Help printing Prusament PLA Blend
I've been trying to print a Benchy for my Benchy collection, but i cannot figure this filament out.
I've tried temperatures ranging from 190 to 225 and i can barely even tell them apart, because the overhangs look crappy on all of them.
Does anyone have print settings for this type of filament?
225°:
215°:
205°:
190°:
215° 0.1mm 50% Speed:
Galaxy Silver 215°:
Temp Tower:
RE: Help printing Prusament PLA Blend
The Benchy bow is intended to highlight cooling issues. Be sure you part cooling fan is aligned to blow cooling air on the print properly. Possibly reduce temps a bit, at least to test the bow. Some filaments just won't print good overhangs. Silk filaments can be tricky.
The Galaxy Silver one prints just fine.
So i think my cooling should be enough?
I did change the cooling shroud with the delta-p one:
https://www.prusaprinters.org/prints/62523-delta-p-fan-duct-v2-r2-for-mk3s-extruder
I did not think of testing the old shroud, so i dont actually know of this one is better. I trusted the comments saying that it is good.
I will try installing the default one again and see if it makes a difference.
The Delta-P fan duct is hot garbage.
The default fan shroud fixed it.
Now i only have a small corner on the backside that does not look nice, bit it is only minor.
