Is there a setting to increase the bridging anchor area?
Jan-E.de
(@jan-e-de)
I am trying to bridge a sheet of cut-out letters. Fortunately I found the bridging angle setting to prevent the letters from being bridged along the long edge. 😉
This is how far I got:
Now, there is the infill and the anchoring region of the bridging. Change of structure of the two areas leads to tiny "bumps" on the layer. I would like to increase the area of the bridge anchoring to merge all bridging into one single area. So basicly one big bridge area across all the letters.
Is there a setting for the "anchoring overlap"? Or how could I achieve a straigt bridge area? Can I "define" the whole layer as a bridge? That could also do the trick.
For this project a really smooth surface is needed. The letters are cut out of coloured PLA which is roughly 1 mm high and I would like to bridge it with transparent PLA to keep the "loose bits" of the letters (e.g. insides of "O", "B" etc.) connected to the whole sheet.
Thank you very much!
Jan
Veröffentlicht : 17/05/2020 6:15 pm
