Issues printing vase mode
suicidesushi
(@suicidesushi)
Hello,
I'm having difficulties when I'm trying to print this vase: https://www.thingiverse.com/thing:126567 on a Mk3s+.
I've printed with 0,4 nozzle in vase mode and extrusion width ~0,8 mm, but when I try to remove the vase the base layer or first layer gets separated from the vase. If I try to have less extrusion width the vase gets gaps.
What am I doing wrong? Please help.
Opublikowany : 04/11/2021 6:40 pm
The fact your layers are separating/de-laminating, even on the base would suggest you are printing too cold for the filament.  That looks like a silk filament, is it a silk pla?  Those 'normally' need 10-15 degrees more to print properly.
Opublikowany : 04/11/2021 9:01 pm
Swiss_Cheese
(@swiss_cheese)
@suicidesushi
You mentioned your printing with an extrusion width of 0.8, what (layer height) are you printing at ?
Regards
Swiss_Cheese
The Filament Whisperer
Opublikowany : 05/11/2021 3:34 pm
