Hairy Einstein - Hair Prints in Mid-Air?
jazzmac251
(@jazzmac251)
Trying to print the eponymous Hairy Einstein model. Everything's going fine, but the hair keeps trying to print the wrong direction. I assume it's supposed to print starting FROM the model TO thin air, but for some reason my printer is STARTING from thin-air TO the model. Of course, this doesn't work at all and leads to print failure. I double-checked the travel paths in Slicer and, sure enough, it has the hair strands begin printing over nothing.
I'm sure there's a setting I need to flip in Prusa Slicer, but I have no idea what it is. Any thoughts?
Thanks!
Veröffentlicht : 10/11/2020 7:02 pm
jazzmac251
(@jazzmac251)
RE: Hairy Einstein - Hair Prints in Mid-Air?
Actually, it just occurred to me that this could be how it's SUPPOSED to work? It's kind of like printing little curly hairs and then attaching them to the model. Pretty cool!
Although, I don't think this is how the original model was designed. I seem to remember the original model having somewhat straight hair that needed to be styled after the print similar to the Hairy Lion model (but without the sacrificial cylinder).
Interesting!
Veröffentlicht : 10/11/2020 7:08 pm
Most of the hair models I have seen are printed with a full height 360 degree 'skirt' that surrounds the model and is the start/end point for the hair. You cut the skirt off and that leaves the hair for forming with the hair dryer/heat gun.
Diese r Beitrag wurde geändert Vor 5 years von --
Veröffentlicht : 11/11/2020 1:07 am
jazzmac251
(@jazzmac251)
@tim-m30
Yeah, this one doesn't have that. Somehow it's supposed to work without.
https://www.thingiverse.com/thing:2151104
Veröffentlicht : 11/11/2020 1:21 am
Only if you use the exact same tools he was using. Some of the comments say the process doesn't work with normal printers and slicers.
Veröffentlicht : 14/11/2020 12:44 am
Looking at the model, it is not printable on a Prusa. Each hair is ending in free space and requires support to print. Even a shroud won't help.
Veröffentlicht : 14/11/2020 12:51 am
Flo4Print
(@flo4print)
Hello, I did never try to print such stl with hairs, if this is not possible without outside support you can try to create your own with this scad tool : https://www.thingiverse.com/thing:2306455
I have just found it looking at things available with hairs after having read this topic.
MK3S & Fusion 360
Veröffentlicht : 14/11/2020 8:24 am
