How do I set an auto pause during print to change filament
Jake
 Jake
(@jake-6)
Hi I need to be able to slice a model in which the gcode pauses the printer at a specific layer height so that I can swap out filaments. If anyone can guide me that would be great. Thanks!
Publié : 16/06/2019 4:56 pm
RE: How do I set an auto pause during print to change filament
Use custom gcode and insert a pause at the correct layer_num ...
{if layer_num == XX}G4 Z{endif} ; At layer XX, pause
Publié : 16/06/2019 6:38 pm
Jake
 Jake
(@jake-6)
so at the xx parts would i replace that with the layer height? and if it is a single digit would i type 07 for instance?
Publié : 21/06/2019 2:24 am
Jake
 Jake
(@jake-6)
and how do i edit it . where do i insert it?
Publié : 21/06/2019 2:33 am
Peter M
(@peter-m)
In latest prusaslicer you can do it.
Search for the movie that explains the new slicer, it explanes the color change.
Publié : 21/06/2019 3:47 am
RH_Dreambox
(@rh_dreambox)
If you are going to change the filament or change color at a certain level, it is preferable to use the Color change function found in the latest version of PrusaSlicer.
Attachment removed
Publié : 21/06/2019 2:50 pm
