506
G1 X99.826 Y92.307 E.0128
G1 X105.618 Y86.516 E.2008
G1 X105.097 Y86.516 E.01277
G1 X99.305 Y92.307 E.2008
G1 X98.784 Y92.307 E.01277
G1 X104.576 Y86.516 E.2008
G1 X104.055 Y86.515 E.01277
G1 X98.263 Y92.307 E.20081
G1 X97.742 Y92.307 E.01277
G1 X103.578 Y86.471 E.20234
G1 X103.334 Y86.439 E.00603
G1 X103.145 Y86.382 E.00484
G1 X97.22 Y92.307 E.20543
G1 X96.699 Y92.307 E.01277
G1 X102.745 Y86.261 E.20962
G1 X102.485 Y86.182 E.00666
G1 X102.364 Y86.121 E.00332
G1 X96.178 Y92.307 E.21447
G1 X95.657 Y92.307 E.01277
G1 X102.016 Y85.948 E.22047
G1 X101.699 Y85.744 E.00924
G1 X95.135 Y92.307 E.22756
G1 X94.614 Y92.307 E.01277
G1 X101.391 Y85.531 E.23495
G1 X101.121 Y85.28 E.00904
G1 X94.093 Y92.307 E.24365
G1 X93.572 Y92.307 E.01277
G1 X100.864 Y85.015 E.25282
G1 X100.637 Y84.721 E.00911
G1 X93.051 Y92.307 E.26301
G1 X92.529 Y92.307 E.0128
G1 X100.412 Y84.424 E.27331
G1 X100.23 Y84.086 E.00941
G1 X92.008 Y92.307 E.28505
G1 X91.792 Y92.307 E.0053
G1 X91.553 Y92.342 E.00592
G1 X91.388 Y92.407 E.00435
G1 X100.063 Y83.732 E.30077
G1 X99.927 Y83.346 E.01003
G1 X90.991 Y92.282 E.30982
G1 X90.991 Y91.761 E.01277
G1 X99.823 Y82.929 E.30621
G1 X99.77 Y82.672 E.00643
G1 X99.755 Y82.476 E.00482
G1 X90.991 Y91.24 E.30386
G1 X90.99 Y90.719 E.01277
G1 X99.251 Y82.458 E.28642
G1 X98.727 Y82.462 E.01285
G1 X90.99 Y90.198 E.26823
G1 X90.99 Y89.677 E.01277
G1 X98.202 Y82.465 E.25005
G1 X97.677 Y82.468 E.01287
G1 X90.99 Y89.156 E.23186
G1 X90.99 Y88.635 E.01277
G1 X97.153 Y82.472 E.21368
G1 X97.068 Y82.472 E.00208
G1 X96.995 Y82.108 E.0091
G1 X90.989 Y88.114 E.20823
G1 X90.989 Y87.593 E.01277
G1 X96.929 Y81.653 E.20595
G1 X96.878 Y81.183 E.01159
G1 X90.989 Y87.072 E.20418
G1 X90.989 Y86.551 E.01277
G1 X96.843 Y80.697 E.20296
G1 X96.815 Y80.204 E.01211
G1 X90.989 Y86.03 E.20199
G1 X90.988 Y85.509 E.01277
G1 X96.815 Y79.683 E.20201
G1 X96.814 Y79.162 E.01277
G1 X90.665 Y85.311 E.21319
G1 X90.202 Y85.309 E.01135
G1 X90.244 Y85.267 E.00146
G1 X90.269 Y85.186 E.00208
G1 X96.814 Y78.641 E.22692
G1 X96.814 Y78.119 E.0128
G1 X90.3 Y84.633 E.22585
G1 X90.3 Y84.112 E.01277
G1 X96.814 Y77.598 E.22585
G1 X96.814 Y77.077 E.01277
G1 X90.3 Y83.591 E.22585
G1 X90.3 Y83.07 E.01277
G1 X96.979 Y76.391 E.23157
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X94.746 Y78.624 E-1.5
;WIPE_END
G1 X96.815 Y79.519 F9000
G1 X99.651 Y80.746
G1 X101.099 Y81.371
G1 X102.986 Y82.188
G1 X122.812 Y90.762
G1 X124.941 Y91.683
G1 X126.765 Y91.826
G1 X126.765 Y92.472
G1 E5 F2400
G1 F900
G1 X127.41 Y91.826 E.02238
G1 X126.889 Y91.826 E.01277
G1 X126.243 Y92.472 E.0224
G1 E-5 F3600
G1 X126.243 Y92.472 F9000
G1 X130.724 Y83.821
G1 E5 F2400
G1 F900
G1 X132.085 Y82.46 E.04719
G1 X131.567 Y82.457 E.0127
G1 X130.978 Y83.046 E.02042
G1 E-5 F3600
G1 X130.978 Y83.046 F9000
G1 X133.903 Y81.685
G1 E5 F2400
G1 F900
G1 X139.211 Y76.377 E.18403
G1 X139.114 Y76.264 E.00365
G1 X138.946 Y76.12 E.00542
G1 X134.134 Y80.933 E.16685
G1 X134.173 Y80.372 E.01379
G1 X138.666 Y75.88 E.15576
G1 X138.356 Y75.669 E.00919
G1 X134.186 Y79.839 E.14458
G1 X134.186 Y79.317 E.0128
G1 X138.037 Y75.467 E.1335
G1 X137.689 Y75.293 E.00954
G1 X134.186 Y78.796 E.12145
G1 X134.187 Y78.274 E.0128
G1 X137.314 Y75.146 E.10843
G1 X136.919 Y75.021 E.01016
G1 X134.187 Y77.753 E.09472
G1 X134.187 Y77.231 E.0128
G1 X136.512 Y74.906 E.08061
G1 X136.061 Y74.836 E.01119
G1 X134.187 Y76.71 E.06497
G1 X134.188 Y76.188 E.0128
G1 X135.571 Y74.805 E.04795
G1 X135.054 Y74.801 E.01268
G1 X134.188 Y75.667 E.03003
G1 X133.677 Y75.656 E.01253
G1 X134.533 Y74.801 E.02966
G1 X134.012 Y74.801 E.01277
G1 X133.157 Y75.655 E.02963
G1 X132.638 Y75.653 E.01272
G1 X133.49 Y74.801 E.02954
G1 X132.969 Y74.801 E.01277
G1 X132.118 Y75.652 E.0295
G1 X131.598 Y75.651 E.01275
G1 X132.448 Y74.801 E.02947
G1 X131.927 Y74.801 E.01277
G1 X131.182 Y75.546 E.02583
G1 X131.144 Y75.471 E.00206
G1 X130.856 Y75.35 E.00766
G1 X131.406 Y74.801 E.01905
G1 X130.884 Y74.801 E.0128
G1 X130.344 Y75.341 E.01872
G1 X129.823 Y75.341 E.01277
G1 X130.363 Y74.801 E.01872
G1 X129.842 Y74.801 E.01277
G1 X129.301 Y75.341 E.01874
G1 X128.78 Y75.341 E.01277
G1 X129.321 Y74.801 E.01874
G1 X128.8 Y74.801 E.01277
G1 X128.259 Y75.341 E.01874
G1 X127.738 Y75.341 E.01277
G1 X128.278 Y74.801 E.01872
G1 X127.757 Y74.801 E.01277
G1 X127.217 Y75.341 E.01872
G1 X126.695 Y75.341 E.0128
G1 X127.236 Y74.801 E.01874
G1 X126.715 Y74.801 E.01277
G1 X126.174 Y75.341 E.01874
G1 X125.653 Y75.341 E.01277
G1 X126.194 Y74.801 E.01874
G1 X125.672 Y74.801 E.0128
G1 X125.132 Y75.341 E.01872
G1 X124.611 Y75.341 E.01277
G1 X125.151 Y74.801 E.01872
G1 X124.63 Y74.801 E.01277
G1 X124.089 Y75.341 E.01874
G1 X123.568 Y75.341 E.01277
G1 X124.109 Y74.801 E.01874
G1 X123.588 Y74.801 E.01277
G1 X123.047 Y75.341 E.01874
G1 X122.526 Y75.341 E.01277
G1 X123.066 Y74.801 E.01872
G1 X122.545 Y74.801 E.01277
G1 X122.005 Y75.341 E.01872
G1 X121.483 Y75.341 E.0128
G1 X122.024 Y74.801 E.01874
G1 X121.503 Y74.801 E.01277
G1 X120.962 Y75.341 E.01874
G1 X120.441 Y75.341 E.01277
G1 X120.982 Y74.801 E.01874
G1 X120.46 Y74.801 E.0128
G1 X119.92 Y75.341 E.01872
G1 X119.398 Y75.341 E.0128
G1 X119.939 Y74.801 E.01874
G1 X119.418 Y74.801 E.01277
G1 X118.877 Y75.341 E.01874
G1 X118.356 Y75.341 E.01277
G1 X118.897 Y74.801 E.01874
G1 X118.376 Y74.801 E.01277
G1 X117.835 Y75.341 E.01874
G1 X117.314 Y75.341 E.01277
G1 X117.854 Y74.801 E.01872
G1 X117.333 Y74.801 E.01277
G1 X116.792 Y75.341 E.01874
G1 X116.271 Y75.341 E.01277
G1 X116.812 Y74.801 E.01874
G1 X116.291 Y74.801 E.01277
G1 X115.75 Y75.341 E.01874
G1 X115.229 Y75.341 E.01277
G1 X115.77 Y74.801 E.01874
G1 X115.248 Y74.801 E.0128
G1 X114.708 Y75.341 E.01872
G1 X114.186 Y75.341 E.0128
G1 X114.727 Y74.801 E.01874
G1 X114.206 Y74.801 E.01277
G1 X113.665 Y75.341 E.01874
G1 X113.144 Y75.341 E.01277
G1 X113.685 Y74.801 E.01874
G1 X113.164 Y74.801 E.01277
G1 X112.623 Y75.341 E.01874
G1 X112.102 Y75.341 E.01277
G1 X112.642 Y74.801 E.01872
G1 X112.121 Y74.801 E.01277
G1 X111.58 Y75.341 E.01874
G1 X111.059 Y75.341 E.01277
G1 X111.6 Y74.801 E.01874
G1 X111.079 Y74.801 E.01277
G1 X110.538 Y75.341 E.01874
G1 X110.017 Y75.341 E.01277
G1 X110.557 Y74.801 E.01872
G1 X110.036 Y74.801 E.01277
G1 X109.496 Y75.341 E.01872
G1 X108.974 Y75.341 E.0128
G1 X109.515 Y74.801 E.01874
G1 X108.994 Y74.801 E.01277
G1 X108.453 Y75.341 E.01874
G1 X107.932 Y75.341 E.01277
G1 X108.473 Y74.801 E.01874
G1 X107.951 Y74.8 E.0128
G1 X107.411 Y75.341 E.01874
G1 X106.889 Y75.341 E.0128
G1 X107.43 Y74.8 E.01876
G1 X106.909 Y74.8 E.01277
G1 X106.368 Y75.341 E.01876
G1 X105.847 Y75.341 E.01277
G1 X106.388 Y74.8 E.01876
G1 X105.867 Y74.8 E.01277
G1 X105.326 Y75.341 E.01876
G1 X104.805 Y75.341 E.01277
G1 X105.345 Y74.8 E.01874
G1 X104.824 Y74.8 E.01277
G1 X104.283 Y75.341 E.01876
G1 X103.762 Y75.341 E.01277
G1 X104.303 Y74.8 E.01876
G1 X103.782 Y74.8 E.01277
G1 X103.241 Y75.341 E.01876
G1 X102.72 Y75.341 E.01277
G1 X103.261 Y74.8 E.01876
G1 X102.739 Y74.8 E.0128
G1 X102.199 Y75.341 E.01874
G1 X101.677 Y75.341 E.0128
G1 X102.218 Y74.8 E.01876
G1 X101.697 Y74.8 E.01277
G1 X101.156 Y75.341 E.01876
G1 X100.635 Y75.341 E.01277
G1 X101.176 Y74.8 E.01876
G1 X100.655 Y74.8 E.01277
G1 X100.108 Y75.347 E.01896
G1 X99.856 Y75.472 E.0069
G1 X99.766 Y75.651 E.00491
G1 X99.283 Y75.651 E.01184
G1 X100.133 Y74.8 E.02949
G1 X99.612 Y74.8 E.01277
G1 X98.762 Y75.651 E.02949
G1 X98.24 Y75.651 E.0128
G1 X99.091 Y74.8 E.0295
G1 X98.57 Y74.8 E.01277
G1 X97.555 Y75.816 E.03521
G1 X97.555 Y75.816 F9000
G1 X98.213 Y74.636
G1 F900
G1 X97.198 Y75.651 E.03519
G1 X96.814 Y75.651 E.00941
G1 X96.814 Y76.035 E.00941
G1 X90.301 Y82.548 E.22581
G1 X90.301 Y82.027 E.01277
G1 X97.527 Y74.8 E.25055
G1 X97.006 Y74.8 E.01277
G1 X90.301 Y81.506 E.23249
G1 X90.301 Y80.985 E.01277
G1 X96.485 Y74.8 E.21442
G1 X95.964 Y74.8 E.01277
G1 X90.301 Y80.463 E.19634
G1 X90.305 Y79.937 E.0129
G1 X95.435 Y74.808 E.17784
G1 X95.022 Y74.824 E.01013
G1 X94.875 Y74.846 E.00364
G1 X90.34 Y79.382 E.15725
G1 X90.456 Y78.745 E.01587
G1 X94.235 Y74.965 E.13104
G1 X93.772 Y75.097 E.0118
G1 X93.443 Y75.237 E.00877
G1 X90.734 Y77.945 E.09391
G1 X90.92 Y77.541 E.0109
G1 X91.257 Y76.997 E.01569
G1 X91.651 Y76.508 E.0154
G1 X92.754 Y75.404 E.03826
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X91.651 Y76.508 E-.74128
G1 X91.257 Y76.997 E-.29829
G1 X90.92 Y77.541 E-.30396
G1 X90.782 Y77.84 E-.15647
;WIPE_END
G1 X96.831 Y80.494 F9000
G1 X99.651 Y81.731
G1 X101.173 Y82.398
G1 X101.302 Y82.455
G1 X122.819 Y91.894
G1 X124.901 Y92.808
G1 X126.691 Y93.593
G1 X134.638 Y97.079
G1 X140.009 Y99.508
G1 X140.174 Y99.508
G1 E5 F2400
;WIDTH:0.404969
G1 F900
G1 X139.588 Y100.093 E.02041
G1 X139.064 Y100.093 E.01292
G1 X140.009 Y99.148 E.03295
G1 X140.009 Y98.624 E.01292
G1 X138.54 Y100.093 E.05122
G1 X138.016 Y100.093 E.01292
G1 X140.009 Y98.1 E.06949
G1 X140.009 Y97.576 E.01292
G1 X137.492 Y100.093 E.08776
G1 X136.974 Y100.093 E.01277
G1 X140.009 Y97.052 E.10593
G1 X140.009 Y96.528 E.01292
G1 X136.974 Y99.562 E.1058
G1 X136.974 Y99.038 E.01292
G1 X139.57 Y96.442 E.09051
G1 X139.448 Y96.487 E.00321
G1 X139.208 Y96.521 E.00598
G1 X138.967 Y96.521 E.00594
G1 X136.974 Y98.514 E.06949
G1 X136.974 Y97.99 E.01292
G1 X138.443 Y96.521 E.05122
G1 X137.919 Y96.521 E.01292
G1 X136.974 Y97.466 E.03295
G1 X136.974 Y96.942 E.01292
G1 X137.559 Y96.357 E.0204
G1 E-5 F3600
G1 X137.559 Y96.357 F9000
G1 X138.092 Y100.093
G1 X140.193 Y102.62
G1 X140.193 Y105.38
G1 X139.122 Y107.324
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X138.437 Y108.009 E.02356
G1 X138.437 Y108.509 E.01216
G1 X138.526 Y108.509 E.00216
G1 X139.563 Y107.473 E.03565
G1 X139.563 Y108.062 E.01433
G1 X138.949 Y108.675 E.0211
G1 E-5 F3600
G1 X138.949 Y108.675 F9000
G1 X140.055 Y110.35
G1 X140.117 Y110.443
G1 X140.165 Y110.552
G1 X140.193 Y110.62
G1 X140.193 Y113.38
G1 X139.119 Y115.333
G1 E5 F2400
G1 F3072.127
G1 X138.437 Y116.015 E.02346
G1 X138.437 Y116.503 E.01187
G1 X138.538 Y116.503 E.00246
G1 X139.563 Y115.478 E.03526
G1 X139.563 Y116.067 E.01433
G1 X138.962 Y116.667 E.02066
G1 E-5 F3600
G1 X138.962 Y116.667 F9000
G1 X140.117 Y118.443
G1 X140.165 Y118.552
G1 X140.193 Y118.62
G1 X140.236 Y118.799
G1 X140.249 Y118.962
G1 X140.193 Y121.38
G1 X139.123 Y123.324
G1 E5 F2400
G1 F3072.127
G1 X138.437 Y124.011 E.02362
G1 X138.437 Y124.503 E.01197
G1 X138.535 Y124.503 E.00238
G1 X139.563 Y123.475 E.03536
G1 X139.563 Y124.065 E.01435
G1 X138.96 Y124.667 E.02073
G1 E-5 F3600
G1 X138.96 Y124.667 F9000
G1 X140.193 Y126.62
G1 X140.193 Y129.38
G1 X139.12 Y131.324
G1 E5 F2400
G1 F3072.127
G1 X138.429 Y132.015 E.02377
G1 X138.428 Y132.503 E.01187
G1 X138.532 Y132.503 E.00253
G1 X139.562 Y131.472 E.03545
G1 X139.562 Y132.063 E.01438
G1 X138.959 Y132.667 E.02076
G1 E-5 F3600
G1 X138.959 Y132.667 F9000
G1 X140.193 Y134.62
G1 X140.236 Y137.201
G1 X140.193 Y137.38
G1 X140.165 Y137.448
G1 X140.117 Y137.557
G1 X140.015 Y137.711
G1 X139.888 Y137.847
G1 X139.738 Y137.958
G1 X136.647 Y140.152
G1 E5 F2400
G1 F3072.127
G1 X137.302 Y139.497 E.02253
G1 X137.874 Y139.497 E.01391
G1 X136.869 Y140.502 E.03457
G1 X137.44 Y140.502 E.01389
G1 X138.446 Y139.496 E.03461
G1 X139.017 Y139.496 E.01389
G1 X138.011 Y140.502 E.03461
G1 X138.582 Y140.502 E.01389
G1 X139.562 Y139.522 E.03371
G1 X139.562 Y140.093 E.01389
G1 X138.988 Y140.667 E.01975
G1 E-5 F3600
G1 X138.988 Y140.667 F9000
G1 X135.333 Y141.315
G1 E5 F2400
;WIDTH:0.416656
G1 F900
G1 X134.875 Y141.773 E.01647
G1 X134.431 Y141.676 E.01156
G1 X135.167 Y140.94 E.02647
G1 X135.167 Y140.4 E.01373
G1 X133.974 Y141.593 E.04291
G1 X133.441 Y141.584 E.01356
G1 X135.166 Y139.86 E.06202
G1 X135.165 Y139.32 E.01373
G1 X132.736 Y141.749 E.08736
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X134.969 Y139.516 E-1.5
;WIPE_END
G1 X136.649 Y148.156 F9000
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X137.308 Y147.498 E.02265
G1 X137.881 Y147.498 E.01394
G1 X136.875 Y148.503 E.03459
G1 X137.446 Y148.505 E.01389
G1 X138.454 Y147.498 E.03466
G1 X139.027 Y147.497 E.01394
G1 X138.017 Y148.507 E.03474
G1 X138.588 Y148.509 E.01389
G1 X139.562 Y147.535 E.03351
G1 X139.562 Y148.108 E.01394
G1 X138.995 Y148.675 E.0195
G1 E-5 F3600
G1 X138.995 Y148.675 F9000
G1 X134.817 Y149.922
G1 E5 F2400
;WIDTH:0.400378
G1 F900
G1 X135.169 Y149.57 E.01212
G1 X135.169 Y149.053 E.01259
G1 X134.531 Y149.69 E.02195
G1 X134.092 Y149.612 E.01086
G1 X135.169 Y148.535 E.03709
G1 X135.169 Y148.017 E.01261
G1 X133.603 Y149.583 E.05393
G1 X133.085 Y149.583 E.01261
G1 X135.169 Y147.5 E.07175
G1 X135.169 Y146.982 E.01261
G1 X132.567 Y149.583 E.08958
G1 X132.05 Y149.584 E.01259
G1 X135.169 Y146.464 E.10742
G1 X135.182 Y146.162 E.00736
G1 X134.887 Y146.228 E.00736
G1 X131.532 Y149.584 E.11555
G1 X131.014 Y149.584 E.01261
G1 X134.225 Y146.373 E.11057
G1 X133.861 Y146.418 E.00893
G1 X133.663 Y146.417 E.00482
G1 X130.496 Y149.584 E.10906
G1 X129.978 Y149.585 E.01261
G1 X133.145 Y146.417 E.10907
G1 X132.628 Y146.417 E.01259
G1 X129.46 Y149.585 E.10909
G1 X128.942 Y149.585 E.01261
G1 X132.111 Y146.417 E.10911
G1 X131.593 Y146.416 E.01261
G1 X128.424 Y149.586 E.10914
G1 X127.906 Y149.586 E.01261
G1 X131.076 Y146.416 E.10916
G1 X130.559 Y146.416 E.01259
G1 X127.388 Y149.586 E.10918
G1 X126.87 Y149.587 E.01261
G1 X130.041 Y146.415 E.10921
G1 X129.524 Y146.415 E.01259
G1 X126.352 Y149.587 E.10923
G1 X125.834 Y149.587 E.01261
G1 X129.006 Y146.415 E.10923
G1 X128.489 Y146.414 E.01259
G1 X125.151 Y149.752 E.11494
G1 E-5 F3600
G1 X125.151 Y149.752 F9000
G1 X134.78 Y156.171
G1 E5 F2400
G1 F900
G1 X135.164 Y155.787 E.01322
G1 X135.165 Y155.268 E.01264
G1 X134.533 Y155.901 E.02178
G1 X134.103 Y155.813 E.01069
G1 X135.167 Y154.749 E.03664
G1 X135.176 Y154.222 E.01283
G1 X133.633 Y155.765 E.05313
G1 X133.115 Y155.765 E.01261
G1 X134.582 Y154.298 E.05052
G1 X134.287 Y154.365 E.00737
G1 X133.957 Y154.406 E.0081
G1 X132.597 Y155.765 E.04681
G1 X132.08 Y155.765 E.01259
G1 X133.428 Y154.417 E.04642
G1 X132.91 Y154.417 E.01261
G1 X131.562 Y155.765 E.04642
G1 X131.044 Y155.765 E.01261
G1 X132.393 Y154.417 E.04644
G1 X131.876 Y154.416 E.01259
G1 X130.527 Y155.765 E.04645
G1 X130.009 Y155.765 E.01261
G1 X131.358 Y154.416 E.04645
G1 X130.841 Y154.416 E.01259
G1 X129.491 Y155.765 E.04647
G1 X128.974 Y155.765 E.01259
G1 X130.324 Y154.415 E.04649
G1 X129.806 Y154.415 E.01261
G1 X128.456 Y155.765 E.04649
G1 X127.938 Y155.765 E.01261
G1 X129.289 Y154.415 E.0465
G1 X128.772 Y154.414 E.01259
G1 X127.421 Y155.765 E.04652
G1 X126.903 Y155.765 E.01261
G1 X128.254 Y154.414 E.04652
G1 X127.737 Y154.414 E.01259
G1 X126.385 Y155.765 E.04654
G1 X125.868 Y155.765 E.01259
G1 X127.22 Y154.414 E.04654
G1 X126.702 Y154.413 E.01261
G1 X125.35 Y155.765 E.04656
G1 X124.832 Y155.765 E.01261
G1 X126.185 Y154.413 E.04657
G1 X125.667 Y154.413 E.01261
G1 X124.315 Y155.765 E.04656
G1 X123.797 Y155.765 E.01261
G1 X125.15 Y154.412 E.04659
G1 X124.914 Y154.412 E.00575
G1 X124.703 Y154.342 E.00541
G1 X123.279 Y155.765 E.04902
G1 X122.762 Y155.765 E.01259
G1 X124.488 Y154.04 E.05942
G1 X124.472 Y153.964 E.00189
G1 X124.472 Y153.537 E.0104
G1 X122.244 Y155.765 E.07672
G1 X121.726 Y155.765 E.01261
G1 X124.472 Y153.019 E.09456
G1 X124.472 Y152.502 E.01259
G1 X121.209 Y155.765 E.11236
G1 X120.691 Y155.765 E.01261
G1 X124.472 Y151.984 E.1302
G1 X124.472 Y151.466 E.01261
G1 X120.173 Y155.765 E.14804
G1 X119.656 Y155.765 E.01259
G1 X124.472 Y150.949 E.16584
G1 X124.472 Y150.431 E.01261
G1 X119.138 Y155.765 E.18368
G1 X118.62 Y155.765 E.01261
G1 X127.972 Y146.414 E.32202
G1 X127.454 Y146.414 E.01261
G1 X118.103 Y155.765 E.322
G1 X117.585 Y155.765 E.01261
G1 X126.937 Y146.413 E.32204
G1 X126.42 Y146.413 E.01259
G1 X117.068 Y155.765 E.32204
G1 X116.55 Y155.765 E.01261
G1 X125.902 Y146.413 E.32204
G1 X125.385 Y146.412 E.01259
G1 X116.032 Y155.765 E.32207
G1 X115.515 Y155.765 E.01259
G1 X124.876 Y146.404 E.32235
G1 X124.765 Y146.384 E.00275
G1 X124.589 Y146.262 E.00521
G1 X124.554 Y146.208 E.00157
G1 X114.997 Y155.765 E.3291
G1 X114.479 Y155.765 E.01261
G1 X124.472 Y145.772 E.34411
G1 X124.471 Y145.256 E.01256
G1 X113.962 Y155.765 E.36188
G1 X113.444 Y155.765 E.01261
G1 X124.47 Y144.739 E.37968
G1 X124.469 Y144.222 E.01259
G1 X112.926 Y155.765 E.39748
G1 X112.409 Y155.765 E.01259
G1 X124.468 Y143.706 E.41525
G1 X124.468 Y143.401 E.00743
G1 X124.256 Y143.401 E.00516
G1 X111.891 Y155.765 E.42577
G1 X111.373 Y155.765 E.01261
G1 X123.738 Y143.401 E.42577
G1 X123.22 Y143.401 E.01261
G1 X110.856 Y155.765 E.42575
G1 X110.338 Y155.765 E.01261
G1 X122.702 Y143.401 E.42575
G1 X122.185 Y143.401 E.01259
G1 X109.82 Y155.765 E.42577
G1 X109.303 Y155.765 E.01259
G1 X121.667 Y143.401 E.42575
G1 X121.149 Y143.401 E.01261
G1 X108.785 Y155.765 E.42575
G1 X108.267 Y155.765 E.01261
G1 X120.631 Y143.401 E.42575
G1 X120.114 Y143.401 E.01259
G1 X107.75 Y155.765 E.42575
G1 X107.232 Y155.765 E.01261
G1 X119.596 Y143.401 E.42575
G1 X119.078 Y143.401 E.01261
G1 X106.714 Y155.765 E.42575
G1 X106.197 Y155.765 E.01259
G1 X118.56 Y143.402 E.42572
G1 X118.043 Y143.402 E.01259
G1 X105.679 Y155.765 E.42574
G1 X105.161 Y155.765 E.01261
G1 X117.525 Y143.402 E.42574
G1 X117.007 Y143.402 E.01261
G1 X106.528 Y153.881 E.36084
G1 X106.493 Y154.135 E.00624
G1 X106.348 Y154.322 E.00576
G1 X106.156 Y154.405 E.00509
G1 X105.997 Y154.412 E.00388
G1 X104.644 Y155.765 E.04659
G1 X104.126 Y155.765 E.01261
G1 X105.479 Y154.412 E.04659
G1 X104.961 Y154.413 E.01261
G1 X103.608 Y155.765 E.04657
G1 X103.091 Y155.765 E.01259
G1 X104.443 Y154.413 E.04656
G1 X103.925 Y154.413 E.01261
G1 X102.573 Y155.765 E.04656
G1 X102.055 Y155.765 E.01261
G1 X103.407 Y154.414 E.04654
G1 X102.889 Y154.414 E.01261
G1 X101.538 Y155.765 E.04652
G1 X101.02 Y155.765 E.01261
G1 X102.371 Y154.414 E.04652
G1 X101.853 Y154.415 E.01261
G1 X100.502 Y155.765 E.0465
G1 X99.985 Y155.765 E.01259
G1 X101.335 Y154.415 E.04649
G1 X100.817 Y154.415 E.01261
G1 X99.467 Y155.765 E.04649
G1 X98.949 Y155.765 E.01261
G1 X100.299 Y154.416 E.04647
G1 X99.781 Y154.416 E.01261
G1 X98.432 Y155.765 E.04645
G1 X97.914 Y155.765 E.01261
G1 X99.263 Y154.416 E.04645
G1 X98.745 Y154.417 E.01261
G1 X97.396 Y155.765 E.04644
G1 X97.136 Y155.765 E.00633
G1 X96.816 Y155.828 E.00794
G1 X98.227 Y154.417 E.04859
G1 X97.709 Y154.417 E.01261
G1 X96.078 Y156.049 E.05618
G1 X95.838 Y156.14 E.00625
G1 X95.836 Y155.772 E.00896
G1 X97.191 Y154.418 E.04664
G1 X96.726 Y154.365 E.0114
G1 X95.835 Y155.256 E.03068
G1 X95.833 Y154.74 E.01256
G1 X96.301 Y154.272 E.01612
G1 X95.877 Y154.178 E.01057
G1 X95.667 Y154.388 E.00723
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X95.877 Y154.178 E-.14107
G1 X96.301 Y154.272 E-.20629
G1 X95.833 Y154.74 E-.31438
G1 X95.835 Y155.256 E-.2451
G1 X96.718 Y154.373 E-.59316
;WIPE_END
G1 X106.363 Y153.528 F9000
G1 E5 F2400
G1 F900
G1 X116.489 Y143.402 E.34869
G1 X115.972 Y143.402 E.01259
G1 X106.528 Y152.846 E.3252
G1 X106.528 Y152.328 E.01261
G1 X115.454 Y143.402 E.30737
G1 X114.936 Y143.402 E.01261
G1 X106.528 Y151.811 E.28955
G1 X106.528 Y151.293 E.01261
G1 X114.418 Y143.402 E.27171
G1 X113.901 Y143.402 E.01259
G1 X106.528 Y150.775 E.25389
G1 X106.528 Y150.258 E.01259
G1 X113.383 Y143.402 E.23607
G1 X112.865 Y143.402 E.01261
G1 X106.458 Y149.81 E.22064
G1 X106.411 Y149.738 E.00209
G1 X106.235 Y149.616 E.00521
G1 X106.149 Y149.601 E.00213
G1 X112.347 Y143.403 E.21343
G1 X111.83 Y143.403 E.01259
G1 X105.645 Y149.588 E.21298
G1 X105.127 Y149.587 E.01261
G1 X111.312 Y143.403 E.21296
G1 X110.794 Y143.403 E.01261
G1 X104.61 Y149.587 E.21295
G1 X104.093 Y149.587 E.01259
G1 X110.276 Y143.403 E.21293
G1 X109.759 Y143.403 E.01259
G1 X103.575 Y149.586 E.21293
G1 X103.058 Y149.586 E.01259
G1 X109.241 Y143.403 E.21291
G1 X108.723 Y143.403 E.01261
G1 X106.528 Y145.598 E.07558
G1 X106.529 Y145.079 E.01264
G1 X108.206 Y143.403 E.05773
G1 X107.688 Y143.403 E.01261
G1 X106.53 Y144.561 E.03988
G1 X106.531 Y144.042 E.01264
G1 X107.17 Y143.403 E.022
G1 X106.652 Y143.403 E.01261
G1 X106.367 Y143.688 E.00981
G1 E-5 F3600
G1 X106.367 Y143.688 F9000
G1 X105.879 Y146.248
G1 E5 F2400
G1 F900
G1 X102.541 Y149.586 E.11494
G1 X102.023 Y149.585 E.01261
G1 X105.196 Y146.413 E.10924
G1 X104.678 Y146.413 E.01261
G1 X101.506 Y149.585 E.10923
G1 X100.989 Y149.585 E.01259
G1 X104.16 Y146.413 E.10921
G1 X103.642 Y146.414 E.01261
G1 X100.471 Y149.584 E.10918
G1 X99.954 Y149.584 E.01259
G1 X103.124 Y146.414 E.10916
G1 X102.606 Y146.414 E.01261
G1 X99.437 Y149.584 E.10914
G1 X98.919 Y149.584 E.01261
G1 X102.088 Y146.415 E.10912
G1 X101.57 Y146.415 E.01261
G1 X98.402 Y149.583 E.10909
G1 X97.885 Y149.583 E.01259
G1 X101.052 Y146.415 E.10907
G1 X100.534 Y146.416 E.01261
G1 X97.367 Y149.583 E.10906
G1 X97.139 Y149.582 E.00555
G1 X96.809 Y149.623 E.0081
G1 X100.016 Y146.416 E.11043
G1 X99.498 Y146.416 E.01261
G1 X96.152 Y149.762 E.11522
G1 X95.818 Y149.838 E.00834
G1 X95.831 Y149.565 E.00665
G1 X98.98 Y146.416 E.10844
G1 X98.462 Y146.417 E.01261
G1 X95.831 Y149.048 E.0906
G1 X95.831 Y148.53 E.01261
G1 X97.944 Y146.417 E.07276
G1 X97.426 Y146.417 E.01261
G1 X95.831 Y148.012 E.05492
G1 X95.831 Y147.495 E.01259
G1 X96.934 Y146.392 E.03798
G1 X96.493 Y146.315 E.0109
G1 X95.831 Y146.977 E.0228
G1 X95.831 Y146.459 E.01261
G1 X96.208 Y146.083 E.01296
M106 S137.7
;LAYER_CHANGE
;Z:2.22
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;2.22
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X95.831 Y146.459 E-.25291
G1 X95.831 Y146.977 E-.24605
G1 X96.493 Y146.315 E-.4447
G1 X96.934 Y146.392 E-.21264
G1 X96.423 Y146.903 E-.3437
;WIPE_END
G1 Z2.22 F9000
;AFTER_LAYER_CHANGE
;2.22
G1 Z2.22
G1 X102.572 Y138.595
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X102.476 Y138.505 E.0032
G1 X102.4 Y138.263 E.00617
G1 X102.408 Y136.134 E.05179
G1 X102.506 Y135.377 E.01857
G1 X102.629 Y134.88 E.01245
G1 X102.761 Y134.592 E.00771
G1 X104.837 Y134.593 E.0505
G1 X105 Y135.478 E.02189
G1 X105 Y136.117 E.01554
G1 X104.539 Y136.575 E.01581
G1 X104.131 Y137.111 E.01639
G1 X104.029 Y137.469 E.00905
G1 X104.102 Y137.821 E.00874
G1 X104.419 Y138.295 E.01387
G1 X104.775 Y138.659 E.01238
G1 X102.817 Y138.652 E.04763
G1 X102.623 Y138.621 E.00478
G1 X102.623 Y138.621 F9000
G1 X102.789 Y138.273
;TYPE:Perimeter
G1 F6000
G1 X102.767 Y137.813 E.0112
G1 X102.772 Y136.403 E.0343
G1 X102.824 Y135.772 E.0154
G1 X104.634 Y135.769 E.04403
G1 X104.634 Y135.907 E.00336
G1 X104.594 Y136.004 E.00255
G1 X104.039 Y136.591 E.01965
G1 X103.776 Y137.018 E.0122
G1 X103.668 Y137.426 E.01027
G1 X103.723 Y137.848 E.01035
G1 X103.976 Y138.29 E.01239
G1 X102.837 Y138.286 E.02771
G1 X102.837 Y138.286 F9000
G1 X103.217 Y137.212
;WIDTH:0.580476
G1 F6000
G1 X103.202 Y137.027 E.00674
;WIDTH:0.533099
G1 X103.18 Y136.735 E.00972
;WIDTH:0.485722
G1 X103.182 Y136.18 E.01666
G1 X103.857 Y136.179 E.02027
G1 X103.732 Y136.322 E.0057
G1 X103.427 Y136.805 E.01715
;WIDTH:0.533099
G1 X103.326 Y137.062 E.00916
;WIDTH:0.580476
G1 X103.225 Y137.319 E.01003
G1 X103.221 Y137.272 E.00171
G1 X103.221 Y137.272 F9000
G1 X103.238 Y137.817
;WIDTH:0.609674
G1 F6000
G1 X103.225 Y137.319 E.01907
G1 E-5 F3600
G1 X103.225 Y137.319 F9000
G1 X104.89 Y135.612
G1 E5 F2400
;WIDTH:0.411481
G1 F900
G1 X104.145 Y134.867 E.02643
G1 X103.611 Y134.867 E.0134
G1 X104.241 Y135.496 E.02233
G1 X103.708 Y135.496 E.01337
G1 X103.078 Y134.866 E.02235
G1 X102.932 Y134.866 E.00366
G1 X102.839 Y135.161 E.00776
G1 X103.34 Y135.661 E.01776
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X102.839 Y135.161 E-.33621
G1 X102.932 Y134.866 E-.14692
G1 X103.078 Y134.866 E-.06935
G1 X103.708 Y135.496 E-.4232
G1 X104.241 Y135.496 E-.25318
G1 X103.837 Y135.092 E-.27114
;WIPE_END
G1 X103.838 Y135.496 F9000
G1 X104.324 Y136.291
G1 X105.03 Y137.452
G1 X104.738 Y137.312
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X104.897 Y137.035 E.00777
G1 X105.697 Y136.231 E.02759
G1 X105.75 Y136.102 E.00339
G1 X105.75 Y134.596 E.03663
G1 X107.939 Y134.592 E.05325
G1 X108.071 Y134.88 E.00771
G1 X108.194 Y135.368 E.01224
G1 X108.274 Y135.924 E.01366
G1 X108.3 Y136.429 E.0123
G1 X108.3 Y138.206 E.04322
G1 X108.249 Y138.484 E.00687
G1 X108.137 Y138.613 E.00416
G1 X107.982 Y138.659 E.00393
G1 X105.582 Y138.66 E.05838
G1 X104.902 Y137.963 E.02369
G1 X104.687 Y137.623 E.00978
G1 X104.69 Y137.396 E.00552
G1 X104.708 Y137.364 E.00089
G1 X104.708 Y137.364 F9000
G1 X105.059 Y137.487
;TYPE:Perimeter
G1 F6000
G1 X105.057 Y137.483 E.00011
G1 X105.324 Y137.124 E.01088
G1 X105.974 Y136.469 E.02245
G1 X106.104 Y136.166 E.00802
G1 X106.116 Y135.77 E.00964
G1 X107.878 Y135.772 E.04286
G1 X107.934 Y136.421 E.01584
G1 X107.934 Y138.181 E.04281
G1 X107.903 Y138.285 E.00264
G1 X105.732 Y138.294 E.05281
G1 X105.283 Y137.85 E.01536
G1 X105.091 Y137.538 E.00891
G1 X105.535 Y137.447 F9000
G1 F6000
G1 X105.597 Y137.368 E.00244
G1 X106.234 Y136.727 E.02198
G1 X106.356 Y136.538 E.00547
G1 X106.475 Y136.136 E.0102
G1 X107.548 Y136.137 E.0261
G1 X107.569 Y136.421 E.00693
G1 X107.569 Y137.928 E.03666
G1 X105.882 Y137.929 E.04103
G1 X105.489 Y137.504 E.01408
G1 X105.497 Y137.493 E.00033
G1 X105.497 Y137.493 F9000
G1 X106.056 Y137.563
G1 F6000
G1 X105.975 Y137.506 E.00241
G1 X106.537 Y136.937 E.01945
G1 X106.76 Y136.502 E.01189
G1 X107.203 Y136.502 E.01078
G1 X107.203 Y137.563 E.02581
G1 X106.116 Y137.563 E.02644
G1 X106.116 Y137.563 F9000
G1 X106.873 Y137.184
;WIDTH:0.426118
G1 F6000
G1 X106.849 Y137.226 E.00126
G1 X106.775 Y137.184 E.00222
G1 X106.849 Y137.142 E.00222
G1 E-5 F3600
G1 X106.849 Y137.142 F9000
G1 X108.02 Y135.126
G1 E5 F2400
;WIDTH:0.463589
G1 F900
G1 X107.761 Y134.867 E.01046
G1 X107.156 Y134.868 E.01728
G1 X107.785 Y135.497 E.0254
G1 X107.177 Y135.497 E.01736
G1 X106.55 Y134.869 E.02534
G1 X106.024 Y134.87 E.01502
G1 X106.024 Y134.951 E.00231
G1 X106.734 Y135.661 E.02867
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X106.024 Y134.951 E-.47694
G1 X106.024 Y134.87 E-.03847
G1 X106.55 Y134.869 E-.24985
G1 X107.177 Y135.497 E-.42152
G1 X107.785 Y135.497 E-.2888
G1 X107.749 Y135.461 E-.02442
;WIPE_END
G1 X122.728 Y138.352 F9000
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X122.7 Y138.263 E.00227
G1 X122.708 Y136.134 E.05179
G1 X122.806 Y135.376 E.01859
G1 X122.929 Y134.88 E.01243
G1 X123.061 Y134.592 E.00771
G1 X125.25 Y134.598 E.05325
G1 X125.25 Y136.102 E.03658
G1 X125.305 Y136.233 E.00346
G1 X125.917 Y136.83 E.0208
G1 X126.206 Y137.202 E.01146
G1 X126.302 Y137.396 E.00527
G1 X126.33 Y137.521 E.00312
G1 X126.246 Y137.762 E.00621
G1 X125.803 Y138.287 E.01671
G1 X125.42 Y138.66 E.013
G1 X123.127 Y138.66 E.05577
G1 X122.905 Y138.637 E.00543
G1 X122.776 Y138.505 E.00449
G1 X122.746 Y138.409 E.00245
G1 X122.746 Y138.409 F9000
G1 X123.096 Y138.292
;TYPE:Perimeter
G1 F6000
G1 X123.089 Y138.292 E.00017
G1 X123.066 Y138.208 E.00212
G1 X123.073 Y136.185 E.04921
G1 X123.124 Y135.772 E.01012
G1 X124.886 Y135.77 E.04286
G1 X124.89 Y136.166 E.00963
G1 X125.05 Y136.494 E.00888
G1 X125.691 Y137.12 E.02179
G1 X125.931 Y137.515 E.01124
G1 X125.698 Y137.833 E.00959
G1 X125.272 Y138.294 E.01527
G1 X123.156 Y138.292 E.05147
G1 X123.156 Y138.292 F9000
G1 X123.433 Y137.837
G1 F6000
G1 X123.445 Y136.137 E.04135
G1 X124.491 Y136.136 E.02544
G1 X124.587 Y136.419 E.00727
G1 X124.794 Y136.756 E.00962
G1 X125.244 Y137.195 E.01529
G1 X125.501 Y137.493 E.00957
G1 X125.121 Y137.928 E.01405
G1 X123.433 Y137.926 E.04106
G1 X123.433 Y137.897 E.00071
G1 X123.433 Y137.897 F9000
G1 X124.024 Y137.561
G1 F6000
G1 X123.8 Y137.561 E.00545
G1 X123.803 Y136.502 E.02576
G1 X124.241 Y136.502 E.01065
G1 X124.29 Y136.641 E.00358
G1 X124.539 Y137.018 E.01099
G1 X125.031 Y137.498 E.01672
G1 X124.971 Y137.563 E.00215
G1 X124.084 Y137.562 E.02158
G1 X124.084 Y137.562 F9000
G1 X124.228 Y137.184
;WIDTH:0.424642
G1 F6000
G1 X124.203 Y137.226 E.00127
G1 X124.13 Y137.184 E.00219
G1 X124.203 Y137.141 E.0022
G1 X124.203 Y137.141 F9000
G1 X125.14 Y135.494
;WIDTH:0.422088
G1 F900
G1 X124.517 Y134.871 E.02273
G1 X123.967 Y134.87 E.01419
G1 X124.594 Y135.496 E.02285
G1 X124.046 Y135.497 E.01413
G1 X123.418 Y134.868 E.02293
G1 X123.232 Y134.868 E.0048
G1 X123.143 Y135.143 E.00746
G1 X123.662 Y135.662 E.01893
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X123.143 Y135.143 E-.34864
G1 X123.232 Y134.868 E-.1373
G1 X123.418 Y134.868 E-.08835
G1 X124.046 Y135.497 E-.4222
G1 X124.594 Y135.496 E-.2603
G1 X124.232 Y135.134 E-.24321
;WIPE_END
G1 X124.232 Y135.497 F9000
G1 X124.901 Y135.506
G1 X126.348 Y135.964
G1 X126 Y136.116
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X126 Y135.388 E.01771
G1 X126.163 Y134.593 E.01974
G1 X128.239 Y134.592 E.0505
G1 X128.371 Y134.88 E.00771
G1 X128.494 Y135.368 E.01224
G1 X128.574 Y135.918 E.01352
G1 X128.6 Y136.421 E.01225
G1 X128.589 Y138.303 E.04578
G1 X128.504 Y138.543 E.00619
G1 X128.337 Y138.653 E.00486
G1 X126.225 Y138.659 E.05137
G1 X126.581 Y138.295 E.01238
G1 X126.898 Y137.821 E.01387
G1 X126.969 Y137.501 E.00797
G1 X126.892 Y137.163 E.00843
G1 X126.649 Y136.786 E.01091
G1 X126.039 Y136.16 E.02126
G1 X126.039 Y136.16 F9000
G1 X126.366 Y135.959
;TYPE:Perimeter
G1 F6000
G1 X126.366 Y135.769 E.00462
G1 X128.179 Y135.772 E.0441
G1 X128.234 Y136.421 E.01584
G1 X128.234 Y137.689 E.03084
G1 X128.211 Y138.272 E.01419
G1 X127.016 Y138.291 E.02907
G1 X127.2 Y138.027 E.00783
G1 X127.296 Y137.695 E.00841
G1 X127.323 Y137.362 E.00813
G1 X127.195 Y136.953 E.01042
G1 X126.896 Y136.515 E.0129
G1 X126.399 Y136.006 E.0173
G1 X126.399 Y136.006 F9000
G1 X127.14 Y136.18
;WIDTH:0.48705
G1 F6000
G1 X127.81 Y136.18 E.02018
G1 X127.825 Y136.421 E.00727
G1 X127.825 Y136.785 E.01096
;WIDTH:0.533744
G1 X127.802 Y137.061 E.0092
;WIDTH:0.580438
G1 X127.778 Y137.338 E.0101
G1 X127.728 Y137.177 E.00612
;WIDTH:0.540044
G1 X127.617 Y136.924 E.00929
;WIDTH:0.513547
G1 X127.507 Y136.672 E.00877
;WIDTH:0.48705
G1 X127.176 Y136.228 E.01668
G1 X127.176 Y136.228 F9000
G1 X127.758 Y137.812
;WIDTH:0.621488
G1 F6000
G1 X127.778 Y137.338 E.01853
G1 E-5 F3600
G1 X127.778 Y137.338 F9000
G1 X128.322 Y135.132
G1 E5 F2400
;WIDTH:0.470568
G1 F900
G1 X128.056 Y134.866 E.01092
G1 X127.439 Y134.867 E.0179
G1 X128.07 Y135.497 E.02587
G1 X127.453 Y135.497 E.0179
G1 X126.823 Y134.867 E.02585
G1 X126.387 Y134.867 E.01265
G1 X126.356 Y135.017 E.00444
G1 X127 Y135.661 E.02643
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X126.356 Y135.017 E-.43261
G1 X126.387 Y134.867 E-.07276
G1 X126.823 Y134.867 E-.2071
G1 X127.453 Y135.497 E-.4232
G1 X128.07 Y135.497 E-.29307
G1 X127.964 Y135.391 E-.07126
;WIPE_END
G1 X135.381 Y137.809 F9000
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X135.381 Y137.808 E.00002
G1 X139.21 Y137.807 E.09314
G1 X139.511 Y137.726 E.00758
G1 X139.716 Y137.571 E.00625
G1 X139.846 Y137.363 E.00597
G1 X139.9 Y137.087 E.00684
G1 X139.9 Y134.913 E.05288
G1 X139.867 Y134.697 E.00531
G1 X139.683 Y134.398 E.00854
G1 X139.47 Y134.253 E.00627
G1 X139.202 Y134.193 E.00668
G1 X136.7 Y134.194 E.06086
G1 X136.7 Y129.806 E.10673
G1 X139.291 Y129.797 E.06302
G1 X139.523 Y129.722 E.00593
G1 X139.716 Y129.571 E.00596
G1 X139.846 Y129.363 E.00597
G1 X139.9 Y129.087 E.00684
G1 X139.9 Y126.913 E.05288
G1 X139.867 Y126.697 E.00531
G1 X139.683 Y126.399 E.00852
G1 X139.47 Y126.253 E.00628
G1 X139.202 Y126.193 E.00668
G1 X136.7 Y126.194 E.06086
G1 X136.7 Y121.806 E.10673
G1 X139.291 Y121.797 E.06302
G1 X139.523 Y121.722 E.00593
G1 X139.716 Y121.571 E.00596
G1 X139.846 Y121.363 E.00597
G1 X139.9 Y121.087 E.00684
G1 X139.9 Y118.913 E.05288
G1 X139.867 Y118.697 E.00531
G1 X139.683 Y118.398 E.00854
G1 X139.47 Y118.253 E.00627
G1 X139.202 Y118.193 E.00668
G1 X136.7 Y118.194 E.06086
G1 X136.7 Y113.806 E.10673
G1 X139.291 Y113.797 E.06302
G1 X139.523 Y113.722 E.00593
G1 X139.716 Y113.571 E.00596
G1 X139.846 Y113.363 E.00597
G1 X139.9 Y113.087 E.00684
G1 X139.9 Y110.913 E.05288
G1 X139.867 Y110.697 E.00531
G1 X139.683 Y110.398 E.00854
G1 X139.47 Y110.253 E.00627
G1 X139.202 Y110.193 E.00668
G1 X136.7 Y110.194 E.06086
G1 X136.7 Y105.806 E.10673
G1 X139.291 Y105.797 E.06302
G1 X139.523 Y105.722 E.00593
G1 X139.716 Y105.571 E.00596
G1 X139.846 Y105.363 E.00597
G1 X139.9 Y105.087 E.00684
G1 X139.9 Y102.913 E.05288
G1 X139.867 Y102.697 E.00531
G1 X139.683 Y102.399 E.00852
G1 X139.47 Y102.253 E.00628
G1 X139.202 Y102.193 E.00668
G1 X136.7 Y102.194 E.06086
G1 X136.7 Y99.985 E.05373
G1 X139.718 Y99.985 E.07341
G1 X139.852 Y99.925 E.00357
G1 X139.9 Y99.802 E.00321
G1 X139.908 Y85.522 E.34735
G1 X139.947 Y85.374 E.00372
G1 X140.095 Y85.228 E.00506
G1 X140.585 Y85.214 E.01192
G1 X141.104 Y85.23 E.01263
G1 X141.237 Y85.331 E.00406
G1 X141.3 Y85.551 E.00557
G1 X141.29 Y151.343 E1.60032
G1 X141.218 Y151.963 E.01518
G1 X140.957 Y152.958 E.02502
G1 X140.526 Y153.892 E.02502
G1 X140.118 Y154.508 E.01797
G1 X139.714 Y154.984 E.01519
G1 X138.944 Y155.666 E.02502
G1 X138.067 Y156.2 E.02498
G1 X137.23 Y156.534 E.02192
G1 X136.649 Y156.62 E.01429
G1 X136.018 Y156.552 E.01544
G1 X135.588 Y156.42 E.01094
G1 X135.154 Y156.143 E.01252
G1 X135.054 Y155.971 E.00484
G1 X135.06 Y154.398 E.03826
G1 X135.103 Y154.22 E.00445
G1 X135.478 Y154.009 E.01047
G1 X136.124 Y153.862 E.01611
G1 X136.726 Y153.807 E.0147
G1 X139.212 Y153.797 E.06047
G1 X139.523 Y153.722 E.00778
G1 X139.716 Y153.571 E.00596
G1 X139.846 Y153.363 E.00597
G1 X139.9 Y153.086 E.00686
G1 X139.892 Y150.818 E.05517
G1 X139.763 Y150.492 E.00853
G1 X139.483 Y150.261 E.00883
G1 X139.202 Y150.193 E.00703
G1 X136.788 Y150.193 E.05872
G1 X136.236 Y150.158 E.01345
G1 X135.7 Y150.056 E.01327
G1 X135.356 Y149.937 E.00885
G1 X135.122 Y149.796 E.00665
G1 X135.06 Y149.669 E.00344
G1 X135.075 Y146.253 E.08309
G1 X135.332 Y146.07 E.00767
G1 X135.89 Y145.894 E.01423
G1 X136.729 Y145.807 E.02052
G1 X139.291 Y145.797 E.06232
G1 X139.523 Y145.722 E.00593
G1 X139.716 Y145.571 E.00596
G1 X139.846 Y145.363 E.00597
G1 X139.9 Y145.087 E.00684
G1 X139.892 Y142.818 E.05519
G1 X139.763 Y142.492 E.00853
G1 X139.483 Y142.261 E.00883
G1 X139.202 Y142.193 E.00703
G1 X136.788 Y142.193 E.05872
G1 X136.236 Y142.158 E.01345
G1 X135.7 Y142.056 E.01327
G1 X135.356 Y141.937 E.00885
G1 X135.122 Y141.796 E.00665
G1 X135.06 Y141.669 E.00344
G1 X135.057 Y138.775 E.07039
G1 X135.157 Y138.388 E.00972
G1 X135.359 Y137.865 E.01364
G1 X135.636 Y138.181 F9000
;TYPE:Perimeter
G1 F6000
G1 X135.639 Y138.173 E.00021
G1 X139.095 Y138.172 E.08406
G1 X139.607 Y138.079 E.01266
G1 X139.94 Y137.859 E.00971
G1 X140.158 Y137.553 E.00914
;WIDTH:0.448693
G1 X140.218 Y137.398 E.00458
;WIDTH:0.497386
G1 X140.278 Y137.243 E.00512
;WIDTH:0.546079
G1 X140.339 Y137.087 E.0057
;WIDTH:0.548784
G1 X140.335 Y134.852 E.07648
G1 X140.267 Y134.703 E.0056
;WIDTH:0.499189
G1 X140.199 Y134.554 E.00506
;WIDTH:0.449594
G1 X140.13 Y134.405 E.00454
;WIDTH:0.399999
G1 X139.8 Y134.024 E.01226
G1 X139.461 Y133.869 E.00907
G1 X138.898 Y133.827 E.01373
G1 X137.066 Y133.828 E.04456
G1 X137.066 Y130.17 E.08898
G1 X139.292 Y130.163 E.05415
G1 X139.638 Y130.069 E.00872
G1 X139.944 Y129.857 E.00905
G1 X140.158 Y129.553 E.00904
;WIDTH:0.448974
G1 X140.218 Y129.398 E.00458
;WIDTH:0.497948
G1 X140.279 Y129.243 E.00514
;WIDTH:0.546922
G1 X140.339 Y129.087 E.0057
;WIDTH:0.549627
G1 X140.336 Y126.852 E.07661
G1 X140.267 Y126.704 E.0056
;WIDTH:0.499751
G1 X140.199 Y126.555 E.00507
;WIDTH:0.449875
G1 X140.13 Y126.406 E.00454
;WIDTH:0.399999
G1 X139.801 Y126.024 E.01226
G1 X139.461 Y125.869 E.00909
G1 X138.898 Y125.827 E.01373
G1 X137.066 Y125.828 E.04456
G1 X137.066 Y122.17 E.08898
G1 X139.292 Y122.163 E.05415
G1 X139.638 Y122.069 E.00872
G1 X139.944 Y121.857 E.00905
G1 X140.158 Y121.553 E.00904
;WIDTH:0.449255
G1 X140.218 Y121.398 E.00459
;WIDTH:0.498511
G1 X140.279 Y121.243 E.00514
;WIDTH:0.547766
G1 X140.34 Y121.087 E.00572
;WIDTH:0.55047
G1 X140.336 Y118.852 E.07674
G1 X140.285 Y118.741 E.00419
;WIDTH:0.512853
G1 X140.233 Y118.629 E.00393
;WIDTH:0.475235
G1 X140.182 Y118.517 E.00361
;WIDTH:0.437617
G1 X140.13 Y118.405 E.00331
;WIDTH:0.399999
G1 X139.8 Y118.024 E.01226
G1 X139.461 Y117.869 E.00907
G1 X138.898 Y117.827 E.01373
G1 X137.066 Y117.828 E.04456
G1 X137.066 Y114.17 E.08898
G1 X139.292 Y114.163 E.05415
G1 X139.638 Y114.069 E.00872
G1 X139.944 Y113.857 E.00905
G1 X140.158 Y113.553 E.00904
;WIDTH:0.449536
G1 X140.218 Y113.398 E.00459
;WIDTH:0.499073
G1 X140.279 Y113.243 E.00515
;WIDTH:0.548609
G1 X140.34 Y113.087 E.00573
;WIDTH:0.551313
G1 X140.336 Y110.852 E.07686
G1 X140.285 Y110.741 E.0042
;WIDTH:0.513485
G1 X140.233 Y110.629 E.00394
;WIDTH:0.475656
G1 X140.182 Y110.517 E.00361
;WIDTH:0.437828
G1 X140.13 Y110.405 E.00331
;WIDTH:0.399999
G1 X139.8 Y110.024 E.01226
G1 X139.461 Y109.869 E.00907
G1 X138.898 Y109.827 E.01373
G1 X137.066 Y109.828 E.04456
G1 X137.066 Y106.17 E.08898
G1 X139.292 Y106.163 E.05415
G1 X139.638 Y106.069 E.00872
G1 X139.944 Y105.857 E.00905
G1 X140.158 Y105.553 E.00904
;WIDTH:0.449817
G1 X140.218 Y105.398 E.00459
;WIDTH:0.499635
G1 X140.279 Y105.243 E.00516
;WIDTH:0.549452
G1 X140.34 Y105.087 E.00574
;WIDTH:0.552156
G1 X140.337 Y102.852 E.07699
G1 X140.294 Y102.758 E.00356
;WIDTH:0.514117
G1 X140.251 Y102.663 E.00333
;WIDTH:0.476078
G1 X140.208 Y102.568 E.00306
;WIDTH:0.438039
G1 X140.165 Y102.473 E.0028
;WIDTH:0.399999
G1 X139.861 Y102.072 E.01224
G1 X139.561 Y101.903 E.00838
G1 X139.202 Y101.827 E.00893
G1 X137.066 Y101.828 E.05196
G1 X137.066 Y100.35 E.03595
G1 X139.603 Y100.35 E.06171
G1 X139.901 Y100.313 E.0073
;WIDTH:0.409797
G1 X140.162 Y100.117 E.00815
;WIDTH:0.456462
G1 X140.222 Y100.012 E.0034
;WIDTH:0.503126
G1 X140.281 Y99.907 E.00376
;WIDTH:0.54979
G1 X140.341 Y99.802 E.00415
G1 X140.347 Y85.918 E.47606
;WIDTH:0.547583
G1 X140.347 Y85.66 E.00881
;WIDTH:0.547458
G1 X140.852 Y85.646 E.01724
;WIDTH:0.547583
G1 X140.86 Y85.918 E.00929
;WIDTH:0.54979
G1 X140.856 Y99.802 E.47606
G1 X140.88 Y99.955 E.00531
;WIDTH:0.503126
G1 X140.903 Y100.108 E.00482
;WIDTH:0.456462
G1 X140.926 Y100.261 E.00434
;WIDTH:0.409797
G1 X140.931 Y100.689 E.01069
;WIDTH:0.399999
G1 X140.931 Y102.372 E.04094
;WIDTH:0.440317
G1 X140.911 Y102.458 E.00238
;WIDTH:0.480634
G1 X140.89 Y102.544 E.00263
;WIDTH:0.520951
G1 X140.87 Y102.63 E.00286
;WIDTH:0.561268
G1 X140.85 Y102.716 E.00309
G1 X140.855 Y102.852 E.00477
;WIDTH:0.552156
G1 X140.856 Y105.086 E.07695
;WIDTH:0.549452
G1 X140.88 Y105.247 E.00558
;WIDTH:0.500346
G1 X140.905 Y105.408 E.00505
;WIDTH:0.45124
G1 X140.929 Y105.569 E.00451
;WIDTH:0.402134
G1 X140.93 Y105.785 E.00528
;WIDTH:0.399999
G1 X140.929 Y110.371 E.11155
;WIDTH:0.440106
G1 X140.909 Y110.458 E.00241
;WIDTH:0.480212
G1 X140.889 Y110.544 E.00262
;WIDTH:0.520318
G1 X140.869 Y110.63 E.00285
;WIDTH:0.560424
G1 X140.849 Y110.716 E.00309
G1 X140.853 Y110.852 E.00476
;WIDTH:0.551313
G1 X140.854 Y113.086 E.07683
;WIDTH:0.548609
G1 X140.879 Y113.247 E.00557
;WIDTH:0.499777
G1 X140.903 Y113.408 E.00504
;WIDTH:0.450945
G1 X140.927 Y113.569 E.00451
;WIDTH:0.402113
G1 X140.928 Y113.785 E.00528
;WIDTH:0.399999
G1 X140.927 Y118.372 E.11157
;WIDTH:0.439891
G1 X140.907 Y118.458 E.00238
;WIDTH:0.479783
G1 X140.888 Y118.544 E.00261
;WIDTH:0.519675
G1 X140.868 Y118.63 E.00285
;WIDTH:0.559567
G1 X140.848 Y118.716 E.00308
G1 X140.852 Y118.852 E.00475
;WIDTH:0.55047
G1 X140.853 Y121.086 E.0767
;WIDTH:0.547766
G1 X140.877 Y121.247 E.00556
;WIDTH:0.499215
G1 X140.901 Y121.408 E.00503
;WIDTH:0.450664
G1 X140.926 Y121.569 E.00451
;WIDTH:0.402113
G1 X140.927 Y121.784 E.00526
;WIDTH:0.399999
G1 X140.926 Y126.372 E.1116
;WIDTH:0.439673
G1 X140.906 Y126.458 E.00238
;WIDTH:0.479347
G1 X140.886 Y126.544 E.00261
;WIDTH:0.519021
G1 X140.866 Y126.63 E.00285
;WIDTH:0.558694
G1 X140.846 Y126.716 E.00308
G1 X140.851 Y126.852 E.00475
;WIDTH:0.549627
G1 X140.852 Y129.086 E.07658
;WIDTH:0.546923
G1 X140.853 Y129.195 E.00372
;WIDTH:0.543717
G1 X140.877 Y129.391 E.00669
;WIDTH:0.495811
G1 X140.901 Y129.588 E.00609
;WIDTH:0.447905
G1 X140.925 Y129.784 E.00543
;WIDTH:0.399999
G1 X140.924 Y134.372 E.1116
;WIDTH:0.439462
G1 X140.904 Y134.458 E.00238
;WIDTH:0.478925
G1 X140.885 Y134.544 E.0026
;WIDTH:0.518388
G1 X140.865 Y134.63 E.00284
;WIDTH:0.55785
G1 X140.845 Y134.717 E.00311
G1 X140.85 Y134.852 E.0047
;WIDTH:0.548784
G1 X140.85 Y137.086 E.07645
;WIDTH:0.54608
G1 X140.852 Y137.195 E.00371
;WIDTH:0.542918
G1 X140.876 Y137.391 E.00668
;WIDTH:0.495279
G1 X140.9 Y137.587 E.00605
;WIDTH:0.447639
G1 X140.923 Y137.783 E.00543
;WIDTH:0.399999
G1 X140.922 Y142.209 E.10766
;WIDTH:0.44976
G1 X140.897 Y142.411 E.00562
;WIDTH:0.499521
G1 X140.873 Y142.613 E.00629
;WIDTH:0.549282
G1 X140.848 Y142.815 E.00697
G1 X140.849 Y145.084 E.07772
;WIDTH:0.545237
G1 X140.851 Y145.193 E.00371
;WIDTH:0.542263
G1 X140.874 Y145.39 E.0067
;WIDTH:0.494842
G1 X140.898 Y145.586 E.00605
;WIDTH:0.447421
G1 X140.922 Y145.783 E.00545
;WIDTH:0.399999
G1 X140.921 Y150.209 E.10766
;WIDTH:0.449479
G1 X140.896 Y150.411 E.00562
;WIDTH:0.498959
G1 X140.871 Y150.613 E.00629
;WIDTH:0.548439
G1 X140.846 Y150.815 E.00696
G1 X140.845 Y151.361 E.01867
;WIDTH:0.547522
G1 X140.789 Y151.932 E.01959
;WIDTH:0.513239
G1 X140.554 Y152.825 E.02942
G1 X140.253 Y153.471 E.0227
G1 X140.322 Y153.085 E.01249
G1 X140.318 Y151.873 E.03861
;WIDTH:0.547522
G1 X140.334 Y151.331 E.01851
;WIDTH:0.548439
G1 X140.332 Y150.816 E.01761
G1 X140.255 Y150.662 E.00589
;WIDTH:0.498959
G1 X140.178 Y150.508 E.00532
;WIDTH:0.449479
G1 X140.101 Y150.354 E.00475
;WIDTH:0.399999
G1 X139.95 Y150.154 E.0061
G1 X139.541 Y149.894 E.01179
G1 X139.093 Y149.827 E.01102
G1 X137.249 Y149.824 E.04485
G1 X136.27 Y149.793 E.02383
G1 X135.751 Y149.687 E.01288
G1 X135.444 Y149.553 E.00815
G1 X135.426 Y148.891 E.01611
G1 X135.426 Y146.445 E.0595
G1 X135.965 Y146.254 E.01391
G1 X136.749 Y146.173 E.01917
G1 X139.292 Y146.163 E.06186
G1 X139.638 Y146.069 E.00872
G1 X139.944 Y145.857 E.00905
G1 X140.158 Y145.553 E.00904
;WIDTH:0.448412
G1 X140.218 Y145.397 E.0046
;WIDTH:0.496824
G1 X140.278 Y145.242 E.00511
;WIDTH:0.545236
G1 X140.338 Y145.086 E.00568
;WIDTH:0.549282
G1 X140.333 Y142.816 E.07776
G1 X140.255 Y142.662 E.00591
;WIDTH:0.499521
G1 X140.178 Y142.508 E.00533
;WIDTH:0.44976
G1 X140.101 Y142.354 E.00476
;WIDTH:0.399999
G1 X139.95 Y142.154 E.0061
G1 X139.541 Y141.894 E.01179
G1 X139.099 Y141.827 E.01087
G1 X137.247 Y141.824 E.04505
G1 X136.27 Y141.793 E.02378
G1 X135.751 Y141.687 E.01288
G1 X135.444 Y141.553 E.00815
G1 X135.425 Y140.891 E.01611
G1 X135.423 Y138.827 E.0502
G1 X135.617 Y138.238 E.01508
G1 E-5 F3600
G1 X135.617 Y138.238 F9000
G1 X135.587 Y138.227
G1 X139.216 Y138.156
G1 X139.257 Y138.153
G1 X139.394 Y138.137
G1 X139.564 Y138.09
G1 X139.731 Y138.01
G1 X139.881 Y137.902
G1 X140.009 Y137.77
G1 X140.113 Y137.618
G1 X140.189 Y137.452
G1 X140.208 Y137.377
G1 X140.235 Y137.269
G1 X140.249 Y137.108
G1 X140.249 Y118.892
G1 X140.235 Y118.731
G1 X140.208 Y118.623
G1 X140.189 Y118.549
G1 X140.113 Y118.382
G1 X140.009 Y118.23
G1 X137.049 Y114.155
G1 X137.432 Y114.155
G1 X137.431 Y114.534
G1 E5 F2400
G1 F6000
G1 X139.293 Y114.528 E.04529
G1 X139.74 Y114.42 E.01119
G1 X140.162 Y114.15 E.01219
G1 X140.463 Y113.755 E.01208
;WIDTH:0.402113
G1 X140.56 Y113.496 E.00677
G1 X140.563 Y113.785 E.00707
;WIDTH:0.399999
G1 X140.562 Y118.541 E.11568
G1 X140.415 Y118.176 E.00957
G1 X140.145 Y117.842 E.01045
G1 X139.964 Y117.697 E.00564
G1 X139.488 Y117.504 E.01249
G1 X138.898 Y117.462 E.01439
G1 X137.431 Y117.462 E.03568
G1 X137.431 Y114.594 E.06976
G1 E-5 F3600
G1 X137.431 Y114.594 F9000
G1 X137.797 Y117.096
G1 E5 F2400
G1 F6000
G1 X137.797 Y114.899 E.05344
G1 X139.294 Y114.894 E.03641
G1 X139.843 Y114.771 E.01368
G1 X140.197 Y114.579 E.0098
G1 X140.196 Y117.425 E.06923
G1 X139.857 Y117.234 E.00946
G1 X139.515 Y117.139 E.00863
G1 X138.898 Y117.096 E.01504
G1 X137.857 Y117.096 E.02532
G1 X137.857 Y117.096 F9000
G1 X138.163 Y116.731
G1 F6000
G1 X138.163 Y115.263 E.03571
G1 X139.295 Y115.26 E.02753
G1 X139.831 Y115.156 E.01328
G1 X139.831 Y116.854 E.0413
G1 X139.542 Y116.775 E.00729
G1 X138.898 Y116.73 E.0157
G1 X138.223 Y116.731 E.01642
G1 E-5 F3600
G1 X138.223 Y116.731 F9000
G1 X140.113 Y113.618
G1 X140.189 Y113.452
G1 X140.208 Y113.377
G1 X140.235 Y113.269
G1 X140.249 Y113.108
G1 X140.249 Y110.892
G1 X140.235 Y110.731
G1 X140.208 Y110.623
G1 X140.189 Y110.549
G1 X140.113 Y110.382
G1 X140.009 Y110.23
G1 X137.172 Y106.155
G1 X137.432 Y106.155
G1 X137.431 Y106.534
G1 E5 F2400
G1 F6000
G1 X139.293 Y106.528 E.04529
G1 X139.74 Y106.42 E.01119
G1 X140.162 Y106.15 E.01219
G1 X140.463 Y105.755 E.01208
;WIDTH:0.402134
G1 X140.561 Y105.489 E.00694
G1 X140.564 Y105.785 E.00724
;WIDTH:0.399999
G1 X140.563 Y110.547 E.11583
G1 X140.415 Y110.176 E.00972
G1 X140.145 Y109.842 E.01045
G1 X139.964 Y109.697 E.00564
G1 X139.488 Y109.504 E.01249
G1 X138.898 Y109.462 E.01439
G1 X137.431 Y109.462 E.03568
G1 X137.431 Y106.594 E.06976
G1 X137.431 Y106.594 F9000
G1 X137.797 Y106.899
G1 F6000
G1 X139.294 Y106.894 E.03641
G1 X139.843 Y106.771 E.01368
G1 X140.199 Y106.578 E.00985
G1 X140.198 Y109.426 E.06927
G1 X139.857 Y109.234 E.00952
G1 X139.515 Y109.139 E.00863
G1 X138.898 Y109.096 E.01504
G1 X137.797 Y109.096 E.02678
G1 X137.797 Y106.959 E.05198
G1 X138.163 Y107.263 F9000
G1 F6000
G1 X139.295 Y107.26 E.02753
G1 X139.833 Y107.155 E.01333
G1 X139.832 Y108.855 E.04135
G1 X139.542 Y108.775 E.00732
G1 X138.898 Y108.73 E.0157
G1 X138.163 Y108.731 E.01788
G1 X138.163 Y107.323 E.03425
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X138.163 Y107.263 E-.0285
G1 X139.295 Y107.26 E-.5377
G1 X139.833 Y107.155 E-.26037
G1 X139.833 Y108.573 E-.67343
;WIPE_END
G1 X140.235 Y105.269 F9000
G1 X140.249 Y105.108
G1 X140.249 Y102.892
G1 X140.235 Y102.731
G1 X140.208 Y102.623
G1 X140.189 Y102.549
G1 X140.113 Y102.382
G1 X140.009 Y102.23
G1 X139.881 Y102.098
G1 X139.731 Y101.99
G1 X137.049 Y100.333
G1 X137.431 Y100.333
G1 X137.431 Y100.716
G1 E5 F2400
G1 F6000
G1 X139.354 Y100.716 E.04678
G1 X139.939 Y100.689 E.01424
G1 X140.268 Y100.52 E.009
;WIDTH:0.409797
G1 X140.512 Y100.253 E.00903
G1 X140.551 Y100.153 E.00268
G1 X140.565 Y100.689 E.01339
;WIDTH:0.399999
G1 X140.565 Y102.553 E.04534
G1 X140.415 Y102.176 E.00987
G1 X140.145 Y101.842 E.01045
G1 X139.965 Y101.697 E.00562
G1 X139.693 Y101.561 E.0074
G1 X139.202 Y101.462 E.01218
G1 X137.431 Y101.462 E.04308
G1 X137.431 Y100.776 E.01669
G1 X137.431 Y100.776 F9000
G1 X137.804 Y101.089
;WIDTH:0.414826
G1 F6000
G1 X139.202 Y101.089 E.03538
;WIDTH:0.44119
G1 X139.402 Y101.102 E.00542
;WIDTH:0.468056
G1 X139.603 Y101.116 E.00581
G1 X139.718 Y101.1 E.00335
;WIDTH:0.435928
G1 X139.969 Y101.02 E.00704
;WIDTH:0.396401
G1 X140.221 Y100.941 E.00636
;WIDTH:0.356874
G1 X140.221 Y101.472 E.01139
G1 X140.119 Y101.389 E.00282
;WIDTH:0.393935
G1 X139.947 Y101.298 E.00465
;WIDTH:0.430996
G1 X139.775 Y101.207 E.00513
;WIDTH:0.468056
G1 X139.656 Y101.144 E.00388
G1 E-5 F3600
G1 X139.656 Y101.144 F9000
G1 X140.249 Y121.108
G1 X140.235 Y121.269
G1 X140.208 Y121.377
G1 X140.189 Y121.452
G1 X140.113 Y121.618
G1 X140.009 Y121.77
G1 X137.172 Y125.845
G1 X137.432 Y125.845
G1 X137.431 Y125.462
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y122.534 E.07122
G1 X139.293 Y122.528 E.04529
G1 X139.74 Y122.42 E.01119
G1 X140.162 Y122.15 E.01219
G1 X140.463 Y121.755 E.01208
;WIDTH:0.402113
G1 X140.558 Y121.504 E.00657
G1 X140.561 Y121.784 E.00685
;WIDTH:0.399999
G1 X140.56 Y126.534 E.11554
G1 X140.415 Y126.176 E.0094
G1 X140.145 Y125.842 E.01045
G1 X139.965 Y125.697 E.00562
G1 X139.488 Y125.504 E.01252
G1 X138.898 Y125.462 E.01439
G1 X137.491 Y125.462 E.03422
G1 X137.491 Y125.462 F9000
G1 X137.797 Y125.096
G1 F6000
G1 X137.797 Y122.899 E.05344
G1 X139.294 Y122.894 E.03641
G1 X139.843 Y122.771 E.01368
G1 X140.195 Y122.581 E.00973
G1 X140.195 Y125.423 E.06913
G1 X139.857 Y125.234 E.00942
G1 X139.515 Y125.139 E.00863
G1 X138.898 Y125.096 E.01504
G1 X137.857 Y125.096 E.02532
G1 X137.857 Y125.096 F9000
G1 X138.163 Y124.731
G1 F6000
G1 X138.163 Y123.263 E.03571
G1 X139.295 Y123.26 E.02753
G1 X139.829 Y123.156 E.01323
G1 X139.829 Y124.854 E.0413
G1 X139.542 Y124.775 E.00724
G1 X138.898 Y124.73 E.0157
G1 X138.223 Y124.731 E.01642
G1 E-5 F3600
G1 X138.223 Y124.731 F9000
G1 X139.881 Y126.098
G1 X140.009 Y126.23
G1 X140.113 Y126.382
G1 X140.189 Y126.549
G1 X140.208 Y126.623
G1 X140.235 Y126.731
G1 X140.249 Y126.892
G1 X140.249 Y129.108
G1 X140.235 Y129.269
G1 X140.208 Y129.377
G1 X140.189 Y129.451
G1 X140.113 Y129.618
G1 X140.009 Y129.77
G1 X137.172 Y133.845
G1 X137.432 Y133.845
G1 X137.431 Y133.462
G1 E5 F2400
G1 F6000
G1 X137.431 Y130.534 E.07122
G1 X139.293 Y130.528 E.04529
G1 X139.74 Y130.42 E.01119
G1 X140.162 Y130.15 E.01219
G1 X140.463 Y129.755 E.01208
;WIDTH:0.402134
G1 X140.556 Y129.513 E.00634
G1 X140.559 Y129.784 E.00663
;WIDTH:0.399999
G1 X140.558 Y134.528 E.11539
G1 X140.415 Y134.176 E.00924
G1 X140.145 Y133.842 E.01045
G1 X139.964 Y133.697 E.00564
G1 X139.488 Y133.504 E.01249
G1 X138.898 Y133.462 E.01439
G1 X137.491 Y133.462 E.03422
G1 X137.491 Y133.462 F9000
G1 X137.797 Y133.096
G1 F6000
G1 X137.797 Y130.899 E.05344
G1 X139.294 Y130.894 E.03641
G1 X139.843 Y130.771 E.01368
G1 X140.194 Y130.582 E.0097
G1 X140.193 Y133.422 E.06908
G1 X139.857 Y133.234 E.00937
G1 X139.515 Y133.139 E.00863
G1 X138.898 Y133.096 E.01504
G1 X137.857 Y133.096 E.02532
G1 X137.857 Y133.096 F9000
G1 X138.163 Y132.731
G1 F6000
G1 X138.163 Y131.263 E.03571
G1 X139.295 Y131.26 E.02753
G1 X139.828 Y131.157 E.0132
G1 X139.827 Y132.853 E.04125
G1 X139.542 Y132.775 E.00719
G1 X138.898 Y132.73 E.0157
G1 X138.223 Y132.731 E.01642
G1 E-5 F3600
G1 X138.223 Y132.731 F9000
G1 X139.881 Y134.098
G1 X140.009 Y134.23
G1 X140.113 Y134.382
G1 X140.189 Y134.549
G1 X140.208 Y134.623
G1 X140.235 Y134.731
G1 X140.249 Y134.892
G1 X140.009 Y137.77
G1 X139.731 Y138.01
G1 X135.408 Y140.797
G1 X135.408 Y140.887
G1 X135.791 Y140.886
G1 E5 F2400
G1 F6000
G1 X135.789 Y138.952 E.04704
G1 X135.903 Y138.539 E.01042
G1 X139.21 Y138.538 E.08044
G1 X139.695 Y138.434 E.01207
G1 X140.151 Y138.158 E.01297
G1 X140.463 Y137.755 E.0124
;WIDTH:0.402123
G1 X140.555 Y137.52 E.00617
G1 X140.558 Y137.783 E.00643
;WIDTH:0.399999
G1 X140.557 Y142.536 E.11561
G1 X140.444 Y142.228 E.00798
G1 X140.233 Y141.922 E.00904
G1 X139.73 Y141.581 E.01478
G1 X139.51 Y141.506 E.00565
G1 X139.099 Y141.462 E.01005
G1 X137.247 Y141.458 E.04505
G1 X136.304 Y141.429 E.02295
G1 X135.827 Y141.329 E.01185
G1 X135.796 Y140.946 E.00935
G1 E-5 F3600
G1 X135.796 Y140.946 F9000
G1 X136.155 Y138.952
G1 E5 F2400
G1 F6000
G1 X136.168 Y138.904 E.00121
G1 X139.21 Y138.904 E.07399
G1 X139.784 Y138.788 E.01424
G1 X140.192 Y138.576 E.01118
G1 X140.191 Y141.433 E.06949
G1 X139.919 Y141.268 E.00774
G1 X139.552 Y141.143 E.00943
G1 X139.1 Y141.096 E.01105
G1 X136.691 Y141.09 E.0586
G1 X136.16 Y141.03 E.013
G1 X136.155 Y139.012 E.04909
G1 X136.155 Y139.012 F9000
G1 X136.52 Y139.27
G1 F6000
G1 X139.21 Y139.269 E.06543
G1 X139.826 Y139.155 E.01524
G1 X139.826 Y140.859 E.04145
G1 X139.595 Y140.78 E.00594
G1 X139.1 Y140.73 E.0121
G1 X136.522 Y140.712 E.06271
G1 X136.521 Y139.33 E.03362
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X136.52 Y139.27 E-.0285
G1 X139.21 Y139.269 E-1.27775
G1 X139.611 Y139.195 E-.19375
;WIPE_END
G1 X140.235 Y142.731 F9000
G1 X140.249 Y142.892
G1 X140.249 Y145.108
G1 X140.235 Y145.269
G1 X140.208 Y145.377
G1 X140.189 Y145.452
G1 X140.113 Y145.618
G1 X140.009 Y145.77
G1 X139.881 Y145.902
G1 X139.731 Y146.01
G1 X139.564 Y146.09
G1 X139.394 Y146.137
G1 X139.257 Y146.153
G1 X135.409 Y146.422
G1 X135.409 Y146.692
G1 X135.791 Y146.692
G1 E5 F2400
G1 F6000
G1 X136.039 Y146.614 E.00632
G1 X136.769 Y146.538 E.01785
G1 X139.084 Y146.529 E.05631
G1 X139.445 Y146.506 E.0088
G1 X139.913 Y146.334 E.01213
G1 X140.293 Y146.012 E.01212
;WIDTH:0.401783
G1 X140.549 Y145.568 E.01253
G1 X140.556 Y145.783 E.00526
;WIDTH:0.399999
G1 X140.555 Y150.532 E.11551
G1 X140.444 Y150.228 E.00787
G1 X140.233 Y149.922 E.00904
G1 X139.73 Y149.581 E.01478
G1 X139.509 Y149.506 E.00568
G1 X139.093 Y149.462 E.01018
G1 X137.25 Y149.458 E.04483
G1 X136.304 Y149.429 E.02302
G1 X135.827 Y149.329 E.01185
G1 X135.791 Y148.886 E.01081
G1 X135.791 Y146.752 E.05191
G1 X135.791 Y146.752 F9000
G1 X136.157 Y146.969
G1 F6000
G1 X136.788 Y146.904 E.01543
G1 X139.295 Y146.894 E.06098
G1 X139.843 Y146.771 E.01366
G1 X140.19 Y146.584 E.00959
G1 X140.19 Y149.432 E.06927
G1 X139.919 Y149.268 E.0077
G1 X139.551 Y149.143 E.00945
G1 X139.094 Y149.096 E.01117
G1 X136.691 Y149.09 E.05845
G1 X136.161 Y149.03 E.01297
G1 X136.157 Y147.029 E.04867
G1 X136.157 Y147.029 F9000
G1 X136.523 Y147.299
G1 F6000
G1 X136.808 Y147.27 E.00697
G1 X139.296 Y147.26 E.06052
G1 X139.824 Y147.158 E.01308
G1 X139.824 Y148.858 E.04135
G1 X139.593 Y148.779 E.00594
G1 X139.095 Y148.73 E.01217
G1 X136.523 Y148.712 E.06256
G1 X136.523 Y147.359 E.03291
G1 E-5 F3600
G1 X136.523 Y147.359 F9000
G1 X139.881 Y150.098
G1 X140.009 Y150.23
G1 X140.113 Y150.382
G1 X140.189 Y150.549
G1 X140.208 Y150.623
G1 X140.235 Y150.731
G1 X140.249 Y150.892
G1 X140.249 Y152.811
G1 X140.218 Y153.107
G1 X140.187 Y153.261
G1 X140.132 Y153.431
G1 X140.112 Y153.474
G1 X140.058 Y153.587
G1 X139.963 Y153.732
G1 X139.937 Y153.762
G1 X140.039 Y153.853
G1 E5 F2400
;WIDTH:0.522894
G1 F6000
G1 X140.253 Y153.471 E.01423
G1 E-5 F3600
G1 X140.253 Y153.471 F9000
G1 X139.848 Y153.864
G1 X139.713 Y153.981
G1 X139.56 Y154.08
G1 X139.473 Y154.115
G1 X139.394 Y154.137
G1 X139.257 Y154.153
G1 X135.408 Y154.422
G1 X135.408 Y154.455
G1 X135.43 Y154.455
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X135.605 Y154.356 E.00489
G1 X136.285 Y154.201 E.01696
G1 X136.822 Y154.172 E.01308
G1 X139.292 Y154.163 E.06008
G1 X139.641 Y154.068 E.0088
;WIDTH:0.440964
G1 X139.774 Y153.996 E.00409
;WIDTH:0.481929
G1 X139.906 Y153.925 E.00446
;WIDTH:0.522894
G1 X140.039 Y153.853 E.00492
G1 X139.962 Y154.004 E.00551
;WIDTH:0.481929
G1 X139.886 Y154.156 E.00506
;WIDTH:0.440964
G1 X139.809 Y154.307 E.00458
;WIDTH:0.399999
G1 X139.425 Y154.751 E.01428
G1 X138.726 Y155.37 E.02271
G1 X137.903 Y155.872 E.02345
G1 X137.24 Y156.136 E.01736
G1 X136.767 Y156.234 E.01175
G1 X136.327 Y156.219 E.01071
G1 X135.829 Y156.113 E.01238
G1 X135.431 Y155.875 E.01128
G1 X135.43 Y154.515 E.03308
G1 X135.43 Y154.515 F9000
G1 X135.793 Y154.688
G1 F6000
G1 X136.282 Y154.577 E.0122
G1 X136.833 Y154.538 E.01344
G1 X139.124 Y154.529 E.05573
G1 X138.507 Y155.075 E.02004
G1 X137.739 Y155.544 E.02189
G1 X137.104 Y155.797 E.01663
G1 X136.63 Y155.884 E.01172
G1 X136.116 Y155.819 E.0126
G1 X135.793 Y155.677 E.00858
G1 X135.793 Y154.748 E.0226
G1 X135.793 Y154.748 F9000
G1 X136.207 Y155.021
;WIDTH:0.504158
G1 F6000
G1 X136.861 Y154.956 E.02054
G1 X137.907 Y154.952 E.03269
G1 X137.551 Y155.169 E.01303
G1 X136.949 Y155.409 E.02025
;WIDTH:0.515743
G1 X136.653 Y155.453 E.00958
G1 X136.204 Y155.41 E.01444
;WIDTH:0.501131
G1 X136.207 Y155.081 E.01022
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X136.207 Y155.021 E-.0285
G1 X136.861 Y154.956 E-.31218
G1 X137.907 Y154.952 E-.49685
G1 X137.551 Y155.169 E-.19804
G1 X136.949 Y155.409 E-.30784
G1 X136.653 Y155.453 E-.14214
G1 X136.623 Y155.45 E-.01445
;WIPE_END
G1 X137.435 Y148.617 F9000
G1 E5 F2400
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X136.797 Y147.979 E.02195
G1 X136.797 Y147.555 E.01031
G1 X136.93 Y147.553 E.00324
G1 X137.829 Y148.453 E.03094
G1 X138.389 Y148.454 E.01362
G1 X137.483 Y147.549 E.03115
G1 X138.037 Y147.544 E.01348
G1 X138.948 Y148.456 E.03136
G1 X139.55 Y148.505 E.01469
G1 X138.59 Y147.54 E.03311
G1 X139.144 Y147.535 E.01348
G1 X139.714 Y148.106 E.01962
G1 E-5 F3600
G1 X139.714 Y148.106 F9000
G1 X140.208 Y142.623
G1 X140.189 Y142.549
G1 X140.113 Y142.382
G1 X140.009 Y142.23
G1 X139.881 Y142.098
G1 X139.731 Y141.99
G1 X137.435 Y140.616
G1 E5 F2400
G1 F3072.127
G1 X136.795 Y139.977 E.022
G1 X136.795 Y139.544 E.01053
G1 X136.922 Y139.544 E.00309
G1 X137.83 Y140.453 E.03125
G1 X138.391 Y140.454 E.01365
G1 X137.48 Y139.544 E.03132
G1 X138.039 Y139.544 E.0136
G1 X138.951 Y140.456 E.03137
G1 X139.552 Y140.505 E.01467
G1 X138.598 Y139.544 E.03294
G1 X139.157 Y139.544 E.0136
G1 X139.716 Y140.103 E.01923
G1 E-5 F3600
G1 X139.716 Y140.103 F9000
G1 X139.718 Y132.118
G1 E5 F2400
G1 F3072.127
G1 X139.134 Y131.534 E.02009
G1 X138.569 Y131.536 E.01374
G1 X139.531 Y132.499 E.03311
G1 X138.925 Y132.46 E.01477
G1 X138.272 Y131.807 E.02246
G1 E-5 F3600
G1 X138.272 Y131.807 F9000
G1 X140.009 Y129.77
G1 X139.72 Y124.119
G1 E5 F2400
G1 F3072.127
G1 X139.135 Y123.534 E.02012
G1 X138.57 Y123.536 E.01374
G1 X139.532 Y124.499 E.03311
G1 X138.926 Y124.46 E.01477
G1 X138.272 Y123.806 E.0225
G1 E-5 F3600
G1 X138.272 Y123.806 F9000
G1 X140.009 Y121.77
G1 X139.721 Y116.119
G1 E5 F2400
G1 F3072.127
G1 X139.137 Y115.534 E.02011
G1 X138.571 Y115.536 E.01377
G1 X139.533 Y116.499 E.03311
G1 X138.926 Y116.46 E.0148
G1 X138.272 Y115.805 E.02251
G1 E-5 F3600
G1 X138.272 Y115.805 F9000
G1 X140.009 Y113.77
G1 X139.723 Y108.119
G1 E5 F2400
G1 F3072.127
G1 X139.138 Y107.534 E.02012
G1 X138.572 Y107.536 E.01377
G1 X139.535 Y108.499 E.03313
G1 X138.927 Y108.46 E.01482
G1 X138.272 Y107.805 E.02253
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X138.927 Y108.46 E-.44
G1 X139.535 Y108.499 E-.28939
G1 X138.572 Y107.536 E-.6469
G1 X138.832 Y107.535 E-.12371
;WIPE_END
G1 X138.361 Y106.156 F9000
G1 X134.991 Y96.292
G1 X134.092 Y93.659
G1 X129.782 Y81.04
G1 X128.295 Y76.689
G1 X127.99 Y75.621
G1 X127.943 Y75.656
G1 E5 F2400
;WIDTH:0.633526
G1 F6000
G1 X130.818 Y75.658 E.11459
G1 X130.818 Y75.658 F9000
G1 X130.931 Y75.845
;WIDTH:0.49341
G1 F6000
G1 X130.927 Y75.838 E.00025
;WIDTH:0.540115
G1 X130.891 Y75.778 E.00235
;WIDTH:0.586821
G1 X130.854 Y75.718 E.00259
;WIDTH:0.633526
G1 X130.818 Y75.658 E.00279
G1 X130.936 Y75.635 E.00479
;WIDTH:0.586821
G1 X131.054 Y75.612 E.00442
;WIDTH:0.540115
G1 X131.173 Y75.588 E.00408
;WIDTH:0.49341
G1 X131.291 Y75.565 E.00367
;WIDTH:0.446705
G1 X131.409 Y75.542 E.0033
;WIDTH:0.399999
G1 X134.013 Y75.542 E.06334
G1 X134.234 Y75.606 E.0056
G1 X134.3 Y75.821 E.00547
G1 X134.3 Y79.795 E.09666
G1 X134.276 Y80.605 E.01971
G1 X134.152 Y81.887 E.03133
G1 X134.006 Y82.582 E.01727
G1 X130.953 Y82.564 E.07426
G1 X131 Y82.05 E.01255
G1 X131 Y78.88 E.07711
G1 X131.482 Y78.397 E.0166
G1 X131.858 Y77.908 E.015
G1 X131.963 Y77.594 E.00805
G1 X131.884 Y77.144 E.01111
G1 X131.572 Y76.694 E.01332
G1 X131 Y76.12 E.01971
G1 X131 Y75.958 E.00394
;WIDTH:0.446705
G1 X130.964 Y75.898 E.00192
G1 X130.964 Y75.898 F9000
G1 X131.378 Y75.983
;TYPE:Perimeter
;WIDTH:0.399999
G1 F6000
G1 X131.347 Y75.907 E.002
G1 X133.934 Y75.907 E.06293
G1 X133.933 Y79.827 E.09535
G1 X133.893 Y80.77 E.02296
G1 X131.366 Y80.762 E.06147
G1 X131.366 Y79.03 E.04213
G1 X131.894 Y78.489 E.01839
G1 X132.237 Y77.952 E.0155
G1 X132.332 Y77.504 E.01114
G1 X132.211 Y76.988 E.01289
G1 X131.871 Y76.483 E.01481
G1 X131.421 Y76.026 E.0156
G1 E-5 F3600
G1 X131.421 Y76.026 F9000
G1 X131.357 Y76.155
G1 X131.623 Y76.286
G1 X131.845 Y76.476
G1 X131.989 Y76.652
G1 X132.099 Y76.809
G1 X132.184 Y76.958
G1 X132.25 Y77.108
G1 X132.295 Y77.262
G1 X132.319 Y77.42
G1 X132.319 Y77.58
G1 X132.295 Y77.738
G1 X132.25 Y77.892
G1 X132.184 Y78.042
G1 X132.099 Y78.191
G1 X131.989 Y78.348
G1 X131.845 Y78.524
G1 X131.649 Y78.739
G1 X131.47 Y78.917
G1 X131.731 Y79.18
G1 E5 F2400
G1 F6000
G1 X132.199 Y78.691 E.01646
G1 X132.591 Y78.043 E.01842
G1 X132.702 Y77.541 E.01251
G1 X132.595 Y76.977 E.01396
G1 X132.515 Y76.786 E.00504
G1 X132.169 Y76.273 E.01505
G1 X133.569 Y76.273 E.03405
G1 X133.568 Y79.805 E.08591
G1 X133.548 Y80.403 E.01455
G1 X131.731 Y80.398 E.0442
G1 X131.731 Y79.24 E.02817
G1 E-5 F3600
G1 X131.731 Y79.24 F9000
G1 X133.128 Y77.712
G1 E5 F2400
;WIDTH:0.55652
G1 F6000
G1 X133.125 Y77.337 E.01303
G1 E-5 F3600
G1 X133.125 Y77.337 F9000
G1 X132.097 Y79.33
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X132.504 Y78.893 E.01453
G1 X132.822 Y78.411 E.01405
;WIDTH:0.437534
G1 X132.898 Y78.237 E.00509
;WIDTH:0.475069
G1 X132.975 Y78.062 E.00561
;WIDTH:0.512604
G1 X133.051 Y77.887 E.00607
;WIDTH:0.550138
G1 X133.128 Y77.712 E.00656
G1 X133.146 Y77.826 E.00396
;WIDTH:0.512604
G1 X133.165 Y77.939 E.00365
;WIDTH:0.475069
G1 X133.184 Y78.053 E.00339
;WIDTH:0.437534
G1 X133.203 Y78.166 E.00307
;WIDTH:0.399999
G1 X133.195 Y80.036 E.04549
G1 X132.097 Y80.033 E.02671
G1 X132.097 Y79.39 E.01564
G1 X132.097 Y79.39 F9000
G1 X132.454 Y79.535
;WIDTH:0.382676
G1 F6000
G1 X132.495 Y79.434 E.00253
G1 X132.846 Y79.023 E.01252
G1 X132.845 Y79.678 E.01518
G1 X132.454 Y79.677 E.00906
G1 X132.454 Y79.595 E.0019
G1 E-5 F3600
G1 X132.454 Y79.595 F9000
G1 X133.125 Y77.337
G1 E5 F2400
;WIDTH:0.55652
G1 F6000
G1 X133.062 Y77.193 E.00546
;WIDTH:0.516414
G1 X132.999 Y77.049 E.00504
;WIDTH:0.476309
G1 X132.937 Y76.905 E.00461
;WIDTH:0.436203
G1 X132.874 Y76.761 E.0042
;WIDTH:0.396097
G1 X132.811 Y76.617 E.00378
;WIDTH:0.355991
G1 X133.225 Y76.617 E.00886
G1 X133.225 Y76.778 E.00344
;WIDTH:0.396097
G1 X133.205 Y76.889 E.00271
;WIDTH:0.436203
G1 X133.185 Y77.001 E.00304
;WIDTH:0.476309
G1 X133.165 Y77.113 E.00334
;WIDTH:0.516414
G1 X133.145 Y77.225 E.00365
;WIDTH:0.55652
G1 X133.135 Y77.278 E.00187
G1 E-5 F3600
G1 X134.076 Y81.564 F9000
G1 E5 F2400
;TYPE:Top solid infill
;WIDTH:0.404985
G1 F900
G1 X133.555 Y81.043 E.01817
G1 X133.029 Y81.042 E.01297
G1 X133.873 Y81.886 E.02943
G1 X133.795 Y82.306 E.01053
G1 X133.77 Y82.306 E.00062
G1 X132.503 Y81.04 E.04416
G1 X131.978 Y81.038 E.01294
G1 X133.242 Y82.303 E.04409
G1 X132.715 Y82.3 E.01299
G1 X131.452 Y81.037 E.04404
G1 X131.274 Y81.036 E.00439
G1 X131.274 Y81.383 E.00856
G1 X132.188 Y82.297 E.03187
G1 X131.661 Y82.294 E.01299
G1 X131.11 Y81.743 E.01921
G1 X131.11 Y81.743 F9000
G1 X130.137 Y82.555
;WIDTH:0.399999
G1 F6000
G1 X130.135 Y82.563 E.0002
G1 X127.998 Y82.571 E.05198
G1 X127.897 Y82.176 E.00992
G1 X127.792 Y81.439 E.01811
G1 X127.724 Y80.606 E.02033
G1 X127.7 Y79.795 E.01974
G1 X127.7 Y76.642 E.07669
G1 X127.746 Y76.451 E.00478
G1 X127.909 Y76.342 E.00477
G1 X130.42 Y76.341 E.06108
G1 X130.752 Y76.659 E.01118
G1 X131.128 Y77.066 E.01348
G1 X131.314 Y77.411 E.00953
G1 X131.314 Y77.591 E.00438
G1 X131.144 Y77.913 E.00886
G1 X130.302 Y78.771 E.02924
G1 X130.25 Y78.898 E.00334
G1 X130.239 Y81.972 E.07477
G1 X130.147 Y82.496 E.01294
G1 E-5 F3600
G1 X130.147 Y82.496 F9000
G1 X129.058 Y80.764
G1 E5 F2400
;TYPE:Perimeter
G1 F6000
G1 X128.11 Y80.763 E.02306
G1 X128.066 Y79.804 E.02335
G1 X128.068 Y76.708 E.07531
G1 X130.273 Y76.707 E.05363
G1 X130.614 Y77.046 E.0117
G1 X130.943 Y77.468 E.01302
G1 X130.848 Y77.692 E.00592
G1 X130.025 Y78.532 E.0286
G1 X129.884 Y78.897 E.00952
G1 X129.878 Y80.765 E.04544
G1 X129.118 Y80.764 E.01849
G1 E-5 F3600
G1 X129.118 Y80.764 F9000
G1 X129.619 Y78.546
G1 E5 F2400
G1 F6000
G1 X129.519 Y78.896 E.00885
G1 X129.513 Y80.397 E.03651
G1 X128.459 Y80.395 E.02564
G1 X128.432 Y79.796 E.01458
G1 X128.433 Y77.073 E.06623
G1 X130.125 Y77.073 E.04116
G1 X130.514 Y77.51 E.01423
G1 X129.764 Y78.276 E.02608
G1 X129.642 Y78.469 E.00555
G1 X129.636 Y78.488 E.00048
G1 X129.636 Y78.488 F9000
G1 X129.278 Y78.397
G1 F6000
G1 X129.211 Y78.578 E.00469
;WIDTH:0.399889
G1 X129.156 Y78.894 E.0078
;WIDTH:0.394758
G1 X129.153 Y80.034 E.02733
;WIDTH:0.391628
G1 X128.804 Y80.032 E.00829
;WIDTH:0.393378
G1 X128.794 Y79.788 E.00583
;WIDTH:0.394758
G1 X128.795 Y78.894 E.02143
;WIDTH:0.399999
G1 X128.799 Y77.439 E.03539
G1 X129.957 Y77.438 E.02817
G1 X130.026 Y77.486 E.00204
G1 X129.503 Y78.021 E.0182
G1 X129.299 Y78.341 E.00923
G1 X129.299 Y78.341 F9000
G1 X129.225 Y77.817
;WIDTH:0.425114
G1 F6000
G1 X129.201 Y77.859 E.00126
G1 X129.128 Y77.817 E.00219
G1 X129.201 Y77.774 E.0022
G1 E-5 F3600
G1 X129.201 Y77.774 F9000
G1 X130.131 Y81.63
G1 E5 F2400
;WIDTH:0.408631
G1 F900
G1 X129.54 Y81.04 E.02079
G1 X129.011 Y81.039 E.01317
G1 X129.958 Y81.987 E.03336
G1 X129.905 Y82.29 E.00766
G1 X129.732 Y82.29 E.00431
G1 X128.481 Y81.039 E.04405
G1 X128.035 Y81.039 E.0111
G1 X128.042 Y81.13 E.00227
G1 X129.205 Y82.292 E.04093
G1 X128.678 Y82.295 E.01312
G1 X127.917 Y81.533 E.02681
G1 E-5 F3600
G1 X127.917 Y81.533 F9000
G1 X125.421 Y89.342
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X125.755 Y89.67 E.01139
G1 X126.186 Y90.143 E.01557
G1 X126.322 Y90.447 E.0081
G1 X126.31 Y90.604 E.00383
G1 X126.103 Y90.965 E.01012
G1 X125.303 Y91.769 E.02759
G1 X125.25 Y91.898 E.00339
G1 X125.25 Y93.404 E.03663
G1 X123.061 Y93.408 E.05325
G1 X122.955 Y93.192 E.00585
G1 X122.813 Y92.679 E.01295
G1 X122.733 Y92.133 E.01342
G1 X122.7 Y91.607 E.01282
G1 X122.7 Y89.797 E.04403
G1 X122.755 Y89.507 E.00718
G1 X122.861 Y89.39 E.00384
G1 X123.028 Y89.34 E.00424
G1 X125.362 Y89.34 E.05677
G1 X125.362 Y89.34 F9000
G1 X125.276 Y89.713
;TYPE:Perimeter
G1 F6000
G1 X125.717 Y90.15 E.0151
G1 X125.943 Y90.517 E.01048
G1 X125.676 Y90.876 E.01088
G1 X125.026 Y91.531 E.02245
G1 X124.896 Y91.834 E.00802
G1 X124.884 Y92.23 E.00964
G1 X123.125 Y92.228 E.04279
G1 X123.067 Y91.622 E.01481
G1 X123.066 Y89.818 E.04388
G1 X123.096 Y89.716 E.00259
G1 X125.22 Y89.706 E.05166
G1 X125.22 Y89.706 F9000
G1 X125.131 Y90.085
G1 F6000
G1 X125.511 Y90.496 E.01362
G1 X125.402 Y90.632 E.00424
G1 X124.766 Y91.273 E.02196
G1 X124.644 Y91.462 E.00547
G1 X124.525 Y91.864 E.0102
G1 X123.457 Y91.863 E.02598
G1 X123.433 Y91.605 E.0063
G1 X123.432 Y90.071 E.03731
G1 X125.077 Y90.071 E.04001
G1 X125.077 Y90.071 F9000
G1 X124.985 Y90.466
G1 F6000
G1 X125.025 Y90.494 E.00119
G1 X124.463 Y91.063 E.01945
G1 X124.241 Y91.498 E.01188
G1 X123.798 Y91.498 E.01078
G1 X123.798 Y90.437 E.02581
G1 X124.934 Y90.437 E.02763
G1 X124.934 Y90.437 F9000
G1 X124.225 Y90.816
;WIDTH:0.425796
G1 F6000
G1 X124.201 Y90.858 E.00126
G1 X124.127 Y90.816 E.00222
G1 X124.201 Y90.773 E.00223
G1 X124.201 Y90.773 F9000
G1 X124.265 Y92.339
;WIDTH:0.463585
G1 F900
G1 X124.976 Y93.049 E.02869
G1 X124.976 Y93.13 E.00231
G1 X124.45 Y93.131 E.01502
G1 X123.822 Y92.503 E.02536
G1 X123.215 Y92.503 E.01733
G1 X123.844 Y93.132 E.0254
G1 X123.238 Y93.133 E.0173
G1 X122.977 Y92.872 E.01054
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X123.238 Y93.133 E-.17533
G1 X123.844 Y93.132 E-.28785
G1 X123.215 Y92.503 E-.42253
G1 X123.822 Y92.503 E-.28832
G1 X124.307 Y92.988 E-.32597
;WIPE_END
G1 X126 Y91.935 F9000
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X126.011 Y91.871 E.00158
G1 X126.409 Y91.483 E.01352
G1 X126.853 Y90.914 E.01756
G1 X126.968 Y90.572 E.00878
G1 X126.903 Y90.191 E.0094
G1 X126.573 Y89.695 E.01449
G1 X126.161 Y89.281 E.01421
G1 X128.156 Y89.281 E.04853
G1 X128.376 Y89.315 E.00541
G1 X128.552 Y89.51 E.00639
G1 X128.592 Y89.707 E.00489
G1 X128.592 Y90.833 E.02739
G1 X128.565 Y91.466 E.01541
G1 X128.422 Y91.809 E.00904
G1 X128.276 Y91.935 E.00469
G1 X126.06 Y91.935 E.0539
G1 X126.06 Y91.935 F9000
G1 X126.806 Y91.569
;TYPE:Perimeter
G1 F6000
G1 X127.142 Y91.139 E.01327
G1 X127.235 Y90.96 E.00491
G1 X127.328 Y90.635 E.00822
G1 X127.292 Y90.209 E.0104
G1 X127.209 Y89.99 E.0057
G1 X126.983 Y89.647 E.00999
G1 X128.197 Y89.649 E.02953
G1 X128.227 Y89.707 E.00159
G1 X128.227 Y91.279 E.03824
G1 X128.141 Y91.569 E.00736
G1 X126.866 Y91.569 E.03101
G1 X126.866 Y91.569 F9000
G1 X127.755 Y90.118
;WIDTH:0.611576
G1 F6000
G1 X127.768 Y90.33 E.00816
;WIDTH:0.585323
G1 X127.782 Y90.541 E.00775
;WIDTH:0.596433
G1 X127.763 Y90.716 E.00658
;WIDTH:0.633796
G1 X127.744 Y90.892 E.00706
;WIDTH:0.671158
G1 X127.726 Y91.068 E.00749
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X127.744 Y90.892 E-.08404
G1 X127.763 Y90.716 E-.08409
G1 X127.782 Y90.541 E-.08361
G1 X127.768 Y90.33 E-.10045
G1 X127.755 Y90.118 E-.10089
;WIPE_END
G1 E-1.04692 F3600
G1 X128.251 Y90.118 F9000
G1 X126.869 Y91.767
G1 X126.349 Y93.659
G1 X126.039 Y93.311
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X138.145 Y93.317 E.29447
G1 X139.033 Y93.332 E.0216
G1 X139.214 Y93.516 E.00628
G1 X139.243 Y93.661 E.0036
G1 X139.243 Y95.128 E.03568
G1 X139.164 Y95.402 E.00694
G1 X138.997 Y95.511 E.00485
G1 X136.183 Y95.52 E.06845
G1 X136.031 Y95.602 E.0042
G1 X136 Y95.703 E.00257
G1 X136 Y97.189 E.03615
G1 X126.122 Y97.186 E.24027
G1 X126 Y96.591 E.01477
G1 X126 Y93.382 E.07806
G1 X126.01 Y93.363 E.00052
G1 X126.01 Y93.363 F9000
G1 X126.446 Y93.676
;TYPE:Perimeter
G1 F6000
G1 X138.144 Y93.682 E.28454
G1 X138.877 Y93.707 E.01784
G1 X138.865 Y95.141 E.03488
G1 X136.182 Y95.155 E.06526
G1 X135.952 Y95.211 E.00576
G1 X135.753 Y95.368 E.00617
G1 X135.643 Y95.65 E.00736
G1 X135.635 Y96.018 E.00895
G1 X126.366 Y96.015 E.22546
G1 X126.366 Y93.676 E.05689
G1 X126.386 Y93.676 E.00049
G1 X126.386 Y93.676 F9000
G1 X126.925 Y94.042
G1 F6000
G1 X138.512 Y94.048 E.28184
G1 X138.512 Y94.779 E.01778
G1 X136.18 Y94.789 E.05672
G1 X135.856 Y94.858 E.00806
G1 X135.623 Y94.988 E.00649
G1 X135.398 Y95.237 E.00816
G1 X135.277 Y95.652 E.01051
G1 X126.731 Y95.65 E.20787
G1 X126.731 Y94.042 E.03911
G1 X126.865 Y94.042 E.00326
G1 E-5 F3600
G1 X126.865 Y94.042 F9000
G1 X136.022 Y94.425
G1 E5 F2400
;WIDTH:0.424676
G1 F6000
G1 X136.179 Y94.418 E.00408
;WIDTH:0.410746
G1 X138.144 Y94.415 E.0492
G1 E-5 F3600
G1 X138.144 Y94.415 F9000
G1 X136.022 Y94.425
G1 E5 F2400
;WIDTH:0.424676
G1 F6000
G1 X135.759 Y94.501 E.00711
;WIDTH:0.407601
G1 X135.372 Y94.722 E.01107
;WIDTH:0.399999
G1 X135.078 Y95.06 E.0109
G1 X134.988 Y95.286 E.00592
G1 X127.097 Y95.284 E.19194
G1 X127.097 Y94.408 E.02131
G1 X135.249 Y94.412 E.19829
;WIDTH:0.424676
G1 X135.963 Y94.424 E.01854
G1 E-5 F3600
G1 X135.963 Y94.424 F9000
G1 X127.535 Y94.846
G1 E5 F2400
;WIDTH:0.544668
G1 F6000
G1 X134.695 Y94.849 E.24306
G1 X135.125 Y96.127 F9000
;WIDTH:0.412551
G1 F900
G1 X135.726 Y96.728 E.02138
G1 X135.726 Y96.915 E.0047
G1 X135.377 Y96.914 E.00878
G1 X134.754 Y96.292 E.02215
G1 X134.219 Y96.292 E.01346
G1 X134.842 Y96.914 E.02215
G1 X134.307 Y96.914 E.01346
G1 X133.684 Y96.291 E.02217
G1 X133.149 Y96.291 E.01346
G1 X133.772 Y96.914 E.02217
G1 X133.237 Y96.914 E.01346
G1 X132.614 Y96.291 E.02217
G1 X132.079 Y96.291 E.01346
G1 X132.702 Y96.914 E.02217
G1 X132.167 Y96.913 E.01346
G1 X131.544 Y96.291 E.02215
G1 X131.009 Y96.291 E.01346
G1 X131.632 Y96.913 E.02215
G1 X131.097 Y96.913 E.01346
G1 X130.474 Y96.291 E.02215
G1 X129.939 Y96.29 E.01346
G1 X130.561 Y96.913 E.02215
G1 X130.026 Y96.913 E.01346
G1 X129.404 Y96.29 E.02215
G1 X128.869 Y96.29 E.01346
G1 X129.491 Y96.912 E.02213
G1 X128.956 Y96.912 E.01346
G1 X128.334 Y96.29 E.02213
G1 X127.799 Y96.29 E.01346
G1 X128.421 Y96.912 E.02213
G1 X127.886 Y96.912 E.01346
G1 X127.264 Y96.29 E.02213
G1 X126.729 Y96.29 E.01346
G1 X127.351 Y96.912 E.02213
G1 X126.816 Y96.912 E.01346
G1 X126.11 Y96.205 E.02514
G1 E-5 F3600
G1 X126.11 Y96.205 F9000
G1 X105 Y95.475
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X104.928 Y95.519 E.00205
G1 X104.709 Y95.591 E.00561
G1 X104.671 Y95.702 E.00285
G1 X104.671 Y97.186 E.0361
G1 X94.999 Y97.198 E.23526
G1 X94.999 Y95.703 E.03636
G1 X94.969 Y95.603 E.00254
G1 X94.817 Y95.52 E.00421
G1 X91.967 Y95.497 E.06933
G1 X91.84 Y95.378 E.00423
G1 X91.758 Y95.209 E.00457
G1 X91.758 Y93.701 E.03668
G1 X91.836 Y93.427 E.00693
G1 X92.003 Y93.317 E.00486
G1 X104.96 Y93.309 E.31517
G1 X105 Y93.382 E.00202
G1 X105 Y95.415 E.04945
G1 X105 Y95.415 F9000
G1 X104.571 Y95.279
;TYPE:Perimeter
G1 F6000
G1 X104.418 Y95.369 E.00432
G1 X104.315 Y95.643 E.00712
G1 X104.306 Y96.016 E.00908
G1 X95.362 Y96.02 E.21755
G1 X95.356 Y95.623 E.00966
G1 X95.29 Y95.431 E.00494
G1 X95.126 Y95.254 E.00587
G1 X94.818 Y95.155 E.00787
G1 X92.123 Y95.129 E.06556
G1 X92.135 Y93.687 E.03508
G1 X104.634 Y93.674 E.30403
G1 X104.634 Y94.729 E.02566
G1 X104.634 Y95.241 E.01245
G1 X104.623 Y95.248 E.00032
G1 X104.623 Y95.248 F9000
G1 X104.228 Y95.072
G1 F6000
G1 X104.079 Y95.223 E.00516
G1 X103.948 Y95.65 E.01086
G1 X95.723 Y95.654 E.20006
G1 X95.602 Y95.237 E.01056
G1 X95.377 Y94.989 E.00815
G1 X95.144 Y94.858 E.0065
G1 X94.82 Y94.789 E.00806
G1 X92.489 Y94.778 E.0567
G1 X92.489 Y94.051 E.01768
G1 X104.269 Y94.04 E.28654
G1 X104.269 Y94.729 E.01676
G1 X104.269 Y95.029 E.0073
G1 X104.269 Y95.029 F9000
G1 X103.903 Y94.814
G1 F6000
G1 X103.903 Y94.871 E.00139
G1 X103.837 Y94.925 E.00207
G1 X103.665 Y95.285 E.0097
G1 X96.041 Y95.288 E.18545
G1 X95.922 Y95.061 E.00623
G1 X95.629 Y94.723 E.01088
;WIDTH:0.42303
G1 X95.243 Y94.494 E.0116
;WIDTH:0.444134
G1 X95.063 Y94.434 E.00517
G1 X95.252 Y94.423 E.00516
;WIDTH:0.42303
G1 X95.753 Y94.412 E.01296
;WIDTH:0.399999
G1 X103.903 Y94.406 E.19824
G1 X103.903 Y94.729 E.00786
G1 X103.903 Y94.754 E.00061
G1 E-5 F3600
G1 X103.903 Y94.754 F9000
G1 X96.306 Y94.85
G1 E5 F2400
;WIDTH:0.546888
G1 F6000
G1 X103.368 Y94.846 E.24078
G1 E-5 F3600
G1 X103.368 Y94.846 F9000
G1 X92.855 Y94.414
G1 E5 F2400
;WIDTH:0.411212
G1 F6000
G1 X94.822 Y94.418 E.04931
;WIDTH:0.444134
G1 X95.063 Y94.434 E.00658
G1 E-5 F3600
G1 X95.063 Y94.434 F9000
G1 X103.812 Y96.126
G1 E5 F2400
;WIDTH:0.405166
G1 F900
G1 X104.397 Y96.711 E.02041
G1 X104.397 Y96.912 E.00496
G1 X104.074 Y96.912 E.00797
G1 X103.452 Y96.29 E.0217
G1 X102.928 Y96.291 E.01293
G1 X103.55 Y96.913 E.0217
G1 X103.026 Y96.914 E.01293
G1 X102.404 Y96.291 E.02172
G1 X101.879 Y96.291 E.01295
G1 X102.503 Y96.914 E.02175
G1 X101.979 Y96.915 E.01293
G1 X101.355 Y96.291 E.02177
G1 X100.831 Y96.291 E.01293
G1 X101.455 Y96.915 E.02177
G1 X100.931 Y96.916 E.01293
G1 X100.307 Y96.292 E.02177
G1 X99.783 Y96.292 E.01293
G1 X100.408 Y96.917 E.0218
G1 X99.884 Y96.917 E.01293
G1 X99.258 Y96.292 E.02182
G1 X98.734 Y96.292 E.01293
G1 X99.36 Y96.918 E.02184
G1 X98.836 Y96.919 E.01293
G1 X98.21 Y96.293 E.02184
G1 X97.686 Y96.293 E.01293
G1 X98.312 Y96.919 E.02184
G1 X97.789 Y96.92 E.0129
G1 X97.162 Y96.293 E.02187
G1 X96.637 Y96.293 E.01295
G1 X97.265 Y96.921 E.02191
G1 X96.741 Y96.921 E.01293
G1 X96.113 Y96.293 E.02191
G1 X95.589 Y96.294 E.01293
G1 X96.217 Y96.922 E.02191
G1 X95.693 Y96.923 E.01293
G1 X95.109 Y96.338 E.02039
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X95.693 Y96.923 E-.39264
G1 X96.217 Y96.922 E-.2489
G1 X95.589 Y96.294 E-.42186
G1 X96.113 Y96.293 E-.2489
G1 X96.392 Y96.573 E-.1877
;WIPE_END
G1 X96.392 Y96.293 F9000
G1 X100.223 Y93.659
G1 X102.844 Y91.586
G1 X102.628 Y91.83
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X102.496 Y91.677 E.00492
G1 X102.4 Y91.269 E.0102
G1 X102.407 Y89.645 E.0395
G1 X102.528 Y89.386 E.00695
G1 X102.727 Y89.281 E.00547
G1 X104.832 Y89.281 E.0512
G1 X104.297 Y89.853 E.01905
G1 X104.092 Y90.199 E.00978
G1 X104.029 Y90.54 E.00843
G1 X104.147 Y90.914 E.00954
G1 X104.608 Y91.502 E.01817
G1 X105 Y91.898 E.01355
G1 X105 Y91.935 E.0009
G1 X102.704 Y91.919 E.05585
G1 X102.667 Y91.875 E.0014
G1 X102.667 Y91.875 F9000
G1 X102.898 Y91.569
;TYPE:Perimeter
G1 F6000
G1 X102.87 Y91.569 E.00068
G1 X102.833 Y91.518 E.00153
G1 X102.766 Y91.248 E.00677
G1 X102.794 Y89.647 E.03895
G1 X103.997 Y89.647 E.02926
G1 X103.776 Y90.015 E.01044
G1 X103.67 Y90.459 E.0111
G1 X103.687 Y90.699 E.00585
G1 X103.858 Y91.139 E.01148
G1 X104.194 Y91.569 E.01327
G1 X102.958 Y91.569 E.03006
G1 X102.958 Y91.569 F9000
G1 X103.271 Y91.065
;WIDTH:0.676786
G1 F6000
G1 X103.247 Y90.887 E.00768
;WIDTH:0.627573
G1 X103.223 Y90.709 E.00709
;WIDTH:0.61366
G1 X103.243 Y90.12 E.02271
G1 X103.243 Y90.12 F9000
G1 X104.702 Y90.438
;WIDTH:0.399999
G1 F6000
G1 X104.727 Y90.288 E.0037
G1 X105.034 Y89.877 E.01248
G1 X105.582 Y89.34 E.01866
G1 X107.873 Y89.341 E.05573
G1 X108.143 Y89.388 E.00667
G1 X108.24 Y89.502 E.00364
G1 X108.3 Y89.768 E.00663
G1 X108.298 Y91.642 E.04558
G1 X108.261 Y92.2 E.0136
G1 X108.168 Y92.738 E.01328
G1 X107.944 Y93.408 E.01718
G1 X105.75 Y93.404 E.05337
G1 X105.75 Y91.898 E.03663
G1 X105.695 Y91.767 E.00346
G1 X105.08 Y91.167 E.0209
G1 X104.784 Y90.795 E.01156
G1 X104.676 Y90.584 E.00577
G1 X104.691 Y90.497 E.00215
G1 X104.691 Y90.497 F9000
G1 X105.077 Y90.502
;TYPE:Perimeter
G1 F6000
G1 X105.068 Y90.458 E.00109
G1 X105.313 Y90.148 E.00961
G1 X105.731 Y89.706 E.0148
G1 X107.911 Y89.706 E.05303
G1 X107.934 Y89.781 E.00191
G1 X107.931 Y91.646 E.04536
G1 X107.887 Y92.228 E.0142
G1 X106.116 Y92.23 E.04308
G1 X106.116 Y91.898 E.00808
G1 X105.972 Y91.529 E.00963
G1 X105.345 Y90.914 E.02136
G1 X105.089 Y90.563 E.01057
G1 X105.089 Y90.561 E.00005
G1 X105.089 Y90.561 F9000
G1 X105.539 Y90.449
G1 F6000
G1 X105.88 Y90.071 E.01238
G1 X107.568 Y90.072 E.04106
G1 X107.551 Y91.863 E.04357
G1 X106.475 Y91.864 E.02617
G1 X106.359 Y91.469 E.01001
G1 X106.228 Y91.268 E.00584
G1 X105.759 Y90.809 E.01596
G1 X105.491 Y90.501 E.00993
G1 X105.498 Y90.493 E.00026
G1 X105.498 Y90.493 F9000
G1 X106.078 Y90.609
G1 F6000
G1 X105.972 Y90.505 E.00361
G1 X106.031 Y90.437 E.00219
G1 X107.202 Y90.437 E.02848
G1 X107.201 Y91.498 E.02581
G1 X106.759 Y91.498 E.01075
G1 X106.701 Y91.341 E.00407
G1 X106.484 Y91.006 E.00971
G1 X106.121 Y90.651 E.01235
G1 X106.121 Y90.651 F9000
G1 X106.873 Y90.816
;WIDTH:0.425598
G1 F6000
G1 X106.848 Y90.858 E.00127
G1 X106.775 Y90.816 E.00219
G1 X106.848 Y90.773 E.00221
G1 X106.848 Y90.773 F9000
G1 X107.344 Y92.338
;WIDTH:0.423441
G1 F900
G1 X107.849 Y92.844 E.0185
G1 X107.762 Y93.133 E.00781
G1 X107.588 Y93.133 E.0045
G1 X106.958 Y92.503 E.02306
G1 X106.408 Y92.504 E.01424
G1 X107.036 Y93.132 E.02299
G1 X106.485 Y93.131 E.01426
G1 X105.86 Y92.505 E.0229
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X106.485 Y93.131 E-.42018
G1 X107.036 Y93.132 E-.26173
G1 X106.408 Y92.504 E-.42186
G1 X106.958 Y92.503 E-.26125
G1 X107.159 Y92.704 E-.13498
;WIPE_END
G1 X107.159 Y92.503 F9000
G1 X105.918 Y89.689
G1 X102.989 Y82.571
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X100.865 Y82.563 E.05166
G1 X100.761 Y81.972 E.0146
G1 X100.75 Y78.898 E.07477
G1 X100.694 Y78.767 E.00347
G1 X100.17 Y78.264 E.01767
G1 X99.84 Y77.879 E.01233
G1 X99.673 Y77.551 E.00895
G1 X99.704 Y77.339 E.00521
G1 X99.993 Y76.923 E.01232
G1 X100.582 Y76.341 E.02014
G1 X103.006 Y76.34 E.05896
G1 X103.151 Y76.375 E.00363
G1 X103.261 Y76.468 E.0035
G1 X103.3 Y76.635 E.00417
G1 X103.299 Y79.814 E.07733
G1 X103.272 Y80.645 E.02022
G1 X103.152 Y81.886 E.03033
G1 X103.017 Y82.532 E.01605
G1 E-5 F3600
G1 X103.017 Y82.532 F9000
G1 X101.988 Y80.764
G1 E5 F2400
;TYPE:Perimeter
G1 F6000
G1 X101.122 Y80.765 E.02106
G1 X101.116 Y78.897 E.04544
G1 X100.948 Y78.504 E.0104
G1 X100.504 Y78.072 E.01507
G1 X100.108 Y77.608 E.01484
G1 X100.067 Y77.493 E.00297
G1 X100.277 Y77.156 E.00966
G1 X100.732 Y76.707 E.01555
G1 X102.934 Y76.706 E.05356
G1 X102.934 Y78.894 E.05322
G1 X102.92 Y80.228 E.03245
G1 X102.894 Y80.763 E.01303
G1 X102.048 Y80.764 E.02058
G1 X102.048 Y80.764 F9000
G1 X101.731 Y80.397
G1 F6000
G1 X101.487 Y80.397 E.00594
G1 X101.481 Y78.896 E.03651
G1 X101.325 Y78.419 E.01221
G1 X101.203 Y78.242 E.00523
G1 X100.491 Y77.504 E.02494
G1 X100.882 Y77.072 E.01417
G1 X102.569 Y77.072 E.04103
G1 X102.568 Y79.799 E.06633
G1 X102.549 Y80.395 E.0145
G1 X101.791 Y80.397 E.01844
G1 X101.791 Y80.397 F9000
G1 X101.714 Y78.4
G1 F6000
G1 X101.661 Y78.276 E.00328
G1 X101.458 Y77.98 E.00873
G1 X100.967 Y77.502 E.01667
G1 X101.033 Y77.438 E.00224
G1 X102.203 Y77.438 E.02846
G1 X102.205 Y78.894 E.03542
;WIDTH:0.395029
G1 X102.199 Y80.032 E.0273
;WIDTH:0.392243
G1 X101.847 Y80.034 E.00838
;WIDTH:0.393376
G1 X101.847 Y79.791 E.0058
;WIDTH:0.395029
G1 X101.844 Y78.894 E.02152
;WIDTH:0.399999
G1 X101.773 Y78.538 E.00883
G1 X101.738 Y78.455 E.00219
G1 X101.738 Y78.455 F9000
G1 X101.872 Y77.817
;WIDTH:0.428036
G1 F6000
G1 X101.848 Y77.86 E.00129
G1 X101.774 Y77.817 E.00224
G1 X101.848 Y77.775 E.00223
G1 E-5 F3600
G1 X101.848 Y77.775 F9000
G1 X103.073 Y81.59
G1 E5 F2400
;WIDTH:0.421744
G1 F900
G1 X102.522 Y81.039 E.02008
G1 X101.974 Y81.039 E.01412
G1 X102.865 Y81.93 E.03247
G1 X102.797 Y82.296 E.00959
G1 X102.683 Y82.296 E.00294
G1 X101.427 Y81.04 E.04577
G1 X101.032 Y81.04 E.01018
G1 X101.032 Y81.193 E.00394
G1 X102.133 Y82.294 E.04013
G1 X101.583 Y82.292 E.01417
G1 X100.869 Y81.578 E.02602
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X101.583 Y82.292 E-.47963
G1 X102.133 Y82.294 E-.26125
G1 X101.032 Y81.193 E-.7396
G1 X101.032 Y81.152 E-.01952
;WIPE_END
G1 X101.098 Y81.04 F9000
G1 X101.099 Y78.668
G1 X100.358 Y77.043
G1 X100.123 Y75.53
G1 X100.131 Y75.661
G1 E5 F2400
;WIDTH:0.638068
G1 F6000
G1 X100.182 Y75.658 E.00205
;WIDTH:0.633526
G1 X103.044 Y75.656 E.11407
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X100.182 Y75.658 E-1.35945
G1 X100.131 Y75.661 E-.02427
;WIPE_END
G1 E-.11628 F3600
G1 X100.124 Y75.53 F9000
G1 X99.155 Y76.476
G1 X99.011 Y76.652
G1 X98.901 Y76.809
G1 X98.816 Y76.958
G1 X98.75 Y77.108
G1 X98.705 Y77.262
G1 X98.681 Y77.42
G1 X98.681 Y77.58
G1 X98.705 Y77.738
G1 X98.75 Y77.892
G1 X98.816 Y78.042
G1 X98.901 Y78.191
G1 X99.011 Y78.348
G1 X99.155 Y78.524
G1 X99.351 Y78.739
G1 X99.642 Y79.028
G1 X99.651 Y79.036
G1 X99.651 Y79.134
G1 X100 Y79.134
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X100 Y82.05 E.07093
G1 X100.047 Y82.564 E.01255
G1 X97.004 Y82.582 E.07402
G1 X96.841 Y81.845 E.01836
G1 X96.753 Y81.038 E.01975
G1 X96.706 Y80.204 E.02032
G1 X96.7 Y75.844 E.10605
G1 X96.762 Y75.611 E.00586
G1 X96.926 Y75.542 E.00433
G1 X99.591 Y75.542 E.06482
;WIDTH:0.447613
G1 X99.699 Y75.565 E.00304
;WIDTH:0.495227
G1 X99.807 Y75.589 E.00339
;WIDTH:0.542841
G1 X99.915 Y75.613 E.00374
;WIDTH:0.590454
G1 X100.023 Y75.637 E.00409
;WIDTH:0.638068
G1 X100.131 Y75.661 E.00444
G1 X100.105 Y75.72 E.00259
;WIDTH:0.590454
G1 X100.078 Y75.779 E.0024
;WIDTH:0.542841
G1 X100.052 Y75.838 E.00218
;WIDTH:0.495227
G1 X100.026 Y75.897 E.00198
;WIDTH:0.447613
G1 X100 Y75.956 E.00177
;WIDTH:0.399999
G1 X100 Y76.12 E.00399
G1 X99.404 Y76.723 E.02062
G1 X99.097 Y77.19 E.01359
G1 X99.042 Y77.61 E.0103
G1 X99.209 Y78.022 E.01081
G1 X99.608 Y78.502 E.01518
G1 X100 Y78.882 E.01328
G1 X100 Y79.074 E.00467
G1 X100 Y79.074 F9000
G1 X99.634 Y79.037
;TYPE:Perimeter
G1 F6000
G1 X99.634 Y80.762 E.04196
G1 X97.105 Y80.77 E.06152
G1 X97.072 Y80.154 E.01501
G1 X97.066 Y75.907 E.1033
G1 X99.651 Y75.907 E.06288
G1 X99.622 Y75.982 E.00196
G1 X99.146 Y76.463 E.01646
G1 X98.793 Y76.988 E.01539
G1 X98.703 Y77.254 E.00683
G1 X98.698 Y77.763 E.01238
G1 X98.928 Y78.256 E.01323
G1 X99.298 Y78.7 E.01406
G1 X99.592 Y78.994 E.01011
G1 X99.592 Y78.994 F9000
G1 X99.269 Y79.192
G1 F6000
G1 X99.269 Y80.398 E.02933
G1 X97.451 Y80.403 E.04422
G1 X97.437 Y80.144 E.00631
G1 X97.432 Y76.273 E.09416
G1 X98.833 Y76.273 E.03408
G1 X98.49 Y76.784 E.01497
G1 X98.366 Y77.086 E.00794
G1 X98.317 Y77.66 E.01401
G1 X98.365 Y77.913 E.00626
G1 X98.647 Y78.49 E.01562
G1 X99.229 Y79.147 E.02135
G1 X99.229 Y79.147 F9000
G1 X97.883 Y77.861
;WIDTH:0.573678
G1 F6000
G1 X97.886 Y77.214 E.02321
G1 E-5 F3600
G1 X97.886 Y77.214 F9000
G1 X98.903 Y79.347
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X98.903 Y80.033 E.01669
G1 X97.803 Y80.036 E.02676
G1 X97.801 Y78.609 E.03471
;WIDTH:0.44147
G1 X97.821 Y78.422 E.00509
;WIDTH:0.482941
G1 X97.842 Y78.235 E.00562
;WIDTH:0.524412
G1 X97.862 Y78.048 E.00613
;WIDTH:0.565882
G1 X97.883 Y77.861 E.00665
G1 X97.923 Y77.933 E.00291
;WIDTH:0.530598
G1 X97.964 Y78.004 E.00271
;WIDTH:0.495314
G1 X98.004 Y78.076 E.00253
;WIDTH:0.46003
G1 X98.185 Y78.4 E.01051
;WIDTH:0.430015
G1 X98.366 Y78.724 E.00977
;WIDTH:0.399999
G1 X98.864 Y79.301 E.01854
G1 X98.864 Y79.301 F9000
G1 X98.448 Y79.375
;WIDTH:0.379895
G1 F6000
G1 X98.547 Y79.492 E.00352
G1 X98.547 Y79.679 E.0043
G1 X98.158 Y79.68 E.00894
G1 X98.157 Y79.029 E.01496
G1 X98.41 Y79.329 E.00902
G1 E-5 F3600
G1 X98.41 Y79.329 F9000
G1 X98.192 Y76.617
G1 E5 F2400
;WIDTH:0.399986
G1 F6000
G1 X98.131 Y76.736 E.00325
;WIDTH:0.443409
G1 X98.069 Y76.856 E.00368
;WIDTH:0.486832
G1 X98.008 Y76.975 E.00403
;WIDTH:0.530255
G1 X97.947 Y77.094 E.00441
;WIDTH:0.573678
G1 X97.886 Y77.214 E.00483
G1 X97.866 Y77.143 E.00265
;WIDTH:0.535185
G1 X97.847 Y77.072 E.00245
;WIDTH:0.4
