Give density instead of infill %
Hi all,
i want to print a object with a given density (0,91 - water ice). Is it possible to set a density for the whole object instead of a infill %?
Best Regards
Christian
Postato : 25/03/2019 9:07 am
Re: Give density instead of infill %
I am not aware of such setting in Slic3er. Probably not that easy to implement either because it has to take number of perimeters and bottom/top solid layers into account. But you can easily working around in an iterative process.
Once you have determined the volume of your model (in CAD for example) you can calculate the desired weight of your part. Now you can set the material density in the slicer and adjust your infill density (or basically any other setting) until your part weight equasls that weight.
Postato : 25/03/2019 1:33 pm
