Help with planter print - weird ridge
gvajcner
(@gvajcner)
Mitglied
I’m wondering if someone could help me debug this print of a geometric planter. I made the above model in fusion 360. Everything looks right in the model, but when I print it, I get a ridge near the bottom of the outside. It seems to be happening at the level of the bottom of the hole on the inside. It’s like the solid base prints a diameter a few mm smaller than the rest of the body.
any thoughts?
I’m pretty new to all of this, using stock settings on my mk3s+, prusa slicer. 15% infill, 15mm layer height with default pla heat settings and speeds. It’s eSun eMarble PLA, but I’ve had the same result with prusa Pla. I’ve also tried with and without supports - same result. The supports stop at the level of the ridge, interestingly enough.
Thanks in advance
-glen
Veröffentlicht : 19/06/2023 2:55 pm
RE: Help with planter print - weird ridge
Do a search for "buldge".  Yes I know its not spelt correctly.  Masses of info on a well known problem.  With unfortunately no single solution.
Veröffentlicht : 19/06/2023 5:00 pm
gvajcner
(@gvajcner)
Mitglied
Thanks Neophyl - so many possibilities of where it went wrong. Time to debug. Thanks for your help
Veröffentlicht : 20/06/2023 12:23 pm
