Fuzzy Skin - First Fuzzy Skin layers will not stick to outer edge
Bart
 Bart
(@bart-6)
Hey guys, I am having some issues with printing a example object with the fuzzy skin settings. After the initial first solid bottom layer the fuzzy skin edge should be applied to the outer edge to the layer but it seems it will not stick to the edge. I tried adjusting the Fuzzy Skin settings but that did not help so i stick to the default fuzzy skin settings. I also tried using variable layer hight in PrusaSlicer with the hope that it would help but it seems it does no have an effect. You can see the shape of the object below but I cannot imagine that the overhang is the issue why the fuzzy skin layer cannot stick. Apart from the variable layer hight and Fuzzy Skin settings, i did not change any other default settings. I really would love to hear some suggestions as I cannot believe the solution is far off. Nonetheless I appreciate your input and thank you for a reply.
Note: The picture with the stopped print in my hand is the underside.
Layer hight: 0,3mm draft
Nozzle: 0,4mm
Opublikowany : 19/12/2024 5:09 pm
