Infill shifted
I try to print his battery holder but the infill is shifted to the left. On the right hand you can see that it is even not a static shift, but the gap increases.
Any idea what is wrong?
Material: Prusa PLA, printer MK3S, latest firmware.
Thanks for hints!
Posted : 26/02/2021 7:45 pm
RE: Infill shifted
The holes are shifted as well. The first layer shows shifting as well all across the surface. Think about whether your belt for X motion is tight enough, and check the grub screws on the motor pulley for being tightened in the proper order.
Posted : 26/02/2021 9:58 pm
Topic starter
answered:
RE: Infill shifted
Thanks a lot. I have tighten the belts and now everything is perfect!
Posted : 27/02/2021 8:08 pm
