First time PETG/trouble using LACK Enclosure v2 gcode
mektek21
(@mektek21)
Hello, I have had my printer (i3 MK3S) about two months, and have only been printing PLA so far. I wanted to start printing the v2 enclosure published by Prusa: https://blog.prusaprinters.org/mmu2s-printer-enclosure/ as well as replacement parts.
I was able to get the 1st layer calibration done using PET, but any actual print I've tried to do has had a lot of issues with plate adhesion/blobbing on nozzle. I have tried adjusting temps up and down with no good result.
Opublikowany : 11/05/2020 6:57 pm
JM
 JM
(@jm-2)
RE: First time PETG/trouble using LACK Enclosure v2 gcode
I'm print the same right now as well. The supplied gcode just would not work for me. First layer looked like yours. I ended up reslicing it for slower speeds and it's working well so far.
But I suppose you could lower the speed on the printer, at least for the first few layers, and still use their gcode.
Opublikowany : 14/05/2020 5:52 pm
