Infill and warping
greatprints
(@greatprints)
Infill and warping
Hello,
Does anyone know about the effects of different types of infill and different amounts of infill on warping (specifically of large, flat prints)?
Thanks.
Opublikowany : 02/08/2022 7:47 pm
RE: Infill and warping
lots of infill is likely to induce warping.
I believe,100% infill is only available in rectilinear infill
If I want a solid model, I use lots of top and bottom layers instead of infill, top and bottom layers seem to give less problems than rectilinear, at 100%
Opublikowany : 02/08/2022 7:59 pm
Swiss_Cheese
(@swiss_cheese)
@chess3d
I know that there are a lot of people here that Know a great deal about the questions you keep asking, and you might find that you get a better response and learn more from those folks if you stick around after asking a question, and  strike up a dialog, rather then just posting thread after thread and not responding to folks after they respond to you.
Good luck buddy
The Filament Whisperer
Opublikowany : 03/08/2022 3:11 am
