"Fungi" and "Blobs" on otherwise perfect surface prints
Durahl
(@durahl)
Greetings!
I've recently started experimenting with CF-Nylon and, after some initial Bed Adhesion issues on the PEI ( Sticky Glue FTW ) and consistent dimensional inaccuracy ( Extrusion Multiplier changed from 1.04 to 0.7 ) one of the last challenges I've come across would be those "fungi" and "zits" appearing around the surface regardless of seam positioning.
Photos:
Video:
Slicer Extruder Settings:
Simple shapes like a Calibration Cube sure are printing flawless but anything requiring the toolhead to cross a gap has these issues... Is this perhaps a Retraction related issue or simply the nature of the material with the ~20% CF content smearing along as the nozzle crosses borders? 🤔
Postato : 15/09/2021 8:09 pm
Utenti
RE: Filament
Did you dry your filament? Nylon soaks up water.
Postato : 16/09/2021 10:30 am
Durahl
(@durahl)
I'd say I did
Sure did, the spool has been permanently residing in an eSUN eBox Filament Drying Box set to max Temp ( 50°C ) incl. a Dessicant Pouch before and during the prints 🤔
Postato : 16/09/2021 10:46 am
Utenti
Extrusion
Try lowering the Extrusion multiplier one more to 0.6 and see what happens.
Postato : 16/09/2021 10:50 am
Swiss_Cheese
(@swiss_cheese)
This is not adequate, you need 70C active drying, meaning 350watts minimum with a strong active fan circulating. run it the entire time your printing the nylon.
Good Luck
Swiss_Cheese
The Filament Whisperer
Postato : 16/09/2021 2:14 pm
Utenti
RE: Drying
I just read this again from work.  I agree with Swiss Cheese.
The bottom line, is you need more time and at least 70C if not 80C.
Posted by: @durahl
Postato : 16/09/2021 2:33 pm
Durahl
(@durahl)
Yeaa...
There's not much I can do about raising the temps in that enclosure.
I mean the manual states that the built in heater plate raises the temps to 80°C with expected actual temperatures getting circulated by the also built in (and super noisy fan ) in the 50°C but yea... Can't raise it higher than that 🤔 The Spool also arrived inflated ( or at least without a vacuum ) indicating the presence of untreated air inside but a lengthy treatment inside the dryer probably dealt with most moisture that managed to get inside.
I did though in the meantime play around with retraction settings ( like increasing them to 5mm, enabling wipe, etc... ) and reducing the temperatures back to 260°C from the previous 270° due to the higher speeds at which I'm printing while also increasing the cooling fan % and it looks like those changes were helping a fair bit with solving the problem. 🙂
Postato : 16/09/2021 3:02 pm
