jam in nozzle when getting to print details (Prusament PETG)
Please see picture (lower right corner)- the print of the detail (6mm pipe 10mm long with 2.5mm hole) results in a jam in the nozzle and the Prusament PETG grinds in the extruder gear. When unloading and loading filament all is ok until that Detail.I printed a small piece, it works (see left side). I suspect this is a temperature cooling stetting that I do not get... any help would be very welcome!I also printed yesterday the Extruder MK3S to MK3S+ upgrade (6h20m PETG), 1st attempt no issue marvelous print (so this issue is with the MK3S and MK3S+ extruder assembly).
thanks - peter
Publié : 10/04/2022 3:26 pm
RE: jam in nozzle when getting to print details (Prusament PETG)
Is the print curling up off the build plate on the corner? I could only think that it is curling up into the nozzle leaving no room to extrude.
Publié : 12/04/2022 9:28 pm
