Just Can't Prevent These Walls From Fusing Together.
Nafiul Ahmed
(@nafiul-ahmed)
I just started printing a few days ago on an Ender 3 Pro using PETG filament.
These last few days I've been messing with different configurations on Prusaslicer (wasn't able to get Cura working on my linux distro) and seeing the different kind of results.
I've been trying to print this phone stand, but whenever I go to slice the model, there are parts that should be separate and free that end up touching, which result in the print fusing the stand on those critical points, which then causes it to break when I try to snap them free so it can move properly.
I tried every single option I could find and every single time those external perimeters will end up touching. So I am printing a different phone stand as I type this, but I need to get some feedback on this issue so I can move on and get some sleep.
Do I need a more precise nozzle? I am certain my printer is running 0.40mm.
Anyways, I will be providing screenshots and the .gcode file so my settings can be looked at.
I appreciate you all, especially anyone who takes the time to check this out.
; generated by PrusaSlicer 2.8.0 on 2024-06-29 at 08:22:01 UTC
; external perimeters extrusion width = 0.40mm
; perimeters extrusion width = 0.40mm
; infill extrusion width = 0.40mm
; solid infill extrusion width = 0.40mm
; top infill extrusion width = 0.40mm
; support material extrusion width = 0.36mm
; first layer extrusion width = 0.40mm
M201 X500 Y500 Z100 E5000 ; sets maximum accelerations, mm/sec^2
M203 X500 Y500 Z10 E60 ; sets maximum feedrates, mm / sec
M204 S500 T1000 ; sets acceleration (S) and retract acceleration (R), mm/sec^2
M205 X8.00 Y8.00 Z0.40 E5.00 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
; printing object stand_s.stl id:0 copy 0
; stop printing object stand_s.stl id:0 copy 0
;TYPE:Custom
M83 ; extruder relative mode
M104 S150 ; set temporary nozzle temp to prevent oozing during homing
M140 S80 ; set final bed temp
G4 S30 ; allow partial nozzle warmup
G28 ; home all axis
G1 Z50 F240
G1 X2.0 Y10 F3000
M104 S240 ; set final nozzle temp
M190 S80 ; wait for bed temp to stabilize
M109 S240 ; wait for nozzle temp to stabilize
G1 Z0.28 F240
G92 E0
G1 X2.0 Y140 E10 F1500 ; prime the nozzle
G1 X2.3 Y140 F5000
G92 E0
G1 X2.3 Y10 E10 F1200 ; prime the nozzle
G92 E0
G21 ; set units to millimeters
M83 ; use relative distances for extrusion
; Filament gcode
M107
;LAYER_CHANGE
;Z:0.3
;HEIGHT:0.3
G1 E-5 F3600
G1 Z.3 F9000
G1 X87.039 Y72.713
G1 Z.3
G1 E5 F2400
;TYPE:Skirt/Brim
;WIDTH:0.4
G1 F1200
G1 X87.979 Y71.746 E.05645
G1 X89.029 Y70.9 E.05644
G1 X90.173 Y70.186 E.05645
G1 X91.395 Y69.615 E.05646
G1 X92.676 Y69.196 E.05642
G1 X93.999 Y68.935 E.05645
G1 X95.5 Y68.832 E.06298
G1 X135.656 Y68.835 E1.68094
G1 X137.666 Y69.046 E.0846
G1 X139.605 Y69.615 E.08459
G1 X141.41 Y70.526 E.08464
G1 X143.021 Y71.746 E.08459
G1 X144.385 Y73.237 E.08459
G1 X145.459 Y74.949 E.0846
G1 X146.206 Y76.827 E.0846
G1 X146.603 Y78.809 E.08462
G1 X146.668 Y80 E.04993
G1 X146.666 Y151.152 E2.97844
G1 X146.569 Y152.479 E.0557
G1 X146.314 Y153.784 E.05566
G1 X145.907 Y155.05 E.05567
G1 X145.462 Y156.046 E.04566
G1 X144.785 Y157.203 E.05611
G1 X143.967 Y158.281 E.05665
G1 X143.028 Y159.247 E.05639
G1 X141.818 Y160.208 E.06468
G1 X140.679 Y160.894 E.05566
G1 X139.338 Y161.486 E.06136
G1 X138.001 Y161.883 E.05838
G1 X136.349 Y162.134 E.06995
G1 X95.35 Y162.166 E1.71623
G1 X94.213 Y162.093 E.04769
G1 X92.855 Y161.85 E.05775
G1 X91.692 Y161.497 E.05088
G1 X90.47 Y160.97 E.05571
G1 X89.16 Y160.194 E.06374
G1 X88.001 Y159.273 E.06197
G1 X87.06 Y158.311 E.05633
G1 X86.218 Y157.208 E.05809
G1 X85.538 Y156.046 E.05636
G1 X84.894 Y154.492 E.07042
G1 X84.539 Y153.135 E.05872
G1 X84.345 Y151.518 E.06817
G1 X84.335 Y79.844 E3.0003
G1 X84.397 Y78.809 E.0434
G1 X84.622 Y77.48 E.05642
G1 X85.005 Y76.187 E.05645
G1 X85.541 Y74.949 E.05647
G1 X86.222 Y73.786 E.05642
G1 X87.003 Y72.76 E.05398
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X87.039 Y72.713 E-.02812
G1 X87.979 Y71.746 E-.64058
G1 X89.029 Y70.9 E-.6405
G1 X89.37 Y70.687 E-.1908
;WIPE_END
G1 X92.125 Y94.242 F9000
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.42372
G1 F1200
G1 X92.126 Y94.233 E.00041
G1 X92.27 Y94.233 E.00645
;WIDTH:0.42809
G1 X95.72 Y94.221 E.15651
;WIDTH:0.4
G1 X104.808 Y94.221 E.38043
G1 X104.839 Y94.432 E.00893
G1 X104.839 Y136.791 E1.77316
G1 X104.81 Y137.421 E.0264
G1 X104.839 Y137.81 E.01633
G1 X104.858 Y139.571 E.07372
G1 X105.006 Y139.661 E.00725
G1 X125.994 Y139.661 E.87856
G1 X126.086 Y139.633 E.00403
G1 X126.161 Y139.495 E.00657
G1 X126.161 Y138.382 E.04659
G1 X126.186 Y137.614 E.03217
G1 X126.161 Y137.19 E.01778
G1 X126.161 Y94.449 E1.78915
G1 X126.194 Y94.218 E.00977
G1 X135.279 Y94.221 E.3803
;WIDTH:0.428347
G1 X138.727 Y94.233 E.15653
;WIDTH:0.423744
G1 X138.867 Y94.233 E.00628
G1 X138.902 Y94.458 E.01021
G1 X138.868 Y94.592 E.0062
G1 X138.729 Y94.593 E.00623
;WIDTH:0.428347
G1 X136.006 Y94.599 E.12361
G1 X135.839 Y94.781 E.01121
;WIDTH:0.4
G1 X135.839 Y126.998 E1.34861
G1 X135.817 Y127.466 E.01961
G1 X135.817 Y132.943 E.22927
G1 X135.665 Y134.108 E.04918
G1 X135.528 Y134.726 E.0265
G1 X135.259 Y135.592 E.03796
G1 X134.985 Y136.261 E.03026
G1 X134.707 Y136.832 E.02658
G1 X134.243 Y137.611 E.03796
G1 X133.821 Y138.198 E.03026
G1 X133.418 Y138.688 E.02656
G1 X132.785 Y139.338 E.03798
G1 X132.237 Y139.81 E.03028
G1 X131.731 Y140.194 E.02659
G1 X130.965 Y140.678 E.03793
G1 X130.322 Y141.01 E.03029
G1 X129.741 Y141.265 E.02656
G1 X128.883 Y141.558 E.03795
G1 X128.18 Y141.73 E.0303
G1 X127.557 Y141.843 E.0265
G1 X126.192 Y141.939 E.05728
G1 X104.347 Y141.928 E.91444
G1 X103.262 Y141.813 E.04567
G1 X102.554 Y141.674 E.0302
G1 X101.683 Y141.421 E.03797
G1 X101.091 Y141.194 E.02654
G1 X100.433 Y140.893 E.03029
G1 X99.645 Y140.445 E.03794
G1 X99.121 Y140.086 E.02659
G1 X98.553 Y139.641 E.0302
G1 X97.581 Y138.688 E.05698
G1 X96.909 Y137.831 E.04559
G1 X96.516 Y137.229 E.03009
G1 X95.904 Y136.012 E.05702
G1 X95.544 Y134.984 E.04559
G1 X95.367 Y134.284 E.03022
G1 X95.265 Y133.669 E.0261
G1 X95.16 Y132.8 E.03664
G1 X95.16 Y94.781 E1.59148
;WIDTH:0.42809
G1 X94.993 Y94.599 E.01121
G1 X92.27 Y94.593 E.12353
;WIDTH:0.42372
G1 X92.125 Y94.592 E.0065
G1 X92.094 Y94.453 E.00638
G1 X92.116 Y94.301 E.00688
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X92.125 Y94.242 E-.02835
G1 X92.126 Y94.233 E-.0043
G1 X92.27 Y94.233 E-.0684
G1 X95.215 Y94.223 E-1.39895
;WIPE_END
G1 X135.375 Y94.326 F9000
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.400666
G1 F1200
G1 X135.68 Y94.63 E.01806
G1 X135.587 Y94.753 E.00647
G1 X135.587 Y95.013 E.01091
G1 X135.046 Y94.472 E.03209
G1 X134.571 Y94.472 E.01992
G1 X135.587 Y95.489 E.0603
G1 X135.587 Y95.965 E.01997
G1 X134.095 Y94.472 E.08853
G1 X133.619 Y94.472 E.01997
G1 X135.587 Y96.44 E.11674
G1 X135.587 Y96.916 E.01997
G1 X133.143 Y94.472 E.14497
G1 X132.668 Y94.472 E.01992
G1 X135.587 Y97.391 E.17315
G1 X135.587 Y97.867 E.01997
G1 X132.192 Y94.472 E.20138
G1 X131.716 Y94.471 E.01997
G1 X135.587 Y98.342 E.22962
G1 X135.587 Y98.818 E.01997
G1 X131.241 Y94.471 E.25782
G1 X130.765 Y94.471 E.01997
G1 X135.587 Y99.294 E.28606
G1 X135.587 Y99.769 E.01992
G1 X130.289 Y94.471 E.31426
G1 X129.814 Y94.471 E.01992
G1 X135.587 Y100.245 E.34247
G1 X135.587 Y100.72 E.01992
G1 X129.338 Y94.471 E.37067
G1 X128.862 Y94.471 E.01997
G1 X135.587 Y101.196 E.39891
G1 X135.587 Y101.671 E.01992
G1 X128.387 Y94.471 E.42708
G1 X127.911 Y94.471 E.01997
G1 X135.587 Y102.147 E.45532
G1 X135.587 Y102.623 E.01997
G1 X127.435 Y94.47 E.48358
G1 X126.96 Y94.47 E.01992
G1 X135.587 Y103.098 E.51176
G1 X135.587 Y103.574 E.01997
G1 X126.484 Y94.47 E.53999
G1 X126.413 Y94.47 E.00298
G1 X126.413 Y94.875 E.01699
G1 X135.587 Y104.049 E.54417
G1 X135.587 Y104.525 E.01997
G1 X126.413 Y95.351 E.54417
G1 X126.413 Y95.826 E.01992
G1 X135.587 Y105 E.54417
G1 X135.587 Y105.476 E.01997
G1 X126.413 Y96.302 E.54417
G1 X126.413 Y96.777 E.01992
G1 X135.587 Y105.952 E.5442
G1 X135.587 Y106.427 E.01992
G1 X126.413 Y97.253 E.54417
G1 X126.413 Y97.728 E.01992
G1 X135.587 Y106.903 E.5442
G1 X135.587 Y107.378 E.01992
G1 X126.413 Y98.204 E.54417
G1 X126.413 Y98.68 E.01997
G1 X135.587 Y107.854 E.54417
G1 X135.587 Y108.329 E.01992
G1 X126.413 Y99.155 E.54417
G1 X126.413 Y99.631 E.01997
G1 X135.587 Y108.805 E.54417
G1 X135.587 Y109.281 E.01997
G1 X126.413 Y100.106 E.5442
G1 X126.413 Y100.582 E.01997
G1 X135.587 Y109.756 E.54417
G1 X135.587 Y110.232 E.01997
G1 X126.413 Y101.058 E.54417
G1 X126.413 Y101.533 E.01992
G1 X135.587 Y110.707 E.54417
G1 X135.587 Y111.183 E.01997
G1 X126.413 Y102.009 E.54417
G1 X126.413 Y102.484 E.01992
G1 X135.587 Y111.658 E.54417
G1 X135.587 Y112.134 E.01997
G1 X126.413 Y102.96 E.54417
G1 X126.413 Y103.435 E.01992
G1 X135.587 Y112.61 E.5442
G1 X135.587 Y113.085 E.01992
G1 X126.413 Y103.911 E.54417
G1 X126.413 Y104.387 E.01997
G1 X135.587 Y113.561 E.54417
G1 X135.587 Y114.036 E.01992
G1 X126.413 Y104.862 E.54417
G1 X126.413 Y105.338 E.01997
G1 X135.587 Y114.512 E.54417
G1 X135.587 Y114.987 E.01992
G1 X126.413 Y105.813 E.54417
G1 X126.413 Y106.289 E.01997
G1 X135.587 Y115.463 E.54417
G1 X135.587 Y115.939 E.01997
G1 X126.413 Y106.764 E.5442
G1 X126.413 Y107.24 E.01997
G1 X135.587 Y116.414 E.54417
G1 X135.587 Y116.89 E.01997
G1 X126.413 Y107.716 E.54417
G1 X126.413 Y108.191 E.01992
G1 X135.587 Y117.365 E.54417
G1 X135.587 Y117.841 E.01997
G1 X126.413 Y108.667 E.54417
G1 X126.413 Y109.142 E.01992
G1 X135.587 Y118.316 E.54417
G1 X135.587 Y118.792 E.01997
G1 X126.413 Y109.618 E.54417
G1 X126.413 Y110.094 E.01997
G1 X135.587 Y119.268 E.54417
G1 X135.587 Y119.743 E.01992
G1 X126.413 Y110.569 E.54417
G1 X126.413 Y111.045 E.01997
G1 X135.587 Y120.219 E.54417
G1 X135.587 Y120.694 E.01992
G1 X126.413 Y111.52 E.54417
G1 X126.413 Y111.996 E.01997
G1 X135.587 Y121.17 E.54417
G1 X135.587 Y121.645 E.01992
G1 X126.413 Y112.471 E.54417
G1 X126.413 Y112.947 E.01997
G1 X135.587 Y122.121 E.54417
G1 X135.587 Y122.597 E.01997
G1 X126.413 Y113.423 E.54417
G1 X126.413 Y113.898 E.01992
G1 X135.587 Y123.072 E.54417
G1 X135.587 Y123.548 E.01997
G1 X126.413 Y114.374 E.54417
G1 X126.413 Y114.849 E.01992
G1 X135.587 Y124.023 E.54417
G1 X135.587 Y124.499 E.01997
G1 X126.413 Y115.325 E.54417
G1 X126.413 Y115.8 E.01992
G1 X135.587 Y124.974 E.54417
G1 X135.587 Y125.45 E.01997
G1 X126.413 Y116.276 E.54417
G1 X126.413 Y116.752 E.01997
G1 X135.587 Y125.926 E.54417
G1 X135.587 Y126.401 E.01992
G1 X126.413 Y117.227 E.54417
G1 X126.413 Y117.703 E.01997
G1 X135.587 Y126.877 E.54417
G1 X135.587 Y127.352 E.01992
G1 X126.413 Y118.178 E.54417
G1 X126.413 Y118.654 E.01997
G1 X135.565 Y127.806 E.54287
G1 X135.565 Y128.282 E.01997
G1 X126.413 Y119.13 E.54287
G1 X126.413 Y119.605 E.01992
G1 X135.565 Y128.757 E.54287
G1 X135.565 Y129.233 E.01997
G1 X126.413 Y120.081 E.54287
G1 X126.413 Y120.556 E.01992
G1 X135.565 Y129.708 E.54287
G1 X135.565 Y130.184 E.01997
G1 X126.413 Y121.032 E.54287
G1 X126.413 Y121.507 E.01992
G1 X135.565 Y130.659 E.54287
G1 X135.565 Y131.135 E.01997
G1 X126.413 Y121.983 E.54287
G1 X126.413 Y122.459 E.01997
G1 X135.565 Y131.611 E.54287
G1 X135.565 Y132.086 E.01992
G1 X126.413 Y122.934 E.54287
G1 X126.413 Y123.41 E.01997
G1 X135.565 Y132.562 E.54287
G1 X135.552 Y133.025 E.01943
G1 X126.413 Y123.885 E.54213
G1 X126.413 Y124.361 E.01997
G1 X135.497 Y133.445 E.53883
G1 X135.443 Y133.866 E.0178
G1 X126.413 Y124.836 E.53563
G1 X126.413 Y125.312 E.01997
G1 X135.371 Y134.27 E.53136
G1 X135.285 Y134.66 E.01675
G1 X126.413 Y125.788 E.52626
G1 X126.413 Y126.263 E.01992
G1 X135.172 Y135.023 E.51959
G1 X135.06 Y135.385 E.01589
G1 X126.413 Y126.739 E.51288
G1 X126.413 Y127.214 E.01992
G1 X134.93 Y135.731 E.5052
G1 X134.791 Y136.068 E.01529
G1 X126.413 Y127.69 E.49696
G1 X126.413 Y128.166 E.01997
G1 X134.64 Y136.393 E.488
G1 X134.485 Y136.713 E.01491
G1 X126.413 Y128.641 E.47881
G1 X126.413 Y129.117 E.01997
G1 X134.307 Y137.011 E.46825
G1 X134.13 Y137.309 E.01454
G1 X126.413 Y129.592 E.45775
G1 X126.413 Y130.068 E.01997
G1 X133.943 Y137.598 E.44666
G1 X133.744 Y137.874 E.01427
G1 X126.413 Y130.543 E.43485
G1 X126.413 Y131.019 E.01997
G1 X133.539 Y138.144 E.42266
G1 X133.324 Y138.406 E.01422
G1 X126.413 Y131.495 E.40994
G1 X126.413 Y131.97 E.01992
G1 X133.098 Y138.655 E.39653
G1 X132.864 Y138.897 E.01412
G1 X126.413 Y132.446 E.38265
G1 X126.413 Y132.921 E.01992
G1 X132.629 Y139.138 E.36874
G1 X132.375 Y139.359 E.01412
G1 X126.413 Y133.397 E.35365
G1 X126.413 Y133.872 E.01992
G1 X132.12 Y139.579 E.33852
G1 X131.852 Y139.787 E.01423
G1 X126.413 Y134.348 E.32262
G1 X126.413 Y134.824 E.01997
G1 X131.581 Y139.991 E.30652
G1 X131.289 Y140.175 E.01448
G1 X126.413 Y135.299 E.28923
G1 X126.413 Y135.775 E.01997
G1 X130.998 Y140.36 E.27197
G1 X130.696 Y140.534 E.01462
G1 X126.413 Y136.25 E.25408
G1 X126.413 Y136.726 E.01997
G1 X130.383 Y140.696 E.23549
G1 X130.061 Y140.85 E.01497
G1 X126.417 Y137.205 E.21618
G1 X126.451 Y137.481 E.01166
G1 X126.428 Y137.692 E.0089
G1 X129.73 Y140.994 E.19586
G1 X129.649 Y141.03 E.00372
G1 X129.382 Y141.121 E.01183
G1 X126.413 Y138.153 E.17608
G1 X126.413 Y138.628 E.01992
G1 X129.027 Y141.242 E.15505
G1 X128.662 Y141.353 E.016
G1 X126.413 Y139.104 E.1334
G1 X126.403 Y139.569 E.01951
G1 X128.28 Y141.447 E.11137
G1 X127.886 Y141.528 E.01687
G1 X126.21 Y139.852 E.09941
G1 X126.006 Y139.913 E.00893
G1 X125.795 Y139.913 E.00885
G1 X127.478 Y141.596 E.09983
G1 X127.034 Y141.627 E.01867
G1 X125.32 Y139.913 E.10167
G1 X124.844 Y139.913 E.01997
G1 X126.59 Y141.659 E.10357
G1 X126.143 Y141.687 E.01879
G1 X124.369 Y139.913 E.10523
G1 X123.893 Y139.913 E.01997
G1 X125.667 Y141.687 E.10523
G1 X125.191 Y141.687 E.01997
G1 X123.418 Y139.913 E.1052
G1 X122.942 Y139.913 E.01997
G1 X124.715 Y141.686 E.10517
G1 X124.24 Y141.686 E.01992
G1 X122.466 Y139.913 E.1052
G1 X121.991 Y139.913 E.01992
G1 X123.764 Y141.686 E.10517
G1 X123.288 Y141.686 E.01997
G1 X121.515 Y139.913 E.10517
G1 X121.04 Y139.913 E.01992
G1 X122.812 Y141.685 E.10511
G1 X122.336 Y141.685 E.01997
G1 X120.564 Y139.913 E.10511
G1 X120.089 Y139.913 E.01992
G1 X121.861 Y141.685 E.10511
G1 X121.385 Y141.685 E.01997
G1 X119.613 Y139.913 E.10511
G1 X119.137 Y139.913 E.01997
G1 X120.909 Y141.685 E.10511
G1 X120.433 Y141.684 E.01997
G1 X118.662 Y139.913 E.10505
G1 X118.186 Y139.913 E.01997
G1 X119.957 Y141.684 E.10505
G1 X119.481 Y141.684 E.01997
G1 X117.711 Y139.913 E.10502
G1 X117.235 Y139.913 E.01997
G1 X119.006 Y141.684 E.10505
G1 X118.53 Y141.683 E.01997
G1 X116.759 Y139.913 E.10502
G1 X116.284 Y139.913 E.01992
G1 X118.054 Y141.683 E.10499
G1 X117.578 Y141.683 E.01997
G1 X115.808 Y139.913 E.10499
G1 X115.333 Y139.913 E.01992
G1 X117.102 Y141.683 E.10496
G1 X116.627 Y141.682 E.01992
G1 X114.857 Y139.913 E.10496
G1 X114.382 Y139.913 E.01992
G1 X116.151 Y141.682 E.10493
G1 X115.675 Y141.682 E.01997
G1 X113.906 Y139.913 E.10493
G1 X113.43 Y139.913 E.01997
G1 X115.199 Y141.682 E.10493
G1 X114.723 Y141.681 E.01997
G1 X112.955 Y139.913 E.10487
G1 X112.479 Y139.913 E.01997
G1 X114.247 Y141.681 E.10487
G1 X113.772 Y141.681 E.01992
G1 X112.004 Y139.913 E.10487
G1 X111.528 Y139.913 E.01997
G1 X113.296 Y141.681 E.10487
G1 X112.82 Y141.681 E.01997
G1 X111.053 Y139.913 E.10484
G1 X110.577 Y139.913 E.01997
G1 X112.344 Y141.68 E.10481
G1 X111.868 Y141.68 E.01997
G1 X110.101 Y139.913 E.10481
G1 X109.626 Y139.913 E.01992
G1 X111.393 Y141.68 E.10481
G1 X110.917 Y141.68 E.01997
G1 X109.15 Y139.913 E.10481
G1 X108.675 Y139.913 E.01992
G1 X110.441 Y141.679 E.10475
G1 X109.965 Y141.679 E.01997
G1 X108.199 Y139.913 E.10475
G1 X107.723 Y139.913 E.01997
G1 X109.489 Y141.679 E.10475
G1 X109.013 Y141.679 E.01997
G1 X107.248 Y139.913 E.10472
G1 X106.772 Y139.913 E.01997
G1 X108.538 Y141.678 E.10472
G1 X108.062 Y141.678 E.01997
G1 X106.297 Y139.913 E.10469
G1 X105.821 Y139.913 E.01997
G1 X107.586 Y141.678 E.10469
G1 X107.11 Y141.678 E.01997
G1 X105.195 Y139.762 E.11362
G1 E-5 F3600
G1 X105.195 Y139.762 F9000
G1 X105.195 Y139.865
G1 X104.635 Y139.865
G1 X104.597 Y137.5
G1 X104.102 Y94.422
G1 X103.983 Y94.422
G1 X103.983 Y94.321
G1 E5 F2400
G1 F1200
G1 X104.579 Y94.918 E.03538
G1 X104.579 Y95.393 E.01992
G1 X103.658 Y94.472 E.05463
G1 X103.183 Y94.473 E.01992
G1 X104.579 Y95.869 E.08281
G1 X104.579 Y96.345 E.01997
G1 X102.707 Y94.473 E.11104
G1 X102.232 Y94.473 E.01992
G1 X104.579 Y96.82 E.13922
G1 X104.579 Y97.296 E.01997
G1 X101.756 Y94.473 E.16745
G1 X101.281 Y94.473 E.01992
G1 X104.579 Y97.772 E.19566
G1 X104.58 Y98.247 E.01992
G1 X100.805 Y94.473 E.22389
G1 X100.329 Y94.473 E.01997
G1 X104.58 Y98.723 E.25213
G1 X104.58 Y99.199 E.01997
G1 X99.854 Y94.473 E.28033
G1 X99.378 Y94.473 E.01997
G1 X104.58 Y99.674 E.30854
G1 X104.58 Y100.15 E.01997
G1 X98.903 Y94.473 E.33674
G1 X98.427 Y94.473 E.01997
G1 X104.58 Y100.626 E.36498
G1 X104.58 Y101.101 E.01992
G1 X97.952 Y94.473 E.39315
G1 X97.476 Y94.473 E.01997
G1 X104.58 Y101.577 E.42139
G1 X104.58 Y102.053 E.01997
G1 X97.001 Y94.473 E.44959
G1 X96.525 Y94.473 E.01997
G1 X104.58 Y102.528 E.4778
G1 X104.58 Y103.004 E.01997
G1 X96.049 Y94.473 E.50603
G1 X95.579 Y94.478 E.01971
G1 X104.581 Y103.48 E.53397
G1 X104.581 Y103.955 E.01992
G1 X95.412 Y94.787 E.54385
G1 X95.412 Y95.262 E.01992
G1 X104.581 Y104.431 E.54388
G1 X104.581 Y104.907 E.01997
G1 X95.412 Y95.738 E.54388
G1 X95.412 Y96.213 E.01992
G1 X104.581 Y105.382 E.54388
G1 X104.581 Y105.858 E.01997
G1 X95.412 Y96.689 E.54388
G1 X95.412 Y97.164 E.01992
G1 X104.581 Y106.334 E.54391
G1 X104.581 Y106.809 E.01992
G1 X95.412 Y97.64 E.54388
G1 X95.412 Y98.116 E.01997
G1 X104.581 Y107.285 E.54388
G1 X104.581 Y107.761 E.01997
G1 X95.412 Y98.591 E.54391
G1 X95.412 Y99.067 E.01997
G1 X104.581 Y108.236 E.54388
G1 X104.582 Y108.712 E.01997
G1 X95.412 Y99.542 E.54394
G1 X95.412 Y100.018 E.01997
G1 X104.582 Y109.188 E.54394
G1 X104.582 Y109.663 E.01992
G1 X95.412 Y100.493 E.54394
G1 X95.412 Y100.969 E.01997
G1 X104.582 Y110.139 E.54394
G1 X104.582 Y110.615 E.01997
G1 X95.412 Y101.445 E.54394
G1 X95.412 Y101.92 E.01992
G1 X104.582 Y111.09 E.54394
G1 X104.582 Y111.566 E.01997
G1 X95.412 Y102.396 E.54394
G1 X95.412 Y102.871 E.01992
G1 X104.582 Y112.042 E.54396
G1 X104.582 Y112.517 E.01992
G1 X95.412 Y103.347 E.54394
G1 X95.412 Y103.822 E.01992
G1 X104.582 Y112.993 E.54396
G1 X104.582 Y113.469 E.01997
G1 X95.412 Y104.298 E.54396
G1 X95.412 Y104.774 E.01997
G1 X104.583 Y113.944 E.54396
G1 X104.583 Y114.42 E.01997
G1 X95.412 Y105.249 E.54399
G1 X95.412 Y105.725 E.01997
G1 X104.583 Y114.896 E.54399
G1 X104.583 Y115.371 E.01992
G1 X95.412 Y106.2 E.54399
G1 X95.412 Y106.676 E.01997
G1 X104.583 Y115.847 E.54399
G1 X104.583 Y116.323 E.01997
G1 X95.412 Y107.151 E.54402
G1 X95.412 Y107.627 E.01997
G1 X104.583 Y116.798 E.54399
G1 X104.583 Y117.274 E.01997
G1 X95.412 Y108.103 E.54399
G1 X95.412 Y108.578 E.01992
G1 X104.583 Y117.75 E.54402
G1 X104.583 Y118.225 E.01992
G1 X95.412 Y109.054 E.54399
G1 X95.412 Y109.529 E.01992
G1 X104.583 Y118.701 E.54402
G1 X104.584 Y119.177 E.01997
G1 X95.412 Y110.005 E.54405
G1 X95.412 Y110.48 E.01992
G1 X104.584 Y119.652 E.54405
G1 X104.584 Y120.128 E.01997
G1 X95.412 Y110.956 E.54405
G1 X95.412 Y111.432 E.01997
G1 X104.584 Y120.604 E.54405
G1 X104.584 Y121.079 E.01992
G1 X95.412 Y111.907 E.54405
G1 X95.412 Y112.383 E.01997
G1 X104.584 Y121.555 E.54405
G1 X104.584 Y122.031 E.01997
G1 X95.412 Y112.858 E.54408
G1 X95.412 Y113.334 E.01997
G1 X104.584 Y122.506 E.54405
G1 X104.584 Y122.982 E.01997
G1 X95.412 Y113.809 E.54408
G1 X95.412 Y114.285 E.01997
G1 X104.584 Y123.458 E.54408
G1 X104.584 Y123.933 E.01992
G1 X95.412 Y114.761 E.54405
G1 X95.412 Y115.236 E.01992
G1 X104.585 Y124.409 E.54411
G1 X104.585 Y124.885 E.01997
G1 X95.412 Y115.712 E.54411
G1 X95.412 Y116.187 E.01992
G1 X104.585 Y125.36 E.54411
G1 X104.585 Y125.836 E.01997
G1 X95.412 Y116.663 E.54411
G1 X95.412 Y117.138 E.01992
G1 X104.585 Y126.312 E.54414
G1 X104.585 Y126.787 E.01992
G1 X95.412 Y117.614 E.54411
G1 X95.412 Y118.09 E.01997
G1 X104.585 Y127.263 E.54411
G1 X104.585 Y127.739 E.01997
G1 X95.412 Y118.565 E.54414
G1 X95.412 Y119.041 E.01997
G1 X104.585 Y128.214 E.54411
G1 X104.585 Y128.69 E.01997
G1 X95.412 Y119.516 E.54414
G1 X95.412 Y119.992 E.01997
G1 X104.585 Y129.166 E.54414
G1 X104.586 Y129.641 E.01992
G1 X95.412 Y120.467 E.54417
G1 X95.412 Y120.943 E.01997
G1 X104.586 Y130.117 E.54417
G1 X104.586 Y130.593 E.01997
G1 X95.412 Y121.419 E.54417
G1 X95.412 Y121.894 E.01992
G1 X104.586 Y131.068 E.54417
G1 X104.586 Y131.544 E.01997
G1 X95.411 Y122.37 E.5442
G1 X95.411 Y122.845 E.01992
G1 X104.586 Y132.02 E.54423
G1 X104.586 Y132.495 E.01992
G1 X95.411 Y123.321 E.5442
G1 X95.411 Y123.796 E.01992
G1 X104.586 Y132.971 E.54423
G1 X104.586 Y133.447 E.01997
G1 X95.411 Y124.272 E.54423
G1 X95.411 Y124.748 E.01997
G1 X104.586 Y133.922 E.5442
G1 X104.586 Y134.398 E.01997
G1 X95.411 Y125.223 E.54423
G1 X95.411 Y125.699 E.01997
G1 X104.587 Y134.874 E.54426
G1 X104.587 Y135.349 E.01992
G1 X95.411 Y126.174 E.54426
G1 X95.411 Y126.65 E.01997
G1 X104.587 Y135.825 E.54426
G1 X104.587 Y136.301 E.01997
G1 X95.411 Y127.125 E.54429
G1 X95.411 Y127.601 E.01997
G1 X104.587 Y136.776 E.54426
G1 X104.579 Y137.244 E.01963
G1 X95.411 Y128.077 E.54379
G1 X95.411 Y128.552 E.01992
G1 X104.574 Y137.714 E.54349
G1 X104.587 Y138.203 E.02052
G1 X95.411 Y129.028 E.54426
G1 X95.411 Y129.503 E.01992
G1 X104.587 Y138.679 E.54429
G1 X104.587 Y139.154 E.01992
G1 X95.411 Y129.979 E.54426
G1 X95.411 Y130.454 E.01992
G1 X106.634 Y141.677 E.66571
G1 X106.159 Y141.677 E.01992
G1 X95.411 Y130.93 E.63751
G1 X95.411 Y131.405 E.01992
G1 X105.683 Y141.677 E.6093
G1 X105.207 Y141.677 E.01997
G1 X95.411 Y131.881 E.58107
G1 X95.411 Y132.357 E.01997
G1 X104.731 Y141.676 E.5528
G1 X104.243 Y141.664 E.02047
G1 X95.419 Y132.84 E.52341
G1 X95.483 Y133.38 E.02281
G1 X103.711 Y141.607 E.48803
G1 X103.165 Y141.537 E.02309
G1 X95.557 Y133.929 E.45128
G1 X95.691 Y134.539 E.0262
G1 X102.568 Y141.416 E.40792
G1 X101.898 Y141.221 E.02927
G1 X95.892 Y135.215 E.35626
G1 X96.158 Y135.957 E.03306
G1 X101.142 Y140.941 E.29563
G1 X100.548 Y140.669 E.0274
G1 X100.192 Y140.467 E.01717
G1 X96.639 Y136.914 E.21075
G1 X96.735 Y137.103 E.00889
G1 X97.113 Y137.684 E.02907
G1 X97.768 Y138.518 E.04448
G1 X99.416 Y140.166 E.09775
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X97.768 Y138.518 E-1.10705
G1 X97.257 Y137.868 E-.39295
;WIPE_END
G1 X97.21 Y137.904 F9000
G1 X104.635 Y128.876
G1 X106.065 Y127.134
G1 X112.043 Y119.888
G1 X112.155 Y119.712
G1 E5 F2400
;WIDTH:0.4
G1 F1200
G1 X111.717 Y119.403 E.02244
G1 X111.173 Y118.805 E.03384
G1 X109.297 Y115.578 E.15625
G1 X109.067 Y115.085 E.02277
G1 X108.922 Y114.543 E.02349
G1 X108.876 Y113.983 E.02352
G1 X108.922 Y113.457 E.0221
G1 X109.057 Y112.943 E.02225
G1 X109.297 Y112.422 E.02401
G1 X111.173 Y109.195 E.15625
G1 X111.674 Y108.648 E.03105
G1 X112.144 Y108.314 E.02414
G1 X112.423 Y108.14 E.01376
G1 X112.981 Y107.94 E.02481
G1 X113.766 Y107.839 E.03313
G1 X117.498 Y107.85 E.15622
G1 X118.253 Y108.01 E.03231
G1 X118.775 Y108.248 E.02402
G1 X119.441 Y108.74 E.03466
G1 X119.827 Y109.194 E.02495
G1 X121.703 Y112.422 E.15629
G1 X121.933 Y112.915 E.02277
G1 X122.078 Y113.457 E.02349
G1 X122.116 Y114.228 E.03231
G1 X122.025 Y114.788 E.02375
G1 X121.837 Y115.318 E.02354
G1 X119.827 Y118.805 E.16848
G1 X119.264 Y119.42 E.0349
G1 X118.851 Y119.714 E.02122
G1 X118.347 Y119.957 E.02342
G1 X117.806 Y120.108 E.02351
G1 X117.236 Y120.161 E.02396
G1 X113.764 Y120.161 E.14534
G1 X113.025 Y120.063 E.03121
G1 X112.205 Y119.746 E.0368
G1 E-5 F3600
G1 X112.205 Y119.746 F9000
G1 X112.102 Y119.923
G1 X112.052 Y119.894
G1 X111.864 Y119.774
G1 X111.801 Y119.729
G1 X111.625 Y119.594
G1 X111.566 Y119.543
G1 X111.402 Y119.393
G1 X111.348 Y119.337
G1 X111.198 Y119.172
G1 X111.15 Y119.111
G1 X111.015 Y118.935
G1 X110.973 Y118.87
G1 X110.859 Y118.692
G1 X109.116 Y115.673
G1 X109.019 Y115.486
G1 X108.984 Y115.417
G1 X108.898 Y115.211
G1 X108.87 Y115.139
G1 X108.803 Y114.927
G1 X108.781 Y114.853
G1 X108.733 Y114.635
G1 X108.718 Y114.559
G1 X108.689 Y114.338
G1 X108.681 Y114.261
G1 X108.672 Y114.039
G1 X108.672 Y113.961
G1 X108.681 Y113.739
G1 X108.689 Y113.662
G1 X108.718 Y113.441
G1 X108.733 Y113.365
G1 X108.781 Y113.147
G1 X108.803 Y113.073
G1 X108.87 Y112.861
G1 X108.898 Y112.789
G1 X108.984 Y112.583
G1 X109.019 Y112.514
G1 X109.116 Y112.327
G1 X110.859 Y109.308
G1 X110.973 Y109.13
G1 X111.015 Y109.065
G1 X111.15 Y108.889
G1 X111.198 Y108.828
G1 X111.348 Y108.663
G1 X111.402 Y108.607
G1 X111.566 Y108.457
G1 X111.625 Y108.406
G1 X111.801 Y108.271
G1 X111.864 Y108.226
G1 X112.052 Y108.106
G1 X112.119 Y108.067
G1 X112.317 Y107.964
G1 X112.387 Y107.932
G1 X112.593 Y107.847
G1 X112.666 Y107.822
G1 X112.879 Y107.755
G1 X112.954 Y107.736
G1 X113.172 Y107.688
G1 X113.248 Y107.677
G1 X113.333 Y107.666
G1 X113.448 Y106.349
G1 X113.477 Y106.123
G1 E5 F2400
G1 F1200
G1 X113.025 Y106.063 E.01909
G1 X112.202 Y105.745 E.03693
G1 X111.693 Y105.383 E.02615
G1 X111.173 Y104.805 E.03255
G1 X109.297 Y101.578 E.15625
G1 X109.067 Y101.085 E.02277
G1 X108.922 Y100.543 E.02349
G1 X108.876 Y99.983 E.02352
G1 X108.922 Y99.457 E.0221
G1 X109.057 Y98.943 E.02225
G1 X109.289 Y98.436 E.02334
G1 X111.173 Y95.195 E.15693
G1 X111.736 Y94.58 E.0349
G1 X112.389 Y94.157 E.03257
G1 X112.981 Y93.94 E.02639
G1 X113.744 Y93.84 E.03221
G1 X117.498 Y93.85 E.15714
G1 X118.253 Y94.01 E.03231
G1 X118.826 Y94.271 E.02636
G1 X119.441 Y94.74 E.03238
G1 X119.827 Y95.194 E.02495
G1 X121.703 Y98.422 E.15629
G1 X121.933 Y98.915 E.02277
G1 X122.078 Y99.457 E.02349
G1 X122.116 Y100.228 E.03231
G1 X122.025 Y100.788 E.02375
G1 X121.837 Y101.318 E.02354
G1 X119.827 Y104.805 E.16848
G1 X119.264 Y105.42 E.0349
G1 X118.797 Y105.745 E.02382
G1 X118.338 Y105.962 E.02125
G1 X117.806 Y106.108 E.02309
G1 X117.251 Y106.161 E.02334
G1 X113.764 Y106.161 E.14597
G1 X113.537 Y106.131 E.00958
G1 E-5 F3600
G1 X113.537 Y106.131 F9000
G1 X113.526 Y106.355
G1 X111.15 Y108.889
G1 X110.973 Y109.13
G1 X108.87 Y112.861
G1 X108.87 Y115.139
G1 X110.973 Y118.87
G1 X111.15 Y119.111
G1 X112.119 Y119.933
G1 X112.317 Y120.036
G1 X112.387 Y120.068
G1 X112.593 Y120.153
G1 X112.666 Y120.178
G1 X112.879 Y120.245
G1 X112.954 Y120.264
G1 X113.172 Y120.312
G1 X113.248 Y120.323
G1 X113.469 Y120.352
G1 X113.546 Y120.356
G1 X113.746 Y120.364
G1 X113.768 Y121.635
G1 X113.768 Y121.839
G1 E5 F2400
G1 F1200
G1 X117.498 Y121.85 E.15614
G1 X118.253 Y122.01 E.03231
G1 X118.826 Y122.271 E.02636
G1 X119.441 Y122.74 E.03238
G1 X119.81 Y123.17 E.02372
G1 X121.703 Y126.422 E.15751
G1 X121.933 Y126.915 E.02277
G1 X122.078 Y127.457 E.02349
G1 X122.116 Y128.228 E.03231
G1 X122.025 Y128.788 E.02375
G1 X121.825 Y129.345 E.02477
G1 X119.827 Y132.805 E.16725
G1 X119.264 Y133.42 E.0349
G1 X118.797 Y133.745 E.02382
G1 X118.319 Y133.968 E.02208
G1 X117.806 Y134.108 E.02226
G1 X117.236 Y134.161 E.02396
G1 X113.764 Y134.161 E.14534
G1 X112.956 Y134.054 E.03412
G1 X112.234 Y133.763 E.03259
G1 X111.717 Y133.403 E.02637
G1 X111.173 Y132.805 E.03384
G1 X109.297 Y129.578 E.15625
G1 X109.067 Y129.085 E.02277
G1 X108.922 Y128.543 E.02349
G1 X108.876 Y127.983 E.02352
G1 X108.922 Y127.457 E.0221
G1 X109.067 Y126.915 E.02349
G1 X109.297 Y126.422 E.02277
G1 X111.173 Y123.195 E.15625
G1 X111.674 Y122.648 E.03105
G1 X112.144 Y122.314 E.02414
G1 X112.423 Y122.14 E.01376
G1 X112.981 Y121.94 E.02481
G1 X113.708 Y121.846 E.03069
G1 E-5 F3600
G1 X113.708 Y121.846 F9000
G1 X113.699 Y121.638
G1 X113.547 Y121.644
G1 X113.469 Y121.648
G1 X113.248 Y121.677
G1 X113.172 Y121.688
G1 X112.954 Y121.736
G1 X112.879 Y121.755
G1 X112.666 Y121.822
G1 X112.593 Y121.847
G1 X112.387 Y121.932
G1 X112.317 Y121.964
G1 X112.119 Y122.067
G1 X112.052 Y122.106
G1 X111.864 Y122.226
G1 X111.801 Y122.271
G1 X111.625 Y122.406
G1 X111.566 Y122.457
G1 X111.402 Y122.607
G1 X111.348 Y122.663
G1 X111.198 Y122.828
G1 X111.15 Y122.889
G1 X111.015 Y123.065
G1 X110.973 Y123.13
G1 X110.859 Y123.308
G1 X109.116 Y126.327
G1 X109.019 Y126.514
G1 X108.984 Y126.583
G1 X108.898 Y126.789
G1 X108.87 Y126.861
G1 X108.803 Y127.073
G1 X108.781 Y127.147
G1 X108.733 Y127.365
G1 X108.718 Y127.441
G1 X108.689 Y127.662
G1 X108.681 Y127.739
G1 X108.672 Y127.961
G1 X108.672 Y128.039
G1 X108.681 Y128.261
G1 X108.689 Y128.338
G1 X108.718 Y128.559
G1 X108.733 Y128.635
G1 X108.781 Y128.853
G1 X108.803 Y128.927
G1 X108.87 Y129.139
G1 X108.898 Y129.211
G1 X108.984 Y129.417
G1 X109.019 Y129.486
G1 X109.116 Y129.673
G1 X109.37 Y130.112
G1 X106.04 Y136.927
G1 X105.846 Y136.827
G1 E5 F2400
G1 F1200
G1 X105.861 Y136.788 E.00175
G1 X105.861 Y91.211 E1.90786
G1 X105.713 Y90.856 E.0161
G1 X105.638 Y90.555 E.01299
G1 X105.707 Y90.176 E.01613
G1 X125.3 Y90.176 E.82017
G1 X125.356 Y90.45 E.01171
G1 X125.321 Y90.743 E.01235
G1 X125.139 Y91.212 E.02106
G1 X125.139 Y136.789 E1.90786
G1 X125.287 Y137.144 E.0161
G1 X125.36 Y137.487 E.01468
G1 X125.293 Y137.824 E.01438
G1 X105.7 Y137.824 E.82017
G1 X105.644 Y137.55 E.01171
G1 X105.679 Y137.257 E.01235
G1 X105.825 Y136.882 E.01685
G1 E-5 F3600
G1 X105.825 Y136.882 F9000
G1 X106.013 Y136.98
G1 X106.065 Y136.88
G1 X109.248 Y90.379
G1 X125.098 Y90.798
G1 X125.074 Y90.853
G1 X125.16 Y90.89
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.400211
G1 F1200
G1 X124.699 Y90.428 E.02734
G1 X124.224 Y90.428 E.0199
G1 X124.907 Y91.112 E.04049
G1 X124.887 Y91.203 E.0039
G1 X124.887 Y91.566 E.0152
G1 X123.749 Y90.428 E.06741
G1 X123.274 Y90.428 E.0199
G1 X124.887 Y92.041 E.09555
G1 X124.887 Y92.516 E.0199
G1 X122.799 Y90.428 E.12369
G1 X122.324 Y90.428 E.0199
G1 X124.887 Y92.991 E.15182
G1 X124.887 Y93.466 E.0199
G1 X121.849 Y90.428 E.17996
G1 X121.374 Y90.428 E.0199
G1 X124.887 Y93.941 E.2081
G1 X124.887 Y94.416 E.0199
G1 X120.899 Y90.428 E.23624
G1 X120.424 Y90.428 E.0199
G1 X124.887 Y94.891 E.26437
G1 X124.887 Y95.366 E.0199
G1 X119.949 Y90.428 E.29251
G1 X119.474 Y90.428 E.0199
G1 X124.887 Y95.841 E.32065
G1 X124.887 Y96.316 E.0199
G1 X118.999 Y90.428 E.34878
G1 X118.525 Y90.428 E.01985
G1 X124.887 Y96.791 E.37689
G1 X124.887 Y97.266 E.0199
G1 X118.05 Y90.428 E.40503
G1 X117.575 Y90.428 E.0199
G1 X124.887 Y97.74 E.43314
G1 X124.887 Y98.215 E.0199
G1 X117.1 Y90.428 E.46128
G1 X116.625 Y90.428 E.0199
G1 X124.887 Y98.69 E.48941
G1 X124.887 Y99.165 E.0199
G1 X116.15 Y90.428 E.51755
G1 X115.675 Y90.428 E.0199
G1 X124.887 Y99.64 E.54569
G1 X124.887 Y100.115 E.0199
G1 X120.328 Y95.556 E.27006
G1 X120.04 Y95.061 E.02399
G1 X119.602 Y94.546 E.02832
G1 X119.004 Y94.086 E.0316
G1 X118.731 Y93.959 E.01261
G1 X115.2 Y90.428 E.20916
G1 X114.725 Y90.428 E.0199
G1 X117.997 Y93.7 E.19382
G1 X117.507 Y93.599 E.02096
G1 X117.42 Y93.598 E.00364
G1 X114.25 Y90.428 E.18778
G1 X113.775 Y90.428 E.0199
G1 X116.944 Y93.597 E.18772
G1 X116.468 Y93.596 E.01994
G1 X113.3 Y90.428 E.18766
G1 X112.825 Y90.428 E.0199
G1 X115.992 Y93.595 E.1876
G1 X115.516 Y93.594 E.01994
G1 X112.35 Y90.428 E.18754
G1 X111.875 Y90.428 E.0199
G1 X115.04 Y93.593 E.18748
G1 X114.564 Y93.592 E.01994
G1 X111.401 Y90.428 E.18739
G1 X110.926 Y90.428 E.0199
G1 X114.088 Y93.59 E.18731
G1 X113.624 Y93.601 E.01944
G1 X110.451 Y90.428 E.18796
G1 X109.976 Y90.428 E.0199
G1 X113.202 Y93.655 E.19113
G1 X112.96 Y93.685 E.01021
G1 X112.812 Y93.739 E.0066
G1 X109.501 Y90.428 E.19613
G1 X109.026 Y90.428 E.0199
G1 X112.464 Y93.866 E.20366
G1 X112.261 Y93.94 E.00905
G1 X112.141 Y94.019 E.00602
G1 X108.551 Y90.428 E.21269
G1 X108.076 Y90.428 E.0199
G1 X111.855 Y94.207 E.22385
G1 X111.568 Y94.395 E.01437
G1 X107.601 Y90.428 E.23499
G1 X107.126 Y90.428 E.0199
G1 X111.34 Y94.642 E.24962
G1 X111.114 Y94.891 E.01409
G1 X106.651 Y90.428 E.26437
G1 X106.176 Y90.428 E.0199
G1 X110.904 Y95.156 E.28007
G1 X110.73 Y95.457 E.01456
G1 X105.912 Y90.639 E.2854
G1 X105.93 Y90.725 E.00368
G1 X106.078 Y91.042 E.01465
G1 X106.113 Y91.202 E.00686
G1 X106.113 Y91.315 E.00473
G1 X110.555 Y95.757 E.26313
G1 X110.381 Y96.057 E.01453
G1 X106.113 Y91.79 E.25279
G1 X106.113 Y92.265 E.0199
G1 X110.206 Y96.358 E.24246
G1 X110.031 Y96.658 E.01455
G1 X106.113 Y92.74 E.23209
G1 X106.113 Y93.215 E.0199
G1 X109.857 Y96.958 E.22175
G1 X109.682 Y97.259 E.01458
G1 X106.113 Y93.69 E.21142
G1 X106.113 Y94.164 E.01985
G1 X109.507 Y97.559 E.20108
G1 X109.333 Y97.859 E.01453
G1 X106.113 Y94.639 E.19074
G1 X106.113 Y95.114 E.0199
G1 X109.158 Y98.159 E.18038
G1 X108.997 Y98.474 E.01482
G1 X106.113 Y95.589 E.17087
G1 X106.113 Y96.064 E.0199
G1 X108.848 Y98.8 E.16204
G1 X108.739 Y99.165 E.01596
G1 X106.113 Y96.539 E.15556
G1 X106.113 Y97.014 E.0199
G1 X108.662 Y99.563 E.15099
G1 X108.626 Y100.002 E.01845
G1 X106.113 Y97.489 E.14886
G1 X106.113 Y97.964 E.0199
G1 X108.667 Y100.517 E.15126
G1 X108.827 Y101.153 E.02747
G1 X106.113 Y98.439 E.16077
G1 X106.113 Y98.914 E.0199
G1 X109.323 Y102.123 E.19012
G1 X109.982 Y103.258 E.05497
G1 X105.962 Y99.238 E.23813
G1 E-5 F3600
G1 X105.962 Y99.238 F9000
G1 X106.065 Y99.238
G1 X111.566 Y94.457
G1 X111.625 Y94.406
G1 X111.801 Y94.271
G1 X111.864 Y94.226
G1 X112.052 Y94.106
G1 X112.119 Y94.067
G1 X112.317 Y93.964
G1 X112.387 Y93.932
G1 X112.593 Y93.847
G1 X112.666 Y93.822
G1 X112.879 Y93.755
G1 X112.954 Y93.736
G1 X113.172 Y93.688
G1 X113.248 Y93.677
G1 X113.469 Y93.648
G1 X113.547 Y93.644
G1 X113.757 Y93.635
G1 X117.243 Y93.635
G1 X117.453 Y93.644
G1 X117.531 Y93.648
G1 X117.752 Y93.677
G1 X117.828 Y93.688
G1 X118.046 Y93.736
G1 X118.121 Y93.755
G1 X118.334 Y93.822
G1 X118.407 Y93.847
G1 X118.613 Y93.932
G1 X118.683 Y93.964
G1 X118.881 Y94.067
G1 X118.948 Y94.106
G1 X119.136 Y94.226
G1 X119.199 Y94.271
G1 X119.375 Y94.406
G1 X119.434 Y94.457
G1 X119.598 Y94.607
G1 X119.652 Y94.663
G1 X119.802 Y94.828
G1 X119.85 Y94.889
G1 X119.985 Y95.065
G1 X120.027 Y95.13
G1 X120.141 Y95.308
G1 X120.563 Y96.04
G1 X120.666 Y96.219
G1 X120.571 Y96.274
G1 E5 F2400
G1 F1200
G1 X124.887 Y100.59 E.25566
G1 X124.887 Y101.065 E.0199
G1 X121.648 Y97.826 E.19187
G1 X121.923 Y98.299 E.02292
G1 X122.165 Y98.818 E.02399
G1 X124.887 Y101.54 E.16124
G1 X124.887 Y102.015 E.0199
G1 X122.331 Y99.458 E.15144
G1 X122.355 Y99.958 E.02097
G1 X124.887 Y102.49 E.14999
G1 X124.887 Y102.965 E.0199
G1 X122.34 Y100.417 E.15091
G1 X122.274 Y100.826 E.01735
G1 X124.887 Y103.44 E.15481
G1 X124.887 Y103.915 E.0199
G1 X122.15 Y101.177 E.16216
G1 X122.015 Y101.518 E.01536
G1 X124.887 Y104.39 E.17013
G1 X124.887 Y104.865 E.0199
G1 X121.841 Y101.818 E.18046
G1 X121.667 Y102.119 E.01456
G1 X124.887 Y105.339 E.19074
G1 X124.887 Y105.814 E.0199
G1 X121.492 Y102.42 E.20108
G1 X121.318 Y102.72 E.01453
G1 X124.887 Y106.289 E.21142
G1 X124.887 Y106.764 E.0199
G1 X121.143 Y103.021 E.22175
G1 X120.969 Y103.321 E.01453
G1 X124.887 Y107.239 E.23209
G1 X124.887 Y107.714 E.0199
G1 X120.795 Y103.622 E.2424
G1 X120.62 Y103.922 E.01455
G1 X124.887 Y108.189 E.25276
G1 X124.887 Y108.664 E.0199
G1 X120.446 Y104.223 E.26307
G1 X120.272 Y104.524 E.01456
G1 X124.887 Y109.139 E.27338
G1 X124.887 Y109.614 E.0199
G1 X120.097 Y104.824 E.28374
G1 X119.996 Y104.999 E.00846
G1 X119.9 Y105.101 E.00587
G1 X124.887 Y110.089 E.29544
G1 X124.887 Y110.564 E.0199
G1 X119.669 Y105.346 E.3091
G1 X119.439 Y105.59 E.01405
G1 X124.887 Y111.039 E.32275
G1 X124.887 Y111.514 E.0199
G1 X119.168 Y105.795 E.33877
G1 X118.884 Y105.985 E.01431
G1 X124.887 Y111.989 E.35563
G1 X124.887 Y112.463 E.01985
G1 X118.559 Y106.136 E.37482
G1 X118.43 Y106.196 E.00596
G1 X118.207 Y106.258 E.00969
G1 X124.887 Y112.938 E.3957
G1 X124.887 Y113.413 E.0199
G1 X117.83 Y106.356 E.41803
G1 X117.398 Y106.399 E.01818
G1 X124.887 Y113.888 E.44362
G1 X124.887 Y114.363 E.0199
G1 X120.673 Y110.149 E.24962
G1 X121.333 Y111.284 E.05499
G1 X124.887 Y114.838 E.21053
G1 X124.887 Y115.313 E.0199
G1 X121.967 Y112.393 E.17297
G1 X122.164 Y112.816 E.01955
G1 X122.251 Y113.152 E.01454
G1 X124.887 Y115.788 E.15615
G1 X124.887 Y116.263 E.0199
G1 X122.345 Y113.721 E.15058
G1 X122.367 Y114.218 E.02084
G1 X124.887 Y116.738 E.14928
G1 X124.887 Y117.213 E.0199
G1 X122.305 Y114.631 E.15295
G1 X122.272 Y114.839 E.00882
G1 X122.21 Y115.011 E.00766
G1 X124.887 Y117.688 E.15858
G1 X124.887 Y118.163 E.0199
G1 X122.084 Y115.36 E.16604
G1 X122.046 Y115.464 E.00464
G1 X121.924 Y115.675 E.01021
G1 X124.887 Y118.638 E.17552
G1 X124.887 Y119.113 E.0199
G1 X121.75 Y115.975 E.18585
G1 X121.575 Y116.276 E.01458
G1 X124.887 Y119.588 E.19619
G1 X124.887 Y120.062 E.01985
G1 X121.401 Y116.577 E.20647
G1 X121.227 Y116.877 E.01453
G1 X124.887 Y120.537 E.21681
G1 X124.887 Y121.012 E.0199
G1 X121.052 Y117.178 E.22714
G1 X120.878 Y117.478 E.01453
G1 X124.887 Y121.487 E.23748
G1 X124.887 Y121.962 E.0199
G1 X120.704 Y117.779 E.24779
G1 X120.529 Y118.079 E.01455
G1 X124.887 Y122.437 E.25815
G1 X124.887 Y122.912 E.0199
G1 X120.355 Y118.38 E.26846
G1 X120.181 Y118.681 E.01456
G1 X124.887 Y123.387 E.27877
G1 X124.887 Y123.862 E.0199
G1 X120.006 Y118.981 E.28913
G1 X119.779 Y119.229 E.01408
G1 X124.887 Y124.337 E.30258
G1 X124.887 Y124.812 E.0199
G1 X119.549 Y119.474 E.3162
G1 X119.388 Y119.645 E.00984
G1 X119.303 Y119.703 E.00431
G1 X124.887 Y125.287 E.33078
G1 X124.887 Y125.762 E.0199
G1 X119.022 Y119.897 E.34742
G1 X118.712 Y120.062 E.01471
G1 X124.887 Y126.237 E.36579
G1 X124.887 Y126.712 E.0199
G1 X118.384 Y120.209 E.38522
G1 X118.013 Y120.312 E.01613
G1 X124.887 Y127.186 E.40719
G1 X124.887 Y127.661 E.0199
G1 X117.604 Y120.379 E.43139
G1 X117.162 Y120.412 E.01857
G1 X118.682 Y121.932 E.09004
G1 X118.992 Y122.077 E.01434
G1 X119.617 Y122.558 E.03303
G1 X120.041 Y123.062 E.02759
G1 X120.358 Y123.607 E.02641
G1 X124.887 Y128.136 E.26828
G1 X124.887 Y128.611 E.0199
G1 X121.018 Y124.742 E.22919
G1 X121.678 Y125.877 E.05499
G1 X124.887 Y129.086 E.19009
G1 X124.887 Y129.561 E.0199
G1 X122.172 Y126.846 E.16083
G1 X122.335 Y127.484 E.02758
G1 X124.887 Y130.036 E.15117
G1 X124.887 Y130.511 E.0199
G1 X122.356 Y127.98 E.14993
G1 X122.368 Y128.241 E.01094
G1 X122.337 Y128.436 E.00827
G1 X124.887 Y130.986 E.15105
G1 X124.887 Y131.461 E.0199
G1 X122.27 Y128.844 E.15502
G1 X122.144 Y129.193 E.01554
G1 X124.887 Y131.936 E.16249
G1 X124.887 Y132.411 E.0199
G1 X122.008 Y129.531 E.17057
G1 X121.833 Y129.832 E.01458
G1 X124.887 Y132.886 E.18091
G1 X124.887 Y133.361 E.0199
G1 X121.659 Y130.133 E.19122
G1 X121.485 Y130.434 E.01456
G1 X124.887 Y133.836 E.20152
G1 X124.887 Y134.311 E.0199
G1 X121.311 Y130.734 E.21186
G1 X121.137 Y131.035 E.01456
G1 X124.887 Y134.785 E.22214
G1 X124.887 Y135.26 E.0199
G1 X120.962 Y131.336 E.23247
G1 X120.788 Y131.637 E.01456
G1 X124.887 Y135.735 E.24278
G1 X124.887 Y136.21 E.0199
G1 X120.614 Y131.937 E.25312
G1 X120.44 Y132.238 E.01456
G1 X124.887 Y136.685 E.26342
G1 X124.887 Y136.798 E.00473
G1 X124.922 Y136.958 E.00686
G1 X125.07 Y137.275 E.01465
G1 X125.088 Y137.361 E.00368
G1 X120.266 Y132.539 E.28564
G1 X120.091 Y132.839 E.01455
G1 X124.824 Y137.572 E.28037
G1 X124.349 Y137.572 E.0199
G1 X119.889 Y133.112 E.2642
G1 X119.659 Y133.357 E.01408
G1 X123.874 Y137.572 E.24968
G1 X123.399 Y137.572 E.0199
G1 X119.428 Y133.601 E.23523
G1 X119.156 Y133.804 E.01422
G1 X122.924 Y137.572 E.2232
G1 X122.449 Y137.572 E.0199
G1 X118.866 Y133.989 E.21224
G1 X118.544 Y134.142 E.01493
G1 X121.974 Y137.572 E.20318
G1 X121.499 Y137.572 E.0199
G1 X118.188 Y134.261 E.19613
G1 X117.814 Y134.362 E.01623
G1 X121.024 Y137.572 E.19015
G1 X120.549 Y137.572 E.0199
G1 X117.379 Y134.402 E.18778
G1 X116.914 Y134.412 E.01948
G1 X120.074 Y137.572 E.18719
G1 X119.599 Y137.572 E.0199
G1 X116.44 Y134.412 E.18716
G1 X115.965 Y134.412 E.0199
G1 X119.125 Y137.572 E.18719
G1 X118.65 Y137.572 E.0199
G1 X115.49 Y134.412 E.18719
G1 X115.015 Y134.413 E.0199
G1 X118.175 Y137.572 E.18716
G1 X117.7 Y137.572 E.0199
G1 X114.541 Y134.413 E.18713
G1 X114.066 Y134.413 E.0199
G1 X117.225 Y137.572 E.18713
G1 X116.75 Y137.572 E.0199
G1 X113.566 Y134.388 E.18861
G1 X113.019 Y134.316 E.02311
G1 X116.426 Y137.723 E.20182
G1 E-5 F3600
G1 X116.426 Y137.723 F9000
G1 X116.426 Y137.621
G1 X119.985 Y132.935
G1 X120.027 Y132.87
G1 X120.141 Y132.692
G1 X121.884 Y129.673
G1 X121.981 Y129.486
G1 X122.016 Y129.417
G1 X122.102 Y129.211
G1 X122.13 Y129.139
G1 X122.197 Y128.927
G1 X122.219 Y128.853
G1 X122.267 Y128.635
G1 X122.282 Y128.559
G1 X122.311 Y128.338
G1 X122.319 Y128.261
G1 X122.328 Y128.039
G1 X122.328 Y127.961
G1 X122.319 Y127.739
G1 X122.311 Y127.662
G1 X122.282 Y127.441
G1 X122.267 Y127.365
G1 X122.219 Y127.147
G1 X122.197 Y127.073
G1 X122.13 Y126.861
G1 X122.102 Y126.789
G1 X122.016 Y126.583
G1 X121.981 Y126.514
G1 X121.884 Y126.327
G1 X120.141 Y123.308
G1 X120.027 Y123.13
G1 X119.985 Y123.065
G1 X119.85 Y122.889
G1 X119.802 Y122.828
G1 X119.652 Y122.663
G1 X119.598 Y122.607
G1 X119.434 Y122.457
G1 X119.375 Y122.406
G1 X119.199 Y122.271
G1 X119.136 Y122.226
G1 X118.948 Y122.106
G1 X118.881 Y122.067
G1 X118.683 Y121.964
G1 X118.613 Y121.932
G1 X118.407 Y121.847
G1 X118.334 Y121.822
G1 X118.202 Y121.78
G1 X118.167 Y121.891
G1 E5 F2400
G1 F1200
G1 X116.688 Y120.412 E.08761
G1 X116.213 Y120.412 E.0199
G1 X117.399 Y121.598 E.07025
G1 X116.923 Y121.597 E.01994
G1 X115.738 Y120.412 E.0702
G1 X115.263 Y120.412 E.0199
G1 X116.446 Y121.595 E.07008
G1 X115.97 Y121.594 E.01994
G1 X114.789 Y120.413 E.06996
G1 X114.314 Y120.413 E.0199
G1 X115.493 Y121.592 E.06984
G1 X115.017 Y121.591 E.01994
G1 X113.839 Y120.413 E.06978
G1 X113.302 Y120.351 E.02264
G1 X114.541 Y121.589 E.07336
G1 X114.064 Y121.588 E.01998
G1 X112.425 Y119.949 E.09709
G1 E-5 F3600
G1 X112.425 Y119.949 F9000
G1 X112.374 Y120.062
G1 X111.15 Y119.111
G1 X110.973 Y118.87
G1 X108.87 Y115.139
G1 X108.87 Y112.861
G1 X110.973 Y109.13
G1 X111.15 Y108.889
G1 X113.469 Y107.648
G1 X113.547 Y107.644
G1 X113.757 Y107.635
G1 X116.347 Y107.635
G1 X116.785 Y106.365
G1 X116.785 Y106.261
G1 E5 F2400
G1 F1200
G1 X118.286 Y107.762 E.08891
G1 X117.685 Y107.636 E.02572
G1 X116.461 Y106.412 E.07251
G1 X115.986 Y106.412 E.0199
G1 X117.171 Y107.598 E.07022
G1 X116.695 Y107.596 E.01994
G1 X115.511 Y106.412 E.07014
G1 X115.037 Y106.413 E.01985
G1 X116.219 Y107.595 E.07002
G1 X115.742 Y107.593 E.01998
G1 X114.562 Y106.413 E.0699
G1 X114.087 Y106.413 E.0199
G1 X115.266 Y107.592 E.06984
G1 X114.789 Y107.59 E.01998
G1 X113.589 Y106.39 E.07108
G1 X113.039 Y106.315 E.02325
G1 X114.313 Y107.589 E.07547
G1 X113.837 Y107.587 E.01994
G1 X112.318 Y106.068 E.08998
G1 X112.117 Y105.986 E.00909
G1 X111.538 Y105.583 E.02955
G1 X110.96 Y104.939 E.03625
G1 X110.642 Y104.393 E.02647
G1 X106.113 Y99.864 E.26828
G1 X106.113 Y100.339 E.0199
G1 X113.405 Y107.631 E.43195
G1 X112.982 Y107.683 E.01785
G1 X106.113 Y100.814 E.4069
G1 X106.113 Y101.289 E.0199
G1 X112.629 Y107.804 E.38596
G1 X112.28 Y107.93 E.01554
G1 X106.113 Y101.763 E.36531
G1 X106.113 Y102.238 E.0199
G1 X111.99 Y108.116 E.34816
G1 X111.702 Y108.302 E.01436
G1 X106.113 Y102.713 E.33107
G1 X106.113 Y103.188 E.0199
G1 X111.449 Y108.524 E.31609
G1 X111.222 Y108.773 E.01411
G1 X106.113 Y103.663 E.30267
G1 X106.113 Y104.138 E.0199
G1 X110.996 Y109.021 E.28925
G1 X110.813 Y109.313 E.01443
G1 X106.113 Y104.613 E.27841
G1 X106.113 Y105.088 E.0199
G1 X110.639 Y109.614 E.2681
G1 X110.464 Y109.914 E.01455
G1 X106.113 Y105.563 E.25774
G1 X106.113 Y106.038 E.0199
G1 X110.289 Y110.214 E.24737
G1 X110.115 Y110.514 E.01453
G1 X106.113 Y106.513 E.23704
G1 X106.113 Y106.988 E.0199
G1 X109.94 Y110.815 E.2267
G1 X109.765 Y111.115 E.01455
G1 X106.113 Y107.463 E.21633
G1 X106.113 Y107.938 E.0199
G1 X109.591 Y111.415 E.206
G1 X109.416 Y111.716 E.01458
G1 X106.113 Y108.413 E.19566
G1 X106.113 Y108.887 E.01985
G1 X109.242 Y112.016 E.18535
G1 X109.068 Y112.318 E.0146
G1 X106.113 Y109.362 E.17507
G1 X106.113 Y109.837 E.0199
G1 X108.92 Y112.644 E.16628
G1 X108.815 Y112.872 E.01051
G1 X108.786 Y112.985 E.00489
G1 X106.113 Y110.312 E.15834
G1 X106.113 Y110.787 E.0199
G1 X108.687 Y113.361 E.15247
G1 X108.64 Y113.789 E.01804
G1 X106.113 Y111.262 E.14969
G1 X106.113 Y111.737 E.0199
G1 X108.647 Y114.271 E.15011
G1 X108.671 Y114.572 E.01265
G1 X108.744 Y114.843 E.01176
G1 X106.113 Y112.212 E.15585
G1 X106.113 Y112.687 E.0199
G1 X109.033 Y115.607 E.17297
G1 X109.667 Y116.716 E.05351
G1 X106.113 Y113.162 E.21053
G1 X106.113 Y113.637 E.0199
G1 X110.745 Y118.268 E.27435
G1 E-5 F3600
G1 X110.745 Y118.268 F9000
G1 X113.743 Y121.741
G1 E5 F2400
G1 F1200
G1 X106.113 Y114.112 E.45195
G1 X106.113 Y114.587 E.0199
G1 X113.184 Y121.658 E.41886
G1 X112.956 Y121.686 E.00962
G1 X112.795 Y121.744 E.00717
G1 X106.113 Y115.062 E.39582
G1 X106.113 Y115.537 E.0199
G1 X112.446 Y121.87 E.37515
G1 X112.274 Y121.932 E.00766
G1 X112.128 Y122.026 E.00727
G1 X106.113 Y116.012 E.35628
G1 X106.113 Y116.486 E.01985
G1 X111.839 Y122.213 E.33922
G1 X111.557 Y122.405 E.01429
G1 X106.113 Y116.961 E.32248
G1 X106.113 Y117.436 E.0199
G1 X111.33 Y122.654 E.30907
G1 X111.104 Y122.902 E.01405
G1 X106.113 Y117.911 E.29565
G1 X106.113 Y118.386 E.0199
G1 X110.897 Y123.17 E.28339
G1 X110.722 Y123.47 E.01455
G1 X106.113 Y118.861 E.27302
G1 X106.113 Y119.336 E.0199
G1 X110.547 Y123.77 E.26265
G1 X110.373 Y124.071 E.01456
G1 X106.113 Y119.811 E.25235
G1 X106.113 Y120.286 E.0199
G1 X110.198 Y124.371 E.24198
G1 X110.023 Y124.671 E.01455
G1 X106.113 Y120.761 E.23161
G1 X106.113 Y121.236 E.0199
G1 X109.849 Y124.972 E.22131
G1 X109.674 Y125.272 E.01455
G1 X106.113 Y121.711 E.21094
G1 X106.113 Y122.186 E.0199
G1 X109.5 Y125.572 E.2006
G1 X109.325 Y125.873 E.01458
G1 X106.113 Y122.661 E.19027
G1 X106.113 Y123.136 E.0199
G1 X109.15 Y126.173 E.1799
G1 X108.991 Y126.488 E.01478
G1 X106.113 Y123.61 E.17048
G1 X106.113 Y124.085 E.0199
G1 X108.842 Y126.814 E.16166
G1 X108.734 Y127.182 E.01606
G1 X106.113 Y124.56 E.15529
G1 X106.113 Y125.035 E.0199
G1 X108.66 Y127.582 E.15088
G1 X108.628 Y128.025 E.0186
G1 X106.113 Y125.51 E.14898
G1 X106.113 Y125.985 E.0199
G1 X108.668 Y128.541 E.15138
G1 X108.835 Y129.182 E.02775
G1 X106.113 Y126.46 E.16124
G1 X106.113 Y126.935 E.0199
G1 X109.352 Y130.174 E.19187
G1 X110.012 Y131.309 E.05499
G1 X106.113 Y127.41 E.23096
G1 X106.113 Y127.885 E.0199
G1 X110.672 Y132.444 E.27006
G1 X110.96 Y132.939 E.02399
G1 X111.508 Y133.555 E.03453
G1 X112.13 Y133.992 E.03184
G1 X112.279 Y134.051 E.00671
G1 X115.8 Y137.572 E.20857
G1 X115.325 Y137.572 E.0199
G1 X106.113 Y128.36 E.54569
G1 X106.113 Y128.835 E.0199
G1 X114.85 Y137.572 E.51755
G1 X114.375 Y137.572 E.0199
G1 X106.113 Y129.31 E.48941
G1 X106.113 Y129.785 E.0199
G1 X113.9 Y137.572 E.46128
G1 X113.425 Y137.572 E.0199
G1 X106.113 Y130.26 E.43314
G1 X106.113 Y130.735 E.0199
G1 X112.95 Y137.572 E.405
G1 X112.475 Y137.572 E.0199
G1 X106.113 Y131.209 E.37689
G1 X106.113 Y131.684 E.0199
G1 X112 Y137.572 E.34876
G1 X111.526 Y137.572 E.01985
G1 X106.113 Y132.159 E.32065
G1 X106.113 Y132.634 E.0199
G1 X111.051 Y137.572 E.29251
G1 X110.576 Y137.572 E.0199
G1 X106.113 Y133.109 E.26437
G1 X106.113 Y133.584 E.0199
G1 X110.101 Y137.572 E.23624
G1 X109.626 Y137.572 E.0199
G1 X106.113 Y134.059 E.2081
G1 X106.113 Y134.534 E.0199
G1 X109.151 Y137.572 E.17996
G1 X108.676 Y137.572 E.0199
G1 X106.113 Y135.009 E.15182
G1 X106.113 Y135.484 E.0199
G1 X108.201 Y137.572 E.12369
G1 X107.726 Y137.572 E.0199
G1 X106.113 Y135.959 E.09555
G1 X106.113 Y136.434 E.0199
G1 X107.251 Y137.572 E.06741
G1 X106.776 Y137.572 E.0199
G1 X106.093 Y136.888 E.04049
G1 X105.953 Y137.224 E.01525
G1 X106.452 Y137.723 E.02956
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X105.953 Y137.224 E-.3352
G1 X106.093 Y136.888 E-.1729
G1 X106.776 Y137.572 E-.45914
G1 X107.251 Y137.572 E-.22563
G1 X106.794 Y137.115 E-.30713
;WIPE_END
G1 X106.793 Y137.622 F9000
G1 X108.506 Y90.378
G1 X109.5 Y90.379
G1 X109.733 Y90.379
G1 X109.874 Y88.135
G1 X109.97 Y86.615
G1 X109.847 Y85.135
G1 X110.05 Y85.338
G1 E5 F2400
;WIDTH:0.4
G1 F1200
G1 X104.278 Y85.328 E.24162
G1 X103.74 Y85.247 E.02277
G1 X103.221 Y85.087 E.02273
G1 X102.731 Y84.851 E.02277
G1 X102.282 Y84.544 E.02277
G1 X101.883 Y84.175 E.02275
G1 X101.544 Y83.749 E.02279
G1 X101.274 Y83.281 E.02262
G1 X101.003 Y82.506 E.03437
G1 X100.911 Y81.694 E.03421
G1 X100.911 Y78.294 E.14232
G1 X100.723 Y77.878 E.01911
G1 X100.639 Y77.562 E.01369
G1 X100.7 Y77.177 E.01632
G1 X130.3 Y77.176 E1.23906
G1 X130.327 Y77.253 E.00342
G1 X130.354 Y77.44 E.00791
G1 X130.284 Y77.842 E.01708
G1 X130.089 Y78.29 E.02045
G1 X130.089 Y81.258 E.12424
G1 X130.068 Y81.971 E.02986
G1 X129.987 Y82.507 E.02269
G1 X129.827 Y83.025 E.02269
G1 X129.592 Y83.514 E.02271
G1 X129.286 Y83.962 E.02271
G1 X128.918 Y84.359 E.02266
G1 X128.494 Y84.697 E.0227
G1 X128.024 Y84.969 E.02273
G1 X127.519 Y85.167 E.02271
G1 X126.991 Y85.287 E.02267
G1 X126.444 Y85.339 E.023
G1 X120.979 Y85.339 E.22877
G1 X120.833 Y85.149 E.01003
G1 X120.782 Y85.141 E.00216
G1 X110.218 Y85.141 E.44221
G1 X110.168 Y85.149 E.00212
G1 X110.082 Y85.287 E.00681
G1 E-5 F3600
G1 X110.082 Y85.287 F9000
G1 X109.847 Y85.135
G1 X109.847 Y84.938
G1 X130.048 Y77.907
G1 X130.074 Y77.852
G1 X130.165 Y77.894
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.400309
G1 F1200
G1 X129.699 Y77.428 E.02761
G1 X129.223 Y77.428 E.01994
G1 X129.887 Y78.092 E.03934
G1 X129.837 Y78.28 E.00815
G1 X129.837 Y78.517 E.00993
G1 X128.748 Y77.428 E.06453
G1 X128.273 Y77.428 E.0199
G1 X129.837 Y78.992 E.09267
G1 X129.837 Y79.467 E.0199
G1 X127.798 Y77.428 E.12082
G1 X127.323 Y77.428 E.0199
G1 X129.837 Y79.942 E.14896
G1 X129.837 Y80.417 E.0199
G1 X126.848 Y77.428 E.17711
G1 X126.373 Y77.428 E.0199
G1 X129.837 Y80.892 E.20526
G1 X129.837 Y81.367 E.0199
G1 X125.898 Y77.428 E.2334
G1 X125.423 Y77.428 E.0199
G1 X129.826 Y81.831 E.26089
G1 X129.784 Y82.265 E.01827
G1 X124.948 Y77.428 E.28658
G1 X124.473 Y77.428 E.0199
G1 X129.696 Y82.651 E.30948
G1 X129.567 Y82.998 E.01551
G1 X123.998 Y77.428 E.33001
G1 X123.523 Y77.428 E.0199
G1 X129.414 Y83.319 E.34906
G1 X129.238 Y83.619 E.01457
G1 X123.047 Y77.428 E.36684
G1 X122.572 Y77.428 E.0199
G1 X129.027 Y83.883 E.38248
G1 X128.797 Y84.128 E.01408
G1 X122.097 Y77.428 E.397
G1 X121.622 Y77.428 E.0199
G1 X128.549 Y84.355 E.41045
G1 X128.267 Y84.548 E.01432
G1 X121.147 Y77.428 E.42189
G1 X120.672 Y77.428 E.0199
G1 X127.963 Y84.719 E.43202
G1 X127.636 Y84.867 E.01504
G1 X120.197 Y77.428 E.44079
G1 X119.722 Y77.428 E.0199
G1 X127.273 Y84.979 E.44743
G1 X126.87 Y85.051 E.01715
G1 X119.247 Y77.428 E.45169
G1 X118.772 Y77.428 E.0199
G1 X126.431 Y85.087 E.45383
G1 X125.956 Y85.087 E.0199
G1 X118.297 Y77.428 E.45383
G1 X117.822 Y77.428 E.0199
G1 X125.48 Y85.087 E.4538
G1 X125.005 Y85.087 E.0199
G1 X117.347 Y77.428 E.4538
G1 X116.872 Y77.428 E.0199
G1 X124.53 Y85.087 E.4538
G1 X124.055 Y85.087 E.0199
G1 X116.396 Y77.428 E.45383
G1 X115.921 Y77.428 E.0199
G1 X123.58 Y85.087 E.45383
G1 X123.105 Y85.087 E.0199
G1 X115.446 Y77.428 E.45383
G1 X114.971 Y77.428 E.0199
G1 X122.63 Y85.087 E.45383
G1 X122.155 Y85.087 E.0199
G1 X114.496 Y77.428 E.45383
G1 X114.021 Y77.428 E.0199
G1 X121.68 Y85.087 E.45383
G1 X121.205 Y85.087 E.0199
G1 X113.546 Y77.428 E.45383
G1 X113.071 Y77.428 E.0199
G1 X120.532 Y84.89 E.44212
G1 X120.057 Y84.89 E.0199
G1 X112.596 Y77.428 E.44212
G1 X112.121 Y77.428 E.0199
G1 X119.582 Y84.89 E.44212
G1 X119.107 Y84.89 E.0199
G1 X111.646 Y77.428 E.44212
G1 X111.171 Y77.428 E.0199
G1 X118.632 Y84.89 E.44212
G1 X118.157 Y84.89 E.0199
G1 X110.696 Y77.428 E.44212
G1 X110.22 Y77.428 E.01994
G1 X117.682 Y84.89 E.44215
G1 X117.207 Y84.89 E.0199
G1 X109.745 Y77.428 E.44215
G1 X109.27 Y77.428 E.0199
G1 X116.732 Y84.89 E.44215
G1 X116.257 Y84.89 E.0199
G1 X108.795 Y77.428 E.44215
G1 X108.32 Y77.428 E.0199
G1 X115.782 Y84.89 E.44215
G1 X115.307 Y84.89 E.0199
G1 X107.845 Y77.428 E.44215
G1 X107.37 Y77.428 E.0199
G1 X114.832 Y84.89 E.44215
G1 X114.356 Y84.89 E.01994
G1 X106.895 Y77.428 E.44212
G1 X106.42 Y77.428 E.0199
G1 X113.881 Y84.89 E.44212
G1 X113.406 Y84.89 E.0199
G1 X105.945 Y77.428 E.44212
G1 X105.47 Y77.428 E.0199
G1 X112.931 Y84.89 E.44212
G1 X112.456 Y84.89 E.0199
G1 X104.995 Y77.428 E.44212
G1 X104.52 Y77.428 E.0199
G1 X111.981 Y84.89 E.44212
G1 X111.506 Y84.89 E.0199
G1 X104.045 Y77.428 E.44212
G1 X103.569 Y77.428 E.01994
G1 X111.031 Y84.89 E.44215
G1 X110.556 Y84.89 E.0199
G1 X103.094 Y77.428 E.44215
G1 X102.619 Y77.428 E.0199
G1 X110.084 Y84.893 E.44233
G1 X109.942 Y85.086 E.01004
G1 X109.802 Y85.086 E.00587
G1 X102.144 Y77.428 E.45377
G1 X101.669 Y77.428 E.0199
G1 X109.326 Y85.085 E.45371
G1 X108.85 Y85.084 E.01994
G1 X101.194 Y77.428 E.45365
G1 X100.908 Y77.428 E.01198
G1 X100.894 Y77.549 E.0051
G1 X100.909 Y77.618 E.00296
G1 X108.374 Y85.084 E.44236
G1 X107.898 Y85.083 E.01994
G1 X101.163 Y78.347 E.3991
G1 X101.163 Y78.822 E.0199
G1 X107.423 Y85.082 E.37093
G1 X106.947 Y85.081 E.01994
G1 X101.163 Y79.297 E.34272
G1 X101.163 Y79.773 E.01994
G1 X106.471 Y85.08 E.31449
G1 X105.995 Y85.079 E.01994
G1 X101.163 Y80.248 E.28628
G1 X101.163 Y80.723 E.0199
G1 X105.519 Y85.078 E.25808
G1 X105.043 Y85.078 E.01994
G1 X101.163 Y81.198 E.2299
G1 X101.163 Y81.673 E.0199
G1 X104.567 Y85.077 E.2017
G1 X104.297 Y85.076 E.01131
G1 X104.055 Y85.04 E.01025
G1 X101.21 Y82.195 E.16858
G1 X101.248 Y82.446 E.01064
G1 X101.389 Y82.849 E.01789
G1 X103.655 Y85.115 E.13427
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X101.422 Y82.882 E-1.5
;WIPE_END
G1 X101.337 Y82.912 F9000
G1 X102.313 Y84.303
G1 X103.746 Y86.59
G1 X104.635 Y88.407
G1 X104.886 Y88.407
G1 E5 F2400
;WIDTH:0.4
G1 F1200
G1 X104.9 Y88.377 E.00139
G1 X105.006 Y88.339 E.00471
G1 X125.994 Y88.339 E.87856
G1 X126.114 Y88.389 E.00544
G1 X126.161 Y88.506 E.00528
G1 X126.161 Y90.19 E.07049
G1 X126.198 Y90.521 E.01394
G1 X126.161 Y90.945 E.01782
G1 X126.161 Y93.098 E.09013
G1 X139.209 Y93.098 E.54619
G1 X139.419 Y93.145 E.00901
G1 X139.598 Y93.262 E.00895
G1 X139.846 Y93.262 E.01038
G1 X139.942 Y93.302 E.00435
G1 X140 Y93.429 E.00584
G1 X140 Y95.399 E.08246
G1 X139.942 Y95.527 E.00588
G1 X139.61 Y95.567 E.014
G1 X139.492 Y95.65 E.00604
G1 X139.209 Y95.731 E.01232
G1 X136.861 Y95.731 E.09829
G1 X136.859 Y132.813 E1.55226
G1 X136.823 Y133.464 E.02729
G1 X136.638 Y134.736 E.05381
G1 X136.484 Y135.362 E.02699
G1 X136.237 Y136.142 E.03425
G1 X135.862 Y137.04 E.04074
G1 X135.567 Y137.61 E.02687
G1 X135.146 Y138.311 E.03423
G1 X134.572 Y139.096 E.04071
G1 X134.152 Y139.582 E.02689
G1 X133.579 Y140.166 E.03425
G1 X132.839 Y140.796 E.04068
G1 X132.305 Y141.179 E.02751
G1 X131.199 Y141.834 E.05381
G1 X129.856 Y142.402 E.06104
G1 X129.224 Y142.594 E.02765
G1 X127.966 Y142.857 E.0538
G1 X126.994 Y142.95 E.04087
G1 X104.498 Y142.962 E.94169
G1 X103.536 Y142.916 E.04032
G1 X102.572 Y142.78 E.04075
G1 X101.772 Y142.593 E.03439
G1 X100.706 Y142.242 E.04698
G1 X99.94 Y141.901 E.0351
G1 X98.972 Y141.364 E.04634
G1 X98.283 Y140.886 E.0351
G1 X97.433 Y140.177 E.04633
G1 X96.845 Y139.579 E.03511
G1 X96.142 Y138.724 E.04634
G1 X95.684 Y138.039 E.03449
G1 X95.145 Y137.055 E.04697
G1 X94.768 Y136.157 E.04077
G1 X94.478 Y135.228 E.04074
G1 X94.208 Y133.796 E.061
G1 X94.138 Y132.911 E.03716
G1 X94.139 Y95.731 E1.55636
G1 X91.791 Y95.731 E.09829
G1 X91.582 Y95.683 E.00898
G1 X91.402 Y95.567 E.00896
G1 X91.154 Y95.566 E.01038
G1 X91.059 Y95.527 E.0043
G1 X91 Y95.399 E.0059
G1 X91 Y93.429 E.08246
G1 X91.059 Y93.302 E.00586
G1 X91.39 Y93.262 E.01396
G1 X91.509 Y93.178 E.0061
G1 X91.791 Y93.098 E.01227
G1 X101.736 Y93.098 E.4163
G1 X104.839 Y93.098 E.12989
G1 X104.839 Y90.81 E.09578
G1 X104.814 Y90.383 E.0179
G1 X104.839 Y88.506 E.07858
G1 X104.86 Y88.461 E.00208
G1 E-5 F3600
G1 X104.86 Y88.461 F9000
G1 X104.635 Y88.461
G1 X101.134 Y85.432
G1 X101.053 Y85.356
G1 X100.894 Y85.197
G1 X100.818 Y85.116
G1 X100.671 Y84.945
G1 X100.602 Y84.859
G1 X100.468 Y84.677
G1 X100.405 Y84.586
G1 X100.285 Y84.395
G1 X100.228 Y84.3
G1 X100.123 Y84.101
G1 X100.074 Y84.002
G1 X99.983 Y83.795
G1 X99.941 Y83.693
G1 X99.867 Y83.48
G1 X99.832 Y83.375
G1 X99.773 Y83.157
G1 X99.746 Y83.05
G1 X99.704 Y82.829
G1 X99.684 Y82.72
G1 X99.659 Y82.496
G1 X99.647 Y82.386
G1 X99.639 Y82.16
G1 X99.635 Y82.059
G1 X99.612 Y77.724
G1 X99.598 Y77.515
G1 X99.824 Y77.5
G1 E5 F2400
G1 F1200
G1 X99.818 Y77.355 E.00607
G1 X99.839 Y76.269 E.04547
G1 X99.906 Y76.135 E.00627
G1 X100.006 Y76.101 E.00442
G1 X130.994 Y76.101 E1.29717
G1 X131.094 Y76.135 E.00442
G1 X131.161 Y76.269 E.00627
G1 X131.161 Y77.19 E.03855
G1 X131.19 Y77.581 E.01641
G1 X131.161 Y78.777 E.05008
G1 X131.161 Y82.053 E.13713
G1 X131.116 Y82.678 E.02623
G1 X130.976 Y83.305 E.02689
G1 X130.747 Y83.905 E.02688
G1 X130.431 Y84.465 E.02692
G1 X130.037 Y84.971 E.02685
G1 X129.721 Y85.287 E.01871
G1 X129.235 Y85.667 E.02582
G1 X128.388 Y86.111 E.04003
G1 X127.803 Y86.291 E.02562
G1 X126.803 Y86.411 E.04216
G1 X104.197 Y86.411 E.94629
G1 X103.572 Y86.366 E.02623
G1 X103.03 Y86.245 E.02325
G1 X102.51 Y86.06 E.0231
G1 X101.785 Y85.681 E.03425
G1 X101.279 Y85.287 E.02685
G1 X100.773 Y84.746 E.03101
G1 X100.413 Y84.212 E.02696
G1 X100.136 Y83.632 E.02691
G1 X99.948 Y83.019 E.02684
G1 X99.839 Y82.053 E.04069
G1 X99.839 Y77.81 E.17761
G1 X99.827 Y77.56 E.01048
G1 E-5 F3600
G1 X99.827 Y77.56 F9000
G1 X99.827 Y74.372
G1 E5 F2400
G1 F1200
G1 X134.833 Y74.369 E1.46536
G1 X135.951 Y74.385 E.0468
G1 X136.605 Y74.481 E.02767
G1 X137.23 Y74.642 E.02702
G1 X137.839 Y74.87 E.02722
G1 X138.356 Y75.14 E.02442
G1 X139.013 Y75.59 E.03333
G1 X139.447 Y75.974 E.02426
G1 X140.117 Y76.765 E.04339
G1 X140.629 Y77.661 E.0432
G1 X140.97 Y78.635 E.0432
G1 X141.128 Y79.658 E.04333
G1 X141.128 Y80.039 E.01595
G1 X141.139 Y150.992 E2.97011
G1 X141.096 Y151.688 E.02919
G1 X140.97 Y152.365 E.02883
G1 X140.763 Y153.022 E.02883
G1 X140.477 Y153.649 E.02885
G1 X140.117 Y154.236 E.02882
G1 X139.687 Y154.775 E.02886
G1 X139.277 Y155.186 E.0243
G1 X138.445 Y155.807 E.04346
G1 X137.84 Y156.13 E.02871
G1 X137.197 Y156.377 E.02883
G1 X136.528 Y156.544 E.02886
G1 X135.845 Y156.628 E.02881
G1 X95.508 Y156.639 E1.68852
G1 X94.812 Y156.596 E.02919
G1 X94.135 Y156.47 E.02883
G1 X93.478 Y156.263 E.02883
G1 X92.851 Y155.977 E.02885
G1 X92.264 Y155.617 E.02882
G1 X91.725 Y155.187 E.02886
G1 X91.314 Y154.777 E.0243
G1 X90.693 Y153.945 E.04346
G1 X90.37 Y153.34 E.02871
G1 X90.123 Y152.697 E.02883
G1 X89.956 Y152.029 E.02882
G1 X89.869 Y151.237 E.03335
G1 X89.861 Y80.008 E2.98166
G1 X89.904 Y79.312 E.02919
G1 X90.03 Y78.635 E.02883
G1 X90.237 Y77.978 E.02883
G1 X90.523 Y77.351 E.02885
G1 X90.883 Y76.764 E.02882
G1 X91.313 Y76.225 E.02886
G1 X91.723 Y75.814 E.0243
G1 X92.555 Y75.193 E.04346
G1 X93.16 Y74.87 E.02871
G1 X93.803 Y74.623 E.02883
G1 X94.472 Y74.456 E.02886
G1 X95.155 Y74.372 E.02881
G1 X99.767 Y74.372 E.19306
G1 E-5 F3600
G1 X99.767 Y74.372 F9000
G1 X102.678 Y74.565
G1 X139.377 Y76.192
G1 X140.006 Y76.962
G1 X140.091 Y77.094
G1 X140.162 Y77.047
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.401179
G1 F1200
G1 X139.264 Y76.149 E.05335
G1 X138.858 Y75.789 E.02279
G1 X138.226 Y75.356 E.03218
G1 X137.742 Y75.103 E.02294
G1 X140.393 Y77.754 E.15749
G1 X140.653 Y78.49 E.03279
G1 X136.996 Y74.833 E.21725
G1 X136.806 Y74.774 E.00836
G1 X136.382 Y74.696 E.01811
G1 X140.787 Y79.101 E.26169
G1 X140.874 Y79.664 E.02393
G1 X135.839 Y74.629 E.29912
G1 X135.354 Y74.621 E.02038
G1 X140.876 Y80.142 E.32802
G1 X140.876 Y80.619 E.02004
G1 X134.878 Y74.621 E.35632
G1 X134.402 Y74.621 E.02
G1 X140.876 Y81.095 E.3846
G1 X140.876 Y81.571 E.02
G1 X133.926 Y74.621 E.41288
G1 X133.449 Y74.621 E.02004
G1 X140.876 Y82.048 E.44122
G1 X140.876 Y82.524 E.02
G1 X132.973 Y74.621 E.4695
G1 X132.497 Y74.621 E.02
G1 X140.877 Y83.001 E.49783
G1 X140.877 Y83.477 E.02
G1 X132.02 Y74.621 E.52614
G1 X131.544 Y74.621 E.02
G1 X140.877 Y83.953 E.55442
G1 X140.877 Y84.43 E.02004
G1 X131.068 Y74.621 E.58273
G1 X130.592 Y74.621 E.02
G1 X140.877 Y84.906 E.611
G1 X140.877 Y85.383 E.02004
G1 X130.115 Y74.621 E.63934
G1 X129.639 Y74.621 E.02
G1 X130.868 Y75.85 E.07301
G1 X131.007 Y75.85 E.00584
G1 X131.246 Y75.929 E.01057
G1 X131.382 Y76.104 E.00931
G1 X131.413 Y76.261 E.00672
G1 X131.413 Y76.395 E.00563
G1 X140.877 Y85.859 E.56223
G1 X140.877 Y86.335 E.02
G1 X131.413 Y76.871 E.56223
G1 X131.413 Y77.174 E.01273
G1 X131.438 Y77.373 E.00843
G1 X140.877 Y86.812 E.56075
G1 X140.877 Y87.288 E.02
G1 X131.413 Y77.824 E.56223
G1 X131.413 Y78.3 E.02
G1 X140.877 Y87.764 E.56223
G1 X140.877 Y88.241 E.02004
G1 X131.413 Y78.776 E.56226
G1 X131.413 Y79.252 E.02
G1 X140.877 Y88.717 E.56226
G1 X140.877 Y89.194 E.02004
G1 X131.413 Y79.729 E.56226
G1 X131.413 Y80.205 E.02
G1 X140.878 Y89.67 E.56229
G1 X140.878 Y90.146 E.02
G1 X131.412 Y80.681 E.56232
G1 X131.412 Y81.157 E.02
G1 X140.878 Y90.623 E.56235
G1 X140.878 Y91.099 E.02
G1 X131.412 Y81.633 E.56235
G1 X131.41 Y82.108 E.01995
G1 X140.878 Y91.575 E.56244
G1 X140.878 Y92.052 E.02004
G1 X131.376 Y82.55 E.56449
G1 X131.362 Y82.736 E.00784
G1 X131.311 Y82.962 E.00973
G1 X140.878 Y92.528 E.56832
G1 X140.878 Y93.005 E.02004
G1 X131.224 Y83.351 E.57352
G1 X131.093 Y83.696 E.0155
G1 X140.878 Y93.481 E.5813
G1 X140.878 Y93.957 E.02
G1 X130.961 Y84.04 E.58914
G1 X130.788 Y84.343 E.01466
G1 X139.31 Y92.865 E.50627
G1 X139.218 Y92.846 E.00395
G1 X138.814 Y92.846 E.01697
G1 X130.613 Y84.644 E.48723
G1 X130.403 Y84.911 E.01427
G1 X138.338 Y92.846 E.4714
G1 X137.862 Y92.846 E.02
G1 X130.191 Y85.175 E.45571
G1 X129.951 Y85.412 E.01417
G1 X137.385 Y92.846 E.44163
G1 X136.909 Y92.846 E.02
G1 X129.692 Y85.629 E.42874
G1 X129.425 Y85.838 E.01424
G1 X136.433 Y92.846 E.41633
G1 X135.956 Y92.846 E.02004
G1 X129.119 Y86.008 E.4062
G1 X128.805 Y86.171 E.01486
G1 X135.48 Y92.846 E.39654
G1 X135.004 Y92.846 E.02
G1 X128.492 Y86.334 E.38686
G1 X128.135 Y86.453 E.01581
G1 X134.527 Y92.846 E.37976
G1 X134.051 Y92.846 E.02
G1 X127.762 Y86.557 E.37361
G1 X127.335 Y86.606 E.01805
G1 X133.575 Y92.846 E.3707
G1 X133.099 Y92.846 E.02
G1 X126.907 Y86.654 E.36785
G1 X126.437 Y86.661 E.01975
G1 X132.622 Y92.846 E.36743
G1 X132.146 Y92.846 E.02
G1 X125.961 Y86.661 E.36743
G1 X125.485 Y86.661 E.02
G1 X131.67 Y92.846 E.36743
G1 X131.193 Y92.846 E.02004
G1 X125.009 Y86.661 E.3674
G1 X124.532 Y86.661 E.02004
G1 X130.717 Y92.846 E.36743
G1 X130.241 Y92.846 E.02
G1 X126.412 Y89.017 E.22747
G1 X126.412 Y89.494 E.02004
G1 X129.765 Y92.846 E.19916
G1 X129.288 Y92.846 E.02004
G1 X126.413 Y89.971 E.1708
G1 X126.413 Y90.174 E.00853
G1 X126.446 Y90.48 E.01293
G1 X128.812 Y92.846 E.14056
G1 X128.336 Y92.846 E.02
G1 X126.413 Y90.923 E.11424
G1 X126.413 Y91.4 E.02004
G1 X127.859 Y92.846 E.0859
G1 X127.383 Y92.846 E.02
G1 X126.413 Y91.876 E.05763
G1 X126.413 Y92.352 E.02
G1 X126.907 Y92.846 E.02935
G1 X126.431 Y92.846 E.02
G1 X126.262 Y92.678 E.01001
G1 E-5 F3600
G1 X126.262 Y92.678 F9000
G1 X126.365 Y92.678
G1 X126.403 Y90.5
G1 X126.365 Y88.135
G1 X125.633 Y88.135
G1 X125.633 Y88.238
G1 E5 F2400
G1 F1200
G1 X124.056 Y86.661 E.09369
G1 X123.58 Y86.661 E.02
G1 X125.005 Y88.087 E.08469
G1 X124.529 Y88.087 E.02
G1 X123.104 Y86.661 E.08469
G1 X122.627 Y86.661 E.02004
G1 X124.053 Y88.087 E.08471
G1 X123.577 Y88.087 E.02
G1 X122.151 Y86.661 E.08471
G1 X121.675 Y86.661 E.02
G1 X123.1 Y88.087 E.08469
G1 X122.624 Y88.087 E.02
G1 X121.198 Y86.661 E.08471
G1 X120.722 Y86.662 E.02
G1 X122.148 Y88.087 E.08469
G1 X121.671 Y88.087 E.02004
G1 X120.246 Y86.662 E.08466
G1 X119.77 Y86.662 E.02
G1 X121.195 Y88.087 E.08466
G1 X120.719 Y88.087 E.02
G1 X119.293 Y86.662 E.08469
G1 X118.817 Y86.662 E.02
G1 X120.242 Y88.087 E.08466
G1 X119.766 Y88.087 E.02
G1 X118.341 Y86.662 E.08466
G1 X117.865 Y86.662 E.02
G1 X119.29 Y88.087 E.08466
G1 X118.814 Y88.087 E.02
G1 X117.388 Y86.662 E.08469
G1 X116.912 Y86.662 E.02
G1 X118.337 Y88.087 E.08466
G1 X117.861 Y88.087 E.02
G1 X116.436 Y86.662 E.08466
G1 X115.96 Y86.662 E.02
G1 X117.385 Y88.087 E.08466
G1 X116.908 Y88.087 E.02004
G1 X115.483 Y86.662 E.08466
G1 X115.007 Y86.662 E.02
G1 X116.432 Y88.087 E.08466
G1 X115.956 Y88.087 E.02
G1 X114.531 Y86.662 E.08466
G1 X114.055 Y86.662 E.02
G1 X115.479 Y88.087 E.08463
G1 X115.003 Y88.087 E.02
G1 X113.578 Y86.662 E.08466
G1 X113.102 Y86.662 E.02
G1 X114.527 Y88.087 E.08466
G1 X114.05 Y88.087 E.02004
G1 X112.626 Y86.662 E.08463
G1 X112.15 Y86.662 E.02
G1 X113.574 Y88.087 E.08463
G1 X113.098 Y88.087 E.02
G1 X111.673 Y86.662 E.08466
G1 X111.197 Y86.662 E.02
G1 X112.622 Y88.087 E.08466
G1 X112.145 Y88.087 E.02004
G1 X110.721 Y86.662 E.08463
G1 X110.244 Y86.662 E.02004
G1 X111.669 Y88.087 E.08466
G1 X111.193 Y88.087 E.02
G1 X109.768 Y86.663 E.08463
G1 X109.292 Y86.663 E.02
G1 X110.716 Y88.087 E.0846
G1 X110.24 Y88.087 E.02
G1 X108.816 Y86.663 E.0846
G1 X108.339 Y86.663 E.02004
G1 X109.764 Y88.087 E.08463
G1 X109.287 Y88.087 E.02004
G1 X107.863 Y86.663 E.0846
G1 X107.387 Y86.663 E.02
G1 X108.811 Y88.087 E.0846
G1 X108.335 Y88.087 E.02
G1 X106.911 Y86.663 E.0846
G1 X106.434 Y86.663 E.02004
G1 X107.859 Y88.087 E.08463
G1 X107.382 Y88.087 E.02004
G1 X105.958 Y86.663 E.0846
G1 X105.482 Y86.663 E.02
G1 X106.906 Y88.087 E.0846
G1 X106.43 Y88.087 E.02
G1 X105.006 Y86.663 E.0846
G1 X104.529 Y86.663 E.02004
G1 X105.953 Y88.087 E.0846
G1 X105.477 Y88.087 E.02
G1 X104.042 Y86.652 E.08525
G1 X103.525 Y86.611 E.02179
G1 X105.001 Y88.087 E.08769
G1 X104.925 Y88.094 E.00321
G1 X104.718 Y88.198 E.00973
G1 X104.685 Y88.247 E.00248
G1 X102.662 Y86.225 E.12015
G1 E-5 F3600
G1 X102.662 Y86.225 F9000
G1 X102.625 Y86.333
G1 X90.797 Y93.058
G1 X90.797 Y95.77
G1 X91.709 Y95.927
G1 X91.739 Y95.931
G1 X91.775 Y95.934
G1 X92.658 Y95.936
G1 X93.336 Y95.935
G1 X93.693 Y95.935
G1 X93.693 Y95.832
G1 E5 F2400
G1 F1200
G1 X93.887 Y96.025 E.0115
G1 X93.887 Y96.502 E.02004
G1 X93.368 Y95.983 E.03083
G1 X92.892 Y95.983 E.02
G1 X93.887 Y96.978 E.05911
G1 X93.887 Y97.454 E.02
G1 X92.415 Y95.983 E.08742
G1 X91.939 Y95.983 E.02
G1 X94.038 Y98.082 E.1247
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X91.939 Y95.983 E-1.41001
G1 X92.129 Y95.983 E-.08999
;WIPE_END
G1 X92.129 Y95.935 F9000
G1 X91.775 Y95.934
G1 X91.739 Y95.931
G1 X91.709 Y95.927
G1 X90.797 Y95.77
G1 X90.797 Y93.058
G1 X108.19 Y86.615
G1 X126.809 Y86.615
G1 X126.91 Y86.611
G1 X127.136 Y86.603
G1 X127.246 Y86.591
G1 X127.47 Y86.566
G1 X127.579 Y86.546
G1 X127.8 Y86.504
G1 X127.907 Y86.477
G1 X128.125 Y86.418
G1 X128.23 Y86.383
G1 X128.443 Y86.309
G1 X128.545 Y86.267
G1 X128.752 Y86.176
G1 X128.851 Y86.127
G1 X129.05 Y86.022
G1 X129.145 Y85.965
G1 X129.336 Y85.845
G1 X129.427 Y85.782
G1 X129.609 Y85.648
G1 X129.695 Y85.579
G1 X129.866 Y85.432
G1 X129.947 Y85.356
G1 X130.106 Y85.197
G1 X130.182 Y85.116
G1 X130.329 Y84.945
G1 X130.398 Y84.859
G1 X130.532 Y84.677
G1 X130.595 Y84.586
G1 X130.715 Y84.395
G1 X130.772 Y84.3
G1 X130.877 Y84.101
G1 X130.926 Y84.002
G1 X131.017 Y83.795
G1 X131.059 Y83.693
G1 X131.133 Y83.48
G1 X131.168 Y83.375
G1 X131.227 Y83.157
G1 X131.254 Y83.05
G1 X131.296 Y82.829
G1 X131.316 Y82.72
G1 X131.341 Y82.496
G1 X131.353 Y82.386
G1 X131.361 Y82.16
G1 X131.365 Y82.059
G1 X131.403 Y77.5
G1 X131.365 Y75.898
G1 X128.145 Y75.898
G1 X126.561 Y75.9
G1 X128.85 Y74.565
G1 X129.012 Y74.47
G1 E5 F2400
G1 F1200
G1 X130.391 Y75.85 E.08195
G1 X129.915 Y75.85 E.02
G1 X128.687 Y74.621 E.07298
G1 X128.21 Y74.621 E.02004
G1 X129.439 Y75.85 E.07301
G1 X128.962 Y75.85 E.02004
G1 X127.734 Y74.621 E.07298
G1 X127.258 Y74.621 E.02
G1 X128.486 Y75.85 E.07298
G1 X128.01 Y75.85 E.02
G1 X126.782 Y74.621 E.07298
G1 X126.305 Y74.621 E.02004
G1 X127.534 Y75.85 E.07301
G1 X127.057 Y75.85 E.02004
G1 X125.829 Y74.621 E.07298
G1 X125.353 Y74.621 E.02
G1 X126.581 Y75.85 E.07298
G1 X126.105 Y75.85 E.02
G1 X124.877 Y74.621 E.07298
G1 X124.4 Y74.622 E.02004
G1 X125.628 Y75.85 E.07295
G1 X125.152 Y75.85 E.02
G1 X123.924 Y74.622 E.07295
G1 X123.448 Y74.622 E.02
G1 X124.676 Y75.85 E.07295
G1 X124.199 Y75.85 E.02004
G1 X122.971 Y74.622 E.07295
G1 X122.495 Y74.622 E.02
G1 X123.723 Y75.85 E.07295
G1 X123.247 Y75.85 E.02
G1 X122.019 Y74.622 E.07295
G1 X121.543 Y74.622 E.02
G1 X122.771 Y75.85 E.07295
G1 X122.294 Y75.85 E.02004
G1 X121.066 Y74.622 E.07295
G1 X120.59 Y74.622 E.02
G1 X121.818 Y75.85 E.07295
G1 X121.342 Y75.85 E.02
G1 X120.114 Y74.622 E.07295
G1 X119.638 Y74.622 E.02
G1 X120.865 Y75.85 E.07292
G1 X120.389 Y75.85 E.02
G1 X119.161 Y74.622 E.07295
G1 X118.685 Y74.622 E.02
G1 X119.913 Y75.85 E.07295
G1 X119.436 Y75.85 E.02004
G1 X118.209 Y74.622 E.07292
G1 X117.733 Y74.622 E.02
G1 X118.96 Y75.85 E.07292
G1 X118.484 Y75.85 E.02
G1 X117.256 Y74.622 E.07295
G1 X116.78 Y74.622 E.02
G1 X118.007 Y75.85 E.07292
G1 X117.531 Y75.85 E.02
G1 X116.304 Y74.622 E.07292
G1 X115.827 Y74.622 E.02004
G1 X117.055 Y75.85 E.07295
G1 X116.579 Y75.85 E.02
G1 X115.351 Y74.622 E.07295
G1 X114.875 Y74.622 E.02
G1 X116.102 Y75.85 E.07292
G1 X115.626 Y75.85 E.02
G1 X114.399 Y74.622 E.07292
G1 X113.922 Y74.622 E.02004
G1 X115.15 Y75.85 E.07295
G1 X114.673 Y75.85 E.02004
G1 X113.446 Y74.622 E.07292
G1 X112.97 Y74.622 E.02
G1 X114.197 Y75.85 E.07292
G1 X113.721 Y75.85 E.02
G1 X112.494 Y74.623 E.07289
G1 X112.017 Y74.623 E.02004
G1 X113.244 Y75.85 E.07289
G1 X112.768 Y75.85 E.02
G1 X111.541 Y74.623 E.07289
G1 X111.065 Y74.623 E.02
G1 X112.292 Y75.85 E.07289
G1 X111.816 Y75.85 E.02
G1 X110.589 Y74.623 E.07289
G1 X110.112 Y74.623 E.02004
G1 X111.339 Y75.85 E.07289
G1 X110.863 Y75.85 E.02
G1 X109.636 Y74.623 E.07289
G1 X109.16 Y74.623 E.02
G1 X110.387 Y75.85 E.07289
G1 X109.91 Y75.85 E.02004
G1 X108.684 Y74.623 E.07286
G1 X108.207 Y74.623 E.02004
G1 X109.434 Y75.85 E.07289
G1 X108.958 Y75.85 E.02
G1 X107.731 Y74.623 E.07289
G1 X107.255 Y74.623 E.02
G1 X108.481 Y75.85 E.07286
G1 X108.005 Y75.85 E.02
G1 X106.778 Y74.623 E.07289
G1 X106.302 Y74.623 E.02
G1 X107.529 Y75.85 E.07289
G1 X107.052 Y75.85 E.02004
G1 X105.826 Y74.623 E.07286
G1 X105.35 Y74.623 E.02
G1 X106.576 Y75.85 E.07286
G1 X106.1 Y75.85 E.02
G1 X104.873 Y74.623 E.07289
G1 X104.397 Y74.623 E.02
G1 X105.624 Y75.85 E.07289
G1 X105.147 Y75.85 E.02004
G1 X103.921 Y74.623 E.07286
G1 X103.445 Y74.623 E.02
G1 X104.671 Y75.85 E.07286
G1 X104.195 Y75.85 E.02
G1 X102.968 Y74.623 E.07289
G1 X102.492 Y74.623 E.02
G1 X103.718 Y75.85 E.07286
G1 X103.242 Y75.85 E.02
G1 X102.016 Y74.623 E.07286
G1 X101.54 Y74.623 E.02
G1 X102.766 Y75.85 E.07286
G1 X102.289 Y75.85 E.02004
G1 X101.063 Y74.623 E.07286
G1 X100.587 Y74.624 E.02
G1 X101.813 Y75.85 E.07283
G1 X101.337 Y75.85 E.02
G1 X100.111 Y74.624 E.07283
G1 X99.635 Y74.624 E.02
G1 X100.861 Y75.85 E.07283
G1 X100.384 Y75.85 E.02004
G1 X99.158 Y74.624 E.07283
G1 X98.682 Y74.624 E.02
G1 X99.918 Y75.86 E.07343
G1 X99.752 Y75.932 E.0076
G1 X99.648 Y76.066 E.00713
G1 X98.206 Y74.624 E.08567
G1 X97.729 Y74.624 E.02004
G1 X99.587 Y76.481 E.11035
G1 X99.587 Y76.958 E.02004
G1 X97.253 Y74.624 E.13866
G1 X96.777 Y74.624 E.02
G1 X99.564 Y77.411 E.16557
G1 X99.551 Y77.543 E.00557
G1 X99.587 Y77.91 E.01549
G1 X96.301 Y74.624 E.19521
G1 X95.824 Y74.624 E.02004
G1 X99.587 Y78.387 E.22355
G1 X99.587 Y78.863 E.02
G1 X95.348 Y74.624 E.25183
G1 X95.171 Y74.624 E.00744
G1 X94.905 Y74.657 E.01126
G1 X99.587 Y79.339 E.27814
G1 X99.587 Y79.815 E.02
G1 X94.484 Y74.713 E.30313
G1 X94.103 Y74.808 E.01649
G1 X99.587 Y80.292 E.32579
G1 X99.587 Y80.768 E.02
G1 X93.737 Y74.918 E.34753
G1 X93.393 Y75.05 E.01548
G1 X99.587 Y81.244 E.36797
G1 X99.587 Y81.721 E.02004
G1 X93.07 Y75.204 E.38716
G1 X92.759 Y75.369 E.01479
G1 X99.605 Y82.215 E.4067
G1 X99.667 Y82.753 E.02275
G1 X92.478 Y75.564 E.42708
G1 X92.205 Y75.768 E.01432
G1 X100.016 Y83.579 E.46403
G1 E-5 F3600
G1 X100.016 Y83.579 F9000
G1 X99.914 Y83.615
G1 X99.941 Y83.693
G1 X99.983 Y83.795
G1 X100.074 Y84.002
G1 X100.123 Y84.101
G1 X100.228 Y84.3
G1 X100.285 Y84.395
G1 X100.405 Y84.586
G1 X100.468 Y84.677
G1 X100.602 Y84.859
G1 X100.671 Y84.945
G1 X100.818 Y85.116
G1 X100.894 Y85.197
G1 X101.053 Y85.356
G1 X101.134 Y85.432
G1 X101.305 Y85.579
G1 X101.391 Y85.648
G1 X101.573 Y85.782
G1 X101.664 Y85.845
G1 X101.855 Y85.965
G1 X101.95 Y86.022
G1 X102.149 Y86.127
G1 X102.248 Y86.176
G1 X102.459 Y86.269
G1 X104.635 Y88.777
G1 X104.738 Y88.777
G1 E5 F2400
G1 F1200
G1 X102.116 Y86.155 E.15577
G1 X101.656 Y85.897 E.02216
G1 X101.079 Y85.445 E.03079
G1 X100.584 Y84.912 E.03056
G1 X100.199 Y84.344 E.02882
G1 X100.1 Y84.139 E.00956
G1 X91.933 Y75.972 E.48518
G1 X91.689 Y76.204 E.01414
G1 X104.587 Y89.102 E.76624
G1 X104.587 Y89.578 E.02
G1 X91.457 Y76.448 E.78002
G1 X91.245 Y76.713 E.01426
G1 X104.587 Y90.055 E.79261
G1 X104.556 Y90.5 E.01874
G1 X91.042 Y76.986 E.80283
G1 X90.861 Y77.281 E.01454
G1 X104.587 Y91.007 E.81542
G1 X104.587 Y91.484 E.02004
G1 X90.691 Y77.588 E.82552
G1 X90.542 Y77.915 E.0151
G1 X104.587 Y91.96 E.83438
G1 X104.587 Y92.436 E.02
G1 X90.412 Y78.261 E.8421
G1 X90.297 Y78.623 E.01596
G1 X104.52 Y92.846 E.84495
G1 X104.044 Y92.846 E.02
G1 X90.215 Y79.017 E.82154
G1 X90.149 Y79.427 E.01744
G1 X103.568 Y92.846 E.79719
G1 X103.091 Y92.846 E.02004
G1 X90.122 Y79.876 E.77048
G1 X90.113 Y80.344 E.01966
G1 X102.615 Y92.846 E.74271
G1 X102.139 Y92.846 E.02
G1 X90.113 Y80.82 E.71443
G1 X90.113 Y81.297 E.02004
G1 X101.663 Y92.846 E.68612
G1 X101.186 Y92.846 E.02004
G1 X90.113 Y81.773 E.65782
G1 X90.113 Y82.249 E.02
G1 X100.71 Y92.846 E.62954
G1 X100.234 Y92.846 E.02
G1 X90.113 Y82.726 E.60123
G1 X90.113 Y83.202 E.02
G1 X99.757 Y92.846 E.57292
G1 X99.281 Y92.846 E.02
G1 X90.113 Y83.678 E.54465
G1 X90.113 Y84.155 E.02004
G1 X98.805 Y92.846 E.51634
G1 X98.328 Y92.846 E.02004
G1 X90.114 Y84.631 E.488
G1 X90.114 Y85.107 E.02
G1 X97.852 Y92.846 E.45972
G1 X97.376 Y92.846 E.02
G1 X90.114 Y85.584 E.43142
G1 X90.114 Y86.06 E.02
G1 X96.899 Y92.846 E.40311
G1 X96.423 Y92.846 E.02
G1 X90.114 Y86.537 E.3748
G1 X90.114 Y87.013 E.02
G1 X95.947 Y92.846 E.34652
G1 X95.47 Y92.846 E.02004
G1 X90.114 Y87.489 E.31822
G1 X90.114 Y87.966 E.02004
G1 X94.994 Y92.846 E.28991
G1 X94.518 Y92.846 E.02
G1 X90.114 Y88.442 E.26163
G1 X90.114 Y88.918 E.02
G1 X94.042 Y92.846 E.23335
G1 X93.565 Y92.846 E.02004
G1 X90.114 Y89.395 E.20501
G1 X90.114 Y89.871 E.02
G1 X93.089 Y92.846 E.17674
G1 X92.613 Y92.846 E.02
G1 X90.114 Y90.347 E.14846
G1 X90.114 Y90.824 E.02004
G1 X92.136 Y92.846 E.12012
G1 X91.78 Y92.846 E.01495
G1 X91.686 Y92.871 E.00409
G1 X90.114 Y91.3 E.09336
G1 X90.114 Y91.776 E.02
G1 X91.331 Y92.993 E.0723
G1 X91.304 Y93.01 E.00134
G1 X91.124 Y93.011 E.00756
G1 X90.946 Y93.085 E.0081
G1 X90.114 Y92.253 E.04943
G1 X90.114 Y92.729 E.02
G1 X90.763 Y93.378 E.03856
G1 X90.748 Y93.411 E.00152
G1 X90.748 Y93.839 E.01798
G1 X90.114 Y93.205 E.03766
G1 X90.114 Y93.682 E.02004
G1 X90.748 Y94.316 E.03766
G1 X90.748 Y94.792 E.02
G1 X90.115 Y94.158 E.03763
G1 X90.115 Y94.635 E.02004
G1 X90.748 Y95.268 E.0376
G1 X90.755 Y95.483 E.00904
G1 X90.891 Y95.721 E.01151
G1 X91.123 Y95.817 E.01055
G1 X91.298 Y95.818 E.00735
G1 X93.887 Y98.407 E.15381
G1 X93.887 Y98.883 E.02
G1 X90.115 Y95.111 E.22408
G1 X90.115 Y95.587 E.02
G1 X93.887 Y99.359 E.22408
G1 X93.887 Y99.836 E.02004
G1 X90.115 Y96.064 E.22408
G1 X90.115 Y96.54 E.02
G1 X93.887 Y100.312 E.22408
G1 X93.887 Y100.788 E.02
G1 X90.115 Y97.016 E.22408
G1 X90.115 Y97.493 E.02004
G1 X93.887 Y101.265 E.22408
G1 X93.887 Y101.741 E.02
G1 X90.115 Y97.969 E.22408
G1 X90.115 Y98.445 E.02
G1 X93.887 Y102.217 E.22408
G1 X93.887 Y102.694 E.02004
G1 X90.115 Y98.922 E.22408
G1 X90.115 Y99.398 E.02
G1 X93.887 Y103.17 E.22408
G1 X93.887 Y103.646 E.02
G1 X90.115 Y99.874 E.22408
G1 X90.115 Y100.351 E.02004
G1 X93.887 Y104.122 E.22405
G1 X93.887 Y104.599 E.02004
G1 X90.115 Y100.827 E.22408
G1 X90.115 Y101.304 E.02004
G1 X93.887 Y105.075 E.22405
G1 X93.887 Y105.551 E.02
G1 X90.115 Y101.78 E.22405
G1 X90.115 Y102.256 E.02
G1 X93.887 Y106.028 E.22408
G1 X93.887 Y106.504 E.02
G1 X90.115 Y102.733 E.22405
G1 X90.115 Y103.209 E.02
G1 X93.887 Y106.98 E.22405
G1 X93.887 Y107.457 E.02004
G1 X90.116 Y103.685 E.22405
G1 X90.116 Y104.162 E.02004
G1 X93.887 Y107.933 E.22402
G1 X93.887 Y108.409 E.02
G1 X90.116 Y104.638 E.22402
G1 X90.116 Y105.114 E.02
G1 X93.887 Y108.885 E.22402
G1 X93.887 Y109.362 E.02004
G1 X90.116 Y105.591 E.22402
G1 X90.116 Y106.067 E.02
G1 X93.887 Y109.838 E.22402
G1 X93.887 Y110.314 E.02
G1 X90.116 Y106.543 E.22402
G1 X90.116 Y107.02 E.02004
G1 X93.887 Y110.791 E.22402
G1 X93.887 Y111.267 E.02
G1 X90.116 Y107.496 E.22402
G1 X90.116 Y107.972 E.02
G1 X93.887 Y111.743 E.22402
G1 X93.887 Y112.219 E.02
G1 X90.116 Y108.449 E.224
G1 X90.116 Y108.925 E.02
G1 X93.887 Y112.696 E.22402
G1 X93.887 Y113.172 E.02
G1 X90.116 Y109.402 E.224
G1 X90.116 Y109.878 E.02
G1 X93.887 Y113.648 E.224
G1 X93.887 Y114.125 E.02004
G1 X90.116 Y110.354 E.22402
G1 X90.116 Y110.831 E.02004
G1 X93.887 Y114.601 E.224
G1 X93.887 Y115.077 E.02
G1 X90.116 Y111.307 E.224
G1 X90.116 Y111.783 E.02
G1 X93.887 Y115.554 E.22402
G1 X93.887 Y116.03 E.02
G1 X90.116 Y112.26 E.224
G1 X90.116 Y112.736 E.02
G1 X93.887 Y116.506 E.224
G1 X93.887 Y116.982 E.02
G1 X90.117 Y113.212 E.22397
G1 X90.117 Y113.689 E.02004
G1 X93.887 Y117.459 E.22397
G1 X93.887 Y117.935 E.02
G1 X90.117 Y114.165 E.22397
G1 X90.117 Y114.641 E.02
G1 X93.887 Y118.411 E.22397
G1 X93.887 Y118.888 E.02004
G1 X90.117 Y115.118 E.22397
G1 X90.117 Y115.594 E.02
G1 X93.887 Y119.364 E.22397
G1 X93.887 Y119.84 E.02
G1 X90.117 Y116.071 E.22394
G1 X90.117 Y116.547 E.02
G1 X93.887 Y120.317 E.22397
G1 X93.887 Y120.793 E.02
G1 X90.117 Y117.023 E.22397
G1 X90.117 Y117.5 E.02004
G1 X93.887 Y121.269 E.22394
G1 X93.887 Y121.745 E.02
G1 X90.117 Y117.976 E.22394
G1 X90.117 Y118.452 E.02
G1 X93.887 Y122.222 E.22397
G1 X93.887 Y122.698 E.02
G1 X90.117 Y118.929 E.22394
G1 X90.117 Y119.405 E.02
G1 X93.887 Y123.174 E.22394
G1 X93.886 Y123.651 E.02004
G1 X90.117 Y119.881 E.22394
G1 X90.117 Y120.358 E.02004
G1 X93.886 Y124.127 E.22391
G1 X93.886 Y124.603 E.02
G1 X90.117 Y120.834 E.22391
G1 X90.117 Y121.31 E.02
G1 X93.886 Y125.079 E.22391
G1 X93.886 Y125.556 E.02004
G1 X90.117 Y121.787 E.22391
G1 X90.118 Y122.263 E.02
G1 X93.886 Y126.032 E.22388
G1 X93.886 Y126.508 E.02
G1 X90.118 Y122.739 E.22388
G1 X90.118 Y123.216 E.02004
G1 X93.886 Y126.985 E.22388
G1 X93.886 Y127.461 E.02
G1 X90.118 Y123.692 E.22388
G1 X90.118 Y124.169 E.02004
G1 X93.886 Y127.937 E.22385
G1 X93.886 Y128.414 E.02004
G1 X90.118 Y124.645 E.22388
G1 X90.118 Y125.121 E.02
G1 X93.886 Y128.89 E.22388
G1 X93.886 Y129.366 E.02
G1 X90.118 Y125.598 E.22385
G1 X90.118 Y126.074 E.02
G1 X93.886 Y129.842 E.22385
G1 X93.886 Y130.319 E.02004
G1 X90.118 Y126.55 E.22388
G1 X90.118 Y127.027 E.02004
G1 X93.886 Y130.795 E.22385
G1 X93.886 Y131.271 E.02
G1 X90.118 Y127.503 E.22385
G1 X90.118 Y127.979 E.02
G1 X93.886 Y131.748 E.22388
G1 X93.886 Y132.224 E.02
G1 X90.118 Y128.456 E.22385
G1 X90.118 Y128.932 E.02
G1 X93.886 Y132.7 E.22385
G1 X93.909 Y133.199 E.02098
G1 X90.118 Y129.408 E.22521
G1 X90.118 Y129.885 E.02004
G1 X93.95 Y133.717 E.22765
G1 X94.044 Y134.287 E.02427
G1 X90.118 Y130.361 E.23323
G1 X90.118 Y130.838 E.02004
G1 X94.154 Y134.873 E.23974
G1 X94.226 Y135.26 E.01654
G1 X94.299 Y135.494 E.0103
G1 X90.118 Y131.314 E.24835
G1 X90.119 Y131.79 E.02
G1 X94.513 Y136.184 E.26104
G1 X94.849 Y136.997 E.03695
G1 X90.119 Y132.267 E.281
G1 X90.119 Y132.743 E.02
G1 X95.866 Y138.49 E.34141
G1 E-5 F3600
G1 X95.866 Y138.49 F9000
G1 X95.775 Y138.553
G1 X95.972 Y138.837
G1 X96.274 Y139.23
G1 X96.595 Y139.609
G1 X96.932 Y139.972
G1 X97.287 Y140.32
G1 X97.657 Y140.65
G1 X98.043 Y140.962
G1 X98.442 Y141.256
G1 X98.856 Y141.531
G1 X99.281 Y141.786
G1 X99.718 Y142.021
G1 X100.166 Y142.235
G1 X100.623 Y142.428
G1 X101.089 Y142.599
G1 X101.562 Y142.748
G1 X102.042 Y142.875
G1 X102.527 Y142.979
G1 X103.016 Y143.06
G1 X103.509 Y143.119
G1 X104.004 Y143.154
G1 X104.494 Y143.165
G1 X126.506 Y143.165
G1 X126.996 Y143.154
G1 X127.491 Y143.119
G1 X127.984 Y143.06
G1 X128.473 Y142.979
G1 X128.958 Y142.875
G1 X129.438 Y142.748
G1 X129.911 Y142.599
G1 X130.377 Y142.428
G1 X130.834 Y142.235
G1 X131.282 Y142.021
G1 X131.719 Y141.786
G1 X132.144 Y141.531
G1 X132.558 Y141.256
G1 X132.957 Y140.962
G1 X133.343 Y140.65
G1 X133.713 Y140.32
G1 X134.068 Y139.972
G1 X134.405 Y139.609
G1 X134.726 Y139.23
G1 X135.028 Y138.837
G1 X135.311 Y138.429
G1 X135.575 Y138.009
G1 X135.819 Y137.577
G1 X136.043 Y137.134
G1 X136.245 Y136.681
G1 X136.426 Y136.219
G1 X136.585 Y135.749
G1 X136.722 Y135.272
G1 X136.836 Y134.789
G1 X136.927 Y134.301
G1 X136.996 Y133.81
G1 X137.041 Y133.316
G1 X140.204 Y95.77
G1 X140.204 Y95.387
G1 X140.935 Y94.676
G1 X141.029 Y94.585
G1 E5 F2400
G1 F1200
G1 X140.252 Y93.808 E.04616
G1 X140.252 Y94.284 E.02
G1 X140.878 Y94.91 E.03719
G1 X140.878 Y95.386 E.02
G1 X140.252 Y94.76 E.03719
G1 X140.252 Y95.236 E.02
G1 X140.879 Y95.863 E.03725
G1 X140.879 Y96.339 E.02
G1 X140.164 Y95.625 E.04245
G1 X140.109 Y95.721 E.00465
G1 X139.879 Y95.816 E.01045
G1 X140.879 Y96.816 E.05941
G1 X140.879 Y97.292 E.02
G1 X139.496 Y95.909 E.08216
G1 X139.22 Y95.983 E.012
G1 X139.093 Y95.983 E.00533
G1 X140.879 Y97.768 E.10607
G1 X140.879 Y98.245 E.02004
G1 X138.617 Y95.983 E.13438
G1 X138.14 Y95.983 E.02004
G1 X140.879 Y98.721 E.16269
G1 X140.879 Y99.197 E.02
G1 X137.664 Y95.983 E.19096
G1 X137.188 Y95.983 E.02
G1 X140.879 Y99.674 E.21927
G1 X140.879 Y100.15 E.02
G1 X137.113 Y96.384 E.22373
G1 X137.113 Y96.86 E.02
G1 X140.879 Y100.627 E.22376
G1 X140.879 Y101.103 E.02
G1 X137.113 Y97.337 E.22373
G1 X137.113 Y97.813 E.02
G1 X140.879 Y101.579 E.22373
G1 X140.879 Y102.056 E.02004
G1 X137.113 Y98.289 E.22376
G1 X137.113 Y98.765 E.02
G1 X140.88 Y102.532 E.22379
G1 X140.88 Y103.008 E.02
G1 X137.113 Y99.242 E.22376
G1 X137.113 Y99.718 E.02
G1 X140.88 Y103.485 E.22379
G1 X140.88 Y103.961 E.02
G1 X137.113 Y100.194 E.22379
G1 X137.113 Y100.671 E.02004
G1 X140.88 Y104.438 E.22379
G1 X140.88 Y104.914 E.02
G1 X137.113 Y101.147 E.22379
G1 X137.113 Y101.623 E.02
G1 X140.88 Y105.39 E.22379
G1 X140.88 Y105.867 E.02004
G1 X137.113 Y102.099 E.22382
G1 X137.113 Y102.576 E.02004
G1 X140.88 Y106.343 E.22379
G1 X140.88 Y106.82 E.02004
G1 X137.113 Y103.052 E.22382
G1 X137.113 Y103.528 E.02
G1 X140.88 Y107.296 E.22382
G1 X140.88 Y107.772 E.02
G1 X137.113 Y104.004 E.22382
G1 X137.113 Y104.481 E.02004
G1 X140.88 Y108.249 E.22382
G1 X140.88 Y108.725 E.02
G1 X137.112 Y104.957 E.22385
G1 X137.112 Y105.433 E.02
G1 X140.881 Y109.201 E.22388
G1 X140.881 Y109.678 E.02004
G1 X137.112 Y105.91 E.22388
G1 X137.112 Y106.386 E.02
G1 X140.881 Y110.154 E.22388
G1 X140.881 Y110.631 E.02004
G1 X137.112 Y106.862 E.22391
G1 X137.112 Y107.338 E.02
G1 X140.881 Y111.107 E.22391
G1 X140.881 Y111.583 E.02
G1 X137.112 Y107.815 E.22388
G1 X137.112 Y108.291 E.02
G1 X140.881 Y112.06 E.22391
G1 X140.881 Y112.536 E.02
G1 X137.112 Y108.767 E.22391
G1 X137.112 Y109.244 E.02004
G1 X140.881 Y113.012 E.22388
G1 X140.881 Y113.489 E.02004
G1 X137.112 Y109.72 E.22391
G1 X137.112 Y110.196 E.02
G1 X140.881 Y113.965 E.22391
G1 X140.881 Y114.442 E.02004
G1 X137.112 Y110.672 E.22394
G1 X137.112 Y111.149 E.02004
G1 X140.881 Y114.918 E.22391
G1 X140.882 Y115.394 E.02
G1 X137.112 Y111.625 E.22394
G1 X137.112 Y112.101 E.02
G1 X140.882 Y115.871 E.22397
G1 X140.882 Y116.347 E.02
G1 X137.112 Y112.577 E.22397
G1 X137.112 Y113.054 E.02004
G1 X140.882 Y116.823 E.22394
G1 X140.882 Y117.3 E.02004
G1 X137.112 Y113.53 E.22397
G1 X137.112 Y114.006 E.02
G1 X140.882 Y117.776 E.22397
G1 X140.882 Y118.253 E.02004
G1 X137.112 Y114.483 E.22397
G1 X137.112 Y114.959 E.02
G1 X140.882 Y118.729 E.22397
G1 X140.882 Y119.205 E.02
G1 X137.112 Y115.435 E.22397
G1 X137.112 Y115.911 E.02
G1 X140.882 Y119.682 E.224
G1 X140.882 Y120.158 E.02
G1 X137.112 Y116.388 E.22397
G1 X137.112 Y116.864 E.02
G1 X140.882 Y120.634 E.22397
G1 X140.882 Y121.111 E.02004
G1 X137.112 Y117.34 E.224
G1 X137.112 Y117.816 E.02
G1 X140.882 Y121.587 E.224
G1 X140.883 Y122.064 E.02004
G1 X137.112 Y118.293 E.22402
G1 X137.112 Y118.769 E.02
G1 X140.883 Y122.54 E.22402
G1 X140.883 Y123.016 E.02
G1 X137.112 Y119.245 E.22402
G1 X137.112 Y119.722 E.02004
G1 X140.883 Y123.493 E.22402
G1 X140.883 Y123.969 E.02
G1 X137.112 Y120.198 E.22402
G1 X137.112 Y120.674 E.02
G1 X140.883 Y124.445 E.22402
G1 X140.883 Y124.922 E.02004
G1 X137.112 Y121.15 E.22405
G1 X137.112 Y121.627 E.02004
G1 X140.883 Y125.398 E.22402
G1 X140.883 Y125.875 E.02004
G1 X137.111 Y122.103 E.22408
G1 X137.111 Y122.579 E.02
G1 X140.883 Y126.351 E.22408
G1 X140.883 Y126.827 E.02
G1 X137.111 Y123.056 E.22405
G1 X137.111 Y123.532 E.02
G1 X140.883 Y127.304 E.22408
G1 X140.883 Y127.78 E.02
G1 X137.111 Y124.008 E.22408
G1 X137.111 Y124.484 E.02
G1 X140.883 Y128.256 E.22408
G1 X140.884 Y128.733 E.02004
G1 X137.111 Y124.961 E.22411
G1 X137.111 Y125.437 E.02
G1 X140.884 Y129.209 E.22411
G1 X140.884 Y129.686 E.02004
G1 X137.111 Y125.913 E.22414
G1 X137.111 Y126.389 E.02
G1 X140.884 Y130.162 E.22414
G1 X140.884 Y130.638 E.02
G1 X137.111 Y126.866 E.22411
G1 X137.111 Y127.342 E.02
G1 X140.884 Y131.115 E.22414
G1 X140.884 Y131.591 E.02
G1 X137.111 Y127.818 E.22414
G1 X137.111 Y128.295 E.02004
G1 X140.884 Y132.068 E.22414
G1 X140.884 Y132.544 E.02
G1 X137.111 Y128.771 E.22414
G1 X137.111 Y129.247 E.02
G1 X140.884 Y133.02 E.22414
G1 X140.884 Y133.497 E.02004
G1 X137.111 Y129.723 E.22417
G1 X137.111 Y130.2 E.02004
G1 X140.884 Y133.973 E.22414
G1 X140.884 Y134.449 E.02
G1 X137.111 Y130.676 E.22414
G1 X137.111 Y131.152 E.02
G1 X140.885 Y134.926 E.2242
G1 X140.885 Y135.402 E.02
G1 X137.111 Y131.629 E.22417
G1 X137.111 Y132.105 E.02
G1 X140.885 Y135.879 E.2242
G1 X140.885 Y136.355 E.02
G1 X137.111 Y132.581 E.2242
G1 X137.098 Y133.044 E.01946
G1 X140.885 Y136.831 E.22498
G1 X140.885 Y137.308 E.02004
G1 X137.072 Y133.495 E.22652
G1 X137.012 Y133.911 E.01766
G1 X140.885 Y137.784 E.23008
G1 X140.885 Y138.26 E.02
G1 X136.952 Y134.327 E.23365
G1 X136.892 Y134.743 E.01766
G1 X140.885 Y138.737 E.23724
G1 X140.885 Y139.213 E.02
G1 X136.801 Y135.129 E.24262
G1 X136.703 Y135.507 E.0164
G1 X140.885 Y139.69 E.24847
G1 X140.885 Y140.166 E.02
G1 X136.588 Y135.868 E.2553
G1 X136.473 Y136.23 E.01596
G1 X140.885 Y140.642 E.26211
G1 X140.885 Y141.119 E.02004
G1 X136.332 Y136.565 E.27051
G1 X136.192 Y136.901 E.01529
G1 X140.886 Y141.595 E.27886
G1 X140.886 Y142.071 E.02
G1 X136.046 Y137.232 E.2875
G1 X135.883 Y137.546 E.01486
G1 X140.886 Y142.548 E.29719
G1 X140.886 Y143.024 E.02
G1 X135.715 Y137.853 E.3072
G1 X135.536 Y138.151 E.0146
G1 X140.886 Y143.501 E.31783
G1 X140.886 Y143.977 E.02
G1 X135.356 Y138.448 E.32849
G1 X135.156 Y138.723 E.01428
G1 X140.886 Y144.453 E.3404
G1 X140.886 Y144.93 E.02004
G1 X134.955 Y138.998 E.35237
G1 X134.752 Y139.272 E.01432
G1 X140.886 Y145.406 E.3644
G1 X140.886 Y145.882 E.02
G1 X134.531 Y139.528 E.3775
G1 X134.309 Y139.782 E.01417
G1 X140.886 Y146.359 E.39072
G1 X140.886 Y146.835 E.02
G1 X134.073 Y140.022 E.40474
G1 X133.837 Y140.262 E.01414
G1 X140.886 Y147.312 E.41879
G1 X140.886 Y147.788 E.02
G1 X133.587 Y140.489 E.43361
G1 X133.33 Y140.708 E.01418
G1 X140.887 Y148.264 E.44891
G1 X140.887 Y148.741 E.02004
G1 X133.073 Y140.927 E.46421
G1 X132.802 Y141.132 E.01427
G1 X140.887 Y149.217 E.48031
G1 X140.887 Y149.693 E.02
G1 X132.524 Y141.331 E.49679
G1 X132.232 Y141.515 E.0145
G1 X140.887 Y150.17 E.51417
G1 X140.887 Y150.646 E.02
G1 X131.932 Y141.691 E.53199
G1 X131.632 Y141.868 E.01463
G1 X140.879 Y151.115 E.54934
G1 X140.852 Y151.563 E.01885
G1 X131.333 Y142.044 E.5655
G1 X131.004 Y142.192 E.01515
G1 X140.787 Y151.975 E.58118
G1 X140.705 Y152.37 E.01695
G1 X130.669 Y142.333 E.59624
G1 X130.334 Y142.474 E.01527
G1 X140.591 Y152.732 E.60937
G1 X140.461 Y153.078 E.01553
G1 X129.999 Y142.616 E.62152
G1 X129.638 Y142.732 E.01593
G1 X140.312 Y153.405 E.63408
G1 X140.143 Y153.712 E.01472
G1 X129.271 Y142.84 E.64588
G1 X128.877 Y142.923 E.01691
G1 X139.962 Y154.008 E.65853
G1 X139.759 Y154.281 E.01429
G1 X128.483 Y143.006 E.66985
G1 X128.089 Y143.088 E.01691
G1 X139.548 Y154.546 E.68072
G1 X139.499 Y154.607 E.00329
G1 X139.316 Y154.791 E.0109
G1 X127.663 Y143.138 E.69227
G1 X127.228 Y143.179 E.01835
G1 X139.073 Y155.024 E.70368
G1 X138.8 Y155.228 E.01432
G1 X126.775 Y143.202 E.7144
G1 X126.299 Y143.202 E.02
G1 X138.528 Y155.432 E.72652
G1 X138.247 Y155.628 E.01439
G1 X125.822 Y143.203 E.73814
G1 X125.346 Y143.203 E.02
G1 X137.937 Y155.793 E.74797
G1 X137.614 Y155.947 E.01503
G1 X124.87 Y143.203 E.75709
G1 X124.394 Y143.203 E.02
G1 X137.27 Y156.079 E.76493
G1 X136.905 Y156.19 E.01603
G1 X123.918 Y143.204 E.77149
G1 X123.442 Y143.204 E.02
G1 X136.524 Y156.285 E.77714
G1 X136.104 Y156.342 E.0178
G1 X122.966 Y143.204 E.78049
G1 X122.49 Y143.204 E.02
G1 X135.662 Y156.376 E.78251
G1 X135.186 Y156.376 E.02
G1 X122.014 Y143.205 E.78248
G1 X121.538 Y143.205 E.02
G1 X134.709 Y156.376 E.78245
G1 X134.233 Y156.376 E.02
G1 X121.062 Y143.205 E.78245
G1 X120.586 Y143.205 E.02
G1 X133.757 Y156.377 E.78248
G1 X133.281 Y156.377 E.02
G1 X120.11 Y143.205 E.78248
G1 X119.634 Y143.206 E.02
G1 X132.805 Y156.377 E.78245
G1 X132.329 Y156.377 E.02
G1 X119.158 Y143.206 E.78245
G1 X118.681 Y143.206 E.02004
G1 X131.852 Y156.377 E.78245
G1 X131.376 Y156.377 E.02
G1 X118.205 Y143.206 E.78245
G1 X117.729 Y143.207 E.02
G1 X130.9 Y156.377 E.78242
G1 X130.424 Y156.377 E.02
G1 X117.253 Y143.207 E.78242
G1 X116.777 Y143.207 E.02
G1 X129.948 Y156.378 E.78245
G1 X129.471 Y156.378 E.02004
G1 X116.301 Y143.207 E.78242
G1 X115.825 Y143.208 E.02
G1 X128.995 Y156.378 E.78239
G1 X128.519 Y156.378 E.02
G1 X115.349 Y143.208 E.78239
G1 X114.873 Y143.208 E.02
G1 X128.043 Y156.378 E.78239
G1 X127.567 Y156.378 E.02
G1 X114.397 Y143.208 E.78239
G1 X113.921 Y143.209 E.02
G1 X127.091 Y156.378 E.78236
G1 X126.614 Y156.379 E.02004
G1 X113.445 Y143.209 E.78236
G1 X112.969 Y143.209 E.02
G1 X126.138 Y156.379 E.78236
G1 X125.662 Y156.379 E.02
G1 X112.493 Y143.209 E.78236
G1 X112.017 Y143.21 E.02
G1 X125.186 Y156.379 E.78233
G1 X124.71 Y156.379 E.02
G1 X111.54 Y143.21 E.78236
G1 X111.064 Y143.21 E.02
G1 X124.234 Y156.379 E.78236
G1 X123.757 Y156.379 E.02004
G1 X110.588 Y143.21 E.78233
G1 X110.112 Y143.21 E.02
G1 X123.281 Y156.379 E.78233
G1 X122.805 Y156.38 E.02
G1 X109.636 Y143.211 E.78233
G1 X109.16 Y143.211 E.02
G1 X122.329 Y156.38 E.78233
G1 X121.853 Y156.38 E.02
G1 X108.684 Y143.211 E.78233
G1 X108.208 Y143.211 E.02
G1 X121.377 Y156.38 E.78233
G1 X120.9 Y156.38 E.02004
G1 X107.732 Y143.212 E.78228
G1 X107.256 Y143.212 E.02
G1 X120.424 Y156.38 E.78228
G1 X119.948 Y156.38 E.02
G1 X106.78 Y143.212 E.78228
G1 X106.304 Y143.212 E.02
G1 X119.472 Y156.38 E.78228
G1 X118.996 Y156.381 E.02
G1 X105.828 Y143.213 E.78228
G1 X105.352 Y143.213 E.02
G1 X118.519 Y156.381 E.78225
G1 X118.043 Y156.381 E.02
G1 X104.875 Y143.213 E.78228
G1 X104.394 Y143.208 E.02021
G1 X117.567 Y156.381 E.78257
G1 X117.091 Y156.381 E.02
G1 X103.894 Y143.184 E.784
G1 X103.383 Y143.15 E.02151
G1 X116.615 Y156.381 E.78605
G1 X116.139 Y156.381 E.02
G1 X102.828 Y143.071 E.79074
G1 X102.533 Y143.029 E.01252
G1 X102.242 Y142.961 E.01255
G1 X115.662 Y156.381 E.79725
G1 X115.186 Y156.382 E.02
G1 X101.608 Y142.804 E.80663
G1 X100.896 Y142.568 E.03151
G1 X114.71 Y156.382 E.82065
G1 X114.234 Y156.382 E.02
G1 X100.099 Y142.247 E.83972
G1 X99.821 Y142.123 E.01279
G1 X99.096 Y141.72 E.03484
G1 X113.758 Y156.382 E.87103
G1 X113.282 Y156.382 E.02
G1 X90.119 Y133.219 E1.37605
G1 X90.119 Y133.696 E.02004
G1 X112.805 Y156.382 E1.34771
G1 X112.329 Y156.382 E.02
G1 X90.119 Y134.172 E1.31944
G1 X90.119 Y134.648 E.02
G1 X111.853 Y156.383 E1.29119
G1 X111.377 Y156.383 E.02
G1 X90.119 Y135.125 E1.26288
G1 X90.119 Y135.601 E.02
G1 X110.901 Y156.383 E1.2346
G1 X110.424 Y156.383 E.02004
G1 X90.119 Y136.077 E1.20629
G1 X90.119 Y136.554 E.02004
G1 X109.948 Y156.383 E1.17799
G1 X109.472 Y156.383 E.02
G1 X90.119 Y137.03 E1.14971
G1 X90.119 Y137.506 E.02
G1 X108.996 Y156.383 E1.12143
G1 X108.52 Y156.383 E.02
G1 X90.119 Y137.983 E1.09312
G1 X90.119 Y138.459 E.02
G1 X108.044 Y156.384 E1.06488
G1 X107.567 Y156.384 E.02004
G1 X90.119 Y138.936 E1.03654
G1 X90.119 Y139.412 E.02
G1 X107.091 Y156.384 E1.00826
G1 X106.615 Y156.384 E.02
G1 X90.119 Y139.888 E.97998
G1 X90.119 Y140.365 E.02004
G1 X106.139 Y156.384 E.95168
G1 X105.663 Y156.384 E.02
G1 X90.119 Y140.841 E.9234
G1 X90.12 Y141.317 E.02
G1 X105.187 Y156.384 E.89509
G1 X104.71 Y156.384 E.02004
G1 X90.12 Y141.794 E.86675
G1 X90.12 Y142.27 E.02
G1 X104.234 Y156.385 E.8385
G1 X103.758 Y156.385 E.02
G1 X90.12 Y142.746 E.81023
G1 X90.12 Y143.223 E.02004
G1 X103.282 Y156.385 E.78192
G1 X102.806 Y156.385 E.02
G1 X90.12 Y143.699 E.75364
G1 X90.12 Y144.175 E.02
G1 X102.33 Y156.385 E.72536
G1 X101.853 Y156.385 E.02004
G1 X90.12 Y144.652 E.69703
G1 X90.12 Y145.128 E.02
G1 X101.377 Y156.385 E.66875
G1 X100.901 Y156.386 E.02
G1 X90.12 Y145.604 E.6405
G1 X90.12 Y146.081 E.02004
G1 X100.425 Y156.386 E.61219
G1 X99.949 Y156.386 E.02
G1 X90.12 Y146.557 E.58391
G1 X90.12 Y147.034 E.02004
G1 X99.472 Y156.386 E.55558
G1 X98.996 Y156.386 E.02
G1 X90.12 Y147.51 E.5273
G1 X90.12 Y147.986 E.02
G1 X98.52 Y156.386 E.49902
G1 X98.044 Y156.386 E.02
G1 X90.12 Y148.463 E.47071
G1 X90.12 Y148.939 E.02
G1 X97.568 Y156.386 E.44244
G1 X97.092 Y156.387 E.02
G1 X90.12 Y149.415 E.41419
G1 X90.12 Y149.892 E.02004
G1 X96.615 Y156.387 E.38585
G1 X96.139 Y156.387 E.02
G1 X90.12 Y150.368 E.35757
G1 X90.121 Y150.844 E.02
G1 X95.663 Y156.387 E.32926
G1 X95.165 Y156.366 E.02094
G1 X90.133 Y151.333 E.29897
G1 X90.192 Y151.868 E.02261
G1 X94.63 Y156.306 E.26365
G1 X94.196 Y156.226 E.01854
G1 X94.016 Y156.169 E.00793
G1 X90.329 Y152.482 E.21903
G1 X90.364 Y152.621 E.00602
G1 X90.596 Y153.225 E.02718
G1 X93.256 Y155.885 E.15802
G1 X92.97 Y155.755 E.0132
G1 X92.409 Y155.41 E.02767
G1 X91.898 Y155.003 E.02744
G1 X90.769 Y153.874 E.06707
;LAYER_CHANGE
;Z:0.46
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;0.46
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X91.898 Y155.003 E-.75841
G1 X92.409 Y155.41 E-.31031
G1 X92.97 Y155.755 E-.31283
G1 X93.197 Y155.858 E-.11845
;WIPE_END
G1 Z.46 F9000
;AFTER_LAYER_CHANGE
;0.46
M140 S70 ; set bed temperature
; stop printing object stand_s.stl id:0 copy 0
G1 Z.46
G1 X90.908 Y161.158
G1 E5 F2400
;TYPE:Skirt/Brim
;WIDTH:0.4
G1 F3600
G1 X90.47 Y160.97 E.01159
G1 X89.16 Y160.194 E.03704
G1 X88.001 Y159.273 E.03601
G1 X87.06 Y158.311 E.03273
G1 X86.218 Y157.208 E.03375
G1 X85.538 Y156.046 E.03275
G1 X84.894 Y154.492 E.04092
G1 X84.539 Y153.135 E.03412
G1 X84.345 Y151.518 E.03961
G1 X84.335 Y79.844 E1.7434
G1 X84.397 Y78.809 E.02522
G1 X84.622 Y77.48 E.03279
G1 X85.005 Y76.187 E.0328
G1 X85.541 Y74.949 E.03281
G1 X86.222 Y73.786 E.03278
G1 X87.039 Y72.713 E.0328
G1 X87.979 Y71.746 E.0328
G1 X89.029 Y70.9 E.0328
G1 X90.173 Y70.186 E.0328
G1 X91.395 Y69.615 E.03281
G1 X92.676 Y69.196 E.03278
G1 X93.999 Y68.935 E.0328
G1 X95.5 Y68.832 E.0366
G1 X135.656 Y68.835 E.97676
G1 X137.666 Y69.046 E.04916
G1 X139.605 Y69.615 E.04915
G1 X141.41 Y70.526 E.04918
G1 X143.021 Y71.746 E.04915
G1 X144.385 Y73.237 E.04915
G1 X145.459 Y74.949 E.04916
G1 X146.206 Y76.827 E.04916
G1 X146.603 Y78.809 E.04917
G1 X146.668 Y80 E.02901
G1 X146.666 Y151.152 E1.7307
G1 X146.569 Y152.479 E.03236
G1 X146.314 Y153.784 E.03234
G1 X145.907 Y155.05 E.03235
G1 X145.462 Y156.046 E.02653
G1 X144.785 Y157.203 E.03261
G1 X143.967 Y158.281 E.03292
G1 X143.028 Y159.247 E.03277
G1 X141.818 Y160.208 E.03759
G1 X140.679 Y160.894 E.03234
G1 X139.338 Y161.486 E.03566
G1 X138.001 Y161.883 E.03392
G1 X136.349 Y162.134 E.04064
G1 X95.35 Y162.166 E.99726
G1 X94.213 Y162.093 E.02771
G1 X92.855 Y161.85 E.03356
G1 X91.692 Y161.497 E.02956
G1 X90.963 Y161.182 E.01932
G1 E-3.5
;WIPE_START
G1 F7200
G1 X90.908 Y161.158 E-.0285
G1 X90.47 Y160.97 E-.22641
G1 X89.16 Y160.194 E-.72323
G1 X88.3 Y159.511 E-.52186
;WIPE_END
G1 X91.952 Y155.136 F9000
G1 X102.175 Y142.888
G1 X103.235 Y141.619
G1 X104.651 Y138.568
G1 X104.651 Y139.44
; printing object stand_s.stl id:0 copy 0
G1 X105.054 Y139.44
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X105.059 Y139.451 E.00029
G1 X105.183 Y139.5 E.00324
G1 X125.817 Y139.5 E.5019
G1 X125.941 Y139.452 E.00323
G1 X126 Y139.317 E.00358
G1 X126 Y138.451 E.02106
G1 X126.264 Y138 E.01271
G1 X126.37 Y137.533 E.01165
G1 X126.264 Y137 E.01322
G1 X126 Y136.549 E.01271
G1 X126 Y103.852 E.79532
G1 X126.044 Y103.792 E.00181
G1 X126.044 Y98.457 E.12977
G1 X126 Y98.395 E.00185
G1 X126 Y93.87 E.11007
G1 X126.064 Y93.718 E.00401
;TYPE:Overhang perimeter
;WIDTH:0.368782
;HEIGHT:0.368782
G1 X138.882 Y93.721 E.56922
;WIDTH:0.399999
;HEIGHT:0.16
G1 X139.062 Y93.777 E.00459
G1 X139.151 Y93.977 E.00532
G1 X139.206 Y94.5 E.01279
G1 X139.184 Y94.728 E.00557
G1 X139.053 Y95.055 E.00857
G1 X138.937 Y95.107 E.00309
;WIDTH:0.368782
;HEIGHT:0.368782
G1 X136.339 Y95.119 E.11537
;WIDTH:0.399999
;HEIGHT:0.16
G1 X136.183 Y95.119 E.00379
G1 X136.037 Y95.192 E.00397
G1 X136 Y95.301 E.0028
G1 X136 Y127.168 E.77513
G1 X135.978 Y127.642 E.01154
G1 X135.978 Y132.948 E.12906
G1 X135.87 Y133.89 E.02306
G1 X135.689 Y134.747 E.02131
G1 X135.249 Y136.062 E.03373
G1 X134.835 Y136.933 E.02346
G1 X134.387 Y137.686 E.02131
G1 X133.544 Y138.788 E.03375
G1 X132.871 Y139.478 E.02344
G1 X132.203 Y140.046 E.02133
G1 X131.05 Y140.816 E.03372
G1 X130.189 Y141.251 E.02346
G1 X129.371 Y141.573 E.02138
G1 X128.484 Y141.83 E.02246
G1 X127.993 Y141.934 E.01221
G1 X127.171 Y142.05 E.02019
G1 X126.663 Y142.089 E.01239
G1 X120.734 Y142.1 E.14422
G1 X120.667 Y142.062 E.00187
G1 X110.333 Y142.062 E.25136
G1 X110.265 Y142.1 E.00189
G1 X104.804 Y142.1 E.13283
G1 X103.879 Y142.057 E.02252
G1 X102.646 Y141.854 E.0304
G1 X102.069 Y141.712 E.01445
G1 X101.195 Y141.413 E.02247
G1 X100.394 Y141.053 E.02136
G1 X99.554 Y140.578 E.02347
G1 X98.472 Y139.783 E.03266
G1 X97.766 Y139.125 E.02347
G1 X97.283 Y138.579 E.01773
G1 X96.878 Y138.071 E.0158
G1 X96.163 Y136.932 E.03271
G1 X95.749 Y136.06 E.02348
G1 X95.437 Y135.195 E.02237
G1 X95.129 Y133.888 E.03266
G1 X95.021 Y132.948 E.02301
G1 X95.021 Y127.642 E.12906
G1 X94.999 Y127.607 E.00101
G1 X94.999 Y95.301 E.78581
G1 X94.962 Y95.192 E.0028
G1 X94.816 Y95.119 E.00397
G1 X94.66 Y95.119 E.00379
;WIDTH:0.368782
;HEIGHT:0.368782
G1 X92.155 Y95.107 E.11124
;WIDTH:0.399999
;HEIGHT:0.16
G1 X91.953 Y95.068 E.005
G1 X91.846 Y94.867 E.00554
G1 X91.786 Y94.413 E.01114
G1 X91.847 Y93.952 E.01131
G1 X91.953 Y93.782 E.00487
G1 X92.057 Y93.721 E.00293
;WIDTH:0.368782
;HEIGHT:0.368782
G1 X104.939 Y93.721 E.57207
;WIDTH:0.399999
;HEIGHT:0.16
G1 X105 Y93.829 E.00302
G1 X105 Y98.395 E.11106
G1 X104.956 Y98.457 E.00185
G1 X104.956 Y103.792 E.12977
G1 X105 Y103.852 E.00181
G1 X105 Y136.549 E.79532
G1 X104.736 Y137 E.01271
G1 X104.629 Y137.471 E.01175
G1 X104.736 Y138 E.01313
G1 X105 Y138.451 E.01271
G1 X105 Y139.317 E.02106
G1 X105.03 Y139.385 E.00181
G1 X105.03 Y139.385 F9000
G1 X104.796 Y139.691
;TYPE:Perimeter
G1 F6000
G1 X104.811 Y139.72 E.00079
G1 X105.056 Y139.851 E.00676
G1 X105.183 Y139.866 E.00311
G1 X125.817 Y139.866 E.5019
G1 X126.093 Y139.792 E.00695
G1 X126.321 Y139.535 E.00836
G1 X126.366 Y139.317 E.00541
G1 X126.366 Y138.55 E.01866
G1 X126.644 Y138.017 E.01462
G1 X126.736 Y137.447 E.01404
G1 X126.621 Y136.902 E.01355
G1 X126.366 Y136.45 E.01262
G1 X126.366 Y103.897 E.79182
G1 X126.409 Y103.792 E.00276
G1 X126.409 Y98.457 E.12977
G1 X126.366 Y98.346 E.0029
G1 X126.366 Y94.077 E.10384
G1 X138.796 Y94.075 E.30235
G1 X138.842 Y94.465 E.00955
G1 X138.795 Y94.753 E.0071
G1 X136.088 Y94.761 E.06585
G1 X135.745 Y94.972 E.0098
G1 X135.635 Y95.301 E.00844
G1 X135.634 Y127.168 E.77513
G1 X135.613 Y127.642 E.01154
G1 X135.613 Y132.927 E.12855
G1 X135.508 Y133.831 E.02214
G1 X135.336 Y134.651 E.02038
G1 X134.909 Y135.925 E.03268
G1 X134.512 Y136.761 E.02251
G1 X134.083 Y137.481 E.02039
G1 X133.267 Y138.549 E.03269
G1 X132.621 Y139.211 E.0225
G1 X131.982 Y139.754 E.0204
G1 X130.865 Y140.499 E.03266
G1 X130.039 Y140.917 E.02252
G1 X129.253 Y141.226 E.02054
G1 X128.395 Y141.475 E.02173
G1 X127.88 Y141.58 E.01278
G1 X126.65 Y141.724 E.03012
G1 X120.999 Y141.734 E.13746
G1 X120.667 Y141.697 E.00813
G1 X110.333 Y141.697 E.25136
G1 X110.191 Y141.735 E.00358
G1 X104.812 Y141.735 E.13084
G1 X103.918 Y141.692 E.02177
G1 X102.705 Y141.493 E.0299
G1 X102.175 Y141.362 E.01328
G1 X101.329 Y141.073 E.02175
G1 X100.559 Y140.727 E.02053
G1 X99.753 Y140.27 E.02254
G1 X98.706 Y139.501 E.0316
G1 X98.029 Y138.869 E.02253
G1 X97.557 Y138.337 E.0173
G1 X97.179 Y137.861 E.01478
G1 X96.484 Y136.755 E.03177
G1 X96.087 Y135.919 E.02251
G1 X95.788 Y135.09 E.02144
G1 X95.49 Y133.824 E.03164
G1 X95.386 Y132.927 E.02196
G1 X95.386 Y127.642 E.12855
G1 X95.365 Y127.574 E.00173
G1 X95.365 Y95.301 E.78501
G1 X95.255 Y94.972 E.00844
G1 X94.816 Y94.753 E.01193
G1 X92.194 Y94.753 E.06378
G1 X92.157 Y94.447 E.0075
G1 X92.192 Y94.075 E.00909
G1 X104.634 Y94.077 E.30264
G1 X104.634 Y98.346 E.10384
G1 X104.591 Y98.457 E.0029
G1 X104.591 Y103.792 E.12977
G1 X104.634 Y103.897 E.00276
G1 X104.634 Y136.45 E.79182
G1 X104.42 Y136.816 E.01031
G1 X104.35 Y137.013 E.00509
G1 X104.264 Y137.549 E.0132
G1 X104.378 Y138.096 E.01359
G1 X104.634 Y138.55 E.01268
G1 X104.636 Y139.364 E.0198
G1 X104.77 Y139.637 E.0074
G1 E-5 F3600
G1 X104.77 Y139.637 F9000
G1 X104.651 Y139.637
G1 X104.651 Y139.849
G1 X126.349 Y139.849
G1 X126.709 Y137.703
G1 X126.723 Y137.5
G1 X127.769 Y94.058
G1 X136.475 Y94.77
G1 X136.029 Y94.77
G1 X136.029 Y94.421
G1 E5 F2400
;WIDTH:0.359528
G1 F6000
G1 X136.183 Y94.414 E.00333
;WIDTH:0.346948
G1 X138.502 Y94.414 E.04822
G1 E-5 F3600
G1 X138.502 Y94.414 F9000
G1 X138.502 Y94.058
G1 X135.652 Y94.77
G1 X135.652 Y96.54
G1 X135.269 Y96.54
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X135.269 Y127.168 E.745
G1 X135.247 Y127.642 E.01154
G1 X135.247 Y132.906 E.12804
G1 X135.147 Y133.772 E.0212
G1 X134.982 Y134.555 E.01946
G1 X134.569 Y135.788 E.03163
G1 X134.189 Y136.589 E.02156
G1 X133.78 Y137.276 E.01945
G1 X132.99 Y138.309 E.03163
G1 X132.371 Y138.943 E.02155
G1 X131.762 Y139.461 E.01945
G1 X130.68 Y140.183 E.03164
G1 X129.889 Y140.583 E.02156
G1 X129.135 Y140.88 E.01971
G1 X128.353 Y141.107 E.01981
G1 X127.829 Y141.218 E.01303
G1 X126.637 Y141.358 E.02919
G1 X120.998 Y141.368 E.13716
G1 X120.667 Y141.331 E.0081
G1 X110.333 Y141.331 E.25136
G1 X110.116 Y141.369 E.00536
G1 X104.821 Y141.369 E.1288
G1 X103.956 Y141.328 E.02106
G1 X102.765 Y141.132 E.02936
G1 X102.28 Y141.011 E.01216
G1 X101.464 Y140.732 E.02098
G1 X100.724 Y140.4 E.01973
G1 X99.952 Y139.963 E.02158
G1 X98.94 Y139.219 E.03055
G1 X98.291 Y138.614 E.02158
G1 X97.83 Y138.094 E.0169
G1 X97.479 Y137.652 E.01373
G1 X96.806 Y136.579 E.03081
G1 X96.425 Y135.778 E.02158
G1 X96.139 Y134.986 E.02048
G1 X95.851 Y133.761 E.03061
G1 X95.752 Y132.906 E.02094
G1 X95.752 Y127.642 E.12804
G1 X95.73 Y127.542 E.00249
G1 X95.73 Y95.301 E.78423
G1 X95.547 Y94.753 E.01405
G1 X95.182 Y94.583 E.00979
;WIDTH:0.373053
G1 X94.816 Y94.414 E.00908
G1 X95.26 Y94.428 E.01001
;WIDTH:0.399999
G1 X95.703 Y94.441 E.01078
G1 X104.269 Y94.443 E.20836
G1 X104.269 Y98.298 E.09377
G1 X104.234 Y98.328 E.00112
G1 X104.225 Y98.457 E.00315
G1 X104.225 Y103.792 E.12977
G1 X104.233 Y103.91 E.00288
G1 X104.269 Y103.941 E.00116
G1 X104.269 Y136.35 E.78832
G1 X104.024 Y136.809 E.01266
G1 X103.914 Y137.316 E.01262
G1 X103.914 Y137.684 E.00895
G1 X104.035 Y138.222 E.01341
G1 X104.269 Y138.65 E.01187
G1 X104.291 Y139.517 E.0211
G1 X104.563 Y139.989 E.01325
G1 X104.971 Y140.206 E.01124
G1 X105.183 Y140.231 E.00519
G1 X125.817 Y140.231 E.5019
G1 X125.977 Y140.217 E.00391
G1 X126.276 Y140.108 E.00774
G1 X126.436 Y139.99 E.00484
G1 X126.656 Y139.68 E.00925
G1 X126.731 Y139.317 E.00902
G1 X126.731 Y138.65 E.01622
G1 X126.924 Y138.316 E.00938
G1 X127.086 Y137.684 E.01587
G1 X127.1 Y137.412 E.00662
G1 X126.994 Y136.872 E.01339
G1 X126.731 Y136.35 E.01422
G1 X126.731 Y103.941 E.78832
G1 X126.767 Y103.91 E.00116
G1 X126.775 Y103.792 E.00288
G1 X126.775 Y98.689 E.12413
G1 X126.766 Y98.328 E.00878
G1 X126.731 Y98.298 E.00112
G1 X126.731 Y94.443 E.09377
G1 X135.296 Y94.441 E.20834
G1 X136.029 Y94.421 E.01784
G1 X135.452 Y94.753 E.01619
G1 X135.269 Y95.301 E.01405
G1 X135.269 Y96.48 E.02868
G1 X135.269 Y96.48 F9000
G1 X135.068 Y94.807
G1 F6000
G1 X134.903 Y95.301 E.01267
G1 X134.903 Y127.168 E.77513
G1 X134.881 Y127.642 E.01154
G1 X134.881 Y132.885 E.12753
G1 X134.786 Y133.713 E.02027
G1 X134.629 Y134.459 E.01854
G1 X134.23 Y135.651 E.03058
G1 X133.866 Y136.416 E.02061
G1 X133.477 Y137.071 E.01853
G1 X132.827 Y137.921 E.02603
G1 X132.456 Y138.332 E.01347
G1 X131.97 Y138.804 E.01648
G1 X131.418 Y139.251 E.01728
G1 X130.32 Y139.955 E.03173
G1 X129.664 Y140.278 E.01779
G1 X128.8 Y140.596 E.02239
G1 X127.778 Y140.856 E.02565
G1 X126.613 Y140.992 E.02853
;WIDTH:0.415528
G1 X125.818 Y140.986 E.02016
;WIDTH:0.419963
G1 X120.997 Y140.993 E.12367
G1 X120.667 Y140.965 E.0085
;WIDTH:0.401407
G1 X110.333 Y140.965 E.25233
;WIDTH:0.420283
G1 X110 Y140.993 E.00858
G1 X105.183 Y140.993 E.12367
;WIDTH:0.440706
G1 X103.995 Y140.964 E.03212
;WIDTH:0.399999
G1 X102.824 Y140.771 E.02887
G1 X102.385 Y140.661 E.01101
G1 X101.598 Y140.392 E.02023
G1 X100.89 Y140.073 E.01889
G1 X100.151 Y139.655 E.02065
G1 X99.173 Y138.937 E.02951
G1 X98.553 Y138.358 E.02063
G1 X98.104 Y137.852 E.01645
G1 X97.78 Y137.443 E.01269
G1 X97.127 Y136.403 E.02987
G1 X96.763 Y135.637 E.02063
G1 X96.49 Y134.882 E.01953
G1 X96.212 Y133.698 E.02958
G1 X96.118 Y132.885 E.01991
G1 X96.118 Y127.642 E.12753
G1 X96.096 Y127.51 E.00326
G1 X96.096 Y95.301 E.78345
G1 X95.931 Y94.807 E.01267
G1 X103.903 Y94.808 E.19391
G1 X103.903 Y97.845 E.07387
G1 X103.859 Y98.457 E.01492
G1 X103.859 Y103.792 E.12977
G1 X103.87 Y103.957 E.00402
G1 X103.903 Y103.986 E.00107
G1 X103.903 Y136.251 E.78481
G1 X103.677 Y136.695 E.01212
G1 X103.547 Y137.295 E.01493
G1 X103.556 Y137.757 E.01124
G1 X103.692 Y138.348 E.01475
G1 X103.903 Y138.749 E.01102
G1 X103.934 Y139.597 E.02064
G1 X104.315 Y140.257 E.01854
;WIDTH:0.440706
G1 X104.882 Y140.582 E.01767
G1 X105.183 Y140.607 E.00816
;WIDTH:0.420285
G1 X110.333 Y140.598 E.13222
;WIDTH:0.401407
G1 X120.667 Y140.598 E.25233
;WIDTH:0.419963
G1 X125.817 Y140.605 E.13211
;WIDTH:0.426727
G1 X126.043 Y140.59 E.00591
G1 X126.46 Y140.424 E.01172
;WIDTH:0.399999
G1 X126.684 Y140.259 E.00677
G1 X126.992 Y139.825 E.01294
G1 X127.061 Y139.618 E.00531
G1 X127.097 Y139.317 E.00737
G1 X127.097 Y138.749 E.01382
G1 X127.346 Y138.227 E.01407
G1 X127.444 Y137.757 E.01168
G1 X127.464 Y137.376 E.00928
G1 X127.307 Y136.648 E.01811
G1 X127.097 Y136.251 E.01092
G1 X127.097 Y103.986 E.78481
G1 X127.13 Y103.957 E.00107
G1 X127.141 Y103.792 E.00402
G1 X127.141 Y98.457 E.12977
G1 X127.097 Y98.249 E.00517
G1 X127.097 Y94.808 E.0837
G1 X135.008 Y94.807 E.19243
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X135.068 Y94.807 E-.0285
G1 X134.903 Y95.301 E-.24739
G1 X134.903 Y97.878 E-1.22411
;WIPE_END
G1 X103.537 Y95.174 F9000
G1 E5 F2400
G1 F6000
G1 X103.537 Y97.845 E.06497
G1 X103.494 Y98.457 E.01492
G1 X103.494 Y103.792 E.12977
G1 X103.537 Y104.031 E.00591
G1 X103.537 Y136.152 E.78131
G1 X103.329 Y136.582 E.01162
G1 X103.186 Y137.236 E.01628
G1 X103.198 Y137.83 E.01445
G1 X103.348 Y138.474 E.01608
G1 X103.537 Y138.848 E.01019
G1 X103.537 Y139.134 E.00696
G1 X103.577 Y139.676 E.01322
G1 X104.067 Y140.526 E.02386
G1 X104.221 Y140.608 E.00424
G1 X104.033 Y140.6 E.00458
G1 X102.884 Y140.41 E.02833
G1 X102.491 Y140.311 E.00986
G1 X101.732 Y140.051 E.01952
G1 X101.055 Y139.747 E.01805
G1 X100.35 Y139.348 E.0197
G1 X99.516 Y138.735 E.02518
G1 X99.188 Y138.45 E.01057
G1 X98.711 Y137.985 E.0162
G1 X98.08 Y137.234 E.02386
G1 X97.448 Y136.226 E.02894
G1 X97.101 Y135.497 E.01964
G1 X96.841 Y134.777 E.01862
G1 X96.572 Y133.635 E.02854
G1 X96.483 Y132.864 E.01888
G1 X96.483 Y127.642 E.12702
G1 X96.462 Y127.478 E.00402
G1 X96.462 Y95.301 E.78267
G1 X96.419 Y95.173 E.00328
G1 X103.477 Y95.174 E.17168
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.537 Y95.174 E-.0285
G1 X103.537 Y97.845 E-1.26872
G1 X103.507 Y98.271 E-.20278
;WIPE_END
G1 X127.463 Y114.216 F9000
G1 E5 F2400
G1 F6000
G1 X127.463 Y104.462 E.23726
G1 X127.506 Y103.792 E.01633
G1 X127.506 Y98.457 E.12977
G1 X127.463 Y98.201 E.00631
G1 X127.463 Y95.174 E.07363
G1 X134.581 Y95.173 E.17314
G1 X134.538 Y95.301 E.00328
G1 X134.537 Y127.168 E.77513
G1 X134.516 Y127.642 E.01154
G1 X134.516 Y132.864 E.12702
G1 X134.424 Y133.655 E.01937
G1 X134.275 Y134.363 E.0176
G1 X133.89 Y135.514 E.02952
G1 X133.543 Y136.244 E.01966
G1 X133.173 Y136.865 E.01758
G1 X132.536 Y137.698 E.02551
G1 X132.195 Y138.077 E.0124
G1 X131.734 Y138.525 E.01564
G1 X131.215 Y138.947 E.01627
G1 X130.155 Y139.629 E.03066
G1 X129.53 Y139.938 E.01696
G1 X128.698 Y140.245 E.02157
G1 X127.727 Y140.494 E.02438
G1 X126.817 Y140.612 E.02232
G1 X126.932 Y140.528 E.00346
G1 X127.328 Y139.97 E.01664
G1 X127.417 Y139.704 E.00682
G1 X127.463 Y139.317 E.00948
G1 X127.463 Y138.848 E.01141
G1 X127.7 Y138.319 E.0141
G1 X127.802 Y137.83 E.01215
G1 X127.828 Y137.341 E.01191
G1 X127.65 Y136.521 E.02041
G1 X127.463 Y136.152 E.01006
G1 X127.463 Y114.276 E.53211
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X127.463 Y114.216 E-.0285
G1 X127.463 Y111.118 E-1.4715
;WIPE_END
G1 X92.494 Y94.414 F9000
G1 E5 F2400
;WIDTH:0.346952
G1 F6000
G1 X94.816 Y94.414 E.04829
;WIDTH:0.346106
G1 E-5 F3600
G1 X94.816 Y94.414 F9000
G1 X96.835 Y95.477
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.488694
G1 F1200
G1 X96.795 Y95.436 E.00173
G1 X96.74 Y95.451 E.00172
G1 X96.725 Y95.506 E.00172
G1 X96.766 Y95.546 E.00173
G1 X96.82 Y95.532 E.00169
;WIDTH:0.399999
G1 X97.404 Y95.447 E.01435
G1 X96.736 Y96.116 E.023
G1 X96.736 Y96.633 E.01258
G1 X97.921 Y95.447 E.04078
G1 X98.438 Y95.447 E.01258
G1 X96.736 Y97.15 E.05856
G1 X96.736 Y97.667 E.01258
G1 X98.955 Y95.447 E.07635
G1 X99.473 Y95.447 E.0126
G1 X96.736 Y98.184 E.09415
G1 X96.736 Y98.701 E.01258
G1 X99.99 Y95.448 E.11192
G1 X100.507 Y95.448 E.01258
G1 X96.736 Y99.218 E.1297
G1 X96.736 Y99.735 E.01258
G1 X101.024 Y95.448 E.14749
G1 X101.541 Y95.448 E.01258
G1 X96.736 Y100.253 E.16529
G1 X96.736 Y100.77 E.01258
G1 X102.058 Y95.448 E.18307
G1 X102.575 Y95.448 E.01258
G1 X96.736 Y101.287 E.20086
G1 X96.736 Y101.804 E.01258
G1 X103.092 Y95.448 E.21864
G1 X103.263 Y95.794 E.00939
G1 X96.736 Y102.321 E.22452
G1 X96.736 Y102.838 E.01258
G1 X103.263 Y96.311 E.22452
G1 X103.263 Y96.828 E.01258
G1 X96.736 Y103.355 E.22452
G1 X96.736 Y103.872 E.01258
G1 X103.263 Y97.345 E.22452
G1 X103.263 Y97.862 E.01258
G1 X96.736 Y104.39 E.22454
G1 X96.736 Y104.907 E.01258
G1 X103.222 Y98.421 E.22311
G1 X103.22 Y98.94 E.01262
G1 X96.736 Y105.424 E.22305
G1 X96.736 Y105.941 E.01258
G1 X103.22 Y99.457 E.22305
G1 X103.22 Y99.974 E.01258
G1 X96.736 Y106.458 E.22305
G1 X96.736 Y106.975 E.01258
G1 X103.22 Y100.492 E.22303
G1 X103.22 Y101.009 E.01258
G1 X96.736 Y107.492 E.22303
G1 X96.736 Y108.009 E.01258
G1 X103.22 Y101.526 E.22303
G1 X103.22 Y102.043 E.01258
G1 X96.736 Y108.527 E.22305
G1 X96.736 Y109.044 E.01258
G1 X103.22 Y102.56 E.22305
G1 X103.22 Y103.077 E.01258
G1 X96.736 Y109.561 E.22305
G1 X96.736 Y110.078 E.01258
G1 X103.22 Y103.594 E.22305
G1 X103.249 Y104.082 E.01189
G1 X96.736 Y110.595 E.22404
G1 X96.736 Y111.112 E.01258
G1 X103.263 Y104.585 E.22452
G1 X103.263 Y105.102 E.01258
G1 X96.736 Y111.629 E.22452
G1 X96.736 Y112.146 E.01258
G1 X103.263 Y105.619 E.22452
G1 X103.263 Y106.136 E.01258
G1 X96.736 Y112.664 E.22454
G1 X96.736 Y113.181 E.01258
G1 X103.263 Y106.654 E.22452
G1 X103.263 Y107.171 E.01258
G1 X96.736 Y113.698 E.22452
G1 X96.736 Y114.215 E.01258
G1 X103.263 Y107.688 E.22452
G1 X103.263 Y108.205 E.01258
G1 X96.736 Y114.732 E.22452
G1 X96.736 Y115.249 E.01258
G1 X103.263 Y108.722 E.22452
G1 X103.263 Y109.239 E.01258
G1 X96.736 Y115.766 E.22452
G1 X96.736 Y116.283 E.01258
G1 X103.263 Y109.756 E.22452
G1 X103.263 Y110.273 E.01258
G1 X96.736 Y116.801 E.22454
G1 X96.736 Y117.318 E.01258
G1 X103.263 Y110.791 E.22452
G1 X103.263 Y111.308 E.01258
G1 X96.736 Y117.835 E.22452
G1 X96.736 Y118.352 E.01258
G1 X103.263 Y111.825 E.22452
G1 X103.263 Y112.342 E.01258
G1 X96.736 Y118.869 E.22452
G1 X96.736 Y119.386 E.01258
G1 X103.263 Y112.859 E.22452
G1 X103.263 Y113.376 E.01258
G1 X96.736 Y119.903 E.22452
G1 X96.736 Y120.42 E.01258
G1 X103.263 Y113.893 E.22452
G1 X103.263 Y114.41 E.01258
G1 X96.736 Y120.938 E.22454
G1 X96.736 Y121.455 E.01258
G1 X103.263 Y114.928 E.22452
G1 X103.263 Y115.445 E.01258
G1 X96.736 Y121.972 E.22452
G1 X96.736 Y122.489 E.01258
G1 X103.263 Y115.962 E.22452
G1 X103.263 Y116.479 E.01258
G1 X96.736 Y123.006 E.22452
G1 X96.736 Y123.523 E.01258
G1 X103.263 Y116.996 E.22452
G1 X103.263 Y117.513 E.01258
G1 X96.736 Y124.04 E.22452
G1 X96.736 Y124.557 E.01258
G1 X103.263 Y118.03 E.22452
G1 X103.263 Y118.547 E.01258
G1 X96.736 Y125.075 E.22454
G1 X96.736 Y125.592 E.01258
G1 X103.263 Y119.065 E.22452
G1 X103.263 Y119.582 E.01258
G1 X96.736 Y126.109 E.22452
G1 X96.736 Y126.626 E.01258
G1 X103.263 Y120.099 E.22452
G1 X103.263 Y120.616 E.01258
G1 X96.736 Y127.143 E.22452
G1 X96.758 Y127.638 E.01205
G1 X103.263 Y121.133 E.22377
G1 X103.263 Y121.65 E.01258
G1 X96.758 Y128.156 E.22378
G1 X96.758 Y128.673 E.01258
G1 X103.263 Y122.167 E.22378
G1 X103.263 Y122.684 E.01258
G1 X96.758 Y129.19 E.22378
G1 X96.758 Y129.707 E.01258
G1 X103.263 Y123.202 E.22377
G1 X103.263 Y123.719 E.01258
G1 X96.758 Y130.224 E.22377
G1 X96.758 Y130.741 E.01258
G1 X103.263 Y124.236 E.22377
G1 X103.263 Y124.753 E.01258
G1 X96.758 Y131.258 E.22377
G1 X96.758 Y131.775 E.01258
G1 X103.263 Y125.27 E.22377
G1 X103.263 Y125.787 E.01258
G1 X96.758 Y132.293 E.22378
G1 X96.758 Y132.81 E.01258
G1 X103.263 Y126.304 E.22378
G1 X103.263 Y126.821 E.01258
G1 X96.807 Y133.277 E.22208
G1 X96.875 Y133.726 E.01105
G1 X103.263 Y127.339 E.21973
G1 X103.263 Y127.856 E.01258
G1 X96.974 Y134.145 E.21634
G1 X97.072 Y134.563 E.01044
G1 X103.263 Y128.373 E.21295
G1 X103.263 Y128.89 E.01258
G1 X97.197 Y134.956 E.20867
G1 X97.334 Y135.336 E.00983
G1 X103.263 Y129.407 E.20395
G1 X103.263 Y129.924 E.01258
G1 X97.497 Y135.691 E.19836
G1 X97.663 Y136.041 E.00942
G1 X103.263 Y130.441 E.19264
G1 X103.263 Y130.958 E.01258
G1 X97.858 Y136.364 E.18595
G1 X98.057 Y136.682 E.00912
G1 X103.263 Y131.476 E.17908
G1 X103.263 Y131.993 E.01258
G1 X98.257 Y136.999 E.1722
G1 X98.475 Y137.298 E.009
G1 X103.263 Y132.51 E.1647
G1 X103.263 Y133.027 E.01258
G1 X98.714 Y137.576 E.15648
G1 X98.957 Y137.85 E.00891
G1 X103.263 Y133.544 E.14812
G1 X103.263 Y134.061 E.01258
G1 X99.219 Y138.105 E.13911
G1 X99.487 Y138.354 E.0089
G1 X103.263 Y134.578 E.12989
G1 X103.263 Y135.095 E.01258
G1 X99.774 Y138.584 E.12002
G1 X100.072 Y138.803 E.009
G1 X103.263 Y135.613 E.10975
G1 X103.216 Y136.177 E.01377
G1 X100.37 Y139.022 E.09788
G1 E-5 F3600
G1 X100.37 Y139.022 F9000
G1 X102.836 Y137.074
G1 E5 F2400
G1 F1200
G1 X100.687 Y139.223 E.07392
G1 X101.179 Y139.502 E.01376
G1 X101.831 Y139.795 E.01739
G1 X102.918 Y140.138 E.02773
G1 X103.601 Y140.251 E.01684
G1 X103.328 Y139.777 E.01331
G1 X103.27 Y139.466 E.0077
G1 X103.263 Y138.919 E.01331
G1 X103.087 Y138.553 E.00988
G1 X102.901 Y137.688 E.02152
G1 X102.917 Y137.181 E.01234
G1 X102.965 Y136.945 E.00586
G1 X102.965 Y136.945 F9000
G1 X102.562 Y137.865
G1 F1200
G1 X102.664 Y138.403 E.01332
G1 X102.852 Y138.912 E.0132
G1 X102.9 Y139.111 E.00498
G1 X102.943 Y139.763 E.01589
G1 X101.935 Y139.441 E.02574
G1 X101.285 Y139.142 E.0174
G1 X102.432 Y137.995 E.03946
G1 X102.338 Y138.612 E.01518
;WIDTH:0.409155
G1 X102.52 Y139.076 E.01243
G1 X102.531 Y139.244 E.0042
G1 X101.922 Y139.029 E.0161
G1 X102.209 Y138.742 E.01012
G1 E-5 F3600
G1 X102.209 Y138.742 F9000
G1 X126.723 Y137.5
G1 X127.836 Y95.478
G1 E5 F2400
;WIDTH:0.488738
G1 F1200
G1 X127.796 Y95.438 E.00171
G1 X127.741 Y95.452 E.00172
G1 X127.726 Y95.507 E.00172
G1 X127.767 Y95.547 E.00173
G1 X127.821 Y95.533 E.00169
;WIDTH:0.399999
G1 X127.737 Y96.117 E.01435
G1 X128.406 Y95.448 E.02301
G1 X128.576 Y95.322 E.00515
;WIDTH:0.374336
G1 X128.535 Y95.333 E.00096
G1 X128.516 Y95.262 E.00166
G1 X128.587 Y95.281 E.00166
;WIDTH:0.399999
G1 X128.923 Y95.448 E.00913
G1 X127.737 Y96.634 E.0408
G1 X127.737 Y97.151 E.01258
G1 X129.44 Y95.448 E.05858
G1 X129.957 Y95.448 E.01258
G1 X127.737 Y97.668 E.07637
G1 X127.76 Y98.162 E.01203
G1 X130.474 Y95.448 E.09336
G1 X130.992 Y95.448 E.0126
G1 X127.78 Y98.659 E.11047
G1 X127.78 Y99.176 E.01258
G1 X131.509 Y95.448 E.12826
G1 X132.026 Y95.447 E.01258
G1 X127.78 Y99.693 E.14606
G1 X127.78 Y100.21 E.01258
G1 X132.543 Y95.447 E.16384
G1 X133.061 Y95.447 E.0126
G1 X127.78 Y100.727 E.18165
G1 X127.78 Y101.244 E.01258
G1 X133.578 Y95.447 E.19943
G1 X134.095 Y95.447 E.01258
G1 X127.78 Y101.762 E.21723
G1 X127.78 Y102.279 E.01258
G1 X134.264 Y95.796 E.22303
G1 X134.264 Y96.313 E.01258
G1 X127.78 Y102.796 E.22303
G1 X127.78 Y103.313 E.01258
G1 X134.264 Y96.83 E.22303
G1 X134.264 Y97.347 E.01258
G1 X127.778 Y103.833 E.22311
G1 X127.737 Y104.391 E.01361
G1 X134.264 Y97.864 E.22452
G1 X134.264 Y98.381 E.01258
G1 X127.737 Y104.908 E.22452
G1 X127.737 Y105.425 E.01258
G1 X134.264 Y98.898 E.22452
G1 X134.263 Y99.416 E.0126
G1 X127.737 Y105.942 E.22449
G1 X127.737 Y106.459 E.01258
G1 X134.263 Y99.933 E.22449
G1 X134.263 Y100.45 E.01258
G1 X127.737 Y106.976 E.22449
G1 X127.737 Y107.494 E.0126
G1 X134.263 Y100.967 E.22451
G1 X134.263 Y101.484 E.01258
G1 X127.737 Y108.011 E.22451
G1 X127.737 Y108.528 E.01258
G1 X134.263 Y102.001 E.22451
G1 X134.263 Y102.518 E.01258
G1 X127.737 Y109.045 E.22451
G1 X127.737 Y109.562 E.01258
G1 X134.263 Y103.036 E.22449
G1 X134.263 Y103.553 E.01258
G1 X127.737 Y110.079 E.22449
G1 X127.737 Y110.596 E.01258
G1 X134.263 Y104.07 E.22449
G1 X134.263 Y104.587 E.01258
G1 X127.737 Y111.113 E.22449
G1 X127.737 Y111.631 E.0126
G1 X134.263 Y105.104 E.22451
G1 X134.263 Y105.621 E.01258
G1 X127.737 Y112.148 E.22451
G1 X127.737 Y112.665 E.01258
G1 X134.263 Y106.138 E.22451
G1 X134.263 Y106.655 E.01258
G1 X127.737 Y113.182 E.22451
G1 X127.737 Y113.699 E.01258
G1 X134.263 Y107.173 E.22449
G1 X134.263 Y107.69 E.01258
G1 X127.737 Y114.216 E.22449
G1 X127.737 Y114.733 E.01258
G1 X134.263 Y108.207 E.22449
G1 X134.263 Y108.724 E.01258
G1 X127.737 Y115.25 E.22449
G1 X127.737 Y115.768 E.0126
G1 X134.263 Y109.241 E.22451
G1 X134.263 Y109.758 E.01258
G1 X127.737 Y116.285 E.22451
G1 X127.737 Y116.802 E.01258
G1 X134.263 Y110.275 E.22451
G1 X134.263 Y110.792 E.01258
G1 X127.737 Y117.319 E.22451
G1 X127.737 Y117.836 E.01258
G1 X134.263 Y111.31 E.22449
G1 X134.263 Y111.827 E.01258
G1 X127.737 Y118.353 E.22449
G1 X127.737 Y118.87 E.01258
G1 X134.263 Y112.344 E.22449
G1 X134.263 Y112.861 E.01258
G1 X127.737 Y119.387 E.22449
G1 X127.737 Y119.905 E.0126
G1 X134.263 Y113.378 E.22451
G1 X134.263 Y113.895 E.01258
G1 X127.737 Y120.422 E.22451
G1 X127.737 Y120.939 E.01258
G1 X134.263 Y114.412 E.22451
G1 X134.263 Y114.93 E.0126
G1 X127.737 Y121.456 E.22449
G1 X127.737 Y121.973 E.01258
G1 X134.263 Y115.447 E.22449
G1 X134.263 Y115.964 E.01258
G1 X127.737 Y122.49 E.22449
G1 X127.737 Y123.007 E.01258
G1 X134.263 Y116.481 E.22449
G1 X134.263 Y116.998 E.01258
G1 X127.737 Y123.524 E.22449
G1 X127.737 Y124.042 E.0126
G1 X134.263 Y117.515 E.22451
G1 X134.263 Y118.032 E.01258
G1 X127.737 Y124.559 E.22451
G1 X127.737 Y125.076 E.01258
G1 X134.263 Y118.549 E.22451
G1 X134.263 Y119.067 E.0126
G1 X127.737 Y125.593 E.22449
G1 X127.737 Y126.11 E.01258
G1 X134.263 Y119.584 E.22449
G1 X134.263 Y120.101 E.01258
G1 X127.737 Y126.627 E.22449
G1 X127.737 Y127.144 E.01258
G1 X134.263 Y120.618 E.22449
G1 X134.263 Y121.135 E.01258
G1 X127.737 Y127.661 E.22449
G1 X127.737 Y128.179 E.0126
G1 X134.263 Y121.652 E.22451
G1 X134.263 Y122.169 E.01258
G1 X127.737 Y128.696 E.22451
G1 X127.737 Y129.213 E.01258
G1 X134.263 Y122.687 E.22449
G1 X134.263 Y123.204 E.01258
G1 X127.737 Y129.73 E.22449
G1 X127.737 Y130.247 E.01258
G1 X134.263 Y123.721 E.22449
G1 X134.263 Y124.238 E.01258
G1 X127.737 Y130.764 E.22449
G1 X127.737 Y131.281 E.01258
G1 X134.263 Y124.755 E.22449
G1 X134.263 Y125.272 E.01258
G1 X127.737 Y131.798 E.22449
G1 X127.737 Y132.316 E.0126
G1 X134.263 Y125.789 E.22451
G1 X134.263 Y126.306 E.01258
G1 X127.737 Y132.833 E.22451
G1 X127.737 Y133.35 E.01258
G1 X134.263 Y126.824 E.22449
G1 X134.263 Y127.341 E.01258
G1 X127.737 Y133.867 E.22449
G1 X127.737 Y134.384 E.01258
G1 X134.241 Y127.88 E.22373
G1 X134.241 Y128.397 E.01258
G1 X127.737 Y134.901 E.22373
G1 X127.737 Y135.418 E.01258
G1 X134.241 Y128.914 E.22373
G1 X134.241 Y129.431 E.01258
G1 X127.737 Y135.935 E.22373
G1 X127.86 Y136.33 E.01006
G1 X134.241 Y129.948 E.21952
G1 X134.241 Y130.465 E.01258
G1 X127.987 Y136.72 E.21515
G1 X128.07 Y137.153 E.01072
G1 X134.241 Y130.982 E.21228
G1 X134.241 Y131.499 E.01258
G1 X128.088 Y137.653 E.21168
G1 X128.088 Y137.653 F9000
G1 X127.864 Y138.554
;WIDTH:0.374336
G1 F1200
G1 X127.823 Y138.565 E.00096
G1 X127.804 Y138.494 E.00166
G1 X127.875 Y138.513 E.00166
;WIDTH:0.399999
G1 X127.993 Y138.265 E.00668
G1 X134.241 Y132.017 E.21493
G1 X134.241 Y132.534 E.01258
G1 X127.737 Y139.038 E.22373
G1 X127.705 Y139.587 E.01338
G1 X134.215 Y133.077 E.22394
G1 X134.141 Y133.668 E.01449
G1 X127.57 Y140.239 E.22604
G1 X127.462 Y140.017 E.00601
;WIDTH:0.374336
G1 X127.326 Y140.331 E.00774
G1 X127.326 Y140.331 F9000
G1 X128.232 Y140.095
;WIDTH:0.399999
G1 F1200
G1 X133.998 Y134.329 E.19835
G1 X133.935 Y134.837 E.01245
;WIDTH:0.374336
G1 X133.864 Y134.818 E.00166
G1 X133.883 Y134.889 E.00166
G1 X133.924 Y134.878 E.00096
;WIDTH:0.399999
G1 X133.737 Y135.107 E.00719
G1 X128.986 Y139.858 E.16343
G1 X128.76 Y140.049 E.0072
;WIDTH:0.374336
G1 X128.719 Y140.06 E.00096
G1 X128.7 Y139.989 E.00166
G1 X128.771 Y140.008 E.00166
G1 X128.771 Y140.008 F9000
G1 X129.705 Y139.611
G1 F1200
G1 X129.634 Y139.592 E.00166
G1 X129.653 Y139.663 E.00166
G1 X129.694 Y139.652 E.00096
;WIDTH:0.399999
G1 X133.35 Y136.01 E.12552
G1 X133.556 Y135.782 E.00747
;WIDTH:0.374336
G1 X133.515 Y135.793 E.00096
G1 X133.496 Y135.722 E.00166
G1 X133.567 Y135.741 E.00166
G1 X133.567 Y135.741 F9000
G1 X133.01 Y136.757
G1 F1200
G1 X132.455 Y137.39 E.01904
G1 X132.415 Y137.576 E.0043
G1 X131.743 Y138.271 E.02186
G1 X131.507 Y138.487 E.00724
G1 X131.334 Y138.523 E.004
G1 X131.169 Y138.676 E.00509
;WIDTH:0.399999
G1 X131.593 Y138.285 E.01403
G1 X132.229 Y137.649 E.02188
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X131.593 Y138.285 E-.42723
G1 X131.169 Y138.676 E-.27396
G1 X131.334 Y138.523 E-.10688
G1 X131.507 Y138.487 E-.08394
G1 X131.743 Y138.271 E-.15196
G1 X132.41 Y137.581 E-.45603
;WIPE_END
G1 X126.349 Y129.348 F9000
G1 X124.901 Y127.382
G1 X119.129 Y119.551
G1 X118.921 Y119.259
G1 E5 F2400
G1 F6000
G1 X118.592 Y119.481 E.00965
G1 X118.234 Y119.647 E.0096
G1 X117.742 Y119.785 E.01243
G1 X117.233 Y119.831 E.01243
G1 X113.767 Y119.831 E.08431
G1 X112.978 Y119.718 E.01939
G1 X112.44 Y119.499 E.01413
G1 X111.886 Y119.112 E.01644
G1 X111.447 Y118.621 E.01602
G1 X109.584 Y115.415 E.09019
G1 X109.373 Y114.959 E.01222
G1 X109.242 Y114.456 E.01264
G1 X109.207 Y113.937 E.01265
G1 X109.243 Y113.544 E.0096
G1 X109.373 Y113.041 E.01264
G1 X109.584 Y112.585 E.01222
G1 X111.447 Y109.379 E.09019
G1 X112.005 Y108.786 E.01981
G1 X112.494 Y108.473 E.01412
G1 X113.13 Y108.244 E.01644
G1 X113.768 Y108.169 E.01563
G1 X117.475 Y108.18 E.09017
G1 X117.774 Y108.223 E.00735
G1 X118.465 Y108.453 E.01771
G1 X119.001 Y108.79 E.0154
G1 X119.553 Y109.379 E.01964
G1 X121.416 Y112.585 E.09019
G1 X121.627 Y113.041 E.01222
G1 X121.757 Y113.544 E.01264
G1 X121.789 Y114.161 E.01503
G1 X121.712 Y114.677 E.01269
G1 X121.472 Y115.306 E.01638
G1 X119.553 Y118.621 E.09317
G1 X119.029 Y119.185 E.01873
G1 X118.97 Y119.225 E.00173
G1 X118.97 Y119.225 F9000
G1 X119.189 Y119.51
;TYPE:Perimeter
G1 F6000
G1 X118.795 Y119.786 E.0117
G1 X118.334 Y119.999 E.01235
G1 X117.792 Y120.147 E.01367
G1 X117.233 Y120.197 E.01365
G1 X113.767 Y120.197 E.08431
G1 X113.152 Y120.117 E.01509
G1 X112.84 Y120.056 E.00773
G1 X112.302 Y119.837 E.01413
G1 X111.877 Y119.554 E.01242
G1 X111.582 Y119.328 E.00904
G1 X111.131 Y118.805 E.0168
G1 X109.268 Y115.599 E.09019
G1 X109.041 Y115.112 E.01307
G1 X108.888 Y114.545 E.01429
G1 X108.842 Y113.96 E.01427
G1 X108.888 Y113.455 E.01233
G1 X109.041 Y112.888 E.01429
G1 X109.268 Y112.401 E.01307
G1 X111.131 Y109.195 E.09019
G1 X111.537 Y108.742 E.0148
G1 X111.808 Y108.478 E.0092
G1 X112.297 Y108.165 E.01412
G1 X112.794 Y107.975 E.01294
G1 X113.129 Y107.872 E.00852
G1 X113.706 Y107.806 E.01413
G1 X117.477 Y107.814 E.09173
G1 X117.89 Y107.876 E.01016
G1 X118.581 Y108.107 E.01772
G1 X119.212 Y108.492 E.01798
G1 X119.74 Y109.037 E.01846
G1 X119.869 Y109.195 E.00496
G1 X121.732 Y112.401 E.09019
G1 X121.959 Y112.888 E.01307
G1 X122.112 Y113.454 E.01426
G1 X122.155 Y114.144 E.01682
G1 X122.074 Y114.734 E.01449
G1 X121.813 Y115.439 E.01829
G1 X119.869 Y118.804 E.09453
G1 X119.296 Y119.436 E.02075
G1 X119.238 Y119.476 E.00171
G1 X119.238 Y119.476 F9000
G1 X119.442 Y119.772
G1 F6000
G1 X118.997 Y120.091 E.01332
G1 X118.433 Y120.351 E.01511
G1 X117.842 Y120.509 E.01488
G1 X117.233 Y120.563 E.01487
G1 X113.767 Y120.563 E.08431
G1 X113.101 Y120.479 E.01633
G1 X112.702 Y120.395 E.00992
G1 X112.164 Y120.176 E.01413
G1 X111.666 Y119.852 E.01445
G1 X111.309 Y119.571 E.01105
G1 X110.923 Y119.137 E.01413
G1 X110.815 Y118.988 E.00448
G1 X108.952 Y115.783 E.09017
G1 X108.708 Y115.265 E.01393
G1 X108.533 Y114.635 E.0159
G1 X108.477 Y113.983 E.01592
G1 X108.533 Y113.365 E.01509
G1 X108.708 Y112.735 E.0159
G1 X108.952 Y112.217 E.01393
G1 X110.815 Y109.011 E.09019
G1 X111.27 Y108.492 E.01679
G1 X111.611 Y108.17 E.01141
G1 X112.1 Y107.857 E.01412
G1 X112.672 Y107.63 E.01497
G1 X113.088 Y107.508 E.01054
G1 X113.665 Y107.443 E.01412
G1 X117.478 Y107.448 E.09275
G1 X118.006 Y107.529 E.01299
G1 X118.696 Y107.76 E.0177
G1 X119.423 Y108.193 E.02058
G1 X120.006 Y108.787 E.02024
G1 X120.185 Y109.011 E.00697
G1 X122.048 Y112.217 E.09019
G1 X122.292 Y112.735 E.01393
G1 X122.467 Y113.365 E.0159
G1 X122.52 Y114.127 E.01858
G1 X122.435 Y114.79 E.01626
G1 X122.154 Y115.572 E.02021
G1 X120.185 Y118.988 E.09591
G1 X119.562 Y119.686 E.02276
G1 X119.491 Y119.737 E.00213
G1 E-5 F3600
G1 X119.491 Y119.737 F9000
G1 X119.248 Y119.458
G1 X119.362 Y119.36
G1 X119.451 Y119.278
G1 X119.569 Y119.154
G1 X119.65 Y119.066
G1 X119.756 Y118.93
G1 X119.83 Y118.835
G1 X119.922 Y118.691
G1 X119.98 Y118.6
G1 X121.724 Y115.58
G1 X121.773 Y115.485
G1 X121.852 Y115.332
G1 X121.898 Y115.221
G1 X121.962 Y115.061
G1 X121.998 Y114.947
G1 X122.046 Y114.782
G1 X122.073 Y114.665
G1 X122.105 Y114.496
G1 X122.121 Y114.377
G1 X122.137 Y114.206
G1 X122.142 Y114.086
G1 X122.142 Y113.914
G1 X122.137 Y113.794
G1 X122.121 Y113.623
G1 X122.105 Y113.504
G1 X122.073 Y113.335
G1 X122.046 Y113.218
G1 X121.998 Y113.053
G1 X121.962 Y112.939
G1 X121.898 Y112.779
G1 X121.852 Y112.668
G1 X121.773 Y112.515
G1 X121.724 Y112.42
G1 X120.98 Y111.131
G1 X122.027 Y100.85
G1 X122.723 Y101.054
G1 E5 F2400
G1 F6000
G1 X122.494 Y101.704 E.01676
G1 X122.193 Y102.254 E.01525
G1 X120.502 Y105.171 E.08201
G1 X119.829 Y105.936 E.02478
G1 X119.357 Y106.301 E.01451
G1 X118.757 Y106.616 E.01648
G1 X118.13 Y106.817 E.01602
;WIDTH:0.440341
G1 X118.037 Y106.852 E.00268
;WIDTH:0.480682
G1 X117.944 Y106.888 E.00296
;WIDTH:0.521023
G1 X117.851 Y106.924 E.00323
;WIDTH:0.561365
G1 X117.758 Y106.959 E.00348
;WIDTH:0.601706
G1 X117.665 Y106.995 E.00376
G1 X117.836 Y107.059 E.00689
;WIDTH:0.561365
G1 X118.007 Y107.123 E.0064
;WIDTH:0.521023
G1 X118.178 Y107.187 E.00591
;WIDTH:0.480682
G1 X118.348 Y107.251 E.00539
;WIDTH:0.440341
G1 X118.519 Y107.315 E.00493
;WIDTH:0.399999
G1 X119.097 Y107.549 E.01517
G1 X119.586 Y107.862 E.01412
G1 X119.829 Y108.064 E.00769
G1 X120.327 Y108.595 E.01771
G1 X120.501 Y108.827 E.00705
G1 X122.365 Y112.033 E.09021
G1 X122.624 Y112.582 E.01477
G1 X122.821 Y113.275 E.01752
G1 X122.885 Y114.111 E.02039
G1 X122.796 Y114.847 E.01803
G1 X122.494 Y115.704 E.0221
G1 X122.409 Y115.882 E.0048
G1 X120.502 Y119.171 E.09248
G1 X119.829 Y119.936 E.02478
G1 X119.2 Y120.395 E.01894
G1 X118.721 Y120.633 E.01301
G1 X118.13 Y120.817 E.01506
;WIDTH:0.44034
G1 X118.037 Y120.852 E.00268
;WIDTH:0.480681
G1 X117.944 Y120.888 E.00296
;WIDTH:0.521022
G1 X117.851 Y120.924 E.00323
;WIDTH:0.561363
G1 X117.758 Y120.959 E.00348
;WIDTH:0.601704
G1 X117.665 Y120.995 E.00376
G1 X117.836 Y121.059 E.00689
;WIDTH:0.561363
G1 X118.007 Y121.123 E.0064
;WIDTH:0.521022
G1 X118.177 Y121.187 E.00588
;WIDTH:0.480681
G1 X118.348 Y121.251 E.00542
;WIDTH:0.44034
G1 X118.519 Y121.315 E.00493
;WIDTH:0.399999
G1 X119.002 Y121.494 E.01253
G1 X119.586 Y121.862 E.01679
G1 X119.829 Y122.064 E.00769
G1 X120.327 Y122.595 E.01771
G1 X120.501 Y122.827 E.00705
G1 X122.365 Y126.033 E.09021
G1 X122.624 Y126.582 E.01477
G1 X122.821 Y127.275 E.01752
G1 X122.885 Y128.111 E.02039
G1 X122.796 Y128.847 E.01803
G1 X122.494 Y129.704 E.0221
G1 X122.409 Y129.882 E.0048
G1 X120.502 Y133.171 E.09248
G1 X119.829 Y133.936 E.02478
G1 X119.357 Y134.301 E.01451
G1 X118.753 Y134.618 E.01659
G1 X118.066 Y134.835 E.01752
G1 X117.233 Y134.928 E.02039
G1 X113.767 Y134.928 E.08431
G1 X112.871 Y134.816 E.02196
G1 X112.564 Y134.734 E.00773
G1 X112.027 Y134.515 E.01411
G1 X111.252 Y134.007 E.02254
G1 X110.737 Y133.479 E.01794
G1 X110.499 Y133.172 E.00945
G1 X108.635 Y129.967 E.09018
G1 X108.376 Y129.418 E.01477
G1 X108.179 Y128.724 E.01755
G1 X108.112 Y128.007 E.01752
G1 X108.145 Y127.473 E.01301
G1 X108.298 Y126.804 E.01669
G1 X108.579 Y126.141 E.01752
G1 X110.499 Y122.828 E.09314
G1 X111.004 Y122.242 E.01882
G1 X111.414 Y121.862 E.0136
G1 X111.903 Y121.549 E.01412
G1 X112.551 Y121.285 E.01702
G1 X113.047 Y121.145 E.01254
;WIDTH:0.44229
G1 X113.225 Y121.104 E.00496
;WIDTH:0.484581
G1 X113.404 Y121.062 E.00551
;WIDTH:0.526872
G1 X113.582 Y121.021 E.00598
;WIDTH:0.553692
G1 X113.649 Y121 E.00243
G1 X113.5 Y120.96 E.00533
;WIDTH:0.515269
G1 X113.35 Y120.921 E.00496
;WIDTH:0.476846
G1 X113.201 Y120.881 E.00454
;WIDTH:0.438423
G1 X113.051 Y120.841 E.00417
;WIDTH:0.399999
G1 X112.564 Y120.734 E.01213
G1 X112.027 Y120.515 E.01411
G1 X111.454 Y120.15 E.01653
G1 X111.036 Y119.814 E.01305
G1 X110.65 Y119.38 E.01413
G1 X110.499 Y119.172 E.00625
G1 X108.635 Y115.967 E.09018
G1 X108.376 Y115.418 E.01477
G1 X108.179 Y114.724 E.01755
G1 X108.112 Y114.007 E.01752
G1 X108.145 Y113.473 E.01301
G1 X108.298 Y112.804 E.01669
G1 X108.579 Y112.141 E.01752
G1 X110.499 Y108.828 E.09314
G1 X111.004 Y108.242 E.01882
G1 X111.414 Y107.862 E.0136
G1 X111.903 Y107.549 E.01412
G1 X112.551 Y107.285 E.01702
G1 X113.047 Y107.145 E.01254
;WIDTH:0.44229
G1 X113.225 Y107.104 E.00496
;WIDTH:0.484581
G1 X113.404 Y107.062 E.00551
;WIDTH:0.526872
G1 X113.582 Y107.021 E.00598
;WIDTH:0.553692
G1 X113.649 Y107 E.00243
G1 X113.5 Y106.96 E.00533
;WIDTH:0.515269
G1 X113.35 Y106.921 E.00496
;WIDTH:0.476846
G1 X113.201 Y106.881 E.00454
;WIDTH:0.438423
G1 X113.051 Y106.841 E.00417
;WIDTH:0.399999
G1 X112.564 Y106.734 E.01213
G1 X112.027 Y106.515 E.01411
G1 X111.454 Y106.15 E.01653
G1 X111.036 Y105.814 E.01305
G1 X110.65 Y105.38 E.01413
G1 X110.499 Y105.172 E.00625
G1 X108.635 Y101.967 E.09018
G1 X108.376 Y101.418 E.01477
G1 X108.179 Y100.724 E.01755
G1 X108.112 Y100.007 E.01752
G1 X108.145 Y99.473 E.01301
G1 X108.294 Y98.821 E.01627
G1 X108.579 Y98.141 E.01793
G1 X110.499 Y94.828 E.09314
G1 X111.171 Y94.064 E.02475
G1 X111.414 Y93.862 E.00769
G1 X111.903 Y93.549 E.01412
G1 X112.767 Y93.209 E.02258
G1 X113.771 Y93.072 E.02465
G1 X117.479 Y93.083 E.09019
G1 X118.122 Y93.182 E.01582
G1 X118.812 Y93.413 E.0177
G1 X119.097 Y93.549 E.00768
G1 X119.586 Y93.862 E.01412
G1 X119.829 Y94.064 E.00769
G1 X120.327 Y94.595 E.01771
G1 X120.501 Y94.827 E.00705
G1 X122.365 Y98.033 E.09021
G1 X122.624 Y98.582 E.01477
G1 X122.821 Y99.275 E.01752
G1 X122.885 Y100.111 E.02039
G1 X122.796 Y100.847 E.01803
G1 X122.743 Y100.997 E.00387
G1 E-5 F3600
G1 X122.743 Y100.997 F9000
G1 X122.044 Y100.792
G1 X121.724 Y115.58
G1 X119.98 Y118.6
G1 X119.83 Y118.835
G1 X119.756 Y118.93
G1 X119.65 Y119.066
G1 E5 F2400
;WIDTH:0.601704
G1 F6000
G1 X117.233 Y121.005 E.01631
;WIDTH:0.553774
G1 X113.649 Y121 E.12384
G1 E-5 F3600
G1 X113.649 Y121 F9000
G1 X111.768 Y122.528
G1 X111.638 Y122.64
G1 X111.549 Y122.722
G1 X111.431 Y122.846
G1 X111.35 Y122.934
G1 X111.244 Y123.069
G1 X111.17 Y123.165
G1 X111.078 Y123.309
G1 X111.02 Y123.4
G1 X109.276 Y126.42
G1 X109.227 Y126.515
G1 X109.148 Y126.668
G1 X109.102 Y126.779
G1 X109.038 Y126.939
G1 X109.002 Y127.053
G1 X108.954 Y127.218
G1 X108.927 Y127.335
G1 X108.895 Y127.504
G1 X108.879 Y127.623
G1 X108.863 Y127.794
G1 X108.858 Y127.914
G1 X108.858 Y128.086
G1 X108.863 Y128.206
G1 X108.879 Y128.377
G1 X108.895 Y128.496
G1 X108.927 Y128.665
G1 X108.954 Y128.782
G1 X109.002 Y128.947
G1 X109.038 Y129.061
G1 X109.102 Y129.221
G1 X109.148 Y129.332
G1 X109.227 Y129.485
G1 X109.276 Y129.58
G1 X112.161 Y134.964
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X111.889 Y134.853 E.00715
G1 X111.558 Y134.672 E.00918
G1 X111.04 Y134.306 E.01543
G1 X110.464 Y133.722 E.01995
G1 X110.183 Y133.356 E.01122
G1 X108.319 Y130.151 E.09018
G1 X108.044 Y129.571 E.01561
;WIDTH:0.435993
G1 X107.917 Y129.197 E.01055
;WIDTH:0.471986
G1 X107.789 Y128.822 E.01154
;WIDTH:0.49988
G1 X107.728 Y128.518 E.0096
G1 X107.702 Y127.926 E.01835
;WIDTH:0.527739
G1 X107.762 Y127.17 E.02489
G1 X107.856 Y126.923 E.00867
;WIDTH:0.485159
G1 X107.95 Y126.676 E.00793
;WIDTH:0.442579
G1 X108.044 Y126.429 E.00718
;WIDTH:0.399999
G1 X108.319 Y125.849 E.01561
G1 X110.183 Y122.644 E.09018
G1 X110.737 Y121.991 E.02083
G1 X111.078 Y121.653 E.01168
G1 X111.542 Y121.346 E.01353
G1 X112.047 Y121.075 E.01394
G1 X112.254 Y121.002 E.00534
G1 X111.694 Y120.759 E.01485
G1 X111.243 Y120.449 E.01331
G1 X110.763 Y120.057 E.01507
G1 X110.376 Y119.623 E.01414
G1 X110.183 Y119.356 E.00801
G1 X108.319 Y116.151 E.09018
G1 X108.044 Y115.571 E.01561
;WIDTH:0.435993
G1 X107.917 Y115.197 E.01055
;WIDTH:0.471986
G1 X107.789 Y114.822 E.01154
;WIDTH:0.49988
G1 X107.728 Y114.518 E.0096
G1 X107.702 Y113.926 E.01835
;WIDTH:0.527738
G1 X107.762 Y113.17 E.02489
G1 X107.856 Y112.923 E.00867
;WIDTH:0.485159
G1 X107.95 Y112.676 E.00793
;WIDTH:0.442579
G1 X108.044 Y112.429 E.00718
;WIDTH:0.399999
G1 X108.319 Y111.849 E.01561
G1 X110.183 Y108.644 E.09018
G1 X110.737 Y107.991 E.02083
G1 X111.078 Y107.653 E.01168
G1 X111.542 Y107.346 E.01353
G1 X112.047 Y107.075 E.01394
G1 X112.254 Y107.002 E.00534
G1 X111.694 Y106.759 E.01485
G1 X111.243 Y106.449 E.01331
G1 X110.763 Y106.057 E.01507
G1 X110.376 Y105.623 E.01414
G1 X110.183 Y105.356 E.00801
G1 X108.319 Y102.151 E.09018
G1 X108.044 Y101.571 E.01561
G1 X107.824 Y100.814 E.01918
G1 X107.747 Y100.03 E.01916
G1 X107.781 Y99.44 E.01437
G1 X107.939 Y98.732 E.01765
G1 X108.319 Y97.849 E.02338
G1 X110.183 Y94.644 E.09018
G1 X110.433 Y94.316 E.01003
G1 X110.904 Y93.814 E.01674
G1 X111.217 Y93.554 E.0099
G1 X111.706 Y93.241 E.01412
G1 X112.047 Y93.075 E.00923
G1 X112.645 Y92.864 E.01542
G1 X113.006 Y92.782 E.009
G1 X113.773 Y92.706 E.01875
G1 X117.48 Y92.717 E.09017
G1 X117.943 Y92.766 E.01132
G1 X118.928 Y93.066 E.02505
G1 X119.294 Y93.241 E.00987
G1 X119.783 Y93.554 E.01412
G1 X120.095 Y93.813 E.00986
G1 X120.594 Y94.344 E.01772
G1 X120.817 Y94.644 E.00909
G1 X122.681 Y97.849 E.09018
G1 X122.956 Y98.429 E.01561
G1 X123.176 Y99.186 E.01918
G1 X123.25 Y100.094 E.02216
G1 X123.157 Y100.903 E.01981
G1 X123.065 Y101.246 E.00864
G1 X122.835 Y101.837 E.01543
G1 X122.509 Y102.438 E.01663
G1 X120.818 Y105.354 E.08199
G1 X120.539 Y105.714 E.01108
G1 X120.095 Y106.187 E.01578
G1 X119.568 Y106.6 E.01629
G1 X118.92 Y106.943 E.01783
G1 X118.753 Y107.008 E.00436
G1 X119.294 Y107.241 E.01433
G1 X119.783 Y107.554 E.01412
G1 X120.096 Y107.814 E.0099
G1 X120.594 Y108.344 E.01769
G1 X120.817 Y108.644 E.00909
G1 X122.681 Y111.849 E.09018
G1 X122.956 Y112.429 E.01561
;WIDTH:0.442587
G1 X123.05 Y112.676 E.00718
;WIDTH:0.485174
G1 X123.144 Y112.923 E.00793
;WIDTH:0.527761
G1 X123.238 Y113.17 E.00867
G1 X123.293 Y114.092 E.03032
;WIDTH:0.534046
G1 X123.224 Y114.914 E.02742
G1 X123.094 Y115.221 E.01108
;WIDTH:0.489364
G1 X122.965 Y115.529 E.01011
;WIDTH:0.444682
G1 X122.835 Y115.837 E.00913
;WIDTH:0.399999
G1 X122.725 Y116.065 E.00616
G1 X120.818 Y119.354 E.09248
G1 X120.539 Y119.714 E.01108
G1 X120.095 Y120.187 E.01578
G1 X119.773 Y120.453 E.01016
G1 X119.306 Y120.759 E.01358
G1 X118.756 Y121.009 E.0147
G1 X119.294 Y121.241 E.01425
G1 X119.783 Y121.554 E.01412
G1 X120.096 Y121.814 E.0099
G1 X120.594 Y122.344 E.01769
G1 X120.817 Y122.644 E.00909
G1 X122.681 Y125.849 E.09018
G1 X122.956 Y126.429 E.01561
;WIDTH:0.442587
G1 X123.05 Y126.676 E.00718
;WIDTH:0.485174
G1 X123.144 Y126.923 E.00793
;WIDTH:0.527761
G1 X123.238 Y127.17 E.00867
G1 X123.293 Y128.092 E.03032
;WIDTH:0.534046
G1 X123.224 Y128.914 E.02742
G1 X123.094 Y129.221 E.01108
;WIDTH:0.489364
G1 X122.965 Y129.529 E.01011
;WIDTH:0.444682
G1 X122.835 Y129.837 E.00913
;WIDTH:0.399999
G1 X122.725 Y130.065 E.00616
G1 X120.818 Y133.355 E.0925
G1 X120.567 Y133.684 E.01007
G1 X120.096 Y134.186 E.01674
G1 X119.568 Y134.6 E.01632
G1 X118.916 Y134.945 E.01794
G1 X118.165 Y135.187 E.01919
G1 X117.233 Y135.294 E.02282
G1 X113.767 Y135.294 E.08431
G1 X112.82 Y135.178 E.02321
G1 X112.427 Y135.072 E.0099
G1 X112.217 Y134.987 E.00551
G1 E-5 F3600
G1 X112.217 Y134.987 F9000
G1 X109.276 Y129.58
G1 X109.276 Y126.42
G1 X111.02 Y123.4
G1 X111.17 Y123.165
G1 X111.35 Y122.934
G1 X111.638 Y122.64
G1 X111.863 Y122.455
G1 X112.003 Y122.355
G1 X115.099 Y120.18
G1 X117.244 Y120.18
G1 X117.351 Y120.175
G1 X117.523 Y120.167
G1 X117.642 Y120.151
G1 X117.812 Y120.127
G1 X117.929 Y120.101
G1 X118.096 Y120.06
G1 X118.211 Y120.024
G1 X118.373 Y119.968
G1 X118.484 Y119.922
G1 X118.64 Y119.851
G1 X118.747 Y119.795
G1 X118.895 Y119.709
G1 X118.997 Y119.645
G1 X119.137 Y119.545
G1 X119.232 Y119.472
G1 X119.362 Y119.36
G1 X119.65 Y119.066
G1 X119.756 Y118.93
G1 X119.83 Y118.835
G1 X119.98 Y118.6
G1 X121.724 Y115.58
G1 X121.724 Y112.42
G1 X119.98 Y109.4
G1 X119.922 Y109.309
G1 X119.83 Y109.165
G1 X119.756 Y109.07
G1 X119.65 Y108.934
G1 X119.569 Y108.846
G1 X119.451 Y108.722
G1 E5 F2400
;WIDTH:0.601706
G1 F6000
G1 X117.233 Y107.005 E.01631
;WIDTH:0.553774
G1 X113.649 Y107 E.12384
G1 X113.649 Y107 F9000
G1 X113.703 Y105.822
;WIDTH:0.399999
G1 F6000
G1 X112.978 Y105.718 E.01782
G1 X112.418 Y105.488 E.01473
G1 X111.886 Y105.112 E.01585
G1 X111.447 Y104.621 E.01602
G1 X109.584 Y101.415 E.09019
G1 X109.373 Y100.959 E.01222
G1 X109.242 Y100.456 E.01264
G1 X109.207 Y99.937 E.01265
G1 X109.243 Y99.544 E.0096
G1 X109.373 Y99.041 E.01264
G1 X109.584 Y98.585 E.01222
G1 X111.447 Y95.379 E.09019
G1 X111.97 Y94.815 E.01871
G1 X112.494 Y94.473 E.01522
G1 X113.13 Y94.244 E.01644
G1 X113.768 Y94.169 E.01563
G1 X117.475 Y94.18 E.09017
G1 X117.774 Y94.223 E.00735
G1 X118.465 Y94.453 E.01771
G1 X118.994 Y94.786 E.0152
G1 X119.553 Y95.379 E.01982
G1 X121.416 Y98.585 E.09019
G1 X121.627 Y99.041 E.01222
G1 X121.757 Y99.544 E.01264
G1 X121.789 Y100.161 E.01503
G1 X121.712 Y100.677 E.01269
G1 X121.472 Y101.306 E.01638
G1 X119.553 Y104.621 E.09317
G1 X119.029 Y105.185 E.01873
G1 X118.671 Y105.434 E.01061
G1 X118.234 Y105.647 E.01183
G1 X117.742 Y105.785 E.01243
G1 X117.233 Y105.831 E.01243
G1 X113.767 Y105.831 E.08431
G1 X113.763 Y105.831 E.0001
G1 X113.763 Y105.831 F9000
G1 X113.742 Y106.194
;TYPE:Perimeter
G1 F6000
G1 X113.152 Y106.117 E.01447
G1 X112.84 Y106.056 E.00773
G1 X112.237 Y105.806 E.01588
G1 X111.675 Y105.41 E.01672
G1 X111.131 Y104.805 E.01979
G1 X109.268 Y101.599 E.09019
G1 X109.041 Y101.112 E.01307
G1 X108.888 Y100.545 E.01429
G1 X108.842 Y99.96 E.01427
G1 X108.888 Y99.455 E.01233
G1 X109.041 Y98.888 E.01429
G1 X109.268 Y98.401 E.01307
G1 X111.131 Y95.195 E.09019
G1 X111.704 Y94.565 E.02071
G1 X112.297 Y94.165 E.0174
G1 X113.009 Y93.899 E.01849
G1 X113.769 Y93.803 E.01863
G1 X117.477 Y93.814 E.09019
G1 X117.89 Y93.876 E.01016
G1 X118.581 Y94.107 E.01772
G1 X119.191 Y94.478 E.01737
G1 X119.768 Y95.067 E.02006
G1 X119.869 Y95.195 E.00397
G1 X121.732 Y98.401 E.09019
G1 X121.959 Y98.888 E.01307
G1 X122.112 Y99.454 E.01426
G1 X122.155 Y100.144 E.01682
G1 X122.074 Y100.734 E.01449
G1 X121.813 Y101.439 E.01829
G1 X119.869 Y104.804 E.09453
G1 X119.296 Y105.436 E.02075
G1 X118.863 Y105.746 E.01295
G1 X118.334 Y105.999 E.01426
G1 X117.792 Y106.147 E.01367
G1 X117.233 Y106.197 E.01365
G1 X113.802 Y106.197 E.08346
G1 X113.802 Y106.197 F9000
G1 X113.802 Y106.563
G1 F6000
G1 X113.767 Y106.563 E.00085
G1 X113.101 Y106.479 E.01633
G1 X112.702 Y106.395 E.00992
G1 X112.056 Y106.123 E.01705
G1 X111.463 Y105.709 E.01759
G1 X111.039 Y105.267 E.0149
G1 X110.815 Y104.988 E.0087
G1 X108.952 Y101.783 E.09017
G1 X108.708 Y101.265 E.01393
G1 X108.533 Y100.635 E.0159
G1 X108.477 Y99.983 E.01592
G1 X108.512 Y99.484 E.01217
G1 X108.648 Y98.911 E.01432
G1 X108.952 Y98.217 E.01843
G1 X110.815 Y95.011 E.09019
G1 X111.437 Y94.314 E.02272
G1 X112.1 Y93.857 E.01959
G1 X112.888 Y93.554 E.02054
G1 X113.77 Y93.437 E.02164
G1 X117.478 Y93.448 E.09019
G1 X118.006 Y93.529 E.01299
G1 X118.696 Y93.76 E.0177
G1 X119.389 Y94.17 E.01959
G1 X120.034 Y94.817 E.02222
G1 X120.185 Y95.011 E.00598
G1 X122.048 Y98.217 E.09019
G1 X122.292 Y98.735 E.01393
G1 X122.467 Y99.365 E.0159
G1 X122.52 Y100.127 E.01858
G1 X122.435 Y100.79 E.01626
G1 X122.154 Y101.572 E.02021
G1 X120.185 Y104.988 E.09591
G1 X119.563 Y105.686 E.02274
G1 X119.147 Y106.002 E.01271
G1 X118.595 Y106.288 E.01512
G1 X118.031 Y106.465 E.01438
G1 X117.233 Y106.563 E.01956
G1 X113.862 Y106.563 E.082
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.802 Y106.563 E-.0285
G1 X113.767 Y106.563 E-.01663
G1 X113.101 Y106.479 E-.31886
G1 X112.702 Y106.395 E-.19368
G1 X112.056 Y106.123 E-.33294
G1 X111.463 Y105.709 E-.34353
G1 X111.075 Y105.306 E-.26586
;WIPE_END
G1 X111.35 Y105.066 F9000
G1 X108.954 Y113.218
G1 X108.927 Y113.335
G1 X108.895 Y113.504
G1 X108.879 Y113.623
G1 X108.863 Y113.794
G1 X108.858 Y113.914
G1 X108.858 Y114.086
G1 X108.863 Y114.206
G1 X108.879 Y114.377
G1 X108.895 Y114.496
G1 X108.927 Y114.665
G1 X108.954 Y114.782
G1 X109.002 Y114.947
G1 X109.038 Y115.061
G1 X109.102 Y115.221
G1 X109.148 Y115.332
G1 X109.227 Y115.485
G1 X109.276 Y115.58
G1 X111.02 Y118.6
G1 X111.078 Y118.691
G1 X111.17 Y118.835
G1 X111.244 Y118.93
G1 X111.35 Y119.066
G1 X111.431 Y119.154
G1 X111.549 Y119.278
G1 X111.638 Y119.36
G1 X111.768 Y119.472
G1 X111.863 Y119.545
G1 X112.003 Y119.645
G1 X112.105 Y119.709
G1 X112.253 Y119.795
G1 X112.36 Y119.851
G1 X112.516 Y119.922
G1 X112.627 Y119.968
G1 X112.789 Y120.024
G1 X112.904 Y120.06
G1 X113.071 Y120.101
G1 X113.188 Y120.127
G1 X113.358 Y120.151
G1 X113.477 Y120.167
G1 X113.531 Y120.17
G1 X113.862 Y121.82
G1 X113.862 Y122.169
G1 E5 F2400
G1 F6000
G1 X117.475 Y122.18 E.08788
G1 X117.774 Y122.223 E.00735
G1 X118.465 Y122.453 E.01771
G1 X118.994 Y122.786 E.0152
G1 X119.553 Y123.379 E.01982
G1 X121.416 Y126.585 E.09019
G1 X121.627 Y127.041 E.01222
G1 X121.757 Y127.544 E.01264
G1 X121.789 Y128.161 E.01503
G1 X121.712 Y128.677 E.01269
G1 X121.472 Y129.306 E.01638
G1 X119.553 Y132.621 E.09317
G1 X119.029 Y133.185 E.01873
G1 X118.701 Y133.419 E.0098
G1 X118.234 Y133.647 E.01264
G1 X117.748 Y133.784 E.01228
G1 X117.233 Y133.831 E.01258
G1 X113.767 Y133.831 E.08431
G1 X113.022 Y133.729 E.01829
G1 X112.44 Y133.499 E.01522
G1 X111.886 Y133.112 E.01644
G1 X111.447 Y132.621 E.01602
G1 X109.584 Y129.415 E.09019
G1 X109.373 Y128.959 E.01222
G1 X109.242 Y128.456 E.01264
G1 X109.207 Y127.937 E.01265
G1 X109.243 Y127.544 E.0096
G1 X109.373 Y127.041 E.01264
G1 X109.584 Y126.585 E.01222
G1 X111.447 Y123.379 E.09019
G1 X112.005 Y122.786 E.01981
G1 X112.494 Y122.473 E.01412
G1 X113.13 Y122.244 E.01644
G1 X113.768 Y122.169 E.01563
G1 X113.802 Y122.169 E.00083
G1 X113.802 Y122.169 F9000
G1 X113.802 Y121.807
;TYPE:Perimeter
G1 F6000
G1 X117.477 Y121.814 E.08939
G1 X117.89 Y121.876 E.01016
G1 X118.581 Y122.107 E.01772
G1 X119.191 Y122.478 E.01737
G1 X119.74 Y123.037 E.01906
G1 X119.869 Y123.195 E.00496
G1 X121.732 Y126.401 E.09019
G1 X121.959 Y126.888 E.01307
G1 X122.112 Y127.454 E.01426
G1 X122.155 Y128.144 E.01682
G1 X122.074 Y128.734 E.01449
G1 X121.813 Y129.439 E.01829
G1 X119.869 Y132.804 E.09453
G1 X119.296 Y133.436 E.02075
G1 X118.863 Y133.746 E.01295
G1 X118.334 Y133.999 E.01426
G1 X117.811 Y134.144 E.0132
G1 X117.233 Y134.197 E.01412
G1 X113.767 Y134.197 E.08431
G1 X112.971 Y134.092 E.01953
G1 X112.302 Y133.837 E.01741
G1 X111.675 Y133.41 E.01845
G1 X111.131 Y132.805 E.01979
G1 X109.268 Y129.599 E.09019
G1 X109.041 Y129.112 E.01307
G1 X108.888 Y128.545 E.01429
G1 X108.842 Y127.96 E.01427
G1 X108.888 Y127.455 E.01233
G1 X109.041 Y126.888 E.01429
G1 X109.268 Y126.401 E.01307
G1 X111.131 Y123.195 E.09019
G1 X111.537 Y122.742 E.0148
G1 X111.808 Y122.478 E.0092
G1 X112.297 Y122.165 E.01412
G1 X112.794 Y121.975 E.01294
G1 X113.129 Y121.872 E.00852
G1 X113.706 Y121.806 E.01413
G1 X113.742 Y121.807 E.00088
G1 X113.742 Y121.807 F9000
G1 X113.725 Y121.443
G1 F6000
G1 X117.478 Y121.448 E.09129
G1 X118.006 Y121.529 E.01299
G1 X118.696 Y121.76 E.0177
G1 X119.389 Y122.17 E.01959
G1 X120.006 Y122.787 E.02122
G1 X120.185 Y123.011 E.00697
G1 X122.048 Y126.217 E.09019
G1 X122.292 Y126.735 E.01393
G1 X122.467 Y127.365 E.0159
G1 X122.52 Y128.127 E.01858
G1 X122.435 Y128.79 E.01626
G1 X122.154 Y129.572 E.02021
G1 X120.185 Y132.988 E.09591
G1 X119.563 Y133.686 E.02274
G1 X119.147 Y134.002 E.01271
G1 X118.591 Y134.29 E.01523
G1 X117.966 Y134.483 E.01591
G1 X117.233 Y134.563 E.01794
G1 X113.767 Y134.563 E.08431
G1 X112.921 Y134.454 E.02075
G1 X112.164 Y134.176 E.01962
G1 X111.463 Y133.709 E.02049
G1 X111.01 Y133.236 E.01593
G1 X110.815 Y132.988 E.00767
G1 X108.952 Y129.783 E.09017
G1 X108.708 Y129.265 E.01393
G1 X108.533 Y128.635 E.0159
G1 X108.477 Y127.983 E.01592
G1 X108.533 Y127.365 E.01509
G1 X108.708 Y126.735 E.0159
G1 X108.952 Y126.217 E.01393
G1 X110.815 Y123.011 E.09019
G1 X111.27 Y122.492 E.01679
G1 X111.611 Y122.17 E.01141
G1 X112.1 Y121.857 E.01412
G1 X112.672 Y121.63 E.01497
G1 X113.088 Y121.508 E.01054
G1 X113.665 Y121.443 E.01412
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.725 Y121.443 E-.0285
G1 X116.823 Y121.448 E-1.4715
;WIPE_END
G1 X116.823 Y121.82 F9000
G1 X113.756 Y121.82
G1 X113.649 Y121.825
G1 X113.477 Y121.833
G1 X113.358 Y121.849
G1 X113.188 Y121.873
G1 X113.071 Y121.899
G1 X112.904 Y121.94
G1 X112.789 Y121.976
G1 X112.627 Y122.032
G1 X112.516 Y122.078
G1 X112.36 Y122.149
G1 X112.253 Y122.205
G1 X112.105 Y122.291
G1 X111.638 Y122.64
G1 X111.35 Y122.934
G1 X111.17 Y123.165
G1 X111.02 Y123.4
G1 X109.276 Y126.42
G1 X109.276 Y129.58
G1 X109.959 Y130.762
G1 X106.099 Y136.512
G1 X105.721 Y136.512
G1 E5 F2400
G1 F6000
G1 X105.75 Y136.459 E.00147
G1 X105.75 Y103.607 E.79909
G1 X105.74 Y103.547 E.00148
G1 X105.616 Y103.459 E.0037
G1 X105.616 Y98.791 E.11354
G1 X105.738 Y98.707 E.0036
G1 X105.75 Y98.642 E.00161
G1 X105.75 Y91.541 E.17272
G1 X105.717 Y91.436 E.00268
G1 X105.48 Y91.101 E.00998
G1 X105.294 Y90.715 E.01042
G1 X105.272 Y90.385 E.00804
G1 X105.339 Y90.152 E.0059
G1 X105.61 Y89.716 E.01249
G1 X125.39 Y89.716 E.48113
G1 X125.658 Y90.148 E.01237
G1 X125.736 Y90.507 E.00894
G1 X125.666 Y90.791 E.00711
G1 X125.25 Y91.541 E.02086
G1 X125.255 Y98.684 E.17375
G1 X125.384 Y98.791 E.00408
G1 X125.384 Y103.459 E.11354
G1 X125.26 Y103.547 E.0037
G1 X125.25 Y103.607 E.00148
G1 X125.25 Y136.459 E.79909
G1 X125.283 Y136.564 E.00268
G1 X125.52 Y136.899 E.00998
G1 X125.651 Y137.156 E.00702
G1 X125.715 Y137.423 E.00668
G1 X125.728 Y137.615 E.00468
G1 X125.661 Y137.848 E.0059
G1 X125.39 Y138.284 E.01249
G1 X105.61 Y138.284 E.48113
G1 X105.342 Y137.852 E.01237
G1 X105.264 Y137.493 E.00894
G1 X105.334 Y137.209 E.00711
G1 X105.692 Y136.564 E.01794
G1 X105.692 Y136.564 F9000
G1 X106.06 Y136.625
;TYPE:Perimeter
G1 F6000
G1 X106.116 Y136.459 E.00426
G1 X106.116 Y103.607 E.79909
G1 X106.085 Y103.427 E.00444
G1 X105.982 Y103.354 E.00307
G1 X105.982 Y98.905 E.10822
G1 X106.079 Y98.839 E.00285
G1 X106.116 Y98.642 E.00488
G1 X106.116 Y91.541 E.17272
G1 X106.016 Y91.225 E.00806
G1 X105.685 Y90.699 E.01512
G1 X105.641 Y90.425 E.00675
G1 X105.813 Y90.082 E.00933
G1 X125.187 Y90.082 E.47125
G1 X125.284 Y90.239 E.00449
G1 X125.365 Y90.522 E.00716
G1 X125.172 Y90.96 E.01164
G1 X124.996 Y91.21 E.00744
G1 X124.884 Y91.541 E.0085
G1 X124.884 Y98.247 E.16312
G1 X124.914 Y98.818 E.01391
G1 X125.018 Y98.905 E.0033
G1 X125.018 Y103.354 E.10822
G1 X124.915 Y103.427 E.00307
G1 X124.884 Y103.607 E.00444
G1 X124.884 Y136.459 E.79909
G1 X124.984 Y136.775 E.00806
G1 X125.251 Y137.154 E.01128
G1 X125.35 Y137.447 E.00752
G1 X125.359 Y137.575 E.00312
G1 X125.187 Y137.918 E.00933
G1 X105.814 Y137.918 E.47123
G1 X105.716 Y137.761 E.0045
G1 X105.635 Y137.478 E.00716
G1 X105.828 Y137.04 E.01164
G1 X106.004 Y136.79 E.00744
G1 X106.041 Y136.681 E.0028
G1 X106.041 Y136.681 F9000
G1 X106.389 Y136.735
G1 F6000
G1 X106.481 Y136.459 E.00708
G1 X106.481 Y103.607 E.79909
G1 X106.43 Y103.306 E.00743
G1 X106.348 Y103.248 E.00244
G1 X106.348 Y99.02 E.10284
G1 X106.42 Y98.97 E.00213
G1 X106.481 Y98.642 E.00812
G1 X106.481 Y91.541 E.17272
G1 X106.314 Y91.015 E.01342
G1 X106.02 Y90.554 E.0133
G1 X106.017 Y90.448 E.00258
G1 X124.975 Y90.448 E.46113
G1 X124.98 Y90.528 E.00195
G1 X124.704 Y90.989 E.01307
G1 X124.519 Y91.541 E.01416
G1 X124.519 Y98.624 E.17229
G1 X124.568 Y98.936 E.00768
G1 X124.652 Y99.02 E.00289
G1 X124.652 Y103.248 E.10284
G1 X124.57 Y103.307 E.00246
G1 X124.519 Y103.607 E.0074
G1 X124.519 Y136.459 E.79909
G1 X124.686 Y136.985 E.01342
G1 X124.922 Y137.321 E.00999
G1 X124.986 Y137.471 E.00397
G1 X124.983 Y137.552 E.00197
G1 X106.025 Y137.552 E.46113
G1 X106.02 Y137.472 E.00195
G1 X106.296 Y137.011 E.01307
G1 X106.369 Y136.792 E.00562
G1 X106.369 Y136.792 F9000
G1 X106.717 Y136.845
G1 F6000
G1 X106.847 Y136.459 E.00991
G1 X106.847 Y103.607 E.79909
G1 X106.776 Y103.186 E.01039
G1 X106.713 Y103.142 E.00187
G1 X106.713 Y99.134 E.09749
G1 X106.761 Y99.101 E.00142
G1 X106.847 Y98.642 E.01136
G1 X106.847 Y91.541 E.17272
G1 X106.616 Y90.813 E.01858
G1 X124.398 Y90.813 E.43253
G1 X124.153 Y91.541 E.01868
G1 X124.153 Y98.624 E.17229
G1 X124.221 Y99.054 E.01059
G1 X124.287 Y99.134 E.00252
G1 X124.287 Y103.142 E.09749
G1 X124.224 Y103.186 E.00187
G1 X124.153 Y103.607 E.01039
G1 X124.153 Y136.459 E.79909
G1 X124.384 Y137.187 E.01858
G1 X106.602 Y137.187 E.43253
G1 X106.698 Y136.902 E.00732
G1 X106.698 Y136.902 F9000
G1 X107.091 Y136.821
G1 F6000
G1 X107.213 Y136.459 E.00929
G1 X107.213 Y129.376 E.17229
;WIDTH:0.44994
G1 X107.238 Y128.954 E.01169
;WIDTH:0.49988
G1 X107.263 Y128.532 E.01309
G1 X107.256 Y127.752 E.02416
;WIDTH:0.527739
G1 X107.277 Y127.11 E.02108
G1 X107.255 Y126.948 E.00537
;WIDTH:0.485159
G1 X107.234 Y126.786 E.0049
;WIDTH:0.442579
G1 X107.213 Y126.624 E.00444
;WIDTH:0.399999
G1 X107.213 Y115.376 E.2736
;WIDTH:0.44994
G1 X107.238 Y114.954 E.01169
;WIDTH:0.49988
G1 X107.263 Y114.532 E.01309
G1 X107.256 Y113.752 E.02416
;WIDTH:0.527738
G1 X107.277 Y113.11 E.02108
G1 X107.255 Y112.948 E.00537
;WIDTH:0.485159
G1 X107.234 Y112.786 E.0049
;WIDTH:0.442579
G1 X107.213 Y112.624 E.00444
;WIDTH:0.399999
G1 X107.213 Y103.607 E.21933
G1 X107.121 Y103.066 E.01335
G1 X107.079 Y103.036 E.00126
G1 X107.079 Y99.36 E.08942
G1 X107.213 Y98.642 E.01777
G1 X107.213 Y91.541 E.17272
G1 X107.098 Y91.179 E.00924
G1 X123.909 Y91.179 E.40891
G1 X123.787 Y91.541 E.00929
G1 X123.787 Y98.247 E.16312
G1 X123.833 Y99.024 E.01893
G1 X123.921 Y99.249 E.00588
G1 X123.921 Y103.036 E.09211
G1 X123.879 Y103.066 E.00126
G1 X123.787 Y103.607 E.01335
G1 X123.787 Y112.624 E.21933
;WIDTH:0.442587
G1 X123.766 Y112.786 E.00444
;WIDTH:0.485174
G1 X123.745 Y112.948 E.0049
;WIDTH:0.527761
G1 X123.723 Y113.11 E.00537
G1 X123.738 Y113.501 E.01284
;WIDTH:0.499021
G1 X123.745 Y114.169 E.02065
;WIDTH:0.534046
G1 X123.72 Y114.952 E.02604
G1 X123.742 Y115.095 E.00481
;WIDTH:0.489749
G1 X123.765 Y115.239 E.00442
;WIDTH:0.445451
G1 X123.787 Y115.382 E.00396
;WIDTH:0.401153
G1 X123.787 Y116.016 E.01547
;WIDTH:0.399999
G1 X123.787 Y126.624 E.25803
;WIDTH:0.442587
G1 X123.766 Y126.786 E.00444
;WIDTH:0.485174
G1 X123.745 Y126.948 E.0049
;WIDTH:0.527761
G1 X123.723 Y127.11 E.00537
G1 X123.738 Y127.501 E.01284
;WIDTH:0.499021
G1 X123.745 Y128.169 E.02065
;WIDTH:0.534046
G1 X123.72 Y128.952 E.02604
G1 X123.742 Y129.095 E.00481
;WIDTH:0.489749
G1 X123.765 Y129.239 E.00442
;WIDTH:0.445451
G1 X123.787 Y129.382 E.00396
;WIDTH:0.401153
G1 X123.787 Y130.016 E.01547
;WIDTH:0.399999
G1 X123.787 Y136.459 E.15672
G1 X123.902 Y136.821 E.00924
G1 X107.151 Y136.821 E.40745
G1 E-5 F3600
G1 X107.151 Y136.821 F9000
G1 X107.564 Y129.094
G1 E5 F2400
;TYPE:Solid infill
G1 F1200
G1 X107.797 Y129.689 E.01554
G1 X108.084 Y130.292 E.01624
G1 X109.943 Y133.49 E.08998
G1 X110.55 Y134.23 E.02328
G1 X110.886 Y134.532 E.01099
G1 X111.395 Y134.893 E.01518
G1 X111.79 Y135.109 E.01095
G1 X112.318 Y135.324 E.01387
G1 X112.788 Y135.451 E.01184
G1 X113.771 Y135.568 E.02408
G1 X117.244 Y135.568 E.08448
G1 X116.99 Y135.847 E.00918
G1 X116.937 Y135.999 E.00392
G1 X117.072 Y136.189 E.00567
G1 X117.105 Y136.547 E.00874
G1 X107.465 Y136.547 E.23448
G1 X107.487 Y136.444 E.00256
G1 X107.487 Y129.735 E.16319
G1 X107.519 Y129.245 E.01194
G1 X107.519 Y129.245 F9000
G1 X107.853 Y130.621
G1 F1200
G1 X109.627 Y133.674 E.08589
G1 X110.268 Y134.463 E.02473
G1 X110.675 Y134.831 E.01335
G1 X111.184 Y135.191 E.01516
G1 X111.652 Y135.448 E.01299
G1 X112.245 Y135.685 E.01553
;WIDTH:0.402305
G1 X112.738 Y135.814 E.01247
G1 X113.365 Y135.879 E.01543
;WIDTH:0.407063
G1 X113.425 Y135.909 E.00166
;WIDTH:0.455433
G1 X113.485 Y135.938 E.00187
;WIDTH:0.503803
G1 X113.544 Y135.968 E.00207
;WIDTH:0.552174
G1 X113.604 Y135.998 E.00231
;WIDTH:0.600544
G1 X113.664 Y136.027 E.00251
;WIDTH:0.648914
G1 X113.724 Y136.057 E.00274
G1 X113.66 Y136.081 E.00279
;WIDTH:0.600544
G1 X113.597 Y136.105 E.00254
;WIDTH:0.552174
G1 X113.533 Y136.129 E.00235
;WIDTH:0.503803
G1 X113.47 Y136.153 E.00211
;WIDTH:0.455433
G1 X113.406 Y136.178 E.00192
;WIDTH:0.407063
G1 X113.342 Y136.202 E.00169
;WIDTH:0.402305
G1 X112.179 Y136.181 E.02847
;WIDTH:0.399999
G1 X107.853 Y136.181 E.10523
G1 X107.853 Y130.804 E.13079
G1 X107.853 Y130.804 F9000
G1 X108.218 Y131.977
G1 F1200
G1 X109.311 Y133.857 E.0529
G1 X110.082 Y134.795 E.02953
G1 X110.463 Y135.129 E.01232
G1 X111.061 Y135.545 E.01772
G1 X111.585 Y135.816 E.01435
G1 X108.218 Y135.816 E.0819
G1 X108.218 Y132.16 E.08893
G1 X108.218 Y132.16 F9000
G1 X108.584 Y133.334
G1 F1200
G1 X109.113 Y134.211 E.02491
G1 X109.838 Y135.068 E.0273
G1 X110.284 Y135.45 E.01428
G1 X108.584 Y135.45 E.04135
G1 X108.584 Y133.517 E.04702
G1 X108.584 Y133.517 F9000
G1 X108.924 Y134.516
;WIDTH:0.348256
G1 F1200
G1 X109.413 Y135.11 E.01607
G1 X108.924 Y135.11 E.01021
G1 X108.924 Y134.698 E.0086
G1 E-5 F3600
G1 X108.924 Y134.698 F9000
G1 E5 F2400
;WIDTH:0.648914
G1 F1200
G1 X113.771 Y136.058 E.00192
;WIDTH:0.64731
G1 X116.452 Y136.058 E.10932
G1 X116.452 Y136.058 F9000
G1 X117.377 Y135.977
;WIDTH:0.399999
G1 F1200
G1 X117.834 Y135.52 E.01572
G1 X118.492 Y135.379 E.01637
G1 X117.421 Y136.45 E.03684
G1 E-5 F3600
G1 X117.421 Y136.45 F9000
G1 X123.335 Y129.349
G1 E5 F2400
;WIDTH:0.410891
G1 F1200
G1 X123.115 Y129.889 E.01461
G1 X123.131 Y129.965 E.00195
G1 X123.272 Y130.071 E.00442
G1 X123.507 Y130.134 E.00609
G1 X123.507 Y129.398 E.01844
G1 X123.437 Y129.198 E.00531
G1 X123.437 Y129.198 F9000
G1 X122.998 Y130.357
;WIDTH:0.399999
G1 F1200
G1 X122.702 Y130.652 E.01017
G1 X122.544 Y130.9 E.00715
;WIDTH:0.374336
G1 X122.473 Y130.881 E.00166
G1 X122.492 Y130.952 E.00166
G1 X122.533 Y130.941 E.00096
G1 X123.405 Y130.466 F9000
;WIDTH:0.399999
G1 F1200
G1 X121.988 Y131.883 E.04874
G1 X121.83 Y132.131 E.00715
;WIDTH:0.374336
G1 X121.759 Y132.112 E.00166
G1 X121.778 Y132.183 E.00166
G1 X121.819 Y132.172 E.00096
G1 E-5 F3600
G1 X121.819 Y132.172 F9000
G1 X123.512 Y130.876
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X121.275 Y133.114 E.07697
G1 X121.068 Y133.372 E.00805
;WIDTH:0.374336
G1 X120.724 Y133.789 E.01223
G1 X119.961 Y134.55 E.02437
G1 X119.614 Y134.834 E.01014
;WIDTH:0.399999
G1 X119.355 Y135.033 E.00794
G1 X117.842 Y136.547 E.05206
G1 X118.13 Y136.684 E.00776
;WIDTH:0.374336
G1 X118.089 Y136.695 E.00096
G1 X118.07 Y136.624 E.00166
G1 X118.141 Y136.643 E.00166
;WIDTH:0.399999
G1 X118.359 Y136.547 E.00579
G1 X123.512 Y131.393 E.17728
G1 X123.512 Y131.91 E.01258
G1 X118.876 Y136.547 E.15949
G1 X119.393 Y136.547 E.01258
G1 X123.512 Y132.427 E.14171
G1 X123.513 Y132.944 E.01258
G1 X119.91 Y136.547 E.12394
G1 X120.427 Y136.547 E.01258
G1 X123.513 Y133.461 E.10616
G1 X123.513 Y133.979 E.0126
G1 X120.944 Y136.547 E.08835
G1 X121.461 Y136.547 E.01258
G1 X123.513 Y134.496 E.07057
G1 X123.513 Y135.013 E.01258
G1 X121.979 Y136.547 E.05277
G1 X122.496 Y136.547 E.01258
G1 X123.513 Y135.53 E.03498
G1 X123.513 Y136.047 E.01258
G1 X123.013 Y136.547 E.0172
G1 X122.914 Y136.692 E.00427
;WIDTH:0.374336
G1 X122.842 Y136.673 E.00168
G1 X122.862 Y136.744 E.00167
G1 X122.903 Y136.733 E.00096
;WIDTH:0.399999
G1 X123.565 Y136.578 E.01654
;WIDTH:0.402388
G1 X123.521 Y136.59 E.00112
G1 X123.5 Y136.513 E.00195
G1 X123.577 Y136.534 E.00195
G1 E-5 F3600
G1 X123.577 Y136.534 F9000
G1 X123.437 Y115.198
G1 E5 F2400
;WIDTH:0.411317
G1 F1200
G1 X123.506 Y115.398 E.00531
G1 X123.506 Y116.134 E.01846
G1 X123.26 Y116.068 E.00639
G1 X123.097 Y115.935 E.00528
G1 X123.335 Y115.35 E.01584
G1 X123.335 Y115.35 F9000
G1 X122.986 Y116.354
;WIDTH:0.399999
G1 F1200
G1 X122.721 Y116.619 E.00912
G1 X122.564 Y116.866 E.00712
;WIDTH:0.374336
G1 X122.493 Y116.847 E.00166
G1 X122.512 Y116.918 E.00166
G1 X122.553 Y116.907 E.00096
G1 X122.553 Y116.907 F9000
G1 X123.394 Y116.463
;WIDTH:0.399999
G1 F1200
G1 X122.008 Y117.849 E.04768
G1 X121.85 Y118.097 E.00715
;WIDTH:0.374336
G1 X121.779 Y118.078 E.00166
G1 X121.798 Y118.149 E.00166
G1 X121.839 Y118.138 E.00096
G1 X121.294 Y119.08 F9000
;WIDTH:0.399999
G1 F1200
G1 X123.512 Y116.862 E.0763
G1 E-5 F3600
G1 X123.512 Y116.862 F9000
G1 X121.088 Y119.339
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X120.733 Y119.772 E.01266
G1 X120.09 Y120.429 E.02079
G1 X119.39 Y121.003 E.02047
;WIDTH:0.399999
G1 X119.707 Y121.184 E.00888
G1 X123.512 Y117.379 E.13089
G1 X123.512 Y117.896 E.01258
G1 X120.02 Y121.389 E.12014
G1 X120.292 Y121.634 E.0089
G1 X123.512 Y118.413 E.11078
G1 X123.512 Y118.93 E.01258
G1 X120.545 Y121.897 E.10206
G1 E-5 F3600
G1 X120.545 Y121.897 F9000
G1 X123.383 Y119.577
G1 E5 F2400
G1 F1200
G1 X120.788 Y122.172 E.08927
G1 X121.057 Y122.51 E.01051
G1 X122.916 Y125.708 E.08998
G1 X123.313 Y126.622 E.02424
G1 X123.446 Y126.866 E.00676
G1 X123.513 Y126.581 E.00712
G1 X123.512 Y119.448 E.1735
G1 X123.512 Y119.448 F9000
G1 X123.147 Y120.33
G1 F1200
G1 X123.147 Y125.379 E.12281
G1 X121.61 Y122.734 E.07441
G1 X121.278 Y122.199 E.01532
G1 X123.018 Y120.46 E.05984
G1 X123.018 Y120.46 F9000
G1 X122.781 Y121.213
G1 F1200
G1 X122.782 Y124.022 E.06833
G1 X121.749 Y122.245 E.05
G1 X122.652 Y121.342 E.03106
G1 X122.652 Y121.342 F9000
G1 X122.389 Y122.302
;WIDTH:0.586028
G1 F1200
G1 X122.341 Y122.254 E.00249
G1 X122.274 Y122.271 E.00254
G1 X122.256 Y122.338 E.00255
G1 X122.305 Y122.387 E.00254
G1 X122.371 Y122.369 E.00251
G1 E-5 F3600
G1 X122.371 Y122.369 F9000
G1 X112.904 Y120.06
G1 X112.36 Y119.851
G1 X111.638 Y119.36
G1 X107.564 Y115.094
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X107.797 Y115.689 E.01554
G1 X108.084 Y116.292 E.01624
G1 X109.943 Y119.49 E.08998
G1 X110.211 Y119.835 E.01063
G1 X107.487 Y122.559 E.0937
G1 X107.487 Y115.735 E.16599
G1 X107.519 Y115.245 E.01194
G1 X107.519 Y115.245 F9000
G1 X107.853 Y116.621
G1 F1200
G1 X109.392 Y119.268 E.07448
G1 X109.724 Y119.805 E.01536
G1 X107.853 Y121.676 E.06436
G1 X107.853 Y116.804 E.11851
G1 X107.853 Y116.804 F9000
G1 X108.218 Y117.977
G1 F1200
G1 X109.253 Y119.758 E.0501
G1 X108.218 Y120.793 E.0356
G1 X108.218 Y118.16 E.06405
G1 X108.218 Y118.16 F9000
G1 X108.745 Y119.665
;WIDTH:0.588332
G1 F1200
G1 X108.696 Y119.616 E.00255
G1 X108.629 Y119.634 E.00256
G1 X108.611 Y119.701 E.00256
G1 X108.66 Y119.75 E.00255
G1 X108.727 Y119.732 E.00256
G1 X108.727 Y119.732 F9000
G1 X110.448 Y120.116
;WIDTH:0.399999
G1 F1200
G1 X107.487 Y123.076 E.10184
G1 X107.487 Y123.593 E.01258
G1 X110.702 Y120.379 E.11058
G1 X110.993 Y120.604 E.00895
G1 X107.487 Y124.11 E.1206
G1 X107.487 Y124.628 E.0126
G1 X111.294 Y120.82 E.13098
G1 X111.613 Y121.002 E.00893
;WIDTH:0.375456
G1 X110.864 Y121.617 E.02199
;WIDTH:0.374336
G1 X110.27 Y122.228 E.01927
G1 X109.902 Y122.677 E.01313
;WIDTH:0.399999
G1 X109.696 Y122.935 E.00803
G1 X107.487 Y125.145 E.07601
G1 X107.615 Y125.534 E.00996
G1 X109.207 Y123.942 E.05476
;WIDTH:0.374336
G1 X109.166 Y123.953 E.00096
G1 X109.147 Y123.882 E.00166
G1 X109.218 Y123.901 E.00166
G1 X109.218 Y123.901 F9000
G1 X108.261 Y125.405
;WIDTH:0.399645
G1 F1200
G1 X108.077 Y125.722 E.00891
G1 X107.554 Y126.866 E.03057
G1 X107.487 Y126.612 E.00638
G1 X107.487 Y125.922 E.01677
G1 X107.642 Y125.973 E.00397
G1 X107.744 Y125.922 E.00277
G1 X108.131 Y125.534 E.01332
G1 E-5 F3600
G1 X108.131 Y125.534 F9000
G1 X107.549 Y91.465
G1 E5 F2400
;WIDTH:0.450666
G1 F1200
G1 X107.512 Y91.428 E.00145
G1 X107.462 Y91.442 E.00144
G1 X107.449 Y91.492 E.00143
G1 X107.485 Y91.529 E.00143
G1 X107.536 Y91.515 E.00146
;WIDTH:0.399999
G1 X107.487 Y92.043 E.0129
G1 X108.077 Y91.453 E.0203
;WIDTH:0.449921
G1 X108.116 Y91.433 E.00121
;WIDTH:0.499844
G1 X108.155 Y91.412 E.00137
;WIDTH:0.549766
G1 X108.194 Y91.392 E.0015
;WIDTH:0.599688
G1 X108.233 Y91.372 E.00165
;WIDTH:0.64961
G1 X108.272 Y91.351 E.00181
G1 X108.198 Y91.371 E.00314
G1 X108.143 Y91.317 E.00315
G1 X108.163 Y91.243 E.00314
G1 X108.237 Y91.223 E.00314
G1 X108.292 Y91.277 E.00315
;WIDTH:0.399999
G1 X108.594 Y91.453 E.0085
G1 X107.487 Y92.56 E.03808
G1 X107.487 Y93.078 E.0126
G1 X109.111 Y91.453 E.05588
G1 X109.628 Y91.453 E.01258
G1 X107.487 Y93.595 E.07367
G1 X107.487 Y94.112 E.01258
G1 X110.146 Y91.453 E.09147
G1 X110.663 Y91.453 E.01258
G1 X107.487 Y94.629 E.10925
G1 X107.487 Y95.146 E.01258
G1 X111.18 Y91.453 E.12704
G1 X111.697 Y91.453 E.01258
G1 X107.487 Y95.663 E.14482
G1 X107.487 Y96.18 E.01258
G1 X112.214 Y91.453 E.16261
G1 X112.731 Y91.453 E.01258
G1 X107.487 Y96.697 E.18039
G1 X107.421 Y96.945 E.00624
;WIDTH:0.374336
G1 X107.35 Y96.926 E.00166
G1 X107.369 Y96.997 E.00166
G1 X107.41 Y96.986 E.00096
G1 E-5 F3600
G1 X107.41 Y96.986 F9000
G1 X109.798 Y94.844
G1 E5 F2400
G1 F1200
G1 X110.297 Y94.235 E.01781
G1 X111.134 Y93.412 E.02655
G1 X111.561 Y93.077 E.01227
;WIDTH:0.399999
G1 X111.82 Y92.882 E.00789
G1 X113.248 Y91.453 E.04914
G1 X123.535 Y91.453 E.25022
G1 X123.513 Y91.556 E.00256
G1 X123.513 Y97.783 E.15147
;WIDTH:0.44743
G1 X123.489 Y97.997 E.00592
;WIDTH:0.49486
G1 X123.466 Y98.211 E.00659
;WIDTH:0.54229
G1 X123.442 Y98.426 E.00731
;WIDTH:0.58972
G1 X123.418 Y98.64 E.00796
G1 X123.391 Y98.595 E.00194
;WIDTH:0.564095
G1 X123.292 Y98.412 E.00733
;WIDTH:0.523071
G1 X123.193 Y98.229 E.00676
;WIDTH:0.482047
G1 X123.095 Y98.045 E.00621
;WIDTH:0.441023
G1 X122.996 Y97.862 E.00563
;WIDTH:0.399999
G1 X121.057 Y94.511 E.09417
G1 X120.79 Y94.153 E.01086
G1 X120.299 Y93.63 E.01745
G1 X119.926 Y93.32 E.0118
G1 X119.446 Y93.013 E.01386
G1 X119.01 Y92.804 E.01176
G1 X118.306 Y92.571 E.01804
G1 X117.478 Y92.443 E.02038
G1 X113.821 Y92.432 E.08895
G1 X114.018 Y92.235 E.00678
G1 X114.066 Y92.062 E.00437
G1 X113.933 Y91.891 E.00527
G1 X113.886 Y91.633 E.00638
G1 X113.571 Y91.648 E.00767
G1 X112.634 Y92.584 E.03221
G1 X112.42 Y92.734 E.00636
;WIDTH:0.374336
G1 X112.348 Y92.715 E.00168
G1 X112.368 Y92.786 E.00167
G1 X112.409 Y92.775 E.00096
G1 X112.409 Y92.775 F9000
G1 X113.251 Y92.485
;WIDTH:0.399999
G1 F1200
G1 X113.63 Y92.106 E.01304
G1 X113.63 Y92.106 F9000
G1 X114.542 Y91.944
;WIDTH:0.655606
G1 F1200
G1 X116.538 Y91.947 E.08249
G1 X116.596 Y91.924 E.00258
;WIDTH:0.611131
G1 X116.653 Y91.902 E.00234
;WIDTH:0.566656
G1 X116.71 Y91.88 E.00216
;WIDTH:0.522182
G1 X116.768 Y91.858 E.00201
G1 X116.71 Y91.88 E.00201
;WIDTH:0.566656
G1 X116.653 Y91.902 E.00216
;WIDTH:0.611131
G1 X116.596 Y91.924 E.00234
;WIDTH:0.655606
G1 X116.538 Y91.947 E.00258
G1 X116.595 Y91.969 E.00253
;WIDTH:0.611316
G1 X116.652 Y91.991 E.00235
;WIDTH:0.567025
G1 X116.71 Y92.014 E.00221
;WIDTH:0.522734
G1 X116.767 Y92.036 E.00198
;WIDTH:0.478443
G1 X116.824 Y92.058 E.0018
;WIDTH:0.434153
G1 X116.881 Y92.081 E.00163
;WIDTH:0.389862
G1 X116.938 Y92.103 E.00144
;WIDTH:0.346382
G1 X117.479 Y92.104 E.01123
;WIDTH:0.373191
G1 X117.927 Y92.158 E.01017
;WIDTH:0.399999
G1 X118.375 Y92.212 E.01098
G1 X119.125 Y92.457 E.01919
G1 X119.584 Y92.672 E.01233
G1 X120.123 Y93.012 E.0155
G1 X120.516 Y93.333 E.01234
G1 X121.034 Y93.878 E.01829
G1 X121.373 Y94.327 E.01368
G1 X123.147 Y97.394 E.08618
G1 X123.147 Y91.819 E.13561
G1 X118.413 Y91.819 E.11515
G1 X117.849 Y91.799 E.01373
;WIDTH:0.36121
G1 X116.938 Y91.792 E.01981
G1 E-5 F3600
G1 X116.938 Y91.792 F9000
G1 X119.412 Y92.184
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X122.782 Y92.184 E.08197
G1 X122.782 Y96.032 E.0936
G1 X121.69 Y94.144 E.05305
G1 X121.3 Y93.628 E.01573
G1 X120.75 Y93.052 E.01937
G1 X120.32 Y92.704 E.01346
G1 X119.84 Y92.397 E.01386
G1 X119.576 Y92.266 E.00717
G1 X119.576 Y92.266 F9000
G1 X120.718 Y92.55
G1 F1200
G1 X122.416 Y92.55 E.0413
G1 X122.416 Y94.669 E.05154
G1 X121.925 Y93.838 E.02348
G1 X121.59 Y93.402 E.01337
G1 X121.099 Y92.879 E.01745
G1 X120.857 Y92.67 E.00778
G1 X120.857 Y92.67 F9000
G1 X121.999 Y93.021
;WIDTH:0.650826
G1 F1200
G1 X121.945 Y92.967 E.00313
G1 X121.871 Y92.987 E.00314
G1 X121.851 Y93.061 E.00314
G1 X121.905 Y93.116 E.00316
G1 X121.98 Y93.096 E.00318
G1 E-5 F3600
G1 X121.98 Y93.096 F9000
G1 X123.418 Y98.64
G1 E5 F2400
;WIDTH:0.58972
G1 F1200
G1 X123.557 Y99.337 E.02626
;WIDTH:0.579208
G1 X123.576 Y100.439 E.03995
;WIDTH:0.546926
G1 X123.525 Y100.669 E.00803
;WIDTH:0.524641
G1 X123.437 Y100.997 E.01108
;WIDTH:0.483278
G1 X123.348 Y101.324 E.01012
;WIDTH:0.441915
G1 X123.147 Y101.849 E.01524
G1 X123.278 Y101.849 E.00355
G1 X123.409 Y101.959 E.00464
G1 X123.626 Y102.037 E.00625
G1 X123.626 Y101.353 E.01854
;WIDTH:0.476919
G1 X123.608 Y101.066 E.00847
;WIDTH:0.511923
G1 X123.591 Y100.78 E.0091
;WIDTH:0.546926
G1 X123.573 Y100.493 E.00981
G1 X123.573 Y100.493 F9000
G1 X123.134 Y102.252
;WIDTH:0.399999
G1 F1200
G1 X122.657 Y102.729 E.01641
G1 X122.5 Y102.977 E.00714
;WIDTH:0.374336
G1 X122.428 Y102.958 E.00168
G1 X122.447 Y103.029 E.00166
G1 X122.489 Y103.018 E.00098
G1 X122.489 Y103.018 F9000
G1 X123.514 Y102.389
;WIDTH:0.399999
G1 F1200
G1 X121.944 Y103.96 E.05402
G1 X121.786 Y104.208 E.00715
;WIDTH:0.374336
G1 X121.715 Y104.188 E.00167
G1 X121.734 Y104.26 E.00168
G1 X121.775 Y104.249 E.00096
G1 E-5 F3600
G1 X121.775 Y104.249 F9000
G1 X123.647 Y102.774
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X121.23 Y105.191 E.08314
G1 X121.022 Y105.449 E.00806
;WIDTH:0.374336
G1 X120.117 Y106.427 E.03014
G1 X119.705 Y106.782 E.0123
;WIDTH:0.405594
G1 X119.423 Y106.994 E.00871
;WIDTH:0.399999
G1 X119.738 Y107.2 E.00916
G1 X123.549 Y103.389 E.1311
G1 X123.513 Y103.942 E.01348
G1 X120.048 Y107.407 E.11919
G1 X120.316 Y107.656 E.0089
G1 X123.513 Y104.459 E.10997
G1 X123.513 Y104.976 E.01258
G1 X120.569 Y107.921 E.10129
G1 E-5 F3600
G1 X120.569 Y107.921 F9000
G1 X123.384 Y105.623
G1 E5 F2400
G1 F1200
G1 X120.81 Y108.196 E.08853
G1 X121.057 Y108.51 E.00972
G1 X122.916 Y111.708 E.08998
G1 X123.313 Y112.622 E.02424
G1 X123.446 Y112.866 E.00676
G1 X123.513 Y112.581 E.00712
G1 X123.513 Y105.493 E.17241
G1 X123.513 Y105.493 F9000
G1 X123.147 Y106.376
G1 F1200
G1 X123.147 Y111.379 E.12169
G1 X121.299 Y108.224 E.08894
G1 X123.018 Y106.505 E.05913
G1 X123.018 Y106.505 F9000
G1 X122.782 Y107.259
G1 F1200
G1 X122.782 Y110.023 E.06723
G1 X121.766 Y108.275 E.04918
G1 X122.652 Y107.388 E.0305
G1 X122.652 Y107.388 F9000
G1 X122.395 Y108.331
;WIDTH:0.571236
G1 F1200
G1 X122.348 Y108.284 E.00237
G1 X122.283 Y108.301 E.0024
G1 X122.266 Y108.366 E.0024
G1 X122.313 Y108.413 E.00237
G1 X122.378 Y108.396 E.0024
G1 E-5 F3600
G1 X122.378 Y108.396 F9000
G1 X112.904 Y106.06
G1 X112.789 Y106.024
G1 X112.627 Y105.968
G1 X112.516 Y105.922
G1 X112.36 Y105.851
G1 X112.253 Y105.795
G1 X112.105 Y105.709
G1 X112.003 Y105.645
G1 X111.863 Y105.545
G1 X111.768 Y105.472
G1 X111.638 Y105.36
G1 X111.549 Y105.278
G1 X111.431 Y105.154
G1 X111.35 Y105.066
G1 X111.244 Y104.93
G1 X111.17 Y104.835
G1 X111.078 Y104.691
G1 X111.02 Y104.6
G1 X109.276 Y101.58
G1 X109.227 Y101.485
G1 X109.148 Y101.332
G1 X109.102 Y101.221
G1 X109.038 Y101.061
G1 X109.002 Y100.947
G1 X108.954 Y100.782
G1 X108.927 Y100.665
G1 X108.895 Y100.496
G1 X108.879 Y100.377
G1 X108.863 Y100.206
G1 X108.858 Y100.086
G1 X108.858 Y99.914
G1 X108.863 Y99.794
G1 X108.879 Y99.623
G1 X108.895 Y99.504
G1 X109.599 Y95.102
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X107.487 Y97.215 E.07267
G1 X107.67 Y97.549 E.00926
G1 X109.11 Y96.109 E.04954
;WIDTH:0.374336
G1 X109.069 Y96.12 E.00096
G1 X109.05 Y96.049 E.00166
G1 X109.121 Y96.068 E.00166
G1 X109.121 Y96.068 F9000
G1 X108.172 Y97.561
;WIDTH:0.396155
G1 F1200
G1 X107.932 Y98.031 E.0127
;WIDTH:0.437043
G1 X107.863 Y98.158 E.00387
;WIDTH:0.477931
G1 X107.793 Y98.286 E.0043
;WIDTH:0.518819
G1 X107.724 Y98.414 E.00469
;WIDTH:0.559706
G1 X107.655 Y98.542 E.00508
;WIDTH:0.600594
G1 X107.585 Y98.669 E.00546
G1 X107.561 Y98.575 E.00365
;WIDTH:0.552056
G1 X107.538 Y98.481 E.00333
;WIDTH:0.503517
G1 X107.514 Y98.387 E.00303
;WIDTH:0.454979
G1 X107.49 Y98.293 E.00271
;WIDTH:0.40644
G1 X107.485 Y97.86 E.01072
;WIDTH:0.396155
G1 X107.668 Y97.988 E.00537
G1 X107.798 Y97.935 E.00338
G1 X108.043 Y97.69 E.00834
G1 X108.043 Y97.69 F9000
G1 X107.585 Y98.669
;WIDTH:0.600594
G1 F1200
G1 X107.443 Y99.337 E.02572
;WIDTH:0.579398
G1 X107.428 Y99.619 E.01024
;WIDTH:0.54856
G1 X107.412 Y99.9 E.00963
;WIDTH:0.550444
G1 X107.429 Y100.533 E.02174
;WIDTH:0.553934
G1 X107.414 Y100.755 E.00769
;WIDTH:0.516223
G1 X107.393 Y100.962 E.00667
;WIDTH:0.477482
G1 X107.373 Y101.169 E.00613
;WIDTH:0.438741
G1 X107.353 Y101.376 E.00559
;WIDTH:0.399999
G1 X107.353 Y102.959 E.0385
G1 X107.487 Y103.615 E.01629
G1 X107.487 Y108.591 E.12104
G1 X110.226 Y105.852 E.09422
G1 X109.943 Y105.49 E.01118
G1 X108.004 Y102.138 E.09419
G1 X107.685 Y101.374 E.02014
;WIDTH:0.437564
G1 X107.622 Y101.174 E.00562
;WIDTH:0.475129
G1 X107.558 Y100.973 E.00619
;WIDTH:0.512694
G1 X107.495 Y100.773 E.00667
;WIDTH:0.550258
G1 X107.431 Y100.573 E.00721
G1 X107.431 Y100.573 F9000
G1 X107.719 Y102.375
;WIDTH:0.399999
G1 F1200
G1 X109.403 Y105.286 E.0818
G1 X109.738 Y105.823 E.0154
G1 X107.853 Y107.709 E.06486
G1 X107.853 Y103.615 E.09958
G1 X107.726 Y102.873 E.01831
G1 X107.722 Y102.558 E.00766
G1 X107.722 Y102.558 F9000
G1 X108.218 Y103.968
G1 F1200
G1 X109.265 Y105.778 E.05086
G1 X108.218 Y106.826 E.03603
G1 X108.218 Y104.151 E.06507
G1 X108.218 Y104.151 F9000
G1 X108.752 Y105.684
;WIDTH:0.599502
G1 F1200
G1 X108.702 Y105.634 E.00266
G1 X108.634 Y105.652 E.00264
G1 X108.615 Y105.72 E.00265
G1 X108.665 Y105.77 E.00266
G1 X108.734 Y105.752 E.00268
G1 X108.734 Y105.752 F9000
G1 X110.463 Y106.133
;WIDTH:0.399999
G1 F1200
G1 X107.487 Y109.108 E.10236
G1 X107.487 Y109.626 E.0126
G1 X110.718 Y106.394 E.11116
G1 X111.012 Y106.618 E.00899
G1 X107.487 Y110.143 E.12126
G1 X107.487 Y110.66 E.01258
G1 X111.313 Y106.834 E.13161
G1 X111.632 Y107.001 E.00876
;WIDTH:0.374336
G1 X110.873 Y107.625 E.02222
G1 X110.28 Y108.234 E.01922
G1 X109.857 Y108.754 E.01516
;WIDTH:0.399999
G1 X109.651 Y109.013 E.00805
G1 X107.487 Y111.177 E.07444
G1 X107.64 Y111.541 E.0096
G1 X109.162 Y110.019 E.05236
;WIDTH:0.374336
G1 X109.121 Y110.03 E.00096
G1 X109.102 Y109.959 E.00166
G1 X109.173 Y109.978 E.00166
G1 X109.173 Y109.978 F9000
G1 X108.22 Y111.476
;WIDTH:0.397814
G1 F1200
G1 X108.078 Y111.722 E.00687
G1 X107.553 Y112.869 E.0305
G1 X107.486 Y112.612 E.00642
G1 X107.486 Y111.939 E.01627
G1 X107.654 Y111.981 E.00419
G1 X107.769 Y111.928 E.00306
G1 X108.091 Y111.606 E.01101
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X107.769 Y111.928 E-.2163
G1 X107.654 Y111.981 E-.06015
G1 X107.486 Y111.939 E-.08226
G1 X107.486 Y112.612 E-.31968
G1 X107.553 Y112.869 E-.12616
G1 X108.078 Y111.722 E-.59918
G1 X108.179 Y111.547 E-.09627
;WIPE_END
G1 X108.863 Y99.794 F9000
G1 X108.879 Y99.623
G1 X109.803 Y90.065
G1 X109.948 Y88.151
G1 X110.065 Y86.599
G1 X109.801 Y85.151
G1 X110.149 Y85.499
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X105.142 Y85.5 E.12179
G1 X104.267 Y85.478 E.02129
G1 X103.709 Y85.394 E.01373
G1 X103.167 Y85.227 E.0138
G1 X102.655 Y84.981 E.01382
G1 X102.187 Y84.662 E.01378
G1 X101.773 Y84.277 E.01375
G1 X101.42 Y83.835 E.01376
G1 X101.137 Y83.345 E.01376
G1 X100.928 Y82.813 E.0139
G1 X100.795 Y82.21 E.01502
G1 X100.75 Y81.696 E.01255
G1 X100.75 Y78.538 E.07682
G1 X100.718 Y78.436 E.0026
G1 X100.344 Y77.847 E.01697
G1 X100.264 Y77.507 E.0085
G1 X100.342 Y77.148 E.00894
G1 X100.61 Y76.716 E.01237
G1 X130.39 Y76.716 E.72437
G1 X130.689 Y77.251 E.01491
G1 X130.719 Y77.517 E.00651
G1 X130.705 Y77.718 E.0049
G1 X130.555 Y78.036 E.00855
G1 X130.286 Y78.429 E.01158
G1 X130.25 Y78.538 E.00279
G1 X130.239 Y81.983 E.0838
G1 X130.155 Y82.541 E.01373
G1 X129.871 Y83.352 E.0209
G1 X129.604 Y83.816 E.01302
G1 X129.031 Y84.487 E.02146
G1 X128.591 Y84.839 E.01371
G1 X128.113 Y85.115 E.01343
G1 X127.29 Y85.405 E.02123
G1 X126.951 Y85.457 E.00834
G1 X126.446 Y85.5 E.01233
G1 X120.851 Y85.499 E.13609
G1 X120.719 Y85.323 E.00535
G1 X120.667 Y85.316 E.00128
G1 X110.333 Y85.316 E.25136
G1 X110.307 Y85.318 E.00063
G1 X110.188 Y85.453 E.00438
G1 X110.188 Y85.453 F9000
G1 X110.01 Y85.134
;TYPE:Perimeter
G1 F6000
G1 X105.142 Y85.134 E.11841
G1 X104.294 Y85.114 E.02063
G1 X103.79 Y85.038 E.0124
G1 X103.301 Y84.887 E.01245
G1 X102.838 Y84.664 E.0125
G1 X102.415 Y84.376 E.01245
G1 X102.041 Y84.029 E.01241
G1 X101.722 Y83.629 E.01244
G1 X101.466 Y83.186 E.01245
G1 X101.278 Y82.705 E.01256
G1 X101.165 Y82.212 E.0123
G1 X101.116 Y81.688 E.0128
G1 X101.116 Y78.538 E.07662
G1 X101.021 Y78.23 E.00784
G1 X100.732 Y77.804 E.01252
G1 X100.649 Y77.625 E.0048
G1 X100.674 Y77.343 E.00689
G1 X100.813 Y77.082 E.00719
G1 X130.187 Y77.082 E.71449
G1 X130.324 Y77.302 E.0063
G1 X130.354 Y77.492 E.00468
G1 X130.35 Y77.543 E.00124
G1 X130.224 Y77.88 E.00875
G1 X129.992 Y78.212 E.00985
G1 X129.884 Y78.536 E.00831
G1 X129.873 Y81.955 E.08316
G1 X129.798 Y82.453 E.01225
G1 X129.537 Y83.199 E.01922
G1 X129.304 Y83.604 E.01137
G1 X128.776 Y84.223 E.01979
G1 X128.553 Y84.401 E.00694
G1 X127.96 Y84.782 E.01714
G1 X127.201 Y85.049 E.01957
G1 X126.438 Y85.134 E.01867
G1 X120.943 Y85.134 E.13366
G1 X120.821 Y84.972 E.00493
G1 X120.667 Y84.95 E.00378
G1 X110.333 Y84.95 E.25136
G1 X110.179 Y84.972 E.00378
G1 X110.065 Y85.124 E.00462
G1 X110.065 Y85.124 F9000
G1 X109.756 Y84.769
G1 F6000
G1 X105.142 Y84.769 E.11223
G1 X104.382 Y84.754 E.01849
G1 X103.872 Y84.681 E.01253
G1 X103.22 Y84.463 E.01672
G1 X102.643 Y84.09 E.01671
G1 X102.154 Y83.612 E.01663
G1 X101.796 Y83.027 E.01668
G1 X101.56 Y82.381 E.01673
G1 X101.481 Y81.68 E.01716
G1 X101.481 Y78.538 E.07643
G1 X101.324 Y78.025 E.01305
G1 X101.034 Y77.598 E.01256
G1 X101.025 Y77.448 E.00366
G1 X129.422 Y77.448 E.69073
G1 X129.989 Y77.467 E.0138
G1 X129.894 Y77.724 E.00666
G1 X129.698 Y77.994 E.00812
G1 X129.519 Y78.535 E.01386
G1 X129.508 Y81.733 E.07779
G1 X129.442 Y82.365 E.01546
G1 X129.27 Y82.857 E.01268
G1 X129.004 Y83.392 E.01453
G1 X128.681 Y83.772 E.01213
G1 X128.325 Y84.115 E.01202
G1 X127.806 Y84.448 E.015
G1 X127.112 Y84.693 E.0179
G1 X126.43 Y84.769 E.01669
G1 X121.034 Y84.769 E.13125
G1 X120.924 Y84.621 E.00449
G1 X120.667 Y84.584 E.00632
G1 X110.333 Y84.584 E.25136
G1 X110.076 Y84.621 E.00632
G1 X109.966 Y84.769 E.00449
G1 X109.816 Y84.769 E.00365
G1 X109.816 Y84.769 F9000
G1 X109.494 Y84.402
G1 F6000
G1 X104.492 Y84.395 E.12167
G1 X103.953 Y84.325 E.01322
G1 X103.379 Y84.132 E.01473
G1 X102.871 Y83.804 E.01471
G1 X102.44 Y83.384 E.01464
G1 X102.125 Y82.868 E.01471
G1 X101.918 Y82.299 E.01473
G1 X101.847 Y81.672 E.01535
G1 X101.847 Y78.538 E.07623
G1 X101.63 Y77.818 E.01829
G1 X129.392 Y77.813 E.67528
G1 X129.153 Y78.534 E.01848
G1 X129.145 Y81.119 E.06288
G1 X129.117 Y82.064 E.023
G1 X128.989 Y82.552 E.01227
G1 X128.787 Y83.038 E.0128
G1 X128.403 Y83.534 E.01526
G1 X128.097 Y83.829 E.01034
G1 X127.652 Y84.115 E.01287
G1 X127.023 Y84.336 E.01622
G1 X126.422 Y84.403 E.01471
G1 X121.126 Y84.403 E.12882
G1 X121.027 Y84.27 E.00403
G1 X120.667 Y84.219 E.00884
G1 X110.333 Y84.219 E.25136
G1 X109.973 Y84.27 E.00884
G1 X109.874 Y84.403 E.00403
G1 X109.554 Y84.403 E.00778
G1 X109.554 Y84.403 F9000
G1 X109.23 Y84.037
G1 F6000
G1 X104.612 Y84.037 E.11233
G1 X104.034 Y83.968 E.01416
G1 X103.538 Y83.802 E.01272
G1 X103.099 Y83.518 E.01272
G1 X102.727 Y83.155 E.01264
G1 X102.454 Y82.71 E.0127
G1 X102.275 Y82.217 E.01276
G1 X102.213 Y81.664 E.01354
G1 X102.213 Y78.538 E.07604
G1 X102.102 Y78.179 E.00914
G1 X128.905 Y78.179 E.65196
G1 X128.787 Y78.533 E.00908
G1 X128.779 Y81.118 E.06288
G1 X128.756 Y82.01 E.0217
G1 X128.579 Y82.616 E.01536
G1 X128.404 Y82.969 E.00958
G1 X128.01 Y83.431 E.01477
G1 X127.499 Y83.781 E.01507
G1 X126.934 Y83.98 E.01457
G1 X126.414 Y84.037 E.01272
G1 X121.218 Y84.037 E.12639
G1 X121.129 Y83.919 E.0036
G1 X120.667 Y83.853 E.01135
G1 X110.333 Y83.853 E.25136
G1 X109.871 Y83.919 E.01135
G1 X109.782 Y84.037 E.0036
G1 X109.29 Y84.037 E.01197
G1 E-5 F3600
G1 X109.29 Y84.037 F9000
G1 X102.55 Y78.466
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.45165
G1 F1200
G1 X102.513 Y78.429 E.00145
G1 X102.463 Y78.442 E.00143
G1 X102.45 Y78.493 E.00146
G1 X102.486 Y78.529 E.00141
G1 X102.537 Y78.516 E.00146
;WIDTH:0.399999
G1 X102.488 Y79.045 E.01292
G1 X103.079 Y78.453 E.02035
G1 X103.25 Y78.327 E.00517
;WIDTH:0.374336
G1 X103.209 Y78.338 E.00096
G1 X103.19 Y78.267 E.00166
G1 X103.261 Y78.286 E.00166
;WIDTH:0.399999
G1 X103.597 Y78.453 E.00913
G1 X102.489 Y79.56 E.0381
G1 X102.491 Y80.076 E.01255
G1 X104.114 Y78.453 E.05583
G1 X104.631 Y78.453 E.01258
G1 X102.492 Y80.592 E.07358
G1 X102.493 Y81.108 E.01255
G1 X105.148 Y78.453 E.09133
G1 X105.665 Y78.453 E.01258
G1 X102.494 Y81.624 E.10908
G1 X102.535 Y82.1 E.01162
G1 X106.182 Y78.453 E.12545
G1 X106.699 Y78.453 E.01258
G1 X102.656 Y82.496 E.13908
G1 X102.838 Y82.832 E.00929
G1 X107.216 Y78.453 E.15062
G1 X107.734 Y78.453 E.0126
G1 X103.068 Y83.119 E.16051
G1 X103.342 Y83.361 E.00889
G1 X108.251 Y78.453 E.16885
G1 X108.768 Y78.453 E.01258
G1 X103.664 Y83.557 E.17557
G1 X104.048 Y83.69 E.00988
G1 X109.285 Y78.453 E.18015
G1 X109.802 Y78.453 E.01258
G1 X104.501 Y83.754 E.18235
G1 X105.009 Y83.763 E.01236
G1 X110.319 Y78.453 E.18266
G1 X110.836 Y78.453 E.01258
G1 X105.526 Y83.763 E.18266
G1 X106.044 Y83.763 E.0126
G1 X111.353 Y78.453 E.18264
G1 X111.871 Y78.453 E.0126
G1 X106.561 Y83.763 E.18266
G1 X107.078 Y83.763 E.01258
G1 X112.388 Y78.453 E.18266
G1 X112.905 Y78.453 E.01258
G1 X107.595 Y83.763 E.18266
G1 X108.112 Y83.763 E.01258
G1 X113.422 Y78.453 E.18266
G1 X113.939 Y78.453 E.01258
G1 X108.629 Y83.763 E.18266
G1 X109.146 Y83.763 E.01258
G1 X114.456 Y78.453 E.18266
G1 X114.973 Y78.453 E.01258
G1 X109.663 Y83.763 E.18266
G1 X109.792 Y83.881 E.00425
;WIDTH:0.374336
G1 X109.721 Y83.862 E.00166
G1 X109.74 Y83.933 E.00166
G1 X109.781 Y83.922 E.00096
;WIDTH:0.399999
G1 X110.365 Y83.579 E.01647
G1 X115.49 Y78.453 E.17631
G1 X116.008 Y78.453 E.0126
G1 X110.882 Y83.579 E.17633
G1 X111.399 Y83.579 E.01258
G1 X116.525 Y78.453 E.17633
G1 X117.042 Y78.453 E.01258
G1 X111.916 Y83.579 E.17633
G1 X112.433 Y83.579 E.01258
G1 X117.559 Y78.453 E.17633
G1 X118.076 Y78.453 E.01258
G1 X112.95 Y83.579 E.17633
G1 X113.468 Y83.579 E.0126
G1 X118.593 Y78.453 E.17631
G1 X119.11 Y78.453 E.01258
G1 X113.985 Y83.579 E.17631
G1 X114.502 Y83.579 E.01258
G1 X119.627 Y78.453 E.17631
G1 X120.145 Y78.453 E.0126
G1 X115.019 Y83.579 E.17633
G1 X115.536 Y83.579 E.01258
G1 X120.662 Y78.453 E.17633
G1 X121.179 Y78.453 E.01258
G1 X116.053 Y83.579 E.17633
G1 X116.57 Y83.579 E.01258
G1 X121.696 Y78.453 E.17633
G1 X122.213 Y78.453 E.01258
G1 X117.087 Y83.579 E.17633
G1 X117.605 Y83.579 E.0126
G1 X122.73 Y78.453 E.17631
G1 X123.247 Y78.453 E.01258
G1 X118.122 Y83.579 E.17631
G1 X118.639 Y83.579 E.01258
G1 X123.764 Y78.453 E.17631
G1 X124.282 Y78.453 E.0126
G1 X119.156 Y83.579 E.17633
G1 X119.673 Y83.579 E.01258
G1 X124.799 Y78.453 E.17633
G1 X125.316 Y78.453 E.01258
G1 X120.19 Y83.579 E.17633
G1 X120.705 Y83.581 E.01253
G1 X125.833 Y78.453 E.1764
G1 X126.35 Y78.453 E.01258
G1 X121.158 Y83.645 E.1786
G1 X121.289 Y83.883 E.00661
;WIDTH:0.374336
G1 X121.218 Y83.864 E.00166
G1 X121.237 Y83.935 E.00166
G1 X121.278 Y83.924 E.00096
;WIDTH:0.399999
G1 X121.557 Y83.763 E.00784
G1 X126.867 Y78.453 E.18266
G1 X127.384 Y78.453 E.01258
G1 X122.074 Y83.763 E.18266
G1 X122.592 Y83.763 E.0126
G1 X127.901 Y78.453 E.18264
G1 X127.901 Y78.453 F9000
G1 X128.692 Y78.352
;WIDTH:0.374336
G1 F1200
G1 X128.621 Y78.333 E.00166
G1 X128.64 Y78.404 E.00166
G1 X128.681 Y78.393 E.00096
;WIDTH:0.399999
G1 X128.419 Y78.453 E.00654
G1 X123.109 Y83.763 E.18266
G1 X123.626 Y83.763 E.01258
G1 X128.512 Y78.877 E.16808
G1 X128.51 Y79.396 E.01262
G1 X124.143 Y83.763 E.15022
G1 X124.66 Y83.763 E.01258
G1 X128.509 Y79.915 E.13239
G1 X128.507 Y80.433 E.0126
G1 X125.177 Y83.763 E.11455
G1 X125.694 Y83.763 E.01258
G1 X128.505 Y80.952 E.0967
G1 X128.504 Y81.471 E.01262
G1 X126.211 Y83.763 E.07886
G1 X126.769 Y83.723 E.01361
G1 X128.478 Y82.014 E.05879
G1 X128.285 Y82.684 E.01696
;WIDTH:0.374336
G1 X128.255 Y82.873 E.00433
G1 X127.874 Y83.285 E.01269
G1 X127.505 Y83.589 E.01081
G1 X127.349 Y83.593 E.00353
;WIDTH:0.399999
G1 X127.608 Y83.401 E.00784
G1 X128.067 Y82.942 E.01579
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X127.608 Y83.401 E-.30833
G1 X127.349 Y83.593 E-.15314
G1 X127.505 Y83.589 E-.07412
G1 X127.874 Y83.285 E-.2271
G1 X128.255 Y82.873 E-.26655
G1 X128.285 Y82.684 E-.0909
G1 X128.478 Y82.014 E-.33119
G1 X128.406 Y82.086 E-.04867
;WIPE_END
G1 X127.276 Y85.049 F9000
G1 X126.685 Y86.599
G1 X125.941 Y88.151
G1 X125.941 Y88.552
G1 E5 F2400
G1 F6000
G1 X125.947 Y88.555 E.00016
G1 X126 Y88.683 E.00337
G1 X126 Y89.551 E.02111
G1 X126.264 Y90 E.01267
G1 X126.369 Y90.537 E.01331
G1 X126.264 Y91 E.01155
G1 X126 Y91.449 E.01267
G1 X126 Y92.948 E.03646
G1 X139.202 Y92.948 E.32113
G1 X139.507 Y93.043 E.00777
G1 X139.77 Y93.328 E.00943
G1 X139.9 Y93.602 E.00738
G1 X139.9 Y95.227 E.03953
G1 X139.861 Y95.34 E.00291
G1 X139.604 Y95.72 E.01116
G1 X139.264 Y95.869 E.00903
G1 X136.7 Y95.88 E.06237
G1 X136.698 Y132.81 E.89829
G1 X136.634 Y133.757 E.02309
G1 X136.471 Y134.748 E.02443
G1 X136.253 Y135.585 E.02104
G1 X135.913 Y136.529 E.02441
G1 X135.491 Y137.416 E.02389
G1 X135.031 Y138.19 E.0219
G1 X134.438 Y139.005 E.02452
G1 X133.808 Y139.715 E.02309
G1 X132.723 Y140.681 E.03534
G1 X131.987 Y141.198 E.02188
G1 X131.105 Y141.701 E.0247
G1 X129.768 Y142.262 E.03527
G1 X128.945 Y142.502 E.02085
G1 X127.897 Y142.704 E.02596
G1 X126.886 Y142.792 E.02468
G1 X120.483 Y142.8 E.15575
G1 X120.397 Y142.729 E.00271
G1 X110.603 Y142.729 E.23823
G1 X110.517 Y142.8 E.00271
G1 X104.5 Y142.8 E.14636
G1 X103.859 Y142.778 E.0156
G1 X102.622 Y142.626 E.03032
G1 X102.051 Y142.501 E.01422
G1 X101.252 Y142.269 E.02024
G1 X100.298 Y141.894 E.02493
G1 X99.488 Y141.484 E.02208
G1 X98.613 Y140.929 E.0252
G1 X97.567 Y140.081 E.03275
G1 X97.186 Y139.709 E.01295
G1 X96.573 Y139.018 E.02247
G1 X95.967 Y138.186 E.02504
G1 X95.302 Y137.008 E.0329
G1 X94.915 Y136.088 E.02428
G1 X94.621 Y135.135 E.02426
G1 X94.371 Y133.801 E.03301
G1 X94.303 Y132.823 E.02385
G1 X94.3 Y95.88 E.8986
G1 X91.798 Y95.88 E.06086
G1 X91.493 Y95.786 E.00776
G1 X91.231 Y95.501 E.00942
G1 X91.1 Y95.227 E.00739
G1 X91.1 Y93.602 E.03953
G1 X91.259 Y93.278 E.00878
G1 X91.458 Y93.067 E.00705
G1 X91.798 Y92.948 E.00876
G1 X103.822 Y92.948 E.29247
G1 X105 Y92.948 E.02865
G1 X105 Y91.449 E.03646
G1 X104.736 Y91 E.01267
G1 X104.631 Y90.463 E.01331
G1 X104.736 Y90 E.01155
G1 X105 Y89.551 E.01267
G1 X105 Y88.683 E.02111
G1 X105.062 Y88.545 E.00368
G1 X105.183 Y88.5 E.00314
G1 X125.817 Y88.5 E.5019
G1 X125.885 Y88.529 E.0018
G1 X125.885 Y88.529 F9000
G1 X126.189 Y88.29
;TYPE:Perimeter
G1 F6000
G1 X126.208 Y88.298 E.0005
G1 X126.35 Y88.553 E.0071
G1 X126.366 Y89.451 E.02185
G1 X126.617 Y89.892 E.01234
G1 X126.727 Y90.39 E.01241
G1 X126.727 Y90.61 E.00535
G1 X126.579 Y91.185 E.01444
G1 X126.366 Y91.549 E.01026
G1 X126.366 Y92.583 E.02515
G1 X139.202 Y92.583 E.31222
G1 X139.505 Y92.639 E.00749
G1 X139.766 Y92.784 E.00726
G1 X139.986 Y93.003 E.00755
;WIDTH:0.448959
G1 X140.104 Y93.203 E.0064
;WIDTH:0.497919
G1 X140.222 Y93.402 E.00713
;WIDTH:0.546878
G1 X140.34 Y93.602 E.00792
;WIDTH:0.547002
G1 X140.34 Y95.227 E.05542
;WIDTH:0.553658
G1 X140.334 Y95.334 E.0037
G1 X140.256 Y95.447 E.00474
;WIDTH:0.515244
G1 X140.179 Y95.559 E.00435
;WIDTH:0.476829
G1 X140.101 Y95.671 E.00402
;WIDTH:0.438414
G1 X140.024 Y95.783 E.00365
;WIDTH:0.399999
G1 X139.887 Y95.951 E.00527
G1 X139.647 Y96.121 E.00715
G1 X139.202 Y96.246 E.01124
G1 X137.066 Y96.246 E.05196
G1 X137.063 Y132.81 E.88938
G1 X136.995 Y133.817 E.02455
G1 X136.831 Y134.812 E.02453
G1 X136.607 Y135.677 E.02173
G1 X136.257 Y136.653 E.02522
G1 X135.821 Y137.573 E.02476
G1 X135.345 Y138.377 E.02273
G1 X134.734 Y139.22 E.02532
G1 X134.051 Y139.988 E.025
G1 X132.966 Y140.954 E.03534
G1 X132.197 Y141.497 E.0229
G1 X131.286 Y142.019 E.02554
G1 X129.909 Y142.599 E.03634
G1 X129.014 Y142.861 E.02268
G1 X127.97 Y143.062 E.02586
G1 X126.918 Y143.156 E.02569
G1 X120.483 Y143.166 E.15653
G1 X120.406 Y143.16 E.00188
G1 X120.349 Y143.095 E.0021
G1 X110.651 Y143.095 E.23589
G1 X110.594 Y143.16 E.0021
G1 X110.517 Y143.166 E.00188
G1 X104.5 Y143.166 E.14636
G1 X103.814 Y143.141 E.0167
G1 X102.577 Y142.988 E.03032
G1 X101.972 Y142.858 E.01505
G1 X101.15 Y142.62 E.02082
G1 X100.162 Y142.234 E.0258
G1 X99.323 Y141.81 E.02287
G1 X98.435 Y141.25 E.02554
G1 X97.337 Y140.365 E.0343
G1 X96.93 Y139.971 E.01378
G1 X96.299 Y139.261 E.0231
G1 X95.648 Y138.366 E.02692
G1 X94.984 Y137.187 E.03291
G1 X94.578 Y136.23 E.02529
G1 X94.276 Y135.263 E.02464
G1 X94.012 Y133.87 E.03449
G1 X93.938 Y132.848 E.02492
G1 X93.934 Y96.246 E.89031
G1 X91.798 Y96.246 E.05196
G1 X91.496 Y96.19 E.00747
G1 X91.235 Y96.045 E.00726
G1 X91.015 Y95.825 E.00757
;WIDTH:0.439255
G1 X90.928 Y95.703 E.00404
;WIDTH:0.478511
G1 X90.84 Y95.58 E.00447
;WIDTH:0.517767
G1 X90.753 Y95.458 E.00482
;WIDTH:0.557023
G1 X90.665 Y95.335 E.00526
G1 X90.659 Y95.227 E.00376
;WIDTH:0.550466
G1 X90.659 Y93.602 E.05579
G1 X90.737 Y93.464 E.00544
;WIDTH:0.51285
G1 X90.815 Y93.327 E.00502
;WIDTH:0.475233
G1 X90.894 Y93.189 E.00466
;WIDTH:0.437616
G1 X90.972 Y93.051 E.00425
;WIDTH:0.399999
G1 X91.094 Y92.897 E.00478
G1 X91.326 Y92.726 E.00701
G1 X91.798 Y92.583 E.012
G1 X103.822 Y92.583 E.29247
G1 X104.634 Y92.583 E.01975
G1 X104.634 Y91.549 E.02515
G1 X104.356 Y91.017 E.0146
G1 X104.273 Y90.61 E.0101
G1 X104.273 Y90.39 E.00535
G1 X104.381 Y89.897 E.01228
G1 X104.634 Y89.451 E.01247
G1 X104.634 Y88.683 E.01868
G1 X104.732 Y88.37 E.00798
G1 X104.822 Y88.27 E.00327
G1 X105.088 Y88.143 E.00717
G1 X125.817 Y88.134 E.50421
G1 X126.134 Y88.267 E.00836
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X126.189 Y88.29 E-.02832
G1 X126.208 Y88.298 E-.00979
G1 X126.35 Y88.553 E-.13864
G1 X126.366 Y89.451 E-.42662
G1 X126.617 Y89.892 E-.24103
G1 X126.727 Y90.39 E-.24225
G1 X126.727 Y90.61 E-.1045
G1 X126.579 Y91.185 E-.28203
G1 X126.55 Y91.234 E-.02682
;WIPE_END
G1 X126.543 Y91.231 F9000
G1 X126.602 Y91.103
G1 X126.668 Y90.905
G1 X126.709 Y90.703
G1 X126.723 Y90.5
G1 X126.709 Y90.297
G1 X126.349 Y88.151
G1 X122.784 Y88.151
G1 X120.371 Y86.599
G1 X120.371 Y86.177
G1 E5 F2400
G1 F6000
G1 X120.342 Y86.131 E.00132
G1 X110.658 Y86.131 E.23555
G1 X110.549 Y86.247 E.00387
G1 X110.517 Y86.25 E.00078
G1 X104.2 Y86.25 E.15365
G1 X103.844 Y86.233 E.00867
G1 X102.993 Y86.072 E.02107
G1 X102.459 Y85.867 E.01391
G1 X101.844 Y85.526 E.0171
G1 X101.355 Y85.139 E.01517
G1 X100.93 Y84.685 E.01513
G1 X100.576 Y84.172 E.01516
G1 X100.292 Y83.587 E.01582
G1 X100.05 Y82.69 E.0226
G1 X100.001 Y82.064 E.01527
G1 X100 Y78.449 E.08793
G1 X99.736 Y78 E.01267
G1 X99.627 Y77.504 E.01235
G1 X99.736 Y77 E.01254
G1 X100 Y76.551 E.01267
G1 X100.018 Y76.072 E.01166
G1 X100.151 Y75.97 E.00408
G1 X100.183 Y75.967 E.00078
G1 X130.817 Y75.967 E.74514
G1 X130.922 Y76 E.00268
G1 X131 Y76.15 E.00411
G1 X131 Y76.551 E.00975
G1 X131.264 Y77 E.01267
G1 X131.373 Y77.503 E.01252
G1 X131.264 Y78 E.01238
G1 X131 Y78.45 E.01269
G1 X130.996 Y79.712 E.0307
G1 X130.989 Y82.348 E.06412
G1 X130.899 Y82.964 E.01514
G1 X130.709 Y83.585 E.0158
G1 X130.297 Y84.365 E.02146
G1 X129.669 Y85.116 E.02381
G1 X128.897 Y85.687 E.02336
G1 X128.356 Y85.951 E.01464
G1 X127.44 Y86.2 E.02309
G1 X126.814 Y86.249 E.01527
G1 X120.483 Y86.25 E.154
G1 X120.408 Y86.234 E.00187
G1 X120.404 Y86.228 E.00018
G1 X120.404 Y86.228 F9000
G1 X120.124 Y86.497
;TYPE:Perimeter
G1 F6000
G1 X110.787 Y86.497 E.22711
G1 X110.741 Y86.568 E.00206
G1 X110.517 Y86.616 E.00557
G1 X104.2 Y86.616 E.15365
G1 X103.775 Y86.593 E.01035
G1 X102.925 Y86.431 E.02105
G1 X102.326 Y86.208 E.01555
G1 X101.662 Y85.843 E.01843
G1 X101.127 Y85.425 E.01651
G1 X100.662 Y84.934 E.01645
G1 X100.274 Y84.378 E.01649
G1 X99.963 Y83.746 E.01713
G1 X99.697 Y82.784 E.02428
G1 X99.634 Y82.051 E.0179
G1 X99.634 Y78.549 E.08518
G1 X99.375 Y78.086 E.0129
G1 X99.262 Y77.511 E.01425
G1 X99.356 Y76.983 E.01305
G1 X99.634 Y76.451 E.0146
G1 X99.635 Y76.122 E.008
G1 X99.687 Y75.915 E.00519
G1 X99.867 Y75.701 E.0068
G1 X100.183 Y75.601 E.00806
G1 X130.817 Y75.601 E.74514
G1 X131.133 Y75.701 E.00806
G1 X131.313 Y75.915 E.0068
G1 X131.366 Y76.15 E.00586
G1 X131.366 Y76.451 E.00732
G1 X131.644 Y76.983 E.0146
G1 X131.738 Y77.508 E.01297
G1 X131.644 Y78.017 E.01259
G1 X131.365 Y78.55 E.01463
G1 X131.362 Y79.713 E.02829
G1 X131.355 Y82.349 E.06412
G1 X131.26 Y83.018 E.01644
G1 X131.058 Y83.693 E.01714
G1 X130.62 Y84.537 E.02313
G1 X129.946 Y85.355 E.02578
G1 X129.113 Y85.982 E.02536
G1 X128.514 Y86.28 E.01627
G1 X127.534 Y86.553 E.02475
G1 X126.841 Y86.614 E.01692
G1 X120.483 Y86.616 E.15465
G1 X120.259 Y86.568 E.00557
G1 X120.213 Y86.497 E.00206
G1 X120.184 Y86.497 E.00071
G1 X120.184 Y86.497 F9000
G1 X119.855 Y86.863
G1 F6000
G1 X110.915 Y86.863 E.21746
G1 X110.89 Y86.902 E.00113
G1 X110.517 Y86.981 E.00927
G1 X104.2 Y86.981 E.15365
G1 X103.707 Y86.952 E.01201
G1 X102.857 Y86.79 E.02105
G1 X102.194 Y86.549 E.01716
G1 X101.48 Y86.16 E.01978
G1 X100.899 Y85.711 E.01786
G1 X100.395 Y85.183 E.01775
G1 X99.973 Y84.585 E.0178
G1 X99.633 Y83.904 E.01851
G1 X99.344 Y82.878 E.02593
G1 X99.271 Y82.119 E.01855
G1 X99.269 Y78.648 E.08443
G1 X99.029 Y78.206 E.01223
G1 X98.914 Y77.684 E.013
G1 X98.914 Y77.316 E.00895
G1 X98.998 Y76.909 E.01011
G1 X99.166 Y76.526 E.01017
G1 X99.269 Y76.352 E.00492
G1 X99.27 Y76.103 E.00606
G1 X99.356 Y75.759 E.00862
G1 X99.657 Y75.402 E.01136
G1 X100.027 Y75.263 E.00961
;WIDTH:0.372535
G1 X100.183 Y75.253 E.00352
;WIDTH:0.368101
G1 X130.817 Y75.252 E.68014
;WIDTH:0.399999
G1 X131.343 Y75.402 E.0133
G1 X131.643 Y75.759 E.01134
G1 X131.731 Y76.15 E.00975
G1 X131.731 Y76.352 E.00491
G1 X131.895 Y76.629 E.00783
G1 X132.002 Y76.909 E.00729
G1 X132.104 Y77.513 E.0149
G1 X132.009 Y78.058 E.01346
G1 X131.895 Y78.371 E.0081
G1 X131.731 Y78.65 E.00787
G1 X131.728 Y79.714 E.02588
G1 X131.72 Y82.35 E.06412
G1 X131.622 Y83.072 E.01772
G1 X131.407 Y83.802 E.01851
G1 X130.943 Y84.709 E.02478
G1 X130.805 Y84.918 E.00609
G1 X130.223 Y85.593 E.02168
G1 X129.329 Y86.277 E.02738
G1 X128.672 Y86.61 E.01792
G1 X127.629 Y86.906 E.02637
G1 X126.868 Y86.979 E.0186
G1 X120.483 Y86.981 E.15531
G1 X120.11 Y86.902 E.00927
G1 X120.085 Y86.863 E.00113
G1 X119.915 Y86.863 E.00414
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X119.855 Y86.863 E-.0285
G1 X116.757 Y86.863 E-1.4715
;WIPE_END
G1 X119.915 Y74.205 F9000
G1 E5 F2400
G1 F6000
G1 X135.541 Y74.201 E.38009
G1 X136.199 Y74.243 E.01604
G1 X136.888 Y74.369 E.01704
G1 X137.557 Y74.577 E.01704
G1 X138.195 Y74.865 E.01703
G1 X138.792 Y75.226 E.01697
G1 X139.601 Y75.9 E.02561
G1 X140.273 Y76.706 E.02553
G1 X140.788 Y77.62 E.02552
G1 X141.131 Y78.612 E.02553
G1 X141.289 Y79.653 E.02561
G1 X141.289 Y80.042 E.00946
G1 X141.3 Y150.994 E1.72584
G1 X141.258 Y151.698 E.01715
G1 X141.132 Y152.385 E.01699
G1 X140.924 Y153.053 E.01702
G1 X140.638 Y153.69 E.01698
G1 X140.277 Y154.289 E.01701
G1 X139.847 Y154.84 E.017
G1 X139.353 Y155.334 E.01699
G1 X138.783 Y155.781 E.01762
G1 X138.186 Y156.14 E.01694
G1 X137.245 Y156.53 E.02478
G1 X136.531 Y156.707 E.01789
G1 X135.845 Y156.789 E.01681
G1 X95.482 Y156.8 E.98179
G1 X94.792 Y156.756 E.01682
G1 X94.102 Y156.629 E.01707
G1 X93.448 Y156.425 E.01666
G1 X92.816 Y156.141 E.01685
G1 X92.196 Y155.766 E.01762
G1 X91.647 Y155.335 E.01698
G1 X91.153 Y154.84 E.01701
G1 X90.723 Y154.289 E.017
G1 X90.363 Y153.692 E.01696
G1 X89.969 Y152.743 E.02499
G1 X89.795 Y152.043 E.01754
G1 X89.711 Y151.349 E.017
G1 X89.7 Y80.006 E1.73535
G1 X89.743 Y79.301 E.01718
G1 X89.869 Y78.612 E.01704
G1 X90.077 Y77.943 E.01704
G1 X90.365 Y77.305 E.01703
G1 X90.727 Y76.705 E.01704
G1 X91.159 Y76.154 E.01703
G1 X91.654 Y75.659 E.01703
G1 X92.205 Y75.227 E.01703
G1 X92.805 Y74.865 E.01704
G1 X93.441 Y74.578 E.01697
G1 X94.412 Y74.305 E.02453
G1 X95.15 Y74.211 E.0181
G1 X119.855 Y74.205 E.60092
G1 X119.855 Y74.205 F9000
G1 X119.855 Y74.571
;TYPE:Perimeter
G1 F6000
G1 X135.529 Y74.567 E.38125
G1 X136.154 Y74.606 E.01523
G1 X136.8 Y74.725 E.01598
G1 X137.427 Y74.92 E.01597
G1 X138.025 Y75.189 E.01595
G1 X138.58 Y75.524 E.01577
G1 X139.341 Y76.159 E.02411
G1 X139.971 Y76.914 E.02392
G1 X140.454 Y77.771 E.02393
G1 X140.774 Y78.7 E.0239
G1 X140.923 Y79.68 E.02411
G1 X140.923 Y80.042 E.00881
G1 X140.925 Y93.02 E.31568
;WIDTH:0.448959
G1 X140.901 Y93.214 E.00539
;WIDTH:0.497919
G1 X140.877 Y93.408 E.00603
;WIDTH:0.546878
G1 X140.852 Y93.602 E.00667
;WIDTH:0.547002
G1 X140.852 Y95.226 E.05538
G1 X140.877 Y95.42 E.00667
;WIDTH:0.498001
G1 X140.901 Y95.614 E.00603
;WIDTH:0.449
G1 X140.926 Y95.809 E.00542
;WIDTH:0.399999
G1 X140.934 Y150.983 E1.34205
G1 X140.894 Y151.654 E.01635
G1 X140.776 Y152.298 E.01593
G1 X140.582 Y152.923 E.01592
G1 X140.313 Y153.52 E.01593
G1 X139.975 Y154.081 E.01593
G1 X139.572 Y154.597 E.01593
G1 X139.11 Y155.06 E.01591
G1 X138.575 Y155.479 E.01653
G1 X138.021 Y155.812 E.01572
G1 X137.13 Y156.182 E.02347
G1 X136.465 Y156.347 E.01667
G1 X135.823 Y156.424 E.01573
G1 X95.493 Y156.434 E.98099
G1 X94.836 Y156.393 E.01601
G1 X94.19 Y156.273 E.01598
G1 X93.578 Y156.082 E.01559
G1 X92.986 Y155.817 E.01578
G1 X92.405 Y155.465 E.01652
G1 X91.89 Y155.061 E.01592
G1 X91.428 Y154.597 E.01593
G1 X91.025 Y154.081 E.01593
G1 X90.691 Y153.527 E.01574
G1 X90.318 Y152.629 E.02365
G1 X90.155 Y151.977 E.01635
G1 X90.077 Y151.327 E.01592
G1 X90.068 Y95.81 E1.3504
;WIDTH:0.437585
G1 X90.087 Y95.664 E.00395
;WIDTH:0.475171
G1 X90.106 Y95.519 E.00429
;WIDTH:0.512757
G1 X90.124 Y95.373 E.00468
;WIDTH:0.550342
G1 X90.143 Y95.227 E.00505
;WIDTH:0.550466
G1 X90.143 Y93.602 E.05579
G1 X90.124 Y93.456 E.00505
;WIDTH:0.51285
G1 X90.105 Y93.31 E.00469
;WIDTH:0.475233
G1 X90.086 Y93.164 E.00432
;WIDTH:0.437616
G1 X90.068 Y93.018 E.00395
;WIDTH:0.399999
G1 X90.066 Y80.017 E.31624
G1 X90.106 Y79.345 E.01637
G1 X90.225 Y78.7 E.01595
G1 X90.42 Y78.073 E.01597
G1 X90.689 Y77.475 E.01595
G1 X91.028 Y76.914 E.01594
G1 X91.433 Y76.397 E.01597
G1 X91.897 Y75.933 E.01596
G1 X92.414 Y75.528 E.01597
G1 X92.975 Y75.189 E.01594
G1 X93.567 Y74.923 E.01579
G1 X94.485 Y74.664 E.0232
G1 X95.173 Y74.577 E.01687
G1 X119.795 Y74.571 E.59891
G1 E-5 F3600
G1 X119.795 Y74.571 F9000
G1 X119.795 Y74.549
G1 X139.559 Y76.363
G1 X140.951 Y80.008
G1 X140.951 Y95.519
G1 X140.56 Y95.519
G1 E5 F2400
G1 F6000
G1 X140.569 Y150.972 E1.34884
G1 X140.53 Y151.61 E.01555
G1 X140.42 Y152.21 E.01484
G1 X140.239 Y152.793 E.01485
G1 X139.989 Y153.35 E.01485
G1 X139.673 Y153.873 E.01486
G1 X139.297 Y154.354 E.01485
G1 X138.867 Y154.786 E.01483
G1 X138.367 Y155.177 E.01544
G1 X137.856 Y155.485 E.01451
G1 X137.016 Y155.833 E.02212
G1 X136.399 Y155.986 E.01546
G1 X135.802 Y156.058 E.01463
G1 X95.505 Y156.068 E.98018
G1 X94.881 Y156.029 E.01521
G1 X94.278 Y155.917 E.01492
G1 X93.708 Y155.739 E.01452
G1 X93.156 Y155.492 E.01471
G1 X92.613 Y155.164 E.01543
G1 X92.134 Y154.787 E.01483
G1 X91.703 Y154.354 E.01486
G1 X91.327 Y153.873 E.01485
G1 X91.018 Y153.361 E.01455
G1 X90.666 Y152.514 E.02231
G1 X90.516 Y151.91 E.01514
G1 X90.442 Y151.305 E.01483
G1 X90.434 Y95.504 E1.3573
G1 X90.549 Y95.772 E.00709
G1 X90.757 Y96.085 E.00914
G1 X90.978 Y96.304 E.00757
G1 X91.412 Y96.546 E.01209
G1 X91.798 Y96.612 E.00953
G1 X93.569 Y96.612 E.04308
G1 X93.571 Y132.81 E.88048
G1 X93.653 Y133.937 E.02749
G1 X93.927 Y135.371 E.03551
G1 X94.241 Y136.371 E.02549
G1 X94.665 Y137.367 E.02633
G1 X95.387 Y138.635 E.03549
G1 X96.025 Y139.503 E.0262
G1 X96.675 Y140.232 E.02376
G1 X97.106 Y140.649 E.01459
G1 X98.152 Y141.497 E.03275
G1 X99.157 Y142.136 E.02897
G1 X100.027 Y142.573 E.02368
G1 X101.047 Y142.971 E.02663
G1 X101.894 Y143.215 E.02144
G1 X102.533 Y143.351 E.01589
G1 X103.769 Y143.504 E.03029
G1 X104.5 Y143.532 E.01779
G1 X110.517 Y143.532 E.14636
G1 X110.645 Y143.523 E.00312
G1 X110.699 Y143.46 E.00202
G1 X120.301 Y143.46 E.23356
G1 X120.355 Y143.523 E.00202
G1 X120.483 Y143.532 E.00312
G1 X126.871 Y143.524 E.15538
G1 X128.039 Y143.421 E.02852
G1 X129.084 Y143.22 E.02588
G1 X130.05 Y142.937 E.02448
G1 X131.467 Y142.337 E.03743
G1 X132.407 Y141.797 E.02637
G1 X133.209 Y141.227 E.02393
G1 X134.294 Y140.261 E.03534
G1 X135.029 Y139.436 E.02688
G1 X135.66 Y138.564 E.02618
G1 X136.152 Y137.73 E.02355
G1 X136.601 Y136.778 E.0256
G1 X136.961 Y135.769 E.02606
G1 X137.193 Y134.865 E.0227
G1 X137.365 Y133.789 E.0265
G1 X137.429 Y132.81 E.02386
G1 X137.431 Y96.612 E.88048
G1 X138.996 Y96.612 E.03807
G1 X139.511 Y96.558 E.0126
G1 X139.771 Y96.465 E.00672
G1 X140.171 Y96.182 E.01192
G1 X140.307 Y96.014 E.00526
G1 X140.533 Y95.572 E.01208
G1 X140.533 Y95.572 F9000
G1 X140.195 Y96.596
G1 F6000
G1 X140.203 Y150.961 E1.32237
G1 X140.167 Y151.565 E.01472
G1 X140.065 Y152.123 E.0138
G1 X139.896 Y152.664 E.01379
G1 X139.664 Y153.18 E.01376
G1 X139.372 Y153.666 E.01379
G1 X139.023 Y154.112 E.01378
G1 X138.624 Y154.512 E.01374
G1 X138.16 Y154.875 E.01433
G1 X137.69 Y155.158 E.01334
G1 X136.901 Y155.485 E.02077
G1 X136.333 Y155.626 E.01424
G1 X135.78 Y155.692 E.01355
G1 X95.516 Y155.703 E.97938
G1 X94.926 Y155.665 E.01438
G1 X94.366 Y155.562 E.01385
G1 X93.837 Y155.397 E.01348
G1 X93.326 Y155.168 E.01362
G1 X92.821 Y154.862 E.01436
G1 X92.377 Y154.513 E.01374
G1 X91.977 Y154.112 E.01378
G1 X91.628 Y153.666 E.01378
G1 X91.345 Y153.196 E.01334
G1 X91.014 Y152.399 E.02099
G1 X90.876 Y151.844 E.01391
G1 X90.808 Y151.283 E.01375
G1 X90.8 Y96.608 E1.32991
G1 X91.328 Y96.901 E.01469
G1 X91.798 Y96.977 E.01158
G1 X93.203 Y96.977 E.03418
G1 X93.208 Y132.899 E.87377
G1 X93.293 Y134.005 E.02698
G1 X93.578 Y135.479 E.03652
G1 X93.904 Y136.512 E.02635
G1 X94.347 Y137.547 E.02738
G1 X95.011 Y138.725 E.03289
G1 X95.752 Y139.746 E.03069
G1 X96.419 Y140.494 E.02438
G1 X96.876 Y140.933 E.01541
G1 X98.043 Y141.868 E.03637
G1 X98.992 Y142.462 E.02723
G1 X99.892 Y142.913 E.02449
G1 X100.945 Y143.322 E.02748
G1 X101.815 Y143.572 E.02202
G1 X102.488 Y143.714 E.01673
G1 X103.724 Y143.867 E.03029
G1 X104.5 Y143.897 E.01889
G1 X110.517 Y143.897 E.14636
G1 X110.696 Y143.885 E.00436
G1 X110.747 Y143.826 E.0019
G1 X120.253 Y143.826 E.23122
G1 X120.304 Y143.885 E.0019
G1 X120.483 Y143.897 E.00436
G1 X126.981 Y143.885 E.15806
G1 X128.108 Y143.78 E.02753
G1 X129.153 Y143.579 E.02588
G1 X130.191 Y143.274 E.02632
G1 X131.005 Y142.933 E.02147
G1 X131.648 Y142.654 E.01705
G1 X132.616 Y142.096 E.02718
G1 X133.453 Y141.5 E.02499
G1 X134.644 Y140.428 E.03898
G1 X135.325 Y139.651 E.02513
G1 X135.974 Y138.751 E.02699
G1 X136.482 Y137.887 E.02438
G1 X136.944 Y136.902 E.02646
G1 X137.314 Y135.862 E.02685
G1 X137.553 Y134.925 E.02352
G1 X137.73 Y133.813 E.02739
G1 X137.795 Y132.81 E.02445
G1 X137.797 Y96.977 E.8716
G1 X138.996 Y96.977 E.02916
G1 X139.635 Y96.902 E.01565
G1 X139.894 Y96.809 E.00669
G1 X140.146 Y96.631 E.0075
G1 X140.146 Y96.631 F9000
G1 X139.829 Y97.221
G1 F6000
G1 X139.837 Y150.814 E1.3036
G1 X139.818 Y151.262 E.01091
G1 X139.756 Y151.78 E.01269
G1 X139.631 Y152.287 E.0127
G1 X139.445 Y152.775 E.0127
G1 X139.203 Y153.238 E.01271
G1 X138.905 Y153.669 E.01275
G1 X138.561 Y154.057 E.01261
G1 X138.129 Y154.435 E.01396
G1 X137.525 Y154.83 E.01755
G1 X136.786 Y155.137 E.01946
G1 X136.267 Y155.266 E.01301
G1 X135.758 Y155.327 E.01247
G1 X95.67 Y155.337 E.9751
G1 X95.229 Y155.318 E.01074
G1 X94.706 Y155.253 E.01282
G1 X94.211 Y155.13 E.01241
G1 X93.734 Y154.95 E.0124
G1 X93.252 Y154.695 E.01326
G1 X92.82 Y154.396 E.01278
G1 X92.426 Y154.044 E.01285
G1 X92.067 Y153.634 E.01326
G1 X91.672 Y153.03 E.01755
G1 X91.362 Y152.284 E.01965
G1 X91.236 Y151.777 E.01271
G1 X91.174 Y151.261 E.01264
G1 X91.165 Y97.214 E1.31464
G1 X91.244 Y97.257 E.00219
G1 X91.798 Y97.343 E.01364
G1 X92.837 Y97.343 E.02527
G1 X92.84 Y132.81 E.8627
G1 X92.934 Y134.072 E.03078
G1 X93.228 Y135.587 E.03754
G1 X93.566 Y136.654 E.02722
G1 X94.028 Y137.726 E.02839
G1 X94.796 Y139.065 E.03755
G1 X95.478 Y139.989 E.02793
G1 X96.163 Y140.755 E.025
G1 X96.646 Y141.217 E.01626
G1 X97.692 Y142.065 E.03275
G1 X98.826 Y142.788 E.03271
G1 X99.756 Y143.253 E.02529
G1 X100.843 Y143.673 E.02835
G1 X101.737 Y143.93 E.02263
G1 X102.443 Y144.077 E.01754
G1 X103.679 Y144.23 E.03029
G1 X104.5 Y144.263 E.01999
G1 X110.517 Y144.263 E.14636
G1 X110.748 Y144.247 E.00563
G1 X110.795 Y144.192 E.00176
G1 X120.205 Y144.192 E.22889
G1 X120.252 Y144.247 E.00176
G1 X120.483 Y144.263 E.00563
G1 X126.872 Y144.255 E.15541
G1 X128.177 Y144.139 E.03187
G1 X129.37 Y143.902 E.02959
G1 X130.332 Y143.611 E.02445
G1 X131.829 Y142.972 E.03959
G1 X132.826 Y142.396 E.02801
G1 X133.696 Y141.773 E.02603
G1 X134.78 Y140.808 E.0353
G1 X135.62 Y139.866 E.0307
G1 X136.288 Y138.938 E.02781
G1 X136.812 Y138.045 E.02518
G1 X137.288 Y137.026 E.02736
G1 X137.668 Y135.954 E.02767
G1 X137.914 Y134.984 E.02434
G1 X138.095 Y133.838 E.02822
G1 X138.16 Y132.81 E.02506
G1 X138.163 Y97.343 E.8627
G1 X139.202 Y97.343 E.02527
G1 X139.77 Y97.232 E.01408
G1 E-5 F3600
G1 X139.77 Y97.232 F9000
G1 X140.249 Y95.726
G1 X140.249 Y93.071
G1 X139.61 Y92.691
G1 X139.422 Y92.624
G1 X139.304 Y92.606
G1 X139.224 Y92.6
G1 X138.594 Y92.599
G1 X134.11 Y74.549
G1 X134.11 Y74.933
G1 E5 F2400
G1 F6000
G1 X135.518 Y74.933 E.03425
G1 X136.11 Y74.97 E.01443
G1 X136.713 Y75.08 E.01491
G1 X137.297 Y75.262 E.01488
G1 X137.855 Y75.513 E.01488
G1 X138.367 Y75.823 E.01456
G1 X139.082 Y76.419 E.02264
G1 X139.668 Y77.123 E.02228
G1 X140.119 Y77.921 E.0223
G1 X140.418 Y78.788 E.02231
G1 X140.558 Y79.708 E.02264
G1 X140.558 Y80.042 E.00812
G1 X140.56 Y93.385 E.32456
G1 X140.451 Y93.056 E.00843
G1 X140.244 Y92.744 E.00911
G1 X140.024 Y92.525 E.00755
G1 X139.589 Y92.283 E.01211
G1 X139.202 Y92.217 E.00955
G1 X126.731 Y92.217 E.30334
G1 X126.731 Y91.648 E.01384
G1 X127.002 Y91.091 E.01507
G1 X127.086 Y90.684 E.01011
G1 X127.086 Y90.316 E.00895
G1 X126.984 Y89.835 E.01196
G1 X126.731 Y89.352 E.01326
G1 X126.731 Y88.683 E.01627
G1 X126.649 Y88.304 E.00943
G1 X126.419 Y87.995 E.00937
G1 X125.817 Y87.769 E.01564
G1 X105.183 Y87.769 E.5019
G1 X105.025 Y87.782 E.00386
G1 X104.581 Y87.995 E.01198
G1 X104.364 Y88.276 E.00864
G1 X104.269 Y88.683 E.01017
G1 X104.269 Y89.352 E.01627
G1 X104.039 Y89.767 E.01154
G1 X103.914 Y90.316 E.0137
G1 X103.914 Y90.684 E.00895
G1 X103.998 Y91.091 E.01011
G1 X104.105 Y91.371 E.00729
G1 X104.269 Y91.648 E.00783
G1 X104.269 Y92.217 E.01384
G1 X91.798 Y92.217 E.30334
G1 X91.467 Y92.279 E.00819
G1 X91.193 Y92.385 E.00715
G1 X90.808 Y92.67 E.01165
G1 X90.557 Y93.043 E.01094
G1 X90.433 Y93.406 E.00933
G1 X90.431 Y80.028 E.32541
G1 X90.47 Y79.389 E.01557
G1 X90.58 Y78.787 E.01489
G1 X90.762 Y78.203 E.01488
G1 X91.013 Y77.645 E.01488
G1 X91.33 Y77.122 E.01488
G1 X91.707 Y76.64 E.01488
G1 X92.14 Y76.207 E.01489
G1 X92.622 Y75.83 E.01488
G1 X93.145 Y75.513 E.01488
G1 X93.692 Y75.267 E.01459
G1 X94.558 Y75.023 E.02188
G1 X95.196 Y74.942 E.01564
G1 X99.511 Y74.941 E.10496
G1 X100.183 Y74.923 E.01635
;WIDTH:0.368101
G1 X130.817 Y74.918 E.68014
;WIDTH:0.399999
G1 X131.491 Y74.934 E.0164
G1 X134.05 Y74.933 E.06225
G1 E-5 F3600
G1 X134.05 Y74.933 F9000
G1 X134.05 Y74.549
G1 X131.138 Y83.418
G1 X131.041 Y83.693
G1 X131.024 Y83.736
G1 X130.908 Y84.004
G1 X130.887 Y84.045
G1 X130.751 Y84.303
G1 X130.728 Y84.343
G1 X130.574 Y84.588
G1 X130.548 Y84.627
G1 X130.376 Y84.86
G1 X130.348 Y84.896
G1 X130.159 Y85.116
G1 X130.128 Y85.15
G1 X129.923 Y85.356
G1 X129.891 Y85.388
G1 X129.671 Y85.577
G1 X129.637 Y85.606
G1 X129.6 Y85.633
G1 X129.367 Y85.805
G1 X129.328 Y85.83
G1 X129.083 Y85.985
G1 X129.042 Y86.007
G1 X128.785 Y86.143
G1 X128.743 Y86.162
G1 X128.478 Y86.278
G1 X128.436 Y86.294
G1 X128.163 Y86.39
G1 X128.119 Y86.403
G1 X127.84 Y86.478
G1 X127.795 Y86.488
G1 X127.511 Y86.542
G1 X127.466 Y86.55
G1 X127.179 Y86.582
G1 X127.133 Y86.587
G1 X126.844 Y86.597
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X105.183 Y87.375 E.0067
;WIDTH:0.456022
G1 X110.517 Y87.375 E.14962
;WIDTH:0.495578
G1 X110.703 Y87.355 E.00574
;WIDTH:0.535136
G1 X110.889 Y87.335 E.00623
;WIDTH:0.574694
G1 X111.074 Y87.316 E.00668
G1 X119.926 Y87.316 E.31818
G1 X120.111 Y87.335 E.00668
;WIDTH:0.535134
G1 X120.297 Y87.355 E.00623
;WIDTH:0.495576
G1 X120.483 Y87.375 E.00574
;WIDTH:0.456022
G1 X125.817 Y87.375 E.14962
G1 E-5 F3600
G1 X125.817 Y87.375 F9000
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X104.628 Y87.57 E.01103
;WIDTH:0.43792
G1 X104.3 Y87.756 E.01012
;WIDTH:0.399999
G1 X104.037 Y88.113 E.01079
G1 X103.903 Y88.683 E.01424
G1 X103.903 Y89.252 E.01384
G1 X103.698 Y89.637 E.01061
G1 X103.556 Y90.243 E.01514
G1 X103.556 Y90.757 E.0125
G1 X103.64 Y91.164 E.01011
G1 X103.892 Y91.729 E.01505
G1 X103.903 Y91.851 E.00298
G1 X91.798 Y91.851 E.29444
G1 X91.335 Y91.938 E.01146
G1 X91.061 Y92.044 E.00715
G1 X90.799 Y92.238 E.00793
G1 X90.797 Y80.039 E.29673
G1 X90.834 Y79.433 E.01477
G1 X90.936 Y78.875 E.0138
G1 X91.105 Y78.333 E.01381
G1 X91.338 Y77.816 E.01379
G1 X91.631 Y77.33 E.0138
G1 X91.982 Y76.883 E.01382
G1 X92.383 Y76.482 E.01379
G1 X92.83 Y76.131 E.01382
G1 X93.315 Y75.838 E.01378
G1 X93.817 Y75.612 E.01339
G1 X94.631 Y75.383 E.02057
G1 X95.22 Y75.308 E.01444
G1 X99.275 Y75.307 E.09863
G1 X99.026 Y75.603 E.00941
G1 X98.905 Y76.084 E.01206
G1 X98.903 Y76.252 E.00409
G1 X98.64 Y76.836 E.01558
G1 X98.53 Y77.526 E.017
G1 X98.556 Y77.757 E.00565
G1 X98.674 Y78.297 E.01344
G1 X98.903 Y78.748 E.0123
G1 X98.907 Y82.146 E.08265
G1 X98.99 Y82.972 E.02019
G1 X99.304 Y84.063 E.02761
G1 X99.671 Y84.792 E.01985
G1 X100.127 Y85.432 E.01911
G1 X100.671 Y85.997 E.01908
G1 X101.298 Y86.477 E.01921
G1 X102.062 Y86.89 E.02113
G1 X102.789 Y87.149 E.01877
G1 X103.639 Y87.311 E.02105
G1 X104.2 Y87.347 E.01367
;WIDTH:0.43792
G1 X104.577 Y87.366 E.01013
;WIDTH:0.47584
G1 X104.895 Y87.382 E.00935
G1 X104.895 Y87.382 F9000
G1 X103.869 Y87.7
;WIDTH:0.399999
G1 F6000
G1 X103.709 Y87.95 E.00722
G1 X103.541 Y88.571 E.01565
G1 X103.537 Y89.153 E.01416
G1 X103.356 Y89.507 E.00967
G1 X103.198 Y90.17 E.01658
G1 X103.198 Y90.83 E.01605
G1 X103.281 Y91.238 E.01013
G1 X103.377 Y91.486 E.00647
G1 X91.798 Y91.486 E.28165
G1 X91.164 Y91.612 E.01572
G1 X91.163 Y80.05 E.28123
G1 X91.197 Y79.478 E.01394
G1 X91.292 Y78.963 E.01274
G1 X91.447 Y78.463 E.01273
G1 X91.662 Y77.986 E.01273
G1 X91.933 Y77.538 E.01274
G1 X92.256 Y77.126 E.01273
G1 X92.626 Y76.756 E.01273
G1 X93.038 Y76.433 E.01273
G1 X93.486 Y76.162 E.01274
G1 X93.943 Y75.957 E.01218
G1 X94.704 Y75.742 E.01924
G1 X95.243 Y75.674 E.01321
G1 X98.638 Y75.673 E.08258
G1 X98.537 Y76.15 E.01186
G1 X98.475 Y76.259 E.00305
G1 X98.281 Y76.762 E.01311
G1 X98.165 Y77.534 E.01899
G1 X98.198 Y77.83 E.00724
G1 X98.317 Y78.38 E.01369
G1 X98.537 Y78.847 E.01256
G1 X98.542 Y82.173 E.0809
G1 X98.637 Y83.066 E.02184
G1 X98.974 Y84.222 E.02929
G1 X99.369 Y84.998 E.02118
G1 X99.859 Y85.681 E.02045
G1 X100.443 Y86.283 E.0204
G1 X101.116 Y86.795 E.02057
G1 X101.929 Y87.231 E.02244
G1 X102.72 Y87.509 E.02039
G1 X103.81 Y87.69 E.02688
G1 E-5 F3600
G1 X103.81 Y87.69 F9000
G1 X125.817 Y87.375
G1 E5 F2400
;WIDTH:0.456022
G1 F6000
G1 X126.356 Y87.359 E.01513
;WIDTH:0.428011
G1 X126.895 Y87.343 E.01412
;WIDTH:0.399999
G1 X127.724 Y87.259 E.02027
G1 X128.309 Y87.102 E.01473
G1 X128.831 Y86.939 E.0133
G1 X129.545 Y86.572 E.01953
G1 X130.5 Y85.832 E.02939
G1 X131.082 Y85.157 E.02168
G1 X131.265 Y84.881 E.00806
G1 X131.756 Y83.91 E.02647
G1 X131.984 Y83.126 E.01986
G1 X132.086 Y82.351 E.01901
G1 X132.096 Y78.75 E.08759
G1 X132.21 Y78.556 E.00547
G1 X132.367 Y78.131 E.01102
G1 X132.47 Y77.518 E.01512
G1 X132.36 Y76.836 E.0168
G1 X132.097 Y76.252 E.01558
G1 X132.097 Y76.15 E.00248
G1 X131.974 Y75.602 E.01366
G1 X131.719 Y75.299 E.00963
G1 X135.507 Y75.298 E.09214
G1 X136.065 Y75.333 E.0136
G1 X136.625 Y75.436 E.01385
G1 X137.167 Y75.605 E.01381
G1 X137.684 Y75.838 E.01379
G1 X138.154 Y76.122 E.01336
G1 X138.822 Y76.678 E.02114
G1 X139.366 Y77.332 E.02069
G1 X139.784 Y78.072 E.02067
G1 X140.061 Y78.876 E.02068
G1 X140.146 Y79.433 E.01371
G1 X140.192 Y80.042 E.01486
G1 X140.194 Y92.217 E.29614
G1 X139.673 Y91.927 E.0145
G1 X139.202 Y91.851 E.0116
G1 X127.097 Y91.851 E.29444
G1 X127.108 Y91.729 E.00298
G1 X127.36 Y91.164 E.01505
G1 X127.444 Y90.757 E.01011
G1 X127.444 Y90.243 E.0125
G1 X127.334 Y89.732 E.01271
G1 X127.097 Y89.252 E.01302
G1 X127.061 Y88.38 E.02123
G1 X126.982 Y88.152 E.00587
G1 X126.66 Y87.72 E.01311
;WIDTH:0.428011
G1 X126.239 Y87.548 E.01191
;WIDTH:0.456022
G1 X125.873 Y87.398 E.0111
G1 X125.873 Y87.398 F9000
G1 X127.104 Y87.695
;WIDTH:0.399999
G1 F6000
G1 X127.819 Y87.612 E.01751
G1 X128.511 Y87.427 E.01742
G1 X128.989 Y87.269 E.01225
G1 X129.762 Y86.867 E.02119
G1 X130.503 Y86.324 E.02235
G1 X130.777 Y86.071 E.00907
G1 X131.359 Y85.396 E.02168
G1 X131.588 Y85.052 E.01005
G1 X132.106 Y84.018 E.02813
G1 X132.345 Y83.18 E.0212
G1 X132.452 Y82.352 E.02031
G1 X132.461 Y78.85 E.08518
G1 X132.661 Y78.448 E.01092
G1 X132.757 Y78.048 E.01001
G1 X132.835 Y77.523 E.01291
G1 X132.719 Y76.762 E.01872
G1 X132.464 Y76.155 E.01601
G1 X132.36 Y75.665 E.01218
G1 X134.721 Y75.664 E.05743
G1 X135.845 Y75.686 E.02735
G1 X136.351 Y75.758 E.01243
G1 X136.849 Y75.889 E.01253
G1 X137.329 Y76.079 E.01256
G1 X137.941 Y76.42 E.01704
G1 X138.562 Y76.938 E.01967
G1 X139.064 Y77.54 E.01907
G1 X139.449 Y78.223 E.01907
G1 X139.705 Y78.964 E.01907
G1 X139.785 Y79.488 E.01289
G1 X139.826 Y80.042 E.01351
G1 X139.828 Y91.611 E.2814
G1 X139.757 Y91.571 E.00198
G1 X139.202 Y91.486 E.01366
G1 X127.623 Y91.486 E.28165
G1 X127.719 Y91.238 E.00647
G1 X127.802 Y90.83 E.01013
G1 X127.802 Y90.17 E.01605
G1 X127.685 Y89.628 E.01349
G1 X127.463 Y89.153 E.01275
G1 X127.463 Y88.794 E.00873
G1 X127.416 Y88.293 E.01224
G1 X127.315 Y88.001 E.00752
G1 X127.138 Y87.744 E.00759
G1 E-5 F3600
G1 X127.138 Y87.744 F9000
G1 X129.671 Y85.577
G1 X129.891 Y85.388
G1 X129.923 Y85.356
G1 X130.128 Y85.15
G1 X130.159 Y85.116
G1 X130.348 Y84.896
G1 X130.376 Y84.86
G1 X130.548 Y84.627
G1 X130.574 Y84.588
G1 X130.728 Y84.343
G1 X130.751 Y84.303
G1 X130.887 Y84.045
G1 X130.908 Y84.004
G1 X131.024 Y83.736
G1 X131.041 Y83.693
G1 X131.138 Y83.418
G1 X131.151 Y83.374
G1 X131.227 Y83.093
G1 X131.238 Y83.049
G1 X132.791 Y75.955
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.4594
G1 F1200
G1 X132.754 Y75.918 E.00148
G1 X132.703 Y75.931 E.00149
G1 X132.689 Y75.983 E.00152
G1 X132.726 Y76.02 E.00148
G1 X132.778 Y76.006 E.00152
;WIDTH:0.399999
G1 X132.865 Y76.403 E.00989
G1 X133.328 Y75.94 E.01593
G1 X133.845 Y75.941 E.01258
G1 X133.003 Y76.783 E.02896
G1 X133.081 Y77.221 E.01082
G1 X134.361 Y75.941 E.04403
G1 X134.877 Y75.942 E.01255
G1 X133.089 Y77.731 E.06152
G1 X133.089 Y77.731 F9000
G1 X132.827 Y78.656
;WIDTH:0.374336
G1 F1200
G1 X132.786 Y78.667 E.00096
G1 X132.767 Y78.596 E.00166
G1 X132.838 Y78.615 E.00166
;WIDTH:0.399999
G1 X132.969 Y78.367 E.00682
G1 X135.394 Y75.943 E.0834
G1 X135.89 Y75.964 E.01208
G1 X132.735 Y79.119 E.10853
G1 X132.733 Y79.638 E.01262
G1 X136.337 Y76.034 E.12398
G1 X136.745 Y76.144 E.01028
G1 X132.732 Y80.156 E.13803
G1 X132.731 Y80.675 E.01262
G1 X137.12 Y76.285 E.151
G1 X137.468 Y76.455 E.00942
G1 X132.729 Y81.193 E.163
G1 X132.728 Y81.712 E.01262
G1 X137.789 Y76.65 E.17411
G1 X138.071 Y76.886 E.00894
G1 X132.726 Y82.23 E.18385
G1 X132.681 Y82.793 E.01374
G1 X138.353 Y77.121 E.19511
G1 X138.591 Y77.4 E.00892
G1 X132.572 Y83.419 E.20705
G1 X132.464 Y83.667 E.00658
;WIDTH:0.374336
G1 X132.393 Y83.648 E.00166
G1 X132.412 Y83.719 E.00166
G1 X132.453 Y83.708 E.00096
G1 X132.453 Y83.708 F9000
G1 X132.195 Y84.458
G1 F1200
G1 X132.154 Y84.469 E.00096
G1 X132.134 Y84.397 E.00169
G1 X132.206 Y84.417 E.00169
;WIDTH:0.399999
G1 X132.339 Y84.169 E.00685
G1 X138.826 Y77.682 E.22315
G1 E-5 F3600
G1 X138.826 Y77.682 F9000
G1 X128.492 Y87.633
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X128.421 Y87.614 E.00166
G1 X128.44 Y87.685 E.00166
G1 X128.481 Y87.674 E.00096
;WIDTH:0.399999
G1 X128.196 Y87.795 E.00753
G1 X127.691 Y88.299 E.01735
G1 X127.737 Y88.771 E.01154
G1 X128.92 Y87.588 E.04069
G1 X128.92 Y87.588 F9000
G1 X129.973 Y87.052
G1 F1200
G1 X127.81 Y89.215 E.07441
G1 E-5 F3600
G1 X127.81 Y89.215 F9000
G1 X130.232 Y86.83
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X130.622 Y86.495 E.01163
G1 X131.582 Y85.49 E.03143
;WIDTH:0.399999
G1 X131.793 Y85.232 E.00811
G1 X139.015 Y78.011 E.24841
G1 X139.2 Y78.342 E.00922
G1 X127.956 Y89.586 E.38679
G1 X128.048 Y90.011 E.01058
G1 X139.333 Y78.727 E.38818
G1 X139.452 Y79.125 E.0101
G1 X128.073 Y90.504 E.39143
G1 X128.073 Y90.504 F9000
G1 X127.927 Y91.325
;WIDTH:0.374336
G1 F1200
G1 X127.886 Y91.336 E.00096
G1 X127.867 Y91.265 E.00166
G1 X127.938 Y91.284 E.00166
;WIDTH:0.399999
G1 X128.033 Y91.061 E.0059
G1 X139.52 Y79.573 E.39516
G1 X139.552 Y80.059 E.01185
G1 X128.399 Y91.211 E.38364
G1 X128.917 Y91.211 E.0126
G1 X139.552 Y80.576 E.36584
G1 X139.552 Y81.093 E.01258
G1 X129.434 Y91.211 E.34805
G1 X129.951 Y91.211 E.01258
G1 X139.552 Y81.61 E.33027
G1 X139.553 Y82.127 E.01258
G1 X130.468 Y91.211 E.3125
G1 X130.985 Y91.211 E.01258
G1 X139.553 Y82.644 E.29472
G1 X139.553 Y83.161 E.01258
G1 X131.502 Y91.211 E.27693
G1 X132.019 Y91.211 E.01258
G1 X139.553 Y83.678 E.25915
G1 X139.553 Y84.195 E.01258
G1 X132.536 Y91.211 E.24136
G1 X133.054 Y91.211 E.0126
G1 X139.553 Y84.712 E.22356
G1 X139.553 Y85.229 E.01258
G1 X133.571 Y91.211 E.20578
G1 X134.088 Y91.211 E.01258
G1 X139.553 Y85.746 E.18799
G1 X139.553 Y86.263 E.01258
G1 X134.605 Y91.211 E.17021
G1 X135.122 Y91.211 E.01258
G1 X139.553 Y86.78 E.15242
G1 X139.553 Y87.297 E.01258
G1 X135.639 Y91.211 E.13464
G1 X136.156 Y91.211 E.01258
G1 X139.553 Y87.814 E.11685
G1 X139.553 Y88.331 E.01258
G1 X136.673 Y91.211 E.09907
G1 X137.191 Y91.211 E.0126
G1 X139.554 Y88.848 E.08129
G1 X139.554 Y89.365 E.01258
G1 X137.708 Y91.211 E.0635
G1 X138.225 Y91.211 E.01258
G1 X139.554 Y89.882 E.04572
G1 X139.554 Y90.399 E.01258
G1 X138.742 Y91.211 E.02793
G1 X139.254 Y91.217 E.01245
G1 X139.554 Y90.916 E.01034
G1 E-5 F3600
G1 X139.554 Y90.916 F9000
G1 X140.249 Y93.071
G1 X140.249 Y95.726
G1 X138.813 Y97.617
G1 E5 F2400
G1 F1200
G1 X138.437 Y97.617 E.00915
G1 X138.434 Y132.819 E.85625
G1 X138.367 Y133.869 E.02559
G1 X138.147 Y135.207 E.03298
G1 X137.885 Y136.18 E.02451
G1 X137.548 Y137.115 E.02418
G1 X137.259 Y137.724 E.0164
G1 X139.432 Y135.551 E.07475
G1 X139.561 Y135.551 E.00314
G1 X139.555 Y97.557 E.92417
G1 X138.996 Y97.617 E.01368
G1 X139.001 Y97.988 E.00903
;WIDTH:0.410621
G1 X138.808 Y97.988 E.00483
G1 X138.808 Y98.176 E.00471
;WIDTH:0.414298
G1 X138.808 Y132.807 E.8753
;WIDTH:0.415047
G1 X138.807 Y132.842 E.00089
;WIDTH:0.447801
G1 X138.758 Y133.876 E.02847
;WIDTH:0.452198
G1 X138.754 Y133.933 E.00159
;WIDTH:0.499806
G1 X138.683 Y134.513 E.01809
;WIDTH:0.547414
G1 X138.612 Y135.093 E.01994
G1 X138.398 Y135.964 E.03061
G1 X139.12 Y135.24 E.0349
G1 X139.145 Y134.55 E.02357
;WIDTH:0.499806
G1 X139.169 Y133.967 E.01807
;WIDTH:0.452198
G1 X139.171 Y133.889 E.00217
;WIDTH:0.447801
G1 X139.187 Y132.854 E.02847
;WIDTH:0.415047
G1 X139.187 Y132.807 E.00119
;WIDTH:0.414298
G1 X139.184 Y98.176 E.8753
;WIDTH:0.410621
G1 X139.184 Y97.988 E.00471
G1 E-5 F3600
G1 X139.184 Y97.988 F9000
G1 X139.709 Y136.187
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X139.638 Y136.168 E.00166
G1 X139.657 Y136.239 E.00166
G1 X139.698 Y136.228 E.00096
;WIDTH:0.399999
G1 X139.561 Y135.939 E.00778
G1 X136.661 Y138.839 E.09976
G1 X136.458 Y139.098 E.008
;WIDTH:0.374336
G1 X135.735 Y139.951 E.02529
G1 E-5 F3600
G1 X135.735 Y139.951 F9000
G1 X130.843 Y142.213
G1 X130.824 Y142.222
G1 X130.804 Y142.231
G1 X130.781 Y142.241
G1 X130.417 Y142.394
G1 X130.394 Y142.404
G1 X130.341 Y142.425
G1 X129.931 Y142.575
G1 X129.862 Y142.599
G1 X129.519 Y142.707
G1 X129.452 Y142.727
G1 X129.367 Y142.751
G1 X129.044 Y142.837
G1 X128.958 Y142.858
G1 X128.858 Y142.881
G1 X128.556 Y142.946
G1 X128.452 Y142.967
G1 X128.337 Y142.986
G1 X128.056 Y143.033
G1 X127.935 Y143.051
G1 X127.545 Y143.097
G1 X127.413 Y143.109
G1 X127.155 Y143.127
G1 X127.025 Y143.136
G1 X126.887 Y143.141
G1 X126.637 Y143.147
G1 X126.504 Y143.149
G1 X104.496 Y143.149
G1 X104.363 Y143.147
G1 X104.113 Y143.141
G1 X103.975 Y143.136
G1 X103.845 Y143.127
G1 X103.587 Y143.109
G1 X103.455 Y143.097
G1 X103.065 Y143.051
G1 X102.944 Y143.033
G1 X102.663 Y142.986
G1 X102.548 Y142.967
G1 X102.444 Y142.946
G1 X102.142 Y142.881
G1 X102.042 Y142.858
G1 X101.956 Y142.837
G1 X101.633 Y142.751
G1 X101.548 Y142.727
G1 X101.481 Y142.707
G1 X101.138 Y142.599
G1 X101.069 Y142.575
G1 X100.659 Y142.424
G1 X100.606 Y142.404
G1 X100.583 Y142.394
G1 X100.219 Y142.241
G1 X100.196 Y142.231
G1 X100.176 Y142.222
G1 X100.157 Y142.213
G1 X100.138 Y142.204
G1 X99.753 Y142.02
G1 X99.733 Y142.01
G1 X99.714 Y142.001
G1 X99.696 Y141.991
G1 X99.312 Y141.785
G1 X99.25 Y141.749
G1 X98.888 Y141.532
G1 X98.827 Y141.493
G1 X98.477 Y141.26
G1 X98.417 Y141.218
G1 X98.078 Y140.968
G1 X98.021 Y140.924
G1 X97.693 Y140.658
G1 X97.638 Y140.611
G1 X97.324 Y140.331
G1 X97.271 Y140.281
G1 X96.971 Y139.988
G1 X96.929 Y139.946
G1 X96.644 Y139.639
G1 X96.606 Y139.597
G1 X96.57 Y139.556
G1 X96.299 Y139.234
G1 X96.264 Y139.191
G1 X96.007 Y138.855
G1 X95.974 Y138.812
G1 X95.731 Y138.463
G1 X95.702 Y138.421
G1 X95.677 Y138.38
G1 X95.448 Y138.017
G1 X95.424 Y137.975
G1 X95.205 Y137.587
G1 X95.191 Y137.561
G1 X95.172 Y137.525
G1 X94.993 Y137.17
G1 X94.984 Y137.152
G1 X94.973 Y137.13
G1 X94.961 Y137.103
G1 X94.948 Y137.074
G1 X94.795 Y136.732
G1 X94.783 Y136.705
G1 X94.769 Y136.671
G1 X94.754 Y136.635
G1 X94.74 Y136.6
G1 X94.611 Y136.271
G1 X94.597 Y136.234
G1 X94.583 Y136.196
G1 X94.57 Y136.159
G1 X94.445 Y135.789
G1 X94.433 Y135.752
G1 X94.422 Y135.716
G1 X94.414 Y135.686
G1 X94.311 Y135.329
G1 X94.302 Y135.297
G1 X94.295 Y135.269
G1 X94.288 Y135.244
G1 X94.284 Y135.225
G1 X94.188 Y134.819
G1 X94.18 Y134.786
G1 X94.174 Y134.754
G1 X94.094 Y134.326
G1 X94.085 Y134.271
G1 X94.024 Y133.837
G1 X94.018 Y133.781
G1 X93.978 Y133.345
G1 X93.974 Y133.289
G1 X91.804 Y97.617
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X92.563 Y97.617 E.01846
G1 X92.566 Y132.821 E.8563
G1 X92.661 Y134.105 E.03132
G1 X92.968 Y135.674 E.03889
G1 X93.309 Y136.748 E.02741
G1 X93.697 Y137.672 E.02438
G1 X94.133 Y138.446 E.02161
G1 X91.446 Y141.132 E.09241
G1 X91.44 Y97.573 E1.05953
G1 X91.622 Y97.595 E.00446
G1 X91.812 Y97.989 E.01064
;WIDTH:0.413297
G1 X92.191 Y97.989 E.00955
G1 X92.194 Y132.807 E.87771
;WIDTH:0.412677
G1 X92.195 Y132.848 E.00103
;WIDTH:0.459342
G1 X92.265 Y134.116 E.0359
;WIDTH:0.461882
G1 X92.438 Y134.954 E.02434
;WIDTH:0.430941
G1 X92.604 Y135.724 E.02078
;WIDTH:0.399999
G1 X92.978 Y136.905 E.03013
G1 X93.38 Y137.854 E.02507
G1 X93.678 Y138.383 E.01477
G1 X91.812 Y140.25 E.06421
G1 X91.811 Y135.8 E.10824
;WIDTH:0.430941
G1 X91.826 Y135.013 E.02077
;WIDTH:0.461882
G1 X91.841 Y134.132 E.02506
;WIDTH:0.459342
G1 X91.817 Y132.862 E.03591
;WIDTH:0.412677
G1 X91.816 Y132.807 E.00138
;WIDTH:0.413297
G1 X91.812 Y98.172 E.8731
G1 E-5 F3600
G1 X91.812 Y98.172 F9000
G1 X92.177 Y135.442
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X92.271 Y135.895 E.01125
G1 X92.612 Y136.97 E.02743
G1 X93.014 Y137.938 E.0255
G1 X93.223 Y138.321 E.01061
G1 X92.177 Y139.367 E.03598
G1 X92.177 Y135.625 E.09102
G1 E-5 F3600
G1 X92.177 Y135.625 F9000
G1 X92.712 Y138.223
G1 E5 F2400
;WIDTH:0.601186
G1 F1200
G1 X92.662 Y138.173 E.00267
G1 X92.593 Y138.192 E.0027
G1 X92.575 Y138.26 E.00265
G1 X92.625 Y138.31 E.00267
G1 X92.693 Y138.292 E.00265
G1 X92.693 Y138.292 F9000
G1 X94.32 Y138.776
;WIDTH:0.399999
G1 F1200
G1 X91.446 Y141.649 E.09885
G1 X91.446 Y142.167 E.0126
G1 X94.506 Y139.107 E.10526
G1 X94.714 Y139.416 E.00906
G1 X91.446 Y142.684 E.11242
G1 X91.447 Y143.201 E.01258
G1 X94.934 Y139.713 E.11997
G1 X95.154 Y140.01 E.00899
G1 X91.447 Y143.718 E.12754
G1 X91.447 Y144.235 E.01258
G1 X95.385 Y140.296 E.13548
G1 X95.629 Y140.569 E.00891
G1 X91.447 Y144.752 E.14388
G1 X91.447 Y145.269 E.01258
G1 X95.874 Y140.842 E.15229
G1 X96.13 Y141.103 E.00889
G1 X91.447 Y145.786 E.16109
G1 X91.447 Y146.303 E.01258
G1 X96.395 Y141.355 E.17021
G1 X96.674 Y141.593 E.00892
G1 X91.447 Y146.82 E.17981
G1 X91.447 Y147.337 E.01258
G1 X96.96 Y141.824 E.18964
G1 X97.245 Y142.056 E.00894
G1 X91.447 Y147.854 E.19945
G1 X91.447 Y148.371 E.01258
G1 X97.532 Y142.287 E.2093
G1 X97.847 Y142.488 E.00909
G1 X91.447 Y148.888 E.22016
G1 X91.448 Y149.405 E.01258
G1 X98.163 Y142.689 E.23101
G1 X98.479 Y142.891 E.00912
G1 X91.448 Y149.922 E.24186
G1 X91.448 Y150.439 E.01258
G1 X98.804 Y143.083 E.25304
G1 X99.149 Y143.255 E.00938
G1 X91.448 Y150.956 E.26491
G1 X91.473 Y151.449 E.01201
G1 X99.494 Y143.427 E.27593
G1 X99.854 Y143.584 E.00955
G1 X91.547 Y151.891 E.28576
G1 X91.663 Y152.293 E.01018
G1 X100.227 Y143.728 E.29461
G1 X100.6 Y143.873 E.00973
G1 X91.815 Y152.658 E.3022
G1 X91.98 Y153.01 E.00946
G1 X100.989 Y144 E.30992
G1 X101.391 Y144.115 E.01017
G1 X92.178 Y153.329 E.31694
G1 X92.404 Y153.62 E.00896
G1 X101.801 Y144.223 E.32325
G1 X102.229 Y144.312 E.01063
G1 X92.655 Y153.886 E.32934
G1 X92.927 Y154.131 E.0089
G1 X102.676 Y144.382 E.33536
G1 X103.136 Y144.439 E.01127
G1 X93.22 Y154.356 E.34112
G1 X93.542 Y154.55 E.00914
G1 X103.596 Y144.496 E.34585
G1 X104.089 Y144.521 E.01201
G1 X93.89 Y154.719 E.35082
G1 X94.266 Y154.86 E.00977
G1 X104.59 Y144.537 E.35512
G1 X105.107 Y144.537 E.01258
G1 X94.676 Y154.968 E.35882
G1 X95.124 Y155.037 E.01103
G1 X105.624 Y144.537 E.36119
G1 X106.141 Y144.537 E.01258
G1 X95.615 Y155.063 E.36209
G1 X96.133 Y155.063 E.0126
G1 X106.658 Y144.537 E.36207
G1 X107.175 Y144.537 E.01258
G1 X96.65 Y155.062 E.36205
G1 X97.167 Y155.062 E.01258
G1 X107.692 Y144.537 E.36205
G1 X108.209 Y144.537 E.01258
G1 X97.684 Y155.062 E.36205
G1 X98.202 Y155.062 E.0126
G1 X108.727 Y144.537 E.36205
G1 X109.244 Y144.537 E.01258
G1 X98.719 Y155.062 E.36205
G1 X99.236 Y155.062 E.01258
G1 X109.761 Y144.537 E.36205
G1 X110.278 Y144.537 E.01258
G1 X99.753 Y155.062 E.36205
G1 X100.271 Y155.062 E.0126
G1 X110.816 Y144.516 E.36276
G1 X110.978 Y144.334 E.00593
;WIDTH:0.374336
G1 X110.802 Y144.338 E.00398
;WIDTH:0.399999
G1 X111.383 Y144.466 E.01447
G1 X100.788 Y155.061 E.36446
G1 X101.305 Y155.061 E.01258
G1 X111.9 Y144.466 E.36446
G1 X112.418 Y144.466 E.0126
G1 X101.822 Y155.061 E.36448
G1 X102.34 Y155.061 E.0126
G1 X112.935 Y144.466 E.36446
G1 X113.452 Y144.466 E.01258
G1 X102.857 Y155.061 E.36446
G1 X103.374 Y155.061 E.01258
G1 X113.969 Y144.466 E.36446
G1 X114.486 Y144.466 E.01258
G1 X103.891 Y155.061 E.36446
G1 X104.409 Y155.06 E.0126
G1 X115.003 Y144.466 E.36443
G1 X115.52 Y144.466 E.01258
G1 X104.926 Y155.06 E.36443
G1 X105.443 Y155.06 E.01258
G1 X116.037 Y144.466 E.36443
G1 X116.555 Y144.466 E.0126
G1 X105.961 Y155.06 E.36443
G1 X106.478 Y155.06 E.01258
G1 X117.072 Y144.466 E.36443
G1 X117.589 Y144.466 E.01258
G1 X106.995 Y155.06 E.36443
G1 X107.512 Y155.06 E.01258
G1 X118.106 Y144.466 E.36443
G1 X118.623 Y144.466 E.01258
G1 X108.03 Y155.06 E.36441
G1 X108.547 Y155.059 E.01258
G1 X119.14 Y144.466 E.36439
G1 X119.657 Y144.466 E.01258
G1 X109.064 Y155.059 E.36439
G1 X109.581 Y155.059 E.01258
G1 X120.155 Y144.485 E.36374
G1 X120.621 Y144.537 E.01141
G1 X110.099 Y155.059 E.36195
G1 X110.616 Y155.059 E.01258
G1 X121.138 Y144.536 E.36197
G1 X121.656 Y144.536 E.0126
G1 X111.133 Y155.059 E.36198
G1 X111.65 Y155.059 E.01258
G1 X122.174 Y144.535 E.36202
G1 X122.692 Y144.535 E.0126
G1 X112.168 Y155.058 E.362
G1 X112.685 Y155.058 E.01258
G1 X123.209 Y144.534 E.36202
G1 X123.727 Y144.533 E.0126
G1 X113.202 Y155.058 E.36205
G1 X113.719 Y155.058 E.01258
G1 X124.245 Y144.533 E.36207
G1 X124.762 Y144.532 E.01258
G1 X114.237 Y155.058 E.36207
G1 X114.754 Y155.058 E.01258
G1 X125.28 Y144.532 E.36209
G1 X125.798 Y144.531 E.0126
G1 X115.271 Y155.058 E.36212
G1 X115.788 Y155.058 E.01258
G1 X126.316 Y144.53 E.36216
G1 X126.833 Y144.53 E.01258
G1 X116.306 Y155.057 E.36212
G1 X116.823 Y155.057 E.01258
G1 X127.396 Y144.485 E.36369
G1 X127.962 Y144.435 E.01382
G1 X117.34 Y155.057 E.36539
G1 X117.857 Y155.057 E.01258
G1 X128.727 Y144.2 E.3737
;WIDTH:0.374336
G1 X128.686 Y144.211 E.00096
G1 X128.667 Y144.14 E.00166
G1 X128.738 Y144.159 E.00166
;WIDTH:0.399999
G1 X129.221 Y144.211 E.01182
G1 X118.375 Y155.057 E.3731
G1 X118.892 Y155.057 E.01258
G1 X129.93 Y144.019 E.3797
G1 X130.215 Y143.89 E.00761
;WIDTH:0.374336
G1 X130.174 Y143.901 E.00096
G1 X130.155 Y143.829 E.00168
G1 X130.226 Y143.849 E.00167
;WIDTH:0.399999
G1 X130.719 Y143.747 E.01225
G1 X119.409 Y155.057 E.38906
G1 X119.926 Y155.057 E.01258
G1 X131.608 Y143.375 E.40185
G1 E-5 F3600
G1 X131.608 Y143.375 F9000
G1 X133.798 Y141.881
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X132.982 Y142.568 E.02413
;WIDTH:0.399999
G1 X132.723 Y142.777 E.0081
G1 X120.444 Y155.056 E.42239
G1 X120.961 Y155.056 E.01258
G1 X139.561 Y136.456 E.63983
G1 X139.561 Y136.973 E.01258
G1 X121.478 Y155.056 E.62204
G1 X121.995 Y155.056 E.01258
G1 X139.561 Y137.49 E.60426
G1 X139.561 Y138.007 E.01258
G1 X122.513 Y155.056 E.58646
G1 X123.03 Y155.056 E.01258
G1 X139.561 Y138.525 E.56866
G1 X139.561 Y139.042 E.01258
G1 X123.547 Y155.056 E.55087
G1 X124.065 Y155.055 E.0126
G1 X139.561 Y139.559 E.53305
G1 X139.561 Y140.076 E.01258
G1 X124.582 Y155.055 E.51527
G1 X125.099 Y155.055 E.01258
G1 X139.562 Y140.593 E.4975
G1 X139.562 Y141.11 E.01258
G1 X125.616 Y155.055 E.47972
G1 X126.134 Y155.055 E.0126
G1 X139.562 Y141.627 E.46191
G1 X139.562 Y142.144 E.01258
G1 X126.651 Y155.055 E.44413
G1 X127.168 Y155.055 E.01258
G1 X139.562 Y142.661 E.42635
G1 X139.562 Y143.178 E.01258
G1 X127.685 Y155.055 E.40856
G1 X128.203 Y155.054 E.0126
G1 X139.562 Y143.695 E.39074
G1 X139.562 Y144.212 E.01258
G1 X128.72 Y155.054 E.37296
G1 X129.237 Y155.054 E.01258
G1 X139.562 Y144.729 E.35517
G1 X139.562 Y145.246 E.01258
G1 X129.754 Y155.054 E.33739
G1 X130.272 Y155.054 E.0126
G1 X139.562 Y145.763 E.31959
G1 X139.562 Y146.28 E.01258
G1 X130.789 Y155.054 E.3018
G1 X131.306 Y155.054 E.01258
G1 X139.562 Y146.797 E.28402
G1 X139.563 Y147.314 E.01258
G1 X131.823 Y155.053 E.26623
G1 X132.341 Y155.053 E.0126
G1 X139.563 Y147.831 E.24843
G1 X139.563 Y148.348 E.01258
G1 X132.858 Y155.053 E.23065
G1 X133.375 Y155.053 E.01258
G1 X139.563 Y148.865 E.21286
G1 X139.563 Y149.383 E.0126
G1 X133.892 Y155.053 E.19506
G1 X134.41 Y155.053 E.0126
G1 X139.563 Y149.9 E.17726
G1 X139.563 Y150.417 E.01258
G1 X134.927 Y155.053 E.15948
G1 X135.444 Y155.053 E.01258
G1 X139.563 Y150.934 E.14169
G1 X139.53 Y151.483 E.01338
G1 X135.991 Y155.022 E.12174
G1 X136.64 Y154.89 E.01611
G1 X139.388 Y152.143 E.09451
G1 X139.18 Y152.798 E.01672
;WIDTH:0.374336
G1 X139.174 Y152.973 E.00396
G1 X138.563 Y153.706 E.02158
G1 X137.829 Y154.395 E.02277
G1 X137.452 Y154.686 E.01077
G1 X137.301 Y154.681 E.00342
;WIDTH:0.399999
G1 X137.557 Y154.491 E.00775
G1 X138.992 Y153.056 E.04936
G1 E-5 F3600
G1 X138.992 Y153.056 F9000
G1 X99.753 Y142.02
G1 X99.733 Y142.01
G1 X99.714 Y142.001
G1 X99.696 Y141.991
G1 X99.312 Y141.785
G1 X99.25 Y141.749
G1 X98.888 Y141.532
G1 X98.827 Y141.493
G1 X98.477 Y141.26
G1 X98.417 Y141.218
G1 X98.078 Y140.968
G1 X98.021 Y140.924
G1 X97.693 Y140.658
G1 X97.638 Y140.611
G1 X97.324 Y140.331
G1 X97.271 Y140.281
G1 X96.971 Y139.988
G1 X96.929 Y139.946
G1 X96.644 Y139.639
G1 X96.606 Y139.597
G1 X96.57 Y139.556
G1 X96.299 Y139.234
G1 X96.264 Y139.191
G1 X96.007 Y138.855
G1 X95.974 Y138.812
G1 X95.731 Y138.463
G1 X95.702 Y138.421
G1 X95.677 Y138.38
G1 X95.448 Y138.017
G1 X95.424 Y137.975
G1 X95.205 Y137.587
G1 X95.191 Y137.561
G1 X95.172 Y137.525
G1 X94.993 Y137.17
G1 X94.984 Y137.152
G1 X94.973 Y137.13
G1 X94.961 Y137.103
G1 X94.948 Y137.074
G1 X94.795 Y136.732
G1 X94.783 Y136.705
G1 X94.769 Y136.671
G1 X94.754 Y136.635
G1 X94.74 Y136.6
G1 X94.611 Y136.271
G1 X94.597 Y136.234
G1 X94.583 Y136.196
G1 X94.57 Y136.159
G1 X94.445 Y135.789
G1 X94.433 Y135.752
G1 X94.422 Y135.716
G1 X94.414 Y135.686
G1 X94.311 Y135.329
G1 X94.302 Y135.297
G1 X94.295 Y135.269
G1 X94.288 Y135.244
G1 X94.284 Y135.225
G1 X94.188 Y134.819
G1 X94.18 Y134.786
G1 X94.174 Y134.754
G1 X94.094 Y134.326
G1 X94.085 Y134.271
G1 X94.024 Y133.837
G1 X94.018 Y133.781
G1 X93.978 Y133.345
G1 X90.751 Y95.758
G1 X90.751 Y93.103
G1 X93.123 Y76.56
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X92.747 Y76.893 E.01136
G1 X92.393 Y77.247 E.01132
G1 X92.06 Y77.623 E.01136
G1 X92.06 Y77.623 F9000
G1 X91.75 Y78.419
G1 F1200
G1 X91.709 Y78.43 E.00096
G1 X91.689 Y78.358 E.00169
G1 X91.761 Y78.378 E.00169
;WIDTH:0.399999
G1 X91.898 Y78.13 E.00689
G1 X93.63 Y76.398 E.05958
G1 X94.445 Y76.1 F9000
G1 F1200
G1 X91.577 Y78.968 E.09866
G1 X91.465 Y79.597 E.01554
G1 X95.093 Y75.969 E.1248
G1 X95.632 Y75.948 E.01312
G1 X91.437 Y80.142 E.14429
G1 X91.437 Y80.659 E.01258
G1 X96.149 Y75.948 E.16207
G1 X96.666 Y75.947 E.01258
G1 X91.437 Y81.177 E.17989
G1 X91.437 Y81.694 E.01258
G1 X97.183 Y75.947 E.19768
G1 X97.701 Y75.947 E.0126
G1 X91.437 Y82.211 E.21548
G1 X91.437 Y82.728 E.01258
G1 X98.218 Y75.947 E.23326
G1 X98.424 Y75.845 E.00559
;WIDTH:0.374336
G1 X98.22 Y76.529 E.01614
;WIDTH:0.399999
G1 X98.036 Y76.646 E.0053
G1 X91.437 Y83.245 E.227
G1 X91.437 Y83.762 E.01258
G1 X97.913 Y77.286 E.22277
G1 X97.919 Y77.797 E.01243
G1 X91.438 Y84.279 E.22296
G1 X91.438 Y84.796 E.01258
G1 X98.003 Y78.231 E.22583
G1 X98.123 Y78.627 E.01006
G1 X91.438 Y85.313 E.22998
G1 X91.438 Y85.83 E.01258
G1 X98.263 Y79.004 E.23479
G1 X98.264 Y79.521 E.01258
G1 X91.438 Y86.347 E.23481
G1 X91.438 Y86.864 E.01258
G1 X98.265 Y80.037 E.23484
G1 X98.266 Y80.553 E.01255
G1 X91.438 Y87.381 E.23488
G1 X91.438 Y87.898 E.01258
G1 X98.266 Y81.07 E.23488
G1 X98.267 Y81.586 E.01255
G1 X91.438 Y88.415 E.23491
G1 X91.438 Y88.932 E.01258
G1 X98.268 Y82.102 E.23495
G1 X98.302 Y82.585 E.01178
G1 X91.438 Y89.449 E.23612
G1 X91.438 Y89.966 E.01258
G1 X98.355 Y83.05 E.23792
G1 X98.461 Y83.46 E.0103
G1 X91.439 Y90.483 E.24157
G1 X91.439 Y90.483 F9000
G1 X91.413 Y91.374
;WIDTH:0.374336
G1 F1200
G1 X91.372 Y91.385 E.00096
G1 X91.353 Y91.314 E.00166
G1 X91.424 Y91.333 E.00166
;WIDTH:0.399999
G1 X91.439 Y91 E.00811
G1 X98.568 Y83.871 E.24523
G1 X98.697 Y84.259 E.00995
G1 X91.734 Y91.222 E.23952
G1 X92.262 Y91.211 E.01285
G1 X98.861 Y84.612 E.227
G1 X99.031 Y84.959 E.0094
G1 X92.779 Y91.211 E.21506
G1 X93.296 Y91.211 E.01258
G1 X99.231 Y85.277 E.20414
G1 X99.439 Y85.585 E.00904
G1 X93.813 Y91.211 E.19353
G1 X94.33 Y91.211 E.01258
G1 X99.666 Y85.876 E.18354
G1 X99.915 Y86.144 E.0089
G1 X94.848 Y91.211 E.1743
G1 X95.365 Y91.211 E.01258
G1 X100.172 Y86.404 E.16536
G1 X100.452 Y86.641 E.00892
G1 X95.882 Y91.211 E.1572
G1 X96.399 Y91.211 E.01258
G1 X100.74 Y86.87 E.14933
G1 X101.053 Y87.075 E.0091
G1 X96.916 Y91.211 E.14229
G1 X97.433 Y91.211 E.01258
G1 X101.381 Y87.263 E.13581
G1 X101.722 Y87.44 E.00935
G1 X97.95 Y91.211 E.12974
G1 X98.467 Y91.211 E.01258
G1 X102.091 Y87.588 E.12465
G1 X102.473 Y87.722 E.00985
G1 X98.985 Y91.211 E.12
G1 X99.502 Y91.211 E.01258
G1 X102.893 Y87.82 E.11665
G1 X103.59 Y87.848 E.01697
;WIDTH:0.374336
G1 X103.519 Y87.829 E.00166
G1 X103.538 Y87.9 E.00166
G1 X103.579 Y87.889 E.00096
;WIDTH:0.399999
G1 X103.328 Y87.902 E.00611
G1 X100.019 Y91.211 E.11383
G1 X100.536 Y91.211 E.01258
G1 X103.293 Y88.454 E.09484
G1 X103.264 Y89 E.0133
G1 X101.053 Y91.211 E.07606
G1 X101.57 Y91.211 E.01258
G1 X102.997 Y89.784 E.04909
G1 X103.184 Y89.556 E.00717
;WIDTH:0.374336
G1 X103.143 Y89.567 E.00096
G1 X103.124 Y89.496 E.00166
G1 X103.195 Y89.515 E.00166
G1 X103.195 Y89.515 F9000
G1 X102.927 Y90.371
;WIDTH:0.399999
G1 F1200
G1 X102.087 Y91.211 E.0289
G1 X102.604 Y91.211 E.01258
G1 X102.929 Y90.886 E.01118
;LAYER_CHANGE
;Z:0.62
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;0.62
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X102.604 Y91.211 E-.21832
G1 X102.087 Y91.211 E-.24557
G1 X102.927 Y90.371 E-.56427
;WIPE_END
G1 E-.47184 F3600
G1 Z.62 F9000
;AFTER_LAYER_CHANGE
;0.62
G1 Z.62
G1 X104.266 Y92.473
G1 X104.651 Y93.889
G1 X104.947 Y93.543
G1 E5 F2400
;TYPE:External perimeter
G1 F6000
G1 X105 Y93.618 E.00223
G1 X105 Y98.295 E.11376
G1 X104.852 Y98.407 E.00451
G1 X104.845 Y98.457 E.00123
G1 X104.845 Y103.792 E.12977
G1 X104.846 Y103.814 E.00054
G1 X105 Y103.953 E.00505
G1 X105 Y136.368 E.78846
G1 X104.602 Y136.915 E.01645
G1 X104.526 Y137.09 E.00464
G1 X104.438 Y137.475 E.00961
G1 X104.469 Y137.754 E.00683
G1 X104.601 Y138.085 E.00867
G1 X105 Y138.632 E.01647
G1 X105 Y139.323 E.01681
G1 X105.094 Y139.477 E.00439
G1 X105.182 Y139.5 E.00221
G1 X125.817 Y139.5 E.50193
G1 X125.924 Y139.465 E.00274
G1 X126 Y139.317 E.00405
G1 X126 Y138.632 E.01666
G1 X126.398 Y138.085 E.01645
G1 X126.519 Y137.797 E.0076
G1 X126.562 Y137.525 E.0067
G1 X126.531 Y137.246 E.00683
G1 X126.398 Y136.915 E.00868
G1 X126 Y136.368 E.01645
G1 X126 Y103.953 E.78846
G1 X126.15 Y103.836 E.00463
G1 X126.156 Y103.792 E.00108
G1 X126.156 Y98.462 E.12965
G1 X126.154 Y98.433 E.00071
G1 X126 Y98.295 E.00503
G1 X126 Y93.653 E.11291
G1 X126.054 Y93.54 E.00305
G1 X138.926 Y93.54 E.3131
G1 X139.108 Y93.627 E.00491
G1 X139.226 Y93.982 E.0091
G1 X139.227 Y94.847 E.02104
G1 X139.108 Y95.201 E.00908
G1 X138.926 Y95.289 E.00492
G1 X136.183 Y95.289 E.06672
G1 X136.074 Y95.326 E.0028
G1 X136 Y95.472 E.00398
G1 X136 Y127.168 E.77097
G1 X135.978 Y127.642 E.01154
G1 X135.978 Y132.948 E.12906
G1 X135.865 Y133.916 E.02371
G1 X135.692 Y134.735 E.02036
G1 X135.42 Y135.62 E.02252
G1 X135.221 Y136.126 E.01323
G1 X134.861 Y136.884 E.02041
G1 X134.391 Y137.681 E.02251
G1 X134.079 Y138.126 E.01322
G1 X133.552 Y138.78 E.02043
G1 X132.908 Y139.444 E.0225
G1 X132.501 Y139.805 E.01323
G1 X131.836 Y140.317 E.02041
G1 X131.055 Y140.813 E.0225
G1 X130.574 Y141.068 E.01324
G1 X129.808 Y141.412 E.02042
G1 X128.933 Y141.711 E.02249
G1 X128.406 Y141.847 E.01324
G1 X127.583 Y142.002 E.02037
G1 X126.193 Y142.1 E.03389
G1 X120.824 Y142.1 E.1306
G1 X120.745 Y141.976 E.00358
G1 X120.667 Y141.959 E.00194
G1 X110.333 Y141.959 E.25136
G1 X110.301 Y141.961 E.00078
G1 X110.176 Y142.1 E.00455
G1 X104.339 Y142.089 E.14198
G1 X103.043 Y141.94 E.03173
G1 X102.512 Y141.83 E.01319
G1 X101.624 Y141.571 E.0225
G1 X100.843 Y141.265 E.0204
G1 X100.353 Y141.033 E.01319
G1 X99.163 Y140.317 E.03378
G1 X98.15 Y139.498 E.03169
G1 X97.763 Y139.122 E.01312
G1 X96.87 Y138.059 E.03377
G1 X96.177 Y136.956 E.03169
G1 X95.933 Y136.475 E.01312
G1 X95.432 Y135.179 E.0338
G1 X95.134 Y133.914 E.03161
G1 X95.021 Y132.948 E.02366
G1 X95.021 Y127.642 E.12906
G1 X94.999 Y127.607 E.00101
G1 X94.999 Y95.472 E.78165
G1 X94.926 Y95.326 E.00397
G1 X94.816 Y95.289 E.00282
G1 X92.64 Y95.289 E.05293
G1 X91.981 Y95.265 E.01604
G1 X91.843 Y95.125 E.00478
G1 X91.776 Y94.915 E.00536
G1 X91.758 Y94.076 E.02041
G1 X91.883 Y93.648 E.01085
G1 X92.085 Y93.54 E.00557
G1 X104.889 Y93.541 E.31144
G1 X104.889 Y93.541 F9000
G1 X104.634 Y93.968
;TYPE:Perimeter
G1 F6000
G1 X104.634 Y98.205 E.10306
G1 X104.5 Y98.306 E.00408
G1 X104.479 Y98.457 E.00371
G1 X104.479 Y103.792 E.12977
G1 X104.487 Y103.886 E.00229
G1 X104.634 Y104.033 E.00506
G1 X104.634 Y136.249 E.78362
G1 X104.306 Y136.699 E.01354
G1 X104.141 Y137.067 E.00981
G1 X104.076 Y137.426 E.00887
G1 X104.12 Y137.87 E.01085
G1 X104.305 Y138.299 E.01136
G1 X104.634 Y138.751 E.0136
G1 X104.634 Y139.307 E.01352
G1 X104.68 Y139.537 E.00571
G1 X104.917 Y139.797 E.00856
G1 X105.182 Y139.866 E.00666
G1 X125.817 Y139.866 E.50193
G1 X125.912 Y139.857 E.00232
G1 X126.138 Y139.762 E.00596
G1 X126.275 Y139.619 E.00482
G1 X126.366 Y139.317 E.00767
G1 X126.366 Y138.751 E.01377
G1 X126.694 Y138.301 E.01354
G1 X126.859 Y137.933 E.00981
G1 X126.924 Y137.574 E.00887
G1 X126.875 Y137.115 E.01123
G1 X126.694 Y136.699 E.01104
G1 X126.366 Y136.249 E.01354
G1 X126.366 Y104.033 E.78362
G1 X126.505 Y103.925 E.00428
G1 X126.521 Y103.792 E.00326
G1 X126.521 Y98.462 E.12965
G1 X126.5 Y98.306 E.00383
G1 X126.366 Y98.205 E.00408
G1 X126.366 Y93.905 E.10459
G1 X138.828 Y93.905 E.30313
G1 X138.861 Y94 E.00245
G1 X138.882 Y94.44 E.01071
G1 X138.828 Y94.923 E.01182
G1 X136.183 Y94.923 E.06434
G1 X135.854 Y95.033 E.00844
G1 X135.677 Y95.261 E.00702
G1 X135.635 Y95.472 E.00523
G1 X135.634 Y127.168 E.77097
G1 X135.613 Y127.642 E.01154
G1 X135.613 Y132.927 E.12855
G1 X135.504 Y133.857 E.02278
G1 X135.338 Y134.644 E.01956
G1 X135.075 Y135.499 E.02176
G1 X134.886 Y135.98 E.01257
G1 X134.538 Y136.713 E.01974
G1 X134.083 Y137.483 E.02176
G1 X133.786 Y137.906 E.01257
G1 X133.277 Y138.537 E.01972
G1 X132.655 Y139.18 E.02176
G1 X132.268 Y139.523 E.01258
G1 X131.626 Y140.018 E.01972
G1 X130.871 Y140.497 E.02175
G1 X130.414 Y140.74 E.01259
G1 X129.674 Y141.071 E.01972
G1 X128.828 Y141.361 E.02175
G1 X128.327 Y141.49 E.01258
G1 X127.536 Y141.639 E.01958
G1 X126.18 Y141.735 E.03307
G1 X120.958 Y141.735 E.12702
G1 X120.901 Y141.645 E.00259
G1 X120.667 Y141.593 E.00583
G1 X110.333 Y141.593 E.25136
G1 X110.1 Y141.645 E.00581
G1 X110.043 Y141.734 E.00257
G1 X104.361 Y141.724 E.13821
G1 X103.101 Y141.578 E.03085
G1 X102.601 Y141.474 E.01242
G1 X101.742 Y141.225 E.02175
G1 X100.988 Y140.929 E.0197
G1 X100.525 Y140.71 E.01246
G1 X99.373 Y140.017 E.0327
G1 X98.393 Y139.224 E.03066
G1 X98.031 Y138.873 E.01226
G1 X97.166 Y137.843 E.03272
G1 X96.495 Y136.776 E.03066
G1 X96.267 Y136.326 E.01227
G1 X95.782 Y135.071 E.03273
G1 X95.495 Y133.85 E.03051
G1 X95.386 Y132.927 E.02261
G1 X95.386 Y127.642 E.12855
G1 X95.365 Y127.574 E.00173
G1 X95.365 Y95.472 E.78085
G1 X95.322 Y95.261 E.00524
G1 X95.145 Y95.033 E.00702
G1 X94.816 Y94.923 E.00844
G1 X92.162 Y94.923 E.06456
G1 X92.14 Y94.855 E.00174
G1 X92.125 Y94.145 E.01727
G1 X92.175 Y93.905 E.00596
G1 X104.634 Y93.907 E.30305
G1 X104.634 Y93.907 F9000
G1 X104.073 Y94.272
G1 F6000
G1 X104.269 Y94.272 E.00477
G1 X104.269 Y98.114 E.09345
G1 X104.149 Y98.205 E.00366
G1 X104.113 Y98.457 E.00619
G1 X104.113 Y103.792 E.12977
G1 X104.141 Y104.014 E.00544
G1 X104.269 Y104.114 E.00395
G1 X104.269 Y136.13 E.77876
G1 X104.011 Y136.484 E.01065
G1 X103.802 Y136.932 E.01202
G1 X103.713 Y137.376 E.01101
G1 X103.745 Y137.853 E.01163
G1 X103.945 Y138.412 E.01444
G1 X104.269 Y138.87 E.01365
G1 X104.269 Y139.307 E.01063
G1 X104.346 Y139.684 E.00936
G1 X104.741 Y140.117 E.01426
G1 X105.181 Y140.231 E.01106
G1 X125.817 Y140.231 E.50195
G1 X125.975 Y140.218 E.00386
G1 X126.352 Y140.058 E.00996
G1 X126.581 Y139.82 E.00803
G1 X126.703 Y139.542 E.00738
G1 X126.728 Y139.393 E.00367
G1 X126.731 Y138.87 E.01272
G1 X126.989 Y138.516 E.01065
G1 X127.198 Y138.068 E.01202
G1 X127.287 Y137.624 E.01101
G1 X127.254 Y137.139 E.01182
G1 X127.082 Y136.642 E.01279
G1 X126.731 Y136.13 E.0151
G1 X126.731 Y104.114 E.77876
G1 X126.859 Y104.014 E.00395
G1 X126.887 Y103.792 E.00544
G1 X126.887 Y98.462 E.12965
G1 X126.851 Y98.205 E.00631
G1 X126.731 Y98.114 E.00366
G1 X126.731 Y94.271 E.09348
G1 X135.478 Y94.271 E.21276
G1 X136.183 Y94.251 E.01716
;WIDTH:0.360531
G1 X138.527 Y94.251 E.05086
;WIDTH:0.360458
G1 X138.528 Y94.577 E.00707
G1 X136.183 Y94.577 E.05087
;WIDTH:0.368544
G1 X136.028 Y94.587 E.00345
;WIDTH:0.399999
G1 X135.635 Y94.741 E.01027
G1 X135.339 Y95.12 E.0117
G1 X135.269 Y95.472 E.00873
G1 X135.269 Y127.168 E.77097
G1 X135.247 Y127.642 E.01154
G1 X135.247 Y132.905 E.12802
G1 X135.142 Y133.798 E.02187
G1 X134.983 Y134.552 E.01874
G1 X134.776 Y135.228 E.0172
G1 X134.55 Y135.835 E.01575
G1 X134.215 Y136.541 E.01901
G1 X133.849 Y137.16 E.01749
G1 X133.494 Y137.687 E.01546
G1 X133.003 Y138.295 E.01901
G1 X132.484 Y138.831 E.01815
G1 X132.035 Y139.241 E.01479
G1 X131.416 Y139.718 E.01901
G1 X130.762 Y140.133 E.01884
G1 X130.253 Y140.411 E.01411
G1 X129.54 Y140.731 E.01901
G1 X128.78 Y140.991 E.01954
G1 X128.247 Y141.133 E.01342
G1 X127.489 Y141.275 E.01876
G1 X126.167 Y141.369 E.03224
G1 X121.091 Y141.369 E.12347
G1 X121.057 Y141.315 E.00155
G1 X120.667 Y141.227 E.00972
G1 X110.333 Y141.227 E.25136
G1 X109.945 Y141.314 E.00967
G1 X109.91 Y141.368 E.00157
G1 X104.382 Y141.358 E.13446
G1 X103.209 Y141.223 E.02872
G1 X102.689 Y141.119 E.0129
G1 X101.86 Y140.879 E.02099
G1 X101.195 Y140.617 E.01739
G1 X100.698 Y140.388 E.01331
G1 X99.584 Y139.716 E.03165
G1 X98.746 Y139.04 E.02619
G1 X98.3 Y138.623 E.01485
G1 X97.462 Y137.627 E.03166
G1 X96.912 Y136.751 E.02516
G1 X96.602 Y136.177 E.01587
G1 X96.132 Y134.963 E.03167
G1 X95.855 Y133.787 E.02939
G1 X95.752 Y132.905 E.0216
G1 X95.752 Y127.642 E.12802
G1 X95.73 Y127.542 E.00249
G1 X95.73 Y95.472 E.78007
G1 X95.66 Y95.12 E.00873
G1 X95.365 Y94.741 E.01168
G1 X94.816 Y94.577 E.01394
;WIDTH:0.360424
G1 X92.48 Y94.577 E.05067
G1 X92.474 Y94.251 E.00707
G1 X94.816 Y94.251 E.0508
;WIDTH:0.399999
G1 X95.521 Y94.271 E.01716
G1 X104.013 Y94.272 E.20656
G1 X104.013 Y94.272 F9000
G1 X103.58 Y94.638
G1 F6000
G1 X103.903 Y94.638 E.00786
G1 X103.903 Y98.024 E.08236
G1 X103.797 Y98.104 E.00323
G1 X103.748 Y98.457 E.00867
G1 X103.748 Y103.792 E.12977
G1 X103.786 Y104.103 E.00762
G1 X103.903 Y104.194 E.00361
G1 X103.903 Y136.011 E.77392
G1 X103.586 Y136.49 E.01397
G1 X103.397 Y137.015 E.01357
G1 X103.34 Y137.524 E.01246
G1 X103.413 Y138.056 E.01306
G1 X103.624 Y138.586 E.01388
G1 X103.903 Y138.989 E.01192
G1 X103.904 Y139.359 E.009
G1 X104.011 Y139.831 E.01177
G1 X104.564 Y140.437 E.01996
;WIDTH:0.415519
G1 X105.183 Y140.605 E.01626
;WIDTH:0.419686
G1 X109.703 Y140.607 E.11586
G1 X110.018 Y140.589 E.00809
;WIDTH:0.384601
G1 X110.333 Y140.572 E.00735
;WIDTH:0.349516
G1 X120.667 Y140.572 E.21666
;WIDTH:0.3849
G1 X120.983 Y140.589 E.00738
;WIDTH:0.420284
G1 X121.299 Y140.607 E.00813
G1 X125.817 Y140.607 E.11599
;WIDTH:0.42588
G1 X126.101 Y140.578 E.00744
G1 X126.567 Y140.355 E.01346
;WIDTH:0.399999
G1 X126.886 Y140.021 E.01123
G1 X127.058 Y139.632 E.01035
G1 X127.097 Y138.989 E.01567
G1 X127.439 Y138.452 E.01549
G1 X127.59 Y138.046 E.01054
G1 X127.66 Y137.526 E.01276
G1 X127.616 Y137.087 E.01073
G1 X127.414 Y136.49 E.01533
G1 X127.097 Y136.011 E.01397
G1 X127.097 Y104.194 E.77392
G1 X127.214 Y104.103 E.00361
G1 X127.252 Y103.792 E.00762
G1 X127.252 Y98.462 E.12965
G1 X127.203 Y98.104 E.00879
G1 X127.097 Y98.024 E.00323
G1 X127.097 Y94.637 E.08239
G1 X135.269 Y94.637 E.19878
G1 X135.002 Y94.98 E.01057
G1 X134.903 Y95.472 E.01221
G1 X134.903 Y127.168 E.77097
G1 X134.881 Y127.642 E.01154
G1 X134.881 Y132.884 E.12751
G1 X134.781 Y133.739 E.02094
G1 X134.629 Y134.461 E.01795
G1 X134.426 Y135.121 E.0168
G1 X134.214 Y135.689 E.01475
G1 X133.892 Y136.369 E.0183
G1 X133.534 Y136.974 E.0171
G1 X133.201 Y137.467 E.01447
G1 X132.729 Y138.053 E.0183
G1 X132.222 Y138.576 E.01772
G1 X131.802 Y138.959 E.01383
G1 X131.206 Y139.418 E.0183
G1 X130.566 Y139.824 E.01844
G1 X130.092 Y140.082 E.01313
G1 X129.405 Y140.39 E.01831
G1 X128.662 Y140.645 E.01911
G1 X128.168 Y140.776 E.01243
G1 X127.443 Y140.912 E.01794
G1 X126.786 Y140.959 E.01602
;WIDTH:0.420285
G1 X125.817 Y140.993 E.02489
G1 X121.299 Y140.993 E.11599
G1 X120.942 Y140.931 E.0093
;WIDTH:0.3849
G1 X120.667 Y140.887 E.00649
;WIDTH:0.349516
G1 X110.333 Y140.887 E.21666
;WIDTH:0.384601
G1 X110.018 Y140.94 E.00744
;WIDTH:0.419686
G1 X109.703 Y140.992 E.00818
G1 X105.182 Y140.986 E.11589
;WIDTH:0.415519
G1 X104.403 Y140.992 E.01975
;WIDTH:0.399999
G1 X103.251 Y140.86 E.0282
G1 X102.777 Y140.764 E.01176
G1 X101.979 Y140.532 E.02021
G1 X101.329 Y140.277 E.01698
G1 X100.871 Y140.065 E.01228
G1 X99.794 Y139.416 E.03059
G1 X98.976 Y138.755 E.02558
G1 X98.568 Y138.374 E.01358
G1 X97.758 Y137.411 E.03061
G1 X97.221 Y136.557 E.02454
G1 X96.936 Y136.028 E.01462
G1 X96.483 Y134.854 E.03061
G1 X96.216 Y133.724 E.02824
G1 X96.118 Y132.884 E.02057
G1 X96.118 Y127.642 E.12751
G1 X96.096 Y127.51 E.00326
G1 X96.096 Y95.472 E.77929
G1 X95.998 Y94.98 E.0122
G1 X95.731 Y94.637 E.01057
G1 X103.52 Y94.638 E.18946
G1 X103.52 Y94.638 F9000
G1 X103.537 Y95.004
G1 F6000
G1 X103.537 Y97.934 E.07127
G1 X103.446 Y98.003 E.00278
G1 X103.382 Y98.457 E.01115
G1 X103.382 Y103.792 E.12977
G1 X103.431 Y104.192 E.0098
G1 X103.537 Y104.274 E.00326
G1 X103.537 Y135.892 E.76908
G1 X103.221 Y136.412 E.0148
G1 X103.026 Y137.009 E.01528
G1 X102.974 Y137.531 E.01276
G1 X103.059 Y138.149 E.01517
G1 X103.302 Y138.76 E.01599
G1 X103.537 Y139.108 E.01021
G1 X103.582 Y139.699 E.01442
G1 X103.676 Y139.978 E.00716
G1 X104.249 Y140.606 E.02068
G1 X103.292 Y140.496 E.02343
G1 X102.866 Y140.409 E.01058
G1 X102.097 Y140.186 E.01948
G1 X101.514 Y139.957 E.01524
G1 X101.044 Y139.742 E.01257
G1 X100.004 Y139.116 E.02953
G1 X99.206 Y138.471 E.02496
G1 X98.836 Y138.125 E.01232
G1 X98.055 Y137.195 E.02954
G1 X97.531 Y136.362 E.02394
G1 X97.271 Y135.879 E.01334
G1 X96.833 Y134.746 E.02955
G1 X96.577 Y133.66 E.02714
G1 X96.483 Y132.863 E.01952
G1 X96.483 Y127.642 E.127
G1 X96.462 Y127.478 E.00402
G1 X96.462 Y95.472 E.77851
G1 X96.368 Y95.003 E.01163
G1 X103.477 Y95.004 E.17292
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.537 Y95.004 E-.0285
G1 X103.537 Y97.934 E-1.39175
G1 X103.446 Y98.003 E-.05425
G1 X103.438 Y98.056 E-.0255
;WIPE_END
G1 X127.463 Y95.002 F9000
G1 E5 F2400
G1 F6000
G1 X134.632 Y95.002 E.17438
G1 X134.538 Y95.472 E.01166
G1 X134.537 Y127.168 E.77097
G1 X134.516 Y127.642 E.01154
G1 X134.516 Y132.863 E.127
G1 X134.42 Y133.68 E.02001
G1 X134.275 Y134.369 E.01713
G1 X134.077 Y135.013 E.01639
G1 X133.879 Y135.544 E.01378
G1 X133.568 Y136.197 E.01759
G1 X133.22 Y136.787 E.01666
G1 X132.909 Y137.247 E.01351
G1 X132.455 Y137.81 E.01759
G1 X131.959 Y138.322 E.01734
G1 X131.569 Y138.676 E.01281
G1 X130.996 Y139.118 E.0176
G1 X130.393 Y139.5 E.01736
G1 X129.931 Y139.753 E.01281
G1 X129.271 Y140.05 E.0176
G1 X128.66 Y140.259 E.01571
G1 X128.088 Y140.418 E.01444
G1 X127.396 Y140.549 E.01713
G1 X126.841 Y140.588 E.01353
G1 X127.192 Y140.222 E.01233
G1 X127.412 Y139.722 E.01329
G1 X127.463 Y139.108 E.01499
G1 X127.779 Y138.588 E.0148
G1 X127.944 Y138.136 E.0117
G1 X128.011 Y137.722 E.0102
G1 X128.012 Y137.282 E.0107
G1 X127.927 Y136.804 E.01181
G1 X127.747 Y136.338 E.01215
G1 X127.463 Y135.892 E.01286
G1 X127.463 Y104.274 E.76908
G1 X127.569 Y104.192 E.00326
G1 X127.618 Y103.792 E.0098
G1 X127.618 Y98.462 E.12965
G1 X127.554 Y98.003 E.01127
G1 X127.463 Y97.934 E.00278
G1 X127.463 Y95.062 E.06986
G1 E-5 F3600
G1 X127.463 Y95.062 F9000
G1 X127.733 Y139.195
G1 E5 F2400
;TYPE:Solid infill
G1 F1200
G1 X128.037 Y138.681 E.01453
G1 X128.213 Y138.184 E.01282
G1 X128.298 Y137.509 E.01655
G1 X128.199 Y136.777 E.01797
G1 X130.518 Y139.096 E.07977
G1 X130.184 Y139.309 E.00964
G1 X129.168 Y139.795 E.0274
G1 X128.439 Y140.045 E.01875
G1 X127.481 Y140.24 E.02378
G1 X127.683 Y139.757 E.01273
G1 X127.717 Y139.377 E.00928
G1 X128.084 Y139.373 E.00893
G1 X128.336 Y138.899 E.01306
G1 X128.547 Y138.347 E.01437
G1 X128.643 Y137.738 E.015
G1 X129.929 Y139.025 E.04425
G1 X128.84 Y139.521 E.02911
G1 X128.051 Y139.75 E.01998
G1 X128.068 Y139.555 E.00476
G1 X128.585 Y139.212 E.01509
;WIDTH:0.41782
G1 X128.657 Y139.091 E.00359
G1 X128.886 Y138.511 E.01591
G1 X129.29 Y138.916 E.01459
G1 X128.754 Y139.141 E.01483
G1 E-5 F3600
G1 X128.754 Y139.141 F9000
G1 X130.834 Y138.896
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X127.737 Y135.798 E.10655
G1 X127.737 Y135.281 E.01258
G1 X131.127 Y138.671 E.11661
G1 X131.417 Y138.444 E.00896
G1 X127.737 Y134.764 E.12659
G1 X127.737 Y134.247 E.01258
G1 X131.692 Y138.201 E.13603
G1 X131.947 Y137.94 E.00888
G1 X127.737 Y133.73 E.14482
G1 X127.737 Y133.212 E.0126
G1 X132.202 Y137.677 E.15359
G1 X132.437 Y137.395 E.00893
G1 X127.737 Y132.695 E.16168
G1 X127.737 Y132.178 E.01258
G1 X132.668 Y137.109 E.16962
G1 X132.882 Y136.807 E.009
G1 X127.737 Y131.661 E.177
G1 X127.737 Y131.144 E.01258
G1 X133.079 Y136.486 E.18376
G1 X133.271 Y136.161 E.00918
G1 X127.737 Y130.627 E.19037
G1 X127.737 Y130.11 E.01258
G1 X133.445 Y135.818 E.19635
G1 X133.611 Y135.467 E.00944
G1 X127.737 Y129.593 E.20206
G1 X127.737 Y129.075 E.0126
G1 X133.759 Y135.098 E.20717
G1 X133.884 Y134.706 E.01001
G1 X127.737 Y128.558 E.21147
G1 X127.737 Y128.041 E.01258
G1 X134.006 Y134.31 E.21565
G1 X134.097 Y133.884 E.0106
G1 X127.737 Y127.524 E.21878
G1 X127.737 Y127.007 E.01258
G1 X134.172 Y133.442 E.22136
G1 X134.226 Y132.979 E.01134
G1 X127.737 Y126.49 E.22322
G1 X127.737 Y125.973 E.01258
G1 X134.241 Y132.477 E.22373
G1 X134.241 Y131.96 E.01258
G1 X127.737 Y125.456 E.22373
G1 X127.737 Y124.938 E.0126
G1 X134.241 Y131.443 E.22375
G1 X134.241 Y130.926 E.01258
G1 X127.737 Y124.421 E.22375
G1 X127.737 Y123.904 E.01258
G1 X134.241 Y130.409 E.22375
G1 X134.241 Y129.892 E.01258
G1 X127.737 Y123.387 E.22375
G1 X127.737 Y122.87 E.01258
G1 X134.241 Y129.374 E.22373
G1 X134.241 Y128.857 E.01258
G1 X127.737 Y122.353 E.22373
G1 X127.737 Y121.836 E.01258
G1 X134.241 Y128.34 E.22373
G1 X134.241 Y127.823 E.01258
G1 X127.737 Y121.319 E.22373
G1 X127.737 Y120.801 E.0126
G1 X134.263 Y127.328 E.22451
G1 X134.263 Y126.811 E.01258
G1 X127.737 Y120.284 E.22451
G1 X127.737 Y119.767 E.01258
G1 X134.263 Y126.293 E.22449
G1 X134.263 Y125.776 E.01258
G1 X127.737 Y119.25 E.22449
G1 X127.737 Y118.733 E.01258
G1 X134.263 Y125.259 E.22449
G1 X134.263 Y124.742 E.01258
G1 X127.737 Y118.216 E.22449
G1 X127.737 Y117.699 E.01258
G1 X134.263 Y124.225 E.22449
G1 X134.263 Y123.708 E.01258
G1 X127.737 Y117.182 E.22449
G1 X127.737 Y116.664 E.0126
G1 X134.263 Y123.191 E.22451
G1 X134.263 Y122.674 E.01258
G1 X127.737 Y116.147 E.22451
G1 X127.737 Y115.63 E.01258
G1 X134.263 Y122.157 E.22451
G1 X134.263 Y121.639 E.0126
G1 X127.737 Y115.113 E.22449
G1 X127.737 Y114.596 E.01258
G1 X134.263 Y121.122 E.22449
G1 X134.263 Y120.605 E.01258
G1 X127.737 Y114.079 E.22449
G1 X127.737 Y113.562 E.01258
G1 X134.263 Y120.088 E.22449
G1 X134.263 Y119.571 E.01258
G1 X127.737 Y113.045 E.22449
G1 X127.737 Y112.527 E.0126
G1 X134.263 Y119.054 E.22451
G1 X134.263 Y118.537 E.01258
G1 X127.737 Y112.01 E.22451
G1 X127.737 Y111.493 E.01258
G1 X134.263 Y118.02 E.22451
G1 X134.263 Y117.502 E.0126
G1 X127.737 Y110.976 E.22449
G1 X127.737 Y110.459 E.01258
G1 X134.263 Y116.985 E.22449
G1 X134.263 Y116.468 E.01258
G1 X127.737 Y109.942 E.22449
G1 X127.737 Y109.425 E.01258
G1 X134.263 Y115.951 E.22449
G1 X134.263 Y115.434 E.01258
G1 X127.737 Y108.908 E.22449
G1 X127.737 Y108.39 E.0126
G1 X134.263 Y114.917 E.22451
G1 X134.263 Y114.4 E.01258
G1 X127.737 Y107.873 E.22451
G1 X127.737 Y107.356 E.01258
G1 X134.263 Y113.883 E.22451
G1 X134.263 Y113.365 E.0126
G1 X127.737 Y106.839 E.22449
G1 X127.737 Y106.322 E.01258
G1 X134.263 Y112.848 E.22449
G1 X134.263 Y112.331 E.01258
G1 X127.737 Y105.805 E.22449
G1 X127.737 Y105.288 E.01258
G1 X134.263 Y111.814 E.22449
G1 X134.263 Y111.297 E.01258
G1 X127.737 Y104.771 E.22449
G1 X127.796 Y104.313 E.01123
G1 X134.263 Y110.78 E.22246
G1 X134.263 Y110.263 E.01258
G1 X127.887 Y103.886 E.21935
G1 X127.892 Y103.375 E.01243
G1 X134.263 Y109.746 E.21916
G1 X134.263 Y109.229 E.01258
G1 X127.892 Y102.858 E.21916
G1 X127.892 Y102.34 E.0126
G1 X134.263 Y108.711 E.21916
G1 X134.263 Y108.194 E.01258
G1 X127.892 Y101.823 E.21916
G1 X127.892 Y101.306 E.01258
G1 X134.263 Y107.677 E.21916
G1 X134.263 Y107.16 E.01258
G1 X127.892 Y100.789 E.21916
G1 X127.892 Y100.272 E.01258
G1 X134.263 Y106.643 E.21916
G1 X134.263 Y106.126 E.01258
G1 X127.892 Y99.755 E.21916
G1 X127.892 Y99.238 E.01258
G1 X134.263 Y105.609 E.21916
G1 X134.263 Y105.092 E.01258
G1 X127.892 Y98.721 E.21916
G1 X127.871 Y98.182 E.01312
G1 X134.263 Y104.574 E.21988
G1 X134.263 Y104.057 E.01258
G1 X127.737 Y97.531 E.22449
G1 X127.661 Y97.866 E.00836
;WIDTH:0.374336
G1 X127.672 Y97.907 E.00096
G1 X127.601 Y97.926 E.00166
G1 X127.62 Y97.855 E.00166
G1 X127.62 Y97.855 F9000
G1 X127.737 Y97.014
;WIDTH:0.399999
G1 F1200
G1 X134.263 Y103.54 E.22449
G1 X134.263 Y103.023 E.01258
G1 X127.737 Y96.497 E.22449
G1 X127.737 Y95.979 E.0126
G1 X134.263 Y102.506 E.22451
G1 X134.263 Y101.989 E.01258
G1 X127.737 Y95.462 E.22451
G1 X128.068 Y95.277 E.00922
G1 X134.263 Y101.472 E.2131
G1 X134.263 Y100.955 E.01258
G1 X128.585 Y95.277 E.19532
G1 X129.102 Y95.277 E.01258
G1 X134.263 Y100.438 E.17753
G1 X134.263 Y99.92 E.0126
G1 X129.62 Y95.277 E.15972
G1 X130.137 Y95.277 E.01258
G1 X134.263 Y99.403 E.14193
G1 X134.264 Y98.886 E.01258
G1 X130.654 Y95.277 E.12416
G1 X131.171 Y95.277 E.01258
G1 X134.264 Y98.369 E.10638
G1 X134.264 Y97.852 E.01258
G1 X131.688 Y95.277 E.0886
G1 X132.205 Y95.277 E.01258
G1 X134.264 Y97.335 E.07081
G1 X134.264 Y96.818 E.01258
G1 X132.722 Y95.277 E.05303
G1 X133.239 Y95.277 E.01258
G1 X134.264 Y96.301 E.03524
G1 X134.264 Y95.783 E.0126
G1 X133.757 Y95.277 E.01742
G1 X133.646 Y95.09 E.00529
;WIDTH:0.374336
G1 X133.657 Y95.131 E.00096
G1 X133.586 Y95.15 E.00166
G1 X133.605 Y95.079 E.00166
;WIDTH:0.399999
G1 X134.279 Y95.238 E.01684
;WIDTH:0.414892
G1 X134.258 Y95.318 E.00209
G1 X134.338 Y95.296 E.0021
G1 X134.325 Y95.25 E.00121
G1 E-5 F3600
G1 X134.325 Y95.25 F9000
G1 X126.901 Y137.685
G1 X126.864 Y137.867
G1 X126.349 Y139.849
G1 X104.651 Y139.849
G1 X97.867 Y136.426
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X97.848 Y136.498 E.00168
G1 X97.919 Y136.478 E.00167
G1 X97.908 Y136.437 E.00096
;WIDTH:0.399999
G1 X98.084 Y136.726 E.00823
G1 X100.38 Y139.022 E.07898
G1 X100.668 Y139.194 E.00816
;WIDTH:0.374336
G1 X100.679 Y139.235 E.00096
G1 X100.608 Y139.254 E.00166
G1 X100.627 Y139.183 E.00166
G1 X100.627 Y139.183 F9000
G1 X101.799 Y139.805
G1 F1200
G1 X101.78 Y139.876 E.00166
G1 X101.852 Y139.857 E.00168
G1 X101.841 Y139.816 E.00096
;WIDTH:0.399999
G1 X101.552 Y139.677 E.0078
G1 X97.446 Y135.571 E.14124
G1 X97.446 Y135.571 F9000
G1 X97.12 Y134.728
G1 F1200
G1 X102.372 Y139.98 E.18067
G1 X102.658 Y140.103 E.00757
;WIDTH:0.374336
G1 X102.669 Y140.144 E.00096
G1 X102.598 Y140.163 E.00166
G1 X102.617 Y140.092 E.00166
;WIDTH:0.399999
G1 X103.083 Y140.174 E.01151
G1 X96.948 Y134.039 E.21104
G1 X96.822 Y133.396 E.01594
G1 X103.379 Y139.953 E.22556
G1 X103.565 Y140.213 E.00778
;WIDTH:0.392992
G1 X103.545 Y140.288 E.00185
G1 X103.62 Y140.268 E.00185
G1 X103.608 Y140.225 E.00107
G1 X103.608 Y140.225 F9000
G1 X103.264 Y139.32
;WIDTH:0.399999
G1 F1200
G1 X96.758 Y132.814 E.2238
G1 X96.758 Y132.297 E.01258
G1 X102.849 Y138.389 E.20954
G1 X103.011 Y138.606 E.00659
;WIDTH:0.374336
G1 X102.992 Y138.677 E.00166
G1 X103.063 Y138.658 E.00166
G1 X103.052 Y138.617 E.00096
G1 X103.052 Y138.617 F9000
G1 X102.722 Y137.744
;WIDTH:0.399999
G1 F1200
G1 X96.758 Y131.78 E.20516
G1 X96.758 Y131.263 E.01258
G1 X102.729 Y137.234 E.2054
G1 X102.803 Y136.791 E.01092
G1 X96.758 Y130.746 E.20794
G1 X96.758 Y130.229 E.01258
G1 X102.931 Y136.402 E.21235
G1 X103.105 Y136.059 E.00936
G1 X96.758 Y129.712 E.21833
G1 X96.758 Y129.194 E.0126
G1 X103.263 Y135.7 E.22378
G1 X103.263 Y135.183 E.01258
G1 X96.758 Y128.677 E.22378
G1 X96.758 Y128.16 E.01258
G1 X103.263 Y134.666 E.22378
G1 X103.263 Y134.148 E.0126
G1 X96.758 Y127.643 E.22377
G1 X96.736 Y127.104 E.01312
G1 X103.263 Y133.631 E.22452
G1 X103.263 Y133.114 E.01258
G1 X96.736 Y126.587 E.22452
G1 X96.736 Y126.07 E.01258
G1 X103.263 Y132.597 E.22452
G1 X103.263 Y132.08 E.01258
G1 X96.736 Y125.553 E.22452
G1 X96.736 Y125.036 E.01258
G1 X103.263 Y131.563 E.22452
G1 X103.263 Y131.046 E.01258
G1 X96.736 Y124.519 E.22452
G1 X96.736 Y124.001 E.0126
G1 X103.263 Y130.529 E.22454
G1 X103.263 Y130.011 E.0126
G1 X96.736 Y123.484 E.22452
G1 X96.736 Y122.967 E.01258
G1 X103.263 Y129.494 E.22452
G1 X103.263 Y128.977 E.01258
G1 X96.736 Y122.45 E.22452
G1 X96.736 Y121.933 E.01258
G1 X103.263 Y128.46 E.22452
G1 X103.263 Y127.943 E.01258
G1 X96.736 Y121.416 E.22452
G1 X96.736 Y120.899 E.01258
G1 X103.263 Y127.426 E.22452
G1 X103.263 Y126.909 E.01258
G1 X96.736 Y120.381 E.22454
G1 X96.736 Y119.864 E.01258
G1 X103.263 Y126.392 E.22454
G1 X103.263 Y125.874 E.0126
G1 X96.736 Y119.347 E.22452
G1 X96.736 Y118.83 E.01258
G1 X103.263 Y125.357 E.22452
G1 X103.263 Y124.84 E.01258
G1 X96.736 Y118.313 E.22452
G1 X96.736 Y117.796 E.01258
G1 X103.263 Y124.323 E.22452
G1 X103.263 Y123.806 E.01258
G1 X96.736 Y117.279 E.22452
G1 X96.736 Y116.762 E.01258
G1 X103.263 Y123.289 E.22452
G1 X103.263 Y122.772 E.01258
G1 X96.736 Y116.244 E.22454
G1 X96.736 Y115.727 E.01258
G1 X103.263 Y122.255 E.22454
G1 X103.263 Y121.737 E.0126
G1 X96.736 Y115.21 E.22452
G1 X96.736 Y114.693 E.01258
G1 X103.263 Y121.22 E.22452
G1 X103.263 Y120.703 E.01258
G1 X96.736 Y114.176 E.22452
G1 X96.736 Y113.659 E.01258
G1 X103.263 Y120.186 E.22452
G1 X103.263 Y119.669 E.01258
G1 X96.736 Y113.142 E.22452
G1 X96.736 Y112.625 E.01258
G1 X103.263 Y119.152 E.22452
G1 X103.263 Y118.635 E.01258
G1 X96.736 Y112.107 E.22454
G1 X96.736 Y111.59 E.01258
G1 X103.263 Y118.118 E.22454
G1 X103.263 Y117.6 E.0126
G1 X96.736 Y111.073 E.22452
G1 X96.736 Y110.556 E.01258
G1 X103.263 Y117.083 E.22452
G1 X103.263 Y116.566 E.01258
G1 X96.736 Y110.039 E.22452
G1 X96.736 Y109.522 E.01258
G1 X103.263 Y116.049 E.22452
G1 X103.263 Y115.532 E.01258
G1 X96.736 Y109.005 E.22452
G1 X96.736 Y108.488 E.01258
G1 X103.263 Y115.015 E.22452
G1 X103.263 Y114.498 E.01258
G1 X96.736 Y107.97 E.22454
G1 X96.736 Y107.453 E.01258
G1 X103.263 Y113.981 E.22454
G1 X103.263 Y113.463 E.0126
G1 X96.736 Y106.936 E.22452
G1 X96.736 Y106.419 E.01258
G1 X103.263 Y112.946 E.22452
G1 X103.263 Y112.429 E.01258
G1 X96.736 Y105.902 E.22452
G1 X96.736 Y105.385 E.01258
G1 X103.263 Y111.912 E.22452
G1 X103.263 Y111.395 E.01258
G1 X96.736 Y104.868 E.22452
G1 X96.736 Y104.351 E.01258
G1 X103.263 Y110.878 E.22452
G1 X103.263 Y110.361 E.01258
G1 X96.736 Y103.833 E.22454
G1 X96.736 Y103.316 E.01258
G1 X103.263 Y109.844 E.22454
G1 X103.263 Y109.326 E.0126
G1 X96.736 Y102.799 E.22452
G1 X96.736 Y102.282 E.01258
G1 X103.263 Y108.809 E.22452
G1 X103.263 Y108.292 E.01258
G1 X96.736 Y101.765 E.22452
G1 X96.736 Y101.248 E.01258
G1 X103.263 Y107.775 E.22452
G1 X103.263 Y107.258 E.01258
G1 X96.736 Y100.731 E.22452
G1 X96.736 Y100.214 E.01258
G1 X103.263 Y106.741 E.22452
G1 X103.263 Y106.224 E.01258
G1 X96.736 Y99.696 E.22454
G1 X96.736 Y99.179 E.01258
G1 X103.263 Y105.707 E.22454
G1 X103.263 Y105.189 E.0126
G1 X96.736 Y98.662 E.22452
G1 X96.736 Y98.145 E.01258
G1 X103.263 Y104.672 E.22452
G1 X103.397 Y104.278 E.01012
;WIDTH:0.374336
G1 X103.408 Y104.319 E.00096
G1 X103.337 Y104.339 E.00167
G1 X103.356 Y104.267 E.00168
;WIDTH:0.399999
G1 X103.121 Y104.013 E.00842
G1 X96.736 Y97.628 E.21964
G1 X96.736 Y97.111 E.01258
G1 X103.108 Y103.483 E.21919
G1 X103.108 Y102.965 E.0126
G1 X96.736 Y96.594 E.21918
G1 X96.736 Y96.077 E.01258
G1 X103.108 Y102.448 E.21918
G1 X103.108 Y101.931 E.01258
G1 X96.736 Y95.559 E.21919
G1 X96.614 Y95.176 E.00978
;WIDTH:0.374336
G1 X96.595 Y95.247 E.00166
G1 X96.666 Y95.228 E.00166
G1 X96.655 Y95.187 E.00096
;WIDTH:0.399999
G1 X96.971 Y95.277 E.00799
G1 X103.108 Y101.414 E.21111
G1 X103.108 Y100.897 E.01258
G1 X97.488 Y95.277 E.19332
G1 X98.005 Y95.277 E.01258
G1 X103.108 Y100.38 E.17554
G1 X103.108 Y99.863 E.01258
G1 X98.522 Y95.277 E.15776
G1 X99.039 Y95.277 E.01258
G1 X103.108 Y99.346 E.13997
G1 X103.108 Y98.828 E.0126
G1 X99.557 Y95.277 E.12215
G1 X100.074 Y95.277 E.01258
G1 X103.116 Y98.32 E.10466
G1 X103.202 Y97.889 E.01069
G1 X100.591 Y95.278 E.08982
G1 X101.108 Y95.278 E.01258
G1 X103.263 Y97.433 E.07413
G1 X103.263 Y96.915 E.0126
G1 X101.625 Y95.278 E.05633
G1 X102.143 Y95.278 E.0126
G1 X103.263 Y96.398 E.03853
G1 X103.263 Y95.881 E.01258
G1 X102.66 Y95.278 E.02074
G1 X102.549 Y95.092 E.00527
;WIDTH:0.374336
G1 X102.56 Y95.133 E.00096
G1 X102.489 Y95.152 E.00166
G1 X102.508 Y95.081 E.00166
G1 X102.508 Y95.081 F9000
G1 X103.224 Y95.253
;WIDTH:0.45048
G1 F1200
G1 X103.188 Y95.29 E.00143
G1 X103.201 Y95.34 E.00143
G1 X103.251 Y95.353 E.00143
G1 X103.288 Y95.317 E.00143
G1 X103.275 Y95.266 E.00146
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.288 Y95.317 E-.025
G1 X103.251 Y95.353 E-.02452
G1 X103.201 Y95.34 E-.02454
G1 X103.188 Y95.29 E-.02454
G1 X103.224 Y95.253 E-.02452
;WIPE_END
G1 E-1.37688 F3600
G1 X104.651 Y97.371 F9000
G1 X105.866 Y99.173
G1 X112.136 Y108.459
G1 X112.34 Y108.779
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X112.549 Y108.624 E.00633
G1 X113.044 Y108.43 E.01293
G1 X113.768 Y108.329 E.01778
G1 X117.467 Y108.34 E.08997
G1 X117.983 Y108.438 E.01278
G1 X118.449 Y108.622 E.01219
G1 X119.059 Y109.054 E.01818
G1 X119.418 Y109.466 E.01329
G1 X121.277 Y112.664 E.08998
G1 X121.551 Y113.339 E.01772
G1 X121.632 Y114.089 E.01835
G1 X121.562 Y114.618 E.01298
G1 X121.385 Y115.127 E.01311
G1 X119.419 Y118.533 E.09566
G1 X118.909 Y119.077 E.01814
G1 X118.482 Y119.36 E.01246
G1 X117.783 Y119.609 E.01805
G1 X117.25 Y119.671 E.01305
G1 X113.767 Y119.671 E.08472
G1 X113.228 Y119.615 E.01318
G1 X112.759 Y119.472 E.01193
G1 X112.132 Y119.11 E.01761
G1 X111.581 Y118.534 E.01939
G1 X109.723 Y115.336 E.08996
G1 X109.449 Y114.66 E.01774
G1 X109.369 Y114.132 E.01299
G1 X109.391 Y113.629 E.01225
G1 X109.508 Y113.139 E.01225
G1 X109.714 Y112.68 E.01224
G1 X111.455 Y109.664 E.08471
G1 X111.882 Y109.116 E.0169
G1 X112.291 Y108.814 E.01237
G1 X112.291 Y108.814 F9000
G1 X112.074 Y108.511
;TYPE:Perimeter
G1 F6000
G1 X112.101 Y108.489 E.00085
G1 X112.413 Y108.285 E.00907
G1 X112.987 Y108.069 E.01492
G1 X113.769 Y107.963 E.0192
G1 X117.468 Y107.974 E.08997
G1 X118.029 Y108.074 E.01386
G1 X118.505 Y108.25 E.01234
G1 X119.007 Y108.568 E.01445
G1 X119.369 Y108.844 E.01107
G1 X119.734 Y109.282 E.01387
G1 X121.594 Y112.48 E.08999
G1 X121.89 Y113.203 E.019
G1 X121.996 Y114.053 E.02084
G1 X121.924 Y114.67 E.01511
G1 X121.702 Y115.31 E.01648
G1 X119.735 Y118.716 E.09567
G1 X119.174 Y119.329 E.02021
G1 X118.739 Y119.629 E.01285
G1 X118.204 Y119.849 E.01407
G1 X117.671 Y119.998 E.01346
G1 X117.233 Y120.037 E.0107
G1 X113.767 Y120.037 E.08431
G1 X113.125 Y119.966 E.01571
G1 X112.58 Y119.79 E.01393
G1 X111.949 Y119.426 E.01772
G1 X111.428 Y118.91 E.01784
G1 X111.265 Y118.717 E.00614
G1 X109.406 Y115.52 E.08996
G1 X109.11 Y114.797 E.019
G1 X109.007 Y114.184 E.01512
G1 X109.026 Y113.61 E.01397
G1 X109.153 Y113.052 E.01392
G1 X109.382 Y112.528 E.01391
G1 X111.138 Y109.481 E.08554
G1 X111.594 Y108.891 E.01814
G1 X112.027 Y108.548 E.01344
G1 X112.027 Y108.548 F9000
G1 X111.811 Y108.247
G1 F6000
G1 X112.085 Y108.051 E.00819
G1 X112.669 Y107.788 E.01558
G1 X113.216 Y107.667 E.01363
G1 X113.767 Y107.597 E.01351
G1 X117.469 Y107.608 E.09005
G1 X118.099 Y107.715 E.01554
G1 X118.641 Y107.91 E.01401
G1 X118.893 Y108.038 E.00688
G1 X119.483 Y108.458 E.01762
G1 X119.952 Y108.96 E.01671
G1 X120.051 Y109.099 E.00415
G1 X121.91 Y112.297 E.08998
G1 X122.229 Y113.067 E.02027
G1 X122.291 Y113.317 E.00627
G1 X122.36 Y114.017 E.01711
G1 X122.286 Y114.721 E.01722
G1 X122.09 Y115.336 E.0157
G1 X122.019 Y115.493 E.00419
G1 X120.052 Y118.899 E.09567
G1 X119.724 Y119.281 E.01225
G1 X119.366 Y119.65 E.01251
G1 X118.938 Y119.936 E.01252
G1 X118.684 Y120.069 E.00697
G1 X118 Y120.308 E.01762
G1 X117.233 Y120.403 E.0188
G1 X113.767 Y120.403 E.08431
G1 X113.189 Y120.349 E.01412
G1 X113.022 Y120.317 E.00414
G1 X112.399 Y120.108 E.01598
G1 X111.767 Y119.743 E.01775
G1 X111.561 Y119.581 E.00637
G1 X111.077 Y119.071 E.0171
G1 X110.949 Y118.901 E.00518
G1 X109.09 Y115.703 E.08998
G1 X108.771 Y114.933 E.02027
G1 X108.645 Y114.235 E.01725
G1 X108.661 Y113.591 E.01567
G1 X108.798 Y112.965 E.01559
G1 X109.049 Y112.376 E.01557
G1 X110.821 Y109.298 E.08639
G1 X111.307 Y108.665 E.01941
G1 X111.513 Y108.46 E.00707
G1 X111.762 Y108.282 E.00745
G1 X111.762 Y108.282 F9000
G1 X111.549 Y107.985
G1 F6000
G1 X111.871 Y107.754 E.00964
G1 X112.532 Y107.448 E.01772
G1 X112.892 Y107.344 E.00911
;WIDTH:0.443276
G1 X113.584 Y107.223 E.01911
;WIDTH:0.448854
G1 X113.771 Y107.207 E.00518
;WIDTH:0.45401
G1 X117.232 Y107.215 E.09662
G1 X117.715 Y107.259 E.01354
;WIDTH:0.416339
G1 X118.424 Y107.429 E.01853
;WIDTH:0.399999
G1 X118.965 Y107.654 E.01425
G1 X119.431 Y107.972 E.01372
G1 X119.922 Y108.366 E.01531
G1 X120.367 Y108.915 E.01719
G1 X122.226 Y112.113 E.08998
G1 X122.569 Y112.93 E.02155
G1 X122.655 Y113.281 E.00879
G1 X122.724 Y113.981 E.01711
G1 X122.717 Y114.287 E.00745
G1 X122.642 Y114.813 E.01292
G1 X122.436 Y115.456 E.01642
G1 X122.335 Y115.675 E.00587
G1 X120.369 Y119.082 E.09568
G1 X119.989 Y119.533 E.01434
G1 X119.602 Y119.929 E.01347
G1 X119.137 Y120.243 E.01365
G1 X118.804 Y120.415 E.00912
G1 X118.12 Y120.653 E.01762
;WIDTH:0.431122
G1 X117.786 Y120.719 E.00899
;WIDTH:0.462244
G1 X117.451 Y120.785 E.00972
G1 X117.233 Y120.795 E.00621
;WIDTH:0.45401
G1 X113.772 Y120.793 E.09662
;WIDTH:0.448853
G1 X113.152 Y120.713 E.01724
;WIDTH:0.399999
G1 X112.918 Y120.667 E.0058
G1 X112.219 Y120.426 E.01798
G1 X111.584 Y120.06 E.01783
G1 X111.296 Y119.833 E.00892
G1 X110.812 Y119.323 E.0171
G1 X110.633 Y119.085 E.00724
G1 X108.774 Y115.887 E.08998
G1 X108.431 Y115.069 E.02158
G1 X108.283 Y114.287 E.01936
G1 X108.296 Y113.573 E.01737
G1 X108.442 Y112.878 E.01727
G1 X108.717 Y112.224 E.01726
G1 X110.505 Y109.115 E.08724
G1 X111.019 Y108.439 E.02066
G1 X111.3 Y108.163 E.00958
G1 X111.5 Y108.02 E.00598
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X111.549 Y107.985 E-.0286
G1 X111.871 Y107.754 E-.18824
G1 X112.532 Y107.448 E-.34599
G1 X112.892 Y107.344 E-.17799
G1 X113.584 Y107.223 E-.33369
G1 X113.771 Y107.207 E-.08915
G1 X114.479 Y107.209 E-.33634
;WIPE_END
G1 X112.361 Y108.328 F9000
G1 X112.157 Y108.446
G1 X112.117 Y108.471
G1 X111.925 Y108.608
G1 X111.887 Y108.637
G1 X111.709 Y108.791
G1 X111.674 Y108.824
G1 X111.511 Y108.994
G1 X111.479 Y109.029
G1 X111.334 Y109.215
G1 X111.305 Y109.252
G1 X111.177 Y109.451
G1 X111.159 Y109.48
G1 X109.415 Y112.5
G1 X109.399 Y112.531
G1 X109.291 Y112.741
G1 X109.272 Y112.784
G1 X109.185 Y113.003
G1 X109.171 Y113.049
G1 X109.104 Y113.275
G1 X109.094 Y113.321
G1 X109.049 Y113.553
G1 X109.043 Y113.6
G1 X109.021 Y113.835
G1 X109.019 Y113.882
G1 X109.019 Y114.118
G1 X109.021 Y114.165
G1 X109.043 Y114.4
G1 X109.049 Y114.447
G1 X109.094 Y114.679
G1 X109.104 Y114.725
G1 X109.171 Y114.951
G1 X109.185 Y114.997
G1 X109.272 Y115.216
G1 X109.291 Y115.259
G1 X109.399 Y115.469
G1 X109.415 Y115.5
G1 X111.159 Y118.52
G1 X111.177 Y118.549
G1 X111.305 Y118.748
G1 X111.333 Y118.785
G1 X111.479 Y118.971
G1 X111.511 Y119.006
G1 X111.674 Y119.176
G1 X111.709 Y119.209
G1 X111.887 Y119.363
G1 X111.925 Y119.392
G1 X112.117 Y119.529
G1 X112.157 Y119.554
G1 X112.361 Y119.672
G1 X112.403 Y119.694
G1 X112.618 Y119.792
G1 X112.662 Y119.81
G1 X112.885 Y119.887
G1 X112.93 Y119.902
G1 X113.159 Y119.957
G1 X113.206 Y119.967
G1 X113.439 Y120.001
G1 X113.486 Y120.007
G1 X113.674 Y120.016
G1 X113.509 Y121.992
G1 X113.527 Y122.362
G1 E5 F2400
G1 F6000
G1 X113.768 Y122.329 E.00592
G1 X117.467 Y122.34 E.08997
G1 X117.983 Y122.438 E.01278
G1 X118.449 Y122.622 E.01219
G1 X119.059 Y123.054 E.01818
G1 X119.418 Y123.466 E.01329
G1 X121.277 Y126.664 E.08998
G1 X121.551 Y127.339 E.01772
G1 X121.632 Y128.089 E.01835
G1 X121.562 Y128.618 E.01298
G1 X121.385 Y129.127 E.01311
G1 X119.419 Y132.533 E.09566
G1 X118.909 Y133.077 E.01814
G1 X118.482 Y133.36 E.01246
G1 X117.759 Y133.617 E.01866
G1 X117.233 Y133.671 E.01286
G1 X113.767 Y133.671 E.08431
G1 X113.262 Y133.622 E.01234
G1 X112.759 Y133.472 E.01277
G1 X112.132 Y133.11 E.01761
G1 X111.581 Y132.534 E.01939
G1 X109.723 Y129.336 E.08996
G1 X109.449 Y128.66 E.01774
G1 X109.369 Y128.132 E.01299
G1 X109.391 Y127.629 E.01225
G1 X109.508 Y127.139 E.01225
G1 X109.714 Y126.68 E.01224
G1 X111.455 Y123.664 E.08471
G1 X111.882 Y123.116 E.0169
G1 X112.549 Y122.624 E.02016
G1 X113.044 Y122.43 E.01293
G1 X113.467 Y122.371 E.01039
G1 X113.467 Y122.371 F9000
G1 X113.416 Y122.011
;TYPE:Perimeter
G1 F6000
G1 X113.769 Y121.963 E.00867
G1 X117.468 Y121.974 E.08997
G1 X118.029 Y122.074 E.01386
G1 X118.505 Y122.25 E.01234
G1 X119.007 Y122.568 E.01445
G1 X119.369 Y122.844 E.01107
G1 X119.734 Y123.282 E.01387
G1 X121.594 Y126.48 E.08999
G1 X121.89 Y127.203 E.019
G1 X121.996 Y128.053 E.02084
G1 X121.924 Y128.67 E.01511
G1 X121.702 Y129.31 E.01648
G1 X119.735 Y132.716 E.09567
G1 X119.174 Y133.329 E.02021
G1 X118.681 Y133.666 E.01453
G1 X117.88 Y133.962 E.02077
G1 X117.233 Y134.037 E.01584
G1 X113.767 Y134.037 E.08431
G1 X113.225 Y133.985 E.01324
G1 X112.696 Y133.839 E.01335
G1 X111.949 Y133.426 E.02076
G1 X111.411 Y132.892 E.01844
G1 X111.265 Y132.717 E.00554
G1 X109.406 Y129.52 E.08996
G1 X109.11 Y128.797 E.019
G1 X109.007 Y128.184 E.01512
G1 X109.026 Y127.61 E.01397
G1 X109.153 Y127.052 E.01392
G1 X109.382 Y126.528 E.01391
G1 X111.138 Y123.481 E.08554
G1 X111.594 Y122.891 E.01814
G1 X112.101 Y122.489 E.01574
G1 X112.413 Y122.285 E.00907
G1 X112.987 Y122.069 E.01492
G1 X113.356 Y122.019 E.00906
G1 X113.356 Y122.019 F9000
G1 X113.305 Y121.656
G1 F6000
G1 X113.767 Y121.597 E.01133
G1 X117.469 Y121.608 E.09005
G1 X118.099 Y121.715 E.01554
G1 X118.641 Y121.91 E.01401
G1 X118.893 Y122.038 E.00688
G1 X119.483 Y122.458 E.01762
G1 X119.952 Y122.96 E.01671
G1 X120.051 Y123.099 E.00415
G1 X121.91 Y126.297 E.08998
G1 X122.229 Y127.067 E.02027
G1 X122.291 Y127.317 E.00627
G1 X122.36 Y128.017 E.01711
G1 X122.286 Y128.721 E.01722
G1 X122.09 Y129.336 E.0157
G1 X122.019 Y129.493 E.00419
G1 X120.052 Y132.899 E.09567
G1 X119.439 Y133.581 E.02231
G1 X118.88 Y133.973 E.01661
G1 X118 Y134.308 E.0229
G1 X117.233 Y134.403 E.0188
G1 X113.767 Y134.403 E.08431
G1 X113.189 Y134.349 E.01412
G1 X112.592 Y134.19 E.01503
G1 X111.767 Y133.743 E.02282
G1 X111.561 Y133.581 E.00637
G1 X111.077 Y133.071 E.0171
G1 X110.949 Y132.901 E.00518
G1 X109.09 Y129.703 E.08998
G1 X108.771 Y128.933 E.02027
G1 X108.645 Y128.235 E.01725
G1 X108.661 Y127.591 E.01567
G1 X108.798 Y126.965 E.01559
G1 X109.049 Y126.376 E.01557
G1 X110.821 Y123.298 E.08639
G1 X111.307 Y122.665 E.01941
G1 X111.513 Y122.46 E.00707
G1 X112.085 Y122.051 E.0171
G1 X112.669 Y121.788 E.01558
G1 X113.216 Y121.667 E.01363
G1 X113.245 Y121.663 E.00071
G1 X113.245 Y121.663 F9000
G1 X113.192 Y121.291
;WIDTH:0.443276
G1 F6000
G1 X113.584 Y121.223 E.01082
;WIDTH:0.448853
G1 X113.771 Y121.207 E.00518
;WIDTH:0.45401
G1 X117.232 Y121.215 E.09662
G1 X117.715 Y121.259 E.01354
;WIDTH:0.416339
G1 X118.424 Y121.429 E.01853
;WIDTH:0.399999
G1 X118.965 Y121.654 E.01425
G1 X119.431 Y121.972 E.01372
G1 X119.922 Y122.366 E.01531
G1 X120.367 Y122.915 E.01719
G1 X122.226 Y126.113 E.08998
G1 X122.569 Y126.93 E.02155
G1 X122.655 Y127.281 E.00879
G1 X122.724 Y127.981 E.01711
G1 X122.717 Y128.287 E.00745
G1 X122.642 Y128.813 E.01292
G1 X122.436 Y129.456 E.01642
G1 X122.335 Y129.675 E.00587
G1 X120.369 Y133.082 E.09568
G1 X119.704 Y133.833 E.0244
G1 X119.079 Y134.28 E.01869
G1 X118.804 Y134.415 E.00745
G1 X118.12 Y134.653 E.01762
G1 X117.82 Y134.718 E.00747
G1 X117.233 Y134.768 E.01433
G1 X113.767 Y134.768 E.08431
G1 X113.152 Y134.713 E.01502
G1 X112.489 Y134.541 E.01666
G1 X112.211 Y134.422 E.00736
G1 X111.584 Y134.06 E.01761
G1 X111.296 Y133.833 E.00892
G1 X110.812 Y133.323 E.0171
G1 X110.633 Y133.085 E.00724
G1 X108.774 Y129.887 E.08998
G1 X108.431 Y129.069 E.02158
G1 X108.283 Y128.287 E.01936
G1 X108.296 Y127.573 E.01737
G1 X108.442 Y126.878 E.01727
G1 X108.717 Y126.224 E.01726
G1 X110.505 Y123.115 E.08724
G1 X111.019 Y122.439 E.02066
G1 X111.3 Y122.163 E.00958
G1 X111.871 Y121.754 E.01708
G1 X112.533 Y121.448 E.01774
G1 X112.892 Y121.344 E.00909
;WIDTH:0.443276
G1 X113.133 Y121.302 E.00665
G1 E-5 F3600
G1 X113.133 Y121.302 F9000
G1 X111.674 Y122.824
G1 X111.511 Y122.994
G1 X111.479 Y123.029
G1 X111.334 Y123.215
G1 X111.305 Y123.252
G1 X111.177 Y123.451
G1 X111.159 Y123.48
G1 X109.415 Y126.5
G1 X109.399 Y126.531
G1 X109.291 Y126.741
G1 X109.272 Y126.784
G1 X109.185 Y127.003
G1 X109.171 Y127.049
G1 X109.104 Y127.275
G1 X109.094 Y127.321
G1 X109.049 Y127.553
G1 X109.043 Y127.6
G1 X109.021 Y127.835
G1 X109.019 Y127.882
G1 X109.019 Y128.118
G1 X109.021 Y128.165
G1 X109.043 Y128.4
G1 X109.049 Y128.447
G1 X109.094 Y128.679
G1 X109.104 Y128.725
G1 X109.171 Y128.951
G1 X109.185 Y128.997
G1 X109.272 Y129.216
G1 X109.291 Y129.259
G1 X109.399 Y129.469
G1 X109.415 Y129.5
G1 X112.316 Y134.862
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X112.028 Y134.738 E.00763
G1 X111.401 Y134.376 E.01761
G1 X111.031 Y134.084 E.01146
G1 X110.546 Y133.575 E.0171
G1 X110.317 Y133.269 E.0093
G1 X108.458 Y130.071 E.08998
G1 X108.092 Y129.206 E.02285
G1 X107.99 Y128.824 E.00962
G1 X107.904 Y128.107 E.01757
G1 X107.931 Y127.554 E.01347
G1 X108.087 Y126.791 E.01894
G1 X108.455 Y125.934 E.02269
G1 X110.188 Y122.933 E.08429
G1 X110.731 Y122.213 E.02194
G1 X111.087 Y121.866 E.01209
G1 X111.658 Y121.457 E.01708
G1 X112.003 Y121.267 E.00958
G1 X112.758 Y121.001 E.01947
G1 X112.038 Y120.744 E.0186
G1 X111.401 Y120.376 E.01789
G1 X111.031 Y120.084 E.01146
G1 X110.546 Y119.575 E.0171
G1 X110.317 Y119.269 E.0093
G1 X108.458 Y116.071 E.08998
G1 X108.092 Y115.206 E.02285
G1 X107.99 Y114.824 E.00962
G1 X107.904 Y114.107 E.01757
G1 X107.931 Y113.554 E.01347
G1 X108.087 Y112.791 E.01894
G1 X108.455 Y111.934 E.02269
G1 X110.188 Y108.933 E.08429
G1 X110.731 Y108.213 E.02194
G1 X111.087 Y107.866 E.01209
G1 X111.658 Y107.457 E.01708
G1 X112.003 Y107.267 E.00958
G1 X112.758 Y107.001 E.01947
G1 X112.038 Y106.744 E.0186
G1 X111.401 Y106.376 E.01789
G1 X111.031 Y106.084 E.01146
G1 X110.546 Y105.575 E.0171
G1 X110.317 Y105.269 E.0093
G1 X108.458 Y102.071 E.08998
G1 X108.092 Y101.206 E.02285
G1 X107.99 Y100.824 E.00962
G1 X107.904 Y100.107 E.01757
G1 X107.931 Y99.554 E.01347
G1 X108.087 Y98.791 E.01894
G1 X108.384 Y98.072 E.01892
G1 X110.188 Y94.933 E.08806
G1 X110.735 Y94.209 E.02207
G1 X111.031 Y93.908 E.01027
G1 X111.417 Y93.605 E.01194
G1 X111.754 Y93.401 E.00958
G1 X112.394 Y93.112 E.01708
G1 X112.84 Y92.982 E.0113
G1 X113.535 Y92.883 E.01708
G1 X113.772 Y92.866 E.00578
G1 X117.472 Y92.877 E.09
G1 X118.265 Y93.002 E.01953
G1 X118.976 Y93.256 E.01836
G1 X119.316 Y93.442 E.00943
G1 X119.907 Y93.862 E.01764
G1 X120.329 Y94.278 E.01441
G1 X120.683 Y94.731 E.01398
G1 X122.542 Y97.929 E.08998
G1 X122.908 Y98.794 E.02285
G1 X123.018 Y99.245 E.01129
G1 X123.088 Y99.945 E.01711
G1 X123.079 Y100.338 E.00956
G1 X123.002 Y100.877 E.01324
G1 X122.781 Y101.576 E.01783
G1 X122.552 Y102.031 E.01239
G1 X120.686 Y105.264 E.0908
G1 X120.254 Y105.785 E.01646
G1 X119.838 Y106.209 E.01445
G1 X119.335 Y106.55 E.01478
G1 X118.924 Y106.76 E.01123
G1 X118.242 Y106.998 E.01757
G1 X118.913 Y107.231 E.01728
G1 X119.316 Y107.442 E.01106
G1 X119.907 Y107.862 E.01764
G1 X120.331 Y108.28 E.01448
G1 X120.683 Y108.731 E.01392
G1 X122.542 Y111.929 E.08998
G1 X122.908 Y112.794 E.02285
G1 X123.018 Y113.245 E.01129
G1 X123.088 Y113.945 E.01711
G1 X123.079 Y114.338 E.00956
G1 X123.002 Y114.877 E.01324
G1 X122.781 Y115.576 E.01783
G1 X122.652 Y115.858 E.00754
G1 X120.686 Y119.264 E.09566
G1 X120.254 Y119.785 E.01646
G1 X119.838 Y120.209 E.01445
G1 X119.335 Y120.55 E.01478
G1 X118.924 Y120.76 E.01123
G1 X118.242 Y120.998 E.01757
G1 X118.913 Y121.231 E.01728
G1 X119.316 Y121.442 E.01106
G1 X119.907 Y121.862 E.01764
G1 X120.331 Y122.28 E.01448
G1 X120.683 Y122.731 E.01392
G1 X122.542 Y125.929 E.08998
G1 X122.908 Y126.794 E.02285
G1 X123.018 Y127.245 E.01129
G1 X123.088 Y127.945 E.01711
G1 X123.079 Y128.338 E.00956
G1 X123.002 Y128.877 E.01324
G1 X122.781 Y129.576 E.01783
G1 X122.652 Y129.858 E.00754
G1 X120.686 Y133.264 E.09566
G1 X120.385 Y133.647 E.01185
G1 X119.97 Y134.084 E.01466
G1 X119.671 Y134.332 E.00945
G1 X119.278 Y134.587 E.0114
G1 X118.924 Y134.76 E.00958
G1 X118.24 Y134.998 E.01762
G1 X117.854 Y135.082 E.00961
G1 X117.233 Y135.134 E.01516
G1 X113.767 Y135.134 E.08431
G1 X113.116 Y135.077 E.0159
G1 X112.386 Y134.892 E.01832
G1 X112.371 Y134.885 E.0004
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X112.316 Y134.862 E-.02832
G1 X112.028 Y134.738 E-.14894
G1 X111.401 Y134.376 E-.3439
G1 X111.031 Y134.084 E-.22389
G1 X110.546 Y133.575 E-.33396
G1 X110.317 Y133.269 E-.18155
G1 X110.064 Y132.833 E-.23944
;WIPE_END
G1 X109.104 Y128.725 F9000
G1 X109.043 Y128.4
G1 X109.043 Y113.6
G1 X109.415 Y112.5
G1 X111.159 Y109.48
G1 X112.403 Y108.306
G1 X112.618 Y108.208
G1 X112.662 Y108.19
G1 X112.885 Y108.113
G1 X112.93 Y108.098
G1 X113.159 Y108.043
G1 X113.206 Y108.033
G1 X113.436 Y107.999
G1 X113.737 Y106.019
G1 X113.752 Y105.67
G1 E5 F2400
G1 F6000
G1 X113.262 Y105.622 E.01198
G1 X112.76 Y105.472 E.01274
G1 X112.132 Y105.11 E.01763
G1 X111.581 Y104.534 E.01939
G1 X109.721 Y101.333 E.09005
G1 X109.449 Y100.66 E.01766
G1 X109.367 Y100.107 E.0136
G1 X109.396 Y99.595 E.01247
G1 X109.519 Y99.106 E.01226
G1 X109.722 Y98.665 E.01181
G1 X111.455 Y95.664 E.08429
G1 X111.885 Y95.112 E.01702
G1 X112.32 Y94.757 E.01366
G1 X112.997 Y94.444 E.01814
G1 X113.768 Y94.329 E.01896
G1 X117.467 Y94.34 E.08997
G1 X117.983 Y94.438 E.01278
G1 X118.469 Y94.635 E.01276
G1 X119.059 Y95.054 E.0176
G1 X119.418 Y95.466 E.01329
G1 X121.277 Y98.664 E.08998
G1 X121.551 Y99.339 E.01772
G1 X121.631 Y100.132 E.01939
G1 X121.554 Y100.652 E.01279
G1 X121.385 Y101.127 E.01226
G1 X119.419 Y104.533 E.09566
G1 X118.909 Y105.077 E.01814
G1 X118.482 Y105.36 E.01246
G1 X117.783 Y105.609 E.01805
G1 X117.25 Y105.671 E.01305
G1 X113.812 Y105.671 E.08363
G1 X113.812 Y105.671 F9000
G1 X113.812 Y106.037
;TYPE:Perimeter
G1 F6000
G1 X113.767 Y106.037 E.00109
G1 X113.225 Y105.985 E.01324
G1 X112.696 Y105.839 E.01335
G1 X112.159 Y105.547 E.01487
G1 X111.826 Y105.329 E.00968
G1 X111.342 Y104.819 E.0171
G1 X111.265 Y104.717 E.00311
G1 X109.406 Y101.52 E.08996
G1 X109.11 Y100.797 E.019
G1 X109.001 Y100.107 E.01699
G1 X109.032 Y99.553 E.0135
G1 X109.153 Y99.052 E.01254
G1 X109.405 Y98.482 E.01516
G1 X111.138 Y95.481 E.08429
G1 X111.598 Y94.887 E.01827
G1 X112.094 Y94.469 E.01578
G1 X112.847 Y94.111 E.02028
G1 X113.69 Y93.969 E.02079
G1 X117.468 Y93.974 E.0919
G1 X118.054 Y94.079 E.01448
G1 X118.567 Y94.275 E.01336
G1 X119.271 Y94.756 E.02074
G1 X119.675 Y95.199 E.01458
G1 X121.594 Y98.48 E.09246
G1 X121.89 Y99.203 E.019
G1 X121.979 Y99.884 E.01671
G1 X121.993 Y100.184 E.00731
G1 X121.921 Y100.687 E.01236
G1 X121.745 Y101.216 E.01356
G1 X119.735 Y104.716 E.09817
G1 X119.174 Y105.329 E.02021
G1 X118.739 Y105.629 E.01285
G1 X118.204 Y105.849 E.01407
G1 X117.671 Y105.998 E.01346
G1 X117.233 Y106.037 E.0107
G1 X113.872 Y106.037 E.08175
G1 X113.872 Y106.037 F9000
G1 X113.872 Y106.403
G1 F6000
G1 X113.767 Y106.403 E.00255
G1 X113.189 Y106.349 E.01412
G1 X112.657 Y106.209 E.01338
G1 X112.394 Y106.105 E.00688
G1 X111.767 Y105.743 E.01761
G1 X111.561 Y105.581 E.00637
G1 X111.077 Y105.071 E.0171
G1 X110.949 Y104.901 E.00518
G1 X109.09 Y101.703 E.08998
G1 X108.771 Y100.933 E.02027
G1 X108.636 Y100.107 E.02036
G1 X108.661 Y99.591 E.01257
G1 X108.798 Y98.965 E.01559
G1 X109.049 Y98.376 E.01557
G1 X110.821 Y95.298 E.08639
G1 X111.31 Y94.661 E.01953
G1 X111.869 Y94.181 E.01792
G1 X112.696 Y93.778 E.02238
G1 X112.944 Y93.706 E.00628
G1 X113.77 Y93.597 E.02027
G1 X117.469 Y93.608 E.08997
G1 X118.124 Y93.72 E.01616
G1 X118.703 Y93.935 E.01502
G1 X119.483 Y94.458 E.02284
G1 X119.952 Y94.96 E.01671
G1 X120.051 Y95.099 E.00415
G1 X121.91 Y98.297 E.08998
G1 X122.229 Y99.067 E.02027
G1 X122.291 Y99.317 E.00627
G1 X122.36 Y100.017 E.01711
G1 X122.286 Y100.721 E.01722
G1 X122.09 Y101.336 E.0157
G1 X121.742 Y101.972 E.01763
G1 X120.052 Y104.899 E.08221
G1 X119.724 Y105.281 E.01225
G1 X119.366 Y105.65 E.01251
G1 X118.938 Y105.936 E.01252
G1 X118.684 Y106.069 E.00697
G1 X118 Y106.308 E.01762
G1 X117.233 Y106.403 E.0188
G1 X113.932 Y106.403 E.08029
G1 X113.932 Y106.403 F9000
G1 X113.932 Y106.793
;WIDTH:0.45401
G1 F6000
G1 X113.772 Y106.793 E.00447
;WIDTH:0.448854
G1 X113.152 Y106.713 E.01724
;WIDTH:0.399999
G1 X112.554 Y106.56 E.01501
G1 X112.211 Y106.422 E.00899
G1 X111.584 Y106.06 E.01761
G1 X111.296 Y105.833 E.00892
G1 X110.812 Y105.323 E.0171
G1 X110.633 Y105.085 E.00724
G1 X108.774 Y101.887 E.08998
G1 X108.431 Y101.069 E.02158
G1 X108.283 Y100.287 E.01936
G1 X108.27 Y100.107 E.00439
G1 X108.296 Y99.573 E.013
G1 X108.442 Y98.878 E.01727
G1 X108.772 Y98.117 E.02018
G1 X110.505 Y95.115 E.08431
G1 X111.022 Y94.435 E.02078
G1 X111.257 Y94.196 E.00815
G1 X111.905 Y93.734 E.01936
G1 X112.545 Y93.445 E.01708
G1 X112.892 Y93.344 E.00879
G1 X113.771 Y93.232 E.02155
G1 X117.471 Y93.243 E.09
G1 X118.195 Y93.361 E.01784
G1 X118.84 Y93.596 E.0167
G1 X119.104 Y93.74 E.00731
G1 X119.695 Y94.16 E.01764
G1 X120.052 Y94.517 E.01228
G1 X120.367 Y94.915 E.01235
G1 X122.226 Y98.113 E.08998
G1 X122.569 Y98.93 E.02155
G1 X122.655 Y99.281 E.00879
G1 X122.724 Y99.981 E.01711
G1 X122.717 Y100.287 E.00745
G1 X122.642 Y100.813 E.01292
G1 X122.436 Y101.456 E.01642
G1 X122.059 Y102.155 E.01932
G1 X120.369 Y105.082 E.08221
G1 X119.989 Y105.533 E.01434
G1 X119.602 Y105.929 E.01347
G1 X119.137 Y106.243 E.01365
G1 X118.804 Y106.415 E.00912
G1 X118.12 Y106.653 E.01762
;WIDTH:0.431122
G1 X117.786 Y106.719 E.00899
;WIDTH:0.462244
G1 X117.451 Y106.785 E.00972
G1 X117.233 Y106.795 E.00621
;WIDTH:0.45401
G1 X113.992 Y106.793 E.09048
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.932 Y106.793 E-.0285
G1 X113.772 Y106.793 E-.076
G1 X113.152 Y106.713 E-.29694
G1 X112.554 Y106.56 E-.2932
G1 X112.211 Y106.422 E-.17562
G1 X111.584 Y106.06 E-.3439
G1 X111.296 Y105.833 E-.17419
G1 X111.134 Y105.663 E-.11165
;WIPE_END
G1 X111.66 Y105.162 F9000
G1 X106.099 Y103.505
G1 X105.669 Y103.505
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.567 Y103.424 E.00317
G1 X105.457 Y103.424 E.00268
G1 X105.457 Y98.824 E.11189
G1 X105.567 Y98.824 E.00268
G1 X105.725 Y98.734 E.00442
G1 X105.75 Y98.642 E.00232
G1 X105.75 Y91.689 E.16912
G1 X105.708 Y91.572 E.00302
G1 X105.359 Y91.152 E.01328
G1 X105.13 Y90.774 E.01075
G1 X105.074 Y90.501 E.00678
G1 X105.113 Y90.323 E.00443
G1 X105.249 Y90.008 E.00835
G1 X105.595 Y89.559 E.01379
G1 X125.401 Y89.559 E.48176
G1 X125.806 Y90.091 E.01626
G1 X125.913 Y90.397 E.00789
G1 X125.911 Y90.597 E.00487
G1 X125.793 Y90.932 E.00864
G1 X125.289 Y91.576 E.01989
G1 X125.25 Y91.688 E.00288
G1 X125.257 Y98.691 E.17034
G1 X125.433 Y98.824 E.00537
G1 X125.543 Y98.824 E.00268
G1 X125.543 Y103.424 E.11189
G1 X125.433 Y103.424 E.00268
G1 X125.272 Y103.521 E.00457
G1 X125.25 Y103.607 E.00216
G1 X125.25 Y136.311 E.79549
G1 X125.292 Y136.428 E.00302
G1 X125.641 Y136.848 E.01328
G1 X125.87 Y137.226 E.01075
G1 X125.926 Y137.499 E.00678
G1 X125.887 Y137.677 E.00443
G1 X125.751 Y137.992 E.00835
G1 X125.405 Y138.441 E.01379
G1 X105.599 Y138.441 E.48176
G1 X105.258 Y137.993 E.01369
G1 X105.099 Y137.685 E.00843
G1 X105.089 Y137.403 E.00686
G1 X105.207 Y137.068 E.00864
G1 X105.711 Y136.424 E.01989
G1 X105.75 Y136.312 E.00288
G1 X105.75 Y103.607 E.79552
G1 X105.745 Y103.565 E.00103
G1 X105.716 Y103.542 E.0009
G1 X105.716 Y103.542 F9000
G1 X105.907 Y103.264
;TYPE:Perimeter
G1 F6000
G1 X105.822 Y103.211 E.00244
G1 X105.822 Y99.044 E.10136
G1 X106.041 Y98.918 E.00615
G1 X106.116 Y98.642 E.00696
G1 X106.116 Y91.689 E.16912
G1 X106.091 Y91.525 E.00404
G1 X105.989 Y91.339 E.00516
G1 X105.641 Y90.918 E.01329
G1 X105.465 Y90.586 E.00914
G1 X105.485 Y90.335 E.00612
G1 X105.77 Y89.925 E.01215
G1 X125.22 Y89.925 E.4731
G1 X125.451 Y90.228 E.00927
G1 X125.551 Y90.45 E.00592
G1 X125.557 Y90.492 E.00103
G1 X125.479 Y90.74 E.00632
G1 X125.001 Y91.35 E.01885
G1 X124.884 Y91.688 E.0087
G1 X124.884 Y98.642 E.16915
G1 X124.959 Y98.918 E.00696
G1 X125.178 Y99.044 E.00615
G1 X125.178 Y103.211 E.10136
G1 X124.95 Y103.348 E.00647
G1 X124.884 Y103.607 E.0065
G1 X124.884 Y136.311 E.79549
G1 X124.909 Y136.475 E.00404
G1 X125.011 Y136.661 E.00516
G1 X125.359 Y137.082 E.01329
G1 X125.535 Y137.414 E.00914
G1 X125.515 Y137.665 E.00612
G1 X125.23 Y138.075 E.01215
G1 X105.78 Y138.075 E.4731
G1 X105.513 Y137.724 E.01073
G1 X105.443 Y137.507 E.00555
G1 X105.521 Y137.26 E.0063
G1 X105.999 Y136.65 E.01885
G1 X106.116 Y136.312 E.0087
G1 X106.116 Y103.607 E.79552
G1 X106.055 Y103.356 E.00628
G1 X105.958 Y103.295 E.00279
G1 X105.958 Y103.295 F9000
G1 X106.188 Y103.024
G1 F6000
G1 X106.188 Y99.199 E.09304
G1 X106.356 Y99.103 E.00471
G1 X106.396 Y99.028 E.00207
G1 X106.481 Y98.642 E.00961
G1 X106.481 Y91.689 E.16912
G1 X106.44 Y91.416 E.00671
G1 X106.271 Y91.105 E.00861
G1 X105.922 Y90.685 E.01328
G1 X105.823 Y90.512 E.00485
G1 X105.944 Y90.29 E.00615
G1 X125.039 Y90.29 E.46447
G1 X125.185 Y90.5 E.00622
G1 X125.165 Y90.548 E.00126
G1 X124.713 Y91.125 E.01783
G1 X124.519 Y91.688 E.01448
G1 X124.523 Y98.732 E.17134
G1 X124.643 Y99.102 E.00946
G1 X124.812 Y99.199 E.00474
G1 X124.812 Y103.064 E.09401
G1 X124.627 Y103.175 E.00525
G1 X124.574 Y103.294 E.00317
G1 X124.519 Y103.607 E.00773
G1 X124.519 Y136.311 E.79549
G1 X124.56 Y136.584 E.00671
G1 X124.729 Y136.895 E.00861
G1 X125.078 Y137.315 E.01328
G1 X125.177 Y137.488 E.00485
G1 X125.056 Y137.71 E.00615
G1 X105.961 Y137.71 E.46447
G1 X105.837 Y137.547 E.00498
G1 X105.835 Y137.452 E.00231
G1 X106.287 Y136.875 E.01783
G1 X106.481 Y136.312 E.01448
G1 X106.481 Y103.607 E.79552
G1 X106.456 Y103.395 E.00519
G1 X106.38 Y103.188 E.00536
G1 X106.205 Y103.075 E.00507
G1 X106.205 Y103.075 F9000
G1 X106.554 Y102.756
G1 F6000
G1 X106.554 Y99.355 E.08273
G1 X106.672 Y99.287 E.00331
G1 X106.778 Y99.058 E.00614
G1 X106.847 Y98.642 E.01026
G1 X106.847 Y91.689 E.16912
G1 X106.789 Y91.307 E.0094
G1 X106.552 Y90.872 E.01205
G1 X106.373 Y90.656 E.00682
G1 X124.616 Y90.656 E.44374
G1 X124.425 Y90.899 E.00752
G1 X124.153 Y91.688 E.0203
G1 X124.165 Y98.816 E.17338
G1 X124.328 Y99.287 E.01212
G1 X124.446 Y99.355 E.00331
G1 X124.446 Y102.917 E.08664
G1 X124.305 Y103.002 E.004
G1 X124.231 Y103.168 E.00442
G1 X124.153 Y103.607 E.01085
G1 X124.153 Y136.311 E.79549
G1 X124.211 Y136.693 E.0094
G1 X124.448 Y137.128 E.01205
G1 X124.627 Y137.344 E.00682
G1 X106.384 Y137.344 E.44374
G1 X106.575 Y137.101 E.00752
G1 X106.847 Y136.312 E.0203
G1 X106.847 Y103.607 E.79552
G1 X106.812 Y103.311 E.00725
G1 X106.705 Y103.021 E.00752
G1 X106.554 Y102.917 E.00446
G1 X106.554 Y102.816 E.00246
G1 X106.554 Y102.816 F9000
G1 X106.919 Y102.483
G1 F6000
G1 X106.919 Y99.511 E.07229
G1 X106.988 Y99.472 E.00193
G1 X107.123 Y99.176 E.00791
G1 X107.213 Y98.642 E.01317
G1 X107.213 Y91.689 E.16912
G1 X107.138 Y91.197 E.01211
G1 X107.042 Y91.022 E.00486
G1 X124.017 Y91.022 E.4129
G1 X123.787 Y91.688 E.01714
G1 X123.787 Y98.624 E.16871
G1 X123.849 Y99.087 E.01136
G1 X124.012 Y99.471 E.01015
G1 X124.081 Y99.511 E.00194
G1 X124.081 Y102.77 E.07927
G1 X123.983 Y102.829 E.00278
G1 X123.887 Y103.043 E.00571
G1 X123.787 Y103.607 E.01393
G1 X123.787 Y136.311 E.79549
G1 X123.862 Y136.803 E.01211
G1 X123.958 Y136.978 E.00486
G1 X106.983 Y136.978 E.4129
G1 X107.213 Y136.312 E.01714
G1 X107.213 Y103.607 E.79552
G1 X107.168 Y103.226 E.00933
G1 X107.03 Y102.853 E.00967
G1 X106.919 Y102.77 E.00337
G1 X106.919 Y102.543 E.00552
G1 E-5 F3600
G1 X106.919 Y102.543 F9000
G1 X107.384 Y136.632
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.444708
G1 F1200
G1 X107.347 Y136.669 E.00143
G1 X107.361 Y136.718 E.00139
G1 X107.41 Y136.731 E.00138
G1 X107.447 Y136.695 E.00141
G1 X107.433 Y136.646 E.00139
;WIDTH:0.399999
G1 X107.487 Y136.223 E.01037
G1 X107.968 Y136.704 E.01655
G1 X108.485 Y136.704 E.01258
G1 X107.487 Y135.706 E.03433
G1 X107.487 Y135.189 E.01258
G1 X109.002 Y136.704 E.05211
G1 X109.52 Y136.704 E.0126
G1 X107.487 Y134.672 E.06992
G1 X107.487 Y134.154 E.0126
G1 X110.037 Y136.704 E.08772
G1 X110.554 Y136.704 E.01258
G1 X107.487 Y133.637 E.1055
G1 X107.487 Y133.12 E.01258
G1 X111.071 Y136.704 E.12329
G1 X111.588 Y136.704 E.01258
G1 X107.487 Y132.603 E.14107
G1 X107.487 Y132.086 E.01258
G1 X112.105 Y136.704 E.15886
G1 X112.622 Y136.704 E.01258
G1 X107.487 Y131.569 E.17664
G1 X107.487 Y131.052 E.01258
G1 X113.139 Y136.704 E.19443
G1 X113.139 Y136.704 F9000
G1 X112.087 Y135.134
G1 F1200
G1 X113.527 Y136.575 E.04955
G1 X113.527 Y136.704 E.00314
G1 X123.572 Y136.704 E.24433
G1 X123.513 Y136.304 E.00983
G1 X123.513 Y129.295 E.17049
;WIDTH:0.446251
G1 X123.49 Y129.21 E.00241
;WIDTH:0.492503
G1 X123.467 Y129.124 E.00271
;WIDTH:0.538755
G1 X123.444 Y129.039 E.00295
;WIDTH:0.585006
G1 X123.421 Y128.954 E.00323
;WIDTH:0.631258
G1 X123.397 Y128.868 E.00355
G1 X123.356 Y128.941 E.00332
;WIDTH:0.585006
G1 X123.315 Y129.015 E.0031
;WIDTH:0.538755
G1 X123.273 Y129.088 E.00283
;WIDTH:0.492503
G1 X123.232 Y129.161 E.00255
;WIDTH:0.446251
G1 X123.19 Y129.234 E.00231
;WIDTH:0.399999
G1 X122.887 Y129.999 E.02001
G1 X120.926 Y133.397 E.09543
G1 X120.583 Y133.836 E.01355
G1 X120.172 Y134.269 E.01452
G1 X119.816 Y134.565 E.01126
G1 X119.412 Y134.825 E.01169
G1 X119.009 Y135.021 E.0109
G1 X118.336 Y135.255 E.01733
G1 X117.873 Y135.356 E.01153
G1 X117.229 Y135.408 E.01572
G1 X113.771 Y135.408 E.08411
G1 X113.095 Y135.35 E.0165
G1 X112.32 Y135.158 E.01942
G1 X111.957 Y135.005 E.00958
G1 X111.957 Y135.005 F9000
G1 X113.327 Y135.787
;WIDTH:0.499473
G1 F1200
G1 X113.771 Y135.824 E.01379
G1 X117.229 Y135.824 E.10699
;WIDTH:0.500863
G1 X117.278 Y135.822 E.00152
;WIDTH:0.531731
G1 X117.964 Y135.779 E.02274
G1 X118.128 Y135.72 E.00577
;WIDTH:0.487821
G1 X118.292 Y135.66 E.00527
;WIDTH:0.44391
G1 X118.456 Y135.601 E.00475
;WIDTH:0.399999
G1 X119.13 Y135.366 E.01736
G1 X119.573 Y135.154 E.01195
G1 X120.014 Y134.872 E.01273
G1 X120.437 Y134.521 E.01337
G1 X120.914 Y134.019 E.01684
G1 X121.242 Y133.58 E.01333
G1 X123.147 Y130.28 E.09268
G1 X123.15 Y136.339 E.14738
G1 X118.47 Y136.339 E.11384
;WIDTH:0.442224
G1 X118.29 Y136.317 E.00492
;WIDTH:0.484449
G1 X118.109 Y136.296 E.00546
;WIDTH:0.526673
G1 X117.928 Y136.275 E.00597
G1 X117.229 Y136.289 E.0229
;WIDTH:0.499473
G1 X113.821 Y136.281 E.10545
G1 X113.457 Y135.917 E.01593
G1 E-5 F3600
G1 X113.457 Y135.917 F9000
G1 X110.446 Y133.678
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X109.892 Y132.999 E.01982
;WIDTH:0.399999
G1 X109.693 Y132.74 E.00794
G1 X107.487 Y130.535 E.07587
G1 X107.617 Y130.147 E.00995
G1 X108.975 Y131.505 E.04671
G1 X109.163 Y131.723 E.007
;WIDTH:0.374336
G1 X109.144 Y131.794 E.00166
G1 X109.215 Y131.775 E.00166
G1 X109.204 Y131.734 E.00096
G1 E-5 F3600
G1 X109.204 Y131.734 F9000
G1 X107.499 Y129.563
G1 E5 F2400
;WIDTH:0.424281
G1 F1200
G1 X107.499 Y129.744 E.0047
G1 X107.655 Y129.697 E.00423
G1 X107.754 Y129.751 E.00293
G1 X108.202 Y130.198 E.01642
G1 X107.821 Y129.298 E.02535
;WIDTH:0.467933
G1 X107.779 Y129.226 E.0024
;WIDTH:0.511586
G1 X107.736 Y129.155 E.00264
;WIDTH:0.555238
G1 X107.693 Y129.084 E.00288
;WIDTH:0.59889
G1 X107.651 Y129.013 E.0031
;WIDTH:0.642542
G1 X107.608 Y128.942 E.00336
G1 X107.586 Y129.029 E.00363
;WIDTH:0.59889
G1 X107.565 Y129.117 E.0034
;WIDTH:0.555238
G1 X107.543 Y129.205 E.00314
;WIDTH:0.511586
G1 X107.521 Y129.293 E.00288
;WIDTH:0.467933
G1 X107.499 Y129.38 E.00259
;WIDTH:0.399999
G1 X107.608 Y128.942 E.01098
;WIDTH:0.642542
G1 X107.584 Y128.539 E.01633
;WIDTH:0.593884
G1 X107.56 Y128.136 E.01503
;WIDTH:0.582208
G1 X107.578 Y127.666 E.01714
;WIDTH:0.61919
G1 X107.596 Y127.196 E.0183
;WIDTH:0.399999
G1 X107.508 Y126.525 E.01646
;WIDTH:0.491019
G1 X107.532 Y126.729 E.00624
;WIDTH:0.539241
G1 X107.557 Y126.934 E.00694
;WIDTH:0.587464
G1 X107.581 Y127.138 E.00756
;WIDTH:0.61919
G1 X107.596 Y127.196 E.00233
G1 X107.664 Y127.038 E.00669
;WIDTH:0.575352
G1 X107.731 Y126.88 E.00618
;WIDTH:0.531514
G1 X107.798 Y126.722 E.00568
;WIDTH:0.487676
G1 X107.865 Y126.564 E.00518
;WIDTH:0.443837
G1 X107.932 Y126.406 E.00467
;WIDTH:0.399999
G1 X108.22 Y125.793 E.01647
G1 X109.949 Y122.798 E.08412
G1 X110.229 Y122.417 E.0115
G1 X107.487 Y119.675 E.09432
G1 X107.487 Y126.343 E.16219
G1 X107.853 Y125.713 E.01772
G1 X107.853 Y120.558 E.12539
G1 X109.748 Y122.453 E.06519
G1 X109.632 Y122.615 E.00485
G1 X107.937 Y125.551 E.08246
G1 X107.937 Y125.551 F9000
G1 X108.218 Y124.333
G1 F1200
G1 X108.218 Y121.441 E.07035
G1 X109.277 Y122.499 E.03641
G1 X108.31 Y124.175 E.04707
G1 X108.31 Y124.175 F9000
G1 X108.74 Y122.526
;WIDTH:0.60999
G1 F1200
G1 X108.758 Y122.595 E.00273
G1 X108.708 Y122.646 E.00273
G1 X108.638 Y122.628 E.00277
G1 X108.619 Y122.558 E.00278
G1 X108.67 Y122.507 E.00276
G1 X108.67 Y122.507 F9000
G1 X110.453 Y122.124
;WIDTH:0.399999
G1 F1200
G1 X107.487 Y119.158 E.10203
G1 X107.487 Y118.641 E.01258
G1 X110.695 Y121.849 E.11035
G1 X110.979 Y121.615 E.00895
G1 X107.487 Y118.124 E.12011
G1 X107.487 Y117.606 E.0126
G1 X111.277 Y121.396 E.13037
G1 X111.584 Y121.186 E.00905
G1 X107.487 Y117.089 E.14093
G1 X107.487 Y116.572 E.01258
G1 X109.745 Y118.83 E.07767
G1 X109.944 Y119.089 E.00794
;WIDTH:0.374336
G1 X110.431 Y119.681 E.01734
G1 X111.066 Y120.325 E.02045
;WIDTH:0.397658
G1 X111.883 Y120.97 E.02516
;WIDTH:0.419142
G1 X111.934 Y121.005 E.00158
G1 E-5 F3600
G1 X111.934 Y121.005 F9000
G1 X109.256 Y117.823
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X109.267 Y117.864 E.00096
G1 X109.196 Y117.884 E.00167
G1 X109.215 Y117.812 E.00168
;WIDTH:0.399999
G1 X109.027 Y117.595 E.00698
G1 X107.587 Y116.155 E.04954
G1 X107.994 Y116.045 E.01026
G1 X108.309 Y116.36 E.01084
G1 X108.497 Y116.577 E.00698
;WIDTH:0.374336
G1 X108.478 Y116.648 E.00166
G1 X108.549 Y116.629 E.00166
G1 X108.538 Y116.588 E.00096
G1 X108.538 Y116.588 F9000
G1 X107.565 Y115.119
;WIDTH:0.55573
G1 F1200
G1 X107.543 Y115.206 E.00311
;WIDTH:0.513192
G1 X107.522 Y115.293 E.00285
;WIDTH:0.470655
G1 X107.501 Y115.38 E.0026
;WIDTH:0.428117
G1 X107.501 Y115.81 E.01126
G1 X107.796 Y115.707 E.00818
G1 X107.855 Y115.647 E.0022
G1 X107.959 Y115.647 E.00272
G1 X107.82 Y115.298 E.00984
;WIDTH:0.471002
G1 X107.777 Y115.227 E.00241
;WIDTH:0.513887
G1 X107.735 Y115.156 E.00263
;WIDTH:0.556772
G1 X107.693 Y115.084 E.0029
;WIDTH:0.599657
G1 X107.65 Y115.013 E.00312
;WIDTH:0.642542
G1 X107.608 Y114.942 E.00334
G1 X107.584 Y114.539 E.01633
;WIDTH:0.593883
G1 X107.56 Y114.136 E.01503
;WIDTH:0.582204
G1 X107.578 Y113.666 E.01714
;WIDTH:0.619184
G1 X107.596 Y113.196 E.0183
;WIDTH:0.399999
G1 X107.508 Y112.525 E.01646
;WIDTH:0.491016
G1 X107.532 Y112.729 E.00624
;WIDTH:0.539238
G1 X107.557 Y112.934 E.00694
;WIDTH:0.58746
G1 X107.581 Y113.138 E.00756
;WIDTH:0.619184
G1 X107.596 Y113.196 E.00233
G1 X107.664 Y113.038 E.00669
;WIDTH:0.575347
G1 X107.731 Y112.88 E.00618
;WIDTH:0.53151
G1 X107.798 Y112.722 E.00568
;WIDTH:0.487673
G1 X107.865 Y112.564 E.00518
;WIDTH:0.443836
G1 X107.932 Y112.406 E.00467
;WIDTH:0.399999
G1 X108.22 Y111.793 E.01647
G1 X109.949 Y108.798 E.08412
G1 X110.213 Y108.438 E.01086
G1 X107.487 Y105.713 E.09376
G1 X107.487 Y112.343 E.16127
G1 X107.853 Y111.713 E.01772
G1 X107.853 Y106.595 E.12449
G1 X109.732 Y108.475 E.06465
G1 X109.632 Y108.615 E.00418
G1 X107.937 Y111.551 E.08246
G1 X107.937 Y111.551 F9000
G1 X108.218 Y110.333
G1 F1200
G1 X108.218 Y107.478 E.06945
G1 X109.263 Y108.523 E.03595
G1 X108.31 Y110.175 E.04639
G1 X108.31 Y110.175 F9000
G1 X108.733 Y108.55
;WIDTH:0.59775
G1 F1200
G1 X108.751 Y108.618 E.00264
G1 X108.701 Y108.668 E.00265
G1 X108.633 Y108.649 E.00265
G1 X108.615 Y108.581 E.00264
G1 X108.665 Y108.532 E.00262
G1 X108.665 Y108.532 F9000
G1 X110.436 Y108.145
;WIDTH:0.399999
G1 F1200
G1 X107.487 Y105.195 E.10146
G1 X107.361 Y105.025 E.00515
;WIDTH:0.374336
G1 X107.372 Y105.066 E.00096
G1 X107.301 Y105.085 E.00166
G1 X107.32 Y105.014 E.00166
;WIDTH:0.399999
G1 X107.487 Y104.678 E.00913
G1 X110.677 Y107.868 E.10973
G1 X110.957 Y107.631 E.00892
G1 X107.487 Y104.161 E.11937
G1 X107.487 Y103.644 E.01258
G1 X111.255 Y107.412 E.12962
G1 X111.559 Y107.199 E.00903
G1 X107.397 Y103.037 E.14317
G1 X107.226 Y102.778 E.00755
;WIDTH:0.374336
G1 X107.13 Y102.68 E.0031
;WIDTH:0.399999
G1 X107.194 Y102.316 E.00899
G1 X109.797 Y104.92 E.08956
G1 X110.003 Y105.178 E.00803
;WIDTH:0.374336
G1 X110.417 Y105.685 E.0148
G1 X111.059 Y106.336 E.02068
;WIDTH:0.399478
G1 X111.467 Y106.659 E.01264
;WIDTH:0.42462
G1 X111.876 Y106.981 E.01351
;WIDTH:0.438826
G1 X111.911 Y107.006 E.00116
G1 E-5 F3600
G1 X111.911 Y107.006 F9000
G1 X109.267 Y103.902
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X109.248 Y103.973 E.00166
G1 X109.319 Y103.954 E.00166
G1 X109.308 Y103.913 E.00096
;WIDTH:0.399999
G1 X107.265 Y101.871 E.07026
G1 X107.074 Y101.732 E.00575
;WIDTH:0.374336
G1 X107.061 Y101.885 E.00347
G1 E-5 F3600
G1 X107.061 Y101.885 F9000
G1 X107.485 Y98.459
G1 E5 F2400
;WIDTH:0.397848
G1 F1200
G1 X107.482 Y98.697 E.00576
;WIDTH:0.395044
G1 X107.374 Y99.213 E.01265
;WIDTH:0.410544
G1 X107.295 Y99.467 E.00666
;WIDTH:0.447056
G1 X107.217 Y99.72 E.00727
;WIDTH:0.48446
G1 X107.236 Y100.943 E.03662
;WIDTH:0.490065
G1 X107.239 Y101.432 E.01482
G1 X107.542 Y101.218 E.01125
G1 X107.779 Y101.269 E.00735
G1 X107.684 Y100.916 E.01108
;WIDTH:0.48446
G1 X107.613 Y100.13 E.02363
;WIDTH:0.437019
G1 X107.649 Y99.743 E.01041
;WIDTH:0.409425
G1 X107.685 Y99.356 E.0097
;WIDTH:0.395044
G1 X107.835 Y98.768 E.01456
;WIDTH:0.399999
G1 X107.942 Y98.379 E.00981
G1 X108.22 Y97.793 E.01578
G1 X109.949 Y94.798 E.08412
G1 X110.519 Y94.04 E.02307
G1 X110.866 Y93.689 E.01201
G1 X111.262 Y93.38 E.01222
G1 X111.646 Y93.149 E.0109
G1 X112.276 Y92.864 E.01682
G1 X112.754 Y92.718 E.01216
G1 X113.771 Y92.592 E.02493
G1 X117.468 Y92.603 E.08993
G1 X118.307 Y92.731 E.02064
G1 X119.067 Y92.993 E.01955
G1 X117.504 Y91.425 E.05385
G1 X117.504 Y91.296 E.00314
G1 X107.428 Y91.296 E.24509
G1 X107.487 Y91.696 E.00983
G1 X107.487 Y98.276 E.16005
G1 X107.852 Y97.714 E.0163
G1 X107.85 Y91.661 E.14723
G1 X112.062 Y91.661 E.10245
;WIDTH:0.441319
G1 X112.213 Y91.682 E.00413
;WIDTH:0.482639
G1 X112.364 Y91.703 E.00455
;WIDTH:0.523959
G1 X112.515 Y91.723 E.00496
;WIDTH:0.565278
G1 X112.665 Y91.744 E.00535
G1 X113.166 Y91.728 E.0177
;WIDTH:0.534003
G1 X113.667 Y91.713 E.01666
;WIDTH:0.502727
G1 X113.771 Y91.711 E.00324
;WIDTH:0.504443
G1 X117.209 Y91.714 E.10751
G1 X117.703 Y92.214 E.02198
G1 X117.104 Y92.184 E.01876
G1 X113.772 Y92.176 E.1042
;WIDTH:0.502727
G1 X113.696 Y92.179 E.00237
;WIDTH:0.534003
G1 X113.197 Y92.226 E.01666
;WIDTH:0.565278
G1 X112.698 Y92.273 E.0177
G1 X112.598 Y92.318 E.00387
;WIDTH:0.520234
G1 X112.44 Y92.389 E.0056
;WIDTH:0.480156
G1 X112.283 Y92.46 E.00511
;WIDTH:0.440078
G1 X112.125 Y92.531 E.00468
;WIDTH:0.399999
G1 X111.495 Y92.816 E.01682
G1 X111.018 Y93.105 E.01357
G1 X110.592 Y93.445 E.01326
G1 X110.231 Y93.814 E.01256
G1 X109.632 Y94.615 E.02433
G1 X107.937 Y97.552 E.08248
G1 X107.937 Y97.552 F9000
G1 X108.218 Y96.334
G1 F1200
G1 X108.218 Y92.027 E.10476
G1 X112.503 Y92.027 E.10423
G1 X111.974 Y92.198 E.01352
G1 X111.247 Y92.534 E.01948
G1 X110.793 Y92.817 E.01301
G1 X110.333 Y93.186 E.01434
G1 X109.943 Y93.589 E.01364
G1 X109.316 Y94.433 E.02557
G1 X108.309 Y96.175 E.04894
G1 X108.309 Y96.175 F9000
G1 X108.584 Y94.969
G1 F1200
G1 X108.584 Y92.393 E.06266
G1 X110.775 Y92.393 E.05329
G1 X110.567 Y92.53 E.00606
G1 X110.075 Y92.927 E.01538
G1 X109.656 Y93.363 E.01471
G1 X108.999 Y94.25 E.02685
G1 X108.675 Y94.811 E.01576
G1 X108.675 Y94.811 F9000
G1 X108.975 Y93.596
;WIDTH:0.451407
G1 F1200
G1 X108.975 Y92.784 E.02253
G1 X109.664 Y92.784 E.01912
G1 X109.362 Y93.104 E.01221
G1 X109.088 Y93.453 E.01231
G1 E-5 F3600
G1 X109.088 Y93.453 F9000
G1 X107.607 Y101.695
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X108.361 Y102.45 E.02595
G1 X108.549 Y102.667 E.00698
;WIDTH:0.374336
G1 X108.53 Y102.738 E.00166
G1 X108.601 Y102.719 E.00166
G1 X108.59 Y102.678 E.00096
G1 E-5 F3600
G1 X109.049 Y99.553 F9000
G1 X109.094 Y99.321
G1 X109.104 Y99.275
G1 X109.171 Y99.049
G1 X109.185 Y99.003
G1 X109.272 Y98.784
G1 X109.291 Y98.741
G1 X109.399 Y98.531
G1 X109.415 Y98.5
G1 X111.159 Y95.48
G1 X111.177 Y95.451
G1 X111.305 Y95.252
G1 X111.334 Y95.215
G1 X111.479 Y95.029
G1 X111.511 Y94.994
G1 X111.674 Y94.824
G1 X111.709 Y94.791
G1 X111.887 Y94.637
G1 X111.925 Y94.608
G1 X112.117 Y94.471
G1 X112.157 Y94.446
G1 X112.361 Y94.328
G1 X112.403 Y94.306
G1 X112.618 Y94.208
G1 X112.662 Y94.19
G1 X112.885 Y94.113
G1 X112.93 Y94.098
G1 X113.159 Y94.043
G1 X113.206 Y94.033
G1 X113.439 Y93.999
G1 X113.486 Y93.993
G1 X119.443 Y93.274
G1 E5 F2400
G1 F1200
G1 X119.995 Y93.74 E.01634
G1 E-5 F3600
G1 X119.995 Y93.74 F9000
G1 X121.815 Y99.003
G1 X121.829 Y99.049
G1 X121.896 Y99.275
G1 X121.906 Y99.321
G1 X121.951 Y99.553
G1 X121.957 Y99.6
G1 X121.979 Y99.835
G1 X123.392 Y127.173
G1 E5 F2400
;WIDTH:0.614786
G1 F1200
G1 X123.303 Y126.966 E.0087
;WIDTH:0.566892
G1 X123.213 Y126.758 E.00803
;WIDTH:0.518998
G1 X123.124 Y126.551 E.00726
;WIDTH:0.471104
G1 X123.035 Y126.344 E.00655
;WIDTH:0.423209
G1 X123.184 Y126.349 E.00386
G1 X123.264 Y126.27 E.00291
G1 X123.502 Y126.187 E.00652
G1 X123.501 Y126.669 E.01247
;WIDTH:0.464454
G1 X123.478 Y126.777 E.00316
;WIDTH:0.505699
G1 X123.454 Y126.886 E.0035
;WIDTH:0.546944
G1 X123.431 Y126.995 E.0038
;WIDTH:0.585863
G1 X123.416 Y127.093 E.00364
;WIDTH:0.624782
G1 X123.402 Y127.216 E.00486
;WIDTH:0.621492
G1 X123.421 Y127.676 E.01798
;WIDTH:0.583473
G1 X123.44 Y128.135 E.01678
;WIDTH:0.588356
G1 X123.419 Y128.502 E.01355
;WIDTH:0.631258
G1 X123.397 Y128.868 E.01456
G1 E-5 F3600
G1 X123.397 Y128.868 F9000
G1 X118.664 Y135.973
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X122.782 Y135.973 E.10017
G1 X122.782 Y131.645 E.10527
G1 X121.559 Y133.762 E.05947
G1 X121.248 Y134.189 E.01285
G1 X120.702 Y134.773 E.01945
G1 X120.3 Y135.115 E.01284
G1 X119.829 Y135.428 E.01376
G1 X119.351 Y135.669 E.01302
G1 X118.481 Y135.973 E.02242
G1 X118.481 Y135.973 F9000
G1 X120.225 Y135.607
G1 F1200
G1 X120.534 Y135.397 E.00909
G1 X120.967 Y135.025 E.01389
G1 X121.541 Y134.408 E.0205
G1 X121.876 Y133.945 E.0139
G1 X122.416 Y133.009 E.02628
G1 X122.416 Y135.607 E.06319
G1 X120.408 Y135.607 E.04884
G1 X120.408 Y135.607 F9000
G1 X121.328 Y135.215
;WIDTH:0.452802
G1 F1200
G1 X121.663 Y134.862 E.01355
G1 X122.024 Y134.417 E.01595
G1 X122.024 Y135.215 E.02221
G1 X121.51 Y135.215 E.01431
G1 E-5 F3600
G1 X121.51 Y135.215 F9000
G1 X123.06 Y125.94
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X122.595 Y125.475 E.016
G1 X122.426 Y125.186 E.00814
;WIDTH:0.374336
G1 X122.437 Y125.227 E.00096
G1 X122.366 Y125.246 E.00166
G1 X122.385 Y125.175 E.00166
G1 X122.385 Y125.175 F9000
G1 X123.468 Y125.83
;WIDTH:0.399999
G1 F1200
G1 X121.877 Y124.24 E.05471
G1 X121.708 Y123.951 E.00814
;WIDTH:0.374336
G1 X121.719 Y123.992 E.00096
G1 X121.648 Y124.011 E.00166
G1 X121.667 Y123.94 E.00166
G1 E-5 F3600
G1 X121.667 Y123.94 F9000
G1 X123.513 Y125.359
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X121.159 Y123.005 E.08098
G1 X120.955 Y122.746 E.00802
;WIDTH:0.374336
G1 X120.164 Y121.856 E.02693
G1 X119.413 Y121.214 E.02235
;WIDTH:0.417676
G1 X119.264 Y121.109 E.00465
;WIDTH:0.461016
G1 X119.115 Y121.004 E.00517
;WIDTH:0.399999
G1 X119.46 Y120.789 E.00989
G1 X123.513 Y124.841 E.1394
G1 X123.513 Y124.324 E.01258
G1 X119.778 Y120.589 E.12848
G1 X120.071 Y120.365 E.00897
G1 X123.513 Y123.807 E.1184
G1 X123.513 Y123.29 E.01258
G1 X120.327 Y120.104 E.1096
G1 X120.58 Y119.84 E.00889
G1 X123.513 Y122.773 E.10089
G1 E-5 F3600
G1 X123.513 Y122.773 F9000
G1 X120.817 Y119.544
G1 E5 F2400
G1 F1200
G1 X123.513 Y122.256 E.09302
G1 X123.513 Y115.295 E.16932
;WIDTH:0.446251
G1 X123.49 Y115.21 E.00241
;WIDTH:0.492504
G1 X123.467 Y115.124 E.00271
;WIDTH:0.538756
G1 X123.444 Y115.039 E.00295
;WIDTH:0.585008
G1 X123.421 Y114.954 E.00323
;WIDTH:0.63126
G1 X123.397 Y114.868 E.00355
G1 X123.356 Y114.941 E.00332
;WIDTH:0.585008
G1 X123.315 Y115.015 E.0031
;WIDTH:0.538756
G1 X123.273 Y115.088 E.00283
;WIDTH:0.492504
G1 X123.232 Y115.161 E.00255
;WIDTH:0.446251
G1 X123.19 Y115.234 E.00231
;WIDTH:0.399999
G1 X122.887 Y115.999 E.02001
G1 X120.926 Y119.397 E.09543
G1 X121.283 Y119.509 E.0091
G1 X123.147 Y116.28 E.09069
G1 X123.147 Y121.373 E.12388
G1 X121.413 Y119.638 E.05967
G1 X121.74 Y119.449 E.00919
G1 X122.782 Y117.645 E.05067
G1 X122.782 Y120.49 E.0692
G1 X121.869 Y119.578 E.03139
G1 X122.301 Y119.305 E.01243
;WIDTH:0.594632
G1 X122.251 Y119.354 E.00261
G1 X122.269 Y119.422 E.00262
G1 X122.337 Y119.44 E.00262
G1 X122.386 Y119.391 E.00258
G1 X122.368 Y119.323 E.00262
G1 E-5 F3600
G1 X122.368 Y119.323 F9000
G1 E5 F2400
;WIDTH:0.63126
G1 F1200
G1 X123.419 Y114.502 E.01456
;WIDTH:0.588357
G1 X123.44 Y114.135 E.01355
;WIDTH:0.583472
G1 X123.421 Y113.676 E.01678
;WIDTH:0.62149
G1 X123.402 Y113.216 E.01798
;WIDTH:0.62478
G1 X123.415 Y113.093 E.00486
;WIDTH:0.586327
G1 X123.43 Y112.994 E.00368
;WIDTH:0.547875
G1 X123.454 Y112.886 E.00378
;WIDTH:0.507156
G1 X123.477 Y112.777 E.0035
;WIDTH:0.466437
G1 X123.5 Y112.669 E.00317
;WIDTH:0.425718
G1 X123.5 Y112.394 E.00716
G1 X123.566 Y112.186 E.00568
;WIDTH:0.400027
G1 X123.631 Y111.978 E.0053
;WIDTH:0.386577
G1 X123.592 Y112.06 E.00213
;WIDTH:0.425718
G1 X123.169 Y112.345 E.01328
G1 X123.037 Y112.346 E.00344
;WIDTH:0.473016
G1 X123.126 Y112.553 E.00658
;WIDTH:0.520313
G1 X123.215 Y112.759 E.00725
;WIDTH:0.567611
G1 X123.303 Y112.966 E.00798
;WIDTH:0.614908
G1 X123.392 Y113.173 E.0087
G1 X123.392 Y113.173 F9000
G1 X123.031 Y111.948
;WIDTH:0.399999
G1 F1200
G1 X122.647 Y111.565 E.01319
G1 X122.478 Y111.276 E.00814
;WIDTH:0.374336
G1 X122.489 Y111.317 E.00096
G1 X122.418 Y111.336 E.00166
G1 X122.437 Y111.265 E.00166
G1 X122.437 Y111.265 F9000
G1 F1200
G1 X123.645 Y111.812 E.00377
;WIDTH:0.399999
G1 X123.438 Y111.838 E.00507
G1 X121.929 Y110.33 E.05189
G1 X121.76 Y110.041 E.00814
;WIDTH:0.374336
G1 X121.771 Y110.082 E.00096
G1 X121.7 Y110.101 E.00166
G1 X121.719 Y110.03 E.00166
G1 E-5 F3600
G1 X121.719 Y110.03 F9000
G1 X123.513 Y111.396
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X121.211 Y109.094 E.07919
G1 X121.008 Y108.836 E.00799
;WIDTH:0.374336
G1 X120.639 Y108.377 E.01332
G1 X120.086 Y107.802 E.01804
G1 X119.404 Y107.224 E.02022
;WIDTH:0.407938
G1 X119.247 Y107.114 E.00476
;WIDTH:0.44154
G1 X119.091 Y107.003 E.00519
;WIDTH:0.399999
G1 X119.437 Y106.803 E.00972
G1 X123.513 Y110.879 E.14021
G1 X123.513 Y110.362 E.01258
G1 X119.755 Y106.604 E.12927
G1 X120.05 Y106.382 E.00898
G1 X123.513 Y109.845 E.11912
G1 X123.513 Y109.328 E.01258
G1 X120.309 Y106.123 E.11023
G1 X120.561 Y105.859 E.00888
G1 X123.513 Y108.811 E.10155
G1 E-5 F3600
G1 X123.513 Y108.811 F9000
G1 X120.817 Y105.544
G1 E5 F2400
G1 F1200
G1 X120.794 Y105.575 E.00094
G1 X123.513 Y108.293 E.09351
G1 X123.513 Y103.613 E.11384
G1 X123.577 Y103.122 E.01204
G1 X123.735 Y102.715 E.01062
G1 X123.806 Y102.637 E.00257
G1 X123.806 Y101.283 E.03293
;WIDTH:0.439993
G1 X123.786 Y101.084 E.0054
;WIDTH:0.479984
G1 X123.766 Y100.886 E.0059
G1 X123.788 Y100.152 E.02177
;WIDTH:0.451982
G1 X123.78 Y99.64 E.01423
G1 X123.691 Y99.4 E.00711
;WIDTH:0.409959
G1 X123.601 Y99.159 E.00643
;WIDTH:0.390437
G1 X123.52 Y98.663 E.0119
;WIDTH:0.428581
G1 X123.499 Y98.19 E.01242
G1 X123.199 Y98.295 E.00834
G1 X123.14 Y98.354 E.00219
G1 X123.042 Y98.354 E.00257
G1 X123.17 Y98.729 E.01039
;WIDTH:0.390437
G1 X123.275 Y99.22 E.01189
;WIDTH:0.409694
G1 X123.319 Y99.479 E.00656
;WIDTH:0.451982
G1 X123.364 Y99.739 E.00733
G1 X123.387 Y100.129 E.01085
;WIDTH:0.479984
G1 X123.322 Y100.86 E.02176
G1 X123.111 Y101.417 E.01766
;WIDTH:0.439992
G1 X122.899 Y101.975 E.01611
;WIDTH:0.399999
G1 X120.926 Y105.397 E.09608
G1 X121.269 Y105.533 E.00898
G1 X122.535 Y103.341 E.06157
;WIDTH:0.434535
G1 X122.859 Y102.814 E.01647
G1 X123.238 Y102.108 E.02133
;WIDTH:0.397538
G1 X123.442 Y101.59 E.01345
G1 X123.418 Y102.535 E.02284
;WIDTH:0.435519
G1 X123.216 Y102.994 E.01338
G1 X123.147 Y103.613 E.01662
;WIDTH:0.399999
G1 X123.147 Y107.411 E.09238
G1 X121.399 Y105.662 E.06015
G1 X121.726 Y105.473 E.00919
G1 X122.782 Y103.645 E.05135
G1 X122.782 Y106.528 E.07013
G1 X121.856 Y105.602 E.03185
G1 X122.294 Y105.326 E.01259
;WIDTH:0.606868
G1 X122.244 Y105.377 E.00272
G1 X122.262 Y105.446 E.00272
G1 X122.331 Y105.464 E.00272
G1 X122.382 Y105.414 E.00272
G1 X122.363 Y105.345 E.00273
G1 E-5 F3600
G1 X122.363 Y105.345 F9000
G1 X123.001 Y97.956
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X122.7 Y97.655 E.01035
G1 X122.531 Y97.366 E.00814
;WIDTH:0.374336
G1 X122.542 Y97.407 E.00096
G1 X122.471 Y97.426 E.00166
G1 X122.49 Y97.355 E.00166
G1 X122.49 Y97.355 F9000
G1 X123.408 Y97.846
;WIDTH:0.399999
G1 F1200
G1 X121.982 Y96.419 E.04907
G1 X121.813 Y96.131 E.00812
;WIDTH:0.374336
G1 X121.824 Y96.172 E.00096
G1 X121.752 Y96.191 E.00168
G1 X121.772 Y96.12 E.00167
G1 X121.772 Y96.12 F9000
G1 X120.837 Y94.631
G1 F1200
G1 X121.065 Y94.926 E.00843
;WIDTH:0.399999
G1 X121.264 Y95.184 E.00793
G1 X123.513 Y97.434 E.07738
G1 X123.513 Y96.917 E.01258
G1 X117.892 Y91.296 E.19336
G1 X118.409 Y91.296 E.01258
G1 X123.513 Y96.4 E.17557
G1 X123.513 Y95.882 E.0126
G1 X118.926 Y91.296 E.15777
G1 X119.444 Y91.296 E.0126
G1 X123.513 Y95.365 E.13997
G1 X123.513 Y94.848 E.01258
G1 X119.961 Y91.296 E.12219
G1 X120.478 Y91.296 E.01258
G1 X123.513 Y94.331 E.1044
G1 X123.513 Y93.814 E.01258
G1 X120.995 Y91.296 E.08662
G1 X121.512 Y91.296 E.01258
G1 X123.513 Y93.297 E.06883
G1 X123.513 Y92.78 E.01258
G1 X122.029 Y91.296 E.05105
G1 X122.546 Y91.296 E.01258
G1 X123.513 Y92.263 E.03326
G1 X123.513 Y91.745 E.0126
G1 X123.063 Y91.296 E.01546
G1 X123.602 Y91.262 E.01314
;WIDTH:0.428146
G1 X123.58 Y91.345 E.00225
G1 X123.662 Y91.323 E.00222
G1 X123.649 Y91.275 E.0013
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X123.662 Y91.323 E-.02362
G1 X123.58 Y91.345 E-.04033
G1 X123.602 Y91.262 E-.04079
G1 X123.063 Y91.296 E-.25653
G1 X123.513 Y91.745 E-.30195
G1 X123.513 Y92.263 E-.24605
G1 X122.634 Y91.383 E-.59073
;WIPE_END
G1 X122.191 Y89.908 F9000
G1 X121.664 Y88.151
G1 X121.198 Y86.599
G1 X121.199 Y85.151
G1 X120.864 Y85.486
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X120.721 Y85.3 E.00571
G1 X120.667 Y85.292 E.00133
G1 X110.333 Y85.292 E.25136
G1 X110.279 Y85.3 E.00133
G1 X110.15 Y85.5 E.00579
G1 X104.557 Y85.5 E.13604
G1 X103.986 Y85.457 E.01393
G1 X103.438 Y85.333 E.01367
G1 X102.65 Y84.99 E.0209
G1 X101.966 Y84.484 E.0207
G1 X101.411 Y83.839 E.0207
G1 X101.118 Y83.328 E.01433
G1 X100.858 Y82.589 E.01906
G1 X100.761 Y81.982 E.01495
G1 X100.75 Y78.688 E.08012
G1 X100.706 Y78.57 E.00306
G1 X100.37 Y78.176 E.0126
G1 X100.114 Y77.73 E.01251
G1 X100.089 Y77.416 E.00766
G1 X100.194 Y77.091 E.00831
G1 X100.599 Y76.559 E.01626
G1 X130.401 Y76.559 E.7249
G1 X130.803 Y77.087 E.01614
G1 X130.925 Y77.486 E.01015
G1 X130.886 Y77.73 E.00601
G1 X130.63 Y78.177 E.01253
G1 X130.294 Y78.57 E.01258
G1 X130.25 Y78.688 E.00306
G1 X130.239 Y81.982 E.08012
G1 X130.154 Y82.544 E.01383
G1 X129.987 Y83.088 E.01384
G1 X129.74 Y83.601 E.01385
G1 X129.419 Y84.071 E.01384
G1 X129.034 Y84.485 E.01375
G1 X128.591 Y84.839 E.01379
G1 X128.125 Y85.11 E.01311
G1 X127.288 Y85.406 E.02159
G1 X126.733 Y85.489 E.01365
G1 X120.918 Y85.5 E.14144
G1 X120.918 Y85.5 F9000
G1 X120.987 Y85.134
;TYPE:Perimeter
G1 F6000
G1 X120.964 Y85.134 E.00056
G1 X120.828 Y84.951 E.00555
G1 X120.667 Y84.926 E.00396
G1 X110.333 Y84.926 E.25136
G1 X110.171 Y84.951 E.00399
G1 X110.036 Y85.134 E.00553
G1 X104.571 Y85.134 E.13293
G1 X104.041 Y85.095 E.01293
G1 X103.552 Y84.984 E.0122
G1 X102.834 Y84.671 E.01905
G1 X102.216 Y84.215 E.01868
G1 X101.711 Y83.627 E.01885
G1 X101.452 Y83.175 E.01267
G1 X101.214 Y82.499 E.01743
G1 X101.127 Y81.952 E.01347
G1 X101.116 Y78.687 E.07942
G1 X101.089 Y78.521 E.00409
G1 X100.984 Y78.332 E.00526
G1 X100.71 Y78.011 E.01027
G1 X100.452 Y77.563 E.01258
G1 X100.477 Y77.361 E.00495
G1 X100.78 Y76.925 E.01291
G1 X130.22 Y76.925 E.7161
G1 X130.434 Y77.206 E.00859
G1 X130.56 Y77.5 E.00778
G1 X130.36 Y77.912 E.01114
G1 X130.016 Y78.332 E.01321
G1 X129.911 Y78.521 E.00526
G1 X129.884 Y78.687 E.00409
G1 X129.874 Y81.705 E.07341
G1 X129.835 Y82.211 E.01234
G1 X129.721 Y82.71 E.01245
G1 X129.531 Y83.191 E.01258
G1 X129.272 Y83.637 E.01255
G1 X128.95 Y84.039 E.01253
G1 X128.548 Y84.405 E.01322
G1 X127.97 Y84.776 E.01671
G1 X127.199 Y85.049 E.01989
G1 X126.705 Y85.123 E.01215
G1 X121.047 Y85.134 E.13763
G1 X121.047 Y85.134 F9000
G1 X121.238 Y84.768
G1 F6000
G1 X121.059 Y84.768 E.00435
G1 X120.936 Y84.601 E.00504
G1 X120.667 Y84.561 E.00662
G1 X110.333 Y84.561 E.25136
G1 X110.063 Y84.602 E.00664
G1 X109.939 Y84.769 E.00506
G1 X105.228 Y84.769 E.11459
G1 X104.289 Y84.747 E.02285
G1 X103.667 Y84.635 E.01537
G1 X103.018 Y84.352 E.01722
G1 X102.466 Y83.945 E.01668
G1 X102.011 Y83.415 E.01699
G1 X101.785 Y83.022 E.01103
G1 X101.57 Y82.409 E.0158
G1 X101.492 Y81.922 E.012
G1 X101.481 Y78.686 E.07871
G1 X101.437 Y78.409 E.00682
G1 X101.262 Y78.095 E.00874
G1 X100.988 Y77.774 E.01027
G1 X100.819 Y77.49 E.00804
G1 X100.961 Y77.29 E.00597
G1 X130.039 Y77.29 E.70729
G1 X130.175 Y77.501 E.00611
G1 X130.116 Y77.603 E.00287
G1 X129.738 Y78.095 E.01509
G1 X129.563 Y78.409 E.00874
G1 X129.519 Y78.686 E.00682
G1 X129.508 Y81.926 E.07881
G1 X129.371 Y82.603 E.0168
G1 X129.105 Y83.234 E.01666
G1 X128.696 Y83.775 E.0165
G1 X128.32 Y84.119 E.0124
G1 X127.816 Y84.443 E.01457
G1 X127.11 Y84.693 E.01822
G1 X126.677 Y84.758 E.01065
G1 X121.298 Y84.767 E.13084
G1 X121.298 Y84.767 F9000
G1 X121.499 Y84.401
G1 F6000
G1 X121.154 Y84.402 E.00839
G1 X121.043 Y84.252 E.00454
G1 X120.667 Y84.195 E.00925
G1 X110.333 Y84.195 E.25136
G1 X109.955 Y84.252 E.0093
G1 X109.843 Y84.403 E.00457
G1 X105.228 Y84.403 E.11226
G1 X104.316 Y84.382 E.02219
G1 X103.782 Y84.286 E.0132
G1 X103.202 Y84.033 E.01539
G1 X102.717 Y83.675 E.01466
G1 X102.439 Y83.352 E.01037
G1 X102.119 Y82.869 E.01409
G1 X101.926 Y82.319 E.01418
G1 X101.858 Y81.893 E.01049
G1 X101.847 Y78.684 E.07806
G1 X101.786 Y78.297 E.00953
G1 X101.54 Y77.858 E.01224
G1 X101.368 Y77.656 E.00645
G1 X129.632 Y77.656 E.68749
G1 X129.46 Y77.858 E.00645
G1 X129.214 Y78.297 E.01224
G1 X129.153 Y78.684 E.00953
G1 X129.143 Y81.702 E.07341
G1 X129.082 Y82.299 E.0146
G1 X128.873 Y82.873 E.01486
G1 X128.559 Y83.385 E.01461
G1 X128.092 Y83.833 E.01574
G1 X127.662 Y84.11 E.01244
G1 X127.021 Y84.336 E.01653
G1 X126.65 Y84.392 E.00913
G1 X121.559 Y84.401 E.12383
G1 X121.559 Y84.401 F9000
G1 X121.763 Y84.035
G1 F6000
G1 X121.25 Y84.036 E.01248
G1 X121.151 Y83.902 E.00405
G1 X120.667 Y83.829 E.01191
G1 X110.333 Y83.829 E.25136
G1 X109.847 Y83.903 E.01196
G1 X109.747 Y84.037 E.00407
G1 X104.43 Y84.024 E.12933
G1 X103.896 Y83.937 E.01316
G1 X103.386 Y83.715 E.01353
G1 X102.967 Y83.405 E.01268
G1 X102.53 Y82.851 E.01716
G1 X102.348 Y82.416 E.01147
G1 X102.223 Y81.863 E.01379
G1 X102.213 Y78.683 E.07735
G1 X102.134 Y78.185 E.01226
G1 X102.042 Y78.022 E.00455
G1 X128.958 Y78.022 E.6547
G1 X128.866 Y78.185 E.00455
G1 X128.787 Y78.683 E.01226
G1 X128.779 Y81.035 E.05721
G1 X128.75 Y82.048 E.02465
G1 X128.621 Y82.552 E.01265
G1 X128.366 Y83.019 E.01294
G1 X128.037 Y83.41 E.01243
G1 X127.651 Y83.693 E.01164
G1 X127.1 Y83.921 E.0145
G1 X126.622 Y84.026 E.0119
G1 X121.823 Y84.035 E.11673
G1 E-5 F3600
G1 X121.823 Y84.035 F9000
G1 X102.746 Y82.898
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.374336
G1 F1200
G1 X103.092 Y83.271 E.01151
G1 X103.458 Y83.586 E.01092
G1 X103.458 Y83.586 F9000
G1 X104.353 Y83.876
G1 F1200
G1 X103.955 Y83.789 E.00921
;WIDTH:0.399999
G1 X103.808 Y83.599 E.00584
G1 X102.645 Y82.437 E.03999
G1 X102.497 Y81.771 E.01659
G1 X104.478 Y83.752 E.06815
G1 X105.006 Y83.763 E.01285
G1 X102.496 Y81.253 E.08634
G1 X102.494 Y80.734 E.01262
G1 X105.523 Y83.763 E.1042
G1 X106.04 Y83.763 E.01258
G1 X102.492 Y80.215 E.12205
G1 X102.49 Y79.696 E.01262
G1 X106.557 Y83.763 E.1399
G1 X107.075 Y83.763 E.0126
G1 X102.489 Y79.177 E.15776
G1 X102.484 Y78.655 E.0127
G1 X107.592 Y83.763 E.17571
G1 X108.109 Y83.763 E.01258
G1 X102.642 Y78.296 E.18806
G1 X102.383 Y78.202 E.0067
;WIDTH:0.374336
G1 X102.394 Y78.244 E.00098
G1 X102.323 Y78.263 E.00166
G1 X102.342 Y78.191 E.00168
G1 X102.342 Y78.191 F9000
G1 X103.159 Y78.296
;WIDTH:0.399999
G1 F1200
G1 X108.626 Y83.763 E.18806
G1 X109.143 Y83.763 E.01258
G1 X103.676 Y78.296 E.18806
G1 X104.193 Y78.296 E.01258
G1 X109.656 Y83.759 E.18792
G1 X110.001 Y83.587 E.00938
G1 X104.71 Y78.296 E.18201
G1 X105.227 Y78.296 E.01258
G1 X110.487 Y83.555 E.18092
G1 X111.004 Y83.555 E.01258
G1 X105.744 Y78.296 E.18092
G1 X106.261 Y78.296 E.01258
G1 X111.521 Y83.555 E.18092
G1 X112.038 Y83.555 E.01258
G1 X106.779 Y78.296 E.18091
G1 X107.296 Y78.296 E.01258
G1 X112.555 Y83.555 E.18091
G1 X113.072 Y83.555 E.01258
G1 X107.813 Y78.296 E.18091
G1 X108.33 Y78.296 E.01258
G1 X113.589 Y83.555 E.18091
G1 X114.106 Y83.555 E.01258
G1 X108.847 Y78.296 E.18091
G1 X109.364 Y78.296 E.01258
G1 X114.624 Y83.555 E.18092
G1 X115.141 Y83.555 E.01258
G1 X109.881 Y78.296 E.18092
G1 X110.398 Y78.296 E.01258
G1 X115.658 Y83.555 E.18092
G1 X116.175 Y83.555 E.01258
G1 X110.916 Y78.296 E.18091
G1 X111.433 Y78.296 E.01258
G1 X116.692 Y83.555 E.18091
G1 X117.209 Y83.555 E.01258
G1 X111.95 Y78.296 E.18091
G1 X112.467 Y78.296 E.01258
G1 X117.726 Y83.555 E.18091
G1 X118.243 Y83.555 E.01258
G1 X112.984 Y78.296 E.18091
G1 X113.501 Y78.296 E.01258
G1 X118.761 Y83.555 E.18092
G1 X119.278 Y83.555 E.01258
G1 X114.018 Y78.296 E.18092
G1 X114.535 Y78.296 E.01258
G1 X119.795 Y83.555 E.18092
G1 X120.312 Y83.555 E.01258
G1 X115.053 Y78.296 E.18091
G1 X115.57 Y78.296 E.01258
G1 X120.842 Y83.568 E.18135
G1 X121.101 Y83.704 E.00712
;WIDTH:0.374336
G1 X121.29 Y83.867 E.00564
;WIDTH:0.399999
G1 X121.552 Y83.761 E.00687
G1 X116.087 Y78.296 E.18799
G1 X116.604 Y78.296 E.01258
G1 X122.069 Y83.761 E.18799
G1 X122.585 Y83.76 E.01255
G1 X117.121 Y78.296 E.18796
G1 X117.638 Y78.296 E.01258
G1 X123.101 Y83.759 E.18792
G1 X123.617 Y83.758 E.01255
G1 X118.155 Y78.296 E.18789
G1 X118.672 Y78.296 E.01258
G1 X124.133 Y83.757 E.18785
G1 X124.65 Y83.756 E.01258
G1 X119.19 Y78.296 E.18782
G1 X119.707 Y78.296 E.01258
G1 X125.166 Y83.755 E.18779
G1 X125.682 Y83.754 E.01255
G1 X120.224 Y78.296 E.18775
G1 X120.741 Y78.296 E.01258
G1 X126.198 Y83.753 E.18772
G1 X126.7 Y83.738 E.01222
G1 X121.258 Y78.296 E.1872
G1 X121.775 Y78.296 E.01258
G1 X127.107 Y83.627 E.1834
G1 X127.475 Y83.478 E.00966
G1 X122.292 Y78.296 E.17827
G1 X122.809 Y78.296 E.01258
G1 X127.779 Y83.265 E.17095
G1 X128.037 Y83.006 E.00889
G1 X123.327 Y78.296 E.16202
G1 X123.844 Y78.296 E.01258
G1 X128.246 Y82.699 E.15144
G1 X128.401 Y82.336 E.0096
G1 X124.361 Y78.296 E.13897
G1 X124.878 Y78.296 E.01258
G1 X128.493 Y81.911 E.12435
G1 X128.504 Y81.405 E.01231
G1 X125.395 Y78.296 E.10695
G1 X125.912 Y78.296 E.01258
G1 X128.506 Y80.889 E.08921
G1 X128.507 Y80.374 E.01253
G1 X126.429 Y78.296 E.07148
G1 X126.946 Y78.296 E.01258
G1 X128.509 Y79.859 E.05377
G1 X128.511 Y79.343 E.01255
G1 X127.464 Y78.296 E.03602
G1 X127.981 Y78.296 E.01258
G1 X128.513 Y78.828 E.0183
G1 X128.585 Y78.281 E.01342
;WIDTH:0.44212
G1 X128.598 Y78.33 E.00138
G1 X128.562 Y78.366 E.00138
G1 X128.513 Y78.353 E.00138
G1 X128.499 Y78.304 E.00138
G1 X128.535 Y78.268 E.00138
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X128.499 Y78.304 E-.02418
G1 X128.513 Y78.353 E-.02421
G1 X128.562 Y78.366 E-.02408
G1 X128.598 Y78.33 E-.02418
G1 X128.585 Y78.281 E-.02408
G1 X128.513 Y78.828 E-.26207
G1 X127.981 Y78.296 E-.35737
G1 X127.464 Y78.296 E-.24558
G1 X128.229 Y79.062 E-.51425
;WIPE_END
G1 X126.764 Y85.135 F9000
G1 X126.411 Y86.599
G1 X125.94 Y88.151
G1 X125.94 Y88.552
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X125.947 Y88.554 E.00018
G1 X126 Y88.689 E.00353
G1 X126 Y89.367 E.01649
G1 X126.399 Y89.915 E.01649
G1 X126.531 Y90.246 E.00867
G1 X126.562 Y90.525 E.00683
G1 X126.519 Y90.797 E.0067
G1 X126.398 Y91.085 E.0076
G1 X126 Y91.633 E.01647
G1 X126 Y92.822 E.02892
G1 X139.202 Y92.821 E.32113
G1 X139.518 Y92.916 E.00803
G1 X139.794 Y93.221 E.01001
G1 X139.9 Y93.658 E.01094
G1 X139.9 Y95.171 E.0368
G1 X139.794 Y95.607 E.01091
G1 X139.518 Y95.913 E.01002
G1 X139.202 Y96.007 E.00802
G1 X136.7 Y96.007 E.06086
G1 X136.698 Y132.81 E.8952
G1 X136.638 Y133.72 E.02218
G1 X136.56 Y134.279 E.01373
G1 X136.461 Y134.79 E.01266
G1 X136.262 Y135.554 E.0192
G1 X135.914 Y136.526 E.02511
G1 X135.482 Y137.432 E.02441
G1 X135.05 Y138.16 E.02059
G1 X134.753 Y138.595 E.01281
G1 X134.427 Y139.018 E.01299
G1 X133.834 Y139.688 E.02176
G1 X133.426 Y140.087 E.01388
G1 X132.7 Y140.699 E.0231
G1 X132.016 Y141.179 E.02033
G1 X131.087 Y141.71 E.02603
G1 X130.617 Y141.932 E.01264
G1 X129.84 Y142.237 E.0203
G1 X128.889 Y142.516 E.02411
G1 X128.379 Y142.626 E.01269
G1 X127.856 Y142.71 E.01288
G1 X127.323 Y142.767 E.01304
G1 X126.775 Y142.796 E.01335
G1 X120.483 Y142.8 E.15305
G1 X120.405 Y142.783 E.00194
G1 X120.254 Y142.572 E.00631
G1 X110.7 Y142.572 E.23239
G1 X110.595 Y142.783 E.00573
G1 X110.517 Y142.8 E.00194
G1 X104.5 Y142.8 E.14636
G1 X103.734 Y142.771 E.01865
G1 X103.154 Y142.711 E.01418
G1 X102.631 Y142.627 E.01288
G1 X101.975 Y142.482 E.01634
G1 X101.271 Y142.275 E.01785
G1 X100.274 Y141.883 E.02606
G1 X99.1 Y141.253 E.03241
G1 X98.599 Y140.919 E.01465
G1 X97.941 Y140.411 E.02022
G1 X97.495 Y140.013 E.01454
G1 X96.932 Y139.437 E.01959
G1 X96.579 Y139.026 E.01318
G1 X96.253 Y138.602 E.01301
G1 X95.956 Y138.17 E.01275
G1 X95.301 Y137.006 E.03249
G1 X94.91 Y136.074 E.02458
G1 X94.613 Y135.103 E.0247
G1 X94.374 Y133.821 E.03172
G1 X94.302 Y132.81 E.02465
G1 X94.3 Y96.007 E.8952
G1 X91.798 Y96.007 E.06086
G1 X91.483 Y95.913 E.008
G1 X91.206 Y95.607 E.01004
G1 X91.108 Y95.259 E.00879
G1 X91.1 Y93.658 E.03894
G1 X91.145 Y93.371 E.00707
G1 X91.281 Y93.1 E.00738
G1 X91.583 Y92.864 E.00932
G1 X91.798 Y92.821 E.00533
G1 X105 Y92.822 E.32113
G1 X105 Y91.633 E.02892
G1 X104.602 Y91.085 E.01647
G1 X104.469 Y90.754 E.00868
G1 X104.438 Y90.475 E.00683
G1 X104.481 Y90.203 E.0067
G1 X104.602 Y89.915 E.0076
G1 X105 Y89.367 E.01647
G1 X105 Y88.683 E.01664
G1 X105.062 Y88.545 E.00368
G1 X105.183 Y88.5 E.00314
G1 X125.817 Y88.5 E.5019
G1 X125.885 Y88.528 E.00179
G1 X125.885 Y88.528 F9000
G1 X126.189 Y88.29
;TYPE:Perimeter
G1 F6000
G1 X126.208 Y88.298 E.0005
G1 X126.35 Y88.552 E.00708
G1 X126.366 Y89.248 E.01693
G1 X126.695 Y89.701 E.01362
G1 X126.875 Y90.115 E.01098
G1 X126.924 Y90.574 E.01123
G1 X126.859 Y90.933 E.00887
G1 X126.694 Y91.3 E.00979
G1 X126.366 Y91.752 E.01358
G1 X126.366 Y92.456 E.01712
G1 X139.202 Y92.455 E.31222
G1 X139.633 Y92.568 E.01084
G1 X139.894 Y92.753 E.00778
G1 X140.083 Y92.997 E.00751
;WIDTH:0.439107
G1 X140.145 Y93.13 E.00395
;WIDTH:0.478215
G1 X140.207 Y93.263 E.00433
;WIDTH:0.517323
G1 X140.269 Y93.396 E.00471
;WIDTH:0.55643
G1 X140.331 Y93.529 E.0051
G1 X140.34 Y93.658 E.00449
;WIDTH:0.546998
G1 X140.34 Y95.171 E.0516
G1 X140.323 Y95.298 E.00437
;WIDTH:0.540725
G1 X140.243 Y95.476 E.00657
;WIDTH:0.493817
G1 X140.163 Y95.654 E.00596
;WIDTH:0.446908
G1 X140.083 Y95.831 E.00533
;WIDTH:0.399999
G1 X139.894 Y96.075 E.00751
G1 X139.633 Y96.26 E.00778
G1 X139.202 Y96.373 E.01084
G1 X137.066 Y96.372 E.05196
G1 X137.063 Y132.81 E.88632
G1 X137.003 Y133.744 E.02277
G1 X136.923 Y134.329 E.01436
G1 X136.82 Y134.86 E.01316
G1 X136.606 Y135.678 E.02057
G1 X136.258 Y136.649 E.02509
G1 X135.812 Y137.59 E.02533
G1 X135.364 Y138.347 E.0214
G1 X135.054 Y138.801 E.01337
G1 X134.717 Y139.241 E.01348
G1 X134.108 Y139.931 E.02239
G1 X133.682 Y140.349 E.01452
G1 X132.935 Y140.979 E.02377
G1 X132.226 Y141.478 E.02109
G1 X131.268 Y142.028 E.02687
G1 X130.772 Y142.263 E.01335
G1 X129.974 Y142.578 E.02087
G1 X128.991 Y142.867 E.02492
G1 X128.455 Y142.983 E.01334
G1 X127.914 Y143.071 E.01333
G1 X127.361 Y143.13 E.01353
G1 X126.776 Y143.162 E.01425
G1 X120.483 Y143.166 E.15307
G1 X120.249 Y143.113 E.00584
G1 X120.137 Y142.937 E.00507
G1 X110.863 Y142.937 E.22558
G1 X110.751 Y143.113 E.00507
G1 X110.517 Y143.166 E.00584
G1 X104.5 Y143.166 E.14636
G1 X103.72 Y143.136 E.01899
G1 X103.116 Y143.075 E.01477
G1 X102.573 Y142.988 E.01338
G1 X101.895 Y142.839 E.01689
G1 X101.137 Y142.615 E.01923
G1 X100.082 Y142.196 E.02761
G1 X98.927 Y141.575 E.0319
G1 X98.396 Y141.223 E.0155
G1 X97.717 Y140.7 E.02085
G1 X97.251 Y140.286 E.01516
G1 X96.67 Y139.692 E.02021
G1 X96.301 Y139.264 E.01375
G1 X95.963 Y138.825 E.01348
G1 X95.629 Y138.336 E.0144
G1 X94.964 Y137.148 E.03312
G1 X94.573 Y136.216 E.02458
G1 X94.253 Y135.17 E.02661
G1 X94.014 Y133.885 E.03179
G1 X93.937 Y132.81 E.02622
G1 X93.934 Y96.372 E.88632
G1 X91.798 Y96.373 E.05196
G1 X91.368 Y96.26 E.01081
G1 X91.106 Y96.075 E.0078
G1 X90.917 Y95.831 E.00751
;WIDTH:0.440213
G1 X90.856 Y95.715 E.00354
;WIDTH:0.480427
G1 X90.794 Y95.599 E.0039
;WIDTH:0.520641
G1 X90.733 Y95.483 E.00424
;WIDTH:0.560855
G1 X90.671 Y95.367 E.00461
G1 X90.665 Y95.261 E.00372
;WIDTH:0.554151
G1 X90.659 Y93.658 E.05543
;WIDTH:0.570355
G1 X90.686 Y93.354 E.01088
G1 X90.717 Y93.322 E.00159
;WIDTH:0.527766
G1 X90.748 Y93.291 E.00144
;WIDTH:0.485177
G1 X90.779 Y93.259 E.00134
;WIDTH:0.442588
G1 X90.809 Y93.227 E.00119
;WIDTH:0.399999
G1 X90.898 Y93.021 E.00546
G1 X91.039 Y92.826 E.00585
G1 X91.259 Y92.632 E.00713
G1 X91.504 Y92.507 E.00669
G1 X91.798 Y92.455 E.00726
G1 X104.634 Y92.456 E.31222
G1 X104.634 Y91.752 E.01712
G1 X104.306 Y91.3 E.01358
G1 X104.107 Y90.804 E.013
G1 X104.076 Y90.426 E.00923
G1 X104.141 Y90.067 E.00887
G1 X104.306 Y89.7 E.00979
G1 X104.634 Y89.248 E.01358
G1 X104.634 Y88.683 E.01374
G1 X104.728 Y88.377 E.00779
G1 X104.822 Y88.27 E.00346
G1 X105.088 Y88.143 E.00717
G1 X105.183 Y88.134 E.00232
G1 X125.817 Y88.134 E.5019
G1 X126.134 Y88.267 E.00836
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X126.189 Y88.29 E-.02832
G1 X126.208 Y88.298 E-.00979
G1 X126.35 Y88.552 E-.13822
G1 X126.366 Y89.248 E-.33069
G1 X126.695 Y89.701 E-.26594
G1 X126.875 Y90.115 E-.21443
G1 X126.924 Y90.574 E-.21926
G1 X126.859 Y90.933 E-.1733
G1 X126.755 Y91.164 E-.12005
;WIPE_END
G1 X126.751 Y91.162 F9000
G1 X126.804 Y91.046
G1 X126.864 Y90.867
G1 X126.901 Y90.685
G1 X126.913 Y90.5
G1 X126.901 Y90.315
G1 X126.864 Y90.133
G1 X126.349 Y88.151
G1 X122.885 Y88.151
G1 X120.36 Y86.599
G1 X120.36 Y86.186
G1 E5 F2400
G1 F6000
G1 X120.3 Y86.067 E.00324
G1 X120.3 Y85.971 E.00234
G1 X110.7 Y85.971 E.23351
G1 X110.7 Y86.067 E.00234
G1 X110.625 Y86.215 E.00404
G1 X110.517 Y86.25 E.00276
G1 X104.2 Y86.25 E.15365
G1 X103.823 Y86.231 E.00918
G1 X103.001 Y86.074 E.02036
G1 X102.425 Y85.855 E.01499
G1 X101.842 Y85.524 E.01631
G1 X101.356 Y85.14 E.01507
G1 X100.935 Y84.691 E.01497
G1 X100.582 Y84.182 E.01507
G1 X100.307 Y83.625 E.01511
G1 X100.118 Y83.033 E.01512
G1 X100.044 Y82.652 E.00944
G1 X100 Y82.051 E.01466
G1 X100 Y78.633 E.08314
G1 X99.602 Y78.085 E.01647
G1 X99.468 Y77.745 E.00889
G1 X99.438 Y77.475 E.00661
G1 X99.481 Y77.203 E.0067
G1 X99.602 Y76.915 E.0076
G1 X100 Y76.367 E.01647
G1 X100.001 Y76.009 E.00871
G1 X100.047 Y75.907 E.00272
G1 X100.183 Y75.846 E.00363
G1 X130.817 Y75.846 E.74514
G1 X130.953 Y75.907 E.00363
G1 X131 Y76.029 E.00318
G1 X131 Y76.367 E.00822
G1 X131.398 Y76.915 E.01647
G1 X131.531 Y77.246 E.00868
G1 X131.55 Y77.614 E.00896
G1 X131.458 Y77.95 E.00847
G1 X131.398 Y78.085 E.00359
G1 X131 Y78.634 E.01649
G1 X130.989 Y82.345 E.09027
G1 X130.9 Y82.957 E.01504
G1 X130.703 Y83.599 E.01633
G1 X130.246 Y84.448 E.02345
G1 X129.668 Y85.117 E.02151
G1 X129.182 Y85.509 E.01519
G1 X128.437 Y85.912 E.0206
G1 X127.4 Y86.206 E.02622
G1 X126.814 Y86.25 E.01429
G1 X120.483 Y86.25 E.154
G1 X120.401 Y86.223 E.0021
G1 X120.401 Y86.223 F9000
G1 X120.116 Y86.425
;TYPE:Perimeter
G1 F6000
G1 X120.071 Y86.337 E.0024
G1 X110.929 Y86.337 E.22237
G1 X110.841 Y86.51 E.00472
G1 X110.517 Y86.616 E.00829
G1 X104.2 Y86.616 E.15365
G1 X103.754 Y86.59 E.01087
G1 X102.925 Y86.432 E.02053
G1 X102.294 Y86.196 E.01639
G1 X101.66 Y85.842 E.01766
G1 X101.128 Y85.426 E.01643
G1 X100.667 Y84.94 E.01629
G1 X100.281 Y84.389 E.01636
G1 X99.979 Y83.785 E.01643
G1 X99.769 Y83.143 E.01643
G1 X99.679 Y82.679 E.0115
G1 X99.634 Y82.051 E.01531
G1 X99.634 Y78.752 E.08024
G1 X99.306 Y78.3 E.01358
G1 X99.111 Y77.828 E.01242
G1 X99.076 Y77.426 E.00982
G1 X99.141 Y77.067 E.00887
G1 X99.306 Y76.7 E.00979
G1 X99.634 Y76.248 E.01358
G1 X99.638 Y75.967 E.00684
G1 X99.775 Y75.663 E.00811
G1 X100.088 Y75.489 E.00871
G1 X130.817 Y75.481 E.74745
G1 X131.225 Y75.663 E.01087
G1 X131.366 Y76.029 E.00954
G1 X131.366 Y76.248 E.00533
G1 X131.694 Y76.7 E.01358
G1 X131.893 Y77.196 E.013
G1 X131.924 Y77.574 E.00923
G1 X131.846 Y77.964 E.00967
G1 X131.694 Y78.3 E.00897
G1 X131.365 Y78.753 E.01362
G1 X131.355 Y82.346 E.0874
G1 X131.262 Y83.011 E.01633
G1 X131.052 Y83.707 E.01768
G1 X130.523 Y84.687 E.02709
G1 X129.944 Y85.356 E.02152
G1 X129.41 Y85.795 E.01681
G1 X129.008 Y86.044 E.0115
G1 X128.522 Y86.277 E.01311
G1 X127.482 Y86.564 E.02624
G1 X126.841 Y86.614 E.01564
G1 X120.483 Y86.616 E.15465
G1 X120.159 Y86.51 E.00829
G1 X120.143 Y86.478 E.00087
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X120.116 Y86.425 E-.02825
G1 X120.071 Y86.337 E-.04695
G1 X117.071 Y86.337 E-1.4248
;WIPE_END
G1 X120.143 Y74.206 F9000
G1 E5 F2400
G1 F6000
G1 X135.585 Y74.203 E.37561
G1 X136.199 Y74.243 E.01497
G1 X136.888 Y74.369 E.01704
G1 X137.472 Y74.548 E.01486
G1 X138.196 Y74.865 E.01922
G1 X138.792 Y75.226 E.01695
G1 X139.601 Y75.9 E.02561
G1 X140.273 Y76.706 E.02553
G1 X140.788 Y77.62 E.02552
G1 X141.131 Y78.612 E.02553
G1 X141.289 Y79.653 E.02561
G1 X141.289 Y80.041 E.00944
G1 X141.3 Y150.994 E1.72586
G1 X141.258 Y151.696 E.01711
G1 X141.132 Y152.383 E.01699
G1 X140.926 Y153.049 E.01696
G1 X140.64 Y153.686 E.01698
G1 X140.281 Y154.283 E.01694
G1 X139.852 Y154.834 E.01699
G1 X139.36 Y155.328 E.01696
G1 X138.772 Y155.788 E.01816
G1 X138.175 Y156.145 E.01692
G1 X137.266 Y156.523 E.02395
G1 X136.58 Y156.698 E.01722
G1 X135.84 Y156.79 E.01814
G1 X95.459 Y156.799 E.98223
G1 X94.783 Y156.755 E.01648
G1 X94.093 Y156.626 E.01707
G1 X93.453 Y156.426 E.01631
G1 X92.827 Y156.147 E.01667
G1 X92.187 Y155.76 E.01819
G1 X91.64 Y155.328 E.01695
G1 X91.148 Y154.834 E.01696
G1 X90.719 Y154.283 E.01699
G1 X90.361 Y153.687 E.01691
G1 X89.976 Y152.763 E.02435
G1 X89.795 Y152.041 E.01811
G1 X89.711 Y151.349 E.01696
G1 X89.7 Y80.006 E1.73535
G1 X89.743 Y79.301 E.01718
G1 X89.869 Y78.612 E.01704
G1 X90.077 Y77.943 E.01704
G1 X90.365 Y77.305 E.01703
G1 X90.727 Y76.705 E.01704
G1 X91.159 Y76.154 E.01703
G1 X91.654 Y75.659 E.01703
G1 X92.205 Y75.227 E.01703
G1 X92.805 Y74.865 E.01704
G1 X93.442 Y74.578 E.01699
G1 X94.37 Y74.314 E.02347
G1 X95.151 Y74.211 E.01916
G1 X120.083 Y74.206 E.60645
G1 X120.083 Y74.572 F9000
;TYPE:Perimeter
G1 F6000
G1 X135.573 Y74.568 E.37678
G1 X136.154 Y74.606 E.01416
G1 X136.802 Y74.725 E.01603
G1 X137.344 Y74.891 E.01379
G1 X138.027 Y75.19 E.01814
G1 X138.58 Y75.524 E.01571
G1 X139.341 Y76.159 E.02411
G1 X139.971 Y76.914 E.02392
G1 X140.454 Y77.771 E.02393
G1 X140.774 Y78.7 E.0239
G1 X140.923 Y79.68 E.02411
G1 X140.923 Y80.041 E.00878
G1 X140.925 Y93.142 E.31867
;WIDTH:0.439107
G1 X140.906 Y93.225 E.00229
;WIDTH:0.478215
G1 X140.886 Y93.308 E.00252
;WIDTH:0.517323
G1 X140.867 Y93.392 E.00277
;WIDTH:0.55643
G1 X140.847 Y93.475 E.00297
G1 X140.852 Y93.658 E.00636
;WIDTH:0.546998
G1 X140.852 Y95.171 E.0516
G1 X140.877 Y95.342 E.00589
;WIDTH:0.497999
G1 X140.901 Y95.514 E.00536
;WIDTH:0.448999
G1 X140.926 Y95.686 E.00479
;WIDTH:0.399999
G1 X140.934 Y150.983 E1.34504
G1 X140.894 Y151.652 E.0163
G1 X140.777 Y152.295 E.0159
G1 X140.583 Y152.92 E.01592
G1 X140.316 Y153.516 E.01589
G1 X139.979 Y154.076 E.0159
G1 X139.577 Y154.591 E.01589
G1 X139.117 Y155.054 E.01588
G1 X138.564 Y155.486 E.01707
G1 X138.01 Y155.818 E.01571
G1 X137.15 Y156.175 E.02265
G1 X136.512 Y156.338 E.01602
G1 X135.818 Y156.424 E.01701
G1 X95.471 Y156.434 E.9814
G1 X94.828 Y156.392 E.01567
G1 X94.182 Y156.271 E.01599
G1 X93.582 Y156.084 E.01529
G1 X92.997 Y155.822 E.01559
G1 X92.396 Y155.459 E.01708
G1 X91.884 Y155.055 E.01586
G1 X91.423 Y154.591 E.01591
G1 X91.021 Y154.076 E.01589
G1 X90.688 Y153.522 E.01572
G1 X90.324 Y152.648 E.02303
G1 X90.155 Y151.974 E.0169
G1 X90.077 Y151.327 E.01585
G1 X90.068 Y95.726 E1.35244
;WIDTH:0.441884
G1 X90.089 Y95.644 E.00229
;WIDTH:0.483769
G1 X90.11 Y95.563 E.0025
;WIDTH:0.525654
G1 X90.131 Y95.481 E.00277
;WIDTH:0.554151
G1 X90.145 Y95.262 E.00759
G1 X90.143 Y93.662 E.05533
;WIDTH:0.570355
G1 X90.153 Y93.316 E.01234
G1 X90.132 Y93.256 E.00227
;WIDTH:0.527766
G1 X90.11 Y93.195 E.00213
;WIDTH:0.485177
G1 X90.089 Y93.135 E.00191
;WIDTH:0.442588
G1 X90.068 Y93.075 E.00173
;WIDTH:0.399999
G1 X90.066 Y80.017 E.31762
G1 X90.106 Y79.345 E.01637
G1 X90.225 Y78.7 E.01595
G1 X90.42 Y78.073 E.01597
G1 X90.689 Y77.475 E.01595
G1 X91.028 Y76.914 E.01594
G1 X91.433 Y76.397 E.01597
G1 X91.897 Y75.933 E.01596
G1 X92.414 Y75.528 E.01597
G1 X92.975 Y75.189 E.01594
G1 X93.567 Y74.922 E.0158
G1 X94.444 Y74.673 E.02218
G1 X95.175 Y74.577 E.01793
G1 X120.023 Y74.572 E.6044
G1 E-5 F3600
G1 X120.023 Y74.572 F9000
G1 X120.023 Y74.549
G1 X139.355 Y76.145
G1 X140.951 Y81.116
G1 X140.951 Y95.605
G1 X140.56 Y95.605
G1 E5 F2400
G1 F6000
G1 X140.569 Y150.972 E1.34675
G1 X140.53 Y151.608 E.0155
G1 X140.421 Y152.208 E.01483
G1 X140.24 Y152.79 E.01483
G1 X139.991 Y153.346 E.01482
G1 X139.677 Y153.869 E.01484
G1 X139.302 Y154.349 E.01482
G1 X138.874 Y154.78 E.01477
G1 X138.357 Y155.184 E.01596
G1 X137.845 Y155.49 E.01451
G1 X137.034 Y155.827 E.02136
G1 X136.444 Y155.978 E.01481
G1 X135.795 Y156.058 E.01591
G1 X95.482 Y156.068 E.98057
G1 X94.874 Y156.028 E.01482
G1 X94.27 Y155.915 E.01495
G1 X93.712 Y155.741 E.01422
G1 X93.167 Y155.497 E.01452
G1 X92.605 Y155.158 E.01596
G1 X92.128 Y154.781 E.01479
G1 X91.698 Y154.349 E.01483
G1 X91.323 Y153.869 E.01482
G1 X91.015 Y153.357 E.01453
G1 X90.672 Y152.532 E.02173
G1 X90.515 Y151.908 E.01565
G1 X90.442 Y151.305 E.01477
G1 X90.434 Y95.598 E1.35502
G1 X90.628 Y96.054 E.01205
G1 X90.817 Y96.299 E.00753
G1 X91.253 Y96.607 E.01298
G1 X91.798 Y96.739 E.01364
G1 X93.569 Y96.738 E.04308
G1 X93.571 Y132.81 E.87742
G1 X93.655 Y133.957 E.02797
G1 X93.918 Y135.337 E.03417
G1 X94.236 Y136.357 E.02599
G1 X94.627 Y137.289 E.02458
G1 X95.353 Y138.584 E.03611
G1 X95.673 Y139.048 E.01371
G1 X96.024 Y139.502 E.01396
G1 X96.409 Y139.948 E.01433
G1 X97.008 Y140.559 E.02081
G1 X97.494 Y140.989 E.01578
G1 X98.193 Y141.527 E.02146
G1 X98.754 Y141.897 E.01635
G1 X99.909 Y142.518 E.0319
G1 X101.004 Y142.956 E.02869
G1 X101.816 Y143.196 E.0206
G1 X102.515 Y143.35 E.01741
G1 X103.078 Y143.438 E.01386
G1 X103.706 Y143.502 E.01535
G1 X104.5 Y143.532 E.01933
G1 X110.517 Y143.532 E.14636
G1 X110.632 Y143.524 E.0028
G1 X110.907 Y143.444 E.00697
G1 X110.997 Y143.303 E.00407
G1 X120.003 Y143.303 E.21906
G1 X120.093 Y143.444 E.00407
G1 X120.256 Y143.503 E.00422
G1 X120.483 Y143.532 E.00557
G1 X126.776 Y143.528 E.15307
G1 X127.4 Y143.494 E.0152
G1 X127.972 Y143.432 E.01399
G1 X128.531 Y143.341 E.01378
G1 X129.094 Y143.218 E.01402
G1 X130.108 Y142.918 E.02572
G1 X130.928 Y142.594 E.02145
G1 X131.449 Y142.345 E.01405
G1 X132.365 Y141.823 E.02564
G1 X133.171 Y141.259 E.02393
G1 X133.937 Y140.611 E.0244
G1 X134.382 Y140.173 E.01519
G1 X135.008 Y139.464 E.02301
G1 X135.356 Y139.008 E.01395
G1 X135.679 Y138.534 E.01395
G1 X136.142 Y137.747 E.02221
G1 X136.603 Y136.772 E.02623
G1 X136.95 Y135.801 E.02508
G1 X137.179 Y134.929 E.02193
G1 X137.285 Y134.38 E.0136
G1 X137.368 Y133.768 E.01502
G1 X137.429 Y132.81 E.02335
G1 X137.431 Y96.738 E.87742
G1 X139.202 Y96.739 E.04308
G1 X139.747 Y96.607 E.01364
G1 X140.183 Y96.299 E.01298
G1 X140.372 Y96.055 E.00751
G1 X140.537 Y95.661 E.01039
G1 X140.537 Y95.661 F9000
G1 X140.195 Y96.719
G1 F6000
G1 X140.203 Y150.961 E1.31938
G1 X140.167 Y151.564 E.01469
G1 X140.065 Y152.121 E.01377
G1 X139.898 Y152.661 E.01375
G1 X139.666 Y153.177 E.01376
G1 X139.375 Y153.661 E.01374
G1 X139.027 Y154.107 E.01376
G1 X138.631 Y154.506 E.01367
G1 X138.15 Y154.882 E.01485
G1 X137.68 Y155.163 E.01332
G1 X136.918 Y155.48 E.02007
G1 X136.376 Y155.618 E.0136
G1 X135.772 Y155.693 E.0148
G1 X95.494 Y155.702 E.97972
G1 X94.92 Y155.665 E.01399
G1 X94.358 Y155.56 E.01391
G1 X93.841 Y155.398 E.01318
G1 X93.336 Y155.173 E.01345
G1 X92.813 Y154.857 E.01486
G1 X92.371 Y154.508 E.0137
G1 X91.973 Y154.107 E.01374
G1 X91.625 Y153.661 E.01376
G1 X91.342 Y153.191 E.01334
G1 X91.02 Y152.417 E.02039
G1 X90.875 Y151.841 E.01445
G1 X90.808 Y151.283 E.01367
G1 X90.8 Y96.715 E1.32731
G1 X91.138 Y96.954 E.01007
G1 X91.396 Y97.04 E.00662
G1 X91.799 Y97.104 E.00993
G1 X93.203 Y97.104 E.03415
G1 X93.205 Y132.81 E.86851
G1 X93.296 Y134.024 E.02961
G1 X93.569 Y135.445 E.0352
G1 X93.899 Y136.499 E.02686
G1 X94.29 Y137.431 E.02458
G1 X95.052 Y138.79 E.0379
G1 X95.383 Y139.271 E.0142
G1 X95.746 Y139.74 E.01443
G1 X96.147 Y140.203 E.0149
G1 X96.764 Y140.832 E.02143
G1 X97.27 Y141.279 E.01642
G1 X97.99 Y141.831 E.02207
G1 X98.58 Y142.219 E.01718
G1 X99.735 Y142.84 E.0319
G1 X100.87 Y143.296 E.02975
G1 X101.736 Y143.552 E.02197
G1 X102.457 Y143.711 E.01796
G1 X103.04 Y143.802 E.01435
G1 X103.692 Y143.867 E.01594
G1 X104.5 Y143.897 E.01967
G1 X110.517 Y143.897 E.14636
G1 X110.678 Y143.887 E.00392
G1 X111.063 Y143.775 E.00975
G1 X111.131 Y143.669 E.00306
G1 X119.869 Y143.669 E.21254
G1 X119.937 Y143.775 E.00306
G1 X120.165 Y143.857 E.00589
G1 X120.483 Y143.897 E.0078
G1 X126.776 Y143.893 E.15307
G1 X127.439 Y143.858 E.01615
G1 X128.029 Y143.793 E.01444
G1 X128.607 Y143.699 E.01424
G1 X129.197 Y143.569 E.0147
G1 X130.242 Y143.258 E.02652
G1 X131.083 Y142.925 E.022
G1 X131.631 Y142.663 E.01477
G1 X132.546 Y142.14 E.02564
G1 X133.406 Y141.538 E.02553
G1 X134.193 Y140.872 E.02508
G1 X134.655 Y140.416 E.01579
G1 X135.298 Y139.686 E.02366
G1 X135.657 Y139.215 E.01441
G1 X135.993 Y138.721 E.01453
G1 X136.472 Y137.905 E.02302
G1 X136.947 Y136.896 E.02713
G1 X137.295 Y135.924 E.02511
G1 X137.538 Y134.999 E.02326
G1 X137.647 Y134.43 E.01409
G1 X137.732 Y133.793 E.01563
G1 X137.795 Y132.81 E.02396
G1 X137.797 Y97.104 E.86851
G1 X138.996 Y97.104 E.02916
G1 X139.604 Y97.04 E.01487
G1 X139.862 Y96.954 E.00662
G1 X140.146 Y96.754 E.00845
G1 X140.146 Y96.754 F9000
G1 X139.829 Y97.35
G1 F6000
G1 X139.837 Y150.814 E1.30046
G1 X139.819 Y151.261 E.01088
G1 X139.756 Y151.778 E.01267
G1 X139.631 Y152.284 E.01268
G1 X139.447 Y152.772 E.01269
G1 X139.205 Y153.234 E.01269
G1 X138.909 Y153.664 E.0127
G1 X138.573 Y154.045 E.01236
G1 X138.123 Y154.439 E.01455
G1 X137.516 Y154.835 E.01763
G1 X136.802 Y155.132 E.01881
G1 X136.308 Y155.258 E.0124
G1 X135.75 Y155.327 E.01368
G1 X95.506 Y155.337 E.9789
G1 X94.965 Y155.301 E.01319
G1 X94.447 Y155.204 E.01282
G1 X93.744 Y154.954 E.01815
G1 X93.247 Y154.691 E.01368
G1 X92.814 Y154.392 E.0128
G1 X92.422 Y154.04 E.01282
G1 X92.065 Y153.631 E.01321
G1 X91.67 Y153.026 E.01757
G1 X91.368 Y152.301 E.0191
G1 X91.236 Y151.774 E.01321
G1 X91.174 Y151.261 E.01257
G1 X91.165 Y97.348 E1.31138
G1 X91.282 Y97.387 E.003
G1 X91.799 Y97.47 E.01274
G1 X92.837 Y97.47 E.02525
G1 X92.84 Y132.81 E.85961
G1 X92.936 Y134.091 E.03125
G1 X93.219 Y135.552 E.0362
G1 X93.561 Y136.64 E.02774
G1 X93.952 Y137.572 E.02458
G1 X94.75 Y138.997 E.03973
G1 X95.093 Y139.493 E.01467
G1 X95.469 Y139.979 E.01495
G1 X95.885 Y140.458 E.01543
G1 X96.521 Y141.104 E.02205
G1 X97.046 Y141.568 E.01704
G1 X97.787 Y142.135 E.0227
G1 X98.407 Y142.541 E.01803
G1 X99.562 Y143.162 E.0319
G1 X100.736 Y143.636 E.0308
G1 X101.657 Y143.909 E.02337
G1 X102.4 Y144.072 E.0185
G1 X103.002 Y144.166 E.01482
G1 X103.678 Y144.232 E.01652
G1 X104.5 Y144.263 E.02001
G1 X110.517 Y144.263 E.14636
G1 X110.724 Y144.25 E.00504
G1 X111.219 Y144.105 E.01255
G1 X111.265 Y144.034 E.00206
G1 X119.735 Y144.034 E.20602
G1 X119.781 Y144.105 E.00206
G1 X120.074 Y144.211 E.00758
G1 X120.483 Y144.263 E.01003
G1 X126.776 Y144.259 E.15307
G1 X127.478 Y144.221 E.0171
G1 X128.087 Y144.154 E.0149
G1 X128.684 Y144.056 E.01472
G1 X129.299 Y143.92 E.01532
G1 X130.376 Y143.599 E.02734
G1 X131.239 Y143.255 E.0226
G1 X131.812 Y142.98 E.01546
G1 X132.727 Y142.458 E.02562
G1 X133.642 Y141.818 E.02716
G1 X134.448 Y141.134 E.02571
G1 X134.929 Y140.659 E.01644
G1 X135.588 Y139.909 E.02428
G1 X135.959 Y139.422 E.01489
G1 X136.307 Y138.908 E.0151
G1 X136.802 Y138.062 E.02384
G1 X137.291 Y137.019 E.02802
G1 X137.639 Y136.047 E.02511
G1 X137.897 Y135.069 E.0246
G1 X138.009 Y134.481 E.01456
G1 X138.097 Y133.817 E.01629
G1 X138.16 Y132.81 E.02454
G1 X138.163 Y97.47 E.85961
G1 X139.202 Y97.47 E.02527
G1 X139.77 Y97.362 E.01406
G1 E-5 F3600
G1 X139.77 Y97.362 F9000
G1 X140.249 Y95.718
G1 X140.249 Y93.111
G1 X139.93 Y92.795
G1 X139.875 Y92.744
G1 X139.765 Y92.651
G1 X139.593 Y92.554
G1 X139.411 Y92.495
G1 X139.288 Y92.477
G1 X139.221 Y92.472
G1 X137.64 Y92.471
G1 X131.438 Y78.659
G1 X131.73 Y78.901
G1 E5 F2400
G1 F6000
G1 X131.73 Y78.872 E.00071
G1 X131.99 Y78.515 E.01074
G1 X132.186 Y78.1 E.01116
G1 X132.287 Y77.624 E.01184
G1 X132.255 Y77.147 E.01163
G1 X132.099 Y76.683 E.01191
G1 X131.731 Y76.129 E.01618
G1 X131.725 Y75.925 E.00496
G1 X131.497 Y75.418 E.01352
;WIDTH:0.445022
G1 X131.327 Y75.32 E.00536
;WIDTH:0.490044
G1 X131.157 Y75.222 E.00595
;WIDTH:0.535066
G1 X130.987 Y75.123 E.00655
;WIDTH:0.580088
G1 X130.817 Y75.025 E.00712
G1 X131.041 Y75.003 E.00817
;WIDTH:0.535066
G1 X131.265 Y74.98 E.0075
;WIDTH:0.490044
G1 X131.489 Y74.957 E.00683
;WIDTH:0.445022
G1 X131.713 Y74.935 E.00615
;WIDTH:0.399999
G1 X135.561 Y74.934 E.0936
G1 X136.109 Y74.97 E.01336
G1 X136.715 Y75.081 E.01499
G1 X137.217 Y75.235 E.01277
G1 X137.859 Y75.516 E.01705
G1 X138.367 Y75.823 E.01444
G1 X139.082 Y76.419 E.02264
G1 X139.668 Y77.123 E.02228
G1 X140.119 Y77.921 E.0223
G1 X140.418 Y78.788 E.02231
G1 X140.558 Y79.708 E.02264
G1 X140.558 Y80.041 E.0081
G1 X140.56 Y93.142 E.31867
G1 X140.372 Y92.773 E.01007
G1 X140.183 Y92.53 E.00749
G1 X139.747 Y92.221 E.013
G1 X139.202 Y92.09 E.01363
G1 X126.731 Y92.091 E.30334
G1 X126.731 Y91.871 E.00535
G1 X126.99 Y91.515 E.01071
G1 X127.198 Y91.068 E.01199
G1 X127.287 Y90.624 E.01101
G1 X127.255 Y90.147 E.01163
G1 X127.088 Y89.655 E.01264
G1 X126.731 Y89.129 E.01546
G1 X126.731 Y88.657 E.01148
G1 X126.648 Y88.301 E.00889
G1 X126.419 Y87.995 E.0093
G1 X125.817 Y87.769 E.01564
G1 X105.183 Y87.769 E.5019
G1 X105.025 Y87.782 E.00386
G1 X104.581 Y87.995 E.01198
G1 X104.424 Y88.173 E.00577
G1 X104.271 Y88.618 E.01145
G1 X104.269 Y89.129 E.01243
G1 X104.01 Y89.485 E.01071
G1 X103.802 Y89.932 E.01199
G1 X103.713 Y90.376 E.01101
G1 X103.745 Y90.853 E.01163
G1 X103.901 Y91.317 E.01191
G1 X104.269 Y91.871 E.01618
G1 X104.269 Y92.091 E.00535
G1 X91.798 Y92.09 E.30334
G1 X91.425 Y92.15 E.00919
G1 X91.017 Y92.358 E.01114
G1 X90.797 Y92.552 E.00713
G1 X90.562 Y92.876 E.00974
G1 X90.433 Y93.226 E.00907
G1 X90.431 Y80.028 E.32103
G1 X90.47 Y79.389 E.01557
G1 X90.58 Y78.787 E.01489
G1 X90.762 Y78.203 E.01488
G1 X91.013 Y77.645 E.01488
G1 X91.33 Y77.122 E.01488
G1 X91.707 Y76.64 E.01488
G1 X92.14 Y76.207 E.01489
G1 X92.622 Y75.83 E.01488
G1 X93.145 Y75.513 E.01488
G1 X93.693 Y75.267 E.01461
G1 X94.518 Y75.032 E.02087
G1 X95.199 Y74.942 E.01671
G1 X99.289 Y74.941 E.09949
;WIDTH:0.447265
G1 X99.469 Y74.965 E.00499
;WIDTH:0.494531
G1 X99.649 Y74.989 E.00556
;WIDTH:0.541797
G1 X99.829 Y75.012 E.00613
;WIDTH:0.589062
G1 X100.008 Y75.036 E.00666
G1 X99.882 Y75.132 E.00585
;WIDTH:0.541797
G1 X99.755 Y75.227 E.00535
;WIDTH:0.494531
G1 X99.629 Y75.323 E.00485
;WIDTH:0.447265
G1 X99.502 Y75.419 E.00437
;WIDTH:0.399999
G1 X99.275 Y75.926 E.01351
G1 X99.269 Y76.129 E.00494
G1 X99.01 Y76.485 E.01071
G1 X98.802 Y76.932 E.01199
G1 X98.713 Y77.376 E.01101
G1 X98.745 Y77.853 E.01163
G1 X98.91 Y78.339 E.01248
G1 X99.269 Y78.871 E.01561
G1 X99.269 Y82.051 E.07735
G1 X99.315 Y82.706 E.01597
G1 X99.421 Y83.253 E.01355
G1 X99.65 Y83.946 E.01775
G1 X99.98 Y84.596 E.01773
G1 X100.4 Y85.189 E.01768
G1 X100.9 Y85.712 E.0176
G1 X101.479 Y86.16 E.01781
G1 X102.037 Y86.478 E.01562
G1 X102.868 Y86.793 E.02162
G1 X103.686 Y86.949 E.02026
G1 X104.2 Y86.981 E.01253
G1 X110.517 Y86.981 E.15365
G1 X110.675 Y86.968 E.00386
G1 X111.056 Y86.805 E.01008
G1 X111.109 Y86.703 E.0028
G1 X119.891 Y86.703 E.21361
G1 X119.944 Y86.805 E.0028
G1 X120.483 Y86.981 E.01379
G1 X125.817 Y86.981 E.12974
G1 X126.868 Y86.979 E.02556
G1 X127.546 Y86.924 E.01655
G1 X128.68 Y86.607 E.02864
G1 X129.166 Y86.373 E.01312
G1 X129.637 Y86.081 E.01348
G1 X130.221 Y85.595 E.01848
G1 X130.799 Y84.927 E.02149
G1 X130.997 Y84.606 E.00917
G1 X131.401 Y83.816 E.02158
G1 X131.624 Y83.064 E.01908
G1 X131.72 Y82.348 E.01757
G1 X131.73 Y78.961 E.08239
G1 E-5 F3600
G1 X131.73 Y78.961 F9000
G1 X131.349 Y78.961
G1 X131.349 Y82.06
G1 X131.347 Y82.114
G1 X131.337 Y82.382
G1 X131.33 Y82.448
G1 X131.3 Y82.714
G1 X131.288 Y82.78
G1 X131.239 Y83.042
G1 X131.223 Y83.109
G1 X131.154 Y83.366
G1 X131.133 Y83.432
G1 X131.045 Y83.684
G1 X131.019 Y83.749
G1 X130.912 Y83.993
G1 X130.882 Y84.056
G1 X130.758 Y84.291
G1 X130.723 Y84.352
G1 X130.582 Y84.576
G1 X130.543 Y84.634
G1 X130.386 Y84.846
G1 X130.343 Y84.902
G1 X130.171 Y85.102
G1 X130.125 Y85.154
G1 X129.939 Y85.34
G1 X129.889 Y85.389
G1 X129.69 Y85.561
G1 X129.637 Y85.606
G1 X129.581 Y85.647
G1 X129.369 Y85.804
G1 X129.309 Y85.842
G1 X129.086 Y85.982
G1 X129.023 Y86.017
G1 X128.79 Y86.14
G1 X128.727 Y86.169
G1 X128.486 Y86.274
G1 X128.422 Y86.299
G1 X128.174 Y86.386
G1 X128.108 Y86.406
G1 X127.854 Y86.474
G1 X127.787 Y86.49
G1 X127.529 Y86.539
G1 X127.46 Y86.551
G1 X127.199 Y86.58
G1 X127.131 Y86.587
G1 X126.868 Y86.597
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X105.183 Y87.375 E.0067
;WIDTH:0.456022
G1 X110.517 Y87.375 E.14962
;WIDTH:0.475838
G1 X110.745 Y87.365 E.0067
G1 X110.745 Y87.365 F9000
G1 X110.773 Y87.349
G1 F6000
G1 X111.015 Y87.213 E.00815
;WIDTH:0.430177
G1 X111.285 Y87.061 E.00816
;WIDTH:0.384515
G1 X119.715 Y87.061 E.19637
G1 X119.732 Y87.094 E.00086
;WIDTH:0.420267
G1 X120.108 Y87.235 E.01031
;WIDTH:0.456018
G1 X120.483 Y87.375 E.01123
G1 X120.056 Y87.393 E.01199
;WIDTH:0.420267
G1 X119.629 Y87.411 E.01097
;WIDTH:0.384515
G1 X111.371 Y87.411 E.19236
;WIDTH:0.430177
G1 X111.058 Y87.388 E.00826
;WIDTH:0.475838
G1 X110.772 Y87.367 E.00842
G1 E-5 F3600
G1 X110.772 Y87.367 F9000
G1 X125.817 Y87.375
G1 E5 F2400
;WIDTH:0.456022
G1 F6000
G1 X120.483 Y87.375 E.14962
G1 E-5 F3600
G1 X120.483 Y87.375 F9000
G1 X125.817 Y87.375
G1 E5 F2400
G1 F6000
G1 X126.356 Y87.359 E.01513
;WIDTH:0.428011
G1 X126.895 Y87.344 E.01412
;WIDTH:0.399999
G1 X127.719 Y87.26 E.02015
G1 X128.617 Y87.019 E.02262
G1 X128.912 Y86.901 E.00773
G1 X129.444 Y86.638 E.01444
G1 X129.865 Y86.366 E.01219
G1 X130.497 Y85.835 E.02008
G1 X131.076 Y85.166 E.02152
G1 X131.319 Y84.779 E.01112
G1 X131.751 Y83.924 E.0233
G1 X131.985 Y83.118 E.02041
G1 X132.086 Y82.349 E.01887
G1 X132.096 Y78.992 E.08166
G1 X132.286 Y78.73 E.00787
G1 X132.548 Y78.179 E.01484
G1 X132.649 Y77.673 E.01255
G1 X132.617 Y77.097 E.01403
G1 X132.439 Y76.548 E.01404
G1 X132.096 Y76.008 E.01556
G1 X132.089 Y75.883 E.00305
G1 X131.826 Y75.301 E.01553
G1 X135.367 Y75.3 E.08613
G1 X135.883 Y75.321 E.01256
G1 X136.438 Y75.402 E.01364
G1 X137.089 Y75.578 E.0164
G1 X137.69 Y75.841 E.01596
G1 X138.154 Y76.122 E.01319
G1 X138.822 Y76.678 E.02114
G1 X139.366 Y77.332 E.02069
G1 X139.784 Y78.072 E.02067
G1 X140.061 Y78.876 E.02068
G1 X140.146 Y79.434 E.01373
G1 X140.192 Y80.041 E.01481
G1 X140.194 Y92.109 E.29354
G1 X139.862 Y91.874 E.00989
G1 X139.604 Y91.789 E.00661
G1 X139.202 Y91.724 E.00991
G1 X127.289 Y91.725 E.28977
G1 X127.538 Y91.204 E.01405
G1 X127.649 Y90.673 E.0132
G1 X127.617 Y90.097 E.01403
G1 X127.422 Y89.508 E.01509
G1 X127.097 Y89.01 E.01446
G1 X127.06 Y88.376 E.01545
G1 X126.98 Y88.148 E.00588
G1 X126.66 Y87.72 E.013
;WIDTH:0.428011
G1 X126.239 Y87.548 E.01191
;WIDTH:0.456022
G1 X125.873 Y87.398 E.0111
G1 X125.873 Y87.398 F9000
G1 X127.118 Y87.714
;WIDTH:0.399999
G1 F6000
G1 X127.104 Y87.695 E.00057
G1 X127.814 Y87.613 E.01738
G1 X128.712 Y87.372 E.02262
G1 X129.07 Y87.231 E.00936
G1 X129.637 Y86.949 E.0154
G1 X130.093 Y86.652 E.01324
G1 X130.774 Y86.074 E.02173
G1 X131.353 Y85.405 E.02152
G1 X131.641 Y84.951 E.01308
G1 X132.1 Y84.033 E.02497
G1 X132.347 Y83.172 E.02179
G1 X132.452 Y82.35 E.02016
G1 X132.461 Y79.111 E.07879
G1 X132.761 Y78.631 E.01377
G1 X132.907 Y78.26 E.0097
G1 X133.011 Y77.722 E.01333
G1 X132.98 Y77.048 E.01641
G1 X132.779 Y76.412 E.01622
G1 X132.373 Y75.666 E.02066
G1 X135.618 Y75.671 E.07893
G1 X136.176 Y75.725 E.01364
G1 X136.795 Y75.87 E.01546
G1 X137.328 Y76.082 E.01395
G1 X137.941 Y76.42 E.01703
G1 X138.562 Y76.938 E.01967
G1 X139.064 Y77.54 E.01907
G1 X139.449 Y78.223 E.01907
G1 X139.705 Y78.964 E.01907
G1 X139.785 Y79.489 E.01292
G1 X139.826 Y80.041 E.01346
G1 X139.828 Y91.478 E.27819
G1 X139.719 Y91.442 E.00279
G1 X139.202 Y91.358 E.01274
G1 X127.891 Y91.359 E.27513
G1 X127.98 Y90.952 E.01013
G1 X128.011 Y90.278 E.01641
G1 X127.927 Y89.804 E.01171
G1 X127.757 Y89.361 E.01154
G1 X127.463 Y88.891 E.01348
G1 X127.415 Y88.289 E.01469
G1 X127.312 Y87.995 E.00758
G1 X127.152 Y87.764 E.00684
G1 E-5 F3600
G1 X127.152 Y87.764 F9000
G1 X103.869 Y86.587
G1 X103.801 Y86.58
G1 X103.54 Y86.551
G1 X103.471 Y86.539
G1 X103.213 Y86.49
G1 X103.146 Y86.474
G1 X102.892 Y86.406
G1 X102.826 Y86.386
G1 X102.578 Y86.299
G1 X102.514 Y86.274
G1 X102.273 Y86.169
G1 X102.21 Y86.14
G1 X101.977 Y86.017
G1 X101.914 Y85.982
G1 X101.691 Y85.842
G1 X101.631 Y85.804
G1 X101.419 Y85.647
G1 X101.363 Y85.606
G1 X101.31 Y85.561
G1 X101.111 Y85.389
G1 X101.061 Y85.34
G1 X100.875 Y85.154
G1 X100.829 Y85.102
G1 X100.657 Y84.902
G1 X100.614 Y84.846
G1 X100.457 Y84.634
G1 X100.418 Y84.576
G1 X100.277 Y84.352
G1 X100.242 Y84.291
G1 X100.118 Y84.056
G1 X100.088 Y83.993
G1 X99.981 Y83.749
G1 X99.955 Y83.684
G1 X99.867 Y83.432
G1 X99.846 Y83.366
G1 X99.777 Y83.109
G1 X99.761 Y83.042
G1 X99.712 Y82.78
G1 X99.7 Y82.714
G1 X99.099 Y77.685
G1 X99.087 Y77.5
G1 X99.099 Y77.315
G1 X99.136 Y77.133
G1 X99.651 Y75.498
G1 X100.009 Y75.498
G1 X100.008 Y75.036
G1 E5 F2400
;WIDTH:0.589062
G1 F6000
G1 X100.183 Y75.028 E.00646
;WIDTH:0.580088
G1 X130.817 Y75.025 E1.11212
G1 E-5 F3600
G1 X130.817 Y75.025 F9000
G1 X130.817 Y75.498
G1 X131.349 Y75.498
G1 X131.864 Y77.133
G1 X131.901 Y77.315
G1 X131.913 Y77.5
G1 X131.901 Y77.685
G1 X131.3 Y82.714
G1 X131.288 Y82.78
G1 X131.239 Y83.042
G1 X131.223 Y83.109
G1 X131.154 Y83.366
G1 X131.133 Y83.432
G1 X131.045 Y83.684
G1 X131.019 Y83.749
G1 X130.912 Y83.993
G1 X130.882 Y84.056
G1 X130.758 Y84.291
G1 X130.723 Y84.352
G1 X130.582 Y84.576
G1 X130.543 Y84.634
G1 X130.386 Y84.846
G1 X130.343 Y84.902
G1 X130.171 Y85.102
G1 X130.125 Y85.154
G1 X129.939 Y85.34
G1 X129.889 Y85.389
G1 X129.69 Y85.561
G1 X129.637 Y85.606
G1 X129.581 Y85.647
G1 X129.369 Y85.804
G1 X129.309 Y85.842
G1 X129.086 Y85.982
G1 X129.023 Y86.017
G1 X128.79 Y86.14
G1 X128.727 Y86.169
G1 X128.486 Y86.274
G1 X128.422 Y86.299
G1 X128.174 Y86.386
G1 X128.108 Y86.406
G1 X127.854 Y86.474
G1 X127.787 Y86.49
G1 X127.529 Y86.539
G1 X127.46 Y86.551
G1 X127.199 Y86.58
G1 X127.131 Y86.587
G1 X126.868 Y86.597
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X104.626 Y87.572 E.01111
;WIDTH:0.43792
G1 X104.297 Y87.759 E.01016
;WIDTH:0.399999
G1 X104.03 Y88.127 E.01106
G1 X103.906 Y88.592 E.01171
G1 X103.903 Y89.01 E.01017
G1 X103.714 Y89.27 E.00782
G1 X103.561 Y89.548 E.00772
G1 X103.383 Y90.097 E.01404
G1 X103.351 Y90.673 E.01403
G1 X103.462 Y91.204 E.0132
G1 X103.711 Y91.725 E.01405
G1 X91.798 Y91.724 E.28977
G1 X91.346 Y91.793 E.01112
G1 X90.799 Y92.071 E.01492
G1 X90.797 Y80.039 E.29267
G1 X90.834 Y79.433 E.01477
G1 X90.936 Y78.875 E.0138
G1 X91.105 Y78.333 E.01381
G1 X91.338 Y77.816 E.01379
G1 X91.631 Y77.33 E.0138
G1 X91.982 Y76.883 E.01382
G1 X92.383 Y76.482 E.01379
G1 X92.83 Y76.131 E.01382
G1 X93.315 Y75.838 E.01378
G1 X93.819 Y75.611 E.01345
G1 X94.593 Y75.391 E.01957
G1 X95.223 Y75.308 E.01546
G1 X99.171 Y75.307 E.09603
G1 X98.911 Y75.884 E.01539
G1 X98.904 Y76.008 E.00302
G1 X98.714 Y76.27 E.00787
G1 X98.462 Y76.796 E.01419
G1 X98.351 Y77.327 E.0132
G1 X98.392 Y77.959 E.01541
G1 X98.574 Y78.483 E.01349
G1 X98.903 Y78.99 E.0147
G1 X98.907 Y82.145 E.07674
G1 X98.966 Y82.86 E.01745
G1 X99.072 Y83.364 E.01253
G1 X99.322 Y84.107 E.01907
G1 X99.678 Y84.803 E.01902
G1 X100.132 Y85.438 E.01899
G1 X100.672 Y85.998 E.01892
G1 X101.298 Y86.477 E.01917
G1 X101.856 Y86.796 E.01563
G1 X102.219 Y86.951 E.0096
G1 X102.799 Y87.153 E.01494
G1 X103.617 Y87.309 E.02026
G1 X104.2 Y87.347 E.01421
;WIDTH:0.43792
G1 X104.577 Y87.366 E.01013
;WIDTH:0.47584
G1 X104.895 Y87.382 E.00935
G1 X104.895 Y87.382 F9000
G1 X103.872 Y87.699
;WIDTH:0.399999
G1 F6000
G1 X103.7 Y87.969 E.00779
G1 X103.541 Y88.566 E.01503
G1 X103.537 Y88.891 E.00791
G1 X103.369 Y89.127 E.00705
G1 X103.122 Y89.661 E.01431
G1 X103.02 Y90.048 E.00973
G1 X102.989 Y90.722 E.01641
G1 X103.13 Y91.359 E.01587
G1 X91.798 Y91.358 E.27564
G1 X91.444 Y91.397 E.00866
G1 X91.164 Y91.488 E.00716
G1 X91.163 Y80.05 E.27822
G1 X91.197 Y79.478 E.01394
G1 X91.292 Y78.963 E.01274
G1 X91.447 Y78.463 E.01273
G1 X91.662 Y77.986 E.01273
G1 X91.933 Y77.538 E.01274
G1 X92.256 Y77.126 E.01273
G1 X92.626 Y76.756 E.01273
G1 X93.038 Y76.433 E.01273
G1 X93.486 Y76.162 E.01274
G1 X93.945 Y75.956 E.01224
G1 X94.667 Y75.75 E.01826
G1 X95.247 Y75.674 E.01423
G1 X98.624 Y75.673 E.08214
G1 X98.52 Y75.916 E.00643
G1 X98.221 Y76.412 E.01409
G1 X98.02 Y77.048 E.01622
G1 X97.989 Y77.722 E.01641
G1 X98.056 Y78.134 E.01015
G1 X98.238 Y78.628 E.01281
G1 X98.537 Y79.109 E.01378
G1 X98.542 Y82.172 E.0745
G1 X98.611 Y82.952 E.01905
G1 X98.723 Y83.474 E.01299
G1 X98.994 Y84.268 E.02041
G1 X99.377 Y85.011 E.02033
G1 X99.865 Y85.688 E.0203
G1 X100.444 Y86.284 E.02021
G1 X101.116 Y86.795 E.02053
G1 X101.674 Y87.113 E.01562
G1 X102.087 Y87.292 E.01095
G1 X102.731 Y87.512 E.01655
G1 X103.813 Y87.69 E.02667
G1 E-5 F3600
G1 X103.813 Y87.69 F9000
G1 X91.462 Y91.038
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.475842
G1 F1200
G1 X91.423 Y91.077 E.00162
G1 X91.437 Y91.131 E.00164
G1 X91.491 Y91.145 E.00164
G1 X91.53 Y91.106 E.00162
G1 X91.516 Y91.053 E.00161
;WIDTH:0.399999
G1 X92.04 Y91.084 E.01277
G1 X91.438 Y90.483 E.02069
G1 X91.438 Y89.966 E.01258
G1 X92.557 Y91.084 E.03848
G1 X93.074 Y91.084 E.01258
G1 X91.438 Y89.449 E.05626
G1 X91.438 Y88.931 E.0126
G1 X93.591 Y91.084 E.07406
G1 X94.108 Y91.084 E.01258
G1 X91.438 Y88.414 E.09185
G1 X91.438 Y87.897 E.01258
G1 X94.626 Y91.084 E.10965
G1 X95.143 Y91.084 E.01258
G1 X91.438 Y87.38 E.12743
G1 X91.438 Y86.862 E.0126
G1 X95.66 Y91.084 E.14523
G1 X96.177 Y91.084 E.01258
G1 X91.438 Y86.345 E.16302
G1 X91.438 Y85.828 E.01258
G1 X96.694 Y91.084 E.1808
G1 X97.211 Y91.085 E.01258
G1 X91.438 Y85.311 E.1986
G1 X91.438 Y84.794 E.01258
G1 X97.729 Y91.085 E.21641
G1 X98.246 Y91.085 E.01258
G1 X91.438 Y84.276 E.23421
G1 X91.437 Y83.759 E.01258
G1 X98.763 Y91.085 E.25201
G1 X99.28 Y91.085 E.01258
G1 X91.437 Y83.242 E.26979
G1 X91.437 Y82.725 E.01258
G1 X99.797 Y91.085 E.28758
G1 X100.314 Y91.085 E.01258
G1 X91.437 Y82.208 E.30536
G1 X91.437 Y81.69 E.0126
G1 X100.831 Y91.085 E.32316
G1 X101.349 Y91.085 E.0126
G1 X91.437 Y81.173 E.34097
G1 X91.437 Y80.656 E.01258
G1 X101.866 Y91.085 E.35875
G1 X102.383 Y91.085 E.01258
G1 X91.437 Y80.139 E.37654
G1 X91.462 Y79.647 E.01198
G1 X102.74 Y90.924 E.38794
G1 X102.87 Y91.122 E.00576
;WIDTH:0.374336
G1 X102.851 Y91.193 E.00166
G1 X102.922 Y91.174 E.00166
G1 X102.911 Y91.133 E.00096
G1 X102.911 Y91.133 F9000
G1 X102.716 Y90.384
;WIDTH:0.399999
G1 F1200
G1 X91.528 Y79.195 E.38488
G1 X91.634 Y78.785 E.0103
G1 X102.769 Y89.92 E.38304
G1 X102.886 Y89.519 E.01016
G1 X91.773 Y78.407 E.38226
G1 X91.94 Y78.056 E.00945
G1 X99.382 Y85.498 E.256
G1 X99.61 Y85.757 E.00839
;WIDTH:0.374336
G1 X100.107 Y86.285 E.0164
G1 X100.524 Y86.668 E.01281
;WIDTH:0.399999
G1 X100.783 Y86.899 E.00844
G1 X103.041 Y89.157 E.07767
G1 X103.238 Y88.838 E.00912
G1 X101.921 Y87.52 E.04532
G1 X101.692 Y87.314 E.00749
;WIDTH:0.374336
G1 X101.703 Y87.355 E.00096
G1 X101.632 Y87.374 E.00166
G1 X101.651 Y87.303 E.00166
G1 X101.651 Y87.303 F9000
G1 X102.423 Y87.59
G1 F1200
G1 X102.404 Y87.661 E.00166
G1 X102.475 Y87.642 E.00166
G1 X102.464 Y87.601 E.00096
;WIDTH:0.399999
G1 X102.693 Y87.775 E.007
G1 X103.31 Y88.392 E.02122
G1 X103.448 Y87.908 E.01224
;WIDTH:0.445518
G1 X103.462 Y87.958 E.00142
G1 X103.425 Y87.994 E.00141
G1 X103.376 Y87.981 E.00139
G1 X103.362 Y87.932 E.00139
G1 X103.399 Y87.895 E.00143
G1 E-5 F3600
G1 X103.399 Y87.895 F9000
G1 X98.931 Y84.547
G1 E5 F2400
;WIDTH:0.374336
G1 F1200
G1 X98.942 Y84.588 E.00096
G1 X98.871 Y84.607 E.00166
G1 X98.89 Y84.536 E.00166
;WIDTH:0.399999
G1 X98.719 Y84.318 E.00674
G1 X92.135 Y77.734 E.22649
G1 X92.358 Y77.44 E.00898
G1 X98.458 Y83.54 E.20984
G1 X98.603 Y83.757 E.00635
;WIDTH:0.374336
G1 X98.584 Y83.829 E.00168
G1 X98.655 Y83.809 E.00167
G1 X98.644 Y83.768 E.00096
G1 X98.644 Y83.768 F9000
G1 X98.329 Y82.893
;WIDTH:0.399999
G1 F1200
G1 X92.602 Y77.167 E.19699
G1 X92.867 Y76.915 E.0089
G1 X98.28 Y82.328 E.1862
G1 X98.267 Y81.798 E.0129
G1 X93.157 Y76.688 E.17578
G1 X93.475 Y76.489 E.00912
G1 X98.267 Y81.28 E.16482
G1 X98.266 Y80.762 E.0126
G1 X93.817 Y76.314 E.15303
G1 X94.191 Y76.171 E.00974
G1 X98.265 Y80.244 E.14013
G1 X98.264 Y79.726 E.0126
G1 X94.594 Y76.056 E.12625
G1 X95.033 Y75.978 E.01085
G1 X98.263 Y79.208 E.11111
G1 X98.263 Y79.208 F9000
G1 X97.971 Y78.306
;WIDTH:0.374336
G1 F1200
G1 X97.959 Y78.484 E.00403
;WIDTH:0.399999
G1 X97.797 Y78.225 E.00743
G1 X95.52 Y75.948 E.07833
G1 X96.037 Y75.948 E.01258
G1 X97.716 Y77.627 E.05776
G1 X97.733 Y77.126 E.01219
G1 X96.554 Y75.948 E.04054
G1 X97.071 Y75.947 E.01258
G1 X97.828 Y76.705 E.02606
G1 X97.962 Y76.322 E.00987
G1 X97.588 Y75.947 E.01288
G1 X98.128 Y75.914 E.01316
;WIDTH:0.429824
G1 X98.106 Y75.997 E.00226
G1 X98.189 Y75.975 E.00226
G1 X98.176 Y75.927 E.00131
G1 E-5 F3600
G1 X98.176 Y75.927 F9000
G1 X99.761 Y83.042
G1 X99.777 Y83.109
G1 X99.846 Y83.366
G1 X99.867 Y83.432
G1 X99.955 Y83.684
G1 X99.981 Y83.749
G1 X100.088 Y83.993
G1 X100.118 Y84.056
G1 X100.242 Y84.291
G1 X100.277 Y84.352
G1 X100.418 Y84.576
G1 X100.457 Y84.634
G1 X100.614 Y84.846
G1 X100.657 Y84.902
G1 X100.829 Y85.102
G1 X100.875 Y85.154
G1 X101.061 Y85.34
G1 X101.111 Y85.389
G1 X101.31 Y85.561
G1 X101.363 Y85.606
G1 X101.419 Y85.647
G1 X101.631 Y85.804
G1 X101.691 Y85.842
G1 X101.914 Y85.982
G1 X101.977 Y86.017
G1 X102.21 Y86.14
G1 X102.273 Y86.169
G1 X102.514 Y86.274
G1 X102.578 Y86.299
G1 X102.826 Y86.386
G1 X102.892 Y86.406
G1 X103.146 Y86.474
G1 X103.213 Y86.49
G1 X103.471 Y86.539
G1 X103.54 Y86.551
G1 X103.801 Y86.58
G1 X103.869 Y86.587
G1 X126.349 Y88.151
G1 X128.239 Y91.002
G1 E5 F2400
;WIDTH:0.461662
G1 F1200
G1 X128.202 Y91.04 E.00151
G1 X128.215 Y91.092 E.00152
G1 X128.267 Y91.106 E.00153
G1 X128.305 Y91.068 E.00153
G1 X128.291 Y91.016 E.00153
;WIDTH:0.399999
G1 X128.284 Y90.524 E.01197
G1 X128.974 Y91.2 E.0235
;WIDTH:0.374336
G1 X128.955 Y91.271 E.00166
G1 X129.026 Y91.252 E.00166
G1 X129.015 Y91.211 E.00096
;WIDTH:0.399999
G1 X129.362 Y91.085 E.00898
G1 X128.241 Y89.964 E.03856
G1 X128.128 Y89.678 E.00748
;WIDTH:0.374336
G1 X128.139 Y89.719 E.00096
G1 X128.068 Y89.739 E.00167
G1 X128.087 Y89.667 E.00168
G1 X128.087 Y89.667 F9000
G1 X127.752 Y88.876
G1 F1200
G1 X127.733 Y88.947 E.00166
G1 X127.804 Y88.928 E.00166
G1 X127.793 Y88.887 E.00096
;WIDTH:0.399999
G1 X127.966 Y89.172 E.00811
G1 X129.879 Y91.085 E.06581
G1 X130.396 Y91.085 E.01258
G1 X127.707 Y88.396 E.0925
G1 X127.472 Y87.835 E.01479
;WIDTH:0.374336
G1 X127.453 Y87.906 E.00166
G1 X127.524 Y87.887 E.00166
G1 X127.513 Y87.846 E.00096
;WIDTH:0.399999
G1 X127.73 Y87.902 E.00545
G1 X130.913 Y91.085 E.10949
G1 X131.43 Y91.085 E.01258
G1 X128.151 Y87.806 E.1128
G1 X128.559 Y87.696 E.01028
G1 X131.947 Y91.085 E.11656
G1 X132.464 Y91.085 E.01258
G1 X128.956 Y87.576 E.12069
G1 X129.315 Y87.418 E.00954
G1 X132.981 Y91.085 E.12613
G1 X133.499 Y91.085 E.0126
G1 X129.66 Y87.246 E.13206
G1 X129.985 Y87.053 E.00919
G1 X134.016 Y91.085 E.13868
G1 X134.533 Y91.084 E.01258
G1 X130.286 Y86.838 E.14608
G1 X130.578 Y86.613 E.00897
G1 X135.05 Y91.084 E.15382
G1 X135.567 Y91.084 E.01258
G1 X130.856 Y86.374 E.16204
G1 X131.106 Y86.106 E.00891
G1 X136.084 Y91.084 E.17124
G1 X136.601 Y91.084 E.01258
G1 X131.343 Y85.826 E.18087
G1 X131.58 Y85.546 E.00892
G1 X137.118 Y91.084 E.1905
G1 X137.635 Y91.084 E.01258
G1 X131.789 Y85.238 E.2011
G1 X131.972 Y84.904 E.00926
G1 X138.152 Y91.084 E.21259
G1 X138.669 Y91.084 E.01258
G1 X132.155 Y84.57 E.22408
G1 X132.319 Y84.217 E.00947
G1 X139.187 Y91.084 E.23624
G1 X139.649 Y91.186 E.01151
;WIDTH:0.374336
G1 X139.66 Y91.227 E.00096
G1 X139.589 Y91.247 E.00167
G1 X139.608 Y91.175 E.00168
;WIDTH:0.399999
G1 X139.554 Y90.934 E.00601
G1 X132.45 Y83.83 E.24437
G1 X132.568 Y83.432 E.0101
G1 X139.554 Y90.417 E.2403
G1 X139.554 Y89.9 E.01258
G1 X132.65 Y82.996 E.23749
G1 X132.712 Y82.541 E.01117
G1 X139.554 Y89.383 E.23536
G1 X139.554 Y88.866 E.01258
G1 X132.727 Y82.039 E.23484
G1 X132.728 Y81.523 E.01255
G1 X139.553 Y88.348 E.23478
G1 X139.553 Y87.831 E.01258
G1 X132.73 Y81.008 E.23471
G1 X132.731 Y80.492 E.01255
G1 X139.553 Y87.314 E.23467
G1 X139.553 Y86.797 E.01258
G1 X132.733 Y79.976 E.23462
G1 X132.734 Y79.461 E.01253
G1 X139.553 Y86.28 E.23457
G1 X139.553 Y85.762 E.0126
G1 X132.831 Y79.04 E.23123
G1 X133.023 Y78.715 E.00918
G1 X139.553 Y85.245 E.22463
G1 X139.553 Y84.728 E.01258
G1 X133.165 Y78.34 E.21974
G1 X133.259 Y77.917 E.01054
G1 X139.553 Y84.211 E.21651
G1 X139.553 Y83.694 E.01258
G1 X133.284 Y77.424 E.21567
G1 X133.204 Y76.828 E.01463
G1 X139.553 Y83.176 E.21838
G1 X139.553 Y82.659 E.01258
G1 X132.834 Y75.941 E.23111
G1 X132.638 Y75.79 E.00602
;WIDTH:0.374336
G1 X132.649 Y75.831 E.00096
G1 X132.577 Y75.85 E.00168
G1 X132.596 Y75.779 E.00166
G1 X132.596 Y75.779 F9000
G1 X133.352 Y75.941
;WIDTH:0.399999
G1 F1200
G1 X139.553 Y82.142 E.21331
G1 X139.552 Y81.625 E.01258
G1 X133.87 Y75.942 E.19547
G1 X134.388 Y75.943 E.0126
G1 X139.552 Y81.107 E.17764
G1 X139.552 Y80.59 E.01258
G1 X134.906 Y75.944 E.15982
G1 X135.423 Y75.944 E.01258
G1 X139.552 Y80.073 E.14203
G1 X139.511 Y79.515 E.01361
G1 X135.964 Y75.968 E.12201
G1 X136.615 Y76.102 E.01617
G1 X139.382 Y78.868 E.09517
G1 E-5 F3600
G1 X139.382 Y78.868 F9000
G1 X137.511 Y76.481
G1 E5 F2400
G1 F1200
G1 X138.98 Y77.95 E.05053
G1 X139.177 Y78.208 E.0079
;WIDTH:0.374336
G1 X139.173 Y78.056 E.00344
G1 X138.881 Y77.666 E.01102
G1 X138.381 Y77.119 E.01676
G1 X137.431 Y76.303 E.02832
G1 X137.253 Y76.299 E.00403
G1 E-5 F3600
G1 X137.253 Y76.299 F9000
G1 X126.602 Y89.571
G1 X126.349 Y88.151
G1 X104.651 Y88.151
G1 X91.407 Y92.554
G1 X91.235 Y92.651
G1 X91.126 Y92.744
G1 X91.07 Y92.795
G1 X90.751 Y93.111
G1 X90.751 Y95.718
G1 X92.053 Y153.369
G1 E5 F2400
G1 F1200
G1 X92.385 Y153.744 E.01133
G1 X93.108 Y154.428 E.02251
G1 X93.108 Y154.428 F9000
G1 X93.917 Y154.75
G1 F1200
G1 X93.928 Y154.791 E.00096
G1 X93.857 Y154.81 E.00166
G1 X93.876 Y154.739 E.00166
;WIDTH:0.399999
G1 X93.629 Y154.602 E.00687
G1 X91.905 Y152.878 E.0593
G1 X91.762 Y152.592 E.00778
;WIDTH:0.374336
G1 X91.773 Y152.633 E.00096
G1 X91.702 Y152.652 E.00166
G1 X91.721 Y152.581 E.00166
;WIDTH:0.399999
G1 X91.586 Y152.041 E.01354
G1 X94.468 Y154.924 E.09916
G1 X95.096 Y155.035 E.01551
G1 X91.467 Y151.406 E.12484
G1 X91.448 Y150.869 E.01307
G1 X95.641 Y155.062 E.14424
G1 X96.158 Y155.062 E.01258
G1 X91.448 Y150.352 E.16202
G1 X91.448 Y149.835 E.01258
G1 X96.675 Y155.062 E.17981
G1 X97.192 Y155.062 E.01258
G1 X91.447 Y149.318 E.19761
G1 X91.447 Y148.8 E.0126
G1 X97.709 Y155.062 E.21541
G1 X98.226 Y155.062 E.01258
G1 X91.447 Y148.283 E.23319
G1 X91.447 Y147.766 E.01258
G1 X98.743 Y155.062 E.25098
G1 X99.26 Y155.062 E.01258
G1 X91.447 Y147.249 E.26876
G1 X91.447 Y146.732 E.01258
G1 X99.777 Y155.061 E.28653
G1 X100.294 Y155.061 E.01258
G1 X91.447 Y146.214 E.30433
G1 X91.447 Y145.697 E.01258
G1 X100.811 Y155.061 E.32212
G1 X101.328 Y155.061 E.01258
G1 X91.447 Y145.18 E.3399
G1 X91.447 Y144.663 E.01258
G1 X101.845 Y155.061 E.35768
G1 X102.362 Y155.061 E.01258
G1 X91.447 Y144.146 E.37547
G1 X91.447 Y143.628 E.0126
G1 X102.879 Y155.061 E.39327
G1 X103.396 Y155.061 E.01258
G1 X91.447 Y143.111 E.41105
G1 X91.446 Y142.594 E.01258
G1 X103.913 Y155.06 E.42884
G1 X104.43 Y155.06 E.01258
G1 X91.446 Y142.077 E.44662
G1 X91.446 Y141.56 E.01258
G1 X104.947 Y155.06 E.46441
G1 X105.464 Y155.06 E.01258
G1 X91.446 Y141.042 E.48221
G1 X91.446 Y140.525 E.01258
G1 X105.981 Y155.06 E.49999
G1 X106.498 Y155.06 E.01258
G1 X91.446 Y140.008 E.51778
G1 X91.446 Y139.491 E.01258
G1 X107.015 Y155.06 E.53556
G1 X107.532 Y155.06 E.01258
G1 X91.446 Y138.974 E.55335
G1 X91.446 Y138.456 E.0126
G1 X108.049 Y155.059 E.57113
G1 X108.566 Y155.059 E.01258
G1 X91.446 Y137.939 E.58892
G1 X91.446 Y137.422 E.01258
G1 X109.083 Y155.059 E.6067
G1 X109.083 Y155.059 F9000
G1 X109.888 Y155.136
;WIDTH:0.374336
G1 F1200
G1 X109.899 Y155.177 E.00096
G1 X109.828 Y155.196 E.00166
G1 X109.847 Y155.125 E.00166
;WIDTH:0.399999
G1 X109.6 Y155.059 E.00622
G1 X91.446 Y136.905 E.62449
G1 X91.445 Y136.388 E.01258
G1 X95.788 Y140.738 E.14952
;WIDTH:0.388756
G1 X96.322 Y141.279 E.01792
;WIDTH:0.399999
G1 X110.117 Y155.059 E.47428
G1 X110.634 Y155.059 E.01258
G1 X98.451 Y142.876 E.41909
G1 X98.192 Y142.674 E.00799
;WIDTH:0.374336
G1 X97.467 Y142.079 E.02121
G1 E-5 F3600
G1 X97.467 Y142.079 F9000
G1 X99.271 Y143.225
G1 E5 F2400
G1 F1200
G1 X99.252 Y143.296 E.00166
G1 X99.323 Y143.277 E.00166
G1 X99.312 Y143.236 E.00096
;WIDTH:0.399999
G1 X111.151 Y155.059 E.40698
G1 X111.668 Y155.059 E.01258
G1 X100.409 Y143.8 E.3873
G1 X100.181 Y143.602 E.00735
;WIDTH:0.374336
G1 X100.192 Y143.643 E.00096
G1 X100.121 Y143.662 E.00166
G1 X100.14 Y143.591 E.00166
G1 X100.14 Y143.591 F9000
G1 X100.921 Y143.894
G1 F1200
G1 X101.064 Y143.874 E.00327
G1 X101.13 Y143.893 E.00155
;WIDTH:0.399999
G1 X101.18 Y144.053 E.00408
G1 X112.185 Y155.058 E.37856
G1 X112.702 Y155.058 E.01258
G1 X101.885 Y144.241 E.3721
G1 X102.529 Y144.368 E.01597
G1 X113.219 Y155.058 E.36773
G1 X113.736 Y155.058 E.01258
G1 X103.129 Y144.451 E.36487
G1 X103.703 Y144.508 E.01403
G1 X114.253 Y155.058 E.36291
G1 X114.77 Y155.058 E.01258
G1 X104.24 Y144.528 E.36222
G1 X104.766 Y144.537 E.0128
G1 X115.287 Y155.058 E.36192
G1 X115.804 Y155.058 E.01258
G1 X105.283 Y144.537 E.36192
G1 X105.801 Y144.537 E.0126
G1 X116.321 Y155.057 E.36188
G1 X116.838 Y155.057 E.01258
G1 X106.318 Y144.537 E.36188
G1 X106.835 Y144.537 E.01258
G1 X117.355 Y155.057 E.36188
G1 X117.872 Y155.057 E.01258
G1 X107.352 Y144.537 E.36188
G1 X107.869 Y144.537 E.01258
G1 X118.389 Y155.057 E.36188
G1 X118.906 Y155.057 E.01258
G1 X108.386 Y144.537 E.36188
G1 X108.903 Y144.537 E.01258
G1 X119.423 Y155.057 E.36188
G1 X119.94 Y155.057 E.01258
G1 X109.42 Y144.537 E.36188
G1 X109.938 Y144.537 E.0126
G1 X120.457 Y155.056 E.36185
G1 X120.974 Y155.056 E.01258
G1 X110.455 Y144.537 E.36185
G1 X110.925 Y144.49 E.01149
G1 X121.491 Y155.056 E.36346
G1 X122.008 Y155.056 E.01258
G1 X111.314 Y144.362 E.36787
G1 X111.777 Y144.308 E.01134
G1 X122.525 Y155.056 E.36972
G1 X123.042 Y155.056 E.01258
G1 X112.295 Y144.308 E.36971
G1 X112.812 Y144.308 E.01258
G1 X123.559 Y155.056 E.36971
G1 X124.076 Y155.056 E.01258
G1 X113.329 Y144.308 E.36971
G1 X113.846 Y144.308 E.01258
G1 X124.593 Y155.055 E.36969
G1 X125.11 Y155.055 E.01258
G1 X114.363 Y144.308 E.36969
G1 X114.88 Y144.308 E.01258
G1 X125.627 Y155.055 E.36969
G1 X126.144 Y155.055 E.01258
G1 X115.397 Y144.308 E.36969
G1 X115.914 Y144.308 E.01258
G1 X126.661 Y155.055 E.36969
G1 X127.178 Y155.055 E.01258
G1 X116.432 Y144.308 E.36967
G1 X116.949 Y144.308 E.01258
G1 X127.695 Y155.055 E.36967
G1 X128.212 Y155.055 E.01258
G1 X117.466 Y144.308 E.36967
G1 X117.983 Y144.308 E.01258
G1 X128.729 Y155.054 E.36966
G1 X129.246 Y155.054 E.01258
G1 X118.5 Y144.308 E.36966
G1 X119.017 Y144.308 E.01258
G1 X129.763 Y155.054 E.36966
G1 X130.28 Y155.054 E.01258
G1 X119.534 Y144.308 E.36966
G1 X119.997 Y144.334 E.01128
;WIDTH:0.374336
G1 X119.978 Y144.405 E.00166
G1 X120.049 Y144.386 E.00166
G1 X120.038 Y144.345 E.00096
;WIDTH:0.399999
G1 X120.267 Y144.524 E.00707
G1 X130.797 Y155.054 E.36222
G1 X131.314 Y155.054 E.01258
G1 X120.797 Y144.537 E.36178
G1 X121.314 Y144.537 E.01258
G1 X131.831 Y155.054 E.36178
G1 X132.348 Y155.054 E.01258
G1 X121.831 Y144.536 E.36179
G1 X122.347 Y144.536 E.01255
G1 X132.865 Y155.053 E.36179
G1 X133.382 Y155.053 E.01258
G1 X122.864 Y144.536 E.36179
G1 X123.381 Y144.535 E.01258
G1 X133.899 Y155.053 E.36181
G1 X134.416 Y155.053 E.01258
G1 X123.898 Y144.535 E.36181
G1 X124.415 Y144.535 E.01258
G1 X134.933 Y155.053 E.36181
G1 X135.45 Y155.053 E.01258
G1 X124.931 Y144.534 E.36185
G1 X125.448 Y144.534 E.01258
G1 X135.941 Y155.027 E.36095
G1 X136.386 Y154.955 E.01096
G1 X125.965 Y144.534 E.35848
G1 X126.482 Y144.533 E.01258
G1 X136.789 Y154.84 E.35455
G1 X137.154 Y154.689 E.00961
G1 X126.988 Y144.522 E.34972
G1 X127.478 Y144.496 E.01194
G1 X137.505 Y154.522 E.3449
G1 X137.824 Y154.324 E.00913
G1 X127.945 Y144.445 E.33983
G1 X128.399 Y144.382 E.01115
G1 X138.114 Y154.097 E.33419
G1 X138.382 Y153.848 E.0089
G1 X128.836 Y144.302 E.32838
G1 X129.26 Y144.209 E.01056
G1 X138.629 Y153.577 E.32227
G1 X138.854 Y153.286 E.00895
G1 X129.665 Y144.097 E.3161
G1 X130.063 Y143.978 E.0101
G1 X139.048 Y152.963 E.30908
G1 X139.217 Y152.614 E.00943
G1 X130.461 Y143.859 E.30118
G1 X130.833 Y143.713 E.00972
G1 X139.358 Y152.239 E.29327
G1 X139.468 Y151.831 E.01028
G1 X131.204 Y143.567 E.28428
G1 X131.558 Y143.404 E.00948
G1 X139.537 Y151.383 E.27447
G1 X139.563 Y150.892 E.01196
G1 X131.909 Y143.238 E.26329
G1 X132.24 Y143.052 E.00924
G1 X139.563 Y150.375 E.25191
G1 X139.563 Y149.858 E.01258
G1 X132.569 Y142.864 E.24059
G1 X132.896 Y142.674 E.0092
G1 X139.563 Y149.34 E.22932
G1 X139.563 Y148.823 E.01258
G1 X133.202 Y142.463 E.2188
G1 X133.509 Y142.252 E.00906
G1 X139.563 Y148.306 E.20825
G1 X139.563 Y147.789 E.01258
G1 X133.805 Y142.031 E.19807
G1 X134.088 Y141.797 E.00893
G1 X139.563 Y147.272 E.18834
G1 X139.562 Y146.754 E.0126
G1 X134.37 Y141.562 E.1786
G1 X134.645 Y141.32 E.00891
G1 X139.562 Y146.237 E.16914
G1 X139.562 Y145.72 E.01258
G1 X134.908 Y141.066 E.16009
G1 X135.162 Y140.803 E.00889
G1 X139.562 Y145.203 E.15136
G1 X139.562 Y144.686 E.01258
G1 X135.406 Y140.53 E.14296
G1 X135.651 Y140.257 E.00892
G1 X139.562 Y144.168 E.13454
G1 X139.562 Y143.651 E.01258
G1 X135.881 Y139.97 E.12662
G1 X136.107 Y139.679 E.00896
G1 X139.562 Y143.134 E.11885
G1 X139.562 Y142.617 E.01258
G1 X136.321 Y139.376 E.11149
G1 X136.53 Y139.068 E.00905
G1 X139.562 Y142.1 E.1043
G1 X139.562 Y141.582 E.0126
G1 X136.722 Y138.742 E.09769
G1 E-5 F3600
G1 X136.722 Y138.742 F9000
G1 X138.424 Y132.99
G1 E5 F2400
G1 F1200
G1 X138.371 Y133.831 E.0205
G1 X138.281 Y134.515 E.01678
G1 X138.141 Y135.231 E.01775
G1 X137.949 Y135.973 E.01864
G1 X137.551 Y137.107 E.02923
G1 X137.052 Y138.176 E.0287
G1 X136.912 Y138.416 E.00676
G1 X139.562 Y141.065 E.09114
G1 X139.555 Y97.689 E1.05508
G1 X138.996 Y97.744 E.01366
G1 X138.437 Y97.744 E.0136
G1 X138.435 Y132.807 E.85287
G1 X138.808 Y132.807 E.00907
;WIDTH:0.4143
G1 X138.808 Y98.115 E.87685
;WIDTH:0.410631
G1 X139.184 Y98.115 E.00941
G1 X139.184 Y98.303 E.00471
;WIDTH:0.4143
G1 X139.187 Y132.807 E.8721
;WIDTH:0.415028
G1 X139.187 Y132.854 E.00119
;WIDTH:0.446754
G1 X139.171 Y133.869 E.02785
;WIDTH:0.449364
G1 X139.17 Y133.922 E.00146
;WIDTH:0.498113
G1 X139.146 Y134.65 E.02247
G1 X139.17 Y135.009 E.0111
;WIDTH:0.449056
G1 X139.195 Y135.368 E.00993
;WIDTH:0.399999
G1 X139.196 Y140.182 E.1171
G1 X137.391 Y138.378 E.06207
G1 X137.383 Y138.331 E.00116
G1 X137.896 Y137.228 E.02959
G1 X138.289 Y136.109 E.02885
G1 X138.5 Y135.301 E.02031
;WIDTH:0.446968
G1 X138.595 Y134.935 E.01038
;WIDTH:0.493936
G1 X138.69 Y134.569 E.01156
G1 X138.759 Y133.856 E.0219
;WIDTH:0.446754
G1 X138.8 Y132.99 E.02378
G1 E-5 F3600
G1 X138.8 Y132.99 F9000
G1 X138.829 Y135.492
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X138.83 Y139.299 E.0926
G1 X137.811 Y138.28 E.03505
G1 X138.241 Y137.349 E.02494
G1 X138.634 Y136.23 E.02885
G1 X138.783 Y135.669 E.01412
G1 E-5 F3600
G1 X138.783 Y135.669 F9000
G1 X138.349 Y138.115
G1 E5 F2400
;WIDTH:0.594024
G1 F1200
G1 X138.3 Y138.164 E.00258
G1 X138.318 Y138.232 E.00262
G1 X138.385 Y138.25 E.00258
G1 X138.435 Y138.2 E.00263
G1 X138.417 Y138.133 E.00258
G1 E-5 F3600
G1 X138.417 Y138.133 F9000
G1 X131.67 Y141.795
G1 X131.325 Y141.98
G1 X131.294 Y141.997
G1 X131.262 Y142.013
G1 X131.229 Y142.029
G1 X130.885 Y142.194
G1 X130.854 Y142.208
G1 X130.822 Y142.223
G1 X130.788 Y142.238
G1 X130.747 Y142.255
G1 X130.451 Y142.38
G1 X130.412 Y142.396
G1 X130.319 Y142.433
G1 X129.95 Y142.569
G1 X129.827 Y142.61
G1 X129.59 Y142.685
G1 X129.466 Y142.723
G1 X129.311 Y142.767
G1 X129.119 Y142.818
G1 X128.962 Y142.858
G1 X128.775 Y142.9
G1 X128.629 Y142.931
G1 X128.437 Y142.969
G1 X128.221 Y143.007
G1 X128.12 Y143.023
G1 X127.897 Y143.056
G1 X127.593 Y143.092
G1 X127.346 Y143.115
G1 X127.295 Y143.118
G1 X127.05 Y143.134
G1 X126.792 Y143.145
G1 X126.758 Y143.145
G1 X126.504 Y143.149
G1 X104.496 Y143.149
G1 X104.242 Y143.145
G1 X104.208 Y143.145
G1 X103.95 Y143.134
G1 X103.705 Y143.118
G1 X103.654 Y143.115
G1 X103.407 Y143.092
G1 X103.103 Y143.056
G1 X102.88 Y143.023
G1 X102.779 Y143.007
G1 X102.563 Y142.969
G1 X102.371 Y142.931
G1 X102.225 Y142.9
G1 X102.039 Y142.858
G1 X101.881 Y142.818
G1 X101.689 Y142.767
G1 X101.534 Y142.723
G1 X101.41 Y142.685
G1 X101.173 Y142.61
G1 X101.05 Y142.569
G1 X100.681 Y142.433
G1 X100.588 Y142.396
G1 X100.549 Y142.38
G1 X100.253 Y142.255
G1 X100.212 Y142.238
G1 X100.178 Y142.223
G1 X100.146 Y142.208
G1 X100.114 Y142.193
G1 X99.771 Y142.029
G1 X99.738 Y142.013
G1 X99.706 Y141.997
G1 X99.675 Y141.98
G1 X99.33 Y141.795
G1 X99.219 Y141.731
G1 X98.907 Y141.544
G1 X98.798 Y141.474
G1 X98.495 Y141.273
G1 X98.39 Y141.198
G1 X98.097 Y140.983
G1 X91.613 Y136.038
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X94.242 Y138.666 E.09042
G1 X93.791 Y137.865 E.02236
G1 X93.304 Y136.733 E.02997
G1 X92.904 Y135.415 E.0335
G1 X92.639 Y133.919 E.03696
G1 X92.565 Y132.807 E.02711
G1 X92.563 Y97.744 E.85287
G1 X92.001 Y97.744 E.01367
G1 X91.44 Y97.688 E.01371
G1 X91.445 Y136 E.9319
G1 E-5 F3600
G1 X91.445 Y136 F9000
G1 X91.819 Y132.99
G1 E5 F2400
;WIDTH:0.448994
G1 F1200
G1 X91.835 Y133.959 E.02673
;WIDTH:0.454218
G1 X91.824 Y134.795 E.02335
;WIDTH:0.427109
G1 X91.811 Y135.544 E.01957
;WIDTH:0.399999
G1 X91.833 Y135.741 E.00482
G1 X92.967 Y136.875 E.03901
G1 X92.544 Y135.479 E.03548
;WIDTH:0.427109
G1 X92.399 Y134.744 E.01957
;WIDTH:0.454218
G1 X92.249 Y133.945 E.02271
;WIDTH:0.448994
G1 X92.195 Y132.844 E.03041
;WIDTH:0.412501
G1 X92.194 Y132.807 E.00093
;WIDTH:0.413291
G1 X92.191 Y98.116 E.8745
G1 X91.812 Y98.117 E.00955
G1 X91.816 Y132.807 E.87447
G1 E-5 F3600
G1 X91.816 Y132.807 F9000
G1 X92.17 Y135.519
G1 E5 F2400
;WIDTH:0.411462
G1 F1200
G1 X92.149 Y135.598 E.00205
G1 X92.228 Y135.577 E.00205
G1 X92.216 Y135.532 E.00117
;LAYER_CHANGE
;Z:0.78
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;0.78
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X92.228 Y135.577 E-.02212
G1 X92.149 Y135.598 E-.03883
G1 X92.17 Y135.519 E-.03883
;WIPE_END
G1 E-1.40022 F3600
G1 Z.78 F9000
;AFTER_LAYER_CHANGE
;0.78
G1 Z.78
G1 X94.473 Y135.874
G1 X96.162 Y136.134
G1 X103.907 Y137.333
G1 X103.906 Y137.357
G1 X104.263 Y137.382
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X104.247 Y137.475 E.0023
G1 X104.31 Y137.831 E.00879
G1 X104.47 Y138.142 E.00851
G1 X105 Y138.766 E.01991
G1 X105.001 Y139.339 E.01394
G1 X105.094 Y139.477 E.00405
G1 X105.182 Y139.5 E.00221
G1 X125.817 Y139.5 E.50193
G1 X125.924 Y139.465 E.00274
G1 X126 Y139.317 E.00405
G1 X126 Y138.766 E.0134
G1 X126.512 Y138.163 E.01924
G1 X126.711 Y137.769 E.01074
G1 X126.753 Y137.525 E.00602
G1 X126.69 Y137.169 E.00879
G1 X126.53 Y136.858 E.00851
G1 X126 Y136.234 E.01991
G1 X126 Y103.974 E.78469
G1 X126.133 Y103.974 E.00324
G1 X126.285 Y103.892 E.0042
G1 X126.316 Y103.792 E.00255
G1 X126.316 Y98.457 E.12977
G1 X126.311 Y98.419 E.00093
G1 X126.133 Y98.274 E.00558
G1 X126 Y98.274 E.00324
G1 X126 Y93.502 E.11607
G1 X126.046 Y93.413 E.00244
G1 X138.248 Y93.415 E.2968
G1 X139.039 Y93.439 E.01925
G1 X139.168 Y93.568 E.00444
G1 X139.243 Y93.849 E.00707
G1 X139.25 Y94.865 E.02471
G1 X139.205 Y95.178 E.00769
G1 X139.103 Y95.329 E.00443
G1 X138.929 Y95.413 E.0047
G1 X136.183 Y95.413 E.06679
G1 X136.074 Y95.45 E.0028
G1 X136 Y95.596 E.00398
G1 X136 Y127.168 E.76796
G1 X135.978 Y127.642 E.01154
G1 X135.978 Y132.948 E.12906
G1 X135.86 Y133.942 E.02435
G1 X135.696 Y134.722 E.01939
G1 X135.425 Y135.607 E.02251
G1 X135.21 Y136.153 E.01427
G1 X134.867 Y136.874 E.01942
G1 X134.396 Y137.672 E.02254
G1 X134.06 Y138.152 E.01425
G1 X133.558 Y138.773 E.01942
G1 X132.914 Y139.439 E.02253
G1 X132.474 Y139.826 E.01425
G1 X131.841 Y140.314 E.01944
G1 X131.06 Y140.81 E.0225
G1 X130.541 Y141.084 E.01428
G1 X129.812 Y141.41 E.01942
G1 X128.936 Y141.71 E.02252
G1 X128.368 Y141.855 E.01426
G1 X127.585 Y142.002 E.01938
G1 X126.193 Y142.1 E.03394
G1 X120.85 Y142.1 E.12996
G1 X120.85 Y141.982 E.00287
G1 X120.778 Y141.836 E.00396
G1 X120.667 Y141.799 E.00285
G1 X110.333 Y141.799 E.25136
G1 X110.223 Y141.836 E.00282
G1 X110.15 Y141.982 E.00397
G1 X110.15 Y142.1 E.00287
G1 X104.339 Y142.089 E.14135
G1 X103.082 Y141.946 E.03077
G1 X102.51 Y141.829 E.0142
G1 X101.621 Y141.57 E.02252
G1 X100.877 Y141.279 E.01943
G1 X100.348 Y141.031 E.01421
G1 X99.158 Y140.313 E.03381
G1 X98.175 Y139.521 E.03071
G1 X97.757 Y139.116 E.01416
G1 X96.864 Y138.05 E.03383
G1 X96.191 Y136.983 E.03069
G1 X95.928 Y136.464 E.01415
G1 X95.428 Y135.166 E.03383
G1 X95.191 Y134.163 E.02507
G1 X95.074 Y133.484 E.01676
G1 X95.021 Y132.951 E.01303
G1 X95.021 Y127.642 E.12914
G1 X94.999 Y127.607 E.00101
G1 X94.999 Y95.596 E.77864
G1 X94.926 Y95.45 E.00397
G1 X94.816 Y95.413 E.00282
G1 X92.192 Y95.413 E.06383
G1 X91.92 Y95.36 E.00674
G1 X91.852 Y95.273 E.00269
G1 X91.758 Y95.032 E.00629
G1 X91.758 Y93.875 E.02814
G1 X91.813 Y93.633 E.00604
G1 X91.907 Y93.492 E.00412
G1 X92.071 Y93.415 E.00441
G1 X104.913 Y93.415 E.31237
G1 X105 Y93.471 E.00252
G1 X105 Y98.274 E.11683
G1 X104.867 Y98.274 E.00324
G1 X104.7 Y98.384 E.00486
G1 X104.685 Y98.457 E.00181
G1 X104.685 Y103.792 E.12977
G1 X104.696 Y103.854 E.00153
G1 X104.867 Y103.974 E.00508
G1 X105 Y103.974 E.00324
G1 X105 Y136.234 E.78469
G1 X104.47 Y136.858 E.01991
G1 X104.289 Y137.231 E.01008
G1 X104.273 Y137.323 E.00227
G1 X104.273 Y137.323 F9000
G1 X103.904 Y137.334
;TYPE:Perimeter
G1 F6000
G1 X103.885 Y137.426 E.00229
G1 X103.961 Y137.942 E.01269
G1 X104.191 Y138.379 E.01201
G1 X104.634 Y138.9 E.01663
G1 X104.634 Y139.317 E.01014
G1 X104.685 Y139.546 E.00571
G1 X104.917 Y139.797 E.00831
G1 X105.182 Y139.866 E.00666
G1 X125.817 Y139.866 E.50193
G1 X125.912 Y139.857 E.00232
G1 X126.139 Y139.762 E.00599
G1 X126.276 Y139.618 E.00483
G1 X126.347 Y139.461 E.00419
G1 X126.366 Y138.9 E.01365
G1 X126.809 Y138.379 E.01663
G1 X127.042 Y137.924 E.01243
G1 X127.115 Y137.574 E.0087
G1 X127.041 Y137.064 E.01254
G1 X126.809 Y136.621 E.01216
G1 X126.366 Y136.1 E.01663
G1 X126.366 Y104.215 E.77557
G1 X126.59 Y104.094 E.00619
G1 X126.648 Y103.98 E.00311
G1 X126.681 Y103.792 E.00464
G1 X126.681 Y98.457 E.12977
G1 X126.635 Y98.236 E.00549
G1 X126.366 Y98.061 E.00781
G1 X126.366 Y93.778 E.10418
G1 X138.862 Y93.781 E.30395
G1 X138.878 Y93.851 E.00175
G1 X138.863 Y95.048 E.02912
G1 X136.183 Y95.048 E.06519
G1 X135.854 Y95.157 E.00843
G1 X135.677 Y95.385 E.00702
G1 X135.635 Y95.596 E.00523
G1 X135.634 Y127.168 E.76796
G1 X135.613 Y127.642 E.01154
G1 X135.613 Y132.926 E.12853
G1 X135.499 Y133.883 E.02344
G1 X135.341 Y134.63 E.01857
G1 X135.079 Y135.486 E.02177
G1 X134.874 Y136.007 E.01362
G1 X134.544 Y136.702 E.01871
G1 X134.089 Y137.474 E.0218
G1 X133.767 Y137.932 E.01362
G1 X133.284 Y138.531 E.01872
G1 X132.661 Y139.174 E.02178
G1 X132.241 Y139.544 E.01361
G1 X131.631 Y140.014 E.01873
G1 X130.876 Y140.494 E.02176
G1 X130.381 Y140.755 E.01361
G1 X129.678 Y141.07 E.01874
G1 X128.832 Y141.36 E.02175
G1 X128.289 Y141.498 E.01363
G1 X127.538 Y141.638 E.01858
G1 X126.18 Y141.735 E.03312
G1 X121.093 Y141.735 E.12374
G1 X120.998 Y141.545 E.00517
G1 X120.667 Y141.434 E.00849
G1 X110.333 Y141.434 E.25136
G1 X110.002 Y141.544 E.00848
G1 X109.908 Y141.734 E.00516
G1 X104.36 Y141.723 E.13495
G1 X103.14 Y141.585 E.02986
G1 X102.598 Y141.474 E.01346
G1 X101.739 Y141.224 E.02176
G1 X101.022 Y140.943 E.01873
G1 X100.521 Y140.708 E.01346
G1 X99.368 Y140.013 E.03275
G1 X98.418 Y139.246 E.0297
G1 X98.025 Y138.866 E.0133
G1 X97.16 Y137.835 E.03274
G1 X96.51 Y136.802 E.02969
G1 X96.262 Y136.315 E.01329
G1 X95.778 Y135.058 E.03276
G1 X95.547 Y134.079 E.02447
G1 X95.436 Y133.433 E.01594
G1 X95.386 Y132.935 E.01217
G1 X95.386 Y127.642 E.12875
G1 X95.365 Y127.574 E.00173
G1 X95.365 Y95.596 E.77783
G1 X95.322 Y95.385 E.00524
G1 X95.145 Y95.157 E.00702
G1 X94.816 Y95.048 E.00843
G1 X92.143 Y95.048 E.06502
G1 X92.123 Y94.987 E.00156
G1 X92.123 Y94.414 E.01394
G1 X92.149 Y93.781 E.01541
G1 X104.634 Y93.781 E.30369
G1 X104.634 Y98.061 E.10411
G1 X104.365 Y98.236 E.00781
G1 X104.319 Y98.457 E.00549
G1 X104.319 Y103.792 E.12977
G1 X104.327 Y103.886 E.00229
G1 X104.41 Y104.094 E.00545
G1 X104.634 Y104.215 E.00619
G1 X104.634 Y136.1 E.77557
G1 X104.191 Y136.621 E.01663
G1 X103.958 Y137.076 E.01243
G1 X103.916 Y137.275 E.00495
G1 X103.916 Y137.275 F9000
G1 X103.542 Y137.286
G1 F6000
G1 X103.515 Y137.542 E.00626
G1 X103.646 Y138.148 E.01508
G1 X103.913 Y138.616 E.01311
G1 X104.269 Y139.035 E.01337
G1 X104.269 Y139.317 E.00686
G1 X104.352 Y139.699 E.00951
G1 X104.74 Y140.117 E.01387
G1 X105.181 Y140.231 E.01108
G1 X125.817 Y140.231 E.50195
G1 X125.975 Y140.218 E.00386
G1 X126.353 Y140.058 E.00998
G1 X126.581 Y139.819 E.00803
G1 X126.7 Y139.556 E.00702
G1 X126.731 Y139.035 E.0127
G1 X127.104 Y138.596 E.01401
G1 X127.374 Y138.078 E.01421
G1 X127.477 Y137.624 E.01132
G1 X127.467 Y137.316 E.0075
G1 X127.341 Y136.823 E.01238
G1 X127.087 Y136.384 E.01234
G1 X126.731 Y135.965 E.01337
G1 X126.731 Y104.384 E.76818
G1 X126.895 Y104.296 E.00453
G1 X126.991 Y104.106 E.00518
G1 X127.047 Y103.792 E.00776
G1 X127.047 Y98.457 E.12977
G1 X126.969 Y98.089 E.00915
G1 X126.731 Y97.934 E.00691
G1 X126.731 Y94.144 E.09219
G1 X135.395 Y94.146 E.21074
;WIDTH:0.442585
G1 X135.789 Y94.167 E.01071
;WIDTH:0.485171
G1 X136.183 Y94.189 E.01183
G1 X138.472 Y94.189 E.06865
;WIDTH:0.484976
G1 X138.475 Y94.639 E.01349
;WIDTH:0.485171
G1 X136.183 Y94.639 E.06874
;WIDTH:0.494128
G1 X136.017 Y94.649 E.00509
G1 X135.826 Y94.757 E.00671
;WIDTH:0.447064
G1 X135.635 Y94.865 E.00602
;WIDTH:0.399999
G1 X135.339 Y95.244 E.0117
G1 X135.269 Y95.596 E.00873
G1 X135.269 Y127.168 E.76796
G1 X135.247 Y127.642 E.01154
G1 X135.247 Y132.905 E.12802
G1 X135.138 Y133.823 E.02249
G1 X134.987 Y134.539 E.0178
G1 X134.734 Y135.366 E.02104
G1 X134.538 Y135.861 E.01295
G1 X134.22 Y136.531 E.01804
G1 X133.781 Y137.275 E.02101
G1 X133.475 Y137.711 E.01296
G1 X133.009 Y138.288 E.01804
G1 X132.409 Y138.909 E.021
G1 X132.009 Y139.262 E.01298
G1 X131.421 Y139.714 E.01804
G1 X130.692 Y140.177 E.02101
G1 X130.221 Y140.426 E.01296
G1 X129.544 Y140.729 E.01804
G1 X128.727 Y141.009 E.02101
G1 X128.21 Y141.141 E.01298
G1 X127.491 Y141.275 E.01779
G1 X126.167 Y141.369 E.03229
G1 X121.276 Y141.369 E.11897
G1 X121.219 Y141.254 E.00312
G1 X120.667 Y141.068 E.01417
G1 X110.333 Y141.068 E.25136
G1 X110.175 Y141.082 E.00386
G1 X109.782 Y141.253 E.01043
G1 X109.725 Y141.368 E.00312
G1 X104.381 Y141.358 E.12999
G1 X103.197 Y141.223 E.02899
G1 X102.686 Y141.118 E.01269
G1 X101.857 Y140.877 E.021
G1 X101.166 Y140.607 E.01805
G1 X100.693 Y140.385 E.01271
G1 X99.578 Y139.713 E.03167
G1 X98.66 Y138.972 E.0287
G1 X98.293 Y138.617 E.01242
G1 X97.456 Y137.619 E.03168
G1 X96.828 Y136.621 E.02868
G1 X96.597 Y136.166 E.01241
G1 X96.23 Y135.213 E.02484
G1 X96.064 Y134.675 E.0137
G1 X95.83 Y133.608 E.02657
G1 X95.752 Y132.919 E.01687
G1 X95.752 Y127.642 E.12836
G1 X95.73 Y127.542 E.00249
G1 X95.73 Y95.596 E.77705
G1 X95.66 Y95.244 E.00873
G1 X95.365 Y94.865 E.01168
;WIDTH:0.44246
G1 X95.09 Y94.752 E.00807
;WIDTH:0.48492
G1 X94.816 Y94.639 E.00888
G1 X92.531 Y94.639 E.06849
G1 X92.531 Y94.189 E.01349
G1 X94.816 Y94.189 E.06849
G1 X95.21 Y94.168 E.01183
;WIDTH:0.44246
G1 X95.604 Y94.146 E.01071
;WIDTH:0.399999
G1 X104.269 Y94.146 E.21077
G1 X104.269 Y97.934 E.09214
G1 X104.031 Y98.089 E.00691
G1 X103.953 Y98.457 E.00915
G1 X103.953 Y103.792 E.12977
G1 X103.967 Y103.949 E.00383
G1 X104.105 Y104.296 E.00908
G1 X104.269 Y104.384 E.00453
G1 X104.269 Y135.965 E.76818
G1 X103.781 Y136.59 E.01929
G1 X103.559 Y137.127 E.01413
G1 X103.548 Y137.226 E.00242
G1 E-5 F3600
G1 X103.548 Y137.226 F9000
G1 X103.914 Y137.301
G1 X103.896 Y137.5
G1 X103.907 Y137.667
G1 X103.941 Y137.83
G1 X103.994 Y137.989
G1 X104.651 Y139.849
G1 X110.101 Y140.66
G1 E5 F2400
;WIDTH:0.525622
G1 F6000
G1 X110.333 Y140.65 E.00759
;WIDTH:0.505428
G1 X120.667 Y140.65 E.32384
G1 E-5 F3600
G1 X120.667 Y140.65 F9000
G1 X103.941 Y137.83
G1 X103.896 Y137.5
G1 X103.903 Y124.395
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X103.903 Y135.831 E.27817
G1 X103.634 Y136.148 E.01011
G1 X103.449 Y136.436 E.00833
G1 X103.2 Y137.055 E.01623
G1 X103.15 Y137.559 E.01232
G1 X103.257 Y138.14 E.01437
G1 X103.502 Y138.666 E.01411
G1 X103.903 Y139.169 E.01565
G1 X103.912 Y139.468 E.00728
G1 X104.02 Y139.852 E.0097
G1 X104.562 Y140.437 E.0194
;WIDTH:0.415509
G1 X105.183 Y140.605 E.01631
;WIDTH:0.419442
G1 X109.44 Y140.607 E.10905
;WIDTH:0.454836
G1 X109.66 Y140.624 E.00617
;WIDTH:0.490229
G1 X109.881 Y140.642 E.00672
;WIDTH:0.525622
G1 X110.101 Y140.66 E.00721
G1 X109.913 Y140.771 E.00713
;WIDTH:0.490229
G1 X109.725 Y140.881 E.00661
;WIDTH:0.454836
G1 X109.537 Y140.992 E.00611
;WIDTH:0.419442
G1 X105.182 Y140.986 E.11156
;WIDTH:0.415509
G1 X104.402 Y140.992 E.01978
;WIDTH:0.399999
G1 X103.287 Y140.866 E.02729
G1 X102.774 Y140.763 E.01273
G1 X101.975 Y140.531 E.02024
G1 X101.357 Y140.289 E.01614
G1 X100.866 Y140.062 E.01316
G1 X99.788 Y139.412 E.03062
G1 X98.995 Y138.772 E.02479
G1 X98.561 Y138.367 E.01444
G1 X97.753 Y137.403 E.0306
G1 X97.235 Y136.581 E.02363
G1 X96.931 Y136.017 E.01558
G1 X96.571 Y135.082 E.02437
G1 X96.419 Y134.591 E.0125
G1 X96.192 Y133.557 E.02575
G1 X96.118 Y132.903 E.01601
G1 X96.118 Y127.642 E.12797
G1 X96.096 Y127.51 E.00326
G1 X96.096 Y95.596 E.77628
G1 X95.998 Y95.104 E.0122
G1 X95.584 Y94.572 E.0164
G1 X95.404 Y94.512 E.00462
G1 X103.903 Y94.512 E.20673
G1 X103.903 Y97.807 E.08015
G1 X103.696 Y97.942 E.00601
G1 X103.616 Y98.187 E.00627
G1 X103.588 Y98.457 E.0066
G1 X103.588 Y103.792 E.12977
G1 X103.665 Y104.231 E.01084
G1 X103.8 Y104.498 E.00728
G1 X103.903 Y104.553 E.00284
G1 X103.903 Y124.335 E.48118
G1 E-5 F3600
G1 X103.903 Y124.335 F9000
G1 X103.537 Y135.697
G1 E5 F2400
G1 F6000
G1 X103.157 Y136.203 E.01539
G1 X102.963 Y136.613 E.01103
G1 X102.826 Y137.073 E.01167
G1 X102.785 Y137.576 E.01228
G1 X102.905 Y138.239 E.01639
G1 X103.186 Y138.85 E.01636
G1 X103.528 Y139.293 E.01361
G1 X103.549 Y139.512 E.00535
G1 X103.688 Y140.005 E.01246
G1 X104.246 Y140.607 E.01997
G1 X103.297 Y140.497 E.02324
G1 X102.558 Y140.32 E.01848
G1 X101.709 Y140.034 E.02179
G1 X101.038 Y139.739 E.01783
G1 X99.998 Y139.112 E.02954
G1 X99.224 Y138.488 E.02418
G1 X98.829 Y138.118 E.01316
G1 X98.049 Y137.187 E.02954
G1 X97.545 Y136.386 E.02302
G1 X97.266 Y135.868 E.01431
G1 X96.912 Y134.95 E.02393
G1 X96.775 Y134.507 E.01128
G1 X96.554 Y133.507 E.02491
G1 X96.483 Y132.887 E.01518
G1 X96.483 Y127.642 E.12758
G1 X96.462 Y127.478 E.00402
G1 X96.462 Y95.596 E.7755
G1 X96.335 Y94.963 E.0157
G1 X96.269 Y94.878 E.00262
G1 X103.537 Y94.878 E.17679
G1 X103.537 Y97.68 E.06816
G1 X103.361 Y97.794 E.0051
G1 X103.259 Y98.11 E.00808
G1 X103.222 Y98.457 E.00849
G1 X103.222 Y103.792 E.12977
G1 X103.247 Y104.076 E.00693
G1 X103.322 Y104.357 E.00707
G1 X103.537 Y104.722 E.0103
G1 X103.537 Y135.637 E.75198
G1 E-5 F3600
G1 X103.537 Y135.637 F9000
G1 X103.941 Y137.83
G1 X121.199 Y141.451
G1 X120.85 Y141.451
G1 X120.85 Y140.721
G1 E5 F2400
;WIDTH:0.505428
G1 F6000
G1 X120.667 Y140.65 E.00615
G1 X121.115 Y140.628 E.01406
;WIDTH:0.462856
G1 X121.563 Y140.607 E.01278
;WIDTH:0.420285
G1 X125.817 Y140.607 E.10921
;WIDTH:0.425885
G1 X126.101 Y140.578 E.00744
G1 X126.567 Y140.354 E.01347
;WIDTH:0.399999
G1 X126.887 Y140.019 E.01127
G1 X127.052 Y139.652 E.00979
G1 X127.097 Y139.169 E.0118
G1 X127.348 Y138.874 E.00942
G1 X127.598 Y138.462 E.01172
G1 X127.802 Y137.936 E.01372
G1 X127.844 Y137.367 E.01388
G1 X127.747 Y136.873 E.01225
G1 X127.52 Y136.375 E.01331
G1 X127.097 Y135.831 E.01676
G1 X127.097 Y104.553 E.76081
G1 X127.2 Y104.498 E.00284
G1 X127.335 Y104.231 E.00728
G1 X127.412 Y103.792 E.01084
G1 X127.411 Y98.406 E.13101
G1 X127.304 Y97.942 E.01158
G1 X127.097 Y97.807 E.00601
G1 X127.097 Y94.51 E.0802
G1 X135.556 Y94.511 E.20576
G1 X135.415 Y94.572 E.00374
G1 X135.002 Y95.104 E.01638
G1 X134.903 Y95.596 E.01221
G1 X134.903 Y127.168 E.76796
G1 X134.881 Y127.642 E.01154
G1 X134.881 Y132.883 E.12748
G1 X134.777 Y133.764 E.02158
G1 X134.632 Y134.447 E.01698
G1 X134.388 Y135.245 E.0203
G1 X134.203 Y135.716 E.01231
G1 X133.897 Y136.359 E.01732
G1 X133.474 Y137.077 E.02027
G1 X133.183 Y137.491 E.01231
G1 X132.735 Y138.046 E.01735
G1 X132.156 Y138.645 E.02026
G1 X131.776 Y138.979 E.01231
G1 X131.211 Y139.414 E.01734
G1 X130.508 Y139.861 E.02026
G1 X130.061 Y140.097 E.0123
G1 X129.41 Y140.388 E.01734
G1 X128.622 Y140.658 E.02026
G1 X128.131 Y140.784 E.01233
G1 X127.445 Y140.912 E.01697
G1 X126.787 Y140.958 E.01604
;WIDTH:0.420285
G1 X125.817 Y140.993 E.02492
G1 X121.465 Y140.993 E.11173
G1 X121.446 Y140.954 E.00111
;WIDTH:0.462856
G1 X121.057 Y140.802 E.01191
;WIDTH:0.505428
G1 X120.906 Y140.743 E.00508
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X120.85 Y140.721 E-.02858
G1 X120.667 Y140.65 E-.09324
G1 X121.115 Y140.628 E-.21306
G1 X121.563 Y140.607 E-.21303
G1 X123.567 Y140.607 E-.95209
;WIPE_END
G1 X126.349 Y139.849 F9000
G1 X127.006 Y137.989
G1 X127.059 Y137.83
G1 X127.093 Y137.667
G1 X127.463 Y135.697
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X127.463 Y104.722 E.75344
G1 X127.678 Y104.357 E.0103
G1 X127.753 Y104.081 E.00696
G1 X127.778 Y103.792 E.00706
G1 X127.778 Y98.457 E.12977
G1 X127.741 Y98.109 E.00851
G1 X127.639 Y97.795 E.00803
G1 X127.463 Y97.68 E.00511
G1 X127.463 Y94.875 E.06823
G1 X134.731 Y94.877 E.17679
G1 X134.664 Y94.963 E.00265
G1 X134.538 Y95.596 E.0157
G1 X134.537 Y127.168 E.76796
G1 X134.516 Y127.642 E.01154
G1 X134.516 Y132.862 E.12697
G1 X134.416 Y133.704 E.02062
G1 X134.278 Y134.356 E.01621
G1 X134.082 Y134.997 E.0163
G1 X133.867 Y135.57 E.01489
G1 X133.574 Y136.187 E.01661
G1 X133.225 Y136.778 E.01669
G1 X132.891 Y137.271 E.01448
G1 X132.461 Y137.803 E.01664
G1 X131.965 Y138.316 E.01736
G1 X131.544 Y138.697 E.01381
G1 X131.001 Y139.114 E.01665
G1 X130.374 Y139.513 E.01808
G1 X129.9 Y139.769 E.0131
G1 X129.275 Y140.048 E.01665
G1 X128.548 Y140.297 E.01869
G1 X128.053 Y140.426 E.01244
G1 X127.398 Y140.548 E.01621
G1 X126.841 Y140.588 E.01358
G1 X127.193 Y140.22 E.01239
G1 X127.405 Y139.748 E.01259
G1 X127.463 Y139.317 E.01058
G1 X127.674 Y139.054 E.0082
G1 X128.037 Y138.387 E.01847
G1 X128.176 Y137.914 E.01199
G1 X128.208 Y137.33 E.01423
G1 X128.1 Y136.778 E.01368
G1 X127.843 Y136.203 E.01532
G1 X127.499 Y135.745 E.01393
G1 E-5 F3600
G1 X127.499 Y135.745 F9000
G1 X130.75 Y139.144
G1 E5 F2400
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X132.255 Y137.621 E.05208
G1 X132.935 Y136.73 E.02726
G1 X133.346 Y136.028 E.01979
G1 X129.933 Y139.441 E.11741
G1 X129.003 Y139.851 E.02472
G1 X133.76 Y135.094 E.16364
G1 X133.997 Y134.338 E.01927
G1 X128.239 Y140.096 E.19807
G1 X127.585 Y140.229 E.01623
G1 X134.142 Y133.673 E.22554
G1 X134.213 Y133.082 E.01448
G1 X127.717 Y139.578 E.22346
G1 X127.732 Y139.41 E.0041
G1 X128.128 Y138.84 E.01688
G1 X128.294 Y138.481 E.00962
G1 X134.241 Y132.534 E.20457
G1 X134.241 Y132.014 E.01265
G1 X128.464 Y137.792 E.19874
G1 X128.467 Y137.269 E.01272
G1 X134.241 Y131.494 E.19864
G1 X134.241 Y130.975 E.01262
G1 X128.39 Y136.826 E.20127
G1 X128.263 Y136.433 E.01005
G1 X134.241 Y130.455 E.20564
G1 X134.241 Y129.935 E.01265
G1 X128.091 Y136.086 E.21157
G1 X127.882 Y135.774 E.00913
G1 X134.241 Y129.415 E.21875
G1 X134.241 Y128.895 E.01265
G1 X127.737 Y135.4 E.22375
G1 X127.737 Y134.88 E.01265
G1 X134.241 Y128.376 E.22373
G1 X134.241 Y127.856 E.01265
G1 X127.737 Y134.36 E.22373
G1 X127.737 Y133.841 E.01262
G1 X134.263 Y127.314 E.22451
G1 X134.263 Y126.795 E.01262
G1 X127.737 Y133.321 E.22449
G1 X127.737 Y132.801 E.01265
G1 X134.263 Y126.275 E.22449
G1 X134.263 Y125.755 E.01265
G1 X127.737 Y132.281 E.22449
G1 X127.737 Y131.762 E.01262
G1 X134.263 Y125.235 E.22451
G1 X134.263 Y124.716 E.01262
G1 X127.737 Y131.242 E.22449
G1 X127.737 Y130.722 E.01265
G1 X134.263 Y124.196 E.22449
G1 X134.263 Y123.676 E.01265
G1 X127.737 Y130.202 E.22449
G1 X127.737 Y129.683 E.01262
G1 X134.263 Y123.156 E.22451
G1 X134.263 Y122.636 E.01265
G1 X127.737 Y129.163 E.22451
G1 X127.737 Y128.643 E.01265
G1 X134.263 Y122.117 E.22449
G1 X134.263 Y121.597 E.01265
G1 X127.737 Y128.123 E.22449
G1 X127.737 Y127.603 E.01265
G1 X134.263 Y121.077 E.22449
G1 X134.263 Y120.557 E.01265
G1 X127.737 Y127.084 E.22451
G1 X127.737 Y126.564 E.01265
G1 X134.263 Y120.038 E.22449
G1 X134.263 Y119.518 E.01265
G1 X127.737 Y126.044 E.22449
G1 X127.737 Y125.524 E.01265
G1 X134.263 Y118.998 E.22449
G1 X134.263 Y118.478 E.01265
G1 X127.737 Y125.005 E.22451
G1 X127.737 Y124.485 E.01265
G1 X134.263 Y117.958 E.22451
G1 X134.263 Y117.439 E.01262
G1 X127.737 Y123.965 E.22449
G1 X127.737 Y123.445 E.01265
G1 X134.263 Y116.919 E.22449
G1 X134.263 Y116.399 E.01265
G1 X127.737 Y122.926 E.22451
G1 X127.737 Y122.406 E.01265
G1 X134.263 Y115.879 E.22451
G1 X134.263 Y115.36 E.01262
G1 X127.737 Y121.886 E.22449
G1 X127.737 Y121.366 E.01265
G1 X134.263 Y114.84 E.22449
G1 X134.263 Y114.32 E.01265
G1 X127.737 Y120.846 E.22449
G1 X127.737 Y120.327 E.01262
G1 X134.263 Y113.8 E.22451
G1 X134.263 Y113.281 E.01262
G1 X127.737 Y119.807 E.22449
G1 X127.737 Y119.287 E.01265
G1 X134.263 Y112.761 E.22449
G1 X134.263 Y112.241 E.01265
G1 X127.737 Y118.767 E.22449
G1 X127.737 Y118.248 E.01262
G1 X134.263 Y111.721 E.22451
G1 X134.263 Y111.201 E.01265
G1 X127.737 Y117.728 E.22451
G1 X127.737 Y117.208 E.01265
G1 X134.263 Y110.682 E.22449
G1 X134.263 Y110.162 E.01265
G1 X127.737 Y116.688 E.22449
G1 X127.737 Y116.169 E.01262
G1 X134.263 Y109.642 E.22451
G1 X134.263 Y109.122 E.01265
G1 X127.737 Y115.649 E.22451
G1 X127.737 Y115.129 E.01265
G1 X134.263 Y108.603 E.22449
G1 X134.263 Y108.083 E.01265
G1 X127.737 Y114.609 E.22449
G1 X127.737 Y114.089 E.01265
G1 X134.263 Y107.563 E.22449
G1 X134.263 Y107.043 E.01265
G1 X127.737 Y113.57 E.22451
G1 X127.737 Y113.05 E.01265
G1 X134.263 Y106.523 E.22451
G1 X134.263 Y106.004 E.01262
G1 X127.737 Y112.53 E.22449
G1 X127.737 Y112.01 E.01265
G1 X134.263 Y105.484 E.22449
G1 X134.263 Y104.964 E.01265
G1 X127.737 Y111.491 E.22451
G1 X127.737 Y110.971 E.01265
G1 X134.263 Y104.444 E.22451
G1 X134.263 Y103.925 E.01262
G1 X127.737 Y110.451 E.22449
G1 X127.737 Y109.931 E.01265
G1 X134.263 Y103.405 E.22449
G1 X134.263 Y102.885 E.01265
G1 X127.737 Y109.412 E.22451
G1 X127.737 Y108.892 E.01265
G1 X134.263 Y102.365 E.22451
G1 X134.263 Y101.845 E.01265
G1 X127.737 Y108.372 E.22451
G1 X127.737 Y107.852 E.01265
G1 X134.263 Y101.326 E.22449
G1 X134.263 Y100.806 E.01265
G1 X127.737 Y107.333 E.22451
G1 X127.737 Y106.813 E.01265
G1 X134.263 Y100.286 E.22451
G1 X134.264 Y99.766 E.01265
G1 X127.737 Y106.293 E.22452
G1 X127.737 Y105.773 E.01265
G1 X134.264 Y99.247 E.22451
G1 X134.264 Y98.727 E.01265
G1 X127.737 Y105.253 E.22451
G1 X127.737 Y104.83 E.01029
G1 X127.844 Y104.627 E.00558
G1 X134.264 Y98.207 E.22084
G1 X134.264 Y97.687 E.01265
G1 X128.042 Y103.908 E.21402
G1 X128.052 Y103.379 E.01287
G1 X134.264 Y97.168 E.21367
G1 X134.264 Y96.648 E.01265
G1 X128.052 Y102.859 E.21367
G1 X128.052 Y102.339 E.01265
G1 X134.264 Y96.128 E.21367
G1 X134.264 Y95.608 E.01265
G1 X128.052 Y101.82 E.21369
G1 X128.052 Y101.3 E.01265
G1 X133.828 Y95.524 E.19869
G1 X133.308 Y95.524 E.01265
G1 X128.052 Y100.781 E.18082
G1 X128.051 Y100.261 E.01265
G1 X132.788 Y95.524 E.16295
G1 X132.269 Y95.524 E.01262
G1 X128.051 Y99.741 E.14508
G1 X128.051 Y99.222 E.01262
G1 X131.749 Y95.524 E.12721
G1 X131.229 Y95.524 E.01265
G1 X128.051 Y98.702 E.10932
G1 X128.029 Y98.205 E.0121
G1 X130.709 Y95.524 E.09221
G1 X130.189 Y95.525 E.01265
G1 X127.924 Y97.789 E.0779
G1 X127.883 Y97.662 E.00325
G1 X127.737 Y97.567 E.00424
G1 X127.737 Y97.457 E.00268
G1 X129.669 Y95.525 E.06646
G1 X129.149 Y95.525 E.01265
G1 X127.737 Y96.937 E.04857
G1 X127.737 Y96.417 E.01265
G1 X128.63 Y95.525 E.0307
G1 X128.11 Y95.525 E.01265
G1 X127.572 Y96.062 E.01849
G1 X127.572 Y96.062 F9000
G1 X127.742 Y95.155
;TYPE:Solid infill
;WIDTH:0.409484
G1 F1200
G1 X134.337 Y95.155 E.16458
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X131.179 Y95.155 E-1.5
;WIPE_END
G1 X97.247 Y95.359 F9000
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X96.736 Y95.87 E.01758
G1 X96.736 Y96.392 E.0127
G1 X97.604 Y95.524 E.02986
G1 X98.126 Y95.524 E.0127
G1 X96.736 Y96.914 E.04782
G1 X96.736 Y97.435 E.01267
G1 X98.647 Y95.524 E.06574
G1 X99.169 Y95.524 E.0127
G1 X96.736 Y97.957 E.08369
G1 X96.736 Y98.479 E.0127
G1 X99.69 Y95.524 E.10163
G1 X100.212 Y95.524 E.0127
G1 X96.736 Y99 E.11957
G1 X96.736 Y99.522 E.0127
G1 X100.734 Y95.524 E.13753
G1 X101.255 Y95.525 E.01267
G1 X96.736 Y100.044 E.15545
G1 X96.736 Y100.566 E.0127
G1 X101.777 Y95.525 E.17341
G1 X102.298 Y95.525 E.01267
G1 X96.736 Y101.087 E.19133
G1 X96.736 Y101.609 E.0127
G1 X102.82 Y95.525 E.20929
G1 X103.263 Y95.525 E.01078
G1 X103.263 Y95.603 E.0019
G1 X96.736 Y102.131 E.22454
G1 X96.736 Y102.652 E.01267
G1 X103.263 Y96.125 E.22452
G1 X103.263 Y96.647 E.0127
G1 X96.736 Y103.174 E.22452
G1 X96.736 Y103.696 E.0127
G1 X103.263 Y97.169 E.22452
G1 X103.263 Y97.566 E.00966
G1 X103.117 Y97.662 E.00425
G1 X103.033 Y97.92 E.0066
G1 X96.736 Y104.217 E.21661
G1 X96.736 Y104.739 E.0127
G1 X102.948 Y98.527 E.21369
G1 X102.948 Y99.049 E.0127
G1 X96.736 Y105.261 E.21369
G1 X96.736 Y105.782 E.01267
G1 X102.948 Y99.571 E.21367
G1 X102.948 Y100.092 E.01267
G1 X96.736 Y106.304 E.21369
G1 X96.736 Y106.826 E.0127
G1 X102.948 Y100.614 E.21369
G1 X102.948 Y101.136 E.0127
G1 X96.736 Y107.348 E.21369
G1 X96.736 Y107.869 E.01267
G1 X102.948 Y101.658 E.21367
G1 X102.948 Y102.179 E.01267
G1 X96.736 Y108.391 E.21369
G1 X96.736 Y108.913 E.0127
G1 X102.948 Y102.701 E.21369
G1 X102.948 Y103.223 E.0127
G1 X96.736 Y109.434 E.21367
G1 X96.736 Y109.956 E.0127
G1 X102.948 Y103.744 E.21369
G1 X103 Y104.214 E.0115
G1 X96.736 Y110.478 E.21548
G1 X96.736 Y110.999 E.01267
G1 X103.14 Y104.596 E.22028
G1 X103.263 Y104.83 E.00643
G1 X103.263 Y104.994 E.00399
G1 X96.736 Y111.521 E.22452
G1 X96.736 Y112.043 E.0127
G1 X103.263 Y105.516 E.22452
G1 X103.263 Y106.037 E.01267
G1 X96.736 Y112.565 E.22454
G1 X96.736 Y113.086 E.01267
G1 X103.263 Y106.559 E.22452
G1 X103.263 Y107.081 E.0127
G1 X96.736 Y113.608 E.22452
G1 X96.736 Y114.13 E.0127
G1 X103.263 Y107.602 E.22454
G1 X103.263 Y108.124 E.0127
G1 X96.736 Y114.651 E.22452
G1 X96.736 Y115.173 E.0127
G1 X103.263 Y108.646 E.22452
G1 X103.263 Y109.167 E.01267
G1 X96.736 Y115.695 E.22454
G1 X96.736 Y116.216 E.01267
G1 X103.263 Y109.689 E.22452
G1 X103.263 Y110.211 E.0127
G1 X96.736 Y116.738 E.22452
G1 X96.736 Y117.26 E.0127
G1 X103.263 Y110.733 E.22452
G1 X103.263 Y111.254 E.01267
G1 X96.736 Y117.781 E.22452
G1 X96.736 Y118.303 E.0127
G1 X103.263 Y111.776 E.22452
G1 X103.263 Y112.298 E.0127
G1 X96.736 Y118.825 E.22452
G1 X96.736 Y119.347 E.0127
G1 X103.263 Y112.819 E.22454
G1 X103.263 Y113.341 E.0127
G1 X96.736 Y119.868 E.22452
G1 X96.736 Y120.39 E.0127
G1 X103.263 Y113.863 E.22452
G1 X103.263 Y114.384 E.01267
G1 X96.736 Y120.912 E.22454
G1 X96.736 Y121.433 E.01267
G1 X103.263 Y114.906 E.22452
G1 X103.263 Y115.428 E.0127
G1 X96.736 Y121.955 E.22452
G1 X96.736 Y122.477 E.0127
G1 X103.263 Y115.949 E.22454
G1 X103.263 Y116.471 E.0127
G1 X96.736 Y122.998 E.22452
G1 X96.736 Y123.52 E.0127
G1 X103.263 Y116.993 E.22452
G1 X103.263 Y117.515 E.0127
G1 X96.736 Y124.042 E.22452
G1 X96.736 Y124.563 E.01267
G1 X103.263 Y118.036 E.22452
G1 X103.263 Y118.558 E.0127
G1 X96.736 Y125.085 E.22452
G1 X96.736 Y125.607 E.0127
G1 X103.263 Y119.08 E.22452
G1 X103.263 Y119.601 E.01267
G1 X96.736 Y126.129 E.22454
G1 X96.736 Y126.65 E.01267
G1 X103.263 Y120.123 E.22452
G1 X103.263 Y120.645 E.0127
G1 X96.736 Y127.172 E.22452
G1 X96.736 Y127.457 E.00693
G1 X96.758 Y127.672 E.00526
G1 X103.263 Y121.166 E.22379
G1 X103.263 Y121.688 E.0127
G1 X96.758 Y128.194 E.22379
G1 X96.758 Y128.715 E.01267
G1 X103.263 Y122.21 E.22377
G1 X103.263 Y122.731 E.01267
G1 X96.758 Y129.237 E.22379
G1 X96.758 Y129.759 E.0127
G1 X103.263 Y123.253 E.22379
G1 X103.263 Y123.775 E.0127
G1 X96.758 Y130.28 E.22377
G1 X96.758 Y130.802 E.0127
G1 X103.263 Y124.297 E.22377
G1 X103.263 Y124.818 E.01267
G1 X96.758 Y131.324 E.22379
G1 X96.758 Y131.845 E.01267
G1 X103.263 Y125.34 E.22377
G1 X103.263 Y125.862 E.0127
G1 X96.758 Y132.367 E.22377
G1 X96.758 Y132.873 E.01231
G1 X103.263 Y126.383 E.22351
G1 X103.263 Y126.905 E.0127
G1 X96.815 Y133.353 E.22181
G1 X96.89 Y133.8 E.01102
G1 X103.263 Y127.427 E.21923
G1 X103.263 Y127.948 E.01267
G1 X96.99 Y134.222 E.2158
G1 X97.089 Y134.644 E.01054
G1 X103.263 Y128.47 E.21238
G1 X103.263 Y128.992 E.0127
G1 X97.234 Y135.021 E.20739
G1 X97.379 Y135.398 E.00983
G1 X103.263 Y129.514 E.20241
G1 X103.263 Y130.035 E.01267
G1 X97.525 Y135.773 E.19738
G1 X97.701 Y136.119 E.00944
G1 X103.263 Y130.557 E.19133
G1 X103.263 Y131.079 E.0127
G1 X97.902 Y136.44 E.18442
G1 X98.104 Y136.76 E.0092
G1 X103.263 Y131.6 E.17748
G1 X103.263 Y132.122 E.0127
G1 X98.312 Y137.074 E.17033
G1 X98.55 Y137.357 E.00899
G1 X103.263 Y132.644 E.16212
G1 X103.263 Y133.165 E.01267
G1 X98.788 Y137.641 E.15395
G1 X99.025 Y137.925 E.009
G1 X103.263 Y133.687 E.14578
G1 X103.263 Y134.209 E.0127
G1 X99.29 Y138.182 E.13667
G1 X99.575 Y138.418 E.009
G1 X103.263 Y134.73 E.12686
G1 X103.263 Y135.252 E.0127
G1 X99.864 Y138.651 E.11692
G1 X100.153 Y138.884 E.00903
G1 X102.872 Y136.165 E.09353
G1 X102.563 Y136.996 E.02157
G1 X100.478 Y139.081 E.07172
G1 X100.803 Y139.277 E.00923
G1 X102.511 Y137.569 E.05875
G1 X102.582 Y138.02 E.01111
G1 X101.129 Y139.473 E.04998
G1 X101.48 Y139.644 E.0095
G1 X102.687 Y138.436 E.04154
G1 X102.85 Y138.795 E.00959
G1 X101.85 Y139.795 E.0344
G1 X102.229 Y139.938 E.00985
G1 X103.048 Y139.119 E.02817
G1 X103.271 Y139.418 E.00907
G1 X102.633 Y140.056 E.02195
G1 X103.045 Y140.166 E.01037
G1 X103.349 Y139.861 E.01047
G1 X103.519 Y140.213 E.00951
G1 X103.339 Y140.393 E.00619
G1 E-5 F3600
G1 X103.339 Y140.393 F9000
G1 X96.662 Y95.155
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.407356
G1 F1200
G1 X103.259 Y95.156 E.16369
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X100.101 Y95.156 E-1.5
;WIPE_END
G1 X104.336 Y99.901 F9000
G1 X105.645 Y101.368
G1 X112.178 Y108.593
G1 X112.365 Y108.898
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X112.559 Y108.772 E.00563
G1 X112.927 Y108.608 E.0098
G1 X113.488 Y108.48 E.014
G1 X117.376 Y108.468 E.09457
G1 X117.974 Y108.575 E.01478
G1 X118.392 Y108.745 E.01098
G1 X118.743 Y108.963 E.01005
G1 X119.059 Y109.241 E.01024
G1 X119.43 Y109.73 E.01493
G1 X121.162 Y112.732 E.0843
G1 X121.337 Y113.103 E.00998
G1 X121.451 Y113.501 E.01007
G1 X121.499 Y113.911 E.01004
G1 X121.48 Y114.324 E.01006
G1 X121.391 Y114.734 E.01021
G1 X121.172 Y115.249 E.01361
G1 X119.43 Y118.269 E.0848
G1 X119.059 Y118.758 E.01493
G1 X118.578 Y119.149 E.01508
G1 X118.017 Y119.411 E.01506
G1 X117.376 Y119.532 E.01587
G1 X113.768 Y119.538 E.08776
G1 X113.126 Y119.453 E.01575
G1 X112.695 Y119.297 E.01115
G1 X112.205 Y118.996 E.01399
G1 X111.873 Y118.685 E.01107
G1 X111.57 Y118.27 E.0125
G1 X109.838 Y115.269 E.08428
G1 X109.582 Y114.639 E.01654
G1 X109.507 Y114.192 E.01102
G1 X109.509 Y113.778 E.01007
G1 X109.582 Y113.361 E.0103
G1 X109.826 Y112.755 E.01589
G1 X111.57 Y109.73 E.08493
G1 X111.873 Y109.315 E.0125
G1 X112.198 Y109.008 E.01087
G1 X112.315 Y108.931 E.00341
G1 X112.315 Y108.931 F9000
G1 X112.1 Y108.637
;TYPE:Perimeter
G1 F6000
G1 X112.407 Y108.439 E.00889
G1 X112.846 Y108.251 E.01162
G1 X113.407 Y108.123 E.014
G1 X113.775 Y108.108 E.00896
G1 X117.377 Y108.102 E.08762
G1 X118.041 Y108.216 E.01639
G1 X118.566 Y108.423 E.01373
G1 X118.983 Y108.687 E.012
G1 X119.349 Y109.02 E.01204
G1 X119.746 Y109.547 E.01605
G1 X121.479 Y112.549 E.08431
G1 X121.688 Y113 E.01209
G1 X121.814 Y113.456 E.01151
G1 X121.864 Y113.926 E.0115
G1 X121.838 Y114.399 E.01152
G1 X121.728 Y114.878 E.01195
G1 X121.509 Y115.392 E.01359
G1 X119.747 Y118.452 E.08589
G1 X119.35 Y118.98 E.01607
G1 X118.806 Y119.435 E.01725
G1 X118.169 Y119.744 E.01722
G1 X117.377 Y119.898 E.01963
G1 X113.768 Y119.904 E.08779
G1 X113.077 Y119.815 E.01695
G1 X112.519 Y119.618 E.01439
G1 X112.013 Y119.308 E.01443
G1 X111.625 Y118.957 E.01273
G1 X111.254 Y118.453 E.01522
G1 X109.521 Y115.451 E.08431
G1 X109.243 Y114.775 E.01778
G1 X109.141 Y114.192 E.0144
G1 X109.148 Y113.719 E.01151
G1 X109.243 Y113.225 E.01224
G1 X109.487 Y112.618 E.01591
G1 X111.254 Y109.547 E.08618
G1 X111.578 Y109.099 E.01345
G1 X111.973 Y108.72 E.01332
G1 X112.049 Y108.67 E.00221
G1 X112.049 Y108.67 F9000
G1 X111.836 Y108.379
G1 F6000
G1 X112.109 Y108.187 E.00812
G1 X112.56 Y107.968 E.0122
G1 X113.102 Y107.818 E.01368
G1 X113.548 Y107.744 E.011
G1 X117.378 Y107.736 E.09316
G1 X118.108 Y107.856 E.01799
G1 X118.642 Y108.054 E.01385
G1 X119.102 Y108.322 E.01295
G1 X119.512 Y108.661 E.01294
G1 X119.998 Y109.267 E.0189
G1 X121.796 Y112.366 E.08715
G1 X122.038 Y112.897 E.01419
G1 X122.177 Y113.411 E.01295
G1 X122.23 Y113.941 E.01296
G1 X122.201 Y114.445 E.01228
G1 X122.064 Y115.021 E.0144
G1 X121.845 Y115.535 E.01359
G1 X120.063 Y118.635 E.08697
G1 X119.641 Y119.202 E.01719
G1 X119.034 Y119.72 E.01941
G1 X118.321 Y120.076 E.01938
G1 X117.543 Y120.248 E.01938
G1 X117.378 Y120.264 E.00403
G1 X113.769 Y120.269 E.08779
G1 X113.256 Y120.208 E.01257
G1 X112.84 Y120.132 E.01029
G1 X112.337 Y119.935 E.01314
G1 X111.822 Y119.619 E.0147
G1 X111.394 Y119.243 E.01386
G1 X110.991 Y118.718 E.0161
G1 X109.204 Y115.634 E.0867
G1 X108.904 Y114.912 E.01902
G1 X108.788 Y114.34 E.0142
G1 X108.776 Y114.192 E.00361
G1 X108.788 Y113.66 E.01294
G1 X108.904 Y113.088 E.0142
G1 X109.148 Y112.482 E.01589
G1 X110.937 Y109.365 E.08742
G1 X111.283 Y108.883 E.01443
G1 X111.674 Y108.494 E.01342
G1 X111.787 Y108.414 E.00337
G1 X111.787 Y108.414 F9000
G1 X111.573 Y108.121
G1 F6000
G1 X111.905 Y107.883 E.00994
G1 X112.408 Y107.635 E.01364
G1 X113.021 Y107.461 E.0155
G1 X113.523 Y107.378 E.01238
G1 X117.379 Y107.371 E.09379
G1 X118.174 Y107.497 E.01958
G1 X118.78 Y107.715 E.01567
G1 X119.293 Y108.011 E.01441
G1 X119.751 Y108.385 E.01438
G1 X120.289 Y109.045 E.02071
G1 X122.113 Y112.183 E.08829
G1 X122.389 Y112.794 E.01631
G1 X122.54 Y113.367 E.01441
G1 X122.596 Y113.904 E.01313
G1 X122.561 Y114.509 E.01474
G1 X122.401 Y115.164 E.0164
G1 X122.182 Y115.678 E.01359
G1 X120.38 Y118.818 E.08806
G1 X119.931 Y119.423 E.01833
G1 X119.509 Y119.81 E.01393
G1 X119.038 Y120.15 E.01413
G1 X118.473 Y120.409 E.01512
G1 X118.175 Y120.503 E.0076
G1 X117.609 Y120.608 E.014
G1 X117.378 Y120.629 E.00564
G1 X113.769 Y120.635 E.08779
G1 X113.206 Y120.571 E.01378
G1 X112.716 Y120.475 E.01215
G1 X112.156 Y120.253 E.01465
G1 X111.631 Y119.931 E.01498
G1 X111.144 Y119.51 E.01566
G1 X110.696 Y118.934 E.01775
G1 X108.888 Y115.817 E.08765
G1 X108.565 Y115.048 E.02029
G1 X108.427 Y114.4 E.01612
G1 X108.41 Y114.192 E.00508
G1 X108.427 Y113.6 E.01441
G1 X108.565 Y112.952 E.01612
G1 X108.808 Y112.345 E.0159
G1 X110.62 Y109.182 E.08867
G1 X110.988 Y108.667 E.0154
G1 X111.423 Y108.227 E.01505
G1 X111.524 Y108.156 E.003
G1 E-5 F3600
G1 X111.524 Y108.156 F9000
G1 X108.217 Y101.146
G1 E5 F2400
G1 F6000
G1 X108.066 Y100.459 E.01711
G1 X108.044 Y99.808 E.01584
G1 X108.128 Y99.162 E.01585
G1 X108.225 Y98.816 E.00874
G1 X108.571 Y98 E.02156
G1 X110.304 Y94.999 E.08429
G1 X110.692 Y94.451 E.01633
G1 X111.173 Y93.961 E.0167
G1 X111.929 Y93.457 E.0221
G1 X112.592 Y93.181 E.01747
G1 X113.228 Y93.04 E.01585
G1 X113.521 Y93.013 E.00716
G1 X117.38 Y93.005 E.09387
G1 X117.99 Y93.076 E.01494
G1 X118.855 Y93.353 E.02209
G1 X119.214 Y93.534 E.00978
G1 X119.691 Y93.855 E.01399
G1 X120.218 Y94.343 E.01747
G1 X120.618 Y94.877 E.01623
G1 X122.429 Y98 E.08781
G1 X122.649 Y98.451 E.01221
G1 X122.848 Y99.06 E.01558
G1 X122.949 Y99.703 E.01583
G1 X122.945 Y100.355 E.01586
G1 X122.834 Y100.996 E.01582
G1 X122.524 Y101.809 E.02116
G1 X120.697 Y105.001 E.08946
G1 X120.222 Y105.645 E.01946
G1 X119.939 Y105.934 E.00984
G1 X119.49 Y106.293 E.01398
G1 X119.147 Y106.503 E.00978
G1 X118.624 Y106.742 E.01399
G1 X118.241 Y106.863 E.00977
;WIDTH:0.402393
G1 X117.676 Y106.969 E.01407
;WIDTH:0.409774
G1 X117.38 Y107 E.00743
G1 X118.241 Y107.137 E.02177
;WIDTH:0.399999
G1 X118.918 Y107.377 E.01747
G1 X119.485 Y107.699 E.01586
G1 X119.896 Y108.027 E.01279
G1 X120.222 Y108.354 E.01123
G1 X120.58 Y108.824 E.01437
G1 X120.696 Y108.999 E.00511
G1 X122.429 Y112 E.08429
G1 X122.649 Y112.451 E.01221
G1 X122.848 Y113.059 E.01556
G1 X122.949 Y113.703 E.01586
G1 X122.945 Y114.355 E.01586
G1 X122.834 Y114.996 E.01582
G1 X122.518 Y115.821 E.02149
G1 X120.697 Y119.001 E.08913
G1 X120.222 Y119.645 E.01946
G1 X119.94 Y119.934 E.00982
G1 X119.49 Y120.292 E.01399
G1 X119.148 Y120.502 E.00976
G1 X118.625 Y120.741 E.01399
G1 X118.241 Y120.863 E.0098
;WIDTH:0.413322
G1 X117.677 Y120.974 E.01449
;WIDTH:0.422368
G1 X117.52 Y121 E.00411
G1 X118.241 Y121.137 E.01894
;WIDTH:0.399999
G1 X118.918 Y121.377 E.01747
G1 X119.485 Y121.699 E.01586
G1 X119.897 Y122.028 E.01282
G1 X120.222 Y122.354 E.0112
G1 X120.696 Y122.999 E.01947
G1 X122.429 Y126 E.08429
G1 X122.649 Y126.451 E.01221
G1 X122.848 Y127.059 E.01556
G1 X122.949 Y127.703 E.01586
G1 X122.945 Y128.355 E.01586
G1 X122.834 Y128.996 E.01582
G1 X122.518 Y129.821 E.02149
G1 X122.429 Y130 E.00486
G1 X120.697 Y133.001 E.08428
G1 X120.222 Y133.645 E.01946
G1 X119.94 Y133.934 E.00982
G1 X119.49 Y134.292 E.01399
G1 X119.147 Y134.503 E.0098
G1 X118.625 Y134.742 E.01396
G1 X118.242 Y134.863 E.00977
G1 X117.677 Y134.967 E.01397
G1 X117.379 Y134.995 E.00728
G1 X113.767 Y135.001 E.08786
G1 X112.93 Y134.902 E.0205
G1 X112.196 Y134.673 E.0187
G1 X111.648 Y134.388 E.01502
G1 X110.943 Y133.821 E.02201
G1 X110.692 Y133.549 E.009
G1 X110.304 Y133.001 E.01633
G1 X108.571 Y130 E.08429
G1 X108.225 Y129.184 E.02156
G1 X108.066 Y128.459 E.01805
G1 X108.044 Y127.808 E.01584
G1 X108.128 Y127.162 E.01585
G1 X108.225 Y126.816 E.00874
G1 X108.469 Y126.209 E.01591
G1 X108.571 Y126 E.00566
G1 X110.304 Y122.999 E.08429
G1 X110.692 Y122.451 E.01633
G1 X111.173 Y121.961 E.0167
G1 X111.701 Y121.58 E.01584
G1 X112.256 Y121.302 E.0151
G1 X112.939 Y121.105 E.01729
;WIDTH:0.439126
G1 X113.464 Y120.994 E.01445
G1 X112.93 Y120.902 E.01459
;WIDTH:0.399999
G1 X112.26 Y120.7 E.01702
G1 X111.677 Y120.389 E.01607
G1 X111.173 Y120.039 E.01493
G1 X110.782 Y119.66 E.01325
G1 X110.401 Y119.15 E.01548
G1 X108.571 Y116 E.08861
G1 X108.225 Y115.184 E.02156
G1 X108.066 Y114.459 E.01805
G1 X108.044 Y114.192 E.00652
G1 X108.066 Y113.541 E.01584
G1 X108.225 Y112.816 E.01805
G1 X108.469 Y112.209 E.01591
G1 X108.571 Y112 E.00566
G1 X110.304 Y108.999 E.08429
G1 X110.692 Y108.451 E.01633
G1 X111.173 Y107.961 E.0167
G1 X111.701 Y107.58 E.01584
G1 X112.256 Y107.302 E.0151
G1 X112.939 Y107.105 E.01729
;WIDTH:0.439124
G1 X113.464 Y106.994 E.01445
G1 X112.93 Y106.902 E.01459
;WIDTH:0.399999
G1 X112.26 Y106.699 E.01703
G1 X111.653 Y106.39 E.01657
G1 X111.132 Y105.985 E.01605
G1 X110.692 Y105.549 E.01507
G1 X110.304 Y105.001 E.01633
G1 X108.571 Y102 E.08429
G1 X108.233 Y101.203 E.02106
G1 E-5 F3600
G1 X108.233 Y101.203 F9000
G1 X109.16 Y114.235
G1 X109.188 Y114.469
G1 X109.236 Y114.699
G1 X109.302 Y114.925
G1 X109.387 Y115.145
G1 X109.49 Y115.36
G1 X109.529 Y115.432
G1 X111.274 Y118.454
G1 X111.339 Y118.558
G1 X111.475 Y118.753
G1 X111.626 Y118.934
G1 X111.791 Y119.102
G1 X111.969 Y119.256
G1 X112.159 Y119.395
G1 X112.359 Y119.519
G1 X112.569 Y119.625
G1 X112.787 Y119.714
G1 X113.012 Y119.785
G1 X117.52 Y121
G1 E5 F2400
;WIDTH:0.422368
G1 F6000
G1 X117.38 Y121 E.00361
;WIDTH:0.40977
G1 X115.949 Y120.999 E.03574
;WIDTH:0.410754
G1 X113.77 Y121.006 E.05456
;WIDTH:0.439126
G1 X113.464 Y120.994 E.00825
G1 E-5 F3600
G1 X113.464 Y120.994 F9000
G1 X109.49 Y115.36
G1 X109.16 Y114.235
G1 X109.15 Y114
G1 X109.16 Y113.765
G1 X109.188 Y113.531
G1 X109.236 Y113.301
G1 X109.302 Y113.075
G1 X109.387 Y112.855
G1 X109.49 Y112.64
G1 X109.529 Y112.568
G1 X111.274 Y109.546
G1 X111.339 Y109.442
G1 X111.475 Y109.247
G1 X111.626 Y109.066
G1 X111.791 Y108.898
G1 X111.969 Y108.744
G1 X112.159 Y108.605
G1 X112.359 Y108.481
G1 X112.569 Y108.375
G1 X112.787 Y108.286
G1 X113.012 Y108.215
G1 X117.38 Y107
G1 E5 F2400
;WIDTH:0.409774
G1 F6000
G1 X115.937 Y106.999 E.03604
;WIDTH:0.410752
G1 X113.77 Y107.006 E.05426
;WIDTH:0.439124
G1 X113.464 Y106.994 E.00825
G1 X113.464 Y106.994 F9000
G1 X113.547 Y105.507
;WIDTH:0.399999
G1 F6000
G1 X113.089 Y105.444 E.01125
G1 X112.685 Y105.292 E.0105
G1 X112.336 Y105.092 E.00978
G1 X111.901 Y104.716 E.01399
G1 X111.57 Y104.27 E.01351
G1 X109.838 Y101.269 E.08428
G1 X109.582 Y100.639 E.01654
G1 X109.507 Y100.192 E.01102
G1 X109.527 Y99.669 E.01273
G1 X109.582 Y99.361 E.00761
G1 X109.838 Y98.731 E.01654
G1 X111.57 Y95.73 E.08428
G1 X111.873 Y95.315 E.0125
G1 X112.204 Y95.004 E.01105
G1 X112.694 Y94.703 E.01399
G1 X113.118 Y94.548 E.01098
G1 X113.528 Y94.475 E.01013
G1 X117.377 Y94.468 E.09362
G1 X117.818 Y94.533 E.01084
G1 X118.358 Y94.728 E.01397
G1 X118.876 Y95.069 E.01508
G1 X119.192 Y95.39 E.01096
G1 X119.43 Y95.73 E.0101
G1 X121.162 Y98.732 E.0843
G1 X121.365 Y99.2 E.01241
G1 X121.451 Y99.503 E.00766
G1 X121.498 Y99.922 E.01026
G1 X121.48 Y100.324 E.00979
G1 X121.391 Y100.734 E.01021
G1 X121.172 Y101.249 E.01361
G1 X119.43 Y104.269 E.0848
G1 X119.059 Y104.758 E.01493
G1 X118.578 Y105.149 E.01508
G1 X118.017 Y105.411 E.01506
G1 X117.376 Y105.532 E.01587
G1 X113.768 Y105.538 E.08776
G1 X113.607 Y105.516 E.00395
G1 X113.607 Y105.516 F9000
G1 X113.587 Y105.878
;TYPE:Perimeter
G1 F6000
G1 X112.965 Y105.788 E.01529
G1 X112.507 Y105.611 E.01194
G1 X112.096 Y105.369 E.0116
G1 X111.661 Y104.992 E.014
G1 X111.254 Y104.453 E.01643
G1 X109.521 Y101.451 E.08431
G1 X109.243 Y100.775 E.01778
G1 X109.148 Y100.281 E.01224
G1 X109.148 Y99.719 E.01367
G1 X109.243 Y99.225 E.01224
G1 X109.487 Y98.618 E.01591
G1 X111.254 Y95.547 E.08618
G1 X111.578 Y95.099 E.01345
G1 X112.013 Y94.692 E.01449
G1 X112.503 Y94.391 E.01399
G1 X113.051 Y94.189 E.01421
G1 X113.526 Y94.11 E.01171
G1 X115.946 Y94.098 E.05886
G1 X117.378 Y94.102 E.03483
G1 X117.942 Y94.189 E.01388
G1 X118.483 Y94.384 E.01399
G1 X119.08 Y94.766 E.01724
G1 X119.441 Y95.119 E.01228
G1 X119.746 Y95.547 E.01278
G1 X121.479 Y98.549 E.08431
G1 X121.716 Y99.097 E.01452
G1 X121.814 Y99.459 E.00912
G1 X121.864 Y99.937 E.01169
G1 X121.838 Y100.399 E.01126
G1 X121.728 Y100.878 E.01195
G1 X121.509 Y101.392 E.01359
G1 X119.747 Y104.452 E.08589
G1 X119.35 Y104.98 E.01607
G1 X118.806 Y105.435 E.01725
G1 X118.169 Y105.744 E.01722
G1 X117.377 Y105.898 E.01963
G1 X113.768 Y105.904 E.08779
G1 X113.646 Y105.886 E.003
G1 X113.625 Y106.252 F9000
G1 F6000
G1 X113.256 Y106.208 E.00904
G1 X112.84 Y106.132 E.01029
G1 X112.344 Y105.939 E.01295
G1 X111.891 Y105.673 E.01278
G1 X111.422 Y105.268 E.01507
G1 X110.937 Y104.636 E.01938
G1 X109.204 Y101.634 E.08431
G1 X108.904 Y100.912 E.01902
G1 X108.788 Y100.34 E.0142
G1 X108.776 Y99.808 E.01294
G1 X108.85 Y99.281 E.01294
G1 X109.148 Y98.482 E.02074
G1 X110.937 Y95.364 E.08744
G1 X111.283 Y94.883 E.01441
G1 X111.674 Y94.494 E.01342
G1 X112.311 Y94.08 E.01848
G1 X112.84 Y93.868 E.01386
G1 X113.361 Y93.759 E.01295
G1 X113.524 Y93.744 E.00398
G1 X117.379 Y93.736 E.09377
G1 X117.886 Y93.8 E.01243
G1 X118.607 Y94.04 E.01848
G1 X119.283 Y94.462 E.01938
G1 X119.695 Y94.855 E.01385
G1 X120.02 Y95.297 E.01334
G1 X121.796 Y98.366 E.08625
G1 X122.038 Y98.897 E.01419
G1 X122.177 Y99.411 E.01295
G1 X122.23 Y99.941 E.01296
G1 X122.201 Y100.445 E.01228
G1 X122.064 Y101.021 E.0144
G1 X121.845 Y101.535 E.01359
G1 X120.063 Y104.635 E.08697
G1 X119.64 Y105.202 E.01721
G1 X119.034 Y105.721 E.01941
G1 X118.32 Y106.076 E.0194
G1 X117.543 Y106.248 E.01936
G1 X117.377 Y106.264 E.00406
G1 X113.769 Y106.269 E.08776
G1 X113.685 Y106.259 E.00206
G1 X113.685 Y106.259 F9000
G1 X113.664 Y106.623
G1 F6000
G1 X113.206 Y106.571 E.01121
G1 X112.716 Y106.475 E.01215
G1 X112.165 Y106.258 E.0144
G1 X111.665 Y105.961 E.01415
G1 X111.183 Y105.545 E.01549
G1 X110.62 Y104.818 E.02237
G1 X108.888 Y101.817 E.08428
G1 X108.565 Y101.048 E.02029
G1 X108.427 Y100.4 E.01612
G1 X108.41 Y99.808 E.01441
G1 X108.489 Y99.222 E.01438
G1 X108.808 Y98.345 E.0227
G1 X110.62 Y95.182 E.08867
G1 X110.988 Y94.667 E.0154
G1 X111.423 Y94.228 E.01503
G1 X112.12 Y93.768 E.02031
G1 X112.716 Y93.525 E.01566
G1 X113.295 Y93.4 E.01441
G1 X113.522 Y93.378 E.00555
G1 X117.38 Y93.371 E.09384
G1 X117.938 Y93.438 E.01367
G1 X118.731 Y93.697 E.02029
G1 X119.487 Y94.159 E.02155
G1 X119.956 Y94.599 E.01564
G1 X120.319 Y95.087 E.01479
G1 X122.113 Y98.183 E.08704
G1 X122.389 Y98.794 E.01631
G1 X122.54 Y99.367 E.01441
G1 X122.595 Y99.956 E.01439
G1 X122.561 Y100.509 E.01348
G1 X122.401 Y101.164 E.0164
G1 X122.182 Y101.678 E.01359
G1 X120.38 Y104.818 E.08806
G1 X119.931 Y105.424 E.01835
G1 X119.509 Y105.809 E.01389
G1 X119.038 Y106.15 E.01414
G1 X118.472 Y106.409 E.01514
G1 X118.174 Y106.503 E.0076
G1 X117.609 Y106.608 E.01398
G1 X117.378 Y106.629 E.00564
G1 X113.769 Y106.635 E.08779
G1 X113.724 Y106.63 E.0011
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.664 Y106.623 E-.02869
G1 X113.206 Y106.571 E-.21895
G1 X112.716 Y106.475 E-.23717
G1 X112.165 Y106.258 E-.28129
G1 X111.665 Y105.961 E-.27624
G1 X111.183 Y105.545 E-.30243
G1 X110.983 Y105.287 E-.15523
;WIPE_END
G1 X111.537 Y104.827 F9000
G1 X109.16 Y113.765
G1 X109.15 Y114
G1 X109.16 Y114.235
G1 X109.49 Y115.36
G1 X113.241 Y119.837
G1 X113.342 Y119.852
G1 X113.769 Y122.113
G1 X113.768 Y122.479
G1 E5 F2400
G1 F6000
G1 X117.409 Y122.471 E.08856
G1 X117.975 Y122.576 E.014
G1 X118.392 Y122.745 E.01094
G1 X118.743 Y122.963 E.01005
G1 X119.059 Y123.241 E.01024
G1 X119.43 Y123.73 E.01493
G1 X121.162 Y126.732 E.0843
G1 X121.337 Y127.103 E.00998
G1 X121.451 Y127.501 E.01007
G1 X121.499 Y127.911 E.01004
G1 X121.48 Y128.324 E.01006
G1 X121.391 Y128.734 E.01021
G1 X121.172 Y129.249 E.01361
G1 X119.43 Y132.269 E.0848
G1 X119.059 Y132.758 E.01493
G1 X118.578 Y133.149 E.01508
G1 X118.017 Y133.411 E.01506
G1 X117.376 Y133.532 E.01587
G1 X113.767 Y133.538 E.08779
G1 X113.126 Y133.453 E.01573
G1 X112.677 Y133.289 E.01163
G1 X112.336 Y133.092 E.00958
G1 X111.901 Y132.716 E.01399
G1 X111.581 Y132.286 E.01304
G1 X109.838 Y129.269 E.08475
G1 X109.582 Y128.639 E.01654
G1 X109.507 Y128.192 E.01102
G1 X109.509 Y127.778 E.01007
G1 X109.582 Y127.361 E.0103
G1 X109.826 Y126.755 E.01589
G1 X111.57 Y123.73 E.08493
G1 X111.873 Y123.315 E.0125
G1 X112.285 Y122.949 E.0134
G1 X112.543 Y122.779 E.00752
G1 X112.927 Y122.608 E.01022
G1 X113.488 Y122.48 E.014
G1 X113.708 Y122.479 E.00535
G1 X113.708 Y122.479 F9000
G1 X113.685 Y122.121
;TYPE:Perimeter
G1 F6000
G1 X115.946 Y122.098 E.055
G1 X117.476 Y122.111 E.03722
G1 X118.041 Y122.216 E.01398
G1 X118.566 Y122.423 E.01373
G1 X118.983 Y122.687 E.012
G1 X119.349 Y123.02 E.01204
G1 X119.746 Y123.547 E.01605
G1 X121.479 Y126.549 E.08431
G1 X121.688 Y127 E.01209
G1 X121.814 Y127.456 E.01151
G1 X121.864 Y127.926 E.0115
G1 X121.838 Y128.399 E.01152
G1 X121.728 Y128.878 E.01195
G1 X121.479 Y129.451 E.0152
G1 X119.747 Y132.452 E.08428
G1 X119.35 Y132.98 E.01607
G1 X118.806 Y133.435 E.01725
G1 X118.169 Y133.744 E.01722
G1 X117.377 Y133.898 E.01963
G1 X113.767 Y133.904 E.08781
G1 X113.077 Y133.815 E.01692
G1 X112.577 Y133.644 E.01285
G1 X112.096 Y133.369 E.01348
G1 X111.661 Y132.992 E.014
G1 X111.286 Y132.502 E.01501
G1 X109.521 Y129.451 E.08574
G1 X109.243 Y128.775 E.01778
G1 X109.148 Y128.281 E.01224
G1 X109.148 Y127.719 E.01367
G1 X109.243 Y127.225 E.01224
G1 X109.487 Y126.618 E.01591
G1 X111.254 Y123.547 E.08618
G1 X111.578 Y123.099 E.01345
G1 X111.956 Y122.733 E.0128
G1 X112.375 Y122.454 E.01224
G1 X112.836 Y122.254 E.01222
G1 X113.407 Y122.123 E.01425
G1 X113.625 Y122.121 E.0053
G1 X113.625 Y122.121 F9000
G1 X113.602 Y121.744
G1 F6000
G1 X115.947 Y121.733 E.05704
G1 X117.378 Y121.736 E.03481
G1 X117.543 Y121.752 E.00403
G1 X118.108 Y121.857 E.01398
G1 X118.642 Y122.054 E.01384
G1 X119.102 Y122.322 E.01295
G1 X119.512 Y122.661 E.01294
G1 X120.063 Y123.365 E.02175
G1 X121.796 Y126.366 E.08429
G1 X122.038 Y126.897 E.01419
G1 X122.177 Y127.411 E.01295
G1 X122.23 Y127.941 E.01296
G1 X122.201 Y128.445 E.01228
G1 X122.064 Y129.021 E.0144
G1 X121.796 Y129.634 E.01627
G1 X120.063 Y132.635 E.08429
G1 X119.641 Y133.202 E.01719
G1 X119.034 Y133.721 E.01943
G1 X118.321 Y134.076 E.01937
G1 X117.543 Y134.248 E.01938
G1 X117.378 Y134.264 E.00403
G1 X113.767 Y134.269 E.08783
G1 X113.028 Y134.178 E.01811
G1 X112.45 Y133.987 E.01481
G1 X112.007 Y133.751 E.01221
G1 X111.422 Y133.268 E.01845
G1 X110.991 Y132.718 E.017
G1 X109.204 Y129.634 E.0867
G1 X108.904 Y128.912 E.01902
G1 X108.788 Y128.34 E.0142
G1 X108.776 Y127.808 E.01294
G1 X108.85 Y127.281 E.01294
G1 X109.148 Y126.482 E.02074
G1 X110.937 Y123.365 E.08742
G1 X111.283 Y122.883 E.01443
G1 X111.674 Y122.494 E.01342
G1 X112.109 Y122.187 E.01295
G1 X112.56 Y121.967 E.01221
G1 X113.102 Y121.818 E.01367
G1 X113.542 Y121.745 E.01085
G1 X113.542 Y121.745 F9000
G1 X113.528 Y121.378
G1 F6000
G1 X117.379 Y121.371 E.09367
G1 X117.609 Y121.392 E.00562
G1 X118.175 Y121.497 E.014
G1 X118.78 Y121.715 E.01564
G1 X119.293 Y122.011 E.01441
G1 X119.751 Y122.385 E.01438
G1 X120.289 Y123.045 E.02071
G1 X120.38 Y123.182 E.004
G1 X122.113 Y126.183 E.08429
G1 X122.389 Y126.794 E.01631
G1 X122.54 Y127.367 E.01441
G1 X122.596 Y127.904 E.01313
G1 X122.561 Y128.509 E.01474
G1 X122.401 Y129.164 E.0164
G1 X122.113 Y129.817 E.01736
G1 X120.38 Y132.818 E.08429
G1 X119.931 Y133.423 E.01833
G1 X119.712 Y133.648 E.00764
G1 X119.262 Y134.006 E.01399
G1 X118.473 Y134.409 E.02155
G1 X117.61 Y134.608 E.02154
G1 X117.378 Y134.629 E.00567
G1 X113.767 Y134.635 E.08783
G1 X112.979 Y134.54 E.01931
G1 X112.323 Y134.33 E.01675
G1 X111.827 Y134.069 E.01363
G1 X111.183 Y133.545 E.02019
G1 X110.696 Y132.934 E.01901
G1 X108.888 Y129.817 E.08765
G1 X108.565 Y129.048 E.02029
G1 X108.427 Y128.4 E.01612
G1 X108.41 Y127.808 E.01441
G1 X108.489 Y127.222 E.01438
G1 X108.808 Y126.345 E.0227
G1 X110.62 Y123.182 E.08867
G1 X110.988 Y122.667 E.0154
G1 X111.423 Y122.227 E.01505
G1 X111.905 Y121.883 E.0144
G1 X112.408 Y121.635 E.01364
G1 X113.021 Y121.461 E.0155
G1 X113.469 Y121.387 E.01104
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.528 Y121.378 E-.02835
G1 X116.626 Y121.372 E-1.47165
;WIPE_END
G1 X113.012 Y122.215 F9000
G1 X112.787 Y122.286
G1 X112.569 Y122.375
G1 X112.359 Y122.481
G1 X112.159 Y122.605
G1 X111.969 Y122.744
G1 X111.791 Y122.898
G1 X111.626 Y123.066
G1 X111.475 Y123.247
G1 X111.339 Y123.442
G1 X111.274 Y123.546
G1 X109.529 Y126.568
G1 X109.49 Y126.64
G1 X109.387 Y126.855
G1 X109.302 Y127.075
G1 X109.236 Y127.301
G1 X109.188 Y127.531
G1 X109.16 Y127.765
G1 X109.15 Y128
G1 X109.16 Y128.235
G1 X109.188 Y128.469
G1 X109.236 Y128.699
G1 X109.302 Y128.925
G1 X109.387 Y129.145
G1 X109.49 Y129.36
G1 X109.529 Y129.432
G1 X110.058 Y130.344
G1 X106.099 Y136.265
G1 X105.725 Y136.265
G1 E5 F2400
G1 F6000
G1 X105.75 Y136.199 E.00172
G1 X105.75 Y103.607 E.79277
G1 X105.739 Y103.545 E.00153
G1 X105.567 Y103.424 E.00512
G1 X105.297 Y103.424 E.00657
G1 X105.297 Y98.824 E.11189
G1 X105.567 Y98.824 E.00657
G1 X105.714 Y98.751 E.00399
G1 X105.75 Y98.642 E.00279
G1 X105.75 Y91.802 E.16638
G1 X105.701 Y91.677 E.00327
G1 X105.181 Y91.119 E.01855
G1 X104.914 Y90.674 E.01262
G1 X104.913 Y90.336 E.00822
G1 X105.164 Y89.903 E.01217
G1 X105.588 Y89.441 E.01525
G1 X125.41 Y89.441 E.48215
G1 X125.854 Y89.948 E.01639
G1 X126.042 Y90.247 E.00859
G1 X126.099 Y90.466 E.0055
G1 X126.105 Y90.6 E.00326
G1 X125.93 Y90.97 E.00996
G1 X125.296 Y91.68 E.02315
G1 X125.25 Y91.801 E.00315
G1 X125.25 Y98.195 E.15553
G1 X125.27 Y98.725 E.0129
G1 X125.433 Y98.824 E.00464
G1 X125.703 Y98.824 E.00657
G1 X125.703 Y103.424 E.11189
G1 X125.433 Y103.424 E.00657
G1 X125.283 Y103.503 E.00412
G1 X125.25 Y103.607 E.00265
G1 X125.25 Y136.198 E.79274
G1 X125.299 Y136.323 E.00327
G1 X125.819 Y136.881 E.01855
G1 X126.086 Y137.326 E.01262
G1 X126.087 Y137.664 E.00822
G1 X125.837 Y138.097 E.01216
G1 X125.412 Y138.559 E.01527
G1 X105.59 Y138.559 E.48215
G1 X105.121 Y138.024 E.01731
G1 X104.906 Y137.649 E.01051
G1 X104.895 Y137.4 E.00606
G1 X105.07 Y137.03 E.00996
G1 X105.703 Y136.321 E.02312
G1 X105.703 Y136.321 F9000
G1 X106.065 Y136.409
;TYPE:Perimeter
G1 F6000
G1 X106.088 Y136.37 E.0011
G1 X106.116 Y136.199 E.00421
G1 X106.116 Y103.607 E.79277
G1 X106.1 Y103.479 E.00314
G1 X106.018 Y103.294 E.00492
G1 X105.662 Y103.108 E.00977
G1 X105.662 Y99.142 E.09647
G1 X106.007 Y98.969 E.00939
G1 X106.075 Y98.849 E.00335
G1 X106.116 Y98.642 E.00513
G1 X106.116 Y91.802 E.16638
G1 X106.087 Y91.626 E.00434
G1 X105.969 Y91.428 E.00561
G1 X105.546 Y90.973 E.01511
G1 X105.294 Y90.595 E.01105
G1 X105.262 Y90.472 E.00309
G1 X105.426 Y90.173 E.0083
G1 X105.749 Y89.807 E.01187
G1 X125.244 Y89.807 E.4742
G1 X125.603 Y90.217 E.01326
G1 X125.734 Y90.482 E.00719
G1 X125.622 Y90.766 E.00743
G1 X125.024 Y91.436 E.02184
G1 X124.912 Y91.63 E.00545
G1 X124.884 Y91.801 E.00421
G1 X124.889 Y98.714 E.16815
G1 X124.992 Y98.967 E.00664
G1 X125.338 Y99.142 E.00943
G1 X125.338 Y103.108 E.09647
G1 X124.982 Y103.294 E.00977
G1 X124.946 Y103.354 E.0017
G1 X124.884 Y103.607 E.00634
G1 X124.884 Y136.198 E.79274
G1 X124.913 Y136.374 E.00434
G1 X125.031 Y136.572 E.00561
G1 X125.454 Y137.027 E.01511
G1 X125.706 Y137.405 E.01105
G1 X125.738 Y137.528 E.00309
G1 X125.574 Y137.827 E.0083
G1 X125.251 Y138.193 E.01187
G1 X105.756 Y138.193 E.4742
G1 X105.396 Y137.783 E.01327
G1 X105.266 Y137.518 E.00718
G1 X105.378 Y137.234 E.00743
G1 X105.976 Y136.564 E.02184
G1 X106.035 Y136.461 E.00289
G1 X106.035 Y136.461 F9000
G1 X106.398 Y136.55
G1 F6000
G1 X106.436 Y136.484 E.00185
G1 X106.481 Y136.199 E.00702
G1 X106.481 Y103.607 E.79277
G1 X106.456 Y103.394 E.00522
G1 X106.318 Y103.086 E.00821
G1 X106.028 Y102.934 E.00796
G1 X106.028 Y99.324 E.08781
G1 X106.3 Y99.188 E.0074
G1 X106.413 Y98.988 E.00559
G1 X106.481 Y98.642 E.00858
G1 X106.481 Y91.802 E.16638
G1 X106.433 Y91.509 E.00722
G1 X106.236 Y91.179 E.00935
G1 X105.813 Y90.724 E.01511
G1 X105.658 Y90.492 E.00679
G1 X105.909 Y90.172 E.00989
G1 X125.078 Y90.172 E.46627
G1 X125.347 Y90.492 E.01017
G1 X125.314 Y90.562 E.00188
G1 X124.751 Y91.193 E.02057
G1 X124.564 Y91.516 E.00908
G1 X124.519 Y91.801 E.00702
G1 X124.519 Y98.541 E.16394
G1 X124.558 Y98.907 E.00895
G1 X124.697 Y99.184 E.00754
G1 X124.972 Y99.324 E.00751
G1 X124.972 Y102.934 E.08781
G1 X124.682 Y103.086 E.00796
G1 X124.574 Y103.294 E.0057
G1 X124.519 Y103.607 E.00773
G1 X124.519 Y136.198 E.79274
G1 X124.567 Y136.491 E.00722
G1 X124.764 Y136.821 E.00935
G1 X125.187 Y137.276 E.01511
G1 X125.342 Y137.508 E.00679
G1 X125.091 Y137.828 E.00989
G1 X105.922 Y137.828 E.46627
G1 X105.671 Y137.542 E.00926
G1 X105.686 Y137.438 E.00256
G1 X106.249 Y136.807 E.02057
G1 X106.368 Y136.602 E.00577
G1 X106.368 Y136.602 F9000
G1 X106.73 Y136.69
G1 F6000
G1 X106.783 Y136.598 E.00258
G1 X106.847 Y136.199 E.00983
G1 X106.847 Y103.607 E.79277
G1 X106.769 Y103.168 E.01085
G1 X106.619 Y102.877 E.00796
G1 X106.394 Y102.76 E.00617
G1 X106.394 Y99.507 E.07913
G1 X106.593 Y99.406 E.00543
G1 X106.775 Y99.065 E.0094
G1 X106.847 Y98.642 E.01044
G1 X106.847 Y91.802 E.16638
G1 X106.78 Y91.392 E.01011
G1 X106.504 Y90.93 E.01309
G1 X106.139 Y90.538 E.01303
G1 X124.845 Y90.538 E.455
G1 X124.478 Y90.949 E.0134
G1 X124.217 Y91.402 E.01272
G1 X124.153 Y91.801 E.00983
G1 X124.153 Y98.541 E.16394
G1 X124.208 Y99.014 E.01158
G1 X124.403 Y99.402 E.01056
G1 X124.606 Y99.507 E.00556
G1 X124.606 Y102.76 E.07913
G1 X124.381 Y102.877 E.00617
G1 X124.231 Y103.168 E.00796
G1 X124.153 Y103.607 E.01085
G1 X124.153 Y136.198 E.79274
G1 X124.22 Y136.608 E.01011
G1 X124.496 Y137.07 E.01309
G1 X124.861 Y137.462 E.01303
G1 X106.155 Y137.462 E.455
G1 X106.522 Y137.051 E.0134
G1 X106.7 Y136.742 E.00867
G1 X106.7 Y136.742 F9000
G1 X107.062 Y136.831
G1 F6000
G1 X107.13 Y136.712 E.00333
G1 X107.213 Y136.199 E.01264
G1 X107.213 Y103.607 E.79277
G1 X107.113 Y103.043 E.01393
G1 X106.919 Y102.669 E.01025
G1 X106.759 Y102.585 E.0044
G1 X106.759 Y99.689 E.07044
G1 X106.887 Y99.625 E.00348
G1 X107.09 Y99.265 E.01005
G1 X107.177 Y98.983 E.00718
G1 X107.213 Y98.642 E.00834
G1 X107.213 Y91.802 E.16638
G1 X107.126 Y91.275 E.01299
G1 X106.905 Y90.904 E.0105
G1 X124.091 Y90.904 E.41803
G1 X123.87 Y91.288 E.01078
G1 X123.787 Y91.801 E.01264
G1 X123.787 Y98.642 E.1664
G1 X123.859 Y99.122 E.01181
G1 X124.109 Y99.619 E.01353
G1 X124.241 Y99.689 E.00363
G1 X124.241 Y102.585 E.07044
G1 X124.081 Y102.669 E.0044
G1 X123.887 Y103.043 E.01025
G1 X123.787 Y103.607 E.01393
G1 X123.787 Y136.198 E.79274
G1 X123.874 Y136.725 E.01299
G1 X124.095 Y137.096 E.0105
G1 X106.909 Y137.096 E.41803
G1 X107.032 Y136.883 E.00598
G1 X107.032 Y136.883 F9000
G1 X107.392 Y136.829
;TYPE:Solid infill
;WIDTH:0.386478
G1 F1200
G1 X123.611 Y136.829 E.37992
G1 X123.611 Y136.829 F9000
G1 X123.023 Y136.635
;WIDTH:0.4
G1 F3072.127
G1 X123.513 Y136.145 E.01686
G1 X123.513 Y135.619 E.01279
G1 X122.662 Y136.47 E.02927
G1 X122.136 Y136.47 E.01279
G1 X123.513 Y135.093 E.04737
G1 X123.513 Y134.567 E.01279
G1 X121.61 Y136.47 E.06546
G1 X121.084 Y136.47 E.01279
G1 X123.513 Y134.041 E.08356
G1 X123.513 Y133.515 E.01279
G1 X120.558 Y136.47 E.10165
G1 X120.032 Y136.47 E.01279
G1 X123.513 Y132.988 E.11976
G1 X123.513 Y132.462 E.01279
G1 X119.505 Y136.47 E.13787
G1 X118.979 Y136.47 E.01279
G1 X123.513 Y131.936 E.15597
G1 X123.513 Y131.41 E.01279
G1 X118.453 Y136.47 E.17406
G1 X117.927 Y136.47 E.01279
G1 X119.203 Y135.194 E.04389
G1 X118.381 Y135.491 E.02126
G1 X117.401 Y136.47 E.03369
G1 X116.875 Y136.47 E.01279
G1 X117.741 Y135.605 E.02977
G1 X117.174 Y135.645 E.01383
G1 X116.349 Y136.47 E.02838
G1 X115.823 Y136.47 E.01279
G1 X116.648 Y135.645 E.02838
G1 X116.122 Y135.645 E.01279
G1 X115.297 Y136.47 E.02838
G1 X114.771 Y136.47 E.01279
G1 X115.596 Y135.645 E.02838
G1 X115.07 Y135.645 E.01279
G1 X114.245 Y136.47 E.02838
G1 X113.719 Y136.47 E.01279
G1 X114.544 Y135.645 E.02838
G1 X114.018 Y135.645 E.01279
G1 X113.193 Y136.47 E.02838
G1 X112.667 Y136.47 E.01279
G1 X113.509 Y135.628 E.02896
G1 X113.047 Y135.564 E.01135
G1 X112.141 Y136.47 E.03117
G1 X111.615 Y136.47 E.01279
G1 X112.603 Y135.482 E.03399
G1 X112.2 Y135.359 E.01025
G1 X111.089 Y136.47 E.03822
G1 X110.563 Y136.47 E.01279
G1 X111.826 Y135.207 E.04345
G1 X111.479 Y135.028 E.0095
G1 X110.037 Y136.47 E.0496
G1 X109.511 Y136.47 E.01279
G1 X111.16 Y134.821 E.05672
G1 X110.852 Y134.602 E.00919
G1 X108.985 Y136.47 E.06424
G1 X108.459 Y136.47 E.01279
G1 X110.572 Y134.356 E.0727
G1 X110.318 Y134.085 E.00903
G1 X107.933 Y136.47 E.08204
G1 X107.445 Y136.47 E.01187
G1 X110.074 Y133.803 E.09109
G1 X109.857 Y133.494 E.00918
G1 X107.487 Y135.864 E.08153
G1 X107.487 Y135.338 E.01279
G1 X109.663 Y133.161 E.07487
G1 X109.47 Y132.828 E.00936
G1 X107.487 Y134.812 E.06823
G1 X107.487 Y134.286 E.01279
G1 X109.277 Y132.496 E.06157
G1 X109.083 Y132.163 E.00937
G1 X107.487 Y133.759 E.0549
G1 X107.487 Y133.233 E.01279
G1 X108.89 Y131.83 E.04826
G1 X108.696 Y131.498 E.00935
G1 X107.487 Y132.707 E.04159
G1 X107.487 Y132.181 E.01279
G1 X108.503 Y131.165 E.03495
G1 X108.31 Y130.833 E.00934
G1 X107.487 Y131.655 E.02829
G1 X107.487 Y131.129 E.01279
G1 X108.116 Y130.5 E.02164
G1 X107.934 Y130.156 E.00947
G1 X107.487 Y130.603 E.01538
G1 X107.487 Y130.077 E.01279
G1 X107.764 Y129.8 E.00953
G1 X107.611 Y129.427 E.00981
G1 X107.322 Y129.716 E.00994
G1 E-5 F3600
G1 X107.322 Y129.716 F9000
G1 X109.588 Y123.297
G1 E5 F2400
G1 F3072.127
G1 X107.487 Y125.397 E.07226
G1 X107.487 Y125.916 E.01262
G1 X108.413 Y124.99 E.03185
G1 X107.803 Y126.119 E.03121
G1 X107.322 Y126.6 E.01655
G1 X107.322 Y126.6 F9000
G1 X107.322 Y125.043
G1 F3072.127
G1 X111.388 Y120.978 E.13985
G1 X111.083 Y120.763 E.00908
G1 X107.487 Y124.36 E.12372
G1 X107.487 Y123.841 E.01262
G1 X110.782 Y120.546 E.11335
G1 X110.509 Y120.3 E.00894
G1 X107.487 Y123.322 E.10395
G1 X107.487 Y122.803 E.01262
G1 X110.265 Y120.026 E.09554
G1 X110.03 Y119.742 E.00897
G1 X107.487 Y122.285 E.08748
G1 X107.487 Y121.766 E.01262
G1 X109.821 Y119.432 E.08029
G1 X109.63 Y119.104 E.00923
G1 X107.487 Y121.247 E.07372
G1 X107.487 Y120.728 E.01262
G1 X109.439 Y118.776 E.06715
G1 X109.249 Y118.448 E.00922
G1 X107.487 Y120.209 E.06059
G1 X107.487 Y119.691 E.0126
G1 X109.058 Y118.12 E.05404
G1 X108.867 Y117.791 E.00925
G1 X107.487 Y119.172 E.04749
G1 X107.487 Y118.653 E.01262
G1 X108.676 Y117.463 E.04092
G1 X108.486 Y117.135 E.00922
G1 X107.487 Y118.134 E.03437
G1 X107.487 Y117.615 E.01262
G1 X108.295 Y116.807 E.02779
G1 X108.104 Y116.479 E.00923
G1 X107.487 Y117.097 E.02124
G1 X107.487 Y116.578 E.01262
G1 X107.926 Y116.139 E.0151
G1 X107.758 Y115.787 E.00949
G1 X107.487 Y116.059 E.00934
G1 X107.487 Y115.54 E.01262
G1 X107.735 Y115.292 E.00853
G1 X107.735 Y115.292 F9000
G1 X107.781 Y114.814
;TYPE:Solid infill
;WIDTH:0.534686
G1 F1200
G1 X107.815 Y114.883 E.00256
;WIDTH:0.494595
G1 X107.848 Y114.951 E.00231
;WIDTH:0.454504
G1 X108.075 Y115.558 E.01811
;WIDTH:0.436574
G1 X108.336 Y116.146 E.01721
;WIDTH:0.403992
G1 X110.066 Y119.133 E.08488
;WIDTH:0.41674
G1 X110.195 Y119.331 E.00601
G1 X110.593 Y119.846 E.01656
;WIDTH:0.38425
G1 X111.115 Y120.339 E.01671
;WIDTH:0.40834
G1 X111.752 Y120.758 E.01897
;WIDTH:0.450318
G1 X111.787 Y120.799 E.00149
;WIDTH:0.492296
G1 X111.822 Y120.84 E.00164
;WIDTH:0.534274
G1 X111.856 Y120.88 E.00175
;WIDTH:0.576252
G1 X111.891 Y120.921 E.00194
;WIDTH:0.61823
G1 X111.926 Y120.961 E.00206
;WIDTH:0.660208
G1 X111.961 Y121.002 E.00224
G1 X111.926 Y121.041 E.00218
;WIDTH:0.615857
G1 X111.891 Y121.081 E.00206
;WIDTH:0.571506
G1 X111.855 Y121.12 E.0019
;WIDTH:0.527155
G1 X111.82 Y121.16 E.00174
;WIDTH:0.482804
G1 X111.785 Y121.199 E.00156
;WIDTH:0.438453
G1 X111.75 Y121.238 E.00141
;WIDTH:0.409828
G1 X110.996 Y121.752 E.02279
;WIDTH:0.411238
G1 X110.432 Y122.346 E.02054
G1 X110.067 Y122.867 E.01595
;WIDTH:0.40398
G1 X108.324 Y125.88 E.08559
;WIDTH:0.41069
G1 X107.949 Y126.762 E.02399
;WIDTH:0.407582
G1 X107.808 Y127.522 E.01919
;WIDTH:0.373249
G1 X107.811 Y128.415 E.02013
;WIDTH:0.419969
G1 X107.794 Y128.467 E.0014
;WIDTH:0.466689
G1 X107.777 Y128.519 E.00157
;WIDTH:0.513409
G1 X107.76 Y128.571 E.00174
;WIDTH:0.560129
G1 X107.744 Y128.624 E.00194
G1 X107.781 Y128.814 E.00677
;WIDTH:0.560667
G1 X107.699 Y128.749 E.00366
G1 X107.567 Y128.715 E.00477
;WIDTH:0.560129
G1 X107.567 Y128.635 E.0028
G1 X107.544 Y128.585 E.00192
;WIDTH:0.513409
G1 X107.52 Y128.536 E.00174
;WIDTH:0.466689
G1 X107.497 Y128.486 E.00158
;WIDTH:0.419969
G1 X107.474 Y128.437 E.00139
;WIDTH:0.373249
G1 X107.466 Y128.177 E.00586
;WIDTH:0.370521
G1 X107.472 Y127.415 E.01704
G1 X107.626 Y127.303 E.00426
;WIDTH:0.39957
G1 X107.867 Y126.891 E.0116
G1 X107.867 Y126.891 F9000
;WIDTH:0.533854
G1 F1200
G1 X107.815 Y128.883 E.00256
;WIDTH:0.494353
G1 X107.848 Y128.951 E.00231
;WIDTH:0.454852
G1 X108.069 Y129.561 E.01815
;WIDTH:0.423024
G1 X108.336 Y130.146 E.01663
;WIDTH:0.40399
G1 X110.066 Y133.133 E.08488
;WIDTH:0.394892
G1 X110.076 Y133.149 E.00045
;WIDTH:0.418624
G1 X110.398 Y133.611 E.0144
G1 X110.768 Y134.029 E.01427
;WIDTH:0.415898
G1 X111.219 Y134.417 E.0151
;WIDTH:0.406964
G1 X111.901 Y134.838 E.01987
;WIDTH:0.407212
G1 X112.416 Y135.048 E.0138
G1 X112.901 Y135.174 E.01243
;WIDTH:0.404124
G1 X113.776 Y135.277 E.02167
;WIDTH:0.409412
G1 X117.402 Y135.263 E.09047
;WIDTH:0.39749
G1 X118.308 Y135.127 E.02213
;WIDTH:0.4163
G1 X118.92 Y134.917 E.01644
G1 X119.666 Y134.504 E.02167
;WIDTH:0.4009
G1 X120.12 Y134.139 E.0142
;WIDTH:0.418126
G1 X120.565 Y133.652 E.01684
G1 X120.934 Y133.132 E.01628
;WIDTH:0.400058
G1 X122.665 Y130.139 E.08411
;WIDTH:0.41584
G1 X122.815 Y129.824 E.00885
;WIDTH:0.416382
G1 X123.042 Y129.245 E.01581
G1 E-5 F3600
G1 X123.042 Y129.245 F9000
G1 X123.055 Y112.775
G1 E5 F2400
;WIDTH:0.415045
G1 F1200
G1 X123.372 Y113.304 E.01562
;WIDTH:0.375878
G1 X123.525 Y113.416 E.00431
G1 X123.535 Y113.999 E.01325
;WIDTH:0.377139
G1 X123.525 Y114.678 E.01549
G1 X123.362 Y114.816 E.00487
;WIDTH:0.416332
G1 X123.042 Y115.245 E.0136
G1 X123.051 Y115.199 E.00119
;WIDTH:0.411731
G1 X123.182 Y114.595 E.01552
;WIDTH:0.377139
G1 X123.212 Y113.963 E.01443
;WIDTH:0.375878
G1 X123.159 Y113.272 E.01575
;WIDTH:0.400964
G1 X123.092 Y112.954 E.00793
;WIDTH:0.416632
G1 X123.049 Y112.76 E.00505
G1 X122.934 Y112.437 E.00872
;WIDTH:0.416038
G1 X122.664 Y111.854 E.01631
;WIDTH:0.403992
G1 X120.934 Y108.868 E.08486
;WIDTH:0.41871
G1 X120.805 Y108.671 E.00602
G1 X120.366 Y108.12 E.01801
;WIDTH:0.409742
G1 X119.827 Y107.608 E.01856
G1 X119.253 Y107.234 E.01711
;WIDTH:0.447313
G1 X119.218 Y107.195 E.00144
;WIDTH:0.490893
G1 X119.182 Y107.156 E.00161
;WIDTH:0.534473
G1 X119.147 Y107.116 E.00177
;WIDTH:0.578054
G1 X119.112 Y107.077 E.0019
;WIDTH:0.621634
G1 X119.076 Y107.037 E.0021
;WIDTH:0.665214
G1 X119.041 Y106.998 E.0022
G1 X119.076 Y106.957 E.00226
;WIDTH:0.620922
G1 X119.112 Y106.917 E.0021
;WIDTH:0.576629
G1 X119.148 Y106.876 E.00197
;WIDTH:0.532336
G1 X119.184 Y106.836 E.00178
;WIDTH:0.488044
G1 X119.22 Y106.795 E.00165
;WIDTH:0.443751
G1 X119.255 Y106.755 E.00145
;WIDTH:0.414126
G1 X119.557 Y106.58 E.00882
;WIDTH:0.426722
G1 X119.961 Y106.275 E.01321
G1 X120.566 Y105.651 E.02269
;WIDTH:0.417422
G1 X120.933 Y105.134 E.01616
;WIDTH:0.400054
G1 X122.664 Y102.141 E.08411
;WIDTH:0.408014
G1 X122.987 Y101.388 E.02037
;WIDTH:0.38724
G1 X123.187 Y100.601 E.01906
;WIDTH:0.394222
G1 X123.231 Y99.963 E.01531
G1 X123.164 Y99.271 E.01664
;WIDTH:0.393812
G1 X122.993 Y98.595 E.01667
;WIDTH:0.39604
G1 X122.663 Y97.861 E.01936
G1 X120.933 Y94.866 E.08322
;WIDTH:0.3939
G1 X120.926 Y94.855 E.00031
;WIDTH:0.401406
G1 X120.578 Y94.351 E.01496
;WIDTH:0.403036
G1 X120.096 Y93.838 E.01726
G1 X119.369 Y93.307 E.02208
;WIDTH:0.404628
G1 X118.908 Y93.077 E.01269
;WIDTH:0.412826
G1 X117.932 Y92.787 E.02563
G1 X117.376 Y92.731 E.01407
;WIDTH:0.399692
G1 X115.936 Y92.727 E.035
;WIDTH:0.416476
G1 X113.783 Y92.729 E.05473
G1 X113.499 Y92.745 E.00723
;WIDTH:0.408924
G1 X112.648 Y92.884 E.02149
G1 X112.069 Y93.086 E.01528
;WIDTH:0.406478
G1 X111.305 Y93.517 E.02171
;WIDTH:0.422494
G1 X110.919 Y93.837 E.01295
G1 X110.433 Y94.347 E.01819
;WIDTH:0.412802
G1 X110.067 Y94.867 E.01601
;WIDTH:0.403982
G1 X108.323 Y97.882 E.08564
;WIDTH:0.401756
G1 X107.905 Y98.929 E.02755
;WIDTH:0.403206
G1 X107.792 Y99.517 E.01469
G1 X107.774 Y100.182 E.01632
;WIDTH:0.419254
G1 X107.823 Y100.688 E.01302
;WIDTH:0.434446
G1 X107.972 Y101.268 E.01594
G1 X108.337 Y102.139 E.02514
;WIDTH:0.403868
G1 X110.169 Y105.3 E.08981
;WIDTH:0.407592
G1 X110.654 Y105.911 E.01937
;WIDTH:0.381724
G1 X111.294 Y106.466 E.01958
;WIDTH:0.406202
G1 X111.751 Y106.759 E.01343
;WIDTH:0.448174
G1 X111.786 Y106.8 E.00148
;WIDTH:0.490146
G1 X111.821 Y106.84 E.00161
;WIDTH:0.532118
G1 X111.856 Y106.88 E.00176
;WIDTH:0.57409
G1 X111.89 Y106.921 E.00191
;WIDTH:0.616062
G1 X111.925 Y106.961 E.00206
;WIDTH:0.658034
G1 X111.96 Y107.002 E.00224
G1 X111.926 Y107.041 E.00215
;WIDTH:0.615185
G1 X111.891 Y107.081 E.00205
;WIDTH:0.572336
G1 X111.856 Y107.121 E.0019
;WIDTH:0.529486
G1 X111.821 Y107.161 E.00175
;WIDTH:0.486637
G1 X111.787 Y107.201 E.00158
;WIDTH:0.443788
G1 X111.752 Y107.241 E.00145
;WIDTH:0.412938
G1 X110.997 Y107.753 E.02297
;WIDTH:0.41733
G1 X110.434 Y108.348 E.02087
G1 X110.067 Y108.867 E.01619
;WIDTH:0.40398
G1 X108.324 Y111.88 E.08559
;WIDTH:0.410692
G1 X107.949 Y112.762 E.02399
;WIDTH:0.407582
G1 X107.808 Y113.522 E.01919
;WIDTH:0.373394
G1 X107.811 Y114.416 E.02016
;WIDTH:0.420041
G1 X107.794 Y114.467 E.00138
;WIDTH:0.466688
G1 X107.778 Y114.519 E.00156
;WIDTH:0.513335
G1 X107.761 Y114.571 E.00174
;WIDTH:0.559982
G1 X107.744 Y114.623 E.00191
G1 X107.781 Y114.814 E.0068
;WIDTH:0.560771
G1 X107.699 Y114.749 E.00366
G1 X107.567 Y114.715 E.00477
;WIDTH:0.559982
G1 X107.567 Y114.635 E.0028
G1 X107.544 Y114.585 E.00192
;WIDTH:0.513335
G1 X107.52 Y114.536 E.00174
;WIDTH:0.466688
G1 X107.497 Y114.487 E.00156
;WIDTH:0.420041
G1 X107.474 Y114.437 E.00141
;WIDTH:0.373394
G1 X107.466 Y114.177 E.00587
;WIDTH:0.370521
G1 X107.472 Y113.415 E.01704
G1 X107.626 Y113.303 E.00426
;WIDTH:0.399571
G1 X107.867 Y112.891 E.0116
G1 E-5 F3600
G1 X107.867 Y112.891 F9000
G1 X113.474 Y119.871
G1 X113.671 Y119.883
G1 X113.75 Y119.887
G1 X117.245 Y119.887
G1 X117.406 Y119.881
G1 X117.643 Y119.857
G1 X117.874 Y119.814
G1 X118.101 Y119.752
G1 X118.323 Y119.672
G1 X118.537 Y119.574
G1 X118.742 Y119.459
G1 X118.938 Y119.328
G1 X119.122 Y119.181
G1 X119.293 Y119.02
G1 E5 F2400
;WIDTH:0.416332
G1 F1200
G1 X122.815 Y115.824 E.0158
;WIDTH:0.415994
G1 X122.664 Y116.141 E.00891
;WIDTH:0.400052
G1 X120.934 Y119.132 E.08406
;WIDTH:0.415102
G1 X120.567 Y119.652 E.01612
G1 X120.176 Y120.081 E.0147
;WIDTH:0.39251
G1 X119.599 Y120.549 E.0177
;WIDTH:0.408236
G1 X119.254 Y120.76 E.01006
;WIDTH:0.451015
G1 X119.219 Y120.8 E.00147
;WIDTH:0.493793
G1 X119.183 Y120.839 E.00162
;WIDTH:0.536571
G1 X119.148 Y120.879 E.00178
;WIDTH:0.57935
G1 X119.113 Y120.918 E.0019
;WIDTH:0.622128
G1 X119.077 Y120.958 E.0021
;WIDTH:0.664906
G1 X119.042 Y120.997 E.0022
G1 X119.078 Y121.038 E.00229
;WIDTH:0.619958
G1 X119.115 Y121.079 E.00215
;WIDTH:0.57501
G1 X119.151 Y121.12 E.00196
;WIDTH:0.530061
G1 X119.187 Y121.162 E.00182
;WIDTH:0.485113
G1 X119.224 Y121.203 E.00166
;WIDTH:0.440165
G1 X119.26 Y121.244 E.00147
;WIDTH:0.410654
G1 X119.77 Y121.57 E.01515
G1 X120.369 Y122.118 E.02032
;WIDTH:0.41873
G1 X120.805 Y122.671 E.01801
G1 X120.934 Y122.868 E.00602
;WIDTH:0.40399
G1 X122.664 Y125.854 E.08486
;WIDTH:0.41604
G1 X122.934 Y126.437 E.01631
;WIDTH:0.416624
G1 X123.049 Y126.76 E.00872
G1 X123.092 Y126.954 E.00505
;WIDTH:0.400376
G1 X123.158 Y127.272 E.00791
;WIDTH:0.374435
G1 X123.213 Y127.891 E.01406
;WIDTH:0.377028
G1 X123.182 Y128.596 E.01609
;WIDTH:0.411762
G1 X123.051 Y129.199 E.01549
;WIDTH:0.416382
G1 X123.042 Y129.245 E.00119
G1 X123.362 Y128.816 E.0136
;WIDTH:0.377028
G1 X123.525 Y128.678 E.00487
G1 X123.535 Y127.927 E.01712
;WIDTH:0.374435
G1 X123.526 Y127.416 E.01156
G1 X123.373 Y127.304 E.00429
;WIDTH:0.414983
G1 X123.055 Y126.775 E.01563
G1 X123.055 Y126.775 F9000
G1 X123.35 Y126.872
;WIDTH:0.4
G1 F3072.127
G1 X123.513 Y126.709 E.00561
G1 X123.513 Y126.184 E.01277
G1 X123.312 Y126.385 E.00691
G1 X123.151 Y126.022 E.00966
G1 X123.513 Y125.66 E.01245
G1 X123.513 Y125.135 E.01277
G1 X122.981 Y125.667 E.0183
G1 X122.788 Y125.335 E.00934
G1 X123.513 Y124.61 E.02494
G1 X123.513 Y124.086 E.01275
G1 X122.595 Y125.004 E.03158
G1 X122.402 Y124.672 E.00934
G1 X123.513 Y123.561 E.03822
G1 X123.513 Y123.036 E.01277
G1 X122.209 Y124.34 E.04486
G1 X122.016 Y124.008 E.00934
G1 X123.513 Y122.512 E.05148
G1 X123.513 Y121.987 E.01277
G1 X121.823 Y123.676 E.05812
G1 X121.631 Y123.345 E.00931
G1 X123.513 Y121.462 E.06476
G1 X123.513 Y120.938 E.01275
G1 X121.438 Y123.013 E.07138
G1 X121.245 Y122.681 E.00934
G1 X123.513 Y120.413 E.07802
G1 X123.513 Y119.888 E.01277
G1 X121.042 Y122.36 E.08502
G1 X120.812 Y122.065 E.0091
G1 X123.513 Y119.364 E.09291
G1 X123.513 Y118.839 E.01277
G1 X120.555 Y121.797 E.10175
G1 X120.298 Y121.529 E.00903
G1 X123.513 Y118.314 E.11059
G1 X123.513 Y117.79 E.01275
G1 X120.014 Y121.289 E.12036
G1 X119.693 Y121.085 E.00925
G1 X123.513 Y117.265 E.13141
G1 X123.513 Y116.74 E.01277
G1 X121.672 Y118.581 E.06333
G1 X122.396 Y117.332 E.03512
G1 X123.513 Y116.216 E.03841
G1 X123.513 Y115.691 E.01277
G1 X122.668 Y116.536 E.02907
G1 E-5 F3600
G1 X122.668 Y116.536 F9000
G1 X123.352 Y112.877
G1 E5 F2400
G1 F3072.127
G1 X123.513 Y112.716 E.00554
G1 X123.513 Y112.197 E.01262
G1 X123.315 Y112.395 E.00681
G1 X123.156 Y112.034 E.00959
G1 X123.513 Y111.677 E.01228
G1 X123.513 Y111.157 E.01265
G1 X122.989 Y111.682 E.01804
G1 X122.798 Y111.353 E.00925
G1 X123.513 Y110.638 E.0246
G1 X123.513 Y110.118 E.01265
G1 X122.607 Y111.024 E.03117
G1 X122.416 Y110.695 E.00925
G1 X123.513 Y109.598 E.03774
G1 X123.513 Y109.079 E.01262
G1 X122.225 Y110.367 E.04431
G1 X122.034 Y110.038 E.00925
G1 X123.513 Y108.559 E.05088
G1 X123.513 Y108.039 E.01265
G1 X121.843 Y109.71 E.05746
G1 X121.652 Y109.381 E.00925
G1 X123.513 Y107.52 E.06402
G1 X123.513 Y107 E.01265
G1 X121.461 Y109.052 E.07059
G1 X121.27 Y108.724 E.00923
G1 X123.513 Y106.48 E.07718
G1 X123.513 Y105.961 E.01262
G1 X121.073 Y108.401 E.08393
G1 X120.85 Y108.104 E.00903
G1 X123.513 Y105.441 E.09161
G1 X123.513 Y104.921 E.01265
G1 X120.596 Y107.838 E.10034
G1 X120.342 Y107.573 E.00893
G1 X123.513 Y104.402 E.10908
G1 X123.513 Y103.882 E.01265
G1 X120.069 Y107.326 E.11847
G1 X119.755 Y107.12 E.00913
G1 X123.545 Y103.33 E.13037
G1 X123.73 Y102.72 E.01551
G1 X123.866 Y102.496 E.00637
G1 X123.966 Y102.443 E.00275
G1 X123.966 Y102.389 E.00131
G1 X121.531 Y104.824 E.08376
G1 X122.248 Y103.588 E.03476
G1 X123.966 Y101.869 E.05912
G1 X123.966 Y101.35 E.01262
G1 X122.965 Y102.351 E.03443
G1 X123.372 Y101.424 E.02463
G1 X123.966 Y100.83 E.02043
G1 X123.966 Y100.31 E.01265
G1 X123.538 Y100.739 E.01474
G1 X123.603 Y100.154 E.01432
G1 X123.936 Y99.821 E.01146
G1 X123.723 Y99.515 E.00907
G1 X123.581 Y99.656 E.00487
G1 X123.516 Y98.683 E.02372
G1 X123.432 Y98.766 E.00287
G1 X123.307 Y98.372 E.01005
G1 X123.513 Y98.165 E.0071
G1 X123.513 Y97.646 E.01262
G1 X123.149 Y98.01 E.01252
G1 X122.972 Y97.667 E.00939
G1 X123.513 Y97.126 E.01861
G1 X123.513 Y96.606 E.01265
G1 X122.781 Y97.338 E.02518
G1 X122.591 Y97.009 E.00924
G1 X123.513 Y96.087 E.03172
G1 X123.513 Y95.567 E.01265
G1 X122.4 Y96.68 E.03829
G1 X122.21 Y96.351 E.00924
G1 X123.513 Y95.047 E.04484
G1 X123.513 Y94.528 E.01262
G1 X122.02 Y96.021 E.05136
G1 X121.829 Y95.692 E.00925
G1 X123.513 Y94.008 E.05793
G1 X123.513 Y93.488 E.01265
G1 X121.639 Y95.363 E.06448
G1 X121.448 Y95.034 E.00925
G1 X123.513 Y92.969 E.07103
G1 X123.513 Y92.449 E.01265
G1 X121.258 Y94.704 E.07757
G1 X121.059 Y94.383 E.00919
G1 X123.513 Y91.929 E.08442
G1 X123.555 Y91.53 E.00976
G1 X123.393 Y91.53 E.00394
G1 X120.835 Y94.088 E.08799
G1 X120.583 Y93.82 E.00895
G1 X122.873 Y91.53 E.07877
G1 X122.353 Y91.53 E.01265
G1 X120.33 Y93.554 E.06961
G1 X120.046 Y93.318 E.00898
G1 X121.834 Y91.53 E.06151
G1 X121.314 Y91.53 E.01265
G1 X119.737 Y93.107 E.05425
G1 X119.414 Y92.911 E.00919
G1 X120.794 Y91.53 E.04749
G1 X120.275 Y91.53 E.01262
G1 X119.062 Y92.743 E.04173
G1 X118.674 Y92.611 E.00997
G1 X119.755 Y91.53 E.03719
G1 X119.235 Y91.53 E.01265
G1 X118.28 Y92.486 E.03287
G1 X117.847 Y92.399 E.01074
G1 X118.716 Y91.53 E.02989
G1 X118.196 Y91.53 E.01265
G1 X117.36 Y92.366 E.02876
G1 X116.842 Y92.364 E.0126
G1 X117.676 Y91.53 E.02869
G1 X117.157 Y91.53 E.01262
G1 X116.324 Y92.363 E.02865
G1 X115.806 Y92.361 E.0126
G1 X116.637 Y91.53 E.02859
G1 X116.117 Y91.53 E.01265
G1 X115.288 Y92.36 E.02853
G1 X114.77 Y92.358 E.0126
G1 X115.598 Y91.53 E.02848
G1 X115.078 Y91.53 E.01265
G1 X114.252 Y92.356 E.02841
G1 X113.73 Y92.358 E.0127
G1 X114.558 Y91.53 E.02848
G1 X114.039 Y91.53 E.01262
G1 X113.15 Y92.418 E.03056
G1 X112.509 Y92.54 E.01587
G1 X113.519 Y91.53 E.03474
G1 X112.999 Y91.53 E.01265
G1 X111.65 Y92.879 E.0464
G1 X111.029 Y93.258 E.0177
G1 X110.647 Y93.575 E.01207
G1 X110.137 Y94.12 E.01816
G1 X109.626 Y94.903 E.02274
G1 X107.487 Y97.042 E.07358
G1 X107.487 Y96.523 E.01262
G1 X112.48 Y91.53 E.17176
G1 X111.96 Y91.53 E.01265
G1 X107.487 Y96.003 E.15387
G1 X107.487 Y95.483 E.01265
G1 X111.44 Y91.53 E.13598
G1 X110.921 Y91.53 E.01262
G1 X107.487 Y94.964 E.11813
G1 X107.487 Y94.444 E.01265
G1 X110.401 Y91.53 E.10024
G1 X109.881 Y91.53 E.01265
G1 X107.487 Y93.924 E.08235
G1 X107.487 Y93.405 E.01262
G1 X109.362 Y91.53 E.0645
G1 X108.842 Y91.53 E.01265
G1 X107.487 Y92.885 E.04661
G1 X107.487 Y92.365 E.01265
G1 X108.322 Y91.53 E.02872
G1 X107.803 Y91.53 E.01262
G1 X107.322 Y92.01 E.01653
G1 X107.322 Y92.01 F9000
G1 X107.389 Y91.171
;TYPE:Solid infill
;WIDTH:0.386506
G1 F1200
G1 X123.608 Y91.171 E.37995
G1 E-5 F3600
G1 X113.012 Y94.215 F9000
G1 X112.787 Y94.286
G1 X112.569 Y94.375
G1 X112.359 Y94.481
G1 X112.159 Y94.605
G1 X107.322 Y97.727
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X108.904 Y96.145 E.05442
G1 X108.183 Y97.386 E.03491
G1 X107.487 Y98.082 E.02394
G1 X107.487 Y98.601 E.01262
G1 X107.68 Y98.408 E.00664
G1 X107.478 Y99.129 E.01821
G1 X107.203 Y99.646 E.01424
G1 X107.034 Y99.836 E.00619
G1 X107.034 Y100.094 E.00628
G1 X107.408 Y99.72 E.01287
G1 X107.41 Y100.237 E.01258
G1 X107.034 Y100.614 E.01295
G1 X107.034 Y101.133 E.01262
G1 X107.449 Y100.718 E.01428
G1 X107.547 Y101.14 E.01054
G1 X107.034 Y101.653 E.01765
G1 X107.034 Y102.173 E.01265
G1 X107.663 Y101.543 E.02165
G1 X107.815 Y101.911 E.00968
G1 X107.17 Y102.556 E.02219
G1 X107.348 Y102.898 E.00938
G1 X107.986 Y102.26 E.02195
G1 X108.176 Y102.589 E.00924
G1 X107.453 Y103.313 E.02489
G1 X107.487 Y103.798 E.01183
G1 X108.367 Y102.918 E.03027
G1 X108.557 Y103.247 E.00924
G1 X107.487 Y104.318 E.03682
G1 X107.487 Y104.837 E.01262
G1 X108.748 Y103.577 E.04336
G1 X108.938 Y103.906 E.00924
G1 X107.487 Y105.357 E.04991
G1 X107.487 Y105.877 E.01265
G1 X109.129 Y104.235 E.05648
G1 X109.319 Y104.564 E.00924
G1 X107.487 Y106.397 E.06304
G1 X107.487 Y106.916 E.01262
G1 X109.51 Y104.893 E.06959
G1 X109.7 Y105.223 E.00926
G1 X107.487 Y107.436 E.07613
G1 X107.487 Y107.956 E.01265
G1 X109.892 Y105.551 E.08273
G1 X110.11 Y105.852 E.00904
G1 X107.487 Y108.475 E.09023
G1 X107.487 Y108.995 E.01265
G1 X110.355 Y106.127 E.09866
G1 X110.607 Y106.394 E.00893
G1 X107.487 Y109.515 E.10734
G1 X107.487 Y110.034 E.01262
G1 X110.894 Y106.627 E.1172
G1 X111.196 Y106.844 E.00905
G1 X107.487 Y110.554 E.1276
G1 X107.487 Y111.074 E.01265
G1 X109.583 Y108.978 E.0721
G1 X108.861 Y110.219 E.03492
G1 X107.487 Y111.593 E.04726
G1 X107.487 Y112.113 E.01265
G1 X108.139 Y111.46 E.02245
G1 X107.663 Y112.456 E.02685
G1 X107.322 Y112.797 E.01173
G1 E-5 F3600
G1 X107.322 Y112.797 F9000
G1 X116.587 Y122.114
G1 X117.245 Y122.113
G1 X117.406 Y122.119
G1 X117.643 Y122.143
G1 X117.874 Y122.186
G1 X118.101 Y122.248
G1 X118.323 Y122.328
G1 X118.537 Y122.426
G1 X118.742 Y122.541
G1 X118.938 Y122.672
G1 X119.122 Y122.819
G1 X119.293 Y122.98
G1 X119.451 Y123.155
G1 X119.594 Y123.342
G1 X119.709 Y123.517
G1 X121.471 Y126.569
G1 X121.563 Y126.745
G1 X123.069 Y129.75
G1 E5 F2400
G1 F3072.127
G1 X123.513 Y129.306 E.01527
G1 X123.513 Y129.832 E.01279
G1 X122.925 Y130.42 E.02023
G1 X122.199 Y131.672 E.0352
G1 X123.513 Y130.358 E.0452
G1 X123.513 Y130.884 E.01279
G1 X121.021 Y133.377 E.08574
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X123.254 Y131.144 E-1.5
;WIPE_END
G1 X121.848 Y99.882 F9000
G1 X121.076 Y89.79
G1 X120.99 Y88.151
G1 X120.908 Y86.599
G1 X121.199 Y85.151
G1 X120.85 Y85.5
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X120.85 Y85.38 E.00292
G1 X120.77 Y85.229 E.00416
G1 X120.667 Y85.197 E.00262
G1 X110.333 Y85.197 E.25136
G1 X110.268 Y85.209 E.00161
G1 X110.15 Y85.38 E.00505
G1 X110.15 Y85.5 E.00292
G1 X104.557 Y85.5 E.13604
G1 X103.987 Y85.458 E.0139
G1 X103.437 Y85.333 E.01372
G1 X102.867 Y85.106 E.01492
G1 X102.41 Y84.839 E.01287
G1 X102.078 Y84.567 E.01044
G1 X101.584 Y84.074 E.01698
G1 X101.127 Y83.348 E.02087
G1 X100.864 Y82.612 E.01901
G1 X100.761 Y81.98 E.01558
G1 X100.75 Y78.802 E.0773
G1 X100.7 Y78.677 E.00327
G1 X100.071 Y77.966 E.02309
G1 X99.901 Y77.62 E.00938
G1 X99.903 Y77.357 E.0064
G1 X100.055 Y77.052 E.00829
G1 X100.59 Y76.441 E.01975
G1 X130.41 Y76.441 E.72534
G1 X130.992 Y77.145 E.02222
G1 X131.107 Y77.451 E.00795
G1 X131.117 Y77.537 E.00211
G1 X131.053 Y77.748 E.00536
G1 X130.745 Y78.208 E.01347
G1 X130.3 Y78.677 E.01573
G1 X130.25 Y78.802 E.00327
G1 X130.24 Y81.704 E.07059
G1 X130.197 Y82.263 E.01364
G1 X130.071 Y82.814 E.01375
G1 X129.862 Y83.346 E.0139
G1 X129.577 Y83.839 E.01385
G1 X129.227 Y84.278 E.01366
G1 X128.803 Y84.67 E.01405
G1 X128.357 Y84.975 E.01314
G1 X127.833 Y85.239 E.01427
G1 X127.29 Y85.405 E.01381
G1 X126.732 Y85.489 E.01373
G1 X120.91 Y85.5 E.14161
G1 X120.91 Y85.5 F9000
G1 X121.029 Y85.027
;TYPE:Perimeter
G1 F6000
G1 X120.975 Y84.926 E.00279
G1 X120.86 Y84.866 E.00316
G1 X120.667 Y84.831 E.00477
G1 X110.333 Y84.831 E.25136
G1 X110.238 Y84.84 E.00232
G1 X110.024 Y84.927 E.00562
G1 X109.914 Y85.134 E.0057
G1 X105.287 Y85.134 E.11255
G1 X104.299 Y85.114 E.02404
G1 X103.8 Y85.04 E.01227
G1 X103.295 Y84.882 E.01287
G1 X102.829 Y84.66 E.01256
G1 X102.309 Y84.284 E.01561
G1 X101.876 Y83.852 E.01488
G1 X101.458 Y83.187 E.01911
G1 X101.22 Y82.52 E.01723
G1 X101.127 Y81.95 E.01405
G1 X101.116 Y78.801 E.0766
G1 X101.086 Y78.624 E.00437
G1 X100.965 Y78.425 E.00567
G1 X100.379 Y77.767 E.02143
G1 X100.253 Y77.518 E.00679
G1 X100.361 Y77.257 E.00687
G1 X100.756 Y76.807 E.01456
G1 X130.244 Y76.807 E.71727
G1 X130.602 Y77.215 E.0132
G1 X130.744 Y77.49 E.00753
G1 X130.737 Y77.562 E.00176
G1 X130.466 Y77.971 E.01193
G1 X130.035 Y78.425 E.01523
G1 X129.914 Y78.624 E.00567
G1 X129.884 Y78.801 E.00437
G1 X129.874 Y81.703 E.07059
G1 X129.835 Y82.208 E.01232
G1 X129.722 Y82.706 E.01242
G1 X129.533 Y83.187 E.01257
G1 X129.275 Y83.633 E.01253
G1 X128.959 Y84.029 E.01232
G1 X128.585 Y84.375 E.01239
G1 X128.173 Y84.659 E.01217
G1 X127.704 Y84.896 E.01278
G1 X127.209 Y85.048 E.0126
G1 X126.704 Y85.123 E.01242
G1 X121.085 Y85.134 E.13668
G1 X121.057 Y85.08 E.00148
G1 X121.057 Y85.08 F9000
G1 X121.268 Y84.768
G1 F6000
G1 X121.257 Y84.768 E.00027
G1 X121.181 Y84.624 E.00396
G1 X120.988 Y84.524 E.00529
G1 X120.667 Y84.466 E.00793
G1 X110.333 Y84.466 E.25136
G1 X110.175 Y84.479 E.00386
G1 X109.818 Y84.624 E.00937
G1 X109.742 Y84.769 E.00398
G1 X105.287 Y84.769 E.10836
G1 X104.316 Y84.749 E.02362
G1 X103.655 Y84.632 E.01633
G1 X103.014 Y84.344 E.01709
G1 X102.541 Y84.001 E.01421
G1 X102.168 Y83.629 E.01281
G1 X101.789 Y83.027 E.0173
G1 X101.575 Y82.428 E.01547
G1 X101.492 Y81.92 E.01252
G1 X101.481 Y78.8 E.07589
G1 X101.431 Y78.505 E.00728
G1 X101.23 Y78.173 E.00944
G1 X100.651 Y77.52 E.02123
G1 X100.922 Y77.172 E.01073
G1 X130.078 Y77.172 E.70919
G1 X130.355 Y77.508 E.01059
G1 X130.187 Y77.734 E.00685
G1 X129.77 Y78.173 E.01473
G1 X129.569 Y78.505 E.00944
G1 X129.519 Y78.8 E.00728
G1 X129.509 Y81.701 E.07056
G1 X129.439 Y82.38 E.0166
G1 X129.204 Y83.028 E.01677
G1 X128.845 Y83.614 E.01672
G1 X128.347 Y84.098 E.01689
G1 X127.797 Y84.455 E.01595
G1 X127.346 Y84.624 E.01172
G1 X126.677 Y84.758 E.0166
G1 X121.328 Y84.767 E.13011
G1 X121.328 Y84.767 F9000
G1 X121.544 Y84.401
G1 F6000
G1 X121.429 Y84.402 E.0028
G1 X121.386 Y84.321 E.00223
G1 X121.117 Y84.182 E.00737
G1 X120.667 Y84.1 E.01113
G1 X110.333 Y84.1 E.25136
G1 X109.881 Y84.182 E.01117
G1 X109.612 Y84.322 E.00738
G1 X109.569 Y84.403 E.00223
G1 X104.493 Y84.395 E.12347
G1 X103.962 Y84.327 E.01302
G1 X103.349 Y84.117 E.01576
G1 X102.862 Y83.792 E.01424
G1 X102.46 Y83.406 E.01356
G1 X102.12 Y82.866 E.01552
G1 X101.931 Y82.336 E.01369
G1 X101.858 Y81.89 E.01099
G1 X101.847 Y78.798 E.07521
G1 X101.777 Y78.386 E.01017
G1 X101.496 Y77.922 E.01319
G1 X101.131 Y77.538 E.01289
G1 X129.869 Y77.538 E.69902
G1 X129.504 Y77.922 E.01289
G1 X129.223 Y78.386 E.01319
G1 X129.153 Y78.798 E.01017
G1 X129.143 Y81.7 E.07059
G1 X129.082 Y82.299 E.01465
G1 X128.874 Y82.869 E.01476
G1 X128.558 Y83.385 E.01472
G1 X128.13 Y83.803 E.01455
G1 X127.712 Y84.081 E.01221
G1 X127.238 Y84.274 E.01245
G1 X126.649 Y84.392 E.01461
G1 X121.604 Y84.401 E.12271
G1 X121.604 Y84.401 F9000
G1 X121.822 Y84.035
G1 F6000
G1 X121.647 Y84.036 E.00426
G1 X121.245 Y83.839 E.01089
G1 X120.963 Y83.761 E.00712
G1 X120.667 Y83.734 E.00723
G1 X110.333 Y83.734 E.25136
G1 X110.049 Y83.759 E.00693
G1 X109.752 Y83.84 E.00749
G1 X109.397 Y84.037 E.00988
G1 X104.612 Y84.037 E.11639
G1 X104.042 Y83.97 E.01396
G1 X103.51 Y83.787 E.01368
G1 X103.125 Y83.535 E.01119
G1 X102.752 Y83.183 E.01247
G1 X102.451 Y82.705 E.01374
G1 X102.356 Y82.441 E.00682
G1 X102.223 Y81.859 E.01452
G1 X102.213 Y78.797 E.07448
G1 X102.123 Y78.267 E.01308
G1 X101.902 Y77.903 E.01036
G1 X129.098 Y77.903 E.66152
G1 X128.877 Y78.267 E.01036
G1 X128.787 Y78.797 E.01308
G1 X128.78 Y80.977 E.05303
G1 X128.75 Y82.045 E.02599
G1 X128.621 Y82.552 E.01273
G1 X128.369 Y83.014 E.0128
G1 X128.037 Y83.41 E.01257
G1 X127.528 Y83.765 E.01509
G1 X127.131 Y83.924 E.0104
G1 X126.622 Y84.027 E.01263
G1 X121.882 Y84.035 E.1153
G1 E-5 F3600
G1 X121.882 Y84.035 F9000
G1 X127.317 Y83.739
G1 E5 F2400
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X128.057 Y82.985 E.0257
G1 X128.365 Y82.451 E.01499
G1 X128.47 Y82.065 E.00973
G1 X126.814 Y83.72 E.05695
G1 X126.26 Y83.753 E.0135
G1 X128.504 Y81.51 E.07718
G1 X128.506 Y80.986 E.01275
G1 X125.738 Y83.754 E.09522
G1 X125.216 Y83.755 E.0127
G1 X128.507 Y80.463 E.11323
G1 X128.509 Y79.94 E.01272
G1 X124.693 Y83.756 E.13127
G1 X124.171 Y83.757 E.0127
G1 X128.511 Y79.417 E.14929
G1 X128.513 Y78.893 E.01275
G1 X123.649 Y83.758 E.16734
G1 X123.126 Y83.759 E.01272
G1 X128.355 Y78.53 E.17987
G1 X127.833 Y78.53 E.0127
G1 X122.604 Y83.76 E.17989
G1 X122.081 Y83.761 E.01272
G1 X127.312 Y78.53 E.17994
G1 X126.79 Y78.53 E.0127
G1 X121.603 Y83.717 E.17843
G1 X121.244 Y83.555 E.00958
G1 X126.269 Y78.53 E.17286
G1 X125.748 Y78.53 E.01267
G1 X120.805 Y83.472 E.17002
G1 X120.296 Y83.46 E.01238
G1 X125.226 Y78.53 E.16959
G1 X124.705 Y78.53 E.01267
G1 X119.775 Y83.46 E.16959
G1 X119.253 Y83.46 E.0127
G1 X124.183 Y78.53 E.16959
G1 X123.662 Y78.53 E.01267
G1 X118.732 Y83.46 E.16959
G1 X118.21 Y83.46 E.0127
G1 X123.14 Y78.53 E.16959
G1 X122.619 Y78.53 E.01267
G1 X117.689 Y83.46 E.16959
G1 X117.167 Y83.46 E.0127
G1 X122.098 Y78.53 E.16961
G1 X121.576 Y78.53 E.0127
G1 X116.646 Y83.46 E.16959
G1 X116.125 Y83.46 E.01267
G1 X121.055 Y78.53 E.16959
G1 X120.533 Y78.53 E.0127
G1 X115.603 Y83.46 E.16959
G1 X115.082 Y83.46 E.01267
G1 X120.012 Y78.53 E.16959
G1 X119.49 Y78.53 E.0127
G1 X114.56 Y83.46 E.16959
G1 X114.039 Y83.46 E.01267
G1 X118.969 Y78.53 E.16959
G1 X118.447 Y78.53 E.0127
G1 X113.517 Y83.46 E.16959
G1 X112.996 Y83.46 E.01267
G1 X117.926 Y78.53 E.16959
G1 X117.405 Y78.53 E.01267
G1 X112.474 Y83.46 E.16961
G1 X111.953 Y83.46 E.01267
G1 X116.883 Y78.53 E.16959
G1 X116.362 Y78.53 E.01267
G1 X111.432 Y83.46 E.16959
G1 X110.91 Y83.46 E.0127
G1 X115.84 Y78.53 E.16959
G1 X115.319 Y78.53 E.01267
G1 X110.389 Y83.46 E.16959
G1 X109.778 Y83.549 E.01502
G1 X114.797 Y78.53 E.17265
G1 X114.276 Y78.53 E.01267
G1 X109.043 Y83.763 E.18001
G1 X108.521 Y83.763 E.0127
G1 X113.755 Y78.53 E.18003
G1 X113.233 Y78.53 E.0127
G1 X108 Y83.763 E.18001
G1 X107.479 Y83.763 E.01267
G1 X112.712 Y78.53 E.18001
G1 X112.19 Y78.53 E.0127
G1 X106.957 Y83.763 E.18001
G1 X106.436 Y83.763 E.01267
G1 X111.669 Y78.53 E.18001
G1 X111.147 Y78.53 E.0127
G1 X105.914 Y83.763 E.18001
G1 X105.393 Y83.763 E.01267
G1 X110.626 Y78.53 E.18001
G1 X110.105 Y78.53 E.01267
G1 X104.871 Y83.763 E.18003
G1 X104.369 Y83.744 E.01222
G1 X109.583 Y78.53 E.17936
G1 X109.062 Y78.53 E.01267
G1 X103.932 Y83.66 E.17647
G1 X103.567 Y83.503 E.00966
G1 X108.54 Y78.53 E.17107
G1 X108.019 Y78.53 E.01267
G1 X103.259 Y83.29 E.16374
G1 X102.99 Y83.037 E.00898
G1 X107.497 Y78.53 E.15504
G1 X106.976 Y78.53 E.01267
G1 X102.785 Y82.721 E.14417
G1 X102.62 Y82.364 E.00957
G1 X106.454 Y78.53 E.13189
G1 X105.933 Y78.53 E.01267
G1 X102.516 Y81.947 E.11754
G1 X102.496 Y81.445 E.01222
G1 X105.412 Y78.53 E.10029
G1 X104.89 Y78.53 E.0127
G1 X102.494 Y80.926 E.08242
G1 X102.492 Y80.406 E.01265
G1 X104.369 Y78.53 E.06455
G1 X103.847 Y78.53 E.0127
G1 X102.491 Y79.887 E.04666
G1 X102.489 Y79.367 E.01265
G1 X103.326 Y78.53 E.02879
G1 X102.804 Y78.53 E.0127
G1 X102.323 Y79.011 E.01655
G1 X102.323 Y79.011 F9000
G1 X102.387 Y78.171
;TYPE:Solid infill
;WIDTH:0.386574
G1 F1200
G1 X128.613 Y78.171 E.6145
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X125.455 Y78.171 E-1.5
;WIPE_END
G1 X125.779 Y85.151 F9000
G1 X125.846 Y86.599
G1 X125.937 Y88.151
G1 X125.937 Y88.558
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X125.961 Y88.57 E.00065
G1 X126 Y88.683 E.00291
G1 X126 Y89.233 E.01338
G1 X126.522 Y89.846 E.01958
G1 X126.69 Y90.169 E.00886
G1 X126.753 Y90.525 E.00879
G1 X126.711 Y90.77 E.00605
G1 X126.522 Y91.155 E.01043
G1 X126 Y91.767 E.01957
G1 X126 Y92.723 E.02325
G1 X139.202 Y92.722 E.32113
G1 X139.514 Y92.81 E.00789
G1 X139.789 Y93.089 E.00953
G1 X139.9 Y93.531 E.01109
G1 X139.9 Y95.298 E.04298
G1 X139.852 Y95.601 E.00746
G1 X139.713 Y95.851 E.00696
G1 X139.415 Y96.066 E.00894
G1 X138.997 Y96.106 E.01021
G1 X136.7 Y96.105 E.05587
G1 X136.698 Y132.81 E.89281
G1 X136.64 Y133.7 E.02169
G1 X136.557 Y134.298 E.01469
G1 X136.449 Y134.844 E.01354
G1 X136.102 Y136.041 E.03031
G1 X135.88 Y136.605 E.01474
G1 X135.553 Y137.298 E.01864
G1 X135.298 Y137.76 E.01284
G1 X135.01 Y138.223 E.01326
G1 X134.688 Y138.682 E.01364
G1 X134.222 Y139.261 E.01808
G1 X133.843 Y139.679 E.01372
G1 X133.407 Y140.105 E.01483
G1 X132.68 Y140.714 E.02307
G1 X132.046 Y141.16 E.01885
G1 X131.069 Y141.719 E.02738
G1 X130.449 Y141.994 E.0165
G1 X129.688 Y142.289 E.01985
G1 X129.113 Y142.459 E.01458
G1 X128.511 Y142.601 E.01504
G1 X127.84 Y142.722 E.01658
G1 X127.307 Y142.785 E.01305
G1 X126.773 Y142.817 E.01301
G1 X120.483 Y142.8 E.153
G1 X120.387 Y142.773 E.00243
G1 X120.3 Y142.617 E.00434
G1 X120.3 Y142.412 E.00499
G1 X110.7 Y142.412 E.23351
G1 X110.7 Y142.617 E.00499
G1 X110.576 Y142.791 E.0052
G1 X110.517 Y142.8 E.00145
G1 X105.923 Y142.8 E.11174
G1 X105.741 Y142.821 E.00446
G1 X104.5 Y142.822 E.03019
G1 X103.309 Y142.742 E.02904
G1 X102.126 Y142.52 E.02928
G1 X101.449 Y142.332 E.01709
G1 X100.832 Y142.118 E.01588
G1 X100.231 Y141.863 E.01588
G1 X99.119 Y141.264 E.03072
G1 X98.572 Y140.899 E.016
G1 X97.96 Y140.427 E.0188
G1 X97.473 Y139.992 E.01588
G1 X96.96 Y139.468 E.01784
G1 X96.587 Y139.036 E.01388
G1 X96.245 Y138.591 E.01365
G1 X95.937 Y138.14 E.01328
G1 X95.319 Y137.043 E.03063
G1 X95.09 Y136.536 E.01353
G1 X94.903 Y136.056 E.01253
G1 X94.605 Y135.071 E.02503
G1 X94.377 Y133.842 E.0304
G1 X94.302 Y132.81 E.02517
G1 X94.3 Y96.105 E.89281
G1 X91.798 Y96.106 E.06086
G1 X91.508 Y96.03 E.00729
G1 X91.232 Y95.774 E.00916
G1 X91.108 Y95.413 E.00928
G1 X91.108 Y93.415 E.0486
G1 X91.201 Y93.103 E.00792
G1 X91.367 Y92.89 E.00657
G1 X91.586 Y92.762 E.00617
G1 X91.798 Y92.722 E.00525
G1 X104.301 Y92.723 E.30412
G1 X105 Y92.723 E.017
G1 X105 Y91.767 E.02325
G1 X104.478 Y91.155 E.01957
G1 X104.31 Y90.831 E.00888
G1 X104.247 Y90.475 E.00879
G1 X104.289 Y90.23 E.00605
G1 X104.478 Y89.845 E.01043
G1 X105 Y89.233 E.01957
G1 X105 Y88.683 E.01338
G1 X105.062 Y88.545 E.00368
G1 X105.183 Y88.5 E.00314
G1 X125.817 Y88.5 E.5019
G1 X125.883 Y88.532 E.00178
G1 X126.189 Y88.311 F9000
;TYPE:Perimeter
G1 F6000
G1 X126.293 Y88.409 E.00348
G1 X126.366 Y88.683 E.0069
G1 X126.366 Y89.099 E.01012
G1 X126.801 Y89.609 E.0163
G1 X127.036 Y90.048 E.01211
G1 X127.115 Y90.574 E.01294
G1 X127.041 Y90.926 E.00875
G1 X126.8 Y91.392 E.01276
G1 X126.366 Y91.901 E.01627
G1 X126.366 Y92.357 E.01109
G1 X139.202 Y92.357 E.31222
G1 X139.622 Y92.46 E.01052
G1 X139.879 Y92.63 E.0075
G1 X140.068 Y92.853 E.00711
;WIDTH:0.439128
G1 X140.133 Y92.99 E.00408
;WIDTH:0.478257
G1 X140.199 Y93.127 E.00449
;WIDTH:0.517386
G1 X140.265 Y93.264 E.00489
;WIDTH:0.556515
G1 X140.331 Y93.401 E.00528
G1 X140.34 Y93.531 E.00453
;WIDTH:0.547008
G1 X140.34 Y95.298 E.06026
;WIDTH:0.569133
G1 X140.311 Y95.632 E.01193
G1 X140.278 Y95.664 E.00164
;WIDTH:0.526853
G1 X140.246 Y95.695 E.00146
;WIDTH:0.484572
G1 X140.214 Y95.727 E.00136
;WIDTH:0.442291
G1 X140.182 Y95.759 E.00123
;WIDTH:0.40001
G1 X139.944 Y96.135 E.01082
G1 X139.724 Y96.313 E.00688
G1 X139.489 Y96.425 E.00633
G1 X138.996 Y96.472 E.01205
G1 X137.066 Y96.471 E.04695
G1 X137.063 Y132.81 E.88394
G1 X137.005 Y133.724 E.02228
G1 X136.919 Y134.349 E.01535
G1 X136.8 Y134.946 E.01481
G1 X136.453 Y136.143 E.03032
G1 X136.221 Y136.739 E.01556
G1 X135.883 Y137.455 E.01926
G1 X135.618 Y137.937 E.01338
G1 X135.32 Y138.417 E.01374
G1 X134.987 Y138.892 E.01411
G1 X134.507 Y139.491 E.01867
G1 X134.114 Y139.925 E.01424
G1 X133.662 Y140.367 E.01538
G1 X132.915 Y140.994 E.02372
G1 X132.213 Y141.486 E.02085
G1 X131.25 Y142.037 E.02699
G1 X130.597 Y142.329 E.0174
G1 X129.811 Y142.633 E.0205
G1 X129.217 Y142.81 E.01508
G1 X128.595 Y142.957 E.01555
G1 X127.904 Y143.082 E.01708
G1 X127.35 Y143.148 E.01357
G1 X126.763 Y143.183 E.0143
G1 X120.483 Y143.166 E.15276
G1 X120.307 Y143.137 E.00434
G1 X120.196 Y143.085 E.00298
G1 X120.024 Y142.777 E.00858
G1 X110.976 Y142.777 E.22009
G1 X110.804 Y143.085 E.00858
G1 X110.577 Y143.163 E.00584
G1 X105.945 Y143.166 E.11267
G1 X105.742 Y143.187 E.00496
G1 X104.5 Y143.188 E.03021
G1 X103.307 Y143.11 E.02908
G1 X102.058 Y142.879 E.0309
G1 X101.351 Y142.684 E.01784
G1 X100.712 Y142.463 E.01645
G1 X100.058 Y142.185 E.01729
G1 X98.945 Y141.586 E.03075
G1 X98.368 Y141.203 E.01685
G1 X97.736 Y140.716 E.01941
G1 X97.229 Y140.265 E.01651
G1 X96.699 Y139.723 E.01844
G1 X96.31 Y139.275 E.01443
G1 X95.955 Y138.814 E.01415
G1 X95.635 Y138.346 E.01379
G1 X95 Y137.222 E.0314
G1 X94.757 Y136.686 E.01432
G1 X94.562 Y136.188 E.01301
G1 X94.26 Y135.197 E.0252
G1 X94.016 Y133.905 E.03198
G1 X93.937 Y132.81 E.0267
G1 X93.934 Y96.471 E.88394
G1 X91.798 Y96.472 E.05196
G1 X91.513 Y96.425 E.00703
G1 X91.279 Y96.314 E.0063
G1 X91.058 Y96.137 E.00689
G1 X90.89 Y95.904 E.00699
G1 X90.777 Y95.607 E.00773
;WIDTH:0.44021
G1 X90.751 Y95.586 E.0009
;WIDTH:0.480421
G1 X90.724 Y95.564 E.00103
;WIDTH:0.520632
G1 X90.698 Y95.543 E.00108
;WIDTH:0.560843
G1 X90.671 Y95.522 E.0012
G1 X90.665 Y95.413 E.00382
;WIDTH:0.554286
G1 X90.665 Y93.415 E.06911
;WIDTH:0.572659
G1 X90.681 Y93.236 E.00644
G1 X90.765 Y93.109 E.00545
;WIDTH:0.529494
G1 X90.849 Y92.982 E.00502
;WIDTH:0.486329
G1 X90.933 Y92.856 E.00455
;WIDTH:0.443164
G1 X91.017 Y92.729 E.00414
;WIDTH:0.399999
G1 X91.323 Y92.482 E.00957
G1 X91.688 Y92.368 E.0093
G1 X91.798 Y92.357 E.00269
G1 X104.301 Y92.357 E.30412
G1 X104.634 Y92.357 E.0081
G1 X104.634 Y91.901 E.01109
G1 X104.2 Y91.392 E.01627
G1 X104.004 Y91.051 E.00957
G1 X103.891 Y90.61 E.01107
G1 X103.911 Y90.234 E.00916
G1 X104.121 Y89.73 E.01328
G1 X104.634 Y89.099 E.01978
G1 X104.656 Y88.531 E.01383
G1 X104.821 Y88.27 E.00751
G1 X105.088 Y88.143 E.00719
G1 X125.817 Y88.134 E.50421
G1 X126.069 Y88.196 E.00631
G1 X126.146 Y88.269 E.00258
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X126.189 Y88.311 E-.02855
G1 X126.293 Y88.409 E-.06788
G1 X126.366 Y88.683 E-.13469
G1 X126.366 Y89.099 E-.1976
G1 X126.801 Y89.609 E-.3184
G1 X127.036 Y90.048 E-.23652
G1 X127.115 Y90.574 E-.25265
G1 X127.041 Y90.926 E-.17085
G1 X126.951 Y91.1 E-.09286
;WIPE_END
G1 X126.955 Y91.102 F9000
G1 X127.006 Y90.989
G1 X127.059 Y90.83
G1 X127.093 Y90.667
G1 X127.104 Y90.5
G1 X127.093 Y90.333
G1 X127.059 Y90.17
G1 X127.006 Y90.011
G1 X126.349 Y88.151
G1 X122.988 Y88.151
G1 X119.951 Y86.191
G1 X120.352 Y86.191
G1 E5 F2400
G1 F6000
G1 X120.3 Y86.067 E.00327
G1 X120.3 Y85.811 E.00623
G1 X110.7 Y85.811 E.23351
G1 X110.7 Y86.067 E.00623
G1 X110.645 Y86.197 E.00343
G1 X110.517 Y86.25 E.00337
G1 X105.183 Y86.25 E.12974
G1 X104.199 Y86.25 E.02393
G1 X103.606 Y86.207 E.01446
G1 X102.94 Y86.055 E.01662
G1 X102.077 Y85.673 E.02296
G1 X101.652 Y85.386 E.01247
G1 X101.092 Y84.872 E.01849
G1 X100.553 Y84.129 E.02233
G1 X100.312 Y83.637 E.01333
G1 X100.105 Y82.978 E.0168
G1 X100.013 Y82.369 E.01498
G1 X100 Y78.767 E.08762
G1 X99.478 Y78.155 E.01957
G1 X99.31 Y77.831 E.00888
G1 X99.247 Y77.475 E.00879
G1 X99.289 Y77.23 E.00605
G1 X99.478 Y76.845 E.01043
G1 X100 Y76.233 E.01957
G1 X100.002 Y75.905 E.00798
G1 X100.051 Y75.807 E.00267
G1 X100.183 Y75.751 E.00349
G1 X130.817 Y75.751 E.74514
G1 X130.949 Y75.807 E.00349
G1 X131 Y75.934 E.00333
G1 X131 Y76.233 E.00727
G1 X131.522 Y76.845 E.01957
G1 X131.69 Y77.169 E.00888
G1 X131.753 Y77.525 E.00879
G1 X131.711 Y77.77 E.00605
G1 X131.522 Y78.155 E.01043
G1 X131 Y78.767 E.01957
G1 X130.989 Y82.343 E.08698
G1 X130.824 Y83.25 E.02242
G1 X130.572 Y83.894 E.01682
G1 X130.26 Y84.429 E.01506
G1 X129.666 Y85.118 E.02213
G1 X129.183 Y85.507 E.01508
G1 X128.652 Y85.819 E.01498
G1 X128.159 Y86.016 E.01291
G1 X127.694 Y86.153 E.01179
G1 X127.118 Y86.238 E.01416
G1 X120.483 Y86.25 E.16139
G1 X120.403 Y86.217 E.0021
G1 X120.403 Y86.217 F9000
G1 X120.09 Y86.439
;TYPE:Perimeter
G1 F6000
G1 X119.98 Y86.177 E.00691
G1 X111.02 Y86.177 E.21794
G1 X110.902 Y86.458 E.00741
G1 X110.612 Y86.607 E.00793
G1 X110.517 Y86.616 E.00232
G1 X105.183 Y86.616 E.12974
G1 X104.199 Y86.616 E.02393
G1 X103.58 Y86.572 E.01509
G1 X102.858 Y86.412 E.01799
G1 X101.873 Y85.976 E.0262
G1 X101.447 Y85.689 E.01249
G1 X100.844 Y85.141 E.01982
G1 X100.256 Y84.343 E.02411
G1 X99.983 Y83.795 E.01489
G1 X99.756 Y83.086 E.01811
G1 X99.645 Y82.344 E.01825
G1 X99.635 Y78.902 E.08372
G1 X99.2 Y78.392 E.0163
G1 X98.963 Y77.951 E.01218
G1 X98.885 Y77.426 E.01291
G1 X98.959 Y77.074 E.00875
G1 X99.2 Y76.608 E.01276
G1 X99.634 Y76.099 E.01627
G1 X99.641 Y75.846 E.00616
G1 X99.788 Y75.553 E.00797
G1 X100.088 Y75.394 E.00826
G1 X130.817 Y75.385 E.74745
G1 X131.212 Y75.553 E.01044
G1 X131.359 Y75.846 E.00797
G1 X131.366 Y76.099 E.00616
G1 X131.8 Y76.608 E.01627
G1 X131.996 Y76.949 E.00957
G1 X132.109 Y77.39 E.01107
G1 X132.074 Y77.838 E.01093
G1 X131.8 Y78.392 E.01503
G1 X131.365 Y78.902 E.0163
G1 X131.355 Y82.344 E.08372
G1 X131.297 Y82.827 E.01183
G1 X131.181 Y83.332 E.0126
G1 X130.912 Y84.029 E.01817
G1 X130.576 Y84.614 E.01641
G1 X129.943 Y85.358 E.02376
G1 X129.411 Y85.793 E.01672
G1 X128.836 Y86.135 E.01627
G1 X128.264 Y86.366 E.01501
G1 X127.747 Y86.515 E.01309
G1 X127.171 Y86.599 E.01416
G1 X120.483 Y86.616 E.16268
G1 X120.134 Y86.473 E.00917
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X120.09 Y86.439 E-.02641
G1 X119.98 Y86.177 E-.13497
G1 X117.162 Y86.177 E-1.33862
;WIPE_END
G1 X120.134 Y74.207 F9000
G1 E5 F2400
G1 F6000
G1 X135.629 Y74.204 E.3769
G1 X136.198 Y74.243 E.01387
G1 X136.889 Y74.369 E.01709
G1 X137.43 Y74.534 E.01376
G1 X138.196 Y74.865 E.0203
G1 X138.792 Y75.226 E.01695
G1 X139.601 Y75.9 E.02561
G1 X140.273 Y76.706 E.02553
G1 X140.788 Y77.62 E.02552
G1 X141.131 Y78.612 E.02553
G1 X141.289 Y79.653 E.02561
G1 X141.289 Y80.035 E.00929
G1 X141.3 Y150.994 E1.72601
G1 X141.258 Y151.695 E.01708
G1 X141.133 Y152.38 E.01694
G1 X140.927 Y153.045 E.01693
G1 X140.643 Y153.681 E.01694
G1 X140.284 Y154.278 E.01694
G1 X139.857 Y154.828 E.01694
G1 X139.367 Y155.322 E.01692
G1 X138.76 Y155.796 E.01873
G1 X138.23 Y156.116 E.01506
G1 X137.229 Y156.536 E.0264
G1 X136.503 Y156.712 E.01817
G1 X135.836 Y156.79 E.01633
G1 X95.435 Y156.799 E.98271
G1 X94.774 Y156.754 E.01612
G1 X94.084 Y156.624 E.01708
G1 X93.457 Y156.428 E.01598
G1 X92.838 Y156.152 E.01649
G1 X92.179 Y155.754 E.01873
G1 X91.633 Y155.322 E.01694
G1 X91.143 Y154.828 E.01692
G1 X90.716 Y154.278 E.01694
G1 X90.358 Y153.683 E.01689
G1 X89.983 Y152.783 E.02372
G1 X89.794 Y152.039 E.01867
G1 X89.711 Y151.348 E.01693
G1 X89.7 Y80.006 E1.73532
G1 X89.743 Y79.301 E.01718
G1 X89.869 Y78.612 E.01704
G1 X90.077 Y77.943 E.01704
G1 X90.365 Y77.305 E.01703
G1 X90.727 Y76.705 E.01704
G1 X91.159 Y76.154 E.01703
G1 X91.654 Y75.659 E.01703
G1 X92.205 Y75.227 E.01703
G1 X92.803 Y74.866 E.01699
G1 X93.651 Y74.506 E.02241
G1 X94.456 Y74.295 E.02024
G1 X95.15 Y74.211 E.017
G1 X120.074 Y74.207 E.60625
G1 X120.074 Y74.207 F9000
G1 X120.074 Y74.572
;TYPE:Perimeter
G1 F6000
G1 X135.617 Y74.57 E.37807
G1 X136.153 Y74.606 E.01307
G1 X136.802 Y74.725 E.01605
G1 X137.304 Y74.877 E.01276
G1 X138.028 Y75.191 E.0192
G1 X138.58 Y75.524 E.01568
G1 X139.341 Y76.159 E.02411
G1 X139.971 Y76.914 E.02392
G1 X140.454 Y77.771 E.02393
G1 X140.774 Y78.7 E.0239
G1 X140.923 Y79.68 E.02411
G1 X140.923 Y80.035 E.00864
G1 X140.925 Y93.016 E.31575
;WIDTH:0.439128
G1 X140.906 Y93.099 E.00229
;WIDTH:0.478257
G1 X140.886 Y93.182 E.00252
;WIDTH:0.517386
G1 X140.867 Y93.264 E.0027
;WIDTH:0.556515
G1 X140.847 Y93.347 E.00297
G1 X140.852 Y93.531 E.00639
;WIDTH:0.547008
G1 X140.852 Y95.297 E.06023
;WIDTH:0.566483
G1 X140.843 Y95.644 E.01229
G1 X140.863 Y95.715 E.00261
;WIDTH:0.524865
G1 X140.884 Y95.786 E.00242
;WIDTH:0.483247
G1 X140.905 Y95.856 E.00218
;WIDTH:0.441629
G1 X140.926 Y95.927 E.00201
;WIDTH:0.40001
G1 X140.934 Y150.983 E1.33922
G1 X140.894 Y151.651 E.01628
G1 X140.777 Y152.293 E.01587
G1 X140.584 Y152.916 E.01586
G1 X140.318 Y153.512 E.01588
G1 X139.982 Y154.071 E.01586
G1 X139.582 Y154.586 E.01586
G1 X139.124 Y155.048 E.01582
G1 X138.552 Y155.494 E.01764
G1 X138.064 Y155.789 E.01387
G1 X137.114 Y156.187 E.02505
G1 X136.439 Y156.351 E.0169
G1 X135.815 Y156.424 E.01528
G1 X95.448 Y156.433 E.98192
G1 X94.82 Y156.391 E.01531
G1 X94.173 Y156.269 E.01602
G1 X93.587 Y156.085 E.01494
G1 X93.007 Y155.827 E.01544
G1 X92.388 Y155.453 E.01759
G1 X91.877 Y155.049 E.01585
G1 X91.418 Y154.586 E.01586
G1 X91.018 Y154.071 E.01586
G1 X90.686 Y153.517 E.01571
G1 X90.33 Y152.667 E.02242
G1 X90.154 Y151.972 E.01744
G1 X90.076 Y151.326 E.01583
G1 X90.068 Y95.737 E1.35219
;WIDTH:0.44021
G1 X90.088 Y95.695 E.00126
;WIDTH:0.480421
G1 X90.108 Y95.652 E.00141
;WIDTH:0.520632
G1 X90.128 Y95.61 E.0015
;WIDTH:0.560843
G1 X90.148 Y95.567 E.00166
G1 X90.145 Y95.413 E.00539
;WIDTH:0.554286
G1 X90.145 Y93.415 E.06911
;WIDTH:0.572659
G1 X90.154 Y93.16 E.00914
G1 X90.132 Y93.106 E.00209
;WIDTH:0.529494
G1 X90.111 Y93.052 E.00191
;WIDTH:0.486329
G1 X90.089 Y92.998 E.00175
;WIDTH:0.443164
G1 X90.068 Y92.944 E.00158
;WIDTH:0.399999
G1 X90.066 Y80.017 E.31444
G1 X90.106 Y79.345 E.01637
G1 X90.225 Y78.7 E.01595
G1 X90.42 Y78.073 E.01597
G1 X90.689 Y77.475 E.01595
G1 X91.028 Y76.914 E.01594
G1 X91.433 Y76.397 E.01597
G1 X91.897 Y75.933 E.01596
G1 X92.414 Y75.528 E.01597
G1 X92.97 Y75.192 E.0158
G1 X93.769 Y74.853 E.02111
G1 X94.524 Y74.655 E.01899
G1 X95.172 Y74.577 E.01588
G1 X120.014 Y74.572 E.60426
G1 E-5 F3600
G1 X120.014 Y74.572 F9000
G1 X120.014 Y74.549
G1 X139.115 Y75.92
G1 X140.951 Y80.008
G1 X140.951 Y95.766
G1 X140.56 Y95.766
G1 E5 F2400
G1 F6000
G1 X140.569 Y150.972 E1.34283
G1 X140.53 Y151.607 E.01547
G1 X140.421 Y152.206 E.01481
G1 X140.241 Y152.787 E.01479
G1 X139.993 Y153.342 E.01479
G1 X139.68 Y153.864 E.0148
G1 X139.307 Y154.344 E.01479
G1 X138.88 Y154.774 E.01474
G1 X138.345 Y155.193 E.01653
G1 X137.898 Y155.463 E.0127
G1 X137 Y155.839 E.02368
G1 X136.374 Y155.991 E.01567
G1 X135.794 Y156.059 E.0142
G1 X95.46 Y156.068 E.98108
G1 X94.867 Y156.027 E.01446
G1 X94.262 Y155.913 E.01497
G1 X93.716 Y155.743 E.01391
G1 X93.177 Y155.502 E.01436
G1 X92.597 Y155.152 E.01648
G1 X92.122 Y154.776 E.01474
G1 X91.693 Y154.344 E.01481
G1 X91.32 Y153.864 E.01479
G1 X91.013 Y153.352 E.01452
G1 X90.678 Y152.551 E.02112
G1 X90.515 Y151.905 E.01621
G1 X90.442 Y151.304 E.01473
G1 X90.435 Y95.737 E1.35161
G1 X90.548 Y96.033 E.00771
G1 X90.829 Y96.421 E.01165
G1 X91.049 Y96.599 E.00688
G1 X91.439 Y96.783 E.01049
G1 X91.799 Y96.838 E.00886
G1 X93.569 Y96.837 E.04305
G1 X93.571 Y132.81 E.87501
G1 X93.658 Y133.977 E.02846
G1 X93.91 Y135.304 E.03285
G1 X94.222 Y136.321 E.02588
G1 X94.423 Y136.836 E.01345
G1 X94.682 Y137.401 E.01512
G1 X95.333 Y138.552 E.03216
G1 X95.665 Y139.037 E.0143
G1 X96.033 Y139.514 E.01465
G1 X96.437 Y139.979 E.01498
G1 X96.986 Y140.538 E.01906
G1 X97.513 Y141.005 E.01713
G1 X98.165 Y141.507 E.02002
G1 X98.772 Y141.908 E.0177
G1 X99.885 Y142.507 E.03074
G1 X100.592 Y142.808 E.01869
G1 X101.253 Y143.037 E.01702
G1 X101.991 Y143.239 E.01861
G1 X103.282 Y143.475 E.03192
G1 X104.5 Y143.553 E.02969
G1 X105.742 Y143.552 E.03021
G1 X105.967 Y143.532 E.00549
G1 X110.517 Y143.532 E.11067
G1 X110.675 Y143.518 E.00386
G1 X110.996 Y143.396 E.00835
G1 X111.137 Y143.143 E.00705
G1 X119.863 Y143.143 E.21225
G1 X120.004 Y143.396 E.00705
G1 X120.19 Y143.483 E.00499
G1 X120.483 Y143.532 E.00723
G1 X126.764 Y143.549 E.15278
G1 X127.393 Y143.512 E.01533
G1 X127.969 Y143.442 E.01411
G1 X128.678 Y143.313 E.01753
G1 X129.32 Y143.161 E.01605
G1 X129.934 Y142.978 E.01558
G1 X130.744 Y142.663 E.02114
G1 X131.432 Y142.354 E.01835
G1 X132.395 Y141.803 E.02699
G1 X133.15 Y141.275 E.02241
G1 X133.917 Y140.629 E.02439
G1 X134.385 Y140.171 E.01593
G1 X134.792 Y139.72 E.01478
G1 X135.286 Y139.103 E.01923
G1 X135.631 Y138.61 E.01464
G1 X135.938 Y138.114 E.01419
G1 X136.214 Y137.611 E.01396
G1 X136.561 Y136.873 E.01984
G1 X136.804 Y136.245 E.01638
G1 X137.151 Y135.048 E.03031
G1 X137.281 Y134.399 E.0161
G1 X137.37 Y133.748 E.01598
G1 X137.429 Y132.81 E.02286
G1 X137.431 Y96.837 E.87501
G1 X139.202 Y96.838 E.04308
G1 X139.562 Y96.783 E.00886
G1 X139.954 Y96.597 E.01055
G1 X140.174 Y96.419 E.00688
G1 X140.423 Y96.103 E.00979
G1 X140.538 Y95.821 E.00741
G1 X140.538 Y95.821 F9000
G1 X140.195 Y96.873
G1 F6000
G1 X140.203 Y150.814 E1.31206
G1 X140.184 Y151.283 E.01142
G1 X140.116 Y151.843 E.01372
G1 X139.981 Y152.391 E.01373
G1 X139.782 Y152.919 E.01372
G1 X139.52 Y153.42 E.01375
G1 X139.199 Y153.887 E.01378
G1 X138.839 Y154.296 E.01325
G1 X138.304 Y154.76 E.01723
G1 X137.732 Y155.136 E.01665
G1 X136.885 Y155.49 E.02233
G1 X136.31 Y155.63 E.01439
G1 X135.772 Y155.693 E.01318
G1 X95.473 Y155.702 E.98023
G1 X94.913 Y155.664 E.01365
G1 X94.35 Y155.558 E.01394
G1 X93.845 Y155.4 E.01287
G1 X93.346 Y155.178 E.01328
G1 X92.805 Y154.851 E.01538
G1 X92.366 Y154.503 E.01363
G1 X91.969 Y154.102 E.01373
G1 X91.622 Y153.657 E.01373
G1 X91.34 Y153.186 E.01335
G1 X91.026 Y152.435 E.0198
G1 X90.875 Y151.838 E.01498
G1 X90.808 Y151.282 E.01362
G1 X90.8 Y96.867 E1.32359
G1 X91.366 Y97.141 E.0153
G1 X91.799 Y97.203 E.01064
G1 X93.203 Y97.203 E.03415
G1 X93.205 Y132.81 E.8661
G1 X93.298 Y134.044 E.0301
G1 X93.56 Y135.41 E.03383
G1 X93.881 Y136.453 E.02654
G1 X94.09 Y136.986 E.01393
G1 X94.363 Y137.581 E.01592
G1 X95.031 Y138.758 E.03292
G1 X95.375 Y139.259 E.01478
G1 X95.757 Y139.753 E.01519
G1 X96.175 Y140.234 E.0155
G1 X96.742 Y140.81 E.01966
G1 X97.289 Y141.295 E.01778
G1 X97.962 Y141.811 E.02063
G1 X98.599 Y142.23 E.01855
G1 X99.711 Y142.829 E.03072
G1 X100.471 Y143.154 E.02011
G1 X101.155 Y143.389 E.01759
G1 X101.923 Y143.598 E.01936
G1 X103.258 Y143.839 E.033
G1 X104.5 Y143.919 E.03027
G1 X105.742 Y143.918 E.03021
G1 X105.989 Y143.897 E.00603
G1 X110.517 Y143.897 E.11014
G1 X110.739 Y143.878 E.00542
G1 X111.187 Y143.708 E.01166
G1 X111.298 Y143.509 E.00554
G1 X119.702 Y143.509 E.20442
G1 X119.813 Y143.708 E.00554
G1 X120.073 Y143.83 E.00699
G1 X120.483 Y143.897 E.01011
G1 X126.765 Y143.915 E.1528
G1 X127.436 Y143.875 E.01635
G1 X128.034 Y143.802 E.01465
G1 X128.762 Y143.669 E.018
G1 X129.424 Y143.511 E.01655
G1 X130.057 Y143.322 E.01607
G1 X130.892 Y142.998 E.02179
G1 X131.613 Y142.671 E.01926
G1 X132.576 Y142.121 E.02698
G1 X133.384 Y141.555 E.024
G1 X134.172 Y140.891 E.02506
G1 X134.655 Y140.417 E.01646
G1 X135.077 Y139.949 E.01533
G1 X135.585 Y139.313 E.0198
G1 X135.941 Y138.803 E.01513
G1 X136.258 Y138.291 E.01465
G1 X136.544 Y137.768 E.0145
G1 X136.901 Y137.007 E.02045
G1 X137.155 Y136.346 E.01722
G1 X137.503 Y135.15 E.0303
G1 X137.644 Y134.449 E.01739
G1 X137.735 Y133.772 E.01662
G1 X137.795 Y132.81 E.02345
G1 X137.797 Y97.203 E.8661
G1 X139.202 Y97.203 E.03418
G1 X139.636 Y97.141 E.01066
G1 X140.141 Y96.899 E.01362
G1 X140.141 Y96.899 F9000
G1 X139.829 Y97.442
G1 F6000
G1 X139.837 Y150.814 E1.29822
G1 X139.819 Y151.261 E.01088
G1 X139.756 Y151.778 E.01267
G1 X139.632 Y152.283 E.01265
G1 X139.448 Y152.77 E.01266
G1 X139.207 Y153.231 E.01265
G1 X138.91 Y153.662 E.01273
G1 X138.58 Y154.039 E.01219
G1 X138.079 Y154.472 E.01611
G1 X137.566 Y154.809 E.01493
G1 X137.053 Y155.023 E.01352
G1 X136.473 Y155.214 E.01485
G1 X135.751 Y155.327 E.01778
G1 X95.485 Y155.336 E.97943
G1 X94.96 Y155.301 E.0128
G1 X94.439 Y155.202 E.0129
G1 X93.753 Y154.958 E.01771
G1 X93.24 Y154.687 E.01411
G1 X92.807 Y154.386 E.01283
G1 X92.418 Y154.036 E.01273
G1 X92.063 Y153.628 E.01315
G1 X91.667 Y153.021 E.01763
G1 X91.374 Y152.319 E.0185
G1 X91.235 Y151.771 E.01375
G1 X91.173 Y151.26 E.01252
G1 X91.165 Y97.439 E1.30914
G1 X91.292 Y97.499 E.00342
G1 X91.799 Y97.569 E.01245
G1 X92.837 Y97.569 E.02525
G1 X92.84 Y132.81 E.8572
G1 X92.939 Y134.11 E.03171
G1 X93.21 Y135.516 E.03483
G1 X93.54 Y136.585 E.02721
G1 X93.756 Y137.136 E.0144
G1 X94.044 Y137.76 E.01672
G1 X94.728 Y138.964 E.03368
G1 X95.085 Y139.482 E.0153
G1 X95.48 Y139.992 E.01569
G1 X95.914 Y140.489 E.01605
G1 X96.498 Y141.083 E.02026
G1 X97.065 Y141.584 E.0184
G1 X97.758 Y142.115 E.02124
G1 X98.425 Y142.552 E.0194
G1 X99.538 Y143.151 E.03074
G1 X100.351 Y143.499 E.02151
G1 X101.057 Y143.741 E.01815
G1 X101.856 Y143.957 E.02013
G1 X103.234 Y144.204 E.03405
G1 X104.5 Y144.285 E.03086
G1 X105.743 Y144.284 E.03023
G1 X106.011 Y144.263 E.00654
G1 X110.517 Y144.263 E.1096
G1 X110.874 Y144.224 E.00874
G1 X111.378 Y144.02 E.01323
G1 X111.46 Y143.874 E.00407
G1 X119.54 Y143.874 E.19654
G1 X119.622 Y144.02 E.00407
G1 X120.126 Y144.224 E.01323
G1 X120.483 Y144.263 E.00874
G1 X126.766 Y144.28 E.15283
G1 X127.478 Y144.238 E.01735
G1 X128.099 Y144.162 E.01522
G1 X128.846 Y144.025 E.01847
G1 X129.528 Y143.862 E.01706
G1 X130.18 Y143.666 E.01656
G1 X131.04 Y143.332 E.02244
G1 X131.795 Y142.989 E.02017
G1 X132.758 Y142.438 E.02699
G1 X133.619 Y141.835 E.02557
G1 X134.428 Y141.153 E.02574
G1 X134.926 Y140.662 E.01701
G1 X135.362 Y140.178 E.01585
G1 X135.884 Y139.523 E.02037
G1 X136.252 Y138.996 E.01563
G1 X136.578 Y138.468 E.01509
G1 X136.875 Y137.924 E.01508
G1 X137.242 Y137.141 E.02103
G1 X137.507 Y136.448 E.01805
G1 X137.854 Y135.252 E.03029
G1 X138.006 Y134.5 E.01866
G1 X138.099 Y133.796 E.01727
G1 X138.16 Y132.81 E.02403
G1 X138.163 Y97.569 E.8572
G1 X138.996 Y97.569 E.02026
G1 X139.533 Y97.535 E.01309
G1 X139.772 Y97.46 E.00609
G1 E-5 F3600
G1 X139.772 Y97.46 F9000
G1 X140.197 Y95.677
G1 X140.218 Y95.58
G1 X140.238 Y95.484
G1 X140.249 Y95.314
G1 X140.249 Y93.514
G1 X140.238 Y93.344
G1 X140.218 Y93.248
G1 X140.197 Y93.152
G1 X140.13 Y92.978
G1 X140.035 Y92.815
G1 X139.951 Y92.712
G1 X139.9 Y92.655
G1 X139.751 Y92.537
G1 X139.581 Y92.447
G1 X139.404 Y92.394
G1 X139.285 Y92.378
G1 X139.219 Y92.374
G1 X137.549 Y92.373
G1 X131.452 Y78.801
G1 X131.73 Y79.059
G1 E5 F2400
G1 F6000
G1 X131.73 Y79.037 E.00054
G1 X132.209 Y78.426 E.01888
G1 X132.444 Y77.857 E.01497
G1 X132.467 Y77.316 E.01317
G1 X132.319 Y76.778 E.01357
G1 X132.078 Y76.371 E.01151
G1 X131.751 Y75.987 E.01227
G1 X131.719 Y75.787 E.00493
G1 X131.475 Y75.299 E.01327
;WIDTH:0.441718
G1 X131.146 Y75.139 E.00991
;WIDTH:0.483436
G1 X130.817 Y74.978 E.01094
G1 X131.223 Y74.957 E.01215
;WIDTH:0.441718
G1 X131.63 Y74.936 E.01104
;WIDTH:0.399999
G1 X135.502 Y74.935 E.09418
G1 X135.921 Y74.957 E.01021
G1 X136.52 Y75.045 E.01473
G1 X137.178 Y75.221 E.01657
G1 X137.86 Y75.517 E.01808
G1 X138.367 Y75.823 E.0144
G1 X139.082 Y76.419 E.02264
G1 X139.668 Y77.123 E.02228
G1 X140.119 Y77.921 E.0223
G1 X140.418 Y78.788 E.02231
G1 X140.509 Y79.385 E.01469
G1 X140.558 Y80.035 E.01586
G1 X140.56 Y93.096 E.3177
G1 X140.347 Y92.617 E.01275
G1 X140.158 Y92.394 E.00711
G1 X139.73 Y92.111 E.01248
G1 X139.202 Y91.991 E.01317
G1 X126.769 Y91.992 E.30242
G1 X127.209 Y91.426 E.01744
G1 X127.451 Y90.816 E.01596
G1 X127.467 Y90.316 E.01217
G1 X127.345 Y89.832 E.01214
G1 X127.08 Y89.373 E.01289
G1 X126.731 Y88.964 E.01308
G1 X126.708 Y88.477 E.01186
G1 X126.536 Y88.118 E.00968
G1 X126.237 Y87.871 E.00943
G1 X125.817 Y87.769 E.01051
G1 X105.183 Y87.769 E.5019
G1 X105.025 Y87.782 E.00386
G1 X104.532 Y88.041 E.01355
G1 X104.304 Y88.43 E.01097
G1 X104.269 Y88.964 E.01302
G1 X103.922 Y89.371 E.01301
G1 X103.725 Y89.712 E.00958
G1 X103.549 Y90.184 E.01225
G1 X103.533 Y90.684 E.01217
G1 X103.593 Y90.978 E.0073
G1 X103.81 Y91.464 E.01295
G1 X104.231 Y91.992 E.01643
G1 X91.798 Y91.991 E.30242
G1 X91.438 Y92.046 E.00886
G1 X90.967 Y92.277 E.01276
G1 X90.602 Y92.685 E.01332
G1 X90.433 Y93.089 E.01065
G1 X90.431 Y80.028 E.3177
G1 X90.47 Y79.389 E.01557
G1 X90.58 Y78.787 E.01489
G1 X90.762 Y78.203 E.01488
G1 X91.013 Y77.645 E.01488
G1 X91.33 Y77.122 E.01488
G1 X91.707 Y76.64 E.01488
G1 X92.14 Y76.207 E.01489
G1 X92.622 Y75.83 E.01488
G1 X93.137 Y75.518 E.01465
G1 X93.888 Y75.2 E.01984
G1 X94.593 Y75.015 E.01773
G1 X95.194 Y74.942 E.01473
G1 X99.372 Y74.942 E.10163
;WIDTH:0.446358
G1 X99.694 Y74.965 E.00885
;WIDTH:0.492716
G1 X100.017 Y74.988 E.00987
G1 X99.771 Y75.144 E.00888
;WIDTH:0.446358
G1 X99.524 Y75.3 E.00801
;WIDTH:0.399999
G1 X99.281 Y75.787 E.01324
G1 X99.269 Y75.934 E.00359
G1 X98.791 Y76.574 E.01943
G1 X98.549 Y77.184 E.01596
G1 X98.532 Y77.678 E.01202
G1 X98.653 Y78.165 E.01221
G1 X98.922 Y78.629 E.01305
G1 X99.27 Y79.037 E.01304
G1 X99.279 Y82.345 E.08046
G1 X99.407 Y83.195 E.02091
G1 X99.653 Y83.954 E.01941
G1 X99.959 Y84.556 E.01643
G1 X100.596 Y85.41 E.02591
G1 X101.243 Y85.992 E.02117
G1 X101.668 Y86.279 E.01247
G1 X102.017 Y86.45 E.00945
G1 X102.775 Y86.768 E.01999
G1 X103.553 Y86.937 E.01937
G1 X104.199 Y86.981 E.01575
G1 X110.517 Y86.981 E.15368
G1 X110.675 Y86.968 E.00386
G1 X111.158 Y86.719 E.01322
G1 X111.232 Y86.543 E.00464
G1 X119.768 Y86.543 E.20763
G1 X119.842 Y86.719 E.00464
G1 X120.483 Y86.981 E.01684
G1 X127.224 Y86.961 E.16397
G1 X127.93 Y86.848 E.01739
G1 X128.53 Y86.667 E.01524
G1 X129.02 Y86.451 E.01303
G1 X129.639 Y86.079 E.01757
G1 X130.219 Y85.597 E.01834
G1 X130.891 Y84.799 E.02538
G1 X131.252 Y84.163 E.01779
G1 X131.537 Y83.414 E.01949
G1 X131.663 Y82.861 E.0138
G1 X131.721 Y82.345 E.01263
G1 X131.73 Y79.119 E.07847
G1 E-5 F3600
G1 X131.73 Y79.119 F9000
G1 X131.349 Y79.119
G1 X131.349 Y82.06
G1 X131.346 Y82.136
G1 X131.337 Y82.379
G1 X131.328 Y82.468
G1 X131.301 Y82.709
G1 X131.285 Y82.798
G1 X131.24 Y83.035
G1 X131.219 Y83.125
G1 X131.156 Y83.358
G1 X131.128 Y83.447
G1 X131.048 Y83.674
G1 X131.014 Y83.762
G1 X130.917 Y83.982
G1 X130.876 Y84.067
G1 X130.764 Y84.279
G1 X130.717 Y84.361
G1 X130.59 Y84.563
G1 X130.538 Y84.642
G1 X130.396 Y84.833
G1 X130.339 Y84.907
G1 X130.184 Y85.087
G1 X130.122 Y85.157
G1 X129.954 Y85.325
G1 X129.888 Y85.39
G1 X129.708 Y85.545
G1 X129.637 Y85.605
G1 X129.562 Y85.662
G1 X129.371 Y85.802
G1 X129.29 Y85.854
G1 X129.09 Y85.98
G1 X129.005 Y86.027
G1 X128.795 Y86.138
G1 X128.711 Y86.177
G1 X128.495 Y86.271
G1 X128.408 Y86.304
G1 X128.185 Y86.382
G1 X128.096 Y86.41
G1 X127.868 Y86.471
G1 X127.778 Y86.492
G1 X127.546 Y86.536
G1 X127.455 Y86.551
G1 X127.22 Y86.578
G1 X127.128 Y86.587
G1 X126.892 Y86.596
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X105.183 Y87.375 E.0067
;WIDTH:0.456022
G1 X110.517 Y87.375 E.14962
;WIDTH:0.475838
G1 X110.745 Y87.365 E.0067
G1 X111.437 Y87.002 E.02295
;WIDTH:0.464516
G1 X111.463 Y86.941 E.0019
G1 X119.537 Y86.941 E.23104
G1 X119.562 Y87.002 E.00189
G1 X120.483 Y87.375 E.02843
G1 X111.588 Y87.371 E.25454
;WIDTH:0.475838
G1 X110.805 Y87.365 E.023
G1 E-5 F3600
G1 X110.805 Y87.365 F9000
G1 X125.817 Y87.371
G1 E5 F2400
;WIDTH:0.464534
G1 F6000
G1 X120.483 Y87.375 E.15264
G1 E-5 F3600
G1 X120.483 Y87.375 F9000
G1 X125.817 Y87.371
G1 E5 F2400
G1 F6000
G1 X126.136 Y87.354 E.00914
;WIDTH:0.432267
G1 X126.455 Y87.337 E.00846
;WIDTH:0.399999
G1 X127.277 Y87.323 E.02
G1 X128.035 Y87.198 E.01869
G1 X128.731 Y86.981 E.01773
G1 X129.204 Y86.767 E.01263
G1 X129.867 Y86.365 E.01886
G1 X130.495 Y85.837 E.01996
G1 X131.206 Y84.985 E.02699
G1 X131.592 Y84.297 E.01919
G1 X131.893 Y83.496 E.02081
G1 X132.033 Y82.859 E.01586
G1 X132.086 Y82.346 E.01254
G1 X132.096 Y79.173 E.07718
G1 X132.526 Y78.612 E.01719
G1 X132.702 Y78.239 E.01003
G1 X132.818 Y77.831 E.01032
G1 X132.825 Y77.243 E.0143
G1 X132.765 Y76.949 E.0073
G1 X132.513 Y76.364 E.01549
G1 X132.088 Y75.818 E.01683
G1 X132.08 Y75.728 E.0022
G1 X131.867 Y75.302 E.01159
G1 X135.502 Y75.301 E.08842
G1 X135.897 Y75.322 E.00962
G1 X136.454 Y75.405 E.0137
G1 X137.051 Y75.565 E.01503
G1 X137.692 Y75.842 E.01699
G1 X138.154 Y76.122 E.01314
G1 X138.822 Y76.678 E.02114
G1 X139.366 Y77.332 E.02069
G1 X139.784 Y78.072 E.02067
G1 X140.061 Y78.876 E.02068
G1 X140.147 Y79.44 E.01388
G1 X140.192 Y80.035 E.01451
G1 X140.194 Y91.997 E.29096
G1 X139.837 Y91.762 E.0104
G1 X139.202 Y91.625 E.0158
G1 X127.512 Y91.626 E.28435
G1 X127.702 Y91.239 E.01049
G1 X127.813 Y90.865 E.00949
G1 X127.825 Y90.243 E.01513
G1 X127.736 Y89.836 E.01013
G1 X127.513 Y89.364 E.0127
G1 X127.097 Y88.829 E.01648
G1 X127.087 Y88.519 E.00754
G1 X126.927 Y88.045 E.01217
G1 X126.824 Y87.892 E.00449
G1 X126.405 Y87.546 E.01322
;WIDTH:0.432267
G1 X126.111 Y87.458 E.00812
;WIDTH:0.464534
G1 X125.875 Y87.388 E.00704
G1 X125.875 Y87.388 F9000
G1 X127.133 Y87.699
;WIDTH:0.399999
G1 F6000
G1 X127.33 Y87.685 E.0048
G1 X128.14 Y87.549 E.01998
G1 X128.876 Y87.317 E.01877
G1 X129.388 Y87.083 E.01369
G1 X130.095 Y86.651 E.02015
G1 X130.771 Y86.077 E.02157
G1 X131.521 Y85.17 E.02863
G1 X131.933 Y84.431 E.02058
G1 X132.25 Y83.578 E.02213
G1 X132.396 Y82.903 E.0168
G1 X132.452 Y82.347 E.01359
G1 X132.461 Y79.308 E.07392
G1 X132.635 Y79.103 E.00654
G1 X132.871 Y78.739 E.01055
G1 X133.104 Y78.22 E.01384
G1 X133.205 Y77.7 E.01288
G1 X133.183 Y77.17 E.0129
G1 X133.123 Y76.876 E.0073
G1 X132.836 Y76.193 E.01802
G1 X132.443 Y75.669 E.01593
G1 X135.502 Y75.667 E.07441
G1 X136.193 Y75.728 E.01687
G1 X136.771 Y75.862 E.01443
G1 X137.333 Y76.085 E.01471
G1 X137.941 Y76.42 E.01689
G1 X138.562 Y76.938 E.01967
G1 X139.064 Y77.54 E.01907
G1 X139.449 Y78.223 E.01907
G1 X139.705 Y78.964 E.01907
G1 X139.786 Y79.495 E.01307
G1 X139.826 Y80.035 E.01317
G1 X139.828 Y91.376 E.27586
G1 X139.202 Y91.26 E.01549
G1 X128.073 Y91.26 E.2707
G1 X128.202 Y90.722 E.01346
G1 X128.183 Y90.17 E.01343
G1 X128.074 Y89.693 E.0119
G1 X127.836 Y89.193 E.01347
G1 X127.47 Y88.703 E.01488
G1 X127.449 Y88.473 E.00562
G1 X127.244 Y87.862 E.01568
G1 X127.167 Y87.749 E.00333
G1 E-5 F3600
G1 X103.872 Y86.587 F9000
G1 X103.78 Y86.578
G1 X103.545 Y86.551
G1 X103.454 Y86.536
G1 X103.222 Y86.492
G1 X103.132 Y86.471
G1 X102.904 Y86.41
G1 X102.815 Y86.382
G1 X102.592 Y86.304
G1 X102.505 Y86.271
G1 X102.289 Y86.177
G1 X102.205 Y86.138
G1 X101.995 Y86.027
G1 X101.91 Y85.98
G1 X101.71 Y85.854
G1 X101.629 Y85.802
G1 X101.438 Y85.662
G1 X101.363 Y85.605
G1 X101.292 Y85.545
G1 X101.112 Y85.39
G1 X101.046 Y85.325
G1 X100.878 Y85.157
G1 X100.816 Y85.087
G1 X100.661 Y84.907
G1 X100.604 Y84.833
G1 X100.462 Y84.642
G1 X100.41 Y84.563
G1 X100.283 Y84.361
G1 X100.236 Y84.279
G1 X100.124 Y84.067
G1 X100.083 Y83.982
G1 X99.986 Y83.762
G1 X99.952 Y83.674
G1 X99.872 Y83.447
G1 X99.844 Y83.358
G1 X99.781 Y83.125
G1 X99.76 Y83.035
G1 X99.715 Y82.798
G1 X99.699 Y82.709
G1 X98.907 Y77.667
G1 X98.896 Y77.5
G1 X98.907 Y77.333
G1 X98.941 Y77.17
G1 X98.994 Y77.011
G1 X99.651 Y75.403
G1 X100.017 Y75.403
G1 X100.017 Y74.988
G1 E5 F2400
;WIDTH:0.492716
G1 F6000
G1 X100.183 Y74.981 E.00507
;WIDTH:0.483436
G1 X130.817 Y74.978 E.91517
G1 E-5 F3600
G1 X130.817 Y74.978 F9000
G1 X130.817 Y75.402
G1 X131.349 Y75.403
G1 X132.006 Y77.011
G1 X132.059 Y77.17
G1 X132.093 Y77.333
G1 X132.104 Y77.5
G1 X132.093 Y77.667
G1 X131.301 Y82.709
G1 X131.285 Y82.798
G1 X131.24 Y83.035
G1 X131.219 Y83.125
G1 X131.156 Y83.358
G1 X131.128 Y83.447
G1 X131.048 Y83.674
G1 X131.014 Y83.762
G1 X130.917 Y83.982
G1 X130.876 Y84.067
G1 X130.764 Y84.279
G1 X130.717 Y84.361
G1 X130.59 Y84.563
G1 X130.538 Y84.642
G1 X130.396 Y84.833
G1 X130.339 Y84.907
G1 X130.184 Y85.087
G1 X130.122 Y85.157
G1 X129.954 Y85.325
G1 X129.888 Y85.39
G1 X129.708 Y85.545
G1 X129.637 Y85.605
G1 X129.562 Y85.662
G1 X129.371 Y85.802
G1 X129.29 Y85.854
G1 X129.09 Y85.98
G1 X129.005 Y86.027
G1 X128.795 Y86.138
G1 X128.711 Y86.177
G1 X128.495 Y86.271
G1 X128.408 Y86.304
G1 X128.185 Y86.382
G1 X128.096 Y86.41
G1 X127.868 Y86.471
G1 X127.778 Y86.492
G1 X127.546 Y86.536
G1 X127.455 Y86.551
G1 X127.22 Y86.578
G1 X127.128 Y86.587
G1 X126.892 Y86.596
G1 X104.955 Y87.385
G1 E5 F2400
;WIDTH:0.47584
G1 F6000
G1 X104.647 Y87.552 E.01029
;WIDTH:0.43792
G1 X104.34 Y87.72 E.0094
;WIDTH:0.399999
G1 X104.022 Y88.144 E.01289
G1 X103.953 Y88.329 E.0048
G1 X103.903 Y88.829 E.01222
G1 X103.548 Y89.261 E.0136
G1 X103.298 Y89.761 E.0136
G1 X103.187 Y90.135 E.00949
G1 X103.175 Y90.757 E.01513
G1 X103.235 Y91.051 E.0073
G1 X103.481 Y91.626 E.01521
G1 X91.798 Y91.625 E.28418
G1 X91.365 Y91.688 E.01064
G1 X90.799 Y91.95 E.01517
G1 X90.797 Y80.039 E.28972
G1 X90.834 Y79.433 E.01477
G1 X90.936 Y78.875 E.0138
G1 X91.105 Y78.333 E.01381
G1 X91.338 Y77.816 E.01379
G1 X91.631 Y77.33 E.0138
G1 X91.982 Y76.883 E.01382
G1 X92.383 Y76.482 E.01379
G1 X92.83 Y76.131 E.01382
G1 X93.304 Y75.845 E.01347
G1 X94.006 Y75.547 E.01855
G1 X94.662 Y75.375 E.0165
G1 X95.216 Y75.308 E.01357
G1 X99.13 Y75.307 E.0952
G1 X98.92 Y75.729 E.01147
G1 X98.912 Y75.818 E.00217
G1 X98.643 Y76.134 E.01009
G1 X98.298 Y76.761 E.01741
G1 X98.187 Y77.135 E.00949
G1 X98.163 Y77.693 E.01359
G1 X98.263 Y78.161 E.01164
G1 X98.487 Y78.636 E.01277
G1 X98.904 Y79.173 E.01654
G1 X98.927 Y82.529 E.08163
G1 X99.057 Y83.304 E.01911
G1 X99.324 Y84.113 E.02072
G1 X99.662 Y84.77 E.01797
G1 X100.348 Y85.678 E.02768
G1 X101.038 Y86.295 E.02252
G1 X101.661 Y86.692 E.01797
G1 X102.462 Y87.047 E.02131
G1 X102.994 Y87.194 E.01343
G1 X103.526 Y87.301 E.0132
G1 X104.199 Y87.347 E.01641
;WIDTH:0.43792
G1 X104.577 Y87.366 E.01016
;WIDTH:0.47584
G1 X104.895 Y87.382 E.00935
G1 X104.895 Y87.382 F9000
G1 X103.895 Y87.695
;WIDTH:0.399999
G1 F6000
G1 X103.69 Y87.99 E.00874
G1 X103.602 Y88.228 E.00617
G1 X103.537 Y88.683 E.01118
G1 X103.365 Y88.897 E.00668
G1 X103.129 Y89.261 E.01055
G1 X102.895 Y89.785 E.01396
G1 X102.798 Y90.278 E.01222
G1 X102.817 Y90.83 E.01343
G1 X102.926 Y91.26 E.01079
G1 X91.798 Y91.26 E.27068
G1 X91.467 Y91.293 E.00809
G1 X91.164 Y91.382 E.00768
G1 X91.163 Y80.05 E.27564
G1 X91.197 Y79.478 E.01394
G1 X91.292 Y78.963 E.01274
G1 X91.447 Y78.463 E.01273
G1 X91.662 Y77.986 E.01273
G1 X91.933 Y77.538 E.01274
G1 X92.256 Y77.126 E.01273
G1 X92.626 Y76.756 E.01273
G1 X93.038 Y76.433 E.01273
G1 X93.471 Y76.171 E.01231
G1 X94.124 Y75.894 E.01725
G1 X94.73 Y75.735 E.01524
G1 X95.238 Y75.674 E.01245
G1 X98.556 Y75.673 E.08071
G1 X98.129 Y76.261 E.01768
G1 X97.967 Y76.605 E.00925
G1 X97.798 Y77.278 E.01688
G1 X97.817 Y77.83 E.01343
G1 X97.937 Y78.341 E.01277
G1 X98.164 Y78.807 E.01261
G1 X98.539 Y79.308 E.01522
G1 X98.548 Y82.347 E.07392
G1 X98.566 Y82.583 E.00576
G1 X98.708 Y83.413 E.02048
G1 X98.995 Y84.272 E.02203
G1 X99.366 Y84.984 E.01953
G1 X100.1 Y85.947 E.02945
G1 X100.833 Y86.598 E.02385
G1 X101.512 Y87.026 E.01952
G1 X102.106 Y87.289 E.0158
G1 X102.61 Y87.481 E.01312
G1 X103.249 Y87.628 E.01595
G1 X103.835 Y87.689 E.01433
G1 E-5 F3600
G1 X103.835 Y87.689 F9000
G1 X102.031 Y91.151
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X102.539 Y90.643 E.01747
G1 X102.553 Y90.108 E.01302
G1 X101.675 Y90.986 E.0302
G1 X101.155 Y90.986 E.01265
G1 X102.795 Y89.345 E.05643
G1 X102.94 Y89.03 E.00843
G1 X103.269 Y88.586 E.01344
G1 X103.303 Y88.317 E.0066
G1 X100.635 Y90.986 E.09179
G1 X100.114 Y90.986 E.01267
G1 X103.202 Y87.898 E.10623
G1 X102.779 Y87.801 E.01056
G1 X99.594 Y90.986 E.10956
G1 X99.074 Y90.986 E.01265
G1 X102.367 Y87.692 E.11329
G1 X101.999 Y87.54 E.00968
G1 X98.554 Y90.986 E.11852
G1 X98.034 Y90.986 E.01265
G1 X101.638 Y87.381 E.12399
G1 X101.286 Y87.213 E.00949
G1 X97.513 Y90.986 E.12979
G1 X96.993 Y90.986 E.01265
G1 X100.963 Y87.016 E.13657
G1 X100.654 Y86.805 E.0091
G1 X96.473 Y90.986 E.14382
G1 X95.953 Y90.986 E.01265
G1 X100.37 Y86.569 E.15194
G1 X100.099 Y86.319 E.00897
G1 X95.433 Y90.986 E.16052
G1 X94.912 Y90.986 E.01267
G1 X99.837 Y86.061 E.16942
G1 X99.6 Y85.777 E.009
G1 X94.392 Y90.985 E.17915
G1 X93.872 Y90.985 E.01265
G1 X99.386 Y85.472 E.18966
G1 X99.171 Y85.166 E.0091
G1 X93.352 Y90.985 E.20017
G1 X92.832 Y90.985 E.01265
G1 X98.97 Y84.847 E.21114
G1 X98.8 Y84.497 E.00946
G1 X92.311 Y90.985 E.2232
G1 X91.791 Y90.986 E.01265
G1 X98.645 Y84.131 E.23579
G1 X98.521 Y83.735 E.01009
G1 X91.439 Y90.818 E.24363
G1 X91.438 Y90.298 E.01265
G1 X98.406 Y83.33 E.2397
G1 X98.333 Y82.883 E.01102
G1 X91.438 Y89.778 E.23718
G1 X91.438 Y89.257 E.01267
G1 X98.279 Y82.417 E.23531
G1 X98.273 Y81.903 E.0125
G1 X91.438 Y88.737 E.2351
G1 X91.438 Y88.217 E.01265
G1 X98.271 Y81.384 E.23505
G1 X98.269 Y80.866 E.0126
G1 X91.438 Y87.697 E.23498
G1 X91.438 Y87.177 E.01265
G1 X98.268 Y80.347 E.23495
G1 X98.266 Y79.828 E.01262
G1 X91.438 Y86.657 E.2349
G1 X91.438 Y86.136 E.01267
G1 X98.219 Y79.355 E.23326
G1 X98.001 Y79.053 E.00906
G1 X91.438 Y85.616 E.22576
G1 X91.438 Y85.096 E.01265
G1 X97.811 Y78.723 E.21923
G1 X97.657 Y78.356 E.00968
G1 X91.438 Y84.576 E.21395
G1 X91.438 Y84.056 E.01265
G1 X97.56 Y77.933 E.21061
G1 X97.527 Y77.446 E.01187
G1 X91.437 Y83.536 E.20949
G1 X91.437 Y83.016 E.01265
G1 X97.614 Y76.839 E.21249
G1 X97.716 Y76.494 E.00875
G1 X98.008 Y75.947 E.01508
G1 X91.437 Y82.495 E.22564
G1 X91.437 Y81.975 E.01265
G1 X97.465 Y75.947 E.20736
G1 X96.945 Y75.948 E.01265
G1 X91.437 Y81.455 E.18945
G1 X91.437 Y80.935 E.01265
G1 X96.424 Y75.948 E.17155
G1 X95.904 Y75.948 E.01265
G1 X91.437 Y80.415 E.15366
G1 X91.447 Y79.884 E.01292
G1 X95.384 Y75.948 E.13541
G1 X94.809 Y76.002 E.01405
G1 X91.508 Y79.303 E.11355
G1 X91.692 Y78.599 E.0177
G1 X94.081 Y76.21 E.08218
G1 X93.194 Y76.659 E.02418
G1 X92.815 Y76.956 E.01171
G1 X91.798 Y77.973 E.03498
G1 E-5 F3600
G1 X91.798 Y77.973 F9000
G1 X90.756 Y93.444
G1 X90.751 Y93.514
G1 X90.751 Y95.314
G1 X90.763 Y95.484
G1 X91.275 Y98.393
G1 E5 F2400
G1 F3072.127
G1 X91.825 Y97.843 E.01892
G1 X92.363 Y97.843 E.01309
G1 X91.44 Y98.766 E.03175
G1 X91.44 Y99.303 E.01306
G1 X92.563 Y98.18 E.03863
G1 X92.563 Y98.718 E.01309
G1 X91.44 Y99.841 E.03863
G1 X91.44 Y100.378 E.01306
G1 X92.563 Y99.255 E.03863
G1 X92.563 Y99.793 E.01309
G1 X91.44 Y100.916 E.03863
G1 X91.44 Y101.313 E.00966
G1 X91.603 Y101.291 E.004
G1 X92.563 Y100.33 E.03304
G1 X92.563 Y100.868 E.01309
G1 X91.999 Y101.433 E.01942
G1 X91.999 Y101.433 F9000
G1 X91.784 Y101.635
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X92.563 Y101.633 E.01895
G1 X92.564 Y106.367 E.11515
G1 X92.001 Y106.366 E.01369
G1 X91.441 Y106.304 E.0137
G1 X91.44 Y101.698 E.11204
G1 X91.604 Y101.668 E.00406
G1 X92.008 Y102.01 E.01288
;WIDTH:0.413117
G1 X91.812 Y102.014 E.00494
G1 X91.813 Y105.987 E.10011
;WIDTH:0.412947
G1 X92.192 Y105.994 E.00955
G1 X92.192 Y105.804 E.00479
;WIDTH:0.413117
G1 X92.191 Y102.006 E.0957
G1 E-5 F3600
G1 X92.191 Y102.006 F9000
G1 X91.276 Y107.283
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X91.828 Y106.732 E.01897
G1 X92.393 Y106.732 E.01374
G1 X91.441 Y107.685 E.03277
G1 X91.441 Y108.25 E.01374
G1 X92.564 Y107.128 E.03861
G1 X92.564 Y107.694 E.01377
G1 X91.441 Y108.816 E.03861
G1 X91.441 Y109.313 E.01209
G1 X91.521 Y109.302 E.00196
G1 X92.564 Y108.26 E.03586
G1 X92.564 Y108.825 E.01374
G1 X91.957 Y109.433 E.0209
G1 X91.957 Y109.433 F9000
G1 X91.784 Y109.635
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X92.564 Y109.633 E.01897
G1 X92.564 Y114.367 E.11515
G1 X92.002 Y114.366 E.01367
G1 X91.442 Y114.305 E.0137
G1 X91.441 Y109.698 E.11206
G1 X91.604 Y109.668 E.00403
G1 X92.009 Y110.009 E.01288
;WIDTH:0.412747
G1 X91.813 Y110.013 E.00493
G1 X91.814 Y113.988 E.10006
;WIDTH:0.412578
G1 X92.192 Y113.994 E.00951
G1 X92.192 Y113.805 E.00476
;WIDTH:0.412747
G1 X92.192 Y110.006 E.09563
G1 E-5 F3600
G1 X92.192 Y110.006 F9000
G1 X91.278 Y115.283
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X91.829 Y114.732 E.01895
G1 X92.395 Y114.732 E.01377
G1 X91.442 Y115.685 E.03278
G1 X91.442 Y116.25 E.01374
G1 X92.564 Y115.128 E.0386
G1 X92.564 Y115.694 E.01377
G1 X91.442 Y116.816 E.0386
G1 X91.443 Y117.313 E.01209
G1 X91.523 Y117.302 E.00196
G1 X92.564 Y116.26 E.03583
G1 X92.564 Y116.826 E.01377
G1 X91.957 Y117.433 E.02088
G1 X91.957 Y117.433 F9000
G1 X91.784 Y117.635
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X92.564 Y117.633 E.01897
G1 X92.565 Y122.367 E.11515
G1 X92.003 Y122.366 E.01367
G1 X91.443 Y122.305 E.0137
G1 X91.443 Y117.698 E.11206
G1 X91.604 Y117.668 E.00398
G1 X92.01 Y118.009 E.0129
;WIDTH:0.412377
G1 X91.819 Y118.011 E.0048
G1 X91.815 Y121.805 E.09541
;WIDTH:0.412208
G1 X91.819 Y121.99 E.00465
G1 X92.193 Y121.994 E.0094
G1 X92.193 Y121.805 E.00475
;WIDTH:0.412377
G1 X92.193 Y118.006 E.09553
G1 E-5 F3600
G1 X92.193 Y118.006 F9000
G1 X91.279 Y123.283
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X91.831 Y122.732 E.01897
G1 X92.396 Y122.732 E.01374
G1 X91.444 Y123.685 E.03277
G1 X91.444 Y124.25 E.01374
G1 X92.565 Y123.129 E.03856
G1 X92.565 Y123.695 E.01377
G1 X91.444 Y124.816 E.03856
G1 X91.444 Y125.313 E.01209
G1 X91.524 Y125.302 E.00196
G1 X92.565 Y124.26 E.03583
G1 X92.565 Y124.826 E.01377
G1 X91.958 Y125.433 E.02088
G1 X91.958 Y125.433 F9000
G1 X91.784 Y125.635
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X92.565 Y125.633 E.019
G1 X92.565 Y130.367 E.11515
G1 X92.004 Y130.366 E.01365
G1 X91.445 Y130.305 E.01368
G1 X91.444 Y125.697 E.11208
G1 X91.604 Y125.668 E.00396
G1 X92.01 Y126.008 E.01288
;WIDTH:0.412008
G1 X91.819 Y126.01 E.0048
G1 X91.816 Y129.806 E.09537
;WIDTH:0.41184
G1 X91.819 Y129.991 E.00465
G1 X92.194 Y129.995 E.00942
G1 X92.194 Y129.806 E.00475
;WIDTH:0.412008
G1 X92.193 Y126.006 E.09547
G1 E-5 F3600
G1 X92.193 Y126.006 F9000
G1 X91.28 Y131.29
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X91.839 Y130.732 E.01921
G1 X92.408 Y130.733 E.01384
G1 X91.445 Y131.696 E.03313
G1 X91.445 Y132.266 E.01386
G1 X92.565 Y131.145 E.03854
G1 X92.565 Y131.715 E.01386
G1 X91.445 Y132.836 E.03854
G1 X91.445 Y133.312 E.01158
G1 X91.553 Y133.297 E.00265
G1 X92.565 Y132.286 E.03479
G1 X92.568 Y132.853 E.01379
G1 X91.988 Y133.433 E.01995
G1 X91.988 Y133.433 F9000
G1 X91.785 Y133.635
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X92.621 Y133.633 E.02033
G1 X92.644 Y133.962 E.00802
G1 X92.896 Y135.382 E.03508
G1 X93.281 Y136.674 E.03279
G1 X93.508 Y137.252 E.0151
G1 X93.807 Y137.898 E.01731
G1 X94.072 Y138.368 E.01312
G1 X91.819 Y138.366 E.0548
G1 X91.446 Y138.306 E.00919
G1 X91.445 Y133.697 E.11211
G1 X91.605 Y133.668 E.00396
G1 X92.07 Y134.004 E.01395
G1 X91.811 Y134.009 E.0063
G1 X91.811 Y137.999 E.09705
G1 X93.452 Y138.002 E.03992
G1 X93.176 Y137.406 E.01598
G1 X92.93 Y136.779 E.01638
G1 X92.551 Y135.507 E.03228
G1 X92.284 Y134.025 E.03663
G1 X92.253 Y134 E.00097
G1 X92.253 Y134 F9000
G1 X92.226 Y135.872
;WIDTH:0.498868
G1 F1200
G1 X92.533 Y136.898 E.03309
G1 X92.795 Y137.582 E.02263
G1 X92.226 Y137.585 E.01758
G1 X92.226 Y136.055 E.04728
G1 E-5 F3600
G1 X92.226 Y136.055 F9000
G1 X91.281 Y139.233
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X91.783 Y138.732 E.01725
G1 X92.314 Y138.732 E.01292
G1 X91.446 Y139.6 E.02986
G1 X91.446 Y140.132 E.01294
G1 X92.846 Y138.733 E.04814
G1 X93.377 Y138.733 E.01292
G1 X91.446 Y140.664 E.06643
G1 X91.446 Y141.195 E.01292
G1 X93.908 Y138.734 E.08467
G1 X94.278 Y138.734 E.009
G1 X94.336 Y138.838 E.0029
G1 X91.905 Y141.268 E.08361
G1 X92.437 Y141.268 E.01294
G1 X94.54 Y139.165 E.07234
G1 X94.753 Y139.484 E.00933
G1 X92.969 Y141.268 E.06137
G1 X93.501 Y141.268 E.01294
G1 X94.978 Y139.791 E.05081
G1 X95.208 Y140.092 E.00921
G1 X94.033 Y141.268 E.04044
G1 X94.565 Y141.267 E.01294
G1 X95.453 Y140.379 E.03055
G1 X95.703 Y140.661 E.00917
G1 X95.097 Y141.267 E.02085
G1 X95.629 Y141.267 E.01294
G1 X95.966 Y140.93 E.01159
G1 X96.229 Y141.199 E.00915
G1 X95.996 Y141.432 E.00802
G1 E-5 F3600
G1 X95.996 Y141.432 F9000
G1 X91.559 Y141.728
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.50993
G1 F1200
G1 X91.517 Y141.685 E.0019
G1 X91.459 Y141.701 E.0019
G1 X91.444 Y141.758 E.00186
G1 X91.486 Y141.8 E.00188
G1 X91.543 Y141.785 E.00186
;WIDTH:0.399999
G1 X92.205 Y141.634 E.01652
G1 X91.331 Y142.522 E.03031
;WIDTH:0.374336
G1 X91.26 Y142.503 E.00166
G1 X91.279 Y142.574 E.00166
G1 X91.32 Y142.563 E.00096
;WIDTH:0.399999
G1 X91.446 Y142.91 E.00898
G1 X92.722 Y141.634 E.04389
G1 X93.24 Y141.634 E.0126
G1 X91.447 Y143.427 E.06168
G1 X91.447 Y143.944 E.01258
G1 X93.757 Y141.633 E.07948
G1 X94.274 Y141.633 E.01258
G1 X91.447 Y144.461 E.09726
G1 X91.447 Y144.978 E.01258
G1 X94.792 Y141.633 E.11507
G1 X95.309 Y141.633 E.01258
G1 X91.447 Y145.495 E.13285
G1 X91.447 Y146.012 E.01258
G1 X95.826 Y141.633 E.15063
G1 X96.343 Y141.633 E.01258
G1 X91.623 Y146.353 E.16236
G1 X91.39 Y146.377 E.0057
;WIDTH:0.374336
G1 X91.319 Y146.358 E.00166
G1 X91.338 Y146.429 E.00166
G1 X91.379 Y146.418 E.00096
G1 X91.379 Y146.418 F9000
G1 X92.127 Y146.366
;WIDTH:0.399999
G1 F1200
G1 X96.788 Y141.705 E.16034
G1 X97.073 Y141.937 E.00894
G1 X92.644 Y146.366 E.15235
G1 X93.162 Y146.366 E.0126
G1 X97.365 Y142.162 E.1446
G1 X97.667 Y142.378 E.00903
G1 X93.679 Y146.366 E.13718
G1 X94.196 Y146.366 E.01258
G1 X97.978 Y142.584 E.1301
G1 X98.289 Y142.79 E.00907
G1 X94.713 Y146.366 E.12301
G1 X95.23 Y146.366 E.01258
G1 X98.625 Y142.971 E.11679
G1 X98.961 Y143.152 E.00928
G1 X95.747 Y146.366 E.11056
G1 X96.265 Y146.366 E.0126
G1 X99.297 Y143.333 E.10432
G1 X99.651 Y143.497 E.00949
G1 X96.782 Y146.365 E.09867
G1 E-5 F3600
G1 X96.782 Y146.365 F9000
G1 X99.883 Y143.781
G1 E5 F2400
G1 F1200
G1 X97.299 Y146.365 E.08889
G1 X105.795 Y146.365 E.20666
G1 X106.329 Y146.195 E.01363
G1 X106.644 Y145.92 E.01017
G1 X106.867 Y145.584 E.00981
G1 X106.964 Y145.046 E.0133
G1 X106.965 Y144.537 E.01238
G1 X104.503 Y144.559 E.05989
G1 X103.004 Y144.451 E.03656
G1 X101.655 Y144.192 E.03341
G1 X100.986 Y144.006 E.01689
G1 X100.265 Y143.759 E.01854
G1 X100.013 Y143.652 E.00666
G1 X100.146 Y144.105 E.01148
G1 X100.888 Y144.358 E.01907
G1 X101.586 Y144.551 E.01762
G1 X102.913 Y144.807 E.03287
G1 X104.503 Y144.925 E.03878
G1 X106.599 Y144.903 E.05099
G1 X106.519 Y145.458 E.01364
G1 X106.387 Y145.661 E.00589
G1 X106.195 Y145.851 E.00657
G1 X105.747 Y145.999 E.01148
G1 X98.182 Y146 E.18401
G1 X100 Y144.181 E.06256
G1 X100.191 Y144.507 E.00919
G1 X100.789 Y144.711 E.01537
G1 X101.517 Y144.91 E.01836
;WIDTH:0.426506
G1 X102.178 Y145.051 E.01763
;WIDTH:0.453012
G1 X102.95 Y145.202 E.02191
;WIDTH:0.444073
G1 X103.694 Y145.243 E.02031
;WIDTH:0.417109
G1 X104.438 Y145.283 E.01897
;WIDTH:0.390145
G1 X104.503 Y145.285 E.00154
;WIDTH:0.389202
G1 X105.677 Y145.284 E.02771
G1 X106.191 Y145.263 E.01214
G1 X106.134 Y145.404 E.00359
G1 X105.998 Y145.539 E.00452
G1 X105.7 Y145.639 E.00742
G1 X104.504 Y145.639 E.02823
;WIDTH:0.390145
G1 X104.425 Y145.638 E.00187
;WIDTH:0.417109
G1 X103.68 Y145.625 E.01897
;WIDTH:0.444073
G1 X102.935 Y145.612 E.02031
;WIDTH:0.453012
G1 X102.123 Y145.62 E.02262
;WIDTH:0.426506
G1 X101.447 Y145.634 E.01764
;WIDTH:0.399999
G1 X99.065 Y145.634 E.05794
G1 X100.062 Y144.636 E.03431
G1 X100.285 Y144.913 E.00865
;WIDTH:0.375923
G1 X100.695 Y145.051 E.00983
G1 X101.568 Y145.28 E.02051
G1 X99.919 Y145.28 E.03747
G1 X100.156 Y145.043 E.00762
G1 E-5 F3600
G1 X100.156 Y145.043 F9000
G1 X103.059 Y149.434
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X105.763 Y146.73 E.09302
G1 X105.245 Y146.73 E.0126
G1 X102.706 Y149.269 E.08734
G1 X102.187 Y149.269 E.01262
G1 X104.726 Y146.73 E.08734
G1 X104.208 Y146.73 E.0126
G1 X101.669 Y149.269 E.08734
G1 X101.15 Y149.269 E.01262
G1 X103.689 Y146.73 E.08734
G1 X103.171 Y146.731 E.0126
G1 X100.632 Y149.269 E.08732
G1 X100.114 Y149.269 E.0126
G1 X102.652 Y146.731 E.08731
G1 X102.134 Y146.731 E.0126
G1 X99.595 Y149.269 E.08732
G1 X99.077 Y149.269 E.0126
G1 X101.615 Y146.731 E.08731
G1 X101.097 Y146.731 E.0126
G1 X98.559 Y149.269 E.08731
G1 X98.04 Y149.269 E.01262
G1 X100.578 Y146.731 E.08731
G1 X100.06 Y146.731 E.0126
G1 X97.522 Y149.269 E.08731
G1 X97.004 Y149.269 E.0126
G1 X99.542 Y146.731 E.08731
G1 X99.023 Y146.731 E.01262
G1 X96.485 Y149.269 E.08731
G1 X95.967 Y149.269 E.0126
G1 X98.505 Y146.731 E.08731
G1 X97.986 Y146.731 E.01262
G1 X95.448 Y149.269 E.08731
G1 X94.93 Y149.269 E.0126
G1 X97.468 Y146.731 E.08731
G1 X96.949 Y146.731 E.01262
G1 X94.412 Y149.269 E.08729
G1 X93.893 Y149.269 E.01262
G1 X96.431 Y146.731 E.08731
G1 X95.912 Y146.731 E.01262
G1 X93.375 Y149.269 E.08729
G1 X92.857 Y149.268 E.0126
G1 X95.394 Y146.731 E.08727
G1 X94.875 Y146.731 E.01262
G1 X92.338 Y149.268 E.08727
G1 X91.82 Y149.268 E.0126
G1 X94.357 Y146.731 E.08727
G1 X93.838 Y146.731 E.01262
G1 X91.447 Y149.122 E.08225
G1 X91.447 Y148.604 E.0126
G1 X93.32 Y146.731 E.06443
G1 X92.801 Y146.732 E.01262
G1 X91.447 Y148.086 E.04658
G1 X91.447 Y147.567 E.01262
G1 X92.283 Y146.732 E.02874
G1 X91.765 Y146.731 E.0126
G1 X91.283 Y147.214 E.0166
G1 E-5 F3600
G1 X91.283 Y147.214 F9000
G1 X91.56 Y149.727
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.509918
G1 F1200
G1 X91.518 Y149.685 E.00188
G1 X91.46 Y149.701 E.0019
G1 X91.445 Y149.758 E.00186
G1 X91.487 Y149.8 E.00188
G1 X91.544 Y149.785 E.00186
;WIDTH:0.399999
G1 X91.448 Y150.392 E.01495
G1 X92.206 Y149.634 E.02607
G1 X92.723 Y149.634 E.01258
G1 X91.448 Y150.909 E.04386
G1 X91.467 Y151.407 E.01212
G1 X93.24 Y149.634 E.06099
G1 X93.757 Y149.634 E.01258
G1 X91.539 Y151.853 E.07631
G1 X91.647 Y152.261 E.01027
G1 X94.274 Y149.634 E.09037
G1 X94.791 Y149.634 E.01258
G1 X91.799 Y152.626 E.10292
G1 X91.962 Y152.98 E.00948
G1 X95.308 Y149.634 E.1151
G1 X95.825 Y149.634 E.01258
G1 X92.157 Y153.302 E.12618
G1 X92.384 Y153.593 E.00898
G1 X96.343 Y149.634 E.13619
G1 X96.86 Y149.634 E.01258
G1 X92.632 Y153.862 E.14544
G1 X92.901 Y154.11 E.0089
G1 X97.377 Y149.635 E.15395
G1 X97.894 Y149.635 E.01258
G1 X93.192 Y154.337 E.16175
G1 X93.514 Y154.531 E.00914
G1 X98.411 Y149.635 E.16844
G1 X98.928 Y149.635 E.01258
G1 X94.196 Y154.367 E.16278
G1 X94.713 Y154.367 E.01258
G1 X99.445 Y149.635 E.16278
G1 X99.962 Y149.635 E.01258
G1 X95.23 Y154.367 E.16278
G1 X95.747 Y154.367 E.01258
G1 X100.479 Y149.635 E.16278
G1 X100.996 Y149.635 E.01258
G1 X96.264 Y154.367 E.16278
G1 X96.781 Y154.367 E.01258
G1 X101.513 Y149.635 E.16278
G1 X102.03 Y149.635 E.01258
G1 X97.298 Y154.368 E.16279
G1 X97.815 Y154.368 E.01258
G1 X102.547 Y149.635 E.16279
G1 X103.065 Y149.635 E.0126
G1 X98.332 Y154.368 E.16281
G1 X98.849 Y154.368 E.01258
G1 X103.582 Y149.635 E.16281
G1 X104.099 Y149.635 E.01258
G1 X99.366 Y154.368 E.16281
G1 X99.883 Y154.368 E.01258
G1 X104.616 Y149.635 E.16281
G1 X105.133 Y149.635 E.01258
G1 X100.4 Y154.369 E.16283
G1 X100.917 Y154.369 E.01258
G1 X105.65 Y149.635 E.16283
G1 X106.1 Y149.703 E.01107
G1 X101.433 Y154.369 E.16052
G1 X101.95 Y154.369 E.01258
G1 X106.444 Y149.876 E.15457
G1 X106.706 Y150.13 E.00888
G1 X102.467 Y154.369 E.14582
G1 X102.984 Y154.369 E.01258
G1 X106.886 Y150.468 E.13421
G1 X106.965 Y150.905 E.0108
G1 X103.501 Y154.369 E.11916
G1 X104.018 Y154.37 E.01258
G1 X106.965 Y151.423 E.10137
G1 X106.965 Y151.94 E.01258
G1 X104.535 Y154.37 E.08359
G1 X105.052 Y154.37 E.01258
G1 X106.965 Y152.457 E.06581
G1 X106.965 Y152.974 E.01258
G1 X105.569 Y154.37 E.04802
G1 X105.693 Y154.503 E.00442
;WIDTH:0.374336
G1 X106.114 Y154.415 E.00973
G1 X106.339 Y154.273 E.00602
G1 X106.738 Y153.904 E.01229
G1 X107 Y153.547 E.01002
G1 X107.094 Y153.107 E.01018
;WIDTH:0.399999
G1 X106.825 Y153.631 E.01433
G1 X106.207 Y154.249 E.02126
G1 X106.207 Y154.249 F9000
G1 X105.564 Y155.224
;WIDTH:0.4
G1 F3072.127
G1 X106.123 Y154.665 E.01923
G1 X105.534 Y154.736 E.01443
G1 X105.21 Y155.06 E.01115
G1 X104.691 Y155.06 E.01262
G1 X105.016 Y154.736 E.01116
G1 X104.497 Y154.735 E.01262
G1 X104.173 Y155.06 E.01116
G1 X103.654 Y155.06 E.01262
G1 X103.979 Y154.735 E.01118
G1 X103.461 Y154.735 E.0126
G1 X103.136 Y155.06 E.01118
G1 X102.617 Y155.06 E.01262
G1 X102.942 Y154.735 E.01118
G1 X102.424 Y154.735 E.0126
G1 X102.098 Y155.061 E.01121
G1 X101.58 Y155.061 E.0126
G1 X101.906 Y154.735 E.01121
G1 X101.388 Y154.735 E.0126
G1 X101.061 Y155.061 E.01123
G1 X100.543 Y155.061 E.0126
G1 X100.869 Y154.734 E.01123
G1 X100.351 Y154.734 E.0126
G1 X100.024 Y155.061 E.01125
G1 X99.506 Y155.061 E.0126
G1 X99.833 Y154.734 E.01125
G1 X99.315 Y154.734 E.0126
G1 X98.987 Y155.061 E.01127
G1 X98.469 Y155.061 E.0126
G1 X98.796 Y154.734 E.01125
G1 X98.278 Y154.734 E.0126
G1 X97.95 Y155.062 E.01128
G1 X97.432 Y155.062 E.0126
G1 X97.76 Y154.733 E.0113
G1 X97.242 Y154.733 E.0126
G1 X96.913 Y155.062 E.01132
G1 X96.395 Y155.062 E.0126
G1 X96.723 Y154.733 E.0113
G1 X96.205 Y154.733 E.0126
G1 X95.876 Y155.062 E.01132
G1 X95.366 Y155.053 E.01241
G1 X95.687 Y154.733 E.01103
G1 X95.169 Y154.733 E.0126
G1 X94.892 Y155.009 E.00951
G1 X94.461 Y154.922 E.0107
G1 X94.65 Y154.732 E.00652
G1 X94.132 Y154.732 E.0126
G1 X93.942 Y154.923 E.00655
G1 E-5 F3600
G1 X93.942 Y154.923 F9000
G1 X107.602 Y144.373
G1 E5 F2400
G1 F3072.127
G1 X107.331 Y144.644 E.00932
G1 X107.321 Y145.172 E.01285
G1 X107.956 Y144.537 E.02184
G1 X108.475 Y144.537 E.01262
G1 X103.742 Y149.269 E.1628
G1 X104.261 Y149.27 E.01262
G1 X108.993 Y144.537 E.1628
G1 X109.511 Y144.537 E.0126
G1 X104.779 Y149.27 E.1628
G1 X105.297 Y149.27 E.0126
G1 X110.03 Y144.537 E.16281
G1 X110.551 Y144.535 E.01267
G1 X105.816 Y149.27 E.16288
G1 X106.24 Y149.364 E.01056
G1 X111.198 Y144.406 E.17055
G1 X111.301 Y144.543 E.00417
G1 X111.579 Y144.543 E.00676
G1 X106.59 Y149.532 E.17162
G1 X106.87 Y149.771 E.00895
G1 X112.098 Y144.543 E.17984
G1 X112.616 Y144.543 E.0126
G1 X107.094 Y150.065 E.18995
G1 X107.254 Y150.424 E.00956
G1 X113.135 Y144.543 E.2023
G1 X113.653 Y144.543 E.0126
G1 X107.329 Y150.867 E.21754
G1 X107.331 Y151.383 E.01255
G1 X114.171 Y144.543 E.23529
G1 X114.69 Y144.543 E.01262
G1 X107.331 Y151.902 E.25315
G1 X107.331 Y152.42 E.0126
G1 X115.208 Y144.543 E.27096
G1 X115.727 Y144.543 E.01262
G1 X107.331 Y152.938 E.2888
G1 X107.274 Y153.514 E.01408
G1 X116.245 Y144.543 E.3086
G1 X116.764 Y144.543 E.01262
G1 X106.247 Y155.06 E.36178
G1 X106.765 Y155.06 E.0126
G1 X117.282 Y144.543 E.36178
G1 X117.8 Y144.543 E.0126
G1 X107.284 Y155.059 E.36174
G1 X107.802 Y155.059 E.0126
G1 X118.319 Y144.543 E.36176
G1 X118.837 Y144.543 E.0126
G1 X108.321 Y155.059 E.36174
G1 X108.839 Y155.059 E.0126
G1 X119.356 Y144.543 E.36176
G1 X119.699 Y144.543 E.00834
G1 X119.784 Y144.397 E.00411
G1 X119.96 Y144.457 E.00452
G1 X109.358 Y155.059 E.3647
G1 X109.876 Y155.059 E.0126
G1 X120.409 Y144.526 E.36233
G1 X120.926 Y144.528 E.01258
G1 X110.395 Y155.059 E.36226
G1 X110.913 Y155.059 E.0126
G1 X121.443 Y144.529 E.36223
G1 X121.96 Y144.53 E.01258
G1 X111.432 Y155.058 E.36216
G1 X111.951 Y155.058 E.01262
G1 X122.478 Y144.531 E.36212
G1 X122.995 Y144.532 E.01258
G1 X112.469 Y155.058 E.36209
G1 X112.988 Y155.058 E.01262
G1 X123.512 Y144.534 E.36202
G1 X123.669 Y144.534 E.00382
G1 X123.669 Y144.895 E.00878
G1 X113.506 Y155.058 E.3496
G1 X114.025 Y155.058 E.01262
G1 X123.715 Y145.367 E.33335
G1 X123.822 Y145.779 E.01035
G1 X114.543 Y155.058 E.31919
G1 X115.062 Y155.058 E.01262
G1 X124.016 Y146.103 E.30803
G1 X124.272 Y146.366 E.00893
G1 X115.58 Y155.058 E.299
G1 X116.099 Y155.057 E.01262
G1 X124.586 Y146.57 E.29195
G1 X124.974 Y146.701 E.00996
G1 X116.617 Y155.057 E.28746
G1 X117.136 Y155.057 E.01262
G1 X125.463 Y146.73 E.28644
G1 X125.981 Y146.73 E.0126
G1 X117.654 Y155.057 E.28644
G1 X118.173 Y155.057 E.01262
G1 X126.499 Y146.73 E.28643
G1 X127.018 Y146.731 E.01262
G1 X118.691 Y155.057 E.28643
G1 X119.21 Y155.057 E.01262
G1 X123.707 Y150.56 E.15469
G1 X123.669 Y151.116 E.01356
G1 X119.729 Y155.057 E.13555
G1 X120.247 Y155.057 E.0126
G1 X123.669 Y151.635 E.11771
G1 X123.669 Y152.153 E.0126
G1 X120.766 Y155.056 E.09986
G1 X121.284 Y155.056 E.0126
G1 X123.669 Y152.671 E.08204
G1 X123.678 Y153.181 E.01241
G1 X121.803 Y155.056 E.0645
G1 X122.321 Y155.056 E.0126
G1 X123.759 Y153.618 E.04947
G1 X123.932 Y153.964 E.00941
G1 X122.84 Y155.056 E.03756
G1 X123.358 Y155.056 E.0126
G1 X124.173 Y154.241 E.02804
G1 X124.452 Y154.48 E.00894
G1 X123.877 Y155.056 E.0198
G1 X124.395 Y155.056 E.0126
G1 X124.828 Y154.623 E.01489
G1 X125.243 Y154.727 E.01041
G1 X124.914 Y155.055 E.0113
G1 X125.432 Y155.055 E.0126
G1 X125.752 Y154.736 E.01099
G1 X126.27 Y154.736 E.0126
G1 X125.951 Y155.055 E.01097
G1 X126.469 Y155.055 E.0126
G1 X126.789 Y154.735 E.01101
G1 X127.308 Y154.735 E.01262
G1 X126.988 Y155.055 E.01101
G1 X127.507 Y155.055 E.01262
G1 X127.826 Y154.735 E.01099
G1 X128.345 Y154.735 E.01262
G1 X128.025 Y155.055 E.01101
G1 X128.544 Y155.055 E.01262
G1 X128.863 Y154.735 E.01099
G1 X129.382 Y154.735 E.01262
G1 X129.062 Y155.055 E.01101
G1 X129.581 Y155.054 E.01262
G1 X129.901 Y154.734 E.01101
G1 X130.419 Y154.734 E.0126
G1 X130.099 Y155.054 E.01101
G1 X130.618 Y155.054 E.01262
G1 X130.938 Y154.734 E.01101
G1 X131.456 Y154.734 E.0126
G1 X131.136 Y155.054 E.01101
G1 X131.655 Y155.054 E.01262
G1 X131.975 Y154.734 E.01101
G1 X132.493 Y154.734 E.0126
G1 X132.173 Y155.054 E.01101
G1 X132.692 Y155.054 E.01262
G1 X133.012 Y154.734 E.01101
G1 X133.531 Y154.733 E.01262
G1 X133.21 Y155.054 E.01104
G1 X133.729 Y155.053 E.01262
G1 X134.049 Y154.733 E.01101
G1 X134.568 Y154.733 E.01262
G1 X134.247 Y155.053 E.01103
G1 X134.766 Y155.053 E.01262
G1 X135.086 Y154.733 E.01101
G1 X135.605 Y154.733 E.01262
G1 X135.284 Y155.053 E.01103
G1 X135.735 Y155.053 E.01097
G1 X135.812 Y155.044 E.00189
G1 X136.123 Y154.733 E.0107
G1 X136.642 Y154.732 E.01262
G1 X136.211 Y155.163 E.01483
G1 E-5 F3600
G1 X136.211 Y155.163 F9000
G1 X139.34 Y149.443
G1 E5 F2400
G1 F3072.127
G1 X139.563 Y149.219 E.00769
G1 X139.563 Y148.701 E.0126
G1 X138.996 Y149.268 E.0195
G1 X138.477 Y149.268 E.01262
G1 X139.563 Y148.183 E.03734
G1 X139.563 Y147.664 E.01262
G1 X137.959 Y149.268 E.05518
G1 X137.44 Y149.269 E.01262
G1 X139.563 Y147.146 E.07303
G1 X139.562 Y146.686 E.01119
G1 X139.495 Y146.696 E.00165
G1 X136.922 Y149.269 E.08851
G1 X136.403 Y149.269 E.01262
G1 X138.94 Y146.732 E.08727
G1 X138.422 Y146.732 E.0126
G1 X135.885 Y149.269 E.08727
G1 X135.366 Y149.269 E.01262
G1 X137.904 Y146.732 E.08729
G1 X137.385 Y146.731 E.01262
G1 X134.848 Y149.269 E.08729
G1 X134.329 Y149.269 E.01262
G1 X136.867 Y146.731 E.08731
G1 X136.348 Y146.731 E.01262
G1 X133.811 Y149.269 E.08729
G1 X133.292 Y149.269 E.01262
G1 X135.83 Y146.731 E.08731
G1 X135.312 Y146.731 E.0126
G1 X132.774 Y149.269 E.08731
G1 X132.255 Y149.269 E.01262
G1 X134.793 Y146.731 E.08731
G1 X134.275 Y146.731 E.0126
G1 X131.737 Y149.269 E.08731
G1 X131.219 Y149.269 E.0126
G1 X133.757 Y146.731 E.08731
G1 X133.238 Y146.731 E.01262
G1 X130.7 Y149.269 E.08731
G1 X130.182 Y149.269 E.0126
G1 X132.72 Y146.731 E.08731
G1 X132.201 Y146.731 E.01262
G1 X129.663 Y149.269 E.08731
G1 X129.145 Y149.269 E.0126
G1 X131.683 Y146.731 E.08731
G1 X131.165 Y146.731 E.0126
G1 X128.626 Y149.269 E.08732
G1 X128.108 Y149.269 E.0126
G1 X130.646 Y146.731 E.08731
G1 X130.128 Y146.731 E.0126
G1 X127.589 Y149.27 E.08734
G1 X127.071 Y149.27 E.0126
G1 X129.61 Y146.731 E.08734
G1 X129.091 Y146.731 E.01262
G1 X126.552 Y149.27 E.08734
G1 X126.034 Y149.27 E.0126
G1 X128.573 Y146.731 E.08734
G1 X128.055 Y146.731 E.0126
G1 X125.515 Y149.27 E.08736
G1 X124.966 Y149.301 E.01338
G1 X127.701 Y146.566 E.09408
G1 E-5 F3600
G1 X127.701 Y146.566 F9000
G1 X130.667 Y143.783
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X128.215 Y146.236 E.08436
G1 X128.215 Y146.364 E.00311
G1 X125.19 Y146.363 E.07358
G1 X124.752 Y146.242 E.01105
G1 X124.352 Y145.931 E.01232
G1 X124.123 Y145.558 E.01065
G1 X124.034 Y145.077 E.0119
G1 X124.035 Y144.535 E.01318
G1 X125.263 Y144.558 E.02988
G1 X126.764 Y144.555 E.03651
G1 X127.585 Y144.501 E.02001
G1 X128.15 Y144.431 E.01385
G1 X128.816 Y144.311 E.01646
G1 X129.507 Y144.151 E.01725
G1 X130.495 Y143.844 E.02517
G1 X130.495 Y143.844 F9000
G1 X131.572 Y143.396
G1 F1200
G1 X128.603 Y146.365 E.10213
G1 X129.12 Y146.365 E.01258
G1 X132.716 Y142.768 E.12372
G1 X132.975 Y142.562 E.00805
;WIDTH:0.374336
G1 X133.825 Y141.847 E.02512
;WIDTH:0.399999
G1 X134.369 Y141.633 E.01422
G1 X129.637 Y146.365 E.16278
G1 X130.154 Y146.365 E.01258
G1 X134.886 Y141.633 E.16278
G1 X135.403 Y141.633 E.01258
G1 X130.671 Y146.365 E.16278
G1 X131.188 Y146.365 E.01258
G1 X135.92 Y141.633 E.16278
G1 X136.437 Y141.633 E.01258
G1 X131.705 Y146.365 E.16278
G1 X132.222 Y146.365 E.01258
G1 X136.954 Y141.633 E.16278
G1 X137.471 Y141.634 E.01258
G1 X132.739 Y146.365 E.16276
G1 X133.256 Y146.365 E.01258
G1 X137.988 Y141.634 E.16276
G1 X138.505 Y141.634 E.01258
G1 X133.773 Y146.365 E.16276
G1 X134.29 Y146.366 E.01258
G1 X139.022 Y141.634 E.16278
G1 X139.507 Y141.666 E.01182
G1 X134.808 Y146.366 E.16166
G1 X135.325 Y146.366 E.01258
G1 X139.562 Y142.129 E.14575
G1 X139.562 Y142.646 E.01258
G1 X135.842 Y146.366 E.12797
G1 X136.359 Y146.366 E.01258
G1 X139.562 Y143.163 E.11018
G1 X139.562 Y143.68 E.01258
G1 X136.876 Y146.366 E.0924
G1 X137.393 Y146.366 E.01258
G1 X139.562 Y144.197 E.07461
G1 X139.562 Y144.714 E.01258
G1 X137.91 Y146.366 E.05683
G1 X138.427 Y146.366 E.01258
G1 X139.562 Y145.231 E.03904
G1 X139.562 Y145.748 E.01258
G1 X138.944 Y146.366 E.02126
G1 X139.586 Y146.326 E.01565
;WIDTH:0.422308
G1 X139.539 Y146.339 E.00126
G1 X139.517 Y146.258 E.00217
G1 X139.598 Y146.279 E.00216
G1 E-5 F3600
G1 X139.598 Y146.279 F9000
G1 X129.377 Y144.557
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X127.956 Y145.998 E.04923
G1 X125.313 Y145.998 E.06429
G1 X124.993 Y145.929 E.00796
G1 X124.671 Y145.741 E.00907
G1 X124.473 Y145.437 E.00882
G1 X124.4 Y144.901 E.01316
G1 X125.264 Y144.923 E.02102
G1 X126.796 Y144.919 E.03726
G1 X127.63 Y144.864 E.02033
G1 X128.214 Y144.791 E.01432
G1 X129.199 Y144.598 E.02441
G1 X129.199 Y144.598 F9000
G1 X128.23 Y145.17
;WIDTH:0.420789
G1 F1200
G1 X127.779 Y145.622 E.01641
G1 X127.558 Y145.626 E.00568
;WIDTH:0.413185
G1 X126.766 Y145.637 E.01996
;WIDTH:0.390362
G1 X125.313 Y145.638 E.03441
;WIDTH:0.388705
G1 X125.141 Y145.597 E.00417
G1 X124.915 Y145.472 E.00609
G1 X124.807 Y145.262 E.00557
G1 X125.264 Y145.283 E.01078
;WIDTH:0.390362
G1 X126.765 Y145.281 E.03555
;WIDTH:0.391335
G1 X126.818 Y145.28 E.00126
;WIDTH:0.420789
G1 X127.676 Y145.237 E.02208
G1 X128.049 Y145.192 E.00966
G1 E-5 F3600
G1 X128.049 Y145.192 F9000
G1 X125.006 Y149.666
G1 E5 F2400
;WIDTH:0.399999
G1 F1200
G1 X124.078 Y150.594 E.03192
G1 X124.035 Y151.154 E.01366
G1 X125.553 Y149.635 E.05224
G1 X126.071 Y149.635 E.0126
G1 X124.035 Y151.671 E.07004
G1 X124.035 Y152.189 E.0126
G1 X126.588 Y149.635 E.08784
G1 X127.105 Y149.635 E.01258
G1 X124.035 Y152.706 E.10562
G1 X124.051 Y153.206 E.01217
G1 X127.622 Y149.635 E.12284
G1 X128.139 Y149.635 E.01258
G1 X124.164 Y153.61 E.13674
G1 X124.366 Y153.925 E.0091
G1 X128.657 Y149.635 E.14759
G1 X129.174 Y149.635 E.01258
G1 X124.645 Y154.164 E.15579
G1 X125.029 Y154.297 E.00988
G1 X129.691 Y149.635 E.16037
G1 X130.208 Y149.635 E.01258
G1 X125.473 Y154.37 E.16288
G1 X125.99 Y154.37 E.01258
G1 X130.725 Y149.635 E.16288
G1 X131.242 Y149.635 E.01258
G1 X126.507 Y154.37 E.16288
G1 X127.025 Y154.37 E.0126
G1 X131.76 Y149.635 E.16288
G1 X132.277 Y149.635 E.01258
G1 X127.542 Y154.37 E.16288
G1 X128.059 Y154.369 E.01258
G1 X132.794 Y149.635 E.16286
G1 X133.311 Y149.635 E.01258
G1 X128.577 Y154.369 E.16285
G1 X129.094 Y154.369 E.01258
G1 X133.828 Y149.635 E.16285
G1 X134.345 Y149.635 E.01258
G1 X129.611 Y154.369 E.16285
G1 X130.128 Y154.369 E.01258
G1 X134.863 Y149.634 E.16288
G1 X135.38 Y149.634 E.01258
G1 X130.646 Y154.369 E.16286
G1 X131.163 Y154.368 E.01258
G1 X135.897 Y149.634 E.16285
G1 X136.414 Y149.634 E.01258
G1 X131.68 Y154.368 E.16285
G1 X132.197 Y154.368 E.01258
G1 X136.931 Y149.634 E.16285
G1 X137.449 Y149.634 E.0126
G1 X132.715 Y154.368 E.16285
G1 X133.232 Y154.368 E.01258
G1 X137.966 Y149.634 E.16285
G1 X138.483 Y149.634 E.01258
G1 X133.749 Y154.368 E.16285
G1 X134.267 Y154.367 E.0126
G1 X139 Y149.634 E.16281
G1 X139.688 Y149.587 E.01677
;WIDTH:0.374336
G1 X139.695 Y149.679 E.00209
;WIDTH:0.399999
G1 X139.49 Y149.661 E.00501
G1 X134.784 Y154.367 E.16188
G1 X135.301 Y154.367 E.01258
G1 X139.563 Y150.105 E.14661
G1 X139.563 Y150.622 E.01258
G1 X135.818 Y154.367 E.12883
G1 X136.336 Y154.367 E.0126
G1 X139.55 Y151.152 E.11058
G1 X139.485 Y151.735 E.01427
G1 X136.853 Y154.367 E.09054
G1 X137.305 Y154.432 E.01111
G1 X139.293 Y152.443 E.0684
G1 X139.477 Y152.218 E.00707
;WIDTH:0.374336
G1 X139.436 Y152.229 E.00096
G1 X139.417 Y152.158 E.00166
G1 X139.488 Y152.177 E.00166
G1 X139.488 Y152.177 F9000
G1 X138.882 Y153.317
;WIDTH:0.38435
G1 F1200
G1 X138.216 Y154.027 E.02267
G1 X137.799 Y154.396 E.01296
G1 E-5 F3600
G1 X137.799 Y154.396 F9000
G1 X139.019 Y141.433
G1 E5 F2400
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X139.562 Y140.891 E.01866
G1 X139.561 Y140.331 E.01362
G1 X138.624 Y141.268 E.03223
G1 X138.064 Y141.268 E.01362
G1 X139.561 Y139.77 E.05151
G1 X139.561 Y139.21 E.01362
G1 X137.504 Y141.268 E.07078
G1 X136.944 Y141.268 E.01362
G1 X139.519 Y138.692 E.0886
G1 X138.92 Y138.732 E.0146
G1 X136.384 Y141.268 E.08724
G1 X135.824 Y141.267 E.01362
G1 X138.359 Y138.732 E.0872
G1 X137.798 Y138.733 E.01365
G1 X135.264 Y141.267 E.08717
G1 X134.704 Y141.267 E.01362
G1 X137.402 Y138.569 E.09281
G1 E-5 F3600
G1 X137.402 Y138.569 F9000
G1 X139.023 Y133.634
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X138.384 Y133.633 E.01554
G1 X138.325 Y134.172 E.01319
G1 X138.12 Y135.318 E.02832
G1 X137.771 Y136.521 E.03047
G1 X137.491 Y137.254 E.01909
G1 X136.936 Y138.368 E.03027
G1 X139.215 Y138.365 E.05543
G1 X139.561 Y138.301 E.00856
G1 X139.56 Y133.681 E.11238
G1 X139.205 Y133.634 E.00871
G1 X138.749 Y134.035 E.01477
;WIDTH:0.471959
G1 X139.159 Y134.036 E.01194
;WIDTH:0.496688
G1 X139.147 Y134.743 E.02175
G1 X139.171 Y135.104 E.01113
;WIDTH:0.448344
G1 X139.195 Y135.465 E.00996
;WIDTH:0.399999
G1 X139.183 Y137.999 E.06164
G1 X137.527 Y138.002 E.04028
G1 X137.936 Y137.117 E.02371
G1 X138.122 Y136.623 E.01284
G1 X138.478 Y135.392 E.03117
;WIDTH:0.433573
G1 X138.545 Y135.145 E.0068
;WIDTH:0.467146
G1 X138.613 Y134.899 E.00735
;WIDTH:0.500719
G1 X138.68 Y134.653 E.00791
G1 X138.729 Y134.217 E.01361
G1 X138.729 Y134.217 F9000
G1 X138.778 Y135.859
;WIDTH:0.502725
G1 F1200
G1 X138.778 Y137.583 E.05372
G1 X138.2 Y137.584 E.01801
G1 X138.523 Y136.739 E.02819
G1 X138.727 Y136.034 E.02287
G1 E-5 F3600
G1 X138.727 Y136.034 F9000
G1 X139.009 Y133.433
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X139.56 Y132.881 E.01897
G1 X139.56 Y132.315 E.01377
G1 X138.607 Y133.268 E.03278
G1 X138.407 Y133.268 E.00486
G1 X138.431 Y132.878 E.0095
G1 X139.56 Y131.749 E.03884
G1 X139.56 Y131.182 E.01379
G1 X138.435 Y132.308 E.03872
G1 X138.435 Y131.741 E.01379
G1 X139.478 Y130.698 E.03588
G1 X138.878 Y130.732 E.01462
G1 X138.27 Y131.34 E.02091
G1 E-5 F3600
G1 X138.27 Y131.34 F9000
G1 X138.998 Y125.634
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X139.559 Y125.696 E.01373
G1 X139.56 Y130.302 E.11204
G1 X139.216 Y130.365 E.00851
G1 X138.435 Y130.367 E.019
G1 X138.435 Y125.633 E.11515
G1 X138.815 Y125.634 E.00924
G1 X138.808 Y126.006 E.00905
;WIDTH:0.413594
G1 X139.18 Y126.007 E.00938
G1 X139.187 Y126.196 E.00477
;WIDTH:0.413979
G1 X139.182 Y129.992 E.09586
G1 X138.808 Y129.993 E.00945
G1 X138.808 Y126.189 E.09607
G1 X138.808 Y126.189 F9000
G1 X139.007 Y125.433
;WIDTH:0.4
G1 F3072.127
G1 X139.559 Y124.881 E.01899
G1 X139.559 Y124.315 E.01377
G1 X138.606 Y125.268 E.03278
G1 X138.435 Y125.268 E.00416
G1 X138.435 Y124.873 E.00961
G1 X139.559 Y123.749 E.03866
G1 X139.559 Y123.183 E.01377
G1 X138.435 Y124.307 E.03866
G1 X138.435 Y123.741 E.01377
G1 X139.478 Y122.698 E.03588
G1 X138.878 Y122.732 E.01462
G1 X138.271 Y123.339 E.02088
G1 E-5 F3600
G1 X138.271 Y123.339 F9000
G1 X138.998 Y117.634
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X139.558 Y117.695 E.0137
G1 X139.559 Y122.302 E.11206
G1 X139.216 Y122.365 E.00848
G1 X138.435 Y122.367 E.019
G1 X138.436 Y117.633 E.11515
G1 X138.815 Y117.634 E.00922
G1 X138.808 Y118.006 E.00905
;WIDTH:0.412743
G1 X139.181 Y118.006 E.00939
G1 X139.186 Y118.195 E.00476
;WIDTH:0.413128
G1 X139.182 Y121.993 E.0957
G1 X138.808 Y121.994 E.00942
G1 X138.808 Y118.189 E.09588
G1 X138.808 Y118.189 F9000
G1 X139.006 Y117.433
;WIDTH:0.4
G1 F3072.127
G1 X139.558 Y116.881 E.01899
G1 X139.558 Y116.315 E.01377
G1 X138.605 Y117.268 E.03278
G1 X138.436 Y117.268 E.00411
G1 X138.436 Y116.872 E.00963
G1 X139.558 Y115.75 E.0386
G1 X139.558 Y115.184 E.01377
G1 X138.436 Y116.306 E.0386
G1 X138.436 Y115.74 E.01377
G1 X139.478 Y114.698 E.03584
G1 X138.878 Y114.732 E.01462
G1 X138.271 Y115.339 E.02088
G1 E-5 F3600
G1 X138.271 Y115.339 F9000
G1 X138.997 Y109.634
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X139.557 Y109.695 E.0137
G1 X139.557 Y114.302 E.11206
G1 X139.216 Y114.365 E.00843
G1 X138.436 Y114.367 E.01897
G1 X138.436 Y109.633 E.11515
G1 X138.814 Y109.634 E.00919
G1 X138.808 Y110.005 E.00903
;WIDTH:0.411893
G1 X139.181 Y110.01 E.00937
G1 X139.185 Y110.194 E.00462
;WIDTH:0.412278
G1 X139.181 Y113.989 E.09541
G1 X138.808 Y113.994 E.00938
G1 X138.808 Y110.188 E.09569
G1 X138.808 Y110.188 F9000
G1 X139.005 Y109.433
;WIDTH:0.4
G1 F3072.127
G1 X139.557 Y108.881 E.01899
G1 X139.557 Y108.316 E.01374
G1 X138.605 Y109.268 E.03275
G1 X138.436 Y109.268 E.00411
G1 X138.436 Y108.871 E.00966
G1 X139.556 Y107.75 E.03854
G1 X139.556 Y107.185 E.01374
G1 X138.436 Y108.305 E.03853
G1 X138.436 Y107.739 E.01377
G1 X139.477 Y106.698 E.03581
G1 X138.878 Y106.732 E.01459
G1 X138.272 Y107.338 E.02085
G1 E-5 F3600
G1 X138.272 Y107.338 F9000
G1 X138.997 Y101.634
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.399999
G1 F1200
G1 X139.556 Y101.695 E.01368
G1 X139.556 Y106.303 E.11208
G1 X139.216 Y106.365 E.00841
G1 X138.436 Y106.367 E.01897
G1 X138.437 Y101.633 E.11515
G1 X138.814 Y101.634 E.00917
G1 X138.808 Y102.005 E.00903
;WIDTH:0.411041
G1 X139.181 Y102.009 E.00935
G1 X139.184 Y102.194 E.00464
;WIDTH:0.411428
G1 X139.181 Y105.99 E.09522
G1 X138.808 Y105.995 E.00936
G1 X138.808 Y102.188 E.0955
G1 X138.808 Y102.188 F9000
G1 X139.046 Y101.433
;WIDTH:0.4
G1 F3072.127
G1 X139.555 Y100.924 E.01751
G1 X139.555 Y100.387 E.01306
G1 X138.674 Y101.268 E.03031
G1 X138.437 Y101.268 E.00576
G1 X138.437 Y100.968 E.0073
G1 X139.555 Y99.85 E.03846
G1 X139.555 Y99.313 E.01306
G1 X138.437 Y100.431 E.03846
G1 X138.437 Y99.894 E.01306
G1 X139.555 Y98.776 E.03846
G1 X139.555 Y98.239 E.01306
G1 X138.437 Y99.357 E.03846
G1 X138.437 Y98.82 E.01306
G1 X139.441 Y97.815 E.03455
G1 X138.876 Y97.843 E.01376
G1 X138.272 Y98.447 E.02078
G1 E-5 F3600
G1 X138.272 Y98.447 F9000
G1 X140.035 Y96.014
G1 X140.13 Y95.851
G1 X140.197 Y95.677
G1 X140.218 Y95.58
G1 X140.238 Y95.484
G1 X140.249 Y95.314
G1 X140.249 Y93.514
G1 X140.238 Y93.344
G1 X140.218 Y93.248
G1 X140.197 Y93.152
G1 X140.13 Y92.978
G1 X140.035 Y92.815
G1 X139.049 Y91.15
G1 E5 F2400
G1 F3072.127
G1 X139.554 Y90.645 E.01737
G1 X139.554 Y90.12 E.01277
G1 X138.688 Y90.985 E.02977
G1 X138.163 Y90.985 E.01277
G1 X139.554 Y89.595 E.04783
G1 X139.554 Y89.07 E.01277
G1 X137.638 Y90.985 E.06589
G1 X137.113 Y90.985 E.01277
G1 X139.554 Y88.545 E.08395
G1 X139.553 Y88.02 E.01277
G1 X136.588 Y90.985 E.10199
G1 X136.063 Y90.986 E.01277
G1 X139.553 Y87.495 E.12007
G1 X139.553 Y86.97 E.01277
G1 X135.538 Y90.986 E.13813
G1 X135.013 Y90.986 E.01277
G1 X139.553 Y86.445 E.15619
G1 X139.553 Y85.92 E.01277
G1 X134.488 Y90.986 E.17425
G1 X133.963 Y90.986 E.01277
G1 X139.553 Y85.395 E.19231
G1 X139.553 Y84.87 E.01277
G1 X133.437 Y90.986 E.21039
G1 X132.912 Y90.986 E.01277
G1 X139.553 Y84.345 E.22845
G1 X139.553 Y83.82 E.01277
G1 X132.387 Y90.986 E.24651
G1 X131.862 Y90.986 E.01277
G1 X139.553 Y83.295 E.26457
G1 X139.553 Y82.77 E.01277
G1 X131.337 Y90.986 E.28263
G1 X130.812 Y90.986 E.01277
G1 X139.553 Y82.245 E.30069
G1 X139.552 Y81.72 E.01277
G1 X130.287 Y90.986 E.31873
G1 X129.762 Y90.986 E.01277
G1 X139.552 Y81.195 E.33679
G1 X139.552 Y80.67 E.01277
G1 X129.237 Y90.986 E.35485
G1 X128.712 Y90.986 E.01277
G1 X139.552 Y80.145 E.37291
G1 X139.531 Y79.642 E.01225
G1 X128.473 Y90.7 E.38039
G1 X128.456 Y90.192 E.01236
G1 X139.461 Y79.186 E.37858
G1 X139.349 Y78.773 E.01041
G1 X128.371 Y89.751 E.37764
G1 X128.234 Y89.364 E.00999
G1 X139.214 Y78.383 E.37772
G1 X139.032 Y78.041 E.00942
G1 X128.051 Y89.021 E.37772
G1 X127.836 Y88.711 E.00918
G1 X128.98 Y87.567 E.03935
G1 X128.208 Y87.814 E.01972
G1 X127.697 Y88.325 E.01758
G1 X127.564 Y87.933 E.01007
G1 X127.765 Y87.732 E.00691
G1 E-5 F3600
G1 X127.765 Y87.732 F9000
G1 X131.995 Y84.552
G1 E5 F2400
G1 F3072.127
G1 X138.842 Y77.705 E.23553
G1 X138.605 Y77.417 E.00907
G1 X132.556 Y83.466 E.20808
G1 X132.676 Y82.821 E.01596
G1 X138.366 Y77.131 E.19573
G1 X138.079 Y76.893 E.00907
G1 X132.726 Y82.245 E.18412
G1 X132.728 Y81.719 E.01279
G1 X137.793 Y76.654 E.17423
G1 X137.467 Y76.454 E.0093
G1 X132.73 Y81.192 E.16297
G1 X132.731 Y80.666 E.01279
G1 X137.109 Y76.287 E.15062
G1 X136.734 Y76.137 E.00982
G1 X132.733 Y80.139 E.13765
G1 X132.734 Y79.612 E.01282
G1 X136.317 Y76.03 E.12324
G1 X135.861 Y75.961 E.01122
G1 X133.255 Y78.567 E.08964
G1 X133.4 Y78.187 E.00989
G1 X133.46 Y77.837 E.00864
G1 X135.351 Y75.945 E.06507
G1 X134.827 Y75.945 E.01275
G1 X133.461 Y77.31 E.04697
G1 X133.398 Y76.849 E.01132
G1 X134.303 Y75.944 E.03113
G1 X133.778 Y75.943 E.01277
G1 X133.263 Y76.459 E.01773
G1 X133.097 Y76.099 E.00964
G1 X133.418 Y75.778 E.01104
G1 E-5 F3600
G1 X133.418 Y75.778 F9000
G1 X140.13 Y92.978
G1 X140.197 Y93.152
G1 X140.218 Y93.248
G1 X140.238 Y93.344
G1 X140.249 Y93.514
G1 X140.249 Y95.314
G1 X140.238 Y95.484
G1 X137.018 Y133.39
G1 X136.986 Y133.743
G1 X136.97 Y133.879
G1 X136.921 Y134.23
G1 X136.9 Y134.364
G1 X136.831 Y134.733
G1 X136.82 Y134.784
G1 X136.812 Y134.82
G1 X136.803 Y134.863
G1 X136.791 Y134.915
G1 X136.732 Y135.162
G1 X136.721 Y135.209
G1 X136.705 Y135.269
G1 X136.686 Y135.34
G1 X136.663 Y135.423
G1 X136.614 Y135.595
G1 X136.591 Y135.672
G1 X136.564 Y135.761
G1 X136.533 Y135.858
G1 X136.5 Y135.956
G1 X136.46 Y136.073
G1 X136.427 Y136.169
G1 X136.391 Y136.265
G1 X136.356 Y136.359
G1 X136.309 Y136.477
G1 X136.272 Y136.573
G1 X136.234 Y136.665
G1 X136.198 Y136.749
G1 X136.167 Y136.82
G1 X136.091 Y136.99
G1 X136.056 Y137.066
G1 X136.025 Y137.132
G1 X135.999 Y137.187
G1 X135.977 Y137.23
G1 X135.862 Y137.46
G1 X135.837 Y137.508
G1 X135.816 Y137.548
G1 X135.799 Y137.581
G1 X135.784 Y137.608
G1 X135.764 Y137.644
G1 X135.598 Y137.937
G1 X135.539 Y138.037
G1 X135.361 Y138.321
G1 X135.298 Y138.42
G1 X135.226 Y138.525
G1 X135.042 Y138.79
G1 X134.963 Y138.897
G1 X134.77 Y139.147
G1 X134.686 Y139.254
G1 X134.485 Y139.491
G1 X134.396 Y139.595
G1 X134.299 Y139.701
G1 X134.092 Y139.923
G1 X133.99 Y140.027
G1 X133.773 Y140.24
G1 X133.637 Y140.367
G1 X133.409 Y140.57
G1 X133.268 Y140.691
G1 X133.03 Y140.883
G1 X132.884 Y140.997
G1 X132.637 Y141.178
G1 X132.486 Y141.286
G1 X132.231 Y141.455
G1 X132.075 Y141.555
G1 X131.812 Y141.712
G1 X131.652 Y141.805
G1 X131.345 Y141.97
G1 X131.302 Y141.993
G1 X131.257 Y142.015
G1 X131.211 Y142.038
G1 X130.909 Y142.183
G1 X130.865 Y142.203
G1 X130.819 Y142.224
G1 X130.771 Y142.245
G1 X130.713 Y142.27
G1 X130.485 Y142.366
G1 X130.43 Y142.389
G1 X130.297 Y142.442
G1 X129.969 Y142.562
G1 X129.792 Y142.622
G1 X129.661 Y142.663
G1 X129.481 Y142.719
G1 X129.256 Y142.782
G1 X129.194 Y142.798
G1 X128.965 Y142.857
G1 X128.699 Y142.918
G1 X128.426 Y142.975
G1 X128.158 Y143.025
G1 X127.883 Y143.068
G1 X127.61 Y143.104
G1 X127.333 Y143.133
G1 X127.056 Y143.154
G1 X111.602 Y144.163
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.428734
G1 F1200
G1 X119.398 Y144.163 E.20453
;LAYER_CHANGE
;Z:0.94
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;0.94
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X116.24 Y144.163 E-1.5
;WIPE_END
G1 Z.94 F9000
;AFTER_LAYER_CHANGE
;0.94
G1 Z.94
G1 X119.701 Y142.614
G1 X121.198 Y141.752
G1 X120.85 Y142.1
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X120.85 Y141.837 E.0064
G1 X120.798 Y141.71 E.00334
G1 X120.667 Y141.655 E.00346
G1 X110.333 Y141.655 E.25136
G1 X110.202 Y141.709 E.00345
G1 X110.15 Y141.837 E.00336
G1 X110.15 Y142.1 E.0064
G1 X104.338 Y142.089 E.14137
G1 X103.121 Y141.953 E.02979
G1 X102.507 Y141.828 E.01524
G1 X101.617 Y141.569 E.02255
G1 X100.912 Y141.294 E.01841
G1 X100.343 Y141.028 E.01528
G1 X99.152 Y140.309 E.03384
G1 X98.2 Y139.543 E.02972
G1 X97.751 Y139.109 E.01519
G1 X96.858 Y138.042 E.03384
G1 X96.206 Y137.009 E.02971
G1 X95.923 Y136.453 E.01518
G1 X95.424 Y135.153 E.03387
G1 X95.143 Y133.966 E.02967
G1 X95.021 Y132.948 E.02494
G1 X95.021 Y127.642 E.12906
G1 X94.999 Y127.607 E.00101
G1 X94.999 Y95.69 E.77635
G1 X94.926 Y95.543 E.00399
G1 X94.816 Y95.507 E.00282
G1 X92.846 Y95.507 E.04792
G1 X91.995 Y95.482 E.02071
G1 X91.851 Y95.39 E.00416
G1 X91.757 Y95.188 E.00542
G1 X91.75 Y93.803 E.03369
G1 X91.794 Y93.554 E.00615
G1 X91.911 Y93.372 E.00526
G1 X92.078 Y93.321 E.00425
G1 X104.927 Y93.321 E.31254
G1 X105 Y93.366 E.00209
G1 X105 Y98.274 E.11938
G1 X104.729 Y98.274 E.00659
G1 X104.599 Y98.328 E.00342
G1 X104.546 Y98.457 E.00339
G1 X104.546 Y103.792 E.12977
G1 X104.562 Y103.866 E.00184
G1 X104.729 Y103.974 E.00484
G1 X105 Y103.974 E.00659
G1 X105 Y136.13 E.78216
G1 X104.324 Y136.845 E.02393
G1 X104.129 Y137.17 E.00922
G1 X104.059 Y137.463 E.00733
G1 X104.107 Y137.773 E.00763
G1 X104.33 Y138.162 E.01091
G1 X105 Y138.867 E.02366
G1 X105.003 Y139.352 E.0118
G1 X105.094 Y139.477 E.00376
G1 X105.182 Y139.5 E.00221
G1 X125.817 Y139.5 E.50193
G1 X125.924 Y139.465 E.00274
G1 X125.993 Y139.368 E.0029
G1 X126 Y138.87 E.01211
G1 X126.651 Y138.185 E.02299
G1 X126.871 Y137.83 E.01016
G1 X126.941 Y137.537 E.00733
G1 X126.893 Y137.227 E.00763
G1 X126.67 Y136.838 E.01091
G1 X126 Y136.133 E.02366
G1 X126 Y103.974 E.78224
G1 X126.271 Y103.974 E.00659
G1 X126.414 Y103.906 E.00385
G1 X126.454 Y103.792 E.00294
G1 X126.454 Y98.457 E.12977
G1 X126.431 Y98.368 E.00224
G1 X126.271 Y98.274 E.00451
G1 X126 Y98.274 E.00659
G1 X126 Y93.393 E.11873
G1 X126.04 Y93.319 E.00205
G1 X138.15 Y93.321 E.29456
G1 X139.044 Y93.344 E.02175
G1 X139.201 Y93.497 E.00533
G1 X139.243 Y93.691 E.00483
G1 X139.216 Y95.274 E.03851
G1 X139.09 Y95.456 E.00538
G1 X138.922 Y95.507 E.00427
G1 X136.183 Y95.507 E.06662
G1 X136.074 Y95.543 E.00279
G1 X136 Y95.69 E.004
G1 X136 Y127.168 E.76567
G1 X135.978 Y127.642 E.01154
G1 X135.978 Y132.95 E.12911
G1 X135.924 Y133.507 E.01361
G1 X135.699 Y134.71 E.02977
G1 X135.429 Y135.595 E.02251
G1 X135.198 Y136.18 E.0153
G1 X134.872 Y136.864 E.01843
G1 X134.402 Y137.663 E.02255
G1 X134.04 Y138.177 E.01529
G1 X133.564 Y138.766 E.01842
G1 X132.92 Y139.433 E.02255
G1 X132.447 Y139.848 E.01531
G1 X131.847 Y140.31 E.01842
G1 X131.065 Y140.807 E.02254
G1 X130.508 Y141.1 E.01531
G1 X129.816 Y141.409 E.01843
G1 X128.939 Y141.709 E.02255
G1 X128.329 Y141.864 E.01531
G1 X127.586 Y142.001 E.01838
G1 X126.193 Y142.1 E.03397
G1 X120.91 Y142.1 E.1285
G1 X120.91 Y142.1 F9000
G1 X121.195 Y141.735
;TYPE:Perimeter
G1 F6000
G1 X121.174 Y141.735 E.00051
G1 X121.059 Y141.454 E.00739
G1 X120.667 Y141.289 E.01035
G1 X110.333 Y141.289 E.25136
G1 X110.238 Y141.297 E.00232
G1 X109.941 Y141.453 E.00816
G1 X109.827 Y141.734 E.00738
G1 X104.359 Y141.723 E.133
G1 X103.178 Y141.591 E.02891
G1 X102.595 Y141.473 E.01447
G1 X101.735 Y141.223 E.02178
G1 X101.055 Y140.957 E.01776
G1 X100.516 Y140.705 E.01447
G1 X99.362 Y140.009 E.03278
G1 X98.443 Y139.269 E.0287
G1 X98.019 Y138.86 E.01433
G1 X97.154 Y137.826 E.03279
G1 X96.524 Y136.828 E.02871
G1 X96.257 Y136.304 E.01431
G1 X95.774 Y135.045 E.0328
G1 X95.504 Y133.902 E.02857
G1 X95.386 Y132.926 E.02391
G1 X95.386 Y127.642 E.12853
G1 X95.365 Y127.574 E.00173
G1 X95.365 Y95.69 E.77555
G1 X95.322 Y95.479 E.00524
G1 X95.145 Y95.251 E.00702
G1 X94.816 Y95.141 E.00844
G1 X92.123 Y95.131 E.0655
G1 X92.139 Y93.687 E.03513
G1 X104.634 Y93.687 E.30393
G1 X104.634 Y97.948 E.10364
G1 X104.34 Y98.07 E.00774
G1 X104.25 Y98.19 E.00365
G1 X104.18 Y98.457 E.00671
G1 X104.18 Y103.792 E.12977
G1 X104.186 Y103.869 E.00188
G1 X104.302 Y104.136 E.00708
G1 X104.634 Y104.295 E.00895
G1 X104.634 Y135.976 E.77061
G1 X104.046 Y136.607 E.02098
G1 X103.781 Y137.051 E.01258
G1 X103.691 Y137.541 E.01212
G1 X103.768 Y137.918 E.00936
G1 X104.065 Y138.414 E.01406
G1 X104.634 Y139.013 E.0201
G1 X104.634 Y139.317 E.00739
G1 X104.689 Y139.555 E.00594
G1 X104.916 Y139.797 E.00807
G1 X105.182 Y139.866 E.00668
G1 X125.817 Y139.866 E.50193
G1 X125.912 Y139.857 E.00232
G1 X126.139 Y139.761 E.006
G1 X126.276 Y139.617 E.00483
G1 X126.344 Y139.469 E.00396
G1 X126.366 Y139.024 E.01084
G1 X126.575 Y138.818 E.00714
G1 X126.954 Y138.393 E.01385
G1 X127.228 Y137.929 E.01311
G1 X127.309 Y137.46 E.01158
G1 X127.209 Y137.027 E.01081
G1 X126.935 Y136.586 E.01263
G1 X126.366 Y135.987 E.0201
G1 X126.366 Y104.295 E.77088
G1 X126.698 Y104.136 E.00895
G1 X126.772 Y104.016 E.00343
G1 X126.82 Y103.792 E.00557
G1 X126.82 Y98.457 E.12977
G1 X126.799 Y98.309 E.00364
G1 X126.66 Y98.07 E.00673
G1 X126.366 Y97.948 E.00774
G1 X126.366 Y93.685 E.10369
G1 X138.874 Y93.691 E.30424
G1 X138.868 Y95.141 E.03527
G1 X136.183 Y95.141 E.06531
G1 X135.854 Y95.251 E.00844
G1 X135.677 Y95.479 E.00702
G1 X135.635 Y95.69 E.00523
G1 X135.634 Y127.168 E.76567
G1 X135.613 Y127.642 E.01154
G1 X135.613 Y132.932 E.12867
G1 X135.562 Y133.455 E.01278
G1 X135.343 Y134.623 E.02891
G1 X135.084 Y135.474 E.02164
G1 X134.862 Y136.034 E.01465
G1 X134.549 Y136.692 E.01772
G1 X134.095 Y137.464 E.02178
G1 X133.748 Y137.957 E.01466
G1 X133.29 Y138.524 E.01773
G1 X132.667 Y139.168 E.02179
G1 X132.215 Y139.566 E.01465
G1 X131.637 Y140.01 E.01773
G1 X130.881 Y140.491 E.0218
G1 X130.348 Y140.771 E.01464
G1 X129.682 Y141.068 E.01774
G1 X128.835 Y141.359 E.02178
G1 X128.251 Y141.506 E.01465
G1 X127.54 Y141.638 E.01759
G1 X126.18 Y141.735 E.03316
G1 X121.255 Y141.735 E.1198
G1 X121.255 Y141.735 F9000
G1 X121.287 Y141.184
G1 F6000
G1 X120.667 Y140.923 E.01636
G1 X110.333 Y140.923 E.25136
G1 X110.175 Y140.937 E.00386
G1 X109.681 Y141.197 E.01358
G1 X109.611 Y141.368 E.00449
G1 X104.379 Y141.358 E.12726
G1 X103.235 Y141.23 E.028
G1 X102.682 Y141.118 E.01372
G1 X101.853 Y140.876 E.02101
G1 X101.199 Y140.621 E.01707
G1 X100.688 Y140.382 E.01372
G1 X99.572 Y139.709 E.0317
G1 X98.685 Y138.994 E.02771
G1 X98.287 Y138.61 E.01345
G1 X97.45 Y137.61 E.03172
G1 X96.843 Y136.647 E.02769
G1 X96.592 Y136.155 E.01343
G1 X96.125 Y134.937 E.03173
G1 X95.864 Y133.838 E.02748
G1 X95.752 Y132.904 E.02288
G1 X95.752 Y127.642 E.12799
G1 X95.73 Y127.542 E.00249
G1 X95.73 Y95.69 E.77477
G1 X95.66 Y95.338 E.00873
G1 X95.365 Y94.958 E.0117
G1 X94.816 Y94.776 E.01407
G1 X92.487 Y94.776 E.05665
G1 X92.483 Y94.053 E.01759
G1 X104.269 Y94.052 E.28668
G1 X104.269 Y97.734 E.08956
G1 X104.081 Y97.812 E.00495
G1 X103.931 Y98.011 E.00606
G1 X103.848 Y98.211 E.00527
G1 X103.815 Y98.457 E.00604
G1 X103.815 Y103.792 E.12977
G1 X103.851 Y104.047 E.00626
G1 X104.017 Y104.365 E.00873
G1 X104.269 Y104.485 E.00679
G1 X104.269 Y135.823 E.76227
G1 X103.768 Y136.369 E.01802
G1 X103.557 Y136.699 E.00953
G1 X103.391 Y137.08 E.01011
G1 X103.326 Y137.568 E.01197
G1 X103.391 Y137.92 E.00871
G1 X103.499 Y138.201 E.00732
G1 X103.8 Y138.666 E.01347
G1 X104.269 Y139.159 E.01655
G1 X104.269 Y139.317 E.00384
G1 X104.359 Y139.714 E.0099
G1 X104.739 Y140.116 E.01346
G1 X105.181 Y140.231 E.01111
G1 X125.817 Y140.231 E.50195
G1 X125.975 Y140.218 E.00386
G1 X126.354 Y140.057 E.01002
G1 X126.582 Y139.818 E.00803
G1 X126.695 Y139.571 E.00661
G1 X126.731 Y139.177 E.00962
G1 X126.965 Y138.942 E.00807
G1 X127.324 Y138.501 E.01383
G1 X127.57 Y138.057 E.01235
G1 X127.674 Y137.57 E.01211
G1 X127.609 Y137.08 E.01202
G1 X127.501 Y136.799 E.00732
G1 X127.2 Y136.334 E.01347
G1 X126.731 Y135.841 E.01655
G1 X126.731 Y104.485 E.7627
G1 X126.983 Y104.365 E.00679
G1 X127.105 Y104.166 E.00568
G1 X127.185 Y103.792 E.0093
G1 X127.185 Y98.457 E.12977
G1 X127.183 Y98.391 E.00161
G1 X127.069 Y98.011 E.00965
G1 X126.919 Y97.812 E.00606
G1 X126.731 Y97.734 E.00495
G1 X126.731 Y94.051 E.08959
G1 X138.512 Y94.053 E.28656
G1 X138.512 Y94.776 E.01759
G1 X136.183 Y94.776 E.05665
G1 X136.025 Y94.789 E.00386
G1 X135.635 Y94.958 E.01034
G1 X135.339 Y95.338 E.01172
G1 X135.269 Y95.69 E.00873
G1 X135.269 Y127.168 E.76567
G1 X135.247 Y127.642 E.01154
G1 X135.247 Y132.709 E.12325
G1 X135.2 Y133.404 E.01694
G1 X134.987 Y134.535 E.02799
G1 X134.738 Y135.353 E.0208
G1 X134.527 Y135.888 E.01399
G1 X134.226 Y136.52 E.01703
G1 X133.787 Y137.266 E.02105
G1 X133.456 Y137.736 E.01398
G1 X133.015 Y138.281 E.01705
G1 X132.415 Y138.903 E.02102
G1 X131.983 Y139.283 E.01399
G1 X131.427 Y139.71 E.01705
G1 X130.697 Y140.174 E.02104
G1 X130.189 Y140.442 E.01397
G1 X129.548 Y140.727 E.01706
G1 X128.731 Y141.008 E.02102
G1 X128.173 Y141.149 E.014
G1 X127.494 Y141.275 E.0168
G1 X126.167 Y141.369 E.03236
G1 X121.39 Y141.369 E.1162
G1 X121.329 Y141.22 E.00392
G1 E-5 F3600
G1 X121.329 Y141.22 F9000
G1 X110.113 Y140.587
G1 E5 F2400
;WIDTH:0.37974
G1 F6000
G1 X110.333 Y140.577 E.00506
;WIDTH:0.360642
G1 X120.667 Y140.577 E.22431
G1 E-5 F3600
G1 X120.667 Y140.577 F9000
G1 X120.667 Y139.849
G1 X104.651 Y139.849
G1 X103.792 Y137.933
G1 X103.745 Y137.793
G1 X103.715 Y137.648
G1 X103.705 Y137.5
G1 X103.903 Y124.423
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X103.903 Y135.67 E.27357
G1 X103.491 Y136.132 E.01506
G1 X103.184 Y136.613 E.01388
G1 X103.032 Y137.007 E.01027
G1 X102.961 Y137.596 E.01443
G1 X103.032 Y137.993 E.00981
G1 X103.184 Y138.387 E.01027
G1 X103.535 Y138.918 E.01548
G1 X103.895 Y139.296 E.0127
G1 X103.926 Y139.561 E.00649
G1 X104.03 Y139.873 E.008
G1 X104.561 Y140.436 E.01882
;WIDTH:0.4155
G1 X105.183 Y140.605 E.01634
;WIDTH:0.419288
G1 X109.275 Y140.607 E.10478
G1 X110.113 Y140.587 E.02146
G1 X109.413 Y140.934 E.02001
G1 X109.389 Y140.992 E.00161
G1 X105.182 Y140.986 E.10773
;WIDTH:0.4155
G1 X104.4 Y140.992 E.01983
;WIDTH:0.399999
G1 X103.292 Y140.868 E.02712
G1 X102.77 Y140.762 E.01296
G1 X101.971 Y140.529 E.02024
G1 X101.343 Y140.285 E.01639
G1 X100.86 Y140.059 E.01297
G1 X99.782 Y139.408 E.03063
G1 X98.927 Y138.72 E.02669
G1 X98.555 Y138.361 E.01257
G1 X97.747 Y137.395 E.03063
G1 X97.161 Y136.466 E.02672
G1 X96.926 Y136.006 E.01256
G1 X96.475 Y134.829 E.03066
G1 X96.225 Y133.774 E.02637
G1 X96.118 Y132.882 E.02185
G1 X96.118 Y127.642 E.12746
G1 X96.096 Y127.51 E.00326
G1 X96.096 Y95.69 E.77399
G1 X95.998 Y95.198 E.0122
G1 X95.584 Y94.666 E.0164
G1 X94.816 Y94.414 E.01966
G1 X103.903 Y94.418 E.22103
G1 X103.903 Y97.52 E.07545
G1 X103.822 Y97.554 E.00214
G1 X103.611 Y97.833 E.00851
G1 X103.496 Y98.112 E.00734
G1 X103.449 Y98.457 E.00847
G1 X103.449 Y103.792 E.12977
G1 X103.5 Y104.149 E.00877
G1 X103.732 Y104.594 E.01221
G1 X103.903 Y104.676 E.00461
G1 X103.903 Y124.363 E.47887
G1 E-5 F3600
G1 X103.903 Y124.363 F9000
G1 X103.537 Y135.52
G1 E5 F2400
G1 F6000
G1 X103.012 Y136.184 E.02059
G1 X102.769 Y136.625 E.01225
G1 X102.654 Y137.033 E.01031
G1 X102.597 Y137.623 E.01442
G1 X102.733 Y138.279 E.0163
G1 X103.076 Y138.922 E.01773
G1 X103.552 Y139.466 E.01758
G1 X103.567 Y139.63 E.00401
G1 X103.701 Y140.032 E.01031
G1 X104.243 Y140.607 E.01922
G1 X103.349 Y140.507 E.02188
G1 X102.858 Y140.407 E.01219
G1 X102.088 Y140.183 E.01951
G1 X101.487 Y139.948 E.0157
G1 X101.033 Y139.736 E.01219
G1 X99.993 Y139.108 E.02955
G1 X99.243 Y138.505 E.02341
G1 X98.823 Y138.111 E.01401
G1 X98.043 Y137.179 E.02956
G1 X97.556 Y136.407 E.0222
G1 X97.261 Y135.857 E.01518
G1 X96.825 Y134.721 E.0296
G1 X96.585 Y133.71 E.02527
G1 X96.483 Y132.86 E.02082
G1 X96.483 Y127.642 E.12692
G1 X96.462 Y127.478 E.00402
G1 X96.462 Y95.69 E.77321
G1 X96.335 Y95.057 E.0157
G1 X96.123 Y94.784 E.00841
G1 X103.537 Y94.784 E.18034
G1 X103.537 Y97.33 E.06193
G1 X103.292 Y97.655 E.0099
G1 X103.144 Y98.014 E.00945
G1 X103.083 Y98.457 E.01088
G1 X103.083 Y103.792 E.12977
G1 X103.1 Y104.025 E.00568
G1 X103.227 Y104.465 E.01114
G1 X103.447 Y104.824 E.01024
G1 X103.537 Y104.867 E.00243
G1 X103.537 Y135.46 E.74414
G1 E-5 F3600
G1 X103.537 Y135.46 F9000
G1 X95.348 Y95.158
G1 X92.846 Y94.414
G1 E5 F2400
;WIDTH:0.391736
G1 F6000
G1 X94.816 Y94.414 E.04684
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X92.846 Y94.414 E-.93575
;WIPE_END
G1 E-.56425 F3600
G1 X135.961 Y94.424 F9000
G1 E5 F2400
;WIDTH:0.411382
G1 F6000
G1 X136.183 Y94.414 E.00557
;WIDTH:0.39205
G1 X138.15 Y94.414 E.04681
G1 E-5 F3600
G1 X138.15 Y94.414 F9000
G1 X127.097 Y94.416
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X135.333 Y94.418 E.20033
;WIDTH:0.411382
G1 X135.961 Y94.424 E.01575
G1 X135.415 Y94.666 E.01498
;WIDTH:0.399999
G1 X135.002 Y95.198 E.01638
G1 X134.903 Y95.69 E.01221
G1 X134.903 Y127.168 E.76567
G1 X134.881 Y127.642 E.01154
G1 X134.881 Y132.709 E.12325
G1 X134.837 Y133.352 E.01568
G1 X134.631 Y134.448 E.02713
G1 X134.393 Y135.233 E.01995
G1 X134.191 Y135.742 E.01332
G1 X133.902 Y136.349 E.01635
G1 X133.479 Y137.068 E.02029
G1 X133.164 Y137.516 E.01332
G1 X132.741 Y138.039 E.01636
G1 X132.162 Y138.639 E.02028
G1 X131.751 Y139 E.01331
G1 X131.217 Y139.41 E.01638
G1 X130.514 Y139.858 E.02028
G1 X130.029 Y140.113 E.01333
G1 X129.414 Y140.387 E.01638
G1 X128.626 Y140.657 E.02026
G1 X128.095 Y140.791 E.01332
G1 X127.447 Y140.911 E.01603
G1 X126.788 Y140.958 E.01607
;WIDTH:0.420285
G1 X125.817 Y140.993 E.02495
G1 X121.613 Y140.993 E.10793
G1 X121.589 Y140.935 E.00161
G1 X121.128 Y140.756 E.0127
;WIDTH:0.390463
G1 X120.667 Y140.577 E.01172
G1 X121.197 Y140.592 E.01256
;WIDTH:0.420284
G1 X121.727 Y140.607 E.01361
G1 X125.817 Y140.607 E.105
;WIDTH:0.42589
G1 X126.101 Y140.578 E.00744
G1 X126.568 Y140.353 E.0135
;WIDTH:0.399999
G1 X126.888 Y140.018 E.01127
G1 X127.047 Y139.672 E.00926
G1 X127.096 Y139.331 E.00838
G1 X127.291 Y139.124 E.00692
G1 X127.639 Y138.687 E.01359
G1 X127.912 Y138.185 E.0139
G1 X128.016 Y137.757 E.01071
G1 X128.039 Y137.407 E.00853
G1 X127.968 Y137.007 E.00988
G1 X127.816 Y136.613 E.01027
G1 X127.465 Y136.082 E.01548
G1 X127.097 Y135.695 E.01299
G1 X127.097 Y104.676 E.75451
G1 X127.268 Y104.594 E.00461
G1 X127.5 Y104.149 E.01221
G1 X127.551 Y103.792 E.00877
G1 X127.551 Y98.457 E.12977
G1 X127.504 Y98.112 E.00847
G1 X127.389 Y97.833 E.00734
G1 X127.178 Y97.554 E.00851
G1 X127.097 Y97.52 E.00214
G1 X127.097 Y94.476 E.07404
G1 X127.097 Y94.476 F9000
G1 X127.463 Y94.782
G1 F6000
G1 X134.877 Y94.783 E.18034
G1 X134.664 Y95.057 E.00844
G1 X134.538 Y95.69 E.0157
G1 X134.537 Y127.168 E.76567
G1 X134.516 Y127.642 E.01154
G1 X134.516 Y132.709 E.12325
G1 X134.475 Y133.301 E.01443
G1 X134.276 Y134.361 E.02623
G1 X134.047 Y135.112 E.0191
G1 X133.856 Y135.596 E.01266
G1 X133.579 Y136.177 E.01566
G1 X133.172 Y136.87 E.01955
G1 X132.872 Y137.295 E.01265
G1 X132.467 Y137.796 E.01567
G1 X131.909 Y138.374 E.01954
G1 X131.518 Y138.718 E.01267
G1 X131.007 Y139.11 E.01567
G1 X130.33 Y139.541 E.01952
G1 X129.869 Y139.784 E.01268
G1 X129.28 Y140.046 E.01568
G1 X128.522 Y140.306 E.01949
G1 X128.017 Y140.434 E.01267
G1 X127.401 Y140.548 E.01524
G1 X126.842 Y140.588 E.01363
G1 X127.194 Y140.218 E.01242
G1 X127.398 Y139.774 E.01189
G1 X127.449 Y139.531 E.00604
G1 X127.954 Y138.873 E.02018
G1 X128.255 Y138.314 E.01544
G1 X128.374 Y137.83 E.01212
G1 X128.403 Y137.381 E.01094
G1 X128.326 Y136.933 E.01106
G1 X128.198 Y136.554 E.00973
G1 X127.943 Y136.109 E.01248
G1 X127.463 Y135.549 E.01794
G1 X127.463 Y104.867 E.74631
G1 X127.553 Y104.824 E.00243
G1 X127.773 Y104.465 E.01024
G1 X127.851 Y104.252 E.00552
G1 X127.917 Y103.792 E.0113
G1 X127.917 Y98.457 E.12977
G1 X127.856 Y98.014 E.01088
G1 X127.708 Y97.655 E.00945
G1 X127.463 Y97.33 E.0099
G1 X127.463 Y94.842 E.06052
G1 E-5 F3600
G1 X127.463 Y94.842 F9000
G1 X134.471 Y95.501
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X134.027 Y95.057 E.01527
G1 X133.507 Y95.057 E.01265
G1 X134.264 Y95.814 E.02604
G1 X134.264 Y96.334 E.01265
G1 X132.986 Y95.057 E.04395
G1 X132.466 Y95.057 E.01265
G1 X134.264 Y96.855 E.06185
G1 X134.264 Y97.375 E.01265
G1 X131.946 Y95.057 E.07974
G1 X131.425 Y95.057 E.01267
G1 X134.264 Y97.895 E.09764
G1 X134.264 Y98.416 E.01267
G1 X130.905 Y95.057 E.11555
G1 X130.385 Y95.057 E.01265
G1 X134.264 Y98.936 E.13344
G1 X134.264 Y99.456 E.01265
G1 X129.864 Y95.057 E.15134
G1 X129.344 Y95.057 E.01265
G1 X134.264 Y99.976 E.16923
G1 X134.263 Y100.497 E.01267
G1 X128.824 Y95.057 E.18712
G1 X128.303 Y95.056 E.01267
G1 X134.263 Y101.017 E.20504
G1 X134.263 Y101.537 E.01265
G1 X127.737 Y95.056 E.22372
G1 X127.737 Y95.531 E.01155
G1 X134.263 Y102.057 E.22449
G1 X134.263 Y102.578 E.01267
G1 X127.737 Y96.051 E.22451
G1 X127.737 Y96.571 E.01265
G1 X134.263 Y103.098 E.22451
G1 X134.263 Y103.618 E.01265
G1 X127.737 Y97.092 E.22449
G1 X127.737 Y97.241 E.00362
G1 X127.947 Y97.52 E.00849
G1 X128.132 Y98.007 E.01267
G1 X134.263 Y104.138 E.2109
G1 X134.263 Y104.659 E.01267
G1 X128.191 Y98.586 E.20889
G1 X128.191 Y99.106 E.01265
G1 X134.263 Y105.179 E.20889
G1 X134.263 Y105.699 E.01265
G1 X128.191 Y99.627 E.20887
G1 X128.191 Y100.147 E.01265
G1 X134.263 Y106.219 E.20887
G1 X134.263 Y106.74 E.01267
G1 X128.191 Y100.667 E.20889
G1 X128.191 Y101.188 E.01267
G1 X134.263 Y107.26 E.20887
G1 X134.263 Y107.78 E.01265
G1 X128.191 Y101.708 E.20887
G1 X128.191 Y102.228 E.01265
G1 X134.263 Y108.301 E.20889
G1 X134.263 Y108.821 E.01265
G1 X128.191 Y102.748 E.20889
G1 X128.191 Y103.269 E.01267
G1 X134.263 Y109.341 E.20887
G1 X134.263 Y109.861 E.01265
G1 X128.191 Y103.789 E.20887
G1 X128.133 Y104.251 E.01133
G1 X134.263 Y110.382 E.21089
G1 X134.263 Y110.902 E.01265
G1 X127.991 Y104.63 E.21575
G1 X127.794 Y104.952 E.00918
G1 X134.263 Y111.422 E.22255
G1 X134.263 Y111.942 E.01265
G1 X127.737 Y105.416 E.22449
G1 X127.737 Y105.936 E.01265
G1 X134.263 Y112.463 E.22451
G1 X134.263 Y112.983 E.01265
G1 X127.737 Y106.456 E.22451
G1 X127.737 Y106.977 E.01267
G1 X134.263 Y113.503 E.22449
G1 X134.263 Y114.023 E.01265
G1 X127.737 Y107.497 E.22449
G1 X127.737 Y108.017 E.01265
G1 X134.263 Y114.544 E.22451
G1 X134.263 Y115.064 E.01265
G1 X127.737 Y108.538 E.22449
G1 X127.737 Y109.058 E.01265
G1 X134.263 Y115.584 E.22449
G1 X134.263 Y116.105 E.01267
G1 X127.737 Y109.578 E.22451
G1 X127.737 Y110.098 E.01265
G1 X134.263 Y116.625 E.22451
G1 X134.263 Y117.145 E.01265
G1 X127.737 Y110.619 E.22449
G1 X127.737 Y111.139 E.01265
G1 X134.263 Y117.665 E.22449
G1 X134.263 Y118.186 E.01267
G1 X127.737 Y111.659 E.22451
G1 X127.737 Y112.179 E.01265
G1 X134.263 Y118.706 E.22451
G1 X134.263 Y119.226 E.01265
G1 X127.737 Y112.7 E.22449
G1 X127.737 Y113.22 E.01265
G1 X134.263 Y119.746 E.22449
G1 X134.263 Y120.267 E.01267
G1 X127.737 Y113.74 E.22451
G1 X127.737 Y114.261 E.01267
G1 X134.263 Y120.787 E.22449
G1 X134.263 Y121.307 E.01265
G1 X127.737 Y114.781 E.22449
G1 X127.737 Y115.301 E.01265
G1 X134.263 Y121.827 E.22449
G1 X134.263 Y122.348 E.01267
G1 X127.737 Y115.821 E.22451
G1 X127.737 Y116.342 E.01267
G1 X134.263 Y122.868 E.22449
G1 X134.263 Y123.388 E.01265
G1 X127.737 Y116.862 E.22449
G1 X127.737 Y117.382 E.01265
G1 X134.263 Y123.908 E.22449
G1 X134.263 Y124.429 E.01267
G1 X127.737 Y117.902 E.22451
G1 X127.737 Y118.423 E.01267
G1 X134.263 Y124.949 E.22449
G1 X134.263 Y125.469 E.01265
G1 X127.737 Y118.943 E.22449
G1 X127.737 Y119.463 E.01265
G1 X134.263 Y125.99 E.22451
G1 X134.263 Y126.51 E.01265
G1 X127.737 Y119.984 E.22449
G1 X127.737 Y120.504 E.01265
G1 X134.263 Y127.03 E.22449
G1 X134.253 Y127.54 E.01241
G1 X127.737 Y121.024 E.22415
G1 X127.737 Y121.544 E.01265
G1 X134.241 Y128.049 E.22375
G1 X134.241 Y128.569 E.01265
G1 X127.737 Y122.065 E.22373
G1 X127.737 Y122.585 E.01265
G1 X134.241 Y129.089 E.22373
G1 X134.241 Y129.61 E.01267
G1 X127.737 Y123.105 E.22375
G1 X127.737 Y123.625 E.01265
G1 X134.241 Y130.13 E.22375
G1 X134.241 Y130.65 E.01265
G1 X127.737 Y124.146 E.22373
G1 X127.737 Y124.666 E.01265
G1 X134.241 Y131.17 E.22373
G1 X134.241 Y131.691 E.01267
G1 X127.737 Y125.186 E.22375
G1 X127.737 Y125.707 E.01267
G1 X134.241 Y132.211 E.22373
G1 X134.241 Y132.731 E.01265
G1 X127.737 Y126.227 E.22373
G1 X127.737 Y126.747 E.01265
G1 X134.207 Y133.217 E.22256
G1 X134.129 Y133.659 E.01092
G1 X127.737 Y127.267 E.21988
G1 X127.737 Y127.788 E.01267
G1 X134.046 Y134.097 E.21703
G1 X133.943 Y134.514 E.01045
G1 X127.737 Y128.308 E.21348
G1 X127.737 Y128.828 E.01265
G1 X133.821 Y134.913 E.2093
G1 X133.681 Y135.293 E.00985
G1 X127.737 Y129.348 E.20449
G1 X127.737 Y129.869 E.01267
G1 X133.524 Y135.656 E.19907
G1 X133.356 Y136.008 E.00949
G1 X127.737 Y130.389 E.19329
G1 X127.737 Y130.909 E.01265
G1 X133.166 Y136.338 E.18675
G1 X132.973 Y136.666 E.00926
G1 X127.737 Y131.43 E.18012
G1 X127.737 Y131.95 E.01265
G1 X132.762 Y136.975 E.17286
G1 X132.539 Y137.272 E.00903
G1 X127.737 Y132.47 E.16519
G1 X127.737 Y132.99 E.01265
G1 X132.306 Y137.559 E.15717
G1 X132.055 Y137.829 E.00897
G1 X127.737 Y133.511 E.14854
G1 X127.737 Y134.031 E.01265
G1 X131.799 Y138.093 E.13973
G1 X131.529 Y138.343 E.00895
G1 X127.737 Y134.551 E.13044
G1 X127.737 Y135.071 E.01265
G1 X131.246 Y138.581 E.12072
G1 X130.952 Y138.807 E.00902
G1 X128.272 Y136.127 E.09219
G1 X128.5 Y136.56 E.0119
G1 X128.615 Y136.991 E.01085
G1 X130.642 Y139.017 E.06971
G1 X130.324 Y139.22 E.00918
G1 X128.677 Y137.572 E.05667
G1 X128.611 Y138.026 E.01116
G1 X129.993 Y139.409 E.04756
G1 X129.647 Y139.583 E.00942
G1 X128.5 Y138.436 E.03946
G1 X128.326 Y138.782 E.00942
G1 X129.287 Y139.743 E.03306
G1 X128.907 Y139.884 E.00986
G1 X128.126 Y139.103 E.02687
G1 X127.9 Y139.396 E.009
G1 X128.52 Y140.017 E.02134
G1 X128.11 Y140.127 E.01033
G1 X127.692 Y139.709 E.01438
G1 X127.552 Y140.09 E.00987
G1 X127.819 Y140.357 E.00918
G1 E-5 F3600
G1 X127.819 Y140.357 F9000
G1 X97.989 Y136.888
G1 E5 F2400
G1 F3072.127
G1 X99.351 Y138.24 E.04668
G1 X100.15 Y138.883 E.02495
G1 X101.039 Y139.42 E.02526
G1 X97.664 Y136.044 E.11612
G1 X97.28 Y135.142 E.02385
G1 X101.988 Y139.849 E.16194
G1 X102.746 Y140.089 E.01934
G1 X97.023 Y134.365 E.19688
G1 X96.861 Y133.685 E.017
G1 X103.414 Y140.238 E.22542
G1 X103.543 Y140.252 E.00316
G1 X103.456 Y140.16 E.00308
G1 X103.291 Y139.596 E.01429
G1 X96.788 Y133.093 E.2237
G1 X96.758 Y132.544 E.01337
G1 X102.432 Y138.218 E.19518
G1 X102.325 Y137.593 E.01542
G1 X96.758 Y132.025 E.19152
G1 X96.758 Y131.506 E.01262
G1 X102.359 Y137.108 E.19269
G1 X102.462 Y136.692 E.01042
G1 X96.758 Y130.988 E.19621
G1 X96.758 Y130.469 E.01262
G1 X102.62 Y136.331 E.20165
G1 X102.805 Y135.998 E.00927
G1 X96.758 Y129.95 E.20803
G1 X96.758 Y129.431 E.01262
G1 X103.022 Y135.695 E.21548
G1 X103.262 Y135.416 E.00895
G1 X96.758 Y128.912 E.22373
G1 X96.758 Y128.394 E.0126
G1 X103.263 Y134.899 E.22377
G1 X103.263 Y134.38 E.01262
G1 X96.758 Y127.875 E.22377
G1 X96.736 Y127.334 E.01317
G1 X103.263 Y133.862 E.22454
G1 X103.263 Y133.343 E.01262
G1 X96.736 Y126.815 E.22454
G1 X96.736 Y126.297 E.0126
G1 X103.263 Y132.824 E.22452
G1 X103.263 Y132.305 E.01262
G1 X96.736 Y125.778 E.22452
G1 X96.736 Y125.259 E.01262
G1 X103.263 Y131.786 E.22452
G1 X103.263 Y131.268 E.0126
G1 X96.736 Y124.74 E.22454
G1 X96.736 Y124.222 E.0126
G1 X103.263 Y130.749 E.22452
G1 X103.263 Y130.23 E.01262
G1 X96.736 Y123.703 E.22452
G1 X96.736 Y123.184 E.01262
G1 X103.263 Y129.711 E.22452
G1 X103.263 Y129.192 E.01262
G1 X96.736 Y122.665 E.22452
G1 X96.736 Y122.146 E.01262
G1 X103.263 Y128.674 E.22454
G1 X103.263 Y128.155 E.01262
G1 X96.736 Y121.628 E.22452
G1 X96.736 Y121.109 E.01262
G1 X103.263 Y127.636 E.22452
G1 X103.263 Y127.117 E.01262
G1 X96.736 Y120.59 E.22452
G1 X96.736 Y120.071 E.01262
G1 X103.263 Y126.598 E.22452
G1 X103.263 Y126.08 E.0126
G1 X96.736 Y119.552 E.22454
G1 X96.736 Y119.034 E.0126
G1 X103.263 Y125.561 E.22452
G1 X103.263 Y125.042 E.01262
G1 X96.736 Y118.515 E.22452
G1 X96.736 Y117.996 E.01262
G1 X103.263 Y124.523 E.22452
G1 X103.263 Y124.004 E.01262
G1 X96.736 Y117.477 E.22452
G1 X96.736 Y116.958 E.01262
G1 X103.263 Y123.486 E.22454
G1 X103.263 Y122.967 E.01262
G1 X96.736 Y116.44 E.22452
G1 X96.736 Y115.921 E.01262
G1 X103.263 Y122.448 E.22452
G1 X103.263 Y121.929 E.01262
G1 X96.736 Y115.402 E.22452
G1 X96.736 Y114.883 E.01262
G1 X103.263 Y121.41 E.22452
G1 X103.263 Y120.892 E.0126
G1 X96.736 Y114.364 E.22454
G1 X96.736 Y113.846 E.0126
G1 X103.263 Y120.373 E.22452
G1 X103.263 Y119.854 E.01262
G1 X96.736 Y113.327 E.22452
G1 X96.736 Y112.808 E.01262
G1 X103.263 Y119.335 E.22452
G1 X103.263 Y118.816 E.01262
G1 X96.736 Y112.289 E.22452
G1 X96.736 Y111.77 E.01262
G1 X103.263 Y118.298 E.22454
G1 X103.263 Y117.779 E.01262
G1 X96.736 Y111.252 E.22452
G1 X96.736 Y110.733 E.01262
G1 X103.263 Y117.26 E.22452
G1 X103.263 Y116.741 E.01262
G1 X96.736 Y110.214 E.22452
G1 X96.736 Y109.695 E.01262
G1 X103.263 Y116.222 E.22452
G1 X103.263 Y115.704 E.0126
G1 X96.736 Y109.176 E.22454
G1 X96.736 Y108.658 E.0126
G1 X103.263 Y115.185 E.22452
G1 X103.263 Y114.666 E.01262
G1 X96.736 Y108.139 E.22452
G1 X96.736 Y107.62 E.01262
G1 X103.263 Y114.147 E.22452
G1 X103.263 Y113.628 E.01262
G1 X96.736 Y107.101 E.22452
G1 X96.736 Y106.582 E.01262
G1 X103.263 Y113.11 E.22454
G1 X103.263 Y112.591 E.01262
G1 X96.736 Y106.064 E.22452
G1 X96.736 Y105.545 E.01262
G1 X103.263 Y112.072 E.22452
G1 X103.263 Y111.553 E.01262
G1 X96.736 Y105.026 E.22452
G1 X96.736 Y104.507 E.01262
G1 X103.263 Y111.034 E.22452
G1 X103.263 Y110.516 E.0126
G1 X96.736 Y103.988 E.22454
G1 X96.736 Y103.47 E.0126
G1 X103.263 Y109.997 E.22452
G1 X103.263 Y109.478 E.01262
G1 X96.736 Y102.951 E.22452
G1 X96.736 Y102.432 E.01262
G1 X103.263 Y108.959 E.22452
G1 X103.263 Y108.44 E.01262
G1 X96.736 Y101.913 E.22452
G1 X96.736 Y101.394 E.01262
G1 X103.263 Y107.922 E.22454
G1 X103.263 Y107.403 E.01262
G1 X96.736 Y100.876 E.22452
G1 X96.736 Y100.357 E.01262
G1 X103.263 Y106.884 E.22452
G1 X103.263 Y106.365 E.01262
G1 X96.736 Y99.838 E.22452
G1 X96.736 Y99.319 E.01262
G1 X103.263 Y105.846 E.22452
G1 X103.263 Y105.328 E.0126
G1 X96.736 Y98.8 E.22454
G1 X96.736 Y98.282 E.0126
G1 X102.945 Y104.491 E.21359
G1 X102.813 Y103.84 E.01616
G1 X96.736 Y97.763 E.20905
G1 X96.736 Y97.244 E.01262
G1 X102.809 Y103.318 E.20892
G1 X102.81 Y102.799 E.01262
G1 X96.736 Y96.725 E.20894
G1 X96.736 Y96.206 E.01262
G1 X102.81 Y102.281 E.20896
G1 X102.811 Y101.762 E.01262
G1 X96.736 Y95.688 E.20896
G1 X96.602 Y95.058 E.01567
G1 X102.811 Y101.244 E.21319
G1 X102.812 Y100.726 E.0126
G1 X97.144 Y95.058 E.19498
G1 X97.663 Y95.058 E.01262
G1 X102.812 Y100.207 E.17712
G1 X102.813 Y99.689 E.0126
G1 X98.182 Y95.058 E.1593
G1 X98.7 Y95.058 E.0126
G1 X102.813 Y99.171 E.14148
G1 X102.813 Y98.652 E.01262
G1 X99.219 Y95.058 E.12363
G1 X99.738 Y95.058 E.01262
G1 X102.841 Y98.161 E.10674
G1 X102.955 Y97.756 E.01023
G1 X100.257 Y95.058 E.09281
G1 X100.775 Y95.058 E.0126
G1 X103.132 Y97.415 E.08108
G1 X103.263 Y97.241 E.0053
G1 X103.263 Y97.027 E.00521
G1 X101.294 Y95.058 E.06773
G1 X101.813 Y95.058 E.01262
G1 X103.263 Y96.508 E.04988
G1 X103.263 Y95.989 E.01262
G1 X102.332 Y95.058 E.03203
G1 X102.851 Y95.058 E.01262
G1 X103.428 Y95.635 E.01985
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X102.851 Y95.058 E-.3876
G1 X102.332 Y95.058 E-.24652
G1 X103.263 Y95.989 E-.6254
G1 X103.263 Y96.495 E-.24048
;WIPE_END
G1 X104.204 Y97.926 F9000
G1 X105.507 Y99.908
G1 X111.538 Y109.276
G1 X111.819 Y109.51
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X112.019 Y109.266 E.00767
G1 X112.543 Y108.856 E.01618
G1 X112.949 Y108.671 E.01085
G1 X113.273 Y108.597 E.00808
G1 X113.902 Y108.532 E.01538
G1 X117.372 Y108.534 E.0844
G1 X117.955 Y108.639 E.01441
G1 X118.371 Y108.81 E.01094
G1 X118.899 Y109.182 E.01571
G1 X119.262 Y109.594 E.01336
G1 X121.102 Y112.766 E.0892
G1 X121.275 Y113.127 E.00974
G1 X121.386 Y113.521 E.00996
G1 X121.432 Y114.078 E.01359
G1 X121.377 Y114.522 E.01088
G1 X121.198 Y115.051 E.01358
G1 X119.263 Y118.406 E.09421
G1 X118.986 Y118.739 E.01054
G1 X118.487 Y119.119 E.01526
G1 X118.058 Y119.31 E.01142
G1 X117.767 Y119.411 E.00749
G1 X117.371 Y119.466 E.00972
G1 X113.721 Y119.47 E.08878
G1 X113.142 Y119.388 E.01422
G1 X112.582 Y119.166 E.01465
G1 X112.092 Y118.814 E.01468
G1 X111.685 Y118.328 E.01542
G1 X109.859 Y115.167 E.08879
G1 X109.646 Y114.62 E.01428
G1 X109.567 Y114.022 E.01467
G1 X109.601 Y113.584 E.01069
G1 X109.701 Y113.194 E.00979
G1 X109.859 Y112.833 E.00959
G1 X111.685 Y109.672 E.08879
G1 X111.781 Y109.556 E.00366
G1 X111.781 Y109.556 F9000
G1 X111.53 Y109.289
;TYPE:Perimeter
G1 F6000
G1 X111.738 Y109.032 E.00804
G1 X111.876 Y108.892 E.00478
G1 X112.327 Y108.561 E.01361
G1 X112.833 Y108.323 E.0136
G1 X113.192 Y108.24 E.00896
G1 X113.521 Y108.176 E.00815
G1 X113.902 Y108.166 E.00927
G1 X117.372 Y108.168 E.0844
G1 X118.021 Y108.279 E.01602
G1 X118.553 Y108.492 E.01394
G1 X119.11 Y108.883 E.01655
G1 X119.579 Y109.411 E.01718
G1 X121.418 Y112.583 E.08918
G1 X121.625 Y113.024 E.01185
G1 X121.751 Y113.491 E.01177
G1 X121.796 Y114.049 E.01362
G1 X121.744 Y114.558 E.01245
G1 X121.5 Y115.267 E.01824
G1 X119.579 Y118.589 E.09334
G1 X119.248 Y118.995 E.01274
G1 X118.871 Y119.313 E.012
G1 X118.453 Y119.556 E.01176
G1 X117.928 Y119.746 E.01358
G1 X117.42 Y119.83 E.01252
G1 X113.721 Y119.835 E.08997
G1 X113.09 Y119.75 E.01549
G1 X112.444 Y119.504 E.01681
G1 X111.876 Y119.108 E.01684
G1 X111.422 Y118.588 E.01679
G1 X109.542 Y115.35 E.09107
G1 X109.305 Y114.752 E.01565
G1 X109.204 Y114.067 E.01684
G1 X109.247 Y113.495 E.01395
G1 X109.366 Y113.049 E.01123
G1 X109.542 Y112.65 E.01061
G1 X111.369 Y109.489 E.08881
G1 X111.493 Y109.336 E.00479
G1 X111.493 Y109.336 F9000
G1 X111.242 Y109.068
G1 F6000
G1 X111.457 Y108.798 E.0084
G1 X111.66 Y108.597 E.00695
G1 X112.111 Y108.266 E.01361
G1 X112.61 Y108.017 E.01356
G1 X113.11 Y107.884 E.01258
G1 X113.511 Y107.811 E.00991
G1 X113.903 Y107.801 E.00954
G1 X117.373 Y107.803 E.0844
G1 X118.088 Y107.92 E.01762
G1 X118.599 Y108.108 E.01324
G1 X119.082 Y108.416 E.01393
G1 X119.482 Y108.729 E.01235
G1 X119.895 Y109.227 E.01574
G1 X121.734 Y112.399 E.08918
G1 X121.976 Y112.921 E.014
G1 X122.115 Y113.462 E.01359
G1 X122.161 Y114.019 E.01359
G1 X122.112 Y114.575 E.01358
G1 X121.891 Y115.285 E.01809
G1 X121.816 Y115.45 E.00441
G1 X119.896 Y118.772 E.09333
G1 X119.569 Y119.185 E.01281
G1 X119.183 Y119.536 E.01269
G1 X118.745 Y119.819 E.01268
G1 X118.052 Y120.09 E.0181
G1 X117.372 Y120.197 E.01674
G1 X113.722 Y120.201 E.08878
G1 X113.038 Y120.112 E.01678
G1 X112.306 Y119.843 E.01897
G1 X111.66 Y119.403 E.01901
G1 X111.141 Y118.821 E.01897
G1 X111.052 Y118.694 E.00377
G1 X109.226 Y115.533 E.08879
G1 X108.964 Y114.883 E.01705
G1 X108.841 Y114.112 E.01899
G1 X108.868 Y113.554 E.01359
G1 X108.982 Y113.045 E.01269
G1 X109.225 Y112.467 E.01525
G1 X111.052 Y109.306 E.08881
G1 X111.204 Y109.115 E.00594
G1 X111.204 Y109.115 F9000
G1 X110.953 Y108.847
G1 F6000
G1 X111.176 Y108.564 E.00876
G1 X111.444 Y108.302 E.00912
G1 X111.895 Y107.971 E.01361
G1 X112.458 Y107.685 E.01536
G1 X113.029 Y107.527 E.01441
G1 X113.501 Y107.445 E.01165
G1 X113.903 Y107.435 E.00978
G1 X117.373 Y107.437 E.0844
G1 X117.903 Y107.514 E.01303
G1 X118.405 Y107.634 E.01255
G1 X118.936 Y107.869 E.01412
G1 X119.531 Y108.285 E.01766
G1 X119.87 Y108.617 E.01154
G1 X120.211 Y109.044 E.01329
G1 X122.051 Y112.216 E.0892
G1 X122.327 Y112.818 E.01611
G1 X122.48 Y113.432 E.01539
G1 X122.525 Y113.989 E.01359
G1 X122.474 Y114.619 E.01537
G1 X122.237 Y115.403 E.01992
G1 X122.133 Y115.633 E.00614
G1 X120.212 Y118.955 E.09334
G1 X119.85 Y119.419 E.01431
G1 X119.422 Y119.812 E.01413
G1 X118.936 Y120.131 E.01414
G1 X118.431 Y120.342 E.01331
G1 X117.923 Y120.497 E.01292
G1 X117.373 Y120.563 E.01347
G1 X113.722 Y120.567 E.08881
G1 X113.21 Y120.507 E.01254
G1 X112.685 Y120.392 E.01307
G1 X112.168 Y120.181 E.01358
G1 X111.895 Y120.029 E.0076
G1 X111.444 Y119.698 E.01361
G1 X111.176 Y119.436 E.00912
G1 X110.736 Y118.877 E.0173
G1 X108.909 Y115.716 E.08881
G1 X108.622 Y115.014 E.01845
G1 X108.546 Y114.711 E.0076
G1 X108.478 Y114.156 E.0136
G1 X108.503 Y113.524 E.01538
G1 X108.628 Y112.956 E.01415
G1 X108.909 Y112.284 E.01772
G1 X110.736 Y109.123 E.08881
G1 X110.916 Y108.895 E.00707
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X110.953 Y108.847 E-.02879
G1 X111.176 Y108.564 E-.17114
G1 X111.444 Y108.302 E-.17803
G1 X111.895 Y107.971 E-.26573
G1 X112.458 Y107.685 E-.29995
G1 X113.029 Y107.527 E-.28142
G1 X113.501 Y107.445 E-.22756
G1 X113.601 Y107.442 E-.04738
;WIPE_END
G1 X111.528 Y104.712 F9000
G1 X111.52 Y104.7
G1 X111.82 Y104.489
G1 E5 F2400
G1 F6000
G1 X111.685 Y104.328 E.00511
G1 X109.859 Y101.167 E.08879
G1 X109.646 Y100.62 E.01428
G1 X109.567 Y100.022 E.01467
G1 X109.601 Y99.584 E.01069
G1 X109.701 Y99.194 E.00979
G1 X109.859 Y98.833 E.00959
G1 X111.685 Y95.672 E.08879
G1 X111.936 Y95.343 E.01007
G1 X112.326 Y94.999 E.01265
G1 X112.903 Y94.688 E.01594
G1 X113.494 Y94.546 E.01478
G1 X113.902 Y94.532 E.00993
G1 X117.372 Y94.534 E.0844
G1 X117.955 Y94.639 E.01441
G1 X118.368 Y94.808 E.01085
G1 X118.832 Y95.119 E.01359
G1 X119.263 Y95.594 E.0156
G1 X121.102 Y98.766 E.08918
G1 X121.299 Y99.21 E.01182
G1 X121.386 Y99.521 E.00786
G1 X121.432 Y100.079 E.01362
G1 X121.364 Y100.575 E.01218
G1 X121.197 Y101.054 E.01234
G1 X120.931 Y101.52 E.01305
G1 X119.263 Y104.406 E.08108
G1 X118.98 Y104.744 E.01072
G1 X118.543 Y105.092 E.01359
G1 X118.127 Y105.3 E.01131
G1 X117.767 Y105.411 E.00916
G1 X117.371 Y105.466 E.00972
G1 X113.721 Y105.47 E.08878
G1 X113.142 Y105.388 E.01422
G1 X112.582 Y105.165 E.01466
G1 X112.093 Y104.814 E.01464
G1 X111.859 Y104.535 E.00886
G1 X111.535 Y104.707 F9000
;TYPE:Perimeter
G1 F6000
G1 X111.369 Y104.511 E.00625
G1 X109.542 Y101.35 E.08881
G1 X109.305 Y100.752 E.01565
G1 X109.204 Y100.067 E.01684
G1 X109.236 Y99.55 E.0126
G1 X109.366 Y99.049 E.01259
G1 X109.542 Y98.65 E.01061
G1 X111.369 Y95.489 E.08881
G1 X111.667 Y95.095 E.01202
G1 X112.046 Y94.752 E.01243
G1 X112.73 Y94.366 E.0191
G1 X113.413 Y94.19 E.01716
G1 X113.902 Y94.166 E.01191
G1 X117.372 Y94.168 E.0844
G1 X118.021 Y94.279 E.01602
G1 X118.572 Y94.504 E.01448
G1 X119.036 Y94.816 E.0136
G1 X119.512 Y95.318 E.01683
G1 X119.579 Y95.411 E.00279
G1 X121.418 Y98.583 E.08918
G1 X121.65 Y99.107 E.01394
G1 X121.751 Y99.491 E.00966
G1 X121.796 Y100.049 E.01362
G1 X121.726 Y100.628 E.01419
G1 X121.542 Y101.176 E.01406
G1 X121.248 Y101.703 E.01468
G1 X119.579 Y104.589 E.08109
G1 X119.241 Y105.001 E.01296
G1 X118.771 Y105.378 E.01466
G1 X118.262 Y105.641 E.01394
G1 X117.819 Y105.773 E.01124
G1 X117.372 Y105.832 E.01097
G1 X113.721 Y105.835 E.08881
G1 X113.09 Y105.75 E.01549
G1 X112.444 Y105.504 E.01681
G1 X111.876 Y105.108 E.01684
G1 X111.574 Y104.753 E.01134
G1 X111.574 Y104.753 F9000
G1 X111.24 Y104.933
G1 F6000
G1 X111.141 Y104.821 E.00364
G1 X111.052 Y104.694 E.00377
G1 X109.226 Y101.533 E.08879
G1 X108.964 Y100.883 E.01705
G1 X108.841 Y100.112 E.01899
G1 X108.868 Y99.554 E.01359
G1 X108.982 Y99.045 E.01269
G1 X109.178 Y98.562 E.01268
G1 X111.052 Y95.306 E.09138
G1 X111.399 Y94.846 E.01402
G1 X111.802 Y94.48 E.01324
G1 X112.557 Y94.044 E.02121
G1 X113.331 Y93.833 E.01951
G1 X113.903 Y93.801 E.01394
G1 X117.372 Y93.803 E.08438
G1 X118.088 Y93.92 E.01765
G1 X118.612 Y94.113 E.01358
G1 X119.24 Y94.512 E.0181
G1 X119.783 Y95.073 E.01899
G1 X119.895 Y95.227 E.00463
G1 X121.734 Y98.399 E.08918
G1 X121.976 Y98.921 E.014
G1 X122.112 Y99.426 E.01272
G1 X122.161 Y100.019 E.01447
G1 X122.087 Y100.681 E.0162
G1 X121.887 Y101.298 E.01578
G1 X121.565 Y101.886 E.01631
G1 X119.896 Y104.772 E.08109
G1 X119.569 Y105.185 E.01281
G1 X118.999 Y105.664 E.01811
G1 X118.522 Y105.927 E.01325
G1 X118.016 Y106.102 E.01302
G1 X117.502 Y106.188 E.01268
G1 X113.722 Y106.201 E.09195
G1 X113.038 Y106.112 E.01678
G1 X112.305 Y105.843 E.01899
G1 X111.66 Y105.403 E.01899
G1 X111.28 Y104.978 E.01387
G1 X111.28 Y104.978 F9000
G1 X110.953 Y105.153
G1 F6000
G1 X110.735 Y104.877 E.00855
G1 X108.909 Y101.716 E.08879
G1 X108.622 Y101.014 E.01845
G1 X108.546 Y100.711 E.0076
G1 X108.478 Y100.156 E.0136
G1 X108.503 Y99.524 E.01538
G1 X108.628 Y98.956 E.01415
G1 X108.842 Y98.417 E.01411
G1 X110.736 Y95.123 E.09242
G1 X111.131 Y94.598 E.01598
G1 X111.557 Y94.207 E.01407
G1 X112.384 Y93.722 E.02332
G1 X112.705 Y93.601 E.00834
G1 X113.25 Y93.477 E.0136
G1 X113.903 Y93.435 E.01592
G1 X117.373 Y93.437 E.0844
G1 X118.155 Y93.56 E.01926
G1 X118.75 Y93.775 E.01539
G1 X119.444 Y94.209 E.01991
G1 X119.836 Y94.587 E.01325
G1 X120.212 Y95.044 E.01439
G1 X122.051 Y98.216 E.08918
G1 X122.327 Y98.818 E.01611
G1 X122.462 Y99.303 E.01225
G1 X122.525 Y99.989 E.01676
G1 X122.449 Y100.734 E.01822
G1 X122.231 Y101.421 E.01753
G1 X121.881 Y102.069 E.01791
G1 X120.212 Y104.955 E.08109
G1 X119.85 Y105.419 E.01431
G1 X119.455 Y105.768 E.01282
G1 X119.008 Y106.091 E.01341
G1 X118.482 Y106.338 E.01413
G1 X117.923 Y106.497 E.01414
G1 X117.373 Y106.563 E.01347
G1 X113.722 Y106.567 E.08881
G1 X113.21 Y106.507 E.01254
G1 X112.684 Y106.392 E.0131
G1 X112.167 Y106.181 E.01358
G1 X111.894 Y106.028 E.00761
G1 X111.444 Y105.698 E.01357
G1 X111.176 Y105.436 E.00912
G1 X110.99 Y105.2 E.00731
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X110.953 Y105.153 E-.02841
G1 X110.735 Y104.877 E-.16706
G1 X109.361 Y102.499 E-1.30453
;WIPE_END
G1 X109.217 Y114 F9000
G1 X109.226 Y114.23
G1 X109.254 Y114.458
G1 X109.301 Y114.683
G1 X109.365 Y114.904
G1 X109.448 Y115.119
G1 X109.549 Y115.328
G1 X110.461 Y116.909
G1 X111.195 Y118.177
G1 X111.538 Y123.276
G1 X111.819 Y123.51
G1 E5 F2400
G1 F6000
G1 X112.019 Y123.266 E.00767
G1 X112.543 Y122.856 E.01618
G1 X112.949 Y122.671 E.01085
G1 X113.494 Y122.546 E.0136
G1 X113.902 Y122.532 E.00993
G1 X117.372 Y122.534 E.0844
G1 X117.955 Y122.639 E.01441
G1 X118.371 Y122.81 E.01094
G1 X118.9 Y123.183 E.01574
G1 X119.262 Y123.594 E.01332
G1 X121.102 Y126.766 E.0892
G1 X121.275 Y127.127 E.00974
G1 X121.386 Y127.521 E.00996
G1 X121.432 Y128.079 E.01362
G1 X121.364 Y128.575 E.01218
G1 X121.183 Y129.084 E.01314
G1 X119.245 Y132.431 E.09408
G1 X118.98 Y132.744 E.00998
G1 X118.543 Y133.092 E.01359
G1 X118.152 Y133.292 E.01068
G1 X117.767 Y133.411 E.0098
G1 X117.372 Y133.466 E.0097
G1 X113.721 Y133.47 E.08881
G1 X113.142 Y133.388 E.01422
G1 X112.582 Y133.165 E.01466
G1 X112.092 Y132.814 E.01466
G1 X111.703 Y132.354 E.01465
G1 X109.859 Y129.167 E.08956
G1 X109.646 Y128.62 E.01428
G1 X109.567 Y128.022 E.01467
G1 X109.601 Y127.584 E.01069
G1 X109.701 Y127.194 E.00979
G1 X109.859 Y126.833 E.00959
G1 X111.685 Y123.672 E.08879
G1 X111.781 Y123.556 E.00366
G1 X111.781 Y123.556 F9000
G1 X111.53 Y123.289
;TYPE:Perimeter
G1 F6000
G1 X111.738 Y123.032 E.00804
G1 X111.876 Y122.892 E.00478
G1 X112.327 Y122.561 E.01361
G1 X112.833 Y122.323 E.0136
G1 X113.413 Y122.19 E.01447
G1 X113.902 Y122.166 E.01191
G1 X117.372 Y122.168 E.0844
G1 X118.021 Y122.279 E.01602
G1 X118.516 Y122.471 E.01291
G1 X119.11 Y122.883 E.01758
G1 X119.517 Y123.324 E.0146
G1 X121.418 Y126.583 E.09177
G1 X121.625 Y127.024 E.01185
G1 X121.751 Y127.491 E.01177
G1 X121.796 Y128.049 E.01362
G1 X121.726 Y128.628 E.01419
G1 X121.5 Y129.267 E.01649
G1 X119.526 Y132.665 E.09559
G1 X119.208 Y133.029 E.01176
G1 X118.771 Y133.378 E.0136
G1 X118.262 Y133.641 E.01394
G1 X117.819 Y133.773 E.01124
G1 X117.373 Y133.832 E.01094
G1 X113.721 Y133.835 E.08883
G1 X113.09 Y133.75 E.01549
G1 X112.444 Y133.504 E.01681
G1 X111.876 Y133.108 E.01684
G1 X111.422 Y132.588 E.01679
G1 X109.542 Y129.35 E.09107
G1 X109.305 Y128.752 E.01565
G1 X109.204 Y128.067 E.01684
G1 X109.247 Y127.495 E.01395
G1 X109.366 Y127.049 E.01123
G1 X109.542 Y126.65 E.01061
G1 X111.369 Y123.489 E.08881
G1 X111.493 Y123.336 E.00479
G1 X111.493 Y123.336 F9000
G1 X111.242 Y123.068
G1 F6000
G1 X111.457 Y122.798 E.0084
G1 X111.66 Y122.597 E.00695
G1 X112.111 Y122.266 E.01361
G1 X112.61 Y122.017 E.01356
G1 X113.111 Y121.884 E.01261
G1 X113.511 Y121.811 E.00989
G1 X117.373 Y121.803 E.09394
G1 X118.088 Y121.92 E.01762
G1 X118.612 Y122.113 E.01358
G1 X119.32 Y122.584 E.02068
G1 X119.792 Y123.083 E.01671
G1 X119.895 Y123.227 E.00431
G1 X121.734 Y126.399 E.08918
G1 X121.976 Y126.921 E.014
G1 X122.115 Y127.462 E.01359
G1 X122.161 Y128.019 E.01359
G1 X122.087 Y128.681 E.0162
G1 X121.887 Y129.298 E.01578
G1 X121.817 Y129.45 E.00407
G1 X119.896 Y132.772 E.09334
G1 X119.807 Y132.899 E.00377
G1 X119.436 Y133.315 E.01356
G1 X118.999 Y133.664 E.0136
G1 X118.51 Y133.933 E.01358
G1 X118.016 Y134.102 E.0127
G1 X117.373 Y134.197 E.01581
G1 X113.721 Y134.201 E.08883
G1 X113.038 Y134.112 E.01675
G1 X112.305 Y133.843 E.01899
G1 X111.66 Y133.403 E.01899
G1 X111.141 Y132.821 E.01897
G1 X111.052 Y132.694 E.00377
G1 X109.226 Y129.533 E.08879
G1 X108.964 Y128.883 E.01705
G1 X108.841 Y128.112 E.01899
G1 X108.868 Y127.554 E.01359
G1 X108.982 Y127.045 E.01269
G1 X109.225 Y126.467 E.01525
G1 X111.052 Y123.306 E.08881
G1 X111.204 Y123.115 E.00594
G1 X111.204 Y123.115 F9000
G1 X110.953 Y122.847
G1 F6000
G1 X111.176 Y122.564 E.00876
G1 X111.444 Y122.302 E.00912
G1 X111.895 Y121.971 E.01361
G1 X112.458 Y121.685 E.01536
G1 X113.029 Y121.527 E.01441
G1 X113.501 Y121.445 E.01165
G1 X117.373 Y121.437 E.09418
G1 X117.903 Y121.514 E.01303
G1 X118.405 Y121.634 E.01255
G1 X118.936 Y121.869 E.01412
G1 X119.531 Y122.285 E.01766
G1 X119.87 Y122.617 E.01154
G1 X120.211 Y123.044 E.01329
G1 X122.051 Y126.216 E.0892
G1 X122.327 Y126.818 E.01611
G1 X122.48 Y127.432 E.01539
G1 X122.525 Y127.989 E.01359
G1 X122.449 Y128.734 E.01822
G1 X122.231 Y129.421 E.01753
G1 X122.133 Y129.633 E.00568
G1 X120.212 Y132.955 E.09334
G1 X120.089 Y133.132 E.00524
G1 X119.664 Y133.601 E.0154
G1 X119.227 Y133.95 E.0136
G1 X118.675 Y134.259 E.01539
G1 X118.127 Y134.451 E.01412
G1 X117.554 Y134.55 E.01414
G1 X117.373 Y134.563 E.00441
G1 X113.721 Y134.567 E.08883
G1 X112.986 Y134.474 E.01802
G1 X112.167 Y134.181 E.02116
G1 X111.444 Y133.698 E.02115
G1 X110.86 Y133.055 E.02113
G1 X110.736 Y132.877 E.00528
G1 X108.909 Y129.716 E.08881
G1 X108.622 Y129.014 E.01845
G1 X108.546 Y128.711 E.0076
G1 X108.478 Y128.156 E.0136
G1 X108.503 Y127.524 E.01538
G1 X108.628 Y126.956 E.01415
G1 X108.909 Y126.284 E.01772
G1 X110.736 Y123.123 E.08881
G1 X110.916 Y122.895 E.00707
G1 E-5 F3600
G1 X110.916 Y122.895 F9000
G1 X111.511 Y123.312
G1 X111.395 Y123.477
G1 X111.334 Y123.581
G1 X110.671 Y124.726
G1 X109.549 Y126.672
G1 X109.448 Y126.881
G1 X109.365 Y127.096
G1 X109.301 Y127.317
G1 X109.254 Y127.542
G1 X109.226 Y127.77
G1 X109.217 Y128
G1 X109.226 Y128.23
G1 X109.254 Y128.458
G1 X109.301 Y128.683
G1 X109.365 Y128.904
G1 X109.448 Y129.119
G1 X109.549 Y129.328
G1 X112.346 Y134.649
G1 E5 F2400
G1 F6000
G1 X112.029 Y134.52 E.00832
G1 X111.678 Y134.323 E.00979
G1 X111.228 Y133.993 E.01357
G1 X110.935 Y133.718 E.00977
G1 X110.578 Y133.289 E.01358
G1 X110.419 Y133.06 E.00678
G1 X108.592 Y129.899 E.08881
G1 X108.281 Y129.146 E.01982
G1 X108.184 Y128.756 E.00978
G1 X108.115 Y128.201 E.0136
G1 X108.139 Y127.494 E.01721
G1 X108.273 Y126.868 E.01557
G1 X108.507 Y126.272 E.01557
G1 X110.419 Y122.94 E.09344
G1 X110.895 Y122.331 E.0188
G1 X111.228 Y122.007 E.0113
G1 X111.678 Y121.676 E.01359
G1 X112.307 Y121.352 E.01721
G1 X112.948 Y121.171 E.0162
;WIDTH:0.441282
G1 X113.079 Y121.127 E.00374
;WIDTH:0.482564
G1 X113.211 Y121.084 E.00414
;WIDTH:0.523846
G1 X113.343 Y121.041 E.00452
;WIDTH:0.565128
G1 X113.475 Y120.997 E.00491
G1 X113.339 Y120.957 E.00501
;WIDTH:0.523846
G1 X113.204 Y120.917 E.00458
;WIDTH:0.482564
G1 X113.069 Y120.876 E.00421
;WIDTH:0.441282
G1 X112.934 Y120.836 E.00381
;WIDTH:0.399999
G1 X112.547 Y120.731 E.00975
G1 X112.029 Y120.52 E.01361
G1 X111.678 Y120.324 E.00978
G1 X111.228 Y119.993 E.01359
G1 X110.895 Y119.669 E.0113
G1 X110.419 Y119.06 E.0188
G1 X108.592 Y115.899 E.08881
G1 X108.281 Y115.146 E.01982
G1 X108.184 Y114.756 E.00978
G1 X108.115 Y114.201 E.0136
G1 X108.139 Y113.494 E.01721
G1 X108.273 Y112.868 E.01557
G1 X108.507 Y112.272 E.01557
G1 X110.419 Y108.94 E.09344
G1 X110.895 Y108.331 E.0188
G1 X111.228 Y108.007 E.0113
G1 X111.678 Y107.676 E.01359
G1 X112.307 Y107.352 E.01721
G1 X112.947 Y107.171 E.01618
;WIDTH:0.441286
G1 X113.079 Y107.127 E.00377
;WIDTH:0.482572
G1 X113.211 Y107.084 E.00414
;WIDTH:0.523858
G1 X113.343 Y107.041 E.00452
;WIDTH:0.565144
G1 X113.475 Y106.997 E.00491
G1 X113.339 Y106.957 E.00501
;WIDTH:0.523858
G1 X113.204 Y106.917 E.00458
;WIDTH:0.482572
G1 X113.069 Y106.876 E.00421
;WIDTH:0.441286
G1 X112.934 Y106.836 E.00381
;WIDTH:0.399999
G1 X112.546 Y106.731 E.00978
G1 X112.029 Y106.52 E.01358
G1 X111.678 Y106.323 E.00979
G1 X111.228 Y105.993 E.01357
G1 X110.895 Y105.669 E.0113
G1 X110.419 Y105.06 E.0188
G1 X108.592 Y101.899 E.08881
G1 X108.281 Y101.146 E.01982
G1 X108.184 Y100.756 E.00978
G1 X108.115 Y100.201 E.0136
G1 X108.139 Y99.494 E.01721
G1 X108.273 Y98.868 E.01557
G1 X108.507 Y98.272 E.01557
G1 X110.419 Y94.94 E.09344
G1 X110.863 Y94.349 E.01798
G1 X111.313 Y93.935 E.01487
G1 X111.633 Y93.711 E.0095
G1 X112.21 Y93.4 E.01594
G1 X112.624 Y93.245 E.01075
G1 X113.169 Y93.12 E.0136
G1 X113.903 Y93.069 E.0179
G1 X117.373 Y93.071 E.0844
G1 X118.221 Y93.201 E.02087
G1 X118.888 Y93.436 E.0172
G1 X119.647 Y93.905 E.0217
G1 X120.107 Y94.341 E.01542
G1 X120.528 Y94.861 E.01627
G1 X122.367 Y98.032 E.08916
G1 X122.678 Y98.715 E.01825
G1 X122.822 Y99.236 E.01315
G1 X122.89 Y99.959 E.01766
G1 X122.878 Y100.332 E.00908
G1 X122.804 Y100.833 E.01232
G1 X122.576 Y101.543 E.01814
G1 X122.198 Y102.252 E.01954
G1 X120.529 Y105.138 E.08109
G1 X120.132 Y105.653 E.01582
G1 X119.683 Y106.054 E.01464
G1 X119.264 Y106.367 E.01272
G1 X118.592 Y106.687 E.0181
G1 X117.975 Y106.859 E.01558
;WIDTH:0.43894
G1 X117.862 Y106.894 E.00318
;WIDTH:0.477881
G1 X117.749 Y106.929 E.00349
;WIDTH:0.516822
G1 X117.635 Y106.965 E.00384
;WIDTH:0.555762
G1 X117.522 Y107 E.0041
G1 X117.697 Y107.05 E.00631
;WIDTH:0.516822
G1 X117.872 Y107.1 E.00584
;WIDTH:0.477881
G1 X118.047 Y107.151 E.00538
;WIDTH:0.43894
G1 X118.221 Y107.201 E.00487
;WIDTH:0.399999
G1 X118.875 Y107.431 E.01686
G1 X119.213 Y107.614 E.00935
G1 X119.741 Y107.986 E.01571
G1 X120.145 Y108.376 E.01366
G1 X120.528 Y108.86 E.01501
G1 X122.367 Y112.032 E.08918
G1 X122.678 Y112.715 E.01825
G1 X122.844 Y113.402 E.01719
G1 X122.89 Y113.959 E.01359
G1 X122.837 Y114.664 E.0172
G1 X122.584 Y115.52 E.02171
G1 X122.45 Y115.816 E.0079
G1 X120.529 Y119.138 E.09334
G1 X120.131 Y119.653 E.01583
G1 X119.662 Y120.089 E.01558
G1 X119.128 Y120.442 E.01557
G1 X118.555 Y120.685 E.01514
G1 X117.975 Y120.859 E.01473
;WIDTH:0.43894
G1 X117.862 Y120.894 E.00318
;WIDTH:0.477881
G1 X117.749 Y120.929 E.00349
;WIDTH:0.516822
G1 X117.635 Y120.965 E.00384
;WIDTH:0.555762
G1 X117.522 Y121 E.0041
G1 X117.697 Y121.05 E.00631
;WIDTH:0.516822
G1 X117.872 Y121.1 E.00584
;WIDTH:0.477881
G1 X118.047 Y121.151 E.00538
;WIDTH:0.43894
G1 X118.221 Y121.201 E.00487
;WIDTH:0.399999
G1 X118.81 Y121.404 E.01515
G1 X119.213 Y121.614 E.01105
G1 X119.741 Y121.986 E.01571
G1 X120.145 Y122.376 E.01366
G1 X120.528 Y122.86 E.01501
G1 X122.367 Y126.032 E.08918
G1 X122.678 Y126.715 E.01825
G1 X122.844 Y127.402 E.01719
G1 X122.89 Y127.959 E.01359
G1 X122.878 Y128.332 E.00908
G1 X122.804 Y128.833 E.01232
G1 X122.576 Y129.543 E.01814
G1 X122.45 Y129.816 E.00731
G1 X120.529 Y133.138 E.09334
G1 X120.131 Y133.653 E.01583
G1 X119.455 Y134.236 E.02171
G1 X118.841 Y134.585 E.01718
G1 X118.237 Y134.799 E.01559
G1 X117.606 Y134.912 E.01559
G1 X117.374 Y134.929 E.00566
G1 X113.721 Y134.932 E.08886
G1 X112.934 Y134.836 E.01928
G1 X112.546 Y134.731 E.00978
G1 X112.401 Y134.672 E.00381
G1 E-5 F3600
G1 X112.401 Y134.672 F9000
G1 X109.226 Y128.23
G1 X109.217 Y128
G1 X109.226 Y127.77
G1 X111.528 Y123.288
G1 X111.675 Y123.111
G1 X111.836 Y122.946
G1 X112.01 Y122.796
G1 X112.196 Y122.66
G1 X112.392 Y122.539
G1 X112.597 Y122.435
G1 X112.81 Y122.349
G1 X113.029 Y122.279
G1 X117.522 Y121
G1 E5 F2400
;WIDTH:0.555762
G1 F6000
G1 X117.373 Y121 E.00517
;WIDTH:0.542648
G1 X113.903 Y121.001 E.11733
;WIDTH:0.565128
G1 X113.475 Y120.997 E.01511
G1 E-5 F3600
G1 X113.475 Y120.997 F9000
G1 X111.675 Y118.889
G1 X111.528 Y118.712
G1 X111.395 Y118.523
G1 X111.335 Y118.419
G1 X109.226 Y114.23
G1 X109.217 Y114
G1 X109.226 Y113.77
G1 X109.254 Y113.542
G1 X109.301 Y113.317
G1 X109.365 Y113.096
G1 X109.448 Y112.881
G1 X109.549 Y112.672
G1 X110.461 Y111.091
G1 X111.334 Y109.581
G1 X111.395 Y109.477
G1 X111.528 Y109.288
G1 X111.675 Y109.111
G1 X111.836 Y108.946
G1 X112.01 Y108.796
G1 X112.196 Y108.66
G1 X112.392 Y108.539
G1 X112.597 Y108.435
G1 X112.81 Y108.349
G1 X113.029 Y108.279
G1 X117.522 Y107
G1 E5 F2400
;WIDTH:0.555762
G1 F6000
G1 X117.373 Y107 E.00517
;WIDTH:0.542648
G1 X113.903 Y107.001 E.11733
;WIDTH:0.565144
G1 X113.475 Y106.997 E.01511
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.903 Y107.001 E-.20331
G1 X116.633 Y107 E-1.29669
;WIPE_END
G1 X105.681 Y103.076 F9000
G1 X105.681 Y103.491
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.567 Y103.424 E.00322
G1 X105.158 Y103.424 E.00995
G1 X105.158 Y98.824 E.11189
G1 X105.567 Y98.824 E.00995
G1 X105.705 Y98.762 E.00368
G1 X105.75 Y98.642 E.00312
G1 X105.75 Y91.888 E.16428
G1 X105.696 Y91.758 E.00342
G1 X105.25 Y91.318 E.01524
G1 X104.83 Y90.832 E.01562
G1 X104.696 Y90.523 E.00819
G1 X104.731 Y90.332 E.00472
G1 X105.036 Y89.894 E.01298
G1 X105.583 Y89.351 E.01875
G1 X125.419 Y89.351 E.48249
G1 X125.747 Y89.667 E.01108
G1 X126.09 Y90.044 E.0124
G1 X126.285 Y90.403 E.00994
G1 X126.279 Y90.613 E.00511
G1 X126.08 Y90.969 E.00992
G1 X125.302 Y91.759 E.02697
G1 X125.25 Y91.888 E.00338
G1 X125.25 Y98.556 E.16219
G1 X125.281 Y98.743 E.00461
G1 X125.433 Y98.824 E.00419
G1 X125.842 Y98.824 E.00995
G1 X125.842 Y103.424 E.11189
G1 X125.433 Y103.424 E.00995
G1 X125.292 Y103.491 E.0038
G1 X125.25 Y103.607 E.003
G1 X125.25 Y136.112 E.79065
G1 X125.304 Y136.242 E.00342
G1 X125.75 Y136.682 E.01524
G1 X126.17 Y137.168 E.01562
G1 X126.304 Y137.477 E.00819
G1 X126.285 Y137.582 E.0026
G1 X126.269 Y137.668 E.00213
G1 X125.964 Y138.106 E.01298
G1 X125.417 Y138.649 E.01875
G1 X105.581 Y138.649 E.48249
G1 X105.252 Y138.333 E.0111
G1 X104.91 Y137.956 E.01238
G1 X104.715 Y137.597 E.00994
G1 X104.721 Y137.387 E.00511
G1 X104.92 Y137.031 E.00992
G1 X105.698 Y136.241 E.02697
G1 X105.75 Y136.112 E.00338
G1 X105.75 Y103.607 E.79065
G1 X105.729 Y103.525 E.00206
G1 X105.729 Y103.525 F9000
G1 X105.925 Y103.23
;TYPE:Perimeter
G1 F6000
G1 X105.524 Y103.059 E.0106
G1 X105.524 Y99.233 E.09306
G1 X105.98 Y99.003 E.01242
G1 X106.077 Y98.844 E.00453
G1 X106.116 Y98.642 E.005
G1 X106.116 Y91.888 E.16428
G1 X106.084 Y91.704 E.00454
G1 X105.952 Y91.497 E.00597
G1 X105.324 Y90.878 E.02145
G1 X105.076 Y90.506 E.01087
G1 X105.318 Y90.13 E.01088
G1 X105.733 Y89.717 E.01424
G1 X125.272 Y89.717 E.47527
G1 X125.775 Y90.24 E.01765
G1 X125.928 Y90.481 E.00694
G1 X125.794 Y90.738 E.00705
G1 X125.042 Y91.503 E.02609
G1 X124.915 Y91.706 E.00582
G1 X124.884 Y91.888 E.00449
G1 X124.884 Y98.185 E.15317
G1 X124.899 Y98.768 E.01419
G1 X125.02 Y99.003 E.00643
G1 X125.476 Y99.19 E.01199
G1 X125.476 Y103.059 E.09411
G1 X125.01 Y103.258 E.01233
G1 X124.964 Y103.322 E.00192
G1 X124.884 Y103.607 E.0072
G1 X124.884 Y136.112 E.79065
G1 X124.916 Y136.296 E.00454
G1 X125.048 Y136.503 E.00597
G1 X125.493 Y136.942 E.0152
G1 X125.879 Y137.389 E.01437
G1 X125.925 Y137.515 E.00326
G1 X125.683 Y137.869 E.01043
G1 X125.267 Y138.283 E.01428
G1 X105.728 Y138.283 E.47527
G1 X105.225 Y137.76 E.01765
G1 X105.072 Y137.519 E.00694
G1 X105.206 Y137.262 E.00705
G1 X105.958 Y136.497 E.02609
G1 X106.085 Y136.294 E.00582
G1 X106.116 Y136.112 E.00449
G1 X106.116 Y103.607 E.79065
G1 X106.099 Y103.471 E.00333
G1 X105.991 Y103.259 E.00579
G1 X105.98 Y103.254 E.00029
G1 X106.17 Y102.984 F9000
G1 F6000
G1 X105.889 Y102.845 E.00763
G1 X105.889 Y99.41 E.08355
G1 X106.255 Y99.244 E.00978
G1 X106.417 Y98.98 E.00753
G1 X106.481 Y98.642 E.00837
G1 X106.481 Y91.888 E.16428
G1 X106.428 Y91.581 E.00758
G1 X106.209 Y91.237 E.00992
G1 X105.501 Y90.507 E.02474
G1 X105.884 Y90.083 E.0139
G1 X125.125 Y90.083 E.46802
G1 X125.507 Y90.508 E.0139
G1 X124.781 Y91.247 E.0252
G1 X124.57 Y91.586 E.00971
G1 X124.519 Y91.888 E.00745
G1 X124.519 Y98.556 E.16219
G1 X124.558 Y98.908 E.00861
G1 X124.745 Y99.244 E.00935
G1 X125.111 Y99.41 E.00978
G1 X125.111 Y102.845 E.08355
G1 X124.727 Y103.026 E.01033
G1 X124.574 Y103.293 E.00749
G1 X124.519 Y103.607 E.00775
G1 X124.519 Y136.112 E.79065
G1 X124.572 Y136.419 E.00758
G1 X124.791 Y136.763 E.00992
G1 X125.499 Y137.493 E.02474
G1 X125.116 Y137.917 E.0139
G1 X105.875 Y137.917 E.46802
G1 X105.493 Y137.492 E.0139
G1 X106.219 Y136.753 E.0252
G1 X106.43 Y136.414 E.00971
G1 X106.481 Y136.112 E.00745
G1 X106.481 Y103.607 E.79065
G1 X106.453 Y103.38 E.00556
G1 X106.285 Y103.042 E.00918
G1 X106.224 Y103.011 E.00166
G1 X106.224 Y103.011 F9000
G1 X106.419 Y102.736
G1 F6000
G1 X106.255 Y102.652 E.00448
G1 X106.255 Y99.609 E.07402
G1 X106.53 Y99.484 E.00735
G1 X106.597 Y99.401 E.00259
G1 X106.783 Y99.041 E.00986
G1 X106.847 Y98.642 E.00983
G1 X106.847 Y91.888 E.16428
G1 X106.773 Y91.458 E.01061
G1 X106.466 Y90.976 E.0139
G1 X105.983 Y90.5 E.01649
G1 X106.035 Y90.448 E.00179
G1 X124.962 Y90.448 E.46038
G1 X125.014 Y90.488 E.0016
G1 X124.52 Y90.99 E.01713
G1 X124.225 Y91.465 E.0136
G1 X124.153 Y91.888 E.01044
G1 X124.153 Y98.642 E.16428
G1 X124.224 Y99.063 E.01039
G1 X124.47 Y99.485 E.01188
G1 X124.745 Y99.609 E.00734
G1 X124.745 Y102.652 E.07402
G1 X124.445 Y102.793 E.00806
G1 X124.231 Y103.168 E.0105
G1 X124.153 Y103.607 E.01085
G1 X124.153 Y136.112 E.79065
G1 X124.227 Y136.542 E.01061
G1 X124.534 Y137.024 E.0139
G1 X125.017 Y137.5 E.01649
G1 X124.965 Y137.552 E.00179
G1 X106.038 Y137.552 E.46038
G1 X105.986 Y137.512 E.0016
G1 X106.48 Y137.01 E.01713
G1 X106.775 Y136.535 E.0136
G1 X106.847 Y136.112 E.01044
G1 X106.847 Y103.607 E.79065
G1 X106.769 Y103.168 E.01085
G1 X106.573 Y102.815 E.00982
G1 X106.472 Y102.764 E.00275
G1 X106.472 Y102.764 F9000
G1 X106.677 Y102.49
G1 F6000
G1 X106.621 Y102.459 E.00156
G1 X106.621 Y99.809 E.06446
G1 X106.805 Y99.725 E.00492
G1 X106.892 Y99.618 E.00335
G1 X107.13 Y99.155 E.01266
G1 X107.213 Y98.642 E.01264
G1 X107.213 Y91.888 E.16428
G1 X107.117 Y91.335 E.01365
G1 X106.785 Y90.814 E.01503
G1 X124.21 Y90.814 E.42385
G1 X123.88 Y91.344 E.01519
G1 X123.787 Y91.888 E.01342
G1 X123.787 Y98.556 E.16219
G1 X123.832 Y99.022 E.01139
G1 X124.062 Y99.552 E.01405
G1 X124.195 Y99.726 E.00533
G1 X124.379 Y99.809 E.00491
G1 X124.379 Y102.459 E.06446
G1 X124.163 Y102.561 E.00581
G1 X123.887 Y103.042 E.01349
G1 X123.787 Y103.607 E.01396
G1 X123.787 Y136.112 E.79065
G1 X123.883 Y136.665 E.01365
G1 X124.215 Y137.186 E.01503
G1 X106.79 Y137.186 E.42385
G1 X107.12 Y136.656 E.01519
G1 X107.213 Y136.112 E.01342
G1 X107.213 Y103.607 E.79065
G1 X107.113 Y103.043 E.01393
G1 X106.86 Y102.589 E.01264
G1 X106.73 Y102.519 E.00359
G1 E-5 F3600
G1 X106.73 Y102.519 F9000
G1 X112.028 Y106.638
G1 E5 F2400
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X112.539 Y107.148 E.01756
G1 E-5 F3600
G1 X112.539 Y107.148 F9000
G1 X118.973 Y107.357
G1 E5 F2400
G1 F3072.127
G1 X118.59 Y106.974 E.01317
G1 X118.965 Y106.83 E.00977
G1 X123.513 Y111.378 E.15645
G1 X123.513 Y110.86 E.0126
G1 X119.307 Y106.653 E.1447
G1 X119.624 Y106.452 E.00913
G1 X123.513 Y110.341 E.13378
G1 X123.513 Y109.822 E.01262
G1 X119.913 Y106.222 E.12384
G1 X120.192 Y105.982 E.00895
G1 X123.513 Y109.303 E.11424
G1 X123.513 Y108.784 E.01262
G1 X120.439 Y105.71 E.10574
G1 X120.666 Y105.419 E.00898
G1 X123.513 Y108.266 E.09794
G1 X123.513 Y107.747 E.01262
G1 X120.867 Y105.101 E.09102
G1 X121.057 Y104.772 E.00924
G1 X123.513 Y107.228 E.08448
G1 X123.513 Y106.709 E.01262
G1 X121.247 Y104.443 E.07795
G1 X121.437 Y104.115 E.00922
G1 X123.513 Y106.191 E.07141
G1 X123.513 Y105.672 E.01262
G1 X121.627 Y103.786 E.06488
G1 X121.817 Y103.457 E.00924
G1 X123.513 Y105.153 E.05834
G1 X123.513 Y104.634 E.01262
G1 X122.007 Y103.129 E.05179
G1 X122.198 Y102.8 E.00925
G1 X123.513 Y104.116 E.04525
G1 X123.514 Y103.597 E.01262
G1 X122.388 Y102.471 E.03873
G1 X122.578 Y102.142 E.00924
G1 X123.575 Y103.14 E.03431
G1 X123.716 Y102.762 E.00981
G1 X122.759 Y101.805 E.03292
G1 X122.905 Y101.433 E.00972
G1 X123.913 Y102.441 E.03467
G1 X124.105 Y102.304 E.00574
G1 X124.105 Y102.114 E.00462
G1 X123.032 Y101.04 E.03693
G1 X123.115 Y100.604 E.0108
G1 X124.105 Y101.595 E.03407
G1 X124.105 Y101.076 E.01262
G1 X123.157 Y100.128 E.03261
G1 X123.134 Y99.587 E.01317
G1 X124.105 Y100.557 E.03338
G1 X124.105 Y100.039 E.0126
G1 X123.039 Y98.973 E.03667
G1 X122.733 Y98.147 E.02143
G1 X123.545 Y98.96 E.02795
G1 X123.513 Y98.409 E.01343
G1 X122.05 Y96.946 E.05033
G1 X121.34 Y95.717 E.03452
G1 X123.678 Y98.055 E.08043
G1 E-5 F3600
G1 X123.678 Y98.055 F9000
G1 X123.762 Y91.395
G1 E5 F2400
G1 F3072.127
G1 X123.455 Y91.088 E.01056
G1 X122.936 Y91.088 E.01262
G1 X123.544 Y91.696 E.02091
G1 X123.513 Y92.184 E.01189
G1 X122.417 Y91.088 E.0377
G1 X121.899 Y91.088 E.0126
G1 X123.513 Y92.703 E.05554
G1 X123.513 Y93.221 E.0126
G1 X121.38 Y91.088 E.07337
G1 X120.861 Y91.088 E.01262
G1 X123.513 Y93.74 E.09123
G1 X123.513 Y94.259 E.01262
G1 X120.342 Y91.088 E.10908
G1 X119.824 Y91.088 E.0126
G1 X123.513 Y94.778 E.12692
G1 X123.513 Y95.296 E.0126
G1 X119.305 Y91.088 E.14475
G1 X118.786 Y91.088 E.01262
G1 X123.513 Y95.815 E.16261
G1 X123.513 Y96.334 E.01262
G1 X118.267 Y91.088 E.18046
G1 X117.749 Y91.088 E.0126
G1 X123.513 Y96.853 E.1983
G1 X123.513 Y97.371 E.0126
G1 X117.23 Y91.088 E.21613
G1 X116.711 Y91.088 E.01262
G1 X118.676 Y93.054 E.06761
G1 X117.982 Y92.877 E.01742
G1 X116.192 Y91.088 E.06156
G1 X115.673 Y91.088 E.01262
G1 X117.383 Y92.798 E.05882
G1 X116.863 Y92.797 E.01265
G1 X115.155 Y91.088 E.05877
G1 X114.636 Y91.088 E.01262
G1 X116.344 Y92.797 E.05877
G1 X115.825 Y92.796 E.01262
G1 X114.117 Y91.088 E.05875
G1 X113.598 Y91.088 E.01262
G1 X115.306 Y92.796 E.05875
G1 X114.788 Y92.796 E.0126
G1 X113.08 Y91.088 E.05875
G1 X112.561 Y91.088 E.01262
G1 X114.269 Y92.796 E.05875
G1 X113.752 Y92.798 E.01258
G1 X112.042 Y91.088 E.05882
G1 X111.523 Y91.088 E.01262
G1 X113.267 Y92.832 E.05999
G1 X112.832 Y92.916 E.01078
G1 X111.004 Y91.088 E.06288
G1 X110.486 Y91.088 E.0126
G1 X112.426 Y93.028 E.06673
G1 X112.052 Y93.173 E.00976
G1 X109.967 Y91.088 E.07172
G1 X109.448 Y91.088 E.01262
G1 X111.715 Y93.355 E.07798
G1 X111.389 Y93.548 E.00922
G1 X108.929 Y91.088 E.08462
G1 X108.411 Y91.088 E.0126
G1 X111.09 Y93.768 E.09217
G1 X110.82 Y94.016 E.00892
G1 X107.892 Y91.088 E.10072
G1 X107.373 Y91.088 E.01262
G1 X110.567 Y94.282 E.10987
G1 X110.338 Y94.572 E.00899
G1 X107.454 Y91.687 E.09923
G1 X107.487 Y92.239 E.01345
G1 X110.133 Y94.886 E.09104
G1 X109.943 Y95.215 E.00924
G1 X107.487 Y92.758 E.0845
G1 X107.487 Y93.277 E.01262
G1 X109.753 Y95.544 E.07797
G1 X109.563 Y95.872 E.00922
G1 X107.486 Y93.795 E.07145
G1 X107.486 Y94.314 E.01262
G1 X109.373 Y96.201 E.06491
G1 X109.184 Y96.53 E.00923
G1 X107.486 Y94.833 E.05839
G1 X107.486 Y95.351 E.0126
G1 X108.994 Y96.859 E.05187
G1 X108.804 Y97.188 E.00924
G1 X107.486 Y95.87 E.04534
G1 X107.486 Y96.388 E.0126
G1 X108.614 Y97.516 E.0388
G1 X108.424 Y97.845 E.00924
G1 X107.486 Y96.907 E.03227
G1 X107.485 Y97.426 E.01262
G1 X108.251 Y98.191 E.02633
G1 X108.091 Y98.55 E.00956
G1 X107.485 Y97.944 E.02085
G1 X107.485 Y98.463 E.01262
G1 X107.974 Y98.952 E.01682
G1 X107.877 Y99.374 E.01053
G1 X107.456 Y98.952 E.0145
G1 X107.346 Y99.361 E.0103
G1 X107.84 Y99.856 E.01701
G1 X107.87 Y100.404 E.01335
G1 X107.166 Y99.7 E.02422
G1 X106.909 Y99.962 E.00893
G1 X107.969 Y101.022 E.03646
G1 X108.254 Y101.826 E.02075
G1 X106.895 Y100.467 E.04675
G1 X106.895 Y100.985 E.0126
G1 X108.915 Y103.006 E.0695
G1 X109.625 Y104.234 E.0345
G1 X106.895 Y101.504 E.09391
G1 X106.895 Y102.023 E.01262
G1 X112.043 Y107.171 E.17709
G1 X111.7 Y107.347 E.00938
G1 X107.401 Y103.048 E.14788
G1 X107.487 Y103.652 E.01484
G1 X111.388 Y107.554 E.13421
G1 X111.094 Y107.779 E.00901
G1 X107.487 Y104.171 E.1241
G1 X107.487 Y104.69 E.01262
G1 X110.813 Y108.016 E.11441
G1 X110.573 Y108.295 E.00895
G1 X107.487 Y105.209 E.10616
G1 X107.487 Y105.728 E.01262
G1 X110.338 Y108.578 E.09806
G1 X110.131 Y108.89 E.00911
G1 X107.487 Y106.246 E.09095
G1 X107.487 Y106.765 E.01262
G1 X109.941 Y109.219 E.08442
G1 X109.751 Y109.548 E.00924
G1 X107.487 Y107.284 E.07788
G1 X107.487 Y107.803 E.01262
G1 X109.561 Y109.877 E.07134
G1 X109.371 Y110.205 E.00922
G1 X107.487 Y108.321 E.06481
G1 X107.487 Y108.84 E.01262
G1 X109.181 Y110.534 E.05827
G1 X108.991 Y110.863 E.00924
G1 X107.487 Y109.359 E.05174
G1 X107.487 Y109.878 E.01262
G1 X108.801 Y111.192 E.0452
G1 X108.611 Y111.521 E.00924
G1 X107.487 Y110.396 E.03868
G1 X107.487 Y110.915 E.01262
G1 X108.421 Y111.849 E.03213
G1 X108.248 Y112.196 E.00943
G1 X107.487 Y111.434 E.0262
G1 X107.487 Y111.953 E.01262
G1 X108.09 Y112.555 E.02073
G1 X107.969 Y112.953 E.01012
G1 X107.487 Y112.472 E.01656
G1 X107.487 Y112.99 E.0126
G1 X107.88 Y113.383 E.01352
G1 X107.835 Y113.857 E.01158
G1 X107.487 Y113.509 E.01197
G1 X107.487 Y114.028 E.01262
G1 X107.865 Y114.406 E.013
G1 X107.963 Y115.023 E.0152
G1 X107.487 Y114.547 E.01637
G1 X107.487 Y115.065 E.0126
G1 X108.26 Y115.839 E.02661
G1 X108.924 Y117.022 E.033
G1 X107.487 Y115.584 E.04945
G1 X107.487 Y116.103 E.01262
G1 X110.085 Y118.701 E.08937
G1 E-5 F3600
G1 X110.085 Y118.701 F9000
G1 X112.015 Y120.631
G1 E5 F2400
G1 F3072.127
G1 X112.534 Y121.15 E.01785
G1 X112.162 Y121.297 F9000
G1 F3072.127
G1 X107.487 Y116.622 E.16082
G1 X107.487 Y117.14 E.0126
G1 X111.696 Y121.349 E.14479
G1 X111.384 Y121.557 E.00912
G1 X107.487 Y117.659 E.13407
G1 X107.487 Y118.178 E.01262
G1 X111.09 Y121.781 E.12394
G1 X110.809 Y122.019 E.00896
G1 X107.487 Y118.697 E.11427
G1 X107.487 Y119.216 E.01262
G1 X110.57 Y122.299 E.10605
G1 X110.335 Y122.582 E.00895
G1 X107.487 Y119.734 E.09797
G1 X107.487 Y120.253 E.01262
G1 X110.129 Y122.895 E.09088
G1 X109.94 Y123.225 E.00925
G1 X107.487 Y120.772 E.08438
G1 X107.487 Y121.291 E.01262
G1 X109.75 Y123.554 E.07785
G1 X109.561 Y123.884 E.00925
G1 X107.487 Y121.809 E.07136
G1 X107.487 Y122.328 E.01262
G1 X109.372 Y124.214 E.06486
G1 X109.183 Y124.543 E.00923
G1 X107.487 Y122.847 E.05834
G1 X107.487 Y123.366 E.01262
G1 X108.994 Y124.873 E.05184
G1 X108.805 Y125.203 E.00925
G1 X107.487 Y123.885 E.04534
G1 X107.487 Y124.403 E.0126
G1 X108.616 Y125.532 E.03884
G1 X108.427 Y125.862 E.00925
G1 X107.487 Y124.922 E.03234
G1 X107.487 Y125.441 E.01262
G1 X108.241 Y126.195 E.02594
G1 X108.088 Y126.561 E.00965
G1 X107.487 Y125.96 E.02067
G1 X107.487 Y126.478 E.0126
G1 X107.967 Y126.959 E.01653
G1 X107.879 Y127.389 E.01068
G1 X107.487 Y126.997 E.01348
G1 X107.487 Y127.516 E.01262
G1 X107.835 Y127.864 E.01197
G1 X107.866 Y128.414 E.0134
G1 X107.487 Y128.035 E.01304
G1 X107.487 Y128.553 E.0126
G1 X107.966 Y129.033 E.01649
G1 X108.267 Y129.852 E.02122
G1 X107.487 Y129.072 E.02683
G1 X107.487 Y129.591 E.01262
G1 X108.934 Y131.038 E.04978
G1 X109.644 Y132.267 E.03452
G1 X107.322 Y129.945 E.07988
G1 E-5 F3600
G1 X107.322 Y129.945 F9000
G1 X107.238 Y136.605
G1 E5 F2400
G1 F3072.127
G1 X107.545 Y136.912 E.01056
G1 X108.064 Y136.912 E.01262
G1 X107.456 Y136.304 E.02091
G1 X107.487 Y135.816 E.01189
G1 X108.583 Y136.912 E.0377
G1 X109.101 Y136.912 E.0126
G1 X107.487 Y135.298 E.05552
G1 X107.487 Y134.779 E.01262
G1 X109.62 Y136.912 E.07337
G1 X110.139 Y136.912 E.01262
G1 X107.487 Y134.26 E.09123
G1 X107.487 Y133.741 E.01262
G1 X110.658 Y136.912 E.10908
G1 X111.176 Y136.912 E.0126
G1 X107.487 Y133.222 E.12692
G1 X107.487 Y132.704 E.0126
G1 X111.695 Y136.912 E.14475
G1 X112.214 Y136.912 E.01262
G1 X107.487 Y132.185 E.16261
G1 X107.487 Y131.666 E.01262
G1 X112.733 Y136.912 E.18046
G1 X113.251 Y136.912 E.0126
G1 X107.487 Y131.147 E.1983
G1 X107.487 Y130.629 E.0126
G1 X113.77 Y136.912 E.21613
G1 X114.289 Y136.912 E.01262
G1 X112.306 Y134.929 E.06821
G1 X113.022 Y135.126 E.01806
G1 X114.808 Y136.912 E.06144
G1 X115.327 Y136.912 E.01262
G1 X113.614 Y135.199 E.05893
G1 X114.14 Y135.206 E.0128
G1 X115.845 Y136.912 E.05867
G1 X116.364 Y136.912 E.01262
G1 X114.658 Y135.206 E.05869
G1 X115.176 Y135.205 E.0126
G1 X116.883 Y136.912 E.05872
G1 X117.402 Y136.912 E.01262
G1 X115.694 Y135.205 E.05874
G1 X116.213 Y135.204 E.01262
G1 X117.92 Y136.912 E.05874
G1 X118.439 Y136.912 E.01262
G1 X116.731 Y135.204 E.05875
G1 X117.249 Y135.203 E.0126
G1 X118.958 Y136.912 E.05879
G1 X119.477 Y136.912 E.01262
G1 X117.735 Y135.17 E.05992
G1 X118.179 Y135.095 E.01095
G1 X119.995 Y136.912 E.06249
G1 X120.514 Y136.912 E.01262
G1 X118.581 Y134.978 E.06651
G1 X118.955 Y134.834 E.00975
G1 X121.033 Y136.912 E.07148
G1 X121.552 Y136.912 E.01262
G1 X119.3 Y134.66 E.07747
G1 X119.616 Y134.457 E.00914
G1 X122.071 Y136.912 E.08445
G1 X122.589 Y136.912 E.0126
G1 X119.905 Y134.228 E.09233
G1 X120.182 Y133.986 E.00895
G1 X123.108 Y136.912 E.10065
G1 X123.627 Y136.912 E.01262
G1 X120.433 Y133.718 E.10987
G1 X120.661 Y133.427 E.00899
G1 X123.546 Y136.313 E.09926
G1 X123.513 Y135.761 E.01345
G1 X120.862 Y133.11 E.09119
G1 X121.052 Y132.781 E.00924
G1 X123.513 Y135.242 E.08466
G1 X123.513 Y134.723 E.01262
G1 X121.242 Y132.452 E.07812
G1 X121.432 Y132.123 E.00924
G1 X123.513 Y134.204 E.07159
G1 X123.513 Y133.685 E.01262
G1 X121.622 Y131.795 E.06503
G1 X121.812 Y131.466 E.00924
G1 X123.513 Y133.167 E.05851
G1 X123.513 Y132.648 E.01262
G1 X122.002 Y131.137 E.05198
G1 X122.193 Y130.809 E.00923
G1 X123.513 Y132.129 E.04541
G1 X123.513 Y131.61 E.01262
G1 X122.383 Y130.48 E.03887
G1 X122.573 Y130.151 E.00924
G1 X123.513 Y131.092 E.03235
G1 X123.513 Y130.573 E.01262
G1 X122.753 Y129.812 E.02616
G1 X122.902 Y129.443 E.00968
G1 X123.513 Y130.054 E.02102
G1 X123.513 Y129.535 E.01262
G1 X123.027 Y129.05 E.0167
G1 X123.113 Y128.617 E.01074
G1 X123.513 Y129.017 E.01376
G1 X123.513 Y128.498 E.01262
G1 X123.157 Y128.142 E.01225
G1 X123.136 Y127.601 E.01317
G1 X123.513 Y127.979 E.01299
G1 X123.513 Y127.46 E.01262
G1 X123.045 Y126.992 E.0161
G1 X122.741 Y126.169 E.02134
G1 X123.513 Y126.941 E.02656
G1 X123.513 Y126.423 E.0126
G1 X122.079 Y124.988 E.04935
G1 X121.363 Y123.754 E.0347
G1 X123.678 Y126.068 E.07962
G1 E-5 F3600
G1 X123.678 Y126.068 F9000
G1 X118.963 Y121.354
G1 E5 F2400
G1 F3072.127
G1 X118.571 Y120.962 E.01348
G1 X118.958 Y120.83 E.00995
G1 X123.513 Y125.385 E.15669
G1 X123.513 Y124.866 E.01262
G1 X119.303 Y120.656 E.14482
G1 X119.622 Y120.457 E.00915
G1 X123.513 Y124.348 E.13385
G1 X123.513 Y123.829 E.01262
G1 X119.914 Y120.23 E.1238
G1 X120.188 Y119.985 E.00894
G1 X123.513 Y123.31 E.11438
G1 X123.513 Y122.791 E.01262
G1 X120.436 Y119.714 E.10585
G1 X120.664 Y119.423 E.00899
G1 X123.513 Y122.273 E.09802
G1 X123.513 Y121.754 E.01262
G1 X120.865 Y119.105 E.09111
G1 X121.055 Y118.776 E.00924
G1 X123.513 Y121.235 E.08457
G1 X123.513 Y120.716 E.01262
G1 X121.245 Y118.448 E.07802
G1 X121.435 Y118.119 E.00924
G1 X123.513 Y120.197 E.07148
G1 X123.513 Y119.679 E.0126
G1 X121.625 Y117.79 E.06496
G1 X121.815 Y117.462 E.00922
G1 X123.513 Y119.16 E.05841
G1 X123.513 Y118.641 E.01262
G1 X122.005 Y117.133 E.05187
G1 X122.195 Y116.804 E.00924
G1 X123.513 Y118.122 E.04534
G1 X123.513 Y117.604 E.0126
G1 X122.385 Y116.476 E.0388
G1 X122.575 Y116.147 E.00924
G1 X123.513 Y117.085 E.03227
G1 X123.513 Y116.566 E.01262
G1 X122.754 Y115.807 E.02611
G1 X122.902 Y115.436 E.00972
G1 X123.513 Y116.047 E.02102
G1 X123.513 Y115.528 E.01262
G1 X123.031 Y115.046 E.01658
G1 X123.118 Y114.615 E.0107
G1 X123.513 Y115.01 E.01359
G1 X123.513 Y114.491 E.01262
G1 X123.159 Y114.137 E.01218
G1 X123.135 Y113.594 E.01322
G1 X123.513 Y113.972 E.013
G1 X123.513 Y113.453 E.01262
G1 X123.042 Y112.983 E.01618
G1 X122.734 Y112.156 E.02147
G1 X123.513 Y112.935 E.0268
G1 X123.513 Y112.416 E.01262
G1 X122.069 Y110.972 E.04967
G1 X121.353 Y109.737 E.03472
G1 X123.678 Y112.062 E.07998
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X121.445 Y109.829 E-1.5
;WIPE_END
G1 X121.781 Y100.115 F9000
G1 X121.781 Y99.885
G1 X120.953 Y89.7
G1 X120.915 Y88.151
G1 X120.877 Y86.599
G1 X121.199 Y85.151
G1 X120.85 Y85.5
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X120.85 Y85.237 E.0064
G1 X120.784 Y85.097 E.00376
G1 X120.667 Y85.054 E.00303
G1 X110.333 Y85.054 E.25136
G1 X110.256 Y85.072 E.00192
G1 X110.15 Y85.237 E.00477
G1 X110.15 Y85.5 E.0064
G1 X104.557 Y85.5 E.13604
G1 X103.988 Y85.458 E.01388
G1 X103.44 Y85.334 E.01367
G1 X102.856 Y85.1 E.0153
G1 X102.41 Y84.839 E.01257
G1 X102.051 Y84.543 E.01132
G1 X101.585 Y84.075 E.01606
G1 X101.127 Y83.348 E.0209
G1 X100.87 Y82.635 E.01844
G1 X100.761 Y81.979 E.01618
G1 X100.75 Y78.888 E.07519
G1 X100.695 Y78.758 E.00343
G1 X100.136 Y78.214 E.01897
G1 X99.821 Y77.822 E.01223
G1 X99.693 Y77.524 E.00789
G1 X99.747 Y77.317 E.0052
G1 X100.033 Y76.898 E.01234
G1 X100.583 Y76.351 E.01887
G1 X130.417 Y76.351 E.72568
G1 X130.751 Y76.682 E.01144
G1 X131.175 Y77.158 E.01551
G1 X131.3 Y77.46 E.00795
G1 X131.291 Y77.587 E.0031
G1 X131.126 Y77.909 E.0088
G1 X130.301 Y78.762 E.02887
G1 X130.25 Y78.888 E.00331
G1 X130.24 Y81.704 E.0685
G1 X130.197 Y82.262 E.01361
G1 X130.072 Y82.812 E.01372
G1 X129.862 Y83.346 E.01396
G1 X129.576 Y83.841 E.01391
G1 X129.227 Y84.278 E.0136
G1 X128.799 Y84.672 E.01415
G1 X128.282 Y85.019 E.01515
G1 X127.83 Y85.24 E.01224
G1 X127.289 Y85.406 E.01376
G1 X126.731 Y85.489 E.01372
G1 X120.91 Y85.5 E.14159
G1 X120.91 Y85.5 F9000
G1 X121.192 Y85.133
;TYPE:Perimeter
G1 F6000
G1 X121.167 Y85.133 E.00061
G1 X121.018 Y84.816 E.00852
G1 X120.898 Y84.74 E.00346
G1 X120.667 Y84.689 E.00575
G1 X110.333 Y84.689 E.25136
G1 X110.252 Y84.695 E.00198
G1 X109.981 Y84.816 E.00722
G1 X109.832 Y85.134 E.00854
G1 X105.332 Y85.134 E.10946
G1 X104.303 Y85.114 E.02503
G1 X103.804 Y85.041 E.01227
G1 X103.278 Y84.875 E.01342
G1 X102.825 Y84.658 E.01222
G1 X102.283 Y84.261 E.01634
G1 X101.877 Y83.853 E.014
G1 X101.458 Y83.187 E.01914
G1 X101.225 Y82.542 E.01668
G1 X101.127 Y81.948 E.01464
G1 X101.116 Y78.887 E.07446
G1 X101.083 Y78.702 E.00457
G1 X100.95 Y78.496 E.00596
G1 X100.192 Y77.719 E.0264
G1 X100.064 Y77.5 E.00617
G1 X100.306 Y77.142 E.01051
G1 X100.733 Y76.717 E.01465
G1 X130.267 Y76.717 E.71839
G1 X130.694 Y77.142 E.01465
G1 X130.936 Y77.5 E.01051
G1 X130.835 Y77.684 E.00511
G1 X130.039 Y78.508 E.02787
G1 X129.915 Y78.708 E.00572
G1 X129.884 Y78.887 E.00442
G1 X129.873 Y81.953 E.07458
G1 X129.797 Y82.46 E.01247
G1 X129.646 Y82.953 E.01254
G1 X129.421 Y83.419 E.01259
G1 X129.131 Y83.843 E.01249
G1 X128.785 Y84.216 E.01238
G1 X128.176 Y84.657 E.01829
G1 X127.701 Y84.897 E.01294
G1 X127.208 Y85.048 E.01254
G1 X126.704 Y85.123 E.01239
G1 X121.252 Y85.133 E.13261
G1 X121.252 Y85.133 F9000
G1 X121.296 Y84.628
G1 F6000
G1 X121.252 Y84.535 E.0025
G1 X120.931 Y84.362 E.00887
G1 X120.667 Y84.323 E.00649
G1 X110.333 Y84.323 E.25136
G1 X110.068 Y84.362 E.00652
G1 X109.747 Y84.536 E.00888
G1 X109.638 Y84.769 E.00626
G1 X105.332 Y84.769 E.10474
G1 X104.314 Y84.749 E.02477
G1 X103.658 Y84.633 E.0162
G1 X103.01 Y84.343 E.01727
G1 X102.623 Y84.067 E.01156
G1 X102.169 Y83.63 E.01533
G1 X101.789 Y83.026 E.01736
G1 X101.581 Y82.449 E.01492
G1 X101.492 Y81.918 E.0131
G1 X101.481 Y78.886 E.07375
G1 X101.427 Y78.577 E.00763
G1 X101.205 Y78.234 E.00994
G1 X100.487 Y77.501 E.02496
G1 X100.884 Y77.083 E.01402
G1 X130.116 Y77.083 E.71104
G1 X130.509 Y77.496 E.01387
G1 X129.776 Y78.253 E.02563
G1 X129.57 Y78.588 E.00957
G1 X129.519 Y78.886 E.00735
G1 X129.509 Y81.701 E.06847
G1 X129.44 Y82.379 E.01658
G1 X129.203 Y83.029 E.01683
G1 X128.844 Y83.615 E.01672
G1 X128.344 Y84.1 E.01694
G1 X127.807 Y84.45 E.01559
G1 X127.344 Y84.624 E.01203
G1 X126.676 Y84.758 E.01657
G1 X121.361 Y84.767 E.12928
G1 X121.322 Y84.683 E.00225
G1 X121.322 Y84.683 F9000
G1 X121.541 Y84.37
G1 F6000
G1 X121.486 Y84.254 E.00312
G1 X121.036 Y84.012 E.01243
G1 X120.667 Y83.957 E.00907
G1 X110.333 Y83.957 E.25136
G1 X109.963 Y84.012 E.0091
G1 X109.512 Y84.255 E.01246
G1 X109.443 Y84.403 E.00397
G1 X104.493 Y84.395 E.1204
G1 X103.965 Y84.328 E.01295
G1 X103.339 Y84.112 E.01611
G1 X102.855 Y83.784 E.01422
G1 X102.461 Y83.408 E.01325
G1 X102.119 Y82.865 E.01561
G1 X101.936 Y82.356 E.01316
G1 X101.858 Y81.887 E.01156
G1 X101.847 Y78.884 E.07305
G1 X101.77 Y78.453 E.01065
G1 X101.459 Y77.971 E.01395
G1 X100.979 Y77.504 E.01629
G1 X101.035 Y77.448 E.00193
G1 X129.948 Y77.448 E.70328
G1 X130.006 Y77.489 E.00173
G1 X129.513 Y77.999 E.01725
G1 X129.224 Y78.467 E.01338
G1 X129.153 Y78.884 E.01029
G1 X129.146 Y80.933 E.04984
G1 X129.112 Y82.099 E.02837
G1 X128.963 Y82.686 E.01473
G1 X128.67 Y83.222 E.01486
G1 X128.286 Y83.678 E.0145
G1 X127.728 Y84.073 E.01663
G1 X127.237 Y84.274 E.01291
G1 X126.649 Y84.392 E.01459
G1 X121.581 Y84.401 E.12327
G1 X121.581 Y84.401 F9000
G1 X121.812 Y84.035
G1 F6000
G1 X121.75 Y84.035 E.00151
G1 X121.721 Y83.973 E.00166
G1 X121.36 Y83.745 E.01039
G1 X121.141 Y83.662 E.0057
G1 X120.667 Y83.592 E.01165
G1 X110.333 Y83.592 E.25136
G1 X110.091 Y83.61 E.0059
G1 X109.638 Y83.746 E.0115
G1 X109.278 Y83.975 E.01038
G1 X109.248 Y84.037 E.00168
G1 X104.612 Y84.037 E.11277
G1 X104.046 Y83.971 E.01386
G1 X103.5 Y83.782 E.01405
G1 X103.134 Y83.54 E.01067
G1 X102.753 Y83.185 E.01267
G1 X102.45 Y82.703 E.01385
G1 X102.291 Y82.263 E.01138
G1 X102.223 Y81.856 E.01004
G1 X102.213 Y78.883 E.07232
G1 X102.114 Y78.328 E.01371
G1 X101.782 Y77.814 E.01488
G1 X129.208 Y77.814 E.66711
G1 X128.879 Y78.347 E.01524
G1 X128.787 Y78.883 E.01323
G1 X128.78 Y80.932 E.04984
G1 X128.75 Y82.045 E.02708
G1 X128.621 Y82.552 E.01273
G1 X128.368 Y83.015 E.01283
G1 X128.037 Y83.409 E.01252
G1 X127.543 Y83.757 E.0147
G1 X127.13 Y83.925 E.01085
G1 X126.621 Y84.027 E.01263
G1 X121.872 Y84.035 E.11551
G1 E-5 F3600
G1 X121.872 Y84.035 F9000
G1 X128.761 Y78.404
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X128.445 Y78.088 E.01087
G1 X127.921 Y78.088 E.01275
G1 X128.542 Y78.709 E.02136
G1 X128.512 Y79.204 E.01206
G1 X127.397 Y78.088 E.03837
G1 X126.872 Y78.088 E.01277
G1 X128.51 Y79.726 E.05635
G1 X128.508 Y80.249 E.01272
G1 X126.348 Y78.088 E.07432
G1 X125.823 Y78.088 E.01277
G1 X128.506 Y80.771 E.09229
G1 X128.505 Y81.293 E.0127
G1 X125.299 Y78.088 E.11027
G1 X124.775 Y78.088 E.01275
G1 X128.503 Y81.816 E.12824
G1 X128.424 Y82.261 E.01099
G1 X124.25 Y78.088 E.14357
G1 X123.726 Y78.088 E.01275
G1 X128.276 Y82.638 E.15652
G1 X128.074 Y82.96 E.00925
G1 X123.202 Y78.088 E.16759
G1 X122.677 Y78.088 E.01277
G1 X127.821 Y83.231 E.17693
G1 X127.516 Y83.451 E.00915
G1 X122.153 Y78.088 E.18448
G1 X121.629 Y78.088 E.01275
G1 X127.167 Y83.627 E.19052
G1 X126.904 Y83.707 E.00669
G1 X126.747 Y83.731 E.00386
G1 X121.104 Y78.088 E.19412
G1 X120.58 Y78.088 E.01275
G1 X126.245 Y83.753 E.19487
G1 X125.722 Y83.754 E.01272
G1 X120.056 Y78.088 E.19491
G1 X119.531 Y78.088 E.01277
G1 X125.198 Y83.755 E.19494
G1 X124.675 Y83.756 E.01272
G1 X119.007 Y78.088 E.19498
G1 X118.483 Y78.088 E.01275
G1 X124.151 Y83.757 E.19499
G1 X123.628 Y83.758 E.01272
G1 X117.958 Y78.088 E.19504
G1 X117.434 Y78.088 E.01275
G1 X123.105 Y83.759 E.19508
G1 X122.581 Y83.76 E.01275
G1 X116.91 Y78.088 E.1951
G1 X116.385 Y78.088 E.01277
G1 X122.058 Y83.761 E.19515
G1 X121.874 Y83.761 E.00448
G1 X121.479 Y83.497 E.01156
G1 X121.158 Y83.385 E.00827
G1 X115.861 Y78.088 E.18221
G1 X115.337 Y78.088 E.01275
G1 X120.566 Y83.318 E.17989
G1 X120.042 Y83.318 E.01275
G1 X114.812 Y78.088 E.17991
G1 X114.288 Y78.088 E.01275
G1 X119.517 Y83.318 E.17989
G1 X118.993 Y83.318 E.01275
G1 X113.764 Y78.088 E.17989
G1 X113.239 Y78.088 E.01277
G1 X118.469 Y83.318 E.17991
G1 X117.944 Y83.318 E.01277
G1 X112.715 Y78.088 E.17989
G1 X112.191 Y78.088 E.01275
G1 X117.42 Y83.318 E.17989
G1 X116.896 Y83.318 E.01275
G1 X111.666 Y78.088 E.17991
G1 X111.142 Y78.088 E.01275
G1 X116.371 Y83.318 E.17989
G1 X115.847 Y83.318 E.01275
G1 X110.618 Y78.088 E.17989
G1 X110.093 Y78.088 E.01277
G1 X115.323 Y83.318 E.17991
G1 X114.798 Y83.318 E.01277
G1 X109.569 Y78.088 E.17989
G1 X109.044 Y78.088 E.01277
G1 X114.274 Y83.318 E.17991
G1 X113.75 Y83.318 E.01275
G1 X108.52 Y78.088 E.17991
G1 X107.996 Y78.088 E.01275
G1 X113.225 Y83.318 E.17989
G1 X112.701 Y83.318 E.01275
G1 X107.471 Y78.088 E.17991
G1 X106.947 Y78.088 E.01275
G1 X112.177 Y83.318 E.17991
G1 X111.652 Y83.318 E.01277
G1 X106.423 Y78.088 E.17989
G1 X105.898 Y78.088 E.01277
G1 X111.128 Y83.318 E.17991
G1 X110.604 Y83.318 E.01275
G1 X105.374 Y78.088 E.17991
G1 X104.85 Y78.088 E.01275
G1 X110.096 Y83.335 E.18048
G1 X109.676 Y83.438 E.01052
G1 X104.325 Y78.088 E.18405
G1 X103.801 Y78.088 E.01275
G1 X109.334 Y83.621 E.19033
G1 X109.123 Y83.763 E.00619
G1 X108.952 Y83.763 E.00416
G1 X103.277 Y78.088 E.19522
G1 X102.752 Y78.088 E.01277
G1 X108.427 Y83.763 E.19522
G1 X107.903 Y83.763 E.01275
G1 X102.373 Y78.233 E.19023
G1 X102.486 Y78.871 E.01576
G1 X107.379 Y83.763 E.1683
G1 X106.854 Y83.763 E.01277
G1 X102.489 Y79.397 E.15017
G1 X102.491 Y79.924 E.01282
G1 X106.33 Y83.763 E.13206
G1 X105.806 Y83.763 E.01275
G1 X102.492 Y80.45 E.11398
G1 X102.494 Y80.976 E.01279
G1 X105.281 Y83.763 E.09587
G1 X104.757 Y83.763 E.01275
G1 X102.496 Y81.502 E.07778
G1 X102.536 Y82.067 E.01378
G1 X104.193 Y83.723 E.05698
G1 X103.957 Y83.67 E.00588
G1 X103.407 Y83.41 E.0148
G1 X102.52 Y82.575 E.02963
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X103.407 Y83.41 E-.57864
G1 X103.957 Y83.67 E-.28897
G1 X104.193 Y83.723 E-.11489
G1 X103.423 Y82.953 E-.5175
;WIPE_END
G1 X104.056 Y85.115 F9000
G1 X104.491 Y86.599
G1 X105.067 Y88.151
G1 X105.067 Y88.567
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.151 Y88.503 E.00257
G1 X125.817 Y88.5 E.50268
G1 X125.961 Y88.57 E.00389
G1 X126 Y88.683 E.00291
G1 X126 Y89.133 E.01095
G1 X126.653 Y89.816 E.02298
G1 X126.893 Y90.226 E.01156
G1 X126.941 Y90.537 E.00765
G1 X126.87 Y90.831 E.00736
G1 X126.656 Y91.181 E.00998
G1 X126.324 Y91.556 E.01218
G1 X126 Y91.871 E.01099
G1 X126 Y92.647 E.01888
G1 X139.202 Y92.646 E.32113
G1 X139.511 Y92.728 E.00778
G1 X139.785 Y92.991 E.00924
G1 X139.9 Y93.409 E.01055
G1 X139.9 Y95.42 E.04892
G1 X139.85 Y95.707 E.00709
G1 X139.709 Y95.943 E.00669
G1 X139.412 Y96.145 E.00874
G1 X138.996 Y96.182 E.01016
G1 X136.7 Y96.182 E.05585
G1 X136.698 Y132.81 E.89094
G1 X136.642 Y133.68 E.02121
G1 X136.554 Y134.317 E.01564
G1 X136.444 Y134.867 E.01364
G1 X136.266 Y135.543 E.017
G1 X136.105 Y136.033 E.01255
G1 X135.871 Y136.628 E.01555
G1 X135.57 Y137.265 E.01714
G1 X135.309 Y137.741 E.0132
G1 X135.01 Y138.223 E.0138
G1 X134.672 Y138.702 E.01426
G1 X134.25 Y139.229 E.01642
G1 X133.855 Y139.667 E.01435
G1 X133.387 Y140.123 E.01589
G1 X132.661 Y140.729 E.023
G1 X132.075 Y141.141 E.01742
G1 X131.051 Y141.728 E.02871
G1 X130.548 Y141.962 E.01349
G1 X129.866 Y142.229 E.01781
G1 X128.626 Y142.61 E.03155
G1 X128.104 Y142.734 E.01305
G1 X127.577 Y142.826 E.01301
G1 X126.763 Y142.897 E.01987
G1 X125.482 Y142.902 E.03116
G1 X125.115 Y142.8 E.00927
G1 X120.483 Y142.8 E.11267
G1 X120.353 Y142.746 E.00342
G1 X120.3 Y142.617 E.00339
G1 X120.3 Y142.267 E.00851
G1 X110.7 Y142.267 E.23351
G1 X110.7 Y142.617 E.00851
G1 X110.607 Y142.776 E.00448
G1 X110.517 Y142.8 E.00227
G1 X105.841 Y142.8 E.11374
G1 X105.518 Y142.902 E.00824
G1 X104.5 Y142.902 E.02476
G1 X103.696 Y142.859 E.01958
G1 X102.555 Y142.657 E.02819
G1 X101.607 Y142.384 E.024
G1 X100.855 Y142.127 E.01933
G1 X100.33 Y141.909 E.01383
G1 X99.804 Y141.654 E.01422
G1 X99.134 Y141.274 E.01874
G1 X98.353 Y140.739 E.02303
G1 X97.801 Y140.291 E.01729
G1 X97.28 Y139.804 E.01735
G1 X96.868 Y139.367 E.01461
G1 X96.335 Y138.712 E.02054
G1 X95.996 Y138.232 E.01429
G1 X95.696 Y137.749 E.01383
G1 X95.325 Y137.057 E.0191
G1 X95.089 Y136.533 E.01398
G1 X94.898 Y136.042 E.01281
G1 X94.737 Y135.554 E.0125
G1 X94.6 Y135.054 E.01261
G1 X94.448 Y134.33 E.01799
G1 X94.331 Y133.389 E.02307
G1 X94.302 Y132.81 E.0141
G1 X94.3 Y96.182 E.89094
G1 X91.798 Y96.182 E.06086
G1 X91.526 Y96.121 E.00678
G1 X91.312 Y95.967 E.00641
G1 X91.133 Y95.651 E.00883
G1 X91.1 Y95.42 E.00568
G1 X91.108 Y93.302 E.05152
G1 X91.205 Y93.004 E.00762
G1 X91.371 Y92.803 E.00634
G1 X91.588 Y92.683 E.00603
G1 X91.798 Y92.646 E.00519
G1 X105 Y92.647 E.32113
G1 X105 Y91.867 E.01897
G1 X104.349 Y91.186 E.02292
G1 X104.107 Y90.774 E.01162
G1 X104.059 Y90.463 E.00765
G1 X104.151 Y90.133 E.00833
G1 X104.344 Y89.819 E.00897
G1 X104.676 Y89.444 E.01218
G1 X105 Y89.129 E.01099
G1 X105.017 Y88.605 E.01275
G1 X105.02 Y88.603 E.00009
G1 X105.02 Y88.603 F9000
G1 X104.793 Y88.306
;TYPE:Perimeter
G1 F6000
G1 X104.805 Y88.286 E.00057
G1 X105.183 Y88.134 E.00991
G1 X125.817 Y88.134 E.5019
G1 X126.101 Y88.217 E.0072
G1 X126.269 Y88.377 E.00564
G1 X126.356 Y88.595 E.00571
G1 X126.364 Y88.984 E.00946
G1 X126.916 Y89.561 E.01942
G1 X127.197 Y90.007 E.01282
G1 X127.302 Y90.45 E.01107
G1 X127.231 Y90.9 E.01108
G1 X126.952 Y91.392 E.01376
G1 X126.366 Y92.021 E.02091
G1 X126.366 Y92.281 E.00632
G1 X139.202 Y92.28 E.31222
G1 X139.659 Y92.398 E.01148
G1 X139.867 Y92.536 E.00607
G1 X140.082 Y92.784 E.00798
;WIDTH:0.438052
G1 X140.146 Y92.927 E.00421
;WIDTH:0.476104
G1 X140.21 Y93.07 E.0046
;WIDTH:0.514156
G1 X140.273 Y93.213 E.00499
;WIDTH:0.552208
G1 X140.337 Y93.356 E.0054
G1 X140.34 Y93.409 E.00183
;WIDTH:0.547018
G1 X140.34 Y95.42 E.06858
G1 X140.282 Y95.577 E.00571
;WIDTH:0.498012
G1 X140.224 Y95.733 E.00513
;WIDTH:0.449006
G1 X140.166 Y95.889 E.00459
;WIDTH:0.399999
G1 X139.918 Y96.243 E.01051
G1 X139.476 Y96.505 E.0125
G1 X138.996 Y96.548 E.01172
G1 X137.066 Y96.548 E.04695
G1 X137.065 Y102.714 E.14998
G1 X139.225 Y102.716 E.05254
G1 X139.402 Y102.746 E.00437
G1 X139.686 Y102.888 E.00772
G1 X139.962 Y103.183 E.00983
G1 X140.09 Y103.513 E.00861
G1 X140.145 Y104.022 E.01245
G1 X140.077 Y104.535 E.01259
G1 X139.932 Y104.865 E.00877
G1 X139.743 Y105.078 E.00693
G1 X139.501 Y105.226 E.0069
G1 X139.225 Y105.284 E.00686
G1 X137.065 Y105.286 E.05254
G1 X137.065 Y110.714 E.13203
G1 X139.225 Y110.716 E.05254
G1 X139.402 Y110.746 E.00437
G1 X139.686 Y110.888 E.00772
G1 X139.962 Y111.183 E.00983
G1 X140.09 Y111.513 E.00861
G1 X140.145 Y112.022 E.01245
G1 X140.077 Y112.535 E.01259
G1 X139.932 Y112.865 E.00877
G1 X139.743 Y113.078 E.00693
G1 X139.501 Y113.226 E.0069
G1 X139.225 Y113.284 E.00686
G1 X137.065 Y113.286 E.05254
G1 X137.064 Y118.714 E.13203
G1 X139.225 Y118.716 E.05256
G1 X139.402 Y118.746 E.00437
G1 X139.686 Y118.888 E.00772
G1 X139.962 Y119.183 E.00983
G1 X140.09 Y119.513 E.00861
G1 X140.145 Y120.022 E.01245
G1 X140.077 Y120.535 E.01259
G1 X139.932 Y120.865 E.00877
G1 X139.743 Y121.078 E.00693
G1 X139.501 Y121.226 E.0069
G1 X139.225 Y121.284 E.00686
G1 X137.064 Y121.286 E.05256
G1 X137.064 Y126.714 E.13203
G1 X139.225 Y126.716 E.05256
G1 X139.402 Y126.746 E.00437
G1 X139.686 Y126.888 E.00772
G1 X139.962 Y127.183 E.00983
G1 X140.09 Y127.513 E.00861
G1 X140.145 Y128.022 E.01245
G1 X140.077 Y128.535 E.01259
G1 X139.932 Y128.865 E.00877
G1 X139.743 Y129.078 E.00693
G1 X139.501 Y129.226 E.0069
G1 X139.225 Y129.284 E.00686
G1 X137.064 Y129.286 E.05256
G1 X137.063 Y132.81 E.08572
G1 X137.007 Y133.704 E.02179
G1 X136.916 Y134.368 E.0163
G1 X136.847 Y134.714 E.00858
G1 X139.225 Y134.716 E.05784
G1 X139.402 Y134.746 E.00437
G1 X139.686 Y134.888 E.00772
G1 X139.962 Y135.183 E.00983
G1 X140.09 Y135.513 E.00861
G1 X140.145 Y136.022 E.01245
G1 X140.077 Y136.535 E.01259
G1 X139.932 Y136.865 E.00877
G1 X139.743 Y137.078 E.00693
G1 X139.501 Y137.226 E.0069
G1 X139.225 Y137.284 E.00686
G1 X135.964 Y137.287 E.07932
G1 X135.63 Y137.917 E.01734
G1 X135.321 Y138.416 E.01428
G1 X134.971 Y138.913 E.01479
G1 X134.535 Y139.458 E.01698
G1 X134.126 Y139.912 E.01486
G1 X133.642 Y140.385 E.01646
G1 X132.895 Y141.009 E.02368
G1 X132.285 Y141.44 E.01817
G1 X131.233 Y142.045 E.02952
G1 X130.702 Y142.294 E.01427
G1 X130.012 Y142.565 E.01803
G1 X129.528 Y142.714 E.01232
G1 X139.225 Y142.716 E.23587
G1 X139.402 Y142.746 E.00437
G1 X139.686 Y142.888 E.00772
G1 X139.962 Y143.183 E.00983
G1 X140.09 Y143.513 E.00861
G1 X140.145 Y144.022 E.01245
G1 X140.077 Y144.535 E.01259
G1 X139.932 Y144.865 E.00877
G1 X139.743 Y145.078 E.00693
G1 X139.501 Y145.226 E.0069
G1 X139.225 Y145.284 E.00686
G1 X125.3 Y145.288 E.33871
G1 X125.16 Y145.223 E.00375
G1 X125.117 Y145.105 E.00305
G1 X125.117 Y143.171 E.04704
G1 X120.436 Y143.163 E.11386
G1 X120.142 Y143.038 E.00777
G1 X120.054 Y142.944 E.00313
G1 X119.937 Y142.632 E.00811
G1 X111.063 Y142.632 E.21585
G1 X110.946 Y142.944 E.00811
G1 X110.858 Y143.038 E.00313
G1 X110.564 Y143.163 E.00777
G1 X105.888 Y143.171 E.11374
G1 X105.883 Y145.105 E.04704
G1 X105.826 Y145.238 E.00352
G1 X105.7 Y145.288 E.0033
G1 X91.775 Y145.284 E.33871
G1 X91.598 Y145.254 E.00437
G1 X91.314 Y145.112 E.00772
G1 X91.038 Y144.817 E.00983
G1 X90.91 Y144.487 E.00861
G1 X90.855 Y143.978 E.01245
G1 X90.923 Y143.465 E.01259
G1 X91.068 Y143.135 E.00877
G1 X91.257 Y142.922 E.00693
G1 X91.499 Y142.774 E.0069
G1 X91.775 Y142.716 E.00686
G1 X101.441 Y142.713 E.23512
G1 X100.737 Y142.473 E.01809
G1 X100.259 Y142.275 E.01258
G1 X99.645 Y141.984 E.01653
G1 X98.953 Y141.592 E.01935
G1 X98.146 Y141.04 E.02378
G1 X97.571 Y140.575 E.01799
G1 X97.03 Y140.071 E.01798
G1 X96.602 Y139.618 E.01516
G1 X96.052 Y138.943 E.02118
G1 X95.697 Y138.443 E.01492
G1 X95.385 Y137.942 E.01436
G1 X95.036 Y137.287 E.01805
G1 X91.775 Y137.284 E.07932
G1 X91.598 Y137.254 E.00437
G1 X91.314 Y137.112 E.00772
G1 X91.038 Y136.817 E.00983
G1 X90.91 Y136.487 E.00861
G1 X90.855 Y135.978 E.01245
G1 X90.923 Y135.465 E.01259
G1 X91.068 Y135.135 E.00877
G1 X91.257 Y134.922 E.00693
G1 X91.499 Y134.774 E.0069
G1 X91.775 Y134.716 E.00686
G1 X94.155 Y134.714 E.05789
G1 X93.969 Y133.434 E.03146
G1 X93.937 Y132.838 E.01452
G1 X93.936 Y129.287 E.08637
G1 X91.775 Y129.284 E.05256
G1 X91.598 Y129.254 E.00437
G1 X91.314 Y129.112 E.00772
G1 X91.038 Y128.817 E.00983
G1 X90.91 Y128.487 E.00861
G1 X90.855 Y127.978 E.01245
G1 X90.91 Y127.513 E.01139
G1 X91.068 Y127.135 E.00997
G1 X91.257 Y126.922 E.00693
G1 X91.499 Y126.774 E.0069
G1 X91.775 Y126.716 E.00686
G1 X93.936 Y126.714 E.05256
G1 X93.936 Y121.286 E.13203
G1 X91.775 Y121.284 E.05256
G1 X91.598 Y121.254 E.00437
G1 X91.314 Y121.112 E.00772
G1 X91.038 Y120.817 E.00983
G1 X90.91 Y120.487 E.00861
G1 X90.855 Y119.978 E.01245
G1 X90.923 Y119.465 E.01259
G1 X91.068 Y119.135 E.00877
G1 X91.257 Y118.922 E.00693
G1 X91.499 Y118.774 E.0069
G1 X91.775 Y118.716 E.00686
G1 X93.936 Y118.714 E.05256
G1 X93.935 Y113.286 E.13203
G1 X91.775 Y113.284 E.05254
G1 X91.598 Y113.254 E.00437
G1 X91.314 Y113.112 E.00772
G1 X91.038 Y112.817 E.00983
G1 X90.91 Y112.487 E.00861
G1 X90.855 Y111.978 E.01245
G1 X90.923 Y111.465 E.01259
G1 X91.068 Y111.135 E.00877
G1 X91.257 Y110.922 E.00693
G1 X91.499 Y110.774 E.0069
G1 X91.775 Y110.716 E.00686
G1 X93.935 Y110.714 E.05254
G1 X93.935 Y105.286 E.13203
G1 X91.775 Y105.284 E.05254
G1 X91.598 Y105.254 E.00437
G1 X91.314 Y105.112 E.00772
G1 X91.038 Y104.817 E.00983
G1 X90.91 Y104.487 E.00861
G1 X90.855 Y103.978 E.01245
G1 X90.923 Y103.465 E.01259
G1 X91.068 Y103.135 E.00877
G1 X91.257 Y102.922 E.00693
G1 X91.499 Y102.774 E.0069
G1 X91.775 Y102.716 E.00686
G1 X93.935 Y102.714 E.05254
G1 X93.934 Y96.548 E.14998
G1 X92.001 Y96.548 E.04702
G1 X91.47 Y96.487 E.013
G1 X91.129 Y96.29 E.00958
;WIDTH:0.405113
G1 X90.823 Y95.86 E.01302
;WIDTH:0.454207
G1 X90.77 Y95.732 E.00387
;WIDTH:0.503301
G1 X90.716 Y95.603 E.00436
;WIDTH:0.552395
G1 X90.662 Y95.475 E.00479
;WIDTH:0.554305
G1 X90.665 Y93.301 E.0752
G1 X90.711 Y93.201 E.00381
;WIDTH:0.515729
G1 X90.758 Y93.101 E.00354
;WIDTH:0.477152
G1 X90.804 Y93.001 E.00324
;WIDTH:0.438576
G1 X90.85 Y92.901 E.00296
;WIDTH:0.399999
G1 X91.066 Y92.593 E.00915
G1 X91.388 Y92.374 E.00947
G1 X91.798 Y92.28 E.01023
G1 X104.634 Y92.281 E.31222
G1 X104.634 Y92.014 E.00649
G1 X104.084 Y91.439 E.01935
G1 X103.796 Y90.972 E.01335
G1 X103.698 Y90.55 E.01054
G1 X103.768 Y90.102 E.01103
G1 X104.023 Y89.64 E.01284
G1 X104.636 Y88.976 E.02198
G1 X104.664 Y88.523 E.01104
G1 X104.763 Y88.357 E.0047
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X104.793 Y88.306 E-.02811
G1 X104.805 Y88.286 E-.01108
G1 X105.183 Y88.134 E-.19352
G1 X107.851 Y88.134 E-1.26729
;WIPE_END
G1 X107.851 Y88.151 F9000
G1 X110.638 Y86.599
G1 X110.638 Y86.194
G1 E5 F2400
G1 F6000
G1 X110.517 Y86.25 E.00324
G1 X104.199 Y86.25 E.15368
G1 X103.586 Y86.204 E.01495
G1 X103.023 Y86.081 E.01402
G1 X102.618 Y85.94 E.01043
G1 X102.096 Y85.684 E.01414
G1 X101.364 Y85.147 E.02208
G1 X100.765 Y84.463 E.02212
G1 X100.388 Y83.81 E.01834
G1 X100.128 Y83.07 E.01908
G1 X100.011 Y82.34 E.01798
G1 X100 Y78.868 E.08445
G1 X99.349 Y78.186 E.02293
G1 X99.107 Y77.774 E.01162
G1 X99.059 Y77.463 E.00765
G1 X99.13 Y77.169 E.00736
G1 X99.344 Y76.819 E.00998
G1 X99.676 Y76.444 E.01218
G1 X100 Y76.129 E.01099
G1 X100.004 Y75.82 E.00752
G1 X100.056 Y75.727 E.00259
G1 X100.183 Y75.676 E.00333
G1 X130.817 Y75.676 E.74514
G1 X130.946 Y75.729 E.00339
G1 X131 Y75.859 E.00342
G1 X131 Y76.133 E.00666
G1 X131.651 Y76.814 E.02292
G1 X131.893 Y77.226 E.01162
G1 X131.941 Y77.537 E.00765
G1 X131.87 Y77.831 E.00736
G1 X131.656 Y78.181 E.00998
G1 X131.324 Y78.556 E.01218
G1 X131 Y78.872 E.01101
G1 X130.989 Y82.34 E.08436
G1 X130.935 Y82.771 E.01057
G1 X130.694 Y83.62 E.02147
G1 X130.24 Y84.458 E.02318
G1 X129.874 Y84.911 E.01417
G1 X129.431 Y85.323 E.01472
G1 X128.663 Y85.813 E.02216
G1 X128.099 Y86.043 E.01482
G1 X127.685 Y86.155 E.01043
G1 X127.115 Y86.238 E.01401
G1 X120.483 Y86.25 E.16132
G1 X120.344 Y86.186 E.00372
G1 X120.3 Y86.067 E.00309
G1 X120.3 Y85.697 E.009
G1 X110.7 Y85.697 E.23351
G1 X110.7 Y86.067 E.009
G1 X110.67 Y86.148 E.0021
G1 X110.67 Y86.148 F9000
G1 X110.895 Y86.451
;TYPE:Perimeter
G1 F6000
G1 X110.718 Y86.574 E.00524
G1 X110.517 Y86.616 E.00499
G1 X104.199 Y86.616 E.15368
G1 X103.586 Y86.573 E.01495
G1 X103.053 Y86.462 E.01324
G1 X102.481 Y86.278 E.01462
G1 X101.877 Y85.977 E.01641
G1 X101.087 Y85.386 E.024
G1 X100.447 Y84.645 E.02382
G1 X100.043 Y83.93 E.01998
G1 X99.768 Y83.133 E.02051
G1 X99.652 Y82.426 E.01743
G1 X99.635 Y79.015 E.08297
G1 X99.084 Y78.439 E.01939
G1 X98.811 Y78.01 E.01237
G1 X98.698 Y77.55 E.01152
G1 X98.769 Y77.1 E.01108
G1 X99.048 Y76.608 E.01376
G1 X99.634 Y75.979 E.02091
G1 X99.649 Y75.787 E.00468
G1 X99.761 Y75.524 E.00695
G1 X99.861 Y75.426 E.00341
G1 X100.183 Y75.311 E.00832
G1 X130.817 Y75.311 E.74514
G1 X131.143 Y75.43 E.00844
G1 X131.235 Y75.512 E.003
G1 X131.359 Y75.783 E.00725
G1 X131.364 Y75.984 E.00489
G1 X131.916 Y76.561 E.01942
G1 X132.231 Y77.099 E.01516
G1 X132.305 Y77.569 E.01157
G1 X132.209 Y77.968 E.00998
G1 X131.95 Y78.397 E.01219
G1 X131.365 Y79.022 E.02082
G1 X131.355 Y82.341 E.08073
G1 X131.292 Y82.845 E.01235
G1 X131.014 Y83.796 E.0241
G1 X130.523 Y84.689 E.02479
G1 X130.122 Y85.18 E.01542
G1 X129.625 Y85.633 E.01636
G1 X128.858 Y86.122 E.02213
G1 X128.108 Y86.407 E.01952
G1 X127.781 Y86.508 E.00832
G1 X127.168 Y86.6 E.01508
G1 X120.483 Y86.616 E.16261
G1 X120.212 Y86.541 E.00684
G1 X120.034 Y86.369 E.00602
G1 X119.93 Y86.067 E.00777
G1 X119.28 Y86.062 E.01581
G1 X111.07 Y86.067 E.1997
G1 X110.938 Y86.412 E.00899
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X110.895 Y86.451 E-.02757
G1 X110.718 Y86.574 E-.10238
G1 X110.517 Y86.616 E-.09754
G1 X107.838 Y86.616 E-1.27251
;WIPE_END
G1 X110.938 Y74.209 F9000
G1 E5 F2400
G1 F6000
G1 X135.674 Y74.205 E.60168
G1 X136.198 Y74.242 E.01278
G1 X136.889 Y74.369 E.01709
G1 X137.391 Y74.52 E.01275
G1 X137.877 Y74.71 E.01269
G1 X138.795 Y75.227 E.02563
G1 X139.601 Y75.9 E.02554
G1 X140.273 Y76.706 E.02553
G1 X140.788 Y77.62 E.02552
G1 X141.131 Y78.612 E.02553
G1 X141.289 Y79.653 E.02561
G1 X141.289 Y80.028 E.00912
G1 X141.3 Y150.994 E1.72618
G1 X141.258 Y151.694 E.01706
G1 X141.134 Y152.378 E.01691
G1 X140.928 Y153.042 E.01691
G1 X140.645 Y153.676 E.01689
G1 X140.288 Y154.272 E.0169
G1 X139.862 Y154.822 E.01692
G1 X139.374 Y155.316 E.01689
G1 X138.749 Y155.803 E.01927
G1 X138.241 Y156.111 E.01445
G1 X137.231 Y156.535 E.02664
G1 X136.49 Y156.714 E.01854
G1 X135.832 Y156.79 E.01611
G1 X95.412 Y156.799 E.98318
G1 X94.765 Y156.753 E.01578
G1 X94.075 Y156.622 E.01708
G1 X93.462 Y156.43 E.01562
G1 X92.848 Y156.157 E.01634
G1 X92.17 Y155.748 E.01926
G1 X91.626 Y155.316 E.0169
G1 X91.138 Y154.822 E.01689
G1 X90.712 Y154.272 E.01692
G1 X90.356 Y153.678 E.01684
G1 X89.989 Y152.802 E.0231
G1 X89.794 Y152.037 E.0192
G1 X89.711 Y151.347 E.0169
G1 X89.7 Y80.006 E1.7353
G1 X89.743 Y79.301 E.01718
G1 X89.869 Y78.612 E.01704
G1 X90.077 Y77.943 E.01704
G1 X90.365 Y77.305 E.01703
G1 X90.727 Y76.705 E.01704
G1 X91.159 Y76.154 E.01703
G1 X91.654 Y75.659 E.01703
G1 X92.205 Y75.227 E.01703
G1 X92.804 Y74.865 E.01702
G1 X93.612 Y74.519 E.02138
G1 X94.109 Y74.37 E.01262
G1 X95.153 Y74.211 E.02569
G1 X110.878 Y74.209 E.38249
G1 X110.878 Y74.209 F9000
G1 X110.878 Y74.574
;TYPE:Perimeter
G1 F6000
G1 X134.806 Y74.571 E.58202
G1 X135.962 Y74.592 E.02812
G1 X136.601 Y74.688 E.01572
G1 X137.124 Y74.822 E.01313
G1 X137.72 Y75.041 E.01544
G1 X138.586 Y75.53 E.02419
G1 X139.341 Y76.159 E.0239
G1 X139.971 Y76.914 E.02392
G1 X140.454 Y77.771 E.02393
G1 X140.774 Y78.7 E.0239
G1 X140.923 Y79.68 E.02411
G1 X140.923 Y80.028 E.00846
G1 X140.925 Y92.76 E.30969
;WIDTH:0.448954
G1 X140.901 Y92.976 E.00599
;WIDTH:0.497909
G1 X140.877 Y93.192 E.0067
;WIDTH:0.546863
G1 X140.852 Y93.409 E.00745
;WIDTH:0.547018
G1 X140.852 Y95.42 E.06858
G1 X140.877 Y95.578 E.00546
;WIDTH:0.498012
G1 X140.901 Y95.736 E.00493
;WIDTH:0.449006
G1 X140.926 Y95.894 E.00441
;WIDTH:0.399999
G1 X140.934 Y150.983 E1.33998
G1 X140.896 Y151.626 E.01567
;WIDTH:0.43505
G1 X140.857 Y151.747 E.00339
;WIDTH:0.4701
G1 X140.818 Y151.869 E.00371
;WIDTH:0.50515
G1 X140.779 Y151.99 E.00398
;WIDTH:0.519232
G1 X140.621 Y152.595 E.02017
;WIDTH:0.521429
G1 X140.399 Y153.223 E.02158
;WIDTH:0.480953
G1 X140.337 Y153.403 E.00566
;WIDTH:0.440476
G1 X140.275 Y153.582 E.00512
;WIDTH:0.399999
G1 X139.986 Y154.066 E.01371
G1 X139.587 Y154.58 E.01583
G1 X139.13 Y155.042 E.01581
G1 X138.541 Y155.502 E.01818
G1 X138.074 Y155.784 E.01327
G1 X137.116 Y156.187 E.02528
G1 X136.426 Y156.353 E.01726
G1 X135.811 Y156.424 E.01506
G1 X95.425 Y156.433 E.98235
G1 X94.812 Y156.39 E.01495
G1 X94.164 Y156.266 E.01605
G1 X93.591 Y156.087 E.0146
G1 X93.018 Y155.832 E.01526
G1 X92.379 Y155.447 E.01815
G1 X91.871 Y155.043 E.01579
G1 X91.413 Y154.58 E.01584
G1 X91.014 Y154.066 E.01583
G1 X90.721 Y153.576 E.01389
;WIDTH:0.439681
G1 X90.673 Y153.418 E.00445
;WIDTH:0.479363
G1 X90.624 Y153.26 E.0049
;WIDTH:0.519045
G1 X90.576 Y153.103 E.00529
;WIDTH:0.52074
G1 X90.373 Y152.583 E.01806
G1 X90.197 Y151.941 E.02154
;WIDTH:0.491532
G1 X90.137 Y151.633 E.00954
;WIDTH:0.445766
G1 X90.076 Y151.326 E.00857
;WIDTH:0.399999
G1 X90.068 Y96.189 E1.34115
;WIDTH:0.438098
G1 X90.087 Y96.01 E.00483
;WIDTH:0.476197
G1 X90.106 Y95.832 E.00526
;WIDTH:0.514296
G1 X90.125 Y95.653 E.00575
;WIDTH:0.552394
G1 X90.144 Y95.475 E.00617
;WIDTH:0.554305
G1 X90.145 Y93.3 E.07523
;WIDTH:0.562954
G1 X90.149 Y93.167 E.00468
G1 X90.129 Y93.09 E.0028
;WIDTH:0.522216
G1 X90.108 Y93.012 E.00262
;WIDTH:0.481477
G1 X90.088 Y92.934 E.0024
;WIDTH:0.440738
G1 X90.068 Y92.857 E.00215
;WIDTH:0.399999
G1 X90.066 Y80.017 E.31232
G1 X90.106 Y79.345 E.01637
G1 X90.225 Y78.7 E.01595
G1 X90.42 Y78.073 E.01597
G1 X90.689 Y77.475 E.01595
G1 X91.028 Y76.914 E.01594
G1 X91.433 Y76.397 E.01597
G1 X91.897 Y75.933 E.01596
G1 X92.414 Y75.528 E.01597
G1 X92.971 Y75.192 E.01582
G1 X93.733 Y74.865 E.02017
G1 X94.457 Y74.687 E.01814
G1 X95.18 Y74.577 E.01779
G1 X110.818 Y74.574 E.38038
G1 E-5 F3600
G1 X110.818 Y74.574 F9000
G1 X110.818 Y74.549
G1 X92.012 Y75.814
G1 X90.049 Y80.008
G1 X90.049 Y112.571
G1 X90.494 Y112.571
G1 E5 F2400
;WIDTH:0.516128
G1 F6000
G1 X90.479 Y112.319 E.00809
;WIDTH:0.485872
G1 X90.464 Y112.068 E.00755
;WIDTH:0.483509
G1 X90.478 Y111.766 E.00903
;WIDTH:0.511402
G1 X90.492 Y111.463 E.00963
G1 X90.492 Y111.463 F9000
G1 X90.494 Y112.571
;WIDTH:0.516128
G1 F6000
G1 X90.549 Y112.689 E.00417
;WIDTH:0.477153
G1 X90.684 Y112.912 E.00768
;WIDTH:0.438576
G1 X90.82 Y113.136 E.00705
;WIDTH:0.399999
G1 X91.056 Y113.371 E.0081
G1 X91.445 Y113.587 E.01082
G1 X91.774 Y113.649 E.00814
G1 X93.57 Y113.651 E.04369
G1 X93.57 Y118.349 E.11427
G1 X91.774 Y118.351 E.04369
G1 X91.419 Y118.417 E.00878
G1 X91.053 Y118.619 E.01017
G1 X90.789 Y118.899 E.00936
;WIDTH:0.436728
G1 X90.69 Y119.087 E.00569
;WIDTH:0.473457
G1 X90.591 Y119.275 E.00621
;WIDTH:0.510186
G1 X90.492 Y119.463 E.00673
G1 X90.474 Y119.307 E.00497
;WIDTH:0.473457
G1 X90.456 Y119.15 E.00462
;WIDTH:0.436728
G1 X90.437 Y118.994 E.00421
;WIDTH:0.399999
G1 X90.436 Y113.295 E.13862
;WIDTH:0.438709
G1 X90.456 Y113.054 E.0065
;WIDTH:0.477419
G1 X90.475 Y112.812 E.00715
;WIDTH:0.516128
G1 X90.49 Y112.63 E.00585
G1 E-5 F3600
G1 X90.49 Y112.63 F9000
G1 X93.204 Y114.017
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.204 Y117.983 E.09647
G1 X91.774 Y117.985 E.03478
G1 X91.339 Y118.06 E.01074
G1 X91.028 Y118.195 E.00825
G1 X90.803 Y118.357 E.00674
G1 X90.802 Y113.633 E.11491
G1 X91.293 Y113.919 E.01382
G1 X91.774 Y114.015 E.01193
G1 X93.144 Y114.016 E.03332
G1 E-5 F3600
G1 X93.144 Y114.016 F9000
G1 X92.839 Y117.618
G1 E5 F2400
G1 F6000
G1 X92.004 Y117.619 E.02031
G1 X91.494 Y117.651 E.01243
G1 X91.168 Y117.743 E.00824
G1 X91.168 Y114.26 E.08472
G1 X91.517 Y114.358 E.00882
G1 X91.773 Y114.381 E.00625
G1 X92.838 Y114.382 E.02591
G1 X92.839 Y117.558 E.07725
G1 E-5 F3600
G1 X92.839 Y117.558 F9000
G1 X90.494 Y104.571
G1 E5 F2400
;WIDTH:0.517346
G1 F6000
G1 X90.479 Y104.319 E.00811
;WIDTH:0.487087
G1 X90.463 Y104.068 E.00757
;WIDTH:0.484721
G1 X90.477 Y103.766 E.00906
;WIDTH:0.512614
G1 X90.491 Y103.463 E.00965
G1 E-5 F3600
G1 X90.491 Y103.463 F9000
G1 X93.57 Y110.349
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X91.774 Y110.351 E.04369
G1 X91.419 Y110.417 E.00878
G1 X91.053 Y110.619 E.01017
G1 X90.789 Y110.899 E.00936
;WIDTH:0.437134
G1 X90.69 Y111.087 E.00569
;WIDTH:0.474268
G1 X90.591 Y111.275 E.00622
;WIDTH:0.511402
G1 X90.492 Y111.463 E.00674
G1 X90.473 Y111.306 E.00502
;WIDTH:0.474268
G1 X90.455 Y111.15 E.0046
;WIDTH:0.437134
G1 X90.436 Y110.993 E.00424
;WIDTH:0.399999
G1 X90.435 Y105.296 E.13857
;WIDTH:0.439115
G1 X90.455 Y105.054 E.00654
;WIDTH:0.478231
G1 X90.474 Y104.812 E.00717
;WIDTH:0.517346
G1 X90.494 Y104.571 E.00777
G1 X90.548 Y104.689 E.00417
;WIDTH:0.477924
G1 X90.684 Y104.912 E.00771
;WIDTH:0.438962
G1 X90.82 Y105.136 E.00705
;WIDTH:0.399999
G1 X91.056 Y105.371 E.0081
G1 X91.445 Y105.587 E.01082
G1 X91.774 Y105.649 E.00814
G1 X93.569 Y105.651 E.04366
G1 X93.57 Y110.289 E.11281
G1 X93.57 Y110.289 F9000
G1 X93.204 Y109.983
G1 F6000
G1 X91.774 Y109.985 E.03478
G1 X91.339 Y110.06 E.01074
G1 X91.028 Y110.195 E.00825
G1 X90.802 Y110.358 E.00678
G1 X90.801 Y105.632 E.11496
G1 X91.063 Y105.814 E.00776
G1 X91.293 Y105.919 E.00615
G1 X91.774 Y106.015 E.01193
G1 X93.204 Y106.017 E.03478
G1 X93.204 Y109.923 E.09501
G1 X93.204 Y109.923 F9000
G1 X92.838 Y109.618
G1 F6000
G1 X92.004 Y109.619 E.02029
G1 X91.494 Y109.651 E.01243
G1 X91.167 Y109.743 E.00826
G1 X91.167 Y106.259 E.08474
G1 X91.517 Y106.358 E.00885
G1 X91.773 Y106.381 E.00625
G1 X92.838 Y106.382 E.02591
G1 X92.838 Y109.558 E.07725
G1 E-5 F3600
G1 X92.838 Y109.558 F9000
G1 X93.569 Y102.349
G1 E5 F2400
G1 F6000
G1 X91.774 Y102.351 E.04366
G1 X91.419 Y102.417 E.00878
G1 X91.053 Y102.619 E.01017
G1 X90.789 Y102.899 E.00936
;WIDTH:0.437538
G1 X90.69 Y103.087 E.0057
;WIDTH:0.475076
G1 X90.59 Y103.275 E.00624
;WIDTH:0.512614
G1 X90.491 Y103.463 E.00676
G1 X90.472 Y103.306 E.00503
;WIDTH:0.475076
G1 X90.454 Y103.15 E.0046
;WIDTH:0.437538
G1 X90.435 Y102.993 E.00424
;WIDTH:0.399999
G1 X90.434 Y96.643 E.15446
;WIDTH:0.405113
G1 X90.441 Y95.859 E.01934
G1 X90.564 Y96.145 E.00768
;WIDTH:0.399999
G1 X90.836 Y96.509 E.01105
G1 X91.023 Y96.668 E.00597
G1 X91.505 Y96.871 E.01272
G1 X92.001 Y96.914 E.01211
G1 X93.569 Y96.913 E.03814
G1 X93.569 Y102.289 E.13077
G1 X93.569 Y102.289 F9000
G1 X93.203 Y101.983
G1 F6000
G1 X91.774 Y101.985 E.03476
G1 X91.339 Y102.06 E.01074
G1 X91.028 Y102.195 E.00825
G1 X90.8 Y102.359 E.00683
G1 X90.8 Y96.946 E.13167
G1 X91.134 Y97.137 E.00936
G1 X91.472 Y97.236 E.00857
G1 X92.001 Y97.279 E.01291
G1 X93.203 Y97.279 E.02924
G1 X93.203 Y101.923 E.11296
G1 X93.203 Y101.923 F9000
G1 X92.838 Y101.618
G1 F6000
G1 X92.003 Y101.619 E.02031
G1 X91.494 Y101.651 E.01241
G1 X91.166 Y101.744 E.00829
G1 X91.165 Y97.52 E.10274
G1 X91.44 Y97.6 E.00697
G1 X92.001 Y97.645 E.01369
G1 X92.837 Y97.645 E.02033
G1 X92.838 Y101.558 E.09518
G1 E-5 F3600
G1 X92.838 Y101.558 F9000
G1 X90.495 Y120.57
G1 E5 F2400
;WIDTH:0.514912
G1 F6000
G1 X90.48 Y120.319 E.00804
;WIDTH:0.484659
G1 X90.465 Y120.068 E.00753
;WIDTH:0.482296
G1 X90.478 Y119.766 E.00901
;WIDTH:0.510186
G1 X90.492 Y119.463 E.0096
G1 E-5 F3600
G1 X90.492 Y119.463 F9000
G1 X93.57 Y121.651
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.57 Y126.349 E.11427
G1 X91.774 Y126.351 E.04369
G1 X91.419 Y126.417 E.00878
G1 X91.053 Y126.619 E.01017
G1 X90.789 Y126.899 E.00936
;WIDTH:0.436325
G1 X90.69 Y127.087 E.00568
;WIDTH:0.472651
G1 X90.592 Y127.275 E.00618
;WIDTH:0.508976
G1 X90.493 Y127.463 E.00671
G1 X90.475 Y127.307 E.00496
;WIDTH:0.472651
G1 X90.457 Y127.15 E.00461
;WIDTH:0.436325
G1 X90.438 Y126.994 E.0042
;WIDTH:0.399999
G1 X90.438 Y121.294 E.13865
;WIDTH:0.438304
G1 X90.457 Y121.053 E.0065
;WIDTH:0.476608
G1 X90.476 Y120.812 E.00711
;WIDTH:0.514912
G1 X90.495 Y120.57 E.00776
G1 X90.549 Y120.689 E.00418
;WIDTH:0.476383
G1 X90.685 Y120.912 E.00768
;WIDTH:0.438191
G1 X90.82 Y121.136 E.00703
;WIDTH:0.399999
G1 X91.056 Y121.371 E.0081
G1 X91.445 Y121.587 E.01082
G1 X91.774 Y121.649 E.00814
G1 X93.51 Y121.651 E.04223
G1 X93.51 Y121.651 F9000
G1 X93.205 Y122.017
G1 F6000
G1 X93.205 Y125.984 E.09649
G1 X91.774 Y125.985 E.03481
G1 X91.339 Y126.06 E.01074
G1 X91.028 Y126.195 E.00825
G1 X90.804 Y126.356 E.00671
G1 X90.803 Y121.634 E.11486
G1 X91.293 Y121.919 E.01379
G1 X91.774 Y122.015 E.01193
G1 X93.145 Y122.016 E.03335
G1 E-5 F3600
G1 X93.145 Y122.016 F9000
G1 X92.839 Y125.618
G1 E5 F2400
G1 F6000
G1 X92.005 Y125.619 E.02029
G1 X91.494 Y125.651 E.01245
G1 X91.17 Y125.742 E.00819
G1 X91.169 Y122.26 E.0847
G1 X91.517 Y122.358 E.00879
G1 X91.773 Y122.381 E.00625
G1 X92.839 Y122.382 E.02593
G1 X92.839 Y125.558 E.07725
G1 E-5 F3600
G1 X92.839 Y125.558 F9000
G1 X90.496 Y128.57
G1 E5 F2400
;WIDTH:0.513692
G1 F6000
G1 X90.48 Y128.319 E.00802
;WIDTH:0.483442
G1 X90.465 Y128.068 E.00751
;WIDTH:0.481084
G1 X90.479 Y127.766 E.00898
;WIDTH:0.508976
G1 X90.493 Y127.463 E.00958
G1 X90.496 Y128.57 F9000
;WIDTH:0.513692
G1 F6000
G1 X90.549 Y128.689 E.00415
;WIDTH:0.475612
G1 X90.685 Y128.912 E.00767
;WIDTH:0.437806
G1 X90.82 Y129.136 E.00702
;WIDTH:0.399999
G1 X91.056 Y129.371 E.0081
G1 X91.445 Y129.587 E.01082
G1 X91.774 Y129.649 E.00814
G1 X93.571 Y129.652 E.04371
G1 X93.572 Y132.857 E.07796
G1 X93.606 Y133.479 E.01515
G1 X93.714 Y134.349 E.02132
G1 X91.775 Y134.351 E.04716
G1 X91.419 Y134.417 E.00881
G1 X91.053 Y134.619 E.01017
G1 X90.789 Y134.899 E.00936
;WIDTH:0.43592
G1 X90.69 Y135.087 E.00568
;WIDTH:0.471841
G1 X90.592 Y135.275 E.00617
;WIDTH:0.507762
G1 X90.494 Y135.463 E.00668
G1 X90.476 Y135.307 E.00495
;WIDTH:0.471841
G1 X90.458 Y135.15 E.0046
;WIDTH:0.43592
G1 X90.44 Y134.994 E.00419
;WIDTH:0.399999
G1 X90.439 Y129.294 E.13865
;WIDTH:0.437897
G1 X90.458 Y129.053 E.00649
;WIDTH:0.475795
G1 X90.477 Y128.812 E.0071
;WIDTH:0.513692
G1 X90.491 Y128.63 E.00582
G1 E-5 F3600
G1 X90.491 Y128.63 F9000
G1 X93.3 Y133.984
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X91.774 Y133.985 E.03712
G1 X91.339 Y134.06 E.01074
G1 X91.028 Y134.195 E.00825
G1 X90.805 Y134.354 E.00666
G1 X90.804 Y129.635 E.11478
G1 X91.293 Y129.919 E.01375
G1 X91.774 Y130.015 E.01193
G1 X93.205 Y130.017 E.03481
G1 X93.207 Y132.875 E.06952
G1 X93.237 Y133.458 E.0142
G1 X93.293 Y133.924 E.01142
G1 X93.293 Y133.924 F9000
G1 X92.886 Y133.618
G1 F6000
G1 X92.006 Y133.619 E.02141
G1 X91.494 Y133.651 E.01248
G1 X91.171 Y133.742 E.00816
G1 X91.17 Y130.26 E.0847
G1 X91.517 Y130.358 E.00877
G1 X91.773 Y130.381 E.00625
G1 X92.84 Y130.382 E.02595
G1 X92.84 Y132.784 E.05843
G1 X92.883 Y133.559 E.01888
G1 E-5 F3600
G1 X92.883 Y133.559 F9000
G1 X90.496 Y136.57
G1 E5 F2400
;WIDTH:0.512474
G1 F6000
G1 X90.481 Y136.319 E.008
;WIDTH:0.482226
G1 X90.466 Y136.068 E.00749
;WIDTH:0.47987
G1 X90.48 Y135.766 E.00896
;WIDTH:0.507762
G1 X90.494 Y135.463 E.00955
G1 E-5 F3600
G1 X90.494 Y135.463 F9000
G1 X99.25 Y142.176
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X99.56 Y142.348 E.00862
G1 X91.775 Y142.351 E.18936
G1 X91.419 Y142.417 E.00881
G1 X91.053 Y142.619 E.01017
G1 X90.789 Y142.899 E.00936
;WIDTH:0.435516
G1 X90.691 Y143.087 E.00566
;WIDTH:0.471033
G1 X90.592 Y143.275 E.00617
;WIDTH:0.50655
G1 X90.494 Y143.463 E.00666
G1 X90.476 Y143.307 E.00493
;WIDTH:0.471033
G1 X90.459 Y143.151 E.00456
;WIDTH:0.435516
G1 X90.441 Y142.994 E.00422
;WIDTH:0.399999
G1 X90.44 Y137.293 E.13867
;WIDTH:0.437491
G1 X90.459 Y137.052 E.00648
;WIDTH:0.474983
G1 X90.477 Y136.811 E.00708
;WIDTH:0.512474
G1 X90.496 Y136.57 E.00769
G1 X90.55 Y136.688 E.00413
;WIDTH:0.47484
G1 X90.685 Y136.912 E.00766
;WIDTH:0.43742
G1 X90.82 Y137.136 E.00701
;WIDTH:0.399999
G1 X91.056 Y137.371 E.0081
G1 X91.445 Y137.587 E.01082
G1 X91.775 Y137.649 E.00817
G1 X94.816 Y137.652 E.07397
G1 X95.075 Y138.136 E.01335
G1 X95.399 Y138.654 E.01486
G1 X95.768 Y139.174 E.01551
G1 X96.336 Y139.869 E.02183
G1 X96.78 Y140.338 E.01571
G1 X97.34 Y140.859 E.0186
G1 X97.939 Y141.342 E.01872
G1 X98.773 Y141.91 E.02454
G1 X99.198 Y142.146 E.01182
G1 X99.198 Y142.146 F9000
G1 X98.229 Y141.983
G1 F6000
G1 X91.775 Y141.985 E.15699
G1 X91.339 Y142.06 E.01076
G1 X91.028 Y142.195 E.00825
G1 X90.806 Y142.353 E.00663
G1 X90.806 Y137.635 E.11476
G1 X91.293 Y137.919 E.01371
G1 X91.774 Y138.015 E.01193
G1 X94.596 Y138.018 E.06864
G1 X94.764 Y138.329 E.0086
G1 X95.1 Y138.865 E.01539
G1 X95.485 Y139.405 E.01613
G1 X96.07 Y140.12 E.02247
G1 X96.531 Y140.606 E.01629
G1 X97.11 Y141.143 E.01921
G1 X97.733 Y141.644 E.01945
G1 X98.179 Y141.949 E.01314
G1 X98.179 Y141.949 F9000
G1 X97.115 Y141.618
G1 F6000
G1 X91.775 Y141.619 E.12989
G1 X91.495 Y141.651 E.00686
G1 X91.172 Y141.741 E.00816
G1 X91.171 Y138.261 E.08465
G1 X91.517 Y138.358 E.00874
G1 X91.774 Y138.381 E.00628
G1 X94.377 Y138.383 E.06332
G1 X94.802 Y139.076 E.01977
G1 X95.201 Y139.636 E.01673
G1 X95.804 Y140.371 E.02312
G1 X96.282 Y140.873 E.01686
G1 X97.07 Y141.578 E.02572
G1 E-5 F3600
G1 X97.07 Y141.578 F9000
G1 X106.249 Y143.531
G1 E5 F2400
G1 F6000
G1 X110.653 Y143.521 E.10712
G1 X111.02 Y143.366 E.00969
G1 X111.284 Y143.083 E.00941
G1 X111.319 Y142.998 E.00224
G1 X119.681 Y142.998 E.2034
G1 X119.716 Y143.083 E.00224
G1 X119.98 Y143.366 E.00941
G1 X120.193 Y143.472 E.00579
G1 X120.435 Y143.529 E.00605
G1 X124.751 Y143.536 E.10498
G1 X124.751 Y145.105 E.03816
G1 X124.852 Y145.421 E.00807
G1 X125.066 Y145.601 E.0068
G1 X125.3 Y145.654 E.00584
G1 X139.225 Y145.649 E.33871
G1 X139.581 Y145.583 E.00881
G1 X139.947 Y145.381 E.01017
G1 X140.211 Y145.101 E.00936
;WIDTH:0.44002
G1 X140.31 Y144.925 E.00545
;WIDTH:0.480041
G1 X140.409 Y144.748 E.00601
;WIDTH:0.520062
G1 X140.508 Y144.571 E.00655
G1 X140.528 Y144.716 E.00473
;WIDTH:0.480041
G1 X140.548 Y144.862 E.00437
;WIDTH:0.44002
G1 X140.568 Y145.007 E.00395
;WIDTH:0.399999
G1 X140.569 Y150.703 E.13855
G1 X140.549 Y151.304 E.01463
G1 X140.494 Y151.81 E.01238
G1 X140.453 Y151.469 E.00835
G1 X140.292 Y151.027 E.01144
G1 X139.944 Y150.629 E.01286
G1 X139.555 Y150.413 E.01082
G1 X139.225 Y150.351 E.00817
G1 X125.3 Y150.347 E.33871
G1 X125.252 Y150.349 E.00117
G1 X124.983 Y150.447 E.00696
G1 X124.81 Y150.648 E.00645
G1 X124.751 Y150.895 E.00618
G1 X124.751 Y153.105 E.05376
G1 X124.773 Y153.259 E.00378
G1 X124.861 Y153.434 E.00476
G1 X125.042 Y153.589 E.0058
G1 X125.3 Y153.654 E.00647
G1 X139.225 Y153.649 E.33871
G1 X139.581 Y153.583 E.00881
G1 X139.988 Y153.349 E.01142
G1 X139.683 Y153.859 E.01445
G1 X139.311 Y154.339 E.01477
G1 X138.887 Y154.768 E.01467
G1 X138.373 Y155.169 E.01586
G1 X137.908 Y155.457 E.0133
G1 X137.001 Y155.838 E.02393
G1 X136.362 Y155.993 E.01599
G1 X135.79 Y156.059 E.01401
G1 X95.395 Y156.064 E.98257
G1 X94.791 Y156.013 E.01474
G1 X94.19 Y155.891 E.01492
G1 X93.664 Y155.719 E.01346
G1 X93.134 Y155.476 E.01418
G1 X92.547 Y155.113 E.01679
G1 X92.089 Y154.743 E.01432
G1 X91.674 Y154.319 E.01443
G1 X91.271 Y153.782 E.01633
;WIDTH:0.400286
G1 X91.011 Y153.347 E.01234
G1 X91.056 Y153.371 E.00124
;WIDTH:0.399999
G1 X91.445 Y153.587 E.01082
G1 X91.775 Y153.649 E.00817
G1 X105.7 Y153.653 E.33871
G1 X105.958 Y153.589 E.00647
G1 X106.139 Y153.434 E.0058
G1 X106.227 Y153.259 E.00476
G1 X106.249 Y153.105 E.00378
G1 X106.249 Y150.895 E.05376
G1 X106.24 Y150.797 E.00239
G1 X106.148 Y150.579 E.00576
G1 X105.934 Y150.399 E.0068
G1 X105.7 Y150.346 E.00584
G1 X91.775 Y150.351 E.33871
G1 X91.419 Y150.417 E.00881
G1 X91.053 Y150.619 E.01017
G1 X90.789 Y150.899 E.00936
G1 X90.584 Y151.327 E.01154
G1 X90.505 Y151.824 E.01224
G1 X90.442 Y151.304 E.01274
G1 X90.441 Y145.293 E.14621
;WIDTH:0.437085
G1 X90.46 Y145.052 E.00648
;WIDTH:0.474171
G1 X90.478 Y144.811 E.00707
;WIDTH:0.511256
G1 X90.497 Y144.57 E.00767
G1 X90.55 Y144.688 E.0041
;WIDTH:0.474067
G1 X90.685 Y144.912 E.00765
;WIDTH:0.437033
G1 X90.82 Y145.136 E.00701
;WIDTH:0.399999
G1 X91.056 Y145.371 E.0081
G1 X91.445 Y145.587 E.01082
G1 X91.775 Y145.649 E.00817
G1 X105.7 Y145.653 E.33871
G1 X105.934 Y145.601 E.00583
G1 X106.148 Y145.421 E.0068
G1 X106.249 Y145.105 E.00807
G1 X106.249 Y143.591 E.03683
G1 E-5 F3600
G1 X106.249 Y143.591 F9000
G1 X90.497 Y144.57
G1 E5 F2400
;WIDTH:0.511256
G1 F6000
G1 X90.482 Y144.319 E.00798
;WIDTH:0.481011
G1 X90.466 Y144.068 E.00747
;WIDTH:0.478658
G1 X90.48 Y143.766 E.00894
;WIDTH:0.50655
G1 X90.494 Y143.463 E.00953
G1 E-5 F3600
G1 X90.494 Y143.463 F9000
G1 X106.614 Y143.897
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X109.798 Y143.895 E.07745
G1 X110.772 Y143.87 E.0237
G1 X111.183 Y143.694 E.01088
G1 X111.491 Y143.364 E.01098
G1 X119.509 Y143.364 E.19503
G1 X119.817 Y143.694 E.01098
G1 X120.089 Y143.826 E.00735
G1 X120.435 Y143.894 E.00858
G1 X124.386 Y143.901 E.0961
G1 X124.386 Y145.105 E.02929
G1 X124.448 Y145.438 E.00824
G1 X124.553 Y145.632 E.00537
G1 X124.771 Y145.851 E.00752
G1 X125.09 Y145.995 E.00851
G1 X125.3 Y146.019 E.00514
G1 X139.225 Y146.015 E.33871
G1 X139.661 Y145.94 E.01076
G1 X139.972 Y145.805 E.00825
G1 X140.202 Y145.639 E.0069
G1 X140.202 Y150.37 E.11508
G1 X139.707 Y150.08 E.01395
G1 X139.225 Y149.985 E.01195
G1 X125.3 Y149.981 E.33871
G1 X125.22 Y149.984 E.00195
G1 X124.91 Y150.068 E.00781
G1 X124.602 Y150.304 E.00944
G1 X124.451 Y150.554 E.0071
G1 X124.386 Y150.895 E.00844
G1 X124.386 Y153.105 E.05376
G1 X124.422 Y153.361 E.00629
G1 X124.568 Y153.654 E.00796
G1 X124.87 Y153.912 E.00966
G1 X125.3 Y154.019 E.01078
G1 X139.099 Y154.015 E.33565
G1 X138.643 Y154.494 E.01609
G1 X138.148 Y154.881 E.01528
G1 X137.742 Y155.13 E.01158
G1 X136.887 Y155.49 E.02257
G1 X136.297 Y155.632 E.01476
G1 X135.769 Y155.693 E.01293
G1 X95.481 Y155.702 E.97997
G1 X94.859 Y155.654 E.01517
G1 X94.299 Y155.542 E.01389
G1 X93.812 Y155.385 E.01245
G1 X93.323 Y155.163 E.01306
G1 X92.774 Y154.827 E.01566
G1 X92.349 Y154.486 E.01325
G1 X91.901 Y154.015 E.01581
G1 X105.7 Y154.019 E.33565
G1 X106.13 Y153.912 E.01078
G1 X106.431 Y153.654 E.00964
G1 X106.578 Y153.361 E.00797
G1 X106.614 Y153.105 E.00629
G1 X106.614 Y150.895 E.05376
G1 X106.588 Y150.679 E.00529
G1 X106.447 Y150.368 E.00831
G1 X106.229 Y150.149 E.00752
G1 X105.91 Y150.005 E.00851
G1 X105.7 Y149.981 E.00514
G1 X91.775 Y149.985 E.33871
G1 X91.339 Y150.06 E.01076
G1 X91.028 Y150.195 E.00825
G1 X90.808 Y150.352 E.00657
G1 X90.807 Y145.636 E.11471
G1 X91.293 Y145.919 E.01368
G1 X91.775 Y146.015 E.01195
G1 X105.78 Y146.016 E.34066
G1 X106.09 Y145.932 E.00781
G1 X106.328 Y145.77 E.007
G1 X106.552 Y145.438 E.00974
G1 X106.614 Y145.105 E.00824
G1 X106.614 Y143.957 E.02792
G1 X106.614 Y143.957 F9000
G1 X106.98 Y144.262
G1 F6000
G1 X110.565 Y144.26 E.0872
G1 X110.855 Y144.226 E.0071
G1 X111.345 Y144.022 E.01291
G1 X111.617 Y143.729 E.00972
G1 X119.383 Y143.729 E.1889
G1 X119.655 Y144.022 E.00972
G1 X120.071 Y144.207 E.01107
G1 X120.434 Y144.26 E.00892
G1 X124.02 Y144.266 E.08723
G1 X124.02 Y145.105 E.02041
G1 X124.108 Y145.572 E.01156
G1 X124.254 Y145.843 E.00749
G1 X124.56 Y146.15 E.01054
G1 X125.006 Y146.351 E.0119
G1 X125.3 Y146.385 E.0072
G1 X139.225 Y146.381 E.33871
G1 X139.505 Y146.349 E.00686
G1 X139.837 Y146.255 E.00839
G1 X139.837 Y149.742 E.08482
G1 X139.483 Y149.642 E.00895
G1 X139.225 Y149.619 E.0063
G1 X125.3 Y149.615 E.33871
G1 X125.006 Y149.649 E.0072
G1 X124.56 Y149.85 E.0119
G1 X124.254 Y150.157 E.01054
G1 X124.079 Y150.51 E.00958
G1 X124.02 Y150.895 E.00947
G1 X124.02 Y153.105 E.05376
G1 X124.071 Y153.463 E.0088
G1 X124.276 Y153.873 E.01115
G1 X124.698 Y154.234 E.01351
G1 X125.3 Y154.385 E.0151
G1 X138.194 Y154.381 E.31363
G1 X137.576 Y154.803 E.0182
G1 X136.772 Y155.141 E.02121
G1 X136.26 Y155.265 E.01281
G1 X135.747 Y155.327 E.01257
G1 X95.464 Y155.336 E.97984
G1 X94.954 Y155.3 E.01244
G1 X94.455 Y155.205 E.01236
G1 X93.979 Y155.059 E.01211
G1 X93.512 Y154.85 E.01245
G1 X92.801 Y154.381 E.02072
G1 X105.7 Y154.385 E.31376
G1 X105.922 Y154.365 E.00542
G1 X106.302 Y154.234 E.00978
G1 X106.724 Y153.873 E.01351
G1 X106.929 Y153.463 E.01115
G1 X106.98 Y153.105 E.0088
G1 X106.98 Y150.895 E.05376
G1 X106.921 Y150.509 E.0095
G1 X106.746 Y150.157 E.00956
G1 X106.44 Y149.85 E.01054
G1 X105.994 Y149.649 E.0119
G1 X105.7 Y149.615 E.0072
G1 X91.775 Y149.619 E.33871
G1 X91.495 Y149.651 E.00686
G1 X91.173 Y149.741 E.00813
G1 X91.173 Y146.261 E.08465
G1 X91.517 Y146.358 E.00869
G1 X91.775 Y146.381 E.0063
G1 X105.7 Y146.385 E.33871
G1 X105.994 Y146.351 E.0072
G1 X106.44 Y146.149 E.01191
G1 X106.677 Y145.932 E.00782
G1 X106.892 Y145.571 E.01022
G1 X106.98 Y145.105 E.01154
G1 X106.98 Y144.322 E.01905
G1 E-5 F3600
G1 X106.98 Y144.322 F9000
G1 X96.576 Y150.715
G1 E5 F2400
G1 F6000
G1 X105.7 Y150.712 E.22193
G1 X105.84 Y150.777 E.00375
G1 X105.878 Y150.852 E.00205
G1 X105.883 Y153.105 E.0548
G1 X105.846 Y153.215 E.00282
G1 X105.7 Y153.288 E.00397
G1 X91.775 Y153.284 E.33871
G1 X91.598 Y153.254 E.00437
;WIDTH:0.400286
G1 X91.281 Y153.079 E.00881
;WIDTH:0.438659
G1 X91.182 Y152.999 E.00342
;WIDTH:0.477032
G1 X91.084 Y152.919 E.00373
;WIDTH:0.515404
G1 X90.985 Y152.839 E.00407
;WIDTH:0.52074
G1 X90.85 Y152.494 E.01199
;WIDTH:0.551586
G1 X90.779 Y152.031 E.01612
G1 X90.812 Y151.901 E.00461
;WIDTH:0.51369
G1 X90.845 Y151.772 E.00425
;WIDTH:0.475793
G1 X90.877 Y151.642 E.00393
;WIDTH:0.437896
G1 X90.91 Y151.513 E.00357
;WIDTH:0.399999
G1 X91.068 Y151.135 E.00997
G1 X91.257 Y150.922 E.00693
G1 X91.5 Y150.774 E.00692
G1 X91.775 Y150.716 E.00684
G1 X96.516 Y150.715 E.11532
G1 E-5 F3600
G1 X96.516 Y150.715 F9000
G1 X125.117 Y150.895
G1 E5 F2400
G1 F6000
G1 X125.174 Y150.762 E.00352
G1 X125.3 Y150.712 E.0033
G1 X139.225 Y150.716 E.33871
G1 X139.402 Y150.746 E.00437
G1 X139.686 Y150.888 E.00772
G1 X139.962 Y151.183 E.00983
G1 X140.09 Y151.513 E.00861
;WIDTH:0.438169
G1 X140.123 Y151.642 E.00358
;WIDTH:0.476339
G1 X140.155 Y151.772 E.00394
;WIDTH:0.514509
G1 X140.188 Y151.901 E.00425
;WIDTH:0.552679
G1 X140.221 Y152.031 E.00462
G1 X140.138 Y152.537 E.01768
;WIDTH:0.515263
G1 X139.974 Y152.9 E.01274
;WIDTH:0.507944
G1 X139.837 Y153 E.00534
;WIDTH:0.471963
G1 X139.7 Y153.099 E.00492
;WIDTH:0.435981
G1 X139.563 Y153.199 E.00453
;WIDTH:0.399999
G1 X139.225 Y153.284 E.00848
G1 X125.3 Y153.288 E.33871
G1 X125.154 Y153.215 E.00397
G1 X125.117 Y153.105 E.00282
G1 X125.117 Y150.955 E.0523
G1 E-5 F3600
G1 X140.51 Y143.463 F9000
G1 E5 F2400
;WIDTH:0.515014
G1 F6000
G1 X140.525 Y143.731 E.00858
;WIDTH:0.485176
G1 X140.54 Y144 E.00808
G1 X140.525 Y144.269 E.00808
;WIDTH:0.515182
G1 X140.51 Y144.537 E.00859
;WIDTH:0.520062
G1 X140.508 Y144.571 E.0011
G1 E-5 F3600
G1 X140.508 Y144.571 F9000
G1 X131.439 Y142.349
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X132.453 Y141.766 E.02845
G1 X133.129 Y141.29 E.02011
G1 X133.898 Y140.647 E.02438
G1 X134.398 Y140.157 E.01703
G1 X134.821 Y139.686 E.0154
G1 X135.27 Y139.124 E.0175
G1 X135.632 Y138.608 E.01533
G1 X135.95 Y138.092 E.01474
G1 X136.191 Y137.652 E.0122
G1 X139.225 Y137.649 E.0738
G1 X139.581 Y137.583 E.00881
G1 X139.947 Y137.381 E.01017
G1 X140.211 Y137.101 E.00936
;WIDTH:0.439608
G1 X140.31 Y136.924 E.00547
;WIDTH:0.479217
G1 X140.408 Y136.748 E.00596
;WIDTH:0.518826
G1 X140.507 Y136.571 E.00654
G1 X140.527 Y136.716 E.00472
;WIDTH:0.479217
G1 X140.547 Y136.862 E.00436
;WIDTH:0.439608
G1 X140.567 Y137.007 E.00395
;WIDTH:0.399999
G1 X140.567 Y142.703 E.13855
;WIDTH:0.438338
G1 X140.548 Y142.957 E.00685
;WIDTH:0.476676
G1 X140.529 Y143.21 E.00747
;WIDTH:0.515014
G1 X140.51 Y143.463 E.00811
G1 X140.446 Y143.313 E.00521
;WIDTH:0.466653
G1 X140.313 Y143.089 E.00749
;WIDTH:0.433326
G1 X140.18 Y142.864 E.00694
;WIDTH:0.399999
G1 X139.944 Y142.629 E.0081
G1 X139.555 Y142.413 E.01082
G1 X139.225 Y142.351 E.00817
G1 X131.499 Y142.349 E.18793
G1 X131.499 Y142.349 F9000
G1 X132.784 Y141.983
G1 F6000
G1 X133.364 Y141.571 E.01731
G1 X134.153 Y140.908 E.02507
G1 X134.67 Y140.402 E.0176
G1 X135.106 Y139.915 E.0159
G1 X135.569 Y139.334 E.01807
G1 X135.943 Y138.801 E.01584
G1 X136.408 Y138.018 E.02215
G1 X139.226 Y138.015 E.06855
G1 X139.661 Y137.94 E.01074
G1 X139.972 Y137.805 E.00825
G1 X140.201 Y137.64 E.00687
G1 X140.202 Y142.37 E.11505
G1 X139.937 Y142.186 E.00785
G1 X139.707 Y142.08 E.00616
G1 X139.225 Y141.985 E.01195
G1 X132.844 Y141.983 E.15521
G1 X132.844 Y141.983 F9000
G1 X133.878 Y141.618
G1 F6000
G1 X134.409 Y141.17 E.0169
G1 X134.941 Y140.646 E.01816
G1 X135.391 Y140.144 E.0164
G1 X135.868 Y139.544 E.01864
G1 X136.254 Y138.993 E.01636
G1 X136.625 Y138.383 E.01737
G1 X139.226 Y138.381 E.06327
G1 X139.505 Y138.349 E.00683
G1 X139.835 Y138.256 E.00834
G1 X139.836 Y141.742 E.08479
G1 X139.483 Y141.642 E.00892
G1 X139.225 Y141.619 E.0063
G1 X133.938 Y141.618 E.1286
G1 E-5 F3600
G1 X140.509 Y135.463 F9000
G1 E5 F2400
;WIDTH:0.513784
G1 F6000
G1 X140.524 Y135.731 E.00856
;WIDTH:0.483947
G1 X140.539 Y136 E.00806
G1 X140.524 Y136.269 E.00806
;WIDTH:0.51395
G1 X140.509 Y136.537 E.00856
;WIDTH:0.518826
G1 X140.507 Y136.571 E.0011
G1 E-5 F3600
G1 X140.507 Y136.571 F9000
G1 X137.288 Y134.349
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.372 Y133.727 E.01527
G1 X137.429 Y132.81 E.02235
G1 X137.429 Y129.651 E.07684
G1 X139.226 Y129.649 E.04371
G1 X139.581 Y129.583 E.00878
G1 X139.947 Y129.381 E.01017
G1 X140.211 Y129.101 E.00936
;WIDTH:0.439195
G1 X140.31 Y128.924 E.00546
;WIDTH:0.478391
G1 X140.408 Y128.747 E.00598
;WIDTH:0.517586
G1 X140.506 Y128.57 E.0065
G1 X140.526 Y128.716 E.00474
;WIDTH:0.478391
G1 X140.546 Y128.861 E.00432
;WIDTH:0.439195
G1 X140.565 Y129.007 E.00397
;WIDTH:0.399999
G1 X140.566 Y134.704 E.13857
;WIDTH:0.437928
G1 X140.547 Y134.957 E.00681
;WIDTH:0.475856
G1 X140.528 Y135.21 E.00745
;WIDTH:0.513784
G1 X140.509 Y135.463 E.00809
G1 X140.446 Y135.313 E.00519
;WIDTH:0.46599
G1 X140.313 Y135.089 E.00748
;WIDTH:0.432995
G1 X140.18 Y134.864 E.00693
;WIDTH:0.399999
G1 X139.944 Y134.629 E.0081
G1 X139.555 Y134.413 E.01082
G1 X139.225 Y134.351 E.00817
G1 X137.348 Y134.349 E.04566
G1 X137.348 Y134.349 F9000
G1 X137.707 Y133.984
G1 F6000
G1 X137.795 Y132.81 E.02864
G1 X137.795 Y130.017 E.06794
G1 X139.226 Y130.015 E.03481
G1 X139.661 Y129.94 E.01074
G1 X139.972 Y129.805 E.00825
G1 X140.2 Y129.641 E.00683
G1 X140.2 Y134.369 E.115
G1 X139.937 Y134.186 E.00779
G1 X139.707 Y134.08 E.00616
G1 X139.226 Y133.985 E.01193
G1 X137.767 Y133.984 E.03549
G1 X137.767 Y133.984 F9000
G1 X138.112 Y133.618
G1 F6000
G1 X138.16 Y132.81 E.01969
G1 X138.161 Y130.382 E.05906
G1 X138.996 Y130.381 E.02031
G1 X139.506 Y130.349 E.01243
G1 X139.834 Y130.256 E.00829
G1 X139.835 Y133.741 E.08477
G1 X139.483 Y133.642 E.00889
G1 X139.226 Y133.619 E.00628
G1 X138.172 Y133.619 E.02564
G1 E-5 F3600
G1 X138.172 Y133.619 F9000
G1 X140.509 Y127.463
G1 E5 F2400
;WIDTH:0.51255
G1 F6000
G1 X140.524 Y127.731 E.00854
;WIDTH:0.482717
G1 X140.539 Y128 E.00804
G1 X140.524 Y128.269 E.00804
;WIDTH:0.512716
G1 X140.509 Y128.537 E.00854
;WIDTH:0.517586
G1 X140.506 Y128.57 E.00107
G1 E-5 F3600
G1 X140.506 Y128.57 F9000
G1 X137.43 Y126.349
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.43 Y121.651 E.11427
G1 X139.226 Y121.649 E.04369
G1 X139.581 Y121.583 E.00878
G1 X139.947 Y121.381 E.01017
G1 X140.211 Y121.101 E.00936
;WIDTH:0.438782
G1 X140.309 Y120.924 E.00544
;WIDTH:0.477565
G1 X140.408 Y120.747 E.00598
;WIDTH:0.516348
G1 X140.506 Y120.57 E.00649
G1 X140.525 Y120.716 E.00472
;WIDTH:0.477565
G1 X140.545 Y120.861 E.00432
;WIDTH:0.438782
G1 X140.564 Y121.007 E.00396
;WIDTH:0.399999
G1 X140.565 Y126.704 E.13857
;WIDTH:0.437516
G1 X140.546 Y126.957 E.0068
;WIDTH:0.475033
G1 X140.528 Y127.21 E.00744
;WIDTH:0.51255
G1 X140.509 Y127.463 E.00807
G1 X140.446 Y127.313 E.00518
;WIDTH:0.46532
G1 X140.313 Y127.089 E.00747
;WIDTH:0.43266
G1 X140.18 Y126.864 E.00693
;WIDTH:0.399999
G1 X139.944 Y126.629 E.0081
G1 X139.555 Y126.413 E.01082
G1 X139.226 Y126.351 E.00814
G1 X137.49 Y126.349 E.04223
G1 E-5 F3600
G1 X137.49 Y126.349 F9000
G1 X137.795 Y122.017
G1 E5 F2400
G1 F6000
G1 X139.226 Y122.015 E.03481
G1 X139.661 Y121.94 E.01074
G1 X139.972 Y121.805 E.00825
G1 X140.199 Y121.642 E.0068
G1 X140.199 Y126.368 E.11496
G1 X139.937 Y126.186 E.00776
G1 X139.707 Y126.081 E.00615
G1 X139.226 Y125.985 E.01193
G1 X137.795 Y125.983 E.03481
G1 X137.795 Y122.077 E.09501
G1 X137.795 Y122.077 F9000
G1 X138.161 Y122.382
G1 F6000
G1 X138.996 Y122.381 E.02031
G1 X139.506 Y122.349 E.01243
G1 X139.833 Y122.257 E.00826
G1 X139.833 Y125.741 E.08474
G1 X139.483 Y125.642 E.00885
G1 X139.227 Y125.619 E.00625
G1 X138.161 Y125.618 E.02593
G1 X138.161 Y122.442 E.07725
G1 E-5 F3600
G1 X138.161 Y122.442 F9000
G1 X140.508 Y119.463
G1 E5 F2400
;WIDTH:0.511318
G1 F6000
G1 X140.523 Y119.731 E.00852
;WIDTH:0.481487
G1 X140.538 Y120 E.00801
G1 X140.523 Y120.269 E.00801
;WIDTH:0.511482
G1 X140.508 Y120.537 E.00852
;WIDTH:0.516348
G1 X140.506 Y120.57 E.00106
G1 E-5 F3600
G1 X140.506 Y120.57 F9000
G1 X137.43 Y118.349
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.43 Y113.651 E.11427
G1 X139.226 Y113.649 E.04369
G1 X139.581 Y113.583 E.00878
G1 X139.947 Y113.381 E.01017
G1 X140.211 Y113.101 E.00936
;WIDTH:0.438371
G1 X140.309 Y112.924 E.00544
;WIDTH:0.476743
G1 X140.407 Y112.747 E.00595
;WIDTH:0.515114
G1 X140.505 Y112.57 E.00647
G1 X140.524 Y112.716 E.00471
;WIDTH:0.476743
G1 X140.544 Y112.861 E.00431
;WIDTH:0.438371
G1 X140.563 Y113.006 E.00393
;WIDTH:0.399999
G1 X140.564 Y118.705 E.13862
;WIDTH:0.437106
G1 X140.545 Y118.958 E.0068
;WIDTH:0.474212
G1 X140.527 Y119.21 E.00739
;WIDTH:0.511318
G1 X140.508 Y119.463 E.00805
G1 X140.445 Y119.314 E.00513
;WIDTH:0.464653
G1 X140.313 Y119.089 E.00747
;WIDTH:0.432326
G1 X140.18 Y118.864 E.00692
;WIDTH:0.399999
G1 X139.944 Y118.629 E.0081
G1 X139.555 Y118.413 E.01082
G1 X139.226 Y118.351 E.00814
G1 X137.49 Y118.349 E.04223
G1 X137.49 Y118.349 F9000
G1 X137.796 Y117.983
G1 F6000
G1 X137.796 Y114.017 E.09647
G1 X139.226 Y114.015 E.03478
G1 X139.661 Y113.94 E.01074
G1 X139.972 Y113.805 E.00825
G1 X140.197 Y113.643 E.00674
G1 X140.198 Y118.367 E.11491
G1 X139.707 Y118.081 E.01382
G1 X139.226 Y117.985 E.01193
G1 X137.856 Y117.984 E.03332
G1 X137.856 Y117.984 F9000
G1 X138.161 Y117.618
G1 F6000
G1 X138.162 Y114.382 E.07871
G1 X138.996 Y114.381 E.02029
G1 X139.506 Y114.349 E.01243
G1 X139.832 Y114.257 E.00824
G1 X139.832 Y117.74 E.08472
G1 X139.483 Y117.642 E.00882
G1 X139.227 Y117.619 E.00625
G1 X138.221 Y117.618 E.02447
G1 E-5 F3600
G1 X138.221 Y117.618 F9000
G1 X140.508 Y111.463
G1 E5 F2400
;WIDTH:0.51009
G1 F6000
G1 X140.523 Y111.731 E.00849
;WIDTH:0.48026
G1 X140.537 Y112 E.00799
G1 X140.523 Y112.268 E.00796
;WIDTH:0.510252
G1 X140.508 Y112.537 E.00853
;WIDTH:0.515114
G1 X140.505 Y112.57 E.00106
G1 E-5 F3600
G1 X140.505 Y112.57 F9000
G1 X137.431 Y105.651
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X139.226 Y105.649 E.04366
G1 X139.581 Y105.583 E.00878
G1 X139.947 Y105.381 E.01017
G1 X140.211 Y105.101 E.00936
;WIDTH:0.437958
G1 X140.309 Y104.924 E.00543
;WIDTH:0.475917
G1 X140.407 Y104.747 E.00594
;WIDTH:0.513876
G1 X140.505 Y104.57 E.00645
G1 X140.524 Y104.715 E.00466
;WIDTH:0.475917
G1 X140.543 Y104.861 E.00432
;WIDTH:0.437958
G1 X140.562 Y105.006 E.00393
;WIDTH:0.399999
G1 X140.562 Y110.706 E.13865
;WIDTH:0.436696
G1 X140.544 Y110.958 E.00676
;WIDTH:0.473393
G1 X140.526 Y111.21 E.00738
;WIDTH:0.51009
G1 X140.508 Y111.463 E.00803
G1 X140.445 Y111.314 E.00512
;WIDTH:0.463988
G1 X140.313 Y111.089 E.00746
;WIDTH:0.431994
G1 X140.18 Y110.864 E.00691
;WIDTH:0.399999
G1 X139.944 Y110.629 E.0081
G1 X139.555 Y110.413 E.01082
G1 X139.226 Y110.351 E.00814
G1 X137.43 Y110.349 E.04369
G1 X137.431 Y105.711 E.11281
G1 X137.431 Y105.711 F9000
G1 X137.796 Y106.017
G1 F6000
G1 X139.226 Y106.015 E.03478
G1 X139.661 Y105.94 E.01074
G1 X139.972 Y105.805 E.00825
G1 X140.196 Y105.644 E.00671
G1 X140.197 Y110.366 E.11486
G1 X139.707 Y110.081 E.01379
G1 X139.226 Y109.985 E.01193
G1 X137.796 Y109.983 E.03478
G1 X137.796 Y106.077 E.09501
G1 X137.796 Y106.077 F9000
G1 X138.162 Y106.382
G1 F6000
G1 X138.995 Y106.381 E.02026
G1 X139.506 Y106.349 E.01245
G1 X139.83 Y106.258 E.00819
G1 X139.831 Y109.74 E.0847
G1 X139.483 Y109.642 E.00879
G1 X139.227 Y109.619 E.00625
G1 X138.162 Y109.618 E.02591
G1 X138.162 Y106.442 E.07725
G1 E-5 F3600
G1 X138.162 Y106.442 F9000
G1 X140.507 Y103.463
G1 E5 F2400
;WIDTH:0.508858
G1 F6000
G1 X140.522 Y103.731 E.00847
;WIDTH:0.47903
G1 X140.537 Y104 E.00797
G1 X140.522 Y104.268 E.00794
;WIDTH:0.50902
G1 X140.507 Y104.537 E.00851
;WIDTH:0.513876
G1 X140.505 Y104.57 E.00105
G1 E-5 F3600
G1 X140.505 Y104.57 F9000
G1 X137.431 Y102.349
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y96.913 E.13223
G1 X139.291 Y96.906 E.04524
G1 X139.74 Y96.788 E.01129
G1 X140.114 Y96.551 E.01077
G1 X140.281 Y96.386 E.00571
G1 X140.556 Y95.894 E.01371
G1 X140.561 Y102.706 E.1657
;WIDTH:0.436286
G1 X140.543 Y102.958 E.00676
;WIDTH:0.472572
G1 X140.525 Y103.211 E.00739
;WIDTH:0.508858
G1 X140.507 Y103.463 E.00797
G1 X140.445 Y103.314 E.00509
;WIDTH:0.463317
G1 X140.312 Y103.089 E.00746
;WIDTH:0.431658
G1 X140.18 Y102.864 E.00689
;WIDTH:0.399999
G1 X139.944 Y102.629 E.0081
G1 X139.555 Y102.413 E.01082
G1 X139.226 Y102.351 E.00814
G1 X137.491 Y102.349 E.0422
G1 X137.491 Y102.349 F9000
G1 X137.797 Y101.983
G1 F6000
G1 X137.797 Y97.279 E.11442
G1 X138.996 Y97.279 E.02916
G1 X139.594 Y97.227 E.0146
G1 X139.936 Y97.097 E.0089
G1 X140.195 Y96.933 E.00746
G1 X140.196 Y102.365 E.13213
G1 X139.707 Y102.081 E.01375
G1 X139.226 Y101.985 E.01193
G1 X137.857 Y101.984 E.0333
G1 X137.857 Y101.984 F9000
G1 X138.162 Y101.618
G1 F6000
G1 X138.163 Y97.645 E.09664
G1 X139.409 Y97.628 E.03031
G1 X139.829 Y97.521 E.01054
G1 X139.83 Y101.74 E.10262
G1 X139.483 Y101.642 E.00877
G1 X139.227 Y101.619 E.00625
G1 X138.222 Y101.618 E.02445
G1 E-5 F3600
G1 X138.222 Y101.618 F9000
G1 X140.194 Y95.787
G1 X140.236 Y95.609
G1 X140.241 Y95.55
G1 X140.249 Y95.439
G1 X140.249 Y93.39
G1 X140.241 Y93.278
G1 X140.236 Y93.22
G1 X140.194 Y93.041
G1 X140.123 Y92.87
G1 X140.025 Y92.712
G1 X139.943 Y92.619
G1 X139.89 Y92.562
G1 X139.74 Y92.45
G1 X139.571 Y92.365
G1 X126.349 Y88.151
G1 X121.628 Y88.151
G1 X119.951 Y86.599
G1 X119.844 Y86.703
G1 E5 F2400
G1 F6000
G1 X119.87 Y86.74 E.0011
G1 X120.201 Y86.931 E.0093
G1 X120.483 Y86.981 E.00697
G1 X126.835 Y86.968 E.15451
G1 X127.422 Y86.931 E.01431
G1 X127.919 Y86.85 E.01225
G1 X128.555 Y86.648 E.01623
G1 X129.054 Y86.431 E.01324
G1 X129.871 Y85.904 E.02365
G1 X130.405 Y85.412 E.01766
G1 X130.806 Y84.92 E.01544
G1 X131.365 Y83.9 E.02829
G1 X131.655 Y82.891 E.02554
G1 X131.721 Y82.342 E.01345
G1 X131.73 Y79.168 E.0772
G1 X132.262 Y78.586 E.01918
G1 X132.522 Y78.158 E.01218
G1 X132.627 Y77.811 E.00882
G1 X132.668 Y77.444 E.00898
G1 X132.548 Y76.917 E.01315
G1 X132.18 Y76.308 E.01731
G1 X131.726 Y75.833 E.01598
G1 X131.714 Y75.68 E.00373
G1 X131.557 Y75.338 E.00915
G1 X131.282 Y75.091 E.00899
;WIDTH:0.40745
G1 X130.817 Y74.941 E.01213
G1 X131.312 Y74.937 E.01229
;WIDTH:0.399999
G1 X135.75 Y74.944 E.10795
G1 X136.274 Y75 E.01282
G1 X137.019 Y75.172 E.0186
G1 X137.563 Y75.372 E.0141
G1 X138.377 Y75.832 E.02274
G1 X139.082 Y76.419 E.02231
G1 X139.668 Y77.123 E.02228
G1 X140.119 Y77.922 E.02232
G1 X140.418 Y78.788 E.02228
G1 X140.51 Y79.392 E.01486
G1 X140.558 Y80.028 E.01551
G1 X140.56 Y92.411 E.3012
;WIDTH:0.404459
G1 X140.551 Y92.918 E.01248
G1 X140.327 Y92.501 E.01165
;WIDTH:0.399999
G1 X140.022 Y92.194 E.01053
G1 X139.694 Y92.02 E.00903
G1 X139.202 Y91.915 E.01224
G1 X126.969 Y91.915 E.29756
G1 X127.271 Y91.572 E.01112
G1 X127.549 Y91.081 E.01372
G1 X127.616 Y90.879 E.00518
G1 X127.665 Y90.495 E.00942
G1 X127.651 Y90.286 E.0051
G1 X127.491 Y89.782 E.01286
G1 X127.18 Y89.308 E.01379
G1 X126.727 Y88.834 E.01595
G1 X126.712 Y88.496 E.00823
G1 X126.598 Y88.218 E.00731
G1 X126.453 Y88.033 E.00572
G1 X126.114 Y87.825 E.00967
G1 X125.817 Y87.769 E.00735
G1 X105.183 Y87.769 E.5019
G1 X104.971 Y87.811 E.00526
G1 X104.542 Y88.031 E.01173
G1 X104.31 Y88.42 E.01102
G1 X104.272 Y88.825 E.00989
G1 X103.686 Y89.489 E.02154
G1 X103.412 Y90.004 E.01419
G1 X103.335 Y90.505 E.01233
G1 X103.349 Y90.714 E.0051
G1 X103.443 Y91.066 E.00886
G1 X103.752 Y91.605 E.01511
G1 X104.034 Y91.915 E.01019
G1 X91.798 Y91.915 E.29763
G1 X91.302 Y92.018 E.01232
G1 X91.105 Y92.11 E.00529
G1 X90.849 Y92.298 E.00773
G1 X90.544 Y92.701 E.01229
G1 X90.433 Y93.013 E.00806
G1 X90.431 Y80.028 E.31585
G1 X90.47 Y79.389 E.01557
G1 X90.58 Y78.787 E.01489
G1 X90.762 Y78.203 E.01488
G1 X91.013 Y77.645 E.01488
G1 X91.33 Y77.122 E.01488
G1 X91.707 Y76.64 E.01488
G1 X92.14 Y76.207 E.01489
G1 X92.622 Y75.83 E.01488
G1 X93.138 Y75.518 E.01467
G1 X93.849 Y75.213 E.01882
G1 X94.528 Y75.046 E.01701
G1 X95.208 Y74.942 E.01673
G1 X99.135 Y74.942 E.09552
;WIDTH:0.41165
G1 X100.087 Y74.947 E.02389
G1 X99.725 Y75.086 E.00973
;WIDTH:0.400104
G1 X99.425 Y75.38 E.01022
;WIDTH:0.399999
G1 X99.313 Y75.644 E.00698
G1 X99.273 Y75.829 E.0046
G1 X98.729 Y76.428 E.01968
G1 X98.451 Y76.919 E.01372
G1 X98.384 Y77.121 E.00518
G1 X98.335 Y77.505 E.00942
G1 X98.349 Y77.714 E.0051
G1 X98.509 Y78.218 E.01286
G1 X98.82 Y78.692 E.01379
G1 X99.27 Y79.162 E.01583
G1 X99.284 Y82.399 E.07874
G1 X99.422 Y83.252 E.02102
G1 X99.697 Y84.05 E.02053
G1 X100.169 Y84.883 E.02329
G1 X100.867 Y85.678 E.02573
G1 X101.713 Y86.304 E.0256
G1 X102.369 Y86.626 E.01778
G1 X102.978 Y86.82 E.01555
G1 X103.56 Y86.938 E.01444
G1 X104.199 Y86.981 E.01558
G1 X110.517 Y86.981 E.15368
G1 X110.612 Y86.973 E.00232
G1 X111.012 Y86.83 E.01033
G1 X111.211 Y86.662 E.00633
G1 X111.334 Y86.428 E.00643
G1 X119.666 Y86.428 E.20267
G1 X119.691 Y86.495 E.00174
G1 X119.808 Y86.655 E.00482
G1 E-5 F3600
G1 X119.808 Y86.655 F9000
G1 X105.019 Y87.382
G1 E5 F2400
;WIDTH:0.4703
G1 F6000
G1 X105.183 Y87.375 E.00476
;WIDTH:0.456022
G1 X110.517 Y87.375 E.14962
;WIDTH:0.4703
G1 X110.681 Y87.368 E.00476
;WIDTH:0.498002
G1 X110.893 Y87.335 E.00662
;WIDTH:0.521824
G1 X111.273 Y87.168 E.01346
G1 X111.39 Y87.077 E.00481
G1 X111.585 Y86.855 E.00958
G1 X119.415 Y86.855 E.25391
G1 X119.465 Y86.94 E.0032
G1 X119.728 Y87.168 E.01129
G1 X120.108 Y87.335 E.01346
;WIDTH:0.497328
G1 X120.269 Y87.363 E.00503
;WIDTH:0.521824
G1 X119.669 Y87.342 E.01947
G1 X111.007 Y87.355 E.28089
;WIDTH:0.496062
G1 X110.741 Y87.365 E.00818
G1 E-5 F3600
G1 X110.741 Y87.365 F9000
G1 X120.269 Y87.363
G1 E5 F2400
;WIDTH:0.480186
G1 F6000
G1 X120.485 Y87.375 E.00642
;WIDTH:0.46734
G1 X125.817 Y87.369 E.15358
;WIDTH:0.494918
G1 X126.044 Y87.383 E.00697
G1 X126.216 Y87.362 E.00531
;WIDTH:0.453713
G1 X126.526 Y87.348 E.00866
;WIDTH:0.426856
G1 X126.835 Y87.334 E.00808
;WIDTH:0.399999
G1 X127.476 Y87.293 E.01562
G1 X128.028 Y87.199 E.01362
G1 X128.696 Y86.985 E.01706
G1 X129.25 Y86.74 E.01473
G1 X130.116 Y86.175 E.02515
G1 X130.688 Y85.643 E.019
G1 X131.09 Y85.152 E.01544
G1 X131.409 Y84.603 E.01544
G1 X131.716 Y84.003 E.01639
G1 X132.017 Y82.938 E.02692
G1 X132.086 Y82.343 E.01457
G1 X132.095 Y79.313 E.0737
G1 X132.575 Y78.776 E.01752
G1 X132.835 Y78.347 E.0122
G1 X132.939 Y78.1 E.00652
G1 X133.038 Y77.608 E.01221
G1 X132.975 Y77.045 E.01378
G1 X132.865 Y76.735 E.008
G1 X132.576 Y76.232 E.01411
G1 X132.138 Y75.736 E.0161
G1 X131.953 Y75.303 E.01145
G1 X135.635 Y75.302 E.08956
G1 X136.208 Y75.36 E.01401
G1 X136.914 Y75.522 E.01762
G1 X137.405 Y75.703 E.01273
G1 X138.169 Y76.134 E.02134
G1 X138.822 Y76.678 E.02067
G1 X139.366 Y77.332 E.02069
G1 X139.784 Y78.072 E.02067
G1 X140.061 Y78.876 E.02068
G1 X140.148 Y79.447 E.01405
G1 X140.192 Y80.028 E.01417
G1 X140.194 Y91.87 E.28804
G1 X139.782 Y91.665 E.01119
G1 X139.202 Y91.549 E.01439
G1 X127.704 Y91.549 E.27968
G1 X127.867 Y91.261 E.00805
G1 X127.979 Y90.925 E.00861
G1 X128.027 Y90.541 E.00941
G1 X128.004 Y90.192 E.00851
G1 X127.911 Y89.84 E.00886
G1 X127.801 Y89.588 E.00669
G1 X127.444 Y89.056 E.01558
G1 X127.089 Y88.684 E.01251
G1 X127.087 Y88.579 E.00255
G1 X126.996 Y88.201 E.00946
G1 X126.844 Y87.92 E.00777
G1 X126.566 Y87.653 E.00938
;WIDTH:0.447459
G1 X126.305 Y87.518 E.00808
;WIDTH:0.494918
G1 X126.097 Y87.41 E.00718
G1 X126.097 Y87.41 F9000
G1 X127.144 Y87.703
;WIDTH:0.399999
G1 F6000
G1 X128.138 Y87.548 E.02447
G1 X128.837 Y87.323 E.01786
G1 X129.445 Y87.049 E.01622
G1 X130.362 Y86.446 E.0267
G1 X130.971 Y85.875 E.02031
G1 X131.373 Y85.383 E.01545
G1 X131.729 Y84.78 E.01703
G1 X132.067 Y84.106 E.01834
G1 X132.38 Y82.984 E.02833
G1 X132.452 Y82.344 E.01567
G1 X132.461 Y79.459 E.07018
G1 X132.888 Y78.965 E.01588
G1 X133.147 Y78.537 E.01217
G1 X133.304 Y78.143 E.01032
G1 X133.402 Y77.639 E.01249
G1 X133.336 Y76.987 E.01594
G1 X133.182 Y76.552 E.01122
G1 X132.893 Y76.05 E.01409
G1 X132.58 Y75.669 E.01199
G1 X135.622 Y75.668 E.07399
G1 X136.142 Y75.719 E.01271
G1 X136.698 Y75.839 E.01384
G1 X137.248 Y76.035 E.0142
G1 X137.96 Y76.436 E.01988
G1 X138.562 Y76.938 E.01907
G1 X139.064 Y77.54 E.01907
G1 X139.449 Y78.223 E.01907
G1 X139.705 Y78.964 E.01907
G1 X139.787 Y79.502 E.01324
G1 X139.826 Y80.028 E.01283
G1 X139.828 Y91.3 E.27418
G1 X139.202 Y91.183 E.01549
G1 X128.271 Y91.184 E.26589
G1 X128.342 Y90.971 E.00546
G1 X128.39 Y90.587 E.00941
G1 X128.358 Y90.098 E.01192
G1 X128.217 Y89.604 E.0125
G1 X127.867 Y89.006 E.01685
G1 X127.448 Y88.531 E.01541
G1 X127.43 Y88.359 E.00421
G1 X127.325 Y88.042 E.00812
G1 X127.172 Y87.755 E.00791
G1 E-5 F3600
G1 X127.172 Y87.755 F9000
G1 X103.875 Y86.587
G1 X103.76 Y86.576
G1 X103.551 Y86.552
G1 X103.436 Y86.533
G1 X103.231 Y86.494
G1 X103.117 Y86.467
G1 X102.915 Y86.413
G1 X102.804 Y86.378
G1 X102.606 Y86.309
G1 X102.497 Y86.268
G1 X102.305 Y86.184
G1 X102.199 Y86.135
G1 X102.013 Y86.036
G1 X101.906 Y85.978
G1 X101.728 Y85.866
G1 X101.627 Y85.8
G1 X101.458 Y85.676
G1 X101.362 Y85.605
G1 X101.273 Y85.529
G1 X101.113 Y85.391
G1 X101.03 Y85.31
G1 X100.881 Y85.161
G1 X100.803 Y85.073
G1 X100.666 Y84.913
G1 X100.593 Y84.819
G1 X100.468 Y84.649
G1 X100.402 Y84.55
G1 X100.289 Y84.371
G1 X100.229 Y84.267
G1 X100.13 Y84.079
G1 X100.078 Y83.971
G1 X99.992 Y83.775
G1 X99.948 Y83.665
G1 X99.877 Y83.461
G1 X99.841 Y83.35
G1 X99.786 Y83.141
G1 X99.758 Y83.029
G1 X98.715 Y77.648
G1 X98.705 Y77.5
G1 X98.715 Y77.352
G1 X98.745 Y77.207
G1 X98.792 Y77.067
G1 X98.854 Y76.931
G1 X99.651 Y75.328
G1 X100.087 Y75.328
G1 X100.087 Y74.947
G1 E5 F2400
;WIDTH:0.41165
G1 F6000
G1 X100.183 Y74.943 E.00241
;WIDTH:0.40745
G1 X130.817 Y74.941 E.76032
G1 E-5 F3600
G1 X130.817 Y74.941 F9000
G1 X130.817 Y75.328
G1 X131.349 Y75.328
G1 X132.146 Y76.931
G1 X132.208 Y77.067
G1 X132.255 Y77.207
G1 X132.285 Y77.352
G1 X132.295 Y77.5
G1 X132.285 Y77.648
G1 X131.242 Y83.029
G1 X131.214 Y83.141
G1 X131.159 Y83.35
G1 X131.123 Y83.461
G1 X131.052 Y83.665
G1 X131.008 Y83.775
G1 X130.922 Y83.971
G1 X130.87 Y84.079
G1 X130.771 Y84.267
G1 X130.711 Y84.371
G1 X130.598 Y84.55
G1 X130.532 Y84.649
G1 X130.407 Y84.819
G1 X130.334 Y84.913
G1 X130.197 Y85.073
G1 X130.119 Y85.16
G1 X129.97 Y85.31
G1 X129.887 Y85.391
G1 X129.727 Y85.529
G1 X129.638 Y85.605
G1 X129.542 Y85.676
G1 X129.373 Y85.8
G1 X129.272 Y85.866
G1 X129.094 Y85.978
G1 X128.987 Y86.036
G1 X128.801 Y86.135
G1 X128.695 Y86.184
G1 X128.503 Y86.268
G1 X128.394 Y86.309
G1 X128.196 Y86.378
G1 X128.085 Y86.413
G1 X127.883 Y86.467
G1 X127.769 Y86.494
G1 X127.564 Y86.533
G1 X127.449 Y86.552
G1 X127.24 Y86.576
G1 X127.125 Y86.587
G1 X104.651 Y88.151
G1 X103.507 Y89.134
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X103.365 Y89.313 E.00556
G1 X103.068 Y89.88 E.01557
G1 X102.973 Y90.459 E.01427
G1 X102.996 Y90.808 E.00851
G1 X103.089 Y91.16 E.00886
G1 X103.285 Y91.549 E.0106
G1 X91.798 Y91.549 E.27941
G1 X91.217 Y91.663 E.0144
G1 X90.799 Y91.881 E.01147
G1 X90.797 Y80.039 E.28804
G1 X90.834 Y79.433 E.01477
G1 X90.936 Y78.875 E.0138
G1 X91.105 Y78.333 E.01381
G1 X91.338 Y77.815 E.01382
G1 X91.631 Y77.33 E.01378
G1 X91.982 Y76.883 E.01382
G1 X92.383 Y76.482 E.01379
G1 X92.83 Y76.131 E.01382
G1 X93.306 Y75.844 E.01352
G1 X93.966 Y75.561 E.01747
G1 X94.599 Y75.405 E.01586
G1 X95.236 Y75.308 E.01567
G1 X99.059 Y75.307 E.09299
G1 X98.88 Y75.712 E.01077
G1 X98.411 Y76.247 E.01731
G1 X98.133 Y76.739 E.01375
G1 X98.021 Y77.075 E.00861
G1 X97.968 Y77.648 E.014
G1 X98.065 Y78.068 E.01048
G1 X98.199 Y78.412 E.00898
G1 X98.556 Y78.944 E.01558
G1 X98.905 Y79.31 E.0123
G1 X98.93 Y82.541 E.07859
G1 X99.076 Y83.371 E.0205
G1 X99.351 Y84.169 E.02053
G1 X99.557 Y84.564 E.01084
G1 X99.892 Y85.121 E.01581
G1 X100.647 Y85.97 E.02764
G1 X101.549 Y86.631 E.0272
G1 X102.256 Y86.974 E.01911
G1 X102.902 Y87.177 E.01647
G1 X103.534 Y87.302 E.01567
G1 X104.199 Y87.347 E.01621
;WIDTH:0.43515
G1 X104.609 Y87.365 E.01094
;WIDTH:0.4703
G1 X105.019 Y87.382 E.0119
G1 X104.824 Y87.459 E.00608
;WIDTH:0.432359
G1 X104.336 Y87.724 E.0147
;WIDTH:0.399999
G1 X104.116 Y87.995 E.00849
G1 X103.967 Y88.294 E.00813
G1 X103.909 Y88.674 E.00935
G1 X103.684 Y88.909 E.00791
G1 X103.544 Y89.087 E.00551
G1 X103.544 Y89.087 F9000
G1 X103.212 Y88.922
G1 F6000
G1 X103.044 Y89.138 E.00666
G1 X102.724 Y89.756 E.01693
G1 X102.61 Y90.413 E.01622
G1 X102.642 Y90.902 E.01192
G1 X102.717 Y91.184 E.0071
G1 X91.798 Y91.183 E.26559
G1 X91.164 Y91.299 E.01568
G1 X91.163 Y80.05 E.27362
G1 X91.197 Y79.478 E.01394
G1 X91.292 Y78.963 E.01274
G1 X91.447 Y78.463 E.01273
G1 X91.662 Y77.986 E.01273
G1 X91.933 Y77.538 E.01274
G1 X92.256 Y77.126 E.01273
G1 X92.626 Y76.756 E.01273
G1 X93.038 Y76.433 E.01273
G1 X93.473 Y76.17 E.01236
G1 X94.082 Y75.909 E.01612
G1 X94.671 Y75.764 E.01475
G1 X95.263 Y75.674 E.01457
G1 X98.414 Y75.673 E.07664
G1 X98.093 Y76.067 E.01236
G1 X97.815 Y76.559 E.01375
G1 X97.658 Y77.029 E.01205
G1 X97.604 Y77.678 E.01584
G1 X97.642 Y77.902 E.00553
G1 X97.839 Y78.518 E.01573
G1 X98.133 Y78.994 E.01361
G1 X98.54 Y79.457 E.01499
G1 X98.553 Y82.403 E.07166
G1 X98.569 Y82.599 E.00478
G1 X98.731 Y83.49 E.02203
G1 X99.006 Y84.288 E.02053
G1 X99.239 Y84.744 E.01246
G1 X99.614 Y85.359 E.01752
G1 X100.427 Y86.262 E.02956
G1 X101.385 Y86.958 E.0288
G1 X101.964 Y87.248 E.01575
G1 X102.826 Y87.535 E.0221
G1 X103.333 Y87.642 E.0126
G1 X103.891 Y87.694 E.01363
G1 X103.794 Y87.823 E.00393
G1 X103.623 Y88.168 E.00937
G1 X103.551 Y88.519 E.00872
G1 X103.405 Y88.672 E.00514
G1 X103.249 Y88.875 E.00623
G1 X103.249 Y88.875 F9000
G1 X102.762 Y89.447
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X91.757 Y78.443 E.37855
G1 X91.621 Y78.826 E.00989
G1 X102.464 Y89.669 E.37299
G1 X102.373 Y90.097 E.01064
G1 X91.519 Y79.243 E.37337
G1 X91.459 Y79.701 E.01124
G1 X102.354 Y90.596 E.37478
G1 X102.38 Y90.91 E.00766
G1 X102.148 Y90.91 E.00564
G1 X91.437 Y80.198 E.36847
G1 X91.437 Y80.717 E.01262
G1 X101.629 Y90.91 E.35062
G1 X101.11 Y90.91 E.01262
G1 X91.437 Y81.236 E.33276
G1 X91.437 Y81.755 E.01262
G1 X100.592 Y90.909 E.31491
G1 X100.073 Y90.909 E.01262
G1 X91.437 Y82.274 E.29706
G1 X91.437 Y82.793 E.01262
G1 X99.554 Y90.909 E.2792
G1 X99.035 Y90.909 E.01262
G1 X91.437 Y83.312 E.26135
G1 X91.437 Y83.831 E.01262
G1 X98.516 Y90.909 E.2435
G1 X97.997 Y90.909 E.01262
G1 X91.438 Y84.35 E.22563
G1 X91.438 Y84.869 E.01262
G1 X97.478 Y90.909 E.20777
G1 X96.959 Y90.909 E.01262
G1 X91.438 Y85.388 E.18992
G1 X91.438 Y85.907 E.01262
G1 X96.44 Y90.909 E.17207
G1 X95.921 Y90.909 E.01262
G1 X91.438 Y86.426 E.15421
G1 X91.438 Y86.945 E.01262
G1 X95.402 Y90.909 E.13636
G1 X94.883 Y90.909 E.01262
G1 X91.438 Y87.464 E.11851
G1 X91.438 Y87.983 E.01262
G1 X94.365 Y90.909 E.10067
G1 X93.846 Y90.909 E.01262
G1 X91.438 Y88.502 E.08282
G1 X91.438 Y89.021 E.01262
G1 X93.327 Y90.909 E.06496
G1 X92.808 Y90.909 E.01262
G1 X91.438 Y89.54 E.04711
G1 X91.438 Y90.059 E.01262
G1 X92.289 Y90.909 E.02926
G1 X91.773 Y90.912 E.01255
G1 X91.274 Y90.413 E.01717
G1 E-5 F3600
G1 X91.274 Y90.413 F9000
G1 X90.764 Y93.22
G1 X90.759 Y93.278
G1 X90.751 Y93.39
G1 X90.751 Y95.439
G1 X90.759 Y95.55
G1 X90.764 Y95.609
G1 X90.806 Y95.787
G1 X90.877 Y95.958
G1 X90.975 Y96.117
G1 X92.728 Y98.521
G1 E5 F2400
G1 F3072.127
G1 X92.126 Y97.919 E.02071
G1 X91.555 Y97.884 E.01392
G1 X92.563 Y98.892 E.03467
G1 X92.563 Y99.427 E.01301
G1 X91.44 Y98.304 E.03863
G1 X91.44 Y98.839 E.01301
G1 X92.563 Y99.963 E.03865
G1 X92.563 Y100.498 E.01301
G1 X91.44 Y99.375 E.03863
G1 X91.44 Y99.91 E.01301
G1 X92.563 Y101.033 E.03863
G1 X92.563 Y101.344 E.00756
G1 X92.339 Y101.345 E.00545
G1 X91.44 Y100.445 E.03094
G1 X91.44 Y100.981 E.01304
G1 X91.969 Y101.51 E.0182
G1 X91.969 Y101.51 F9000
G1 X93.378 Y102.824
;TYPE:Top solid infill
;WIDTH:0.435098
G1 F900
G1 X94.026 Y103.472 E.02443
G1 X94.026 Y104.039 E.01512
G1 X92.976 Y102.989 E.03959
G1 X92.41 Y102.99 E.01509
G1 X94.026 Y104.606 E.06093
G1 X94.026 Y105.012 E.01082
G1 X93.865 Y105.012 E.00429
G1 X91.844 Y102.991 E.07619
G1 X91.576 Y103.038 E.00725
G1 X91.426 Y103.139 E.00482
G1 X93.298 Y105.011 E.07058
G1 X92.73 Y105.01 E.01514
G1 X91.209 Y103.489 E.05734
G1 X91.14 Y103.79 E.00823
G1 X91.129 Y103.976 E.00497
G1 X92.163 Y105.01 E.03898
G1 X91.785 Y105.009 E.01008
G1 X91.576 Y104.962 E.00571
G1 X91.491 Y104.905 E.00273
G1 X91.01 Y104.424 E.01813
G1 E-5 F3600
G1 X91.01 Y104.424 F9000
G1 X92.728 Y107.32
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X92.063 Y106.655 E.02288
G1 X91.455 Y106.624 E.01481
G1 X92.564 Y107.733 E.03815
G1 X92.564 Y108.31 E.01403
G1 X91.441 Y107.187 E.03863
G1 X91.441 Y107.764 E.01403
G1 X92.564 Y108.887 E.03863
G1 X92.564 Y109.344 E.01112
G1 X92.445 Y109.344 E.00289
G1 X91.441 Y108.341 E.03452
G1 X91.441 Y108.918 E.01403
G1 X92.033 Y109.509 E.02035
G1 X92.033 Y109.509 F9000
G1 X93.378 Y110.824
;WIDTH:0.435136
G1 F900
G1 X94.027 Y111.473 E.02447
G1 X94.027 Y112.039 E.01509
G1 X92.977 Y110.989 E.03959
G1 X92.41 Y110.99 E.01512
G1 X94.027 Y112.606 E.06095
G1 X94.027 Y113.012 E.01082
G1 X93.865 Y113.012 E.00432
G1 X91.844 Y110.991 E.0762
G1 X91.576 Y111.038 E.00725
G1 X91.426 Y111.139 E.00482
G1 X93.298 Y113.011 E.07058
G1 X92.731 Y113.01 E.01512
G1 X91.209 Y111.489 E.05737
G1 X91.14 Y111.79 E.00823
G1 X91.129 Y111.976 E.00497
G1 X92.163 Y113.01 E.03899
G1 X91.785 Y113.009 E.01008
G1 X91.576 Y112.962 E.00571
G1 X91.491 Y112.905 E.00273
G1 X91.01 Y112.424 E.01814
G1 E-5 F3600
G1 X91.01 Y112.424 F9000
G1 X92.729 Y115.32
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X92.064 Y114.655 E.02288
G1 X91.456 Y114.624 E.01481
G1 X92.564 Y115.732 E.03811
G1 X92.564 Y116.309 E.01403
G1 X91.442 Y115.187 E.0386
G1 X91.442 Y115.764 E.01403
G1 X92.564 Y116.886 E.0386
G1 X92.564 Y117.344 E.01114
G1 X92.446 Y117.344 E.00287
G1 X91.442 Y116.341 E.03452
G1 X91.442 Y116.918 E.01403
G1 X92.034 Y117.509 E.02035
G1 X92.034 Y117.509 F9000
G1 X93.379 Y118.824
;WIDTH:0.435173
G1 F900
G1 X94.027 Y119.473 E.02445
G1 X94.027 Y120.039 E.01509
G1 X92.977 Y118.989 E.03959
G1 X92.411 Y118.99 E.01509
G1 X94.027 Y120.606 E.06094
G1 X94.027 Y121.012 E.01083
G1 X93.866 Y121.012 E.00429
G1 X91.845 Y118.991 E.07621
G1 X91.576 Y119.038 E.00728
G1 X91.426 Y119.139 E.00482
G1 X93.298 Y121.011 E.07059
G1 X92.731 Y121.01 E.01512
G1 X91.209 Y119.489 E.05737
G1 X91.14 Y119.79 E.00823
G1 X91.129 Y119.976 E.00497
G1 X92.163 Y121.01 E.03899
G1 X91.785 Y121.009 E.01008
G1 X91.576 Y120.962 E.00571
G1 X91.492 Y120.905 E.00271
G1 X91.01 Y120.424 E.01816
G1 E-5 F3600
G1 X91.01 Y120.424 F9000
G1 X92.729 Y123.32
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X92.064 Y122.655 E.02288
G1 X91.457 Y122.624 E.01478
G1 X92.565 Y123.732 E.03811
G1 X92.565 Y124.309 E.01403
G1 X91.443 Y123.188 E.03858
G1 X91.444 Y123.764 E.01401
G1 X92.565 Y124.886 E.03858
G1 X92.565 Y125.344 E.01114
G1 X92.447 Y125.344 E.00287
G1 X91.444 Y124.341 E.0345
G1 X91.444 Y124.918 E.01403
G1 X92.035 Y125.509 E.02033
G1 X92.035 Y125.509 F9000
G1 X93.379 Y126.824
;WIDTH:0.435203
G1 F900
G1 X94.028 Y127.473 E.02447
G1 X94.028 Y128.04 E.01512
G1 X92.977 Y126.989 E.03963
G1 X92.411 Y126.99 E.01509
G1 X94.028 Y128.607 E.06098
G1 X94.028 Y129.013 E.01083
G1 X93.867 Y129.012 E.00429
G1 X91.845 Y126.991 E.07623
G1 X91.576 Y127.038 E.00728
G1 X91.426 Y127.139 E.00482
G1 X93.299 Y129.012 E.07063
G1 X92.731 Y129.011 E.01515
G1 X91.209 Y127.489 E.0574
G1 X91.14 Y127.79 E.00823
G1 X91.129 Y127.976 E.00497
G1 X92.163 Y129.01 E.03899
G1 X91.785 Y129.009 E.01008
G1 X91.576 Y128.962 E.00571
G1 X91.492 Y128.905 E.00271
G1 X91.01 Y128.424 E.01816
G1 E-5 F3600
G1 X91.01 Y128.424 F9000
G1 X92.73 Y131.32
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X92.065 Y130.655 E.02288
G1 X91.458 Y130.624 E.01478
G1 X92.566 Y131.732 E.03811
G1 X92.566 Y132.309 E.01403
G1 X91.445 Y131.188 E.03856
G1 X91.445 Y131.764 E.01401
G1 X92.569 Y132.888 E.03866
G1 X92.591 Y133.345 E.01113
G1 X92.448 Y133.345 E.00348
G1 X91.445 Y132.341 E.03452
G1 X91.445 Y132.918 E.01403
G1 X92.037 Y133.51 E.02036
G1 E-5 F3600
G1 X92.037 Y133.51 F9000
G1 X94.732 Y135.888
G1 E5 F2400
;WIDTH:0.41211
G1 F900
G1 X93.833 Y134.989 E.03195
G1 X93.299 Y134.989 E.01342
G1 X94.764 Y136.454 E.05206
G1 X95.004 Y137.012 E.01526
G1 X94.788 Y137.012 E.00543
G1 X92.766 Y134.99 E.07186
G1 X92.232 Y134.99 E.01342
G1 X94.253 Y137.012 E.07184
G1 X93.718 Y137.011 E.01344
G1 X91.714 Y135.007 E.07122
G1 X91.576 Y135.038 E.00355
G1 X91.421 Y135.143 E.0047
G1 X91.373 Y135.2 E.00187
G1 X93.184 Y137.011 E.06436
G1 X92.649 Y137.01 E.01344
G1 X91.185 Y135.547 E.05201
G1 X91.14 Y135.79 E.00621
G1 X91.129 Y136.025 E.00591
G1 X92.114 Y137.01 E.03501
G1 X91.785 Y137.009 E.00827
G1 X91.576 Y136.962 E.00538
G1 X91.441 Y136.871 E.00409
G1 X91.014 Y136.443 E.01519
G1 E-5 F3600
G1 X91.014 Y136.443 F9000
G1 X91.282 Y140.775
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X91.852 Y141.345 E.01961
G1 X92.414 Y141.345 E.01367
G1 X91.446 Y140.377 E.0333
G1 X91.446 Y139.815 E.01367
G1 X92.975 Y141.345 E.05261
G1 X93.537 Y141.345 E.01367
G1 X91.446 Y139.253 E.07195
G1 X91.446 Y138.691 E.01367
G1 X94.099 Y141.344 E.09126
G1 X94.66 Y141.344 E.01365
G1 X91.971 Y138.655 E.0925
G1 X92.534 Y138.656 E.01369
G1 X95.222 Y141.344 E.09247
G1 X95.784 Y141.344 E.01367
G1 X93.096 Y138.656 E.09247
G1 X93.659 Y138.657 E.01369
G1 X96.51 Y141.508 E.09807
G1 E-5 F3600
G1 X96.51 Y141.508 F9000
G1 X91.733 Y146.63
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.374336
G1 F1200
G1 X105.423 Y146.631 E.30963
G1 E-5 F3600
G1 X105.423 Y146.631 F9000
G1 X105.199 Y149.177
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X103.009 Y146.987 E.07533
G1 X102.486 Y146.987 E.01272
G1 X104.512 Y149.013 E.06969
G1 X103.99 Y149.013 E.0127
G1 X101.964 Y146.987 E.06969
G1 X101.442 Y146.987 E.0127
G1 X103.468 Y149.013 E.06969
G1 X102.946 Y149.013 E.0127
G1 X100.92 Y146.987 E.06969
G1 X100.398 Y146.987 E.0127
G1 X102.424 Y149.013 E.06969
G1 X101.902 Y149.013 E.0127
G1 X99.876 Y146.987 E.06969
G1 X99.354 Y146.987 E.0127
G1 X101.38 Y149.013 E.06969
G1 X100.858 Y149.013 E.0127
G1 X98.832 Y146.987 E.06969
G1 X98.31 Y146.987 E.0127
G1 X100.336 Y149.013 E.06969
G1 X99.814 Y149.013 E.0127
G1 X97.788 Y146.987 E.06969
G1 X97.266 Y146.987 E.0127
G1 X99.292 Y149.013 E.06969
G1 X98.77 Y149.013 E.0127
G1 X96.744 Y146.987 E.06969
G1 X96.222 Y146.987 E.0127
G1 X98.248 Y149.014 E.06971
G1 X97.726 Y149.014 E.0127
G1 X95.7 Y146.987 E.06971
G1 X95.178 Y146.987 E.0127
G1 X97.204 Y149.014 E.06971
G1 X96.682 Y149.014 E.0127
G1 X94.656 Y146.987 E.06971
G1 X94.134 Y146.987 E.0127
G1 X96.16 Y149.014 E.06971
G1 X95.638 Y149.014 E.0127
G1 X93.612 Y146.987 E.06971
G1 X93.09 Y146.987 E.0127
G1 X95.117 Y149.014 E.06973
G1 X94.595 Y149.014 E.0127
G1 X92.568 Y146.987 E.06973
G1 X92.046 Y146.987 E.0127
G1 X94.073 Y149.014 E.06973
G1 X93.551 Y149.014 E.0127
G1 X91.447 Y146.935 E.07195
G1 X91.447 Y147.433 E.01211
G1 X93.029 Y149.014 E.0544
G1 X92.507 Y149.014 E.0127
G1 X91.447 Y147.955 E.03645
G1 X91.447 Y148.477 E.0127
G1 X91.985 Y149.014 E.01849
G1 X91.52 Y149.072 E.0114
G1 X91.283 Y148.834 E.00817
G1 X91.283 Y148.834 F9000
G1 X91.743 Y149.372
;TYPE:Solid infill
;WIDTH:0.374336
G1 F1200
G1 X105.422 Y149.369 E.30938
G1 E-5 F3600
G1 X105.422 Y149.369 F9000
G1 X105.773 Y151.567
G1 E5 F2400
;WIDTH:0.403026
G1 F900
G1 X105.192 Y150.986 E.02015
G1 X104.671 Y150.987 E.01278
G1 X105.609 Y151.924 E.03252
G1 X105.609 Y152.446 E.0128
G1 X104.15 Y150.987 E.0506
G1 X103.629 Y150.987 E.01278
G1 X105.609 Y152.967 E.06867
G1 X105.609 Y153.014 E.00115
G1 X105.134 Y153.013 E.01165
G1 X103.108 Y150.987 E.07027
G1 X102.586 Y150.987 E.0128
G1 X104.612 Y153.013 E.07027
G1 X104.091 Y153.013 E.01278
G1 X102.065 Y150.987 E.07027
G1 X101.544 Y150.988 E.01278
G1 X103.569 Y153.013 E.07024
G1 X103.048 Y153.013 E.01278
G1 X101.023 Y150.988 E.07024
G1 X100.501 Y150.988 E.0128
G1 X102.526 Y153.013 E.07024
G1 X102.004 Y153.012 E.0128
G1 X99.98 Y150.988 E.0702
G1 X99.459 Y150.988 E.01278
G1 X101.483 Y153.012 E.0702
G1 X100.961 Y153.012 E.0128
G1 X98.938 Y150.988 E.07018
G1 X98.416 Y150.989 E.0128
G1 X100.44 Y153.012 E.07018
G1 X99.918 Y153.012 E.0128
G1 X97.895 Y150.989 E.07017
G1 X97.374 Y150.989 E.01278
G1 X99.397 Y153.012 E.07017
G1 X98.875 Y153.012 E.0128
G1 X96.853 Y150.989 E.07015
G1 X96.331 Y150.989 E.0128
G1 X98.353 Y153.011 E.07013
G1 X97.832 Y153.011 E.01278
G1 X95.81 Y150.989 E.07013
G1 X95.289 Y150.99 E.01278
G1 X97.31 Y153.011 E.0701
G1 X96.789 Y153.011 E.01278
G1 X94.768 Y150.99 E.0701
G1 X94.246 Y150.99 E.0128
G1 X96.267 Y153.011 E.0701
G1 X95.746 Y153.011 E.01278
G1 X93.725 Y150.99 E.0701
G1 X93.204 Y150.99 E.01278
G1 X95.224 Y153.01 E.07006
G1 X94.702 Y153.01 E.0128
G1 X92.683 Y150.99 E.07004
G1 X92.161 Y150.991 E.0128
G1 X94.181 Y153.01 E.07004
G1 X93.659 Y153.01 E.0128
G1 X91.667 Y151.017 E.06911
G1 X91.576 Y151.038 E.00229
G1 X91.421 Y151.143 E.00459
G1 X91.352 Y151.224 E.00261
G1 X93.138 Y153.01 E.06195
G1 X92.616 Y153.01 E.0128
G1 X91.178 Y151.571 E.04989
G1 X91.14 Y151.79 E.00545
G1 X91.13 Y152.045 E.00626
G1 X92.095 Y153.009 E.03345
G1 X91.786 Y153.009 E.00758
G1 X91.576 Y152.962 E.00528
G1 X91.422 Y152.858 E.00456
G1 X91.015 Y152.451 E.01412
G1 E-5 F3600
G1 X91.015 Y152.451 F9000
G1 X93.819 Y154.657
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.403577
G1 F1200
G1 X94.532 Y154.657 E.01751
;WIDTH:0.420075
G1 X105.34 Y154.668 E.27733
;WIDTH:0.41755
G1 X105.739 Y154.664 E.01017
G1 X105.588 Y154.797 E.00513
G1 X105.498 Y155.051 E.00687
G1 X105.34 Y155.051 E.00403
;WIDTH:0.420075
G1 X95.481 Y155.052 E.25298
G1 X94.99 Y155.026 E.01262
;WIDTH:0.403577
G1 X94.491 Y154.93 E.01248
G1 X93.967 Y154.74 E.01369
G1 E-5 F3600
G1 X93.967 Y154.74 F9000
G1 X106.547 Y155.224
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X106.136 Y154.813 E.01414
G1 X106.259 Y154.715 E.00383
G1 X106.196 Y154.558 E.00411
G1 X106.35 Y154.505 E.00396
G1 X106.904 Y155.059 E.01906
G1 X107.426 Y155.059 E.0127
G1 X106.655 Y154.288 E.02652
G1 X106.936 Y154.047 E.009
G1 X107.948 Y155.059 E.03481
G1 X108.47 Y155.059 E.0127
G1 X107.113 Y153.702 E.04668
G1 X107.228 Y153.295 E.01029
G1 X108.992 Y155.059 E.06068
G1 X109.514 Y155.059 E.0127
G1 X107.254 Y152.799 E.07774
G1 X107.254 Y152.277 E.0127
G1 X110.036 Y155.059 E.0957
G1 X110.558 Y155.059 E.0127
G1 X107.254 Y151.755 E.11366
G1 X107.254 Y151.233 E.0127
G1 X111.08 Y155.058 E.13159
G1 X111.602 Y155.058 E.0127
G1 X107.236 Y150.693 E.15017
G1 X107.142 Y150.314 E.0095
G1 X106.884 Y149.887 E.01214
G1 X106.363 Y149.489 E.01595
G1 X105.9 Y149.357 E.01171
G1 X103.531 Y146.987 E.08151
G1 X104.053 Y146.987 E.0127
G1 X112.124 Y155.058 E.27764
G1 X112.646 Y155.058 E.0127
G1 X104.575 Y146.987 E.27764
G1 X105.097 Y146.987 E.0127
G1 X113.167 Y155.058 E.27762
G1 X113.689 Y155.058 E.0127
G1 X105.589 Y146.957 E.27865
G1 X105.785 Y146.933 E.0048
G1 X105.768 Y146.653 E.00682
G1 X105.807 Y146.653 E.00095
G1 X114.211 Y155.058 E.28911
G1 X114.733 Y155.058 E.0127
G1 X106.232 Y146.557 E.29243
G1 X106.581 Y146.384 E.00947
G1 X115.255 Y155.058 E.29838
G1 X115.777 Y155.057 E.0127
G1 X106.855 Y146.135 E.30691
G1 X107.066 Y145.824 E.00914
G1 X116.299 Y155.057 E.31761
G1 X116.821 Y155.057 E.0127
G1 X107.194 Y145.431 E.33115
G1 X107.254 Y144.969 E.01133
G1 X117.343 Y155.057 E.34704
G1 X117.865 Y155.057 E.0127
G1 X107.344 Y144.536 E.36192
G1 X107.865 Y144.535 E.01267
G1 X118.387 Y155.057 E.36195
G1 X118.909 Y155.057 E.0127
G1 X108.385 Y144.534 E.362
G1 X108.906 Y144.532 E.01267
G1 X119.431 Y155.057 E.36205
G1 X119.952 Y155.057 E.01267
G1 X109.427 Y144.531 E.36207
G1 X109.948 Y144.53 E.01267
G1 X120.474 Y155.056 E.36209
G1 X120.996 Y155.056 E.0127
G1 X110.469 Y144.529 E.36212
G1 X110.944 Y144.482 E.01161
G1 X121.518 Y155.056 E.36374
G1 X122.04 Y155.056 E.0127
G1 X111.317 Y144.333 E.36886
G1 X111.361 Y144.314 E.00117
G1 X111.392 Y144.385 E.00188
G1 X111.891 Y144.385 E.01214
G1 X122.562 Y155.056 E.36708
G1 X123.084 Y155.056 E.0127
G1 X112.413 Y144.385 E.36708
G1 X112.935 Y144.385 E.0127
G1 X123.606 Y155.056 E.36708
G1 X124.128 Y155.056 E.0127
G1 X113.457 Y144.385 E.36708
G1 X113.979 Y144.385 E.0127
G1 X124.65 Y155.056 E.36708
G1 X125.172 Y155.055 E.0127
G1 X114.501 Y144.385 E.36706
G1 X115.023 Y144.385 E.0127
G1 X123.746 Y153.107 E.30005
G1 X123.746 Y152.585 E.0127
G1 X115.546 Y144.385 E.28208
G1 X116.068 Y144.385 E.0127
G1 X123.746 Y152.063 E.26412
G1 X123.746 Y151.541 E.0127
G1 X116.59 Y144.385 E.24616
G1 X117.112 Y144.385 E.0127
G1 X123.746 Y151.019 E.22821
G1 X123.792 Y150.543 E.01163
G1 X117.634 Y144.385 E.21183
G1 X118.156 Y144.385 E.0127
G1 X123.938 Y150.167 E.1989
G1 X124.149 Y149.857 E.00912
G1 X118.678 Y144.385 E.18822
G1 X119.2 Y144.385 E.0127
G1 X124.426 Y149.612 E.17979
G1 X124.777 Y149.44 E.00951
G1 X119.66 Y144.323 E.17602
G1 X119.992 Y144.47 E.00883
G1 X120.387 Y144.529 E.00971
G1 X125.205 Y149.347 E.16574
G1 X125.215 Y149.067 E.00682
G1 X125.422 Y149.041 E.00507
G1 X120.911 Y144.53 E.15518
G1 X121.435 Y144.532 E.01275
G1 X125.915 Y149.013 E.15413
G1 X126.437 Y149.013 E.0127
G1 X121.959 Y144.534 E.15406
G1 X122.482 Y144.535 E.01272
G1 X126.96 Y149.013 E.15404
G1 X127.482 Y149.013 E.0127
G1 X125.114 Y146.645 E.08146
G1 X124.637 Y146.511 E.01205
G1 X124.232 Y146.234 E.01194
G1 X123.85 Y145.669 E.01659
G1 X123.784 Y145.315 E.00876
G1 X123.006 Y144.537 E.02676
G1 X123.53 Y144.539 E.01275
G1 X123.91 Y144.919 E.01307
G1 E-5 F3600
G1 X123.91 Y144.919 F9000
G1 X125.578 Y146.631
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.374336
G1 F1200
G1 X139.269 Y146.629 E.30965
G1 X139.727 Y147.163 F9000
;WIDTH:0.4
G1 F3072.127
G1 X139.506 Y146.943 E.00759
G1 X139.029 Y146.987 E.01165
G1 X139.563 Y147.521 E.01837
G1 X139.563 Y148.043 E.0127
G1 X138.507 Y146.987 E.03633
G1 X137.985 Y146.987 E.0127
G1 X139.563 Y148.565 E.05428
G1 X139.563 Y149.084 E.01262
G1 X137.463 Y146.987 E.07219
G1 X136.941 Y146.987 E.0127
G1 X138.966 Y149.013 E.06968
G1 X138.444 Y149.013 E.0127
G1 X136.419 Y146.987 E.06968
G1 X135.897 Y146.987 E.0127
G1 X137.922 Y149.013 E.06968
G1 X137.4 Y149.013 E.0127
G1 X135.375 Y146.987 E.06968
G1 X134.853 Y146.987 E.0127
G1 X136.878 Y149.013 E.06968
G1 X136.356 Y149.013 E.0127
G1 X134.331 Y146.987 E.06968
G1 X133.809 Y146.987 E.0127
G1 X135.834 Y149.013 E.06968
G1 X135.312 Y149.013 E.0127
G1 X133.287 Y146.987 E.06968
G1 X132.764 Y146.987 E.01272
G1 X134.79 Y149.013 E.06969
G1 X134.268 Y149.013 E.0127
G1 X132.242 Y146.987 E.06969
G1 X131.72 Y146.987 E.0127
G1 X133.746 Y149.013 E.06969
G1 X133.224 Y149.013 E.0127
G1 X131.198 Y146.987 E.06969
G1 X130.676 Y146.987 E.0127
G1 X132.702 Y149.013 E.06969
G1 X132.18 Y149.013 E.0127
G1 X130.154 Y146.987 E.06969
G1 X129.632 Y146.987 E.0127
G1 X131.658 Y149.013 E.06969
G1 X131.136 Y149.013 E.0127
G1 X129.11 Y146.987 E.06969
G1 X128.588 Y146.987 E.0127
G1 X130.614 Y149.013 E.06969
G1 X130.092 Y149.013 E.0127
G1 X128.066 Y146.987 E.06969
G1 X127.544 Y146.987 E.0127
G1 X129.57 Y149.013 E.06969
G1 X129.048 Y149.013 E.0127
G1 X127.022 Y146.987 E.06969
G1 X126.5 Y146.987 E.0127
G1 X128.526 Y149.013 E.06969
G1 X128.004 Y149.013 E.0127
G1 X125.814 Y146.823 E.07533
G1 E-5 F3600
G1 X125.814 Y146.823 F9000
G1 X125.577 Y149.369
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.374336
G1 F1200
G1 X139.253 Y149.37 E.30931
G1 E-5 F3600
G1 X139.253 Y149.37 F9000
G1 X139.985 Y151.549
G1 E5 F2400
;WIDTH:0.403026
G1 F900
G1 X139.578 Y151.142 E.01412
G1 X139.424 Y151.038 E.00456
G1 X139.214 Y150.991 E.00528
G1 X138.905 Y150.991 E.00758
G1 X139.87 Y151.955 E.03345
G1 X139.86 Y152.21 E.00626
G1 X139.822 Y152.429 E.00545
G1 X138.384 Y150.99 E.04989
G1 X137.862 Y150.99 E.0128
G1 X139.648 Y152.776 E.06195
G1 X139.579 Y152.857 E.00261
G1 X139.424 Y152.962 E.00459
G1 X139.333 Y152.983 E.00229
G1 X137.341 Y150.99 E.06911
G1 X136.819 Y150.99 E.0128
G1 X138.839 Y153.009 E.07004
G1 X138.317 Y153.01 E.0128
G1 X136.298 Y150.99 E.07004
G1 X135.776 Y150.99 E.0128
G1 X137.796 Y153.01 E.07006
G1 X137.275 Y153.01 E.01278
G1 X135.254 Y150.99 E.07008
G1 X134.733 Y150.989 E.01278
G1 X136.754 Y153.01 E.0701
G1 X136.232 Y153.01 E.0128
G1 X134.211 Y150.989 E.0701
G1 X133.69 Y150.989 E.01278
G1 X135.711 Y153.01 E.0701
G1 X135.19 Y153.011 E.01278
G1 X133.168 Y150.989 E.07013
G1 X132.647 Y150.989 E.01278
G1 X134.669 Y153.011 E.07013
G1 X134.147 Y153.011 E.0128
G1 X132.125 Y150.989 E.07013
G1 X131.604 Y150.989 E.01278
G1 X133.626 Y153.011 E.07013
G1 X133.105 Y153.011 E.01278
G1 X131.082 Y150.989 E.07015
G1 X130.561 Y150.988 E.01278
G1 X132.584 Y153.011 E.07017
G1 X132.062 Y153.012 E.0128
G1 X130.039 Y150.988 E.07018
G1 X129.517 Y150.988 E.0128
G1 X131.541 Y153.012 E.0702
G1 X131.02 Y153.012 E.01278
G1 X128.996 Y150.988 E.0702
G1 X128.474 Y150.988 E.0128
G1 X130.499 Y153.012 E.07022
G1 X129.977 Y153.012 E.0128
G1 X127.953 Y150.988 E.0702
G1 X127.431 Y150.988 E.0128
G1 X129.456 Y153.012 E.07022
G1 X128.935 Y153.013 E.01278
G1 X126.91 Y150.987 E.07025
G1 X126.388 Y150.987 E.0128
G1 X128.414 Y153.013 E.07027
G1 X127.892 Y153.013 E.0128
G1 X125.867 Y150.987 E.07025
G1 X125.391 Y150.987 E.01167
G1 X125.391 Y151.033 E.00113
G1 X127.371 Y153.013 E.06867
G1 X126.85 Y153.013 E.01278
G1 X125.391 Y151.554 E.0506
G1 X125.391 Y152.076 E.0128
G1 X126.329 Y153.013 E.03252
G1 X125.807 Y153.014 E.0128
G1 X125.227 Y152.433 E.02013
G1 E-5 F3600
G1 X125.227 Y152.433 F9000
G1 X125.455 Y154.667
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.415352
G1 F1200
G1 X125.804 Y154.667 E.00885
;WIDTH:0.415821
G1 X136.65 Y154.651 E.27523
;WIDTH:0.390904
G1 X137.152 Y154.669 E.01191
G1 X137.155 Y154.688 E.00046
G1 X136.688 Y154.884 E.01201
G1 X136.197 Y155.003 E.01198
;WIDTH:0.415821
G1 X135.72 Y155.045 E.01215
G1 X125.804 Y155.048 E.25163
;WIDTH:0.415352
G1 X125.609 Y155.048 E.00494
G1 X125.594 Y154.831 E.00551
G1 X125.573 Y154.806 E.00083
G1 E-5 F3600
G1 X125.573 Y154.806 F9000
G1 X134.953 Y141.509
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X134.702 Y141.258 E.00863
G1 X134.981 Y140.992 E.00938
G1 X135.333 Y141.344 E.01211
G1 X135.878 Y141.344 E.01326
G1 X135.247 Y140.713 E.02171
G1 X135.505 Y140.426 E.00939
G1 X136.423 Y141.344 E.03158
G1 X136.968 Y141.345 E.01326
G1 X135.753 Y140.129 E.04181
G1 X135.995 Y139.826 E.00943
G1 X137.513 Y141.345 E.05224
G1 X138.058 Y141.345 E.01326
G1 X136.226 Y139.512 E.06304
G1 X136.45 Y139.191 E.00952
G1 X138.604 Y141.345 E.0741
G1 X139.149 Y141.345 E.01326
G1 X136.66 Y138.857 E.0856
G1 X136.783 Y138.657 E.00571
G1 X137.005 Y138.657 E.0054
G1 X139.562 Y141.213 E.08794
G1 X139.562 Y140.668 E.01326
G1 X137.55 Y138.656 E.06921
G1 X138.094 Y138.656 E.01323
G1 X139.561 Y140.123 E.05046
G1 X139.561 Y139.578 E.01326
G1 X138.638 Y138.655 E.03175
G1 X139.183 Y138.655 E.01326
G1 X139.726 Y139.198 E.01868
G1 E-5 F3600
G1 X139.726 Y139.198 F9000
G1 X139.989 Y135.572
G1 E5 F2400
;WIDTH:0.429725
G1 F900
G1 X139.52 Y135.103 E.01744
G1 X139.424 Y135.038 E.00305
G1 X139.215 Y134.991 E.00563
G1 X138.848 Y134.99 E.00965
G1 X139.871 Y136.013 E.03805
G1 X139.86 Y136.21 E.00519
G1 X139.796 Y136.498 E.00776
G1 X138.289 Y134.99 E.05607
G1 X137.729 Y134.989 E.01473
G1 X139.587 Y136.848 E.06913
G1 X139.424 Y136.962 E.00523
G1 X139.19 Y137.009 E.00628
G1 X137.169 Y134.989 E.07515
G1 X136.695 Y134.988 E.01247
G1 X136.677 Y135.056 E.00185
G1 X138.631 Y137.01 E.07268
G1 X138.073 Y137.01 E.01468
G1 X136.561 Y135.499 E.05622
G1 X136.429 Y135.926 E.01176
G1 X137.514 Y137.011 E.04036
G1 X136.955 Y137.012 E.0147
G1 X136.28 Y136.336 E.02513
G1 X136.122 Y136.737 E.01134
G1 X136.561 Y137.176 E.01633
G1 E-5 F3600
G1 X136.561 Y137.176 F9000
G1 X138.27 Y132.811
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X138.804 Y133.345 E.01837
G1 X139.331 Y133.354 E.01282
G1 X138.435 Y132.458 E.03082
G1 X138.435 Y131.94 E.0126
G1 X139.56 Y133.065 E.0387
G1 X139.56 Y132.547 E.0126
G1 X138.435 Y131.422 E.0387
G1 X138.435 Y130.904 E.0126
G1 X139.56 Y132.029 E.0387
G1 X139.56 Y131.511 E.0126
G1 X138.704 Y130.655 E.02945
G1 X139.222 Y130.655 E.0126
G1 X139.725 Y131.158 E.0173
G1 E-5 F3600
G1 X139.725 Y131.158 F9000
G1 X139.99 Y127.577
G1 E5 F2400
;WIDTH:0.43522
G1 F900
G1 X139.508 Y127.095 E.01818
G1 X139.424 Y127.038 E.00271
G1 X139.215 Y126.991 E.00571
G1 X138.837 Y126.99 E.01008
G1 X139.871 Y128.024 E.03899
G1 X139.86 Y128.21 E.00497
G1 X139.82 Y128.44 E.00623
G1 X139.791 Y128.511 E.00205
G1 X138.269 Y126.99 E.05738
G1 X137.701 Y126.989 E.01515
G1 X139.574 Y128.861 E.07062
G1 X139.424 Y128.962 E.00482
G1 X139.155 Y129.009 E.00728
G1 X137.134 Y126.988 E.07622
G1 X136.972 Y126.988 E.00432
G1 X136.972 Y127.394 E.01083
G1 X138.589 Y129.01 E.06096
G1 X138.022 Y129.011 E.01512
G1 X136.972 Y127.961 E.0396
G1 X136.972 Y128.528 E.01512
G1 X137.621 Y129.176 E.02446
G1 E-5 F3600
G1 X137.621 Y129.176 F9000
G1 X139.101 Y125.51
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X138.435 Y124.844 E.02291
G1 X138.435 Y124.267 E.01403
G1 X139.559 Y125.38 E.03848
G1 X139.559 Y124.814 E.01377
G1 X138.435 Y123.69 E.03866
G1 X138.435 Y123.113 E.01403
G1 X139.559 Y124.237 E.03866
G1 X139.559 Y123.659 E.01406
G1 X138.555 Y122.656 E.03452
G1 X139.131 Y122.655 E.01401
G1 X139.723 Y123.247 E.02036
G1 E-5 F3600
G1 X139.723 Y123.247 F9000
G1 X139.99 Y119.576
G1 E5 F2400
;WIDTH:0.435182
G1 F900
G1 X139.508 Y119.095 E.01816
G1 X139.424 Y119.038 E.00271
G1 X139.215 Y118.991 E.00571
G1 X138.837 Y118.99 E.01008
G1 X139.871 Y120.024 E.03899
G1 X139.86 Y120.21 E.00497
G1 X139.82 Y120.44 E.00622
G1 X139.791 Y120.511 E.00205
G1 X138.269 Y118.99 E.05737
G1 X137.702 Y118.989 E.01512
G1 X139.574 Y120.861 E.07059
G1 X139.424 Y120.962 E.00482
G1 X139.155 Y121.009 E.00728
G1 X137.134 Y118.988 E.07621
G1 X136.973 Y118.988 E.00429
G1 X136.973 Y119.394 E.01083
G1 X138.589 Y121.01 E.06094
G1 X138.023 Y121.011 E.01509
G1 X136.973 Y119.961 E.03959
G1 X136.973 Y120.528 E.01512
G1 X137.621 Y121.176 E.02444
G1 E-5 F3600
G1 X137.621 Y121.176 F9000
G1 X139.101 Y117.51
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X138.436 Y116.845 E.02288
G1 X138.436 Y116.268 E.01403
G1 X139.558 Y117.38 E.03842
G1 X139.558 Y116.813 E.01379
G1 X138.436 Y115.691 E.0386
G1 X138.436 Y115.114 E.01403
G1 X139.558 Y116.236 E.0386
G1 X139.558 Y115.659 E.01403
G1 X138.554 Y114.656 E.03452
G1 X139.13 Y114.655 E.01401
G1 X139.722 Y115.247 E.02036
G1 E-5 F3600
G1 X139.722 Y115.247 F9000
G1 X139.99 Y111.576
G1 E5 F2400
;WIDTH:0.435145
G1 F900
G1 X139.508 Y111.095 E.01816
G1 X139.424 Y111.038 E.00271
G1 X139.215 Y110.991 E.00571
G1 X138.837 Y110.99 E.01008
G1 X139.871 Y112.024 E.03899
G1 X139.86 Y112.21 E.00497
G1 X139.791 Y112.511 E.00823
G1 X138.269 Y110.99 E.05737
G1 X137.702 Y110.989 E.01512
G1 X139.574 Y112.861 E.07058
G1 X139.424 Y112.962 E.00482
G1 X139.155 Y113.009 E.00728
G1 X137.134 Y110.988 E.0762
G1 X136.973 Y110.988 E.00429
G1 X136.973 Y111.394 E.01082
G1 X138.589 Y113.01 E.06093
G1 X138.023 Y113.011 E.01509
G1 X136.973 Y111.961 E.03959
G1 X136.973 Y112.528 E.01512
G1 X137.621 Y113.176 E.02443
G1 E-5 F3600
G1 X137.621 Y113.176 F9000
G1 X139.101 Y109.51
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X138.436 Y108.845 E.02288
G1 X138.436 Y108.268 E.01403
G1 X139.557 Y109.38 E.03841
G1 X139.557 Y108.812 E.01382
G1 X138.436 Y107.692 E.03854
G1 X138.436 Y107.115 E.01403
G1 X139.557 Y108.236 E.03856
G1 X139.556 Y107.659 E.01403
G1 X138.553 Y106.656 E.0345
G1 X139.129 Y106.655 E.01401
G1 X139.721 Y107.247 E.02036
G1 E-5 F3600
G1 X139.721 Y107.247 F9000
G1 X139.99 Y103.576
G1 E5 F2400
;WIDTH:0.435108
G1 F900
G1 X139.508 Y103.095 E.01815
G1 X139.424 Y103.038 E.00271
G1 X139.215 Y102.991 E.00571
G1 X138.837 Y102.99 E.01008
G1 X139.871 Y104.024 E.03898
G1 X139.86 Y104.21 E.00497
G1 X139.791 Y104.511 E.00823
G1 X138.269 Y102.99 E.05736
G1 X137.702 Y102.989 E.01512
G1 X139.574 Y104.861 E.07058
G1 X139.424 Y104.962 E.00482
G1 X139.156 Y105.009 E.00725
G1 X137.135 Y102.988 E.0762
G1 X136.974 Y102.988 E.00429
G1 X136.974 Y103.394 E.01082
G1 X138.59 Y105.01 E.06093
G1 X138.023 Y105.011 E.01512
G1 X136.974 Y103.961 E.03957
G1 X136.974 Y104.528 E.01512
G1 X137.622 Y105.176 E.02443
G1 E-5 F3600
G1 X137.622 Y105.176 F9000
G1 X139.037 Y101.51
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X138.437 Y100.909 E.02066
G1 X138.437 Y100.375 E.01299
G1 X139.423 Y101.361 E.03392
G1 X139.556 Y101.379 E.00326
G1 X139.555 Y100.96 E.01019
G1 X138.437 Y99.841 E.03848
G1 X138.437 Y99.307 E.01299
G1 X139.555 Y100.426 E.03848
G1 X139.555 Y99.892 E.01299
G1 X138.437 Y98.773 E.03848
G1 X138.437 Y98.239 E.01299
G1 X139.555 Y99.358 E.03848
G1 X139.555 Y98.824 E.01299
G1 X138.651 Y97.919 E.03111
G1 X139.185 Y97.919 E.01299
G1 X139.72 Y98.454 E.0184
G1 E-5 F3600
G1 X139.72 Y98.454 F9000
G1 X140.236 Y95.609
G1 X140.241 Y95.55
G1 X140.249 Y95.439
G1 X140.249 Y93.39
G1 X140.241 Y93.278
G1 X140.236 Y93.22
G1 X140.194 Y93.041
G1 X140.123 Y92.87
G1 X140.025 Y92.712
G1 X139.943 Y92.619
G1 X139.89 Y92.562
G1 X139.74 Y92.45
G1 X139.571 Y92.365
G1 X139.398 Y92.316
G1 X128.482 Y90.37
G1 E5 F2400
G1 F3072.127
G1 X129.022 Y90.91 E.01858
G1 X129.547 Y90.91 E.01277
G1 X128.607 Y89.969 E.03235
G1 X128.507 Y89.6 E.0093
G1 X128.226 Y89.063 E.01474
G1 X130.073 Y90.91 E.06354
G1 X130.598 Y90.909 E.01277
G1 X127.607 Y87.919 E.10287
G1 X128.06 Y87.846 E.01116
G1 X131.124 Y90.909 E.10538
G1 X131.649 Y90.909 E.01277
G1 X128.468 Y87.729 E.10941
G1 X128.868 Y87.603 E.0102
G1 X132.174 Y90.909 E.11372
G1 X132.7 Y90.909 E.01279
G1 X129.239 Y87.449 E.11904
G1 X129.59 Y87.274 E.00954
G1 X133.225 Y90.909 E.12504
G1 X133.751 Y90.909 E.01279
G1 X129.914 Y87.072 E.13199
G1 X130.237 Y86.871 E.00925
G1 X134.276 Y90.909 E.13892
G1 X134.802 Y90.909 E.01279
G1 X130.544 Y86.651 E.14647
G1 X130.819 Y86.402 E.00902
G1 X135.327 Y90.909 E.15506
G1 X135.852 Y90.909 E.01277
G1 X131.087 Y86.143 E.16393
G1 X131.328 Y85.859 E.00906
G1 X136.378 Y90.909 E.17372
G1 X136.903 Y90.909 E.01277
G1 X131.569 Y85.575 E.18349
G1 X131.778 Y85.259 E.00922
G1 X137.429 Y90.909 E.19437
G1 X137.954 Y90.909 E.01277
G1 X131.965 Y84.92 E.20602
G1 X132.152 Y84.582 E.0094
G1 X138.479 Y90.909 E.21765
G1 X139.005 Y90.909 E.01279
G1 X132.315 Y84.22 E.23011
G1 X132.438 Y83.817 E.01025
G1 X139.554 Y90.933 E.24479
G1 X139.554 Y90.407 E.01279
G1 X132.557 Y83.411 E.24068
G1 X132.655 Y82.983 E.01068
G1 X139.554 Y89.882 E.23732
G1 X139.554 Y89.356 E.01279
G1 X132.715 Y82.517 E.23526
G1 X132.718 Y81.995 E.0127
G1 X139.554 Y88.831 E.23515
G1 X139.553 Y88.305 E.01279
G1 X132.722 Y81.473 E.235
G1 X132.725 Y80.951 E.0127
G1 X139.553 Y87.78 E.2349
G1 X139.553 Y87.254 E.01279
G1 X132.729 Y80.429 E.23476
G1 X132.732 Y79.907 E.0127
G1 X139.553 Y86.729 E.23466
G1 X139.553 Y86.203 E.01279
G1 X132.824 Y79.474 E.23147
G1 X133.062 Y79.187 E.00907
G1 X139.553 Y85.678 E.22329
G1 X139.553 Y85.152 E.01279
G1 X133.267 Y78.866 E.21623
G1 X133.457 Y78.531 E.00937
G1 X139.553 Y84.626 E.20968
G1 X139.553 Y84.101 E.01277
G1 X133.584 Y78.132 E.20533
G1 X133.67 Y77.692 E.01091
G1 X139.553 Y83.575 E.20237
G1 X139.553 Y83.05 E.01277
G1 X133.637 Y77.134 E.20351
G1 X133.387 Y76.359 E.01981
G1 X139.553 Y82.524 E.21209
G1 X139.553 Y81.999 E.01277
G1 X133.497 Y75.944 E.20831
G1 X134.024 Y75.944 E.01282
G1 X139.552 Y81.473 E.19018
G1 X139.552 Y80.948 E.01277
G1 X134.55 Y75.945 E.17208
G1 X135.076 Y75.946 E.01279
G1 X139.552 Y80.422 E.15397
G1 X139.552 Y79.897 E.01277
G1 X135.603 Y75.947 E.13586
G1 X136.187 Y76.006 E.01428
G1 X139.478 Y79.297 E.11321
G1 X139.28 Y78.574 E.01823
G1 X136.899 Y76.192 E.08192
G1 X137.804 Y76.663 E.02482
G1 X138.349 Y77.117 E.01725
G1 X139.153 Y77.921 E.02766
G1 E-5 F3600
G1 X139.153 Y77.921 F9000
G1 X129.638 Y85.605
G1 X129.542 Y85.676
G1 X129.373 Y85.8
G1 X129.272 Y85.866
G1 X129.094 Y85.978
G1 X128.987 Y86.036
G1 X128.801 Y86.135
G1 X128.695 Y86.184
G1 X128.503 Y86.268
G1 X128.394 Y86.309
G1 X128.196 Y86.378
G1 X128.085 Y86.413
G1 X127.883 Y86.467
G1 X127.769 Y86.494
G1 X127.564 Y86.533
G1 X127.449 Y86.552
G1 X127.24 Y86.576
G1 X127.125 Y86.587
G1 X103.093 Y87.703
G1 E5 F2400
G1 F3072.127
G1 X103.397 Y88.007 E.01046
G1 X103.279 Y88.408 E.01017
G1 X102.639 Y87.768 E.02202
G1 X101.849 Y87.497 E.02032
G1 X103.038 Y88.686 E.0409
G1 X102.818 Y88.985 E.00903
G1 X91.921 Y78.088 E.37485
G1 X92.116 Y77.764 E.0092
G1 X98.76 Y84.408 E.22855
G1 X98.482 Y83.611 E.02053
G1 X92.337 Y77.466 E.21138
G1 X92.58 Y77.19 E.00894
G1 X98.348 Y82.958 E.19842
G1 X98.278 Y82.369 E.01443
G1 X92.843 Y76.934 E.18696
G1 X93.134 Y76.706 E.00899
G1 X98.276 Y81.848 E.17688
G1 X98.274 Y81.327 E.01267
G1 X93.45 Y76.504 E.16593
G1 X93.795 Y76.33 E.0094
G1 X98.271 Y80.806 E.15397
G1 X98.269 Y80.285 E.01267
G1 X94.159 Y76.174 E.1414
G1 X94.573 Y76.07 E.01038
G1 X98.267 Y79.764 E.12707
G1 X98.266 Y79.567 E.00479
G1 X97.903 Y79.144 E.01356
G1 X97.548 Y78.526 E.01734
G1 X95.011 Y75.989 E.08727
G1 X95.489 Y75.948 E.01167
G1 X97.348 Y77.806 E.06393
G1 X97.349 Y77.289 E.01258
G1 X96.008 Y75.948 E.04613
G1 X96.526 Y75.948 E.0126
G1 X97.432 Y76.853 E.03115
G1 X97.561 Y76.463 E.00999
G1 X97.045 Y75.948 E.01773
G1 X97.564 Y75.948 E.01262
G1 X97.865 Y76.248 E.01034
G1 E-5 F3600
G1 X97.865 Y76.248 F9000
G1 X90.877 Y92.87
G1 X90.806 Y93.041
G1 X90.764 Y93.22
G1 X90.759 Y93.278
G1 X90.751 Y93.39
G1 X90.751 Y95.439
G1 X91.128 Y144
G1 X91.14 Y144.21
G1 X91.18 Y144.44
G1 X91.287 Y144.699
G1 X91.421 Y144.858
G1 X91.576 Y144.962
G1 X91.786 Y145.009
G1 X105.609 Y145.014
G1 X105.609 Y143.68
G1 X105.773 Y143.68
G1 E5 F2400
;WIDTH:0.400417
G1 F900
G1 X105.27 Y143.176 E.01734
G1 X104.752 Y143.176 E.01261
G1 X105.609 Y144.033 E.02951
G1 X105.609 Y144.551 E.01261
G1 X104.219 Y143.161 E.04787
G1 X103.671 Y143.131 E.01336
G1 X105.554 Y145.014 E.06485
G1 X105.036 Y145.013 E.01261
G1 X103.045 Y143.022 E.06857
G1 X102.845 Y142.987 E.00494
G1 X102.492 Y142.987 E.0086
G1 X104.518 Y145.013 E.06977
G1 X104 Y145.013 E.01261
G1 X101.974 Y142.987 E.06977
G1 X101.457 Y142.987 E.01259
G1 X103.482 Y145.013 E.06976
G1 X102.964 Y145.013 E.01261
G1 X100.939 Y142.987 E.06976
G1 X100.422 Y142.988 E.01259
G1 X102.447 Y145.013 E.06974
G1 X101.929 Y145.012 E.01261
G1 X99.904 Y142.988 E.06972
G1 X99.387 Y142.988 E.01259
G1 X101.411 Y145.012 E.0697
G1 X100.893 Y145.012 E.01261
G1 X98.869 Y142.988 E.0697
G1 X98.351 Y142.988 E.01261
G1 X100.375 Y145.012 E.0697
G1 X99.857 Y145.012 E.01261
G1 X97.834 Y142.989 E.06967
G1 X97.316 Y142.989 E.01261
G1 X99.339 Y145.012 E.06967
G1 X98.821 Y145.011 E.01261
G1 X96.799 Y142.989 E.06963
G1 X96.281 Y142.989 E.01261
G1 X98.304 Y145.011 E.06965
G1 X97.786 Y145.011 E.01261
G1 X95.764 Y142.989 E.06963
G1 X95.246 Y142.989 E.01261
G1 X97.268 Y145.011 E.06963
G1 X96.75 Y145.011 E.01261
G1 X94.729 Y142.99 E.0696
G1 X94.211 Y142.99 E.01261
G1 X96.232 Y145.011 E.0696
G1 X95.714 Y145.011 E.01261
G1 X93.694 Y142.99 E.06958
G1 X93.176 Y142.99 E.01261
G1 X95.196 Y145.01 E.06957
G1 X94.678 Y145.01 E.01261
G1 X92.659 Y142.99 E.06955
G1 X92.141 Y142.99 E.01261
G1 X94.161 Y145.01 E.06957
G1 X93.643 Y145.01 E.01261
G1 X91.653 Y143.02 E.06853
G1 X91.576 Y143.038 E.00193
G1 X91.421 Y143.143 E.00456
G1 X91.346 Y143.231 E.00282
G1 X93.125 Y145.01 E.06127
G1 X92.607 Y145.01 E.01261
G1 X91.177 Y143.579 E.04926
G1 X91.14 Y143.79 E.00522
G1 X91.131 Y144.051 E.00636
G1 X92.254 Y145.174 E.03867
G1 E-5 F3600
G1 X92.254 Y145.174 F9000
G1 X111.724 Y144.012
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.415904
G1 F1200
G1 X119.276 Y144.012 E.19168
G1 E-5 F3600
G1 X119.276 Y144.012 F9000
G1 X139.985 Y143.549
G1 E5 F2400
;WIDTH:0.403029
G1 F900
G1 X139.578 Y143.142 E.01412
G1 X139.424 Y143.038 E.00456
G1 X139.214 Y142.991 E.00528
G1 X138.905 Y142.991 E.00758
G1 X139.87 Y143.955 E.03345
G1 X139.86 Y144.21 E.00626
G1 X139.822 Y144.429 E.00545
G1 X138.384 Y142.991 E.04988
G1 X137.862 Y142.991 E.0128
G1 X139.648 Y144.776 E.06193
G1 X139.579 Y144.857 E.00261
G1 X139.424 Y144.962 E.00459
G1 X139.333 Y144.983 E.00229
G1 X137.341 Y142.991 E.06909
G1 X136.82 Y142.991 E.01278
G1 X138.839 Y145.009 E.07001
G1 X138.317 Y145.01 E.0128
G1 X136.298 Y142.991 E.07003
G1 X135.777 Y142.991 E.01278
G1 X137.796 Y145.01 E.07003
G1 X137.275 Y145.01 E.01278
G1 X135.255 Y142.991 E.07005
G1 X134.734 Y142.991 E.01278
G1 X136.754 Y145.01 E.07005
G1 X136.232 Y145.01 E.0128
G1 X134.213 Y142.991 E.07003
G1 X133.691 Y142.991 E.0128
G1 X135.711 Y145.01 E.07005
G1 X135.19 Y145.011 E.01278
G1 X133.17 Y142.991 E.07006
G1 X132.648 Y142.991 E.0128
G1 X134.669 Y145.011 E.07008
G1 X134.147 Y145.011 E.0128
G1 X132.127 Y142.991 E.07006
G1 X131.606 Y142.991 E.01278
G1 X133.626 Y145.011 E.07006
G1 X133.105 Y145.011 E.01278
G1 X131.084 Y142.991 E.07008
G1 X130.563 Y142.991 E.01278
G1 X132.584 Y145.011 E.07008
G1 X132.062 Y145.012 E.0128
G1 X130.041 Y142.991 E.0701
G1 X129.52 Y142.991 E.01278
G1 X131.541 Y145.012 E.0701
G1 X131.02 Y145.012 E.01278
G1 X128.999 Y142.991 E.0701
G1 X128.475 Y142.988 E.01285
G1 X130.499 Y145.012 E.0702
G1 X129.977 Y145.012 E.0128
G1 X127.993 Y143.028 E.06881
G1 X127.548 Y143.104 E.01107
G1 X129.456 Y145.012 E.06618
G1 X128.935 Y145.013 E.01278
G1 X127.068 Y143.146 E.06476
G1 X126.573 Y143.172 E.01216
G1 X128.414 Y145.013 E.06385
G1 X127.892 Y145.013 E.0128
G1 X126.054 Y143.174 E.06377
G1 X125.534 Y143.176 E.01275
G1 X127.371 Y145.013 E.06372
G1 X126.85 Y145.013 E.01278
G1 X125.391 Y143.555 E.05059
G1 X125.391 Y144.076 E.01278
G1 X126.329 Y145.013 E.03252
G1 X125.807 Y145.014 E.0128
G1 X125.227 Y144.433 E.02013
;LAYER_CHANGE
;Z:1.1
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;1.1
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X125.807 Y145.014 E-.38995
G1 X126.329 Y145.013 E-.24795
G1 X125.391 Y144.076 E-.62977
G1 X125.391 Y143.587 E-.23233
;WIPE_END
G1 Z1.1 F9000
;AFTER_LAYER_CHANGE
;1.1
G1 Z1.1
G1 X125.942 Y139.441
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X125.992 Y139.371 E.00209
G1 X126 Y138.944 E.01039
G1 X126.855 Y138.106 E.02912
G1 X127.119 Y137.631 E.01322
G1 X127.093 Y137.287 E.00839
G1 X126.826 Y136.858 E.01229
G1 X126 Y136.059 E.02795
G1 X126 Y103.974 E.78044
G1 X126.304 Y103.974 E.00739
G1 X126.444 Y103.909 E.00375
G1 X126.487 Y103.792 E.00303
G1 X126.487 Y98.457 E.12977
G1 X126.462 Y98.365 E.00232
G1 X126.304 Y98.274 E.00444
G1 X126 Y98.274 E.00739
G1 X126 Y93.315 E.12062
G1 X126.037 Y93.25 E.00182
G1 X138.081 Y93.252 E.29296
G1 X139.048 Y93.274 E.02353
G1 X139.204 Y93.416 E.00513
G1 X139.243 Y93.588 E.00429
G1 X139.243 Y95.212 E.0395
G1 X139.206 Y95.373 E.00402
G1 X139.101 Y95.51 E.0042
G1 X138.932 Y95.576 E.00441
G1 X136.183 Y95.576 E.06687
G1 X136.074 Y95.612 E.00279
G1 X136 Y95.759 E.004
G1 X135.99 Y132.733 E.89936
G1 X135.946 Y133.327 E.01449
G1 X135.851 Y133.993 E.01636
G1 X135.703 Y134.694 E.01743
G1 X135.434 Y135.582 E.02257
G1 X135.186 Y136.207 E.01636
G1 X134.878 Y136.853 E.01741
G1 X134.408 Y137.654 E.02259
G1 X134.021 Y138.203 E.01634
G1 X133.57 Y138.759 E.01741
G1 X132.926 Y139.427 E.02257
G1 X132.421 Y139.87 E.01634
G1 X131.852 Y140.306 E.01744
G1 X131.07 Y140.804 E.02255
G1 X130.475 Y141.116 E.01634
G1 X129.82 Y141.407 E.01743
G1 X128.942 Y141.708 E.02258
G1 X128.291 Y141.872 E.01633
G1 X127.588 Y142.001 E.01739
G1 X126.193 Y142.1 E.03402
G1 X120.85 Y142.1 E.12996
G1 X120.85 Y141.796 E.00739
G1 X120.803 Y141.673 E.0032
G1 X120.667 Y141.613 E.00362
G1 X110.333 Y141.613 E.25136
G1 X110.198 Y141.673 E.00359
G1 X110.15 Y141.796 E.00321
G1 X110.15 Y142.1 E.00739
G1 X104.337 Y142.089 E.1414
G1 X103.161 Y141.96 E.02878
G1 X102.504 Y141.828 E.0163
G1 X101.614 Y141.568 E.02255
G1 X100.946 Y141.308 E.01744
G1 X100.339 Y141.026 E.01628
G1 X99.147 Y140.305 E.03389
G1 X98.226 Y139.566 E.02872
G1 X97.745 Y139.103 E.01624
G1 X96.852 Y138.034 E.03388
G1 X96.221 Y137.036 E.02872
G1 X95.918 Y136.441 E.01624
G1 X95.42 Y135.14 E.03388
G1 X95.148 Y133.992 E.0287
G1 X95.031 Y133.074 E.02251
G1 X94.999 Y132.296 E.01894
G1 X94.999 Y95.759 E.88873
G1 X94.926 Y95.612 E.00399
G1 X94.816 Y95.576 E.00282
G1 X92.038 Y95.57 E.06757
G1 X91.821 Y95.451 E.00602
G1 X91.75 Y95.205 E.00623
G1 X91.75 Y93.674 E.03724
G1 X91.799 Y93.418 E.00634
G1 X91.909 Y93.3 E.00392
G1 X92.077 Y93.252 E.00425
G1 X104.937 Y93.252 E.31281
G1 X105 Y93.29 E.00179
G1 X105 Y98.274 E.12123
G1 X104.696 Y98.274 E.00739
G1 X104.569 Y98.326 E.00334
G1 X104.513 Y98.457 E.00347
G1 X104.513 Y103.792 E.12977
G1 X104.53 Y103.869 E.00192
G1 X104.696 Y103.974 E.00478
G1 X105 Y103.974 E.00739
G1 X105 Y136.056 E.78036
G1 X104.145 Y136.894 E.02912
G1 X103.884 Y137.347 E.01272
G1 X103.907 Y137.713 E.00892
G1 X104.174 Y138.142 E.01229
G1 X105 Y138.941 E.02795
G1 X105.006 Y139.363 E.01027
G1 X105.094 Y139.477 E.0035
G1 X105.182 Y139.5 E.00221
G1 X125.817 Y139.5 E.50193
G1 X125.896 Y139.474 E.00202
G1 X125.896 Y139.474 F9000
G1 X126.199 Y139.698
;TYPE:Perimeter
G1 F6000
G1 X126.277 Y139.617 E.00274
G1 X126.342 Y139.478 E.00373
G1 X126.366 Y139.104 E.00912
G1 X126.807 Y138.695 E.01463
G1 X127.168 Y138.295 E.01311
G1 X127.462 Y137.777 E.01449
G1 X127.481 Y137.313 E.0113
G1 X127.406 Y137.098 E.00554
G1 X127.08 Y136.595 E.01458
G1 X126.366 Y135.904 E.02417
G1 X126.366 Y104.311 E.76847
G1 X126.724 Y104.144 E.00961
G1 X126.801 Y104.024 E.00347
G1 X126.852 Y103.792 E.00578
G1 X126.852 Y98.457 E.12977
G1 X126.829 Y98.3 E.00386
G1 X126.685 Y98.062 E.00677
G1 X126.366 Y97.934 E.00836
G1 X126.366 Y93.616 E.10503
G1 X138.877 Y93.618 E.30432
G1 X138.877 Y95.211 E.03875
G1 X136.183 Y95.21 E.06553
G1 X135.854 Y95.32 E.00844
G1 X135.677 Y95.548 E.00702
G1 X135.635 Y95.758 E.00521
G1 X135.625 Y132.719 E.89904
G1 X135.582 Y133.287 E.01386
G1 X135.491 Y133.93 E.0158
G1 X135.348 Y134.603 E.01674
G1 X135.088 Y135.462 E.02183
G1 X134.851 Y136.06 E.01565
G1 X134.554 Y136.682 E.01677
G1 X134.1 Y137.455 E.02181
G1 X133.729 Y137.982 E.01568
G1 X133.296 Y138.517 E.01674
G1 X132.673 Y139.162 E.02181
G1 X132.189 Y139.587 E.01567
G1 X131.642 Y140.006 E.01676
G1 X130.886 Y140.488 E.02181
G1 X130.315 Y140.787 E.01568
G1 X129.686 Y141.066 E.01674
G1 X128.838 Y141.358 E.02182
G1 X128.213 Y141.514 E.01567
G1 X127.542 Y141.638 E.0166
G1 X126.18 Y141.735 E.03321
G1 X121.192 Y141.735 E.12133
G1 X121.073 Y141.428 E.00801
G1 X120.667 Y141.248 E.0108
G1 X110.333 Y141.248 E.25136
G1 X110.238 Y141.256 E.00232
G1 X109.927 Y141.427 E.00863
G1 X109.809 Y141.734 E.008
G1 X104.358 Y141.723 E.13259
G1 X103.217 Y141.598 E.02792
G1 X102.592 Y141.472 E.01551
G1 X101.731 Y141.221 E.02181
G1 X101.089 Y140.972 E.01675
G1 X100.511 Y140.703 E.01551
G1 X99.357 Y140.005 E.03281
G1 X98.467 Y139.291 E.02775
G1 X98.013 Y138.853 E.01534
G1 X97.148 Y137.818 E.03281
G1 X96.539 Y136.854 E.02774
G1 X96.252 Y136.293 E.01533
G1 X95.77 Y135.032 E.03284
G1 X95.508 Y133.927 E.02762
G1 X95.396 Y133.043 E.02167
G1 X95.365 Y132.289 E.01836
G1 X95.365 Y95.759 E.88856
G1 X95.322 Y95.548 E.00524
G1 X95.145 Y95.32 E.00702
G1 X94.816 Y95.21 E.00844
G1 X92.124 Y95.211 E.06548
G1 X92.129 Y93.62 E.0387
G1 X104.634 Y93.618 E.30417
G1 X104.634 Y97.934 E.10498
G1 X104.315 Y98.062 E.00836
G1 X104.222 Y98.181 E.00367
G1 X104.148 Y98.457 E.00695
G1 X104.148 Y103.792 E.12977
G1 X104.154 Y103.872 E.00195
G1 X104.276 Y104.144 E.00725
G1 X104.634 Y104.311 E.00961
G1 X104.634 Y135.896 E.76827
G1 X103.903 Y136.612 E.02489
G1 X103.685 Y136.947 E.00972
G1 X103.525 Y137.276 E.0089
G1 X103.515 Y137.618 E.00832
G1 X103.594 Y137.903 E.00719
G1 X103.92 Y138.405 E.01456
G1 X104.634 Y139.096 E.02417
G1 X104.634 Y139.317 E.00538
G1 X104.693 Y139.565 E.0062
G1 X104.916 Y139.796 E.00781
G1 X105.182 Y139.866 E.00669
G1 X125.817 Y139.866 E.50193
G1 X125.912 Y139.857 E.00232
G1 X126.139 Y139.761 E.006
G1 X126.158 Y139.742 E.00065
G1 X126.158 Y139.742 F9000
G1 X126.453 Y139.953
G1 F6000
G1 X126.583 Y139.816 E.00459
G1 X126.691 Y139.585 E.0062
G1 X126.731 Y139.264 E.00787
G1 X127.072 Y138.947 E.01132
G1 X127.481 Y138.485 E.01501
G1 X127.755 Y138.026 E.013
G1 X127.849 Y137.681 E.0087
G1 X127.844 Y137.267 E.01007
G1 X127.719 Y136.908 E.00925
G1 X127.334 Y136.332 E.01685
G1 X126.731 Y135.749 E.0204
G1 X126.731 Y104.506 E.75995
G1 X127.005 Y104.378 E.00736
G1 X127.179 Y104.056 E.0089
G1 X127.218 Y103.792 E.00649
G1 X127.218 Y98.457 E.12977
G1 X127.214 Y98.376 E.00197
G1 X127.094 Y97.997 E.00967
G1 X126.938 Y97.799 E.00613
G1 X126.731 Y97.715 E.00543
G1 X126.731 Y93.982 E.0908
G1 X138.512 Y93.984 E.28656
G1 X138.512 Y94.845 E.02094
G1 X136.183 Y94.844 E.05665
G1 X136.025 Y94.858 E.00386
G1 X135.635 Y95.027 E.01034
G1 X135.34 Y95.407 E.0117
G1 X135.269 Y95.758 E.00871
G1 X135.259 Y132.705 E.8987
G1 X135.218 Y133.248 E.01325
G1 X135.131 Y133.866 E.01518
G1 X134.994 Y134.512 E.01606
G1 X134.743 Y135.341 E.02107
G1 X134.515 Y135.914 E.015
G1 X134.231 Y136.51 E.01606
G1 X133.793 Y137.257 E.02106
G1 X133.437 Y137.761 E.01501
G1 X133.022 Y138.274 E.01605
G1 X132.421 Y138.898 E.02107
G1 X131.957 Y139.304 E.015
G1 X131.432 Y139.706 E.01608
G1 X130.703 Y140.171 E.02103
G1 X130.156 Y140.457 E.01501
G1 X129.552 Y140.726 E.01608
G1 X128.734 Y141.007 E.02104
G1 X128.136 Y141.157 E.015
G1 X127.496 Y141.275 E.01583
G1 X126.167 Y141.369 E.03241
G1 X121.416 Y141.369 E.11556
G1 X121.344 Y141.182 E.00487
;WIDTH:0.447528
G1 X121.119 Y141.058 E.00706
;WIDTH:0.495057
G1 X120.893 Y140.935 E.00789
;WIDTH:0.542585
G1 X120.667 Y140.811 E.00872
G1 X110.333 Y140.811 E.34938
;WIDTH:0.551978
G1 X110.162 Y140.821 E.0059
G1 X110.035 Y140.911 E.00536
;WIDTH:0.513984
G1 X109.909 Y141.001 E.00494
;WIDTH:0.475989
G1 X109.783 Y141.091 E.00455
;WIDTH:0.437994
G1 X109.657 Y141.181 E.00416
;WIDTH:0.399999
G1 X109.585 Y141.367 E.00485
G1 X104.378 Y141.358 E.12666
G1 X103.273 Y141.236 E.02704
G1 X102.679 Y141.117 E.01474
G1 X101.849 Y140.875 E.02103
G1 X101.233 Y140.635 E.01608
G1 X100.683 Y140.38 E.01475
G1 X99.567 Y139.705 E.03172
G1 X98.709 Y139.016 E.02677
G1 X98.281 Y138.604 E.01445
G1 X97.444 Y137.602 E.03176
G1 X96.857 Y136.673 E.02673
G1 X96.587 Y136.144 E.01445
G1 X96.121 Y134.924 E.03177
G1 X95.868 Y133.861 E.02658
G1 X95.76 Y133.012 E.02082
G1 X95.73 Y132.281 E.0178
G1 X95.73 Y95.759 E.88836
G1 X95.66 Y95.407 E.00873
G1 X95.365 Y95.027 E.0117
G1 X94.816 Y94.844 E.01408
G1 X92.481 Y94.845 E.0568
G1 X92.481 Y93.984 E.02094
G1 X104.269 Y93.984 E.28673
G1 X104.269 Y97.715 E.09075
G1 X104.062 Y97.799 E.00543
G1 X103.906 Y97.997 E.00613
G1 X103.82 Y98.196 E.00527
G1 X103.782 Y98.457 E.00642
G1 X103.782 Y103.792 E.12977
G1 X103.821 Y104.056 E.00649
G1 X103.995 Y104.378 E.0089
G1 X104.269 Y104.506 E.00736
G1 X104.269 Y135.736 E.75964
G1 X103.928 Y136.053 E.01132
G1 X103.548 Y136.47 E.01372
G1 X103.281 Y136.908 E.01248
G1 X103.166 Y137.206 E.00777
G1 X103.149 Y137.618 E.01003
G1 X103.23 Y137.994 E.00936
G1 X103.346 Y138.199 E.00573
G1 X103.666 Y138.668 E.01381
G1 X104.269 Y139.251 E.0204
G1 X104.269 Y139.317 E.00161
G1 X104.367 Y139.73 E.01032
G1 X104.738 Y140.116 E.01302
G1 X105.181 Y140.231 E.01113
G1 X109.237 Y140.231 E.09866
;WIDTH:0.447528
G1 X109.602 Y140.255 E.01005
;WIDTH:0.495057
G1 X109.967 Y140.279 E.01121
;WIDTH:0.542585
G1 X110.333 Y140.303 E.0124
G1 X120.667 Y140.303 E.34938
G1 X121.033 Y140.279 E.0124
;WIDTH:0.495057
G1 X121.399 Y140.255 E.01124
;WIDTH:0.447528
G1 X121.766 Y140.231 E.01011
;WIDTH:0.399999
G1 X125.817 Y140.231 E.09854
G1 X125.975 Y140.218 E.00386
G1 X126.354 Y140.057 E.01002
G1 X126.412 Y139.996 E.00205
G1 E-5 F3600
G1 X126.412 Y139.996 F9000
G1 X126.348 Y139.848
G1 X104.651 Y139.849
G1 X103.642 Y137.99
G1 X103.589 Y137.876
G1 X103.549 Y137.756
G1 X103.524 Y137.63
G1 X103.515 Y137.5
G1 X103.903 Y124.292
G1 E5 F2400
G1 F6000
G1 X103.903 Y135.576 E.27447
G1 X103.662 Y135.802 E.00804
G1 X103.247 Y136.263 E.01509
G1 X102.969 Y136.719 E.01299
G1 X102.807 Y137.136 E.01088
G1 X102.784 Y137.618 E.01174
G1 X102.897 Y138.144 E.01309
G1 X103.206 Y138.674 E.01492
G1 X103.412 Y138.931 E.00801
G1 X103.916 Y139.419 E.01706
G1 X103.943 Y139.636 E.00532
G1 X104.041 Y139.895 E.00674
G1 X104.56 Y140.435 E.01822
;WIDTH:0.41549
G1 X105.183 Y140.605 E.01637
;WIDTH:0.41925
G1 X109.964 Y140.607 E.12242
G1 X109.379 Y140.929 E.0171
G1 X109.355 Y140.992 E.00173
G1 X105.182 Y140.986 E.10685
;WIDTH:0.41549
G1 X104.398 Y140.992 E.01988
;WIDTH:0.399999
G1 X103.329 Y140.874 E.02616
G1 X102.767 Y140.761 E.01394
G1 X101.967 Y140.528 E.02027
G1 X101.376 Y140.299 E.01542
G1 X100.855 Y140.056 E.01398
G1 X99.777 Y139.404 E.03064
G1 X98.951 Y138.742 E.02575
G1 X98.549 Y138.354 E.01359
G1 X97.741 Y137.386 E.03067
G1 X97.175 Y136.492 E.02574
G1 X96.921 Y135.995 E.01358
G1 X96.471 Y134.816 E.0307
G1 X96.228 Y133.796 E.0255
G1 X96.125 Y132.982 E.01996
G1 X96.096 Y132.274 E.01724
G1 X96.096 Y95.759 E.88819
G1 X95.998 Y95.266 E.01223
G1 X95.584 Y94.735 E.01638
;WIDTH:0.443184
G1 X95.328 Y94.628 E.00755
;WIDTH:0.486368
G1 X95.072 Y94.521 E.00834
;WIDTH:0.529552
G1 X94.816 Y94.414 E.00914
G1 X95.115 Y94.392 E.00988
;WIDTH:0.486368
G1 X95.414 Y94.371 E.00901
;WIDTH:0.443184
G1 X95.712 Y94.349 E.00813
;WIDTH:0.399999
G1 X103.903 Y94.349 E.19924
G1 X103.903 Y97.497 E.07657
G1 X103.808 Y97.536 E.0025
G1 X103.59 Y97.813 E.00857
G1 X103.47 Y98.091 E.00737
G1 X103.416 Y98.457 E.009
G1 X103.416 Y103.792 E.12977
G1 X103.471 Y104.162 E.0091
G1 X103.715 Y104.613 E.01247
G1 X103.903 Y104.701 E.00505
G1 X103.903 Y124.232 E.47507
G1 E-5 F3600
G1 X103.903 Y124.232 F9000
G1 X103.537 Y135.416
G1 E5 F2400
G1 F6000
G1 X103.106 Y135.858 E.01502
G1 X102.857 Y136.197 E.01023
G1 X102.564 Y136.703 E.01422
G1 X102.427 Y137.207 E.0127
G1 X102.422 Y137.728 E.01267
G1 X102.563 Y138.295 E.01421
G1 X102.894 Y138.863 E.01599
G1 X103.157 Y139.194 E.01028
G1 X103.573 Y139.595 E.01405
G1 X103.714 Y140.06 E.01182
G1 X104.24 Y140.607 E.01846
G1 X103.385 Y140.513 E.02092
G1 X102.854 Y140.406 E.01318
G1 X102.084 Y140.182 E.01951
G1 X101.52 Y139.962 E.01473
G1 X101.028 Y139.733 E.0132
G1 X99.987 Y139.104 E.02958
G1 X99.193 Y138.467 E.02476
G1 X98.817 Y138.105 E.0127
G1 X98.037 Y137.17 E.02962
G1 X97.493 Y136.311 E.02473
G1 X97.256 Y135.846 E.0127
G1 X96.821 Y134.708 E.02963
G1 X96.589 Y133.73 E.02445
G1 X96.49 Y132.951 E.0191
G1 X96.462 Y132.266 E.01668
G1 X96.462 Y95.759 E.888
G1 X96.335 Y95.126 E.0157
G1 X96.016 Y94.715 E.01266
G1 X103.537 Y94.715 E.18294
G1 X103.537 Y97.294 E.06273
G1 X103.274 Y97.629 E.01036
G1 X103.119 Y97.986 E.00947
G1 X103.051 Y98.457 E.01158
G1 X103.051 Y103.792 E.12977
G1 X103.069 Y104.034 E.0059
G1 X103.205 Y104.488 E.01153
G1 X103.434 Y104.848 E.01038
G1 X103.537 Y104.896 E.00276
G1 X103.537 Y135.356 E.74091
G1 E-5 F3600
G1 X103.537 Y135.356 F9000
G1 X95.348 Y95.226
G1 X92.912 Y94.414
G1 E5 F2400
;WIDTH:0.529834
G1 F6000
G1 X94.816 Y94.414 E.06276
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X92.912 Y94.414 E-.9044
;WIPE_END
G1 E-.5956 F3600
G1 X135.949 Y94.424 F9000
G1 E5 F2400
;WIDTH:0.550358
G1 F6000
G1 X136.183 Y94.414 E.00804
;WIDTH:0.529982
G1 X138.081 Y94.414 E.06258
G1 E-5 F3600
G1 X138.081 Y94.414 F9000
G1 X127.097 Y94.347
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X135.287 Y94.349 E.19921
;WIDTH:0.437589
G1 X135.453 Y94.367 E.00448
;WIDTH:0.475179
G1 X135.618 Y94.386 E.00487
;WIDTH:0.512769
G1 X135.784 Y94.405 E.00532
;WIDTH:0.550358
G1 X135.949 Y94.424 E.0057
G1 X135.816 Y94.502 E.00529
;WIDTH:0.512769
G1 X135.682 Y94.579 E.00492
;WIDTH:0.475179
G1 X135.549 Y94.657 E.00452
;WIDTH:0.437589
G1 X135.416 Y94.735 E.00414
;WIDTH:0.399999
G1 X135.002 Y95.266 E.01638
G1 X134.903 Y95.758 E.01221
G1 X134.893 Y132.691 E.89836
G1 X134.854 Y133.209 E.01264
G1 X134.77 Y133.802 E.01457
G1 X134.639 Y134.421 E.01539
G1 X134.397 Y135.221 E.02033
G1 X134.18 Y135.768 E.01431
G1 X133.908 Y136.339 E.01538
G1 X133.485 Y137.059 E.02031
G1 X133.146 Y137.54 E.01431
G1 X132.747 Y138.032 E.01541
G1 X132.168 Y138.633 E.0203
G1 X131.725 Y139.021 E.01432
G1 X131.222 Y139.406 E.01541
G1 X130.519 Y139.854 E.02028
G1 X129.997 Y140.128 E.01434
G1 X129.418 Y140.385 E.01541
G1 X128.63 Y140.656 E.02027
G1 X128.058 Y140.799 E.01434
G1 X127.45 Y140.911 E.01504
G1 X126.79 Y140.958 E.01609
;WIDTH:0.420285
G1 X125.817 Y140.993 E.025
G1 X121.647 Y140.993 E.10706
G1 X121.623 Y140.93 E.00173
G1 X120.895 Y140.607 E.02045
G1 X125.817 Y140.607 E.12636
;WIDTH:0.425895
G1 X126.101 Y140.578 E.00744
G1 X126.569 Y140.353 E.01353
;WIDTH:0.399999
G1 X126.889 Y140.016 E.0113
G1 X127.041 Y139.693 E.00868
G1 X127.082 Y139.438 E.00628
G1 X127.338 Y139.198 E.00854
G1 X127.794 Y138.674 E.0169
G1 X128.082 Y138.189 E.01372
G1 X128.213 Y137.706 E.01217
G1 X128.216 Y137.382 E.00788
G1 X128.163 Y137.017 E.00897
G1 X127.904 Y136.508 E.01389
G1 X127.588 Y136.069 E.01316
G1 X127.097 Y135.594 E.01662
G1 X127.097 Y104.701 E.75144
G1 X127.285 Y104.613 E.00505
G1 X127.529 Y104.162 E.01247
G1 X127.584 Y103.792 E.0091
G1 X127.584 Y98.457 E.12977
G1 X127.53 Y98.091 E.009
G1 X127.41 Y97.813 E.00737
G1 X127.192 Y97.536 E.00857
G1 X127.097 Y97.497 E.0025
G1 X127.097 Y94.407 E.07516
G1 X127.097 Y94.407 F9000
G1 X127.463 Y94.713
G1 F6000
G1 X134.984 Y94.714 E.18294
G1 X134.665 Y95.125 E.01266
G1 X134.538 Y95.758 E.0157
G1 X134.528 Y132.545 E.89481
G1 X134.491 Y133.169 E.0152
G1 X134.41 Y133.739 E.014
G1 X134.285 Y134.33 E.01469
G1 X134.051 Y135.1 E.01958
G1 X133.845 Y135.622 E.01365
G1 X133.584 Y136.167 E.0147
G1 X133.178 Y136.861 E.01956
G1 X132.854 Y137.32 E.01367
G1 X132.473 Y137.789 E.0147
G1 X131.916 Y138.368 E.01954
G1 X131.493 Y138.738 E.01367
G1 X131.013 Y139.106 E.01471
G1 X130.336 Y139.538 E.01953
G1 X129.838 Y139.799 E.01368
G1 X129.284 Y140.044 E.01473
G1 X128.526 Y140.305 E.0195
G1 X127.98 Y140.442 E.01369
G1 X127.403 Y140.548 E.01427
G1 X126.842 Y140.588 E.01368
G1 X127.196 Y140.216 E.01249
G1 X127.39 Y139.8 E.01117
G1 X127.426 Y139.618 E.00451
G1 X127.894 Y139.142 E.01624
G1 X128.344 Y138.471 E.01965
G1 X128.512 Y138.094 E.01004
G1 X128.578 Y137.73 E.009
G1 X128.569 Y137.176 E.01348
G1 X128.457 Y136.753 E.01064
G1 X128.216 Y136.318 E.0121
G1 X127.843 Y135.806 E.01541
G1 X127.463 Y135.439 E.01285
G1 X127.463 Y104.896 E.74293
G1 X127.566 Y104.848 E.00276
G1 X127.795 Y104.488 E.01038
G1 X127.879 Y104.268 E.00573
G1 X127.949 Y103.792 E.0117
G1 X127.949 Y98.457 E.12977
G1 X127.88 Y97.986 E.01158
G1 X127.726 Y97.629 E.00946
G1 X127.463 Y97.294 E.01036
G1 X127.463 Y94.773 E.06132
G1 X127.463 Y94.773 F9000
G1 X128.315 Y94.823
;WIDTH:0.4
G1 F3072.127
G1 X127.737 Y95.401 E.01988
G1 X127.737 Y95.92 E.01262
G1 X128.67 Y94.988 E.03208
G1 X129.189 Y94.988 E.01262
G1 X127.737 Y96.44 E.04995
G1 X127.737 Y96.96 E.01265
G1 X129.709 Y94.988 E.06784
G1 X130.228 Y94.988 E.01262
G1 X127.859 Y97.357 E.08149
G1 X128.048 Y97.687 E.00925
G1 X130.748 Y94.988 E.09286
G1 X131.267 Y94.988 E.01262
G1 X128.177 Y98.078 E.10629
G1 X128.224 Y98.551 E.01156
G1 X131.786 Y94.988 E.12255
G1 X132.306 Y94.988 E.01265
G1 X128.224 Y99.07 E.14042
G1 X128.224 Y99.59 E.01265
G1 X132.825 Y94.988 E.15829
G1 X133.345 Y94.988 E.01265
G1 X128.224 Y100.109 E.17616
G1 X128.224 Y100.629 E.01265
G1 X133.864 Y94.988 E.19403
G1 X134.384 Y94.988 E.01265
G1 X128.224 Y101.148 E.2119
G1 X128.224 Y101.668 E.01265
G1 X134.294 Y95.598 E.2088
G1 X134.263 Y96.148 E.0134
G1 X128.224 Y102.188 E.20776
G1 X128.224 Y102.707 E.01262
G1 X134.263 Y96.667 E.20776
G1 X134.263 Y97.187 E.01265
G1 X128.224 Y103.227 E.20776
G1 X128.224 Y103.746 E.01262
G1 X134.263 Y97.707 E.20774
G1 X134.263 Y98.226 E.01262
G1 X128.142 Y104.348 E.21058
G1 X128.043 Y104.606 E.00672
G1 X127.737 Y105.052 E.01316
G1 X127.737 Y105.272 E.00535
G1 X134.263 Y98.746 E.22449
G1 X134.263 Y99.266 E.01265
G1 X127.737 Y105.791 E.22447
G1 X127.737 Y106.311 E.01265
G1 X134.262 Y99.785 E.22447
G1 X134.262 Y100.305 E.01265
G1 X127.737 Y106.83 E.22446
G1 X127.737 Y107.35 E.01265
G1 X134.262 Y100.825 E.22446
G1 X134.262 Y101.344 E.01262
G1 X127.737 Y107.869 E.22446
G1 X127.737 Y108.389 E.01265
G1 X134.262 Y101.864 E.22446
G1 X134.262 Y102.384 E.01265
G1 X127.737 Y108.908 E.22444
G1 X127.737 Y109.428 E.01265
G1 X134.262 Y102.903 E.22446
G1 X134.261 Y103.423 E.01265
G1 X127.737 Y109.947 E.22442
G1 X127.737 Y110.467 E.01265
G1 X134.261 Y103.943 E.22442
G1 X134.261 Y104.462 E.01262
G1 X127.737 Y110.986 E.22442
G1 X127.737 Y111.506 E.01265
G1 X134.261 Y104.982 E.22442
G1 X134.261 Y105.502 E.01265
G1 X127.737 Y112.026 E.22442
G1 X127.737 Y112.545 E.01262
G1 X134.261 Y106.021 E.22442
G1 X134.261 Y106.541 E.01265
G1 X127.737 Y113.065 E.22442
G1 X127.737 Y113.584 E.01262
G1 X134.26 Y107.06 E.2244
G1 X134.26 Y107.58 E.01265
G1 X127.737 Y114.104 E.2244
G1 X127.737 Y114.623 E.01262
G1 X134.26 Y108.1 E.22439
G1 X134.26 Y108.619 E.01262
G1 X127.737 Y115.143 E.2244
G1 X127.737 Y115.662 E.01262
G1 X134.26 Y109.139 E.22439
G1 X134.26 Y109.659 E.01265
G1 X127.737 Y116.182 E.22439
G1 X127.737 Y116.701 E.01262
G1 X134.26 Y110.178 E.22439
G1 X134.259 Y110.698 E.01265
G1 X127.737 Y117.221 E.22437
G1 X127.737 Y117.74 E.01262
G1 X134.259 Y111.218 E.22435
G1 X134.259 Y111.737 E.01262
G1 X127.737 Y118.26 E.22437
G1 X127.737 Y118.779 E.01262
G1 X134.259 Y112.257 E.22435
G1 X134.259 Y112.777 E.01265
G1 X127.737 Y119.299 E.22435
G1 X127.737 Y119.818 E.01262
G1 X134.259 Y113.296 E.22435
G1 X134.259 Y113.816 E.01265
G1 X127.737 Y120.338 E.22435
G1 X127.737 Y120.857 E.01262
G1 X134.258 Y114.336 E.22432
G1 X134.258 Y114.855 E.01262
G1 X127.737 Y121.377 E.22434
G1 X127.737 Y121.896 E.01262
G1 X134.258 Y115.375 E.22432
G1 X134.258 Y115.895 E.01265
G1 X127.737 Y122.416 E.22432
G1 X127.737 Y122.935 E.01262
G1 X134.258 Y116.414 E.22432
G1 X134.258 Y116.934 E.01265
G1 X127.737 Y123.455 E.22432
G1 X127.737 Y123.974 E.01262
G1 X134.258 Y117.454 E.2243
G1 X134.257 Y117.973 E.01262
G1 X127.737 Y124.494 E.2243
G1 X127.737 Y125.013 E.01262
G1 X134.257 Y118.493 E.22428
G1 X134.257 Y119.013 E.01265
G1 X127.737 Y125.533 E.22428
G1 X127.737 Y126.052 E.01262
G1 X134.257 Y119.532 E.22428
G1 X134.257 Y120.052 E.01265
G1 X127.737 Y126.572 E.22428
G1 X127.737 Y127.092 E.01265
G1 X134.257 Y120.572 E.22428
G1 X134.257 Y121.091 E.01262
G1 X127.737 Y127.611 E.22428
G1 X127.737 Y128.131 E.01265
G1 X134.256 Y121.611 E.22427
G1 X134.256 Y122.131 E.01265
G1 X127.737 Y128.65 E.22425
G1 X127.737 Y129.17 E.01265
G1 X134.256 Y122.65 E.22427
G1 X134.256 Y123.17 E.01265
G1 X127.737 Y129.689 E.22425
G1 X127.737 Y130.209 E.01265
G1 X134.256 Y123.69 E.22425
G1 X134.256 Y124.209 E.01262
G1 X127.737 Y130.728 E.22425
G1 X127.737 Y131.248 E.01265
G1 X134.256 Y124.729 E.22425
G1 X134.255 Y125.249 E.01265
G1 X127.737 Y131.767 E.22422
G1 X127.737 Y132.287 E.01265
G1 X134.255 Y125.768 E.22423
G1 X134.255 Y126.288 E.01265
G1 X127.737 Y132.806 E.22422
G1 X127.737 Y133.326 E.01265
G1 X134.255 Y126.808 E.22422
G1 X134.255 Y127.327 E.01262
G1 X127.737 Y133.845 E.22422
G1 X127.737 Y134.365 E.01265
G1 X134.255 Y127.847 E.22422
G1 X134.255 Y128.367 E.01265
G1 X127.737 Y134.884 E.2242
G1 X127.737 Y135.322 E.01065
G1 X127.778 Y135.362 E.00139
G1 X134.254 Y128.886 E.22277
G1 X134.254 Y129.406 E.01265
G1 X128.042 Y135.618 E.21369
G1 X128.28 Y135.9 E.00898
G1 X134.254 Y129.926 E.2055
G1 X134.254 Y130.445 E.01262
G1 X128.475 Y136.224 E.19879
G1 X128.664 Y136.554 E.00925
G1 X134.254 Y130.965 E.19228
G1 X134.254 Y131.484 E.01262
G1 X128.799 Y136.939 E.18765
G1 X128.85 Y137.408 E.01148
G1 X134.254 Y132.004 E.18589
G1 X134.253 Y132.524 E.01265
G1 X128.813 Y137.964 E.18713
G1 X128.655 Y138.474 E.01299
G1 X128.413 Y138.884 E.01158
G1 X134.223 Y133.074 E.19986
G1 X134.142 Y133.674 E.01473
G1 X127.586 Y140.23 E.22552
G1 X128.242 Y140.093 E.0163
G1 X133.995 Y134.341 E.19788
G1 X133.757 Y135.098 E.0193
G1 X129.005 Y139.85 E.16347
G1 X129.939 Y139.436 E.02485
G1 X133.347 Y136.028 E.11723
G1 X132.947 Y136.712 E.01927
G1 X132.267 Y137.608 E.02736
G1 X130.752 Y139.142 E.05244
G1 E-5 F3600
G1 X130.752 Y139.142 F9000
G1 X126.349 Y139.849
G1 X103.332 Y140.39
G1 E5 F2400
G1 F3072.127
G1 X103.501 Y140.222 E.0058
G1 X103.346 Y139.857 E.00965
G1 X103.04 Y140.164 E.01054
G1 X102.629 Y140.055 E.01034
G1 X103.132 Y139.551 E.01732
G1 X102.876 Y139.288 E.00893
G1 X102.227 Y139.937 E.02233
G1 X101.849 Y139.796 E.00981
G1 X102.655 Y138.99 E.02773
G1 X102.456 Y138.669 E.00919
G1 X101.483 Y139.643 E.03349
G1 X101.131 Y139.475 E.00949
G1 X102.289 Y138.317 E.03983
G1 X102.185 Y137.901 E.01043
G1 X100.807 Y139.279 E.0474
G1 X100.483 Y139.084 E.0092
G1 X102.148 Y137.419 E.05728
G1 X102.246 Y136.801 E.01522
G1 X100.16 Y138.888 E.07177
G1 X99.87 Y138.658 E.009
G1 X103.263 Y135.265 E.11672
G1 X103.263 Y134.746 E.01262
G1 X99.582 Y138.427 E.12662
G1 X99.3 Y138.189 E.00898
G1 X103.263 Y134.226 E.13632
G1 X103.263 Y133.707 E.01262
G1 X99.036 Y137.934 E.14541
G1 X98.797 Y137.653 E.00897
G1 X103.263 Y133.187 E.15363
G1 X103.263 Y132.668 E.01262
G1 X98.561 Y137.37 E.16175
G1 X98.324 Y137.087 E.00898
G1 X103.263 Y132.149 E.16988
G1 X103.263 Y131.629 E.01265
G1 X98.113 Y136.779 E.17716
G1 X97.912 Y136.461 E.00915
G1 X103.263 Y131.11 E.18407
G1 X103.263 Y130.59 E.01265
G1 X97.714 Y136.14 E.1909
G1 X97.538 Y135.796 E.0094
G1 X103.263 Y130.071 E.19694
G1 X103.263 Y129.551 E.01265
G1 X97.389 Y135.426 E.20208
G1 X97.245 Y135.05 E.00979
G1 X103.263 Y129.032 E.20702
G1 X103.263 Y128.513 E.01262
G1 X97.102 Y134.674 E.21193
G1 X96.996 Y134.26 E.01039
G1 X103.263 Y127.993 E.21558
G1 X103.263 Y127.474 E.01262
G1 X96.897 Y133.84 E.21899
G1 X96.823 Y133.395 E.01097
G1 X103.263 Y126.954 E.22155
G1 X103.263 Y126.435 E.01262
G1 X96.764 Y132.934 E.22356
G1 X96.743 Y132.435 E.01215
G1 X103.263 Y125.915 E.22428
G1 X103.263 Y125.396 E.01262
G1 X96.736 Y131.923 E.22452
G1 X96.736 Y131.404 E.01262
G1 X103.263 Y124.877 E.22452
G1 X103.263 Y124.357 E.01265
G1 X96.736 Y130.884 E.22452
G1 X96.736 Y130.365 E.01262
G1 X103.263 Y123.838 E.22452
G1 X103.263 Y123.318 E.01265
G1 X96.736 Y129.845 E.22452
G1 X96.736 Y129.326 E.01262
G1 X103.263 Y122.799 E.22452
G1 X103.263 Y122.279 E.01265
G1 X96.736 Y128.807 E.22454
G1 X96.736 Y128.287 E.01265
G1 X103.263 Y121.76 E.22452
G1 X103.263 Y121.241 E.01262
G1 X96.736 Y127.768 E.22452
G1 X96.736 Y127.248 E.01265
G1 X103.263 Y120.721 E.22452
G1 X103.263 Y120.202 E.01262
G1 X96.736 Y126.729 E.22452
G1 X96.736 Y126.209 E.01265
G1 X103.263 Y119.682 E.22452
G1 X103.263 Y119.163 E.01262
G1 X96.736 Y125.69 E.22452
G1 X96.736 Y125.171 E.01262
G1 X103.263 Y118.643 E.22454
G1 X103.263 Y118.124 E.01262
G1 X96.736 Y124.651 E.22452
G1 X96.736 Y124.132 E.01262
G1 X103.263 Y117.605 E.22452
G1 X103.263 Y117.085 E.01265
G1 X96.736 Y123.612 E.22452
G1 X96.736 Y123.093 E.01262
G1 X103.263 Y116.566 E.22452
G1 X103.263 Y116.046 E.01265
G1 X96.736 Y122.573 E.22452
G1 X96.736 Y122.054 E.01262
G1 X103.263 Y115.527 E.22452
G1 X103.263 Y115.007 E.01265
G1 X96.736 Y121.535 E.22454
G1 X96.736 Y121.015 E.01265
G1 X103.263 Y114.488 E.22452
G1 X103.263 Y113.969 E.01262
G1 X96.736 Y120.496 E.22452
G1 X96.736 Y119.976 E.01265
G1 X103.263 Y113.449 E.22452
G1 X103.263 Y112.93 E.01262
G1 X96.736 Y119.457 E.22452
G1 X96.736 Y118.937 E.01265
G1 X103.263 Y112.41 E.22452
G1 X103.263 Y111.891 E.01262
G1 X96.736 Y118.418 E.22452
G1 X96.736 Y117.899 E.01262
G1 X103.263 Y111.371 E.22454
G1 X103.263 Y110.852 E.01262
G1 X96.736 Y117.379 E.22452
G1 X96.736 Y116.86 E.01262
G1 X103.263 Y110.333 E.22452
G1 X103.263 Y109.813 E.01265
G1 X96.736 Y116.34 E.22452
G1 X96.736 Y115.821 E.01262
G1 X103.263 Y109.294 E.22452
G1 X103.263 Y108.774 E.01265
G1 X96.736 Y115.301 E.22452
G1 X96.736 Y114.782 E.01262
G1 X103.263 Y108.255 E.22452
G1 X103.263 Y107.735 E.01265
G1 X96.736 Y114.263 E.22454
G1 X96.736 Y113.743 E.01265
G1 X103.263 Y107.216 E.22452
G1 X103.263 Y106.697 E.01262
G1 X96.736 Y113.224 E.22452
G1 X96.736 Y112.704 E.01265
G1 X103.263 Y106.177 E.22452
G1 X103.263 Y105.658 E.01262
G1 X96.736 Y112.185 E.22452
G1 X96.736 Y111.665 E.01265
G1 X103.263 Y105.138 E.22452
G1 X103.263 Y105.051 E.00212
G1 X103.081 Y104.801 E.00752
G1 X96.736 Y111.146 E.21826
G1 X96.736 Y110.627 E.01262
G1 X102.902 Y104.461 E.21211
G1 X102.798 Y104.045 E.01043
G1 X96.736 Y110.107 E.20853
G1 X96.736 Y109.588 E.01262
G1 X102.777 Y103.547 E.20781
G1 X102.777 Y103.027 E.01265
G1 X96.736 Y109.068 E.20781
G1 X96.736 Y108.549 E.01262
G1 X102.778 Y102.507 E.20784
G1 X102.779 Y101.987 E.01265
G1 X96.736 Y108.03 E.20788
G1 X96.736 Y107.51 E.01265
G1 X102.779 Y101.467 E.20788
G1 X102.78 Y100.946 E.01267
G1 X96.736 Y106.991 E.20793
G1 X96.736 Y106.471 E.01265
G1 X102.781 Y100.426 E.20794
G1 X102.781 Y99.906 E.01265
G1 X96.736 Y105.952 E.20796
G1 X96.736 Y105.432 E.01265
G1 X102.782 Y99.386 E.20798
G1 X102.783 Y98.866 E.01265
G1 X96.736 Y104.913 E.20801
G1 X96.736 Y104.394 E.01262
G1 X102.784 Y98.346 E.20805
G1 X102.856 Y97.907 E.01082
G1 X102.974 Y97.636 E.00719
G1 X96.736 Y103.874 E.21458
G1 X96.736 Y103.355 E.01262
G1 X103.263 Y96.827 E.22454
G1 X103.263 Y96.308 E.01262
G1 X96.736 Y102.835 E.22452
G1 X96.736 Y102.316 E.01262
G1 X103.263 Y95.789 E.22452
G1 X103.263 Y95.269 E.01265
G1 X96.736 Y101.796 E.22452
G1 X96.736 Y101.277 E.01262
G1 X103.024 Y94.989 E.2163
G1 X102.504 Y94.989 E.01265
G1 X96.736 Y100.758 E.19843
G1 X96.736 Y100.238 E.01265
G1 X101.985 Y94.989 E.18056
G1 X101.465 Y94.989 E.01265
G1 X96.736 Y99.719 E.16269
G1 X96.736 Y99.199 E.01265
G1 X100.946 Y94.989 E.14482
G1 X100.427 Y94.989 E.01262
G1 X96.736 Y98.68 E.12697
G1 X96.736 Y98.16 E.01265
G1 X99.907 Y94.989 E.10908
G1 X99.388 Y94.989 E.01262
G1 X96.736 Y97.641 E.09123
G1 X96.736 Y97.122 E.01262
G1 X98.868 Y94.989 E.07336
G1 X98.349 Y94.989 E.01262
G1 X96.736 Y96.602 E.05549
G1 X96.736 Y96.083 E.01262
G1 X97.829 Y94.989 E.03762
G1 X97.31 Y94.989 E.01262
G1 X96.705 Y95.594 E.02081
G1 X96.618 Y95.161 E.01074
G1 X96.955 Y94.825 E.01158
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X96.618 Y95.161 E-.22604
G1 X96.705 Y95.594 E-.20979
G1 X97.31 Y94.989 E-.40641
G1 X97.829 Y94.989 E-.24653
G1 X97.217 Y95.601 E-.41123
;WIPE_END
G1 X104.166 Y102.085 F9000
G1 X106.099 Y103.888
G1 X111.707 Y109.109
G1 X111.969 Y109.366
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X112.072 Y109.235 E.00405
G1 X112.554 Y108.874 E.01465
G1 X113.105 Y108.643 E.01453
G1 X113.704 Y108.553 E.01473
G1 X117.371 Y108.555 E.0892
G1 X117.948 Y108.659 E.01426
G1 X118.494 Y108.902 E.01454
G1 X118.996 Y109.303 E.01563
G1 X119.354 Y109.774 E.01439
G1 X121.087 Y112.775 E.08429
G1 X121.255 Y113.135 E.00966
G1 X121.366 Y113.526 E.00989
G1 X121.411 Y114.078 E.01347
G1 X121.357 Y114.517 E.01076
G1 X121.164 Y115.075 E.01436
G1 X119.246 Y118.394 E.09324
G1 X118.874 Y118.808 E.01354
G1 X118.667 Y118.984 E.00661
G1 X118.319 Y119.193 E.00987
G1 X117.799 Y119.382 E.01346
G1 X117.254 Y119.45 E.01336
G1 X113.767 Y119.451 E.08482
G1 X113.149 Y119.368 E.01517
G1 X112.593 Y119.148 E.01454
G1 X112.108 Y118.799 E.01453
G1 X111.703 Y118.317 E.01531
G1 X109.913 Y115.225 E.0869
G1 X109.667 Y114.617 E.01595
G1 X109.594 Y114.185 E.01066
G1 X109.598 Y113.779 E.00988
G1 X109.71 Y113.236 E.01349
G1 X109.913 Y112.775 E.01225
G1 X111.646 Y109.774 E.08429
G1 X111.932 Y109.413 E.0112
G1 X111.932 Y109.413 F9000
G1 X111.651 Y109.18
;TYPE:Perimeter
G1 F6000
G1 X111.786 Y109.008 E.00532
G1 X112.208 Y108.674 E.01309
G1 X112.455 Y108.514 E.00716
G1 X112.967 Y108.305 E.01345
G1 X113.653 Y108.191 E.01692
G1 X117.372 Y108.189 E.09046
G1 X118.014 Y108.299 E.01584
G1 X118.646 Y108.57 E.01673
G1 X119.193 Y108.985 E.0167
G1 X119.287 Y109.081 E.00327
G1 X119.671 Y109.591 E.01553
G1 X121.404 Y112.592 E.08429
G1 X121.606 Y113.032 E.01178
G1 X121.73 Y113.496 E.01168
G1 X121.775 Y114.048 E.01347
G1 X121.724 Y114.554 E.01237
G1 X121.481 Y115.258 E.01812
G1 X119.562 Y118.577 E.09325
G1 X119.243 Y118.97 E.01231
G1 X118.859 Y119.296 E.01225
G1 X118.444 Y119.537 E.01167
G1 X117.923 Y119.725 E.01347
G1 X117.296 Y119.813 E.0154
G1 X113.767 Y119.816 E.08584
G1 X113.1 Y119.731 E.01636
G1 X112.455 Y119.486 E.01678
G1 X111.891 Y119.094 E.01671
G1 X111.387 Y118.5 E.01895
G1 X109.597 Y115.408 E.0869
G1 X109.328 Y114.754 E.0172
G1 X109.228 Y114.185 E.01405
G1 X109.24 Y113.705 E.01168
G1 X109.352 Y113.162 E.01349
G1 X109.571 Y112.642 E.01372
G1 X111.329 Y109.591 E.08565
G1 X111.614 Y109.227 E.01124
G1 X111.614 Y109.227 F9000
G1 X111.334 Y108.994
G1 F6000
G1 X111.5 Y108.78 E.00659
G1 X111.992 Y108.379 E.01544
G1 X112.316 Y108.175 E.00931
G1 X112.829 Y107.966 E.01347
G1 X113.601 Y107.829 E.01907
G1 X117.372 Y107.824 E.09173
G1 X118.081 Y107.94 E.01748
G1 X118.798 Y108.237 E.01888
G1 X119.421 Y108.699 E.01887
G1 X119.578 Y108.859 E.00545
G1 X119.988 Y109.409 E.01669
G1 X121.72 Y112.41 E.08428
G1 X121.957 Y112.929 E.01388
G1 X122.095 Y113.466 E.01349
G1 X122.14 Y114.018 E.01347
G1 X122.091 Y114.57 E.01348
G1 X121.872 Y115.276 E.01798
G1 X121.798 Y115.441 E.0044
G1 X119.879 Y118.76 E.09325
G1 X119.554 Y119.171 E.01275
G1 X119.17 Y119.519 E.01261
G1 X118.736 Y119.8 E.01258
G1 X118.048 Y120.069 E.01797
G1 X117.338 Y120.176 E.01747
G1 X113.767 Y120.182 E.08686
G1 X113.051 Y120.093 E.01755
G1 X112.317 Y119.825 E.01901
G1 X111.675 Y119.389 E.01888
G1 X111.158 Y118.81 E.01888
G1 X111.07 Y118.683 E.00376
G1 X109.28 Y115.592 E.08688
G1 X108.989 Y114.89 E.01848
G1 X108.875 Y114.333 E.01383
G1 X108.863 Y113.816 E.01258
G1 X108.994 Y113.088 E.01799
G1 X109.237 Y112.493 E.01563
G1 X111.012 Y109.408 E.08657
G1 X111.297 Y109.041 E.0113
G1 X111.297 Y109.041 F9000
G1 X111.017 Y108.808
G1 F6000
G1 X111.214 Y108.552 E.00786
G1 X111.459 Y108.317 E.00826
G1 X111.905 Y107.989 E.01347
G1 X112.422 Y107.737 E.01399
G1 X112.995 Y107.545 E.0147
G1 X113.55 Y107.467 E.01363
G1 X117.373 Y107.458 E.09299
G1 X118.148 Y107.58 E.01908
G1 X118.446 Y107.675 E.00761
G1 X118.95 Y107.904 E.01347
G1 X119.216 Y108.068 E.0076
G1 X119.649 Y108.414 E.01348
G1 X119.868 Y108.637 E.0076
G1 X120.304 Y109.226 E.01782
G1 X122.037 Y112.227 E.08429
G1 X122.308 Y112.826 E.01599
G1 X122.459 Y113.436 E.01529
G1 X122.504 Y113.988 E.01347
G1 X122.454 Y114.615 E.0153
G1 X122.218 Y115.394 E.0198
G1 X122.114 Y115.624 E.00614
G1 X120.195 Y118.943 E.09325
G1 X119.835 Y119.404 E.01423
G1 X119.41 Y119.795 E.01405
G1 X118.927 Y120.112 E.01405
G1 X118.172 Y120.413 E.01977
G1 X117.638 Y120.509 E.0132
G1 X117.233 Y120.548 E.0099
G1 X113.766 Y120.548 E.08433
G1 X113.001 Y120.455 E.01874
G1 X112.69 Y120.372 E.00783
G1 X112.177 Y120.163 E.01347
G1 X111.905 Y120.01 E.00759
G1 X111.458 Y119.683 E.01347
G1 X111.197 Y119.428 E.00888
G1 X110.877 Y119.043 E.01218
G1 X110.754 Y118.866 E.00524
G1 X108.964 Y115.775 E.08688
G1 X108.649 Y115.026 E.01976
G1 X108.514 Y114.393 E.01574
G1 X108.497 Y113.816 E.01404
G1 X108.636 Y113.014 E.0198
G1 X108.904 Y112.343 E.01758
G1 X110.696 Y109.226 E.08745
G1 X110.98 Y108.856 E.01135
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X111.017 Y108.808 E-.02879
G1 X111.214 Y108.552 E-.15344
G1 X111.459 Y108.317 E-.16126
G1 X111.905 Y107.989 E-.26297
G1 X112.422 Y107.737 E-.27319
G1 X112.995 Y107.545 E-.28705
G1 X113.55 Y107.467 E-.26622
G1 X113.691 Y107.467 E-.06708
;WIPE_END
G1 X112.586 Y105.535 F9000
G1 X112.744 Y105.222
G1 E5 F2400
G1 F6000
G1 X112.731 Y105.218 E.00033
G1 X112.259 Y104.928 E.01347
G1 X111.938 Y104.627 E.0107
G1 X111.646 Y104.226 E.01207
G1 X109.913 Y101.225 E.08429
G1 X109.667 Y100.617 E.01595
G1 X109.594 Y100.185 E.01066
G1 X109.612 Y99.691 E.01202
G1 X109.667 Y99.383 E.00761
G1 X109.902 Y98.798 E.01533
G1 X111.646 Y95.774 E.08491
G1 X111.953 Y95.355 E.01263
G1 X112.253 Y95.076 E.00997
G1 X112.592 Y94.853 E.00987
G1 X113.105 Y94.643 E.01348
G1 X113.537 Y94.562 E.01069
G1 X117.233 Y94.549 E.0899
G1 X117.602 Y94.58 E.00901
G1 X118.137 Y94.725 E.01348
G1 X118.518 Y94.918 E.01039
G1 X118.964 Y95.27 E.01382
G1 X119.355 Y95.775 E.01554
G1 X121.165 Y98.926 E.08839
G1 X121.351 Y99.486 E.01435
G1 X121.411 Y100.085 E.01464
G1 X121.319 Y100.668 E.01436
G1 X121.097 Y101.205 E.01413
G1 X119.354 Y104.226 E.08484
G1 X118.997 Y104.697 E.01438
G1 X118.532 Y105.074 E.01456
G1 X117.991 Y105.327 E.01453
G1 X117.37 Y105.445 E.01538
G1 X113.767 Y105.451 E.08764
G1 X113.149 Y105.368 E.01517
G1 X112.801 Y105.243 E.00899
G1 X112.801 Y105.243 F9000
G1 X112.663 Y105.58
;TYPE:Perimeter
G1 F6000
G1 X112.578 Y105.551 E.00218
G1 X112.068 Y105.239 E.01454
G1 X111.692 Y104.901 E.0123
G1 X111.362 Y104.459 E.01342
G1 X109.596 Y101.408 E.08575
G1 X109.328 Y100.754 E.01719
G1 X109.229 Y100.203 E.01362
G1 X109.251 Y99.631 E.01392
G1 X109.328 Y99.246 E.00955
G1 X109.562 Y98.662 E.0153
G1 X111.329 Y95.591 E.08618
G1 X111.643 Y95.157 E.01303
G1 X112.049 Y94.773 E.01359
G1 X112.454 Y94.514 E.01169
G1 X112.967 Y94.305 E.01347
G1 X113.535 Y94.197 E.01406
G1 X117.233 Y94.184 E.08995
G1 X117.698 Y94.227 E.01136
G1 X118.232 Y94.372 E.01346
G1 X118.745 Y94.631 E.01398
G1 X119.191 Y94.983 E.01382
G1 X119.632 Y95.533 E.01715
G1 X121.482 Y98.743 E.09012
G1 X121.676 Y99.25 E.0132
G1 X121.762 Y99.701 E.01117
G1 X121.77 Y100.181 E.01168
G1 X121.679 Y100.733 E.01361
G1 X121.433 Y101.348 E.01611
G1 X119.671 Y104.409 E.08591
G1 X119.287 Y104.919 E.01553
G1 X118.76 Y105.36 E.01671
G1 X118.143 Y105.66 E.01669
G1 X117.371 Y105.811 E.01913
G1 X113.767 Y105.816 E.08766
G1 X113.1 Y105.731 E.01636
G1 X112.72 Y105.6 E.00978
G1 X112.72 Y105.6 F9000
G1 X112.58 Y105.942
G1 F6000
G1 X112.516 Y105.922 E.00163
G1 X112.013 Y105.635 E.01409
G1 X111.728 Y105.438 E.00843
G1 X111.348 Y105.059 E.01305
G1 X111.013 Y104.592 E.01398
G1 X109.28 Y101.591 E.08429
G1 X108.989 Y100.89 E.01846
G1 X108.875 Y100.333 E.01383
G1 X108.863 Y99.815 E.0126
G1 X108.935 Y99.302 E.0126
G1 X109.223 Y98.526 E.02013
G1 X111.013 Y95.408 E.08745
G1 X111.348 Y94.941 E.01398
G1 X111.728 Y94.562 E.01305
G1 X112.151 Y94.263 E.0126
G1 X112.828 Y93.966 E.01798
G1 X113.37 Y93.846 E.0135
G1 X113.534 Y93.831 E.00401
G1 X117.233 Y93.818 E.08998
G1 X117.794 Y93.874 E.01371
G1 X118.328 Y94.019 E.01346
G1 X118.816 Y94.245 E.01308
G1 X119.418 Y94.696 E.0183
G1 X119.923 Y95.311 E.01936
G1 X121.799 Y98.561 E.09128
G1 X121.992 Y99.033 E.0124
G1 X122.109 Y99.538 E.01261
G1 X122.142 Y100.055 E.0126
G1 X122.041 Y100.787 E.01797
G1 X121.77 Y101.491 E.01835
G1 X119.988 Y104.591 E.08697
G1 X119.578 Y105.141 E.01669
G1 X118.988 Y105.646 E.01889
G1 X118.294 Y105.993 E.01887
G1 X117.538 Y106.161 E.01884
G1 X117.371 Y106.176 E.00408
G1 X113.767 Y106.182 E.08766
G1 X113.051 Y106.093 E.01755
G1 X112.637 Y105.96 E.01058
G1 X112.637 Y105.96 F9000
G1 X112.5 Y106.299
G1 F6000
G1 X112.392 Y106.265 E.00275
G1 X111.822 Y105.947 E.01588
G1 X111.478 Y105.704 E.01024
G1 X111.053 Y105.275 E.01469
G1 X110.696 Y104.775 E.01494
G1 X108.963 Y101.773 E.08431
G1 X108.649 Y101.026 E.01971
G1 X108.514 Y100.393 E.01574
G1 X108.497 Y99.815 E.01407
G1 X108.574 Y99.243 E.01404
G1 X108.884 Y98.39 E.02208
G1 X110.696 Y95.225 E.08871
G1 X111.053 Y94.725 E.01494
G1 X111.478 Y94.296 E.01469
G1 X111.947 Y93.96 E.01403
G1 X112.69 Y93.628 E.01979
G1 X113.304 Y93.487 E.01532
G1 X113.533 Y93.465 E.0056
G1 X117.233 Y93.452 E.09
G1 X117.89 Y93.521 E.01607
G1 X118.424 Y93.666 E.01346
G1 X118.981 Y93.918 E.01487
G1 X119.644 Y94.41 E.02008
G1 X119.868 Y94.637 E.00776
G1 X120.213 Y95.089 E.01383
G1 X122.116 Y98.379 E.09245
G1 X122.333 Y98.902 E.01377
G1 X122.467 Y99.464 E.01405
G1 X122.507 Y100.04 E.01404
G1 X122.402 Y100.846 E.01977
G1 X122.211 Y101.388 E.01398
G1 X121.868 Y102.066 E.01848
G1 X120.304 Y104.774 E.07607
G1 X119.868 Y105.363 E.01782
G1 X119.649 Y105.587 E.00762
G1 X119.216 Y105.932 E.01347
G1 X118.95 Y106.096 E.0076
G1 X118.446 Y106.326 E.01348
G1 X118.148 Y106.42 E.0076
G1 X117.604 Y106.521 E.01346
G1 X117.372 Y106.542 E.00567
G1 X113.766 Y106.548 E.08771
G1 X113.001 Y106.455 E.01874
G1 X112.557 Y106.317 E.01131
G1 E-5 F3600
G1 X112.557 Y106.317 F9000
G1 X108.292 Y101.081
G1 E5 F2400
G1 F6000
G1 X108.153 Y100.452 E.01567
G1 X108.131 Y99.815 E.0155
G1 X108.213 Y99.183 E.0155
G1 X108.31 Y98.838 E.00872
G1 X108.646 Y98.044 E.02097
G1 X110.379 Y95.042 E.08431
G1 X110.758 Y94.509 E.01591
G1 X111.227 Y94.029 E.01632
G1 X111.744 Y93.656 E.01551
G1 X112.552 Y93.289 E.02159
G1 X113.237 Y93.127 E.01712
G1 X113.531 Y93.1 E.00718
G1 X117.233 Y93.087 E.09005
G1 X117.986 Y93.169 E.01842
G1 X118.52 Y93.314 E.01346
G1 X119.146 Y93.592 E.01666
G1 X119.871 Y94.123 E.02186
G1 X120.159 Y94.415 E.00998
G1 X120.504 Y94.867 E.01383
G1 X120.623 Y95.046 E.00523
G1 X122.433 Y98.197 E.08839
G1 X122.675 Y98.771 E.01515
G1 X122.825 Y99.39 E.01549
G1 X122.873 Y100.025 E.01549
G1 X122.763 Y100.905 E.02157
G1 X122.547 Y101.531 E.01611
G1 X122.185 Y102.248 E.01954
G1 X120.621 Y104.957 E.07609
G1 X120.159 Y105.584 E.01894
G1 X119.877 Y105.872 E.0098
G1 X119.444 Y106.218 E.01348
G1 X119.102 Y106.428 E.00976
G1 X118.598 Y106.658 E.01348
G1 X118.215 Y106.779 E.00977
;WIDTH:0.436733
G1 X117.675 Y106.898 E.0148
;WIDTH:0.486005
G1 X117.574 Y106.932 E.0032
;WIDTH:0.535277
G1 X117.474 Y106.966 E.00352
;WIDTH:0.584548
G1 X117.373 Y107 E.0039
G1 X117.584 Y107.055 E.00798
;WIDTH:0.538411
G1 X117.794 Y107.11 E.00728
;WIDTH:0.492274
G1 X118.004 Y107.166 E.00662
;WIDTH:0.446137
G1 X118.215 Y107.221 E.00597
;WIDTH:0.399999
G1 X118.598 Y107.342 E.00977
G1 X119.102 Y107.572 E.01348
G1 X119.444 Y107.782 E.00976
G1 X119.877 Y108.128 E.01348
G1 X120.159 Y108.416 E.0098
G1 X120.504 Y108.867 E.01381
G1 X120.621 Y109.043 E.00514
G1 X122.354 Y112.044 E.08429
G1 X122.658 Y112.723 E.0181
G1 X122.824 Y113.406 E.0171
G1 X122.869 Y113.958 E.01347
G1 X122.817 Y114.66 E.01712
G1 X122.565 Y115.511 E.02159
G1 X122.431 Y115.807 E.0079
G1 X120.512 Y119.126 E.09325
G1 X120.116 Y119.638 E.01574
G1 X119.649 Y120.072 E.01551
G1 X119.118 Y120.424 E.0155
G1 X118.627 Y120.637 E.01302
G1 X118.194 Y120.79 E.01117
;WIDTH:0.433246
G1 X117.939 Y120.848 E.00694
;WIDTH:0.466493
G1 X117.684 Y120.906 E.00752
;WIDTH:0.50816
G1 X117.6 Y120.936 E.00281
;WIDTH:0.549826
G1 X117.517 Y120.967 E.00304
;WIDTH:0.591492
G1 X117.433 Y120.998 E.00332
G1 X117.554 Y121.04 E.00475
;WIDTH:0.543619
G1 X117.674 Y121.081 E.0043
;WIDTH:0.495746
G1 X117.795 Y121.123 E.00393
;WIDTH:0.447873
G1 X117.915 Y121.165 E.0035
;WIDTH:0.399999
G1 X118.32 Y121.244 E.01004
G1 X119.102 Y121.572 E.02063
G1 X119.444 Y121.782 E.00976
G1 X119.877 Y122.128 E.01348
G1 X120.159 Y122.416 E.0098
G1 X120.621 Y123.043 E.01894
G1 X122.354 Y126.044 E.08429
G1 X122.675 Y126.783 E.0196
G1 X122.807 Y127.305 E.0131
G1 X122.872 Y128.017 E.01739
G1 X122.767 Y128.887 E.02132
G1 X122.545 Y129.567 E.0174
G1 X122.431 Y129.807 E.00646
G1 X120.512 Y133.125 E.09323
G1 X120.06 Y133.68 E.01741
G1 X119.689 Y134.04 E.01257
G1 X119.162 Y134.399 E.01551
G1 X118.584 Y134.667 E.0155
G1 X118.021 Y134.83 E.01426
G1 X117.422 Y134.903 E.01468
G1 X113.767 Y134.913 E.0889
G1 X112.952 Y134.818 E.01996
G1 X112.552 Y134.711 E.01007
G1 X112.039 Y134.501 E.01348
G1 X111.688 Y134.305 E.00978
G1 X111.242 Y133.978 E.01345
G1 X110.95 Y133.703 E.00976
G1 X110.596 Y133.278 E.01345
G1 X110.437 Y133.05 E.00676
G1 X108.647 Y129.958 E.0869
G1 X108.31 Y129.163 E.021
G1 X108.204 Y128.755 E.01025
G1 X108.137 Y128.22 E.01311
G1 X108.159 Y127.506 E.01738
G1 X108.293 Y126.874 E.01571
G1 X108.646 Y126.044 E.02194
G1 X110.379 Y123.043 E.08429
G1 X110.927 Y122.324 E.02199
G1 X111.243 Y122.022 E.01063
G1 X111.689 Y121.694 E.01347
G1 X112.04 Y121.498 E.00978
G1 X112.553 Y121.289 E.01347
;WIDTH:0.444545
G1 X112.786 Y121.221 E.00662
;WIDTH:0.489091
G1 X113.02 Y121.153 E.00737
;WIDTH:0.533637
G1 X113.253 Y121.085 E.00806
;WIDTH:0.578183
G1 X113.487 Y121.017 E.00882
;WIDTH:0.602448
G1 X113.532 Y120.999 E.00183
G1 X113.416 Y120.963 E.00459
;WIDTH:0.561958
G1 X113.3 Y120.926 E.00427
;WIDTH:0.521469
G1 X113.184 Y120.89 E.00394
;WIDTH:0.480979
G1 X113.068 Y120.854 E.00361
;WIDTH:0.440489
G1 X112.952 Y120.818 E.00328
;WIDTH:0.399999
G1 X112.552 Y120.711 E.01007
G1 X112.039 Y120.501 E.01348
G1 X111.688 Y120.305 E.00978
G1 X111.242 Y119.978 E.01345
G1 X110.916 Y119.662 E.01104
G1 X110.596 Y119.277 E.01218
G1 X110.437 Y119.05 E.00674
G1 X108.647 Y115.958 E.0869
G1 X108.31 Y115.162 E.02103
G1 X108.153 Y114.452 E.01769
G1 X108.131 Y113.816 E.01548
G1 X108.278 Y112.94 E.02161
G1 X108.57 Y112.193 E.01951
G1 X110.379 Y109.043 E.08836
G1 X110.927 Y108.324 E.02199
G1 X111.243 Y108.022 E.01063
G1 X111.689 Y107.694 E.01347
G1 X112.04 Y107.498 E.00978
G1 X112.553 Y107.289 E.01347
;WIDTH:0.444541
G1 X112.786 Y107.221 E.00662
;WIDTH:0.489083
G1 X113.02 Y107.153 E.00737
;WIDTH:0.533625
G1 X113.253 Y107.085 E.00806
;WIDTH:0.578167
G1 X113.487 Y107.017 E.00882
;WIDTH:0.602442
G1 X113.532 Y106.999 E.00183
G1 X113.416 Y106.963 E.00459
;WIDTH:0.561954
G1 X113.3 Y106.926 E.00427
;WIDTH:0.521465
G1 X113.184 Y106.89 E.00394
;WIDTH:0.480976
G1 X113.068 Y106.854 E.00361
;WIDTH:0.440488
G1 X112.952 Y106.818 E.00328
;WIDTH:0.399999
G1 X112.267 Y106.609 E.01742
G1 X111.631 Y106.258 E.01767
G1 X111.227 Y105.971 E.01205
G1 X110.86 Y105.616 E.01242
G1 X110.477 Y105.107 E.01549
G1 X108.646 Y101.956 E.08865
G1 X108.31 Y101.162 E.02097
G1 X108.305 Y101.14 E.00055
G1 E-5 F3600
G1 X108.305 Y101.14 F9000
G1 X109.247 Y114.228
G1 X109.275 Y114.455
G1 X109.321 Y114.678
G1 X109.385 Y114.897
G1 X109.467 Y115.11
G1 X109.567 Y115.317
G1 X109.605 Y115.389
G1 X111.35 Y118.41
G1 X111.413 Y118.512
G1 X111.545 Y118.7
G1 X111.691 Y118.875
G1 X111.851 Y119.038
G1 X112.023 Y119.188
G1 X112.207 Y119.323
G1 X112.402 Y119.442
G1 X112.605 Y119.545
G1 X112.817 Y119.632
G1 X113.035 Y119.701
G1 E5 F2400
;WIDTH:0.591492
G1 F6000
G1 X117.233 Y121.003 E.00741
;WIDTH:0.578678
G1 X113.766 Y121.001 E.12554
;WIDTH:0.602448
G1 X113.532 Y120.999 E.00884
G1 E-5 F3600
G1 X113.532 Y120.999 F9000
G1 X111.545 Y118.7
G1 X111.35 Y118.41
G1 X109.467 Y115.11
G1 X109.238 Y114
G1 X109.247 Y113.772
G1 X109.275 Y113.545
G1 X109.321 Y113.322
G1 X109.385 Y113.103
G1 X109.467 Y112.89
G1 X109.567 Y112.683
G1 X109.605 Y112.611
G1 X111.35 Y109.59
G1 X111.413 Y109.488
G1 X111.545 Y109.3
G1 X111.691 Y109.125
G1 X111.851 Y108.962
G1 X112.023 Y108.812
G1 X112.207 Y108.677
G1 X112.402 Y108.558
G1 X112.605 Y108.455
G1 X112.817 Y108.368
G1 X113.035 Y108.299
G1 X117.373 Y107
G1 E5 F2400
;WIDTH:0.584548
G1 F6000
G1 X113.77 Y107.001 E.13187
;WIDTH:0.602442
G1 X113.532 Y106.999 E.00899
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.77 Y107.001 E-.11305
G1 X116.69 Y107 E-1.38695
;WIPE_END
G1 X112.817 Y108.368 F9000
G1 X111.545 Y109.3
G1 X111.35 Y109.59
G1 X109.467 Y112.89
G1 X109.238 Y114
G1 X109.467 Y115.11
G1 X111.35 Y118.41
G1 X111.545 Y118.7
G1 X113.257 Y119.751
G1 X113.483 Y119.784
G1 X113.716 Y119.798
G1 X113.752 Y119.799
G1 X114.286 Y119.799
G1 X113.769 Y122.201
G1 X113.768 Y122.553
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X117.371 Y122.555 E.08764
G1 X117.948 Y122.659 E.01426
G1 X118.494 Y122.902 E.01454
G1 X118.965 Y123.271 E.01455
G1 X119.354 Y123.774 E.01547
G1 X121.087 Y126.775 E.08429
G1 X121.257 Y127.141 E.00982
G1 X121.388 Y127.663 E.01309
G1 X121.409 Y128.121 E.01115
G1 X121.323 Y128.655 E.01316
G1 X121.164 Y129.075 E.01092
G1 X119.246 Y132.393 E.09322
G1 X118.852 Y132.835 E.0144
G1 X118.501 Y133.094 E.01061
G1 X118.144 Y133.273 E.00971
G1 X117.758 Y133.391 E.00982
G1 X117.254 Y133.45 E.01234
G1 X113.767 Y133.451 E.08482
G1 X113.149 Y133.368 E.01517
G1 X112.592 Y133.147 E.01458
G1 X112.107 Y132.798 E.01453
G1 X111.703 Y132.317 E.01528
G1 X109.913 Y129.225 E.0869
G1 X109.656 Y128.572 E.01707
G1 X109.589 Y128.038 E.01309
G1 X109.622 Y127.587 E.011
G1 X109.722 Y127.198 E.00977
G1 X109.913 Y126.775 E.01129
G1 X111.646 Y123.774 E.08429
G1 X112.072 Y123.235 E.01671
G1 X112.553 Y122.875 E.01461
G1 X113.104 Y122.644 E.01453
G1 X113.704 Y122.553 E.01476
G1 X113.708 Y122.553 E.0001
G1 X113.708 Y122.553 F9000
G1 X113.689 Y122.197
;TYPE:Perimeter
G1 F6000
G1 X113.766 Y122.186 E.00189
G1 X117.371 Y122.189 E.08769
G1 X118.015 Y122.3 E.0159
G1 X118.646 Y122.57 E.01669
G1 X119.193 Y122.985 E.0167
G1 X119.632 Y123.533 E.01708
G1 X121.404 Y126.592 E.08599
G1 X121.611 Y127.052 E.01227
G1 X121.743 Y127.574 E.0131
G1 X121.777 Y128.092 E.01263
G1 X121.684 Y128.711 E.01523
G1 X121.481 Y129.258 E.01419
G1 X119.562 Y132.576 E.09323
G1 X119.123 Y133.08 E.01626
G1 X118.666 Y133.421 E.01387
G1 X118.254 Y133.621 E.01114
G1 X117.8 Y133.754 E.01151
G1 X117.233 Y133.816 E.01387
G1 X113.767 Y133.816 E.08431
G1 X113.1 Y133.731 E.01636
G1 X112.454 Y133.486 E.01681
G1 X111.891 Y133.093 E.0167
G1 X111.387 Y132.5 E.01893
G1 X109.597 Y129.408 E.0869
G1 X109.328 Y128.754 E.0172
G1 X109.293 Y128.618 E.00342
G1 X109.226 Y128.084 E.01309
G1 X109.267 Y127.499 E.01426
G1 X109.389 Y127.049 E.01134
G1 X109.596 Y126.593 E.01218
G1 X111.329 Y123.591 E.08431
G1 X111.786 Y123.008 E.01802
G1 X112.337 Y122.58 E.01697
G1 X112.966 Y122.305 E.0167
G1 X113.629 Y122.206 E.01631
G1 X113.629 Y122.206 F9000
G1 X113.608 Y121.829
G1 F6000
G1 X113.767 Y121.82 E.00387
G1 X117.372 Y121.824 E.08769
G1 X118.082 Y121.94 E.0175
G1 X118.798 Y122.237 E.01885
G1 X119.232 Y122.548 E.01299
G1 X119.578 Y122.859 E.01132
G1 X119.988 Y123.409 E.01669
G1 X121.72 Y126.41 E.08428
G1 X121.966 Y126.962 E.0147
G1 X122.098 Y127.484 E.0131
G1 X122.142 Y128.05 E.01381
G1 X122.045 Y128.77 E.01767
G1 X121.861 Y129.307 E.01381
G1 X121.798 Y129.441 E.0036
G1 X119.879 Y132.759 E.09323
G1 X119.517 Y133.19 E.01369
G1 X119.257 Y133.45 E.00894
G1 X118.832 Y133.747 E.01261
G1 X118.364 Y133.97 E.01261
G1 X117.842 Y134.118 E.0132
G1 X117.233 Y134.182 E.01489
G1 X113.767 Y134.182 E.08431
G1 X113.051 Y134.093 E.01755
G1 X112.316 Y133.824 E.01904
G1 X111.675 Y133.388 E.01886
G1 X111.159 Y132.81 E.01885
G1 X111.07 Y132.684 E.00375
G1 X109.28 Y129.592 E.0869
G1 X108.989 Y128.89 E.01848
G1 X108.93 Y128.664 E.00568
G1 X108.863 Y128.129 E.01311
G1 X108.888 Y127.562 E.01381
G1 X109.002 Y127.052 E.01271
G1 X109.28 Y126.41 E.01702
G1 X111.012 Y123.408 E.0843
G1 X111.5 Y122.78 E.01935
G1 X111.675 Y122.612 E.0059
G1 X112.121 Y122.284 E.01347
G1 X112.828 Y121.967 E.01885
G1 X113.548 Y121.839 E.01779
G1 X113.548 Y121.839 F9000
G1 X113.527 Y121.47
G1 F6000
G1 X113.55 Y121.467 E.00056
G1 X113.767 Y121.455 E.00529
G1 X117.372 Y121.458 E.08769
G1 X118.149 Y121.581 E.01914
G1 X118.63 Y121.758 E.01247
G1 X119.165 Y122.029 E.01459
G1 X119.649 Y122.413 E.01503
G1 X119.868 Y122.637 E.00762
G1 X120.213 Y123.089 E.01383
G1 X122.037 Y126.227 E.08829
G1 X122.32 Y126.873 E.01715
G1 X122.452 Y127.395 E.0131
G1 X122.507 Y128.034 E.0156
G1 X122.406 Y128.828 E.01947
G1 X122.203 Y129.437 E.01561
G1 X122.114 Y129.624 E.00504
G1 X120.195 Y132.942 E.09323
G1 X119.789 Y133.435 E.01553
G1 X119.473 Y133.745 E.01077
G1 X118.997 Y134.073 E.01406
G1 X118.474 Y134.319 E.01406
G1 X117.958 Y134.47 E.01308
G1 X117.233 Y134.548 E.01774
G1 X113.767 Y134.548 E.08431
G1 X113.001 Y134.455 E.01877
G1 X112.69 Y134.372 E.00783
G1 X112.177 Y134.163 E.01347
G1 X111.459 Y133.683 E.02101
G1 X111.231 Y133.469 E.00761
G1 X110.877 Y133.044 E.01345
G1 X110.754 Y132.867 E.00524
G1 X108.964 Y129.775 E.0869
G1 X108.649 Y129.027 E.01974
G1 X108.567 Y128.709 E.00799
G1 X108.5 Y128.175 E.01309
G1 X108.523 Y127.534 E.0156
G1 X108.647 Y126.963 E.01421
G1 X108.963 Y126.227 E.01948
G1 X110.696 Y123.226 E.08429
G1 X111.214 Y122.552 E.02068
G1 X111.459 Y122.317 E.00826
G1 X111.905 Y121.989 E.01347
G1 X112.178 Y121.837 E.0076
G1 X112.691 Y121.628 E.01347
G1 X113.004 Y121.544 E.00788
G1 X113.468 Y121.479 E.0114
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X113.527 Y121.47 E-.02835
G1 X113.55 Y121.467 E-.01102
G1 X113.767 Y121.455 E-.10323
G1 X116.625 Y121.457 E-1.3574
;WIPE_END
G1 X113.035 Y122.299 F9000
G1 X112.817 Y122.368
G1 X112.605 Y122.455
G1 X112.402 Y122.558
G1 X112.207 Y122.677
G1 X112.023 Y122.812
G1 X111.851 Y122.962
G1 X111.691 Y123.125
G1 X111.545 Y123.3
G1 X111.413 Y123.488
G1 X111.35 Y123.59
G1 X109.605 Y126.611
G1 X109.567 Y126.683
G1 X109.467 Y126.89
G1 X109.385 Y127.103
G1 X109.321 Y127.322
G1 X109.275 Y127.545
G1 X109.247 Y127.772
G1 X109.238 Y128
G1 X109.247 Y128.228
G1 X109.275 Y128.455
G1 X109.321 Y128.678
G1 X109.385 Y128.897
G1 X109.467 Y129.11
G1 X109.567 Y129.317
G1 X109.605 Y129.389
G1 X110.095 Y130.235
G1 X106.099 Y136.118
G1 X105.719 Y136.118
G1 E5 F2400
G1 F6000
G1 X105.75 Y136.048 E.00186
G1 X105.75 Y103.607 E.78909
G1 X105.729 Y103.523 E.00211
G1 X105.567 Y103.424 E.00462
G1 X105.125 Y103.424 E.01075
G1 X105.125 Y98.824 E.11189
G1 X105.567 Y98.824 E.01075
G1 X105.703 Y98.764 E.00362
G1 X105.75 Y98.642 E.00318
G1 X105.75 Y91.952 E.16273
G1 X105.691 Y91.817 E.00358
G1 X104.902 Y91.088 E.02613
G1 X104.577 Y90.675 E.01278
G1 X104.51 Y90.472 E.0052
G1 X104.629 Y90.24 E.00634
G1 X104.886 Y89.928 E.00983
G1 X105.579 Y89.285 E.02299
G1 X125.423 Y89.285 E.48269
G1 X126.193 Y90.016 E.02583
G1 X126.443 Y90.372 E.01058
G1 X126.481 Y90.511 E.00351
G1 X126.479 Y90.581 E.0017
G1 X126.238 Y90.94 E.01052
G1 X125.878 Y91.303 E.01244
G1 X125.31 Y91.816 E.01862
G1 X125.25 Y91.952 E.00362
G1 X125.25 Y98.195 E.15185
G1 X125.269 Y98.723 E.01285
G1 X125.433 Y98.824 E.00468
G1 X125.875 Y98.824 E.01075
G1 X125.875 Y103.424 E.11189
G1 X125.433 Y103.424 E.01075
G1 X125.294 Y103.489 E.00373
G1 X125.25 Y103.607 E.00306
G1 X125.25 Y136.048 E.78909
G1 X125.309 Y136.183 E.00358
G1 X126.098 Y136.912 E.02613
G1 X126.423 Y137.325 E.01278
G1 X126.49 Y137.528 E.0052
G1 X126.371 Y137.759 E.00632
G1 X126.114 Y138.071 E.00983
G1 X125.421 Y138.715 E.02301
G1 X105.577 Y138.715 E.48269
G1 X104.801 Y137.978 E.02603
G1 X104.516 Y137.565 E.01221
G1 X104.52 Y137.419 E.00355
G1 X104.762 Y137.06 E.01053
G1 X105.122 Y136.697 E.01244
G1 X105.69 Y136.184 E.01862
G1 X105.695 Y136.172 E.00032
G1 X105.695 Y136.172 F9000
G1 X106.059 Y136.273
;TYPE:Perimeter
G1 F6000
G1 X106.081 Y136.241 E.00094
G1 X106.116 Y136.048 E.00477
G1 X106.116 Y103.607 E.78909
G1 X106.1 Y103.479 E.00314
G1 X106.013 Y103.287 E.00513
G1 X105.567 Y103.059 E.01218
G1 X105.491 Y103.059 E.00185
G1 X105.491 Y99.19 E.09411
G1 X105.567 Y99.19 E.00185
G1 X105.974 Y99.009 E.01083
G1 X106.076 Y98.845 E.0047
G1 X106.116 Y98.642 E.00503
G1 X106.116 Y91.952 E.16273
G1 X106.081 Y91.761 E.00472
G1 X105.94 Y91.549 E.00619
G1 X105.201 Y90.865 E.02449
G1 X104.906 Y90.502 E.01138
G1 X105.147 Y90.185 E.00969
G1 X105.722 Y89.65 E.0191
G1 X125.282 Y89.65 E.47578
G1 X125.933 Y90.273 E.02192
G1 X126.092 Y90.503 E.0068
G1 X125.976 Y90.674 E.00503
G1 X125.625 Y91.038 E.0123
G1 X125.065 Y91.545 E.01837
G1 X124.919 Y91.759 E.0063
G1 X124.884 Y91.952 E.00477
G1 X124.889 Y98.712 E.16443
G1 X124.988 Y98.962 E.00654
G1 X125.433 Y99.19 E.01216
G1 X125.509 Y99.19 E.00185
G1 X125.509 Y103.059 E.09411
G1 X125.433 Y103.059 E.00185
G1 X125.015 Y103.252 E.0112
G1 X124.947 Y103.353 E.00296
G1 X124.884 Y103.607 E.00637
G1 X124.884 Y136.048 E.78909
G1 X124.919 Y136.239 E.00472
G1 X125.06 Y136.451 E.00619
G1 X125.799 Y137.135 E.02449
G1 X126.094 Y137.498 E.01138
G1 X125.853 Y137.815 E.00969
G1 X125.278 Y138.35 E.0191
G1 X105.718 Y138.35 E.47578
G1 X105.067 Y137.727 E.02192
G1 X104.908 Y137.497 E.0068
G1 X105.024 Y137.326 E.00503
G1 X105.375 Y136.962 E.0123
G1 X105.935 Y136.455 E.01837
G1 X106.025 Y136.323 E.00389
G1 X106.025 Y136.323 F9000
G1 X106.387 Y136.423
G1 F6000
G1 X106.423 Y136.37 E.00156
G1 X106.481 Y136.048 E.00796
G1 X106.481 Y103.607 E.78909
G1 X106.426 Y103.294 E.00773
G1 X106.263 Y103.015 E.00786
G1 X105.857 Y102.827 E.01088
G1 X105.857 Y99.427 E.0827
G1 X106.245 Y99.255 E.01032
G1 X106.416 Y98.981 E.00786
G1 X106.481 Y98.642 E.0084
G1 X106.481 Y91.952 E.16273
G1 X106.424 Y91.634 E.00786
G1 X106.188 Y91.281 E.01033
G1 X105.363 Y90.491 E.02778
G1 X105.866 Y90.016 E.01683
G1 X125.14 Y90.016 E.46882
G1 X125.644 Y90.5 E.017
G1 X125.372 Y90.773 E.00937
G1 X124.82 Y91.274 E.01813
G1 X124.577 Y91.63 E.01048
G1 X124.519 Y91.952 E.00796
G1 X124.519 Y98.564 E.16083
G1 X124.57 Y98.945 E.00935
G1 X124.755 Y99.255 E.00878
G1 X125.143 Y99.427 E.01032
G1 X125.143 Y102.827 E.0827
G1 X124.737 Y103.014 E.01087
G1 X124.574 Y103.294 E.00788
G1 X124.519 Y103.607 E.00773
G1 X124.519 Y136.048 E.78909
G1 X124.576 Y136.366 E.00786
G1 X124.812 Y136.719 E.01033
G1 X125.637 Y137.509 E.02778
G1 X125.134 Y137.984 E.01683
G1 X105.86 Y137.984 E.46882
G1 X105.356 Y137.5 E.017
G1 X105.628 Y137.227 E.00937
G1 X106.18 Y136.726 E.01813
G1 X106.353 Y136.472 E.00748
G1 X106.353 Y136.472 F9000
G1 X106.715 Y136.572
G1 F6000
G1 X106.765 Y136.498 E.00217
G1 X106.847 Y136.048 E.01113
G1 X106.847 Y103.607 E.78909
G1 X106.769 Y103.168 E.01085
G1 X106.542 Y102.778 E.01098
G1 X106.222 Y102.63 E.00858
G1 X106.222 Y99.63 E.07297
G1 X106.544 Y99.469 E.00876
G1 X106.775 Y99.065 E.01132
G1 X106.847 Y98.642 E.01044
G1 X106.847 Y91.952 E.16273
G1 X106.767 Y91.507 E.011
G1 X106.436 Y91.012 E.01448
G1 X105.882 Y90.5 E.01835
G1 X106.01 Y90.382 E.00423
G1 X124.999 Y90.382 E.46189
G1 X125.129 Y90.5 E.00427
G1 X124.574 Y91.002 E.0182
G1 X124.235 Y91.502 E.01469
G1 X124.153 Y91.952 E.01113
G1 X124.164 Y98.805 E.16669
G1 X124.287 Y99.211 E.01032
G1 X124.484 Y99.5 E.00851
G1 X124.778 Y99.631 E.00783
G1 X124.778 Y102.63 E.07295
G1 X124.459 Y102.777 E.00854
G1 X124.231 Y103.168 E.01101
G1 X124.153 Y103.607 E.01085
G1 X124.153 Y136.048 E.78909
G1 X124.233 Y136.493 E.011
G1 X124.564 Y136.988 E.01448
G1 X125.118 Y137.5 E.01835
G1 X124.99 Y137.618 E.00423
G1 X106.001 Y137.618 E.46189
G1 X105.88 Y137.491 E.00427
G1 X106.426 Y136.998 E.01789
G1 X106.681 Y136.622 E.01105
G1 X106.681 Y136.622 F9000
G1 X107.043 Y136.722
G1 F6000
G1 X107.108 Y136.627 E.0028
G1 X107.213 Y136.048 E.01431
G1 X107.213 Y103.607 E.78909
G1 X107.167 Y103.222 E.00943
G1 X107.026 Y102.846 E.00977
G1 X106.82 Y102.541 E.00895
G1 X106.588 Y102.433 E.00622
G1 X106.588 Y99.834 E.06322
G1 X106.788 Y99.745 E.00532
G1 X106.975 Y99.493 E.00763
G1 X107.176 Y98.987 E.01324
G1 X107.213 Y98.642 E.00844
G1 X107.213 Y91.952 E.16273
G1 X107.11 Y91.38 E.01414
G1 X106.687 Y90.747 E.01852
G1 X124.318 Y90.747 E.42886
G1 X123.892 Y91.373 E.01842
G1 X123.787 Y91.952 E.01431
G1 X123.787 Y98.195 E.15185
G1 X123.821 Y98.975 E.01899
G1 X123.959 Y99.374 E.01027
G1 X124.213 Y99.745 E.01094
G1 X124.412 Y99.834 E.0053
G1 X124.412 Y102.433 E.06322
G1 X124.18 Y102.54 E.00621
G1 X124.077 Y102.674 E.00411
G1 X123.887 Y103.043 E.0101
G1 X123.787 Y103.607 E.01393
G1 X123.787 Y136.048 E.78909
G1 X123.89 Y136.62 E.01414
G1 X124.313 Y137.253 E.01852
G1 X106.682 Y137.253 E.42886
G1 X107.009 Y136.771 E.01417
G1 E-5 F3600
G1 X107.009 Y136.771 F9000
G1 X116.666 Y137.143
G1 E5 F2400
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X119.042 Y134.768 E.08172
G1 X118.241 Y135.052 E.02067
G1 X116.314 Y136.978 E.06627
G1 X115.797 Y136.978 E.01258
G1 X117.62 Y135.155 E.06271
G1 X117.081 Y135.177 E.01312
G1 X115.279 Y136.978 E.06197
G1 X114.762 Y136.978 E.01258
G1 X116.562 Y135.178 E.06192
G1 X116.043 Y135.18 E.01262
G1 X114.245 Y136.978 E.06185
G1 X113.728 Y136.978 E.01258
G1 X115.524 Y135.182 E.06178
G1 X115.005 Y135.184 E.01262
G1 X113.21 Y136.978 E.06173
G1 X112.693 Y136.978 E.01258
G1 X114.486 Y135.185 E.06168
G1 X113.967 Y135.187 E.01262
G1 X112.176 Y136.978 E.06161
G1 X111.659 Y136.978 E.01258
G1 X113.472 Y135.165 E.06237
G1 X113.017 Y135.103 E.01117
G1 X111.142 Y136.978 E.0645
G1 X110.624 Y136.978 E.0126
G1 X112.597 Y135.005 E.06787
G1 X112.216 Y134.87 E.00983
G1 X110.107 Y136.978 E.07253
G1 X109.59 Y136.978 E.01258
G1 X111.856 Y134.712 E.07795
G1 X111.525 Y134.526 E.00924
G1 X109.073 Y136.978 E.08435
G1 X108.555 Y136.978 E.0126
G1 X111.227 Y134.307 E.0919
G1 X110.943 Y134.073 E.00895
G1 X108.038 Y136.978 E.09993
G1 X107.521 Y136.978 E.01258
G1 X110.686 Y133.814 E.10886
G1 X110.451 Y133.531 E.00895
G1 X107.39 Y136.593 E.10531
G1 X107.487 Y135.978 E.01514
G1 X110.232 Y133.233 E.09443
G1 X110.039 Y132.909 E.00917
G1 X107.487 Y135.461 E.08779
G1 X107.487 Y134.944 E.01258
G1 X109.849 Y132.581 E.08127
G1 X109.66 Y132.254 E.00919
G1 X107.487 Y134.426 E.07473
G1 X107.487 Y133.909 E.01258
G1 X109.47 Y131.926 E.06821
G1 X109.28 Y131.599 E.0092
G1 X107.487 Y133.392 E.06168
G1 X107.487 Y132.875 E.01258
G1 X109.091 Y131.271 E.05518
G1 X108.901 Y130.943 E.00922
G1 X107.487 Y132.357 E.04864
G1 X107.487 Y131.84 E.01258
G1 X108.711 Y130.616 E.0421
G1 X108.522 Y130.288 E.00921
G1 X107.487 Y131.323 E.0356
G1 X107.487 Y130.806 E.01258
G1 X108.34 Y129.952 E.02936
G1 X108.186 Y129.59 E.00957
G1 X107.487 Y130.289 E.02405
G1 X107.487 Y129.771 E.0126
G1 X108.041 Y129.217 E.01906
G1 X107.937 Y128.804 E.01036
G1 X107.487 Y129.254 E.01548
G1 X107.487 Y128.737 E.01258
G1 X107.886 Y128.338 E.01373
G1 X107.861 Y127.845 E.01201
G1 X107.487 Y128.22 E.01288
G1 X107.487 Y127.702 E.0126
G1 X107.92 Y127.269 E.01489
G1 X108.112 Y126.56 E.01787
G1 X107.487 Y127.185 E.0215
G1 X107.487 Y126.668 E.01258
G1 X108.628 Y125.526 E.03927
G1 X109.335 Y124.303 E.03436
G1 X107.487 Y126.151 E.06357
G1 X107.487 Y125.634 E.01258
G1 X110.042 Y123.079 E.08789
G1 X110.3 Y122.672 E.01172
G1 X110.879 Y121.969 E.02215
G1 X111.819 Y121.301 E.02805
G1 X112.241 Y120.88 E.0145
G1 X111.877 Y120.727 E.0096
G1 X107.487 Y125.116 E.151
G1 X107.487 Y124.599 E.01258
G1 X111.546 Y120.54 E.13963
G1 X111.252 Y120.316 E.00899
G1 X107.487 Y124.082 E.12953
G1 X107.487 Y123.565 E.01258
G1 X110.96 Y120.092 E.11947
G1 X110.706 Y119.828 E.00891
G1 X107.487 Y123.048 E.11075
G1 X107.487 Y122.53 E.0126
G1 X110.468 Y119.549 E.10254
G1 X110.246 Y119.254 E.00898
G1 X107.487 Y122.013 E.09491
G1 X107.487 Y121.496 E.01258
G1 X110.052 Y118.931 E.08823
G1 X109.862 Y118.604 E.0092
G1 X107.487 Y120.979 E.0817
G1 X107.487 Y120.461 E.0126
G1 X109.672 Y118.276 E.07516
G1 X109.483 Y117.948 E.00921
G1 X107.487 Y119.944 E.06866
G1 X107.487 Y119.427 E.01258
G1 X109.293 Y117.621 E.06213
G1 X109.103 Y117.293 E.00922
G1 X107.487 Y118.91 E.05561
G1 X107.487 Y118.393 E.01258
G1 X108.914 Y116.966 E.04909
G1 X108.724 Y116.638 E.00922
G1 X107.487 Y117.875 E.04255
G1 X107.487 Y117.358 E.01258
G1 X108.535 Y116.31 E.03605
G1 X108.352 Y115.976 E.00926
G1 X107.487 Y116.841 E.02976
G1 X107.487 Y116.324 E.01258
G1 X108.196 Y115.615 E.02439
G1 X108.049 Y115.244 E.00971
G1 X107.487 Y115.806 E.01933
G1 X107.487 Y115.289 E.01258
G1 X107.939 Y114.837 E.01555
G1 X107.873 Y114.386 E.01109
G1 X107.487 Y114.772 E.01328
G1 X107.487 Y114.255 E.01258
G1 X107.857 Y113.884 E.01274
G1 X107.923 Y113.302 E.01425
G1 X107.487 Y113.738 E.015
G1 X107.487 Y113.22 E.0126
G1 X108.097 Y112.61 E.02098
G1 X108.581 Y111.61 E.02702
G1 X107.487 Y112.703 E.03762
G1 X107.487 Y112.186 E.01258
G1 X109.287 Y110.386 E.06192
G1 X109.994 Y109.162 E.03438
G1 X107.487 Y111.669 E.08624
G1 X107.487 Y111.151 E.0126
G1 X111.899 Y106.739 E.15177
G1 X111.577 Y106.544 E.00916
G1 X107.487 Y110.634 E.14069
G1 X107.487 Y110.117 E.01258
G1 X111.26 Y106.344 E.12979
G1 X110.978 Y106.109 E.00893
G1 X107.487 Y109.6 E.12009
G1 X107.487 Y109.083 E.01258
G1 X110.711 Y105.859 E.1109
G1 X110.485 Y105.567 E.00898
G1 X107.487 Y108.565 E.10313
G1 X107.487 Y108.048 E.01258
G1 X110.26 Y105.275 E.09539
G1 X110.069 Y104.949 E.00919
G1 X107.487 Y107.531 E.08882
G1 X107.487 Y107.014 E.01258
G1 X109.879 Y104.622 E.08228
G1 X109.689 Y104.295 E.0092
G1 X107.487 Y106.497 E.07575
G1 X107.487 Y105.979 E.0126
G1 X109.498 Y103.968 E.06918
G1 X109.308 Y103.641 E.0092
G1 X107.487 Y105.462 E.06264
G1 X107.487 Y104.945 E.01258
G1 X109.118 Y103.314 E.05611
G1 X108.928 Y102.986 E.00922
G1 X107.487 Y104.428 E.04959
G1 X107.487 Y103.91 E.0126
G1 X108.738 Y102.659 E.04303
G1 X108.548 Y102.332 E.0092
G1 X107.465 Y103.415 E.03725
G1 X107.381 Y102.982 E.01073
G1 X108.363 Y102 E.03378
G1 X108.206 Y101.64 E.00955
G1 X107.212 Y102.634 E.03419
G1 X106.992 Y102.336 E.00901
G1 X108.058 Y101.271 E.03665
G1 X107.944 Y100.867 E.01021
G1 X106.862 Y101.949 E.03722
G1 X106.862 Y101.432 E.01258
G1 X107.881 Y100.413 E.03505
G1 X107.857 Y99.919 E.01203
G1 X106.862 Y100.914 E.03423
G1 X106.862 Y100.397 E.01258
G1 X107.911 Y99.348 E.03608
G1 X108.1 Y98.642 E.01778
G1 X107.302 Y99.44 E.02745
G1 X107.444 Y99.045 E.01021
G1 X107.478 Y98.747 E.0073
G1 X108.533 Y97.693 E.03627
G1 X109.239 Y96.469 E.03437
G1 X107.479 Y98.229 E.06054
G1 X107.479 Y97.711 E.0126
G1 X109.946 Y95.245 E.08485
G1 X110.693 Y94.16 E.03204
G1 X111.281 Y93.637 E.01914
G1 X111.953 Y93.238 E.01901
G1 X114.169 Y91.022 E.07623
G1 X114.686 Y91.022 E.01258
G1 X112.766 Y92.942 E.06605
G1 X113.387 Y92.838 E.01532
G1 X115.203 Y91.022 E.06247
G1 X115.721 Y91.022 E.0126
G1 X113.918 Y92.824 E.062
G1 X114.437 Y92.822 E.01262
G1 X116.238 Y91.022 E.06194
G1 X116.755 Y91.022 E.01258
G1 X114.956 Y92.82 E.06187
G1 X115.475 Y92.819 E.01262
G1 X117.272 Y91.022 E.06182
G1 X117.789 Y91.022 E.01258
G1 X115.994 Y92.817 E.06175
G1 X116.514 Y92.815 E.01265
G1 X118.307 Y91.022 E.06168
G1 X118.824 Y91.022 E.01258
G1 X117.033 Y92.813 E.06161
G1 X117.531 Y92.832 E.01212
G1 X119.341 Y91.022 E.06226
G1 X119.858 Y91.022 E.01258
G1 X117.988 Y92.892 E.06433
G1 X118.4 Y92.997 E.01034
G1 X120.376 Y91.022 E.06796
G1 X120.893 Y91.022 E.01258
G1 X118.79 Y93.125 E.07234
G1 X119.147 Y93.285 E.00952
G1 X121.41 Y91.022 E.07785
G1 X121.927 Y91.022 E.01258
G1 X119.473 Y93.476 E.08442
G1 X119.772 Y93.695 E.00902
G1 X122.444 Y91.022 E.09193
G1 X122.962 Y91.022 E.0126
G1 X120.059 Y93.924 E.09984
G1 X120.319 Y94.182 E.00891
G1 X123.479 Y91.022 E.1087
G1 X123.806 Y91.022 E.00795
G1 X123.635 Y91.273 E.00739
G1 X123.61 Y91.407 E.00332
G1 X120.545 Y94.473 E.10545
G1 X120.767 Y94.768 E.00898
G1 X123.513 Y92.022 E.09446
G1 X123.513 Y92.539 E.01258
G1 X120.964 Y95.089 E.0877
G1 X121.152 Y95.417 E.0092
G1 X123.513 Y93.056 E.08122
G1 X123.513 Y93.574 E.0126
G1 X121.341 Y95.746 E.07472
G1 X121.53 Y96.074 E.00921
G1 X123.513 Y94.091 E.06821
G1 X123.513 Y94.608 E.01258
G1 X121.718 Y96.403 E.06175
G1 X121.907 Y96.731 E.00921
G1 X123.513 Y95.125 E.05525
G1 X123.513 Y95.642 E.01258
G1 X122.096 Y97.06 E.04876
G1 X122.285 Y97.388 E.00921
G1 X123.513 Y96.16 E.04224
G1 X123.513 Y96.677 E.01258
G1 X122.473 Y97.717 E.03578
G1 X122.662 Y98.045 E.00921
G1 X123.513 Y97.194 E.02927
G1 X123.513 Y97.711 E.01258
G1 X122.825 Y98.399 E.02367
G1 X122.964 Y98.778 E.00982
G1 X123.513 Y98.229 E.01889
G1 X123.519 Y98.74 E.01243
G1 X123.06 Y99.199 E.01579
G1 X123.132 Y99.644 E.01096
G1 X123.593 Y99.183 E.01586
G1 X123.745 Y99.548 E.00962
G1 X123.142 Y100.151 E.02074
G1 X123.064 Y100.746 E.0146
G1 X123.952 Y99.859 E.03053
G1 X124.138 Y99.995 E.0056
G1 X124.138 Y100.19 E.00474
G1 X122.879 Y101.449 E.04331
G1 X122.372 Y102.473 E.02779
G1 X124.138 Y100.707 E.06075
G1 X124.138 Y101.225 E.0126
G1 X121.665 Y103.697 E.08505
G1 X120.959 Y104.921 E.03437
G1 X124.138 Y101.742 E.10936
G1 X124.138 Y102.259 E.01258
G1 X119.117 Y107.279 E.1727
G1 X119.457 Y107.457 E.00933
G1 X123.54 Y103.374 E.14045
G1 X123.513 Y103.918 E.01325
G1 X119.749 Y107.682 E.12948
G1 X120.041 Y107.907 E.00897
G1 X123.513 Y104.435 E.11943
G1 X123.513 Y104.952 E.01258
G1 X120.304 Y108.161 E.11039
G1 X120.526 Y108.457 E.009
G1 X123.513 Y105.47 E.10275
G1 X123.513 Y105.987 E.01258
G1 X120.746 Y108.754 E.09518
G1 X120.951 Y109.066 E.00908
G1 X123.513 Y106.504 E.08813
G1 X123.513 Y107.021 E.01258
G1 X121.14 Y109.394 E.08163
G1 X121.33 Y109.722 E.00922
G1 X123.513 Y107.539 E.07509
G1 X123.513 Y108.056 E.01258
G1 X121.519 Y110.05 E.06859
G1 X121.708 Y110.378 E.00921
G1 X123.513 Y108.573 E.06209
G1 X123.513 Y109.09 E.01258
G1 X121.898 Y110.706 E.05557
G1 X122.087 Y111.034 E.00921
G1 X123.513 Y109.607 E.04907
G1 X123.513 Y110.125 E.0126
G1 X122.276 Y111.361 E.04253
G1 X122.466 Y111.689 E.00922
G1 X123.513 Y110.642 E.03602
G1 X123.513 Y111.159 E.01258
G1 X122.648 Y112.024 E.02976
G1 X122.818 Y112.372 E.00942
G1 X123.513 Y111.676 E.02392
G1 X123.513 Y112.193 E.01258
G1 X122.946 Y112.76 E.0195
G1 X123.057 Y113.167 E.01026
G1 X123.513 Y112.711 E.01569
G1 X123.513 Y113.228 E.01258
G1 X123.117 Y113.624 E.01362
G1 X123.139 Y114.119 E.01205
G1 X123.513 Y113.745 E.01287
G1 X123.513 Y114.262 E.01258
G1 X123.088 Y114.688 E.01464
G1 X122.891 Y115.401 E.01799
G1 X123.513 Y114.78 E.02138
G1 X123.513 Y115.297 E.01258
G1 X122.397 Y116.413 E.03839
G1 X121.688 Y117.639 E.03445
G1 X123.513 Y115.814 E.06278
G1 X123.513 Y116.331 E.01258
G1 X120.979 Y118.865 E.08717
G1 X120.566 Y119.527 E.01898
G1 X120.223 Y119.929 E.01285
G1 X119.659 Y120.41 E.01803
G1 X119.107 Y120.737 E.01561
G1 X118.739 Y121.105 E.01266
G1 X119.094 Y121.268 E.0095
G1 X123.513 Y116.848 E.15203
G1 X123.513 Y117.366 E.0126
G1 X119.433 Y121.445 E.14033
G1 X119.73 Y121.666 E.009
G1 X123.513 Y117.883 E.13013
G1 X123.513 Y118.4 E.01258
G1 X120.014 Y121.899 E.12036
G1 X120.284 Y122.147 E.00892
G1 X123.513 Y118.917 E.11109
G1 X123.513 Y119.435 E.0126
G1 X120.512 Y122.436 E.10323
G1 X120.739 Y122.726 E.00896
G1 X123.513 Y119.952 E.09542
G1 X123.513 Y120.469 E.01258
G1 X120.938 Y123.044 E.08858
G1 X121.128 Y123.372 E.00922
G1 X123.513 Y120.986 E.08206
G1 X123.513 Y121.503 E.01258
G1 X121.317 Y123.7 E.07556
G1 X121.506 Y124.028 E.00921
G1 X123.513 Y122.021 E.06904
G1 X123.513 Y122.538 E.01258
G1 X121.695 Y124.355 E.06252
G1 X121.885 Y124.683 E.00922
G1 X123.513 Y123.055 E.056
G1 X123.513 Y123.572 E.01258
G1 X122.074 Y125.011 E.0495
G1 X122.263 Y125.339 E.00921
G1 X123.513 Y124.09 E.04298
G1 X123.513 Y124.607 E.01258
G1 X122.453 Y125.667 E.03646
G1 X122.637 Y126 E.00925
G1 X123.513 Y125.124 E.03013
G1 X123.513 Y125.641 E.01258
G1 X122.806 Y126.348 E.02432
G1 X122.944 Y126.728 E.00983
G1 X123.513 Y126.158 E.01959
G1 X123.513 Y126.676 E.0126
G1 X123.048 Y127.141 E.016
G1 X123.124 Y127.582 E.01089
G1 X123.513 Y127.193 E.01338
G1 X123.513 Y127.71 E.01258
G1 X123.143 Y128.081 E.01274
G1 X123.082 Y128.659 E.01414
G1 X123.513 Y128.227 E.01484
G1 X123.513 Y128.744 E.01258
G1 X122.928 Y129.33 E.02014
G1 X122.445 Y130.329 E.02699
G1 X123.513 Y129.262 E.03672
G1 X123.513 Y129.779 E.01258
G1 X121.736 Y131.556 E.06113
G1 X121.027 Y132.782 E.03445
G1 X123.513 Y130.296 E.08552
G1 X123.513 Y130.813 E.01258
G1 X117.348 Y136.978 E.21207
G1 X117.865 Y136.978 E.01258
G1 X123.513 Y131.331 E.19427
G1 X123.513 Y131.848 E.01258
G1 X118.383 Y136.978 E.17647
G1 X118.9 Y136.978 E.01258
G1 X123.513 Y132.365 E.15868
G1 X123.513 Y132.882 E.01258
G1 X119.417 Y136.978 E.1409
G1 X119.934 Y136.978 E.01258
G1 X123.513 Y133.399 E.12312
G1 X123.513 Y133.917 E.0126
G1 X120.452 Y136.978 E.1053
G1 X120.969 Y136.978 E.01258
G1 X123.513 Y134.434 E.08751
G1 X123.513 Y134.951 E.01258
G1 X121.486 Y136.978 E.06973
G1 X122.003 Y136.978 E.01258
G1 X123.513 Y135.468 E.05194
G1 X123.513 Y135.986 E.0126
G1 X122.52 Y136.978 E.03414
G1 X123.038 Y136.978 E.0126
G1 X123.581 Y136.435 E.01868
G1 X123.705 Y136.828 E.01002
G1 X123.39 Y137.143 E.01084
G1 E-5 F3600
G1 X123.39 Y137.143 F9000
G1 X121.76 Y113.886
G1 X121.742 Y113.658
G1 X121.704 Y113.433
G1 X119.865 Y106.014
G1 E5 F2400
G1 F3072.127
G1 X118.632 Y107.247 E.04241
G1 E-5 F3600
G1 X118.632 Y107.247 F9000
G1 X112.39 Y106.765
G1 E5 F2400
G1 F3072.127
G1 X111.345 Y107.811 E.03596
G1 E-5 F3600
G1 X111.345 Y107.811 F9000
G1 X107.315 Y97.358
G1 E5 F2400
G1 F3072.127
G1 X113.652 Y91.022 E.21797
G1 X113.135 Y91.022 E.01258
G1 X107.481 Y96.676 E.19449
G1 X107.481 Y96.158 E.0126
G1 X112.617 Y91.022 E.17668
G1 X112.1 Y91.022 E.01258
G1 X107.482 Y95.64 E.15886
G1 X107.483 Y95.122 E.0126
G1 X111.583 Y91.022 E.14104
G1 X111.066 Y91.022 E.01258
G1 X107.483 Y94.604 E.12324
G1 X107.484 Y94.086 E.0126
G1 X110.548 Y91.022 E.1054
G1 X110.031 Y91.022 E.01258
G1 X107.485 Y93.568 E.08758
G1 X107.485 Y93.05 E.0126
G1 X109.514 Y91.022 E.06978
G1 X108.997 Y91.022 E.01258
G1 X107.486 Y92.532 E.05196
G1 X107.487 Y92.014 E.0126
G1 X108.48 Y91.022 E.03414
G1 X107.962 Y91.022 E.0126
G1 X107.419 Y91.565 E.01868
G1 X107.295 Y91.172 E.01002
G1 X107.61 Y90.857 E.01084
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X107.295 Y91.172 E-.2116
G1 X107.419 Y91.565 E-.19575
G1 X107.962 Y91.022 E-.36476
G1 X108.48 Y91.022 E-.24605
G1 X107.762 Y91.739 E-.48184
;WIPE_END
G1 X108.568 Y89.634 F9000
G1 X109.135 Y88.151
G1 X109.73 Y86.599
G1 X109.801 Y85.151
G1 X110.15 Y85.5
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X104.557 Y85.5 E.13604
G1 X103.99 Y85.458 E.01383
G1 X103.442 Y85.334 E.01367
G1 X102.844 Y85.094 E.01567
G1 X102.41 Y84.839 E.01224
G1 X101.88 Y84.399 E.01676
G1 X101.413 Y83.842 E.01768
G1 X101.157 Y83.407 E.01228
G1 X100.92 Y82.819 E.01542
G1 X100.761 Y81.976 E.02087
G1 X100.75 Y78.952 E.07356
G1 X100.691 Y78.817 E.00358
G1 X99.976 Y78.16 E.02362
G1 X99.585 Y77.704 E.01461
G1 X99.511 Y77.47 E.00597
G1 X99.659 Y77.182 E.00788
G1 X100.114 Y76.705 E.01603
G1 X100.577 Y76.285 E.01521
G1 X130.423 Y76.285 E.72597
G1 X130.886 Y76.705 E.01521
G1 X131.272 Y77.109 E.01359
G1 X131.489 Y77.47 E.01025
G1 X131.468 Y77.58 E.00272
G1 X131.294 Y77.876 E.00835
G1 X130.307 Y78.82 E.03322
G1 X130.25 Y78.952 E.0035
G1 X130.24 Y81.703 E.06692
G1 X130.197 Y82.261 E.01361
G1 X130.072 Y82.811 E.01372
G1 X129.862 Y83.347 E.014
G1 X129.575 Y83.842 E.01392
G1 X129.226 Y84.278 E.01358
G1 X128.796 Y84.675 E.01424
G1 X128.298 Y85.01 E.0146
G1 X127.827 Y85.241 E.01276
G1 X127.287 Y85.406 E.01373
G1 X126.731 Y85.489 E.01367
G1 X120.85 Y85.5 E.14305
G1 X120.85 Y85.196 E.00739
G1 X120.787 Y85.058 E.00369
G1 X120.667 Y85.013 E.00312
G1 X110.333 Y85.013 E.25136
G1 X110.253 Y85.032 E.002
G1 X110.15 Y85.196 E.00471
G1 X110.15 Y85.44 E.00594
G1 X109.95 Y84.83 F9000
;TYPE:Perimeter
G1 F6000
G1 X109.812 Y85.134 E.00812
G1 X105.365 Y85.134 E.10817
G1 X104.309 Y85.115 E.02569
G1 X103.807 Y85.042 E.01234
G1 X103.205 Y84.845 E.01541
G1 X102.621 Y84.539 E.01604
G1 X102.138 Y84.138 E.01527
G1 X101.713 Y83.631 E.01609
G1 X101.486 Y83.245 E.01089
G1 X101.272 Y82.716 E.01388
G1 X101.127 Y81.942 E.01915
G1 X101.116 Y78.95 E.07278
G1 X101.081 Y78.759 E.00472
G1 X100.938 Y78.548 E.0062
G1 X100.241 Y77.908 E.02302
G1 X99.899 Y77.515 E.01267
G1 X99.948 Y77.419 E.00262
G1 X100.241 Y77.102 E.0105
G1 X100.718 Y76.65 E.01598
G1 X130.282 Y76.65 E.71911
G1 X130.63 Y76.967 E.01145
G1 X131.007 Y77.362 E.01328
G1 X131.101 Y77.515 E.00437
G1 X131.015 Y77.637 E.00363
G1 X130.054 Y78.556 E.03234
G1 X129.918 Y78.764 E.00604
G1 X129.884 Y78.95 E.0046
G1 X129.873 Y81.952 E.07302
G1 X129.797 Y82.46 E.01249
G1 X129.646 Y82.953 E.01254
G1 X129.421 Y83.419 E.01259
G1 X129.13 Y83.844 E.01253
G1 X128.785 Y84.216 E.01234
G1 X128.18 Y84.655 E.01818
G1 X127.698 Y84.898 E.01313
G1 X127.206 Y85.048 E.01251
G1 X126.703 Y85.123 E.01237
G1 X121.187 Y85.133 E.13417
G1 X121.028 Y84.783 E.00935
G1 X120.907 Y84.703 E.00353
G1 X120.667 Y84.648 E.00599
G1 X110.333 Y84.648 E.25136
G1 X110.238 Y84.656 E.00232
G1 X109.979 Y84.78 E.00698
G1 X109.979 Y84.78 F9000
G1 X109.696 Y84.584
G1 F6000
G1 X109.613 Y84.769 E.00493
G1 X104.416 Y84.756 E.12641
G1 X103.888 Y84.685 E.01296
G1 X103.342 Y84.506 E.01398
G1 X102.832 Y84.238 E.01401
G1 X102.397 Y83.878 E.01373
G1 X102.145 Y83.577 E.00955
G1 X101.815 Y83.083 E.01445
G1 X101.625 Y82.613 E.01233
G1 X101.492 Y81.907 E.01747
G1 X101.481 Y78.949 E.07195
G1 X101.423 Y78.631 E.00786
G1 X101.184 Y78.278 E.01037
G1 X100.362 Y77.505 E.02745
G1 X100.86 Y77.016 E.01698
G1 X130.14 Y77.016 E.71221
G1 X130.631 Y77.498 E.01674
G1 X129.801 Y78.292 E.02794
G1 X129.574 Y78.638 E.01007
G1 X129.519 Y78.949 E.00768
G1 X129.509 Y81.701 E.06694
G1 X129.44 Y82.378 E.01655
G1 X129.203 Y83.029 E.01685
G1 X128.844 Y83.615 E.01672
G1 X128.34 Y84.103 E.01706
G1 X127.817 Y84.445 E.0152
G1 X127.342 Y84.625 E.01236
G1 X126.676 Y84.758 E.01652
G1 X121.386 Y84.767 E.12867
G1 X121.268 Y84.507 E.00695
G1 X120.942 Y84.324 E.00909
G1 X120.667 Y84.282 E.00677
G1 X110.333 Y84.282 E.25136
G1 X110.057 Y84.324 E.00679
G1 X109.731 Y84.508 E.00911
G1 X109.721 Y84.529 E.00057
G1 X109.721 Y84.529 F9000
G1 X109.448 Y84.326
G1 F6000
G1 X109.413 Y84.403 E.00206
G1 X104.703 Y84.403 E.11457
G1 X104.152 Y84.37 E.01343
G1 X103.557 Y84.198 E.01507
G1 X103.042 Y83.938 E.01403
G1 X102.656 Y83.618 E.0122
G1 X102.223 Y83.056 E.01726
G1 X101.978 Y82.51 E.01456
G1 X101.858 Y81.872 E.01579
G1 X101.847 Y78.948 E.07112
G1 X101.765 Y78.502 E.01103
G1 X101.431 Y78.008 E.0145
G1 X100.881 Y77.504 E.01815
G1 X101.001 Y77.382 E.00416
G1 X129.958 Y77.382 E.70435
G1 X130.114 Y77.486 E.00456
G1 X129.548 Y78.027 E.01904
G1 X129.231 Y78.512 E.01409
G1 X129.153 Y78.948 E.01077
G1 X129.143 Y81.699 E.06692
G1 X129.082 Y82.297 E.01462
G1 X128.874 Y82.87 E.01483
G1 X128.557 Y83.387 E.01475
G1 X128.112 Y83.817 E.01505
G1 X127.65 Y84.119 E.01343
G1 X127.235 Y84.275 E.01078
G1 X126.648 Y84.392 E.01456
G1 X121.586 Y84.401 E.12313
G1 X121.509 Y84.232 E.00452
G1 X121.051 Y83.975 E.01277
G1 X120.667 Y83.916 E.00945
G1 X110.333 Y83.916 E.25136
G1 X110.137 Y83.931 E.00478
G1 X109.771 Y84.046 E.00933
G1 X109.49 Y84.233 E.00821
G1 X109.473 Y84.271 E.00101
G1 X109.473 Y84.271 F9000
G1 X109.193 Y84.037
G1 F6000
G1 X105.365 Y84.037 E.09311
G1 X104.39 Y84.021 E.02372
G1 X103.879 Y83.933 E.01261
G1 X103.377 Y83.71 E.01336
G1 X102.915 Y83.357 E.01414
G1 X102.538 Y82.871 E.01496
G1 X102.33 Y82.407 E.01237
G1 X102.223 Y81.837 E.01411
G1 X102.213 Y78.946 E.07032
G1 X102.107 Y78.374 E.01415
G1 X101.684 Y77.747 E.0184
G1 X129.312 Y77.747 E.67202
G1 X128.888 Y78.387 E.01867
G1 X128.787 Y78.946 E.01382
G1 X128.78 Y80.899 E.04751
G1 X128.75 Y82.044 E.02786
G1 X128.622 Y82.552 E.01274
G1 X128.367 Y83.017 E.0129
G1 X128.037 Y83.409 E.01246
G1 X127.557 Y83.749 E.01431
G1 X127.128 Y83.925 E.01128
G1 X126.621 Y84.027 E.01258
G1 X121.785 Y84.035 E.11763
G1 X121.749 Y83.956 E.00211
G1 X121.387 Y83.717 E.01055
G1 X121.161 Y83.627 E.00592
G1 X120.667 Y83.551 E.01216
G1 X110.333 Y83.551 E.25136
G1 X110.081 Y83.57 E.00615
G1 X109.61 Y83.718 E.01201
G1 X109.249 Y83.958 E.01054
G1 X109.23 Y84.001 E.00114
G1 E-5 F3600
G1 X109.23 Y84.001 F9000
G1 X102.177 Y78.29
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X102.445 Y78.022 E.00922
G1 X102.964 Y78.022 E.01262
G1 X102.419 Y78.567 E.01875
G1 X102.487 Y79.017 E.01107
G1 X103.482 Y78.022 E.03423
G1 X104.001 Y78.022 E.01262
G1 X102.489 Y79.533 E.05199
G1 X102.491 Y80.05 E.01258
G1 X104.519 Y78.022 E.06976
G1 X105.038 Y78.022 E.01262
G1 X102.493 Y80.567 E.08755
G1 X102.495 Y81.083 E.01255
G1 X105.556 Y78.022 E.1053
G1 X106.075 Y78.022 E.01262
G1 X102.497 Y81.6 E.12308
G1 X102.546 Y82.069 E.01147
G1 X106.593 Y78.022 E.13921
G1 X107.112 Y78.022 E.01262
G1 X102.655 Y82.478 E.1533
G1 X102.828 Y82.823 E.00939
G1 X107.63 Y78.022 E.16517
G1 X108.149 Y78.022 E.01262
G1 X103.063 Y83.107 E.17494
G1 X103.337 Y83.351 E.00892
G1 X108.667 Y78.022 E.18333
G1 X109.186 Y78.022 E.01262
G1 X103.658 Y83.549 E.19014
G1 X104.038 Y83.688 E.00984
G1 X109.704 Y78.022 E.19491
G1 X110.223 Y78.022 E.01262
G1 X104.491 Y83.753 E.19716
G1 X105 Y83.763 E.01238
G1 X110.741 Y78.022 E.19749
G1 X111.259 Y78.022 E.0126
G1 X105.518 Y83.763 E.19749
G1 X106.037 Y83.763 E.01262
G1 X111.778 Y78.022 E.19749
G1 X112.296 Y78.022 E.0126
G1 X106.555 Y83.763 E.19749
G1 X107.074 Y83.763 E.01262
G1 X112.815 Y78.022 E.19749
G1 X113.333 Y78.022 E.0126
G1 X107.592 Y83.763 E.19749
G1 X108.111 Y83.763 E.01262
G1 X113.852 Y78.022 E.19749
G1 X114.37 Y78.022 E.0126
G1 X108.629 Y83.763 E.19749
G1 X109.05 Y83.763 E.01024
G1 X109.342 Y83.569 E.00853
G1 X114.889 Y78.022 E.19081
G1 X115.407 Y78.022 E.0126
G1 X110.138 Y83.291 E.18125
G1 X110.671 Y83.276 E.01297
G1 X115.926 Y78.022 E.18075
G1 X116.444 Y78.022 E.0126
G1 X111.19 Y83.276 E.18073
G1 X111.708 Y83.276 E.0126
G1 X116.963 Y78.022 E.18075
G1 X117.481 Y78.022 E.0126
G1 X112.227 Y83.276 E.18073
G1 X112.745 Y83.276 E.0126
G1 X118 Y78.022 E.18075
G1 X118.518 Y78.022 E.0126
G1 X113.264 Y83.276 E.18073
G1 X113.782 Y83.276 E.0126
G1 X119.037 Y78.022 E.18075
G1 X119.555 Y78.022 E.0126
G1 X114.301 Y83.276 E.18073
G1 X114.819 Y83.276 E.0126
G1 X120.074 Y78.022 E.18075
G1 X120.592 Y78.022 E.0126
G1 X115.338 Y83.276 E.18073
G1 X115.856 Y83.276 E.0126
G1 X121.111 Y78.022 E.18075
G1 X121.629 Y78.022 E.0126
G1 X116.375 Y83.276 E.18073
G1 X116.893 Y83.276 E.0126
G1 X122.148 Y78.022 E.18075
G1 X122.666 Y78.022 E.0126
G1 X117.412 Y83.276 E.18073
G1 X117.93 Y83.276 E.0126
G1 X123.185 Y78.022 E.18075
G1 X123.703 Y78.022 E.0126
G1 X118.449 Y83.276 E.18073
G1 X118.967 Y83.276 E.0126
G1 X124.222 Y78.022 E.18075
G1 X124.74 Y78.022 E.0126
G1 X119.485 Y83.276 E.18075
G1 X120.004 Y83.276 E.01262
G1 X125.259 Y78.022 E.18075
G1 X125.777 Y78.022 E.0126
G1 X120.522 Y83.276 E.18075
G1 X121.008 Y83.31 E.01185
G1 X126.296 Y78.022 E.1819
G1 X126.814 Y78.022 E.0126
G1 X121.406 Y83.43 E.18603
G1 X121.735 Y83.62 E.00924
G1 X127.333 Y78.022 E.19257
G1 X127.851 Y78.022 E.0126
G1 X122.112 Y83.76 E.1974
G1 X122.632 Y83.76 E.01265
G1 X128.37 Y78.022 E.19738
G1 X128.804 Y78.022 E.01056
G1 X128.646 Y78.264 E.00703
G1 X123.151 Y83.759 E.18902
G1 X123.671 Y83.758 E.01265
G1 X128.518 Y78.91 E.16675
G1 X128.511 Y79.435 E.01277
G1 X124.19 Y83.757 E.14866
G1 X124.709 Y83.756 E.01262
G1 X128.509 Y79.956 E.13072
G1 X128.508 Y80.476 E.01265
G1 X125.229 Y83.755 E.1128
G1 X125.748 Y83.754 E.01262
G1 X128.506 Y80.997 E.09486
G1 X128.504 Y81.517 E.01265
G1 X126.268 Y83.753 E.07692
G1 X126.819 Y83.72 E.01343
G1 X128.469 Y82.07 E.05676
G1 X128.365 Y82.451 E.00961
G1 X128.056 Y82.986 E.01503
G1 X127.306 Y83.752 E.02608
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X128.056 Y82.986 E-.50922
G1 X128.365 Y82.451 E-.29347
G1 X128.469 Y82.07 E-.1876
G1 X127.71 Y82.829 E-.50971
;WIPE_END
G1 X127.006 Y85.105 F9000
G1 X126.544 Y86.599
G1 X125.937 Y88.151
G1 X125.937 Y88.558
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X125.961 Y88.569 E.00064
G1 X126 Y88.683 E.00293
G1 X126 Y89.056 E.00907
G1 X126.422 Y89.441 E.01389
G1 X126.801 Y89.828 E.01318
G1 X127.092 Y90.285 E.01318
G1 X127.119 Y90.618 E.00813
G1 X126.825 Y91.141 E.01459
G1 X126.43 Y91.552 E.01387
G1 X126 Y91.944 E.01415
G1 X126 Y92.589 E.01569
G1 X139.201 Y92.589 E.3211
G1 X139.581 Y92.706 E.00967
G1 X139.758 Y92.878 E.006
G1 X139.867 Y93.102 E.00606
G1 X139.9 Y93.321 E.00539
G1 X139.9 Y95.508 E.0532
G1 X139.848 Y95.784 E.00683
G1 X139.706 Y96.01 E.00649
G1 X139.41 Y96.205 E.00862
G1 X138.996 Y96.239 E.0101
G1 X136.7 Y96.239 E.05585
G1 X136.7 Y103.098 E.16684
G1 X139.248 Y103.105 E.06198
G1 X139.47 Y103.201 E.00588
G1 X139.698 Y103.553 E.0102
G1 X139.762 Y104.021 E.01149
G1 X139.698 Y104.447 E.01048
G1 X139.47 Y104.799 E.0102
G1 X139.248 Y104.895 E.00588
G1 X136.7 Y104.902 E.06198
G1 X136.7 Y111.098 E.15071
G1 X139.248 Y111.105 E.06198
G1 X139.47 Y111.201 E.00588
G1 X139.698 Y111.553 E.0102
G1 X139.762 Y112.021 E.01149
G1 X139.698 Y112.447 E.01048
G1 X139.47 Y112.799 E.0102
G1 X139.248 Y112.895 E.00588
G1 X136.7 Y112.902 E.06198
G1 X136.7 Y119.098 E.15071
G1 X139.248 Y119.105 E.06198
G1 X139.47 Y119.201 E.00588
G1 X139.698 Y119.553 E.0102
G1 X139.762 Y120.021 E.01149
G1 X139.698 Y120.447 E.01048
G1 X139.47 Y120.799 E.0102
G1 X139.248 Y120.895 E.00588
G1 X136.7 Y120.902 E.06198
G1 X136.7 Y127.098 E.15071
G1 X139.248 Y127.105 E.06198
G1 X139.36 Y127.143 E.00288
G1 X139.631 Y127.395 E.009
G1 X139.753 Y127.835 E.01111
G1 X139.721 Y128.37 E.01304
G1 X139.542 Y128.728 E.00974
G1 X139.336 Y128.873 E.00613
G1 X138.993 Y128.896 E.00836
G1 X136.7 Y128.902 E.05578
G1 X136.7 Y132.616 E.09034
G1 X136.642 Y133.679 E.02589
G1 X136.455 Y134.819 E.0281
G1 X136.386 Y135.097 E.00697
G1 X139.202 Y135.099 E.0685
G1 X139.419 Y135.168 E.00554
G1 X139.64 Y135.411 E.00799
G1 X139.753 Y135.835 E.01067
G1 X139.721 Y136.37 E.01304
G1 X139.542 Y136.727 E.00971
G1 X139.275 Y136.885 E.00755
G1 X139.202 Y136.901 E.00182
G1 X135.744 Y136.904 E.08411
G1 X135.517 Y137.367 E.01254
G1 X135.232 Y137.872 E.0141
G1 X134.955 Y138.292 E.01224
G1 X134.404 Y139.047 E.02274
G1 X133.99 Y139.522 E.01533
G1 X133.58 Y139.942 E.01428
G1 X133.011 Y140.451 E.01857
G1 X132.257 Y141.019 E.02296
G1 X131.703 Y141.372 E.01598
G1 X131.162 Y141.672 E.01505
G1 X130.665 Y141.911 E.01341
G1 X128.89 Y142.62 E.04649
G1 X128.128 Y142.869 E.0195
;WIDTH:0.446054
G1 X127.869 Y142.956 E.00748
;WIDTH:0.492109
G1 X127.611 Y143.043 E.00829
G1 X127.875 Y143.068 E.00808
;WIDTH:0.446054
G1 X128.14 Y143.093 E.00729
;WIDTH:0.399999
G1 X139.202 Y143.099 E.26907
G1 X139.419 Y143.168 E.00554
G1 X139.64 Y143.411 E.00799
G1 X139.753 Y143.835 E.01067
G1 X139.721 Y144.37 E.01304
G1 X139.542 Y144.727 E.00971
G1 X139.275 Y144.885 E.00755
G1 X139.202 Y144.901 E.00182
G1 X125.683 Y144.905 E.32884
G1 X125.538 Y144.833 E.00394
G1 X125.5 Y144.722 E.00285
G1 X125.5 Y143.274 E.03522
G1 X125.515 Y143.204 E.00174
;WIDTH:0.397057
G1 X125.653 Y143.101 E.00415
;WIDTH:0.399999
G1 X125.464 Y142.969 E.00561
G1 X125.352 Y142.848 E.00401
G1 X125.026 Y142.8 E.00802
G1 X120.483 Y142.8 E.1105
G1 X120.35 Y142.743 E.00352
G1 X120.3 Y142.617 E.0033
G1 X120.3 Y142.226 E.00951
G1 X110.7 Y142.226 E.23351
G1 X110.7 Y142.617 E.00951
G1 X110.61 Y142.775 E.00442
G1 X109.587 Y142.8 E.02489
G1 X105.819 Y142.8 E.09165
G1 X105.62 Y142.882 E.00524
G1 X105.5 Y143.023 E.0045
;WIDTH:0.397076
G1 X105.347 Y143.101 E.00414
;WIDTH:0.399999
G1 X105.496 Y143.237 E.00491
G1 X105.5 Y143.274 E.00091
G1 X105.5 Y144.722 E.03522
G1 X105.437 Y144.86 E.00369
G1 X105.317 Y144.905 E.00312
G1 X91.798 Y144.901 E.32884
G1 X91.584 Y144.834 E.00545
G1 X91.369 Y144.605 E.00764
G1 X91.247 Y144.165 E.01111
G1 X91.279 Y143.63 E.01304
G1 X91.458 Y143.273 E.00971
G1 X91.725 Y143.115 E.00755
G1 X91.798 Y143.099 E.00182
G1 X102.903 Y143.093 E.27012
;WIDTH:0.40024
G1 X104.075 Y143.092 E.02853
G1 X102.922 Y142.882 E.02853
;WIDTH:0.399999
G1 X102.15 Y142.635 E.01972
G1 X100.666 Y142.052 E.03878
G1 X100.197 Y141.848 E.01244
G1 X99.56 Y141.524 E.01738
G1 X98.757 Y141.029 E.02295
G1 X98.14 Y140.574 E.01865
G1 X97.642 Y140.149 E.01592
G1 X97.142 Y139.664 E.01694
G1 X96.604 Y139.057 E.01973
G1 X96.229 Y138.569 E.01497
G1 X95.775 Y137.882 E.02003
G1 X95.488 Y137.377 E.01413
G1 X95.256 Y136.904 E.01281
G1 X91.798 Y136.901 E.08411
G1 X91.584 Y136.834 E.00545
G1 X91.369 Y136.605 E.00764
G1 X91.247 Y136.165 E.01111
G1 X91.279 Y135.63 E.01304
G1 X91.458 Y135.273 E.00971
G1 X91.725 Y135.115 E.00755
G1 X94.62 Y135.097 E.07042
G1 X94.449 Y134.332 E.01907
G1 X94.319 Y133.202 E.02767
G1 X94.3 Y132.67 E.01295
G1 X94.3 Y128.903 E.09163
G1 X91.751 Y128.895 E.062
G1 X91.53 Y128.799 E.00586
G1 X91.302 Y128.447 E.0102
G1 X91.238 Y127.979 E.01149
G1 X91.302 Y127.553 E.01048
G1 X91.53 Y127.201 E.0102
G1 X91.752 Y127.105 E.00588
G1 X94.3 Y127.098 E.06198
G1 X94.3 Y120.902 E.15071
G1 X91.752 Y120.895 E.06198
G1 X91.53 Y120.799 E.00588
G1 X91.302 Y120.447 E.0102
G1 X91.238 Y119.979 E.01149
G1 X91.302 Y119.553 E.01048
G1 X91.53 Y119.201 E.0102
G1 X91.752 Y119.105 E.00588
G1 X94.3 Y119.098 E.06198
G1 X94.3 Y112.902 E.15071
G1 X91.752 Y112.895 E.06198
G1 X91.53 Y112.799 E.00588
G1 X91.302 Y112.447 E.0102
G1 X91.238 Y111.979 E.01149
G1 X91.302 Y111.553 E.01048
G1 X91.53 Y111.201 E.0102
G1 X91.752 Y111.105 E.00588
G1 X94.3 Y111.098 E.06198
G1 X94.3 Y104.902 E.15071
G1 X91.752 Y104.895 E.06198
G1 X91.53 Y104.799 E.00588
G1 X91.302 Y104.447 E.0102
G1 X91.238 Y103.979 E.01149
G1 X91.302 Y103.553 E.01048
G1 X91.53 Y103.201 E.0102
G1 X91.752 Y103.105 E.00588
G1 X94.3 Y103.098 E.06198
G1 X94.3 Y96.239 E.16684
G1 X91.798 Y96.239 E.06086
G1 X91.529 Y96.182 E.00669
G1 X91.315 Y96.033 E.00634
G1 X91.133 Y95.727 E.00866
G1 X91.1 Y95.508 E.00539
G1 X91.1 Y93.321 E.0532
G1 X91.153 Y93.044 E.00686
G1 X91.295 Y92.818 E.00649
G1 X91.591 Y92.623 E.00862
G1 X91.798 Y92.589 E.0051
G1 X105 Y92.589 E.32113
G1 X105 Y91.944 E.01569
G1 X104.578 Y91.559 E.01389
G1 X104.199 Y91.172 E.01318
G1 X103.908 Y90.715 E.01318
G1 X103.881 Y90.382 E.00813
G1 X104.175 Y89.859 E.01459
G1 X104.57 Y89.448 E.01387
G1 X105 Y89.056 E.01415
G1 X105.018 Y88.605 E.01098
G1 X105.151 Y88.503 E.00408
G1 X125.817 Y88.5 E.50268
G1 X125.883 Y88.532 E.00178
G1 X125.883 Y88.532 F9000
G1 X126.194 Y88.305
;TYPE:Perimeter
G1 F6000
G1 X126.267 Y88.374 E.00244
G1 X126.353 Y88.583 E.0055
G1 X126.363 Y88.892 E.00752
G1 X126.751 Y89.256 E.01294
G1 X127.107 Y89.624 E.01245
G1 X127.422 Y90.127 E.01444
G1 X127.484 Y90.602 E.01165
G1 X127.4 Y90.912 E.00781
G1 X127.085 Y91.399 E.01411
G1 X126.366 Y92.142 E.02515
G1 X126.366 Y92.224 E.00199
G1 X139.201 Y92.224 E.3122
G1 X139.662 Y92.341 E.01157
G1 X139.994 Y92.593 E.01014
;WIDTH:0.438921
G1 X140.079 Y92.746 E.00471
;WIDTH:0.477843
G1 X140.163 Y92.899 E.00515
;WIDTH:0.516765
G1 X140.248 Y93.051 E.00559
;WIDTH:0.555687
G1 X140.333 Y93.204 E.00607
G1 X140.336 Y93.262 E.00201
;WIDTH:0.549097
G1 X140.34 Y95.508 E.07691
;WIDTH:0.546881
G1 X140.28 Y95.663 E.00567
;WIDTH:0.497921
G1 X140.22 Y95.818 E.00513
;WIDTH:0.44896
G1 X140.16 Y95.973 E.00458
;WIDTH:0.399999
G1 X139.91 Y96.313 E.01027
G1 X139.469 Y96.566 E.01237
G1 X138.996 Y96.605 E.01154
G1 X137.066 Y96.605 E.04695
G1 X137.066 Y102.733 E.14906
G1 X139.249 Y102.739 E.0531
G1 X139.536 Y102.823 E.00727
G1 X139.861 Y103.094 E.01029
G1 X140.038 Y103.432 E.00928
G1 X140.124 Y103.926 E.0122
G1 X140.082 Y104.433 E.01237
G1 X139.866 Y104.896 E.01243
G1 X139.624 Y105.13 E.00819
G1 X139.249 Y105.261 E.00966
G1 X137.066 Y105.267 E.0531
G1 X137.066 Y110.733 E.13295
G1 X139.249 Y110.739 E.0531
G1 X139.536 Y110.823 E.00727
G1 X139.861 Y111.094 E.01029
G1 X140.038 Y111.432 E.00928
G1 X140.124 Y111.926 E.0122
G1 X140.082 Y112.433 E.01237
G1 X139.866 Y112.896 E.01243
G1 X139.624 Y113.13 E.00819
G1 X139.249 Y113.261 E.00966
G1 X137.066 Y113.267 E.0531
G1 X137.066 Y118.733 E.13295
G1 X139.249 Y118.739 E.0531
G1 X139.536 Y118.823 E.00727
G1 X139.861 Y119.094 E.01029
G1 X140.038 Y119.432 E.00928
G1 X140.124 Y119.926 E.0122
G1 X140.082 Y120.433 E.01237
G1 X139.866 Y120.896 E.01243
G1 X139.624 Y121.13 E.00819
G1 X139.249 Y121.261 E.00966
G1 X137.066 Y121.267 E.0531
G1 X137.066 Y126.733 E.13295
G1 X139.249 Y126.739 E.0531
G1 X139.583 Y126.853 E.00858
G1 X139.83 Y127.055 E.00776
G1 X139.983 Y127.295 E.00692
G1 X140.119 Y127.824 E.01329
G1 X140.081 Y128.433 E.01484
G1 X139.865 Y128.899 E.01249
G1 X139.624 Y129.13 E.00812
G1 X139.249 Y129.261 E.00966
G1 X137.066 Y129.267 E.0531
G1 X137.066 Y132.616 E.08146
G1 X137.003 Y133.738 E.02733
G1 X136.836 Y134.732 E.02452
G1 X139.279 Y134.742 E.05942
G1 X139.669 Y134.902 E.01025
G1 X139.871 Y135.1 E.00688
G1 X139.993 Y135.315 E.00601
G1 X140.119 Y135.824 E.01275
G1 X140.081 Y136.433 E.01484
G1 X139.866 Y136.898 E.01246
G1 X139.588 Y137.146 E.00906
G1 X139.202 Y137.266 E.00983
G1 X135.972 Y137.27 E.07857
G1 X135.55 Y138.052 E.02161
G1 X135.258 Y138.496 E.01293
G1 X134.694 Y139.27 E.02329
G1 X134.266 Y139.762 E.01586
G1 X133.841 Y140.198 E.01481
G1 X133.255 Y140.723 E.01914
G1 X132.477 Y141.311 E.02372
G1 X131.9 Y141.68 E.01666
G1 X131.34 Y141.992 E.01559
G1 X130.823 Y142.241 E.01396
G1 X129.606 Y142.728 E.03188
G1 X139.202 Y142.734 E.23341
G1 X139.348 Y142.756 E.00359
G1 X139.669 Y142.902 E.00858
G1 X139.871 Y143.1 E.00688
G1 X139.993 Y143.315 E.00601
G1 X140.119 Y143.824 E.01275
G1 X140.081 Y144.434 E.01487
G1 X139.866 Y144.898 E.01244
G1 X139.588 Y145.146 E.00906
G1 X139.202 Y145.266 E.00983
G1 X125.683 Y145.27 E.32884
G1 X125.425 Y145.201 E.0065
G1 X125.219 Y145.003 E.00695
G1 X125.134 Y144.722 E.00714
G1 X125.134 Y143.274 E.03522
G1 X125.149 Y143.181 E.00229
G1 X125.026 Y143.166 E.00301
G1 X120.429 Y143.162 E.11182
G1 X120.102 Y143.011 E.00876
G1 X119.908 Y142.591 E.01125
G1 X111.066 Y142.591 E.21507
G1 X110.952 Y142.937 E.00886
G1 X110.866 Y143.032 E.00312
G1 X110.571 Y143.162 E.00784
G1 X105.868 Y143.166 E.1144
G1 X105.866 Y144.722 E.03785
G1 X105.772 Y145.021 E.00762
G1 X105.569 Y145.203 E.00663
G1 X105.317 Y145.27 E.00634
G1 X91.798 Y145.266 E.32884
G1 X91.393 Y145.139 E.01032
G1 X91.145 Y144.921 E.00803
G1 X91.017 Y144.705 E.00611
G1 X90.884 Y144.207 E.01254
G1 X90.914 Y143.609 E.01456
G1 X91.132 Y143.107 E.01331
G1 X91.412 Y142.854 E.00918
G1 X91.798 Y142.734 E.00983
G1 X101.388 Y142.728 E.23327
G1 X100.051 Y142.183 E.03512
G1 X99.394 Y141.85 E.01792
G1 X98.565 Y141.34 E.02367
G1 X97.923 Y140.868 E.01938
G1 X97.405 Y140.428 E.01653
G1 X96.888 Y139.926 E.01753
G1 X96.331 Y139.3 E.02038
G1 X95.939 Y138.792 E.01561
G1 X95.456 Y138.063 E.02127
G1 X95.032 Y137.27 E.02187
G1 X91.798 Y137.266 E.07866
G1 X91.393 Y137.139 E.01032
G1 X91.145 Y136.921 E.00803
G1 X91.017 Y136.705 E.00611
G1 X90.884 Y136.207 E.01254
G1 X90.914 Y135.609 E.01456
G1 X91.132 Y135.107 E.01331
G1 X91.412 Y134.854 E.00918
G1 X91.798 Y134.734 E.00983
G1 X94.163 Y134.732 E.05753
G1 X94.092 Y134.413 E.00795
G1 X93.955 Y133.244 E.02863
G1 X93.936 Y132.73 E.01251
G1 X93.934 Y129.268 E.08421
G1 X91.75 Y129.261 E.05312
G1 X91.464 Y129.177 E.00725
G1 X91.139 Y128.906 E.01029
G1 X90.962 Y128.568 E.00928
G1 X90.876 Y128.074 E.0122
G1 X90.934 Y127.52 E.01355
G1 X91.17 Y127.053 E.01273
G1 X91.376 Y126.87 E.0067
G1 X91.751 Y126.739 E.00966
G1 X93.934 Y126.733 E.0531
G1 X93.934 Y121.267 E.13295
G1 X91.751 Y121.261 E.0531
G1 X91.464 Y121.177 E.00727
G1 X91.139 Y120.906 E.01029
G1 X90.962 Y120.568 E.00928
G1 X90.876 Y120.074 E.0122
G1 X90.934 Y119.52 E.01355
G1 X91.17 Y119.053 E.01273
G1 X91.376 Y118.87 E.0067
G1 X91.751 Y118.739 E.00966
G1 X93.934 Y118.733 E.0531
G1 X93.934 Y113.267 E.13295
G1 X91.751 Y113.261 E.0531
G1 X91.464 Y113.177 E.00727
G1 X91.139 Y112.906 E.01029
G1 X90.962 Y112.568 E.00928
G1 X90.876 Y112.074 E.0122
G1 X90.934 Y111.52 E.01355
G1 X91.17 Y111.053 E.01273
G1 X91.376 Y110.87 E.0067
G1 X91.751 Y110.739 E.00966
G1 X93.934 Y110.733 E.0531
G1 X93.934 Y105.267 E.13295
G1 X91.751 Y105.261 E.0531
G1 X91.464 Y105.177 E.00727
G1 X91.139 Y104.906 E.01029
G1 X90.962 Y104.568 E.00928
G1 X90.876 Y104.074 E.0122
G1 X90.934 Y103.52 E.01355
G1 X91.17 Y103.053 E.01273
G1 X91.376 Y102.87 E.0067
G1 X91.751 Y102.739 E.00966
G1 X93.934 Y102.733 E.0531
G1 X93.934 Y96.605 E.14906
G1 X92.001 Y96.605 E.04702
G1 X91.477 Y96.549 E.01282
G1 X91.136 Y96.359 E.0095
;WIDTH:0.404937
G1 X90.828 Y95.944 E.01274
;WIDTH:0.454192
G1 X90.773 Y95.818 E.00384
;WIDTH:0.503447
G1 X90.718 Y95.693 E.00426
;WIDTH:0.552702
G1 X90.663 Y95.567 E.00474
G1 X90.659 Y93.321 E.07745
;WIDTH:0.550503
G1 X90.704 Y93.204 E.0043
;WIDTH:0.512877
G1 X90.75 Y93.088 E.00397
;WIDTH:0.475251
G1 X90.795 Y92.971 E.00368
;WIDTH:0.437625
G1 X90.84 Y92.855 E.00334
;WIDTH:0.399999
G1 X91.091 Y92.515 E.01028
G1 X91.531 Y92.263 E.01233
G1 X91.798 Y92.224 E.00656
G1 X104.634 Y92.224 E.31222
G1 X104.608 Y92.081 E.00354
G1 X103.887 Y91.364 E.02473
G1 X103.598 Y90.909 E.01311
G1 X103.515 Y90.618 E.00736
G1 X103.521 Y90.333 E.00693
G1 X103.594 Y90.099 E.00596
G1 X103.865 Y89.665 E.01245
G1 X104.244 Y89.259 E.01351
G1 X104.635 Y88.894 E.01301
G1 X104.659 Y88.542 E.00858
G1 X104.806 Y88.285 E.0072
G1 X105.183 Y88.134 E.00988
G1 X125.817 Y88.134 E.5019
G1 X126.1 Y88.216 E.00717
G1 X126.151 Y88.264 E.0017
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X126.194 Y88.305 E-.02822
G1 X126.267 Y88.374 E-.04771
G1 X126.353 Y88.583 E-.10735
G1 X126.363 Y88.892 E-.14685
G1 X126.751 Y89.256 E-.25271
G1 X127.107 Y89.624 E-.24321
G1 X127.422 Y90.127 E-.28191
G1 X127.484 Y90.602 E-.22754
G1 X127.4 Y90.912 E-.15256
G1 X127.386 Y90.933 E-.01194
;WIPE_END
G1 X104.075 Y143.092 F9000
G1 E5 F2400
;WIDTH:0.40024
G1 F6000
G1 X104.106 Y143.093 E.00075
;WIDTH:0.39727
G1 X105.319 Y143.1 E.02929
;WIDTH:0.385098
G1 X105.347 Y143.101 E.00065
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X105.319 Y143.1 E-.01331
G1 X104.106 Y143.093 E-.57618
G1 X104.075 Y143.092 E-.01473
;WIPE_END
G1 E-.89578 F3600
G1 X104.07 Y143.227 F9000
G1 X105.354 Y143.237
G1 X105.765 Y144.113
G1 X105.849 Y144.348
G1 X105.849 Y145.254
G1 X104.44 Y145.252
G1 X105.436 Y150.747
G1 X105.437 Y151.154
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.462 Y151.167 E.00069
G1 X105.5 Y151.278 E.00285
G1 X105.5 Y152.722 E.03512
G1 X105.443 Y152.854 E.0035
G1 X105.317 Y152.905 E.00331
G1 X95.461 Y152.902 E.23974
G1 X91.798 Y152.901 E.0891
G1 X91.584 Y152.834 E.00545
G1 X91.369 Y152.605 E.00764
G1 X91.247 Y152.165 E.01111
G1 X91.279 Y151.63 E.01304
G1 X91.458 Y151.273 E.00971
G1 X91.725 Y151.115 E.00755
G1 X91.798 Y151.099 E.00182
G1 X105.317 Y151.095 E.32884
G1 X105.383 Y151.128 E.00179
G1 X105.383 Y151.128 F9000
G1 X105.693 Y150.896
;TYPE:Perimeter
G1 F6000
G1 X105.732 Y150.92 E.00111
G1 X105.863 Y151.235 E.0083
G1 X105.866 Y152.721 E.03615
G1 X105.799 Y152.984 E.0066
G1 X105.581 Y153.195 E.00738
G1 X105.317 Y153.27 E.00668
G1 X92.545 Y153.267 E.31067
G1 X91.571 Y153.23 E.02371
;WIDTH:0.400455
G1 X91.193 Y152.972 E.01115
;WIDTH:0.449282
G1 X91.156 Y152.969 E.00102
;WIDTH:0.498109
G1 X91.119 Y152.965 E.00115
;WIDTH:0.546936
G1 X91.083 Y152.961 E.00124
G1 X90.954 Y152.719 E.00935
;WIDTH:0.542627
G1 X90.819 Y152.217 E.01758
;WIDTH:0.556673
G1 X90.805 Y152.132 E.00299
G1 X90.829 Y152.073 E.00221
;WIDTH:0.517505
G1 X90.854 Y152.014 E.00206
;WIDTH:0.478336
G1 X90.878 Y151.955 E.00188
;WIDTH:0.439168
G1 X90.903 Y151.895 E.00175
;WIDTH:0.399999
G1 X90.958 Y151.428 E.01144
G1 X91.175 Y151.049 E.01062
G1 X91.412 Y150.854 E.00747
G1 X91.798 Y150.734 E.00983
G1 X105.317 Y150.73 E.32884
G1 X105.442 Y150.744 E.00306
G1 X105.642 Y150.865 E.00569
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X105.693 Y150.896 E-.02835
G1 X105.732 Y150.92 E-.02175
G1 X105.863 Y151.235 E-.16205
G1 X105.866 Y152.721 E-.70585
G1 X105.799 Y152.984 E-.12892
G1 X105.581 Y153.195 E-.14411
G1 X105.317 Y153.27 E-.13036
G1 X104.941 Y153.27 E-.17861
;WIPE_END
G1 X104.941 Y153.253 F9000
G1 X105.849 Y153.254
G1 X105.849 Y152.824
G1 X125.653 Y143.237
G1 E5 F2400
;WIDTH:0.385048
G1 F6000
G1 X125.683 Y143.1 E.0007
;WIDTH:0.388922
G1 X126.767 Y143.097 E.02557
;WIDTH:0.42393
G1 X127.04 Y143.08 E.00709
;WIDTH:0.458937
G1 X127.313 Y143.063 E.00773
;WIDTH:0.493944
G1 X127.586 Y143.045 E.00836
;WIDTH:0.495486
G1 X127.596 Y143.045 E.00031
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X127.586 Y143.045 E-.00475
G1 X127.313 Y143.063 E-.12996
G1 X127.04 Y143.08 E-.12993
G1 X126.767 Y143.097 E-.12993
G1 X125.683 Y143.1 E-.5149
G1 X125.653 Y143.101 E-.01426
;WIPE_END
G1 E-.57627 F3600
G1 X125.653 Y143.237 F9000
G1 X125.646 Y143.237
G1 X125.234 Y144.115
G1 X125.151 Y144.389
G1 X125.151 Y145.254
G1 X125.627 Y145.253
G1 X125.151 Y151.157
G1 X125.555 Y151.157
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X125.563 Y151.14 E.00046
G1 X125.683 Y151.095 E.00312
G1 X139.202 Y151.099 E.32884
G1 X139.456 Y151.194 E.0066
G1 X139.616 Y151.404 E.00642
G1 X139.72 Y151.62 E.00583
G1 X139.75 Y152.126 E.01233
G1 X139.689 Y152.464 E.00835
G1 X139.503 Y152.776 E.00884
G1 X139.202 Y152.901 E.00793
G1 X125.683 Y152.905 E.32884
G1 X125.557 Y152.854 E.00331
G1 X125.5 Y152.722 E.0035
G1 X125.5 Y151.278 E.03512
G1 X125.53 Y151.211 E.00179
G1 X125.53 Y151.211 F9000
G1 X125.307 Y150.904
;TYPE:Perimeter
G1 F6000
G1 X125.366 Y150.831 E.00228
G1 X125.683 Y150.73 E.00809
G1 X139.202 Y150.734 E.32884
G1 X139.653 Y150.892 E.01162
G1 X139.862 Y151.095 E.00709
G1 X140.038 Y151.432 E.00925
;WIDTH:0.435377
G1 X140.084 Y151.594 E.00449
;WIDTH:0.470755
G1 X140.13 Y151.756 E.00489
;WIDTH:0.506132
G1 X140.176 Y151.917 E.00526
;WIDTH:0.535971
G1 X140.192 Y151.95 E.00122
;WIDTH:0.56581
G1 X140.208 Y151.983 E.0013
G1 X140.125 Y152.508 E.01879
;WIDTH:0.551826
G1 X139.916 Y152.962 E.0172
G1 X139.834 Y153.008 E.00324
;WIDTH:0.51387
G1 X139.752 Y153.054 E.003
;WIDTH:0.475913
G1 X139.67 Y153.1 E.00276
;WIDTH:0.437956
G1 X139.588 Y153.146 E.00252
;WIDTH:0.399999
G1 X139.202 Y153.266 E.00983
G1 X125.683 Y153.27 E.32884
G1 X125.419 Y153.195 E.00668
G1 X125.183 Y152.938 E.00849
G1 X125.134 Y152.722 E.00539
G1 X125.134 Y151.278 E.03512
G1 X125.194 Y151.043 E.0059
G1 X125.269 Y150.95 E.00291
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X125.307 Y150.904 E-.02834
G1 X125.366 Y150.831 E-.04458
G1 X125.683 Y150.73 E-.15803
G1 X128.355 Y150.731 E-1.26905
;WIPE_END
G1 X128.355 Y150.75 F9000
G1 X128.38 Y142.803
G1 X128.591 Y142.769
G1 X128.649 Y142.759
G1 X128.839 Y142.726
G1 X128.918 Y142.711
G1 X129.11 Y142.675
G1 X130.249 Y142.45
G1 X130.466 Y142.375
G1 X130.553 Y142.338
G1 X130.645 Y142.3
G1 X130.738 Y142.26
G1 X130.815 Y142.226
G1 X130.887 Y142.193
G1 X130.957 Y142.161
G1 X131.102 Y142.091
G1 X131.175 Y142.056
G1 X131.247 Y142.02
G1 X131.317 Y141.984
G1 X131.386 Y141.948
G1 X131.616 Y141.825
G1 X131.875 Y141.676
G1 X139.525 Y137.184
G1 X139.74 Y137.038
G1 X139.886 Y136.866
G1 X139.941 Y136.778
G1 X140.052 Y136.507
G1 X140.099 Y136.237
G1 X140.113 Y136
G1 X140.249 Y95.527
G1 X140.249 Y93.301
G1 X140.243 Y93.221
G1 X140.236 Y93.137
G1 X140.191 Y92.959
G1 X140.118 Y92.791
G1 X140.017 Y92.636
G1 X139.89 Y92.5
G1 X139.837 Y92.46
G1 X139.732 Y92.384
G1 X139.565 Y92.304
G1 X126.349 Y88.151
G1 X120.605 Y88.151
G1 X120.362 Y86.599
G1 X120.362 Y86.193
G1 E5 F2400
G1 F6000
G1 X120.342 Y86.183 E.00054
G1 X120.3 Y86.067 E.003
G1 X120.3 Y85.667 E.00973
G1 X110.7 Y85.667 E.23351
G1 X110.7 Y86.067 E.00973
G1 X110.658 Y86.183 E.003
G1 X110.517 Y86.25 E.0038
G1 X104.199 Y86.25 E.15368
G1 X103.618 Y86.209 E.01417
G1 X103.079 Y86.094 E.01341
G1 X102.609 Y85.936 E.01206
G1 X102.092 Y85.681 E.01402
G1 X101.366 Y85.148 E.02191
G1 X100.77 Y84.471 E.02194
G1 X100.465 Y83.947 E.01475
G1 X100.132 Y83.087 E.02243
G1 X100.013 Y82.366 E.01777
G1 X100 Y78.945 E.08321
G1 X99.578 Y78.559 E.01391
G1 X99.199 Y78.172 E.01318
G1 X98.908 Y77.715 E.01318
G1 X98.881 Y77.618 E.00245
G1 X98.908 Y77.285 E.00813
G1 X99.175 Y76.859 E.01223
G1 X99.57 Y76.448 E.01387
G1 X100 Y76.056 E.01415
G1 X100.005 Y75.761 E.00718
G1 X100.058 Y75.67 E.00256
G1 X100.183 Y75.621 E.00327
G1 X130.817 Y75.621 E.74514
G1 X130.942 Y75.67 E.00327
G1 X131 Y75.804 E.00355
G1 X131 Y76.056 E.00613
G1 X131.422 Y76.441 E.01389
G1 X131.801 Y76.828 E.01318
G1 X132.092 Y77.285 E.01318
G1 X132.118 Y77.639 E.00863
G1 X131.825 Y78.141 E.01414
G1 X131.43 Y78.552 E.01387
G1 X131 Y78.945 E.01417
G1 X130.99 Y82.337 E.08251
G1 X130.931 Y82.79 E.01111
G1 X130.688 Y83.634 E.02136
G1 X130.252 Y84.439 E.02227
G1 X129.871 Y84.914 E.01481
G1 X129.431 Y85.323 E.01461
G1 X128.668 Y85.81 E.02202
G1 X128.11 Y86.039 E.01467
G1 X127.628 Y86.164 E.01211
G1 X127.111 Y86.238 E.0127
G1 X120.483 Y86.25 E.16122
G1 X120.416 Y86.219 E.0018
G1 X120.416 Y86.219 F9000
G1 X120.109 Y86.441
;TYPE:Perimeter
G1 F6000
G1 X120.028 Y86.361 E.00277
G1 X119.9 Y86.033 E.00856
G1 X111.066 Y86.033 E.21488
G1 X110.972 Y86.361 E.0083
G1 X110.795 Y86.537 E.00607
G1 X110.517 Y86.616 E.00703
G1 X104.199 Y86.616 E.15368
G1 X103.592 Y86.574 E.0148
G1 X103.003 Y86.451 E.01464
G1 X102.47 Y86.274 E.01366
G1 X101.999 Y86.038 E.01281
G1 X101.089 Y85.387 E.02722
G1 X100.452 Y84.652 E.02366
G1 X100.038 Y83.92 E.02046
G1 X99.772 Y83.149 E.01984
G1 X99.652 Y82.424 E.01787
G1 X99.635 Y79.106 E.08071
G1 X98.891 Y78.369 E.02547
G1 X98.574 Y77.863 E.01452
G1 X98.515 Y77.397 E.01143
G1 X98.6 Y77.088 E.0078
G1 X98.915 Y76.601 E.01411
G1 X99.309 Y76.193 E.0138
G1 X99.634 Y75.894 E.01074
G1 X99.65 Y75.731 E.00398
G1 X99.766 Y75.463 E.0071
G1 X99.867 Y75.366 E.00341
G1 X100.183 Y75.256 E.00814
G1 X130.817 Y75.256 E.74514
G1 X131.133 Y75.366 E.00814
G1 X131.224 Y75.444 E.00292
G1 X131.355 Y75.71 E.00721
G1 X131.362 Y75.892 E.00443
G1 X132.113 Y76.636 E.02571
G1 X132.449 Y77.199 E.01595
G1 X132.48 Y77.66 E.01124
G1 X132.4 Y77.912 E.00643
G1 X132.085 Y78.399 E.01411
G1 X131.691 Y78.807 E.0138
G1 X131.365 Y79.106 E.01076
G1 X131.355 Y82.339 E.07864
G1 X131.294 Y82.835 E.01216
G1 X131.04 Y83.734 E.02272
G1 X130.535 Y84.671 E.02589
G1 X130.118 Y85.184 E.01608
G1 X129.626 Y85.633 E.0162
G1 X128.851 Y86.127 E.02236
G1 X128.248 Y86.378 E.01589
G1 X127.676 Y86.524 E.01436
G1 X127.164 Y86.6 E.01259
G1 X120.483 Y86.616 E.16251
G1 X120.206 Y86.537 E.00701
G1 X120.151 Y86.483 E.00187
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X120.109 Y86.441 E-.02821
G1 X120.028 Y86.361 E-.05408
G1 X119.9 Y86.033 E-.16724
G1 X117.267 Y86.033 E-1.25047
;WIPE_END
G1 X120.151 Y74.208 F9000
G1 E5 F2400
G1 F6000
G1 X135.589 Y74.207 E.37551
G1 X136.198 Y74.242 E.01484
G1 X136.885 Y74.368 E.01699
G1 X137.88 Y74.712 E.02561
G1 X138.795 Y75.227 E.02554
G1 X139.601 Y75.9 E.02554
G1 X140.273 Y76.706 E.02553
G1 X140.788 Y77.62 E.02552
G1 X141.131 Y78.612 E.02553
G1 X141.289 Y79.653 E.02561
G1 X141.289 Y80.022 E.00898
G1 X141.3 Y150.994 E1.72632
G1 X141.258 Y151.692 E.01701
G1 X141.134 Y152.375 E.01688
G1 X140.93 Y153.038 E.01687
G1 X140.648 Y153.672 E.01688
G1 X140.292 Y154.267 E.01687
G1 X139.867 Y154.816 E.01689
G1 X139.381 Y155.309 E.01684
G1 X138.738 Y155.811 E.01984
G1 X138.249 Y156.106 E.01389
G1 X137.533 Y156.432 E.01914
G1 X137.018 Y156.593 E.01312
G1 X136.479 Y156.716 E.01345
G1 X135.827 Y156.79 E.01596
G1 X95.389 Y156.798 E.98361
G1 X94.756 Y156.752 E.01544
G1 X94.066 Y156.619 E.01709
G1 X93.466 Y156.431 E.01529
G1 X92.859 Y156.163 E.01614
G1 X92.161 Y155.742 E.01983
G1 X91.62 Y155.31 E.01684
G1 X91.133 Y154.816 E.01687
G1 X90.708 Y154.267 E.01689
G1 X90.353 Y153.673 E.01683
G1 X89.996 Y152.822 E.02245
G1 X89.793 Y152.035 E.01977
G1 X89.711 Y151.347 E.01685
G1 X89.7 Y80.006 E1.7353
G1 X89.743 Y79.301 E.01718
G1 X89.869 Y78.612 E.01704
G1 X90.077 Y77.943 E.01704
G1 X90.365 Y77.305 E.01703
G1 X90.727 Y76.705 E.01704
G1 X91.159 Y76.154 E.01703
G1 X91.654 Y75.659 E.01703
G1 X92.205 Y75.227 E.01703
G1 X92.804 Y74.865 E.01702
G1 X93.571 Y74.533 E.02033
G1 X94.109 Y74.37 E.01367
G1 X95.153 Y74.211 E.02569
G1 X120.091 Y74.208 E.60659
G1 X120.091 Y74.208 F9000
G1 X120.091 Y74.574
;TYPE:Perimeter
G1 F6000
G1 X135.702 Y74.572 E.37972
G1 X136.201 Y74.625 E.01221
G1 X136.792 Y74.723 E.01457
G1 X137.73 Y75.047 E.02414
G1 X138.586 Y75.53 E.02391
G1 X139.341 Y76.159 E.0239
G1 X139.971 Y76.914 E.02392
G1 X140.454 Y77.771 E.02393
G1 X140.774 Y78.7 E.0239
G1 X140.923 Y79.68 E.02411
G1 X140.923 Y80.022 E.00832
G1 X140.925 Y92.638 E.30687
;WIDTH:0.449699
G1 X140.9 Y92.846 E.00579
;WIDTH:0.499398
G1 X140.876 Y93.054 E.00648
;WIDTH:0.549097
G1 X140.851 Y93.261 E.00714
G1 X140.852 Y95.506 E.07687
;WIDTH:0.546882
G1 X140.853 Y95.612 E.00361
;WIDTH:0.54508
G1 X140.877 Y95.811 E.00681
;WIDTH:0.49672
G1 X140.901 Y96.009 E.00613
;WIDTH:0.44836
G1 X140.926 Y96.208 E.00552
;WIDTH:0.399999
G1 X140.932 Y151.021 E1.33327
;WIDTH:0.409698
G1 X140.885 Y151.658 E.01595
;WIDTH:0.457915
G1 X140.837 Y151.79 E.00396
;WIDTH:0.506132
G1 X140.79 Y151.921 E.00437
;WIDTH:0.555388
G1 X140.501 Y152.924 E.03618
;WIDTH:0.545222
G1 X140.418 Y153.15 E.00818
;WIDTH:0.501745
G1 X140.335 Y153.377 E.00751
;WIDTH:0.458267
G1 X140.253 Y153.603 E.00678
;WIDTH:0.414789
G1 X139.963 Y154.094 E.01443
;WIDTH:0.399999
G1 X139.592 Y154.575 E.01478
G1 X139.137 Y155.036 E.01576
G1 X138.53 Y155.509 E.01872
G1 X138.078 Y155.782 E.01284
G1 X137.402 Y156.089 E.01806
G1 X136.841 Y156.265 E.0143
G1 X136.338 Y156.364 E.01247
G1 X135.806 Y156.425 E.01303
G1 X95.396 Y156.428 E.98293
G1 X94.715 Y156.371 E.01662
G1 X94.072 Y156.238 E.01597
G1 X93.52 Y156.055 E.01415
G1 X92.954 Y155.793 E.01517
G1 X92.31 Y155.392 E.01845
G1 X91.795 Y154.967 E.01624
G1 X91.378 Y154.535 E.0146
G1 X90.974 Y153.999 E.01633
;WIDTH:0.400455
G1 X90.681 Y153.507 E.01395
;WIDTH:0.449282
G1 X90.664 Y153.404 E.00288
;WIDTH:0.498109
G1 X90.647 Y153.301 E.00322
;WIDTH:0.546936
G1 X90.63 Y153.197 E.00359
G1 X90.407 Y152.664 E.0197
;WIDTH:0.556673
G1 X90.291 Y152.174 E.0175
G1 X90.256 Y152.113 E.00244
;WIDTH:0.517505
G1 X90.22 Y152.053 E.00225
;WIDTH:0.478336
G1 X90.185 Y151.992 E.00208
;WIDTH:0.439168
G1 X90.149 Y151.932 E.00188
;WIDTH:0.399999
G1 X90.076 Y151.288 E.01576
G1 X90.068 Y96.284 E1.33792
;WIDTH:0.438175
G1 X90.087 Y96.105 E.00484
;WIDTH:0.476351
G1 X90.106 Y95.926 E.00529
;WIDTH:0.514527
G1 X90.125 Y95.747 E.00575
;WIDTH:0.552702
G1 X90.144 Y95.567 E.00624
G1 X90.143 Y93.322 E.07741
;WIDTH:0.550504
G1 X90.124 Y93.203 E.00414
;WIDTH:0.512878
G1 X90.105 Y93.084 E.00384
;WIDTH:0.475252
G1 X90.086 Y92.964 E.00356
;WIDTH:0.437626
G1 X90.068 Y92.845 E.00323
;WIDTH:0.399999
G1 X90.066 Y80.017 E.31203
G1 X90.106 Y79.345 E.01637
G1 X90.225 Y78.7 E.01595
G1 X90.42 Y78.073 E.01597
G1 X90.689 Y77.475 E.01595
G1 X91.028 Y76.914 E.01594
G1 X91.433 Y76.397 E.01597
G1 X91.897 Y75.933 E.01596
G1 X92.414 Y75.528 E.01597
G1 X92.972 Y75.191 E.01586
G1 X93.697 Y74.877 E.01922
G1 X94.19 Y74.727 E.01253
G1 X95.18 Y74.577 E.02436
G1 X120.031 Y74.574 E.60448
G1 E-5 F3600
G1 X120.031 Y74.574 F9000
G1 X120.031 Y74.549
G1 X92.403 Y75.514
G1 X90.049 Y80.008
G1 X90.049 Y112.646
G1 X90.52 Y112.646
G1 E5 F2400
;WIDTH:0.56691
G1 F6000
G1 X90.498 Y112.394 E.00896
;WIDTH:0.523676
G1 X90.476 Y112.143 E.0082
;WIDTH:0.516506
G1 X90.494 Y111.542 E.01929
G1 E-5 F3600
G1 X90.494 Y111.542 F9000
G1 X90.927 Y111.617
G1 X90.901 Y111.763
G1 X90.887 Y112
G1 X90.901 Y112.237
G1 X90.948 Y112.507
G1 X91.059 Y112.778
G1 X91.114 Y112.866
G1 X91.26 Y113.038
G1 X91.475 Y113.184
G1 X91.643 Y113.234
G1 X91.766 Y113.249
G1 X93.303 Y113.253
G1 X93.57 Y113.253
G1 X93.569 Y113.631
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.569 Y118.369 E.11525
G1 X91.75 Y118.373 E.04425
G1 X91.245 Y118.528 E.01285
G1 X91.055 Y118.651 E.00551
G1 X90.804 Y118.945 E.0094
;WIDTH:0.438433
G1 X90.701 Y119.144 E.00602
;WIDTH:0.476867
G1 X90.598 Y119.343 E.0066
;WIDTH:0.5153
G1 X90.495 Y119.542 E.00717
G1 X90.476 Y119.315 E.00729
;WIDTH:0.476867
G1 X90.456 Y119.089 E.00668
;WIDTH:0.438433
G1 X90.437 Y118.862 E.00612
;WIDTH:0.399999
G1 X90.436 Y113.183 E.13814
;WIDTH:0.441727
G1 X90.457 Y113.049 E.00368
;WIDTH:0.483455
G1 X90.478 Y112.915 E.00405
;WIDTH:0.525183
G1 X90.499 Y112.78 E.00446
;WIDTH:0.56691
G1 X90.52 Y112.646 E.00481
G1 X90.575 Y112.734 E.00368
;WIDTH:0.521058
G1 X90.63 Y112.822 E.00336
;WIDTH:0.475206
G1 X90.796 Y113.036 E.00794
;WIDTH:0.437603
G1 X90.961 Y113.25 E.00725
;WIDTH:0.399999
G1 X91.239 Y113.466 E.00856
G1 X91.439 Y113.564 E.00542
G1 X91.75 Y113.627 E.00772
G1 X93.509 Y113.631 E.04279
G1 X93.509 Y113.631 F9000
G1 X93.203 Y113.996
G1 F6000
G1 X93.203 Y118.004 E.09749
G1 X91.749 Y118.008 E.03537
G1 X91.424 Y118.068 E.00804
G1 X91.114 Y118.187 E.00808
G1 X90.803 Y118.389 E.00902
G1 X90.802 Y113.589 E.11676
G1 X91.015 Y113.755 E.00657
G1 X91.348 Y113.918 E.00902
G1 X91.749 Y113.992 E.00992
G1 X93.143 Y113.996 E.03391
G1 X92.837 Y114.361 F9000
G1 F6000
G1 X92.837 Y117.639 E.07973
G1 X91.748 Y117.642 E.02649
G1 X91.168 Y117.775 E.01447
G1 X91.168 Y114.229 E.08625
G1 X91.257 Y114.273 E.00241
G1 X91.748 Y114.358 E.01212
G1 X92.777 Y114.361 E.02503
G1 E-5 F3600
G1 X92.777 Y114.361 F9000
G1 X90.52 Y120.644
G1 E5 F2400
;WIDTH:0.565472
G1 F6000
G1 X90.499 Y120.394 E.00886
;WIDTH:0.522351
G1 X90.477 Y120.143 E.00818
;WIDTH:0.5153
G1 X90.495 Y119.542 E.01924
G1 E-5 F3600
G1 X93.569 Y126.369 F9000
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X91.75 Y126.373 E.04425
G1 X91.245 Y126.528 E.01285
G1 X91.055 Y126.651 E.00551
G1 X90.804 Y126.945 E.0094
;WIDTH:0.43803
G1 X90.701 Y127.144 E.00602
;WIDTH:0.476061
G1 X90.598 Y127.343 E.00658
;WIDTH:0.514092
G1 X90.496 Y127.542 E.00714
G1 X90.476 Y127.315 E.00727
;WIDTH:0.476061
G1 X90.457 Y127.089 E.00666
;WIDTH:0.43803
G1 X90.438 Y126.862 E.00612
;WIDTH:0.399999
G1 X90.438 Y121.183 E.13814
;WIDTH:0.441368
G1 X90.458 Y121.048 E.0037
;WIDTH:0.482736
G1 X90.479 Y120.914 E.00405
;WIDTH:0.524104
G1 X90.5 Y120.779 E.00445
;WIDTH:0.565472
G1 X90.52 Y120.644 E.00482
G1 X90.575 Y120.733 E.0037
;WIDTH:0.519791
G1 X90.631 Y120.821 E.00337
;WIDTH:0.47411
G1 X90.796 Y121.036 E.00793
;WIDTH:0.437055
G1 X90.961 Y121.25 E.00724
;WIDTH:0.399999
G1 X91.239 Y121.466 E.00856
G1 X91.439 Y121.564 E.00542
G1 X91.75 Y121.627 E.00772
G1 X93.569 Y121.631 E.04425
G1 X93.569 Y126.309 E.11379
G1 X93.569 Y126.309 F9000
G1 X93.203 Y126.004
G1 F6000
G1 X91.749 Y126.008 E.03537
G1 X91.424 Y126.068 E.00804
G1 X91.114 Y126.187 E.00808
G1 X90.804 Y126.388 E.00899
G1 X90.803 Y121.59 E.11671
G1 X91.015 Y121.755 E.00653
G1 X91.348 Y121.918 E.00902
G1 X91.749 Y121.992 E.00992
G1 X93.203 Y121.996 E.03537
G1 X93.203 Y125.944 E.09603
G1 X92.837 Y125.639 F9000
G1 F6000
G1 X91.748 Y125.642 E.02649
G1 X91.17 Y125.774 E.01442
G1 X91.169 Y122.229 E.08623
G1 X91.257 Y122.273 E.00239
G1 X91.748 Y122.358 E.01212
G1 X92.837 Y122.361 E.02649
G1 X92.837 Y125.579 E.07827
G1 E-5 F3600
G1 X92.837 Y125.579 F9000
G1 X91.26 Y126.962
G1 X91.114 Y127.134
G1 X91.059 Y127.222
G1 X90.948 Y127.493
G1 X90.901 Y127.763
G1 X90.887 Y128
G1 X90.901 Y128.237
G1 X90.917 Y128.328
G1 X90.948 Y128.507
G1 X90.521 Y128.646
G1 E5 F2400
;WIDTH:0.564482
G1 F6000
G1 X90.499 Y128.394 E.00892
;WIDTH:0.521249
G1 X90.478 Y128.143 E.00816
;WIDTH:0.514092
G1 X90.496 Y127.542 E.01919
G1 E-5 F3600
G1 X90.496 Y127.542 F9000
G1 X93.719 Y134.367
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X91.798 Y134.368 E.04673
G1 X91.295 Y134.507 E.01269
G1 X91.101 Y134.622 E.00549
G1 X90.8 Y134.954 E.0109
;WIDTH:0.436524
G1 X90.698 Y135.164 E.00625
;WIDTH:0.473048
G1 X90.596 Y135.374 E.00681
;WIDTH:0.509572
G1 X90.494 Y135.584 E.00738
G1 X90.476 Y135.348 E.00748
;WIDTH:0.473048
G1 X90.458 Y135.111 E.00694
;WIDTH:0.436524
G1 X90.44 Y134.875 E.00633
;WIDTH:0.399999
G1 X90.439 Y129.183 E.13845
;WIDTH:0.44112
G1 X90.459 Y129.048 E.00369
;WIDTH:0.482241
G1 X90.48 Y128.914 E.00404
;WIDTH:0.523362
G1 X90.5 Y128.78 E.00441
;WIDTH:0.564482
G1 X90.521 Y128.646 E.00478
G1 X90.576 Y128.733 E.00363
;WIDTH:0.519383
G1 X90.631 Y128.821 E.00335
;WIDTH:0.474284
G1 X90.796 Y129.036 E.00793
;WIDTH:0.437142
G1 X90.961 Y129.25 E.00724
;WIDTH:0.399999
G1 X91.239 Y129.466 E.00856
G1 X91.439 Y129.564 E.00542
G1 X91.749 Y129.627 E.00769
G1 X93.569 Y129.632 E.04427
G1 X93.571 Y132.75 E.07584
G1 X93.592 Y133.287 E.01307
G1 X93.712 Y134.307 E.02498
G1 X93.712 Y134.307 F9000
G1 X93.308 Y134.001
G1 F6000
G1 X92.006 Y134.002 E.03167
G1 X91.506 Y134.05 E.01222
G1 X91.178 Y134.161 E.00842
G1 X90.805 Y134.396 E.01072
G1 X90.804 Y129.591 E.11688
G1 X91.015 Y129.755 E.0065
G1 X91.348 Y129.918 E.00902
G1 X91.748 Y129.992 E.00989
G1 X93.204 Y129.997 E.03542
G1 X93.206 Y132.763 E.06728
G1 X93.229 Y133.329 E.01378
G1 X93.301 Y133.942 E.01501
G1 X93.301 Y133.942 F9000
G1 X92.897 Y133.636
G1 F6000
G1 X91.797 Y133.637 E.02676
G1 X91.171 Y133.777 E.0156
G1 X91.17 Y130.23 E.08628
G1 X91.257 Y130.272 E.00235
G1 X91.747 Y130.358 E.0121
G1 X92.838 Y130.361 E.02654
G1 X92.839 Y132.731 E.05765
G1 X92.893 Y133.576 E.0206
G1 E-5 F3600
G1 X90.482 Y136.278 F9000
G1 E5 F2400
;WIDTH:0.509572
G1 F6000
G1 X90.494 Y135.584 E.02194
G1 E-5 F3600
G1 X90.494 Y135.584 F9000
G1 X90.495 Y143.584
G1 E5 F2400
;WIDTH:0.508366
G1 F6000
G1 X90.477 Y143.348 E.00746
;WIDTH:0.472244
G1 X90.459 Y143.111 E.00692
;WIDTH:0.436122
G1 X90.441 Y142.875 E.00633
;WIDTH:0.399999
G1 X90.44 Y136.83 E.14704
;WIDTH:0.442422
G1 X90.461 Y136.554 E.00751
;WIDTH:0.484844
G1 X90.482 Y136.278 E.0083
G1 X90.499 Y136.328 E.00158
;WIDTH:0.473578
G1 X90.582 Y136.564 E.00731
;WIDTH:0.436789
G1 X90.664 Y136.8 E.00669
;WIDTH:0.399999
G1 X90.836 Y137.117 E.00877
G1 X91.094 Y137.377 E.00891
G1 X91.516 Y137.584 E.01143
G1 X91.797 Y137.632 E.00693
G1 X94.813 Y137.635 E.07336
G1 X95.151 Y138.264 E.01737
G1 X95.65 Y139.015 E.02193
G1 X96.057 Y139.542 E.0162
G1 X96.633 Y140.189 E.02107
G1 X97.168 Y140.707 E.01811
G1 X97.706 Y141.162 E.01714
G1 X98.373 Y141.652 E.02013
G1 X99.598 Y142.363 E.03445
G1 X91.798 Y142.368 E.18973
G1 X91.295 Y142.507 E.01269
G1 X91.101 Y142.622 E.00549
G1 X90.8 Y142.954 E.0109
;WIDTH:0.436122
G1 X90.698 Y143.164 E.00624
;WIDTH:0.472244
G1 X90.597 Y143.374 E.00679
;WIDTH:0.508366
G1 X90.521 Y143.53 E.00547
G1 X90.521 Y143.53 F9000
G1 X90.806 Y142.395
;WIDTH:0.399999
G1 F6000
G1 X90.806 Y137.61 E.11639
G1 X91.118 Y137.817 E.00911
G1 X91.379 Y137.923 E.00685
G1 X91.797 Y137.998 E.01033
G1 X94.593 Y138 E.06801
G1 X94.846 Y138.466 E.0129
G1 X95.36 Y139.238 E.02256
G1 X95.784 Y139.785 E.01683
G1 X96.378 Y140.451 E.02171
G1 X96.931 Y140.985 E.0187
G1 X97.489 Y141.456 E.01776
G1 X98.239 Y141.998 E.02251
G1 X91.797 Y142.002 E.1567
G1 X91.506 Y142.05 E.00717
G1 X91.178 Y142.161 E.00842
G1 X90.857 Y142.363 E.00923
G1 X90.857 Y142.363 F9000
G1 X91.172 Y141.777
G1 F6000
G1 X91.171 Y138.233 E.0862
G1 X91.242 Y138.262 E.00187
G1 X91.797 Y138.363 E.01372
G1 X94.374 Y138.366 E.06268
G1 X94.541 Y138.668 E.00839
G1 X95.07 Y139.461 E.02319
G1 X95.51 Y140.028 E.01746
G1 X96.123 Y140.713 E.02236
G1 X96.694 Y141.264 E.0193
G1 X97.129 Y141.633 E.01388
G1 X91.797 Y141.637 E.1297
G1 X91.23 Y141.764 E.01413
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X91.172 Y141.777 E-.02823
G1 X91.171 Y138.679 E-1.47177
;WIPE_END
G1 X99.969 Y145.634 F9000
G1 E5 F2400
G1 F6000
G1 X105.317 Y145.636 E.13008
G1 X105.673 Y145.554 E.00889
G1 X105.87 Y145.448 E.00544
G1 X106.121 Y145.157 E.00935
G1 X106.232 Y144.722 E.01092
G1 X106.231 Y143.531 E.02897
G1 X109.58 Y143.528 E.08146
G1 X110.719 Y143.507 E.02771
G1 X111.131 Y143.293 E.01129
G1 X111.338 Y142.957 E.0096
G1 X119.662 Y142.957 E.20247
G1 X119.869 Y143.293 E.0096
G1 X120.176 Y143.466 E.00857
G1 X120.428 Y143.528 E.00631
G1 X124.769 Y143.531 E.10559
G1 X124.768 Y144.722 E.02897
G1 X124.798 Y144.898 E.00434
G1 X124.915 Y145.214 E.0082
G1 X125.055 Y145.377 E.00523
G1 X125.371 Y145.58 E.00914
G1 X125.683 Y145.636 E.00771
G1 X139.202 Y145.632 E.32884
G1 X139.705 Y145.493 E.01269
G1 X139.899 Y145.379 E.00547
G1 X140.193 Y145.061 E.01053
;WIDTH:0.442936
G1 X140.296 Y144.883 E.00559
;WIDTH:0.485873
G1 X140.399 Y144.706 E.00615
;WIDTH:0.52881
G1 X140.502 Y144.528 E.00676
G1 X140.524 Y144.735 E.00685
;WIDTH:0.485873
G1 X140.545 Y144.942 E.00625
;WIDTH:0.442936
G1 X140.567 Y145.149 E.00566
;WIDTH:0.399999
G1 X140.557 Y151.148 E.14592
;WIDTH:0.409698
G1 X140.484 Y151.777 E.01581
G1 X140.337 Y151.197 E.01494
;WIDTH:0.399999
G1 X140.072 Y150.778 E.01206
G1 X139.705 Y150.507 E.0111
G1 X139.202 Y150.368 E.01269
G1 X125.683 Y150.364 E.32884
G1 X125.327 Y150.446 E.00889
G1 X125.133 Y150.55 E.00535
G1 X124.835 Y150.938 E.0119
G1 X124.768 Y151.278 E.00843
G1 X124.768 Y152.722 E.03512
G1 X124.785 Y152.855 E.00326
G1 X124.882 Y153.164 E.00788
G1 X125.173 Y153.465 E.01018
G1 X125.435 Y153.597 E.00714
G1 X125.683 Y153.636 E.00611
G1 X139.202 Y153.632 E.32884
G1 X139.705 Y153.493 E.01269
;WIDTH:0.414789
G1 X139.959 Y153.354 E.00733
G1 X139.661 Y153.887 E.01545
;WIDTH:0.399999
G1 X139.316 Y154.334 E.01373
G1 X138.894 Y154.762 E.01462
G1 X138.322 Y155.207 E.01763
G1 X137.856 Y155.481 E.01315
G1 X137.207 Y155.767 E.01725
G1 X136.33 Y155.993 E.02203
G1 X135.786 Y156.059 E.01333
G1 X95.396 Y156.062 E.98245
G1 X94.784 Y156.012 E.01494
G1 X94.182 Y155.889 E.01495
G1 X93.668 Y155.721 E.01315
G1 X93.143 Y155.48 E.01405
G1 X92.538 Y155.107 E.01729
G1 X92.056 Y154.711 E.01517
G1 X91.669 Y154.313 E.0135
G1 X91.288 Y153.811 E.01533
;WIDTH:0.400455
G1 X90.979 Y153.271 E.01515
G1 X91.467 Y153.58 E.01407
;WIDTH:0.399999
G1 X92.545 Y153.632 E.02625
G1 X105.317 Y153.636 E.31067
G1 X105.566 Y153.597 E.00613
G1 X105.827 Y153.465 E.00711
G1 X106.009 Y153.3 E.00598
G1 X106.172 Y153.027 E.00773
G1 X106.232 Y152.721 E.00758
G1 X106.229 Y151.234 E.03617
G1 X106.201 Y151.062 E.00424
G1 X105.995 Y150.665 E.01088
G1 X105.623 Y150.422 E.01081
G1 X105.317 Y150.364 E.00758
G1 X91.798 Y150.368 E.32884
G1 X91.295 Y150.507 E.01269
G1 X90.928 Y150.778 E.0111
G1 X90.615 Y151.298 E.01476
G1 X90.531 Y151.951 E.01601
G1 X90.442 Y151.267 E.01678
G1 X90.441 Y144.83 E.15657
;WIDTH:0.441815
G1 X90.462 Y144.554 E.0075
;WIDTH:0.48363
G1 X90.483 Y144.278 E.00827
G1 X90.5 Y144.328 E.00158
;WIDTH:0.472537
G1 X90.582 Y144.564 E.00728
;WIDTH:0.436268
G1 X90.664 Y144.8 E.00668
;WIDTH:0.399999
G1 X90.836 Y145.117 E.00877
G1 X91.094 Y145.377 E.00891
G1 X91.516 Y145.584 E.01143
G1 X91.798 Y145.632 E.00696
G1 X99.909 Y145.634 E.19729
G1 E-5 F3600
G1 X99.909 Y145.634 F9000
G1 X99.909 Y145.249
G1 X91.766 Y145.249
G1 X91.643 Y145.234
G1 X91.475 Y145.184
G1 X91.26 Y145.038
G1 X91.114 Y144.866
G1 X91.059 Y144.778
G1 X90.948 Y144.507
G1 X90.901 Y144.237
G1 X90.483 Y144.278
G1 E5 F2400
;WIDTH:0.508366
G1 F6000
G1 X90.495 Y143.584 E.02189
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X90.483 Y144.278 E-.3297
;WIPE_END
G1 E-1.1703 F3600
G1 X90.901 Y144.237 F9000
G1 X90.887 Y144
G1 X90.901 Y143.763
G1 X90.948 Y143.493
G1 X91.059 Y143.222
G1 X91.114 Y143.134
G1 X91.26 Y142.962
G1 X91.475 Y142.816
G1 X91.643 Y142.766
G1 X91.766 Y142.751
G1 X100.362 Y142.751
G1 X100.845 Y142.787
G1 X106.597 Y143.897
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X110.572 Y143.893 E.09669
G1 X110.93 Y143.82 E.00889
G1 X111.363 Y143.575 E.0121
G1 X111.548 Y143.323 E.0076
G1 X119.452 Y143.323 E.19226
G1 X119.637 Y143.575 E.0076
G1 X120.07 Y143.82 E.0121
G1 X120.428 Y143.893 E.00889
G1 X124.403 Y143.897 E.09669
G1 X124.403 Y144.722 E.02007
G1 X124.527 Y145.238 E.01291
G1 X124.668 Y145.502 E.00728
G1 X124.975 Y145.778 E.01004
G1 X125.261 Y145.929 E.00787
G1 X125.683 Y146.002 E.01042
G1 X139.202 Y145.998 E.32884
G1 X139.494 Y145.95 E.0072
G1 X139.822 Y145.839 E.00842
G1 X140.201 Y145.598 E.01092
G1 X140.202 Y150.402 E.11685
G1 X139.822 Y150.161 E.01095
G1 X139.494 Y150.05 E.00842
G1 X139.202 Y150.002 E.0072
G1 X125.683 Y149.998 E.32884
G1 X125.223 Y150.095 E.01144
G1 X124.934 Y150.241 E.00788
G1 X124.638 Y150.567 E.01071
G1 X124.475 Y150.853 E.00801
G1 X124.403 Y151.278 E.01048
G1 X124.403 Y152.722 E.03512
G1 X124.43 Y152.943 E.00542
G1 X124.564 Y153.343 E.01026
G1 X124.927 Y153.736 E.01301
G1 X125.363 Y153.956 E.01188
G1 X125.683 Y154.002 E.00786
G1 X139.113 Y153.998 E.32667
G1 X138.65 Y154.488 E.0164
G1 X138.138 Y154.887 E.01579
G1 X137.705 Y155.148 E.0123
G1 X137.098 Y155.418 E.01616
G1 X136.618 Y155.564 E.0122
G1 X135.765 Y155.693 E.02098
G1 X95.396 Y155.697 E.98194
G1 X94.9 Y155.662 E.01209
G1 X94.334 Y155.554 E.01402
G1 X93.816 Y155.387 E.01324
G1 X93.332 Y155.167 E.01293
G1 X92.766 Y154.821 E.01614
G1 X92.316 Y154.454 E.01412
G1 X91.873 Y153.977 E.01583
G1 X92.545 Y153.998 E.01635
G1 X105.317 Y154.002 E.31067
G1 X105.637 Y153.956 E.00786
G1 X106.073 Y153.736 E.01188
G1 X106.436 Y153.344 E.013
G1 X106.527 Y153.116 E.00597
G1 X106.597 Y152.72 E.00978
G1 X106.595 Y151.234 E.03615
G1 X106.548 Y150.947 E.00707
G1 X106.315 Y150.478 E.01274
G1 X106.158 Y150.317 E.00547
G1 X105.691 Y150.056 E.01301
G1 X105.317 Y149.998 E.00921
G1 X91.798 Y150.002 E.32884
G1 X91.506 Y150.05 E.0072
G1 X91.178 Y150.161 E.00842
G1 X90.808 Y150.394 E.01064
G1 X90.807 Y145.611 E.11634
G1 X91.118 Y145.817 E.00907
G1 X91.379 Y145.923 E.00685
G1 X91.798 Y145.998 E.01035
G1 X105.317 Y146.002 E.32884
G1 X105.51 Y145.981 E.00472
G1 X105.989 Y145.811 E.01236
G1 X106.335 Y145.489 E.0115
G1 X106.524 Y145.123 E.01002
G1 X106.597 Y144.722 E.00991
G1 X106.597 Y143.957 E.01861
G1 X106.597 Y143.957 F9000
G1 X107.058 Y144.262
G1 F6000
G1 X109.58 Y144.26 E.06135
G1 X110.801 Y144.238 E.0297
G1 X111.161 Y144.115 E.00925
G1 X111.596 Y143.857 E.0123
G1 X111.719 Y143.688 E.00508
G1 X119.281 Y143.688 E.18394
G1 X119.404 Y143.857 E.00508
G1 X119.628 Y144.005 E.00653
G1 X120.084 Y144.211 E.01217
G1 X120.428 Y144.259 E.00845
G1 X124.037 Y144.262 E.08779
G1 X124.037 Y144.722 E.01119
G1 X124.181 Y145.356 E.01581
G1 X124.378 Y145.725 E.01017
G1 X124.75 Y146.066 E.01227
G1 X125.151 Y146.277 E.01102
G1 X125.683 Y146.367 E.01312
G1 X139.202 Y146.363 E.32884
G1 X139.835 Y146.221 E.01578
G1 X139.836 Y149.78 E.08657
G1 X139.202 Y149.637 E.01581
G1 X125.571 Y149.638 E.33156
G1 X125.119 Y149.745 E.0113
G1 X124.714 Y149.949 E.01103
G1 X124.351 Y150.34 E.01298
G1 X124.13 Y150.732 E.01095
G1 X124.037 Y151.278 E.01347
G1 X124.037 Y152.722 E.03512
G1 X124.075 Y153.032 E.0076
G1 X124.246 Y153.523 E.01265
G1 X124.681 Y154.006 E.01581
G1 X125.291 Y154.314 E.01662
G1 X125.683 Y154.367 E.00962
G1 X138.215 Y154.364 E.30483
G1 X137.566 Y154.81 E.01915
G1 X137.03 Y155.054 E.01432
G1 X136.547 Y155.205 E.01231
G1 X135.744 Y155.328 E.01976
G1 X95.396 Y155.331 E.98142
G1 X94.948 Y155.299 E.01092
G1 X94.447 Y155.203 E.01241
G1 X93.983 Y155.06 E.01181
G1 X93.521 Y154.854 E.0123
G1 X92.779 Y154.364 E.02163
G1 X105.317 Y154.367 E.30497
G1 X105.709 Y154.314 E.00962
G1 X106.319 Y154.006 E.01662
G1 X106.754 Y153.523 E.01581
G1 X106.882 Y153.204 E.00836
G1 X106.963 Y152.72 E.01194
G1 X106.96 Y151.233 E.03617
G1 X106.951 Y151.079 E.00375
G1 X106.843 Y150.7 E.00959
G1 X106.575 Y150.218 E.01341
G1 X106.222 Y149.92 E.01124
G1 X105.809 Y149.71 E.01127
G1 X105.317 Y149.633 E.01211
G1 X91.798 Y149.637 E.32884
G1 X91.173 Y149.776 E.01557
G1 X91.173 Y146.234 E.08616
G1 X91.242 Y146.262 E.00181
G1 X91.798 Y146.363 E.01375
G1 X105.317 Y146.367 E.32884
G1 X105.587 Y146.339 E.0066
G1 X106.106 Y146.164 E.01332
G1 X106.456 Y145.898 E.01069
G1 X106.766 Y145.503 E.01221
G1 X106.923 Y145.038 E.01194
G1 X106.963 Y144.262 E.0189
G1 X106.998 Y144.262 E.00085
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X107.058 Y144.262 E-.0285
G1 X109.58 Y144.26 E-1.19795
G1 X110.156 Y144.25 E-.27355
;WIPE_END
G1 X130.638 Y142.751 F9000
G1 X139.234 Y142.751
G1 X139.357 Y142.766
G1 X139.525 Y142.816
G1 X139.74 Y142.962
G1 X139.886 Y143.134
G1 X139.941 Y143.222
G1 X140.052 Y143.493
G1 X140.083 Y143.672
G1 X140.096 Y143.747
G1 X140.516 Y143.674
G1 E5 F2400
;WIDTH:0.520784
G1 F6000
G1 X140.506 Y144.46 E.02544
;WIDTH:0.52881
G1 X140.502 Y144.528 E.00224
G1 E-5 F3600
G1 X140.502 Y144.528 F9000
G1 X140.062 Y144.451
G1 X140.099 Y144.237
G1 X140.113 Y144
G1 X140.099 Y143.763
G1 X139.74 Y142.962
G1 X132.362 Y142.751
G1 X131.469 Y142.751
G1 X131.469 Y142.363
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X131.412 Y142.363 E.00139
G1 X132.096 Y141.989 E.01896
G1 X132.698 Y141.603 E.01739
G1 X133.499 Y140.996 E.02445
G1 X134.103 Y140.453 E.01976
G1 X134.541 Y140.002 E.01529
G1 X134.984 Y139.492 E.01643
G1 X135.563 Y138.697 E.02392
G1 X135.869 Y138.231 E.01356
G1 X136.201 Y137.635 E.01659
G1 X139.203 Y137.632 E.07302
G1 X139.705 Y137.493 E.01267
G1 X139.899 Y137.378 E.00549
G1 X140.193 Y137.061 E.01052
;WIDTH:0.442566
G1 X140.296 Y136.883 E.00558
;WIDTH:0.485133
G1 X140.399 Y136.705 E.00617
;WIDTH:0.5277
G1 X140.502 Y136.528 E.00672
G1 X140.523 Y136.735 E.00683
;WIDTH:0.485133
G1 X140.544 Y136.941 E.00621
;WIDTH:0.442566
G1 X140.566 Y137.148 E.00565
;WIDTH:0.399999
G1 X140.566 Y142.994 E.1422
;WIDTH:0.433712
G1 X140.549 Y143.221 E.00605
;WIDTH:0.467424
G1 X140.533 Y143.448 E.00656
;WIDTH:0.501136
G1 X140.516 Y143.674 E.00704
G1 X140.46 Y143.524 E.00497
;WIDTH:0.467424
G1 X140.403 Y143.374 E.00462
;WIDTH:0.433712
G1 X140.347 Y143.223 E.00428
;WIDTH:0.399999
G1 X140.183 Y142.909 E.00862
G1 X139.919 Y142.635 E.00926
G1 X139.488 Y142.418 E.01174
G1 X139.202 Y142.368 E.00706
G1 X131.529 Y142.363 E.18664
G1 X131.529 Y142.363 F9000
G1 X132.861 Y141.998
G1 F6000
G1 X132.761 Y141.998 E.00243
G1 X133.743 Y141.268 E.02976
G1 X134.365 Y140.708 E.02036
G1 X134.817 Y140.243 E.01577
G1 X135.275 Y139.714 E.01702
G1 X135.694 Y139.163 E.01684
G1 X136.154 Y138.465 E.02033
G1 X136.419 Y138 E.01302
G1 X139.203 Y137.998 E.06772
G1 X139.494 Y137.95 E.00717
G1 X139.822 Y137.839 E.00842
G1 X140.2 Y137.599 E.01089
G1 X140.201 Y142.398 E.11673
G1 X139.895 Y142.191 E.00899
G1 X139.628 Y142.08 E.00703
G1 X139.203 Y142.002 E.01051
G1 X132.921 Y141.998 E.1528
G1 X132.921 Y141.998 F9000
G1 X134.022 Y141.633
G1 F6000
G1 X133.871 Y141.633 E.00367
G1 X134.626 Y140.964 E.02454
G1 X135.093 Y140.483 E.01631
G1 X135.565 Y139.936 E.01757
G1 X136.173 Y139.1 E.02514
G1 X136.633 Y138.366 E.02107
G1 X139.203 Y138.363 E.06251
G1 X139.834 Y138.221 E.01573
G1 X139.835 Y141.77 E.08633
G1 X139.769 Y141.742 E.00174
G1 X139.203 Y141.637 E.014
G1 X134.082 Y141.634 E.12456
G1 E-5 F3600
G1 X134.082 Y141.634 F9000
G1 X139.74 Y137.038
G1 X140.113 Y136
G1 X140.099 Y135.763
G1 X140.096 Y135.747
G1 X140.515 Y135.675
G1 E5 F2400
;WIDTH:0.51968
G1 F6000
G1 X140.506 Y136.46 E.02535
;WIDTH:0.5277
G1 X140.502 Y136.528 E.00224
G1 X140.502 Y136.528 F9000
;WIDTH:0.500038
G1 F6000
G1 X140.438 Y135.474 E.00667
;WIDTH:0.466692
G1 X140.361 Y135.274 E.00616
;WIDTH:0.433346
G1 X140.284 Y135.074 E.00569
;WIDTH:0.399999
G1 X140.091 Y134.796 E.00823
G1 X139.754 Y134.528 E.01047
G1 X139.282 Y134.376 E.01206
G1 X137.268 Y134.367 E.04899
G1 X137.373 Y133.688 E.01671
G1 X137.431 Y132.616 E.02611
G1 X137.431 Y129.631 E.07261
G1 X139.25 Y129.627 E.04425
G1 X139.755 Y129.472 E.01285
G1 X139.945 Y129.349 E.00551
G1 X140.192 Y129.062 E.00921
;WIDTH:0.442203
G1 X140.295 Y128.884 E.00558
;WIDTH:0.484407
G1 X140.398 Y128.706 E.00616
;WIDTH:0.52661
G1 X140.501 Y128.528 E.00673
G1 X140.522 Y128.735 E.00681
;WIDTH:0.484407
G1 X140.543 Y128.942 E.00623
;WIDTH:0.442203
G1 X140.564 Y129.149 E.00565
;WIDTH:0.399999
G1 X140.565 Y134.994 E.14217
;WIDTH:0.433346
G1 X140.549 Y135.221 E.00604
;WIDTH:0.466692
G1 X140.532 Y135.448 E.00655
;WIDTH:0.500038
G1 X140.52 Y135.615 E.00519
G1 X140.52 Y135.615 F9000
G1 X140.199 Y134.396
;WIDTH:0.399999
G1 F6000
G1 X139.895 Y134.191 E.00892
G1 X139.628 Y134.08 E.00703
G1 X139.284 Y134.01 E.00854
G1 X137.7 Y134.001 E.03853
G1 X137.738 Y133.708 E.00719
G1 X137.797 Y132.616 E.0266
G1 X137.797 Y129.996 E.06373
G1 X139.251 Y129.992 E.03537
G1 X139.576 Y129.932 E.00804
G1 X139.886 Y129.813 E.00808
G1 X140.199 Y129.61 E.00907
G1 X140.199 Y134.336 E.11496
G1 X140.199 Y134.336 F9000
G1 X139.834 Y133.769
G1 F6000
G1 X139.287 Y133.645 E.01364
G1 X138.108 Y133.636 E.02868
G1 X138.163 Y132.616 E.02485
G1 X138.163 Y130.361 E.05485
G1 X139.252 Y130.358 E.02649
G1 X139.833 Y130.225 E.0145
G1 X139.834 Y133.709 E.08474
G1 E-5 F3600
G1 X139.834 Y133.709 F9000
G1 X140.514 Y127.669
G1 E5 F2400
;WIDTH:0.518594
G1 F6000
G1 X140.505 Y128.46 E.02548
;WIDTH:0.52661
G1 X140.501 Y128.528 E.00223
G1 X140.501 Y128.528 F9000
;WIDTH:0.500512
G1 F6000
G1 X140.429 Y127.456 E.00711
;WIDTH:0.467008
G1 X140.343 Y127.243 E.00661
;WIDTH:0.433504
G1 X140.258 Y127.031 E.00606
;WIDTH:0.399999
G1 X140.015 Y126.724 E.00952
G1 X139.649 Y126.479 E.01071
G1 X139.25 Y126.373 E.01004
G1 X137.431 Y126.369 E.04425
G1 X137.431 Y121.631 E.11525
G1 X139.25 Y121.627 E.04425
G1 X139.755 Y121.472 E.01285
G1 X139.945 Y121.349 E.00551
G1 X140.196 Y121.055 E.0094
;WIDTH:0.440766
G1 X140.298 Y120.872 E.00566
;WIDTH:0.481532
G1 X140.4 Y120.689 E.00623
;WIDTH:0.522298
G1 X140.502 Y120.506 E.0068
G1 X140.523 Y120.717 E.00688
;WIDTH:0.481532
G1 X140.543 Y120.928 E.0063
;WIDTH:0.440766
G1 X140.563 Y121.138 E.0057
;WIDTH:0.399999
G1 X140.564 Y127.169 E.1467
;WIDTH:0.433504
G1 X140.547 Y127.336 E.00446
;WIDTH:0.467008
G1 X140.531 Y127.502 E.0048
;WIDTH:0.500512
G1 X140.52 Y127.609 E.00334
G1 X140.198 Y126.404 F9000
;WIDTH:0.399999
G1 F6000
G1 X139.767 Y126.133 E.01238
G1 X139.251 Y126.008 E.01291
G1 X137.797 Y126.004 E.03537
G1 X137.797 Y121.996 E.09749
G1 X139.251 Y121.992 E.03537
G1 X139.576 Y121.932 E.00804
G1 X139.886 Y121.813 E.00808
G1 X140.198 Y121.611 E.00904
G1 X140.198 Y126.344 E.11513
G1 X140.198 Y126.344 F9000
G1 X139.833 Y125.769
G1 F6000
G1 X139.252 Y125.642 E.01447
G1 X138.163 Y125.639 E.02649
G1 X138.163 Y122.361 E.07973
G1 X139.252 Y122.358 E.02649
G1 X139.832 Y122.225 E.01447
G1 X139.833 Y125.709 E.08474
G1 E-5 F3600
G1 X139.833 Y125.709 F9000
G1 X140.48 Y119.356
G1 E5 F2400
;WIDTH:0.566024
G1 F6000
G1 X140.502 Y119.606 E.00888
;WIDTH:0.522897
G1 X140.523 Y119.857 E.00819
;WIDTH:0.515832
G1 X140.505 Y120.458 E.01926
;WIDTH:0.522298
G1 X140.502 Y120.506 E.00156
G1 E-5 F3600
G1 X140.502 Y120.506 F9000
G1 X140.065 Y120.43
G1 X140.099 Y120.237
G1 X140.113 Y120
G1 X140.099 Y119.763
G1 X140.052 Y119.493
G1 X139.941 Y119.221
G1 X139.886 Y119.134
G1 X139.74 Y118.962
G1 X139.525 Y118.816
G1 X139.357 Y118.766
G1 X139.234 Y118.751
G1 X137.697 Y118.747
G1 X137.43 Y118.747
G1 X137.431 Y118.369
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y113.631 E.11525
G1 X139.25 Y113.627 E.04425
G1 X139.755 Y113.472 E.01285
G1 X139.945 Y113.349 E.00551
G1 X140.196 Y113.055 E.0094
;WIDTH:0.440402
G1 X140.298 Y112.872 E.00566
;WIDTH:0.480805
G1 X140.4 Y112.689 E.00622
;WIDTH:0.521208
G1 X140.502 Y112.506 E.00679
G1 X140.522 Y112.717 E.00686
;WIDTH:0.480805
G1 X140.542 Y112.927 E.00627
;WIDTH:0.440402
G1 X140.562 Y113.138 E.00572
;WIDTH:0.399999
G1 X140.563 Y118.817 E.13814
;WIDTH:0.441506
G1 X140.542 Y118.952 E.0037
;WIDTH:0.483012
G1 X140.522 Y119.086 E.00404
;WIDTH:0.524518
G1 X140.501 Y119.221 E.00445
;WIDTH:0.566024
G1 X140.48 Y119.356 E.00483
G1 X140.425 Y119.267 E.0037
;WIDTH:0.52017
G1 X140.369 Y119.179 E.00337
;WIDTH:0.474316
G1 X140.204 Y118.964 E.00793
;WIDTH:0.437158
G1 X140.039 Y118.75 E.00724
;WIDTH:0.399999
G1 X139.761 Y118.534 E.00856
G1 X139.561 Y118.436 E.00542
G1 X139.25 Y118.373 E.00772
G1 X137.491 Y118.369 E.04279
G1 X137.491 Y118.369 F9000
G1 X137.797 Y118.004
G1 F6000
G1 X137.797 Y113.996 E.09749
G1 X139.251 Y113.992 E.03537
G1 X139.576 Y113.932 E.00804
G1 X139.886 Y113.813 E.00808
G1 X140.197 Y113.612 E.00901
G1 X140.197 Y118.41 E.11671
G1 X139.985 Y118.245 E.00653
G1 X139.652 Y118.082 E.00902
G1 X139.251 Y118.008 E.00992
G1 X137.857 Y118.004 E.03391
G1 X138.163 Y117.639 F9000
G1 F6000
G1 X138.163 Y114.361 E.07973
G1 X139.252 Y114.358 E.02649
G1 X139.831 Y114.226 E.01444
G1 X139.832 Y117.771 E.08623
G1 X139.743 Y117.727 E.00241
G1 X139.252 Y117.642 E.01212
G1 X138.223 Y117.639 E.02503
G1 E-5 F3600
G1 X138.223 Y117.639 F9000
G1 X140.48 Y111.356
G1 E5 F2400
;WIDTH:0.564934
G1 F6000
G1 X140.501 Y111.606 E.00885
;WIDTH:0.521807
G1 X140.523 Y111.857 E.00817
;WIDTH:0.514746
G1 X140.505 Y112.458 E.01921
;WIDTH:0.521208
G1 X140.502 Y112.506 E.00156
G1 E-5 F3600
G1 X140.502 Y112.506 F9000
G1 X140.065 Y112.43
G1 X140.099 Y112.237
G1 X140.113 Y112
G1 X140.099 Y111.763
G1 X140.052 Y111.493
G1 X139.941 Y111.221
G1 X139.886 Y111.134
G1 X139.74 Y110.962
G1 X139.525 Y110.816
G1 X139.357 Y110.766
G1 X139.234 Y110.751
G1 X138.107 Y110.748
G1 X137.821 Y110.747
G1 X137.822 Y110.37
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y110.369 E.00951
G1 X137.431 Y105.631 E.11525
G1 X139.25 Y105.627 E.04425
G1 X139.755 Y105.472 E.01285
G1 X139.945 Y105.349 E.00551
G1 X140.196 Y105.055 E.0094
;WIDTH:0.440038
G1 X140.298 Y104.872 E.00565
;WIDTH:0.480077
G1 X140.399 Y104.689 E.0062
;WIDTH:0.520116
G1 X140.501 Y104.506 E.00677
G1 X140.521 Y104.717 E.00685
;WIDTH:0.480077
G1 X140.541 Y104.927 E.00625
;WIDTH:0.440038
G1 X140.561 Y105.138 E.00572
;WIDTH:0.399999
G1 X140.562 Y110.817 E.13814
;WIDTH:0.441233
G1 X140.541 Y110.952 E.0037
;WIDTH:0.482467
G1 X140.521 Y111.086 E.00404
;WIDTH:0.523701
G1 X140.5 Y111.221 E.00445
;WIDTH:0.564934
G1 X140.48 Y111.356 E.00482
G1 X140.424 Y111.267 E.00371
;WIDTH:0.519421
G1 X140.369 Y111.179 E.00335
;WIDTH:0.473907
G1 X140.204 Y110.964 E.00792
;WIDTH:0.436953
G1 X140.039 Y110.75 E.00724
;WIDTH:0.399999
G1 X139.761 Y110.534 E.00856
G1 X139.561 Y110.436 E.00542
G1 X139.25 Y110.373 E.00772
G1 X137.882 Y110.37 E.03328
G1 X137.882 Y110.37 F9000
G1 X137.946 Y110.004
G1 F6000
G1 X137.797 Y110.004 E.00362
G1 X137.797 Y105.996 E.09749
G1 X139.251 Y105.992 E.03537
G1 X139.576 Y105.932 E.00804
G1 X139.886 Y105.813 E.00808
G1 X140.196 Y105.612 E.00899
G1 X140.196 Y110.41 E.11671
G1 X139.985 Y110.245 E.00652
G1 X139.652 Y110.082 E.00902
G1 X139.251 Y110.008 E.00992
G1 X138.006 Y110.004 E.03028
G1 X138.006 Y110.004 F9000
G1 X138.377 Y109.64
G1 F6000
G1 X138.163 Y109.639 E.00521
G1 X138.163 Y106.361 E.07973
G1 X139.252 Y106.358 E.02649
G1 X139.83 Y106.226 E.01442
G1 X139.83 Y109.77 E.0862
G1 X139.743 Y109.727 E.00236
G1 X139.252 Y109.642 E.01212
G1 X138.437 Y109.64 E.01982
G1 E-5 F3600
G1 X138.437 Y109.64 F9000
G1 X140.479 Y103.356
G1 E5 F2400
;WIDTH:0.563844
G1 F6000
G1 X140.501 Y103.606 E.00884
;WIDTH:0.520718
G1 X140.522 Y103.857 E.00815
;WIDTH:0.51366
G1 X140.504 Y104.458 E.01917
;WIDTH:0.520116
G1 X140.501 Y104.506 E.00155
G1 E-5 F3600
G1 X140.065 Y104.43 F9000
G1 X140.099 Y104.237
G1 X140.113 Y104
G1 X140.099 Y103.763
G1 X140.052 Y103.493
G1 X139.941 Y103.222
G1 X139.886 Y103.134
G1 X139.74 Y102.962
G1 X139.525 Y102.816
G1 X139.357 Y102.766
G1 X139.234 Y102.751
G1 X137.697 Y102.747
G1 X137.43 Y102.747
G1 X137.431 Y102.369
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X137.431 Y96.971 E.1313
G1 X139.285 Y96.964 E.0451
G1 X139.727 Y96.853 E.01109
G1 X140.1 Y96.625 E.01063
G1 X140.269 Y96.465 E.00566
;WIDTH:0.404586
G1 X140.553 Y95.983 E.01378
G1 X140.56 Y96.208 E.00554
;WIDTH:0.399999
G1 X140.561 Y102.817 E.16076
;WIDTH:0.440961
G1 X140.54 Y102.952 E.0037
;WIDTH:0.481922
G1 X140.52 Y103.087 E.00406
;WIDTH:0.522883
G1 X140.499 Y103.221 E.00441
;WIDTH:0.563844
G1 X140.479 Y103.356 E.00481
G1 X140.424 Y103.267 E.00369
;WIDTH:0.51867
G1 X140.369 Y103.179 E.00334
;WIDTH:0.473496
G1 X140.204 Y102.965 E.00789
;WIDTH:0.436748
G1 X140.039 Y102.75 E.00725
;WIDTH:0.399999
G1 X139.761 Y102.534 E.00856
G1 X139.561 Y102.436 E.00542
G1 X139.25 Y102.373 E.00772
G1 X137.491 Y102.369 E.04279
G1 X137.491 Y102.369 F9000
G1 X137.797 Y102.004
G1 F6000
G1 X137.797 Y97.336 E.11354
G1 X138.996 Y97.336 E.02916
G1 X139.58 Y97.289 E.01425
G1 X139.918 Y97.165 E.00876
G1 X140.194 Y96.996 E.00787
G1 X140.195 Y102.409 E.13167
G1 X139.985 Y102.245 E.00648
G1 X139.652 Y102.082 E.00902
G1 X139.251 Y102.008 E.00992
G1 X137.857 Y102.004 E.03391
G1 X138.163 Y101.639 F9000
G1 F6000
G1 X138.163 Y97.702 E.09576
G1 X139.396 Y97.687 E.02999
G1 X139.829 Y97.58 E.01085
G1 X139.829 Y101.77 E.10192
G1 X139.743 Y101.727 E.00234
G1 X139.252 Y101.642 E.01212
G1 X138.223 Y101.639 E.02503
G1 E-5 F3600
G1 X138.223 Y101.639 F9000
G1 X140.191 Y95.869
G1 X140.236 Y95.692
G1 X140.243 Y95.607
G1 X140.249 Y95.527
G1 X140.249 Y93.301
G1 X140.243 Y93.221
G1 X140.236 Y93.137
G1 X140.191 Y92.959
G1 X140.118 Y92.791
G1 X140.017 Y92.636
G1 X139.89 Y92.5
G1 X139.837 Y92.46
G1 X139.732 Y92.384
G1 X139.565 Y92.304
G1 X126.349 Y88.151
G1 X121.622 Y88.151
G1 X119.951 Y86.599
G1 X119.842 Y86.704
G1 E5 F2400
G1 F6000
G1 X119.859 Y86.729 E.00074
G1 X120.194 Y86.928 E.00948
G1 X120.483 Y86.981 E.00715
G1 X126.832 Y86.968 E.15443
G1 X127.393 Y86.936 E.01367
G1 X127.892 Y86.857 E.01229
G1 X128.387 Y86.716 E.01252
G1 X129.047 Y86.436 E.01744
G1 X129.871 Y85.904 E.02386
G1 X130.401 Y85.416 E.01752
G1 X130.854 Y84.85 E.01763
G1 X131.11 Y84.396 E.01268
G1 X131.391 Y83.834 E.01528
G1 X131.663 Y82.851 E.02481
G1 X131.721 Y82.34 E.01251
G1 X131.73 Y79.268 E.07472
G1 X131.953 Y79.063 E.00737
G1 X132.392 Y78.597 E.01557
G1 X132.707 Y78.11 E.01411
G1 X132.829 Y77.77 E.00879
G1 X132.839 Y77.272 E.01212
G1 X132.764 Y77.014 E.00654
G1 X132.378 Y76.384 E.01797
G1 X131.743 Y75.744 E.02193
G1 X131.706 Y75.589 E.00388
G1 X131.539 Y75.259 E.009
G1 X131.267 Y75.026 E.00871
G1 X131.013 Y74.939 E.00653
G1 X135.542 Y74.938 E.11016
G1 X136.163 Y74.989 E.01516
G1 X136.699 Y75.078 E.01322
G1 X137.579 Y75.381 E.02264
G1 X138.377 Y75.832 E.0223
G1 X139.082 Y76.419 E.02231
G1 X139.668 Y77.123 E.02228
G1 X140.119 Y77.922 E.02232
G1 X140.418 Y78.788 E.02228
G1 X140.51 Y79.397 E.01498
G1 X140.558 Y80.022 E.01525
G1 X140.56 Y92.833 E.31161
G1 X140.472 Y92.664 E.00463
G1 X140.157 Y92.244 E.01277
G1 X139.873 Y92.042 E.00848
G1 X139.682 Y91.956 E.0051
G1 X139.201 Y91.858 E.01194
G1 X127.153 Y91.858 E.29306
G1 X127.392 Y91.597 E.00861
G1 X127.774 Y90.964 E.01798
G1 X127.849 Y90.569 E.00978
G1 X127.763 Y89.991 E.01421
G1 X127.482 Y89.533 E.01307
G1 X127.246 Y89.24 E.00915
G1 X126.724 Y88.726 E.01782
G1 X126.714 Y88.516 E.00511
G1 X126.594 Y88.21 E.008
G1 X126.452 Y88.032 E.00554
G1 X126.113 Y87.825 E.00966
G1 X125.817 Y87.769 E.00733
G1 X105.183 Y87.769 E.5019
G1 X104.972 Y87.811 E.00523
G1 X104.543 Y88.03 E.01172
G1 X104.31 Y88.429 E.01124
G1 X104.272 Y88.733 E.00745
G1 X103.978 Y89.008 E.00979
G1 X103.555 Y89.471 E.01525
G1 X103.237 Y89.998 E.01497
G1 X103.149 Y90.382 E.00958
G1 X103.17 Y90.77 E.00945
G1 X103.288 Y91.103 E.00859
G1 X103.555 Y91.529 E.01223
G1 X103.852 Y91.858 E.01078
G1 X91.715 Y91.864 E.29522
G1 X91.273 Y91.975 E.01109
G1 X90.9 Y92.203 E.01063
G1 X90.732 Y92.363 E.00564
G1 X90.538 Y92.65 E.00843
G1 X90.433 Y92.951 E.00775
G1 X90.431 Y80.028 E.31434
G1 X90.47 Y79.389 E.01557
G1 X90.58 Y78.787 E.01489
G1 X90.762 Y78.203 E.01488
G1 X91.013 Y77.645 E.01488
G1 X91.33 Y77.122 E.01488
G1 X91.707 Y76.64 E.01488
G1 X92.14 Y76.207 E.01489
G1 X92.622 Y75.83 E.01488
G1 X93.14 Y75.517 E.01472
G1 X93.653 Y75.295 E.0136
G1 X94.271 Y75.085 E.01588
G1 X95.208 Y74.942 E.02306
G1 X99.185 Y74.942 E.09674
G1 X99.985 Y74.926 E.01946
;WIDTH:0.397859
G1 X99.733 Y75.027 E.00656
;WIDTH:0.399999
G1 X99.431 Y75.317 E.01018
G1 X99.283 Y75.72 E.01044
G1 X99.047 Y75.937 E.0078
G1 X98.608 Y76.403 E.01557
G1 X98.293 Y76.89 E.01411
G1 X98.171 Y77.23 E.00879
G1 X98.183 Y77.813 E.01418
G1 X98.263 Y78.056 E.00622
G1 X98.626 Y78.622 E.01636
G1 X99.27 Y79.268 E.02219
G1 X99.284 Y82.398 E.07613
G1 X99.426 Y83.268 E.02144
G1 X99.692 Y84.039 E.01984
G1 X100.175 Y84.891 E.02382
G1 X100.868 Y85.679 E.02553
G1 X101.625 Y86.249 E.02305
G1 X102.354 Y86.62 E.0199
G1 X102.927 Y86.809 E.01468
G1 X103.567 Y86.938 E.01588
G1 X104.199 Y86.981 E.01541
G1 X110.517 Y86.981 E.15368
G1 X110.612 Y86.973 E.00232
G1 X111.022 Y86.823 E.01062
G1 X111.223 Y86.648 E.00648
G1 X111.347 Y86.399 E.00677
G1 X119.653 Y86.399 E.20204
G1 X119.684 Y86.485 E.00222
G1 X119.807 Y86.656 E.00512
G1 E-5 F3600
G1 X119.807 Y86.656 F9000
G1 X105.019 Y87.382
G1 E5 F2400
;WIDTH:0.4703
G1 F6000
G1 X105.183 Y87.375 E.00476
;WIDTH:0.456022
G1 X110.517 Y87.375 E.14962
;WIDTH:0.4703
G1 X110.681 Y87.368 E.00476
;WIDTH:0.507536
G1 X110.903 Y87.336 E.00706
;WIDTH:0.536576
G1 X111.293 Y87.163 E.01425
G1 X111.412 Y87.068 E.00509
G1 X111.61 Y86.832 E.01029
G1 X119.39 Y86.832 E.25992
G1 X119.442 Y86.924 E.00353
G1 X119.708 Y87.163 E.01195
G1 X120.098 Y87.335 E.01424
;WIDTH:0.504721
G1 X120.264 Y87.362 E.00526
;WIDTH:0.509012
G1 X119.956 Y87.349 E.00973
;WIDTH:0.536576
G1 X119.648 Y87.335 E.0103
G1 X111.353 Y87.335 E.27713
G1 X111.017 Y87.351 E.01124
;WIDTH:0.503438
G1 X110.741 Y87.365 E.00862
G1 E-5 F3600
G1 X110.741 Y87.365 F9000
G1 X120.264 Y87.362
G1 E5 F2400
;WIDTH:0.481448
G1 F6000
G1 X120.485 Y87.375 E.00658
;WIDTH:0.467118
G1 X125.817 Y87.369 E.1535
;WIDTH:0.494564
G1 X126.043 Y87.383 E.00693
G1 X126.215 Y87.362 E.0053
;WIDTH:0.453602
G1 X126.524 Y87.348 E.00863
;WIDTH:0.426801
G1 X126.833 Y87.334 E.00808
;WIDTH:0.399999
G1 X127.446 Y87.297 E.01494
G1 X127.99 Y87.21 E.0134
G1 X128.526 Y87.054 E.01358
G1 X129.242 Y86.745 E.01897
G1 X130.117 Y86.175 E.0254
G1 X130.684 Y85.648 E.01883
G1 X131.173 Y85.029 E.01919
G1 X131.433 Y84.566 E.01292
G1 X131.743 Y83.934 E.01712
G1 X132.026 Y82.895 E.02619
G1 X132.087 Y82.341 E.01356
G1 X132.095 Y79.429 E.07083
G1 X132.739 Y78.735 E.02303
G1 X133.054 Y78.242 E.01423
G1 X133.193 Y77.825 E.01069
G1 X133.205 Y77.26 E.01375
G1 X133.079 Y76.829 E.01092
G1 X132.643 Y76.132 E.02
G1 X132.108 Y75.583 E.01865
G1 X131.981 Y75.304 E.00746
G1 X135.784 Y75.317 E.0925
G1 X136.606 Y75.432 E.02019
G1 X137.428 Y75.716 E.02115
G1 X138.169 Y76.134 E.02069
G1 X138.822 Y76.678 E.02067
G1 X139.366 Y77.332 E.02069
G1 X139.784 Y78.072 E.02067
G1 X140.061 Y78.876 E.02068
G1 X140.149 Y79.452 E.01417
G1 X140.192 Y80.022 E.0139
G1 X140.194 Y91.822 E.28702
G1 X139.765 Y91.6 E.01175
G1 X139.201 Y91.492 E.01397
G1 X127.896 Y91.492 E.27498
G1 X128.125 Y91.065 E.01179
G1 X128.213 Y90.536 E.01304
G1 X128.177 Y90.141 E.00965
G1 X128.065 Y89.779 E.00922
G1 X127.792 Y89.339 E.0126
G1 X127.508 Y88.985 E.01104
G1 X127.085 Y88.56 E.01459
G1 X127.054 Y88.354 E.00507
G1 X126.843 Y87.918 E.01178
G1 X126.565 Y87.652 E.00936
;WIDTH:0.447282
G1 X126.304 Y87.517 E.00807
;WIDTH:0.494564
G1 X126.097 Y87.41 E.00713
G1 X126.097 Y87.41 F9000
G1 X127.14 Y87.701
;WIDTH:0.399999
G1 F6000
G1 X128.087 Y87.562 E.02328
G1 X128.666 Y87.393 E.01467
G1 X129.438 Y87.054 E.02051
G1 X130.362 Y86.446 E.0269
G1 X130.966 Y85.88 E.02013
G1 X131.492 Y85.209 E.02074
G1 X131.757 Y84.736 E.01319
G1 X132.095 Y84.033 E.01897
G1 X132.389 Y82.939 E.02755
G1 X132.452 Y82.342 E.0146
G1 X132.476 Y79.574 E.06733
G1 X132.847 Y79.194 E.01292
G1 X133.046 Y78.933 E.00798
G1 X133.447 Y78.255 E.01916
G1 X133.575 Y77.751 E.01265
G1 X133.57 Y77.247 E.01226
G1 X133.395 Y76.643 E.0153
G1 X133.084 Y76.114 E.01493
G1 X132.708 Y75.67 E.01415
G1 X135.746 Y75.68 E.0739
G1 X136.513 Y75.787 E.01884
G1 X137.277 Y76.051 E.01966
G1 X137.96 Y76.436 E.01907
G1 X138.562 Y76.938 E.01907
G1 X139.064 Y77.54 E.01907
G1 X139.449 Y78.223 E.01907
G1 X139.705 Y78.964 E.01907
G1 X139.787 Y79.507 E.01336
G1 X139.826 Y80.022 E.01256
G1 X139.828 Y91.239 E.27284
G1 X139.201 Y91.127 E.01549
G1 X128.488 Y91.127 E.26058
G1 X128.577 Y90.503 E.01533
G1 X128.541 Y90.108 E.00965
G1 X128.457 Y89.754 E.00885
G1 X128.352 Y89.546 E.00567
G1 X127.877 Y88.84 E.0207
G1 X127.463 Y88.414 E.01445
G1 X127.315 Y88.015 E.01035
G1 X127.169 Y87.753 E.0073
G1 E-5 F3600
G1 X127.169 Y87.753 F9000
G1 X105.019 Y87.382
G1 E5 F2400
;WIDTH:0.4703
G1 F6000
G1 X104.825 Y87.459 E.00605
;WIDTH:0.432421
G1 X104.289 Y87.767 E.01637
;WIDTH:0.399999
G1 X104.006 Y88.212 E.01283
G1 X103.913 Y88.567 E.00893
G1 X103.713 Y88.756 E.00669
G1 X103.245 Y89.277 E.01703
G1 X102.974 Y89.711 E.01245
G1 X102.816 Y90.14 E.01112
G1 X102.784 Y90.618 E.01165
G1 X102.875 Y91.065 E.0111
G1 X103.1 Y91.492 E.01174
G1 X91.798 Y91.492 E.27491
G1 X91.42 Y91.54 E.00927
G1 X91.083 Y91.663 E.00873
G1 X90.799 Y91.836 E.00809
G1 X90.797 Y80.039 E.28695
G1 X90.834 Y79.433 E.01477
G1 X90.936 Y78.875 E.0138
G1 X91.105 Y78.333 E.01381
G1 X91.338 Y77.815 E.01382
G1 X91.631 Y77.33 E.01378
G1 X91.982 Y76.883 E.01382
G1 X92.383 Y76.482 E.01379
G1 X92.83 Y76.131 E.01382
G1 X93.308 Y75.842 E.01359
G1 X93.798 Y75.63 E.01299
G1 X94.352 Y75.442 E.01423
G1 X95.236 Y75.308 E.02175
G1 X99.036 Y75.308 E.09243
G1 X98.954 Y75.502 E.00512
G1 X98.3 Y76.204 E.02334
G1 X97.986 Y76.692 E.01412
G1 X97.875 Y76.935 E.0065
G1 X97.787 Y77.457 E.01288
G1 X97.837 Y77.967 E.01246
G1 X97.952 Y78.248 E.00739
G1 X98.362 Y78.874 E.0182
G1 X98.905 Y79.43 E.0189
G1 X98.93 Y82.541 E.07567
G1 X99.08 Y83.387 E.0209
G1 X99.347 Y84.158 E.01985
G1 X99.536 Y84.524 E.01002
G1 X99.898 Y85.129 E.01715
G1 X100.648 Y85.971 E.02743
G1 X101.405 Y86.541 E.02305
G1 X101.67 Y86.691 E.00741
G1 X102.237 Y86.967 E.01534
G1 X102.852 Y87.167 E.01573
G1 X103.541 Y87.303 E.01708
G1 X104.199 Y87.347 E.01604
;WIDTH:0.43515
G1 X104.609 Y87.365 E.01094
;WIDTH:0.4703
G1 X104.959 Y87.38 E.01016
G1 X104.959 Y87.38 F9000
G1 X103.894 Y87.694
;WIDTH:0.399999
G1 F6000
G1 X103.704 Y88 E.00876
G1 X103.57 Y88.387 E.00996
G1 X102.935 Y89.083 E.02292
G1 X102.641 Y89.554 E.01351
G1 X102.463 Y90.044 E.01268
G1 X102.418 Y90.618 E.014
G1 X102.512 Y91.127 E.01259
G1 X91.798 Y91.127 E.26061
G1 X91.604 Y91.141 E.00473
G1 X91.164 Y91.251 E.01103
G1 X91.163 Y80.05 E.27245
G1 X91.197 Y79.478 E.01394
G1 X91.292 Y78.963 E.01274
G1 X91.447 Y78.463 E.01273
G1 X91.662 Y77.986 E.01273
G1 X91.933 Y77.538 E.01274
G1 X92.256 Y77.126 E.01273
G1 X92.626 Y76.756 E.01273
G1 X93.038 Y76.433 E.01273
G1 X93.476 Y76.168 E.01245
G1 X93.943 Y75.966 E.01238
G1 X94.433 Y75.8 E.01258
G1 X95.263 Y75.674 E.02042
G1 X98.283 Y75.673 E.07346
G1 X97.993 Y76.006 E.01074
G1 X97.678 Y76.493 E.01411
G1 X97.468 Y77.029 E.014
G1 X97.425 Y77.524 E.01209
G1 X97.48 Y78.046 E.01277
G1 X97.64 Y78.44 E.01034
G1 X98.097 Y79.127 E.02007
G1 X98.54 Y79.589 E.01557
G1 X98.552 Y82.401 E.0684
G1 X98.569 Y82.6 E.00486
G1 X98.735 Y83.507 E.02243
G1 X99.001 Y84.278 E.01984
G1 X99.217 Y84.703 E.0116
G1 X99.62 Y85.367 E.01889
G1 X100.428 Y86.263 E.02935
G1 X101.184 Y86.833 E.02303
G1 X101.505 Y87.018 E.00901
G1 X102.121 Y87.313 E.01661
G1 X102.777 Y87.525 E.01677
G1 X103.341 Y87.644 E.01402
G1 X103.834 Y87.689 E.01204
G1 E-5 F3600
G1 X103.834 Y87.689 F9000
G1 X101.362 Y85.604
G1 X101.254 Y85.512
G1 X101.115 Y85.392
G1 X101.015 Y85.294
G1 X100.884 Y85.164
G1 X100.791 Y85.058
G1 X100.67 Y84.918
G1 X100.583 Y84.805
G1 X100.473 Y84.657
G1 X100.393 Y84.537
G1 X100.294 Y84.38
G1 X100.223 Y84.255
G1 X100.135 Y84.09
G1 X100.073 Y83.961
G1 X99.997 Y83.787
G1 X99.944 Y83.655
G1 X99.882 Y83.476
G1 X99.839 Y83.341
G1 X99.79 Y83.157
G1 X99.757 Y83.022
G1 X98.549 Y77.756
G1 X98.524 Y77.63
G1 X98.515 Y77.5
G1 X98.524 Y77.37
G1 X98.549 Y77.244
G1 X98.589 Y77.124
G1 X98.642 Y77.008
G1 X99.651 Y75.273
G1 X100.092 Y75.273
G1 X100.092 Y74.92
G1 E5 F2400
;WIDTH:0.356236
G1 F6000
G1 X100.183 Y74.916 E.00195
;WIDTH:0.35143
G1 X130.817 Y74.914 E.64617
G1 E-5 F3600
G1 X130.817 Y74.914 F9000
G1 X130.817 Y75.273
G1 X131.349 Y75.273
G1 X132.358 Y77.008
G1 X132.411 Y77.124
G1 X132.451 Y77.244
G1 X132.476 Y77.37
G1 X132.485 Y77.5
G1 X132.476 Y77.63
G1 X132.451 Y77.756
G1 X131.243 Y83.022
G1 X131.21 Y83.157
G1 X131.161 Y83.341
G1 X131.118 Y83.476
G1 X131.056 Y83.655
G1 X131.003 Y83.787
G1 X130.927 Y83.961
G1 X130.865 Y84.09
G1 X130.777 Y84.255
G1 X130.706 Y84.38
G1 X130.607 Y84.537
G1 X130.527 Y84.657
G1 X130.417 Y84.805
G1 X130.33 Y84.918
G1 X130.209 Y85.058
G1 X130.116 Y85.164
G1 X129.985 Y85.294
G1 X129.885 Y85.392
G1 X129.746 Y85.513
G1 X129.638 Y85.604
G1 X129.523 Y85.69
G1 X129.376 Y85.799
G1 X129.253 Y85.878
G1 X129.098 Y85.975
G1 X128.969 Y86.046
G1 X128.806 Y86.132
G1 X128.679 Y86.191
G1 X128.511 Y86.264
G1 X128.38 Y86.314
G1 X128.208 Y86.375
G1 X128.074 Y86.416
G1 X127.897 Y86.463
G1 X127.761 Y86.496
G1 X127.581 Y86.53
G1 X127.443 Y86.553
G1 X127.261 Y86.573
G1 X127.122 Y86.587
G1 X104.651 Y88.151
G1 X91.435 Y92.304
G1 X91.268 Y92.384
G1 X91.163 Y92.46
G1 X91.111 Y92.5
G1 X90.984 Y92.636
G1 X90.882 Y92.791
G1 X90.809 Y92.959
G1 X90.765 Y93.137
G1 X90.758 Y93.221
G1 X90.751 Y93.301
G1 X90.751 Y95.527
G1 X90.758 Y95.607
G1 X90.765 Y95.692
G1 X90.809 Y95.869
G1 X90.882 Y96.038
G1 X90.984 Y96.193
G1 X91.111 Y96.329
G1 X91.163 Y96.368
G1 X91.268 Y96.444
G1 X91.435 Y96.524
G1 X91.606 Y96.572
G1 X91.692 Y96.582
G1 X91.783 Y96.588
G1 X93.04 Y96.589
G1 X93.315 Y96.589
G1 X93.568 Y96.588
G1 X93.569 Y96.971
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.569 Y102.369 E.1313
G1 X91.75 Y102.373 E.04425
G1 X91.245 Y102.528 E.01285
G1 X91.055 Y102.651 E.00551
G1 X90.804 Y102.945 E.0094
;WIDTH:0.439237
G1 X90.701 Y103.144 E.00604
;WIDTH:0.478475
G1 X90.597 Y103.343 E.00663
;WIDTH:0.517712
G1 X90.494 Y103.542 E.00721
G1 X90.474 Y103.315 E.00733
;WIDTH:0.478475
G1 X90.454 Y103.088 E.00673
;WIDTH:0.439237
G1 X90.435 Y102.861 E.00614
;WIDTH:0.399999
G1 X90.434 Y96.727 E.1492
;WIDTH:0.404937
G1 X90.441 Y95.927 E.01972
G1 X90.576 Y96.236 E.00831
;WIDTH:0.399999
G1 X90.848 Y96.584 E.01074
G1 X91.036 Y96.737 E.0059
G1 X91.513 Y96.932 E.01253
G1 X92.001 Y96.971 E.01191
G1 X93.509 Y96.971 E.03668
G1 X93.509 Y96.971 F9000
G1 X93.203 Y97.336
G1 F6000
G1 X93.203 Y102.004 E.11354
G1 X91.749 Y102.008 E.03537
G1 X91.423 Y102.068 E.00806
G1 X91.114 Y102.187 E.00805
G1 X90.8 Y102.39 E.00909
G1 X90.8 Y97.005 E.13098
G1 X91.151 Y97.203 E.0098
G1 X91.483 Y97.296 E.00839
G1 X92.001 Y97.336 E.01264
G1 X93.143 Y97.336 E.02778
G1 X93.143 Y97.336 F9000
G1 X92.837 Y97.702
G1 F6000
G1 X92.837 Y101.639 E.09576
G1 X91.748 Y101.642 E.02649
G1 X91.166 Y101.776 E.01453
G1 X91.165 Y97.58 E.10206
G1 X91.453 Y97.661 E.00728
G1 X92.001 Y97.702 E.01337
G1 X92.777 Y97.702 E.01888
G1 E-5 F3600
G1 X92.777 Y97.702 F9000
G1 X90.519 Y104.645
G1 E5 F2400
;WIDTH:0.567898
G1 F6000
G1 X90.497 Y104.394 E.00894
;WIDTH:0.524777
G1 X90.476 Y104.143 E.00822
;WIDTH:0.517712
G1 X90.494 Y103.542 E.01933
G1 E-5 F3600
G1 X90.494 Y103.542 F9000
G1 X90.927 Y103.617
G1 X90.901 Y103.763
G1 X90.887 Y104
G1 X90.901 Y104.237
G1 X90.948 Y104.507
G1 X91.059 Y104.778
G1 X91.114 Y104.866
G1 X91.26 Y105.038
G1 X91.475 Y105.184
G1 X91.643 Y105.234
G1 X91.766 Y105.249
G1 X92.073 Y105.25
G1 X92.857 Y105.252
G1 X92.856 Y105.63
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X93.569 Y105.631 E.01734
G1 X93.569 Y110.369 E.11525
G1 X91.75 Y110.373 E.04425
G1 X91.245 Y110.528 E.01285
G1 X91.055 Y110.651 E.00551
G1 X90.804 Y110.945 E.0094
;WIDTH:0.438835
G1 X90.701 Y111.144 E.00603
;WIDTH:0.477671
G1 X90.598 Y111.343 E.00661
;WIDTH:0.516506
G1 X90.494 Y111.542 E.0072
G1 X90.475 Y111.315 E.00731
;WIDTH:0.477671
G1 X90.455 Y111.088 E.00672
;WIDTH:0.438835
G1 X90.436 Y110.862 E.0061
;WIDTH:0.399999
G1 X90.435 Y105.184 E.13811
;WIDTH:0.441974
G1 X90.456 Y105.049 E.0037
;WIDTH:0.483949
G1 X90.477 Y104.914 E.00409
;WIDTH:0.525924
G1 X90.498 Y104.779 E.00447
;WIDTH:0.567898
G1 X90.519 Y104.645 E.00481
G1 X90.575 Y104.733 E.0037
;WIDTH:0.521458
G1 X90.63 Y104.822 E.00339
;WIDTH:0.475018
G1 X90.796 Y105.036 E.00794
;WIDTH:0.437509
G1 X90.961 Y105.25 E.00725
;WIDTH:0.399999
G1 X91.239 Y105.466 E.00856
G1 X91.439 Y105.564 E.00542
G1 X91.75 Y105.627 E.00772
G1 X92.796 Y105.629 E.02544
G1 X92.796 Y105.629 F9000
G1 X93.065 Y105.996
G1 F6000
G1 X93.203 Y105.996 E.00336
G1 X93.203 Y110.004 E.09749
G1 X91.749 Y110.008 E.03537
G1 X91.424 Y110.068 E.00804
G1 X91.114 Y110.187 E.00808
G1 X90.802 Y110.389 E.00904
G1 X90.801 Y105.588 E.11678
G1 X91.015 Y105.755 E.0066
G1 X91.348 Y105.918 E.00902
G1 X91.749 Y105.992 E.00992
G1 X93.005 Y105.996 E.03055
G1 X93.005 Y105.996 F9000
G1 X92.656 Y106.36
G1 F6000
G1 X92.837 Y106.361 E.0044
G1 X92.837 Y109.639 E.07973
G1 X91.748 Y109.642 E.02649
G1 X91.167 Y109.775 E.0145
G1 X91.167 Y106.228 E.08628
G1 X91.257 Y106.273 E.00245
G1 X91.748 Y106.358 E.01212
G1 X92.596 Y106.36 E.02063
G1 X92.596 Y106.36 F9000
G1 X91.276 Y107.239
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X91.883 Y106.633 E.02086
G1 X92.463 Y106.634 E.01411
G1 X91.441 Y107.656 E.03516
G1 X91.441 Y108.237 E.01413
G1 X92.563 Y107.115 E.0386
G1 X92.563 Y107.696 E.01413
G1 X91.441 Y108.818 E.0386
G1 X91.441 Y109.399 E.01413
G1 X92.563 Y108.278 E.03858
G1 X92.563 Y108.859 E.01413
G1 X91.89 Y109.532 E.02315
G1 E-5 F3600
G1 X91.89 Y109.532 F9000
G1 X91.059 Y111.222
G1 X90.948 Y111.493
G1 X90.901 Y111.763
G1 X90.887 Y112
G1 X90.901 Y112.237
G1 X91.278 Y115.239
G1 E5 F2400
G1 F3072.127
G1 X91.884 Y114.633 E.02085
G1 X92.464 Y114.634 E.01411
G1 X91.442 Y115.656 E.03516
G1 X91.442 Y116.237 E.01413
G1 X92.563 Y115.116 E.03856
G1 X92.563 Y115.697 E.01413
G1 X91.442 Y116.818 E.03856
G1 X91.443 Y117.399 E.01413
G1 X92.563 Y116.278 E.03854
G1 X92.563 Y116.859 E.01413
G1 X91.89 Y117.532 E.02315
G1 E-5 F3600
G1 X91.89 Y117.532 F9000
G1 X91.059 Y119.222
G1 X90.948 Y119.493
G1 X90.901 Y119.763
G1 X90.887 Y120
G1 X90.901 Y120.237
G1 X91.279 Y123.239
G1 E5 F2400
G1 F3072.127
G1 X91.885 Y122.633 E.02085
G1 X92.465 Y122.634 E.01411
G1 X91.443 Y123.656 E.03516
G1 X91.444 Y124.236 E.01411
G1 X92.563 Y123.117 E.03849
G1 X92.563 Y123.698 E.01413
G1 X91.444 Y124.817 E.03849
G1 X91.444 Y125.398 E.01413
G1 X92.563 Y124.279 E.03849
G1 X92.563 Y124.859 E.01411
G1 X91.891 Y125.532 E.02313
G1 E-5 F3600
G1 X91.891 Y125.532 F9000
G1 X91.059 Y127.222
G1 X90.948 Y127.493
G1 X90.901 Y127.763
G1 X90.887 Y128
G1 X90.901 Y128.237
G1 X90.948 Y128.507
G1 X91.059 Y128.778
G1 X91.96 Y130.468
G1 E5 F2400
G1 F3072.127
G1 X91.445 Y130.984 E.01773
G1 X91.445 Y131.504 E.01265
G1 X92.315 Y130.634 E.02993
G1 X92.564 Y130.635 E.00606
G1 X92.564 Y130.905 E.00657
G1 X91.445 Y132.025 E.03851
G1 X91.445 Y132.545 E.01265
G1 X92.564 Y131.425 E.03851
G1 X92.565 Y131.946 E.01267
G1 X91.445 Y133.065 E.03851
G1 X91.445 Y133.419 E.00861
G1 X91.645 Y133.386 E.00493
G1 X92.565 Y132.466 E.03165
G1 X92.577 Y132.974 E.01236
G1 X92.024 Y133.527 E.01902
G1 E-5 F3600
G1 X92.024 Y133.527 F9000
G1 X91.059 Y135.222
G1 X90.948 Y135.493
G1 X90.901 Y135.763
G1 X90.887 Y136
G1 X90.901 Y136.237
G1 X91.281 Y139.166
G1 E5 F2400
G1 F3072.127
G1 X91.809 Y138.638 E.01816
G1 X92.359 Y138.638 E.01338
G1 X91.446 Y139.551 E.03141
G1 X91.446 Y140.101 E.01338
G1 X92.908 Y138.639 E.05029
G1 X93.458 Y138.639 E.01338
G1 X91.446 Y140.651 E.06921
G1 X91.446 Y140.911 E.00632
G1 X91.808 Y140.838 E.00898
G1 X94.007 Y138.64 E.07563
G1 X94.211 Y138.64 E.00496
G1 X94.339 Y138.858 E.00615
G1 X92.359 Y140.838 E.06811
G1 X92.91 Y140.837 E.0134
G1 X94.558 Y139.189 E.05669
G1 X94.776 Y139.52 E.00964
G1 X93.461 Y140.836 E.04525
G1 X94.012 Y140.835 E.0134
G1 X95.013 Y139.834 E.03443
G1 X95.252 Y140.145 E.00954
G1 X94.562 Y140.834 E.02372
G1 X95.113 Y140.834 E.0134
G1 X95.511 Y140.436 E.01369
G1 X95.769 Y140.727 E.00946
G1 X95.499 Y140.997 E.00929
G1 E-5 F3600
G1 X95.499 Y140.997 F9000
G1 X91.511 Y141.343
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.558216
G1 F1200
G1 X91.804 Y141.283 E.01042
;WIDTH:0.562138
G1 X96.201 Y141.279 E.15438
G1 E-5 F3600
G1 X96.201 Y141.279 F9000
G1 X91.475 Y142.816
G1 X91.26 Y142.962
G1 X91.114 Y143.134
G1 X91.059 Y143.222
G1 X90.948 Y143.493
G1 X90.901 Y143.763
G1 X90.887 Y144
G1 X90.901 Y144.237
G1 X91.283 Y147.656
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X91.768 Y147.171 E.01668
G1 X92.283 Y147.173 E.01253
G1 X91.447 Y148.009 E.02876
G1 X91.447 Y148.526 E.01258
G1 X92.801 Y147.173 E.04656
G1 X93.318 Y147.173 E.01258
G1 X91.639 Y148.852 E.05776
G1 X92.179 Y148.829 E.01315
G1 X93.836 Y147.172 E.057
G1 X94.354 Y147.172 E.0126
G1 X92.697 Y148.829 E.057
G1 X93.214 Y148.829 E.01258
G1 X94.871 Y147.172 E.057
G1 X95.389 Y147.172 E.0126
G1 X93.732 Y148.829 E.057
G1 X94.25 Y148.829 E.0126
G1 X95.907 Y147.172 E.057
G1 X96.425 Y147.171 E.0126
G1 X94.767 Y148.828 E.05702
G1 X95.285 Y148.828 E.0126
G1 X96.942 Y147.171 E.057
G1 X97.46 Y147.171 E.0126
G1 X95.803 Y148.828 E.057
G1 X96.32 Y148.828 E.01258
G1 X97.978 Y147.171 E.05702
G1 X98.495 Y147.171 E.01258
G1 X96.838 Y148.828 E.057
G1 X97.356 Y148.828 E.0126
G1 X99.013 Y147.17 E.05702
G1 X99.531 Y147.17 E.0126
G1 X97.873 Y148.827 E.05702
G1 X98.391 Y148.827 E.0126
G1 X100.048 Y147.17 E.057
G1 X100.566 Y147.17 E.0126
G1 X98.909 Y148.827 E.057
G1 X99.426 Y148.827 E.01258
G1 X101.084 Y147.17 E.05702
G1 X101.602 Y147.169 E.0126
G1 X99.944 Y148.827 E.05703
G1 X100.462 Y148.827 E.0126
G1 X102.119 Y147.169 E.05702
G1 X102.637 Y147.169 E.0126
G1 X100.979 Y148.827 E.05703
G1 X101.497 Y148.826 E.0126
G1 X103.155 Y147.169 E.05702
G1 X103.672 Y147.169 E.01258
G1 X102.015 Y148.826 E.057
G1 X102.533 Y148.826 E.0126
G1 X104.19 Y147.168 E.05702
G1 X104.708 Y147.168 E.0126
G1 X103.05 Y148.826 E.05703
G1 X103.568 Y148.826 E.0126
G1 X105.226 Y147.168 E.05703
G1 X105.785 Y147.126 E.01364
G1 X104.086 Y148.826 E.05846
G1 X104.603 Y148.825 E.01258
G1 X108.896 Y144.533 E.14766
G1 X109.414 Y144.532 E.0126
G1 X105.121 Y148.825 E.14768
G1 X105.619 Y148.845 E.01212
G1 X109.933 Y144.531 E.1484
G1 X110.451 Y144.53 E.0126
G1 X106.033 Y148.948 E.15198
G1 X106.39 Y149.109 E.00953
G1 X111.044 Y144.455 E.16009
G1 X111.502 Y144.246 E.01225
G1 X111.852 Y143.963 E.01095
G1 X112.054 Y143.963 E.00491
G1 X106.69 Y149.326 E.1845
G1 X106.943 Y149.591 E.00891
G1 X112.571 Y143.963 E.1936
G1 X113.089 Y143.963 E.0126
G1 X107.144 Y149.907 E.20449
G1 X107.287 Y150.281 E.00974
G1 X113.606 Y143.963 E.21735
G1 X114.124 Y143.963 E.0126
G1 X107.19 Y150.896 E.23851
G1 X107.235 Y151.369 E.01156
G1 X114.641 Y143.963 E.25476
G1 X115.159 Y143.963 E.0126
G1 X107.236 Y151.885 E.27253
G1 X107.237 Y152.402 E.01258
G1 X115.676 Y143.963 E.2903
G1 X116.194 Y143.963 E.0126
G1 X107.21 Y152.946 E.30903
G1 X107.099 Y153.396 E.01127
G1 X107.213 Y153.46 E.00318
G1 X116.711 Y143.963 E.32671
G1 X117.229 Y143.963 E.0126
G1 X106.156 Y155.035 E.38089
G1 X106.653 Y155.056 E.0121
G1 X117.746 Y143.963 E.38159
G1 X118.264 Y143.963 E.0126
G1 X107.17 Y155.056 E.38161
G1 X107.688 Y155.056 E.0126
G1 X118.781 Y143.963 E.38159
G1 X119.149 Y143.963 E.00895
G1 X119.212 Y144.049 E.00259
G1 X108.206 Y155.056 E.37862
G1 X108.723 Y155.056 E.01258
G1 X119.52 Y144.258 E.37143
G1 X119.874 Y144.422 E.00949
G1 X109.241 Y155.056 E.36579
G1 X109.758 Y155.056 E.01258
G1 X120.288 Y144.526 E.36223
G1 X120.802 Y144.529 E.0125
G1 X110.276 Y155.056 E.36211
G1 X110.793 Y155.055 E.01258
G1 X121.318 Y144.531 E.36204
G1 X121.835 Y144.532 E.01258
G1 X111.311 Y155.055 E.362
G1 X111.828 Y155.055 E.01258
G1 X122.351 Y144.533 E.36197
G1 X122.867 Y144.534 E.01255
G1 X112.346 Y155.055 E.36192
G1 X112.863 Y155.055 E.01258
G1 X123.384 Y144.535 E.3619
G1 X123.763 Y144.536 E.00922
G1 X123.763 Y144.673 E.00333
G1 X113.381 Y155.055 E.35713
G1 X113.899 Y155.055 E.0126
G1 X123.828 Y145.125 E.34157
G1 X123.912 Y145.389 E.00674
G1 X123.644 Y145.52 E.00726
G1 X123.721 Y145.751 E.00592
G1 X114.416 Y155.055 E.32007
G1 X114.934 Y155.055 E.0126
G1 X123.87 Y146.119 E.30739
G1 X124.079 Y146.427 E.00905
G1 X115.451 Y155.055 E.2968
G1 X115.969 Y155.055 E.0126
G1 X124.33 Y146.693 E.28763
G1 X124.634 Y146.907 E.00904
G1 X116.486 Y155.055 E.28029
G1 X117.004 Y155.055 E.0126
G1 X124.996 Y147.063 E.27492
G1 X125.427 Y147.15 E.0107
G1 X117.521 Y155.055 E.27194
G1 X118.039 Y155.055 E.0126
G1 X125.919 Y147.175 E.27107
G1 X126.437 Y147.175 E.0126
G1 X118.392 Y155.219 E.27673
G1 E-5 F3600
G1 X118.392 Y155.219 F9000
G1 X124.946 Y154.876
G1 E5 F2400
G1 F3072.127
G1 X124.767 Y155.054 E.00614
G1 X124.25 Y155.054 E.01258
G1 X124.508 Y154.796 E.00888
G1 X124.21 Y154.576 E.00901
G1 X123.732 Y155.054 E.01644
G1 X123.214 Y155.054 E.0126
G1 X123.987 Y154.282 E.02657
G1 X123.801 Y153.95 E.00926
G1 X122.697 Y155.055 E.03799
G1 X122.179 Y155.055 E.0126
G1 X123.883 Y153.351 E.05862
G1 X123.788 Y152.929 E.01052
G1 X121.662 Y155.055 E.07313
G1 X121.144 Y155.055 E.0126
G1 X123.763 Y152.436 E.09009
G1 X123.763 Y151.918 E.0126
G1 X120.627 Y155.055 E.10789
G1 X120.109 Y155.055 E.0126
G1 X123.763 Y151.401 E.1257
G1 X123.831 Y150.815 E.01435
G1 X119.592 Y155.055 E.14584
G1 X119.074 Y155.055 E.0126
G1 X123.64 Y150.489 E.15707
G1 X123.838 Y149.936 E.01429
G1 X124.169 Y149.458 E.01414
G1 X124.66 Y149.075 E.01515
G1 X125.256 Y148.873 E.01531
G1 X126.954 Y147.175 E.05841
G1 X127.472 Y147.175 E.0126
G1 X125.821 Y148.825 E.05678
G1 X126.339 Y148.825 E.0126
G1 X127.989 Y147.175 E.05676
G1 X128.507 Y147.175 E.0126
G1 X126.856 Y148.826 E.05679
G1 X127.373 Y148.826 E.01258
G1 X129.024 Y147.174 E.05681
G1 X129.542 Y147.174 E.0126
G1 X127.891 Y148.826 E.05681
G1 X128.408 Y148.826 E.01258
G1 X130.06 Y147.174 E.05683
G1 X130.577 Y147.174 E.01258
G1 X128.925 Y148.826 E.05683
G1 X129.443 Y148.826 E.0126
G1 X131.095 Y147.174 E.05683
G1 X131.612 Y147.174 E.01258
G1 X129.96 Y148.826 E.05683
G1 X130.477 Y148.827 E.01258
G1 X132.13 Y147.174 E.05686
G1 X132.647 Y147.174 E.01258
G1 X130.995 Y148.827 E.05685
G1 X131.512 Y148.827 E.01258
G1 X133.165 Y147.174 E.05686
G1 X133.683 Y147.174 E.0126
G1 X132.029 Y148.827 E.05688
G1 X132.547 Y148.827 E.0126
G1 X134.2 Y147.174 E.05686
G1 X134.718 Y147.174 E.0126
G1 X133.064 Y148.827 E.05688
G1 X133.581 Y148.828 E.01258
G1 X135.235 Y147.174 E.0569
G1 X135.753 Y147.174 E.0126
G1 X134.099 Y148.828 E.0569
G1 X134.616 Y148.828 E.01258
G1 X136.27 Y147.174 E.0569
G1 X136.788 Y147.173 E.0126
G1 X135.133 Y148.828 E.05693
G1 X135.651 Y148.828 E.0126
G1 X137.306 Y147.173 E.05693
G1 X137.823 Y147.173 E.01258
G1 X136.168 Y148.828 E.05693
G1 X136.685 Y148.829 E.01258
G1 X138.341 Y147.173 E.05697
G1 X138.858 Y147.173 E.01258
G1 X137.203 Y148.829 E.05695
G1 X137.72 Y148.829 E.01258
G1 X139.4 Y147.149 E.05779
G1 X139.561 Y147.129 E.00395
G1 X139.561 Y147.505 E.00915
G1 X138.237 Y148.829 E.04554
G1 X138.755 Y148.829 E.0126
G1 X139.561 Y148.023 E.02773
G1 X139.561 Y148.54 E.01258
G1 X139.108 Y148.994 E.0156
G1 E-5 F3600
G1 X139.108 Y148.994 F9000
G1 X140.052 Y144.507
G1 X140.113 Y144
G1 X139.118 Y141.003
G1 E5 F2400
G1 F3072.127
G1 X139.56 Y140.56 E.01522
G1 X139.56 Y140.037 E.01272
G1 X138.759 Y140.838 E.02755
G1 X138.236 Y140.837 E.01272
G1 X139.56 Y139.513 E.04554
G1 X139.56 Y138.99 E.01272
G1 X137.714 Y140.836 E.0635
G1 X137.191 Y140.835 E.01272
G1 X139.424 Y138.603 E.0768
G1 X138.865 Y138.638 E.01362
G1 X136.668 Y140.835 E.07558
G1 X136.145 Y140.834 E.01272
G1 X138.341 Y138.638 E.07554
G1 X137.817 Y138.639 E.01275
G1 X135.622 Y140.833 E.07549
G1 X135.138 Y140.832 E.01177
G1 X137.457 Y138.475 E.08043
G1 E-5 F3600
G1 X137.457 Y138.475 F9000
G1 X134.806 Y141.279
G1 E5 F2400
;TYPE:Solid infill
;WIDTH:0.562006
G1 F1200
G1 X139.2 Y141.285 E.15423
;WIDTH:0.553864
G1 X139.494 Y141.345 E.01037
G1 E-5 F3600
G1 X139.494 Y141.345 F9000
G1 X140.099 Y136.237
G1 X140.113 Y136
G1 X140.052 Y135.493
G1 X139.941 Y135.222
G1 X139.076 Y133.533
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X139.559 Y133.05 E.01661
G1 X139.559 Y132.529 E.01267
G1 X138.722 Y133.366 E.02879
G1 X138.398 Y133.364 E.00788
G1 X138.408 Y133.16 E.00497
G1 X139.559 Y132.009 E.03959
G1 X139.559 Y131.489 E.01265
G1 X138.437 Y132.611 E.0386
G1 X138.437 Y132.091 E.01265
G1 X139.559 Y130.968 E.03861
G1 X139.559 Y130.577 E.00951
G1 X139.401 Y130.606 E.00391
G1 X138.437 Y131.57 E.03316
G1 X138.437 Y131.05 E.01265
G1 X139.018 Y130.468 E.02
G1 E-5 F3600
G1 X139.018 Y130.468 F9000
G1 X139.941 Y128.778
G1 X140.052 Y128.507
G1 X140.099 Y128.237
G1 X140.113 Y128
G1 X140.099 Y127.763
G1 X140.052 Y127.493
G1 X139.941 Y127.222
G1 X139.065 Y125.532
G1 E5 F2400
G1 F3072.127
G1 X139.558 Y125.038 E.01698
G1 X139.558 Y124.52 E.0126
G1 X138.712 Y125.366 E.0291
G1 X138.437 Y125.366 E.00669
G1 X138.437 Y125.122 E.00594
G1 X139.558 Y124.001 E.03856
G1 X139.558 Y123.482 E.01262
G1 X138.437 Y124.604 E.03858
G1 X138.437 Y124.085 E.01262
G1 X139.558 Y122.964 E.03856
G1 X139.558 Y122.577 E.00941
G1 X139.396 Y122.607 E.00401
G1 X138.437 Y123.566 E.03299
G1 X138.437 Y123.047 E.01262
G1 X139.016 Y122.468 E.01992
G1 E-5 F3600
G1 X139.016 Y122.468 F9000
G1 X139.941 Y120.778
G1 X140.052 Y120.507
G1 X140.113 Y120
G1 X138.955 Y117.531
G1 E5 F2400
G1 F3072.127
G1 X139.557 Y116.93 E.02069
G1 X139.557 Y116.348 E.01416
G1 X138.539 Y117.366 E.03502
G1 X138.437 Y117.366 E.00248
G1 X138.437 Y116.887 E.01165
G1 X139.557 Y115.767 E.03853
G1 X139.557 Y115.185 E.01416
G1 X138.437 Y116.305 E.03853
G1 X138.437 Y115.723 E.01416
G1 X139.557 Y114.577 E.03898
G1 X138.945 Y114.633 E.01495
G1 X138.272 Y115.306 E.02315
G1 E-5 F3600
G1 X138.272 Y115.306 F9000
G1 X139.886 Y112.866
G1 X139.941 Y112.778
G1 X140.052 Y112.507
G1 X140.113 Y112
G1 X138.954 Y109.531
G1 E5 F2400
G1 F3072.127
G1 X139.556 Y108.93 E.02069
G1 X139.556 Y108.348 E.01416
G1 X138.538 Y109.366 E.03502
G1 X138.437 Y109.366 E.00246
G1 X138.437 Y108.886 E.01168
G1 X139.556 Y107.767 E.03849
G1 X139.556 Y107.185 E.01416
G1 X138.437 Y108.304 E.03849
G1 X138.437 Y107.723 E.01413
G1 X139.556 Y106.577 E.03896
G1 X138.945 Y106.633 E.01492
G1 X138.272 Y107.306 E.02315
G1 E-5 F3600
G1 X138.272 Y107.306 F9000
G1 X139.886 Y104.866
G1 X139.941 Y104.778
G1 X140.052 Y104.507
G1 X140.113 Y104
G1 X139.029 Y101.532
G1 E5 F2400
G1 F3072.127
G1 X139.555 Y101.005 E.01811
G1 X139.555 Y100.474 E.01292
G1 X138.663 Y101.366 E.03068
G1 X138.437 Y101.366 E.0055
G1 X138.437 Y101.061 E.00742
G1 X139.555 Y99.943 E.03846
G1 X139.555 Y99.413 E.01289
G1 X138.437 Y100.531 E.03846
G1 X138.437 Y100 E.01292
G1 X139.555 Y98.882 E.03846
G1 X139.555 Y98.351 E.01292
G1 X138.437 Y99.469 E.03846
G1 X138.437 Y98.938 E.01292
G1 X139.423 Y97.951 E.03394
G1 X138.868 Y97.976 E.01351
G1 X138.272 Y98.571 E.02048
G1 E-5 F3600
G1 X138.272 Y98.571 F9000
G1 X140.017 Y96.193
G1 X140.118 Y96.038
G1 X140.191 Y95.869
G1 X140.236 Y95.692
G1 X140.243 Y95.607
G1 X140.249 Y95.527
G1 X140.249 Y93.301
G1 X140.243 Y93.221
G1 X140.236 Y93.137
G1 X140.191 Y92.959
G1 X140.118 Y92.791
G1 X139.044 Y91.017
G1 E5 F2400
G1 F3072.127
G1 X139.554 Y90.507 E.01754
G1 X139.554 Y89.981 E.01279
G1 X138.682 Y90.852 E.02998
G1 X138.156 Y90.852 E.01279
G1 X139.553 Y89.455 E.04806
G1 X139.553 Y88.928 E.01282
G1 X137.629 Y90.852 E.06618
G1 X137.103 Y90.852 E.01279
G1 X139.553 Y88.402 E.08428
G1 X139.553 Y87.876 E.01279
G1 X136.577 Y90.852 E.10237
G1 X136.05 Y90.852 E.01282
G1 X139.553 Y87.35 E.12048
G1 X139.553 Y86.823 E.01282
G1 X135.524 Y90.852 E.1386
G1 X134.998 Y90.852 E.01279
G1 X139.553 Y86.297 E.15669
G1 X139.553 Y85.771 E.01279
G1 X134.471 Y90.852 E.1748
G1 X133.945 Y90.852 E.01279
G1 X139.553 Y85.244 E.19291
G1 X139.553 Y84.718 E.01279
G1 X133.419 Y90.852 E.21101
G1 X132.892 Y90.852 E.01282
G1 X139.553 Y84.192 E.22912
G1 X139.553 Y83.665 E.01282
G1 X132.366 Y90.852 E.24723
G1 X131.839 Y90.852 E.01282
G1 X139.553 Y83.139 E.26534
G1 X139.553 Y82.613 E.01279
G1 X131.313 Y90.852 E.28343
G1 X130.787 Y90.852 E.01279
G1 X139.552 Y82.087 E.30151
G1 X139.552 Y81.56 E.01282
G1 X130.26 Y90.852 E.31964
G1 X129.734 Y90.852 E.01279
G1 X139.552 Y81.034 E.33773
G1 X139.552 Y80.508 E.01279
G1 X129.208 Y90.852 E.35583
G1 X128.816 Y90.852 E.00954
G1 X128.83 Y90.703 E.00364
G1 X139.552 Y79.981 E.36883
G1 X139.509 Y79.499 E.01177
G1 X128.823 Y90.184 E.36757
G1 X128.735 Y89.746 E.01087
G1 X139.439 Y79.042 E.36821
G1 X139.306 Y78.649 E.01009
G1 X128.573 Y89.382 E.36921
G1 X128.369 Y89.059 E.00929
G1 X139.16 Y78.268 E.3712
G1 X138.97 Y77.932 E.00939
G1 X131.935 Y84.966 E.24198
G1 X132.241 Y84.403 E.01559
G1 X132.395 Y83.98 E.01095
G1 X138.765 Y77.61 E.21912
G1 X138.526 Y77.323 E.00908
G1 X132.603 Y83.246 E.20375
G1 X132.701 Y82.622 E.01536
G1 X138.271 Y77.052 E.1916
G1 X137.984 Y76.813 E.00908
G1 X132.719 Y82.078 E.18111
G1 X132.722 Y81.548 E.01289
G1 X137.678 Y76.592 E.17048
G1 X137.342 Y76.402 E.00939
G1 X132.726 Y81.018 E.15879
G1 X132.729 Y80.488 E.01289
G1 X136.979 Y76.238 E.1462
G1 X136.588 Y76.103 E.01006
G1 X132.733 Y79.958 E.13261
G1 X132.734 Y79.702 E.00623
G1 X133.235 Y79.147 E.01819
G1 X133.606 Y78.559 E.01691
G1 X136.163 Y76.002 E.08796
G1 X135.685 Y75.953 E.01169
G1 X133.846 Y77.792 E.06326
G1 X133.844 Y77.267 E.01277
G1 X135.16 Y75.951 E.04527
G1 X134.636 Y75.949 E.01275
G1 X133.735 Y76.851 E.03101
G1 X133.603 Y76.456 E.01013
G1 X134.111 Y75.948 E.01747
G1 X133.587 Y75.946 E.01275
G1 X133.288 Y76.245 E.01029
G1 E-5 F3600
G1 X133.288 Y76.245 F9000
G1 X131.161 Y83.341
G1 X131.118 Y83.476
G1 X131.056 Y83.655
G1 X131.003 Y83.787
G1 X130.927 Y83.961
G1 X130.865 Y84.09
G1 X130.777 Y84.255
G1 X130.706 Y84.38
G1 X130.607 Y84.537
G1 X130.527 Y84.657
G1 X130.417 Y84.805
G1 X130.33 Y84.918
G1 X128.208 Y87.641
G1 E5 F2400
G1 F3072.127
G1 X127.661 Y88.188 E.01882
G1 X127.898 Y88.477 E.00909
G1 X128.712 Y87.664 E.02798
G1 X129.69 Y87.212 E.02621
G1 X128.037 Y88.865 E.05686
G1 E-5 F3600
G1 X128.037 Y88.865 F9000
G1 X126.349 Y88.151
G1 X104.651 Y88.151
G1 X101.625 Y91.017
G1 E5 F2400
G1 F3072.127
G1 X102.144 Y90.498 E.01785
G1 X102.219 Y89.902 E.01461
G1 X101.269 Y90.852 E.03268
G1 X100.75 Y90.852 E.01262
G1 X103.317 Y88.25 E.08891
G1 X103.436 Y87.931 E.00828
G1 X103.19 Y87.892 E.00606
G1 X100.23 Y90.852 E.10182
G1 X99.71 Y90.852 E.01265
G1 X102.762 Y87.8 E.10499
G1 X102.361 Y87.682 E.01017
G1 X99.19 Y90.852 E.10906
G1 X98.67 Y90.852 E.01265
G1 X101.976 Y87.547 E.11371
G1 X101.625 Y87.378 E.00948
G1 X98.151 Y90.852 E.1195
G1 X97.631 Y90.852 E.01265
G1 X101.275 Y87.208 E.12535
G1 X100.958 Y87.006 E.00914
G1 X97.111 Y90.852 E.13232
G1 X96.591 Y90.852 E.01265
G1 X100.661 Y86.782 E.14001
G1 X100.365 Y86.559 E.00901
G1 X96.071 Y90.852 E.14769
G1 X95.552 Y90.852 E.01262
G1 X100.087 Y86.317 E.156
G1 X99.84 Y86.044 E.00896
G1 X95.032 Y90.852 E.16539
G1 X94.512 Y90.852 E.01265
G1 X99.6 Y85.765 E.17501
G1 X99.365 Y85.48 E.00899
G1 X93.992 Y90.852 E.18481
G1 X93.472 Y90.852 E.01265
G1 X99.162 Y85.163 E.19572
G1 X98.974 Y84.831 E.00928
G1 X92.953 Y90.852 E.20712
G1 X92.433 Y90.852 E.01265
G1 X98.796 Y84.489 E.21888
G1 X98.654 Y84.112 E.0098
G1 X91.913 Y90.852 E.23187
G1 X91.439 Y90.893 E.01157
G1 X91.439 Y90.807 E.00209
G1 X98.52 Y83.725 E.2436
G1 X98.408 Y83.318 E.01027
G1 X91.438 Y90.287 E.23975
G1 X91.438 Y89.768 E.01262
G1 X98.335 Y82.871 E.23725
G1 X98.278 Y82.408 E.01135
G1 X91.438 Y89.248 E.23529
G1 X91.438 Y88.728 E.01265
G1 X98.276 Y81.89 E.23522
G1 X98.274 Y81.373 E.01258
G1 X91.438 Y88.209 E.23515
G1 X91.438 Y87.689 E.01265
G1 X98.272 Y80.855 E.23509
G1 X98.269 Y80.338 E.01258
G1 X91.438 Y87.169 E.23498
G1 X91.438 Y86.649 E.01265
G1 X98.267 Y79.82 E.23491
G1 X98.267 Y79.701 E.00289
G1 X98.071 Y79.496 E.0069
G1 X91.438 Y86.13 E.22819
G1 X91.438 Y85.61 E.01265
G1 X97.826 Y79.222 E.21974
G1 X97.613 Y78.914 E.00911
G1 X91.438 Y85.09 E.21243
G1 X91.438 Y84.571 E.01262
G1 X97.418 Y78.59 E.20573
G1 X97.25 Y78.239 E.00947
G1 X91.437 Y84.051 E.19995
G1 X91.437 Y83.531 E.01265
G1 X97.173 Y77.795 E.19731
G1 X97.17 Y77.279 E.01255
G1 X91.437 Y83.011 E.19719
G1 X91.437 Y82.492 E.01262
G1 X97.332 Y76.597 E.20278
G1 X97.704 Y75.948 E.0182
G1 X97.462 Y75.948 E.00589
G1 X91.437 Y81.972 E.20724
G1 X91.437 Y81.452 E.01265
G1 X96.942 Y75.948 E.18935
G1 X96.422 Y75.948 E.01265
G1 X91.437 Y80.933 E.17148
G1 X91.437 Y80.413 E.01265
G1 X95.902 Y75.948 E.15359
G1 X95.382 Y75.948 E.01265
G1 X91.448 Y79.883 E.13534
G1 X91.508 Y79.302 E.01421
G1 X94.787 Y76.024 E.11278
G1 X94.089 Y76.202 E.01752
G1 X91.693 Y78.598 E.08242
G1 X92.159 Y77.694 E.02474
G1 X92.457 Y77.314 E.01175
G1 X93.472 Y76.299 E.03492
G1 E-5 F3600
G1 X93.472 Y76.299 F9000
G1 X90.765 Y93.137
G1 X90.758 Y93.221
G1 X90.751 Y93.301
G1 X90.751 Y95.527
G1 X90.758 Y95.607
G1 X90.765 Y95.692
G1 X91.275 Y98.514
G1 E5 F2400
G1 F3072.127
G1 X91.826 Y97.963 E.01895
G1 X92.343 Y97.976 E.01258
G1 X91.44 Y98.88 E.03108
G1 X91.44 Y99.409 E.01287
G1 X92.563 Y98.286 E.03863
G1 X92.563 Y98.816 E.01289
G1 X91.44 Y99.939 E.03863
G1 X91.44 Y100.469 E.01289
G1 X92.563 Y99.346 E.03863
G1 X92.563 Y99.876 E.01289
G1 X91.44 Y100.999 E.03863
G1 X91.44 Y101.423 E.01031
G1 X91.57 Y101.399 E.00322
G1 X92.563 Y100.406 E.03416
G1 X92.563 Y100.936 E.01289
G1 X91.967 Y101.532 E.0205
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X92.563 Y100.936 E-.40036
G1 X92.563 Y100.406 E-.25175
G1 X91.57 Y101.399 E-.66705
G1 X91.44 Y101.423 E-.06279
G1 X91.44 Y101.174 E-.11805
;WIPE_END
G1 X90.948 Y103.493 F9000
G1 X90.901 Y103.763
G1 X90.887 Y104
G1 X90.887 Y136
G1 X90.901 Y136.237
G1 X90.948 Y136.507
G1 X91.059 Y136.778
G1 X91.114 Y136.866
G1 X91.26 Y137.038
G1 X91.475 Y137.184
G1 X99.126 Y141.676
G1 X99.384 Y141.825
G1 X99.614 Y141.948
G1 X99.683 Y141.984
G1 X99.753 Y142.02
G1 X99.825 Y142.056
G1 X99.897 Y142.091
G1 X100.043 Y142.16
G1 X100.113 Y142.193
G1 X100.185 Y142.226
G1 X100.262 Y142.26
G1 X100.355 Y142.3
G1 X100.447 Y142.339
G1 X100.534 Y142.375
G1 X100.751 Y142.45
G1 X100.778 Y142.456
G1 X101.962 Y142.689
G1 X102.127 Y142.72
G1 X102.518 Y142.787
G1 X102.915 Y142.847
G1 X103.311 Y142.897
G1 X103.707 Y142.933
G1 X106.537 Y143.149
G1 X107.505 Y144.371
G1 E5 F2400
G1 F3072.127
G1 X107.237 Y144.639 E.00922
G1 X107.155 Y145.239 E.01473
G1 X107.859 Y144.535 E.02422
G1 X108.377 Y144.534 E.0126
G1 X107.079 Y145.832 E.04465
G1 X107.079 Y145.832 F9000
G1 X106.934 Y145.682
;TYPE:Solid infill
;WIDTH:0.411054
G1 F1200
G1 X106.838 Y145.85 E.00485
;WIDTH:0.447772
G1 X106.741 Y146.018 E.00534
;WIDTH:0.485102
G1 X106.529 Y146.261 E.00967
;WIDTH:0.522099
G1 X106.322 Y146.399 E.00807
;WIDTH:0.559096
G1 X106.114 Y146.537 E.00871
;WIDTH:0.572176
G1 X105.462 Y146.718 E.02421
;WIDTH:0.569096
G1 X91.809 Y146.722 E.48567
;WIDTH:0.576014
G1 X91.549 Y146.685 E.00946
G1 E-5 F3600
G1 X91.549 Y146.685 F9000
G1 X91.52 Y149.333
G1 E5 F2400
;WIDTH:0.565056
G1 F1200
G1 X91.805 Y149.28 E.01023
;WIDTH:0.575878
G1 X105.356 Y149.279 E.48815
;WIDTH:0.587588
G1 X105.784 Y149.344 E.01593
G1 X106.114 Y149.46 E.01287
;WIDTH:0.554786
G1 X106.323 Y149.603 E.00877
;WIDTH:0.524086
G1 X106.532 Y149.746 E.00825
;WIDTH:0.493386
G1 X106.685 Y149.93 E.00731
;WIDTH:0.446929
G1 X106.839 Y150.114 E.00659
;WIDTH:0.400472
G1 X106.933 Y150.321 E.00554
G1 E-5 F3600
G1 X106.933 Y150.321 F9000
G1 X105.129 Y154.654
G1 E5 F2400
;WIDTH:0.426152
G1 F1200
G1 X94.527 Y154.644 E.27633
;WIDTH:0.411977
G1 X93.783 Y154.644 E.01869
G1 X94.086 Y154.799 E.00855
G1 X94.5 Y154.928 E.01089
G1 X94.996 Y155.022 E.01268
;WIDTH:0.426152
G1 X95.396 Y155.044 E.01044
G1 X105.311 Y155.044 E.25842
;WIDTH:0.435439
G1 X105.506 Y155.038 E.00521
;WIDTH:0.475453
G1 X105.542 Y155.018 E.00121
;WIDTH:0.515466
G1 X105.579 Y154.998 E.00135
G1 X105.724 Y154.998 E.00464
;WIDTH:0.56308
G1 X105.792 Y154.732 E.00966
;WIDTH:0.589191
G1 X105.843 Y154.655 E.00341
G1 X105.7 Y154.662 E.00528
;WIDTH:0.552329
G1 X105.558 Y154.669 E.0049
;WIDTH:0.515466
G1 X105.435 Y154.661 E.00394
;WIDTH:0.469919
G1 X105.312 Y154.654 E.00357
;WIDTH:0.399999
G1 X105.844 Y154.655 E.01294
;WIDTH:0.594572
G1 X105.938 Y154.606 E.00395
;WIDTH:0.591862
G1 X106.202 Y154.452 E.01133
;WIDTH:0.555471
G1 X106.467 Y154.298 E.01063
;WIDTH:0.51908
G1 X106.623 Y154.12 E.00763
;WIDTH:0.485612
G1 X106.78 Y153.941 E.00715
G1 E-5 F3600
G1 X106.78 Y153.941 F9000
G1 X124.175 Y150.112
G1 E5 F2400
;WIDTH:0.455211
G1 F1200
G1 X124.335 Y149.917 E.00706
;WIDTH:0.485206
G1 X124.494 Y149.723 E.00752
;WIDTH:0.520281
G1 X124.737 Y149.573 E.00923
;WIDTH:0.555356
G1 X124.98 Y149.423 E.0099
;WIDTH:0.560768
G1 X125.503 Y149.291 E.01889
;WIDTH:0.573272
G1 X125.652 Y149.277 E.00537
G1 X139.195 Y149.28 E.48552
;WIDTH:0.565056
G1 X139.477 Y149.329 E.0101
G1 E-5 F3600
G1 X139.477 Y149.329 F9000
G1 X125.151 Y150.746
G1 X125.151 Y153.254
G1 X125.689 Y154.653
G1 E5 F2400
;WIDTH:0.424579
G1 F1200
G1 X136.089 Y154.64 E.26997
;WIDTH:0.403529
G1 X137.196 Y154.64 E.02719
G1 X137.203 Y154.672 E.0008
G1 X136.915 Y154.803 E.00777
G1 X136.135 Y155.004 E.01978
;WIDTH:0.424579
G1 X135.717 Y155.041 E.01089
G1 X125.689 Y155.042 E.26032
;WIDTH:0.465804
G1 X125.5 Y155.021 E.00546
;WIDTH:0.508039
G1 X125.311 Y155 E.00599
;WIDTH:0.545712
G1 X125.274 Y154.818 E.00632
;WIDTH:0.581544
G1 X125.16 Y154.649 E.00742
G1 X125.275 Y154.65 E.00419
;WIDTH:0.547074
G1 X125.391 Y154.651 E.00396
;WIDTH:0.512603
G1 X125.506 Y154.652 E.00366
G1 X125.391 Y154.651 E.00366
;WIDTH:0.547074
G1 X125.275 Y154.65 E.00396
;WIDTH:0.581544
G1 X125.141 Y154.638 E.0049
;WIDTH:0.578928
G1 X124.849 Y154.476 E.0121
;WIDTH:0.552711
G1 X124.557 Y154.314 E.01151
;WIDTH:0.526494
G1 X124.386 Y154.129 E.00825
;WIDTH:0.483536
G1 X124.214 Y153.943 E.00757
G1 E-5 F3600
G1 X124.214 Y153.943 F9000
G1 X124.075 Y145.693
G1 E5 F2400
;WIDTH:0.408192
G1 F1200
G1 X124.166 Y145.856 E.00464
;WIDTH:0.442048
G1 X124.256 Y146.019 E.00505
;WIDTH:0.46962
G1 X124.361 Y146.135 E.00453
;WIDTH:0.497192
G1 X124.466 Y146.251 E.00482
;WIDTH:0.523371
G1 X124.675 Y146.396 E.00827
;WIDTH:0.54955
G1 X124.884 Y146.542 E.00874
;WIDTH:0.57761
G1 X125.212 Y146.66 E.0126
G1 X125.64 Y146.721 E.01562
;WIDTH:0.574602
G1 X139.185 Y146.722 E.48679
;WIDTH:0.56903
G1 X139.481 Y146.675 E.01066
;LAYER_CHANGE
;Z:1.26
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;1.26
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X139.185 Y146.722 E-.14236
G1 X136.327 Y146.722 E-1.35764
;WIPE_END
G1 Z1.26 F9000
;AFTER_LAYER_CHANGE
;1.26
G1 Z1.26
G1 X125.935 Y139.44
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X125.97 Y139.417 E.00102
G1 X126 Y138.994 E.01031
G1 X126.725 Y138.354 E.02352
G1 X127.201 Y137.844 E.01697
G1 X127.326 Y137.499 E.00893
G1 X127.201 Y137.156 E.00888
G1 X126.712 Y136.633 E.01742
G1 X126 Y136.006 E.02308
G1 X126 Y103.974 E.77915
G1 X126.241 Y103.974 E.00586
G1 X126.386 Y103.904 E.00392
G1 X126.424 Y103.792 E.00288
G1 X126.424 Y98.457 E.12977
G1 X126.403 Y98.372 E.00213
G1 X126.241 Y98.274 E.00461
G1 X126 Y98.274 E.00586
G1 X126 Y93.263 E.12189
G1 X126.034 Y93.203 E.00168
G1 X138.037 Y93.204 E.29196
G1 X139.05 Y93.226 E.02465
G1 X139.206 Y93.362 E.00503
G1 X139.243 Y93.519 E.00392
G1 X139.243 Y95.333 E.04412
G1 X139.132 Y95.553 E.00599
G1 X138.932 Y95.624 E.00516
G1 X136.183 Y95.623 E.06687
G1 X136.074 Y95.66 E.0028
G1 X136 Y95.806 E.00398
G1 X135.996 Y132.558 E.89396
G1 X135.966 Y133.099 E.01318
G1 X135.888 Y133.772 E.01648
G1 X135.754 Y134.474 E.01738
G1 X135.583 Y135.126 E.0164
G1 X135.173 Y136.236 E.02878
G1 X134.883 Y136.843 E.01636
G1 X134.414 Y137.645 E.0226
G1 X134.002 Y138.228 E.01736
G1 X133.576 Y138.752 E.01643
G1 X132.932 Y139.422 E.0226
G1 X132.394 Y139.892 E.01738
G1 X131.858 Y140.302 E.01641
G1 X131.075 Y140.802 E.0226
G1 X130.441 Y141.132 E.01739
G1 X129.824 Y141.405 E.01641
G1 X128.945 Y141.708 E.02262
G1 X128.252 Y141.88 E.01737
G1 X127.59 Y142.001 E.01637
G1 X126.193 Y142.1 E.03407
G1 X120.85 Y142.1 E.12996
G1 X120.85 Y141.847 E.00615
G1 X120.797 Y141.718 E.00339
G1 X120.667 Y141.665 E.00341
G1 X110.333 Y141.665 E.25136
G1 X110.204 Y141.718 E.00339
G1 X110.15 Y141.847 E.0034
G1 X110.15 Y142.1 E.00615
G1 X104.337 Y142.089 E.1414
G1 X103.2 Y141.966 E.02782
G1 X102.502 Y141.827 E.01731
G1 X101.61 Y141.567 E.0226
G1 X100.98 Y141.323 E.01643
G1 X100.334 Y141.024 E.01731
G1 X99.141 Y140.302 E.03392
G1 X98.251 Y139.589 E.02774
G1 X97.739 Y139.097 E.01727
G1 X96.846 Y138.026 E.03392
G1 X96.236 Y137.062 E.02775
G1 X95.912 Y136.43 E.01728
G1 X95.416 Y135.127 E.03391
G1 X95.152 Y134.019 E.02771
G1 X95.033 Y133.099 E.02256
G1 X94.999 Y132.296 E.01955
G1 X94.999 Y95.806 E.88758
G1 X94.926 Y95.66 E.00397
G1 X94.816 Y95.623 E.00282
G1 X92.037 Y95.618 E.0676
G1 X91.821 Y95.504 E.00594
G1 X91.75 Y95.286 E.00558
G1 X91.75 Y93.599 E.04103
G1 X91.797 Y93.363 E.00585
G1 X91.906 Y93.252 E.00378
G1 X92.077 Y93.204 E.00432
G1 X104.942 Y93.205 E.31293
G1 X105 Y93.239 E.00164
G1 X105 Y98.274 E.12247
G1 X104.759 Y98.274 E.00586
G1 X104.625 Y98.332 E.00355
G1 X104.576 Y98.457 E.00327
G1 X104.576 Y103.792 E.12977
G1 X104.591 Y103.864 E.00179
G1 X104.759 Y103.974 E.00488
G1 X105 Y103.974 E.00586
G1 X105 Y136.006 E.77915
G1 X104.277 Y136.644 E.02345
G1 X103.841 Y137.095 E.01526
G1 X103.675 Y137.48 E.0102
G1 X103.804 Y137.849 E.00951
G1 X103.895 Y137.961 E.00351
G1 X104.288 Y138.367 E.01374
G1 X105 Y138.994 E.02308
G1 X105.009 Y139.373 E.00922
G1 X105.094 Y139.477 E.00327
G1 X105.182 Y139.5 E.00221
G1 X125.817 Y139.5 E.50193
G1 X125.849 Y139.497 E.00078
G1 X125.885 Y139.473 E.00105
G1 X125.885 Y139.473 F9000
G1 X126.199 Y139.698
;TYPE:Perimeter
G1 F6000
G1 X126.277 Y139.616 E.00275
G1 X126.339 Y139.487 E.00348
G1 X126.366 Y139.159 E.00801
G1 X126.992 Y138.604 E.02035
G1 X127.469 Y138.094 E.01699
G1 X127.586 Y137.899 E.00553
G1 X127.692 Y137.498 E.01009
G1 X127.586 Y137.101 E.00999
G1 X127.469 Y136.906 E.00553
G1 X126.954 Y136.359 E.01827
G1 X126.366 Y135.841 E.01906
G1 X126.366 Y104.279 E.76771
G1 X126.675 Y104.128 E.00837
G1 X126.745 Y104.009 E.00336
G1 X126.79 Y103.792 E.00539
G1 X126.79 Y98.457 E.12977
G1 X126.77 Y98.309 E.00363
G1 X126.642 Y98.082 E.00634
G1 X126.366 Y97.963 E.00731
G1 X126.366 Y93.569 E.10688
G1 X138.878 Y93.57 E.30434
G1 X138.882 Y95.256 E.04101
G1 X136.183 Y95.258 E.06565
G1 X135.854 Y95.367 E.00843
G1 X135.677 Y95.595 E.00702
G1 X135.635 Y95.806 E.00523
G1 X135.63 Y132.548 E.89371
G1 X135.602 Y133.068 E.01267
G1 X135.527 Y133.716 E.01587
G1 X135.398 Y134.393 E.01676
G1 X135.234 Y135.016 E.01567
G1 X134.836 Y136.093 E.02793
G1 X134.56 Y136.671 E.01558
G1 X134.106 Y137.447 E.02187
G1 X133.71 Y138.007 E.01668
G1 X133.302 Y138.51 E.01575
G1 X132.679 Y139.157 E.02185
G1 X132.163 Y139.609 E.01669
G1 X131.648 Y140.002 E.01576
G1 X130.891 Y140.485 E.02184
G1 X130.283 Y140.803 E.01669
G1 X129.69 Y141.065 E.01577
G1 X128.842 Y141.357 E.02182
G1 X128.175 Y141.523 E.01672
G1 X127.544 Y141.638 E.0156
G1 X126.18 Y141.735 E.03326
G1 X121.169 Y141.735 E.12189
G1 X121.055 Y141.46 E.00724
G1 X120.667 Y141.299 E.01022
G1 X110.333 Y141.299 E.25136
G1 X110.238 Y141.307 E.00232
G1 X109.945 Y141.459 E.00803
G1 X109.832 Y141.734 E.00723
G1 X104.357 Y141.723 E.13317
G1 X103.256 Y141.604 E.02694
G1 X102.589 Y141.471 E.01654
G1 X101.728 Y141.22 E.02181
G1 X101.123 Y140.986 E.01578
G1 X100.506 Y140.7 E.01654
G1 X99.351 Y140.001 E.03284
G1 X98.492 Y139.314 E.02675
G1 X98.007 Y138.847 E.01638
G1 X97.142 Y137.81 E.03285
G1 X96.554 Y136.881 E.02674
G1 X96.247 Y136.282 E.01637
G1 X95.766 Y135.019 E.03287
G1 X95.512 Y133.953 E.02666
G1 X95.398 Y133.068 E.0217
G1 X95.365 Y132.288 E.01899
G1 X95.365 Y95.806 E.88739
G1 X95.322 Y95.595 E.00524
G1 X95.145 Y95.367 E.00702
G1 X94.816 Y95.258 E.00843
G1 X92.119 Y95.255 E.0656
G1 X92.126 Y93.57 E.04099
G1 X104.634 Y93.571 E.30424
G1 X104.634 Y97.963 E.10683
G1 X104.358 Y98.082 E.00731
G1 X104.273 Y98.203 E.0036
G1 X104.21 Y98.457 E.00637
G1 X104.21 Y103.792 E.12977
G1 X104.215 Y103.867 E.00183
G1 X104.325 Y104.128 E.00689
G1 X104.634 Y104.279 E.00837
G1 X104.634 Y135.841 E.76771
G1 X104.014 Y136.39 E.02014
G1 X103.556 Y136.865 E.01605
G1 X103.35 Y137.288 E.01144
G1 X103.313 Y137.575 E.00704
G1 X103.467 Y137.99 E.01077
G1 X103.632 Y138.215 E.00679
G1 X104.046 Y138.641 E.01445
G1 X104.634 Y139.159 E.01906
G1 X104.634 Y139.317 E.00384
G1 X104.698 Y139.574 E.00644
G1 X104.915 Y139.796 E.00755
G1 X105.182 Y139.866 E.00671
G1 X125.817 Y139.866 E.50193
G1 X125.912 Y139.857 E.00232
G1 X126.14 Y139.761 E.00602
G1 X126.158 Y139.742 E.00064
G1 X126.158 Y139.742 F9000
G1 X126.453 Y139.953
G1 F6000
G1 X126.584 Y139.815 E.00463
G1 X126.686 Y139.6 E.00579
G1 X126.73 Y139.326 E.00675
G1 X127.349 Y138.758 E.02043
G1 X127.877 Y138.145 E.01968
G1 X128.049 Y137.626 E.0133
G1 X128.049 Y137.371 E.0062
G1 X127.926 Y136.965 E.01032
G1 X127.736 Y136.656 E.00882
G1 X127.196 Y136.084 E.01913
G1 X126.731 Y135.675 E.01506
G1 X126.731 Y104.466 E.75913
G1 X126.964 Y104.352 E.00631
G1 X127.081 Y104.154 E.00559
G1 X127.155 Y103.792 E.00899
G1 X127.155 Y98.457 E.12977
G1 X127.152 Y98.374 E.00202
G1 X127.051 Y98.033 E.00865
G1 X126.909 Y97.832 E.00599
G1 X126.731 Y97.756 E.00471
G1 X126.731 Y93.934 E.09297
G1 X138.514 Y93.935 E.28661
G1 X138.517 Y94.893 E.0233
G1 X136.184 Y94.892 E.05675
G1 X136.025 Y94.906 E.00388
G1 X135.635 Y95.075 E.01034
G1 X135.34 Y95.454 E.01168
G1 X135.269 Y95.806 E.00873
G1 X135.265 Y132.538 E.89347
G1 X135.237 Y133.037 E.01216
G1 X135.165 Y133.661 E.01528
G1 X135.041 Y134.313 E.01614
G1 X134.885 Y134.906 E.01491
G1 X134.499 Y135.951 E.0271
G1 X134.236 Y136.5 E.01481
G1 X133.799 Y137.248 E.02107
G1 X133.419 Y137.786 E.01602
G1 X133.028 Y138.267 E.01508
G1 X132.427 Y138.892 E.02109
G1 X131.931 Y139.325 E.01602
G1 X131.438 Y139.702 E.0151
G1 X130.708 Y140.168 E.02107
G1 X130.124 Y140.473 E.01603
G1 X129.556 Y140.724 E.0151
G1 X128.738 Y141.006 E.02105
G1 X128.098 Y141.165 E.01604
G1 X127.498 Y141.274 E.01483
G1 X126.167 Y141.369 E.03246
G1 X121.383 Y141.369 E.11637
G1 X121.314 Y141.202 E.0044
G1 X120.667 Y140.933 E.01704
G1 X110.333 Y140.933 E.25136
G1 X110.175 Y140.947 E.00386
G1 X109.687 Y141.201 E.01338
G1 X109.618 Y141.368 E.0044
G1 X104.377 Y141.358 E.12748
G1 X103.311 Y141.243 E.02608
G1 X102.676 Y141.116 E.01575
G1 X101.845 Y140.873 E.02106
G1 X101.266 Y140.65 E.01509
G1 X100.678 Y140.377 E.01577
G1 X99.561 Y139.701 E.03176
G1 X98.734 Y139.039 E.02577
G1 X98.275 Y138.597 E.0155
G1 X97.438 Y137.594 E.03178
G1 X96.871 Y136.699 E.02577
G1 X96.582 Y136.133 E.01546
G1 X96.117 Y134.911 E.0318
G1 X95.873 Y133.887 E.02561
G1 X95.762 Y133.037 E.02085
G1 X95.73 Y132.281 E.01841
G1 X95.73 Y95.806 E.88722
G1 X95.66 Y95.455 E.00871
G1 X95.365 Y95.075 E.0117
G1 X94.816 Y94.892 E.01408
G1 X92.481 Y94.893 E.0568
G1 X92.481 Y93.936 E.02328
G1 X104.269 Y93.936 E.28673
G1 X104.269 Y97.756 E.09292
G1 X104.091 Y97.832 E.00471
G1 X103.949 Y98.033 E.00599
G1 X103.878 Y98.211 E.00466
G1 X103.845 Y98.457 E.00604
G1 X103.845 Y103.792 E.12977
G1 X103.879 Y104.039 E.00606
G1 X104.036 Y104.352 E.00852
G1 X104.269 Y104.466 E.00631
G1 X104.269 Y135.675 E.75913
G1 X103.751 Y136.136 E.01687
G1 X103.187 Y136.754 E.02035
G1 X102.963 Y137.306 E.01449
G1 X102.951 Y137.625 E.00776
G1 X103.13 Y138.131 E.01306
G1 X103.369 Y138.469 E.01007
G1 X103.804 Y138.915 E.01515
G1 X104.27 Y139.326 E.01511
G1 X104.375 Y139.745 E.01051
G1 X104.737 Y140.115 E.01259
G1 X105.181 Y140.231 E.01116
G1 X125.817 Y140.231 E.50195
G1 X125.975 Y140.218 E.00386
G1 X126.355 Y140.056 E.01005
G1 X126.412 Y139.996 E.00201
G1 E-5 F3600
G1 X126.412 Y139.996 F9000
G1 X110.113 Y140.592
G1 E5 F2400
;WIDTH:0.38983
G1 F6000
G1 X110.333 Y140.582 E.00521
;WIDTH:0.370658
G1 X120.667 Y140.582 E.23119
G1 E-5 F3600
G1 X120.667 Y140.582 F9000
G1 X104.651 Y139.849
G1 X103.483 Y138.005
G1 X103.43 Y137.913
G1 X103.387 Y137.819
G1 X103.353 Y137.719
G1 X103.332 Y137.612
G1 X103.324 Y137.5
G1 X103.903 Y124.442
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X103.903 Y135.51 E.26922
G1 X103.488 Y135.882 E.01356
G1 X103.001 Y136.389 E.0171
G1 X102.793 Y136.727 E.00965
G1 X102.606 Y137.229 E.01303
G1 X102.589 Y137.675 E.01086
G1 X102.793 Y138.273 E.01537
G1 X103.052 Y138.667 E.01147
G1 X103.488 Y139.118 E.01526
G1 X103.934 Y139.517 E.01456
G1 X103.963 Y139.705 E.00463
G1 X104.052 Y139.916 E.00557
G1 X104.558 Y140.434 E.01761
;WIDTH:0.41548
G1 X105.183 Y140.605 E.01643
;WIDTH:0.419293
G1 X109.285 Y140.607 E.10504
G1 X110.113 Y140.592 E.02121
G1 X109.421 Y140.935 E.01978
G1 X109.398 Y140.992 E.00157
G1 X105.182 Y140.986 E.10796
;WIDTH:0.41548
G1 X104.397 Y140.992 E.0199
;WIDTH:0.399999
G1 X103.367 Y140.881 E.0252
G1 X102.763 Y140.761 E.01498
G1 X101.963 Y140.527 E.02027
G1 X101.409 Y140.313 E.01445
G1 X100.85 Y140.054 E.01499
G1 X99.771 Y139.4 E.03069
G1 X98.975 Y138.763 E.0248
G1 X98.543 Y138.348 E.01457
G1 X97.734 Y137.378 E.03072
G1 X97.189 Y136.518 E.02477
G1 X96.916 Y135.984 E.01459
G1 X96.467 Y134.803 E.03073
G1 X96.233 Y133.82 E.02458
G1 X96.127 Y133.005 E.01999
G1 X96.096 Y132.273 E.01782
G1 X96.096 Y95.806 E.88702
G1 X95.998 Y95.314 E.0122
G1 X95.584 Y94.782 E.0164
;WIDTH:0.444999
G1 X95.43 Y94.709 E.00466
;WIDTH:0.489999
G1 X95.277 Y94.635 E.00515
;WIDTH:0.534999
G1 X95.123 Y94.561 E.00569
;WIDTH:0.579998
G1 X94.97 Y94.488 E.00615
;WIDTH:0.624998
G1 X94.816 Y94.414 E.00671
G1 X95.002 Y94.391 E.00736
;WIDTH:0.579998
G1 X95.187 Y94.369 E.00676
;WIDTH:0.534999
G1 X95.373 Y94.346 E.00624
;WIDTH:0.489999
G1 X95.559 Y94.324 E.00568
;WIDTH:0.444999
G1 X95.744 Y94.301 E.00509
;WIDTH:0.399999
G1 X103.903 Y94.302 E.19846
G1 X103.903 Y97.548 E.07896
G1 X103.824 Y97.583 E.0021
G1 X103.625 Y97.863 E.00836
G1 X103.526 Y98.113 E.00654
G1 X103.479 Y98.457 E.00845
G1 X103.479 Y103.792 E.12977
G1 X103.527 Y104.137 E.00847
G1 X103.747 Y104.576 E.01194
G1 X103.903 Y104.652 E.00422
G1 X103.903 Y124.382 E.47991
G1 E-5 F3600
G1 X103.903 Y124.382 F9000
G1 X103.537 Y135.345
G1 E5 F2400
G1 F6000
G1 X103.225 Y135.628 E.01025
G1 X102.608 Y136.302 E.02223
G1 X102.431 Y136.644 E.00937
G1 X102.248 Y137.152 E.01313
G1 X102.226 Y137.725 E.01395
G1 X102.339 Y138.136 E.01037
G1 X102.608 Y138.697 E.01513
G1 X102.789 Y138.921 E.00701
G1 X103.225 Y139.372 E.01526
G1 X103.598 Y139.708 E.01221
G1 X103.729 Y140.087 E.00975
G1 X104.237 Y140.607 E.01768
G1 X103.422 Y140.519 E.01994
G1 X102.85 Y140.405 E.01419
G1 X102.08 Y140.18 E.01951
G1 X101.552 Y139.976 E.01377
G1 X101.022 Y139.731 E.0142
G1 X99.981 Y139.1 E.02961
G1 X99.217 Y138.488 E.02381
G1 X98.811 Y138.098 E.01369
G1 X98.031 Y137.162 E.02964
G1 X97.507 Y136.336 E.02379
G1 X97.251 Y135.835 E.01369
G1 X96.817 Y134.696 E.02965
G1 X96.593 Y133.754 E.02355
G1 X96.492 Y132.974 E.01913
G1 X96.462 Y132.265 E.01726
G1 X96.462 Y95.806 E.88683
G1 X96.335 Y95.173 E.0157
G1 X95.941 Y94.667 E.0156
G1 X103.537 Y94.668 E.18477
G1 X103.537 Y97.361 E.0655
G1 X103.301 Y97.693 E.00991
G1 X103.174 Y98.014 E.0084
G1 X103.113 Y98.457 E.01088
G1 X103.113 Y103.792 E.12977
G1 X103.129 Y104.017 E.00549
G1 X103.248 Y104.443 E.01076
G1 X103.458 Y104.8 E.01007
G1 X103.537 Y104.839 E.00214
G1 X103.537 Y135.285 E.74057
G1 E-5 F3600
G1 X103.537 Y135.285 F9000
G1 X95.348 Y95.273
G1 X92.96 Y94.414
G1 E5 F2400
;WIDTH:0.625724
G1 F6000
G1 X94.816 Y94.414 E.07301
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X92.96 Y94.414 E-.8816
;WIPE_END
G1 E-.6184 F3600
G1 X135.941 Y94.424 F9000
G1 E5 F2400
;WIDTH:0.646578
G1 F6000
G1 X136.184 Y94.414 E.0099
;WIDTH:0.625878
G1 X138.037 Y94.414 E.07291
G1 E-5 F3600
G1 X127.097 Y94.3 F9000
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X135.255 Y94.301 E.19844
;WIDTH:0.449315
G1 X135.392 Y94.325 E.00384
;WIDTH:0.498631
G1 X135.53 Y94.35 E.00433
;WIDTH:0.547947
G1 X135.667 Y94.375 E.00476
;WIDTH:0.597262
G1 X135.804 Y94.4 E.00521
;WIDTH:0.646578
G1 X135.941 Y94.424 E.00566
G1 X135.836 Y94.496 E.00519
;WIDTH:0.597262
G1 X135.731 Y94.567 E.00475
;WIDTH:0.547947
G1 X135.626 Y94.639 E.00435
;WIDTH:0.498631
G1 X135.521 Y94.711 E.00393
;WIDTH:0.449315
G1 X135.416 Y94.782 E.0035
;WIDTH:0.399999
G1 X135.002 Y95.314 E.0164
G1 X134.903 Y95.806 E.01221
G1 X134.899 Y132.42 E.8906
G1 X134.873 Y133.006 E.01427
G1 X134.803 Y133.606 E.01469
G1 X134.684 Y134.232 E.0155
G1 X134.536 Y134.796 E.01418
G1 X134.162 Y135.808 E.02624
G1 X133.913 Y136.329 E.01405
G1 X133.491 Y137.05 E.02032
G1 X133.127 Y137.565 E.01534
G1 X132.753 Y138.025 E.01442
G1 X132.174 Y138.627 E.02032
G1 X131.699 Y139.042 E.01534
G1 X131.228 Y139.402 E.01442
G1 X130.525 Y139.851 E.02029
G1 X129.965 Y140.143 E.01536
G1 X129.423 Y140.383 E.01442
G1 X128.634 Y140.655 E.0203
G1 X128.021 Y140.807 E.01536
G1 X127.452 Y140.911 E.01407
G1 X126.791 Y140.958 E.01612
;WIDTH:0.420284
G1 X125.817 Y140.993 E.02502
G1 X121.604 Y140.993 E.10816
G1 X121.58 Y140.936 E.00159
G1 X120.667 Y140.582 E.02514
G1 X121.717 Y140.607 E.02696
G1 X125.817 Y140.607 E.10526
;WIDTH:0.425899
G1 X126.101 Y140.578 E.00744
G1 X126.57 Y140.352 E.01356
;WIDTH:0.399999
G1 X126.89 Y140.014 E.01132
G1 X127.034 Y139.713 E.00812
G1 X127.066 Y139.517 E.00483
G1 X127.616 Y139.007 E.01824
G1 X128.062 Y138.525 E.01597
G1 X128.278 Y138.137 E.0108
G1 X128.411 Y137.676 E.01167
G1 X128.411 Y137.32 E.00866
G1 X128.221 Y136.724 E.01522
G1 X128.003 Y136.407 E.00936
G1 X127.527 Y135.897 E.01697
G1 X127.097 Y135.51 E.01407
G1 X127.097 Y104.652 E.75059
G1 X127.253 Y104.576 E.00422
G1 X127.473 Y104.137 E.01194
G1 X127.521 Y103.792 E.00847
G1 X127.521 Y98.457 E.12977
G1 X127.516 Y98.34 E.00285
G1 X127.375 Y97.863 E.0121
G1 X127.176 Y97.583 E.00836
G1 X127.097 Y97.548 E.0021
G1 X127.097 Y94.36 E.07754
G1 X127.463 Y94.666 F9000
G1 F6000
G1 X135.059 Y94.666 E.18477
G1 X134.664 Y95.173 E.01563
G1 X134.538 Y95.806 E.0157
G1 X134.533 Y132.42 E.8906
G1 X134.508 Y132.975 E.01351
G1 X134.442 Y133.55 E.01408
G1 X134.327 Y134.151 E.01488
G1 X134.187 Y134.686 E.01345
G1 X133.825 Y135.666 E.02541
G1 X133.59 Y136.157 E.01324
G1 X133.183 Y136.852 E.01959
G1 X132.835 Y137.344 E.01466
G1 X132.479 Y137.783 E.01375
G1 X131.922 Y138.362 E.01954
G1 X131.468 Y138.759 E.01467
G1 X131.019 Y139.102 E.01374
G1 X130.341 Y139.535 E.01957
G1 X129.806 Y139.814 E.01468
G1 X129.289 Y140.043 E.01375
G1 X128.53 Y140.304 E.01952
G1 X127.944 Y140.45 E.01469
G1 X127.406 Y140.548 E.0133
G1 X126.842 Y140.588 E.01375
G1 X127.197 Y140.214 E.01254
G1 X127.382 Y139.826 E.01046
G1 X127.402 Y139.708 E.00291
G1 X127.794 Y139.353 E.01286
G1 X128.27 Y138.843 E.01697
G1 X128.524 Y138.485 E.01068
G1 X128.699 Y138.037 E.0117
G1 X128.789 Y137.494 E.01339
G1 X128.71 Y136.994 E.01231
G1 X128.55 Y136.566 E.01111
G1 X128.27 Y136.157 E.01206
G1 X127.463 Y135.345 E.02785
G1 X127.463 Y104.839 E.74203
G1 X127.541 Y104.8 E.00212
G1 X127.752 Y104.443 E.01009
G1 X127.826 Y104.236 E.00535
G1 X127.887 Y103.792 E.0109
G1 X127.887 Y98.457 E.12977
G1 X127.826 Y98.014 E.01088
G1 X127.699 Y97.694 E.00837
G1 X127.463 Y97.361 E.00993
G1 X127.463 Y94.726 E.06409
G1 E-5 F3600
G1 X127.463 Y94.726 F9000
G1 X134.55 Y95.206
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X134.284 Y94.941 E.00913
G1 X133.765 Y94.941 E.01262
G1 X134.323 Y95.498 E.01918
G1 X134.264 Y95.958 E.01128
G1 X133.247 Y94.941 E.03498
G1 X132.728 Y94.94 E.01262
G1 X134.263 Y96.476 E.05282
G1 X134.263 Y96.995 E.01262
G1 X132.209 Y94.94 E.07067
G1 X131.69 Y94.94 E.01262
G1 X134.263 Y97.514 E.08853
G1 X134.263 Y98.033 E.01262
G1 X131.171 Y94.94 E.10638
G1 X130.652 Y94.94 E.01262
G1 X134.263 Y98.551 E.12422
G1 X134.263 Y99.07 E.01262
G1 X130.133 Y94.94 E.14207
G1 X129.614 Y94.94 E.01262
G1 X134.263 Y99.589 E.15992
G1 X134.263 Y100.108 E.01262
G1 X129.095 Y94.94 E.17778
G1 X128.576 Y94.94 E.01262
G1 X134.263 Y100.627 E.19563
G1 X134.263 Y101.145 E.0126
G1 X128.058 Y94.94 E.21345
G1 X127.737 Y94.94 E.00781
G1 X127.737 Y95.138 E.00482
G1 X134.263 Y101.664 E.22449
G1 X134.263 Y102.183 E.01262
G1 X127.737 Y95.657 E.22449
G1 X127.737 Y96.176 E.01262
G1 X134.263 Y102.702 E.22449
G1 X134.263 Y103.221 E.01262
G1 X127.737 Y96.695 E.22449
G1 X127.737 Y97.214 E.01262
G1 X134.263 Y103.739 E.22447
G1 X134.263 Y104.258 E.01262
G1 X128.123 Y98.119 E.2112
G1 X128.161 Y98.675 E.01356
G1 X134.262 Y104.777 E.20989
G1 X134.262 Y105.296 E.01262
G1 X128.161 Y99.194 E.20989
G1 X128.161 Y99.713 E.01262
G1 X134.262 Y105.815 E.20989
G1 X134.262 Y106.333 E.0126
G1 X128.161 Y100.232 E.20987
G1 X128.161 Y100.751 E.01262
G1 X134.262 Y106.852 E.20987
G1 X134.262 Y107.371 E.01262
G1 X128.161 Y101.27 E.20987
G1 X128.161 Y101.789 E.01262
G1 X134.262 Y107.89 E.20987
G1 X134.262 Y108.408 E.0126
G1 X128.161 Y102.307 E.20987
G1 X128.161 Y102.826 E.01262
G1 X134.262 Y108.927 E.20987
G1 X134.262 Y109.446 E.01262
G1 X128.161 Y103.345 E.20987
G1 X128.156 Y103.858 E.01248
G1 X134.262 Y109.965 E.21006
G1 X134.262 Y110.484 E.01262
G1 X128.08 Y104.301 E.21267
G1 X127.933 Y104.674 E.00975
G1 X134.262 Y111.002 E.2177
G1 X134.262 Y111.521 E.01262
G1 X127.737 Y104.996 E.22446
G1 X127.737 Y105.515 E.01262
G1 X134.262 Y112.04 E.22446
G1 X134.262 Y112.559 E.01262
G1 X127.737 Y106.034 E.22446
G1 X127.737 Y106.553 E.01262
G1 X134.262 Y113.078 E.22446
G1 X134.261 Y113.596 E.0126
G1 X127.737 Y107.072 E.22442
G1 X127.737 Y107.591 E.01262
G1 X134.261 Y114.115 E.22442
G1 X134.261 Y114.634 E.01262
G1 X127.737 Y108.11 E.22442
G1 X127.737 Y108.628 E.0126
G1 X134.261 Y115.153 E.22444
G1 X134.261 Y115.672 E.01262
G1 X127.737 Y109.147 E.22444
G1 X127.737 Y109.666 E.01262
G1 X134.261 Y116.19 E.22442
G1 X134.261 Y116.709 E.01262
G1 X127.737 Y110.185 E.22442
G1 X127.737 Y110.704 E.01262
G1 X134.261 Y117.228 E.22442
G1 X134.261 Y117.747 E.01262
G1 X127.737 Y111.223 E.22442
G1 X127.737 Y111.741 E.0126
G1 X134.261 Y118.265 E.22442
G1 X134.261 Y118.784 E.01262
G1 X127.737 Y112.26 E.22442
G1 X127.737 Y112.779 E.01262
G1 X134.261 Y119.303 E.22442
G1 X134.261 Y119.822 E.01262
G1 X127.737 Y113.298 E.22442
G1 X127.737 Y113.817 E.01262
G1 X134.261 Y120.341 E.22442
G1 X134.261 Y120.859 E.0126
G1 X127.737 Y114.336 E.2244
G1 X127.737 Y114.855 E.01262
G1 X134.261 Y121.378 E.2244
G1 X134.26 Y121.897 E.01262
G1 X127.737 Y115.373 E.2244
G1 X127.737 Y115.892 E.01262
G1 X134.26 Y122.416 E.2244
G1 X134.26 Y122.935 E.01262
G1 X127.737 Y116.411 E.2244
G1 X127.737 Y116.93 E.01262
G1 X134.26 Y123.453 E.22439
G1 X134.26 Y123.972 E.01262
G1 X127.737 Y117.449 E.22439
G1 X127.737 Y117.968 E.01262
G1 X134.26 Y124.491 E.22439
G1 X134.26 Y125.01 E.01262
G1 X127.737 Y118.487 E.22439
G1 X127.737 Y119.005 E.0126
G1 X134.26 Y125.529 E.2244
G1 X134.26 Y126.047 E.0126
G1 X127.737 Y119.524 E.22439
G1 X127.737 Y120.043 E.01262
G1 X134.26 Y126.566 E.22439
G1 X134.26 Y127.085 E.01262
G1 X127.737 Y120.562 E.22439
G1 X127.737 Y121.081 E.01262
G1 X134.26 Y127.604 E.22439
G1 X134.26 Y128.122 E.0126
G1 X127.737 Y121.6 E.22437
G1 X127.737 Y122.118 E.0126
G1 X134.26 Y128.641 E.22439
G1 X134.26 Y129.16 E.01262
G1 X127.737 Y122.637 E.22439
G1 X127.737 Y123.156 E.01262
G1 X134.26 Y129.679 E.22439
G1 X134.259 Y130.198 E.01262
G1 X127.737 Y123.675 E.22437
G1 X127.737 Y124.194 E.01262
G1 X134.259 Y130.716 E.22435
G1 X134.259 Y131.235 E.01262
G1 X127.737 Y124.713 E.22435
G1 X127.737 Y125.232 E.01262
G1 X134.259 Y131.754 E.22435
G1 X134.259 Y132.273 E.01262
G1 X127.737 Y125.75 E.22437
G1 X127.737 Y126.269 E.01262
G1 X134.244 Y132.777 E.22385
G1 X134.2 Y133.251 E.01158
G1 X127.737 Y126.788 E.22232
G1 X127.737 Y127.307 E.01262
G1 X134.133 Y133.703 E.22002
G1 X134.047 Y134.136 E.01074
G1 X127.737 Y127.826 E.21706
G1 X127.737 Y128.345 E.01262
G1 X133.939 Y134.547 E.21335
G1 X133.804 Y134.931 E.0099
G1 X127.737 Y128.864 E.2087
G1 X127.737 Y129.382 E.0126
G1 X133.664 Y135.309 E.20389
G1 X133.514 Y135.679 E.00971
G1 X127.737 Y129.901 E.19874
G1 X127.737 Y130.42 E.01262
G1 X133.347 Y136.03 E.19298
G1 X133.155 Y136.357 E.00922
G1 X127.737 Y130.939 E.18638
G1 X127.737 Y131.458 E.01262
G1 X132.964 Y136.684 E.17979
G1 X132.75 Y136.99 E.00908
G1 X127.737 Y131.977 E.17244
G1 X127.737 Y132.496 E.01262
G1 X132.528 Y137.287 E.16481
G1 X132.296 Y137.573 E.00896
G1 X127.737 Y133.014 E.15683
G1 X127.737 Y133.533 E.01262
G1 X132.044 Y137.84 E.14816
G1 X131.789 Y138.104 E.00893
G1 X127.737 Y134.052 E.13939
G1 X127.737 Y134.571 E.01262
G1 X131.517 Y138.351 E.13003
G1 X131.237 Y138.59 E.00895
G1 X127.737 Y135.09 E.1204
G1 X127.737 Y135.222 E.00321
G1 X128.677 Y136.234 E.0336
G1 X128.93 Y136.802 E.01512
G1 X130.943 Y138.815 E.06925
G1 X130.633 Y139.023 E.00908
G1 X129.061 Y137.451 E.05408
G1 X129.009 Y137.918 E.01143
G1 X130.316 Y139.225 E.04496
G1 X129.984 Y139.412 E.00927
G1 X128.885 Y138.313 E.0378
G1 X128.727 Y138.674 E.00959
G1 X129.64 Y139.587 E.03141
G1 X129.281 Y139.746 E.00955
G1 X128.514 Y138.98 E.02637
G1 X128.265 Y139.25 E.00893
G1 X128.901 Y139.886 E.02188
G1 X128.515 Y140.019 E.00993
G1 X128.015 Y139.518 E.01722
G1 X127.745 Y139.768 E.00895
G1 X128.105 Y140.127 E.01237
G1 X127.675 Y140.216 E.01068
G1 X127.432 Y139.973 E.00836
G1 E-5 F3600
G1 X127.432 Y139.973 F9000
G1 X97.98 Y136.878
G1 E5 F2400
G1 F3072.127
G1 X99.398 Y138.282 E.04854
G1 X100.138 Y138.875 E.02307
G1 X101.048 Y139.425 E.02586
G1 X97.665 Y136.043 E.11636
G1 X97.278 Y135.136 E.02399
G1 X101.996 Y139.854 E.1623
G1 X102.754 Y140.091 E.01932
G1 X97.018 Y134.356 E.1973
G1 X96.859 Y133.677 E.01696
G1 X103.422 Y140.239 E.22575
G1 X103.501 Y140.252 E.00195
G1 X103.345 Y139.85 E.01049
G1 X102.589 Y139.109 E.02575
G1 X102.188 Y138.485 E.01804
G1 X96.782 Y133.079 E.18596
G1 X96.747 Y132.525 E.0135
G1 X101.953 Y137.731 E.17908
G1 X101.96 Y137.217 E.0125
G1 X96.736 Y131.993 E.1797
G1 X96.736 Y131.473 E.01265
G1 X102.07 Y136.807 E.18349
G1 X102.223 Y136.44 E.00967
G1 X96.736 Y130.953 E.18875
G1 X96.736 Y130.433 E.01265
G1 X102.412 Y136.11 E.19527
G1 X102.65 Y135.828 E.00898
G1 X96.736 Y129.913 E.20346
G1 X96.736 Y129.393 E.01265
G1 X102.906 Y135.563 E.21224
G1 X103.17 Y135.307 E.00894
G1 X96.736 Y128.873 E.22133
G1 X96.736 Y128.353 E.01265
G1 X103.263 Y134.88 E.22452
G1 X103.263 Y134.36 E.01265
G1 X96.736 Y127.833 E.22452
G1 X96.736 Y127.313 E.01265
G1 X103.263 Y133.84 E.22452
G1 X103.263 Y133.32 E.01265
G1 X96.736 Y126.793 E.22452
G1 X96.736 Y126.273 E.01265
G1 X103.263 Y132.8 E.22452
G1 X103.263 Y132.28 E.01265
G1 X96.736 Y125.753 E.22452
G1 X96.736 Y125.233 E.01265
G1 X103.263 Y131.76 E.22452
G1 X103.263 Y131.24 E.01265
G1 X96.736 Y124.713 E.22452
G1 X96.736 Y124.193 E.01265
G1 X103.263 Y130.72 E.22452
G1 X103.263 Y130.2 E.01265
G1 X96.736 Y123.672 E.22454
G1 X96.736 Y123.152 E.01265
G1 X103.263 Y129.68 E.22454
G1 X103.263 Y129.16 E.01265
G1 X96.736 Y122.632 E.22454
G1 X96.736 Y122.112 E.01265
G1 X103.263 Y128.64 E.22454
G1 X103.263 Y128.12 E.01265
G1 X96.736 Y121.592 E.22454
G1 X96.736 Y121.072 E.01265
G1 X103.263 Y127.599 E.22452
G1 X103.263 Y127.079 E.01265
G1 X96.736 Y120.552 E.22452
G1 X96.736 Y120.032 E.01265
G1 X103.263 Y126.559 E.22452
G1 X103.263 Y126.039 E.01265
G1 X96.736 Y119.512 E.22452
G1 X96.736 Y118.992 E.01265
G1 X103.263 Y125.519 E.22452
G1 X103.263 Y124.999 E.01265
G1 X96.736 Y118.472 E.22452
G1 X96.736 Y117.952 E.01265
G1 X103.263 Y124.479 E.22452
G1 X103.263 Y123.959 E.01265
G1 X96.736 Y117.432 E.22452
G1 X96.736 Y116.912 E.01265
G1 X103.263 Y123.439 E.22452
G1 X103.263 Y122.919 E.01265
G1 X96.736 Y116.392 E.22452
G1 X96.736 Y115.872 E.01265
G1 X103.263 Y122.399 E.22452
G1 X103.263 Y121.879 E.01265
G1 X96.736 Y115.352 E.22452
G1 X96.736 Y114.832 E.01265
G1 X103.263 Y121.359 E.22452
G1 X103.263 Y120.839 E.01265
G1 X96.736 Y114.312 E.22452
G1 X96.736 Y113.792 E.01265
G1 X103.263 Y120.319 E.22452
G1 X103.263 Y119.799 E.01265
G1 X96.736 Y113.272 E.22452
G1 X96.736 Y112.751 E.01267
G1 X103.263 Y119.279 E.22454
G1 X103.263 Y118.759 E.01265
G1 X96.736 Y112.231 E.22454
G1 X96.736 Y111.711 E.01265
G1 X103.263 Y118.239 E.22454
G1 X103.263 Y117.719 E.01265
G1 X96.736 Y111.191 E.22454
G1 X96.736 Y110.671 E.01265
G1 X103.263 Y117.198 E.22452
G1 X103.263 Y116.678 E.01265
G1 X96.736 Y110.151 E.22452
G1 X96.736 Y109.631 E.01265
G1 X103.263 Y116.158 E.22452
G1 X103.263 Y115.638 E.01265
G1 X96.736 Y109.111 E.22452
G1 X96.736 Y108.591 E.01265
G1 X103.263 Y115.118 E.22452
G1 X103.263 Y114.598 E.01265
G1 X96.736 Y108.071 E.22452
G1 X96.736 Y107.551 E.01265
G1 X103.263 Y114.078 E.22452
G1 X103.263 Y113.558 E.01265
G1 X96.736 Y107.031 E.22452
G1 X96.736 Y106.511 E.01265
G1 X103.263 Y113.038 E.22452
G1 X103.263 Y112.518 E.01265
G1 X96.736 Y105.991 E.22452
G1 X96.736 Y105.471 E.01265
G1 X103.263 Y111.998 E.22452
G1 X103.263 Y111.478 E.01265
G1 X96.736 Y104.951 E.22452
G1 X96.736 Y104.431 E.01265
G1 X103.263 Y110.958 E.22452
G1 X103.263 Y110.438 E.01265
G1 X96.736 Y103.911 E.22452
G1 X96.736 Y103.391 E.01265
G1 X103.263 Y109.918 E.22452
G1 X103.263 Y109.398 E.01265
G1 X96.736 Y102.871 E.22452
G1 X96.736 Y102.35 E.01267
G1 X103.263 Y108.878 E.22454
G1 X103.263 Y108.358 E.01265
G1 X96.736 Y101.83 E.22454
G1 X96.736 Y101.31 E.01265
G1 X103.263 Y107.838 E.22454
G1 X103.263 Y107.318 E.01265
G1 X96.736 Y100.79 E.22454
G1 X96.736 Y100.27 E.01265
G1 X103.263 Y106.798 E.22454
G1 X103.263 Y106.277 E.01267
G1 X96.736 Y99.75 E.22452
G1 X96.736 Y99.23 E.01265
G1 X103.263 Y105.757 E.22452
G1 X103.263 Y105.237 E.01265
G1 X96.736 Y98.71 E.22452
G1 X96.736 Y98.19 E.01265
G1 X102.952 Y104.406 E.21383
G1 X102.839 Y103.773 E.01564
G1 X96.736 Y97.67 E.20994
G1 X96.736 Y97.15 E.01265
G1 X102.84 Y103.254 E.20997
G1 X102.84 Y102.734 E.01265
G1 X96.736 Y96.63 E.20997
G1 X96.736 Y96.11 E.01265
G1 X102.841 Y102.215 E.21001
G1 X102.842 Y101.696 E.01262
G1 X96.684 Y95.538 E.21183
G1 X96.589 Y95.064 E.01176
G1 X96.494 Y94.941 E.00378
G1 X96.608 Y94.941 E.00277
G1 X102.843 Y101.177 E.2145
G1 X102.843 Y100.657 E.01265
G1 X97.128 Y94.941 E.19661
G1 X97.648 Y94.942 E.01265
G1 X102.844 Y100.138 E.17874
G1 X102.845 Y99.619 E.01262
G1 X98.168 Y94.942 E.16089
G1 X98.688 Y94.942 E.01265
G1 X102.845 Y99.099 E.143
G1 X102.846 Y98.58 E.01262
G1 X99.208 Y94.942 E.12515
G1 X99.728 Y94.942 E.01265
G1 X102.881 Y98.095 E.10846
G1 X103.005 Y97.699 E.01009
G1 X100.248 Y94.942 E.09484
G1 X100.768 Y94.942 E.01265
G1 X103.197 Y97.37 E.08354
G1 X103.263 Y97.276 E.00279
G1 X103.263 Y96.917 E.00873
G1 X101.288 Y94.942 E.06794
G1 X101.808 Y94.942 E.01265
G1 X103.263 Y96.397 E.05005
G1 X103.263 Y95.876 E.01267
G1 X102.328 Y94.942 E.03215
G1 X102.849 Y94.942 E.01267
G1 X103.428 Y95.521 E.01992
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X102.849 Y94.942 E-.38894
G1 X102.328 Y94.942 E-.24748
G1 X103.263 Y95.876 E-.62775
G1 X103.263 Y96.372 E-.23583
;WIPE_END
G1 X104.227 Y98.835 F9000
G1 X105.536 Y102.182
G1 X106.099 Y103.076
G1 X106.099 Y103.618
G1 X109.45 Y112.866
G1 X109.779 Y113.025
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X109.855 Y112.831 E.00507
G1 X111.626 Y109.763 E.08617
G1 X112.054 Y109.217 E.01687
G1 X112.407 Y108.934 E.01101
G1 X112.906 Y108.681 E.01361
G1 X113.494 Y108.541 E.0147
G1 X117.373 Y108.529 E.09435
G1 X117.804 Y108.593 E.0106
G1 X118.33 Y108.783 E.0136
G1 X118.835 Y109.116 E.01471
G1 X119.266 Y109.591 E.0156
G1 X121.107 Y112.763 E.08921
G1 X121.279 Y113.126 E.00977
G1 X121.391 Y113.52 E.00996
G1 X121.435 Y114.119 E.01461
G1 X121.365 Y114.59 E.01158
G1 X121.187 Y115.086 E.01282
G1 X119.266 Y118.408 E.09334
G1 X118.983 Y118.747 E.01074
G1 X118.546 Y119.096 E.0136
G1 X118.153 Y119.296 E.01073
G1 X117.768 Y119.416 E.00981
G1 X117.372 Y119.471 E.00972
G1 X113.721 Y119.474 E.08881
G1 X113.141 Y119.393 E.01424
G1 X112.58 Y119.17 E.01468
G1 X112.089 Y118.817 E.01471
G1 X111.699 Y118.356 E.01469
G1 X109.855 Y115.169 E.08956
G1 X109.686 Y114.772 E.0105
G1 X109.572 Y114.224 E.01361
G1 X109.571 Y113.783 E.01073
G1 X109.641 Y113.379 E.00997
G1 X109.758 Y113.08 E.00781
G1 X109.758 Y113.08 F9000
G1 X109.446 Y112.88
;TYPE:Perimeter
G1 F6000
G1 X109.538 Y112.648 E.00607
G1 X111.309 Y109.58 E.08617
G1 X111.767 Y108.991 E.01815
G1 X112.201 Y108.631 E.01372
G1 X112.741 Y108.355 E.01475
G1 X113.413 Y108.185 E.01686
G1 X114.233 Y108.161 E.01995
G1 X117.373 Y108.164 E.07638
G1 X117.907 Y108.242 E.01313
G1 X118.455 Y108.44 E.01417
G1 X118.91 Y108.726 E.01307
G1 X119.14 Y108.9 E.00702
G1 X119.515 Y109.316 E.01362
G1 X121.423 Y112.58 E.09196
G1 X121.63 Y113.023 E.01189
G1 X121.755 Y113.491 E.01178
G1 X121.797 Y114.171 E.01657
G1 X121.71 Y114.711 E.0133
G1 X121.504 Y115.269 E.01447
G1 X119.583 Y118.591 E.09334
G1 X119.254 Y118.995 E.01267
G1 X118.774 Y119.382 E.015
G1 X118.33 Y119.619 E.01224
G1 X117.82 Y119.778 E.01299
G1 X117.373 Y119.836 E.01096
G1 X113.721 Y119.84 E.08883
G1 X113.089 Y119.755 E.01551
G1 X112.442 Y119.508 E.01685
G1 X111.873 Y119.112 E.01686
G1 X111.418 Y118.59 E.01684
G1 X109.538 Y115.352 E.09107
G1 X109.328 Y114.846 E.01333
G1 X109.214 Y114.298 E.01361
G1 X109.21 Y113.724 E.01396
G1 X109.3 Y113.248 E.01178
G1 X109.424 Y112.936 E.00817
G1 X109.424 Y112.936 F9000
G1 X109.119 Y112.739
G1 F6000
G1 X109.221 Y112.465 E.00711
G1 X110.992 Y109.397 E.08617
G1 X111.48 Y108.764 E.01944
G1 X111.92 Y108.383 E.01416
G1 X112.396 Y108.12 E.01323
G1 X112.786 Y107.953 E.01032
G1 X113.332 Y107.828 E.01362
G1 X114.219 Y107.796 E.02159
G1 X117.373 Y107.798 E.07672
G1 X117.872 Y107.86 E.01223
G1 X118.579 Y108.096 E.01813
G1 X119.114 Y108.423 E.01525
G1 X119.411 Y108.655 E.00917
G1 X119.787 Y109.07 E.01362
G1 X119.899 Y109.224 E.00463
G1 X121.739 Y112.396 E.0892
G1 X121.981 Y112.92 E.01404
G1 X122.12 Y113.461 E.01359
G1 X122.165 Y114.019 E.01362
G1 X122.159 Y114.222 E.00494
G1 X122.055 Y114.832 E.01505
G1 X121.82 Y115.452 E.01613
G1 X119.9 Y118.774 E.09333
G1 X119.572 Y119.188 E.01285
G1 X119.122 Y119.572 E.01439
G1 X118.845 Y119.769 E.00827
G1 X118.374 Y119.994 E.0127
G1 X117.872 Y120.14 E.01272
G1 X117.373 Y120.202 E.01223
G1 X113.722 Y120.206 E.08881
G1 X113.037 Y120.117 E.0168
G1 X112.49 Y119.923 E.01412
G1 X112.108 Y119.738 E.01032
G1 X111.657 Y119.407 E.01361
G1 X111.137 Y118.824 E.019
G1 X111.048 Y118.697 E.00377
G1 X109.221 Y115.535 E.08883
G1 X108.97 Y114.92 E.01616
G1 X108.856 Y114.372 E.01361
G1 X108.837 Y113.813 E.0136
G1 X108.91 Y113.296 E.0127
G1 X109.098 Y112.795 E.01302
G1 X109.098 Y112.795 F9000
G1 X108.774 Y112.59
G1 F6000
G1 X108.819 Y112.463 E.00328
G1 X108.905 Y112.282 E.00487
G1 X110.676 Y109.214 E.08617
G1 X111.193 Y108.537 E.02072
G1 X111.692 Y108.097 E.01618
G1 X112.23 Y107.794 E.01502
G1 X112.704 Y107.597 E.01249
G1 X113.25 Y107.472 E.01362
G1 X114.214 Y107.43 E.02347
G1 X117.374 Y107.432 E.07686
G1 X117.924 Y107.498 E.01347
G1 X118.457 Y107.663 E.01357
G1 X118.938 Y107.865 E.01269
G1 X119.446 Y108.205 E.01487
G1 X119.897 Y108.647 E.01536
G1 X120.215 Y109.041 E.01232
G1 X122.055 Y112.213 E.0892
G1 X122.331 Y112.817 E.01615
G1 X122.484 Y113.431 E.01539
G1 X122.53 Y113.989 E.01362
G1 X122.521 Y114.274 E.00694
G1 X122.4 Y114.953 E.01678
G1 X122.137 Y115.635 E.01778
G1 X120.216 Y118.957 E.09334
G1 X119.854 Y119.422 E.01433
G1 X119.35 Y119.857 E.01619
G1 X119.01 Y120.095 E.0101
G1 X118.484 Y120.342 E.01413
G1 X117.924 Y120.501 E.01416
G1 X117.374 Y120.568 E.01348
G1 X113.722 Y120.571 E.08883
G1 X113.211 Y120.511 E.01251
G1 X112.683 Y120.397 E.01314
G1 X112.165 Y120.185 E.01361
G1 X111.646 Y119.852 E.015
G1 X111.213 Y119.487 E.01378
G1 X110.855 Y119.057 E.01361
G1 X110.732 Y118.879 E.00526
G1 X108.905 Y115.718 E.08881
G1 X108.69 Y115.243 E.01268
G1 X108.498 Y114.446 E.01994
G1 X108.472 Y113.813 E.01541
G1 X108.549 Y113.237 E.01414
G1 X108.754 Y112.647 E.01519
G1 E-5 F3600
G1 X108.754 Y112.647 F9000
G1 X108.254 Y101.069
G1 E5 F2400
G1 F6000
G1 X108.14 Y100.52 E.01364
G1 X108.106 Y99.813 E.01722
G1 X108.188 Y99.177 E.0156
G1 X108.477 Y98.331 E.02175
G1 X108.588 Y98.1 E.00623
G1 X110.359 Y95.031 E.08619
G1 X110.906 Y94.311 E.02199
G1 X111.225 Y94.003 E.01079
G1 X111.676 Y93.672 E.01361
G1 X112.305 Y93.348 E.01721
G1 X113.169 Y93.115 E.02177
G1 X113.511 Y93.074 E.00838
G1 X117.373 Y93.067 E.09394
G1 X118.223 Y93.196 E.02091
G1 X118.89 Y93.432 E.01721
G1 X119.65 Y93.902 E.02174
G1 X120.056 Y94.278 E.01346
G1 X120.531 Y94.857 E.01822
G1 X122.372 Y98.029 E.08921
G1 X122.682 Y98.714 E.01829
G1 X122.827 Y99.235 E.01315
G1 X122.894 Y99.959 E.01769
G1 X122.884 Y100.325 E.00891
G1 X122.745 Y101.074 E.01853
G1 X122.545 Y101.634 E.01446
G1 X120.533 Y105.14 E.09832
G1 X120.135 Y105.656 E.01585
G1 X119.578 Y106.143 E.018
G1 X119.176 Y106.421 E.01189
G1 X118.594 Y106.691 E.01561
;WIDTH:0.409556
G1 X117.977 Y106.868 E.01602
;WIDTH:0.449313
G1 X117.887 Y106.901 E.00265
;WIDTH:0.489069
G1 X117.798 Y106.934 E.00287
;WIDTH:0.528826
G1 X117.708 Y106.967 E.00315
;WIDTH:0.568582
G1 X117.619 Y107 E.00337
G1 X117.773 Y107.049 E.00574
;WIDTH:0.526437
G1 X117.928 Y107.098 E.00532
;WIDTH:0.484291
G1 X118.083 Y107.147 E.00487
;WIDTH:0.442145
G1 X118.238 Y107.196 E.00441
;WIDTH:0.399999
G1 X118.827 Y107.408 E.01523
G1 X119.186 Y107.589 E.00978
G1 X119.65 Y107.902 E.01361
G1 X119.954 Y108.165 E.00978
G1 X120.329 Y108.58 E.01361
G1 X120.531 Y108.857 E.00834
G1 X122.372 Y112.029 E.08921
G1 X122.682 Y112.714 E.01829
G1 X122.849 Y113.401 E.0172
G1 X122.894 Y113.959 E.01362
G1 X122.884 Y114.325 E.00891
G1 X122.745 Y115.074 E.01853
G1 X122.454 Y115.818 E.01943
G1 X120.533 Y119.14 E.09334
G1 X120.135 Y119.656 E.01585
G1 X119.578 Y120.143 E.018
G1 X119.176 Y120.421 E.01189
G1 X118.594 Y120.691 E.01561
G1 X117.976 Y120.863 E.0156
;WIDTH:0.448816
G1 X117.825 Y120.909 E.00435
;WIDTH:0.497633
G1 X117.674 Y120.954 E.00486
;WIDTH:0.54645
G1 X117.522 Y121 E.00541
G1 X117.761 Y121.065 E.00844
;WIDTH:0.497633
G1 X117.999 Y121.131 E.00761
;WIDTH:0.448816
G1 X118.238 Y121.196 E.00683
;WIDTH:0.399999
G1 X118.827 Y121.408 E.01523
G1 X119.186 Y121.589 E.00978
G1 X119.65 Y121.902 E.01361
G1 X119.954 Y122.165 E.00978
G1 X120.329 Y122.58 E.01361
G1 X120.531 Y122.857 E.00834
G1 X122.372 Y126.029 E.08921
G1 X122.682 Y126.714 E.01829
G1 X122.849 Y127.401 E.0172
G1 X122.894 Y127.959 E.01362
G1 X122.884 Y128.325 E.00891
G1 X122.745 Y129.074 E.01853
G1 X122.454 Y129.818 E.01943
G1 X120.533 Y133.14 E.09334
G1 X120.135 Y133.656 E.01585
G1 X119.458 Y134.24 E.02175
G1 X118.842 Y134.59 E.01723
G1 X118.238 Y134.804 E.01559
G1 X117.607 Y134.917 E.01559
G1 X117.374 Y134.933 E.00568
G1 X113.721 Y134.937 E.08886
G1 X112.932 Y134.841 E.01933
G1 X112.545 Y134.735 E.00976
G1 X112.027 Y134.524 E.01361
G1 X111.676 Y134.327 E.00979
G1 X111.224 Y133.996 E.01363
G1 X110.932 Y133.721 E.00976
G1 X110.574 Y133.291 E.01361
G1 X110.415 Y133.062 E.00678
G1 X108.588 Y129.901 E.08881
G1 X108.354 Y129.388 E.01372
G1 X108.14 Y128.52 E.02175
G1 X108.106 Y127.813 E.01722
G1 X108.188 Y127.177 E.0156
G1 X108.477 Y126.331 E.02175
G1 X108.588 Y126.099 E.00626
G1 X110.359 Y123.031 E.08617
G1 X110.906 Y122.311 E.02199
G1 X111.265 Y121.97 E.01204
G1 X111.745 Y121.63 E.01431
G1 X112.245 Y121.377 E.01363
G1 X112.623 Y121.24 E.00978
;WIDTH:0.425874
G1 X113.166 Y121.103 E.01459
;WIDTH:0.469176
G1 X113.269 Y121.068 E.00315
;WIDTH:0.512477
G1 X113.372 Y121.033 E.00346
;WIDTH:0.555778
G1 X113.475 Y120.997 E.00378
G1 X113.34 Y120.958 E.00487
;WIDTH:0.516834
G1 X113.204 Y120.919 E.00454
;WIDTH:0.477889
G1 X113.068 Y120.88 E.00417
;WIDTH:0.438944
G1 X112.933 Y120.841 E.00378
;WIDTH:0.399999
G1 X112.545 Y120.735 E.00978
G1 X112.027 Y120.524 E.01361
G1 X111.676 Y120.328 E.00978
G1 X111.224 Y119.996 E.01364
G1 X110.891 Y119.671 E.01132
G1 X110.415 Y119.062 E.0188
G1 X108.588 Y115.901 E.08881
G1 X108.354 Y115.388 E.01372
G1 X108.14 Y114.52 E.02175
G1 X108.106 Y113.813 E.01722
G1 X108.188 Y113.177 E.0156
G1 X108.477 Y112.331 E.02175
G1 X108.588 Y112.1 E.00623
G1 X110.359 Y109.031 E.08619
G1 X110.906 Y108.311 E.02199
G1 X111.265 Y107.97 E.01204
G1 X111.745 Y107.63 E.01431
G1 X112.245 Y107.377 E.01363
G1 X112.623 Y107.24 E.00978
;WIDTH:0.425892
G1 X113.166 Y107.103 E.01459
;WIDTH:0.46919
G1 X113.269 Y107.068 E.00315
;WIDTH:0.512487
G1 X113.372 Y107.033 E.00346
;WIDTH:0.555784
G1 X113.475 Y106.997 E.00378
G1 X113.339 Y106.958 E.00491
;WIDTH:0.516838
G1 X113.204 Y106.919 E.00451
;WIDTH:0.477892
G1 X113.068 Y106.88 E.00417
;WIDTH:0.438946
G1 X112.932 Y106.841 E.00381
;WIDTH:0.399999
G1 X112.545 Y106.735 E.00976
G1 X112.027 Y106.524 E.01361
G1 X111.676 Y106.327 E.00979
G1 X111.224 Y105.996 E.01363
G1 X110.891 Y105.671 E.01132
G1 X110.415 Y105.062 E.0188
G1 X108.588 Y101.901 E.08881
G1 X108.456 Y101.624 E.00746
G1 X108.274 Y101.125 E.01292
G1 E-5 F3600
G1 X108.274 Y101.125 F9000
G1 X109.221 Y114.23
G1 X109.249 Y114.459
G1 X109.296 Y114.684
G1 X109.361 Y114.905
G1 X109.444 Y115.12
G1 X109.544 Y115.33
G1 X110.457 Y116.912
G1 X111.33 Y118.422
G1 X111.392 Y118.526
G1 X111.525 Y118.715
G1 X111.672 Y118.892
G1 X111.833 Y119.057
G1 X112.007 Y119.208
G1 X112.193 Y119.344
G1 X112.389 Y119.465
G1 X112.595 Y119.569
G1 X112.808 Y119.656
G1 X113.028 Y119.725
G1 X117.522 Y121
G1 E5 F2400
;WIDTH:0.54645
G1 F6000
G1 X117.374 Y121 E.00504
;WIDTH:0.53337
G1 X114.23 Y121 E.10437
;WIDTH:0.534266
G1 X113.722 Y121.004 E.01689
;WIDTH:0.555778
G1 X113.475 Y120.997 E.00857
G1 E-5 F3600
G1 X113.475 Y120.997 F9000
G1 X111.33 Y118.422
G1 X109.544 Y115.33
G1 X109.444 Y115.12
G1 X109.221 Y114.23
G1 X109.212 Y114
G1 X109.221 Y113.77
G1 X109.249 Y113.541
G1 X109.296 Y113.316
G1 X109.361 Y113.095
G1 X109.444 Y112.88
G1 X109.544 Y112.67
G1 X110.457 Y111.088
G1 X111.33 Y109.578
G1 X111.391 Y109.474
G1 X111.525 Y109.285
G1 X111.672 Y109.108
G1 X111.833 Y108.943
G1 X112.007 Y108.792
G1 X112.193 Y108.656
G1 X112.389 Y108.535
G1 X112.595 Y108.431
G1 X112.808 Y108.344
G1 X113.028 Y108.275
G1 X117.619 Y107
G1 E5 F2400
;WIDTH:0.568582
G1 F6000
G1 X114.233 Y107 E.12033
;WIDTH:0.527734
G1 X114.207 Y107 E.00085
;WIDTH:0.555784
G1 X113.475 Y106.997 E.02539
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X114.207 Y107 E-.3477
G1 X114.233 Y107 E-.01235
G1 X116.633 Y107 E-1.13995
;WIPE_END
G1 X112.808 Y105.656 F9000
G1 X112.595 Y105.569
G1 X112.389 Y105.465
G1 X112.193 Y105.344
G1 X112.007 Y105.208
G1 X111.833 Y105.057
G1 X111.672 Y104.892
G1 X111.525 Y104.715
G1 X111.391 Y104.526
G1 X111.33 Y104.422
G1 X110.538 Y103.053
G1 X109.545 Y101.33
G1 X109.444 Y101.12
G1 X109.438 Y101.107
G1 X109.772 Y100.979
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X109.686 Y100.772 E.00545
G1 X109.572 Y100.224 E.01361
G1 X109.587 Y99.685 E.01312
G1 X109.647 Y99.365 E.00792
G1 X109.855 Y98.831 E.01394
G1 X111.626 Y95.763 E.08617
G1 X112.054 Y95.217 E.01687
G1 X112.541 Y94.852 E.0148
G1 X112.948 Y94.666 E.01088
G1 X113.494 Y94.541 E.01362
G1 X117.372 Y94.529 E.09433
G1 X117.956 Y94.635 E.01444
G1 X118.37 Y94.804 E.01088
G1 X118.835 Y95.116 E.01362
G1 X119.266 Y95.591 E.0156
G1 X121.107 Y98.763 E.08921
G1 X121.303 Y99.209 E.01185
G1 X121.391 Y99.52 E.00786
G1 X121.437 Y100.079 E.01364
G1 X121.365 Y100.59 E.01255
G1 X121.198 Y101.066 E.01227
G1 X119.266 Y104.408 E.0939
G1 X118.983 Y104.747 E.01074
G1 X118.546 Y105.096 E.0136
G1 X118.153 Y105.296 E.01073
G1 X117.768 Y105.416 E.00981
G1 X117.372 Y105.471 E.00972
G1 X113.721 Y105.474 E.08881
G1 X113.141 Y105.393 E.01424
G1 X112.58 Y105.17 E.01468
G1 X112.089 Y104.817 E.01471
G1 X111.681 Y104.331 E.01543
G1 X109.855 Y101.169 E.08882
G1 X109.799 Y101.043 E.00335
G1 X109.795 Y101.034 E.00024
G1 X109.437 Y101.123 F9000
;TYPE:Perimeter
G1 F6000
G1 X109.328 Y100.846 E.00724
G1 X109.214 Y100.298 E.01361
G1 X109.21 Y99.724 E.01396
G1 X109.305 Y99.234 E.01214
G1 X109.538 Y98.648 E.01534
G1 X111.309 Y95.58 E.08617
G1 X111.767 Y94.991 E.01815
G1 X112.325 Y94.557 E.01719
G1 X112.867 Y94.31 E.01449
G1 X113.413 Y94.185 E.01362
G1 X114.233 Y94.161 E.01995
G1 X117.373 Y94.164 E.07638
G1 X118.023 Y94.275 E.01604
G1 X118.574 Y94.5 E.01448
G1 X119.039 Y94.812 E.01362
G1 X119.515 Y95.316 E.01686
G1 X119.583 Y95.408 E.00278
G1 X121.423 Y98.58 E.0892
G1 X121.654 Y99.106 E.01397
G1 X121.755 Y99.491 E.00968
G1 X121.801 Y100.049 E.01362
G1 X121.736 Y100.606 E.01364
G1 X121.547 Y101.176 E.01461
G1 X119.583 Y104.591 E.09582
G1 X119.254 Y104.995 E.01267
G1 X118.774 Y105.382 E.015
G1 X118.33 Y105.619 E.01224
G1 X117.82 Y105.778 E.01299
G1 X117.373 Y105.836 E.01096
G1 X113.721 Y105.84 E.08883
G1 X113.089 Y105.755 E.01551
G1 X112.441 Y105.508 E.01687
G1 X111.873 Y105.112 E.01684
G1 X111.365 Y104.514 E.01909
G1 X109.538 Y101.352 E.08883
G1 X109.463 Y101.188 E.00439
G1 X109.46 Y101.179 E.00023
G1 X109.46 Y101.179 F9000
G1 X109.103 Y101.268
G1 F6000
G1 X108.97 Y100.921 E.00904
G1 X108.856 Y100.372 E.01364
G1 X108.837 Y99.813 E.0136
G1 X108.91 Y99.296 E.0127
G1 X109.221 Y98.465 E.02158
G1 X110.992 Y95.397 E.08617
G1 X111.48 Y94.764 E.01944
G1 X112.109 Y94.262 E.01958
G1 X112.609 Y94.013 E.01359
G1 X113.332 Y93.828 E.01815
G1 X114.219 Y93.796 E.02159
G1 X117.373 Y93.798 E.07672
G1 X118.089 Y93.916 E.01765
G1 X118.614 Y94.109 E.01361
G1 X119.243 Y94.509 E.01813
G1 X119.787 Y95.07 E.01901
G1 X119.899 Y95.224 E.00463
G1 X121.739 Y98.396 E.0892
G1 X121.981 Y98.92 E.01404
G1 X122.116 Y99.425 E.01271
G1 X122.165 Y100.019 E.0145
G1 X122.098 Y100.658 E.01563
G1 X121.892 Y101.298 E.01635
G1 X121.569 Y101.888 E.01636
G1 X119.9 Y104.774 E.08109
G1 X119.572 Y105.188 E.01285
G1 X119.122 Y105.572 E.01439
G1 X118.845 Y105.769 E.00827
G1 X118.374 Y105.994 E.0127
G1 X117.872 Y106.14 E.01272
G1 X117.373 Y106.202 E.01223
G1 X113.722 Y106.206 E.08881
G1 X113.037 Y106.117 E.0168
G1 X112.49 Y105.923 E.01412
G1 X112.108 Y105.738 E.01032
G1 X111.657 Y105.407 E.01361
G1 X111.137 Y104.823 E.01902
G1 X111.048 Y104.697 E.00375
G1 X109.221 Y101.535 E.08883
G1 X109.128 Y101.333 E.00541
G1 X109.124 Y101.324 E.00024
G1 X108.767 Y101.413 F9000
G1 F6000
G1 X108.612 Y100.995 E.01084
G1 X108.498 Y100.446 E.01364
G1 X108.472 Y99.813 E.01541
G1 X108.549 Y99.237 E.01414
G1 X108.819 Y98.463 E.01994
G1 X108.905 Y98.282 E.00487
G1 X110.676 Y95.214 E.08617
G1 X111.193 Y94.538 E.0207
G1 X111.441 Y94.298 E.00839
G1 X111.893 Y93.967 E.01363
G1 X112.457 Y93.68 E.01539
G1 X113.25 Y93.472 E.01994
G1 X114.214 Y93.43 E.02347
G1 X117.373 Y93.432 E.07684
G1 X118.156 Y93.556 E.01928
G1 X118.752 Y93.771 E.01541
G1 X119.446 Y94.205 E.01991
G1 X120.058 Y94.825 E.02119
G1 X120.215 Y95.041 E.0065
G1 X122.055 Y98.213 E.0892
G1 X122.331 Y98.817 E.01615
G1 X122.467 Y99.302 E.01225
G1 X122.53 Y99.989 E.01678
G1 X122.46 Y100.709 E.0176
G1 X122.237 Y101.419 E.0181
G1 X121.885 Y102.071 E.01802
G1 X120.216 Y104.957 E.08109
G1 X119.854 Y105.422 E.01433
G1 X119.35 Y105.857 E.01619
G1 X119.01 Y106.095 E.0101
G1 X118.484 Y106.342 E.01413
G1 X117.924 Y106.501 E.01416
G1 X117.374 Y106.568 E.01348
G1 X113.722 Y106.571 E.08883
G1 X113.211 Y106.511 E.01251
G1 X112.683 Y106.397 E.01314
G1 X112.165 Y106.185 E.01361
G1 X111.646 Y105.852 E.015
G1 X111.213 Y105.487 E.01378
G1 X110.855 Y105.057 E.01361
G1 X110.732 Y104.879 E.00526
G1 X108.905 Y101.718 E.08881
G1 X108.792 Y101.479 E.00643
G1 X108.788 Y101.469 E.00026
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X108.767 Y101.413 E-.02841
G1 X108.612 Y100.995 E-.21176
G1 X108.498 Y100.446 E-.26634
G1 X108.472 Y99.813 E-.30093
G1 X108.549 Y99.237 E-.27603
G1 X108.819 Y98.463 E-.38938
G1 X108.843 Y98.411 E-.02715
;WIPE_END
G1 X109.212 Y114 F9000
G1 X109.221 Y114.23
G1 X109.384 Y114.965
G1 X109.438 Y126.893
G1 X109.778 Y127.024
G1 E5 F2400
G1 F6000
G1 X109.842 Y126.856 E.00437
G1 X111.626 Y123.763 E.08685
G1 X112.054 Y123.217 E.01687
G1 X112.407 Y122.934 E.01101
G1 X112.906 Y122.681 E.01361
G1 X113.494 Y122.541 E.0147
G1 X117.373 Y122.529 E.09435
G1 X117.804 Y122.593 E.0106
G1 X118.33 Y122.783 E.0136
G1 X118.835 Y123.116 E.01471
G1 X119.266 Y123.591 E.0156
G1 X121.107 Y126.763 E.08921
G1 X121.279 Y127.126 E.00977
G1 X121.391 Y127.52 E.00996
G1 X121.437 Y128.079 E.01364
G1 X121.365 Y128.59 E.01255
G1 X121.187 Y129.086 E.01282
G1 X119.266 Y132.408 E.09334
G1 X118.983 Y132.747 E.01074
G1 X118.546 Y133.096 E.0136
G1 X118.153 Y133.296 E.01073
G1 X117.768 Y133.416 E.00981
G1 X117.373 Y133.471 E.0097
G1 X113.695 Y133.473 E.08946
G1 X113.141 Y133.393 E.01362
G1 X112.58 Y133.17 E.01468
G1 X112.089 Y132.817 E.01471
G1 X111.681 Y132.331 E.01543
G1 X109.855 Y129.169 E.08882
G1 X109.686 Y128.772 E.0105
G1 X109.572 Y128.224 E.01361
G1 X109.571 Y127.783 E.01073
G1 X109.641 Y127.379 E.00997
G1 X109.756 Y127.08 E.00779
G1 X109.756 Y127.08 F9000
G1 X109.442 Y126.879
;TYPE:Perimeter
G1 F6000
G1 X109.501 Y126.725 E.00401
G1 X111.309 Y123.58 E.08824
G1 X111.767 Y122.991 E.01815
G1 X112.201 Y122.631 E.01372
G1 X112.741 Y122.355 E.01475
G1 X113.413 Y122.185 E.01686
G1 X114.233 Y122.161 E.01995
G1 X117.373 Y122.164 E.07638
G1 X117.907 Y122.242 E.01313
G1 X118.455 Y122.44 E.01417
G1 X118.91 Y122.726 E.01307
G1 X119.14 Y122.9 E.00702
G1 X119.583 Y123.408 E.0164
G1 X121.423 Y126.58 E.0892
G1 X121.63 Y127.023 E.01189
G1 X121.755 Y127.491 E.01178
G1 X121.801 Y128.049 E.01362
G1 X121.736 Y128.606 E.01364
G1 X121.547 Y129.176 E.01461
G1 X119.583 Y132.591 E.09582
G1 X119.211 Y133.033 E.01405
G1 X118.774 Y133.382 E.0136
G1 X118.264 Y133.645 E.01396
G1 X117.82 Y133.778 E.01127
G1 X117.373 Y133.836 E.01096
G1 X113.643 Y133.835 E.09073
G1 X113.089 Y133.755 E.01362
G1 X112.441 Y133.508 E.01687
G1 X111.873 Y133.112 E.01684
G1 X111.365 Y132.514 E.01909
G1 X109.538 Y129.352 E.08883
G1 X109.328 Y128.846 E.01333
G1 X109.214 Y128.298 E.01361
G1 X109.21 Y127.724 E.01396
G1 X109.3 Y127.248 E.01178
G1 X109.42 Y126.935 E.00815
G1 X109.42 Y126.935 F9000
G1 X109.11 Y126.735
G1 F6000
G1 X109.16 Y126.594 E.00364
G1 X110.992 Y123.397 E.08963
G1 X111.48 Y122.764 E.01944
G1 X111.92 Y122.383 E.01416
G1 X112.396 Y122.12 E.01323
G1 X112.786 Y121.953 E.01032
G1 X113.332 Y121.828 E.01362
G1 X114.233 Y121.795 E.02193
G1 X117.373 Y121.798 E.07638
G1 X117.872 Y121.86 E.01223
G1 X118.579 Y122.096 E.01813
G1 X119.114 Y122.423 E.01525
G1 X119.411 Y122.655 E.00917
G1 X119.787 Y123.07 E.01362
G1 X119.899 Y123.224 E.00463
G1 X121.739 Y126.396 E.0892
G1 X121.981 Y126.92 E.01404
G1 X122.12 Y127.461 E.01359
G1 X122.165 Y128.019 E.01362
G1 X122.098 Y128.658 E.01563
G1 X121.892 Y129.298 E.01635
G1 X121.82 Y129.452 E.00414
G1 X119.9 Y132.774 E.09333
G1 X119.572 Y133.188 E.01285
G1 X119.002 Y133.668 E.01813
G1 X118.512 Y133.937 E.0136
G1 X118.017 Y134.106 E.01272
G1 X117.503 Y134.193 E.01268
G1 X113.59 Y134.196 E.09518
G1 X113.037 Y134.117 E.01359
G1 X112.303 Y133.847 E.01902
G1 X111.657 Y133.407 E.01901
G1 X111.137 Y132.824 E.019
G1 X111.048 Y132.697 E.00377
G1 X109.221 Y129.535 E.08883
G1 X108.97 Y128.921 E.01613
G1 X108.856 Y128.372 E.01364
G1 X108.837 Y127.813 E.0136
G1 X108.91 Y127.296 E.0127
G1 X109.089 Y126.792 E.01301
G1 X109.089 Y126.792 F9000
G1 X108.774 Y126.59
G1 F6000
G1 X108.819 Y126.463 E.00328
G1 X108.905 Y126.282 E.00487
G1 X110.676 Y123.214 E.08617
G1 X111.193 Y122.537 E.02072
G1 X111.692 Y122.097 E.01618
G1 X112.231 Y121.794 E.01504
G1 X112.704 Y121.597 E.01246
G1 X113.25 Y121.472 E.01362
G1 X114.214 Y121.43 E.02347
G1 X117.374 Y121.432 E.07686
G1 X117.924 Y121.498 E.01347
G1 X118.457 Y121.663 E.01357
G1 X118.938 Y121.865 E.01269
G1 X119.446 Y122.205 E.01487
G1 X119.897 Y122.647 E.01536
G1 X120.215 Y123.041 E.01232
G1 X122.055 Y126.213 E.0892
G1 X122.331 Y126.817 E.01615
G1 X122.484 Y127.431 E.01539
G1 X122.53 Y127.989 E.01362
G1 X122.46 Y128.709 E.0176
G1 X122.237 Y129.419 E.0181
G1 X122.137 Y129.635 E.00579
G1 X120.216 Y132.957 E.09334
G1 X119.854 Y133.422 E.01433
G1 X119.23 Y133.954 E.01995
G1 X118.677 Y134.264 E.01542
G1 X118.128 Y134.455 E.01414
G1 X117.555 Y134.555 E.01415
G1 X113.721 Y134.571 E.09326
G1 X113.538 Y134.558 E.00446
G1 X112.985 Y134.479 E.01359
G1 X112.165 Y134.185 E.02119
G1 X111.441 Y133.702 E.02117
G1 X111.213 Y133.487 E.00762
G1 X110.855 Y133.057 E.01361
G1 X110.732 Y132.879 E.00526
G1 X108.905 Y129.718 E.08881
G1 X108.69 Y129.243 E.01268
G1 X108.498 Y128.446 E.01994
G1 X108.472 Y127.813 E.01541
G1 X108.549 Y127.237 E.01414
G1 X108.754 Y126.647 E.01519
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X108.774 Y126.59 E-.02869
G1 X108.819 Y126.463 E-.064
G1 X108.905 Y126.282 E-.09519
G1 X110.286 Y123.89 E-1.31212
;WIPE_END
G1 X106.099 Y135.059 F9000
G1 X106.099 Y136.074
G1 X105.718 Y136.074
G1 E5 F2400
G1 F6000
G1 X105.75 Y136.004 E.00187
G1 X105.75 Y103.607 E.78802
G1 X105.727 Y103.518 E.00224
G1 X105.567 Y103.424 E.00451
G1 X105.188 Y103.424 E.00922
G1 X105.188 Y98.824 E.11189
G1 X105.567 Y98.824 E.00922
G1 X105.707 Y98.76 E.00374
G1 X105.75 Y98.643 E.00303
G1 X105.75 Y91.996 E.16168
G1 X105.687 Y91.858 E.00369
G1 X104.966 Y91.231 E.02324
G1 X104.499 Y90.782 E.01576
G1 X104.326 Y90.54 E.00724
G1 X104.357 Y90.406 E.00335
G1 X104.7 Y90.014 E.01267
G1 X105.576 Y89.239 E.02845
G1 X125.425 Y89.239 E.48281
G1 X126.402 Y90.115 E.03192
G1 X126.644 Y90.414 E.00936
G1 X126.674 Y90.535 E.00303
G1 X126.435 Y90.854 E.0097
G1 X126.035 Y91.23 E.01335
G1 X125.313 Y91.858 E.02328
G1 X125.25 Y91.996 E.00369
G1 X125.25 Y98.555 E.15954
G1 X125.281 Y98.743 E.00463
G1 X125.433 Y98.824 E.00419
G1 X125.812 Y98.824 E.00922
G1 X125.812 Y103.424 E.11189
G1 X125.433 Y103.424 E.00922
G1 X125.29 Y103.493 E.00386
G1 X125.25 Y103.607 E.00294
G1 X125.25 Y136.004 E.78802
G1 X125.313 Y136.142 E.00369
G1 X126.034 Y136.77 E.02326
G1 X126.501 Y137.218 E.01574
G1 X126.645 Y137.417 E.00597
G1 X126.671 Y137.512 E.0024
G1 X126.643 Y137.594 E.00211
G1 X126.3 Y137.986 E.01267
G1 X125.424 Y138.761 E.02845
G1 X105.575 Y138.761 E.48281
G1 X104.598 Y137.885 E.03192
G1 X104.356 Y137.586 E.00936
G1 X104.326 Y137.465 E.00303
G1 X104.565 Y137.146 E.0097
G1 X104.965 Y136.77 E.01335
G1 X105.687 Y136.142 E.02328
G1 X105.693 Y136.128 E.00037
G1 X105.693 Y136.128 F9000
G1 X106.057 Y136.232
;TYPE:Perimeter
G1 F6000
G1 X106.079 Y136.2 E.00094
G1 X106.116 Y136.004 E.00485
G1 X106.116 Y103.607 E.78802
G1 X106.098 Y103.471 E.00334
G1 X106.011 Y103.286 E.00497
G1 X105.554 Y103.059 E.01241
G1 X105.554 Y99.204 E.09377
G1 X105.986 Y98.996 E.01166
G1 X106.076 Y98.846 E.00425
G1 X106.116 Y98.645 E.00498
G1 X106.116 Y91.996 E.16173
G1 X106.079 Y91.8 E.00485
G1 X105.927 Y91.582 E.00646
G1 X105.213 Y90.961 E.02302
G1 X104.751 Y90.516 E.0156
G1 X104.951 Y90.28 E.00752
G1 X105.714 Y89.604 E.0248
G1 X125.288 Y89.604 E.47612
G1 X125.802 Y90.053 E.0166
G1 X126.246 Y90.497 E.01527
G1 X126.161 Y90.61 E.00344
G1 X125.79 Y90.958 E.01237
G1 X125.073 Y91.582 E.02312
G1 X124.921 Y91.8 E.00646
G1 X124.884 Y91.996 E.00485
G1 X124.884 Y98.19 E.15066
G1 X124.899 Y98.769 E.01409
G1 X125.014 Y98.996 E.00619
G1 X125.446 Y99.19 E.01152
G1 X125.446 Y103.045 E.09377
G1 X125.004 Y103.266 E.01202
G1 X124.964 Y103.322 E.00167
G1 X124.884 Y103.607 E.0072
G1 X124.884 Y136.004 E.78802
G1 X124.921 Y136.2 E.00485
G1 X125.073 Y136.418 E.00646
G1 X125.798 Y137.05 E.02339
G1 X126.262 Y137.502 E.01576
G1 X126.049 Y137.72 E.00741
G1 X125.286 Y138.396 E.0248
G1 X105.712 Y138.396 E.47612
G1 X105.197 Y137.946 E.01664
G1 X104.754 Y137.503 E.01524
G1 X104.839 Y137.39 E.00344
G1 X105.21 Y137.042 E.01237
G1 X105.927 Y136.418 E.02312
G1 X106.023 Y136.281 E.00407
G1 X106.023 Y136.281 F9000
G1 X106.384 Y136.384
G1 F6000
G1 X106.421 Y136.332 E.00155
G1 X106.481 Y136.004 E.00811
G1 X106.481 Y103.607 E.78802
G1 X106.453 Y103.38 E.00556
G1 X106.308 Y103.071 E.0083
G1 X105.919 Y102.863 E.01073
G1 X105.919 Y99.392 E.08443
G1 X106.265 Y99.232 E.00927
G1 X106.415 Y98.983 E.00707
G1 X106.481 Y98.648 E.00831
G1 X106.481 Y91.996 E.1618
G1 X106.421 Y91.668 E.00811
G1 X106.167 Y91.307 E.01074
G1 X105.258 Y90.497 E.02962
G1 X105.853 Y89.97 E.01933
G1 X125.151 Y89.97 E.4694
G1 X125.744 Y90.5 E.01935
G1 X124.833 Y91.307 E.0296
G1 X124.579 Y91.668 E.01074
G1 X124.519 Y91.996 E.00811
G1 X124.519 Y98.555 E.15954
G1 X124.558 Y98.908 E.00864
G1 X124.735 Y99.232 E.00898
G1 X125.081 Y99.393 E.00928
G1 X125.081 Y102.863 E.0844
G1 X124.717 Y103.038 E.00982
G1 X124.574 Y103.293 E.00711
G1 X124.519 Y103.607 E.00775
G1 X124.519 Y136.004 E.78802
G1 X124.579 Y136.332 E.00811
G1 X124.833 Y136.693 E.01074
G1 X125.742 Y137.503 E.02962
G1 X125.147 Y138.03 E.01933
G1 X105.849 Y138.03 E.4694
G1 X105.256 Y137.5 E.01935
G1 X106.167 Y136.693 E.0296
G1 X106.35 Y136.433 E.00773
G1 X106.35 Y136.433 F9000
G1 X106.711 Y136.536
G1 F6000
G1 X106.762 Y136.463 E.00217
G1 X106.847 Y136.004 E.01135
G1 X106.847 Y103.607 E.78802
G1 X106.769 Y103.168 E.01085
G1 X106.604 Y102.857 E.00856
G1 X106.285 Y102.674 E.00895
G1 X106.285 Y99.589 E.07504
G1 X106.544 Y99.469 E.00694
G1 X106.775 Y99.065 E.01132
G1 X106.847 Y98.65 E.01025
G1 X106.847 Y91.996 E.16185
G1 X106.762 Y91.537 E.01135
G1 X106.407 Y91.031 E.01503
G1 X105.802 Y90.504 E.01952
G1 X105.992 Y90.336 E.00617
G1 X125.014 Y90.336 E.46269
G1 X125.203 Y90.5 E.00609
G1 X124.593 Y91.031 E.01967
G1 X124.238 Y91.537 E.01503
G1 X124.153 Y91.996 E.01135
G1 X124.153 Y98.642 E.16166
G1 X124.224 Y99.063 E.01039
G1 X124.456 Y99.469 E.01137
G1 X124.715 Y99.589 E.00694
G1 X124.715 Y102.674 E.07504
G1 X124.431 Y102.81 E.00766
G1 X124.231 Y103.168 E.00997
G1 X124.153 Y103.607 E.01085
G1 X124.153 Y136.004 E.78802
G1 X124.238 Y136.463 E.01135
G1 X124.593 Y136.969 E.01503
G1 X125.198 Y137.496 E.01952
G1 X125.008 Y137.664 E.00617
G1 X105.986 Y137.664 E.46269
G1 X105.797 Y137.5 E.00609
G1 X106.407 Y136.969 E.01967
G1 X106.676 Y136.585 E.0114
G1 X106.676 Y136.585 F9000
G1 X107.037 Y136.688
G1 F6000
G1 X107.103 Y136.594 E.00279
G1 X107.213 Y136.004 E.0146
G1 X107.213 Y103.607 E.78802
G1 X107.113 Y103.043 E.01393
G1 X106.855 Y102.583 E.01283
G1 X106.651 Y102.484 E.00552
G1 X106.651 Y99.785 E.06565
G1 X106.823 Y99.705 E.00461
G1 X107.094 Y99.256 E.01276
G1 X107.176 Y98.986 E.00686
G1 X107.213 Y98.642 E.00842
G1 X107.213 Y91.996 E.16166
G1 X107.103 Y91.406 E.0146
G1 X106.586 Y90.701 E.02127
G1 X124.414 Y90.701 E.43365
G1 X124.353 Y90.755 E.00198
G1 X123.897 Y91.406 E.01933
G1 X123.787 Y91.996 E.0146
G1 X123.787 Y98.19 E.15066
G1 X123.802 Y98.857 E.01623
G1 X123.879 Y99.183 E.00815
G1 X124.177 Y99.705 E.01462
G1 X124.349 Y99.785 E.00461
G1 X124.349 Y102.484 E.06565
G1 X124.145 Y102.583 E.00552
G1 X123.887 Y103.042 E.01281
G1 X123.787 Y103.607 E.01396
G1 X123.787 Y136.004 E.78802
G1 X123.897 Y136.594 E.0146
G1 X124.414 Y137.299 E.02127
G1 X106.586 Y137.299 E.43365
G1 X106.647 Y137.245 E.00198
G1 X107.003 Y136.737 E.01509
G1 X107.003 Y136.737 F9000
G1 X107.539 Y137.189
;TYPE:Internal infill
;WIDTH:0.4
G1 F3072.127
G1 X107.231 Y136.881 E.0106
G1 X107.36 Y136.696 E.00549
G1 X107.392 Y136.523 E.00428
G1 X107.894 Y137.025 E.01727
G1 X108.413 Y137.025 E.01262
G1 X107.473 Y136.085 E.03234
G1 X107.487 Y135.579 E.01231
G1 X108.932 Y137.025 E.04972
G1 X109.451 Y137.025 E.01262
G1 X107.487 Y135.06 E.06758
G1 X107.487 Y134.541 E.01262
G1 X109.971 Y137.025 E.08545
G1 X110.49 Y137.025 E.01262
G1 X107.487 Y134.022 E.1033
G1 X107.487 Y133.503 E.01262
G1 X111.009 Y137.025 E.12115
G1 X111.528 Y137.025 E.01262
G1 X107.487 Y132.983 E.13903
G1 X107.487 Y132.464 E.01262
G1 X112.047 Y137.025 E.15688
G1 X112.566 Y137.025 E.01262
G1 X107.487 Y131.945 E.17473
G1 X107.487 Y131.426 E.01262
G1 X113.086 Y137.025 E.1926
G1 X113.605 Y137.025 E.01262
G1 X107.487 Y130.907 E.21046
G1 X107.487 Y130.388 E.01262
G1 X110.014 Y132.915 E.08693
G1 X110.361 Y133.463 E.01578
G1 X110.755 Y133.937 E.01499
G1 X111.058 Y134.215 E.01
G1 X111.82 Y134.721 E.02225
G1 X114.124 Y137.025 E.07926
G1 X114.643 Y137.025 E.01262
G1 X112.671 Y135.052 E.06785
G1 X113.31 Y135.172 E.01581
G1 X115.162 Y137.025 E.06372
G1 X115.681 Y137.025 E.01262
G1 X113.868 Y135.211 E.06238
G1 X114.387 Y135.211 E.01262
G1 X116.2 Y137.025 E.06238
G1 X116.72 Y137.025 E.01265
G1 X114.905 Y135.21 E.06243
G1 X115.424 Y135.21 E.01262
G1 X117.239 Y137.025 E.06243
G1 X117.758 Y137.025 E.01262
G1 X115.942 Y135.209 E.06247
G1 X116.461 Y135.208 E.01262
G1 X118.277 Y137.025 E.06249
G1 X118.796 Y137.025 E.01262
G1 X116.98 Y135.208 E.06249
G1 X117.49 Y135.199 E.01241
G1 X119.315 Y137.025 E.0628
G1 X119.835 Y137.025 E.01265
G1 X117.953 Y135.143 E.06474
G1 X118.377 Y135.047 E.01057
G1 X120.354 Y137.025 E.06802
G1 X120.873 Y137.025 E.01262
G1 X118.765 Y134.917 E.07251
G1 X119.123 Y134.755 E.00956
G1 X121.392 Y137.025 E.07807
G1 X121.911 Y137.025 E.01262
G1 X119.454 Y134.567 E.08454
G1 X119.757 Y134.351 E.00905
G1 X122.43 Y137.025 E.09197
G1 X122.95 Y137.025 E.01265
G1 X120.046 Y134.121 E.0999
G1 X120.311 Y133.866 E.00895
G1 X123.469 Y137.025 E.10865
G1 X123.87 Y137.025 E.00975
G1 X123.635 Y136.672 E.01032
G1 X120.549 Y133.586 E.10616
G1 X120.766 Y133.284 E.00905
G1 X123.517 Y136.035 E.09463
G1 X123.513 Y135.511 E.01275
G1 X120.957 Y132.955 E.08792
G1 X121.147 Y132.626 E.00924
G1 X123.513 Y134.992 E.08139
G1 X123.513 Y134.473 E.01262
G1 X121.337 Y132.297 E.07485
G1 X121.527 Y131.968 E.00924
G1 X123.513 Y133.954 E.06832
G1 X123.513 Y133.435 E.01262
G1 X121.718 Y131.639 E.06176
G1 X121.908 Y131.31 E.00924
G1 X123.513 Y132.916 E.05523
G1 X123.513 Y132.396 E.01265
G1 X122.098 Y130.981 E.04868
G1 X122.288 Y130.652 E.00924
G1 X123.513 Y131.877 E.04214
G1 X123.513 Y131.358 E.01262
G1 X122.478 Y130.323 E.0356
G1 X122.669 Y129.994 E.00925
G1 X123.513 Y130.839 E.02905
G1 X123.513 Y130.32 E.01262
G1 X122.836 Y129.642 E.02331
G1 X122.971 Y129.259 E.00988
G1 X123.513 Y129.801 E.01864
G1 X123.513 Y129.281 E.01265
G1 X123.081 Y128.85 E.01484
G1 X123.15 Y128.399 E.0111
G1 X123.513 Y128.762 E.01249
G1 X123.513 Y128.243 E.01262
G1 X123.164 Y127.894 E.01201
G1 X123.112 Y127.323 E.01395
G1 X123.513 Y127.724 E.01379
G1 X123.513 Y127.205 E.01262
G1 X122.946 Y126.637 E.01952
G1 X122.457 Y125.629 E.02725
G1 X123.513 Y126.686 E.03634
G1 X123.513 Y126.166 E.01265
G1 X121.739 Y124.392 E.06102
G1 X121.022 Y123.156 E.03476
G1 X123.513 Y125.647 E.08569
G1 X123.513 Y125.128 E.01262
G1 X119.133 Y120.748 E.15067
G1 X119.467 Y120.563 E.00929
G1 X123.513 Y124.609 E.13918
G1 X123.513 Y124.09 E.01262
G1 X119.765 Y120.342 E.12893
G1 X120.051 Y120.108 E.00899
G1 X123.513 Y123.571 E.11911
G1 X123.513 Y123.051 E.01265
G1 X120.317 Y119.855 E.10994
G1 X120.557 Y119.576 E.00895
G1 X123.513 Y122.532 E.10168
G1 X123.513 Y122.013 E.01262
G1 X120.773 Y119.273 E.09425
G1 X120.963 Y118.944 E.00924
G1 X123.513 Y121.494 E.08772
G1 X123.513 Y120.975 E.01262
G1 X121.153 Y118.615 E.08118
G1 X121.344 Y118.286 E.00925
G1 X123.513 Y120.456 E.07463
G1 X123.513 Y119.936 E.01265
G1 X121.534 Y117.957 E.06808
G1 X121.724 Y117.628 E.00924
G1 X123.513 Y119.417 E.06154
G1 X123.513 Y118.898 E.01262
G1 X121.914 Y117.299 E.055
G1 X122.104 Y116.97 E.00924
G1 X123.513 Y118.379 E.04847
G1 X123.513 Y117.86 E.01262
G1 X122.295 Y116.641 E.04192
G1 X122.485 Y116.312 E.00924
G1 X123.513 Y117.341 E.03538
G1 X123.513 Y116.821 E.01265
G1 X122.675 Y115.983 E.02883
G1 X122.841 Y115.63 E.00949
G1 X123.513 Y116.302 E.02312
G1 X123.513 Y115.783 E.01262
G1 X122.976 Y115.246 E.01847
G1 X123.087 Y114.838 E.01028
G1 X123.513 Y115.264 E.01465
G1 X123.513 Y114.745 E.01262
G1 X123.152 Y114.384 E.01242
G1 X123.163 Y113.875 E.01238
G1 X123.513 Y114.226 E.01206
G1 X123.513 Y113.706 E.01265
G1 X123.108 Y113.301 E.01393
G1 X122.936 Y112.61 E.01732
G1 X123.513 Y113.187 E.01985
G1 X123.513 Y112.668 E.01262
G1 X122.433 Y111.588 E.03715
G1 X121.715 Y110.351 E.03479
G1 X123.513 Y112.149 E.06185
G1 X123.513 Y111.63 E.01262
G1 X120.998 Y109.114 E.08653
G1 X120.536 Y108.4 E.02069
G1 X120.015 Y107.838 E.01864
G1 X119.139 Y107.256 E.02558
G1 X118.792 Y106.908 E.01195
G1 X119.145 Y106.742 E.00949
G1 X123.513 Y111.111 E.15027
G1 X123.513 Y110.591 E.01265
G1 X119.478 Y106.556 E.1388
G1 X119.775 Y106.334 E.00902
G1 X123.513 Y110.072 E.12858
G1 X123.513 Y109.553 E.01262
G1 X120.06 Y106.1 E.11878
G1 X120.325 Y105.846 E.00893
G1 X123.513 Y109.034 E.10967
G1 X123.513 Y108.515 E.01262
G1 X120.565 Y105.567 E.10141
G1 X120.779 Y105.262 E.00906
G1 X123.513 Y107.996 E.09405
G1 X123.513 Y107.476 E.01265
G1 X120.97 Y104.933 E.08748
G1 X121.16 Y104.604 E.00924
G1 X123.513 Y106.957 E.08094
G1 X123.513 Y106.438 E.01262
G1 X121.35 Y104.275 E.07441
G1 X121.54 Y103.946 E.00924
G1 X123.513 Y105.919 E.06787
G1 X123.513 Y105.4 E.01262
G1 X121.73 Y103.617 E.06133
G1 X121.921 Y103.288 E.00925
G1 X123.513 Y104.881 E.05478
G1 X123.513 Y104.362 E.01262
G1 X122.111 Y102.959 E.04825
G1 X122.301 Y102.63 E.00924
G1 X123.513 Y103.842 E.04169
G1 X123.546 Y103.356 E.01185
G1 X122.491 Y102.301 E.03629
G1 X122.681 Y101.972 E.00924
G1 X123.638 Y102.929 E.03292
G1 X123.813 Y102.584 E.00941
G1 X122.843 Y101.615 E.03335
G1 X122.98 Y101.232 E.00989
G1 X124.075 Y102.328 E.03768
G1 X124.075 Y101.809 E.01262
G1 X123.089 Y100.822 E.03394
G1 X123.154 Y100.369 E.01113
G1 X124.075 Y101.289 E.03166
G1 X124.075 Y100.77 E.01262
G1 X123.161 Y99.856 E.03144
G1 X123.111 Y99.287 E.01389
G1 X124.075 Y100.251 E.03316
G1 X124.075 Y99.941 E.00754
G1 X123.833 Y99.703 E.00826
G1 X123.622 Y99.279 E.01152
G1 X122.925 Y98.581 E.02399
G1 X122.408 Y97.546 E.02814
G1 X123.514 Y98.651 E.03803
G1 X123.513 Y98.132 E.01262
G1 X121.691 Y96.309 E.06269
G1 X120.973 Y95.073 E.03477
G1 X123.678 Y97.777 E.09303
G1 E-5 F3600
G1 X123.678 Y97.777 F9000
G1 X123.887 Y91.238
G1 E5 F2400
G1 F3072.127
G1 X123.625 Y90.975 E.00903
G1 X123.106 Y90.975 E.01262
G1 X123.608 Y91.477 E.01727
G1 X123.527 Y91.915 E.01083
G1 X122.587 Y90.975 E.03234
G1 X122.068 Y90.975 E.01262
G1 X123.513 Y92.421 E.04972
G1 X123.513 Y92.94 E.01262
G1 X121.549 Y90.975 E.06758
G1 X121.029 Y90.975 E.01265
G1 X123.513 Y93.459 E.08545
G1 X123.513 Y93.978 E.01262
G1 X120.51 Y90.975 E.1033
G1 X119.991 Y90.975 E.01262
G1 X123.513 Y94.497 E.12115
G1 X123.513 Y95.017 E.01265
G1 X119.472 Y90.975 E.13903
G1 X118.953 Y90.975 E.01262
G1 X123.513 Y95.536 E.15688
G1 X123.513 Y96.055 E.01262
G1 X118.434 Y90.975 E.17473
G1 X117.914 Y90.975 E.01265
G1 X123.513 Y96.574 E.1926
G1 X123.513 Y97.093 E.01262
G1 X117.395 Y90.975 E.21046
G1 X116.876 Y90.975 E.01262
G1 X119.175 Y93.274 E.07908
G1 X118.323 Y92.941 E.02225
G1 X116.357 Y90.975 E.06763
G1 X115.838 Y90.975 E.01262
G1 X117.683 Y92.821 E.06348
G1 X117.136 Y92.792 E.01332
G1 X115.319 Y90.975 E.0625
G1 X114.799 Y90.975 E.01265
G1 X116.616 Y92.792 E.0625
G1 X116.096 Y92.792 E.01265
G1 X114.28 Y90.975 E.06249
G1 X113.761 Y90.975 E.01262
G1 X115.577 Y92.791 E.06247
G1 X115.057 Y92.791 E.01265
G1 X113.242 Y90.975 E.06245
G1 X112.723 Y90.975 E.01262
G1 X114.538 Y92.79 E.06243
G1 X114.021 Y92.793 E.01258
G1 X112.204 Y90.975 E.06252
G1 X111.685 Y90.975 E.01262
G1 X113.509 Y92.8 E.06276
G1 X113.053 Y92.863 E.0112
G1 X111.165 Y90.975 E.06495
G1 X110.646 Y90.975 E.01262
G1 X112.629 Y92.958 E.06821
G1 X112.235 Y93.083 E.01005
G1 X110.127 Y90.975 E.07251
G1 X109.608 Y90.975 E.01262
G1 X111.875 Y93.243 E.078
G1 X111.545 Y93.432 E.00925
G1 X109.089 Y90.975 E.0845
G1 X108.57 Y90.975 E.01262
G1 X111.244 Y93.649 E.09198
G1 X110.955 Y93.88 E.009
G1 X108.05 Y90.975 E.09993
G1 X107.531 Y90.975 E.01262
G1 X110.695 Y94.139 E.10884
G1 X110.465 Y94.428 E.00898
G1 X107.365 Y91.328 E.10664
G1 X107.483 Y91.965 E.01576
G1 X110.239 Y94.721 E.0948
G1 X110.038 Y95.039 E.00915
G1 X107.487 Y92.489 E.08774
G1 X107.487 Y93.008 E.01262
G1 X109.848 Y95.369 E.08122
G1 X109.658 Y95.698 E.00924
G1 X107.486 Y93.526 E.07472
G1 X107.485 Y94.045 E.01262
G1 X109.468 Y96.027 E.0682
G1 X109.278 Y96.356 E.00924
G1 X107.484 Y94.563 E.0617
G1 X107.484 Y95.081 E.0126
G1 X109.088 Y96.685 E.05518
G1 X108.898 Y97.014 E.00924
G1 X107.483 Y95.6 E.04866
G1 X107.482 Y96.118 E.0126
G1 X108.708 Y97.344 E.04217
G1 X108.518 Y97.673 E.00924
G1 X107.481 Y96.636 E.03567
G1 X107.48 Y97.155 E.01262
G1 X108.33 Y98.004 E.02922
G1 X108.171 Y98.364 E.00957
G1 X107.48 Y97.673 E.02377
G1 X107.479 Y98.191 E.0126
G1 X108.027 Y98.739 E.01885
G1 X107.915 Y99.147 E.01029
G1 X107.478 Y98.71 E.01503
G1 X107.411 Y99.162 E.01111
G1 X107.849 Y99.6 E.01507
G1 X107.832 Y100.102 E.01222
G1 X107.26 Y99.53 E.01968
G1 X107.058 Y99.847 E.00914
G1 X107.894 Y100.683 E.02876
G1 X108.062 Y101.371 E.01723
G1 X106.925 Y100.233 E.03913
G1 X106.925 Y100.752 E.01262
G1 X108.543 Y102.37 E.05566
G1 X109.253 Y103.6 E.03455
G1 X106.925 Y101.272 E.08008
G1 X106.925 Y101.791 E.01262
G1 X109.964 Y104.829 E.10452
G1 X110.361 Y105.464 E.01822
G1 X110.839 Y106.026 E.01795
G1 X111.518 Y106.552 E.02089
G1 X111.899 Y106.765 E.01062
G1 X112.224 Y107.09 E.01118
G1 X111.873 Y107.258 E.00947
G1 X106.76 Y102.145 E.17588
G1 E-5 F3600
G1 X106.76 Y102.145 F9000
G1 X111.655 Y107.559
G1 E5 F2400
G1 F3072.127
G1 X107.457 Y103.361 E.14441
G1 X107.487 Y103.91 E.01337
G1 X111.226 Y107.65 E.12864
G1 X110.943 Y107.885 E.00895
G1 X107.487 Y104.429 E.11888
G1 X107.487 Y104.949 E.01265
G1 X110.686 Y108.148 E.11004
G1 X110.457 Y108.438 E.00899
G1 X107.487 Y105.468 E.10217
G1 X107.487 Y105.987 E.01262
G1 X110.232 Y108.732 E.09443
G1 X110.031 Y109.051 E.00917
G1 X107.487 Y106.506 E.08753
G1 X107.487 Y107.025 E.01262
G1 X109.841 Y109.38 E.08099
G1 X109.651 Y109.709 E.00924
G1 X107.487 Y107.544 E.07446
G1 X107.487 Y108.064 E.01265
G1 X109.461 Y110.038 E.0679
G1 X109.271 Y110.367 E.00924
G1 X107.487 Y108.583 E.06137
G1 X107.487 Y109.102 E.01262
G1 X109.081 Y110.696 E.05483
G1 X108.891 Y111.025 E.00924
G1 X107.487 Y109.621 E.0483
G1 X107.487 Y110.14 E.01262
G1 X108.701 Y111.355 E.04178
G1 X108.511 Y111.684 E.00924
G1 X107.487 Y110.659 E.03524
G1 X107.487 Y111.179 E.01265
G1 X108.324 Y112.016 E.02879
G1 X108.166 Y112.377 E.00959
G1 X107.487 Y111.698 E.02336
G1 X107.487 Y112.217 E.01262
G1 X108.022 Y112.752 E.0184
G1 X107.913 Y113.162 E.01032
G1 X107.487 Y112.736 E.01465
G1 X107.487 Y113.255 E.01262
G1 X107.847 Y113.616 E.0124
G1 X107.832 Y114.119 E.01224
G1 X107.487 Y113.774 E.01187
G1 X107.487 Y114.294 E.01265
G1 X107.899 Y114.706 E.01417
G1 X108.07 Y115.396 E.01729
G1 X107.487 Y114.813 E.02005
G1 X107.487 Y115.332 E.01262
G1 X108.566 Y116.411 E.03712
G1 X109.277 Y117.641 E.03456
G1 X107.487 Y115.851 E.06157
G1 X107.487 Y116.37 E.01262
G1 X109.987 Y118.871 E.08602
G1 X110.361 Y119.464 E.01705
G1 X110.839 Y120.027 E.01796
G1 X111.866 Y120.749 E.03054
G1 X112.212 Y121.095 E.0119
G1 X111.863 Y121.266 E.00945
G1 X107.487 Y116.889 E.15055
G1 X107.487 Y117.409 E.01265
G1 X111.521 Y121.443 E.13877
G1 X111.225 Y121.666 E.00901
G1 X107.487 Y117.928 E.12858
G1 X107.487 Y118.447 E.01262
G1 X110.936 Y121.896 E.11864
G1 X110.684 Y122.164 E.00895
G1 X107.487 Y118.966 E.10999
G1 X107.487 Y119.485 E.01262
G1 X110.452 Y122.45 E.10199
G1 X110.225 Y122.742 E.009
G1 X107.487 Y120.004 E.09419
G1 X107.487 Y120.524 E.01265
G1 X110.025 Y123.062 E.08731
G1 X109.835 Y123.391 E.00924
G1 X107.487 Y121.043 E.08077
G1 X107.487 Y121.562 E.01262
G1 X109.645 Y123.72 E.07423
G1 X109.455 Y124.049 E.00924
G1 X107.487 Y122.081 E.0677
G1 X107.487 Y122.6 E.01262
G1 X109.265 Y124.378 E.06116
G1 X109.075 Y124.707 E.00924
G1 X107.487 Y123.119 E.05463
G1 X107.487 Y123.638 E.01262
G1 X108.885 Y125.037 E.04811
G1 X108.695 Y125.366 E.00924
G1 X107.487 Y124.158 E.04155
G1 X107.487 Y124.677 E.01262
G1 X108.505 Y125.695 E.03502
G1 X108.319 Y126.028 E.00928
G1 X107.487 Y125.196 E.02862
G1 X107.487 Y125.715 E.01262
G1 X108.161 Y126.389 E.02319
G1 X108.017 Y126.765 E.00979
G1 X107.487 Y126.234 E.01825
G1 X107.487 Y126.753 E.01262
G1 X107.911 Y127.177 E.01459
G1 X107.846 Y127.632 E.01118
G1 X107.487 Y127.273 E.01235
G1 X107.487 Y127.792 E.01262
G1 X107.832 Y128.137 E.01187
G1 X107.903 Y128.728 E.01448
G1 X107.487 Y128.311 E.01433
G1 X107.487 Y128.83 E.01262
G1 X108.079 Y129.422 E.02036
G1 X108.618 Y130.48 E.02888
G1 X107.487 Y129.349 E.03891
G1 X107.487 Y129.868 E.01262
G1 X109.761 Y132.142 E.07822
G1 E-5 F3600
G1 X109.761 Y132.142 F9000
G1 X109.249 Y128.459
G1 X109.221 Y128.23
G1 X109.212 Y128
G1 X109.221 Y127.77
G1 X109.249 Y127.541
G1 X109.296 Y127.316
G1 X109.361 Y127.095
G1 X109.444 Y126.88
G1 X109.545 Y126.67
G1 X110.667 Y124.724
G1 X111.33 Y123.578
G1 X111.391 Y123.474
G1 X111.525 Y123.285
G1 X111.672 Y123.108
G1 X111.833 Y122.943
G1 X112.007 Y122.792
G1 X112.193 Y122.656
G1 X112.389 Y122.535
G1 X112.595 Y122.431
G1 X112.808 Y122.344
G1 X113.028 Y122.275
G1 X113.252 Y122.223
G1 X113.48 Y122.191
G1 X119.606 Y121.74
G1 E5 F2400
G1 F3072.127
G1 X118.652 Y120.786 E.03282
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X119.606 Y121.74 E-.64085
;WIPE_END
G1 E-.85915 F3600
G1 X121.674 Y114.796 F9000
G1 X121.73 Y114.572
G1 X121.767 Y114.345
G1 X121.786 Y114.115
G1 X121.786 Y99.885
G1 X121.767 Y99.655
G1 X120.71 Y89.587
G1 X120.759 Y88.151
G1 X120.812 Y86.599
G1 X121.199 Y85.151
G1 X120.85 Y85.5
G1 E5 F2400
;TYPE:External perimeter
;WIDTH:0.399999
G1 F6000
G1 X120.85 Y85.247 E.00615
G1 X120.783 Y85.106 E.0038
G1 X120.667 Y85.064 E.003
G1 X110.333 Y85.064 E.25136
G1 X110.257 Y85.081 E.00189
G1 X110.15 Y85.247 E.0048
G1 X110.15 Y85.5 E.00615
G1 X104.557 Y85.5 E.13604
G1 X103.991 Y85.458 E.01381
G1 X103.445 Y85.335 E.01361
G1 X103.051 Y85.176 E.01033
G1 X102.41 Y84.839 E.01762
G1 X101.862 Y84.381 E.01737
G1 X101.416 Y83.846 E.01694
G1 X101.042 Y83.156 E.01909
G1 X100.881 Y82.609 E.01387
G1 X100.761 Y81.98 E.01558
G1 X100.75 Y78.995 E.07261
G1 X100.688 Y78.859 E.00364
G1 X99.82 Y78.098 E.02808
G1 X99.467 Y77.724 E.01251
G1 X99.317 Y77.508 E.0064
G1 X99.459 Y77.258 E.00699
G1 X99.964 Y76.771 E.01706
G1 X100.575 Y76.238 E.01972
G1 X130.425 Y76.238 E.72607
G1 X131.036 Y76.771 E.01972
G1 X131.537 Y77.254 E.01693
G1 X131.678 Y77.505 E.007
G1 X131.55 Y77.712 E.00592
G1 X131.183 Y78.096 E.01292
G1 X130.312 Y78.859 E.02817
G1 X130.25 Y78.995 E.00364
G1 X130.24 Y81.703 E.06587
G1 X130.197 Y82.261 E.01361
G1 X130.072 Y82.81 E.0137
G1 X129.861 Y83.348 E.01406
G1 X129.574 Y83.844 E.01394
G1 X129.226 Y84.278 E.01353
G1 X128.792 Y84.678 E.01436
G1 X128.315 Y85.001 E.01401
G1 X127.824 Y85.243 E.01331
G1 X127.285 Y85.407 E.0137
G1 X126.73 Y85.489 E.01365
G1 X120.91 Y85.5 E.14157
G1 X120.91 Y85.5 F9000
G1 X121.19 Y85.133
;TYPE:Perimeter
G1 F6000
G1 X121.162 Y85.133 E.00068
G1 X121.014 Y84.823 E.00836
G1 X120.894 Y84.748 E.00344
G1 X120.667 Y84.699 E.00565
G1 X110.333 Y84.699 E.25136
G1 X110.254 Y84.705 E.00193
G1 X109.985 Y84.823 E.00715
G1 X109.838 Y85.134 E.00837
G1 X104.571 Y85.134 E.12811
G1 X104.045 Y85.095 E.01283
G1 X103.554 Y84.985 E.01224
G1 X103.188 Y84.837 E.0096
G1 X102.622 Y84.539 E.01556
G1 X102.122 Y84.122 E.01584
G1 X101.72 Y83.64 E.01527
G1 X101.382 Y83.016 E.01726
G1 X101.231 Y82.505 E.01296
G1 X101.127 Y81.955 E.01362
G1 X101.116 Y78.994 E.07202
G1 X101.079 Y78.799 E.00483
G1 X100.929 Y78.584 E.00638
G1 X100.222 Y77.964 E.02287
G1 X99.747 Y77.488 E.01636
G1 X100.211 Y77.041 E.01567
G1 X100.712 Y76.604 E.01617
G1 X130.288 Y76.604 E.71941
G1 X130.8 Y77.052 E.01655
G1 X131.257 Y77.494 E.01546
G1 X130.935 Y77.827 E.01127
G1 X130.071 Y78.584 E.02794
G1 X129.921 Y78.799 E.00638
G1 X129.884 Y78.994 E.00483
G1 X129.873 Y81.951 E.07193
G1 X129.797 Y82.459 E.01249
G1 X129.646 Y82.953 E.01256
G1 X129.42 Y83.42 E.01262
G1 X129.13 Y83.845 E.01252
G1 X128.785 Y84.216 E.01232
G1 X128.184 Y84.653 E.01807
G1 X127.695 Y84.899 E.01331
G1 X127.204 Y85.049 E.01249
G1 X126.703 Y85.124 E.01232
G1 X121.25 Y85.133 E.13264
G1 X121.25 Y85.133 F9000
G1 X121.293 Y84.639
G1 F6000
G1 X121.246 Y84.539 E.00269
G1 X121.046 Y84.415 E.00572
G1 X120.667 Y84.333 E.00943
G1 X110.333 Y84.333 E.25136
G1 X110.073 Y84.371 E.00639
G1 X109.753 Y84.54 E.0088
G1 X109.645 Y84.769 E.00616
G1 X105.388 Y84.769 E.10355
G1 X104.466 Y84.76 E.02243
G1 X103.891 Y84.686 E.0141
G1 X103.325 Y84.498 E.01451
G1 X102.833 Y84.239 E.01352
G1 X102.381 Y83.862 E.01432
G1 X102.024 Y83.433 E.01358
G1 X101.722 Y82.875 E.01543
G1 X101.618 Y82.524 E.0089
G1 X101.492 Y81.929 E.01479
G1 X101.481 Y78.993 E.07142
G1 X101.42 Y78.667 E.00807
G1 X101.17 Y78.309 E.01062
G1 X100.261 Y77.5 E.0296
G1 X100.849 Y76.97 E.01926
G1 X130.151 Y76.97 E.71274
G1 X130.742 Y77.504 E.01937
G1 X129.83 Y78.309 E.02959
G1 X129.58 Y78.667 E.01062
G1 X129.519 Y78.993 E.00807
G1 X129.509 Y81.7 E.06585
G1 X129.44 Y82.378 E.01658
G1 X129.203 Y83.029 E.01685
G1 X128.843 Y83.616 E.01675
G1 X128.337 Y84.106 E.01713
G1 X127.828 Y84.439 E.0148
G1 X127.34 Y84.625 E.0127
G1 X126.675 Y84.758 E.0165
G1 X121.354 Y84.767 E.12943
G1 X121.319 Y84.693 E.00199
G1 X121.319 Y84.693 F9000
G1 X121.536 Y84.382
G1 F6000
G1 X121.477 Y84.256 E.00338
G1 X121.197 Y84.082 E.00802
G1 X120.941 Y83.997 E.00656
G1 X120.667 Y83.967 E.0067
G1 X110.333 Y83.967 E.25136
G1 X109.969 Y84.02 E.00895
G1 X109.521 Y84.258 E.01234
G1 X109.453 Y84.403 E.0039
G1 X104.703 Y84.403 E.11554
G1 X104.153 Y84.37 E.0134
G1 X103.557 Y84.197 E.0151
G1 X103.045 Y83.939 E.01395
G1 X102.641 Y83.602 E.0128
G1 X102.328 Y83.227 E.01188
G1 X102.061 Y82.735 E.01362
G1 X101.969 Y82.421 E.00796
G1 X101.858 Y81.904 E.01286
G1 X101.847 Y78.991 E.07086
G1 X101.761 Y78.536 E.01126
G1 X101.411 Y78.034 E.01489
G1 X100.8 Y77.498 E.01977
G1 X100.986 Y77.335 E.00602
G1 X130.014 Y77.335 E.70608
G1 X130.2 Y77.498 E.00602
G1 X129.589 Y78.034 E.01977
G1 X129.239 Y78.536 E.01489
G1 X129.153 Y78.991 E.01126
G1 X129.143 Y81.699 E.06587
G1 X129.082 Y82.296 E.0146
G1 X128.874 Y82.87 E.01485
G1 X128.557 Y83.387 E.01475
G1 X128.109 Y83.82 E.01516
G1 X127.659 Y84.114 E.01307
G1 X127.234 Y84.276 E.01106
G1 X126.648 Y84.392 E.01453
G1 X121.584 Y84.401 E.12318
G1 X121.584 Y84.401 F9000
G1 X121.811 Y84.035
G1 F6000
G1 X121.738 Y84.035 E.00178
G1 X121.709 Y83.973 E.00166
G1 X121.349 Y83.749 E.01031
G1 X121.02 Y83.64 E.00843
G1 X120.667 Y83.602 E.00864
G1 X110.333 Y83.602 E.25136
G1 X110.095 Y83.619 E.0058
G1 X109.649 Y83.751 E.01131
G1 X109.29 Y83.975 E.01029
G1 X109.26 Y84.037 E.00168
G1 X104.611 Y84.037 E.11308
G1 X104.052 Y83.972 E.01369
G1 X103.482 Y83.773 E.01469
G1 X103.054 Y83.471 E.01274
G1 X102.632 Y83.021 E.01501
G1 X102.401 Y82.595 E.01179
G1 X102.223 Y81.878 E.01797
G1 X102.213 Y78.99 E.07025
G1 X102.103 Y78.404 E.0145
G1 X101.586 Y77.701 E.02123
G1 X129.414 Y77.701 E.67689
G1 X129.348 Y77.759 E.00214
G1 X128.897 Y78.404 E.01914
G1 X128.787 Y78.99 E.0145
G1 X128.78 Y80.876 E.04588
G1 X128.75 Y82.044 E.02842
G1 X128.622 Y82.551 E.01272
G1 X128.366 Y83.018 E.01295
G1 X128.037 Y83.409 E.01243
G1 X127.572 Y83.741 E.0139
G1 X127.127 Y83.926 E.01172
G1 X126.621 Y84.027 E.01255
G1 X121.871 Y84.035 E.11554
G1 E-5 F3600
G1 X121.871 Y84.035 F9000
G1 X128.886 Y78.239
G1 E5 F2400
;WIDTH:0.4
G1 F3072.127
G1 X128.622 Y77.975 E.00908
G1 X128.102 Y77.975 E.01265
G1 X128.607 Y78.481 E.01739
G1 X128.525 Y78.919 E.01084
G1 X127.581 Y77.975 E.03247
G1 X127.061 Y77.975 E.01265
G1 X128.512 Y79.426 E.04991
G1 X128.51 Y79.944 E.0126
G1 X126.541 Y77.975 E.06773
G1 X126.02 Y77.975 E.01267
G1 X128.508 Y80.463 E.08559
G1 X128.506 Y80.981 E.0126
G1 X125.5 Y77.975 E.1034
G1 X124.98 Y77.975 E.01265
G1 X128.504 Y81.5 E.12124
G1 X128.48 Y81.996 E.01208
G1 X124.459 Y77.975 E.13832
G1 X123.939 Y77.975 E.01265
G1 X128.377 Y82.413 E.15266
G1 X128.208 Y82.764 E.00948
G1 X123.419 Y77.975 E.16474
G1 X122.898 Y77.975 E.01267
G1 X127.985 Y83.062 E.17499
G1 X127.717 Y83.314 E.00895
G1 X122.378 Y77.975 E.18366
G1 X121.858 Y77.975 E.01265
G1 X127.404 Y83.522 E.1908
G1 X127.031 Y83.668 E.00974
G1 X121.337 Y77.975 E.19585
G1 X120.817 Y77.975 E.01265
G1 X126.594 Y83.752 E.19873
G1 X126.075 Y83.753 E.01262
G1 X120.297 Y77.975 E.19876
G1 X119.776 Y77.975 E.01267
G1 X125.555 Y83.754 E.19879
G1 X125.036 Y83.755 E.01262
G1 X119.256 Y77.975 E.19883
G1 X118.736 Y77.975 E.01265
G1 X124.517 Y83.756 E.19886
G1 X123.997 Y83.757 E.01265
G1 X118.215 Y77.975 E.1989
G1 X117.695 Y77.975 E.01265
G1 X123.478 Y83.758 E.19893
G1 X122.958 Y83.759 E.01265
G1 X117.175 Y77.975 E.19895
G1 X116.655 Y77.975 E.01265
G1 X122.439 Y83.76 E.19898
G1 X121.92 Y83.761 E.01262
G1 X116.134 Y77.975 E.19903
G1 X115.614 Y77.975 E.01265
G1 X121.002 Y83.363 E.18534
G1 X120.446 Y83.328 E.01355
G1 X115.094 Y77.975 E.18412
G1 X114.573 Y77.975 E.01267
G1 X119.925 Y83.328 E.18412
G1 X119.405 Y83.328 E.01265
G1 X114.053 Y77.975 E.18412
G1 X113.533 Y77.975 E.01265
G1 X118.885 Y83.328 E.18412
G1 X118.365 Y83.328 E.01265
G1 X113.012 Y77.975 E.18414
G1 X112.492 Y77.975 E.01265
G1 X117.844 Y83.328 E.18412
G1 X117.324 Y83.328 E.01265
G1 X111.972 Y77.975 E.18412
G1 X111.451 Y77.975 E.01267
G1 X116.804 Y83.328 E.18414
G1 X116.283 Y83.328 E.01267
G1 X110.931 Y77.975 E.18412
G1 X110.411 Y77.975 E.01265
G1 X115.763 Y83.328 E.18412
G1 X115.243 Y83.328 E.01265
G1 X109.89 Y77.975 E.18414
G1 X109.37 Y77.975 E.01265
G1 X114.722 Y83.328 E.18412
G1 X114.202 Y83.328 E.01265
G1 X108.85 Y77.975 E.18412
G1 X108.329 Y77.975 E.01267
G1 X113.682 Y83.328 E.18414
G1 X113.161 Y83.328 E.01267
G1 X107.809 Y77.975 E.18412
G1 X107.289 Y77.975 E.01265
G1 X112.641 Y83.328 E.18412
G1 X112.121 Y83.328 E.01265
G1 X106.768 Y77.975 E.18414
G1 X106.248 Y77.975 E.01265
G1 X111.6 Y83.328 E.18412
G1 X111.08 Y83.328 E.01265
G1 X105.728 Y77.975 E.18412
G1 X105.208 Y77.975 E.01265
G1 X110.56 Y83.328 E.18412
G1 X110.059 Y83.347 E.0122
G1 X104.687 Y77.975 E.18479
G1 X104.167 Y77.975 E.01265
G1 X109.65 Y83.458 E.18861
G1 X109.316 Y83.645 E.00931
G1 X103.647 Y77.975 E.19503
G1 X103.126 Y77.975 E.01267
G1 X108.914 Y83.763 E.1991
G1 X108.394 Y83.763 E.01265
G1 X102.606 Y77.975 E.1991
G1 X102.131 Y77.975 E.01155
G1 X107.873 Y83.763 E.19831
G1 X107.353 Y83.763 E.01265
G1 X102.467 Y78.877 E.16808
G1 X102.488 Y79.419 E.01319
G1 X106.833 Y83.763 E.14945
G1 X106.312 Y83.763 E.01267
G1 X102.49 Y79.941 E.13147
G1 X102.492 Y80.463 E.0127
G1 X105.792 Y83.763 E.11352
G1 X105.272 Y83.763 E.01265
G1 X102.494 Y80.986 E.09554
G1 X102.496 Y81.508 E.0127
G1 X104.751 Y83.763 E.07757
G1 X104.191 Y83.723 E.01366
G1 X102.53 Y82.062 E.05714
G1 X102.656 Y82.49 E.01085
G1 X102.86 Y82.866 E.01041
G1 X103.684 Y83.736 E.02915
G1 E-3.5 F3600
;WIPE_START
G1 F7200
G1 X102.86 Y82.866 E-.56918
G1 X102.656 Y82.49 E-.20319
G1 X102.53 Y82.062 E-.21193
G1 X103.298 Y82.83 E-.5157
;WIPE_END
G1 X104 Y85.106 F9000
G1 X104.46 Y86.599
G1 X105.067 Y88.151
G1 X105.067 Y88.567
G1 E5 F2400
;WIDTH:0.399999
G1 F6000
G1 X105.151 Y88.503 E.00257
G1 X125.817 Y88.5 E.50268
G1 X125.96 Y88.569 E.00386
G1 X126 Y88.683 E.00294
G1 X126 Y89.005 E.00783
G1 X126.559 Y89.494 E.01807
G1 X127.196 Y90.148 E.02221
G1 X1
