Inner print layer effecting outer wall
Chris C
(@chris-c)
I am make a coaster however the inner layer is showing a line/bulge on the exterior wall where the rim is being printed.  Not sure why this is happen other than the where the inner layer changes to solid it is pushing out the outer wall.
Napsal : 13/01/2022 1:49 pm
RE: Inner print layer effecting outer wall
Loads and loads of threads on this here.  Nicely summarised links part way down this one https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/not-exactly-layer-shifting-issues-misalignment/   found on page 2 of this very forum.
Originally mis-spelled as buldge which can make search easier.  There are things you can try to mitigate that work in some cases but no overall solution.  It varies on model geometry.
Napsal : 13/01/2022 2:07 pm
Chris C
(@chris-c)
Thank you and I will check it out.  And report back if any of the suggestions work.  Thank you.
Napsal : 13/01/2022 10:26 pm
