First layer problem after firmware update 3.11.0
Ratthy
(@ratthy)
For a few years, I was printing correctly without any trouble. Now I have trouble with my first layer.
This image is from a old print that I have made last year.
after that I have made the update to 3.11.0, I have started to have problem, the PLA was not sticking on the print plate at some place. I have made some deep cleaning of my plate, and same thing.
i have redefined my first layer, and I have finally made a print, but the first layer have this strange pattern.
i have try a small print, and adjusted the first layer, lowering it a bit.
‘now the first layer is better, but my top layer is textured.
after seeing this, I have check my previous box, and in the bottom is not strait (thin wall without infill).
I’m not sure what to check next. If I check my first box printed, if I check the edge, I think my first layer is ok, maybe a bit low, but the center seem too high. I have print a box and his cover in the same time, and all the edge is ok, but only the center of the print that seem too high.
Opublikowany : 19/09/2022 11:35 pm
Your first layer is calibrated too low, raise it until the patterns *just* disappear.
Top layer patterns similar to this are sometimes a symptom of damp filament.
Opublikowany : 20/09/2022 12:39 am
Ratthy
(@ratthy)
RE: First layer problem after firmware update 3.11.0
On my last print, this is what I was thinking, this was a try to remove my wave on the previous print. Even on this one I think my print is too low, but if I go up, it does not stick on the plate at some place.
Opublikowany : 20/09/2022 9:23 am
Look up threads here about cleaning the build plate.
Opublikowany : 20/09/2022 11:22 am
Ratthy
(@ratthy)
I have wash the plate with dish soap, and with isopropanol.
but this will not give me wave in my first print. I have this wave all the time in my first layer.
Opublikowany : 20/09/2022 8:12 pm
Opublikowany : 20/09/2022 11:33 pm
Ratthy
(@ratthy)
I will try, not sure this will work, because when I have some problem with the adhesion, the wave pattern was also present. Maybe the adhesion problem was due to this patterns.
But I found strange that this have started after the firmware update.
I will also check if I have the same trouble with an other color. I have change my PLA lately, but I will find it strange, I have finish 2 roll of this company without any problem. I still have some roll from my previous supplier.
Opublikowany : 21/09/2022 10:04 am
Ratthy
(@ratthy)
Finally, with many test this morning, I have almost a perfect first layer.
you was almost correct, I was too low. But also, I have always print with the default temperature, now I have to reduce my print temperature by 20 degrees.
now trying with TPU if I have to change also my setting.
Opublikowany : 25/09/2022 5:42 pm
