First layer curling
I have an issue where my first layer curls up from the bed on PLA prints. This usually happens on the right side of the print.
I already tried several things to try to solve it, but they didn't help:
- I ran the full setup again to re-level the bed.
- I also tried a hotter bed temp and a lower bed temp and changing the hot-end temp
- I also tried printing with and without glue stick.
- I tried the old hotend and the new one where the fan is angled.
Re: First layer curling
if the curling appears always on the same area, it looks like your bed is not in level. it's visible at the rights side the lines are not squished to the bed.
but you can try printing the 1st layer slower and maybe print it thicker (200%?)
Assuming no hardware problems, there are several likely culprits:
It's hard to see much in your pic,
Thanks, that was it 😀
How do you do a 'cold' pull? I'm thinking I might have this problem also.
Rather than repeat the detailed process, I've compiled my notes here. Basically, you melt some material in the hotend, let it cool, re-heat and remove the filament when it's just softening. This will help trap and remove gunk in the pulled filament. You can find some variations by searching on the web.
Thank you, I hadn't heard of that yet. I've marked your page for additional references and will give that a try to see if it helps me.
