How to print this MMU2S print pls
RadimR
(@radimr)
Guys, I have a bunch of single-color prints successfully completed, but as of last week I have the MMU2S installed and need some help with the following print: https://www.thingiverse.com/thing:2299727
Originally, i thought i had to print each STL separately in its respective color. I even now have the #1 printed in blue. But quite obviously #2-4 won't print (or even slice) now, as they hang in the air.
Then I thought I had to import all four STLs at the same time and slice them togetether. But they don't seem "fit" properly into one another when imported at the same time, and I somehow doubt I can successfully position them manually in prusaslicer.
So what is the magic here please?
Veröffentlicht : 11/03/2020 5:32 pm
Lichtjaeger
(@lichtjaeger)
RE: How to print this MMU2S print pls
First chose the right printer. The "MK3S MMU2S" without "Single". You should see the purge block. Then it works as you thought.
Veröffentlicht : 11/03/2020 5:54 pm
K7ZPJ
(@k7zpj)
Posted by: @radim-r
Section 9 of the MMU2S printer handbook goes over the process for printing multi-colors.
https://cdn.prusa3d.com/downloads/manual/prusa3d_manual_mmu2s_en_1_1.pdf#_ga=2.231386006.824106673.1583887071-679196829.1572537160
Veröffentlicht : 11/03/2020 5:57 pm
RadimR
(@radimr)
@lichtjaeger
Excellent, thank you very much!! I didn't realize that importing while the wrong (single) profile is active would result in something different than when the multi profile is active.
Veröffentlicht : 11/03/2020 6:07 pm
