Help needed for Prusaslicer Settings...
I want to print a sorta compliant spring mechanism with the most delicate wall thickness possible, so I chose a thickness of 0,4mm..:
from above, sliced it looks like this (its supposed to be made in PA):
though, from here I run into problems!
Which settings will I have to choose -- or, what to do, if I wanna have a continuous extrution of filament around each loop of hole?
thanks a million!
RE: Help needed for Prusaslicer Settings...
I changed the minimum wall thickness to 0,5mm now..:
but I still get unwanted "interconnections" - which I rather choose to change some shift somewhere away from the most critical region of the spring.
Any suggestions?
thx
By the look of it your wall thickness in some of the curves fell below a single extrusion width. Where parallel curves are laid out with cartesian spacing the distances can vary in hard-to-calculate ways. If you want a single extrusion then your best chance is to set the cartesian spacing at just under two extrusion widths, say, 0.8mmn and disable arachne.
