First layer (noob) issues !
Casper Grasp
(@casper-grasp)
Miembro
Hey there,
Sorry for this, as it's been asked many times, I guess.
I'm a  French noob at hardware and software settings : I have a second hand MK3S and I use Prusa Slicer.
I have many different and random results on my first layers.
Here's a picture of my First Layer test
and the screens of some of my Slicer settings.
Thanks for any advice !
Respondido : 23/09/2024 3:02 pm
Robin
(@robin)
RE: First layer (noob) issues !
Is the printer stock version or has it been modified in any way?
Get yourself a filament that has a profile in slicer already (prusa, prusament, Verbatim, Filamentum ect..) and print with the default settings for everything and use 0.2mm quality setting.
Respondido : 25/09/2024 11:09 am
Casper Grasp me gusta
Robin
(@robin)
If you want people to see your settings, save, zip and post your slicer project. Screenshots are difficult to read (especally when everthing is in French - at least for me 🙂 ) and do not contain every setting. The slicer-project file does contain everything and is diplayed in the local language when loaded by somebody else... (You need to zip-compress before attaching it to your post with the button below the textbox, otherwise the forum software will ignore it)
Respondido : 25/09/2024 11:12 am
Casper Grasp
(@casper-grasp)
Miembro
Thanks a lot, Robin.
My MK3S is a stock version but it's a second hand : I bought it from a friend, couple of months ago.
I just changed the noozle and the fan shroud as I had some issues : some of the melted filament was kinda leaking from the extruder... I just read someone with the same issue on the forum... Should I change the whole extruder ? Please, no ! Ah ah ah
Sometimes, I have some big filament marshmalows stuck around the extruder head... That's bad, isnt' it ?...
I have some Prusament but I sometimes have random results with it too.
When I changed the noozle, couple of weeks ago, the head seemed a bit loose to me, even once I set it back in its intial position. I don't know if it's normal or if it's what can cause these random leaks...
I'm such a noob ah ! 🙂
Thanks again for your time and advices.
Merci beaucoup !
Respondido : 25/09/2024 12:11 pm
