Help printing lithophanes on Slic3r PE
MikeOKC
(@mikeokc)
I am trying to print a lithophane on Slic3r PE and when I slice the STL, I get "no layers were detected, you might want to repair your file or check size/thickness" message.
I am using the 0.1mm DETAIL MK3 print setting and the thinnest part of the file is 0.8 mm. I have tried multiple files and tried repairing them on Slic3r and Meshmixer but, nothing helps...
Any and all advice welcome and thank you.
Publié : 12/05/2018 3:29 am
MikeOKC
(@mikeokc)
Re: Help printing lithophanes on Slic3r PE
One more thing, I can take the same files and slice them on Simplify3D and they slice correctly...
Publié : 12/05/2018 3:33 am
Dylan Miller
(@dylan-miller)
Just run the STL through any STL repairer. Quick google search should pop up several of them.
Publié : 14/05/2018 9:42 pm
Vojtěch Bubník
(@vojtech-bubnik)
Membre Admin
Slic3r 1.40.0-alpha1 should be able to handle these inconsistent STLs much better. Please note this is an alpha release, so use with caution.
https://github.com/prusa3d/Slic3r/releases/tag/untagged-8fc8ca127d0924fe5504
Publié : 15/05/2018 7:38 am
