FLOW problem in slicer.
diicasses
(@diicasses)
I set the Flow to 1 in the slicer but when it starts to print it drops down to 95. Is there anyway to fix this?
Best Answer by RandyM9:
You don’t have to delete the line, just ‘comment’ it out by placing a semi colon before the text.
See below:
; M221 S{if layer_height<0.075}100{else}95{endif}
This way, you’ll have a record of the original gcode in place and a simple way to put it back the way it was, or modify it with different values, if you find the need to.
Cheers
Publié : 01/01/2023 11:48 pm
RE: FLOW problem in slicer.
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/why-is-flow-set-to-95-as-standard/
Publié : 02/01/2023 1:38 am
Remove "M221 S{if layer_height<0.075}100{else}95{endif}" in PrusaSlicer (100% is MK2 compatible, which tended rather to under-extrude).
wbr,
Karl
Publié : 02/01/2023 2:41 pm
diicasses
(@diicasses)
Where is this located?
Posted by: @karl-herbert
wbr,
Karl
Publié : 02/01/2023 10:46 pm
You can find the gcode in the expert settings in the PrusaSlicer startup code:
wbr,
Karl
Publié : 03/01/2023 12:53 am
RandyM9
(@randym9)
See below:
Cheers
Publié : 03/01/2023 4:52 am
