Heat creep and stuck filament in PTFE tube
The linked model seems to be unprintable for me. I think it can be related to heat creeping up the filament and into the PTFE tube as the print means a very small amount of filament is used and it is extruded and retracted all the time.
Using PrusaSlicer 2.2.0 with default settings and original roll of Prusa filament that came with the printer.
Should I look for other issues on the printer?
(G-code: https://1drv.ms/u/s!Ap8H-OUKkFTthzFDMEkbvP47qblh?e=xwwAEX )
Napsal : 09/04/2020 1:44 pm
