Horrible print quality within a layer range
RussG
(@russg)
I'm including 2 photos of a little dish I am printing. It looks like there is a range of layer heights at which the printer is messing up the print. It's worse on one side than the other. I haven't a clue why this would be and not sure what info to provide that might help people more knowledgeable than I fix the problem.
I can say that the side of the dish is at a 45º angle without supports for the walls (there were supports elsewhere, where the protrusions stick out). The wall is the same angle except for a 6mm section at the top (left in photo) that is perpendicular, Prusament PETG, nozzle ~240.
Any thoughts about the cause and solution to the problem would be appreciated.
Respondido : 01/01/2026 12:48 am
mnentwig
(@mnentwig)
RE: Horrible print quality within a layer range
The first thought is "cooling" but that may be just the first item on a list of issues. I'd go back to square one and check with a benchie that the printer works as intended. You could look at the layer-dependent fan controls whether anything correlates with the height. And, drying filament is never a bad idea.
For comparison, two Muesli bowls from my own collection (the yellow one is not postprocessed, the red/black one did see some grinding paper). It's on Core One, ASA and slightly steeper but that should matter only in details.
Respondido : 01/01/2026 1:44 am
1 les gusta
Make sure the print fan is clean and turning freely, check the fan shroud is correctly aligned and undamaged.
If problems persist save your project as a .3mf file
Files > Save Project as
Respondido : 01/01/2026 11:46 am
1 les gusta
RussG
(@russg)
@mnentwig @Diem
Taking my cue from your suggestions that this may be a cooling issue, and doing some additional research based on that thesis, it seems the print fan air flow of the i3MK3S+ may not be up to the task for some print jobs where the print fan airflow for certain parts of the model isn't sufficient. I think I recall reading that this is more likely to happen at the back of the model, exactly where the problem existed for me, because the airflow is coming from the front; possibly other factors such as parts of the model blocking print fan air flow. I'm sure you already knew about this.
Based on thesis I downloaded, printed and installed the Delta-P v2.2 fan duct from Printables.com. I have not as yet done any testing with it but hope it will help.
Most of my prints have been fine so I think it less likely there has been any issue with the fan or OEM shroud.
Examining the GCode seemed like a daunting task and I don't really have the expertise to know exactly what to look for.
If I can add anything to this thread at a later date I will do so. Meanwhile, thanks to all who have read and/or posted in reply to my query for your time and assistance.
Esta publicación ha sido modificada el hace 4 months por RussG
Respondido : 03/01/2026 7:59 pm
Fan blades can gather enough dust to reduce efficiency surprisingly quickly if the air is dry enough for static build-up.  Make a check and possible clean part of your regular monthly maintenance.
Respondido : 03/01/2026 11:54 pm
1 les gusta
