        Flow problem?
I calibrated first layer- it was good but now this. Any ideas?
                            Posted : 21/10/2023 1:24 pm
                    RE: Flow problem?
It sure looks like the nozzle is too high; for a first layer, the filament doesn't look squished enough to me. It also looks like the nozzle temperature may be a bit high, and the filament is oozing out more than usual. Are you using the same filament as before?
                            Posted : 22/10/2023 10:18 pm
                    Topic starter
 answered:
                        RE: Flow problem?
Same filament.
I looked closer and found a lot of deposits on the outside of the nozzle. After cleaning it does a lot better (recalibrated) but still picks up some strands on the second pass.
I ordered new nozzle so I'll change it anyway and see what happens. Thanks!
                            Posted : 22/10/2023 10:51 pm
