Help! First design and trying to print but failing after first layer...
Travis Edson
(@travis-edson)
Hey guys/gals,
Everytime I try to print a file I created, it ends up gooping on the second layer and I can't even proceed before things turn to shit. Not quite sure why and I would love the knowledge of this group.
Also, how do I upload the STL I created for you to check it out?
Please help me out, try to learn here...
With thanks...
-Travis
Questa discussione è stata modificata 6 years fa 2 tempo da Travis Edson
Postato : 16/11/2019 6:04 am
RE: Help! First design and trying to print but failing after first layer...
Zip the file before uploading. A project (3MF) with your part and setting would be most helpful.
Postato : 16/11/2019 5:11 pm
Travis Edson
(@travis-edson)
Holder 11:16.3mf
Postato : 16/11/2019 5:40 pm
Travis Edson
(@travis-edson)
Thank you so much for your help!
Postato : 16/11/2019 5:41 pm
You are printing a model that requires lots of support on that gradually sloping bottom with no support enabled.  It will print the first layer fine but the layers above are printing in thin air.
When you slice the model its good practice to step through the slice layer by layer looking at the model once its finished and all the areas are colour coded.  Bridges, overhangs etc are coloured differently so you can easily spot them.
You could enable auto support from the build plate but that gradual curve on the bottom isn't going to print well even with support.  Personally I would adjust your original model to put a bevel on the bottom instead of a chamfer.
Postato : 16/11/2019 6:25 pm
1 persone hanno apprezzato
My computer is telling me the 3MF is corrupt ...
Postato : 17/11/2019 12:38 am
Travis Edson
(@travis-edson)
@tim-m30
Oh weird, let me double check on the file. I just unzipped it again and it worked for me...hmmmm
Postato : 17/11/2019 1:15 am
Travis Edson
(@travis-edson)
@neophyl
Thank you so much!
Postato : 17/11/2019 1:16 am
The colon in the filename is the issue for us Win7 users.
Postato : 17/11/2019 1:41 am
As Neo said, the part design is unprintable without supports.
By turning on Detect Bridging Perimeters, it becomes clear why it fails. The layer 2 perimeters are printing midair.
Postato : 17/11/2019 1:44 am
Travis Edson
(@travis-edson)
@tim-m30
Amazing! I really appreciate you all!
Postato : 17/11/2019 1:47 am
