First time printing PETG and getting some odd overhangs
Shogunjp
(@shogunjp)
hey all!
Have had my MK3S+ For about a month, and am trying to print something in PETG for the first time, and I am seeing some of these weird artifacts on the print.. looks like I will be able to nip them off, but was wondering if anyone had an idea of why it’s happening
sliced 0.2mm, nozzle: 240C, bed 90C, Filament: HatchBox PETG
Opublikowany : 06/09/2021 12:11 am
RE: First time printing PETG and getting some odd overhangs
We always expect a little more stringing with PETG but recently the humid weather here has made it much worse.  With long (30+hour) prints I can see deterioration worsen towards the end of the print 'though the first few layers (after drying) are fine...
This behaviour is expected with nylon, I hope this is just a temporary problem.
Some of your strings look like those expected from PETG, some look like humidity symptoms.
I suggest you try drying the filament before each use and printing your project one part at a time.  If this helps then you may need to print PETG from a drybox, at least until the weather changes.
Opublikowany : 06/09/2021 9:22 am
Yeah, as @diem said, what's happening is... PETG. Love PETG, print it a lot more than other filaments, but if it captures moisture, all hell breaks loose.
Opublikowany : 06/09/2021 11:36 am
