Issue with first layer on support material.
Demado
(@demado)
Hi All,
I am trying to print a part with large overhands. I have used support material but am getting a poor surface finish on the first layer building on the support material. If you can offer any help i would appreciate it.
Regards
Dave
Publié : 10/11/2019 8:31 am
Ed
 Ed
(@ed-4)
RE: Issue with first layer on support material.
I've had *some* success with the following:
  • smaller layers seem to be easier to peel, leaving fewer scars from the support removal process itself
  • smaller layers will also have less stair-stepping, so hopefully that will mask some of the issue as well
  • dense interface layers are essential.  I've been using 5 solid layers for dense interface
  • make the air gap as small as possible that you can still peel.
  • for whatever reason, I get better quality out of Simplify3D for big overhangs than any other slicer (except for my Cetus.  The Cetus + Up Studio slicer is a support material wizard somehow)
All that being said, this kind of extreme example will probably have some bad-looking overhangs, it sorta comes with the territory.  A little high-fill primer and some sandpaper can hide a lot of sins...
Publié : 10/11/2019 11:16 pm
If the carnage in the photo is the bottom, it looks like the support density is lacking.  You might try variable layer heights to fill those layers to improve printer capability; and then work the separation between interface layers and part layers.  Lower separation is a mixed bag, sometimes makes it better, sometimes cause increased welding. Ensuring perimeter bridge detection is enabled and being enforced may also help.
Publié : 12/11/2019 6:50 am
