Flow problem?
Michael Pierich
(@michael-pierich)
Flow problem?
I calibrated first layer- it was good but now this. Any ideas?
Postato : 21/10/2023 1:24 pm
ga
 ga
(@ga)
RE: Flow problem?
It sure looks like the nozzle is too high; for a first layer, the filament doesn't look squished enough to me.  It also looks like the nozzle temperature may be a bit high, and the filament is oozing out more than usual.  Are you using the same filament as before?
Postato : 22/10/2023 10:18 pm
Michael Pierich
(@michael-pierich)
RE: Flow problem?
Same filament.
I looked closer and found a lot of deposits on the outside of the nozzle. After cleaning it does a lot better (recalibrated) but still picks up some strands on the second pass.
I ordered new nozzle so I'll change it anyway and see what happens. Thanks!
Postato : 22/10/2023 10:51 pm
