How to print this very small piece
FerTech
(@fertech)
Hi guys, I am quite new to 3D printing, found a piece which is an adapter of a butane canister to refill some kitchen lighter with gas. You can find the model here.
But when I printed it although I choose 0.05 Ultra detail, PLA and 100% infill on the Prusa Slicer profile, the quality of the thinner part is really bad.
Any tips of how to print this? If I try to slice on Vase mode it seems some parts are not going to be printed at all.
Thank you!
Best Answer by Diem:
No point in printing that so fine.
Try 0.2mm layers, 30% fill and 6 perimeters.  It's probably best to print at least two copies on the bed at once to aid cooling.
If it needs more strength raise the print temperature 5 degrees but you might be better using PETG for toughness.
Postato : 03/07/2023 9:27 pm
Postato : 03/07/2023 10:07 pm
RE: How to print this very small piece
Too small for the filament to cool down properly. So either adjust minimum layer time in Prusaslicer and/or do what diem suggested, print multiple copies at the same time. I'd probably print a dozen, because why not.
Also, anything less than 0.1 mm layer height is not going to give you any more detail with a 0.4 mm nozzle and is certainly not required for this model.
Postato : 04/07/2023 7:30 am
FerTech
(@fertech)
Thanks a lot!
Postato : 04/07/2023 7:44 am
For something with as little footprint as this it may also be advisable to add a brim. But is easy and quick enough to test without it first.
Postato : 04/07/2023 7:46 am
FerTech
(@fertech)
Hi there, yup, I usually add a brim on these small prints because otherwise the item might get too unstable 😉 thanks!
Postato : 04/07/2023 8:45 am
Thejiral
(@thejiral)
An easy solution for issues with such tiny parts is to print multiple copies at once, also print it slow with high part cooling.
Postato : 04/07/2023 12:09 pm
