First Layer Problems
I recently changed my nozzle, and decided to print some parts for the enclosure with PETG on the textured sheet. I am currently trying to print the left side sheet holder and I am having trouble with the first layer, and printing this part in general. In the pictures below, I am having this adhesion issue with the first layer. These wrinkles form for some reason. Then the second layer is having flow? issues as well, so I stopped the print. What do you think the issue is? I have already tried cleaning it with alcohol, and I am still having issues.
Print settings: 0.30mm Draft, 15% infill. default Prusa PETG settings
Current Belt tensions: X:263, Y:276
Current Z: -1.957
Best Answer by Diem:
Your first layer 'Z' is a fraction too low but it should print OK even if that face is not perfect. If you have been tweaking the extrusion multiplier, reset it.
Scrub your print-sheet with dishwashing detergent and HOT water.
RE: First Layer Problems
Thanks for the help. That did the trick!
