How to print small PLA patterns on glass?
Hello,
I would like to 3D print some small PLA patterns (each looks like 0.5 mm x 0.5 mm x ~25 mm) on the surface of 1" round, 1 mm thick fused silica substrate (see model attached below)? I have multiple Prusa 3D printers. One I use often is Original Prusa i3 MK3. How can I do this? How should I hold the fused silica substrate on the magnetic printbed? How do I set the printer? Thanks.
Posted : 11/12/2024 5:33 pm
