first layer problem
3d.ae
(@3d-ae)
first layer problem
hi
i facing a problem with the filament not sticking the bed as shown in the pic
i have tried to calibrate the first layer but as soon as i start any print it end up as the pic i have uploaded
please help me to solve it
Opublikowany : 05/08/2018 12:41 am
Gato
 Gato
(@gato)
Re: first layer problem
If you haven't seen this thread https://shop.prusa3d.com/forum/-f6/life-adjust-z-my-way-t2981.html , that is the best way to make sure your live z is correctly tuned.
Also make sure that the bed is correctly cleaned up. Once these 2 things are take care of, things will work fine.
Opublikowany : 05/08/2018 1:05 am
3d.ae
(@3d-ae)
hi there
i have followed the the link and got good result on small prints but when it comes a bigger print i found that the filament sticks nicely in some places and doesn't stick in other so, what i have to do to fix that ?
thanks
Opublikowany : 17/08/2018 1:17 am
Kai
 Kai
(@kai-2)
Hello ibrahim,
did you already try to clean the Printbed/Steel sheet?
If your first Layer Calibration is (quite) ok, it is possible that you have some kind of grease etc. on the flexplate.
Even touching it could be enough to cause adhesion "problems".
Give it a good wash with disch washing liquid and dry it with a paper towel.
Greetings Kai
nec aspera terrent
Opublikowany : 17/08/2018 11:29 am
Hi Ibrahim,
for larger prints you sometimes have to adjust settings for the edges of the bed
these adjustments can be found in the calibration menu on the LCD
under the Bed Level Correction option
you can adjust up to +50 micron or - 50 micron as required.
Opublikowany : 17/08/2018 12:12 pm
