Gloomhaven Insert failing
jeffrey.l9
(@jeffrey-l9)
I am printing inserts for the board game gloomhaven. While I successfully printed the first inserts using 2 pieces that are the size of the bed they now mess up. The gray one at the top is a smaller version (insert in 1/4s) of the file and prints with no issues. However, the green one at the bottom is the insert printed in half pieces that are designed to use the full MK3 bed. The Black line show where a raised spot has occurred that isn't in the slic3r or file. The walls should like like the gray one.
What would cause the issues. The print has failed in the exact same with on a different insert at the same spots. I did print the green at 5% infill, but had the issue with 10%. Both prints were done one right after the other. Thanks in advanced,
Jeff
Postato : 20/10/2018 5:50 am
