Having cyclic underextrusion. Suspect bontech gear malfunction
RedDawg
(@reddawg)
This is an unmodified or upgraded MK3 machine. After years of printing without issues, I am now having a weird, cyclic underextrusion problem that I suspect may be related to some malfunction with the bontech gears. As the first layer is being laid down, it exhibits a "banding" pattern, alternating between what appears to be a normal thickness band, followed by an underextruded or thinner band, then this repeats. Each of the two bands appears to be approximately the same width and can be readily felt by sliding a finger over them. As the first layer continues and each trace gets longer and longer (part geometry dependent), the bands get progressively narrower and narrower, seemingly in sync with how much filament is extruded during one revolution of the bontech gears. Oddly, the bands have sharp edges, as if, at some point during the gears' revolution, they meet a step-function friction component increase that continues for half a revolution, and then, just as suddenly, returns to its normal, value, whereupon the layer returns to its proper thickness. This same behavior happens with all  filaments.
When I removed the pressure door, it appeared that the axel of the non-driven (idler) gear had possibly worn an "egg" shaped hole in the pressure door. I did not think this to be unusual, given the number of hours of printing on the machine. What did seem odd is that this problem was not present one day and appeared all at once the next time I used the machine. I cleaned the compartment to make sure there was no filament residue inside or on the gear teeth. The gears themselves do not appear to be worn or damaged. I printed a new pressure door and reinstalled the idler gear which did not exhibit any "slop" in the axel hole. The banding/underextrusion problem continues. The attached photos shows the print after the first full layer. Note that when the nozzle gets to the central hole, shortening the line length until it restarts "full" width lines on the "other side", then the band lines get wider, corresponding with a lesser rotation of the gears. Once the hole is passed and the "long" lines resume, the bands get narrower again. (Pictures attached out-of-order, sorry.)
The next picture shows the result of the second layer in the reverse direction: short excursions at layer start - wide bands. Long excursions at layer end - narrow bands. When the bottom layers are complete and the infill starts (honeycomb), the "cells" of the infill are poorly formed and do not reinforce each other. After several layers of infill, I stopped the print. The whole print feels very "spongy" and is not structurally stable (twists easily).
A first layer calibration test gives inconsistent results. For a given Z-offset value, the line width varies and the final rectangle is incomplete. Will new bontech gears solve this problem? What other solutions should I explore?
Ce sujet a été modifié il y a 1 year 5 fois par RedDawg
Hear ye, Hear ye! Step right up folks and get your Government salvation here! Less than $.002 per word! Amazon.com/dp/B0B8XMMFP4
Publié : 08/12/2024 3:10 am
RedDawg
(@reddawg)
RE: Having cyclic underextrusion. Suspect bontech gear malfunction
Correct order of pictures is (last two digits in file name): 64, 65, 66, 67, 68
Publié : 08/12/2024 3:34 am
Artur5
(@artur5)
It could be several different things but, as you say,  it’s unlikely that the Bondetch gears worked fine for years and then they were worn overnight. Discarding a damaged printed part on the idler mechanism, then maybe the stepper developped a faulty coil ?, That can happen instantly, thus explaining the uneven rotation of the motor shaft and the subsequent cyclic under/over extrusion issue,
Just guessing because I’m not exactly an expert on stepper motors, but if you had a spare at hand you could check it. If I recall correctly, the extruder and the X or Y axis motors are the same model with different cable lengths, so any of these would serve for testing purposes.
Ce message a été modifié il y a 1 year par Artur5
Publié : 08/12/2024 4:19 pm
RedDawg
(@reddawg)
Don't have a spare motor to substitute. Is there a software routine to test whether a coil has developed a fault? I'm pretty sure the change in banding width and thickness is synchronous with the rotational period of the gears, so my sense is that a motor coil failure would not be periodic in this same way.
All things considered, it may be time to bite the bullet and upgrade the machine, but which upgrade path would give me the most bang for the buck? Since I already have a MK4 I probably don't need to go all the way to that. But are there upgrade kits for all the intervening steps, MK3+, MKS, MK3s+ , etc.?
Publié : 09/12/2024 4:08 am
