First layer problem
Hello, I have problems printing larger areas on Prusa i3 MK3 as the first layer does not seem to be consistent.
I had successfully calibrated it. The bed is clean. As you see on the image, the brim is sticking well almost everywhere, but there are some areas (orange), where it is bending upward. Later the head collides it.
The material is Fiberlogy HD PLA, gcode is generated by Prusa Control using Prusa PLA setting.
How to avoid this? Is the Z-adjustment too low/high or temperature (215 C) is not optimal?
Publié : 01/06/2018 4:38 pm
