Front-right corner uneven despite calibrations
3DALHEMIJA
(@3dalhemija)
Since i recieved my MK3, i got problems with tweaking first layer.
First layers of all of my prints were fine except front-right part, which makes squished (rough) layers.
I did all calibrations including bed leveling correction
Than i went for the nyloc mod, which helped a lot but still havent solved totaly.
My bed leveling variation is 0.07, which is pretty "flat", despite that my frontright first layers turned squished
Opublikowany : 10/03/2019 7:52 pm
Re: Front-right corner uneven despite calibrations
Are you still using the stock 3x3 cal ? With a bed that flat you may do better not using the autolevel function.
Opublikowany : 11/03/2019 8:26 pm
